<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting keepoldvectorfont="yes"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="mm" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
</layers>
<schematic>
<libraries>
<library name="atmel" urn="urn:adsk.eagle:library:105">
<packages>
<package name="DIL28-3" urn="urn:adsk.eagle:footprint:4162/1" library_version="1">
<description>&lt;B&gt;Dual In Line&lt;/B&gt; 0.3 inch</description>
<wire x1="-18.542" y1="-0.635" x2="-18.542" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="0.635" x2="-18.542" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="-18.542" y1="-2.794" x2="18.542" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="2.794" x2="-18.542" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="2.794" x2="18.542" y2="2.794" width="0.1524" layer="21"/>
<wire x1="18.542" y1="2.794" x2="18.542" y2="-2.794" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-19.2024" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-15.875" y="-0.635" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="DIL28-3" urn="urn:adsk.eagle:package:4320/1" type="box" library_version="1">
<description>Dual In Line 0.3 inch</description>
</package3d>
</packages3d>
<symbols>
<symbol name="23-I/O-2" urn="urn:adsk.eagle:symbol:4242/1" library_version="1">
<wire x1="-17.78" y1="30.48" x2="20.32" y2="30.48" width="0.254" layer="94"/>
<wire x1="20.32" y1="30.48" x2="20.32" y2="-33.02" width="0.254" layer="94"/>
<wire x1="20.32" y1="-33.02" x2="-17.78" y2="-33.02" width="0.254" layer="94"/>
<wire x1="-17.78" y1="-33.02" x2="-17.78" y2="30.48" width="0.254" layer="94"/>
<text x="-17.78" y="-35.56" size="1.778" layer="95">&gt;NAME</text>
<text x="-17.78" y="31.75" size="1.778" layer="96">&gt;VALUE</text>
<pin name="PB5(SCK)" x="25.4" y="-30.48" length="middle" rot="R180"/>
<pin name="PB7(XTAL2/TOSC2)" x="-22.86" y="5.08" length="middle"/>
<pin name="PB6(XTAL1/TOSC1)" x="-22.86" y="10.16" length="middle"/>
<pin name="GND@1" x="-22.86" y="-2.54" length="middle" direction="pwr"/>
<pin name="VCC@1" x="-22.86" y="-7.62" length="middle" direction="pwr"/>
<pin name="GND" x="-22.86" y="22.86" length="middle" direction="pwr"/>
<pin name="AREF" x="-22.86" y="20.32" length="middle" direction="pas"/>
<pin name="AVCC" x="-22.86" y="17.78" length="middle" direction="pwr"/>
<pin name="PB4(MISO)" x="25.4" y="-27.94" length="middle" rot="R180"/>
<pin name="PB3(MOSI/OC2)" x="25.4" y="-25.4" length="middle" rot="R180"/>
<pin name="PB2(SS/OC1B)" x="25.4" y="-22.86" length="middle" rot="R180"/>
<pin name="PB1(OC1A)" x="25.4" y="-20.32" length="middle" rot="R180"/>
<pin name="PB0(ICP)" x="25.4" y="-17.78" length="middle" rot="R180"/>
<pin name="PD7(AIN1)" x="25.4" y="-12.7" length="middle" rot="R180"/>
<pin name="PD6(AIN0)" x="25.4" y="-10.16" length="middle" rot="R180"/>
<pin name="PD5(T1)" x="25.4" y="-7.62" length="middle" rot="R180"/>
<pin name="PD4(XCK/T0)" x="25.4" y="-5.08" length="middle" rot="R180"/>
<pin name="PD3(INT1)" x="25.4" y="-2.54" length="middle" rot="R180"/>
<pin name="PD2(INT0)" x="25.4" y="0" length="middle" rot="R180"/>
<pin name="PD1(TXD)" x="25.4" y="2.54" length="middle" rot="R180"/>
<pin name="PD0(RXD)" x="25.4" y="5.08" length="middle" rot="R180"/>
<pin name="PC5(ADC5/SCL)" x="25.4" y="15.24" length="middle" rot="R180"/>
<pin name="PC4(ADC4/SDA)" x="25.4" y="17.78" length="middle" rot="R180"/>
<pin name="PC3(ADC3)" x="25.4" y="20.32" length="middle" rot="R180"/>
<pin name="PC2(ADC2)" x="25.4" y="22.86" length="middle" rot="R180"/>
<pin name="PC1(ADC1)" x="25.4" y="25.4" length="middle" rot="R180"/>
<pin name="PC0(ADC0)" x="25.4" y="27.94" length="middle" rot="R180"/>
<pin name="PC6(/RESET)" x="-22.86" y="27.94" length="middle" function="dot"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MEGA8-P" urn="urn:adsk.eagle:component:4382/1" prefix="IC" library_version="1">
<description>&lt;b&gt;MICROCONTROLLER&lt;/b&gt;&lt;p&gt;
8 Kbytes FLASH, 1 kbytes SRAM, 512 bytes EEPROM, USART, 4-channel 10 bit ADC, 2-channel 8 bit ADC&lt;br&gt;
Pin compatible with Atmega48, ATMega88, ATMega168&lt;br&gt;
Source: avr.lbr</description>
<gates>
<gate name="G$1" symbol="23-I/O-2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL28-3">
<connects>
<connect gate="G$1" pin="AREF" pad="21"/>
<connect gate="G$1" pin="AVCC" pad="20"/>
<connect gate="G$1" pin="GND" pad="22"/>
<connect gate="G$1" pin="GND@1" pad="8"/>
<connect gate="G$1" pin="PB0(ICP)" pad="14"/>
<connect gate="G$1" pin="PB1(OC1A)" pad="15"/>
<connect gate="G$1" pin="PB2(SS/OC1B)" pad="16"/>
<connect gate="G$1" pin="PB3(MOSI/OC2)" pad="17"/>
<connect gate="G$1" pin="PB4(MISO)" pad="18"/>
<connect gate="G$1" pin="PB5(SCK)" pad="19"/>
<connect gate="G$1" pin="PB6(XTAL1/TOSC1)" pad="9"/>
<connect gate="G$1" pin="PB7(XTAL2/TOSC2)" pad="10"/>
<connect gate="G$1" pin="PC0(ADC0)" pad="23"/>
<connect gate="G$1" pin="PC1(ADC1)" pad="24"/>
<connect gate="G$1" pin="PC2(ADC2)" pad="25"/>
<connect gate="G$1" pin="PC3(ADC3)" pad="26"/>
<connect gate="G$1" pin="PC4(ADC4/SDA)" pad="27"/>
<connect gate="G$1" pin="PC5(ADC5/SCL)" pad="28"/>
<connect gate="G$1" pin="PC6(/RESET)" pad="1"/>
<connect gate="G$1" pin="PD0(RXD)" pad="2"/>
<connect gate="G$1" pin="PD1(TXD)" pad="3"/>
<connect gate="G$1" pin="PD2(INT0)" pad="4"/>
<connect gate="G$1" pin="PD3(INT1)" pad="5"/>
<connect gate="G$1" pin="PD4(XCK/T0)" pad="6"/>
<connect gate="G$1" pin="PD5(T1)" pad="11"/>
<connect gate="G$1" pin="PD6(AIN0)" pad="12"/>
<connect gate="G$1" pin="PD7(AIN1)" pad="13"/>
<connect gate="G$1" pin="VCC@1" pad="7"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:4320/1"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="rcl">
<packages>
