; Source created with Parsic Version 3.x
; at              : 2008.09.10. 11:41:24
; Project File    : C:\PROGRA~1\Parsic\Examples\HE\RS_REC.PIC
; Project Version : 1.0.3
; Created         : 2008.09.06. 20:27:00
; Last change     : 2008.09.10. 11:40:37
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
UD1_FD	= 32	; located in Bank 0
S2	= 33	; located in Bank 0
MF1	= 34	; located in Bank 0
MF1_HI	= 35	; located in Bank 0
ADAT1	= 36	; located in Bank 0
ADAT2	= 37	; located in Bank 0
S0	= 38	; located in Bank 0
S1	= 39	; located in Bank 0
UA1RSFLAG	= 40	; located in Bank 0
UA1INBUF	= 41	; located in Bank 0
UA1INBUF1	= 42	; located in Bank 0
UA1INBUF2	= 43	; located in Bank 0
UA1INBUF3	= 44	; located in Bank 0
UA1INBUF4	= 45	; located in Bank 0
UA1INBUF5	= 46	; located in Bank 0
RAM	= 47	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 114	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_0
	INCF MF1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
; UART -> UA1
	BTFSS PIR1,RCIF	; byte received?
	GOTO UA1ENDINT	; no
	MOVFW RCSTA	; error ?
	ANDLW B'110'
	BTFSS STATUS,ZERO
	GOTO UA1RCERROR	; yes
	MOVFW UA1INBUF+1	; all received ? 
	BTFSC STATUS,ZERO	; length =0 ?
	GOTO UA1RCINT2	; yes
	ERRORLEVEL -312
	BANKISEL UA1INBUF
	ERRORLEVEL +312
	MOVFW UA1INBUF
	MOVWF FSR
	INCF UA1INBUF,F	; pointer+1
	MOVFW RCREG	; store
	MOVWF INDF
	ADDWF UA1INBUF+2,F	; checksum
	DECFSZ UA1INBUF+1,F	; length-1
	GOTO EXITINT
	SUBWF UA1INBUF+2,F	; checksum
	BSF UA1RSFLAG,0		; ready
	GOTO EXITINT
UA1RCINT2
	MOVFW RCREG	; trash
	GOTO EXITINT
UA1RCERROR
	MOVFW RCREG	; reset error status
	BCF RCSTA,CREN
	BSF RCSTA,CREN
	BSF UA1RSFLAG,1	; error
	GOTO EXITINT
UA1ENDINT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000100'
	MOVWF PORTB
	MOVLW 15
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11110000'
	MOVWF TRISA
	MOVLW B'00001010'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
; initalisize UA1
	MOVLW B'10010000'	; serial enable,8-bit,continous-enable
	MOVWF RCSTA
	MOVLW 25
	MOVWF SPBRG	; BAUDRATE GENERATOR
	MOVLW B'00000100'	; 8-BIt,TRANSMIT DISABLED,ASYNCHRON,BRGH=1=HIGH SPEED
	MOVWF TXSTA
	BSF PIE1,RCIE	; enable INTERRUPT for receive
	BSF INTCON,PEIE	; PERIPHERIE INT ENABLE
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; UDATA -> UD1
	BTFSC S2,0	; active
	GOTO LABEL_UD1_1	; yes
; test positive edge
	BTFSS S2,1
	GOTO LABEL_UD1_SETFD
	BTFSC UD1_FD,0
	BSF UD1_FD,0
	BCF UA1RSFLAG,0	; set nothing received
	BCF UA1RSFLAG,1	; set no error
	BSF S2,0	; active
	MOVLW LOW UA1INBUF+3	; set pointer (adress)
	MOVWF UA1INBUF
	MOVLW H'AA'	; init checksum
	MOVWF UA1INBUF+2
	MOVLW 3	; 3 bytes
	MOVWF UA1INBUF+1
LABEL_UD1_1
	BTFSC UA1RSFLAG,1	; error ?
	GOTO LABEL_UD1_3	; break
	BTFSS UA1RSFLAG,0	; received ?
	GOTO LABEL_UD1_2	; no
	MOVFW UA1INBUF+2	; checksum
	SUBWF UA1INBUF+5,W	; checksum
	BTFSS STATUS,ZERO
	BCF INTCON,GIE	; disable interrupts
	BTFSC INTCON,GIE	; disabled ?
	GOTO $-2	; no
	MOVFW UA1INBUF+3
	MOVWF ADAT1
	MOVFW UA1INBUF+4
	MOVWF ADAT2
	BSF INTCON,GIE	; enable interrupts
LABEL_UD1_3
	BCF S2,0	; not active
LABEL_UD1_2
LABEL_UD1_SETFD
; test negative edge
	BTFSC S2,1
	GOTO LABEL_UD1_EXIT
	BCF UD1_FD,0
LABEL_UD1_EXIT
; Anzug-Verzögerung -> MF1
	BTFSS S2,0	; Eingang auf Low ?
	GOTO LABEL_MF1_CHKTIME	; Ja
; RESET
	CLRF MF1
	CLRF MF1_HI
	BCF S2,1
	GOTO LABEL_MF1_EXIT	; raus
LABEL_MF1_CHKTIME
	BTFSC S2,1	; Ausgang schon auf High ?
	GOTO LABEL_MF1_EXIT	; Ja
	MOVLW 0
	SUBWF MF1_HI,W
	BTFSS STATUS,CARRY
	GOTO LABEL_MF1_EXIT
	MOVLW 78
	SUBWF MF1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_MF1_EXIT
	BSF S2,1
LABEL_MF1_EXIT
;AF1
	MOVFW ADAT1
	ADDLW 0
	MOVWF S0
LABEL_AF1_EXIT
;AF2
	MOVFW ADAT2
	ADDLW 0
	MOVWF S1
LABEL_AF2_EXIT
; Verteiler -> BV1
	BTFSC S1,0
	GOTO LABEL_BV1_0
	BCF PORTB,4
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF PORTB,4
LABEL_BV1_0_END
	BTFSC S1,1
	GOTO LABEL_BV1_1
	BCF PORTB,5
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF PORTB,5
LABEL_BV1_1_END
	BTFSC S1,2
	GOTO LABEL_BV1_2
	BCF PORTB,6
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF PORTB,6
LABEL_BV1_2_END
	BTFSC S1,3
	GOTO LABEL_BV1_3
	BCF PORTB,7
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF PORTB,7
LABEL_BV1_3_END
; Verteiler -> BV2
	BTFSC S0,0
	GOTO LABEL_BV2_0
	BCF PORTA,0
	GOTO LABEL_BV2_0_END
LABEL_BV2_0
	BSF PORTA,0
LABEL_BV2_0_END
	BTFSC S0,1
	GOTO LABEL_BV2_1
	BCF PORTA,1
	GOTO LABEL_BV2_1_END
LABEL_BV2_1
	BSF PORTA,1
LABEL_BV2_1_END
	BTFSC S0,2
	GOTO LABEL_BV2_2
	BCF PORTA,2
	GOTO LABEL_BV2_2_END
LABEL_BV2_2
	BSF PORTA,2
LABEL_BV2_2_END
	BTFSC S0,3
	GOTO LABEL_BV2_3
	BCF PORTA,3
	GOTO LABEL_BV2_3_END
LABEL_BV2_3
	BSF PORTA,3
LABEL_BV2_3_END
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S2,0
	GOTO LABEL_LG1_FALSE
LABEL_LG1_TRUE
	BSF PORTB,0
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF PORTB,0
LABEL_LG1_ENDE
	GOTO MAIN
	END
