  Example for receiving
  https://github.com/sui77/rc-switch/
  If you want to visualize a telegram copy the raw data and 
  paste it into http://test.sui.li/oszi/
                                      // 31 bit +   25bit                            26bit
#define Code1Up  0b1010010110010101011001010101011 //0100101101001011001100101   01010101010101011010101001 1s
#define Code1Low 0b0100101101001011001100101
#define Code2Up  0b1001101010101001010110100110010 //1011010011001010110100101   01010101011001010110101001 1s
#define Code2Low 0b1011010011001010110100101
#define Code3Up  0b1001100110010110100101011001100 //1100101101001100101100101   01010101010110101001100110 1s
#define Code3Low 0b1100101101001100101100101
#define Code4Up  0b1001101010100110010110011001011 //0100101101001011010100101   01100101011010100101010110 1s
#define Code4Low 0b0100101101001011010100101
unsigned long lastTime = 0; 
uint8_t volatile CodeReceived = 0;
uint8_t  CodeCount = 0;
uint32_t UpperCode = 0;
uint32_t LowerCode = 0;
uint32_t UpperBits = 0;
uint32_t LowerBits = 0;
#define intPin 2
// ************Interrupt rutin************
void handleInterrupt() {
  uint8_t Tol = 60;                    // Tolerancce in microseconds
  unsigned long actTime = micros();
  uint16_t BitCounter;    
  unsigned long sigTime = actTime - lastTime;
  lastTime = actTime;
  if(sigTime < (1200 + Tol) && sigTime > (1200 - Tol))
    UpperCode = 0;
    LowerCode = 0;
    BitCounter = 0;
    CodeReceived = 0;
 if(BitCounter < 60)
  if(digitalRead(intPin) == 1 && sigTime < (200 + Tol) && sigTime > (200 - Tol))
    LowerCode = (LowerCode<<1);
    BitCounter ++;
  else if(digitalRead(intPin) == 1 && sigTime < (400 + Tol) && sigTime > (400 - Tol))
    LowerCode = (LowerCode<<2);
    BitCounter = BitCounter + 2;
  else if(digitalRead(intPin) == 0 && sigTime < (200 + Tol) && sigTime > (200 - Tol))
    LowerCode = (LowerCode<<1) +1;
    BitCounter ++;
  else if(digitalRead(intPin) == 0 && sigTime < (400 + Tol) && sigTime > (400 - Tol))
    LowerCode = (LowerCode<<2) +3;
  if(BitCounter == 31)
    UpperCode = LowerCode;
    LowerCode = 0;
  if(BitCounter == 56)
    UpperBits = UpperCode;
    LowerBits = LowerCode;
    CodeReceived = 1;    
  if(BitCounter == 65530) BitCounter = 60;
void setup() {
  Serial.begin(115200);
  pinMode(intPin, INPUT);
  attachInterrupt(0, handleInterrupt, CHANGE);
void loop() {
  if(CodeReceived)
    if(UpperBits == Code1Up && LowerBits == Code1Low)
      //CODE1 kapcsol
      Serial.println("Adó1 jele érkezett");
      CodeReceived = 0;
    if(UpperBits == Code2Up && LowerBits == Code2Low)
      //CODE2 kapcsol
      Serial.println("Adó2 jele érkezett");
      CodeReceived = 0;
    if(UpperBits == Code3Up && LowerBits == Code3Low)
      //CODE3 kapcsol
      Serial.println("Adó3 jele érkezett");
      CodeReceived = 0;
    if(UpperBits == Code4Up && LowerBits == Code4Low)
      //CODE4 kapcsol
      Serial.println("Adó4 jele érkezett");
      CodeReceived = 0;
