; Source created with Parsic Version 3.x
; at              : 2008.09.10. 11:30:56
; Project File    : C:\PROGRA~1\Parsic\Examples\HE\RS_TR.PIC
; Project Version : 1.0.3
; Created         : 2008.09.06. 20:37:00
; Last change     : 2008.09.10. 11:30:33
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV1	= 32	; located in Bank 0
EE1_FD	= 33	; located in Bank 0
ZV2	= 34	; located in Bank 0
EE2_FD	= 35	; located in Bank 0
UD1_FD	= 36	; located in Bank 0
S1	= 37	; located in Bank 0
S0	= 38	; located in Bank 0
OS1_FD	= 39	; located in Bank 0
OS2_FD	= 40	; located in Bank 0
ZV1_FD	= 41	; located in Bank 0
ZV2_FD	= 42	; located in Bank 0
UA1RSFLAG	= 43	; located in Bank 0
OS3_FD	= 44	; located in Bank 0
OS4_FD	= 45	; located in Bank 0
UA1OUTBUF	= 46	; located in Bank 0
UA1OUTBUF1	= 47	; located in Bank 0
UA1OUTBUF2	= 48	; located in Bank 0
UA1OUTBUF3	= 49	; located in Bank 0
UA1OUTBUF4	= 50	; located in Bank 0
RAM	= 51	; located in Bank 0
SYS_TMP1	= 112	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 114	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 115	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
; UART -> UA1
UA1CHKTX
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	BTFSS PIR1,TXIF	; send byte ?
	GOTO UA1ENDINT	; no
	MOVFW UA1OUTBUF+1	; all transmitted ? 
	BTFSC STATUS,ZERO
	GOTO UA1TXINT1
	ERRORLEVEL -312
	BANKISEL UA1OUTBUF	; FILE INDIREKT
	ERRORLEVEL +312
	MOVFW UA1OUTBUF	; pointer
	INCF UA1OUTBUF,F	; pointer+1
	MOVWF FSR
	MOVFW INDF	; data
	MOVWF TXREG	; Transmit Register
	DECF UA1OUTBUF+1,F	; length-1
	GOTO EXITINT	; that's all
UA1TXINT1
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	BTFSS TXSTA,TRMT	; last byte transmitted ?
	GOTO EXITINT	; no
	BCF TXSTA,TXEN	; transmitter off
	BSF UA1RSFLAG,2	; ready
	GOTO EXITINT
UA1ENDINT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
EEINT_WRITE
	MOVFW INDF
EEINT_WRITE_0
	MOVWF EEDATA
	BSF EECON1,WREN
EEINT_DISINT
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO EEINT_DISINT
	MOVLW H'55'
	MOVWF EECON2
	MOVLW H'AA'
	MOVWF EECON2
	BSF EECON1,WR	; start write
	BSF INTCON,GIE
EEINT_WRITE_1
	BTFSC EECON1,WR	; ready ?
	GOTO EEINT_WRITE_1	; no
	BCF EECON1,WREN
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_WRITE
	RETURN
EEINT_READ
	BSF EECON1,RD
	MOVFW EEDATA
	MOVWF INDF
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_READ
	RETURN
; EE-Modul -> EE1
WRITE_EE1
	MOVLW 0
	MOVWF EEADR
	BCF STATUS,IRP	; vars - located in Bank 0
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV1
	MOVWF FSR
	CALL EEINT_WRITE
	RETURN
; EE-Modul -> EE1
READ_EE1
	MOVLW 0
	MOVWF EEADR
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV1
	MOVWF FSR
	CALL EEINT_READ
	RETURN
; EE-Modul -> EE2
WRITE_EE2
	MOVLW 1
	MOVWF EEADR
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_WRITE
	RETURN
; EE-Modul -> EE2
READ_EE2
	MOVLW 1
	MOVWF EEADR
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_READ
	RETURN
;Initialisierung
SYS_INIT
	MOVLW B'00000000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000100'
	MOVWF PORTB
	MOVLW 15
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11111010'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CALL READ_EE1	; read vars from internal EE
	CALL READ_EE2	; read vars from internal EE
; initalisize UA1
	MOVLW B'10010000'	; serial enable,8-bit,continous-enable
	MOVWF RCSTA
	MOVLW 25
	MOVWF SPBRG	; BAUDRATE GENERATOR
	MOVLW B'00000100'	; 8-BIt,TRANSMIT DISABLED,ASYNCHRON,BRGH=1=HIGH SPEED
	MOVWF TXSTA
	BSF PIE1,TXIE	; enable INTERRUPT for transmit
	BSF INTCON,PEIE	; PERIPHERIE INT ENABLE
;******* Haupt-Programm ***********
MAIN
; One Shot -> OS1
	BTFSC PORTA,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S0,1
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S0,1
	BTFSS PORTA,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; One Shot -> OS2
	BTFSC PORTA,1
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S0,3
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S0,3
	BTFSS PORTA,1
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; Zähler -> ZV1
	BTFSS S0,0	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S0,1
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S0,4	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S0,1
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Zähler -> ZV2
	BTFSS S0,2	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S0,3
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S0,3
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Schmitt-Trigger 8-Bit -> ST1
	BTFSC S0,0	; Ausgang gesetzt ?
