<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="yes" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="yes" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="yes" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="yes" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="yes" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="yes" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="yes" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="yes" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="yes" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="yes" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="yes" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="yes" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="yes" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="6" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="6" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="5" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="6" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="11" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="NOVAL_PCB">
<description>TUBE SOCKET, NOVAL PCB</description>
<circle x="0" y="0" radius="7.62" width="0.127" layer="21"/>
<circle x="0" y="0" radius="7.62" width="0.127" layer="22"/>
<pad name="1" x="6.2992" y="-8.4836" drill="1.9304" diameter="3.81"/>
<pad name="2" x="9.9822" y="-3.2512" drill="1.9304" diameter="3.81"/>
<pad name="3" x="9.9822" y="3.2512" drill="1.9304" diameter="3.81"/>
<pad name="4" x="6.2992" y="8.4836" drill="1.9304" diameter="3.81"/>
<pad name="5" x="0" y="10.4902" drill="1.9304" diameter="3.81"/>
<pad name="6" x="-6.2992" y="8.4836" drill="1.9304" diameter="3.81"/>
<pad name="7" x="-9.9822" y="3.2512" drill="1.9304" diameter="3.81"/>
<pad name="8" x="-9.9822" y="-3.2512" drill="1.9304" diameter="3.81"/>
<pad name="9" x="-6.2992" y="-8.4836" drill="1.9304" diameter="3.81"/>
<text x="2.54" y="-10.16" size="1.27" layer="21" font="vector">1</text>
<text x="-3.81" y="-10.16" size="1.27" layer="21" font="vector">9</text>
<text x="-2.54" y="-12.7" size="1.27" layer="25" font="vector">&gt;NAME</text>
<text x="-2.54" y="-15.24" size="1.27" layer="27" font="vector">&gt;VALUE</text>
</package>
<package name="OCTAL_BOTTOM">
<description>TUBE SOCKET, OCTAL, PCB, BOTTOM SIDE</description>
<wire x1="0.9854" y1="-2.4935" x2="1.3419" y2="-3.3106" width="0.8128" layer="21"/>
<circle x="0" y="0" radius="10.16" width="0.6096" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.6096" layer="21"/>
<pad name="1" x="0" y="-12.7" drill="2.54" diameter="6.4516"/>
<pad name="2" x="-8.89" y="-8.89" drill="2.54" diameter="6.4516"/>
<pad name="3" x="-12.7" y="0" drill="2.54" diameter="6.4516"/>
<pad name="4" x="-8.89" y="8.89" drill="2.54" diameter="6.4516"/>
<pad name="5" x="0" y="12.7" drill="2.54" diameter="6.4516"/>
<pad name="6" x="8.89" y="8.89" drill="2.54" diameter="6.4516"/>
<pad name="7" x="12.7" y="0" drill="2.54" diameter="6.4516"/>
<pad name="8" x="8.89" y="-8.89" drill="2.54" diameter="6.4516"/>
<text x="-0.4567" y="-8.6844" size="1.778" layer="21">1</text>
<text x="-5.8307" y="-6.395" size="1.778" layer="21">2</text>
<text x="-8.5584" y="-0.6888" size="1.778" layer="21">3</text>
<text x="-6.3313" y="4.7669" size="1.778" layer="21">4</text>
<text x="-0.6882" y="6.9135" size="1.778" layer="21">5</text>
<text x="4.9548" y="4.7492" size="1.778" layer="21">6</text>
<text x="7.62" y="-0.6888" size="1.778" layer="21">7</text>
<text x="4.7671" y="-6.4576" size="1.778" layer="21">8</text>
<text x="5.08" y="-16.51" size="1.778" layer="21">&gt;NAME</text>
<text x="5.08" y="-19.05" size="1.778" layer="21">&gt;VALUE</text>
</package>
<package name="MINI7_PCB">
<description>TUBE SOCKET, 7-PIN MINI, .75 CIRCLE</description>
<pad name="1" x="6.731" y="-6.731" drill="1.9304" diameter="3.81"/>
<pad name="2" x="9.525" y="0" drill="1.9304" diameter="3.81"/>
<pad name="3" x="6.731" y="6.731" drill="1.9304" diameter="3.81"/>
<pad name="4" x="0" y="9.525" drill="1.9304" diameter="3.81"/>
<pad name="5" x="-6.731" y="6.731" drill="1.9304" diameter="3.81"/>
<pad name="6" x="-9.525" y="0" drill="1.9304" diameter="3.81"/>
<pad name="7" x="-6.731" y="-6.731" drill="1.9304" diameter="3.81"/>
<text x="2.54" y="-10.16" size="1.27" layer="21">1</text>
<text x="-3.81" y="-10.16" size="1.27" layer="21">7</text>
<text x="-2.54" y="-12.7" size="1.778" layer="25">&gt;NAME</text>
<text x="-2.54" y="-15.24" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="SUBMINI5">
<description>Subminiature tube, 5 pin, press seal</description>
<wire x1="1.27" y1="0" x2="7.62" y2="0" width="0.6096" layer="21"/>
<wire x1="1.27" y1="1.905" x2="7.62" y2="1.27" width="0.6096" layer="21"/>
<wire x1="1.27" y1="3.81" x2="7.62" y2="2.54" width="0.6096" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="7.62" y2="-1.27" width="0.6096" layer="21"/>
<wire x1="1.27" y1="-3.81" x2="7.62" y2="-2.54" width="0.6096" layer="21"/>
<wire x1="9.525" y1="3.81" x2="10.795" y2="3.175" width="0.254" layer="21"/>
<wire x1="10.795" y1="3.175" x2="12.065" y2="3.175" width="0.254" layer="21"/>
<wire x1="12.065" y1="3.175" x2="12.7" y2="3.81" width="0.254" layer="21"/>
<wire x1="12.7" y1="3.81" x2="38.1" y2="3.81" width="0.254" layer="21"/>
<wire x1="9.525" y1="3.81" x2="7.62" y2="3.81" width="0.254" layer="21"/>
<wire x1="7.62" y1="3.81" x2="7.62" y2="2.54" width="0.254" layer="21"/>
<wire x1="7.62" y1="2.54" x2="7.62" y2="1.27" width="0.254" layer="21"/>
<wire x1="7.62" y1="1.27" x2="7.62" y2="-1.27" width="0.254" layer="21"/>
<wire x1="7.62" y1="-1.27" x2="7.62" y2="-2.54" width="0.254" layer="21"/>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="-4.445" width="0.254" layer="21"/>
<wire x1="7.62" y1="-4.445" x2="9.525" y2="-4.445" width="0.254" layer="21"/>
<wire x1="9.525" y1="-4.445" x2="10.795" y2="-3.81" width="0.254" layer="21"/>
<wire x1="10.795" y1="-3.81" x2="12.065" y2="-3.81" width="0.254" layer="21"/>
<wire x1="12.065" y1="-3.81" x2="12.7" y2="-4.445" width="0.254" layer="21"/>
<wire x1="12.7" y1="-4.445" x2="38.1" y2="-4.445" width="0.254" layer="21"/>
<wire x1="38.1" y1="-4.445" x2="38.735" y2="-1.27" width="0.254" layer="21"/>
<wire x1="38.735" y1="-1.27" x2="40.005" y2="0" width="0.254" layer="21"/>
<wire x1="40.005" y1="0" x2="38.735" y2="0.635" width="0.254" layer="21"/>
<wire x1="38.735" y1="0.635" x2="38.1" y2="3.81" width="0.254" layer="21"/>
<circle x="11.43" y="-2.54" radius="0.635" width="0.254" layer="21"/>
<pad name="1" x="0" y="-3.81" drill="0.8128" shape="long"/>
<pad name="2" x="0" y="-1.905" drill="0.8128" shape="long"/>
<pad name="3" x="0" y="0" drill="0.8128" shape="long"/>
<pad name="4" x="0" y="1.905" drill="0.8128" shape="long"/>
<pad name="5" x="0" y="3.81" drill="0.8128" shape="long"/>
<text x="19.685" y="4.445" size="1.778" layer="25">&gt;NAME</text>
<text x="20.955" y="-0.635" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="7.62" y1="-4.445" x2="9.525" y2="3.81" layer="21"/>
</package>
<package name="OCTAL">
<description>OCTAL TUBE SOCKET, TOP MOUNT</description>
<pad name="8" x="0" y="-12.7" drill="2.54" diameter="6.4516"/>
<pad name="7" x="-8.89" y="-8.89" drill="2.54" diameter="6.4516"/>
<pad name="6" x="-12.7" y="0" drill="2.54" diameter="6.4516"/>
<pad name="5" x="-8.89" y="8.89" drill="2.54" diameter="6.4516"/>
<pad name="4" x="0" y="12.7" drill="2.54" diameter="6.4516"/>
<pad name="3" x="8.89" y="8.89" drill="2.54" diameter="6.4516"/>
<pad name="2" x="12.7" y="0" drill="2.54" diameter="6.4516"/>
<pad name="1" x="8.89" y="-8.89" drill="2.54" diameter="6.4516"/>
<text x="4.1153" y="-6.3984" size="1.778" layer="21">1</text>
<text x="7.1233" y="-0.807" size="1.778" layer="21">2</text>
<text x="5.1576" y="3.6292" size="1.778" layer="21">3</text>
<text x="-0.4893" y="6.5449" size="1.778" layer="21">4</text>
<text x="-6.0222" y="4.1195" size="1.778" layer="21">5</text>
<text x="-8.2532" y="-0.5848" size="1.778" layer="21">6</text>
<text x="-6.096" y="-6.0228" size="1.778" layer="21">7</text>
<text x="-0.5669" y="-8.2356" size="1.778" layer="21">8</text>
<text x="6.604" y="-15.748" size="1.778" layer="21">&gt;NAME</text>
<text x="-3.556" y="3.81" size="1.27" layer="21">&gt;VALUE</text>
</package>
<package name="OCTAL_CHASSIS_ON_PCB">
<description>OCTAL TUBE SOCKET, BOTTOM MOUNTED ON PCB</description>
<wire x1="-22.225" y1="3.175" x2="-13.335" y2="12.065" width="0.127" layer="22"/>
<wire x1="-13.97" y1="-11.43" x2="-22.86" y2="-2.54" width="0.127" layer="22"/>
<wire x1="22.225" y1="-2.54" x2="13.335" y2="-12.065" width="0.127" layer="22"/>
<wire x1="13.335" y1="12.065" x2="22.225" y2="2.54" width="0.127" layer="22"/>
<wire x1="-22.86" y1="-2.54" x2="-22.225" y2="3.175" width="0.127" layer="22" curve="-78.578814"/>
<wire x1="21.59" y1="-3.175" x2="22.225" y2="2.54" width="0.127" layer="22" curve="78.578814"/>
<wire x1="-13.335" y1="12.065" x2="13.335" y2="12.065" width="0.127" layer="22" curve="-95.72481"/>
<wire x1="-13.97" y1="-11.43" x2="13.335" y2="-12.065" width="0.127" layer="22" curve="97.064589"/>
<wire x1="-24.13" y1="2.54" x2="-24.13" y2="-2.54" width="2.54" layer="43" style="shortdash"/>
<wire x1="-24.13" y1="-2.54" x2="-7.62" y2="-19.05" width="2.54" layer="43"/>
<wire x1="-7.62" y1="-19.05" x2="7.62" y2="-19.05" width="2.54" layer="43"/>
<wire x1="7.62" y1="-19.05" x2="24.13" y2="-2.54" width="2.54" layer="43"/>
<wire x1="24.13" y1="-2.54" x2="24.13" y2="2.54" width="2.54" layer="43"/>
<wire x1="24.13" y1="2.54" x2="7.62" y2="19.05" width="2.54" layer="43"/>
<wire x1="7.62" y1="19.05" x2="-7.62" y2="19.05" width="2.54" layer="43"/>
<wire x1="-7.62" y1="19.05" x2="-24.13" y2="2.54" width="2.54" layer="43"/>
<wire x1="-22.86" y1="2.54" x2="-22.86" y2="-2.54" width="2.54" layer="40"/>
<wire x1="-22.86" y1="-2.54" x2="-3.81" y2="-17.78" width="2.54" layer="40"/>
<wire x1="-3.81" y1="-17.78" x2="3.81" y2="-17.78" width="2.54" layer="40"/>
<wire x1="3.81" y1="-17.78" x2="22.86" y2="-2.54" width="2.54" layer="40"/>
<wire x1="22.86" y1="-2.54" x2="22.86" y2="1.27" width="2.54" layer="40"/>
<wire x1="22.86" y1="1.27" x2="5.08" y2="17.78" width="2.54" layer="40"/>
<wire x1="5.08" y1="17.78" x2="-5.08" y2="17.78" width="2.54" layer="40"/>
<wire x1="-5.08" y1="17.78" x2="-22.86" y2="2.54" width="2.54" layer="40"/>
<circle x="0" y="0" radius="3.175" width="0.127" layer="52"/>
<circle x="9.525" y="4.445" radius="1.27" width="0.127" layer="52"/>
<circle x="9.525" y="-3.81" radius="1.27" width="0.127" layer="52"/>
