<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.2.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="MCP3204">
<packages>
<package name="TSSOP14" urn="urn:adsk.eagle:footprint:20706/1" locally_modified="yes">
<description>&lt;b&gt;14-Lead Plastic Thin Shrink Small Outline (ST)&lt;/b&gt; - 4.4 mm Body  TSSOP &lt;/b&gt;&lt;p&gt;
Source: http://ww1.microchip.com/downloads/en/DeviceDoc/40039E.pdf</description>
<wire x1="2.455" y1="-2.15" x2="-2.455" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.455" y1="-2.15" x2="-2.455" y2="2.15" width="0.2032" layer="21"/>
<wire x1="2.455" y1="2.15" x2="2.455" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.455" y1="2.15" x2="2.455" y2="2.15" width="0.2032" layer="21"/>
<circle x="-1.825" y="-1.525" radius="0.375" width="0" layer="21"/>
<smd name="1" x="-1.95" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="2" x="-1.3" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="3" x="-0.65" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="4" x="0" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="5" x="0.65" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="6" x="1.3" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="7" x="1.95" y="-2.825" dx="0.35" dy="1" layer="1" roundness="10"/>
<smd name="8" x="1.95" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="9" x="1.3" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="10" x="0.65" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="11" x="0" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="12" x="-0.65" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="13" x="-1.3" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<smd name="14" x="-1.95" y="2.825" dx="0.35" dy="1" layer="1" roundness="10" rot="R180"/>
<text x="-3.15" y="-2.85" size="1.27" layer="25" font="vector" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.1" y="-3.15" size="1.27" layer="27" font="vector" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1" y1="-3.2" x2="-1.8" y2="-2.225" layer="51"/>
<rectangle x1="-1.45" y1="-3.2" x2="-1.15" y2="-2.225" layer="51"/>
<rectangle x1="-0.8" y1="-3.2" x2="-0.5" y2="-2.225" layer="51"/>
<rectangle x1="-0.15" y1="-3.2" x2="0.15" y2="-2.225" layer="51"/>
<rectangle x1="0.5" y1="-3.2" x2="0.8" y2="-2.225" layer="51"/>
<rectangle x1="1.15" y1="-3.2" x2="1.45" y2="-2.225" layer="51"/>
<rectangle x1="1.8" y1="-3.2" x2="2.1" y2="-2.225" layer="51"/>
<rectangle x1="1.8" y1="2.225" x2="2.1" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="1.15" y1="2.225" x2="1.45" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="0.5" y1="2.225" x2="0.8" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="-0.15" y1="2.225" x2="0.15" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="-0.8" y1="2.225" x2="-0.5" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="-1.45" y1="2.225" x2="-1.15" y2="3.2" layer="51" rot="R180"/>
<rectangle x1="-2.1" y1="2.225" x2="-1.8" y2="3.2" layer="51" rot="R180"/>
</package>
</packages>
<packages3d>
<package3d name="TSSOP14" urn="urn:adsk.eagle:package:20830/2" locally_modified="yes" type="model">
<description>14-Lead Plastic Thin Shrink Small Outline (ST) - 4.4 mm Body  TSSOP
<packageinstances>
<packageinstance name="TSSOP14"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="MCP3204">
<pin name="CH0" x="-20.32" y="15.24" length="middle"/>
<pin name="CH1" x="-20.32" y="10.16" length="middle"/>
<pin name="CH2" x="-20.32" y="5.08" length="middle"/>
<pin name="CH3" x="-20.32" y="0" length="middle"/>
<pin name="NC1" x="-20.32" y="-5.08" length="middle"/>
<pin name="NC2" x="-20.32" y="-10.16" length="middle"/>
<pin name="DGND" x="-20.32" y="-15.24" length="middle"/>
<pin name="CS/SHDN" x="20.32" y="-15.24" length="middle" rot="R180"/>
<pin name="DIN" x="20.32" y="-10.16" length="middle" rot="R180"/>
<pin name="DOUT" x="20.32" y="-5.08" length="middle" rot="R180"/>
<pin name="CLK" x="20.32" y="0" length="middle" rot="R180"/>
<pin name="AGND" x="20.32" y="5.08" length="middle" rot="R180"/>
<pin name="VREF" x="20.32" y="10.16" length="middle" rot="R180"/>
<pin name="VDD" x="20.32" y="15.24" length="middle" rot="R180"/>
<wire x1="-15.24" y1="-17.78" x2="-15.24" y2="17.78" width="0.254" layer="94"/>
<wire x1="-15.24" y1="17.78" x2="-2.54" y2="17.78" width="0.254" layer="94"/>
<wire x1="-2.54" y1="17.78" x2="0" y2="15.24" width="0.254" layer="94" curve="90"/>
<wire x1="0" y1="15.24" x2="2.54" y2="17.78" width="0.254" layer="94" curve="90"/>
<wire x1="2.54" y1="17.78" x2="15.24" y2="17.78" width="0.254" layer="94"/>
<wire x1="15.24" y1="17.78" x2="15.24" y2="-17.78" width="0.254" layer="94"/>
<wire x1="15.24" y1="-17.78" x2="-15.24" y2="-17.78" width="0.254" layer="94"/>
<text x="-15.24" y="20.32" size="1.27" layer="95">&gt;NAME</text>
<text x="-12.7" y="-20.32" size="1.27" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="MCP3204" prefix="IC">
<gates>
<gate name="G$1" symbol="MCP3204" x="0" y="0"/>
</gates>
<devices>
<device name="TSSOP-14" package="TSSOP14">
<connects>
<connect gate="G$1" pin="AGND" pad="12"/>
<connect gate="G$1" pin="CH0" pad="1"/>
<connect gate="G$1" pin="CH1" pad="2"/>
<connect gate="G$1" pin="CH2" pad="3"/>
<connect gate="G$1" pin="CH3" pad="4"/>
<connect gate="G$1" pin="CLK" pad="11"/>
<connect gate="G$1" pin="CS/SHDN" pad="8"/>
<connect gate="G$1" pin="DGND" pad="7"/>
<connect gate="G$1" pin="DIN" pad="9"/>
<connect gate="G$1" pin="DOUT" pad="10"/>
<connect gate="G$1" pin="NC1" pad="5"/>
<connect gate="G$1" pin="NC2" pad="6"/>
<connect gate="G$1" pin="VDD" pad="14"/>
<connect gate="G$1" pin="VREF" pad="13"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:20830/2"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="MPN" value="MCP3204-CI/ST"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="MCP4922">
<packages>
<text x="-2.6" y="-2.6" size="1.27" layer="25" font="vector" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.9" y="-3.25" size="1.27" layer="27" font="vector" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<packageinstances>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="MCP4922T">
<pin name="VDD" x="-22.86" y="15.24" length="middle"/>
<pin name="NC1" x="-22.86" y="10.16" length="middle"/>
<pin name="CS" x="-22.86" y="5.08" length="middle"/>
<pin name="SCK" x="-22.86" y="0" length="middle"/>
<pin name="SDI" x="-22.86" y="-5.08" length="middle"/>
<pin name="NC2" x="-22.86" y="-10.16" length="middle"/>
<pin name="NC3" x="-22.86" y="-15.24" length="middle"/>
<pin name="LDAC" x="22.86" y="-15.24" length="middle" rot="R180"/>
<pin name="SHDN" x="22.86" y="-10.16" length="middle" rot="R180"/>
<pin name="VOUTB" x="22.86" y="-5.08" length="middle" rot="R180"/>
<pin name="VREFB" x="22.86" y="0" length="middle" rot="R180"/>
<pin name="VSS" x="22.86" y="5.08" length="middle" rot="R180"/>
<pin name="VREFA" x="22.86" y="10.16" length="middle" rot="R180"/>
<pin name="VOUTA" x="22.86" y="15.24" length="middle" rot="R180"/>
<wire x1="-17.78" y1="-17.78" x2="-17.78" y2="17.78" width="0.254" layer="94"/>
<wire x1="-17.78" y1="-17.78" x2="17.78" y2="-17.78" width="0.254" layer="94"/>
<wire x1="17.78" y1="-17.78" x2="17.78" y2="17.78" width="0.254" layer="94"/>
<wire x1="17.78" y1="17.78" x2="2.54" y2="17.78" width="0.254" layer="94"/>
<wire x1="2.54" y1="17.78" x2="0" y2="15.24" width="0.254" layer="94" curve="-90"/>
<wire x1="0" y1="15.24" x2="-2.54" y2="17.78" width="0.254" layer="94" curve="-90"/>
<wire x1="-2.54" y1="17.78" x2="-17.78" y2="17.78" width="0.254" layer="94"/>
<text x="-15.24" y="20.32" size="1.778" layer="95">&gt;NAME</text>
<text x="-15.24" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="MCP4922T" prefix="IC">
<gates>
<gate name="G$1" symbol="MCP4922T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="CS" pad="3"/>
<connect gate="G$1" pin="LDAC" pad="8"/>
<connect gate="G$1" pin="NC1" pad="2"/>
<connect gate="G$1" pin="NC3" pad="7"/>
<connect gate="G$1" pin="SCK" pad="4"/>
<connect gate="G$1" pin="SDI" pad="5"/>
<connect gate="G$1" pin="SHDN" pad="9"/>
<connect gate="G$1" pin="VDD" pad="1"/>
<connect gate="G$1" pin="VOUTA" pad="14"/>
<connect gate="G$1" pin="VOUTB" pad="10"/>
<connect gate="G$1" pin="VREFA" pad="13"/>
<connect gate="G$1" pin="VREFB" pad="11"/>
<connect gate="G$1" pin="VSS" pad="12"/>
</connects>
<technologies>
<attribute name="MPN" value="MCP4922T-E/ST"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="LM341T-5.0:NOPB">
<packages>
<package name="TO220V" urn="urn:adsk.eagle:footprint:8085814/1" locally_modified="yes">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="51"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="51"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="51"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="51"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="51"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="51"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="51"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="51"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="51"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="51"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="51"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="TO220V" urn="urn:adsk.eagle:package:8089447/1" locally_modified="yes" type="box">
<packageinstances>
<packageinstance name="TO220V"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="LM341T-5.0/NOPB">
<pin name="IN" x="-15.24" y="2.54" length="middle"/>
<pin name="GND" x="0" y="-12.7" length="middle" rot="R90"/>
<pin name="OUT" x="15.24" y="2.54" length="middle" rot="R180"/>
<wire x1="-10.16" y1="7.62" x2="-10.16" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-7.62" x2="10.16" y2="-7.62" width="0.254" layer="94"/>
<wire x1="10.16" y1="-7.62" x2="10.16" y2="7.62" width="0.254" layer="94"/>
<wire x1="10.16" y1="7.62" x2="-10.16" y2="7.62" width="0.254" layer="94"/>
<text x="-10.16" y="10.16" size="1.778" layer="95">&gt;NAME</text>
<text x="-15.24" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="LM341T-5.0/NOPB" prefix="IC">
<gates>
<gate name="G$1" symbol="LM341T-5.0/NOPB" x="0" y="0"/>
</gates>
<devices>
<device name="TO-220" package="TO220V">
<connects>
<connect gate="G$1" pin="GND" pad="2"/>
<connect gate="G$1" pin="IN" pad="1"/>
<connect gate="G$1" pin="OUT" pad="3"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:8089447/1"/>
<technologies>
<attribute name="MPN" value="LM341T-5.0/NOPB"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="MCP1700-3302E:TO">
<packages>
<package name="TO-92" urn="urn:adsk.eagle:footprint:8085814/1" locally_modified="yes">
<wire x1="-2.0746" y1="-2.171" x2="-2.6349" y2="-0.774" width="0.127" layer="21" curve="-32.78104"/>
<wire x1="-2.6349" y1="-0.774" x2="-0.7663" y2="2.0285" width="0.127" layer="21" curve="-78.318477"/>
<wire x1="0.8063" y1="2.0284" x2="2.1145" y2="-2.171" width="0.127" layer="21" curve="-111.09954"/>
<wire x1="-2.0745" y1="-2.171" x2="2.1145" y2="-2.171" width="0.127" layer="51"/>
<wire x1="-2.2337" y1="-0.774" x2="-0.2663" y2="-0.774" width="0.127" layer="51"/>
<wire x1="-2.6349" y1="-0.774" x2="-2.2337" y2="-0.774" width="0.127" layer="21"/>
<wire x1="-0.2663" y1="-0.774" x2="0.3063" y2="-0.774" width="0.127" layer="21"/>
<wire x1="2.2737" y1="-0.774" x2="2.6749" y2="-0.774" width="0.127" layer="21"/>
<wire x1="0.3063" y1="-0.774" x2="2.2737" y2="-0.774" width="0.127" layer="51"/>
<wire x1="-0.7663" y1="2.0285" x2="0.8063" y2="2.0285" width="0.127" layer="51" curve="-34.293591"/>
<pad name="3" x="1.29" y="-0.52" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="0.02" y="1.385" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="1" x="-1.25" y="-0.52" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="3.195" y="0.115" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="3.195" y="-1.79" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<packageinstances>
<packageinstance name="TO-92"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
</symbol>
</symbols>
<devicesets>
<deviceset name="MCP1700-3302E/TO" prefix="IC">
<gates>
</gates>
<devices>
<device name="TO-220" package="TO-92">
<connects>
<connect gate="G$1" pin="GND" pad="1"/>
<connect gate="G$1" pin="IN" pad="2"/>
</connects>
<technologies>
<attribute name="MPN" value="MCP1700-3302E/TO"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="NJM14558D">
<packages>
<package name="DIL8" urn="urn:adsk.eagle:footprint:20613/1">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type P</description>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="5.08" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90" first="yes"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.2578" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.239" y="-2.54" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="DIL8" urn="urn:adsk.eagle:package:20796/2" type="model">
<description>Dual In Line
<packageinstances>
<packageinstance name="DIL8"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="NJM14558D">
<pin name="1OUT" x="-17.78" y="7.62" length="middle"/>
<pin name="1IN-" x="-17.78" y="2.54" length="middle"/>
<pin name="1IN+" x="-17.78" y="-2.54" length="middle"/>
<pin name="VCC" x="-17.78" y="-7.62" length="middle"/>
<pin name="2IN+" x="17.78" y="-7.62" length="middle" rot="R180"/>
<pin name="2IN-" x="17.78" y="-2.54" length="middle" rot="R180"/>
<pin name="2OUT" x="17.78" y="2.54" length="middle" rot="R180"/>
<pin name="VDD" x="17.78" y="7.62" length="middle" rot="R180"/>
<wire x1="-12.7" y1="10.16" x2="-12.7" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-12.7" y1="-10.16" x2="12.7" y2="-10.16" width="0.254" layer="94"/>
<wire x1="12.7" y1="-10.16" x2="12.7" y2="10.16" width="0.254" layer="94"/>
<wire x1="12.7" y1="10.16" x2="2.54" y2="10.16" width="0.254" layer="94"/>
<wire x1="2.54" y1="10.16" x2="0" y2="7.62" width="0.254" layer="94" curve="-90"/>
<wire x1="0" y1="7.62" x2="-2.54" y2="10.16" width="0.254" layer="94" curve="-90"/>
<wire x1="-2.54" y1="10.16" x2="-12.7" y2="10.16" width="0.254" layer="94"/>
<text x="-12.7" y="12.7" size="1.778" layer="95">&gt;NAME</text>
<text x="-12.7" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="NJM14558D" prefix="IC">
<gates>
<gate name="G$1" symbol="NJM14558D" x="0" y="0"/>
</gates>
<devices>
<device name="DIL-8" package="DIL8">
<connects>
<connect gate="G$1" pin="1IN+" pad="3"/>
<connect gate="G$1" pin="1IN-" pad="2"/>
<connect gate="G$1" pin="1OUT" pad="1"/>
<connect gate="G$1" pin="2IN+" pad="5"/>
<connect gate="G$1" pin="2IN-" pad="6"/>
<connect gate="G$1" pin="2OUT" pad="7"/>
<connect gate="G$1" pin="VCC" pad="4"/>
<connect gate="G$1" pin="VDD" pad="8"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:20796/2"/>
<technologies>
<attribute name="MPN" value="NJM14558D"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="MAX4080F">
<packages>
<package name="SOIC8" urn="urn:adsk.eagle:footprint:15990/1" locally_modified="yes">
<description>&lt;b&gt;Small Outline IC&lt;/b&gt;</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1" roundness="10"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" font="vector" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" font="vector" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="SOIC8" urn="urn:adsk.eagle:package:16057/2" locally_modified="yes" type="model">
<description>Small Outline IC</description>
<packageinstances>
<packageinstance name="SOIC8"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="MAX4080FASA+">
<pin name="RS+" x="-20.32" y="7.62" length="middle"/>
<pin name="VCC" x="-20.32" y="2.54" length="middle"/>
<pin name="NC1" x="-20.32" y="-2.54" length="middle"/>
<pin name="GND" x="-20.32" y="-7.62" length="middle"/>
<pin name="OUT" x="20.32" y="-7.62" length="middle" rot="R180"/>
<pin name="NC2" x="20.32" y="-2.54" length="middle" rot="R180"/>
<pin name="NC3" x="20.32" y="2.54" length="middle" rot="R180"/>
<pin name="RS-" x="20.32" y="7.62" length="middle" rot="R180"/>
<wire x1="-15.24" y1="10.16" x2="-15.24" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-15.24" y1="-10.16" x2="15.24" y2="-10.16" width="0.254" layer="94"/>
<wire x1="15.24" y1="-10.16" x2="15.24" y2="10.16" width="0.254" layer="94"/>
<wire x1="15.24" y1="10.16" x2="2.54" y2="10.16" width="0.254" layer="94"/>
<wire x1="-2.54" y1="10.16" x2="-15.24" y2="10.16" width="0.254" layer="94"/>
<text x="-15.24" y="12.7" size="1.778" layer="95">&gt;NAME</text>
<text x="-15.24" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="MAX4080FASA+" prefix="IC">
<gates>
<gate name="G$1" symbol="MAX4080FASA+" x="0" y="0"/>
</gates>
<devices>
<device name="8-SOIC" package="SOIC8">
<connects>
<connect gate="G$1" pin="GND" pad="4"/>
<connect gate="G$1" pin="NC1" pad="3"/>
<connect gate="G$1" pin="OUT" pad="5"/>
<connect gate="G$1" pin="RS+" pad="1"/>
<connect gate="G$1" pin="RS-" pad="8"/>
<connect gate="G$1" pin="VCC" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:16057/2"/>
<technologies>
<attribute name="MPN" value="MAX4080FASA+"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="MAX4238ASA+">
<packages>
<package name="8-SO">
<smd name="P$1" x="-1.905" y="-2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$2" x="-0.635" y="-2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$3" x="0.635" y="-2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$4" x="1.905" y="-2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$5" x="1.855" y="2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$6" x="0.635" y="2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$7" x="-0.635" y="2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<smd name="P$8" x="-1.905" y="2.5" dx="0.8" dy="1.5" layer="1" roundness="10"/>
<wire x1="2.5" y1="2" x2="-2.5" y2="2" width="0.127" layer="51"/>
<wire x1="-2.5" y1="2" x2="-2.5" y2="-2" width="0.127" layer="51"/>
<wire x1="-2.5" y1="-2" x2="2.5" y2="-2" width="0.127" layer="51"/>
<wire x1="2.5" y1="-2" x2="2.5" y2="2" width="0.127" layer="51"/>
