<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="8.6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="50" unitdist="mil" unit="mm" style="lines" multiple="1" display="no" altdistance="5" altunitdist="mil" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="no" active="no"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="91.11" y2="0" width="0" layer="20"/>
<wire x1="91.11" y1="0" x2="91.11" y2="74.92" width="0" layer="20"/>
<wire x1="91.11" y1="74.92" x2="0" y2="74.92" width="0" layer="20"/>
<wire x1="0" y1="74.92" x2="0" y2="0" width="0" layer="20"/>
</plain>
<libraries>
<library name="rcl" urn="urn:adsk.eagle:library:334">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C050-025X075" urn="urn:adsk.eagle:footprint:23148/1" library_version="3">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-5" urn="urn:adsk.eagle:footprint:22845/1" library_version="3">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E5-8,5" urn="urn:adsk.eagle:footprint:22875/1" library_version="3">
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="C025-024X044" urn="urn:adsk.eagle:footprint:23136/1" library_version="3">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10" urn="urn:adsk.eagle:footprint:22992/1" library_version="3">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="RDH/15" urn="urn:adsk.eagle:footprint:23099/1" library_version="3">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="0617/17" urn="urn:adsk.eagle:footprint:23081/1" library_version="3">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="RTRIMT93YB" urn="urn:adsk.eagle:footprint:23273/1" library_version="3">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; VISHAY&lt;p&gt;
Cermet, abgedichtet nach IP67</description>
<wire x1="2.35" y1="-4.75" x2="2.35" y2="4.75" width="0.254" layer="21"/>
<wire x1="2.35" y1="4.75" x2="-2.35" y2="4.75" width="0.254" layer="21"/>
<wire x1="-2.35" y1="4.75" x2="-2.35" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-2.35" y1="-4.75" x2="2.35" y2="-4.75" width="0.254" layer="21"/>
<circle x="-1.05" y="3.45" radius="1.0049" width="0.1524" layer="21"/>
<pad name="1" x="1.27" y="-2.54" drill="0.6096"/>
<pad name="2" x="-1.27" y="0" drill="0.6096"/>
<pad name="3" x="1.27" y="2.54" drill="0.6096"/>
<text x="-2.79" y="-4.89" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.01" y="-4.89" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.2" y1="2.5" x2="-0.9" y2="4.4" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="C050-025X075" urn="urn:adsk.eagle:package:23637/1" type="box" library_version="3">
<description>CAPACITOR
</package3d>
<package3d name="E2,5-5" urn="urn:adsk.eagle:package:23344/1" type="box" library_version="3">
<description>ELECTROLYTIC CAPACITOR
</package3d>
<package3d name="E5-8,5" urn="urn:adsk.eagle:package:23374/1" type="box" library_version="3">
</package3d>
<package3d name="C025-024X044" urn="urn:adsk.eagle:package:23630/1" type="box" library_version="3">
</package3d>
<package3d name="0207/15" urn="urn:adsk.eagle:package:23492/1" type="box" library_version="3">
<description>RESISTOR
type 0207, grid 15mm</description>
</package3d>
<package3d name="VMTA55" urn="urn:adsk.eagle:package:23600/1" type="box" library_version="3">
<description>Bulk Metal® Foil Technology, Tubular Axial Lead Resistors, Meets or Exceeds MIL-R-39005 Requirements
MIL SIZE RNC55
Source: VISHAY .. vta56.pdf</description>
</package3d>
<package3d name="VTA52" urn="urn:adsk.eagle:package:23596/1" type="box" library_version="3">
MIL SIZE RBR52
</package3d>
<package3d name="RTRIMT93YB" urn="urn:adsk.eagle:package:23763/1" type="box" library_version="3">
<description>Trimm resistor VISHAY
</package3d>
<package3d name="P0613/15" urn="urn:adsk.eagle:package:23581/1" type="box" library_version="3">
type 0613, grid 15 mm</description>
</package3d>
<package3d name="0617/17" urn="urn:adsk.eagle:package:23575/1" type="box" library_version="3">
</package3d>
<package3d name="VMTB60" urn="urn:adsk.eagle:package:23607/1" type="box" library_version="3">
MIL SIZE RNC60
</package3d>
<package3d name="RDH/15" urn="urn:adsk.eagle:package:23595/1" type="box" library_version="3">
</package3d>
<package3d name="0207/10" urn="urn:adsk.eagle:package:23491/1" type="box" library_version="3">
</package3d>
<package3d name="0414/15" urn="urn:adsk.eagle:package:23579/1" type="box" library_version="3">
type 0414, grid 15 mm</description>
</package3d>
</packages3d>
</library>
<library name="diode" urn="urn:adsk.eagle:library:210">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DO35Z10" urn="urn:adsk.eagle:footprint:43098/1" library_version="2">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 10.16mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="DO35Z10" urn="urn:adsk.eagle:package:43342/1" type="box" library_version="2">
<description>DIODE
</package3d>
</packages3d>
</library>
<library name="mc34063">
<description>&lt;b&gt;MC34063: 1.5 A, Step-Up/Down/Inverting Switching Regulator&lt;/b&gt;
&lt;p&gt;&lt;b&gt;Doublecheck before using!&lt;/b&gt;&lt;/p&gt;</description>
<packages>
<package name="DIL08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-jack" urn="urn:adsk.eagle:library:154">
<description>&lt;b&gt;Jacks&lt;/b&gt;&lt;p&gt;
Power Connectors&lt;br&gt;
Phone Connectors&lt;br&gt;
Cinch Connectors&lt;br&gt;
<packages>
<package name="SPC4077" urn="urn:adsk.eagle:footprint:7488/1" library_version="1">
<description>&lt;b&gt;DC POWER JACK 2mm&lt;/b&gt;&lt;br&gt; Right Angle, Through Hole, Rated 5A at 16VDC, PC Terminals&lt;p&gt;
Source: www.spctechnology.com .. 84N1161.pdf&lt;br&gt;
Distributor: &lt;b&gt;Farnell (www.Farnell.de)&lt;/b&gt;&lt;br&gt;
Created by Robert Siegler</description>
<wire x1="-10.75" y1="-4.5" x2="-10.75" y2="-3.2" width="0.1" layer="21"/>
<wire x1="-10.75" y1="-3.2" x2="-10.75" y2="3.2" width="0.1" layer="21"/>
<wire x1="-10.75" y1="3.2" x2="-10.75" y2="4.5" width="0.1" layer="21"/>
<wire x1="-7.25" y1="-4.5" x2="-7.25" y2="4" width="0.1" layer="21"/>
<wire x1="-7.25" y1="4" x2="-7.25" y2="4.5" width="0.1" layer="21"/>
<wire x1="-7.25" y1="-4" x2="1.25" y2="-4" width="0.1" layer="51"/>
<wire x1="-7.25" y1="4" x2="1.25" y2="4" width="0.1" layer="21"/>
<wire x1="1.25" y1="-4" x2="1.25" y2="4" width="0.1" layer="51"/>
<wire x1="1.25" y1="-4.5" x2="1.25" y2="-4" width="0.1" layer="51"/>
<wire x1="1.25" y1="4" x2="1.25" y2="4.5" width="0.1" layer="21"/>
<wire x1="-10.75" y1="4.5" x2="1.25" y2="4.5" width="0.1" layer="21"/>
<wire x1="-10.75" y1="-4.5" x2="1.25" y2="-4.5" width="0.1" layer="51"/>
<wire x1="1.25" y1="-4" x2="2.75" y2="-4" width="0.1" layer="51"/>
<wire x1="2.75" y1="-4" x2="3.25" y2="-4" width="0.1" layer="51"/>
<wire x1="1.25" y1="4" x2="2.75" y2="4" width="0.1" layer="21"/>
<wire x1="2.75" y1="4" x2="3.25" y2="4" width="0.1" layer="21"/>
<wire x1="3.25" y1="-4" x2="3.25" y2="4" width="0.1" layer="51"/>
<wire x1="2.75" y1="-4" x2="2.75" y2="4" width="0.1" layer="51"/>
<wire x1="-10.75" y1="3.2" x2="-1.75" y2="3.2" width="0.1" layer="21" style="shortdash"/>
<wire x1="-10.75" y1="-3.2" x2="-1.75" y2="-3.2" width="0.1" layer="21" style="shortdash"/>
<wire x1="-1.75" y1="-3.2" x2="-1.75" y2="-1" width="0.1" layer="21" style="shortdash"/>
<wire x1="-1.75" y1="-1" x2="-1.75" y2="1" width="0.1" layer="21" style="shortdash"/>
<wire x1="-1.75" y1="1" x2="-1.75" y2="3.2" width="0.1" layer="21" style="shortdash"/>
<wire x1="-8.75" y1="-1" x2="-1.75" y2="-1" width="0.1" layer="51" style="shortdash"/>
<wire x1="-8.75" y1="1" x2="-1.75" y2="1" width="0.1" layer="51" style="shortdash"/>
<wire x1="-8.75" y1="-1" x2="-8.75" y2="1" width="0.1" layer="21" curve="-180"/>
<wire x1="2.5" y1="1.75" x2="3.5" y2="1.75" width="0" layer="46"/>
<wire x1="3.5" y1="1.75" x2="3.5" y2="-1.75" width="0" layer="46"/>
<wire x1="3.5" y1="-1.75" x2="2.5" y2="-1.75" width="0" layer="46"/>
<wire x1="2.5" y1="-1.75" x2="2.5" y2="1.75" width="0" layer="46"/>
<wire x1="-3.4" y1="1.5" x2="-2.6" y2="1.5" width="0" layer="46"/>
<wire x1="-2.6" y1="1.5" x2="-2.6" y2="-1.5" width="0" layer="46"/>
<wire x1="-2.6" y1="-1.5" x2="-3.4" y2="-1.5" width="0" layer="46"/>
<wire x1="-3.4" y1="-1.5" x2="-3.4" y2="1.5" width="0" layer="46"/>
<wire x1="-1.5" y1="-4.4" x2="1.5" y2="-4.4" width="0" layer="46"/>
<wire x1="1.5" y1="-4.4" x2="1.5" y2="-5.2" width="0" layer="46"/>
<wire x1="1.5" y1="-5.2" x2="-1.5" y2="-5.2" width="0" layer="46"/>
<wire x1="-1.5" y1="-5.2" x2="-1.5" y2="-4.4" width="0" layer="46"/>
<wire x1="-10.75" y1="-4.5" x2="-2.56" y2="-4.5" width="0.1" layer="21"/>
<wire x1="2.75" y1="-4" x2="3.25" y2="-4" width="0.1" layer="21"/>
<wire x1="3.25" y1="-4" x2="3.25" y2="-2.35" width="0.1" layer="21"/>
<wire x1="3.25" y1="2.35" x2="3.25" y2="4" width="0.1" layer="21"/>
<wire x1="1.25" y1="-2.73" x2="1.25" y2="4" width="0.1" layer="21"/>
<wire x1="2.75" y1="2.35" x2="2.75" y2="4" width="0.1" layer="21"/>
<wire x1="2.75" y1="-4" x2="2.75" y2="-2.35" width="0.1" layer="21"/>
<pad name="2" x="0" y="-4.8" drill="0.8" diameter="2.1844" shape="long"/>
<pad name="1" x="-3" y="0" drill="0.8" diameter="2.1844" shape="long" rot="R90"/>
<pad name="3" x="3" y="0" drill="1" diameter="2.1844" shape="long" rot="R90"/>
<text x="-10.16" y="5.08" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.16" y="-6.35" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.25" y1="-5.05" x2="1.25" y2="-4.55" layer="51"/>
