Parts:
R1______________47K   1/4W Resistor
R2_______________4K7  1/4W Resistor
R3______________22K   1/4W Resistor
R4_______________1K   1/4W Resistor
R5,R12,R13_____330R   1/4W Resistors
R6_______________1K5  1/4W Resistor
R7______________15K   1/4W Resistor
R8______________33K   1/4W Resistor
R9_____________150K   1/4W Resistor
R10____________500R   1/2W Trimmer Cermet
R11_____________39R   1/4W Resistor
R14,R15___________R33 2.5W Resistors
R16_____________10R   2.5W Resistor
R17_______________R22   5W Resistor (wirewound)
C1_____________470nF   63V Polyester Capacitor
C2_____________470pF   63V Polystyrene or ceramic Capacitor
C3______________47F   63V Electrolytic Capacitor
C4,C8,C9,C11___100nF   63V Polyester Capacitors
C5______________10pF   63V Polystyrene or ceramic Capacitor
C6_______________1F   63V Polyester Capacitor
C7,C10_________100F   63V Electrolytic Capacitors
D1,D2,D3_____1N4002  100V 1A Diodes
Q1,Q2,Q4_____MPSA43   200V 500mA NPN Transistors
Q3,Q5________BC546     65V 100mA NPN Transistors
Q6___________MJE340   200V 500mA NPN Transistor
Q7___________MJE350   200V 500mA PNP Transistor
Q8___________IRFP240  200V 20A N-Channel Hexfet Transistor
Q9___________IRFP9240 200V 12A P-Channel Hexfet Transistor
Power supply circuit diagram:
Parts:
R1_______________3K9   1W Resistor
C1,C2_________4700F  63V Electrolytic Capacitors (See Notes)
C3,C4__________100nF  63V Polyester Capacitors
D1_____________400V 8A Diode bridge
D2_____________5mm. Red LED
F1,F2__________4A Fuses with sockets
T1_____________230V or 115V Primary, 30 + 30V Secondary 160VA Mains transformer
PL1____________Male Mains plug
SW1____________SPST Mains switch
Comments:
To celebrate the hundredth design posted to this website, and to fulfil the requests of many correspondents wanting an amplifier more powerful than the 25W MosFet, a 60 - 90W High Quality power amplifier design is presented here.
Circuit topology is about the same of the above mentioned amplifier, but the extremely rugged IRFP240 and IRFP9240 MosFet devices are used as the output pair, and well renowned high voltage Motorola's transistors are employed in the preceding stages.
The supply rails voltage was kept prudentially at the rather low value of + and - 40V. For those wishing to experiment, the supply rails voltage could be raised to + and - 50V maximum, allowing the amplifier to approach the 100W into 8 Ohm target: enjoy!
A matching, discrete components, Modular Preamplifier design is available here: Modular Audio Preamplifier.
Notes:
    * A small, U-shaped heatsink must be fitted to Q6 & Q7.
    * Q8 & Q9 must be mounted on large heatsinks.
    * Quiescent current can be measured by means of an Avo-meter wired in series to the positive supply rail and no input signal.
    * Set the Trimmer R10 to its minimum resistance.
    * Power-on the amplifier and adjust R10 to read a current drawing of about 120 - 130mA.
    * Wait about 15 minutes, watch if the current is varying and readjust if necessary.
    * The value suggested for C1 and C2 in the Power Supply Parts List is the minimum required for a mono amplifier. For optimum performance and in stereo configurations, this value should be increased: 10000F is a good compromise.
    * A correct grounding is very important to eliminate hum and ground loops. Connect to the same point the ground sides of R1, R3, C2, C3 and C4 and the ground input wire. Connect R7 and C7 to C11 to output ground. Then connect separately the input and output grounds to the power supply ground.
Technical data:
Output power: 60 Watt RMS @ 8 Ohm (1KHz sinewave) - 90W RMS @ 4 Ohm
Sensitivity: 1V RMS input for 58W output
Frequency response: 30Hz to 20KHz -1dB
Total harmonic distortion @ 1KHz: 1W 0.003%  10W 0.006%  20W 0.01%  40W 0.013%  60W 0.018%
Total harmonic distortion @10KHz: 1W 0.005%  10W 0.02%   20W 0.03%  40W 0.06%   60W 0.09%
Unconditionally stable on capacitive loads
