<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.635" unitdist="mm" unit="mm" style="lines" multiple="1" display="no" altdistance="0.3175" altunitdist="mm" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="16" fill="1" visible="no" active="no"/>
<layer number="3" name="Route3" color="17" fill="1" visible="no" active="no"/>
<layer number="4" name="Route4" color="18" fill="1" visible="no" active="no"/>
<layer number="5" name="Route5" color="19" fill="1" visible="no" active="no"/>
<layer number="6" name="Route6" color="25" fill="1" visible="no" active="no"/>
<layer number="7" name="Route7" color="26" fill="1" visible="no" active="no"/>
<layer number="8" name="Route8" color="27" fill="1" visible="no" active="no"/>
<layer number="9" name="Route9" color="28" fill="1" visible="no" active="no"/>
<layer number="10" name="Route10" color="29" fill="1" visible="no" active="no"/>
<layer number="11" name="Route11" color="30" fill="1" visible="no" active="no"/>
<layer number="12" name="Route12" color="20" fill="1" visible="no" active="no"/>
<layer number="13" name="Route13" color="21" fill="1" visible="no" active="no"/>
<layer number="14" name="Route14" color="22" fill="1" visible="no" active="no"/>
<layer number="15" name="Route15" color="23" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="57" name="tCAD" color="7" fill="1" visible="no" active="no"/>
<layer number="59" name="tCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="60" name="bCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="no" active="no"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="7" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="yes" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="yes" active="yes"/>
<layer number="103" name="tMap" color="7" fill="1" visible="yes" active="yes"/>
<layer number="104" name="Name" color="16" fill="1" visible="yes" active="yes"/>
<layer number="105" name="tPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="106" name="bPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="107" name="Crop" color="7" fill="1" visible="yes" active="yes"/>
<layer number="108" name="tplace-old" color="10" fill="1" visible="yes" active="yes"/>
<layer number="109" name="ref-old" color="11" fill="1" visible="yes" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="yes" active="yes"/>
<layer number="111" name="LPC17xx" color="7" fill="1" visible="yes" active="yes"/>
<layer number="112" name="tSilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="113" name="IDFDebug" color="7" fill="1" visible="yes" active="yes"/>
<layer number="114" name="Badge_Outline" color="7" fill="1" visible="yes" active="yes"/>
<layer number="115" name="ReferenceISLANDS" color="7" fill="1" visible="yes" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="yes" active="yes"/>
<layer number="118" name="Rect_Pads" color="7" fill="1" visible="yes" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="126" name="_bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="127" name="_tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="128" name="_bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="129" name="Mask" color="7" fill="1" visible="yes" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="yes" active="yes"/>
<layer number="150" name="Notes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="yes" active="yes"/>
<layer number="152" name="_bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="153" name="FabDoc1" color="7" fill="1" visible="yes" active="yes"/>
<layer number="154" name="FabDoc2" color="7" fill="1" visible="yes" active="yes"/>
<layer number="155" name="FabDoc3" color="7" fill="1" visible="yes" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="yes" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="yes" active="yes"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="yes" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="yes" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="yes" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="yes" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="yes" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="yes" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="225" name="225bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="226" name="226bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="227" name="227bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="228" name="228bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="229" name="229bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="230" name="230bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="231" name="231bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="248" name="Housing" color="7" fill="1" visible="yes" active="yes"/>
<layer number="249" name="Edge" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="yes" active="yes"/>
<layer number="255" name="routoute" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<fusionsync huburn="a.cGVyc29uYWw6dWUyODBjMGJh" projecturn="a.cGVyc29uYWw6dWUyODBjMGJhIzIwMTYxMjA4NTQyODc0NTE" f3durn="urn:adsk.wipprod:dm.lineage:Bany7sWtQ5-HQ2eKNhdaYg" pcbguid="2470fd00-9d75-4f06-b2b6-4178268f7088" lastpulledtime="" lastsyncedchangeguid="ebc3a4e7-3058-8bd5-e343-28cf14e1406c"/>
<plain>
<wire x1="92" y1="46" x2="168" y2="46" width="0" layer="20" locked="yes"/>
<wire x1="168" y1="46" x2="168" y2="112" width="0" layer="20" locked="yes"/>
<wire x1="168" y1="112" x2="92" y2="112" width="0" layer="20" locked="yes"/>
<wire x1="92" y1="112" x2="92" y2="46" width="0" layer="20" locked="yes"/>
<text x="111.76" y="98.425" size="1.778" layer="25" align="center">ARDUINO
NANO</text>
<text x="113.665" y="80.645" size="2" layer="22" distance="30" rot="MR90" align="center">JYAVP14E82A001533
2019-09-12
Made.In.Hungary</text>
<text x="157.48" y="96.52" size="1.778" layer="22" rot="MR0">HI.BEAM</text>
<text x="157.48" y="88.9" size="1.778" layer="22" rot="MR0">RIGHT.TURN</text>
<text x="157.48" y="81.28" size="1.778" layer="22" rot="MR0">LEFT.TURN</text>
<text x="157.48" y="74.295" size="1.778" layer="22" rot="MR0">HORN</text>
<text x="157.48" y="66.675" size="1.778" layer="22" rot="MR0">STARTER</text>
<text x="157.48" y="59.055" size="1.778" layer="22" rot="MR0">ENGINE.CUT.OFF</text>
<text x="113.665" y="80.645" size="1.9304" layer="21" rot="R90" align="center">#asdkpz156</text>
</plain>
<libraries>
<library name="Arduino-clone">
<description>Arduino Clone pinheaders
By cl@xganon.com
http://www.xganon.com</description>
<packages>
<package name="NANO">
<pad name="TX0" x="5.08" y="-8.89" drill="0.8" shape="long"/>
<pad name="RX1" x="5.08" y="-6.35" drill="0.8" shape="long"/>
<pad name="RST1" x="5.08" y="-3.81" drill="0.8" shape="long"/>
<pad name="GND1" x="5.08" y="-1.27" drill="0.8" shape="long"/>
<pad name="D2" x="5.08" y="1.27" drill="0.8" shape="long"/>
<pad name="D3" x="5.08" y="3.81" drill="0.8" shape="long"/>
<pad name="D4" x="5.08" y="6.35" drill="0.8" shape="long"/>
<pad name="D5" x="5.08" y="8.89" drill="0.8" shape="long"/>
<pad name="D6" x="5.08" y="11.43" drill="0.8" shape="long"/>
<pad name="D7" x="5.08" y="13.97" drill="0.8" shape="long"/>
<pad name="D8" x="5.08" y="16.51" drill="0.8" shape="long"/>
<pad name="D9" x="5.08" y="19.05" drill="0.8" shape="long"/>
<pad name="RAW" x="-10.16" y="-8.89" drill="0.8" shape="long"/>
<pad name="GND" x="-10.16" y="-6.35" drill="0.8" shape="long"/>
<pad name="RST" x="-10.16" y="-3.81" drill="0.8" shape="long"/>
<pad name="A3" x="-10.16" y="11.43" drill="0.8" shape="long"/>
<pad name="A2" x="-10.16" y="13.97" drill="0.8" shape="long"/>
<pad name="A1" x="-10.16" y="16.51" drill="0.8" shape="long"/>
<pad name="A0" x="-10.16" y="19.05" drill="0.8" shape="long"/>
<pad name="D13" x="-10.16" y="26.67" drill="0.8" shape="long"/>
<pad name="D12" x="5.08" y="26.67" drill="0.8" shape="long"/>
<pad name="D11" x="5.08" y="24.13" drill="0.8" shape="long"/>
<pad name="D10" x="5.08" y="21.59" drill="0.8" shape="long"/>
<pad name="3.3V" x="-10.16" y="24.13" drill="0.8" shape="long" rot="R180"/>
<pad name="AREF" x="-10.16" y="21.59" drill="0.8" shape="long" rot="R180"/>
<pad name="5V" x="-10.16" y="-1.27" drill="0.8" shape="long"/>
<pad name="A4" x="-10.16" y="8.89" drill="0.8" shape="long" rot="R180"/>
<pad name="A5" x="-10.16" y="6.35" drill="0.8" shape="long" rot="R180"/>
<pad name="A6" x="-10.16" y="3.81" drill="0.8" shape="long" rot="R180"/>
<pad name="A7" x="-10.16" y="1.27" drill="0.8" shape="long" rot="R180"/>
<wire x1="-12.2" y1="27.94" x2="-12.2" y2="-10.16" width="0.127" layer="21"/>
<wire x1="-12.2" y1="-10.16" x2="7.12" y2="-10.16" width="0.127" layer="21"/>
<wire x1="7.12" y1="-10.16" x2="7.12" y2="27.94" width="0.127" layer="21"/>
<wire x1="7.12" y1="27.94" x2="-12.2" y2="27.94" width="0.127" layer="21"/>
</package>
</packages>
</library>
<library name="v-reg" urn="urn:adsk.eagle:library:409">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="78MXXS" urn="urn:adsk.eagle:footprint:30286/1" library_version="4">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="-4.826" y1="-4.7498" x2="2.794" y2="-4.7498" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.127" x2="4.8006" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-4.7498" x2="4.8006" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.7498" x2="-4.826" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="4.8006" y1="-0.127" x2="4.8006" y2="-2.794" width="0.1524" layer="21"/>
<circle x="-4.064" y="-3.9878" radius="0.4318" width="0" layer="21"/>
<pad name="IN" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="GND" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="OUT" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-4.826" y="-6.477" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-8.128" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.508" y="-1.778" size="1.27" layer="51" ratio="10">-</text>
<text x="-3.048" y="-1.778" size="1.27" layer="51" ratio="10">I</text>
<text x="2.032" y="-1.778" size="1.27" layer="51" ratio="10">O</text>
<rectangle x1="3.429" y1="-2.794" x2="4.826" y2="-2.286" layer="21"/>
<rectangle x1="0.889" y1="-2.794" x2="1.651" y2="-2.286" layer="21"/>
<rectangle x1="-1.651" y1="-2.794" x2="-0.889" y2="-2.286" layer="21"/>
<rectangle x1="-4.826" y1="-2.794" x2="-3.429" y2="-2.286" layer="21"/>
<rectangle x1="-3.429" y1="-2.794" x2="-1.651" y2="-2.286" layer="51"/>
<rectangle x1="-0.889" y1="-2.794" x2="0.889" y2="-2.286" layer="51"/>
<rectangle x1="1.651" y1="-2.794" x2="3.429" y2="-2.286" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="78MXXS" urn="urn:adsk.eagle:package:30347/1" type="box" library_version="4">
<description>VOLTAGE REGULATOR</description>
<packageinstances>
<packageinstance name="78MXXS"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="con-phoenix-350">
<description>&lt;b&gt;Phoenix Connectors&lt;/b&gt; Grid 3.50 mm&lt;p&gt;
<packages>
<package name="1751277" urn="urn:adsk.eagle:footprint:9374/1" locally_modified="yes">
<description>&lt;b&gt;MKDS 1/ 5-3,5&lt;/b&gt; Printklemme&lt;p&gt;
Nennstrom: 10 A&lt;br&gt;
Bemessungsspannung: 160 V&lt;br&gt;
Raster: 3,5 mm&lt;br&gt;
Polzahl: 5&lt;br&gt;
Montageart: Löten&lt;br&gt;
Anschlussart: Schraubanschluss&lt;br&gt;
Anschlussrichtung vom Leiter zur Platine: 0°&lt;br&gt;
Source: http://eshop.phoenixcontact.com .. 1751277.pdf</description>
<wire x1="-9" y1="3.396" x2="9" y2="3.396" width="0.1016" layer="21"/>
<wire x1="-9" y1="3.396" x2="-9" y2="1.9123" width="0.1016" layer="21"/>
<wire x1="9" y1="-2.0993" x2="-9" y2="-2.0993" width="0.1016" layer="21"/>
<wire x1="9" y1="-2.0993" x2="9" y2="1.9123" width="0.1016" layer="21"/>
<wire x1="9" y1="-2.0993" x2="9" y2="-3.396" width="0.1016" layer="21"/>
<wire x1="-9" y1="1.9123" x2="9" y2="1.9123" width="0.1016" layer="21"/>
