<root>
<document schema='101' license='-1,88263627,K38DMR' title='' description='' target='PIC.12F.12F1840' >
	<config data='!0,f84!10,1aff%0,4%3,0%5,0%6,0%7,1%8,1%9,3%b,1%c,0%d,0%10,3%14,1%18,0%19,1%1a,0%1c,1%1d,0' clkspd='16000000' simspd='1' usewdt='0' constif='0' />
	<plugins >
		<dll_dbg_icd enabled='0' >
			<data name='debug' value='1' />
			<data name='userpins' value='0' />
			<data name='speed' value='0' />
			<data name='usev9' value='0' />
			<data name='breaks' value='8' />
			<data name='stacks' value='8' />
			<data name='clkport' value='1' />
			<data name='clkbit' value='6' />
			<data name='dataport' value='1' />
			<data name='databit' value='7' />
			<data name='ghostype' value='0' />
			<data name='monitor' value='1' />
			<data name='ictloop' value='0' />
			<data name='ictrate' value='20000' />
			<data name='ictmask' value='0' />
			<data name='anlpres' value='255' />
			<data name='digmask1' value='-1' />
			<data name='digmask2' value='-1' />
		</dll_dbg_icd>
		<dll_models enabled='1' />
		<dll_upgrader enabled='1' />
		<dll_webhelp enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug />
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='0' iconpath='' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='pwm_2' type='u8' description='' isconst='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
					<def class_type='variable' name='pwm_1' type='u8' description='' isconst='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
					<def class_type='variable' name='pwm_1_n' type='u8' description='' isconst='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
					<def class_type='variable' name='pwm_2_cs' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='pwm1_duty' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='pwm_2_n' type='u8' description='' isconst='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
					<def class_type='variable' name='pwm_2_enable' type='b1' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='pwm2_duty' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='pwm_1_cs' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='pwm_1_enable' type='b1' description='' isconst='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='pwm2' description='' >
						<return name='Return' type='v0' description='' isconst='0' isinit='0' usrinit='' setinit='' />
						<command class_type='decision' title='Feltételes elágazás' exp='pwm_2_n = 1' swap='0' >
							<flowline >
								<command class_type='calculation' title='Számítás' >
									<exp exp='pwm2_duty = pwm2_duty + 1' />
								</command>
								<command class_type='decision' title='Feltételes elágazás' exp='pwm2_duty &gt; 254' swap='0' >
									<flowline >
											<exp exp='pwm_2_n = 0' />
											<exp exp='pwm_2_cs = 1' />
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
							<flowline />
						</command>
						<command class_type='decision' title='Feltételes elágazás' exp='pwm_2_cs = 1' swap='0' >
							<flowline >
									<exp exp='pwm2_duty = pwm2_duty - 1' />
								</command>
								<command class_type='decision' title='Feltételes elágazás' exp='pwm2_duty &lt; 2' swap='0' >
									<flowline >
											<exp exp='pwm_2_n = 1' />
											<exp exp='pwm_2_cs = 0' />
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
							<flowline />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='pwm1' description='' >
						<command class_type='decision' title='Feltételes elágazás' exp='pwm_1_n = 1' swap='0' >
							<flowline >
									<exp exp='pwm1_duty = pwm1_duty + 1' />
								</command>
								<command class_type='decision' title='Feltételes elágazás' exp='pwm1_duty &gt; 254' swap='0' >
									<flowline >
											<exp exp='pwm_1_n = 0' />
											<exp exp='pwm_1_cs = 1' />
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
							<flowline />
						</command>
						<command class_type='decision' title='Feltételes elágazás' exp='pwm_1_cs = 1' swap='0' >
							<flowline >
									<exp exp='pwm1_duty = pwm1_duty - 1' />
								</command>
								<command class_type='decision' title='Feltételes elágazás' exp='pwm1_duty &lt; 2' swap='0' >
									<flowline >
											<exp exp='pwm_1_n = 1' />
											<exp exp='pwm_1_cs = 0' />
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
							<flowline />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='TMR0_Macro' description='' >
						<command class_type='decision' title='Feltételes elágazás' exp='pwm_1_enable = 1' swap='0' >
							<flowline >
								<command class_type='decision' title='Feltételes elágazás' exp='pwm_1 &lt; 254' swap='0' >
									<flowline >
											<exp exp='pwm_1 = pwm_1 + 1' />
											<exp exp='' />
										</command>
									</flowline>
									<flowline >
											<exp exp='pwm_1 = 1' />
										</command>
									</flowline>
								</command>
							</flowline>
							<flowline >
									<exp exp='pwm1_duty = 0' />
								</command>
							</flowline>
						</command>
						<command class_type='decision' title='Feltételes elágazás' exp='pwm_2_enable = 1' swap='0' >
							<flowline >
								<command class_type='decision' title='Feltételes elágazás' exp='pwm_2 &lt; 254' swap='0' >
