solid CLOCK_V3_4mm facet normal 0.0 0.0 1.0 outer loop vertex 4.102222521132799 157.45673583640084 45.0 vertex 4.00000000000001 273.6802787010933 45.0 vertex 4.0000000000000036 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.00000000000001 273.6802787010933 45.0 vertex 4.102222521132799 157.45673583640084 45.0 vertex 4.102222521132804 272.9038215657858 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.102222521132804 272.9038215657858 45.0 vertex 4.102222521132799 157.45673583640084 45.0 vertex 4.401923788646688 158.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.102222521132804 272.9038215657858 45.0 vertex 4.401923788646688 158.1802787010933 45.0 vertex 4.401923788646692 272.18027870109336 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.401923788646692 272.18027870109336 45.0 vertex 4.401923788646688 158.1802787010933 45.0 vertex 4.878679656440362 158.80159904465293 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.401923788646692 272.18027870109336 45.0 vertex 4.878679656440362 158.80159904465293 45.0 vertex 4.878679656440364 271.5589583575337 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.878679656440364 271.5589583575337 45.0 vertex 4.878679656440362 158.80159904465293 45.0 vertex 5.500000000000004 159.27835491244662 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.878679656440364 271.5589583575337 45.0 vertex 5.500000000000004 159.27835491244662 45.0 vertex 5.500000000000005 271.08220248974004 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.500000000000005 271.08220248974004 45.0 vertex 5.500000000000004 159.27835491244662 45.0 vertex 6.223542864692443 159.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.500000000000005 271.08220248974004 45.0 vertex 6.223542864692443 159.5780561799605 45.0 vertex 6.2235428646924404 270.78250122222613 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.2235428646924404 270.78250122222613 45.0 vertex 6.223542864692443 159.5780561799605 45.0 vertex 7.000000000000004 270.68027870109336 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.000000000000004 270.68027870109336 45.0 vertex 6.223542864692443 159.5780561799605 45.0 vertex 7.000000000000005 159.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.000000000000004 270.68027870109336 45.0 vertex 7.000000000000005 159.6802787010933 45.0 vertex 7.776457135307566 270.78250122222613 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.776457135307566 270.78250122222613 45.0 vertex 7.000000000000005 159.6802787010933 45.0 vertex 7.776457135307567 159.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.776457135307566 270.78250122222613 45.0 vertex 7.776457135307567 159.5780561799605 45.0 vertex 8.500000000000002 271.08220248974004 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.500000000000002 271.08220248974004 45.0 vertex 7.776457135307567 159.5780561799605 45.0 vertex 8.500000000000004 159.27835491244662 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.500000000000002 271.08220248974004 45.0 vertex 8.500000000000004 159.27835491244662 45.0 vertex 9.121320343559644 271.5589583575337 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.121320343559644 271.5589583575337 45.0 vertex 8.500000000000004 159.27835491244662 45.0 vertex 9.121320343559645 158.80159904465293 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.121320343559644 271.5589583575337 45.0 vertex 9.121320343559645 158.80159904465293 45.0 vertex 9.598076211353316 272.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.598076211353316 272.1802787010933 45.0 vertex 9.121320343559645 158.80159904465293 45.0 vertex 9.59807621135332 158.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.598076211353316 272.1802787010933 45.0 vertex 9.59807621135332 158.1802787010933 45.0 vertex 9.897777478867203 272.9038215657858 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.897777478867203 272.9038215657858 45.0 vertex 9.59807621135332 158.1802787010933 45.0 vertex 9.897777478867209 157.45673583640084 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.897777478867203 272.9038215657858 45.0 vertex 9.897777478867209 157.45673583640084 45.0 vertex 9.999999999999998 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.999999999999998 273.6802787010933 45.0 vertex 9.897777478867209 157.45673583640084 45.0 vertex 10.000000000000004 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 3.0 152.6802787010933 45.0 vertex 4.0000000000000036 156.6802787010933 45.0 vertex 3.0 277.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.0000000000000036 156.6802787010933 45.0 vertex 3.0 152.6802787010933 45.0 vertex 4.102222521132799 155.90382156578573 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.102222521132799 155.90382156578573 45.0 vertex 3.0 152.6802787010933 45.0 vertex 4.401923788646688 155.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.401923788646688 155.1802787010933 45.0 vertex 3.0 152.6802787010933 45.0 vertex 4.878679656440363 154.55895835753364 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.878679656440363 154.55895835753364 45.0 vertex 3.0 152.6802787010933 45.0 vertex 5.500000000000005 154.08220248973998 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.500000000000005 154.08220248973998 45.0 vertex 3.0 152.6802787010933 45.0 vertex 6.223542864692442 153.7825012222261 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.223542864692442 153.7825012222261 45.0 vertex 3.0 152.6802787010933 45.0 vertex 7.000000000000004 153.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.000000000000004 153.6802787010933 45.0 vertex 3.0 152.6802787010933 45.0 vertex 336.0 152.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.000000000000004 153.6802787010933 45.0 vertex 336.0 152.6802787010933 45.0 vertex 7.776457135307566 153.7825012222261 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.776457135307566 153.7825012222261 45.0 vertex 336.0 152.6802787010933 45.0 vertex 8.500000000000002 154.08220248973998 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.500000000000002 154.08220248973998 45.0 vertex 336.0 152.6802787010933 45.0 vertex 9.121320343559645 154.55895835753364 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.121320343559645 154.55895835753364 45.0 vertex 336.0 152.6802787010933 45.0 vertex 169.5 153.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.121320343559645 154.55895835753364 45.0 vertex 169.5 153.6802787010933 45.0 vertex 9.59807621135332 155.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.59807621135332 155.1802787010933 45.0 vertex 169.5 153.6802787010933 45.0 vertex 9.897777478867207 155.90382156578573 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 9.897777478867207 155.90382156578573 45.0 vertex 169.5 153.6802787010933 45.0 vertex 10.000000000000004 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 10.000000000000004 156.6802787010933 45.0 vertex 169.5 153.6802787010933 45.0 vertex 168.72354286469246 153.7825012222261 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 10.000000000000004 156.6802787010933 45.0 vertex 168.72354286469246 153.7825012222261 45.0 vertex 168.0 154.08220248973998 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 10.000000000000004 156.6802787010933 45.0 vertex 168.0 154.08220248973998 45.0 vertex 167.37867965644037 154.55895835753364 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 10.000000000000004 156.6802787010933 45.0 vertex 167.37867965644037 154.55895835753364 45.0 vertex 166.9019237886467 155.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 10.000000000000004 156.6802787010933 45.0 vertex 166.9019237886467 155.1802787010933 45.0 vertex 166.6022225211328 155.90382156578573 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 10.000000000000004 156.6802787010933 45.0 vertex 166.6022225211328 155.90382156578573 45.0 vertex 166.5 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 169.5 153.6802787010933 45.0 vertex 336.0 152.6802787010933 45.0 vertex 170.27645713530757 153.7825012222261 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 170.27645713530757 153.7825012222261 45.0 vertex 336.0 152.6802787010933 45.0 vertex 171.0 154.08220248973998 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 171.0 154.08220248973998 45.0 vertex 336.0 152.6802787010933 45.0 vertex 171.62132034355966 154.55895835753364 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 171.62132034355966 154.55895835753364 45.0 vertex 336.0 152.6802787010933 45.0 vertex 172.09807621135332 155.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.09807621135332 155.1802787010933 45.0 vertex 336.0 152.6802787010933 45.0 vertex 172.3977774788672 155.90382156578573 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.3977774788672 155.90382156578573 45.0 vertex 336.0 152.6802787010933 45.0 vertex 172.5 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.5 156.6802787010933 45.0 vertex 336.0 152.6802787010933 45.0 vertex 331.2235428646925 153.7825012222261 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.5 156.6802787010933 45.0 vertex 331.2235428646925 153.7825012222261 45.0 vertex 330.5 154.08220248973998 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.5 156.6802787010933 45.0 vertex 330.5 154.08220248973998 45.0 vertex 172.5 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.5 273.6802787010933 45.0 vertex 330.5 154.08220248973998 45.0 vertex 329.8786796564404 154.55895835753364 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.5 273.6802787010933 45.0 vertex 329.8786796564404 154.55895835753364 45.0 vertex 329.40192378864674 155.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.5 273.6802787010933 45.0 vertex 329.40192378864674 155.1802787010933 45.0 vertex 329.10222252113283 155.90382156578573 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.5 273.6802787010933 45.0 vertex 329.10222252113283 155.90382156578573 45.0 vertex 329.00000000000006 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 331.2235428646925 153.7825012222261 45.0 vertex 336.0 152.6802787010933 45.0 vertex 332.0 153.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.0 153.6802787010933 45.0 vertex 336.0 152.6802787010933 45.0 vertex 332.77645713530757 153.7825012222261 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.77645713530757 153.7825012222261 45.0 vertex 336.0 152.6802787010933 45.0 vertex 333.5 154.08220248973998 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.5 154.08220248973998 45.0 vertex 336.0 152.6802787010933 45.0 vertex 334.12132034355966 154.55895835753364 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.12132034355966 154.55895835753364 45.0 vertex 336.0 152.6802787010933 45.0 vertex 334.5980762113533 155.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.5980762113533 155.1802787010933 45.0 vertex 336.0 152.6802787010933 45.0 vertex 334.8977774788672 155.90382156578573 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.8977774788672 155.90382156578573 45.0 vertex 336.0 152.6802787010933 45.0 vertex 335.0 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 335.0 156.6802787010933 45.0 vertex 336.0 152.6802787010933 45.0 vertex 335.0 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 3.0 277.6802787010933 45.0 vertex 7.000000000000004 276.6802787010933 45.0 vertex 336.0 277.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.000000000000004 276.6802787010933 45.0 vertex 3.0 277.6802787010933 45.0 vertex 6.223542864692444 276.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.223542864692444 276.5780561799605 45.0 vertex 3.0 277.6802787010933 45.0 vertex 5.500000000000007 276.2783549124466 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.500000000000007 276.2783549124466 45.0 vertex 3.0 277.6802787010933 45.0 vertex 4.878679656440366 275.80159904465296 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.878679656440366 275.80159904465296 45.0 vertex 3.0 277.6802787010933 45.0 vertex 4.401923788646694 275.18027870109336 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.401923788646694 275.18027870109336 45.0 vertex 3.0 277.6802787010933 45.0 vertex 4.102222521132805 274.45673583640087 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.102222521132805 274.45673583640087 45.0 vertex 3.0 277.6802787010933 45.0 vertex 4.00000000000001 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 4.00000000000001 273.6802787010933 45.0 vertex 3.0 277.6802787010933 45.0 vertex 4.0000000000000036 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 7.000000000000004 276.6802787010933 45.0 vertex 7.776457135307566 276.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 7.776457135307566 276.5780561799605 45.0 vertex 8.500000000000004 276.2783549124466 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 8.500000000000004 276.2783549124466 45.0 vertex 9.121320343559644 275.80159904465296 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 9.121320343559644 275.80159904465296 45.0 vertex 169.5 276.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 169.5 276.6802787010933 45.0 vertex 9.121320343559644 275.80159904465296 45.0 vertex 9.598076211353316 275.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 169.5 276.6802787010933 45.0 vertex 9.598076211353316 275.1802787010933 45.0 vertex 9.897777478867203 274.45673583640087 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 169.5 276.6802787010933 45.0 vertex 9.897777478867203 274.45673583640087 45.0 vertex 9.999999999999998 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 169.5 276.6802787010933 45.0 vertex 9.999999999999998 273.6802787010933 45.0 vertex 168.72354286469246 276.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 168.72354286469246 276.5780561799605 45.0 vertex 9.999999999999998 273.6802787010933 45.0 vertex 168.0 276.2783549124466 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 168.0 276.2783549124466 45.0 vertex 9.999999999999998 273.6802787010933 45.0 vertex 10.000000000000004 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 168.0 276.2783549124466 45.0 vertex 10.000000000000004 156.6802787010933 45.0 vertex 167.37867965644037 275.80159904465296 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 167.37867965644037 275.80159904465296 45.0 vertex 10.000000000000004 156.6802787010933 45.0 vertex 166.9019237886467 275.18027870109336 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 166.9019237886467 275.18027870109336 45.0 vertex 10.000000000000004 156.6802787010933 45.0 vertex 166.6022225211328 274.45673583640087 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 166.6022225211328 274.45673583640087 45.0 vertex 10.000000000000004 156.6802787010933 45.0 vertex 166.5 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 166.5 273.6802787010933 45.0 vertex 10.000000000000004 156.6802787010933 45.0 vertex 166.5 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 169.5 276.6802787010933 45.0 vertex 170.27645713530757 276.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 170.27645713530757 276.5780561799605 45.0 vertex 171.0 276.2783549124466 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 171.0 276.2783549124466 45.0 vertex 171.62132034355966 275.80159904465296 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 171.62132034355966 275.80159904465296 45.0 vertex 172.09807621135332 275.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 172.09807621135332 275.1802787010933 45.0 vertex 172.3977774788672 274.45673583640087 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 172.3977774788672 274.45673583640087 45.0 vertex 172.5 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 172.5 273.6802787010933 45.0 vertex 331.2235428646925 276.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 331.2235428646925 276.5780561799605 45.0 vertex 172.5 273.6802787010933 45.0 vertex 330.50000000000006 276.2783549124466 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.50000000000006 276.2783549124466 45.0 vertex 172.5 273.6802787010933 45.0 vertex 329.8786796564404 275.80159904465296 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.8786796564404 275.80159904465296 45.0 vertex 172.5 273.6802787010933 45.0 vertex 329.40192378864674 275.18027870109336 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.40192378864674 275.18027870109336 45.0 vertex 172.5 273.6802787010933 45.0 vertex 329.10222252113283 274.45673583640087 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.10222252113283 274.45673583640087 45.0 vertex 172.5 273.6802787010933 45.0 vertex 329.00000000000006 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.00000000000006 273.6802787010933 45.0 vertex 172.5 273.6802787010933 45.0 vertex 329.00000000000006 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 331.2235428646925 276.5780561799605 45.0 vertex 332.0 276.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 332.0 276.6802787010933 45.0 vertex 332.77645713530757 276.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 332.77645713530757 276.5780561799605 45.0 vertex 333.50000000000006 276.2783549124466 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 333.50000000000006 276.2783549124466 45.0 vertex 334.12132034355966 275.80159904465296 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 334.12132034355966 275.80159904465296 45.0 vertex 334.5980762113533 275.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 334.5980762113533 275.1802787010933 45.0 vertex 334.8977774788672 274.45673583640087 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 334.8977774788672 274.45673583640087 45.0 vertex 335.0 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 336.0 277.6802787010933 45.0 vertex 335.0 273.6802787010933 45.0 vertex 336.0 152.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.10222252113283 157.45673583640084 45.0 vertex 329.00000000000006 273.6802787010933 45.0 vertex 329.00000000000006 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.00000000000006 273.6802787010933 45.0 vertex 329.10222252113283 157.45673583640084 45.0 vertex 329.10222252113283 272.9038215657858 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.10222252113283 272.9038215657858 45.0 vertex 329.10222252113283 157.45673583640084 45.0 vertex 329.40192378864674 158.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.10222252113283 272.9038215657858 45.0 vertex 329.40192378864674 158.1802787010933 45.0 vertex 329.40192378864674 272.18027870109336 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.40192378864674 272.18027870109336 45.0 vertex 329.40192378864674 158.1802787010933 45.0 vertex 329.8786796564404 158.80159904465293 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.40192378864674 272.18027870109336 45.0 vertex 329.8786796564404 158.80159904465293 45.0 vertex 329.8786796564404 271.5589583575337 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.8786796564404 271.5589583575337 45.0 vertex 329.8786796564404 158.80159904465293 45.0 vertex 330.50000000000006 159.27835491244662 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 329.8786796564404 271.5589583575337 45.0 vertex 330.50000000000006 159.27835491244662 45.0 vertex 330.5 271.08220248974004 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.5 271.08220248974004 45.0 vertex 330.50000000000006 159.27835491244662 45.0 vertex 331.2235428646925 270.78250122222613 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 331.2235428646925 270.78250122222613 45.0 vertex 330.50000000000006 159.27835491244662 45.0 vertex 331.2235428646925 159.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 331.2235428646925 270.78250122222613 45.0 vertex 331.2235428646925 159.5780561799605 45.0 vertex 332.0 159.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 331.2235428646925 270.78250122222613 45.0 vertex 332.0 159.6802787010933 45.0 vertex 332.0 270.68027870109336 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.0 270.68027870109336 45.0 vertex 332.0 159.6802787010933 45.0 vertex 332.77645713530757 159.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.0 270.68027870109336 45.0 vertex 332.77645713530757 159.5780561799605 45.0 vertex 332.77645713530757 270.78250122222613 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.77645713530757 270.78250122222613 45.0 vertex 332.77645713530757 159.5780561799605 45.0 vertex 333.50000000000006 159.2783549124466 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.77645713530757 270.78250122222613 45.0 vertex 333.50000000000006 159.2783549124466 45.0 vertex 333.5 271.08220248974004 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.5 271.08220248974004 45.0 vertex 333.50000000000006 159.2783549124466 45.0 vertex 334.12132034355966 271.5589583575337 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.12132034355966 271.5589583575337 45.0 vertex 333.50000000000006 159.2783549124466 45.0 vertex 334.12132034355966 158.80159904465293 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.12132034355966 271.5589583575337 45.0 vertex 334.12132034355966 158.80159904465293 45.0 vertex 334.5980762113533 158.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.12132034355966 271.5589583575337 45.0 vertex 334.5980762113533 158.1802787010933 45.0 vertex 334.5980762113533 272.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.5980762113533 272.1802787010933 45.0 vertex 334.5980762113533 158.1802787010933 45.0 vertex 334.8977774788672 157.45673583640084 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.5980762113533 272.1802787010933 45.0 vertex 334.8977774788672 157.45673583640084 45.0 vertex 334.8977774788672 272.9038215657858 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.8977774788672 272.9038215657858 45.0 vertex 334.8977774788672 157.45673583640084 45.0 vertex 335.0 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 334.8977774788672 272.9038215657858 45.0 vertex 335.0 156.6802787010933 45.0 vertex 335.0 273.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 166.6022225211328 157.45673583640084 45.0 vertex 166.5 273.6802787010933 45.0 vertex 166.5 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 166.5 273.6802787010933 45.0 vertex 166.6022225211328 157.45673583640084 45.0 vertex 166.6022225211328 272.9038215657858 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 166.6022225211328 272.9038215657858 45.0 vertex 166.6022225211328 157.45673583640084 45.0 vertex 166.9019237886467 158.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 166.6022225211328 272.9038215657858 45.0 vertex 166.9019237886467 158.1802787010933 45.0 vertex 166.9019237886467 272.18027870109336 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 166.9019237886467 272.18027870109336 45.0 vertex 166.9019237886467 158.1802787010933 45.0 vertex 167.37867965644037 158.80159904465293 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 166.9019237886467 272.18027870109336 45.0 vertex 167.37867965644037 158.80159904465293 45.0 vertex 167.37867965644037 271.5589583575337 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 167.37867965644037 271.5589583575337 45.0 vertex 167.37867965644037 158.80159904465293 45.0 vertex 168.0 159.27835491244662 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 167.37867965644037 271.5589583575337 45.0 vertex 168.0 159.27835491244662 45.0 vertex 168.0 271.08220248974004 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 168.0 271.08220248974004 45.0 vertex 168.0 159.27835491244662 45.0 vertex 168.72354286469246 159.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 168.0 271.08220248974004 45.0 vertex 168.72354286469246 159.5780561799605 45.0 vertex 168.72354286469246 270.78250122222613 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 168.72354286469246 270.78250122222613 45.0 vertex 168.72354286469246 159.5780561799605 45.0 vertex 169.5 159.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 168.72354286469246 270.78250122222613 45.0 vertex 169.5 159.6802787010933 45.0 vertex 169.5 270.68027870109336 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 169.5 270.68027870109336 45.0 vertex 169.5 159.6802787010933 45.0 vertex 170.27645713530757 159.5780561799605 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 169.5 270.68027870109336 45.0 vertex 170.27645713530757 159.5780561799605 45.0 vertex 170.27645713530757 270.78250122222613 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 170.27645713530757 270.78250122222613 45.0 vertex 170.27645713530757 159.5780561799605 45.0 vertex 171.0 159.2783549124466 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 170.27645713530757 270.78250122222613 45.0 vertex 171.0 159.2783549124466 45.0 vertex 171.0 271.08220248974004 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 171.0 271.08220248974004 45.0 vertex 171.0 159.2783549124466 45.0 vertex 171.62132034355966 158.80159904465293 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 171.0 271.08220248974004 45.0 vertex 171.62132034355966 158.80159904465293 45.0 vertex 171.62132034355966 271.5589583575337 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 171.62132034355966 271.5589583575337 45.0 vertex 171.62132034355966 158.80159904465293 45.0 vertex 172.09807621135332 158.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 171.62132034355966 271.5589583575337 45.0 vertex 172.09807621135332 158.1802787010933 45.0 vertex 172.09807621135332 272.1802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.09807621135332 272.1802787010933 45.0 vertex 172.09807621135332 158.1802787010933 45.0 vertex 172.3977774788672 157.45673583640084 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.09807621135332 272.1802787010933 45.0 vertex 172.3977774788672 157.45673583640084 45.0 vertex 172.3977774788672 272.9038215657858 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.3977774788672 272.9038215657858 45.0 vertex 172.3977774788672 157.45673583640084 45.0 vertex 172.5 156.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 172.3977774788672 272.9038215657858 45.0 vertex 172.5 156.6802787010933 45.0 vertex 172.5 273.6802787010933 45.0 endloop endfacet facet normal -1.0 0.0 0.0 outer loop vertex 3.0 277.6802787010933 45.0 vertex 3.0 152.6802787010933 41.00000000000001 vertex 3.0 152.6802787010933 45.0 endloop endfacet facet normal -1.0 0.0 0.0 outer loop vertex 3.0 152.6802787010933 41.00000000000001 vertex 3.0 277.6802787010933 45.0 vertex 3.0 277.