<root>
<document schema='100' platform='pic8' license='Upgraded,v5 User,******' title='' description='' guid='' target='16F887' >
	<config data='#0,23c4#1,3fff' clkspd='8000000' simspd='1' usewdt='0' constif='0' />
	<supplement use='0' head='' body='' />
	<debug />
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' protect='187' />
		<definition guid='' vmin='0' vmaj='1' visiblename='' description='' category='' dynamic='0' standalone='0' iconpath='' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='adc4' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='adc3' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='adc2' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='m10' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='adc1' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='tmr0_counter' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='houradd' type='sint' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='adc0' type='sint' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='m1' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='x' type='sint' array='0' byref='0' description='' isconst='0' isinit='0' usrinit='0' setinit='' />
				</variable>
					<def class_type='variable' name='hour12h' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='valid' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='btn' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='h10' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='h1' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='blshift' type='sint' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='b2' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='pmbit' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='b1' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
					<def class_type='variable' name='b0' type='ubyte' array='0' byref='0' description='' isconst='0' isinit='1' usrinit='0x0' setinit='0' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='DisplayDataInvalid' description='' >
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='252' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='128' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='64' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='32' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='16' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='8' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='4' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='0' port='1' mask='0' exp='0b00000010' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='128' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='64' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='32' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='16' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='8' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='4' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='2' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='1' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='59' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='32' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='16' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='8' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='2' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='1' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='0' port='3' mask='0' exp='0b00100010' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='128' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='64' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='32' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='16' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='8' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='4' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='2' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='1' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='4' mask='7' exp='0b00000100' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='4' mask='4' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='4' mask='2' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='4' mask='1' exp='0' />
					</flowline>
				</macro>
				<macro >
					<flowline name='ReadButtons' description='' >
						<command class_type='call' title='Komponens makró hívása' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' component='v5__adc0' macro='GetByte' >
							<return exp='x' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x &lt; 20' swap='0' >
								<command class_type='calculation' title='Számítás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' >
									<exp exp='btn = 0' />
								</command>
							</flowline>
							<flowline name='ReadButtons' description='' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x &gt; 40 AND x &lt; 100' swap='0' >
									<exp exp='btn = 1' />
								</command>
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x &gt; 100 AND x &lt; 180' swap='0' >
									<exp exp='btn = 2' />
								</command>
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='200 &lt; x' swap='0' >
									<exp exp='btn = 3' />
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='DisplayTest' description='' >
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='48' exp='0b00110000' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='32' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='16' exp='1' />
