<root>
<document schema='101' license='1,,*****' title='' description='' target='PIC.18F.18F14K22' >
	<config data='!0,28ff!10,1efe!20,88ff!30,b3!40,c0ff!50,e0ff!60,40ff%8,8%c,0%d,1%e,0%f,0%10,0%11,3%13,3%18,0%19,f%2b,1%2f,1%30,1%32,0%33,0%36,0%37,1%40,1%41,1%4e,1%4f,1%50,1%51,1%5d,1%5e,1%5f,1%60,1%61,1%6e,1' clkspd='16000000' simspd='1' usewdt='0' constif='0' />
	<plugins >
		<dll_dbg_icd enabled='0' >
			<data name='debug' value='1' />
			<data name='userpins' value='0' />
			<data name='speed' value='0' />
			<data name='usev9' value='0' />
			<data name='breaks' value='8' />
			<data name='stacks' value='8' />
			<data name='clkport' value='1' />
			<data name='clkbit' value='6' />
			<data name='dataport' value='1' />
			<data name='databit' value='7' />
			<data name='ghostype' value='0' />
			<data name='monitor' value='1' />
			<data name='ictloop' value='0' />
			<data name='ictrate' value='20000' />
			<data name='ictmask' value='0' />
			<data name='anlpres' value='255' />
			<data name='digmask1' value='-1' />
			<data name='digmask2' value='-1' />
		</dll_dbg_icd>
		<dll_models enabled='1' />
		<dll_upgrader enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug >
		<watch expr='cur' />
		<watch expr='Termistor' />
	</debug>
	<ghost >
		<FK2 >
			<data name='FK2D0' port='4294967295' pin='4294967295' />
			<data name='FK2D1' port='4294967295' pin='4294967295' />
			<data name='FK2D2' port='4294967295' pin='4294967295' />
			<data name='FK2D3' port='4294967295' pin='4294967295' />
			<data name='FK2D4' port='4294967295' pin='4294967295' />
			<data name='FK2D5' port='4294967295' pin='4294967295' />
			<data name='FK2D6' port='4294967295' pin='4294967295' />
			<data name='FK2D7' port='4294967295' pin='4294967295' />
			<data name='FK2D8' port='4294967295' pin='4294967295' />
			<data name='FK2D9' port='4294967295' pin='4294967295' />
			<data name='FK2D10' port='4294967295' pin='4294967295' />
			<data name='FK2D11' port='4294967295' pin='4294967295' />
			<data name='FK2D12' port='4294967295' pin='4294967295' />
			<data name='FK2D13' port='4294967295' pin='4294967295' />
			<data name='FK2D14' port='4294967295' pin='4294967295' />
			<data name='FK2D15' port='4294967295' pin='4294967295' />
			<data name='FK2A0' port='4294967295' pin='4294967295' />
			<data name='FK2A1' port='4294967295' pin='4294967295' />
			<data name='FK2A2' port='4294967295' pin='4294967295' />
			<data name='FK2A3' port='4294967295' pin='4294967295' />
			<data name='FK2A4' port='4294967295' pin='4294967295' />
			<data name='FK2A5' port='4294967295' pin='4294967295' />
		</FK2>
		<ICD >
			<data name='AnalogPrescaleValue' value='19' />
			<data name='DigitalSampleRate' value='100000' />
			<data name='BreakpointCount' value='8' />
			<data name='CallStackDepthCount' value='8' />
			<data name='ClockPort' value='1' />
			<data name='ClockPin' value='6' />
			<data name='DataPort' value='1' />
			<data name='DataPin' value='7' />
			<data name='UseDefaultPins' value='1' />
			<data name='WrapEnabled' value='1' />
			<data name='CommsDelayOverridden' value='0' />
			<data name='CommsDelay' value='11' />
			<data name='CalculatedCommsDelay' value='11' />
		</ICD>
		<pins >
			<digital A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
			<analog A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
		</pins>
	</ghost>
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='d3369289-b274-4571-8602-7c51c398d727' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='0' iconpath='' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
			<resources />
			<properties >
				<property name='100C Thermistor Value' target='Thermistor1::P100' typeid='21' hidden='0' locked='0' info='Value in Ohms of the Thermistor at 100 deg C' />
				<property name='ADC Bit Resolution' target='Thermistor1::ADC_BITS' typeid='21' hidden='0' locked='0' info='' />
				<property name='Scale divisions' target='Thermistor1::scale_divisions' typeid='21' hidden='0' locked='0' info='Number of numbered divisions shown on the thermometer scale.' />
			</properties>
			<values >
				<value target='Thermistor1::P100' data='677' />
				<value target='Thermistor1::ADC_BITS' data='8' />
				<value target='Thermistor1::scale_divisions' data='7' />
			</values>
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='cur' type='s16' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='false' type='b1' description='' isconst='1' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Termistor' type='s16' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='tertek' type='s16' description='' isconst='0' isinit='0' usrinit='0' setinit='' />
				</variable>
					<def class_type='variable' name='true' type='b1' description='' isconst='1' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='Main' description='' >
						<return name='Return' type='v0' description='' isconst='0' isinit='0' usrinit='' setinit='' />
						<command class_type='native' title='C Code' ccode='OSCCON=0b1110000;' cmdcolor='1973790' cmdcolor_sec='16777193' language='C' />
						<command class_type='call' title='Komponens makró hívása' cmdcolor='2960685' cmdcolor_sec='11773618' component='lcd_I2C1' macro='Start' />
						<command class_type='call' title='Call Component Macro' cmdcolor='2960685' cmdcolor_sec='11773618' component='lcd_I2C1' macro='Clear' />
