<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.0.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="57" name="tCAD" color="7" fill="1" visible="no" active="no"/>
<layer number="59" name="tCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="60" name="bCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="yes" active="yes"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="no" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="no" active="yes"/>
<layer number="103" name="fp3" color="7" fill="1" visible="no" active="yes"/>
<layer number="104" name="Name" color="7" fill="1" visible="no" active="yes"/>
<layer number="105" name="Beschreib" color="9" fill="1" visible="no" active="yes"/>
<layer number="106" name="BGA-Top" color="4" fill="1" visible="no" active="yes"/>
<layer number="107" name="BD-Top" color="5" fill="1" visible="no" active="yes"/>
<layer number="108" name="fp8" color="7" fill="1" visible="no" active="yes"/>
<layer number="109" name="fp9" color="7" fill="1" visible="no" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="no" active="yes"/>
<layer number="111" name="LPC17xx" color="7" fill="1" visible="no" active="yes"/>
<layer number="112" name="tSilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="113" name="ReferenceLS" color="7" fill="1" visible="no" active="no"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="no" active="yes"/>
<layer number="118" name="Rect_Pads" color="7" fill="1" visible="no" active="no"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="no" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="no" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="126" name="_bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="127" name="_tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="128" name="_bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="129" name="Mask" color="7" fill="1" visible="yes" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="no" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="no" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="no" active="yes"/>
<layer number="150" name="Notes" color="7" fill="1" visible="no" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="no" active="yes"/>
<layer number="152" name="_bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="153" name="FabDoc1" color="6" fill="1" visible="no" active="no"/>
<layer number="154" name="FabDoc2" color="2" fill="1" visible="no" active="no"/>
<layer number="155" name="FabDoc3" color="7" fill="15" visible="no" active="no"/>
<layer number="199" name="Contour" color="7" fill="1" visible="no" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="1" visible="no" active="no"/>
<layer number="202" name="202bmp" color="3" fill="1" visible="no" active="no"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="no" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="no" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="no" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="no" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="no" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="no" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="225" name="225bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="226" name="226bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="227" name="227bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="228" name="228bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="229" name="229bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="230" name="230bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="231" name="Eagle3D_PG1" color="7" fill="1" visible="no" active="no"/>
<layer number="232" name="Eagle3D_PG2" color="7" fill="1" visible="no" active="no"/>
<layer number="233" name="Eagle3D_PG3" color="7" fill="1" visible="no" active="no"/>
<layer number="248" name="Housing" color="7" fill="1" visible="no" active="yes"/>
<layer number="249" name="Edge" color="7" fill="1" visible="no" active="yes"/>
<layer number="250" name="Descript" color="7" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="7" fill="1" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="no" active="yes"/>
<layer number="255" name="routoute" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="microchip" urn="urn:adsk.eagle:library:294">
<description>&lt;b&gt;Microchip PIC Microcontrollers and other Devices&lt;/b&gt;&lt;p&gt;
Based on the following sources :
&lt;ul&gt;
&lt;li&gt;Microchip Data Book, 1993
&lt;li&gt;THE EMERGING WORLD STANDARD, 1995/1996
&lt;li&gt;Microchip, Technical Library CD-ROM, June 1998
&lt;li&gt;www.microchip.com
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL28-3" urn="urn:adsk.eagle:footprint:20609/1" library_version="2">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type P</description>
<wire x1="-17.78" y1="-1.27" x2="-17.78" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.27" x2="-17.78" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="17.78" y1="-2.54" x2="17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.54" x2="-17.78" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.54" x2="17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="-2.54" x2="17.78" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-17.907" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-15.748" y="-0.9398" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SO28W" urn="urn:adsk.eagle:footprint:20598/1" library_version="2">
<description>&lt;B&gt;28-Lead Plastic Small Outline (SO) &lt;/B&gt; Wide, 300 mil Body (SOIC)&lt;/B&gt;&lt;p&gt;
Source: http://ww1.microchip.com/downloads/en/devicedoc/39632c.pdf</description>
<wire x1="-8.1788" y1="-3.7132" x2="9.4742" y2="-3.7132" width="0.1524" layer="21"/>
<wire x1="9.4742" y1="-3.7132" x2="9.4742" y2="3.7132" width="0.1524" layer="21"/>
<wire x1="9.4742" y1="3.7132" x2="-8.1788" y2="3.7132" width="0.1524" layer="21"/>
<wire x1="-8.1788" y1="3.7132" x2="-8.1788" y2="-3.7132" width="0.1524" layer="21"/>
<circle x="-7.239" y="-3.1496" radius="0.5334" width="0.1524" layer="21"/>
<smd name="1" x="-7.62" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="2" x="-6.35" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="3" x="-5.08" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="4" x="-3.81" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="5" x="-2.54" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="6" x="-1.27" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="7" x="0" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="8" x="1.27" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="9" x="2.54" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="10" x="3.81" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="20" x="2.54" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="19" x="3.81" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="18" x="5.08" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="17" x="6.35" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="16" x="7.62" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="15" x="8.89" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="14" x="8.89" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="13" x="7.62" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="12" x="6.35" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="11" x="5.08" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="21" x="1.27" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="22" x="0" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="23" x="-1.27" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="24" x="-2.54" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="25" x="-3.81" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="26" x="-5.08" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="27" x="-6.35" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="28" x="-7.62" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<text x="-8.509" y="-4.064" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="11.557" y="-4.064" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-7.874" y1="-5.2626" x2="-7.366" y2="-3.7386" layer="51"/>
<rectangle x1="-6.604" y1="-5.2626" x2="-6.096" y2="-3.7386" layer="51"/>
<rectangle x1="-5.334" y1="-5.2626" x2="-4.826" y2="-3.7386" layer="51"/>
<rectangle x1="-4.064" y1="-5.2626" x2="-3.556" y2="-3.7386" layer="51"/>
<rectangle x1="-2.794" y1="-5.2626" x2="-2.286" y2="-3.7386" layer="51"/>
<rectangle x1="-1.524" y1="-5.2626" x2="-1.016" y2="-3.7386" layer="51"/>
<rectangle x1="-0.254" y1="-5.2626" x2="0.254" y2="-3.7386" layer="51"/>
<rectangle x1="1.016" y1="-5.2626" x2="1.524" y2="-3.7386" layer="51"/>
<rectangle x1="2.286" y1="-5.2626" x2="2.794" y2="-3.7386" layer="51"/>
<rectangle x1="3.556" y1="-5.2626" x2="4.064" y2="-3.7386" layer="51"/>
<rectangle x1="4.826" y1="-5.2626" x2="5.334" y2="-3.7386" layer="51"/>
<rectangle x1="6.096" y1="-5.2626" x2="6.604" y2="-3.7386" layer="51"/>
<rectangle x1="7.366" y1="-5.2626" x2="7.874" y2="-3.7386" layer="51"/>
<rectangle x1="8.636" y1="-5.2626" x2="9.144" y2="-3.7386" layer="51"/>
<rectangle x1="8.636" y1="3.7386" x2="9.144" y2="5.2626" layer="51"/>
<rectangle x1="7.366" y1="3.7386" x2="7.874" y2="5.2626" layer="51"/>
<rectangle x1="6.096" y1="3.7386" x2="6.604" y2="5.2626" layer="51"/>
<rectangle x1="4.826" y1="3.7386" x2="5.334" y2="5.2626" layer="51"/>
<rectangle x1="3.556" y1="3.7386" x2="4.064" y2="5.2626" layer="51"/>
<rectangle x1="2.286" y1="3.7386" x2="2.794" y2="5.2626" layer="51"/>
<rectangle x1="1.016" y1="3.7386" x2="1.524" y2="5.2626" layer="51"/>
<rectangle x1="-0.254" y1="3.7386" x2="0.254" y2="5.2626" layer="51"/>
<rectangle x1="-1.524" y1="3.7386" x2="-1.016" y2="5.2626" layer="51"/>
<rectangle x1="-2.794" y1="3.7386" x2="-2.286" y2="5.2626" layer="51"/>
<rectangle x1="-4.064" y1="3.7386" x2="-3.556" y2="5.2626" layer="51"/>
<rectangle x1="-5.334" y1="3.7386" x2="-4.826" y2="5.2626" layer="51"/>
<rectangle x1="-6.604" y1="3.7386" x2="-6.096" y2="5.2626" layer="51"/>
<rectangle x1="-7.874" y1="3.7386" x2="-7.366" y2="5.2626" layer="51"/>
</package>
<package name="SSOP28" urn="urn:adsk.eagle:footprint:20599/1" library_version="2">
<description>&lt;b&gt;Shrink Small Outline Package&lt;/b&gt;&lt;p&gt;
package type SS</description>
<wire x1="-5.1" y1="-2.6" x2="5.1" y2="-2.6" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-2.6" x2="5.1" y2="2.6" width="0.2032" layer="21"/>
<wire x1="5.1" y1="2.6" x2="-5.1" y2="2.6" width="0.2032" layer="21"/>
<smd name="1" x="-4.225" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="2" x="-3.575" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="3" x="-2.925" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="4" x="-2.275" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="5" x="-1.625" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="6" x="-0.975" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="7" x="-0.325" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="8" x="0.325" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="9" x="0.975" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="10" x="1.625" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="11" x="2.275" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="12" x="2.925" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="13" x="3.575" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="14" x="4.225" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="15" x="4.225" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="16" x="3.575" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="17" x="2.925" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="18" x="2.275" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="19" x="1.625" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="20" x="0.975" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="21" x="0.325" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="22" x="-0.325" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="23" x="-0.975" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="24" x="-1.625" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="25" x="-2.275" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="26" x="-2.925" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="27" x="-3.575" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="28" x="-4.225" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<text x="-5.476" y="-2.6299" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-3.8999" y="-0.68" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.4028" y1="-3.937" x2="-4.0472" y2="-2.6416" layer="51"/>
<rectangle x1="-3.7529" y1="-3.937" x2="-3.3973" y2="-2.6416" layer="51"/>
<rectangle x1="-3.1029" y1="-3.937" x2="-2.7473" y2="-2.6416" layer="51"/>
<rectangle x1="-2.4529" y1="-3.937" x2="-2.0973" y2="-2.6416" layer="51"/>
<rectangle x1="-1.8029" y1="-3.937" x2="-1.4473" y2="-2.6416" layer="51"/>
<rectangle x1="-1.1529" y1="-3.937" x2="-0.7973" y2="-2.6416" layer="51"/>
<rectangle x1="-0.5029" y1="-3.937" x2="-0.1473" y2="-2.6416" layer="51"/>
<rectangle x1="0.1473" y1="-3.937" x2="0.5029" y2="-2.6416" layer="51"/>
<rectangle x1="0.7973" y1="-3.937" x2="1.1529" y2="-2.6416" layer="51"/>
<rectangle x1="1.4473" y1="-3.937" x2="1.8029" y2="-2.6416" layer="51"/>
<rectangle x1="2.0973" y1="-3.937" x2="2.4529" y2="-2.6416" layer="51"/>
<rectangle x1="2.7473" y1="-3.937" x2="3.1029" y2="-2.6416" layer="51"/>
<rectangle x1="3.3973" y1="-3.937" x2="3.7529" y2="-2.6416" layer="51"/>
<rectangle x1="4.0472" y1="-3.937" x2="4.4028" y2="-2.6416" layer="51"/>
<rectangle x1="4.0472" y1="2.6416" x2="4.4028" y2="3.937" layer="51"/>
<rectangle x1="3.3973" y1="2.6416" x2="3.7529" y2="3.937" layer="51"/>
<rectangle x1="2.7473" y1="2.6416" x2="3.1029" y2="3.937" layer="51"/>
<rectangle x1="2.0973" y1="2.6416" x2="2.4529" y2="3.937" layer="51"/>
<rectangle x1="1.4473" y1="2.6416" x2="1.8029" y2="3.937" layer="51"/>
<rectangle x1="0.7973" y1="2.6416" x2="1.1529" y2="3.937" layer="51"/>
<rectangle x1="0.1473" y1="2.6416" x2="0.5029" y2="3.937" layer="51"/>
<rectangle x1="-0.5029" y1="2.6416" x2="-0.1473" y2="3.937" layer="51"/>
<rectangle x1="-1.1529" y1="2.6416" x2="-0.7973" y2="3.937" layer="51"/>
<rectangle x1="-1.8029" y1="2.6416" x2="-1.4473" y2="3.937" layer="51"/>
<rectangle x1="-2.4529" y1="2.6416" x2="-2.0973" y2="3.937" layer="51"/>
<rectangle x1="-3.1029" y1="2.6416" x2="-2.7473" y2="3.937" layer="51"/>
<rectangle x1="-3.7529" y1="2.6416" x2="-3.3973" y2="3.937" layer="51"/>
<rectangle x1="-4.4028" y1="2.6416" x2="-4.0472" y2="3.937" layer="51"/>
<rectangle x1="-5.1999" y1="-2.5999" x2="-4.225" y2="2.5999" layer="27"/>
</package>
<package name="QFN28-ML_6X6MM" urn="urn:adsk.eagle:footprint:20673/1" library_version="2">
<description>&lt;b&gt;QFN28-ML_6X6MM&lt;/b&gt;&lt;p&gt;
Source: http://www.microchip.com .. 39637a.pdf</description>
<wire x1="-2.8984" y1="-2.8984" x2="2.8984" y2="-2.8984" width="0.2032" layer="51"/>
<wire x1="2.8984" y1="-2.8984" x2="2.8984" y2="2.8984" width="0.2032" layer="51"/>
<wire x1="2.8984" y1="2.8984" x2="-2.22" y2="2.8984" width="0.2032" layer="51"/>
<wire x1="-2.22" y1="2.8984" x2="-2.22" y2="2.9" width="0.2032" layer="21"/>
<wire x1="-2.8984" y1="2.8984" x2="-2.22" y2="2.8984" width="0.2032" layer="21"/>
<wire x1="-2.22" y1="2.9" x2="-2.8984" y2="2.2216" width="0.2032" layer="21"/>
<wire x1="-2.8984" y1="2.2216" x2="-2.8984" y2="-2.8984" width="0.2032" layer="51"/>
<wire x1="-2.8984" y1="2.2216" x2="-2.8984" y2="2.8984" width="0.2032" layer="21"/>
<smd name="1" x="-2.7" y="1.95" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="2" x="-2.7" y="1.3" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="3" x="-2.7" y="0.65" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="4" x="-2.7" y="0" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="5" x="-2.7" y="-0.65" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="6" x="-2.7" y="-1.3" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="7" x="-2.7" y="-1.95" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="8" x="-1.95" y="-2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="9" x="-1.3" y="-2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="10" x="-0.65" y="-2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="11" x="0" y="-2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="12" x="0.65" y="-2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="13" x="1.3" y="-2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="14" x="1.95" y="-2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="15" x="2.7" y="-1.95" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="16" x="2.7" y="-1.3" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="17" x="2.7" y="-0.65" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="18" x="2.7" y="0" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="19" x="2.7" y="0.65" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="20" x="2.7" y="1.3" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="21" x="2.7" y="1.95" dx="0.7" dy="0.35" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="22" x="1.95" y="2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="23" x="1.3" y="2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="24" x="0.65" y="2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="25" x="0" y="2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="26" x="-0.65" y="2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="27" x="-1.3" y="2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="28" x="-1.95" y="2.7" dx="0.35" dy="0.7" layer="1" roundness="20" stop="no" cream="no"/>
<smd name="EXP" x="0" y="0" dx="3.7" dy="3.7" layer="1" roundness="20" stop="no" cream="no"/>
<text x="-3.175" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.055" y1="1.768" x2="-2.3465" y2="2.132" layer="29"/>
<rectangle x1="-3.042" y1="1.7875" x2="-2.3595" y2="2.1125" layer="31"/>
<rectangle x1="-3.055" y1="1.118" x2="-2.3465" y2="1.482" layer="29"/>
<rectangle x1="-3.042" y1="1.1375" x2="-2.3595" y2="1.4625" layer="31"/>
<rectangle x1="-3.055" y1="0.468" x2="-2.3465" y2="0.832" layer="29"/>
<rectangle x1="-3.042" y1="0.4875" x2="-2.3595" y2="0.8125" layer="31"/>
<rectangle x1="-3.055" y1="-0.182" x2="-2.3465" y2="0.182" layer="29"/>
<rectangle x1="-3.042" y1="-0.1625" x2="-2.3595" y2="0.1625" layer="31"/>
<rectangle x1="-3.055" y1="-0.832" x2="-2.3465" y2="-0.468" layer="29"/>
<rectangle x1="-3.042" y1="-0.8125" x2="-2.3595" y2="-0.4875" layer="31"/>
<rectangle x1="-3.055" y1="-1.482" x2="-2.3465" y2="-1.118" layer="29"/>
<rectangle x1="-3.042" y1="-1.4625" x2="-2.3595" y2="-1.1375" layer="31"/>
<rectangle x1="-3.055" y1="-2.132" x2="-2.3465" y2="-1.768" layer="29"/>
<rectangle x1="-3.042" y1="-2.1125" x2="-2.3595" y2="-1.7875" layer="31"/>
<rectangle x1="-2.3042" y1="-2.8827" x2="-1.5958" y2="-2.5187" layer="29" rot="R90"/>
<rectangle x1="-2.2912" y1="-2.8632" x2="-1.6088" y2="-2.5382" layer="31" rot="R90"/>
<rectangle x1="-1.6542" y1="-2.8827" x2="-0.9458" y2="-2.5187" layer="29" rot="R90"/>
<rectangle x1="-1.6412" y1="-2.8632" x2="-0.9588" y2="-2.5382" layer="31" rot="R90"/>
<rectangle x1="-1.0042" y1="-2.8827" x2="-0.2958" y2="-2.5187" layer="29" rot="R90"/>
<rectangle x1="-0.9912" y1="-2.8632" x2="-0.3088" y2="-2.5382" layer="31" rot="R90"/>
<rectangle x1="-0.3542" y1="-2.8827" x2="0.3542" y2="-2.5187" layer="29" rot="R90"/>
<rectangle x1="-0.3412" y1="-2.8632" x2="0.3412" y2="-2.5382" layer="31" rot="R90"/>
<rectangle x1="0.2958" y1="-2.8827" x2="1.0042" y2="-2.5187" layer="29" rot="R90"/>
<rectangle x1="0.3088" y1="-2.8632" x2="0.9912" y2="-2.5382" layer="31" rot="R90"/>
<rectangle x1="0.9458" y1="-2.8827" x2="1.6542" y2="-2.5187" layer="29" rot="R90"/>
<rectangle x1="0.9588" y1="-2.8632" x2="1.6412" y2="-2.5382" layer="31" rot="R90"/>
<rectangle x1="1.5958" y1="-2.8827" x2="2.3042" y2="-2.5187" layer="29" rot="R90"/>
<rectangle x1="1.6088" y1="-2.8632" x2="2.2912" y2="-2.5382" layer="31" rot="R90"/>
<rectangle x1="2.3465" y1="-2.132" x2="3.0549" y2="-1.768" layer="29" rot="R180"/>
<rectangle x1="2.3595" y1="-2.1125" x2="3.0419" y2="-1.7875" layer="31" rot="R180"/>
<rectangle x1="2.3465" y1="-1.482" x2="3.0549" y2="-1.118" layer="29" rot="R180"/>
<rectangle x1="2.3595" y1="-1.4625" x2="3.0419" y2="-1.1375" layer="31" rot="R180"/>
<rectangle x1="2.3465" y1="-0.832" x2="3.0549" y2="-0.468" layer="29" rot="R180"/>
<rectangle x1="2.3595" y1="-0.8125" x2="3.0419" y2="-0.4875" layer="31" rot="R180"/>
<rectangle x1="2.3465" y1="-0.182" x2="3.0549" y2="0.182" layer="29" rot="R180"/>
<rectangle x1="2.3595" y1="-0.1625" x2="3.0419" y2="0.1625" layer="31" rot="R180"/>
<rectangle x1="2.3465" y1="0.468" x2="3.0549" y2="0.832" layer="29" rot="R180"/>
<rectangle x1="2.3595" y1="0.4875" x2="3.0419" y2="0.8125" layer="31" rot="R180"/>
<rectangle x1="2.3465" y1="1.118" x2="3.0549" y2="1.482" layer="29" rot="R180"/>
<rectangle x1="2.3595" y1="1.1375" x2="3.0419" y2="1.4625" layer="31" rot="R180"/>
<rectangle x1="2.3465" y1="1.768" x2="3.0549" y2="2.132" layer="29" rot="R180"/>
<rectangle x1="2.3595" y1="1.7875" x2="3.0419" y2="2.1125" layer="31" rot="R180"/>
<rectangle x1="1.5958" y1="2.5187" x2="2.3042" y2="2.8827" layer="29" rot="R270"/>
<rectangle x1="1.6088" y1="2.5382" x2="2.2912" y2="2.8632" layer="31" rot="R270"/>
<rectangle x1="0.9458" y1="2.5187" x2="1.6542" y2="2.8827" layer="29" rot="R270"/>
<rectangle x1="0.9588" y1="2.5382" x2="1.6412" y2="2.8632" layer="31" rot="R270"/>
<rectangle x1="0.2958" y1="2.5187" x2="1.0042" y2="2.8827" layer="29" rot="R270"/>
<rectangle x1="0.3088" y1="2.5382" x2="0.9912" y2="2.8632" layer="31" rot="R270"/>
<rectangle x1="-0.3542" y1="2.5187" x2="0.3542" y2="2.8827" layer="29" rot="R270"/>
<rectangle x1="-0.3412" y1="2.5382" x2="0.3412" y2="2.8632" layer="31" rot="R270"/>
<rectangle x1="-1.0042" y1="2.5187" x2="-0.2958" y2="2.8827" layer="29" rot="R270"/>
<rectangle x1="-0.9912" y1="2.5382" x2="-0.3088" y2="2.8632" layer="31" rot="R270"/>
<rectangle x1="-1.6542" y1="2.5187" x2="-0.9458" y2="2.8827" layer="29" rot="R270"/>
<rectangle x1="-1.6412" y1="2.5382" x2="-0.9588" y2="2.8632" layer="31" rot="R270"/>
<rectangle x1="-2.3042" y1="2.5187" x2="-1.5958" y2="2.8827" layer="29" rot="R270"/>
<rectangle x1="-2.2912" y1="2.5382" x2="-1.6088" y2="2.8632" layer="31" rot="R270"/>
<rectangle x1="-1.859" y1="-1.859" x2="1.859" y2="1.859" layer="29"/>
<rectangle x1="-1.7355" y1="-1.7355" x2="1.7355" y2="1.7355" layer="31"/>
</package>
</packages>
<packages3d>
<package3d name="DIL28-3" urn="urn:adsk.eagle:package:20799/2" type="model" library_version="2">
<description>Dual In Line
<packageinstances>
<packageinstance name="DIL28-3"/>
</packageinstances>
</package3d>
<package3d name="SO28W" urn="urn:adsk.eagle:package:20803/2" type="model" library_version="2">
<description>28-Lead Plastic Small Outline (SO)  Wide, 300 mil Body (SOIC)
<packageinstances>
<packageinstance name="SO28W"/>
</packageinstances>
</package3d>
<package3d name="SSOP28" urn="urn:adsk.eagle:package:20800/1" type="box" library_version="2">
<description>Shrink Small Outline Package
<packageinstances>
<packageinstance name="SSOP28"/>
</packageinstances>
</package3d>
<package3d name="QFN28-ML_6X6MM" urn="urn:adsk.eagle:package:20818/2" type="model" library_version="2">
<description>QFN28-ML_6X6MM
<packageinstances>
<packageinstance name="QFN28-ML_6X6MM"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="MCP23017" urn="urn:adsk.eagle:symbol:20682/1" library_version="2">
<wire x1="-10.16" y1="22.86" x2="10.16" y2="22.86" width="0.254" layer="94"/>
<wire x1="10.16" y1="22.86" x2="10.16" y2="-22.86" width="0.254" layer="94"/>
<wire x1="10.16" y1="-22.86" x2="-10.16" y2="-22.86" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-22.86" x2="-10.16" y2="22.86" width="0.254" layer="94"/>
<text x="-10.16" y="24.13" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-25.4" size="1.778" layer="96">&gt;VALUE</text>
<pin name="SCL" x="-12.7" y="-2.54" length="short" direction="in"/>
<pin name="SDA" x="-12.7" y="-5.08" length="short"/>
<pin name="A0" x="-12.7" y="-10.16" length="short" direction="in"/>
<pin name="A1" x="-12.7" y="-12.7" length="short" direction="in"/>
<pin name="A2" x="-12.7" y="-15.24" length="short" direction="in"/>
<pin name="!RESET" x="-12.7" y="15.24" length="short" direction="in"/>
<pin name="INTA" x="-12.7" y="10.16" length="short" direction="out"/>
<pin name="INTB" x="-12.7" y="7.62" length="short" direction="out"/>
<pin name="GPB0" x="12.7" y="-2.54" length="short" rot="R180"/>
<pin name="GPB1" x="12.7" y="-5.08" length="short" rot="R180"/>
<pin name="GPB2" x="12.7" y="-7.62" length="short" rot="R180"/>
<pin name="GPB3" x="12.7" y="-10.16" length="short" rot="R180"/>
<pin name="GPB4" x="12.7" y="-12.7" length="short" rot="R180"/>
<pin name="GPB5" x="12.7" y="-15.24" length="short" rot="R180"/>
<pin name="GPB6" x="12.7" y="-17.78" length="short" rot="R180"/>
<pin name="GPB7" x="12.7" y="-20.32" length="short" rot="R180"/>
<pin name="GPA0" x="12.7" y="20.32" length="short" rot="R180"/>
<pin name="GPA1" x="12.7" y="17.78" length="short" rot="R180"/>
<pin name="GPA2" x="12.7" y="15.24" length="short" rot="R180"/>
<pin name="GPA3" x="12.7" y="12.7" length="short" rot="R180"/>
<pin name="GPA4" x="12.7" y="10.16" length="short" rot="R180"/>
<pin name="GPA5" x="12.7" y="7.62" length="short" rot="R180"/>
<pin name="GPA6" x="12.7" y="5.08" length="short" rot="R180"/>
<pin name="GPA7" x="12.7" y="2.54" length="short" rot="R180"/>
<pin name="VDD" x="-12.7" y="20.32" length="short" direction="pwr"/>
<pin name="VSS" x="-12.7" y="-20.32" length="short" direction="pwr"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MCP23017" urn="urn:adsk.eagle:component:20914/4" prefix="IC" library_version="2">
<description>&lt;b&gt;http://ww1.microchip.com/downloads/en/DeviceDoc/21952a.pdf&lt;/b&gt;&lt;p&gt;