<rectangle x1="2.75" y1="-1.5" x2="3.25" y2="1.5" layer="51"/>
<rectangle x1="-3.1" y1="-1.25" x2="-2.9" y2="1.25" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="SPC4077" urn="urn:adsk.eagle:package:7492/1" type="box" library_version="1">
<description>DC POWER JACK 2mm Right Angle, Through Hole, Rated 5A at 16VDC, PC Terminals
Distributor: Farnell (www.Farnell.de)
</package3d>
</packages3d>
</library>
<library name="inductors" urn="urn:adsk.eagle:library:243">
<description>&lt;b&gt;Inductors and Filters&lt;/b&gt;&lt;p&gt;
Based on the previous library ind-a.lbr&lt;p&gt;
<packages>
<package name="A26GFC" urn="urn:adsk.eagle:footprint:14971/1" library_version="2">
<description>&lt;B&gt;INDUCTOR&lt;/B&gt;&lt;p&gt;
manufacturer Jelonnek</description>
<wire x1="-7.493" y1="-4.826" x2="-1.397" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="7.493" y1="4.826" x2="7.493" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="7.493" y1="4.826" x2="1.397" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="-4.826" x2="-7.493" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.683" x2="-1.397" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="6.35" y1="3.683" x2="1.397" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-3.683" x2="1.397" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-4.826" x2="1.397" y2="-4.826" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-3.683" x2="6.35" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-4.826" x2="7.493" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-4.826" x2="1.4022" y2="-4.821" width="0.1524" layer="51" curve="85.220769"/>
<wire x1="-1.397" y1="4.826" x2="-1.397" y2="3.683" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="4.826" x2="-7.493" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="3.683" x2="-6.35" y2="3.683" width="0.1524" layer="21"/>
<wire x1="1.397" y1="4.826" x2="1.397" y2="3.683" width="0.1524" layer="51"/>
<wire x1="1.397" y1="4.826" x2="-1.397" y2="4.826" width="0.1524" layer="51"/>
<wire x1="-1.4023" y1="4.8211" x2="1.3971" y2="4.8261" width="0.1524" layer="51" curve="-85.221096"/>
<wire x1="-3.81" y1="3.429" x2="-3.81" y2="-3.429" width="0.1524" layer="21" curve="180"/>
<wire x1="3.81" y1="3.429" x2="3.81" y2="-3.429" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.921" y1="3.429" x2="2.921" y2="-3.429" width="0.508" layer="21" curve="-180"/>
<wire x1="2.032" y1="3.429" x2="2.032" y2="-3.429" width="0.508" layer="21" curve="-180"/>
<wire x1="-2.921" y1="3.429" x2="-2.921" y2="-3.429" width="0.508" layer="21" curve="180"/>
<wire x1="-2.032" y1="3.429" x2="-2.032" y2="-3.429" width="0.508" layer="21" curve="180"/>
<wire x1="-4.191" y1="0" x2="-1.9288" y2="3.4863" width="0.508" layer="21" curve="-62.332725"/>
<wire x1="-4.191" y1="0" x2="-1.9001" y2="-3.494" width="0.508" layer="21" curve="66.501338"/>
<wire x1="-2.921" y1="0" x2="-1.5401" y2="-3.5318" width="0.508" layer="21" curve="42.709433"/>
<wire x1="-2.921" y1="0" x2="-1.494" y2="3.5811" width="0.508" layer="21" curve="-43.452148"/>
<wire x1="-1.905" y1="0" x2="-1.1945" y2="3.139" width="0.508" layer="21" curve="-25.50584"/>
<wire x1="-1.905" y1="0" x2="-1.1945" y2="-3.139" width="0.508" layer="21" curve="25.50584"/>
<wire x1="-1.143" y1="0" x2="-0.6665" y2="2.7508" width="0.508" layer="21" curve="-19.65365"/>
<wire x1="-1.143" y1="0" x2="-0.6709" y2="-2.7384" width="0.508" layer="21" curve="19.561456"/>
<wire x1="-0.381" y1="0" x2="-0.065" y2="-2.53" width="0.508" layer="21" curve="14.237501"/>
<wire x1="-0.381" y1="0" x2="-0.0739" y2="2.495" width="0.508" layer="21" curve="-14.036414"/>
<wire x1="0.0739" y1="-2.495" x2="0.381" y2="0" width="0.508" layer="21" curve="14.036414"/>
<wire x1="0.065" y1="2.53" x2="0.381" y2="0" width="0.508" layer="21" curve="-14.237501"/>
<wire x1="0.6709" y1="2.7384" x2="1.143" y2="0" width="0.508" layer="21" curve="-19.561456"/>
<wire x1="0.6665" y1="-2.7508" x2="1.143" y2="0" width="0.508" layer="21" curve="19.65365"/>
<wire x1="1.1945" y1="-3.139" x2="1.905" y2="0" width="0.508" layer="21" curve="25.50584"/>
<wire x1="1.1945" y1="3.139" x2="1.905" y2="0" width="0.508" layer="21" curve="-25.50584"/>
<wire x1="1.5401" y1="3.5572" x2="2.921" y2="0.0254" width="0.508" layer="21" curve="-42.709433"/>
<wire x1="1.494" y1="-3.5557" x2="2.921" y2="0.0254" width="0.508" layer="21" curve="43.452148"/>
<wire x1="1.9288" y1="-3.4863" x2="4.191" y2="0" width="0.508" layer="21" curve="62.332725"/>
<wire x1="1.9001" y1="3.494" x2="4.1909" y2="0" width="0.508" layer="21" curve="-66.502324"/>
<wire x1="2.286" y1="-3.429" x2="-2.286" y2="-3.429" width="0.508" layer="51"/>
<wire x1="1.2446" y1="-2.9718" x2="1.0922" y2="-3.302" width="0.508" layer="51"/>
<wire x1="0.7366" y1="-2.5908" x2="0.508" y2="-3.2004" width="0.508" layer="51"/>
<wire x1="0.127" y1="-2.3114" x2="0" y2="-3.1242" width="0.508" layer="51"/>
<wire x1="0" y1="-3.1242" x2="-0.1016" y2="-2.3114" width="0.508" layer="51"/>
<wire x1="-0.7366" y1="-2.5146" x2="-0.4826" y2="-3.175" width="0.508" layer="51"/>
<wire x1="-1.2446" y1="-2.9718" x2="-1.016" y2="-3.302" width="0.508" layer="51"/>
<wire x1="1.397" y1="3.683" x2="-1.397" y2="3.683" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="3.429" x2="2.286" y2="3.429" width="0.508" layer="51"/>
<wire x1="-1.2446" y1="2.9718" x2="-1.0922" y2="3.302" width="0.508" layer="51"/>
<wire x1="-0.7366" y1="2.5908" x2="-0.508" y2="3.2004" width="0.508" layer="51"/>
<wire x1="-0.127" y1="2.3114" x2="0" y2="3.1242" width="0.508" layer="51"/>
<wire x1="0" y1="3.1242" x2="0.1016" y2="2.3114" width="0.508" layer="51"/>
<wire x1="0.7366" y1="2.5146" x2="0.4826" y2="3.175" width="0.508" layer="51"/>
<wire x1="1.2446" y1="2.9718" x2="1.016" y2="3.302" width="0.508" layer="51"/>
<wire x1="6.35" y1="-3.683" x2="6.35" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.35" y1="2.286" x2="6.35" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.683" x2="-6.35" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="2.286" x2="-6.35" y2="3.683" width="0.1524" layer="21"/>
<pad name="1" x="0" y="3.81" drill="1.1938" shape="long"/>
<pad name="2" x="0" y="-3.81" drill="1.1938" shape="long"/>
<text x="-7.62" y="5.715" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.62" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="A26GFC" urn="urn:adsk.eagle:package:15069/1" type="box" library_version="2">
<description>INDUCTOR
</package3d>
</packages3d>
</library>
<library name="transistor-small-signal" urn="urn:adsk.eagle:library:401">
<description>&lt;b&gt;Small Signal Transistors&lt;/b&gt;&lt;p&gt;
Packages from :&lt;br&gt;
www.infineon.com; &lt;br&gt;
www.semiconductors.com;&lt;br&gt;
www.irf.com&lt;p&gt;
<packages>
<package name="SOT54E" urn="urn:adsk.eagle:footprint:29639/1" library_version="1">
<description>&lt;b&gt;SOT-54&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="-0.9692" y1="2.2098" x2="0.9692" y2="2.2098" width="0.1524" layer="51" curve="-47.3637"/>
<wire x1="-1.631" y1="-1.778" x2="-0.9689" y2="2.2098" width="0.1524" layer="21" curve="-113.782"/>
<wire x1="0.9689" y1="2.2098" x2="1.631" y2="-1.778" width="0.1524" layer="21" curve="-113.782"/>
<wire x1="-1.631" y1="-1.778" x2="1.631" y2="-1.778" width="0.1524" layer="21"/>
<pad name="D" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="G" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="S" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.175" y="0" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
<packages3d>
<package3d name="SOT54E" urn="urn:adsk.eagle:package:29751/1" type="box" library_version="1">
<description>SOT-54
</package3d>
</packages3d>
</library>
<library name="transistor-power" urn="urn:adsk.eagle:library:400">
<description>&lt;b&gt;Power Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="D2PACK" urn="urn:adsk.eagle:footprint:29392/1" library_version="2">
<description>&lt;b&gt;D2PACK&lt;/b&gt;&lt;p&gt;
INTERNATIONAL RECTIFIER, irg4bc15ud-s.pdf</description>
<wire x1="-5.1308" y1="-4.0894" x2="5.1308" y2="-4.0894" width="0.254" layer="21"/>
<wire x1="5.1308" y1="-4.0894" x2="5.1308" y2="4.445" width="0.254" layer="51"/>
<wire x1="5.1308" y1="4.445" x2="3.1242" y2="5.8166" width="0.254" layer="51"/>
<wire x1="3.1242" y1="5.8166" x2="-3.3782" y2="5.8166" width="0.254" layer="51"/>
<wire x1="-3.3782" y1="5.8166" x2="-5.1308" y2="4.699" width="0.254" layer="51"/>
<wire x1="-5.1308" y1="4.699" x2="-5.1308" y2="4.445" width="0.254" layer="51"/>
<wire x1="-5.1308" y1="4.445" x2="-5.1308" y2="-4.0894" width="0.254" layer="51"/>
<wire x1="-5.1308" y1="4.445" x2="5.1308" y2="4.445" width="0.254" layer="51"/>
<wire x1="-5.1308" y1="-4.0894" x2="-5.1308" y2="-2.3114" width="0.254" layer="21"/>
<wire x1="5.1308" y1="-4.0894" x2="5.1308" y2="-2.3114" width="0.254" layer="21"/>
<smd name="1" x="-2.54" y="-8.89" dx="2.0828" dy="3.81" layer="1"/>
<smd name="3" x="2.54" y="-8.89" dx="2.0828" dy="3.81" layer="1"/>
<smd name="2" x="0" y="2.54" dx="11.43" dy="8.89" layer="1"/>
<text x="-5.588" y="7.239" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.0988" y1="-9.525" x2="-1.9812" y2="-8.1026" layer="51"/>
<rectangle x1="-3.2512" y1="-8.1534" x2="-1.8288" y2="-6.731" layer="51"/>
<rectangle x1="-3.2512" y1="-6.731" x2="-1.8288" y2="-4.2418" layer="21"/>
<rectangle x1="1.9812" y1="-9.525" x2="3.0988" y2="-8.1026" layer="51"/>
