<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.2.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.0125" unitdist="mm" unit="mm" style="lines" multiple="1" display="no" altdistance="5" altunitdist="mil" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="no" active="no"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="65" y2="0" width="0" layer="20"/>
<wire x1="65" y1="0" x2="65" y2="78" width="0" layer="20"/>
<wire x1="65" y1="78" x2="0" y2="78" width="0" layer="20"/>
<wire x1="0" y1="78" x2="0" y2="0" width="0" layer="20"/>
<wire x1="37.75" y1="54.825" x2="37.7375" y2="54.4" width="1.8" layer="29"/>
<wire x1="37.7375" y1="54.4" x2="37.1625" y2="53.8875" width="1.8" layer="29"/>
<wire x1="37.1625" y1="53.8875" x2="35.4625" y2="53.8875" width="1.8" layer="29"/>
<wire x1="35.4625" y1="53.8875" x2="34.75" y2="53.0875" width="1.8" layer="29"/>
<wire x1="34.75" y1="53.0875" x2="34.75" y2="49.5375" width="1.8" layer="29"/>
<wire x1="45.375" y1="51.325" x2="45.375" y2="65.0375" width="1.016" layer="30"/>
<wire x1="55.55" y1="51.325" x2="55.55" y2="65.0125" width="1.016" layer="30"/>
<wire x1="42.7625" y1="36.8625" x2="42" y2="37.625" width="1.016" layer="29"/>
<wire x1="42" y1="37.625" x2="42" y2="39.4" width="1.016" layer="29"/>
<wire x1="48.2375" y1="37.5" x2="48.2375" y2="34.65" width="1.3" layer="29"/>
<wire x1="49.5875" y1="48.9875" x2="44.1125" y2="48.9875" width="1.3" layer="29"/>
<wire x1="44.1125" y1="48.9875" x2="44.1125" y2="46.225" width="1.3" layer="29"/>
<wire x1="44.1125" y1="46.225" x2="38.6125" y2="40.725" width="1.3" layer="29"/>
<wire x1="38.6125" y1="40.725" x2="38.6125" y2="37.35" width="1.3" layer="29"/>
<wire x1="44.45" y1="36.4875" x2="43.225" y2="36.4875" width="1.3" layer="29"/>
<wire x1="43.225" y1="36.4875" x2="42.0125" y2="37.7" width="1.3" layer="29"/>
<wire x1="42.0125" y1="37.7" x2="42.0125" y2="39.8875" width="1.3" layer="29"/>
<wire x1="42.0125" y1="39.8875" x2="43.6" y2="41.475" width="1.3" layer="29"/>
<wire x1="43.6" y1="41.475" x2="44.9875" y2="41.475" width="1.3" layer="29"/>
<wire x1="44.9875" y1="41.475" x2="46.9125" y2="43.4" width="1.3" layer="29"/>
<wire x1="46.9125" y1="43.4" x2="46.9125" y2="48.9625" width="1.3" layer="29"/>
<wire x1="55.5625" y1="50.25" x2="55.5625" y2="68.3375" width="1.3" layer="29"/>
<wire x1="55.5625" y1="68.3375" x2="53.5375" y2="70.3625" width="1.3" layer="29"/>
<wire x1="53.5375" y1="70.3625" x2="25.3875" y2="70.3625" width="1.3" layer="29"/>
<wire x1="25.3875" y1="70.3625" x2="23.9875" y2="68.9625" width="1.3" layer="29"/>
<wire x1="23.9875" y1="68.9625" x2="23.9875" y2="67.5875" width="1.3" layer="29"/>
<wire x1="45.375" y1="51.3375" x2="45.375" y2="65.0375" width="1.3" layer="29"/>
<wire x1="40.225" y1="64.1625" x2="40.225" y2="61.8625" width="1.3" layer="29"/>
<wire x1="40.225" y1="61.8625" x2="41.925" y2="60.1625" width="1.3" layer="29"/>
<wire x1="41.925" y1="60.1625" x2="41.925" y2="57.0875" width="1.3" layer="29"/>
<wire x1="41.925" y1="57.0875" x2="41.925" y2="55.075" width="1.3" layer="29"/>
<wire x1="43.7" y1="59.425" x2="43.7" y2="57.5375" width="1.3" layer="29"/>
<wire x1="43.7" y1="57.5375" x2="43.25" y2="57.0875" width="1.3" layer="29"/>
<wire x1="43.25" y1="57.0875" x2="41.925" y2="57.0875" width="1.3" layer="29"/>
<wire x1="38.5125" y1="60.175" x2="38.5125" y2="56.55" width="1.3" layer="29"/>
<wire x1="38.5125" y1="56.55" x2="38.425" y2="56.4625" width="1.3" layer="29"/>
<wire x1="38.425" y1="56.4625" x2="38.425" y2="55.375" width="1.3" layer="29"/>
<wire x1="23.2" y1="60.2" x2="22.525" y2="60.2" width="1.016" layer="29"/>
<wire x1="22.525" y1="60.2" x2="21.3875" y2="59.0625" width="1.016" layer="29"/>
<wire x1="21.3875" y1="59.0625" x2="21.3875" y2="49.3125" width="1.016" layer="29"/>
<wire x1="21.3875" y1="49.3125" x2="23.375" y2="47.325" width="1.016" layer="29"/>
<wire x1="23.375" y1="47.325" x2="23.375" y2="46.15" width="1.016" layer="29"/>
<wire x1="18.4875" y1="39.35" x2="20.975" y2="39.35" width="1.016" layer="29"/>
<wire x1="20.975" y1="39.35" x2="23.3875" y2="41.7625" width="1.016" layer="29"/>
<wire x1="23.3875" y1="41.7625" x2="23.3875" y2="42.625" width="1.016" layer="29"/>
<wire x1="24.6625" y1="44.4" x2="26.3625" y2="44.4" width="1.016" layer="29"/>
<wire x1="28.8125" y1="44.9375" x2="29.4125" y2="45.5375" width="1.016" layer="29"/>
<wire x1="29.4125" y1="45.5375" x2="39.325" y2="45.5375" width="1.016" layer="29"/>
<wire x1="39.325" y1="45.5375" x2="42.0875" y2="48.3" width="1.016" layer="29"/>
<wire x1="42.0875" y1="48.3" x2="43.6125" y2="48.3" width="1.016" layer="29"/>
<wire x1="44.1875" y1="38.825" x2="48.3125" y2="38.825" width="1.3" layer="29"/>
<wire x1="40.95" y1="24.25" x2="40.9625" y2="36.1125" width="0.508" layer="29"/>
<wire x1="40.9625" y1="36.1125" x2="40.35" y2="36.725" width="0.508" layer="29"/>
<wire x1="40.35" y1="36.725" x2="40.3625" y2="40.3375" width="0.508" layer="29"/>
<wire x1="40.3625" y1="40.3375" x2="43.0625" y2="43.0375" width="0.508" layer="29"/>
<wire x1="43.0625" y1="43.0375" x2="44.1625" y2="43.0375" width="0.508" layer="29"/>
<wire x1="44.1625" y1="43.0375" x2="45.575" y2="44.45" width="0.508" layer="29"/>
<wire x1="45.575" y1="44.45" x2="45.575" y2="49" width="0.508" layer="29"/>
<wire x1="45.575" y1="49" x2="45.5625" y2="49.0125" width="0.508" layer="29"/>
<wire x1="37.6125" y1="42.2875" x2="37.8625" y2="42.2875" width="0.508" layer="29"/>
<wire x1="37.8625" y1="42.2875" x2="42.8875" y2="47.3125" width="0.508" layer="29"/>
<wire x1="42.8875" y1="47.3125" x2="42.8875" y2="48.1125" width="0.508" layer="29"/>
<wire x1="19.35" y1="47.5375" x2="21.775" y2="45.1125" width="0.508" layer="29"/>
<wire x1="21.775" y1="45.1125" x2="22.5375" y2="45.1125" width="0.508" layer="29"/>
<wire x1="19.3375" y1="47.55" x2="19.3375" y2="56.3375" width="0.508" layer="29"/>
<wire x1="19.3375" y1="56.3375" x2="18.6" y2="57.075" width="0.508" layer="29"/>
<wire x1="18.6" y1="57.075" x2="18.2875" y2="57.075" width="0.508" layer="29"/>
<text x="50.425" y="41.65" size="1.27" layer="25" font="vector" ratio="10" rot="R90">R34-5</text>
<text x="49.025" y="41.65" size="1.27" layer="25" font="vector" ratio="10" rot="R90">R37-8</text>
<text x="63.0125" y="37.15" size="1.778" layer="1" font="vector" rot="R90">http://www.eevblog.com</text>
<text x="63.0125" y="64.325" size="1.778" layer="16" font="vector" rot="MR270">http://www.eevblog.com</text>
<text x="23.5625" y="48.4875" size="1.016" layer="21" font="vector" ratio="10">J1</text>
</plain>
<libraries>
<library name="MCP3204">
<packages>
<package name="TSSOP14" urn="urn:adsk.eagle:footprint:20706/1" locally_modified="yes">
<description>&lt;b&gt;14-Lead Plastic Thin Shrink Small Outline (ST)&lt;/b&gt; - 4.4 mm Body  TSSOP &lt;/b&gt;&lt;p&gt;
Source: http://ww1.microchip.com/downloads/en/DeviceDoc/40039E.pdf</description>
<wire x1="2.455" y1="-2.15" x2="-2.455" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.455" y1="-2.15" x2="-2.455" y2="2.15" width="0.2032" layer="21"/>
<wire x1="2.455" y1="2.15" x2="2.455" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.455" y1="2.15" x2="2.455" y2="2.15" width="0.2032" layer="21"/>
<circle x="-1.825" y="-1.525" radius="0.375" width="0" layer="21"/>
<smd name="1" x="-1.95" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="2" x="-1.3" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="3" x="-0.65" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="4" x="0" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="5" x="0.65" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="6" x="1.3" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="7" x="1.95" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="8" x="1.95" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="9" x="1.3" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="10" x="0.65" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="11" x="0" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="12" x="-0.65" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="13" x="-1.3" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="14" x="-1.95" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<text x="-3.15" y="-2.85" size="1.27" layer="25" font="vector" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.1" y="-3.15" size="1.27" layer="27" font="vector" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1" y1="-3.2" x2="-1.8" y2="-2.225" layer="51"/>
<rectangle x1="-1.45" y1="-3.2" x2="-1.15" y2="-2.225" layer="51"/>
<rectangle x1="-0.8" y1="-3.2" x2="-0.5" y2="-2.225" layer="51"/>
<rectangle x1="-0.15" y1="-3.2" x2="0.15" y2="-2.225" layer="51"/>
<rectangle x1="0.5" y1="-3.2" x2="0.8" y2="-2.225" layer="51"/>
<rectangle x1="1.15" y1="-3.2" x2="1.45" y2="-2.225" layer="51"/>
<rectangle x1="1.8" y1="-3.2" x2="2.1" y2="-2.225" layer="51"/>
<rectangle x1="1.8" y1="2.225" x2="2.1" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="1.15" y1="2.225" x2="1.45" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="0.5" y1="2.225" x2="0.8" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="-0.15" y1="2.225" x2="0.15" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="-0.8" y1="2.225" x2="-0.5" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="-1.45" y1="2.225" x2="-1.15" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="-2.1" y1="2.225" x2="-1.8" y2="3.2" layer="51" rot="R180"/>
</package>
</packages>
<packages3d>
<package3d name="TSSOP14" urn="urn:adsk.eagle:package:20830/2" locally_modified="yes" type="model">
<description>14-Lead Plastic Thin Shrink Small Outline (ST) - 4.4 mm Body  TSSOP
<packageinstances>
<packageinstance name="TSSOP14"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="MCP4922">
<packages>
<text x="-2.6" y="-2.6" size="1.27" layer="25" font="vector" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.9" y="-3.25" size="1.27" layer="27" font="vector" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<packageinstances>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="LM341T-5.0:NOPB">
<packages>
<package name="TO220V" urn="urn:adsk.eagle:footprint:8085814/1" locally_modified="yes">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="51"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="51"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="51"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="51"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="51"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="51"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="51"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="51"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="51"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="51"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="51"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="TO220V" urn="urn:adsk.eagle:package:8089447/1" locally_modified="yes" type="box">
<packageinstances>
<packageinstance name="TO220V"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="MCP1700-3302E:TO">
<packages>
<package name="TO-92" urn="urn:adsk.eagle:footprint:8085814/1" locally_modified="yes">
<wire x1="-2.0746" y1="-2.171" x2="-2.6349" y2="-0.774" width="0.127" layer="21" curve="-32.78104"/>
<wire x1="-2.6349" y1="-0.774" x2="-0.7663" y2="2.0285" width="0.127" layer="21" curve="-78.318477"/>
<wire x1="0.8063" y1="2.0284" x2="2.1145" y2="-2.171" width="0.127" layer="21" curve="-111.09954"/>
<wire x1="-2.0745" y1="-2.171" x2="2.1145" y2="-2.171" width="0.127" layer="51"/>
<wire x1="-2.2337" y1="-0.774" x2="-0.2663" y2="-0.774" width="0.127" layer="51"/>
<wire x1="-2.6349" y1="-0.774" x2="-2.2337" y2="-0.774" width="0.127" layer="21"/>
<wire x1="-0.2663" y1="-0.774" x2="0.3063" y2="-0.774" width="0.127" layer="21"/>
<wire x1="2.2737" y1="-0.774" x2="2.6749" y2="-0.774" width="0.127" layer="21"/>
<wire x1="0.3063" y1="-0.774" x2="2.2737" y2="-0.774" width="0.127" layer="51"/>
<wire x1="-0.7663" y1="2.0285" x2="0.8063" y2="2.0285" width="0.127" layer="51" curve="-34.293591"/>
<pad name="3" x="1.29" y="-0.52" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="0.02" y="1.385" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="1" x="-1.25" y="-0.52" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="3.195" y="0.115" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="3.195" y="-1.79" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<packageinstances>
<packageinstance name="TO-92"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="NJM14558D">
<packages>
<package name="DIL8" urn="urn:adsk.eagle:footprint:20613/1">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type P</description>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="5.08" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90" first="yes"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.2578" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.239" y="-2.54" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="DIL8" urn="urn:adsk.eagle:package:20796/2" type="model">
<description>Dual In Line
<packageinstances>
<packageinstance name="DIL8"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="MAX4080F">
<packages>
<package name="SOIC8" urn="urn:adsk.eagle:footprint:15990/1" locally_modified="yes">
<description>&lt;b&gt;Small Outline IC&lt;/b&gt;</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" font="vector" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" font="vector" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="SOIC8" urn="urn:adsk.eagle:package:16057/2" locally_modified="yes" type="model">
<description>Small Outline IC</description>
<packageinstances>
<packageinstance name="SOIC8"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="MAX4238ASA+">
<packages>
<package name="8-SO">
<smd name="P$1" x="-1.905" y="-2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$2" x="-0.635" y="-2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$3" x="0.635" y="-2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$4" x="1.905" y="-2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$5" x="1.855" y="2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$6" x="0.635" y="2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$7" x="-0.635" y="2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$8" x="-1.905" y="2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<wire x1="2.5" y1="2" x2="-2.5" y2="2" width="0.127" layer="51"/>
<wire x1="-2.5" y1="2" x2="-2.5" y2="-2" width="0.127" layer="51"/>
<wire x1="-2.5" y1="-2" x2="2.5" y2="-2" width="0.127" layer="51"/>
<wire x1="2.5" y1="-2" x2="2.5" y2="2" width="0.127" layer="51"/>
<circle x="-2.05" y="-1.45" radius="0.206153125" width="0.127" layer="51"/>
<wire x1="-2.5" y1="2" x2="-2.5" y2="-2" width="0.127" layer="21"/>
<circle x="-2.9" y="-1.85" radius="0.206153125" width="0.127" layer="21"/>
<wire x1="2.5" y1="2" x2="2.5" y2="-2" width="0.127" layer="21"/>
<text x="-3.15" y="3.9" size="1.27" layer="21" font="vector" ratio="10">&gt;NAME</text>
<text x="-3.45" y="-5.2" size="1.27" layer="21" font="vector" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="LT3083">
<packages>
<package name="TO220-5" urn="urn:adsk.eagle:footprint:15991/1">
<description>&lt;b&gt;TO220-5&lt;/b&gt;</description>
<wire x1="-1.87" y1="-0.2" x2="-1.87" y2="-0.3" width="0.0508" layer="51"/>
<wire x1="-1.87" y1="-0.4" x2="-1.87" y2="-0.5" width="0.0508" layer="51"/>
<wire x1="-1.87" y1="-0.6" x2="-1.87" y2="-0.7" width="0.0508" layer="51"/>
<wire x1="-1.87" y1="-1" x2="-1.87" y2="-1.17" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-1.17" x2="1.87" y2="-1" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-0.9" x2="1.87" y2="-0.8" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-0.7" x2="1.87" y2="-0.6" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-0.5" x2="1.87" y2="-0.4" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-0.3" x2="1.87" y2="-0.2" width="0.0508" layer="51"/>
<wire x1="-5" y1="-0.1" x2="-5" y2="-1.2" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="-1.2" x2="-4.9" y2="-3.6" width="0.2032" layer="51"/>
<wire x1="-4.9" y1="-3.6" x2="-4.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-4.5" x2="4.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="4.5" y1="-4.5" x2="4.9" y2="-3.6" width="0.2032" layer="51"/>
<wire x1="4.9" y1="-3.6" x2="4.9" y2="-1.2" width="0.2032" layer="51"/>
<wire x1="5" y1="-1.2" x2="5" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="5" y1="-0.1" x2="-5" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="-5" y1="-1.2" x2="5" y2="-1.2" width="0.2032" layer="21"/>
<wire x1="-1.87" y1="-0.8" x2="-1.87" y2="-0.9" width="0.0508" layer="51"/>
<wire x1="-4.9" y1="-3.6" x2="4.9" y2="-3.6" width="0.2032" layer="51"/>
<pad name="2" x="-1.7" y="-4.5" drill="0.9" shape="long" rot="R90"/>
<pad name="4" x="1.7" y="-4.5" drill="0.9" shape="long" rot="R90"/>
<pad name="1" x="-3.4" y="-8.4" drill="0.9" shape="long" rot="R90"/>
<pad name="3" x="0" y="-8.4" drill="0.9" shape="long" rot="R90"/>
<pad name="5" x="3.4" y="-8.4" drill="0.9" shape="long" rot="R90"/>
<text x="-5.08" y="-8.382" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="6.35" y="-8.382" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-3.8" y1="-8.6" x2="-3" y2="-7.5" layer="51"/>
<rectangle x1="-0.4" y1="-8.6" x2="0.4" y2="-7.5" layer="51"/>
<rectangle x1="3" y1="-8.6" x2="3.8" y2="-7.5" layer="51"/>
<rectangle x1="-3.8" y1="-7.5" x2="-3" y2="-4.5" layer="51"/>
<rectangle x1="-0.4" y1="-7.5" x2="0.4" y2="-4.5" layer="51"/>
<rectangle x1="3" y1="-7.5" x2="3.8" y2="-4.5" layer="51"/>
<rectangle x1="-2.1" y1="-4.7" x2="-1.3" y2="-4.5" layer="51"/>
<rectangle x1="1.3" y1="-4.7" x2="2.1" y2="-4.5" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="TO220-5" urn="urn:adsk.eagle:package:16056/1" type="box">
<description>TO220-5</description>
<packageinstances>
<packageinstance name="TO220-5"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="SB540E-G">
<packages>
<package name="DO201-15" urn="urn:adsk.eagle:footprint:43127/1" locally_modified="yes">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 5.6 mm, horizontal, grid 15.24 mm</description>
<wire x1="-5.08" y1="-2.794" x2="-5.08" y2="2.794" width="0.1524" layer="51"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="51"/>
<wire x1="5.08" y1="-2.794" x2="-5.08" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="7.62" y1="0" x2="6.223" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.223" y2="0" width="1.27" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.4986" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.4986" shape="long"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.159" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.191" y1="-2.794" x2="-3.429" y2="2.794" layer="51"/>
<rectangle x1="-5.969" y1="-0.635" x2="-5.08" y2="0.635" layer="51"/>
<rectangle x1="5.08" y1="-0.635" x2="5.969" y2="0.635" layer="51"/>
<wire x1="-6.2" y1="2.05" x2="-6.2" y2="1.7" width="0.127" layer="21"/>
<wire x1="-6.2" y1="1.7" x2="-6.2" y2="1.35" width="0.127" layer="21"/>
<wire x1="-6.2" y1="1.7" x2="-5.85" y2="2.05" width="0.127" layer="21"/>
<wire x1="-5.85" y1="2.05" x2="-5.85" y2="1.35" width="0.127" layer="21"/>
<wire x1="-5.85" y1="1.35" x2="-6.2" y2="1.7" width="0.127" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="DO201-15" urn="urn:adsk.eagle:package:43365/2" locally_modified="yes" type="model">
<description>DIODE
<packageinstances>
<packageinstance name="DO201-15"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="R0805_330">
<packages>
<package name="R0805">
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1" roundness="15"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1" roundness="15"/>
<text x="-0.635" y="1.27" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
</packages>
</library>
<library name="C0805_1uF:50V">
<packages>