						<command class_type='delay' title='Késleltetés' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='100' type='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='186' exp='0b10001010' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='128' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='8' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='206' exp='0b01000100' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='64' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='4' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='2' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='3' mask='16' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='69' exp='0b00000001' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='1' mask='1' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='176' exp='0b10100000' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='128' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='2' mask='32' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='1' mask='1' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='224' exp='0b01000000' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='64' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='32' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='48' exp='0b00010000' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='16' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='76' exp='0b00001100' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='8' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='4' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='2' mask='16' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='12' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='36' exp='0b00100100' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='32' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='4' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='4' mask='5' exp='0b00000101' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='4' mask='1' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='44' exp='0b00001000' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='8' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='4' mask='7' exp='0b00000010' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='4' mask='4' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='4' mask='2' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='24' exp='0b00010000' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='16' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='4' mask='2' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='2' mask='2' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='144' exp='0b10000000' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='128' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='3' mask='2' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='10' exp='0b00001000' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='8' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='192' exp='0b01000000' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='0' mask='64' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='3' exp='0b00000001' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='2' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='1' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='9' exp='0b00000001' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='1' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='0' mask='64' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='2' mask='1' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='3' mask='1' exp='0' />
					</flowline>
				</macro>
				<macro >
					<flowline name='ReadRMC' description='' >
						<command class_type='label' title='Kapcsolódási pont' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' labelid='0' labelname='A' />
							<exp exp='b2 = b1' />
							<exp exp='b1 = b0' />
						</command>
						<command class_type='call' title='Komponens makró hívása' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' component='v5__rs2320' macro='ReceiveChar' >
							<return exp='b0' />
							<argument exp='100' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,36,0' break='0' mark='0' disable='0' hide='0' customize='0' exp='b2 = 82 AND b1 = 77 AND b0 = 67' swap='0' >
								<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='3' mask='4' exp='0' />
									<exp exp='tmr0_counter = 0' />
								</command>
									<return exp='h10' />
								</command>
								</command>
									<return exp='h1' />
								</command>
									<return exp='m10' />
								</command>
									<return exp='m1' />
								</command>
								<command class_type='loop' title='Ciklus' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='1' type='2' start='1' count='7' breakend='0' >
											<return exp='valid' />
										</command>
									</flowline>
								</command>
							</flowline>
								<command class_type='goto' title='Menj a kapcsolódási porthoz' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' labelid='0' labelname='' />
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Init' description='' >
						<command class_type='call' title='Komponens makró hívása' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' component='v5__eeprom0' macro='Read' >
							<return exp='x' />
							<argument exp='0' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x = 133' swap='0' >
							<flowline name='Init' description='' />
								<command class_type='call' title='Komponens makró hívása' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' component='v5__eeprom0' macro='Write' >
									<argument exp='1' />
								</command>
									<argument exp='2' />
								</command>
									<argument exp='3' />
								</command>
									<argument exp='4' />
								</command>
									<argument exp='5' />
								</command>
									<argument exp='133' />
								</command>
							</flowline>
						</command>
							<return exp='blshift' />
						</command>
							<return exp='x' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x = 1' swap='0' >
									<exp exp='blshift = blshift * -1' />
								</command>
							</flowline>
						</command>
							<return exp='hour12h' />
						</command>
							<return exp='houradd' />
						</command>
							<return exp='x' />
						</command>
									<exp exp='houradd = houradd * -1' />
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='ConvertData' description='' >
						<command class_type='switch' title='Többirányú elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,25,511,325' break='0' mark='0' disable='0' hide='0' customize='0' exp='h10' >
							<case >
								<flowline name='ConvertData' description='' />
							</case>
							<case exp='48' >
										<exp exp='x = 0' />
									</command>
