; Source created with Parsic Version 3.x
; at              : 2008.09.02. 17:34:06
; Project File    : C:\Program Files\Parsic\Parsic_3.4.3.w.CR\win2.pic
; Project Version : 1.0.24
; Created         : 2008.08.21. 2:12:00
; Last change     : 2008.09.02. 17:34:00
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_ON
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
S0	= 32	; located in Bank 0
MF1	= 33	; located in Bank 0
MF1_HI	= 34	; located in Bank 0
S2	= 35	; located in Bank 0
MF2	= 36	; located in Bank 0
MF2_HI	= 37	; located in Bank 0
MF2_FD	= 38	; located in Bank 0
S1	= 39	; located in Bank 0
MF3	= 40	; located in Bank 0
MF3_HI	= 41	; located in Bank 0
MF3_FD	= 42	; located in Bank 0
OS1_FD	= 43	; located in Bank 0
MF4	= 44	; located in Bank 0
MF4_HI	= 45	; located in Bank 0
MF4_FD	= 46	; located in Bank 0
OS2_FD	= 47	; located in Bank 0
S3	= 48	; located in Bank 0
MF5	= 49	; located in Bank 0
MF5_HI	= 50	; located in Bank 0
MF5_FD	= 51	; located in Bank 0
RAM	= 52	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_0
	INCF MF1_HI,F
SYS_INT_LABEL_0
	INCFSZ MF2,F
	GOTO SYS_INT_LABEL_1
	BSF STATUS,RP0	; Bank 1
	INCF MF2_HI,F
SYS_INT_LABEL_1
	BSF STATUS,RP1	; Bank 2
	INCFSZ MF3,F
	GOTO SYS_INT_LABEL_2
	INCF MF3_HI,F
SYS_INT_LABEL_2
	BCF STATUS,RP1	; Bank 1
	INCFSZ MF4,F
	GOTO SYS_INT_LABEL_3
	BCF STATUS,RP0	; Bank 2
	INCF MF4_HI,F
SYS_INT_LABEL_3
	INCFSZ MF5,F
	GOTO SYS_INT_LABEL_4
	INCF MF5_HI,F
SYS_INT_LABEL_4
EXITINT
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETURN
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 15
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11001111'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; ODER - Gatter -> BE
LABEL_BE_1
	BTFSC PORTB,2
	GOTO LABEL_BE_TRUE
LABEL_BE_2
	BTFSC PORTB,1
	GOTO LABEL_BE_TRUE
LABEL_BE_FALSE
	BCF S0,4
	GOTO LABEL_BE_ENDE
LABEL_BE_TRUE
	BSF S0,4
LABEL_BE_ENDE
; Anzug-Verzögerung -> MF1
	BTFSC S0,4	; Eingang auf High ?
	GOTO LABEL_MF1_CHKTIME	; Ja
; RESET
	CLRF MF1
	CLRF MF1_HI
	BCF S0,3
	GOTO LABEL_MF1_EXIT	; raus
LABEL_MF1_CHKTIME
	BTFSC S0,3	; Ausgang schon auf High ?
	GOTO LABEL_MF1_EXIT	; Ja
	MOVLW 7
	SUBWF MF1_HI,W
	BTFSS STATUS,CARRY
	GOTO LABEL_MF1_EXIT
	MOVLW 161
	SUBWF MF1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_MF1_EXIT
	BSF S0,3
LABEL_MF1_EXIT
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S0,0
	GOTO LABEL_LG2_FALSE
LABEL_LG2_2
	BTFSS S0,3
LABEL_LG2_TRUE
	BSF S0,5
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF S0,5
LABEL_LG2_ENDE
; ODER - Gatter -> LG3
LABEL_LG3_1
	BTFSC S0,5
	GOTO LABEL_LG3_TRUE
LABEL_LG3_2
	BTFSC S0,2
	GOTO LABEL_LG3_TRUE
LABEL_LG3_FALSE
	BCF S2,4
	GOTO LABEL_LG3_ENDE
LABEL_LG3_TRUE
	BSF S2,4
LABEL_LG3_ENDE
; Mono-Flop -> MF2
; Läuft der Impuls ?