						<command class_type='call' title='Call Component Macro' cmdcolor='2960685' cmdcolor_sec='11773618' component='lcd_I2C1' macro='Cursor' >
							<argument exp='0' />
						</command>
						<command class_type='call' title='Komponens makró hívása' cmdcolor='2960685' cmdcolor_sec='11773618' component='lcd_I2C1' macro='PrintString' >
							<argument exp='&quot;Szoba hom.: &quot;' />
						</command>
						<command class_type='calculation' title='Calculation' cmdcolor='1973790' cmdcolor_sec='15335423' >
							<exp exp='cur = 12' />
						</command>
							<argument exp='cur' />
						</command>
						<command class_type='loop' title='Ciklus' cmdcolor='1973790' cmdcolor_sec='13421754' type='0' exp='1' >
							<flowline >
								<command class_type='call' title='Call Component Macro' cmdcolor='2960685' cmdcolor_sec='11773618' component='Thermistor1' macro='GetRealTemperature' >
									<return exp='Termistor' />
								</command>
								<command class_type='decision' title='Decision' cmdcolor='1973790' cmdcolor_sec='13421754' exp='Termistor &gt; 0 AND tertek &lt;&gt; Termistor' swap='0' >
									<flowline >
											<argument exp='11' />
										</command>
											<argument exp='&quot; &quot;' />
										</command>
										</command>
										<command class_type='call' title='Call Component Macro' cmdcolor='2960685' cmdcolor_sec='11773618' component='lcd_I2C1' macro='PrintString' >
										</command>
									</flowline>
									<flowline >
										<command class_type='decision' title='Decision' cmdcolor='1973790' cmdcolor_sec='13421754' exp='Termistor &lt; 0 AND tertek &lt;&gt; Termistor' swap='0' >
											<flowline >
													<exp exp='cur = 11' />
												</command>
												</command>
												</command>
											</flowline>
											<flowline />
										</command>
									</flowline>
								</command>
								</command>
								<command class_type='call' title='Call Component Macro' cmdcolor='2960685' cmdcolor_sec='11773618' component='lcd_I2C1' macro='PrintNumber' >
									<argument exp='Termistor' />
								</command>
									<exp exp='tertek = Termistor' />
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='bcd6a955-12c6-4ed4-a22f-f16eb62e0762' vmin='0' vmaj='2' codename='lcd_I2C1' x='60' y='0' z='3.575' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='1' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='Address' data='39' />
					<value target='cal_i2c1::CHANNEL' data='001' />
					<value target='cal_i2c1::BAUD_LIST' data='002' />
					<value target='cal_i2c1::BAUD' data='400000' />
					<value target='cal_i2c1::StopDel' data='0' />
					<value target='cal_i2c1::SDA' data='$PORTB.4' />
					<value target='cal_i2c1::SDAPins' data='000' />
					<value target='cal_i2c1::SCL' data='$PORTB.6' />
					<value target='cal_i2c1::SCLPins' data='000' />
					<value target='Rows' data='002' />
					<value target='Columns' data='016' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='93ab1895-66cf-4fd8-a04f-79f09acc19e6' vmin='1' vmaj='1' codename='Thermistor1' x='-40' y='0' z='0.55' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='1' poslock='1' >
				<resources />
				<properties />
				<values >
					<value target='CHANNEL' data='0' />
					<value target='Thermistor_base1::Wiring' data='000' />
					<value target='ADC_BITS' data='8' />
					<value target='RESISTOR' data='10000' />
					<value target='M25' data='129287' />
					<value target='P0' data='32554' />
					<value target='P25' data='10000' />
					<value target='P50' data='3605' />
					<value target='P75' data='1481' />
					<value target='P100' data='677' />
					<value target='P125' data='338' />
					<value target='label' data='Temperature' />
					<value target='min_temp' data='-25.000000' />
					<value target='max_temp' data='30.000000' />
					<value target='scale_divisions' data='7' />
					<value target='temperature' data='30.000000' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<keymap />
	<panel2d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='7292207' img='' style='0' />
		<camera xe='18.9364' ye='-3.16699' ze='227.56' xt='18.9364' yt='-3.16699' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='8409120' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='25' />
		<camera xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey0 xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey1 xe='-3.67394e-14' ye='0' ze='-300' xt='0' yt='0' zt='0' xquat='0' yquat='1' zquat='0' wquat='6.12323e-17' />
		<camerakey2 xe='0' ye='-300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.707107' yquat='0' zquat='0' wquat='0.707107' />
		<camerakey3 xe='-3.67394e-14' ye='300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-4.32978e-17' yquat='0.707107' zquat='0.707107' wquat='4.32978e-17' />
		<camerakey4 xe='-300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='0.5' zquat='0.5' wquat='0.5' />
		<camerakey5 xe='300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='-0.5' zquat='-0.5' wquat='0.5' />
		<camerakey6 xe='-173.205' ye='-173.205' ze='173.205' xt='0' yt='0' zt='0' xquat='-0.424708' yquat='0.17592' zquat='0.339851' wquat='0.820473' />
	</panel3d>
	<layout >
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAAEwYAAPkBAAA' zoom='75' scrollx='0' scrolly='894' flags='0' />
	</layout>
</document>
</root>