<rectangle x1="1.8288" y1="-8.1534" x2="3.2512" y2="-6.731" layer="51"/>
<rectangle x1="1.8288" y1="-6.731" x2="3.2512" y2="-4.2418" layer="21"/>
<rectangle x1="-0.7112" y1="-6.731" x2="0.7112" y2="-4.2418" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="D2PACK" urn="urn:adsk.eagle:package:29497/2" type="model" library_version="2">
<description>D2PACK
</package3d>
</packages3d>
</library>
<library name="switch-omron" urn="urn:adsk.eagle:library:377">
<description>&lt;b&gt;Omron Switches&lt;/b&gt;&lt;p&gt;
<packages>
<package name="B3F-31XX" urn="urn:adsk.eagle:footprint:27478/1" library_version="1">
<description>&lt;b&gt;OMRON SWITCH&lt;/b&gt;</description>
<wire x1="3.683" y1="2.667" x2="3.683" y2="0" width="0.1524" layer="51"/>
<wire x1="3.683" y1="0" x2="3.683" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.556" x2="2.54" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-3.683" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-3.683" y2="2.667" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="2.667" x2="-3.429" y2="2.667" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="2.667" x2="-3.429" y2="0" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-3.302" x2="-0.635" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="3.429" y1="0" x2="3.429" y2="2.667" width="0.1524" layer="51"/>
<wire x1="3.429" y1="2.667" x2="3.683" y2="2.667" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.556" x2="-2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.81" x2="-1.27" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.556" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.556" x2="-3.683" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.81" x2="-1.27" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.81" x2="1.27" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-4.191" x2="1.27" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-3.81" x2="1.27" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-3.81" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.302" x2="-0.635" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.302" x2="0.635" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="0.635" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.302" x2="0.635" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.302" x2="3.429" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.254" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.254" x2="-1.905" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.905" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-0.254" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-0.254" x2="0.762" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0" x2="0.762" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0" x2="1.778" y2="0" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="1.778" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.254" x2="2.667" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.667" y1="0" x2="2.667" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.667" y1="0" x2="3.429" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-0.889" x2="-0.762" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-0.889" x2="0.508" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-0.889" x2="1.651" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="0" y1="-1.27" x2="0" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.651" x2="0" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="0" y1="-1.651" x2="0.254" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-0.508" x2="-3.429" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-0.508" x2="-3.429" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.032" x2="-3.429" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-2.032" x2="3.429" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-0.508" x2="3.429" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.508" x2="3.429" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.2606" y="-1.2446" drill="1.016" shape="octagon"/>
<pad name="2" x="2.2606" y="-1.2446" drill="1.016" shape="octagon"/>
<pad name="3" x="-3.5052" y="1.2446" drill="1.4986" diameter="2.159"/>
<pad name="4" x="3.5052" y="1.2446" drill="1.4986" diameter="2.159"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-5.969" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="B3F-31XX" urn="urn:adsk.eagle:package:27487/1" type="box" library_version="1">
<description>OMRON SWITCH</description>
</package3d>
</packages3d>
</library>
<library name="con-lsta" urn="urn:adsk.eagle:library:161">
<description>&lt;b&gt;Female Headers etc.&lt;/b&gt;&lt;p&gt;
Naming:&lt;p&gt;
FE = female&lt;p&gt;
# contacts - # rows&lt;p&gt;
W = angled&lt;p&gt;
<packages>
<package name="FE20W" urn="urn:adsk.eagle:footprint:8169/1" library_version="1">
<description>&lt;b&gt;FEMALE HEADER&lt;/b&gt;</description>
<wire x1="-25.4" y1="1.016" x2="-25.4" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="1.524" x2="-25.4" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="8.89" x2="-23.241" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="8.89" x2="-22.86" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="8.89" x2="-22.479" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="8.89" x2="-20.701" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="8.89" x2="-20.32" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.89" x2="-19.939" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="8.89" x2="-18.161" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="8.89" x2="-17.78" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="8.89" x2="-17.399" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-17.399" y1="8.89" x2="-15.621" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-15.621" y1="8.89" x2="-15.24" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="8.89" x2="-14.859" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.89" x2="-13.081" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="8.89" x2="-12.7" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="1.524" x2="-23.241" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="1.524" x2="-22.86" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="1.524" x2="-22.479" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="1.524" x2="-20.701" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="1.524" x2="-20.32" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="1.524" x2="-19.939" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="1.524" x2="-18.161" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="1.524" x2="-17.78" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.524" x2="-17.399" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-17.399" y1="1.524" x2="-15.621" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-15.621" y1="1.524" x2="-15.24" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="1.524" x2="-14.859" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="1.524" x2="-13.081" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-13.081" y1="1.524" x2="-12.7" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="8.89" x2="-15.24" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="8.89" x2="-17.78" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.89" x2="-20.32" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="8.89" x2="-22.86" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="8.89" x2="-23.241" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-22.479" y1="8.89" x2="-22.479" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-20.701" y1="8.89" x2="-20.701" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-19.939" y1="8.89" x2="-19.939" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-18.161" y1="8.89" x2="-18.161" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-17.399" y1="8.89" x2="-17.399" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-15.621" y1="8.89" x2="-15.621" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-14.859" y1="8.89" x2="-14.859" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-13.081" y1="8.89" x2="-13.081" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-13.081" y1="8.89" x2="-12.7" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="8.89" x2="-12.319" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.89" x2="-12.319" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-12.319" y1="8.89" x2="-10.541" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="8.89" x2="-10.16" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.524" x2="-12.319" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="1.524" x2="-10.541" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="1.524" x2="-10.16" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="8.89" x2="-10.541" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-10.541" y1="8.89" x2="-10.16" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="8.89" x2="-9.779" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="8.89" x2="-8.001" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="8.89" x2="-7.62" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="8.89" x2="-7.62" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="8.89" x2="-9.779" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-10.16" y1="1.524" x2="-9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