<circle x="-9.525" y="-3.81" radius="1.27" width="0.127" layer="52"/>
<circle x="-9.525" y="4.445" radius="1.27" width="0.127" layer="52"/>
<circle x="-4.445" y="9.525" radius="1.27" width="0.127" layer="52"/>
<circle x="-4.445" y="-9.525" radius="1.27" width="0.127" layer="52"/>
<circle x="4.445" y="-9.525" radius="1.27" width="0.127" layer="52"/>
<circle x="4.445" y="9.525" radius="1.27" width="0.127" layer="52"/>
<circle x="0" y="0" radius="15.24" width="0.127" layer="20"/>
<pad name="8" x="17.78" y="13.97" drill="1.4224" diameter="3.81"/>
<pad name="7" x="7.62" y="21.59" drill="1.4224" diameter="3.81"/>
<pad name="6" x="-7.62" y="21.59" drill="1.4224" diameter="3.81"/>
<pad name="5" x="-17.78" y="13.97" drill="1.4224" diameter="3.81"/>
<pad name="4" x="-17.78" y="-13.97" drill="1.4224" diameter="3.81"/>
<pad name="3" x="-7.62" y="-21.59" drill="1.4224" diameter="3.81"/>
<pad name="2" x="7.62" y="-21.59" drill="1.4224" diameter="3.81"/>
<pad name="1" x="17.78" y="-13.97" drill="1.4224" diameter="3.81"/>
<text x="21.59" y="-12.7" size="1.778" layer="21">1</text>
<text x="11.43" y="-20.32" size="1.778" layer="21">2</text>
<text x="-10.795" y="-20.32" size="1.778" layer="21">3</text>
<text x="-20.32" y="-12.065" size="1.778" layer="21">4</text>
<text x="-20.32" y="10.16" size="1.778" layer="21">5</text>
<text x="-11.43" y="18.415" size="1.778" layer="21">6</text>
<text x="10.16" y="18.415" size="1.778" layer="21">7</text>
<text x="20.32" y="9.525" size="1.778" layer="21">8</text>
<text x="26.67" y="3.81" size="1.778" layer="25" rot="R270">&gt;NAME</text>
<text x="3.175" y="5.08" size="1.27" layer="27" rot="R180">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.635" x2="5.08" y2="0.635" layer="52"/>
<hole x="-19.05" y="0" drill="3.81"/>
<hole x="19.05" y="0" drill="3.81"/>
</package>
<package name="OCTAL_CHASSIS_PCB2">
<pad name="8" x="19.05" y="21.59" drill="1.4224" diameter="3.81"/>
<pad name="7" x="10.16" y="26.67" drill="1.4224" diameter="3.81"/>
<pad name="6" x="-10.16" y="26.67" drill="1.4224" diameter="3.81"/>
<pad name="5" x="-19.05" y="21.59" drill="1.4224" diameter="3.81"/>
<pad name="4" x="-19.05" y="-21.59" drill="1.4224" diameter="3.81"/>
<pad name="3" x="-10.16" y="-26.67" drill="1.4224" diameter="3.81"/>
<pad name="2" x="10.16" y="-26.67" drill="1.4224" diameter="3.81"/>
<pad name="1" x="19.05" y="-21.59" drill="1.4224" diameter="3.81"/>
<text x="19.05" y="-17.78" size="1.778" layer="21">1</text>
<text x="10.16" y="-22.86" size="1.778" layer="21">2</text>
<text x="-9.525" y="-22.86" size="1.778" layer="21">3</text>
<text x="-17.78" y="-17.145" size="1.778" layer="21">4</text>
<text x="-16.51" y="15.24" size="1.778" layer="21">5</text>
<text x="-8.89" y="20.955" size="1.778" layer="21">6</text>
<text x="8.89" y="20.955" size="1.778" layer="21">7</text>
<text x="19.05" y="15.875" size="1.778" layer="21">8</text>
<text x="1.905" y="5.08" size="1.27" layer="27" rot="R180">&gt;VALUE</text>
</package>
<package name="OCTAL_ONPCB_4P">
<description>OCTAL chassis-mount SOCKET, THRU PCB, ONLY 4 PINS
FOR RECTIFIERS (connected with wires)</description>
<wire x1="-22.86" y1="2.54" x2="-22.86" y2="-2.54" width="2.54" layer="39"/>
<wire x1="-22.86" y1="-2.54" x2="-3.81" y2="-17.78" width="2.54" layer="39"/>
<wire x1="-3.81" y1="-17.78" x2="3.81" y2="-17.78" width="2.54" layer="39"/>
<wire x1="3.81" y1="-17.78" x2="22.86" y2="-2.54" width="2.54" layer="39"/>
<wire x1="22.86" y1="-2.54" x2="22.86" y2="1.27" width="2.54" layer="39"/>
<wire x1="22.86" y1="1.27" x2="5.08" y2="17.78" width="2.54" layer="39"/>
<wire x1="5.08" y1="17.78" x2="-5.08" y2="17.78" width="2.54" layer="39"/>
<wire x1="-5.08" y1="17.78" x2="-22.86" y2="2.54" width="2.54" layer="39"/>
<pad name="6" x="-12.7" y="19.05" drill="1.4224" diameter="3.81"/>
<pad name="4" x="-19.05" y="-12.7" drill="1.4224" diameter="3.81"/>
<pad name="2" x="13.97" y="-17.78" drill="1.4224" diameter="3.81"/>
<text x="17.78" y="-19.05" size="1.778" layer="21">2</text>
<text x="-22.86" y="-12.065" size="1.778" layer="21">4</text>
<text x="-17.78" y="15.875" size="1.778" layer="21">6</text>
<text x="20.32" y="10.795" size="1.778" layer="21">8</text>
<text x="3.175" y="6.35" size="1.27" layer="27" rot="R180">&gt;VALUE</text>
</package>
<package name="TRIODE_703A">
<description>triode, 703a ufo (using Mil-Max socket pins)</description>
<circle x="6.35" y="0" radius="3.175" width="0" layer="40"/>
<circle x="12.7" y="0" radius="3.175" width="0" layer="40"/>
<circle x="-4.7625" y="3.175" radius="3.175" width="0" layer="40"/>
<circle x="-4.7625" y="-3.175" radius="3.175" width="0" layer="40"/>
<pad name="F1" x="6.35" y="0" drill="1.778" diameter="3.81"/>
<pad name="F2" x="12.7" y="0" drill="1.778" diameter="3.81"/>
<pad name="G" x="-4.7625" y="-3.175" drill="1.778" diameter="3.81"/>
<pad name="P" x="-4.7625" y="3.175" drill="1.778" diameter="3.81"/>
<text x="-8.382" y="2.6035" size="1.27" layer="21">P</text>
<text x="-8.509" y="-3.8735" size="1.27" layer="21">G</text>
<text x="5.461" y="-3.6195" size="1.27" layer="21">F1</text>
<text x="11.938" y="-3.7465" size="1.27" layer="21">F2</text>
<text x="-4.7625" y="-9.525" size="1.778" layer="25">&gt;NAME</text>
<text x="-3.8735" y="-11.303" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="COMPACTRON_BOT">
<description>12-PIN COMPACTRON MTD BOTTOM SIDE</description>
<circle x="0" y="0" radius="15.875" width="0.127" layer="21"/>
<pad name="12" x="11.176" y="5.842" drill="2.1844" diameter="3.81"/>
<pad name="11" x="7.239" y="10.414" drill="2.1844" diameter="3.81"/>
<pad name="10" x="1.524" y="12.573" drill="2.1844" diameter="3.81"/>
<pad name="9" x="-4.445" y="11.811" drill="2.1844" diameter="3.81"/>
<pad name="8" x="-9.525" y="8.382" drill="2.1844" diameter="3.81"/>
<pad name="7" x="-12.319" y="3.048" drill="2.1844" diameter="3.81"/>
<pad name="6" x="-12.446" y="-3.048" drill="2.1844" diameter="3.81"/>
<pad name="5" x="-9.525" y="-8.382" drill="2.1844" diameter="3.81"/>
<pad name="4" x="-4.445" y="-11.811" drill="2.1844" diameter="3.81"/>
<pad name="3" x="1.524" y="-12.573" drill="2.1844" diameter="3.81"/>
<pad name="2" x="7.239" y="-10.414" drill="2.1844" diameter="3.81"/>
<pad name="1" x="11.303" y="-5.842" drill="2.1844" diameter="3.81"/>
<text x="-3.81" y="0.762" size="1.778" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="8.128" y="-6.731" size="1.778" layer="21" font="vector" ratio="10">1</text>
<text x="8.89" y="6.604" size="1.778" layer="21" font="vector" ratio="10" rot="R180">12</text>
<text x="-3.683" y="-8.763" size="1.27" layer="27" font="vector" ratio="10">&gt;VALUE</text>
</package>
<package name="COMPACTRON_BOT_2">
<description>12-PIN COMPACTRON, MOUNTED BOTTOM SIDE
1-1/16" PIN CICLE, LIKE SURPLUS SALES</description>
<wire x1="14.605" y1="5.715" x2="14.605" y2="-5.715" width="0.127" layer="21"/>
<wire x1="14.605" y1="-5.715" x2="14.605" y2="5.715" width="0.127" layer="21" curve="-317.258755" cap="flat"/>
<pad name="12" x="11.938" y="6.223" drill="2.1844" diameter="3.81"/>
<pad name="11" x="7.62" y="11.049" drill="2.1844" diameter="3.81"/>
<pad name="10" x="1.651" y="13.335" drill="2.1844" diameter="3.81"/>
<pad name="9" x="-4.826" y="12.573" drill="2.1844" diameter="3.81"/>
<pad name="8" x="-10.033" y="8.89" drill="2.1844" diameter="3.81"/>
<pad name="7" x="-13.081" y="3.175" drill="2.1844" diameter="3.81"/>
<pad name="6" x="-13.081" y="-3.175" drill="2.1844" diameter="3.81"/>
<pad name="5" x="-10.033" y="-8.89" drill="2.1844" diameter="3.81"/>
<pad name="4" x="-4.826" y="-12.573" drill="2.1844" diameter="3.81"/>
<pad name="3" x="1.651" y="-13.335" drill="2.1844" diameter="3.81"/>
<pad name="2" x="7.62" y="-11.049" drill="2.1844" diameter="3.81"/>
<pad name="1" x="11.938" y="-6.223" drill="2.1844" diameter="3.81"/>
<text x="-5.08" y="17.78" size="1.778" layer="25">&gt;NAME</text>
<text x="8.763" y="-3.81" size="1.778" layer="21" rot="R180">1</text>
<text x="9.271" y="4.826" size="1.778" layer="21" rot="R180">12</text>
<text x="-4.826" y="-1.27" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="MINI7_PCB_BOT">
<description>Standard 7-pin-mini PCB socket, mounted backside</description>
<pad name="7" x="6.731" y="-6.731" drill="1.9304" diameter="3.81"/>
<pad name="6" x="9.525" y="0" drill="1.9304" diameter="3.81"/>
<pad name="5" x="6.731" y="6.731" drill="1.9304" diameter="3.81"/>
<pad name="3" x="-6.731" y="6.731" drill="1.9304" diameter="3.81"/>
<pad name="2" x="-9.525" y="0" drill="1.9304" diameter="3.81"/>
<pad name="1" x="-6.731" y="-6.731" drill="1.9304" diameter="3.81"/>
<text x="-3.556" y="-6.35" size="1.27" layer="21" font="vector" ratio="10">1</text>
<text x="2.286" y="-6.35" size="1.27" layer="21" font="vector" ratio="10">7</text>
<text x="-4.064" y="1.27" size="1.778" layer="25" font="vector" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" font="vector" ratio="10">&gt;VALUE</text>
</package>
<package name="NOVAL_BELTON_SH">
<description>9-pin Noval tube socket with shield connection
Belton VT9-PT-C</description>
<wire x1="-10.15" y1="6.4" x2="-3.15" y2="16.3" width="0.254" layer="21"/>
<wire x1="10.05" y1="-6.6" x2="3.05" y2="-16.5" width="0.254" layer="21"/>
<wire x1="9.75" y1="7" x2="3" y2="16.5" width="0.254" layer="21"/>
<wire x1="-9.75" y1="-7.05" x2="-2.95" y2="-16.6" width="0.254" layer="21"/>
<wire x1="-3.15" y1="16.3" x2="3.05" y2="16.45" width="0.254" layer="21" curve="-106.260205"/>
<wire x1="-3.05" y1="-16.5" x2="3.15" y2="-16.35" width="0.254" layer="21" curve="106.260205"/>
<circle x="0" y="0" radius="12.0001" width="0.254" layer="21"/>
<circle x="0" y="0" radius="8.6759" width="0.254" layer="21"/>
<pad name="G" x="0" y="14.25" drill="1.4224" diameter="4"/>
<pad name="9" x="3.25" y="10" drill="1.8" diameter="4"/>
<pad name="8" x="8.45" y="6.15" drill="1.8" diameter="4"/>
<pad name="7" x="10.5" y="0" drill="1.8" diameter="4"/>
<pad name="2" x="-10.5" y="0" drill="1.8" diameter="4"/>
<pad name="5" x="3.25" y="-10" drill="1.8" diameter="4"/>
<pad name="4" x="-3.25" y="-10" drill="1.8" diameter="4"/>
<pad name="6" x="8.5" y="-6.15" drill="1.8" diameter="4"/>
<pad name="3" x="-8.5" y="-6.15" drill="1.8" diameter="4"/>
<pad name="1" x="-8.5" y="6.15" drill="1.8" diameter="4"/>
<text x="15.875" y="-4.445" size="1.778" layer="21" font="vector" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="25" font="vector" ratio="10">&gt;VALUE</text>
<text x="-5.715" y="3.81" size="1.27" layer="21" font="vector" ratio="10">1</text>
<text x="1.905" y="5.715" size="1.27" layer="21" font="vector" ratio="10">9</text>