<package name="C0805">
<wire x1="-1.623" y1="0.983" x2="1.623" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.623" y1="0.983" x2="1.623" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.623" y1="-0.983" x2="-1.623" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.623" y1="-0.983" x2="-1.623" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.456" y1="0.632" x2="0.456" y2="0.632" width="0.1016" layer="51"/>
<wire x1="-0.456" y1="-0.619" x2="0.456" y2="-0.619" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1" dy="1.4" layer="1" roundness="15"/>
<smd name="2" x="1" y="0" dx="1" dy="1.4" layer="1" roundness="15"/>
<text x="-0.685" y="1.585" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-0.685" y="-2.805" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.0882" y1="-0.4699" x2="-0.5881" y2="0.4801" layer="51"/>
<rectangle x1="0.5802" y1="-0.4699" x2="1.0803" y2="0.4801" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
<rectangle x1="-1.1" y1="-0.65" x2="-0.55" y2="0.65" layer="51"/>
<rectangle x1="0.55" y1="-0.65" x2="1.1" y2="0.65" layer="51"/>
</package>
</packages>
</library>
<library name="C0805_100nF:50V">
<packages>
</package>
</packages>
</library>
<library name="MAX6126AASA21+">
<packages>
</package>
</packages>
</library>
<library name="2Ohm_06W">
<packages>
<package name="0207/10" urn="urn:adsk.eagle:footprint:8118326/1">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="0207/10" urn="urn:adsk.eagle:package:8118469/1" type="box">
<packageinstances>
<packageinstance name="0207/10"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="C0805_10uF:35V">
<packages>
</package>
</packages>
</library>
<library name="LM334Z:LFT1">
<packages>
<package name="TO92" urn="urn:adsk.eagle:footprint:20710/1" locally_modified="yes">
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-2.6549" y2="-0.254" width="0.127" layer="21" curve="-32.78104"/>
<wire x1="-2.6549" y1="-0.254" x2="-0.7863" y2="2.5485" width="0.127" layer="21" curve="-78.318477"/>
<wire x1="0.7863" y1="2.5484" x2="2.0945" y2="-1.651" width="0.127" layer="21" curve="-111.09954"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.2537" y1="-0.254" x2="-0.2863" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.2863" y1="-0.254" x2="2.2537" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.127" layer="51" curve="-34.293591"/>
<pad name="3" x="1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="TO92" urn="urn:adsk.eagle:package:20831/2" locally_modified="yes" type="model">
<description>TO 92</description>
<packageinstances>
<packageinstance name="TO92"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name=" 1N457">
<packages>
<package name="DO35-7" urn="urn:adsk.eagle:footprint:43093/1" locally_modified="yes">
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="51" curve="-90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="51"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="51"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<wire x1="1.2" y1="0" x2="1.2" y2="0.3" width="0.127" layer="21"/>
<wire x1="1.2" y1="0" x2="1.2" y2="-0.3" width="0.127" layer="21"/>
<wire x1="1.2" y1="0" x2="1.5" y2="0.3" width="0.127" layer="21"/>
<wire x1="1.5" y1="0.3" x2="1.5" y2="-0.3" width="0.127" layer="21"/>
<wire x1="1.5" y1="-0.3" x2="1.2" y2="0" width="0.127" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="DO35-7" urn="urn:adsk.eagle:package:43339/2" locally_modified="yes" type="model">
<description>DIODE
<packageinstances>
<packageinstance name="DO35-7"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="R0805_10k_0.1%">
<packages>
</package>
</packages>
</library>
<library name="R0805_10k">
<packages>
</package>
</packages>
</library>
<library name="R0805_1k">
<packages>
</package>
</packages>
</library>
<library name="R0805_100">
<packages>
</package>
</packages>
</library>
<library name="2N3904-AP">
<packages>
</package>
</packages>
<packages3d>
<packageinstances>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="IRLU8721-701PBF">
<packages>
<package name="TO252" urn="urn:adsk.eagle:footprint:28481/1" locally_modified="yes">
<description>&lt;b&gt;SMALL OUTLINE TRANSISTOR&lt;/b&gt;&lt;p&gt;
TS-003</description>
<wire x1="3.2766" y1="3.8354" x2="3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-2.159" x2="-3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-2.159" x2="-3.2766" y2="3.8354" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="3.835" x2="3.2774" y2="3.8346" width="0.2032" layer="51"/>
<wire x1="-3.973" y1="5.983" x2="3.973" y2="5.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-5.983" x2="-3.973" y2="-5.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-5.983" x2="-3.973" y2="5.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="5.983" x2="3.973" y2="-5.983" width="0.0508" layer="39"/>
<wire x1="-2.5654" y1="3.937" x2="-2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="4.6482" x2="-2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="-2.1082" y1="5.1054" x2="2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="2.1082" y1="5.1054" x2="2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="4.6482" x2="2.5654" y2="3.937" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="3.937" x2="-2.5654" y2="3.937" width="0.2032" layer="51"/>
<smd name="3" x="0" y="2.5" dx="5.4" dy="6.2" layer="1"/>
<smd name="1" x="-2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<smd name="2" x="2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" font="vector" ratio="10" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" font="vector" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7178" y1="-5.1562" x2="-1.8542" y2="-2.2606" layer="51"/>
<rectangle x1="1.8542" y1="-5.1562" x2="2.7178" y2="-2.2606" layer="51"/>
<rectangle x1="-0.4318" y1="-3.0226" x2="0.4318" y2="-2.2606" layer="51"/>
<polygon width="0.1998" layer="51">
<vertex x="-2.5654" y="3.937"/>
<vertex x="-2.5654" y="4.6482"/>
<vertex x="-2.1082" y="5.1054"/>
<vertex x="2.1082" y="5.1054"/>
<vertex x="2.5654" y="4.6482"/>
<vertex x="2.5654" y="3.937"/>
</polygon>
</package>
</packages>
<packages3d>
<package3d name="TO252" urn="urn:adsk.eagle:package:28537/2" locally_modified="yes" type="model">
<description>SMALL OUTLINE TRANSISTOR
<packageinstances>
<packageinstance name="TO252"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="R0805_133Ohm_0.1%">
<packages>
</package>
</packages>
</library>
<library name="R0805_1k33_0.1%">
<packages>
</package>
</packages>
</library>
<library name="20Ohm_06W_0.1%">
<packages>
<package name="0207/10" urn="urn:adsk.eagle:footprint:8118326/1" locally_modified="yes">
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="51" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="51" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="51" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="51"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<text x="-3.048" y="2.794" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-3.5306" y="-3.175" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="0207/10" urn="urn:adsk.eagle:package:8118469/1" locally_modified="yes" type="box">
<packageinstances>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="R0805_2.21k_0.1%">
<packages>
</package>
</packages>
</library>
<library name="R0805_12.1Ohm_0.1%">
<packages>
</package>
</packages>
</library>
<library name="R0805_191k_0.1%">
<packages>
</package>
</packages>
</library>
<library name="R0805_0Ohm">
<packages>
</package>
</packages>
</library>
<library name="con-wago-508" urn="urn:adsk.eagle:library:196">
<description>&lt;b&gt;Wago Screw Clamps&lt;/b&gt;&lt;p&gt;
Grid 5.08 mm&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="W237-132" urn="urn:adsk.eagle:footprint:10712/1" library_version="1">
<description>&lt;b&gt;WAGO SREW CLAMP&lt;/b&gt;</description>
<wire x1="-3.5306" y1="-1.651" x2="-1.524" y2="0.3556" width="0.254" layer="51"/>
<wire x1="1.6256" y1="-1.6764" x2="3.5306" y2="0.3556" width="0.254" layer="51"/>
<wire x1="-5.08" y1="4.191" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-3.429" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.413" x2="-1.651" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.413" x2="1.651" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-2.413" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.413" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.445" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.191" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-2.413" x2="3.429" y2="-2.413" width="0.1524" layer="51"/>
<circle x="-2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="-2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<text x="-4.445" y="1.27" size="1.27" layer="51" ratio="10">1</text>
<text x="0.6858" y="1.2192" size="1.27" layer="51" ratio="10">2</text>
<text x="-3.81" y="-6.985" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.81" y="-4.318" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
<packages3d>
<package3d name="W237-132" urn="urn:adsk.eagle:package:10734/1" type="box" library_version="1">
<description>WAGO SREW CLAMP</description>
<packageinstances>
<packageinstance name="W237-132"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="R0805_52.3Ohm_0.1%">
<packages>
</package>
</packages>
</library>
<library name="R0805_100_0.1%">
<packages>
</package>
</packages>
</library>
<library name="R1206_10k_0.1%">
<packages>
<package name="R1206">
<rectangle x1="-0.1799" y1="-0.5001" x2="0.2199" y2="0.5001" layer="35"/>
<wire x1="0.9925" y1="-0.8128" x2="-0.9252" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9925" y1="0.8128" x2="-0.9252" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.433" y1="0.983" x2="2.513" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.513" y1="0.983" x2="2.513" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.513" y1="-0.983" x2="-2.433" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.433" y1="-0.983" x2="-2.433" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.462" y="0" dx="1.6" dy="1.803" layer="1" roundness="10"/>
<smd name="1" x="-1.382" y="0" dx="1.6" dy="1.803" layer="1" roundness="10"/>
<text x="-1.23" y="1.27" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-1.23" y="-2.54" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.6491" y1="-0.8763" x2="-0.9125" y2="0.8763" layer="51"/>
<rectangle x1="0.9925" y1="-0.8763" x2="1.7291" y2="0.8763" layer="51"/>
<rectangle x1="-0.26" y1="-0.7" x2="0.34" y2="0.7" layer="35"/>
</package>
</packages>
</library>
<library name="R1206_2M_0.1%">
<packages>
</package>
</packages>
</library>
<library name="RFDuino">
<packages>
<package name="RFDUINO">
<wire x1="9.144" y1="-13.208" x2="9.398" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-13.208" x2="9.398" y2="-13.462" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-13.462" x2="10.414" y2="-13.462" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-13.462" x2="10.414" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-13.208" x2="10.668" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-13.208" x2="10.668" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-12.7" x2="10.414" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-12.7" x2="10.414" y2="-12.446" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-12.446" x2="9.398" y2="-12.446" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-12.446" x2="9.398" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-12.7" x2="9.144" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-12.7" x2="9.144" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-10.668" x2="9.398" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-10.668" x2="9.398" y2="-10.922" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-10.922" x2="10.414" y2="-10.922" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-10.922" x2="10.414" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-10.668" x2="10.668" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-10.668" x2="10.668" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-10.16" x2="10.414" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-10.16" x2="10.414" y2="-9.906" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-9.906" x2="9.398" y2="-9.906" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-9.906" x2="9.398" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-10.16" x2="9.144" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-10.16" x2="9.144" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-8.128" x2="9.398" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-8.128" x2="9.398" y2="-8.382" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-8.382" x2="10.414" y2="-8.382" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-8.382" x2="10.414" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-8.128" x2="10.668" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-8.128" x2="10.668" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-7.62" x2="10.414" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-7.62" x2="10.414" y2="-7.366" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-7.366" x2="9.398" y2="-7.366" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-7.366" x2="9.398" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-7.62" x2="9.144" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-7.62" x2="9.144" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-5.588" x2="9.398" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-5.588" x2="9.398" y2="-5.842" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-5.842" x2="10.414" y2="-5.842" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-5.842" x2="10.414" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-5.588" x2="10.668" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-5.588" x2="10.668" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-5.08" x2="10.414" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-5.08" x2="10.414" y2="-4.826" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-4.826" x2="9.398" y2="-4.826" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-4.826" x2="9.398" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-5.08" x2="9.144" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-5.08" x2="9.144" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-3.048" x2="9.398" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-3.048" x2="9.398" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-3.302" x2="10.414" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-3.302" x2="10.414" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-3.048" x2="10.668" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-3.048" x2="10.668" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-2.54" x2="10.414" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-2.54" x2="10.414" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-2.286" x2="9.398" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-2.286" x2="9.398" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-2.54" x2="9.144" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-2.54" x2="9.144" y2="-3.048" width="0.1524" layer="51"/>
<pad name="1" x="9.906" y="-12.954" drill="1.02" shape="long" rot="R180"/>
<pad name="2" x="9.906" y="-10.414" drill="1.02" shape="long" rot="R180"/>
<pad name="3" x="9.906" y="-7.874" drill="1.02" shape="long" rot="R180"/>
<pad name="4" x="9.906" y="-5.334" drill="1.02" shape="long" rot="R180"/>
<pad name="5" x="9.906" y="-2.794" drill="1.02" shape="long" rot="R180"/>
<rectangle x1="9.271" y1="-13.208" x2="9.525" y2="-12.7" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-13.208" x2="10.541" y2="-12.7" layer="51" rot="R90"/>
<rectangle x1="9.271" y1="-10.668" x2="9.525" y2="-10.16" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-10.668" x2="10.541" y2="-10.16" layer="51" rot="R90"/>
<rectangle x1="9.271" y1="-8.128" x2="9.525" y2="-7.62" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-8.128" x2="10.541" y2="-7.62" layer="51" rot="R90"/>
<rectangle x1="9.271" y1="-5.588" x2="9.525" y2="-5.08" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-5.588" x2="10.541" y2="-5.08" layer="51" rot="R90"/>
<rectangle x1="9.271" y1="-3.048" x2="9.525" y2="-2.54" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-3.048" x2="10.541" y2="-2.54" layer="51" rot="R90"/>
<wire x1="-9.144" y1="2.54" x2="-9.398" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="2.54" x2="-9.398" y2="2.794" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="2.794" x2="-10.414" y2="2.794" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="2.794" x2="-10.414" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="2.54" x2="-10.668" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="2.54" x2="-10.668" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="2.032" x2="-10.414" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="2.032" x2="-10.414" y2="1.778" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="1.778" x2="-9.398" y2="1.778" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="1.778" x2="-9.398" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="2.032" x2="-9.144" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="2.032" x2="-9.144" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="0" x2="-9.398" y2="0" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="0" x2="-9.398" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="0.254" x2="-10.414" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0.254" x2="-10.414" y2="0" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0" x2="-10.668" y2="0" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="0" x2="-10.668" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-0.508" x2="-10.414" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-0.508" x2="-10.414" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-0.762" x2="-9.398" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-0.762" x2="-9.398" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-0.508" x2="-9.144" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-0.508" x2="-9.144" y2="0" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-2.54" x2="-9.398" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-2.54" x2="-9.398" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-2.286" x2="-10.414" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-2.286" x2="-10.414" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-2.54" x2="-10.668" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-2.54" x2="-10.668" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-3.048" x2="-10.414" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-3.048" x2="-10.414" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-3.302" x2="-9.398" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-3.302" x2="-9.398" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-3.048" x2="-9.144" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-3.048" x2="-9.144" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-5.08" x2="-9.398" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-5.08" x2="-9.398" y2="-4.826" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-4.826" x2="-10.414" y2="-4.826" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-4.826" x2="-10.414" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.08" x2="-10.668" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-5.08" x2="-10.668" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-5.588" x2="-10.414" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.588" x2="-10.414" y2="-5.842" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.842" x2="-9.398" y2="-5.842" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-5.842" x2="-9.398" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-5.588" x2="-9.144" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-5.588" x2="-9.144" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-7.62" x2="-9.398" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-7.62" x2="-9.398" y2="-7.366" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-7.366" x2="-10.414" y2="-7.366" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-7.366" x2="-10.414" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-7.62" x2="-10.668" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-7.62" x2="-10.668" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-8.128" x2="-10.414" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-8.128" x2="-10.414" y2="-8.382" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-8.382" x2="-9.398" y2="-8.382" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-8.382" x2="-9.398" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-8.128" x2="-9.144" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-8.128" x2="-9.144" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-10.16" x2="-9.398" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-10.16" x2="-9.398" y2="-9.906" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-9.906" x2="-10.414" y2="-9.906" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-9.906" x2="-10.414" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-10.16" x2="-10.668" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-10.16" x2="-10.668" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-10.668" x2="-10.414" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-10.668" x2="-10.414" y2="-10.922" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-10.922" x2="-9.398" y2="-10.922" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-10.922" x2="-9.398" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-10.668" x2="-9.144" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-10.668" x2="-9.144" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-12.7" x2="-9.398" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-12.7" x2="-9.398" y2="-12.446" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-12.446" x2="-10.414" y2="-12.446" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-12.446" x2="-10.414" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-12.7" x2="-10.668" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-12.7" x2="-10.668" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-13.208" x2="-10.414" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-13.208" x2="-10.414" y2="-13.462" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-13.462" x2="-9.398" y2="-13.462" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-13.462" x2="-9.398" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-13.208" x2="-9.144" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-13.208" x2="-9.144" y2="-12.7" width="0.1524" layer="51"/>