="1.524" x2="-8.001" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="1.524" x2="-7.62" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="8.89" x2="-5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="8.89" x2="-7.239" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="8.89" x2="-5.461" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="8.89" x2="-5.08" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="8.89" x2="-4.699" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="8.89" x2="-2.921" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="8.89" x2="-2.54" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="8.89" x2="-7.239" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-8.001" y1="8.89" x2="-8.001" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="8.89" x2="-4.699" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-5.461" y1="8.89" x2="-5.461" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-7.239" y1="1.524" x2="-5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.524" x2="-7.239" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="1.524" x2="-2.921" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.524" x2="-2.54" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.524" x2="-4.699" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.524" x2="-2.54" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="8.89" x2="-2.159" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="8.89" x2="-0.381" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="8.89" x2="0" y2="8.89" width="0.1524" layer="21"/>
<wire x1="0" y1="8.89" x2="0.381" y2="8.89" width="0.1524" layer="21"/>
<wire x1="0.381" y1="8.89" x2="2.159" y2="8.89" width="0.1524" layer="21"/>
<wire x1="2.159" y1="8.89" x2="2.54" y2="8.89" width="0.1524" layer="21"/>
<wire x1="2.54" y1="8.89" x2="2.921" y2="8.89" width="0.1524" layer="21"/>
<wire x1="2.921" y1="8.89" x2="4.699" y2="8.89" width="0.1524" layer="21"/>
<wire x1="4.699" y1="8.89" x2="5.08" y2="8.89" width="0.1524" layer="21"/>
<wire x1="5.08" y1="8.89" x2="5.461" y2="8.89" width="0.1524" layer="21"/>
<wire x1="5.461" y1="8.89" x2="7.239" y2="8.89" width="0.1524" layer="21"/>
<wire x1="7.239" y1="8.89" x2="7.62" y2="8.89" width="0.1524" layer="21"/>
<wire x1="7.62" y1="8.89" x2="8.001" y2="8.89" width="0.1524" layer="21"/>
<wire x1="8.001" y1="8.89" x2="9.779" y2="8.89" width="0.1524" layer="21"/>
<wire x1="10.16" y1="8.89" x2="10.16" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.524" x2="-2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.524" x2="-0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.524" x2="0" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0" y1="1.524" x2="0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.54" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.524" x2="2.921" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.524" x2="4.699" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.524" x2="5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.524" x2="5.461" y2="1.524" width="0.1524" layer="21"/>
<wire x1="5.461" y1="1.524" x2="7.239" y2="1.524" width="0.1524" layer="21"/>
<wire x1="7.239" y1="1.524" x2="7.62" y2="1.524" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.524" x2="8.001" y2="1.524" width="0.1524" layer="21"/>
<wire x1="8.001" y1="1.524" x2="9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="9.779" y1="1.524" x2="10.16" y2="1.524" width="0.1524" layer="21"/>
<wire x1="7.62" y1="8.89" x2="7.62" y2="1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="8.89" x2="5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.54" y1="8.89" x2="2.54" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0" y1="8.89" x2="0" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="8.89" x2="-0.381" y2="1.524" width="0.0508" layer="21"/>
<wire x1="0.381" y1="8.89" x2="0.381" y2="1.524" width="0.0508" layer="21"/>
<wire x1="2.159" y1="8.89" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.921" y1="8.89" x2="2.921" y2="1.524" width="0.0508" layer="21"/>
<wire x1="4.699" y1="8.89" x2="4.699" y2="1.524" width="0.0508" layer="21"/>
<wire x1="5.461" y1="8.89" x2="5.461" y2="1.524" width="0.0508" layer="21"/>
<wire x1="7.239" y1="8.89" x2="7.239" y2="1.524" width="0.0508" layer="21"/>
<wire x1="8.001" y1="8.89" x2="8.001" y2="1.524" width="0.0508" layer="21"/>
<wire x1="9.779" y1="8.89" x2="9.779" y2="1.524" width="0.0508" layer="21"/>
<wire x1="9.779" y1="8.89" x2="10.16" y2="8.89" width="0.1524" layer="21"/>
<wire x1="10.16" y1="8.89" x2="10.541" y2="8.89" width="0.1524" layer="21"/>
<wire x1="10.541" y1="8.89" x2="10.541" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-25.4" y1="1.016" x2="25.4" y2="1.016" width="0.1524" layer="21"/>
<wire x1="10.541" y1="8.89" x2="12.319" y2="8.89" width="0.1524" layer="21"/>
<wire x1="12.7" y1="8.89" x2="12.7" y2="1.524" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.524" x2="10.541" y2="1.524" width="0.1524" layer="21"/>
<wire x1="10.541" y1="1.524" x2="12.319" y2="1.524" width="0.1524" layer="21"/>
<wire x1="12.319" y1="1.524" x2="12.7" y2="1.524" width="0.1524" layer="21"/>
<wire x1="12.319" y1="8.89" x2="12.319" y2="1.524" width="0.0508" layer="21"/>
<wire x1="12.319" y1="8.89" x2="12.7" y2="8.89" width="0.1524" layer="21"/>
<wire x1="12.7" y1="8.89" x2="13.081" y2="8.89" width="0.1524" layer="21"/>
<wire x1="13.081" y1="8.89" x2="14.859" y2="8.89" width="0.1524" layer="21"/>
<wire x1="14.859" y1="8.89" x2="15.24" y2="8.89" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.89" x2="15.24" y2="1.524" width="0.1524" layer="21"/>
<wire x1="13.081" y1="8.89" x2="13.081" y2="1.524" width="0.0508" layer="21"/>
<wire x1="12.7" y1="1.524" x2="13.081" y2="1.524" width="0.1524" layer="21"/>
<wire x1="13.081" y1="1.524" x2="14.859" y2="1.524" width="0.1524" layer="21"/>
<wire x1="14.859" y1="1.524" x2="15.24" y2="1.524" width="0.1524" layer="21"/>
<wire x1="17.78" y1="8.89" x2="17.78" y2="1.524" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.89" x2="20.32" y2="1.524" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.89" x2="15.621" y2="8.89" width="0.1524" layer="21"/>
<wire x1="15.621" y1="8.89" x2="17.399" y2="8.89" width="0.1524" layer="21"/>
<wire x1="17.399" y1="8.89" x2="17.78" y2="8.89" width="0.1524" layer="21"/>
<wire x1="17.78" y1="8.89" x2="18.161" y2="8.89" width="0.1524" layer="21"/>
<wire x1="18.161" y1="8.89" x2="19.939" y2="8.89" width="0.1524" layer="21"/>
<wire x1="19.939" y1="8.89" x2="20.32" y2="8.89" width="0.1524" layer="21"/>
<wire x1="15.621" y1="8.89" x2="15.621" y2="1.524" width="0.0508" layer="21"/>
<wire x1="14.859" y1="8.89" x2="14.859" y2="1.524" width="0.0508" layer="21"/>
<wire x1="18.161" y1="8.89" x2="18.161" y2="1.524" width="0.0508" layer="21"/>
<wire x1="17.399" y1="8.89" x2="17.399" y2="1.524" width="0.0508" layer="21"/>
<wire x1="15.621" y1="1.524" x2="17.78" y2="1.524" width="0.1524" layer="21"/>
<wire x1="15.24" y1="1.524" x2="15.621" y2="1.524" width="0.1524" layer="21"/>
<wire x1="18.161" y1="1.524" x2="19.939" y2="1.524" width="0.1524" layer="21"/>
<wire x1="19.939" y1="1.524" x2="20.32" y2="1.524" width="0.1524" layer="21"/>
<wire x1="17.78" y1="1.524" x2="18.161" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="8.89" x2="-2.159" y2="1.524" width="0.0508" layer="21"/>
<wire x1="-2.921" y1="8.89" x2="-2.921" y2="1.524" width="0.0508" layer="21"/>
<wire x1="22.86" y1="8.89" x2="22.86" y2="1.524" width="0.1524" layer="21"/>
<wire x1="25.4" y1="8.89" x2="25.4" y2="1.524" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.89" x2="20.701" y2="8.89" width="0.1524" layer="21"/>
<wire x1="20.701" y1="8.89" x2="22.479" y2="8.89" width="0.1524" layer="21"/>
<wire x1="22.479" y1="8.89" x2="22.86" y2="8.89" width="0.1524" layer="21"/>
<wire x1="22.86" y1="8.89" x2="23.241" y2="8.89" width="0.1524" layer="21"/>
<wire x1="23.241" y1="8.89" x2="25.4" y2="8.89" width="0.1524" layer="21"/>
<wire x1="20.701" y1="8.89" x2="20.701" y2="1.524" width="0.0508" layer="21"/>
<wire x1="23.241" y1="8.89" x2="23.241" y2="1.524" width="0.0508" layer="21"/>
<wire x1="19.939" y1="8.89" x2="19.939" y2="1.524" width="0.0508" layer="21"/>
<wire x1="22.479" y1="8.89" x2="22.479" y2="1.524" width="0.0508" layer="21"/>
<wire x1="20.701" y1="1.524" x2="22.479" y2="1.524" width="0.1524" layer="21"/>
<wire x1="22.479" y1="1.524" x2="22.86" y2="1.524" width="0.1524" layer="21"/>
<wire x1="23.241" y1="1.524" x2="25.4" y2="1.524" width="0.1524" layer="21"/>
<wire x1="20.32" y1="1.524" x2="20.701" y2="1.524" width="0.1524" layer="21"/>
<wire x1="22.86" y1="1.524" x2="23.241" y2="1.524" width="0.1524" layer="21"/>
<wire x1="25.4" y1="1.524" x2="25.4" y2="1.016" width="0.1524" layer="21"/>
<pad name="1" x="-24.13" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-25.4" y="-2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-23.622" y="2.032" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-20.955" y="2.54" size="1.27" layer="21" ratio="10" rot="R90">2</text>
<text x="-13.335" y="2.54" size="1.27" layer="21" ratio="10" rot="R90">5</text>
<text x="-0.635" y="2.54" size="1.27" layer="21" ratio="10" rot="R90">10</text>
<text x="12.065" y="2.54" size="1.27" layer="21" ratio="10" rot="R90">15</text>
<text x="24.765" y="2.54" size="1.27" layer="21" ratio="10" rot="R90">20</text>
