[mp3DirectCut Language File]
 Language: Generic/English
 Composer: Martin Pesch
 Version:  2.09
 Update:   2008-05-30
 IMPORTANT INFORMATIONS FOR TRANSLATORS
 This is the english template file. If you want to write
 or update a translation, please note these things:
 o You should contact the author first, to make sure that
   not another one is already working on the same thing.
   Otherwise it cannot be guaranted that your translation
   will be published.
 o Your real name is needed in the "Composer" field above
   (may be together with an email address or website if you
   want).
 o If you update an existing file, please use the language
   file of the latest distribution as base, because even
   without translation of the updated parts the files
   might be adapted to the newer program version.
  CHANGES AND ADDITIONS
 Version 2.05:
   item changed: men023=&Undo	Ctrl+Z
   new item: dlg067=Keep Lame data in Xing headers
 Version 2.06:
   new item: men028
   cosmetically changed: men036 - men041
   new items: men046 - men049
   new items: men074 - men079
Version 2.07:
   new item: men068=&New program window
Version 2.08:
   removed item: men057
   changed items: win023, men012, dlg049, dlg067
   new items: msg009, msg028, msg034, msg035, msg036, msg037
   new items: cfg006, cfg050, cfg051, cfg055, cfg056
Version 2.09:
   new item: dlg055
 TRANSLATION AND SHORTCUT NOTES
 You should not translate terms like "Cue sheet",
 "header" or "frame", as they are technical expressions
 (like "Playlist" or "samplerate") and of international
 use in many cases.
 Please be sure to keep the same keyboard shortcuts
 for the "win"-button area (e.g. for "win007=&Edit" the
 shortcut must always be "e". If the word doesn't contain
 an "e" in your language, you must leave out the "&" or
 set an "&e" besides the word).
 In the menus you can choose the fast access letters
 on your own, but each underlined letter in a menu may
 appear only once. The shortcuts on the other hand are
 even fixed in the menus. Example:
   &Open   Ctrl+O
   "&Open" could be changed to "Op&en".
   The O in "Ctrl+O" must not be changed.
 Entrys beginning with ### are comments and not needed
 to be translated. Even normal text (like this) will be
 ignored by the program.
 A translation of an item is not compelling. If you leave
 out an item, the program uses the default english text
 for it.
 Menus
men000=&File
men001=&Edit
men002=S&pecial
men003=&List
men004=&Settings
men005=&?
men010=&Open...	Ctrl+O
men011=&Close	Ctrl+F4
men012=&Save all audio...	Ctrl+W
men013=Save s&election...	Ctrl+E
###men014=Appen&d all/selection to...	Ctrl+D
men015=Save spli&t...	Ctrl+T
men016=Save P&roject file/Cue sheet	Ctrl+S
men017=Save &Project file/Cue sheet as...
men018=&Quit	Alt+F4
men019=Create simple &fade	Ctrl+F
men020=Remo&ve selected elements
men021=&Gain...	Ctrl+G
men022=Tag &ID3 and file info...	Ctrl+I
men023=&Undo	Ctrl+Z
men024=&Remove selection	Ctrl+R
men025=Select &All	Ctrl+A
men026=Nor&malize...	Ctrl+M
men027=&Pause detection...
men028=Cr&op
###men029 (used earlier)
men030=Cu&t	Ctrl+X
men031=&Copy	Ctrl+C
men032=&Paste	Ctrl+V
men033=S&elect current part
men034=&Names and part properties...	Ctrl+N
men035=Set Cue f&lag for all simple split points
men036=|....     <<	1
men037=|....     >>	2
men038=  ....|   <<	3
men039=  ....|   >>	4
men040=|.....|   <<	5
men041=|.....|   >>	6
men042=&Auto Cue...
men043=Save Cue sheet and edit with &Notepad
men044=High speed recording
men045=Load Cue sheet over current audio file...
men046=Selection fine adjustment
men047=Trim/move current point
men048=Keyboard recommended	v
men049=Loop play selection	F4
men050=(No cut/gain/cue present)
men051=Cut
men052=Gain
men053=Cue
men054=&Configure...	F11
men055=&Big timer
men056=Show &miliseconds
###men057=Show &dB scale (used earlier)
###men058 (used earlier)
men059=Enable Mar&gin button
men060=Show b&itrate graph on VBR
men061=Big shows &relative times
###men062 (used earlier)
men063=&Keep date of source file
men064=&Manual
men065=&FAQ
men066=&About
men067=Use '&TOC' correction on VBR
men070=MPEG graph &level
men071=Higher	Num +
men072=Lower	Num  -
men073=Default
men074=..<<..|......	Ctrl+1
men075=..>>..|......	Ctrl+2
men076=......|..<<..	Ctrl+3
men077=......|..>>..	Ctrl+4
men078=......|......   <<	Ctrl+5, Alt+Left, Mouse
men079=......|......   >>	Ctrl+6, Alt+Right, Mouse
 Main window: groups, buttons, edit field text
win000=Nav
win001=Edit
win002=Audio
win003=&In
win004=&Out
win005=&Cut
###win006 (used earlier)
win007=&Edit
win008=Set &begin
win009=Set e&nd
win010=Rew
win011=&Stop
win012=&Play
win013=&Rec
win014=Margin
win020=Total
win021=Now
win022=Selection
win023=Part
win024=(VBR visualisation shows displaced cursor)
win025=(Layer 2 graph shows limited audio information)
win026=Recording time
win027=Buffer
win028= Press Play to start recording...