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 3.0 277.6802787010933 41.00000000000001 vertex 5.4000000000000075 273.6802787010933 41.00000000000001 vertex 3.0 152.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.4000000000000075 273.6802787010933 41.00000000000001 vertex 3.0 277.6802787010933 41.00000000000001 vertex 5.4545186779374975 274.09438917325735 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.4545186779374975 274.09438917325735 41.00000000000001 vertex 3.0 277.6802787010933 41.00000000000001 vertex 5.614359353944905 274.4802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.614359353944905 274.4802787010933 41.00000000000001 vertex 3.0 277.6802787010933 41.00000000000001 vertex 5.86862915010153 274.8116495509918 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.86862915010153 274.8116495509918 41.00000000000001 vertex 3.0 277.6802787010933 41.00000000000001 vertex 6.200000000000005 275.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 6.200000000000005 275.0659193471484 41.00000000000001 vertex 3.0 277.6802787010933 41.00000000000001 vertex 6.58588952783597 275.22576002315583 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 6.58588952783597 275.22576002315583 41.00000000000001 vertex 3.0 277.6802787010933 41.00000000000001 vertex 7.000000000000004 275.2802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.000000000000004 275.2802787010933 41.00000000000001 vertex 3.0 277.6802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 3.0 152.6802787010933 41.00000000000001 vertex 5.4000000000000075 273.6802787010933 41.00000000000001 vertex 5.400000000000004 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.000000000000004 275.2802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 7.414110472164036 275.22576002315583 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.414110472164036 275.22576002315583 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 7.8000000000000025 275.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.8000000000000025 275.0659193471484 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 8.131370849898477 274.8116495509918 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.131370849898477 274.8116495509918 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 8.385640646055103 274.4802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.385640646055103 274.4802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 8.54548132206251 274.09438917325735 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.54548132206251 274.09438917325735 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 8.600000000000001 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.600000000000001 273.6802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 169.5 275.2802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.600000000000001 273.6802787010933 41.00000000000001 vertex 169.5 275.2802787010933 41.00000000000001 vertex 169.08588952783597 275.22576002315583 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.600000000000001 273.6802787010933 41.00000000000001 vertex 169.08588952783597 275.22576002315583 41.00000000000001 vertex 168.70000000000002 275.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.600000000000001 273.6802787010933 41.00000000000001 vertex 168.70000000000002 275.0659193471484 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 168.70000000000002 275.0659193471484 41.00000000000001 vertex 168.36862915010153 274.8116495509918 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 168.36862915010153 274.8116495509918 41.00000000000001 vertex 168.1143593539449 274.4802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 168.1143593539449 274.4802787010933 41.00000000000001 vertex 167.9545186779375 274.09438917325735 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 167.9545186779375 274.09438917325735 41.00000000000001 vertex 167.9 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.5 275.2802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 169.91411047216403 275.22576002315583 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.91411047216403 275.22576002315583 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 170.3 275.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 170.3 275.0659193471484 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 170.63137084989847 274.8116495509918 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 170.63137084989847 274.8116495509918 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 170.88564064605512 274.4802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 170.88564064605512 274.4802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 171.0454813220625 274.09438917325735 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 171.0454813220625 274.09438917325735 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 171.1 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 171.1 273.6802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 331.20000000000005 275.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 171.1 273.6802787010933 41.00000000000001 vertex 331.20000000000005 275.0659193471484 41.00000000000001 vertex 171.1 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 171.1 156.6802787010933 41.00000000000001 vertex 331.20000000000005 275.0659193471484 41.00000000000001 vertex 330.8686291501015 274.8116495509918 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 171.1 156.6802787010933 41.00000000000001 vertex 330.8686291501015 274.8116495509918 41.00000000000001 vertex 330.61435935394496 274.4802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 171.1 156.6802787010933 41.00000000000001 vertex 330.61435935394496 274.4802787010933 41.00000000000001 vertex 330.4545186779375 274.09438917325735 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 171.1 156.6802787010933 41.00000000000001 vertex 330.4545186779375 274.09438917325735 41.00000000000001 vertex 330.40000000000003 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 331.20000000000005 275.0659193471484 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 331.58588952783595 275.22576002315583 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 331.58588952783595 275.22576002315583 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 332.0 275.2802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 332.0 275.2802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 332.41411047216405 275.22576002315583 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 332.41411047216405 275.22576002315583 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 332.8 275.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 332.8 275.0659193471484 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 333.1313708498985 274.8116495509918 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.1313708498985 274.8116495509918 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 333.3856406460551 274.4802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.3856406460551 274.4802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 333.5454813220625 274.09438917325735 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.5454813220625 274.09438917325735 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 333.6 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.6 273.6802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 vertex 333.6 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 3.0 152.6802787010933 41.00000000000001 vertex 7.000000000000004 155.0802787010933 41.00000000000001 vertex 336.0 152.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.000000000000004 155.0802787010933 41.00000000000001 vertex 3.0 152.6802787010933 41.00000000000001 vertex 6.58588952783597 155.1347973790308 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 6.58588952783597 155.1347973790308 41.00000000000001 vertex 3.0 152.6802787010933 41.00000000000001 vertex 6.200000000000004 155.29463805503818 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 6.200000000000004 155.29463805503818 41.00000000000001 vertex 3.0 152.6802787010933 41.00000000000001 vertex 5.868629150101529 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.868629150101529 155.54890785119483 41.00000000000001 vertex 3.0 152.6802787010933 41.00000000000001 vertex 5.614359353944902 155.8802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.614359353944902 155.8802787010933 41.00000000000001 vertex 3.0 152.6802787010933 41.00000000000001 vertex 5.454518677937496 156.26616822892927 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.454518677937496 156.26616822892927 41.00000000000001 vertex 3.0 152.6802787010933 41.00000000000001 vertex 5.400000000000004 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 7.000000000000004 155.0802787010933 41.00000000000001 vertex 7.414110472164038 155.1347973790308 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 7.414110472164038 155.1347973790308 41.00000000000001 vertex 7.800000000000004 155.29463805503818 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 7.800000000000004 155.29463805503818 41.00000000000001 vertex 8.13137084989848 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 8.13137084989848 155.54890785119483 41.00000000000001 vertex 8.385640646055105 155.8802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 8.385640646055105 155.8802787010933 41.00000000000001 vertex 8.545481322062512 156.26616822892927 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 8.545481322062512 156.26616822892927 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 169.5 155.0802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.5 155.0802787010933 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 169.08588952783597 155.1347973790308 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.08588952783597 155.1347973790308 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 168.70000000000002 155.29463805503818 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 168.70000000000002 155.29463805503818 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 168.36862915010153 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 168.36862915010153 155.54890785119483 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 168.1143593539449 155.8802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 168.1143593539449 155.8802787010933 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 167.9545186779375 156.26616822892927 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 167.9545186779375 156.26616822892927 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 167.9 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 167.9 156.6802787010933 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 167.9 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 169.5 155.0802787010933 41.00000000000001 vertex 169.91411047216403 155.1347973790308 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 169.91411047216403 155.1347973790308 41.00000000000001 vertex 170.3 155.29463805503818 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 170.3 155.29463805503818 41.00000000000001 vertex 170.63137084989847 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 170.63137084989847 155.54890785119483 41.00000000000001 vertex 170.88564064605512 155.8802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 170.88564064605512 155.8802787010933 41.00000000000001 vertex 171.0454813220625 156.26616822892927 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 171.0454813220625 156.26616822892927 41.00000000000001 vertex 171.1 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 171.1 156.6802787010933 41.00000000000001 vertex 331.20000000000005 155.29463805503818 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 331.20000000000005 155.29463805503818 41.00000000000001 vertex 171.1 156.6802787010933 41.00000000000001 vertex 330.8686291501015 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.8686291501015 155.54890785119483 41.00000000000001 vertex 171.1 156.6802787010933 41.00000000000001 vertex 330.61435935394496 155.8802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.61435935394496 155.8802787010933 41.00000000000001 vertex 171.1 156.6802787010933 41.00000000000001 vertex 330.4545186779375 156.26616822892927 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.4545186779375 156.26616822892927 41.00000000000001 vertex 171.1 156.6802787010933 41.00000000000001 vertex 330.40000000000003 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.40000000000003 156.6802787010933 41.00000000000001 vertex 171.1 156.6802787010933 41.00000000000001 vertex 330.40000000000003 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 331.20000000000005 155.29463805503818 41.00000000000001 vertex 331.58588952783595 155.1347973790308 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 331.58588952783595 155.1347973790308 41.00000000000001 vertex 332.0 155.0802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 332.0 155.0802787010933 41.00000000000001 vertex 332.41411047216405 155.1347973790308 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 332.41411047216405 155.1347973790308 41.00000000000001 vertex 332.8 155.29463805503818 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 332.8 155.29463805503818 41.00000000000001 vertex 333.1313708498985 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 333.1313708498985 155.54890785119483 41.00000000000001 vertex 333.3856406460551 155.8802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 333.3856406460551 155.8802787010933 41.00000000000001 vertex 333.5454813220625 156.26616822892927 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 333.5454813220625 156.26616822892927 41.00000000000001 vertex 333.6 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 336.0 152.6802787010933 41.00000000000001 vertex 333.6 156.6802787010933 41.00000000000001 vertex 336.0 277.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.4545186779375 273.26616822892925 41.00000000000001 vertex 330.40000000000003 156.6802787010933 41.00000000000001 vertex 330.40000000000003 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.40000000000003 156.6802787010933 41.00000000000001 vertex 330.4545186779375 273.26616822892925 41.00000000000001 vertex 330.4545186779375 157.09438917325733 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.4545186779375 157.09438917325733 41.00000000000001 vertex 330.4545186779375 273.26616822892925 41.00000000000001 vertex 330.61435935394496 272.88027870109335 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.4545186779375 157.09438917325733 41.00000000000001 vertex 330.61435935394496 272.88027870109335 41.00000000000001 vertex 330.61435935394496 157.48027870109328 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.61435935394496 157.48027870109328 41.00000000000001 vertex 330.61435935394496 272.88027870109335 41.00000000000001 vertex 330.8686291501015 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.61435935394496 157.48027870109328 41.00000000000001 vertex 330.8686291501015 272.5489078511949 41.00000000000001 vertex 330.8686291501015 157.81164955099177 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.8686291501015 157.81164955099177 41.00000000000001 vertex 330.8686291501015 272.5489078511949 41.00000000000001 vertex 331.20000000000005 272.29463805503826 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 330.8686291501015 157.81164955099177 41.00000000000001 vertex 331.20000000000005 272.29463805503826 41.00000000000001 vertex 331.20000000000005 158.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 331.20000000000005 158.0659193471484 41.00000000000001 vertex 331.20000000000005 272.29463805503826 41.00000000000001 vertex 331.58588952783595 272.13479737903083 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 331.20000000000005 158.0659193471484 41.00000000000001 vertex 331.58588952783595 272.13479737903083 41.00000000000001 vertex 331.58588952783595 158.2257600231558 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 331.58588952783595 158.2257600231558 41.00000000000001 vertex 331.58588952783595 272.13479737903083 41.00000000000001 vertex 332.0 272.08027870109333 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 331.58588952783595 158.2257600231558 41.00000000000001 vertex 332.0 272.08027870109333 41.00000000000001 vertex 332.0 158.2802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 332.0 158.2802787010933 41.00000000000001 vertex 332.0 272.08027870109333 41.00000000000001 vertex 332.41411047216405 272.13479737903083 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 332.0 158.2802787010933 41.00000000000001 vertex 332.41411047216405 272.13479737903083 41.00000000000001 vertex 332.41411047216405 158.2257600231558 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 332.41411047216405 158.2257600231558 41.00000000000001 vertex 332.41411047216405 272.13479737903083 41.00000000000001 vertex 332.8 272.29463805503826 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 332.41411047216405 158.2257600231558 41.00000000000001 vertex 332.8 272.29463805503826 41.00000000000001 vertex 332.8 158.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 332.8 158.0659193471484 41.00000000000001 vertex 332.8 272.29463805503826 41.00000000000001 vertex 333.1313708498985 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 332.8 158.0659193471484 41.00000000000001 vertex 333.1313708498985 272.5489078511949 41.00000000000001 vertex 333.1313708498985 157.81164955099177 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.1313708498985 157.81164955099177 41.00000000000001 vertex 333.1313708498985 272.5489078511949 41.00000000000001 vertex 333.3856406460551 272.88027870109335 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.1313708498985 157.81164955099177 41.00000000000001 vertex 333.3856406460551 272.88027870109335 41.00000000000001 vertex 333.3856406460551 157.48027870109328 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.3856406460551 157.48027870109328 41.00000000000001 vertex 333.3856406460551 272.88027870109335 41.00000000000001 vertex 333.5454813220625 273.2661682289293 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.3856406460551 157.48027870109328 41.00000000000001 vertex 333.5454813220625 273.2661682289293 41.00000000000001 vertex 333.5454813220625 157.09438917325733 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.5454813220625 157.09438917325733 41.00000000000001 vertex 333.5454813220625 273.2661682289293 41.00000000000001 vertex 333.6 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 333.5454813220625 157.09438917325733 41.00000000000001 vertex 333.6 273.6802787010933 41.00000000000001 vertex 333.6 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 167.9545186779375 273.2661682289293 41.00000000000001 vertex 167.9 156.6802787010933 41.00000000000001 vertex 167.9 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 167.9 156.6802787010933 41.00000000000001 vertex 167.9545186779375 273.2661682289293 41.00000000000001 vertex 167.9545186779375 157.09438917325733 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 167.9545186779375 157.09438917325733 41.00000000000001 vertex 167.9545186779375 273.2661682289293 41.00000000000001 vertex 168.1143593539449 272.88027870109335 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 167.9545186779375 157.09438917325733 41.00000000000001 vertex 168.1143593539449 272.88027870109335 41.00000000000001 vertex 168.1143593539449 157.48027870109328 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 168.1143593539449 157.48027870109328 41.00000000000001 vertex 168.1143593539449 272.88027870109335 41.00000000000001 vertex 168.36862915010153 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 168.1143593539449 157.48027870109328 41.00000000000001 vertex 168.36862915010153 272.5489078511949 41.00000000000001 vertex 168.36862915010153 157.81164955099177 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 168.36862915010153 157.81164955099177 41.00000000000001 vertex 168.36862915010153 272.5489078511949 41.00000000000001 vertex 168.70000000000002 272.29463805503826 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 168.36862915010153 157.81164955099177 41.00000000000001 vertex 168.70000000000002 272.29463805503826 41.00000000000001 vertex 168.70000000000002 158.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 168.70000000000002 158.0659193471484 41.00000000000001 vertex 168.70000000000002 272.29463805503826 41.00000000000001 vertex 169.08588952783597 272.13479737903083 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 168.70000000000002 158.0659193471484 41.00000000000001 vertex 169.08588952783597 272.13479737903083 41.00000000000001 vertex 169.08588952783597 158.2257600231558 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.08588952783597 158.2257600231558 41.00000000000001 vertex 169.08588952783597 272.13479737903083 41.00000000000001 vertex 169.5 272.08027870109333 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.08588952783597 158.2257600231558 41.00000000000001 vertex 169.5 272.08027870109333 41.00000000000001 vertex 169.5 158.2802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.5 158.2802787010933 41.00000000000001 vertex 169.5 272.08027870109333 41.00000000000001 vertex 169.91411047216403 272.13479737903083 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.5 158.2802787010933 41.00000000000001 vertex 169.91411047216403 272.13479737903083 41.00000000000001 vertex 169.91411047216403 158.2257600231558 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.91411047216403 158.2257600231558 41.00000000000001 vertex 169.91411047216403 272.13479737903083 41.00000000000001 vertex 170.3 272.29463805503826 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 169.91411047216403 158.2257600231558 41.00000000000001 vertex 170.3 272.29463805503826 41.00000000000001 vertex 170.3 158.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 170.3 158.0659193471484 41.00000000000001 vertex 170.3 272.29463805503826 41.00000000000001 vertex 170.63137084989847 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 170.3 158.0659193471484 41.00000000000001 vertex 170.63137084989847 272.5489078511949 41.00000000000001 vertex 170.63137084989847 157.81164955099177 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 170.63137084989847 157.81164955099177 41.00000000000001 vertex 170.63137084989847 272.5489078511949 41.00000000000001 vertex 170.88564064605512 272.88027870109335 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 170.63137084989847 157.81164955099177 41.00000000000001 vertex 170.88564064605512 272.88027870109335 41.00000000000001 vertex 170.88564064605512 157.48027870109328 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 170.88564064605512 157.48027870109328 41.00000000000001 vertex 170.88564064605512 272.88027870109335 41.00000000000001 vertex 171.0454813220625 273.26616822892925 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 170.88564064605512 157.48027870109328 41.00000000000001 vertex 171.0454813220625 273.26616822892925 41.00000000000001 vertex 171.0454813220625 157.09438917325733 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 171.0454813220625 157.09438917325733 41.00000000000001 vertex 171.0454813220625 273.26616822892925 41.00000000000001 vertex 171.1 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 171.0454813220625 157.09438917325733 41.00000000000001 vertex 171.1 273.6802787010933 41.00000000000001 vertex 171.1 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.4000000000000075 273.6802787010933 41.00000000000001 vertex 5.454518677937495 157.09438917325733 41.00000000000001 vertex 5.400000000000004 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.454518677937495 157.09438917325733 41.00000000000001 vertex 5.4000000000000075 273.6802787010933 41.00000000000001 vertex 5.454518677937498 273.26616822892925 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.454518677937495 157.09438917325733 41.00000000000001 vertex 5.454518677937498 273.26616822892925 41.00000000000001 vertex 5.614359353944902 157.48027870109328 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.614359353944902 157.48027870109328 41.00000000000001 vertex 5.454518677937498 273.26616822892925 41.00000000000001 vertex 5.614359353944905 272.88027870109335 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.614359353944902 157.48027870109328 41.00000000000001 vertex 5.614359353944905 272.88027870109335 41.00000000000001 vertex 5.868629150101527 157.81164955099177 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.868629150101527 157.81164955099177 41.00000000000001 vertex 5.614359353944905 272.88027870109335 41.00000000000001 vertex 5.86862915010153 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 5.868629150101527 157.81164955099177 41.00000000000001 vertex 5.86862915010153 272.5489078511949 41.00000000000001 vertex 6.200000000000004 158.