<package name="0204/5">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0207/15">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0204V">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="L2012C">
<description>&lt;b&gt;INDUCTOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.864" y1="0.54" x2="0.864" y2="0.54" width="0.1016" layer="51"/>
<wire x1="-0.864" y1="-0.553" x2="0.864" y2="-0.553" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-1" y="0" dx="1" dy="1" layer="1"/>
<smd name="2" x="1" y="0" dx="1" dy="1" layer="1"/>
<text x="-1.016" y="0.889" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.016" y="-2.159" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.6096" x2="-0.843" y2="0.5903" layer="51"/>
<rectangle x1="0.8382" y1="-0.6096" x2="1.1382" y2="0.5903" layer="51"/>
<rectangle x1="-0.3" y1="-0.4001" x2="0.3" y2="0.4001" layer="35"/>
</package>
<package name="L2825P">
precision wire wound</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.762" y1="1.2" x2="0.762" y2="1.2" width="0.1016" layer="51"/>
<wire x1="-0.762" y1="-1.213" x2="0.762" y2="-1.213" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.34" y1="-0.965" x2="1.34" y2="0.965" width="0.1016" layer="51"/>
<wire x1="-1.34" y1="0.965" x2="-1.34" y2="-0.965" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="0.6604" width="0.1524" layer="51"/>
<smd name="1" x="-1.2" y="0" dx="1.4" dy="2.4" layer="1"/>
<smd name="2" x="1.2" y="0" dx="1.4" dy="2.4" layer="1"/>
<text x="-1.27" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.7366" y1="-1.27" x2="1.3208" y2="1.27" layer="51"/>
<rectangle x1="-1.3208" y1="-1.27" x2="-0.7366" y2="1.27" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="L3216C">
chip</description>
<wire x1="-1.27" y1="0.896" x2="1.27" y2="0.896" width="0.1016" layer="51"/>
<wire x1="-1.27" y1="-0.883" x2="1.27" y2="-0.883" width="0.1016" layer="51"/>
<wire x1="-0.762" y1="0.896" x2="0.762" y2="0.896" width="0.1016" layer="21"/>
<wire x1="-0.762" y1="-0.883" x2="0.762" y2="-0.883" width="0.1016" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7526" y1="-0.9525" x2="-1.2525" y2="0.9474" layer="51"/>
<rectangle x1="1.2446" y1="-0.9525" x2="1.7447" y2="0.9474" layer="51"/>
<rectangle x1="-0.4001" y1="-0.5999" x2="0.4001" y2="0.5999" layer="35"/>
</package>
<package name="L3225M">
molded</description>
<wire x1="-1.575" y1="1.27" x2="1.575" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.575" y1="1.27" x2="1.575" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.575" y1="-1.27" x2="-1.575" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.575" y1="-1.27" x2="-1.575" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0.94" x2="-1.651" y2="-0.94" width="0.1524" layer="51"/>
<wire x1="1.651" y1="0.94" x2="1.651" y2="-0.94" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.2" layer="1"/>
<text x="-1.397" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="L3225P">
<wire x1="-1.676" y1="0.845" x2="1.676" y2="0.845" width="0.1524" layer="51"/>
<wire x1="-1.676" y1="0.838" x2="-1.676" y2="-0.838" width="0.1524" layer="51"/>
<wire x1="-1.168" y1="0.838" x2="-1.168" y2="-0.838" width="0.1524" layer="51"/>
<wire x1="1.168" y1="0.838" x2="1.168" y2="-0.838" width="0.1524" layer="51"/>
<wire x1="1.676" y1="0.838" x2="1.676" y2="-0.838" width="0.1524" layer="51"/>
<wire x1="1.676" y1="-0.845" x2="-1.676" y2="-0.845" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="0.7117" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.8" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.8" dy="2" layer="1"/>
<text x="-1.397" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="L3230M">
<text x="-1.397" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="L4035M">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.083" y1="0.686" x2="-2.083" y2="-0.686" width="0.1524" layer="51"/>
<wire x1="2.083" y1="0.686" x2="2.083" y2="-0.686" width="0.1524" layer="51"/>
<wire x1="-1.981" y1="1.524" x2="-1.981" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="-1.981" y1="-1.524" x2="1.981" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.981" y1="-1.524" x2="1.981" y2="1.524" width="0.1524" layer="51"/>
<wire x1="1.981" y1="1.524" x2="-1.981" y2="1.524" width="0.1524" layer="21"/>
<smd name="1" x="-1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<smd name="2" x="1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<text x="-1.651" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="L4516C">
chip</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-1.626" y1="0.54" x2="1.626" y2="0.54" width="0.1016" layer="51"/>
<wire x1="-1.626" y1="-0.527" x2="1.626" y2="-0.527" width="0.1016" layer="51"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.372" y1="0.54" x2="1.372" y2="0.54" width="0.1016" layer="21"/>
<wire x1="-1.372" y1="-0.527" x2="1.372" y2="-0.527" width="0.1016" layer="21"/>
<smd name="1" x="-2.1" y="0" dx="1" dy="1.6" layer="1"/>
<smd name="2" x="2.1" y="0" dx="1" dy="1.6" layer="1"/>
<text x="-2.032" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.032" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4003" y1="-0.5969" x2="-1.6002" y2="0.603" layer="51"/>
<rectangle x1="1.6002" y1="-0.603" x2="2.4003" y2="0.5969" layer="51"/>
<rectangle x1="-0.7" y1="-0.3" x2="0.7" y2="0.3" layer="35"/>
</package>
<package name="L4532M">
<wire x1="-3.473" y1="1.983" x2="3.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.983" x2="-3.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.983" x2="-3.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.983" x2="3.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.21" y1="-1.626" x2="2.21" y2="-1.626" width="0.1524" layer="21"/>