</package>
<package name="NOVAL_BOTTOM_PCB">
<description>Standard 9-pin socket (Chinese ceramic,  Belton, etc.), mounted bottom side</description>
<pad name="9" x="6.2992" y="-8.4836" drill="1.9304" diameter="3.81"/>
<pad name="8" x="9.9822" y="-3.2512" drill="1.9304" diameter="3.81"/>
<pad name="7" x="9.9822" y="3.2512" drill="1.9304" diameter="3.81"/>
<pad name="6" x="6.2992" y="8.4836" drill="1.9304" diameter="3.81"/>
<pad name="4" x="-6.2992" y="8.4836" drill="1.9304" diameter="3.81"/>
<pad name="3" x="-9.9822" y="3.2512" drill="1.9304" diameter="3.81"/>
<pad name="2" x="-9.9822" y="-3.2512" drill="1.9304" diameter="3.81"/>
<pad name="1" x="-6.2992" y="-8.4836" drill="1.9304" diameter="3.81"/>
<text x="-3.175" y="-10.16" size="1.27" layer="21" font="vector">1</text>
<text x="2.54" y="-10.16" size="1.27" layer="21" font="vector">9</text>
</package>
</packages>
<symbols>
<symbol name="TRIODE_9H_A">
<description>Triode base 9H section 1</description>
<wire x1="-3.81" y1="2.54" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="3.81" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="7.62" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-5.08" x2="-3.81" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-5.08" x2="-3.81" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-2.54" x2="3.81" y2="-2.54" width="0.254" layer="94"/>
<wire x1="3.81" y1="-2.54" x2="3.81" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-7.62" x2="-2.54" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-6.35" x2="0" y2="-3.81" width="0.254" layer="94"/>
<wire x1="0" y1="-3.81" x2="2.54" y2="-6.35" width="0.254" layer="94"/>
<wire x1="2.54" y1="-6.35" x2="2.54" y2="-7.62" width="0.254" layer="94"/>
<wire x1="0" y1="-7.62" x2="0" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-7.62" y1="0" x2="-3.81" y2="0" width="0.254" layer="94" style="shortdash"/>
<wire x1="-3.81" y1="0" x2="3.81" y2="0" width="0.254" layer="94" style="shortdash"/>
<wire x1="-8.89" y1="0" x2="-3.81" y2="0" width="0.254" layer="94"/>
<circle x="0" y="0" radius="7.62" width="0.254" layer="94"/>
<text x="3.81" y="11.43" size="1.27" layer="95">&gt;NAME</text>
<text x="3.81" y="8.89" size="1.27" layer="96">&gt;VALUE</text>
<pin name="2" x="-12.7" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="1" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="3" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
<pin name="4" x="-2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="8" x="0" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="5" x="2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
</symbol>
<symbol name="TRIODE_9H_B">
<description>Triode base 9H section 2</description>
<pin name="7" x="-12.7" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="9" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="6" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="TRIODE_9A_A">
<description>Triode base 9A section 1</description>
<pin name="9" x="0" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
</symbol>
<symbol name="TRIODE_9A_B">
<description>Triode base 9A section 2</description>
<pin name="6" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="8" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="TRIODE_8A">
<description>Single triode section 1</description>
<pin name="1G" x="-12.7" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="1A" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="1K" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
<pin name="F1" x="-2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="F2" x="2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
</symbol>
<symbol name="TRIODE_8B">
<description>Standard triode section 2</description>
<pin name="2G" x="-12.7" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="2A" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="2K" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="RECT_OCTAL">
<description>Standard DH rectifier</description>
<wire x1="-3.81" y1="2.54" x2="-2.54" y2="2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="2.54" x2="3.81" y2="2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="-2.54" y2="2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="7.62" x2="2.54" y2="2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-7.62" x2="-2.54" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-5.08" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="2.54" y2="-5.08" width="0.254" layer="94"/>
<wire x1="2.54" y1="-5.08" x2="2.54" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-1.27" y2="2.54" width="0.254" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.254" layer="94"/>
<pin name="P1" x="-2.54" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="P2" x="2.54" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
</symbol>
<symbol name="TRIODE_7BT">
<description>Triode plus dual diode, base 7BT</description>
<wire x1="-3.81" y1="5.08" x2="0" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="5.08" x2="3.81" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="7.62" x2="0" y2="5.08" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-2.54" x2="-3.81" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-2.54" x2="-3.81" y2="0" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="3.81" y2="0" width="0.254" layer="94"/>
<wire x1="3.81" y1="0" x2="3.81" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-4.445" y1="2.54" x2="3.81" y2="2.54" width="0.254" layer="94" style="shortdash"/>
<wire x1="5.08" y1="-1.27" x2="6.35" y2="-1.27" width="0.254" layer="94"/>
<wire x1="5.08" y1="-3.81" x2="6.35" y2="-3.81" width="0.254" layer="94"/>
<wire x1="5.08" y1="-1.905" x2="5.08" y2="-1.27" width="0.254" layer="94"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="-0.635" width="0.254" layer="94"/>
<wire x1="5.08" y1="-4.445" x2="5.08" y2="-3.81" width="0.254" layer="94"/>
<wire x1="5.08" y1="-3.81" x2="5.08" y2="-3.175" width="0.254" layer="94"/>
<wire x1="6.35" y1="-1.27" x2="7.62" y2="0" width="0.254" layer="94"/>
<wire x1="6.35" y1="-3.81" x2="7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-7.62" y1="2.54" x2="-4.445" y2="2.54" width="0.254" layer="94"/>
<text x="3.81" y="11.43" size="1.778" layer="95">&gt;NAME</text>
<text x="3.81" y="8.89" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-12.7" y="2.54" visible="pad" length="middle" direction="pas"/>
<pin name="7" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="2" x="-12.7" y="-2.54" visible="pad" length="middle" direction="pas"/>
<pin name="3" x="-2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="4" x="2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="6" x="12.7" y="-5.08" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="5" x="12.7" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
</symbol>
<symbol name="TRIODE_9AJ_A">
<description>Triode base 9AJ section 1</description>
</symbol>
<symbol name="TRIODE_9AJ_B">
<description>Triode base 9AJ section 2</description>
<pin name="9" x="12.7" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
</symbol>
<symbol name="VRTUBE_MINI7">
<description>Mini VR tube (2P 3K)</description>
<wire x1="-6.35" y1="3.81" x2="-2.54" y2="3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="3.81" x2="1.27" y2="3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="-2.54" y2="6.35" width="0.254" layer="94"/>
<wire x1="-2.54" y1="6.35" x2="-2.54" y2="3.81" width="0.254" layer="94"/>
<wire x1="-5.08" y1="7.62" x2="-5.08" y2="6.35" width="0.254" layer="94"/>
<wire x1="-5.08" y1="6.35" x2="-2.54" y2="6.35" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-3.81" x2="-2.54" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-6.35" x2="-2.54" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-6.35" x2="0" y2="-6.35" width="0.254" layer="94"/>
<wire x1="0" y1="-6.35" x2="0" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-6.35" x2="-5.08" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-6.35" x2="-5.08" y2="-7.62" width="0.254" layer="94"/>
<circle x="-2.54" y="0" radius="7.62" width="0.254" layer="94"/>
<circle x="-2.54" y="-2.54" radius="1.27" width="0.254" layer="94"/>
<circle x="-2.54" y="-6.35" radius="0.254" width="0.254" layer="94"/>
<circle x="-2.54" y="6.35" radius="0.254" width="0.254" layer="94"/>
<text x="1.27" y="11.43" size="1.778" layer="95">&gt;NAME</text>
<text x="1.27" y="8.89" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A1" x="-5.08" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="A2" x="-2.54" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="K2" x="-2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="K1" x="-5.08" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="K3" x="0" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
</symbol>
<symbol name="GBDISC_7DF">
<description>Gated-beam discriminator</description>
<wire x1="-3.81" y1="2.54" x2="3.81" y2="2.54" width="0.254" layer="94" style="shortdash"/>
<wire x1="-3.81" y1="3.81" x2="-5.08" y2="3.81" width="0.254" layer="94"/>
<wire x1="-5.08" y1="3.81" x2="-5.08" y2="1.27" width="0.254" layer="94"/>
<wire x1="-5.08" y1="1.27" x2="-3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="3.81" x2="5.08" y2="3.81" width="0.254" layer="94"/>
<wire x1="5.08" y1="3.81" x2="5.08" y2="1.27" width="0.254" layer="94"/>
<wire x1="5.08" y1="1.27" x2="3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="8.89" y1="2.54" x2="3.81" y2="2.54" width="0.254" layer="94"/>
<wire x1="8.89" y1="0" x2="6.35" y2="0" width="0.254" layer="94"/>
<wire x1="6.35" y1="0" x2="5.08" y2="1.27" width="0.254" layer="94"/>
<pin name="1" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
<pin name="5" x="12.7" y="2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="6" x="12.7" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
</symbol>
<symbol name="PENTODE_9AQ">
<description>Pentode, like EF184</description>
<wire x1="3.81" y1="-2.54" x2="3.81" y2="-4.445" width="0.254" layer="94"/>
<wire x1="-4.445" y1="-0.635" x2="-3.81" y2="-0.635" width="0.254" layer="94" style="shortdash"/>
<wire x1="-3.81" y1="-0.635" x2="3.81" y2="-0.635" width="0.254" layer="94" style="shortdash"/>
<wire x1="-7.62" y1="0" x2="-3.81" y2="-0.635" width="0.254" layer="94"/>
<wire x1="-3.81" y1="3.175" x2="3.81" y2="3.175" width="0.254" layer="94" style="shortdash"/>
<wire x1="8.89" y1="2.54" x2="3.81" y2="3.175" width="0.254" layer="94"/>
<wire x1="6.35" y1="0" x2="3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.27" x2="3.81" y2="1.27" width="0.254" layer="94" style="shortdash"/>
