<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.2.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="relay" urn="urn:adsk.eagle:library:339">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="G5LE" urn="urn:adsk.eagle:footprint:23966/1" library_version="1">
<description>&lt;b&gt;RELAY&lt;/b&gt;&lt;p&gt;
1 x switch, 10 A/120 V AC, 8 A/30 V ADC, Omron</description>
<wire x1="-12.065" y1="8.255" x2="10.541" y2="8.255" width="0.1524" layer="21"/>
<wire x1="10.541" y1="-8.255" x2="10.541" y2="8.255" width="0.1524" layer="21"/>
<wire x1="10.541" y1="-8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="5.969" x2="-4.445" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="5.969" x2="-4.445" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.635" x2="-5.715" y2="0.635" width="0.254" layer="21"/>
<wire x1="-5.715" y1="0.635" x2="-5.715" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-3.175" y2="0.635" width="0.254" layer="21"/>
<wire x1="-3.175" y1="0.635" x2="-4.445" y2="0.635" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-0.635" x2="-4.445" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-4.445" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-3.175" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-5.969" x2="-5.08" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-0.635" x2="-3.175" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="4.064" y2="0" width="0.1524" layer="21"/>
<wire x1="4.064" y1="0" x2="4.699" y2="0.635" width="0.254" layer="21"/>
<wire x1="4.699" y1="3.7338" x2="4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-0.635" x2="4.699" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="4.699" y1="0.635" x2="5.0292" y2="0.9398" width="0.254" layer="21"/>
<wire x1="-7.366" y1="0" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<pad name="P" x="-9.525" y="0" drill="1.3208" shape="long"/>
<pad name="1" x="-7.493" y="-5.969" drill="1.3208" shape="long"/>
<pad name="2" x="-7.493" y="5.969" drill="1.3208" shape="long"/>
<pad name="O" x="4.699" y="5.969" drill="1.3208" shape="long"/>
<pad name="S" x="4.699" y="-5.969" drill="1.3208" shape="long"/>
<text x="12.827" y="-8.255" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="9.525" y="-7.62" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="G5LE" urn="urn:adsk.eagle:package:24308/1" type="box" library_version="1">
<description>RELAY
<packageinstances>
<packageinstance name="G5LE"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="K" urn="urn:adsk.eagle:symbol:23941/1" library_version="1">
<wire x1="-3.81" y1="-1.905" x2="-1.905" y2="-1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.905" x2="1.905" y2="1.905" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.905" x2="3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="1.905" x2="-3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="1.905" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="0" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.905" x2="0" y2="1.905" width="0.254" layer="94"/>
<text x="1.27" y="2.921" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="5.08" size="1.778" layer="95">&gt;PART</text>
<pin name="2" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="1" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="U" urn="urn:adsk.eagle:symbol:23944/1" library_version="1">
<wire x1="3.175" y1="5.08" x2="1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="-3.175" y1="5.08" x2="-1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="2.54" y2="5.715" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="0" width="0.254" layer="94"/>
<circle x="0" y="1.27" radius="0.127" width="0.4064" layer="94"/>
<text x="2.54" y="0" size="1.778" layer="95">&gt;PART</text>
<pin name="O" x="5.08" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="S" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="P" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="G5LE" urn="urn:adsk.eagle:component:24583/1" prefix="K" library_version="1">
1 x switch, 10 A/120 V AC, 8 A/30 V DC, Omron</description>
<gates>
<gate name="1" symbol="K" x="-7.62" y="0" addlevel="must"/>
<gate name="2" symbol="U" x="15.24" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="G5LE">
<connects>
<connect gate="1" pin="1" pad="1"/>
<connect gate="1" pin="2" pad="2"/>
<connect gate="2" pin="O" pad="O"/>
<connect gate="2" pin="P" pad="P"/>
<connect gate="2" pin="S" pad="S"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:24308/1"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-wago-508" urn="urn:adsk.eagle:library:196">
<description>&lt;b&gt;Wago Screw Clamps&lt;/b&gt;&lt;p&gt;
Grid 5.08 mm&lt;p&gt;
<packages>
<package name="W237-132" urn="urn:adsk.eagle:footprint:10712/1" library_version="1">
<description>&lt;b&gt;WAGO SREW CLAMP&lt;/b&gt;</description>
<wire x1="-3.5306" y1="-1.651" x2="-1.524" y2="0.3556" width="0.254" layer="51"/>
<wire x1="1.6256" y1="-1.6764" x2="3.5306" y2="0.3556" width="0.254" layer="51"/>
<wire x1="-5.08" y1="4.191" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-3.429" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.413" x2="-1.651" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.413" x2="1.651" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-2.413" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.413" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.445" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.191" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-2.413" x2="3.429" y2="-2.413" width="0.1524" layer="51"/>
<circle x="-2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="-2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<text x="-4.445" y="1.27" size="1.27" layer="51" ratio="10">1</text>
<text x="0.6858" y="1.2192" size="1.27" layer="51" ratio="10">2</text>
<text x="-3.81" y="-6.985" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.81" y="-4.318" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
<packages3d>
<package3d name="W237-132" urn="urn:adsk.eagle:package:10734/1" type="box" library_version="1">
<description>WAGO SREW CLAMP</description>
<packageinstances>
<packageinstance name="W237-132"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="KL" urn="urn:adsk.eagle:symbol:10710/1" library_version="1">
<wire x1="1.778" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<circle x="0.889" y="0" radius="0.898" width="0.254" layer="94"/>
<text x="-1.27" y="0.889" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<pin name="KL" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="KL+V" urn="urn:adsk.eagle:symbol:10711/1" library_version="1">
<text x="0" y="2.54" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="W237-02P" urn="urn:adsk.eagle:component:10750/1" prefix="X" uservalue="yes" library_version="1">
<gates>
<gate name="-1" symbol="KL" x="0" y="0" addlevel="always"/>
<gate name="-2" symbol="KL+V" x="0" y="-5.08" addlevel="always"/>
</gates>
<devices>
<device name="" package="W237-132">
<connects>
<connect gate="-1" pin="KL" pad="1"/>
<connect gate="-2" pin="KL" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:10734/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="fuse" urn="urn:adsk.eagle:library:233">
<description>&lt;b&gt;Fuses and Fuse Holders&lt;/b&gt;&lt;p&gt;
<packages>
<package name="19559" urn="urn:adsk.eagle:footprint:14028/1" library_version="1">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt;
TR5 Fuse Holder Wickmann</description>
<wire x1="1.778" y1="-1.397" x2="2.413" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-1.778" x2="2.032" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="2.413" x2="-1.397" y2="1.778" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="2.032" x2="-1.778" y2="1.397" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-3.937" x2="2.413" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-3.175" x2="3.175" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-2.413" x2="3.937" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="4.064" y1="-3.683" x2="3.683" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-3.175" x2="3.175" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="2.413" x2="-2.413" y2="3.175" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="3.937" x2="-2.413" y2="3.175" width="0.1524" layer="51"/>
<wire x1="-3.937" y1="3.175" x2="-3.175" y2="2.413" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="2.794" x2="-2.794" y2="3.175" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="3.683" x2="-3.683" y2="4.064" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-3.683" x2="3.683" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.302" x2="3.175" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="3.302" y1="-3.683" x2="3.683" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-3.683" x2="2.794" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="3.683" x2="-3.683" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="3.302" x2="-3.175" y2="2.794" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="4.064" x2="-3.302" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="3.683" x2="-2.794" y2="3.175" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<circle x="1.905" y="-1.905" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.905" y="1.905" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.905" y="1.905" radius="0.5334" width="0.1524" layer="51"/>
<circle x="1.905" y="-1.905" radius="0.5334" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="2.54" drill="1.3208" diameter="2.54" shape="octagon"/>
<pad name="2" x="2.54" y="-2.54" drill="1.3208" diameter="2.54" shape="octagon"/>
<text x="-4.572" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.81" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="19560" urn="urn:adsk.eagle:footprint:14029/1" library_version="1">
<wire x1="2.54" y1="-3.937" x2="3.937" y2="-2.54" width="0.1524" layer="21" curve="177.916747"/>
<circle x="0" y="0" radius="4.699" width="0.1524" layer="21"/>
<circle x="2.54" y="0" radius="0.762" width="0.1524" layer="51"/>
<circle x="2.54" y="0" radius="0.254" width="0.254" layer="51"/>
<circle x="-2.54" y="0" radius="0.254" width="0.254" layer="51"/>
<circle x="-2.54" y="0" radius="0.762" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.778" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.778" shape="long" rot="R90"/>
<text x="-2.54" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="F456" urn="urn:adsk.eagle:footprint:14039/1" library_version="1">
CS Schukat</description>
<wire x1="-6.35" y1="-6.35" x2="-6.35" y2="6.35" width="0.1524" layer="21"/>
<wire x1="6.35" y1="6.35" x2="6.35" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.27" x2="-2.54" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-1.27" x2="-2.54" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="1.27" x2="2.54" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="2.54" y1="1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.27" x2="4.318" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="5.461" x2="-2.286" y2="3.937" width="0.1524" layer="51"/>
<wire x1="0" y1="6.35" x2="0" y2="4.572" width="0.1524" layer="51"/>
<wire x1="6.35" y1="6.35" x2="0.889" y2="6.35" width="0.1524" layer="21"/>
<wire x1="0.889" y1="6.35" x2="-0.889" y2="6.35" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="6.35" x2="-6.35" y2="6.35" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-6.35" x2="0.889" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-6.35" x2="0" y2="-6.35" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-6.35" x2="-6.35" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="0" y1="-6.35" x2="0" y2="-4.572" width="0.1524" layer="51"/>
<wire x1="0" y1="-6.35" x2="-0.889" y2="-6.35" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-5.461" x2="2.286" y2="-3.937" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="6.35" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="51"/>
<pad name="1" x="0" y="5.08" drill="1.3208" diameter="2.54" shape="octagon"/>
<pad name="2" x="0" y="-5.08" drill="1.3208" diameter="2.54" shape="octagon"/>
<text x="-6.35" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-8.89" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<hole x="5.08" y="5.08" drill="2.0066"/>
<hole x="5.08" y="-5.08" drill="2.0066"/>
<hole x="-5.08" y="-5.08" drill="2.0066"/>
<hole x="-5.08" y="5.08" drill="2.0066"/>
</package>
<package name="F457" urn="urn:adsk.eagle:footprint:14035/1" library_version="1">
<wire x1="7.366" y1="6.223" x2="7.366" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-27.686" y1="-6.223" x2="-19.685" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-27.686" y1="-6.223" x2="-27.686" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.366" y1="6.223" x2="4.318" y2="6.223" width="0.1524" layer="21"/>
<wire x1="4.318" y1="6.223" x2="4.318" y2="3.175" width="0.1524" layer="21"/>
<wire x1="4.318" y1="6.223" x2="-16.637" y2="6.223" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-6.223" x2="7.366" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.318" y1="3.175" x2="-16.637" y2="3.175" width="0.1524" layer="21"/>
<wire x1="4.318" y1="1.27" x2="4.318" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="4.318" y1="-3.175" x2="-16.637" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-3.175" x2="4.318" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-16.637" y1="6.223" x2="-16.637" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-16.637" y1="6.223" x2="-19.685" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="6.223" x2="-19.685" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="6.223" x2="-27.686" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-6.223" x2="-16.637" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-16.637" y1="-6.223" x2="4.318" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-21.717" y1="4.064" x2="-21.717" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-25.654" y1="-4.064" x2="-21.717" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-21.717" y1="4.064" x2="-25.654" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-25.654" y1="-4.064" x2="-25.654" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-25.654" y1="-0.127" x2="-25.654" y2="0.127" width="0.1524" layer="21"/>
<wire x1="-25.654" y1="-0.127" x2="-25.4" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.127" x2="-25.4" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.127" x2="-25.654" y2="0.127" width="0.1524" layer="21"/>
<wire x1="-25.654" y1="0.127" x2="-25.654" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-25.654" y1="-3.683" x2="-22.86" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-25.654" y1="-3.683" x2="-25.654" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-0.381" x2="-22.86" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-0.381" x2="-25.654" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-25.654" y1="-0.381" x2="-25.654" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="4.318" y1="3.175" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-16.637" y1="3.175" x2="-16.637" y2="-6.223" width="0.1524" layer="21"/>
<pad name="2" x="5.08" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="1" x="-5.08" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="-15.875" y="1.143" size="1.27" layer="51" ratio="10">F457 10A/250V</text>
<text x="-15.875" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-27.686" y="-8.636" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-25.654" y1="-3.683" x2="-22.86" y2="-0.381" layer="21"/>
<rectangle x1="-16.637" y1="3.175" x2="4.318" y2="6.223" layer="21"/>
<rectangle x1="-16.637" y1="-6.223" x2="4.318" y2="-3.175" layer="21"/>
</package>
<package name="FUSE_HOLDER_5X20MM" urn="urn:adsk.eagle:footprint:14052/1" library_version="1">
<description>&lt;b&gt;Fuse Holder&lt;/b&gt; 5x20 mm&lt;p&gt;
Source: User LBR Version 2.05</description>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="1.016" y1="-3.556" x2="-2.032" y2="-3.556" width="0.3048" layer="21"/>
<wire x1="-2.032" y1="-3.556" x2="-2.032" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="-2.032" y1="3.556" x2="1.016" y2="3.556" width="0.3048" layer="21"/>
<wire x1="-2.286" y1="-3.048" x2="-3.048" y2="-3.048" width="0.3048" layer="21"/>
<wire x1="-3.048" y1="-1.778" x2="-3.048" y2="-3.048" width="0.3048" layer="21"/>
<wire x1="13.716" y1="2.54" x2="13.716" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="1.524" y1="2.54" x2="1.524" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="1.524" y1="2.54" x2="13.716" y2="2.54" width="0.3048" layer="21"/>
<wire x1="1.524" y1="-2.54" x2="13.716" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="-2.032" y1="-2.286" x2="1.016" y2="-2.286" width="0.3048" layer="21"/>
<wire x1="-2.032" y1="2.286" x2="1.016" y2="2.286" width="0.3048" layer="21"/>
<wire x1="1.524" y1="2.54" x2="1.016" y2="2.54" width="0.3048" layer="21"/>
<wire x1="1.016" y1="2.54" x2="1.016" y2="3.556" width="0.3048" layer="21"/>
<wire x1="1.016" y1="2.54" x2="1.016" y2="2.286" width="0.3048" layer="21"/>
<wire x1="-2.032" y1="2.286" x2="-2.032" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-2.032" y1="2.54" x2="-2.032" y2="3.556" width="0.3048" layer="21"/>
<wire x1="-2.032" y1="2.54" x2="-2.54" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-2.032" y2="-2.286" width="0.3048" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-2.54" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="1.524" y1="-2.54" x2="1.016" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="1.016" y1="-2.54" x2="1.016" y2="-2.286" width="0.3048" layer="21"/>
<wire x1="1.016" y1="-2.54" x2="1.016" y2="-3.556" width="0.3048" layer="21"/>
<wire x1="17.78" y1="-2.54" x2="17.78" y2="2.54" width="0.3048" layer="21"/>
<wire x1="14.224" y1="3.556" x2="17.272" y2="3.556" width="0.3048" layer="21"/>
<wire x1="17.272" y1="3.556" x2="17.272" y2="2.54" width="0.3048" layer="21"/>
<wire x1="17.272" y1="-3.556" x2="14.224" y2="-3.556" width="0.3048" layer="21"/>
<wire x1="17.526" y1="3.048" x2="18.288" y2="3.048" width="0.3048" layer="21"/>
<wire x1="18.288" y1="1.778" x2="18.288" y2="3.048" width="0.3048" layer="21"/>
<wire x1="17.272" y1="2.286" x2="14.224" y2="2.286" width="0.3048" layer="21"/>
<wire x1="17.272" y1="-2.286" x2="14.224" y2="-2.286" width="0.3048" layer="21"/>
<wire x1="13.716" y1="-2.54" x2="14.224" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="14.224" y1="-2.54" x2="14.224" y2="-3.556" width="0.3048" layer="21"/>
<wire x1="14.224" y1="-2.54" x2="14.224" y2="-2.286" width="0.3048" layer="21"/>
<wire x1="17.272" y1="-2.286" x2="17.272" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="17.272" y1="-2.54" x2="17.272" y2="-3.556" width="0.3048" layer="21"/>
<wire x1="17.272" y1="-2.54" x2="17.78" y2="-2.54" width="0.3048" layer="21"/>
<wire x1="17.272" y1="2.54" x2="17.272" y2="2.286" width="0.3048" layer="21"/>
<wire x1="17.272" y1="2.54" x2="17.78" y2="2.54" width="0.3048" layer="21"/>
<wire x1="13.716" y1="2.54" x2="14.224" y2="2.54" width="0.3048" layer="21"/>
<wire x1="14.224" y1="2.54" x2="14.224" y2="2.286" width="0.3048" layer="21"/>
<wire x1="14.224" y1="2.54" x2="14.224" y2="3.556" width="0.3048" layer="21"/>
<pad name="1" x="0" y="0" drill="1.4224" diameter="2.286" shape="square"/>
<pad name="2" x="15.24" y="0" drill="1.4224" diameter="2.286" shape="square"/>
<text x="2.032" y="3.81" size="2.54" layer="25">&gt;NAME</text>
<text x="1.778" y="-5.842" size="2.54" layer="27">&gt;VALUE</text>
</package>
<package name="FUSE_HOLDER_MENTOR-1821" urn="urn:adsk.eagle:footprint:14050/1" library_version="1">
<description>&lt;b&gt;Fuse Holder&lt;/b&gt; 5x20 mm Manufacturer: MENTOR Type: 1821&lt;p&gt;
Distributor: Bürklin 46 G 6111&lt;br&gt;
<wire x1="10.795" y1="5.08" x2="-5.08" y2="5.08" width="0.3048" layer="21"/>
<wire x1="-22.225" y1="4.445" x2="-22.225" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="10.795" y1="-5.08" x2="-5.08" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="10.795" y1="-5.08" x2="10.795" y2="5.08" width="0.3048" layer="21"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="-5.08" y1="5.08" x2="-12.065" y2="5.08" width="0.3048" layer="21"/>
<wire x1="-5.08" y1="-5.08" x2="-12.065" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="5.08" x2="-12.065" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-18.415" y1="3.81" x2="-12.065" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-18.415" y1="3.81" x2="-18.415" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-18.415" y1="4.445" x2="-22.225" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-22.225" y1="-4.445" x2="-18.415" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="-18.415" y1="-3.81" x2="-18.415" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="-3.81" x2="-12.065" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="-3.81" x2="-18.415" y2="-3.81" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="3.81" x2="-12.065" y2="-3.81" width="0.3048" layer="21"/>
<wire x1="-18.415" y1="3.81" x2="-18.415" y2="-3.81" width="0.3048" layer="21"/>
<pad name="B" x="0" y="0" drill="1.2192" diameter="1.905" shape="square"/>
<pad name="A" x="10.16" y="0" drill="1.2192" diameter="1.905" shape="square"/>
<text x="-11.43" y="-8.255" size="1.778" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="FUSE_HOLDER_SCHURTER-FAS" urn="urn:adsk.eagle:footprint:14053/1" library_version="1">
<description>&lt;b&gt;Fuse holder&lt;/b&gt; 5x20 mm Manufacturer: SCHURTER Type: FAS&lt;p&gt;
Distributor: Bürklin 46 G 611&lt;br&gt;
<wire x1="-5.08" y1="-5.08" x2="-5.08" y2="5.08" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-6.35" x2="-8.89" y2="-3.81" width="0.3048" layer="21"/>
<wire x1="-17.78" y1="-4.445" x2="-17.78" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-17.78" y1="4.445" x2="-11.43" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-11.43" y1="4.445" x2="-11.43" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-17.78" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="13.335" y1="5.08" x2="-5.08" y2="5.08" width="0.3048" layer="21"/>
<wire x1="-11.43" y1="3.81" x2="-8.89" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-11.43" y1="3.81" x2="-11.43" y2="-3.81" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="3.81" x2="-8.89" y2="6.35" width="0.3048" layer="21"/>
<wire x1="-11.43" y1="-3.81" x2="-8.89" y2="-3.81" width="0.3048" layer="21"/>
<wire x1="-11.43" y1="-3.81" x2="-11.43" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-3.81" x2="-8.89" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-5.08" y1="-5.08" x2="13.335" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="6.35" width="0.3048" layer="21"/>
<wire x1="-5.08" y1="6.35" x2="-8.89" y2="6.35" width="0.3048" layer="21"/>
<wire x1="-5.08" y1="-5.08" x2="-5.08" y2="-6.35" width="0.3048" layer="21"/>
<wire x1="-5.08" y1="-6.35" x2="-8.89" y2="-6.35" width="0.3048" layer="21"/>
<pad name="A" x="0" y="0" drill="1.2192" diameter="1.905" shape="square"/>
<pad name="B" x="12.7" y="0" drill="1.2192" diameter="1.905" shape="square"/>
<text x="-3.81" y="-7.62" size="1.778" layer="25">&gt;NAME</text>
</package>
<package name="FUSE_HOLDER_WICKMANN-19596" urn="urn:adsk.eagle:footprint:14051/1" library_version="1">
<description>&lt;b&gt;Fuse holder&lt;/b&gt; 5x20 mm Manufacturer: WICKMANN Type: 19596&lt;p&gt;
Distributor: Bürklin 46 G 612&lt;br&gt;
<wire x1="-5.715" y1="-5.08" x2="-5.715" y2="5.08" width="0.3048" layer="21"/>
<wire x1="-9.525" y1="-5.715" x2="-9.525" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="-17.145" y1="-5.08" x2="-17.145" y2="5.08" width="0.3048" layer="21"/>
<wire x1="-17.145" y1="5.08" x2="-10.795" y2="5.08" width="0.3048" layer="21"/>
<wire x1="-10.795" y1="5.08" x2="-10.795" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-10.795" y1="-5.08" x2="-17.145" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="13.97" y1="4.445" x2="13.97" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="-10.795" y1="4.445" x2="-9.525" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-10.795" y1="4.445" x2="-10.795" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="-9.525" y1="4.445" x2="-9.525" y2="5.715" width="0.3048" layer="21"/>
<wire x1="-10.795" y1="-4.445" x2="-9.525" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="-10.795" y1="-4.445" x2="-10.795" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="-9.525" y1="-4.445" x2="-9.525" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-5.715" y1="5.08" x2="-5.715" y2="5.715" width="0.3048" layer="21"/>
<wire x1="-5.715" y1="5.715" x2="-9.525" y2="5.715" width="0.3048" layer="21"/>
<wire x1="-5.715" y1="-5.08" x2="-5.715" y2="-5.715" width="0.3048" layer="21"/>
<wire x1="-5.715" y1="-5.715" x2="-9.525" y2="-5.715" width="0.3048" layer="21"/>
<wire x1="-5.715" y1="5.08" x2="1.905" y2="5.08" width="0.3048" layer="21"/>
<wire x1="1.905" y1="4.445" x2="1.905" y2="5.08" width="0.3048" layer="21"/>
<wire x1="1.905" y1="4.445" x2="13.97" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-5.715" y1="-5.08" x2="1.905" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="1.905" y1="-4.445" x2="1.905" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="1.905" y1="-4.445" x2="13.97" y2="-4.445" width="0.3048" layer="21"/>
<wire x1="-6.985" y1="3.175" x2="-8.255" y2="0.635" width="0.3048" layer="21"/>
<wire x1="-8.255" y1="0.635" x2="-6.985" y2="0.635" width="0.3048" layer="21"/>
<wire x1="-6.985" y1="0.635" x2="-8.255" y2="-1.905" width="0.3048" layer="21"/>
<wire x1="-8.255" y1="-1.905" x2="-8.255" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="-8.255" y1="-1.905" x2="-7.62" y2="-1.27" width="0.3048" layer="21"/>
<pad name="A" x="12.7" y="0" drill="1.2192" diameter="1.905" shape="square"/>
<pad name="B@1" x="2.54" y="0" drill="1.2192" diameter="1.905" shape="square"/>
</package>
<package name="GSH15" urn="urn:adsk.eagle:footprint:14041/1" library_version="1">
grid 15mm, 19649 Wickmann</description>
<wire x1="-12.573" y1="-4.572" x2="-12.573" y2="4.572" width="0.1524" layer="21"/>
<wire x1="12.573" y1="4.572" x2="12.573" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="5.08" y2="2.921" width="0.0508" layer="21"/>
<wire x1="-11.43" y1="3.683" x2="-8.382" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-3.683" x2="-11.43" y2="3.683" width="0.1524" layer="21"/>
<wire x1="11.43" y1="3.683" x2="11.43" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="0" x2="5.207" y2="0" width="0.0508" layer="21"/>
<wire x1="12.573" y1="-4.572" x2="5.08" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.048" x2="5.08" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.048" x2="-5.08" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.572" x2="-12.573" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="4.572" x2="-5.08" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.572" x2="5.08" y2="3.683" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.572" x2="12.573" y2="4.572" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.683" x2="6.858" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="6.858" y1="-4.191" x2="6.858" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="6.858" y1="-4.191" x2="8.382" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.382" y1="-3.683" x2="8.382" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.382" y1="-3.683" x2="11.43" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.683" x2="6.858" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.858" y1="4.191" x2="6.858" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.858" y1="4.191" x2="8.382" y2="4.191" width="0.1524" layer="21"/>
<wire x1="8.382" y1="3.683" x2="8.382" y2="4.191" width="0.1524" layer="21"/>
<wire x1="8.382" y1="3.683" x2="11.43" y2="3.683" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.683" x2="5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.683" x2="5.08" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.08" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.683" x2="-5.08" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.572" x2="-5.08" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.683" x2="-5.08" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="3.683" x2="-5.08" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="4.191" x2="-6.858" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="4.191" x2="-6.858" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="3.683" x2="-8.382" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="-3.683" x2="-5.08" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="-4.191" x2="-6.858" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-4.191" x2="-6.858" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-3.683" x2="-8.382" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-3.683" x2="-11.43" y2="-3.683" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2" x="7.62" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="-4.4196" y="3.6068" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.4196" y="-5.461" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="1.651" x2="5.08" y2="2.159" layer="21"/>
<rectangle x1="-5.08" y1="-2.159" x2="5.08" y2="-1.651" layer="21"/>
<rectangle x1="5.08" y1="-3.175" x2="5.715" y2="-1.524" layer="21"/>
<rectangle x1="5.08" y1="1.524" x2="5.715" y2="3.175" layer="21"/>
<rectangle x1="5.08" y1="-1.524" x2="5.715" y2="1.524" layer="51"/>
<rectangle x1="10.287" y1="-2.032" x2="10.541" y2="2.032" layer="21"/>
<rectangle x1="6.731" y1="1.905" x2="8.509" y2="2.032" layer="51"/>
<rectangle x1="6.731" y1="-2.032" x2="8.509" y2="-1.905" layer="51"/>
<rectangle x1="5.715" y1="2.032" x2="10.541" y2="3.175" layer="21"/>
<rectangle x1="5.715" y1="-3.175" x2="10.541" y2="-2.032" layer="21"/>
<rectangle x1="7.112" y1="-3.937" x2="8.128" y2="-3.175" layer="21"/>
<rectangle x1="7.112" y1="3.175" x2="8.128" y2="3.937" layer="21"/>
<rectangle x1="-5.715" y1="-1.524" x2="-5.08" y2="1.524" layer="51"/>
<rectangle x1="-5.715" y1="1.524" x2="-5.08" y2="3.175" layer="21"/>
<rectangle x1="-5.715" y1="-3.175" x2="-5.08" y2="-1.524" layer="21"/>
<rectangle x1="-10.541" y1="-3.175" x2="-5.715" y2="-2.032" layer="21"/>
<rectangle x1="-8.509" y1="-2.032" x2="-6.731" y2="-1.905" layer="51"/>
<rectangle x1="-10.541" y1="-2.032" x2="-10.287" y2="2.032" layer="21"/>
<rectangle x1="-8.509" y1="1.905" x2="-6.731" y2="2.032" layer="51"/>
<rectangle x1="-10.541" y1="2.032" x2="-5.715" y2="3.175" layer="21"/>
<rectangle x1="-8.128" y1="3.175" x2="-7.112" y2="3.937" layer="21"/>
<rectangle x1="-8.128" y1="-3.937" x2="-7.112" y2="-3.175" layer="21"/>
<rectangle x1="5.715" y1="-2.032" x2="6.731" y2="-1.905" layer="21"/>
<rectangle x1="5.715" y1="1.905" x2="6.731" y2="2.032" layer="21"/>
<rectangle x1="8.509" y1="1.905" x2="10.287" y2="2.032" layer="21"/>
<rectangle x1="8.509" y1="-2.032" x2="10.287" y2="-1.905" layer="21"/>
<rectangle x1="-10.287" y1="1.905" x2="-8.509" y2="2.032" layer="21"/>
<rectangle x1="-6.731" y1="1.905" x2="-5.715" y2="2.032" layer="21"/>
<rectangle x1="-6.731" y1="-2.032" x2="-5.715" y2="-1.905" layer="21"/>
<rectangle x1="-10.287" y1="-2.032" x2="-8.509" y2="-1.905" layer="21"/>
<hole x="0" y="0" drill="2.794"/>
</package>
<package name="KS10H" urn="urn:adsk.eagle:footprint:14031/1" library_version="1">
<wire x1="-5.08" y1="-7.62" x2="-5.08" y2="17.78" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="17.78" x2="-4.445" y2="17.78" width="0.1524" layer="21"/>
<wire x1="5.08" y1="17.78" x2="5.08" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-7.62" x2="2.032" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-7.62" x2="-5.08" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="17.78" x2="-4.445" y2="19.177" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="17.78" x2="4.445" y2="17.78" width="0.1524" layer="21"/>
<wire x1="4.445" y1="17.78" x2="4.445" y2="19.177" width="0.1524" layer="21"/>
<wire x1="4.445" y1="17.78" x2="5.08" y2="17.78" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="19.177" x2="4.826" y2="19.177" width="0.1524" layer="21"/>
<wire x1="4.826" y1="19.177" x2="4.826" y2="19.812" width="0.1524" layer="21"/>
<wire x1="4.826" y1="19.812" x2="-4.826" y2="19.812" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="19.812" x2="-4.826" y2="19.177" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="19.812" x2="-4.699" y2="24.892" width="0.1524" layer="21"/>
<wire x1="4.572" y1="24.892" x2="4.826" y2="19.812" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="25.4" x2="-0.635" y2="25.4" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="25.4" x2="-0.635" y2="24.765" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="24.765" x2="0.635" y2="24.765" width="0.1524" layer="21"/>
<wire x1="0.635" y1="24.765" x2="0.635" y2="25.4" width="0.1524" layer="21"/>
<wire x1="0.635" y1="25.4" x2="4.064" y2="25.4" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-7.62" x2="2.032" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-7.62" x2="-2.032" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-6.096" x2="-2.032" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="-5.08" x2="2.032" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-5.08" x2="2.032" y2="-6.096" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-5.207" x2="1.397" y2="-5.207" width="0.1524" layer="51"/>
<wire x1="4.064" y1="25.4" x2="4.572" y2="24.892" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.699" y1="24.892" x2="-4.191" y2="25.4" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="0" y="-5.08" drill="1.3208" diameter="2.54" shape="long"/>
<pad name="2" x="0" y="7.62" drill="1.3208" diameter="2.54" shape="long"/>
<text x="7.239" y="-7.62" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.239" y="0.635" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="2.032" y1="-7.62" x2="3.302" y2="17.78" layer="21"/>
<rectangle x1="-3.302" y1="-7.62" x2="-2.032" y2="17.78" layer="21"/>
<rectangle x1="-4.445" y1="17.78" x2="4.445" y2="19.177" layer="21"/>
</package>
<package name="KS16" urn="urn:adsk.eagle:footprint:14032/1" library_version="1">
<wire x1="-5.08" y1="-19.05" x2="-5.08" y2="16.51" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="16.51" x2="-4.445" y2="16.51" width="0.1524" layer="21"/>
<wire x1="5.08" y1="16.51" x2="5.08" y2="-19.05" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="16.51" x2="-4.445" y2="17.145" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="16.51" x2="4.445" y2="16.51" width="0.1524" layer="21"/>
<wire x1="4.445" y1="16.51" x2="4.445" y2="17.145" width="0.1524" layer="21"/>
<wire x1="4.445" y1="16.51" x2="5.08" y2="16.51" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="17.145" x2="-0.6096" y2="17.145" width="0.1524" layer="21"/>
<wire x1="-0.6096" y1="17.145" x2="-0.6096" y2="16.8402" width="0.1524" layer="21"/>
<wire x1="-0.6096" y1="16.8402" x2="0.635" y2="16.8402" width="0.1524" layer="21"/>
<wire x1="0.635" y1="16.8402" x2="0.635" y2="17.145" width="0.1524" layer="21"/>
<wire x1="4.445" y1="17.145" x2="0.635" y2="17.145" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-19.05" x2="1.651" y2="-19.05" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-19.05" x2="-1.651" y2="-19.05" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-19.05" x2="-5.08" y2="-19.05" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-17.78" drill="1.4986" diameter="2.54" shape="long"/>
<pad name="2" x="0" y="-8.255" drill="1.4986" diameter="2.54" shape="long"/>
<text x="7.366" y="-19.05" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="0.889" y="-2.54" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-4.445" y1="16.51" x2="-0.635" y2="17.145" layer="21"/>
<rectangle x1="-0.635" y1="16.51" x2="0.635" y2="16.8402" layer="21"/>
<rectangle x1="0.635" y1="16.51" x2="4.445" y2="17.145" layer="21"/>
<rectangle x1="3.175" y1="-19.05" x2="4.1402" y2="16.51" layer="21"/>
<rectangle x1="-4.1402" y1="-19.05" x2="-3.175" y2="16.51" layer="21"/>
</package>
<package name="KS17" urn="urn:adsk.eagle:footprint:14033/1" library_version="1">
<wire x1="-3.81" y1="-6.35" x2="-3.81" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-6.35" x2="3.81" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.985" x2="3.81" y2="6.985" width="0.1524" layer="21"/>
<wire x1="3.81" y1="6.985" x2="3.81" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.985" x2="-3.81" y2="6.35" width="0.1524" layer="21"/>
<wire x1="3.81" y1="6.35" x2="3.81" y2="-6.35" width="0.1524" layer="21" curve="-118.072487"/>
<wire x1="-3.81" y1="-6.35" x2="-3.81" y2="6.35" width="0.1524" layer="21" curve="-118.072487"/>
<wire x1="-3.175" y1="0.381" x2="-3.175" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.381" x2="3.175" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.381" x2="3.175" y2="0.381" width="0.1524" layer="21"/>
<wire x1="3.175" y1="0.381" x2="-3.175" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.2223" y1="-4.5681" x2="5.08" y2="0" width="0.3048" layer="21" curve="64.057726"/>
<wire x1="2.2718" y1="4.5437" x2="5.08" y2="0" width="0.3048" layer="21" curve="-63.435374"/>
<wire x1="-2.2718" y1="4.5437" x2="0" y2="5.08" width="0.3048" layer="51" curve="-26.564517"/>
<wire x1="0" y1="5.08" x2="2.2718" y2="4.5437" width="0.3048" layer="51" curve="-26.564517"/>
<wire x1="-5.08" y1="0" x2="-2.2718" y2="-4.5437" width="0.3048" layer="21" curve="63.435374"/>
<wire x1="-5.08" y1="0" x2="-2.2223" y2="4.5681" width="0.3048" layer="21" curve="-64.057726"/>
<wire x1="0" y1="-5.08" x2="2.2718" y2="-4.5437" width="0.3048" layer="51" curve="26.564517"/>
<wire x1="-2.2718" y1="-4.5437" x2="0" y2="-5.08" width="0.3048" layer="51" curve="26.564517"/>
<wire x1="3.81" y1="-6.985" x2="1.016" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-6.985" x2="-1.016" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-6.985" x2="-3.81" y2="-6.985" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-5.08" drill="1.4986" diameter="2.54" shape="long"/>
<pad name="2" x="0" y="4.445" drill="1.4986" diameter="2.54" shape="long"/>
<text x="-3.81" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-2.667" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="KS9V" urn="urn:adsk.eagle:footprint:14049/1" library_version="1">
<wire x1="-1.8331" y1="-4.3286" x2="1.8331" y2="-4.3286" width="0.1524" layer="51" curve="45.903921"/>
<wire x1="-1.6181" y1="-4.8154" x2="1.6181" y2="-4.8154" width="0.1524" layer="51" curve="37.147383"/>
<wire x1="-1.42" y1="-5.08" x2="1.42" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-1.2381" y1="-2.3622" x2="1.2381" y2="-2.3622" width="0.1524" layer="51" curve="55.320768"/>
<wire x1="-1.2381" y1="2.3622" x2="1.2381" y2="2.3622" width="0.1524" layer="51" curve="-55.320768"/>
<wire x1="-1.3394" y1="5.1647" x2="1.3394" y2="5.1647" width="0.1524" layer="51" curve="-29.077303"/>
<wire x1="-2.556" y1="0.762" x2="2.556" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.556" y1="-0.762" x2="2.556" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-1.6181" y1="4.8154" x2="1.6181" y2="4.8154" width="0.1524" layer="51" curve="-37.147383"/>
<wire x1="-1.8331" y1="4.3286" x2="1.8331" y2="4.3286" width="0.1524" layer="51" curve="-45.903921"/>
<wire x1="-3.683" y1="-3.861" x2="-1.3394" y2="5.1642" width="0.1524" layer="21" curve="-121.809325"/>
<wire x1="-1.6181" y1="4.8154" x2="-1.6181" y2="-4.8154" width="0.1524" layer="21" curve="142.852617"/>
<wire x1="-1.8331" y1="4.3286" x2="-1.8331" y2="-4.3286" width="0.1524" layer="21" curve="134.096079"/>
<wire x1="-1.2381" y1="2.3622" x2="-1.2381" y2="-2.3622" width="0.1524" layer="21" curve="124.679232"/>
<wire x1="-3.683" y1="-4.826" x2="-3.683" y2="-3.861" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-5.08" x2="-1.42" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="-4.826" x2="-3.429" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="1.3394" y1="5.1642" x2="3.683" y2="-3.861" width="0.1524" layer="21" curve="-121.809325"/>
<wire x1="1.2381" y1="-2.3622" x2="1.2381" y2="2.3622" width="0.1524" layer="21" curve="124.679232"/>
<wire x1="1.8331" y1="-4.3286" x2="1.8331" y2="4.3286" width="0.1524" layer="21" curve="134.096079"/>
<wire x1="1.6181" y1="-4.8154" x2="1.6181" y2="4.8154" width="0.1524" layer="21" curve="142.852617"/>
<wire x1="3.683" y1="-4.826" x2="3.683" y2="-3.861" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-5.08" x2="3.683" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="1.42" y1="-5.08" x2="3.429" y2="-5.08" width="0.1524" layer="21"/>
<pad name="1" x="0" y="3.81" drill="1.3208" diameter="2.54" shape="long"/>
<pad name="2" x="0" y="-3.81" drill="1.3208" diameter="2.54" shape="long"/>
<text x="-2.54" y="5.588" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LITTLEFUSE" urn="urn:adsk.eagle:footprint:14040/1" library_version="1">
<description>&lt;B&gt;LITTLEFUSE&lt;/B&gt;&lt;p&gt;
Picofuse/slow Littelfuse</description>
<wire x1="5.08" y1="0" x2="3.937" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.937" y2="0" width="0.6096" layer="51"/>
<wire x1="2.667" y1="1.778" x2="-2.667" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.778" x2="-2.667" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0.254" x2="-0.762" y2="-0.254" width="0.0508" layer="21"/>
<wire x1="-2.667" y1="1.016" x2="-2.667" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="2.667" y1="1.016" x2="2.667" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="0.762" y1="0.254" x2="0.762" y2="-0.254" width="0.0508" layer="21"/>
<wire x1="3.556" y1="0.508" x2="3.556" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.778" x2="3.556" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.667" y1="1.778" x2="3.556" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.778" x2="-3.556" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0.508" x2="-3.556" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-0.508" x2="-2.667" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="1.524" y2="0" width="0.0508" layer="21"/>
<wire x1="-0.762" y1="0.254" x2="0.762" y2="0.254" width="0.0508" layer="21"/>
<wire x1="-0.762" y1="-0.254" x2="0.762" y2="-0.254" width="0.0508" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" diameter="1.778" shape="long" rot="R90"/>
<pad name="2" x="5.08" y="0" drill="0.8128" diameter="1.778" shape="long" rot="R90"/>
<text x="-2.54" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.667" y="-3.4798" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.556" y1="-0.3048" x2="3.9116" y2="0.3048" layer="21"/>
<rectangle x1="-3.9116" y1="-0.3048" x2="-3.556" y2="0.3048" layer="21"/>
</package>
<package name="PICOFUSE" urn="urn:adsk.eagle:footprint:14036/1" library_version="1">
<description>&lt;B&gt;PICOFUSE&lt;/B&gt;&lt;p&gt;
Picofuse, 19275 Wickmann</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.794" y1="1.27" x2="-1.524" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.016" x2="-1.524" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-1.27" x2="-1.524" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.016" x2="-1.524" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.016" x2="1.524" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.016" x2="-1.27" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.016" x2="1.524" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.016" x2="-1.27" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.27" x2="1.524" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-1.27" x2="1.524" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.016" x2="-1.524" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="-2.794" y1="1.016" x2="-2.794" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="2.794" y1="1.016" x2="2.794" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="1.524" y1="1.016" x2="1.524" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="3.81" y1="0.508" x2="3.81" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.508" x2="3.556" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-1.27" x2="3.556" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.508" x2="3.556" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.27" x2="3.556" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.27" x2="-3.556" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0.508" x2="-3.81" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.508" x2="-3.81" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.508" x2="-3.556" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-0.508" x2="-2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.0508" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.8448" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.81" y1="-0.3048" x2="4.1656" y2="0.3048" layer="21"/>