<wire x1="-9" y1="-2.0993" x2="-9" y2="1.9123" width="0.1016" layer="21"/>
<wire x1="9" y1="3.396" x2="9" y2="1.9123" width="0.1016" layer="21"/>
<wire x1="-9" y1="-2.0993" x2="-9" y2="-3.396" width="0.1016" layer="21"/>
<wire x1="-8.206" y1="-0.811" x2="-6.289" y2="1.106" width="0.1016" layer="51"/>
<wire x1="-9" y1="-3.396" x2="9" y2="-3.396" width="0.1016" layer="21"/>
<wire x1="-5.794" y1="0.611" x2="-5.8" y2="0.605" width="0.1016" layer="21"/>
<wire x1="-5.8" y1="0.605" x2="-7.711" y2="-1.306" width="0.1016" layer="51"/>
<wire x1="-4.706" y1="-0.811" x2="-2.789" y2="1.106" width="0.1016" layer="51"/>
<wire x1="-2.294" y1="0.611" x2="-2.3" y2="0.605" width="0.1016" layer="21"/>
<wire x1="-2.3" y1="0.605" x2="-4.211" y2="-1.306" width="0.1016" layer="51"/>
<wire x1="-1.206" y1="-0.811" x2="0.711" y2="1.106" width="0.1016" layer="51"/>
<wire x1="1.206" y1="0.611" x2="1.2" y2="0.605" width="0.1016" layer="21"/>
<wire x1="1.2" y1="0.605" x2="-0.711" y2="-1.306" width="0.1016" layer="51"/>
<wire x1="2.294" y1="-0.811" x2="4.211" y2="1.106" width="0.1016" layer="51"/>
<wire x1="4.706" y1="0.611" x2="4.7" y2="0.605" width="0.1016" layer="21"/>
<wire x1="4.7" y1="0.605" x2="2.789" y2="-1.306" width="0.1016" layer="51"/>
<wire x1="5.794" y1="-0.811" x2="7.711" y2="1.106" width="0.1016" layer="51"/>
<wire x1="8.206" y1="0.611" x2="8.2" y2="0.605" width="0.1016" layer="21"/>
<wire x1="8.2" y1="0.605" x2="6.289" y2="-1.306" width="0.1016" layer="51"/>
<circle x="-7" y="-0.1" radius="1.45" width="0.1016" layer="21"/>
<circle x="-3.5" y="-0.1" radius="1.45" width="0.1016" layer="21"/>
<circle x="0" y="-0.1" radius="1.45" width="0.1016" layer="21"/>
<circle x="3.5" y="-0.1" radius="1.45" width="0.1016" layer="21"/>
<circle x="7" y="-0.1" radius="1.45" width="0.1016" layer="21"/>
<pad name="1" x="-7" y="-0.1" drill="1.1" diameter="2.1844" rot="R90"/>
<pad name="2" x="-3.5" y="-0.1" drill="1.1" diameter="2.1844" rot="R90"/>
<pad name="3" x="0" y="-0.1" drill="1.1" diameter="2.1844" rot="R90"/>
<pad name="4" x="3.5" y="-0.1" drill="1.1" diameter="2.1844" rot="R90"/>
<pad name="5" x="7" y="-0.1" drill="1.1" diameter="2.1844" rot="R90"/>
<text x="-7.45" y="2.2225" size="1.016" layer="21" font="vector">1</text>
<text x="-3.9575" y="2.2225" size="1.016" layer="21" font="vector">2</text>
<text x="-0.465" y="2.2225" size="1.016" layer="21" font="vector">3</text>
<text x="3.0275" y="2.2225" size="1.016" layer="21" font="vector">4</text>
<text x="6.52" y="2.2225" size="1.016" layer="21" font="vector">5</text>
<text x="-9.355" y="-2.8575" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-2.0525" y="4.1275" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="1751277" urn="urn:adsk.eagle:package:9396/1" locally_modified="yes" type="box">
<description>MKDS 1/ 5-3,5 Printklemme
Nennstrom: 10 A
Raster: 3,5 mm
Polzahl: 5
Montageart: Löten
<packageinstances>
<packageinstance name="1751277"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C050-025X075" urn="urn:adsk.eagle:footprint:23148/1" locally_modified="yes">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.6764"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.6764"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0309V" urn="urn:adsk.eagle:footprint:23075/1" locally_modified="yes">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" diameter="1.6764"/>
<pad name="2" x="1.27" y="0" drill="0.8128" diameter="1.6764"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="C050-025X075" urn="urn:adsk.eagle:package:23637/1" type="box">
<description>CAPACITOR
<packageinstances>
<packageinstance name="C050-025X075"/>
</packageinstances>
</package3d>
<package3d name="0309V" urn="urn:adsk.eagle:package:23572/1" type="box">
<description>RESISTOR
<packageinstances>
<packageinstance name="0309V"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
<packages>
<package name="AZ9371-AZETTLER">
<wire x1="11.304" y1="-3.6" x2="-9.804" y2="-3.6" width="0.127" layer="21"/>
<wire x1="-9.804" y1="-3.6" x2="-9.804" y2="3.6" width="0.127" layer="21"/>
<wire x1="-9.804" y1="3.6" x2="11.304" y2="3.6" width="0.127" layer="21"/>
<wire x1="11.304" y1="3.6" x2="11.304" y2="-3.6" width="0.127" layer="21"/>
<pad name="COIL1" x="10" y="-2.35" drill="1.1" diameter="2"/>
<pad name="COIL2" x="10" y="2.35" drill="1.1" diameter="2"/>
<pad name="CONN2" x="-8.5" y="-2.35" drill="1.1" diameter="2"/>
<pad name="CONN1" x="-1.5" y="-2.35" drill="1.1" diameter="2"/>
</package>
</packages>
</library>
<library name="con-ptr500_edit">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/4" urn="urn:adsk.eagle:footprint:9856/1" locally_modified="yes">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-10.0838" y1="-3.556" x2="-10.0838" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-3.556" x2="0" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="3.048" x2="-10.0838" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="2.159" x2="-10.0838" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="2.159" x2="0" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-2.159" x2="0" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-2.159" x2="-10.0838" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-1.397" x2="-1.0922" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.8862" y1="-1.016" x2="-1.4732" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-8.9154" y1="-1.016" x2="-6.5024" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-8.5344" y1="-1.397" x2="-6.1214" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.5052" y1="-1.016" x2="-1.4732" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-8.5344" y1="-1.016" x2="-6.5024" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-3.8862" y1="-1.016" x2="-3.5052" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-1.4732" y1="1.397" x2="-1.0922" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-8.9154" y1="-1.016" x2="-8.5344" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-6.5024" y1="1.397" x2="-6.1214" y2="1.016" width="0.1524" layer="51"/>
<wire x1="0" y1="-3.556" x2="0" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="3.937" x2="0" y2="3.937" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="3.937" x2="10.0838" y2="2.159" width="0.1524" layer="21"/>
<wire x1="0" y1="-3.556" x2="10.0838" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="0" y1="2.159" x2="0" y2="3.937" width="0.1524" layer="21"/>
<wire x1="0" y1="2.159" x2="10.0838" y2="2.159" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="2.159" x2="10.0838" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="0" y1="-2.159" x2="10.0838" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="0" y1="-2.159" x2="0" y2="2.159" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-2.159" x2="10.0838" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="6.5024" y1="-1.397" x2="8.9154" y2="1.016" width="0.1524" layer="51"/>
<wire x1="6.1214" y1="-1.016" x2="8.5344" y2="1.397" width="0.1524" layer="51"/>
<wire x1="1.0922" y1="-1.016" x2="3.5052" y2="1.397" width="0.1524" layer="51"/>
<wire x1="1.4732" y1="-1.397" x2="3.8862" y2="1.016" width="0.1524" layer="51"/>
<wire x1="6.5024" y1="-1.016" x2="8.5344" y2="1.016" width="0.6096" layer="51"/>
<wire x1="1.4732" y1="-1.016" x2="3.5052" y2="1.016" width="0.6096" layer="51"/>
<wire x1="6.1214" y1="-1.016" x2="6.5024" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="8.5344" y1="1.397" x2="8.9154" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.0922" y1="-1.016" x2="1.4732" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.5052" y1="1.397" x2="3.8862" y2="1.016" width="0.1524" layer="51"/>
<wire x1="0" y1="3.937" x2="-10.0838" y2="3.937" width="0.1524" layer="21"/>
<circle x="-2.4892" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-7.5184" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-2.4892" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-7.5184" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="7.5184" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.4892" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="7.5184" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="2.4892" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="-7.5184" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="2" x="-2.4892" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="3" x="2.4892" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="4" x="7.5184" y="0" drill="1.3208" diameter="3" rot="R90"/>
<text x="-10.0838" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.0838" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-9.144" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-4.191" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="0.762" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<text x="5.842" y="2.54" size="0.9906" layer="21" ratio="12">4</text>
<rectangle x1="-5.3848" y1="-1.905" x2="-4.6228" y2="1.905" layer="21"/>
<rectangle x1="4.6228" y1="-1.905" x2="5.3848" y2="1.905" layer="21"/>
</package>
<package name="AK500/5" urn="urn:adsk.eagle:footprint:9857/1" locally_modified="yes">
<wire x1="-12.5222" y1="-3.556" x2="-12.5222" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="-3.556" x2="-2.4892" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="2.159" x2="-12.5222" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="2.159" x2="-2.4892" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="-2.159" x2="-2.4892" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-12.5222" y1="-2.159" x2="-12.5222" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-6.0198" y1="-1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-3.9878" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="-1.016" x2="-9.017" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-1.397" x2="-8.636" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-6.0198" y1="-1.016" x2="-3.9878" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-11.049" y1="-1.016" x2="-9.017" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-6.0198" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.9878" y1="1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="-1.016" x2="-11.049" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-9.017" y1="1.397" x2="-8.636" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.4892" y1="-3.556" x2="-2.4892" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="12.5222" y1="3.937" x2="-2.4892" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="2.159" x2="-2.4892" y2="3.937" width="0.1524" layer="21"/>
<wire x1="12.5222" y1="3.937" x2="12.5222" y2="2.159" width="0.1524" layer="21"/>
<wire x1="12.5222" y1="2.159" x2="12.5222" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="-2.159" x2="12.5222" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="-2.159" x2="-2.4892" y2="2.159" width="0.1524" layer="21"/>
<wire x1="12.5222" y1="-2.159" x2="12.5222" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="3.9878" y1="-1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="6.0198" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="1.016" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.9878" y1="-1.016" x2="6.0198" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-1.016" y1="-1.016" x2="1.016" y2="1.016" width="0.6096" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="3.9878" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="6.0198" y1="1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="-1.016" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="1.016" y1="1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="8.9916" y1="-1.016" x2="11.0236" y2="1.016" width="0.6096" layer="51"/>
<wire x1="8.9916" y1="-1.397" x2="11.4046" y2="1.016" width="0.1524" layer="51"/>
