<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.2.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.01" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.0025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="57" name="tCAD" color="7" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="no" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="no" active="yes"/>
<layer number="103" name="fp3" color="7" fill="1" visible="no" active="yes"/>
<layer number="104" name="Name" color="7" fill="1" visible="no" active="yes"/>
<layer number="105" name="Beschreib" color="9" fill="1" visible="no" active="yes"/>
<layer number="106" name="BGA-Top" color="4" fill="1" visible="no" active="yes"/>
<layer number="107" name="BD-Top" color="5" fill="1" visible="no" active="yes"/>
<layer number="108" name="fp8" color="7" fill="1" visible="no" active="yes"/>
<layer number="109" name="fp9" color="7" fill="1" visible="no" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="no" active="yes"/>
<layer number="111" name="LPC17xx" color="7" fill="1" visible="no" active="yes"/>
<layer number="112" name="tSilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="113" name="ReferenceLS" color="7" fill="1" visible="no" active="no"/>
<layer number="114" name="FRNTMAAT1" color="7" fill="1" visible="no" active="yes"/>
<layer number="115" name="FRNTMAAT2" color="7" fill="1" visible="no" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="no" active="yes"/>
<layer number="117" name="BACKMAAT1" color="7" fill="1" visible="no" active="yes"/>
<layer number="118" name="Rect_Pads" color="7" fill="1" visible="no" active="no"/>
<layer number="119" name="KAP_TEKEN" color="7" fill="1" visible="no" active="yes"/>
<layer number="120" name="KAP_MAAT1" color="7" fill="1" visible="no" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="no" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="no" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="126" name="_bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="127" name="_tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="128" name="_bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="130" name="SMDSTROOK" color="7" fill="1" visible="no" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="no" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="no" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="no" active="yes"/>
<layer number="150" name="Notes" color="7" fill="1" visible="no" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="no" active="yes"/>
<layer number="152" name="_bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="153" name="FabDoc1" color="6" fill="1" visible="no" active="no"/>
<layer number="154" name="FabDoc2" color="2" fill="1" visible="no" active="no"/>
<layer number="155" name="FabDoc3" color="7" fill="15" visible="no" active="no"/>
<layer number="199" name="Contour" color="7" fill="1" visible="no" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="1" visible="no" active="no"/>
<layer number="202" name="202bmp" color="3" fill="1" visible="no" active="no"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="no" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="no" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="no" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="no" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="no" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="no" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="231" name="Eagle3D_PG1" color="7" fill="1" visible="no" active="no"/>
<layer number="232" name="Eagle3D_PG2" color="7" fill="1" visible="no" active="no"/>
<layer number="233" name="Eagle3D_PG3" color="7" fill="1" visible="no" active="no"/>
<layer number="248" name="Housing" color="7" fill="1" visible="no" active="yes"/>
<layer number="249" name="Edge" color="7" fill="1" visible="no" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="no" active="yes"/>
<layer number="255" name="Accent" color="7" fill="1" visible="no" active="yes"/>
</layers>
<board>
<plain>
<text x="38.1" y="14.351" size="1.4224" layer="25" font="vector" rot="R90">Audio AMP vT2</text>
<hole x="35.1155" y="8.8265" drill="3.3"/>
<hole x="35.1155" y="32.9565" drill="3.3"/>
<text x="6.9596" y="14.8463" size="1.27" layer="25" font="vector" rot="R90">ON</text>
<text x="21.2725" y="35.306" size="1.27" layer="25" font="vector" rot="R270">GND</text>
<text x="8.2296" y="20.9677" size="1.27" layer="25" font="vector" rot="R270">AN</text>
<text x="8.255" y="8.7249" size="1.27" layer="25" font="vector" rot="R270">GND</text>
<text x="5.715" y="8.6233" size="1.27" layer="25" font="vector" rot="R270">+5V</text>
<text x="28.2575" y="33.7185" size="1.27" layer="25" font="vector" rot="R270">IN</text>
<text x="37.5793" y="3.4925" size="1.016" layer="16" font="vector" rot="MR0">B-Amp</text>
<wire x1="43.942" y1="41.656" x2="43.942" y2="0" width="0.254" layer="20"/>
<wire x1="43.942" y1="0" x2="0" y2="0" width="0.254" layer="20"/>
<wire x1="0" y1="0" x2="0" y2="41.656" width="0.254" layer="20"/>
<wire x1="0" y1="41.656" x2="43.942" y2="41.656" width="0.254" layer="20"/>
<text x="1.27" y="23.622" size="1.778" layer="21" font="vector" rot="R270">Audio_AMP_v40W</text>
<text x="37.3507" y="39.6875" size="1.016" layer="1" font="vector" rot="R180">T-Amp</text>
<text x="1.27" y="32.258" size="1.016" layer="21" font="vector">+24V</text>
<text x="22.352" y="31.496" size="1.016" layer="21" font="vector" rot="R90">GND</text>
<text x="28.702" y="6.35" size="1.016" layer="21" font="vector" rot="R180">SPK OUT</text>
<text x="5.334" y="20.066" size="1.016" layer="21" font="vector">ON</text>
<text x="8.128" y="20.066" size="1.016" layer="21" font="vector">AN</text>
<text x="5.08" y="1.016" size="0.8128" layer="21" font="vector">+5V</text>