<rectangle x1="-4.1656" y1="-0.3048" x2="-3.81" y2="0.3048" layer="21"/>
</package>
<package name="SH22" urn="urn:adsk.eagle:footprint:14037/1" library_version="1">
CS PFP30, Schukat</description>
<wire x1="-13.208" y1="-4.826" x2="13.208" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="13.208" y1="4.826" x2="13.208" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="13.208" y1="4.826" x2="-13.208" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-13.208" y1="-4.826" x2="-13.208" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<pad name="1" x="-10.9982" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2" x="10.9982" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="-13.208" y="-6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-6.985" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-13.208" y1="3.937" x2="13.208" y2="4.826" layer="21"/>
<rectangle x1="-13.208" y1="-4.826" x2="13.208" y2="-3.937" layer="21"/>
</package>
<package name="SH22,5" urn="urn:adsk.eagle:footprint:14030/1" library_version="1">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; grid 22,5 mm, OGN0031 8201 Schurter (Buerklin)</description>
<wire x1="-12.573" y1="-3.937" x2="12.573" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="12.573" y1="3.937" x2="-12.573" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.0508" layer="21"/>
<wire x1="-10.795" y1="3.683" x2="-5.715" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.683" x2="-10.795" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.683" x2="-10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.54" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-3.683" x2="-10.795" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-3.683" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.683" x2="-11.43" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-3.683" x2="-11.43" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-11.176" y1="-2.032" x2="-11.176" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-11.176" y1="-3.175" x2="-10.795" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.175" x2="-10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-5.715" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.032" x2="-11.43" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="-1.27" x2="-11.176" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.176" y1="-1.27" x2="-11.176" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="10.795" y1="-3.683" x2="5.715" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.683" x2="10.795" y2="3.175" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.54" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.683" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="3.683" x2="10.795" y2="3.683" width="0.1524" layer="21"/>
<wire x1="5.715" y1="3.683" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.683" x2="11.43" y2="3.683" width="0.1524" layer="21"/>
<wire x1="11.43" y1="3.683" x2="11.43" y2="2.032" width="0.1524" layer="21"/>
<wire x1="11.176" y1="2.032" x2="11.176" y2="3.175" width="0.1524" layer="21"/>
<wire x1="11.176" y1="3.175" x2="10.795" y2="3.175" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.175" x2="10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="5.715" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.032" x2="11.43" y2="1.27" width="0.1524" layer="51"/>
<wire x1="11.43" y1="1.27" x2="11.176" y2="1.27" width="0.1524" layer="51"/>
<wire x1="11.176" y1="1.27" x2="11.176" y2="2.032" width="0.1524" layer="51"/>
<wire x1="12.573" y1="3.937" x2="12.573" y2="1.651" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-1.651" x2="12.573" y2="1.651" width="0.1524" layer="51"/>
<wire x1="12.573" y1="-1.651" x2="12.573" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="3.937" x2="-12.573" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-1.651" x2="-12.573" y2="1.651" width="0.1524" layer="51"/>
<wire x1="-12.573" y1="-1.651" x2="-12.573" y2="-3.937" width="0.1524" layer="21"/>
<pad name="1" x="-11.2522" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2" x="11.2522" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="-12.7" y="-6.096" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="1.143" y="-6.096" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.541" y1="-2.032" x2="-10.16" y2="2.032" layer="51"/>
<rectangle x1="-10.541" y1="1.905" x2="-9.652" y2="2.032" layer="51"/>
<rectangle x1="-10.541" y1="-2.032" x2="-9.652" y2="-1.905" layer="51"/>
<rectangle x1="-5.715" y1="-3.175" x2="-5.08" y2="-2.032" layer="21"/>
<rectangle x1="-5.715" y1="2.032" x2="-5.08" y2="3.175" layer="21"/>
<rectangle x1="-5.715" y1="-2.032" x2="-5.08" y2="2.032" layer="21"/>
<rectangle x1="10.16" y1="-2.032" x2="10.541" y2="2.032" layer="51"/>
<rectangle x1="9.652" y1="-2.032" x2="10.541" y2="-1.905" layer="51"/>
<rectangle x1="9.652" y1="1.905" x2="10.541" y2="2.032" layer="51"/>
<rectangle x1="5.08" y1="2.032" x2="5.715" y2="3.175" layer="21"/>
<rectangle x1="5.08" y1="-3.175" x2="5.715" y2="-2.032" layer="21"/>
<rectangle x1="5.08" y1="-2.032" x2="5.715" y2="2.032" layer="21"/>
<rectangle x1="-5.08" y1="2.159" x2="5.08" y2="2.667" layer="21"/>
<rectangle x1="-5.08" y1="-2.667" x2="5.08" y2="-2.159" layer="21"/>
<rectangle x1="5.715" y1="-2.032" x2="9.652" y2="-1.905" layer="21"/>
<rectangle x1="5.715" y1="1.905" x2="9.652" y2="2.032" layer="21"/>
<rectangle x1="-9.652" y1="1.905" x2="-5.715" y2="2.032" layer="21"/>
<rectangle x1="-9.652" y1="-2.032" x2="-5.715" y2="-1.905" layer="21"/>
<rectangle x1="-10.541" y1="-2.54" x2="-5.715" y2="-2.032" layer="21"/>
<rectangle x1="-10.541" y1="2.032" x2="-5.715" y2="2.54" layer="21"/>
<rectangle x1="5.715" y1="2.032" x2="10.541" y2="2.54" layer="21"/>
<rectangle x1="5.715" y1="-2.54" x2="10.541" y2="-2.032" layer="21"/>
</package>
<package name="SH22,5A" urn="urn:adsk.eagle:footprint:14045/1" library_version="1">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; grid 22,5 mm, isolated cap&lt;p&gt; OGN0031 8201 Schurter (Buerklin)</description>
<wire x1="-12.573" y1="-5.461" x2="12.573" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="12.573" y1="5.461" x2="-12.573" y2="5.461" width="0.1524" layer="21"/>
<wire x1="12.573" y1="5.461" x2="12.573" y2="1.651" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-1.651" x2="12.573" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="5.461" x2="-12.573" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-1.651" x2="-12.573" y2="-5.461" width="0.1524" layer="21"/>
<text x="-12.7" y="-7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="0.0254" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SH25" urn="urn:adsk.eagle:footprint:14042/1" library_version="1">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; grid 2,5 mm,  OGN0031 8211 Schurter (Buerklin)</description>
<wire x1="-13.081" y1="-5.461" x2="13.081" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="13.081" y1="5.461" x2="-13.081" y2="5.461" width="0.1524" layer="21"/>
<wire x1="13.081" y1="5.461" x2="13.081" y2="2.032" width="0.1524" layer="21"/>
<wire x1="13.081" y1="-2.032" x2="13.081" y2="2.032" width="0.1524" layer="51"/>
<wire x1="13.081" y1="-2.032" x2="13.081" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="-13.081" y1="5.461" x2="-13.081" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-13.081" y1="-2.032" x2="-13.081" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-13.081" y1="-2.032" x2="-13.081" y2="-5.461" width="0.1524" layer="21"/>
<pad name="1" x="-12.5222" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2" x="12.5222" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="0" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.541" y1="-2.032" x2="-10.16" y2="2.032" layer="21"/>
<rectangle x1="-10.541" y1="1.905" x2="-9.652" y2="2.032" layer="21"/>
<rectangle x1="-10.541" y1="-2.032" x2="-9.652" y2="-1.905" layer="21"/>
<rectangle x1="10.16" y1="-2.032" x2="10.541" y2="2.032" layer="21"/>
<rectangle x1="9.652" y1="-2.032" x2="10.541" y2="-1.905" layer="21"/>
<rectangle x1="9.652" y1="1.905" x2="10.541" y2="2.032" layer="21"/>
</package>
<package name="SH32" urn="urn:adsk.eagle:footprint:14044/1" library_version="1">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; 6 x 32 mm, SH contact, SHH3N Schukat / Wickmann 102071 (Buerklin)</description>
<wire x1="9.017" y1="3.81" x2="9.525" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="3.556" x2="8.89" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.89" y1="3.556" x2="9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="9.017" y1="-3.81" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="9.017" y1="-3.556" x2="8.89" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-3.556" x2="-8.89" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="9.017" y1="3.556" x2="9.017" y2="3.81" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-3.81" x2="9.525" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-3.81" x2="9.017" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-4.445" x2="16.764" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="16.764" y1="4.445" x2="9.525" y2="4.445" width="0.1524" layer="21"/>
<wire x1="9.525" y1="3.81" x2="9.525" y2="4.445" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-3.81" x2="9.525" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="9.525" y1="3.81" x2="9.525" y2="2.794" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-2.794" x2="16.002" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.794" x2="16.002" y2="2.794" width="0.1524" layer="21"/>
<wire x1="16.764" y1="-2.032" x2="16.764" y2="2.032" width="0.1524" layer="51"/>
<wire x1="16.002" y1="-2.032" x2="16.002" y2="2.032" width="0.1524" layer="51"/>
<wire x1="9.017" y1="-2.032" x2="9.017" y2="0" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-2.032" x2="16.764" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="16.764" y1="-2.794" x2="16.764" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="16.002" y1="-2.032" x2="16.002" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="16.002" y1="-2.794" x2="16.764" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="16.764" y1="4.445" x2="16.764" y2="2.794" width="0.1524" layer="21"/>
<wire x1="16.764" y1="2.794" x2="16.764" y2="2.032" width="0.1524" layer="21"/>
<wire x1="16.002" y1="2.032" x2="16.002" y2="2.794" width="0.1524" layer="21"/>
<wire x1="16.002" y1="2.794" x2="16.764" y2="2.794" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="9.017" y1="-2.032" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="9.017" y1="0" x2="6.985" y2="0" width="0.0508" layer="51"/>
<wire x1="9.017" y1="0" x2="9.017" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-9.017" y1="-3.81" x2="-9.525" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-3.556" x2="-9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="3.81" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="3.556" x2="8.89" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="3.81" x2="-9.525" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="3.81" x2="-9.017" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="4.445" x2="-16.764" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-4.445" x2="-9.525" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-3.81" x2="-9.525" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="3.81" x2="-9.525" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-3.81" x2="-9.525" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.794" x2="-16.002" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-2.794" x2="-16.002" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="2.032" x2="-16.764" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-16.002" y1="2.032" x2="-16.002" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-9.017" y1="2.032" x2="-9.017" y2="0" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="2.032" x2="-16.764" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="2.794" x2="-16.764" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="2.032" x2="-16.002" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="2.794" x2="-16.764" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-4.445" x2="-16.764" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-2.794" x2="-16.764" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-2.032" x2="-16.002" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-2.794" x2="-16.764" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="2.032" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="0" x2="-6.985" y2="0" width="0.0508" layer="51"/>
<wire x1="-9.017" y1="0" x2="-9.017" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="0" x2="6.985" y2="0" width="0.0508" layer="21"/>
<pad name="2B" x="16.764" y="0" drill="2.0066" shape="long" rot="R90"/>
<pad name="2A" x="9.144" y="0" drill="2.0066" shape="long" rot="R90"/>
<pad name="1A" x="-16.764" y="0" drill="2.0066" shape="long" rot="R90"/>
<pad name="1B" x="-9.144" y="0" drill="2.0066" shape="long" rot="R90"/>
<text x="-7.62" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.62" y="-5.334" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="9.017" y1="-3.81" x2="9.525" y2="-2.159" layer="21"/>
<rectangle x1="9.017" y1="2.159" x2="9.525" y2="3.81" layer="21"/>
<rectangle x1="9.017" y1="-2.159" x2="9.525" y2="2.159" layer="51"/>
<rectangle x1="-9.525" y1="-3.81" x2="-9.017" y2="-2.159" layer="21"/>
<rectangle x1="-9.525" y1="2.159" x2="-9.017" y2="3.81" layer="21"/>
<rectangle x1="-9.525" y1="-2.159" x2="-9.017" y2="2.159" layer="51"/>
</package>
<package name="SHK20L" urn="urn:adsk.eagle:footprint:14046/1" library_version="1">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; 5 x 20 mm, SH contact, SHH1 Schukat / E1073 Buerklin</description>
<wire x1="-5.334" y1="2.921" x2="5.334" y2="2.921" width="0.0508" layer="21"/>
<wire x1="-3.302" y1="0" x2="3.302" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-5.969" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.683" x2="-10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-2.54" x2="-5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.54" x2="-5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-3.683" x2="-10.414" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-3.683" x2="-5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.683" x2="-11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-3.683" x2="-11.049" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.032" x2="-10.795" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.429" x2="-10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.429" x2="-10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="2.54" x2="-5.969" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-2.032" x2="-11.049" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-1.27" x2="-10.795" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-10.795" y1="-1.27" x2="-10.795" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0" x2="-5.334" y2="0" width="0.1524" layer="51"/>
<wire x1="5.334" y1="-2.921" x2="-5.334" y2="-2.921" width="0.0508" layer="21"/>
<wire x1="10.414" y1="-3.683" x2="5.969" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.683" x2="10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="2.54" x2="5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-3.683" x2="10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.54" x2="5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.969" y1="3.683" x2="10.414" y2="3.683" width="0.1524" layer="21"/>
<wire x1="5.969" y1="3.683" x2="5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.683" x2="11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="11.049" y1="3.683" x2="11.049" y2="2.032" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.032" x2="10.795" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.429" x2="10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.429" x2="10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-2.54" x2="5.969" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="11.049" y1="2.032" x2="11.049" y2="1.27" width="0.1524" layer="51"/>
<wire x1="11.049" y1="1.27" x2="10.795" y2="1.27" width="0.1524" layer="51"/>
<wire x1="10.795" y1="1.27" x2="10.795" y2="2.032" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0" x2="5.334" y2="0" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-3.683" x2="11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-2.032" x2="11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.429" x2="10.795" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.429" x2="10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-3.429" x2="10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.049" y1="1.27" x2="11.049" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="10.795" y1="1.27" x2="10.795" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-10.795" y1="2.032" x2="-10.795" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="2.032" x2="-11.049" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="3.683" x2="-11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.429" x2="-10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.429" x2="-10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.429" x2="-10.795" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="2.032" x2="-11.049" y2="3.683" width="0.1524" layer="21"/>
<pad name="1A" x="-10.414" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2A" x="10.414" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2B" x="5.334" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="1B" x="-5.334" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="-3.81" y="3.175" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.033" y1="-2.032" x2="-9.652" y2="2.032" layer="51"/>
<rectangle x1="-5.969" y1="-3.175" x2="-5.334" y2="-2.032" layer="21"/>
<rectangle x1="-5.969" y1="2.032" x2="-5.334" y2="3.175" layer="21"/>
<rectangle x1="-5.969" y1="-2.032" x2="-5.334" y2="2.032" layer="51"/>
<rectangle x1="9.652" y1="-2.032" x2="10.033" y2="2.032" layer="51"/>
<rectangle x1="5.334" y1="2.032" x2="5.969" y2="3.175" layer="21"/>
<rectangle x1="5.334" y1="-3.175" x2="5.969" y2="-2.032" layer="21"/>
<rectangle x1="5.334" y1="-2.032" x2="5.969" y2="2.032" layer="51"/>
<rectangle x1="4.064" y1="1.651" x2="5.334" y2="2.159" layer="51"/>
<rectangle x1="4.064" y1="-2.159" x2="5.334" y2="-1.651" layer="51"/>
<rectangle x1="-5.334" y1="1.651" x2="-4.064" y2="2.159" layer="51"/>
<rectangle x1="-5.334" y1="-2.159" x2="-4.064" y2="-1.651" layer="51"/>
<rectangle x1="-10.414" y1="-2.54" x2="-5.969" y2="-2.032" layer="21"/>
<rectangle x1="-4.064" y1="-2.159" x2="4.064" y2="-1.651" layer="21"/>
<rectangle x1="-4.064" y1="1.651" x2="4.064" y2="2.159" layer="21"/>
<rectangle x1="-6.223" y1="1.905" x2="-5.969" y2="2.032" layer="51"/>
<rectangle x1="5.969" y1="1.905" x2="6.223" y2="2.032" layer="51"/>
<rectangle x1="5.969" y1="-2.032" x2="6.223" y2="-1.905" layer="51"/>
<rectangle x1="9.398" y1="1.905" x2="9.652" y2="2.032" layer="51"/>
<rectangle x1="9.398" y1="-2.032" x2="9.652" y2="-1.905" layer="51"/>
<rectangle x1="6.223" y1="-2.032" x2="9.398" y2="-1.905" layer="21"/>
<rectangle x1="6.223" y1="1.905" x2="9.398" y2="2.032" layer="21"/>
<rectangle x1="5.969" y1="2.032" x2="10.033" y2="2.54" layer="21"/>
<rectangle x1="5.969" y1="-2.54" x2="10.033" y2="-2.032" layer="21"/>
<rectangle x1="-10.033" y1="2.032" x2="-5.969" y2="2.54" layer="21"/>
<rectangle x1="-9.398" y1="1.905" x2="-6.223" y2="2.032" layer="21"/>
<rectangle x1="-9.652" y1="1.905" x2="-9.398" y2="2.032" layer="51"/>
<rectangle x1="-6.223" y1="-2.032" x2="-5.969" y2="-1.905" layer="51"/>
<rectangle x1="-9.398" y1="-2.032" x2="-6.223" y2="-1.905" layer="21"/>
<rectangle x1="-9.652" y1="-2.032" x2="-9.398" y2="-1.905" layer="51"/>
</package>
<package name="SHK20Q" urn="urn:adsk.eagle:footprint:14047/1" library_version="1">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; 5 x 20 mm, SH contact, E1207 Buerklin 46G6061</description>
<wire x1="-9.652" y1="3.683" x2="-6.096" y2="3.683" width="0.1524" layer="51"/>
<wire x1="-9.906" y1="2.54" x2="-5.842" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-6.096" y1="-3.683" x2="-9.652" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="-5.842" y1="-3.683" x2="-5.842" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.54" x2="-5.842" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-3.683" x2="-11.049" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="0.889" x2="-10.795" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="0.889" x2="-10.795" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="-5.08" y2="0" width="0.0508" layer="21"/>
<wire x1="5.08" y1="-2.921" x2="-5.08" y2="-2.921" width="0.0508" layer="21"/>
<wire x1="9.652" y1="-3.683" x2="6.096" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="9.906" y1="2.54" x2="5.842" y2="2.54" width="0.1524" layer="51"/>
<wire x1="9.906" y1="-2.54" x2="5.842" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="6.096" y1="3.683" x2="9.652" y2="3.683" width="0.1524" layer="51"/>
<wire x1="5.842" y1="3.683" x2="5.842" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.54" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.429" x2="10.795" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="11.049" y1="3.683" x2="11.049" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.54" x2="-10.414" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.429" x2="-10.795" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="0.889" x2="-11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-0.889" x2="11.049" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-0.889" x2="10.795" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-0.889" x2="11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="9.906" y1="2.54" x2="10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.652" y1="3.683" x2="10.414" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.683" x2="5.842" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.683" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="9.652" y1="-3.683" x2="10.414" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-2.54" x2="10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.54" x2="10.414" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.683" x2="-5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-9.652" y1="-3.683" x2="-10.414" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-2.54" x2="-10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.54" x2="-9.906" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-9.652" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="3.683" x2="-5.842" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-2.54" x2="-5.842" y2="-2.54" width="0.1524" layer="51"/>
<pad name="1A" x="-7.874" y="2.54" drill="1.5" diameter="3.81" shape="octagon"/>
<pad name="2A" x="7.874" y="2.54" drill="1.5" diameter="3.81" shape="octagon"/>
<pad name="2B" x="7.874" y="-2.54" drill="1.5" diameter="3.81" shape="octagon"/>
<pad name="1B" x="-7.874" y="-2.54" drill="1.5" diameter="3.81" shape="octagon"/>
<text x="-3.81" y="3.302" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="5.08" y1="-3.175" x2="5.588" y2="3.175" layer="21"/>
<rectangle x1="10.795" y1="-0.889" x2="11.049" y2="3.683" layer="21"/>
<rectangle x1="-10.795" y1="-3.683" x2="-10.414" y2="-3.429" layer="21"/>
<rectangle x1="-5.588" y1="-3.175" x2="-5.08" y2="3.175" layer="21"/>
<rectangle x1="-11.049" y1="-3.683" x2="-10.795" y2="0.889" layer="21"/>
<rectangle x1="5.588" y1="-3.175" x2="5.842" y2="-2.159" layer="21"/>
<rectangle x1="5.588" y1="2.159" x2="5.842" y2="3.175" layer="21"/>
<rectangle x1="9.906" y1="-2.54" x2="10.16" y2="2.54" layer="21"/>
<rectangle x1="5.842" y1="-2.54" x2="9.906" y2="-2.159" layer="51"/>
<rectangle x1="5.842" y1="2.159" x2="9.906" y2="2.54" layer="51"/>
<rectangle x1="-10.16" y1="-2.54" x2="-9.906" y2="2.54" layer="21"/>
<rectangle x1="-9.906" y1="2.159" x2="-5.842" y2="2.54" layer="51"/>
<rectangle x1="-5.842" y1="2.159" x2="-5.588" y2="3.175" layer="21"/>
<rectangle x1="-9.906" y1="-2.54" x2="-5.842" y2="-2.159" layer="51"/>
<rectangle x1="-5.842" y1="-3.175" x2="-5.588" y2="-2.159" layer="21"/>
</package>
<package name="SHKOG" urn="urn:adsk.eagle:footprint:14048/1" library_version="1">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; 5 x 20/6 x 32 mm, SH contact, OG 46G6083 Buerklin</description>
<wire x1="-3.048" y1="0" x2="-5.08" y2="0" width="0.0508" layer="51"/>
<wire x1="9.144" y1="-3.683" x2="5.969" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="5.969" y1="3.683" x2="9.144" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="5.08" y2="0" width="0.0508" layer="21"/>
<wire x1="17.78" y1="3.683" x2="12.192" y2="3.683" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-3.683" x2="12.192" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="17.78" y1="3.683" x2="17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.144" y1="-3.683" x2="11.049" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="9.144" y1="3.683" x2="11.049" y2="3.683" width="0.1524" layer="51"/>
<wire x1="8.636" y1="-2.54" x2="5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-2.54" x2="11.049" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="12.192" y1="-2.54" x2="17.78" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-2.54" x2="17.78" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="17.78" y1="2.54" x2="12.192" y2="2.54" width="0.1524" layer="21"/>
<wire x1="17.78" y1="2.54" x2="17.78" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.192" y1="2.54" x2="11.049" y2="2.54" width="0.1524" layer="51"/>
<wire x1="8.636" y1="2.54" x2="5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.192" y1="-1.397" x2="12.192" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="12.192" y1="-3.683" x2="11.684" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="12.192" y1="1.397" x2="12.192" y2="3.683" width="0.1524" layer="21"/>
<wire x1="12.192" y1="3.683" x2="11.684" y2="3.683" width="0.1524" layer="21"/>
<wire x1="12.192" y1="1.397" x2="11.684" y2="1.397" width="0.1524" layer="21"/>
<wire x1="12.192" y1="-1.397" x2="11.684" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="11.684" y1="-1.397" x2="11.049" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="11.049" y1="-2.54" x2="11.049" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="11.049" y1="-2.54" x2="12.192" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="11.684" y1="1.397" x2="11.049" y2="1.397" width="0.1524" layer="51"/>
<wire x1="11.049" y1="2.54" x2="11.049" y2="1.397" width="0.1524" layer="51"/>
<wire x1="11.049" y1="2.54" x2="8.636" y2="2.54" width="0.1524" layer="51"/>
<wire x1="11.049" y1="-2.54" x2="11.049" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="11.049" y1="-3.683" x2="11.684" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="11.049" y1="2.54" x2="11.049" y2="3.683" width="0.1524" layer="51"/>
<wire x1="11.049" y1="3.683" x2="11.684" y2="3.683" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="2.921" x2="5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="3.683" x2="-5.969" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-3.683" x2="-9.144" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-3.683" x2="-12.192" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="3.683" x2="-12.192" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-3.683" x2="-17.78" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="3.683" x2="-11.049" y2="3.683" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-3.683" x2="-11.049" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="-8.636" y1="2.54" x2="-5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="2.54" x2="-11.049" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-12.192" y1="2.54" x2="-17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.54" x2="-17.78" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.54" x2="-12.192" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.54" x2="-17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.192" y1="-2.54" x2="-11.049" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-8.636" y1="-2.54" x2="-5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.192" y1="1.397" x2="-12.192" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-12.192" y1="3.683" x2="-11.684" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-12.192" y1="-1.397" x2="-12.192" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-12.192" y1="-3.683" x2="-11.684" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-12.192" y1="-1.397" x2="-11.684" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-12.192" y1="1.397" x2="-11.684" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="1.397" x2="-11.049" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="2.54" x2="-11.049" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="2.54" x2="-12.192" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-1.397" x2="-11.049" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-2.54" x2="-11.049" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-2.54" x2="-8.636" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="2.54" x2="-11.049" y2="3.683" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="3.683" x2="-11.684" y2="3.683" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-2.54" x2="-11.049" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-3.683" x2="-11.684" y2="-3.683" width="0.1524" layer="51"/>
<pad name="2B" x="10.414" y="-2.54" drill="1.3208" diameter="2.54" shape="long"/>
<pad name="2A" x="10.414" y="2.54" drill="1.3208" diameter="2.54" shape="long"/>
<pad name="1A" x="-10.414" y="2.54" drill="1.3208" diameter="2.54" shape="long"/>
<pad name="1B" x="-10.414" y="-2.54" drill="1.3208" diameter="2.54" shape="long"/>
<rectangle x1="16.637" y1="-2.54" x2="17.78" y2="-1.397" layer="21"/>
<rectangle x1="16.637" y1="1.397" x2="17.78" y2="2.54" layer="21"/>
<rectangle x1="11.049" y1="-2.54" x2="12.192" y2="-1.397" layer="51"/>
<rectangle x1="11.049" y1="1.397" x2="12.192" y2="2.54" layer="51"/>
<rectangle x1="5.715" y1="-2.54" x2="8.509" y2="-1.905" layer="21"/>
<rectangle x1="8.509" y1="-2.54" x2="10.16" y2="-1.905" layer="51"/>
<rectangle x1="5.715" y1="1.905" x2="8.509" y2="2.54" layer="21"/>
<rectangle x1="8.509" y1="1.905" x2="10.16" y2="2.54" layer="51"/>
<rectangle x1="-17.78" y1="1.397" x2="-16.637" y2="2.54" layer="21"/>
<rectangle x1="-17.78" y1="-2.54" x2="-16.637" y2="-1.397" layer="21"/>
<rectangle x1="-12.192" y1="1.397" x2="-11.049" y2="2.54" layer="51"/>
<rectangle x1="-12.192" y1="-2.54" x2="-11.049" y2="-1.397" layer="51"/>
<rectangle x1="-8.509" y1="1.905" x2="-5.715" y2="2.54" layer="21"/>
<rectangle x1="-10.16" y1="1.905" x2="-8.509" y2="2.54" layer="51"/>
<rectangle x1="-8.509" y1="-2.54" x2="-5.715" y2="-1.905" layer="21"/>
<rectangle x1="-10.16" y1="-2.54" x2="-8.509" y2="-1.905" layer="51"/>
<rectangle x1="9.779" y1="-0.889" x2="10.16" y2="0.889" layer="21"/>
<rectangle x1="9.779" y1="0.889" x2="10.16" y2="1.905" layer="51"/>
<rectangle x1="9.779" y1="-1.905" x2="10.16" y2="-0.889" layer="51"/>
<rectangle x1="-10.16" y1="-0.889" x2="-9.779" y2="0.889" layer="21"/>
<rectangle x1="-10.16" y1="0.889" x2="-9.779" y2="1.905" layer="51"/>
<rectangle x1="-10.16" y1="-1.905" x2="-9.779" y2="-0.889" layer="51"/>
<rectangle x1="5.08" y1="-3.175" x2="5.969" y2="3.175" layer="21"/>
<rectangle x1="-5.969" y1="-3.175" x2="-5.08" y2="3.175" layer="21"/>
</package>
<package name="TE5" urn="urn:adsk.eagle:footprint:14038/1" library_version="1">
<description>&lt;b&gt;FUSE&lt;/b&gt;&lt;p&gt;
<wire x1="3.683" y1="2.032" x2="4.318" y2="1.397" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.683" y1="-2.032" x2="4.318" y2="-1.397" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.318" y1="-1.397" x2="-3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.318" y1="1.397" x2="-3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.683" y1="2.032" x2="-3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.397" x2="-4.318" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="-2.032" x2="3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.397" x2="4.318" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="2.159" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-0.381" x2="1.27" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0.381" x2="1.27" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0.381" x2="-1.27" y2="0.381" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-4.191" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TR5" urn="urn:adsk.eagle:footprint:14034/1" library_version="1">
<circle x="0" y="0" radius="4.318" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.778" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.778" shape="long" rot="R90"/>
<text x="-2.54" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="19559" urn="urn:adsk.eagle:package:14056/1" type="box" library_version="1">
<description>FUSE HOLDER
TR5 Fuse Holder Wickmann</description>
<packageinstances>
<packageinstance name="19559"/>
</packageinstances>
</package3d>
<package3d name="19560" urn="urn:adsk.eagle:package:14057/1" type="box" library_version="1">
<packageinstances>
<packageinstance name="19560"/>
</packageinstances>
</package3d>
<package3d name="F456" urn="urn:adsk.eagle:package:14063/1" type="box" library_version="1">
CS Schukat</description>
<packageinstances>
<packageinstance name="F456"/>
</packageinstances>
</package3d>
<package3d name="F457" urn="urn:adsk.eagle:package:14076/1" type="box" library_version="1">
<packageinstances>
<packageinstance name="F457"/>
</packageinstances>
</package3d>
<package3d name="FUSE_HOLDER_5X20MM" urn="urn:adsk.eagle:package:14079/1" type="box" library_version="1">
<description>Fuse Holder 5x20 mm
Source: User LBR Version 2.05</description>
<packageinstances>
<packageinstance name="FUSE_HOLDER_5X20MM"/>
</packageinstances>
</package3d>
<package3d name="FUSE_HOLDER_MENTOR-1821" urn="urn:adsk.eagle:package:14077/1" type="box" library_version="1">
<description>Fuse Holder 5x20 mm Manufacturer: MENTOR Type: 1821
Distributor: Bürklin 46 G 6111
<packageinstances>
<packageinstance name="FUSE_HOLDER_MENTOR-1821"/>
</packageinstances>
</package3d>
<package3d name="FUSE_HOLDER_SCHURTER-FAS" urn="urn:adsk.eagle:package:14080/1" type="box" library_version="1">
<description>Fuse holder 5x20 mm Manufacturer: SCHURTER Type: FAS
<packageinstances>
<packageinstance name="FUSE_HOLDER_SCHURTER-FAS"/>
</packageinstances>
</package3d>
<package3d name="FUSE_HOLDER_WICKMANN-19596" urn="urn:adsk.eagle:package:14078/1" type="box" library_version="1">
<description>Fuse holder 5x20 mm Manufacturer: WICKMANN Type: 19596
Distributor: Bürklin 46 G 612
<packageinstances>
<packageinstance name="FUSE_HOLDER_WICKMANN-19596"/>
</packageinstances>
</package3d>
<package3d name="GSH15" urn="urn:adsk.eagle:package:14065/1" type="box" library_version="1">
<packageinstances>
<packageinstance name="GSH15"/>
</packageinstances>
</package3d>
<package3d name="KS10H" urn="urn:adsk.eagle:package:14058/1" type="box" library_version="1">
<packageinstances>
<packageinstance name="KS10H"/>
</packageinstances>
</package3d>
<package3d name="KS16" urn="urn:adsk.eagle:package:14060/1" type="box" library_version="1">
<packageinstances>
<packageinstance name="KS16"/>
</packageinstances>
</package3d>
<package3d name="KS17" urn="urn:adsk.eagle:package:14067/1" type="box" library_version="1">
<packageinstances>
<packageinstance name="KS17"/>
</packageinstances>
</package3d>
<package3d name="KS9V" urn="urn:adsk.eagle:package:14075/1" type="box" library_version="1">
<packageinstances>
<packageinstance name="KS9V"/>
</packageinstances>
</package3d>
<package3d name="LITTLEFUSE" urn="urn:adsk.eagle:package:14064/1" type="box" library_version="1">
<description>LITTLEFUSE
<packageinstances>
<packageinstance name="LITTLEFUSE"/>
</packageinstances>
</package3d>
<package3d name="PICOFUSE" urn="urn:adsk.eagle:package:14074/1" type="box" library_version="1">
<description>PICOFUSE
<packageinstances>
<packageinstance name="PICOFUSE"/>
</packageinstances>
</package3d>
<package3d name="SH22" urn="urn:adsk.eagle:package:14062/1" type="box" library_version="1">
<packageinstances>
<packageinstance name="SH22"/>
</packageinstances>
</package3d>
<package3d name="SH22,5" urn="urn:adsk.eagle:package:14059/1" type="box" library_version="1">
<description>FUSE HOLDER grid 22,5 mm, OGN0031 8201 Schurter (Buerklin)</description>
<packageinstances>
<packageinstance name="SH22,5"/>
</packageinstances>
</package3d>
<package3d name="SH22,5A" urn="urn:adsk.eagle:package:14070/1" type="box" library_version="1">
<description>FUSE HOLDER grid 22,5 mm, isolated cap OGN0031 8201 Schurter (Buerklin)</description>
<packageinstances>
<packageinstance name="SH22,5A"/>
</packageinstances>
</package3d>
<package3d name="SH25" urn="urn:adsk.eagle:package:14066/1" type="box" library_version="1">
<description>FUSE HOLDER grid 2,5 mm,  OGN0031 8211 Schurter (Buerklin)</description>
<packageinstances>
<packageinstance name="SH25"/>
</packageinstances>
</package3d>
<package3d name="SH32" urn="urn:adsk.eagle:package:14068/1" type="box" library_version="1">
<description>FUSE HOLDER 6 x 32 mm, SH contact, SHH3N Schukat / Wickmann 102071 (Buerklin)</description>
<packageinstances>
<packageinstance name="SH32"/>
</packageinstances>
</package3d>
<package3d name="SHK20L" urn="urn:adsk.eagle:package:14071/1" type="box" library_version="1">
<description>FUSE HOLDER 5 x 20 mm, SH contact, SHH1 Schukat / E1073 Buerklin</description>
<packageinstances>
<packageinstance name="SHK20L"/>
</packageinstances>
</package3d>
<package3d name="SHK20Q" urn="urn:adsk.eagle:package:14073/1" type="box" library_version="1">
<description>FUSE HOLDER 5 x 20 mm, SH contact, E1207 Buerklin 46G6061</description>
<packageinstances>
<packageinstance name="SHK20Q"/>
</packageinstances>
</package3d>
<package3d name="SHKOG" urn="urn:adsk.eagle:package:14072/1" type="box" library_version="1">
<description>FUSE HOLDER 5 x 20/6 x 32 mm, SH contact, OG 46G6083 Buerklin</description>
<packageinstances>
<packageinstance name="SHKOG"/>
</packageinstances>
</package3d>
<package3d name="TE5" urn="urn:adsk.eagle:package:14069/1" type="box" library_version="1">
<description>FUSE
<packageinstances>
<packageinstance name="TE5"/>
</packageinstances>
</package3d>
<package3d name="TR5" urn="urn:adsk.eagle:package:14061/1" type="box" library_version="1">
<description>FUSE
<packageinstances>
<packageinstance name="TR5"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="FUSE" urn="urn:adsk.eagle:symbol:14027/1" library_version="1">
<wire x1="-3.81" y1="-0.762" x2="3.81" y2="-0.762" width="0.254" layer="94"/>
<wire x1="3.81" y1="0.762" x2="-3.81" y2="0.762" width="0.254" layer="94"/>
<wire x1="3.81" y1="-0.762" x2="3.81" y2="0.762" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0.762" x2="-3.81" y2="-0.762" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<text x="-3.81" y="1.397" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-2.921" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="FUSE" urn="urn:adsk.eagle:component:14105/1" prefix="F" library_version="1">
<description>&lt;b&gt;Fuse&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="FUSE" x="0" y="0"/>
</gates>
<devices>
<device name="19559" package="19559">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14056/1"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="55900000001" constant="no"/>
<attribute name="OC_FARNELL" value="9516360" constant="no"/>
<attribute name="OC_NEWARK" value="02P0286" constant="no"/>
</technology>
</technologies>
</device>
<device name="19560" package="19560">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14057/1"/>
<technologies>
<attribute name="MPN" value="56000001009" constant="no"/>
<attribute name="OC_FARNELL" value="1185363" constant="no"/>
<attribute name="OC_NEWARK" value="98K6125" constant="no"/>
</technology>
</technologies>
</device>
<device name="F456" package="F456">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14063/1"/>
<technologies>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
<device name="F457" package="F457">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14076/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="BLANK_5X20MM" package="FUSE_HOLDER_5X20MM">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14079/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="1821" package="FUSE_HOLDER_MENTOR-1821">
<connects>
<connect gate="G$1" pin="1" pad="A"/>
<connect gate="G$1" pin="2" pad="B"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14077/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="FAS" package="FUSE_HOLDER_SCHURTER-FAS">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14080/1"/>
<technologies>
<attribute name="MPN" value="0031.3501" constant="no"/>
<attribute name="OC_FARNELL" value="1214778" constant="no"/>
<attribute name="OC_NEWARK" value="98K4273" constant="no"/>
</technology>
</technologies>
</device>
<device name="19596" package="FUSE_HOLDER_WICKMANN-19596">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14078/1"/>
<technologies>
<attribute name="OC_FARNELL" value="1271669" constant="no"/>
</technology>
</technologies>
</device>
<device name="GSH15" package="GSH15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14065/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="KS10H" package="KS10H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14058/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="KS16" package="KS16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14060/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="KS17" package="KS17">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14067/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="KS9V" package="KS9V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14075/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="LITTLEFUSE" package="LITTLEFUSE">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14064/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="PICOFUSE" package="PICOFUSE">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14074/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SH22" package="SH22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14062/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SH22,5" package="SH22,5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14059/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SH22,5A" package="SH22,5A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14070/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SH35" package="SH25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14066/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SH32" package="SH32">
<connects>
<connect gate="G$1" pin="1" pad="1A"/>
<connect gate="G$1" pin="2" pad="2A"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14068/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SHK20L" package="SHK20L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14071/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SHK20Q" package="SHK20Q">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14073/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SHKOG" package="SHKOG">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14072/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TE5" package="TE5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14069/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TR5" package="TR5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14061/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="rectifier" urn="urn:adsk.eagle:library:336">
<description>&lt;b&gt;Rectifiers&lt;/b&gt;&lt;p&gt;
General Instrument, Semikron, Diotec, Fagor&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="B-DIL" urn="urn:adsk.eagle:footprint:23824/1" library_version="1">
<description>&lt;b&gt;RECTIFIER&lt;/b&gt;</description>
