#ifndef	_HTC_H_
#warning Header file pic12f609.h included directly. Use #include <htc.h> instead.
#endif
/* header file for the MICROCHIP PIC microcontroller
 *  12F609
#ifndef __PIC12F609_H
#define __PIC12F609_H
// Configuration mask definitions
// Config Register: CONFIG
#define CONFIG               0x2007
// Oscillator Selection bits
// RC oscillator: CLKOUT function on GP4/OSC2/CLKOUT pin, RC on GP5/OSC1/CLKIN
#define FOSC_EXTRCCLK        0xFFFF
// RCIO oscillator: I/O function on GP4/OSC2/CLKOUT pin, RC on GP5/OSC1/CLKIN
#define FOSC_EXTRCIO         0xFFFE
// INTOSC oscillator: CLKOUT function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN
#define FOSC_INTOSCCLK       0xFFFD
// INTOSCIO oscillator: I/O function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN
#define FOSC_INTOSCIO        0xFFFC
// EC: I/O function on GP4/OSC2/CLKOUT pin, CLKIN on GP5/OSC1/CLKIN
#define FOSC_EC              0xFFFB
// HS oscillator: High-speed crystal/resonator on GP4/OSC2/CLKOUT and GP5/OSC1/CLKIN
#define FOSC_HS              0xFFFA
// XT oscillator: Crystal/resonator on GP4/OSC2/CLKOUT and GP5/OSC1/CLKIN
#define FOSC_XT              0xFFF9
// LP oscillator: Low-power crystal on GP4/OSC2/CLKOUT and GP5/OSC1/CLKIN
#define FOSC_LP              0xFFF8
// Watchdog Timer Enable bit
// WDT enabled
#define WDTE_ON              0xFFFF
// WDT disabled and can be enabled by SWDTEN bit of the WDTCON register
#define WDTE_OFF             0xFFF7
// Power-up Timer Enable bit
// PWRT disabled
#define PWRTE_OFF            0xFFFF
// PWRT enabled
#define PWRTE_ON             0xFFEF
// MCLR Pin Function Select bit
// MCLR pin function is MCLR
#define MCLRE_ON             0xFFFF
// MCLR pin function is digital input, MCLR internally tied to VDD
#define MCLRE_OFF            0xFFDF
// Code Protection bit
// Program memory code protection is disabled
#define CP_OFF               0xFFFF
// Program memory code protection is enabled
#define CP_ON                0xFFBF
// Internal Oscillator Frequency Select
// 8 MHz
#define IOSCFS_8MHZ          0xFFFF
// 4 MHz
#define IOSCFS_4MHZ          0xFF7F
// Brown-out Reset Selection bits
// BOR enabled
#define BOREN_ON             0xFFFF
// BOR enabled during operation and disabled in Sleep
#define BOREN_NSLEEP         0xFEFF
// BOR disabled
#define BOREN_OFF            0xFCFF
// Special function register definitions
// Register: INDF
volatile unsigned char           INDF                @ 0x000;
// bit and bitfield definitions
// Register: TMR0
volatile unsigned char           TMR0                @ 0x001;
// Register: PCL
volatile unsigned char           PCL                 @ 0x002;
// Register: STATUS
volatile unsigned char           STATUS              @ 0x003;
volatile bit CARRY               @ ((unsigned)&STATUS*8)+0;
volatile bit DC                  @ ((unsigned)&STATUS*8)+1;
volatile bit ZERO                @ ((unsigned)&STATUS*8)+2;
volatile bit nPD                 @ ((unsigned)&STATUS*8)+3;
volatile bit nTO                 @ ((unsigned)&STATUS*8)+4;
volatile bit IRP                 @ ((unsigned)&STATUS*8)+7;
volatile bit RP0                 @ ((unsigned)&STATUS*8)+5;
volatile bit RP1                 @ ((unsigned)&STATUS*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	C                   : 1;
        unsigned	DC                  : 1;
        unsigned	Z                   : 1;
        unsigned	nPD                 : 1;
        unsigned	nTO                 : 1;
        unsigned	RP                  : 2;
        unsigned	IRP                 : 1;
    struct {
        unsigned	                    : 5;
        unsigned	RP0                 : 1;
        unsigned	RP1                 : 1;
} STATUSbits @ 0x003;
#endif
// Register: FSR
volatile unsigned char           FSR                 @ 0x004;
// Register: GPIO
volatile unsigned char           GPIO                @ 0x005;
volatile unsigned char           PORTA               @ 0x005;
volatile bit GP0                 @ ((unsigned)&GPIO*8)+0;
volatile bit GP1                 @ ((unsigned)&GPIO*8)+1;
volatile bit GP2                 @ ((unsigned)&GPIO*8)+2;