<text x="28.194" y="33.528" size="1.016" layer="21" font="vector" rot="R270">IN</text>
<text x="10.541" y="1.0795" size="0.8128" layer="21" font="vector">GND</text>
<text x="10.033" y="1.8415" size="0.8128" layer="21" font="vector" rot="R180">GND</text>
</plain>
<libraries>
<library name="resistor">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;tr valign="top"&gt;
&lt;/td&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="C0805K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="1" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1" y="0.875" size="1.016" layer="25">&gt;NAME</text>
<text x="-1" y="-1.9" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
</packages>
</library>
<library name="rcl">
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;/ul&gt;
&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;P&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
  &lt;TR&gt;
      &lt;P&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
    &lt;/TD&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="R2010">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="-1.027" y1="1.245" x2="1.027" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.002" y1="-1.245" x2="1.052" y2="-1.245" width="0.1524" layer="21"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-3.175" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="E5-10,5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
</package>
<package name="R2512">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="E3,5-8">
grid 3.5 mm, diameter 8 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="C0805">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="E5-13">
grid 5.08 mm, diameter 13 mm</description>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-0.889" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.27" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.445" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="6.985" width="0.1524" layer="21"/>
<text x="6.3754" y="4.1148" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-3.937" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.889" y2="1.27" layer="21"/>
</package>
<package name="RTRIMT93XB">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; VISHAY&lt;p&gt;
Cermet, abgedichtet nach IP67</description>
<wire x1="1.9182" y1="-4.75" x2="1.9182" y2="4.75" width="0.254" layer="21"/>
<wire x1="1.9182" y1="4.75" x2="-1.8928" y2="4.75" width="0.254" layer="21"/>
<wire x1="-1.8928" y1="4.75" x2="-1.8928" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-1.8928" y1="-4.75" x2="1.9182" y2="-4.75" width="0.254" layer="21"/>
<pad name="1" x="1.27" y="-2.54" drill="1.2" diameter="2.1"/>
<pad name="2" x="-1.27" y="0" drill="1.2" diameter="2.1"/>
<pad name="3" x="1.27" y="2.54" drill="1.2" diameter="2.1"/>
<text x="-2.79" y="-4.89" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.01" y="-4.89" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SOT23-5">
<description>&lt;b&gt;Small Outline Transistor&lt;/b&gt;, 5 lead</description>
<wire x1="-1.544" y1="0.713" x2="1.544" y2="0.713" width="0.1524" layer="51"/>
<wire x1="1.544" y1="0.713" x2="1.544" y2="-0.712" width="0.1524" layer="21"/>
<wire x1="1.544" y1="-0.712" x2="-1.544" y2="-0.712" width="0.1524" layer="51"/>
<wire x1="-1.544" y1="-0.712" x2="-1.544" y2="0.713" width="0.1524" layer="21"/>
<smd name="5" x="-0.95" y="1.306" dx="0.6" dy="1.2" layer="1"/>
<smd name="4" x="0.95" y="1.306" dx="0.6" dy="1.2" layer="1"/>
<smd name="1" x="-0.95" y="-1.306" dx="0.6" dy="1.2" layer="1"/>
<smd name="2" x="0" y="-1.306" dx="0.6" dy="1.2" layer="1"/>
<smd name="3" x="0.95" y="-1.306" dx="0.6" dy="1.2" layer="1"/>
<text x="-1.778" y="-1.778" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.048" y="-1.778" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.1875" y1="0.7126" x2="-0.7125" y2="1.5439" layer="51"/>
<rectangle x1="0.7125" y1="0.7126" x2="1.1875" y2="1.5439" layer="51"/>
<rectangle x1="-1.1875" y1="-1.5437" x2="-0.7125" y2="-0.7124" layer="51"/>
<rectangle x1="-0.2375" y1="-1.5437" x2="0.2375" y2="-0.7124" layer="51"/>
<rectangle x1="0.7125" y1="-1.5437" x2="1.1875" y2="-0.7124" layer="51"/>
</package>
</packages>
</library>
<library name="jumper">
<description>&lt;b&gt;Jumpers&lt;/b&gt;&lt;p&gt;
<packages>
<package name="JP1">
<description>&lt;b&gt;JUMPER&lt;/b&gt;</description>
<wire x1="-1.016" y1="0" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.54" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="1.016" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-1.27" drill="0.9144" shape="square"/>
<pad name="2" x="0" y="1.27" drill="0.9144" shape="square"/>
<text x="-1.651" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.921" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="0.9652" x2="0.3048" y2="1.5748" layer="51"/>
<rectangle x1="-0.3048" y1="-1.5748" x2="0.3048" y2="-0.9652" layer="51"/>
</package>
</packages>
</library>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="CHIPLED_0805">
<description>&lt;b&gt;CHIPLED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LG_R971.pdf</description>
<wire x1="-0.35" y1="0.925" x2="0.35" y2="0.925" width="0.1016" layer="51" curve="162.394521"/>
<wire x1="-0.35" y1="-0.925" x2="0.35" y2="-0.925" width="0.1016" layer="51" curve="-162.394521"/>
<wire x1="0.575" y1="0.525" x2="0.575" y2="-0.525" width="0.1016" layer="51"/>
<wire x1="-0.575" y1="-0.5" x2="-0.575" y2="0.925" width="0.1016" layer="51"/>
<circle x="-0.45" y="0.85" radius="0.103" width="0.1016" layer="51"/>
<smd name="C" x="0" y="1.05" dx="1.2" dy="1.2" layer="1"/>
<smd name="A" x="0" y="-1.05" dx="1.2" dy="1.2" layer="1"/>
<text x="-1.27" y="-1.27" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.54" y="-1.27" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="0.3" y1="0.5" x2="0.625" y2="1" layer="51"/>
