/*		Multichannel_ADC_DMA.ino
  Modositva kapu48    2019. 01.
  This example shows how to use the ADC multichannel (scan), single conversion mode.
  A scan of all the channels is triggered by a timer interrupt so the sample time is
  regular and predictable. The DMA then transfers the data into a buffer.
  Since the ADC conversion and transfer to the buffer do not require the main processor,
  it is kept free to service other tasks and do useful work on the data.
  When testing different configurations and sample rates, keep an eye on the timer and
  DMA ISR counts. If the timer interrupts faster than the ADC/DMA then these values 
  will get out of sync. At high sample rates they may be out by a few counts as they
  get updated in between reading the values, but they shouldn't drift further apart
  the longer the sketch runs.
#include "libmaple/dma.h"
static const uint8_t LED = PC13;
static const uint32_t SAMPLE_FREQ = 50000;
//static const uint8_t adc_pins[] = {PA0,PA1,PA2,PA3,PA4,PA5,PA6,PA7};
static const uint8_t adc_pins[] = {PA0,PA1,PA2};
static const uint8_t num_adc_pins = sizeof(adc_pins)/sizeof(adc_pins[0]);
static const uint8_t num_adc_repeat = 32;
static const uint8_t num_adc_buffer = num_adc_pins * num_adc_repeat;
volatile bool transfer_complete = false;
volatile uint16_t next_sample_time = 0;
//volatile uint32_t dma_isr_count = 0;
//volatile uint32_t timer_isr_count = 0;
//uint16_t adc_buffer[num_adc_pins];
uint16_t adc_buffer[num_adc_buffer];
HardwareTimer timer(2);
void set_adc(adc_dev* dev);
void set_adc_channels(adc_dev* dev, const uint8_t* pins, uint8_t length);
void set_dma(uint16_t* buf, uint16_t bufLen, uint32_t dmaFlags, voidFuncPtr func);
void set_timer(HardwareTimer* timer, voidFuncPtr func);
void setup()
  Serial1.begin(115200);
  pinMode(LED, OUTPUT);
  for(uint8_t i = 0; i < num_adc_pins; i++)
    pinMode(adc_pins[i], INPUT_ANALOG);
  delay(500);    // wait for the serial console window
  // set the dma first
  //set_dma(adc_buffer, num_adc_pins, (DMA_CCR_MINC | DMA_CCR_CIRC | DMA_TRNS_CMPLT), DMA1_CH1_isr);
  set_dma(adc_buffer, num_adc_buffer, (DMA_CCR_MINC | DMA_CCR_CIRC | DMA_TRNS_CMPLT), DMA1_CH1_isr);
  set_adc(ADC1);
  start_conversion(ADC1);          // start the first adc conversion
  set_timer(&timer, timer_isr);    // start the timer for the next conversion
//  Serial.println("Sample,CH0,CH1,CH2,CH3,CH4,CH5,CH6,CH7");
  Serial1.println("Sample,CH0,CH1,CH2");	
void loop()
//  static uint32_t dma_count;
//  static uint32_t timer_count;
  static uint32_t sumADC[num_adc_pins];
  // Store these values as they will update while we are trying to print them
//  dma_count = dma_isr_count;
//  timer_count = timer_isr_count;
//  Serial1.print(dma_count);
//  Serial1.print(':');
//  Serial1.print(timer_count);
  for(uint8_t i = 0; i < num_adc_pins; i++){
    sumADC[i] = 0;
  for(uint8_t i = 0; i < num_adc_buffer; i++)
//    Serial1.print(i);
//    Serial1.print(": ");
//    Serial1.print(adc_buffer[i]);    
    sumADC[0] += adc_buffer[i++];
//    Serial1.print(", ");
    sumADC[1] += adc_buffer[i++];
//    Serial1.println(adc_buffer[i]);    
    sumADC[2] += adc_buffer[i];
//  Serial1.print("Sum: ");
    Serial1.print(i);
    Serial1.print(sumADC[i]/num_adc_repeat);
    Serial1.print(" , "); 
  Serial1.println();
//Serial1.println();
  digitalWrite(LED, !digitalRead(LED));
  delay(1000);
    Interrupt handlers
static void DMA1_CH1_isr() {
  transfer_complete = true;
  //++dma_isr_count;
static void timer_isr()
  //++timer_isr_count;
  timer.setCompare(TIMER_CH1, ++next_sample_time);  // set next sample time
  adc_calibrate(dev);
  //adc_set_sample_rate(dev, ADC_SMPR_1_5);
  adc_set_sample_rate(dev, ADC_SMPR_41_5);
  set_adc_channels(dev, adc_pins, num_adc_pins);
  dev->regs->CR2 |= ADC_CR2_DMA;     //enable ADC DMA transfer
  dev->regs->CR1 |= ADC_CR1_SCAN;    //Set the ADC in Scan Mode
void set_adc_channels(adc_dev* dev, const uint8_t* pins, const uint8_t num_pins)
   * From libraries/STM32ADC/src/utility/util_adc.c
  uint8_t channels[num_pins];
  uint32_t records[3] = {0,0,0};
  //convert from pins to channels
  for (uint8_t i = 0; i < num_pins; i++)
    channels[i] = PIN_MAP[pins[i]].adc_channel;
  //write the length
  records[2] |= (num_pins - 1) << 20;
  //i goes through records, j goes through variables.
  for (uint8_t i = 0, j = 0; i < num_pins; i++)
      if ((i != 0) && (i%6 == 0))
        j++;
      records[j] |= (channels[i] << ((i%6)*5));
  //update the registers inside with the scan sequence.
  dev->regs->SQR1 = records[2];
  dev->regs->SQR2 = records[1];
  dev->regs->SQR3 = records[0];
void start_conversion(adc_dev* dev)
  dev->regs->CR2 |= ADC_CR2_SWSTART;
void set_dma(uint16_t* buf, uint16_t bufLen, uint32_t dmaFlags, voidFuncPtr func) {
  dma_init(DMA1);
  if (func != NULL) {
    dma_attach_interrupt(DMA1, DMA_CH1, func);
  dma_setup_transfer(
    DMA1,
    DMA_CH1,
    &ADC1->regs->DR,
    DMA_SIZE_16BITS,
    buf,
    DMA_SIZE_16BITS,
    dmaFlags
  dma_set_num_transfers(DMA1, DMA_CH1, bufLen);
  dma_enable(DMA1, DMA_CH1);
  timer->pause();
  timer->setPrescaleFactor(72000000u / SAMPLE_FREQ);
  timer->setOverflow(65535);
  timer->setMode(TIMER_CH1, TIMER_OUTPUT_COMPARE);
  timer->setCompare(TIMER_CH1, 1);  // initial compare value for the timer
  next_sample_time = 1;             // sync next_sample_time with the compare value
  if (func != NULL)
    timer->attachInterrupt(TIMER_CH1, func);
  timer->refresh();
  timer->resume();