								</flowline>
							</case>
							<case exp='49' >
										<exp exp='x = 1' />
									</command>
								</flowline>
							</case>
							<case exp='50' >
										<exp exp='x = 2' />
									</command>
								</flowline>
							</case>
						</command>
						<command class_type='switch' title='Többirányú elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,25,511,325' break='0' mark='0' disable='0' hide='0' customize='0' exp='h1' >
							<case >
							</case>
							<case exp='48' >
										<exp exp='x = x * 10' />
									</command>
								</flowline>
							</case>
							<case exp='49' >
										<exp exp='x = x * 10 + 1' />
									</command>
								</flowline>
							</case>
							<case exp='50' >
										<exp exp='x = x * 10 + 2' />
									</command>
								</flowline>
							</case>
							<case exp='51' >
										<exp exp='x = x * 10 + 3' />
									</command>
								</flowline>
							</case>
							<case exp='52' >
										<exp exp='x = x * 10 + 4' />
									</command>
								</flowline>
							</case>
							<case exp='53' >
										<exp exp='x = x * 10 + 5' />
									</command>
								</flowline>
							</case>
							<case exp='54' >
										<exp exp='x = x * 10 + 6' />
									</command>
								</flowline>
							</case>
							<case exp='55' >
										<exp exp='x = x * 10 + 7' />
									</command>
								</flowline>
							</case>
							<case exp='56' >
										<exp exp='x = x * 10 + 8' />
										<exp exp='' />
									</command>
								</flowline>
							</case>
							<case exp='57' >
										<exp exp='x = x * 10 + 9' />
									</command>
								</flowline>
							</case>
						</command>
							<exp exp='x = x + houradd' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x &gt; 23' swap='0' >
									<exp exp='x = x - 24' />
								</command>
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x &lt; 0' swap='0' >
									<exp exp='x = x + 24' />
								</command>
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='hour12h = 1' swap='0' >
								<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x &gt; 11' swap='0' >
											<exp exp='pmbit = 1' />
											<exp exp='' />
										</command>
									</flowline>
											<exp exp='pmbit = 0' />
										</command>
									</flowline>
								</command>
								<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x &gt; 12' swap='0' >
											<exp exp='x = x - 12' />
										</command>
									</flowline>
								</command>
								<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='x = 0' swap='0' >
											<exp exp='x = 12' />
										</command>
									</flowline>
								</command>
							</flowline>
								</command>
							</flowline>
						</command>
							<exp exp='h1 = x MOD 10' />
							<exp exp='h10 = x / 10' />
						</command>
						<command class_type='switch' title='Többirányú elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,25,511,325' break='0' mark='0' disable='0' hide='0' customize='0' exp='m10' >
							<case >
							</case>
							<case exp='48' >
										<exp exp='m10 = 0' />
									</command>
								</flowline>
							</case>
							<case exp='49' >
										<exp exp='m10 = 1' />
									</command>
								</flowline>
							</case>
							<case exp='50' >
										<exp exp='m10 = 2' />
									</command>
								</flowline>
							</case>
							<case exp='51' >
										<exp exp='m10 = 3' />
									</command>
								</flowline>
							</case>
							<case exp='52' >
										<exp exp='m10 = 4' />
									</command>
								</flowline>
							</case>
							<case exp='53' >
										<exp exp='m10 = 5' />
									</command>
								</flowline>
							</case>
						</command>
						<command class_type='switch' title='Többirányú elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,25,511,325' break='0' mark='0' disable='0' hide='0' customize='0' exp='m1' >
							<case >
							</case>
							<case exp='48' >
										<exp exp='m1 = 0' />
									</command>
								</flowline>
							</case>
							<case exp='49' >
										<exp exp='m1 = 1' />
									</command>
								</flowline>
							</case>
							<case exp='50' >
										<exp exp='m1 = 2' />
									</command>
								</flowline>
							</case>
							<case exp='51' >
										<exp exp='m1 = 3' />
									</command>
								</flowline>
							</case>
							<case exp='52' >
										<exp exp='m1 = 4' />
									</command>
								</flowline>
							</case>
							<case exp='53' >
										<exp exp='m1 = 5' />
									</command>
								</flowline>
							</case>
							<case exp='54' >
										<exp exp='m1 = 6' />
									</command>
								</flowline>
							</case>
							<case exp='55' >
										<exp exp='m1 = 7' />
									</command>
								</flowline>
							</case>
							<case exp='56' >
										<exp exp='m1 = 8' />
									</command>
								</flowline>
							</case>
							<case exp='57' >
										<exp exp='m1 = 9' />
									</command>
								</flowline>
							</case>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='TMR0_Macro' description='' >
							<exp exp='tmr0_counter = tmr0_counter + 1' />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Setup' description='' >
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='12' exp='0b00000100' />
							<exp exp='h10 = 0' />
							<exp exp='h1 = 1' />
						</command>
						<command class_type='call' title='Makró hívás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' macro='DisplayDataValid' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='3' mask='16' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='49' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='36' exp='0' />
						<command class_type='loop' title='Ciklus' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='btn = 1' type='0' start='1' count='1' breakend='0' >
								<command class_type='call' title='Makró hívás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' macro='ReadButtons' />
							</flowline>
						</command>