Source: http://ww1.microchip.com/downloads/en/DeviceDoc/21952a.pdf</description>
<gates>
<gate name="G$1" symbol="MCP23017" x="0" y="0"/>
</gates>
<devices>
<device name="SP" package="DIL28-3">
<connects>
<connect gate="G$1" pin="!RESET" pad="18"/>
<connect gate="G$1" pin="A0" pad="15"/>
<connect gate="G$1" pin="A1" pad="16"/>
<connect gate="G$1" pin="A2" pad="17"/>
<connect gate="G$1" pin="GPA0" pad="21"/>
<connect gate="G$1" pin="GPA1" pad="22"/>
<connect gate="G$1" pin="GPA2" pad="23"/>
<connect gate="G$1" pin="GPA3" pad="24"/>
<connect gate="G$1" pin="GPA4" pad="25"/>
<connect gate="G$1" pin="GPA5" pad="26"/>
<connect gate="G$1" pin="GPA6" pad="27"/>
<connect gate="G$1" pin="GPA7" pad="28"/>
<connect gate="G$1" pin="GPB0" pad="1"/>
<connect gate="G$1" pin="GPB1" pad="2"/>
<connect gate="G$1" pin="GPB2" pad="3"/>
<connect gate="G$1" pin="GPB3" pad="4"/>
<connect gate="G$1" pin="GPB4" pad="5"/>
<connect gate="G$1" pin="GPB5" pad="6"/>
<connect gate="G$1" pin="GPB6" pad="7"/>
<connect gate="G$1" pin="GPB7" pad="8"/>
<connect gate="G$1" pin="INTA" pad="20"/>
<connect gate="G$1" pin="INTB" pad="19"/>
<connect gate="G$1" pin="SCL" pad="12"/>
<connect gate="G$1" pin="SDA" pad="13"/>
<connect gate="G$1" pin="VDD" pad="9"/>
<connect gate="G$1" pin="VSS" pad="10"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:20799/2"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="MF" value="MICROCHIP" constant="no"/>
<attribute name="MPN" value="MCP23017-E/SP" constant="no"/>
<attribute name="OC_FARNELL" value="1332088" constant="no"/>
<attribute name="OC_NEWARK" value="31K2959" constant="no"/>
</technology>
</technologies>
</device>
<device name="SO" package="SO28W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:20803/2"/>
<technologies>
<attribute name="MPN" value="MCP23017-E/SO" constant="no"/>
<attribute name="OC_FARNELL" value="1332087" constant="no"/>
<attribute name="OC_NEWARK" value="31K2958" constant="no"/>
</technology>
</technologies>
</device>
<device name="SS" package="SSOP28">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:20800/1"/>
<technologies>
<attribute name="MPN" value="MCP23017-E/SS" constant="no"/>
<attribute name="OC_FARNELL" value="1467674" constant="no"/>
<attribute name="OC_NEWARK" value="31K2960" constant="no"/>
</technology>
</technologies>
</device>
<device name="ML" package="QFN28-ML_6X6MM">
<connects>
<connect gate="G$1" pin="!RESET" pad="14"/>
<connect gate="G$1" pin="A0" pad="11"/>
<connect gate="G$1" pin="A1" pad="12"/>
<connect gate="G$1" pin="A2" pad="13"/>
<connect gate="G$1" pin="GPA0" pad="17"/>
<connect gate="G$1" pin="GPA1" pad="18"/>
<connect gate="G$1" pin="GPA2" pad="19"/>
<connect gate="G$1" pin="GPA3" pad="20"/>
<connect gate="G$1" pin="GPA4" pad="21"/>
<connect gate="G$1" pin="GPA5" pad="22"/>
<connect gate="G$1" pin="GPA6" pad="23"/>
<connect gate="G$1" pin="GPA7" pad="24"/>
<connect gate="G$1" pin="GPB0" pad="25"/>
<connect gate="G$1" pin="GPB1" pad="26"/>
<connect gate="G$1" pin="GPB2" pad="27"/>
<connect gate="G$1" pin="GPB3" pad="28"/>
<connect gate="G$1" pin="GPB4" pad="1"/>
<connect gate="G$1" pin="GPB5" pad="2"/>
<connect gate="G$1" pin="GPB6" pad="3"/>
<connect gate="G$1" pin="GPB7" pad="4"/>
<connect gate="G$1" pin="INTA" pad="16"/>
<connect gate="G$1" pin="INTB" pad="15"/>
<connect gate="G$1" pin="SCL" pad="8"/>
<connect gate="G$1" pin="SDA" pad="9"/>
<connect gate="G$1" pin="VDD" pad="5"/>
<connect gate="G$1" pin="VSS" pad="6"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:20818/2"/>
<technologies>
<attribute name="MPN" value="MCP23017-E/ML" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="31K2957" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1" urn="urn:adsk.eagle:library:371">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
<packages>
</packages>
<symbols>
<symbol name="+5V" urn="urn:adsk.eagle:symbol:26929/1" library_version="1">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<text x="-2.54" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="+5V" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="GND" urn="urn:adsk.eagle:symbol:26925/1" library_version="1">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="+12V" urn="urn:adsk.eagle:symbol:26931/1" library_version="1">
<wire x1="1.27" y1="-0.635" x2="0" y2="1.27" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="-1.27" y2="-0.635" width="0.254" layer="94"/>
<pin name="+12V" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="+5V" urn="urn:adsk.eagle:component:26963/1" prefix="P+" library_version="1">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="+5V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GND" urn="urn:adsk.eagle:component:26954/1" prefix="GND" library_version="1">
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="+12V" urn="urn:adsk.eagle:component:26959/1" prefix="P+" library_version="1">
<gates>
<gate name="1" symbol="+12V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-lstb" urn="urn:adsk.eagle:library:162">
<description>&lt;b&gt;Pin Headers&lt;/b&gt;&lt;p&gt;
Naming:&lt;p&gt;
MA = male&lt;p&gt;
# contacts - # rows&lt;p&gt;
W = angled&lt;p&gt;
<packages>
<package name="MA03-1" urn="urn:adsk.eagle:footprint:8281/1" library_version="1">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-3.175" y1="1.27" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-3.81" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-0.635" size="1.27" layer="21" ratio="10">1</text>
<text x="-3.81" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="MA03-1" urn="urn:adsk.eagle:package:8339/1" type="box" library_version="1">
<description>PIN HEADER</description>
<packageinstances>
<packageinstance name="MA03-1"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="MA03-1" urn="urn:adsk.eagle:symbol:8280/1" library_version="1">
<wire x1="3.81" y1="-5.08" x2="-1.27" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="-1.27" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="3.81" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="3.81" y2="5.08" width="0.4064" layer="94"/>
<text x="-1.27" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<text x="-1.27" y="5.842" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MA03-1" urn="urn:adsk.eagle:component:8376/1" prefix="SV" uservalue="yes" library_version="1">
<gates>
<gate name="G$1" symbol="MA03-1" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MA03-1">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:8339/1"/>
<technologies>
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="adafruit">
<packages>
<package name="ARDUINOR3-BPLACE">
<wire x1="0" y1="0" x2="66.04" y2="0" width="0" layer="22"/>
<wire x1="66.04" y1="0" x2="66.04" y2="2.54" width="0" layer="22"/>
<wire x1="66.04" y1="2.54" x2="68.58" y2="5.08" width="0" layer="22"/>
<wire x1="68.58" y1="5.08" x2="68.58" y2="37.846" width="0" layer="22"/>
<wire x1="68.58" y1="37.846" x2="66.04" y2="40.386" width="0" layer="22"/>
<wire x1="66.04" y1="40.386" x2="66.04" y2="51.816" width="0" layer="22"/>
<wire x1="66.04" y1="51.816" x2="64.516" y2="53.34" width="0" layer="22"/>
<wire x1="64.516" y1="53.34" x2="0" y2="53.34" width="0" layer="22"/>
<wire x1="0" y1="53.34" x2="0" y2="0" width="0" layer="22"/>
<circle x="15.24" y="50.8" radius="1.796" width="0.127" layer="51"/>
<circle x="13.97" y="2.54" radius="1.796" width="0.127" layer="51"/>
<circle x="66.04" y="35.56" radius="1.796" width="0.127" layer="51"/>
<circle x="66.04" y="7.62" radius="1.796" width="0.127" layer="51"/>
<pad name="D0" x="63.5" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="GND" x="26.416" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="AREF" x="23.876" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="A4" x="60.96" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="A5" x="63.5" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="GND2" x="40.64" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="5V" x="38.1" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="SDA" x="21.336" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="SCL" x="18.796" y="50.8" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="IOREF" x="30.48" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="RESERVED" x="27.94" y="2.54" drill="1" diameter="1.6764" shape="octagon"/>
<text x="37.5463" y="3.81" size="1.016" layer="21" font="vector">5v</text>
<text x="40.7771" y="3.81" size="1.016" layer="21" font="vector">Gnd</text>
<text x="60.579" y="3.81" size="1.016" layer="21" font="vector">4</text>
<text x="63.119" y="3.81" size="1.016" layer="21" font="vector">5</text>
<text x="23.368" y="49.911" size="1.016" layer="21" font="vector" rot="R270">ARef</text>
<text x="25.908" y="49.784" size="1.016" layer="21" font="vector" rot="R270">gnd</text>
<text x="64.135" y="49.53" size="1.016" layer="21" font="vector" rot="R180">0</text>
<text x="18.288" y="49.911" size="1.016" layer="21" font="vector" rot="R270">SCL</text>
<text x="20.828" y="49.911" size="1.016" layer="21" font="vector" rot="R270">SDA</text>
<text x="30.988" y="3.7999" size="1.016" layer="21" font="vector" rot="R90">IOr</text>
</package>
<package name="1206">
<description>&lt;b&gt;CHICAGO MINIATURE LAMP, INC.&lt;/b&gt;&lt;p&gt;
7022X Series SMT LEDs 1206 Package Size</description>
<wire x1="1.55" y1="-0.75" x2="-1.55" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.55" y1="-0.75" x2="-1.55" y2="0.75" width="0.1016" layer="51"/>
<wire x1="-1.55" y1="0.75" x2="1.55" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.55" y1="0.75" x2="1.55" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-0.55" y1="-0.5" x2="0.55" y2="-0.5" width="0.1016" layer="21" curve="95.452622" cap="flat"/>
<wire x1="-0.55" y1="-0.5" x2="-0.55" y2="0.5" width="0.1016" layer="51" curve="-84.547378" cap="flat"/>
<wire x1="-0.55" y1="0.5" x2="0.55" y2="0.5" width="0.1016" layer="21" curve="-95.452622" cap="flat"/>
<wire x1="0.55" y1="0.5" x2="0.55" y2="-0.5" width="0.1016" layer="51" curve="-84.547378" cap="flat"/>
<smd name="A" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="C" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.1" y1="-0.1" x2="0.1" y2="0.1" layer="21"/>
<rectangle x1="0.45" y1="-0.7" x2="0.8" y2="-0.45" layer="51"/>
<rectangle x1="0.8" y1="-0.7" x2="0.9" y2="0.5" layer="51"/>
<rectangle x1="0.8" y1="0.55" x2="0.9" y2="0.7" layer="51"/>
<rectangle x1="-0.9" y1="-0.7" x2="-0.8" y2="0.5" layer="51"/>
<rectangle x1="-0.9" y1="0.55" x2="-0.8" y2="0.7" layer="51"/>
<rectangle x1="0.45" y1="-0.7" x2="0.6" y2="-0.45" layer="21"/>
</package>
<package name="LD260">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
5 mm, square, Siemens</description>
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.889" x2="1.27" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.889" x2="-1.27" y2="0.889" width="0.1524" layer="51"/>
<wire x1="0" y1="1.27" x2="0.9917" y2="0.7934" width="0.1524" layer="21" curve="-51.33923" cap="flat"/>
<wire x1="-0.9917" y1="0.7934" x2="0" y2="1.27" width="0.1524" layer="21" curve="-51.33923" cap="flat"/>
<wire x1="0" y1="-1.27" x2="0.9917" y2="-0.7934" width="0.1524" layer="21" curve="51.33923" cap="flat"/>
<wire x1="-0.9917" y1="-0.7934" x2="0" y2="-1.27" width="0.1524" layer="21" curve="51.33923" cap="flat"/>
<wire x1="0.9558" y1="-0.8363" x2="1.27" y2="0" width="0.1524" layer="51" curve="41.185419" cap="flat"/>
<wire x1="0.9756" y1="0.813" x2="1.2699" y2="0" width="0.1524" layer="51" curve="-39.806332" cap="flat"/>
<wire x1="-1.27" y1="0" x2="-0.9643" y2="-0.8265" width="0.1524" layer="51" curve="40.600331" cap="flat"/>
<wire x1="-1.27" y1="0" x2="-0.9643" y2="0.8265" width="0.1524" layer="51" curve="-40.600331" cap="flat"/>
<wire x1="-0.889" y1="0" x2="0" y2="0.889" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="-0.508" y1="0" x2="0" y2="0.508" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-0.508" x2="0.508" y2="0" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="0" y1="-0.889" x2="0.889" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.2954" y="1.4732" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-1.27" y="-2.4892" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
<rectangle x1="1.27" y1="-0.635" x2="2.032" y2="0.635" layer="51"/>
<rectangle x1="1.905" y1="-0.635" x2="2.032" y2="0.635" layer="21"/>
</package>
<package name="LED2X5">
2 x 5 mm, rectangle</description>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.381" x2="-0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.381" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="-0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0.381" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-0.254" x2="1.143" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.762" x2="1.143" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.762" x2="0.9398" y2="-0.6096" width="0.1524" layer="51"/>
<wire x1="0.9398" y1="-0.6096" x2="1.143" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-0.254" x2="1.651" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.762" x2="1.651" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.762" x2="1.4478" y2="-0.6096" width="0.1524" layer="51"/>
<wire x1="1.4478" y1="-0.6096" x2="1.651" y2="-0.508" width="0.1524" layer="51"/>
<text x="-2.54" y="1.397" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-2.54" y="-2.413" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
<rectangle x1="2.159" y1="-1.27" x2="2.413" y2="1.27" layer="21"/>
</package>
<package name="LED3MM">
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361" cap="flat"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208" cap="flat"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165" cap="flat"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361" cap="flat"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337" cap="flat"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102" cap="flat"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876" cap="flat"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876" cap="flat"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108" cap="flat"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949" cap="flat"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022" cap="flat"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215" cap="flat"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701" cap="flat"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822" cap="flat"/>
<wire x1="-2.5908" y1="1.7272" x2="-1.8542" y2="1.7272" width="0.127" layer="21"/>
<wire x1="-2.2352" y1="1.3208" x2="-2.2352" y2="2.1082" width="0.127" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LED5MM">
5 mm, round</description>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.254" layer="21" curve="-286.260205" cap="flat"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="3.175" y="0.5334" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.2004" y="-1.8034" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LSU260">
1 mm, round, Siemens</description>
<wire x1="0" y1="-0.508" x2="-1.143" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.508" x2="-1.143" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="0.508" x2="0" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-1.397" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-0.254" x2="-1.397" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="0.254" x2="-1.143" y2="0.508" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-0.254" x2="1.397" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-0.254" x2="1.397" y2="0.254" width="0.1524" layer="51"/>
<wire x1="1.397" y1="0.254" x2="0.508" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-0.381" x2="0.254" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.508" x2="-0.254" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.254" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0.381" x2="0.254" y2="0.508" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.508" x2="-0.254" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.381" x2="-0.254" y2="0.508" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.254" x2="0.254" y2="0" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="-0.254" y1="0" x2="0" y2="0.254" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="0.381" y1="-0.381" x2="0.381" y2="0.381" width="0.1524" layer="21" curve="90"/>
<circle x="0" y="0" radius="0.508" width="0.1524" layer="51"/>
<text x="-1.2954" y="0.8382" size="1.016" layer="25" ratio="14">&gt;NAME</text>
<text x="-1.27" y="-1.8542" size="1.016" layer="27" ratio="14">&gt;VALUE</text>
<rectangle x1="-1.397" y1="-0.254" x2="-1.143" y2="0.254" layer="51"/>
<rectangle x1="0.508" y1="-0.254" x2="1.397" y2="0.254" layer="51"/>
</package>
<package name="LZR181">
<description>&lt;B&gt;LED BLOCK&lt;/B&gt;&lt;p&gt;
1 LED, Siemens</description>
<wire x1="-0.8678" y1="0.7439" x2="0" y2="1.143" width="0.1524" layer="21" curve="-49.396139" cap="flat"/>
<wire x1="0" y1="1.143" x2="0.8678" y2="0.7439" width="0.1524" layer="21" curve="-49.396139" cap="flat"/>
<wire x1="-0.8678" y1="-0.7439" x2="0" y2="-1.143" width="0.1524" layer="21" curve="49.396139" cap="flat"/>
<wire x1="0" y1="-1.143" x2="0.8678" y2="-0.7439" width="0.1524" layer="21" curve="49.396139" cap="flat"/>
<wire x1="0.8678" y1="0.7439" x2="1.143" y2="0" width="0.1524" layer="51" curve="-40.604135" cap="flat"/>
<wire x1="0.8678" y1="-0.7439" x2="1.143" y2="0" width="0.1524" layer="51" curve="40.604135" cap="flat"/>
<wire x1="-1.143" y1="0" x2="-0.8678" y2="0.7439" width="0.1524" layer="51" curve="-40.604135" cap="flat"/>
<wire x1="-1.143" y1="0" x2="-0.8678" y2="-0.7439" width="0.1524" layer="51" curve="40.604135" cap="flat"/>
<wire x1="-1.27" y1="1.27" x2="1.27" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="1.27" y1="-0.889" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.27" y2="0.254" layer="51"/>
</package>
<package name="Q62902-B152">
<description>&lt;b&gt;LED HOLDER&lt;/b&gt;&lt;p&gt;
<wire x1="2.9718" y1="-1.8542" x2="-2.1082" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-2.1082" y1="1.8542" x2="2.9718" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-1.8542" x2="-2.9718" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.1082" y1="-1.8542" x2="-2.54" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-2.1082" y1="1.8542" x2="-2.54" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.8542" x2="-2.54" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.8542" x2="-2.9718" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.8542" x2="-2.9718" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="0.254" x2="-2.9718" y2="-0.254" width="0.1524" layer="21" curve="180"/>
<wire x1="-1.1486" y1="0.8814" x2="0" y2="1.4478" width="0.1524" layer="21" curve="-52.498642" cap="flat"/>
<wire x1="0" y1="1.4478" x2="1.1476" y2="0.8827" width="0.1524" layer="21" curve="-52.433716" cap="flat"/>
<wire x1="-1.1351" y1="-0.8987" x2="0" y2="-1.4478" width="0.1524" layer="21" curve="51.629985" cap="flat"/>
<wire x1="0" y1="-1.4478" x2="1.1305" y2="-0.9044" width="0.1524" layer="21" curve="51.339172" cap="flat"/>
<wire x1="1.1281" y1="-0.9074" x2="1.4478" y2="0" width="0.1524" layer="51" curve="38.811177" cap="flat"/>
<wire x1="1.1401" y1="0.8923" x2="1.4478" y2="0" width="0.1524" layer="51" curve="-38.048073" cap="flat"/>
<wire x1="-1.4478" y1="0" x2="-1.1305" y2="-0.9044" width="0.1524" layer="51" curve="38.659064" cap="flat"/>
<wire x1="-1.4478" y1="0" x2="-1.1456" y2="0.8853" width="0.1524" layer="51" curve="-37.696376" cap="flat"/>
<wire x1="0" y1="1.7018" x2="1.4674" y2="0.8618" width="0.1524" layer="21" curve="-59.573488" cap="flat"/>
<wire x1="-1.4618" y1="0.8714" x2="0" y2="1.7018" width="0.1524" layer="21" curve="-59.200638" cap="flat"/>
<wire x1="0" y1="-1.7018" x2="1.4571" y2="-0.8793" width="0.1524" layer="21" curve="58.891781" cap="flat"/>
<wire x1="-1.4571" y1="-0.8793" x2="0" y2="-1.7018" width="0.1524" layer="21" curve="58.891781" cap="flat"/>
<wire x1="-1.7018" y1="0" x2="-1.4447" y2="0.8995" width="0.1524" layer="51" curve="-31.907626" cap="flat"/>
<wire x1="-1.7018" y1="0" x2="-1.4502" y2="-0.8905" width="0.1524" layer="51" curve="31.551992" cap="flat"/>
<wire x1="1.4521" y1="0.8874" x2="1.7018" y2="0" width="0.1524" layer="51" curve="-31.429586" cap="flat"/>
<wire x1="1.4459" y1="-0.8975" x2="1.7018" y2="0" width="0.1524" layer="51" curve="31.828757" cap="flat"/>
<wire x1="-2.1082" y1="1.8542" x2="-2.1082" y2="0.4826" width="0.1524" layer="21"/>
<wire x1="-2.1082" y1="0.4826" x2="-2.1082" y2="-0.4826" width="0.1524" layer="21"/>
<wire x1="-2.1082" y1="-0.4826" x2="-2.1082" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="2.9718" y1="1.8542" x2="2.9718" y2="0.4826" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="0.4826" x2="2.9718" y2="-0.4826" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-0.4826" x2="2.9718" y2="-1.8542" width="0.1524" layer="21"/>
<pad name="K" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-1.905" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="Q62902-B153">
<wire x1="5.5118" y1="-3.5052" x2="-4.6482" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-4.6482" y1="3.5052" x2="5.5118" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="-3.5052" x2="-5.5118" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-4.6482" y1="-3.5052" x2="-5.08" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-4.6482" y1="3.5052" x2="-5.08" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.5052" x2="-5.08" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.5052" x2="-5.5118" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.5052" x2="-5.5118" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="0.254" x2="-5.5118" y2="-0.254" width="0.1524" layer="21" curve="180"/>
<wire x1="-4.6482" y1="3.5052" x2="-4.6482" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="3.5052" x2="5.5118" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="3.175" width="0.254" layer="21"/>
<text x="-4.191" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="Q62902-B155">
<wire x1="-1.27" y1="-3.048" x2="-1.27" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.033" y1="3.048" x2="2.921" y2="3.048" width="0.1524" layer="21"/>
<wire x1="10.033" y1="3.048" x2="10.033" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.048" x2="2.921" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-3.048" x2="2.921" y2="3.048" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-3.048" x2="10.033" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.921" y1="3.048" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-5.207" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.54" x2="-1.27" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-2.54" x2="-1.27" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.54" x2="-5.207" y2="-2.54" width="0.1524" layer="21" curve="180"/>
<wire x1="-6.985" y1="0.635" x2="-6.985" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.397" x2="-6.096" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="1.905" x2="-5.207" y2="-1.905" width="0.1524" layer="21"/>
<pad name="K" x="7.62" y="1.27" drill="0.8128" shape="long"/>
<pad name="A" x="7.62" y="-1.27" drill="0.8128" shape="long"/>
<text x="3.302" y="-2.794" size="1.016" layer="21" ratio="14">A+</text>
<text x="3.302" y="1.778" size="1.016" layer="21" ratio="14">K-</text>
<text x="11.684" y="-2.794" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="0.635" y="-4.445" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.921" y1="1.016" x2="6.731" y2="1.524" layer="21"/>
<rectangle x1="2.921" y1="-1.524" x2="6.731" y2="-1.016" layer="21"/>
<hole x="0" y="0" drill="0.8128"/>
</package>
<package name="Q62902-B156">
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.81" x2="3.81" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.81" x2="-3.81" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-3.81" x2="-3.81" y2="3.81" width="0.1524" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-3.81" x2="-2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.302" x2="-2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-3.81" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.302" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.302" x2="-2.54" y2="-3.302" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="K" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-3.81" y="4.0894" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.7846" y="-5.3594" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.556" y="-3.302" size="1.016" layer="21" ratio="14">+</text>
<text x="2.794" y="-3.302" size="1.016" layer="21" ratio="14">-</text>
</package>
<package name="SFH480">
<description>&lt;B&gt;IR LED&lt;/B&gt;&lt;p&gt;
infrared emitting diode, Infineon
TO-18, lead spacing 2.54 mm, cathode marking&lt;p&gt;
Inifineon</description>
<wire x1="-2.159" y1="1.524" x2="-2.794" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.159" x2="-2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.159" x2="-2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0" y1="1.778" x2="1.5358" y2="0.8959" width="0.1524" layer="21" curve="-59.743278" cap="flat"/>
<wire x1="-1.5358" y1="0.8959" x2="0" y2="1.778" width="0.1524" layer="21" curve="-59.743278" cap="flat"/>
<wire x1="-1.5358" y1="-0.8959" x2="0" y2="-1.778" width="0.1524" layer="21" curve="59.743278" cap="flat"/>
<wire x1="0" y1="-1.778" x2="1.5358" y2="-0.8959" width="0.1524" layer="21" curve="59.743278" cap="flat"/>
<wire x1="1.5142" y1="0.9318" x2="1.778" y2="0" width="0.1524" layer="51" curve="-31.606487" cap="flat"/>
<wire x1="1.5" y1="-0.9546" x2="1.778" y2="0" width="0.1524" layer="51" curve="32.472615" cap="flat"/>
<wire x1="-1.778" y1="0" x2="-1.5142" y2="-0.9318" width="0.1524" layer="51" curve="31.606487" cap="flat"/>