<wire x1="2.21" y1="1.626" x2="-2.21" y2="1.626" width="0.1524" layer="21"/>
<wire x1="-2.337" y1="1.041" x2="-2.337" y2="-1.041" width="0.1524" layer="51"/>
<wire x1="2.337" y1="1.041" x2="2.337" y2="-1.041" width="0.1524" layer="51"/>
<wire x1="-2.21" y1="1.626" x2="-2.21" y2="-1.626" width="0.1524" layer="51"/>
<wire x1="2.21" y1="1.626" x2="2.21" y2="-1.626" width="0.1524" layer="51"/>
<smd name="1" x="-1.9" y="0" dx="2" dy="2.4" layer="1"/>
<smd name="2" x="1.9" y="0" dx="2" dy="2.4" layer="1"/>
<text x="-1.905" y="2.032" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.302" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="L4532P">
<wire x1="-2.311" y1="1.675" x2="2.311" y2="1.675" width="0.1524" layer="51"/>
<wire x1="-2.311" y1="-1.653" x2="2.311" y2="-1.653" width="0.1524" layer="51"/>
<wire x1="-2.311" y1="1.626" x2="-2.311" y2="-1.626" width="0.1524" layer="51"/>
<wire x1="2.311" y1="1.675" x2="2.311" y2="-1.626" width="0.1524" layer="51"/>
<wire x1="-1.448" y1="1.651" x2="-1.448" y2="-1.626" width="0.1524" layer="51"/>
<wire x1="1.448" y1="1.626" x2="1.448" y2="-1.626" width="0.1524" layer="51"/>
<wire x1="-0.66" y1="1.675" x2="0.66" y2="1.675" width="0.1524" layer="21"/>
<wire x1="-0.66" y1="-1.653" x2="0.66" y2="-1.653" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.3211" width="0.1524" layer="51"/>
<smd name="1" x="-2" y="0" dx="1.8" dy="3.6" layer="1"/>
<smd name="2" x="2" y="0" dx="1.8" dy="3.6" layer="1"/>
</package>
<package name="L5038P">
<description>&lt;b&gt;INDUCTOR&lt;/b&gt; &lt;p&gt;
<wire x1="-2.286" y1="1.853" x2="2.311" y2="1.853" width="0.1016" layer="21"/>
<wire x1="-2.286" y1="-1.856" x2="2.311" y2="-1.856" width="0.1016" layer="21"/>
<wire x1="2.389" y1="-1.27" x2="2.389" y2="1.27" width="0.1016" layer="51"/>
<wire x1="-2.386" y1="-1.27" x2="-2.386" y2="1.27" width="0.1016" layer="51"/>
<wire x1="1.602" y1="-1.854" x2="1.602" y2="1.854" width="0.1016" layer="51"/>
<wire x1="-1.624" y1="-1.854" x2="-1.624" y2="1.854" width="0.1016" layer="51"/>
<wire x1="-2.31" y1="-1.854" x2="-2.31" y2="1.854" width="0.1016" layer="51"/>
<wire x1="2.313" y1="-1.854" x2="2.313" y2="1.854" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.4732" width="0.1524" layer="51"/>
<smd name="1" x="-2.2" y="0" dx="1.4" dy="2.8" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.4" dy="2.8" layer="1"/>
<text x="-2.159" y="2.159" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="L5650M">
<wire x1="-3.973" y1="2.983" x2="3.973" y2="2.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-2.983" x2="-3.973" y2="-2.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-2.983" x2="-3.973" y2="2.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="2.983" x2="3.973" y2="-2.983" width="0.0508" layer="39"/>
<wire x1="-2.108" y1="-2.591" x2="2.083" y2="-2.591" width="0.1524" layer="21"/>
<wire x1="2.083" y1="2.591" x2="-2.108" y2="2.591" width="0.1524" layer="21"/>
<wire x1="2.184" y1="2.032" x2="2.184" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-2.21" y1="2.032" x2="-2.21" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-2.108" y1="2.591" x2="-2.108" y2="-2.591" width="0.1524" layer="51"/>
<wire x1="2.083" y1="2.591" x2="2.083" y2="-2.591" width="0.1524" layer="51"/>
<smd name="1" x="-2.5" y="0" dx="1.8" dy="4" layer="1"/>
<smd name="2" x="2.5" y="0" dx="1.8" dy="4" layer="1"/>
<text x="-2.54" y="2.921" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-4.191" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="L8530M">
<wire x1="-5.473" y1="1.983" x2="5.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="5.473" y1="-1.983" x2="-5.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-5.473" y1="-1.983" x2="-5.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="5.473" y1="1.983" x2="5.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-4.191" y1="-1.524" x2="-4.191" y2="1.524" width="0.1524" layer="51"/>
<wire x1="4.191" y1="1.524" x2="-4.191" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.191" y1="-1.524" x2="-4.191" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.293" y1="-0.66" x2="-4.293" y2="0.66" width="0.1524" layer="51"/>
<wire x1="4.293" y1="-0.66" x2="4.293" y2="0.66" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-1.524" x2="4.191" y2="1.524" width="0.1524" layer="51"/>
<smd name="1" x="-3.7" y="0" dx="2.4" dy="1.4" layer="1"/>
<smd name="2" x="3.7" y="0" dx="2.4" dy="1.4" layer="1"/>
<text x="-3.683" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.683" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="L1812">
chip</description>
<wire x1="-1.4732" y1="1.6002" x2="1.4732" y2="1.6002" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-1.6002" x2="1.4732" y2="-1.6002" width="0.1016" layer="51"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3876" y1="-1.651" x2="-1.4376" y2="1.649" layer="51"/>
<rectangle x1="1.4478" y1="-1.651" x2="2.3978" y2="1.649" layer="51"/>
</package>
<package name="TJ3-U1">
<description>&lt;b&gt;Inductor&lt;/b&gt;&lt;p&gt;
Source: TJ-Serie Vishay.pdf</description>
<wire x1="-3.65" y1="8.15" x2="3.65" y2="8.15" width="0.2032" layer="21"/>
<wire x1="3.65" y1="-8.15" x2="-3.65" y2="-8.15" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="-8.15" x2="-3.65" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="-1.1" x2="-3.65" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-3.65" y1="1.1" x2="-3.65" y2="8.15" width="0.2032" layer="21"/>
<wire x1="3.65" y1="8.15" x2="3.65" y2="1.1" width="0.2032" layer="21"/>
<wire x1="3.65" y1="1.1" x2="3.65" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="3.65" y1="-1.1" x2="3.65" y2="-8.15" width="0.2032" layer="21"/>
<pad name="1" x="-3.3" y="0" drill="0.9"/>