<pad name="6" x="-9.906" y="2.286" drill="1.02" shape="long"/>
<pad name="7" x="-9.906" y="-0.254" drill="1.02" shape="long"/>
<pad name="8" x="-9.906" y="-2.794" drill="1.02" shape="long"/>
<pad name="9" x="-9.906" y="-5.334" drill="1.02" shape="long"/>
<pad name="10" x="-9.906" y="-7.874" drill="1.02" shape="long"/>
<pad name="11" x="-9.906" y="-10.414" drill="1.02" shape="long"/>
<pad name="12" x="-9.906" y="-12.954" drill="1.02" shape="long"/>
<text x="2.032" y="12.827" size="1.27" layer="25" font="vector" ratio="10" rot="R180">&gt;NAME</text>
<text x="3.048" y="-12.319" size="1.27" layer="27" font="vector" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="-9.525" y1="2.032" x2="-9.271" y2="2.54" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="2.032" x2="-10.287" y2="2.54" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-0.508" x2="-9.271" y2="0" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-0.508" x2="-10.287" y2="0" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-3.048" x2="-9.271" y2="-2.54" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-3.048" x2="-10.287" y2="-2.54" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-5.588" x2="-9.271" y2="-5.08" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-5.588" x2="-10.287" y2="-5.08" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-8.128" x2="-9.271" y2="-7.62" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-8.128" x2="-10.287" y2="-7.62" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-10.668" x2="-9.271" y2="-10.16" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-10.668" x2="-10.287" y2="-10.16" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-13.208" x2="-9.271" y2="-12.7" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-13.208" x2="-10.287" y2="-12.7" layer="51" rot="R270"/>
<wire x1="11.93" y1="14.478" x2="-11.93" y2="14.478" width="0.127" layer="21"/>
<wire x1="-11.93" y1="14.478" x2="-11.93" y2="-14.478" width="0.127" layer="21"/>
<wire x1="-11.93" y1="-14.478" x2="11.93" y2="-14.478" width="0.127" layer="21"/>
<wire x1="11.93" y1="-14.478" x2="11.93" y2="14.478" width="0.127" layer="21"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="Zsolt">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="6mil"/>
<param name="mdSmdVia" value="6mil"/>
<param name="mdSmdSmd" value="6mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="20mil"/>
<param name="mdDrill" value="26mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="20mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="8mil"/>
<param name="rlMaxPadTop" value="40mil"/>
<param name="rlMinPadInner" value="8mil"/>
<param name="rlMaxPadInner" value="40mil"/>
<param name="rlMinPadBottom" value="8mil"/>
<param name="rlMaxPadBottom" value="40mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="40mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="40mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="0"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="0mil"/>
<param name="mlMaxStopFrame" value="0mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0.2"/>
<param name="srMinRoundness" value="1mil"/>
<param name="srMaxRoundness" value="5mil"/>
<param name="slThermalIsolate" value="6mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="checkStop" value="0"/>
<param name="checkValues" value="0"/>
<param name="checkNames" value="1"/>
<param name="checkWireStubs" value="1"/>
<param name="checkPolygonWidth" value="0"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="a"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="a"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="IC11" library="MCP3204" package="TSSOP14" package3d_urn="urn:adsk.eagle:package:20830/2" value="MCP3204TSSOP-14" x="28.31" y="32.71" smashed="yes">
<attribute name="MPN" value="MCP3204-CI/ST" x="56.25" y="3.5" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="25.465" y="33.6725" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="32.41" y="29.56" size="1.27" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
<element name="IC4" library="MCP4922" package="TSSOP14" package3d_urn="urn:adsk.eagle:package:20830/2" value="MCP4922TTSSOP-14" x="28.4825" y="36.11" smashed="yes" rot="MR0">
<attribute name="MPN" value="MCP4922T-E/ST" x="10.7025" y="6.9" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="NAME" x="33.615" y="35.67" size="1.27" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="24.5825" y="32.86" size="1.27" layer="28" font="vector" ratio="10" rot="MR90"/>
</element>
<element name="IC1" library="LM341T-5.0:NOPB" package="TO220V" package3d_urn="urn:adsk.eagle:package:8089447/1" value="LM341T-5.0/NOPBTO-220" x="26.4875" y="67.79" smashed="yes">
<attribute name="MPN" value="LM341T-5.0/NOPB" x="70.9375" y="14.45" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="20.145" y="66.5073" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="21.4075" y="60.17" size="1.27" layer="27" ratio="10"/>
</element>
<element name="IC2" library="MCP1700-3302E:TO" package="TO-92" package3d_urn="urn:adsk.eagle:package:8089447/1" value="MCP1700-3302E/TOTO-220" x="27.0225" y="59.23" smashed="yes" rot="R270">
<attribute name="MPN" value="MCP1700-3302E/TO" x="-32.6675" y="17.32" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="29.415" y="57.97" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="25.2325" y="56.035" size="1.27" layer="27" font="vector" ratio="10" rot="R270"/>
</element>
<element name="IC6" library="NJM14558D" package="DIL8" package3d_urn="urn:adsk.eagle:package:20796/2" value="NJM14558DDIL-8" x="12.9" y="53.2725" smashed="yes" rot="R90">
<attribute name="MPN" value="NJM14558D" x="19.25" y="74.8625" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="16.365" y="60.4397" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="15.44" y="60.5115" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="IC9" library="NJM14558D" package="DIL8" package3d_urn="urn:adsk.eagle:package:20796/2" value="NJM14558DDIL-8" x="12.9" y="35.55" smashed="yes" rot="R90">
<attribute name="MPN" value="NJM14558D" x="19.25" y="73.65" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="16.9775" y="29.3547" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="15.44" y="42.789" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="IC5" library="MAX4080F" package="SOIC8" package3d_urn="urn:adsk.eagle:package:16057/2" value="MAX4080FASA+8-SOIC" x="50.465" y="56.2125" smashed="yes" rot="MR270">
<attribute name="MPN" value="MAX4080FASA+" x="54.275" y="5.4125" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="52.795" y="52.0295" size="1.27" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="52.37" y="52.2755" size="1.27" layer="28" font="vector" rot="MR0"/>
</element>
<element name="IC10" library="MAX4238ASA+" package="8-SO" value="MAX4238ASA+" x="49.3375" y="44.26" smashed="yes" rot="MR90">
<attribute name="MPN" value="MAX4238ASA+" x="-1.4625" y="67.12" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="NAME" x="56.5775" y="44.2375" size="1.27" layer="22" font="vector" ratio="10" rot="MR0"/>
</element>
<element name="IC7" library="LT3083" package="TO220-5" package3d_urn="urn:adsk.eagle:package:16056/1" value="LT3083ET#PBFTO220-5" x="38.5225" y="67.77" smashed="yes">
<attribute name="MPN" value="LT3083ET#PBF" x="38.5225" y="67.77" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="46.887" y="67.5925" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="44.8725" y="59.388" size="1.27" layer="27" rot="R90"/>
</element>
<element name="D3" library="SB540E-G" package="DO201-15" package3d_urn="urn:adsk.eagle:package:43365/2" value="SB540E-GDO-201AD" x="38.5825" y="41.89" smashed="yes" rot="R270">
<attribute name="MPN" value="SB540E-G" x="38.5825" y="41.89" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="38.07" y="31.7825" size="1.27" layer="25" font="vector" ratio="10" rot="R270"/>
<attribute name="VALUE" x="36.4235" y="44.43" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="D1" library="SB540E-G" package="DO201-15" package3d_urn="urn:adsk.eagle:package:43365/2" value="SB540E-GDO-201AD" x="34.2275" y="55.07" smashed="yes" rot="R180">
<attribute name="MPN" value="SB540E-G" x="34.2275" y="55.07" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="34.42" y="55.495" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="36.7675" y="57.229" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R12" library="R0805_330" package="R0805" value="R0805_330" x="9.1075" y="60.5275" smashed="yes" rot="MR270">
<attribute name="MPN" value="CR0805-FX-3300ELF" x="9.1075" y="60.5275" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="7.925" y="62.1" size="1.27" layer="26" font="vector" ratio="10" rot="MR270"/>
<attribute name="VALUE" x="11.6475" y="61.1625" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="C11" library="C0805_1uF:50V" package="C0805" value="C0805_1UF/50V" x="12.1175" y="59.54" smashed="yes" rot="MR180">
<attribute name="MPN" value="CL21B105KBFNNNG" x="12.1175" y="59.54" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="NAME" x="12.7325" y="61.805" size="1.27" layer="26" font="vector" ratio="10" rot="MR180"/>
<attribute name="VALUE" x="11.6825" y="62.145" size="1.27" layer="28" font="vector" ratio="10" rot="MR180"/>
</element>
<element name="C10" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="52.07" y="59.9525" smashed="yes" rot="MR0">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="52.07" y="59.9525" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="NAME" x="53.43" y="61.1125" size="1.27" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="52.755" y="57.1475" size="1.27" layer="28" font="vector" ratio="10" rot="MR0"/>
</element>
<element name="IC3" library="MAX6126AASA21+" package="8-SO" value="MAX6126AASA21+" x="32.095" y="40.3975" smashed="yes" rot="R90">
<attribute name="MPN" value="MAX6126AASA21+" x="32.095" y="40.3975" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="33.5025" y="44.47" size="1.27" layer="21" font="vector" ratio="10" rot="R180"/>
</element>
<element name="C6" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="33.6875" y="36.845" smashed="yes">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="33.6875" y="36.845" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="32.8275" y="34.58" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="33.0025" y="34.04" size="1.27" layer="27" font="vector" ratio="10"/>
</element>
<element name="C9" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="27.7" y="43.075" smashed="yes" rot="R270">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="27.7" y="43.075" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="26.8775" y="41.89" size="1.27" layer="25" font="vector" ratio="10" rot="R90"/>
<attribute name="VALUE" x="24.895" y="43.76" size="1.27" layer="27" font="vector" ratio="10" rot="R270"/>
</element>
<element name="C4" library="C0805_1uF:50V" package="C0805" value="C0805_1UF/50V" x="24.4825" y="59.2" smashed="yes" rot="R90">
<attribute name="MPN" value="CL21B105KBFNNNG" x="24.4825" y="59.2" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="22.3025" y="59.2475" size="1.27" layer="25" font="vector" ratio="10" rot="R270"/>
<attribute name="VALUE" x="27.2875" y="58.515" size="1.27" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
<element name="C5" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="36.56" y="40.725" smashed="yes" rot="R270">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="36.56" y="40.725" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="35.9525" y="42.8325" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="33.755" y="41.41" size="1.27" layer="27" font="vector" ratio="10" rot="R270"/>
</element>
<element name="C7" library="C0805_1uF:50V" package="C0805" value="C0805_1UF/50V" x="31.765" y="30.9" smashed="yes" rot="R270">
<attribute name="MPN" value="CL21B105KBFNNNG" x="31.765" y="30.9" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="32.765" y="30.325" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="28.96" y="31.585" size="1.27" layer="27" font="vector" ratio="10" rot="R270"/>
</element>
<element name="C8" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="24.8425" y="38.425" smashed="yes" rot="MR270">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="24.8425" y="38.425" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="22.1025" y="39.145" size="1.27" layer="26" font="vector" ratio="10" rot="MR180"/>
<attribute name="VALUE" x="27.6475" y="39.11" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="C3" library="C0805_1uF:50V" package="C0805" value="C0805_1UF/50V" x="31.0875" y="64.275" smashed="yes" rot="R90">
<attribute name="MPN" value="CL21B105KBFNNNG" x="31.0875" y="64.275" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="31.54" y="65.915" size="1.27" layer="25" font="vector" ratio="10" rot="R90"/>
<attribute name="VALUE" x="33.8925" y="63.59" size="1.27" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
<element name="C2" library="C0805_1uF:50V" package="C0805" value="C0805_1UF/50V" x="28.175" y="62.67" smashed="yes" rot="R180">
<attribute name="MPN" value="CL21B105KBFNNNG" x="28.175" y="62.67" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="30.6225" y="61.7725" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="28.86" y="65.475" size="1.27" layer="27" font="vector" ratio="10" rot="R180"/>
</element>
<element name="C1" library="C0805_1uF:50V" package="C0805" value="C0805_1UF/50V" x="24.875" y="62.67" smashed="yes">
<attribute name="MPN" value="CL21B105KBFNNNG" x="24.875" y="62.67" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="21.44" y="62.1175" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="24.19" y="59.865" size="1.27" layer="27" font="vector" ratio="10"/>
</element>
<element name="R11" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="65.010028125" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="65.010028125" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.9105" y="65.661028125" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="65.645028125" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R10" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="63.490025" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="63.490025" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="60.048" y="64.128525" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="64.125025" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R9" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="61.970021875" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="61.970021875" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.048" y="62.571021875" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="62.605021875" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R8" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="60.45001875" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="60.45001875" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.048" y="61.05101875" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="61.08501875" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R7" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="58.930015625" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="58.930015625" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.048" y="59.531015625" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="59.565015625" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R6" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="57.4100125" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="57.4100125" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.048" y="58.0110125" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="58.0450125" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R5" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="55.890009375" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="55.890009375" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.048" y="56.478509375" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="56.525009375" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R4" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="54.37000625" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="54.37000625" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.048" y="54.95850625" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="55.00500625" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R3" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="52.850003125" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="52.850003125" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.048" y="53.463503125" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="53.485003125" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R2" library="2Ohm_06W" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="2OHM_06WMBB/SMA0207" x="50.4625" y="51.33" smashed="yes" rot="R180">