<circle x="-2.05" y="-1.45" radius="0.206153125" width="0.127" layer="51"/>
<wire x1="-2.5" y1="2" x2="-2.5" y2="-2" width="0.127" layer="21"/>
<circle x="-2.9" y="-1.85" radius="0.206153125" width="0.127" layer="21"/>
<wire x1="2.5" y1="2" x2="2.5" y2="-2" width="0.127" layer="21"/>
<text x="-3.15" y="3.9" size="1.27" layer="21" font="vector" ratio="10">&gt;NAME</text>
<text x="-3.45" y="-5.2" size="1.27" layer="21" font="vector" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="MAX4238ASA+">
<pin name="SHDN" x="-20.32" y="7.62" length="middle"/>
<pin name="IN-" x="-20.32" y="2.54" length="middle"/>
<pin name="IN+" x="-20.32" y="-2.54" length="middle"/>
<pin name="NC1" x="20.32" y="-7.62" length="middle" rot="R180"/>
<pin name="OUT" x="20.32" y="-2.54" length="middle" rot="R180"/>
<pin name="VCC" x="20.32" y="2.54" length="middle" rot="R180"/>
<pin name="NC2" x="20.32" y="7.62" length="middle" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MAX4238ASA+" prefix="IC">
<gates>
<gate name="G$1" symbol="MAX4238ASA+" x="0" y="0"/>
</gates>
<devices>
<device name="" package="8-SO">
<connects>
<connect gate="G$1" pin="GND" pad="P$4"/>
<connect gate="G$1" pin="IN+" pad="P$3"/>
<connect gate="G$1" pin="IN-" pad="P$2"/>
<connect gate="G$1" pin="NC1" pad="P$5"/>
<connect gate="G$1" pin="NC2" pad="P$8"/>
<connect gate="G$1" pin="OUT" pad="P$6"/>
<connect gate="G$1" pin="SHDN" pad="P$1"/>
<connect gate="G$1" pin="VCC" pad="P$7"/>
</connects>
<technologies>
<attribute name="MPN" value="MAX4238ASA+"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="LT3083">
<packages>
<package name="TO220-5" urn="urn:adsk.eagle:footprint:15991/1">
<description>&lt;b&gt;TO220-5&lt;/b&gt;</description>
<wire x1="-1.87" y1="-0.2" x2="-1.87" y2="-0.3" width="0.0508" layer="51"/>
<wire x1="-1.87" y1="-0.4" x2="-1.87" y2="-0.5" width="0.0508" layer="51"/>
<wire x1="-1.87" y1="-0.6" x2="-1.87" y2="-0.7" width="0.0508" layer="51"/>
<wire x1="-1.87" y1="-1" x2="-1.87" y2="-1.17" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-1.17" x2="1.87" y2="-1" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-0.9" x2="1.87" y2="-0.8" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-0.7" x2="1.87" y2="-0.6" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-0.5" x2="1.87" y2="-0.4" width="0.0508" layer="51"/>
<wire x1="1.87" y1="-0.3" x2="1.87" y2="-0.2" width="0.0508" layer="51"/>
<wire x1="-5" y1="-0.1" x2="-5" y2="-1.2" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="-1.2" x2="-4.9" y2="-3.6" width="0.2032" layer="51"/>
<wire x1="-4.9" y1="-3.6" x2="-4.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-4.5" x2="4.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="4.5" y1="-4.5" x2="4.9" y2="-3.6" width="0.2032" layer="51"/>
<wire x1="4.9" y1="-3.6" x2="4.9" y2="-1.2" width="0.2032" layer="51"/>
<wire x1="5" y1="-1.2" x2="5" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="5" y1="-0.1" x2="-5" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="-5" y1="-1.2" x2="5" y2="-1.2" width="0.2032" layer="21"/>
<wire x1="-1.87" y1="-0.8" x2="-1.87" y2="-0.9" width="0.0508" layer="51"/>
<wire x1="-4.9" y1="-3.6" x2="4.9" y2="-3.6" width="0.2032" layer="51"/>
<pad name="2" x="-1.7" y="-4.5" drill="0.9" shape="long" rot="R90"/>
<pad name="4" x="1.7" y="-4.5" drill="0.9" shape="long" rot="R90"/>
<pad name="1" x="-3.4" y="-8.4" drill="0.9" shape="long" rot="R90"/>
<pad name="3" x="0" y="-8.4" drill="0.9" shape="long" rot="R90"/>
<pad name="5" x="3.4" y="-8.4" drill="0.9" shape="long" rot="R90"/>
<text x="-5.08" y="-8.382" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="6.35" y="-8.382" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-3.8" y1="-8.6" x2="-3" y2="-7.5" layer="51"/>
<rectangle x1="-0.4" y1="-8.6" x2="0.4" y2="-7.5" layer="51"/>
<rectangle x1="3" y1="-8.6" x2="3.8" y2="-7.5" layer="51"/>
<rectangle x1="-3.8" y1="-7.5" x2="-3" y2="-4.5" layer="51"/>
<rectangle x1="-0.4" y1="-7.5" x2="0.4" y2="-4.5" layer="51"/>
<rectangle x1="3" y1="-7.5" x2="3.8" y2="-4.5" layer="51"/>
<rectangle x1="-2.1" y1="-4.7" x2="-1.3" y2="-4.5" layer="51"/>
<rectangle x1="1.3" y1="-4.7" x2="2.1" y2="-4.5" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="TO220-5" urn="urn:adsk.eagle:package:16056/1" type="box">
<description>TO220-5</description>
<packageinstances>
<packageinstance name="TO220-5"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="LT3083ET#PBF">
<pin name="VCONTROL" x="-17.78" y="5.08" length="middle"/>
<pin name="IN" x="-17.78" y="0" length="middle"/>
<pin name="SET" x="0" y="-12.7" length="middle" rot="R90"/>
<pin name="OUT" x="17.78" y="0" length="middle" rot="R180"/>
<wire x1="-12.7" y1="7.62" x2="-12.7" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-12.7" y1="-7.62" x2="12.7" y2="-7.62" width="0.254" layer="94"/>
<wire x1="12.7" y1="-7.62" x2="12.7" y2="7.62" width="0.254" layer="94"/>
<wire x1="12.7" y1="7.62" x2="-12.7" y2="7.62" width="0.254" layer="94"/>
<text x="-12.7" y="10.16" size="1.778" layer="95">&gt;NAME</text>
<pin name="NC" x="-17.78" y="-5.08" length="middle"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="LT3083ET#PBF" prefix="IC">
<gates>
<gate name="G$1" symbol="LT3083ET#PBF" x="0" y="0"/>
</gates>
<devices>
<device name="TO220-5" package="TO220-5">
<connects>
<connect gate="G$1" pin="IN" pad="5"/>
<connect gate="G$1" pin="NC" pad="1"/>
<connect gate="G$1" pin="SET" pad="2"/>
<connect gate="G$1" pin="VCONTROL" pad="4"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:16056/1"/>
<technologies>
<attribute name="MPN" value="LT3083ET#PBF"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="SB540E-G">
<packages>
<package name="DO201-15" urn="urn:adsk.eagle:footprint:43127/1" locally_modified="yes">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 5.6 mm, horizontal, grid 15.24 mm</description>
<wire x1="-5.08" y1="-2.794" x2="-5.08" y2="2.794" width="0.1524" layer="51"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="51"/>
<wire x1="5.08" y1="-2.794" x2="-5.08" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="7.62" y1="0" x2="6.223" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.223" y2="0" width="1.27" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.4986" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.4986" shape="long"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.159" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.191" y1="-2.794" x2="-3.429" y2="2.794" layer="51"/>
<rectangle x1="-5.969" y1="-0.635" x2="-5.08" y2="0.635" layer="51"/>
<rectangle x1="5.08" y1="-0.635" x2="5.969" y2="0.635" layer="51"/>
<wire x1="-6.2" y1="2.05" x2="-6.2" y2="1.7" width="0.127" layer="21"/>
<wire x1="-6.2" y1="1.7" x2="-6.2" y2="1.35" width="0.127" layer="21"/>
<wire x1="-6.2" y1="1.7" x2="-5.85" y2="2.05" width="0.127" layer="21"/>
<wire x1="-5.85" y1="2.05" x2="-5.85" y2="1.35" width="0.127" layer="21"/>
<wire x1="-5.85" y1="1.35" x2="-6.2" y2="1.7" width="0.127" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="DO201-15" urn="urn:adsk.eagle:package:43365/2" locally_modified="yes" type="model">
<description>DIODE
<packageinstances>
<packageinstance name="DO201-15"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="SB540E-G">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.27" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.27" x2="1.905" y2="1.016" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="0.635" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0.635" y1="-1.016" x2="0.635" y2="-1.27" width="0.254" layer="94"/>
<text x="-2.286" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="SB540E-G" prefix="D">
<gates>
<gate name="G$1" symbol="SB540E-G" x="0" y="0"/>
</gates>
<devices>
<device name="DO-201AD" package="DO201-15">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43365/2"/>
<technologies>
<attribute name="MPN" value="SB540E-G"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_330">
<packages>
<package name="R0805">
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1" roundness="15"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1" roundness="15"/>
<text x="-0.635" y="1.27" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
</packages>
<symbols>
<symbol name="330">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_330" prefix="R">
<description>&lt;a href="http://de.farnell.com/multicomp/mcwr08x3002ftl/dickschichtwiderstand-30k-1-0/dp/2446951"&gt;Farnell&lt;/a&gt;
&lt;br&gt;
&lt;a href="http://www.farnell.com/datasheets/1849611.pdf?_ga=2.55851695.565178279.1509960112-1235631276.1508230459"&gt;Datasheet&lt;/a&gt;</description>
<gates>
<gate name="G$1" symbol="330" x="0" y="0"/>
</gates>
<devices>
<device name="" package="R0805">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<attribute name="MPN" value="CR0805-FX-3300ELF"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1" urn="urn:adsk.eagle:library:371">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
 &lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
</packages>
<symbols>
<symbol name="GND" urn="urn:adsk.eagle:symbol:26925/1" library_version="1">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="GND" urn="urn:adsk.eagle:component:26954/1" prefix="GND" library_version="1">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="C0805_1uF:50V">
<packages>
<package name="C0805">
<wire x1="-1.623" y1="0.983" x2="1.623" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.623" y1="0.983" x2="1.623" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.623" y1="-0.983" x2="-1.623" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.623" y1="-0.983" x2="-1.623" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.456" y1="0.632" x2="0.456" y2="0.632" width="0.1016" layer="51"/>
<wire x1="-0.456" y1="-0.619" x2="0.456" y2="-0.619" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1" dy="1.4" layer="1" roundness="15"/>
<smd name="2" x="1" y="0" dx="1" dy="1.4" layer="1" roundness="15"/>
<text x="-0.685" y="1.585" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-0.685" y="-2.805" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.0882" y1="-0.4699" x2="-0.5881" y2="0.4801" layer="51"/>
<rectangle x1="0.5802" y1="-0.4699" x2="1.0803" y2="0.4801" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
<rectangle x1="-1.1" y1="-0.65" x2="-0.55" y2="0.65" layer="51"/>
<rectangle x1="0.55" y1="-0.65" x2="1.1" y2="0.65" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="_">
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="C0805_1UF/50V" prefix="C">
<description>&lt;a href="http://de.farnell.com/kemet/c0603c105k9pactu/cap-mlcc-x5r-1uf-6-3v-0603/dp/2409038"&gt;Farnell&lt;/a&gt;
&lt;br&gt;
&lt;a href="http://www.farnell.com/datasheets/2315122.pdf?_ga=2.257401614.424028208.1508487000-1235631276.1508230459"&gt;Datasheet&lt;/a&gt;</description>
<gates>
<gate name="G$1" symbol="_" x="0" y="0"/>
</gates>
<devices>
<device name="" package="C0805">
<connects>
</connects>
<technologies>
<attribute name="MPN" value="CL21B105KBFNNNG"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="C0805_100nF:50V">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="C0805_100NF/50V" prefix="C">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="CC0805ZRY5V9BB104"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="MAX6126AASA21+">
<packages>
</package>
</packages>
<symbols>
<symbol name="MAX6126AASA21+">
<pin name="NR" x="-20.32" y="7.62" length="middle"/>
<pin name="IN" x="-20.32" y="2.54" length="middle"/>
<pin name="GND" x="-20.32" y="-2.54" length="middle"/>
<pin name="GNDS" x="-20.32" y="-7.62" length="middle"/>
<pin name="I.C.1" x="20.32" y="-7.62" length="middle" rot="R180"/>
<pin name="OUTS" x="20.32" y="-2.54" length="middle" rot="R180"/>
<pin name="OUTF" x="20.32" y="2.54" length="middle" rot="R180"/>
<pin name="I.C.2" x="20.32" y="7.62" length="middle" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MAX6126AASA21+" prefix="IC">
<gates>
<gate name="G$1" symbol="MAX6126AASA21+" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="GND" pad="P$3"/>
<connect gate="G$1" pin="GNDS" pad="P$4"/>
<connect gate="G$1" pin="I.C.1" pad="P$5"/>
<connect gate="G$1" pin="I.C.2" pad="P$8"/>
<connect gate="G$1" pin="IN" pad="P$2"/>
<connect gate="G$1" pin="NR" pad="P$1"/>
<connect gate="G$1" pin="OUTF" pad="P$7"/>
<connect gate="G$1" pin="OUTS" pad="P$6"/>
</connects>
<technologies>
<attribute name="MPN" value="MAX6126AASA21+"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="2Ohm_06W">
<packages>
<package name="0207/10" urn="urn:adsk.eagle:footprint:8118326/1">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="0207/10" urn="urn:adsk.eagle:package:8118469/1" type="box">
<packageinstances>
<packageinstance name="0207/10"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="2OHM_06W">
</symbol>
</symbols>
<devicesets>
<deviceset name="2OHM_06W" prefix="R">
<gates>
<gate name="G$1" symbol="2OHM_06W" x="0" y="0"/>
</gates>
<devices>
<device name="MBB/SMA0207" package="0207/10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<technologies>
<attribute name="MPN" value="MBB02070C2008FRP00"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="C0805_10uF:35V">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="C0805_10UF/35V" prefix="C">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="GRM21BC8YA106KE11L"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="LM334Z:LFT1">
<packages>
<package name="TO92" urn="urn:adsk.eagle:footprint:20710/1" locally_modified="yes">
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-2.6549" y2="-0.254" width="0.127" layer="21" curve="-32.78104"/>
<wire x1="-2.6549" y1="-0.254" x2="-0.7863" y2="2.5485" width="0.127" layer="21" curve="-78.318477"/>
<wire x1="0.7863" y1="2.5484" x2="2.0945" y2="-1.651" width="0.127" layer="21" curve="-111.09954"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.2537" y1="-0.254" x2="-0.2863" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.2863" y1="-0.254" x2="2.2537" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.127" layer="51" curve="-34.293591"/>
<pad name="3" x="1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="TO92" urn="urn:adsk.eagle:package:20831/2" locally_modified="yes" type="model">
<description>TO 92</description>
<packageinstances>
<packageinstance name="TO92"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="LM334Z/LFT1">
<pin name="V+" x="-15.24" y="0" length="middle"/>
<pin name="R" x="0" y="-15.24" length="middle" rot="R90"/>
<pin name="V-" x="15.24" y="0" length="middle" rot="R180"/>
<wire x1="-10.16" y1="5.08" x2="-10.16" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-10.16" x2="10.16" y2="-10.16" width="0.254" layer="94"/>
<wire x1="10.16" y1="-10.16" x2="10.16" y2="5.08" width="0.254" layer="94"/>
<wire x1="10.16" y1="5.08" x2="-10.16" y2="5.08" width="0.254" layer="94"/>
<text x="-10.16" y="7.62" size="1.778" layer="95">&gt;NAME</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="LM334Z/LFT1" prefix="IC">
<gates>
<gate name="G$1" symbol="LM334Z/LFT1" x="0" y="2.54"/>
</gates>
<devices>
<device name="TO-92" package="TO92">
<connects>
<connect gate="G$1" pin="R" pad="2"/>
<connect gate="G$1" pin="V+" pad="1"/>
<connect gate="G$1" pin="V-" pad="3"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:20831/2"/>
<technologies>
<attribute name="MPN" value="LM334Z/LFT1"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name=" 1N457">
<packages>
<package name="DO35-7" urn="urn:adsk.eagle:footprint:43093/1" locally_modified="yes">
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="51" curve="-90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="51"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="51"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<wire x1="1.2" y1="0" x2="1.2" y2="0.3" width="0.127" layer="21"/>
<wire x1="1.2" y1="0" x2="1.2" y2="-0.3" width="0.127" layer="21"/>
<wire x1="1.2" y1="0" x2="1.5" y2="0.3" width="0.127" layer="21"/>
<wire x1="1.5" y1="0.3" x2="1.5" y2="-0.3" width="0.127" layer="21"/>
<wire x1="1.5" y1="-0.3" x2="1.2" y2="0" width="0.127" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="DO35-7" urn="urn:adsk.eagle:package:43339/2" locally_modified="yes" type="model">
<description>DIODE
<packageinstances>
<packageinstance name="DO35-7"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="1N457">
<text x="2.54" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.3114" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="0" size="0.4064" layer="99" align="center">SpiceOrder 1</text>
<text x="2.54" y="0" size="0.4064" layer="99" align="center">SpiceOrder 2</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="1N457" prefix="D">
<gates>
<gate name="G$1" symbol="1N457" x="0" y="0"/>
</gates>
<devices>
<device name="DO-35" package="DO35-7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43339/2"/>
<technologies>
<attribute name="MPN" value="1N457"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_10k_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_10K_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="ERA-6AEB103V"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_10k">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_10K" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="RMCF0805JT10K0"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_1k">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_1K" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="CRGCQ0805J1K0"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_100">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_100" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="CRGCQ0805J100R"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="2N3904-AP">
<packages>
</package>
</packages>
<packages3d>
<packageinstances>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="2N3904-AP">