<rectangle x1="-24.384" y1="0" x2="-23.876" y2="1.016" layer="51"/>
<rectangle x1="-21.844" y1="0" x2="-21.336" y2="1.016" layer="51"/>
<rectangle x1="-19.304" y1="0" x2="-18.796" y2="1.016" layer="51"/>
<rectangle x1="-16.764" y1="0" x2="-16.256" y2="1.016" layer="51"/>
<rectangle x1="-14.224" y1="0" x2="-13.716" y2="1.016" layer="51"/>
<rectangle x1="-11.684" y1="0" x2="-11.176" y2="1.016" layer="51"/>
<rectangle x1="-9.144" y1="0" x2="-8.636" y2="1.016" layer="51"/>
<rectangle x1="-6.604" y1="0" x2="-6.096" y2="1.016" layer="51"/>
<rectangle x1="-4.064" y1="0" x2="-3.556" y2="1.016" layer="51"/>
<rectangle x1="-1.524" y1="0" x2="-1.016" y2="1.016" layer="51"/>
<rectangle x1="1.016" y1="0" x2="1.524" y2="1.016" layer="51"/>
<rectangle x1="3.556" y1="0" x2="4.064" y2="1.016" layer="51"/>
<rectangle x1="6.096" y1="0" x2="6.604" y2="1.016" layer="51"/>
<rectangle x1="8.636" y1="0" x2="9.144" y2="1.016" layer="51"/>
<rectangle x1="11.176" y1="0" x2="11.684" y2="1.016" layer="51"/>
<rectangle x1="13.716" y1="0" x2="14.224" y2="1.016" layer="51"/>
<rectangle x1="16.256" y1="0" x2="16.764" y2="1.016" layer="51"/>
<rectangle x1="18.796" y1="0" x2="19.304" y2="1.016" layer="51"/>
<rectangle x1="21.336" y1="0" x2="21.844" y2="1.016" layer="51"/>
<rectangle x1="23.876" y1="0" x2="24.384" y2="1.016" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="FE20W" urn="urn:adsk.eagle:package:8215/1" type="box" library_version="1">
<description>FEMALE HEADER</description>
</package3d>
</packages3d>
</library>
<library name="con-phoenix-254" urn="urn:adsk.eagle:library:172">
<description>&lt;b&gt;Phoenix Connectors&lt;/b&gt;&lt;p&gt;
Grid 2.54 mm&lt;p&gt;
<packages>
<package name="2POL254" urn="urn:adsk.eagle:footprint:9305/1" library_version="1">
<description>&lt;b&gt;PHOENIX CONNECTOR&lt;/b&gt;</description>
<wire x1="-2.67" y1="-1.45" x2="2.67" y2="-1.45" width="0.254" layer="21"/>
<wire x1="2.67" y1="-1.45" x2="2.67" y2="1.45" width="0.254" layer="21"/>
<wire x1="2.67" y1="1.45" x2="-2.67" y2="1.45" width="0.254" layer="21"/>
<wire x1="-2.67" y1="1.45" x2="-2.67" y2="-1.45" width="0.254" layer="21"/>
<wire x1="-2.56" y1="1.1" x2="2.56" y2="1.1" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-0.508" x2="-0.762" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-0.254" x2="2.032" y2="0.127" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="1.2" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="1.2" shape="long" rot="R90"/>
<text x="-2.794" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="2POL254" urn="urn:adsk.eagle:package:9320/1" type="box" library_version="1">
<description>PHOENIX CONNECTOR</description>
</package3d>
</packages3d>
</library>
<library name="con-subd" urn="urn:adsk.eagle:library:189">
<description>&lt;b&gt;SUB-D Connectors&lt;/b&gt;&lt;p&gt;
Harting&lt;br&gt;
NorComp&lt;br&gt;
&lt;p&gt;
PREFIX :&lt;br&gt;
H = High density&lt;br&gt;
F = Female&lt;br&gt;
M = Male&lt;p&gt;
NUMBER: Number of pins&lt;p&gt;
SUFFIX :&lt;br&gt;
H = Horizontal&lt;br&gt;
V = Vertical &lt;br&gt;
P = Shield pin on housing&lt;br&gt;
B = No mounting holes&lt;br&gt;
S = Pins individually placeable (Single)&lt;br&gt;
D = Direct mounting &lt;p&gt;
<packages>
<package name="HDM15V" urn="urn:adsk.eagle:footprint:10153/1" library_version="1">
<description>&lt;b&gt;SUB-D&lt;/b&gt;</description>
<wire x1="-7.409" y1="-3.146" x2="-8.197" y2="2.537" width="0.1524" layer="21"/>
<wire x1="6.876" y1="4.137" x2="8.1915" y2="2.5038" width="0.1524" layer="21" curve="-102.298925"/>
<wire x1="8.197" y1="2.511" x2="7.409" y2="-3.121" width="0.1524" layer="21"/>
<wire x1="-6.876" y1="4.137" x2="6.876" y2="4.137" width="0.1524" layer="21"/>
<wire x1="-8.1961" y1="2.5268" x2="-6.876" y2="4.137" width="0.1524" layer="21" curve="-101.30773"/>
<wire x1="-7.4169" y1="-3.1295" x2="-6.114" y2="-4.137" width="0.1524" layer="21" curve="75.428151"/>
<wire x1="-6.114" y1="-4.137" x2="6.114" y2="-4.137" width="0.1524" layer="21"/>
<wire x1="-15.556" y1="-6.288" x2="-14.921" y2="-6.923" width="0.1524" layer="21" curve="90"/>
<wire x1="14.921" y1="-6.923" x2="15.556" y2="-6.288" width="0.1524" layer="21" curve="90"/>
<wire x1="15.556" y1="6.288" x2="15.556" y2="-6.288" width="0.1524" layer="21"/>
<wire x1="14.921" y1="6.923" x2="15.556" y2="6.288" width="0.1524" layer="21" curve="-90"/>
<wire x1="-15.556" y1="6.288" x2="-15.556" y2="-6.288" width="0.1524" layer="21"/>
<wire x1="-15.556" y1="6.288" x2="-14.921" y2="6.923" width="0.1524" layer="21" curve="-90"/>
<wire x1="-14.913" y1="-6.923" x2="14.921" y2="-6.923" width="0.1524" layer="21"/>
<wire x1="14.913" y1="6.923" x2="-14.921" y2="6.923" width="0.1524" layer="21"/>
<wire x1="6.114" y1="-4.137" x2="7.4169" y2="-3.1295" width="0.1524" layer="21" curve="75.428151"/>
<circle x="12.5" y="0" radius="1.651" width="0.1524" layer="21"/>
<circle x="12.5" y="0" radius="2.667" width="0" layer="42"/>
<circle x="12.5" y="0" radius="2.667" width="0" layer="43"/>
<circle x="-12.5" y="0" radius="2.667" width="0" layer="42"/>
<circle x="-12.5" y="0" radius="2.667" width="0" layer="43"/>
<circle x="-12.5" y="0" radius="1.651" width="0.1524" layer="21"/>
<pad name="10" x="3.677" y="0" drill="0.9"/>
<pad name="9" x="1.391" y="0" drill="0.9"/>
<pad name="8" x="-0.895" y="0" drill="0.9"/>
<pad name="7" x="-3.181" y="0" drill="0.9"/>
<pad name="6" x="-5.467" y="0" drill="0.9"/>
<pad name="5" x="4.82" y="1.98" drill="0.9"/>
<pad name="4" x="2.534" y="1.98" drill="0.9"/>
<pad name="3" x="0.248" y="1.98" drill="0.9"/>
<pad name="2" x="-2.038" y="1.98" drill="0.9"/>
<pad name="1" x="-4.324" y="1.98" drill="0.9"/>
<pad name="15" x="4.82" y="-1.98" drill="0.9"/>
<pad name="14" x="2.534" y="-1.98" drill="0.9"/>
<pad name="13" x="0.248" y="-1.98" drill="0.9"/>
<pad name="12" x="-2.038" y="-1.98" drill="0.9"/>
<pad name="11" x="-4.324" y="-1.98" drill="0.9"/>
<text x="-11.43" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.16" y="-6.35" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.12" y="2.035" size="1.27" layer="21" ratio="10">1</text>
<text x="5.985" y="2.135" size="1.016" layer="21" ratio="10">5</text>
<text x="-7.42" y="-0.465" size="1.016" layer="21" ratio="10">6</text>
<text x="4.885" y="-0.465" size="1.016" layer="21" ratio="10">10</text>
<text x="-7.02" y="-2.765" size="1.016" layer="21" ratio="10">15</text>
<text x="5.68" y="-3.005" size="1.016" layer="21" ratio="10">11</text>
<text x="0.032" y="5.349" size="1.27" layer="51" ratio="10">HDF15 CONEC</text>
<text x="-7.239" y="4.826" size="1.27" layer="21">Male</text>
<hole x="-12.5" y="0" drill="3"/>
<hole x="12.5" y="0" drill="3"/>
</package>
</packages>
<packages3d>
<package3d name="HDM15V" urn="urn:adsk.eagle:package:10263/1" type="box" library_version="1">
<description>SUB-D</description>
</package3d>
</packages3d>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="12mil"/>
<param name="mdWirePad" value="12mil"/>
<param name="mdWireVia" value="12mil"/>
<param name="mdPadPad" value="6mil"/>
<param name="mdPadVia" value="6mil"/>
<param name="mdViaVia" value="6mil"/>
<param name="mdSmdPad" value="6mil"/>
<param name="mdSmdVia" value="6mil"/>
<param name="mdSmdSmd" value="6mil"/>
<param name="mdViaViaSameLayer" value="6mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="6mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="22mil"/>
<param name="msDrill" value="0.35mm"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="20mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="20mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="20mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="2"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="checkStop" value="0"/>
<param name="checkValues" value="0"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="a"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="a"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="C1" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C050-025X075" package3d_urn="urn:adsk.eagle:package:23637/1" value="100n" x="34.29" y="11.43" smashed="yes" rot="R180">
<attribute name="NAME" x="31.369" y="14.859" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="SPICEPREFIX" value="C" x="34.29" y="11.43" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="36.449" y="15.494" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C2" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C050-025X075" package3d_urn="urn:adsk.eagle:package:23637/1" value="100n" x="19.05" y="11.43" smashed="yes">
<attribute name="NAME" x="15.621" y="13.081" size="1.27" layer="25" ratio="10"/>
<attribute name="SPICEPREFIX" value="C" x="19.05" y="11.43" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="15.621" y="8.636" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C3" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E2,5-5" package3d_urn="urn:adsk.eagle:package:23344/1" value="1000uF" x="71.12" y="45.72" smashed="yes" rot="R180">
<attribute name="NAME" x="68.707" y="48.26" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="SPICEPREFIX" value="C" x="71.12" y="45.72" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="75.057" y="43.053" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C4" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E2,5-5" package3d_urn="urn:adsk.eagle:package:23344/1" value="100uF 35v." x="45.72" y="46.99" smashed="yes" rot="R90">
