<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.01" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S." xrefpart="/%S.%C%R">
<libraries>
<library name="memory-motorola-dram" urn="urn:adsk.eagle:library:275">
<description>&lt;b&gt;Motorola DRAMs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SOJ26-20" urn="urn:adsk.eagle:footprint:18748/1" library_version="2">
<description>&lt;b&gt;Small Outline J-Bend&lt;/b&gt;</description>
<wire x1="8.636" y1="-3.7592" x2="8.636" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="3.7592" x2="-8.636" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="3.7592" x2="-8.0264" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="-7.9756" y1="3.7592" x2="-7.2644" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="-7.2136" y1="3.7592" x2="-6.7564" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="-6.7056" y1="3.7592" x2="-5.9944" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="-5.9436" y1="3.7592" x2="-5.4864" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="-5.4356" y1="3.7592" x2="-4.7244" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="-4.6736" y1="3.7592" x2="-4.2164" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="3.7592" x2="-3.4544" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="-3.4036" y1="3.7592" x2="-2.9464" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="-2.8956" y1="3.7592" x2="-2.1844" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="-2.1336" y1="3.7592" x2="2.1336" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="2.1844" y1="3.7592" x2="2.8956" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="2.9464" y1="3.7592" x2="3.4036" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="3.4544" y1="3.7592" x2="4.1656" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="4.2164" y1="3.7592" x2="4.6736" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="4.7244" y1="3.7592" x2="5.4356" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="5.4864" y1="3.7592" x2="5.9436" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="5.9944" y1="3.7592" x2="6.7056" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="6.7564" y1="3.7592" x2="7.2136" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="8.636" y1="3.7592" x2="8.0264" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="7.9756" y1="3.7592" x2="7.2644" y2="3.7592" width="0.1524" layer="51"/>
<wire x1="8.636" y1="-3.7592" x2="8.0264" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="7.9756" y1="-3.7592" x2="7.2644" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="7.2136" y1="-3.7592" x2="6.7564" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="6.7056" y1="-3.7592" x2="5.9944" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="5.9436" y1="-3.7592" x2="5.4864" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="5.4356" y1="-3.7592" x2="4.7244" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="4.6736" y1="-3.7592" x2="4.2164" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="4.1656" y1="-3.7592" x2="3.4544" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="3.4036" y1="-3.7592" x2="2.9464" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="2.8956" y1="-3.7592" x2="2.1844" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="2.1336" y1="-3.7592" x2="-2.1336" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="-2.1844" y1="-3.7592" x2="-2.8956" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="-2.9464" y1="-3.7592" x2="-3.4036" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="-3.4544" y1="-3.7592" x2="-4.1656" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="-4.2164" y1="-3.7592" x2="-4.6736" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="-4.7244" y1="-3.7592" x2="-5.4356" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="-5.4864" y1="-3.7592" x2="-5.9436" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="-5.9944" y1="-3.7592" x2="-6.7056" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="-6.7564" y1="-3.7592" x2="-7.2136" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-3.7592" x2="-8.0264" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="-7.9756" y1="-3.7592" x2="-7.2644" y2="-3.7592" width="0.1524" layer="51"/>