<rectangle x1="-0.325" y1="0.5" x2="-0.175" y2="0.75" layer="51"/>
<rectangle x1="0.175" y1="0.5" x2="0.325" y2="0.75" layer="51"/>
<rectangle x1="-0.2" y1="0.5" x2="0.2" y2="0.675" layer="51"/>
<rectangle x1="0.3" y1="-1" x2="0.625" y2="-0.5" layer="51"/>
<rectangle x1="-0.625" y1="-1" x2="-0.3" y2="-0.5" layer="51"/>
<rectangle x1="0.175" y1="-0.75" x2="0.325" y2="-0.5" layer="51"/>
<rectangle x1="-0.325" y1="-0.75" x2="-0.175" y2="-0.5" layer="51"/>
<rectangle x1="-0.2" y1="-0.675" x2="0.2" y2="-0.5" layer="51"/>
<rectangle x1="-0.6" y1="0.5" x2="-0.3" y2="0.8" layer="51"/>
<rectangle x1="-0.625" y1="0.925" x2="-0.3" y2="1" layer="51"/>
<wire x1="-0.3175" y1="0.3175" x2="0.3175" y2="0.3175" width="0.127" layer="21"/>
</package>
</packages>
</library>
<library name="Audio-Power-amlifier">
<packages>
<package name="TA11B">
<description>&lt;b&gt;TO-220&lt;/b&gt;&lt;p&gt;
11 lead, National Semiconductor</description>
<wire x1="4.6482" y1="-4.445" x2="5.5626" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="1.2446" y1="-4.445" x2="2.159" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-4.445" x2="-1.2446" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.5626" y1="-4.445" x2="-4.6482" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.27" x2="10.16" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.27" x2="-10.16" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-4.445" x2="10.16" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.0518" y1="-4.445" x2="-10.16" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.0518" y1="-4.445" x2="-5.5626" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="-4.6482" y1="-4.445" x2="-2.159" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="-1.2446" y1="-4.445" x2="1.2446" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="4.6482" y1="-4.445" x2="2.159" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="8.0518" y1="-4.445" x2="5.5626" y2="-4.445" width="0.1524" layer="51"/>
<circle x="-9.6266" y="-3.9624" radius="0.254" width="0.0508" layer="21"/>
<pad name="1" x="-8.509" y="-9.525" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-6.8072" y="-4.4704" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-5.1054" y="-9.525" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-3.4036" y="-4.4704" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-1.7018" y="-9.525" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="1.7018" y="-9.525" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="5.1054" y="-9.525" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="8.509" y="-9.525" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="0" y="-4.4704" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="3.4036" y="-4.4704" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="6.8072" y="-4.4704" drill="1.016" shape="long" rot="R90"/>
<text x="-9.652" y="-12.446" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-12.446" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.287" y1="-1.27" x2="10.287" y2="0" layer="21"/>
<rectangle x1="-8.89" y1="-8.255" x2="-8.128" y2="-4.445" layer="21"/>
<rectangle x1="-5.4864" y1="-8.255" x2="-4.7244" y2="-4.445" layer="21"/>
<rectangle x1="-2.0828" y1="-8.255" x2="-1.3208" y2="-4.445" layer="21"/>
<rectangle x1="1.3208" y1="-8.255" x2="2.0828" y2="-4.445" layer="21"/>
<rectangle x1="4.7244" y1="-8.255" x2="5.4864" y2="-4.445" layer="21"/>
<rectangle x1="8.128" y1="-8.255" x2="8.89" y2="-4.445" layer="21"/>
<rectangle x1="8.128" y1="-9.652" x2="8.89" y2="-8.255" layer="51"/>
<rectangle x1="4.7244" y1="-9.652" x2="5.4864" y2="-8.255" layer="51"/>
<rectangle x1="1.3208" y1="-9.652" x2="2.0828" y2="-8.255" layer="51"/>
<rectangle x1="-2.0828" y1="-9.652" x2="-1.3208" y2="-8.255" layer="51"/>
<rectangle x1="-5.4864" y1="-9.652" x2="-4.7244" y2="-8.255" layer="51"/>
<rectangle x1="-8.89" y1="-9.652" x2="-8.128" y2="-8.255" layer="51"/>
</package>
</packages>
</library>
<library name="transistor-npn">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SOT23-BEC">
<description>TO-236 ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="transistor-power">
<description>&lt;b&gt;Power Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO220BV">
<description>&lt;b&gt;Molded Package&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="G" x="-2.54" y="-2.54" drill="1.2" shape="long" rot="R90"/>
<pad name="D" x="0" y="-2.54" drill="1.2" shape="long" rot="R90"/>
<pad name="S" x="2.54" y="-2.54" drill="1.2" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
</library>
<library name="jumperr">
<packages>
<package name="SJ">
<description>&lt;b&gt;Solder jumper&lt;/b&gt;</description>
<wire x1="1.397" y1="-1.016" x2="-1.397" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.397" y1="1.016" x2="1.651" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.651" y1="0.762" x2="-1.397" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.651" y1="-0.762" x2="-1.397" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.397" y1="-1.016" x2="1.651" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.397" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0" x2="-1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-0.127" x2="-0.254" y2="0.127" width="1.27" layer="51" curve="-180" cap="flat"/>
<wire x1="0.254" y1="0.127" x2="0.254" y2="-0.127" width="1.27" layer="51" curve="-180" cap="flat"/>
<smd name="1" x="-0.762" y="0" dx="1.1684" dy="1.6002" layer="1"/>
<smd name="2" x="0.762" y="0" dx="1.1684" dy="1.6002" layer="1"/>
<text x="-1.651" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.4001" y="0" size="0.02" layer="27">&gt;VALUE</text>
<rectangle x1="-0.0762" y1="-0.9144" x2="0.0762" y2="0.9144" layer="29"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="4mil"/>