<attribute name="NAME" x="43.307" y="49.53" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="SPICEPREFIX" value="C" x="45.72" y="46.99" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="48.387" y="44.323" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C5" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E2,5-5" package3d_urn="urn:adsk.eagle:package:23344/1" value="100uF 35v" x="55.88" y="46.99" smashed="yes" rot="R90">
<attribute name="NAME" x="53.467" y="49.53" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="SPICEPREFIX" value="C" x="55.88" y="46.99" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="59.817" y="44.323" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C6" library="rcl" library_urn="urn:adsk.eagle:library:334" package="E5-8,5" package3d_urn="urn:adsk.eagle:package:23374/1" value="100uF" x="72.39" y="59.69" smashed="yes" rot="R180">
<attribute name="NAME" x="68.2498" y="63.754" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="SPICEPREFIX" value="C" x="72.39" y="59.69" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="74.9046" y="62.7126" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C7" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C050-025X075" package3d_urn="urn:adsk.eagle:package:23637/1" value="100n" x="72.39" y="50.8" smashed="yes">
<attribute name="NAME" x="66.421" y="51.181" size="1.27" layer="25" ratio="10"/>
<attribute name="SPICEPREFIX" value="C" x="72.39" y="50.8" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="71.501" y="48.006" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C8" library="rcl" library_urn="urn:adsk.eagle:library:334" package="C025-024X044" package3d_urn="urn:adsk.eagle:package:23630/1" value="680pF" x="40.64" y="62.23" smashed="yes" rot="R90">
<attribute name="NAME" x="39.243" y="60.452" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="SPICEPREFIX" value="C" x="40.64" y="62.23" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="43.307" y="60.452" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="D1" library="diode" library_urn="urn:adsk.eagle:library:210" package="DO35Z10" package3d_urn="urn:adsk.eagle:package:43342/1" value="1N5819" x="35.56" y="63.5" smashed="yes" rot="R270">
<attribute name="NAME" x="36.83" y="65.786" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="33.02" y="65.786" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="IC1" library="mc34063" package="DIL08" value="MC34063AP" x="49.53" y="64.77" smashed="yes" rot="R270">
<attribute name="NAME" x="46.609" y="70.104" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="48.895" y="68.326" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="J1" library="con-jack" library_urn="urn:adsk.eagle:library:154" package="SPC4077" package3d_urn="urn:adsk.eagle:package:7492/1" value="" x="80.01" y="45.72" smashed="yes" rot="R180">
<attribute name="MF" value="" x="80.01" y="45.72" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="80.01" y="45.72" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="90.17" y="40.64" size="1.27" layer="25" rot="R180"/>
<attribute name="OC_FARNELL" value="unknown" x="80.01" y="45.72" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="80.01" y="45.72" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="90.17" y="52.07" size="1.27" layer="27" rot="R180"/>
</element>
<element name="L1" library="inductors" library_urn="urn:adsk.eagle:library:243" package="A26GFC" package3d_urn="urn:adsk.eagle:package:15069/1" value="min 46uH" x="24.13" y="64.77" smashed="yes" rot="R180">
<attribute name="NAME" x="31.75" y="59.055" size="1.778" layer="25" ratio="10" rot="R180"/>
<attribute name="SPICEPREFIX" value="L" x="24.13" y="64.77" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="VALUE" x="31.75" y="72.39" size="1.778" layer="27" ratio="10" rot="R180"/>
</element>
<element name="Q1" library="transistor-small-signal" library_urn="urn:adsk.eagle:library:401" package="SOT54E" package3d_urn="urn:adsk.eagle:package:29751/1" value="BS170" x="13.97" y="31.75" smashed="yes" rot="R90">
<attribute name="NAME" x="15.875" y="36.83" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="15.875" y="28.575" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="Q2" library="transistor-power" library_urn="urn:adsk.eagle:library:400" package="D2PACK" package3d_urn="urn:adsk.eagle:package:29497/2" value="IRLR024" x="22.86" y="48.26" smashed="yes" rot="MR270">
<attribute name="NAME" x="14.732" y="52.451" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="24.13" y="41.529" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R1" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/1" value="100k" x="12.7" y="60.96" smashed="yes" rot="R90">
<attribute name="NAME" x="11.938" y="60.706" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="SPICEPREFIX" value="R" x="12.7" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="18.7706" y="59.055" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R2" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/1" value="100k" x="11.43" y="43.18" smashed="yes" rot="R270">
<attribute name="NAME" x="8.382" y="42.164" size="1.27" layer="25" ratio="10"/>
<attribute name="SPICEPREFIX" value="R" x="11.43" y="43.18" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="12.9794" y="41.275" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R3" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/1" value="1Mohm" x="7.62" y="16.51" smashed="yes" rot="R90">
<attribute name="NAME" x="6.858" y="17.526" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="SPICEPREFIX" value="R" x="7.62" y="16.51" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="14.9606" y="17.145" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R4" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/1" value="10k" x="60.96" y="53.34" smashed="yes" rot="R270">
<attribute name="NAME" x="56.642" y="53.594" size="1.27" layer="25" ratio="10"/>
<attribute name="SPICEPREFIX" value="R" x="60.96" y="53.34" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="62.5094" y="52.705" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R5" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0207/10" package3d_urn="urn:adsk.eagle:package:23491/1" value="150k" x="48.26" y="54.61" smashed="yes">
<attribute name="NAME" x="45.212" y="56.134" size="1.27" layer="25" ratio="10"/>
<attribute name="SPICEPREFIX" value="R" x="48.26" y="54.61" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="45.9994" y="53.975" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R6" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RDH/15" package3d_urn="urn:adsk.eagle:package:23595/1" value="0.8 ohm 5W" x="6.35" y="50.8" smashed="yes" rot="R90">
<attribute name="NAME" x="7.62" y="49.8856" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="SPICEPREFIX" value="R" x="6.35" y="50.8" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="VALUE" x="3.1242" y="45.212" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R7" library="rcl" library_urn="urn:adsk.eagle:library:334" package="0617/17" package3d_urn="urn:adsk.eagle:package:23575/1" value="0.2ohm 5W" x="66.04" y="68.58" smashed="yes">
<attribute name="NAME" x="57.912" y="72.0344" size="1.27" layer="25" ratio="10"/>
<attribute name="SPICEPREFIX" value="R" x="66.04" y="68.58" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="63.754" y="67.8688" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R8" library="rcl" library_urn="urn:adsk.eagle:library:334" package="RTRIMT93YB" package3d_urn="urn:adsk.eagle:package:23763/1" value="" x="27.94" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="26.86" y="33.27" size="1.27" layer="25"/>
<attribute name="SPICEMODEL" value="X" x="27.94" y="30.48" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="SPICEPREFIXL" value="POT" x="27.94" y="30.48" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="23.05" y="26.47" size="1.27" layer="27"/>
</element>
<element name="S1" library="switch-omron" library_urn="urn:adsk.eagle:library:377" package="B3F-31XX" package3d_urn="urn:adsk.eagle:package:27487/1" value="" x="5.08" y="31.75" smashed="yes" rot="R270">
<attribute name="MF" value="" x="5.08" y="31.75" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="B3F-3100" x="5.08" y="31.75" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="7.62" y="34.29" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="OC_FARNELL" value="959704" x="5.08" y="31.75" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="36M3582" x="5.08" y="31.75" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="VALUE" x="-0.889" y="35.433" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="SV1" library="con-lsta" library_urn="urn:adsk.eagle:library:161" package="FE20W" package3d_urn="urn:adsk.eagle:package:8215/1" value="" x="58.42" y="3.81" smashed="yes" rot="MR180">
<attribute name="MF" value="" x="58.42" y="3.81" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="MPN" value="" x="58.42" y="3.81" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="NAME" x="33.02" y="6.35" size="1.27" layer="26" ratio="10" rot="MR180"/>
<attribute name="OC_FARNELL" value="unknown" x="58.42" y="3.81" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="58.42" y="3.81" size="1.778" layer="28" rot="MR180" display="off"/>