<wire x1="4.699" y1="-2.921" x2="4.699" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.921" x2="-4.699" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="2.921" x2="-4.699" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.921" x2="-3.937" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="2.921" x2="-3.937" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-2.032" x2="-2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.524" x2="-2.54" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.032" x2="3.048" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-2.921" x2="4.699" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.921" x2="-3.937" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.413" x2="-2.5146" y2="2.413" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.5146" y1="2.413" x2="-1.8542" y2="2.413" width="0.1524" layer="21" curve="180"/>
<wire x1="2.5654" y1="2.413" x2="3.2258" y2="2.413" width="0.1524" layer="21" curve="180"/>
<wire x1="1.905" y1="2.413" x2="2.5654" y2="2.413" width="0.1524" layer="21" curve="-180"/>
<circle x="-2.54" y="-2.032" radius="0.635" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="-3.81" drill="0.8128"/>
<pad name="-" x="2.54" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="AC1" x="2.54" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="AC2" x="-2.54" y="3.81" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-2.921" y1="-3.81" x2="-2.159" y2="-2.921" layer="51"/>
<rectangle x1="2.159" y1="-3.81" x2="2.921" y2="-2.921" layer="51"/>
<rectangle x1="2.159" y1="2.921" x2="2.921" y2="3.81" layer="51"/>
<rectangle x1="-2.921" y1="2.921" x2="-2.159" y2="3.81" layer="51"/>
<rectangle x1="-3.175" y1="-3.175" x2="-1.905" y2="-2.921" layer="51"/>
<rectangle x1="1.905" y1="-3.175" x2="3.175" y2="-2.921" layer="51"/>
<rectangle x1="1.905" y1="2.921" x2="3.175" y2="3.175" layer="51"/>
<rectangle x1="-3.175" y1="2.921" x2="-1.905" y2="3.175" layer="51"/>
<rectangle x1="-4.445" y1="-3.175" x2="4.445" y2="3.175" layer="43"/>
</package>
</packages>
<packages3d>
<package3d name="B-DIL" urn="urn:adsk.eagle:package:23868/1" type="box" library_version="1">
<description>RECTIFIER</description>
<packageinstances>
<packageinstance name="B-DIL"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="DB" urn="urn:adsk.eagle:symbol:23823/1" library_version="1">
<wire x1="-1.905" y1="-3.175" x2="-4.064" y2="-2.794" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-3.175" x2="-2.286" y2="-1.016" width="0.254" layer="94"/>
<wire x1="-2.7178" y1="-4.0386" x2="-0.9398" y2="-2.2606" width="0.254" layer="94"/>
<wire x1="-1.905" y1="3.175" x2="-4.064" y2="2.794" width="0.254" layer="94"/>
<wire x1="-1.905" y1="3.175" x2="-2.286" y2="1.016" width="0.254" layer="94"/>
<wire x1="-2.7178" y1="4.0386" x2="-1.0668" y2="2.3876" width="0.254" layer="94"/>
<wire x1="3.175" y1="1.905" x2="2.794" y2="4.064" width="0.254" layer="94"/>
<wire x1="3.175" y1="1.905" x2="1.016" y2="2.286" width="0.254" layer="94"/>
<wire x1="2.3622" y1="1.016" x2="4.1402" y2="2.794" width="0.254" layer="94"/>
<wire x1="3.175" y1="-1.905" x2="2.794" y2="-4.064" width="0.254" layer="94"/>
<wire x1="3.175" y1="-1.905" x2="1.016" y2="-2.286" width="0.254" layer="94"/>
<wire x1="2.3622" y1="-1.0668" x2="4.1402" y2="-2.8448" width="0.254" layer="94"/>
<wire x1="5.08" y1="0" x2="3.175" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="-5.08" x2="-1.905" y2="-3.175" width="0.1524" layer="94"/>
<wire x1="-3.2766" y1="-1.8034" x2="-5.08" y2="0" width="0.1524" layer="94"/>
<wire x1="-4.064" y1="-2.794" x2="-2.286" y2="-1.016" width="0.254" layer="94"/>
<wire x1="-5.08" y1="0" x2="-3.2766" y2="1.8034" width="0.1524" layer="94"/>
<wire x1="-4.064" y1="2.794" x2="-2.286" y2="1.016" width="0.254" layer="94"/>
<wire x1="-1.905" y1="3.175" x2="0" y2="5.08" width="0.1524" layer="94"/>
<wire x1="0" y1="5.08" x2="1.8034" y2="3.2766" width="0.1524" layer="94"/>
<wire x1="1.016" y1="2.286" x2="2.794" y2="4.064" width="0.254" layer="94"/>
<wire x1="3.175" y1="1.905" x2="5.08" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="-5.08" x2="1.8034" y2="-3.2766" width="0.1524" layer="94"/>
<wire x1="1.016" y1="-2.286" x2="2.794" y2="-4.064" width="0.254" layer="94"/>
<text x="5.08" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<text x="5.08" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<pin name="AC1" x="0" y="5.08" visible="off" length="point" direction="pas" rot="R270"/>
<pin name="+" x="5.08" y="0" visible="off" length="point" direction="pas" rot="R180"/>
<pin name="AC2" x="0" y="-5.08" visible="off" length="point" direction="pas" rot="R90"/>
<pin name="-" x="-5.08" y="0" visible="off" length="point" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="B-DIL" urn="urn:adsk.eagle:component:23906/1" prefix="B" uservalue="yes" library_version="1">
<gates>
<gate name="1" symbol="DB" x="0" y="0"/>
</gates>
<devices>
<device name="" package="B-DIL">
<connects>
<connect gate="1" pin="+" pad="+"/>
<connect gate="1" pin="-" pad="-"/>
<connect gate="1" pin="AC1" pad="AC1"/>
<connect gate="1" pin="AC2" pad="AC2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23868/1"/>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="v-reg" urn="urn:adsk.eagle:library:409">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="78XXL" urn="urn:adsk.eagle:footprint:30303/1" library_version="1">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="IN" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="GND" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="OUT" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-3.81" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="10">A15,2mm</text>
<text x="-0.508" y="0" size="1.27" layer="51" ratio="10">-</text>
<text x="-3.048" y="0" size="1.27" layer="51" ratio="10">I</text>
<text x="2.032" y="0" size="1.27" layer="51" ratio="10">O</text>
<rectangle x1="1.905" y1="-2.159" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-3.81" x2="3.175" y2="-2.159" layer="51"/>
<rectangle x1="-0.635" y1="-2.159" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="-3.175" y1="-2.159" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-3.81" x2="0.635" y2="-2.159" layer="51"/>
<rectangle x1="-3.175" y1="-3.81" x2="-1.905" y2="-2.159" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
</packages>
<packages3d>
<package3d name="78XXL" urn="urn:adsk.eagle:package:30361/1" type="box" library_version="1">
<description>VOLTAGE REGULATOR</description>
<packageinstances>
<packageinstance name="78XXL"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="78XX" urn="urn:adsk.eagle:symbol:30277/1" library_version="1">
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="2.54" width="0.4064" layer="94"/>
<wire x1="5.08" y1="2.54" x2="-5.08" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<text x="2.54" y="-7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.032" y="-4.318" size="1.524" layer="95">GND</text>
<text x="-4.445" y="-0.635" size="1.524" layer="95">IN</text>
<text x="0.635" y="-0.635" size="1.524" layer="95">OUT</text>
<pin name="IN" x="-7.62" y="0" visible="off" length="short" direction="in"/>
<pin name="GND" x="0" y="-7.62" visible="off" length="short" direction="in" rot="R90"/>
<pin name="OUT" x="7.62" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="78XXL" urn="urn:adsk.eagle:component:30408/1" prefix="IC" uservalue="yes" library_version="1">
<gates>
<gate name="A" symbol="78XX" x="0" y="0"/>
</gates>
<devices>
<device name="" package="78XXL">
<connects>
<connect gate="A" pin="GND" pad="GND"/>
<connect gate="A" pin="IN" pad="IN"/>
<connect gate="A" pin="OUT" pad="OUT"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:30361/1"/>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1" urn="urn:adsk.eagle:library:371">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
<packages>
</packages>
<symbols>
<symbol name="0V" urn="urn:adsk.eagle:symbol:26927/1" library_version="1">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-1.905" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="0V" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="0V" urn="urn:adsk.eagle:component:26956/1" prefix="GND" library_version="1">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="0V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="rcl" urn="urn:adsk.eagle:library:334">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="CT3216" urn="urn:adsk.eagle:footprint:22802/1" library_version="3">
<description>&lt;b&gt;TANTALUM CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.973" y1="1.483" x2="2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.483" x2="-2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.483" x2="-2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.483" x2="2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-1.651" y1="0.559" x2="-1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="1.651" y1="0.559" x2="1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="-1.535" y1="0.798" x2="-1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="-1.535" y1="-0.798" x2="1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="-0.798" x2="1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="0.798" x2="-1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="0" x2="-1.26" y2="0" width="0.2032" layer="51"/>
<wire x1="-0.97" y1="0.26" x2="-0.97" y2="-0.3" width="0.2032" layer="51"/>
<smd name="+" x="-1.4" y="0" dx="2" dy="1.2" layer="1"/>
<smd name="-" x="1.4" y="0" dx="2" dy="1.2" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="CT3528" urn="urn:adsk.eagle:footprint:22803/1" library_version="3">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-1.637" y1="-1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="-1.637" y2="-1.383" width="0.2032" layer="51"/>
<wire x1="1.778" y1="1.016" x2="1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-0.68" y1="0" x2="-1.31" y2="0" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.3" x2="-1" y2="-0.33" width="0.2032" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="2" dy="2.2" layer="1"/>
<smd name="-" x="1.5" y="0" dx="2" dy="2.2" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="CT6032" urn="urn:adsk.eagle:footprint:22804/1" library_version="3">
<wire x1="-4.473" y1="1.983" x2="4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.983" x2="-4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.983" x2="-4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.983" x2="4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.932" y1="-1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-3.073" y1="1.067" x2="-3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="-2.932" y2="-1.637" width="0.2032" layer="51"/>
<wire x1="3.073" y1="1.067" x2="3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="2.957" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-1.18" y1="0" x2="-2.45" y2="0" width="0.2032" layer="51"/>
<wire x1="-1.8" y1="0.63" x2="-1.8" y2="-0.64" width="0.2032" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="CT7343" urn="urn:adsk.eagle:footprint:22807/1" library_version="3">
<wire x1="-4.973" y1="2.483" x2="4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="-2.483" x2="-4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-4.973" y1="-2.483" x2="-4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="2.483" x2="4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-3.592" y1="-2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-3.734" y1="1.143" x2="-3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="-3.592" y2="-2.195" width="0.2032" layer="51"/>
<wire x1="3.734" y1="1.143" x2="3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="3.582" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-2.04" y1="0" x2="-3.09" y2="0" width="0.2032" layer="51"/>
<wire x1="-2.55" y1="0.52" x2="-2.55" y2="-0.52" width="0.2032" layer="51"/>
<smd name="+" x="-3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<smd name="-" x="3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="B45181A" urn="urn:adsk.eagle:footprint:22805/1" library_version="3">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
body 5 x 5 mm, rectangle, grid 2.54 mm</description>
<wire x1="2.032" y1="2.286" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.905" x2="2.413" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-2.286" x2="2.032" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.6764" x2="-1.778" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-1.4478" y1="1.3716" x2="-2.1082" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.286" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.032" y1="2.286" x2="2.413" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.032" y1="-2.286" x2="2.413" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.905" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="B45181B" urn="urn:adsk.eagle:footprint:22806/1" library_version="3">
body 7.6 x 5 mm, rectangle, grid 5.08 mm</description>
<wire x1="3.302" y1="2.413" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="3.683" y1="2.032" x2="3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="3.302" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.413" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.302" y1="-2.413" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-2.54" y="0" drill="0.8128"/>
<pad name="-" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.921" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.191" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="21"/>
</package>
<package name="B45181C" urn="urn:adsk.eagle:footprint:22810/1" library_version="3">
body 12.7 x 7.6 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="3.683" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.302" x2="6.223" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.6764" x2="-4.318" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-3.9878" y1="1.3716" x2="-4.6482" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.2192" x2="-0.254" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.762" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.2192" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.683" x2="6.223" y2="3.302" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-3.683" x2="6.223" y2="-3.302" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-5.08" y="0" drill="0.9144"/>
<pad name="-" x="5.08" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.334" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="B45181D" urn="urn:adsk.eagle:footprint:22816/1" library_version="3">
body 12.5 x 12.5 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.223" y1="5.842" x2="6.223" y2="-5.842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="5.842" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.223" x2="6.223" y2="5.842" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-6.223" x2="6.223" y2="-5.842" width="0.1524" layer="21" curve="90"/>
<text x="-5.08" y="6.604" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TT2D4" urn="urn:adsk.eagle:footprint:22809/1" library_version="3">
diameter 4 mm, grid 2.54 mm</description>
<wire x1="-1.016" y1="0" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.143" x2="-1.143" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.397" x2="-0.889" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<pad name="-" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128"/>
<text x="2.159" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="51"/>
</package>
<package name="TT2D4L" urn="urn:adsk.eagle:footprint:22808/1" library_version="3">
<wire x1="2.159" y1="7.747" x2="2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.016" x2="1.524" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.651" x2="-1.524" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="1.016" x2="2.159" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.762" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.429" x2="-1.016" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="3.81" x2="-1.397" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="-2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="2.159" y2="7.747" width="0.1524" layer="21" curve="-180"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="1.905" y="1.778" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="TT2D5" urn="urn:adsk.eagle:footprint:22811/1" library_version="3">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-1.27" y1="1.016" x2="-1.27" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.397" x2="-1.651" y2="1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.762" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6" urn="urn:adsk.eagle:footprint:22814/1" library_version="3">
diameter 6 mm, grid 2.54 mm</description>
<wire x1="-1.778" y1="1.524" x2="-1.016" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.143" x2="-1.397" y2="1.905" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="2.921" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.254" y="-2.286" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6L" urn="urn:adsk.eagle:footprint:22812/1" library_version="3">
<wire x1="3.048" y1="10.033" x2="3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="10.033" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.651" x2="-2.413" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.413" y1="1.016" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="10.033" x2="3.048" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<wire x1="-1.143" y1="2.413" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.413" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.524" x2="0.0762" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="1.524" x2="0.0762" y2="3.302" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="3.302" x2="-0.254" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="3.302" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.762" y1="2.413" x2="1.27" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.794" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="21"/>
<text x="-3.429" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="0.381" y1="1.4732" x2="0.8128" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7L" urn="urn:adsk.eagle:footprint:22813/1" library_version="3">
diameter 7 mm, grid 2.54 mm</description>
<wire x1="3.556" y1="10.16" x2="3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.016" x2="2.921" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-2.921" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.016" x2="3.556" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.556" y1="10.16" x2="-3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="10.16" x2="3.556" y2="10.16" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.032" y1="2.794" x2="-2.032" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="3.175" x2="-1.651" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.413" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.413" x2="-0.508" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.524" x2="-0.1778" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.524" x2="-0.1778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.302" x2="-0.508" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.302" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<text x="-3.937" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.905" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.048" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.4732" x2="0.5588" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7" urn="urn:adsk.eagle:footprint:22815/1" library_version="3">
<wire x1="-2.286" y1="0" x2="-3.048" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.556" width="0.1524" layer="21"/>
<text x="3.302" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.127" y="-2.667" size="1.27" layer="21" ratio="10">TT</text>
</package>
<package name="TT5D10" urn="urn:adsk.eagle:footprint:22817/1" library_version="3">
diameter 10 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.127" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.27" x2="-0.127" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-1.397" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.143" x2="-1.905" y2="2.159" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<text x="4.191" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.794" y="1.143" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11" urn="urn:adsk.eagle:footprint:22818/1" library_version="3">
diameter 11 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="1.651" x2="-2.286" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.159" x2="-1.778" y2="1.143" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.588" width="0.1524" layer="21"/>
<text x="4.572" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.175" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11L" urn="urn:adsk.eagle:footprint:22819/1" library_version="3">
<wire x1="-5.08" y1="12.954" x2="-5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.016" x2="4.445" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-4.445" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="4.445" y1="1.016" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="0" width="0.762" layer="21"/>
<wire x1="1.524" y1="0" x2="1.27" y2="0" width="0.762" layer="51"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="0" width="0.762" layer="21"/>
<wire x1="-1.524" y1="0" x2="-1.27" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="12.954" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="4.318" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.937" x2="-1.397" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.921" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.921" x2="-0.508" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.032" x2="-0.1778" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="2.032" x2="-0.1778" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.81" x2="-0.508" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.921" x2="1.27" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="12.954" x2="5.08" y2="12.954" width="0.1524" layer="21" curve="-180"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-5.461" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.413" y="5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="4.572" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="21"/>
<rectangle x1="1.651" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-1.651" y2="0.381" layer="51"/>
<rectangle x1="0.127" y1="1.9812" x2="0.5588" y2="3.8608" layer="21"/>
</package>
<package name="TT5D6" urn="urn:adsk.eagle:footprint:22820/1" library_version="3">
diameter 6 mm, grid 5.08 mm</description>
<wire x1="-2.908" y1="0.9307" x2="2.921" y2="0.889" width="0.1524" layer="21" curve="-145.325311"/>
<wire x1="2.8966" y1="-0.9655" x2="2.921" y2="0.889" width="0.1524" layer="51" curve="35.361865"/>
<wire x1="-2.921" y1="-0.889" x2="-2.8966" y2="0.9655" width="0.1524" layer="51" curve="-35.361865"/>
<wire x1="-2.9403" y1="-0.8232" x2="2.9211" y2="-0.889" width="0.1524" layer="21" curve="147.4323"/>
<wire x1="-1.524" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.27" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.651" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<text x="2.921" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.508" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="21"/>
</package>
<package name="TT5D6L" urn="urn:adsk.eagle:footprint:22821/1" library_version="3">
<wire x1="-1.143" y1="2.54" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.54" x2="-0.508" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.651" x2="-0.1778" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.651" x2="-0.1778" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.429" x2="-0.508" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.429" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.921" x2="-1.905" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="3.302" x2="-1.524" y2="3.302" width="0.1524" layer="21"/>
<text x="-3.429" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.524" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.6002" x2="0.5588" y2="3.4798" layer="21"/>
</package>
<package name="TT5D7" urn="urn:adsk.eagle:footprint:22822/1" library_version="3">
diameter 7 mm, grid 5.08 mm</description>
<wire x1="-2.286" y1="1.524" x2="-1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="2.032" width="0.1524" layer="21"/>
<text x="3.302" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.667" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D7L" urn="urn:adsk.eagle:footprint:22823/1" library_version="3">
<wire x1="-2.159" y1="3.683" x2="-2.159" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.302" x2="-1.778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.667" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.667" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.778" x2="-0.1778" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.778" x2="-0.1778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.556" x2="-0.508" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.556" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.667" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<text x="-3.937" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.445" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.175" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.7272" x2="0.5588" y2="3.6068" layer="21"/>
</package>
<package name="TT5D9" urn="urn:adsk.eagle:footprint:22824/1" library_version="3">
diameter 9 mm, grid 5.08 mm</description>
<wire x1="-2.794" y1="1.397" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.905" x2="-3.302" y2="0.889" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<text x="3.81" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.159" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D9L" urn="urn:adsk.eagle:footprint:22825/1" library_version="3">
<wire x1="-4.572" y1="10.033" x2="-4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.016" x2="3.937" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.651" x2="-3.937" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="3.937" y1="1.016" x2="4.572" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="10.033" x2="4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.937" x2="-1.778" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.556" x2="-1.397" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.794" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.794" x2="-0.381" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.905" x2="-0.0508" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="1.905" x2="-0.0508" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="3.683" x2="-0.381" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="3.683" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="1.397" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="10.033" x2="4.572" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<text x="-4.953" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.064" y="1.778" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.254" y1="1.8542" x2="0.6858" y2="3.7338" layer="21"/>
</package>
<package name="ETR1" urn="urn:adsk.eagle:footprint:22826/1" library_version="3">
<wire x1="2.159" y1="2.54" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.54" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.794" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.889" x2="-2.794" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.889" x2="-2.032" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.9304" x2="-1.27" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="1.6256" x2="-1.6002" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.889" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<text x="-2.032" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR2" urn="urn:adsk.eagle:footprint:22827/1" library_version="3">
<wire x1="-3.302" y1="-2.159" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.159" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.159" x2="3.302" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.81" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.762" x2="-3.81" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-0.762" x2="-3.302" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.889" x2="-1.27" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.159" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.159" width="0.1524" layer="21"/>
<text x="-3.302" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.683" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR3" urn="urn:adsk.eagle:footprint:22828/1" library_version="3">
<wire x1="-3.302" y1="-2.54" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.54" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.54" x2="3.302" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.54" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.54" width="0.1524" layer="21"/>
<text x="-3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR4" urn="urn:adsk.eagle:footprint:22829/1" library_version="3">
<wire x1="-0.762" y1="-1.0922" x2="-0.254" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.0922" x2="-0.254" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.0922" x2="-0.762" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.0922" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.81" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="5.842" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.524" x2="-6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="51"/>
<wire x1="3.683" y1="0" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.9652" x2="-1.651" y2="0.3302" width="0.1524" layer="21"/>
<wire x1="-1.3208" y1="0.635" x2="-1.9558" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-3.81" x2="5.842" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="3.81" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="0.8128"/>
<pad name="-" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-5.842" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.762" y2="1.143" layer="21"/>
</package>
<package name="ETR5" urn="urn:adsk.eagle:footprint:22830/1" library_version="3">
<wire x1="-5.842" y1="-6.1722" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.1722" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-6.1722" x2="5.842" y2="-6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-6.604" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.4986" x2="-6.604" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.4986" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.4986" x2="-5.842" y2="1.4986" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="0" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="0" x2="-1.2954" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="1.524" x2="-0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-1.2954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="-1.524" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.2954" x2="-1.905" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="0.9652" x2="-2.2352" y2="0.9652" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-6.1722" x2="5.842" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="6.1722" width="0.1524" layer="21"/>
<text x="-5.842" y="6.477" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="-1.6002" x2="0.3302" y2="1.6002" layer="21"/>
</package>
<package name="P128-35" urn="urn:adsk.eagle:footprint:22831/1" library_version="3">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="1.778" y1="2.54" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="1.397" x2="1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.635" x2="1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.635" x2="-1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="2.667" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.397" x2="-1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.762" y1="3.556" x2="-0.762" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-3.556" x2="0.762" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.016" x2="2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.159" y1="1.016" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.508" x2="-2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="1.016" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-1.016" x2="-2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.667" y2="-0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-2.667" y1="-0.508" x2="-2.667" y2="0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-1.143" y1="1.9304" x2="-1.143" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="1.6256" x2="-1.4732" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-2.54" x2="-0.762" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="-3.556" x2="1.778" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="3.556" x2="1.778" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="2.54" x2="-0.762" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<pad name="+" x="-2.667" y="0" drill="0.9144"/>
<pad name="-" x="2.667" y="0" drill="0.9144" shape="octagon"/>
<text x="-1.651" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-40" urn="urn:adsk.eagle:footprint:22832/1" library_version="3">
<wire x1="2.032" y1="2.54" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.143" x2="2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.762" x2="2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-0.762" x2="2.032" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.762" x2="-2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="2.54" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.143" x2="-2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.762" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="-1.016" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.556" x2="1.016" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.016" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.016" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="2.032" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.016" y1="-3.556" x2="2.032" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="2.54" x2="-1.016" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.032" y1="-2.54" x2="-1.016" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<text x="-2.032" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-5.207" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-50" urn="urn:adsk.eagle:footprint:22833/1" library_version="3">
<wire x1="2.54" y1="3.048" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.524" y1="4.064" x2="-1.524" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-4.064" x2="1.524" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.635" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.143" x2="-2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.143" x2="-2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.1684" x2="-1.27" y2="0.5334" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="0.8636" x2="-1.6002" y2="0.8636" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.667" y2="-0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="2.667" y1="-0.635" x2="2.667" y2="0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="1.524" y1="4.064" x2="2.54" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="3.048" x2="-1.524" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-3.048" x2="-1.524" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-4.064" x2="2.54" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<text x="-2.413" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-60" urn="urn:adsk.eagle:footprint:22834/1" library_version="3">
<wire x1="3.048" y1="3.048" x2="3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.032" y1="4.064" x2="-2.032" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.064" x2="2.032" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="3.048" x2="-3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-4.064" x2="3.048" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="3.048" x2="-2.032" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.048" y1="-3.048" x2="-2.032" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="4.064" x2="3.048" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-2.921" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TAP5-45" urn="urn:adsk.eagle:footprint:22835/1" library_version="3">
diameter 4.5 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.635" x2="-0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.635" x2="-0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.381" x2="-1.143" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.635" x2="-1.397" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.635" x2="0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.508" x2="0.3302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-1.9144" y1="-1.2492" x2="1.9144" y2="-1.2492" width="0.1524" layer="21" curve="113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="21" curve="-113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="-1.9144" y2="-1.2492" width="0.1524" layer="51" curve="66.251163"/>
<wire x1="1.9144" y1="-1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="51" curve="66.251163"/>
<text x="2.286" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.286" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-1.905" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-50" urn="urn:adsk.eagle:footprint:22836/1" library_version="3">
diameter 5.0 mm, grid 5.08 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="-1.143" y1="0.635" x2="-1.143" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.889" x2="0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.889" x2="0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.889" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.762" x2="0.3302" y2="0.762" width="0.1524" layer="21"/>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-70" urn="urn:adsk.eagle:footprint:22837/1" library_version="3">
diameter 7.0 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0.508" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.651" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.3749" y1="-1.1199" x2="3.3749" y2="-1.1199" width="0.1524" layer="21" curve="143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="21" curve="-143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="-3.3749" y2="-1.1199" width="0.1524" layer="51" curve="36.714997"/>
<wire x1="3.3749" y1="-1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="51" curve="36.714997"/>
<text x="3.175" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.413" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-60" urn="urn:adsk.eagle:footprint:22838/1" library_version="3">
diameter 6.0 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="2.921" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0" y="-2.54" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-80" urn="urn:adsk.eagle:footprint:22839/1" library_version="3">
diameter 8.0 mm, grid 5.08 mm</description>
<circle x="0" y="0" radius="4.318" width="0.1524" layer="21"/>
<text x="3.81" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.032" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="E1,8-4" urn="urn:adsk.eagle:footprint:22840/1" library_version="3">
grid 1.8 mm, diameter 4 mm</description>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="1.397" x2="-0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.143" x2="-0.762" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="-" x="0.889" y="0" drill="0.7112" diameter="1.1684" shape="octagon"/>
<pad name="+" x="-0.889" y="0" drill="0.7112" diameter="1.1684"/>
<text x="2.159" y="-1.778" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="51"/>
</package>
<package name="E15-5" urn="urn:adsk.eagle:footprint:22841/1" library_version="3">
grid 15.24 mm, diameter 5 mm</description>
<wire x1="-4.064" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-2.667" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-1.27" x2="-2.667" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.143" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="0.889" x2="-3.556" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.54" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.191" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.413" x2="-5.08" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.286" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.413" x2="5.461" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.445" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.54" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.826" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.032" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.159" x2="-4.445" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.286" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.715" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.286" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.413" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-4.318" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-2.413" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-2.4892" x2="-4.191" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.4892" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.4892" x2="-5.461" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.4892" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.2352" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.159" x2="-4.572" y2="2.159" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="6.477" y2="0" width="0.508" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.477" y2="0" width="0.508" layer="51"/>
<pad name="+" x="-7.62" y="0" drill="0.8128" diameter="2.159"/>
<pad name="-" x="7.62" y="0" drill="0.8128" diameter="2.159" shape="octagon"/>
<text x="-5.461" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.461" y="-4.1402" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.286" y1="-1.27" x2="-1.778" y2="1.27" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-5.715" y2="0.254" layer="21"/>
<rectangle x1="5.715" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
</package>
<package name="E15-6" urn="urn:adsk.eagle:footprint:22842/1" library_version="3">
grid 15.24 mm, diameter 6 mm</description>
<wire x1="-5.715" y1="-2.921" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.175" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.191" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.048" x2="-5.08" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.921" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.048" x2="5.461" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.445" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.175" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.667" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.794" x2="-4.445" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.921" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.715" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.921" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.175" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.175" x2="-5.08" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-4.318" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-3.1242" x2="-4.191" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.1242" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.1242" x2="-5.461" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.1242" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.8702" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.794" x2="-4.572" y2="2.794" width="0.3048" layer="21"/>
<text x="-5.461" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.8542" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E15-9" urn="urn:adsk.eagle:footprint:22843/1" library_version="3">
grid 15.24 mm, diameter 9 mm</description>