<attribute name="MPN" value="MBB02070C2008FRP00" x="50.4625" y="51.33" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="59.0355" y="51.856" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="52.7231" y="51.965" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C12" library="C0805_10uF:35V" package="C0805" value="C0805_10UF/35V" x="43.5725" y="64.2625" smashed="yes" rot="R90">
<attribute name="MPN" value="GRM21BC8YA106KE11L" x="43.5725" y="64.2625" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="41.2125" y="65.6975" size="1.27" layer="25" font="vector" ratio="10" rot="R270"/>
<attribute name="VALUE" x="46.3775" y="63.5775" size="1.27" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
<element name="C13" library="C0805_10uF:35V" package="C0805" value="C0805_10UF/35V" x="33.1175" y="64.275" smashed="yes" rot="R90">
<attribute name="MPN" value="GRM21BC8YA106KE11L" x="33.1175" y="64.275" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="32.0175" y="68.7725" size="1.27" layer="25" font="vector" ratio="10" rot="R270"/>
<attribute name="VALUE" x="35.9225" y="63.59" size="1.27" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
<element name="C15" library="C0805_10uF:35V" package="C0805" value="C0805_10UF/35V" x="41.4625" y="50.075" smashed="yes">
<attribute name="MPN" value="GRM21BC8YA106KE11L" x="41.4625" y="50.075" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="40.0025" y="51.1975" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="40.7775" y="47.27" size="1.27" layer="27" font="vector" ratio="10"/>
</element>
<element name="IC8" library="LM334Z:LFT1" package="TO92" package3d_urn="urn:adsk.eagle:package:20831/2" value="LM334Z/LFT1TO-92" x="26.5625" y="50.83" smashed="yes" rot="R270">
<attribute name="MPN" value="LM334Z/LFT1" x="26.5625" y="50.83" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="28.6075" y="52.8475" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="25.2925" y="47.655" size="1.27" layer="27" font="vector" ratio="10" rot="R270"/>
</element>
<element name="D2" library=" 1N457" package="DO35-7" package3d_urn="urn:adsk.eagle:package:43339/2" value="1N457DO-35" x="23.4425" y="48.2225" smashed="yes" rot="R90">
<attribute name="MPN" value="1N457" x="23.4425" y="48.2225" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="24.426" y="54.71" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="26.1095" y="45.9365" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C14" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="13.1125" y="57.075" smashed="yes" rot="MR180">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="13.1125" y="57.075" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="NAME" x="11.6275" y="56.14" size="1.27" layer="26" font="vector" ratio="10" rot="MR180"/>
<attribute name="VALUE" x="12.4275" y="59.88" size="1.27" layer="28" font="vector" ratio="10" rot="MR180"/>
</element>
<element name="C17" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="13.3875" y="39.345" smashed="yes" rot="MR180">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="13.3875" y="39.345" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="NAME" x="12.89" y="35.465" size="1.27" layer="26" font="vector" ratio="10" rot="MR90"/>
<attribute name="VALUE" x="12.7025" y="42.15" size="1.27" layer="28" font="vector" ratio="10" rot="MR180"/>
</element>
<element name="C18" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="26.9875" y="37.3725" smashed="yes">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="26.9875" y="37.3725" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="22.24" y="36.7575" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="26.3025" y="34.5675" size="1.27" layer="27" font="vector" ratio="10"/>
</element>
<element name="R30" library="R0805_10k_0.1%" package="R0805" value="R0805_10K_0.1%" x="6.26" y="40.3" smashed="yes" rot="MR270">
<attribute name="MPN" value="ERA-6AEB103V" x="6.26" y="40.3" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="4.69" y="38.365" size="1.27" layer="26" font="vector" ratio="10" rot="MR180"/>
<attribute name="VALUE" x="8.8" y="40.935" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="R13" library="R0805_10k_0.1%" package="R0805" value="R0805_10K_0.1%" x="20.235" y="46.45" smashed="yes" rot="MR270">
<attribute name="MPN" value="ERA-6AEB103V" x="20.235" y="46.45" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="22.565" y="47.9725" size="1.27" layer="26" font="vector" ratio="10" rot="MR270"/>
<attribute name="VALUE" x="22.775" y="47.085" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="R14" library="R0805_10k_0.1%" package="R0805" value="R0805_10K_0.1%" x="21.29" y="51.05" smashed="yes" rot="MR90">
<attribute name="MPN" value="ERA-6AEB103V" x="21.29" y="51.05" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="NAME" x="19.99" y="52.51" size="1.27" layer="26" font="vector" ratio="10" rot="MR270"/>
<attribute name="VALUE" x="18.75" y="50.415" size="1.27" layer="28" font="vector" ratio="10" rot="MR90"/>
</element>
<element name="R25" library="R0805_10k_0.1%" package="R0805" value="R0805_10K_0.1%" x="34.4" y="53.2525" smashed="yes" rot="MR0">
<attribute name="MPN" value="ERA-6AEB103V" x="34.4" y="53.2525" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="NAME" x="35.7975" y="54.385" size="1.27" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="35.035" y="50.7125" size="1.27" layer="28" font="vector" ratio="10" rot="MR0"/>
</element>
<element name="R26" library="R0805_10k_0.1%" package="R0805" value="R0805_10K_0.1%" x="38.375" y="53.2525" smashed="yes" rot="MR0">
<attribute name="MPN" value="ERA-6AEB103V" x="38.375" y="53.2525" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="NAME" x="39.535" y="54.435" size="1.27" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="39.01" y="50.7125" size="1.27" layer="28" font="vector" ratio="10" rot="MR0"/>
</element>
<element name="R27" library="R0805_2.21k_0.1%" package="R0805" value="R0805_2.21K_0.1%" x="42.5" y="52.89" smashed="yes" rot="MR0">
<attribute name="MPN" value="ERA-6AEB2211V" x="42.5" y="52.89" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="NAME" x="43.285" y="56.4725" size="1.27" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="43.135" y="50.35" size="1.27" layer="28" font="vector" ratio="10" rot="MR0"/>
</element>
<element name="R28" library="R0805_12.1Ohm_0.1%" package="R0805" value="R0805_12.1OHM_0.1%" x="42.5" y="50.8975" smashed="yes" rot="MR180">
<attribute name="MPN" value="RQ73C2A12R1BTD" x="42.5" y="50.8975" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="NAME" x="39.735" y="49.84" size="1.016" layer="26" font="vector" ratio="10" rot="MR90"/>
<attribute name="VALUE" x="41.865" y="53.4375" size="1.27" layer="28" font="vector" ratio="10" rot="MR180"/>
</element>
<element name="C16" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="41.575" y="48.8825" smashed="yes" rot="MR0">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="41.575" y="48.8825" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="NAME" x="37.9225" y="46.0675" size="1.016" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="42.26" y="46.0775" size="1.27" layer="28" font="vector" ratio="10" rot="MR0"/>
</element>
<element name="R21" library="R0805_10k" package="R0805" value="R0805_10K" x="4.8875" y="52" smashed="yes" rot="MR180">
<attribute name="MPN" value="RMCF0805JT10K0" x="4.8875" y="52" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="NAME" x="4.4275" y="54.33" size="1.27" layer="26" font="vector" ratio="10" rot="MR180"/>
<attribute name="VALUE" x="4.2525" y="54.54" size="1.27" layer="28" font="vector" ratio="10" rot="MR180"/>
</element>
<element name="R20" library="R0805_10k" package="R0805" value="R0805_10K" x="4.8875" y="49.9875" smashed="yes" rot="MR180">
<attribute name="MPN" value="RMCF0805JT10K0" x="4.8875" y="49.9875" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="NAME" x="1.695" y="47.7525" size="1.27" layer="26" font="vector" ratio="10" rot="MR90"/>
<attribute name="VALUE" x="4.2525" y="52.5275" size="1.27" layer="28" font="vector" ratio="10" rot="MR180"/>
</element>
<element name="R17" library="R0805_1k" package="R0805" value="R0805_1K" x="16.725" y="46.475" smashed="yes" rot="MR90">
<attribute name="MPN" value="CRGCQ0805J1K0" x="16.725" y="46.475" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="NAME" x="18.2225" y="43.3575" size="1.27" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="14.185" y="45.84" size="1.27" layer="28" font="vector" ratio="10" rot="MR90"/>
</element>
<element name="R19" library="R0805_100" package="R0805" value="R0805_100" x="33.975" y="63.275" smashed="yes" rot="MR180">
<attribute name="MPN" value="CRGCQ0805J100R" x="33.975" y="63.275" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="NAME" x="32.515" y="65.4925" size="1.27" layer="26" font="vector" ratio="10" rot="MR180"/>
<attribute name="VALUE" x="33.34" y="65.815" size="1.27" layer="28" font="vector" ratio="10" rot="MR180"/>
</element>
<element name="Q1" library="2N3904-AP" package="TO92" package3d_urn="urn:adsk.eagle:package:20831/2" value="2N3904-APTO-92" x="5.895" y="45.525" smashed="yes">
<attribute name="MPN" value="2N3904-AP" x="5.895" y="45.525" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="4.8325" y="48.785" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="9.07" y="44.255" size="1.27" layer="27" font="vector" ratio="10"/>
</element>
<element name="Q2" library="2N3904-AP" package="TO92" package3d_urn="urn:adsk.eagle:package:20831/2" value="2N3904-APTO-92" x="5.845" y="65.1425" smashed="yes" rot="R180">
<attribute name="MPN" value="2N3904-AP" x="5.845" y="65.1425" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="7.245" y="61.9075" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="2.67" y="66.4125" size="1.27" layer="27" font="vector" ratio="10" rot="R180"/>
</element>
<element name="C19" library="C0805_100nF:50V" package="C0805" value="C0805_100NF/50V" x="50.1175" y="48.775" smashed="yes" rot="MR270">
<attribute name="MPN" value="CC0805ZRY5V9BB104" x="50.1175" y="48.775" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="46.3525" y="48.195" size="1.27" layer="26" font="vector" ratio="10" rot="MR180"/>
<attribute name="VALUE" x="52.9225" y="49.46" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="R41" library="R0805_330" package="R0805" value="R0805_330" x="44.2125" y="35.5875" smashed="yes" rot="MR270">
<attribute name="MPN" value="CR0805-FX-3300ELF" x="44.2125" y="35.5875" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="42.8825" y="30.7275" size="1.27" layer="26" font="vector" ratio="10" rot="MR90"/>
<attribute name="VALUE" x="46.7525" y="36.2225" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="C20" library="C0805_1uF:50V" package="C0805" value="C0805_1UF/50V" x="28.3125" y="27.8925" smashed="yes">
<attribute name="MPN" value="CL21B105KBFNNNG" x="28.3125" y="27.8925" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="30.0775" y="27.315" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="27.6275" y="25.0875" size="1.27" layer="27" font="vector" ratio="10"/>
</element>
<element name="R40" library="R1206_10k_0.1%" package="R1206" value="R1206_10K_0.1%" x="39.465" y="41.15" smashed="yes" rot="MR270">
<attribute name="MPN" value="CRT1206-BY-1002ELF" x="39.465" y="41.15" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="44.02" y="43.06" size="1.27" layer="26" font="vector" ratio="10" rot="MR270"/>
<attribute name="VALUE" x="42.005" y="41.785" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="R36" library="R0805_100_0.1%" package="R0805" value="R0805_100_0.1%" x="44.3775" y="45.6375" smashed="yes" rot="MR270">
<attribute name="MPN" value="ERA-6AEB101V" x="44.3775" y="45.6375" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="41.22" y="46.66" size="1.27" layer="26" font="vector" ratio="10" rot="MR270"/>
<attribute name="VALUE" x="46.9175" y="46.2725" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="R33" library="R0805_100_0.1%" package="R0805" value="R0805_100_0.1%" x="42.415" y="45.6375" smashed="yes" rot="MR270">
<attribute name="MPN" value="ERA-6AEB101V" x="42.415" y="45.6375" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="39.42" y="46.66" size="1.27" layer="26" font="vector" ratio="10" rot="MR270"/>
<attribute name="VALUE" x="44.955" y="46.2725" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="R39" library="R1206_2M_0.1%" package="R1206" value="R1206_2M_0.1%" x="41.515" y="41.1625" smashed="yes" rot="MR270">
<attribute name="MPN" value="RG3216P-2004-B-T1" x="41.515" y="41.1625" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="36.88" y="39.715" size="1.27" layer="26" font="vector" ratio="10" rot="MR90"/>
<attribute name="VALUE" x="44.055" y="41.7975" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="R34" library="20Ohm_06W_0.1%" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="20OHM_06W_0.1%MBB/SMA0207" x="48.272503125" y="43.9075" smashed="yes" rot="R90">
<attribute name="MPN" value="YR1B20RCC" x="48.272503125" y="43.9075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="48.907503125" y="41.6469" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R35" library="20Ohm_06W_0.1%" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="20OHM_06W_0.1%MBB/SMA0207" x="46.91416875" y="43.9075" smashed="yes" rot="R90">
<attribute name="MPN" value="YR1B20RCC" x="46.91416875" y="43.9075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="47.54916875" y="41.6469" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R37" library="20Ohm_06W_0.1%" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="20OHM_06W_0.1%MBB/SMA0207" x="45.555834375" y="43.9075" smashed="yes" rot="R90">
<attribute name="MPN" value="YR1B20RCC" x="45.555834375" y="43.9075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="46.190834375" y="41.6469" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R38" library="20Ohm_06W_0.1%" package="0207/10" package3d_urn="urn:adsk.eagle:package:8118469/1" value="20OHM_06W_0.1%MBB/SMA0207" x="44.1975" y="43.9075" smashed="yes" rot="R90">
<attribute name="MPN" value="YR1B20RCC" x="44.1975" y="43.9075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="44.8325" y="41.6469" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="Q4" library="IRLU8721-701PBF" package="TO252" package3d_urn="urn:adsk.eagle:package:28537/2" value="IRLU8721-701PBFTO-252" x="48.315" y="31.6825" smashed="yes" rot="R180">
<attribute name="MPN" value="IRLU8721-701PBF" x="48.315" y="31.6825" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="50.565" y="23.8625" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="43.235" y="34.2225" size="1.27" layer="27" font="vector" ratio="10" rot="R270"/>
</element>
<element name="R31" library="R0805_10k" package="R0805" value="R0805_10K" x="53.995" y="39.52" smashed="yes" rot="MR0">
<attribute name="MPN" value="RMCF0805JT10K0" x="53.995" y="39.52" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="NAME" x="58.8425" y="38.9025" size="1.27" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="54.63" y="36.98" size="1.27" layer="28" font="vector" ratio="10" rot="MR0"/>
</element>
<element name="Q3" library="2N3904-AP" package="TO92" package3d_urn="urn:adsk.eagle:package:20831/2" value="2N3904-APTO-92" x="54.0175" y="37.555" smashed="yes" rot="R180">
<attribute name="MPN" value="2N3904-AP" x="54.0175" y="37.555" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="58.4175" y="36.52" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="50.8425" y="38.825" size="1.27" layer="27" font="vector" ratio="10" rot="R180"/>
</element>
<element name="R32" library="R0805_10k" package="R0805" value="R0805_10K" x="54.0275" y="32.63" smashed="yes" rot="R270">
<attribute name="MPN" value="RMCF0805JT10K0" x="54.0275" y="32.63" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="55.31" y="32.91" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="51.4875" y="33.265" size="1.27" layer="27" font="vector" ratio="10" rot="R270"/>
</element>
<element name="R23" library="R0805_133Ohm_0.1%" package="R0805" value="R0805_133OHM_0.1%" x="27.5075" y="47.215" smashed="yes">
<attribute name="MPN" value="RN73C2A133RBTDF" x="27.5075" y="47.215" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="28.665" y="46.24" size="1.016" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="26.8725" y="44.675" size="1.27" layer="27" font="vector" ratio="10"/>
</element>
<element name="R22" library="R0805_1k33_0.1%" package="R0805" value="R0805_1K33_0.1%" x="30.9725" y="47.7575" smashed="yes" rot="R90">
<attribute name="MPN" value="RG2012P-1331-B-T5" x="30.9725" y="47.7575" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="30.3225" y="52.5775" size="1.27" layer="25" font="vector" ratio="10" rot="R270"/>
<attribute name="VALUE" x="33.5125" y="47.1225" size="1.27" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
<element name="R16" library="R0805_2.21k_0.1%" package="R0805" value="R0805_2.21K_0.1%" x="20.305" y="58.565" smashed="yes" rot="MR180">
<attribute name="MPN" value="ERA-6AEB2211V" x="20.305" y="58.565" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="NAME" x="18.6575" y="60.9825" size="1.27" layer="26" font="vector" ratio="10" rot="MR180"/>
<attribute name="VALUE" x="19.67" y="61.105" size="1.27" layer="28" font="vector" ratio="10" rot="MR180"/>
</element>
<element name="R15" library="R0805_12.1Ohm_0.1%" package="R0805" value="R0805_12.1OHM_0.1%" x="21.285" y="55.0175" smashed="yes" rot="MR270">
<attribute name="MPN" value="RQ73C2A12R1BTD" x="21.285" y="55.0175" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="NAME" x="19.99" y="56.59" size="1.27" layer="26" font="vector" ratio="10" rot="MR270"/>
<attribute name="VALUE" x="23.825" y="55.6525" size="1.27" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="R1" library="R0805_191k_0.1%" package="R0805" value="R0805_191K_0.1%" x="19.32" y="65.2475" smashed="yes">
<attribute name="MPN" value="ERA-6AEB1913V" x="19.32" y="65.2475" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="17.885" y="62.8425" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="18.685" y="62.7075" size="1.27" layer="27" font="vector" ratio="10"/>
</element>
<element name="R29" library="R0805_52.3Ohm_0.1%" package="R0805" value="R0805_52.3OHM_0.1%" x="12.12" y="41.7225" smashed="yes" rot="MR0">
<attribute name="MPN" value="ERA-6AEB52R3V" x="12.12" y="41.7225" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="NAME" x="11.1675" y="42.78" size="1.27" layer="26" font="vector" ratio="10" rot="MR0"/>
<attribute name="VALUE" x="12.755" y="39.1825" size="1.27" layer="28" font="vector" ratio="10" rot="MR0"/>
</element>
<element name="R18" library="R0805_0Ohm" package="R0805" value="R0805_0OHM" x="33.1175" y="60.595" smashed="yes" rot="R90">
<attribute name="MPN" value="RMCF0805ZT0R00" x="33.1175" y="60.595" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="30.8025" y="62.5775" size="1.27" layer="25" font="vector" ratio="10" rot="R270"/>
<attribute name="VALUE" x="35.6575" y="59.96" size="1.27" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
<element name="R24" library="R0805_0Ohm" package="R0805" value="R0805_0OHM" x="36.145" y="56.835" smashed="yes">
<attribute name="MPN" value="RMCF0805ZT0R00" x="36.145" y="56.835" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="32.5775" y="57.42" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="35.51" y="54.295" size="1.27" layer="27" font="vector" ratio="10"/>
</element>
<element name="X1" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" package="W237-132" package3d_urn="urn:adsk.eagle:package:10734/1" value="" x="55.0625" y="44.575" smashed="yes" rot="R90">