<param name="mdWirePad" value="4mil"/>
<param name="mdWireVia" value="4mil"/>
<param name="mdPadPad" value="4mil"/>
<param name="mdPadVia" value="4mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="5mil"/>
<param name="mdDrill" value="5mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="a"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="a"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="C1" library="resistor" package="C0805K" value="100nF" x="7.5565" y="6.0325" smashed="yes" rot="MR180">
<attribute name="VALUE" x="9.4582" y="7.117" size="1.016" layer="28" font="vector" rot="MR0"/>
</element>
<element name="IC1" library="linear" package="SOT23-5" value="TSC101" x="6.096" y="13.716" smashed="yes" rot="MR180">
<attribute name="VALUE" x="3.8481" y="17.3736" size="1.016" layer="28" font="vector" ratio="10" rot="MR270"/>
</element>
<element name="JP1" library="jumper" package="JP1" value="" x="7.62" y="22.606" smashed="yes" rot="R90">
<attribute name="VALUE" x="10.16" y="25.527" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="JP3" library="jumper" package="JP1" value="" x="25.4" y="32.766" smashed="yes" rot="R270">
<attribute name="VALUE" x="22.86" y="29.845" size="1.27" layer="27" ratio="10"/>
</element>
<element name="OUT" library="jumper" package="JP1" value="" x="25.4" y="3.556" smashed="yes" rot="R270">
<attribute name="NAME" x="28.2575" y="2.9845" size="1.27" layer="25" font="vector" ratio="10"/>
<attribute name="VALUE" x="22.86" y="0.635" size="1.27" layer="27" ratio="10"/>
</element>
<element name="+24V" library="jumper" package="JP1" value="" x="7.62" y="32.766" smashed="yes" rot="R90">
<attribute name="NAME" x="10.0457" y="35.6362" size="1.27" layer="25" font="vector" ratio="10" rot="R180"/>
<attribute name="VALUE" x="10.16" y="35.687" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="JP4" library="jumper" package="JP1" value="" x="7.62" y="3.556" smashed="yes" rot="R270">
<attribute name="VALUE" x="5.08" y="0.635" size="1.27" layer="27" ratio="10"/>
</element>
<element name="Q1" library="transistor-power" package="TO220BV" value="IRF4905L" x="6.858" y="30.226" smashed="yes">
<attribute name="VALUE" x="3.5179" y="24.5364" size="1.016" layer="27" font="vector" ratio="10"/>
</element>
<element name="R1" library="resistor" package="R0805" value="1k" x="4.064" y="23.4315" smashed="yes" rot="MR270">
<attribute name="VALUE" x="1.7653" y="22.86" size="1.016" layer="28" font="vector" rot="MR90"/>
</element>
<element name="R2" library="resistor" package="R0805" value="22k" x="4.0005" y="32.004" smashed="yes" rot="MR270">
<attribute name="VALUE" x="2.6416" y="33.5026" size="1.016" layer="28" font="vector" rot="MR270"/>
</element>
<element name="R3" library="rcl" package="R2010" value="0,1R" x="9.398" y="13.716" smashed="yes" rot="MR90">
<attribute name="VALUE" x="7.4168" y="18.3134" size="1.016" layer="28" font="vector" rot="MR180"/>
</element>
<element name="IC3" library="Audio-Power-amlifier" package="TA11B" value="LM3886" x="31.623" y="20.9042" smashed="yes" rot="R270">
<attribute name="NAME" x="19.177" y="30.5562" size="1.27" layer="25" font="vector" ratio="10" rot="R270"/>
<attribute name="VALUE" x="31.3182" y="10.033" size="1.27" layer="27" font="vector" ratio="10" rot="R180"/>
</element>
<element name="R13" library="rcl" package="R0805" value="91k" x="36.068" y="17.78" smashed="yes" rot="MR180">
<attribute name="NAME" x="35.433" y="16.51" size="1.27" layer="26" font="vector" rot="MR180"/>
<attribute name="VALUE" x="36.703" y="19.812" size="1.016" layer="28" font="vector" rot="MR180"/>
</element>
<element name="R14" library="rcl" package="R0805" value="100k" x="32.258" y="17.78" smashed="yes" rot="MR180">
<attribute name="NAME" x="31.623" y="16.51" size="1.27" layer="26" font="vector" rot="MR180"/>
<attribute name="VALUE" x="30.1625" y="16.5735" size="1.016" layer="28" font="vector" rot="MR180"/>
</element>
<element name="R15" library="rcl" package="R0805" value="75k" x="36.068" y="15.494" smashed="yes" rot="MR0">
<attribute name="NAME" x="36.703" y="16.764" size="1.27" layer="26" font="vector" rot="MR0"/>
<attribute name="VALUE" x="36.957" y="13.462" size="1.016" layer="28" font="vector" rot="MR0"/>
</element>
<element name="R16" library="rcl" package="R0805" value="1k" x="16.51" y="16.002" smashed="yes" rot="MR0">
<attribute name="NAME" x="17.145" y="17.272" size="1.27" layer="26" font="vector" rot="MR0"/>
<attribute name="VALUE" x="17.145" y="13.97" size="1.016" layer="28" font="vector" rot="MR0"/>
</element>
<element name="R17" library="rcl" package="R2512" value="2,7R" x="15.748" y="28.956" smashed="yes" rot="MR180">
<attribute name="NAME" x="13.208" y="27.051" size="1.27" layer="26" font="vector" rot="MR180"/>
<attribute name="VALUE" x="17.272" y="30.861" size="1.016" layer="28" font="vector" rot="MR0"/>
</element>
<element name="R18" library="rcl" package="R0805" value="33k" x="17.526" y="3.556" smashed="yes" rot="R180">
<attribute name="NAME" x="18.161" y="2.286" size="1.27" layer="25" font="vector" rot="R180"/>
<attribute name="VALUE" x="19.1135" y="5.715" size="1.016" layer="27" font="vector" rot="R180"/>
</element>
<element name="C10" library="rcl" package="C0805" value="10uF" x="39.116" y="16.764" smashed="yes" rot="MR270">
<attribute name="NAME" x="37.846" y="18.034" size="1.27" layer="26" font="vector" rot="MR270"/>
<attribute name="VALUE" x="41.402" y="18.796" size="1.016" layer="28" font="vector" rot="MR270"/>
</element>
<element name="C11" library="rcl" package="C0805" value="220pF" x="19.304" y="14.986" smashed="yes" rot="MR90">
<attribute name="NAME" x="20.574" y="13.716" size="1.27" layer="26" font="vector" rot="MR90"/>
<attribute name="VALUE" x="16.002" y="18.288" size="1.016" layer="28" font="vector" rot="MR180"/>