<wire x1="-4.445" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.27" x2="-3.048" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.27" x2="-3.048" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.27" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="5.588" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-4.191" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.572" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.572" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="4.572" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.445" x2="-5.461" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-5.461" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="4.318" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-5.207" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.445" x2="5.842" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-4.826" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.572" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-5.207" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.064" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.191" x2="-4.826" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.318" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="6.096" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-4.318" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.572" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-4.445" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.572" x2="-5.461" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.318" x2="-4.699" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-4.445" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-4.5212" x2="-4.572" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.5212" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.5212" x2="-5.842" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.5212" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.2672" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-4.953" y2="4.191" width="0.3048" layer="21"/>
<text x="-5.842" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-1.9812" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.667" y1="-1.27" x2="-2.159" y2="1.27" layer="21"/>
<rectangle x1="6.096" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-6.096" y2="0.254" layer="21"/>
</package>
<package name="E2,5-4R" urn="urn:adsk.eagle:footprint:22844/1" library_version="3">
grid 2.54 mm, diameter 4 mm</description>
<wire x1="-0.127" y1="0" x2="0.0762" y2="0" width="0.6096" layer="21"/>
<wire x1="-2.794" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="21" curve="320.718856"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="51" curve="-39.281144"/>
<text x="0.762" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.762" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-5" urn="urn:adsk.eagle:footprint:22845/1" library_version="3">
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E2,5-6" urn="urn:adsk.eagle:footprint:22846/1" library_version="3">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-7" urn="urn:adsk.eagle:footprint:22847/1" library_version="3">
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5RE" urn="urn:adsk.eagle:footprint:22848/1" library_version="3">
grid 2.54 mm, diameter 4 mm,</description>
<wire x1="0.254" y1="1.143" x2="0.254" y2="-1.143" width="0.1524" layer="21" curve="286.260205"/>
<wire x1="0.254" y1="-1.143" x2="0.254" y2="1.143" width="0.1524" layer="51" curve="73.739795"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<text x="0.635" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-4" urn="urn:adsk.eagle:footprint:22849/1" library_version="3">
grid 2 mm, diameter 4 mm</description>
<wire x1="-0.762" y1="1.524" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.27" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.889" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.159" width="0.1524" layer="21"/>
<pad name="-" x="1.016" y="0" drill="0.8128" diameter="1.27" shape="octagon"/>
<pad name="+" x="-1.016" y="0" drill="0.8128" diameter="1.27"/>
<text x="2.159" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-5" urn="urn:adsk.eagle:footprint:22850/1" library_version="3">
grid 2.032 mm, diameter 5 mm</description>
<wire x1="-1.27" y1="1.778" x2="-0.762" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.524" x2="-1.016" y2="2.032" width="0.1524" layer="21"/>
<text x="2.54" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-10" urn="urn:adsk.eagle:footprint:22851/1" library_version="3">
grid 22.86 mm, diameter 10 mm</description>
<wire x1="-6.35" y1="5.08" x2="8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="5.08" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="5.08" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-7.62" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.318" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.953" x2="8.509" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.826" x2="8.636" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.953" x2="-8.001" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.826" x2="-7.874" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.572" x2="-6.858" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.445" x2="-6.858" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.699" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-5.08" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.62" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="-6.604" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.318" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.826" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.953" x2="-8.001" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-4.572" x2="-6.858" y2="-4.572" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.953" x2="8.509" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-4.445" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-5.08" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.826" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="5.08" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.699" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.524" x2="-4.572" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.524" x2="-4.572" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.524" x2="-5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.27" x2="-5.842" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0.889" x2="-5.461" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.524" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="9.779" y2="0" width="0.762" layer="51"/>
<wire x1="-11.43" y1="0" x2="-9.779" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-11.43" y="0" drill="1.016" diameter="3.1496"/>
<pad name="-" x="11.43" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<text x="-8.509" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.7686" y="-2.3622" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="1.524" layer="21"/>
<rectangle x1="-9.779" y1="-0.381" x2="-8.89" y2="0.381" layer="21"/>
<rectangle x1="8.89" y1="-0.381" x2="9.779" y2="0.381" layer="21"/>
</package>
<package name="E22-6" urn="urn:adsk.eagle:footprint:22852/1" library_version="3">
grid 22.86 mm, diameter 6 mm</description>
<wire x1="-6.35" y1="3.175" x2="8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.175" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.175" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-7.62" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.413" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.048" x2="8.509" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="2.921" x2="8.636" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="-8.001" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="2.921" x2="-7.874" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.667" x2="-6.858" y2="2.667" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.54" x2="-6.858" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-2.794" x2="-8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.175" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.62" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="-6.604" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.413" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-2.921" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.048" x2="-8.001" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-2.667" x2="-6.858" y2="-2.667" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-3.048" x2="8.509" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.54" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.175" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-2.921" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.175" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.794" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<text x="-8.509" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.4836" y="-5.2832" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-9" urn="urn:adsk.eagle:footprint:22853/1" library_version="3">
grid 22.86 mm, diameter 9 mm</description>
<wire x1="-6.35" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.445" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-7.62" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="3.683" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.318" x2="8.509" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.191" x2="8.636" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.318" x2="-8.001" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.191" x2="-7.874" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.937" x2="-6.858" y2="3.937" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.81" x2="-6.858" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.064" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.445" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="-6.604" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="3.683" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.191" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.318" x2="-8.001" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-3.937" x2="-6.858" y2="-3.937" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.318" x2="8.509" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-3.81" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.191" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.064" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<text x="-8.509" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-10" urn="urn:adsk.eagle:footprint:22854/1" library_version="3">
grid 3.5 mm, diameter 10 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="4.064" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E25-10" urn="urn:adsk.eagle:footprint:22855/1" library_version="3">
grid 25.4 mm, diameter 10 mm</description>
<wire x1="-10.16" y1="4.826" x2="-9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="5.08" x2="-9.017" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="5.08" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.08" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="5.08" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-5.08" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="-8.001" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.826" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.572" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.953" x2="9.906" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.953" x2="-9.017" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.763" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.699" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.35" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="1.27" x2="-7.112" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0.889" x2="-6.731" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.524" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0" x2="-6.35" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.826" x2="-10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.08" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.953" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.0292" x2="-9.017" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.0292" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.763" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.7752" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.874" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="-8.001" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.747" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.0292" x2="9.906" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.953" x2="10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.699" x2="-8.128" y2="4.699" width="0.3048" layer="21"/>
<wire x1="12.7" y1="0" x2="11.049" y2="0" width="0.762" layer="51"/>
<wire x1="-12.7" y1="0" x2="-11.049" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-12.7" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="12.7" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-9.906" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.0386" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="1.524" layer="21"/>
<rectangle x1="-11.049" y1="-0.381" x2="-10.16" y2="0.381" layer="21"/>
<rectangle x1="10.16" y1="-0.381" x2="11.049" y2="0.381" layer="21"/>
</package>
<package name="E25-9" urn="urn:adsk.eagle:footprint:22856/1" library_version="3">
grid 25.4 mm, diameter 9 mm</description>
<wire x1="-10.16" y1="4.191" x2="-9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="4.445" x2="-9.017" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="4.445" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.445" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="4.445" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-4.445" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="-8.001" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.191" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="3.937" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.318" x2="9.906" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.318" x2="-9.017" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.763" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.064" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.445" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.318" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.3942" x2="-9.017" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.3942" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.763" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.1402" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.874" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="-8.001" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.747" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.3942" x2="9.906" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.318" x2="10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.064" x2="-8.128" y2="4.064" width="0.3048" layer="21"/>
<text x="-9.779" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-8" urn="urn:adsk.eagle:footprint:22857/1" library_version="3">
grid 3.5 mm, diameter 8 mm</description>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E30-10" urn="urn:adsk.eagle:footprint:22858/1" library_version="3">
grid 30.48 mm, diameter 10 mm</description>
<wire x1="12.7" y1="4.699" x2="12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="5.08" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-10.541" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.43" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-11.43" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="12.7" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="4.953" x2="-11.811" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="4.826" x2="-11.684" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.572" x2="-10.668" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.318" x2="-10.668" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="4.953" x2="12.319" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="4.826" x2="12.446" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-4.699" x2="-12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-5.08" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="-10.414" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-4.826" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-11.43" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.191" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-11.43" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-4.445" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.953" x2="12.319" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-4.953" x2="-11.811" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-4.572" x2="-10.668" y2="-4.572" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-4.699" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-5.08" x2="-10.16" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-4.826" x2="12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.7" y1="4.699" x2="12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.319" y1="5.08" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-1.524" x2="-7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.524" x2="-7.874" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="1.524" x2="-8.382" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="1.27" x2="-9.144" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0.889" x2="-8.763" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="1.524" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="0" x2="-8.382" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0" x2="13.462" y2="0" width="0.762" layer="51"/>
<wire x1="-15.24" y1="0" x2="-13.462" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-15.24" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="15.24" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-12.319" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.0706" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.366" y1="-1.524" x2="-6.858" y2="1.524" layer="21"/>
<rectangle x1="-13.462" y1="-0.381" x2="-12.7" y2="0.381" layer="21"/>
<rectangle x1="12.7" y1="-0.381" x2="13.462" y2="0.381" layer="21"/>
</package>
<package name="E30-12" urn="urn:adsk.eagle:footprint:22859/1" library_version="3">
grid 30.48 mm, diameter 12 mm</description>
<wire x1="12.7" y1="5.969" x2="12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.35" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-10.541" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.43" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-11.43" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="12.7" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.223" x2="-11.811" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="6.096" x2="-11.684" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.842" x2="-10.668" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.588" x2="-10.668" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="6.223" x2="12.319" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="6.096" x2="12.446" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-5.969" x2="-12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.35" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.35" x2="-10.414" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-6.096" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-11.43" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.461" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-11.43" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-5.715" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.223" x2="12.319" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-6.223" x2="-11.811" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-5.842" x2="-10.668" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-5.969" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-6.35" x2="-10.16" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-6.096" x2="12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.7" y1="5.969" x2="12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="12.319" y1="6.35" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<text x="-12.192" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E30-16" urn="urn:adsk.eagle:footprint:22860/1" library_version="3">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 30.48 mm, diameter 16 mm</description>
<wire x1="12.7" y1="7.747" x2="12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.128" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-10.541" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.43" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-11.43" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="12.7" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.001" x2="-11.811" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-11.684" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.62" x2="-10.668" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.366" x2="-10.668" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="8.001" x2="12.319" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="7.874" x2="12.446" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-7.62" x2="-12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-8.001" x2="-10.414" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-7.747" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-11.43" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.239" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-11.43" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-7.366" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-7.874" x2="12.319" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-7.874" x2="-11.811" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-7.493" x2="-10.668" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-7.62" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-8.001" x2="-10.16" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-7.747" x2="12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.7" y1="7.747" x2="12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="12.319" y1="8.128" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<text x="-12.319" y="8.382" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-12" urn="urn:adsk.eagle:footprint:22861/1" library_version="3">
grid 35.56 mm, diameter 12 mm</description>
<wire x1="15.24" y1="5.969" x2="15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.35" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-12.446" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.335" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-13.335" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="15.24" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.223" x2="-13.716" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="6.096" x2="-13.589" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.842" x2="-12.573" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.588" x2="-12.573" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="6.223" x2="14.859" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="6.096" x2="14.986" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-5.969" x2="-15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-6.35" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.35" x2="-12.319" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-6.096" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-13.335" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.461" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-13.335" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-5.715" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.223" x2="14.859" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-6.223" x2="-13.716" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-5.842" x2="-12.573" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-5.969" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-6.35" x2="-12.065" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-6.096" x2="14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.969" x2="14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="14.859" y1="6.35" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="-1.524" x2="-9.779" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-1.524" x2="-9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="1.524" x2="-10.287" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="1.27" x2="-11.049" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.889" x2="-10.668" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="1.524" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="0" x2="-10.287" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0" x2="14.097" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0" x2="16.002" y2="0" width="0.762" layer="51"/>
<wire x1="-17.78" y1="0" x2="-16.002" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-17.78" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="17.78" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-14.732" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.9756" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-9.271" y1="-1.524" x2="-8.763" y2="1.524" layer="21"/>
<rectangle x1="-16.129" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.129" y2="0.381" layer="21"/>
</package>
<package name="E35-14" urn="urn:adsk.eagle:footprint:22862/1" library_version="3">
grid 30.48 mm, diameter 14 mm</description>
<wire x1="15.24" y1="7.239" x2="15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.62" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-12.446" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.335" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-13.335" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="15.24" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.493" x2="-13.716" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="7.366" x2="-13.589" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.112" x2="-12.573" y2="7.112" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="6.858" x2="-12.573" y2="6.858" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="7.493" x2="14.859" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="7.366" x2="14.986" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.239" x2="-15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-7.62" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.62" x2="-12.319" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-7.366" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-13.335" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="6.731" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-13.335" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-6.985" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.493" x2="14.859" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-7.493" x2="-13.716" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.112" x2="-12.573" y2="-7.112" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.239" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-7.62" x2="-12.065" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-7.366" x2="14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.239" x2="14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="14.859" y1="7.62" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<text x="-14.859" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-16" urn="urn:adsk.eagle:footprint:22863/1" library_version="3">
<wire x1="15.24" y1="7.874" x2="15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.255" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-12.446" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.335" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-13.335" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="15.24" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.128" x2="-13.716" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="8.001" x2="-13.589" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.747" x2="-12.573" y2="7.747" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.493" x2="-12.573" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="8.128" x2="14.859" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="8.001" x2="14.986" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.874" x2="-15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-8.255" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.255" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-8.001" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-13.335" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.366" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-13.335" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-7.62" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.128" x2="14.859" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-8.128" x2="-13.716" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.747" x2="-12.573" y2="-7.747" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.874" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-8.001" x2="14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.874" x2="14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="14.859" y1="8.255" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<text x="-14.859" y="8.636" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-18" urn="urn:adsk.eagle:footprint:22864/1" library_version="3">
grid 30.48 mm, diameter 18 mm</description>
<wire x1="15.24" y1="9.779" x2="15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.16" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-12.446" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.335" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-13.335" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="15.24" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.033" x2="-13.716" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="9.906" x2="-13.589" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.652" x2="-12.573" y2="9.652" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.398" x2="-12.573" y2="9.398" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="10.033" x2="14.859" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="9.906" x2="14.986" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-9.779" x2="-15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-10.16" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.16" x2="-12.319" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-9.906" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-13.335" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.271" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-13.335" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-9.525" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.033" x2="14.859" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-10.033" x2="-13.716" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-9.652" x2="-12.573" y2="-9.652" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-9.779" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-10.16" x2="-12.065" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-9.906" x2="14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.24" y1="9.779" x2="14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="14.859" y1="10.16" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<text x="-14.859" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-16.002" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.002" y2="0.381" layer="21"/>
</package>
<package name="E45-16" urn="urn:adsk.eagle:footprint:22865/1" library_version="3">
grid 45.72 mm, diameter 16 mm</description>
<wire x1="-20.32" y1="7.747" x2="-19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.255" x2="-18.288" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.255" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-7.747" x2="-19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-18.288" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.255" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-16.51" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-17.78" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.128" x2="-17.78" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.129" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="-16.002" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.2042" x2="-18.288" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="-16.002" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-17.78" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.6962" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.2042" x2="19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.255" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.128" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="-16.002" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.255" x2="19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-17.78" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.62" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.239" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.747" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.128" x2="-18.288" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.128" x2="19.812" y2="8.128" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.255" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.747" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.048" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.524" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.524" x2="-3.556" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.27" x2="-4.318" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.524" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="19.05" y2="0" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="7.62" x2="-16.637" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="7.874" x2="-18.034" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="7.366" x2="-16.637" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="7.874" x2="20.066" y2="7.874" width="0.3048" layer="21"/>
<wire x1="22.86" y1="0" x2="20.955" y2="0" width="0.762" layer="51"/>
<wire x1="-22.86" y1="0" x2="-20.955" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-22.86" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="22.86" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-19.812" y="8.763" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.2446" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.54" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="20.32" y1="-0.381" x2="20.828" y2="0.381" layer="21"/>
<rectangle x1="-20.828" y1="-0.381" x2="-20.32" y2="0.381" layer="21"/>
</package>
<package name="E45-18" urn="urn:adsk.eagle:footprint:22866/1" library_version="3">
grid 45.72 mm, diameter 18 mm</description>
<wire x1="-20.32" y1="8.382" x2="-19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.89" x2="-18.288" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.89" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-8.382" x2="-19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-18.288" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.89" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-16.51" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-17.78" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.763" x2="-17.78" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.129" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="-16.002" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.8392" x2="-18.288" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="-16.002" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-17.78" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.3312" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.8392" x2="19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.89" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.763" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="-16.002" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.89" x2="19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-17.78" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.255" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.874" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="8.382" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.763" x2="-18.288" y2="8.763" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.763" x2="19.812" y2="8.763" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.89" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.382" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="8.255" x2="-16.637" y2="8.255" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="8.509" x2="-18.034" y2="8.509" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="8.001" x2="-16.637" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="8.509" x2="20.066" y2="8.509" width="0.3048" layer="21"/>
<text x="-19.558" y="9.271" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-21" urn="urn:adsk.eagle:footprint:22867/1" library_version="3">
grid 45.72 mm, diameter 21 mm</description>
<wire x1="-20.32" y1="10.287" x2="-19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.795" x2="-18.288" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="10.795" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.287" x2="-19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-18.288" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-10.795" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-16.51" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-17.78" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.668" x2="-17.78" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.129" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="-16.002" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.7442" x2="-18.288" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="-16.002" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-17.78" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.2362" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.7442" x2="19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-10.795" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.668" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="-16.002" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="10.795" x2="19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-17.78" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.16" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="9.779" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.287" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.668" x2="-18.288" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.668" x2="19.812" y2="10.668" width="0.3048" layer="21"/>
<wire x1="19.812" y1="10.795" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.287" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.16" x2="-16.637" y2="10.16" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.414" x2="-18.034" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="9.906" x2="-16.637" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.414" x2="20.066" y2="10.414" width="0.3048" layer="21"/>
<text x="-19.685" y="11.176" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-22" urn="urn:adsk.eagle:footprint:22868/1" library_version="3">
grid 45.72 mm, diameter 22 mm</description>
<wire x1="-20.32" y1="10.541" x2="-19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="11.049" x2="-18.288" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="11.049" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.541" x2="-19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-18.288" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-11.049" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-16.51" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-17.78" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.922" x2="-17.78" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.129" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="-16.002" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.9982" x2="-18.288" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="-16.002" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-17.78" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.4902" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.9982" x2="19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-11.049" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.922" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="-16.002" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="11.049" x2="19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-17.78" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.414" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.033" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.541" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.922" x2="-18.288" y2="10.922" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.922" x2="19.812" y2="10.922" width="0.3048" layer="21"/>
<wire x1="19.812" y1="11.049" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.541" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.414" x2="-16.637" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.668" x2="-18.034" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.668" x2="20.066" y2="10.668" width="0.3048" layer="21"/>
<text x="-19.685" y="11.43" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-25" urn="urn:adsk.eagle:footprint:22869/1" library_version="3">
grid 45.72 mm, diameter 25 mm</description>
<wire x1="-20.32" y1="12.192" x2="-19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.7" x2="-18.288" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="12.7" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-18.288" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-12.7" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-16.51" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-17.78" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-12.573" x2="-17.78" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.129" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="-16.002" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.6492" x2="-18.288" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="-16.002" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-17.78" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.1412" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.6492" x2="19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-12.7" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-12.573" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="-16.002" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="12.7" x2="19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-17.78" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.065" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="11.684" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="12.192" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.573" x2="-18.288" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="12.573" x2="19.812" y2="12.573" width="0.3048" layer="21"/>
<wire x1="19.812" y1="12.7" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="20.32" y1="12.192" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="12.065" x2="-16.637" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="12.319" x2="-18.034" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="11.811" x2="-16.637" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="12.319" x2="20.066" y2="12.319" width="0.3048" layer="21"/>
<text x="-19.558" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5-10,5" urn="urn:adsk.eagle:footprint:22870/1" library_version="3">
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="E5-13" urn="urn:adsk.eagle:footprint:22871/1" library_version="3">
grid 5.08 mm, diameter 13 mm</description>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-0.889" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.27" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.445" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="6.985" width="0.1524" layer="21"/>
<text x="6.3754" y="4.1148" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-3.937" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.889" y2="1.27" layer="21"/>
</package>
<package name="E5-4" urn="urn:adsk.eagle:footprint:22872/1" library_version="3">
grid 5.05 mm, diameter 4 mm</description>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="-1.397" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.905"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.905" shape="octagon"/>