<circle x="-7.6962" y="-1.7018" radius="0.5334" width="0.1524" layer="21"/>
<smd name="26" x="-7.62" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="25" x="-6.35" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="24" x="-5.08" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="23" x="-3.81" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="22" x="-2.54" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="15" x="6.35" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="16" x="5.08" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="17" x="3.81" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="18" x="2.54" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="12" x="6.35" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="11" x="5.08" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="10" x="3.81" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="9" x="2.54" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="5" x="-2.54" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="4" x="-3.81" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="3" x="-5.08" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="2" x="-6.35" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="1" x="-7.62" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="14" x="7.62" y="3.6322" dx="0.635" dy="1.905" layer="1"/>
<smd name="13" x="7.62" y="-3.6322" dx="0.635" dy="1.905" layer="1"/>
<text x="-9.017" y="-3.81" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-7.62" y="-0.635" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.366" y1="3.81" x2="7.874" y2="4.318" layer="51"/>
<rectangle x1="7.4422" y1="3.048" x2="7.7978" y2="3.81" layer="51"/>
<rectangle x1="7.366" y1="-4.318" x2="7.874" y2="-3.81" layer="51"/>
<rectangle x1="7.4422" y1="-3.81" x2="7.7978" y2="-3.048" layer="51"/>
<rectangle x1="6.096" y1="3.81" x2="6.604" y2="4.318" layer="51"/>
<rectangle x1="6.1722" y1="3.048" x2="6.5278" y2="3.81" layer="51"/>
<rectangle x1="4.826" y1="3.81" x2="5.334" y2="4.318" layer="51"/>
<rectangle x1="4.9022" y1="3.048" x2="5.2578" y2="3.81" layer="51"/>
<rectangle x1="3.556" y1="3.81" x2="4.064" y2="4.318" layer="51"/>
<rectangle x1="3.6322" y1="3.048" x2="3.9878" y2="3.81" layer="51"/>
<rectangle x1="2.286" y1="3.81" x2="2.794" y2="4.318" layer="51"/>
<rectangle x1="2.3622" y1="3.048" x2="2.7178" y2="3.81" layer="51"/>
<rectangle x1="-2.794" y1="3.81" x2="-2.286" y2="4.318" layer="51"/>
<rectangle x1="-2.7178" y1="3.048" x2="-2.3622" y2="3.81" layer="51"/>
<rectangle x1="-4.064" y1="3.81" x2="-3.556" y2="4.318" layer="51"/>
<rectangle x1="-3.9878" y1="3.048" x2="-3.6322" y2="3.81" layer="51"/>
<rectangle x1="-5.334" y1="3.81" x2="-4.826" y2="4.318" layer="51"/>
<rectangle x1="-5.2578" y1="3.048" x2="-4.9022" y2="3.81" layer="51"/>
<rectangle x1="-6.604" y1="3.81" x2="-6.096" y2="4.318" layer="51"/>
<rectangle x1="-6.5278" y1="3.048" x2="-6.1722" y2="3.81" layer="51"/>
<rectangle x1="-7.874" y1="3.81" x2="-7.366" y2="4.318" layer="51"/>
<rectangle x1="-7.7978" y1="3.048" x2="-7.4422" y2="3.81" layer="51"/>
<rectangle x1="-7.874" y1="-4.318" x2="-7.366" y2="-3.81" layer="51"/>
<rectangle x1="-7.7978" y1="-3.81" x2="-7.4422" y2="-3.048" layer="51"/>
<rectangle x1="-6.604" y1="-4.318" x2="-6.096" y2="-3.81" layer="51"/>
<rectangle x1="-6.5278" y1="-3.81" x2="-6.1722" y2="-3.048" layer="51"/>
<rectangle x1="-5.334" y1="-4.318" x2="-4.826" y2="-3.81" layer="51"/>
