<root>
<document schema='101' license='1,,*****' title='' description='' target='PIC.16F.16F877A' >
	<config data='!0,3f72%0,2%2,0%3,0%6,1%7,0%9,3%b,1%8,1%d,1' clkspd='20000000' simspd='1' usewdt='0' constif='0' />
	<plugins >
		<dll_dbg_icd enabled='0' >
			<data name='debug' value='1' />
			<data name='userpins' value='0' />
			<data name='speed' value='0' />
			<data name='usev9' value='0' />
			<data name='breaks' value='8' />
			<data name='stacks' value='8' />
			<data name='clkport' value='1' />
			<data name='clkbit' value='6' />
			<data name='dataport' value='1' />
			<data name='databit' value='7' />
			<data name='ghostype' value='0' />
			<data name='monitor' value='1' />
			<data name='ictloop' value='0' />
			<data name='ictrate' value='20000' />
			<data name='ictmask' value='0' />
			<data name='anlpres' value='19' />
			<data name='digmask1' value='-1' />
			<data name='digmask2' value='-1' />
		</dll_dbg_icd>
		<dll_models enabled='1' />
		<dll_upgrader enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug />
	<ghost >
		<FK2 >
			<data name='FK2D0' port='4294967295' pin='4294967295' />
			<data name='FK2D1' port='4294967295' pin='4294967295' />
			<data name='FK2D2' port='4294967295' pin='4294967295' />
			<data name='FK2D3' port='4294967295' pin='4294967295' />
			<data name='FK2D4' port='4294967295' pin='4294967295' />
			<data name='FK2D5' port='4294967295' pin='4294967295' />
			<data name='FK2D6' port='4294967295' pin='4294967295' />
			<data name='FK2D7' port='4294967295' pin='4294967295' />
			<data name='FK2D8' port='4294967295' pin='4294967295' />
			<data name='FK2D9' port='4294967295' pin='4294967295' />
			<data name='FK2D10' port='4294967295' pin='4294967295' />
			<data name='FK2D11' port='4294967295' pin='4294967295' />
			<data name='FK2D12' port='4294967295' pin='4294967295' />
			<data name='FK2D13' port='4294967295' pin='4294967295' />
			<data name='FK2D14' port='4294967295' pin='4294967295' />
			<data name='FK2D15' port='4294967295' pin='4294967295' />
			<data name='FK2A0' port='4294967295' pin='4294967295' />
			<data name='FK2A1' port='4294967295' pin='4294967295' />
			<data name='FK2A2' port='4294967295' pin='4294967295' />
			<data name='FK2A3' port='4294967295' pin='4294967295' />
			<data name='FK2A4' port='4294967295' pin='4294967295' />
			<data name='FK2A5' port='4294967295' pin='4294967295' />
		</FK2>
		<ICD >
			<data name='AnalogPrescaleValue' value='19' />
			<data name='DigitalSampleRate' value='100000' />
			<data name='BreakpointCount' value='8' />
			<data name='CallStackDepthCount' value='8' />
			<data name='ClockPort' value='1' />
			<data name='ClockPin' value='6' />
			<data name='DataPort' value='1' />
			<data name='DataPin' value='7' />
			<data name='UseDefaultPins' value='1' />
			<data name='WrapEnabled' value='1' />
			<data name='CommsDelayOverridden' value='0' />
			<data name='CommsDelay' value='9' />
			<data name='CalculatedCommsDelay' value='9' />
		</ICD>
		<pins >
			<digital A='255' B='142' C='251' D='255' E='7' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
			<analog A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
		</pins>
	</ghost>
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='0' iconpath='' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='RGB_szinvaltas_old' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Valaszto' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Encoder_SW' type='u8' description='' isconst='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
					<def class_type='variable' name='Valaszto_szamlalo2' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='BT_Adat1' type='u8' description='' isconst='0' isinit='0' usrinit='0' setinit='' />
				</variable>
					<def class_type='variable' name='perges' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='RGB_szinvaltas' type='u8' description='' isconst='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
					<def class_type='variable' name='BT_fenyero_old' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='EEPRomba_iras' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='CountError' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Idozit' type='s16' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='MAX_LED' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Valaszto_menu' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Encoder_csatorna_elozo' type='s16' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Encoder_csatorna_A' type='s16' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Encoder_valtas' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Valaszto_gombhoz' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Elindul' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='LED_Fenyero' type='T8' description='' isconst='0' isinit='0' usrinit='&quot;&quot;' setinit='' >
						<array size='10' />
					</def>
				</variable>
					<def class_type='variable' name='BT_Fenyero' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='Encoder_Fenyero_szab' description='' >
						<return name='Return' type='v0' description='' isconst='0' isinit='0' usrinit='' setinit='' />
						<command class_type='decision' title='Decision' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Encoder_csatorna_A = Encoder_csatorna_elozo' swap='0' >
							<flowline />
							<flowline >
								<command class_type='decision' title='Decision' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Encoder_csatorna_A &gt; Encoder_csatorna_elozo' swap='0' >
									<flowline >
										<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[RGB_szinvaltas] &gt;= 128' swap='0' >
											<flowline >