win029=Writing
win030= Press 'Set begin' to set cues
win031=Fast Play
 Tooltips
ttp000=Skip back defineable large step   [Page up]
ttp001=Skip back defineable small step   [Left]
ttp002=Skip forward defineable small step   [Right]
ttp003=Skip forward defineable large step   [Page down]
ttp004=Go to previous edit range   [Ctrl+Left]
ttp005=Go to next edit range   [Ctrl+Right]
ttp006=Go to beginning of selection   [Up]
ttp007=Go to end of selection   [Down]
ttp008=Zoom in   [i]
ttp009=Zoom out   [o]
ttp010=Cut selection / create edit point   [Del]
###ttp011 (used earlier)
ttp012=Restore range from highlighted cut / remove edit point (not possible on pasted ranges!)   [e]
ttp013=Selection beginning = current position   [b]
ttp014=Selection end = current position   [n]
ttp015=Prelisten 2 sec TO BEGINNING of selection   [F5]
ttp016=Prelisten 2 sec FROM BEGINNING of selection   [F6]
ttp017=Prelisten 2 sec TO END of selection / Fast Play: slower   [F7]
ttp018=Prelisten 2 sec FROM END of selection / Fast Play: faster   [F8]
ttp019=Prelisten selection 4 sec AS CUT   [F9]
ttp020=Rewind   [Home]
ttp021=Stop play or record   [Space]
ttp022=Play from cursor or start recording   [Space]
ttp023=Initialize recording new file   [r]
ttp024=Shows dB level margin (left/right or mono), push resets   [Back]
 Messageboxes, dialog titles
msg001=Open file
msg002=Create audio file
###msg003 (used earlier) Append
msg004=Save Project file or Cue sheet
msg005=Record base filename
msg006=Error
msg007=Warning
msg008=Not possible
msg009=Please note
msg010=File open failed
msg011=Audio file
msg012=Project file
msg013=Could not create/write to file
msg014=Could not replace source file. Saved as:
msg015=While saving %d file(s) %d re-sync(s) occured.
msg016=Selection range seems to be invalid
msg017=Please stop play/rec first
msg018=Unsupported file extension
msg019=Changes unsaved. Save modified Project?
msg020=No selection or selection too short
msg021=Really close and replace the source file?
msg022=Can't change the volume of Layer 2 files
###msg023 (used earlier)
msg024=No active edit range (cut/cue/gain)
msg025=No edit ranges present
msg026=Reload Cue sheet?
msg027=Restart program?
msg028=Don't show this message again
msg030=How to install/use the MPEG decoder "mpglib.dll":###  - Download it from mp3DirectCut's homepage##  - Put it into the program's folder##  - Go to Settings => "Configure..." => "Play"##  - Under "Decoder" select "mpglib.dll"
msg031=Could not open wave/audio device
msg032=How to install/activate the Lame MP3 encoder###  - Download the free "Lame_enc.dll" from the Internet##  - Extract the file into the program's folder##  - Press F12 (or "Settings" => "Configure..." => "Encoder")##  - Select "Lame_enc.dll" and adjust settings
msg033=This incredible breakthrough lets you grab your old 33 rpm longplay records with 45 rpm (1.35x) and saves 30% of your time! Even other grabbing speeds (0.5-2.0x) are possible. You can adjust original and recording speeds in the fields.##Encoding with at least 44.1 kHz is recommended. For best results this feature is not recommended at all, because of the resampling distortions.
msg034=Please note: Project and Cue sheet files do NOT contain audio data.##A Project file stores all edit informations (cuts etc.) while it only links to the corresponding audio files. It usually cannot be opened by other programs.##A Cue sheet contains track names and index times and can be read by some programs (e.g. players, CD burn programs, audio editors).
msg035=Important! Please note that mp3DirectCut does not show the real waveform audio data in the edit graph.##What you see is direct MPEG audio data which contains only higher frequencies in most cases. It can also be too high or too low and sometimes show nothing at all.##Use the edit graph for navigation and editing. The correct audio level is shown while play in the vu meter on the right.
msg036=To create a Cue sheet, the project must not contain cuts or insertions.
msg037=Audio parameters do not match.#Insertion and destination must have#the same samplerate and stereo mode.