									<flowline >
											<exp exp='pwm_2 = pwm_2 + 1' />
											<exp exp='' />
										</command>
									</flowline>
									<flowline >
											<exp exp='pwm_2 = 1' />
										</command>
									</flowline>
								</command>
							</flowline>
							<flowline >
									<exp exp='pwm2_duty = 0' />
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Main' description='' >
						<command class_type='interrupt' title='Megszakítás' enable='1' name='TMR0' call='TMR0_Macro' >
							<settings timer='1' prescale='1' postscale='-1' rollover='-1' bitcount='-1' trigger='3' maskhi='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' masklo='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' >
								<option value='0' />
								<option value='-1' />
							</settings>
						</command>
						<command class_type='interrupt' title='Megszakítás' enable='1' name='TMR1' call='pwm1' >
							</settings>
						</command>
						<command class_type='interrupt' title='Megszakítás' enable='1' name='TMR2' call='pwm2' >
							<settings timer='1' prescale='16' postscale='8' rollover='256' bitcount='-1' trigger='3' maskhi='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' masklo='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' >
								<option value='2' />
								<option value='7' />
								<option value='256' />
							</settings>
						</command>
						<command class_type='loop' title='Ciklus' type='0' exp='1' >
							<flowline >
								<command class_type='input' title='Bemenet' mode='1' port='1048576' mask='2' exp='pwm_1_enable' />
								<command class_type='input' title='Bemenet' mode='1' port='1048576' mask='4' exp='pwm_2_enable' />
									<flowline >
										<command class_type='decision' title='Feltételes elágazás' exp='pwm1_duty &gt; pwm_1' swap='0' >
											<flowline >
												<command class_type='output' title='Kimenet' mode='1' port='1048576' mask='1' exp='1' />
											</flowline>
											<flowline >
												<command class_type='output' title='Kimenet' mode='1' port='1048576' mask='1' exp='0' />
											</flowline>
										</command>
									</flowline>
									<flowline >
									</flowline>
								</command>
									<flowline >
										<command class_type='decision' title='Feltételes elágazás' exp='pwm2_duty &gt; pwm_2' swap='0' >
											<flowline >
												<command class_type='output' title='Kimenet' mode='1' port='1048576' mask='16' exp='1' />
											</flowline>
											<flowline >
												<command class_type='output' title='Kimenet' mode='1' port='1048576' mask='16' exp='0' />
											</flowline>
										</command>
									</flowline>
									<flowline >
									</flowline>
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='d92e8259-f3a8-4176-a8c4-fe7ca42b2c3f' vmin='1' vmaj='1' codename='led_5mm1' x='-8' y='-8' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.0' />
					<value target='polarity' data='001' />
					<value target='on_color' data='10551200' />
					<value target='length' data='4.000000' />
					<value target='show_label' data='002' />
					<value target='label_property' data='pin' />
					<value target='label_color' data='16777215' />
					<value target='label_scale' data='1.000000' />
					<value target='label_auto_scale' data='0' />
					<value target='label_position' data='003' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='7a287a58-cba5-42ad-b8a5-58694d7f678a' vmin='2' vmaj='1' codename='sw_slide_sub_pcb1' x='-8' y='8' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.1' />
					<value target='polarity' data='000' />
					<value target='debounce' data='10' />
					<value target='operation' data='001' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='7a287a58-cba5-42ad-b8a5-58694d7f678a' vmin='2' vmaj='1' codename='sw_slide_sub_pcb2' x='0' y='8' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.2' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='d92e8259-f3a8-4176-a8c4-fe7ca42b2c3f' vmin='1' vmaj='1' codename='led_5mm2' x='0' y='-8' z='3' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTA.4' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<keymap />
	<panel2d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='9737364' img='' style='0' />
		<camera xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='8409120' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='25' />
		<camera xe='0' ye='0' ze='63.2859' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
	</panel3d>
	<layout >
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wAAAAAUAAAARwUAAK0CAAA' zoom='75' scrollx='0' scrolly='34' flags='0' />
		<view type='0' name='TMR0_Macro' mode='0' placement='LAAAAAAAAAABAAAA---------------------wAAAAAUAAAARwUAAK0CAAA' zoom='75' scrollx='0' scrolly='0' flags='0' />
		<view type='0' name='pwm2' mode='0' placement='LAAAAAAAAAABAAAA---------------------wAAAAAUAAAARwUAAK0CAAA' zoom='75' scrollx='0' scrolly='302' flags='0' />
		<view type='0' name='pwm1' mode='0' placement='LAAAAAAAAAABAAAA---------------------wAAAAAUAAAARwUAAK0CAAA' zoom='75' scrollx='0' scrolly='32' flags='0' />
	</layout>
</document>
</root>