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 6.200000000000004 158.0659193471484 41.00000000000001 vertex 5.86862915010153 272.5489078511949 41.00000000000001 vertex 6.2000000000000055 272.29463805503826 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 6.200000000000004 158.0659193471484 41.00000000000001 vertex 6.2000000000000055 272.29463805503826 41.00000000000001 vertex 6.5858895278359695 158.2257600231558 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 6.5858895278359695 158.2257600231558 41.00000000000001 vertex 6.2000000000000055 272.29463805503826 41.00000000000001 vertex 6.585889527835972 272.13479737903083 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 6.5858895278359695 158.2257600231558 41.00000000000001 vertex 6.585889527835972 272.13479737903083 41.00000000000001 vertex 7.000000000000004 158.2802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.000000000000004 158.2802787010933 41.00000000000001 vertex 6.585889527835972 272.13479737903083 41.00000000000001 vertex 7.000000000000004 272.08027870109333 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.000000000000004 158.2802787010933 41.00000000000001 vertex 7.000000000000004 272.08027870109333 41.00000000000001 vertex 7.414110472164038 272.13479737903083 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.000000000000004 158.2802787010933 41.00000000000001 vertex 7.414110472164038 272.13479737903083 41.00000000000001 vertex 7.414110472164036 158.2257600231558 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.414110472164036 158.2257600231558 41.00000000000001 vertex 7.414110472164038 272.13479737903083 41.00000000000001 vertex 7.8000000000000025 158.0659193471484 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.8000000000000025 158.0659193471484 41.00000000000001 vertex 7.414110472164038 272.13479737903083 41.00000000000001 vertex 7.8000000000000025 272.29463805503826 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.8000000000000025 158.0659193471484 41.00000000000001 vertex 7.8000000000000025 272.29463805503826 41.00000000000001 vertex 8.131370849898477 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 7.8000000000000025 158.0659193471484 41.00000000000001 vertex 8.131370849898477 272.5489078511949 41.00000000000001 vertex 8.13137084989848 157.81164955099177 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.13137084989848 157.81164955099177 41.00000000000001 vertex 8.131370849898477 272.5489078511949 41.00000000000001 vertex 8.385640646055105 272.88027870109335 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.13137084989848 157.81164955099177 41.00000000000001 vertex 8.385640646055105 272.88027870109335 41.00000000000001 vertex 8.385640646055105 157.48027870109328 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.385640646055105 157.48027870109328 41.00000000000001 vertex 8.385640646055105 272.88027870109335 41.00000000000001 vertex 8.545481322062512 273.2661682289293 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.385640646055105 157.48027870109328 41.00000000000001 vertex 8.545481322062512 273.2661682289293 41.00000000000001 vertex 8.545481322062512 157.09438917325733 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.545481322062512 157.09438917325733 41.00000000000001 vertex 8.545481322062512 273.2661682289293 41.00000000000001 vertex 8.600000000000001 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 0.0 -1.0 outer loop vertex 8.545481322062512 157.09438917325733 41.00000000000001 vertex 8.600000000000001 273.6802787010933 41.00000000000001 vertex 8.600000000000003 156.6802787010933 41.00000000000001 endloop endfacet facet normal -0.0 -1.0 -0.0 outer loop vertex 336.0 152.6802787010933 45.0 vertex 3.0 152.6802787010933 41.00000000000001 vertex 336.0 152.6802787010933 41.00000000000001 endloop endfacet facet normal -0.0 -1.0 -0.0 outer loop vertex 3.0 152.6802787010933 41.00000000000001 vertex 336.0 152.6802787010933 45.0 vertex 3.0 152.6802787010933 45.0 endloop endfacet facet normal 0.0 1.0 0.0 outer loop vertex 3.0 277.6802787010933 45.0 vertex 336.0 277.6802787010933 41.00000000000001 vertex 3.0 277.6802787010933 41.00000000000001 endloop endfacet facet normal 0.0 1.0 0.0 outer loop vertex 336.0 277.6802787010933 41.00000000000001 vertex 3.0 277.6802787010933 45.0 vertex 336.0 277.6802787010933 45.0 endloop endfacet facet normal 1.0 0.0 0.0 outer loop vertex 336.0 277.6802787010933 41.00000000000001 vertex 336.0 152.6802787010933 45.0 vertex 336.0 152.6802787010933 41.00000000000001 endloop endfacet facet normal 1.0 0.0 0.0 outer loop vertex 336.0 152.6802787010933 45.0 vertex 336.0 277.6802787010933 41.00000000000001 vertex 336.0 277.6802787010933 45.0 endloop endfacet facet normal -0.3826834323650637 0.9238795325112976 0.0 outer loop vertex 169.91411047216403 155.1347973790308 43.0 vertex 170.3 155.29463805503818 41.00000000000001 vertex 169.91411047216403 155.1347973790308 41.00000000000001 endloop endfacet facet normal -0.3826834323650637 0.9238795325112976 0.0 outer loop vertex 170.3 155.29463805503818 41.00000000000001 vertex 169.91411047216403 155.1347973790308 43.0 vertex 170.3 155.29463805503818 43.0 endloop endfacet facet normal -0.6087614290087435 0.7933533402912176 0.0 outer loop vertex 170.3 155.29463805503818 43.0 vertex 170.63137084989847 155.54890785119483 41.00000000000001 vertex 170.3 155.29463805503818 41.00000000000001 endloop endfacet facet normal -0.6087614290087435 0.7933533402912176 0.0 outer loop vertex 170.63137084989847 155.54890785119483 41.00000000000001 vertex 170.3 155.29463805503818 43.0 vertex 170.63137084989847 155.54890785119483 43.0 endloop endfacet facet normal -0.7933533402912176 0.6087614290087435 0.0 outer loop vertex 170.88564064605512 155.8802787010933 43.0 vertex 170.63137084989847 155.54890785119483 41.00000000000001 vertex 170.63137084989847 155.54890785119483 43.0 endloop endfacet facet normal -0.7933533402912176 0.6087614290087435 0.0 outer loop vertex 170.63137084989847 155.54890785119483 41.00000000000001 vertex 170.88564064605512 155.8802787010933 43.0 vertex 170.88564064605512 155.8802787010933 41.00000000000001 endloop endfacet facet normal -0.9238795325112976 0.3826834323650637 0.0 outer loop vertex 171.0454813220625 156.26616822892927 43.0 vertex 170.88564064605512 155.8802787010933 41.00000000000001 vertex 170.88564064605512 155.8802787010933 43.0 endloop endfacet facet normal -0.9238795325112976 0.3826834323650637 0.0 outer loop vertex 170.88564064605512 155.8802787010933 41.00000000000001 vertex 171.0454813220625 156.26616822892927 43.0 vertex 171.0454813220625 156.26616822892927 41.00000000000001 endloop endfacet facet normal -0.991444861373809 0.1305261922200628 0.0 outer loop vertex 171.1 156.6802787010933 43.0 vertex 171.0454813220625 156.26616822892927 41.00000000000001 vertex 171.0454813220625 156.26616822892927 43.0 endloop endfacet facet normal -0.991444861373809 0.1305261922200628 0.0 outer loop vertex 171.0454813220625 156.26616822892927 41.00000000000001 vertex 171.1 156.6802787010933 43.0 vertex 171.1 156.6802787010933 41.00000000000001 endloop endfacet facet normal -0.991444861373809 -0.1305261922200628 0.0 outer loop vertex 171.0454813220625 157.09438917325733 43.0 vertex 171.1 156.6802787010933 41.00000000000001 vertex 171.1 156.6802787010933 43.0 endloop endfacet facet normal -0.991444861373809 -0.1305261922200628 0.0 outer loop vertex 171.1 156.6802787010933 41.00000000000001 vertex 171.0454813220625 157.09438917325733 43.0 vertex 171.0454813220625 157.09438917325733 41.00000000000001 endloop endfacet facet normal -0.9238795325112976 -0.3826834323650637 0.0 outer loop vertex 170.88564064605512 157.48027870109328 43.0 vertex 171.0454813220625 157.09438917325733 41.00000000000001 vertex 171.0454813220625 157.09438917325733 43.0 endloop endfacet facet normal -0.9238795325112976 -0.3826834323650637 0.0 outer loop vertex 171.0454813220625 157.09438917325733 41.00000000000001 vertex 170.88564064605512 157.48027870109328 43.0 vertex 170.88564064605512 157.48027870109328 41.00000000000001 endloop endfacet facet normal -0.7933533402912176 -0.6087614290087435 0.0 outer loop vertex 170.63137084989847 157.81164955099177 43.0 vertex 170.88564064605512 157.48027870109328 41.00000000000001 vertex 170.88564064605512 157.48027870109328 43.0 endloop endfacet facet normal -0.7933533402912176 -0.6087614290087435 0.0 outer loop vertex 170.88564064605512 157.48027870109328 41.00000000000001 vertex 170.63137084989847 157.81164955099177 43.0 vertex 170.63137084989847 157.81164955099177 41.00000000000001 endloop endfacet facet normal -0.6087614290087435 -0.7933533402912176 0.0 outer loop vertex 170.63137084989847 157.81164955099177 43.0 vertex 170.3 158.0659193471484 41.00000000000001 vertex 170.63137084989847 157.81164955099177 41.00000000000001 endloop endfacet facet normal -0.6087614290087435 -0.7933533402912176 0.0 outer loop vertex 170.3 158.0659193471484 41.00000000000001 vertex 170.63137084989847 157.81164955099177 43.0 vertex 170.3 158.0659193471484 43.0 endloop endfacet facet normal -0.3826834323650637 -0.9238795325112976 0.0 outer loop vertex 170.3 158.0659193471484 43.0 vertex 169.91411047216403 158.2257600231558 41.00000000000001 vertex 170.3 158.0659193471484 41.00000000000001 endloop endfacet facet normal -0.3826834323650637 -0.9238795325112976 0.0 outer loop vertex 169.91411047216403 158.2257600231558 41.00000000000001 vertex 170.3 158.0659193471484 43.0 vertex 169.91411047216403 158.2257600231558 43.0 endloop endfacet facet normal -0.1305261922200628 -0.991444861373809 0.0 outer loop vertex 169.91411047216403 158.2257600231558 43.0 vertex 169.5 158.2802787010933 41.00000000000001 vertex 169.91411047216403 158.2257600231558 41.00000000000001 endloop endfacet facet normal -0.1305261922200628 -0.991444861373809 0.0 outer loop vertex 169.5 158.2802787010933 41.00000000000001 vertex 169.91411047216403 158.2257600231558 43.0 vertex 169.5 158.2802787010933 43.0 endloop endfacet facet normal 0.1305261922200628 -0.991444861373809 0.0 outer loop vertex 169.5 158.2802787010933 43.0 vertex 169.08588952783597 158.2257600231558 41.00000000000001 vertex 169.5 158.2802787010933 41.00000000000001 endloop endfacet facet normal 0.1305261922200628 -0.991444861373809 0.0 outer loop vertex 169.08588952783597 158.2257600231558 41.00000000000001 vertex 169.5 158.2802787010933 43.0 vertex 169.08588952783597 158.2257600231558 43.0 endloop endfacet facet normal 0.3826834323650637 -0.9238795325112976 0.0 outer loop vertex 169.08588952783597 158.2257600231558 43.0 vertex 168.70000000000002 158.0659193471484 41.00000000000001 vertex 169.08588952783597 158.2257600231558 41.00000000000001 endloop endfacet facet normal 0.3826834323650637 -0.9238795325112976 0.0 outer loop vertex 168.70000000000002 158.0659193471484 41.00000000000001 vertex 169.08588952783597 158.2257600231558 43.0 vertex 168.70000000000002 158.0659193471484 43.0 endloop endfacet facet normal 0.6087614290087435 -0.7933533402912176 0.0 outer loop vertex 168.70000000000002 158.0659193471484 43.0 vertex 168.36862915010153 157.81164955099177 41.00000000000001 vertex 168.70000000000002 158.0659193471484 41.00000000000001 endloop endfacet facet normal 0.6087614290087435 -0.7933533402912176 0.0 outer loop vertex 168.36862915010153 157.81164955099177 41.00000000000001 vertex 168.70000000000002 158.0659193471484 43.0 vertex 168.36862915010153 157.81164955099177 43.0 endloop endfacet facet normal 0.7933533402912176 -0.6087614290087435 0.0 outer loop vertex 168.36862915010153 157.81164955099177 41.00000000000001 vertex 168.1143593539449 157.48027870109328 43.0 vertex 168.1143593539449 157.48027870109328 41.00000000000001 endloop endfacet facet normal 0.7933533402912176 -0.6087614290087435 0.0 outer loop vertex 168.1143593539449 157.48027870109328 43.0 vertex 168.36862915010153 157.81164955099177 41.00000000000001 vertex 168.36862915010153 157.81164955099177 43.0 endloop endfacet facet normal 0.9238795325112976 -0.3826834323650637 0.0 outer loop vertex 168.1143593539449 157.48027870109328 41.00000000000001 vertex 167.9545186779375 157.09438917325733 43.0 vertex 167.9545186779375 157.09438917325733 41.00000000000001 endloop endfacet facet normal 0.9238795325112976 -0.3826834323650637 0.0 outer loop vertex 167.9545186779375 157.09438917325733 43.0 vertex 168.1143593539449 157.48027870109328 41.00000000000001 vertex 168.1143593539449 157.48027870109328 43.0 endloop endfacet facet normal 0.991444861373809 -0.1305261922200628 0.0 outer loop vertex 167.9545186779375 157.09438917325733 41.00000000000001 vertex 167.9 156.6802787010933 43.0 vertex 167.9 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.991444861373809 -0.1305261922200628 0.0 outer loop vertex 167.9 156.6802787010933 43.0 vertex 167.9545186779375 157.09438917325733 41.00000000000001 vertex 167.9545186779375 157.09438917325733 43.0 endloop endfacet facet normal 0.991444861373809 0.1305261922200628 0.0 outer loop vertex 167.9 156.6802787010933 41.00000000000001 vertex 167.9545186779375 156.26616822892927 43.0 vertex 167.9545186779375 156.26616822892927 41.00000000000001 endloop endfacet facet normal 0.991444861373809 0.1305261922200628 0.0 outer loop vertex 167.9545186779375 156.26616822892927 43.0 vertex 167.9 156.6802787010933 41.00000000000001 vertex 167.9 156.6802787010933 43.0 endloop endfacet facet normal 0.9238795325112976 0.3826834323650637 0.0 outer loop vertex 167.9545186779375 156.26616822892927 41.00000000000001 vertex 168.1143593539449 155.8802787010933 43.0 vertex 168.1143593539449 155.8802787010933 41.00000000000001 endloop endfacet facet normal 0.9238795325112976 0.3826834323650637 0.0 outer loop vertex 168.1143593539449 155.8802787010933 43.0 vertex 167.9545186779375 156.26616822892927 41.00000000000001 vertex 167.9545186779375 156.26616822892927 43.0 endloop endfacet facet normal 0.7933533402912176 0.6087614290087435 0.0 outer loop vertex 168.1143593539449 155.8802787010933 41.00000000000001 vertex 168.36862915010153 155.54890785119483 43.0 vertex 168.36862915010153 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.7933533402912176 0.6087614290087435 0.0 outer loop vertex 168.36862915010153 155.54890785119483 43.0 vertex 168.1143593539449 155.8802787010933 41.00000000000001 vertex 168.1143593539449 155.8802787010933 43.0 endloop endfacet facet normal 0.6087614290087435 0.7933533402912176 0.0 outer loop vertex 168.36862915010153 155.54890785119483 43.0 vertex 168.70000000000002 155.29463805503818 41.00000000000001 vertex 168.36862915010153 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.6087614290087435 0.7933533402912176 0.0 outer loop vertex 168.70000000000002 155.29463805503818 41.00000000000001 vertex 168.36862915010153 155.54890785119483 43.0 vertex 168.70000000000002 155.29463805503818 43.0 endloop endfacet facet normal 0.3826834323650637 0.9238795325112976 0.0 outer loop vertex 168.70000000000002 155.29463805503818 43.0 vertex 169.08588952783597 155.1347973790308 41.00000000000001 vertex 168.70000000000002 155.29463805503818 41.00000000000001 endloop endfacet facet normal 0.3826834323650637 0.9238795325112976 0.0 outer loop vertex 169.08588952783597 155.1347973790308 41.00000000000001 vertex 168.70000000000002 155.29463805503818 43.0 vertex 169.08588952783597 155.1347973790308 43.0 endloop endfacet facet normal 0.1305261922200628 0.991444861373809 0.0 outer loop vertex 169.08588952783597 155.1347973790308 43.0 vertex 169.5 155.0802787010933 41.00000000000001 vertex 169.08588952783597 155.1347973790308 41.00000000000001 endloop endfacet facet normal 0.1305261922200628 0.991444861373809 0.0 outer loop vertex 169.5 155.0802787010933 41.00000000000001 vertex 169.08588952783597 155.1347973790308 43.0 vertex 169.5 155.0802787010933 43.0 endloop endfacet facet normal -0.1305261922200628 0.991444861373809 0.0 outer loop vertex 169.5 155.0802787010933 43.0 vertex 169.91411047216403 155.1347973790308 41.00000000000001 vertex 169.5 155.0802787010933 41.00000000000001 endloop endfacet facet normal -0.1305261922200628 0.991444861373809 0.0 outer loop vertex 169.91411047216403 155.1347973790308 41.00000000000001 vertex 169.5 155.0802787010933 43.0 vertex 169.91411047216403 155.1347973790308 43.0 endloop endfacet facet normal 0.7933533402912437 0.6087614290087096 0.0 outer loop vertex 330.61435935394496 155.8802787010933 41.00000000000001 vertex 330.8686291501015 155.54890785119483 43.0 vertex 330.8686291501015 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.7933533402912437 0.6087614290087096 0.0 outer loop vertex 330.8686291501015 155.54890785119483 43.0 vertex 330.61435935394496 155.8802787010933 41.00000000000001 vertex 330.61435935394496 155.8802787010933 43.0 endloop endfacet facet normal 0.6087614290087435 0.7933533402912176 0.0 outer loop vertex 330.8686291501015 155.54890785119483 43.0 vertex 331.20000000000005 155.29463805503818 41.00000000000001 vertex 330.8686291501015 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.6087614290087435 0.7933533402912176 0.0 outer loop vertex 331.20000000000005 155.29463805503818 41.00000000000001 vertex 330.8686291501015 155.54890785119483 43.0 vertex 331.20000000000005 155.29463805503818 43.0 endloop endfacet facet normal 0.38268343236508273 0.9238795325112896 0.0 outer loop vertex 331.20000000000005 155.29463805503818 43.0 vertex 331.58588952783595 155.1347973790308 41.00000000000001 vertex 331.20000000000005 155.29463805503818 41.00000000000001 endloop endfacet facet normal 0.38268343236508273 0.9238795325112896 0.0 outer loop vertex 331.58588952783595 155.1347973790308 41.00000000000001 vertex 331.20000000000005 155.29463805503818 43.0 vertex 331.58588952783595 155.1347973790308 43.0 endloop endfacet facet normal 0.13052619222005576 0.9914448613738098 0.0 outer loop vertex 331.58588952783595 155.1347973790308 43.0 vertex 332.0 155.0802787010933 41.00000000000001 vertex 331.58588952783595 155.1347973790308 41.00000000000001 endloop endfacet facet normal 0.13052619222005576 0.9914448613738098 0.0 outer loop vertex 332.0 155.0802787010933 41.00000000000001 vertex 331.58588952783595 155.1347973790308 43.0 vertex 332.0 155.0802787010933 43.0 endloop endfacet facet normal -0.13052619222006975 0.991444861373808 0.0 outer loop vertex 332.0 155.0802787010933 43.0 vertex 332.41411047216405 155.1347973790308 41.00000000000001 vertex 332.0 155.0802787010933 41.00000000000001 endloop endfacet facet normal -0.13052619222006975 0.991444861373808 0.0 outer loop vertex 332.41411047216405 155.1347973790308 41.00000000000001 vertex 332.0 155.0802787010933 43.0 vertex 332.41411047216405 155.1347973790308 43.0 endloop endfacet facet normal -0.38268343236504454 0.9238795325113055 0.0 outer loop vertex 332.41411047216405 155.1347973790308 43.0 vertex 332.8 155.29463805503818 41.00000000000001 vertex 332.41411047216405 155.1347973790308 41.00000000000001 endloop endfacet facet normal -0.38268343236504454 0.9238795325113055 0.0 outer loop vertex 332.8 155.29463805503818 41.00000000000001 vertex 332.41411047216405 155.1347973790308 43.0 vertex 332.8 155.29463805503818 43.0 endloop endfacet facet normal -0.6087614290087435 0.7933533402912176 0.0 outer loop vertex 332.8 155.29463805503818 43.0 vertex 333.1313708498985 155.54890785119483 41.00000000000001 vertex 332.8 155.29463805503818 41.00000000000001 endloop endfacet facet normal -0.6087614290087435 0.7933533402912176 0.0 outer loop vertex 333.1313708498985 155.54890785119483 41.00000000000001 vertex 332.8 155.29463805503818 43.0 vertex 333.1313708498985 155.54890785119483 43.0 endloop endfacet facet normal -0.7933533402912437 0.6087614290087096 0.0 outer loop vertex 333.3856406460551 155.8802787010933 43.0 vertex 333.1313708498985 155.54890785119483 41.00000000000001 vertex 333.1313708498985 155.54890785119483 43.0 endloop endfacet facet normal -0.7933533402912437 0.6087614290087096 0.0 outer loop vertex 333.1313708498985 155.54890785119483 41.00000000000001 vertex 333.3856406460551 155.8802787010933 43.0 vertex 333.3856406460551 155.8802787010933 41.00000000000001 endloop endfacet facet normal -0.9238795325112594 0.38268343236515584 0.0 outer loop vertex 333.5454813220625 156.26616822892927 43.0 vertex 333.3856406460551 155.8802787010933 41.00000000000001 vertex 333.3856406460551 155.8802787010933 43.0 endloop endfacet facet normal -0.9238795325112594 0.38268343236515584 0.0 outer loop vertex 333.3856406460551 155.8802787010933 41.00000000000001 vertex 333.5454813220625 156.26616822892927 43.0 vertex 333.5454813220625 156.26616822892927 41.00000000000001 endloop endfacet facet normal -0.991444861373816 0.1305261922200097 0.0 outer loop vertex 333.6 156.6802787010933 43.0 vertex 333.5454813220625 156.26616822892927 41.00000000000001 vertex 333.5454813220625 156.26616822892927 43.0 endloop endfacet facet normal -0.991444861373816 0.1305261922200097 0.0 outer loop vertex 333.5454813220625 156.26616822892927 41.00000000000001 vertex 333.6 156.6802787010933 43.0 vertex 333.6 156.6802787010933 41.00000000000001 endloop endfacet facet normal -0.991444861373816 -0.1305261922200097 0.0 outer loop vertex 333.5454813220625 157.09438917325733 43.0 vertex 333.6 156.6802787010933 41.00000000000001 vertex 333.6 156.6802787010933 43.0 endloop endfacet facet normal -0.991444861373816 -0.1305261922200097 0.0 outer loop vertex 333.6 156.6802787010933 41.00000000000001 vertex 333.5454813220625 157.09438917325733 43.0 vertex 333.5454813220625 157.09438917325733 41.00000000000001 endloop endfacet facet normal -0.9238795325112594 -0.38268343236515584 0.0 outer loop vertex 333.3856406460551 157.48027870109328 43.0 vertex 333.5454813220625 157.09438917325733 41.00000000000001 vertex 333.5454813220625 157.09438917325733 43.0 endloop endfacet facet normal -0.9238795325112594 -0.38268343236515584 0.0 outer loop vertex 333.5454813220625 157.09438917325733 41.00000000000001 vertex 333.3856406460551 157.48027870109328 43.0 vertex 333.3856406460551 157.48027870109328 41.00000000000001 endloop endfacet facet normal -0.7933533402912437 -0.6087614290087096 0.0 outer loop vertex 333.1313708498985 157.81164955099177 43.0 vertex 333.3856406460551 157.48027870109328 41.00000000000001 vertex 333.3856406460551 157.48027870109328 43.0 endloop endfacet facet normal -0.7933533402912437 -0.6087614290087096 0.0 outer loop vertex 333.3856406460551 157.48027870109328 41.00000000000001 vertex 333.1313708498985 157.81164955099177 43.0 vertex 333.1313708498985 157.81164955099177 41.00000000000001 endloop endfacet facet normal -0.6087614290087435 -0.7933533402912176 0.0 outer loop vertex 333.1313708498985 157.81164955099177 43.0 vertex 332.8 158.0659193471484 41.00000000000001 vertex 333.1313708498985 157.81164955099177 41.00000000000001 endloop endfacet facet normal -0.6087614290087435 -0.7933533402912176 0.0 outer loop vertex 332.8 158.0659193471484 41.00000000000001 vertex 333.1313708498985 157.81164955099177 43.0 vertex 332.8 158.0659193471484 43.0 endloop endfacet facet normal -0.38268343236508273 -0.9238795325112896 0.0 outer loop vertex 332.8 158.0659193471484 43.0 vertex 332.41411047216405 158.2257600231558 41.00000000000001 vertex 332.8 158.0659193471484 41.00000000000001 endloop endfacet facet normal -0.38268343236508273 -0.9238795325112896 0.0 outer loop vertex 332.41411047216405 158.2257600231558 41.00000000000001 vertex 332.8 158.0659193471484 43.0 vertex 332.41411047216405 158.2257600231558 43.0 endloop endfacet facet normal -0.13052619222005576 -0.9914448613738098 0.0 outer loop vertex 332.41411047216405 158.2257600231558 43.0 vertex 332.0 158.2802787010933 41.00000000000001 vertex 332.41411047216405 158.2257600231558 41.00000000000001 endloop endfacet facet normal -0.13052619222005576 -0.9914448613738098 0.0 outer loop vertex 332.0 158.2802787010933 41.00000000000001 vertex 332.41411047216405 158.2257600231558 43.0 vertex 332.0 158.2802787010933 43.0 endloop endfacet facet normal 0.13052619222005576 -0.9914448613738098 0.0 outer loop vertex 332.0 158.2802787010933 43.0 vertex 331.58588952783595 158.2257600231558 41.00000000000001 vertex 332.0 158.2802787010933 41.00000000000001 endloop endfacet facet normal 0.13052619222005576 -0.9914448613738098 0.0 outer loop vertex 331.58588952783595 158.2257600231558 41.00000000000001 vertex 332.0 158.2802787010933 43.0 vertex 331.58588952783595 158.2257600231558 43.0 endloop endfacet facet normal 0.38268343236508273 -0.9238795325112896 0.0 outer loop vertex 331.58588952783595 158.2257600231558 43.0 vertex 331.20000000000005 158.0659193471484 41.00000000000001 vertex 331.58588952783595 158.2257600231558 41.00000000000001 endloop endfacet facet normal 0.38268343236508273 -0.9238795325112896 0.0 outer loop vertex 331.20000000000005 158.0659193471484 41.00000000000001 vertex 331.58588952783595 158.2257600231558 43.0 vertex 331.20000000000005 158.0659193471484 43.0 endloop endfacet facet normal 0.6087614290087435 -0.7933533402912176 0.0 outer loop vertex 331.20000000000005 158.0659193471484 43.0 vertex 330.8686291501015 157.81164955099177 41.00000000000001 vertex 331.20000000000005 158.0659193471484 41.00000000000001 endloop endfacet facet normal 0.6087614290087435 -0.7933533402912176 0.0 outer loop vertex 330.8686291501015 157.81164955099177 41.00000000000001 vertex 331.20000000000005 158.0659193471484 43.0 vertex 330.8686291501015 157.81164955099177 43.0 endloop endfacet facet normal 0.7933533402912437 -0.6087614290087096 0.0 outer loop vertex 330.8686291501015 157.81164955099177 41.00000000000001 vertex 330.61435935394496 157.48027870109328 43.0 vertex 330.61435935394496 157.48027870109328 41.00000000000001 endloop endfacet facet normal 0.7933533402912437 -0.6087614290087096 0.0 outer loop vertex 330.61435935394496 157.48027870109328 43.0 vertex 330.8686291501015 157.81164955099177 41.00000000000001 vertex 330.8686291501015 157.81164955099177 43.0 endloop endfacet facet normal 0.9238795325112594 -0.38268343236515584 0.0 outer loop vertex 330.61435935394496 157.48027870109328 41.00000000000001 vertex 330.4545186779375 157.09438917325733 43.0 vertex 330.4545186779375 157.09438917325733 41.00000000000001 endloop endfacet facet normal 0.9238795325112594 -0.38268343236515584 0.0 outer loop vertex 330.4545186779375 157.09438917325733 43.0 vertex 330.61435935394496 157.48027870109328 41.00000000000001 vertex 330.61435935394496 157.48027870109328 43.0 endloop endfacet facet normal 0.991444861373816 -0.1305261922200097 0.0 outer loop vertex 330.4545186779375 157.09438917325733 41.00000000000001 vertex 330.40000000000003 156.6802787010933 43.0 vertex 330.40000000000003 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.991444861373816 -0.1305261922200097 0.0 outer loop vertex 330.40000000000003 156.6802787010933 43.0 vertex 330.4545186779375 157.09438917325733 41.00000000000001 vertex 330.4545186779375 157.09438917325733 43.0 endloop endfacet facet normal 0.991444861373816 0.1305261922200097 0.0 outer loop vertex 330.40000000000003 156.6802787010933 41.00000000000001 vertex 330.4545186779375 156.26616822892927 43.0 vertex 330.4545186779375 156.26616822892927 41.00000000000001 endloop endfacet facet normal 0.991444861373816 0.1305261922200097 0.0 outer loop vertex 330.4545186779375 156.26616822892927 43.0 vertex 330.40000000000003 156.6802787010933 41.00000000000001 vertex 330.40000000000003 156.6802787010933 