</element>
<element name="C12" library="rcl" package="C0805" value="10uF" x="14.224" y="18.796" smashed="yes" rot="MR90">
<attribute name="NAME" x="15.494" y="17.526" size="1.27" layer="26" font="vector" rot="MR90"/>
<attribute name="VALUE" x="12.192" y="17.272" size="1.016" layer="28" font="vector" rot="MR90"/>
</element>
<element name="C13" library="rcl" package="C0805" value="100nF" x="12.192" y="37.338" smashed="yes" rot="MR90">
<attribute name="NAME" x="13.462" y="36.068" size="1.27" layer="26" font="vector" rot="MR90"/>
<attribute name="VALUE" x="10.16" y="35.052" size="1.016" layer="28" font="vector" rot="MR90"/>
</element>
<element name="C14" library="rcl" package="C0805" value="50pF" x="18.288" y="11.938" smashed="yes" rot="MR0">
<attribute name="NAME" x="19.558" y="13.208" size="1.27" layer="26" font="vector" rot="MR0"/>
<attribute name="VALUE" x="16.3195" y="11.557" size="1.016" layer="28" font="vector" rot="MR0"/>
</element>
<element name="R20" library="rcl" package="R0805" value="20k" x="19.558" y="8.89" smashed="yes" rot="MR90">
<attribute name="NAME" x="20.828" y="8.255" size="1.27" layer="26" font="vector" rot="MR90"/>
<attribute name="VALUE" x="20.828" y="7.747" size="1.016" layer="28" font="vector" rot="MR90"/>
</element>
<element name="R21" library="rcl" package="R0805" value="20k" x="17.272" y="8.89" smashed="yes" rot="MR270">
<attribute name="NAME" x="16.002" y="9.525" size="1.27" layer="26" font="vector" rot="MR270"/>
<attribute name="VALUE" x="16.002" y="10.287" size="1.016" layer="28" font="vector" rot="MR270"/>
</element>
<element name="C15" library="rcl" package="C0805" value="0,1uF" x="32.258" y="22.352" smashed="yes" rot="MR0">
<attribute name="NAME" x="33.528" y="23.622" size="1.27" layer="26" font="vector" rot="MR0"/>
<attribute name="VALUE" x="31.8135" y="23.495" size="1.016" layer="28" font="vector" rot="MR90"/>
</element>
<element name="C16" library="rcl" package="C0805" value="100nF" x="21.4884" y="32.639" smashed="yes" rot="MR90">
<attribute name="NAME" x="22.7584" y="31.369" size="1.27" layer="26" font="vector" rot="MR90"/>
<attribute name="VALUE" x="19.2024" y="30.861" size="1.016" layer="28" font="vector" rot="MR90"/>
</element>
<element name="C17" library="rcl" package="E3,5-8" value="100uF" x="16.2052" y="23.7744" smashed="yes" rot="R90">
<attribute name="NAME" x="13.4112" y="27.0764" size="1.27" layer="25" font="vector" ratio="10" rot="R90"/>
<attribute name="VALUE" x="18.4912" y="21.7424" size="1.016" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
<element name="C18" library="rcl" package="E5-13" value="1000uF" x="13.2334" y="12.1158" smashed="yes" rot="R270">
<attribute name="NAME" x="17.3482" y="5.7404" size="1.778" layer="25" font="vector" ratio="10" rot="R270"/>
<attribute name="VALUE" x="9.8044" y="14.4018" size="1.016" layer="27" font="vector" ratio="10" rot="R270"/>
</element>
<element name="C19" library="rcl" package="C0805" value="0,1uF" x="32.258" y="20.066" smashed="yes" rot="MR0">
<attribute name="NAME" x="33.528" y="21.336" size="1.27" layer="26" font="vector" rot="MR0"/>
<attribute name="VALUE" x="29.21" y="17.9705" size="1.016" layer="28" font="vector" rot="MR90"/>
</element>
<element name="R22" library="rcl" package="R0805" value="1k" x="30.0736" y="32.6644" smashed="yes" rot="MR180">
<attribute name="NAME" x="29.4386" y="31.3944" size="1.27" layer="26" font="vector" rot="MR180"/>
<attribute name="VALUE" x="29.1846" y="34.9504" size="1.016" layer="28" font="vector" rot="MR180"/>
</element>
<element name="C20" library="rcl" package="E5-10,5" value="220uF" x="15.6972" y="35.8648" smashed="yes" rot="R90">
<attribute name="NAME" x="12.954" y="40.5638" size="1.27" layer="25" font="vector" ratio="10" rot="R90"/>
<attribute name="VALUE" x="18.669" y="34.2646" size="1.016" layer="27" font="vector" ratio="10" rot="R90"/>
</element>
<element name="LD2" library="led" package="CHIPLED_0805" value="LD" x="7.62" y="38.354" smashed="yes" rot="R270">
<attribute name="NAME" x="6.35" y="39.624" size="1.27" layer="25" font="vector"/>
<attribute name="VALUE" x="7.112" y="39.1795" size="0.8128" layer="27" font="vector"/>
</element>
<element name="R23" library="resistor" package="R0805" value="10k" x="7.62" y="36.322" smashed="yes">
<attribute name="NAME" x="6.985" y="37.592" size="1.27" layer="25" font="vector"/>
<attribute name="VALUE" x="6.731" y="34.29" size="1.016" layer="27" font="vector"/>
</element>
<element name="Q2" library="transistor-npn" package="SOT23-BEC" value="BC817" x="36.068" y="20.828" smashed="yes" rot="MR90">
<attribute name="NAME" x="37.973" y="18.923" size="1.27" layer="26" font="vector" rot="MR90"/>
<attribute name="VALUE" x="36.5125" y="22.9235" size="1.016" layer="28" font="vector" rot="MR180"/>
</element>
<element name="P1" library="rcl" package="RTRIMT93XB" value="10K" x="26.3398" y="37.084" smashed="yes" rot="R90">
<attribute name="NAME" x="31.2298" y="34.294" size="1.27" layer="25" font="vector" rot="R180"/>
<attribute name="VALUE" x="27.6738" y="40.586" size="1.016" layer="27" font="vector" rot="R180"/>
</element>
<element name="MUTE" library="jumper" package="JP1" value="MUTE" x="12.7" y="3.556" smashed="yes" rot="R90">
<attribute name="NAME" x="15.24" y="1.905" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="16.002" y="1.905" size="0.8128" layer="27" font="vector" ratio="10" rot="R180"/>
</element>
<element name="SJ1" library="jumperr" package="SJ" value="" x="12.7" y="3.556" rot="MR0"/>
</elements>
<signals>
<signal name="GND">
<contactref element="C1" pad="2"/>
<contactref element="IC1" pad="2"/>
<contactref element="JP4" pad="2"/>
<contactref element="R14" pad="1"/>
<contactref element="IC3" pad="4"/>
<contactref element="C15" pad="2"/>
<contactref element="C19" pad="2"/>