<pad name="2" x="3.3" y="0" drill="0.9"/>
<text x="-0.635" y="-5.08" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-5.08" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="TJ3-U2">
<circle x="0" y="0" radius="8.3" width="0.2032" layer="27"/>
<pad name="1" x="-7.35" y="0" drill="0.9"/>
<pad name="2" x="7.35" y="0" drill="0.9"/>
<text x="-5.08" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="TJ4-U1">
<wire x1="-4.95" y1="11.05" x2="4.95" y2="11.05" width="0.2032" layer="21"/>
<wire x1="4.95" y1="11.05" x2="4.95" y2="-11.05" width="0.2032" layer="21"/>
<wire x1="4.95" y1="-11.05" x2="-4.95" y2="-11.05" width="0.2032" layer="21"/>
<wire x1="-4.95" y1="-11.05" x2="-4.95" y2="11.05" width="0.2032" layer="21"/>
<pad name="1" x="-3.935" y="0" drill="0.9"/>
<pad name="2" x="3.935" y="0" drill="0.9"/>
</package>
<package name="TJ4-U2">
<circle x="0" y="0" radius="11.1" width="0.2032" layer="27"/>
<pad name="1" x="-9.9" y="0" drill="0.9"/>
<pad name="2" x="9.9" y="0" drill="0.9"/>
</package>
<package name="TJ5-U1">
<wire x1="-5.55" y1="12.55" x2="5.55" y2="12.55" width="0.2032" layer="21"/>
<wire x1="5.55" y1="12.55" x2="5.55" y2="-12.55" width="0.2032" layer="21"/>
<wire x1="5.55" y1="-12.55" x2="-5.55" y2="-12.55" width="0.2032" layer="21"/>
<wire x1="-5.55" y1="-12.55" x2="-5.55" y2="12.55" width="0.2032" layer="21"/>
<pad name="1" x="-4.7" y="0" drill="0.9"/>
<pad name="2" x="4.7" y="0" drill="0.9"/>
</package>
<package name="TJ5-U2">
<circle x="0" y="0" radius="12.6" width="0.2032" layer="27"/>
<pad name="1" x="-11.45" y="0" drill="0.9"/>
<pad name="2" x="11.45" y="0" drill="0.9"/>
</package>
<package name="TJ6-U1">
<wire x1="-10.95" y1="17.45" x2="10.95" y2="17.45" width="0.2032" layer="21"/>
<wire x1="10.95" y1="17.45" x2="10.95" y2="-17.45" width="0.2032" layer="21"/>
<wire x1="10.95" y1="-17.45" x2="-10.95" y2="-17.45" width="0.2032" layer="21"/>
<wire x1="-10.95" y1="-17.45" x2="-10.95" y2="17.45" width="0.2032" layer="21"/>
<pad name="1" x="-9.25" y="0" drill="1.3"/>
<pad name="2" x="9.25" y="0" drill="1.3"/>
</package>
<package name="TJ6-U2">
<circle x="0" y="0" radius="17.5" width="0.2032" layer="27"/>
<pad name="1" x="-15.5" y="0" drill="1.3"/>
<pad name="2" x="15.5" y="0" drill="1.3"/>
</package>
<package name="TJ7-U1">
<wire x1="-9.45" y1="20.85" x2="9.43" y2="20.85" width="0.2032" layer="21"/>
<wire x1="9.43" y1="20.85" x2="9.45" y2="-20.85" width="0.2032" layer="21"/>
<wire x1="9.45" y1="-20.85" x2="-9.45" y2="-20.85" width="0.2032" layer="21"/>
<wire x1="-9.45" y1="-20.85" x2="-9.45" y2="20.85" width="0.2032" layer="21"/>
<pad name="1" x="-7.9" y="0" drill="1.3"/>
<pad name="2" x="7.9" y="0" drill="1.3"/>
</package>
<package name="TJ7-U2">
<circle x="0" y="0" radius="20.9" width="0.2032" layer="27"/>
<pad name="1" x="-18.8" y="0" drill="1.3"/>
<pad name="2" x="18.8" y="0" drill="1.3"/>
</package>
<package name="TJ8-U1">
<wire x1="-12.55" y1="24.25" x2="12.55" y2="24.25" width="0.2032" layer="21"/>
<wire x1="12.55" y1="24.25" x2="12.55" y2="-24.25" width="0.2032" layer="21"/>
<wire x1="12.55" y1="-24.25" x2="-12.55" y2="-24.25" width="0.2032" layer="21"/>
<wire x1="-12.55" y1="-24.25" x2="-12.55" y2="24.25" width="0.2032" layer="21"/>
<pad name="1" x="-10.4" y="0" drill="1.5"/>
<pad name="2" x="10.4" y="0" drill="1.5"/>
</package>
<package name="TJ8-U2">
<circle x="0" y="0" radius="24.6" width="0.2032" layer="27"/>
<pad name="1" x="-22.35" y="0" drill="1.5"/>
<pad name="2" x="22.35" y="0" drill="1.5"/>
</package>
<package name="TJ9-U1">
<wire x1="-17.95" y1="33.75" x2="17.95" y2="33.75" width="0.2032" layer="21"/>
<wire x1="17.95" y1="33.75" x2="17.95" y2="-33.75" width="0.2032" layer="21"/>
<wire x1="17.95" y1="-33.75" x2="-17.95" y2="-33.75" width="0.2032" layer="21"/>
<wire x1="-17.95" y1="-33.75" x2="-17.95" y2="33.75" width="0.2032" layer="21"/>
<pad name="1" x="-15.9" y="0" drill="1.8"/>
<pad name="2" x="15.9" y="0" drill="1.8"/>
</package>
<package name="TJ9-U2">
<circle x="0" y="0" radius="34.5" width="0.2032" layer="27"/>
<pad name="1" x="-31.6" y="0" drill="1.8"/>
<pad name="2" x="31.6" y="0" drill="1.8"/>
</package>
<package name="POWER-CHOKE_WE-TPC">
<description>&lt;b&gt;POWER-CHOKE WE-TPC&lt;/b&gt;&lt;p&gt;
Würth Elektronik, Partnumber: 744053220&lt;br&gt;
Source: WE-TPC 744053220.pdf</description>
<wire x1="-2.8" y1="2.3" x2="-2.3" y2="2.8" width="0.2" layer="51" curve="-90"/>
<wire x1="-2.3" y1="2.8" x2="2.3" y2="2.8" width="0.2" layer="51"/>
<wire x1="2.3" y1="2.8" x2="2.8" y2="2.3" width="0.2" layer="51" curve="-90"/>
<wire x1="2.8" y1="2.3" x2="2.8" y2="-2.3" width="0.2" layer="51"/>
<wire x1="2.8" y1="-2.3" x2="2.3" y2="-2.8" width="0.2" layer="51" curve="-90"/>
<wire x1="2.3" y1="-2.8" x2="-2.3" y2="-2.8" width="0.2" layer="51"/>
<wire x1="-2.3" y1="-2.8" x2="-2.8" y2="-2.3" width="0.2" layer="51" curve="-90"/>
<wire x1="-2.8" y1="-2.3" x2="-2.8" y2="2.3" width="0.2" layer="51"/>
<wire x1="-2.8" y1="0.65" x2="-2.8" y2="-0.65" width="0.2" layer="21"/>
<wire x1="-2" y1="0.65" x2="-2" y2="-0.65" width="0.2" layer="21" curve="36.008323"/>
<wire x1="2.8" y1="-0.65" x2="2.8" y2="0.65" width="0.2" layer="21"/>
<wire x1="2" y1="-0.65" x2="2" y2="0.65" width="0.2" layer="21" curve="36.008323"/>
<circle x="0" y="0" radius="2.1" width="0.2" layer="51"/>
<smd name="1" x="0" y="2.05" dx="6.3" dy="2.2" layer="1" roundness="25"/>
<smd name="2" x="0" y="-2.05" dx="6.3" dy="2.2" layer="1" roundness="25" rot="R180"/>
<text x="-3.5" y="3.5" size="1.778" layer="25">&gt;NAME</text>
<text x="-3.5" y="-5.3" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="2200-12.7">
<description>&lt;b&gt;newport components&lt;/b&gt; 2200 Serie RM 12.7 mm&lt;p&gt;