<wire x1="2.54" y1="2.54" x2="0.508" y2="1.524" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-1.524" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.778" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.54" y1="-2.04" x2="0.308" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-2.413" x2="2.286" y2="-2.413" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.413" x2="1.778" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.778" x2="1.524" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.524" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.032" width="0.254" layer="94"/>
<text x="-10.16" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="E" x="2.54" y="-5.08" visible="off" length="short" direction="pas" swaplevel="3" rot="R90"/>
<pin name="C" x="2.54" y="5.08" visible="off" length="short" direction="pas" swaplevel="2" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="2N3904-AP" prefix="Q">
<gates>
<gate name="G$1" symbol="2N3904-AP" x="0" y="2.54"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="B" pad="2"/>
<connect gate="G$1" pin="C" pad="3"/>
<connect gate="G$1" pin="E" pad="1"/>
</connects>
<technologies>
<attribute name="MPN" value="2N3904-AP"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="IRLU8721-701PBF">
<packages>
<package name="TO252" urn="urn:adsk.eagle:footprint:28481/1" locally_modified="yes">
<description>&lt;b&gt;SMALL OUTLINE TRANSISTOR&lt;/b&gt;&lt;p&gt;
TS-003</description>
<wire x1="3.2766" y1="3.8354" x2="3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-2.159" x2="-3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-2.159" x2="-3.2766" y2="3.8354" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="3.835" x2="3.2774" y2="3.8346" width="0.2032" layer="51"/>
<wire x1="-3.973" y1="5.983" x2="3.973" y2="5.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-5.983" x2="-3.973" y2="-5.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-5.983" x2="-3.973" y2="5.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="5.983" x2="3.973" y2="-5.983" width="0.0508" layer="39"/>
<wire x1="-2.5654" y1="3.937" x2="-2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="4.6482" x2="-2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="-2.1082" y1="5.1054" x2="2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="2.1082" y1="5.1054" x2="2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="4.6482" x2="2.5654" y2="3.937" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="3.937" x2="-2.5654" y2="3.937" width="0.2032" layer="51"/>
<smd name="3" x="0" y="2.5" dx="5.4" dy="6.2" layer="1"/>
<smd name="1" x="-2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<smd name="2" x="2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" font="vector" ratio="10" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" font="vector" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7178" y1="-5.1562" x2="-1.8542" y2="-2.2606" layer="51"/>
<rectangle x1="1.8542" y1="-5.1562" x2="2.7178" y2="-2.2606" layer="51"/>
<rectangle x1="-0.4318" y1="-3.0226" x2="0.4318" y2="-2.2606" layer="51"/>
<polygon width="0.1998" layer="51">
<vertex x="-2.5654" y="3.937"/>
<vertex x="-2.5654" y="4.6482"/>
<vertex x="-2.1082" y="5.1054"/>
<vertex x="2.1082" y="5.1054"/>
<vertex x="2.5654" y="4.6482"/>
<vertex x="2.5654" y="3.937"/>
</polygon>
</package>
</packages>
<packages3d>
<package3d name="TO252" urn="urn:adsk.eagle:package:28537/2" locally_modified="yes" type="model">
<description>SMALL OUTLINE TRANSISTOR
<packageinstances>
<packageinstance name="TO252"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="IRLU8721-701PBF">
<wire x1="-1.778" y1="0.762" x2="-1.778" y2="0" width="0.254" layer="94"/>
<wire x1="-1.778" y1="0" x2="-1.778" y2="-0.762" width="0.254" layer="94"/>
<wire x1="-1.778" y1="3.175" x2="-1.778" y2="2.54" width="0.254" layer="94"/>
<wire x1="-1.778" y1="2.54" x2="-1.778" y2="1.905" width="0.254" layer="94"/>
<wire x1="-1.778" y1="0" x2="0" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-1.778" y1="-1.905" x2="-1.778" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-1.778" y1="-2.54" x2="-1.778" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="-1.778" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="2.54" x2="1.27" y2="0.508" width="0.1524" layer="94"/>
<wire x1="1.27" y1="0.508" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-1.778" y1="2.54" x2="1.27" y2="2.54" width="0.1524" layer="94"/>
<wire x1="2.032" y1="0.762" x2="1.778" y2="0.508" width="0.1524" layer="94"/>
<wire x1="1.778" y1="0.508" x2="1.27" y2="0.508" width="0.1524" layer="94"/>
<wire x1="1.27" y1="0.508" x2="0.762" y2="0.508" width="0.1524" layer="94"/>
<wire x1="0.762" y1="0.508" x2="0.508" y2="0.254" width="0.1524" layer="94"/>
<circle x="0" y="-2.54" radius="0.3592" width="0" layer="94"/>
<circle x="0" y="2.54" radius="0.3592" width="0" layer="94"/>
<text x="-13.97" y="0" size="1.778" layer="96">&gt;VALUE</text>
<text x="-13.97" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<pin name="S" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="G" x="-5.08" y="-2.54" visible="off" length="short" direction="pas"/>
<pin name="D" x="0" y="5.08" visible="off" length="short" direction="pas" rot="R270"/>
<polygon width="0.1524" layer="94">
<vertex x="1.27" y="0.508"/>
<vertex x="0.762" y="-0.254"/>
<vertex x="1.778" y="-0.254"/>
</polygon>
<vertex x="-1.524" y="0"/>
<vertex x="-0.508" y="0.762"/>
<vertex x="-0.508" y="-0.762"/>
</polygon>
</symbol>
</symbols>
<devicesets>
<deviceset name="IRLU8721-701PBF" prefix="Q">
<gates>
<gate name="G$1" symbol="IRLU8721-701PBF" x="0" y="0"/>
</gates>
<devices>
<device name="TO-252" package="TO252">
<connects>
<connect gate="G$1" pin="D" pad="3"/>
<connect gate="G$1" pin="G" pad="1"/>
<connect gate="G$1" pin="S" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28537/2"/>
<technologies>
<attribute name="MPN" value="IRLU8721-701PBF"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_133Ohm_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_133OHM_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="RN73C2A133RBTDF"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_1k33_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_1K33_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="RG2012P-1331-B-T5"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="20Ohm_06W_0.1%">
<packages>
<package name="0207/10" urn="urn:adsk.eagle:footprint:8118326/1" locally_modified="yes">
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="51" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="51" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="51" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="51"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<text x="-3.048" y="2.794" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-3.5306" y="-3.175" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="0207/10" urn="urn:adsk.eagle:package:8118469/1" locally_modified="yes" type="box">
<packageinstances>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="20OHM_06W">
</symbol>
</symbols>
<devicesets>
<deviceset name="20OHM_06W_0.1%" prefix="R">
<gates>
<gate name="G$1" symbol="20OHM_06W" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="YR1B20RCC"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_2.21k_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_2.21K_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="ERA-6AEB2211V"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_12.1Ohm_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_12.1OHM_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="RQ73C2A12R1BTD"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_191k_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_191K_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="ERA-6AEB1913V"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_0Ohm">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_0OHM" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="RMCF0805ZT0R00"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-wago-508" urn="urn:adsk.eagle:library:196">
<description>&lt;b&gt;Wago Screw Clamps&lt;/b&gt;&lt;p&gt;
Grid 5.08 mm&lt;p&gt;
<packages>
<package name="W237-132" urn="urn:adsk.eagle:footprint:10712/1" library_version="1">
<description>&lt;b&gt;WAGO SREW CLAMP&lt;/b&gt;</description>
<wire x1="-3.5306" y1="-1.651" x2="-1.524" y2="0.3556" width="0.254" layer="51"/>
<wire x1="1.6256" y1="-1.6764" x2="3.5306" y2="0.3556" width="0.254" layer="51"/>
<wire x1="-5.08" y1="4.191" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-3.429" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.413" x2="-1.651" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.413" x2="1.651" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-2.413" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.413" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.445" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.191" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-2.413" x2="3.429" y2="-2.413" width="0.1524" layer="51"/>
<circle x="-2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="-2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<text x="-4.445" y="1.27" size="1.27" layer="51" ratio="10">1</text>
<text x="0.6858" y="1.2192" size="1.27" layer="51" ratio="10">2</text>
<text x="-3.81" y="-6.985" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.81" y="-4.318" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
<packages3d>
<package3d name="W237-132" urn="urn:adsk.eagle:package:10734/1" type="box" library_version="1">
<description>WAGO SREW CLAMP</description>
<packageinstances>
<packageinstance name="W237-132"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="KL" urn="urn:adsk.eagle:symbol:10710/1" library_version="1">
<wire x1="1.778" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<circle x="0.889" y="0" radius="0.898" width="0.254" layer="94"/>
<text x="-1.27" y="0.889" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<pin name="KL" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="KL+V" urn="urn:adsk.eagle:symbol:10711/1" library_version="1">
<text x="0" y="2.54" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="W237-02P" urn="urn:adsk.eagle:component:10750/1" prefix="X" uservalue="yes" library_version="1">
<gates>
<gate name="-1" symbol="KL" x="0" y="0" addlevel="always"/>
<gate name="-2" symbol="KL+V" x="0" y="-5.08" addlevel="always"/>
</gates>
<devices>
<device name="" package="W237-132">
<connects>
<connect gate="-1" pin="KL" pad="1"/>
<connect gate="-2" pin="KL" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:10734/1"/>
<technologies>
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_52.3Ohm_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_52.3OHM_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<technology name="">
<attribute name="MPN" value="ERA-6AEB52R3V"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_100_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_100_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="ERA-6AEB101V"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R1206_10k_0.1%">
<packages>
<package name="R1206">
<rectangle x1="-0.1799" y1="-0.5001" x2="0.2199" y2="0.5001" layer="35"/>
<wire x1="0.9925" y1="-0.8128" x2="-0.9252" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9925" y1="0.8128" x2="-0.9252" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.433" y1="0.983" x2="2.513" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.513" y1="0.983" x2="2.513" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.513" y1="-0.983" x2="-2.433" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.433" y1="-0.983" x2="-2.433" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.462" y="0" dx="1.6" dy="1.803" layer="1" roundness="10"/>
<smd name="1" x="-1.382" y="0" dx="1.6" dy="1.803" layer="1" roundness="10"/>
<text x="-1.23" y="1.27" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-1.23" y="-2.54" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.6491" y1="-0.8763" x2="-0.9125" y2="0.8763" layer="51"/>
<rectangle x1="0.9925" y1="-0.8763" x2="1.7291" y2="0.8763" layer="51"/>
<rectangle x1="-0.26" y1="-0.7" x2="0.34" y2="0.7" layer="35"/>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R1206_10K_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<device name="" package="R1206">
<connects>
</connects>
<technologies>
<attribute name="MPN" value="CRT1206-BY-1002ELF"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R1206_2M_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R1206_2M_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="RG3216P-2004-B-T1"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="RFDuino">
<packages>
<package name="RFDUINO">
<wire x1="9.144" y1="-13.208" x2="9.398" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-13.208" x2="9.398" y2="-13.462" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-13.462" x2="10.414" y2="-13.462" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-13.462" x2="10.414" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-13.208" x2="10.668" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-13.208" x2="10.668" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-12.7" x2="10.414" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-12.7" x2="10.414" y2="-12.446" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-12.446" x2="9.398" y2="-12.446" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-12.446" x2="9.398" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-12.7" x2="9.144" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-12.7" x2="9.144" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-10.668" x2="9.398" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-10.668" x2="9.398" y2="-10.922" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-10.922" x2="10.414" y2="-10.922" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-10.922" x2="10.414" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-10.668" x2="10.668" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-10.668" x2="10.668" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-10.16" x2="10.414" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-10.16" x2="10.414" y2="-9.906" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-9.906" x2="9.398" y2="-9.906" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-9.906" x2="9.398" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-10.16" x2="9.144" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-10.16" x2="9.144" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-8.128" x2="9.398" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-8.128" x2="9.398" y2="-8.382" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-8.382" x2="10.414" y2="-8.382" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-8.382" x2="10.414" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-8.128" x2="10.668" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-8.128" x2="10.668" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-7.62" x2="10.414" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-7.62" x2="10.414" y2="-7.366" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-7.366" x2="9.398" y2="-7.366" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-7.366" x2="9.398" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-7.62" x2="9.144" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-7.62" x2="9.144" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-5.588" x2="9.398" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-5.588" x2="9.398" y2="-5.842" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-5.842" x2="10.414" y2="-5.842" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-5.842" x2="10.414" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-5.588" x2="10.668" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-5.588" x2="10.668" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-5.08" x2="10.414" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-5.08" x2="10.414" y2="-4.826" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-4.826" x2="9.398" y2="-4.826" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-4.826" x2="9.398" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-5.08" x2="9.144" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-5.08" x2="9.144" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-3.048" x2="9.398" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-3.048" x2="9.398" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-3.302" x2="10.414" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-3.302" x2="10.414" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-3.048" x2="10.668" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-3.048" x2="10.668" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="10.668" y1="-2.54" x2="10.414" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-2.54" x2="10.414" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-2.286" x2="9.398" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-2.286" x2="9.398" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-2.54" x2="9.144" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-2.54" x2="9.144" y2="-3.048" width="0.1524" layer="51"/>
<pad name="1" x="9.906" y="-12.954" drill="1.02" shape="long" rot="R180"/>
<pad name="2" x="9.906" y="-10.414" drill="1.02" shape="long" rot="R180"/>
<pad name="3" x="9.906" y="-7.874" drill="1.02" shape="long" rot="R180"/>
<pad name="4" x="9.906" y="-5.334" drill="1.02" shape="long" rot="R180"/>
<pad name="5" x="9.906" y="-2.794" drill="1.02" shape="long" rot="R180"/>
<rectangle x1="9.271" y1="-13.208" x2="9.525" y2="-12.7" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-13.208" x2="10.541" y2="-12.7" layer="51" rot="R90"/>
<rectangle x1="9.271" y1="-10.668" x2="9.525" y2="-10.16" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-10.668" x2="10.541" y2="-10.16" layer="51" rot="R90"/>