												<command class_type='calculation' title='Count MAX' textarea='36,0,511,300' cmdcolor='16734039' cmdcolor_sec='16734039' >
													<exp exp='LED_Fenyero[RGB_szinvaltas] = MAX_LED' />
												</command>
											</flowline>
											<flowline >
												<command class_type='calculation' title='Calculation' cmdcolor='16734039' cmdcolor_sec='16734039' >
													<exp exp='LED_Fenyero[RGB_szinvaltas] = LED_Fenyero[RGB_szinvaltas] + 129' />
												</command>
													<flowline >
														</command>
													</flowline>
													<flowline />
												</command>
											</flowline>
										</command>
										<command class_type='calculation' title='Számítás' disable='1' cmdcolor='16734039' cmdcolor_sec='16734039' >
											<exp exp='BT_Fenyero = LED_Fenyero[RGB_szinvaltas]' />
										</command>
									</flowline>
									<flowline />
								</command>
								<command class_type='decision' title='Decision' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Encoder_csatorna_A &lt; Encoder_csatorna_elozo' swap='0' >
									<flowline >
										<command class_type='decision' title='Decision' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[RGB_szinvaltas] &lt; 128' swap='0' >
											<flowline >
												<command class_type='calculation' title='Count MIN' cmdcolor='16734039' cmdcolor_sec='16734039' >
													<exp exp='LED_Fenyero[RGB_szinvaltas] = 0' />
												</command>
											</flowline>
											<flowline >
													<exp exp='LED_Fenyero[RGB_szinvaltas] = LED_Fenyero[RGB_szinvaltas] - 129' />
													<exp exp='' />
												</command>
													<flowline >
														</command>
													</flowline>
													<flowline />
												</command>
											</flowline>
										</command>
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='LCD_kiiras' description='' >
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='LCD_4x20' macro='Cursor' >
							<argument exp='0' />
						</command>
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='LCD_4x20' macro='PrintString' >
							<argument exp='&quot;Feny:&quot;' />
						</command>
							<argument exp='5' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[RGB_szinvaltas] &lt; 100' swap='0' >
							<flowline >
									<argument exp='&quot; &quot;' />
								</command>
								<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[RGB_szinvaltas] &lt; 10' swap='0' >
									<flowline >
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
							<flowline />
						</command>
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='LCD_4x20' macro='PrintNumber' >
							<argument exp='LED_Fenyero[RGB_szinvaltas]' />
						</command>
						</command>
							<argument exp='12' />
						</command>
							<argument exp='&quot;V:&quot;' />
						</command>
							<argument exp='Valaszto_gombhoz' />
						</command>
							<argument exp='1' />
						</command>
							<argument exp='&quot;Szin:&quot;' />
						</command>
							<argument exp='RGB_szinvaltas' />
						</command>
						</command>
							<argument exp='&quot;Val:&quot;' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto &lt; 10' swap='0' >
							<flowline >
									<argument exp='Valaszto' />
								</command>
								</command>
							</flowline>
							<flowline >
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Bluetooth' description='' >
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='Bluetooth_HC05' macro='ReceiveChar' >
							<return exp='BT_Adat1' />
							<argument exp='30' />
						</command>
						<command class_type='switch' title='Többirányú elágazás' textarea='36,25,36,25' cmdcolor='12615680' cmdcolor_sec='15376912' exp='BT_Adat1' >
							<case >
								<flowline />
							</case>
							<case exp='&apos;H&apos;' >
								<flowline >
									<command class_type='calculation' title='Számítás' cmdcolor='16734039' cmdcolor_sec='16734039' >
										<exp exp='Valaszto = &apos;H&apos;' />
										<exp exp='RGB_szinvaltas = 1' />
										<exp exp='RGB_szinvaltas_old = RGB_szinvaltas' />
										<exp exp='' />
										<exp exp='Valaszto_menu = 0' />
										<exp exp='Valaszto_szamlalo2 = 5' />
										<exp exp='' />
										<exp exp='BT_Adat1 = 0' />
										<exp exp='' />
									</command>
								</flowline>
							</case>
							<case exp='&apos;M&apos;' >
								<flowline >
									<command class_type='calculation' title='Számítás' textarea='36,0,511,0' cmdcolor='16734039' cmdcolor_sec='16734039' >
										<exp exp='Valaszto = &apos;M&apos;' />
										<exp exp='RGB_szinvaltas = 4' />
										<exp exp='' />
										<exp exp='Valaszto_szamlalo2 = 15' />
										<exp exp='' />
									</command>
								</flowline>
							</case>
							<case exp='&apos;L&apos;' >
								<flowline >
										<exp exp='Valaszto = &apos;L&apos;' />
										<exp exp='RGB_szinvaltas = 7' />
										<exp exp='' />
										<exp exp='Valaszto_szamlalo2 = 25' />
										<exp exp='' />
									</command>
								</flowline>
							</case>
							<case exp='&apos;R&apos;' >
								<flowline >
									<command class_type='calculation' title='Számítás' textarea='36,0,511,300' cmdcolor='16734039' cmdcolor_sec='16734039' >
										<exp exp='' />
									</command>
									<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = &apos;H&apos;' swap='0' >
										<flowline >
											</command>
										</flowline>
										<flowline />
									</command>
									<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = &apos;M&apos;' swap='0' >
										<flowline >
											<command class_type='calculation' title='Számítás' textarea='36,0,626,0' cmdcolor='16734039' cmdcolor_sec='16734039' >
