[Setting]
FontName=Tahoma
FontSize=8
[Strings]
{Mini Laser}=΢ܼ
{http://diy8000.taobao.com}=http://diy8000.taobao.com
{Form_Work}=Form_Work
{Port Name}=豸˿
{x}=x
{mm}=
{work area size}=
{pixels per mm}=ÿظ
{milliseconds per pixel}=ÿʱ
{Open Larser Device}=豸
{Y+}=Y+
{X+}=X+
{X-}=X-
{Y-}=Y-
{Load Picture}=ͼƬ
{Start}=ʼ
{Pause}=ͣ
{Stop}=ֹͣ
{Close}=ر
{Can not open port!}=豸ʧ!
{Can not check grbl version! Is port right?}=豸ͨʧ?
{Opening %s ...}= %s ...
{Select a picture file}=ѡһͼƬ
{Continue}=
{Event}=Event
{Print Picture}=λͼӡ
{NC Sender}=·
{Form_NCSender}=Form_NCSender
{Button1}=Button1
{Speed}=ٶ
{Load NC File}=뵶·ļ
{Label2}=Label2
{Create NC File}=·ļ
{Label_Status}=Label_Status
{Pixel Size}=С
{Burning Time}=ʱ
{0:00}=0:00
{Gray Style}=ҶȻ
{Chose the style you liked}=ѡһִӡ
{pixels pre mm}=pixels pre mm
{Chose Gray}=Chose Gray
{work area %d x %d mm}= %d x %d
{Click here to update}=ƹ񷢲°汾°!
{Paste Picture}=ճͼƬ
{Label_Speed}=Label_Speed
{Font}=ѡ
{Required working area is too big!}=޷ʹôļ!
{This file is empty!}=ѡNCļǿյŶûɹɣ
{Need Help?}=ʹð
{My NC Files}=ҵĵ·
{Invert}=
{Flip}=
{All Pictures}=ֵ֧ͼƬ(jpg,png,bmp,tif,wmf,gif,tga)
{GCode File / NC File}=·ļ(*.nc,*.lnc)
{Cut a shape}=иͼ
{Grbl Settings}=GRBL
{Create a new NC file}=µ·ļ
{Full Mode}=ʵģʽ
{Cutting Mode}=ģʽ
{Save}=
{Value}=ֵ
{Item}=Ŀ
{Apply}=Ӧ
{Quick Tagging}=ٴ
{Rename}=
{Delete}=ɾ
{Form_Tag}=Form_Tag
{Text:}=:
{Font Height:}=߶:
{(mm)}=()
{Final text is}=տ̵
{Burn Now}=տ
{Special characters}=תΪǰʱַ
{$y   Year of current time}=$y   ǰʱ
{$m   Month}=$m   ·
{$d   Day}=$d
{$H   Hour}=$H   Сʱ
{$M   Minute}=$M
{$S   Second}=$S
{About ...}= ...
{About}=
{Email:}=Email: jxsoftware@126.com
{Power By:}=: DIY8000 TEAM
{Work Area}=
{Y}=Y
{Default Setting}=Ĭ
{More efficiency setting}=Ч
{Speed:}=ٶ:
{Create image NC file}=ͼ񴴽·
{Create text NC file}=ִ·
{Font Name}=
{Char Height}=߶
{Line Height}=о߶
{Create}=
{Outline }=
{Select Font ...}=ѡ ...
{New Size }=³ߴ
{OK}=ȷ
{Reset}=ԭʼ
{Baud Rate}=
{Auto}=Զ
{Laser On (Strong)}=Լ (ǿ)
{Laser On (Weak)}=Լ ()
{Laser power}=⹦
{My Laser Type}=ʹõļͷͺ
{PWM Laser Power Cotrol (If possible)}=PWM ⹦ʿ (Ҫ̻֧)
{Update Now}=
{Downloading new version}=°汾
{Checking update...}=ڼ...
{Update success!}=ɹ!´δΪ°汾
{can not connect to update host!}=ʧ!
{This is the last version.}=ǰ°汾.
{by diy8000.taobao.com}=by Ա꣺ diy8000.taobao.com
{Export NC File}=˵·
{Form_Machine}=Form_Machine
{Which machine do you have?}=ͼĿǰʹõ豸?
{Detail  >>}=ϸ  >>
{Cancel}=ȡ
{Reverse X axis }=תX᷽
{Reverse Y axis }=תY᷽
{Reverse Z axis }=תZ᷽
{Lite Fire Laser}=Lite Fire Laser
{Download Installer}=ذװʽ
{Language}=Language
{English(US)}=English(US)
{Notice}=ʾ
{Language setting  is saved, restart software to take effect.}=ѱ棬ٴδЧ.
{Downloading Installer}=ذװʽ
{Download success!}=سɹ!
{Weak Light Adjust}=
{Device Settings}=豸
{Back <<<}= <<<
{Form_Device}=Form_Device
{Moving speed  (mm/min)}=ƶٶ  (/)
{Acceleration, mm/sec^2}=ٶ, /^2
{My Machine}=ҵĵ̻
{Friendly Machine List}=ֵ֧ĵ̻б
{X STEPS}=X
{Y STEPS}=Y
{Z STEPS}=Z
{Default Acceleration:Unknow}=Ѽٶ:δ֪
{Default Moving Speed:Unknow}=ƶٶ:δ֪
{XY Steps:Unknow}=XY ײ:δ֪
{Unknow Machine}=δָĻ
{Grbl Settings >>>}=Grbl (ר) >>>
{Appliy machine default settings}=Ӧô˻
{Save Settings}=
{Default Acceleration: }=Ѽٶ:
{Default Moving Speed: }=ƶٶ:
{XY Steps: }=XY :
{Engraver Master}=΢ܼ
{Share and Idea}=봴
{Save As ...}=Ϊ ...
{Copy URL to clipboard}=صַ
{i }=i
{Form_IE}=Form_IE
{Detail}=ϸ
{Clear Pixle}=ӵ
{Form_LoadPicture}=Form_LoadPicture
{Picture Height}=ͼƬ
{Picture Width}=ͼƬ
{Pixels}=
{Next}=һ
{Form_LoadPictureII}=Form_LoadPictureII
{Share something}=Ҫϴ
{Shared Photos}=Ƭ
{Shared Pictures}=ԭͼ
{Go back}=
{Form_Upload}=Form_Upload
{The source picture you want to sahre (optional)}=ҪԭͼΪգ
{The photo of picture printed  you want to show (optional)}=ҪƬΪգ
{Example}=
{Upload Now}=ʼϴ
{Upload success, thank you!}=ϴɹǳл!
{Upload fail!}=ϴʧ!
{Push pen down (mm)}=±ʸ߶ ()
{Use as a Pen Drawing Machine}=Ϊʽͼǣдֻʹ
{Test Size}=λ
{Z+}=Z+
{Z -}=Z -
{Load CAD DXF File}=CAD DXFļ
{GCode File (*.nc;*.cnc;*.ngc;*.ncc;*.tap)}=GCode ļ (*.nc;*.cnc;*.ngc;*.ncc;*.tap)
{AutoCAD DXF (*.dxf), CorelDraw DXF (*.dxf)}=AutoCAD DXF (*.dxf), CorelDraw DXF (*.dxf)
{All files (*.*)}=ļ(*.*)
{Please save this file as a DXF (*.dxf) file first.}=뽫ļȱΪ DXF (*.dxf) ʽٵ.
{Repeats}=ظ
{Next Page}=һҳ