	GOTO LABEL_ST1_MH	; dann mit Hysterese ?
	MOVLW 16
	GOTO LABEL_ST1_TEST
LABEL_ST1_MH
	MOVLW 16
LABEL_ST1_TEST
	SUBWF ZV1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
	BSF S0,0	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S0,0	; if less
LABEL_ST1_ENDE
; Schmitt-Trigger 8-Bit -> ST2
	BTFSC S0,2	; Ausgang gesetzt ?
	GOTO LABEL_ST2_MH	; dann mit Hysterese ?
	MOVLW 16
	GOTO LABEL_ST2_TEST
LABEL_ST2_MH
	MOVLW 16
LABEL_ST2_TEST
	SUBWF ZV2,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST2_RESET
	BSF S0,2	; if greater or equal
	GOTO LABEL_ST2_ENDE
LABEL_ST2_RESET
	BCF S0,2	; if less
LABEL_ST2_ENDE
; GND
	BCF S0,4	; immer Low
; EE-Modul -> EE1
; Test of falling edge
	BTFSC S0,1
	GOTO LABEL_EE1_SETFD
	BTFSS EE1_FD,0
	BCF EE1_FD,0
	CALL WRITE_EE1
LABEL_EE1_SETFD
; test input
	BTFSS S0,1
	GOTO LABEL_EE1_EXIT
	BSF EE1_FD,0
LABEL_EE1_EXIT
; EE-Modul -> EE2
	BTFSC S0,3
	GOTO LABEL_EE2_SETFD
	BTFSS EE2_FD,0
	BCF EE2_FD,0
	CALL WRITE_EE2
LABEL_EE2_SETFD
; test input
	BTFSS S0,3
	GOTO LABEL_EE2_EXIT
	BSF EE2_FD,0
LABEL_EE2_EXIT
; UDATA -> UD1
	BTFSC S1,0	; active
	GOTO LABEL_UD1_1	; yes
; test positive edge
	BTFSS S0,7
	GOTO LABEL_UD1_SETFD
	BTFSC UD1_FD,0
	BSF UD1_FD,0
	BCF UA1RSFLAG,2		; set not ready
	BSF S1,0	; active
	MOVLW LOW UA1OUTBUF+2	; set pointer (ADRESS)
	MOVWF UA1OUTBUF
	MOVLW H'AA'	; init checksum
	MOVWF UA1OUTBUF+4
	MOVLW 3	; 3 bytes
	MOVWF UA1OUTBUF+1
	BCF INTCON,GIE	; disable interrupts
	BTFSC INTCON,GIE	; disabled ?
	GOTO $-2	; no
	MOVFW ZV1
	MOVWF UA1OUTBUF+2
	ADDWF UA1OUTBUF+4,F
	MOVFW ZV2
	MOVWF UA1OUTBUF+3
	ADDWF UA1OUTBUF+4,F
	BSF TXSTA,TXEN
	BSF INTCON,GIE	; enable interrupts
LABEL_UD1_1
	BTFSS UA1RSFLAG,2	; transmit ready ?
	GOTO LABEL_UD1_2	; no
	BCF S1,0	; not active
LABEL_UD1_2
LABEL_UD1_SETFD
; test negative edge
	BTFSC S0,7
	GOTO LABEL_UD1_EXIT
	BCF UD1_FD,0
LABEL_UD1_EXIT
; ODER - Gatter -> LG1
LABEL_LG1_1
	BTFSC S0,5
	GOTO LABEL_LG1_TRUE
LABEL_LG1_2
	BTFSC S0,6
	GOTO LABEL_LG1_TRUE
LABEL_LG1_FALSE
	BCF S0,7
	GOTO LABEL_LG1_ENDE
LABEL_LG1_TRUE
	BSF S0,7
LABEL_LG1_ENDE
; One Shot -> OS3
	BTFSC S0,1
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S0,5
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S0,5
	BTFSS S0,1
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; One Shot -> OS4
	BTFSC S0,3
	GOTO LABEL_OS4_1
	BTFSC OS4_FD,0
	GOTO LABEL_OS4_1
	BSF OS4_FD,0
	BSF S0,6
	GOTO LABEL_OS4_2
LABEL_OS4_1
	BCF S0,6
	BTFSS S0,3
	GOTO LABEL_OS4_2
	BCF OS4_FD,0
LABEL_OS4_2
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S1,0
	GOTO LABEL_LG2_FALSE
LABEL_LG2_TRUE
	BSF PORTB,0
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF PORTB,0
LABEL_LG2_ENDE
	GOTO MAIN
	ORG H'2100'
	DE 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	END
