<root>
<document schema='101' license='1,,*****' title='' description='' target='PIC.12F.12F683' >
	<config data='!0,3bc4%0,4%3,0%4,0%5,0%6,1%7,1%8,3%a,0%b,1' clkspd='4000000' simspd='2' usewdt='0' constif='0' />
	<plugins >
		<dll_dbg_icd enabled='0' >
			<data name='debug' value='1' />
			<data name='userpins' value='0' />
			<data name='speed' value='0' />
			<data name='usev9' value='0' />
			<data name='breaks' value='8' />
			<data name='stacks' value='8' />
			<data name='clkport' value='1' />
			<data name='clkbit' value='6' />
			<data name='dataport' value='1' />
			<data name='databit' value='7' />
			<data name='ghostype' value='0' />
			<data name='monitor' value='1' />
			<data name='ictloop' value='0' />
			<data name='ictrate' value='20000' />
			<data name='ictmask' value='0' />
			<data name='anlpres' value='19' />
			<data name='digmask1' value='-1' />
			<data name='digmask2' value='-1' />
		</dll_dbg_icd>
		<dll_models enabled='1' />
		<dll_upgrader enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug />
	<ghost >
		<FK2 >
			<data name='FK2D0' port='4294967295' pin='4294967295' />
			<data name='FK2D1' port='4294967295' pin='4294967295' />
			<data name='FK2D2' port='4294967295' pin='4294967295' />
			<data name='FK2D3' port='4294967295' pin='4294967295' />
			<data name='FK2D4' port='4294967295' pin='4294967295' />
			<data name='FK2D5' port='4294967295' pin='4294967295' />
			<data name='FK2D6' port='4294967295' pin='4294967295' />
			<data name='FK2D7' port='4294967295' pin='4294967295' />
			<data name='FK2D8' port='4294967295' pin='4294967295' />
			<data name='FK2D9' port='4294967295' pin='4294967295' />
			<data name='FK2D10' port='4294967295' pin='4294967295' />
			<data name='FK2D11' port='4294967295' pin='4294967295' />
			<data name='FK2D12' port='4294967295' pin='4294967295' />
			<data name='FK2D13' port='4294967295' pin='4294967295' />
			<data name='FK2D14' port='4294967295' pin='4294967295' />
			<data name='FK2D15' port='4294967295' pin='4294967295' />
			<data name='FK2A0' port='4294967295' pin='4294967295' />
			<data name='FK2A1' port='4294967295' pin='4294967295' />
			<data name='FK2A2' port='4294967295' pin='4294967295' />
			<data name='FK2A3' port='4294967295' pin='4294967295' />
			<data name='FK2A4' port='4294967295' pin='4294967295' />
			<data name='FK2A5' port='4294967295' pin='4294967295' />
		</FK2>
		<ICD >
			<data name='AnalogPrescaleValue' value='19' />
			<data name='DigitalSampleRate' value='100000' />
			<data name='BreakpointCount' value='8' />
			<data name='CallStackDepthCount' value='8' />
			<data name='ClockPort' value='0' />
			<data name='ClockPin' value='1' />
			<data name='DataPort' value='0' />
			<data name='DataPin' value='0' />
			<data name='UseDefaultPins' value='1' />
			<data name='WrapEnabled' value='1' />
			<data name='CommsDelayOverridden' value='0' />
			<data name='CommsDelay' value='42' />
			<data name='CalculatedCommsDelay' value='42' />
		</ICD>
		<pins >
			<digital A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
			<analog A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
		</pins>
	</ghost>
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='a2f30edc-a9e4-4b22-80dd-1e838507ac4e' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='1' iconpath='' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='false' type='b1' description='' isconst='1' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='Megsz' type='s32' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='true' type='b1' description='' isconst='1' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='Megszakitas' description='' >
						<return name='Return' type='v0' description='' isconst='0' isinit='0' usrinit='' setinit='' />
						<command class_type='calculation' title='Calculation' cmdcolor='16760919' cmdcolor_sec='16760832' >
							<exp exp='Megsz = Megsz + 1' />
						</command>
						<command class_type='decision' title=' 5 perc' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Megsz = 30000' swap='0' >
							<flowline >
									<exp exp='Megsz = 0' />
