<root>
<document schema='101' license='-1,88263627,K38DMR' title='' description='' target='PIC.12F.12F675' >
	<config data='!0,3ff4%0,4%3,0%4,1%5,1%6,1%7,1%8,1%c,3' clkspd='4000000' simspd='1' usewdt='0' constif='0' />
	<plugins >
		<dll_dbg_icd enabled='0' >
			<data name='debug' value='1' />
			<data name='userpins' value='0' />
			<data name='speed' value='0' />
			<data name='usev9' value='0' />
			<data name='breaks' value='8' />
			<data name='stacks' value='8' />
			<data name='clkport' value='1' />
			<data name='clkbit' value='6' />
			<data name='dataport' value='1' />
			<data name='databit' value='7' />
			<data name='ghostype' value='0' />
			<data name='monitor' value='1' />
			<data name='ictloop' value='0' />
			<data name='ictrate' value='20000' />
			<data name='ictmask' value='0' />
			<data name='anlpres' value='255' />
			<data name='digmask1' value='-1' />
			<data name='digmask2' value='-1' />
		</dll_dbg_icd>
		<dll_models enabled='1' />
		<dll_upgrader enabled='1' />
		<dll_webhelp enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug />
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='Misc' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='0' iconpath='' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='volt' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='false' type='b1' description='' isconst='1' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='tmr' type='s16' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='sec' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='true' type='b1' description='' isconst='1' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='Main' description='' >
						<return name='Return' type='v0' description='' isconst='0' isinit='0' usrinit='' setinit='' />
						<command class_type='call' title='Komponens makró hívása' component='v5__led0' macro='TurnOff' />
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' component='v5__led1' macro='TurnOff' />
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' component='v5__led2' macro='TurnOff' />
						<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' component='v5__led3' macro='TurnOff' />
						<command class_type='call' title='Komponens makró hívása' component='v5__led3' macro='TurnOn' />
						<command class_type='delay' title='Késleltetés' exp='500' type='1' />
						<command class_type='call' title='Komponens makró hívása' component='v5__led3' macro='TurnOff' />
						<command class_type='loop' title='Ciklus' textarea='36,0,511,300' type='0' exp='1' >
							<flowline >
								<command class_type='call' title='Komponens makró hívása' textarea='36,0,511,300' component='v5__adc0' macro='GetByte' >
									<return exp='volt' />
								</command>
								<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' exp='volt &lt; 153' swap='0' >
									<flowline >
										<command class_type='comment' title='' comment='Alacsony Akku led!
' textarea='129,0,129,0' />
										<command class_type='call' title='Komponens makró hívása' component='v5__led1' macro='TurnOff' />
										<command class_type='call' title='Komponens makró hívása' component='v5__led2' macro='TurnOff' />
										<command class_type='delay' title='Késleltetés' exp='29' type='2' />
										<command class_type='delay' title='Késleltetés' exp='1' type='2' />
										<command class_type='comment' title='' comment='kimenet 0,1ms kinyit, majd zár' textarea='12,0,12,0' />
										<command class_type='call' title='Komponens makró hívása' component='v5__led0' macro='TurnOn' />
										<command class_type='delay' title='Késleltetés' exp='100' type='0' />
									</flowline>
									<flowline >
										<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' exp='volt &lt; 170 AND volt &gt;= 153' swap='0' >
											<flowline >
												<command class_type='comment' title='' comment='Nolmár Akku led!
												<command class_type='delay' title='Késleltetés' exp='19' type='2' />
												<command class_type='call' title='Komponens makró hívása' component='v5__led2' macro='TurnOn' />
											</flowline>
											<flowline >
												<command class_type='decision' title='Feltételes elágazás' textarea='36,0,511,300' exp='volt &gt;= 170' swap='0' >
													<flowline >
														<command class_type='comment' title='' comment='Feltöltött akku led!
														<command class_type='delay' title='Késleltetés' exp='9' type='2' />
														<command class_type='call' title='Komponens makró hívása' component='v5__led1' macro='TurnOn' />
													</flowline>
													<flowline />
												</command>
											</flowline>
										</command>
									</flowline>
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='7fdaec78-394e-4ec9-a578-4f1a12a12076' vmin='1' vmaj='1' codename='v5__led0' x='-80' y='24' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.1' />
					<value target='polarity' data='1' />
					<value target='on_color' data='255' />
					<value target='show_label' data='002' />
					<value target='label_property' data='pin' />
					<value target='label_color' data='16777215' />
					<value target='label_scale' data='1.000000' />
					<value target='label_auto_scale' data='0' />
					<value target='label_position' data='003' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='7fdaec78-394e-4ec9-a578-4f1a12a12076' vmin='1' vmaj='1' codename='v5__led1' x='-32' y='24' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.2' />
					<value target='on_color' data='8453975' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='7fdaec78-394e-4ec9-a578-4f1a12a12076' vmin='1' vmaj='1' codename='v5__led2' x='0' y='24' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.4' />
					<value target='on_color' data='65535' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='7fdaec78-394e-4ec9-a578-4f1a12a12076' vmin='1' vmaj='1' codename='v5__led3' x='40' y='24' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.3' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='14683ea8-5a08-4b3a-be2d-3dea3e17e720' vmin='3' vmaj='1' codename='v5__adc0' x='-27.4286' y='-6.4' z='0' xsz='25.1419' ysz='25.1419' zsz='18.45' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='angle_start' data='225.000000' />
					<value target='angle_sweep' data='270.000000' />
					<value target='cap_color' data='192' />
					<value target='point_color' data='16777215' />
					<value target='ScopeTraces' data='0' />
					<value target='channel' data='0' />
					<value target='vrefvol' data='500' />
					<value target='vrefop' data='0' />
					<value target='convspd' data='3' />
					<value target='actime' data='40' />
					<value target='bits' data='10' />
					<value target='bitmul' data='0.004883' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='text' codename='label1' x='40' y='16' z='0' xsz='4.90909' ysz='8' zsz='0' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='Color' data='192' />
					<value target='Background' data='-1' />
					<value target='Font' data='Arial' />
					<value target='Text' data='10-11volt' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='textbox' codename='textbox1' x='8' y='16' z='0.5' xsz='40' ysz='8' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='FontSize' data='7.000000' />
					<value target='AlignX' data='0' />
					<value target='AlignY' data='0' />
					<value target='Text' data='11-13,3volt
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='text' codename='label2' x='-32' y='16' z='0' xsz='8' ysz='8' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='Text' data='13.3-15Volt' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='text' codename='label3' x='-80' y='16' z='0' xsz='8' ysz='8' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='Text' data='Kimenet Tranyo' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<keymap />
	<panel2d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='9737364' img='' style='0' />
		<camera xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='8409120' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='25' />
	</panel3d>
	<layout >
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wAAAAAUAAAA3wQAAFUCAAA' zoom='75' scrollx='0' scrolly='866' flags='0' />
	</layout>
</document>
</root>