volatile bit GP3                 @ ((unsigned)&GPIO*8)+3;
volatile bit GP4                 @ ((unsigned)&GPIO*8)+4;
volatile bit GP5                 @ ((unsigned)&GPIO*8)+5;
volatile bit GPIO0               @ ((unsigned)&GPIO*8)+0;
volatile bit GPIO1               @ ((unsigned)&GPIO*8)+1;
volatile bit GPIO2               @ ((unsigned)&GPIO*8)+2;
volatile bit GPIO3               @ ((unsigned)&GPIO*8)+3;
volatile bit GPIO4               @ ((unsigned)&GPIO*8)+4;
volatile bit GPIO5               @ ((unsigned)&GPIO*8)+5;
volatile bit RA0                 @ ((unsigned)&GPIO*8)+0;
volatile bit RA1                 @ ((unsigned)&GPIO*8)+1;
volatile bit RA2                 @ ((unsigned)&GPIO*8)+2;
volatile bit RA3                 @ ((unsigned)&GPIO*8)+3;
volatile bit RA4                 @ ((unsigned)&GPIO*8)+4;
volatile bit RA5                 @ ((unsigned)&GPIO*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	GP0                 : 1;
        unsigned	GP1                 : 1;
        unsigned	GP2                 : 1;
        unsigned	GP3                 : 1;
        unsigned	GP4                 : 1;
        unsigned	GP5                 : 1;
    struct {
        unsigned	GPIO0               : 1;
        unsigned	GPIO1               : 1;
        unsigned	GPIO2               : 1;
        unsigned	GPIO3               : 1;
        unsigned	GPIO4               : 1;
        unsigned	GPIO5               : 1;
    struct {
        unsigned	RA0                 : 1;
        unsigned	RA1                 : 1;
        unsigned	RA2                 : 1;
        unsigned	RA3                 : 1;
        unsigned	RA4                 : 1;
        unsigned	RA5                 : 1;
} GPIObits @ 0x005;
#endif
// Register: PCLATH
volatile unsigned char           PCLATH              @ 0x00A;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 5;
} PCLATHbits @ 0x00A;
#endif
// Register: INTCON
volatile unsigned char           INTCON              @ 0x00B;
volatile bit GPIF                @ ((unsigned)&INTCON*8)+0;
volatile bit INTF                @ ((unsigned)&INTCON*8)+1;
volatile bit TMR0IF              @ ((unsigned)&INTCON*8)+2;
volatile bit GPIE                @ ((unsigned)&INTCON*8)+3;
volatile bit INTE                @ ((unsigned)&INTCON*8)+4;
volatile bit TMR0IE              @ ((unsigned)&INTCON*8)+5;
volatile bit PEIE                @ ((unsigned)&INTCON*8)+6;
volatile bit GIE                 @ ((unsigned)&INTCON*8)+7;
volatile bit T0IF                @ ((unsigned)&INTCON*8)+2;
volatile bit T0IE                @ ((unsigned)&INTCON*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	GPIF                : 1;
        unsigned	INTF                : 1;
        unsigned	TMR0IF              : 1;
        unsigned	GPIE                : 1;
        unsigned	INTE                : 1;
        unsigned	TMR0IE              : 1;
        unsigned	PEIE                : 1;
        unsigned	GIE                 : 1;
    struct {
        unsigned	                    : 2;
        unsigned	T0IF                : 1;
        unsigned	: 2;
        unsigned	T0IE                : 1;
} INTCONbits @ 0x00B;
#endif
// Register: PIR1
volatile unsigned char           PIR1                @ 0x00C;
volatile bit TMR1IF              @ ((unsigned)&PIR1*8)+0;
volatile bit C1IF                @ ((unsigned)&PIR1*8)+3;
volatile bit T1IF                @ ((unsigned)&PIR1*8)+0;
volatile bit CMIF                @ ((unsigned)&PIR1*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TMR1IF              : 1;
        unsigned	                    : 2;
        unsigned	C1IF                : 1;
    struct {
        unsigned	T1IF                : 1;
        unsigned	: 2;
        unsigned	CMIF                : 1;
} PIR1bits @ 0x00C;
#endif
// Register: TMR1L
volatile unsigned char           TMR1L               @ 0x00E;
// Register: TMR1H
volatile unsigned char           TMR1H               @ 0x00F;
// Register: TMR1
volatile unsigned int            TMR1                @ 0x00E;
// Register: T1CON
volatile unsigned char           T1CON               @ 0x010;
volatile bit TMR1ON              @ ((unsigned)&T1CON*8)+0;