Miniatur Axial Lead Inductors&lt;br&gt;
Source: www.rsonline.de&lt;br&gt;
Order code 240-517</description>
<wire x1="-4.9" y1="1.9" x2="4.9" y2="1.9" width="0.2032" layer="51"/>
<wire x1="4.9" y1="1.9" x2="4.9" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="4.9" y1="-1.9" x2="-4.9" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-4.9" y1="-1.9" x2="-4.9" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.5" layer="51"/>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.5" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="0.8" diameter="1.27"/>
<pad name="2" x="6.35" y="0" drill="0.8" diameter="1.27"/>
<text x="-4.445" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2200-15.24">
<description>&lt;b&gt;newport components&lt;/b&gt; 2200 Serie RM 15.24 mm&lt;p&gt;
<wire x1="-7.62" y1="0" x2="-5.08" y2="0" width="0.5" layer="51"/>
<wire x1="7.62" y1="0" x2="5.08" y2="0" width="0.5" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.8" diameter="1.27"/>
<pad name="2" x="7.62" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="2200-11.43">
<description>&lt;b&gt;newport components&lt;/b&gt; 2200 Serie RM 11.43 mm&lt;p&gt;
<wire x1="-5.715" y1="0" x2="-5.08" y2="0" width="0.5" layer="51"/>
<wire x1="5.715" y1="0" x2="5.08" y2="0" width="0.5" layer="51"/>
<pad name="1" x="-5.715" y="0" drill="0.8" diameter="1.27"/>
<pad name="2" x="5.715" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="CEP125">
<description>&lt;b&gt;POWER INDUCTORS&lt;/b&gt; (SMT Type)&lt;p&gt;
Source: www.sumida.com/products/pdf/CEP125.pdf</description>
<wire x1="-1.5796" y1="6.3448" x2="-1.5533" y2="6.3448" width="0.2032" layer="21"/>
<wire x1="-1.5533" y1="6.3448" x2="-1.29" y2="6.0815" width="0.2032" layer="21"/>
<wire x1="-1.29" y1="6.0815" x2="-1.1584" y2="6.0816" width="0.2032" layer="21"/>
<wire x1="-1.1584" y1="6.0816" x2="-1.1584" y2="6.2922" width="0.2032" layer="21"/>
<wire x1="-1.1584" y1="6.2922" x2="-1.1583" y2="6.2922" width="0.2032" layer="21"/>
<wire x1="-1.1583" y1="6.2922" x2="-1.1057" y2="6.3448" width="0.2032" layer="21"/>
<wire x1="-1.1057" y1="6.3448" x2="1.1057" y2="6.3448" width="0.2032" layer="21"/>
<wire x1="1.1057" y1="6.3448" x2="1.1057" y2="6.0815" width="0.2032" layer="21"/>
<wire x1="1.1057" y1="6.0815" x2="1.211" y2="6.0815" width="0.2032" layer="21"/>
<wire x1="1.211" y1="6.0815" x2="1.4217" y2="6.3448" width="0.2032" layer="21"/>
<wire x1="1.4217" y1="6.3448" x2="6.1079" y2="6.3448" width="0.2032" layer="51"/>
<wire x1="6.1079" y1="6.3448" x2="6.3448" y2="6.1079" width="0.2032" layer="21" curve="-96.645912"/>
<wire x1="6.3448" y1="6.1079" x2="6.3448" y2="1.8166" width="0.2032" layer="21"/>
<wire x1="6.3448" y1="1.8166" x2="6.2658" y2="1.7376" width="0.2032" layer="21"/>
<wire x1="6.2658" y1="1.7376" x2="6.2658" y2="-1.7376" width="0.2032" layer="21"/>
<wire x1="6.2658" y1="-1.7376" x2="6.3448" y2="-1.8166" width="0.2032" layer="21"/>
<wire x1="6.3448" y1="-1.8166" x2="6.3448" y2="-6.0289" width="0.2032" layer="21"/>
<wire x1="6.3448" y1="-6.0289" x2="6.0289" y2="-6.3448" width="0.2032" layer="21" curve="-91.024745"/>
<wire x1="6.0289" y1="-6.3448" x2="-6.0289" y2="-6.3448" width="0.2032" layer="51"/>
<wire x1="-6.3448" y1="-6.0289" x2="-6.3448" y2="6.1342" width="0.2032" layer="21"/>
<wire x1="-6.3448" y1="6.1342" x2="-6.1342" y2="6.3448" width="0.2032" layer="21" curve="-83.297108"/>
<wire x1="-6.1342" y1="6.3448" x2="-1.5533" y2="6.3448" width="0.2032" layer="51"/>
<wire x1="-6.2395" y1="5.7393" x2="-2.0535" y2="5.7393" width="0.2032" layer="51"/>
<wire x1="-2.0535" y1="5.7393" x2="-1.5534" y2="3.9754" width="0.2032" layer="51"/>
<wire x1="-1.5534" y1="3.9754" x2="1.527" y2="3.9754" width="0.2032" layer="21"/>
<wire x1="1.527" y1="3.9754" x2="2.0535" y2="5.7393" width="0.2032" layer="51"/>
<wire x1="2.0535" y1="5.7393" x2="6.2395" y2="5.7393" width="0.2032" layer="51"/>
<wire x1="6.2395" y1="-3.4752" x2="-6.2658" y2="-3.4752" width="0.2032" layer="21"/>
<wire x1="-5.6077" y1="-3.5805" x2="-5.6077" y2="-6.2395" width="0.2032" layer="21"/>
<wire x1="-4.8968" y1="-6.2395" x2="-4.8968" y2="-3.5805" width="0.2032" layer="21"/>
<wire x1="-4.7915" y1="-6.0552" x2="-2.2115" y2="-6.0552" width="0.2032" layer="21"/>
<wire x1="-2.9486" y1="-5.9499" x2="-2.9223" y2="-5.9499" width="0.2032" layer="21"/>
<wire x1="-2.9223" y1="-5.9499" x2="-2.9223" y2="-3.5805" width="0.2032" layer="21"/>
<wire x1="-2.1588" y1="-6.2395" x2="-2.1588" y2="-3.8701" width="0.2032" layer="21"/>
<wire x1="2.1325" y1="-6.2395" x2="2.1325" y2="-3.8701" width="0.2032" layer="21"/>
<wire x1="2.2378" y1="-6.0289" x2="4.8968" y2="-6.0289" width="0.2032" layer="21"/>
<wire x1="4.8968" y1="-3.5805" x2="4.8968" y2="-6.2395" width="0.2032" layer="21"/>
<wire x1="2.9486" y1="-5.9236" x2="2.9486" y2="-3.5805" width="0.2032" layer="21"/>
<wire x1="5.5813" y1="-6.2395" x2="5.5813" y2="-3.5805" width="0.2032" layer="21"/>
<wire x1="2.5011" y1="-3.5805" x2="-2.4747" y2="-3.5805" width="0.2032" layer="51" curve="-63.906637"/>
<wire x1="1.1057" y1="6.0815" x2="-1.1584" y2="6.0815" width="0.2032" layer="21"/>
<wire x1="-1.7902" y1="5.1601" x2="1.7376" y2="5.1863" width="0.2032" layer="21" curve="-37.134171"/>
<wire x1="-6.0289" y1="-6.3448" x2="-6.3448" y2="-6.0289" width="0.2032" layer="21" curve="-90.91408"/>
<smd name="1" x="-3.5" y="5.375" dx="3" dy="2.75" layer="1"/>
<smd name="2" x="3.5" y="5.375" dx="3" dy="2.75" layer="1"/>
<smd name="3" x="0" y="-5.48" dx="3" dy="2.55" layer="1"/>
<text x="-5.08" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-1.27" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="L0201">
<description>&lt;b&gt;NIS02 Chip Inductor&lt;/b&gt;&lt;p&gt;
Source: http://www.niccomp.com/Catalog/nis.pdf</description>