<wire x1="-1.778" y1="0" x2="-1.5" y2="0.9546" width="0.1524" layer="51" curve="-32.472615" cap="flat"/>
<circle x="0" y="0" radius="2.667" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.413" width="0.254" layer="21"/>
<text x="-1.27" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-4.318" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SFH482">
<pad name="K" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="U57X32">
rectangle, 5.7 x 3.2 mm</description>
<wire x1="-3.175" y1="1.905" x2="3.175" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="3.175" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="-3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.905" x2="-3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="2.54" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.286" y1="1.27" x2="2.286" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0.508" x2="2.54" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.508" x2="2.54" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.016" x2="2.54" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="1.27" x2="-1.778" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.254" y1="1.27" x2="0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.762" y1="1.27" x2="0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.778" y1="1.27" x2="1.778" y2="-1.27" width="0.1524" layer="51"/>
<text x="3.683" y="0.254" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.683" y="-1.524" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="IRL80A">
IR transmitter Siemens</description>
<wire x1="0.889" y1="2.286" x2="0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.889" y1="1.778" x2="0.889" y2="0.762" width="0.1524" layer="51"/>
<wire x1="0.889" y1="0.762" x2="0.889" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.635" x2="0.889" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-1.778" x2="0.889" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-2.286" x2="-0.889" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="2.286" x2="-0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.778" x2="-0.889" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="0.762" x2="-0.889" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-0.762" x2="-0.889" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-1.778" x2="-0.889" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="2.286" x2="0.889" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-0.762" x2="-0.889" y2="0.762" width="0.1524" layer="21" curve="-180"/>
<wire x1="-1.397" y1="0.254" x2="-1.397" y2="-0.254" width="0.0508" layer="21"/>
<wire x1="-1.143" y1="0.508" x2="-1.143" y2="-0.508" width="0.0508" layer="21"/>
<pad name="K" x="0" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="A" x="0" y="-1.27" drill="0.8128" shape="octagon"/>
<text x="1.27" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.27" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P-LCC-2">
<description>&lt;b&gt;TOPLED® High-optical Power LED (HOP)&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... ls_t675.pdf</description>
<wire x1="-1.4" y1="1.6" x2="-1.4" y2="-0.65" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-1.05" x2="-1.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-1.6" x2="-1.1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-1.1" y1="-1.6" x2="-0.85" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-0.85" y1="-1.6" x2="1.1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1.1" y1="-1.6" x2="1.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1.4" y1="-1.6" x2="1.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="1.4" y1="1.6" x2="-1.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1.1" y1="1.6" x2="-1.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="1.8" x2="1.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="1.1" y1="1.8" x2="1.1" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="-1.6" x2="-1.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="-1.8" x2="1.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="1.1" y1="-1.8" x2="1.1" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-0.85" y1="-1.6" x2="-1.4" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-1.05" x2="-1.4" y2="-0.65" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.1" width="0.2032" layer="51"/>
<smd name="C" x="0" y="-2.75" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="2.75" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="-2.54" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-0.635" y="2.54" size="1.27" layer="21">A</text>
<text x="-0.635" y="-3.81" size="1.27" layer="21">C</text>
<rectangle x1="-1.3" y1="-2.25" x2="1.3" y2="-0.75" layer="31"/>
<rectangle x1="-1.3" y1="0.75" x2="1.3" y2="2.25" layer="31"/>
<rectangle x1="-0.25" y1="-0.25" x2="0.25" y2="0.25" layer="21"/>
<rectangle x1="-1.4" y1="0.65" x2="1.4" y2="2.35" layer="29"/>
<rectangle x1="-1.4" y1="-2.35" x2="1.4" y2="-0.65" layer="29"/>
</package>
<package name="OSRAM-MINI-TOP-LED">
<description>&lt;b&gt;BLUE LINETM Hyper Mini TOPLED® Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LB M676.pdf</description>
<wire x1="-0.6" y1="0.9" x2="-0.6" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="-0.9" x2="-0.4" y2="-0.9" width="0.1016" layer="51"/>
<wire x1="-0.4" y1="-0.9" x2="0.6" y2="-0.9" width="0.1016" layer="51"/>
<wire x1="0.6" y1="-0.9" x2="0.6" y2="0.9" width="0.1016" layer="51"/>
<wire x1="0.6" y1="0.9" x2="-0.6" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="0.95" x2="-0.45" y2="1.1" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="1.1" x2="0.45" y2="1.1" width="0.1016" layer="51"/>
<wire x1="0.45" y1="1.1" x2="0.45" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-0.6" y1="-0.7" x2="-0.4" y2="-0.9" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="-0.9" x2="-0.45" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="-1.1" x2="0.45" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="0.45" y1="-1.1" x2="0.45" y2="-0.95" width="0.1016" layer="51"/>
<smd name="A" x="0" y="2.6" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="C" x="0" y="-2.6" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="-0.635" y="1.905" size="1.27" layer="21">A</text>
<text x="-0.635" y="-3.175" size="1.27" layer="21">C</text>
<rectangle x1="-0.5" y1="0.6" x2="0.5" y2="1.4" layer="31"/>
<rectangle x1="-0.5" y1="-1.4" x2="0.5" y2="-0.6" layer="31"/>
<rectangle x1="-0.15" y1="-0.6" x2="0.15" y2="-0.3" layer="51"/>
<rectangle x1="-0.45" y1="0.65" x2="0.45" y2="1.35" layer="31"/>
<rectangle x1="-0.45" y1="-1.35" x2="0.45" y2="-0.65" layer="31"/>
</package>
<package name="OSRAM-SIDELED">
<description>&lt;b&gt;Super SIDELED® High-Current LED&lt;/b&gt;&lt;p&gt;
LG A672, LP A672 &lt;br&gt;
Source: http://www.osram.convergy.de/ ... LG_LP_A672.pdf (2004.05.13)</description>
<wire x1="-1.85" y1="-2.05" x2="-1.85" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.85" y1="-0.75" x2="-1.7" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.7" y1="-0.75" x2="-1.7" y2="0.75" width="0.1016" layer="51"/>
<wire x1="-1.7" y1="0.75" x2="-1.85" y2="0.75" width="0.1016" layer="51"/>
<wire x1="-1.85" y1="0.75" x2="-1.85" y2="2.05" width="0.1016" layer="51"/>
<wire x1="-1.85" y1="2.05" x2="0.9" y2="2.05" width="0.1016" layer="51"/>
<wire x1="0.9" y1="2.05" x2="0.9" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-2.05" x2="-1.85" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-2.05" x2="1.05" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="1.05" y1="-2.05" x2="1.85" y2="-1.85" width="0.1016" layer="51"/>
<wire x1="1.85" y1="-1.85" x2="1.85" y2="1.85" width="0.1016" layer="51"/>
<wire x1="1.85" y1="1.85" x2="1.05" y2="2.05" width="0.1016" layer="51"/>
<wire x1="1.05" y1="2.05" x2="0.9" y2="2.05" width="0.1016" layer="51"/>
<wire x1="1.05" y1="2.05" x2="1.05" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="-0.55" y1="-0.9" x2="-0.55" y2="0.9" width="0.1016" layer="51" curve="-167.319617"/>
<wire x1="-0.55" y1="-0.9" x2="0.85" y2="-1.2" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-0.55" y1="0.9" x2="0.85" y2="1.2" width="0.1016" layer="51" style="shortdash"/>
<smd name="C" x="0" y="-2.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="2.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="0.635" y="-3.175" size="1.27" layer="21" rot="R90">C</text>
<text x="0.635" y="2.54" size="1.27" layer="21" rot="R90">A</text>
<text x="-2.54" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1" y1="-2.2" x2="2.1" y2="-0.4" layer="29"/>
<rectangle x1="-2.1" y1="0.4" x2="2.1" y2="2.2" layer="29"/>
<rectangle x1="-1.9" y1="-2.1" x2="1.9" y2="-0.6" layer="31"/>
<rectangle x1="-1.9" y1="0.6" x2="1.9" y2="2.1" layer="31"/>
<rectangle x1="-1.85" y1="-2.05" x2="-0.7" y2="-1" layer="51"/>
</package>
<package name="SMART-LED">
<description>&lt;b&gt;SmartLEDTM Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY L896.pdf</description>
<wire x1="-0.35" y1="0.6" x2="0.35" y2="0.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="0.35" y1="0.6" x2="0.35" y2="-0.6" width="0.1016" layer="21" style="shortdash"/>
<wire x1="0.35" y1="-0.6" x2="-0.35" y2="-0.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-0.35" y1="-0.6" x2="-0.35" y2="0.6" width="0.1016" layer="21" style="shortdash"/>
<wire x1="0.35" y1="-0.4" x2="0.15" y2="-0.6" width="0.1016" layer="51" style="shortdash"/>
<smd name="A" x="0" y="0.725" dx="0.35" dy="0.35" layer="1"/>
<smd name="B" x="0" y="-0.725" dx="0.35" dy="0.35" layer="1"/>
<text x="-0.635" y="-0.635" size="1.016" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-0.635" size="1.016" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.15" y1="-0.35" x2="0.15" y2="-0.05" layer="21"/>
<rectangle x1="-0.15" y1="0.6" x2="0.15" y2="0.85" layer="51"/>
<rectangle x1="-0.15" y1="-0.85" x2="0.15" y2="-0.6" layer="51"/>
</package>
<package name="P-LCC-2-TOPLED-RG">
<description>&lt;b&gt;Hyper TOPLED® RG Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY T776.pdf</description>
<wire x1="-1.1" y1="1.6" x2="-1.1" y2="2.45" width="0.1016" layer="51"/>
<wire x1="1.1" y1="2.45" x2="1.1" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="-1.6" x2="-1.1" y2="-2.45" width="0.1016" layer="51"/>
<wire x1="1.1" y1="-2.45" x2="1.1" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-1.4" y1="1.6" x2="-1.4" y2="-1.05" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.1" width="0.2032" layer="21"/>
<smd name="C" x="0" y="-3.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="3.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="-0.635" y="3.29" size="1.27" layer="21">A</text>
<text x="-0.635" y="-4.56" size="1.27" layer="21">C</text>
<rectangle x1="-1.3" y1="-3" x2="1.3" y2="-1.5" layer="31"/>
<rectangle x1="-1.3" y1="1.5" x2="1.3" y2="3" layer="31"/>
<rectangle x1="-1.15" y1="2.4" x2="1.15" y2="2.7" layer="51"/>
<rectangle x1="-1.15" y1="-2.7" x2="1.15" y2="-2.4" layer="51"/>
<rectangle x1="-1.5" y1="1.5" x2="1.5" y2="3.2" layer="29"/>
<rectangle x1="-1.5" y1="-3.2" x2="1.5" y2="-1.5" layer="29"/>
<hole x="0" y="0" drill="2.8"/>
</package>
<package name="MICRO-SIDELED">
<description>&lt;b&gt;Hyper Micro SIDELED®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY Y876.pdf</description>
<wire x1="0.65" y1="1.1" x2="-0.1" y2="1.1" width="0.1016" layer="51"/>
<wire x1="-0.1" y1="1.1" x2="-0.35" y2="1" width="0.1016" layer="51"/>
<wire x1="-0.35" y1="1" x2="-0.35" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-0.35" y1="-0.9" x2="-0.1" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="-0.1" y1="-1.1" x2="0.65" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="0.65" y1="-1.1" x2="0.65" y2="1.1" width="0.1016" layer="21"/>
<wire x1="0.6" y1="0.9" x2="0.25" y2="0.7" width="0.0508" layer="21"/>
<wire x1="0.25" y1="0.7" x2="0.25" y2="-0.7" width="0.0508" layer="21"/>
<wire x1="0.25" y1="-0.7" x2="0.6" y2="-0.9" width="0.0508" layer="21"/>
<smd name="A" x="0" y="1.95" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<smd name="C" x="0" y="-1.95" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<text x="-1.27" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.54" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.4" y1="1.1" x2="0.4" y2="1.8" layer="29"/>
<rectangle x1="-0.4" y1="-1.8" x2="0.4" y2="-1.1" layer="29"/>
<rectangle x1="-0.35" y1="-1.75" x2="0.35" y2="-1.15" layer="31"/>
<rectangle x1="-0.35" y1="1.15" x2="0.35" y2="1.75" layer="31"/>
<rectangle x1="-0.125" y1="1.125" x2="0.125" y2="1.75" layer="51"/>
<rectangle x1="-0.125" y1="-1.75" x2="0.125" y2="-1.125" layer="51"/>
</package>
<package name="P-LCC-4">
<description>&lt;b&gt;Power TOPLED®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LA_LY E67B.pdf</description>
<wire x1="-1.4" y1="-1.6" x2="-1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-1" y1="-1.6" x2="-0.85" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-0.85" y1="-1.6" x2="1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1" y1="-1.6" x2="1.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1.4" y1="1.6" x2="-1" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1" y1="1.6" x2="-1.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1" y1="1.6" x2="-1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-1" y1="1.8" x2="-0.5" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-0.5" y1="1.8" x2="-0.5" y2="1.65" width="0.1016" layer="51"/>
<wire x1="0.5" y1="1.65" x2="0.5" y2="1.8" width="0.1016" layer="51"/>
<wire x1="0.5" y1="1.8" x2="1.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-1" y1="-1.6" x2="-1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="-1" y1="-1.8" x2="-0.5" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="-0.5" y1="-1.8" x2="-0.5" y2="-1.65" width="0.1016" layer="51"/>
<wire x1="0.5" y1="-1.65" x2="0.5" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="0.5" y1="-1.8" x2="1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="1" y1="-1.8" x2="1" y2="-1.6" width="0.1016" layer="51"/>
<smd name="A" x="-2" y="3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<smd name="C@3" x="2" y="3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<smd name="C@4" x="2" y="-3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<smd name="C@1" x="-2" y="-3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-1.905" y="-3.81" size="1.27" layer="21">C</text>
<text x="-1.905" y="2.54" size="1.27" layer="21">A</text>
<text x="1.27" y="2.54" size="1.27" layer="21">C</text>
<text x="1.27" y="-3.81" size="1.27" layer="21">C</text>
<rectangle x1="-1.15" y1="0.75" x2="-0.35" y2="1.85" layer="29"/>
<rectangle x1="0.35" y1="0.75" x2="1.15" y2="1.85" layer="29"/>
<rectangle x1="0.35" y1="-1.85" x2="1.15" y2="-0.75" layer="29"/>
<rectangle x1="-1.15" y1="-1.85" x2="-0.35" y2="-0.75" layer="29"/>
<rectangle x1="-1.1" y1="-1.8" x2="-0.4" y2="-0.8" layer="31"/>
<rectangle x1="0.4" y1="-1.8" x2="1.1" y2="-0.8" layer="31"/>
<rectangle x1="0.4" y1="0.8" x2="1.1" y2="1.8" layer="31"/>
<rectangle x1="-1.1" y1="0.8" x2="-0.4" y2="1.8" layer="31"/>
<rectangle x1="-0.2" y1="-0.2" x2="0.2" y2="0.2" layer="21"/>
</package>
<package name="CHIP-LED0603">
<description>&lt;b&gt;Hyper CHIPLED Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
LB Q993&lt;br&gt;
Source: http://www.osram.convergy.de/ ... Lb_q993.pdf</description>
<wire x1="-0.4" y1="0.45" x2="-0.4" y2="-0.45" width="0.1016" layer="51"/>
<wire x1="0.4" y1="0.45" x2="0.4" y2="-0.45" width="0.1016" layer="51"/>
<smd name="C" x="0" y="0.75" dx="0.8" dy="0.8" layer="1"/>
<smd name="A" x="0" y="-0.75" dx="0.8" dy="0.8" layer="1"/>
<text x="-0.635" y="-0.635" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-0.635" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.45" y1="0.45" x2="0.45" y2="0.85" layer="51"/>
<rectangle x1="-0.45" y1="-0.85" x2="0.45" y2="-0.45" layer="51"/>
<rectangle x1="-0.45" y1="0" x2="-0.3" y2="0.3" layer="21"/>
<rectangle x1="0.3" y1="0" x2="0.45" y2="0.3" layer="21"/>
<rectangle x1="-0.15" y1="0" x2="0.15" y2="0.3" layer="21"/>
</package>
<package name="CHIP-LED0805">
LB R99A&lt;br&gt;
Source: http://www.osram.convergy.de/ ... lb_r99a.pdf</description>
<wire x1="-0.625" y1="0.45" x2="-0.625" y2="-0.45" width="0.1016" layer="51"/>
<wire x1="0.625" y1="0.45" x2="0.625" y2="-0.475" width="0.1016" layer="51"/>
<smd name="C" x="0" y="1.05" dx="1.2" dy="1.2" layer="1"/>
<smd name="A" x="0" y="-1.05" dx="1.2" dy="1.2" layer="1"/>
<text x="-1.27" y="-1.27" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.54" y="-1.27" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-1.27" y="-2.54" size="1.016" layer="21" font="vector">+</text>
<rectangle x1="-0.675" y1="0" x2="-0.525" y2="0.3" layer="21"/>
<rectangle x1="0.525" y1="0" x2="0.675" y2="0.3" layer="21"/>
<rectangle x1="-0.675" y1="0.45" x2="0.675" y2="1.05" layer="51"/>
<rectangle x1="-0.675" y1="-1.05" x2="0.675" y2="-0.45" layer="51"/>
</package>
<package name="MINI-TOPLED-SANTANA">
<description>&lt;b&gt;Mini TOPLED Santana®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LG M470.pdf</description>
<wire x1="0.7" y1="-1" x2="0.35" y2="-1" width="0.1016" layer="21"/>
<wire x1="0.35" y1="-1" x2="-0.45" y2="-1" width="0.1016" layer="21"/>
<wire x1="-0.45" y1="-1" x2="-0.7" y2="-1" width="0.1016" layer="21"/>
<wire x1="-0.7" y1="-1" x2="-0.7" y2="-0.75" width="0.1016" layer="21"/>
<wire x1="-0.7" y1="-0.75" x2="-0.7" y2="1" width="0.1016" layer="21"/>
<wire x1="-0.7" y1="1" x2="0.7" y2="1" width="0.1016" layer="21"/>
<wire x1="0.7" y1="1" x2="0.7" y2="-0.65" width="0.1016" layer="21"/>
<wire x1="0.7" y1="-0.65" x2="0.7" y2="-1" width="0.1016" layer="21"/>
<wire x1="0.45" y1="-0.7" x2="-0.45" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="-0.45" y1="-0.7" x2="-0.45" y2="0.7" width="0.1016" layer="21"/>
<wire x1="-0.45" y1="0.7" x2="0.45" y2="0.7" width="0.1016" layer="21"/>
<wire x1="0.45" y1="0.7" x2="0.45" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="0.7" y1="-0.65" x2="0.35" y2="-1" width="0.1016" layer="21"/>
<smd name="C" x="0" y="-2.2" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="2.2" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<rectangle x1="-0.55" y1="1.5" x2="0.55" y2="2.1" layer="29"/>
<rectangle x1="-0.55" y1="-2.1" x2="0.55" y2="-1.5" layer="29"/>
<rectangle x1="-0.5" y1="-2.05" x2="0.5" y2="-1.55" layer="31"/>
<rectangle x1="-0.5" y1="1.55" x2="0.5" y2="2.05" layer="31"/>
<rectangle x1="-0.2" y1="-0.4" x2="0.15" y2="-0.05" layer="21"/>
<rectangle x1="-0.5" y1="-2.1" x2="0.5" y2="-1.4" layer="51"/>
<rectangle x1="-0.5" y1="1.4" x2="0.5" y2="2.05" layer="51"/>
<rectangle x1="-0.5" y1="1" x2="0.5" y2="1.4" layer="21"/>
<rectangle x1="-0.5" y1="-1.4" x2="0.5" y2="-1.05" layer="21"/>
<hole x="0" y="0" drill="2.7"/>
</package>
<package name="CHIPLED_0805">
<description>&lt;b&gt;CHIPLED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LG_R971.pdf</description>
<wire x1="-0.35" y1="1" x2="0.35" y2="1" width="0.1016" layer="51" curve="180" cap="flat"/>
<wire x1="-0.35" y1="-1" x2="0.35" y2="-1" width="0.1016" layer="51" curve="-180" cap="flat"/>
<wire x1="0.575" y1="0.525" x2="0.575" y2="-0.525" width="0.1016" layer="51"/>
<wire x1="-0.575" y1="-0.5" x2="-0.575" y2="0.925" width="0.1016" layer="51"/>
<circle x="-0.45" y="0.85" radius="0.103" width="0.1016" layer="51"/>
<rectangle x1="0.3" y1="0.5" x2="0.625" y2="1" layer="51"/>
<rectangle x1="-0.325" y1="0.5" x2="-0.175" y2="0.75" layer="51"/>
<rectangle x1="0.175" y1="0.5" x2="0.325" y2="0.75" layer="51"/>
<rectangle x1="-0.2" y1="0.5" x2="0.2" y2="0.675" layer="51"/>
<rectangle x1="0.3" y1="-1" x2="0.625" y2="-0.5" layer="51"/>
<rectangle x1="-0.625" y1="-1" x2="-0.3" y2="-0.5" layer="51"/>
<rectangle x1="0.175" y1="-0.75" x2="0.325" y2="-0.5" layer="51"/>
<rectangle x1="-0.325" y1="-0.75" x2="-0.175" y2="-0.5" layer="51"/>
<rectangle x1="-0.2" y1="-0.675" x2="0.2" y2="-0.5" layer="51"/>
<rectangle x1="-0.1" y1="0" x2="0.1" y2="0.2" layer="21"/>
<rectangle x1="-0.6" y1="0.5" x2="-0.3" y2="0.8" layer="51"/>
<rectangle x1="-0.625" y1="0.925" x2="-0.4" y2="1" layer="51"/>
</package>
<package name="CHIPLED_1206">
Source: http://www.osram.convergy.de/ ... LG_LY N971.pdf</description>
<wire x1="-0.4" y1="1.625" x2="0.4" y2="1.625" width="0.1016" layer="51" curve="180" cap="flat"/>
<wire x1="-0.8" y1="-0.95" x2="-0.8" y2="0.95" width="0.1016" layer="51"/>
<wire x1="0.8" y1="0.95" x2="0.8" y2="-0.95" width="0.1016" layer="51"/>
<circle x="-0.55" y="1.425" radius="0.1" width="0.1016" layer="51"/>
<smd name="C" x="0" y="1.75" dx="1.5" dy="1.5" layer="1"/>
<smd name="A" x="0" y="-1.75" dx="1.5" dy="1.5" layer="1"/>
<rectangle x1="-0.85" y1="1.525" x2="-0.35" y2="1.65" layer="51"/>
<rectangle x1="-0.85" y1="1.225" x2="-0.625" y2="1.55" layer="51"/>
<rectangle x1="-0.45" y1="1.225" x2="-0.325" y2="1.45" layer="51"/>
<rectangle x1="-0.65" y1="1.225" x2="-0.225" y2="1.35" layer="51"/>
<rectangle x1="0.35" y1="1.3" x2="0.85" y2="1.65" layer="51"/>
<rectangle x1="0.25" y1="1.225" x2="0.85" y2="1.35" layer="51"/>
<rectangle x1="-0.85" y1="0.95" x2="0.85" y2="1.25" layer="51"/>
<rectangle x1="-0.85" y1="-1.65" x2="0.85" y2="-0.95" layer="51"/>
<rectangle x1="-0.85" y1="0.35" x2="-0.525" y2="0.775" layer="21"/>
<rectangle x1="0.525" y1="0.35" x2="0.85" y2="0.775" layer="21"/>
<rectangle x1="-0.175" y1="0" x2="0.175" y2="0.35" layer="21"/>
</package>
<package name="CHIPLED_0603">
Source: http://www.osram.convergy.de/ ... LG_LY Q971.pdf</description>
<wire x1="-0.3" y1="0.825" x2="0.3" y2="0.825" width="0.1016" layer="51" curve="180" cap="flat"/>
<wire x1="-0.275" y1="-0.825" x2="0.275" y2="-0.825" width="0.0508" layer="51" curve="-180" cap="flat"/>
<wire x1="-0.4" y1="0.375" x2="-0.4" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="0.4" y1="0.35" x2="0.4" y2="-0.35" width="0.1016" layer="51"/>
<circle x="-0.35" y="0.625" radius="0.075" width="0.0508" layer="51"/>
<text x="-0.635" y="-1.27" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-1.27" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.45" y1="0.7" x2="-0.25" y2="0.85" layer="51"/>
<rectangle x1="-0.275" y1="0.55" x2="-0.225" y2="0.6" layer="51"/>
<rectangle x1="-0.45" y1="0.35" x2="-0.4" y2="0.725" layer="51"/>
<rectangle x1="0.25" y1="0.55" x2="0.45" y2="0.85" layer="51"/>
<rectangle x1="-0.45" y1="0.35" x2="0.45" y2="0.575" layer="51"/>
<rectangle x1="-0.45" y1="-0.85" x2="-0.25" y2="-0.35" layer="51"/>
<rectangle x1="0.25" y1="-0.85" x2="0.45" y2="-0.35" layer="51"/>
<rectangle x1="-0.275" y1="-0.575" x2="0.275" y2="-0.35" layer="51"/>
<rectangle x1="-0.275" y1="-0.65" x2="-0.175" y2="-0.55" layer="51"/>
<rectangle x1="0.175" y1="-0.65" x2="0.275" y2="-0.55" layer="51"/>
<rectangle x1="-0.125" y1="0" x2="0.125" y2="0.25" layer="21"/>
</package>
<package name="CHIPLED-0603-TTW">
<description>&lt;b&gt;CHIPLED-0603&lt;/b&gt;&lt;p&gt;
Recommended Solder Pad useable for SmartLEDTM and Chipled - Package 0603&lt;br&gt;
Package able to withstand TTW-soldering heat&lt;br&gt;
Package suitable for TTW-soldering&lt;br&gt;
Source: http://www.osram.convergy.de/ ... LO_LS_LY L89K.pdf</description>
<smd name="C" x="0" y="0.875" dx="0.8" dy="0.5" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="-0.875" dx="0.8" dy="0.5" layer="1" stop="no" cream="no"/>
<smd name="A@1" x="0" y="-0.5" dx="0.35" dy="0.35" layer="1"/>
<smd name="C@1" x="0" y="0.5" dx="0.35" dy="0.35" layer="1"/>
<rectangle x1="-0.175" y1="0.325" x2="0.175" y2="0.7" layer="29"/>
<rectangle x1="-0.4" y1="0.625" x2="0.4" y2="1.125" layer="29"/>
<rectangle x1="-0.4" y1="-1.125" x2="0.4" y2="-0.625" layer="29"/>
<rectangle x1="-0.175" y1="-0.675" x2="0.175" y2="-0.325" layer="29"/>
</package>
<package name="SMARTLED-TTW">
<description>&lt;b&gt;SmartLED TTW&lt;/b&gt;&lt;p&gt;
<smd name="A@1" x="0" y="-0.5" dx="0.35" dy="0.35" layer="1" stop="no" cream="no"/>
<smd name="C@1" x="0" y="0.5" dx="0.35" dy="0.35" layer="1" stop="no" cream="no"/>
<rectangle x1="-0.225" y1="0.3" x2="0.225" y2="0.975" layer="31"/>
<rectangle x1="-0.175" y1="-0.7" x2="0.175" y2="-0.325" layer="29" rot="R180"/>
<rectangle x1="-0.225" y1="-0.975" x2="0.225" y2="-0.3" layer="31" rot="R180"/>
</package>
<package name="SMLK34">
<wire x1="-2" y1="1" x2="1.7" y2="1" width="0.127" layer="21"/>
<wire x1="1.7" y1="1" x2="2" y2="0.7" width="0.127" layer="21"/>
<wire x1="2" y1="0.7" x2="2" y2="-1" width="0.127" layer="21"/>
<wire x1="2" y1="-1" x2="-2" y2="-1" width="0.127" layer="21"/>
<wire x1="-2" y1="-1" x2="-2" y2="1" width="0.127" layer="21"/>
<wire x1="-1.8" y1="0.8" x2="-1.8" y2="-0.8" width="0.127" layer="25"/>
<wire x1="-1.8" y1="-0.8" x2="1.8" y2="-0.8" width="0.127" layer="25"/>
<wire x1="1.8" y1="-0.8" x2="1.8" y2="0.6" width="0.127" layer="25"/>
<wire x1="1.8" y1="0.6" x2="1.6" y2="0.8" width="0.127" layer="25"/>
<wire x1="1.6" y1="0.8" x2="-1.8" y2="0.8" width="0.127" layer="25"/>
<smd name="A" x="0.9" y="0" dx="3.65" dy="1.74" layer="1" rot="R180"/>
<smd name="K" x="-2.1" y="0" dx="1.35" dy="1.74" layer="1" rot="R180"/>
<text x="-2.8" y="-3.97" size="1.27" layer="25" font="vector">&gt;NAME</text>
<text x="-2.8" y="-5.37" size="1.27" layer="27" font="vector">&gt;VALUE</text>
<text x="1.73" y="-2.178" size="1.016" layer="21" font="vector">A</text>
<text x="-2.938" y="-2.178" size="1.016" layer="21" font="vector">K</text>
</package>
<package name="R0402">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.762" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R0603">
chip</description>
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<text x="-0.889" y="0.889" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.889" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
</package>
<package name="R0805">
chip</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-1" y="0" dx="1.1" dy="1.4" layer="1"/>
<smd name="2" x="1" y="0" dx="1.1" dy="1.4" layer="1"/>