<text x="2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="21"/>
</package>
<package name="E5-5" urn="urn:adsk.eagle:footprint:22873/1" library_version="3">
grid 5.08 mm, diameter 5 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-6" urn="urn:adsk.eagle:footprint:22874/1" library_version="3">
grid 5.08 mm, diameter 6 mm</description>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="3.048" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-8,5" urn="urn:adsk.eagle:footprint:22875/1" library_version="3">
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E50-25" urn="urn:adsk.eagle:footprint:22876/1" library_version="3">
grid 50 mm, diameter 25 mm</description>
<wire x1="22.225" y1="-12.192" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-12.7" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="21.717" y1="12.7" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="22.225" y1="12.192" x2="22.225" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.352" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="12.7" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="21.717" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="12.065" x2="-19.177" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="11.811" x2="-19.177" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="12.573" x2="-20.828" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="12.319" x2="-22.479" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-22.479" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-20.701" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.701" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.574" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="12.573" x2="21.717" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="12.319" x2="-18.669" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="-18.669" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="21.971" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.479" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.192" x2="-18.669" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-20.32" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="11.684" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-22.352" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-12.573" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-20.32" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.065" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-22.352" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.6492" x2="-20.828" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.1412" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.7" x2="-18.542" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.6492" x2="21.717" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-12.573" x2="21.717" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.524" x2="-5.588" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-1.524" x2="-5.588" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="1.524" x2="-6.096" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="1.27" x2="-6.858" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="0.889" x2="-6.477" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.524" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="0" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0" x2="20.955" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="24.765" y1="0" x2="22.86" y2="0" width="0.762" layer="51"/>
<wire x1="-25.4" y1="0" x2="-23.495" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-25.4" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-22.098" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.7846" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="-1.524" x2="-4.572" y2="1.524" layer="21"/>
<rectangle x1="22.225" y1="-0.381" x2="22.733" y2="0.381" layer="21"/>
<rectangle x1="-23.368" y1="-0.381" x2="-22.86" y2="0.381" layer="21"/>
</package>
<package name="E50-30" urn="urn:adsk.eagle:footprint:22877/1" library_version="3">
grid 50 mm, diameter 30 mm</description>
<wire x1="22.225" y1="-14.732" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-15.24" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="21.717" y1="15.24" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="22.225" y1="14.732" x2="22.225" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.352" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="15.24" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="21.717" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.32" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-20.32" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="14.605" x2="-19.177" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="14.351" x2="-19.177" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="15.113" x2="-20.828" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="14.859" x2="-22.479" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-22.479" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-20.701" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.701" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.574" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="15.113" x2="21.717" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="14.859" x2="-18.669" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="-18.669" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="21.971" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.479" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.732" x2="-18.669" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-20.32" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.224" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-22.352" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-15.113" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-20.32" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.605" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-22.352" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.1892" x2="-20.828" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-20.32" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.6812" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.24" x2="-18.542" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.1892" x2="21.717" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-15.113" x2="21.717" y2="-15.24" width="0.1524" layer="21"/>
<pad name="+" x="-25.4" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-21.971" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E55-25" urn="urn:adsk.eagle:footprint:22878/1" library_version="3">
grid 55 mm, diameter 25 mm</description>
<wire x1="-25.4" y1="12.192" x2="-24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.7" x2="-23.368" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="12.7" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-12.192" x2="-25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-23.368" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-12.7" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-21.59" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.86" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-12.573" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.209" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="-21.082" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.6492" x2="-23.368" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="-21.082" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-22.86" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.1412" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.6492" x2="24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-12.7" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-12.573" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="-21.082" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="12.7" x2="24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-22.86" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.065" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="11.684" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.573" x2="-23.368" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="12.573" x2="24.892" y2="12.573" width="0.3048" layer="21"/>
<wire x1="24.892" y1="12.7" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="25.4" y1="12.192" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="24.13" y2="0" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="12.065" x2="-21.717" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="12.319" x2="-23.114" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="11.811" x2="-21.717" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="12.319" x2="25.146" y2="12.319" width="0.3048" layer="21"/>
<wire x1="27.94" y1="0" x2="26.035" y2="0" width="0.762" layer="51"/>
<wire x1="-27.94" y1="0" x2="-26.035" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-27.94" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-24.638" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="25.4" y1="-0.381" x2="25.908" y2="0.381" layer="21"/>
<rectangle x1="-25.908" y1="-0.381" x2="-25.4" y2="0.381" layer="21"/>
</package>
<package name="E55-30" urn="urn:adsk.eagle:footprint:22879/1" library_version="3">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 55 mm, diameter 30 mm</description>
<wire x1="-25.4" y1="14.732" x2="-24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.24" x2="-23.368" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="15.24" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-14.732" x2="-25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-23.368" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-15.24" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-21.59" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.86" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-15.113" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.209" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="-21.082" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.1892" x2="-23.368" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="-21.082" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-22.86" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.6812" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.1892" x2="24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-15.24" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-15.113" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="-21.082" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="15.24" x2="24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-22.86" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.605" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.224" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.113" x2="-23.368" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="15.113" x2="24.892" y2="15.113" width="0.3048" layer="21"/>
<wire x1="24.892" y1="15.24" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="25.4" y1="14.732" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="14.605" x2="-21.717" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="14.859" x2="-23.114" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="14.351" x2="-21.717" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="14.859" x2="25.146" y2="14.859" width="0.3048" layer="21"/>
<pad name="+" x="-27.94" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-24.511" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5R" urn="urn:adsk.eagle:footprint:22880/1" library_version="3">
grid 5.08 mm, diameter 9 mm</description>
<wire x1="-0.889" y1="0" x2="0.9398" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.588" y1="0" x2="-4.572" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.508" x2="-5.08" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="1.143" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.016" y2="0" width="0.6096" layer="51"/>
<wire x1="1.778" y1="-1.143" x2="1.7821" y2="1.1275" width="0.1524" layer="21" curve="-330.552701"/>
<wire x1="1.7732" y1="1.1613" x2="1.7781" y2="-1.143" width="0.1524" layer="51" curve="-29.895306"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="2.54" shape="octagon"/>
<text x="1.651" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E7,5-16" urn="urn:adsk.eagle:footprint:22881/1" library_version="3">
grid 7.62 mm, diameter 16 mm</description>
<wire x1="0.635" y1="0" x2="2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.905" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.905" x2="-0.254" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.905" x2="-0.254" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.905" x2="-0.889" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-5.969" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.762" x2="-6.731" y2="0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="8.255" width="0.1524" layer="21"/>
<pad name="-" x="3.81" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<pad name="+" x="-3.81" y="0" drill="1.016" diameter="3.1496"/>
<text x="7.874" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.2926" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.905" x2="0.889" y2="1.905" layer="21"/>
</package>
<package name="E7,5-18" urn="urn:adsk.eagle:footprint:22882/1" library_version="3">
grid 7.62 mm, diameter 18 mm</description>
<circle x="0" y="0" radius="8.89" width="0.1524" layer="21"/>
<text x="8.001" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB20D" urn="urn:adsk.eagle:footprint:22883/1" library_version="3">
grid 10.16 mm, diameter 20 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="10.16" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="7.62" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="2.0066" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="2.0066" diameter="4.5974" shape="octagon"/>
<text x="7.8994" y="7.366" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
<package name="EB22,5D" urn="urn:adsk.eagle:footprint:22884/1" library_version="3">
grid 10.16 mm, diameter 22.5 mm</description>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<circle x="0" y="0" radius="11.303" width="0.1524" layer="21"/>
<text x="8.4074" y="8.509" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB25D" urn="urn:adsk.eagle:footprint:22885/1" library_version="3">
grid 10.16 mm, diameter 25 mm</description>
<circle x="0" y="0" radius="12.7" width="0.254" layer="21"/>
<text x="9.6774" y="9.525" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB30D" urn="urn:adsk.eagle:footprint:22886/1" library_version="3">
grid 10.16 mm, diameter 30 mm</description>
<circle x="0" y="0" radius="15.24" width="0.254" layer="21"/>
<circle x="0" y="0" radius="12.065" width="0.254" layer="21"/>
<text x="10.8204" y="11.938" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB35D" urn="urn:adsk.eagle:footprint:22887/1" library_version="3">
grid 10.16 mm, diameter 35 mm</description>
<wire x1="1.397" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<circle x="0" y="0" radius="17.78" width="0.254" layer="21"/>
<circle x="0" y="0" radius="13.97" width="0.254" layer="21"/>
<text x="12.954" y="13.462" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="085CS_1R" urn="urn:adsk.eagle:footprint:22888/1" library_version="3">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; reflow soldering&lt;p&gt;
SMD (Chip) Standard 085 CS&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="5.7" y1="-0.95" x2="5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="-0.7" x2="5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="0.7" x2="5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.7" y1="0.95" x2="5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="5.8" y1="-0.75" x2="5.8" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-5.7" y1="0.95" x2="-5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="0.7" x2="-5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="-0.7" x2="-5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="-0.95" x2="-5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.8" y1="0.75" x2="-5.8" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.15" y1="-1.85" x2="5.15" y2="1.85" width="0.2032" layer="51"/>
<wire x1="5.15" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-1.35" x2="3.3" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="5.05" y1="1.35" x2="3.3" y2="1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-7" y1="2.2" x2="-7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="7" y1="2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="2.2" x2="7" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="-2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-5.31" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.31" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="3.3" y1="-1" x2="5.65" y2="1" layer="51"/>
<rectangle x1="-5.65" y1="-1" x2="-3.3" y2="1" layer="51"/>
</package>
<package name="085CS_1W" urn="urn:adsk.eagle:footprint:22889/1" library_version="3">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; wave soldering&lt;p&gt;
<wire x1="5.15" y1="1.85" x2="3.2" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.2" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-5.15" y1="-1.85" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.2" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-8.6" y1="4" x2="-8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="8.6" y1="4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="4" x2="8.6" y2="4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="-4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<smd name="+" x="5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="085CS_1AR" urn="urn:adsk.eagle:footprint:22890/1" library_version="3">
<wire x1="4.2" y1="-0.95" x2="4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="-0.7" x2="4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.7" x2="4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.2" y1="0.95" x2="4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-0.75" x2="4.3" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="0.95" x2="-4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.7" x2="-4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="-0.7" x2="-4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-4.2" y1="-0.95" x2="-4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.3" y1="0.75" x2="-4.3" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="3.65" y1="-1.85" x2="3.65" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.65" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.85" x2="-3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-3.65" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.6" y1="-1.35" x2="1.8" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="3.55" y1="1.35" x2="1.8" y2="1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-5.5" y1="2.2" x2="-5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="5.5" y1="2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="2.2" x2="5.5" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="-2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-3.81" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.8" y1="-1" x2="4.15" y2="1" layer="51"/>
<rectangle x1="-4.15" y1="-1" x2="-1.8" y2="1" layer="51"/>
</package>
<package name="085CS_1AW" urn="urn:adsk.eagle:footprint:22891/1" library_version="3">
<wire x1="3.65" y1="1.85" x2="1.7" y2="1.85" width="0.2032" layer="51"/>
<wire x1="1.7" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="-1.85" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.7" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-6.9" y1="4.1" x2="-6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="6.9" y1="4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="4.1" x2="6.9" y2="4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="-4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<smd name="+" x="4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="139CLL-2R" urn="urn:adsk.eagle:footprint:22892/1" library_version="3">
SMD (Chip) Long Life 139 CLL&lt;p&gt;
<wire x1="-8.1" y1="3.9" x2="-8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-3.9" x2="8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-3.9" x2="8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="3.9" x2="-8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="7.15" y1="-0.6" x2="6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="-0.85" x2="6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="0.85" x2="7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="7.15" y1="0.6" x2="7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="0.6" x2="-6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="0.85" x2="-6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="-0.85" x2="-7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="-0.6" x2="-7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="6.4" y1="-3.05" x2="-6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-1.6" x2="-6.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.05" x2="6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="1.6" x2="6.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2" x2="4.25" y2="-2.95" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2" x2="4.25" y2="2.95" width="0.2032" layer="21"/>
<smd name="+" x="6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<smd name="-" x="-6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.5" y1="-1" x2="6.85" y2="1" layer="51"/>
<rectangle x1="-6.85" y1="-1" x2="-4.5" y2="1" layer="51"/>
</package>
<package name="139CLL-2W" urn="urn:adsk.eagle:footprint:22893/1" library_version="3">
<wire x1="-10.15" y1="3.9" x2="-10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-10.15" y1="-3.9" x2="10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="-3.9" x2="10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="3.9" x2="-10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="3.05" width="0.2032" layer="51"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="-3.05" width="0.2032" layer="51"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="51"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="51"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
</package>
<package name="139CLL-3R" urn="urn:adsk.eagle:footprint:22894/1" library_version="3">
<wire x1="-8.1" y1="4.6" x2="-8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-4.6" x2="8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-4.6" x2="8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="4.6" x2="-8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="6.4" y1="-3.75" x2="-6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.75" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.75" x2="6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.75" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2.7" x2="4.5" y2="-2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2.7" x2="4.25" y2="-3.65" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2.7" x2="4.5" y2="2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2.7" x2="4.25" y2="3.65" width="0.2032" layer="21"/>
</package>
<package name="139CLL-3W" urn="urn:adsk.eagle:footprint:22895/1" library_version="3">
<wire x1="-10.6" y1="6.4" x2="-10.6" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="-10.6" y1="-6.4" x2="9.2" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="-6.4" x2="9.2" y2="6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="6.4" x2="-10.6" y2="6.4" width="0.2032" layer="39"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
</package>
<package name="140CLH-0810" urn="urn:adsk.eagle:footprint:22896/1" library_version="3">
<description>&lt;b&gt;Aluminum electrolytic capacitors SMD (Chip)&lt;/b&gt;&lt;p&gt;
Long life base plate, High temperature 140 CLH&lt;p&gt;
<wire x1="-4.85" y1="4.2" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="4.85" y2="1.45" width="0.2032" layer="21"/>
<wire x1="4.85" y1="1.45" x2="4.85" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="4.85" y1="-1.45" x2="4.85" y2="-2.75" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-4.2" x2="-4.85" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-4.2" x2="-4.85" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-1.45" x2="-4.85" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-4.85" y1="1.45" x2="-4.85" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-2.75" x2="3.4" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.4" x2="3.65" y2="1.4" width="0.2032" layer="21" curve="-138.030204"/>
<wire x1="3.65" y1="1.4" x2="3.65" y2="-1.4" width="0.2032" layer="51" curve="-41.969796"/>
<wire x1="-3.65" y1="-1.4" x2="3.65" y2="-1.4" width="0.2032" layer="21" curve="138.030204"/>
<wire x1="-3.65" y1="-1.4" x2="-3.65" y2="1.4" width="0.2032" layer="51" curve="-41.969796"/>
<smd name="+" x="3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<text x="-5.38" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="0.635" y="-3.175" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="140CLH-1010" urn="urn:adsk.eagle:footprint:22897/1" library_version="3">
<wire x1="-5.8" y1="5.15" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="5.8" y2="1.45" width="0.2032" layer="21"/>
<wire x1="5.8" y1="1.45" x2="5.8" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="5.8" y1="-1.45" x2="5.8" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="4.35" y1="-5.15" x2="-5.8" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-5.15" x2="-5.8" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-1.45" x2="-5.8" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-5.8" y1="1.45" x2="-5.8" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="-3.7" x2="4.35" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-1.4" x2="4.7" y2="-1.4" width="0.2032" layer="21" curve="146.825323"/>
<wire x1="4.7" y1="-1.4" x2="4.7" y2="1.4" width="0.2032" layer="51" curve="33.174677"/>
<wire x1="-4.7" y1="1.4" x2="4.7" y2="1.4" width="0.2032" layer="21" curve="-146.825323"/>
<wire x1="-4.7" y1="1.4" x2="-4.7" y2="-1.4" width="0.2032" layer="51" curve="33.174677"/>
<smd name="+" x="4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<smd name="-" x="-4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<text x="-2.74" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.375" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="140CLH-1014" urn="urn:adsk.eagle:footprint:22898/1" library_version="3">
<text x="-2.69" y="1.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.225" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-0810" urn="urn:adsk.eagle:footprint:22899/1" library_version="3">
Long life base plate, very low impedance 150 CLZ&lt;p&gt;
<text x="-5.43" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
</package>
<package name="150CLZ-1010" urn="urn:adsk.eagle:footprint:22900/1" library_version="3">
<text x="-2.79" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.075" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-1014" urn="urn:adsk.eagle:footprint:22901/1" library_version="3">
<wire x1="-4.7" y1="-1.4" x2="-4.7" y2="1.4" width="0.2032" layer="51" curve="-33.174677"/>
<text x="-2.74" y="1.88" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.025" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0405" urn="urn:adsk.eagle:footprint:22902/1" library_version="3">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt;&lt;p&gt;
SMD (Chip) Long Life Vertical 153 CLV&lt;p&gt;
<wire x1="1.25" y1="-2.15" x2="-2.15" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-2.15" x2="-2.15" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-1.1" x2="-2.15" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="1.1" x2="-2.15" y2="2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="1.25" y2="2.15" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.25" x2="2.15" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.1" x2="2.15" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.05" x2="2.15" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.15" y1="-1.25" x2="1.25" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.15" x2="2.15" y2="1.25" width="0.2032" layer="21"/>
<wire x1="-1.65" y1="-0.95" x2="1.65" y2="-0.95" width="0.2032" layer="21" curve="120.136976"/>
<wire x1="-1.65" y1="-0.95" x2="-1.65" y2="0.95" width="0.2032" layer="51" curve="-59.863024"/>
<wire x1="-1.65" y1="0.95" x2="1.65" y2="0.95" width="0.2032" layer="21" curve="-120.136976"/>
<wire x1="1.65" y1="-0.95" x2="1.65" y2="0.95" width="0.2032" layer="51" curve="59.863024"/>
<smd name="+" x="1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<smd name="-" x="-1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<text x="-2.24" y="2.48" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.275" y="-3.735" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0505" urn="urn:adsk.eagle:footprint:22903/1" library_version="3">
<wire x1="1.75" y1="-2.65" x2="-2.65" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-2.65" x2="-2.65" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-1.1" x2="-2.65" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.65" y1="1.1" x2="-2.65" y2="2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.65" x2="1.75" y2="2.65" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.75" x2="2.65" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.1" x2="2.65" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="2.65" y1="-1.1" x2="2.65" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.75" x2="1.75" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.65" x2="2.65" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-0.95" x2="2.2" y2="-0.95" width="0.2032" layer="21" curve="133.28887"/>
<wire x1="-2.2" y1="-0.95" x2="-2.2" y2="0.95" width="0.2032" layer="51" curve="-46.71113"/>
<wire x1="-2.2" y1="0.95" x2="2.2" y2="0.95" width="0.2032" layer="21" curve="-133.28887"/>
<wire x1="2.2" y1="-0.95" x2="2.2" y2="0.95" width="0.2032" layer="51" curve="46.71113"/>
<smd name="+" x="2.2" y="0" dx="3" dy="1.6" layer="1"/>
<smd name="-" x="-2.2" y="0" dx="3" dy="1.6" layer="1"/>
<text x="-2.74" y="2.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.775" y="-4.235" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0605" urn="urn:adsk.eagle:footprint:22904/1" library_version="3">
<wire x1="2.4" y1="-3.3" x2="-3.3" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-3.3" x2="-3.3" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-1.1" x2="-3.3" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-3.3" y1="1.1" x2="-3.3" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="3.3" x2="2.4" y2="3.3" width="0.2032" layer="21"/>
<wire x1="3.3" y1="2.4" x2="3.3" y2="1.1" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.1" x2="3.3" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.1" x2="3.3" y2="-2.4" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-2.4" x2="2.4" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.3" x2="3.3" y2="2.4" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="-0.9" x2="2.95" y2="-0.95" width="0.2032" layer="21" curve="145.181395"/>
<wire x1="-2.95" y1="-0.9" x2="-2.95" y2="0.95" width="0.2032" layer="51" curve="-34.818605"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.9" width="0.2032" layer="21" curve="-145.181395"/>
<wire x1="2.95" y1="-0.95" x2="2.95" y2="0.9" width="0.2032" layer="51" curve="34.818605"/>
<smd name="+" x="2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="-" x="-2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.39" y="3.63" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.425" y="-4.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0807" urn="urn:adsk.eagle:footprint:22905/1" library_version="3">
<wire x1="3.3" y1="-4.2" x2="-4.2" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.1" x2="-4.2" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.1" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="4.2" x2="3.3" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.1" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.1" x2="4.2" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.1" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-3.3" x2="3.3" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="3.3" y1="4.2" x2="4.2" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="-1.05" x2="3.75" y2="-1.05" width="0.2032" layer="21" curve="148.008335"/>
<wire x1="-3.75" y1="-1.05" x2="-3.75" y2="1.05" width="0.2032" layer="51" curve="-31.284493"/>
<wire x1="-3.75" y1="1.05" x2="3.75" y2="1.05" width="0.2032" layer="21" curve="-148.008335"/>
<wire x1="3.75" y1="1.05" x2="3.75" y2="-1.05" width="0.2032" layer="51" curve="-31.284493"/>
<smd name="+" x="3.05" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="-" x="-3.05" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-4.29" y="4.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.325" y="-5.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0810" urn="urn:adsk.eagle:footprint:22906/1" library_version="3">
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.5" x2="-4.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.5" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.5" x2="4.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.5" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="3.65" y1="-1.4" x2="3.65" y2="1.4" width="0.2032" layer="51" curve="41.969796"/>
</package>
<package name="153CLV-1010" urn="urn:adsk.eagle:footprint:22907/1" library_version="3">
<wire x1="4.3" y1="-5.2" x2="-5.2" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-5.2" x2="-5.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-1.5" x2="-5.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-5.2" y1="1.5" x2="-5.2" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="5.2" x2="4.3" y2="5.2" width="0.2032" layer="21"/>
<wire x1="5.2" y1="4.3" x2="5.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="5.2" y1="1.5" x2="5.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="5.2" y1="-1.5" x2="5.2" y2="-4.3" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-4.3" x2="4.3" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="4.3" y1="5.2" x2="5.2" y2="4.3" width="0.2032" layer="21"/>
<wire x1="4.65" y1="-1.55" x2="4.65" y2="1.55" width="0.2032" layer="51" curve="36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="-4.65" y2="1.55" width="0.2032" layer="51" curve="-36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="4.65" y2="-1.55" width="0.2032" layer="21" curve="143.130102"/>
<wire x1="-4.65" y1="1.55" x2="4.65" y2="1.55" width="0.2032" layer="21" curve="-143.130102"/>
<smd name="+" x="4" y="0" dx="4" dy="2.5" layer="1"/>
<smd name="-" x="-4" y="0" dx="4" dy="2.5" layer="1"/>
<text x="-5.29" y="5.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.325" y="-6.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-1012" urn="urn:adsk.eagle:footprint:22908/1" library_version="3">
</package>
<package name="153CLV-1014" urn="urn:adsk.eagle:footprint:22909/1" library_version="3">
</package>
<package name="175TMP-0808" urn="urn:adsk.eagle:footprint:22910/1" library_version="3">
High Temperature solid electrolytic SMD 175 TMP&lt;p&gt;
<wire x1="3.2" y1="-4.1" x2="-4.1" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1.55" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-1.55" x2="-4.1" y2="1.55" width="0.2032" layer="51"/>
<wire x1="-4.1" y1="1.55" x2="-4.1" y2="4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.2" y2="4.1" width="0.2032" layer="21"/>
<wire x1="4.1" y1="3.2" x2="4.1" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.1" y1="1.5" x2="4.1" y2="-1.55" width="0.2032" layer="51"/>
<wire x1="4.1" y1="-1.55" x2="4.1" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-3.2" x2="3.2" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="3.2" y1="4.1" x2="4.1" y2="3.2" width="0.2032" layer="21"/>
<wire x1="-3.6" y1="-1.45" x2="3.6" y2="-1.45" width="0.2032" layer="21" curve="136.123039"/>
<wire x1="-3.6" y1="-1.45" x2="-3.6" y2="1.45" width="0.2032" layer="51" curve="-43.876961"/>
<wire x1="-3.6" y1="1.45" x2="3.6" y2="1.45" width="0.2032" layer="21" curve="-136.123039"/>
<wire x1="3.6" y1="1.45" x2="3.6" y2="-1.45" width="0.2032" layer="51" curve="-43.876961"/>
<smd name="+" x="3.5" y="0" dx="3" dy="2.5" layer="1"/>
<smd name="-" x="-3.5" y="0" dx="3" dy="2.5" layer="1"/>
</package>
<package name="175TMP-0810" urn="urn:adsk.eagle:footprint:22911/1" library_version="3">
<wire x1="3.6" y1="-1.45" x2="3.6" y2="1.45" width="0.2032" layer="51" curve="43.876961"/>
</package>
<package name="A/3216-18R" urn="urn:adsk.eagle:footprint:22912/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 reflow solder&lt;/b&gt;&lt;p&gt;KEMET S / EIA 3216-12</description>
<wire x1="-1.45" y1="0.6" x2="1.45" y2="0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.6" x2="1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.6" x2="-1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.6" x2="-1.45" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<smd name="-" x="-1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<text x="-1.95" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.325" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.475" y2="0.6" layer="51"/>
<rectangle x1="1.475" y1="-0.6" x2="1.6" y2="0.6" layer="51"/>
<rectangle x1="0.8" y1="-0.625" x2="1.1" y2="0.625" layer="51"/>
</package>
<package name="A/3216-18W" urn="urn:adsk.eagle:footprint:22913/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="B/3528-21R" urn="urn:adsk.eagle:footprint:22914/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 reflow solder&lt;/b&gt;&lt;p&gt;KEMET T / EIA 3528-12</description>
<wire x1="-1.6" y1="1.2" x2="1.6" y2="1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.2" x2="1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.2" x2="-1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.2" x2="-1.6" y2="1.2" width="0.1016" layer="51"/>
<smd name="+" x="1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<smd name="-" x="-1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<text x="-1.95" y="1.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.925" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-0.6" x2="-1.625" y2="0.6" layer="51"/>
<rectangle x1="1.625" y1="-0.6" x2="1.75" y2="0.6" layer="51"/>
<rectangle x1="0.95" y1="-1.225" x2="1.25" y2="1.225" layer="51"/>
</package>
<package name="B/3528-21W" urn="urn:adsk.eagle:footprint:22915/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="C/6032-28R" urn="urn:adsk.eagle:footprint:22916/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 reflow solder&lt;/b&gt;&lt;p&gt;KEMET U / EIA 6032-15</description>
<wire x1="-2.8" y1="1.55" x2="2.8" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="1.55" x2="2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-1.55" x2="-2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.8" y1="-1.55" x2="-2.8" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<smd name="-" x="-2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<text x="-3" y="1.825" size="1.27" layer="25">&gt;NAME</text>
<text x="-3" y="-3.05" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3" y1="-1.1" x2="-2.85" y2="1.1" layer="51"/>
<rectangle x1="2.85" y1="-1.1" x2="3" y2="1.1" layer="51"/>
<rectangle x1="1.95" y1="-1.575" x2="2.45" y2="1.575" layer="51"/>
</package>
<package name="C/6032-28W" urn="urn:adsk.eagle:footprint:22917/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 Wafe solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
<smd name="-" x="-2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
</package>
<package name="D/7343-31R" urn="urn:adsk.eagle:footprint:22918/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET D / EIA 7343-21&lt;/b&gt;&lt;p&gt;KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 reflow solder</description>
<wire x1="-3.45" y1="2.1" x2="3.45" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.1" x2="3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.1" x2="-3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.1" x2="-3.45" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<text x="-3.65" y="2.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.65" y="-3.575" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.5" y2="1.2" layer="51"/>
<rectangle x1="3.5" y1="-1.2" x2="3.65" y2="1.2" layer="51"/>
<rectangle x1="2.675" y1="-2.125" x2="3.15" y2="2.125" layer="51"/>
</package>
<package name="D/7343-31W" urn="urn:adsk.eagle:footprint:22919/1" library_version="3">
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Wafe solder</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
</package>
<package name="E/7260-38R" urn="urn:adsk.eagle:footprint:22920/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 reflow solder&lt;/b&gt;</description>
<wire x1="-3.45" y1="2.95" x2="3.45" y2="2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.95" x2="3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.95" x2="-3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.95" x2="-3.45" y2="2.95" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<text x="-4.45" y="3.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.45" y="-4.475" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-2.05" x2="-3.5" y2="2.05" layer="51"/>
<rectangle x1="3.5" y1="-2.05" x2="3.65" y2="2.05" layer="51"/>
<rectangle x1="2.675" y1="-2.975" x2="3.15" y2="2.975" layer="51"/>
</package>
<package name="E/7260-38W" urn="urn:adsk.eagle:footprint:22921/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
</package>
<package name="R/2012-12R" urn="urn:adsk.eagle:footprint:22922/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 reflow solder&lt;/b&gt;</description>
<wire x1="-0.85" y1="0.6" x2="0.85" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="0.6" x2="0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="-0.6" x2="-0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-0.85" y1="-0.6" x2="-0.85" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<smd name="-" x="-1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<rectangle x1="-1" y1="-0.45" x2="-0.875" y2="0.45" layer="51"/>
<rectangle x1="0.875" y1="-0.45" x2="1" y2="0.45" layer="51"/>
<rectangle x1="0.3" y1="-0.625" x2="0.5" y2="0.625" layer="51"/>
</package>
<package name="R/2012-12W" urn="urn:adsk.eagle:footprint:22923/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
<smd name="-" x="-1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
</package>
<package name="PANASONIC_A" urn="urn:adsk.eagle:footprint:22924/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package A&lt;/b&gt;</description>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="1.6" x2="1.6" y2="0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="0.8" x2="1.6" y2="-0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-0.8" x2="0.8" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="0.95" x2="1.1" y2="0.95" width="0.1016" layer="21" curve="-98.369832"/>
<wire x1="-1.1" y1="-0.95" x2="1.15" y2="-0.9" width="0.1016" layer="21" curve="101.144396"/>
<wire x1="-1.6" y1="0.95" x2="-1.6" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="1.6" x2="1.5" y2="0.9" width="0.1016" layer="21"/>
<wire x1="1.5" y1="-0.9" x2="0.8" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="1.2" x2="-0.8" y2="-1.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.45" width="0.1016" layer="51"/>
<smd name="-" x="-1.3" y="0" dx="2" dy="1.5" layer="1"/>
<smd name="+" x="1.3" y="0" dx="2" dy="1.5" layer="1"/>
<text x="-1.65" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.65" y="-2.825" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.3" x2="-1.45" y2="0.3" layer="51"/>
<rectangle x1="1.45" y1="-0.3" x2="1.8" y2="0.3" layer="51"/>
<polygon width="0.1016" layer="51">
<vertex x="-0.85" y="1.1"/>
<vertex x="-1.15" y="0.8"/>
<vertex x="-1.35" y="0.3"/>
<vertex x="-1.35" y="-0.3"/>
<vertex x="-1.15" y="-0.8"/>
<vertex x="-0.85" y="-1.1"/>
<vertex x="-0.85" y="1.05"/>
</polygon>
</package>
<package name="PANASONIC_B" urn="urn:adsk.eagle:footprint:22925/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package B&lt;/b&gt;</description>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1" x2="2.1" y2="-1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.85" x2="1.75" y2="0.85" width="0.1016" layer="21" curve="-128.186984"/>