43.0 endloop endfacet facet normal 0.9238795325112594 0.38268343236515584 0.0 outer loop vertex 330.4545186779375 156.26616822892927 41.00000000000001 vertex 330.61435935394496 155.8802787010933 43.0 vertex 330.61435935394496 155.8802787010933 41.00000000000001 endloop endfacet facet normal 0.9238795325112594 0.38268343236515584 0.0 outer loop vertex 330.61435935394496 155.8802787010933 43.0 vertex 330.4545186779375 156.26616822892927 41.00000000000001 vertex 330.4545186779375 156.26616822892927 43.0 endloop endfacet facet normal -0.991444861373815 0.13052619222001668 0.0 outer loop vertex 333.6 273.6802787010933 43.0 vertex 333.5454813220625 273.2661682289293 41.00000000000001 vertex 333.5454813220625 273.2661682289293 43.0 endloop endfacet facet normal -0.991444861373815 0.13052619222001668 0.0 outer loop vertex 333.5454813220625 273.2661682289293 41.00000000000001 vertex 333.6 273.6802787010933 43.0 vertex 333.6 273.6802787010933 41.00000000000001 endloop endfacet facet normal -0.9914448613738169 -0.1305261922200027 0.0 outer loop vertex 333.5454813220625 274.09438917325735 43.0 vertex 333.6 273.6802787010933 41.00000000000001 vertex 333.6 273.6802787010933 43.0 endloop endfacet facet normal -0.9914448613738169 -0.1305261922200027 0.0 outer loop vertex 333.6 273.6802787010933 41.00000000000001 vertex 333.5454813220625 274.09438917325735 43.0 vertex 333.5454813220625 274.09438917325735 41.00000000000001 endloop endfacet facet normal -0.9238795325112514 -0.38268343236517494 0.0 outer loop vertex 333.3856406460551 274.4802787010933 43.0 vertex 333.5454813220625 274.09438917325735 41.00000000000001 vertex 333.5454813220625 274.09438917325735 43.0 endloop endfacet facet normal -0.9238795325112514 -0.38268343236517494 0.0 outer loop vertex 333.5454813220625 274.09438917325735 41.00000000000001 vertex 333.3856406460551 274.4802787010933 43.0 vertex 333.3856406460551 274.4802787010933 41.00000000000001 endloop endfacet facet normal -0.7933533402912437 -0.6087614290087096 0.0 outer loop vertex 333.1313708498985 274.8116495509918 43.0 vertex 333.3856406460551 274.4802787010933 41.00000000000001 vertex 333.3856406460551 274.4802787010933 43.0 endloop endfacet facet normal -0.7933533402912437 -0.6087614290087096 0.0 outer loop vertex 333.3856406460551 274.4802787010933 41.00000000000001 vertex 333.1313708498985 274.8116495509918 43.0 vertex 333.1313708498985 274.8116495509918 41.00000000000001 endloop endfacet facet normal -0.6087614290087096 -0.7933533402912437 0.0 outer loop vertex 333.1313708498985 274.8116495509918 43.0 vertex 332.8 275.0659193471484 41.00000000000001 vertex 333.1313708498985 274.8116495509918 41.00000000000001 endloop endfacet facet normal -0.6087614290087096 -0.7933533402912437 0.0 outer loop vertex 332.8 275.0659193471484 41.00000000000001 vertex 333.1313708498985 274.8116495509918 43.0 vertex 332.8 275.0659193471484 43.0 endloop endfacet facet normal -0.38268343236513674 -0.9238795325112673 0.0 outer loop vertex 332.8 275.0659193471484 43.0 vertex 332.41411047216405 275.22576002315583 41.00000000000001 vertex 332.8 275.0659193471484 41.00000000000001 endloop endfacet facet normal -0.38268343236513674 -0.9238795325112673 0.0 outer loop vertex 332.41411047216405 275.22576002315583 41.00000000000001 vertex 332.8 275.0659193471484 43.0 vertex 332.41411047216405 275.22576002315583 43.0 endloop endfacet facet normal -0.13052619222001668 -0.991444861373815 0.0 outer loop vertex 332.41411047216405 275.22576002315583 43.0 vertex 332.0 275.2802787010933 41.00000000000001 vertex 332.41411047216405 275.22576002315583 41.00000000000001 endloop endfacet facet normal -0.13052619222001668 -0.991444861373815 0.0 outer loop vertex 332.0 275.2802787010933 41.00000000000001 vertex 332.41411047216405 275.22576002315583 43.0 vertex 332.0 275.2802787010933 43.0 endloop endfacet facet normal 0.1305261922200027 -0.9914448613738169 0.0 outer loop vertex 332.0 275.2802787010933 43.0 vertex 331.58588952783595 275.22576002315583 41.00000000000001 vertex 332.0 275.2802787010933 41.00000000000001 endloop endfacet facet normal 0.1305261922200027 -0.9914448613738169 0.0 outer loop vertex 331.58588952783595 275.22576002315583 41.00000000000001 vertex 332.0 275.2802787010933 43.0 vertex 331.58588952783595 275.22576002315583 43.0 endloop endfacet facet normal 0.38268343236517494 -0.9238795325112514 0.0 outer loop vertex 331.58588952783595 275.22576002315583 43.0 vertex 331.20000000000005 275.0659193471484 41.00000000000001 vertex 331.58588952783595 275.22576002315583 41.00000000000001 endloop endfacet facet normal 0.38268343236517494 -0.9238795325112514 0.0 outer loop vertex 331.20000000000005 275.0659193471484 41.00000000000001 vertex 331.58588952783595 275.22576002315583 43.0 vertex 331.20000000000005 275.0659193471484 43.0 endloop endfacet facet normal 0.6087614290087096 -0.7933533402912437 0.0 outer loop vertex 331.20000000000005 275.0659193471484 43.0 vertex 330.8686291501015 274.8116495509918 41.00000000000001 vertex 331.20000000000005 275.0659193471484 41.00000000000001 endloop endfacet facet normal 0.6087614290087096 -0.7933533402912437 0.0 outer loop vertex 330.8686291501015 274.8116495509918 41.00000000000001 vertex 331.20000000000005 275.0659193471484 43.0 vertex 330.8686291501015 274.8116495509918 43.0 endloop endfacet facet normal 0.7933533402912437 -0.6087614290087096 0.0 outer loop vertex 330.8686291501015 274.8116495509918 41.00000000000001 vertex 330.61435935394496 274.4802787010933 43.0 vertex 330.61435935394496 274.4802787010933 41.00000000000001 endloop endfacet facet normal 0.7933533402912437 -0.6087614290087096 0.0 outer loop vertex 330.61435935394496 274.4802787010933 43.0 vertex 330.8686291501015 274.8116495509918 41.00000000000001 vertex 330.8686291501015 274.8116495509918 43.0 endloop endfacet facet normal 0.9238795325112514 -0.38268343236517494 0.0 outer loop vertex 330.61435935394496 274.4802787010933 41.00000000000001 vertex 330.4545186779375 274.09438917325735 43.0 vertex 330.4545186779375 274.09438917325735 41.00000000000001 endloop endfacet facet normal 0.9238795325112514 -0.38268343236517494 0.0 outer loop vertex 330.4545186779375 274.09438917325735 43.0 vertex 330.61435935394496 274.4802787010933 41.00000000000001 vertex 330.61435935394496 274.4802787010933 43.0 endloop endfacet facet normal 0.9914448613738169 -0.1305261922200027 0.0 outer loop vertex 330.4545186779375 274.09438917325735 41.00000000000001 vertex 330.40000000000003 273.6802787010933 43.0 vertex 330.40000000000003 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.9914448613738169 -0.1305261922200027 0.0 outer loop vertex 330.40000000000003 273.6802787010933 43.0 vertex 330.4545186779375 274.09438917325735 41.00000000000001 vertex 330.4545186779375 274.09438917325735 43.0 endloop endfacet facet normal 0.9914448613738169 0.1305261922200027 0.0 outer loop vertex 330.40000000000003 273.6802787010933 41.00000000000001 vertex 330.4545186779375 273.26616822892925 43.0 vertex 330.4545186779375 273.26616822892925 41.00000000000001 endloop endfacet facet normal 0.9914448613738169 0.1305261922200027 0.0 outer loop vertex 330.4545186779375 273.26616822892925 43.0 vertex 330.40000000000003 273.6802787010933 41.00000000000001 vertex 330.40000000000003 273.6802787010933 43.0 endloop endfacet facet normal 0.9238795325112514 0.38268343236517494 0.0 outer loop vertex 330.4545186779375 273.26616822892925 41.00000000000001 vertex 330.61435935394496 272.88027870109335 43.0 vertex 330.61435935394496 272.88027870109335 41.00000000000001 endloop endfacet facet normal 0.9238795325112514 0.38268343236517494 0.0 outer loop vertex 330.61435935394496 272.88027870109335 43.0 vertex 330.4545186779375 273.26616822892925 41.00000000000001 vertex 330.4545186779375 273.26616822892925 43.0 endloop endfacet facet normal 0.7933533402912437 0.6087614290087096 0.0 outer loop vertex 330.61435935394496 272.88027870109335 41.00000000000001 vertex 330.8686291501015 272.5489078511949 43.0 vertex 330.8686291501015 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.7933533402912437 0.6087614290087096 0.0 outer loop vertex 330.8686291501015 272.5489078511949 43.0 vertex 330.61435935394496 272.88027870109335 41.00000000000001 vertex 330.61435935394496 272.88027870109335 43.0 endloop endfacet facet normal 0.6087614290087096 0.7933533402912437 0.0 outer loop vertex 330.8686291501015 272.5489078511949 43.0 vertex 331.20000000000005 272.29463805503826 41.00000000000001 vertex 330.8686291501015 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.6087614290087096 0.7933533402912437 0.0 outer loop vertex 331.20000000000005 272.29463805503826 41.00000000000001 vertex 330.8686291501015 272.5489078511949 43.0 vertex 331.20000000000005 272.29463805503826 43.0 endloop endfacet facet normal 0.38268343236517494 0.9238795325112514 0.0 outer loop vertex 331.20000000000005 272.29463805503826 43.0 vertex 331.58588952783595 272.13479737903083 41.00000000000001 vertex 331.20000000000005 272.29463805503826 41.00000000000001 endloop endfacet facet normal 0.38268343236517494 0.9238795325112514 0.0 outer loop vertex 331.58588952783595 272.13479737903083 41.00000000000001 vertex 331.20000000000005 272.29463805503826 43.0 vertex 331.58588952783595 272.13479737903083 43.0 endloop endfacet facet normal 0.1305261922200027 0.9914448613738169 0.0 outer loop vertex 331.58588952783595 272.13479737903083 43.0 vertex 332.0 272.08027870109333 41.00000000000001 vertex 331.58588952783595 272.13479737903083 41.00000000000001 endloop endfacet facet normal 0.1305261922200027 0.9914448613738169 0.0 outer loop vertex 332.0 272.08027870109333 41.00000000000001 vertex 331.58588952783595 272.13479737903083 43.0 vertex 332.0 272.08027870109333 43.0 endloop endfacet facet normal -0.1305261922200027 0.9914448613738169 0.0 outer loop vertex 332.0 272.08027870109333 43.0 vertex 332.41411047216405 272.13479737903083 41.00000000000001 vertex 332.0 272.08027870109333 41.00000000000001 endloop endfacet facet normal -0.1305261922200027 0.9914448613738169 0.0 outer loop vertex 332.41411047216405 272.13479737903083 41.00000000000001 vertex 332.0 272.08027870109333 43.0 vertex 332.41411047216405 272.13479737903083 43.0 endloop endfacet facet normal -0.38268343236517494 0.9238795325112514 0.0 outer loop vertex 332.41411047216405 272.13479737903083 43.0 vertex 332.8 272.29463805503826 41.00000000000001 vertex 332.41411047216405 272.13479737903083 41.00000000000001 endloop endfacet facet normal -0.38268343236517494 0.9238795325112514 0.0 outer loop vertex 332.8 272.29463805503826 41.00000000000001 vertex 332.41411047216405 272.13479737903083 43.0 vertex 332.8 272.29463805503826 43.0 endloop endfacet facet normal -0.6087614290087096 0.7933533402912437 0.0 outer loop vertex 332.8 272.29463805503826 43.0 vertex 333.1313708498985 272.5489078511949 41.00000000000001 vertex 332.8 272.29463805503826 41.00000000000001 endloop endfacet facet normal -0.6087614290087096 0.7933533402912437 0.0 outer loop vertex 333.1313708498985 272.5489078511949 41.00000000000001 vertex 332.8 272.29463805503826 43.0 vertex 333.1313708498985 272.5489078511949 43.0 endloop endfacet facet normal -0.7933533402912437 0.6087614290087096 0.0 outer loop vertex 333.3856406460551 272.88027870109335 43.0 vertex 333.1313708498985 272.5489078511949 41.00000000000001 vertex 333.1313708498985 272.5489078511949 43.0 endloop endfacet facet normal -0.7933533402912437 0.6087614290087096 0.0 outer loop vertex 333.1313708498985 272.5489078511949 41.00000000000001 vertex 333.3856406460551 272.88027870109335 43.0 vertex 333.3856406460551 272.88027870109335 41.00000000000001 endloop endfacet facet normal -0.9238795325112673 0.38268343236513674 0.0 outer loop vertex 333.5454813220625 273.2661682289293 43.0 vertex 333.3856406460551 272.88027870109335 41.00000000000001 vertex 333.3856406460551 272.88027870109335 43.0 endloop endfacet facet normal -0.9238795325112673 0.38268343236513674 0.0 outer loop vertex 333.3856406460551 272.88027870109335 41.00000000000001 vertex 333.5454813220625 273.2661682289293 43.0 vertex 333.5454813220625 273.2661682289293 41.00000000000001 endloop endfacet facet normal 0.6087614290087096 0.7933533402912437 0.0 outer loop vertex 168.36862915010153 272.5489078511949 43.0 vertex 168.70000000000002 272.29463805503826 41.00000000000001 vertex 168.36862915010153 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.6087614290087096 0.7933533402912437 0.0 outer loop vertex 168.70000000000002 272.29463805503826 41.00000000000001 vertex 168.36862915010153 272.5489078511949 43.0 vertex 168.70000000000002 272.29463805503826 43.0 endloop endfacet facet normal 0.38268343236515584 0.9238795325112594 0.0 outer loop vertex 168.70000000000002 272.29463805503826 43.0 vertex 169.08588952783597 272.13479737903083 41.00000000000001 vertex 168.70000000000002 272.29463805503826 41.00000000000001 endloop endfacet facet normal 0.38268343236515584 0.9238795325112594 0.0 outer loop vertex 169.08588952783597 272.13479737903083 41.00000000000001 vertex 168.70000000000002 272.29463805503826 43.0 vertex 169.08588952783597 272.13479737903083 43.0 endloop endfacet facet normal 0.1305261922200097 0.991444861373816 0.0 outer loop vertex 169.08588952783597 272.13479737903083 43.0 vertex 169.5 272.08027870109333 41.00000000000001 vertex 169.08588952783597 272.13479737903083 41.00000000000001 endloop endfacet facet normal 0.1305261922200097 0.991444861373816 0.0 outer loop vertex 169.5 272.08027870109333 41.00000000000001 vertex 169.08588952783597 272.13479737903083 43.0 vertex 169.5 272.08027870109333 43.0 endloop endfacet facet normal -0.1305261922200097 0.991444861373816 0.0 outer loop vertex 169.5 272.08027870109333 43.0 vertex 169.91411047216403 272.13479737903083 41.00000000000001 vertex 169.5 272.08027870109333 41.00000000000001 endloop endfacet facet normal -0.1305261922200097 0.991444861373816 0.0 outer loop vertex 169.91411047216403 272.13479737903083 41.00000000000001 vertex 169.5 272.08027870109333 43.0 vertex 169.91411047216403 272.13479737903083 43.0 endloop endfacet facet normal -0.38268343236515584 0.9238795325112594 0.0 outer loop vertex 169.91411047216403 272.13479737903083 43.0 vertex 170.3 272.29463805503826 41.00000000000001 vertex 169.91411047216403 272.13479737903083 41.00000000000001 endloop endfacet facet normal -0.38268343236515584 0.9238795325112594 0.0 outer loop vertex 170.3 272.29463805503826 41.00000000000001 vertex 169.91411047216403 272.13479737903083 43.0 vertex 170.3 272.29463805503826 43.0 endloop endfacet facet normal -0.6087614290087096 0.7933533402912437 0.0 outer loop vertex 170.3 272.29463805503826 43.0 vertex 170.63137084989847 272.5489078511949 41.00000000000001 vertex 170.3 272.29463805503826 41.00000000000001 endloop endfacet facet normal -0.6087614290087096 0.7933533402912437 0.0 outer loop vertex 170.63137084989847 272.5489078511949 41.00000000000001 vertex 170.3 272.29463805503826 43.0 vertex 170.63137084989847 272.5489078511949 43.0 endloop endfacet facet normal -0.7933533402912176 0.6087614290087435 0.0 outer loop vertex 170.88564064605512 272.88027870109335 43.0 vertex 170.63137084989847 272.5489078511949 41.00000000000001 vertex 170.63137084989847 272.5489078511949 43.0 endloop endfacet facet normal -0.7933533402912176 0.6087614290087435 0.0 outer loop vertex 170.63137084989847 272.5489078511949 41.00000000000001 vertex 170.88564064605512 272.88027870109335 43.0 vertex 170.88564064605512 272.88027870109335 41.00000000000001 endloop endfacet facet normal -0.9238795325112896 0.38268343236508273 0.0 outer loop vertex 171.0454813220625 273.26616822892925 43.0 vertex 170.88564064605512 272.88027870109335 41.00000000000001 vertex 170.88564064605512 272.88027870109335 43.0 endloop endfacet facet normal -0.9238795325112896 0.38268343236508273 0.0 outer loop vertex 170.88564064605512 272.88027870109335 41.00000000000001 vertex 171.0454813220625 273.26616822892925 43.0 vertex 171.0454813220625 273.26616822892925 41.00000000000001 endloop endfacet facet normal -0.9914448613738098 0.13052619222005576 0.0 outer loop vertex 171.1 273.6802787010933 43.0 vertex 171.0454813220625 273.26616822892925 41.00000000000001 vertex 171.0454813220625 273.26616822892925 43.0 endloop endfacet facet normal -0.9914448613738098 0.13052619222005576 0.0 outer loop vertex 171.0454813220625 273.26616822892925 41.00000000000001 vertex 171.1 273.6802787010933 43.0 vertex 171.1 273.6802787010933 41.00000000000001 endloop endfacet facet normal -0.9914448613738098 -0.13052619222005576 0.0 outer loop vertex 171.0454813220625 274.09438917325735 43.0 vertex 171.1 273.6802787010933 41.00000000000001 vertex 171.1 273.6802787010933 43.0 endloop endfacet facet normal -0.9914448613738098 -0.13052619222005576 0.0 outer loop vertex 171.1 273.6802787010933 41.00000000000001 vertex 171.0454813220625 274.09438917325735 43.0 vertex 171.0454813220625 274.09438917325735 41.00000000000001 endloop endfacet facet normal -0.9238795325112896 -0.38268343236508273 0.0 outer loop vertex 170.88564064605512 274.4802787010933 43.0 vertex 171.0454813220625 274.09438917325735 41.00000000000001 vertex 171.0454813220625 274.09438917325735 43.0 endloop endfacet facet normal -0.9238795325112896 -0.38268343236508273 0.0 outer loop vertex 171.0454813220625 274.09438917325735 41.00000000000001 vertex 170.88564064605512 274.4802787010933 43.0 vertex 170.88564064605512 274.4802787010933 41.00000000000001 endloop endfacet facet normal -0.7933533402912176 -0.6087614290087435 0.0 outer loop vertex 170.63137084989847 274.8116495509918 43.0 vertex 170.88564064605512 274.4802787010933 41.00000000000001 vertex 170.88564064605512 274.4802787010933 43.0 endloop endfacet facet normal -0.7933533402912176 -0.6087614290087435 0.0 outer loop vertex 170.88564064605512 274.4802787010933 41.00000000000001 vertex 170.63137084989847 274.8116495509918 43.0 vertex 170.63137084989847 274.8116495509918 41.00000000000001 endloop endfacet facet normal -0.6087614290087096 -0.7933533402912437 0.0 outer loop vertex 170.63137084989847 274.8116495509918 43.0 vertex 170.3 275.0659193471484 41.00000000000001 vertex 170.63137084989847 274.8116495509918 41.00000000000001 endloop endfacet facet normal -0.6087614290087096 -0.7933533402912437 0.0 outer loop vertex 170.3 275.0659193471484 41.00000000000001 vertex 170.63137084989847 274.8116495509918 43.0 vertex 170.3 275.0659193471484 43.0 endloop endfacet facet normal -0.38268343236515584 -0.9238795325112594 0.0 outer loop vertex 170.3 275.0659193471484 43.0 vertex 169.91411047216403 275.22576002315583 41.00000000000001 vertex 170.3 275.0659193471484 41.00000000000001 endloop endfacet facet normal -0.38268343236515584 -0.9238795325112594 0.0 outer loop vertex 169.91411047216403 275.22576002315583 41.00000000000001 vertex 170.3 275.0659193471484 43.0 vertex 169.91411047216403 275.22576002315583 43.0 endloop endfacet facet normal -0.1305261922200097 -0.991444861373816 0.0 outer loop vertex 169.91411047216403 275.22576002315583 43.0 vertex 169.5 275.2802787010933 41.00000000000001 vertex 169.91411047216403 275.22576002315583 41.00000000000001 endloop endfacet facet normal -0.1305261922200097 -0.991444861373816 0.0 outer loop vertex 169.5 275.2802787010933 41.00000000000001 vertex 169.91411047216403 275.22576002315583 43.0 vertex 169.5 275.2802787010933 43.0 endloop endfacet facet normal 0.1305261922200097 -0.991444861373816 0.0 outer loop vertex 169.5 275.2802787010933 43.0 vertex 169.08588952783597 275.22576002315583 41.00000000000001 vertex 169.5 275.2802787010933 41.00000000000001 endloop endfacet facet normal 0.1305261922200097 -0.991444861373816 0.0 outer loop vertex 169.08588952783597 275.22576002315583 41.00000000000001 vertex 169.5 275.2802787010933 43.0 vertex 169.08588952783597 275.22576002315583 43.0 endloop endfacet facet normal 0.38268343236515584 -0.9238795325112594 0.0 outer loop vertex 169.08588952783597 275.22576002315583 43.0 vertex 168.70000000000002 275.0659193471484 41.00000000000001 vertex 169.08588952783597 275.22576002315583 41.00000000000001 endloop endfacet facet normal 0.38268343236515584 -0.9238795325112594 0.0 outer loop vertex 168.70000000000002 275.0659193471484 41.00000000000001 vertex 169.08588952783597 275.22576002315583 43.0 vertex 168.70000000000002 275.0659193471484 43.0 endloop endfacet facet normal 0.6087614290087096 -0.7933533402912437 0.0 outer loop vertex 168.70000000000002 275.0659193471484 43.0 vertex 168.36862915010153 274.8116495509918 41.00000000000001 vertex 168.70000000000002 275.0659193471484 41.00000000000001 endloop endfacet facet normal 0.6087614290087096 -0.7933533402912437 0.0 outer loop vertex 168.36862915010153 274.8116495509918 41.00000000000001 vertex 168.70000000000002 275.0659193471484 43.0 vertex 168.36862915010153 274.8116495509918 43.0 endloop endfacet facet normal 0.7933533402912176 -0.6087614290087435 0.0 outer loop vertex 168.36862915010153 274.8116495509918 41.00000000000001 vertex 168.1143593539449 274.4802787010933 43.0 vertex 168.1143593539449 274.4802787010933 41.00000000000001 endloop endfacet facet normal 0.7933533402912176 -0.6087614290087435 0.0 outer loop vertex 168.1143593539449 274.4802787010933 43.0 vertex 168.36862915010153 274.8116495509918 41.00000000000001 vertex 168.36862915010153 274.8116495509918 43.0 endloop endfacet facet normal 0.9238795325112896 -0.38268343236508273 0.0 outer loop vertex 168.1143593539449 274.4802787010933 41.00000000000001 vertex 167.9545186779375 274.09438917325735 43.0 vertex 167.9545186779375 274.09438917325735 41.00000000000001 endloop endfacet facet normal 0.9238795325112896 -0.38268343236508273 0.0 outer loop vertex 167.9545186779375 274.09438917325735 43.0 vertex 168.1143593539449 274.4802787010933 41.00000000000001 vertex 168.1143593539449 274.4802787010933 43.0 endloop endfacet facet normal 0.9914448613738098 -0.13052619222005576 0.0 outer loop vertex 167.9545186779375 274.09438917325735 41.00000000000001 vertex 167.9 273.6802787010933 43.0 vertex 167.9 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.9914448613738098 -0.13052619222005576 0.0 outer loop vertex 167.9 273.6802787010933 43.0 vertex 167.9545186779375 274.09438917325735 41.00000000000001 vertex 167.9545186779375 274.09438917325735 43.0 endloop endfacet facet normal 0.991444861373808 0.13052619222006975 0.0 outer loop vertex 167.9 273.6802787010933 41.00000000000001 vertex 167.9545186779375 273.2661682289293 43.0 vertex 167.9545186779375 273.2661682289293 41.00000000000001 endloop endfacet facet normal 0.991444861373808 0.13052619222006975 0.0 outer loop vertex 167.9545186779375 273.2661682289293 43.0 vertex 167.9 273.6802787010933 41.00000000000001 vertex 167.9 273.6802787010933 43.0 endloop endfacet facet normal 0.9238795325113055 0.38268343236504454 0.0 outer loop vertex 167.9545186779375 273.2661682289293 41.00000000000001 vertex 168.1143593539449 272.88027870109335 43.0 vertex 168.1143593539449 272.88027870109335 41.00000000000001 endloop endfacet facet normal 0.9238795325113055 0.38268343236504454 0.0 outer loop vertex 168.1143593539449 272.88027870109335 43.0 vertex 167.9545186779375 273.2661682289293 41.00000000000001 vertex 167.9545186779375 273.2661682289293 43.0 endloop endfacet facet normal 0.7933533402912176 0.6087614290087435 0.0 outer loop vertex 168.1143593539449 272.88027870109335 41.00000000000001 vertex 168.36862915010153 272.5489078511949 43.0 vertex 168.36862915010153 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.7933533402912176 0.6087614290087435 0.0 outer loop vertex 168.36862915010153 272.5489078511949 43.0 vertex 168.1143593539449 272.88027870109335 41.00000000000001 vertex 168.1143593539449 272.88027870109335 43.0 endloop endfacet facet normal 0.9914448613738115 -0.13052619222004416 0.0 outer loop vertex 5.4545186779374975 274.09438917325735 41.00000000000001 vertex 5.4000000000000075 273.6802787010933 43.0 vertex 5.4000000000000075 273.6802787010933 41.00000000000001 endloop endfacet facet normal 0.9914448613738115 -0.13052619222004416 0.0 outer loop vertex 5.4000000000000075 273.6802787010933 43.0 vertex 5.4545186779374975 274.09438917325735 41.00000000000001 vertex 5.4545186779374975 274.09438917325735 43.0 endloop endfacet facet normal 0.9914448613738113 0.13052619222004583 0.0 outer loop vertex 5.4000000000000075 273.6802787010933 41.00000000000001 vertex 5.454518677937498 273.26616822892925 43.0 vertex 5.454518677937498 273.26616822892925 41.00000000000001 endloop endfacet facet normal 0.9914448613738113 0.13052619222004583 0.0 outer loop vertex 5.454518677937498 273.26616822892925 43.0 vertex 5.4000000000000075 273.6802787010933 41.00000000000001 vertex 5.4000000000000075 273.6802787010933 43.0 endloop endfacet facet normal 0.9238795325112795 0.3826834323651072 0.0 outer loop vertex 5.454518677937498 273.26616822892925 41.00000000000001 vertex 5.614359353944905 272.88027870109335 43.0 vertex 5.614359353944905 272.88027870109335 41.00000000000001 endloop endfacet facet normal 0.9238795325112795 0.3826834323651072 0.0 outer loop vertex 5.614359353944905 272.88027870109335 43.0 vertex 5.454518677937498 273.26616822892925 41.00000000000001 vertex 5.454518677937498 273.26616822892925 43.0 endloop endfacet facet normal 0.7933533402912315 0.6087614290087254 0.0 outer loop vertex 5.614359353944905 272.88027870109335 41.00000000000001 vertex 5.86862915010153 272.5489078511949 43.0 vertex 5.86862915010153 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.7933533402912315 0.6087614290087254 0.0 outer loop vertex 5.86862915010153 272.5489078511949 43.0 vertex 5.614359353944905 272.88027870109335 41.00000000000001 vertex 5.614359353944905 272.88027870109335 43.0 endloop endfacet facet normal 0.6087614290087047 0.7933533402912475 0.0 outer loop vertex 5.86862915010153 272.5489078511949 43.0 vertex 6.2000000000000055 272.29463805503826 41.00000000000001 vertex 5.86862915010153 272.5489078511949 41.00000000000001 endloop endfacet facet normal 0.6087614290087047 0.7933533402912475 0.0 outer loop vertex 6.2000000000000055 272.29463805503826 41.00000000000001 vertex 5.86862915010153 272.5489078511949 43.0 vertex 6.2000000000000055 272.29463805503826 