CPU-Z
Version 1.26
December 2004
Contact : cpuz@cpuid.com
Web page: http://www.cpuid.com/cpuz.php
CPU-Z is a freeware and can be freely distributed.
Configuration file (cpuz.ini)
The configuration file must be named cpuz.ini and be present at the same directory level
as cpuz.exe. It contains the following :
[CPU-Z]
TextFontName=Verdana
TextFontSize=13
TextFontColor=000060
LabelFontName=Verdana
LabelFontSize=13
DMI=1
Sensor=1
SMBus=1
- TextFontName : Font used for the information boxes.
- TextFontSize : Size of the font used for the information boxes.
- TextFontColor : Color of the font used for the information boxes. Value is expressed in hexadecimal, and consists in a classic Red/Green/Blue color code : RRGGBB
- LabelFontName : Font used for the label boxes.
- LabelFontSize : Size of the font used for the label boxes.
- Sensor : Set to 0 disables sensor chip detection and voltages measurement.
- DMI : Set to 0 disables the DMI (Desktop Management Interface) information. This concerns BIOS vendor and version, motherboard vendor and revision.
- SMBus : Set to 0 disables SMBus information : SPD, and, depending on the hardware, sensoring information.
Parameters
-file=filename : Launch CPU-Z in ghost mode : no interface appears,
the file report is created in the same directory than the exe file.
Keys
F5 : save the current tab in a bmp file
F6 : save the current tab in the clipboard
Cache Latency Tool
The cache latency tool is now a stand-alone program that is included in the CPU-Z package.
Please run latency.exe from a console, within Windows.
You can use a pipe command to save the results :
c:\CPUZ>latency.exe >result.txt
History
1.26 - December 2004
- VCore display on Pentium M CPUs.
- New CPU clock computation.
- Improved support of Transmeta CPUs.
- Several bugs fixed.
1.25 - November 2004
- nVidia nForce4 chipset support
- Intel Pentium 4J support
- New button to refresh memory timings
1.24 - September 2004
- AMD Sempron support
- New memory SPD page
- PCI-Express graphic interface support
- Configuration file
- External cache latency tool
- Restored html report
- Fix several bugs
1.23 - June 2004
- Intel i915P/G, i925X chipsets support
- Intel LGA775 CPUs support
- Intel's CPU number display
- New AMD Athlon 64 steppings
- New report in one file
1.22 - April 2004
- New CPUs : Xeon Nocona, Celeron Prescott
- DDR2 memory support
- Clock mode when iconized
1.21 - 01/25/2004
- one file package
- Windows 64 support
- new chipsets support
- new CPU support : Celeron M, Pentium 4 "Prescott"
1.20a - 10/29/2003
- memory frequency and ratio on nForce2
- KT600 support
- W83627THF VRM mode
- SPD read improvement
- Fix some memory leaks (DMI)
- Fix memory size report
- Fix AGP side band status