<wire x1="-7.62" y1="-7.62" x2="-3.81" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-7.62" x2="-3.81" y2="-5.08" width="0.254" layer="94"/>
<wire x1="7.62" y1="-5.08" x2="6.985" y2="-5.08" width="0.254" layer="94"/>
<wire x1="6.985" y1="-5.08" x2="5.715" y2="-3.81" width="0.254" layer="94"/>
<wire x1="3.81" y1="-5.715" x2="6.35" y2="-2.54" width="0.254" layer="94" curve="34.708049"/>
<pin name="9" x="12.7" y="2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="8" x="12.7" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="1" x="-12.7" y="-7.62" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="PENTODE_9AD">
<description>5879 low noise pentode</description>
<wire x1="7.62" y1="-7.62" x2="7.62" y2="-5.08" width="0.254" layer="94"/>
<pin name="1" x="-12.7" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="8" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="7" x="12.7" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="2" x="12.7" y="-7.62" visible="pad" length="middle" direction="pas" rot="R180"/>
</symbol>
<symbol name="SUBMINI_PENTODE">
<description>Submini battery pentode</description>
<wire x1="-2.54" y1="-7.62" x2="-2.54" y2="-5.715" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-5.715" x2="-2.54" y2="-5.08" width="0.254" layer="94"/>
<wire x1="2.54" y1="-5.08" x2="2.54" y2="-5.715" width="0.254" layer="94"/>
<wire x1="2.54" y1="-5.715" x2="2.54" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-1.27" x2="3.81" y2="-1.27" width="0.254" layer="94" style="shortdash"/>
<wire x1="3.81" y1="3.81" x2="5.08" y2="2.54" width="0.254" layer="94"/>
<wire x1="5.08" y1="2.54" x2="3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="3.81" x2="-5.08" y2="2.54" width="0.254" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="-3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="5.08" y1="2.54" x2="5.715" y2="2.54" width="0.254" layer="94"/>
<wire x1="5.715" y1="2.54" x2="5.715" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="-5.715" y2="2.54" width="0.254" layer="94"/>
<wire x1="-5.715" y1="2.54" x2="-5.715" y2="-3.81" width="0.254" layer="94"/>
<wire x1="2.54" y1="-5.715" x2="3.81" y2="-5.715" width="0.254" layer="94"/>
<wire x1="3.81" y1="-5.715" x2="5.715" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-5.715" x2="-3.81" y2="-5.715" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-5.715" x2="-5.715" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-2.54" x2="-3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="8.89" y2="0" width="0.254" layer="94" style="shortdash"/>
<wire x1="-3.81" y1="-7.62" x2="-3.81" y2="-8.89" width="0.254" layer="94"/>
<wire x1="-4.445" y1="-8.255" x2="-3.175" y2="-8.255" width="0.254" layer="94"/>
<wire x1="3.175" y1="-8.255" x2="4.445" y2="-8.255" width="0.254" layer="94"/>
<circle x="-2.54" y="-5.715" radius="0.1796" width="0.254" layer="94"/>
<circle x="2.54" y="-5.715" radius="0.1796" width="0.254" layer="94"/>
<pin name="G1" x="-12.7" y="-2.54" visible="pad" length="middle" direction="pas"/>
<pin name="P" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="FP" x="-2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="FN" x="2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="G2" x="12.7" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
</symbol>
<symbol name="TRIODE_DHT">
<description>Directly heated triode</description>
<pin name="G" x="-12.7" y="0" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="PENTODE_HTR">
<description>Pentode symbol with heater</description>
<wire x1="-3.81" y1="-4.445" x2="-3.81" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-4.445" y1="-0.635" x2="3.81" y2="-0.635" width="0.254" layer="94" style="shortdash"/>
<wire x1="-7.62" y1="0" x2="-4.445" y2="-0.635" width="0.254" layer="94"/>
<wire x1="7.62" y1="5.08" x2="3.81" y2="3.175" width="0.254" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.27" x2="7.62" y2="0" width="0.254" layer="94"/>
<pin name="G1" x="-10.16" y="0" visible="pad" length="short" direction="pas"/>
<pin name="P" x="0" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="K" x="10.16" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="F1" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="F2" x="2.54" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="G3" x="10.16" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="G2" x="10.16" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="PENTODE_NO_HTR">
<description>Pentode symbol. no heater</description>
<wire x1="3.81" y1="3.175" x2="7.62" y2="5.08" width="0.254" layer="94"/>
<pin name="B_G1" x="-10.16" y="0" visible="pad" length="short" direction="pas"/>
<pin name="B_P" x="0" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="B_K" x="10.16" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="B_G3" x="10.16" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="B_G2" x="10.16" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="815">
<description>815 dual beam tube</description>
<wire x1="-11.43" y1="5.08" x2="-7.62" y2="5.08" width="0.254" layer="94"/>
<wire x1="-7.62" y1="5.08" x2="-3.81" y2="5.08" width="0.254" layer="94"/>
<wire x1="-7.62" y1="7.62" x2="-7.62" y2="5.08" width="0.254" layer="94"/>
<wire x1="-10.795" y1="-2.54" x2="-3.81" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-2.54" x2="-3.81" y2="-4.445" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-7.62" x2="-10.16" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-6.35" x2="-7.62" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-3.81" x2="-5.08" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-11.43" y1="-0.635" x2="-3.81" y2="-0.635" width="0.254" layer="94" style="shortdash"/>
<wire x1="5.08" y1="7.62" x2="5.08" y2="5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="5.08" x2="8.89" y2="5.08" width="0.254" layer="94"/>
<wire x1="1.27" y1="5.08" x2="5.08" y2="5.08" width="0.254" layer="94"/>
<wire x1="-6.985" y1="-7.62" x2="-6.985" y2="7.62" width="0.254" layer="94" curve="-180"/>
<wire x1="1.27" y1="-0.635" x2="8.89" y2="-0.635" width="0.254" layer="94" style="shortdash"/>
<wire x1="1.27" y1="-2.54" x2="8.255" y2="-2.54" width="0.254" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.27" y2="-4.445" width="0.254" layer="94"/>
<wire x1="5.08" y1="-3.81" x2="7.62" y2="-6.35" width="0.254" layer="94"/>
<wire x1="2.54" y1="-6.35" x2="5.08" y2="-3.81" width="0.254" layer="94"/>
<wire x1="7.62" y1="-6.35" x2="7.62" y2="-7.62" width="0.254" layer="94"/>
<wire x1="4.445" y1="7.62" x2="4.445" y2="-7.62" width="0.254" layer="94" curve="-180"/>
<wire x1="-6.985" y1="7.62" x2="4.445" y2="7.62" width="0.254" layer="94"/>
<wire x1="-6.985" y1="-7.62" x2="0" y2="-7.62" width="0.254" layer="94"/>
<wire x1="0" y1="-7.62" x2="4.445" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-4.445" x2="1.27" y2="-4.445" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-6.35" x2="0" y2="-6.35" width="0.254" layer="94"/>
<wire x1="0" y1="-6.35" x2="2.54" y2="-6.35" width="0.254" layer="94"/>
<wire x1="12.7" y1="0" x2="11.43" y2="0" width="0.254" layer="94"/>
<wire x1="11.43" y1="0" x2="8.89" y2="-0.635" width="0.254" layer="94"/>
<wire x1="-15.24" y1="0" x2="-13.97" y2="0" width="0.254" layer="94"/>
<wire x1="-13.97" y1="0" x2="-11.43" y2="-0.635" width="0.254" layer="94"/>
<wire x1="12.7" y1="2.54" x2="11.43" y2="2.54" width="0.254" layer="94"/>
<wire x1="11.43" y1="2.54" x2="8.89" y2="1.27" width="0.254" layer="94"/>
<wire x1="-10.795" y1="-3.81" x2="-10.795" y2="-2.54" width="0.254" layer="94"/>
<wire x1="8.255" y1="-2.54" x2="8.255" y2="-3.81" width="0.254" layer="94"/>
<wire x1="0" y1="-7.62" x2="0" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-10.795" y1="-3.81" x2="-12.065" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-12.065" y1="-3.81" x2="-12.065" y2="3.175" width="0.254" layer="94"/>
<wire x1="8.255" y1="-3.81" x2="9.525" y2="-3.81" width="0.254" layer="94"/>
<wire x1="9.525" y1="-3.81" x2="9.525" y2="3.175" width="0.254" layer="94"/>
<wire x1="-11.43" y1="1.27" x2="8.89" y2="1.27" width="0.254" layer="94" style="shortdash"/>
<wire x1="-12.065" y1="3.175" x2="9.525" y2="3.175" width="0.254" layer="94" style="shortdash"/>
<wire x1="-12.065" y1="-3.81" x2="-13.97" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-13.97" y1="-3.81" x2="-15.24" y2="-5.08" width="0.254" layer="94"/>
<wire x1="10.16" y1="-3.81" x2="11.43" y2="-3.81" width="0.254" layer="94"/>
<wire x1="11.43" y1="-3.81" x2="12.7" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-7.62" y1="10.16" x2="-7.62" y2="12.7" width="0.254" layer="94"/>
<wire x1="5.08" y1="10.16" x2="5.08" y2="12.7" width="0.254" layer="94"/>
<circle x="0" y="-6.35" radius="0.635" width="0" layer="94"/>
<circle x="-12.065" y="-3.81" radius="0.635" width="0" layer="94"/>
<circle x="9.525" y="-3.81" radius="0.635" width="0" layer="94"/>
<text x="8.89" y="10.16" size="1.778" layer="95">&gt;NAME</text>
<text x="8.89" y="7.62" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="3.81" y1="7.62" x2="6.35" y2="10.16" layer="94"/>
<rectangle x1="-8.89" y1="7.62" x2="-6.35" y2="10.16" layer="94"/>
<pin name="G1A" x="-17.78" y="0" visible="pad" length="short" direction="pas"/>
<pin name="G1B" x="15.24" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="F1" x="-10.16" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="FCT" x="0" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="G2" x="15.24" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="K2" x="15.24" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="F2" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="K1" x="-17.78" y="-5.08" visible="pad" length="short" direction="pas"/>
</symbol>
<symbol name="BEAM_TUBE_12FK">
<description>6JN6 sweep tube</description>
<wire x1="7.62" y1="2.54" x2="3.81" y2="3.175" width="0.254" layer="94"/>
<pin name="G1" x="-12.7" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="A" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="G3" x="12.7" y="2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="K" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="SWEEP_TOP_NOPIN">
<description>Sweep tube with top cap with no pin</description>
<rectangle x1="-0.9525" y1="7.62" x2="0.9525" y2="9.8425" layer="94"/>
</symbol>
<symbol name="6JM6_6JN6">
<description>6JM6 or 6JN6 sweep tube</description>
<wire x1="-7.62" y1="-2.54" x2="-6.985" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-6.985" y1="-2.54" x2="-3.81" y2="-0.635" width="0.254" layer="94"/>