<text x="-0.762" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.762" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="21"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="21"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="R0805W">
chip, wave soldering</description>
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
<text x="-0.635" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.159" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
</package>
<package name="R1005">
chip</description>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="R1206">
chip</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.397" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R1206W">
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="21"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="21"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
</package>
<package name="R1210">
chip</description>
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.27" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
</package>
<package name="R1210W">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="21"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="21"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<text x="-1.651" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010">
chip</description>
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-1.027" y1="1.245" x2="1.027" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.002" y1="-1.245" x2="1.016" y2="-1.245" width="0.1524" layer="21"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-2.159" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="R2010W">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="21"/>
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
<text x="-2.286" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.286" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R2012">
chip</description>
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="R2012W">
<text x="-0.635" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R2512">
chip</description>
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="1.473" x2="1.498" y2="1.473" width="0.1524" layer="21"/>
<wire x1="-1.473" y1="-1.473" x2="1.498" y2="-1.473" width="0.1524" layer="21"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<text x="-2.667" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.667" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R2512W">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="21"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="21"/>
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-2.794" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3216">
chip</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="R3216W">
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3225">
chip</description>
<text x="-1.397" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="R3225W">
<text x="-1.397" y="1.524" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="R5025">
chip</description>
<wire x1="-0.9" y1="1.245" x2="0.9" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-0.875" y1="-1.245" x2="0.925" y2="-1.245" width="0.1524" layer="21"/>
</package>
<package name="R5025W">
<text x="-2.286" y="1.651" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="R6332">
chip</description>
<text x="-2.794" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R6332W">
<text x="-2.921" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.921" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="M0805">
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1.016" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.016" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="M1206">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
</package>
<package name="M1406">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="0.6858" y1="0.762" x2="-0.6858" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="-0.762" x2="-0.6858" y2="-0.762" width="0.1524" layer="21"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
<package name="M2012">
</package>
<package name="M2309">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<wire x1="1.651" y1="1.1684" x2="-1.6764" y2="1.1684" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.1684" x2="-1.651" y2="-1.1684" width="0.1524" layer="21"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.794" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
</package>
<package name="M3216">
</package>
<package name="M3516">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M5923">
</package>
<package name="0204/5">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/15">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0309/10">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
</package>
<package name="0309/12">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="0411/12">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="0411/15">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0411V">
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="0414/15">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
</package>
<package name="0414V">
type 0414, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
</package>
<package name="0617/17">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="0617/22">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
<package name="0617V">
type 0617, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="0922/22">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="P0613V">
type 0613, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="P0613/15">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="P0817/22">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
</package>
<package name="P0817V">
type 0817, grid 6.35 mm</description>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
</package>
<package name="V234/12">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
</package>
<package name="V235/17">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="V526-0">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102AX">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
<hole x="0" y="0" drill="1.3"/>
</package>
<package name="0922V">
type 0922, grid 7.5 mm</description>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="MINI_MELF-0102R">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0102W">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0204R">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0204W">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0207R">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0207W">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RDH/15">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="0204V">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="0309V">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="0805-THM">
<wire x1="-4.5" y1="0" x2="-1.1" y2="0" width="0.3048" layer="1"/>
<wire x1="1" y1="0" x2="5.1" y2="0" width="0.3048" layer="1"/>
<text x="-3.1306" y="-2.775" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.6254" y1="-0.7" x2="-0.4254" y2="0.7" layer="1"/>
<rectangle x1="0.4254" y1="-0.7" x2="1.6254" y2="0.7" layer="1"/>
<rectangle x1="-1.7254" y1="-0.8" x2="-0.3254" y2="0.8" layer="29"/>
<rectangle x1="0.3254" y1="-0.8" x2="1.7254" y2="0.8" layer="29"/>
<rectangle x1="-1.6254" y1="-0.7" x2="-0.4254" y2="0.7" layer="31"/>
<rectangle x1="0.4254" y1="-0.7" x2="1.6254" y2="0.7" layer="31"/>
</package>
<package name="0805-THM-7">
<wire x1="4.318" y1="0" x2="3.302" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="0" x2="-3.302" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.413" y1="0.889" x2="-2.159" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="-0.889" x2="-2.159" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.159" y1="-1.143" x2="2.413" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.159" y1="1.143" x2="2.413" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="-0.889" x2="-2.413" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.143" x2="-1.778" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.016" x2="-1.778" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-1.143" x2="-1.778" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-1.016" x2="-1.778" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.016" x2="1.778" y2="1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.016" x2="-1.651" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.016" x2="1.778" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.016" x2="-1.651" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.143" x2="1.778" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.143" x2="1.778" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.889" x2="2.413" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.738" y1="0" x2="-1.1" y2="0" width="0.3048" layer="1"/>
<wire x1="1" y1="0" x2="4.338" y2="0" width="0.3048" layer="1"/>
<pad name="1" x="-4.318" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="4.318" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<rectangle x1="2.413" y1="-0.3048" x2="3.2766" y2="0.3048" layer="21"/>
<rectangle x1="-3.2766" y1="-0.3048" x2="-2.413" y2="0.3048" layer="21"/>
<rectangle x1="-1.64" y1="-0.7" x2="-0.41" y2="0.71" layer="31"/>
<rectangle x1="0.4" y1="-0.7" x2="1.64" y2="0.7" layer="31"/>
</package>
<package name="0207/9">
<pad name="1" x="-4.572" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<pad name="2" x="4.572" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
</package>
<package name="SOT23-W">
<description>&lt;b&gt;SOT23&lt;/b&gt; - Wave soldering</description>
<wire x1="1.5724" y1="0.6604" x2="1.5724" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.5724" y1="-0.6604" x2="-1.5724" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.5724" y1="-0.6604" x2="-1.5724" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.5724" y1="0.6604" x2="1.5724" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.5724" y1="-0.3984" x2="-1.5724" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="1.5724" y1="0.6604" x2="1.5724" y2="-0.3984" width="0.1524" layer="21"/>
<wire x1="0.2954" y1="-0.6604" x2="-0.3094" y2="-0.6604" width="0.1524" layer="21"/>
<smd name="3" x="0" y="1.3" dx="2.8" dy="1.4" layer="1"/>
<smd name="2" x="1.1" y="-1.3" dx="1.2" dy="1.4" layer="1"/>
<smd name="1" x="-1.1" y="-1.3" dx="1.2" dy="1.4" layer="1"/>
<text x="2.032" y="0.254" size="0.4064" layer="25">&gt;NAME</text>
<text x="2.032" y="-0.508" size="0.4064" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
<package name="SOT23">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="TO220V">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="ARDUINOR3">
<wire x1="-33.02" y1="25.4" x2="-33.02" y2="-25.4" width="0.254" layer="94"/>
<wire x1="-33.02" y1="-25.4" x2="25.4" y2="-25.4" width="0.254" layer="94"/>
<wire x1="25.4" y1="-25.4" x2="25.4" y2="-22.86" width="0.254" layer="94"/>
<wire x1="25.4" y1="-22.86" x2="30.48" y2="-17.78" width="0.254" layer="94"/>
<wire x1="30.48" y1="-17.78" x2="30.48" y2="7.62" width="0.254" layer="94"/>
<wire x1="30.48" y1="7.62" x2="25.4" y2="12.7" width="0.254" layer="94"/>
<wire x1="25.4" y1="12.7" x2="25.4" y2="22.86" width="0.254" layer="94"/>
<wire x1="25.4" y1="22.86" x2="22.86" y2="25.4" width="0.254" layer="94"/>
<wire x1="22.86" y1="25.4" x2="-33.02" y2="25.4" width="0.254" layer="94"/>
<wire x1="-25.4" y1="17.78" x2="-25.4" y2="-10.16" width="0.254" layer="94" style="shortdash"/>
<wire x1="-25.4" y1="-10.16" x2="22.86" y2="-10.16" width="0.254" layer="94" style="shortdash"/>
<wire x1="22.86" y1="-10.16" x2="22.86" y2="-15.24" width="0.254" layer="94" style="shortdash"/>
<wire x1="-22.86" y1="17.78" x2="-22.86" y2="-7.62" width="0.254" layer="94" style="shortdash"/>
<wire x1="-22.86" y1="-7.62" x2="20.32" y2="-7.62" width="0.254" layer="94" style="shortdash"/>
<wire x1="20.32" y1="-7.62" x2="20.32" y2="-15.24" width="0.254" layer="94" style="shortdash"/>
<text x="-17.78" y="2.54" size="5.08" layer="94">ARDUINO</text>
<text x="-10.16" y="-2.54" size="2.54" layer="94">UNO R3</text>
<pin name="D0" x="20.32" y="30.48" visible="pin" length="middle" rot="R270"/>
<pin name="GND" x="-17.78" y="30.48" visible="pin" length="middle" direction="pwr" rot="R270"/>
<pin name="AREF" x="-20.32" y="30.48" visible="pin" length="middle" rot="R270"/>
<pin name="A5/SCL" x="22.86" y="-30.48" visible="pin" length="middle" rot="R90"/>
<pin name="A4/SDA" x="20.32" y="-30.48" visible="pin" length="middle" rot="R90"/>
<pin name="GND2" x="0" y="-30.48" visible="pin" length="middle" direction="pwr" rot="R90"/>
<pin name="5V" x="-2.54" y="-30.48" visible="pin" length="middle" direction="pwr" rot="R90"/>
<pin name="IOREF" x="-10.16" y="-30.48" visible="pin" length="middle" direction="out" rot="R90"/>
<pin name="RESERVED" x="-12.7" y="-30.48" visible="pin" length="middle" direction="nc" rot="R90"/>
<pin name="SCL" x="-25.4" y="30.48" visible="pin" length="middle" rot="R270"/>
<pin name="SDA" x="-22.86" y="30.48" visible="pin" length="middle" rot="R270"/>
</symbol>
<symbol name="LED">
<wire x1="1.27" y1="0" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="-1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-2.032" y1="-0.762" x2="-3.429" y2="-2.159" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="-3.302" y2="-3.302" width="0.1524" layer="94"/>
<text x="3.556" y="-4.572" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="5.715" y="-4.572" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="C" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="A" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
<polygon width="0.1524" layer="94">
<vertex x="-3.429" y="-2.159"/>
<vertex x="-3.048" y="-1.27"/>
<vertex x="-2.54" y="-1.778"/>
</polygon>
<vertex x="-3.302" y="-3.302"/>
<vertex x="-2.921" y="-2.413"/>
<vertex x="-2.413" y="-2.921"/>
</polygon>
</symbol>
<symbol name="R-US">
<wire x1="-2.54" y1="0" x2="-2.159" y2="1.016" width="0.2032" layer="94"/>
<wire x1="-2.159" y1="1.016" x2="-1.524" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="-1.524" y1="-1.016" x2="-0.889" y2="1.016" width="0.2032" layer="94"/>
<wire x1="-0.889" y1="1.016" x2="-0.254" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="-0.254" y1="-1.016" x2="0.381" y2="1.016" width="0.2032" layer="94"/>
<wire x1="0.381" y1="1.016" x2="1.016" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="1.016" y1="-1.016" x2="1.651" y2="1.016" width="0.2032" layer="94"/>
<wire x1="1.651" y1="1.016" x2="2.286" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="0" width="0.2032" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="MOSFET-N">
<wire x1="0.762" y1="0.762" x2="0.762" y2="0" width="0.254" layer="94"/>
<wire x1="0.762" y1="0" x2="0.762" y2="-0.762" width="0.254" layer="94"/>
<wire x1="0.762" y1="3.175" x2="0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="0.762" y1="2.54" x2="0.762" y2="1.905" width="0.254" layer="94"/>
<wire x1="0.762" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0.762" y1="-1.905" x2="0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0.762" y1="-2.54" x2="0.762" y2="-3.175" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="0.762" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="0.508" width="0.1524" layer="94"/>
<wire x1="3.81" y1="0.508" x2="3.81" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="3.81" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0.762" y1="2.54" x2="3.81" y2="2.54" width="0.1524" layer="94"/>
<wire x1="4.572" y1="0.762" x2="4.318" y2="0.508" width="0.1524" layer="94"/>
<wire x1="4.318" y1="0.508" x2="3.81" y2="0.508" width="0.1524" layer="94"/>
<wire x1="3.81" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="94"/>
<wire x1="3.302" y1="0.508" x2="3.048" y2="0.254" width="0.1524" layer="94"/>
<circle x="2.54" y="-2.54" radius="0.3592" width="0" layer="94"/>
<circle x="2.54" y="2.54" radius="0.3592" width="0" layer="94"/>
<text x="5.08" y="0.635" size="1.27" layer="95">&gt;NAME</text>
<text x="5.08" y="-1.27" size="1.27" layer="96">&gt;VALUE</text>
<text x="3.175" y="3.175" size="0.8128" layer="93">D</text>
<text x="3.175" y="-3.81" size="0.8128" layer="93">S</text>
<text x="-1.27" y="-1.905" size="0.8128" layer="93">G</text>
<pin name="G" x="-2.54" y="-2.54" visible="pad" length="short"/>
<pin name="S" x="2.54" y="-5.08" visible="pad" length="short" rot="R90"/>
<pin name="D" x="2.54" y="5.08" visible="pad" length="short" rot="R270"/>
<vertex x="3.81" y="0.508"/>
<vertex x="3.302" y="-0.254"/>
<vertex x="4.318" y="-0.254"/>
</polygon>
<vertex x="1.016" y="0"/>
<vertex x="2.032" y="0.762"/>
<vertex x="2.032" y="-0.762"/>
</polygon>
</symbol>
</symbols>
<devicesets>
<deviceset name="ARDUINOR3" prefix="U">
<description>This is a new object for the new Arduino R3 - with extra pins that you may want to use (such as IOref, and duplicated A4/A5</description>
<gates>
<gate name="G$1" symbol="ARDUINOR3" x="2.54" y="0"/>
</gates>
<devices>
<device name="-BPLACE" package="ARDUINOR3-BPLACE">
<connects>
<connect gate="G$1" pin="5V" pad="5V"/>
<connect gate="G$1" pin="A4/SDA" pad="A4"/>
<connect gate="G$1" pin="A5/SCL" pad="A5"/>
<connect gate="G$1" pin="AREF" pad="AREF"/>
<connect gate="G$1" pin="D0" pad="D0"/>
<connect gate="G$1" pin="GND" pad="GND"/>
<connect gate="G$1" pin="GND2" pad="GND2"/>
<connect gate="G$1" pin="IOREF" pad="IOREF"/>
<connect gate="G$1" pin="RESERVED" pad="RESERVED"/>
<connect gate="G$1" pin="SCL" pad="SCL"/>
<connect gate="G$1" pin="SDA" pad="SDA"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LED" prefix="LED" uservalue="yes">
<description>&lt;b&gt;LED&lt;/b&gt;&lt;p&gt;
&lt;u&gt;OSRAM&lt;/u&gt;:&lt;br&gt;
- &lt;u&gt;CHIPLED&lt;/u&gt;&lt;br&gt;
LG R971, LG N971, LY N971, LG Q971, LY Q971, LO R971, LY R971
LH N974, LH R974&lt;br&gt;
LS Q976, LO Q976, LY Q976&lt;br&gt;
LO Q996&lt;br&gt;
- &lt;u&gt;Hyper CHIPLED&lt;/u&gt;&lt;br&gt;
LW Q18S&lt;br&gt;
LB Q993, LB Q99A, LB R99A&lt;br&gt;
- &lt;u&gt;SideLED&lt;/u&gt;&lt;br&gt;
LS A670, LO A670, LY A670, LG A670, LP A670&lt;br&gt;
LB A673, LV A673, LT A673, LW A673&lt;br&gt;
LH A674&lt;br&gt;
LY A675&lt;br&gt;
LS A676, LA A676, LO A676, LY A676, LW A676&lt;br&gt;
LS A679, LY A679, LG A679&lt;br&gt;
-  &lt;u&gt;Hyper Micro SIDELED®&lt;/u&gt;&lt;br&gt;
LS Y876, LA Y876, LO Y876, LY Y876&lt;br&gt;
LT Y87S&lt;br&gt;
- &lt;u&gt;SmartLED&lt;/u&gt;&lt;br&gt;
LW L88C, LW L88S&lt;br&gt;
LB L89C, LB L89S, LG L890&lt;br&gt;
LS L89K, LO L89K, LY L89K&lt;br&gt;
LS L896, LA L896, LO L896, LY L896&lt;br&gt;
- &lt;u&gt;TOPLED&lt;/u&gt;&lt;br&gt;
LS T670, LO T670, LY T670, LG T670, LP T670&lt;br&gt;
LSG T670, LSP T670, LSY T670, LOP T670, LYG T670&lt;br&gt;
LG T671, LOG T671, LSG T671&lt;br&gt;
LB T673, LV T673, LT T673, LW T673&lt;br&gt;
LH T674&lt;br&gt;
LS T676, LA T676, LO T676, LY T676, LB T676, LH T676, LSB T676, LW T676&lt;br&gt;
LB T67C, LV T67C, LT T67C, LS T67K, LO T67K, LY T67K, LW E67C&lt;br&gt;
LS E67B, LA E67B, LO E67B, LY E67B, LB E67C, LV E67C, LT E67C&lt;br&gt;
LW T67C&lt;br&gt;
LS T679, LY T679, LG T679&lt;br&gt;
LS T770, LO T770, LY T770, LG T770, LP T770&lt;br&gt;
LB T773, LV T773, LT T773, LW T773&lt;br&gt;
LH T774&lt;br&gt;
LS E675, LA E675, LY E675, LS T675&lt;br&gt;
LS T776, LA T776, LO T776, LY T776, LB T776&lt;br&gt;
LHGB T686&lt;br&gt;
LT T68C, LB T68C&lt;br&gt;
- &lt;u&gt;Hyper Mini TOPLED®&lt;/u&gt;&lt;br&gt;
LB M676&lt;br&gt;
- &lt;u&gt;Mini TOPLED Santana®&lt;/u&gt;&lt;br&gt;
LG M470&lt;br&gt;
LS M47K, LO M47K, LY M47K&lt;br&gt;
&lt;p&gt;
Source: http://www.osram.convergy.de/</description>
<gates>
<gate name="G$1" symbol="LED" x="0" y="0"/>
</gates>
<devices>
<device name="SMT1206" package="1206">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
<device name="LD260" package="LD260">
<connects>
<connect gate="G$1" pin="C" pad="K"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SQR2X5" package="LED2X5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3MM" package="LED3MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5MM" package="LED5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LSU260" package="LSU260">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LZR181" package="LZR181">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B152" package="Q62902-B152">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B153" package="Q62902-B153">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B155" package="Q62902-B155">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B156" package="Q62902-B156">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SFH480" package="SFH480">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SFH482" package="SFH482">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SQR5.7X3.2" package="U57X32">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="IRL80A" package="IRL80A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P-LCC-2" package="P-LCC-2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MINI-TOP" package="OSRAM-MINI-TOP-LED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SIDELED" package="OSRAM-SIDELED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMART-LED" package="SMART-LED">
<connects>
<connect gate="G$1" pin="C" pad="B"/>
</connects>
<technologies>
</technologies>
</device>
<device name="P-LCC-2-BACK" package="P-LCC-2-TOPLED-RG">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MICRO-SIDELED" package="MICRO-SIDELED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P-LCC-4" package="P-LCC-4">
<connects>
<connect gate="G$1" pin="C" pad="C@4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIP-LED0603" package="CHIP-LED0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIP-LED0805" package="CHIP-LED0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TOPLED-SANTANA" package="MINI-TOPLED-SANTANA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED_0805" package="CHIPLED_0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED_1206" package="CHIPLED_1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED_0603" package="CHIPLED_0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED-0603-TTW" package="CHIPLED-0603-TTW">
<connects>
<connect gate="G$1" pin="A" pad="A@1"/>
<connect gate="G$1" pin="C" pad="C@1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="SMARTLED-TTW">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMLK34" package="SMLK34">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="R-US_" prefix="R" uservalue="yes">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, American symbol</description>
<gates>
<gate name="G$1" symbol="R-US" x="0" y="0"/>
</gates>
<devices>
<device name="R0402" package="R0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="R0603" package="R0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805" package="R0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805W" package="R0805W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1005" package="R1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206" package="R1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206W" package="R1206W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210" package="R1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210W" package="R1210W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010" package="R2010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010W" package="R2010W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012" package="R2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012W" package="R2012W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512" package="R2512">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512W" package="R2512W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216" package="R3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216W" package="R3216W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225" package="R3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225W" package="R3225W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025" package="R5025">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025W" package="R5025W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332" package="R6332">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332W" package="R6332W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M0805" package="M0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1206" package="M1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1406" package="M1406">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2012" package="M2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2309" package="M2309">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3216" package="M3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3516" package="M3516">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M5923" package="M5923">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/10" package="0309/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/12" package="0309/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/12" package="0411/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/15" package="0411/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/3V" package="0411V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/15" package="0414/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/5V" package="0414V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/17" package="0617/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/22" package="0617/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/5V" package="0617V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922/22" package="0922/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/5V" package="P0613V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/15" package="P0613/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/22" package="P0817/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/7V" package="P0817V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V234/12" package="V234/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V235/17" package="V235/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V526-0" package="V526-0">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102AX" package="MINI_MELF-0102AX">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922V" package="0922V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102R" package="MINI_MELF-0102R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102W" package="MINI_MELF-0102W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204R" package="MINI_MELF-0204R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204W" package="MINI_MELF-0204W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207R" package="MINI_MELF-0207R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207W" package="MINI_MELF-0207W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RDH/15" package="RDH/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/2V" package="0204V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/V" package="0309V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="FLIPFLOP" package="0805-THM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="FLIPFLOP7" package="0805-THM-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/9" package="0207/9">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MOSFET-N" prefix="Q" uservalue="yes">