	BTFSC MF2_FD,1
	GOTO LABEL_MF2_CHKTIME
; Test auf positive Flanke
	BTFSC MF2_FD,0
	GOTO LABEL_MF2_SETFD
	BTFSS S0,1
LABEL_MF2_RESET
	CLRF MF2
	CLRF MF2_HI
	BSF MF2_FD,1
	BSF S0,6
LABEL_MF2_CHKTIME
	MOVLW 6
	SUBWF MF2_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF2_CHECK
	MOVLW 27
	SUBWF MF2,W
LABEL_MF2_CHECK
	BTFSS STATUS,CARRY
LABEL_MF2_TO
	BCF MF2_FD,1
	BCF S0,6
LABEL_MF2_SETFD
	BTFSS S0,1
	GOTO LABEL_MF2_CLR
	BSF MF2_FD,0
	GOTO LABEL_MF2_ENDE
LABEL_MF2_CLR
	BCF MF2_FD,0
LABEL_MF2_ENDE
; UND - Gatter -> LG4
LABEL_LG4_1
	BTFSS S0,1
	GOTO LABEL_LG4_FALSE
LABEL_LG4_2
	BTFSC S0,7
LABEL_LG4_TRUE
	BSF S0,0
	GOTO LABEL_LG4_ENDE
LABEL_LG4_FALSE
	BCF S0,0
LABEL_LG4_ENDE
; UND - Gatter -> LG5
LABEL_LG5_1
	BTFSS S0,6
	GOTO LABEL_LG5_FALSE
LABEL_LG5_2
	BTFSC S0,4
LABEL_LG5_TRUE
	BSF S1,0
	GOTO LABEL_LG5_ENDE
LABEL_LG5_FALSE
	BCF S1,0
LABEL_LG5_ENDE
; Mono-Flop -> MF3
	BTFSC MF3_FD,1
	GOTO LABEL_MF3_CHKTIME
	BTFSC MF3_FD,0
	GOTO LABEL_MF3_SETFD
	BTFSS PORTB,1
LABEL_MF3_RESET
	CLRF MF3
	CLRF MF3_HI
	BSF MF3_FD,1
	BSF S1,1
LABEL_MF3_CHKTIME
	MOVLW 6
	SUBWF MF3_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF3_CHECK
	MOVLW 27
	SUBWF MF3,W
LABEL_MF3_CHECK
	BTFSS STATUS,CARRY
LABEL_MF3_TO
	BCF MF3_FD,1
	BCF S1,1
LABEL_MF3_SETFD
	BTFSS PORTB,1
	GOTO LABEL_MF3_CLR
	BSF MF3_FD,0
	GOTO LABEL_MF3_ENDE
LABEL_MF3_CLR
	BCF MF3_FD,0
LABEL_MF3_ENDE
; UND - Gatter -> LG6
LABEL_LG6_1
	BTFSC S0,4
	GOTO LABEL_LG6_FALSE
LABEL_LG6_2
	BTFSS S1,1
LABEL_LG6_TRUE
	BSF S1,2
	GOTO LABEL_LG6_ENDE
LABEL_LG6_FALSE
	BCF S1,2
LABEL_LG6_ENDE
; UND - Gatter -> LG7
LABEL_LG7_1
	BTFSS S0,3
	GOTO LABEL_LG7_FALSE
LABEL_LG7_2
	BTFSS S1,4
LABEL_LG7_TRUE
	BSF S1,5
	GOTO LABEL_LG7_ENDE
LABEL_LG7_FALSE
	BCF S1,5
LABEL_LG7_ENDE
; UND - Gatter -> LG8
LABEL_LG8_1
	BTFSC S0,7
	GOTO LABEL_LG8_FALSE
LABEL_LG8_2
	BTFSS PORTB,1
LABEL_LG8_TRUE
	BSF S1,4
	GOTO LABEL_LG8_ENDE
LABEL_LG8_FALSE
	BCF S1,4
LABEL_LG8_ENDE
; ODER - Gatter -> LG9
LABEL_LG9_1
	BTFSC S1,3
	GOTO LABEL_LG9_TRUE
LABEL_LG9_2
	BTFSC S1,5
	GOTO LABEL_LG9_TRUE
LABEL_LG9_FALSE
	BCF S2,5
	GOTO LABEL_LG9_ENDE
LABEL_LG9_TRUE
	BSF S2,5
LABEL_LG9_ENDE
; One Shot -> OS1
	BTFSS S0,4
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S1,6