<rectangle x1="9.271" y1="-8.128" x2="9.525" y2="-7.62" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-8.128" x2="10.541" y2="-7.62" layer="51" rot="R90"/>
<rectangle x1="9.271" y1="-5.588" x2="9.525" y2="-5.08" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-5.588" x2="10.541" y2="-5.08" layer="51" rot="R90"/>
<rectangle x1="9.271" y1="-3.048" x2="9.525" y2="-2.54" layer="51" rot="R90"/>
<rectangle x1="10.287" y1="-3.048" x2="10.541" y2="-2.54" layer="51" rot="R90"/>
<wire x1="-9.144" y1="2.54" x2="-9.398" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="2.54" x2="-9.398" y2="2.794" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="2.794" x2="-10.414" y2="2.794" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="2.794" x2="-10.414" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="2.54" x2="-10.668" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="2.54" x2="-10.668" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="2.032" x2="-10.414" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="2.032" x2="-10.414" y2="1.778" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="1.778" x2="-9.398" y2="1.778" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="1.778" x2="-9.398" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="2.032" x2="-9.144" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="2.032" x2="-9.144" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="0" x2="-9.398" y2="0" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="0" x2="-9.398" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="0.254" x2="-10.414" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0.254" x2="-10.414" y2="0" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0" x2="-10.668" y2="0" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="0" x2="-10.668" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-0.508" x2="-10.414" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-0.508" x2="-10.414" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-0.762" x2="-9.398" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-0.762" x2="-9.398" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-0.508" x2="-9.144" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-0.508" x2="-9.144" y2="0" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-2.54" x2="-9.398" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-2.54" x2="-9.398" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-2.286" x2="-10.414" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-2.286" x2="-10.414" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-2.54" x2="-10.668" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-2.54" x2="-10.668" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-3.048" x2="-10.414" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-3.048" x2="-10.414" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-3.302" x2="-9.398" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-3.302" x2="-9.398" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-3.048" x2="-9.144" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-3.048" x2="-9.144" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-5.08" x2="-9.398" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-5.08" x2="-9.398" y2="-4.826" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-4.826" x2="-10.414" y2="-4.826" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-4.826" x2="-10.414" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.08" x2="-10.668" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-5.08" x2="-10.668" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-5.588" x2="-10.414" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.588" x2="-10.414" y2="-5.842" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.842" x2="-9.398" y2="-5.842" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-5.842" x2="-9.398" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-5.588" x2="-9.144" y2="-5.588" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-5.588" x2="-9.144" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-7.62" x2="-9.398" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-7.62" x2="-9.398" y2="-7.366" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-7.366" x2="-10.414" y2="-7.366" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-7.366" x2="-10.414" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-7.62" x2="-10.668" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-7.62" x2="-10.668" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-8.128" x2="-10.414" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-8.128" x2="-10.414" y2="-8.382" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-8.382" x2="-9.398" y2="-8.382" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-8.382" x2="-9.398" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-8.128" x2="-9.144" y2="-8.128" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-8.128" x2="-9.144" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-10.16" x2="-9.398" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-10.16" x2="-9.398" y2="-9.906" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-9.906" x2="-10.414" y2="-9.906" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-9.906" x2="-10.414" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-10.16" x2="-10.668" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-10.16" x2="-10.668" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-10.668" x2="-10.414" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-10.668" x2="-10.414" y2="-10.922" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-10.922" x2="-9.398" y2="-10.922" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-10.922" x2="-9.398" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-10.668" x2="-9.144" y2="-10.668" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-10.668" x2="-9.144" y2="-10.16" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-12.7" x2="-9.398" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-12.7" x2="-9.398" y2="-12.446" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-12.446" x2="-10.414" y2="-12.446" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-12.446" x2="-10.414" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-12.7" x2="-10.668" y2="-12.7" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-12.7" x2="-10.668" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="-10.668" y1="-13.208" x2="-10.414" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-13.208" x2="-10.414" y2="-13.462" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-13.462" x2="-9.398" y2="-13.462" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-13.462" x2="-9.398" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-13.208" x2="-9.144" y2="-13.208" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-13.208" x2="-9.144" y2="-12.7" width="0.1524" layer="51"/>
<pad name="6" x="-9.906" y="2.286" drill="1.02" shape="long"/>
<pad name="7" x="-9.906" y="-0.254" drill="1.02" shape="long"/>
<pad name="8" x="-9.906" y="-2.794" drill="1.02" shape="long"/>
<pad name="9" x="-9.906" y="-5.334" drill="1.02" shape="long"/>
<pad name="10" x="-9.906" y="-7.874" drill="1.02" shape="long"/>
<pad name="11" x="-9.906" y="-10.414" drill="1.02" shape="long"/>
<pad name="12" x="-9.906" y="-12.954" drill="1.02" shape="long"/>
<text x="2.032" y="12.827" size="1.27" layer="25" font="vector" ratio="10" rot="R180">&gt;NAME</text>
<text x="3.048" y="-12.319" size="1.27" layer="27" font="vector" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="-9.525" y1="2.032" x2="-9.271" y2="2.54" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="2.032" x2="-10.287" y2="2.54" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-0.508" x2="-9.271" y2="0" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-0.508" x2="-10.287" y2="0" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-3.048" x2="-9.271" y2="-2.54" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-3.048" x2="-10.287" y2="-2.54" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-5.588" x2="-9.271" y2="-5.08" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-5.588" x2="-10.287" y2="-5.08" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-8.128" x2="-9.271" y2="-7.62" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-8.128" x2="-10.287" y2="-7.62" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-10.668" x2="-9.271" y2="-10.16" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-10.668" x2="-10.287" y2="-10.16" layer="51" rot="R270"/>
<rectangle x1="-9.525" y1="-13.208" x2="-9.271" y2="-12.7" layer="51" rot="R270"/>
<rectangle x1="-10.541" y1="-13.208" x2="-10.287" y2="-12.7" layer="51" rot="R270"/>
<wire x1="11.93" y1="14.478" x2="-11.93" y2="14.478" width="0.127" layer="21"/>
<wire x1="-11.93" y1="14.478" x2="-11.93" y2="-14.478" width="0.127" layer="21"/>
<wire x1="-11.93" y1="-14.478" x2="11.93" y2="-14.478" width="0.127" layer="21"/>
<wire x1="11.93" y1="-14.478" x2="11.93" y2="14.478" width="0.127" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="RFDUINO">
<pin name="GPIO2" x="-20.32" y="-15.24" length="middle"/>
<pin name="GPIO3" x="-20.32" y="-10.16" length="middle"/>
<pin name="GPIO4" x="-20.32" y="-5.08" length="middle"/>
<pin name="GPIO5" x="-20.32" y="0" length="middle"/>
<pin name="GPIO6" x="-20.32" y="5.08" length="middle"/>
<pin name="GND" x="20.32" y="15.24" length="middle" rot="R180"/>
<pin name="P$7" x="20.32" y="10.16" length="middle" rot="R180"/>
<pin name="+3V" x="20.32" y="5.08" length="middle" rot="R180"/>
<pin name="RESET" x="20.32" y="0" length="middle" rot="R180"/>
<pin name="FACTORY" x="20.32" y="-5.08" length="middle" rot="R180"/>
<pin name="GPIO0" x="20.32" y="-10.16" length="middle" rot="R180"/>
<pin name="GPIO1" x="20.32" y="-15.24" length="middle" rot="R180"/>
<wire x1="15.24" y1="-17.78" x2="15.24" y2="22.86" width="0.254" layer="94"/>
<wire x1="15.24" y1="22.86" x2="-15.24" y2="22.86" width="0.254" layer="94"/>
<wire x1="-15.24" y1="22.86" x2="-15.24" y2="-17.78" width="0.254" layer="94"/>
<wire x1="-15.24" y1="-17.78" x2="15.24" y2="-17.78" width="0.254" layer="94"/>
<text x="-5.08" y="25.4" size="1.27" layer="95">&gt;NAME</text>
<text x="-2.54" y="-20.32" size="1.27" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="RFDUINO" prefix="IC">
<gates>
<gate name="G$1" symbol="RFDUINO" x="0" y="-2.54"/>
</gates>
<devices>
<device name="" package="RFDUINO">
<connects>
<connect gate="G$1" pin="+3V" pad="8"/>
<connect gate="G$1" pin="FACTORY" pad="10"/>
<connect gate="G$1" pin="GND" pad="6"/>
<connect gate="G$1" pin="GPIO0" pad="11"/>
<connect gate="G$1" pin="GPIO1" pad="12"/>
<connect gate="G$1" pin="GPIO2" pad="1"/>
<connect gate="G$1" pin="GPIO3" pad="2"/>
<connect gate="G$1" pin="GPIO4" pad="3"/>
<connect gate="G$1" pin="GPIO5" pad="4"/>
<connect gate="G$1" pin="GPIO6" pad="5"/>
<connect gate="G$1" pin="P$7" pad="7"/>
<connect gate="G$1" pin="RESET" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="IC11" library="MCP3204" deviceset="MCP3204" device="TSSOP-14" package3d_urn="urn:adsk.eagle:package:20830/2"/>
<part name="IC4" library="MCP4922" deviceset="MCP4922T" device="TSSOP-14" package3d_urn="urn:adsk.eagle:package:20830/2"/>
<part name="IC1" library="LM341T-5.0:NOPB" deviceset="LM341T-5.0/NOPB" device="TO-220" package3d_urn="urn:adsk.eagle:package:8089447/1"/>
<part name="IC2" library="MCP1700-3302E:TO" deviceset="MCP1700-3302E/TO" device="TO-220" package3d_urn="urn:adsk.eagle:package:8089447/1"/>
<part name="IC6" library="NJM14558D" deviceset="NJM14558D" device="DIL-8" package3d_urn="urn:adsk.eagle:package:20796/2"/>
<part name="IC9" library="NJM14558D" deviceset="NJM14558D" device="DIL-8" package3d_urn="urn:adsk.eagle:package:20796/2"/>
<part name="IC5" library="MAX4080F" deviceset="MAX4080FASA+" device="8-SOIC" package3d_urn="urn:adsk.eagle:package:16057/2"/>
<part name="IC10" library="MAX4238ASA+" deviceset="MAX4238ASA+" device=""/>
<part name="IC7" library="LT3083" deviceset="LT3083ET#PBF" device="TO220-5" package3d_urn="urn:adsk.eagle:package:16056/1"/>
<part name="D3" library="SB540E-G" deviceset="SB540E-G" device="DO-201AD" package3d_urn="urn:adsk.eagle:package:43365/2"/>
<part name="D1" library="SB540E-G" deviceset="SB540E-G" device="DO-201AD" package3d_urn="urn:adsk.eagle:package:43365/2"/>
<part name="R12" library="R0805_330" deviceset="R0805_330" device=""/>
<part name="GND16" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C11" library="C0805_1uF:50V" deviceset="C0805_1UF/50V" device=""/>
<part name="GND19" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C10" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="GND15" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="IC3" library="MAX6126AASA21+" deviceset="MAX6126AASA21+" device=""/>
<part name="C6" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="GND7" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C9" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="GND14" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND5" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C4" library="C0805_1uF:50V" deviceset="C0805_1UF/50V" device=""/>
<part name="GND6" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C5" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="GND8" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND9" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C7" library="C0805_1uF:50V" deviceset="C0805_1UF/50V" device=""/>
<part name="C8" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="GND11" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND13" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND17" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND18" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND2" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C3" library="C0805_1uF:50V" deviceset="C0805_1UF/50V" device=""/>
<part name="C2" library="C0805_1uF:50V" deviceset="C0805_1UF/50V" device=""/>
<part name="C1" library="C0805_1uF:50V" deviceset="C0805_1UF/50V" device=""/>
<part name="GND1" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND3" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND4" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R11" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R10" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R9" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R8" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R7" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R6" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R5" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R4" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R3" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R2" library="2Ohm_06W" deviceset="2OHM_06W" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="C12" library="C0805_10uF:35V" deviceset="C0805_10UF/35V" device=""/>
<part name="C13" library="C0805_10uF:35V" deviceset="C0805_10UF/35V" device=""/>
<part name="C15" library="C0805_10uF:35V" deviceset="C0805_10UF/35V" device=""/>
<part name="GND22" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND23" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND24" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="IC8" library="LM334Z:LFT1" deviceset="LM334Z/LFT1" device="TO-92" package3d_urn="urn:adsk.eagle:package:20831/2"/>
<part name="GND38" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="D2" library=" 1N457" deviceset="1N457" device="DO-35" package3d_urn="urn:adsk.eagle:package:43339/2"/>
<part name="GND21" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C14" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="GND25" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND35" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C17" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="GND36" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND37" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND39" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C18" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="R30" library="R0805_10k_0.1%" deviceset="R0805_10K_0.1%" device=""/>
<part name="GND29" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND32" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND20" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R13" library="R0805_10k_0.1%" deviceset="R0805_10K_0.1%" device=""/>
<part name="R14" library="R0805_10k_0.1%" deviceset="R0805_10K_0.1%" device=""/>
<part name="R25" library="R0805_10k_0.1%" deviceset="R0805_10K_0.1%" device=""/>
<part name="R26" library="R0805_10k_0.1%" deviceset="R0805_10K_0.1%" device=""/>
<part name="R27" library="R0805_2.21k_0.1%" deviceset="R0805_2.21K_0.1%" device=""/>
<part name="R28" library="R0805_12.1Ohm_0.1%" deviceset="R0805_12.1OHM_0.1%" device=""/>
<part name="GND31" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C16" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="GND30" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R21" library="R0805_10k" deviceset="R0805_10K" device=""/>
<part name="R20" library="R0805_10k" deviceset="R0805_10K" device=""/>
<part name="R17" library="R0805_1k" deviceset="R0805_1K" device=""/>
<part name="R19" library="R0805_100" deviceset="R0805_100" device=""/>
<part name="Q1" library="2N3904-AP" deviceset="2N3904-AP" device="TO-92" package3d_urn="urn:adsk.eagle:package:20831/2"/>
<part name="Q2" library="2N3904-AP" deviceset="2N3904-AP" device="TO-92" package3d_urn="urn:adsk.eagle:package:20831/2"/>
<part name="GND27" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND26" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C19" library="C0805_100nF:50V" deviceset="C0805_100NF/50V" device=""/>
<part name="R41" library="R0805_330" deviceset="R0805_330" device=""/>
<part name="C20" library="C0805_1uF:50V" deviceset="C0805_1UF/50V" device=""/>
<part name="GND40" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R40" library="R1206_10k_0.1%" deviceset="R1206_10K_0.1%" device=""/>