<smd name="1" x="-0.275" y="0" dx="0.25" dy="0.35" layer="1"/>
<smd name="2" x="0.275" y="0" dx="0.25" dy="0.35" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="0.05" x2="0.15" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="-0.05" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="L-EU">
<text x="-1.4986" y="-3.81" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="3.302" y="-3.81" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.016" y1="-3.556" x2="1.016" y2="3.556" layer="94"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="1" x="0" y="5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="L-EU" prefix="L" uservalue="yes">
<description>&lt;B&gt;INDUCTOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="L-EU" x="0" y="0"/>
</gates>
<devices>
<device name="L2012C" package="L2012C">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="L2825P" package="L2825P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L3216C" package="L3216C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L3225M" package="L3225M">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L3225P" package="L3225P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L3230M" package="L3230M">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L4035M" package="L4035M">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L4516C" package="L4516C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L4532C" package="L4532M">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L4532P" package="L4532P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L5038P" package="L5038P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L5650M" package="L5650M">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L8530M" package="L8530M">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204V" package="0204V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L1812" package="L1812">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ3-U1" package="TJ3-U1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ3-U2" package="TJ3-U2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ4-U1" package="TJ4-U1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ4-U2" package="TJ4-U2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ5-U1" package="TJ5-U1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ5-U2" package="TJ5-U2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ6-U1" package="TJ6-U1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ6-U2" package="TJ6-U2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ7-U1" package="TJ7-U1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ7-U2" package="TJ7-U2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ8-U1" package="TJ8-U1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ8-U2" package="TJ8-U2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ9-U1" package="TJ9-U1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TJ9-U2" package="TJ9-U2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WE-TPC" package="POWER-CHOKE_WE-TPC">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2200-12.7" package="2200-12.7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2200-15.24" package="2200-15.24">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2200-11.43" package="2200-11.43">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CEP125" package="CEP125">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="L0201" package="L0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="crystal" urn="urn:adsk.eagle:library:204">
<packages>
<package name="HC49/S" urn="urn:adsk.eagle:footprint:11992/1" library_version="1">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-3.048" y1="-2.159" x2="3.048" y2="-2.159" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="2.159" x2="3.048" y2="2.159" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="-1.651" x2="3.048" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.048" y1="1.651" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="0.254" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.762" x2="0.254" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.762" x2="-0.254" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.762" x2="-0.254" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.762" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.762" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="2.159" x2="-3.048" y2="-2.159" width="0.4064" layer="21" curve="180"/>
<wire x1="3.048" y1="-2.159" x2="3.048" y2="2.159" width="0.4064" layer="21" curve="180"/>
<wire x1="-3.048" y1="1.651" x2="-3.048" y2="-1.651" width="0.1524" layer="21" curve="180"/>
<wire x1="3.048" y1="-1.651" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="180"/>
<pad name="1" x="-2.413" y="0" drill="0.8128"/>
<pad name="2" x="2.413" y="0" drill="0.8128"/>
<text x="-5.08" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.445" y1="-2.54" x2="4.445" y2="2.54" layer="43"/>
<rectangle x1="-5.08" y1="-1.905" x2="-4.445" y2="1.905" layer="43"/>
<rectangle x1="-5.715" y1="-1.27" x2="-5.08" y2="1.27" layer="43"/>
<rectangle x1="4.445" y1="-1.905" x2="5.08" y2="1.905" layer="43"/>
<rectangle x1="5.08" y1="-1.27" x2="5.715" y2="1.27" layer="43"/>
</package>
<package name="HC49GW" urn="urn:adsk.eagle:footprint:11993/1" library_version="1">
<wire x1="-5.08" y1="-6.35" x2="5.08" y2="-6.35" width="0.8128" layer="21"/>
<wire x1="4.445" y1="6.731" x2="1.016" y2="6.731" width="0.1524" layer="21"/>
<wire x1="1.016" y1="6.731" x2="-1.016" y2="6.731" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="6.731" x2="-4.445" y2="6.731" width="0.1524" layer="21"/>