 Configuration window
###cfg000 (used earlier)
###cfg001 (used earlier)
cfg002=Operation
cfg003=Misc
cfg004=Devices
cfg005=Encoder [F12]
cfg006=Paths
cfg010=MPEG Decoder
###cfg011 (used earlier)
cfg012=Wave out device
cfg013=Maximum wave buffer size
cfg014=Max MPEG frames/buffer (fast...reliable)
cfg016=[User presets]
cfg017=Add
cfg018=Delete
cfg019=High quality
cfg020=Wave in device
cfg021=Beep on reaching peak (Asterisk)
cfg022=Encoding path and base filename
cfg023=Add date+time
cfg024=Append audio
cfg025=Enable
cfg026=not found
cfg028=Navigation
cfg029=skips
cfg030=Mouse selection method
cfg031=Left = set begin / Right = set end
cfg032=Left = new + drag / Right = set nearest
cfg033=Language
cfg034=Language appears after program restart
cfg035=frame(s)
cfg037=Colors
cfg038=Background
cfg039=MPEG level graph
cfg040=Cursor, big timer
cfg041=Selection
cfg042=Part boundaries, volume ranges
cfg043=Active part, names
cfg044=VU meter
cfg047=Use higher priority
cfg048=Warn of unsaved changes
cfg049=Show tooltips (changes after restart)
cfg050=Show all warnings/messages (again)
cfg051=Alternative button layout (after restart)
cfg055=Standard working directory
cfg056=Use on save
 Function dialogs
dlg000=&OK
dlg001=&Cancel
dlg002=&Close
dlg003=Yes
dlg004=No
dlg006=Saving data...
dlg007=Never keep save window
dlg008=Configuration
dlg010=Split file
dlg011=%N = Track (cue/cut) number#%T = Track (cue/cut) title#%A = Track (cue/cut) artist#%C = Cue sheet (album) title#%D = Cue sheet (album) artist#%F = Name of (first) source file##Example: %D (%C %N) - %T
dlg012=IMPORTANT: Always use %N if no other information is available. Otherwise the program can't write different files.##%T, %A, %C and %D have only effect if names are present (loaded with a Cue sheet or entered).
dlg013=Split saves every region beginning with a cue (!) to a new file. So make sure that the cue flag at every split position is set (dotted line). NOTE: This function is designed for separating into different audio tracks. It's not recommended for split+join purposes.
dlg014=Destination folder
dlg015=Filename creation
dlg016=%N begins with
dlg017=Create ID3v1.1 tags (using %T, %A (or %D), %C, %N)
dlg020=File information
dlg021=Use ID3v&1 tag
dlg022=Get names from current cue
dlg023=Title
dlg024=Artist
dlg025=Album
dlg026=Year
dlg027=Comment
dlg028=Save options
###dlg029 (used earlier)
dlg030=Total audio size:#First audio frame at:#Current position:#Current bitrate:#Average bitrate:#Size of current frame:#Average frame size:#Xing VBR header:#Encoder ID:#ID3v2 header:
dlg031=Track No.
dlg032=Genre
dlg033=MPEG header bits
dlg034=Enable modifying
dlg035=Normalize selection
dlg036=Seeking maximum gain. This may take a while, because data must be internally decoded (Note: ACM is faster than mpglib.dll).
dlg037=Stop
dlg038=Peak found:
dlg039=Level change:
dlg040=Change gain of selection relatively...
dlg041=from
dlg042=to
dlg043=Fade &in
dlg044=Fade o&ut
dlg045=&Flat
dlg046=&Lock sliders
dlg047=&Silence
dlg048=Lowest Gain =  -
dlg049=Create/keep VBR/Info header (recommended on VBR)
dlg050=Pause detection
dlg051=This function seeks for pauses and sets cues at the pause ends. For good results adjust the level and duration thresholds carefully. Analyzing may take a while, because the data must be internally decoded.
dlg052=Thresholds
dlg053=Level
dlg054=Duration
dlg055=Found
dlg056=&Start
dlg057=St&op
dlg058=After a pause detection skip (sec)
dlg059=Offset
###dlg060 (used earlier)
dlg061=Cut whole pause
dlg062=Names and part properties
dlg063=Part
dlg064=Auto Cue
dlg065=Set a Cue every (min:sec)
dlg066=Keep ID3v2 tag on normal save (without duration info)
dlg067=Keep encoder data in VBR/Info header
