#include <p16F887.inc>
	__CONFIG    _CONFIG1, _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
	__CONFIG    _CONFIG2, _WRT_OFF & _BOR21V
	cblock 0x20
Delay1
Delay2
	endc
	org 0
start:	
	bsf STATUS,RP0 ;bank1
	bsf TRISC,2          	 ;1. Disable the PWM pin (CCPx) output drivers as 
	clrf TRISD				
	movlw .199
	movwf PR2   		 	;2. Set the PWM period by loading the PR2 register.
							; a PR2 periodus regiszterbe betöltjük a periódus értékét
	bcf STATUS,RP0 			;bank0
	clrf CCPR1L
	clrf CCPR1H
	movlw b'10001101' 		
							;3. Configure the CCP module for the PWM mode
					 		;by loading the CCPxCON register with the
					 		;appropriate (kellő) values.
					 	    ;4. Set the PWM duty cycle by loading the CCPRxL
					    	;register and DCxB<1:0> bits of the CCPxCON
					  		;register.
	movwf CCP1CON						
							 ;5. Configure Timer2:
	bcf PIR1,TMR2IF 		;* Clear the TMR2IF interrupt flag bit of the PIR1 register.
	movlw b'101'			 ;* Set the Timer2 prescale value by loading the
							 ;T2CKPS bits of the T2CON register.
					    	;* Enable Timer2 by setting the TMR2ON bit of
					         ;the T2CON register.
	movwf T2CON		       
							;6. Enable PWM output after a new PWM cycle has started:
							; Engedélyezzük a PWM kimenetet miután az új PWM elindult
	btfss PIR1,TMR2IF		 ;* Wait until Timer2 overflows (TMR2IF bit of
							  ;the PIR1 register is set).
	goto $-1				           
	bcf TRISC,2		 		 ;* Enable the CCPx pin output driver by clearing
					 		 ;the associated TRIS bit.
					 		 ; PORTC,2 kimenetre állítva
main:
	movlw b'00000000'  		; bit 9 - 2
	movwf CCPR1L
	bcf CCP1CON,CCP1X  		; bit 1
	bcf CCP1CON,CCP1Y 		 ; bit 0
novekszik:
	incf CCPR1L,f			
	movf CCPR1L,w
	movwf PORTD					
	movlw d'10'		    
	movwf Delay2			
	call delay				
	movf CCPR1L,f
	btfsc STATUS,2			
	goto csokken
	goto novekszik         
csokken	
	decf CCPR1L,f			
	movf CCPR1L,w
	movwf PORTD				
	movlw d'10'		     
	movwf Delay2			
	call delay				
	movf CCPR1L,f
	btfsc STATUS,2			
	goto novekszik
	goto csokken         		
	nop
	goto $-1
delay:
	decfsz    Delay1,f
	goto      delay
	decfsz    Delay2,f
	goto      delay
	return
	end