<wire x1="8.6106" y1="-1.016" x2="11.0236" y2="1.397" width="0.1524" layer="51"/>
<wire x1="8.6106" y1="-1.016" x2="8.9916" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="11.0236" y1="1.397" x2="11.4046" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.4892" y1="-3.556" x2="12.5222" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="2.159" x2="12.5222" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="3.937" x2="-12.5222" y2="3.937" width="0.1524" layer="21"/>
<circle x="-5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-10.033" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-10.033" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="10.0076" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="10.0076" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-10.033" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="2" x="-5.0038" y="0" drill="1.3208" diameter="3" rot="R270"/>
<pad name="3" x="0" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="4" x="5.0038" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="5" x="10.0076" y="0" drill="1.3208" diameter="3" rot="R90"/>
<text x="-12.5984" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-12.5984" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-11.8872" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-7.0612" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="-1.7272" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<text x="3.0988" y="2.54" size="0.9906" layer="21" ratio="12">4</text>
<text x="8.1788" y="2.54" size="0.9906" layer="21" ratio="12">5</text>
<rectangle x1="-7.8994" y1="-1.905" x2="-7.1374" y2="1.905" layer="21"/>
<rectangle x1="2.1082" y1="-1.905" x2="2.8702" y2="1.905" layer="21"/>
<rectangle x1="7.1374" y1="-1.905" x2="7.8994" y2="1.905" layer="21"/>
</package>
<package name="AK500/9" urn="urn:adsk.eagle:footprint:9861/1" locally_modified="yes">
<wire x1="-22.5552" y1="-3.556" x2="-22.5552" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-22.5552" y1="-3.556" x2="-7.493" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-22.5552" y1="3.048" x2="-22.5552" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-22.5552" y1="2.159" x2="-22.5552" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-22.5552" y1="2.159" x2="-7.493" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-22.5552" y1="-2.159" x2="-7.493" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-22.5552" y1="-2.159" x2="-22.5552" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-16.0274" y1="-1.397" x2="-13.6144" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-16.4084" y1="-1.016" x2="-13.9954" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-21.4122" y1="-1.016" x2="-18.9992" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-21.0312" y1="-1.397" x2="-18.6182" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-16.0274" y1="-1.016" x2="-13.9954" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-21.0312" y1="-1.016" x2="-18.9992" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-16.4084" y1="-1.016" x2="-16.0274" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-13.9954" y1="1.397" x2="-13.6144" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-21.4122" y1="-1.016" x2="-21.0312" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-18.9992" y1="1.397" x2="-18.6182" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-7.493" y1="-3.556" x2="-7.493" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="2.159" x2="-7.493" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="-2.159" x2="-7.493" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="3.937" x2="-22.5552" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="2.159" x2="7.5438" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="-2.159" x2="7.5438" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="-3.556" x2="7.5438" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="22.5552" y1="3.937" x2="7.5438" y2="3.937" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="2.159" x2="7.5438" y2="3.937" width="0.1524" layer="21"/>
<wire x1="22.5552" y1="3.937" x2="22.5552" y2="2.159" width="0.1524" layer="21"/>
<wire x1="22.5552" y1="2.159" x2="22.5552" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="-2.159" x2="22.5552" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="-2.159" x2="7.5438" y2="2.159" width="0.1524" layer="21"/>
<wire x1="22.5552" y1="-2.159" x2="22.5552" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="13.9954" y1="-1.397" x2="16.4084" y2="1.016" width="0.1524" layer="51"/>
<wire x1="13.6144" y1="-1.016" x2="16.0274" y2="1.397" width="0.1524" layer="51"/>
<wire x1="8.636" y1="-1.016" x2="11.049" y2="1.397" width="0.1524" layer="51"/>
<wire x1="9.017" y1="-1.397" x2="11.43" y2="1.016" width="0.1524" layer="51"/>
<wire x1="13.9954" y1="-1.016" x2="16.0274" y2="1.016" width="0.6096" layer="51"/>
<wire x1="9.017" y1="-1.016" x2="11.049" y2="1.016" width="0.6096" layer="51"/>
<wire x1="13.6144" y1="-1.016" x2="13.9954" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="16.0274" y1="1.397" x2="16.4084" y2="1.016" width="0.1524" layer="51"/>
<wire x1="8.636" y1="-1.016" x2="9.017" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="11.049" y1="1.397" x2="11.43" y2="1.016" width="0.1524" layer="51"/>
<wire x1="18.9992" y1="-1.016" x2="21.0312" y2="1.016" width="0.6096" layer="51"/>
<wire x1="18.9992" y1="-1.397" x2="21.4122" y2="1.016" width="0.1524" layer="51"/>
<wire x1="18.6182" y1="-1.016" x2="21.0566" y2="1.397" width="0.1524" layer="51"/>
<wire x1="18.6182" y1="-1.016" x2="18.9992" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="21.0566" y1="1.397" x2="21.4122" y2="1.016" width="0.1524" layer="51"/>
<wire x1="7.5438" y1="-3.556" x2="22.5552" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="2.159" x2="22.5552" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="-3.556" x2="7.5438" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="3.937" x2="-7.493" y2="3.937" width="0.1524" layer="21"/>
<circle x="-15.0114" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-20.0152" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-15.0114" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-20.0152" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="15.0114" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="10.033" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="15.0114" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="10.033" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="20.0152" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="20.0152" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-20.0152" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="2" x="-15.0114" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="3" x="-10.033" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="4" x="-5.0038" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="5" x="0" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="6" x="5.0038" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="7" x="10.033" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="8" x="15.0114" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="9" x="20.0152" y="0" drill="1.3208" diameter="3" rot="R90"/>
<text x="-22.5552" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-22.5552" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-21.6408" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-16.7132" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="-11.7602" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<text x="-6.6802" y="2.54" size="0.9906" layer="21" ratio="12">4</text>
<text x="-1.8542" y="2.54" size="0.9906" layer="21" ratio="12">5</text>
<text x="2.9718" y="2.54" size="0.9906" layer="21" ratio="12">6</text>
<text x="8.3058" y="2.54" size="0.9906" layer="21" ratio="12">7</text>
<text x="13.1318" y="2.54" size="0.9906" layer="21" ratio="12">8</text>
<text x="18.1864" y="2.54" size="0.9906" layer="21" ratio="12">9</text>
<rectangle x1="-17.8816" y1="-1.905" x2="-17.1196" y2="1.905" layer="21"/>
<rectangle x1="-12.8778" y1="-1.905" x2="-12.1158" y2="1.905" layer="21"/>
<rectangle x1="-2.8448" y1="-1.905" x2="-2.0828" y2="1.905" layer="21"/>
<rectangle x1="12.1412" y1="-1.905" x2="12.9032" y2="1.905" layer="21"/>
<rectangle x1="17.1704" y1="-1.905" x2="17.9324" y2="1.905" layer="21"/>
<rectangle x1="2.1336" y1="-1.905" x2="2.8956" y2="1.905" layer="21"/>
</package>
<package name="AK500/2" urn="urn:adsk.eagle:footprint:9854/1" locally_modified="yes">
<wire x1="-5.08" y1="-3.556" x2="-5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.556" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.159" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="-1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="3.5306" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-1.4986" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.5306" y1="-1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.4986" y1="-1.016" x2="3.5306" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-3.5306" y1="-1.016" x2="-1.4986" y2="1.016" width="0.6096" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="1.4986" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.5306" y1="1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-3.5306" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-1.4986" y1="1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<circle x="2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" diameter="3" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" diameter="3" rot="R90"/>
<text x="-5.08" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="0.635" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<rectangle x1="-0.381" y1="-1.905" x2="0.381" y2="1.905" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="AK500/4" urn="urn:adsk.eagle:package:9887/1" type="box">
<description>CONNECTOR</description>
<packageinstances>
<packageinstance name="AK500/4"/>
</packageinstances>
</package3d>
<package3d name="AK500/5" urn="urn:adsk.eagle:package:9890/1" type="box">
<packageinstances>
<packageinstance name="AK500/5"/>
</packageinstances>
</package3d>
<package3d name="AK500/9" urn="urn:adsk.eagle:package:9895/1" type="box">
<packageinstances>
<packageinstance name="AK500/9"/>
</packageinstances>
</package3d>
<package3d name="AK500/2" urn="urn:adsk.eagle:package:9880/1" type="box">
<packageinstances>
<packageinstance name="AK500/2"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="D-5" urn="urn:adsk.eagle:footprint:43195/1" locally_modified="yes">
<description>&lt;b&gt;DIODE&lt;/b&gt;</description>
<wire x1="1.27" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.889" x2="-1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.889" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<pad name="A" x="2.35" y="0" drill="0.8128" diameter="1.6764"/>
<pad name="C" x="-2.35" y="0" drill="0.8128" diameter="1.6764"/>
<text x="-1.905" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.889" y1="-0.889" x2="-0.381" y2="0.889" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="D-5" urn="urn:adsk.eagle:package:43440/1" type="box">
<description>DIODE</description>
<packageinstances>
<packageinstance name="D-5"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="SparkFun-IC-Special-Function" urn="urn:adsk.eagle:library:527">
<description>&lt;h3&gt;SparkFun Special Function ICs&lt;/h3&gt;
This library contains ICs that do not really fit into the other, more generic categories.  Basically, anything that serves some function but has a bunch of brains or special bias circuitry that prevents it from being used as a general part qualifies for this category.
