; Source created with Parsic Version 3.x
; at              : 2008.09.02. 21:05:04
; Project File    : C:\PROGRA~1\Parsic\Timers.PIC
; Project Version : 1.0.0
; Created         : 2008.09.02. 20:50:48
; Last change     : 2008.09.02. 21:03:35
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_ON
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV2	= 32	; located in Bank 0
EE1_FD	= 33	; located in Bank 0
TR1	= 34	; located in Bank 0
TR1_HI	= 35	; located in Bank 0
S0	= 36	; located in Bank 0
ZV1	= 37	; located in Bank 0
ZV1_FD	= 38	; located in Bank 0
OS1_FD	= 39	; located in Bank 0
ZV2_FD	= 40	; located in Bank 0
S1	= 41	; located in Bank 0
OS2_FD	= 42	; located in Bank 0
ZV3	= 43	; located in Bank 0
ZV3_FD	= 44	; located in Bank 0
OS3_FD	= 45	; located in Bank 0
RAM	= 46	; located in Bank 0
SYS_TMP1	= 112	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 114	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 115	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
EEINT_WRITE
	MOVFW INDF
EEINT_WRITE_0
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF EEDATA
	BSF EECON1,WREN
EEINT_DISINT
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO EEINT_DISINT
	MOVLW H'55'
	MOVWF EECON2
	MOVLW H'AA'
	MOVWF EECON2
	BSF EECON1,WR	; start write
	BSF INTCON,GIE
EEINT_WRITE_1
	BTFSC EECON1,WR	; ready ?
	GOTO EEINT_WRITE_1	; no
	BCF EECON1,WREN
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_WRITE
	RETURN
EEINT_READ
	BSF EECON1,RD
	MOVFW EEDATA
	MOVWF INDF
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_READ
	RETURN
; EE-Modul -> EE1
WRITE_EE1
	MOVLW 0
	MOVWF EEADR
	BCF STATUS,IRP	; vars - located in Bank 0
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_WRITE
	RETURN
; EE-Modul -> EE1
READ_EE1
	MOVLW 0
	MOVWF EEADR
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_READ
	RETURN
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 15
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11111100'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CALL READ_EE1	; read vars from internal EE
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 20
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 20
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S0,0
	GOTO LABEL_TR1_CLR
	BSF S0,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S0,0
LABEL_TR1_ENDE
; Zähler -> ZV1
	BTFSS S0,5	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S0,3
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S0,4	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S0,3
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S0,0
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS S0,1
LABEL_LG1_TRUE
	BSF S0,3
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S0,3
LABEL_LG1_ENDE
; RS-FLIP-FLOP -> RS1
	BTFSC S0,5
	GOTO LABEL_RS1_RESET
	BTFSS S0,2
	GOTO LABEL_RS1_ENDE
	BSF S0,1	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S0,1	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; One Shot -> OS1
	BTFSS PORTA,1
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S0,2
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S0,2
	BTFSC PORTA,1
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; Schmitt-Trigger 8-Bit -> ST1
	BTFSC S0,5	; Ausgang gesetzt ?
	GOTO LABEL_ST1_MH	; dann mit Hysterese ?
	MOVLW 100
	GOTO LABEL_ST1_TEST
LABEL_ST1_MH
	MOVLW 100
LABEL_ST1_TEST
	SUBWF ZV1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
	BSF S0,5	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S0,5	; if less
LABEL_ST1_ENDE
; GND
	BCF S0,4	; immer Low
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S0,1
	GOTO LABEL_LG2_FALSE
LABEL_LG2_TRUE
	BSF PORTB,0
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF PORTB,0
LABEL_LG2_ENDE
; Zähler -> ZV2
	BTFSS S1,2	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S1,0
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	BTFSC S1,1	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S1,0
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; UND - Gatter -> LG3
LABEL_LG3_1
	BTFSS S0,0
	GOTO LABEL_LG3_FALSE
LABEL_LG3_2
	BTFSS S0,6
LABEL_LG3_TRUE
	BSF S1,0
	GOTO LABEL_LG3_ENDE
LABEL_LG3_FALSE
	BCF S1,0
LABEL_LG3_ENDE
; RS-FLIP-FLOP -> RS2
	BTFSC S1,2
	GOTO LABEL_RS2_RESET
	BTFSS S0,7
	GOTO LABEL_RS2_ENDE
	BSF S0,6	; Ausgang setzen
	GOTO LABEL_RS2_ENDE
LABEL_RS2_RESET
	BCF S0,6	; Ausgang zurücksetzen
LABEL_RS2_ENDE
; One Shot -> OS2
	BTFSS PORTA,2
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S0,7
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S0,7
	BTFSC PORTA,2
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; Schmitt-Trigger 8-Bit -> ST2
	BTFSC S1,2	; Ausgang gesetzt ?
	GOTO LABEL_ST2_MH	; dann mit Hysterese ?
	MOVFW ZV3
	GOTO LABEL_ST2_TEST
LABEL_ST2_MH
	MOVLW 0	; Hysterese
	SUBWF ZV3,W
LABEL_ST2_TEST
	SUBWF ZV2,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST2_RESET
	BSF S1,2	; if greater or equal
	GOTO LABEL_ST2_ENDE
LABEL_ST2_RESET
	BCF S1,2	; if less
LABEL_ST2_ENDE
; GND
	BCF S1,1	; immer Low
; UND - Gatter -> LG4
LABEL_LG4_1
	BTFSS S0,6
	GOTO LABEL_LG4_FALSE
LABEL_LG4_TRUE
	BSF PORTB,1
	GOTO LABEL_LG4_ENDE
LABEL_LG4_FALSE
	BCF PORTB,1
LABEL_LG4_ENDE
; Zähler -> ZV3
	BTFSS S1,1	; Reset ?
	GOTO LABEL_ZV3_COUNT
	CLRF ZV3
	GOTO LABEL_ZV3_SETOUT
LABEL_ZV3_COUNT
	BTFSS S1,3
	GOTO LABEL_ZV3_SETFD
	BTFSC ZV3_FD,0
	BSF ZV3_FD,0
	GOTO LABEL_ZV3_BACKWARD
	INCF ZV3,F
LABEL_ZV3_BACKWARD
	DECF ZV3,F
LABEL_ZV3_SETOUT
LABEL_ZV3_SETFD
	BTFSC S1,3
	GOTO LABEL_ZV3_EXIT
	BCF ZV3_FD,0
LABEL_ZV3_EXIT
; EE-Modul -> EE1
; Test of falling edge
	BTFSC S1,3
	GOTO LABEL_EE1_SETFD
	BTFSS EE1_FD,0
	BCF EE1_FD,0
	CALL WRITE_EE1
LABEL_EE1_SETFD
; test input
	BTFSS S1,3
	GOTO LABEL_EE1_EXIT
	BSF EE1_FD,0
LABEL_EE1_EXIT
; One Shot -> OS3
	BTFSS PORTA,0
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S1,3
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S1,3
	BTFSC PORTA,0
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
	GOTO MAIN
	ORG H'2100'
	DE 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	END