<rectangle x1="-5.2578" y1="-3.81" x2="-4.9022" y2="-3.048" layer="51"/>
<rectangle x1="-4.064" y1="-4.318" x2="-3.556" y2="-3.81" layer="51"/>
<rectangle x1="-3.9878" y1="-3.81" x2="-3.6322" y2="-3.048" layer="51"/>
<rectangle x1="-2.794" y1="-4.318" x2="-2.286" y2="-3.81" layer="51"/>
<rectangle x1="-2.7178" y1="-3.81" x2="-2.3622" y2="-3.048" layer="51"/>
<rectangle x1="2.286" y1="-4.318" x2="2.794" y2="-3.81" layer="51"/>
<rectangle x1="2.3622" y1="-3.81" x2="2.7178" y2="-3.048" layer="51"/>
<rectangle x1="3.556" y1="-4.318" x2="4.064" y2="-3.81" layer="51"/>
<rectangle x1="3.6322" y1="-3.81" x2="3.9878" y2="-3.048" layer="51"/>
<rectangle x1="4.826" y1="-4.318" x2="5.334" y2="-3.81" layer="51"/>
<rectangle x1="4.9022" y1="-3.81" x2="5.2578" y2="-3.048" layer="51"/>
<rectangle x1="6.096" y1="-4.318" x2="6.604" y2="-3.81" layer="51"/>
<rectangle x1="6.1722" y1="-3.81" x2="6.5278" y2="-3.048" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="SOJ26-20" urn="urn:adsk.eagle:package:18765/1" type="box" library_version="2">
<description>Small Outline J-Bend</description>
<packageinstances>
<packageinstance name="SOJ26-20"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="CM44100" urn="urn:adsk.eagle:symbol:18755/1" library_version="2">
<wire x1="-7.62" y1="20.32" x2="-7.62" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-20.32" x2="-7.62" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-20.32" x2="7.62" y2="20.32" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="20.32" x2="7.62" y2="20.32" width="0.4064" layer="94"/>
<text x="-7.62" y="-22.86" size="1.778" layer="96">&gt;VALUE</text>
<text x="-7.62" y="20.955" size="1.778" layer="95">&gt;NAME</text>
<pin name="A0" x="-12.7" y="17.78" length="middle" direction="in"/>
<pin name="A1" x="-12.7" y="15.24" length="middle" direction="in"/>
<pin name="A2" x="-12.7" y="12.7" length="middle" direction="in"/>
<pin name="A3" x="-12.7" y="10.16" length="middle" direction="in"/>
<pin name="A4" x="-12.7" y="7.62" length="middle" direction="in"/>
<pin name="A5" x="-12.7" y="5.08" length="middle" direction="in"/>
<pin name="A6" x="-12.7" y="2.54" length="middle" direction="in"/>
<pin name="A7" x="-12.7" y="0" length="middle" direction="in"/>
<pin name="A8" x="-12.7" y="-2.54" length="middle" direction="in"/>
<pin name="W" x="-12.7" y="-12.7" length="middle" direction="in" function="dot"/>
<pin name="CAS" x="-12.7" y="-15.24" length="middle" direction="in" function="dot"/>
<pin name="!RAS" x="-12.7" y="-17.78" length="middle" direction="in"/>
<pin name="D" x="12.7" y="5.08" length="middle" direction="in" rot="R180"/>
<pin name="Q" x="12.7" y="15.24" length="middle" direction="hiz" rot="R180"/>
<pin name="A9" x="-12.7" y="-5.08" length="middle" direction="in"/>
<pin name="A10" x="-12.7" y="-7.62" length="middle" direction="in"/>
</symbol>
<symbol name="PWRN" urn="urn:adsk.eagle:symbol:18747/1" library_version="2">
<text x="-0.635" y="-0.635" size="1.778" layer="95">&gt;NAME</text>
<text x="1.905" y="2.667" size="1.27" layer="95" rot="R90">VCC</text>
<text x="1.905" y="-5.842" size="1.27" layer="95" rot="R90">GND</text>
<pin name="GND" x="0" y="-7.62" visible="pad" length="middle" direction="pwr" rot="R90"/>
<pin name="VCC" x="0" y="7.62" visible="pad" length="middle" direction="pwr" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MCM44100" urn="urn:adsk.eagle:component:18773/1" prefix="IC" uservalue="yes" library_version="2">
<description>&lt;b&gt;MEMORY&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="CM44100" x="0" y="0"/>
<gate name="P" symbol="PWRN" x="-30.48" y="7.62" addlevel="request"/>
</gates>
<devices>
<device name="" package="SOJ26-20">
<connects>
<connect gate="G$1" pin="!RAS" pad="3"/>
<connect gate="G$1" pin="A0" pad="9"/>
<connect gate="G$1" pin="A1" pad="10"/>
<connect gate="G$1" pin="A10" pad="5"/>