&lt;p&gt;Contents:
&lt;ul&gt;&lt;li&gt;555 timers&lt;/li&gt;
&lt;li&gt;LED drivers&lt;/li&gt;
&lt;li&gt;H-Bridge drivers&lt;/li&gt;
&lt;li&gt;Motor drivers&lt;/li&gt;
&lt;li&gt;Waveform generators&lt;/li&gt;
&lt;li&gt;Crypto&lt;/li&gt;
&lt;/ul&gt;&lt;/p&gt;&lt;br&gt;
We've spent an enormous amount of time creating and checking these footprints and parts, but it is &lt;b&gt; the end user's responsibility&lt;/b&gt; to ensure correctness and suitablity for a given componet or application.
&lt;br&gt;
&lt;br&gt;If you enjoy using this library, please buy one of our products at &lt;a href=" www.sparkfun.com"&gt;SparkFun.com&lt;/a&gt;.
&lt;br&gt;
&lt;br&gt;
&lt;b&gt;Licensing:&lt;/b&gt; Creative Commons ShareAlike 4.0 International - https://creativecommons.org/licenses/by-sa/4.0/
&lt;br&gt;
&lt;br&gt;
You are welcome to use this library for commercial purposes. For attribution, we ask that when you begin to sell your device using our footprint, you email us with a link to the product being sold. We want bragging rights that we helped (in a very small part) to create your 8th world wonder. We would like the opportunity to feature your device on our homepage.</description>
<packages>
<package name="DIL18" urn="urn:adsk.eagle:footprint:39151/1" library_version="1">
<description>&lt;h3&gt;Dual In Line Package - 18 Pin &lt;/h3&gt;
&lt;p&gt;Specifications:
&lt;ul&gt;&lt;li&gt;Pin count: 18&lt;/li&gt;&lt;/p&gt;
&lt;p&gt;Example device(s):
&lt;ul&gt;&lt;li&gt;LM391&lt;/li&gt;
&lt;/ul&gt;&lt;/p&gt;</description>
<wire x1="11.43" y1="2.921" x2="-11.43" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.921" x2="-11.43" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="-11.43" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.016" x2="-11.43" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-11.684" y="0" size="0.6096" layer="25" font="vector" ratio="20" rot="R90" align="bottom-center">&gt;NAME</text>
<text x="11.811" y="0" size="0.6096" layer="27" font="vector" ratio="20" rot="R90" align="top-center">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="DIL18" urn="urn:adsk.eagle:package:39200/1" type="box" library_version="1">
<description>Dual In Line Package - 18 Pin
Specifications:
Pin count: 18
Example device(s):
LM391
</description>
<packageinstances>
<packageinstance name="DIL18"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="LED-sajat">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="LED3MM" urn="urn:adsk.eagle:footprint:15654/1" locally_modified="yes">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" diameter="1.6764"/>
<pad name="K" x="1.27" y="0" drill="0.8128" diameter="1.6764"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="LED3MM" urn="urn:adsk.eagle:package:15797/1" type="box">
<description>LED
<packageinstances>
<packageinstance name="LED3MM"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="resistor-net_sajat">
<description>&lt;b&gt;Generic Resistor Networks&lt;/b&gt;&lt;p&gt;
<packages>
<package name="RN-9" urn="urn:adsk.eagle:footprint:24956/1" locally_modified="yes">
<description>&lt;b&gt;RESISTOR NETWORK&lt;/b&gt;</description>
<wire x1="11.43" y1="-1.524" x2="11.43" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.524" x2="-11.43" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.524" x2="-10.795" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.524" x2="-10.795" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.524" x2="-9.525" y2="0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="1.524" x2="-8.89" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.524" x2="-9.525" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.524" x2="-8.89" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.524" x2="-8.89" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.524" x2="-11.43" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.524" x2="11.43" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-10.7696" y1="0.6096" x2="-9.5504" y2="-0.6096" width="0.1524" layer="51"/>
<wire x1="-10.7696" y1="-0.6096" x2="-9.5504" y2="0.6096" width="0.1524" layer="51"/>
<pad name="1" x="-10.16" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-8.89" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-8.89" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
<packages3d>
<package3d name="RN-9" urn="urn:adsk.eagle:package:24977/1" type="box">
<description>RESISTOR NETWORK</description>
<packageinstances>
<packageinstance name="RN-9"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="transistor-power_SAJAT">
<description>&lt;b&gt;Power Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO262-V" urn="urn:adsk.eagle:footprint:29393/1" locally_modified="yes">
<description>&lt;b&gt;Molded Package&lt;/b&gt;</description>
<wire x1="-4.6228" y1="-1.8796" x2="4.6228" y2="-1.8796" width="0.254" layer="21"/>
<wire x1="4.6228" y1="-1.8796" x2="5.1308" y2="0.1524" width="0.254" layer="21"/>
<wire x1="5.1308" y1="0.1524" x2="5.1308" y2="1.7526" width="0.254" layer="21"/>
<wire x1="-5.1308" y1="1.7526" x2="-5.1308" y2="0.1524" width="0.254" layer="21"/>
<wire x1="-5.1308" y1="0.1524" x2="-4.6228" y2="-1.8796" width="0.254" layer="21"/>
<wire x1="-5.1308" y1="1.7526" x2="5.1308" y2="1.7526" width="0.254" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-4.953" y="-3.429" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="3.937" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.2832" y1="1.778" x2="5.2832" y2="3.2004" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="TO262-V" urn="urn:adsk.eagle:package:29496/2" type="model">
<description>Molded Package</description>
<packageinstances>
<packageinstance name="TO262-V"/>
</packageinstances>
</package3d>
</packages3d>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="6mil"/>
<param name="mdWirePad" value="6mil"/>
<param name="mdWireVia" value="6mil"/>
<param name="mdPadPad" value="6mil"/>
<param name="mdPadVia" value="6mil"/>
<param name="mdViaVia" value="6mil"/>
<param name="mdSmdPad" value="6mil"/>
<param name="mdSmdVia" value="6mil"/>
<param name="mdSmdSmd" value="6mil"/>
<param name="mdViaViaSameLayer" value="6mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="6mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="6mil"/>
<param name="msDrill" value="0.35mm"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="checkStop" value="0"/>
<param name="checkValues" value="0"/>
<param name="checkNames" value="1"/>
<param name="checkWireStubs" value="1"/>
<param name="checkPolygonWidth" value="0"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="a"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="a"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="ARDUINO_NANO" library="Arduino-clone" package="NANO" value="NANO" x="114.3" y="74.295" smashed="yes"/>
<element name="RN1" library="resistor-net_sajat" package="RN-9" package3d_urn="urn:adsk.eagle:package:24977/1" value="10K" x="107.95" y="83.185" smashed="yes" rot="R90">
<attribute name="MF" value="" x="107.95" y="83.185" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="107.95" y="83.185" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="107.95" y="83.185" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="107.95" y="83.185" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="POPULARITY" value="1" x="107.95" y="83.185" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="106.3625" y="69.85" size="1.27" layer="25" ratio="10"/>
</element>
<element name="R1" library="rcl" package="0309V" package3d_urn="urn:adsk.eagle:package:23572/1" value="150R" x="125.73" y="69.85" smashed="yes" rot="R270">
<attribute name="SPICEPREFIX" value="R" x="125.73" y="69.85" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="123.5075" y="72.9615" size="1.27" layer="25"/>
</element>
<element name="R13" library="rcl" package="0309V" package3d_urn="urn:adsk.eagle:package:23572/1" value="10K" x="129.54" y="68.58" smashed="yes" rot="R180">
<attribute name="SPICEPREFIX" value="R" x="129.54" y="68.58" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="132.715" y="71.8185" size="1.27" layer="25" rot="R180"/>
</element>
<element name="IC1" library="v-reg" library_urn="urn:adsk.eagle:library:409" package="78MXXS" package3d_urn="urn:adsk.eagle:package:30347/1" value="L7805CV" x="119.38" y="57.15" smashed="yes" rot="R90">
<attribute name="POPULARITY" value="1" x="119.38" y="57.15" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="119.634" y="50.927" size="1.016" layer="25" ratio="10"/>
</element>
<element name="X5" library="con-phoenix-350" package="1751277" package3d_urn="urn:adsk.eagle:package:9396/1" value="button1" x="97.155" y="93.345" smashed="yes" rot="R270">
<attribute name="MF" value="" x="97.155" y="93.345" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="97.155" y="93.345" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="97.155" y="93.345" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="97.155" y="93.345" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="X1" library="con-phoenix-350" package="1751277" package3d_urn="urn:adsk.eagle:package:9396/1" value="button2" x="97.155" y="74.93" smashed="yes" rot="R270">