											</command>
										</flowline>
										<flowline />
									</command>
									<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = &apos;L&apos;' swap='0' >
										<flowline >
											</command>
										</flowline>
										<flowline />
									</command>
										<exp exp='' />
									</command>
								</flowline>
							</case>
							<case exp='&apos;G&apos;' >
								<flowline >
										<exp exp='' />
									</command>
										<flowline >
												<exp exp='RGB_szinvaltas = 2' />
											</command>
										</flowline>
										<flowline />
									</command>
										<flowline >
												<exp exp='RGB_szinvaltas = 5' />
											</command>
										</flowline>
										<flowline />
									</command>
										<flowline >
												<exp exp='RGB_szinvaltas = 8' />
											</command>
										</flowline>
										<flowline />
									</command>
										<exp exp='' />
									</command>
								</flowline>
							</case>
							<case exp='&apos;B&apos;' >
								<flowline >
										<exp exp='' />
									</command>
										<flowline >
												<exp exp='RGB_szinvaltas = 3' />
											</command>
										</flowline>
										<flowline />
									</command>
										<flowline >
												<exp exp='RGB_szinvaltas = 6' />
											</command>
										</flowline>
										<flowline />
									</command>
										<flowline >
												<exp exp='RGB_szinvaltas = 9' />
											</command>
										</flowline>
										<flowline />
									</command>
									</command>
								</flowline>
							</case>
							<case exp='&apos;J&apos;' >
								<flowline >
										<exp exp='Elindul = 1' />
										<exp exp='' />
									</command>
								</flowline>
							</case>
							<case exp='&apos;K&apos;' >
								<flowline >
										<exp exp='Elindul = 0' />
										<exp exp='' />
									</command>
								</flowline>
							</case>
						</command>
						<command class_type='switch' title='Többirányú elágazás' textarea='36,25,511,325' cmdcolor='12615680' cmdcolor_sec='15376912' exp='BT_Adat1' >
							<case >
								<flowline />
							</case>
							<case exp='&apos;A&apos;' >
								<flowline >
										<exp exp='BT_Fenyero = MAX_LED' />
										<exp exp='EEPRomba_iras = 1' />
									</command>
									</command>
								</flowline>
							</case>
							<case exp='&apos;C&apos;' >
								<flowline >
										<exp exp='BT_Fenyero = 0' />
									</command>
									</command>
								</flowline>
							</case>
							<case exp='&apos;D&apos;' >
								<flowline >
										<exp exp='BT_Fenyero = BT_Fenyero + 129' />
									</command>
									</command>
								</flowline>
							</case>
							<case exp='&apos;E&apos;' >
								<flowline >
										<exp exp='BT_Fenyero = BT_Fenyero - 129' />
									</command>
									</command>
								</flowline>
							</case>
							<case exp='&apos;F&apos;' >
								<flowline >
									</command>
									</command>
								</flowline>
							</case>
							<case exp='&apos;I&apos;' >
								<flowline >
									</command>
									</command>
								</flowline>
							</case>
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='BT_Fenyero &gt;= 128' swap='0' >
							<flowline >
								</command>
							</flowline>
							<flowline />
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='BT_Fenyero &lt; 128' swap='0' >
							<flowline >
								</command>
							</flowline>
							<flowline />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='White_Visszajelzo' description='' >
						<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = 72' swap='0' >
							<flowline >
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='W_led1_Back' macro='TurnOn' />
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='W_led2_pointer' macro='TurnOff' />
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='W_led3_LCD' macro='TurnOff' />
							</flowline>
							<flowline />
						</command>
						<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = 77' swap='0' >
							<flowline >
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='W_led1_Back' macro='TurnOff' />
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='W_led2_pointer' macro='TurnOn' />
							</flowline>
							<flowline />
						</command>
						<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = 76' swap='0' >
							<flowline >
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='W_led3_LCD' macro='TurnOn' />
							</flowline>
							<flowline />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Encoder_kimenet_valaszto' description='' >
							<flowline />
							<flowline >
									<flowline >
											<exp exp='Valaszto_szamlalo2 = Valaszto_szamlalo2 + 1' />
										</command>
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_szamlalo2 &gt; 45' swap='0' >
											<flowline >
													<exp exp='Valaszto_szamlalo2 = 1' />
												</command>
											</flowline>
											<flowline >
												<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_szamlalo2 &gt; 0 AND Valaszto_szamlalo2 &lt;= 10' swap='0' >
													<flowline >
															<exp exp='Valaszto_menu = 1' />
														</command>
													</flowline>
													<flowline />
												</command>
												<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_szamlalo2 &gt; 15 AND Valaszto_szamlalo2 &lt;= 25' swap='0' >
													<flowline >
															<exp exp='Valaszto_menu = 2' />
														</command>
													</flowline>
													<flowline />
												</command>
												<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_szamlalo2 &gt; 30 AND Valaszto_szamlalo2 &lt;= 40' swap='0' >