								</command>
							</flowline>
							<flowline />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Main' description='' >
						<command class_type='interrupt' title='Interrupt' cmdcolor='17151' cmdcolor_sec='355583' enable='1' name='TMR2' call='Megszakitas' >
							<settings timer='1' prescale='4' postscale='10' rollover='250' bitcount='-1' trigger='3' maskhi='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' masklo='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' >
								<option value='1' />
								<option value='9' />
								<option value='250' />
								<option value='-1' />
							</settings>
						</command>
						<command class_type='loop' title='Loop' cmdcolor='12615680' cmdcolor_sec='15376912' type='0' exp='1' >
							<flowline >
								<command class_type='decision' title='2 perc' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Megsz &gt; 12000' swap='0' >
									<flowline >
										<command class_type='call' title='Call Component Macro' cmdcolor='1879295' cmdcolor_sec='5751039' component='lamp_les1' macro='TurnOff' />
									</flowline>
									<flowline >
										<command class_type='call' title='Call Component Macro' cmdcolor='1879295' cmdcolor_sec='5751039' component='lamp_les1' macro='TurnOn' />
									</flowline>
								</command>
								<command class_type='decision' title='1 perc' cmdcolor='12615680' cmdcolor_sec='15376912' exp='Megsz &gt; 499' swap='0' >
									<flowline >
										<command class_type='call' title='Call Component Macro' cmdcolor='1879295' cmdcolor_sec='5751039' component='lamp_les2' macro='TurnOff' />
									</flowline>
									<flowline >
										<command class_type='call' title='Call Component Macro' cmdcolor='1879295' cmdcolor_sec='5751039' component='lamp_les2' macro='TurnOn' />
									</flowline>
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='2c813cfa-9563-4da8-85df-b4355a3c5108' vmin='3' vmaj='1' codename='lamp_les1' x='-70' y='30' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.0' />
					<value target='polarity' data='001' />
					<value target='on_color' data='255' />
					<value target='show_label' data='002' />
					<value target='label_property' data='pin' />
					<value target='label_color' data='16777215' />
					<value target='label_scale' data='1.000000' />
					<value target='label_auto_scale' data='0' />
					<value target='label_position' data='003' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='2c813cfa-9563-4da8-85df-b4355a3c5108' vmin='3' vmaj='1' codename='lamp_les2' x='-30' y='30' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.1' />
					<value target='on_color' data='65280' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<keymap />
	<panel2d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='7292207' img='' style='0' />
		<camera xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='8409120' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='0' />
		<camerakey0 xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey1 xe='-3.67394e-14' ye='0' ze='-300' xt='0' yt='0' zt='0' xquat='0' yquat='1' zquat='0' wquat='6.12323e-17' />
		<camerakey2 xe='0' ye='-300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.707107' yquat='0' zquat='0' wquat='0.707107' />
		<camerakey3 xe='-3.67394e-14' ye='300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-4.32978e-17' yquat='0.707107' zquat='0.707107' wquat='4.32978e-17' />
		<camerakey4 xe='-300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='0.5' zquat='0.5' wquat='0.5' />
		<camerakey5 xe='300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='-0.5' zquat='-0.5' wquat='0.5' />
		<camerakey6 xe='-173.205' ye='-173.205' ze='173.205' xt='0' yt='0' zt='0' xquat='-0.424708' yquat='0.17592' zquat='0.339851' wquat='0.820473' />
	</panel3d>
	<layout >
		<view type='0' name='Megszakitas' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAA8AQAAIICAAA' zoom='75' scrollx='0' scrolly='0' flags='0' />
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAA8AQAAIICAAA' zoom='75' scrollx='0' scrolly='240' flags='0' />
	</layout>
</document>
</root>