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S1,6
	BTFSC S0,4
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; ODER - Gatter -> LG10
LABEL_LG10_1
	BTFSC S0,2
	GOTO LABEL_LG10_TRUE
LABEL_LG10_2
	BTFSC S1,3
LABEL_LG10_FALSE
	BCF S2,0
	GOTO LABEL_LG10_ENDE
LABEL_LG10_TRUE
	BSF S2,0
LABEL_LG10_ENDE
; UND - Gatter -> LG11
LABEL_LG11_1
	BTFSS S2,0
	GOTO LABEL_LG11_FALSE
LABEL_LG11_2
	BTFSS S1,6
LABEL_LG11_TRUE
	BSF S1,7
	GOTO LABEL_LG11_ENDE
LABEL_LG11_FALSE
	BCF S1,7
LABEL_LG11_ENDE
; Mono-Flop -> MF4
	BTFSC MF4_FD,1
	GOTO LABEL_MF4_CHKTIME
	BTFSC MF4_FD,0
	GOTO LABEL_MF4_SETFD
	BTFSS S2,2
LABEL_MF4_RESET
	CLRF MF4
	CLRF MF4_HI
	BSF MF4_FD,1
	BSF S2,6
LABEL_MF4_CHKTIME
	MOVLW 7
	SUBWF MF4_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF4_CHECK
	MOVLW 161
	SUBWF MF4,W
LABEL_MF4_CHECK
	BTFSS STATUS,CARRY
LABEL_MF4_TO
	BCF MF4_FD,1
	BCF S2,6
LABEL_MF4_SETFD
	BTFSS S2,2
	GOTO LABEL_MF4_CLR
	BSF MF4_FD,0
	GOTO LABEL_MF4_ENDE
LABEL_MF4_CLR
	BCF MF4_FD,0
LABEL_MF4_ENDE
; One Shot -> OS2
	BTFSS PORTB,0
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S2,3
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S2,3
	BTFSC PORTB,0
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; ODER - Gatter -> LG12
LABEL_LG12_1
	BTFSC S1,7
	GOTO LABEL_LG12_TRUE
LABEL_LG12_2
	BTFSS S2,1
LABEL_LG12_FALSE
	BCF S2,2
	GOTO LABEL_LG12_ENDE
LABEL_LG12_TRUE
	BSF S2,2
LABEL_LG12_ENDE
; ODER - Gatter -> LG13
LABEL_LG13_1
	BTFSC S2,3
	GOTO LABEL_LG13_TRUE
LABEL_LG13_2
	BTFSC PORTB,2
LABEL_LG13_FALSE
	BCF S0,1
	GOTO LABEL_LG13_ENDE
LABEL_LG13_TRUE
	BSF S0,1
LABEL_LG13_ENDE
; UND - Gatter -> LG14
LABEL_LG14_1
	BTFSS S2,4
	GOTO LABEL_LG14_FALSE
LABEL_LG14_2
	BTFSS S2,1
LABEL_LG14_TRUE
	BSF S3,3
	GOTO LABEL_LG14_ENDE
LABEL_LG14_FALSE
	BCF S3,3
LABEL_LG14_ENDE
; UND - Gatter -> LG15
LABEL_LG15_1
	BTFSS S2,5
	GOTO LABEL_LG15_FALSE
LABEL_LG15_2
	BTFSS S2,1
LABEL_LG15_TRUE
	BSF S3,4
	GOTO LABEL_LG15_ENDE
LABEL_LG15_FALSE
	BCF S3,4
LABEL_LG15_ENDE
; ODER - Gatter -> LG16
LABEL_LG16_1
	BTFSC S2,3
	GOTO LABEL_LG16_TRUE
LABEL_LG16_2
	BTFSC S2,6
LABEL_LG16_FALSE
	BCF S0,7
	GOTO LABEL_LG16_ENDE
LABEL_LG16_TRUE
	BSF S0,7
LABEL_LG16_ENDE
; RS-FLIP-FLOP -> RS1
	BTFSC S0,7
	GOTO LABEL_RS1_RESET