													<flowline >
															<exp exp='Valaszto_menu = 3' />
														</command>
													</flowline>
													<flowline />
												</command>
											</flowline>
										</command>
									</flowline>
									<flowline />
								</command>
									<flowline >
											<exp exp='Valaszto_szamlalo2 = Valaszto_szamlalo2 - 1' />
										</command>
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_szamlalo2 &lt; 1' swap='0' >
											<flowline >
													<exp exp='Valaszto_szamlalo2 = 45' />
												</command>
											</flowline>
											<flowline >
												<command class_type='decision' title='Feltételes elágazás' textarea='102,3,102,3' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_szamlalo2 &gt; 0 AND Valaszto_szamlalo2 &lt;= 10' swap='0' >
													<flowline >
														</command>
													</flowline>
													<flowline />
												</command>
													<flowline >
														</command>
													</flowline>
													<flowline />
												</command>
													<flowline >
														</command>
													</flowline>
													<flowline />
												</command>
											</flowline>
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='EEPROM_olvas' description='' >
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='EEPRom1' macro='Read' >
							<return exp='Valaszto' />
						</command>
							<return exp='LED_Fenyero[1]' />
						</command>
							<return exp='LED_Fenyero[2]' />
							<argument exp='2' />
						</command>
							<return exp='LED_Fenyero[3]' />
							<argument exp='3' />
						</command>
							<return exp='LED_Fenyero[4]' />
							<argument exp='4' />
						</command>
							<return exp='LED_Fenyero[5]' />
						</command>
							<return exp='LED_Fenyero[6]' />
							<argument exp='6' />
						</command>
							<return exp='LED_Fenyero[7]' />
							<argument exp='7' />
						</command>
							<return exp='LED_Fenyero[8]' />
							<argument exp='8' />
						</command>
							<return exp='LED_Fenyero[9]' />
							<argument exp='9' />
						</command>
							<return exp='RGB_szinvaltas' />
							<argument exp='10' />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Idozit_TMR' description='' >
						<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Idozit &gt;= 610' swap='0' >
							<flowline >
								<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Idozit &gt;= 1220' swap='0' >
									<flowline >
											<exp exp='Valaszto_gombhoz = Valaszto_gombhoz + 1' />
											<exp exp='Idozit = 0' />
										</command>
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_gombhoz &gt; 35' swap='0' >
											<flowline >
													<exp exp='Valaszto_gombhoz = 0' />
												</command>
											</flowline>
											<flowline />
										</command>
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = 72 AND perges = 1' swap='0' >
											<flowline >
											</flowline>
											<flowline />
										</command>
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = 77 AND perges = 1' swap='0' >
											<flowline >
											</flowline>
											<flowline />
										</command>
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = 76 AND perges = 1' swap='0' >
											<flowline >
											</flowline>
											<flowline />
										</command>
									</flowline>
									<flowline >
											<flowline >
											</flowline>
											<flowline />
										</command>
											<flowline >
											</flowline>
											<flowline />
										</command>
											<flowline >
											</flowline>
											<flowline />
										</command>
									</flowline>
								</command>
							</flowline>
							<flowline />
						</command>
							<exp exp='Idozit = Idozit + 1' />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='led_setting' description='' >
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[1] &gt;= 128' swap='1' >
							<flowline >
								<command class_type='output' title='Output' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048579' mask='4' exp='0' />
							</flowline>
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048579' mask='4' exp='1' />
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[2] &gt;= 128' swap='1' >
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048579' mask='1' exp='0' />
							</flowline>
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048579' mask='1' exp='1' />
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[3] &gt;= 128' swap='1' >
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048579' mask='2' exp='0' />
							</flowline>
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048579' mask='2' exp='1' />
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[4] &gt;= 128' swap='1' >
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048576' mask='1' exp='0' />
							</flowline>
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048576' mask='1' exp='1' />
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[5] &gt;= 128' swap='1' >
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048576' mask='2' exp='0' />
							</flowline>
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048576' mask='2' exp='1' />
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[6] &gt;= 128' swap='1' >
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048576' mask='4' exp='0' />
							</flowline>
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048576' mask='4' exp='1' />
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[7] &gt;= 128' swap='1' >
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048580' mask='1' exp='0' />