<part name="R36" library="R0805_100_0.1%" deviceset="R0805_100_0.1%" device=""/>
<part name="R33" library="R0805_100_0.1%" deviceset="R0805_100_0.1%" device=""/>
<part name="R39" library="R1206_2M_0.1%" deviceset="R1206_2M_0.1%" device=""/>
<part name="R34" library="20Ohm_06W_0.1%" deviceset="20OHM_06W_0.1%" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R35" library="20Ohm_06W_0.1%" deviceset="20OHM_06W_0.1%" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R37" library="20Ohm_06W_0.1%" deviceset="20OHM_06W_0.1%" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="R38" library="20Ohm_06W_0.1%" deviceset="20OHM_06W_0.1%" device="MBB/SMA0207" package3d_urn="urn:adsk.eagle:package:8118469/1"/>
<part name="Q4" library="IRLU8721-701PBF" deviceset="IRLU8721-701PBF" device="TO-252" package3d_urn="urn:adsk.eagle:package:28537/2"/>
<part name="R31" library="R0805_10k" deviceset="R0805_10K" device=""/>
<part name="Q3" library="2N3904-AP" deviceset="2N3904-AP" device="TO-92" package3d_urn="urn:adsk.eagle:package:20831/2"/>
<part name="GND34" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R32" library="R0805_10k" deviceset="R0805_10K" device=""/>
<part name="R23" library="R0805_133Ohm_0.1%" deviceset="R0805_133OHM_0.1%" device=""/>
<part name="R22" library="R0805_1k33_0.1%" deviceset="R0805_1K33_0.1%" device=""/>
<part name="GND12" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R16" library="R0805_2.21k_0.1%" deviceset="R0805_2.21K_0.1%" device=""/>
<part name="R15" library="R0805_12.1Ohm_0.1%" deviceset="R0805_12.1OHM_0.1%" device=""/>
<part name="R1" library="R0805_191k_0.1%" deviceset="R0805_191K_0.1%" device=""/>
<part name="R29" library="R0805_52.3Ohm_0.1%" deviceset="R0805_52.3OHM_0.1%" device=""/>
<part name="R18" library="R0805_0Ohm" deviceset="R0805_0OHM" device=""/>
<part name="R24" library="R0805_0Ohm" deviceset="R0805_0OHM" device=""/>
<part name="X1" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" deviceset="W237-02P" device="" package3d_urn="urn:adsk.eagle:package:10734/1"/>
<part name="GND10" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND28" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="IC12" library="RFDuino" deviceset="RFDUINO" device=""/>
</parts>
<sheets>
<sheet>
<plain>
<text x="251.46" y="-50.8" size="1.778" layer="91">1.049mA</text>
<text x="274.32" y="-43.18" size="1.778" layer="97">NC</text>
<text x="383.54" y="-193.04" size="1.778" layer="91">MCP3302 16BIT</text>
<text x="459.74" y="-30.48" size="1.778" layer="97">OUT +</text>
<text x="459.74" y="-50.8" size="1.778" layer="97">OUT -</text>
<text x="-287.02" y="-335.28" size="50.8" layer="94" font="vector" ratio="10">www.eevblog.com</text>
</plain>
<instances>
<instance part="IC11" gate="G$1" x="396.24" y="-167.64" smashed="yes">
<attribute name="NAME" x="381" y="-147.32" size="1.27" layer="95"/>
<attribute name="VALUE" x="383.54" y="-187.96" size="1.27" layer="96"/>
</instance>
<instance part="IC4" gate="G$1" x="53.34" y="-175.26" smashed="yes">
<attribute name="NAME" x="38.1" y="-154.94" size="1.778" layer="95"/>
<attribute name="VALUE" x="38.1" y="-195.58" size="1.778" layer="96"/>
</instance>
<instance part="IC1" gate="G$1" x="-157.48" y="-83.82" smashed="yes">
<attribute name="NAME" x="-167.64" y="-73.66" size="1.778" layer="95"/>
<attribute name="VALUE" x="-172.72" y="-96.52" size="1.778" layer="96"/>
</instance>
<instance part="IC2" gate="G$1" x="-96.52" y="-83.82" smashed="yes">
<attribute name="NAME" x="-106.68" y="-73.66" size="1.778" layer="95"/>
<attribute name="VALUE" x="-111.76" y="-96.52" size="1.778" layer="96"/>
</instance>
<instance part="IC6" gate="G$1" x="170.18" y="-175.26" smashed="yes">
<attribute name="NAME" x="157.48" y="-162.56" size="1.778" layer="95"/>
<attribute name="VALUE" x="157.48" y="-190.5" size="1.778" layer="96"/>
</instance>
<instance part="IC9" gate="G$1" x="281.94" y="-175.26" smashed="yes">
<attribute name="NAME" x="269.24" y="-162.56" size="1.778" layer="95"/>
<attribute name="VALUE" x="269.24" y="-190.5" size="1.778" layer="96"/>
</instance>
<instance part="IC5" gate="G$1" x="78.74" y="-83.82" smashed="yes">
<attribute name="NAME" x="63.5" y="-71.12" size="1.778" layer="95"/>
<attribute name="VALUE" x="63.5" y="-99.06" size="1.778" layer="96"/>
</instance>
<instance part="IC10" gate="G$1" x="396.24" y="-91.44" smashed="yes">
<attribute name="NAME" x="381" y="-78.74" size="1.778" layer="95"/>
<attribute name="VALUE" x="381" y="-106.68" size="1.778" layer="96"/>
</instance>
<instance part="IC7" gate="G$1" x="182.88" y="-30.48" smashed="yes">
<attribute name="NAME" x="170.18" y="-20.32" size="1.778" layer="95"/>
<attribute name="VALUE" x="167.64" y="-43.18" size="1.778" layer="96"/>
</instance>
<instance part="D3" gate="G$1" x="454.66" y="-22.86" smashed="yes" rot="R270">
<attribute name="NAME" x="456.565" y="-20.574" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="451.231" y="-20.574" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="D1" gate="G$1" x="182.88" y="-12.7" smashed="yes" rot="R180">
<attribute name="NAME" x="185.166" y="-14.605" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="185.166" y="-9.271" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R12" gate="G$1" x="106.68" y="-91.44" smashed="yes">
<attribute name="NAME" x="102.87" y="-89.9414" size="1.778" layer="95"/>
<attribute name="VALUE" x="102.87" y="-94.742" size="1.778" layer="96"/>
</instance>
<instance part="GND16" gate="1" x="55.88" y="-106.68" smashed="yes">
<attribute name="VALUE" x="53.34" y="-109.22" size="1.778" layer="96"/>
</instance>
<instance part="C11" gate="G$1" x="114.3" y="-96.52" smashed="yes">
<attribute name="NAME" x="115.824" y="-96.139" size="1.778" layer="95"/>
<attribute name="VALUE" x="115.824" y="-101.219" size="1.778" layer="96"/>
</instance>
<instance part="GND19" gate="1" x="114.3" y="-106.68" smashed="yes">
<attribute name="VALUE" x="111.76" y="-109.22" size="1.778" layer="96"/>
</instance>
<instance part="C10" gate="G$1" x="38.1" y="-83.82" smashed="yes">
<attribute name="NAME" x="39.624" y="-83.439" size="1.778" layer="95"/>
<attribute name="VALUE" x="39.624" y="-88.519" size="1.778" layer="96"/>
</instance>
<instance part="GND15" gate="1" x="38.1" y="-93.98" smashed="yes">
<attribute name="VALUE" x="35.56" y="-96.52" size="1.778" layer="96"/>
</instance>
<instance part="IC3" gate="G$1" x="-7.62" y="-83.82" smashed="yes">
<attribute name="NAME" x="-22.86" y="-71.12" size="1.778" layer="95"/>
<attribute name="VALUE" x="-22.86" y="-99.06" size="1.778" layer="96"/>
</instance>
<instance part="C6" gate="G$1" x="-40.64" y="-76.2" smashed="yes" rot="R90">
<attribute name="NAME" x="-41.021" y="-74.676" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="-35.941" y="-74.676" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND7" gate="1" x="-48.26" y="-76.2" smashed="yes" rot="R270">
<attribute name="VALUE" x="-50.8" y="-73.66" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="C9" gate="G$1" x="27.94" y="-76.2" smashed="yes">
<attribute name="NAME" x="29.464" y="-75.819" size="1.778" layer="95"/>
<attribute name="VALUE" x="29.464" y="-80.899" size="1.778" layer="96"/>
</instance>
<instance part="GND14" gate="1" x="27.94" y="-68.58" smashed="yes" rot="R180">
<attribute name="VALUE" x="30.48" y="-66.04" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND5" gate="1" x="-96.52" y="-101.6" smashed="yes">
<attribute name="VALUE" x="-99.06" y="-104.14" size="1.778" layer="96"/>
</instance>
<instance part="C4" gate="G$1" x="-73.66" y="-83.82" smashed="yes">
<attribute name="NAME" x="-72.136" y="-83.439" size="1.778" layer="95"/>
<attribute name="VALUE" x="-72.136" y="-88.519" size="1.778" layer="96"/>
</instance>
<instance part="GND6" gate="1" x="-73.66" y="-93.98" smashed="yes">
<attribute name="VALUE" x="-76.2" y="-96.52" size="1.778" layer="96"/>
</instance>
<instance part="C5" gate="G$1" x="-45.72" y="-86.36" smashed="yes" rot="R180">
<attribute name="NAME" x="-47.244" y="-86.741" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-47.244" y="-81.661" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND8" gate="1" x="-45.72" y="-93.98" smashed="yes">
<attribute name="VALUE" x="-48.26" y="-96.52" size="1.778" layer="96"/>
</instance>
<instance part="GND9" gate="1" x="-38.1" y="-86.36" smashed="yes" rot="R270">
<attribute name="VALUE" x="-40.64" y="-83.82" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="C7" gate="G$1" x="-20.32" y="-162.56" smashed="yes">
<attribute name="NAME" x="-18.796" y="-162.179" size="1.778" layer="95"/>
<attribute name="VALUE" x="-18.796" y="-167.259" size="1.778" layer="96"/>
</instance>
<instance part="C8" gate="G$1" x="-7.62" y="-162.56" smashed="yes">
<attribute name="NAME" x="-6.096" y="-162.179" size="1.778" layer="95"/>
<attribute name="VALUE" x="-6.096" y="-167.259" size="1.778" layer="96"/>
</instance>
<instance part="GND11" gate="1" x="-20.32" y="-172.72" smashed="yes">
<attribute name="VALUE" x="-22.86" y="-175.26" size="1.778" layer="96"/>
</instance>
<instance part="GND13" gate="1" x="-7.62" y="-172.72" smashed="yes">
<attribute name="VALUE" x="-10.16" y="-175.26" size="1.778" layer="96"/>
</instance>
<instance part="GND17" gate="1" x="83.82" y="-170.18" smashed="yes" rot="R90">
<attribute name="VALUE" x="86.36" y="-172.72" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND18" gate="1" x="83.82" y="-190.5" smashed="yes" rot="R90">
<attribute name="VALUE" x="86.36" y="-193.04" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND2" gate="1" x="-157.48" y="-101.6" smashed="yes">
<attribute name="VALUE" x="-160.02" y="-104.14" size="1.778" layer="96"/>
</instance>
<instance part="C3" gate="G$1" x="-119.38" y="-83.82" smashed="yes">
<attribute name="NAME" x="-117.856" y="-83.439" size="1.778" layer="95"/>
<attribute name="VALUE" x="-117.856" y="-88.519" size="1.778" layer="96"/>
</instance>
<instance part="C2" gate="G$1" x="-134.62" y="-83.82" smashed="yes">
<attribute name="NAME" x="-133.096" y="-83.439" size="1.778" layer="95"/>
<attribute name="VALUE" x="-133.096" y="-88.519" size="1.778" layer="96"/>
</instance>
<instance part="C1" gate="G$1" x="-180.34" y="-83.82" smashed="yes">
<attribute name="NAME" x="-178.816" y="-83.439" size="1.778" layer="95"/>
<attribute name="VALUE" x="-178.816" y="-88.519" size="1.778" layer="96"/>
</instance>
<instance part="GND1" gate="1" x="-180.34" y="-101.6" smashed="yes">
<attribute name="VALUE" x="-182.88" y="-104.14" size="1.778" layer="96"/>
</instance>
<instance part="GND3" gate="1" x="-134.62" y="-101.6" smashed="yes">
<attribute name="VALUE" x="-137.16" y="-104.14" size="1.778" layer="96"/>
</instance>
<instance part="GND4" gate="1" x="-119.38" y="-101.6" smashed="yes">
<attribute name="VALUE" x="-121.92" y="-104.14" size="1.778" layer="96"/>
</instance>
<instance part="R11" gate="G$1" x="81.28" y="-55.88" smashed="yes">
<attribute name="NAME" x="77.47" y="-54.3814" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-59.182" size="1.778" layer="96"/>
</instance>
<instance part="R10" gate="G$1" x="81.28" y="-50.8" smashed="yes">
<attribute name="NAME" x="77.47" y="-49.3014" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-54.102" size="1.778" layer="96"/>
</instance>
<instance part="R9" gate="G$1" x="81.28" y="-45.72" smashed="yes">
<attribute name="NAME" x="77.47" y="-44.2214" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-49.022" size="1.778" layer="96"/>
</instance>
<instance part="R8" gate="G$1" x="81.28" y="-40.64" smashed="yes">
<attribute name="NAME" x="77.47" y="-39.1414" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-43.942" size="1.778" layer="96"/>
</instance>
<instance part="R7" gate="G$1" x="81.28" y="-35.56" smashed="yes">
<attribute name="NAME" x="77.47" y="-34.0614" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-38.862" size="1.778" layer="96"/>
</instance>
<instance part="R6" gate="G$1" x="81.28" y="-30.48" smashed="yes">
<attribute name="NAME" x="77.47" y="-28.9814" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-33.782" size="1.778" layer="96"/>
</instance>
<instance part="R5" gate="G$1" x="81.28" y="-25.4" smashed="yes">
<attribute name="NAME" x="77.47" y="-23.9014" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-28.702" size="1.778" layer="96"/>
</instance>
<instance part="R4" gate="G$1" x="81.28" y="-20.32" smashed="yes">
<attribute name="NAME" x="77.47" y="-18.8214" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-23.622" size="1.778" layer="96"/>
</instance>
<instance part="R3" gate="G$1" x="81.28" y="-15.24" smashed="yes">
<attribute name="NAME" x="77.47" y="-13.7414" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-18.542" size="1.778" layer="96"/>
</instance>
<instance part="R2" gate="G$1" x="81.28" y="-10.16" smashed="yes">
<attribute name="NAME" x="77.47" y="-8.6614" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-13.462" size="1.778" layer="96"/>
</instance>
<instance part="C12" gate="G$1" x="152.4" y="-35.56" smashed="yes">
<attribute name="NAME" x="153.924" y="-35.179" size="1.778" layer="95"/>
<attribute name="VALUE" x="153.924" y="-40.259" size="1.778" layer="96"/>
</instance>
<instance part="C13" gate="G$1" x="198.12" y="-55.88" smashed="yes">
<attribute name="NAME" x="199.644" y="-55.499" size="1.778" layer="95"/>
<attribute name="VALUE" x="199.644" y="-60.579" size="1.778" layer="96"/>
</instance>
<instance part="C15" gate="G$1" x="208.28" y="-38.1" smashed="yes">
<attribute name="NAME" x="209.804" y="-37.719" size="1.778" layer="95"/>
<attribute name="VALUE" x="209.804" y="-42.799" size="1.778" layer="96"/>
</instance>
<instance part="GND22" gate="1" x="152.4" y="-45.72" smashed="yes">
<attribute name="VALUE" x="149.86" y="-48.26" size="1.778" layer="96"/>
</instance>
<instance part="GND23" gate="1" x="198.12" y="-83.82" smashed="yes">
<attribute name="VALUE" x="195.58" y="-86.36" size="1.778" layer="96"/>
</instance>
<instance part="GND24" gate="1" x="208.28" y="-48.26" smashed="yes">
<attribute name="VALUE" x="205.74" y="-50.8" size="1.778" layer="96"/>
</instance>
<instance part="IC8" gate="G$1" x="243.84" y="-45.72" smashed="yes" rot="R270">
<attribute name="NAME" x="251.46" y="-35.56" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="228.6" y="-30.48" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND38" gate="1" x="454.66" y="-15.24" smashed="yes" rot="R180">
<attribute name="VALUE" x="457.2" y="-12.7" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D2" gate="G$1" x="226.06" y="-73.66" smashed="yes" rot="R270">
<attribute name="NAME" x="226.5426" y="-76.2" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="223.7486" y="-76.2" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND21" gate="1" x="147.32" y="-187.96" smashed="yes">
<attribute name="VALUE" x="144.78" y="-190.5" size="1.778" layer="96"/>
</instance>
<instance part="C14" gate="G$1" x="205.74" y="-167.64" smashed="yes" rot="R90">
<attribute name="NAME" x="205.359" y="-166.116" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="210.439" y="-166.116" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND25" gate="1" x="215.9" y="-167.64" smashed="yes" rot="R90">
<attribute name="VALUE" x="218.44" y="-170.18" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND35" gate="1" x="322.58" y="-167.64" smashed="yes" rot="R90">
<attribute name="VALUE" x="325.12" y="-170.18" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C17" gate="G$1" x="312.42" y="-167.64" smashed="yes" rot="R90">
<attribute name="NAME" x="312.039" y="-166.116" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="317.119" y="-166.116" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND36" gate="1" x="373.38" y="-187.96" smashed="yes">
<attribute name="VALUE" x="370.84" y="-190.5" size="1.778" layer="96"/>
</instance>
<instance part="GND37" gate="1" x="424.18" y="-162.56" smashed="yes" rot="R90">
<attribute name="VALUE" x="426.72" y="-165.1" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND39" gate="1" x="462.28" y="-152.4" smashed="yes" rot="R90">
<attribute name="VALUE" x="464.82" y="-154.94" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C18" gate="G$1" x="449.58" y="-152.4" smashed="yes" rot="R90">
<attribute name="NAME" x="449.199" y="-150.876" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="454.279" y="-150.876" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R30" gate="G$1" x="307.34" y="-190.5" smashed="yes" rot="R90">
<attribute name="NAME" x="305.8414" y="-194.31" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="310.642" y="-194.31" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND29" gate="1" x="256.54" y="-187.96" smashed="yes">
<attribute name="VALUE" x="254" y="-190.5" size="1.778" layer="96"/>
</instance>
<instance part="GND32" gate="1" x="284.48" y="-198.12" smashed="yes" rot="R270">
<attribute name="VALUE" x="281.94" y="-195.58" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND20" gate="1" x="129.54" y="-203.2" smashed="yes">
<attribute name="VALUE" x="127" y="-205.74" size="1.778" layer="96"/>
</instance>
<instance part="R13" gate="G$1" x="129.54" y="-139.7" smashed="yes" rot="R90">
<attribute name="NAME" x="128.0414" y="-143.51" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="132.842" y="-143.51" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R14" gate="G$1" x="129.54" y="-152.4" smashed="yes" rot="R270">
<attribute name="NAME" x="131.0386" y="-148.59" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="126.238" y="-148.59" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R25" gate="G$1" x="284.48" y="-45.72" smashed="yes" rot="R90">
<attribute name="NAME" x="282.9814" y="-49.53" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="287.782" y="-49.53" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R26" gate="G$1" x="284.48" y="-58.42" smashed="yes" rot="R90">