43.0 endloop endfacet facet normal 0.38268343236515584 0.9238795325112594 0.0 outer loop vertex 6.2000000000000055 272.29463805503826 43.0 vertex 6.585889527835972 272.13479737903083 41.00000000000001 vertex 6.2000000000000055 272.29463805503826 41.00000000000001 endloop endfacet facet normal 0.38268343236515584 0.9238795325112594 0.0 outer loop vertex 6.585889527835972 272.13479737903083 41.00000000000001 vertex 6.2000000000000055 272.29463805503826 43.0 vertex 6.585889527835972 272.13479737903083 43.0 endloop endfacet facet normal 0.1305261922200097 0.991444861373816 0.0 outer loop vertex 6.585889527835972 272.13479737903083 43.0 vertex 7.000000000000004 272.08027870109333 41.00000000000001 vertex 6.585889527835972 272.13479737903083 41.00000000000001 endloop endfacet facet normal 0.1305261922200097 0.991444861373816 0.0 outer loop vertex 7.000000000000004 272.08027870109333 41.00000000000001 vertex 6.585889527835972 272.13479737903083 43.0 vertex 7.000000000000004 272.08027870109333 43.0 endloop endfacet facet normal -0.13052619222000925 0.991444861373816 0.0 outer loop vertex 7.000000000000004 272.08027870109333 43.0 vertex 7.414110472164038 272.13479737903083 41.00000000000001 vertex 7.000000000000004 272.08027870109333 41.00000000000001 endloop endfacet facet normal -0.13052619222000925 0.991444861373816 0.0 outer loop vertex 7.414110472164038 272.13479737903083 41.00000000000001 vertex 7.000000000000004 272.08027870109333 43.0 vertex 7.414110472164038 272.13479737903083 43.0 endloop endfacet facet normal -0.38268343236515706 0.923879532511259 0.0 outer loop vertex 7.414110472164038 272.13479737903083 43.0 vertex 7.8000000000000025 272.29463805503826 41.00000000000001 vertex 7.414110472164038 272.13479737903083 41.00000000000001 endloop endfacet facet normal -0.38268343236515706 0.923879532511259 0.0 outer loop vertex 7.8000000000000025 272.29463805503826 41.00000000000001 vertex 7.414110472164038 272.13479737903083 43.0 vertex 7.8000000000000025 272.29463805503826 43.0 endloop endfacet facet normal -0.6087614290087047 0.7933533402912475 0.0 outer loop vertex 7.8000000000000025 272.29463805503826 43.0 vertex 8.131370849898477 272.5489078511949 41.00000000000001 vertex 7.8000000000000025 272.29463805503826 41.00000000000001 endloop endfacet facet normal -0.6087614290087047 0.7933533402912475 0.0 outer loop vertex 8.131370849898477 272.5489078511949 41.00000000000001 vertex 7.8000000000000025 272.29463805503826 43.0 vertex 8.131370849898477 272.5489078511949 43.0 endloop endfacet facet normal -0.7933533402912306 0.6087614290087265 0.0 outer loop vertex 8.385640646055105 272.88027870109335 43.0 vertex 8.131370849898477 272.5489078511949 41.00000000000001 vertex 8.131370849898477 272.5489078511949 43.0 endloop endfacet facet normal -0.7933533402912306 0.6087614290087265 0.0 outer loop vertex 8.131370849898477 272.5489078511949 41.00000000000001 vertex 8.385640646055105 272.88027870109335 43.0 vertex 8.385640646055105 272.88027870109335 41.00000000000001 endloop endfacet facet normal -0.9238795325112947 0.38268343236507046 0.0 outer loop vertex 8.545481322062512 273.2661682289293 43.0 vertex 8.385640646055105 272.88027870109335 41.00000000000001 vertex 8.385640646055105 272.88027870109335 43.0 endloop endfacet facet normal -0.9238795325112947 0.38268343236507046 0.0 outer loop vertex 8.385640646055105 272.88027870109335 41.00000000000001 vertex 8.545481322062512 273.2661682289293 43.0 vertex 8.545481322062512 273.2661682289293 41.00000000000001 endloop endfacet facet normal -0.9914448613738097 0.1305261922200565 0.0 outer loop vertex 8.600000000000001 273.6802787010933 43.0 vertex 8.545481322062512 273.2661682289293 41.00000000000001 vertex 8.545481322062512 273.2661682289293 43.0 endloop endfacet facet normal -0.9914448613738097 0.1305261922200565 0.0 outer loop vertex 8.545481322062512 273.2661682289293 41.00000000000001 vertex 8.600000000000001 273.6802787010933 43.0 vertex 8.600000000000001 273.6802787010933 41.00000000000001 endloop endfacet facet normal -0.9914448613738113 -0.13052619222004583 0.0 outer loop vertex 8.54548132206251 274.09438917325735 43.0 vertex 8.600000000000001 273.6802787010933 41.00000000000001 vertex 8.600000000000001 273.6802787010933 43.0 endloop endfacet facet normal -0.9914448613738113 -0.13052619222004583 0.0 outer loop vertex 8.600000000000001 273.6802787010933 41.00000000000001 vertex 8.54548132206251 274.09438917325735 43.0 vertex 8.54548132206251 274.09438917325735 41.00000000000001 endloop endfacet facet normal -0.923879532511279 -0.38268343236510866 0.0 outer loop vertex 8.385640646055103 274.4802787010933 43.0 vertex 8.54548132206251 274.09438917325735 41.00000000000001 vertex 8.54548132206251 274.09438917325735 43.0 endloop endfacet facet normal -0.923879532511279 -0.38268343236510866 0.0 outer loop vertex 8.54548132206251 274.09438917325735 41.00000000000001 vertex 8.385640646055103 274.4802787010933 43.0 vertex 8.385640646055103 274.4802787010933 41.00000000000001 endloop endfacet facet normal -0.7933533402912306 -0.6087614290087265 0.0 outer loop vertex 8.131370849898477 274.8116495509918 43.0 vertex 8.385640646055103 274.4802787010933 41.00000000000001 vertex 8.385640646055103 274.4802787010933 43.0 endloop endfacet facet normal -0.7933533402912306 -0.6087614290087265 0.0 outer loop vertex 8.385640646055103 274.4802787010933 41.00000000000001 vertex 8.131370849898477 274.8116495509918 43.0 vertex 8.131370849898477 274.8116495509918 41.00000000000001 endloop endfacet facet normal -0.6087614290087063 -0.7933533402912463 0.0 outer loop vertex 8.131370849898477 274.8116495509918 43.0 vertex 7.8000000000000025 275.0659193471484 41.00000000000001 vertex 8.131370849898477 274.8116495509918 41.00000000000001 endloop endfacet facet normal -0.6087614290087063 -0.7933533402912463 0.0 outer loop vertex 7.8000000000000025 275.0659193471484 41.00000000000001 vertex 8.131370849898477 274.8116495509918 43.0 vertex 7.8000000000000025 275.0659193471484 43.0 endloop endfacet facet normal -0.38268343236515584 -0.9238795325112594 0.0 outer loop vertex 7.8000000000000025 275.0659193471484 43.0 vertex 7.414110472164036 275.22576002315583 41.00000000000001 vertex 7.8000000000000025 275.0659193471484 41.00000000000001 endloop endfacet facet normal -0.38268343236515584 -0.9238795325112594 0.0 outer loop vertex 7.414110472164036 275.22576002315583 41.00000000000001 vertex 7.8000000000000025 275.0659193471484 43.0 vertex 7.414110472164036 275.22576002315583 43.0 endloop endfacet facet normal -0.1305261922200097 -0.991444861373816 0.0 outer loop vertex 7.414110472164036 275.22576002315583 43.0 vertex 7.000000000000004 275.2802787010933 41.00000000000001 vertex 7.414110472164036 275.22576002315583 41.00000000000001 endloop endfacet facet normal -0.1305261922200097 -0.991444861373816 0.0 outer loop vertex 7.000000000000004 275.2802787010933 41.00000000000001 vertex 7.414110472164036 275.22576002315583 43.0 vertex 7.000000000000004 275.2802787010933 43.0 endloop endfacet facet normal 0.13052619222000925 -0.991444861373816 0.0 outer loop vertex 7.000000000000004 275.2802787010933 43.0 vertex 6.58588952783597 275.22576002315583 41.00000000000001 vertex 7.000000000000004 275.2802787010933 41.00000000000001 endloop endfacet facet normal 0.13052619222000925 -0.991444861373816 0.0 outer loop vertex 6.58588952783597 275.22576002315583 41.00000000000001 vertex 7.000000000000004 275.2802787010933 43.0 vertex 6.58588952783597 275.22576002315583 43.0 endloop endfacet facet normal 0.3826834323651564 -0.9238795325112591 0.0 outer loop vertex 6.58588952783597 275.22576002315583 43.0 vertex 6.200000000000005 275.0659193471484 41.00000000000001 vertex 6.58588952783597 275.22576002315583 41.00000000000001 endloop endfacet facet normal 0.3826834323651564 -0.9238795325112591 0.0 outer loop vertex 6.200000000000005 275.0659193471484 41.00000000000001 vertex 6.58588952783597 275.22576002315583 43.0 vertex 6.200000000000005 275.0659193471484 43.0 endloop endfacet facet normal 0.6087614290087054 -0.7933533402912468 0.0 outer loop vertex 6.200000000000005 275.0659193471484 43.0 vertex 5.86862915010153 274.8116495509918 41.00000000000001 vertex 6.200000000000005 275.0659193471484 41.00000000000001 endloop endfacet facet normal 0.6087614290087054 -0.7933533402912468 0.0 outer loop vertex 5.86862915010153 274.8116495509918 41.00000000000001 vertex 6.200000000000005 275.0659193471484 43.0 vertex 5.86862915010153 274.8116495509918 43.0 endloop endfacet facet normal 0.7933533402912315 -0.6087614290087254 0.0 outer loop vertex 5.86862915010153 274.8116495509918 41.00000000000001 vertex 5.614359353944905 274.4802787010933 43.0 vertex 5.614359353944905 274.4802787010933 41.00000000000001 endloop endfacet facet normal 0.7933533402912315 -0.6087614290087254 0.0 outer loop vertex 5.614359353944905 274.4802787010933 43.0 vertex 5.86862915010153 274.8116495509918 41.00000000000001 vertex 5.86862915010153 274.8116495509918 43.0 endloop endfacet facet normal 0.923879532511279 -0.38268343236510866 0.0 outer loop vertex 5.614359353944905 274.4802787010933 41.00000000000001 vertex 5.4545186779374975 274.09438917325735 43.0 vertex 5.4545186779374975 274.09438917325735 41.00000000000001 endloop endfacet facet normal 0.923879532511279 -0.38268343236510866 0.0 outer loop vertex 5.4545186779374975 274.09438917325735 43.0 vertex 5.614359353944905 274.4802787010933 41.00000000000001 vertex 5.614359353944905 274.4802787010933 43.0 endloop endfacet facet normal 0.7933533402912315 -0.6087614290087254 0.0 outer loop vertex 5.868629150101527 157.81164955099177 41.00000000000001 vertex 5.614359353944902 157.48027870109328 43.0 vertex 5.614359353944902 157.48027870109328 41.00000000000001 endloop endfacet facet normal 0.7933533402912315 -0.6087614290087254 0.0 outer loop vertex 5.614359353944902 157.48027870109328 43.0 vertex 5.868629150101527 157.81164955099177 41.00000000000001 vertex 5.868629150101527 157.81164955099177 43.0 endloop endfacet facet normal 0.9238795325112867 -0.38268343236508956 0.0 outer loop vertex 5.614359353944902 157.48027870109328 41.00000000000001 vertex 5.454518677937495 157.09438917325733 43.0 vertex 5.454518677937495 157.09438917325733 41.00000000000001 endloop endfacet facet normal 0.9238795325112867 -0.38268343236508956 0.0 outer loop vertex 5.454518677937495 157.09438917325733 43.0 vertex 5.614359353944902 157.48027870109328 41.00000000000001 vertex 5.614359353944902 157.48027870109328 43.0 endloop endfacet facet normal 0.9914448613738106 -0.13052619222005116 0.0 outer loop vertex 5.454518677937495 157.09438917325733 41.00000000000001 vertex 5.400000000000004 156.6802787010933 43.0 vertex 5.400000000000004 156.6802787010933 41.00000000000001 endloop endfacet facet normal 0.9914448613738106 -0.13052619222005116 0.0 outer loop vertex 5.400000000000004 156.6802787010933 43.0 vertex 5.454518677937495 157.09438917325733 41.00000000000001 vertex 5.454518677937495 157.09438917325733 43.0 endloop endfacet facet normal 0.9914448613738104 0.13052619222005282 0.0 outer loop vertex 5.400000000000004 156.6802787010933 41.00000000000001 vertex 5.454518677937496 156.26616822892927 43.0 vertex 5.454518677937496 156.26616822892927 41.00000000000001 endloop endfacet facet normal 0.9914448613738104 0.13052619222005282 0.0 outer loop vertex 5.454518677937496 156.26616822892927 43.0 vertex 5.400000000000004 156.6802787010933 41.00000000000001 vertex 5.400000000000004 156.6802787010933 43.0 endloop endfacet facet normal 0.9238795325112867 0.38268343236508956 0.0 outer loop vertex 5.454518677937496 156.26616822892927 41.00000000000001 vertex 5.614359353944902 155.8802787010933 43.0 vertex 5.614359353944902 155.8802787010933 41.00000000000001 endloop endfacet facet normal 0.9238795325112867 0.38268343236508956 0.0 outer loop vertex 5.614359353944902 155.8802787010933 43.0 vertex 5.454518677937496 156.26616822892927 41.00000000000001 vertex 5.454518677937496 156.26616822892927 43.0 endloop endfacet facet normal 0.7933533402912306 0.6087614290087265 0.0 outer loop vertex 5.614359353944902 155.8802787010933 41.00000000000001 vertex 5.868629150101529 155.54890785119483 43.0 vertex 5.868629150101529 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.7933533402912306 0.6087614290087265 0.0 outer loop vertex 5.868629150101529 155.54890785119483 43.0 vertex 5.614359353944902 155.8802787010933 41.00000000000001 vertex 5.614359353944902 155.8802787010933 43.0 endloop endfacet facet normal 0.6087614290087386 0.7933533402912214 0.0 outer loop vertex 5.868629150101529 155.54890785119483 43.0 vertex 6.200000000000004 155.29463805503818 41.00000000000001 vertex 5.868629150101529 155.54890785119483 41.00000000000001 endloop endfacet facet normal 0.6087614290087386 0.7933533402912214 0.0 outer loop vertex 6.200000000000004 155.29463805503818 41.00000000000001 vertex 5.868629150101529 155.54890785119483 43.0 vertex 6.200000000000004 155.29463805503818 43.0 endloop endfacet facet normal 0.3826834323650637 0.9238795325112976 0.0 outer loop vertex 6.200000000000004 155.29463805503818 43.0 vertex 6.58588952783597 155.1347973790308 41.00000000000001 vertex 6.200000000000004 155.29463805503818 41.00000000000001 endloop endfacet facet normal 0.3826834323650637 0.9238795325112976 0.0 outer loop vertex 6.58588952783597 155.1347973790308 41.00000000000001 vertex 6.200000000000004 155.29463805503818 43.0 vertex 6.58588952783597 155.1347973790308 43.0 endloop endfacet facet normal 0.13052619222006231 0.991444861373809 0.0 outer loop vertex 6.58588952783597 155.1347973790308 43.0 vertex 7.000000000000004 155.0802787010933 41.00000000000001 vertex 6.58588952783597 155.1347973790308 41.00000000000001 endloop endfacet facet normal 0.13052619222006231 0.991444861373809 0.0 outer loop vertex 7.000000000000004 155.0802787010933 41.00000000000001 vertex 6.58588952783597 155.1347973790308 43.0 vertex 7.000000000000004 155.0802787010933 43.0 endloop endfacet facet normal -0.13052619222006231 0.991444861373809 0.0 outer loop vertex 7.000000000000004 155.0802787010933 43.0 vertex 7.414110472164038 155.1347973790308 41.00000000000001 vertex 7.000000000000004 155.0802787010933 41.00000000000001 endloop endfacet facet normal -0.13052619222006231 0.991444861373809 0.0 outer loop vertex 7.414110472164038 155.1347973790308 41.00000000000001 vertex 7.000000000000004 155.0802787010933 43.0 vertex 7.414110472164038 155.1347973790308 43.0 endloop endfacet facet normal -0.3826834323650637 0.9238795325112976 0.0 outer loop vertex 7.414110472164038 155.1347973790308 43.0 vertex 7.800000000000004 155.29463805503818 41.00000000000001 vertex 7.414110472164038 155.1347973790308 41.00000000000001 endloop endfacet facet normal -0.3826834323650637 0.9238795325112976 0.0 outer loop vertex 7.800000000000004 155.29463805503818 41.00000000000001 vertex 7.414110472164038 155.1347973790308 43.0 vertex 7.800000000000004 155.29463805503818 43.0 endloop endfacet facet normal -0.6087614290087386 0.7933533402912214 0.0 outer loop vertex 7.800000000000004 155.29463805503818 43.0 vertex 8.13137084989848 155.54890785119483 41.00000000000001 vertex 7.800000000000004 155.29463805503818 41.00000000000001 endloop endfacet facet normal -0.6087614290087386 0.7933533402912214 0.0 outer loop vertex 8.13137084989848 155.54890785119483 41.00000000000001 vertex 7.800000000000004 155.29463805503818 43.0 vertex 8.13137084989848 155.54890785119483 43.0 endloop endfacet facet normal -0.7933533402912306 0.6087614290087265 0.0 outer loop vertex 8.385640646055105 155.8802787010933 43.0 vertex 8.13137084989848 155.54890785119483 41.00000000000001 vertex 8.13137084989848 155.54890785119483 43.0 endloop endfacet facet normal -0.7933533402912306 0.6087614290087265 0.0 outer loop vertex 8.13137084989848 155.54890785119483 41.00000000000001 vertex 8.385640646055105 155.8802787010933 43.0 vertex 8.385640646055105 155.8802787010933 41.00000000000001 endloop endfacet facet normal -0.9238795325112867 0.38268343236508956 0.0 outer loop vertex 8.545481322062512 156.26616822892927 43.0 vertex 8.385640646055105 155.8802787010933 41.00000000000001 vertex 8.385640646055105 155.8802787010933 43.0 endloop endfacet facet normal -0.9238795325112867 0.38268343236508956 0.0 outer loop vertex 8.385640646055105 155.8802787010933 41.00000000000001 vertex 8.545481322062512 156.26616822892927 43.0 vertex 8.545481322062512 156.26616822892927 41.00000000000001 endloop endfacet facet normal -0.9914448613738104 0.13052619222005282 0.0 outer loop vertex 8.600000000000003 156.6802787010933 43.0 vertex 8.545481322062512 156.26616822892927 41.00000000000001 vertex 8.545481322062512 156.26616822892927 43.0 endloop endfacet facet normal -0.9914448613738104 0.13052619222005282 0.0 outer loop vertex 8.545481322062512 156.26616822892927 41.00000000000001 vertex 8.600000000000003 156.6802787010933 43.0 vertex 8.600000000000003 156.6802787010933 41.00000000000001 endloop endfacet facet normal -0.9914448613738104 -0.13052619222005282 0.0 outer loop vertex 8.545481322062512 157.09438917325733 43.0 vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 8.600000000000003 156.6802787010933 43.0 endloop endfacet facet normal -0.9914448613738104 -0.13052619222005282 0.0 outer loop vertex 8.600000000000003 156.6802787010933 41.00000000000001 vertex 8.545481322062512 157.09438917325733 43.0 vertex 8.545481322062512 157.09438917325733 41.00000000000001 endloop endfacet facet normal -0.9238795325112867 -0.38268343236508956 0.0 outer loop vertex 8.385640646055105 157.48027870109328 43.0 vertex 8.545481322062512 157.09438917325733 41.00000000000001 vertex 8.545481322062512 157.09438917325733 43.0 endloop endfacet facet normal -0.9238795325112867 -0.38268343236508956 0.0 outer loop vertex 8.545481322062512 157.09438917325733 41.00000000000001 vertex 8.385640646055105 157.48027870109328 43.0 vertex 8.385640646055105 157.48027870109328 41.00000000000001 endloop endfacet facet normal -0.7933533402912306 -0.6087614290087265 0.0 outer loop vertex 8.13137084989848 157.81164955099177 43.0 vertex 8.385640646055105 157.48027870109328 41.00000000000001 vertex 8.385640646055105 157.48027870109328 43.0 endloop endfacet facet normal -0.7933533402912306 -0.6087614290087265 0.0 outer loop vertex 8.385640646055105 157.48027870109328 41.00000000000001 vertex 8.13137084989848 157.81164955099177 43.0 vertex 8.13137084989848 157.81164955099177 41.00000000000001 endloop endfacet facet normal -0.6087614290087371 -0.7933533402912227 0.0 outer loop vertex 8.13137084989848 157.81164955099177 43.0 vertex 7.8000000000000025 158.0659193471484 41.00000000000001 vertex 8.13137084989848 157.81164955099177 41.00000000000001 endloop endfacet facet normal -0.6087614290087371 -0.7933533402912227 0.0 outer loop vertex 7.8000000000000025 158.0659193471484 41.00000000000001 vertex 8.13137084989848 157.81164955099177 43.0 vertex 7.8000000000000025 158.0659193471484 43.0 endloop endfacet facet normal -0.3826834323650637 -0.9238795325112976 0.0 outer loop vertex 7.8000000000000025 158.0659193471484 43.0 vertex 7.414110472164036 158.2257600231558 41.00000000000001 vertex 7.8000000000000025 158.0659193471484 41.00000000000001 endloop endfacet facet normal -0.3826834323650637 -0.9238795325112976 0.0 outer loop vertex 7.414110472164036 158.2257600231558 41.00000000000001 vertex 7.8000000000000025 158.0659193471484 43.0 vertex 7.414110472164036 158.2257600231558 43.0 endloop endfacet facet normal -0.1305261922200628 -0.991444861373809 0.0 outer loop vertex 7.414110472164036 158.2257600231558 43.0 vertex 7.000000000000004 158.2802787010933 41.00000000000001 vertex 7.414110472164036 158.2257600231558 41.00000000000001 endloop endfacet facet normal -0.1305261922200628 -0.991444861373809 0.0 outer loop vertex 7.000000000000004 158.2802787010933 41.00000000000001 vertex 7.414110472164036 158.2257600231558 43.0 vertex 7.000000000000004 158.2802787010933 43.0 endloop endfacet facet normal 0.13052619222006187 -0.991444861373809 0.0 outer loop vertex 7.000000000000004 158.2802787010933 43.0 vertex 6.5858895278359695 158.2257600231558 41.00000000000001 vertex 7.000000000000004 158.2802787010933 41.00000000000001 endloop endfacet facet normal 0.13052619222006187 -0.991444861373809 0.0 outer loop vertex 6.5858895278359695 158.2257600231558 41.00000000000001 vertex 7.000000000000004 158.2802787010933 43.0 vertex 6.5858895278359695 158.2257600231558 43.0 endloop endfacet facet normal 0.3826834323650642 -0.9238795325112973 0.0 outer loop vertex 6.5858895278359695 158.2257600231558 43.0 vertex 6.200000000000004 158.0659193471484 41.00000000000001 vertex 6.5858895278359695 158.2257600231558 41.00000000000001 endloop endfacet facet normal 0.3826834323650642 -0.9238795325112973 0.0 outer loop vertex 6.200000000000004 158.0659193471484 41.00000000000001 vertex 6.5858895278359695 158.2257600231558 43.0 vertex 6.200000000000004 158.0659193471484 43.0 endloop endfacet facet normal 0.6087614290087379 -0.7933533402912221 0.0 outer loop vertex 6.200000000000004 158.0659193471484 43.0 vertex 5.868629150101527 157.81164955099177 41.00000000000001 vertex 6.200000000000004 158.0659193471484 41.00000000000001 endloop endfacet facet normal 0.6087614290087379 -0.7933533402912221 0.0 outer loop vertex 5.868629150101527 157.81164955099177 41.00000000000001 vertex 6.200000000000004 158.0659193471484 43.0 vertex 5.868629150101527 157.81164955099177 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.13137084989848 157.81164955099177 43.0 vertex 8.13137084989848 157.81164955099177 43.0 vertex 8.097985998570229 157.83726542612987 42.999999679625034 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.13137084989848 157.81164955099177 43.0 vertex 8.13137084989848 157.81164955099177 43.0 vertex 8.385640646055105 157.48027870109328 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.13137084989848 157.81164955099177 43.0 vertex 8.385640646055105 157.48027870109328 43.0 vertex 8.385640646055105 157.48027870109328 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.385640646055105 157.48027870109328 43.0 vertex 8.385640646055105 157.48027870109328 43.0 vertex 8.545481322062512 157.09438917325733 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.414110472164036 158.2257600231558 43.0 vertex 7.000000000000008 158.2802787010933 43.0 vertex 7.000000000000008 158.2802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.000000000000008 158.2802787010933 43.0 vertex 7.414110472164036 158.2257600231558 43.0 vertex 7.414110472164036 158.2257600231558 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.414110472164036 158.2257600231558 43.0 vertex 7.414110472164036 158.2257600231558 43.0 vertex 7.453062132667909 158.20962331358874 42.99999935925007 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.585889527835968 155.1347973790308 43.0 vertex 6.585889527835968 155.1347973790308 43.0 vertex 6.585889527835968 155.1347973790308 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.585889527835968 155.1347973790308 43.0 vertex 6.585889527835968 155.1347973790308 43.0 vertex 7.000000000000001 155.0802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.585889527835968 155.1347973790308 43.0 vertex 7.000000000000001 155.0802787010933 43.0 vertex 7.000000000000001 155.0802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.454518677937494 156.26616822892927 43.0 vertex 5.454518677937494 156.26616822892927 43.0 vertex 5.400000000000004 156.6802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.454518677937494 156.26616822892927 43.0 vertex 5.454518677937494 156.26616822892927 43.0 vertex 5.614359353944901 155.8802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.454518677937494 156.26616822892927 43.0 vertex 5.614359353944901 155.8802787010933 43.0 vertex 5.614359353944901 155.8802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.614359353944901 155.8802787010933 43.0 vertex 5.614359353944901 155.8802787010933 43.0 vertex 5.868629150101526 155.54890785119483 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.614359353944901 155.8802787010933 43.0 vertex 5.868629150101526 155.54890785119483 43.0 vertex 5.868629150101526 155.54890785119483 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.868629150101526 155.54890785119483 43.0 vertex 5.868629150101526 155.54890785119483 43.0 vertex 5.900413006733491 155.5245228176615 43.0000009611249 endloop endfacet facet normal 0.6517688105645921 -0.5001197982691571 0.5701557725345193 outer loop vertex 5.868629150101532 157.81164955099177 43.0 vertex 4.401923788646688 158.1802787010933 45.0 vertex 5.614359353944903 157.48027870109328 43.0 endloop endfacet facet normal 0.6517688105645921 -0.5001197982691571 0.5701557725345193 outer loop vertex 4.401923788646688 158.1802787010933 45.0 vertex 5.868629150101532 157.81164955099177 43.0 vertex 4.878679656440362 158.80159904465293 45.0 endloop endfacet facet normal 0.7590008555189364 -0.3143884482087244 0.5701557725345179 outer loop vertex 5.614359353944903 157.48027870109328 43.0 vertex 4.102222521132799 157.45673583640084 45.0 vertex 5.454518677937496 157.09438917325733 43.0 endloop endfacet facet normal 0.7590008555189364 -0.3143884482087244 0.5701557725345179 outer loop vertex 4.102222521132799 157.45673583640084 45.0 vertex 5.614359353944903 157.48027870109328 43.0 vertex 4.401923788646688 158.1802787010933 45.0 endloop endfacet facet normal 0.8145082464778834 -0.1072320449543445 0.570155772534518 outer loop vertex 5.454518677937496 157.09438917325733 43.0 vertex 4.0000000000000036 156.6802787010933 45.0 vertex 5.400000000000004 156.6802787010933 43.0 endloop endfacet facet normal 0.8145082464778834 -0.1072320449543445 0.570155772534518 outer loop vertex 4.0000000000000036 156.6802787010933 45.0 vertex 5.454518677937496 157.09438917325733 43.0 vertex 4.102222521132799 157.45673583640084 45.0 endloop endfacet facet normal 0.8145082464778836 0.10723204495434377 0.5701557725345178 outer loop vertex 5.454518677937494 156.26616822892927 43.0 vertex 4.0000000000000036 156.6802787010933 45.0 vertex 4.102222521132799 155.90382156578573 45.0 endloop endfacet facet normal 0.8145082464778836 0.10723204495434377 0.5701557725345178 outer loop vertex 