<description>&lt;b&gt;N-Channel Mosfet&lt;/b&gt;
&lt;ul&gt;
&lt;li&gt;2N7002E - 60V 260mA SOT23 [Digikey: 2N7002ET1GOSTR-ND] - &lt;b&gt;REEL&lt;/b&gt;&lt;/li&gt;
&lt;li&gt;BSH103 - 30V 850mA SOT23 [Digikey: 568-5013-1-ND]&lt;/li&gt;
&lt;/ul&gt;</description>
<gates>
<gate name="G$1" symbol="MOSFET-N" x="-2.54" y="0"/>
</gates>
<devices>
<device name="WAVE" package="SOT23-W">
<connects>
<connect gate="G$1" pin="D" pad="3"/>
<connect gate="G$1" pin="G" pad="1"/>
<connect gate="G$1" pin="S" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="REFLOW" package="SOT23">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="GDS_TO220V" package="TO220V">
<connects>
<connect gate="G$1" pin="D" pad="2"/>
<connect gate="G$1" pin="S" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="pinhead" urn="urn:adsk.eagle:library:325">
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="1X04" urn="urn:adsk.eagle:footprint:22258/1" library_version="3">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-5.1562" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
</package>
<package name="1X04/90" urn="urn:adsk.eagle:footprint:22259/1" library_version="3">
<wire x1="-5.08" y1="-1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.985" x2="-3.81" y2="1.27" width="0.762" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="6.985" x2="-1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="0" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="6.985" x2="1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="6.985" x2="3.81" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-5.715" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.985" y="-4.445" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-4.191" y1="0.635" x2="-3.429" y2="1.143" layer="21"/>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.143" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.143" layer="21"/>
<rectangle x1="3.429" y1="0.635" x2="4.191" y2="1.143" layer="21"/>
<rectangle x1="-4.191" y1="-2.921" x2="-3.429" y2="-1.905" layer="21"/>
<rectangle x1="-1.651" y1="-2.921" x2="-0.889" y2="-1.905" layer="21"/>
<rectangle x1="0.889" y1="-2.921" x2="1.651" y2="-1.905" layer="21"/>
<rectangle x1="3.429" y1="-2.921" x2="4.191" y2="-1.905" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="1X04" urn="urn:adsk.eagle:package:22407/2" type="model" library_version="3">
<description>PIN HEADER</description>
<packageinstances>
<packageinstance name="1X04"/>
</packageinstances>
</package3d>
<package3d name="1X04/90" urn="urn:adsk.eagle:package:22404/2" type="model" library_version="3">
<packageinstances>
<packageinstance name="1X04/90"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="PINHD4" urn="urn:adsk.eagle:symbol:22257/1" library_version="3">
<wire x1="-6.35" y1="-5.08" x2="1.27" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="1.27" y2="7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="7.62" x2="-6.35" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="7.62" x2="-6.35" y2="-5.08" width="0.4064" layer="94"/>
<text x="-6.35" y="8.255" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="3" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="PINHD-1X4" urn="urn:adsk.eagle:component:22499/4" prefix="JP" uservalue="yes" library_version="3">
<gates>
<gate name="A" symbol="PINHD4" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X04">
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="2" pad="2"/>
<connect gate="A" pin="3" pad="3"/>
<connect gate="A" pin="4" pad="4"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:22407/2"/>
</package3dinstances>
<technologies>
</technologies>
</device>
<device name="/90" package="1X04/90">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:22404/2"/>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0.508" drill="0">
<clearance class="0" value="0.508"/>
</class>
</classes>
<parts>
<part name="IC1" library="microchip" library_urn="urn:adsk.eagle:library:294" deviceset="MCP23017" device="SP" package3d_urn="urn:adsk.eagle:package:20799/2"/>
<part name="P+1" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="GND1" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND2" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="SV1" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV2" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV3" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV4" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV5" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV6" library="pinhead" library_urn="urn:adsk.eagle:library:325" deviceset="PINHD-1X4" device="" package3d_urn="urn:adsk.eagle:package:22407/2"/>
<part name="U1" library="adafruit" deviceset="ARDUINOR3" device="-BPLACE" value="ARDUINOR3-BPLACE"/>
<part name="LED1" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED2" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED3" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED4" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED5" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED6" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED7" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED8" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="R1" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R2" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R3" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R4" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R5" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R6" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R7" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R8" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q1" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND7" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R25" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="P+4" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+12V" device=""/>
<part name="Q2" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND3" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R9" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q3" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND4" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R10" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q4" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND5" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R11" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q5" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND6" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R12" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q6" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND8" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R13" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q7" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND9" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R14" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q8" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND10" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R15" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="IC2" library="microchip" library_urn="urn:adsk.eagle:library:294" deviceset="MCP23017" device="SP" package3d_urn="urn:adsk.eagle:package:20799/2"/>
<part name="P+2" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="GND11" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND12" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="SV7" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV8" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV9" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV10" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV11" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV12" library="pinhead" library_urn="urn:adsk.eagle:library:325" deviceset="PINHD-1X4" device="" package3d_urn="urn:adsk.eagle:package:22407/2"/>
<part name="LED9" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED10" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED11" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED12" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED13" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED14" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED15" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED16" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="R16" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R17" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R18" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R19" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R20" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R21" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R22" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R23" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q9" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND13" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R24" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="P+3" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+12V" device=""/>
<part name="Q10" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND14" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R26" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q11" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND15" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R27" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q12" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND16" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R28" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q13" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND17" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R29" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q14" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND18" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R30" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q15" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND19" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R31" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q16" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND20" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R32" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="IC3" library="microchip" library_urn="urn:adsk.eagle:library:294" deviceset="MCP23017" device="SP" package3d_urn="urn:adsk.eagle:package:20799/2"/>
<part name="P+5" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="GND21" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND22" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="SV13" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV14" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV15" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV16" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV17" library="con-lstb" library_urn="urn:adsk.eagle:library:162" deviceset="MA03-1" device="" package3d_urn="urn:adsk.eagle:package:8339/1"/>
<part name="SV18" library="pinhead" library_urn="urn:adsk.eagle:library:325" deviceset="PINHD-1X4" device="" package3d_urn="urn:adsk.eagle:package:22407/2"/>
<part name="LED17" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED18" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED19" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED20" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED21" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED22" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED23" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="LED24" library="adafruit" deviceset="LED" device="CHIP-LED0805"/>
<part name="R33" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R34" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R35" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R36" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R37" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R38" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R39" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R40" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q17" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND23" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R41" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="P+6" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+12V" device=""/>
<part name="Q18" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND24" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R42" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q19" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND25" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R43" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q20" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND26" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R44" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q21" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND27" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R45" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q22" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND28" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R46" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q23" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND29" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R47" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="Q24" library="adafruit" deviceset="MOSFET-N" device="REFLOW"/>
<part name="GND30" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R48" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R49" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R50" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R51" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R52" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R53" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
<part name="R54" library="adafruit" deviceset="R-US_" device="M0805" value="20k"/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="IC1" gate="G$1" x="15.24" y="55.88"/>
<instance part="P+1" gate="1" x="-12.7" y="88.9"/>
<instance part="GND1" gate="1" x="83.82" y="78.74"/>
<instance part="GND2" gate="1" x="-12.7" y="30.48"/>
<instance part="SV1" gate="G$1" x="22.86" y="96.52" rot="R270"/>
<instance part="SV2" gate="G$1" x="38.1" y="96.52" rot="R270"/>
<instance part="SV3" gate="G$1" x="53.34" y="96.52" rot="R270"/>
<instance part="SV4" gate="G$1" x="116.84" y="0" rot="R180"/>
<instance part="SV5" gate="G$1" x="116.84" y="15.24" rot="R180"/>
<instance part="SV6" gate="A" x="116.84" y="27.94"/>
<instance part="U1" gate="G$1" x="-88.9" y="22.86" rot="R90"/>
<instance part="LED1" gate="G$1" x="58.42" y="53.34" rot="R90"/>
<instance part="LED2" gate="G$1" x="58.42" y="50.8" rot="R90"/>
<instance part="LED3" gate="G$1" x="58.42" y="48.26" rot="R90"/>
<instance part="LED4" gate="G$1" x="58.42" y="45.72" rot="R90"/>
<instance part="LED5" gate="G$1" x="58.42" y="43.18" rot="R90"/>
<instance part="LED6" gate="G$1" x="58.42" y="40.64" rot="R90"/>
<instance part="LED7" gate="G$1" x="58.42" y="38.1" rot="R90"/>
<instance part="LED8" gate="G$1" x="58.42" y="35.56" rot="R90"/>
<instance part="R1" gate="G$1" x="58.42" y="76.2"/>
<instance part="R2" gate="G$1" x="58.42" y="73.66"/>
<instance part="R3" gate="G$1" x="58.42" y="71.12"/>
<instance part="R4" gate="G$1" x="58.42" y="68.58"/>
<instance part="R5" gate="G$1" x="58.42" y="66.04"/>
<instance part="R6" gate="G$1" x="58.42" y="63.5"/>
<instance part="R7" gate="G$1" x="58.42" y="60.96"/>
<instance part="R8" gate="G$1" x="58.42" y="58.42"/>
<instance part="Q1" gate="G$1" x="78.74" y="20.32"/>
<instance part="GND7" gate="1" x="60.96" y="10.16"/>
<instance part="R25" gate="G$1" x="68.58" y="22.86"/>
<instance part="P+4" gate="1" x="101.6" y="45.72"/>
<instance part="Q2" gate="G$1" x="78.74" y="0"/>
<instance part="GND3" gate="1" x="60.96" y="-10.16"/>
<instance part="R9" gate="G$1" x="68.58" y="2.54"/>
<instance part="Q3" gate="G$1" x="78.74" y="-20.32"/>
<instance part="GND4" gate="1" x="60.96" y="-30.48"/>
<instance part="R10" gate="G$1" x="68.58" y="-17.78"/>
<instance part="Q4" gate="G$1" x="78.74" y="-40.64"/>
<instance part="GND5" gate="1" x="60.96" y="-50.8"/>
<instance part="R11" gate="G$1" x="68.58" y="-38.1"/>
<instance part="Q5" gate="G$1" x="78.74" y="-60.96"/>
<instance part="GND6" gate="1" x="60.96" y="-71.12"/>
<instance part="R12" gate="G$1" x="68.58" y="-58.42"/>
<instance part="Q6" gate="G$1" x="78.74" y="-78.74"/>
<instance part="GND8" gate="1" x="60.96" y="-88.9"/>
<instance part="R13" gate="G$1" x="68.58" y="-76.2"/>
<instance part="Q7" gate="G$1" x="78.74" y="-99.06"/>
<instance part="GND9" gate="1" x="60.96" y="-109.22"/>
<instance part="R14" gate="G$1" x="68.58" y="-96.52"/>
<instance part="Q8" gate="G$1" x="78.74" y="-121.92"/>
<instance part="GND10" gate="1" x="60.96" y="-132.08"/>
<instance part="R15" gate="G$1" x="68.58" y="-119.38"/>
<instance part="IC2" gate="G$1" x="208.28" y="63.5"/>
<instance part="P+2" gate="1" x="180.34" y="96.52"/>
<instance part="GND11" gate="1" x="276.86" y="86.36"/>
<instance part="GND12" gate="1" x="180.34" y="38.1"/>
<instance part="SV7" gate="G$1" x="215.9" y="104.14" rot="R270"/>
<instance part="SV8" gate="G$1" x="231.14" y="104.14" rot="R270"/>
<instance part="SV9" gate="G$1" x="246.38" y="104.14" rot="R270"/>
<instance part="SV10" gate="G$1" x="309.88" y="7.62" rot="R180"/>
<instance part="SV11" gate="G$1" x="309.88" y="22.86" rot="R180"/>
<instance part="SV12" gate="A" x="309.88" y="38.1"/>
<instance part="LED9" gate="G$1" x="251.46" y="60.96" rot="R90"/>
<instance part="LED10" gate="G$1" x="251.46" y="58.42" rot="R90"/>
<instance part="LED11" gate="G$1" x="251.46" y="55.88" rot="R90"/>
<instance part="LED12" gate="G$1" x="251.46" y="53.34" rot="R90"/>
<instance part="LED13" gate="G$1" x="251.46" y="50.8" rot="R90"/>
<instance part="LED14" gate="G$1" x="251.46" y="48.26" rot="R90"/>
<instance part="LED15" gate="G$1" x="251.46" y="45.72" rot="R90"/>
<instance part="LED16" gate="G$1" x="251.46" y="43.18" rot="R90"/>
<instance part="R16" gate="G$1" x="251.46" y="83.82"/>
<instance part="R17" gate="G$1" x="251.46" y="81.28"/>
<instance part="R18" gate="G$1" x="251.46" y="78.74"/>
<instance part="R19" gate="G$1" x="251.46" y="76.2"/>
<instance part="R20" gate="G$1" x="251.46" y="73.66"/>
<instance part="R21" gate="G$1" x="251.46" y="71.12"/>
<instance part="R22" gate="G$1" x="251.46" y="68.58"/>
<instance part="R23" gate="G$1" x="251.46" y="66.04"/>
<instance part="Q9" gate="G$1" x="271.78" y="27.94"/>
<instance part="GND13" gate="1" x="254" y="17.78"/>
<instance part="R24" gate="G$1" x="261.62" y="30.48"/>
<instance part="P+3" gate="1" x="294.64" y="53.34"/>
<instance part="Q10" gate="G$1" x="271.78" y="7.62"/>
<instance part="GND14" gate="1" x="254" y="-2.54"/>
<instance part="R26" gate="G$1" x="261.62" y="10.16"/>
<instance part="Q11" gate="G$1" x="271.78" y="-12.7"/>
<instance part="GND15" gate="1" x="254" y="-22.86"/>
<instance part="R27" gate="G$1" x="261.62" y="-10.16"/>
<instance part="Q12" gate="G$1" x="271.78" y="-33.02"/>
<instance part="GND16" gate="1" x="254" y="-43.18"/>
<instance part="R28" gate="G$1" x="261.62" y="-30.48"/>
<instance part="Q13" gate="G$1" x="271.78" y="-53.34"/>
<instance part="GND17" gate="1" x="254" y="-63.5"/>
<instance part="R29" gate="G$1" x="261.62" y="-50.8"/>
<instance part="Q14" gate="G$1" x="271.78" y="-71.12"/>
<instance part="GND18" gate="1" x="254" y="-81.28"/>
<instance part="R30" gate="G$1" x="261.62" y="-68.58"/>
<instance part="Q15" gate="G$1" x="271.78" y="-91.44"/>
<instance part="GND19" gate="1" x="254" y="-101.6"/>
<instance part="R31" gate="G$1" x="261.62" y="-88.9"/>
<instance part="Q16" gate="G$1" x="271.78" y="-114.3"/>
<instance part="GND20" gate="1" x="254" y="-124.46"/>
<instance part="R32" gate="G$1" x="261.62" y="-111.76"/>
<instance part="IC3" gate="G$1" x="393.7" y="73.66"/>
<instance part="P+5" gate="1" x="365.76" y="106.68"/>
<instance part="GND21" gate="1" x="462.28" y="96.52"/>
<instance part="GND22" gate="1" x="365.76" y="48.26"/>
<instance part="SV13" gate="G$1" x="401.32" y="114.3" rot="R270"/>
<instance part="SV14" gate="G$1" x="416.56" y="114.3" rot="R270"/>
<instance part="SV15" gate="G$1" x="431.8" y="114.3" rot="R270"/>
<instance part="SV16" gate="G$1" x="495.3" y="17.78" rot="R180"/>
<instance part="SV17" gate="G$1" x="495.3" y="33.02" rot="R180"/>
<instance part="SV18" gate="A" x="495.3" y="48.26"/>
<instance part="LED17" gate="G$1" x="436.88" y="71.12" rot="R90"/>
<instance part="LED18" gate="G$1" x="436.88" y="68.58" rot="R90"/>
<instance part="LED19" gate="G$1" x="436.88" y="66.04" rot="R90"/>
<instance part="LED20" gate="G$1" x="436.88" y="63.5" rot="R90"/>
<instance part="LED21" gate="G$1" x="436.88" y="60.96" rot="R90"/>
<instance part="LED22" gate="G$1" x="436.88" y="58.42" rot="R90"/>
<instance part="LED23" gate="G$1" x="436.88" y="55.88" rot="R90"/>
<instance part="LED24" gate="G$1" x="436.88" y="53.34" rot="R90"/>
<instance part="R33" gate="G$1" x="436.88" y="93.98"/>
<instance part="R34" gate="G$1" x="436.88" y="91.44"/>
<instance part="R35" gate="G$1" x="436.88" y="88.9"/>
<instance part="R36" gate="G$1" x="436.88" y="86.36"/>
<instance part="R37" gate="G$1" x="436.88" y="83.82"/>
<instance part="R38" gate="G$1" x="436.88" y="81.28"/>
<instance part="R39" gate="G$1" x="436.88" y="78.74"/>
<instance part="R40" gate="G$1" x="436.88" y="76.2"/>
<instance part="Q17" gate="G$1" x="457.2" y="38.1"/>
<instance part="GND23" gate="1" x="439.42" y="27.94"/>
<instance part="R41" gate="G$1" x="447.04" y="40.64"/>
<instance part="P+6" gate="1" x="480.06" y="63.5"/>
<instance part="Q18" gate="G$1" x="457.2" y="17.78"/>
<instance part="GND24" gate="1" x="439.42" y="7.62"/>
<instance part="R42" gate="G$1" x="447.04" y="20.32"/>
<instance part="Q19" gate="G$1" x="457.2" y="-2.54"/>
<instance part="GND25" gate="1" x="439.42" y="-12.7"/>
<instance part="R43" gate="G$1" x="447.04" y="0"/>
<instance part="Q20" gate="G$1" x="457.2" y="-22.86"/>
<instance part="GND26" gate="1" x="439.42" y="-33.02"/>
<instance part="R44" gate="G$1" x="447.04" y="-20.32"/>
<instance part="Q21" gate="G$1" x="457.2" y="-43.18"/>
<instance part="GND27" gate="1" x="439.42" y="-53.34"/>
<instance part="R45" gate="G$1" x="447.04" y="-40.64"/>
<instance part="Q22" gate="G$1" x="457.2" y="-60.96"/>
<instance part="GND28" gate="1" x="439.42" y="-71.12"/>
<instance part="R46" gate="G$1" x="447.04" y="-58.42"/>
<instance part="Q23" gate="G$1" x="457.2" y="-81.28"/>
<instance part="GND29" gate="1" x="439.42" y="-91.44"/>
<instance part="R47" gate="G$1" x="447.04" y="-78.74"/>
<instance part="Q24" gate="G$1" x="457.2" y="-104.14"/>
<instance part="GND30" gate="1" x="439.42" y="-114.3"/>
<instance part="R48" gate="G$1" x="447.04" y="-101.6"/>
<instance part="R49" gate="G$1" x="-5.08" y="63.5" rot="R90"/>
<instance part="R50" gate="G$1" x="-10.16" y="63.5" rot="R90"/>
<instance part="R51" gate="G$1" x="190.5" y="71.12" rot="R90"/>
<instance part="R52" gate="G$1" x="185.42" y="71.12" rot="R90"/>
<instance part="R53" gate="G$1" x="375.92" y="81.28" rot="R90"/>
<instance part="R54" gate="G$1" x="370.84" y="81.28" rot="R90"/>
</instances>
<busses>
</busses>
<nets>
<net name="GND" class="0">
<segment>
<pinref part="GND1" gate="1" pin="GND"/>
<wire x1="83.82" y1="81.28" x2="66.04" y2="81.28" width="0.1524" layer="91"/>
<wire x1="66.04" y1="81.28" x2="66.04" y2="76.2" width="0.1524" layer="91"/>
<wire x1="66.04" y1="76.2" x2="66.04" y2="73.66" width="0.1524" layer="91"/>
<wire x1="66.04" y1="73.66" x2="66.04" y2="71.12" width="0.1524" layer="91"/>
<wire x1="66.04" y1="71.12" x2="66.04" y2="68.58" width="0.1524" layer="91"/>
<wire x1="66.04" y1="68.58" x2="66.04" y2="66.04" width="0.1524" layer="91"/>
<wire x1="66.04" y1="66.04" x2="66.04" y2="63.5" width="0.1524" layer="91"/>
<wire x1="66.04" y1="63.5" x2="66.04" y2="60.96" width="0.1524" layer="91"/>
<wire x1="66.04" y1="60.96" x2="66.04" y2="58.42" width="0.1524" layer="91"/>
<wire x1="63.5" y1="58.42" x2="66.04" y2="58.42" width="0.1524" layer="91"/>
<wire x1="63.5" y1="60.96" x2="66.04" y2="60.96" width="0.1524" layer="91"/>
<wire x1="63.5" y1="63.5" x2="66.04" y2="63.5" width="0.1524" layer="91"/>
<wire x1="63.5" y1="66.04" x2="66.04" y2="66.04" width="0.1524" layer="91"/>