volatile bit TMR1CS              @ ((unsigned)&T1CON*8)+1;
volatile bit nT1SYNC             @ ((unsigned)&T1CON*8)+2;
volatile bit T1OSCEN             @ ((unsigned)&T1CON*8)+3;
volatile bit TMR1GE              @ ((unsigned)&T1CON*8)+6;
volatile bit T1GINV              @ ((unsigned)&T1CON*8)+7;
volatile bit T1CKPS0             @ ((unsigned)&T1CON*8)+4;
volatile bit T1CKPS1             @ ((unsigned)&T1CON*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TMR1ON              : 1;
        unsigned	TMR1CS              : 1;
        unsigned	nT1SYNC             : 1;
        unsigned	T1OSCEN             : 1;
        unsigned	T1CKPS              : 2;
        unsigned	TMR1GE              : 1;
        unsigned	T1GINV              : 1;
    struct {
        unsigned	                    : 4;
        unsigned	T1CKPS0             : 1;
        unsigned	T1CKPS1             : 1;
} T1CONbits @ 0x010;
#endif
// Register: VRCON
volatile unsigned char           VRCON               @ 0x019;
volatile bit FBREN               @ ((unsigned)&VRCON*8)+4;
volatile bit VRR                 @ ((unsigned)&VRCON*8)+5;
volatile bit C1VREN              @ ((unsigned)&VRCON*8)+7;
volatile bit VR0                 @ ((unsigned)&VRCON*8)+0;
volatile bit VR1                 @ ((unsigned)&VRCON*8)+1;
volatile bit VR2                 @ ((unsigned)&VRCON*8)+2;
volatile bit VR3                 @ ((unsigned)&VRCON*8)+3;
volatile bit FVREN               @ ((unsigned)&VRCON*8)+4;
volatile bit CMVREN              @ ((unsigned)&VRCON*8)+7;
volatile bit VP6EN               @ ((unsigned)&VRCON*8)+4;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	VR                  : 4;
        unsigned	FBREN               : 1;
        unsigned	VRR                 : 1;
        unsigned	                    : 1;
        unsigned	C1VREN              : 1;
    struct {
        unsigned	VR0                 : 1;
        unsigned	VR1                 : 1;
        unsigned	VR2                 : 1;
        unsigned	VR3                 : 1;
        unsigned	FVREN               : 1;
        unsigned	: 2;
        unsigned	CMVREN              : 1;
    struct {
        unsigned	: 4;
        unsigned	VP6EN               : 1;
} VRCONbits @ 0x019;
#endif
// Register: CMCON0
volatile unsigned char           CMCON0              @ 0x01A;
volatile bit C1CH                @ ((unsigned)&CMCON0*8)+0;
volatile bit C1R                 @ ((unsigned)&CMCON0*8)+2;
volatile bit C1POL               @ ((unsigned)&CMCON0*8)+4;
volatile bit C1OE                @ ((unsigned)&CMCON0*8)+5;
volatile bit C1OUT               @ ((unsigned)&CMCON0*8)+6;
volatile bit C1ON                @ ((unsigned)&CMCON0*8)+7;
volatile bit C1CH0               @ ((unsigned)&CMCON0*8)+0;
volatile bit CMR                 @ ((unsigned)&CMCON0*8)+2;
volatile bit CMPOL               @ ((unsigned)&CMCON0*8)+4;
volatile bit CMOE                @ ((unsigned)&CMCON0*8)+5;
volatile bit COUT                @ ((unsigned)&CMCON0*8)+6;
volatile bit CMON                @ ((unsigned)&CMCON0*8)+7;
volatile bit CMCH                @ ((unsigned)&CMCON0*8)+0;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	C1CH                : 1;
        unsigned	                    : 1;
        unsigned	C1R                 : 1;
        unsigned	: 1;
        unsigned	C1POL               : 1;
        unsigned	C1OE                : 1;
        unsigned	C1OUT               : 1;
        unsigned	C1ON                : 1;
    struct {
        unsigned	C1CH0               : 1;
        unsigned	: 1;
        unsigned	CMR                 : 1;
        unsigned	: 1;
        unsigned	CMPOL               : 1;
        unsigned	CMOE                : 1;
        unsigned	COUT                : 1;
        unsigned	CMON                : 1;
    struct {
        unsigned	CMCH                : 1;
} CMCON0bits @ 0x01A;
#endif
// Register: CMCON1
volatile unsigned char           CMCON1              @ 0x01C;
volatile bit C1SYNC              @ ((unsigned)&CMCON1*8)+0;
volatile bit T1GSS               @ ((unsigned)&CMCON1*8)+1;
volatile bit C1HYS               @ ((unsigned)&CMCON1*8)+3;