<attribute name="MF" value="" x="97.155" y="74.93" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="97.155" y="74.93" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="97.155" y="74.93" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="97.155" y="74.93" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="STARTER/ENGINE_CUT" library="con-ptr500_edit" package="AK500/4" package3d_urn="urn:adsk.eagle:package:9887/1" value="" x="151.4475" y="51.435" smashed="yes">
<attribute name="MF" value="" x="151.4475" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="151.4475" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="151.4475" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="151.4475" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="141.3637" y="45.72" size="1.778" layer="27" ratio="10"/>
</element>
<element name="REAR.LIGHT" library="con-ptr500_edit" package="AK500/5" package3d_urn="urn:adsk.eagle:package:9890/1" value="REAR.LIGHT" x="161.925" y="68.8975" smashed="yes" rot="R90">
<attribute name="MF" value="" x="161.925" y="68.8975" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="161.925" y="68.8975" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="161.925" y="68.8975" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="161.925" y="68.8975" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="167.005" y="64.5541" size="1.016" layer="25" ratio="10" rot="R90"/>
</element>
<element name="SPEEDOMETER" library="con-ptr500_edit" package="AK500/9" package3d_urn="urn:adsk.eagle:package:9895/1" value="SPEEDOMETER" x="116.205" y="106.68" smashed="yes" rot="R180">
<attribute name="MF" value="" x="116.205" y="106.68" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="116.205" y="106.68" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="116.205" y="106.68" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="116.205" y="106.68" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="110.4773" y="110.49" size="1.016" layer="25" ratio="10"/>
</element>
<element name="D1" library="diode" package="D-5" package3d_urn="urn:adsk.eagle:package:43440/1" value="1N4004" x="135.255" y="60.325" smashed="yes" rot="R270">
<attribute name="POPULARITY" value="8" x="135.255" y="60.325" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="137.033" y="59.6265" size="1.27" layer="25" ratio="10"/>
</element>
<element name="D2" library="diode" package="D-5" package3d_urn="urn:adsk.eagle:package:43440/1" value="1N4004" x="135.255" y="67.945" smashed="yes" rot="R270">
<attribute name="POPULARITY" value="8" x="135.255" y="67.945" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="137.3505" y="67.2465" size="1.27" layer="25" ratio="10"/>
</element>
<element name="D3" library="diode" package="D-5" package3d_urn="urn:adsk.eagle:package:43440/1" value="1N4004" x="135.255" y="75.565" smashed="yes" rot="R270">
<attribute name="POPULARITY" value="8" x="135.255" y="75.565" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="137.3505" y="74.8665" size="1.27" layer="25" ratio="10"/>
</element>
<element name="D4" library="diode" package="D-5" package3d_urn="urn:adsk.eagle:package:43440/1" value="1N4004" x="135.255" y="83.185" smashed="yes" rot="R270">
<attribute name="POPULARITY" value="8" x="135.255" y="83.185" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="137.3505" y="82.4865" size="1.27" layer="25" ratio="10"/>
</element>
<element name="D5" library="diode" package="D-5" package3d_urn="urn:adsk.eagle:package:43440/1" value="1N4004" x="135.255" y="90.805" smashed="yes" rot="R270">
<attribute name="POPULARITY" value="8" x="135.255" y="90.805" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="137.3505" y="90.424" size="1.27" layer="25" ratio="10"/>
</element>
<element name="X4" library="con-ptr500_edit" package="AK500/5" package3d_urn="urn:adsk.eagle:package:9890/1" value="" x="106.045" y="51.435" smashed="yes">
<attribute name="MF" value="" x="106.045" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="106.045" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="106.045" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="106.045" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="93.4466" y="45.72" size="1.778" layer="27" ratio="10"/>
</element>
<element name="ELSő_LáMPA" library="con-ptr500_edit" package="AK500/5" package3d_urn="urn:adsk.eagle:package:9890/1" value="FRONT.LIGHT" x="151.765" y="106.68" smashed="yes" rot="R180">
<attribute name="MF" value="" x="151.765" y="106.68" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="151.765" y="106.68" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="151.765" y="106.68" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="151.765" y="106.68" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="147.4216" y="110.49" size="1.016" layer="25" ratio="10"/>
</element>
<element name="C1" library="rcl" package="C050-025X075" package3d_urn="urn:adsk.eagle:package:23637/1" value="330nF" x="125.73" y="57.15" smashed="yes" rot="R90">
<attribute name="SPICEPREFIX" value="C" x="125.73" y="57.15" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="127.381" y="56.5785" size="1.27" layer="25" ratio="10"/>
</element>
<element name="C2" library="rcl" package="C050-025X075" package3d_urn="urn:adsk.eagle:package:23637/1" value="100nF" x="117.7925" y="59.69" smashed="yes" rot="R270">
<attribute name="SPICEPREFIX" value="C" x="117.7925" y="59.69" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="116.1415" y="59.6265" size="1.27" layer="25" ratio="10" rot="R180"/>
</element>
<element name="D6" library="diode" package="D-5" package3d_urn="urn:adsk.eagle:package:43440/1" value="1N4004" x="135.255" y="98.425" smashed="yes" rot="R270">
<attribute name="POPULARITY" value="8" x="135.255" y="98.425" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="137.3505" y="98" size="1.27" layer="25" ratio="10"/>
</element>
<element name="HI.BEAM" library="relay" package="AZ9371-AZETTLER" value="AZ9371T-1A-12D" x="147.955" y="98.425" smashed="yes" rot="R180"/>
<element name="R.TURN" library="relay" package="AZ9371-AZETTLER" value="AZ9371T-1A-12D" x="147.955" y="90.805" smashed="yes" rot="R180"/>
<element name="L.TURN" library="relay" package="AZ9371-AZETTLER" value="AZ9371T-1A-12D" x="147.955" y="83.185" smashed="yes" rot="R180"/>
<element name="HORN" library="relay" package="AZ9371-AZETTLER" value="AZ9371T-1A-12D" x="147.955" y="75.565" smashed="yes" rot="R180"/>
<element name="STARTER" library="relay" package="AZ9371-AZETTLER" value="AZ9371T-1A-12D" x="147.955" y="67.945" smashed="yes" rot="R180"/>
<element name="E.CUT" library="relay" package="AZ9371-AZETTLER" value="AZ9371T-1A-12D" x="147.955" y="60.325" smashed="yes" rot="R180"/>
<element name="X2" library="con-ptr500_edit" package="AK500/4" package3d_urn="urn:adsk.eagle:package:9887/1" value="" x="161.925" y="92.075" smashed="yes" rot="R90">
<attribute name="MF" value="" x="161.925" y="92.075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="161.925" y="92.075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="161.925" y="92.075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="161.925" y="92.075" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="167.64" y="81.9912" size="1.778" layer="27" ratio="10" rot="R90"/>
</element>
<element name="ULN1" library="SparkFun-IC-Special-Function" library_urn="urn:adsk.eagle:library:527" package="DIL18" package3d_urn="urn:adsk.eagle:package:39200/1" value="ULN2803A" x="126.6825" y="88.265" smashed="yes" rot="R270">
<attribute name="VALUE" x="126.6825" y="100.076" size="1.27" layer="21" font="vector" rot="R180" align="top-center"/>
</element>
<element name="POWER" library="LED-sajat" package="LED3MM" package3d_urn="urn:adsk.eagle:package:15797/1" value="5V_ON" x="101.6" y="58.42" smashed="yes" rot="R270">
<attribute name="NAME" x="92.71" y="59.436" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="92.71" y="57.7215" size="1.27" layer="25" ratio="10"/>
</element>
<element name="R2" library="rcl" package="0309V" package3d_urn="urn:adsk.eagle:package:23572/1" value="270" x="102.87" y="62.23" smashed="yes">
<attribute name="SPICEPREFIX" value="R" x="102.87" y="62.23" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="101.854" y="61.6077" size="1.27" layer="25" ratio="10"/>
</element>
<element name="CHARGER" library="con-ptr500_edit" package="AK500/2" package3d_urn="urn:adsk.eagle:package:9880/1" value="CHARGER" x="132.715" y="51.435" smashed="yes">
<attribute name="MF" value="" x="132.715" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="132.715" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="132.715" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="132.715" y="51.435" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="132.715" y="46.99" size="1.016" layer="25" ratio="10" align="center"/>
</element>
<element name="Q2" library="transistor-power_SAJAT" package="TO262-V" package3d_urn="urn:adsk.eagle:package:29496/2" value="IRFZ44N" x="128.27" y="63.5" smashed="yes">
<attribute name="POPULARITY" value="2" x="128.27" y="63.5" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="127.635" y="59.817" size="1.016" layer="25"/>
</element>
</elements>
<signals>
<signal name="A0">