<wire x1="63.5" y1="68.58" x2="66.04" y2="68.58" width="0.1524" layer="91"/>
<wire x1="63.5" y1="71.12" x2="66.04" y2="71.12" width="0.1524" layer="91"/>
<wire x1="63.5" y1="73.66" x2="66.04" y2="73.66" width="0.1524" layer="91"/>
<junction x="66.04" y="60.96"/>
<junction x="66.04" y="63.5"/>
<junction x="66.04" y="66.04"/>
<junction x="66.04" y="68.58"/>
<junction x="66.04" y="71.12"/>
<junction x="66.04" y="73.66"/>
<wire x1="63.5" y1="35.56" x2="66.04" y2="35.56" width="0.1524" layer="91"/>
<wire x1="66.04" y1="35.56" x2="66.04" y2="38.1" width="0.1524" layer="91"/>
<wire x1="66.04" y1="38.1" x2="66.04" y2="40.64" width="0.1524" layer="91"/>
<wire x1="66.04" y1="40.64" x2="66.04" y2="43.18" width="0.1524" layer="91"/>
<wire x1="66.04" y1="43.18" x2="66.04" y2="45.72" width="0.1524" layer="91"/>
<wire x1="66.04" y1="45.72" x2="66.04" y2="48.26" width="0.1524" layer="91"/>
<wire x1="66.04" y1="48.26" x2="66.04" y2="50.8" width="0.1524" layer="91"/>
<wire x1="66.04" y1="50.8" x2="66.04" y2="53.34" width="0.1524" layer="91"/>
<wire x1="66.04" y1="53.34" x2="66.04" y2="58.42" width="0.1524" layer="91"/>
<wire x1="63.5" y1="53.34" x2="66.04" y2="53.34" width="0.1524" layer="91"/>
<wire x1="63.5" y1="50.8" x2="66.04" y2="50.8" width="0.1524" layer="91"/>
<wire x1="63.5" y1="48.26" x2="66.04" y2="48.26" width="0.1524" layer="91"/>
<wire x1="63.5" y1="45.72" x2="66.04" y2="45.72" width="0.1524" layer="91"/>
<wire x1="63.5" y1="43.18" x2="66.04" y2="43.18" width="0.1524" layer="91"/>
<wire x1="63.5" y1="40.64" x2="66.04" y2="40.64" width="0.1524" layer="91"/>
<wire x1="63.5" y1="38.1" x2="66.04" y2="38.1" width="0.1524" layer="91"/>
<junction x="66.04" y="53.34"/>
<junction x="66.04" y="50.8"/>
<junction x="66.04" y="48.26"/>
<junction x="66.04" y="45.72"/>
<junction x="66.04" y="43.18"/>
<junction x="66.04" y="40.64"/>
<junction x="66.04" y="38.1"/>
<junction x="66.04" y="58.42"/>
<pinref part="R2" gate="G$1" pin="2"/>
<pinref part="R3" gate="G$1" pin="2"/>
<pinref part="R4" gate="G$1" pin="2"/>
<pinref part="R5" gate="G$1" pin="2"/>
<pinref part="R6" gate="G$1" pin="2"/>
<pinref part="R7" gate="G$1" pin="2"/>
<pinref part="R8" gate="G$1" pin="2"/>
<pinref part="LED1" gate="G$1" pin="C"/>
<pinref part="LED2" gate="G$1" pin="C"/>
<pinref part="LED3" gate="G$1" pin="C"/>
<pinref part="LED4" gate="G$1" pin="C"/>
<pinref part="LED5" gate="G$1" pin="C"/>
<pinref part="LED6" gate="G$1" pin="C"/>
<pinref part="LED7" gate="G$1" pin="C"/>
<pinref part="LED8" gate="G$1" pin="C"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="63.5" y1="76.2" x2="66.04" y2="76.2" width="0.1524" layer="91"/>
<junction x="66.04" y="76.2"/>
<pinref part="SV6" gate="A" pin="1"/>
<wire x1="114.3" y1="33.02" x2="104.14" y2="33.02" width="0.1524" layer="91"/>
<wire x1="104.14" y1="33.02" x2="104.14" y2="81.28" width="0.1524" layer="91"/>
<wire x1="104.14" y1="81.28" x2="83.82" y2="81.28" width="0.1524" layer="91"/>
<junction x="83.82" y="81.28"/>
</segment>
<segment>
<wire x1="2.54" y1="35.56" x2="-12.7" y2="35.56" width="0.1524" layer="91"/>
<pinref part="GND2" gate="1" pin="GND"/>
<wire x1="-12.7" y1="35.56" x2="-12.7" y2="33.02" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="A0"/>
<wire x1="2.54" y1="45.72" x2="-12.7" y2="45.72" width="0.1524" layer="91"/>
<wire x1="-12.7" y1="45.72" x2="-12.7" y2="43.18" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="A1"/>
<wire x1="-12.7" y1="43.18" x2="-12.7" y2="40.64" width="0.1524" layer="91"/>
<wire x1="-12.7" y1="40.64" x2="-12.7" y2="35.56" width="0.1524" layer="91"/>
<wire x1="2.54" y1="43.18" x2="-12.7" y2="43.18" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="A2"/>
<wire x1="2.54" y1="40.64" x2="-12.7" y2="40.64" width="0.1524" layer="91"/>
<junction x="-12.7" y="40.64"/>
<junction x="-12.7" y="43.18"/>
<junction x="-12.7" y="45.72"/>
<pinref part="IC1" gate="G$1" pin="VSS"/>
<wire x1="-20.32" y1="22.86" x2="-20.32" y2="33.02" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="33.02" x2="-12.7" y2="33.02" width="0.1524" layer="91"/>
<junction x="-12.7" y="33.02"/>
<junction x="-12.7" y="35.56"/>
<pinref part="U1" gate="G$1" pin="GND2"/>
<wire x1="-58.42" y1="22.86" x2="-20.32" y2="22.86" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND7" gate="1" pin="GND"/>
<pinref part="Q1" gate="G$1" pin="S"/>
<wire x1="60.96" y1="12.7" x2="60.96" y2="15.24" width="0.1524" layer="91"/>
<wire x1="60.96" y1="15.24" x2="63.5" y2="15.24" width="0.1524" layer="91"/>
<pinref part="R25" gate="G$1" pin="1"/>
<wire x1="63.5" y1="15.24" x2="81.28" y2="15.24" width="0.1524" layer="91"/>
<wire x1="63.5" y1="22.86" x2="63.5" y2="15.24" width="0.1524" layer="91"/>
<junction x="63.5" y="15.24"/>
</segment>
<segment>
<pinref part="GND3" gate="1" pin="GND"/>
<pinref part="Q2" gate="G$1" pin="S"/>
<wire x1="60.96" y1="-7.62" x2="60.96" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-5.08" x2="63.5" y2="-5.08" width="0.1524" layer="91"/>
<pinref part="R9" gate="G$1" pin="1"/>
<wire x1="63.5" y1="-5.08" x2="81.28" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="63.5" y1="2.54" x2="63.5" y2="-5.08" width="0.1524" layer="91"/>
<junction x="63.5" y="-5.08"/>
</segment>
<segment>
<pinref part="GND4" gate="1" pin="GND"/>
<pinref part="Q3" gate="G$1" pin="S"/>
<wire x1="60.96" y1="-27.94" x2="60.96" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-25.4" x2="63.5" y2="-25.4" width="0.1524" layer="91"/>
<pinref part="R10" gate="G$1" pin="1"/>
<wire x1="63.5" y1="-25.4" x2="81.28" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="63.5" y1="-17.78" x2="63.5" y2="-25.4" width="0.1524" layer="91"/>
<junction x="63.5" y="-25.4"/>
</segment>
<segment>
<pinref part="GND5" gate="1" pin="GND"/>
<pinref part="Q4" gate="G$1" pin="S"/>
<wire x1="60.96" y1="-48.26" x2="60.96" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-45.72" x2="63.5" y2="-45.72" width="0.1524" layer="91"/>
<pinref part="R11" gate="G$1" pin="1"/>
<wire x1="63.5" y1="-45.72" x2="81.28" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="63.5" y1="-38.1" x2="63.5" y2="-45.72" width="0.1524" layer="91"/>
<junction x="63.5" y="-45.72"/>
</segment>
<segment>
<pinref part="GND6" gate="1" pin="GND"/>
<pinref part="Q5" gate="G$1" pin="S"/>
<wire x1="60.96" y1="-68.58" x2="60.96" y2="-66.04" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-66.04" x2="63.5" y2="-66.04" width="0.1524" layer="91"/>
<pinref part="R12" gate="G$1" pin="1"/>
<wire x1="63.5" y1="-66.04" x2="81.28" y2="-66.04" width="0.1524" layer="91"/>
<wire x1="63.5" y1="-58.42" x2="63.5" y2="-66.04" width="0.1524" layer="91"/>
<junction x="63.5" y="-66.04"/>
</segment>
<segment>
<pinref part="GND8" gate="1" pin="GND"/>
<pinref part="Q6" gate="G$1" pin="S"/>
<wire x1="60.96" y1="-86.36" x2="60.96" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-83.82" x2="63.5" y2="-83.82" width="0.1524" layer="91"/>
<pinref part="R13" gate="G$1" pin="1"/>
<wire x1="63.5" y1="-83.82" x2="81.28" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="63.5" y1="-76.2" x2="63.5" y2="-83.82" width="0.1524" layer="91"/>
<junction x="63.5" y="-83.82"/>
</segment>
<segment>
<pinref part="GND9" gate="1" pin="GND"/>
<pinref part="Q7" gate="G$1" pin="S"/>
<wire x1="60.96" y1="-106.68" x2="60.96" y2="-104.14" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-104.14" x2="63.5" y2="-104.14" width="0.1524" layer="91"/>
<pinref part="R14" gate="G$1" pin="1"/>
<wire x1="63.5" y1="-104.14" x2="81.28" y2="-104.14" width="0.1524" layer="91"/>
<wire x1="63.5" y1="-96.52" x2="63.5" y2="-104.14" width="0.1524" layer="91"/>
<junction x="63.5" y="-104.14"/>
</segment>
<segment>
<pinref part="GND10" gate="1" pin="GND"/>
<pinref part="Q8" gate="G$1" pin="S"/>
<wire x1="60.96" y1="-129.54" x2="60.96" y2="-127" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-127" x2="63.5" y2="-127" width="0.1524" layer="91"/>
<pinref part="R15" gate="G$1" pin="1"/>
<wire x1="63.5" y1="-127" x2="81.28" y2="-127" width="0.1524" layer="91"/>
<wire x1="63.5" y1="-119.38" x2="63.5" y2="-127" width="0.1524" layer="91"/>
<junction x="63.5" y="-127"/>
</segment>
<segment>
<pinref part="GND11" gate="1" pin="GND"/>
<wire x1="276.86" y1="88.9" x2="259.08" y2="88.9" width="0.1524" layer="91"/>
<wire x1="259.08" y1="88.9" x2="259.08" y2="83.82" width="0.1524" layer="91"/>
<wire x1="259.08" y1="83.82" x2="259.08" y2="81.28" width="0.1524" layer="91"/>
<wire x1="259.08" y1="81.28" x2="259.08" y2="78.74" width="0.1524" layer="91"/>
<wire x1="259.08" y1="78.74" x2="259.08" y2="76.2" width="0.1524" layer="91"/>
<wire x1="259.08" y1="76.2" x2="259.08" y2="73.66" width="0.1524" layer="91"/>
<wire x1="259.08" y1="73.66" x2="259.08" y2="71.12" width="0.1524" layer="91"/>
<wire x1="259.08" y1="71.12" x2="259.08" y2="68.58" width="0.1524" layer="91"/>
<wire x1="259.08" y1="68.58" x2="259.08" y2="66.04" width="0.1524" layer="91"/>
<wire x1="256.54" y1="66.04" x2="259.08" y2="66.04" width="0.1524" layer="91"/>
<wire x1="256.54" y1="68.58" x2="259.08" y2="68.58" width="0.1524" layer="91"/>
<wire x1="256.54" y1="71.12" x2="259.08" y2="71.12" width="0.1524" layer="91"/>
<wire x1="256.54" y1="73.66" x2="259.08" y2="73.66" width="0.1524" layer="91"/>
<wire x1="256.54" y1="76.2" x2="259.08" y2="76.2" width="0.1524" layer="91"/>
<wire x1="256.54" y1="78.74" x2="259.08" y2="78.74" width="0.1524" layer="91"/>
<wire x1="256.54" y1="81.28" x2="259.08" y2="81.28" width="0.1524" layer="91"/>
<junction x="259.08" y="68.58"/>
<junction x="259.08" y="71.12"/>
<junction x="259.08" y="73.66"/>
<junction x="259.08" y="76.2"/>
<junction x="259.08" y="78.74"/>
<junction x="259.08" y="81.28"/>
<wire x1="256.54" y1="43.18" x2="259.08" y2="43.18" width="0.1524" layer="91"/>
<wire x1="259.08" y1="43.18" x2="259.08" y2="45.72" width="0.1524" layer="91"/>
<wire x1="259.08" y1="45.72" x2="259.08" y2="48.26" width="0.1524" layer="91"/>
<wire x1="259.08" y1="48.26" x2="259.08" y2="50.8" width="0.1524" layer="91"/>
<wire x1="259.08" y1="50.8" x2="259.08" y2="53.34" width="0.1524" layer="91"/>
<wire x1="259.08" y1="53.34" x2="259.08" y2="55.88" width="0.1524" layer="91"/>
<wire x1="259.08" y1="55.88" x2="259.08" y2="58.42" width="0.1524" layer="91"/>
<wire x1="259.08" y1="58.42" x2="259.08" y2="60.96" width="0.1524" layer="91"/>
<wire x1="259.08" y1="60.96" x2="259.08" y2="66.04" width="0.1524" layer="91"/>
<wire x1="256.54" y1="60.96" x2="259.08" y2="60.96" width="0.1524" layer="91"/>
<wire x1="256.54" y1="58.42" x2="259.08" y2="58.42" width="0.1524" layer="91"/>
<wire x1="256.54" y1="55.88" x2="259.08" y2="55.88" width="0.1524" layer="91"/>
<wire x1="256.54" y1="53.34" x2="259.08" y2="53.34" width="0.1524" layer="91"/>
<wire x1="256.54" y1="50.8" x2="259.08" y2="50.8" width="0.1524" layer="91"/>
<wire x1="256.54" y1="48.26" x2="259.08" y2="48.26" width="0.1524" layer="91"/>
<wire x1="256.54" y1="45.72" x2="259.08" y2="45.72" width="0.1524" layer="91"/>
<junction x="259.08" y="60.96"/>
<junction x="259.08" y="58.42"/>
<junction x="259.08" y="55.88"/>
<junction x="259.08" y="53.34"/>
<junction x="259.08" y="50.8"/>
<junction x="259.08" y="48.26"/>
<junction x="259.08" y="45.72"/>
<junction x="259.08" y="66.04"/>
<pinref part="R17" gate="G$1" pin="2"/>
<pinref part="R18" gate="G$1" pin="2"/>
<pinref part="R19" gate="G$1" pin="2"/>
<pinref part="R20" gate="G$1" pin="2"/>
<pinref part="R21" gate="G$1" pin="2"/>
<pinref part="R22" gate="G$1" pin="2"/>
<pinref part="R23" gate="G$1" pin="2"/>
<pinref part="LED9" gate="G$1" pin="C"/>
<pinref part="LED10" gate="G$1" pin="C"/>
<pinref part="LED11" gate="G$1" pin="C"/>
<pinref part="LED12" gate="G$1" pin="C"/>
<pinref part="LED13" gate="G$1" pin="C"/>
<pinref part="LED14" gate="G$1" pin="C"/>
<pinref part="LED15" gate="G$1" pin="C"/>
<pinref part="LED16" gate="G$1" pin="C"/>
<pinref part="R16" gate="G$1" pin="2"/>
<wire x1="256.54" y1="83.82" x2="259.08" y2="83.82" width="0.1524" layer="91"/>
<junction x="259.08" y="83.82"/>
<pinref part="SV12" gate="A" pin="1"/>
<wire x1="307.34" y1="43.18" x2="299.72" y2="43.18" width="0.1524" layer="91"/>
<wire x1="299.72" y1="43.18" x2="299.72" y2="88.9" width="0.1524" layer="91"/>
<wire x1="299.72" y1="88.9" x2="276.86" y2="88.9" width="0.1524" layer="91"/>
<junction x="276.86" y="88.9"/>
</segment>
<segment>
<wire x1="195.58" y1="43.18" x2="180.34" y2="43.18" width="0.1524" layer="91"/>
<pinref part="GND12" gate="1" pin="GND"/>
<wire x1="180.34" y1="43.18" x2="180.34" y2="40.64" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="A1"/>
<wire x1="180.34" y1="50.8" x2="180.34" y2="48.26" width="0.1524" layer="91"/>
<wire x1="180.34" y1="48.26" x2="180.34" y2="43.18" width="0.1524" layer="91"/>
<wire x1="195.58" y1="50.8" x2="180.34" y2="50.8" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="A2"/>
<wire x1="195.58" y1="48.26" x2="180.34" y2="48.26" width="0.1524" layer="91"/>
<junction x="180.34" y="48.26"/>
<pinref part="IC2" gate="G$1" pin="VSS"/>
<junction x="180.34" y="43.18"/>
</segment>
<segment>
<pinref part="GND13" gate="1" pin="GND"/>
<pinref part="Q9" gate="G$1" pin="S"/>
<wire x1="254" y1="20.32" x2="254" y2="22.86" width="0.1524" layer="91"/>
<wire x1="254" y1="22.86" x2="256.54" y2="22.86" width="0.1524" layer="91"/>
<pinref part="R24" gate="G$1" pin="1"/>
<wire x1="256.54" y1="22.86" x2="274.32" y2="22.86" width="0.1524" layer="91"/>
<wire x1="256.54" y1="30.48" x2="256.54" y2="22.86" width="0.1524" layer="91"/>
<junction x="256.54" y="22.86"/>
</segment>
<segment>
<pinref part="GND14" gate="1" pin="GND"/>
<pinref part="Q10" gate="G$1" pin="S"/>
<wire x1="254" y1="0" x2="254" y2="2.54" width="0.1524" layer="91"/>
<wire x1="254" y1="2.54" x2="256.54" y2="2.54" width="0.1524" layer="91"/>
<pinref part="R26" gate="G$1" pin="1"/>
<wire x1="256.54" y1="2.54" x2="274.32" y2="2.54" width="0.1524" layer="91"/>
<wire x1="256.54" y1="10.16" x2="256.54" y2="2.54" width="0.1524" layer="91"/>
<junction x="256.54" y="2.54"/>
</segment>
<segment>
<pinref part="GND15" gate="1" pin="GND"/>
<pinref part="Q11" gate="G$1" pin="S"/>
<wire x1="254" y1="-20.32" x2="254" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="254" y1="-17.78" x2="256.54" y2="-17.78" width="0.1524" layer="91"/>
<pinref part="R27" gate="G$1" pin="1"/>
<wire x1="256.54" y1="-17.78" x2="274.32" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="256.54" y1="-10.16" x2="256.54" y2="-17.78" width="0.1524" layer="91"/>
<junction x="256.54" y="-17.78"/>
</segment>
<segment>
<pinref part="GND16" gate="1" pin="GND"/>
<pinref part="Q12" gate="G$1" pin="S"/>
<wire x1="254" y1="-40.64" x2="254" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="254" y1="-38.1" x2="256.54" y2="-38.1" width="0.1524" layer="91"/>
<pinref part="R28" gate="G$1" pin="1"/>
<wire x1="256.54" y1="-38.1" x2="274.32" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="256.54" y1="-30.48" x2="256.54" y2="-38.1" width="0.1524" layer="91"/>
<junction x="256.54" y="-38.1"/>
</segment>
<segment>
<pinref part="GND17" gate="1" pin="GND"/>
<pinref part="Q13" gate="G$1" pin="S"/>
<wire x1="254" y1="-60.96" x2="254" y2="-58.42" width="0.1524" layer="91"/>
<wire x1="254" y1="-58.42" x2="256.54" y2="-58.42" width="0.1524" layer="91"/>
<pinref part="R29" gate="G$1" pin="1"/>
<wire x1="256.54" y1="-58.42" x2="274.32" y2="-58.42" width="0.1524" layer="91"/>
<wire x1="256.54" y1="-50.8" x2="256.54" y2="-58.42" width="0.1524" layer="91"/>
<junction x="256.54" y="-58.42"/>
</segment>
<segment>
<pinref part="GND18" gate="1" pin="GND"/>
<pinref part="Q14" gate="G$1" pin="S"/>
<wire x1="254" y1="-78.74" x2="254" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="254" y1="-76.2" x2="256.54" y2="-76.2" width="0.1524" layer="91"/>
<pinref part="R30" gate="G$1" pin="1"/>
<wire x1="256.54" y1="-76.2" x2="274.32" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="256.54" y1="-68.58" x2="256.54" y2="-76.2" width="0.1524" layer="91"/>
<junction x="256.54" y="-76.2"/>
</segment>
<segment>
<pinref part="GND19" gate="1" pin="GND"/>
<pinref part="Q15" gate="G$1" pin="S"/>
<wire x1="254" y1="-99.06" x2="254" y2="-96.52" width="0.1524" layer="91"/>
<wire x1="254" y1="-96.52" x2="256.54" y2="-96.52" width="0.1524" layer="91"/>
<pinref part="R31" gate="G$1" pin="1"/>
<wire x1="256.54" y1="-96.52" x2="274.32" y2="-96.52" width="0.1524" layer="91"/>
<wire x1="256.54" y1="-88.9" x2="256.54" y2="-96.52" width="0.1524" layer="91"/>
<junction x="256.54" y="-96.52"/>
</segment>
<segment>
<pinref part="GND20" gate="1" pin="GND"/>
<pinref part="Q16" gate="G$1" pin="S"/>
<wire x1="254" y1="-121.92" x2="254" y2="-119.38" width="0.1524" layer="91"/>
<wire x1="254" y1="-119.38" x2="256.54" y2="-119.38" width="0.1524" layer="91"/>
<pinref part="R32" gate="G$1" pin="1"/>
<wire x1="256.54" y1="-119.38" x2="274.32" y2="-119.38" width="0.1524" layer="91"/>
<wire x1="256.54" y1="-111.76" x2="256.54" y2="-119.38" width="0.1524" layer="91"/>
<junction x="256.54" y="-119.38"/>
</segment>
<segment>
<pinref part="GND21" gate="1" pin="GND"/>
<wire x1="462.28" y1="99.06" x2="444.5" y2="99.06" width="0.1524" layer="91"/>
<wire x1="444.5" y1="99.06" x2="444.5" y2="93.98" width="0.1524" layer="91"/>
<wire x1="444.5" y1="93.98" x2="444.5" y2="91.44" width="0.1524" layer="91"/>
<wire x1="444.5" y1="91.44" x2="444.5" y2="88.9" width="0.1524" layer="91"/>
<wire x1="444.5" y1="88.9" x2="444.5" y2="86.36" width="0.1524" layer="91"/>
<wire x1="444.5" y1="86.36" x2="444.5" y2="83.82" width="0.1524" layer="91"/>
<wire x1="444.5" y1="83.82" x2="444.5" y2="81.28" width="0.1524" layer="91"/>
<wire x1="444.5" y1="81.28" x2="444.5" y2="78.74" width="0.1524" layer="91"/>
<wire x1="444.5" y1="78.74" x2="444.5" y2="76.2" width="0.1524" layer="91"/>
<wire x1="441.96" y1="76.2" x2="444.5" y2="76.2" width="0.1524" layer="91"/>
<wire x1="441.96" y1="78.74" x2="444.5" y2="78.74" width="0.1524" layer="91"/>
<wire x1="441.96" y1="81.28" x2="444.5" y2="81.28" width="0.1524" layer="91"/>
<wire x1="441.96" y1="83.82" x2="444.5" y2="83.82" width="0.1524" layer="91"/>
<wire x1="441.96" y1="86.36" x2="444.5" y2="86.36" width="0.1524" layer="91"/>
<wire x1="441.96" y1="88.9" x2="444.5" y2="88.9" width="0.1524" layer="91"/>
<wire x1="441.96" y1="91.44" x2="444.5" y2="91.44" width="0.1524" layer="91"/>
<junction x="444.5" y="78.74"/>
<junction x="444.5" y="81.28"/>
<junction x="444.5" y="83.82"/>
<junction x="444.5" y="86.36"/>
<junction x="444.5" y="88.9"/>
<junction x="444.5" y="91.44"/>
<wire x1="441.96" y1="53.34" x2="444.5" y2="53.34" width="0.1524" layer="91"/>
<wire x1="444.5" y1="53.34" x2="444.5" y2="55.88" width="0.1524" layer="91"/>
<wire x1="444.5" y1="55.88" x2="444.5" y2="58.42" width="0.1524" layer="91"/>
<wire x1="444.5" y1="58.42" x2="444.5" y2="60.96" width="0.1524" layer="91"/>
<wire x1="444.5" y1="60.96" x2="444.5" y2="63.5" width="0.1524" layer="91"/>
<wire x1="444.5" y1="63.5" x2="444.5" y2="66.04" width="0.1524" layer="91"/>
<wire x1="444.5" y1="66.04" x2="444.5" y2="68.58" width="0.1524" layer="91"/>
<wire x1="444.5" y1="68.58" x2="444.5" y2="71.12" width="0.1524" layer="91"/>
<wire x1="444.5" y1="71.12" x2="444.5" y2="76.2" width="0.1524" layer="91"/>
<wire x1="441.96" y1="71.12" x2="444.5" y2="71.12" width="0.1524" layer="91"/>
<wire x1="441.96" y1="68.58" x2="444.5" y2="68.58" width="0.1524" layer="91"/>
<wire x1="441.96" y1="66.04" x2="444.5" y2="66.04" width="0.1524" layer="91"/>
<wire x1="441.96" y1="63.5" x2="444.5" y2="63.5" width="0.1524" layer="91"/>
<wire x1="441.96" y1="60.96" x2="444.5" y2="60.96" width="0.1524" layer="91"/>
<wire x1="441.96" y1="58.42" x2="444.5" y2="58.42" width="0.1524" layer="91"/>
<wire x1="441.96" y1="55.88" x2="444.5" y2="55.88" width="0.1524" layer="91"/>
<junction x="444.5" y="71.12"/>
<junction x="444.5" y="68.58"/>
<junction x="444.5" y="66.04"/>
<junction x="444.5" y="63.5"/>
<junction x="444.5" y="60.96"/>
<junction x="444.5" y="58.42"/>
<junction x="444.5" y="55.88"/>
<junction x="444.5" y="76.2"/>
<pinref part="R34" gate="G$1" pin="2"/>
<pinref part="R35" gate="G$1" pin="2"/>
<pinref part="R36" gate="G$1" pin="2"/>
<pinref part="R37" gate="G$1" pin="2"/>
<pinref part="R38" gate="G$1" pin="2"/>
<pinref part="R39" gate="G$1" pin="2"/>
<pinref part="R40" gate="G$1" pin="2"/>
<pinref part="LED17" gate="G$1" pin="C"/>
<pinref part="LED18" gate="G$1" pin="C"/>
<pinref part="LED19" gate="G$1" pin="C"/>
<pinref part="LED20" gate="G$1" pin="C"/>
<pinref part="LED21" gate="G$1" pin="C"/>
<pinref part="LED22" gate="G$1" pin="C"/>
<pinref part="LED23" gate="G$1" pin="C"/>
<pinref part="LED24" gate="G$1" pin="C"/>
<pinref part="R33" gate="G$1" pin="2"/>
<wire x1="441.96" y1="93.98" x2="444.5" y2="93.98" width="0.1524" layer="91"/>
<junction x="444.5" y="93.98"/>
<pinref part="SV18" gate="A" pin="1"/>
<wire x1="492.76" y1="53.34" x2="485.14" y2="53.34" width="0.1524" layer="91"/>
<wire x1="485.14" y1="53.34" x2="485.14" y2="99.06" width="0.1524" layer="91"/>
<wire x1="485.14" y1="99.06" x2="462.28" y2="99.06" width="0.1524" layer="91"/>
<junction x="462.28" y="99.06"/>
</segment>
<segment>
<wire x1="381" y1="53.34" x2="365.76" y2="53.34" width="0.1524" layer="91"/>
<pinref part="GND22" gate="1" pin="GND"/>
<wire x1="365.76" y1="53.34" x2="365.76" y2="50.8" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="A0"/>
<wire x1="381" y1="63.5" x2="365.76" y2="63.5" width="0.1524" layer="91"/>
<wire x1="365.76" y1="63.5" x2="365.76" y2="58.42" width="0.1524" layer="91"/>
<wire x1="365.76" y1="58.42" x2="365.76" y2="53.34" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="A2"/>
<wire x1="381" y1="58.42" x2="365.76" y2="58.42" width="0.1524" layer="91"/>
<junction x="365.76" y="58.42"/>
<junction x="365.76" y="63.5"/>
<pinref part="IC3" gate="G$1" pin="VSS"/>
<junction x="365.76" y="53.34"/>
</segment>
<segment>
<pinref part="GND23" gate="1" pin="GND"/>
<pinref part="Q17" gate="G$1" pin="S"/>
<wire x1="439.42" y1="30.48" x2="439.42" y2="33.02" width="0.1524" layer="91"/>
<wire x1="439.42" y1="33.02" x2="441.96" y2="33.02" width="0.1524" layer="91"/>
<pinref part="R41" gate="G$1" pin="1"/>
<wire x1="441.96" y1="33.02" x2="459.74" y2="33.02" width="0.1524" layer="91"/>
<wire x1="441.96" y1="40.64" x2="441.96" y2="33.02" width="0.1524" layer="91"/>
<junction x="441.96" y="33.02"/>
</segment>
<segment>
<pinref part="GND24" gate="1" pin="GND"/>
<pinref part="Q18" gate="G$1" pin="S"/>
<wire x1="439.42" y1="10.16" x2="439.42" y2="12.7" width="0.1524" layer="91"/>
<wire x1="439.42" y1="12.7" x2="441.96" y2="12.7" width="0.1524" layer="91"/>
<pinref part="R42" gate="G$1" pin="1"/>
<wire x1="441.96" y1="12.7" x2="459.74" y2="12.7" width="0.1524" layer="91"/>
<wire x1="441.96" y1="20.32" x2="441.96" y2="12.7" width="0.1524" layer="91"/>
<junction x="441.96" y="12.7"/>
</segment>
<segment>
<pinref part="GND25" gate="1" pin="GND"/>
<pinref part="Q19" gate="G$1" pin="S"/>
<wire x1="439.42" y1="-10.16" x2="439.42" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="439.42" y1="-7.62" x2="441.96" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="R43" gate="G$1" pin="1"/>
<wire x1="441.96" y1="-7.62" x2="459.74" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="441.96" y1="0" x2="441.96" y2="-7.62" width="0.1524" layer="91"/>
<junction x="441.96" y="-7.62"/>
</segment>
<segment>
<pinref part="GND26" gate="1" pin="GND"/>
<pinref part="Q20" gate="G$1" pin="S"/>
<wire x1="439.42" y1="-30.48" x2="439.42" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="439.42" y1="-27.94" x2="441.96" y2="-27.94" width="0.1524" layer="91"/>
<pinref part="R44" gate="G$1" pin="1"/>
<wire x1="441.96" y1="-27.94" x2="459.74" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="441.96" y1="-20.32" x2="441.96" y2="-27.94" width="0.1524" layer="91"/>
<junction x="441.96" y="-27.94"/>
</segment>
<segment>
<pinref part="GND27" gate="1" pin="GND"/>
<pinref part="Q21" gate="G$1" pin="S"/>
<wire x1="439.42" y1="-50.8" x2="439.42" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="439.42" y1="-48.26" x2="441.96" y2="-48.26" width="0.1524" layer="91"/>
<pinref part="R45" gate="G$1" pin="1"/>
<wire x1="441.96" y1="-48.26" x2="459.74" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="441.96" y1="-40.64" x2="441.96" y2="-48.26" width="0.1524" layer="91"/>
<junction x="441.96" y="-48.26"/>
</segment>
<segment>
<pinref part="GND28" gate="1" pin="GND"/>
<pinref part="Q22" gate="G$1" pin="S"/>
<wire x1="439.42" y1="-68.58" x2="439.42" y2="-66.04" width="0.1524" layer="91"/>
<wire x1="439.42" y1="-66.04" x2="441.96" y2="-66.04" width="0.1524" layer="91"/>
<pinref part="R46" gate="G$1" pin="1"/>
<wire x1="441.96" y1="-66.04" x2="459.74" y2="-66.04" width="0.1524" layer="91"/>
<wire x1="441.96" y1="-58.42" x2="441.96" y2="-66.04" width="0.1524" layer="91"/>
<junction x="441.96" y="-66.04"/>
</segment>
<segment>
<pinref part="GND29" gate="1" pin="GND"/>
<pinref part="Q23" gate="G$1" pin="S"/>
<wire x1="439.42" y1="-88.9" x2="439.42" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="439.42" y1="-86.36" x2="441.96" y2="-86.36" width="0.1524" layer="91"/>
<pinref part="R47" gate="G$1" pin="1"/>
<wire x1="441.96" y1="-86.36" x2="459.74" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="441.96" y1="-78.74" x2="441.96" y2="-86.36" width="0.1524" layer="91"/>
<junction x="441.96" y="-86.36"/>
</segment>
<segment>
<pinref part="GND30" gate="1" pin="GND"/>
<pinref part="Q24" gate="G$1" pin="S"/>
<wire x1="439.42" y1="-111.76" x2="439.42" y2="-109.22" width="0.1524" layer="91"/>
<wire x1="439.42" y1="-109.22" x2="441.96" y2="-109.22" width="0.1524" layer="91"/>
<pinref part="R48" gate="G$1" pin="1"/>
<wire x1="441.96" y1="-109.22" x2="459.74" y2="-109.22" width="0.1524" layer="91"/>
<wire x1="441.96" y1="-101.6" x2="441.96" y2="-109.22" width="0.1524" layer="91"/>
<junction x="441.96" y="-109.22"/>
</segment>
</net>