4.0000000000000036 156.6802787010933 45.0 vertex 5.454518677937494 156.26616822892927 43.0 vertex 5.400000000000004 156.6802787010933 43.0 endloop endfacet facet normal 0.7590008555189367 0.3143884482087252 0.5701557725345173 outer loop vertex 5.614359353944901 155.8802787010933 43.0 vertex 4.102222521132799 155.90382156578573 45.0 vertex 4.401923788646688 155.1802787010933 45.0 endloop endfacet facet normal 0.7590008555189367 0.3143884482087252 0.5701557725345173 outer loop vertex 4.102222521132799 155.90382156578573 45.0 vertex 5.614359353944901 155.8802787010933 43.0 vertex 5.454518677937494 156.26616822892927 43.0 endloop endfacet facet normal 0.6517688105645938 0.5001197982691562 0.5701557725345183 outer loop vertex 5.868629150101526 155.54890785119483 43.0 vertex 4.401923788646688 155.1802787010933 45.0 vertex 4.878679656440363 154.55895835753364 45.0 endloop endfacet facet normal 0.6517688105645938 0.5001197982691562 0.5701557725345183 outer loop vertex 4.401923788646688 155.1802787010933 45.0 vertex 5.868629150101526 155.54890785119483 43.0 vertex 5.614359353944901 155.8802787010933 43.0 endloop endfacet facet normal 0.5001197982691549 0.6517688105645921 0.5701557725345212 outer loop vertex 4.878679656440363 154.55895835753364 45.0 vertex 6.200000000000001 155.2946380550382 43.0 vertex 5.868629150101526 155.54890785119483 43.0 endloop endfacet facet normal 0.5001197982691549 0.6517688105645921 0.5701557725345212 outer loop vertex 6.200000000000001 155.2946380550382 43.0 vertex 4.878679656440363 154.55895835753364 45.0 vertex 5.500000000000005 154.08220248973998 45.0 endloop endfacet facet normal 0.3143884482087233 0.759000855518934 0.5701557725345217 outer loop vertex 5.500000000000005 154.08220248973998 45.0 vertex 6.585889527835968 155.1347973790308 43.0 vertex 6.200000000000001 155.2946380550382 43.0 endloop endfacet facet normal 0.3143884482087233 0.759000855518934 0.5701557725345217 outer loop vertex 6.585889527835968 155.1347973790308 43.0 vertex 5.500000000000005 154.08220248973998 45.0 vertex 6.223542864692442 153.7825012222261 45.0 endloop endfacet facet normal 0.1072320449543412 0.8145082464778834 0.5701557725345184 outer loop vertex 6.223542864692442 153.7825012222261 45.0 vertex 7.000000000000001 155.0802787010933 43.0 vertex 6.585889527835968 155.1347973790308 43.0 endloop endfacet facet normal 0.1072320449543412 0.8145082464778834 0.5701557725345184 outer loop vertex 7.000000000000001 155.0802787010933 43.0 vertex 6.223542864692442 153.7825012222261 45.0 vertex 7.000000000000004 153.6802787010933 45.0 endloop endfacet facet normal -0.10723204495434115 0.8145082464778833 0.5701557725345188 outer loop vertex 7.000000000000004 153.6802787010933 45.0 vertex 7.414110472164035 155.1347973790308 43.0 vertex 7.000000000000001 155.0802787010933 43.0 endloop endfacet facet normal -0.10723204495434115 0.8145082464778833 0.5701557725345188 outer loop vertex 7.414110472164035 155.1347973790308 43.0 vertex 7.000000000000004 153.6802787010933 45.0 vertex 7.776457135307566 153.7825012222261 45.0 endloop endfacet facet normal -0.3143884482087233 0.7590008555189337 0.5701557725345222 outer loop vertex 7.776457135307566 153.7825012222261 45.0 vertex 7.800000000000002 155.2946380550382 43.0 vertex 7.414110472164035 155.1347973790308 43.0 endloop endfacet facet normal -0.3143884482087233 0.7590008555189337 0.5701557725345222 outer loop vertex 7.800000000000002 155.2946380550382 43.0 vertex 7.776457135307566 153.7825012222261 45.0 vertex 8.500000000000002 154.08220248973998 45.0 endloop endfacet facet normal -0.500119798269154 0.6517688105645921 0.5701557725345219 outer loop vertex 8.500000000000002 154.08220248973998 45.0 vertex 8.131370849898477 155.54890785119483 43.0 vertex 7.800000000000002 155.2946380550382 43.0 endloop endfacet facet normal -0.500119798269154 0.6517688105645921 0.5701557725345219 outer loop vertex 8.131370849898477 155.54890785119483 43.0 vertex 8.500000000000002 154.08220248973998 45.0 vertex 9.121320343559645 154.55895835753364 45.0 endloop endfacet facet normal -0.6517688105645928 0.5001197982691566 0.570155772534519 outer loop vertex 9.59807621135332 155.1802787010933 45.0 vertex 8.131370849898477 155.54890785119483 43.0 vertex 9.121320343559645 154.55895835753364 45.0 endloop endfacet facet normal -0.6517688105645928 0.5001197982691566 0.570155772534519 outer loop vertex 8.131370849898477 155.54890785119483 43.0 vertex 9.59807621135332 155.1802787010933 45.0 vertex 8.385640646055105 155.8802787010933 43.0 endloop endfacet facet normal -0.7590008555189364 0.31438844820872486 0.5701557725345177 outer loop vertex 9.897777478867207 155.90382156578573 45.0 vertex 8.385640646055105 155.8802787010933 43.0 vertex 9.59807621135332 155.1802787010933 45.0 endloop endfacet facet normal -0.7590008555189364 0.31438844820872486 0.5701557725345177 outer loop vertex 8.385640646055105 155.8802787010933 43.0 vertex 9.897777478867207 155.90382156578573 45.0 vertex 8.545481322062512 156.26616822892927 43.0 endloop endfacet facet normal -0.8145082464778834 0.10723204495434553 0.5701557725345178 outer loop vertex 10.000000000000004 156.6802787010933 45.0 vertex 8.545481322062512 156.26616822892927 43.0 vertex 9.897777478867207 155.90382156578573 45.0 endloop endfacet facet normal -0.8145082464778834 0.10723204495434553 0.5701557725345178 outer loop vertex 8.545481322062512 156.26616822892927 43.0 vertex 10.000000000000004 156.6802787010933 45.0 vertex 8.600000000000003 156.6802787010933 43.0 endloop endfacet facet normal -0.8145082464778834 -0.1072320449543445 0.570155772534518 outer loop vertex 9.897777478867209 157.45673583640084 45.0 vertex 8.600000000000003 156.6802787010933 43.0 vertex 10.000000000000004 156.6802787010933 45.0 endloop endfacet facet normal -0.8145082464778834 -0.1072320449543445 0.570155772534518 outer loop vertex 8.600000000000003 156.6802787010933 43.0 vertex 9.897777478867209 157.45673583640084 45.0 vertex 8.545481322062512 157.09438917325733 43.0 endloop endfacet facet normal -0.7590008555189369 -0.3143884482087239 0.5701557725345174 outer loop vertex 9.897777478867209 157.45673583640084 45.0 vertex 8.385640646055107 157.48027870109328 43.0 vertex 8.545481322062512 157.09438917325733 43.0 endloop endfacet facet normal -0.7590008555189369 -0.3143884482087239 0.5701557725345174 outer loop vertex 8.385640646055107 157.48027870109328 43.0 vertex 9.897777478867209 157.45673583640084 45.0 vertex 9.59807621135332 158.1802787010933 45.0 endloop endfacet facet normal -0.6517688105645941 -0.5001197982691558 0.5701557725345184 outer loop vertex 9.59807621135332 158.1802787010933 45.0 vertex 8.131370849898483 157.81164955099177 43.0 vertex 8.385640646055107 157.48027870109328 43.0 endloop endfacet facet normal -0.6517688105645941 -0.5001197982691558 0.5701557725345184 outer loop vertex 8.131370849898483 157.81164955099177 43.0 vertex 9.59807621135332 158.1802787010933 45.0 vertex 9.121320343559645 158.80159904465293 45.0 endloop endfacet facet normal -0.500119798269155 -0.6517688105645919 0.5701557725345215 outer loop vertex 9.121320343559645 158.80159904465293 45.0 vertex 7.800000000000007 158.06591934714837 43.0 vertex 8.131370849898483 157.81164955099177 43.0 endloop endfacet facet normal -0.500119798269155 -0.6517688105645919 0.5701557725345215 outer loop vertex 7.800000000000007 158.06591934714837 43.0 vertex 9.121320343559645 158.80159904465293 45.0 vertex 8.500000000000004 159.27835491244662 45.0 endloop endfacet facet normal -0.314388448208723 -0.759000855518934 0.5701557725345218 outer loop vertex 8.500000000000004 159.27835491244662 45.0 vertex 7.414110472164042 158.2257600231558 43.0 vertex 7.800000000000007 158.06591934714837 43.0 endloop endfacet facet normal -0.314388448208723 -0.759000855518934 0.5701557725345218 outer loop vertex 7.414110472164042 158.2257600231558 43.0 vertex 8.500000000000004 159.27835491244662 45.0 vertex 7.776457135307567 159.5780561799605 45.0 endloop endfacet facet normal -0.10723204495434133 -0.8145082464778834 0.5701557725345184 outer loop vertex 7.776457135307567 159.5780561799605 45.0 vertex 7.000000000000008 158.2802787010933 43.0 vertex 7.414110472164042 158.2257600231558 43.0 endloop endfacet facet normal -0.10723204495434133 -0.8145082464778834 0.5701557725345184 outer loop vertex 7.000000000000008 158.2802787010933 43.0 vertex 7.776457135307567 159.5780561799605 45.0 vertex 7.000000000000005 159.6802787010933 45.0 endloop endfacet facet normal 0.10723204495434108 -0.8145082464778833 0.5701557725345187 outer loop vertex 7.000000000000005 159.6802787010933 45.0 vertex 6.585889527835975 158.2257600231558 43.0 vertex 7.000000000000008 158.2802787010933 43.0 endloop endfacet facet normal 0.10723204495434108 -0.8145082464778833 0.5701557725345187 outer loop vertex 6.585889527835975 158.2257600231558 43.0 vertex 7.000000000000005 159.6802787010933 45.0 vertex 6.223542864692443 159.5780561799605 45.0 endloop endfacet facet normal 0.3143884482087229 -0.7590008555189337 0.5701557725345224 outer loop vertex 6.223542864692443 159.5780561799605 45.0 vertex 6.200000000000008 158.06591934714837 43.0 vertex 6.585889527835975 158.2257600231558 43.0 endloop endfacet facet normal 0.3143884482087229 -0.7590008555189337 0.5701557725345224 outer loop vertex 6.200000000000008 158.06591934714837 43.0 vertex 6.223542864692443 159.5780561799605 45.0 vertex 5.500000000000004 159.27835491244662 45.0 endloop endfacet facet normal 0.500119798269154 -0.6517688105645917 0.5701557725345225 outer loop vertex 5.500000000000004 159.27835491244662 45.0 vertex 5.868629150101532 157.81164955099177 43.0 vertex 6.200000000000008 158.06591934714837 43.0 endloop endfacet facet normal 0.500119798269154 -0.6517688105645917 0.5701557725345225 outer loop vertex 5.868629150101532 157.81164955099177 43.0 vertex 5.500000000000004 159.27835491244662 45.0 vertex 4.878679656440362 158.80159904465293 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.4000000000000075 273.6802787010933 43.0 vertex 5.4000000000000075 273.6802787010933 43.0 vertex 5.4323523811881955 273.43453796862667 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.000000000000004 275.2802787010933 43.0 vertex 7.414110472164036 275.22576002315583 43.0 vertex 7.414110472164036 275.22576002315583 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.8000000000000025 275.0659193471484 43.0 vertex 7.414110472164036 275.22576002315583 43.0 vertex 7.414110472164036 275.22576002315583 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.8000000000000025 275.0659193471484 43.0 vertex 7.8000000000000025 275.0659193471484 43.0 vertex 7.414110472164036 275.22576002315583 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.131370849898477 274.8116495509918 43.0 vertex 7.8000000000000025 275.0659193471484 43.0 vertex 7.8000000000000025 275.0659193471484 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.131370849898477 274.8116495509918 43.0 vertex 8.131370849898477 274.8116495509918 43.0 vertex 7.8000000000000025 275.0659193471484 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.385640646055103 274.4802787010933 43.0 vertex 8.131370849898477 274.8116495509918 43.0 vertex 8.131370849898477 274.8116495509918 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.385640646055103 274.4802787010933 43.0 vertex 8.385640646055103 274.4802787010933 43.0 vertex 8.131370849898477 274.8116495509918 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.421817538420019 274.3929311734118 42.99999871850014 vertex 8.385640646055103 274.4802787010933 43.0 vertex 8.385640646055103 274.4802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.579497281350482 272.9644431895632 43.0 vertex 5.6143593539449 272.88027870109335 43.0 vertex 5.6143593539449 272.88027870109335 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.868629150101526 272.5489078511949 43.0 vertex 5.6143593539449 272.88027870109335 43.0 vertex 5.6143593539449 272.88027870109335 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.868629150101526 272.5489078511949 43.0 vertex 5.868629150101526 272.5489078511949 43.0 vertex 5.6143593539449 272.88027870109335 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.200000000000001 272.2946380550382 43.0 vertex 5.868629150101526 272.5489078511949 43.0 vertex 5.868629150101526 272.5489078511949 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.200000000000001 272.2946380550382 43.0 vertex 6.200000000000001 272.2946380550382 43.0 vertex 5.868629150101526 272.5489078511949 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.585889527835968 272.13479737903083 43.0 vertex 6.200000000000001 272.2946380550382 43.0 vertex 6.200000000000001 272.2946380550382 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.585889527835968 272.13479737903083 43.0 vertex 6.585889527835968 272.13479737903083 43.0 vertex 6.200000000000001 272.2946380550382 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.000000000000004 272.08027870109333 43.0 vertex 6.585889527835968 272.13479737903083 43.0 vertex 6.585889527835968 272.13479737903083 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 7.414110472164038 272.13479737903083 43.0 vertex 7.800000000000004 272.2946380550382 43.0 vertex 7.800000000000004 272.2946380550382 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.131370849898477 272.5489078511949 43.0 vertex 7.800000000000004 272.2946380550382 43.0 vertex 7.800000000000004 272.2946380550382 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.131370849898477 272.5489078511949 43.0 vertex 7.800000000000004 272.2946380550382 43.0 vertex 8.131370849898477 272.5489078511949 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.385640646055105 272.88027870109335 43.0 vertex 8.131370849898477 272.5489078511949 43.0 vertex 8.131370849898477 272.5489078511949 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.385640646055105 272.88027870109335 43.0 vertex 8.131370849898477 272.5489078511949 43.0 vertex 8.385640646055105 272.88027870109335 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.545481322062512 273.2661682289293 43.0 vertex 8.385640646055105 272.88027870109335 43.0 vertex 8.385640646055105 272.88027870109335 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.545481322062512 273.2661682289293 43.0 vertex 8.385640646055105 272.88027870109335 43.0 vertex 8.545481322062512 273.2661682289293 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.600000000000001 273.6802787010933 43.0 vertex 8.545481322062512 273.2661682289293 43.0 vertex 8.545481322062512 273.2661682289293 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.600000000000001 273.6802787010933 43.0 vertex 8.545481322062512 273.2661682289293 43.0 vertex 8.600000000000001 273.6802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 8.600000000000001 273.6802787010933 43.0 vertex 8.566062168763638 273.9380520191845 42.99999871850014 vertex 8.600000000000001 273.6802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.4000000000000075 273.6802787010933 43.0 vertex 5.454518677937495 274.09438917325735 43.0 vertex 5.4000000000000075 273.6802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.454518677937495 274.09438917325735 43.0 vertex 5.4000000000000075 273.6802787010933 43.0 vertex 5.454518677937495 274.09438917325735 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.614359353944902 274.4802787010933 43.0 vertex 5.454518677937495 274.09438917325735 43.0 vertex 5.454518677937495 274.09438917325735 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.614359353944902 274.4802787010933 43.0 vertex 5.454518677937495 274.09438917325735 43.0 vertex 5.614359353944902 274.4802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.868629150101529 274.8116495509918 43.0 vertex 5.614359353944902 274.4802787010933 43.0 vertex 5.614359353944902 274.4802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 5.868629150101529 274.8116495509918 43.0 vertex 5.614359353944902 274.4802787010933 43.0 vertex 5.868629150101529 274.8116495509918 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.200000000000004 275.06591934714845 43.0 vertex 5.868629150101529 274.8116495509918 43.0 vertex 5.868629150101529 274.8116495509918 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.200000000000004 275.06591934714845 43.0 vertex 5.868629150101529 274.8116495509918 43.0 vertex 6.200000000000004 275.06591934714845 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 6.58588952783597 275.22576002315583 43.0 vertex 6.200000000000004 275.06591934714845 43.0 vertex 6.200000000000004 275.06591934714845 43.0 endloop endfacet facet normal 0.10723204495433157 0.8145082464778868 0.5701557725345155 outer loop vertex 6.2235428646924404 270.78250122222613 45.0 vertex 7.000000000000004 272.08027870109333 43.0 vertex 6.585889527835968 272.13479737903083 43.0 endloop endfacet facet normal 0.10723204495433157 0.8145082464778868 0.5701557725345155 outer loop vertex 7.000000000000004 272.08027870109333 43.0 vertex 6.2235428646924404 270.78250122222613 45.0 vertex 7.000000000000004 270.68027870109336 45.0 endloop endfacet facet normal -0.10723204495433171 0.8145082464778868 0.5701557725345154 outer loop vertex 7.000000000000004 270.68027870109336 45.0 vertex 7.414110472164038 272.13479737903083 43.0 vertex 7.000000000000004 272.08027870109333 43.0 endloop endfacet facet normal -0.10723204495433171 0.8145082464778868 0.5701557725345154 outer loop vertex 7.414110472164038 272.13479737903083 43.0 vertex 7.000000000000004 270.68027870109336 45.0 vertex 7.776457135307566 270.78250122222613 45.0 endloop endfacet facet normal -0.3143884482087337 0.7590008555189383 0.5701557725345102 outer loop vertex 7.776457135307566 270.78250122222613 45.0 vertex 7.800000000000004 272.2946380550382 43.0 vertex 7.414110472164038 272.13479737903083 43.0 endloop endfacet facet normal -0.3143884482087337 0.7590008555189383 0.5701557725345102 outer loop vertex 7.800000000000004 272.2946380550382 43.0 vertex 7.776457135307566 270.78250122222613 45.0 vertex 8.500000000000002 271.08220248974004 45.0 endloop endfacet facet normal -0.5001197982691599 0.6517688105645947 0.5701557725345141 outer loop vertex 8.500000000000002 271.08220248974004 45.0 vertex 8.13137084989848 272.5489078511949 43.0 vertex 7.800000000000004 272.2946380550382 43.0 endloop endfacet facet normal -0.5001197982691599 0.6517688105645947 0.5701557725345141 outer loop vertex 8.13137084989848 272.5489078511949 43.0 vertex 8.500000000000002 271.08220248974004 45.0 vertex 9.121320343559644 271.5589583575337 45.0 endloop endfacet facet normal -0.6517688105645868 0.5001197982691635 0.5701557725345199 outer loop vertex 9.598076211353316 272.1802787010933 45.0 vertex 8.13137084989848 272.5489078511949 43.0 vertex 9.121320343559644 271.5589583575337 45.0 endloop endfacet facet normal -0.6517688105645868 0.5001197982691635 0.5701557725345199 outer loop vertex 8.13137084989848 272.5489078511949 43.0 vertex 9.598076211353316 272.1802787010933 45.0 vertex 8.385640646055105 272.88027870109335 43.0 endloop endfacet facet normal -0.7590008555189387 0.3143884482087215 0.5701557725345163 outer loop vertex 9.897777478867203 272.9038215657858 45.0 vertex 8.385640646055105 272.88027870109335 43.0 vertex 9.598076211353316 272.1802787010933 45.0 endloop endfacet facet normal -0.7590008555189387 0.3143884482087215 0.5701557725345163 outer loop vertex 8.385640646055105 272.88027870109335 43.0 vertex 9.897777478867203 272.9038215657858 45.0 vertex 8.545481322062514 273.26616822892925 43.0 endloop endfacet facet normal -0.8145082464778852 0.10723204495434287 0.5701557725345158 outer loop vertex 9.999999999999998 273.6802787010933 45.0 vertex 8.545481322062514 273.26616822892925 43.0 vertex 9.897777478867203 272.9038215657858 45.0 endloop endfacet facet normal -0.8145082464778852 0.10723204495434287 0.5701557725345158 outer loop vertex 8.545481322062514 273.26616822892925 43.0 vertex 9.999999999999998 273.6802787010933 45.0 vertex 8.600000000000003 273.6802787010933 43.0 endloop endfacet facet normal -0.8145082464778841 -0.10723204495434525 0.5701557725345167 outer loop vertex 9.897777478867203 274.45673583640087 45.0 vertex 8.600000000000003 273.6802787010933 43.0 vertex 9.999999999999998 273.6802787010933 45.0 endloop endfacet facet normal -0.8145082464778841 -0.10723204495434525 0.5701557725345167 outer loop vertex 8.600000000000003 273.6802787010933 43.0 vertex 9.897777478867203 274.45673583640087 45.0 vertex 8.545481322062514 274.09438917325735 43.0 endloop endfacet facet normal -0.7590008555189366 -0.31438844820872697 0.5701557725345162 outer loop vertex 9.897777478867203 274.45673583640087 45.0 vertex 8.385640646055107 274.4802787010933 43.0 vertex 8.545481322062514 274.09438917325735 43.0 endloop endfacet facet normal -0.7590008555189366 -0.31438844820872697 0.5701557725345162 outer loop vertex 8.385640646055107 274.4802787010933 43.0 vertex 9.897777478867203 274.45673583640087 45.0 vertex 9.598076211353316 275.1802787010933 45.0 endloop endfacet facet normal -0.6517688105646025 -0.5001197982691475 0.570155772534516 outer loop vertex 9.598076211353316 275.1802787010933 45.0 vertex 8.131370849898481 274.8116495509918 43.0 vertex 8.385640646055107 274.4802787010933 43.0 endloop endfacet facet normal -0.6517688105646025 -0.5001197982691475 0.570155772534516 outer loop vertex 8.131370849898481 274.8116495509918 43.0 vertex 9.598076211353316 275.1802787010933 45.0 vertex 9.121320343559644 275.80159904465296 45.0 endloop endfacet facet normal -0.5001197982691598 -0.6517688105645948 0.5701557725345141 outer loop vertex 9.121320343559644 275.80159904465296 45.0 vertex 7.800000000000004 275.06591934714845 43.0 vertex 8.131370849898481 274.8116495509918 43.0 endloop endfacet facet normal -0.5001197982691598 -0.6517688105645948 0.5701557725345141 outer loop vertex 7.800000000000004 275.06591934714845 43.0 vertex 9.121320343559644 275.80159904465296 45.0 vertex 8.500000000000004 276.2783549124466 45.0 endloop endfacet facet normal -0.31438844820873346 -0.7590008555189383 0.5701557725345104 outer loop vertex 8.500000000000004 276.2783549124466 45.0 vertex 7.414110472164038 275.22576002315583 43.0 vertex 7.800000000000004 275.06591934714845 43.0 endloop endfacet facet normal -0.31438844820873346 -0.7590008555189383 0.5701557725345104 outer loop vertex 7.414110472164038 275.22576002315583 43.0 vertex 8.500000000000004 276.2783549124466 45.0 vertex 7.776457135307566 276.5780561799605 45.0 endloop endfacet facet normal -0.10723204495433189 -0.8145082464778868 0.5701557725345155 outer loop vertex 7.776457135307566 276.5780561799605 45.0 vertex 7.000000000000004 275.2802787010933 43.0 vertex 7.414110472164038 275.22576002315583 43.0 endloop endfacet facet normal -0.10723204495433189 -0.8145082464778868 0.5701557725345155 outer loop vertex 7.000000000000004 275.2802787010933 43.0 vertex 7.776457135307566 276.5780561799605 45.0 vertex 7.000000000000004 276.6802787010933 45.0 endloop endfacet facet normal 0.10723204495433196 -0.8145082464778868 0.5701557725345154 outer loop vertex 7.000000000000004 276.6802787010933 45.0 vertex 6.58588952783597 275.22576002315583 43.0 vertex 7.000000000000004 275.2802787010933 43.0 endloop endfacet facet normal 0.10723204495433196 -0.8145082464778868 0.5701557725345154 outer loop vertex 6.58588952783597 275.22576002315583 43.0 vertex 7.000000000000004 276.6802787010933 45.0 vertex 6.223542864692444 276.5780561799605 45.0 endloop endfacet facet normal 0.3143884482087337 -0.7590008555189385 0.5701557725345103 outer loop vertex 6.223542864692444 276.5780561799605 45.0 vertex 6.200000000000004 275.06591934714845 43.0 vertex 6.58588952783597 275.22576002315583 43.0 endloop endfacet facet normal 0.3143884482087337 -0.7590008555189385 0.5701557725345103 outer loop vertex 6.200000000000004 275.06591934714845 43.0 vertex 6.223542864692444 276.5780561799605 45.0 vertex 5.500000000000007 276.2783549124466 45.0 endloop endfacet facet normal 0.5001197982691599 -0.6517688105645949 0.5701557725345138 outer loop vertex 5.500000000000007 276.2783549124466 45.0 vertex 5.868629150101529 274.8116495509918 43.0 vertex 6.200000000000004 275.06591934714845 43.0 endloop endfacet facet normal 0.5001197982691599 -0.6517688105645949 0.5701557725345138 outer loop vertex 5.868629150101529 274.8116495509918 43.0 vertex 5.500000000000007 276.2783549124466 45.0 vertex 4.878679656440366 275.80159904465296 45.0 endloop endfacet facet normal 0.6517688105645866 -0.5001197982691641 0.5701557725345194 outer loop vertex 5.868629150101529 274.8116495509918 43.0 vertex 4.401923788646694 275.18027870109336 45.0 vertex 5.614359353944902 274.4802787010933 43.0 endloop endfacet facet normal 0.6517688105645866 -0.5001197982691641 0.5701557725345194 outer loop vertex 4.401923788646694 275.18027870109336 45.0 vertex 5.868629150101529 274.8116495509918 43.0 vertex 4.878679656440366 275.80159904465296 45.0 endloop endfacet facet normal 0.7590008555189389 -0.31438844820872164 0.5701557725345161 outer loop vertex 5.614359353944902 274.4802787010933 43.0 vertex 4.102222521132805 274.45673583640087 45.0 vertex 5.454518677937495 274.09438917325735 43.0 endloop endfacet facet normal 0.7590008555189389 -0.31438844820872164 0.5701557725345161 outer loop vertex 4.102222521132805 274.45673583640087 45.0 vertex 5.614359353944902 274.4802787010933 43.0 vertex 4.401923788646694 275.18027870109336 45.0 endloop endfacet facet normal 0.8145082464778852 -0.10723204495434348 0.5701557725345159 outer loop vertex 5.454518677937495 274.09438917325735 43.0 vertex 4.00000000000001 273.6802787010933 45.0 vertex 5.400000000000004 273.6802787010933 43.0 endloop endfacet facet normal 0.8145082464778852 -0.10723204495434348 0.5701557725345159 outer loop vertex 4.00000000000001 273.6802787010933 45.0 vertex 5.454518677937495 274.09438917325735 43.0 vertex 4.102222521132805 274.45673583640087 45.0 endloop endfacet facet normal 0.8145082464778842 0.10723204495434531 0.5701557725345167 outer loop vertex 5.454518677937495 273.2661682289293 43.0 vertex 4.00000000000001 273.6802787010933 45.0 vertex 4.102222521132804 272.9038215657858 45.0 endloop endfacet facet normal 0.8145082464778842 0.10723204495434531 