							</flowline>
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048580' mask='1' exp='1' />
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[8] &gt;= 128' swap='1' >
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048580' mask='2' exp='0' />
							</flowline>
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048580' mask='2' exp='1' />
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='LED_Fenyero[9] &gt;= 128' swap='1' >
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048580' mask='4' exp='0' />
							</flowline>
							<flowline >
								<command class_type='output' title='Kimenet' textarea='36,0,511,300' cmdcolor='6914048' cmdcolor_sec='6914048' mode='1' port='1048580' mask='4' exp='1' />
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Encoder_megszakitas' description='' >
						<local name='change' type='u8' description='0' isconst='0' isinit='1' usrinit='0' setinit='0' />
						<command class_type='call' title='Call Component Macro' cmdcolor='12602112' cmdcolor_sec='12602112' component='QuadEncoder1' macro='CheckForChanges' >
							<return exp='.change' />
						</command>
						<command class_type='decision' title='Decision' cmdcolor='12615680' cmdcolor_sec='15376912' exp='.change = 255' swap='0' >
							<flowline >
									<exp exp='CountError = 1' />
								</command>
							</flowline>
							<flowline />
						</command>
						<command class_type='decision' title='Check for any errors' cmdcolor='12615680' cmdcolor_sec='15376912' exp='CountError &gt; 0' swap='0' >
							<flowline />
							<flowline >
								<command class_type='calculation' title='Calculation' textarea='110,-13,110,-13' cmdcolor='16734039' cmdcolor_sec='16734039' >
									<exp exp='Encoder_csatorna_elozo = Encoder_csatorna_A' />
								</command>
								<command class_type='call' title='Call Component Macro' cmdcolor='12602112' cmdcolor_sec='12602112' component='QuadEncoder1' macro='ReadCounter' >
									<return exp='Encoder_csatorna_A' />
								</command>
								<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Elindul = 1' swap='1' >
									<flowline />
									<flowline >
										<command class_type='decision' title='Encoder választó' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Encoder_valtas = 1' swap='0' >
											<flowline >
												<command class_type='call' title='Makró hívás' cmdcolor='12592128' cmdcolor_sec='12592128' macro='Encoder_kimenet_valaszto' />
											</flowline>
											<flowline >
												<command class_type='call' title='Makró hívás' textarea='36,0,422,0' cmdcolor='12592128' cmdcolor_sec='12592128' macro='Encoder_Fenyero_szab' />
											</flowline>
										</command>
									</flowline>
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='EEPRom_iras' description='' >
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='EEPRom1' macro='Write' >
						</command>
							<argument exp='LED_Fenyero[1]' />
						</command>
							<argument exp='LED_Fenyero[2]' />
						</command>
							<argument exp='LED_Fenyero[3]' />
						</command>
							<argument exp='LED_Fenyero[4]' />
						</command>
							<argument exp='LED_Fenyero[5]' />
						</command>
							<argument exp='LED_Fenyero[6]' />
						</command>
							<argument exp='LED_Fenyero[7]' />
						</command>
							<argument exp='LED_Fenyero[8]' />
						</command>
							<argument exp='LED_Fenyero[9]' />
						</command>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='RGB_Visszajelzo' description='' >
						<command class_type='decision' title='Feltételes elágazás' textarea='36,0,1483,0' cmdcolor='12615680' cmdcolor_sec='15376912' exp='RGB_szinvaltas = 1 OR RGB_szinvaltas = 4 OR RGB_szinvaltas = 7' swap='0' >
							<flowline >
								<command class_type='call' title='Call Component Macro' cmdcolor='12602112' cmdcolor_sec='12602112' component='RGB_Red' macro='TurnOn' />
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='RGB_Green' macro='TurnOff' />
								<command class_type='call' title='Call Component Macro' cmdcolor='12602112' cmdcolor_sec='12602112' component='RGB_Blue' macro='TurnOff' />
							</flowline>
							<flowline />
						</command>
						<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='RGB_szinvaltas = 2 OR RGB_szinvaltas = 5 OR RGB_szinvaltas = 8' swap='0' >
							<flowline >
								<command class_type='call' title='Call Component Macro' cmdcolor='12602112' cmdcolor_sec='12602112' component='RGB_Red' macro='TurnOff' />
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='RGB_Green' macro='TurnOn' />
							</flowline>
							<flowline />
						</command>
						<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='RGB_szinvaltas = 3 OR RGB_szinvaltas = 6 OR RGB_szinvaltas = 9' swap='0' >
							<flowline >
								<command class_type='call' title='Call Component Macro' cmdcolor='12602112' cmdcolor_sec='12602112' component='RGB_Blue' macro='TurnOn' />
							</flowline>
							<flowline />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Main' description='' >
						<command class_type='call' title='Call Component Macro' cmdcolor='12602112' cmdcolor_sec='12602112' component='Bluetooth_HC05' macro='Initialise' />
						<command class_type='call' title='Call Component Macro' cmdcolor='12602112' cmdcolor_sec='12602112' component='QuadEncoder1' macro='Enable' />
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='LCD_4x20' macro='Start' />
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='LCD_4x20' macro='Clear' />
							<exp exp='RGB_szinvaltas_old = 0' />
							<exp exp='MAX_LED = 255' />
							<exp exp='EEPRomba_iras = 0' />
							<exp exp='' />
						</command>