volatile bit T1ACS               @ ((unsigned)&CMCON1*8)+4;
volatile bit CMSYNC              @ ((unsigned)&CMCON1*8)+0;
volatile bit CMHYS               @ ((unsigned)&CMCON1*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	C1SYNC              : 1;
        unsigned	T1GSS               : 1;
        unsigned	                    : 1;
        unsigned	C1HYS               : 1;
        unsigned	T1ACS               : 1;
    struct {
        unsigned	CMSYNC              : 1;
        unsigned	: 2;
        unsigned	CMHYS               : 1;
} CMCON1bits @ 0x01C;
#endif
// Special function register definitions: Bank 1
// Register: OPTION_REG
volatile unsigned char           OPTION_REG          @ 0x081;
volatile bit PSA                 @ ((unsigned)&OPTION_REG*8)+3;
volatile bit T0SE                @ ((unsigned)&OPTION_REG*8)+4;
volatile bit T0CS                @ ((unsigned)&OPTION_REG*8)+5;
volatile bit INTEDG              @ ((unsigned)&OPTION_REG*8)+6;
volatile bit nGPPU               @ ((unsigned)&OPTION_REG*8)+7;
volatile bit PS0                 @ ((unsigned)&OPTION_REG*8)+0;
volatile bit PS1                 @ ((unsigned)&OPTION_REG*8)+1;
volatile bit PS2                 @ ((unsigned)&OPTION_REG*8)+2;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	PS                  : 3;
        unsigned	PSA                 : 1;
        unsigned	T0SE                : 1;
        unsigned	T0CS                : 1;
        unsigned	INTEDG              : 1;
        unsigned	nGPPU               : 1;
    struct {
        unsigned	PS0                 : 1;
        unsigned	PS1                 : 1;
        unsigned	PS2                 : 1;
} OPTION_REGbits @ 0x081;
#endif
// Register: TRISIO
volatile unsigned char           TRISIO              @ 0x085;
volatile unsigned char           TRISA               @ 0x085;
volatile bit TRISIO0             @ ((unsigned)&TRISIO*8)+0;
volatile bit TRISIO1             @ ((unsigned)&TRISIO*8)+1;
volatile bit TRISIO2             @ ((unsigned)&TRISIO*8)+2;
volatile bit TRISIO3             @ ((unsigned)&TRISIO*8)+3;
volatile bit TRISIO4             @ ((unsigned)&TRISIO*8)+4;
volatile bit TRISIO5             @ ((unsigned)&TRISIO*8)+5;
volatile bit TRISA0              @ ((unsigned)&TRISIO*8)+0;
volatile bit TRISA1              @ ((unsigned)&TRISIO*8)+1;
volatile bit TRISA2              @ ((unsigned)&TRISIO*8)+2;
volatile bit TRISA3              @ ((unsigned)&TRISIO*8)+3;
volatile bit TRISA4              @ ((unsigned)&TRISIO*8)+4;
volatile bit TRISA5              @ ((unsigned)&TRISIO*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TRISIO0             : 1;
        unsigned	TRISIO1             : 1;
        unsigned	TRISIO2             : 1;
        unsigned	TRISIO3             : 1;
        unsigned	TRISIO4             : 1;
        unsigned	TRISIO5             : 1;
    struct {
        unsigned	TRISA0              : 1;
        unsigned	TRISA1              : 1;
        unsigned	TRISA2              : 1;
        unsigned	TRISA3              : 1;
        unsigned	TRISA4              : 1;
        unsigned	TRISA5              : 1;
} TRISIObits @ 0x085;
#endif
// Register: PIE1
volatile unsigned char           PIE1                @ 0x08C;
volatile bit TMR1IE              @ ((unsigned)&PIE1*8)+0;
volatile bit C1IE                @ ((unsigned)&PIE1*8)+3;
volatile bit T1IE                @ ((unsigned)&PIE1*8)+0;
volatile bit CMIE                @ ((unsigned)&PIE1*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TMR1IE              : 1;
        unsigned	                    : 2;
        unsigned	C1IE                : 1;
    struct {
        unsigned	T1IE                : 1;
        unsigned	: 2;
        unsigned	CMIE                : 1;
} PIE1bits @ 0x08C;
#endif
// Register: PCON
volatile unsigned char           PCON                @ 0x08E;
volatile bit nBOR                @ ((unsigned)&PCON*8)+0;
volatile bit nPOR                @ ((unsigned)&PCON*8)+1;
volatile bit nBOD                @ ((unsigned)&PCON*8)+0;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	nBOR                : 1;