0.5701557725345167 outer loop vertex 4.00000000000001 273.6802787010933 45.0 vertex 5.454518677937495 273.2661682289293 43.0 vertex 5.400000000000004 273.6802787010933 43.0 endloop endfacet facet normal 0.7590008555189366 0.31438844820872675 0.5701557725345162 outer loop vertex 5.6143593539449 272.88027870109335 43.0 vertex 4.102222521132804 272.9038215657858 45.0 vertex 4.401923788646692 272.18027870109336 45.0 endloop endfacet facet normal 0.7590008555189366 0.31438844820872675 0.5701557725345162 outer loop vertex 4.102222521132804 272.9038215657858 45.0 vertex 5.6143593539449 272.88027870109335 43.0 vertex 5.454518677937495 273.2661682289293 43.0 endloop endfacet facet normal 0.6517688105646027 0.5001197982691478 0.5701557725345154 outer loop vertex 5.868629150101526 272.5489078511949 43.0 vertex 4.401923788646692 272.18027870109336 45.0 vertex 4.878679656440364 271.5589583575337 45.0 endloop endfacet facet normal 0.6517688105646027 0.5001197982691478 0.5701557725345154 outer loop vertex 4.401923788646692 272.18027870109336 45.0 vertex 5.868629150101526 272.5489078511949 43.0 vertex 5.6143593539449 272.88027870109335 43.0 endloop endfacet facet normal 0.5001197982691589 0.6517688105645959 0.5701557725345135 outer loop vertex 4.878679656440364 271.5589583575337 45.0 vertex 6.200000000000001 272.2946380550382 43.0 vertex 5.868629150101526 272.5489078511949 43.0 endloop endfacet facet normal 0.5001197982691589 0.6517688105645959 0.5701557725345135 outer loop vertex 6.200000000000001 272.2946380550382 43.0 vertex 4.878679656440364 271.5589583575337 45.0 vertex 5.500000000000005 271.08220248974004 45.0 endloop endfacet facet normal 0.31438844820873374 0.7590008555189384 0.57015577253451 outer loop vertex 5.500000000000005 271.08220248974004 45.0 vertex 6.585889527835968 272.13479737903083 43.0 vertex 6.200000000000001 272.2946380550382 43.0 endloop endfacet facet normal 0.31438844820873374 0.7590008555189384 0.57015577253451 outer loop vertex 6.585889527835968 272.13479737903083 43.0 vertex 5.500000000000005 271.08220248974004 45.0 vertex 6.2235428646924404 270.78250122222613 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 167.9 273.6802787010933 43.0 vertex 167.9545186779375 273.26616822892925 43.0 vertex 167.9545186779375 273.26616822892925 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 168.1143593539449 272.88027870109335 43.0 vertex 167.9545186779375 273.26616822892925 43.0 vertex 167.9545186779375 273.26616822892925 43.0 endloop endfacet facet normal 0.10723204495433239 -0.8145082464778868 0.5701557725345153 outer loop vertex 169.5 276.6802787010933 45.0 vertex 169.08588952783597 275.22576002315583 43.0 vertex 169.5 275.2802787010933 43.0 endloop endfacet facet normal 0.10723204495433239 -0.8145082464778868 0.5701557725345153 outer loop vertex 169.08588952783597 275.22576002315583 43.0 vertex 169.5 276.6802787010933 45.0 vertex 168.72354286469246 276.5780561799605 45.0 endloop endfacet facet normal 0.314388448208748 -0.7590008555189284 0.5701557725345159 outer loop vertex 168.72354286469246 276.5780561799605 45.0 vertex 168.70000000000002 275.0659193471484 43.0 vertex 169.08588952783597 275.22576002315583 43.0 endloop endfacet facet normal 0.314388448208748 -0.7590008555189284 0.5701557725345159 outer loop vertex 168.70000000000002 275.0659193471484 43.0 vertex 168.72354286469246 276.5780561799605 45.0 vertex 168.0 276.2783549124466 45.0 endloop endfacet facet normal 0.5001197982691413 -0.6517688105646033 0.5701557725345202 outer loop vertex 168.0 276.2783549124466 45.0 vertex 168.36862915010153 274.8116495509918 43.0 vertex 168.70000000000002 275.0659193471484 43.0 endloop endfacet facet normal 0.5001197982691413 -0.6517688105646033 0.5701557725345202 outer loop vertex 168.36862915010153 274.8116495509918 43.0 vertex 168.0 276.2783549124466 45.0 vertex 167.37867965644037 275.80159904465296 45.0 endloop endfacet facet normal 0.6517688105645919 -0.5001197982691571 0.5701557725345197 outer loop vertex 168.36862915010153 274.8116495509918 43.0 vertex 166.9019237886467 275.18027870109336 45.0 vertex 168.1143593539449 274.4802787010933 43.0 endloop endfacet facet normal 0.6517688105645919 -0.5001197982691571 0.5701557725345197 outer loop vertex 166.9019237886467 275.18027870109336 45.0 vertex 168.36862915010153 274.8116495509918 43.0 vertex 167.37867965644037 275.80159904465296 45.0 endloop endfacet facet normal 0.7590008555189364 -0.31438844820872813 0.5701557725345159 outer loop vertex 168.1143593539449 274.4802787010933 43.0 vertex 166.6022225211328 274.45673583640087 45.0 vertex 167.9545186779375 274.09438917325735 43.0 endloop endfacet facet normal 0.7590008555189364 -0.31438844820872813 0.5701557725345159 outer loop vertex 166.6022225211328 274.45673583640087 45.0 vertex 168.1143593539449 274.4802787010933 43.0 vertex 166.9019237886467 275.18027870109336 45.0 endloop endfacet facet normal 0.8145082464778839 -0.10723204495434056 0.5701557725345181 outer loop vertex 167.9545186779375 274.09438917325735 43.0 vertex 166.5 273.6802787010933 45.0 vertex 167.9 273.6802787010933 43.0 endloop endfacet facet normal 0.8145082464778839 -0.10723204495434056 0.5701557725345181 outer loop vertex 166.5 273.6802787010933 45.0 vertex 167.9545186779375 274.09438917325735 43.0 vertex 166.6022225211328 274.45673583640087 45.0 endloop endfacet facet normal 0.8145082464778839 0.10723204495434056 0.5701557725345181 outer loop vertex 167.9545186779375 273.26616822892925 43.0 vertex 166.5 273.6802787010933 45.0 vertex 166.6022225211328 272.9038215657858 45.0 endloop endfacet facet normal 0.8145082464778839 0.10723204495434056 0.5701557725345181 outer loop vertex 166.5 273.6802787010933 45.0 vertex 167.9545186779375 273.26616822892925 43.0 vertex 167.9 273.6802787010933 43.0 endloop endfacet facet normal 0.7590008555189326 0.3143884482087416 0.5701557725345137 outer loop vertex 168.1143593539449 272.88027870109335 43.0 vertex 166.6022225211328 272.9038215657858 45.0 vertex 166.9019237886467 272.18027870109336 45.0 endloop endfacet facet normal 0.7590008555189326 0.3143884482087416 0.5701557725345137 outer loop vertex 166.6022225211328 272.9038215657858 45.0 vertex 168.1143593539449 272.88027870109335 43.0 vertex 167.9545186779375 273.26616822892925 43.0 endloop endfacet facet normal 0.6517688105646079 0.5001197982691405 0.5701557725345158 outer loop vertex 168.36862915010153 272.5489078511949 43.0 vertex 166.9019237886467 272.18027870109336 45.0 vertex 167.37867965644037 271.5589583575337 45.0 endloop endfacet facet normal 0.6517688105646079 0.5001197982691405 0.5701557725345158 outer loop vertex 166.9019237886467 272.18027870109336 45.0 vertex 168.36862915010153 272.5489078511949 43.0 vertex 168.1143593539449 272.88027870109335 43.0 endloop endfacet facet normal 0.500119798269142 0.6517688105646029 0.5701557725345203 outer loop vertex 167.37867965644037 271.5589583575337 45.0 vertex 168.70000000000002 272.29463805503826 43.0 vertex 168.36862915010153 272.5489078511949 43.0 endloop endfacet facet normal 0.500119798269142 0.6517688105646029 0.5701557725345203 outer loop vertex 168.70000000000002 272.29463805503826 43.0 vertex 167.37867965644037 271.5589583575337 45.0 vertex 168.0 271.08220248974004 45.0 endloop endfacet facet normal 0.3143884482087478 0.7590008555189283 0.5701557725345158 outer loop vertex 168.0 271.08220248974004 45.0 vertex 169.08588952783597 272.13479737903083 43.0 vertex 168.70000000000002 272.29463805503826 43.0 endloop endfacet facet normal 0.3143884482087478 0.7590008555189283 0.5701557725345158 outer loop vertex 169.08588952783597 272.13479737903083 43.0 vertex 168.0 271.08220248974004 45.0 vertex 168.72354286469246 270.78250122222613 45.0 endloop endfacet facet normal 0.10723204495433229 0.8145082464778868 0.5701557725345154 outer loop vertex 168.72354286469246 270.78250122222613 45.0 vertex 169.5 272.08027870109333 43.0 vertex 169.08588952783597 272.13479737903083 43.0 endloop endfacet facet normal 0.10723204495433229 0.8145082464778868 0.5701557725345154 outer loop vertex 169.5 272.08027870109333 43.0 vertex 168.72354286469246 270.78250122222613 45.0 vertex 169.5 270.68027870109336 45.0 endloop endfacet facet normal -0.10723204495433221 0.8145082464778868 0.5701557725345153 outer loop vertex 169.5 270.68027870109336 45.0 vertex 169.91411047216403 272.13479737903083 43.0 vertex 169.5 272.08027870109333 43.0 endloop endfacet facet normal -0.10723204495433221 0.8145082464778868 0.5701557725345153 outer loop vertex 169.91411047216403 272.13479737903083 43.0 vertex 169.5 270.68027870109336 45.0 vertex 170.27645713530757 270.78250122222613 45.0 endloop endfacet facet normal -0.314388448208748 0.7590008555189284 0.5701557725345159 outer loop vertex 170.27645713530757 270.78250122222613 45.0 vertex 170.3 272.29463805503826 43.0 vertex 169.91411047216403 272.13479737903083 43.0 endloop endfacet facet normal -0.314388448208748 0.7590008555189284 0.5701557725345159 outer loop vertex 170.3 272.29463805503826 43.0 vertex 170.27645713530757 270.78250122222613 45.0 vertex 171.0 271.08220248974004 45.0 endloop endfacet facet normal -0.5001197982691415 0.6517688105646033 0.5701557725345203 outer loop vertex 171.0 271.08220248974004 45.0 vertex 170.63137084989847 272.5489078511949 43.0 vertex 170.3 272.29463805503826 43.0 endloop endfacet facet normal -0.5001197982691415 0.6517688105646033 0.5701557725345203 outer loop vertex 170.63137084989847 272.5489078511949 43.0 vertex 171.0 271.08220248974004 45.0 vertex 171.62132034355966 271.5589583575337 45.0 endloop endfacet facet normal -0.6517688105645923 0.5001197982691565 0.5701557725345198 outer loop vertex 172.09807621135332 272.1802787010933 45.0 vertex 170.63137084989847 272.5489078511949 43.0 vertex 171.62132034355966 271.5589583575337 45.0 endloop endfacet facet normal -0.6517688105645923 0.5001197982691565 0.5701557725345198 outer loop vertex 170.63137084989847 272.5489078511949 43.0 vertex 172.09807621135332 272.1802787010933 45.0 vertex 170.88564064605512 272.88027870109335 43.0 endloop endfacet facet normal -0.7590008555189364 0.31438844820872813 0.5701557725345159 outer loop vertex 172.3977774788672 272.9038215657858 45.0 vertex 170.88564064605512 272.88027870109335 43.0 vertex 172.09807621135332 272.1802787010933 45.0 endloop endfacet facet normal -0.7590008555189364 0.31438844820872813 0.5701557725345159 outer loop vertex 170.88564064605512 272.88027870109335 43.0 vertex 172.3977774788672 272.9038215657858 45.0 vertex 171.0454813220625 273.26616822892925 43.0 endloop endfacet facet normal -0.8145082464778839 0.10723204495434056 0.5701557725345181 outer loop vertex 172.5 273.6802787010933 45.0 vertex 171.0454813220625 273.26616822892925 43.0 vertex 172.3977774788672 272.9038215657858 45.0 endloop endfacet facet normal -0.8145082464778839 0.10723204495434056 0.5701557725345181 outer loop vertex 171.0454813220625 273.26616822892925 43.0 vertex 172.5 273.6802787010933 45.0 vertex 171.1 273.6802787010933 43.0 endloop endfacet facet normal -0.8145082464778838 -0.10723204495434063 0.5701557725345182 outer loop vertex 172.3977774788672 274.45673583640087 45.0 vertex 171.1 273.6802787010933 43.0 vertex 172.5 273.6802787010933 45.0 endloop endfacet facet normal -0.8145082464778838 -0.10723204495434063 0.5701557725345182 outer loop vertex 171.1 273.6802787010933 43.0 vertex 172.3977774788672 274.45673583640087 45.0 vertex 171.0454813220625 274.09438917325735 43.0 endloop endfacet facet normal -0.7590008555189326 -0.3143884482087416 0.5701557725345137 outer loop vertex 172.3977774788672 274.45673583640087 45.0 vertex 170.88564064605512 274.4802787010933 43.0 vertex 171.0454813220625 274.09438917325735 43.0 endloop endfacet facet normal -0.7590008555189326 -0.3143884482087416 0.5701557725345137 outer loop vertex 170.88564064605512 274.4802787010933 43.0 vertex 172.3977774788672 274.45673583640087 45.0 vertex 172.09807621135332 275.1802787010933 45.0 endloop endfacet facet normal -0.6517688105646079 -0.5001197982691405 0.5701557725345158 outer loop vertex 172.09807621135332 275.1802787010933 45.0 vertex 170.63137084989847 274.8116495509918 43.0 vertex 170.88564064605512 274.4802787010933 43.0 endloop endfacet facet normal -0.6517688105646079 -0.5001197982691405 0.5701557725345158 outer loop vertex 170.63137084989847 274.8116495509918 43.0 vertex 172.09807621135332 275.1802787010933 45.0 vertex 171.62132034355966 275.80159904465296 45.0 endloop endfacet facet normal -0.5001197982691418 -0.651768810564603 0.5701557725345203 outer loop vertex 171.62132034355966 275.80159904465296 45.0 vertex 170.3 275.0659193471484 43.0 vertex 170.63137084989847 274.8116495509918 43.0 endloop endfacet facet normal -0.5001197982691418 -0.651768810564603 0.5701557725345203 outer loop vertex 170.3 275.0659193471484 43.0 vertex 171.62132034355966 275.80159904465296 45.0 vertex 171.0 276.2783549124466 45.0 endloop endfacet facet normal -0.3143884482087476 -0.7590008555189285 0.5701557725345159 outer loop vertex 171.0 276.2783549124466 45.0 vertex 169.91411047216403 275.22576002315583 43.0 vertex 170.3 275.0659193471484 43.0 endloop endfacet facet normal -0.3143884482087476 -0.7590008555189285 0.5701557725345159 outer loop vertex 169.91411047216403 275.22576002315583 43.0 vertex 171.0 276.2783549124466 45.0 vertex 170.27645713530757 276.5780561799605 45.0 endloop endfacet facet normal -0.10723204495433229 -0.8145082464778868 0.5701557725345154 outer loop vertex 170.27645713530757 276.5780561799605 45.0 vertex 169.5 275.2802787010933 43.0 vertex 169.91411047216403 275.22576002315583 43.0 endloop endfacet facet normal -0.10723204495433229 -0.8145082464778868 0.5701557725345154 outer loop vertex 169.5 275.2802787010933 43.0 vertex 170.27645713530757 276.5780561799605 45.0 vertex 169.5 276.6802787010933 45.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.3856406460551 274.4802787010933 43.0 vertex 333.3856406460551 274.4802787010933 43.0 vertex 333.1313708498985 274.8116495509918 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.3856406460551 274.4802787010933 43.0 vertex 333.3856406460551 274.4802787010933 43.0 vertex 333.49866507003503 274.20741360384153 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.38564064605515 272.88027870109335 43.0 vertex 333.38564064605515 272.88027870109335 43.0 vertex 333.1313708498985 272.5489078511949 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.38564064605515 272.88027870109335 43.0 vertex 333.38564064605515 272.88027870109335 43.0 vertex 333.5454813220625 273.2661682289293 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.8 275.0659193471484 43.0 vertex 332.8 275.0659193471484 43.0 vertex 332.41411047216405 275.22576002315583 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.8 275.0659193471484 43.0 vertex 332.8 275.0659193471484 43.0 vertex 333.1313708498985 274.8116495509918 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.8 272.2946380550382 43.0 vertex 332.8 272.2946380550382 43.0 vertex 332.5271349027482 272.18161363105827 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 332.8 272.2946380550382 43.0 vertex 332.8 272.2946380550382 43.0 vertex 333.1313708498985 272.5489078511949 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 331.20000000000005 275.0659193471484 43.0 vertex 331.20000000000005 275.0659193471484 43.0 vertex 330.8686291501015 274.8116495509918 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 331.20000000000005 275.0659193471484 43.0 vertex 331.20000000000005 275.0659193471484 43.0 vertex 331.4728650972518 275.1789437711284 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 331.20000000000005 272.2946380550382 43.0 vertex 331.20000000000005 272.2946380550382 43.0 vertex 330.8686291501015 272.5489078511949 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 331.20000000000005 272.2946380550382 43.0 vertex 331.20000000000005 272.2946380550382 43.0 vertex 331.4728650972518 272.18161363105827 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.61435935394496 274.4802787010933 43.0 vertex 330.61435935394496 274.4802787010933 43.0 vertex 330.50133492996497 274.20741360384153 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.61435935394496 274.4802787010933 43.0 vertex 330.61435935394496 274.4802787010933 43.0 vertex 330.8686291501015 274.8116495509918 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.6143593539449 272.88027870109335 43.0 vertex 330.6143593539449 272.88027870109335 43.0 vertex 330.50133492996497 273.1531437983451 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.6143593539449 272.88027870109335 43.0 vertex 330.6143593539449 272.88027870109335 43.0 vertex 330.8686291501015 272.5489078511949 43.0 endloop endfacet facet normal 0.7590008555189374 0.31438844820873585 0.5701557725345102 outer loop vertex 330.6143593539449 272.88027870109335 43.0 vertex 329.10222252113283 272.9038215657858 45.0 vertex 329.40192378864674 272.18027870109336 45.0 endloop endfacet facet normal 0.7590008555189374 0.31438844820873585 0.5701557725345102 outer loop vertex 329.10222252113283 272.9038215657858 45.0 vertex 330.6143593539449 272.88027870109335 43.0 vertex 330.4545186779375 273.2661682289293 43.0 endloop endfacet facet normal 0.6517688105646045 0.5001197982691478 0.5701557725345133 outer loop vertex 330.8686291501015 272.5489078511949 43.0 vertex 329.40192378864674 272.18027870109336 45.0 vertex 329.8786796564404 271.5589583575337 45.0 endloop endfacet facet normal 0.6517688105646045 0.5001197982691478 0.5701557725345133 outer loop vertex 329.40192378864674 272.18027870109336 45.0 vertex 330.8686291501015 272.5489078511949 43.0 vertex 330.6143593539449 272.88027870109335 43.0 endloop endfacet facet normal 0.500119798269164 0.6517688105645887 0.5701557725345172 outer loop vertex 329.8786796564404 271.5589583575337 45.0 vertex 331.20000000000005 272.2946380550382 43.0 vertex 330.8686291501015 272.5489078511949 43.0 endloop endfacet facet normal 0.500119798269164 0.6517688105645887 0.5701557725345172 outer loop vertex 331.20000000000005 272.2946380550382 43.0 vertex 329.8786796564404 271.5589583575337 45.0 vertex 330.5 271.08220248974004 45.0 endloop endfacet facet normal 0.31438844820872186 0.7590008555189416 0.5701557725345127 outer loop vertex 330.5 271.08220248974004 45.0 vertex 331.585889527836 272.13479737903083 43.0 vertex 331.20000000000005 272.2946380550382 43.0 endloop endfacet facet normal 0.31438844820872186 0.7590008555189416 0.5701557725345127 outer loop vertex 331.585889527836 272.13479737903083 43.0 vertex 330.5 271.08220248974004 45.0 vertex 331.2235428646925 270.78250122222613 45.0 endloop endfacet facet normal 0.10723204495433371 0.8145082464778862 0.5701557725345159 outer loop vertex 331.2235428646925 270.78250122222613 45.0 vertex 332.0 272.08027870109333 43.0 vertex 331.585889527836 272.13479737903083 43.0 endloop endfacet facet normal 0.10723204495433371 0.8145082464778862 0.5701557725345159 outer loop vertex 332.0 272.08027870109333 43.0 vertex 331.2235428646925 270.78250122222613 45.0 vertex 332.0 270.68027870109336 45.0 endloop endfacet facet normal -0.10723204495433358 0.8145082464778866 0.5701557725345159 outer loop vertex 332.0 270.68027870109336 45.0 vertex 332.41411047216405 272.13479737903083 43.0 vertex 332.0 272.08027870109333 43.0 endloop endfacet facet normal -0.10723204495433358 0.8145082464778866 0.5701557725345159 outer loop vertex 332.41411047216405 272.13479737903083 43.0 vertex 332.0 270.68027870109336 45.0 vertex 332.77645713530757 270.78250122222613 45.0 endloop endfacet facet normal -0.31438844820873585 0.7590008555189374 0.5701557725345102 outer loop vertex 332.77645713530757 270.78250122222613 45.0 vertex 332.8 272.2946380550382 43.0 vertex 332.41411047216405 272.13479737903083 43.0 endloop endfacet facet normal -0.31438844820873585 0.7590008555189374 0.5701557725345102 outer loop vertex 332.8 272.2946380550382 43.0 vertex 332.77645713530757 270.78250122222613 45.0 vertex 333.5 271.08220248974004 45.0 endloop endfacet facet normal -0.5001197982691478 0.6517688105646045 0.5701557725345133 outer loop vertex 333.5 271.08220248974004 45.0 vertex 333.1313708498985 272.5489078511949 43.0 vertex 332.8 272.2946380550382 43.0 endloop endfacet facet normal -0.5001197982691478 0.6517688105646045 0.5701557725345133 outer loop vertex 333.1313708498985 272.5489078511949 43.0 vertex 333.5 271.08220248974004 45.0 vertex 334.12132034355966 271.5589583575337 45.0 endloop endfacet facet normal -0.6517688105645887 0.500119798269164 0.5701557725345172 outer loop vertex 334.5980762113533 272.1802787010933 45.0 vertex 333.1313708498985 272.5489078511949 43.0 vertex 334.12132034355966 271.5589583575337 45.0 endloop endfacet facet normal -0.6517688105645887 0.500119798269164 0.5701557725345172 outer loop vertex 333.1313708498985 272.5489078511949 43.0 vertex 334.5980762113533 272.1802787010933 45.0 vertex 333.38564064605515 272.88027870109335 43.0 endloop endfacet facet normal -0.7590008555189414 0.3143884482087219 0.5701557725345126 outer loop vertex 334.8977774788672 272.9038215657858 45.0 vertex 333.38564064605515 272.88027870109335 43.0 vertex 334.5980762113533 272.1802787010933 45.0 endloop endfacet facet normal -0.7590008555189414 0.3143884482087219 0.5701557725345126 outer loop vertex 333.38564064605515 272.88027870109335 43.0 vertex 334.8977774788672 272.9038215657858 45.0 vertex 333.5454813220625 273.2661682289293 43.0 endloop endfacet facet normal -0.8145082464778862 0.10723204495433371 0.5701557725345159 outer loop vertex 335.0 273.6802787010933 45.0 vertex 333.5454813220625 273.2661682289293 43.0 vertex 334.8977774788672 272.9038215657858 45.0 endloop endfacet facet normal -0.8145082464778862 0.10723204495433371 0.5701557725345159 outer loop vertex 333.5454813220625 273.2661682289293 43.0 vertex 335.0 273.6802787010933 45.0 vertex 333.6 273.6802787010933 43.0 endloop endfacet facet normal -0.8145082464778864 -0.10723204495433365 0.5701557725345159 outer loop vertex 334.8977774788672 274.45673583640087 45.0 vertex 333.6 273.6802787010933 43.0 vertex 335.0 273.6802787010933 45.0 endloop endfacet facet normal -0.8145082464778864 -0.10723204495433365 0.5701557725345159 outer loop vertex 333.6 273.6802787010933 43.0 vertex 334.8977774788672 274.45673583640087 45.0 vertex 333.5454813220625 274.09438917325735 43.0 endloop endfacet facet normal -0.7590008555189374 -0.31438844820873585 0.5701557725345102 outer loop vertex 334.8977774788672 274.45673583640087 45.0 vertex 333.38564064605515 274.4802787010933 43.0 vertex 333.5454813220625 274.09438917325735 43.0 endloop endfacet facet normal -0.7590008555189374 -0.31438844820873585 0.5701557725345102 outer loop vertex 333.38564064605515 274.4802787010933 43.0 vertex 334.8977774788672 274.45673583640087 45.0 vertex 334.5980762113533 275.1802787010933 45.0 endloop endfacet facet normal -0.6517688105646045 -0.5001197982691478 0.5701557725345133 outer loop vertex 334.5980762113533 275.1802787010933 45.0 vertex 333.1313708498985 274.8116495509918 43.0 vertex 333.38564064605515 274.4802787010933 43.0 endloop endfacet facet normal -0.6517688105646045 -0.5001197982691478 0.5701557725345133 outer loop vertex 333.1313708498985 274.8116495509918 43.0 vertex 334.5980762113533 275.1802787010933 45.0 vertex 334.12132034355966 275.80159904465296 45.0 endloop endfacet facet normal -0.500119798269164 -0.6517688105645887 0.5701557725345172 outer loop vertex 334.12132034355966 275.80159904465296 45.0 vertex 332.8 275.06591934714845 43.0 vertex 333.1313708498985 274.8116495509918 43.0 endloop endfacet facet normal -0.500119798269164 -0.6517688105645887 0.5701557725345172 outer loop vertex 332.8 275.06591934714845 43.0 vertex 334.12132034355966 275.80159904465296 45.0 vertex 333.50000000000006 276.2783549124466 45.0 endloop endfacet facet normal -0.31438844820872186 -0.7590008555189416 0.5701557725345127 outer loop vertex 333.50000000000006 276.2783549124466 45.0 vertex 332.41411047216405 275.22576002315583 43.0 vertex 332.8 275.06591934714845 43.0 endloop endfacet facet normal -0.31438844820872186 -0.7590008555189416 0.5701557725345127 outer loop vertex 332.41411047216405 275.22576002315583 43.0 vertex 333.50000000000006 276.2783549124466 45.0 vertex 332.77645713530757 276.5780561799605 45.0 endloop endfacet facet normal -0.10723204495433371 -0.8145082464778862 0.5701557725345159 outer loop vertex 332.77645713530757 276.5780561799605 45.0 vertex 332.0 275.2802787010933 43.0 vertex 332.41411047216405 275.22576002315583 43.0 endloop endfacet facet normal -0.10723204495433371 -0.8145082464778862 0.5701557725345159 outer loop vertex 332.0 275.2802787010933 43.0 vertex 332.77645713530757 276.5780561799605 45.0 vertex 332.0 276.6802787010933 45.0 endloop endfacet facet normal 0.10723204495433358 -0.8145082464778866 0.5701557725345159 outer loop vertex 332.0 276.6802787010933 45.0 vertex 331.585889527836 275.22576002315583 43.0 vertex 332.0 275.2802787010933 43.0 endloop endfacet facet normal 0.10723204495433358 -0.8145082464778866 0.5701557725345159 outer loop vertex 331.585889527836 275.22576002315583 43.0 vertex 332.0 276.6802787010933 45.0 vertex 331.2235428646925 276.5780561799605 45.0 endloop endfacet facet normal 0.31438844820873585 -0.7590008555189374 0.5701557725345102 outer loop vertex 331.2235428646925 276.5780561799605 45.0 vertex 331.20000000000005 275.06591934714845 43.0 vertex 331.585889527836 275.22576002315583 43.0 endloop endfacet facet normal 0.31438844820873585 -0.7590008555189374 0.5701557725345102 outer loop vertex 331.20000000000005 275.06591934714845 43.0 vertex 331.2235428646925 276.5780561799605 45.0 vertex 330.50000000000006 276.2783549124466 45.0 endloop endfacet facet normal 0.5001197982691479 -0.6517688105646043 0.5701557725345133 outer loop vertex 330.50000000000006 276.2783549124466 45.0 vertex 330.8686291501015 274.8116495509918 43.0 vertex 331.20000000000005 275.06591934714845 43.0 endloop endfacet facet normal 0.5001197982691479 -0.6517688105646043 0.5701557725345133 outer loop vertex 330.8686291501015 274.8116495509918 43.0 vertex 330.50000000000006 276.2783549124466 45.0 vertex 329.8786796564404 275.80159904465296 45.0 endloop endfacet facet normal 0.6517688105645887 -0.500119798269164 0.5701557725345172 outer loop vertex 330.8686291501015 274.8116495509918 43.0 vertex 329.40192378864674 275.18027870109336 45.0 vertex 330.6143593539449 274.4802787010933 43.0 endloop endfacet facet normal 0.6517688105645887 -0.500119798269164 0.5701557725345172 outer loop vertex 329.40192378864674 275.18027870109336 45.0 vertex 330.8686291501015 274.8116495509918 43.0 vertex 329.8786796564404 275.80159904465296 45.0 endloop endfacet facet normal 0.7590008555189416 -0.31438844820872186 0.5701557725345127 outer loop vertex 330.6143593539449 274.4802787010933 43.0 vertex 329.10222252113283 274.45673583640087 45.0 vertex 330.4545186779375 274.09438917325735 43.0 endloop endfacet facet normal 0.7590008555189416 -0.31438844820872186 0.5701557725345127 outer loop vertex 329.10222252113283 274.45673583640087 45.0 vertex 330.6143593539449 274.4802787010933 43.0 vertex 329.40192378864674 275.18027870109336 45.0 endloop endfacet facet normal 0.8145082464778864 -0.10723204495433365 0.5701557725345159 outer loop vertex 330.4545186779375 274.09438917325735 43.0 vertex 329.00000000000006 273.6802787010933 45.0 vertex 330.40000000000003 273.6802787010933 43.0 endloop endfacet facet normal 0.8145082464778864 -0.10723204495433365 0.5701557725345159 outer loop vertex 329.00000000000006 273.6802787010933 45.0 vertex 330.4545186779375 274.09438917325735 43.0 vertex 329.10222252113283 274.45673583640087 45.0 endloop endfacet facet normal 0.8145082464778862 0.10723204495433371 0.5701557725345159 outer loop vertex 330.4545186779375 273.2661682289293 43.0 vertex 329.00000000000006 273.6802787010933 45.0 vertex 329.10222252113283 272.9038215657858 45.0 endloop endfacet facet normal 0.8145082464778862 0.10723204495433371 0.5701557725345159 outer loop vertex 329.00000000000006 273.6802787010933 45.0 vertex 330.4545186779375 273.2661682289293 43.0 vertex 330.40000000000003 273.6802787010933 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.61435935394496 157.48027870109328 43.0 vertex 330.61435935394496 157.48027870109328 43.0 vertex 330.4545186779375 157.09438917325733 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.61435935394496 157.48027870109328 43.0 vertex 330.61435935394496 157.48027870109328 43.0 vertex 330.8686291501015 157.81164955099177 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.6143593539449 155.8802787010933 43.0 vertex 330.6143593539449 155.8802787010933 43.0 vertex 330.4545186779375 156.26616822892927 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 330.6143593539449 155.8802787010933 43.0 vertex 330.6143593539449 155.8802787010933 43.0 vertex 330.8686291501015 155.54890785119483 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.3856406460551 157.48027870109328 43.0 vertex 333.3856406460551 157.48027870109328 43.0 vertex 333.1313708498985 157.81164955099177 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.3856406460551 157.48027870109328 43.0 vertex 333.3856406460551 157.48027870109328 43.0 vertex 333.5454813220625 157.09438917325733 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.38564064605515 155.8802787010933 43.0 vertex 333.38564064605515 155.8802787010933 43.0 vertex 333.1313708498985 155.54890785119483 43.0 endloop endfacet facet normal 0.0 0.0 1.0 outer loop vertex 333.38564064605515 155.8802787010933 43.0 vertex 333.38564064605515 155.8802787010933 43.0 vertex 333.5454813220625 156.26616822892927 43.0 endloop endfacet facet normal -0.6517688105645962 0.5001197982691564 0.5701557725345153 outer loop vertex 334.5980762113533 155.1802787010933 45.0 vertex 333.1313708498985 155.54890785119483 43.0 vertex 334.12132034355966 154.55895835753364 45.0 endloop endfacet facet normal -0.6517688105645962 0.5001197982691564 0.5701557725345153 outer loop vertex 333.1313708498985 155.54890785119483 43.0 vertex 334.5980762113533 155.1802787010933 45.0 vertex 333.38564064605515 155.8802787010933 43.0 endloop endfacet facet normal -0.7590008555189389 0.31438844820873246 0.5701557725345102 outer loop vertex 334.8977774788672 155.90382156578573 45.0 vertex 333.38564064605515 155.8802787010933 43.0 vertex 334.5980762113533 155.1802787010933 45.0 endloop endfacet facet normal -0.7590008555189389 0.31438844820873246 0.5701557725345102 outer loop vertex 333.38564064605515 155.8802787010933 43.0 vertex 334.8977774788672 155.90382156578573 45.0 vertex 333.5454813220625 156.26616822892927 43.0 endloop endfacet facet normal -0.8145082464778868 0.10723204495433229 0.5701557725345154 outer loop vertex 335.0 156.6802787010933 45.0 vertex 333.5454813220625 156.26616822892927 43.0 vertex 334.8977774788672 155.90382156578573 45.0 endloop endfacet facet normal -0.8145082464778868 0.10723204495433229 0.5701557725345154 outer loop vertex 333.5454813220625 156.26616822892927 43.0 vertex 335.0 156.6802787010933 45.0 vertex 333.6 156.6802787010933 43.0 endloop endfacet facet normal -0.8145082464778868 -0.10723204495433229 0.5701557725345154 outer loop vertex 334.8977774788672 157.45673583640084 45.0 vertex 333.6 156.6802787010933 43.0 vertex 335.0 156.6802787010933 45.0 endloop endfacet facet normal -0.8145082464778868 -0.10723204495433229 0.5701557725345154 outer loop vertex 333.6 156.6802787010933 43.0 vertex 334.8977774788672 157.45673583640084 45.0 vertex 333.5454813220625 157.09438917325733 43.0 endloop endfacet facet normal -0.7590008555189388 -0.31438844820873263 0.5701557725345101 outer loop vertex 334.8977774788672 157.45673583640084 45.0 vertex 333.38564064605515 157.48027870109328 43.0 vertex 333.5454813220625 157.09438917325733 43.0 endloop endfacet facet normal -0.7590008555189388 -0.31438844820873263 0.5701557725345101 outer loop vertex 333.38564064605515 157.48027870109328 43.0 vertex 334.8977774788672 157.45673583640084 45.0 vertex 334.5980762113533 158.1802787010933 45.0 endloop endfacet facet normal -0.6517688105645967 -0.5001197982691556 0.5701557725345153 outer loop vertex 334.5980762113533 158.1802787010933 45.0 vertex 333.1313708498985 157.81164955099177 43.0 vertex 333.38564064605515 157.48027870109328 43.0 endloop endfacet facet normal -0.6517688105645967 -0.5001197982691556 0.5701557725345153 outer loop vertex 333.1313708498985 157.81164955099177 43.0 vertex 334.5980762113533 158.1802787010933 45.0 vertex 334.12132034355966 158.80159904465293 45.0 endloop endfacet facet normal -0.5001197982691498 -0.6517688105645953 0.5701557725345221 outer loop vertex 334.12132034355966 158.80159904465293 45.0 vertex 332.8 158.06591934714837 43.0 vertex 333.1313708498985 157.81164955099177 43.0 endloop endfacet facet normal -0.5001197982691498 -0.6517688105645953 0.5701557725345221 outer loop vertex 332.8 158.06591934714837 43.0 vertex 334.12132034355966 158.80159904465293 45.0 vertex 333.50000000000006 159.2783549124466 45.0 endloop endfacet facet normal -0.3143884482087279 -0.7590008555189325 0.5701557725345211 outer loop vertex 333.50000000000006 159.2783549124466 45.0 vertex 332.41411047216405 158.2257600231558 43.0 vertex 332.8 158.06591934714837 43.0 endloop endfacet facet normal -0.3143884482087279 -0.7590008555189325 0.5701557725345211 outer loop vertex 332.41411047216405 158.2257600231558 43.0 vertex 333.50000000000006 159.2783549124466 45.0 vertex 332.77645713530757 159.5780561799605 45.0 endloop endfacet facet normal -0.10723204495434296 -0.8145082464778829 0.570155772534519 outer loop vertex 332.77645713530757 159.5780561799605 45.0 vertex 332.0 158.2802787010933 43.0 vertex 332.41411047216405 158.2257600231558 43.0 endloop endfacet facet normal -0.10723204495434296 -0.8145082464778829 0.570155772534519 outer loop vertex 332.0 158.2802787010933 43.0 vertex 332.77645713530757 159.5780561799605 45.0 vertex 332.0 159.6802787010933 45.0 endloop endfacet facet normal 0.10723204495434296 -0.8145082464778829 0.570155772534519 outer loop vertex 332.0 159.6802787010933 45.0 vertex 331.585889527836 158.2257600231558 43.0 vertex 332.0 158.2802787010933 43.0 endloop endfacet facet normal 0.10723204495434296 -0.8145082464778829 0.570155772534519 outer loop vertex 331.585889527836 158.2257600231558 43.0 vertex 332.0 159.6802787010933 45.0 vertex 331.2235428646925 159.5780561799605 45.0 endloop endfacet facet normal 0.31438844820872536 -0.7590008555189331 0.5701557725345218 outer loop vertex 331.2235428646925 159.5780561799605 45.0 vertex 331.20000000000005 158.06591934714837 43.0 vertex 331.585889527836 158.2257600231558 43.0 endloop endfacet facet normal 0.31438844820872536 -0.7590008555189331 0.5701557725345218 outer loop vertex 331.20000000000005 158.06591934714837 43.0 vertex 331.2235428646925 159.5780561799605 45.0 vertex 330.50000000000006 159.27835491244662 45.0 endloop endfacet facet normal 0.500119798269144 -0.6517688105646011 0.5701557725345208 outer loop vertex 330.50000000000006 159.27835491244662 45.0 vertex 330.8686291501015 157.81164955099177 43.0 vertex 331.20000000000005 158.06591934714837 43.0 endloop endfacet facet normal 0.500119798269144 -0.6517688105646011 0.5701557725345208 outer loop vertex 330.8686291501015 157.81164955099177 43.0 vertex 330.50000000000006 159.27835491244662 45.0 vertex 329.8786796564404 158.80159904465293 45.0 endloop endfacet facet normal 0.6517688105645962 -0.5001197982691564 0.5701557725345153 outer loop vertex 330.8686291501015 157.81164955099177 43.0 vertex 329.40192378864674 158.1802787010933 45.0 vertex 330.6143593539449 157.48027870109328 43.0 endloop endfacet facet normal 0.6517688105645962 -0.5001197982691564 0.5701557725345153 outer loop vertex 329.40192378864674 158.1802787010933 45.0 vertex 330.8686291501015 157.81164955099177 43.0 vertex 329.8786796564404 158.80159904465293 45.0 endloop endfacet facet normal 0.7590008555189389 -0.31438844820873246 0.5701557725345102 outer loop vertex 330.6143593539449 157.48027870109328 43.0 vertex 329.10222252113283 157.45673583640084 45.0 vertex 330.4545186779375 157.09438917325733 43.0 endloop endfacet facet normal 0.7590008555189389 -0.31438844820873246 0.5701557725345102 outer loop vertex 329.10222252113283 157.45673583640084 45.0 vertex 330.6143593539449 157.48027870109328 43.0 vertex 329.40192378864674 158.1802787010933 45.0 endloop endfacet facet normal 0.8145082464778868 -0.10723204495433229 0.5701557725345154 outer loop vertex 330.4545186779375 157.09438917325733 43.0 vertex 329.00000000000006 156.6802787010933 45.0 vertex 330.40000000000003 156.6802787010933 43.0 endloop endfacet facet normal 0.8145082464778868 -0.10723204495433229 0.5701557725345154 outer loop vertex 329.00000000000006 156.6802787010933 45.0 vertex 330.4545186779375 157.09438917325733 43.0 vertex 329.10222252113283 157.45673583640084 45.0 endloop endfacet facet normal 0.8145082464778868 0.10723204495433229 0.5701557725345154 outer loop vertex 330.4545186779375 156.26616822892927 43.0 vertex 329.00000000000006 156.6802787010933 45.0 vertex 329.10222252113283 155.90382156578573 45.0 endloop endfacet facet normal 0.8145082464778868 0.10723204495433229 0.5701557725345154 outer loop vertex 329.00000000000006 156.6802787010933 45.0 vertex 330.4545186779375 156.26616822892927 43.0 vertex 330.40000000000003 156.6802787010933 43.0 endloop endfacet facet normal 0.7590008555189388 0.31438844820873263 0.5701557725345101 outer loop vertex 330.6143593539449 155.8802787010933 43.0 vertex 329.10222252113283 155.90382156578573 45.0 vertex 329.40192378864674 155.1802787010933 45.0 endloop endfacet facet normal 0.7590008555189388 0.31438844820873263 0.5701557725345101 outer loop vertex 329.10222252113283 155.90382156578573 45.0 vertex 330.6143593539449 155.8802787010933 43.0 vertex 330.4545186779375 156.26616822892927 43.0 endloop endfacet facet normal 0.6517688105645967 0.5001197982691556 0.5701557725345153 outer loop vertex 330.8686291501015 155.54890785119483 43.0 vertex 329.40192378864674 155.1802787010933 45.0 vertex 329.8786796564404 154.55895835753364 45.0 endloop endfacet facet normal 0.6517688105645967 0.5001197982691556 0.5701557725345153 outer loop vertex 329.40192378864674 155.1802787010933 45.0 vertex 330.8686291501015 155.54890785119483 43.0 vertex 330.6143593539449 155.8802787010933 43.0 endloop endfacet facet normal 0.5001197982691498 0.6517688105645953 0.5701557725345221 outer loop vertex 329.8786796564404 154.55895835753364 45.0 vertex 331.20000000000005 155.2946380550382 43.0 vertex 330.8686291501015 155.54890785119483 43.0 endloop endfacet facet normal 0.5001197982691498 0.6517688105645953 0.5701557725345221 outer loop vertex 331.20000000000005 155.2946380550382 43.0 vertex 329.8786796564404 154.55895835753364 45.0 vertex 330.5 154.08220248973998 45.0 endloop endfacet facet normal 0.3143884482087281 0.7590008555189324 0.5701557725345212 outer loop vertex 330.5 154.08220248973998 45.0 vertex 331.585889527836 155.1347973790308 43.0 vertex 331.20000000000005 155.2946380550382 43.0 endloop endfacet facet normal 0.3143884482087281 0.7590008555189324 0.5701557725345212 outer loop vertex 331.585889527836 155.1347973790308 43.0 vertex 330.5 154.08220248973998 45.0 vertex 331.2235428646925 153.7825012222261 45.0 endloop endfacet facet normal 0.10723204495434305 0.8145082464778829 0.570155772534519 outer loop vertex 331.2235428646925 153.7825012222261 45.0 vertex 332.0 155.0802787010933 43.0 vertex 331.585889527836 155.1347973790308 43.0 endloop endfacet facet normal 0.10723204495434305 0.8145082464778829 0.570155772534519 outer loop vertex 332.0 155.0802787010933 43.0 vertex 331.2235428646925 153.7825012222261 45.0 vertex 332.0 153.6802787010933 45.0 endloop endfacet facet normal -0.10723204495434296 0.8145082464778829 0.570155772534519 outer loop vertex 332.0 153.6802787010933 45.0 vertex 332.41411047216405 155.1347973790308 43.0 vertex 332.0 155.0802787010933 43.0 endloop endfacet facet normal -0.10723204495434296 0.8145082464778829 0.570155772534519 outer loop vertex 332.41411047216405 155.1347973790308 43.0 vertex 332.0 153.6802787010933 45.0 vertex 332.77645713530757 153.7825012222261 45.0 endloop endfacet facet normal -0.314388448208742 0.7590008555189283 0.5701557725345189 outer loop vertex 332.77645713530757 153.7825012222261 45.0 vertex 332.8 155.2946380550382 43.0 vertex 332.41411047216405 155.1347973790308 43.0 endloop endfacet facet normal -0.314388448208742 0.7590008555189283 0.5701557725345189 outer loop vertex 332.8 155.2946380550382 43.0 vertex 332.77645713530757 153.7825012222261 45.0 vertex 333.5 154.08220248973998 45.0 endloop endfacet facet normal -0.5001197982691334 0.6517688105646112 0.5701557725345182 outer loop vertex 333.5 154.08220248973998 45.0 vertex 333.1313708498985 155.54890785119483 43.0 vertex 332.8 155.2946380550382 43.0 endloop endfacet facet normal -0.5001197982691334 0.6517688105646112 0.5701557725345182 outer loop vertex 333.1313708498985 155.54890785119483 43.0 vertex 333.5 154.08220248973998 45.0 vertex 334.12132034355966 154.55895835753364 45.0 endloop endfacet facet normal 0.8145082464778834 0.10723204495434173 0.5701557725345185 outer loop vertex 167.9545186779375 156.26616822892927 43.0 vertex 166.5 156.6802787010933 45.0 vertex 166.6022225211328 155.90382156578573 45.0 endloop endfacet facet normal 0.8145082464778834 0.10723204495434173 0.5701557725345185 outer loop vertex 166.5 156.6802787010933 45.0 vertex 167.9545186779375 156.26616822892927 43.0 vertex 167.9 156.6802787010933 43.0 endloop endfacet facet normal 0.7590008555189353 0.3143884482087312 0.5701557725345159 outer loop vertex 168.1143593539449 155.8802787010933 43.0 vertex 166.6022225211328 155.90382156578573 45.0 vertex 166.9019237886467 155.1802787010933 45.0 endloop endfacet facet normal 0.7590008555189353 0.3143884482087312 0.5701557725345159 outer loop vertex 166.6022225211328 155.90382156578573 45.0 vertex 168.1143593539449 155.8802787010933 43.0 vertex 167.9545186779375 156.26616822892927 43.0 endloop endfacet facet normal 0.6517688105646 0.5001197982691488 0.5701557725345178 outer loop vertex 168.36862915010153 155.54890785119483 43.0 vertex 166.9019237886467 155.1802787010933 45.0 vertex 167.37867965644037 154.55895835753364 45.0 endloop endfacet facet normal 0.6517688105646 0.5001197982691488 0.5701557725345178 outer loop vertex 166.9019237886467 155.1802787010933 45.0 vertex 168.36862915010153 155.54890785119483 43.0 vertex 168.1143593539449 155.8802787010933 43.0 endloop endfacet facet normal 0.5001197982691495 0.6517688105645992 0.570155772534518 outer loop vertex 167.37867965644037 154.55895835753364 45.0 vertex 168.70000000000002 155.29463805503818 43.0 vertex 168.36862915010153 155.54890785119483 43.0 endloop endfacet facet normal 0.5001197982691495 0.6517688105645992 0.570155772534518 outer loop vertex 168.70000000000002 155.29463805503818 43.0 vertex 167.37867965644037 154.55895835753364 45.0 vertex 168.0 154.08220248973998 45.0 endloop endfacet facet normal 0.3143884482087312 0.7590008555189353 0.5701557725345159 outer loop vertex 168.0 154.08220248973998 45.0 vertex 169.08588952783597 155.1347973790308 43.0 vertex 168.70000000000002 155.29463805503818 43.0 endloop endfacet facet normal 0.3143884482087312 0.7590008555189353 0.5701557725345159 outer loop vertex 169.08588952783597 155.1347973790308 43.0 vertex 168.0 154.08220248973998 45.0 vertex 168.72354286469246 153.7825012222261 45.0 endloop endfacet facet normal 0.10723204495434173 0.8145082464778834 0.5701557725345185 outer loop vertex 168.72354286469246 153.7825012222261 45.0 vertex 169.5 155.0802787010933 43.0 vertex 169.08588952783597 155.1347973790308 43.0 endloop endfacet facet normal 0.10723204495434173 0.8145082464778834 0.5701557725345185 outer loop vertex 169.5 155.0802787010933 43.0 vertex 168.72354286469246 153.7825012222261 45.0 vertex 169.5 153.6802787010933 45.0 endloop endfacet facet normal -0.10723204495434173 0.8145082464778834 0.5701557725345185 outer loop vertex 169.5 153.6802787010933 45.0 vertex 169.91411047216403 155.1347973790308 43.0 vertex 169.5 155.0802787010933 43.0 endloop endfacet facet normal -0.10723204495434173 0.8145082464778834 0.5701557725345185 outer loop vertex 169.91411047216403 155.1347973790308 43.0 vertex 169.5 153.6802787010933 45.0 vertex 170.27645713530757 153.7825012222261 45.0 endloop endfacet facet normal -0.31438844820873113 0.7590008555189351 0.5701557725345159 outer loop vertex 170.27645713530757 153.7825012222261 45.0 vertex 170.3 155.29463805503818 43.0 vertex 169.91411047216403 155.1347973790308 43.0 endloop endfacet facet normal -0.31438844820873113 0.7590008555189351 0.5701557725345159 outer loop vertex 170.3 155.29463805503818 43.0 vertex 170.27645713530757 153.7825012222261 45.0 vertex 171.0 154.08220248973998 45.0 endloop endfacet facet normal -0.5001197982691488 0.6517688105646 0.5701557725345178 outer loop vertex 171.0 154.08220248973998 45.0 vertex 170.63137084989847 155.54890785119483 43.0 vertex 170.3 155.29463805503818 43.0 endloop endfacet facet normal -0.5001197982691488 0.6517688105646 0.5701557725345178 outer loop vertex 170.63137084989847 155.54890785119483 43.0 vertex 171.0 154.08220248973998 45.0 vertex 171.62132034355966 154.55895835753364 45.0 endloop endfacet facet normal -0.6517688105645997 0.500119798269149 0.5701557725345178 outer loop vertex 172.09807621135332 155.1802787010933 45.0 vertex 170.63137084989847 155.54890785119483 43.0 vertex 171.62132034355966 154.55895835753364 45.0 endloop endfacet facet normal -0.6517688105645997 0.500119798269149 0.5701557725345178 outer loop vertex 170.63137084989847 155.54890785119483 43.0 vertex 172.09807621135332 155.1802787010933 45.0 vertex 170.88564064605512 155.8802787010933 43.0 endloop endfacet facet normal -0.7590008555189353 0.31438844820873096 0.570155772534516 outer loop vertex 172.3977774788672 155.90382156578573 45.0 vertex 170.88564064605512 155.8802787010933 43.0 vertex 172.09807621135332 155.1802787010933 45.0 endloop endfacet facet normal -0.7590008555189353 0.31438844820873096 0.570155772534516 outer loop vertex 170.88564064605512 155.8802787010933 43.0 vertex 172.3977774788672 155.90382156578573 45.0 vertex 171.0454813220625 156.26616822892927 43.0 endloop endfacet facet normal -0.8145082464778834 0.10723204495434173 0.5701557725345185 outer loop vertex 172.5 156.6802787010933 45.0 vertex 171.0454813220625 156.26616822892927 43.0 vertex 172.3977774788672 155.90382156578573 45.0 endloop endfacet facet normal -0.8145082464778834 0.10723204495434173 0.5701557725345185 outer loop vertex 171.0454813220625 156.26616822892927 43.0 vertex 172.5 156.6802787010933 45.0 vertex 171.1 156.6802787010933 43.0 endloop endfacet facet normal -0.8145082464778833 -0.1072320449543418 0.5701557725345185 outer loop vertex 172.3977774788672 157.45673583640084 45.0 vertex 171.1 156.6802787010933 43.0 vertex 172.5 156.6802787010933 45.0 endloop endfacet facet normal -0.8145082464778833 -0.1072320449543418 0.5701557725345185 outer loop vertex 171.1 156.6802787010933 43.0 vertex 172.3977774788672 157.45673583640084 45.0 vertex 171.0454813220625 157.09438917325733 43.0 endloop endfacet facet normal -0.7590008555189353 -0.3143884482087312 0.5701557725345159 outer loop vertex 172.3977774788672 157.45673583640084 45.0 vertex 170.88564064605512 157.48027870109328 43.0 vertex 171.0454813220625 157.09438917325733 43.0 endloop endfacet facet normal -0.7590008555189353 -0.3143884482087312 0.5701557725345159 outer loop vertex 170.88564064605512 157.48027870109328 43.0 vertex 172.3977774788672 157.45673583640084 45.0 vertex 172.09807621135332 158.1802787010933 45.0 endloop endfacet facet normal -0.6517688105646 -0.5001197982691488 0.5701557725345178 outer loop vertex 172.09807621135332 158.1802787010933 45.0 vertex 170.63137084989847 157.81164955099177 43.0 vertex 170.88564064605512 157.48027870109328 43.0 endloop endfacet facet normal -0.6517688105646 -0.5001197982691488 0.5701557725345178 outer loop vertex 170.63137084989847 157.81164955099177 43.0 vertex 172.09807621135332 158.1802787010933 45.0 vertex 171.62132034355966 158.80159904465293 45.0 endloop endfacet facet normal -0.5001197982691495 -0.6517688105645992 0.570155772534518 outer loop vertex 171.62132034355966 158.80159904465293 45.0 vertex 170.3 158.0659193471484 43.0 vertex 170.63137084989847 157.81164955099177 43.0 endloop endfacet facet normal -0.5001197982691495 -0.6517688105645992 0.570155772534518 outer loop vertex 170.3 158.0659193471484 43.0 vertex 171.62132034355966 158.80159904465293 45.0 vertex 171.0 159.2783549124466 45.0 endloop endfacet facet normal -0.3143884482087308 -0.7590008555189355 0.5701557725345159 outer loop vertex 171.0 159.2783549124466 45.0 vertex 169.91411047216403 158.2257600231558 43.0 vertex 170.3 158.0659193471484 43.0 endloop endfacet facet normal -0.3143884482087308 -0.7590008555189355 0.5701557725345159 outer loop vertex 169.91411047216403 158.2257600231558 43.0 vertex 171.0 159.2783549124466 45.0 vertex 170.27645713530757 159.5780561799605 45.0 endloop endfacet facet normal -0.10723204495434173 -0.8145082464778834 0.5701557725345185 outer loop vertex 170.27645713530757 159.5780561799605 45.0 vertex 169.5 158.2802787010933 43.0 vertex 169.91411047216403 158.2257600231558 43.0 endloop endfacet facet normal -0.10723204495434173 -0.8145082464778834 0.5701557725345185 outer loop vertex 169.5 158.2802787010933 43.0 vertex 170.27645713530757 159.5780561799605 45.0 vertex 169.5 159.6802787010933 45.0 endloop endfacet facet normal 0.10723204495434183 -0.8145082464778836 0.5701557725345185 outer loop vertex 169.5 159.6802787010933 45.0 vertex 169.08588952783597 158.2257600231558 43.0 vertex 169.5 158.2802787010933 43.0 endloop endfacet facet normal 0.10723204495434183 -0.8145082464778836 0.5701557725345185 outer loop vertex 169.08588952783597 158.2257600231558 43.0 vertex 169.5 159.6802787010933 45.0 vertex 168.72354286469246 159.5780561799605 45.0 endloop endfacet facet normal 0.31438844820871475 -0.7590008555189397 0.5701557725345188 outer loop vertex 168.72354286469246 159.5780561799605 45.0 vertex 168.70000000000002 158.0659193471484 43.0 vertex 169.08588952783597 158.2257600231558 43.0 endloop endfacet facet normal 0.31438844820871475 -0.7590008555189397 0.5701557725345188 outer loop vertex 168.70000000000002 158.0659193471484 43.0 vertex 168.72354286469246 159.5780561799605 45.0 vertex 168.0 159.27835491244662 45.0 endloop endfacet facet normal 0.5001197982691592 -0.6517688105645898 0.5701557725345203 outer loop vertex 168.0 159.27835491244662 45.0 vertex 168.36862915010153 157.81164955099177 43.0 vertex 168.70000000000002 158.0659193471484 43.0 endloop endfacet facet normal 0.5001197982691592 -0.6517688105645898 0.5701557725345203 outer loop vertex 168.36862915010153 157.81164955099177 43.0 vertex 168.0 159.27835491244662 45.0 vertex 167.37867965644037 158.80159904465293 45.0 endloop endfacet facet normal 0.6517688105645992 -0.5001197982691495 0.570155772534518 outer loop vertex 168.36862915010153 157.81164955099177 43.0 vertex 166.9019237886467 158.1802787010933 45.0 vertex 168.1143593539449 157.48027870109328 43.0 endloop endfacet facet normal 0.6517688105645992 -0.5001197982691495 0.570155772534518 outer loop vertex 166.9019237886467 158.1802787010933 45.0 vertex 168.36862915010153 157.81164955099177 43.0 vertex 167.37867965644037 158.80159904465293 45.0 endloop endfacet facet normal 0.7590008555189355 -0.3143884482087308 0.5701557725345159 outer loop vertex 168.1143593539449 157.48027870109328 43.0 vertex 166.6022225211328 157.45673583640084 45.0 vertex 167.9545186779375 157.09438917325733 43.0 endloop endfacet facet normal 0.7590008555189355 -0.3143884482087308 0.5701557725345159 outer loop vertex 166.6022225211328 157.45673583640084 45.0 vertex 168.1143593539449 157.48027870109328 43.0 vertex 166.9019237886467 158.1802787010933 45.0 endloop endfacet facet normal 0.8145082464778834 -0.10723204495434173 0.5701557725345185 outer loop vertex 167.9545186779375 157.09438917325733 43.0 vertex 166.5 156.6802787010933 45.0 vertex 167.9 156.6802787010933 43.0 endloop endfacet facet normal 0.8145082464778834 -0.10723204495434173 0.5701557725345185 outer loop vertex 166.5 156.6802787010933 45.0 vertex 167.9545186779375 157.09438917325733 43.0 vertex 166.6022225211328 157.45673583640084 45.0 endloop endfacet endsolid CLOCK_V3_4mm