<pin name="G1A" x="-12.7" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="G1B" x="-12.7" y="-2.54" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="PENTODE">
<description>Standard pentode</description>
<wire x1="-3.81" y1="4.445" x2="0" y2="4.445" width="0.254" layer="94"/>
<wire x1="0" y1="4.445" x2="3.81" y2="4.445" width="0.254" layer="94"/>
<wire x1="0" y1="7.62" x2="0" y2="4.445" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-5.08" x2="-3.81" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-3.175" x2="3.81" y2="-3.175" width="0.254" layer="94"/>
<wire x1="3.81" y1="-3.175" x2="3.81" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-7.62" x2="-2.54" y2="-6.985" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-6.985" x2="0" y2="-4.445" width="0.254" layer="94"/>
<wire x1="0" y1="-4.445" x2="2.54" y2="-6.985" width="0.254" layer="94"/>
<wire x1="2.54" y1="-6.985" x2="2.54" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-1.27" x2="3.175" y2="-1.27" width="0.254" layer="94" style="shortdash"/>
<wire x1="-7.62" y1="0" x2="-5.08" y2="-1.27" width="0.254" layer="94"/>
<wire x1="7.62" y1="2.54" x2="3.81" y2="2.54" width="0.254" layer="94"/>
<wire x1="7.62" y1="0" x2="6.35" y2="0" width="0.254" layer="94"/>
<wire x1="6.35" y1="0" x2="3.81" y2="0.635" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0.635" x2="3.81" y2="0.635" width="0.254" layer="94" style="shortdash"/>
<pin name="H1" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="H2" x="2.54" y="-10.16" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="G3" x="10.16" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIODE_IDH">
<description>Single diode indirectly heated</description>
<wire x1="-3.81" y1="-2.54" x2="-3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-1.27" x2="3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.27" x2="3.81" y2="-2.54" width="0.254" layer="94"/>
<pin name="K" x="-12.7" y="-2.54" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="PENTODE_2K">
<description>Pentode with 2 cathode pins</description>
<wire x1="-7.62" y1="-5.08" x2="-5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="-3.81" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-7.62" x2="-7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="-5.08" y2="3.175" width="0.254" layer="94"/>
<wire x1="-5.08" y1="3.175" x2="3.81" y2="3.175" width="0.254" layer="94" style="shortdash"/>
<pin name="K1" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
<pin name="H1" x="-2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="H2" x="2.54" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="K2" x="-12.7" y="-7.62" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="TRIODE_9HF_A">
<description>Triode base 9HF section 1</description>
<wire x1="-7.62" y1="0" x2="-5.08" y2="0" width="0.254" layer="94" style="shortdash"/>
<wire x1="-8.89" y1="0" x2="-5.08" y2="0" width="0.254" layer="94"/>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-2.54" x2="-5.08" y2="0" width="0.254" layer="94"/>
<pin name="9" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
<pin name="3" x="-12.7" y="-2.54" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="TRIODE_9HF_B">
<description>Triode base 9HF section 2</description>
</symbol>
<symbol name="PENTODE_12EZ_1">
<description>6T10 section 1</description>
<wire x1="3.81" y1="-5.08" x2="5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="3.175" width="0.254" layer="94"/>
<wire x1="5.08" y1="3.175" x2="4.445" y2="3.175" width="0.254" layer="94"/>
</symbol>
<symbol name="PENTODE_12EZ_2">
<description>6T10 section 2</description>
</symbol>
<symbol name="PENTODE_9BF">
<description>Pentode w/ 2 G3 pins, 12GN7, 12HG7, etc.</description>
<wire x1="0" y1="-3.81" x2="0" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-7.62" y1="2.54" x2="-3.81" y2="3.175" width="0.254" layer="94"/>
<pin name="G3A" x="-12.7" y="2.54" visible="pad" length="middle" direction="pas"/>
<pin name="HCT" x="0" y="-12.7" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="G3B" x="-12.7" y="5.08" visible="pad" length="middle" direction="pas"/>
<wire x1="-7.62" y1="5.08" x2="-7.62" y2="2.54" width="0.254" layer="94"/>
</symbol>
<symbol name="VRTUBE">
<description>Octal VR tube</description>
<wire x1="0" y1="5.08" x2="0" y2="1.905" width="0.254" layer="94"/>
<wire x1="-1.905" y1="1.905" x2="1.905" y2="1.905" width="0.254" layer="94"/>
<wire x1="0" y1="-2.8575" x2="0" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="2.54" width="0.254" layer="94"/>
<circle x="0" y="-1.905" radius="0.898" width="0.254" layer="94"/>
<circle x="0" y="0" radius="5.08" width="0.254" layer="94"/>
<text x="7.62" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<text x="7.62" y="0" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="0" y="10.16" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="K" x="0" y="-10.16" visible="pad" length="middle" direction="pas" rot="R90"/>
<pin name="J1" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="J2" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
</symbol>
<symbol name="TRIODE_HTR">
<description>Standard single triode</description>
</symbol>
<symbol name="TETRODE_9JD">
<description>12DY8 section 1</description>
<wire x1="-3.81" y1="-3.175" x2="-3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-1.905" x2="3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="-4.445" y1="0" x2="3.81" y2="0" width="0.254" layer="94" style="shortdash"/>
<wire x1="-7.62" y1="0" x2="-4.445" y2="0" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="-5.08" width="0.254" layer="94"/>
<wire x1="3.81" y1="2.54" x2="7.62" y2="0" width="0.254" layer="94"/>
</symbol>
<symbol name="TRIODE_9JD">
<description>12DY8 section 2</description>
<wire x1="-3.81" y1="3.81" x2="0" y2="3.81" width="0.254" layer="94"/>
<wire x1="0" y1="3.81" x2="3.81" y2="3.81" width="0.254" layer="94"/>
<wire x1="0" y1="7.62" x2="0" y2="3.81" width="0.254" layer="94"/>
<wire x1="-7.62" y1="0" x2="-3.81" y2="0" width="0.254" layer="94"/>
</symbol>
<symbol name="5B254M">
<description>Beam tube, 5B/254M
(Loctal 807)</description>
<wire x1="-7.62" y1="0" x2="-3.81" y2="-0.635" width="0.1778" layer="94"/>
<wire x1="8.89" y1="0" x2="6.35" y2="0" width="0.1778" layer="94"/>
<wire x1="6.35" y1="0" x2="3.81" y2="1.27" width="0.1778" layer="94"/>
<wire x1="-7.62" y1="-5.08" x2="-4.826" y2="-5.08" width="0.1778" layer="94"/>
<wire x1="-4.826" y1="-5.08" x2="-3.81" y2="-5.08" width="0.1778" layer="94"/>
<wire x1="-4.826" y1="-5.08" x2="-4.826" y2="3.175" width="0.1778" layer="94"/>
<wire x1="-4.826" y1="3.175" x2="-4.191" y2="3.175" width="0.1778" layer="94"/>
<circle x="-4.826" y="-5.08" radius="0.3592" width="0" layer="94"/>
<text x="-9.906" y="0.254" size="1.27" layer="94">5</text>
<text x="8.509" y="0.254" size="1.27" layer="94">3</text>
<text x="-3.81" y="-9.398" size="1.27" layer="94">1</text>
<text x="2.921" y="-9.271" size="1.27" layer="94">8</text>
<text x="-9.779" y="-4.699" size="1.27" layer="94">4</text>
<pin name="5" x="-12.7" y="0" visible="off" length="middle" direction="pas"/>
<pin name="1" x="-2.54" y="-12.7" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="8" x="2.54" y="-12.7" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="3" x="12.7" y="0" visible="off" length="middle" direction="pas" rot="R180"/>
<pin name="K" x="-12.7" y="-5.08" visible="off" length="middle" direction="pas"/>
<pin name="2" x="0" y="12.7" visible="off" length="middle" direction="pas" rot="R270"/>
</symbol>
<symbol name="TRIODE_12">
<description>Triode with heater (compactron)</description>
</symbol>
<symbol name="TRIODE_12B">
<description>Triode without heater (compactron)</description>
</symbol>
<symbol name="TRIODE_7BT-1">
</symbol>
<symbol name="TRIODE_8A-1">
</symbol>
<symbol name="TRIODE_8B-1">
</symbol>
<symbol name="TRIODE_9A_A-1">
</symbol>
<symbol name="TRIODE_9A_B-1">
</symbol>
<symbol name="TRIODE_9AJ_A-1">
</symbol>
<symbol name="TRIODE_9AJ_B-1">
</symbol>
<symbol name="TRIODE_9H_A-1">
</symbol>
<symbol name="TRIODE_9H_B-1">
</symbol>
<symbol name="TRIODE_9HF_1">
</symbol>
<symbol name="TRIODE_9HF_2">
</symbol>
<symbol name="TRIODE_12-1">
</symbol>
<symbol name="TRIODE_12B-1">
</symbol>
<symbol name="BEAM_TUBE_7AC">
<description>Beam power tube, base 7AC (6V6, 6L6, etc.)</description>
<pin name="K_G3" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="PENTODE_9EQ">
<description>Pentode, base 9EQ</description>
<pin name="G3" x="-12.7" y="2.54" visible="pad" length="middle" direction="pas"/>
<wire x1="-5.08" y1="3.175" x2="-7.62" y2="2.54" width="0.254" layer="94"/>
</symbol>
<symbol name="TRIODE_7BQ">
<description>single triode, base 7BQ</description>
<pin name="G1B" x="-12.7" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="G1A" x="-12.7" y="2.54" visible="pad" length="middle" direction="pas"/>
<pin name="G1C" x="-12.7" y="-2.54" visible="pad" length="middle" direction="pas"/>
<wire x1="-7.62" y1="2.54" x2="-7.62" y2="-2.54" width="0.254" layer="94"/>
</symbol>
<symbol name="TRIODE_6BG">
<description>Single mini triode base 6BG (6C4)</description>
<pin name="A2" x="0" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<pin name="A1" x="-2.54" y="12.7" visible="pad" length="middle" direction="pas" rot="R270"/>
<wire x1="-2.54" y1="7.62" x2="0" y2="7.62" width="0.254" layer="94"/>
</symbol>
<symbol name="RECT_OCTAL_IDH">
<description>Octal rectifier with cathode (5AR4, etc.)</description>
<wire x1="-3.175" y1="-1.905" x2="-3.175" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-3.175" y1="-1.27" x2="3.175" y2="-1.27" width="0.254" layer="94"/>
<wire x1="3.175" y1="-1.27" x2="3.175" y2="-2.54" width="0.254" layer="94"/>
<wire x1="3.175" y1="-2.54" x2="2.54" y2="-5.08" width="0.254" layer="94"/>
</symbol>
<symbol name="DIODE_9HP">
<description>Power diode, base 9HP (6CL3, 6CM3, etc.)</description>
</symbol>
</symbols>
<devicesets>
<deviceset name="6BN6" prefix="V">
<description>Gated beam discriminator, base 7DF</description>
<gates>
<gate name="G$1" symbol="GBDISC_7DF" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MINI7_PCB">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EF184" prefix="V">
<description>Pentode, base 9AQ (EF184, etc.)</description>
<gates>
<gate name="G$1" symbol="PENTODE_9AQ" x="0" y="0"/>
</gates>
<devices>
<device name="" package="NOVAL_PCB">
<connects>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5879" prefix="V">