<wire x1="-1.75" y1="-0.85" x2="1.75" y2="-0.85" width="0.1016" layer="21" curve="128.186984"/>
<wire x1="-2.1" y1="0.85" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="-1.2" y1="1.5" x2="-1.2" y2="-1.5" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.95" width="0.1016" layer="51"/>
<smd name="-" x="-1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<smd name="+" x="1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<text x="-2.15" y="2.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.15" y="-3.275" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3" y1="-0.35" x2="-1.85" y2="0.35" layer="51"/>
<rectangle x1="1.9" y1="-0.35" x2="2.3" y2="0.35" layer="51"/>
<vertex x="-1.25" y="1.45"/>
<vertex x="-1.7" y="0.85"/>
<vertex x="-1.85" y="0.35"/>
<vertex x="-1.85" y="-0.4"/>
<vertex x="-1.7" y="-0.85"/>
<vertex x="-1.25" y="-1.4"/>
<vertex x="-1.25" y="1.4"/>
</polygon>
</package>
<package name="PANASONIC_C" urn="urn:adsk.eagle:footprint:22926/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package C&lt;/b&gt;</description>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="-1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="0.95" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="0.95" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-0.95" x2="2.6" y2="-1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.3" y1="0.85" x2="2.3" y2="0.85" width="0.1016" layer="21" curve="-139.434882"/>
<wire x1="-2.3" y1="-0.85" x2="2.3" y2="-0.85" width="0.1016" layer="21" curve="139.434882"/>
<wire x1="-1.55" y1="1.85" x2="-1.55" y2="-1.85" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="2.45" width="0.1016" layer="51"/>
<smd name="-" x="-2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<smd name="+" x="2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<text x="-2.6" y="2.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.65" y="-3.775" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.95" y1="-0.35" x2="-2.4" y2="0.35" layer="51"/>
<rectangle x1="2.4" y1="-0.35" x2="2.95" y2="0.35" layer="51"/>
<vertex x="-1.6" y="1.8"/>
<vertex x="-2" y="1.35"/>
<vertex x="-2.25" y="0.75"/>
<vertex x="-2.45" y="0.05"/>
<vertex x="-2.25" y="-0.75"/>
<vertex x="-1.95" y="-1.35"/>
<vertex x="-1.6" y="-1.8"/>
</polygon>
</package>
<package name="PANASONIC_D" urn="urn:adsk.eagle:footprint:22927/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D&lt;/b&gt;</description>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="0.95" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="0.95" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-0.95" x2="3.25" y2="-1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.95" width="0.1016" layer="21" curve="-144.299363"/>
<wire x1="-2.95" y1="-0.95" x2="2.95" y2="-0.95" width="0.1016" layer="21" curve="144.299363"/>
<wire x1="-2.1" y1="2.25" x2="-2.1" y2="-2.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="3.1" width="0.1016" layer="51"/>
<smd name="-" x="-2.4" y="0" dx="3" dy="1.4" layer="1"/>
<smd name="+" x="2.4" y="0" dx="3" dy="1.4" layer="1"/>
<text x="-1.75" y="1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-1.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-0.35" x2="-3.05" y2="0.35" layer="51"/>
<rectangle x1="3.05" y1="-0.35" x2="3.65" y2="0.35" layer="51"/>
<vertex x="-2.15" y="2.15"/>
<vertex x="-2.6" y="1.6"/>
<vertex x="-2.9" y="0.9"/>
<vertex x="-3.05" y="0"/>
<vertex x="-2.9" y="-0.95"/>
<vertex x="-2.55" y="-1.65"/>
<vertex x="-2.15" y="-2.15"/>
<vertex x="-2.15" y="2.1"/>
</polygon>
</package>
<package name="PANASONIC_E" urn="urn:adsk.eagle:footprint:22928/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package E&lt;/b&gt;</description>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="0.9" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="0.9" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-0.9" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-2.2" y1="3.25" x2="-2.2" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.9" x2="3.85" y2="0.9" width="0.1016" layer="21" curve="-153.684915"/>
<wire x1="-3.85" y1="-0.9" x2="3.85" y2="-0.9" width="0.1016" layer="21" curve="153.684915"/>
<circle x="0" y="0" radius="3.95" width="0.1016" layer="51"/>
<smd name="-" x="-3" y="0" dx="3.8" dy="1.4" layer="1"/>
<smd name="+" x="3" y="0" dx="3.8" dy="1.4" layer="1"/>
<text x="-1.8" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.8" y="-2.225" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5" y1="-0.35" x2="-3.8" y2="0.35" layer="51"/>
<rectangle x1="3.8" y1="-0.35" x2="4.5" y2="0.35" layer="51"/>
<vertex x="-2.25" y="3.2"/>
<vertex x="-3" y="2.5"/>
<vertex x="-3.6" y="1.5"/>
<vertex x="-3.85" y="0.65"/>
<vertex x="-3.85" y="-0.65"/>
<vertex x="-3.55" y="-1.6"/>
<vertex x="-2.95" y="-2.55"/>
<vertex x="-2.25" y="-3.2"/>
<vertex x="-2.25" y="3.15"/>
</polygon>
</package>
<package name="PANASONIC_F" urn="urn:adsk.eagle:footprint:22929/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package F&lt;/b&gt;</description>
<wire x1="-4.1" y1="1" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1" width="0.1016" layer="21"/>
<circle x="0" y="0" radius="4" width="0.001" layer="51"/>
<smd name="-" x="-3.55" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="+" x="3.55" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-1.75" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-2.375" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.85" y1="-0.45" x2="-3.9" y2="0.45" layer="51"/>
<rectangle x1="3.9" y1="-0.45" x2="4.85" y2="0.45" layer="51"/>
</polygon>
</package>
<package name="PANASONIC_G" urn="urn:adsk.eagle:footprint:22930/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G&lt;/b&gt;</description>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="-2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="1" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-1" x2="5.1" y2="-2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-1" width="0.1016" layer="21"/>
<wire x1="-4.85" y1="-1" x2="4.85" y2="-1" width="0.1016" layer="21" curve="156.699401"/>
<wire x1="-4.85" y1="1" x2="4.85" y2="1" width="0.1016" layer="21" curve="-156.699401"/>
<wire x1="-3.25" y1="3.7" x2="-3.25" y2="-3.65" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="4.95" width="0.1016" layer="51"/>
<smd name="-" x="-4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<smd name="+" x="4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<text x="-2.55" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.55" y="-2.675" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-5.85" y1="-0.45" x2="-4.9" y2="0.45" layer="51"/>
<rectangle x1="4.9" y1="-0.45" x2="5.85" y2="0.45" layer="51"/>
<vertex x="-3.3" y="3.6"/>
<vertex x="-4.05" y="2.75"/>
<vertex x="-4.65" y="1.55"/>
<vertex x="-4.85" y="0.45"/>
<vertex x="-4.85" y="-0.45"/>
<vertex x="-4.65" y="-1.55"/>
<vertex x="-4.05" y="-2.75"/>
<vertex x="-3.3" y="-3.6"/>
<vertex x="-3.3" y="3.55"/>
</polygon>
</package>
<package name="TT2D5L" urn="urn:adsk.eagle:footprint:22931/1" library_version="3">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-2.54" y1="8.89" x2="2.54" y2="8.89" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.54" y1="8.89" x2="2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="8.89" x2="-2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.651" x2="-1.905" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.905" y1="1.016" x2="2.54" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.54" x2="0.889" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="3.81" x2="-1.524" y2="3.048" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-2.921" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="2.286" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="E2,5-6E" urn="urn:adsk.eagle:footprint:22932/1" library_version="3">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.159" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.254" x2="-2.413" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="SMC_A" urn="urn:adsk.eagle:footprint:22933/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor &lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194, B 45 197, B 45 198&lt;br&gt;
Source: www.farnell.com/datasheets/247.pdf</description>
<wire x1="-1.45" y1="0.75" x2="1.45" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.75" x2="1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.75" x2="-1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.75" x2="-1.45" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1.6" y="0.975" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.4" y2="0.6" layer="51"/>
<rectangle x1="1.4" y1="-0.6" x2="1.6" y2="0.6" layer="51" rot="R180"/>
<rectangle x1="-1.45" y1="-0.75" x2="-0.8" y2="0.75" layer="51"/>
</package>
<package name="SMC_Z" urn="urn:adsk.eagle:footprint:22934/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor&lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194&lt;br&gt;
<wire x1="-0.9" y1="0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="-0.9" y1="0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<smd name="+" x="-1" y="0" dx="1" dy="1.2" layer="1"/>
<smd name="-" x="1" y="0" dx="1" dy="1.2" layer="1"/>
<text x="-1" y="0.8" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.1" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.45" x2="-0.9" y2="0.45" layer="51"/>
<rectangle x1="0.9" y1="-0.45" x2="1" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-0.9" y1="-0.6" x2="-0.5" y2="0.6" layer="51"/>
</package>
<package name="SMC_P" urn="urn:adsk.eagle:footprint:22935/1" library_version="3">
<wire x1="-1.675" y1="0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.675" y1="0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.575" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.575" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.275" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.45" x2="-1.7" y2="0.45" layer="51"/>
<rectangle x1="1.7" y1="-0.45" x2="1.8" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-1.65" y1="-0.75" x2="-1.075" y2="0.725" layer="51"/>
</package>
<package name="SMC_B" urn="urn:adsk.eagle:footprint:22936/1" library_version="3">
<wire x1="-1.6" y1="1.35" x2="1.6" y2="1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.35" x2="1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.35" x2="-1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.35" x2="-1.6" y2="1.35" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="2.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="2.4" layer="1" rot="R180"/>
<text x="-1.905" y="1.905" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-1.1" x2="-1.55" y2="1.1" layer="51"/>
<rectangle x1="1.55" y1="-1.1" x2="1.75" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-1.6" y1="-1.35" x2="-0.95" y2="1.35" layer="51"/>
</package>
<package name="SMC_C" urn="urn:adsk.eagle:footprint:22937/1" library_version="3">
<wire x1="-2.85" y1="1.55" x2="2.85" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="1.55" x2="2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="-1.55" x2="-2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.85" y1="-1.55" x2="-2.85" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.4" dy="2.4" layer="1" rot="R180"/>
<rectangle x1="-3" y1="-1.1" x2="-2.8" y2="1.1" layer="51"/>
<rectangle x1="2.8" y1="-1.1" x2="3" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-2.85" y1="-1.55" x2="-1.9" y2="1.55" layer="51"/>
</package>
<package name="SMC_D" urn="urn:adsk.eagle:footprint:22938/1" library_version="3">
<wire x1="-3.5" y1="2.1" x2="3.5" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="2.1" x2="3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="-2.1" x2="-3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.5" y1="-2.1" x2="-3.5" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="-3.15" y="0" dx="2.4" dy="2.8" layer="1"/>
<smd name="-" x="3.15" y="0" dx="2.4" dy="2.8" layer="1" rot="R180"/>
<text x="-2.54" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.45" y2="1.2" layer="51"/>
<rectangle x1="3.45" y1="-1.2" x2="3.65" y2="1.2" layer="51" rot="R180"/>
<rectangle x1="-3.5" y1="-2.1" x2="-2.4" y2="2.1" layer="51"/>
</package>
<package name="SMC_E" urn="urn:adsk.eagle:footprint:22939/1" library_version="3">
</package>
<package name="SANYO-OSCON_9E" urn="urn:adsk.eagle:footprint:22940/1" library_version="3">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt;&lt;p&gt;
Source: e_os_all.pdf</description>
<wire x1="-3.55" y1="0" x2="-2.8" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9" width="0.2032" layer="21"/>
<pad name="-" x="-1.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.8" diameter="1.27"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SANYO-OSCON_9F" urn="urn:adsk.eagle:footprint:22941/1" library_version="3">
<wire x1="-4.55" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9" width="0.2032" layer="21"/>
<pad name="-" x="-2.5" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_A" urn="urn:adsk.eagle:footprint:22942/1" library_version="3">
<wire x1="-1.55" y1="-0.4" x2="-1.55" y2="0.4" width="0.4064" layer="51"/>
<circle x="0" y="0" radius="1.9" width="0.2032" layer="21"/>
<pad name="-" x="-1" y="0" drill="0.7" diameter="1.1"/>
<pad name="+" x="1" y="0" drill="0.7" diameter="1.1"/>
</package>
<package name="SANYO-OSCON_A'" urn="urn:adsk.eagle:footprint:22943/1" library_version="3">
<pad name="-" x="-0.75" y="0" drill="0.6" diameter="1"/>
<pad name="+" x="0.75" y="0" drill="0.6" diameter="1"/>
</package>
<package name="SANYO-OSCON_B" urn="urn:adsk.eagle:footprint:22944/1" library_version="3">
<wire x1="-1.9" y1="-0.4" x2="-1.9" y2="0.4" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="2.4" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_B'" urn="urn:adsk.eagle:footprint:22945/1" library_version="3">
</package>
<package name="SANYO-OSCON_C" urn="urn:adsk.eagle:footprint:22946/1" library_version="3">
<wire x1="-2.2" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.05" width="0.2032" layer="21"/>
<pad name="-" x="-1.25" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_C'" urn="urn:adsk.eagle:footprint:22947/1" library_version="3">
<circle x="0" y="0" radius="3.0504" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_C6" urn="urn:adsk.eagle:footprint:22948/1" library_version="3">
<pad name="-" x="-1.25" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.7" diameter="1.27"/>
<text x="-1.905" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="21">
<vertex x="-2.15" y="-2.1" curve="-41.039434"/>
<vertex x="-3" y="0.1" curve="-41.67409"/>
</polygon>
</package>
<package name="SANYO-OSCON_D" urn="urn:adsk.eagle:footprint:22949/1" library_version="3">
</package>
<package name="SANYO-OSCON_E" urn="urn:adsk.eagle:footprint:22950/1" library_version="3">
<wire x1="-3.5" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9003" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_E'" urn="urn:adsk.eagle:footprint:22951/1" library_version="3">
</package>
<package name="SANYO-OSCON_E1" urn="urn:adsk.eagle:footprint:22952/1" library_version="3">
<wire x1="-3.55" y1="0" x2="-2.75" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_E12" urn="urn:adsk.eagle:footprint:22953/1" library_version="3">
<vertex x="-2.65" y="2.7"/>
<vertex x="-2.65" y="-2.75" curve="-41.038922"/>
<vertex x="-3.8" y="0" curve="-41.675057"/>
</polygon>
</package>
<package name="SANYO-OSCON_E13" urn="urn:adsk.eagle:footprint:22954/1" library_version="3">
</polygon>
</package>
<package name="SANYO-OSCON_E7" urn="urn:adsk.eagle:footprint:22955/1" library_version="3">
<pad name="-" x="-1.75" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-2.65" y="2.8"/>
<vertex x="-2.65" y="-2.8" curve="-41.039891"/>
<vertex x="-3.85" y="0" curve="-41.675747"/>
</polygon>
</package>
<package name="SANYO-OSCON_E9" urn="urn:adsk.eagle:footprint:22956/1" library_version="3">
</polygon>
</package>
<package name="SANYO-OSCON_F" urn="urn:adsk.eagle:footprint:22957/1" library_version="3">
<wire x1="-4.5" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_F'" urn="urn:adsk.eagle:footprint:22958/1" library_version="3">
<wire x1="-3.55" y1="0" x2="-4.4" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9002" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_F0" urn="urn:adsk.eagle:footprint:22959/1" library_version="3">
</package>
<package name="SANYO-OSCON_F13" urn="urn:adsk.eagle:footprint:22960/1" library_version="3">
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.4" y="3.45"/>
<vertex x="-3.4" y="-3.4" curve="-41.039359"/>
<vertex x="-4.85" y="0" curve="-41.674636"/>
</polygon>
</package>
<package name="SANYO-OSCON_F8" urn="urn:adsk.eagle:footprint:22961/1" library_version="3">
<pad name="-" x="-2.5" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-3.6" y="3.2"/>
<vertex x="-3.6" y="-3.25" curve="-41.039474"/>
<vertex x="-4.85" y="0" curve="-41.675359"/>
</polygon>
</package>
<package name="SANYO-OSCON_G" urn="urn:adsk.eagle:footprint:22962/1" library_version="3">
<wire x1="-4.5" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="6.15" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_H" urn="urn:adsk.eagle:footprint:22963/1" library_version="3">
<wire x1="-7" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="7.9001" width="0.2032" layer="21"/>
<pad name="-" x="-3.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="3.75" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_SMD_A5" urn="urn:adsk.eagle:footprint:22964/1" library_version="3">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt; SMD type with conductive polymer electrolyte&lt;p&gt;
<wire x1="-2.05" y1="2.05" x2="1.25" y2="2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.05" x2="2.05" y2="1.25" width="0.2032" layer="21"/>
<wire x1="2.05" y1="1.25" x2="2.05" y2="-1.25" width="0.2032" layer="51"/>
<wire x1="2.05" y1="-1.25" x2="1.25" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="-2.05" x2="-2.05" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="-2.05" y1="-2.05" x2="-2.05" y2="2.05" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.85" width="0.2032" layer="51"/>
<text x="-1.905" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="51">
<vertex x="-1.2" y="-1.35"/>
<vertex x="-1.2" y="1.35" curve="44.759919"/>
<vertex x="-1.8" y="0" curve="39.027281"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_B6" urn="urn:adsk.eagle:footprint:22965/1" library_version="3">
<wire x1="-2.55" y1="2.55" x2="1.75" y2="2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.55" x2="2.55" y2="1.75" width="0.2032" layer="21"/>
<wire x1="2.55" y1="1.75" x2="2.55" y2="-1.75" width="0.2032" layer="51"/>
<wire x1="2.55" y1="-1.75" x2="1.75" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="-2.55" x2="-2.55" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="-2.55" y1="-2.55" x2="-2.55" y2="2.55" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.35" width="0.2032" layer="51"/>
<text x="-2.54" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-1.6" y="-1.65"/>
<vertex x="-1.6" y="1.65" curve="35.983944"/>
<vertex x="-2.3" y="0" curve="42.321615"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_C6" urn="urn:adsk.eagle:footprint:22966/1" library_version="3">
<wire x1="-3.2" y1="3.2" x2="2.4" y2="3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.2" x2="3.2" y2="2.4" width="0.2032" layer="21"/>
<wire x1="3.2" y1="2.4" x2="3.2" y2="-2.4" width="0.2032" layer="51"/>
<wire x1="3.2" y1="-2.4" x2="2.4" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="-3.2" x2="-3.2" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="-3.2" y1="-3.2" x2="-3.2" y2="3.2" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.95" width="0.2032" layer="51"/>
<smd name="-" x="-2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="+" x="2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.175" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="1.9"/>
<vertex x="-2.2" y="-1.9" curve="-39.18521"/>
<vertex x="-2.85" y="0" curve="-36.094684"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E12" urn="urn:adsk.eagle:footprint:22967/1" library_version="3">
<wire x1="-4.05" y1="4.05" x2="2.95" y2="4.05" width="0.2032" layer="21"/>
<wire x1="2.95" y1="4.05" x2="4.05" y2="2.95" width="0.2032" layer="21"/>
<wire x1="4.05" y1="2.95" x2="4.05" y2="-2.95" width="0.2032" layer="51"/>
<wire x1="2.95" y1="-4.05" x2="-4.05" y2="-4.05" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="-4.05" x2="-4.05" y2="4.05" width="0.2032" layer="51"/>
<wire x1="4.05" y1="-2.95" x2="2.95" y2="-4.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="3.85" width="0.2032" layer="51"/>
<smd name="-" x="-3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<smd name="+" x="3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<text x="-3.81" y="4.445" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.6" y="-2.75"/>
<vertex x="-2.6" y="2.75" curve="44.955417"/>
<vertex x="-3.85" y="0" curve="45.23973"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E7" urn="urn:adsk.eagle:footprint:22968/1" library_version="3">
<vertex x="-2.7" y="2.65"/>
<vertex x="-2.7" y="-2.65" curve="-47.290335"/>
<vertex x="-3.8" y="0" curve="-44.001093"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F12" urn="urn:adsk.eagle:footprint:22969/1" library_version="3">
<wire x1="-5.05" y1="5.05" x2="3.95" y2="5.05" width="0.2032" layer="21"/>
<wire x1="3.95" y1="5.05" x2="5.05" y2="3.95" width="0.2032" layer="21"/>
<wire x1="5.05" y1="3.95" x2="5.05" y2="-3.95" width="0.2032" layer="51"/>
<wire x1="3.95" y1="-5.05" x2="-5.05" y2="-5.05" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="-5.05" x2="-5.05" y2="5.05" width="0.2032" layer="51"/>
<wire x1="5.05" y1="-3.95" x2="3.95" y2="-5.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="4.8" width="0.2032" layer="51"/>
<smd name="-" x="-4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<smd name="+" x="4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<text x="-5.08" y="5.715" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="-3.65"/>
<vertex x="-3.05" y="3.65" curve="48.708973"/>
<vertex x="-4.75" y="0" curve="43.982679"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F8" urn="urn:adsk.eagle:footprint:22970/1" library_version="3">
<vertex x="-3.05" y="3.65" curve="41.376652"/>
<vertex x="-4.75" y="0" curve="43.010397"/>
</polygon>
</package>
<package name="UD-10X10_NICHICON" urn="urn:adsk.eagle:footprint:22971/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 10 x 10 mm&lt;p&gt;
Source: http://products.nichicon.co.jp/en/pdf/XJA043/e-ud.pdf</description>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="4.3" x2="5.1" y2="-4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-4.875" y1="0.85" x2="4.875" y2="0.85" width="0.1016" layer="21" curve="-160.259855"/>
<wire x1="-5.1" y1="0.875" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="4.875" y1="-0.85" x2="-4.875" y2="-0.85" width="0.1016" layer="21" curve="-160.259855"/>
<smd name="-" x="-3.95" y="0" dx="3.6" dy="1.3" layer="1"/>
<smd name="+" x="3.925" y="0" dx="3.6" dy="1.3" layer="1"/>
<text x="-5.08" y="5.715" size="1.016" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.35" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-4.05" y="2.8" curve="69.465624"/>
<vertex x="-4.05" y="-2.825"/>
</polygon>
</package>
<package name="UD-4X5,8_NICHICON" urn="urn:adsk.eagle:footprint:22972/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 4 x 5.8 mm&lt;p&gt;
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1.3" x2="2.1" y2="-1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.875" x2="1.75" y2="0.875" width="0.1016" layer="21" curve="-126.263848"/>
<wire x1="-2.1" y1="0.9" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="1.75" y1="-0.875" x2="-1.75" y2="-0.875" width="0.1016" layer="21" curve="-126.263848"/>
<circle x="0" y="0" radius="1.9527" width="0.1016" layer="51"/>
<smd name="-" x="-1.425" y="0" dx="2" dy="1" layer="1"/>
<smd name="+" x="1.425" y="0" dx="2" dy="1" layer="1"/>
<text x="-1.905" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-1.55" y="1.175" curve="72.275472"/>
<vertex x="-1.55" y="-1.175"/>
</polygon>
</package>
<package name="UD-5X5,8_NICHICON" urn="urn:adsk.eagle:footprint:22973/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 5 x 5.8 mm&lt;p&gt;
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.8" x2="2.6" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.3" y1="0.85" x2="2.275" y2="0.9" width="0.1016" layer="21" curve="-137.986421"/>
<wire x1="-2.6" y1="0.7" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="2.3" y1="-0.85" x2="-2.275" y2="-0.9" width="0.1016" layer="21" curve="-137.986421"/>
<circle x="0" y="0" radius="2.4501" width="0.1016" layer="51"/>
<smd name="-" x="-1.7" y="0" dx="2.3" dy="1" layer="1"/>
<smd name="+" x="1.725" y="0" dx="2.3" dy="1" layer="1"/>
<text x="-2.54" y="3.175" size="1.016" layer="25">&gt;NAME</text>
<vertex x="-1.55" y="1.875" curve="100.118878"/>
<vertex x="-1.55" y="-1.875"/>
</polygon>
</package>
<package name="UD-6,3X5,8_NICHICON" urn="urn:adsk.eagle:footprint:22974/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 5.8 mm&lt;p&gt;
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="2.45" x2="3.25" y2="-2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3" y1="0.775" x2="2.975" y2="0.85" width="0.1016" layer="21" curve="-149.753145"/>
<wire x1="-3.25" y1="0.8" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="3" y1="-0.775" x2="-2.975" y2="-0.85" width="0.1016" layer="21" curve="-149.753145"/>
<circle x="0" y="0" radius="3.1001" width="0.1016" layer="51"/>
<smd name="-" x="-2.35" y="0" dx="2.8" dy="1" layer="1"/>
<smd name="+" x="2.35" y="0" dx="2.8" dy="1" layer="1"/>
<text x="-3.175" y="3.81" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.175" y="-4.445" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="2.15" curve="88.581463"/>
<vertex x="-2.2" y="-2.15"/>
</polygon>
</package>
<package name="UD-6,3X7,7_NICHICON" urn="urn:adsk.eagle:footprint:22975/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 7.7 mm&lt;p&gt;
</polygon>
</package>
<package name="UD-8X10_NICHICON" urn="urn:adsk.eagle:footprint:22976/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 8 x 10 mm&lt;p&gt;
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="3.3" x2="4.1" y2="-3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.875" x2="3.85" y2="0.875" width="0.1016" layer="21" curve="-154.459402"/>
<wire x1="-4.1" y1="0.825" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="3.85" y1="-0.875" x2="-3.85" y2="-0.875" width="0.1016" layer="21" curve="-154.459402"/>
<smd name="-" x="-3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<smd name="+" x="3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<text x="-3.81" y="4.445" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="2.475" curve="77.887741"/>
<vertex x="-3.05" y="-2.475"/>
</polygon>
</package>
</packages>
<packages3d>
<package3d name="CT3216" urn="urn:adsk.eagle:package:23327/2" type="model" library_version="3">
<description>TANTALUM CAPACITOR</description>
<packageinstances>
<packageinstance name="CT3216"/>
</packageinstances>
</package3d>
<package3d name="CT3528" urn="urn:adsk.eagle:package:23325/2" type="model" library_version="3">
<packageinstances>
<packageinstance name="CT3528"/>
</packageinstances>
</package3d>
<package3d name="CT6032" urn="urn:adsk.eagle:package:23305/2" type="model" library_version="3">
<packageinstances>
<packageinstance name="CT6032"/>
</packageinstances>
</package3d>
<package3d name="CT7343" urn="urn:adsk.eagle:package:23304/2" type="model" library_version="3">
<packageinstances>
<packageinstance name="CT7343"/>
</packageinstances>
</package3d>
<package3d name="B45181A" urn="urn:adsk.eagle:package:23316/1" type="box" library_version="3">
<description>ELECTROLYTIC CAPACITOR
body 5 x 5 mm, rectangle, grid 2.54 mm</description>
<packageinstances>
<packageinstance name="B45181A"/>
</packageinstances>
</package3d>
<package3d name="B45181B" urn="urn:adsk.eagle:package:23320/1" type="box" library_version="3">
body 7.6 x 5 mm, rectangle, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="B45181B"/>
</packageinstances>
</package3d>
<package3d name="B45181C" urn="urn:adsk.eagle:package:23306/1" type="box" library_version="3">
body 12.7 x 7.6 mm, rectangle, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="B45181C"/>
</packageinstances>
</package3d>
<package3d name="B45181D" urn="urn:adsk.eagle:package:23308/1" type="box" library_version="3">
body 12.5 x 12.5 mm, rectangle, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="B45181D"/>
</packageinstances>
</package3d>
<package3d name="TT2D4" urn="urn:adsk.eagle:package:23310/1" type="box" library_version="3">
diameter 4 mm, grid 2.54 mm</description>
<packageinstances>
<packageinstance name="TT2D4"/>
</packageinstances>
</package3d>
<package3d name="TT2D4L" urn="urn:adsk.eagle:package:23321/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="TT2D4L"/>
</packageinstances>
</package3d>
<package3d name="TT2D5" urn="urn:adsk.eagle:package:23300/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="TT2D5"/>
</packageinstances>
</package3d>
<package3d name="TT2D6" urn="urn:adsk.eagle:package:23303/1" type="box" library_version="3">
diameter 6 mm, grid 2.54 mm</description>
<packageinstances>
<packageinstance name="TT2D6"/>
</packageinstances>
</package3d>
<package3d name="TT2D6L" urn="urn:adsk.eagle:package:23323/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="TT2D6L"/>
</packageinstances>
</package3d>
<package3d name="TT2D7L" urn="urn:adsk.eagle:package:23329/1" type="box" library_version="3">
diameter 7 mm, grid 2.54 mm</description>
<packageinstances>
<packageinstance name="TT2D7L"/>
</packageinstances>
</package3d>
<package3d name="TT2D7" urn="urn:adsk.eagle:package:23319/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="TT2D7"/>
</packageinstances>
</package3d>
<package3d name="TT5D10" urn="urn:adsk.eagle:package:23302/1" type="box" library_version="3">
diameter 10 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D10"/>
</packageinstances>
</package3d>
<package3d name="TT5D11" urn="urn:adsk.eagle:package:23309/1" type="box" library_version="3">
diameter 11 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D11"/>
</packageinstances>
</package3d>
<package3d name="TT5D11L" urn="urn:adsk.eagle:package:23312/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="TT5D11L"/>
</packageinstances>
</package3d>
<package3d name="TT5D6" urn="urn:adsk.eagle:package:23307/1" type="box" library_version="3">
diameter 6 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D6"/>
</packageinstances>
</package3d>
<package3d name="TT5D6L" urn="urn:adsk.eagle:package:23324/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="TT5D6L"/>
</packageinstances>
</package3d>
<package3d name="TT5D7" urn="urn:adsk.eagle:package:23314/1" type="box" library_version="3">
diameter 7 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D7"/>
</packageinstances>
</package3d>
<package3d name="TT5D7L" urn="urn:adsk.eagle:package:23318/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="TT5D7L"/>
</packageinstances>
</package3d>
<package3d name="TT5D9" urn="urn:adsk.eagle:package:23301/1" type="box" library_version="3">
diameter 9 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D9"/>
</packageinstances>
</package3d>
<package3d name="TT5D9L" urn="urn:adsk.eagle:package:23313/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="TT5D9L"/>
</packageinstances>
</package3d>
<package3d name="ETR1" urn="urn:adsk.eagle:package:23322/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="ETR1"/>
</packageinstances>
</package3d>
<package3d name="ETR2" urn="urn:adsk.eagle:package:23315/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="ETR2"/>
</packageinstances>
</package3d>
<package3d name="ETR3" urn="urn:adsk.eagle:package:23311/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="ETR3"/>
</packageinstances>
</package3d>
<package3d name="ETR4" urn="urn:adsk.eagle:package:23317/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="ETR4"/>
</packageinstances>
</package3d>
<package3d name="ETR5" urn="urn:adsk.eagle:package:23328/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="ETR5"/>
</packageinstances>
</package3d>
<package3d name="P128-35" urn="urn:adsk.eagle:package:23326/1" type="box" library_version="3">
<description>ELECTROLYTIC CAPACITOR</description>
<packageinstances>
<packageinstance name="P128-35"/>
</packageinstances>
</package3d>
<package3d name="P128-40" urn="urn:adsk.eagle:package:23331/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="P128-40"/>
</packageinstances>
</package3d>
<package3d name="P128-50" urn="urn:adsk.eagle:package:23330/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="P128-50"/>
</packageinstances>
</package3d>
<package3d name="P128-60" urn="urn:adsk.eagle:package:23337/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="P128-60"/>
</packageinstances>
</package3d>
<package3d name="TAP5-45" urn="urn:adsk.eagle:package:23333/3" type="model" library_version="3">
diameter 4.5 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-45"/>
</packageinstances>
</package3d>
<package3d name="TAP5-50" urn="urn:adsk.eagle:package:23335/1" type="box" library_version="3">
diameter 5.0 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-50"/>
</packageinstances>
</package3d>
<package3d name="TAP5-70" urn="urn:adsk.eagle:package:23332/1" type="box" library_version="3">
diameter 7.0 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-70"/>
</packageinstances>
</package3d>
<package3d name="TAP5-60" urn="urn:adsk.eagle:package:23334/1" type="box" library_version="3">
diameter 6.0 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-60"/>
</packageinstances>
</package3d>
<package3d name="TAP5-80" urn="urn:adsk.eagle:package:23338/1" type="box" library_version="3">
diameter 8.0 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-80"/>
</packageinstances>
</package3d>
<package3d name="E1,8-4" urn="urn:adsk.eagle:package:23336/2" type="model" library_version="3">
grid 1.8 mm, diameter 4 mm</description>
<packageinstances>
<packageinstance name="E1,8-4"/>
</packageinstances>
</package3d>
<package3d name="E15-5" urn="urn:adsk.eagle:package:23341/1" type="box" library_version="3">
grid 15.24 mm, diameter 5 mm</description>
<packageinstances>
<packageinstance name="E15-5"/>
</packageinstances>
</package3d>
<package3d name="E15-6" urn="urn:adsk.eagle:package:23339/1" type="box" library_version="3">
grid 15.24 mm, diameter 6 mm</description>
<packageinstances>
<packageinstance name="E15-6"/>
</packageinstances>
</package3d>
<package3d name="E15-9" urn="urn:adsk.eagle:package:23340/1" type="box" library_version="3">
grid 15.24 mm, diameter 9 mm</description>
<packageinstances>
<packageinstance name="E15-9"/>
</packageinstances>
</package3d>
<package3d name="E2,5-4R" urn="urn:adsk.eagle:package:23342/1" type="box" library_version="3">
grid 2.54 mm, diameter 4 mm</description>
<packageinstances>
<packageinstance name="E2,5-4R"/>
</packageinstances>
</package3d>
<package3d name="E2,5-5" urn="urn:adsk.eagle:package:23344/1" type="box" library_version="3">
grid 2.54 mm, diameter 5 mm</description>
<packageinstances>
<packageinstance name="E2,5-5"/>
</packageinstances>
</package3d>
<package3d name="E2,5-6" urn="urn:adsk.eagle:package:23349/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="E2,5-6"/>
</packageinstances>
</package3d>
<package3d name="E2,5-7" urn="urn:adsk.eagle:package:23345/1" type="box" library_version="3">
grid 2.54 mm, diameter 7 mm</description>
<packageinstances>
<packageinstance name="E2,5-7"/>
</packageinstances>
</package3d>
<package3d name="E2,5RE" urn="urn:adsk.eagle:package:23343/1" type="box" library_version="3">
grid 2.54 mm, diameter 4 mm,</description>
<packageinstances>
<packageinstance name="E2,5RE"/>
</packageinstances>
</package3d>
<package3d name="E2-4" urn="urn:adsk.eagle:package:23347/1" type="box" library_version="3">
grid 2 mm, diameter 4 mm</description>
<packageinstances>
<packageinstance name="E2-4"/>
</packageinstances>
</package3d>
<package3d name="E2-5" urn="urn:adsk.eagle:package:23346/2" type="model" library_version="3">
grid 2.032 mm, diameter 5 mm</description>
<packageinstances>
<packageinstance name="E2-5"/>
</packageinstances>
</package3d>
<package3d name="E22-10" urn="urn:adsk.eagle:package:23348/1" type="box" library_version="3">
grid 22.86 mm, diameter 10 mm</description>
<packageinstances>
<packageinstance name="E22-10"/>
</packageinstances>
</package3d>
<package3d name="E22-6" urn="urn:adsk.eagle:package:23359/1" type="box" library_version="3">
grid 22.86 mm, diameter 6 mm</description>
<packageinstances>
<packageinstance name="E22-6"/>
</packageinstances>
</package3d>
<package3d name="E22-9" urn="urn:adsk.eagle:package:23350/1" type="box" library_version="3">
grid 22.86 mm, diameter 9 mm</description>
<packageinstances>
<packageinstance name="E22-9"/>
</packageinstances>
</package3d>
<package3d name="E3,5-10" urn="urn:adsk.eagle:package:23351/1" type="box" library_version="3">
grid 3.5 mm, diameter 10 mm</description>
<packageinstances>
<packageinstance name="E3,5-10"/>
</packageinstances>
</package3d>
<package3d name="E25-10" urn="urn:adsk.eagle:package:23352/1" type="box" library_version="3">
grid 25.4 mm, diameter 10 mm</description>
<packageinstances>
<packageinstance name="E25-10"/>
</packageinstances>
</package3d>
<package3d name="E25-9" urn="urn:adsk.eagle:package:23358/1" type="box" library_version="3">
grid 25.4 mm, diameter 9 mm</description>
<packageinstances>
<packageinstance name="E25-9"/>
</packageinstances>
</package3d>
<package3d name="E3,5-8" urn="urn:adsk.eagle:package:23360/2" type="model" library_version="3">
grid 3.5 mm, diameter 8 mm</description>
<packageinstances>
<packageinstance name="E3,5-8"/>
</packageinstances>
</package3d>
<package3d name="E30-10" urn="urn:adsk.eagle:package:23355/1" type="box" library_version="3">
grid 30.48 mm, diameter 10 mm</description>
<packageinstances>
<packageinstance name="E30-10"/>
</packageinstances>
</package3d>
<package3d name="E30-12" urn="urn:adsk.eagle:package:23354/1" type="box" library_version="3">
grid 30.48 mm, diameter 12 mm</description>
<packageinstances>
<packageinstance name="E30-12"/>
</packageinstances>
</package3d>
<package3d name="E30-16" urn="urn:adsk.eagle:package:23353/1" type="box" library_version="3">
grid 30.48 mm, diameter 16 mm</description>
<packageinstances>
<packageinstance name="E30-16"/>
</packageinstances>
</package3d>
<package3d name="E35-12" urn="urn:adsk.eagle:package:23357/1" type="box" library_version="3">
grid 35.56 mm, diameter 12 mm</description>
<packageinstances>
<packageinstance name="E35-12"/>
</packageinstances>
</package3d>
<package3d name="E35-14" urn="urn:adsk.eagle:package:23377/1" type="box" library_version="3">
grid 30.48 mm, diameter 14 mm</description>
<packageinstances>
<packageinstance name="E35-14"/>
</packageinstances>
</package3d>
<package3d name="E35-16" urn="urn:adsk.eagle:package:23362/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="E35-16"/>
</packageinstances>
</package3d>
<package3d name="E35-18" urn="urn:adsk.eagle:package:23356/1" type="box" library_version="3">
grid 30.48 mm, diameter 18 mm</description>
<packageinstances>
<packageinstance name="E35-18"/>
</packageinstances>
</package3d>
<package3d name="E45-16" urn="urn:adsk.eagle:package:23365/1" type="box" library_version="3">
grid 45.72 mm, diameter 16 mm</description>
<packageinstances>
<packageinstance name="E45-16"/>
</packageinstances>
</package3d>
<package3d name="E45-18" urn="urn:adsk.eagle:package:23361/1" type="box" library_version="3">
grid 45.72 mm, diameter 18 mm</description>
<packageinstances>
<packageinstance name="E45-18"/>
</packageinstances>
</package3d>
<package3d name="E45-21" urn="urn:adsk.eagle:package:23363/1" type="box" library_version="3">
grid 45.72 mm, diameter 21 mm</description>
<packageinstances>
<packageinstance name="E45-21"/>
</packageinstances>
</package3d>
<package3d name="E45-22" urn="urn:adsk.eagle:package:23366/1" type="box" library_version="3">
grid 45.72 mm, diameter 22 mm</description>
<packageinstances>
<packageinstance name="E45-22"/>
</packageinstances>
</package3d>
<package3d name="E45-25" urn="urn:adsk.eagle:package:23364/1" type="box" library_version="3">
grid 45.72 mm, diameter 25 mm</description>
<packageinstances>
<packageinstance name="E45-25"/>
</packageinstances>
</package3d>
<package3d name="E5-10,5" urn="urn:adsk.eagle:package:23372/1" type="box" library_version="3">
grid 5.08 mm, diameter 10.5 mm</description>
<packageinstances>
<packageinstance name="E5-10,5"/>
</packageinstances>
</package3d>
<package3d name="E5-13" urn="urn:adsk.eagle:package:23375/1" type="box" library_version="3">
grid 5.08 mm, diameter 13 mm</description>
<packageinstances>
<packageinstance name="E5-13"/>
</packageinstances>
</package3d>
<package3d name="E5-4" urn="urn:adsk.eagle:package:23370/1" type="box" library_version="3">
grid 5.05 mm, diameter 4 mm</description>
<packageinstances>
<packageinstance name="E5-4"/>
</packageinstances>
</package3d>
<package3d name="E5-5" urn="urn:adsk.eagle:package:23367/1" type="box" library_version="3">
grid 5.08 mm, diameter 5 mm</description>
<packageinstances>
<packageinstance name="E5-5"/>
</packageinstances>
</package3d>
<package3d name="E5-6" urn="urn:adsk.eagle:package:23368/1" type="box" library_version="3">
grid 5.08 mm, diameter 6 mm</description>
<packageinstances>
<packageinstance name="E5-6"/>
</packageinstances>
</package3d>
<package3d name="E5-8,5" urn="urn:adsk.eagle:package:23374/1" type="box" library_version="3">
grid 5.08 mm, diameter 8.5 mm</description>
<packageinstances>
<packageinstance name="E5-8,5"/>
</packageinstances>
</package3d>
<package3d name="E50-25" urn="urn:adsk.eagle:package:23369/1" type="box" library_version="3">
grid 50 mm, diameter 25 mm</description>
<packageinstances>
<packageinstance name="E50-25"/>
</packageinstances>
</package3d>
<package3d name="E50-30" urn="urn:adsk.eagle:package:23371/1" type="box" library_version="3">
grid 50 mm, diameter 30 mm</description>
<packageinstances>
<packageinstance name="E50-30"/>
</packageinstances>
</package3d>
<package3d name="E55-25" urn="urn:adsk.eagle:package:23376/1" type="box" library_version="3">
grid 55 mm, diameter 25 mm</description>
<packageinstances>
<packageinstance name="E55-25"/>
</packageinstances>
</package3d>
<package3d name="E55-30" urn="urn:adsk.eagle:package:23378/1" type="box" library_version="3">
grid 55 mm, diameter 30 mm</description>
<packageinstances>
<packageinstance name="E55-30"/>
</packageinstances>
</package3d>
<package3d name="E5R" urn="urn:adsk.eagle:package:23373/1" type="box" library_version="3">
grid 5.08 mm, diameter 9 mm</description>
<packageinstances>
<packageinstance name="E5R"/>
</packageinstances>
</package3d>
<package3d name="E7,5-16" urn="urn:adsk.eagle:package:23382/2" type="model" library_version="3">
grid 7.62 mm, diameter 16 mm</description>
<packageinstances>
<packageinstance name="E7,5-16"/>
</packageinstances>
</package3d>
<package3d name="E7,5-18" urn="urn:adsk.eagle:package:23379/1" type="box" library_version="3">
grid 7.62 mm, diameter 18 mm</description>
<packageinstances>
<packageinstance name="E7,5-18"/>
</packageinstances>
</package3d>
<package3d name="EB20D" urn="urn:adsk.eagle:package:23381/1" type="box" library_version="3">
grid 10.16 mm, diameter 20 mm</description>
<packageinstances>
<packageinstance name="EB20D"/>
</packageinstances>
</package3d>
<package3d name="EB22,5D" urn="urn:adsk.eagle:package:23380/1" type="box" library_version="3">
grid 10.16 mm, diameter 22.5 mm</description>
<packageinstances>
<packageinstance name="EB22,5D"/>
</packageinstances>
</package3d>
<package3d name="EB25D" urn="urn:adsk.eagle:package:23399/1" type="box" library_version="3">
grid 10.16 mm, diameter 25 mm</description>
<packageinstances>
<packageinstance name="EB25D"/>
</packageinstances>
</package3d>
<package3d name="EB30D" urn="urn:adsk.eagle:package:23389/1" type="box" library_version="3">
grid 10.16 mm, diameter 30 mm</description>