<connect gate="G$1" pin="A2" pad="11"/>
<connect gate="G$1" pin="A3" pad="12"/>
<connect gate="G$1" pin="A4" pad="14"/>
<connect gate="G$1" pin="A5" pad="15"/>
<connect gate="G$1" pin="A6" pad="16"/>
<connect gate="G$1" pin="A7" pad="17"/>
<connect gate="G$1" pin="A8" pad="18"/>
<connect gate="G$1" pin="A9" pad="22"/>
<connect gate="G$1" pin="CAS" pad="24"/>
<connect gate="G$1" pin="D" pad="1"/>
<connect gate="G$1" pin="Q" pad="25"/>
<connect gate="G$1" pin="W" pad="2"/>
<connect gate="P" pin="GND" pad="26"/>
<connect gate="P" pin="VCC" pad="13"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:18765/1"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="micrel" urn="urn:adsk.eagle:library:281">
<description>Devices from www.micrel.com&lt;p&gt;
<packages>
<package name="MLF10" urn="urn:adsk.eagle:footprint:19172/1" library_version="1">
<description>&lt;b&gt;MLF 10&lt;/b&gt; (ML) 2.5 x 2.5 mm, 10-Pin Package&lt;p&gt;
Source: Source: http://www.micrel.com/_PDF/mic2297.pdf</description>
<wire x1="-1.2" y1="1.2" x2="1.2" y2="1.2" width="0.1016" layer="21"/>
<wire x1="1.2" y1="1.2" x2="1.2" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="1.2" y1="-1.2" x2="-1.2" y2="-1.2" width="0.1016" layer="21"/>
<wire x1="-1.2" y1="-1.2" x2="-1.2" y2="1.2" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="1" dx="0.6" dy="0.25" layer="1" stop="no" cream="no"/>
<smd name="2" x="-1" y="0.5" dx="0.6" dy="0.25" layer="1" stop="no" cream="no"/>
<smd name="3" x="-1" y="0" dx="0.6" dy="0.25" layer="1" stop="no" cream="no"/>
<smd name="4" x="-1" y="-0.5" dx="0.6" dy="0.25" layer="1" stop="no" cream="no"/>
<smd name="5" x="-1" y="-1" dx="0.6" dy="0.25" layer="1" stop="no" cream="no"/>
<smd name="6" x="1" y="-1" dx="0.6" dy="0.25" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="7" x="1" y="-0.5" dx="0.6" dy="0.25" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="8" x="1" y="0" dx="0.6" dy="0.25" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="9" x="1" y="0.5" dx="0.6" dy="0.25" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="10" x="1" y="1" dx="0.6" dy="0.25" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="EXP" x="0" y="0" dx="1.2" dy="1.9" layer="1" stop="no" cream="no"/>
<text x="-1.25" y="1.5" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.25" y="-2.75" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.325" y1="0.85" x2="-0.675" y2="1.15" layer="29"/>
<rectangle x1="-1.275" y1="0.9" x2="-0.725" y2="1.1" layer="31"/>
<rectangle x1="-1.325" y1="0.35" x2="-0.675" y2="0.65" layer="29"/>
<rectangle x1="-1.275" y1="0.4" x2="-0.725" y2="0.6" layer="31"/>
<rectangle x1="-1.325" y1="-0.15" x2="-0.675" y2="0.15" layer="29"/>
<rectangle x1="-1.275" y1="-0.1" x2="-0.725" y2="0.1" layer="31"/>
<rectangle x1="-1.325" y1="-0.65" x2="-0.675" y2="-0.35" layer="29"/>
<rectangle x1="-1.275" y1="-0.6" x2="-0.725" y2="-0.4" layer="31"/>
<rectangle x1="-1.325" y1="-1.15" x2="-0.675" y2="-0.85" layer="29"/>
<rectangle x1="-1.275" y1="-1.1" x2="-0.725" y2="-0.9" layer="31"/>
<rectangle x1="0.675" y1="-1.15" x2="1.325" y2="-0.85" layer="29" rot="R180"/>
<rectangle x1="0.725" y1="-1.1" x2="1.275" y2="-0.9" layer="31" rot="R180"/>
<rectangle x1="0.675" y1="-0.65" x2="1.325" y2="-0.35" layer="29" rot="R180"/>
<rectangle x1="0.725" y1="-0.6" x2="1.275" y2="-0.4" layer="31" rot="R180"/>
<rectangle x1="0.675" y1="-0.15" x2="1.325" y2="0.15" layer="29" rot="R180"/>
<rectangle x1="0.725" y1="-0.1" x2="1.275" y2="0.1" layer="31" rot="R180"/>
<rectangle x1="0.675" y1="0.35" x2="1.325" y2="0.65" layer="29" rot="R180"/>
<rectangle x1="0.725" y1="0.4" x2="1.275" y2="0.6" layer="31" rot="R180"/>
<rectangle x1="0.675" y1="0.85" x2="1.325" y2="1.15" layer="29" rot="R180"/>
<rectangle x1="0.725" y1="0.9" x2="1.275" y2="1.1" layer="31" rot="R180"/>