<description>Pentode, low noise (5879)</description>
<gates>
<gate name="G$1" symbol="PENTODE_9AD" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6418" prefix="VT" uservalue="yes">
<description>Submini pentode (512ax, 6418, etc.)</description>
<gates>
<gate name="G$1" symbol="SUBMINI_PENTODE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SUBMINI5">
<connects>
<connect gate="G$1" pin="FN" pad="5"/>
<connect gate="G$1" pin="FP" pad="3"/>
<connect gate="G$1" pin="G1" pad="4"/>
<connect gate="G$1" pin="G2" pad="2"/>
<connect gate="G$1" pin="P" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="703A" prefix="VT">
<description>UHF triode, 703A (UFO/doorknob)</description>
<gates>
<gate name="G$1" symbol="TRIODE_DHT" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TRIODE_703A">
<connects>
<connect gate="G$1" pin="F1" pad="F1"/>
<connect gate="G$1" pin="F2" pad="F2"/>
<connect gate="G$1" pin="G" pad="G"/>
<connect gate="G$1" pin="P" pad="P"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BN11">
<description>Dual pentode, base 12GF (6BN11)</description>
<gates>
<gate name="A" symbol="PENTODE_HTR" x="0" y="20.32"/>
<gate name="B" symbol="PENTODE_NO_HTR" x="0" y="-17.78"/>
</gates>
<devices>
<device name="" package="COMPACTRON_BOT">
<connects>
<connect gate="A" pin="F1" pad="1"/>
<connect gate="A" pin="F2" pad="12"/>
<connect gate="A" pin="G1" pad="7"/>
<connect gate="A" pin="G2" pad="9"/>
<connect gate="A" pin="G3" pad="10"/>
<connect gate="A" pin="K" pad="8"/>
<connect gate="A" pin="P" pad="11"/>
<connect gate="B" pin="B_G1" pad="3"/>
<connect gate="B" pin="B_G2" pad="4"/>
<connect gate="B" pin="B_G3" pad="6"/>
<connect gate="B" pin="B_K" pad="2"/>
<connect gate="B" pin="B_P" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
<device name="_2" package="COMPACTRON_BOT_2">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EL34">
<description>Beam power tube</description>
<gates>
<gate name="A" symbol="PENTODE_HTR" x="0" y="0"/>
</gates>
<devices>
<device name="" package="OCTAL_BOTTOM">
<connects>
<connect gate="A" pin="F1" pad="2"/>
<connect gate="A" pin="F2" pad="7"/>
<connect gate="A" pin="G1" pad="5"/>
<connect gate="A" pin="G2" pad="4"/>
<connect gate="A" pin="G3" pad="1"/>
<connect gate="A" pin="P" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="815" prefix="VT" uservalue="yes">
<description>815 double beam tube (dual 2E26)</description>
<gates>
<gate name="G$1" symbol="815" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="F1" pad="1"/>
<connect gate="G$1" pin="F2" pad="8"/>
<connect gate="G$1" pin="FCT" pad="5"/>
<connect gate="G$1" pin="G1A" pad="7"/>
<connect gate="G$1" pin="G1B" pad="2"/>
<connect gate="G$1" pin="G2" pad="4"/>
<connect gate="G$1" pin="K1" pad="6"/>
<connect gate="G$1" pin="K2" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6JN6" prefix="VT" uservalue="yes">
<description>Compactron sweep tube, base 12FK (6JN6, etc.)</description>
<gates>
<gate name="G$1" symbol="BEAM_TUBE_12FK" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="A" pad="7"/>
<connect gate="G$1" pin="F2" pad="12"/>
<connect gate="G$1" pin="G1" pad="11"/>
<connect gate="G$1" pin="G2" pad="3"/>
<connect gate="G$1" pin="G3" pad="4"/>
<connect gate="G$1" pin="K" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6JM6" prefix="VT" uservalue="yes">
<description>Sweep tube with top cap (6JM6, etc.)</description>
<gates>
<gate name="G$1" symbol="SWEEP_TOP_NOPIN" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="G1" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6JM6_6JN6" prefix="VT" uservalue="yes">
<description>6JM6 or 6JN6 sweep tubes
Two different grid connections, pin 5 for 6JM6, pin 11 for 6JN6
6JN6 has top cap plate connection</description>
<gates>
<gate name="G$1" symbol="6JM6_6JN6" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="G1A" pad="11"/>
<connect gate="G$1" pin="G1B" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CB6" prefix="VT">
<description>Pentode, 7-pin-mini, 6CB6, 6DK6, etc.</description>
<gates>
<gate name="G$1" symbol="PENTODE" x="0" y="0"/>
</gates>
<devices>
<device name="_TOP" package="MINI7_PCB">
<connects>
<connect gate="G$1" pin="G1" pad="1"/>
<connect gate="G$1" pin="G2" pad="6"/>
<connect gate="G$1" pin="G3" pad="7"/>
<connect gate="G$1" pin="H1" pad="3"/>
<connect gate="G$1" pin="H2" pad="4"/>
<connect gate="G$1" pin="P" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
<device name="_BOT" package="MINI7_PCB_BOT">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6W4" uservalue="yes">
<description>Power diode, octal (6W4, 6AX4, etc.)</description>
<gates>
<gate name="G$1" symbol="DIODE_IDH" x="0" y="0"/>
</gates>
<devices>
<device name="_TOP" package="OCTAL">
<connects>
<connect gate="G$1" pin="A" pad="5"/>
<connect gate="G$1" pin="F1" pad="7"/>
<connect gate="G$1" pin="K" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="_BOT" package="OCTAL_BOTTOM">
<connects>
<connect gate="G$1" pin="F1" pad="8"/>
<connect gate="G$1" pin="F2" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6V6" prefix="VT" uservalue="yes">
<gates>
<gate name="A" symbol="BEAM_TUBE_7AC" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="H1" pad="2"/>
<connect gate="A" pin="H2" pad="7"/>
<connect gate="A" pin="K_G3" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6T10" prefix="VT">
<description>Dissimilar double pentode</description>
<gates>
<gate name="A" symbol="PENTODE_12EZ_1" x="0" y="17.78"/>
<gate name="B" symbol="PENTODE_12EZ_2" x="0" y="-15.24"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="G1" pad="8"/>
<connect gate="A" pin="G2" pad="10"/>
<connect gate="A" pin="K" pad="9"/>
<connect gate="B" pin="G1" pad="3"/>
<connect gate="B" pin="G2" pad="6"/>
<connect gate="B" pin="G3" pad="5"/>
<connect gate="B" pin="K" pad="2"/>
<connect gate="B" pin="P" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12GN7" prefix="VT" uservalue="yes">
<description>High Gm pentode</description>
<gates>
<gate name="G$1" symbol="PENTODE_9BF" x="0" y="0"/>
</gates>
<devices>
<device name="" package="NOVAL_BOTTOM_PCB">
<connects>
<connect gate="G$1" pin="G1" pad="2"/>
<connect gate="G$1" pin="G2" pad="8"/>
<connect gate="G$1" pin="G3A" pad="9"/>
<connect gate="G$1" pin="G3B" pad="3"/>
<connect gate="G$1" pin="H1" pad="4"/>
<connect gate="G$1" pin="H2" pad="5"/>
<connect gate="G$1" pin="HCT" pad="6"/>
<connect gate="G$1" pin="K" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="_TOP" package="NOVAL_PCB">
<connects>
<connect gate="G$1" pin="G3A" pad="3"/>
<connect gate="G$1" pin="G3B" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12DY8" prefix="VT">
<description>Triode plus Tetrode</description>
<gates>
<gate name="A" symbol="TETRODE_9JD" x="0" y="17.78"/>
<gate name="B" symbol="TRIODE_9JD" x="0" y="-15.24"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="F1" pad="4"/>
<connect gate="A" pin="F2" pad="5"/>
<connect gate="A" pin="G1" pad="1"/>
<connect gate="A" pin="G2" pad="3"/>
<connect gate="A" pin="K" pad="2"/>
<connect gate="A" pin="P" pad="6"/>
<connect gate="B" pin="G1" pad="9"/>
<connect gate="B" pin="K" pad="7"/>
<connect gate="B" pin="P" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5B254M" prefix="VT">
<description>Beam power tube, 5B/154M, Loctal</description>
<gates>
<gate name="G$1" symbol="5B254M" x="0" y="0"/>
</gates>
<devices>
<device name="" package="OCTAL">
<connects>
<connect gate="G$1" pin="5" pad="4"/>
<connect gate="G$1" pin="8" pad="5"/>
<connect gate="G$1" pin="K" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="VRTUBE_OCTAL" prefix="VT" uservalue="yes">
<description>Octal VR tube (0A3, etc.)</description>
<gates>
<gate name="A" symbol="VRTUBE" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="A" pad="5"/>
<connect gate="A" pin="J1" pad="3"/>
<connect gate="A" pin="J2" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="VRTUBE_MINI" prefix="VT" uservalue="yes">
<description>Mini VR tube (0A2, etc.)</description>
<gates>
<gate name="A" symbol="VRTUBE_MINI7" x="2.54" y="0"/>
</gates>
<devices>
<device name="" package="MINI7_PCB_BOT">
<connects>
<connect gate="A" pin="A1" pad="1"/>
<connect gate="A" pin="A2" pad="5"/>
<connect gate="A" pin="K1" pad="2"/>
<connect gate="A" pin="K2" pad="4"/>
<connect gate="A" pin="K3" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRIODE_DIODE_7BT" prefix="V" uservalue="yes">
<description>TRIODE W/ 2 DIODES, 7-PIN MINI, 7BT</description>
<gates>
<gate name="G$1" symbol="TRIODE_7BT-1" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRIODE_DUAL_8BD" prefix="VT" uservalue="yes">
<description>DUAL OCTAL TRIODE</description>
<gates>
<gate name="A" symbol="TRIODE_8A-1" x="0" y="20.32"/>
<gate name="B" symbol="TRIODE_8B-1" x="0" y="-20.32"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="1A" pad="2"/>
<connect gate="A" pin="1G" pad="1"/>
<connect gate="A" pin="1K" pad="3"/>
<connect gate="A" pin="F1" pad="7"/>
<connect gate="A" pin="F2" pad="8"/>
<connect gate="B" pin="2A" pad="5"/>
<connect gate="B" pin="2G" pad="4"/>
<connect gate="B" pin="2K" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
<connect gate="A" pin="1A" pad="5"/>
<connect gate="A" pin="1G" pad="4"/>
<connect gate="A" pin="1K" pad="6"/>
<connect gate="B" pin="2A" pad="3"/>
<connect gate="B" pin="2G" pad="1"/>
<connect gate="B" pin="2K" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="_CHASSIS" package="OCTAL_CHASSIS_ON_PCB">
<connects>
<connect gate="B" pin="2A" pad="2"/>
<connect gate="B" pin="2K" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="_BIG" package="OCTAL_CHASSIS_PCB2">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRIODE_DUAL_9A" prefix="V" uservalue="yes">
<description>TRIODE, BASE 9A
12AU7, 12AX7, ETC.</description>
<gates>
<gate name="A" symbol="TRIODE_9A_A-1" x="0" y="25.4"/>
<gate name="B" symbol="TRIODE_9A_B-1" x="0" y="-20.32"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="2" pad="2"/>
<connect gate="A" pin="3" pad="3"/>
<connect gate="A" pin="4" pad="4"/>
<connect gate="A" pin="5" pad="5"/>
<connect gate="A" pin="9" pad="9"/>
<connect gate="B" pin="6" pad="6"/>
<connect gate="B" pin="7" pad="7"/>
<connect gate="B" pin="8" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
<device name="BACKSIDE" package="NOVAL_PCB">
<connects>
<connect gate="A" pin="1" pad="9"/>
<connect gate="A" pin="2" pad="8"/>
<connect gate="A" pin="3" pad="7"/>
<connect gate="A" pin="4" pad="6"/>
<connect gate="A" pin="9" pad="1"/>
<connect gate="B" pin="6" pad="4"/>
<connect gate="B" pin="7" pad="3"/>