<attribute name="MF" value="" x="55.0625" y="44.575" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="55.0625" y="44.575" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="59.935" y="39.0555" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="55.0625" y="44.575" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="55.0625" y="44.575" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="62.0475" y="40.765" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="IC12" library="RFDuino" package="RFDUINO" value="RFDUINO" x="34.8625" y="12.0625" smashed="yes" rot="R270">
<attribute name="NAME" x="54.1445" y="11.6645" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="22.5435" y="9.0145" size="1.27" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
</elements>
<signals>
<signal name="GND" airwireshidden="yes">
<contactref element="IC5" pad="4"/>
<contactref element="C11" pad="2"/>
<contactref element="C10" pad="2"/>
<contactref element="C6" pad="1"/>
<contactref element="C9" pad="1"/>
<contactref element="IC2" pad="1"/>
<contactref element="C4" pad="2"/>
<contactref element="C5" pad="1"/>
<contactref element="IC3" pad="P$3"/>
<contactref element="C7" pad="2"/>
<contactref element="C8" pad="2"/>
<contactref element="IC4" pad="12"/>
<contactref element="IC4" pad="8"/>
<contactref element="IC1" pad="2"/>
<contactref element="C1" pad="2"/>
<contactref element="C2" pad="2"/>
<contactref element="C3" pad="2"/>
<contactref element="C12" pad="2"/>
<contactref element="C13" pad="2"/>
<contactref element="C15" pad="2"/>
<contactref element="D3" pad="A"/>
<contactref element="D2" pad="C"/>
<contactref element="IC6" pad="4"/>
<contactref element="C14" pad="2"/>
<contactref element="C17" pad="2"/>
<contactref element="IC11" pad="7"/>
<contactref element="IC11" pad="12"/>
<contactref element="C18" pad="2"/>
<contactref element="IC9" pad="4"/>
<contactref element="C16" pad="1"/>
<contactref element="Q2" pad="1"/>
<contactref element="Q1" pad="1"/>
<contactref element="C20" pad="2"/>
<contactref element="IC10" pad="P$4"/>
<contactref element="C19" pad="1"/>
<contactref element="R36" pad="1"/>
<contactref element="R33" pad="1"/>
<contactref element="R35" pad="2"/>
<contactref element="R37" pad="2"/>
<contactref element="R34" pad="2"/>
<contactref element="R38" pad="2"/>
<contactref element="Q4" pad="2"/>
<contactref element="Q3" pad="1"/>
<contactref element="R22" pad="1"/>
<contactref element="R16" pad="1"/>
<contactref element="R29" pad="1"/>
<contactref element="X1" pad="1"/>
<wire x1="55.6975" y1="42.035" x2="52.815" y2="42.035" width="1.8" layer="1"/>
<wire x1="52.815" y1="42.035" x2="51.775" y2="43.075" width="1.8" layer="1"/>
<wire x1="51.775" y1="43.075" x2="51.775" y2="46.8" width="1.8" layer="1"/>
<wire x1="51.775" y1="46.8" x2="49.5875" y2="48.9875" width="1.8" layer="1"/>
<wire x1="49.5875" y1="48.9875" x2="48.272503125" y2="48.9875" width="1.8" layer="1"/>
<wire x1="44.1975" y1="48.9875" x2="45.555834375" y2="48.9875" width="1.8" layer="1"/>
<wire x1="46.91416875" y1="48.9875" x2="48.272503125" y2="48.9875" width="1.8" layer="1"/>
<wire x1="43.2" y1="36.475" x2="41.9625" y2="37.7125" width="1.8" layer="1"/>
<wire x1="43.2" y1="36.475" x2="45.3625" y2="36.475" width="1.8" layer="1"/>
<wire x1="45.3625" y1="36.475" x2="45.375" y2="36.4625" width="1.8" layer="1"/>
<wire x1="45.3625" y1="36.475" x2="46.0275" y2="36.475" width="0.254" layer="1"/>
<wire x1="46.0275" y1="36.475" x2="46.035" y2="36.4825" width="0.254" layer="1"/>
<wire x1="46.91416875" y1="48.9875" x2="45.555834375" y2="48.9875" width="1.8" layer="1"/>
<wire x1="41.9625" y1="37.7125" x2="41.9625" y2="39.8125" width="1.8" layer="1"/>
<wire x1="43.5875" y1="41.4375" x2="44.9875" y2="41.4375" width="1.8" layer="1"/>
<wire x1="44.9875" y1="41.4375" x2="47.0125" y2="43.4625" width="1.8" layer="1"/>
<wire x1="41.9625" y1="39.8125" x2="43.5875" y2="41.4375" width="1.8" layer="1"/>
<wire x1="46.91416875" y1="48.9875" x2="47.0125" y2="48.88916875" width="1.8" layer="1"/>
<wire x1="47.0125" y1="48.88916875" x2="47.0125" y2="43.4625" width="1.8" layer="1"/>
<wire x1="38.5825" y1="34.27" x2="38.5825" y2="40.6975" width="1.8" layer="1"/>
<wire x1="44.1975" y1="46.3125" x2="44.1975" y2="48.9875" width="1.8" layer="1"/>
<wire x1="44.1975" y1="46.3125" x2="38.5825" y2="40.6975" width="1.8" layer="1"/>
<wire x1="53.065" y1="54.3075" x2="51.53" y2="54.3075" width="0.508" layer="16"/>
<wire x1="51.53" y1="54.3075" x2="51.075" y2="54.7625" width="0.508" layer="16"/>
<wire x1="51.075" y1="54.7625" x2="51.075" y2="59.9475" width="0.508" layer="16"/>
<wire x1="51.075" y1="59.9475" x2="51.07" y2="59.9525" width="0.4064" layer="16"/>
<wire x1="51.07" y1="59.9525" x2="50.24" y2="59.9525" width="0.8128" layer="16"/>
<wire x1="50.24" y1="59.9525" x2="49.7375" y2="59.45" width="0.8128" layer="16"/>
<wire x1="49.7375" y1="59.45" x2="49.7375" y2="52.014996875" width="0.8128" layer="16"/>
<wire x1="49.7375" y1="52.014996875" x2="48.272503125" y2="50.55" width="0.8128" layer="16"/>
<wire x1="48.272503125" y1="50.55" x2="48.272503125" y2="48.9875" width="0.8128" layer="16"/>
<wire x1="46.8375" y1="46.165" x2="47.74" y2="46.165" width="0.8128" layer="16"/>
<wire x1="47.74" y1="46.165" x2="48.2875" y2="46.7125" width="0.8128" layer="16"/>
<wire x1="48.2875" y1="46.7125" x2="48.2875" y2="48.972503125" width="0.8128" layer="16"/>
<wire x1="48.2875" y1="48.972503125" x2="48.272503125" y2="48.9875" width="0.8128" layer="16"/>
<wire x1="44.3775" y1="46.5875" x2="42.415" y2="46.5875" width="0.8128" layer="16"/>
<wire x1="44.3775" y1="46.5875" x2="45.425" y2="46.5875" width="0.8128" layer="16"/>
<wire x1="45.425" y1="46.5875" x2="45.85" y2="46.1625" width="0.8128" layer="16"/>
<wire x1="46.8375" y1="46.165" x2="46.835" y2="46.1625" width="0.8128" layer="16"/>
<wire x1="46.835" y1="46.1625" x2="45.85" y2="46.1625" width="0.8128" layer="16"/>
<wire x1="48.272503125" y1="48.9875" x2="48.3125" y2="48.9875" width="0.8128" layer="16"/>
<wire x1="48.3125" y1="48.9875" x2="49.0125" y2="48.9875" width="0.8128" layer="16"/>
<wire x1="50.1175" y1="49.775" x2="49.8" y2="49.775" width="0.8128" layer="16"/>
<wire x1="49.8" y1="49.775" x2="49.0125" y2="48.9875" width="0.8128" layer="16"/>
<wire x1="13.1175" y1="59.54" x2="16.235" y2="59.54" width="0.8" layer="16"/>
<wire x1="16.235" y1="59.54" x2="16.7125" y2="59.0625" width="0.8" layer="16"/>
<wire x1="16.7125" y1="59.0625" x2="16.7125" y2="57.085" width="0.8" layer="16"/>
<wire x1="16.7125" y1="57.085" x2="16.71" y2="57.0825" width="0.8" layer="16"/>
<wire x1="55.2875" y1="37.555" x2="55.2875" y2="39.5125" width="0.4064" layer="1"/>
<wire x1="55.2875" y1="39.5125" x2="54.65" y2="40.15" width="0.4064" layer="1"/>
<wire x1="54.65" y1="40.15" x2="52.1375" y2="40.15" width="0.4064" layer="1"/>
<wire x1="52.1375" y1="40.15" x2="49.8875" y2="42.4" width="0.4064" layer="1"/>
<wire x1="49.8875" y1="42.4" x2="49.8875" y2="45.9125" width="0.4064" layer="1"/>
<wire x1="49.8875" y1="45.9125" x2="48.275" y2="47.525" width="0.4064" layer="1"/>
<wire x1="48.275" y1="47.525" x2="48.275" y2="48.985003125" width="0.4064" layer="1"/>
<wire x1="48.275" y1="48.985003125" x2="48.272503125" y2="48.9875" width="0.4064" layer="1"/>
<wire x1="19.355" y1="58.565" x2="19.355" y2="57.4425" width="0.8" layer="16"/>
<wire x1="19.355" y1="57.4425" x2="18.995" y2="57.0825" width="0.8" layer="16"/>
<wire x1="14.3875" y1="41.3" x2="14.3875" y2="39.345" width="0.8" layer="16"/>
<wire x1="14.3875" y1="39.345" x2="16.72" y2="39.345" width="0.8" layer="16"/>
<wire x1="16.72" y1="39.345" x2="16.71" y2="39.355" width="0.8" layer="16"/>
<wire x1="16.71" y1="39.355" x2="16.71" y2="39.36" width="0.8" layer="16"/>
<wire x1="44.1975" y1="49.2" x2="44.1975" y2="48.9875" width="1" layer="1"/>
<wire x1="44.1975" y1="49.2" x2="43.3225" y2="50.075" width="1" layer="1"/>
<wire x1="43.3225" y1="50.075" x2="42.4625" y2="50.075" width="1" layer="1"/>
<wire x1="33.1175" y1="65.275" x2="31.0875" y2="65.275" width="1" layer="1"/>
<wire x1="43.5725" y1="65.2625" x2="42.5" y2="65.2625" width="1" layer="1"/>
<wire x1="42.5" y1="65.2625" x2="41.8625" y2="65.9" width="1" layer="1"/>
<wire x1="41.8625" y1="65.9" x2="35.425" y2="65.9" width="1" layer="1"/>
<wire x1="35.425" y1="65.9" x2="34.8125" y2="65.2875" width="1" layer="1"/>
<wire x1="34.8125" y1="65.2875" x2="33.13" y2="65.2875" width="1" layer="1"/>
<wire x1="33.13" y1="65.2875" x2="33.1175" y2="65.275" width="1" layer="1"/>
<wire x1="26.4875" y1="65.25" x2="26.4875" y2="66.9" width="1" layer="1"/>
<wire x1="26.4875" y1="66.9" x2="27.075" y2="67.4875" width="1" layer="1"/>
<wire x1="27.075" y1="67.4875" x2="30.475" y2="67.4875" width="1" layer="1"/>
<wire x1="30.475" y1="67.4875" x2="30.525" y2="67.4375" width="1" layer="1"/>
<wire x1="30.525" y1="67.4375" x2="31.0875" y2="66.875" width="1" layer="1"/>
<wire x1="31.0875" y1="66.875" x2="31.0875" y2="65.275" width="1" layer="1"/>
<wire x1="25.875" y1="62.67" x2="26.7125" y2="62.67" width="1" layer="1"/>
<wire x1="26.7125" y1="62.67" x2="27.175" y2="62.67" width="1" layer="1"/>
<wire x1="26.4875" y1="65.25" x2="26.4875" y2="62.495" width="1.5" layer="1"/>
<wire x1="26.4875" y1="62.495" x2="26.5125" y2="62.47" width="1" layer="1"/>
<wire x1="24.4825" y1="60.2" x2="26.225" y2="60.2" width="1.5" layer="1"/>
<wire x1="26.5025" y1="60.48" x2="26.5025" y2="60.4775" width="1.5" layer="1"/>
<wire x1="26.5025" y1="60.4775" x2="26.225" y2="60.2" width="1.5" layer="1"/>
<wire x1="26.5025" y1="60.48" x2="26.5025" y2="62.46" width="1.5" layer="1"/>
<wire x1="26.5025" y1="62.46" x2="26.5125" y2="62.47" width="1" layer="1"/>
<wire x1="26.5125" y1="62.47" x2="26.7125" y2="62.67" width="1" layer="1"/>
<wire x1="22.525" y1="60.2" x2="24.4825" y2="60.2" width="1.5" layer="1"/>
<wire x1="23.4425" y1="45.075" x2="23.4425" y2="47.245" width="1.5" layer="1"/>
<wire x1="23.4425" y1="47.245" x2="21.3125" y2="49.375" width="1.5" layer="1"/>
<wire x1="23.4425" y1="44.4125" x2="23.455" y2="44.4" width="1" layer="1"/>
<wire x1="44.1975" y1="48.9875" x2="43.4225" y2="48.2125" width="1.8" layer="1"/>
<wire x1="43.81" y1="48.2125" x2="43.4225" y2="48.2125" width="1.8" layer="1"/>
<wire x1="43.4225" y1="48.2125" x2="41.686775" y2="48.2125" width="1.8" layer="1"/>
<wire x1="41.686775" y1="48.2125" x2="39.174275" y2="45.7" width="1.8" layer="1"/>
<wire x1="23.4375" y1="43.7" x2="23.4375" y2="45" width="1.8" layer="1"/>
<wire x1="23.4375" y1="45" x2="23.45" y2="45.0125" width="1.8" layer="1"/>
<wire x1="18.995" y1="57.0825" x2="16.71" y2="57.0825" width="0.8" layer="16"/>
<wire x1="7.115" y1="65.1425" x2="12.12" y2="65.1425" width="0.4064" layer="1"/>
<wire x1="12.12" y1="65.1425" x2="14.1625" y2="63.1" width="0.4064" layer="1"/>
<wire x1="14.1625" y1="63.1" x2="14.1625" y2="48.725" width="0.4064" layer="1"/>
<wire x1="16.71" y1="57.0825" x2="14.12" y2="57.0825" width="0.8" layer="16"/>
<wire x1="14.12" y1="57.0825" x2="14.1125" y2="57.075" width="0.8" layer="16"/>
<wire x1="21.3125" y1="49.375" x2="21.3125" y2="58.9875" width="1.5" layer="1"/>
<wire x1="21.3125" y1="58.9875" x2="22.525" y2="60.2" width="1.5" layer="1"/>
<wire x1="14.1625" y1="48.725" x2="16.3125" y2="46.575" width="0.4064" layer="1"/>
<wire x1="18.3625" y1="46.575" x2="20.5125" y2="44.425" width="0.4064" layer="1"/>
<wire x1="23.4425" y1="44.4125" x2="23.43" y2="44.425" width="0.4064" layer="1"/>
<wire x1="23.43" y1="44.425" x2="20.5125" y2="44.425" width="0.4064" layer="1"/>
<wire x1="16.3125" y1="46.575" x2="18.3625" y2="46.575" width="0.4064" layer="1"/>
<wire x1="13.07" y1="41.7225" x2="13.965" y2="41.7225" width="0.8" layer="16"/>
<wire x1="13.965" y1="41.7225" x2="14.3875" y2="41.3" width="0.8" layer="16"/>
<wire x1="19.39625" y1="56.32125" x2="18.635" y2="57.0825" width="0.8" layer="1"/>
<wire x1="16.71" y1="57.0825" x2="18.635" y2="57.0825" width="0.8" layer="1"/>
<wire x1="19.39625" y1="56.32125" x2="19.39625" y2="47.47875" width="0.8" layer="1"/>
<wire x1="30.525" y1="67.4375" x2="43.2125" y2="67.4375" width="1" layer="1"/>
<wire x1="43.2125" y1="67.4375" x2="43.7625" y2="66.8875" width="1" layer="1"/>
<wire x1="43.7625" y1="66.8875" x2="43.7625" y2="65.4525" width="1" layer="1"/>
<wire x1="43.7625" y1="65.4525" x2="43.5725" y2="65.2625" width="1" layer="1"/>
<wire x1="31.0875" y1="66.875" x2="42.5125" y2="66.875" width="1" layer="1"/>
<wire x1="42.5125" y1="66.875" x2="43.2125" y2="66.175" width="1" layer="1"/>
<wire x1="43.2125" y1="66.175" x2="42.9125" y2="65.875" width="1" layer="1"/>
<wire x1="42.9125" y1="65.875" x2="42.9125" y2="65.8625" width="1" layer="1"/>
<wire x1="42.9125" y1="65.8625" x2="42.7" y2="65.8625" width="1" layer="1"/>
<wire x1="42.7" y1="65.8625" x2="42.3375" y2="66.225" width="1" layer="1"/>
<wire x1="42.3375" y1="66.225" x2="31.8125" y2="66.225" width="1" layer="1"/>
<wire x1="31.8125" y1="66.225" x2="31.6375" y2="66.05" width="1" layer="1"/>
<wire x1="30.0875" y1="45.7" x2="28.8" y2="44.4125" width="1.8" layer="1"/>
<wire x1="28.8" y1="44.4125" x2="23.4425" y2="44.4125" width="1.8" layer="1"/>
<wire x1="39.174275" y1="45.7" x2="30.0875" y2="45.7" width="1.8" layer="1"/>
<wire x1="16.71" y1="39.36" x2="21.035" y2="39.36" width="1.5" layer="1"/>
<wire x1="21.035" y1="39.36" x2="23.425" y2="41.75" width="1.5" layer="1"/>
<wire x1="23.425" y1="41.75" x2="23.425" y2="43.6875" width="1.5" layer="1"/>
<wire x1="23.425" y1="43.6875" x2="23.4375" y2="43.7" width="1.5" layer="1"/>
<wire x1="19.39625" y1="47.47875" x2="21.7625" y2="45.1125" width="0.8" layer="1"/>
<wire x1="21.7625" y1="45.1125" x2="23.325" y2="45.1125" width="0.8" layer="1"/>
<wire x1="23.325" y1="45.1125" x2="23.4375" y2="45" width="0.8" layer="1"/>
<contactref element="IC3" pad="P$4"/>
<wire x1="34.595" y1="42.3025" x2="36.5625" y2="42.3025" width="0.8128" layer="1"/>
<wire x1="36.5625" y1="42.3025" x2="37.9" y2="42.3025" width="0.8128" layer="1"/>
<wire x1="37.9" y1="42.3025" x2="43.81" y2="48.2125" width="0.8128" layer="1"/>
<wire x1="36.56" y1="41.725" x2="36.5625" y2="41.7275" width="0.8128" layer="1"/>
<wire x1="36.5625" y1="41.7275" x2="36.5625" y2="42.3025" width="0.8128" layer="1"/>
<wire x1="34.595" y1="42.3025" x2="33.115" y2="42.3025" width="0.8128" layer="1"/>
<wire x1="32.6875" y1="41.875" x2="32.6875" y2="41.05" width="0.8128" layer="1"/>
<wire x1="32.6875" y1="41.05" x2="32.6875" y2="38.6375" width="0.8128" layer="1"/>
<wire x1="32.6875" y1="38.6375" x2="32.6875" y2="36.845" width="0.8128" layer="1"/>
<wire x1="33.115" y1="42.3025" x2="32.6875" y2="41.875" width="0.8128" layer="1"/>
<wire x1="34.595" y1="41.0325" x2="32.705" y2="41.0325" width="0.8128" layer="1"/>
<wire x1="32.705" y1="41.0325" x2="32.6875" y2="41.05" width="0.8128" layer="1"/>
<wire x1="29.175" y1="37.5375" x2="31.5875" y2="37.5375" width="0.4064" layer="16"/>
<wire x1="31.5875" y1="37.5375" x2="32.6875" y2="38.6375" width="0.4064" layer="16"/>
<via x="32.6875" y="38.6375" extent="1-16" drill="0.35"/>
<wire x1="29.1325" y1="38.935" x2="29.1325" y2="37.58" width="0.254" layer="16"/>
<wire x1="29.1325" y1="37.58" x2="29.175" y2="37.5375" width="0.254" layer="16"/>
<wire x1="24.955" y1="37.5375" x2="24.8425" y2="37.425" width="0.254" layer="16"/>
<wire x1="29.175" y1="37.5375" x2="24.955" y2="37.5375" width="0.4064" layer="16"/>
<wire x1="24.8425" y1="37.425" x2="24.8425" y2="38.305" width="0.254" layer="16"/>
<wire x1="24.8425" y1="38.305" x2="25.025" y2="38.4875" width="0.254" layer="16"/>
<wire x1="25.025" y1="38.4875" x2="25.575" y2="38.4875" width="0.254" layer="16"/>
<wire x1="25.575" y1="38.4875" x2="26.025" y2="38.9375" width="0.254" layer="16"/>
<wire x1="26.025" y1="38.9375" x2="26.53" y2="38.9375" width="0.254" layer="16"/>
<wire x1="26.53" y1="38.9375" x2="26.5325" y2="38.935" width="0.254" layer="16"/>
<wire x1="27.66" y1="35.535" x2="27.66" y2="37.16" width="0.3048" layer="1"/>
<wire x1="28.1125" y1="37.6125" x2="30.8" y2="37.6125" width="0.508" layer="1"/>
<wire x1="30.8" y1="37.6125" x2="31.825" y2="38.6375" width="0.508" layer="1"/>
<wire x1="31.825" y1="38.6375" x2="32.6875" y2="38.6375" width="0.508" layer="1"/>
<wire x1="27.66" y1="37.16" x2="28.1125" y2="37.6125" width="0.3048" layer="1"/>
<wire x1="27.66" y1="35.535" x2="27.66" y2="32.1775" width="0.3048" layer="1"/>
<wire x1="28.1625" y1="31.675" x2="29.8375" y2="31.675" width="0.3048" layer="1"/>
<wire x1="29.8375" y1="31.675" x2="30.2725" y2="31.24" width="0.3048" layer="1"/>
<wire x1="30.2725" y1="31.24" x2="30.2725" y2="29.8975" width="0.3048" layer="1"/>
<wire x1="30.2725" y1="29.8975" x2="30.26" y2="29.885" width="0.3048" layer="1"/>
<wire x1="27.66" y1="32.1775" x2="28.1625" y2="31.675" width="0.3048" layer="1"/>
<wire x1="30.26" y1="29.885" x2="30.26" y2="28.1475" width="0.3048" layer="1"/>
<wire x1="30.26" y1="28.1475" x2="30" y2="27.8875" width="0.3048" layer="1"/>
<wire x1="30" y1="27.8875" x2="29.995" y2="27.8925" width="0.3048" layer="1"/>
<wire x1="29.995" y1="27.8925" x2="29.3125" y2="27.8925" width="0.3048" layer="1"/>
<wire x1="40.325" y1="36.7375" x2="40.9475" y2="36.115" width="0.8128" layer="1"/>
<wire x1="40.325" y1="36.7375" x2="40.325" y2="40.2875" width="0.8128" layer="1"/>
<wire x1="40.325" y1="40.2875" x2="43.1125" y2="43.075" width="0.8128" layer="1"/>
<wire x1="43.1125" y1="43.075" x2="44.225" y2="43.075" width="0.8128" layer="1"/>
<wire x1="45.5875" y1="44.4375" x2="45.5875" y2="48.955834375" width="0.8128" layer="1"/>
<wire x1="45.5875" y1="48.955834375" x2="45.555834375" y2="48.9875" width="0.8128" layer="1"/>
<wire x1="44.225" y1="43.075" x2="45.5875" y2="44.4375" width="0.8128" layer="1"/>
<wire x1="31.765" y1="29.9" x2="30.275" y2="29.9" width="0.3048" layer="1"/>
<wire x1="30.275" y1="29.9" x2="30.2725" y2="29.8975" width="0.3048" layer="1"/>
<wire x1="48.2875" y1="49.0125" x2="48.3125" y2="48.9875" width="1.3" layer="16"/>
<wire x1="43.9125" y1="49.0125" x2="48.2875" y2="49.0125" width="1.3" layer="16"/>
<wire x1="4.625" y1="45.525" x2="4.625" y2="44.425" width="0.4064" layer="1"/>
<wire x1="4.625" y1="44.425" x2="5.5625" y2="43.4875" width="0.4064" layer="1"/>
<wire x1="5.5625" y1="43.4875" x2="8.7875" y2="43.4875" width="0.4064" layer="1"/>
<wire x1="8.7875" y1="43.4875" x2="9.7125" y2="44.4125" width="0.4064" layer="1"/>
<wire x1="9.7125" y1="44.4125" x2="14.575" y2="44.4125" width="0.4064" layer="1"/>
<wire x1="14.575" y1="44.4125" x2="15.075" y2="43.9125" width="0.4064" layer="1"/>
<wire x1="15.075" y1="43.9125" x2="23.225" y2="43.9125" width="0.4064" layer="1"/>
<wire x1="23.225" y1="43.9125" x2="23.4375" y2="43.7" width="0.4064" layer="1"/>
<contactref element="R28" pad="1"/>
<wire x1="42.575" y1="48.8825" x2="42.705" y2="49.0125" width="0.8128" layer="16"/>
<wire x1="42.705" y1="49.0125" x2="43.9125" y2="49.0125" width="0.8128" layer="16"/>
<wire x1="41.55" y1="50.8975" x2="41.6375" y2="50.81" width="0.4064" layer="16"/>
<wire x1="42.551275" y1="49.7036" x2="42.392375" y2="49.8625" width="0.4064" layer="16"/>
<wire x1="42.551275" y1="49.7036" x2="42.5589" y2="49.7036" width="0.4064" layer="16"/>
<wire x1="42.5589" y1="49.7036" x2="42.5625" y2="49.7" width="0.4064" layer="16"/>
<wire x1="42.5625" y1="49.7" x2="42.5625" y2="48.895" width="0.4064" layer="16"/>
<wire x1="42.5625" y1="48.895" x2="42.575" y2="48.8825" width="0.4064" layer="16"/>
<wire x1="42.392375" y1="49.8625" x2="41.7375" y2="49.8625" width="0.4064" layer="16"/>
<wire x1="41.7375" y1="49.8625" x2="41.575" y2="50.025" width="0.4064" layer="16"/>
<wire x1="41.575" y1="50.025" x2="41.575" y2="50.8725" width="0.4064" layer="16"/>
<wire x1="41.575" y1="50.8725" x2="41.55" y2="50.8975" width="0.4064" layer="16"/>
<contactref element="IC12" pad="6"/>
<wire x1="40.9475" y1="36.115" x2="40.9475" y2="24.0975" width="0.8128" layer="1"/>
<wire x1="40.9475" y1="24.0975" x2="38.825" y2="21.975" width="0.8128" layer="1"/>
<wire x1="38.825" y1="21.975" x2="37.155" y2="21.975" width="0.8128" layer="1"/>
<wire x1="37.155" y1="21.975" x2="37.1485" y2="21.9685" width="0.8128" layer="1"/>
<wire x1="30.0875" y1="45.7" x2="30.9725" y2="46.8075" width="0" layer="19" extent="1-1"/>