<rectangle x1="-0.625" y1="-0.975" x2="0.625" y2="0.975" layer="29"/>
<rectangle x1="-0.525" y1="-0.875" x2="0.525" y2="0.875" layer="31"/>
</package>
</packages>
<packages3d>
<package3d name="MLF10" urn="urn:adsk.eagle:package:19173/1" type="box" library_version="1">
<description>MLF 10 (ML) 2.5 x 2.5 mm, 10-Pin Package
<packageinstances>
<packageinstance name="MLF10"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="MIC2297" urn="urn:adsk.eagle:symbol:19171/1" library_version="1">
<wire x1="-7.62" y1="12.7" x2="10.16" y2="12.7" width="0.254" layer="94"/>
<wire x1="10.16" y1="12.7" x2="10.16" y2="-12.7" width="0.254" layer="94"/>
<wire x1="10.16" y1="-12.7" x2="-7.62" y2="-12.7" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-12.7" x2="-7.62" y2="12.7" width="0.254" layer="94"/>
<text x="-7.62" y="13.97" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VIN" x="-10.16" y="10.16" length="short" direction="in"/>
<pin name="EN" x="-10.16" y="7.62" length="short" direction="in"/>
<pin name="BRT" x="-10.16" y="2.54" length="short" direction="in"/>
<pin name="REF" x="-10.16" y="-2.54" length="short" direction="in"/>
<pin name="AGND" x="-10.16" y="-7.62" length="short" direction="in"/>
<pin name="PGND" x="-10.16" y="-10.16" length="short" direction="in"/>
<pin name="COMP" x="12.7" y="-7.62" length="short" direction="pas" rot="R180"/>
<pin name="FB" x="12.7" y="-2.54" length="short" direction="in" rot="R180"/>
<pin name="OVP" x="12.7" y="5.08" length="short" direction="in" rot="R180"/>
<pin name="SW" x="12.7" y="10.16" length="short" direction="oc" rot="R180"/>
<pin name="GND" x="12.7" y="-10.16" length="short" direction="in" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MIC2297" urn="urn:adsk.eagle:component:19174/1" prefix="IC" library_version="1">
<description>&lt;b&gt;40V PWM Boost Regulator White LED Driver&lt;/b&gt;&lt;p&gt;
<gates>
<gate name="G$1" symbol="MIC2297" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MLF10">
<connects>
<connect gate="G$1" pin="AGND" pad="6"/>
<connect gate="G$1" pin="BRT" pad="7"/>
<connect gate="G$1" pin="COMP" pad="5"/>
<connect gate="G$1" pin="EN" pad="4"/>
<connect gate="G$1" pin="FB" pad="9"/>
<connect gate="G$1" pin="GND" pad="EXP"/>
<connect gate="G$1" pin="OVP" pad="2"/>
<connect gate="G$1" pin="PGND" pad="1"/>
<connect gate="G$1" pin="REF" pad="8"/>
<connect gate="G$1" pin="SW" pad="10"/>
<connect gate="G$1" pin="VIN" pad="3"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:19173/1"/>
<technologies>
<attribute name="MPN" value="MIC2297-38YML TR" constant="no"/>
<attribute name="OC_FARNELL" value="1663107" constant="no"/>
<attribute name="OC_NEWARK" value="11R3489" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="IC1" library="memory-motorola-dram" library_urn="urn:adsk.eagle:library:275" deviceset="MCM44100" device="" package3d_urn="urn:adsk.eagle:package:18765/1"/>
<part name="IC2" library="memory-motorola-dram" library_urn="urn:adsk.eagle:library:275" deviceset="MCM44100" device="" package3d_urn="urn:adsk.eagle:package:18765/1"/>
<part name="IC3" library="micrel" library_urn="urn:adsk.eagle:library:281" deviceset="MIC2297" device="" package3d_urn="urn:adsk.eagle:package:19173/1"/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="IC1" gate="G$1" x="83.82" y="55.88" smashed="yes">
<attribute name="VALUE" x="76.2" y="33.02" size="1.778" layer="96"/>
<attribute name="NAME" x="76.2" y="76.835" size="1.778" layer="95"/>
</instance>
<instance part="IC2" gate="G$1" x="7.62" y="55.88" smashed="yes">
<attribute name="VALUE" x="0" y="33.02" size="1.778" layer="96"/>
<attribute name="NAME" x="0" y="76.835" size="1.778" layer="95"/>
</instance>
</instances>
<busses>
<bus name="MISO,MOSI,SCK,VALAMI[0..10]">
<segment>
<wire x1="-17.78" y1="73.66" x2="-17.78" y2="5.08" width="0.762" layer="92"/>