						<command class_type='delay' title='Késleltetés' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='255' type='1' />
						<command class_type='comment' title='' comment='Set HourAdd' ccode='' textshow='1' textmode='0' textarea='12,0,487,300' break='0' mark='0' disable='0' hide='0' customize='0' />
							<exp exp='h10 = 1' />
							<exp exp='h1 = 11' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='houradd &lt; 0' swap='0' >
									<exp exp='m1 = houradd MOD 10' />
									<exp exp='m10 = houradd / 10' />
								</command>
								<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='4' mask='4' exp='1' />
							</flowline>
								</command>
								<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='4' mask='4' exp='0' />
							</flowline>
						</command>
						<command class_type='loop' title='Ciklus' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='1' type='0' start='1' count='1' breakend='0' >
								<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='btn = 0' swap='0' >
											<exp exp='houradd = houradd + 1' />
										</command>
										<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='houradd &gt; 13' swap='0' >
													<exp exp='houradd = -13' />
												</command>
											</flowline>
											<flowline name='Setup' description='' />
										</command>
												</command>
											</flowline>
												</command>
											</flowline>
										</command>
										<command class_type='delay' title='Késleltetés' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='150' type='1' />
									</flowline>
								</command>
								<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='btn = 2' swap='0' >
											<exp exp='houradd = houradd - 1' />
										</command>
										<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='houradd &lt; -13' swap='0' >
													<exp exp='houradd = 13' />
												</command>
											</flowline>
										</command>
												</command>
											</flowline>
												</command>
											</flowline>
										</command>
									</flowline>
								</command>
								<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='btn = 1' swap='0' >
									</flowline>
								</command>
							</flowline>
						</command>
							</flowline>
						</command>
								</command>
									<argument exp='houradd' />
								</command>
								</command>
								</command>
							</flowline>
								</command>
								</command>
							</flowline>
						</command>
						<command class_type='comment' title='' comment='Set HourFormat' ccode='' textshow='1' textmode='0' textarea='12,0,487,300' break='0' mark='0' disable='0' hide='0' customize='0' />
							<exp exp='h10 = 2' />
						</command>
								</command>
							</flowline>
								</command>
							</flowline>
						</command>
								<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='btn = 0 OR btn = 2' swap='0' >
													<exp exp='hour12h = 0' />
												</command>
											</flowline>
													<exp exp='hour12h = 1' />
												</command>
											</flowline>
										</command>
									</flowline>
								</command>
										<command class_type='goto' title='Menj a kapcsolódási porthoz' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' labelid='1' labelname='' />
									</flowline>
								</command>
							</flowline>
						</command>
						<command class_type='label' title='Kapcsolódási pont' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' labelid='1' labelname='B' />
							</flowline>
						</command>
							<argument exp='hour12h' />
						</command>
						<command class_type='comment' title='' comment='Setup LightnessShift' ccode='' textshow='1' textmode='0' textarea='12,0,487,300' break='0' mark='0' disable='0' hide='0' customize='0' />
							<exp exp='h10 = 3' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='blshift &lt; 0' swap='0' >
									<exp exp='m1 = blshift MOD 10' />
									<exp exp='m10 = blshift / 10' />
								</command>
							</flowline>
								</command>
							</flowline>
						</command>
											<exp exp='blshift = blshift + 1' />
										</command>
										<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='blshift &gt; 99' swap='0' >
													<exp exp='blshift = -99' />
												</command>
											</flowline>
										</command>
												</command>
											</flowline>
												</command>
											</flowline>
										</command>
									</flowline>
								</command>
											<exp exp='blshift = blshift - 1' />
										</command>
										<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='blshift &lt; -99' swap='0' >
													<exp exp='blshift = 99' />
												</command>
											</flowline>
										</command>
												</command>
											</flowline>
												</command>
											</flowline>
										</command>
									</flowline>
								</command>
										<command class_type='goto' title='Menj a kapcsolódási porthoz' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' labelid='2' labelname='' />
									</flowline>
								</command>
							</flowline>
						</command>
						<command class_type='label' title='Kapcsolódási pont' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' labelid='2' labelname='C' />
								</command>
									<argument exp='blshift' />
								</command>
								</command>
								</command>
							</flowline>
								</command>
								</command>
							</flowline>
						</command>
						</command>
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='19' exp='0b00000011' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='2' mask='1' exp='1' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='0' mask='32' exp='0' />
							</flowline>
						</command>
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='3' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='3' exp='0' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='132' exp='0' />
					</flowline>
				</macro>
				<macro >
					<flowline name='DisplayDataValid' description='' >
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='3' mask='8' exp='pmbit' />