<wire x1="27.9875" y1="37.3725" x2="28.1125" y2="37.6125" width="0" layer="19" extent="1-1"/>
<wire x1="23.225" y1="43.9125" x2="23.43" y2="44.425" width="0" layer="19" extent="1-1"/>
<wire x1="23.4425" y1="45.075" x2="23.4375" y2="45" width="0" layer="19" extent="1-1"/>
<wire x1="27.7" y1="44.075" x2="28.8" y2="44.4125" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$1">
<contactref element="IC5" pad="5"/>
<contactref element="R12" pad="1"/>
<wire x1="47.865" y1="54.3075" x2="47.865" y2="52.71" width="0.4064" layer="16"/>
<wire x1="47.865" y1="52.71" x2="47.875" y2="52.7" width="0.4064" layer="16"/>
<via x="47.875" y="52.7" extent="1-16" drill="0.4" diameter="0.9"/>
<wire x1="47.875" y1="52.7" x2="47.875" y2="67.025" width="0.4064" layer="1"/>
<wire x1="47.875" y1="67.025" x2="46.2875" y2="68.6125" width="0.4064" layer="1"/>
<wire x1="46.2875" y1="68.6125" x2="25.9875" y2="68.6125" width="0.4064" layer="1"/>
<via x="25.9875" y="68.6125" extent="1-16" drill="0.4" diameter="0.9"/>
<wire x1="25.9875" y1="68.6125" x2="25.9875" y2="68.625" width="0.8" layer="16"/>
<wire x1="25.9875" y1="68.625" x2="14.2875" y2="68.625" width="0.8" layer="16"/>
<wire x1="9.1075" y1="63.445" x2="9.1075" y2="61.4775" width="0.8" layer="16"/>
<wire x1="14.2875" y1="68.625" x2="9.1075" y2="63.445" width="0.8" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="R12" pad="2"/>
<contactref element="C11" pad="1"/>
<contactref element="IC6" pad="5"/>
<contactref element="IC11" pad="2"/>
<wire x1="9.1075" y1="59.5775" x2="9.1075" y2="57.1" width="0.8" layer="16"/>
<wire x1="9.1075" y1="57.1" x2="9.09" y2="57.0825" width="0.8" layer="16"/>
<wire x1="9.1075" y1="59.5775" x2="9.145" y2="59.54" width="0.8" layer="16"/>
<wire x1="9.145" y1="59.54" x2="11.1175" y2="59.54" width="0.8" layer="16"/>
<wire x1="27.01" y1="29.885" x2="27.01" y2="30.665" width="0.3048" layer="1"/>
<wire x1="27.01" y1="30.665" x2="26.5875" y2="31.0875" width="0.3048" layer="1"/>
<wire x1="26.5875" y1="31.0875" x2="18.925" y2="31.0875" width="0.3048" layer="1"/>
<wire x1="18.925" y1="31.0875" x2="18.1875" y2="30.35" width="0.3048" layer="1"/>
<wire x1="18.1875" y1="30.35" x2="15.7375" y2="30.35" width="0.3048" layer="1"/>
<wire x1="15.7375" y1="30.35" x2="11.0375" y2="35.05" width="0.3048" layer="1"/>
<wire x1="11.0375" y1="35.05" x2="11.0375" y2="40.15" width="0.3048" layer="1"/>
<wire x1="11.0375" y1="40.15" x2="9.55" y2="41.6375" width="0.3048" layer="1"/>
<wire x1="9.55" y1="41.6375" x2="5.625" y2="41.6375" width="0.3048" layer="1"/>
<wire x1="5.625" y1="41.6375" x2="3.3375" y2="43.925" width="0.3048" layer="1"/>
<wire x1="3.3375" y1="43.925" x2="3.3375" y2="56.05" width="0.3048" layer="1"/>
<wire x1="3.3375" y1="56.05" x2="4.3875" y2="57.1" width="0.3048" layer="1"/>
<wire x1="4.3875" y1="57.1" x2="9.0725" y2="57.1" width="0.3048" layer="1"/>
<wire x1="9.0725" y1="57.1" x2="9.09" y2="57.0825" width="0.3048" layer="1"/>
</signal>
<signal name="N$4">
<contactref element="IC3" pad="P$1"/>
<contactref element="C6" pad="2"/>
<wire x1="34.6875" y1="38.4" x2="34.595" y2="38.4925" width="0.3048" layer="1"/>
<wire x1="34.6875" y1="36.845" x2="34.6875" y2="38.4" width="0.4064" layer="1"/>
</signal>
<signal name="N$8">
<contactref element="IC4" pad="11"/>
<contactref element="IC4" pad="13"/>
<contactref element="IC3" pad="P$7"/>
<contactref element="C9" pad="2"/>
<contactref element="IC11" pad="13"/>
<wire x1="29.775" y1="39.725" x2="29.775" y2="38.9425" width="0.254" layer="16"/>
<wire x1="29.775" y1="38.9425" x2="29.7825" y2="38.935" width="0.254" layer="16"/>
<contactref element="IC3" pad="P$6"/>
<wire x1="29.595" y1="39.7625" x2="29.595" y2="41.0325" width="0.4064" layer="1"/>
<wire x1="28.4825" y1="38.935" x2="28.4825" y2="39.7099875" width="0.254" layer="16"/>
<wire x1="28.4825" y1="39.7099875" x2="28.3250875" y2="39.8674" width="0.254" layer="16"/>
<wire x1="28.3250875" y1="39.8674" x2="28.3250875" y2="40.4924" width="0.254" layer="16"/>
<via x="28.3250875" y="40.4924" extent="1-16" drill="0.4"/>
<wire x1="28.3250875" y1="40.4924" x2="28.3250875" y2="39.9999125" width="0.254" layer="1"/>
<wire x1="28.3250875" y1="39.9999125" x2="28.5625" y2="39.7625" width="0.254" layer="1"/>
<wire x1="28.5625" y1="39.7625" x2="29.595" y2="39.7625" width="0.254" layer="1"/>
<wire x1="28.3250875" y1="40.4924" x2="29.0076" y2="40.4924" width="0.254" layer="16"/>
<wire x1="29.0076" y1="40.4924" x2="29.775" y2="39.725" width="0.254" layer="16"/>
<wire x1="27.01" y1="35.535" x2="27.01" y2="39.6975" width="0.254" layer="1"/>
<wire x1="27.01" y1="39.6975" x2="27.8049" y2="40.4924" width="0.254" layer="1"/>
<wire x1="27.8049" y1="40.4924" x2="28.3250875" y2="40.4924" width="0.254" layer="1"/>
<wire x1="27.7" y1="42.075" x2="27.7" y2="41.3875" width="0.254" layer="1"/>
<wire x1="28.3250875" y1="41.0374125" x2="28.3250875" y2="40.4924" width="0.254" layer="1"/>
<wire x1="27.7" y1="41.3875" x2="27.85" y2="41.2375" width="0.254" layer="1"/>
<wire x1="27.85" y1="41.2375" x2="28.125" y2="41.2375" width="0.254" layer="1"/>
<wire x1="28.125" y1="41.2375" x2="28.3250875" y2="41.0374125" width="0.254" layer="1"/>
</signal>
<signal name="N$5">
<contactref element="IC2" pad="2"/>
<contactref element="IC1" pad="3"/>
<contactref element="C3" pad="1"/>
<contactref element="C2" pad="1"/>
<contactref element="R31" pad="1"/>
<wire x1="29.0275" y1="65.25" x2="29.0275" y2="63.7225" width="1" layer="1"/>
<wire x1="29.0275" y1="63.7225" x2="29.175" y2="63.575" width="1" layer="1"/>
<wire x1="29.175" y1="63.575" x2="29.175" y2="62.67" width="1" layer="1"/>
<wire x1="31.0875" y1="63.275" x2="29.475" y2="63.275" width="1" layer="1"/>
<wire x1="29.475" y1="63.275" x2="29.175" y2="63.575" width="1" layer="1"/>
<wire x1="29.175" y1="62.67" x2="29.175" y2="59.9775" width="1" layer="1"/>
<wire x1="29.175" y1="59.9775" x2="28.4075" y2="59.21" width="1" layer="1"/>
<wire x1="58.35625" y1="65.70625" x2="56.125" y2="67.9375" width="0.8" layer="16"/>
<wire x1="56.125" y1="67.9375" x2="29.8" y2="67.9375" width="0.8" layer="16"/>
<wire x1="29.8" y1="67.9375" x2="29.05" y2="67.1875" width="0.8" layer="16"/>
<wire x1="29.05" y1="67.1875" x2="29.05" y2="65.2725" width="0.8" layer="16"/>
<wire x1="29.05" y1="65.2725" x2="29.0275" y2="65.25" width="0.4064" layer="16"/>
<wire x1="58.3" y1="65.65" x2="58.35" y2="65.7" width="0.508" layer="16"/>
<wire x1="58.35" y1="65.7" x2="58.35625" y2="65.70625" width="0.508" layer="16"/>
<wire x1="58.35" y1="65.7" x2="58.35" y2="40.775" width="0.8128" layer="16"/>
<wire x1="58.35" y1="40.775" x2="57.1" y2="39.525" width="0.8128" layer="16"/>
<wire x1="57.1" y1="39.525" x2="54.95" y2="39.525" width="0.8128" layer="16"/>
<wire x1="54.95" y1="39.525" x2="54.945" y2="39.52" width="0.8128" layer="16"/>
</signal>
<signal name="V+">
<contactref element="R11" pad="1"/>
<contactref element="R10" pad="1"/>
<contactref element="R2" pad="1"/>
<contactref element="R3" pad="1"/>
<contactref element="R4" pad="1"/>
<contactref element="R5" pad="1"/>
<contactref element="R6" pad="1"/>
<contactref element="R7" pad="1"/>
<contactref element="R8" pad="1"/>
<contactref element="R9" pad="1"/>
<contactref element="IC5" pad="1"/>
<contactref element="IC1" pad="1"/>
<contactref element="C1" pad="1"/>
<contactref element="IC5" pad="2"/>
<contactref element="C10" pad="1"/>
<contactref element="IC6" pad="8"/>
<contactref element="C14" pad="1"/>
<contactref element="IC9" pad="8"/>
<contactref element="C17" pad="1"/>
<contactref element="R1" pad="2"/>
<contactref element="X1" pad="2"/>
<wire x1="55.5425" y1="51.33" x2="55.5425" y2="52.850003125" width="1.8" layer="1"/>
<wire x1="55.5425" y1="52.850003125" x2="55.5425" y2="54.37000625" width="1.8" layer="1"/>
<wire x1="55.5425" y1="54.37000625" x2="55.5425" y2="55.890009375" width="1.8" layer="1"/>
<wire x1="55.5425" y1="55.890009375" x2="55.5425" y2="57.4100125" width="1.8" layer="1"/>
<wire x1="55.5425" y1="57.4100125" x2="55.5425" y2="58.930015625" width="1.8" layer="1"/>
<wire x1="55.5425" y1="60.45001875" x2="55.5425" y2="58.930015625" width="1.8" layer="1"/>
<wire x1="55.5425" y1="60.45001875" x2="55.5425" y2="61.970021875" width="1.8" layer="1"/>
<wire x1="55.5425" y1="61.970021875" x2="55.5425" y2="63.490025" width="1.8" layer="1"/>
<wire x1="55.5425" y1="63.490025" x2="55.5425" y2="65.010028125" width="1.8" layer="1"/>
<wire x1="23.9475" y1="65.25" x2="23.9475" y2="68.91" width="1.8" layer="1"/>
<wire x1="23.9475" y1="68.91" x2="25.4375" y2="70.4" width="1.8" layer="1"/>
<wire x1="25.4375" y1="70.4" x2="53.4875" y2="70.4" width="1.8" layer="1"/>
<wire x1="53.4875" y1="70.4" x2="55.5625" y2="68.325" width="1.8" layer="1"/>
<wire x1="55.5625" y1="68.325" x2="55.5425" y2="68.305" width="1.5" layer="1"/>
<wire x1="55.5425" y1="68.305" x2="55.5425" y2="65.010028125" width="1.8" layer="1"/>
<wire x1="55.6975" y1="47.115" x2="55.6975" y2="49.615" width="1.8" layer="1"/>
<wire x1="55.6975" y1="49.615" x2="55.5375" y2="49.775" width="1.8" layer="1"/>
<wire x1="55.5375" y1="49.775" x2="55.5375" y2="51.325" width="1.8" layer="1"/>
<wire x1="55.5375" y1="51.325" x2="55.5425" y2="51.33" width="1.5" layer="1"/>
<wire x1="23.875" y1="62.67" x2="23.875" y2="63.5625" width="1" layer="1"/>
<wire x1="23.875" y1="63.5625" x2="23.95" y2="63.6375" width="1" layer="1"/>
<wire x1="23.95" y1="63.6375" x2="23.95" y2="65.2475" width="1" layer="1"/>
<wire x1="23.95" y1="65.2475" x2="23.9475" y2="65.25" width="1" layer="1"/>
<wire x1="53.065" y1="58.1175" x2="55.1975125" y2="58.1175" width="0.508" layer="16"/>
<wire x1="55.5425" y1="57.7725125" x2="55.5425" y2="57.4100125" width="0.508" layer="16"/>
<wire x1="55.5425" y1="57.7725125" x2="55.1975125" y2="58.1175" width="0.508" layer="16"/>
<wire x1="53.065" y1="56.8475" x2="55.1549875" y2="56.8475" width="0.508" layer="16"/>
<wire x1="55.5425" y1="57.2350125" x2="55.5425" y2="57.4100125" width="0.508" layer="16"/>
<wire x1="55.5425" y1="57.2350125" x2="55.1549875" y2="56.8475" width="0.508" layer="16"/>
<wire x1="53.07" y1="59.9525" x2="53.07" y2="58.1225" width="0.508" layer="16"/>
<wire x1="53.065" y1="58.1175" x2="53.07" y2="58.1225" width="0.4064" layer="16"/>
<wire x1="23.9475" y1="65.25" x2="15.3375" y2="65.25" width="0.8" layer="16"/>
<wire x1="15.3375" y1="65.25" x2="12.1" y2="62.0125" width="0.8" layer="16"/>
<wire x1="12.1" y1="62.0125" x2="12.1" y2="60.875" width="0.8" layer="16"/>
<wire x1="12.1125" y1="57.075" x2="12.1125" y2="58.35" width="0.8" layer="16"/>
<wire x1="9.09" y1="31.74" x2="9.0925" y2="31.7375" width="0.8" layer="16"/>
<wire x1="12.125" y1="43.25" x2="12.125" y2="43.3125" width="0.8" layer="16"/>
<wire x1="12.125" y1="43.3125" x2="12.125" y2="49.425" width="0.8" layer="16"/>
<wire x1="12.125" y1="49.425" x2="12.125" y2="57.0625" width="0.8" layer="16"/>
<wire x1="12.125" y1="57.0625" x2="12.1125" y2="57.075" width="0.8" layer="16"/>
<wire x1="9.09" y1="49.4625" x2="12.0875" y2="49.4625" width="0.8" layer="16"/>
<wire x1="12.0875" y1="49.4625" x2="12.125" y2="49.425" width="0.8" layer="16"/>
<wire x1="12.3875" y1="39.575" x2="12.3875" y2="38.2875" width="0.8" layer="16"/>
<wire x1="12.3875" y1="38.2875" x2="12.125" y2="38.025" width="0.8" layer="16"/>
<wire x1="12.125" y1="38.025" x2="12.125" y2="32.825" width="0.8" layer="16"/>
<wire x1="12.125" y1="32.825" x2="11.025" y2="31.725" width="0.8" layer="16"/>
<wire x1="11.025" y1="31.725" x2="9.105" y2="31.725" width="0.8" layer="16"/>
<wire x1="9.105" y1="31.725" x2="9.09" y2="31.74" width="0.8" layer="16"/>
<wire x1="20.27" y1="65.2475" x2="23.945" y2="65.2475" width="0.8" layer="1"/>
<wire x1="23.945" y1="65.2475" x2="23.9475" y2="65.25" width="0.8" layer="1"/>
<wire x1="55.55" y1="51.2875" x2="55.55" y2="65.05" width="1.3" layer="16"/>
<via x="12.1125" y="58.35" extent="1-16" drill="0.4"/>
<via x="12.1" y="60.8875" extent="1-16" drill="0.4"/>
<wire x1="12.1" y1="60.8875" x2="12.1" y2="58.3625" width="0.8128" layer="1"/>
<wire x1="12.1" y1="58.3625" x2="12.1125" y2="58.35" width="0.8128" layer="1"/>
<via x="12.125" y="38.025" extent="1-16" drill="0.508"/>
<via x="12.125" y="43.3125" extent="1-16" drill="0.508"/>
<wire x1="12.125" y1="38.025" x2="12.125" y2="43.325" width="0.8128" layer="1"/>
<wire x1="55.5375" y1="51.325" x2="55.55" y2="51.2875" width="0" layer="19" extent="1-16"/>
<wire x1="12.1" y1="60.8875" x2="12.1" y2="60.875" width="0" layer="19" extent="16-16"/>
<wire x1="12.125" y1="43.325" x2="12.125" y2="43.3125" width="0" layer="19" extent="1-16"/>
<wire x1="12.3875" y1="39.345" x2="12.3875" y2="39.575" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$11">
<contactref element="R11" pad="2"/>
<contactref element="R2" pad="2"/>
<contactref element="R3" pad="2"/>
<contactref element="R4" pad="2"/>
<contactref element="R5" pad="2"/>
<contactref element="R6" pad="2"/>
<contactref element="R7" pad="2"/>
<contactref element="R8" pad="2"/>
<contactref element="R9" pad="2"/>
<contactref element="R10" pad="2"/>
<contactref element="IC5" pad="8"/>
<contactref element="IC7" pad="5"/>
<contactref element="D1" pad="C"/>
<contactref element="C12" pad="1"/>
<contactref element="IC7" pad="4"/>
<wire x1="45.3825" y1="51.33" x2="45.3825" y2="52.850003125" width="1.5" layer="1"/>
<wire x1="45.3825" y1="52.850003125" x2="45.3825" y2="54.37000625" width="1.5" layer="1"/>
<wire x1="45.3825" y1="54.37000625" x2="45.3825" y2="55.890009375" width="1.5" layer="1"/>
<wire x1="45.3825" y1="55.890009375" x2="45.3825" y2="57.4100125" width="1.5" layer="1"/>
<wire x1="45.3825" y1="65.010028125" x2="45.3825" y2="63.490025" width="1.5" layer="1"/>
<wire x1="45.3825" y1="63.490025" x2="45.3825" y2="61.970021875" width="1.5" layer="1"/>
<wire x1="45.3825" y1="61.970021875" x2="45.3825" y2="60.45001875" width="1.5" layer="1"/>
<wire x1="45.3825" y1="60.45001875" x2="45.3825" y2="58.930015625" width="1.5" layer="1"/>
<wire x1="45.3825" y1="58.930015625" x2="45.3825" y2="57.4100125" width="1.5" layer="1"/>
<wire x1="45.154975" y1="63.2625" x2="45.3825" y2="63.490025" width="0.8128" layer="1"/>
<wire x1="39.675" y1="64.625" x2="39.375" y2="64.325" width="1" layer="1"/>
<wire x1="39.375" y1="64.325" x2="39.375" y2="62.2625" width="1" layer="1"/>
<wire x1="39.375" y1="62.2625" x2="40.4875" y2="61.15" width="1" layer="1"/>
<wire x1="40.4875" y1="61.15" x2="40.4875" y2="56.0625" width="1" layer="1"/>
<wire x1="40.4875" y1="56.0625" x2="39.975" y2="55.55" width="1" layer="1"/>
<wire x1="39.975" y1="55.55" x2="39.975" y2="54.325" width="1" layer="1"/>
<wire x1="39.975" y1="54.325" x2="40.375" y2="53.925" width="1" layer="1"/>
<wire x1="40.375" y1="53.925" x2="43.625" y2="53.925" width="1" layer="1"/>
<wire x1="43.625" y1="53.925" x2="43.925" y2="54.225" width="1" layer="1"/>
<wire x1="43.925" y1="54.225" x2="43.925" y2="56.6" width="1" layer="1"/>
<wire x1="43.925" y1="56.6" x2="44.325" y2="57" width="1" layer="1"/>
<wire x1="44.325" y1="57" x2="44.9875" y2="57" width="1" layer="1"/>
<wire x1="44.9875" y1="57" x2="44.9875" y2="59.3875" width="1" layer="1"/>
<wire x1="44.9875" y1="59.3875" x2="44.3125" y2="59.3875" width="1" layer="1"/>
<wire x1="44.3125" y1="59.3875" x2="43.7375" y2="59.9625" width="1" layer="1"/>
<wire x1="43.7375" y1="59.9625" x2="43.7375" y2="61.725" width="1" layer="1"/>
<wire x1="43.7375" y1="61.725" x2="43.5375" y2="61.925" width="1" layer="1"/>
<wire x1="43.5375" y1="61.925" x2="42.2" y2="61.925" width="1" layer="1"/>
<wire x1="42.2" y1="61.925" x2="41.7125" y2="62.4125" width="1" layer="1"/>
<wire x1="41.7125" y1="62.4125" x2="41.7125" y2="64.225" width="1" layer="1"/>
<wire x1="41.7125" y1="64.225" x2="41.3125" y2="64.625" width="1" layer="1"/>
<wire x1="41.3125" y1="64.625" x2="39.675" y2="64.625" width="1" layer="1"/>
<wire x1="40.025" y1="64.25" x2="40.025" y2="62.7" width="1" layer="1"/>
<wire x1="40.025" y1="62.7" x2="41.15" y2="61.575" width="1" layer="1"/>
<wire x1="41.15" y1="61.575" x2="41.15" y2="55.7125" width="1" layer="1"/>
<wire x1="41.15" y1="55.7125" x2="40.75" y2="55.3125" width="1" layer="1"/>
<wire x1="40.75" y1="55.3125" x2="40.75" y2="54.8625" width="1" layer="1"/>
<wire x1="40.75" y1="54.8625" x2="40.8875" y2="54.725" width="1" layer="1"/>
<wire x1="40.8875" y1="54.725" x2="40.9625" y2="54.8" width="1" layer="1"/>
<wire x1="40.9625" y1="54.8" x2="43.15" y2="54.8" width="1" layer="1"/>
<wire x1="43.15" y1="54.8" x2="43.15" y2="56.9" width="1" layer="1"/>
<wire x1="43.15" y1="56.9" x2="43.875" y2="57.625" width="1" layer="1"/>
<wire x1="43.875" y1="57.625" x2="44.175" y2="57.625" width="1" layer="1"/>
<wire x1="44.175" y1="57.625" x2="44.175" y2="58.6125" width="1" layer="1"/>
<wire x1="44.175" y1="58.6125" x2="43.1125" y2="59.675" width="1" layer="1"/>
<wire x1="43.1125" y1="59.675" x2="43.0875" y2="59.675" width="1" layer="1"/>
<wire x1="43.0875" y1="59.675" x2="42.925" y2="59.8375" width="1" layer="1"/>
<wire x1="42.925" y1="59.8375" x2="42.925" y2="61.125" width="1" layer="1"/>
<wire x1="42.925" y1="61.125" x2="42.225" y2="61.125" width="1" layer="1"/>
<wire x1="42.225" y1="61.125" x2="40.8625" y2="62.4875" width="1" layer="1"/>
<wire x1="40.8625" y1="62.4875" x2="40.8625" y2="63.3625" width="1" layer="1"/>
<wire x1="40.8625" y1="63.3625" x2="40.8625" y2="63.9375" width="1" layer="1"/>
<wire x1="40.8625" y1="62.4875" x2="40.8625" y2="61.8" width="1" layer="1"/>
<wire x1="40.8625" y1="61.8" x2="41.975" y2="60.6875" width="1" layer="1"/>
<wire x1="41.975" y1="60.6875" x2="41.975" y2="55.6125" width="1" layer="1"/>
<wire x1="41.975" y1="55.6125" x2="41.7625" y2="55.4" width="1" layer="1"/>
<wire x1="41.7" y1="55.3375" x2="41.7625" y2="55.4" width="1" layer="1"/>
<wire x1="41.7625" y1="55.4" x2="42.45" y2="55.4" width="1" layer="1"/>
<wire x1="42.45" y1="55.4" x2="42.45" y2="59.3625" width="1" layer="1"/>
<wire x1="42.45" y1="59.3625" x2="43.3625" y2="58.45" width="1" layer="1"/>
<wire x1="43.3625" y1="58.45" x2="43.0375" y2="58.125" width="1" layer="1"/>
<wire x1="43.0375" y1="58.125" x2="43.0375" y2="57.7625" width="1" layer="1"/>
<wire x1="43.5725" y1="63.2625" x2="40.9625" y2="63.2625" width="1" layer="1"/>
<wire x1="40.9625" y1="63.2625" x2="40.8625" y2="63.3625" width="1" layer="1"/>
<wire x1="47.865" y1="58.1175" x2="45.5899875" y2="58.1175" width="0.508" layer="16"/>
<wire x1="45.5899875" y1="58.1175" x2="45.3825" y2="57.9100125" width="0.508" layer="16"/>
<wire x1="45.3825" y1="57.9100125" x2="45.3825" y2="57.4100125" width="0.508" layer="16"/>
<wire x1="45.375" y1="51.325" x2="45.375" y2="65.075" width="1.3" layer="16"/>
<wire x1="42.45" y1="59.3625" x2="41.9225" y2="59.37" width="0" layer="19" extent="1-1"/>
<wire x1="41.8475" y1="55.07" x2="41.7" y2="55.3375" width="0" layer="19" extent="1-1"/>
<wire x1="39.675" y1="64.625" x2="40.025" y2="64.25" width="0" layer="19" extent="1-1"/>
<wire x1="45.3825" y1="57.4100125" x2="44.9875" y2="57" width="0" layer="19" extent="1-16"/>
<wire x1="45.375" y1="51.325" x2="45.3825" y2="51.33" width="0" layer="19" extent="16-16"/>
<wire x1="40.2225" y1="63.27" x2="40.025" y2="62.7" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="OUT">
<contactref element="IC7" pad="3"/>
<contactref element="D1" pad="A"/>
<contactref element="C15" pad="1"/>
<contactref element="IC8" pad="1"/>
<contactref element="D3" pad="C"/>
<contactref element="R25" pad="2"/>
<contactref element="R24" pad="2"/>
<via x="34.7625" y="49.5375" extent="1-16" drill="2.5" diameter="5"/>
<wire x1="38.5575" y1="49.535" x2="38.5825" y2="49.51" width="1.27" layer="1"/>
<wire x1="34.7625" y1="49.5375" x2="38.555" y2="49.5375" width="2.2" layer="1"/>
<wire x1="38.555" y1="49.5375" x2="38.5575" y2="49.535" width="2.2" layer="1"/>
<wire x1="26.5625" y1="52.1" x2="26.5625" y2="55.05" width="1" layer="1"/>
<wire x1="26.6075" y1="55.07" x2="26.5825" y2="55.07" width="1" layer="1"/>
<wire x1="26.5825" y1="55.07" x2="26.5625" y2="55.05" width="1" layer="1"/>
<wire x1="34.7375" y1="49.5625" x2="34.7625" y2="49.5375" width="1" layer="1"/>