<connect gate="B" pin="8" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRIODE_DUAL_9AJ" prefix="V" uservalue="yes">
<description>TRIODE, BASE 9AJ
(6DJ8, 6922)</description>
<gates>
<gate name="A" symbol="TRIODE_9AJ_A-1" x="2.54" y="22.86"/>
<gate name="B" symbol="TRIODE_9AJ_B-1" x="0" y="-22.86"/>
</gates>
<devices>
<connects>
<connect gate="B" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="_SH" package="NOVAL_BELTON_SH">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRIODE_DUAL_9H" prefix="V" uservalue="yes">
<description>TRIODE, BASE 9H
7119, 7044</description>
<gates>
<gate name="A" symbol="TRIODE_9H_A-1" x="0" y="17.78"/>
<gate name="B" symbol="TRIODE_9H_B-1" x="0" y="-22.86"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="8" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRIODE_DUAL_9HF" prefix="VT" uservalue="yes">
<description>Dual triode, base 9HF (6DE7, 6DR7, 6EW7...)</description>
<gates>
<gate name="A" symbol="TRIODE_9HF_1" x="0" y="17.78"/>
<gate name="B" symbol="TRIODE_9HF_2" x="0" y="-20.32"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRIODE_TRIPLE_12FE" prefix="VT" uservalue="yes">
<description>Compactron triple triode (6AC10, 6U10, etc.)</description>
<gates>
<gate name="A" symbol="TRIODE_12-1" x="-27.94" y="2.54"/>
<gate name="B" symbol="TRIODE_12B-1" x="0" y="0"/>
<gate name="C" symbol="TRIODE_12B-1" x="27.94" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="A" pad="10"/>
<connect gate="A" pin="G" pad="9"/>
<connect gate="A" pin="H1" pad="1"/>
<connect gate="A" pin="H2" pad="12"/>
<connect gate="A" pin="K" pad="4"/>
<connect gate="B" pin="A" pad="5"/>
<connect gate="B" pin="G" pad="7"/>
<connect gate="B" pin="K" pad="6"/>
<connect gate="C" pin="A" pad="2"/>
<connect gate="C" pin="G" pad="11"/>
<connect gate="C" pin="K" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6SN7" prefix="VT" uservalue="yes">
<description>Octal dual triode, base 8BD
(6SN7, 6SL7, 6AS7, etc.)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6SL7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AS7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BL7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BX7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DN7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EA7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EM7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6SU7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6GL7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5691" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5692" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12SN7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12SL7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1633" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5998" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7236" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6336" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6528" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6081" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6082" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6080" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="10EM7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="13EM7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AQ6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AU7" prefix="V" uservalue="yes">
<description>Dual triode, base 9A (12A*7, etc.)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DJ8" prefix="VT" uservalue="yes">
<description>Dual triode, base 9AJ (6DJ8, 6922, etc.)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="_TOP_SH" package="NOVAL_BELTON_SH">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7119" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7044" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="E182CC" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DE7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DR7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EW7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6FD7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6FR7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="13DE7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="13DR7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AC10" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AK10" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6U10" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AC10" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="0A2" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="0B2" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="0C2" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5651" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6073" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6074" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6626" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6627" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CA7">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EY6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EZ5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6L6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6U6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6W6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6Y6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12A6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1614" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1619" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1632" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5824" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5871" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5881" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5932" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5992" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6046" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7408" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7581" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12HG7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="11HM7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12BV7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12BY7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12DQ7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12HL7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BW7" prefix="V">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BX6" prefix="V">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BY7" prefix="V">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EH7" prefix="V">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EJ7" prefix="V">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EL7" prefix="V">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6GK7" prefix="V">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EF183" prefix="V">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6688" prefix="VT" uservalue="yes">
<description>Pentode, base 9EQ (6688, etc.)</description>
<gates>
<gate name="A" symbol="PENTODE_9EQ" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="G1" pad="2"/>
<connect gate="A" pin="G3" pad="8"/>
<connect gate="A" pin="H1" pad="4"/>
<connect gate="A" pin="H2" pad="5"/>
<connect gate="A" pin="K1" pad="1"/>
<connect gate="A" pin="K2" pad="3"/>
<connect gate="A" pin="P" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="E180F" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6J4" prefix="VT" uservalue="yes">
<description>Single triode, base 7BQ (6J4)</description>
<gates>
<gate name="A" symbol="TRIODE_7BQ" x="0" y="-2.54"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="A" pad="7"/>
<connect gate="A" pin="G1A" pad="1"/>
<connect gate="A" pin="G1B" pad="5"/>
<connect gate="A" pin="G1C" pad="6"/>
<connect gate="A" pin="H1" pad="3"/>
<connect gate="A" pin="H2" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="8532" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6J5" prefix="VT" uservalue="yes">
<description>Single octal triode (6J5)</description>
<gates>
<gate name="A" symbol="TRIODE_HTR" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="A" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
<connect gate="A" pin="H1" pad="7"/>
<connect gate="A" pin="H2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AC5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AD5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AE5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AF5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6C5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6D5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6L5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6P5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1626" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6C4" prefix="VT" uservalue="yes">
<description>Single mini triode, base 6BG (6C4, 6DR4, etc.)</description>
<gates>
<gate name="A" symbol="TRIODE_6BG" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="G1" pad="6"/>
<connect gate="A" pin="K" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DR4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6100" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6135" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EC90" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6550" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="KT88" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EL84" prefix="VT" uservalue="yes">
<description>Power pentode, base 9CV (EL84, 6BQ5, etc.)</description>
<gates>
</gates>
<devices>
<connects>
<connect gate="A" pin="K_G3" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BQ5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CW5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DY5" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7189" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EL86" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RECT_DH_OCTAL" prefix="VT" uservalue="yes">
<description>Rectifier, octal DH (5U4, etc.)</description>
<gates>
<gate name="A" symbol="RECT_OCTAL" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="P1" pad="4"/>