<contactref element="C12" pad="2"/>
<contactref element="C13" pad="2"/>
<contactref element="C16" pad="2"/>
<contactref element="C20" pad="-"/>
<contactref element="C17" pad="-"/>
<contactref element="JP3" pad="1"/>
<contactref element="P1" pad="3"/>
<wire x1="6.096" y1="9.398" x2="8.5565" y2="6.9375" width="0.6096" layer="16"/>
<wire x1="8.5565" y1="6.0325" x2="8.5565" y2="6.9375" width="0.6096" layer="16"/>
<wire x1="6.096" y1="15.022" x2="6.096" y2="9.398" width="0.6096" layer="16"/>
<wire x1="27.1526" y1="24.3078" x2="28.3718" y2="24.3078" width="1.27" layer="1"/>
<wire x1="28.3718" y1="24.3078" x2="30.226" y2="26.162" width="1.27" layer="1"/>
<wire x1="30.226" y1="26.162" x2="30.226" y2="28.956" width="1.27" layer="1"/>
<wire x1="30.226" y1="28.956" x2="28.956" y2="30.226" width="1.27" layer="1"/>
<wire x1="28.956" y1="30.226" x2="25.654" y2="30.226" width="1.27" layer="1"/>
<wire x1="18.9332" y1="24.3078" x2="18.796" y2="24.445" width="0.6096" layer="16"/>
<wire x1="16.2052" y1="25.5524" x2="16.2052" y2="24.6482" width="0.6096" layer="16"/>
<wire x1="16.2052" y1="24.6482" x2="16.256" y2="24.445" width="0.6096" layer="16"/>
<wire x1="25.654" y1="30.226" x2="24.13" y2="31.75" width="1.27" layer="1"/>
<wire x1="24.13" y1="31.75" x2="24.13" y2="32.766" width="1.27" layer="1"/>
<polygon width="0.254" layer="16" spacing="0.4064" pour="hatch" isolate="0.8128">
<vertex x="0.3175" y="41.5925"/>
<vertex x="43.6245" y="41.5925"/>
<vertex x="43.6245" y="0.3175"/>
<vertex x="0.3175" y="0.3175"/>
</polygon>
<contactref element="MUTE" pad="2"/>
<contactref element="SJ1" pad="2"/>
<contactref element="LD2" pad="C"/>
<wire x1="8.67" y1="38.354" x2="15.6464" y2="38.354" width="0.6096" layer="1"/>
<wire x1="15.6464" y1="38.354" x2="15.6972" y2="38.4048" width="0.6096" layer="1"/>
</signal>
<signal name="N$166">
<contactref element="R3" pad="2"/>
<contactref element="Q1" pad="D"/>
<contactref element="IC1" pad="3"/>
<wire x1="7.046" y1="15.022" x2="7.046" y2="15.682" width="0.6096" layer="16"/>
<wire x1="7.046" y1="15.682" x2="7.366" y2="16.002" width="0.6096" layer="16"/>
<wire x1="7.366" y1="16.002" x2="9.312" y2="16.002" width="0.6096" layer="16"/>
<wire x1="9.312" y1="16.002" x2="9.398" y2="15.916" width="0.6096" layer="16"/>
<wire x1="9.906" y1="24.638" x2="10.922" y2="23.622" width="1.27" layer="16"/>
<wire x1="10.922" y1="23.622" x2="10.922" y2="20.066" width="1.27" layer="16"/>
<wire x1="10.922" y1="20.066" x2="9.398" y2="18.542" width="1.27" layer="16"/>
<wire x1="9.398" y1="15.916" x2="9.398" y2="18.542" width="1.27" layer="16"/>
<wire x1="6.858" y1="27.686" x2="6.858" y2="25.908" width="1.27" layer="16"/>
<wire x1="6.858" y1="25.908" x2="8.128" y2="24.638" width="1.27" layer="16"/>
<wire x1="8.128" y1="24.638" x2="9.906" y2="24.638" width="1.27" layer="16"/>
</signal>
<signal name="N$171">
<contactref element="R1" pad="1"/>
<contactref element="R2" pad="2"/>
<contactref element="Q1" pad="G"/>
<wire x1="4.064" y1="24.3815" x2="4.064" y2="27.686" width="0.8128" layer="16"/>
<wire x1="4.064" y1="27.686" x2="4.064" y2="30.9905" width="0.8128" layer="16"/>
<wire x1="4.064" y1="30.9905" x2="4.0005" y2="31.054" width="0.8128" layer="16"/>
<wire x1="4.318" y1="27.686" x2="4.064" y2="27.686" width="0.8128" layer="16"/>
</signal>
<signal name="N$223">
<contactref element="IC1" pad="1"/>
<contactref element="JP1" pad="1"/>
<wire x1="8.89" y1="22.606" x2="8.89" y2="21.59" width="0.6096" layer="16"/>
<wire x1="5.146" y1="15.022" x2="5.146" y2="17.846" width="0.6096" layer="16"/>
<wire x1="5.146" y1="17.846" x2="8.89" y2="21.59" width="0.6096" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="R1" pad="2"/>
<contactref element="JP1" pad="2"/>
<wire x1="6.35" y1="22.606" x2="4.1885" y2="22.606" width="0.8128" layer="16"/>
<wire x1="4.1885" y1="22.606" x2="4.064" y2="22.4815" width="0.8128" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="R2" pad="1"/>
<contactref element="Q1" pad="S"/>
<contactref element="+24V" pad="1"/>
<contactref element="+24V" pad="2"/>
<wire x1="6.35" y1="32.766" x2="8.89" y2="32.766" width="1.27" layer="16"/>
<wire x1="6.284" y1="32.7" x2="6.35" y2="32.766" width="1.27" layer="16"/>
<wire x1="9.398" y1="27.686" x2="9.398" y2="32.258" width="1.27" layer="16"/>
<wire x1="9.398" y1="32.258" x2="8.89" y2="32.766" width="1.27" layer="16"/>
<wire x1="4.0005" y1="32.954" x2="6.162" y2="32.954" width="0.8128" layer="16"/>
<wire x1="6.162" y1="32.954" x2="6.35" y2="32.766" width="0.8128" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="IC1" pad="5"/>
<contactref element="C1" pad="1"/>
<contactref element="JP4" pad="1"/>
<wire x1="6.5565" y1="6.0325" x2="6.5565" y2="3.7625" width="0.6096" layer="16"/>
<wire x1="6.5565" y1="3.7625" x2="6.35" y2="3.556" width="0.6096" layer="16"/>
<wire x1="5.146" y1="12.41" x2="5.146" y2="8.824" width="0.6096" layer="16"/>
<wire x1="6.5565" y1="6.0325" x2="6.5565" y2="7.4135" width="0.6096" layer="16"/>
<wire x1="6.5565" y1="7.4135" x2="5.146" y2="8.824" width="0.6096" layer="16"/>
</signal>
<signal name="2">
<contactref element="IC3" pad="2"/>
</signal>
<signal name="N$12">
<contactref element="IC3" pad="10"/>
<contactref element="R15" pad="1"/>
<contactref element="C10" pad="2"/>
<contactref element="C11" pad="1"/>
<wire x1="27.1526" y1="14.097" x2="19.365" y2="14.097" width="0.6096" layer="16"/>
<wire x1="19.365" y1="14.097" x2="19.304" y2="14.036" width="0.6096" layer="16"/>
<wire x1="39.116" y1="15.814" x2="37.084" y2="15.814" width="0.6096" layer="16"/>
<wire x1="37.084" y1="15.814" x2="37.018" y2="15.494" width="0.6096" layer="16"/>
<wire x1="37.018" y1="15.494" x2="37.018" y2="14.92" width="0.6096" layer="16"/>
<wire x1="37.018" y1="14.92" x2="36.195" y2="14.097" width="0.6096" layer="16"/>