<wire x1="38.7875" y1="59.9125" x2="38.7875" y2="57.0125" width="1.8" layer="1"/>
<wire x1="38.7875" y1="57.0125" x2="38.225" y2="56.45" width="1.8" layer="1"/>
<wire x1="38.225" y1="56.45" x2="38.225" y2="53.475" width="1.8" layer="1"/>
<wire x1="38.225" y1="53.475" x2="37.625" y2="52.875" width="1.8" layer="1"/>
<wire x1="37.625" y1="52.875" x2="36.8625" y2="52.875" width="1.8" layer="1"/>
<wire x1="36.8625" y1="52.875" x2="35.7625" y2="51.775" width="1.8" layer="1"/>
<wire x1="35.7625" y1="51.775" x2="35.7625" y2="50.225" width="1.8" layer="1"/>
<wire x1="35.7625" y1="50.225" x2="33.4625" y2="50.225" width="1.8" layer="1"/>
<wire x1="33.4625" y1="50.225" x2="33.3125" y2="50.375" width="1.8" layer="1"/>
<wire x1="33.3125" y1="50.375" x2="33.3125" y2="54.475" width="1.8" layer="1"/>
<wire x1="33.3125" y1="54.475" x2="36.6875" y2="54.475" width="1.8" layer="1"/>
<wire x1="36.6875" y1="54.475" x2="37.4375" y2="55.225" width="1.8" layer="1"/>
<wire x1="37.4375" y1="55.225" x2="37.4375" y2="59.9625" width="1.8" layer="1"/>
<wire x1="37.6375" y1="59.8125" x2="37.6375" y2="59.825" width="1.8" layer="1"/>
<wire x1="37.6375" y1="59.825" x2="37.45" y2="60.0125" width="1.8" layer="1"/>
<wire x1="37.45" y1="60.0125" x2="37.6875" y2="60.25" width="1.8" layer="1"/>
<wire x1="37.6875" y1="60.25" x2="38.4875" y2="60.25" width="1.8" layer="1"/>
<wire x1="38.4875" y1="60.25" x2="38.8" y2="59.9375" width="1.8" layer="1"/>
<wire x1="34.5875" y1="50.025" x2="34.5875" y2="52.7375" width="1.8" layer="1"/>
<wire x1="34.5875" y1="52.7375" x2="35.3125" y2="53.4625" width="1.8" layer="1"/>
<wire x1="35.3125" y1="53.4625" x2="35.8125" y2="53.4625" width="1.8" layer="1"/>
<wire x1="37.095" y1="56.835" x2="37.48" y2="56.45" width="0.254" layer="1"/>
<wire x1="37.48" y1="56.45" x2="38.225" y2="56.45" width="0.254" layer="1"/>
<wire x1="26.6075" y1="55.07" x2="36.3075" y2="55.07" width="1" layer="1"/>
<wire x1="36.3075" y1="55.07" x2="36.925" y2="55.6875" width="1" layer="1"/>
<wire x1="34.7625" y1="49.5375" x2="32.25" y2="52.05" width="0.4064" layer="16"/>
<wire x1="32.25" y1="53" x2="32.5" y2="53.25" width="0.4064" layer="16"/>
<wire x1="32.5" y1="53.25" x2="33.4475" y2="53.25" width="0.4064" layer="16"/>
<wire x1="33.4475" y1="53.25" x2="33.45" y2="53.2525" width="0.4064" layer="16"/>
<wire x1="32.25" y1="52.05" x2="32.25" y2="53" width="0.4064" layer="16"/>
<wire x1="40.4625" y1="50.075" x2="40.424790625" y2="50.112709375" width="1" layer="1"/>
<wire x1="40.424790625" y1="50.112709375" x2="39.135209375" y2="50.112709375" width="1" layer="1"/>
<wire x1="39.135209375" y1="50.112709375" x2="38.5575" y2="49.535" width="1" layer="1"/>
<wire x1="38.7875" y1="59.9125" x2="38.5225" y2="59.37" width="0" layer="19" extent="1-1"/>
<wire x1="38.8" y1="59.9375" x2="38.7875" y2="59.9125" width="0" layer="19" extent="1-1"/>
<wire x1="36.925" y1="55.6875" x2="37.4375" y2="55.225" width="0" layer="19" extent="1-1"/>
<wire x1="34.5875" y1="50.025" x2="33.4625" y2="50.225" width="0" layer="19" extent="1-1"/>
<wire x1="34.7375" y1="49.5625" x2="34.5875" y2="50.025" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$7">
<contactref element="IC7" pad="2"/>
<contactref element="C13" pad="1"/>
<contactref element="R19" pad="2"/>
<contactref element="R18" pad="2"/>
<wire x1="33.1175" y1="63.275" x2="36.8175" y2="63.275" width="1" layer="1"/>
<wire x1="36.8175" y1="63.275" x2="36.8225" y2="63.27" width="0.4064" layer="1"/>
<wire x1="33.1175" y1="61.545" x2="33.1175" y2="63.275" width="0.4064" layer="1"/>
<wire x1="34.925" y1="63.275" x2="36.8175" y2="63.275" width="0.4064" layer="16"/>
<wire x1="36.8175" y1="63.275" x2="36.8225" y2="63.27" width="0.4064" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="IC8" pad="2"/>
<contactref element="R23" pad="2"/>
<contactref element="R22" pad="2"/>
<wire x1="28.4575" y1="50.74" x2="28.4575" y2="47.215" width="1" layer="1"/>
<wire x1="28.5075" y1="50.79" x2="28.4675" y2="50.83" width="1" layer="1"/>
<wire x1="30.9725" y1="48.7075" x2="30.9725" y2="49.765" width="1" layer="1"/>
<wire x1="30.9725" y1="49.765" x2="29.925" y2="50.8125" width="1" layer="1"/>
<wire x1="29.925" y1="50.8125" x2="28.53" y2="50.8125" width="1" layer="1"/>
<wire x1="28.53" y1="50.8125" x2="28.5075" y2="50.79" width="1" layer="1"/>
<wire x1="28.5075" y1="50.79" x2="28.4575" y2="50.74" width="1" layer="1"/>
</signal>
<signal name="N$12">
<contactref element="IC8" pad="3"/>
<contactref element="D2" pad="A"/>
<contactref element="R23" pad="1"/>
<wire x1="26.5625" y1="49.56" x2="26.42" y2="49.4175" width="1" layer="1"/>
<wire x1="26.42" y1="49.4175" x2="26.42" y2="47.3525" width="1" layer="1"/>
<wire x1="26.42" y1="47.3525" x2="26.5575" y2="47.215" width="1" layer="1"/>
<wire x1="23.4425" y1="52.0325" x2="23.4425" y2="50.37" width="1" layer="1"/>
<wire x1="23.4425" y1="50.37" x2="24.25" y2="49.5625" width="1" layer="1"/>
<wire x1="24.25" y1="49.5625" x2="26.56" y2="49.5625" width="1" layer="1"/>
<wire x1="26.56" y1="49.5625" x2="26.5625" y2="49.56" width="1" layer="1"/>
</signal>
<signal name="N$13">
<contactref element="IC4" pad="14"/>
<contactref element="IC6" pad="3"/>
<wire x1="30.4325" y1="38.935" x2="30.4325" y2="40.2175" width="0.254" layer="16"/>
<wire x1="30.4325" y1="40.2175" x2="28.9625" y2="41.6875" width="0.254" layer="16"/>
<wire x1="28.9625" y1="41.6875" x2="17.55" y2="41.6875" width="0.254" layer="16"/>
<wire x1="16.6925" y1="54.525" x2="16.71" y2="54.5425" width="0.254" layer="16"/>
<wire x1="17.55" y1="41.6875" x2="14.2875" y2="44.95" width="0.254" layer="16"/>
<wire x1="14.2875" y1="44.95" x2="14.2875" y2="53.9375" width="0.254" layer="16"/>
<wire x1="14.2875" y1="53.9375" x2="14.875" y2="54.525" width="0.254" layer="16"/>
<wire x1="14.875" y1="54.525" x2="16.6925" y2="54.525" width="0.254" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="IC6" pad="6"/>
<contactref element="IC4" pad="10"/>
<wire x1="27.8325" y1="38.935" x2="27.8325" y2="39.9425" width="0.254" layer="16"/>
<wire x1="27.8325" y1="39.9425" x2="26.775" y2="41" width="0.254" layer="16"/>
<wire x1="26.775" y1="41" x2="17.1625" y2="41" width="0.254" layer="16"/>
<wire x1="17.1625" y1="41" x2="13.4375" y2="44.725" width="0.254" layer="16"/>
<wire x1="13.4375" y1="44.725" x2="13.4375" y2="46.8375" width="0.254" layer="16"/>
<via x="13.4375" y="46.8375" extent="1-16" drill="0.4"/>
<wire x1="13.4375" y1="46.8375" x2="11.6625" y2="48.6125" width="0.4064" layer="1"/>
<wire x1="11.6625" y1="53.9625" x2="11.075" y2="54.55" width="0.4064" layer="1"/>
<wire x1="11.075" y1="54.55" x2="9.0975" y2="54.55" width="0.4064" layer="1"/>
<wire x1="9.0975" y1="54.55" x2="9.09" y2="54.5425" width="0.254" layer="1"/>
<wire x1="11.6625" y1="48.6125" x2="11.6625" y2="53.9625" width="0.4064" layer="1"/>
</signal>
<signal name="N$15">
<contactref element="IC9" pad="6"/>
<contactref element="IC9" pad="7"/>
<contactref element="IC11" pad="4"/>
<wire x1="9.09" y1="34.28" x2="9.09" y2="36.82" width="0.8" layer="16"/>
<wire x1="28.31" y1="29.885" x2="28.31" y2="27.06" width="0.3048" layer="1"/>
<wire x1="28.31" y1="27.06" x2="27.8" y2="26.55" width="0.3048" layer="1"/>
<wire x1="9.09" y1="34.28" x2="7.4525" y2="34.28" width="0.3048" layer="1"/>
<wire x1="6.7625" y1="33.59" x2="7.4525" y2="34.28" width="0.3048" layer="1"/>
<wire x1="11" y1="26.55" x2="6.7625" y2="30.7875" width="0.3048" layer="1"/>
<wire x1="6.7625" y1="30.7875" x2="6.7625" y2="33.59" width="0.3048" layer="1"/>
<wire x1="27.8" y1="26.55" x2="11" y2="26.55" width="0.3048" layer="1"/>
</signal>
<signal name="N$16">
<contactref element="IC9" pad="2"/>
<contactref element="IC9" pad="1"/>
<contactref element="IC11" pad="3"/>
<wire x1="16.71" y1="31.74" x2="16.71" y2="34.28" width="0.8" layer="16"/>
<wire x1="27.66" y1="29.885" x2="27.66" y2="31.0525" width="0.3048" layer="1"/>
<wire x1="27.66" y1="31.0525" x2="26.9625" y2="31.75" width="0.3048" layer="1"/>
<wire x1="26.9625" y1="31.75" x2="16.72" y2="31.75" width="0.3048" layer="1"/>
<wire x1="16.71" y1="31.74" x2="16.72" y2="31.75" width="0.3048" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="IC9" pad="5"/>
<contactref element="R30" pad="2"/>
<contactref element="R1" pad="1"/>
<wire x1="9.09" y1="39.36" x2="6.27" y2="39.36" width="0.8" layer="16"/>
<wire x1="6.27" y1="39.36" x2="6.26" y2="39.35" width="0.8" layer="16"/>
<wire x1="2.2375" y1="65.45" x2="2.2375" y2="41.4" width="0.8" layer="1"/>
<wire x1="2.2375" y1="41.4" x2="4.275" y2="39.3625" width="0.8" layer="1"/>
<wire x1="4.275" y1="39.3625" x2="9.0875" y2="39.3625" width="0.8" layer="1"/>
<wire x1="9.0875" y1="39.3625" x2="9.09" y2="39.36" width="0.8" layer="1"/>
<wire x1="18.37" y1="65.2475" x2="18.37" y2="67.0175" width="0.8" layer="1"/>
<wire x1="18.37" y1="67.0175" x2="16.7375" y2="68.65" width="0.8" layer="1"/>
<wire x1="16.7375" y1="68.65" x2="5.4375" y2="68.65" width="0.8" layer="1"/>
<wire x1="5.4375" y1="68.65" x2="2.2375" y2="65.45" width="0.8" layer="1"/>
</signal>
<signal name="N$18">
<contactref element="IC6" pad="2"/>
<contactref element="R14" pad="2"/>
<contactref element="R15" pad="2"/>
<wire x1="16.71" y1="52.0025" x2="21.2875" y2="52.0025" width="0.8" layer="16"/>
<wire x1="21.2875" y1="52.0025" x2="21.29" y2="52" width="0.8" layer="16"/>
<wire x1="21.29" y1="52" x2="21.285" y2="52.005" width="0.8" layer="16"/>
<wire x1="21.285" y1="52.005" x2="21.285" y2="54.0675" width="0.8" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="R13" pad="1"/>
<contactref element="R14" pad="1"/>
<wire x1="20.235" y1="47.4" x2="20.235" y2="48.4225" width="0.8128" layer="16"/>
<wire x1="21.29" y1="49.0775" x2="21.29" y2="50.1" width="0.8128" layer="16"/>
<wire x1="20.235" y1="48.4225" x2="20.5625" y2="48.75" width="0.8128" layer="16"/>
<wire x1="20.5625" y1="48.75" x2="20.9625" y2="48.75" width="0.8128" layer="16"/>
<wire x1="20.9625" y1="48.75" x2="21.29" y2="49.0775" width="0.8128" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="R25" pad="1"/>
<contactref element="R26" pad="2"/>
<wire x1="35.35" y1="53.2525" x2="37.425" y2="53.2525" width="0.4064" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="R26" pad="1"/>
<contactref element="R27" pad="2"/>
<contactref element="C16" pad="2"/>
<contactref element="IC9" pad="3"/>
<wire x1="41.55" y1="52.89" x2="41.625" y2="52.815" width="0.4064" layer="16"/>
<wire x1="24.8375" y1="43.575" x2="36.15" y2="43.575" width="0.508" layer="16"/>
<wire x1="24.8375" y1="43.575" x2="23.8625" y2="42.6" width="0.508" layer="16"/>
<via x="21.6125" y="42.6" extent="1-16" drill="0.4"/>
<wire x1="21.6125" y1="42.6" x2="15.9375" y2="42.6" width="0.4064" layer="1"/>
<wire x1="23.8625" y1="42.6" x2="21.6125" y2="42.6" width="0.508" layer="16"/>
<wire x1="16.71" y1="36.82" x2="14.9925" y2="36.82" width="0.4064" layer="1"/>
<wire x1="14.9925" y1="36.82" x2="14.5625" y2="37.25" width="0.4064" layer="1"/>
<wire x1="14.5625" y1="37.25" x2="14.5625" y2="41.225" width="0.4064" layer="1"/>
<wire x1="14.5625" y1="41.225" x2="15.9375" y2="42.6" width="0.4064" layer="1"/>
<wire x1="36.15" y1="43.575" x2="38.3875" y2="45.8125" width="0.508" layer="16"/>
<wire x1="38.3875" y1="45.8125" x2="39.7875" y2="45.8125" width="0.508" layer="16"/>
<wire x1="39.7875" y1="45.8125" x2="40.575" y2="46.6" width="0.508" layer="16"/>
<wire x1="40.575" y1="46.6" x2="40.575" y2="48.8825" width="0.508" layer="16"/>
<wire x1="40.575" y1="48.8825" x2="40.575" y2="49.7625" width="0.4064" layer="16"/>
<wire x1="40.575" y1="49.7625" x2="40.3125" y2="50.025" width="0.4064" layer="16"/>
<wire x1="40.3125" y1="53.075" x2="40.1375" y2="53.25" width="0.4064" layer="16"/>
<wire x1="40.1375" y1="53.25" x2="39.3275" y2="53.25" width="0.4064" layer="16"/>
<wire x1="39.3275" y1="53.25" x2="39.325" y2="53.2525" width="0.4064" layer="16"/>
<wire x1="40.3125" y1="50.025" x2="40.3125" y2="52.8375" width="0.4064" layer="16"/>
<wire x1="40.3125" y1="52.8375" x2="40.3125" y2="53.075" width="0.4064" layer="16"/>
<wire x1="41.55" y1="52.89" x2="40.365" y2="52.89" width="0.4064" layer="16"/>
<wire x1="40.365" y1="52.89" x2="40.3125" y2="52.8375" width="0.4064" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="IC6" pad="7"/>
<contactref element="R20" pad="2"/>
<contactref element="R21" pad="2"/>
<wire x1="9.09" y1="52.0025" x2="9.0875" y2="52" width="0.8" layer="16"/>
<wire x1="9.0875" y1="52" x2="5.8375" y2="52" width="0.8" layer="16"/>
<wire x1="5.8375" y1="52" x2="5.8375" y2="49.9875" width="0.8" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="IC6" pad="1"/>
<contactref element="R17" pad="2"/>
<wire x1="16.71" y1="49.4625" x2="16.71" y2="47.44" width="0.8" layer="16"/>
<wire x1="16.71" y1="47.44" x2="16.725" y2="47.425" width="0.8" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="R17" pad="1"/>
<contactref element="R19" pad="1"/>
<contactref element="Q1" pad="3"/>
<wire x1="16.725" y1="45.525" x2="16.7125" y2="45.5125" width="0.8" layer="16"/>
<wire x1="16.7125" y1="45.5125" x2="15.15" y2="45.5125" width="0.8" layer="16"/>
<via x="15.15" y="45.5125" extent="1-16" drill="0.4" diameter="0.9"/>
<wire x1="15.15" y1="45.5125" x2="7.1775" y2="45.5125" width="0.8" layer="1"/>
<wire x1="7.1775" y1="45.5125" x2="7.165" y2="45.525" width="0.8" layer="1"/>
<wire x1="33.025" y1="63.275" x2="33.025" y2="58.75" width="0.4064" layer="16"/>
<wire x1="33.025" y1="58.75" x2="34.275" y2="57.5" width="0.4064" layer="16"/>
<wire x1="34.275" y1="57.5" x2="34.275" y2="56.3625" width="0.4064" layer="16"/>
<wire x1="34.275" y1="56.3625" x2="31.1125" y2="53.2" width="0.4064" layer="16"/>
<wire x1="31.1125" y1="53.2" x2="31.1125" y2="49.5875" width="0.4064" layer="16"/>
<wire x1="31.1125" y1="49.5875" x2="27.8375" y2="46.3125" width="0.4064" layer="16"/>
<wire x1="27.8375" y1="46.3125" x2="23.225" y2="46.3125" width="0.4064" layer="16"/>
<wire x1="23.225" y1="46.3125" x2="21.15" y2="44.2375" width="0.4064" layer="16"/>
<wire x1="21.15" y1="44.2375" x2="16.9625" y2="44.2375" width="0.4064" layer="16"/>
<wire x1="16.9625" y1="44.2375" x2="16.725" y2="44.475" width="0.4064" layer="16"/>
<wire x1="16.725" y1="44.475" x2="16.725" y2="45.525" width="0.4064" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="Q2" pad="2"/>
<contactref element="R21" pad="1"/>
<wire x1="3.9375" y1="52" x2="3.9375" y2="58.0925" width="0.8" layer="16"/>
<wire x1="5.845" y1="60" x2="5.845" y2="63.2375" width="0.8" layer="16"/>
<wire x1="5.845" y1="60" x2="3.9375" y2="58.0925" width="0.8" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="Q1" pad="2"/>
<contactref element="R20" pad="1"/>
<wire x1="5.895" y1="47.43" x2="4.645" y2="47.43" width="0.8" layer="16"/>
<wire x1="4.645" y1="47.43" x2="3.9375" y2="48.1375" width="0.8" layer="16"/>
<wire x1="3.9375" y1="48.1375" x2="3.9375" y2="49.9875" width="0.8" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="IC10" pad="P$6"/>
<contactref element="R41" pad="1"/>
<contactref element="R40" pad="2"/>
<contactref element="R39" pad="2"/>
<wire x1="43.5125" y1="36.975" x2="48.8125" y2="36.975" width="0.8128" layer="16"/>
<wire x1="48.8125" y1="36.975" x2="49.95" y2="38.1125" width="0.8128" layer="16"/>
<wire x1="49.95" y1="38.1125" x2="49.95" y2="39.75" width="0.8128" layer="16"/>
<wire x1="49.95" y1="39.75" x2="51.15" y2="40.95" width="0.8128" layer="16"/>
<wire x1="51.15" y1="40.95" x2="52.45" y2="40.95" width="0.8128" layer="16"/>
<wire x1="52.45" y1="40.95" x2="53.275" y2="41.775" width="0.8128" layer="16"/>
<wire x1="53.275" y1="41.775" x2="53.275" y2="44.525" width="0.8128" layer="16"/>
<wire x1="53.275" y1="44.525" x2="52.9" y2="44.9" width="0.8128" layer="16"/>
<wire x1="52.9" y1="44.9" x2="51.8425" y2="44.9" width="0.8128" layer="16"/>
<wire x1="51.8375" y1="44.895" x2="51.8425" y2="44.9" width="0.8128" layer="16"/>
<wire x1="41.515" y1="39.7005" x2="39.4775" y2="39.7005" width="0.6096" layer="16"/>
<wire x1="39.4775" y1="39.7005" x2="39.465" y2="39.688" width="0.6096" layer="16"/>
<wire x1="44.2125" y1="36.5375" x2="43.95" y2="36.5375" width="0.6096" layer="16"/>
<wire x1="43.95" y1="36.5375" x2="43.5125" y2="36.975" width="0.6096" layer="16"/>
<wire x1="41.515" y1="39.7005" x2="41.515" y2="37.835" width="0.8128" layer="16"/>
<wire x1="41.515" y1="37.835" x2="42.375" y2="36.975" width="0.8128" layer="16"/>
<wire x1="42.375" y1="36.975" x2="43.5125" y2="36.975" width="0.8128" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="R41" pad="2"/>
<contactref element="C20" pad="1"/>
<contactref element="IC11" pad="1"/>
<wire x1="27.2875" y1="27.8925" x2="27.3125" y2="27.8925" width="0.3048" layer="1"/>
<wire x1="44.2125" y1="34.6375" x2="42.4625" y2="34.6375" width="0.508" layer="16"/>
<wire x1="42.4625" y1="34.6375" x2="41.5375" y2="33.7125" width="0.508" layer="16"/>
<wire x1="41.5375" y1="33.7125" x2="41.5375" y2="29.5875" width="0.508" layer="16"/>
<wire x1="41.5375" y1="29.5875" x2="39.8" y2="27.85" width="0.508" layer="16"/>
<wire x1="39.8" y1="27.85" x2="25.725" y2="27.85" width="0.508" layer="16"/>
<via x="25.725" y="27.85" extent="1-16" drill="0.35"/>
<wire x1="27.245" y1="27.85" x2="27.2875" y2="27.8925" width="0.4064" layer="1"/>
<wire x1="26.36" y1="29.885" x2="26.36" y2="29.1475" width="0.3048" layer="1"/>
<wire x1="26.36" y1="29.1475" x2="25.725" y2="28.5125" width="0.3048" layer="1"/>
<wire x1="25.725" y1="28.5125" x2="25.725" y2="27.85" width="0.3048" layer="1"/>
<wire x1="27.3125" y1="27.8925" x2="27.2625" y2="27.8425" width="0.3048" layer="1"/>
<wire x1="27.2625" y1="27.8425" x2="25.7325" y2="27.8425" width="0.3048" layer="1"/>
<wire x1="25.725" y1="27.85" x2="25.7325" y2="27.8425" width="0.3048" layer="1"/>
</signal>
<signal name="N$32">
<contactref element="R36" pad="2"/>
<contactref element="IC10" pad="P$2"/>
<contactref element="R33" pad="2"/>
<contactref element="R40" pad="1"/>
<contactref element="R39" pad="1"/>
<wire x1="44.3775" y1="44.6875" x2="42.415" y2="44.6875" width="0.8128" layer="16"/>
<wire x1="46.8375" y1="43.625" x2="44.425" y2="43.625" width="0.6096" layer="16"/>
<wire x1="44.425" y1="43.625" x2="43.8125" y2="43.625" width="0.6096" layer="16"/>
<wire x1="42.732" y1="42.5445" x2="41.515" y2="42.5445" width="0.6096" layer="16"/>
<wire x1="43.8125" y1="43.625" x2="42.732" y2="42.5445" width="0.6096" layer="16"/>
<wire x1="41.515" y1="42.5445" x2="39.4775" y2="42.5445" width="0.6096" layer="16"/>
<wire x1="39.4775" y1="42.5445" x2="39.465" y2="42.532" width="0.6096" layer="16"/>
<wire x1="44.3775" y1="44.6875" x2="44.3775" y2="43.6725" width="0.6096" layer="16"/>
<wire x1="44.3775" y1="43.6725" x2="44.425" y2="43.625" width="0.6096" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="Q4" pad="1"/>
<contactref element="R31" pad="2"/>
<contactref element="Q3" pad="3"/>
<wire x1="52.7475" y1="37.555" x2="51.675" y2="36.4825" width="0.4064" layer="1"/>
<wire x1="51.675" y1="36.4825" x2="50.595" y2="36.4825" width="0.4064" layer="1"/>
<wire x1="53.045" y1="39.52" x2="52.7475" y2="39.2225" width="0.4064" layer="16"/>
<wire x1="52.7475" y1="39.2225" x2="52.7475" y2="37.555" width="0.4064" layer="16"/>
</signal>
<signal name="N$33">
<contactref element="R32" pad="1"/>
<contactref element="Q3" pad="2"/>
<wire x1="54.0175" y1="35.65" x2="54.0175" y2="33.59" width="0.4064" layer="1"/>
<wire x1="54.0175" y1="33.59" x2="54.0275" y2="33.58" width="0.4064" layer="1"/>
</signal>
<signal name="CS_DAC">
<contactref element="IC4" pad="3"/>
<wire x1="29.1325" y1="33.285" x2="29.1325" y2="32.2825" width="0.3048" layer="16"/>
<wire x1="29.1325" y1="32.2825" x2="28.525" y2="31.675" width="0.3048" layer="16"/>
<wire x1="28.525" y1="31.675" x2="25.075" y2="31.675" width="0.3048" layer="16"/>
<wire x1="25.075" y1="31.675" x2="24.4485" y2="31.0485" width="0.3048" layer="16"/>
<wire x1="24.4485" y1="21.9685" x2="24.4485" y2="31.0485" width="0.3048" layer="16"/>
<contactref element="IC12" pad="11"/>
</signal>
<signal name="CS_ADC">
<contactref element="IC11" pad="8"/>