<wire x1="4.445" y1="6.731" x2="5.08" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="6.096" x2="-4.445" y2="6.731" width="0.1524" layer="21" curve="-90"/>
<wire x1="-0.3302" y1="5.08" x2="-0.3302" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-0.3302" y1="2.54" x2="0.3048" y2="2.54" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="2.54" x2="0.3048" y2="5.08" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="5.08" x2="-0.3302" y2="5.08" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="5.08" x2="0.9398" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="5.08" x2="-0.9398" y2="3.81" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="3.81" x2="2.032" y2="3.81" width="0.1524" layer="21"/>
<wire x1="0.9398" y1="3.81" x2="0.9398" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="3.81" x2="-2.032" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="3.81" x2="-0.9398" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-2.413" y1="-6.604" x2="-2.413" y2="-8.255" width="0.6096" layer="51"/>
<wire x1="2.413" y1="-6.477" x2="2.413" y2="-8.382" width="0.6096" layer="51"/>
<wire x1="5.08" y1="-6.35" x2="5.08" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="6.096" x2="-5.08" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="0" y1="8.382" x2="0" y2="6.985" width="0.6096" layer="51"/>
<smd name="1" x="-2.413" y="-8.001" dx="1.27" dy="2.54" layer="1"/>
<smd name="2" x="2.413" y="-8.001" dx="1.27" dy="2.54" layer="1"/>
<smd name="3" x="0" y="8.001" dx="1.27" dy="2.794" layer="1"/>
<text x="-5.588" y="-5.08" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-2.54" y="-5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-5.715" y1="-8.255" x2="5.715" y2="8.255" layer="43"/>
</package>
<package name="HC49TL-H" urn="urn:adsk.eagle:footprint:11994/1" library_version="1">
<wire x1="5.334" y1="-5.715" x2="-5.461" y2="-5.715" width="0.8128" layer="21"/>
<wire x1="4.445" y1="7.366" x2="1.143" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="7.366" x2="-4.445" y2="7.366" width="0.1524" layer="21"/>
<wire x1="4.445" y1="7.366" x2="5.08" y2="6.731" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="6.731" x2="-4.445" y2="7.366" width="0.1524" layer="21" curve="-90"/>
<wire x1="-0.3302" y1="5.715" x2="-0.3302" y2="3.175" width="0.3048" layer="21"/>
<wire x1="-0.3302" y1="3.175" x2="0.3048" y2="3.175" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="3.175" x2="0.3048" y2="5.715" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="5.715" x2="-0.3302" y2="5.715" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="5.715" x2="0.9398" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="5.715" x2="-0.9398" y2="4.445" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="4.445" x2="2.032" y2="4.445" width="0.1524" layer="21"/>
<wire x1="0.9398" y1="4.445" x2="0.9398" y2="3.175" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="4.445" x2="-2.032" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="4.445" x2="-0.9398" y2="3.175" width="0.3048" layer="21"/>
<wire x1="-2.413" y1="-5.842" x2="-2.413" y2="-7.62" width="0.6096" layer="51"/>
<wire x1="2.413" y1="-5.842" x2="2.413" y2="-7.62" width="0.6096" layer="51"/>
<wire x1="5.08" y1="-5.715" x2="5.08" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="6.731" x2="-5.08" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="1.143" y1="7.366" x2="-1.143" y2="7.366" width="0.1524" layer="51"/>
<wire x1="0" y1="7.874" x2="0" y2="7.62" width="0.6096" layer="51"/>
<pad name="1" x="-2.413" y="-7.62" drill="0.8128"/>
<pad name="2" x="2.413" y="-7.62" drill="0.8128"/>
<pad name="3" x="0" y="7.874" drill="0.8128"/>
<text x="-5.461" y="-4.445" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-2.54" y="-4.699" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="7.366" x2="0.3048" y2="7.5692" layer="51"/>
<rectangle x1="-6.35" y1="-6.985" x2="6.35" y2="-4.445" layer="43"/>
<rectangle x1="-5.715" y1="-4.445" x2="5.715" y2="8.255" layer="43"/>
</package>
<package name="HC49U-H" urn="urn:adsk.eagle:footprint:11995/1" library_version="1">
<wire x1="-5.08" y1="-3.175" x2="5.08" y2="-3.175" width="0.8128" layer="21"/>
<wire x1="4.445" y1="9.906" x2="-4.445" y2="9.906" width="0.1524" layer="21"/>
<wire x1="4.445" y1="9.906" x2="5.08" y2="9.271" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="9.271" x2="-4.445" y2="9.906" width="0.1524" layer="21" curve="-90"/>
<wire x1="-0.3302" y1="8.255" x2="-0.3302" y2="5.715" width="0.3048" layer="21"/>
<wire x1="-0.3302" y1="5.715" x2="0.3048" y2="5.715" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="5.715" x2="0.3048" y2="8.255" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="8.255" x2="-0.3302" y2="8.255" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="8.255" x2="0.9398" y2="6.985" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="8.255" x2="-0.9398" y2="6.985" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="6.985" x2="1.905" y2="6.985" width="0.1524" layer="21"/>
<wire x1="0.9398" y1="6.985" x2="0.9398" y2="5.715" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="6.985" x2="-1.905" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="6.985" x2="-0.9398" y2="5.715" width="0.3048" layer="21"/>
<wire x1="-2.413" y1="-3.302" x2="-2.413" y2="-5.08" width="0.6096" layer="51"/>
<wire x1="2.413" y1="-3.302" x2="2.413" y2="-5.08" width="0.6096" layer="51"/>
<wire x1="5.08" y1="-3.175" x2="5.08" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="9.271" x2="-5.08" y2="-3.175" width="0.1524" layer="21"/>
<pad name="1" x="-2.413" y="-5.08" drill="0.8128"/>
<pad name="2" x="2.413" y="-5.08" drill="0.8128"/>
<text x="-5.461" y="-1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-2.54" y="-2.032" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-6.35" y1="-4.445" x2="6.35" y2="-1.905" layer="43"/>