        unsigned	nPOR                : 1;
    struct {
        unsigned	nBOD                : 1;
} PCONbits @ 0x08E;
#endif
// Register: OSCTUNE
volatile unsigned char           OSCTUNE             @ 0x090;
volatile bit TUN0                @ ((unsigned)&OSCTUNE*8)+0;
volatile bit TUN1                @ ((unsigned)&OSCTUNE*8)+1;
volatile bit TUN2                @ ((unsigned)&OSCTUNE*8)+2;
volatile bit TUN3                @ ((unsigned)&OSCTUNE*8)+3;
volatile bit TUN4                @ ((unsigned)&OSCTUNE*8)+4;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TUN                 : 5;
    struct {
        unsigned	TUN0                : 1;
        unsigned	TUN1                : 1;
        unsigned	TUN2                : 1;
        unsigned	TUN3                : 1;
        unsigned	TUN4                : 1;
} OSCTUNEbits @ 0x090;
#endif
// Register: WPU
volatile unsigned char           WPU                 @ 0x095;
volatile unsigned char           WPUA                @ 0x095;
volatile bit WPUA0               @ ((unsigned)&WPU*8)+0;
volatile bit WPUA1               @ ((unsigned)&WPU*8)+1;
volatile bit WPUA2               @ ((unsigned)&WPU*8)+2;
volatile bit WPUA4               @ ((unsigned)&WPU*8)+4;
volatile bit WPUA5               @ ((unsigned)&WPU*8)+5;
volatile bit WPU0                @ ((unsigned)&WPU*8)+0;
volatile bit WPU1                @ ((unsigned)&WPU*8)+1;
volatile bit WPU2                @ ((unsigned)&WPU*8)+2;
volatile bit WPU4                @ ((unsigned)&WPU*8)+4;
volatile bit WPU5                @ ((unsigned)&WPU*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	WPUA0               : 1;
        unsigned	WPUA1               : 1;
        unsigned	WPUA2               : 1;
        unsigned	                    : 1;
        unsigned	WPUA4               : 1;
        unsigned	WPUA5               : 1;
    struct {
        unsigned	WPU0                : 1;
        unsigned	WPU1                : 1;
        unsigned	WPU2                : 1;
        unsigned	: 1;
        unsigned	WPU4                : 1;
        unsigned	WPU5                : 1;
} WPUbits @ 0x095;
#endif
// Register: IOC
volatile unsigned char           IOC                 @ 0x096;
volatile unsigned char           IOCA                @ 0x096;
volatile bit IOC0                @ ((unsigned)&IOC*8)+0;
volatile bit IOC1                @ ((unsigned)&IOC*8)+1;
volatile bit IOC2                @ ((unsigned)&IOC*8)+2;
volatile bit IOC3                @ ((unsigned)&IOC*8)+3;
volatile bit IOC4                @ ((unsigned)&IOC*8)+4;
volatile bit IOC5                @ ((unsigned)&IOC*8)+5;
volatile bit IOCA0               @ ((unsigned)&IOC*8)+0;
volatile bit IOCA1               @ ((unsigned)&IOC*8)+1;
volatile bit IOCA2               @ ((unsigned)&IOC*8)+2;
volatile bit IOCA3               @ ((unsigned)&IOC*8)+3;
volatile bit IOCA4               @ ((unsigned)&IOC*8)+4;
volatile bit IOCA5               @ ((unsigned)&IOC*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	IOC0                : 1;
        unsigned	IOC1                : 1;
        unsigned	IOC2                : 1;
        unsigned	IOC3                : 1;
        unsigned	IOC4                : 1;
        unsigned	IOC5                : 1;
    struct {
        unsigned	IOCA0               : 1;
        unsigned	IOCA1               : 1;
        unsigned	IOCA2               : 1;
        unsigned	IOCA3               : 1;
        unsigned	IOCA4               : 1;
        unsigned	IOCA5               : 1;
} IOCbits @ 0x096;
#endif
// Register: ANSEL
volatile unsigned char           ANSEL               @ 0x09F;
volatile bit ANS0                @ ((unsigned)&ANSEL*8)+0;
volatile bit ANS1                @ ((unsigned)&ANSEL*8)+1;
volatile bit ANS3                @ ((unsigned)&ANSEL*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	ANS                 : 4;
        unsigned	ADCS                : 3;
    struct {
        unsigned	ANS0                : 1;
        unsigned	ANS1                : 1;
        unsigned	                    : 1;
        unsigned	ANS3                : 1;
} ANSELbits @ 0x09F;
#endif
#endif