<wire x1="27.1526" y1="14.097" x2="36.195" y2="14.097" width="0.6096" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="R14" pad="2"/>
<contactref element="R13" pad="1"/>
<contactref element="R15" pad="2"/>
<contactref element="C19" pad="1"/>
<contactref element="Q2" pad="B"/>
<wire x1="35.118" y1="15.494" x2="35.118" y2="17.78" width="0.6096" layer="16"/>
<wire x1="35.118" y1="17.78" x2="33.208" y2="17.78" width="0.6096" layer="16"/>
<wire x1="35.118" y1="17.78" x2="35.118" y2="19.728" width="0.6096" layer="16"/>
<wire x1="35.118" y1="19.728" x2="34.968" y2="19.878" width="0.6096" layer="16"/>
<wire x1="34.968" y1="19.878" x2="33.396" y2="19.878" width="0.6096" layer="16"/>
<wire x1="33.396" y1="19.878" x2="33.208" y2="20.066" width="0.6096" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="R22" pad="2"/>
<contactref element="P1" pad="1"/>
<wire x1="31.0236" y1="32.6644" x2="31.0236" y2="36.2102" width="1.016" layer="16"/>
<wire x1="31.0236" y1="36.2102" x2="28.8798" y2="38.354" width="1.016" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="C10" pad="1"/>
<contactref element="P1" pad="2"/>
<wire x1="39.116" y1="17.714" x2="39.116" y2="34.544" width="0.6096" layer="16"/>
<via x="35.052" y="36.83" extent="1-16" drill="0.6"/>
<wire x1="39.116" y1="34.544" x2="36.83" y2="36.83" width="0.6096" layer="16"/>
<wire x1="36.83" y1="36.83" x2="35.052" y2="36.83" width="0.6096" layer="16"/>
<wire x1="26.3398" y1="35.814" x2="32.766" y2="35.814" width="0.6096" layer="1"/>
<wire x1="32.766" y1="35.814" x2="33.782" y2="36.83" width="0.6096" layer="1"/>
<wire x1="33.782" y1="36.83" x2="35.052" y2="36.83" width="0.6096" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="IC3" pad="7"/>
<contactref element="C15" pad="1"/>
<contactref element="Q2" pad="E"/>
<wire x1="22.098" y1="19.2024" x2="31.9024" y2="19.2024" width="0.6096" layer="1"/>
<wire x1="31.9024" y1="19.2024" x2="35.814" y2="23.114" width="0.6096" layer="1"/>
<via x="35.814" y="23.114" extent="1-16" drill="0.6"/>
<wire x1="33.274" y1="22.164" x2="33.208" y2="22.352" width="0.6096" layer="16"/>
<wire x1="35.052" y1="21.862" x2="34.968" y2="21.778" width="0.6096" layer="16"/>
<wire x1="35.052" y1="21.862" x2="35.052" y2="22.352" width="0.6096" layer="16"/>
<wire x1="35.052" y1="22.352" x2="35.814" y2="23.114" width="0.6096" layer="16"/>
<wire x1="33.208" y1="22.352" x2="35.052" y2="22.352" width="0.6096" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="IC3" pad="8"/>
<contactref element="R18" pad="1"/>
<contactref element="C17" pad="+"/>
<wire x1="27.1526" y1="17.5006" x2="19.3294" y2="17.5006" width="0.6096" layer="16"/>
<wire x1="16.2052" y1="21.9964" x2="17.3736" y2="21.9964" width="0.6096" layer="16"/>
<wire x1="18.542" y1="20.828" x2="17.3736" y2="21.9964" width="0.6096" layer="16"/>
<wire x1="18.542" y1="20.828" x2="18.542" y2="18.288" width="0.6096" layer="16"/>
<wire x1="18.542" y1="18.288" x2="19.3294" y2="17.5006" width="0.6096" layer="16"/>
<wire x1="18.476" y1="3.556" x2="20.508" y2="5.588" width="0.6096" layer="1"/>
<wire x1="29.972" y1="12.7" x2="29.972" y2="15.494" width="0.6096" layer="1"/>
<wire x1="29.972" y1="15.494" x2="27.9654" y2="17.5006" width="0.6096" layer="1"/>
<wire x1="27.9654" y1="17.5006" x2="27.1526" y2="17.5006" width="0.6096" layer="1"/>
<wire x1="20.508" y1="5.588" x2="22.86" y2="5.588" width="0.6096" layer="1"/>
<wire x1="22.86" y1="5.588" x2="29.972" y2="12.7" width="0.6096" layer="1"/>
</signal>
<signal name="N$19">
<contactref element="R21" pad="1"/>
<contactref element="R16" pad="1"/>
<contactref element="C14" pad="2"/>
<contactref element="IC3" pad="9"/>
<contactref element="C11" pad="2"/>
<wire x1="22.098" y1="15.7988" x2="19.4412" y2="15.7988" width="0.6096" layer="16"/>
<wire x1="19.4412" y1="15.7988" x2="19.304" y2="15.936" width="0.6096" layer="16"/>
<wire x1="17.338" y1="11.938" x2="17.338" y2="10.414" width="0.6096" layer="16"/>
<wire x1="17.338" y1="10.414" x2="17.272" y2="9.84" width="0.6096" layer="16"/>
<wire x1="19.304" y1="15.936" x2="17.526" y2="15.936" width="0.6096" layer="16"/>
<wire x1="17.526" y1="15.936" x2="17.46" y2="16.002" width="0.6096" layer="16"/>
<wire x1="17.46" y1="16.002" x2="17.46" y2="12.314" width="0.6096" layer="16"/>
<wire x1="17.46" y1="12.314" x2="17.338" y2="11.938" width="0.6096" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="R20" pad="2"/>
<contactref element="C14" pad="1"/>
<wire x1="19.238" y1="11.938" x2="19.238" y2="10.668" width="0.6096" layer="16"/>
<wire x1="19.238" y1="10.668" x2="19.558" y2="9.84" width="0.6096" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="R21" pad="2"/>
<contactref element="R20" pad="1"/>
<contactref element="R17" pad="2"/>
<contactref element="IC3" pad="3"/>
<wire x1="18.542" y1="20.1676" x2="18.542" y2="24.13" width="1.016" layer="1"/>
<wire x1="18.542" y1="24.13" x2="20.32" y2="25.908" width="1.016" layer="1"/>
<wire x1="20.32" y1="25.908" x2="21.9964" y2="25.908" width="1.016" layer="1"/>
<wire x1="21.9964" y1="25.908" x2="22.098" y2="26.0096" width="1.016" layer="1"/>
<wire x1="19.558" y1="7.94" x2="17.272" y2="7.94" width="0.6096" layer="16"/>
<wire x1="18.548" y1="28.956" x2="21.4944" y2="26.0096" width="1.016" layer="16"/>
<wire x1="21.4944" y1="26.0096" x2="22.098" y2="26.0096" width="1.016" layer="16"/>
<wire x1="15.494" y1="11.176" x2="15.494" y2="9.2075" width="0.6096" layer="16"/>
<wire x1="15.494" y1="9.2075" x2="16.5735" y2="8.128" width="0.6096" layer="16"/>
<wire x1="16.5735" y1="8.128" x2="17.084" y2="8.128" width="0.6096" layer="16"/>
<wire x1="17.084" y1="8.128" x2="17.272" y2="7.94" width="0.6096" layer="16"/>
<contactref element="C18" pad="+"/>
<wire x1="18.542" y1="20.1676" x2="13.2334" y2="14.859" width="1.016" layer="1"/>
<wire x1="13.2334" y1="14.859" x2="13.2334" y2="14.6558" width="1.016" layer="1"/>