<attribute name="NAME" x="260.1214" y="-133.35" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="267.462" y="-138.43" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R27" gate="G$1" x="289.56" y="-137.16" smashed="yes" rot="R180">
<attribute name="NAME" x="293.37" y="-138.6586" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="293.37" y="-133.858" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R28" gate="G$1" x="297.18" y="-142.24" smashed="yes" rot="R90">
<attribute name="NAME" x="295.6814" y="-146.05" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="300.482" y="-146.05" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND31" gate="1" x="297.18" y="-152.4" smashed="yes">
<attribute name="VALUE" x="294.64" y="-154.94" size="1.778" layer="96"/>
</instance>
<instance part="C16" gate="G$1" x="276.86" y="-142.24" smashed="yes" rot="R180">
<attribute name="NAME" x="275.336" y="-142.621" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="275.336" y="-137.541" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND30" gate="1" x="276.86" y="-152.4" smashed="yes">
<attribute name="VALUE" x="274.32" y="-154.94" size="1.778" layer="96"/>
</instance>
<instance part="R21" gate="G$1" x="218.44" y="-203.2" smashed="yes" rot="R180">
<attribute name="NAME" x="222.25" y="-204.6986" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="222.25" y="-199.898" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R20" gate="G$1" x="218.44" y="-172.72" smashed="yes" rot="R180">
<attribute name="NAME" x="222.25" y="-174.2186" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="222.25" y="-169.418" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R17" gate="G$1" x="167.64" y="-154.94" smashed="yes" rot="R180">
<attribute name="NAME" x="171.45" y="-156.4386" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="171.45" y="-151.638" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R19" gate="G$1" x="182.88" y="-71.12" smashed="yes" rot="R90">
<attribute name="NAME" x="181.3814" y="-74.93" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="186.182" y="-74.93" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="Q1" gate="G$1" x="228.6" y="-172.72" smashed="yes">
<attribute name="NAME" x="218.44" y="-165.1" size="1.778" layer="95"/>
<attribute name="VALUE" x="218.44" y="-167.64" size="1.778" layer="96"/>
</instance>
<instance part="Q2" gate="G$1" x="228.6" y="-203.2" smashed="yes">
<attribute name="NAME" x="218.44" y="-195.58" size="1.778" layer="95"/>
<attribute name="VALUE" x="218.44" y="-198.12" size="1.778" layer="96"/>
</instance>
<instance part="GND27" gate="1" x="231.14" y="-213.36" smashed="yes">
<attribute name="VALUE" x="228.6" y="-215.9" size="1.778" layer="96"/>
</instance>
<instance part="GND26" gate="1" x="231.14" y="-182.88" smashed="yes">
<attribute name="VALUE" x="228.6" y="-185.42" size="1.778" layer="96"/>
</instance>
<instance part="C19" gate="G$1" x="426.72" y="-109.22" smashed="yes" rot="R90">
<attribute name="NAME" x="426.339" y="-107.696" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="431.419" y="-107.696" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R41" gate="G$1" x="472.44" y="-93.98" smashed="yes">
<attribute name="NAME" x="468.63" y="-92.4814" size="1.778" layer="95"/>
<attribute name="VALUE" x="468.63" y="-97.282" size="1.778" layer="96"/>
</instance>
<instance part="C20" gate="G$1" x="485.14" y="-99.06" smashed="yes">
<attribute name="NAME" x="486.664" y="-98.679" size="1.778" layer="95"/>
<attribute name="VALUE" x="486.664" y="-103.759" size="1.778" layer="96"/>
</instance>
<instance part="GND40" gate="1" x="485.14" y="-109.22" smashed="yes">
<attribute name="VALUE" x="482.6" y="-111.76" size="1.778" layer="96"/>
</instance>
<instance part="R40" gate="G$1" x="396.24" y="-66.04" smashed="yes">
<attribute name="NAME" x="392.43" y="-64.5414" size="1.778" layer="95"/>
<attribute name="VALUE" x="392.43" y="-69.342" size="1.778" layer="96"/>
</instance>
<instance part="R36" gate="G$1" x="350.52" y="-93.98" smashed="yes" rot="R90">
<attribute name="NAME" x="349.0214" y="-97.79" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="353.822" y="-97.79" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R33" gate="G$1" x="342.9" y="-93.98" smashed="yes" rot="R90">
<attribute name="NAME" x="341.4014" y="-97.79" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="346.202" y="-97.79" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R39" gate="G$1" x="396.24" y="-55.88" smashed="yes">
<attribute name="NAME" x="392.43" y="-54.3814" size="1.778" layer="95"/>
<attribute name="VALUE" x="392.43" y="-59.182" size="1.778" layer="96"/>
</instance>
<instance part="R34" gate="G$1" x="342.9" y="-121.92" smashed="yes" rot="R90">
<attribute name="NAME" x="341.4014" y="-125.73" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="346.202" y="-125.73" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R35" gate="G$1" x="347.98" y="-121.92" smashed="yes" rot="R90">
<attribute name="NAME" x="346.4814" y="-125.73" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="351.282" y="-125.73" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R37" gate="G$1" x="353.06" y="-121.92" smashed="yes" rot="R90">
<attribute name="NAME" x="351.5614" y="-125.73" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="356.362" y="-125.73" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R38" gate="G$1" x="358.14" y="-121.92" smashed="yes" rot="R90">
<attribute name="NAME" x="356.6414" y="-125.73" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="361.442" y="-125.73" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="Q4" gate="G$1" x="335.28" y="-119.38" smashed="yes" rot="MR180">
<attribute name="VALUE" x="321.31" y="-119.38" size="1.778" layer="96" rot="MR180"/>
<attribute name="NAME" x="321.31" y="-121.92" size="1.778" layer="95" rot="MR180"/>
</instance>
<instance part="R31" gate="G$1" x="309.88" y="-116.84" smashed="yes">
<attribute name="NAME" x="306.07" y="-115.3414" size="1.778" layer="95"/>
<attribute name="VALUE" x="306.07" y="-120.142" size="1.778" layer="96"/>
</instance>
<instance part="Q3" gate="G$1" x="325.12" y="-142.24" smashed="yes" rot="MR0">
<attribute name="NAME" x="335.28" y="-134.62" size="1.778" layer="95" rot="MR0"/>
<attribute name="VALUE" x="335.28" y="-137.16" size="1.778" layer="96" rot="MR0"/>
</instance>
<instance part="GND34" gate="1" x="322.58" y="-152.4" smashed="yes">
<attribute name="VALUE" x="320.04" y="-154.94" size="1.778" layer="96"/>
</instance>
<instance part="R32" gate="G$1" x="335.28" y="-142.24" smashed="yes">
<attribute name="NAME" x="331.47" y="-140.7414" size="1.778" layer="95"/>
<attribute name="VALUE" x="331.47" y="-145.542" size="1.778" layer="96"/>
</instance>
<instance part="R23" gate="G$1" x="226.06" y="-60.96" smashed="yes" rot="R90">
<attribute name="NAME" x="224.5614" y="-64.77" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="229.362" y="-64.77" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R22" gate="G$1" x="220.98" y="-60.96" smashed="yes" rot="R90">
<attribute name="NAME" x="219.4814" y="-64.77" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="224.282" y="-64.77" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND12" gate="1" x="-12.7" y="-353.06" smashed="yes" rot="R180">
<attribute name="VALUE" x="-10.16" y="-350.52" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R16" gate="G$1" x="129.54" y="-193.04" smashed="yes" rot="R90">
<attribute name="NAME" x="128.0414" y="-196.85" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="132.842" y="-196.85" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R15" gate="G$1" x="129.54" y="-180.34" smashed="yes" rot="R90">
<attribute name="NAME" x="128.0414" y="-184.15" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="132.842" y="-184.15" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R1" gate="G$1" x="-195.58" y="-30.48" smashed="yes">
<attribute name="NAME" x="-199.39" y="-28.9814" size="1.778" layer="95"/>
<attribute name="VALUE" x="-199.39" y="-33.782" size="1.778" layer="96"/>
</instance>
<instance part="R29" gate="G$1" x="297.18" y="-198.12" smashed="yes">
<attribute name="NAME" x="293.37" y="-196.6214" size="1.778" layer="95"/>
<attribute name="VALUE" x="293.37" y="-201.422" size="1.778" layer="96"/>
</instance>
<instance part="R18" gate="G$1" x="172.72" y="-50.8" smashed="yes">
<attribute name="NAME" x="168.91" y="-49.3014" size="1.778" layer="95"/>
<attribute name="VALUE" x="168.91" y="-54.102" size="1.778" layer="96"/>
</instance>
<instance part="R24" gate="G$1" x="269.24" y="-45.72" smashed="yes" rot="R90">
<attribute name="NAME" x="267.7414" y="-49.53" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="272.542" y="-49.53" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="X1" gate="-1" x="-12.7" y="-378.46" smashed="yes" rot="R90">
<attribute name="NAME" x="-13.589" y="-379.73" size="1.778" layer="95" rot="R270"/>
</instance>
<instance part="X1" gate="-2" x="-2.54" y="-378.46" smashed="yes" rot="R90">
<attribute name="VALUE" x="-5.08" y="-378.46" size="1.778" layer="96" rot="R90"/>
<attribute name="NAME" x="-3.429" y="-379.73" size="1.778" layer="95" rot="R270"/>
</instance>
<instance part="GND10" gate="1" x="-38.1" y="-91.44" smashed="yes" rot="R270">
<attribute name="VALUE" x="-40.64" y="-88.9" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND28" gate="1" x="304.8" y="-335.28" smashed="yes" rot="R90">
<attribute name="VALUE" x="307.34" y="-337.82" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="IC12" gate="G$1" x="274.32" y="-350.52" smashed="yes">
<attribute name="NAME" x="269.24" y="-325.12" size="1.27" layer="95"/>
<attribute name="VALUE" x="271.78" y="-370.84" size="1.27" layer="96"/>
</instance>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<pinref part="IC5" gate="G$1" pin="OUT"/>
<pinref part="R12" gate="G$1" pin="1"/>
<wire x1="99.06" y1="-91.44" x2="101.6" y2="-91.44" width="0.1524" layer="91"/>
</segment>
</net>
<net name="GND" class="0">
<segment>
<pinref part="GND16" gate="1" pin="GND"/>
<wire x1="55.88" y1="-91.44" x2="55.88" y2="-104.14" width="0.1524" layer="91"/>
<pinref part="IC5" gate="G$1" pin="GND"/>
<wire x1="58.42" y1="-91.44" x2="55.88" y2="-91.44" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND19" gate="1" pin="GND"/>
<pinref part="C11" gate="G$1" pin="2"/>
<wire x1="114.3" y1="-104.14" x2="114.3" y2="-101.6" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND15" gate="1" pin="GND"/>
<pinref part="C10" gate="G$1" pin="2"/>
<wire x1="38.1" y1="-91.44" x2="38.1" y2="-88.9" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C6" gate="G$1" pin="1"/>
<pinref part="GND7" gate="1" pin="GND"/>
<wire x1="-43.18" y1="-76.2" x2="-45.72" y2="-76.2" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C9" gate="G$1" pin="1"/>
<pinref part="GND14" gate="1" pin="GND"/>
<wire x1="27.94" y1="-73.66" x2="27.94" y2="-71.12" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND5" gate="1" pin="GND"/>
<pinref part="IC2" gate="G$1" pin="GND"/>
<wire x1="-96.52" y1="-99.06" x2="-96.52" y2="-96.52" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND6" gate="1" pin="GND"/>
<pinref part="C4" gate="G$1" pin="2"/>
<wire x1="-73.66" y1="-91.44" x2="-73.66" y2="-88.9" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND8" gate="1" pin="GND"/>
<pinref part="C5" gate="G$1" pin="1"/>
<wire x1="-45.72" y1="-91.44" x2="-45.72" y2="-88.9" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC3" gate="G$1" pin="GND"/>
<pinref part="GND9" gate="1" pin="GND"/>
<wire x1="-27.94" y1="-86.36" x2="-35.56" y2="-86.36" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND11" gate="1" pin="GND"/>
<pinref part="C7" gate="G$1" pin="2"/>
<wire x1="-20.32" y1="-170.18" x2="-20.32" y2="-167.64" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND13" gate="1" pin="GND"/>
<pinref part="C8" gate="G$1" pin="2"/>
<wire x1="-7.62" y1="-170.18" x2="-7.62" y2="-167.64" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND17" gate="1" pin="GND"/>
<pinref part="IC4" gate="G$1" pin="VSS"/>
<wire x1="81.28" y1="-170.18" x2="76.2" y2="-170.18" width="0.1524" layer="91"/>
<junction x="76.2" y="-170.18"/>
<pinref part="IC10" gate="G$1" pin="GND"/>
<wire x1="375.92" y1="-99.06" x2="360.68" y2="-99.06" width="0.1524" layer="91"/>
<wire x1="360.68" y1="-99.06" x2="350.52" y2="-109.22" width="0.1524" layer="91"/>
<pinref part="C19" gate="G$1" pin="1"/>
<wire x1="424.18" y1="-109.22" x2="350.52" y2="-109.22" width="0.1524" layer="91"/>
<pinref part="R36" gate="G$1" pin="1"/>
<wire x1="350.52" y1="-99.06" x2="350.52" y2="-109.22" width="0.1524" layer="91"/>
<junction x="350.52" y="-109.22"/>
<pinref part="R33" gate="G$1" pin="1"/>
<wire x1="342.9" y1="-99.06" x2="342.9" y2="-101.6" width="0.1524" layer="91"/>
<wire x1="342.9" y1="-101.6" x2="350.52" y2="-109.22" width="0.1524" layer="91"/>
<wire x1="350.52" y1="-109.22" x2="81.28" y2="-109.22" width="0.1524" layer="91"/>
<wire x1="81.28" y1="-109.22" x2="81.28" y2="-165.1" width="0.1524" layer="91"/>
<wire x1="81.28" y1="-165.1" x2="76.2" y2="-170.18" width="0.1524" layer="91"/>
<pinref part="R35" gate="G$1" pin="2"/>
<wire x1="350.52" y1="-109.22" x2="347.98" y2="-111.76" width="0.1524" layer="91"/>
<wire x1="347.98" y1="-111.76" x2="347.98" y2="-116.84" width="0.1524" layer="91"/>
<wire x1="350.52" y1="-109.22" x2="353.06" y2="-111.76" width="0.1524" layer="91"/>
<pinref part="R37" gate="G$1" pin="2"/>
<wire x1="353.06" y1="-111.76" x2="353.06" y2="-116.84" width="0.1524" layer="91"/>
<pinref part="R34" gate="G$1" pin="2"/>
<wire x1="342.9" y1="-116.84" x2="342.9" y2="-111.76" width="0.1524" layer="91"/>
<wire x1="342.9" y1="-111.76" x2="345.44" y2="-109.22" width="0.1524" layer="91"/>
<wire x1="345.44" y1="-109.22" x2="350.52" y2="-109.22" width="0.1524" layer="91"/>
<pinref part="R38" gate="G$1" pin="2"/>
<wire x1="358.14" y1="-116.84" x2="358.14" y2="-111.76" width="0.1524" layer="91"/>
<wire x1="358.14" y1="-111.76" x2="355.6" y2="-109.22" width="0.1524" layer="91"/>
<wire x1="355.6" y1="-109.22" x2="350.52" y2="-109.22" width="0.1524" layer="91"/>
<pinref part="Q4" gate="G$1" pin="S"/>
<wire x1="335.28" y1="-114.3" x2="340.36" y2="-109.22" width="0.1524" layer="91"/>
<wire x1="340.36" y1="-109.22" x2="350.52" y2="-109.22" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND18" gate="1" pin="GND"/>
<pinref part="IC4" gate="G$1" pin="LDAC"/>
<wire x1="81.28" y1="-190.5" x2="76.2" y2="-190.5" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND2" gate="1" pin="GND"/>
<pinref part="IC1" gate="G$1" pin="GND"/>
<wire x1="-157.48" y1="-99.06" x2="-157.48" y2="-96.52" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND1" gate="1" pin="GND"/>
<pinref part="C1" gate="G$1" pin="2"/>
<wire x1="-180.34" y1="-99.06" x2="-180.34" y2="-88.9" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND3" gate="1" pin="GND"/>
<pinref part="C2" gate="G$1" pin="2"/>
<wire x1="-134.62" y1="-99.06" x2="-134.62" y2="-88.9" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND4" gate="1" pin="GND"/>
<pinref part="C3" gate="G$1" pin="2"/>
<wire x1="-119.38" y1="-99.06" x2="-119.38" y2="-88.9" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND22" gate="1" pin="GND"/>
<pinref part="C12" gate="G$1" pin="2"/>
<wire x1="152.4" y1="-43.18" x2="152.4" y2="-40.64" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND23" gate="1" pin="GND"/>
<pinref part="C13" gate="G$1" pin="2"/>
<wire x1="198.12" y1="-81.28" x2="198.12" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="198.12" y1="-76.2" x2="198.12" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="226.06" y1="-76.2" x2="220.98" y2="-76.2" width="0.1524" layer="91"/>
<junction x="198.12" y="-76.2"/>
<wire x1="220.98" y1="-76.2" x2="198.12" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="220.98" y1="-66.04" x2="220.98" y2="-76.2" width="0.1524" layer="91"/>
<junction x="220.98" y="-76.2"/>
<pinref part="D2" gate="G$1" pin="C"/>
<pinref part="R22" gate="G$1" pin="1"/>
</segment>
<segment>
<pinref part="GND24" gate="1" pin="GND"/>
<pinref part="C15" gate="G$1" pin="2"/>
<wire x1="208.28" y1="-45.72" x2="208.28" y2="-43.18" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND38" gate="1" pin="GND"/>
<pinref part="D3" gate="G$1" pin="A"/>
<wire x1="454.66" y1="-17.78" x2="454.66" y2="-20.32" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC6" gate="G$1" pin="VCC"/>
<wire x1="152.4" y1="-182.88" x2="147.32" y2="-182.88" width="0.1524" layer="91"/>
<pinref part="GND21" gate="1" pin="GND"/>
<wire x1="147.32" y1="-182.88" x2="147.32" y2="-185.42" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND25" gate="1" pin="GND"/>
<pinref part="C14" gate="G$1" pin="2"/>
<wire x1="213.36" y1="-167.64" x2="210.82" y2="-167.64" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND35" gate="1" pin="GND"/>
<pinref part="C17" gate="G$1" pin="2"/>
<wire x1="320.04" y1="-167.64" x2="317.5" y2="-167.64" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC11" gate="G$1" pin="DGND"/>
<wire x1="375.92" y1="-182.88" x2="373.38" y2="-182.88" width="0.1524" layer="91"/>
<pinref part="GND36" gate="1" pin="GND"/>
<wire x1="373.38" y1="-182.88" x2="373.38" y2="-185.42" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND37" gate="1" pin="GND"/>
<pinref part="IC11" gate="G$1" pin="AGND"/>
<wire x1="421.64" y1="-162.56" x2="416.56" y2="-162.56" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND39" gate="1" pin="GND"/>
<pinref part="C18" gate="G$1" pin="2"/>
<wire x1="459.74" y1="-152.4" x2="454.66" y2="-152.4" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC9" gate="G$1" pin="VCC"/>
<wire x1="264.16" y1="-182.88" x2="256.54" y2="-182.88" width="0.1524" layer="91"/>
<pinref part="GND29" gate="1" pin="GND"/>
<wire x1="256.54" y1="-182.88" x2="256.54" y2="-185.42" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C16" gate="G$1" pin="1"/>
<pinref part="GND30" gate="1" pin="GND"/>