<contactref element="ARDUINO_NANO" pad="A0"/>
<contactref element="RN1" pad="9"/>
<wire x1="107.95" y1="93.345" x2="104.14" y2="93.345" width="0.8128" layer="16"/>
<contactref element="X5" pad="2"/>
<wire x1="97.055" y1="96.845" x2="100.555" y2="93.345" width="1.016" layer="16"/>
<wire x1="107.95" y1="93.345" x2="100.555" y2="93.345" width="1.016" layer="16"/>
</signal>
<signal name="A1">
<contactref element="ARDUINO_NANO" pad="A1"/>
<contactref element="RN1" pad="8"/>
<wire x1="107.95" y1="90.805" x2="104.14" y2="90.805" width="0.8128" layer="16"/>
<contactref element="X5" pad="3"/>
<wire x1="107.95" y1="90.805" x2="99.695" y2="90.805" width="1.016" layer="16"/>
<wire x1="99.695" y1="90.805" x2="97.155" y2="93.345" width="1.016" layer="16"/>
<wire x1="97.055" y1="93.345" x2="97.155" y2="93.345" width="1.016" layer="16"/>
</signal>
<signal name="A2">
<contactref element="ARDUINO_NANO" pad="A2"/>
<contactref element="RN1" pad="7"/>
<contactref element="X5" pad="4"/>
<wire x1="106.045" y1="88.265" x2="104.14" y2="88.265" width="0.8128" layer="16"/>
<wire x1="107.95" y1="88.265" x2="106.045" y2="88.265" width="1.016" layer="16"/>
<wire x1="106.045" y1="88.265" x2="98.635" y2="88.265" width="1.016" layer="16"/>
<wire x1="97.055" y1="89.845" x2="98.635" y2="88.265" width="1.016" layer="16"/>
</signal>
<signal name="A3">
<contactref element="ARDUINO_NANO" pad="A3"/>
<contactref element="RN1" pad="6"/>
<wire x1="107.95" y1="85.725" x2="104.14" y2="85.725" width="0.8128" layer="16"/>
<contactref element="X5" pad="5"/>
<wire x1="107.95" y1="85.725" x2="97.675" y2="85.725" width="1.016" layer="16"/>
<wire x1="97.675" y1="85.725" x2="97.055" y2="86.345" width="1.016" layer="16"/>
</signal>
<signal name="A4">
<contactref element="ARDUINO_NANO" pad="A4"/>
<contactref element="RN1" pad="5"/>
<wire x1="107.95" y1="83.185" x2="104.14" y2="83.185" width="0.8128" layer="16"/>
<contactref element="X1" pad="1"/>
<wire x1="107.95" y1="83.185" x2="98.31" y2="83.185" width="1.016" layer="16"/>
<wire x1="97.055" y1="81.93" x2="98.31" y2="83.185" width="1.016" layer="16"/>
</signal>
<signal name="A5">
<contactref element="ARDUINO_NANO" pad="A5"/>
<contactref element="RN1" pad="4"/>
<wire x1="107.95" y1="80.645" x2="104.14" y2="80.645" width="0.8128" layer="16"/>
<contactref element="X1" pad="2"/>
<wire x1="97.055" y1="78.43" x2="99.27" y2="80.645" width="1.016" layer="16"/>
<wire x1="107.95" y1="80.645" x2="99.27" y2="80.645" width="1.016" layer="16"/>
</signal>
<signal name="A6">
<contactref element="ARDUINO_NANO" pad="A6"/>
<contactref element="RN1" pad="3"/>
<wire x1="107.95" y1="78.105" x2="104.14" y2="78.105" width="0.8128" layer="16"/>
<contactref element="X1" pad="3"/>
<wire x1="97.055" y1="74.93" x2="100.23" y2="78.105" width="1.016" layer="16"/>
<wire x1="107.95" y1="78.105" x2="100.23" y2="78.105" width="1.016" layer="16"/>
</signal>
<signal name="GND">
<contactref element="ARDUINO_NANO" pad="GND"/>
<contactref element="IC1" pad="GND"/>
<contactref element="X5" pad="1"/>
<contactref element="X1" pad="5"/>
<contactref element="ELSő_LáMPA" pad="1"/>
<contactref element="C1" pad="2"/>
<contactref element="C2" pad="2"/>
<contactref element="X2" pad="4"/>
<contactref element="ULN1" pad="9"/>
<contactref element="R13" pad="1"/>
<wire x1="161.798" y1="99.7204" x2="161.925" y2="99.5934" width="1.27" layer="1"/>
<contactref element="SPEEDOMETER" pad="8"/>
<wire x1="130.81" y1="68.58" x2="130.81" y2="63.5" width="2" layer="16"/>
<wire x1="128.905" y1="57.15" x2="125.73" y2="57.15" width="2" layer="16"/>
<wire x1="125.73" y1="57.15" x2="121.92" y2="57.15" width="2" layer="16"/>
<wire x1="97.055" y1="67.93" x2="97.055" y2="59.155" width="2" layer="16"/>
<wire x1="99.06" y1="57.15" x2="97.055" y2="59.155" width="2" layer="16"/>
<wire x1="104.14" y1="67.945" x2="104.125" y2="67.93" width="1.27" layer="16"/>
<wire x1="104.125" y1="67.93" x2="97.055" y2="67.93" width="2" layer="16"/>
<contactref element="POWER" pad="K"/>
<wire x1="101.6" y1="57.15" x2="99.06" y2="57.15" width="2" layer="16"/>
<wire x1="130.81" y1="70.485" x2="130.81" y2="68.58" width="2" layer="16"/>
<wire x1="104.14" y1="67.945" x2="104.775" y2="67.945" width="2" layer="16"/>
<wire x1="104.3686" y1="109.855" x2="101.1936" y2="106.68" width="2" layer="1"/>
<wire x1="161.798" y1="106.68" x2="158.623" y2="109.855" width="2" layer="1"/>
<wire x1="158.623" y1="109.855" x2="104.3686" y2="109.855" width="2" layer="1"/>
<wire x1="161.798" y1="106.68" x2="161.798" y2="99.7204" width="2" layer="1"/>
<wire x1="165.4175" y1="96.1009" x2="161.925" y2="99.5934" width="2" layer="1"/>
<contactref element="REAR.LIGHT" pad="4"/>
<wire x1="161.925" y1="73.9013" x2="165.4175" y2="73.9013" width="2" layer="1"/>
<wire x1="165.4175" y1="73.9013" x2="165.4175" y2="96.1009" width="2" layer="1"/>
<contactref element="HORN" pad="CONN1"/>
<wire x1="149.455" y1="77.915" x2="153.4687" y2="73.9013" width="2" layer="1"/>
<wire x1="153.4687" y1="73.9013" x2="161.925" y2="73.9013" width="2" layer="1"/>
<wire x1="125.73" y1="59.69" x2="125.73" y2="57.15" width="2" layer="16"/>
<wire x1="130.81" y1="63.5" x2="130.81" y2="59.055" width="2" layer="16"/>
<wire x1="130.81" y1="59.055" x2="128.905" y2="57.15" width="2" layer="16"/>
<wire x1="165.4175" y1="73.9013" x2="165.4175" y2="53.013815625" width="2" layer="1"/>
<wire x1="165.4175" y1="53.013815625" x2="160.3375" y2="48.0728" width="2" layer="1"/>
<wire x1="160.3375" y1="48.0728" x2="132.2672" y2="48.0728" width="2" layer="1"/>
<wire x1="130.81" y1="71.12" x2="130.81" y2="70.485" width="1.27" layer="16"/>
<wire x1="122.8725" y1="78.105" x2="124.46" y2="78.105" width="2" layer="16"/>
<wire x1="130.81" y1="71.755" x2="130.81" y2="70.485" width="2" layer="16"/>
<wire x1="124.46" y1="78.105" x2="130.81" y2="71.755" width="2" layer="16"/>
<wire x1="122.8725" y1="78.105" x2="122.555" y2="78.105" width="2" layer="16"/>
<wire x1="97.055" y1="100.345" x2="97.055" y2="102.5675" width="2" layer="1"/>
<wire x1="101.1936" y1="106.68" x2="101.1675" y2="106.68" width="2" layer="1"/>
<wire x1="101.1675" y1="106.68" x2="97.055" y2="102.5675" width="2" layer="1"/>
<contactref element="Q2" pad="3"/>
<contactref element="CHARGER" pad="1"/>
<wire x1="121.92" y1="57.15" x2="127" y2="57.15" width="2" layer="1"/>
<wire x1="130.2004" y1="53.9496" x2="130.2004" y2="51.435" width="2" layer="1"/>
<wire x1="130.2004" y1="53.9496" x2="127" y2="57.15" width="2" layer="1"/>
<wire x1="130.2004" y1="51.435" x2="130.2004" y2="50.1396" width="2" layer="1"/>
<wire x1="130.2004" y1="50.1396" x2="132.2672" y2="48.0728" width="2" layer="1"/>
<wire x1="121.92" y1="57.15" x2="117.7925" y2="57.15" width="2" layer="16"/>
<wire x1="101.6" y1="57.15" x2="117.7925" y2="57.15" width="2" layer="16"/>
</signal>
<signal name="+5V">
<contactref element="RN1" pad="1"/>
<contactref element="ARDUINO_NANO" pad="RAW"/>
<contactref element="IC1" pad="OUT"/>
<wire x1="107.95" y1="73.025" x2="107.95" y2="65.405" width="2" layer="16"/>
<contactref element="C2" pad="1"/>
<wire x1="104.14" y1="65.405" x2="107.95" y2="65.405" width="2" layer="16"/>
<wire x1="113.665" y1="59.69" x2="107.95" y2="65.405" width="2" layer="16"/>
<contactref element="R2" pad="2"/>
<wire x1="107.95" y1="73.025" x2="107.315" y2="73.025" width="2" layer="16"/>
<wire x1="108.585" y1="73.025" x2="107.95" y2="73.025" width="2" layer="16"/>
<wire x1="104.14" y1="65.405" x2="103.505" y2="65.405" width="2" layer="16"/>
<wire x1="121.92" y1="59.69" x2="122.555" y2="59.69" width="2" layer="16"/>
<wire x1="121.92" y1="59.69" x2="117.475" y2="59.69" width="2" layer="16"/>
<wire x1="117.475" y1="59.69" x2="113.665" y2="59.69" width="2" layer="16"/>
<wire x1="117.7925" y1="62.23" x2="117.7925" y2="60.0075" width="2" layer="16"/>
<wire x1="117.7925" y1="60.0075" x2="117.475" y2="59.69" width="2" layer="16"/>
<wire x1="104.14" y1="65.405" x2="104.14" y2="62.23" width="1.016" layer="16"/>
</signal>
<signal name="N$34">
<contactref element="D4" pad="A"/>
<contactref element="L.TURN" pad="COIL2"/>
<contactref element="ULN1" pad="15"/>
<wire x1="130.4925" y1="90.805" x2="132.3975" y2="90.805" width="1.016" layer="16"/>
<wire x1="132.3975" y1="90.805" x2="133.0325" y2="90.17" width="1.016" layer="16"/>
<wire x1="133.0325" y1="90.17" x2="133.0325" y2="85.1475" width="1.016" layer="16"/>
<wire x1="135.255" y1="82.925" x2="133.0325" y2="85.1475" width="1.016" layer="16"/>
<wire x1="135.255" y1="82.925" x2="135.255" y2="80.835" width="1.016" layer="16"/>
<wire x1="135.255" y1="80.835" x2="137.955" y2="80.835" width="1.016" layer="16"/>
</signal>
<signal name="N$35">
<contactref element="D6" pad="A"/>
<contactref element="HI.BEAM" pad="COIL2"/>
<contactref element="ULN1" pad="17"/>
<wire x1="135.255" y1="95.885" x2="135.255" y2="96.075" width="0.8128" layer="16"/>
<wire x1="135.255" y1="95.885" x2="130.4925" y2="95.885" width="1.016" layer="16"/>
<wire x1="135.255" y1="96.075" x2="137.955" y2="96.075" width="1.016" layer="16"/>
</signal>
<signal name="N$36">
<contactref element="D5" pad="A"/>
<contactref element="R.TURN" pad="COIL2"/>
<wire x1="135.255" y1="88.455" x2="135.255" y2="90.4875" width="1.016" layer="16"/>
<contactref element="ULN1" pad="16"/>