						<command class_type='call' title='Makró hívás' textarea='36,0,511,300' cmdcolor='12592128' cmdcolor_sec='12592128' macro='EEPROM_olvas' />
						<command class_type='label' title='Kapcsolódási pont' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' labelid='0' labelname='A' />
						<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = &apos;H&apos;OR Valaszto = &apos;M&apos;OR Valaszto = &apos;L&apos;' swap='1' >
							<flowline >
								<command class_type='calculation' title='Számítás' textarea='134,55,134,55' cmdcolor='16734039' cmdcolor_sec='16734039' >
									<exp exp='LED_Fenyero[0] = 0' />
									<exp exp='LED_Fenyero[1] = 0' />
									<exp exp='LED_Fenyero[2] = 0' />
									<exp exp='LED_Fenyero[3] = 0' />
									<exp exp='LED_Fenyero[4] = 0' />
									<exp exp='LED_Fenyero[5] = 0' />
									<exp exp='LED_Fenyero[6] = 0' />
									<exp exp='LED_Fenyero[7] = 0' />
									<exp exp='LED_Fenyero[8] = 0' />
									<exp exp='LED_Fenyero[9] = 0' />
								</command>
							</flowline>
							<flowline />
						</command>
						<command class_type='interrupt' title='Megszakítás' cmdcolor='17151' cmdcolor_sec='355583' enable='1' name='IOC0' call='Encoder_megszakitas' >
							<settings timer='0' prescale='-1' postscale='-1' rollover='-1' bitcount='-1' trigger='3' maskhi='-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAA' masklo='-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAA' >
								<option value='0' />
								<option value='-1' />
							</settings>
						</command>
						<command class_type='interrupt' title='Megszakítás' cmdcolor='17151' cmdcolor_sec='355583' enable='1' name='TMR2' call='Idozit_TMR' >
							<settings timer='1' prescale='1' postscale='8' rollover='256' bitcount='-1' trigger='3' maskhi='-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAA' masklo='-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAA' >
								<option value='7' />
								<option value='256' />
							</settings>
						</command>
						<command class_type='loop' title='Ciklus' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' type='0' exp='1' >
							<flowline >
								<command class_type='switch' title='Többirányú elágazás' textarea='36,25,36,25' disable='1' cmdcolor='16711680' cmdcolor_sec='16734039' cmdcustom_color='1' exp='Valaszto_menu' >
									<case >
										<flowline />
									</case>
									<case exp='1' >
										<flowline >
											</command>
										</flowline>
									</case>
									<case exp='2' >
										<flowline >
											</command>
										</flowline>
									</case>
									<case exp='3' >
										<flowline >
											</command>
										</flowline>
									</case>
								</command>
								<command class_type='call' title='Makró hívás' textarea='159,3,634,303' disable='1' cmdcolor='12592128' cmdcolor_sec='12592128' macro='Bluetooth' />
								<command class_type='decision' title='Feltételes elágazás' disable='1' cmdcolor='12615680' cmdcolor_sec='15376912' exp='RGB_szinvaltas = RGB_szinvaltas_old' swap='0' >
									<flowline >
											<exp exp='LED_Fenyero[RGB_szinvaltas_old] = BT_Fenyero' />
										</command>
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='EEPRomba_iras = 1' swap='0' >
											<flowline >
												</command>
												</command>
												</command>
												</command>
											</flowline>
											<flowline />
										</command>
									</flowline>
									<flowline />
								</command>
								<command class_type='call' title='led_setting' cmdcolor='12592128' cmdcolor_sec='12592128' macro='led_setting' />
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' cmdcolor='12602112' cmdcolor_sec='12602112' component='Encoder_Switch' macro='ReadState' >
									<return exp='Encoder_SW' />
								</command>
								<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Encoder_SW' swap='0' >
									<flowline >
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='perges = 1' swap='0' >
											<flowline >
												<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_gombhoz &gt;= 5' swap='0' >
													<flowline >
														<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_gombhoz &gt;= 10' swap='0' >
															<flowline >
																<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_gombhoz &gt;= 15' swap='0' >
																	<flowline >
																		<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto_gombhoz &gt;= 25' swap='0' >
																			<flowline >
																					<exp exp='Valaszto = 0' />
																				</command>
																				<command class_type='goto' title='Menj a kapcsolódási porthoz' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' labelid='0' labelname='' />
																			</flowline>
																			<flowline >
																				<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Valaszto = 72' swap='0' >
																					<flowline >
																						</command>
																					</flowline>
																					<flowline />
																				</command>
																					<flowline >
																						</command>
																					</flowline>
																					<flowline />
																				</command>
																					<flowline >
																						</command>
																					</flowline>
																					<flowline />
																				</command>
																				<command class_type='calculation' title='Számítás' textarea='36,0,511,300' disable='1' cmdcolor='16734039' cmdcolor_sec='16734039' >
																					<exp exp='' />
																				</command>
																				<command class_type='call' title='Makró hívás' textarea='36,0,511,300' cmdcolor='12592128' cmdcolor_sec='12592128' macro='EEPRom_iras' />