							<case >
								<flowline name='DisplayDataValid' description='' />
							</case>
							<case exp='0' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='192' exp='0' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='11' exp='0' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='3' exp='0' />
								</flowline>
							</case>
							<case exp='1' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='192' exp='0b10000000' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='11' exp='0b0001' />
								</flowline>
							</case>
							<case exp='2' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='192' exp='0b11000000' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='2' exp='1' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='11' exp='0b0010' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='3' exp='0b11' />
								</flowline>
							</case>
							<case exp='3' >
								</flowline>
							</case>
						</command>
							<case >
							</case>
							<case exp='0' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='60' exp='0b110100' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='4' mask='7' exp='0b111' />
								</flowline>
							</case>
							<case exp='1' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='60' exp='0b010100' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='4' mask='7' exp='0' />
								</flowline>
							</case>
							<case exp='2' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='60' exp='0b101100' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='4' mask='7' exp='0b101' />
								</flowline>
							</case>
							<case exp='3' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='60' exp='0b111100' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='4' mask='7' exp='0b001' />
								</flowline>
							</case>
							<case exp='4' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='60' exp='0b011100' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='4' mask='7' exp='0b010' />
								</flowline>
							</case>
							<case exp='5' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='0' mask='60' exp='0b111000' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='4' mask='7' exp='0b011' />
								</flowline>
							</case>
							<case exp='6' >
								</flowline>
							</case>
							<case exp='7' >
								</flowline>
							</case>
							<case exp='8' >
								</flowline>
							</case>
							<case exp='9' >
								</flowline>
							</case>
						</command>
							<case >
							</case>
							<case exp='0' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='1' mask='1' exp='1' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='2' mask='32' exp='1' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='48' exp='0b110000' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='1' hide='0' customize='0' mode='1' port='3' mask='16' exp='1' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='240' exp='0b01110000' />
								</flowline>
							</case>
							<case exp='1' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='48' exp='0' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='240' exp='0b01000000' />
								</flowline>
							</case>
							<case exp='2' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='48' exp='0b010000' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='240' exp='0b10110000' />
								</flowline>
							</case>
							<case exp='3' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='240' exp='0b11110000' />
								</flowline>
							</case>
							<case exp='4' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='2' mask='48' exp='0b100000' />
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='240' exp='0b11000000' />
								</flowline>
							</case>
							<case exp='5' >
								</flowline>
							</case>
							<case exp='6' >
								</flowline>
							</case>
							<case exp='7' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='3' mask='240' exp='0b01010000' />
								</flowline>
							</case>
							<case exp='8' >
								</flowline>
							</case>
							<case exp='9' >
								</flowline>
							</case>
						</command>
							<case >
							</case>
							<case exp='0' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b10111110' />
								</flowline>
							</case>
							<case exp='1' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b10100000' />
								</flowline>
							</case>
							<case exp='2' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b11011010' />
								</flowline>
							</case>
							<case exp='3' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b11111000' />
								</flowline>
							</case>
							<case exp='4' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b11100100' />
								</flowline>
							</case>
							<case exp='5' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b01111100' />
								</flowline>
							</case>
							<case exp='6' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b01111110' />
								</flowline>
							</case>
							<case exp='7' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b10101000' />
								</flowline>
							</case>
							<case exp='8' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b11111110' />
								</flowline>
							</case>
							<case exp='9' >
									<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='2' port='1' mask='254' exp='0b11111100' />
								</flowline>
							</case>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='SetPWM' description='' >
							<exp exp='adc0 = adc1' />
							<exp exp='adc1 = adc2' />
							<exp exp='adc2 = adc3' />
							<exp exp='adc3 = adc4' />
						</command>
						<command class_type='call' title='Komponens makró hívása' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' component='v5__adc1' macro='GetByte' >
							<return exp='adc4' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='adc4 &gt; 249' swap='0' >
									<exp exp='adc4 = 0' />
								</command>
							</flowline>
							<flowline name='SetPWM' description='' />
						</command>