<packageinstances>
<packageinstance name="EB30D"/>
</packageinstances>
</package3d>
<package3d name="EB35D" urn="urn:adsk.eagle:package:23395/1" type="box" library_version="3">
grid 10.16 mm, diameter 35 mm</description>
<packageinstances>
<packageinstance name="EB35D"/>
</packageinstances>
</package3d>
<package3d name="085CS_1R" urn="urn:adsk.eagle:package:23383/1" type="box" library_version="3">
<description>Aluminum electrolytic capacitors reflow soldering
SMD (Chip) Standard 085 CS
http://www.bccomponents.com/</description>
<packageinstances>
<packageinstance name="085CS_1R"/>
</packageinstances>
</package3d>
<package3d name="085CS_1W" urn="urn:adsk.eagle:package:23384/1" type="box" library_version="3">
<description>Aluminum electrolytic capacitors wave soldering
<packageinstances>
<packageinstance name="085CS_1W"/>
</packageinstances>
</package3d>
<package3d name="085CS_1AR" urn="urn:adsk.eagle:package:23396/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="085CS_1AR"/>
</packageinstances>
</package3d>
<package3d name="085CS_1AW" urn="urn:adsk.eagle:package:23385/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="085CS_1AW"/>
</packageinstances>
</package3d>
<package3d name="139CLL-2R" urn="urn:adsk.eagle:package:23387/1" type="box" library_version="3">
SMD (Chip) Long Life 139 CLL
<packageinstances>
<packageinstance name="139CLL-2R"/>
</packageinstances>
</package3d>
<package3d name="139CLL-2W" urn="urn:adsk.eagle:package:23386/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="139CLL-2W"/>
</packageinstances>
</package3d>
<package3d name="139CLL-3R" urn="urn:adsk.eagle:package:23388/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="139CLL-3R"/>
</packageinstances>
</package3d>
<package3d name="139CLL-3W" urn="urn:adsk.eagle:package:23390/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="139CLL-3W"/>
</packageinstances>
</package3d>
<package3d name="140CLH-0810" urn="urn:adsk.eagle:package:23392/1" type="box" library_version="3">
<description>Aluminum electrolytic capacitors SMD (Chip)
Long life base plate, High temperature 140 CLH
<packageinstances>
<packageinstance name="140CLH-0810"/>
</packageinstances>
</package3d>
<package3d name="140CLH-1010" urn="urn:adsk.eagle:package:23391/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="140CLH-1010"/>
</packageinstances>
</package3d>
<package3d name="140CLH-1014" urn="urn:adsk.eagle:package:23393/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="140CLH-1014"/>
</packageinstances>
</package3d>
<package3d name="150CLZ-0810" urn="urn:adsk.eagle:package:23394/1" type="box" library_version="3">
Long life base plate, very low impedance 150 CLZ
<packageinstances>
<packageinstance name="150CLZ-0810"/>
</packageinstances>
</package3d>
<package3d name="150CLZ-1010" urn="urn:adsk.eagle:package:23403/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="150CLZ-1010"/>
</packageinstances>
</package3d>
<package3d name="150CLZ-1014" urn="urn:adsk.eagle:package:23405/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="150CLZ-1014"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0405" urn="urn:adsk.eagle:package:23397/1" type="box" library_version="3">
SMD (Chip) Long Life Vertical 153 CLV
<packageinstances>
<packageinstance name="153CLV-0405"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0505" urn="urn:adsk.eagle:package:23402/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="153CLV-0505"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0605" urn="urn:adsk.eagle:package:23398/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="153CLV-0605"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0807" urn="urn:adsk.eagle:package:23400/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="153CLV-0807"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0810" urn="urn:adsk.eagle:package:23401/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="153CLV-0810"/>
</packageinstances>
</package3d>
<package3d name="153CLV-1010" urn="urn:adsk.eagle:package:23413/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="153CLV-1010"/>
</packageinstances>
</package3d>
<package3d name="153CLV-1012" urn="urn:adsk.eagle:package:23404/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="153CLV-1012"/>
</packageinstances>
</package3d>
<package3d name="153CLV-1014" urn="urn:adsk.eagle:package:23406/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="153CLV-1014"/>
</packageinstances>
</package3d>
<package3d name="175TMP-0808" urn="urn:adsk.eagle:package:23412/1" type="box" library_version="3">
High Temperature solid electrolytic SMD 175 TMP
<packageinstances>
<packageinstance name="175TMP-0808"/>
</packageinstances>
</package3d>
<package3d name="175TMP-0810" urn="urn:adsk.eagle:package:23407/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="175TMP-0810"/>
</packageinstances>
</package3d>
<package3d name="A/3216-18R" urn="urn:adsk.eagle:package:23410/2" type="model" library_version="3">
<description>Chip Capacitor Type KEMET A / EIA 3216-18 reflow solderKEMET S / EIA 3216-12</description>
<packageinstances>
<packageinstance name="A/3216-18R"/>
</packageinstances>
</package3d>
<package3d name="A/3216-18W" urn="urn:adsk.eagle:package:23408/2" type="model" library_version="3">
<description>Chip Capacitor Type KEMET A / EIA 3216-18 Wave solder
<packageinstances>
<packageinstance name="A/3216-18W"/>
</packageinstances>
</package3d>
<package3d name="B/3528-21R" urn="urn:adsk.eagle:package:23409/2" type="model" library_version="3">
<description>Chip Capacitor Type KEMET B / EIA 3528-21 reflow solderKEMET T / EIA 3528-12</description>
<packageinstances>
<packageinstance name="B/3528-21R"/>
</packageinstances>
</package3d>
<package3d name="B/3528-21W" urn="urn:adsk.eagle:package:23411/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET B / EIA 3528-21 Wave solder
<packageinstances>
<packageinstance name="B/3528-21W"/>
</packageinstances>
</package3d>
<package3d name="C/6032-28R" urn="urn:adsk.eagle:package:23415/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET C / EIA 6032-28 reflow solderKEMET U / EIA 6032-15</description>
<packageinstances>
<packageinstance name="C/6032-28R"/>
</packageinstances>
</package3d>
<package3d name="C/6032-28W" urn="urn:adsk.eagle:package:23420/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET C / EIA 6032-28 Wafe solder
<packageinstances>
<packageinstance name="C/6032-28W"/>
</packageinstances>
</package3d>
<package3d name="D/7343-31R" urn="urn:adsk.eagle:package:23417/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET D / EIA 7343-21KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 reflow solder</description>
<packageinstances>
<packageinstance name="D/7343-31R"/>
</packageinstances>
</package3d>
<package3d name="D/7343-31W" urn="urn:adsk.eagle:package:23414/1" type="box" library_version="3">
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Wafe solder</description>
<packageinstances>
<packageinstance name="D/7343-31W"/>
</packageinstances>
</package3d>
<package3d name="E/7260-38R" urn="urn:adsk.eagle:package:23416/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET E / EIA 7260-38 reflow solder</description>
<packageinstances>
<packageinstance name="E/7260-38R"/>
</packageinstances>
</package3d>
<package3d name="E/7260-38W" urn="urn:adsk.eagle:package:23423/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET E / EIA 7260-38 Wafe solder</description>
<packageinstances>
<packageinstance name="E/7260-38W"/>
</packageinstances>
</package3d>
<package3d name="R/2012-12R" urn="urn:adsk.eagle:package:23426/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET R/EIA 2012-12 reflow solder</description>
<packageinstances>
<packageinstance name="R/2012-12R"/>
</packageinstances>
</package3d>
<package3d name="R/2012-12W" urn="urn:adsk.eagle:package:23419/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET R/EIA 2012-12 Wafe solder</description>
<packageinstances>
<packageinstance name="R/2012-12W"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_A" urn="urn:adsk.eagle:package:23418/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package A</description>
<packageinstances>
<packageinstance name="PANASONIC_A"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_B" urn="urn:adsk.eagle:package:23421/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package B</description>
<packageinstances>
<packageinstance name="PANASONIC_B"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_C" urn="urn:adsk.eagle:package:23422/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package C</description>
<packageinstances>
<packageinstance name="PANASONIC_C"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_D" urn="urn:adsk.eagle:package:23424/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D</description>
<packageinstances>
<packageinstance name="PANASONIC_D"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_E" urn="urn:adsk.eagle:package:23425/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package E</description>
<packageinstances>
<packageinstance name="PANASONIC_E"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_F" urn="urn:adsk.eagle:package:23428/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package F</description>
<packageinstances>
<packageinstance name="PANASONIC_F"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_G" urn="urn:adsk.eagle:package:23427/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G</description>
<packageinstances>
<packageinstance name="PANASONIC_G"/>
</packageinstances>
</package3d>
<package3d name="TT2D5L" urn="urn:adsk.eagle:package:23429/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="TT2D5L"/>
</packageinstances>
</package3d>
<package3d name="E2,5-6E" urn="urn:adsk.eagle:package:23430/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="E2,5-6E"/>
</packageinstances>
</package3d>
<package3d name="SMC_A" urn="urn:adsk.eagle:package:23431/1" type="box" library_version="3">
<description>Chip Capacitor  Polar tantalum capacitors with solid electrolyte
<packageinstances>
<packageinstance name="SMC_A"/>
</packageinstances>
</package3d>
<package3d name="SMC_Z" urn="urn:adsk.eagle:package:23433/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SMC_Z"/>
</packageinstances>
</package3d>
<package3d name="SMC_P" urn="urn:adsk.eagle:package:23432/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SMC_P"/>
</packageinstances>
</package3d>
<package3d name="SMC_B" urn="urn:adsk.eagle:package:23436/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SMC_B"/>
</packageinstances>
</package3d>
<package3d name="SMC_C" urn="urn:adsk.eagle:package:23435/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SMC_C"/>
</packageinstances>
</package3d>
<package3d name="SMC_D" urn="urn:adsk.eagle:package:23434/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SMC_D"/>
</packageinstances>
</package3d>
<package3d name="SMC_E" urn="urn:adsk.eagle:package:23446/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SMC_E"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_9E" urn="urn:adsk.eagle:package:23439/1" type="box" library_version="3">
<description>SANYO OSCON Capacitor
<packageinstances>
<packageinstance name="SANYO-OSCON_9E"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_9F" urn="urn:adsk.eagle:package:23437/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_9F"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_A" urn="urn:adsk.eagle:package:23438/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_A"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_A'" urn="urn:adsk.eagle:package:23440/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_A'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_B" urn="urn:adsk.eagle:package:23449/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_B"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_B'" urn="urn:adsk.eagle:package:23442/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_B'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_C" urn="urn:adsk.eagle:package:23441/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_C"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_C'" urn="urn:adsk.eagle:package:23443/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_C'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_C6" urn="urn:adsk.eagle:package:23444/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_C6"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_D" urn="urn:adsk.eagle:package:23445/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_D"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E" urn="urn:adsk.eagle:package:23451/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_E"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E'" urn="urn:adsk.eagle:package:23453/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_E'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E1" urn="urn:adsk.eagle:package:23447/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_E1"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E12" urn="urn:adsk.eagle:package:23448/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_E12"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E13" urn="urn:adsk.eagle:package:23454/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_E13"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E7" urn="urn:adsk.eagle:package:23452/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_E7"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E9" urn="urn:adsk.eagle:package:23457/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_E9"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F" urn="urn:adsk.eagle:package:23462/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_F"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F'" urn="urn:adsk.eagle:package:23450/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_F'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F0" urn="urn:adsk.eagle:package:23459/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_F0"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F13" urn="urn:adsk.eagle:package:23455/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_F13"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F8" urn="urn:adsk.eagle:package:23456/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_F8"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_G" urn="urn:adsk.eagle:package:23458/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_G"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_H" urn="urn:adsk.eagle:package:23463/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_H"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_A5" urn="urn:adsk.eagle:package:23460/1" type="box" library_version="3">
<description>SANYO OSCON Capacitor SMD type with conductive polymer electrolyte
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_A5"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_B6" urn="urn:adsk.eagle:package:23461/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_B6"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_C6" urn="urn:adsk.eagle:package:23465/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_C6"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_E12" urn="urn:adsk.eagle:package:23464/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_E12"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_E7" urn="urn:adsk.eagle:package:23467/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_E7"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_F12" urn="urn:adsk.eagle:package:23468/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_F12"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_F8" urn="urn:adsk.eagle:package:23466/1" type="box" library_version="3">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_F8"/>
</packageinstances>
</package3d>
<package3d name="UD-10X10_NICHICON" urn="urn:adsk.eagle:package:23469/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 10 x 10 mm
<packageinstances>
<packageinstance name="UD-10X10_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-4X5,8_NICHICON" urn="urn:adsk.eagle:package:23474/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 4 x 5.8 mm
<packageinstances>
<packageinstance name="UD-4X5,8_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-5X5,8_NICHICON" urn="urn:adsk.eagle:package:23470/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 5 x 5.8 mm
<packageinstances>
<packageinstance name="UD-5X5,8_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-6,3X5,8_NICHICON" urn="urn:adsk.eagle:package:23471/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 6.3 x 5.8 mm
<packageinstances>
<packageinstance name="UD-6,3X5,8_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-6,3X7,7_NICHICON" urn="urn:adsk.eagle:package:23472/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 6.3 x 7.7 mm
<packageinstances>
<packageinstance name="UD-6,3X7,7_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-8X10_NICHICON" urn="urn:adsk.eagle:package:23473/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 8 x 10 mm
<packageinstances>
<packageinstance name="UD-8X10_NICHICON"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="CPOL" urn="urn:adsk.eagle:symbol:22801/1" library_version="3">
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="-1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="1.524" y2="0" width="0.254" layer="94"/>
<text x="1.143" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="-0.5842" y="0.4064" size="1.27" layer="94" rot="R90">+</text>
<text x="1.143" y="-4.5974" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.54" x2="1.651" y2="-1.651" layer="94"/>
<pin name="-" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="+" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="CPOL-EU" urn="urn:adsk.eagle:component:23787/21" prefix="C" uservalue="yes" library_version="3">
<description>&lt;B&gt;POLARIZED CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="CPOL" x="0" y="0"/>
</gates>
<devices>
<device name="CT3216" package="CT3216">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23327/2"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="SPICEPREFIX" value="C" constant="no"/>
</technology>
</technologies>
</device>
<device name="CT3528" package="CT3528">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23325/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CT6032" package="CT6032">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23305/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CT7343" package="CT7343">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23304/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181A" package="B45181A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23316/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181B" package="B45181B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23320/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181C" package="B45181C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23306/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181D" package="B45181D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23308/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D4" package="TT2D4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23310/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D4L" package="TT2D4L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23321/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D5" package="TT2D5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23300/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D6" package="TT2D6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23303/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D6L" package="TT2D6L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23323/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D7L" package="TT2D7L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23329/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D7" package="TT2D7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23319/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D10" package="TT5D10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23302/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D11" package="TT5D11">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23309/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D11L" package="TT5D11L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23312/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT6D6" package="TT5D6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23307/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D6L" package="TT5D6L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23324/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D7" package="TT5D7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23314/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D7L" package="TT5D7L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23318/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D9" package="TT5D9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23301/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D9L" package="TT5D9L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23313/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR1" package="ETR1">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23322/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR2" package="ETR2">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23315/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR3" package="ETR3">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23311/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR4" package="ETR4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23317/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR5" package="ETR5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23328/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-35" package="P128-35">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23326/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-40" package="P128-40">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23331/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-50" package="P128-50">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23330/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-60" package="P128-60">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23337/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-45" package="TAP5-45">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23333/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-50" package="TAP5-50">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23335/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-70" package="TAP5-70">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23332/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-60" package="TAP5-60">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23334/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-80" package="TAP5-80">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23338/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E1.8-4" package="E1,8-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23336/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E15-5AXIAL" package="E15-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23341/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E15-6AXIAL" package="E15-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23339/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E15-9AXIAL" package="E15-9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23340/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-5V" package="E2,5-4R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23342/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-5" package="E2,5-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23344/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-6" package="E2,5-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23349/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-7" package="E2,5-7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23345/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-4V" package="E2,5RE">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23343/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2-4" package="E2-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23347/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2-5" package="E2-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23346/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E22-10AXIAL" package="E22-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23348/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E22-6AXIAL" package="E22-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23359/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E22-9AXIAL" package="E22-9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23350/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E3.5-10" package="E3,5-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23351/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E25-10AXIAL" package="E25-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23352/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E25-9AXIAL" package="E25-9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23358/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E3.5-8" package="E3,5-8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23360/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E30-10AXIAL" package="E30-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23355/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E30-12AXIAL" package="E30-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23354/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E30-16AXIAL" package="E30-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23353/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-12AXIAL" package="E35-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23357/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-14AXIAL" package="E35-14">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23377/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-16AXIAL" package="E35-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23362/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-18AXIAL" package="E35-18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23356/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-16AXIAL" package="E45-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23365/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-18AXIAL" package="E45-18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23361/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-21AXIAL" package="E45-21">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23363/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-22AXIAL" package="E45-22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23366/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-25AXIAL" package="E45-25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23364/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-10.5" package="E5-10,5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23372/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-13" package="E5-13">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23375/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-4" package="E5-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23370/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-5" package="E5-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23367/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-6" package="E5-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23368/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-8.5" package="E5-8,5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23374/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E50-25AXIAL" package="E50-25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23369/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E50-30AXIAL" package="E50-30">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23371/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E55-25AXIAL" package="E55-25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23376/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E55-30AXIAL" package="E55-30">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23378/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-9VAXIAL" package="E5R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23373/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E7.5-16" package="E7,5-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23382/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E7.5-18" package="E7,5-18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23379/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-20" package="EB20D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23381/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-22.5" package="EB22,5D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23380/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-25" package="EB25D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23399/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-30" package="EB30D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23389/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-35" package="EB35D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23395/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1R" package="085CS_1R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23383/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1W" package="085CS_1W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23384/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1AR" package="085CS_1AR">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23396/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1AW" package="085CS_1AW">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23385/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-2R" package="139CLL-2R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23387/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-2W" package="139CLL-2W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23386/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-3R" package="139CLL-3R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23388/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-3W" package="139CLL-3W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23390/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="140CLH-0810" package="140CLH-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23392/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="140CLH-1010" package="140CLH-1010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23391/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="140CLH-1014" package="140CLH-1014">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23393/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150CLZ-0810" package="150CLZ-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23394/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150CLZ-1010" package="150CLZ-1010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23403/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150CLZ-1014" package="150CLZ-1014">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23405/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0405" package="153CLV-0405">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23397/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0505" package="153CLV-0505">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23402/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0605" package="153CLV-0605">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23398/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0807" package="153CLV-0807">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23400/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0810" package="153CLV-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23401/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-1010" package="153CLV-1010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23413/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-1012" package="153CLV-1012">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23404/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-1014" package="153CLV-1014">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23406/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="175TMP-0808" package="175TMP-0808">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23412/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="175TMP-0810" package="175TMP-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23407/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="A/3216-18R" package="A/3216-18R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23410/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="A/3216-18W" package="A/3216-18W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23408/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B/3528-21R" package="B/3528-21R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23409/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B/3528-21W" package="B/3528-21W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23411/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C/6032-28R" package="C/6032-28R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23415/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C/6032-28W" package="C/6032-28W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23420/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D/7343-31R" package="D/7343-31R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23417/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D/7343-31W" package="D/7343-31W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23414/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E/7260-38R" package="E/7260-38R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23416/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E/7260-38W" package="E/7260-38W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23423/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R/2012-12R" package="R/2012-12R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23426/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R/2012-12W" package="R/2012-12W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23419/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="A" package="PANASONIC_A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23418/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B" package="PANASONIC_B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23421/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C" package="PANASONIC_C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23422/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D" package="PANASONIC_D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23424/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E" package="PANASONIC_E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23425/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="F" package="PANASONIC_F">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23428/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="G" package="PANASONIC_G">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23427/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D5L" package="TT2D5L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23429/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2,5-6E" package="E2,5-6E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23430/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCA" package="SMC_A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23431/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCZ" package="SMC_Z">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23433/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCP" package="SMC_P">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23432/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCB" package="SMC_B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23436/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCC" package="SMC_C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23435/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCD" package="SMC_D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23434/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCE" package="SMC_E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23446/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_9E" package="SANYO-OSCON_9E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23439/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_9F" package="SANYO-OSCON_9F">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23437/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_A" package="SANYO-OSCON_A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23438/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_A'" package="SANYO-OSCON_A'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23440/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_B" package="SANYO-OSCON_B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23449/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_B'" package="SANYO-OSCON_B'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23442/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_C" package="SANYO-OSCON_C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23441/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_C'" package="SANYO-OSCON_C'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23443/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_C6" package="SANYO-OSCON_C6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23444/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_D" package="SANYO-OSCON_D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23445/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E" package="SANYO-OSCON_E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23451/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E'" package="SANYO-OSCON_E'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23453/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E1" package="SANYO-OSCON_E1">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23447/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E12" package="SANYO-OSCON_E12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23448/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E13" package="SANYO-OSCON_E13">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23454/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E7" package="SANYO-OSCON_E7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23452/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E9" package="SANYO-OSCON_E9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23457/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F" package="SANYO-OSCON_F">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23462/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F'" package="SANYO-OSCON_F'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23450/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F0" package="SANYO-OSCON_F0">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23459/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F13" package="SANYO-OSCON_F13">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23455/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F8" package="SANYO-OSCON_F8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23456/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_G" package="SANYO-OSCON_G">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23458/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_H" package="SANYO-OSCON_H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23463/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_A5" package="SANYO-OSCON_SMD_A5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23460/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_B6" package="SANYO-OSCON_SMD_B6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23461/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_C6" package="SANYO-OSCON_SMD_C6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23465/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_E12" package="SANYO-OSCON_SMD_E12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23464/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_E7" package="SANYO-OSCON_SMD_E7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23467/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_F12" package="SANYO-OSCON_SMD_F12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23468/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_F8" package="SANYO-OSCON_SMD_F8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23466/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-10X10" package="UD-10X10_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23469/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-4X5,8" package="UD-4X5,8_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23474/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-5X5,8" package="UD-5X5,8_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23470/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-6,3X8,8" package="UD-6,3X5,8_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23471/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-6,3X7,7" package="UD-6,3X7,7_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23472/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-8X10" package="UD-8X10_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23473/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
<spice>
<pinmapping spiceprefix="C">
<pinmap gate="G$1" pin="+" pinorder="1"/>
<pinmap gate="G$1" pin="-" pinorder="2"/>
</pinmapping>
</spice>
</deviceset>
</devicesets>
</library>
<library name="ULN2803A">
<packages>
<package name="DW(R-PDSO-G18)">
<wire x1="5.5339" y1="3.6863" x2="-5.4389" y2="3.6863" width="0.1524" layer="21"/>
<wire x1="5.5339" y1="-3.7813" x2="5.9149" y2="-3.4003" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.8199" y1="3.3053" x2="-5.4389" y2="3.6863" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.5339" y1="3.6863" x2="5.9149" y2="3.3053" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.8199" y1="-3.4003" x2="-5.4389" y2="-3.7813" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.4389" y1="-3.7813" x2="5.5339" y2="-3.7813" width="0.1524" layer="21"/>
<wire x1="5.9149" y1="-3.4003" x2="5.9149" y2="3.3053" width="0.1524" layer="21"/>
<wire x1="-5.8199" y1="3.3053" x2="-5.8199" y2="-3.4003" width="0.1524" layer="21"/>
<wire x1="-5.7945" y1="-3.4257" x2="5.8895" y2="-3.4257" width="0.0508" layer="21"/>
<wire x1="-5.8199" y1="1.2225" x2="-5.8199" y2="-1.3175" width="0.1524" layer="21" curve="-180"/>
<smd name="1" x="-5.0325" y="-5.0767" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-3.7625" y="-5.0767" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-2.4925" y="-5.0767" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="-1.2225" y="-5.0767" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="0.0475" y="-5.0767" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="1.3175" y="-5.0767" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="2.5875" y="-5.0767" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="3.8575" y="-5.0767" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="3.8575" y="4.9817" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="2.5875" y="4.9817" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="1.3175" y="4.9817" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="0.0475" y="4.9817" dx="0.6604" dy="2.032" layer="1"/>
<smd name="15" x="-1.2225" y="4.9817" dx="0.6604" dy="2.032" layer="1"/>
<smd name="16" x="-2.4925" y="4.9817" dx="0.6604" dy="2.032" layer="1"/>
<smd name="17" x="-3.7625" y="4.9817" dx="0.6604" dy="2.032" layer="1"/>
<smd name="18" x="-5.0325" y="4.9817" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="5.1275" y="-5.0767" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="5.1275" y="4.9817" dx="0.6604" dy="2.032" layer="1"/>
