gorenje
Gorenje, d.d.
3503 Velenje, p.p.107, SLOVENIA
TECHNICAL INFORMATION
Washing machines and dryers 4-023-0902
Due to better operating reliability of the washing machine plastic tub (587301) upon replacing the bearings, unscrewing the front weight or changing the washing group on the tub, a lighter weight of code 111736 is to be built-in according to the instruction PS-09-02.
In replacing procedure, the weight is screwed down with a torque prescribed in GN-TP-023
Screw delta PT 100x36 T45, of code: 245110
The weight is fixed on its left and right side with the screw delta PT 100x36 T45, of code : 245110, applying the spring washer 34/10,5 of code: 117277
In the middle, the weight is fixed with the screw delta PT 100x38 T45, of code: 587310
Without any washer!
SCREWS HAVE TO BE TIGHTENED WITH A TORQUE PRESCRIBED IN GN-TP-023 'FIXING TORQUES FOR SCREWS'.