	BTFSS S1,0
	GOTO LABEL_RS1_ENDE
	BSF S0,2	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S0,2	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; RS-FLIP-FLOP -> RS2
	BTFSS PORTB,3
	GOTO LABEL_RS2_RESET
	BTFSS S2,7
	GOTO LABEL_RS2_ENDE
	BSF S3,0	; Ausgang setzen
	GOTO LABEL_RS2_ENDE
LABEL_RS2_RESET
	BCF S3,0	; Ausgang zurücksetzen
LABEL_RS2_ENDE
; UND - Gatter -> LG17
LABEL_LG17_1
	BTFSS S3,1
	GOTO LABEL_LG17_FALSE
LABEL_LG17_2
	BTFSS S3,0
LABEL_LG17_TRUE
	BSF S2,1
	GOTO LABEL_LG17_ENDE
LABEL_LG17_FALSE
	BCF S2,1
LABEL_LG17_ENDE
; UND - Gatter -> LG18
LABEL_LG18_1
	BTFSC S0,4
	GOTO LABEL_LG18_FALSE
LABEL_LG18_2
	BTFSS PORTB,3
LABEL_LG18_TRUE
	BSF S2,7
	GOTO LABEL_LG18_ENDE
LABEL_LG18_FALSE
	BCF S2,7
LABEL_LG18_ENDE
; RS-FLIP-FLOP -> RS3
	BTFSC S0,7
	GOTO LABEL_RS3_RESET
	BTFSS S1,2
	GOTO LABEL_RS3_ENDE
	BSF S1,3	; Ausgang setzen
	GOTO LABEL_RS3_ENDE
LABEL_RS3_RESET
	BCF S1,3	; Ausgang zurücksetzen
LABEL_RS3_ENDE
; ODER - Gatter -> LG19
LABEL_LG19_1
	BTFSC S0,2
	GOTO LABEL_LG19_TRUE
LABEL_LG19_2
	BTFSC S1,3
LABEL_LG19_3
	BTFSC S0,3
LABEL_LG19_FALSE
	BCF S3,1
	GOTO LABEL_LG19_ENDE
LABEL_LG19_TRUE
	BSF S3,1
LABEL_LG19_ENDE
; Mono-Flop -> MF5
	BTFSC MF5_FD,1
	GOTO LABEL_MF5_CHKTIME
; Test auf negative Flanke
	BTFSS MF5_FD,0
	GOTO LABEL_MF5_SETFD
	BTFSC PORTB,3
LABEL_MF5_RESET
	CLRF MF5
	CLRF MF5_HI
	BSF MF5_FD,1
	BSF S3,2
LABEL_MF5_CHKTIME
	MOVLW 15
	SUBWF MF5_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF5_CHECK
	MOVLW 66
	SUBWF MF5,W
LABEL_MF5_CHECK
	BTFSS STATUS,CARRY
LABEL_MF5_TO
	BCF MF5_FD,1
	BCF S3,2
LABEL_MF5_SETFD
	BTFSS PORTB,3
	GOTO LABEL_MF5_CLR
	BSF MF5_FD,0
	GOTO LABEL_MF5_ENDE
LABEL_MF5_CLR
	BCF MF5_FD,0
LABEL_MF5_ENDE
; EXKLUSIVODER - Gatter -> LG20
	CLRF SYS_TMP1
	BTFSS S3,3
	GOTO LABEL_LG20_1
	INCF SYS_TMP1,F
LABEL_LG20_1
	BTFSS S3,2
	GOTO LABEL_LG20_2
	INCF SYS_TMP1,F
LABEL_LG20_2
	DECF SYS_TMP1,F
	BTFSC STATUS,ZERO
	BSF PORTB,4
	BTFSS STATUS,ZERO
	BCF PORTB,4
; EXKLUSIVODER - Gatter -> LG21
	CLRF SYS_TMP1
	BTFSS S3,4
	GOTO LABEL_LG21_1
	INCF SYS_TMP1,F
LABEL_LG21_1
	BTFSS S3,2
	GOTO LABEL_LG21_2
	INCF SYS_TMP1,F
LABEL_LG21_2
	DECF SYS_TMP1,F
	BTFSC STATUS,ZERO
	BSF PORTB,5
	BTFSS STATUS,ZERO
	BCF PORTB,5
	GOTO MAIN
	END
