  mp3DirectCut
  VERSION HISTORY
  2.09 (2008-05-30)
  - Translations were not shown on the main buttons
  - Re-sync caused jump to track end in rare cases
  - Converting tab char on split filename creation
  - Record file handling improved
  - "Found" in pause detection dialog translateable
  2.08 (2008-04-30)
  - Message dialog system improved
  - Config dialog style improved
  - Optional standard working folder
  - Optional alternative button layout
  - Times shown in hour format
  - Mouse wheel moves small step back/fwd
  - Tracks with ID3v2 tags >2MB can be opened
  - Keeping more encoder data
  - Some more improvements and corrections
  2.07 (2007-11-06)
  - Fixed append paste bug that came with fix of endless resyncs
  - Menu item for new program window
  - Program didn't find languages and docs with ini in user profile
  - Paste to cursor position if no selection
  - Other corrections
  2.06 (2007-08-16)
  - Fixed endless Resyncs on files with non-ID3v1 tags
    after the audio data
  - Edit points can be moved or dragged (right mouse button)
  - Edit point Trim function
  - Crop function
  - Looped play for selection
  - Better ID3v2 size calculation on file opening
  - Deleting all wrong recent file items at once
  - Copy with no selection copies all
  - Point selection shown as dotted line
  - Some more changes
  2.05 (2007-03-28)
  - Undo function extended
  - ID3v1 genre list extended
  - Version info added to resources
  - Pause detection went to the Special menu
  - Ini file stored in user profile if necessary
  - Command line option /localini
  - Reading Project files with relative paths
    (e.g. if edited elsewhere)
  - Optionally keeping Lame header params
    (without Length and CRC)
  - Command line option /split for Cue sheets and Project files
  - Converting possible 8.3 filenames
  - Some other things
  2.04 (2006-10-24)
  - Possible crash on dragging a selection fixed
  - Fixed file open fail on some VBR headers
  - Split destination folder selection knows current path
  - Recording stops if the disk is full
  - Font smoothing support for dialog fonts
  - Minor corrections
  2.03 (2006-07-31)
  - Visible area shown in the map view
  - User presets for Lame settings
  - Frame header bits editable
  - Adapting CRC on volume or header bit changes
  - Added command line option /pausesplit
  - Keeping and showing Encoder ID of VBR headers
  - Not using TOC correction on Xing headers with no TOC
  - Less Fast Play levels, showing current level
  - High speed recording extended
  - Larger re-sync buffer for better handling corrupted files
  - Less false re-syncs
  - Possible re-sync hang fixed
  - Removing of ID3v2 length tag (TLEN) modified
  - No more skipping very low bitrate frames (8 and 16 kpbs)
  - Some more fixings and changes
  2.02 (2006-03-09)
  - More command line options:
    /save, /normalize, /autocue, /overwrite, /rec
    (details in the manual)
  - Split: source filename can be used in name template
  - Optional time and position correction by VBR-TOC
  - Audio file access modified
  - Option for keeping the original file time
  - ID3v1 genre bug fixed
  - ID3v2 can be kept without TLEN on "Save all..."
  - Auto cue only performed on/from selection (if present)
  - New part and selection visualization in the map view
  - Other things
  2.01 (2005-06-12)
  - Query for save modifications did not work
  - Reading old format project files (*.mpd),
    limited to cuts/cues, gain ignored
  - Function for creating a simple fade (depending
    on selection near beginning or end of file)
  - Function for loading a Cue sheet over current file
  - Setting Cue flag on creating 0-length cuts
    (easier split point creation)
  - Removing Cue flag on gain changes
    (assuming point should not be a Cue)
  - Menu option for setting Cue flags to multiple points
  - Smaller grips for gain faders
  - Show gain faders option removed (showing always)
  - Record view modified
  - More accurate one-frame-back-navigation
  - Option for always closing the save window
    (in save window and control settings)
  - Lowest gain for fade buttons can be set
  - Visualization of some joint stereo files failed
  - Some other corrections
  2.0 (2005-04-04)
  - Edit engine completely rewritten
  - Non-destructive Copy and Paste, even from different files
  - Graphical volume sliders
  - Cut areas are now hidden
  - Mouse events accurate even on VBR
  - Should handle files greater than 2 GB (not tested)
  - Genre Strings in ID3v1 dialog
  - Major bug on Split with ID3 tags fixed
  - Single frame selection shifting now accurate
  - Autoselect option removed
  - Append save removed (append works now via paste)
  - Gain button removed (in Edit menu, or use gain sliders)
  - Lots of adaptions and corrections