<attribute name="VALUE" x="34.798" y="1.778" size="1.27" layer="28" ratio="10" rot="MR270"/>
</element>
<element name="X2" library="con-phoenix-254" library_urn="urn:adsk.eagle:library:172" package="2POL254" package3d_urn="urn:adsk.eagle:package:9320/1" value="" x="7.62" y="63.5" smashed="yes">
<attribute name="MF" value="" x="7.62" y="63.5" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="7.62" y="63.5" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="4.826" y="65.278" size="1.27" layer="25"/>
<attribute name="OC_FARNELL" value="unknown" x="7.62" y="63.5" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="7.62" y="63.5" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="4.826" y="60.452" size="1.27" layer="27"/>
</element>
<element name="X1" library="con-subd" library_urn="urn:adsk.eagle:library:189" package="HDM15V" package3d_urn="urn:adsk.eagle:package:10263/1" value="" x="57.15" y="26.67" smashed="yes">
<attribute name="MF" value="" x="57.15" y="26.67" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="57.15" y="26.67" size="1.778" layer="27" display="off"/>
<attribute name="NAME" x="45.72" y="34.29" size="1.778" layer="25" ratio="10"/>
<attribute name="OC_FARNELL" value="unknown" x="57.15" y="26.67" size="1.778" layer="27" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="57.15" y="26.67" size="1.778" layer="27" display="off"/>
<attribute name="VALUE" x="46.99" y="20.32" size="1.778" layer="27" ratio="10"/>
</element>
</elements>
<signals>
<signal name="N$1">
<contactref element="C2" pad="1"/>
<contactref element="R3" pad="1"/>
<wire x1="3.8354" y1="15.2146" x2="7.62" y2="11.43" width="1.016" layer="16"/>
<wire x1="7.62" y1="11.43" x2="16.51" y2="11.43" width="1.016" layer="16"/>
<contactref element="S1" pad="2"/>
<wire x1="3.8354" y1="29.4894" x2="3.8354" y2="15.2146" width="1.016" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="C2" pad="2"/>
<contactref element="Q2" pad="3"/>
<contactref element="Q1" pad="S"/>
<contactref element="C5" pad="+"/>
<contactref element="R8" pad="1"/>
<contactref element="C4" pad="+"/>
<contactref element="L1" pad="1"/>
<contactref element="R5" pad="1"/>
<contactref element="C6" pad="-"/>
<contactref element="C7" pad="1"/>
<contactref element="C3" pad="-"/>
<contactref element="J1" pad="1"/>
<contactref element="SV1" pad="1"/>
<contactref element="C1" pad="2"/>
<contactref element="SV1" pad="18"/>
<contactref element="J1" pad="2"/>
<wire x1="25.4" y1="29.21" x2="25.4" y2="33.02" width="1.016" layer="16"/>
<wire x1="25.4" y1="33.02" x2="31.75" y2="39.37" width="1.016" layer="16"/>
<wire x1="31.75" y1="39.37" x2="31.75" y2="45.72" width="1.016" layer="16"/>
<wire x1="31.75" y1="54.61" x2="38.1" y2="54.61" width="1.016" layer="16"/>
<wire x1="38.1" y1="54.61" x2="43.18" y2="54.61" width="1.016" layer="16"/>
<wire x1="31.75" y1="45.72" x2="38.1" y2="45.72" width="1.016" layer="16"/>
<wire x1="38.1" y1="45.72" x2="45.72" y2="45.72" width="1.016" layer="16"/>
<wire x1="45.72" y1="45.72" x2="55.88" y2="45.72" width="1.016" layer="16"/>
<wire x1="38.1" y1="54.61" x2="38.1" y2="45.72" width="1.016" layer="16"/>
<wire x1="34.29" y1="3.81" x2="34.29" y2="8.89" width="1.016" layer="16"/>
<wire x1="34.29" y1="8.89" x2="31.75" y2="11.43" width="1.016" layer="16"/>
<wire x1="31.75" y1="11.43" x2="25.4" y2="11.43" width="1.016" layer="16"/>
<wire x1="25.4" y1="11.43" x2="21.59" y2="11.43" width="1.016" layer="16"/>
<wire x1="24.13" y1="60.96" x2="25.4" y2="60.96" width="1.016" layer="16"/>
<wire x1="25.4" y1="60.96" x2="31.75" y2="54.61" width="1.016" layer="16"/>
<wire x1="25.4" y1="29.21" x2="25.4" y2="11.43" width="1.016" layer="16"/>
<wire x1="13.97" y1="33.02" x2="25.4" y2="33.02" width="1.016" layer="16"/>
<wire x1="55.88" y1="45.72" x2="69.85" y2="45.72" width="1.016" layer="16"/>
<wire x1="69.85" y1="45.72" x2="69.85" y2="53.34" width="1.016" layer="16"/>
<wire x1="69.85" y1="59.69" x2="69.85" y2="53.34" width="1.016" layer="16"/>
<wire x1="69.85" y1="53.34" x2="69.85" y2="50.8" width="1.016" layer="16"/>
<wire x1="77.47" y1="16.51" x2="81.28" y2="20.32" width="1.016" layer="16"/>
<wire x1="81.28" y1="20.32" x2="81.28" y2="31.75" width="1.016" layer="16"/>
<wire x1="81.28" y1="31.75" x2="69.85" y2="43.18" width="1.016" layer="16"/>
<wire x1="69.85" y1="43.18" x2="69.85" y2="45.72" width="1.016" layer="16"/>
<wire x1="77.47" y1="3.81" x2="77.47" y2="16.51" width="1.016" layer="16"/>
<wire x1="83.01" y1="45.72" x2="83.01" y2="47.52" width="1.016" layer="16"/>
<wire x1="83.01" y1="47.52" x2="80.01" y2="50.52" width="1.016" layer="16"/>
<wire x1="80.01" y1="50.52" x2="80.01" y2="52.07" width="1.016" layer="16"/>
<wire x1="80.01" y1="52.07" x2="78.74" y2="53.34" width="1.016" layer="16"/>
<wire x1="78.74" y1="53.34" x2="77.47" y2="53.34" width="1.016" layer="16"/>
<via x="77.47" y="53.34" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="77.47" y1="53.34" x2="69.85" y2="53.34" width="1.016" layer="1"/>
<via x="69.85" y="53.34" extent="1-16" drill="0.35" diameter="1.3"/>
</signal>
<signal name="N$5">
<contactref element="R2" pad="1"/>
<contactref element="R6" pad="1"/>
<contactref element="Q2" pad="2"/>
<wire x1="11.43" y1="48.26" x2="20.32" y2="48.26" width="1.016" layer="16"/>
<wire x1="6.35" y1="43.18" x2="6.35" y2="45.72" width="1.016" layer="16"/>
<wire x1="6.35" y1="45.72" x2="8.89" y2="48.26" width="1.016" layer="16"/>
<wire x1="8.89" y1="48.26" x2="11.43" y2="48.26" width="1.016" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="Q2" pad="1"/>
<contactref element="Q1" pad="D"/>
<contactref element="R1" pad="1"/>
<contactref element="R3" pad="2"/>
<wire x1="12.7" y1="55.88" x2="26.67" y2="55.88" width="1.016" layer="16"/>
<wire x1="26.67" y1="55.88" x2="27.94" y2="54.61" width="1.016" layer="16"/>
<wire x1="7.62" y1="21.59" x2="8.89" y2="21.59" width="1.016" layer="16"/>
<wire x1="8.89" y1="21.59" x2="13.97" y2="26.67" width="1.016" layer="16"/>
<wire x1="13.97" y1="26.67" x2="13.97" y2="30.48" width="1.016" layer="16"/>
<wire x1="13.97" y1="30.48" x2="21.59" y2="30.48" width="1.016" layer="16"/>
<via x="21.59" y="30.48" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="21.59" y1="30.48" x2="21.59" y2="35.56" width="1.016" layer="1"/>
<via x="21.59" y="35.56" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="21.59" y1="35.56" x2="27.94" y2="41.91" width="1.016" layer="16"/>
<wire x1="27.94" y1="41.91" x2="27.94" y2="50.8" width="1.016" layer="16"/>
<wire x1="27.94" y1="50.8" x2="27.94" y2="54.61" width="1.016" layer="16"/>
<wire x1="31.75" y1="50.8" x2="27.94" y2="50.8" width="1.016" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="Q1" pad="G"/>
<contactref element="R2" pad="2"/>
<wire x1="11.43" y1="38.1" x2="11.43" y2="31.75" width="1.016" layer="16"/>
<wire x1="11.43" y1="31.75" x2="12.065" y2="31.75" width="1.016" layer="16"/>
<contactref element="S1" pad="1"/>
<wire x1="3.8354" y1="34.0106" x2="3.8354" y2="36.8554" width="1.016" layer="16"/>
<wire x1="3.8354" y1="36.8554" x2="5.08" y2="38.1" width="1.016" layer="16"/>
<wire x1="5.08" y1="38.1" x2="11.43" y2="38.1" width="1.016" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="R6" pad="2"/>
<contactref element="X2" pad="1"/>
<wire x1="6.35" y1="58.42" x2="6.35" y2="63.5" width="1.016" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="SV1" pad="17"/>
<contactref element="C4" pad="-"/>
<contactref element="C5" pad="-"/>
<contactref element="IC1" pad="4"/>
<contactref element="R4" pad="2"/>
<contactref element="C8" pad="1"/>
<contactref element="D1" pad="A"/>
<contactref element="R8" pad="3"/>
<wire x1="45.72" y1="60.96" x2="40.64" y2="60.96" width="1.016" layer="16"/>
<wire x1="35.56" y1="58.42" x2="38.1" y2="60.96" width="1.016" layer="16"/>
<wire x1="38.1" y1="60.96" x2="40.64" y2="60.96" width="1.016" layer="16"/>
<wire x1="45.72" y1="60.96" x2="45.72" y2="48.26" width="1.016" layer="16"/>
<wire x1="45.72" y1="48.26" x2="50.8" y2="48.26" width="1.016" layer="16"/>
<wire x1="50.8" y1="48.26" x2="55.88" y2="48.26" width="1.016" layer="16"/>
<wire x1="55.88" y1="48.26" x2="60.96" y2="48.26" width="1.016" layer="16"/>
<wire x1="30.48" y1="29.21" x2="30.48" y2="34.29" width="1.016" layer="16"/>
<wire x1="39.37" y1="43.18" x2="50.8" y2="43.18" width="1.016" layer="16"/>
<via x="50.8" y="43.18" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="50.8" y1="43.18" x2="50.8" y2="48.26" width="1.016" layer="1"/>
<wire x1="30.48" y1="34.29" x2="39.37" y2="43.18" width="1.016" layer="16"/>
<via x="50.8" y="48.26" extent="1-16" drill="0.35" diameter="1.3"/>
<contactref element="X1" pad="3"/>
<wire x1="57.398" y1="28.65" x2="57.398" y2="36.582" width="1.016" layer="16"/>
<wire x1="57.398" y1="36.582" x2="50.8" y2="43.18" width="1.016" layer="16"/>
<wire x1="74.93" y1="17.78" x2="78.74" y2="21.59" width="1.016" layer="16"/>
<wire x1="78.74" y1="21.59" x2="78.74" y2="30.48" width="1.016" layer="16"/>
<via x="66.04" y="43.18" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="66.04" y1="43.18" x2="66.04" y2="48.26" width="1.016" layer="1"/>
<via x="66.04" y="48.26" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="66.04" y1="48.26" x2="60.96" y2="48.26" width="1.016" layer="16"/>
<wire x1="74.93" y1="3.81" x2="74.93" y2="17.78" width="1.016" layer="16"/>
<wire x1="78.74" y1="30.48" x2="66.04" y2="43.18" width="1.016" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="IC1" pad="3"/>