<wire x1="276.86" y1="-144.78" x2="276.86" y2="-149.86" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND27" gate="1" pin="GND"/>
<pinref part="Q2" gate="G$1" pin="E"/>
<wire x1="231.14" y1="-210.82" x2="231.14" y2="-208.28" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND26" gate="1" pin="GND"/>
<pinref part="Q1" gate="G$1" pin="E"/>
<wire x1="231.14" y1="-180.34" x2="231.14" y2="-177.8" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND40" gate="1" pin="GND"/>
<pinref part="C20" gate="G$1" pin="2"/>
<wire x1="485.14" y1="-106.68" x2="485.14" y2="-104.14" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND34" gate="1" pin="GND"/>
<pinref part="Q3" gate="G$1" pin="E"/>
<wire x1="322.58" y1="-149.86" x2="322.58" y2="-147.32" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND12" gate="1" pin="GND"/>
<wire x1="-12.7" y1="-355.6" x2="-12.7" y2="-373.38" width="0.1524" layer="91"/>
<label x="-12.7" y="-365.76" size="1.778" layer="95"/>
<pinref part="X1" gate="-1" pin="KL"/>
</segment>
<segment>
<pinref part="GND20" gate="1" pin="GND"/>
<pinref part="R16" gate="G$1" pin="1"/>
<wire x1="129.54" y1="-200.66" x2="129.54" y2="-198.12" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND32" gate="1" pin="GND"/>
<pinref part="R29" gate="G$1" pin="1"/>
<wire x1="287.02" y1="-198.12" x2="292.1" y2="-198.12" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC3" gate="G$1" pin="GNDS"/>
<wire x1="-27.94" y1="-91.44" x2="-35.56" y2="-91.44" width="0.1524" layer="91"/>
<pinref part="GND10" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="GND28" gate="1" pin="GND"/>
<pinref part="IC12" gate="G$1" pin="GND"/>
<wire x1="294.64" y1="-335.28" x2="302.26" y2="-335.28" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND31" gate="1" pin="GND"/>
<pinref part="R28" gate="G$1" pin="1"/>
<wire x1="297.18" y1="-149.86" x2="297.18" y2="-147.32" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="R12" gate="G$1" pin="2"/>
<wire x1="111.76" y1="-91.44" x2="114.3" y2="-91.44" width="0.1524" layer="91"/>
<pinref part="C11" gate="G$1" pin="1"/>
<wire x1="114.3" y1="-91.44" x2="114.3" y2="-93.98" width="0.1524" layer="91"/>
<wire x1="114.3" y1="-91.44" x2="190.5" y2="-91.44" width="0.1524" layer="91"/>
<junction x="114.3" y="-91.44"/>
<wire x1="190.5" y1="-91.44" x2="190.5" y2="-182.88" width="0.1524" layer="91"/>
<pinref part="IC6" gate="G$1" pin="2IN+"/>
<wire x1="190.5" y1="-182.88" x2="187.96" y2="-182.88" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="CH1"/>
<wire x1="375.92" y1="-157.48" x2="363.22" y2="-157.48" width="0.1524" layer="91"/>
<wire x1="363.22" y1="-157.48" x2="363.22" y2="-228.6" width="0.1524" layer="91"/>
<wire x1="363.22" y1="-228.6" x2="190.5" y2="-228.6" width="0.1524" layer="91"/>
<wire x1="190.5" y1="-228.6" x2="190.5" y2="-182.88" width="0.1524" layer="91"/>
<junction x="190.5" y="-182.88"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="NR"/>
<pinref part="C6" gate="G$1" pin="2"/>
<wire x1="-27.94" y1="-76.2" x2="-35.56" y2="-76.2" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="VREFB"/>
<wire x1="76.2" y1="-175.26" x2="88.9" y2="-175.26" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-175.26" x2="88.9" y2="-165.1" width="0.1524" layer="91"/>
<pinref part="IC4" gate="G$1" pin="VREFA"/>
<wire x1="88.9" y1="-165.1" x2="76.2" y2="-165.1" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="OUTF"/>
<wire x1="12.7" y1="-81.28" x2="27.94" y2="-81.28" width="0.1524" layer="91"/>
<wire x1="27.94" y1="-81.28" x2="27.94" y2="-86.36" width="0.1524" layer="91"/>
<pinref part="C9" gate="G$1" pin="2"/>
<junction x="27.94" y="-81.28"/>
<wire x1="27.94" y1="-86.36" x2="27.94" y2="-139.7" width="0.1524" layer="91"/>
<wire x1="27.94" y1="-139.7" x2="88.9" y2="-139.7" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-139.7" x2="88.9" y2="-165.1" width="0.1524" layer="91"/>
<junction x="88.9" y="-165.1"/>
<pinref part="IC11" gate="G$1" pin="VREF"/>
<wire x1="431.8" y1="-157.48" x2="416.56" y2="-157.48" width="0.1524" layer="91"/>
<wire x1="431.8" y1="-157.48" x2="431.8" y2="-246.38" width="0.1524" layer="91"/>
<wire x1="431.8" y1="-246.38" x2="93.98" y2="-246.38" width="0.1524" layer="91"/>
<wire x1="93.98" y1="-246.38" x2="93.98" y2="-165.1" width="0.1524" layer="91"/>
<wire x1="93.98" y1="-165.1" x2="88.9" y2="-165.1" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="OUTS"/>
<wire x1="12.7" y1="-86.36" x2="27.94" y2="-86.36" width="0.1524" layer="91"/>
<junction x="27.94" y="-86.36"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="IN"/>
<pinref part="IC1" gate="G$1" pin="OUT"/>
<wire x1="-111.76" y1="-81.28" x2="-119.38" y2="-81.28" width="0.1524" layer="91"/>
<pinref part="C3" gate="G$1" pin="1"/>
<wire x1="-119.38" y1="-81.28" x2="-127" y2="-81.28" width="0.1524" layer="91"/>
<junction x="-119.38" y="-81.28"/>
<pinref part="C2" gate="G$1" pin="1"/>
<wire x1="-127" y1="-81.28" x2="-134.62" y2="-81.28" width="0.1524" layer="91"/>
<wire x1="-134.62" y1="-81.28" x2="-142.24" y2="-81.28" width="0.1524" layer="91"/>
<junction x="-134.62" y="-81.28"/>
<pinref part="R31" gate="G$1" pin="1"/>
<wire x1="304.8" y1="-116.84" x2="-127" y2="-116.84" width="0.1524" layer="91"/>
<wire x1="-127" y1="-116.84" x2="-127" y2="-81.28" width="0.1524" layer="91"/>
<junction x="-127" y="-81.28"/>
</segment>
</net>
<net name="V+" class="0">
<segment>
<pinref part="R11" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-55.88" x2="73.66" y2="-55.88" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-55.88" x2="73.66" y2="-50.8" width="0.1524" layer="91"/>
<pinref part="R10" gate="G$1" pin="1"/>
<wire x1="73.66" y1="-50.8" x2="76.2" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-50.8" x2="73.66" y2="-45.72" width="0.1524" layer="91"/>
<junction x="73.66" y="-50.8"/>
<pinref part="R2" gate="G$1" pin="1"/>
<wire x1="73.66" y1="-45.72" x2="73.66" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-40.64" x2="73.66" y2="-35.56" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-35.56" x2="73.66" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-30.48" x2="73.66" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-25.4" x2="73.66" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-20.32" x2="73.66" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-15.24" x2="73.66" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-10.16" x2="76.2" y2="-10.16" width="0.1524" layer="91"/>
<pinref part="R3" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-15.24" x2="73.66" y2="-15.24" width="0.1524" layer="91"/>
<junction x="73.66" y="-15.24"/>
<pinref part="R4" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-20.32" x2="73.66" y2="-20.32" width="0.1524" layer="91"/>
<junction x="73.66" y="-20.32"/>
<pinref part="R5" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-25.4" x2="73.66" y2="-25.4" width="0.1524" layer="91"/>
<junction x="73.66" y="-25.4"/>
<pinref part="R6" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-30.48" x2="73.66" y2="-30.48" width="0.1524" layer="91"/>
<junction x="73.66" y="-30.48"/>
<pinref part="R7" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-35.56" x2="73.66" y2="-35.56" width="0.1524" layer="91"/>
<junction x="73.66" y="-35.56"/>
<pinref part="R8" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-40.64" x2="73.66" y2="-40.64" width="0.1524" layer="91"/>
<junction x="73.66" y="-40.64"/>
<pinref part="R9" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-45.72" x2="73.66" y2="-45.72" width="0.1524" layer="91"/>
<junction x="73.66" y="-45.72"/>
<pinref part="IC5" gate="G$1" pin="RS+"/>
<wire x1="58.42" y1="-76.2" x2="55.88" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="55.88" y1="-76.2" x2="55.88" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="55.88" y1="-48.26" x2="73.66" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-30.48" x2="-180.34" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="IN"/>
<pinref part="C1" gate="G$1" pin="1"/>
<wire x1="-172.72" y1="-81.28" x2="-180.34" y2="-81.28" width="0.1524" layer="91"/>
<wire x1="-180.34" y1="-81.28" x2="-180.34" y2="-63.5" width="0.1524" layer="91"/>
<junction x="-180.34" y="-81.28"/>
<wire x1="-180.34" y1="-63.5" x2="38.1" y2="-63.5" width="0.1524" layer="91"/>
<pinref part="IC5" gate="G$1" pin="VCC"/>
<wire x1="58.42" y1="-81.28" x2="38.1" y2="-81.28" width="0.1524" layer="91"/>
<pinref part="C10" gate="G$1" pin="1"/>
<junction x="38.1" y="-81.28"/>
<wire x1="38.1" y1="-63.5" x2="38.1" y2="-81.28" width="0.1524" layer="91"/>
<wire x1="-180.34" y1="-30.48" x2="-180.34" y2="-63.5" width="0.1524" layer="91"/>
<junction x="-180.34" y="-63.5"/>
<pinref part="IC6" gate="G$1" pin="VDD"/>
<wire x1="187.96" y1="-167.64" x2="200.66" y2="-167.64" width="0.1524" layer="91"/>
<wire x1="200.66" y1="-167.64" x2="200.66" y2="-129.54" width="0.1524" layer="91"/>
<wire x1="200.66" y1="-129.54" x2="-198.12" y2="-129.54" width="0.1524" layer="91"/>
<wire x1="-198.12" y1="-129.54" x2="-198.12" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="-198.12" y1="-63.5" x2="-180.34" y2="-63.5" width="0.1524" layer="91"/>
<pinref part="C14" gate="G$1" pin="1"/>
<wire x1="203.2" y1="-167.64" x2="200.66" y2="-167.64" width="0.1524" layer="91"/>
<junction x="200.66" y="-167.64"/>
<wire x1="200.66" y1="-129.54" x2="307.34" y2="-129.54" width="0.1524" layer="91"/>
<junction x="200.66" y="-129.54"/>
<wire x1="307.34" y1="-129.54" x2="307.34" y2="-167.64" width="0.1524" layer="91"/>
<pinref part="IC9" gate="G$1" pin="VDD"/>
<wire x1="307.34" y1="-167.64" x2="299.72" y2="-167.64" width="0.1524" layer="91"/>
<pinref part="C17" gate="G$1" pin="1"/>
<wire x1="309.88" y1="-167.64" x2="307.34" y2="-167.64" width="0.1524" layer="91"/>
<junction x="307.34" y="-167.64"/>
<wire x1="-198.12" y1="-129.54" x2="-198.12" y2="-276.86" width="0.1524" layer="91"/>
<junction x="-198.12" y="-129.54"/>
<wire x1="-198.12" y1="-276.86" x2="-2.54" y2="-276.86" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="-276.86" x2="-2.54" y2="-373.38" width="0.1524" layer="91"/>
<label x="-2.54" y="-365.76" size="1.778" layer="95"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="-190.5" y1="-30.48" x2="-180.34" y2="-30.48" width="0.1524" layer="91"/>
<junction x="-180.34" y="-30.48"/>
<pinref part="X1" gate="-2" pin="KL"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="R11" gate="G$1" pin="2"/>
<wire x1="86.36" y1="-55.88" x2="88.9" y2="-55.88" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-55.88" x2="88.9" y2="-50.8" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="2"/>
<wire x1="88.9" y1="-50.8" x2="88.9" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-45.72" x2="88.9" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-40.64" x2="88.9" y2="-35.56" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-35.56" x2="88.9" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-30.48" x2="88.9" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-25.4" x2="88.9" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-20.32" x2="88.9" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-15.24" x2="88.9" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-10.16" x2="86.36" y2="-10.16" width="0.1524" layer="91"/>
<pinref part="R3" gate="G$1" pin="2"/>
<wire x1="86.36" y1="-15.24" x2="88.9" y2="-15.24" width="0.1524" layer="91"/>
<junction x="88.9" y="-15.24"/>
<pinref part="R4" gate="G$1" pin="2"/>
<wire x1="86.36" y1="-20.32" x2="88.9" y2="-20.32" width="0.1524" layer="91"/>
<junction x="88.9" y="-20.32"/>
<pinref part="R5" gate="G$1" pin="2"/>
<wire x1="86.36" y1="-25.4" x2="88.9" y2="-25.4" width="0.1524" layer="91"/>
<junction x="88.9" y="-25.4"/>
<pinref part="R6" gate="G$1" pin="2"/>
<wire x1="86.36" y1="-30.48" x2="88.9" y2="-30.48" width="0.1524" layer="91"/>
<junction x="88.9" y="-30.48"/>
<pinref part="R7" gate="G$1" pin="2"/>
<wire x1="86.36" y1="-35.56" x2="88.9" y2="-35.56" width="0.1524" layer="91"/>
<junction x="88.9" y="-35.56"/>
<pinref part="R8" gate="G$1" pin="2"/>
<wire x1="86.36" y1="-40.64" x2="88.9" y2="-40.64" width="0.1524" layer="91"/>
<junction x="88.9" y="-40.64"/>
<pinref part="R9" gate="G$1" pin="2"/>
<wire x1="86.36" y1="-45.72" x2="88.9" y2="-45.72" width="0.1524" layer="91"/>
<junction x="88.9" y="-45.72"/>
<pinref part="R10" gate="G$1" pin="2"/>
<wire x1="86.36" y1="-50.8" x2="88.9" y2="-50.8" width="0.1524" layer="91"/>
<junction x="88.9" y="-50.8"/>
<wire x1="88.9" y1="-30.48" x2="104.14" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="104.14" y1="-45.72" x2="104.14" y2="-76.2" width="0.1524" layer="91"/>
<pinref part="IC5" gate="G$1" pin="RS-"/>
<wire x1="104.14" y1="-76.2" x2="99.06" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-30.48" x2="152.4" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="IC7" gate="G$1" pin="IN"/>
<pinref part="D1" gate="G$1" pin="C"/>
<wire x1="152.4" y1="-30.48" x2="165.1" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="180.34" y1="-12.7" x2="152.4" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="152.4" y1="-12.7" x2="152.4" y2="-25.4" width="0.1524" layer="91"/>
<junction x="152.4" y="-30.48"/>
<pinref part="C12" gate="G$1" pin="1"/>
<wire x1="152.4" y1="-25.4" x2="152.4" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="152.4" y1="-33.02" x2="152.4" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="IC7" gate="G$1" pin="VCONTROL"/>
<wire x1="165.1" y1="-25.4" x2="152.4" y2="-25.4" width="0.1524" layer="91"/>
<junction x="152.4" y="-25.4"/>
</segment>
</net>
<net name="OUT" class="0">
<segment>
<pinref part="IC7" gate="G$1" pin="OUT"/>
<wire x1="200.66" y1="-30.48" x2="208.28" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="208.28" y1="-30.48" x2="208.28" y2="-12.7" width="0.1524" layer="91"/>
<pinref part="D1" gate="G$1" pin="A"/>
<wire x1="208.28" y1="-12.7" x2="185.42" y2="-12.7" width="0.1524" layer="91"/>
<pinref part="C15" gate="G$1" pin="1"/>
<wire x1="208.28" y1="-35.56" x2="208.28" y2="-30.48" width="0.1524" layer="91"/>
<junction x="208.28" y="-30.48"/>
<pinref part="IC8" gate="G$1" pin="V+"/>
<wire x1="208.28" y1="-30.48" x2="243.84" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="243.84" y1="-30.48" x2="269.24" y2="-30.48" width="0.1524" layer="91"/>
<junction x="243.84" y="-30.48"/>
<pinref part="D3" gate="G$1" pin="C"/>
<wire x1="269.24" y1="-30.48" x2="454.66" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="454.66" y1="-30.48" x2="454.66" y2="-25.4" width="0.1524" layer="91"/>
<junction x="454.66" y="-30.48"/>
<wire x1="454.66" y1="-30.48" x2="444.5" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="444.5" y1="-40.64" x2="284.48" y2="-40.64" width="0.1524" layer="91"/>
<pinref part="R25" gate="G$1" pin="2"/>
<pinref part="R24" gate="G$1" pin="2"/>
<wire x1="269.24" y1="-40.64" x2="269.24" y2="-30.48" width="0.1524" layer="91"/>
<junction x="269.24" y="-30.48"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="IC7" gate="G$1" pin="SET"/>
<wire x1="182.88" y1="-43.18" x2="182.88" y2="-50.8" width="0.1524" layer="91"/>
<pinref part="C13" gate="G$1" pin="1"/>
<wire x1="198.12" y1="-53.34" x2="198.12" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="198.12" y1="-50.8" x2="182.88" y2="-50.8" width="0.1524" layer="91"/>
<junction x="182.88" y="-50.8"/>
<wire x1="182.88" y1="-50.8" x2="182.88" y2="-66.04" width="0.1524" layer="91"/>
<pinref part="R19" gate="G$1" pin="2"/>
<pinref part="R18" gate="G$1" pin="2"/>
<wire x1="182.88" y1="-50.8" x2="177.8" y2="-50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="IC8" gate="G$1" pin="R"/>
<wire x1="228.6" y1="-45.72" x2="226.06" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="226.06" y1="-45.72" x2="226.06" y2="-55.88" width="0.1524" layer="91"/>
<wire x1="226.06" y1="-45.72" x2="220.98" y2="-45.72" width="0.1524" layer="91"/>
<junction x="226.06" y="-45.72"/>
<wire x1="220.98" y1="-45.72" x2="220.98" y2="-55.88" width="0.1524" layer="91"/>
<pinref part="R23" gate="G$1" pin="2"/>
<pinref part="R22" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="IC8" gate="G$1" pin="V-"/>
<wire x1="243.84" y1="-60.96" x2="243.84" y2="-66.04" width="0.1524" layer="91"/>
<wire x1="226.06" y1="-66.04" x2="243.84" y2="-66.04" width="0.1524" layer="91"/>
<wire x1="226.06" y1="-66.04" x2="226.06" y2="-71.12" width="0.1524" layer="91"/>
<pinref part="D2" gate="G$1" pin="A"/>
<pinref part="R23" gate="G$1" pin="1"/>
<junction x="226.06" y="-66.04"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="VOUTA"/>
<wire x1="76.2" y1="-160.02" x2="139.7" y2="-160.02" width="0.1524" layer="91"/>
<wire x1="139.7" y1="-160.02" x2="139.7" y2="-177.8" width="0.1524" layer="91"/>
<pinref part="IC6" gate="G$1" pin="1IN+"/>
<wire x1="139.7" y1="-177.8" x2="152.4" y2="-177.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="IC6" gate="G$1" pin="2IN-"/>
<wire x1="187.96" y1="-177.8" x2="200.66" y2="-177.8" width="0.1524" layer="91"/>
<wire x1="200.66" y1="-177.8" x2="200.66" y2="-210.82" width="0.1524" layer="91"/>
<wire x1="200.66" y1="-210.82" x2="104.14" y2="-210.82" width="0.1524" layer="91"/>
<wire x1="104.14" y1="-210.82" x2="104.14" y2="-180.34" width="0.1524" layer="91"/>
<pinref part="IC4" gate="G$1" pin="VOUTB"/>
<wire x1="104.14" y1="-180.34" x2="76.2" y2="-180.34" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="IC9" gate="G$1" pin="2IN-"/>
<wire x1="299.72" y1="-177.8" x2="307.34" y2="-177.8" width="0.1524" layer="91"/>
<wire x1="307.34" y1="-177.8" x2="307.34" y2="-172.72" width="0.1524" layer="91"/>
<pinref part="IC9" gate="G$1" pin="2OUT"/>
<wire x1="307.34" y1="-172.72" x2="299.72" y2="-172.72" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="CH3"/>
<wire x1="375.92" y1="-167.64" x2="353.06" y2="-167.64" width="0.1524" layer="91"/>
<wire x1="353.06" y1="-167.64" x2="353.06" y2="-172.72" width="0.1524" layer="91"/>
<wire x1="353.06" y1="-172.72" x2="307.34" y2="-172.72" width="0.1524" layer="91"/>
<junction x="307.34" y="-172.72"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="IC9" gate="G$1" pin="1IN-"/>