<wire x1="130.4925" y1="93.345" x2="132.3975" y2="93.345" width="1.016" layer="16"/>
<wire x1="132.3975" y1="93.345" x2="135.255" y2="90.4875" width="1.016" layer="16"/>
<wire x1="135.255" y1="88.455" x2="137.955" y2="88.455" width="1.016" layer="16"/>
</signal>
<signal name="N$38">
<contactref element="D2" pad="A"/>
<contactref element="STARTER" pad="COIL2"/>
<wire x1="126.6825" y1="84.7725" x2="126.6825" y2="77.7875" width="1.016" layer="1"/>
<wire x1="126.6825" y1="77.7875" x2="133.0325" y2="71.4375" width="1.016" layer="1"/>
<wire x1="133.0325" y1="71.4375" x2="133.0325" y2="67.595834375" width="1.016" layer="1"/>
<wire x1="133.0325" y1="67.595834375" x2="135.255" y2="65.595" width="1.016" layer="1"/>
<contactref element="ULN1" pad="13"/>
<wire x1="130.4925" y1="85.725" x2="127.635" y2="85.725" width="1.016" layer="1"/>
<wire x1="127.635" y1="85.725" x2="126.6825" y2="84.7725" width="1.016" layer="1"/>
<wire x1="135.255" y1="65.595" x2="137.955" y2="65.595" width="1.016" layer="16"/>
</signal>
<signal name="N$39">
<contactref element="D1" pad="A"/>
<contactref element="E.CUT" pad="COIL2"/>
<wire x1="130.4925" y1="83.185" x2="132.3975" y2="83.185" width="1.016" layer="16"/>
<wire x1="133.0325" y1="82.55" x2="132.3975" y2="83.185" width="1.016" layer="16"/>
<wire x1="133.0325" y1="82.55" x2="133.0325" y2="59.975834375" width="1.016" layer="16"/>
<wire x1="135.255" y1="57.975" x2="133.0325" y2="59.975834375" width="1.016" layer="16"/>
<contactref element="ULN1" pad="12"/>
<wire x1="137.955" y1="57.975" x2="135.255" y2="57.975" width="1.016" layer="16"/>
</signal>
<signal name="RPM_PULSE">
<contactref element="X4" pad="3"/>
<wire x1="106.045" y1="51.435" x2="112.395" y2="57.785" width="1.016" layer="1"/>
<contactref element="SPEEDOMETER" pad="6"/>
<wire x1="112.395" y1="105.4862" x2="111.2012" y2="106.68" width="1.016" layer="1"/>
<wire x1="112.395" y1="57.785" x2="112.395" y2="105.4862" width="1.016" layer="1"/>
</signal>
<signal name="NEUTRAL">
<contactref element="SPEEDOMETER" pad="5"/>
<contactref element="X4" pad="4"/>
<wire x1="114.2238" y1="69.1388" x2="114.266578125" y2="69.181578125" width="1.016" layer="1"/>
<wire x1="111.0488" y1="51.435" x2="114.2238" y2="54.61" width="1.016" layer="1"/>
<wire x1="114.2238" y1="69.1388" x2="114.2238" y2="54.61" width="1.016" layer="1"/>
<wire x1="114.266578125" y1="104.741578125" x2="116.205" y2="106.68" width="1.016" layer="1"/>
<wire x1="114.266578125" y1="69.181578125" x2="114.266578125" y2="104.741578125" width="1.016" layer="1"/>
</signal>
<signal name="FUEL_SIGNAL">
<contactref element="SPEEDOMETER" pad="4"/>
<contactref element="X4" pad="5"/>
<wire x1="121.2088" y1="106.68" x2="121.2088" y2="106.6038" width="1.27" layer="1"/>
<wire x1="121.2088" y1="106.6038" x2="116.205" y2="101.6" width="1.016" layer="1"/>
<wire x1="116.205" y1="51.5874" x2="116.0526" y2="51.435" width="1.27" layer="1"/>
<wire x1="116.205" y1="101.6" x2="116.205" y2="51.5874" width="1.016" layer="1"/>
</signal>
<signal name="SPEED_PULSE">
<contactref element="X4" pad="2"/>
<wire x1="110.49" y1="60.8838" x2="101.0412" y2="51.435" width="1.016" layer="1"/>
<contactref element="SPEEDOMETER" pad="7"/>
<wire x1="106.172" y1="106.68" x2="110.49" y2="102.362" width="1.016" layer="1"/>
<wire x1="110.49" y1="102.362" x2="110.49" y2="60.8838" width="1.016" layer="1"/>
</signal>
<signal name="L.TURN">
<contactref element="SPEEDOMETER" pad="1"/>
<contactref element="ELSő_LáMPA" pad="5"/>
<contactref element="L.TURN" pad="CONN2"/>
<wire x1="153.28" y1="77.5425" x2="153.28" y2="85.535" width="2" layer="16"/>
<wire x1="153.28" y1="85.535" x2="153.28" y2="92.8375" width="2" layer="16"/>
<wire x1="153.28" y1="92.8375" x2="141.7574" y2="104.3601" width="2" layer="16"/>
<wire x1="141.7574" y1="104.3601" x2="141.7574" y2="106.68" width="2" layer="16"/>
<wire x1="156.455" y1="85.535" x2="153.28" y2="85.535" width="2" layer="16"/>
<wire x1="141.7574" y1="106.68" x2="136.2202" y2="106.68" width="1.016" layer="1"/>
<contactref element="REAR.LIGHT" pad="3"/>
<wire x1="161.925" y1="68.8975" x2="153.28" y2="77.5425" width="2" layer="16"/>
</signal>
<signal name="R.TURN">
<contactref element="R.TURN" pad="CONN2"/>
<contactref element="ELSő_LáMPA" pad="3"/>
<contactref element="SPEEDOMETER" pad="3"/>
<wire x1="151.765" y1="106.68" x2="147.955" y2="102.87" width="1.016" layer="1"/>
<wire x1="147.955" y1="102.87" x2="130.048" y2="102.87" width="1.016" layer="1"/>
<wire x1="130.048" y1="102.87" x2="126.238" y2="106.68" width="1.016" layer="1"/>
<wire x1="151.765" y1="106.68" x2="151.765" y2="97.845" width="2" layer="16"/>
<wire x1="151.765" y1="97.845" x2="156.455" y2="93.155" width="2" layer="16"/>
<wire x1="156.455" y1="93.155" x2="159.0675" y2="90.5425" width="2" layer="16"/>
<wire x1="159.0675" y1="81.7626" x2="159.0675" y2="90.5425" width="2" layer="16"/>
<contactref element="REAR.LIGHT" pad="5"/>
<wire x1="161.925" y1="78.9051" x2="159.0675" y2="81.7626" width="2" layer="16"/>
</signal>
<signal name="STARTER2">
<contactref element="STARTER" pad="CONN1"/>
<contactref element="STARTER/ENGINE_CUT" pad="1"/>
<wire x1="143.9291" y1="51.435" x2="143.8275" y2="51.5366" width="2" layer="16"/>
<wire x1="143.8275" y1="51.5366" x2="143.8275" y2="64.6675" width="2" layer="16"/>
<wire x1="143.8275" y1="64.6675" x2="149.455" y2="70.295" width="2" layer="16"/>
</signal>
<signal name="HI.BEAM">
<contactref element="HI.BEAM" pad="CONN1"/>
<contactref element="ELSő_LáMPA" pad="4"/>
<contactref element="SPEEDOMETER" pad="2"/>
<wire x1="131.2164" y1="106.68" x2="133.4389" y2="104.4575" width="1.016" layer="1"/>
<wire x1="144.5387" y1="104.4575" x2="146.7612" y2="106.68" width="1.016" layer="1"/>
<wire x1="133.4389" y1="104.4575" x2="144.5387" y2="104.4575" width="1.016" layer="1"/>
<wire x1="146.7612" y1="106.68" x2="146.7612" y2="103.4688" width="2" layer="16"/>
<wire x1="146.7612" y1="103.4688" x2="149.455" y2="100.775" width="2" layer="16"/>
</signal>
<signal name="HEADLIGHT">
<contactref element="ELSő_LáMPA" pad="2"/>
<contactref element="HI.BEAM" pad="CONN2"/>
<contactref element="X2" pad="3"/>
<wire x1="156.455" y1="100.6512" x2="156.455" y2="100.775" width="2" layer="16"/>
<wire x1="156.455" y1="100.775" x2="161.925" y2="94.5642" width="2" layer="16"/>
<wire x1="156.7688" y1="106.68" x2="156.455" y2="100.6512" width="2" layer="16"/>
</signal>
<signal name="REAR.BRAKE.SW_A7">
<contactref element="ARDUINO_NANO" pad="A7"/>
<contactref element="RN1" pad="2"/>
<contactref element="X1" pad="4"/>
<wire x1="107.95" y1="75.565" x2="104.14" y2="75.565" width="1.016" layer="16"/>
<contactref element="X4" pad="1"/>
<wire x1="97.055" y1="71.43" x2="97.055" y2="71.33" width="1.27" layer="16"/>
<wire x1="94.361" y1="68.636" x2="97.055" y2="71.33" width="1.016" layer="16"/>
<wire x1="97.055" y1="71.43" x2="97.465" y2="71.43" width="1.27" layer="16"/>
<wire x1="97.465" y1="71.43" x2="101.6" y2="75.565" width="1.016" layer="16"/>
<wire x1="104.14" y1="75.565" x2="101.6" y2="75.565" width="1.016" layer="16"/>
<wire x1="96.012" y1="51.435" x2="94.361" y2="53.086" width="1.016" layer="16"/>
<wire x1="94.361" y1="53.086" x2="94.361" y2="68.636" width="1.016" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="D3" pad="A"/>
<contactref element="HORN" pad="COIL2"/>
<wire x1="133.0198" y1="75.22874375" x2="135.255" y2="73.215" width="1.016" layer="1"/>
<wire x1="133.0198" y1="86.995" x2="133.0198" y2="75.22874375" width="1.016" layer="1"/>
<wire x1="131.7498" y1="88.265" x2="133.0198" y2="86.995" width="1.016" layer="1"/>
<contactref element="ULN1" pad="14"/>
<wire x1="130.4925" y1="88.265" x2="131.7498" y2="88.265" width="1.016" layer="1"/>
<wire x1="135.255" y1="73.215" x2="137.955" y2="73.215" width="1.016" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="ARDUINO_NANO" pad="D10"/>
<contactref element="ULN1" pad="2"/>
<wire x1="122.8725" y1="95.885" x2="119.38" y2="95.885" width="1.016" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="ARDUINO_NANO" pad="D9"/>
<contactref element="ULN1" pad="3"/>
<wire x1="119.38" y1="93.345" x2="122.8725" y2="93.345" width="1.016" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="ARDUINO_NANO" pad="D8"/>
<contactref element="ULN1" pad="4"/>
<wire x1="122.8725" y1="90.805" x2="119.38" y2="90.805" width="1.016" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="ARDUINO_NANO" pad="D7"/>
<contactref element="ULN1" pad="5"/>
<wire x1="119.38" y1="88.265" x2="122.8725" y2="88.265" width="1.016" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="ARDUINO_NANO" pad="D6"/>
<contactref element="ULN1" pad="6"/>
<wire x1="122.8725" y1="85.725" x2="119.38" y2="85.725" width="1.016" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="ARDUINO_NANO" pad="D5"/>
<contactref element="ULN1" pad="7"/>
<wire x1="122.8725" y1="83.185" x2="119.38" y2="83.185" width="1.016" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="R1" pad="1"/>
<contactref element="ARDUINO_NANO" pad="D2"/>
<wire x1="119.38" y1="75.565" x2="121.285" y2="75.565" width="1.016" layer="16"/>
<wire x1="125.73" y1="71.12" x2="121.285" y2="75.565" width="1.016" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="R1" pad="2"/>
<contactref element="R13" pad="2"/>