																			</flowline>
																		</command>
																	</flowline>
																	<flowline >
																		<command class_type='calculation' title='Számítás' textarea='80,32,555,32' cmdcolor='16734039' cmdcolor_sec='16734039' >
																			<exp exp='' />
																		</command>
																	</flowline>
																</command>
															</flowline>
															<flowline >
																	<exp exp='Encoder_valtas = 1' />
																</command>
																<command class_type='delay' title='Delay' cmdcolor='32896' cmdcolor_sec='32896' exp='100' type='1' />
															</flowline>
														</command>
													</flowline>
													<flowline >
														<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Encoder_valtas = 1' swap='0' >
															<flowline >
																	<exp exp='Encoder_valtas = 0' />
																</command>
															</flowline>
															<flowline >
																	<exp exp='RGB_szinvaltas = RGB_szinvaltas + 1' />
																</command>
															</flowline>
														</command>
														<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' totalfolded='1' exp='Valaszto = 72' swap='0' >
															<flowline folded='1' totalfolded='1' >
																<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' hiddenFromFold='1' exp='RGB_szinvaltas &gt; 3' swap='0' >
																	<flowline >
																		<command class_type='calculation' title='Számítás' textarea='36,0,511,300' cmdcolor='16734039' cmdcolor_sec='16734039' hiddenFromFold='1' >
																			<exp exp='' />
																		</command>
																	</flowline>
																	<flowline />
																</command>
															</flowline>
															<flowline folded='1' totalfolded='1' />
														</command>
														<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' totalfolded='1' exp='Valaszto = 77' swap='0' >
																<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' hiddenFromFold='1' exp='RGB_szinvaltas &gt; 6' swap='0' >
																	<flowline >
																			<exp exp='' />
																			<exp exp='' />
																		</command>
																	</flowline>
																	<flowline />
																</command>
															</flowline>
														</command>
														<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' totalfolded='1' exp='Valaszto = 76' swap='0' >
																<command class_type='decision' title='Feltételes elágazás' cmdcolor='12615680' cmdcolor_sec='15376912' hiddenFromFold='1' exp='RGB_szinvaltas &gt; 9' swap='0' >
																	<flowline >
																			<exp exp='' />
																		</command>
																	</flowline>
																	<flowline />
																</command>
															</flowline>
														</command>
													</flowline>
												</command>
												</command>
											</flowline>
											<flowline >
													<flowline >
													</flowline>
													<flowline >
														<command class_type='call' title='Call Macro' cmdcolor='12592128' cmdcolor_sec='12592128' macro='White_Visszajelzo' />
														<command class_type='call' title='' textarea='36,0,511,300' cmdcolor='12592128' cmdcolor_sec='12592128' macro='RGB_Visszajelzo' />
													</flowline>
												</command>
											</flowline>
										</command>
											<exp exp='perges = 0' />
										</command>
									</flowline>
									<flowline >
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Elindul = 0' swap='0' >
											<flowline >
												</command>
											</flowline>
											<flowline >
													<exp exp='perges = 1' />
													<exp exp='' />
												</command>
											</flowline>
										</command>
									</flowline>
								</command>
								<command class_type='call' title='Makró hívás' textarea='36,0,511,300' cmdcolor='12592128' cmdcolor_sec='12592128' macro='LCD_kiiras' />
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='a8dbe015-0985-4581-abd5-1cc44f576fab' vmin='0' vmaj='2' codename='Bluetooth_HC05' x='40' y='63.6043' z='0.0715777' xsz='60.0001' ysz='30' zsz='10' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='cal_uart::DBITS' data='008' />
					<value target='cal_uart::RETURN' data='000' />
					<value target='cal_uart::ECHO' data='000' />
					<value target='cal_uart::BAUD_LIST' data='004' />
					<value target='cal_uart::BAUD' data='9600' />
					<value target='cal_uart::CHANNEL' data='001' />
					<value target='cal_uart::UseTX' data='1' />
					<value target='cal_uart::OutputPins' data='007' />
					<value target='cal_uart::TXAlt' data='0' />
					<value target='cal_uart::TX' data='$PORTC.6' />
					<value target='cal_uart::UseRX' data='1' />
					<value target='cal_uart::InputPins' data='013' />
					<value target='cal_uart::RXAlt' data='0' />
					<value target='cal_uart::RX' data='$PORTC.7' />
					<value target='cal_uart::FLOWEN' data='000' />
					<value target='cal_uart::RTS' data='$PORTB.2' />
					<value target='cal_uart::CTS' data='$PORTB.1' />
					<value target='label' data='HC05/HC06' />
					<value target='cal_uart::ScopeTraces' data='0' />
					<value target='cal_uart::ConsoleData' data='0' />
					<value target='cal_uart::ConsoleColumns' data='64' />
					<value target='cal_uart::DataSource' data='000' />
					<value target='cal_uart::com_port' data='000' />
					<value target='cal_uart::Injector' data='000' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='dcbf571f-a6fa-402d-bdd4-be00cca4070f' vmin='1' vmaj='1' codename='EEPRom1' x='20' y='20' z='0' xsz='20' ysz='20' zsz='20' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='EESize' data='256 byte' />