<wire x1="264.16" y1="-172.72" x2="261.62" y2="-172.72" width="0.1524" layer="91"/>
<wire x1="261.62" y1="-172.72" x2="261.62" y2="-167.64" width="0.1524" layer="91"/>
<pinref part="IC9" gate="G$1" pin="1OUT"/>
<wire x1="261.62" y1="-167.64" x2="264.16" y2="-167.64" width="0.1524" layer="91"/>
<wire x1="261.62" y1="-167.64" x2="261.62" y2="-162.56" width="0.1524" layer="91"/>
<junction x="261.62" y="-167.64"/>
<pinref part="IC11" gate="G$1" pin="CH2"/>
<wire x1="261.62" y1="-162.56" x2="375.92" y2="-162.56" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="IC9" gate="G$1" pin="2IN+"/>
<wire x1="299.72" y1="-182.88" x2="307.34" y2="-182.88" width="0.1524" layer="91"/>
<pinref part="R30" gate="G$1" pin="2"/>
<wire x1="307.34" y1="-182.88" x2="307.34" y2="-185.42" width="0.1524" layer="91"/>
<wire x1="307.34" y1="-182.88" x2="320.04" y2="-182.88" width="0.1524" layer="91"/>
<junction x="307.34" y="-182.88"/>
<wire x1="320.04" y1="-182.88" x2="320.04" y2="-251.46" width="0.1524" layer="91"/>
<wire x1="320.04" y1="-251.46" x2="-215.9" y2="-251.46" width="0.1524" layer="91"/>
<wire x1="-215.9" y1="-251.46" x2="-215.9" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="R1" gate="G$1" pin="1"/>
<wire x1="-200.66" y1="-30.48" x2="-215.9" y2="-30.48" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="IC6" gate="G$1" pin="1IN-"/>
<wire x1="152.4" y1="-172.72" x2="129.54" y2="-172.72" width="0.1524" layer="91"/>
<junction x="129.54" y="-172.72"/>
<wire x1="129.54" y1="-172.72" x2="129.54" y2="-157.48" width="0.1524" layer="91"/>
<pinref part="R14" gate="G$1" pin="2"/>
<pinref part="R15" gate="G$1" pin="2"/>
<wire x1="129.54" y1="-175.26" x2="129.54" y2="-172.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="R13" gate="G$1" pin="1"/>
<pinref part="R14" gate="G$1" pin="1"/>
<wire x1="129.54" y1="-147.32" x2="129.54" y2="-144.78" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="R25" gate="G$1" pin="1"/>
<pinref part="R26" gate="G$1" pin="2"/>
<wire x1="284.48" y1="-53.34" x2="284.48" y2="-50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<pinref part="R26" gate="G$1" pin="1"/>
<pinref part="R27" gate="G$1" pin="2"/>
<junction x="284.48" y="-137.16"/>
<pinref part="C16" gate="G$1" pin="2"/>
<wire x1="284.48" y1="-137.16" x2="276.86" y2="-137.16" width="0.1524" layer="91"/>
<pinref part="IC9" gate="G$1" pin="1IN+"/>
<wire x1="264.16" y1="-177.8" x2="256.54" y2="-177.8" width="0.1524" layer="91"/>
<wire x1="256.54" y1="-177.8" x2="256.54" y2="-137.16" width="0.1524" layer="91"/>
<wire x1="256.54" y1="-137.16" x2="276.86" y2="-137.16" width="0.1524" layer="91"/>
<junction x="276.86" y="-137.16"/>
<wire x1="284.48" y1="-137.16" x2="284.48" y2="-63.5" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="IC6" gate="G$1" pin="2OUT"/>
<pinref part="R20" gate="G$1" pin="2"/>
<wire x1="187.96" y1="-172.72" x2="213.36" y2="-172.72" width="0.1524" layer="91"/>
<pinref part="R21" gate="G$1" pin="2"/>
<wire x1="213.36" y1="-203.2" x2="213.36" y2="-172.72" width="0.1524" layer="91"/>
<junction x="213.36" y="-172.72"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<pinref part="IC6" gate="G$1" pin="1OUT"/>
<wire x1="152.4" y1="-167.64" x2="147.32" y2="-167.64" width="0.1524" layer="91"/>
<wire x1="147.32" y1="-167.64" x2="147.32" y2="-154.94" width="0.1524" layer="91"/>
<pinref part="R17" gate="G$1" pin="2"/>
<wire x1="147.32" y1="-154.94" x2="162.56" y2="-154.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="R17" gate="G$1" pin="1"/>
<wire x1="172.72" y1="-154.94" x2="182.88" y2="-154.94" width="0.1524" layer="91"/>
<wire x1="182.88" y1="-154.94" x2="231.14" y2="-154.94" width="0.1524" layer="91"/>
<pinref part="R19" gate="G$1" pin="1"/>
<wire x1="182.88" y1="-154.94" x2="182.88" y2="-76.2" width="0.1524" layer="91"/>
<junction x="182.88" y="-154.94"/>
<pinref part="Q1" gate="G$1" pin="C"/>
<wire x1="231.14" y1="-167.64" x2="231.14" y2="-154.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<pinref part="Q2" gate="G$1" pin="B"/>
<wire x1="226.06" y1="-203.2" x2="223.52" y2="-203.2" width="0.1524" layer="91"/>
<pinref part="R21" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="Q1" gate="G$1" pin="B"/>
<pinref part="R20" gate="G$1" pin="1"/>
<wire x1="226.06" y1="-172.72" x2="223.52" y2="-172.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$29" class="0">
<segment>
<pinref part="IC10" gate="G$1" pin="OUT"/>
<pinref part="R41" gate="G$1" pin="1"/>
<wire x1="416.56" y1="-93.98" x2="426.72" y2="-93.98" width="0.1524" layer="91"/>
<pinref part="R40" gate="G$1" pin="2"/>
<wire x1="426.72" y1="-93.98" x2="467.36" y2="-93.98" width="0.1524" layer="91"/>
<wire x1="401.32" y1="-66.04" x2="426.72" y2="-66.04" width="0.1524" layer="91"/>
<wire x1="426.72" y1="-66.04" x2="426.72" y2="-93.98" width="0.1524" layer="91"/>
<junction x="426.72" y="-93.98"/>
<pinref part="R39" gate="G$1" pin="2"/>
<wire x1="401.32" y1="-55.88" x2="426.72" y2="-55.88" width="0.1524" layer="91"/>
<wire x1="426.72" y1="-55.88" x2="426.72" y2="-66.04" width="0.1524" layer="91"/>
<junction x="426.72" y="-66.04"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="R41" gate="G$1" pin="2"/>
<wire x1="477.52" y1="-93.98" x2="485.14" y2="-93.98" width="0.1524" layer="91"/>
<pinref part="C20" gate="G$1" pin="1"/>
<wire x1="485.14" y1="-93.98" x2="485.14" y2="-96.52" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="CH0"/>
<wire x1="375.92" y1="-152.4" x2="363.22" y2="-152.4" width="0.1524" layer="91"/>
<wire x1="363.22" y1="-152.4" x2="363.22" y2="-142.24" width="0.1524" layer="91"/>
<wire x1="363.22" y1="-142.24" x2="500.38" y2="-142.24" width="0.1524" layer="91"/>
<wire x1="500.38" y1="-142.24" x2="500.38" y2="-93.98" width="0.1524" layer="91"/>
<wire x1="500.38" y1="-93.98" x2="485.14" y2="-93.98" width="0.1524" layer="91"/>
<junction x="485.14" y="-93.98"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="R36" gate="G$1" pin="2"/>
<pinref part="IC10" gate="G$1" pin="IN-"/>
<wire x1="375.92" y1="-88.9" x2="350.52" y2="-88.9" width="0.1524" layer="91"/>
<pinref part="R33" gate="G$1" pin="2"/>
<wire x1="350.52" y1="-88.9" x2="342.9" y2="-88.9" width="0.1524" layer="91"/>
<junction x="350.52" y="-88.9"/>
<pinref part="R40" gate="G$1" pin="1"/>
<wire x1="391.16" y1="-66.04" x2="342.9" y2="-66.04" width="0.1524" layer="91"/>
<wire x1="342.9" y1="-66.04" x2="342.9" y2="-88.9" width="0.1524" layer="91"/>
<junction x="342.9" y="-88.9"/>
<pinref part="R39" gate="G$1" pin="1"/>
<wire x1="391.16" y1="-55.88" x2="342.9" y2="-55.88" width="0.1524" layer="91"/>
<wire x1="342.9" y1="-55.88" x2="342.9" y2="-66.04" width="0.1524" layer="91"/>
<junction x="342.9" y="-66.04"/>
</segment>
</net>
<net name="-" class="0">
<segment>
<pinref part="IC10" gate="G$1" pin="IN+"/>
<wire x1="368.3" y1="-93.98" x2="375.92" y2="-93.98" width="0.1524" layer="91"/>
<wire x1="368.3" y1="-93.98" x2="368.3" y2="-137.16" width="0.1524" layer="91"/>
<wire x1="368.3" y1="-137.16" x2="350.52" y2="-137.16" width="0.1524" layer="91"/>
<pinref part="Q4" gate="G$1" pin="D"/>
<wire x1="335.28" y1="-124.46" x2="335.28" y2="-132.08" width="0.1524" layer="91"/>
<wire x1="335.28" y1="-132.08" x2="345.44" y2="-132.08" width="0.1524" layer="91"/>
<pinref part="R34" gate="G$1" pin="1"/>
<pinref part="R35" gate="G$1" pin="1"/>
<wire x1="342.9" y1="-127" x2="347.98" y2="-127" width="0.1524" layer="91"/>
<pinref part="R37" gate="G$1" pin="1"/>
<wire x1="347.98" y1="-127" x2="350.52" y2="-127" width="0.1524" layer="91"/>
<junction x="347.98" y="-127"/>
<pinref part="R38" gate="G$1" pin="1"/>
<wire x1="350.52" y1="-127" x2="353.06" y2="-127" width="0.1524" layer="91"/>
<wire x1="353.06" y1="-127" x2="358.14" y2="-127" width="0.1524" layer="91"/>
<junction x="353.06" y="-127"/>
<wire x1="350.52" y1="-127" x2="355.6" y2="-132.08" width="0.1524" layer="91"/>
<junction x="350.52" y="-127"/>
<wire x1="355.6" y1="-132.08" x2="449.58" y2="-132.08" width="0.1524" layer="91"/>
<wire x1="449.58" y1="-132.08" x2="449.58" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="449.58" y1="-50.8" x2="454.66" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="345.44" y1="-132.08" x2="350.52" y2="-127" width="0.1524" layer="91"/>
<wire x1="350.52" y1="-137.16" x2="350.52" y2="-127" width="0.1524" layer="91"/>
<junction x="454.66" y="-50.8"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="Q4" gate="G$1" pin="G"/>
<pinref part="R31" gate="G$1" pin="2"/>
<wire x1="330.2" y1="-116.84" x2="322.58" y2="-116.84" width="0.1524" layer="91"/>
<pinref part="Q3" gate="G$1" pin="C"/>
<wire x1="322.58" y1="-116.84" x2="314.96" y2="-116.84" width="0.1524" layer="91"/>
<wire x1="322.58" y1="-137.16" x2="322.58" y2="-116.84" width="0.1524" layer="91"/>
<junction x="322.58" y="-116.84"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="R32" gate="G$1" pin="1"/>
<pinref part="Q3" gate="G$1" pin="B"/>
<wire x1="330.2" y1="-142.24" x2="327.66" y2="-142.24" width="0.1524" layer="91"/>
</segment>
</net>
<net name="CS_DAC" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="CS"/>
<wire x1="30.48" y1="-170.18" x2="12.7" y2="-170.18" width="0.1524" layer="91"/>
<wire x1="12.7" y1="-170.18" x2="12.7" y2="-292.1" width="0.1524" layer="91"/>
<wire x1="317.5" y1="-292.1" x2="12.7" y2="-292.1" width="0.1524" layer="91"/>
<pinref part="IC12" gate="G$1" pin="GPIO0"/>
<wire x1="294.64" y1="-360.68" x2="317.5" y2="-360.68" width="0.1524" layer="91"/>
<wire x1="317.5" y1="-292.1" x2="317.5" y2="-360.68" width="0.1524" layer="91"/>
</segment>
</net>
<net name="CS_ADC" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="CS/SHDN"/>
<wire x1="416.56" y1="-182.88" x2="419.1" y2="-182.88" width="0.1524" layer="91"/>
<wire x1="419.1" y1="-182.88" x2="419.1" y2="-386.08" width="0.1524" layer="91"/>
<pinref part="IC12" gate="G$1" pin="GPIO4"/>
<wire x1="254" y1="-355.6" x2="238.76" y2="-355.6" width="0.1524" layer="91"/>
<wire x1="238.76" y1="-355.6" x2="238.76" y2="-386.08" width="0.1524" layer="91"/>
<wire x1="238.76" y1="-386.08" x2="419.1" y2="-386.08" width="0.1524" layer="91"/>
</segment>
</net>
<net name="SCK" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="CLK"/>
<wire x1="416.56" y1="-167.64" x2="457.2" y2="-167.64" width="0.1524" layer="91"/>
<wire x1="457.2" y1="-167.64" x2="457.2" y2="-276.86" width="0.1524" layer="91"/>
<wire x1="457.2" y1="-276.86" x2="228.6" y2="-276.86" width="0.1524" layer="91"/>
<wire x1="228.6" y1="-276.86" x2="17.78" y2="-276.86" width="0.1524" layer="91"/>
<wire x1="17.78" y1="-276.86" x2="17.78" y2="-175.26" width="0.1524" layer="91"/>
<pinref part="IC4" gate="G$1" pin="SCK"/>
<wire x1="17.78" y1="-175.26" x2="30.48" y2="-175.26" width="0.1524" layer="91"/>
<pinref part="IC12" gate="G$1" pin="GPIO2"/>
<wire x1="254" y1="-365.76" x2="228.6" y2="-365.76" width="0.1524" layer="91"/>
<wire x1="228.6" y1="-365.76" x2="228.6" y2="-276.86" width="0.1524" layer="91"/>
<junction x="228.6" y="-276.86"/>
</segment>
</net>
<net name="SDI" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="SDI"/>
<wire x1="30.48" y1="-180.34" x2="22.86" y2="-180.34" width="0.1524" layer="91"/>
<wire x1="22.86" y1="-180.34" x2="22.86" y2="-271.78" width="0.1524" layer="91"/>
<wire x1="22.86" y1="-271.78" x2="322.58" y2="-271.78" width="0.1524" layer="91"/>
<wire x1="322.58" y1="-271.78" x2="424.18" y2="-271.78" width="0.1524" layer="91"/>
<wire x1="424.18" y1="-271.78" x2="424.18" y2="-177.8" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="DIN"/>
<wire x1="424.18" y1="-177.8" x2="416.56" y2="-177.8" width="0.1524" layer="91"/>
<pinref part="IC12" gate="G$1" pin="GPIO1"/>
<wire x1="294.64" y1="-365.76" x2="322.58" y2="-365.76" width="0.1524" layer="91"/>
<wire x1="322.58" y1="-365.76" x2="322.58" y2="-271.78" width="0.1524" layer="91"/>
<junction x="322.58" y="-271.78"/>
</segment>
</net>
<net name="DOUT" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="DOUT"/>
<wire x1="416.56" y1="-172.72" x2="447.04" y2="-172.72" width="0.1524" layer="91"/>
<wire x1="447.04" y1="-172.72" x2="447.04" y2="-381" width="0.1524" layer="91"/>
<pinref part="IC12" gate="G$1" pin="GPIO3"/>
<wire x1="254" y1="-360.68" x2="243.84" y2="-360.68" width="0.1524" layer="91"/>
<wire x1="243.84" y1="-360.68" x2="243.84" y2="-381" width="0.1524" layer="91"/>
<wire x1="243.84" y1="-381" x2="447.04" y2="-381" width="0.1524" layer="91"/>
</segment>
</net>
<net name="3V3" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="IN"/>
<wire x1="-27.94" y1="-81.28" x2="-45.72" y2="-81.28" width="0.1524" layer="91"/>
<wire x1="-45.72" y1="-81.28" x2="-63.5" y2="-81.28" width="0.1524" layer="91"/>
<pinref part="C5" gate="G$1" pin="2"/>
<junction x="-45.72" y="-81.28"/>
<pinref part="IC4" gate="G$1" pin="VDD"/>
<wire x1="30.48" y1="-160.02" x2="0" y2="-160.02" width="0.1524" layer="91"/>
<wire x1="0" y1="-160.02" x2="-7.62" y2="-160.02" width="0.1524" layer="91"/>
<wire x1="-7.62" y1="-160.02" x2="-20.32" y2="-160.02" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="-160.02" x2="-63.5" y2="-160.02" width="0.1524" layer="91"/>
<wire x1="-63.5" y1="-160.02" x2="-63.5" y2="-81.28" width="0.1524" layer="91"/>
<junction x="-63.5" y="-81.28"/>
<pinref part="C7" gate="G$1" pin="1"/>
<junction x="-20.32" y="-160.02"/>
<pinref part="C8" gate="G$1" pin="1"/>
<junction x="-7.62" y="-160.02"/>
<pinref part="IC4" gate="G$1" pin="SHDN"/>
<wire x1="76.2" y1="-185.42" x2="88.9" y2="-185.42" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-185.42" x2="88.9" y2="-200.66" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-200.66" x2="0" y2="-200.66" width="0.1524" layer="91"/>
<wire x1="0" y1="-200.66" x2="0" y2="-160.02" width="0.1524" layer="91"/>
<junction x="0" y="-160.02"/>
<wire x1="-63.5" y1="-160.02" x2="-63.5" y2="-218.44" width="0.1524" layer="91"/>
<junction x="-63.5" y="-160.02"/>
<wire x1="-63.5" y1="-218.44" x2="312.42" y2="-218.44" width="0.1524" layer="91"/>
<wire x1="312.42" y1="-218.44" x2="441.96" y2="-218.44" width="0.1524" layer="91"/>
<wire x1="441.96" y1="-218.44" x2="441.96" y2="-152.4" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="VDD"/>
<wire x1="441.96" y1="-152.4" x2="416.56" y2="-152.4" width="0.1524" layer="91"/>
<pinref part="C18" gate="G$1" pin="1"/>
<wire x1="447.04" y1="-152.4" x2="441.96" y2="-152.4" width="0.1524" layer="91"/>
<junction x="441.96" y="-152.4"/>
<pinref part="IC10" gate="G$1" pin="VCC"/>
<pinref part="C19" gate="G$1" pin="2"/>
<wire x1="416.56" y1="-88.9" x2="441.96" y2="-88.9" width="0.1524" layer="91"/>
<wire x1="441.96" y1="-152.4" x2="441.96" y2="-109.22" width="0.1524" layer="91"/>
<junction x="441.96" y="-88.9"/>
<pinref part="IC10" gate="G$1" pin="SHDN"/>
<wire x1="441.96" y1="-109.22" x2="441.96" y2="-88.9" width="0.1524" layer="91"/>
<wire x1="375.92" y1="-83.82" x2="360.68" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="360.68" y1="-83.82" x2="360.68" y2="-73.66" width="0.1524" layer="91"/>
<wire x1="360.68" y1="-73.66" x2="441.96" y2="-73.66" width="0.1524" layer="91"/>
<wire x1="441.96" y1="-73.66" x2="441.96" y2="-88.9" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="OUT"/>
<pinref part="C4" gate="G$1" pin="1"/>
<wire x1="-73.66" y1="-81.28" x2="-81.28" y2="-81.28" width="0.1524" layer="91"/>
<junction x="-73.66" y="-81.28"/>
<wire x1="-73.66" y1="-81.28" x2="-63.5" y2="-81.28" width="0.1524" layer="91"/>
<wire x1="431.8" y1="-109.22" x2="441.96" y2="-109.22" width="0.1524" layer="91"/>
<junction x="441.96" y="-109.22"/>
<pinref part="IC12" gate="G$1" pin="+3V"/>
<wire x1="294.64" y1="-345.44" x2="312.42" y2="-345.44" width="0.1524" layer="91"/>
<wire x1="312.42" y1="-345.44" x2="312.42" y2="-218.44" width="0.1524" layer="91"/>
<junction x="312.42" y="-218.44"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="R16" gate="G$1" pin="2"/>
<pinref part="R15" gate="G$1" pin="1"/>
<wire x1="129.54" y1="-187.96" x2="129.54" y2="-185.42" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="R29" gate="G$1" pin="2"/>
<pinref part="R30" gate="G$1" pin="1"/>
<wire x1="302.26" y1="-198.12" x2="307.34" y2="-198.12" width="0.1524" layer="91"/>
<wire x1="307.34" y1="-198.12" x2="307.34" y2="-195.58" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="R13" gate="G$1" pin="2"/>
<pinref part="R18" gate="G$1" pin="1"/>
<wire x1="129.54" y1="-134.62" x2="129.54" y2="-96.52" width="0.1524" layer="91"/>
<wire x1="129.54" y1="-96.52" x2="129.54" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="129.54" y1="-50.8" x2="167.64" y2="-50.8" width="0.1524" layer="91"/>
<pinref part="R24" gate="G$1" pin="1"/>
<wire x1="129.54" y1="-96.52" x2="269.24" y2="-96.52" width="0.1524" layer="91"/>
<wire x1="269.24" y1="-96.52" x2="269.24" y2="-50.8" width="0.1524" layer="91"/>
<junction x="129.54" y="-96.52"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="R27" gate="G$1" pin="1"/>
<pinref part="R28" gate="G$1" pin="2"/>
<wire x1="294.64" y1="-137.16" x2="297.18" y2="-137.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<pinref part="IC12" gate="G$1" pin="GPIO5"/>
<wire x1="254" y1="-350.52" x2="243.84" y2="-350.52" width="0.1524" layer="91"/>
<wire x1="243.84" y1="-350.52" x2="243.84" y2="-193.04" width="0.1524" layer="91"/>
<wire x1="231.14" y1="-193.04" x2="243.84" y2="-193.04" width="0.1524" layer="91"/>
<pinref part="Q2" gate="G$1" pin="C"/>
<wire x1="231.14" y1="-198.12" x2="231.14" y2="-193.04" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<pinref part="IC12" gate="G$1" pin="GPIO6"/>
<wire x1="254" y1="-345.44" x2="248.92" y2="-345.44" width="0.1524" layer="91"/>
<wire x1="248.92" y1="-345.44" x2="248.92" y2="-320.04" width="0.1524" layer="91"/>
<pinref part="R32" gate="G$1" pin="2"/>
<wire x1="340.36" y1="-142.24" x2="345.44" y2="-142.24" width="0.1524" layer="91"/>
<wire x1="248.92" y1="-320.04" x2="345.44" y2="-320.04" width="0.1524" layer="91"/>
<wire x1="345.44" y1="-320.04" x2="345.44" y2="-142.24" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
</compatibility>
</eagle>