<wire x1="-17.78" y1="5.08" x2="60.96" y2="5.08" width="0.762" layer="92"/>
<wire x1="60.96" y1="5.08" x2="60.96" y2="73.66" width="0.762" layer="92"/>
</segment>
</bus>
</busses>
<nets>
<net name="VALAMI0" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="A1"/>
<wire x1="-17.78" y1="73.66" x2="-17.78" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-17.78" y1="71.12" x2="-5.08" y2="71.12" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC1" gate="G$1" pin="A7"/>
<wire x1="71.12" y1="55.88" x2="60.96" y2="55.88" width="0.1524" layer="91"/>
</segment>
</net>
<net name="VALAMI1" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="A5"/>
<wire x1="-17.78" y1="60.96" x2="-5.08" y2="60.96" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC1" gate="G$1" pin="A3"/>
<wire x1="71.12" y1="66.04" x2="60.96" y2="66.04" width="0.1524" layer="91"/>
</segment>
</net>
<net name="MISO" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="A7"/>
<wire x1="-17.78" y1="55.88" x2="-5.08" y2="55.88" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="-17.78" y1="27.94" x2="-17.78" y2="25.4" width="0.1524" layer="91"/>
<wire x1="-17.78" y1="25.4" x2="0" y2="25.4" width="0.1524" layer="91"/>
<label x="0" y="25.4" size="1.778" layer="95" xref="yes"/>
</segment>
</net>
<net name="MOSI" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="A10"/>
<wire x1="60.96" y1="50.8" x2="60.96" y2="48.26" width="0.1524" layer="91"/>
<wire x1="60.96" y1="48.26" x2="71.12" y2="48.26" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="-17.78" y1="20.32" x2="-17.78" y2="17.78" width="0.1524" layer="91"/>
<wire x1="-17.78" y1="17.78" x2="0" y2="17.78" width="0.1524" layer="91"/>
<label x="0" y="17.78" size="1.778" layer="95" xref="yes"/>
</segment>
</net>
<net name="A1" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="Q"/>
<wire x1="20.32" y1="71.12" x2="27.94" y2="71.12" width="0.1524" layer="91"/>
<label x="27.94" y="71.12" size="1.778" layer="95" xref="yes"/>
</segment>
</net>
<net name="A2" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="D"/>
<wire x1="20.32" y1="60.96" x2="27.94" y2="60.96" width="0.1524" layer="91"/>
<label x="27.94" y="60.96" size="1.778" layer="95" xref="yes"/>
</segment>
</net>
<net name="SCK" class="0">
<segment>
<wire x1="-17.78" y1="12.7" x2="5.08" y2="12.7" width="0.1524" layer="91"/>
<label x="5.08" y="12.7" size="1.778" layer="95" xref="yes"/>
</segment>
</net>
</nets>
</sheet>
<sheet>
<plain>
</plain>
<instances>
<instance part="IC3" gate="G$1" x="40.64" y="68.58" smashed="yes">
<attribute name="NAME" x="33.02" y="82.55" size="1.778" layer="95"/>
<attribute name="VALUE" x="33.02" y="53.34" size="1.778" layer="96"/>
</instance>
</instances>
<busses>
</busses>
<nets>
<segment>
<pinref part="IC3" gate="G$1" pin="EN"/>
<wire x1="30.48" y1="76.2" x2="17.78" y2="76.2" width="0.1524" layer="91"/>
<label x="17.78" y="76.2" size="1.778" layer="95" rot="R180" xref="yes"/>
</segment>
</net>
<segment>
<pinref part="IC3" gate="G$1" pin="REF"/>
<wire x1="30.48" y1="66.04" x2="17.78" y2="66.04" width="0.1524" layer="91"/>
<label x="17.78" y="66.04" size="1.778" layer="95" rot="R180" xref="yes"/>
</segment>
</net>
<segment>
<pinref part="IC3" gate="G$1" pin="SW"/>
<wire x1="53.34" y1="78.74" x2="66.04" y2="78.74" width="0.1524" layer="91"/>
<label x="66.04" y="78.74" size="1.778" layer="95" xref="yes"/>
</segment>
</net>
<segment>
<pinref part="IC3" gate="G$1" pin="OVP"/>
<wire x1="53.34" y1="73.66" x2="66.04" y2="73.66" width="0.1524" layer="91"/>
<label x="66.04" y="73.66" size="1.778" layer="95" xref="yes"/>
</segment>
</net>
<segment>
<pinref part="IC3" gate="G$1" pin="FB"/>
<wire x1="53.34" y1="66.04" x2="66.04" y2="66.04" width="0.1524" layer="91"/>
<label x="66.04" y="66.04" size="1.778" layer="95" xref="yes"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
</compatibility>
</eagle>