<text x="6.3565" y="3.4445" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<text x="-6.3965" y="-2.2705" size="1.27" layer="25" font="vector" ratio="10" rot="R180">&gt;NAME</text>
<rectangle x1="-5.2865" y1="-3.9083" x2="-4.7785" y2="-3.7813" layer="21"/>
<rectangle x1="-5.2865" y1="-5.3815" x2="-4.7785" y2="-3.9083" layer="51"/>
<rectangle x1="-4.0165" y1="-3.9083" x2="-3.5085" y2="-3.7813" layer="21"/>
<rectangle x1="-4.0165" y1="-5.3815" x2="-3.5085" y2="-3.9083" layer="51"/>
<rectangle x1="-2.7465" y1="-3.9083" x2="-2.2385" y2="-3.7813" layer="21"/>
<rectangle x1="-2.7465" y1="-5.3815" x2="-2.2385" y2="-3.9083" layer="51"/>
<rectangle x1="-1.4765" y1="-3.9083" x2="-0.9685" y2="-3.7813" layer="21"/>
<rectangle x1="-1.4765" y1="-5.3815" x2="-0.9685" y2="-3.9083" layer="51"/>
<rectangle x1="-0.2065" y1="-5.3815" x2="0.3015" y2="-3.9083" layer="51"/>
<rectangle x1="-0.2065" y1="-3.9083" x2="0.3015" y2="-3.7813" layer="21"/>
<rectangle x1="1.0635" y1="-3.9083" x2="1.5715" y2="-3.7813" layer="21"/>
<rectangle x1="1.0635" y1="-5.3815" x2="1.5715" y2="-3.9083" layer="51"/>
<rectangle x1="2.3335" y1="-3.9083" x2="2.8415" y2="-3.7813" layer="21"/>
<rectangle x1="2.3335" y1="-5.3815" x2="2.8415" y2="-3.9083" layer="51"/>
<rectangle x1="3.6035" y1="-3.9083" x2="4.1115" y2="-3.7813" layer="21"/>
<rectangle x1="3.6035" y1="-5.3815" x2="4.1115" y2="-3.9083" layer="51"/>
<rectangle x1="-5.2865" y1="3.8133" x2="-4.7785" y2="5.2865" layer="51"/>
<rectangle x1="-5.2865" y1="3.6863" x2="-4.7785" y2="3.8133" layer="21"/>
<rectangle x1="-4.0165" y1="3.6863" x2="-3.5085" y2="3.8133" layer="21"/>
<rectangle x1="-4.0165" y1="3.8133" x2="-3.5085" y2="5.2865" layer="51"/>
<rectangle x1="-2.7465" y1="3.6863" x2="-2.2385" y2="3.8133" layer="21"/>
<rectangle x1="-2.7465" y1="3.8133" x2="-2.2385" y2="5.2865" layer="51"/>
<rectangle x1="-1.4765" y1="3.6863" x2="-0.9685" y2="3.8133" layer="21"/>
<rectangle x1="-1.4765" y1="3.8133" x2="-0.9685" y2="5.2865" layer="51"/>
<rectangle x1="-0.2065" y1="3.6863" x2="0.3015" y2="3.8133" layer="21"/>
<rectangle x1="-0.2065" y1="3.8133" x2="0.3015" y2="5.2865" layer="51"/>
<rectangle x1="1.0635" y1="3.6863" x2="1.5715" y2="3.8133" layer="21"/>
<rectangle x1="1.0635" y1="3.8133" x2="1.5715" y2="5.2865" layer="51"/>
<rectangle x1="2.3335" y1="3.6863" x2="2.8415" y2="3.8133" layer="21"/>
<rectangle x1="2.3335" y1="3.8133" x2="2.8415" y2="5.2865" layer="51"/>
<rectangle x1="3.6035" y1="3.6863" x2="4.1115" y2="3.8133" layer="21"/>
<rectangle x1="3.6035" y1="3.8133" x2="4.1115" y2="5.2865" layer="51"/>
<rectangle x1="4.8735" y1="3.6863" x2="5.3815" y2="3.8133" layer="21"/>
<rectangle x1="4.8735" y1="3.8133" x2="5.3815" y2="5.2865" layer="51"/>
<rectangle x1="4.8735" y1="-3.9083" x2="5.3815" y2="-3.7813" layer="21"/>
<rectangle x1="4.8735" y1="-5.3815" x2="5.3815" y2="-3.9083" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="ULN2803A">
<wire x1="-7.62" y1="12.7" x2="7.62" y2="12.7" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-12.7" x2="7.62" y2="12.7" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-12.7" x2="-7.62" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="12.7" x2="-7.62" y2="-12.7" width="0.4064" layer="94"/>
<text x="-7.62" y="13.462" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
<pin name="I1" x="-12.7" y="10.16" length="middle" direction="in"/>
<pin name="I2" x="-12.7" y="7.62" length="middle" direction="in"/>
<pin name="I3" x="-12.7" y="5.08" length="middle" direction="in"/>
<pin name="I4" x="-12.7" y="2.54" length="middle" direction="in"/>
<pin name="I5" x="-12.7" y="0" length="middle" direction="in"/>
<pin name="I6" x="-12.7" y="-2.54" length="middle" direction="in"/>
<pin name="I7" x="-12.7" y="-5.08" length="middle" direction="in"/>
<pin name="I8" x="-12.7" y="-7.62" length="middle" direction="in"/>
<pin name="O8" x="12.7" y="-7.62" length="middle" direction="oc" rot="R180"/>
<pin name="O1" x="12.7" y="10.16" length="middle" direction="oc" rot="R180"/>
<pin name="O2" x="12.7" y="7.62" length="middle" direction="oc" rot="R180"/>
<pin name="O3" x="12.7" y="5.08" length="middle" direction="oc" rot="R180"/>
<pin name="O4" x="12.7" y="2.54" length="middle" direction="oc" rot="R180"/>
<pin name="O5" x="12.7" y="0" length="middle" direction="oc" rot="R180"/>
<pin name="O6" x="12.7" y="-2.54" length="middle" direction="oc" rot="R180"/>
<pin name="O7" x="12.7" y="-5.08" length="middle" direction="oc" rot="R180"/>
<pin name="CD+" x="12.7" y="-10.16" length="middle" direction="pas" rot="R180"/>
<pin name="GND" x="-12.7" y="-10.16" length="middle" direction="pwr"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="ULN2803A" prefix="IC">
<gates>
<gate name="G$1" symbol="ULN2803A" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DW(R-PDSO-G18)">
<connects>
<connect gate="G$1" pin="CD+" pad="10"/>
<connect gate="G$1" pin="GND" pad="9"/>
<connect gate="G$1" pin="I1" pad="1"/>
<connect gate="G$1" pin="I2" pad="2"/>
<connect gate="G$1" pin="I3" pad="3"/>
<connect gate="G$1" pin="I4" pad="4"/>
<connect gate="G$1" pin="I5" pad="5"/>
<connect gate="G$1" pin="I6" pad="6"/>
<connect gate="G$1" pin="I7" pad="7"/>
<connect gate="G$1" pin="I8" pad="8"/>
<connect gate="G$1" pin="O1" pad="18"/>
<connect gate="G$1" pin="O2" pad="17"/>
<connect gate="G$1" pin="O3" pad="16"/>
<connect gate="G$1" pin="O4" pad="15"/>
<connect gate="G$1" pin="O5" pad="14"/>
<connect gate="G$1" pin="O6" pad="13"/>
<connect gate="G$1" pin="O7" pad="12"/>
<connect gate="G$1" pin="O8" pad="11"/>
</connects>
<technologies>
<attribute name="MPN" value="ULN2803ADWR"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="C0603_100n50V">
<packages>
<package name="C0603">
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.356" y1="0.432" x2="0.356" y2="0.432" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.419" x2="0.356" y2="-0.419" width="0.1016" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="0.9" layer="1" roundness="15"/>
<smd name="2" x="0.85" y="0" dx="1" dy="0.9" layer="1" roundness="15"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8382" y1="-0.4699" x2="-0.3381" y2="0.4801" layer="51"/>
<rectangle x1="0.3302" y1="-0.4699" x2="0.8303" y2="0.4801" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
<wire x1="-1.6" y1="0.55" x2="-1.6" y2="-0.55" width="0.127" layer="21"/>
<wire x1="1.6" y1="0.55" x2="1.6" y2="-0.55" width="0.127" layer="21"/>
<wire x1="0" y1="0.85" x2="0" y2="0.55" width="0.127" layer="21"/>
<wire x1="0" y1="-0.55" x2="0" y2="-0.85" width="0.127" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="100N/50V">
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="C0603_100N/50V" prefix="C">
<description>&lt;a href="http://de.farnell.com/kemet/c0603c104k5ractu/cap-mlcc-x7r-100nf-50v-0603/dp/1288255"&gt;Farnell&lt;/a&gt;
&lt;br&gt;
&lt;a href="http://www.farnell.com/datasheets/2315109.pdf?_ga=2.265871882.424028208.1508487000-1235631276.1508230459"&gt;Datasheet&lt;/a&gt;</description>
<gates>
<gate name="G$1" symbol="100N/50V" x="0" y="0"/>
</gates>
<devices>
<device name="" package="C0603">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<attribute name="FARNELL" value="1288255" constant="no"/>
<attribute name="MF" value="KEMET" constant="no"/>
<attribute name="MPN" value="C1608JB1H104K080AA" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="PIC16F1455_14TSSOP">
<packages>
<package name="14TSSOP">
<wire x1="-2.5146" y1="-2.2828" x2="2.5146" y2="-2.2828" width="0.1524" layer="51"/>
<wire x1="2.5146" y1="2.2828" x2="2.5146" y2="-2.2828" width="0.1524" layer="51"/>
<wire x1="2.5146" y1="2.2828" x2="-2.5146" y2="2.2828" width="0.1524" layer="51"/>
<wire x1="-2.5146" y1="-2.2828" x2="-2.5146" y2="2.2828" width="0.1524" layer="51"/>
<circle x="-1.6256" y="-1.2192" radius="0.4572" width="0.1524" layer="51"/>
<smd name="1" x="-1.95" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="2" x="-1.3" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="3" x="-0.65" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="4" x="0" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="5" x="0.65" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="6" x="1.3" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="7" x="1.95" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="8" x="1.95" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="9" x="1.3" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="10" x="0.65" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="11" x="0" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="12" x="-0.65" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="13" x="-1.3" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="14" x="-1.95" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<text x="-3.3956" y="-2.0828" size="1.016" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.3862" y="-2.0828" size="1.016" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.0516" y1="-3.121" x2="-1.8484" y2="-2.2828" layer="51"/>
<rectangle x1="-1.4016" y1="-3.121" x2="-1.1984" y2="-2.2828" layer="51"/>
<rectangle x1="-0.7516" y1="-3.121" x2="-0.5484" y2="-2.2828" layer="51"/>
<rectangle x1="-0.1016" y1="-3.121" x2="0.1016" y2="-2.2828" layer="51"/>
<rectangle x1="0.5484" y1="-3.121" x2="0.7516" y2="-2.2828" layer="51"/>
<rectangle x1="1.1984" y1="-3.121" x2="1.4016" y2="-2.2828" layer="51"/>
<rectangle x1="1.8484" y1="-3.121" x2="2.0516" y2="-2.2828" layer="51"/>
<rectangle x1="1.8484" y1="2.2828" x2="2.0516" y2="3.121" layer="51"/>
<rectangle x1="1.1984" y1="2.2828" x2="1.4016" y2="3.121" layer="51"/>
<rectangle x1="0.5484" y1="2.2828" x2="0.7516" y2="3.121" layer="51"/>
<rectangle x1="-0.1016" y1="2.2828" x2="0.1016" y2="3.121" layer="51"/>
<rectangle x1="-0.7516" y1="2.2828" x2="-0.5484" y2="3.121" layer="51"/>
<rectangle x1="-1.4016" y1="2.2828" x2="-1.1984" y2="3.121" layer="51"/>
<rectangle x1="-2.0516" y1="2.2828" x2="-1.8484" y2="3.121" layer="51"/>
<wire x1="-2.5" y1="-2.5" x2="-3" y2="-2.5" width="0.127" layer="21"/>
<wire x1="-3" y1="-2.5" x2="-3" y2="-2" width="0.127" layer="21"/>
<wire x1="-3" y1="-2" x2="-3" y2="2.5" width="0.127" layer="21"/>
<wire x1="-2.5" y1="2.5" x2="-3" y2="2.5" width="0.127" layer="21"/>
<wire x1="-3" y1="-2" x2="-2.5" y2="-2.5" width="0.127" layer="21"/>
<wire x1="2.5" y1="2.5" x2="3" y2="2.5" width="0.127" layer="21"/>
<wire x1="3" y1="2.5" x2="3" y2="-2.5" width="0.127" layer="21"/>
<wire x1="3" y1="-2.5" x2="2.5" y2="-2.5" width="0.127" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="PIC16F1455">
<pin name="VDD" x="-22.86" y="15.24" length="middle" direction="pwr"/>
<pin name="RA5" x="-22.86" y="10.16" length="middle"/>
<pin name="RA4" x="-22.86" y="5.08" length="middle"/>
<pin name="MCLR/RA3" x="-22.86" y="0" length="middle" direction="in"/>
<pin name="RC5" x="-22.86" y="-5.08" length="middle"/>
<pin name="RC4" x="-22.86" y="-10.16" length="middle"/>
<pin name="RC3" x="-22.86" y="-15.24" length="middle"/>
<pin name="RC2" x="22.86" y="-15.24" length="middle" rot="R180"/>
<pin name="RC1/ICSPCLK" x="22.86" y="-10.16" length="middle" rot="R180"/>
<pin name="RC0/ICSPDAT" x="22.86" y="-5.08" length="middle" rot="R180"/>
<pin name="VUSB3V3" x="22.86" y="0" length="middle" direction="in" rot="R180"/>
<pin name="RA1/D-" x="22.86" y="5.08" length="middle" rot="R180"/>
<pin name="RA0/D+" x="22.86" y="10.16" length="middle" rot="R180"/>
<pin name="VSS" x="22.86" y="15.24" length="middle" direction="pwr" rot="R180"/>
<wire x1="-17.78" y1="17.78" x2="-17.78" y2="-17.78" width="0.254" layer="94"/>
<wire x1="17.78" y1="-17.78" x2="17.78" y2="17.78" width="0.254" layer="94"/>
<wire x1="-17.78" y1="17.78" x2="-2.54" y2="17.78" width="0.254" layer="94"/>
<wire x1="-2.54" y1="17.78" x2="0" y2="15.24" width="0.254" layer="94" curve="90"/>
<wire x1="0" y1="15.24" x2="2.54" y2="17.78" width="0.254" layer="94" curve="90"/>
<wire x1="2.54" y1="17.78" x2="17.78" y2="17.78" width="0.254" layer="94"/>
<wire x1="-17.78" y1="-17.78" x2="17.78" y2="-17.78" width="0.254" layer="94"/>
<text x="-15.24" y="20.32" size="1.778" layer="95">&gt;NAME</text>
<text x="-15.24" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="PIC16F1455" prefix="U">
<gates>
<gate name="G$1" symbol="PIC16F1455" x="0" y="0"/>
</gates>
<devices>
<device name="" package="14TSSOP">
<connects>
<connect gate="G$1" pin="MCLR/RA3" pad="4"/>
<connect gate="G$1" pin="RA0/D+" pad="13"/>
<connect gate="G$1" pin="RA1/D-" pad="12"/>
<connect gate="G$1" pin="RA4" pad="3"/>
<connect gate="G$1" pin="RA5" pad="2"/>
<connect gate="G$1" pin="RC0/ICSPDAT" pad="10"/>
<connect gate="G$1" pin="RC1/ICSPCLK" pad="9"/>
<connect gate="G$1" pin="RC2" pad="8"/>
<connect gate="G$1" pin="RC3" pad="7"/>
<connect gate="G$1" pin="RC4" pad="6"/>
<connect gate="G$1" pin="RC5" pad="5"/>
<connect gate="G$1" pin="VDD" pad="1"/>
<connect gate="G$1" pin="VSS" pad="14"/>
<connect gate="G$1" pin="VUSB3V3" pad="11"/>
</connects>
<technologies>
<attribute name="MPN" value="PIC16F1455-I/SL"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_10k_0.1%">
<packages>
<package name="R0805">
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1" roundness="15"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1" roundness="15"/>
<text x="-0.635" y="1.27" size="1.27" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
</packages>
<symbols>
<symbol name="_">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_10K_0.1%" prefix="R">
<description>&lt;a href="http://de.farnell.com/multicomp/mcwr08x3002ftl/dickschichtwiderstand-30k-1-0/dp/2446951"&gt;Farnell&lt;/a&gt;
&lt;br&gt;
&lt;a href="http://www.farnell.com/datasheets/1849611.pdf?_ga=2.55851695.565178279.1509960112-1235631276.1508230459"&gt;Datasheet&lt;/a&gt;</description>
<gates>
<gate name="G$1" symbol="_" x="0" y="0"/>
</gates>
<devices>
<device name="" package="R0805">
<connects>
</connects>
<technologies>
<attribute name="MPN" value="ERA-6AEB103V"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_2.21k_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_2.21K_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="ERA-6AEB2211V"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="R0805_12.1Ohm_0.1%">
<packages>
</package>
</packages>
<symbols>
<symbol name="_">
</symbol>
</symbols>
<devicesets>
<deviceset name="R0805_12.1OHM_0.1%" prefix="R">
&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="RQ73C2A12R1BTD"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="jumper">
<packages>
<package name="05" urn="urn:adsk.eagle:footprint:15423/1" locally_modified="yes">
<description>&lt;b&gt;JUMPER&lt;/b&gt;</description>
<wire x1="-1.3462" y1="0" x2="1.3462" y2="0" width="0.6096" layer="51"/>
<wire x1="2.74" y1="0" x2="1.447" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.74" y1="0" x2="-1.397" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-2.75" y="0" drill="0.4" diameter="0.8128"/>
<pad name="2" x="2.75" y="0" drill="0.4" diameter="0.8128"/>
<text x="-2.54" y="0.889" size="1.016" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="2.5501" y="0.05" size="0.02" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="05" urn="urn:adsk.eagle:package:15465/1" locally_modified="yes" type="box">
<description>JUMPER</description>
<packageinstances>
<packageinstance name="05"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="JUMPER">
<wire x1="-2.54" y1="0" x2="-1.27" y2="1.27" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="1.27" y2="1.27" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="1.27" y2="1.27" width="0.1524" layer="94"/>
<circle x="-2.54" y="0" radius="0.254" width="0.4064" layer="94"/>
<circle x="2.54" y="0" radius="0.254" width="0.4064" layer="94"/>
<text x="-2.54" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-5.08" y="0" visible="pad" length="short" direction="pas" swaplevel="1"/>
<pin name="2" x="5.08" y="0" visible="pad" length="short" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="JUMPER" prefix="J">
<gates>
<gate name="G$1" symbol="JUMPER" x="0" y="0"/>
</gates>
<devices>
<device name="JUMPER" package="05">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:15465/1"/>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="K1" library="relay" library_urn="urn:adsk.eagle:library:339" deviceset="G5LE" device="" package3d_urn="urn:adsk.eagle:package:24308/1"/>
<part name="K2" library="relay" library_urn="urn:adsk.eagle:library:339" deviceset="G5LE" device="" package3d_urn="urn:adsk.eagle:package:24308/1"/>
<part name="K3" library="relay" library_urn="urn:adsk.eagle:library:339" deviceset="G5LE" device="" package3d_urn="urn:adsk.eagle:package:24308/1"/>
<part name="K4" library="relay" library_urn="urn:adsk.eagle:library:339" deviceset="G5LE" device="" package3d_urn="urn:adsk.eagle:package:24308/1"/>
<part name="K5" library="relay" library_urn="urn:adsk.eagle:library:339" deviceset="G5LE" device="" package3d_urn="urn:adsk.eagle:package:24308/1"/>
<part name="X1" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" deviceset="W237-02P" device="" package3d_urn="urn:adsk.eagle:package:10734/1"/>
<part name="X2" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" deviceset="W237-02P" device="" package3d_urn="urn:adsk.eagle:package:10734/1"/>
<part name="X3" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" deviceset="W237-02P" device="" package3d_urn="urn:adsk.eagle:package:10734/1"/>
<part name="X4" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" deviceset="W237-02P" device="" package3d_urn="urn:adsk.eagle:package:10734/1"/>
<part name="X5" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" deviceset="W237-02P" device="" package3d_urn="urn:adsk.eagle:package:10734/1"/>
<part name="X6" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" deviceset="W237-02P" device="" package3d_urn="urn:adsk.eagle:package:10734/1"/>
<part name="F1" library="fuse" library_urn="urn:adsk.eagle:library:233" deviceset="FUSE" device="SHK20Q" package3d_urn="urn:adsk.eagle:package:14073/1"/>
<part name="F2" library="fuse" library_urn="urn:adsk.eagle:library:233" deviceset="FUSE" device="SHK20Q" package3d_urn="urn:adsk.eagle:package:14073/1"/>
<part name="X7" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" deviceset="W237-02P" device="" package3d_urn="urn:adsk.eagle:package:10734/1"/>
<part name="B1" library="rectifier" library_urn="urn:adsk.eagle:library:336" deviceset="B-DIL" device="" package3d_urn="urn:adsk.eagle:package:23868/1"/>
<part name="IC1" library="v-reg" library_urn="urn:adsk.eagle:library:409" deviceset="78XXL" device="" package3d_urn="urn:adsk.eagle:package:30361/1"/>
<part name="GND1" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="C1" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="CPOL-EU" device="E5-8.5" package3d_urn="urn:adsk.eagle:package:23374/1"/>
<part name="C2" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="CPOL-EU" device="E5-8.5" package3d_urn="urn:adsk.eagle:package:23374/1"/>
<part name="GND2" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="GND3" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="IC2" library="ULN2803A" deviceset="ULN2803A" device=""/>
<part name="GND4" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="C3" library="C0603_100n50V" deviceset="C0603_100N/50V" device=""/>
<part name="U1" library="PIC16F1455_14TSSOP" deviceset="PIC16F1455" device=""/>
<part name="GND5" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="GND6" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="C4" library="C0603_100n50V" deviceset="C0603_100N/50V" device=""/>
<part name="GND7" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="GND8" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="R1" library="R0805_10k_0.1%" deviceset="R0805_10K_0.1%" device=""/>
<part name="R2" library="R0805_10k_0.1%" deviceset="R0805_10K_0.1%" device=""/>
<part name="X8" library="con-wago-508" library_urn="urn:adsk.eagle:library:196" deviceset="W237-02P" device="" package3d_urn="urn:adsk.eagle:package:10734/1"/>
<part name="GND9" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="R3" library="R0805_2.21k_0.1%" deviceset="R0805_2.21K_0.1%" device=""/>
<part name="R4" library="R0805_12.1Ohm_0.1%" deviceset="R0805_12.1OHM_0.1%" device=""/>
<part name="J1" library="jumper" deviceset="JUMPER" device="JUMPER" package3d_urn="urn:adsk.eagle:package:15465/1"/>
<part name="GND10" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
<part name="GND11" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="0V" device=""/>
</parts>
<sheets>
<sheet>
<plain>
<text x="2.54" y="7.62" size="1.778" layer="91">1V AC</text>
<text x="2.54" y="22.86" size="1.778" layer="91">2V AC</text>
<text x="2.54" y="38.1" size="1.778" layer="91">4V AC</text>
<text x="2.54" y="53.34" size="1.778" layer="91">8V AC</text>
<text x="2.54" y="68.58" size="1.778" layer="91">16V AC</text>
<text x="2.54" y="-15.24" size="1.778" layer="91">6V AC</text>
<text x="137.16" y="88.9" size="1.778" layer="91">AC OUT</text>
<text x="276.86" y="12.7" size="1.778" layer="91">2 vagy 3V eses a szabalyozo eszkozon.</text>
</plain>
<instances>
<instance part="K1" gate="1" x="106.68" y="68.58" smashed="yes">
<attribute name="VALUE" x="107.95" y="71.501" size="1.778" layer="96"/>
<attribute name="PART" x="107.95" y="73.66" size="1.778" layer="95"/>
</instance>
<instance part="K1" gate="2" x="53.34" y="68.58" smashed="yes" rot="R90">
<attribute name="PART" x="53.34" y="71.12" size="1.778" layer="95" rot="R90"/>
</instance>
<instance part="K2" gate="1" x="106.68" y="53.34" smashed="yes">
<attribute name="VALUE" x="107.95" y="56.261" size="1.778" layer="96"/>
<attribute name="PART" x="107.95" y="58.42" size="1.778" layer="95"/>
</instance>
<instance part="K2" gate="2" x="53.34" y="53.34" smashed="yes" rot="R90">
<attribute name="PART" x="53.34" y="55.88" size="1.778" layer="95" rot="R90"/>
</instance>
<instance part="K3" gate="1" x="106.68" y="38.1" smashed="yes">
<attribute name="VALUE" x="107.95" y="41.021" size="1.778" layer="96"/>
<attribute name="PART" x="107.95" y="43.18" size="1.778" layer="95"/>
</instance>
<instance part="K3" gate="2" x="53.34" y="38.1" smashed="yes" rot="R90">
<attribute name="PART" x="53.34" y="40.64" size="1.778" layer="95" rot="R90"/>
</instance>
<instance part="K4" gate="1" x="106.68" y="22.86" smashed="yes">
<attribute name="VALUE" x="107.95" y="25.781" size="1.778" layer="96"/>
<attribute name="PART" x="107.95" y="27.94" size="1.778" layer="95"/>
</instance>
<instance part="K4" gate="2" x="53.34" y="22.86" smashed="yes" rot="R90">
<attribute name="PART" x="53.34" y="25.4" size="1.778" layer="95" rot="R90"/>
</instance>
<instance part="K5" gate="1" x="106.68" y="7.62" smashed="yes">
<attribute name="VALUE" x="107.95" y="10.541" size="1.778" layer="96"/>
<attribute name="PART" x="107.95" y="12.7" size="1.778" layer="95"/>
</instance>
<instance part="K5" gate="2" x="53.34" y="7.62" smashed="yes" rot="R90">
<attribute name="PART" x="53.34" y="10.16" size="1.778" layer="95" rot="R90"/>
</instance>
<instance part="X1" gate="-1" x="10.16" y="73.66" smashed="yes">
<attribute name="NAME" x="8.89" y="74.549" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X1" gate="-2" x="10.16" y="63.5" smashed="yes">
<attribute name="VALUE" x="10.16" y="66.04" size="1.778" layer="96"/>
<attribute name="NAME" x="8.89" y="64.389" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X2" gate="-1" x="10.16" y="58.42" smashed="yes">
<attribute name="NAME" x="8.89" y="59.309" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X2" gate="-2" x="10.16" y="48.26" smashed="yes">
<attribute name="VALUE" x="10.16" y="50.8" size="1.778" layer="96"/>
<attribute name="NAME" x="8.89" y="49.149" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X3" gate="-1" x="10.16" y="43.18" smashed="yes">
<attribute name="NAME" x="8.89" y="44.069" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X3" gate="-2" x="10.16" y="33.02" smashed="yes">
<attribute name="VALUE" x="10.16" y="35.56" size="1.778" layer="96"/>
<attribute name="NAME" x="8.89" y="33.909" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X4" gate="-1" x="10.16" y="27.94" smashed="yes">
<attribute name="NAME" x="8.89" y="28.829" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X4" gate="-2" x="10.16" y="17.78" smashed="yes">
<attribute name="VALUE" x="10.16" y="20.32" size="1.778" layer="96"/>
<attribute name="NAME" x="8.89" y="18.669" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X5" gate="-1" x="10.16" y="12.7" smashed="yes">
<attribute name="NAME" x="8.89" y="13.589" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X5" gate="-2" x="10.16" y="2.54" smashed="yes">
<attribute name="VALUE" x="10.16" y="5.08" size="1.778" layer="96"/>
<attribute name="NAME" x="8.89" y="3.429" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X6" gate="-1" x="10.16" y="-10.16" smashed="yes">
<attribute name="NAME" x="8.89" y="-9.271" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X6" gate="-2" x="10.16" y="-20.32" smashed="yes">
<attribute name="VALUE" x="10.16" y="-17.78" size="1.778" layer="96"/>
<attribute name="NAME" x="8.89" y="-19.431" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="F1" gate="G$1" x="68.58" y="68.58" smashed="yes">
<attribute name="NAME" x="64.77" y="69.977" size="1.778" layer="95"/>
<attribute name="VALUE" x="64.77" y="65.659" size="1.778" layer="96"/>
</instance>
<instance part="F2" gate="G$1" x="25.4" y="-10.16" smashed="yes">
<attribute name="NAME" x="21.59" y="-8.763" size="1.778" layer="95"/>
<attribute name="VALUE" x="21.59" y="-13.081" size="1.778" layer="96"/>
</instance>
<instance part="X7" gate="-1" x="129.54" y="83.82" smashed="yes" rot="R180">
<attribute name="NAME" x="130.81" y="82.931" size="1.778" layer="95"/>
</instance>
<instance part="X7" gate="-2" x="129.54" y="91.44" smashed="yes" rot="R180">
<attribute name="VALUE" x="129.54" y="88.9" size="1.778" layer="96" rot="R180"/>
<attribute name="NAME" x="130.81" y="90.551" size="1.778" layer="95"/>
</instance>
<instance part="B1" gate="1" x="43.18" y="-15.24" smashed="yes">
<attribute name="VALUE" x="48.26" y="-20.32" size="1.778" layer="96"/>
<attribute name="NAME" x="48.26" y="-12.7" size="1.778" layer="95"/>
</instance>
<instance part="IC1" gate="A" x="78.74" y="-15.24" smashed="yes">
<attribute name="NAME" x="81.28" y="-22.86" size="1.778" layer="95"/>
<attribute name="VALUE" x="81.28" y="-25.4" size="1.778" layer="96"/>
</instance>
<instance part="GND1" gate="1" x="78.74" y="-27.94" smashed="yes">
<attribute name="VALUE" x="76.835" y="-30.48" size="1.778" layer="96"/>
</instance>
<instance part="C1" gate="G$1" x="60.96" y="-17.78" smashed="yes">
<attribute name="NAME" x="62.103" y="-17.2974" size="1.778" layer="95"/>
<attribute name="VALUE" x="62.103" y="-22.3774" size="1.778" layer="96"/>
</instance>
<instance part="C2" gate="G$1" x="93.98" y="-17.78" smashed="yes">
<attribute name="NAME" x="95.123" y="-17.2974" size="1.778" layer="95"/>
<attribute name="VALUE" x="95.123" y="-22.3774" size="1.778" layer="96"/>
</instance>
<instance part="GND2" gate="1" x="60.96" y="-27.94" smashed="yes">
<attribute name="VALUE" x="59.055" y="-30.48" size="1.778" layer="96"/>
</instance>
<instance part="GND3" gate="1" x="93.98" y="-27.94" smashed="yes">
<attribute name="VALUE" x="92.075" y="-30.48" size="1.778" layer="96"/>
</instance>
<instance part="IC2" gate="G$1" x="154.94" y="12.7" smashed="yes" rot="R180">
<attribute name="NAME" x="162.56" y="-0.762" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="162.56" y="27.94" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND4" gate="1" x="172.72" y="22.86" smashed="yes" rot="R90">
<attribute name="VALUE" x="175.26" y="20.955" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C3" gate="G$1" x="190.5" y="30.48" smashed="yes">
<attribute name="NAME" x="192.024" y="30.861" size="1.778" layer="95"/>
<attribute name="VALUE" x="192.024" y="25.781" size="1.778" layer="96"/>
</instance>
<instance part="U1" gate="G$1" x="226.06" y="7.62" smashed="yes">
<attribute name="NAME" x="210.82" y="27.94" size="1.778" layer="95"/>
<attribute name="VALUE" x="210.82" y="-12.7" size="1.778" layer="96"/>
</instance>
<instance part="GND5" gate="1" x="190.5" y="38.1" smashed="yes" rot="R180">
<attribute name="VALUE" x="192.405" y="40.64" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND6" gate="1" x="254" y="22.86" smashed="yes" rot="R90">
<attribute name="VALUE" x="256.54" y="20.955" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C4" gate="G$1" x="261.62" y="-12.7" smashed="yes">
<attribute name="NAME" x="263.144" y="-12.319" size="1.778" layer="95"/>
<attribute name="VALUE" x="263.144" y="-17.399" size="1.778" layer="96"/>
</instance>
<instance part="GND7" gate="1" x="261.62" y="-25.4" smashed="yes">
<attribute name="VALUE" x="259.715" y="-27.94" size="1.778" layer="96"/>
</instance>
<instance part="GND8" gate="1" x="284.48" y="-35.56" smashed="yes">
<attribute name="VALUE" x="282.575" y="-38.1" size="1.778" layer="96"/>
</instance>
<instance part="R1" gate="G$1" x="307.34" y="-7.62" smashed="yes">
<attribute name="NAME" x="303.53" y="-6.1214" size="1.778" layer="95"/>
<attribute name="VALUE" x="303.53" y="-10.922" size="1.778" layer="96"/>
</instance>
<instance part="R2" gate="G$1" x="294.64" y="-7.62" smashed="yes">
<attribute name="NAME" x="290.83" y="-6.1214" size="1.778" layer="95"/>
<attribute name="VALUE" x="290.83" y="-10.922" size="1.778" layer="96"/>
</instance>
<instance part="X8" gate="-1" x="330.2" y="-12.7" smashed="yes" rot="R180">
<attribute name="NAME" x="331.47" y="-13.589" size="1.778" layer="95"/>
</instance>
<instance part="X8" gate="-2" x="330.2" y="-7.62" smashed="yes" rot="R180">
<attribute name="VALUE" x="330.2" y="-10.16" size="1.778" layer="96" rot="R180"/>
<attribute name="NAME" x="331.47" y="-8.509" size="1.778" layer="95"/>
</instance>
<instance part="GND9" gate="1" x="322.58" y="-20.32" smashed="yes">
<attribute name="VALUE" x="320.675" y="-22.86" size="1.778" layer="96"/>
</instance>
<instance part="R3" gate="G$1" x="284.48" y="-25.4" smashed="yes" rot="R90">
<attribute name="NAME" x="282.9814" y="-29.21" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="287.782" y="-29.21" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R4" gate="G$1" x="284.48" y="-12.7" smashed="yes" rot="R90">
<attribute name="NAME" x="282.9814" y="-16.51" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="287.782" y="-16.51" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="J1" gate="G$1" x="261.62" y="12.7" smashed="yes">
<attribute name="NAME" x="259.08" y="14.605" size="1.778" layer="95"/>
<attribute name="VALUE" x="259.08" y="10.16" size="1.778" layer="96"/>
</instance>
<instance part="GND10" gate="1" x="271.78" y="12.7" smashed="yes" rot="R90">
<attribute name="VALUE" x="274.32" y="10.795" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND11" gate="1" x="30.48" y="-15.24" smashed="yes" rot="R270">
<attribute name="VALUE" x="27.94" y="-13.335" size="1.778" layer="96" rot="R270"/>
</instance>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<pinref part="K1" gate="2" pin="O"/>
<wire x1="48.26" y1="73.66" x2="15.24" y2="73.66" width="0.1524" layer="91"/>
<pinref part="X1" gate="-1" pin="KL"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="K1" gate="2" pin="S"/>
<pinref part="X1" gate="-2" pin="KL"/>
<wire x1="48.26" y1="63.5" x2="15.24" y2="63.5" width="0.1524" layer="91"/>
<wire x1="48.26" y1="63.5" x2="55.88" y2="63.5" width="0.1524" layer="91"/>
<junction x="48.26" y="63.5"/>
<pinref part="K2" gate="2" pin="P"/>
<wire x1="55.88" y1="63.5" x2="55.88" y2="53.34" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="X2" gate="-1" pin="KL"/>
<pinref part="K2" gate="2" pin="O"/>
<wire x1="15.24" y1="58.42" x2="48.26" y2="58.42" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="K2" gate="2" pin="S"/>
<pinref part="X2" gate="-2" pin="KL"/>
<wire x1="48.26" y1="48.26" x2="15.24" y2="48.26" width="0.1524" layer="91"/>
<pinref part="K3" gate="2" pin="P"/>
<wire x1="48.26" y1="48.26" x2="55.88" y2="48.26" width="0.1524" layer="91"/>
<wire x1="55.88" y1="48.26" x2="55.88" y2="38.1" width="0.1524" layer="91"/>
<junction x="48.26" y="48.26"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="X3" gate="-1" pin="KL"/>
<pinref part="K3" gate="2" pin="O"/>
<wire x1="15.24" y1="43.18" x2="48.26" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="X3" gate="-2" pin="KL"/>
<pinref part="K3" gate="2" pin="S"/>
<wire x1="15.24" y1="33.02" x2="48.26" y2="33.02" width="0.1524" layer="91"/>
<wire x1="48.26" y1="33.02" x2="55.88" y2="33.02" width="0.1524" layer="91"/>
<junction x="48.26" y="33.02"/>
<pinref part="K4" gate="2" pin="P"/>
<wire x1="55.88" y1="33.02" x2="55.88" y2="22.86" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="K1" gate="2" pin="P"/>
<wire x1="55.88" y1="68.58" x2="63.5" y2="68.58" width="0.1524" layer="91"/>
<pinref part="F1" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="K4" gate="2" pin="O"/>
<pinref part="X4" gate="-1" pin="KL"/>
<wire x1="48.26" y1="27.94" x2="15.24" y2="27.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="K4" gate="2" pin="S"/>
<pinref part="X4" gate="-2" pin="KL"/>
<wire x1="48.26" y1="17.78" x2="15.24" y2="17.78" width="0.1524" layer="91"/>
<pinref part="K5" gate="2" pin="P"/>
<wire x1="48.26" y1="17.78" x2="55.88" y2="17.78" width="0.1524" layer="91"/>
<wire x1="55.88" y1="17.78" x2="55.88" y2="7.62" width="0.1524" layer="91"/>
<junction x="48.26" y="17.78"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="K5" gate="2" pin="O"/>
<pinref part="X5" gate="-1" pin="KL"/>
<wire x1="48.26" y1="12.7" x2="15.24" y2="12.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="K5" gate="2" pin="S"/>
<pinref part="X5" gate="-2" pin="KL"/>
<wire x1="48.26" y1="2.54" x2="15.24" y2="2.54" width="0.1524" layer="91"/>
<junction x="48.26" y="2.54"/>
<wire x1="48.26" y1="2.54" x2="88.9" y2="2.54" width="0.1524" layer="91"/>
<wire x1="88.9" y1="2.54" x2="88.9" y2="83.82" width="0.1524" layer="91"/>
<wire x1="88.9" y1="83.82" x2="124.46" y2="83.82" width="0.1524" layer="91"/>
<pinref part="X7" gate="-1" pin="KL"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="X6" gate="-1" pin="KL"/>
<pinref part="F2" gate="G$1" pin="1"/>
<wire x1="15.24" y1="-10.16" x2="20.32" y2="-10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="F1" gate="G$1" pin="2"/>
<wire x1="73.66" y1="68.58" x2="78.74" y2="68.58" width="0.1524" layer="91"/>
<wire x1="78.74" y1="68.58" x2="78.74" y2="91.44" width="0.1524" layer="91"/>
<wire x1="78.74" y1="91.44" x2="124.46" y2="91.44" width="0.1524" layer="91"/>
<pinref part="X7" gate="-2" pin="KL"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="X6" gate="-2" pin="KL"/>
<pinref part="B1" gate="1" pin="AC2"/>
<wire x1="15.24" y1="-20.32" x2="43.18" y2="-20.32" width="0.1524" layer="91"/>
<junction x="43.18" y="-20.32"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="F2" gate="G$1" pin="2"/>
<pinref part="B1" gate="1" pin="AC1"/>
<wire x1="30.48" y1="-10.16" x2="43.18" y2="-10.16" width="0.1524" layer="91"/>
<junction x="43.18" y="-10.16"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="B1" gate="1" pin="+"/>
<junction x="48.26" y="-15.24"/>
<pinref part="IC1" gate="A" pin="IN"/>
<wire x1="48.26" y1="-15.24" x2="60.96" y2="-15.24" width="0.1524" layer="91"/>
<pinref part="C1" gate="G$1" pin="+"/>
<wire x1="60.96" y1="-15.24" x2="71.12" y2="-15.24" width="0.1524" layer="91"/>
<junction x="60.96" y="-15.24"/>
</segment>
</net>
<net name="0V" class="0">
<segment>
<pinref part="GND1" gate="1" pin="0V"/>
<pinref part="IC1" gate="A" pin="GND"/>
<wire x1="78.74" y1="-25.4" x2="78.74" y2="-22.86" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND2" gate="1" pin="0V"/>
<pinref part="C1" gate="G$1" pin="-"/>
<wire x1="60.96" y1="-25.4" x2="60.96" y2="-22.86" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND3" gate="1" pin="0V"/>
<pinref part="C2" gate="G$1" pin="-"/>
<wire x1="93.98" y1="-25.4" x2="93.98" y2="-22.86" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND4" gate="1" pin="0V"/>
<pinref part="IC2" gate="G$1" pin="GND"/>
<wire x1="170.18" y1="22.86" x2="167.64" y2="22.86" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND6" gate="1" pin="0V"/>
<pinref part="U1" gate="G$1" pin="VSS"/>
<wire x1="251.46" y1="22.86" x2="248.92" y2="22.86" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C3" gate="G$1" pin="1"/>
<pinref part="GND5" gate="1" pin="0V"/>
<wire x1="190.5" y1="33.02" x2="190.5" y2="35.56" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND7" gate="1" pin="0V"/>
<pinref part="C4" gate="G$1" pin="2"/>
<wire x1="261.62" y1="-22.86" x2="261.62" y2="-17.78" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="X8" gate="-1" pin="KL"/>
<pinref part="GND9" gate="1" pin="0V"/>
<wire x1="325.12" y1="-12.7" x2="322.58" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="322.58" y1="-12.7" x2="322.58" y2="-17.78" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND8" gate="1" pin="0V"/>
<pinref part="R3" gate="G$1" pin="1"/>
<wire x1="284.48" y1="-33.02" x2="284.48" y2="-30.48" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND10" gate="1" pin="0V"/>
<pinref part="J1" gate="G$1" pin="2"/>
<wire x1="269.24" y1="12.7" x2="266.7" y2="12.7" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="B1" gate="1" pin="-"/>
<junction x="38.1" y="-15.24"/>
<pinref part="GND11" gate="1" pin="0V"/>
<wire x1="38.1" y1="-15.24" x2="33.02" y2="-15.24" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="IC1" gate="A" pin="OUT"/>
<pinref part="C2" gate="G$1" pin="+"/>
<wire x1="86.36" y1="-15.24" x2="93.98" y2="-15.24" width="0.1524" layer="91"/>
<pinref part="K1" gate="1" pin="1"/>
<wire x1="106.68" y1="73.66" x2="124.46" y2="73.66" width="0.1524" layer="91"/>
<wire x1="124.46" y1="73.66" x2="124.46" y2="58.42" width="0.1524" layer="91"/>
<pinref part="K5" gate="1" pin="1"/>
<wire x1="124.46" y1="58.42" x2="124.46" y2="43.18" width="0.1524" layer="91"/>
<wire x1="124.46" y1="43.18" x2="124.46" y2="27.94" width="0.1524" layer="91"/>
<wire x1="124.46" y1="27.94" x2="124.46" y2="22.86" width="0.1524" layer="91"/>
<wire x1="124.46" y1="22.86" x2="124.46" y2="12.7" width="0.1524" layer="91"/>
<wire x1="124.46" y1="12.7" x2="106.68" y2="12.7" width="0.1524" layer="91"/>
<pinref part="K4" gate="1" pin="1"/>
<wire x1="106.68" y1="27.94" x2="124.46" y2="27.94" width="0.1524" layer="91"/>
<junction x="124.46" y="27.94"/>
<pinref part="K3" gate="1" pin="1"/>
<wire x1="106.68" y1="43.18" x2="124.46" y2="43.18" width="0.1524" layer="91"/>
<junction x="124.46" y="43.18"/>
<pinref part="K2" gate="1" pin="1"/>
<wire x1="106.68" y1="58.42" x2="124.46" y2="58.42" width="0.1524" layer="91"/>
<junction x="124.46" y="58.42"/>
<wire x1="93.98" y1="-15.24" x2="124.46" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="124.46" y1="-15.24" x2="124.46" y2="12.7" width="0.1524" layer="91"/>
<junction x="93.98" y="-15.24"/>
<junction x="124.46" y="12.7"/>
<pinref part="IC2" gate="G$1" pin="CD+"/>
<wire x1="142.24" y1="22.86" x2="124.46" y2="22.86" width="0.1524" layer="91"/>
<junction x="124.46" y="22.86"/>
<wire x1="124.46" y1="-15.24" x2="190.5" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="190.5" y1="-15.24" x2="190.5" y2="22.86" width="0.1524" layer="91"/>
<junction x="124.46" y="-15.24"/>
<pinref part="C3" gate="G$1" pin="2"/>
<wire x1="190.5" y1="25.4" x2="190.5" y2="22.86" width="0.1524" layer="91"/>
<pinref part="U1" gate="G$1" pin="VDD"/>
<wire x1="190.5" y1="22.86" x2="203.2" y2="22.86" width="0.1524" layer="91"/>
<junction x="190.5" y="22.86"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="O1"/>
<pinref part="K5" gate="1" pin="2"/>
<wire x1="142.24" y1="2.54" x2="106.68" y2="2.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="O2"/>
<wire x1="142.24" y1="5.08" x2="127" y2="5.08" width="0.1524" layer="91"/>
<wire x1="127" y1="5.08" x2="127" y2="17.78" width="0.1524" layer="91"/>
<pinref part="K4" gate="1" pin="2"/>
<wire x1="127" y1="17.78" x2="106.68" y2="17.78" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="O3"/>
<wire x1="142.24" y1="7.62" x2="129.54" y2="7.62" width="0.1524" layer="91"/>
<pinref part="K3" gate="1" pin="2"/>
<wire x1="129.54" y1="7.62" x2="129.54" y2="33.02" width="0.1524" layer="91"/>
<wire x1="129.54" y1="33.02" x2="106.68" y2="33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="O4"/>
<wire x1="142.24" y1="10.16" x2="132.08" y2="10.16" width="0.1524" layer="91"/>
<pinref part="K2" gate="1" pin="2"/>
<wire x1="132.08" y1="10.16" x2="132.08" y2="48.26" width="0.1524" layer="91"/>
<wire x1="132.08" y1="48.26" x2="106.68" y2="48.26" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="O5"/>
<wire x1="142.24" y1="12.7" x2="134.62" y2="12.7" width="0.1524" layer="91"/>
<pinref part="K1" gate="1" pin="2"/>
<wire x1="134.62" y1="12.7" x2="134.62" y2="63.5" width="0.1524" layer="91"/>
<wire x1="134.62" y1="63.5" x2="106.68" y2="63.5" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="U1" gate="G$1" pin="RC3"/>
<wire x1="203.2" y1="-7.62" x2="170.18" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="I1"/>
<wire x1="170.18" y1="-7.62" x2="170.18" y2="2.54" width="0.1524" layer="91"/>
<wire x1="170.18" y1="2.54" x2="167.64" y2="2.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="U1" gate="G$1" pin="RC4"/>
<wire x1="203.2" y1="-2.54" x2="172.72" y2="-2.54" width="0.1524" layer="91"/>
<wire x1="172.72" y1="-2.54" x2="172.72" y2="5.08" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="I2"/>
<wire x1="172.72" y1="5.08" x2="167.64" y2="5.08" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="U1" gate="G$1" pin="RC5"/>
<wire x1="203.2" y1="2.54" x2="175.26" y2="2.54" width="0.1524" layer="91"/>
<wire x1="175.26" y1="2.54" x2="175.26" y2="7.62" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="I3"/>
<wire x1="175.26" y1="7.62" x2="170.18" y2="7.62" width="0.1524" layer="91"/>
<wire x1="167.64" y1="7.62" x2="170.18" y2="7.62" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$29" class="0">
<segment>
<pinref part="U1" gate="G$1" pin="RA4"/>
<wire x1="203.2" y1="12.7" x2="175.26" y2="12.7" width="0.1524" layer="91"/>
<wire x1="175.26" y1="12.7" x2="175.26" y2="10.16" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="I4"/>
<wire x1="175.26" y1="10.16" x2="170.18" y2="10.16" width="0.1524" layer="91"/>
<wire x1="167.64" y1="10.16" x2="170.18" y2="10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="U1" gate="G$1" pin="RA5"/>
<wire x1="203.2" y1="17.78" x2="172.72" y2="17.78" width="0.1524" layer="91"/>
<wire x1="172.72" y1="17.78" x2="172.72" y2="12.7" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="I5"/>
<wire x1="172.72" y1="12.7" x2="167.64" y2="12.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="R1" gate="G$1" pin="1"/>
<pinref part="R2" gate="G$1" pin="2"/>
<wire x1="302.26" y1="-7.62" x2="299.72" y2="-7.62" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$31" class="0">
<segment>
<pinref part="X8" gate="-2" pin="KL"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="325.12" y1="-7.62" x2="312.42" y2="-7.62" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="R2" gate="G$1" pin="1"/>
<pinref part="R4" gate="G$1" pin="2"/>
<wire x1="289.56" y1="-7.62" x2="284.48" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="U1" gate="G$1" pin="RC2"/>
<wire x1="248.92" y1="-7.62" x2="261.62" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="C4" gate="G$1" pin="1"/>
<wire x1="261.62" y1="-10.16" x2="261.62" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="284.48" y1="-7.62" x2="261.62" y2="-7.62" width="0.1524" layer="91"/>
<junction x="284.48" y="-7.62"/>
<junction x="261.62" y="-7.62"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="R3" gate="G$1" pin="2"/>
<pinref part="R4" gate="G$1" pin="1"/>
<wire x1="284.48" y1="-20.32" x2="284.48" y2="-17.78" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<pinref part="J1" gate="G$1" pin="1"/>
<pinref part="U1" gate="G$1" pin="RA1/D-"/>
<wire x1="256.54" y1="12.7" x2="248.92" y2="12.7" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
<note version="8.4" severity="warning">
Since Version 8.4, EAGLE supports properties for SPICE simulation.
Probes in schematics and SPICE mapping objects found in parts and library devices
will not be understood with this version. Update EAGLE to the latest version
for full support of SPICE simulation.
</note>
</compatibility>
</eagle>