<wire x1="15.494" y1="11.176" x2="13.2334" y2="13.4366" width="0.6096" layer="16"/>
<wire x1="13.2334" y1="13.4366" x2="13.2334" y2="14.6558" width="0.6096" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="C13" pad="1"/>
<contactref element="R17" pad="1"/>
<wire x1="12.948" y1="28.956" x2="12.192" y2="29.712" width="1.016" layer="16"/>
<wire x1="12.192" y1="29.712" x2="12.192" y2="36.388" width="1.016" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R16" pad="2"/>
<contactref element="C12" pad="1"/>
<wire x1="15.56" y1="16.002" x2="15.56" y2="15.936" width="0.6096" layer="16"/>
<wire x1="15.56" y1="16.002" x2="15.56" y2="16.51" width="0.6096" layer="16"/>
<wire x1="15.56" y1="16.51" x2="14.224" y2="17.846" width="0.6096" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="OUT" pad="1"/>
<contactref element="OUT" pad="2"/>
<wire x1="24.13" y1="3.556" x2="18.3388" y2="3.556" width="1.016" layer="16"/>
<wire x1="24.13" y1="3.556" x2="26.67" y2="3.556" width="1.016" layer="16"/>
<contactref element="C18" pad="-"/>
<wire x1="18.3388" y1="3.556" x2="13.2334" y2="8.6614" width="1.016" layer="16"/>
<wire x1="13.2334" y1="8.6614" x2="13.2334" y2="9.5758" width="1.016" layer="16"/>
</signal>
<signal name="N$1">
<contactref element="R3" pad="1"/>
<contactref element="IC1" pad="4"/>
<contactref element="IC3" pad="1"/>
<contactref element="C16" pad="1"/>
<contactref element="C20" pad="+"/>
<contactref element="R13" pad="2"/>
<contactref element="Q2" pad="C"/>
<wire x1="9.398" y1="11.516" x2="7.534" y2="11.516" width="0.6096" layer="16"/>
<wire x1="7.534" y1="11.516" x2="7.046" y2="12.004" width="0.6096" layer="16"/>
<wire x1="7.046" y1="12.41" x2="7.046" y2="12.004" width="0.6096" layer="16"/>
<wire x1="13.208" y1="35.814" x2="13.589" y2="35.433" width="0.6096" layer="1"/>
<wire x1="13.589" y1="35.433" x2="15.6972" y2="33.3248" width="0.6096" layer="1"/>
<wire x1="37.018" y1="17.78" x2="37.018" y2="20.678" width="0.6096" layer="16"/>
<wire x1="37.018" y1="20.678" x2="37.168" y2="20.828" width="0.6096" layer="16"/>
<wire x1="37.018" y1="20.678" x2="37.018" y2="26.99" width="0.6096" layer="16"/>
<wire x1="37.018" y1="26.99" x2="34.544" y2="29.464" width="0.6096" layer="16"/>
<via x="9.398" y="9.144" extent="1-16" drill="0.9"/>
<wire x1="9.398" y1="9.144" x2="9.398" y2="18.542" width="1.27" layer="1"/>
<wire x1="9.398" y1="18.542" x2="12.446" y2="21.59" width="1.27" layer="1"/>
<wire x1="12.446" y1="21.59" x2="12.446" y2="26.162" width="1.27" layer="1"/>
<wire x1="12.446" y1="26.162" x2="15.6972" y2="29.4132" width="1.27" layer="1"/>
<wire x1="15.748" y1="29.464" x2="15.6972" y2="29.4132" width="1.27" layer="1"/>
<wire x1="22.098" y1="29.4132" x2="15.6972" y2="29.4132" width="1.27" layer="1"/>
<wire x1="15.6972" y1="33.3248" x2="15.6972" y2="29.4132" width="1.27" layer="1"/>
<wire x1="34.544" y1="29.464" x2="22.1488" y2="29.464" width="0.6096" layer="16"/>
<wire x1="22.1488" y1="29.464" x2="22.098" y2="29.4132" width="0.6096" layer="16"/>
<wire x1="9.398" y1="11.516" x2="9.398" y2="9.144" width="1.27" layer="16"/>
<wire x1="22.1488" y1="29.464" x2="21.4884" y2="29.464" width="0.8128" layer="16"/>
<wire x1="21.4884" y1="29.464" x2="21.4884" y2="31.689" width="0.8128" layer="16"/>
<contactref element="R23" pad="2"/>
<wire x1="8.57" y1="36.322" x2="12.7" y2="36.322" width="0.6096" layer="1"/>
<wire x1="12.7" y1="36.322" x2="13.208" y2="35.814" width="0.6096" layer="1"/>
</signal>
<signal name="N$2">
<contactref element="R22" pad="1"/>
<contactref element="JP3" pad="2"/>
<wire x1="26.67" y1="32.766" x2="29.022" y2="32.766" width="1.016" layer="16"/>
<wire x1="29.022" y1="32.766" x2="29.1236" y2="32.6644" width="1.016" layer="16"/>
</signal>
<signal name="N$3">
<wire x1="32.766" y1="4.826" x2="38.1" y2="4.826" width="0.127" layer="16"/>
<wire x1="38.1" y1="4.826" x2="38.1" y2="3.048" width="0.127" layer="16"/>
<wire x1="38.1" y1="3.048" x2="32.766" y2="3.048" width="0.127" layer="16"/>
<wire x1="32.766" y1="3.048" x2="32.766" y2="4.826" width="0.127" layer="16"/>
</signal>
<signal name="N$4">
<wire x1="37.846" y1="38.354" x2="32.512" y2="38.354" width="0.127" layer="1"/>
<wire x1="32.512" y1="38.354" x2="32.512" y2="40.132" width="0.127" layer="1"/>
<wire x1="32.512" y1="40.132" x2="37.846" y2="40.132" width="0.127" layer="1"/>
<wire x1="37.846" y1="40.132" x2="37.846" y2="38.354" width="0.127" layer="1"/>
</signal>
<signal name="N$7">
<contactref element="R18" pad="2"/>
<contactref element="MUTE" pad="1"/>
<wire x1="16.576" y1="3.556" x2="13.97" y2="3.556" width="0.6096" layer="1"/>
<contactref element="SJ1" pad="1"/>
<wire x1="13.462" y1="3.556" x2="13.97" y2="3.556" width="0.4064" layer="16"/>
</signal>
<signal name="5">
<contactref element="IC3" pad="5"/>
</signal>
<signal name="N$9">
<contactref element="R23" pad="1"/>
<contactref element="LD2" pad="A"/>
<wire x1="6.57" y1="38.354" x2="6.57" y2="36.422" width="0.6096" layer="1"/>
<wire x1="6.57" y1="36.422" x2="6.67" y2="36.322" width="0.6096" layer="1"/>
</signal>
</signals>
<errors>
<approved hash="4,1,b3fc90ade4ab8e39"/>
<approved hash="4,1,4ee631a6f0a93c2d"/>
<approved hash="4,1,8091a3a808a9646c"/>
<approved hash="4,1,9b84c8a874ab7e44"/>
<approved hash="4,16,b3fc90ade4ab8e39"/>
<approved hash="4,16,4ee631a6f0a93c2d"/>
<approved hash="4,16,8091a3a808a9646c"/>
<approved hash="4,16,9b84c8a874ab7e44"/>
<approved hash="4,1,d15049c4a9caf48e"/>
<approved hash="4,1,545ca4dcedd0368e"/>
<approved hash="4,1,02113ad6e9e49ec2"/>
<approved hash="4,1,092e11ca69c394ff"/>
<approved hash="4,16,d15049c4a9caf48e"/>
<approved hash="4,16,545ca4dcedd0368e"/>
<approved hash="4,16,02113ad6e9e49ec2"/>
<approved hash="4,16,092e11ca69c394ff"/>
<approved hash="5,16,a3a0292caeeedd54"/>
<approved hash="19,16,6e340a6eb27a51c4"/>
<approved hash="19,16,dd3d1624cffd6c4f"/>
</errors>
</board>
</drawing>
</eagle>