<net name="+5V" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="VDD"/>
<pinref part="P+1" gate="1" pin="+5V"/>
<wire x1="2.54" y1="76.2" x2="-12.7" y2="76.2" width="0.1524" layer="91"/>
<wire x1="-12.7" y1="76.2" x2="-12.7" y2="78.74" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="!RESET"/>
<wire x1="-12.7" y1="78.74" x2="-12.7" y2="83.82" width="0.1524" layer="91"/>
<wire x1="-12.7" y1="83.82" x2="-12.7" y2="86.36" width="0.1524" layer="91"/>
<wire x1="2.54" y1="71.12" x2="-5.08" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-5.08" y1="71.12" x2="-10.16" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-10.16" y1="71.12" x2="-12.7" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-12.7" y1="71.12" x2="-12.7" y2="76.2" width="0.1524" layer="91"/>
<junction x="-12.7" y="76.2"/>
<wire x1="-12.7" y1="83.82" x2="2.54" y2="83.82" width="0.1524" layer="91"/>
<wire x1="2.54" y1="83.82" x2="2.54" y2="88.9" width="0.1524" layer="91"/>
<wire x1="-43.18" y1="78.74" x2="-12.7" y2="78.74" width="0.1524" layer="91"/>
<junction x="-12.7" y="78.74"/>
<wire x1="-43.18" y1="78.74" x2="-43.18" y2="20.32" width="0.1524" layer="91"/>
<junction x="-12.7" y="83.82"/>
<pinref part="U1" gate="G$1" pin="5V"/>
<wire x1="-58.42" y1="20.32" x2="-43.18" y2="20.32" width="0.1524" layer="91"/>
<pinref part="SV1" gate="G$1" pin="1"/>
<wire x1="20.32" y1="88.9" x2="2.54" y2="88.9" width="0.1524" layer="91"/>
<pinref part="R50" gate="G$1" pin="2"/>
<wire x1="-10.16" y1="68.58" x2="-10.16" y2="71.12" width="0.1524" layer="91"/>
<junction x="-10.16" y="71.12"/>
<pinref part="R49" gate="G$1" pin="2"/>
<wire x1="-5.08" y1="68.58" x2="-5.08" y2="71.12" width="0.1524" layer="91"/>
<junction x="-5.08" y="71.12"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="VDD"/>
<pinref part="P+2" gate="1" pin="+5V"/>
<wire x1="195.58" y1="83.82" x2="180.34" y2="83.82" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="!RESET"/>
<wire x1="180.34" y1="83.82" x2="180.34" y2="91.44" width="0.1524" layer="91"/>
<wire x1="180.34" y1="91.44" x2="180.34" y2="93.98" width="0.1524" layer="91"/>
<wire x1="195.58" y1="78.74" x2="190.5" y2="78.74" width="0.1524" layer="91"/>
<wire x1="190.5" y1="78.74" x2="185.42" y2="78.74" width="0.1524" layer="91"/>
<wire x1="185.42" y1="78.74" x2="180.34" y2="78.74" width="0.1524" layer="91"/>
<wire x1="180.34" y1="78.74" x2="180.34" y2="83.82" width="0.1524" layer="91"/>
<junction x="180.34" y="83.82"/>
<wire x1="180.34" y1="91.44" x2="195.58" y2="91.44" width="0.1524" layer="91"/>
<wire x1="195.58" y1="91.44" x2="195.58" y2="96.52" width="0.1524" layer="91"/>
<junction x="180.34" y="91.44"/>
<pinref part="SV7" gate="G$1" pin="1"/>
<wire x1="213.36" y1="96.52" x2="195.58" y2="96.52" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="A0"/>
<wire x1="195.58" y1="53.34" x2="180.34" y2="53.34" width="0.1524" layer="91"/>
<wire x1="180.34" y1="53.34" x2="180.34" y2="78.74" width="0.1524" layer="91"/>
<junction x="180.34" y="78.74"/>
<pinref part="R52" gate="G$1" pin="2"/>
<wire x1="185.42" y1="78.74" x2="185.42" y2="76.2" width="0.1524" layer="91"/>
<junction x="185.42" y="78.74"/>
<pinref part="R51" gate="G$1" pin="2"/>
<wire x1="190.5" y1="78.74" x2="190.5" y2="76.2" width="0.1524" layer="91"/>
<junction x="190.5" y="78.74"/>
</segment>
<segment>
<pinref part="IC3" gate="G$1" pin="VDD"/>
<pinref part="P+5" gate="1" pin="+5V"/>
<wire x1="381" y1="93.98" x2="365.76" y2="93.98" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="!RESET"/>
<wire x1="365.76" y1="93.98" x2="365.76" y2="101.6" width="0.1524" layer="91"/>
<wire x1="365.76" y1="101.6" x2="365.76" y2="104.14" width="0.1524" layer="91"/>
<wire x1="381" y1="88.9" x2="375.92" y2="88.9" width="0.1524" layer="91"/>
<wire x1="375.92" y1="88.9" x2="370.84" y2="88.9" width="0.1524" layer="91"/>
<wire x1="370.84" y1="88.9" x2="368.3" y2="88.9" width="0.1524" layer="91"/>
<wire x1="368.3" y1="88.9" x2="365.76" y2="88.9" width="0.1524" layer="91"/>
<wire x1="365.76" y1="88.9" x2="365.76" y2="93.98" width="0.1524" layer="91"/>
<junction x="365.76" y="93.98"/>
<wire x1="365.76" y1="101.6" x2="381" y2="101.6" width="0.1524" layer="91"/>
<wire x1="381" y1="101.6" x2="381" y2="106.68" width="0.1524" layer="91"/>
<junction x="365.76" y="101.6"/>
<pinref part="SV13" gate="G$1" pin="1"/>
<wire x1="398.78" y1="106.68" x2="381" y2="106.68" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="A1"/>
<wire x1="381" y1="60.96" x2="368.3" y2="60.96" width="0.1524" layer="91"/>
<wire x1="368.3" y1="60.96" x2="368.3" y2="88.9" width="0.1524" layer="91"/>
<junction x="368.3" y="88.9"/>
<pinref part="R54" gate="G$1" pin="2"/>
<wire x1="370.84" y1="88.9" x2="370.84" y2="86.36" width="0.1524" layer="91"/>
<junction x="370.84" y="88.9"/>
<pinref part="R53" gate="G$1" pin="2"/>
<wire x1="375.92" y1="88.9" x2="375.92" y2="86.36" width="0.1524" layer="91"/>
<junction x="375.92" y="88.9"/>
</segment>
</net>
<net name="N$1" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPA0"/>
<wire x1="27.94" y1="76.2" x2="30.48" y2="76.2" width="0.1524" layer="91"/>
<wire x1="30.48" y1="76.2" x2="53.34" y2="76.2" width="0.1524" layer="91"/>
<wire x1="22.86" y1="83.82" x2="30.48" y2="83.82" width="0.1524" layer="91"/>
<wire x1="30.48" y1="83.82" x2="30.48" y2="76.2" width="0.1524" layer="91"/>
<junction x="30.48" y="76.2"/>
<pinref part="R1" gate="G$1" pin="1"/>
<pinref part="SV1" gate="G$1" pin="2"/>
<wire x1="22.86" y1="83.82" x2="22.86" y2="88.9" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPA1"/>
<wire x1="27.94" y1="73.66" x2="33.02" y2="73.66" width="0.1524" layer="91"/>
<wire x1="33.02" y1="73.66" x2="53.34" y2="73.66" width="0.1524" layer="91"/>
<wire x1="25.4" y1="86.36" x2="33.02" y2="86.36" width="0.1524" layer="91"/>
<wire x1="33.02" y1="86.36" x2="33.02" y2="73.66" width="0.1524" layer="91"/>
<junction x="33.02" y="73.66"/>
<pinref part="R2" gate="G$1" pin="1"/>
<pinref part="SV1" gate="G$1" pin="3"/>
<wire x1="25.4" y1="86.36" x2="25.4" y2="88.9" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPA2"/>
<wire x1="27.94" y1="71.12" x2="35.56" y2="71.12" width="0.1524" layer="91"/>
<wire x1="35.56" y1="71.12" x2="53.34" y2="71.12" width="0.1524" layer="91"/>
<wire x1="35.56" y1="88.9" x2="35.56" y2="71.12" width="0.1524" layer="91"/>
<junction x="35.56" y="71.12"/>
<pinref part="R3" gate="G$1" pin="1"/>
<pinref part="SV2" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPA3"/>
<wire x1="27.94" y1="68.58" x2="38.1" y2="68.58" width="0.1524" layer="91"/>
<pinref part="R4" gate="G$1" pin="1"/>
<pinref part="SV2" gate="G$1" pin="2"/>
<wire x1="38.1" y1="68.58" x2="53.34" y2="68.58" width="0.1524" layer="91"/>
<wire x1="38.1" y1="88.9" x2="38.1" y2="68.58" width="0.1524" layer="91"/>
<junction x="38.1" y="68.58"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPA4"/>
<wire x1="27.94" y1="66.04" x2="40.64" y2="66.04" width="0.1524" layer="91"/>
<pinref part="R5" gate="G$1" pin="1"/>
<pinref part="SV2" gate="G$1" pin="3"/>
<wire x1="40.64" y1="66.04" x2="53.34" y2="66.04" width="0.1524" layer="91"/>
<wire x1="40.64" y1="88.9" x2="40.64" y2="66.04" width="0.1524" layer="91"/>
<junction x="40.64" y="66.04"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPA5"/>
<wire x1="27.94" y1="63.5" x2="43.18" y2="63.5" width="0.1524" layer="91"/>
<pinref part="R6" gate="G$1" pin="1"/>
<pinref part="SV3" gate="G$1" pin="1"/>
<wire x1="43.18" y1="63.5" x2="53.34" y2="63.5" width="0.1524" layer="91"/>
<wire x1="50.8" y1="88.9" x2="43.18" y2="88.9" width="0.1524" layer="91"/>
<wire x1="43.18" y1="88.9" x2="43.18" y2="63.5" width="0.1524" layer="91"/>
<junction x="43.18" y="63.5"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPA6"/>
<wire x1="27.94" y1="60.96" x2="45.72" y2="60.96" width="0.1524" layer="91"/>
<wire x1="45.72" y1="60.96" x2="53.34" y2="60.96" width="0.1524" layer="91"/>
<wire x1="45.72" y1="86.36" x2="45.72" y2="60.96" width="0.1524" layer="91"/>
<junction x="45.72" y="60.96"/>
<pinref part="R7" gate="G$1" pin="1"/>
<wire x1="45.72" y1="86.36" x2="53.34" y2="86.36" width="0.1524" layer="91"/>
<pinref part="SV3" gate="G$1" pin="2"/>
<wire x1="53.34" y1="86.36" x2="53.34" y2="88.9" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPA7"/>
<wire x1="27.94" y1="58.42" x2="48.26" y2="58.42" width="0.1524" layer="91"/>
<wire x1="48.26" y1="58.42" x2="53.34" y2="58.42" width="0.1524" layer="91"/>
<wire x1="55.88" y1="83.82" x2="48.26" y2="83.82" width="0.1524" layer="91"/>
<wire x1="48.26" y1="83.82" x2="48.26" y2="58.42" width="0.1524" layer="91"/>
<junction x="48.26" y="58.42"/>
<pinref part="R8" gate="G$1" pin="1"/>
<pinref part="SV3" gate="G$1" pin="3"/>
<wire x1="55.88" y1="83.82" x2="55.88" y2="88.9" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPB0"/>
<pinref part="LED1" gate="G$1" pin="A"/>
<wire x1="27.94" y1="53.34" x2="53.34" y2="53.34" width="0.1524" layer="91"/>
<wire x1="53.34" y1="53.34" x2="55.88" y2="53.34" width="0.1524" layer="91"/>
<wire x1="53.34" y1="53.34" x2="53.34" y2="30.48" width="0.1524" layer="91"/>
<wire x1="53.34" y1="30.48" x2="76.2" y2="30.48" width="0.1524" layer="91"/>
<junction x="53.34" y="53.34"/>
<pinref part="R25" gate="G$1" pin="2"/>
<wire x1="73.66" y1="22.86" x2="76.2" y2="22.86" width="0.1524" layer="91"/>
<pinref part="Q1" gate="G$1" pin="G"/>
<wire x1="76.2" y1="17.78" x2="76.2" y2="22.86" width="0.1524" layer="91"/>
<wire x1="76.2" y1="30.48" x2="76.2" y2="22.86" width="0.1524" layer="91"/>
<junction x="76.2" y="22.86"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPB1"/>
<wire x1="55.88" y1="50.8" x2="50.8" y2="50.8" width="0.1524" layer="91"/>
<pinref part="LED2" gate="G$1" pin="A"/>
<pinref part="R9" gate="G$1" pin="2"/>
<wire x1="50.8" y1="50.8" x2="27.94" y2="50.8" width="0.1524" layer="91"/>
<wire x1="73.66" y1="2.54" x2="76.2" y2="2.54" width="0.1524" layer="91"/>
<pinref part="Q2" gate="G$1" pin="G"/>
<wire x1="76.2" y1="-2.54" x2="76.2" y2="2.54" width="0.1524" layer="91"/>
<junction x="76.2" y="2.54"/>
<wire x1="76.2" y1="5.08" x2="76.2" y2="2.54" width="0.1524" layer="91"/>
<wire x1="50.8" y1="50.8" x2="50.8" y2="5.08" width="0.1524" layer="91"/>
<wire x1="50.8" y1="5.08" x2="76.2" y2="5.08" width="0.1524" layer="91"/>
<junction x="50.8" y="50.8"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPB2"/>
<wire x1="27.94" y1="48.26" x2="48.26" y2="48.26" width="0.1524" layer="91"/>
<pinref part="LED3" gate="G$1" pin="A"/>
<pinref part="R10" gate="G$1" pin="2"/>
<wire x1="48.26" y1="48.26" x2="55.88" y2="48.26" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-17.78" x2="76.2" y2="-17.78" width="0.1524" layer="91"/>
<pinref part="Q3" gate="G$1" pin="G"/>
<wire x1="76.2" y1="-22.86" x2="76.2" y2="-17.78" width="0.1524" layer="91"/>
<junction x="76.2" y="-17.78"/>
<wire x1="76.2" y1="-15.24" x2="76.2" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="48.26" y1="48.26" x2="48.26" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="48.26" y1="-15.24" x2="76.2" y2="-15.24" width="0.1524" layer="91"/>
<junction x="48.26" y="48.26"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPB3"/>
<wire x1="55.88" y1="45.72" x2="45.72" y2="45.72" width="0.1524" layer="91"/>
<pinref part="LED4" gate="G$1" pin="A"/>
<pinref part="R11" gate="G$1" pin="2"/>
<wire x1="45.72" y1="45.72" x2="27.94" y2="45.72" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-38.1" x2="76.2" y2="-38.1" width="0.1524" layer="91"/>
<pinref part="Q4" gate="G$1" pin="G"/>
<wire x1="76.2" y1="-43.18" x2="76.2" y2="-38.1" width="0.1524" layer="91"/>
<junction x="76.2" y="-38.1"/>
<wire x1="76.2" y1="-35.56" x2="76.2" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="45.72" y1="45.72" x2="45.72" y2="-35.56" width="0.1524" layer="91"/>
<wire x1="45.72" y1="-35.56" x2="76.2" y2="-35.56" width="0.1524" layer="91"/>
<junction x="45.72" y="45.72"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPB4"/>
<wire x1="27.94" y1="43.18" x2="43.18" y2="43.18" width="0.1524" layer="91"/>
<pinref part="LED5" gate="G$1" pin="A"/>
<pinref part="R12" gate="G$1" pin="2"/>
<wire x1="43.18" y1="43.18" x2="55.88" y2="43.18" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-58.42" x2="76.2" y2="-58.42" width="0.1524" layer="91"/>
<pinref part="Q5" gate="G$1" pin="G"/>
<wire x1="76.2" y1="-63.5" x2="76.2" y2="-58.42" width="0.1524" layer="91"/>
<junction x="76.2" y="-58.42"/>
<wire x1="76.2" y1="-55.88" x2="76.2" y2="-58.42" width="0.1524" layer="91"/>
<wire x1="43.18" y1="43.18" x2="43.18" y2="-55.88" width="0.1524" layer="91"/>
<wire x1="43.18" y1="-55.88" x2="76.2" y2="-55.88" width="0.1524" layer="91"/>
<junction x="43.18" y="43.18"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPB5"/>
<wire x1="55.88" y1="40.64" x2="40.64" y2="40.64" width="0.1524" layer="91"/>
<pinref part="LED6" gate="G$1" pin="A"/>
<pinref part="R13" gate="G$1" pin="2"/>
<wire x1="40.64" y1="40.64" x2="27.94" y2="40.64" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-76.2" x2="76.2" y2="-76.2" width="0.1524" layer="91"/>
<pinref part="Q6" gate="G$1" pin="G"/>
<wire x1="76.2" y1="-81.28" x2="76.2" y2="-76.2" width="0.1524" layer="91"/>
<junction x="76.2" y="-76.2"/>
<wire x1="76.2" y1="-73.66" x2="76.2" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="40.64" y1="40.64" x2="40.64" y2="-73.66" width="0.1524" layer="91"/>
<wire x1="40.64" y1="-73.66" x2="76.2" y2="-73.66" width="0.1524" layer="91"/>
<junction x="40.64" y="40.64"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GPB6"/>
<wire x1="27.94" y1="38.1" x2="38.1" y2="38.1" width="0.1524" layer="91"/>
<pinref part="LED7" gate="G$1" pin="A"/>
<pinref part="R14" gate="G$1" pin="2"/>
<wire x1="38.1" y1="38.1" x2="55.88" y2="38.1" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-96.52" x2="76.2" y2="-96.52" width="0.1524" layer="91"/>
<pinref part="Q7" gate="G$1" pin="G"/>
<wire x1="76.2" y1="-101.6" x2="76.2" y2="-96.52" width="0.1524" layer="91"/>
<junction x="76.2" y="-96.52"/>
<wire x1="76.2" y1="-93.98" x2="76.2" y2="-96.52" width="0.1524" layer="91"/>
<wire x1="38.1" y1="38.1" x2="38.1" y2="-93.98" width="0.1524" layer="91"/>
<wire x1="38.1" y1="-93.98" x2="76.2" y2="-93.98" width="0.1524" layer="91"/>
<junction x="38.1" y="38.1"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<wire x1="55.88" y1="35.56" x2="35.56" y2="35.56" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="GPB7"/>
<pinref part="LED8" gate="G$1" pin="A"/>
<pinref part="R15" gate="G$1" pin="2"/>
<wire x1="35.56" y1="35.56" x2="27.94" y2="35.56" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-119.38" x2="76.2" y2="-119.38" width="0.1524" layer="91"/>
<pinref part="Q8" gate="G$1" pin="G"/>
<wire x1="76.2" y1="-124.46" x2="76.2" y2="-119.38" width="0.1524" layer="91"/>
<junction x="76.2" y="-119.38"/>
<wire x1="76.2" y1="-116.84" x2="76.2" y2="-119.38" width="0.1524" layer="91"/>
<wire x1="35.56" y1="35.56" x2="35.56" y2="-116.84" width="0.1524" layer="91"/>
<wire x1="35.56" y1="-116.84" x2="76.2" y2="-116.84" width="0.1524" layer="91"/>
<junction x="35.56" y="35.56"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="Q1" gate="G$1" pin="D"/>
<wire x1="81.28" y1="25.4" x2="81.28" y2="27.94" width="0.1524" layer="91"/>
<pinref part="SV6" gate="A" pin="3"/>
<wire x1="114.3" y1="27.94" x2="81.28" y2="27.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="+12V" class="0">
<segment>
<pinref part="P+6" gate="1" pin="+12V"/>
<wire x1="480.06" y1="60.96" x2="480.06" y2="50.8" width="0.1524" layer="91"/>
<pinref part="SV18" gate="A" pin="2"/>
<wire x1="492.76" y1="50.8" x2="480.06" y2="50.8" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="SV6" gate="A" pin="2"/>
<pinref part="P+4" gate="1" pin="+12V"/>
<wire x1="114.3" y1="30.48" x2="101.6" y2="30.48" width="0.1524" layer="91"/>
<wire x1="101.6" y1="30.48" x2="101.6" y2="43.18" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="SV12" gate="A" pin="2"/>
<wire x1="307.34" y1="40.64" x2="294.64" y2="40.64" width="0.1524" layer="91"/>
<pinref part="P+3" gate="1" pin="+12V"/>
<wire x1="294.64" y1="40.64" x2="294.64" y2="50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<pinref part="Q3" gate="G$1" pin="D"/>
<wire x1="81.28" y1="-15.24" x2="81.28" y2="-10.16" width="0.1524" layer="91"/>
<pinref part="SV5" gate="G$1" pin="1"/>
<wire x1="109.22" y1="17.78" x2="88.9" y2="17.78" width="0.1524" layer="91"/>
<wire x1="88.9" y1="17.78" x2="88.9" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-10.16" x2="81.28" y2="-10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<pinref part="Q4" gate="G$1" pin="D"/>
<wire x1="81.28" y1="-35.56" x2="81.28" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="81.28" y1="-30.48" x2="91.44" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-30.48" x2="91.44" y2="15.24" width="0.1524" layer="91"/>
<pinref part="SV5" gate="G$1" pin="2"/>
<wire x1="91.44" y1="15.24" x2="109.22" y2="15.24" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<pinref part="Q5" gate="G$1" pin="D"/>
<wire x1="81.28" y1="-55.88" x2="81.28" y2="-50.8" width="0.1524" layer="91"/>
<pinref part="SV5" gate="G$1" pin="3"/>
<wire x1="109.22" y1="12.7" x2="93.98" y2="12.7" width="0.1524" layer="91"/>
<wire x1="93.98" y1="12.7" x2="93.98" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="93.98" y1="-50.8" x2="81.28" y2="-50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="Q6" gate="G$1" pin="D"/>
<wire x1="81.28" y1="-73.66" x2="81.28" y2="-68.58" width="0.1524" layer="91"/>
<wire x1="81.28" y1="-68.58" x2="96.52" y2="-68.58" width="0.1524" layer="91"/>
<wire x1="96.52" y1="-68.58" x2="96.52" y2="2.54" width="0.1524" layer="91"/>
<pinref part="SV4" gate="G$1" pin="1"/>
<wire x1="96.52" y1="2.54" x2="109.22" y2="2.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$29" class="0">
<segment>
<pinref part="Q7" gate="G$1" pin="D"/>
<wire x1="81.28" y1="-93.98" x2="81.28" y2="-88.9" width="0.1524" layer="91"/>
<pinref part="SV4" gate="G$1" pin="2"/>
<wire x1="109.22" y1="0" x2="99.06" y2="0" width="0.1524" layer="91"/>
<wire x1="99.06" y1="0" x2="99.06" y2="-88.9" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-88.9" x2="81.28" y2="-88.9" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$31" class="0">
<segment>
<pinref part="Q8" gate="G$1" pin="D"/>
<wire x1="81.28" y1="-116.84" x2="81.28" y2="-111.76" width="0.1524" layer="91"/>
<wire x1="81.28" y1="-111.76" x2="101.6" y2="-111.76" width="0.1524" layer="91"/>
<wire x1="101.6" y1="-111.76" x2="101.6" y2="-2.54" width="0.1524" layer="91"/>
<pinref part="SV4" gate="G$1" pin="3"/>
<wire x1="101.6" y1="-2.54" x2="109.22" y2="-2.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPA0"/>
<wire x1="220.98" y1="83.82" x2="223.52" y2="83.82" width="0.1524" layer="91"/>
<wire x1="223.52" y1="83.82" x2="246.38" y2="83.82" width="0.1524" layer="91"/>
<wire x1="215.9" y1="91.44" x2="223.52" y2="91.44" width="0.1524" layer="91"/>
<wire x1="223.52" y1="91.44" x2="223.52" y2="83.82" width="0.1524" layer="91"/>
<junction x="223.52" y="83.82"/>
<pinref part="R16" gate="G$1" pin="1"/>
<pinref part="SV7" gate="G$1" pin="2"/>
<wire x1="215.9" y1="91.44" x2="215.9" y2="96.52" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPA1"/>
<wire x1="220.98" y1="81.28" x2="226.06" y2="81.28" width="0.1524" layer="91"/>
<wire x1="226.06" y1="81.28" x2="246.38" y2="81.28" width="0.1524" layer="91"/>
<wire x1="218.44" y1="93.98" x2="226.06" y2="93.98" width="0.1524" layer="91"/>
<wire x1="226.06" y1="93.98" x2="226.06" y2="81.28" width="0.1524" layer="91"/>
<junction x="226.06" y="81.28"/>
<pinref part="R17" gate="G$1" pin="1"/>
<pinref part="SV7" gate="G$1" pin="3"/>
<wire x1="218.44" y1="93.98" x2="218.44" y2="96.52" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPA2"/>
<wire x1="220.98" y1="78.74" x2="228.6" y2="78.74" width="0.1524" layer="91"/>
<wire x1="228.6" y1="78.74" x2="246.38" y2="78.74" width="0.1524" layer="91"/>
<wire x1="228.6" y1="96.52" x2="228.6" y2="78.74" width="0.1524" layer="91"/>
<junction x="228.6" y="78.74"/>
<pinref part="R18" gate="G$1" pin="1"/>
<pinref part="SV8" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPA3"/>
<wire x1="220.98" y1="76.2" x2="231.14" y2="76.2" width="0.1524" layer="91"/>
<pinref part="R19" gate="G$1" pin="1"/>
<pinref part="SV8" gate="G$1" pin="2"/>
<wire x1="231.14" y1="76.2" x2="246.38" y2="76.2" width="0.1524" layer="91"/>
<wire x1="231.14" y1="96.52" x2="231.14" y2="76.2" width="0.1524" layer="91"/>
<junction x="231.14" y="76.2"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPA4"/>
<wire x1="220.98" y1="73.66" x2="233.68" y2="73.66" width="0.1524" layer="91"/>
<pinref part="R20" gate="G$1" pin="1"/>
<pinref part="SV8" gate="G$1" pin="3"/>
<wire x1="233.68" y1="73.66" x2="246.38" y2="73.66" width="0.1524" layer="91"/>
<wire x1="233.68" y1="96.52" x2="233.68" y2="73.66" width="0.1524" layer="91"/>
<junction x="233.68" y="73.66"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPA5"/>
<wire x1="220.98" y1="71.12" x2="236.22" y2="71.12" width="0.1524" layer="91"/>
<pinref part="R21" gate="G$1" pin="1"/>
<pinref part="SV9" gate="G$1" pin="1"/>
<wire x1="236.22" y1="71.12" x2="246.38" y2="71.12" width="0.1524" layer="91"/>
<wire x1="243.84" y1="96.52" x2="236.22" y2="96.52" width="0.1524" layer="91"/>
<wire x1="236.22" y1="96.52" x2="236.22" y2="71.12" width="0.1524" layer="91"/>
<junction x="236.22" y="71.12"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPA6"/>
<wire x1="220.98" y1="68.58" x2="238.76" y2="68.58" width="0.1524" layer="91"/>
<wire x1="238.76" y1="68.58" x2="246.38" y2="68.58" width="0.1524" layer="91"/>
<wire x1="238.76" y1="93.98" x2="238.76" y2="68.58" width="0.1524" layer="91"/>
<junction x="238.76" y="68.58"/>
<pinref part="R22" gate="G$1" pin="1"/>
<wire x1="238.76" y1="93.98" x2="246.38" y2="93.98" width="0.1524" layer="91"/>
<pinref part="SV9" gate="G$1" pin="2"/>
<wire x1="246.38" y1="93.98" x2="246.38" y2="96.52" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPA7"/>
<wire x1="220.98" y1="66.04" x2="241.3" y2="66.04" width="0.1524" layer="91"/>
<wire x1="241.3" y1="66.04" x2="246.38" y2="66.04" width="0.1524" layer="91"/>
<wire x1="248.92" y1="91.44" x2="241.3" y2="91.44" width="0.1524" layer="91"/>
<wire x1="241.3" y1="91.44" x2="241.3" y2="66.04" width="0.1524" layer="91"/>
<junction x="241.3" y="66.04"/>
<pinref part="R23" gate="G$1" pin="1"/>
<pinref part="SV9" gate="G$1" pin="3"/>
<wire x1="248.92" y1="91.44" x2="248.92" y2="96.52" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPB0"/>
<pinref part="LED9" gate="G$1" pin="A"/>
<wire x1="220.98" y1="60.96" x2="246.38" y2="60.96" width="0.1524" layer="91"/>
<wire x1="246.38" y1="60.96" x2="248.92" y2="60.96" width="0.1524" layer="91"/>
<wire x1="246.38" y1="60.96" x2="246.38" y2="38.1" width="0.1524" layer="91"/>
<wire x1="246.38" y1="38.1" x2="269.24" y2="38.1" width="0.1524" layer="91"/>
<junction x="246.38" y="60.96"/>
<pinref part="R24" gate="G$1" pin="2"/>
<wire x1="266.7" y1="30.48" x2="269.24" y2="30.48" width="0.1524" layer="91"/>
<pinref part="Q9" gate="G$1" pin="G"/>
<wire x1="269.24" y1="25.4" x2="269.24" y2="30.48" width="0.1524" layer="91"/>
<wire x1="269.24" y1="38.1" x2="269.24" y2="30.48" width="0.1524" layer="91"/>
<junction x="269.24" y="30.48"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPB1"/>
<wire x1="248.92" y1="58.42" x2="243.84" y2="58.42" width="0.1524" layer="91"/>
<pinref part="LED10" gate="G$1" pin="A"/>
<pinref part="R26" gate="G$1" pin="2"/>
<wire x1="243.84" y1="58.42" x2="220.98" y2="58.42" width="0.1524" layer="91"/>
<wire x1="266.7" y1="10.16" x2="269.24" y2="10.16" width="0.1524" layer="91"/>
<pinref part="Q10" gate="G$1" pin="G"/>
<wire x1="269.24" y1="5.08" x2="269.24" y2="10.16" width="0.1524" layer="91"/>
<junction x="269.24" y="10.16"/>
<wire x1="269.24" y1="12.7" x2="269.24" y2="10.16" width="0.1524" layer="91"/>
<wire x1="243.84" y1="58.42" x2="243.84" y2="12.7" width="0.1524" layer="91"/>
<wire x1="243.84" y1="12.7" x2="269.24" y2="12.7" width="0.1524" layer="91"/>
<junction x="243.84" y="58.42"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPB2"/>
<wire x1="220.98" y1="55.88" x2="241.3" y2="55.88" width="0.1524" layer="91"/>
<pinref part="LED11" gate="G$1" pin="A"/>
<pinref part="R27" gate="G$1" pin="2"/>
<wire x1="241.3" y1="55.88" x2="248.92" y2="55.88" width="0.1524" layer="91"/>
<wire x1="266.7" y1="-10.16" x2="269.24" y2="-10.16" width="0.1524" layer="91"/>
<pinref part="Q11" gate="G$1" pin="G"/>
<wire x1="269.24" y1="-15.24" x2="269.24" y2="-10.16" width="0.1524" layer="91"/>
<junction x="269.24" y="-10.16"/>
<wire x1="269.24" y1="-7.62" x2="269.24" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="241.3" y1="55.88" x2="241.3" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="241.3" y1="-7.62" x2="269.24" y2="-7.62" width="0.1524" layer="91"/>
<junction x="241.3" y="55.88"/>
</segment>
</net>
<net name="N$36" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPB3"/>
<wire x1="248.92" y1="53.34" x2="238.76" y2="53.34" width="0.1524" layer="91"/>
<pinref part="LED12" gate="G$1" pin="A"/>
<pinref part="R28" gate="G$1" pin="2"/>
<wire x1="238.76" y1="53.34" x2="220.98" y2="53.34" width="0.1524" layer="91"/>
<wire x1="266.7" y1="-30.48" x2="269.24" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="Q12" gate="G$1" pin="G"/>
<wire x1="269.24" y1="-35.56" x2="269.24" y2="-30.48" width="0.1524" layer="91"/>
<junction x="269.24" y="-30.48"/>
<wire x1="269.24" y1="-27.94" x2="269.24" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="238.76" y1="53.34" x2="238.76" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="238.76" y1="-27.94" x2="269.24" y2="-27.94" width="0.1524" layer="91"/>
<junction x="238.76" y="53.34"/>
</segment>
</net>
<net name="N$37" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPB4"/>
<wire x1="220.98" y1="50.8" x2="236.22" y2="50.8" width="0.1524" layer="91"/>