					<value target='EEbitdepth' data='8 bit' />
					<value target='InitialValues' data='0,1,0x2,0x03,&apos;A&apos;,&apos;b&apos;,&quot;Hello&quot;' />
					<value target='InitValsParsed' data='0,1,0x2,0x03,&apos;A&apos;,&apos;b&apos;,&apos;H&apos;,&apos;e&apos;,&apos;l&apos;,&apos;l&apos;,&apos;o&apos;' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='a2b40602-5421-4e2f-ba82-96db1be51d69' vmin='1' vmaj='1' codename='LCD_4x20' x='-40' y='60' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='Pin_Data_0' data='$PORTD.7' />
					<value target='Pin_Data_1' data='$PORTD.6' />
					<value target='Pin_Data_2' data='$PORTD.5' />
					<value target='Pin_Data_3' data='$PORTD.4' />
					<value target='Pin_RS' data='$PORTC.4' />
					<value target='Pin_E' data='$PORTC.5' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='248e0a81-43e3-4ff7-b87d-69c04add1fb9' vmin='1' vmaj='0' codename='W_led1_Back' x='92.5' y='102.5' z='11' xsz='4' ysz='4' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.3' />
					<value target='polarity' data='001' />
					<value target='on_color' data='16777215' />
					<value target='Shape' data='004' />
					<value target='width' data='5.000000' />
					<value target='height' data='5.000000' />
					<value target='depth' data='2.500000' />
					<value target='show_label' data='002' />
					<value target='label_property' data='pin' />
					<value target='label_color' data='16777215' />
					<value target='label_scale' data='1.000000' />
					<value target='label_auto_scale' data='0' />
					<value target='label_position' data='003' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='248e0a81-43e3-4ff7-b87d-69c04add1fb9' vmin='1' vmaj='0' codename='W_led2_pointer' x='87.5' y='74.15' z='7.425' xsz='4' ysz='4' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.5' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='248e0a81-43e3-4ff7-b87d-69c04add1fb9' vmin='1' vmaj='0' codename='W_led3_LCD' x='87.5' y='47.5' z='9.675' xsz='4' ysz='4' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTB.7' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='a31b1f0a-4221-490d-ae25-027868688f0b' vmin='0' vmaj='1' codename='Encoder_Switch' x='0' y='100' z='9.175' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTD.3' />
					<value target='polarity' data='000' />
					<value target='debounce' data='10' />
					<value target='operation' data='000' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='d92e8259-f3a8-4176-a8c4-fe7ca42b2c3f' vmin='1' vmaj='1' codename='RGB_Red' x='30' y='100' z='6.175' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTC.0' />
					<value target='on_color' data='10551200' />
					<value target='length' data='4.000000' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='d92e8259-f3a8-4176-a8c4-fe7ca42b2c3f' vmin='1' vmaj='1' codename='RGB_Green' x='50' y='100' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTC.1' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='d92e8259-f3a8-4176-a8c4-fe7ca42b2c3f' vmin='1' vmaj='1' codename='RGB_Blue' x='40' y='100' z='8.35' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTC.3' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='3531a68d-7686-44b7-a3a5-67afda8467dc' vmin='3' vmaj='1' codename='QuadEncoder1' x='60' y='20' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='1' >
				<resources />
				<properties />
				<values >
					<value target='Divider' data='001' />
					<value target='pin_a' data='$PORTB.4' />
					<value target='pin_b' data='$PORTB.5' />
					<value target='reprate' data='075' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<keymap />
	<panel2d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='7292207' img='' style='0' />
		<camera xe='-44.4523' ye='-97.6763' ze='1104.84' xt='-44.4523' yt='-97.6763' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
	</panel2d>
	<panel3d shadows='1' lighting='2' brightness='0' perspective='1' >
		<background rgb='8409120' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='0' />
		<camera xe='1.69171' ye='154.98' ze='273.609' xt='1.69171' yt='154.98' zt='0.0715777' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey0 xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey1 xe='-3.67394e-14' ye='0' ze='-300' xt='0' yt='0' zt='0' xquat='0' yquat='1' zquat='0' wquat='6.12323e-17' />
		<camerakey2 xe='0' ye='-300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.707107' yquat='0' zquat='0' wquat='0.707107' />
		<camerakey3 xe='-3.67394e-14' ye='300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-4.32978e-17' yquat='0.707107' zquat='0.707107' wquat='4.32978e-17' />
		<camerakey4 xe='-300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='0.5' zquat='0.5' wquat='0.5' />
		<camerakey5 xe='300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='-0.5' zquat='-0.5' wquat='0.5' />
		<camerakey6 xe='-173.205' ye='-173.205' ze='173.205' xt='0' yt='0' zt='0' xquat='-0.424708' yquat='0.17592' zquat='0.339851' wquat='0.820473' />
	</panel3d>
	<layout >
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAA9AQAAJgCAAA' zoom='75' scrollx='0' scrolly='0' flags='0' />
		<view type='0' name='led_setting' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAA9AQAAJgCAAA' zoom='75' scrollx='0' scrolly='0' flags='0' />
		<view type='0' name='Encoder_megszakitas' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAA9AQAAJgCAAA' zoom='75' scrollx='0' scrolly='72' flags='0' />
		<view type='0' name='Encoder_Fenyero_szab' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAA9AQAAJgCAAA' zoom='75' scrollx='0' scrolly='0' flags='0' />
	</layout>
</document>
</root>