<contactref element="C8" pad="2"/>
<wire x1="45.72" y1="63.5" x2="40.64" y2="63.5" width="1.016" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="IC1" pad="2"/>
<contactref element="L1" pad="2"/>
<contactref element="D1" pad="C"/>
<wire x1="45.72" y1="66.04" x2="38.1" y2="66.04" width="1.016" layer="16"/>
<wire x1="38.1" y1="66.04" x2="35.56" y2="68.58" width="1.016" layer="16"/>
<wire x1="35.56" y1="68.58" x2="24.13" y2="68.58" width="1.016" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="IC1" pad="1"/>
<contactref element="IC1" pad="8"/>
<contactref element="IC1" pad="7"/>
<contactref element="R7" pad="1"/>
<wire x1="45.72" y1="68.58" x2="53.34" y2="68.58" width="1.016" layer="16"/>
<wire x1="53.34" y1="68.58" x2="57.15" y2="68.58" width="1.016" layer="16"/>
<wire x1="53.34" y1="68.58" x2="53.34" y2="66.04" width="1.016" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="R4" pad="1"/>
<contactref element="R5" pad="2"/>
<contactref element="IC1" pad="5"/>
<wire x1="53.34" y1="54.61" x2="53.34" y2="60.96" width="1.016" layer="16"/>
<wire x1="53.34" y1="60.96" x2="58.42" y2="60.96" width="1.016" layer="16"/>
<wire x1="58.42" y1="60.96" x2="60.96" y2="58.42" width="1.016" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="R8" pad="2"/>
<contactref element="SV1" pad="3"/>
<wire x1="27.94" y1="31.75" x2="27.94" y2="27.94" width="1.016" layer="16"/>
<wire x1="27.94" y1="27.94" x2="39.37" y2="16.51" width="1.016" layer="16"/>
<wire x1="39.37" y1="16.51" x2="39.37" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="SV1" pad="19"/>
<contactref element="SV1" pad="16"/>
<contactref element="SV1" pad="5"/>
<contactref element="SV1" pad="2"/>
<contactref element="C1" pad="1"/>
<contactref element="R1" pad="2"/>
<contactref element="X2" pad="2"/>
<contactref element="R7" pad="2"/>
<contactref element="IC1" pad="6"/>
<contactref element="C6" pad="+"/>
<contactref element="C7" pad="2"/>
<contactref element="C3" pad="+"/>
<contactref element="J1" pad="3"/>
<wire x1="15.24" y1="72.39" x2="62.23" y2="72.39" width="1.016" layer="16"/>
<wire x1="62.23" y1="72.39" x2="69.85" y2="72.39" width="1.016" layer="16"/>
<wire x1="69.85" y1="72.39" x2="74.93" y2="68.58" width="1.016" layer="16"/>
<wire x1="53.34" y1="63.5" x2="58.42" y2="63.5" width="1.016" layer="16"/>
<wire x1="62.23" y1="67.31" x2="62.23" y2="72.39" width="1.016" layer="16"/>
<wire x1="58.42" y1="63.5" x2="62.23" y2="67.31" width="1.016" layer="16"/>
<wire x1="36.83" y1="7.62" x2="36.83" y2="3.81" width="1.016" layer="16"/>
<wire x1="80.01" y1="7.62" x2="80.01" y2="3.81" width="1.016" layer="16"/>
<via x="80.01" y="7.62" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="80.01" y1="7.62" x2="72.39" y2="7.62" width="1.016" layer="1"/>
<via x="72.39" y="7.62" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="72.39" y1="7.62" x2="72.39" y2="3.81" width="1.016" layer="16"/>
<via x="44.45" y="7.62" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="44.45" y1="7.62" x2="44.45" y2="3.81" width="1.016" layer="16"/>
<wire x1="44.45" y1="7.62" x2="36.83" y2="7.62" width="1.016" layer="1"/>
<via x="36.83" y="7.62" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="36.83" y1="7.62" x2="36.83" y2="11.43" width="1.016" layer="16"/>
<wire x1="80.01" y1="7.62" x2="80.01" y2="15.24" width="1.016" layer="16"/>
<wire x1="80.01" y1="15.24" x2="83.82" y2="19.05" width="1.016" layer="16"/>
<wire x1="83.82" y1="19.05" x2="83.82" y2="33.02" width="1.016" layer="16"/>
<wire x1="77.01" y1="39.83" x2="77.01" y2="45.72" width="1.016" layer="16"/>
<wire x1="83.82" y1="33.02" x2="77.01" y2="39.83" width="1.016" layer="16"/>
<wire x1="77.01" y1="45.72" x2="74.93" y2="45.72" width="1.016" layer="16"/>
<wire x1="74.93" y1="45.72" x2="72.39" y2="45.72" width="1.016" layer="16"/>
<wire x1="74.93" y1="68.58" x2="74.93" y2="50.8" width="1.016" layer="16"/>
<wire x1="74.93" y1="50.8" x2="74.93" y2="59.69" width="1.016" layer="16"/>
<wire x1="74.93" y1="59.69" x2="74.93" y2="45.72" width="1.016" layer="16"/>
<wire x1="44.45" y1="7.62" x2="44.45" y2="10.16" width="1.016" layer="16"/>
<via x="44.45" y="10.16" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="44.45" y1="10.16" x2="72.39" y2="10.16" width="1.016" layer="1"/>
<via x="72.39" y="10.16" extent="1-16" drill="0.35" diameter="1.3"/>
<wire x1="72.39" y1="10.16" x2="72.39" y2="7.62" width="1.016" layer="16"/>
<wire x1="8.89" y1="63.5" x2="10.16" y2="63.5" width="1.016" layer="16"/>
<wire x1="10.16" y1="63.5" x2="12.7" y2="66.04" width="1.016" layer="16"/>
<wire x1="12.7" y1="69.85" x2="15.24" y2="72.39" width="1.016" layer="16"/>
<wire x1="12.7" y1="66.04" x2="12.7" y2="69.85" width="1.016" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="X1" pad="4"/>
<contactref element="SV1" pad="15"/>
<wire x1="59.684" y1="28.65" x2="59.69" y2="28.656" width="1.016" layer="16"/>
<wire x1="59.69" y1="28.656" x2="59.69" y2="30.48" width="1.016" layer="16"/>
<wire x1="59.69" y1="30.48" x2="62.23" y2="33.02" width="1.016" layer="16"/>
<wire x1="72.3392" y1="33.02" x2="76.1492" y2="29.21" width="1.016" layer="16"/>
<wire x1="62.23" y1="33.02" x2="72.3392" y2="33.02" width="1.016" layer="16"/>
<wire x1="76.1492" y1="29.21" x2="76.1492" y2="22.8092" width="1.016" layer="16"/>
<wire x1="76.1492" y1="22.8092" x2="69.85" y2="16.51" width="1.016" layer="16"/>
<wire x1="69.85" y1="16.51" x2="69.85" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="X1" pad="5"/>
<contactref element="SV1" pad="14"/>
<wire x1="61.97" y1="28.65" x2="63.8" y2="30.48" width="1.016" layer="16"/>
<wire x1="63.8" y1="30.48" x2="71.12" y2="30.48" width="1.016" layer="16"/>
<wire x1="71.12" y1="30.48" x2="73.66" y2="27.94" width="1.016" layer="16"/>
<wire x1="73.66" y1="27.94" x2="73.66" y2="24.13" width="1.016" layer="16"/>
<wire x1="73.66" y1="24.13" x2="67.31" y2="17.78" width="1.016" layer="16"/>
<wire x1="67.31" y1="17.78" x2="67.31" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="X1" pad="6"/>
<contactref element="SV1" pad="7"/>
<wire x1="51.683" y1="26.67" x2="50.8" y2="26.67" width="1.016" layer="16"/>
<wire x1="50.8" y1="26.67" x2="49.53" y2="25.4" width="1.016" layer="16"/>
<wire x1="49.53" y1="25.4" x2="49.53" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="X1" pad="10"/>
<contactref element="SV1" pad="13"/>
<wire x1="60.827" y1="26.67" x2="63.5" y2="26.67" width="1.016" layer="16"/>
<wire x1="63.5" y1="26.67" x2="64.77" y2="25.4" width="1.016" layer="16"/>
<wire x1="64.77" y1="25.4" x2="64.77" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="X1" pad="13"/>
<contactref element="SV1" pad="10"/>
<wire x1="57.398" y1="24.69" x2="57.15" y2="24.442" width="1.016" layer="16" curve="90"/>
<wire x1="57.15" y1="24.442" x2="57.15" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="X1" pad="11"/>
<contactref element="SV1" pad="8"/>
<wire x1="52.826" y1="24.69" x2="52.07" y2="23.934" width="1.016" layer="16" curve="90"/>
<wire x1="52.07" y1="23.934" x2="52.07" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="X1" pad="12"/>
<contactref element="SV1" pad="9"/>
<wire x1="55.112" y1="24.69" x2="54.61" y2="24.188" width="1.016" layer="16" curve="90"/>
<wire x1="54.61" y1="24.188" x2="54.61" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="X1" pad="14"/>
<contactref element="SV1" pad="11"/>
<wire x1="59.69" y1="3.81" x2="59.69" y2="24.684" width="1.016" layer="16"/>
<wire x1="59.69" y1="24.684" x2="59.684" y2="24.69" width="1.016" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="X1" pad="15"/>
<contactref element="SV1" pad="12"/>
<wire x1="61.97" y1="24.69" x2="62.23" y2="24.43" width="1.016" layer="16"/>
<wire x1="62.23" y1="24.43" x2="62.23" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="SV1" pad="4"/>
<contactref element="X1" pad="2"/>
<wire x1="41.91" y1="17.78" x2="38.1" y2="21.59" width="1.016" layer="16"/>
<wire x1="41.91" y1="3.81" x2="41.91" y2="17.78" width="1.016" layer="16"/>
<wire x1="38.1" y1="21.59" x2="38.1" y2="30.48" width="1.016" layer="16"/>
<wire x1="38.1" y1="30.48" x2="40.64" y2="33.02" width="1.016" layer="16"/>
<wire x1="40.64" y1="33.02" x2="52.07" y2="33.02" width="1.016" layer="16"/>
<wire x1="55.112" y1="29.978" x2="55.112" y2="28.65" width="1.016" layer="16"/>
<wire x1="52.07" y1="33.02" x2="55.112" y2="29.978" width="1.016" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="X1" pad="1"/>
<contactref element="SV1" pad="6"/>
<wire x1="52.826" y1="28.65" x2="50.996" y2="30.48" width="1.016" layer="16"/>
<wire x1="50.996" y1="30.48" x2="41.91" y2="30.48" width="1.016" layer="16"/>
<wire x1="41.91" y1="30.48" x2="40.64" y2="29.21" width="1.016" layer="16"/>
<wire x1="40.64" y1="29.21" x2="40.64" y2="22.86" width="1.016" layer="16"/>
<wire x1="40.64" y1="22.86" x2="46.99" y2="16.51" width="1.016" layer="16"/>
<wire x1="46.99" y1="16.51" x2="46.99" y2="3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$23">
<via x="5.08" y="5.08" extent="1-16" drill="1" diameter="3"/>
</signal>
<signal name="N$24">
<via x="86.36" y="5.08" extent="1-16" drill="1" diameter="3"/>
</signal>
<signal name="N$25">
<via x="86.36" y="69.85" extent="1-16" drill="1" diameter="3"/>
</signal>
<signal name="N$26">
<via x="5.08" y="69.85" extent="1-16" drill="1" diameter="3"/>
</signal>
</signals>
</board>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
</compatibility>
</eagle>