<pinref part="LED13" gate="G$1" pin="A"/>
<pinref part="R29" gate="G$1" pin="2"/>
<wire x1="236.22" y1="50.8" x2="248.92" y2="50.8" width="0.1524" layer="91"/>
<wire x1="266.7" y1="-50.8" x2="269.24" y2="-50.8" width="0.1524" layer="91"/>
<pinref part="Q13" gate="G$1" pin="G"/>
<wire x1="269.24" y1="-55.88" x2="269.24" y2="-50.8" width="0.1524" layer="91"/>
<junction x="269.24" y="-50.8"/>
<wire x1="269.24" y1="-48.26" x2="269.24" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="236.22" y1="50.8" x2="236.22" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="236.22" y1="-48.26" x2="269.24" y2="-48.26" width="0.1524" layer="91"/>
<junction x="236.22" y="50.8"/>
</segment>
</net>
<net name="N$39" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPB5"/>
<wire x1="248.92" y1="48.26" x2="233.68" y2="48.26" width="0.1524" layer="91"/>
<pinref part="LED14" gate="G$1" pin="A"/>
<pinref part="R30" gate="G$1" pin="2"/>
<wire x1="233.68" y1="48.26" x2="220.98" y2="48.26" width="0.1524" layer="91"/>
<wire x1="266.7" y1="-68.58" x2="269.24" y2="-68.58" width="0.1524" layer="91"/>
<pinref part="Q14" gate="G$1" pin="G"/>
<wire x1="269.24" y1="-73.66" x2="269.24" y2="-68.58" width="0.1524" layer="91"/>
<junction x="269.24" y="-68.58"/>
<wire x1="269.24" y1="-66.04" x2="269.24" y2="-68.58" width="0.1524" layer="91"/>
<wire x1="233.68" y1="48.26" x2="233.68" y2="-66.04" width="0.1524" layer="91"/>
<wire x1="233.68" y1="-66.04" x2="269.24" y2="-66.04" width="0.1524" layer="91"/>
<junction x="233.68" y="48.26"/>
</segment>
</net>
<net name="N$40" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="GPB6"/>
<wire x1="220.98" y1="45.72" x2="231.14" y2="45.72" width="0.1524" layer="91"/>
<pinref part="LED15" gate="G$1" pin="A"/>
<pinref part="R31" gate="G$1" pin="2"/>
<wire x1="231.14" y1="45.72" x2="248.92" y2="45.72" width="0.1524" layer="91"/>
<wire x1="266.7" y1="-88.9" x2="269.24" y2="-88.9" width="0.1524" layer="91"/>
<pinref part="Q15" gate="G$1" pin="G"/>
<wire x1="269.24" y1="-93.98" x2="269.24" y2="-88.9" width="0.1524" layer="91"/>
<junction x="269.24" y="-88.9"/>
<wire x1="269.24" y1="-86.36" x2="269.24" y2="-88.9" width="0.1524" layer="91"/>
<wire x1="231.14" y1="45.72" x2="231.14" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="231.14" y1="-86.36" x2="269.24" y2="-86.36" width="0.1524" layer="91"/>
<junction x="231.14" y="45.72"/>
</segment>
</net>
<net name="N$41" class="0">
<segment>
<wire x1="248.92" y1="43.18" x2="228.6" y2="43.18" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="GPB7"/>
<pinref part="LED16" gate="G$1" pin="A"/>
<pinref part="R32" gate="G$1" pin="2"/>
<wire x1="228.6" y1="43.18" x2="220.98" y2="43.18" width="0.1524" layer="91"/>
<wire x1="266.7" y1="-111.76" x2="269.24" y2="-111.76" width="0.1524" layer="91"/>
<pinref part="Q16" gate="G$1" pin="G"/>
<wire x1="269.24" y1="-116.84" x2="269.24" y2="-111.76" width="0.1524" layer="91"/>
<junction x="269.24" y="-111.76"/>
<wire x1="269.24" y1="-109.22" x2="269.24" y2="-111.76" width="0.1524" layer="91"/>
<wire x1="228.6" y1="43.18" x2="228.6" y2="-109.22" width="0.1524" layer="91"/>
<wire x1="228.6" y1="-109.22" x2="269.24" y2="-109.22" width="0.1524" layer="91"/>
<junction x="228.6" y="43.18"/>
</segment>
</net>
<net name="N$42" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="SDA"/>
<wire x1="195.58" y1="58.42" x2="185.42" y2="58.42" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="SDA"/>
<wire x1="185.42" y1="58.42" x2="167.64" y2="58.42" width="0.1524" layer="91"/>
<wire x1="381" y1="68.58" x2="370.84" y2="68.58" width="0.1524" layer="91"/>
<wire x1="370.84" y1="68.58" x2="353.06" y2="68.58" width="0.1524" layer="91"/>
<wire x1="353.06" y1="68.58" x2="353.06" y2="114.3" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="SDA"/>
<wire x1="2.54" y1="50.8" x2="-10.16" y2="50.8" width="0.1524" layer="91"/>
<wire x1="-10.16" y1="50.8" x2="-20.32" y2="50.8" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="50.8" x2="-20.32" y2="43.18" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="43.18" x2="-35.56" y2="43.18" width="0.1524" layer="91"/>
<pinref part="U1" gate="G$1" pin="A4/SDA"/>
<wire x1="-35.56" y1="43.18" x2="-20.32" y2="43.18" width="0.1524" layer="91"/>
<wire x1="353.06" y1="114.3" x2="167.64" y2="114.3" width="0.1524" layer="91"/>
<wire x1="167.64" y1="114.3" x2="-35.56" y2="114.3" width="0.1524" layer="91"/>
<wire x1="-35.56" y1="114.3" x2="-35.56" y2="43.18" width="0.1524" layer="91"/>
<junction x="-35.56" y="43.18"/>
<wire x1="167.64" y1="58.42" x2="167.64" y2="114.3" width="0.1524" layer="91"/>
<junction x="167.64" y="114.3"/>
<pinref part="R52" gate="G$1" pin="1"/>
<wire x1="185.42" y1="66.04" x2="185.42" y2="58.42" width="0.1524" layer="91"/>
<junction x="185.42" y="58.42"/>
<pinref part="R54" gate="G$1" pin="1"/>
<wire x1="370.84" y1="76.2" x2="370.84" y2="68.58" width="0.1524" layer="91"/>
<junction x="370.84" y="68.58"/>
<pinref part="R50" gate="G$1" pin="1"/>
<wire x1="-10.16" y1="58.42" x2="-10.16" y2="50.8" width="0.1524" layer="91"/>
<junction x="-10.16" y="50.8"/>
</segment>
</net>
<net name="N$44" class="0">
<segment>
<pinref part="Q9" gate="G$1" pin="D"/>
<wire x1="274.32" y1="33.02" x2="274.32" y2="38.1" width="0.1524" layer="91"/>
<pinref part="SV12" gate="A" pin="3"/>
<wire x1="307.34" y1="38.1" x2="274.32" y2="38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$45" class="0">
<segment>
<pinref part="Q10" gate="G$1" pin="D"/>
<wire x1="274.32" y1="12.7" x2="274.32" y2="17.78" width="0.1524" layer="91"/>
<wire x1="274.32" y1="17.78" x2="279.4" y2="17.78" width="0.1524" layer="91"/>
<wire x1="279.4" y1="17.78" x2="279.4" y2="35.56" width="0.1524" layer="91"/>
<pinref part="SV12" gate="A" pin="4"/>
<wire x1="307.34" y1="35.56" x2="279.4" y2="35.56" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$46" class="0">
<segment>
<pinref part="Q11" gate="G$1" pin="D"/>
<wire x1="274.32" y1="-7.62" x2="274.32" y2="-2.54" width="0.1524" layer="91"/>
<pinref part="SV11" gate="G$1" pin="1"/>
<wire x1="302.26" y1="25.4" x2="281.94" y2="25.4" width="0.1524" layer="91"/>
<wire x1="281.94" y1="25.4" x2="281.94" y2="-2.54" width="0.1524" layer="91"/>
<wire x1="281.94" y1="-2.54" x2="274.32" y2="-2.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$47" class="0">
<segment>
<pinref part="Q12" gate="G$1" pin="D"/>
<wire x1="274.32" y1="-27.94" x2="274.32" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="274.32" y1="-22.86" x2="284.48" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="284.48" y1="-22.86" x2="284.48" y2="22.86" width="0.1524" layer="91"/>
<pinref part="SV11" gate="G$1" pin="2"/>
<wire x1="284.48" y1="22.86" x2="302.26" y2="22.86" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$48" class="0">
<segment>
<pinref part="Q13" gate="G$1" pin="D"/>
<wire x1="274.32" y1="-48.26" x2="274.32" y2="-43.18" width="0.1524" layer="91"/>
<pinref part="SV11" gate="G$1" pin="3"/>
<wire x1="302.26" y1="20.32" x2="287.02" y2="20.32" width="0.1524" layer="91"/>
<wire x1="287.02" y1="20.32" x2="287.02" y2="-43.18" width="0.1524" layer="91"/>
<wire x1="287.02" y1="-43.18" x2="274.32" y2="-43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$49" class="0">
<segment>
<pinref part="Q14" gate="G$1" pin="D"/>
<wire x1="274.32" y1="-66.04" x2="274.32" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="274.32" y1="-60.96" x2="289.56" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="289.56" y1="-60.96" x2="289.56" y2="10.16" width="0.1524" layer="91"/>
<pinref part="SV10" gate="G$1" pin="1"/>
<wire x1="289.56" y1="10.16" x2="302.26" y2="10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$50" class="0">
<segment>
<pinref part="Q15" gate="G$1" pin="D"/>
<wire x1="274.32" y1="-86.36" x2="274.32" y2="-81.28" width="0.1524" layer="91"/>
<pinref part="SV10" gate="G$1" pin="2"/>
<wire x1="302.26" y1="7.62" x2="292.1" y2="7.62" width="0.1524" layer="91"/>
<wire x1="292.1" y1="7.62" x2="292.1" y2="-81.28" width="0.1524" layer="91"/>
<wire x1="292.1" y1="-81.28" x2="274.32" y2="-81.28" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$51" class="0">
<segment>
<pinref part="Q16" gate="G$1" pin="D"/>
<wire x1="274.32" y1="-109.22" x2="274.32" y2="-104.14" width="0.1524" layer="91"/>
<wire x1="274.32" y1="-104.14" x2="294.64" y2="-104.14" width="0.1524" layer="91"/>
<wire x1="294.64" y1="-104.14" x2="294.64" y2="5.08" width="0.1524" layer="91"/>
<pinref part="SV10" gate="G$1" pin="3"/>
<wire x1="294.64" y1="5.08" x2="302.26" y2="5.08" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$52" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPA0"/>
<wire x1="406.4" y1="93.98" x2="408.94" y2="93.98" width="0.1524" layer="91"/>
<wire x1="408.94" y1="93.98" x2="431.8" y2="93.98" width="0.1524" layer="91"/>
<wire x1="401.32" y1="101.6" x2="408.94" y2="101.6" width="0.1524" layer="91"/>
<wire x1="408.94" y1="101.6" x2="408.94" y2="93.98" width="0.1524" layer="91"/>
<junction x="408.94" y="93.98"/>
<pinref part="R33" gate="G$1" pin="1"/>
<pinref part="SV13" gate="G$1" pin="2"/>
<wire x1="401.32" y1="101.6" x2="401.32" y2="106.68" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$53" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPA1"/>
<wire x1="406.4" y1="91.44" x2="411.48" y2="91.44" width="0.1524" layer="91"/>
<wire x1="411.48" y1="91.44" x2="431.8" y2="91.44" width="0.1524" layer="91"/>
<wire x1="403.86" y1="104.14" x2="411.48" y2="104.14" width="0.1524" layer="91"/>
<wire x1="411.48" y1="104.14" x2="411.48" y2="91.44" width="0.1524" layer="91"/>
<junction x="411.48" y="91.44"/>
<pinref part="R34" gate="G$1" pin="1"/>
<pinref part="SV13" gate="G$1" pin="3"/>
<wire x1="403.86" y1="104.14" x2="403.86" y2="106.68" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$54" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPA2"/>
<wire x1="406.4" y1="88.9" x2="414.02" y2="88.9" width="0.1524" layer="91"/>
<wire x1="414.02" y1="88.9" x2="431.8" y2="88.9" width="0.1524" layer="91"/>
<wire x1="414.02" y1="106.68" x2="414.02" y2="88.9" width="0.1524" layer="91"/>
<junction x="414.02" y="88.9"/>
<pinref part="R35" gate="G$1" pin="1"/>
<pinref part="SV14" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$56" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPA3"/>
<wire x1="406.4" y1="86.36" x2="416.56" y2="86.36" width="0.1524" layer="91"/>
<pinref part="R36" gate="G$1" pin="1"/>
<pinref part="SV14" gate="G$1" pin="2"/>
<wire x1="416.56" y1="86.36" x2="431.8" y2="86.36" width="0.1524" layer="91"/>
<wire x1="416.56" y1="106.68" x2="416.56" y2="86.36" width="0.1524" layer="91"/>
<junction x="416.56" y="86.36"/>
</segment>
</net>
<net name="N$57" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPA4"/>
<wire x1="406.4" y1="83.82" x2="419.1" y2="83.82" width="0.1524" layer="91"/>
<pinref part="R37" gate="G$1" pin="1"/>
<pinref part="SV14" gate="G$1" pin="3"/>
<wire x1="419.1" y1="83.82" x2="431.8" y2="83.82" width="0.1524" layer="91"/>
<wire x1="419.1" y1="106.68" x2="419.1" y2="83.82" width="0.1524" layer="91"/>
<junction x="419.1" y="83.82"/>
</segment>
</net>
<net name="N$58" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPA5"/>
<wire x1="406.4" y1="81.28" x2="421.64" y2="81.28" width="0.1524" layer="91"/>
<pinref part="R38" gate="G$1" pin="1"/>
<pinref part="SV15" gate="G$1" pin="1"/>
<wire x1="421.64" y1="81.28" x2="431.8" y2="81.28" width="0.1524" layer="91"/>
<wire x1="429.26" y1="106.68" x2="421.64" y2="106.68" width="0.1524" layer="91"/>
<wire x1="421.64" y1="106.68" x2="421.64" y2="81.28" width="0.1524" layer="91"/>
<junction x="421.64" y="81.28"/>
</segment>
</net>
<net name="N$59" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPA6"/>
<wire x1="406.4" y1="78.74" x2="424.18" y2="78.74" width="0.1524" layer="91"/>
<wire x1="424.18" y1="78.74" x2="431.8" y2="78.74" width="0.1524" layer="91"/>
<wire x1="424.18" y1="104.14" x2="424.18" y2="78.74" width="0.1524" layer="91"/>
<junction x="424.18" y="78.74"/>
<pinref part="R39" gate="G$1" pin="1"/>
<wire x1="424.18" y1="104.14" x2="431.8" y2="104.14" width="0.1524" layer="91"/>
<pinref part="SV15" gate="G$1" pin="2"/>
<wire x1="431.8" y1="104.14" x2="431.8" y2="106.68" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$60" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPA7"/>
<wire x1="406.4" y1="76.2" x2="426.72" y2="76.2" width="0.1524" layer="91"/>
<wire x1="426.72" y1="76.2" x2="431.8" y2="76.2" width="0.1524" layer="91"/>
<wire x1="434.34" y1="101.6" x2="426.72" y2="101.6" width="0.1524" layer="91"/>
<wire x1="426.72" y1="101.6" x2="426.72" y2="76.2" width="0.1524" layer="91"/>
<junction x="426.72" y="76.2"/>
<pinref part="R40" gate="G$1" pin="1"/>
<pinref part="SV15" gate="G$1" pin="3"/>
<wire x1="434.34" y1="101.6" x2="434.34" y2="106.68" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$61" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPB0"/>
<pinref part="LED17" gate="G$1" pin="A"/>
<wire x1="406.4" y1="71.12" x2="431.8" y2="71.12" width="0.1524" layer="91"/>
<wire x1="431.8" y1="71.12" x2="434.34" y2="71.12" width="0.1524" layer="91"/>
<wire x1="431.8" y1="71.12" x2="431.8" y2="48.26" width="0.1524" layer="91"/>
<wire x1="431.8" y1="48.26" x2="454.66" y2="48.26" width="0.1524" layer="91"/>
<junction x="431.8" y="71.12"/>
<pinref part="R41" gate="G$1" pin="2"/>
<wire x1="452.12" y1="40.64" x2="454.66" y2="40.64" width="0.1524" layer="91"/>
<pinref part="Q17" gate="G$1" pin="G"/>
<wire x1="454.66" y1="35.56" x2="454.66" y2="40.64" width="0.1524" layer="91"/>
<wire x1="454.66" y1="48.26" x2="454.66" y2="40.64" width="0.1524" layer="91"/>
<junction x="454.66" y="40.64"/>
</segment>
</net>
<net name="N$62" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPB1"/>
<wire x1="434.34" y1="68.58" x2="429.26" y2="68.58" width="0.1524" layer="91"/>
<pinref part="LED18" gate="G$1" pin="A"/>
<pinref part="R42" gate="G$1" pin="2"/>
<wire x1="429.26" y1="68.58" x2="406.4" y2="68.58" width="0.1524" layer="91"/>
<wire x1="452.12" y1="20.32" x2="454.66" y2="20.32" width="0.1524" layer="91"/>
<pinref part="Q18" gate="G$1" pin="G"/>
<wire x1="454.66" y1="15.24" x2="454.66" y2="20.32" width="0.1524" layer="91"/>
<junction x="454.66" y="20.32"/>
<wire x1="454.66" y1="22.86" x2="454.66" y2="20.32" width="0.1524" layer="91"/>
<wire x1="429.26" y1="68.58" x2="429.26" y2="22.86" width="0.1524" layer="91"/>
<wire x1="429.26" y1="22.86" x2="454.66" y2="22.86" width="0.1524" layer="91"/>
<junction x="429.26" y="68.58"/>
</segment>
</net>
<net name="N$63" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPB2"/>
<wire x1="406.4" y1="66.04" x2="426.72" y2="66.04" width="0.1524" layer="91"/>
<pinref part="LED19" gate="G$1" pin="A"/>
<pinref part="R43" gate="G$1" pin="2"/>
<wire x1="426.72" y1="66.04" x2="434.34" y2="66.04" width="0.1524" layer="91"/>
<wire x1="452.12" y1="0" x2="454.66" y2="0" width="0.1524" layer="91"/>
<pinref part="Q19" gate="G$1" pin="G"/>
<wire x1="454.66" y1="-5.08" x2="454.66" y2="0" width="0.1524" layer="91"/>
<junction x="454.66" y="0"/>
<wire x1="454.66" y1="2.54" x2="454.66" y2="0" width="0.1524" layer="91"/>
<wire x1="426.72" y1="66.04" x2="426.72" y2="2.54" width="0.1524" layer="91"/>
<wire x1="426.72" y1="2.54" x2="454.66" y2="2.54" width="0.1524" layer="91"/>
<junction x="426.72" y="66.04"/>
</segment>
</net>
<net name="N$64" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPB3"/>
<wire x1="434.34" y1="63.5" x2="424.18" y2="63.5" width="0.1524" layer="91"/>
<pinref part="LED20" gate="G$1" pin="A"/>
<pinref part="R44" gate="G$1" pin="2"/>
<wire x1="424.18" y1="63.5" x2="406.4" y2="63.5" width="0.1524" layer="91"/>
<wire x1="452.12" y1="-20.32" x2="454.66" y2="-20.32" width="0.1524" layer="91"/>
<pinref part="Q20" gate="G$1" pin="G"/>
<wire x1="454.66" y1="-25.4" x2="454.66" y2="-20.32" width="0.1524" layer="91"/>
<junction x="454.66" y="-20.32"/>
<wire x1="454.66" y1="-17.78" x2="454.66" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="424.18" y1="63.5" x2="424.18" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="424.18" y1="-17.78" x2="454.66" y2="-17.78" width="0.1524" layer="91"/>
<junction x="424.18" y="63.5"/>
</segment>
</net>
<net name="N$65" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPB4"/>
<wire x1="406.4" y1="60.96" x2="421.64" y2="60.96" width="0.1524" layer="91"/>
<pinref part="LED21" gate="G$1" pin="A"/>
<pinref part="R45" gate="G$1" pin="2"/>
<wire x1="421.64" y1="60.96" x2="434.34" y2="60.96" width="0.1524" layer="91"/>
<wire x1="452.12" y1="-40.64" x2="454.66" y2="-40.64" width="0.1524" layer="91"/>
<pinref part="Q21" gate="G$1" pin="G"/>
<wire x1="454.66" y1="-45.72" x2="454.66" y2="-40.64" width="0.1524" layer="91"/>
<junction x="454.66" y="-40.64"/>
<wire x1="454.66" y1="-38.1" x2="454.66" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="421.64" y1="60.96" x2="421.64" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="421.64" y1="-38.1" x2="454.66" y2="-38.1" width="0.1524" layer="91"/>
<junction x="421.64" y="60.96"/>
</segment>
</net>
<net name="N$66" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPB5"/>
<wire x1="434.34" y1="58.42" x2="419.1" y2="58.42" width="0.1524" layer="91"/>
<pinref part="LED22" gate="G$1" pin="A"/>
<pinref part="R46" gate="G$1" pin="2"/>
<wire x1="419.1" y1="58.42" x2="406.4" y2="58.42" width="0.1524" layer="91"/>
<wire x1="452.12" y1="-58.42" x2="454.66" y2="-58.42" width="0.1524" layer="91"/>
<pinref part="Q22" gate="G$1" pin="G"/>
<wire x1="454.66" y1="-63.5" x2="454.66" y2="-58.42" width="0.1524" layer="91"/>
<junction x="454.66" y="-58.42"/>
<wire x1="454.66" y1="-55.88" x2="454.66" y2="-58.42" width="0.1524" layer="91"/>
<wire x1="419.1" y1="58.42" x2="419.1" y2="-55.88" width="0.1524" layer="91"/>
<wire x1="419.1" y1="-55.88" x2="454.66" y2="-55.88" width="0.1524" layer="91"/>
<junction x="419.1" y="58.42"/>
</segment>
</net>
<net name="N$67" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="GPB6"/>
<wire x1="406.4" y1="55.88" x2="416.56" y2="55.88" width="0.1524" layer="91"/>
<pinref part="LED23" gate="G$1" pin="A"/>
<pinref part="R47" gate="G$1" pin="2"/>
<wire x1="416.56" y1="55.88" x2="434.34" y2="55.88" width="0.1524" layer="91"/>
<wire x1="452.12" y1="-78.74" x2="454.66" y2="-78.74" width="0.1524" layer="91"/>
<pinref part="Q23" gate="G$1" pin="G"/>
<wire x1="454.66" y1="-83.82" x2="454.66" y2="-78.74" width="0.1524" layer="91"/>
<junction x="454.66" y="-78.74"/>
<wire x1="454.66" y1="-76.2" x2="454.66" y2="-78.74" width="0.1524" layer="91"/>
<wire x1="416.56" y1="55.88" x2="416.56" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="416.56" y1="-76.2" x2="454.66" y2="-76.2" width="0.1524" layer="91"/>
<junction x="416.56" y="55.88"/>
</segment>
</net>
<net name="N$68" class="0">
<segment>
<wire x1="434.34" y1="53.34" x2="414.02" y2="53.34" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="GPB7"/>
<pinref part="LED24" gate="G$1" pin="A"/>
<pinref part="R48" gate="G$1" pin="2"/>
<wire x1="414.02" y1="53.34" x2="406.4" y2="53.34" width="0.1524" layer="91"/>
<wire x1="452.12" y1="-101.6" x2="454.66" y2="-101.6" width="0.1524" layer="91"/>
<pinref part="Q24" gate="G$1" pin="G"/>
<wire x1="454.66" y1="-106.68" x2="454.66" y2="-101.6" width="0.1524" layer="91"/>
<junction x="454.66" y="-101.6"/>
<wire x1="454.66" y1="-99.06" x2="454.66" y2="-101.6" width="0.1524" layer="91"/>
<wire x1="414.02" y1="53.34" x2="414.02" y2="-99.06" width="0.1524" layer="91"/>
<wire x1="414.02" y1="-99.06" x2="454.66" y2="-99.06" width="0.1524" layer="91"/>
<junction x="414.02" y="53.34"/>
</segment>
</net>
<net name="N$71" class="0">
<segment>
<pinref part="Q17" gate="G$1" pin="D"/>
<wire x1="459.74" y1="43.18" x2="459.74" y2="48.26" width="0.1524" layer="91"/>
<pinref part="SV18" gate="A" pin="3"/>
<wire x1="492.76" y1="48.26" x2="459.74" y2="48.26" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$72" class="0">
<segment>
<pinref part="Q18" gate="G$1" pin="D"/>
<wire x1="459.74" y1="22.86" x2="459.74" y2="27.94" width="0.1524" layer="91"/>
<wire x1="459.74" y1="27.94" x2="464.82" y2="27.94" width="0.1524" layer="91"/>
<wire x1="464.82" y1="27.94" x2="464.82" y2="45.72" width="0.1524" layer="91"/>
<pinref part="SV18" gate="A" pin="4"/>
<wire x1="492.76" y1="45.72" x2="464.82" y2="45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$73" class="0">
<segment>
<pinref part="Q19" gate="G$1" pin="D"/>
<wire x1="459.74" y1="2.54" x2="459.74" y2="7.62" width="0.1524" layer="91"/>
<pinref part="SV17" gate="G$1" pin="1"/>
<wire x1="487.68" y1="35.56" x2="467.36" y2="35.56" width="0.1524" layer="91"/>
<wire x1="467.36" y1="35.56" x2="467.36" y2="7.62" width="0.1524" layer="91"/>
<wire x1="467.36" y1="7.62" x2="459.74" y2="7.62" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$74" class="0">
<segment>
<pinref part="Q20" gate="G$1" pin="D"/>
<wire x1="459.74" y1="-17.78" x2="459.74" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="459.74" y1="-12.7" x2="469.9" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="469.9" y1="-12.7" x2="469.9" y2="33.02" width="0.1524" layer="91"/>
<pinref part="SV17" gate="G$1" pin="2"/>
<wire x1="469.9" y1="33.02" x2="487.68" y2="33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$75" class="0">
<segment>
<pinref part="Q21" gate="G$1" pin="D"/>
<wire x1="459.74" y1="-38.1" x2="459.74" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="SV17" gate="G$1" pin="3"/>
<wire x1="487.68" y1="30.48" x2="472.44" y2="30.48" width="0.1524" layer="91"/>
<wire x1="472.44" y1="30.48" x2="472.44" y2="-33.02" width="0.1524" layer="91"/>
<wire x1="472.44" y1="-33.02" x2="459.74" y2="-33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$76" class="0">
<segment>
<pinref part="Q22" gate="G$1" pin="D"/>
<wire x1="459.74" y1="-55.88" x2="459.74" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="459.74" y1="-50.8" x2="474.98" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="474.98" y1="-50.8" x2="474.98" y2="20.32" width="0.1524" layer="91"/>
<pinref part="SV16" gate="G$1" pin="1"/>
<wire x1="474.98" y1="20.32" x2="487.68" y2="20.32" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$77" class="0">
<segment>
<pinref part="Q23" gate="G$1" pin="D"/>
<wire x1="459.74" y1="-76.2" x2="459.74" y2="-71.12" width="0.1524" layer="91"/>
<pinref part="SV16" gate="G$1" pin="2"/>
<wire x1="487.68" y1="17.78" x2="477.52" y2="17.78" width="0.1524" layer="91"/>
<wire x1="477.52" y1="17.78" x2="477.52" y2="-71.12" width="0.1524" layer="91"/>
<wire x1="477.52" y1="-71.12" x2="459.74" y2="-71.12" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$78" class="0">
<segment>
<pinref part="Q24" gate="G$1" pin="D"/>
<wire x1="459.74" y1="-99.06" x2="459.74" y2="-93.98" width="0.1524" layer="91"/>
<wire x1="459.74" y1="-93.98" x2="480.06" y2="-93.98" width="0.1524" layer="91"/>
<wire x1="480.06" y1="-93.98" x2="480.06" y2="15.24" width="0.1524" layer="91"/>
<pinref part="SV16" gate="G$1" pin="3"/>
<wire x1="480.06" y1="15.24" x2="487.68" y2="15.24" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$79" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="SCL"/>
<wire x1="170.18" y1="60.96" x2="190.5" y2="60.96" width="0.1524" layer="91"/>
<wire x1="190.5" y1="60.96" x2="195.58" y2="60.96" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="45.72" x2="-38.1" y2="45.72" width="0.1524" layer="91"/>
<wire x1="-38.1" y1="45.72" x2="-22.86" y2="45.72" width="0.1524" layer="91"/>
<wire x1="-22.86" y1="45.72" x2="-22.86" y2="53.34" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="SCL"/>
<wire x1="-22.86" y1="53.34" x2="-5.08" y2="53.34" width="0.1524" layer="91"/>
<pinref part="U1" gate="G$1" pin="A5/SCL"/>
<wire x1="-5.08" y1="53.34" x2="2.54" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-38.1" y1="45.72" x2="-38.1" y2="116.84" width="0.1524" layer="91"/>
<wire x1="-38.1" y1="116.84" x2="170.18" y2="116.84" width="0.1524" layer="91"/>
<junction x="-38.1" y="45.72"/>
<pinref part="IC3" gate="G$1" pin="SCL"/>
<wire x1="170.18" y1="116.84" x2="355.6" y2="116.84" width="0.1524" layer="91"/>
<wire x1="355.6" y1="71.12" x2="375.92" y2="71.12" width="0.1524" layer="91"/>
<wire x1="375.92" y1="71.12" x2="381" y2="71.12" width="0.1524" layer="91"/>
<wire x1="355.6" y1="116.84" x2="355.6" y2="71.12" width="0.1524" layer="91"/>
<wire x1="170.18" y1="60.96" x2="170.18" y2="116.84" width="0.1524" layer="91"/>
<junction x="170.18" y="116.84"/>
<pinref part="R51" gate="G$1" pin="1"/>
<wire x1="190.5" y1="66.04" x2="190.5" y2="60.96" width="0.1524" layer="91"/>
<junction x="190.5" y="60.96"/>
<pinref part="R53" gate="G$1" pin="1"/>
<wire x1="375.92" y1="76.2" x2="375.92" y2="71.12" width="0.1524" layer="91"/>
<junction x="375.92" y="71.12"/>
<pinref part="R49" gate="G$1" pin="1"/>
<wire x1="-5.08" y1="58.42" x2="-5.08" y2="53.34" width="0.1524" layer="91"/>
<junction x="-5.08" y="53.34"/>
</segment>
</net>
<net name="N$38" class="0">
<segment>
<pinref part="SV6" gate="A" pin="4"/>
<pinref part="Q2" gate="G$1" pin="D"/>
<wire x1="81.28" y1="5.08" x2="81.28" y2="10.16" width="0.1524" layer="91"/>
<wire x1="81.28" y1="10.16" x2="86.36" y2="10.16" width="0.1524" layer="91"/>
<wire x1="86.36" y1="10.16" x2="86.36" y2="25.4" width="0.1524" layer="91"/>
<wire x1="114.3" y1="25.4" x2="86.36" y2="25.4" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
<errors>
<approved hash="104,1,2.54,76.2,IC1,VDD,+5V,,,"/>
<approved hash="104,1,2.54,35.56,IC1,VSS,GND,,,"/>
<approved hash="104,1,0,-20.32,IC2,VDD,+5V,,,"/>
<approved hash="104,1,0,-60.96,IC2,VSS,GND,,,"/>
<approved hash="104,1,0,-114.3,IC3,VDD,+5V,,,"/>
<approved hash="104,1,0,-154.94,IC3,VSS,GND,,,"/>
<approved hash="204,1,-58.42,27.94,U1,VIN,,,,"/>
<approved hash="204,1,-58.42,22.86,U1,GND2,,,,"/>
<approved hash="204,1,-58.42,17.78,U1,3V,,,,"/>
</errors>
</schematic>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
</compatibility>
</eagle>
