<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="50" unitdist="mil" unit="mm" style="lines" multiple="1" display="yes" altdistance="5" altunitdist="mil" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="16" fill="1" visible="no" active="yes"/>
<layer number="3" name="Route3" color="17" fill="1" visible="no" active="yes"/>
<layer number="4" name="Route4" color="18" fill="1" visible="no" active="yes"/>
<layer number="5" name="Route5" color="19" fill="1" visible="yes" active="yes"/>
<layer number="6" name="Route6" color="25" fill="1" visible="no" active="yes"/>
<layer number="7" name="Route7" color="26" fill="1" visible="no" active="yes"/>
<layer number="8" name="Route8" color="27" fill="1" visible="no" active="yes"/>
<layer number="9" name="Route9" color="28" fill="1" visible="no" active="yes"/>
<layer number="10" name="Route10" color="29" fill="1" visible="no" active="yes"/>
<layer number="11" name="Route11" color="30" fill="1" visible="no" active="yes"/>
<layer number="12" name="Route12" color="20" fill="1" visible="no" active="yes"/>
<layer number="13" name="Route13" color="21" fill="1" visible="no" active="yes"/>
<layer number="14" name="Route14" color="22" fill="1" visible="no" active="yes"/>
<layer number="15" name="Route15" color="23" fill="1" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="RV16AF-41">
<pad name="P$1" x="-5.08" y="-5.08" drill="1.2" diameter="2.54"/>
<pad name="P$2" x="0" y="-5.08" drill="1.2" diameter="2.54"/>
<pad name="P$3" x="5.08" y="-5.08" drill="1.2" diameter="2.54"/>
<circle x="0" y="10.922" radius="3.5" width="0.127" layer="21"/>
<wire x1="-6.604" y1="3.81" x2="6.731" y2="3.81" width="0.127" layer="21" curve="-264.27519"/>
<text x="-3.429" y="4.699" size="1.27" layer="25">&gt;NAME</text>
<wire x1="-6.604" y1="3.81" x2="6.731" y2="3.81" width="0.127" layer="21"/>
<wire x1="-7.747" y1="-2.54" x2="-7.747" y2="2.667" width="0.127" layer="21"/>
<wire x1="-7.747" y1="2.667" x2="-6.604" y2="3.81" width="0.127" layer="21"/>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="2.921" width="0.127" layer="21"/>
<wire x1="7.62" y1="2.921" x2="6.731" y2="3.81" width="0.127" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="-6.477" width="0.127" layer="21"/>
<wire x1="-3.556" y1="-2.54" x2="-3.556" y2="-6.477" width="0.127" layer="21"/>
<wire x1="-1.524" y1="-2.54" x2="-1.524" y2="-6.477" width="0.127" layer="21"/>
<wire x1="1.524" y1="-2.54" x2="1.524" y2="-6.477" width="0.127" layer="21"/>
<wire x1="3.556" y1="-2.54" x2="3.556" y2="-6.477" width="0.127" layer="21"/>
<wire x1="6.604" y1="-2.54" x2="6.604" y2="-6.477" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="7.62" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-6.604" y1="-6.477" x2="-3.556" y2="-6.477" width="0.127" layer="21"/>
<wire x1="-1.524" y1="-6.477" x2="1.524" y2="-6.477" width="0.127" layer="21"/>
<wire x1="3.556" y1="-6.477" x2="6.604" y2="-6.477" width="0.127" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="RV16AF-41">
<wire x1="-0.762" y1="2.54" x2="-0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0.762" y1="-2.54" x2="0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="1.651" y2="0" width="0.1524" layer="94"/>
<wire x1="1.651" y1="0" x2="-1.8796" y2="1.7526" width="0.1524" layer="94"/>
<wire x1="0.762" y1="2.54" x2="-0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="-0.762" y1="-2.54" x2="0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-3.048" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-2.032" y2="-1.524" width="0.1524" layer="94"/>
<text x="7.112" y="2.413" size="1.016" layer="95" rot="R180">&gt;NAME</text>
<text x="-3.302" y="-2.794" size="1.016" layer="96" rot="R90">&gt;VALUE</text>
<pin name="A" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="E" x="0" y="5.08" visible="off" length="short" direction="pas" rot="R270"/>
<pin name="S" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<text x="0.508" y="3.302" size="1.27" layer="94">1</text>
<wire x1="-1.876" y1="1.754" x2="-1.494" y2="1.188" width="0.1524" layer="94"/>
<wire x1="-1.256" y1="1.764" x2="-1.884" y2="1.768" width="0.1524" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="RV16AF-41">
<gates>
<gate name="G$1" symbol="RV16AF-41" x="0" y="0"/>
</gates>
<devices>
<device name="" package="RV16AF-41">
<connects>
<connect gate="G$1" pin="A" pad="P$1"/>
<connect gate="G$1" pin="E" pad="P$3"/>
<connect gate="G$1" pin="S" pad="P$2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