<wire x1="128.27" y1="68.58" x2="125.73" y2="68.58" width="1.016" layer="16"/>
<wire x1="125.73" y1="64.135" x2="125.73" y2="68.58" width="1.016" layer="16"/>
<wire x1="125.73" y1="63.5" x2="125.73" y2="62.865" width="2" layer="16"/>
<wire x1="125.73" y1="63.5" x2="125.73" y2="64.135" width="2" layer="16"/>
<contactref element="Q2" pad="1"/>
</signal>
<signal name="BRAKE_LIGHT">
<contactref element="REAR.LIGHT" pad="1"/>
<wire x1="128.27" y1="63.5" x2="128.27" y2="64.135" width="2" layer="1"/>
<contactref element="Q2" pad="2"/>
<wire x1="128.27" y1="60.325" x2="133.985" y2="54.61" width="2" layer="1"/>
<wire x1="133.985" y1="54.61" x2="157.6705" y2="54.61" width="2" layer="1"/>
<wire x1="157.6705" y1="54.61" x2="161.925" y2="58.8645" width="2" layer="1"/>
<wire x1="128.27" y1="63.5" x2="128.27" y2="60.325" width="2" layer="1"/>
</signal>
<signal name="E.CUT">
<contactref element="E.CUT" pad="CONN2"/>
<contactref element="STARTER/ENGINE_CUT" pad="4"/>
<wire x1="158.9659" y1="51.5916" x2="156.455" y2="54.1025" width="2" layer="16"/>
<wire x1="156.455" y1="62.675" x2="156.455" y2="54.1025" width="2" layer="16"/>
<wire x1="158.9659" y1="51.5916" x2="158.9659" y2="51.435" width="2" layer="16"/>
</signal>
<signal name="STARTER">
<contactref element="STARTER" pad="CONN2"/>
<contactref element="STARTER/ENGINE_CUT" pad="2"/>
<wire x1="153.48" y1="70.295" x2="156.455" y2="70.295" width="2" layer="16"/>
<wire x1="148.9583" y1="51.435" x2="146.685" y2="53.7083" width="2" layer="16"/>
<wire x1="146.685" y1="53.7083" x2="146.685" y2="63.5" width="2" layer="16"/>
<wire x1="146.685" y1="63.5" x2="153.48" y2="70.295" width="2" layer="16"/>
</signal>
<signal name="E.CUT2">
<contactref element="E.CUT" pad="CONN1"/>
<contactref element="STARTER/ENGINE_CUT" pad="3"/>
<wire x1="153.9367" y1="51.435" x2="153.9367" y2="51.5258" width="2" layer="16"/>
<wire x1="153.9367" y1="51.5258" x2="149.455" y2="56.0075" width="2" layer="16"/>
<wire x1="149.455" y1="56.0075" x2="149.455" y2="62.675" width="2" layer="16"/>
</signal>
<signal name="LED">
<contactref element="POWER" pad="A"/>
<contactref element="R2" pad="1"/>
<wire x1="101.6" y1="62.23" x2="101.6" y2="59.69" width="1.016" layer="16"/>
</signal>
<signal name="+12V">
<contactref element="IC1" pad="IN"/>
<contactref element="C1" pad="1"/>
<wire x1="125.73" y1="54.61" x2="121.92" y2="54.61" width="2" layer="16"/>
<wire x1="121.92" y1="54.61" x2="121.285" y2="54.61" width="2" layer="16"/>
<contactref element="D1" pad="C"/>
<contactref element="D2" pad="C"/>
<contactref element="D3" pad="C"/>
<contactref element="D4" pad="C"/>
<contactref element="D5" pad="C"/>
<contactref element="D6" pad="C"/>
<contactref element="HI.BEAM" pad="COIL1"/>
<contactref element="R.TURN" pad="CONN1"/>
<contactref element="R.TURN" pad="COIL1"/>
<contactref element="L.TURN" pad="COIL1"/>
<contactref element="L.TURN" pad="CONN1"/>
<contactref element="HORN" pad="COIL1"/>
<contactref element="STARTER" pad="COIL1"/>
<contactref element="E.CUT" pad="COIL1"/>
<wire x1="141.2875" y1="77.7875" x2="141.2875" y2="69.5325" width="2" layer="16"/>
<wire x1="141.2875" y1="69.5325" x2="141.2875" y2="62.5475" width="2" layer="16"/>
<contactref element="X2" pad="2"/>
<wire x1="141.2875" y1="62.5475" x2="141.2875" y2="56.8325" width="2" layer="16"/>
<wire x1="149.455" y1="85.535" x2="140.97" y2="85.535" width="2" layer="16"/>
<wire x1="140.97" y1="85.535" x2="140.6525" y2="85.535" width="1.27" layer="16"/>
<wire x1="140.6525" y1="93.155" x2="140.97" y2="93.155" width="1.27" layer="16"/>
<wire x1="141.2875" y1="93.155" x2="141.2875" y2="85.535" width="2" layer="16"/>
<wire x1="141.2875" y1="85.535" x2="141.2875" y2="77.7875" width="2" layer="16"/>
<contactref element="ULN1" pad="10"/>
<wire x1="141.2875" y1="97.4725" x2="141.2875" y2="93.155" width="2" layer="16"/>
<contactref element="REAR.LIGHT" pad="2"/>
<wire x1="161.925" y1="63.8937" x2="162.0012" y2="63.8937" width="2" layer="16"/>
<wire x1="165.4175" y1="67.31" x2="162.0012" y2="63.8937" width="2" layer="16"/>
<wire x1="163.5125" y1="109.855" x2="165.4175" y2="107.95" width="2" layer="16"/>
<wire x1="149.455" y1="93.155" x2="140.97" y2="93.155" width="2" layer="16"/>
<wire x1="165.4175" y1="107.95" x2="165.4175" y2="89.5858" width="2" layer="16"/>
<wire x1="165.4175" y1="89.5858" x2="165.4175" y2="67.31" width="2" layer="16"/>
<wire x1="161.925" y1="89.5858" x2="165.4175" y2="89.5858" width="2" layer="16"/>
<wire x1="139.065" y1="54.61" x2="141.2875" y2="56.8325" width="2" layer="16"/>
<contactref element="SPEEDOMETER" pad="9"/>
<wire x1="96.1898" y1="106.68" x2="99.3648" y2="109.855" width="2" layer="16"/>
<wire x1="99.3648" y1="109.855" x2="139.065" y2="109.855" width="2" layer="16"/>
<wire x1="139.065" y1="109.855" x2="163.5125" y2="109.855" width="2" layer="16"/>
<wire x1="137.955" y1="77.915" x2="141.16" y2="77.915" width="2" layer="16"/>
<wire x1="141.16" y1="77.915" x2="141.2875" y2="77.7875" width="2" layer="16"/>
<wire x1="139.065" y1="104.775" x2="139.065" y2="109.855" width="1.8" layer="16"/>
<wire x1="137.955" y1="85.535" x2="140.6525" y2="85.535" width="2" layer="16"/>
<wire x1="140.6525" y1="85.535" x2="141.2875" y2="85.535" width="2" layer="16"/>
<wire x1="137.955" y1="70.295" x2="140.525" y2="70.295" width="2" layer="16"/>
<wire x1="140.525" y1="70.295" x2="141.2875" y2="69.5325" width="2" layer="16"/>
<wire x1="137.955" y1="62.675" x2="141.16" y2="62.675" width="2" layer="16"/>
<wire x1="141.16" y1="62.675" x2="141.2875" y2="62.5475" width="2" layer="16"/>
<wire x1="137.955" y1="93.155" x2="140.6525" y2="93.155" width="2" layer="16"/>
<wire x1="140.6525" y1="93.155" x2="141.2875" y2="93.155" width="2" layer="16"/>
<wire x1="125.73" y1="54.61" x2="135.255" y2="54.61" width="2" layer="16"/>
<wire x1="135.255" y1="54.61" x2="139.065" y2="54.61" width="2" layer="16"/>
<wire x1="130.4925" y1="78.105" x2="130.81" y2="78.105" width="2" layer="16"/>
<wire x1="130.4925" y1="78.105" x2="128.27" y2="78.105" width="2" layer="16"/>
<wire x1="128.27" y1="78.105" x2="126.6825" y2="79.6925" width="2" layer="16"/>
<wire x1="126.6825" y1="100.33" x2="126.6825" y2="79.6925" width="2" layer="16"/>
<wire x1="139.065" y1="104.775" x2="137.795" y2="103.505" width="1.8" layer="16"/>
<wire x1="137.795" y1="103.505" x2="129.8575" y2="103.505" width="2" layer="16"/>
<wire x1="129.8575" y1="103.505" x2="126.6825" y2="100.33" width="2" layer="16"/>
<wire x1="137.955" y1="100.775" x2="137.955" y2="103.345" width="2" layer="16"/>
<wire x1="137.955" y1="103.345" x2="137.795" y2="103.505" width="2" layer="16"/>
<wire x1="137.955" y1="100.775" x2="141.2575" y2="97.4725" width="2" layer="16"/>
<wire x1="141.2575" y1="97.4725" x2="141.2875" y2="97.4725" width="2" layer="16"/>
<wire x1="137.955" y1="62.675" x2="135.255" y2="62.675" width="1.016" layer="16"/>
<wire x1="137.955" y1="70.295" x2="135.255" y2="70.295" width="1.016" layer="16"/>
<wire x1="137.955" y1="77.915" x2="135.255" y2="77.915" width="1.016" layer="16"/>
<wire x1="137.955" y1="85.535" x2="135.255" y2="85.535" width="1.016" layer="16"/>
<wire x1="137.955" y1="93.155" x2="135.255" y2="93.155" width="1.016" layer="16"/>
<wire x1="137.955" y1="100.775" x2="135.255" y2="100.775" width="1.016" layer="16"/>
<contactref element="CHARGER" pad="2"/>
<wire x1="135.2296" y1="51.435" x2="135.2296" y2="54.5846" width="2" layer="16"/>
<wire x1="135.2296" y1="54.5846" x2="135.255" y2="54.61" width="2" layer="16"/>
</signal>
<signal name="HORN">
<contactref element="HORN" pad="CONN2"/>
<contactref element="X2" pad="1"/>
<wire x1="161.925" y1="84.5566" x2="156.455" y2="77.915" width="2" layer="1"/>
</signal>
</signals>
<mfgpreviewcolors>
<mfgpreviewcolor name="soldermaskcolor" color="0xC8008000"/>
<mfgpreviewcolor name="silkscreencolor" color="0xFFFEFEFE"/>
<mfgpreviewcolor name="backgroundcolor" color="0xFF282828"/>
<mfgpreviewcolor name="coppercolor" color="0xFFFFBF00"/>
<mfgpreviewcolor name="substratecolor" color="0xFF786E46"/>
</mfgpreviewcolors>
<errors>
<approved hash="23,16,8162ec04e84e8528"/>
<approved hash="23,16,c6b6a150ab6dcc8b"/>
<approved hash="23,16,a8a3e9c5e3f5a293"/>
<approved hash="23,16,95a2fd44fb769390"/>
<approved hash="23,16,0248745878670e77"/>
<approved hash="23,16,54a2a5445dc3ac25"/>
<approved hash="23,16,48c4482272b57253"/>
<approved hash="23,16,86eae80cfa0f94e9"/>
<approved hash="23,16,d25306f5fe8e2a28"/>
<approved hash="23,16,48958bf380154373"/>
<approved hash="23,1,95a14b47490a97ec"/>
</errors>
</board>
</drawing>
<compatibility>
<note version="6.3" minversion="6.2.2" severity="warning">
Since Version 6.2.2 text objects can contain more than one line,
which will not be processed correctly with this version.
</note>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports Fusion synchronisation.
This feature will not be available in this version and saving
the document will break the link to the Fusion PCB feature.
</note>
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
<note version="8.5" severity="warning">
Since Version 8.5, EAGLE supports locking for holes, vias, wires and polygons.
The locking property on all objects of these types will not be understood in this version.
</note>
</compatibility>
</eagle>