						<command class_type='calculation' title='Számítás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,36,0' break='0' mark='0' disable='0' hide='0' customize='0' >
							<exp exp='adc0 = adc0 + adc1 + adc2 + adc3 + adc4' />
							<exp exp='adc0 = adc0 / 5' />
							<exp exp='adc0 = adc0 + blshift' />
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='adc0 &lt; 5' swap='0' >
									<exp exp='adc0 = 5' />
								</command>
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='adc0 &gt; 104' swap='0' >
									<exp exp='adc0 = 104' />
								</command>
							</flowline>
						</command>
							<exp exp='adc0 = adc0 - 4' />
							<exp exp='x = (255 * adc0) / 100' />
						</command>
						<command class_type='call' title='Komponens makró hívása' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' component='v5__pwm0' macro='SetDutyCycle' >
							<argument exp='x' />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Main' description='' >
						<command class_type='call' title='' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,36,0' break='0' mark='0' disable='0' hide='0' customize='0' component='v5__rs2320' macro='Initialise' />
						<command class_type='native' title='C kód' comment='' ccode='osccon=0b01110001;' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' language='C' />
						<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='2' mask='4' exp='1' />
						<command class_type='delay' title='Késleltetés' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='2' type='2' />
						<command class_type='interrupt' title='Megszakítás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' enable='1' name='TMR0' call='TMR0_Macro' >
							<settings timer='1' prescale='256' postscale='-1' rollover='-1' bitcount='-1' trigger='3' maskhi='-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' masklo='-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-AAAA-wAAAP8AAAD-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' >
								<option value='1' />
								<option value='0' />
								<option value='8' />
								<option value='-1' />
							</settings>
						</command>
						<command class_type='call' title='Makró hívás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' macro='Init' />
						<command class_type='call' title='Makró hívás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' macro='DisplayTest' />
						<command class_type='call' title='Komponens makró hívása' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' component='v5__pwm0' macro='Enable' />
							<argument exp='255' />
						</command>
										<command class_type='call' title='Makró hívás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' macro='Setup' />
									</flowline>
									<flowline name='Main' description='' />
								</command>
									<exp exp='valid = 0' />
								</command>
								<command class_type='call' title='Makró hívás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' macro='ReadRMC' />
								<command class_type='loop' title='Ciklus' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='tmr0_counter &lt; 15' type='0' start='1' count='1' breakend='0' >
								</command>
								<command class_type='decision' title='Feltételes elágazás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' exp='valid = 65' swap='0' >
										<command class_type='call' title='Makró hívás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' macro='ConvertData' />
										<command class_type='output' title='Kimenet' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' mode='1' port='3' mask='4' exp='1' />
									</flowline>
										<command class_type='call' title='Makró hívás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' macro='DisplayDataInvalid' />
									</flowline>
								</command>
								<command class_type='call' title='Makró hívás' comment='' ccode='' textshow='1' textmode='0' textarea='36,0,511,300' break='0' mark='0' disable='0' hide='0' customize='0' macro='SetPWM' />
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='c73616d1-7ad0-45d9-aada-69ccfa4c5efc' vmin='0' vmaj='0' codename='v5__rs2320' x='-1.82857' y='-1.82857' z='0' xsz='60' ysz='26' zsz='1.51' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' >
				<resources />
				<properties />
				<values >
					<value target='CHANNEL' data='1' />
					<value target='FLOWEN' data='0' />
					<value target='ECHO' data='0' />
					<value target='BAUD_LIST' data='4' />
					<value target='DBITS' data='8' />
					<value target='RETURN' data='0' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='dcbf571f-a6fa-402d-bdd4-be00cca4070f' vmin='0' vmaj='0' codename='v5__eeprom0' x='78.1714' y='-4.11429' z='0' xsz='47.7143' ysz='47.7143' zsz='1.14286' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' >
				<resources />
				<properties />
				<values />
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='444fb704-814c-4707-a15c-759ba088505c' vmin='0' vmaj='0' codename='v5__pwm0' x='135.314' y='0.457143' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' >
				<resources />
				<properties />
				<values >
					<value target='PERIOD' data='255' />
					<value target='PRESCALE' data='4' />
					<value target='HWALT' data='0' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='14683ea8-5a08-4b3a-be2d-3dea3e17e720' vmin='0' vmaj='0' codename='v5__adc0' x='-136.686' y='2.74286' z='0' xsz='25.1419' ysz='25.1419' zsz='18.45' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' >
				<resources />
				<properties />
				<values >
					<value target='channel' data='0' />
					<value target='actime' data='40' />
					<value target='vrefvol' data='500' />
					<value target='vrefop' data='0' />
					<value target='convspd' data='2' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='14683ea8-5a08-4b3a-be2d-3dea3e17e720' vmin='0' vmaj='0' codename='v5__adc1' x='-74.9714' y='2.74286' z='0' xsz='25.1419' ysz='25.1419' zsz='18.45' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' >
				<resources />
				<properties />
				<values >
					<value target='channel' data='1' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
</document>
</root>