<connect gate="A" pin="P2" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5U4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5AS4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5DB4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5R4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5T4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5V3" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5W4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5Y3" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5931" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5AR4" prefix="VT" uservalue="yes">
<description>Octal rectifier with cathode (5AR4, GZ34. etc.)</description>
<gates>
<gate name="A" symbol="RECT_OCTAL_IDH" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GZ32" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GZ33" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GZ34" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GZ37" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5V4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5AT4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5CG4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5Z4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6087" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6106" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AS4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AU4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AX4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CQ4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DA4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DE4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DM4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DQ4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DT4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6U4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12D4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AX4" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AY3">
<gates>
<gate name="A" symbol="DIODE_9HP" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CL3">
<gates>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CM3">
<gates>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DQ3" prefix="VT" uservalue="yes">
<description>Power diode, base 12FX (6DQ3, etc.)</description>
<gates>
</gates>
<devices>
<connects>
<connect gate="A" pin="A" pad="4"/>
<connect gate="A" pin="A1" pad="10"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BW3" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BZ3" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1AG4" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6088" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6419" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5619" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6526" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6611" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6612" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="512AX" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="505AX" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DF67" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="520AX" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AS6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AW6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BH6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BJ6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BZ6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CF6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DB6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DC6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DE6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DK6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6EW6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6GM6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6HQ6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6JH6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6JK6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6JL6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6LU6" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5725" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6187" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6265" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6661" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6662" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6676" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="0A3" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="0B3" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="0C3" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="0D3" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AD10" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BF11" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BY11" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6Y10" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AE10" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="13V10" prefix="VT">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AQ8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BC8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BK7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BQ7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BS8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BX8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BZ7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BZ8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6CG7" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6DT8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6FW8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6HK8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6JK8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6KN8" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC85" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC88" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC189" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="E88CC" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AD7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AE7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AT7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AV7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AX7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AY7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AZ7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12BH7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="NOVAL_BOTTOM_PCB">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12BZ7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12DF7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<device name="_TOP" package="NOVAL_PCB">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12DM7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12DT7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12DW7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12FV7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12U7" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5751" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5814" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5963" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5965" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6057" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6060" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6067" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6072" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6189" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6201" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6211" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6414" prefix="V" uservalue="yes">
<gates>
<gate name="A" symbol="TRIODE_9A_A-1" x="0" y="25.4"/>
<gate name="B" symbol="TRIODE_9A_B-1" x="0" y="-20.32"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="2" pad="2"/>
<connect gate="A" pin="3" pad="3"/>
<connect gate="A" pin="4" pad="4"/>
<connect gate="A" pin="5" pad="5"/>
<connect gate="A" pin="9" pad="9"/>
<connect gate="B" pin="6" pad="6"/>
<connect gate="B" pin="7" pad="7"/>
<connect gate="B" pin="8" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6679" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6680" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6681" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6829" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6851" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6913" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7025" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="7247" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC81" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC82" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ECC83" prefix="V" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5687" prefix="V" uservalue="yes">
<description>Dual triode, base 9H
7119, 7044</description>
<gates>
<gate name="A" symbol="TRIODE_9H_A-1" x="0" y="17.78"/>
<gate name="B" symbol="TRIODE_9H_B-1" x="0" y="-22.86"/>
</gates>
<devices>
<device name="" package="NOVAL_PCB">
<connects>
<connect gate="A" pin="8" pad="8"/>
<connect gate="B" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AT6" prefix="VT" uservalue="yes">
<description>Triode plus dual diode, base 7BT</description>
<gates>
<gate name="G$1" symbol="TRIODE_7BT-1" x="0" y="0"/>
</gates>
<devices>
<device name="_TOP" package="MINI7_PCB">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="MINI7_PCB_BOT">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6AV6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BF6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BK6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BT6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6BU6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AE6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12AJ6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12FK6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12FM6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="26C6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6066" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="12FT6" prefix="VT" uservalue="yes">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="6KS6" prefix="V">
<description>Gated beam discriminator, base 7DF</description>
<gates>
<gate name="G$1" symbol="GBDISC_7DF" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MINI7_PCB">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