<wire x1="30.26" y1="35.535" x2="31.465" y2="35.535" width="0.254" layer="1"/>
<wire x1="31.465" y1="35.535" x2="33.9625" y2="33.0375" width="0.254" layer="1"/>
<wire x1="33.9625" y1="33.0375" x2="33.9625" y2="27.6375" width="0.254" layer="1"/>
<contactref element="IC12" pad="3"/>
<wire x1="20.2625" y1="24.2875" x2="19.15" y2="23.175" width="0.254" layer="1"/>
<wire x1="19.15" y1="23.175" x2="19.15" y2="13.35" width="0.254" layer="1"/>
<wire x1="19.15" y1="13.35" x2="26.9875" y2="5.5125" width="0.254" layer="1"/>
<wire x1="26.9875" y1="5.5125" x2="26.9875" y2="2.1575" width="0.254" layer="1"/>
<wire x1="26.9875" y1="2.1575" x2="26.9885" y2="2.1565" width="0.254" layer="1"/>
<wire x1="33.9625" y1="27.6375" x2="30.6125" y2="24.2875" width="0.254" layer="1"/>
<wire x1="30.6125" y1="24.2875" x2="20.2625" y2="24.2875" width="0.254" layer="1"/>
</signal>
<signal name="SCK">
<contactref element="IC11" pad="11"/>
<contactref element="IC4" pad="4"/>
<wire x1="28.31" y1="35.535" x2="28.31" y2="34.5025" width="0.3048" layer="1"/>
<wire x1="28.31" y1="34.5025" x2="28.475" y2="34.3375" width="0.3048" layer="1"/>
<via x="28.475" y="34.3375" extent="1-16" drill="0.4"/>
<wire x1="28.475" y1="34.3375" x2="28.475" y2="33.2925" width="0.3048" layer="16"/>
<wire x1="28.475" y1="33.2925" x2="28.4825" y2="33.285" width="0.3048" layer="16"/>
<wire x1="28.475" y1="34.3375" x2="28.95" y2="33.8625" width="0.254" layer="1"/>
<wire x1="32.9" y1="29.0125" x2="29.675" y2="25.7875" width="0.254" layer="1"/>
<wire x1="28.95" y1="33.8625" x2="31.75" y2="33.8625" width="0.254" layer="1"/>
<wire x1="31.75" y1="33.8625" x2="32.9" y2="32.7125" width="0.254" layer="1"/>
<wire x1="32.9" y1="32.7125" x2="32.9" y2="29.0125" width="0.254" layer="1"/>
<contactref element="IC12" pad="1"/>
<wire x1="29.675" y1="25.7875" x2="18.6125" y2="25.7875" width="0.254" layer="1"/>
<wire x1="18.6125" y1="25.7875" x2="17.0125" y2="24.1875" width="0.254" layer="1"/>
<wire x1="17.0125" y1="24.1875" x2="17.0125" y2="4.5625" width="0.254" layer="1"/>
<wire x1="19.4185" y1="2.1565" x2="21.9085" y2="2.1565" width="0.254" layer="1"/>
<wire x1="17.0125" y1="4.5625" x2="19.4185" y2="2.1565" width="0.254" layer="1"/>
</signal>
<signal name="SDI">
<contactref element="IC4" pad="5"/>
<contactref element="IC11" pad="9"/>
<wire x1="27.8325" y1="33.285" x2="27.8325" y2="33.9175" width="0.3048" layer="16"/>
<wire x1="27.8325" y1="33.9175" x2="27.6375" y2="34.1125" width="0.3048" layer="16"/>
<wire x1="27.6375" y1="34.1125" x2="27.6375" y2="36.65" width="0.3048" layer="16"/>
<wire x1="27.6375" y1="36.65" x2="27.7125" y2="36.725" width="0.3048" layer="16"/>
<wire x1="27.7125" y1="36.725" x2="29.6125" y2="36.725" width="0.3048" layer="16"/>
<via x="29.6125" y="36.725" extent="1-16" drill="0.4"/>
<wire x1="29.61" y1="35.535" x2="29.61" y2="36.7225" width="0.3048" layer="1"/>
<wire x1="29.61" y1="36.7225" x2="29.6125" y2="36.725" width="0.3048" layer="1"/>
<wire x1="27.7125" y1="36.725" x2="26.525" y2="36.725" width="0.3048" layer="16"/>
<contactref element="IC12" pad="12"/>
<wire x1="21.9085" y1="21.9685" x2="21.9085" y2="32.1085" width="0.3048" layer="16"/>
<wire x1="21.9085" y1="32.1085" x2="26.525" y2="36.725" width="0.3048" layer="16"/>
</signal>
<signal name="DOUT">
<contactref element="IC11" pad="10"/>
<wire x1="28.96" y1="35.535" x2="28.96" y2="34.89" width="0.254" layer="1"/>
<wire x1="28.96" y1="34.89" x2="29.225" y2="34.625" width="0.254" layer="1"/>
<wire x1="29.225" y1="34.625" x2="31.6877625" y2="34.625" width="0.254" layer="1"/>
<wire x1="31.6877625" y1="34.625" x2="33.4561" y2="32.8566625" width="0.254" layer="1"/>
<wire x1="33.4561" y1="32.8566625" x2="33.4561" y2="28.4561" width="0.254" layer="1"/>
<wire x1="19.45" y1="25.0375" x2="18.2" y2="23.7875" width="0.254" layer="1"/>
<wire x1="18.2" y1="23.7875" x2="18.2" y2="10.6875" width="0.254" layer="1"/>
<wire x1="18.2" y1="10.6875" x2="24.44375" y2="4.44375" width="0.254" layer="1"/>
<wire x1="33.4561" y1="28.4561" x2="30.0375" y2="25.0375" width="0.254" layer="1"/>
<wire x1="30.0375" y1="25.0375" x2="19.45" y2="25.0375" width="0.254" layer="1"/>
<contactref element="IC12" pad="2"/>
<wire x1="24.44375" y1="4.44375" x2="24.4485" y2="4.4485" width="0.254" layer="1"/>
<wire x1="24.4485" y1="4.4485" x2="24.4485" y2="2.1565" width="0.254" layer="1"/>
</signal>
<signal name="3V3" airwireshidden="yes">
<contactref element="IC3" pad="P$2"/>
<contactref element="C5" pad="2"/>
<contactref element="IC4" pad="1"/>
<contactref element="C7" pad="1"/>
<contactref element="C8" pad="1"/>
<contactref element="IC4" pad="9"/>
<contactref element="IC11" pad="14"/>
<contactref element="C18" pad="1"/>
<contactref element="IC10" pad="P$7"/>
<contactref element="C19" pad="2"/>
<contactref element="IC10" pad="P$1"/>
<wire x1="46.8375" y1="42.355" x2="46.8375" y2="40.9125" width="0.8128" layer="16"/>
<via x="46.8375" y="40.9125" extent="1-16" drill="0.4" diameter="0.9"/>
<wire x1="46.8375" y1="40.9125" x2="49.375" y2="40.9125" width="0.8128" layer="1"/>
<via x="49.375" y="40.9125" extent="1-16" drill="0.4" diameter="0.9"/>
<wire x1="49.375" y1="46.2125" x2="49.9875" y2="46.825" width="0.8128" layer="16"/>
<wire x1="49.9875" y1="46.825" x2="49.9875" y2="47.645" width="0.8128" layer="16"/>
<wire x1="49.9875" y1="47.645" x2="50.1175" y2="47.775" width="0.8128" layer="16"/>
<wire x1="49.375" y1="40.9125" x2="49.375" y2="43.6375" width="0.8128" layer="16"/>
<wire x1="49.375" y1="43.6375" x2="49.375" y2="46.2125" width="0.8128" layer="16"/>
<wire x1="49.3875" y1="43.625" x2="49.375" y2="43.6375" width="0.8128" layer="16"/>
<wire x1="51.8375" y1="43.625" x2="49.3875" y2="43.625" width="0.8128" layer="16"/>
<wire x1="50.1175" y1="47.775" x2="51.8875" y2="47.775" width="0.8128" layer="16"/>
<wire x1="51.8875" y1="47.775" x2="53.3875" y2="49.275" width="0.8128" layer="16"/>
<wire x1="53.3875" y1="49.275" x2="55.725" y2="49.275" width="0.8128" layer="16"/>
<wire x1="55.725" y1="49.275" x2="57.1125" y2="50.6625" width="0.8128" layer="16"/>
<wire x1="57.1125" y1="50.6625" x2="57.1125" y2="65.35" width="0.8128" layer="16"/>
<wire x1="56.0625" y1="66.4" x2="57.1125" y2="65.35" width="0.8128" layer="16"/>
<wire x1="34.595" y1="39.7625" x2="36.5225" y2="39.7625" width="0.508" layer="1"/>
<wire x1="36.5225" y1="39.7625" x2="36.56" y2="39.725" width="0.4064" layer="1"/>
<wire x1="27.1825" y1="38.935" x2="27.1825" y2="39.93" width="0.254" layer="16"/>
<wire x1="26.875" y1="40.2375" x2="26.4125" y2="40.2375" width="0.254" layer="16"/>
<via x="26.4125" y="40.2375" extent="1-16" drill="0.4"/>
<wire x1="31.4375" y1="42.525" x2="30.8875" y2="43.075" width="0.4064" layer="1"/>
<wire x1="31.4375" y1="42.525" x2="31.4375" y2="39.4875" width="0.4064" layer="1"/>
<via x="31.4375" y="39.4875" extent="1-16" drill="0.35"/>
<wire x1="31.4375" y1="39.4875" x2="32.0375" y2="40.0875" width="0.508" layer="16"/>
<via x="36.5625" y="38.1875" extent="1-16" drill="0.35"/>
<wire x1="36.5625" y1="38.1875" x2="36.5625" y2="39.7225" width="0.508" layer="1"/>
<wire x1="36.5625" y1="39.7225" x2="36.5225" y2="39.7625" width="0.254" layer="1"/>
<wire x1="27.1825" y1="39.93" x2="26.875" y2="40.2375" width="0.254" layer="16"/>
<wire x1="26.4125" y1="40.2375" x2="25.0625" y2="40.2375" width="0.254" layer="16"/>
<wire x1="24.8425" y1="40.0175" x2="24.8425" y2="39.425" width="0.254" layer="16"/>
<wire x1="25.0625" y1="40.2375" x2="24.8425" y2="40.0175" width="0.254" layer="16"/>
<wire x1="26.36" y1="35.535" x2="26.36" y2="39.51" width="0.254" layer="1"/>
<wire x1="26.36" y1="39.51" x2="26.4125" y2="39.5625" width="0.254" layer="1"/>
<wire x1="26.4125" y1="39.5625" x2="26.4125" y2="40.2375" width="0.254" layer="1"/>
<wire x1="31.765" y1="31.9" x2="31.7625" y2="32.525" width="0.508" layer="1"/>
<wire x1="31.7625" y1="32.525" x2="31.7625" y2="32.6" width="0.508" layer="1"/>
<wire x1="31.7625" y1="32.6" x2="31.2625" y2="33.1" width="0.508" layer="1"/>
<via x="31.2625" y="33.1" extent="1-16" drill="0.4"/>
<wire x1="31.2625" y1="33.1" x2="30.825" y2="33.1" width="0.3048" layer="16"/>
<wire x1="30.825" y1="33.1" x2="30.6375" y2="33.2875" width="0.3048" layer="16"/>
<wire x1="30.6375" y1="33.2875" x2="30.435" y2="33.2875" width="0.3048" layer="16"/>
<wire x1="30.4325" y1="33.285" x2="30.435" y2="33.2875" width="0.3048" layer="16"/>
<wire x1="31.2625" y1="33.1" x2="35.1375" y2="33.1" width="0.508" layer="16"/>
<wire x1="35.1375" y1="33.1" x2="36.5625" y2="34.525" width="0.508" layer="16"/>
<wire x1="36.5625" y1="34.525" x2="36.5625" y2="38.1875" width="0.508" layer="16"/>
<wire x1="24.76241875" y1="61.31241875" x2="24.76241875" y2="59.68008125" width="0.8128" layer="16"/>
<wire x1="24.76241875" y1="61.31241875" x2="25.7875" y2="62.3375" width="0.8128" layer="16"/>
<wire x1="25.7875" y1="62.3375" x2="30.0375" y2="62.3375" width="0.8128" layer="16"/>
<wire x1="30.0375" y1="62.3375" x2="31.1875" y2="63.4875" width="0.8128" layer="16"/>
<wire x1="31.1875" y1="63.4875" x2="31.1875" y2="65.3125" width="0.8128" layer="16"/>
<wire x1="32.275" y1="66.4" x2="56.0625" y2="66.4" width="0.8128" layer="16"/>
<wire x1="31.1875" y1="65.3125" x2="32.275" y2="66.4" width="0.8128" layer="16"/>
<contactref element="IC2" pad="3"/>
<contactref element="C4" pad="1"/>
<wire x1="26.5025" y1="57.94" x2="25.5475" y2="57.94" width="1" layer="1"/>
<wire x1="25.5475" y1="57.94" x2="25.2875" y2="58.2" width="1" layer="1"/>
<wire x1="25.2875" y1="58.2" x2="24.4825" y2="58.2" width="1" layer="1"/>
<wire x1="24.76241875" y1="59.68008125" x2="26.5025" y2="57.94" width="0.8128" layer="16"/>
<wire x1="30.8875" y1="43.075" x2="26.6625" y2="43.075" width="0.4064" layer="1"/>
<wire x1="26.6625" y1="43.075" x2="26.4125" y2="42.825" width="0.4064" layer="1"/>
<wire x1="26.4125" y1="42.825" x2="26.4125" y2="40.2375" width="0.4064" layer="1"/>
<wire x1="46.8375" y1="40.9125" x2="43.175" y2="40.9125" width="0.508" layer="16"/>
<wire x1="43.175" y1="40.9125" x2="42.9125" y2="41.175" width="0.508" layer="16"/>
<wire x1="42.9125" y1="41.175" x2="37.0875" y2="41.175" width="0.508" layer="16"/>
<wire x1="36.5625" y1="40.65" x2="36.5625" y2="40.0875" width="0.508" layer="16"/>
<wire x1="37.0875" y1="41.175" x2="36.5625" y2="40.65" width="0.508" layer="16"/>
<wire x1="32.0375" y1="40.0875" x2="36.5625" y2="40.0875" width="0.508" layer="16"/>
<wire x1="36.5625" y1="38.1875" x2="36.5625" y2="40.0875" width="0.508" layer="16"/>
<contactref element="IC12" pad="8"/>
<wire x1="35.7" y1="25.0375" x2="32.925" y2="25.0375" width="0.508" layer="1"/>
<wire x1="32.925" y1="25.0375" x2="32.0685" y2="24.181" width="0.508" layer="1"/>
<wire x1="32.0685" y1="24.181" x2="32.0685" y2="21.9685" width="0.508" layer="1"/>
<wire x1="36.5625" y1="38.1875" x2="36.5625" y2="25.9" width="0.508" layer="1"/>
<wire x1="36.5625" y1="25.9" x2="35.7" y2="25.0375" width="0.508" layer="1"/>
<wire x1="26.36" y1="35.535" x2="25.9875" y2="37.3725" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$6">
<contactref element="R16" pad="2"/>
<contactref element="R15" pad="1"/>
<wire x1="21.255" y1="58.565" x2="21.255" y2="55.9975" width="0.8" layer="16"/>
<wire x1="21.255" y1="55.9975" x2="21.285" y2="55.9675" width="0.8" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="R29" pad="2"/>
<contactref element="R30" pad="1"/>
<wire x1="11.17" y1="41.7225" x2="9.235" y2="41.7225" width="0.8" layer="16"/>
<wire x1="9.235" y1="41.7225" x2="8.75" y2="41.2375" width="0.8" layer="16"/>
<wire x1="8.75" y1="41.2375" x2="6.2725" y2="41.2375" width="0.8" layer="16"/>
<wire x1="6.2725" y1="41.2375" x2="6.26" y2="41.25" width="0.8" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="R13" pad="2"/>
<contactref element="R18" pad="1"/>
<contactref element="R24" pad="1"/>
<via x="33.125" y="56.8375" extent="1-16" drill="0.4" diameter="0.9"/>
<wire x1="35.195" y1="56.835" x2="33.1275" y2="56.835" width="0.4064" layer="1"/>
<wire x1="33.1275" y1="56.835" x2="33.125" y2="56.8375" width="0.4064" layer="1"/>
<wire x1="33.125" y1="56.8375" x2="33.125" y2="59.6375" width="0.4064" layer="1"/>
<wire x1="33.125" y1="59.6375" x2="33.1175" y2="59.645" width="0.4064" layer="1"/>
<wire x1="33.125" y1="56.8375" x2="30.0375" y2="53.75" width="0.4064" layer="16"/>
<wire x1="30.0375" y1="53.75" x2="30.0375" y2="49.85" width="0.4064" layer="16"/>
<wire x1="30.0375" y1="49.85" x2="27.2625" y2="47.075" width="0.4064" layer="16"/>
<wire x1="22.9125" y1="47.075" x2="21.325" y2="45.4875" width="0.4064" layer="16"/>
<wire x1="21.325" y1="45.4875" x2="20.2475" y2="45.4875" width="0.4064" layer="16"/>
<wire x1="20.2475" y1="45.4875" x2="20.235" y2="45.5" width="0.4064" layer="16"/>
<wire x1="27.2625" y1="47.075" x2="22.9125" y2="47.075" width="0.4064" layer="16"/>
</signal>
<signal name="-">
<via x="54.875" y="28" extent="1-16" drill="2.5" diameter="5"/>
<contactref element="IC10" pad="P$3"/>
<contactref element="Q4" pad="3"/>
<contactref element="R34" pad="1"/>
<contactref element="R35" pad="1"/>
<contactref element="R37" pad="1"/>
<contactref element="R38" pad="1"/>
<wire x1="44.1975" y1="38.8275" x2="45.555834375" y2="38.8275" width="2.2" layer="1"/>
<wire x1="45.555834375" y1="38.8275" x2="46.91416875" y2="38.8275" width="2.2" layer="1"/>
<wire x1="46.91416875" y1="38.8275" x2="48.272503125" y2="38.8275" width="2.2" layer="1"/>
<wire x1="48.272503125" y1="38.8275" x2="48.245003125" y2="38.8" width="2.2" layer="1"/>
<wire x1="48.272503125" y1="38.8275" x2="48.272503125" y2="29.224996875" width="2.5" layer="1"/>
<wire x1="48.272503125" y1="29.224996875" x2="48.315" y2="29.1825" width="2.5" layer="1"/>
<wire x1="54.875" y1="28" x2="54.7875" y2="28.0875" width="2.5" layer="1"/>
<wire x1="54.7875" y1="28.0875" x2="49.41" y2="28.0875" width="4" layer="1"/>
<wire x1="49.41" y1="28.0875" x2="48.315" y2="29.1825" width="2.5" layer="1"/>
<wire x1="46.8375" y1="44.895" x2="47.73" y2="44.895" width="0.8128" layer="16"/>
<wire x1="47.73" y1="44.895" x2="48.2625" y2="44.3625" width="0.8128" layer="16"/>
<wire x1="48.2625" y1="44.3625" x2="48.2625" y2="38.837503125" width="0.8128" layer="16"/>
<wire x1="48.2625" y1="38.837503125" x2="48.272503125" y2="38.8275" width="0.8128" layer="16"/>
</signal>
<signal name="N$31">
<via x="4" y="4" extent="1-16" drill="3"/>
<via x="61" y="4" extent="1-16" drill="3"/>
<via x="4" y="74" extent="1-16" drill="3"/>
<via x="61" y="74" extent="1-16" drill="3"/>
<wire x1="4" y1="74" x2="61" y2="74" width="0" layer="19" extent="1-1"/>
<wire x1="61" y1="4" x2="61" y2="74" width="0" layer="19" extent="1-1"/>
<wire x1="4" y1="4" x2="61" y2="4" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$2">
<contactref element="R27" pad="1"/>
<contactref element="R28" pad="2"/>
<wire x1="43.45" y1="52.89" x2="43.45" y2="50.8975" width="0.4064" layer="16"/>
</signal>
<signal name="N$35">
<contactref element="Q2" pad="3"/>
<contactref element="IC12" pad="4"/>
<wire x1="4.575" y1="65.1425" x2="2.15" y2="62.7175" width="0.508" layer="16"/>
<wire x1="2.15" y1="35.425" x2="29.5285" y2="8.0465" width="0.508" layer="16"/>
<wire x1="29.5285" y1="8.0465" x2="29.5285" y2="2.1565" width="0.508" layer="16"/>
<wire x1="2.15" y1="62.7175" x2="2.15" y2="35.425" width="0.508" layer="16"/>
</signal>
<signal name="N$34">
<contactref element="IC12" pad="5"/>
<contactref element="R32" pad="2"/>
<wire x1="54.0275" y1="31.68" x2="57.2575" y2="31.68" width="0.4064" layer="1"/>
<wire x1="57.2575" y1="31.68" x2="59.075" y2="29.8625" width="0.4064" layer="1"/>
<wire x1="59.075" y1="29.8625" x2="59.075" y2="24.6125" width="0.4064" layer="1"/>
<wire x1="59.075" y1="24.6125" x2="36.619" y2="2.1565" width="0.4064" layer="1"/>
<wire x1="36.619" y1="2.1565" x2="32.0685" y2="2.1565" width="0.4064" layer="1"/>
</signal>
</signals>
<mfgpreviewcolors>
<mfgpreviewcolor name="soldermaskcolor" color="0xC8008000"/>
<mfgpreviewcolor name="silkscreencolor" color="0xFFFEFEFE"/>
<mfgpreviewcolor name="backgroundcolor" color="0xFF282828"/>
<mfgpreviewcolor name="coppercolor" color="0xFFFFBF00"/>
<mfgpreviewcolor name="substratecolor" color="0xFF786E46"/>
</mfgpreviewcolors>
<errors>
<approved hash="21,19,2af116f316cd14f1"/>
<approved hash="21,19,7d4a814b7f4b7d73"/>
<approved hash="21,19,48964a940a940896"/>
<approved hash="21,19,82788044803afc38"/>
<approved hash="21,19,8002400242004243"/>
<approved hash="21,19,8cff8c018e3db03d"/>
<approved hash="21,19,8fc58ffb8dc7f3c7"/>
<approved hash="21,19,187e187e1a7c627c"/>
<approved hash="21,19,3522372037203522"/>
<approved hash="21,19,6d96ed96ef94ef93"/>
<approved hash="21,19,cf513353336d3191"/>
<approved hash="21,19,569356ad54916a91"/>
<approved hash="5,16,a2b61aca1867a71d"/>
<approved hash="2,20,ea5448c765e5ca0f"/>
<approved hash="2,20,f78cb95bab91ca0f"/>
<approved hash="2,20,22e10b1d402564a0"/>
<approved hash="2,20,3f39fa818e5164a0"/>
<approved hash="2,20,6b5d3ae9ca9c9651"/>
<approved hash="2,20,7685cb7504e89651"/>
<approved hash="1,20,250b272925c027e2"/>
<approved hash="1,20,b622ba00ba80b6a2"/>
<approved hash="1,20,ad046c666c85ade7"/>
<approved hash="1,20,be455c675c84bea6"/>
<approved hash="1,20,a29c01fe0f8eacec"/>
<approved hash="1,20,e243a261a383e3a1"/>
<approved hash="1,20,a0f2c1103e705f92"/>
<approved hash="1,20,b128181c1880b1b4"/>
<approved hash="1,20,a0bae418e5f1a153"/>
<approved hash="1,20,e3c323e13d87fda5"/>
<approved hash="1,20,224a69286bb220d0"/>
<approved hash="1,20,95cc19ee1b9297b0"/>
<approved hash="1,20,751579377fb67394"/>
<approved hash="1,20,5e807db47da95e9d"/>
<approved hash="1,20,7ea7859386ce7dfa"/>
<approved hash="1,20,a5cba7e9a5f0a7d2"/>
<approved hash="1,20,35683c9c3d0234f6"/>
<approved hash="1,20,72c773a5708371e1"/>
<approved hash="1,20,a39a66f86680a3e2"/>
<approved hash="23,1,527b7e0af1a9ce33"/>
<approved hash="23,1,9a44ef5e16583543"/>
<approved hash="23,16,a0b4331248624946"/>
<approved hash="7,40,280428060d3e0d3c"/>
<approved hash="7,40,10052004d849eeb9"/>
<approved hash="7,40,61f23f8db57aaa04"/>
<approved hash="7,40,281428720d4a0d2c"/>
<approved hash="7,40,b16174d4a5247a2d"/>
<approved hash="7,40,b16174d2a3d649fb"/>
<approved hash="7,40,b16174d77dd649fb"/>
<approved hash="7,40,f9a3d1229d247a3a"/>
<approved hash="7,40,b16174c3d9a47a2d"/>
<approved hash="7,40,f5f639549d247a3a"/>
<approved hash="7,40,f5f00f2291727a3a"/>
<approved hash="7,40,600069a6eec8ca16"/>
<approved hash="7,40,20bf61ffe1ffa0bf"/>
<approved hash="7,40,7850ba173a10f857"/>
<approved hash="7,40,c40035b14658ac91"/>
<approved hash="7,40,0fd3df58650e936d"/>
<approved hash="7,40,74e57438d97be26c"/>
<approved hash="7,40,e5eb8d3c349fe276"/>
<approved hash="7,40,746c26b2f6e747c7"/>
<approved hash="7,40,50e5c8e87c624e53"/>
<approved hash="7,40,8f657c7e846a59fd"/>
<approved hash="7,40,f66437e86f55d1e4"/>
<approved hash="7,40,66328536e56cd7ca"/>
<approved hash="7,40,77859838c2c033d4"/>
<approved hash="7,40,160416717109717c"/>
<approved hash="7,40,387c1669b28cc5c0"/>
<approved hash="7,40,ef910755bee56276"/>
<approved hash="7,40,74eb8d3cd8cd1368"/>
<approved hash="7,40,39964f611fd75ea0"/>
<approved hash="7,40,3823796521e25e9c"/>
<approved hash="7,40,e63a8755bed46276"/>
<approved hash="7,40,9c2acf8b97a0da50"/>
<approved hash="7,40,60d3765edbe29e53"/>
<approved hash="21,19,b9c5c7c5c539c507"/>
<approved hash="21,19,2362216021602362"/>
<approved hash="21,19,300b0c090c3709cb"/>
<approved hash="21,19,b7ebb7944b963597"/>
<approved hash="21,19,2e1c2c1e2c5e2e5c"/>
<approved hash="21,19,5eec5cee5cee5eec"/>
<approved hash="21,19,e35ae364df66e166"/>
<approved hash="21,19,341d341d361f761f"/>
<approved hash="21,19,7f557da983a9bfab"/>
<approved hash="21,19,51bc5240523c6e3c"/>
<approved hash="1,20,a14265a0648da06f"/>
<approved hash="1,20,22632641268e22ac"/>
<approved hash="11,1,0ccfc8c0fb173f18"/>
<approved hash="11,16,bc2378327e07ba16"/>
<approved hash="23,16,24552471dc183918"/>
<approved hash="23,16,3c2f38e9c2a62180"/>
<approved hash="23,16,267567c9604421f8"/>
</errors>
</board>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
</compatibility>
</eagle>