<rectangle x1="-5.715" y1="-1.905" x2="5.715" y2="10.795" layer="43"/>
</package>
<package name="HC49U-LM" urn="urn:adsk.eagle:footprint:11996/1" library_version="1">
<wire x1="-4.572" y1="3.81" x2="4.572" y2="3.81" width="0.6096" layer="21"/>
<wire x1="0.9398" y1="6.985" x2="2.54" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="6.985" x2="-2.54" y2="6.985" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.048" x2="5.08" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.572" x2="5.08" y2="9.271" width="0.1524" layer="21"/>
<wire x1="4.572" y1="3.81" x2="5.08" y2="3.81" width="0.6096" layer="51"/>
<wire x1="5.08" y1="3.81" x2="5.715" y2="3.81" width="0.6096" layer="51"/>
<wire x1="5.08" y1="3.81" x2="5.08" y2="3.048" width="0.1524" layer="51"/>
<wire x1="5.08" y1="3.81" x2="5.08" y2="4.572" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="3.175" x2="-5.08" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.445" x2="-5.08" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="3.81" x2="-5.715" y2="3.81" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="4.445" x2="-5.08" y2="3.175" width="0.1524" layer="51"/>
<pad name="M" x="-5.715" y="3.81" drill="0.8128"/>
<pad name="M1" x="5.715" y="3.81" drill="0.8128"/>
<text x="-5.08" y="10.414" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="0" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.715" y1="-5.08" x2="5.715" y2="10.795" layer="43"/>
</package>
<package name="HC49U-V" urn="urn:adsk.eagle:footprint:11997/1" library_version="1">
<wire x1="-2.921" y1="-2.286" x2="2.921" y2="-2.286" width="0.4064" layer="21"/>
<wire x1="-2.921" y1="2.286" x2="2.921" y2="2.286" width="0.4064" layer="21"/>
<wire x1="-2.921" y1="-1.778" x2="2.921" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.778" x2="-2.921" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.778" x2="2.921" y2="-1.778" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.921" y1="2.286" x2="2.921" y2="-2.286" width="0.4064" layer="21" curve="-180"/>
<wire x1="-2.921" y1="2.286" x2="-2.921" y2="-2.286" width="0.4064" layer="21" curve="180"/>
<wire x1="-2.921" y1="1.778" x2="-2.921" y2="-1.778" width="0.1524" layer="21" curve="180"/>
<wire x1="-0.254" y1="0.889" x2="0.254" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.889" x2="0.254" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.889" x2="-0.254" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.889" x2="-0.254" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.889" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.889" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.889" width="0.1524" layer="21"/>
<text x="-5.08" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.191" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-2.794" x2="3.81" y2="2.794" layer="43"/>
<rectangle x1="-4.318" y1="-2.54" x2="-3.81" y2="2.54" layer="43"/>
<rectangle x1="-4.826" y1="-2.286" x2="-4.318" y2="2.286" layer="43"/>
<rectangle x1="-5.334" y1="-1.778" x2="-4.826" y2="1.778" layer="43"/>
<rectangle x1="-5.588" y1="-1.27" x2="-5.334" y2="1.016" layer="43"/>
<rectangle x1="3.81" y1="-2.54" x2="4.318" y2="2.54" layer="43"/>
<rectangle x1="4.318" y1="-2.286" x2="4.826" y2="2.286" layer="43"/>
<rectangle x1="4.826" y1="-1.778" x2="5.334" y2="1.778" layer="43"/>
<rectangle x1="5.334" y1="-1.016" x2="5.588" y2="1.016" layer="43"/>
</package>
<package name="HC49U70" urn="urn:adsk.eagle:footprint:11998/1" library_version="1">
<wire x1="-3.048" y1="-2.54" x2="3.048" y2="-2.54" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="2.54" x2="3.048" y2="2.54" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="-2.032" x2="3.048" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-0.3302" y1="1.016" x2="-0.3302" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.3302" y1="-1.016" x2="0.3048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="-1.016" x2="0.3048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="1.016" x2="-0.3302" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="1.016" x2="0.6858" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="1.016" x2="-0.6858" y2="0" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="0" x2="0.6858" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="0" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="0" x2="-0.6858" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="2.54" x2="-3.048" y2="-2.54" width="0.4064" layer="21" curve="180"/>
<wire x1="3.048" y1="2.54" x2="3.048" y2="-2.54" width="0.4064" layer="21" curve="-180"/>
<wire x1="-3.048" y1="-2.032" x2="-3.048" y2="2.032" width="0.1524" layer="21" curve="-180"/>
<wire x1="3.048" y1="2.032" x2="3.048" y2="-2.032" width="0.1524" layer="21" curve="-180"/>
<wire x1="3.048" y1="2.032" x2="-3.048" y2="2.032" width="0.1524" layer="21"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.445" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.572" y1="-2.794" x2="-4.064" y2="2.794" layer="43"/>
<rectangle x1="-5.08" y1="-2.54" x2="-4.572" y2="2.54" layer="43"/>
<rectangle x1="-5.588" y1="-2.032" x2="-5.08" y2="2.032" layer="43"/>
<rectangle x1="-5.842" y1="-1.27" x2="-5.588" y2="1.27" layer="43"/>
<rectangle x1="-4.064" y1="-3.048" x2="4.064" y2="3.048" layer="43"/>
<rectangle x1="4.064" y1="-2.794" x2="4.572" y2="2.794" layer="43"/>
<rectangle x1="4.572" y1="-2.54" x2="5.08" y2="2.54" layer="43"/>
<rectangle x1="5.08" y1="-2.032" x2="5.588" y2="2.032" layer="43"/>
<rectangle x1="5.588" y1="-1.27" x2="5.842" y2="1.27" layer="43"/>
</package>
<package name="HC49UP" urn="urn:adsk.eagle:footprint:11999/1" library_version="1">
<wire x1="-5.1091" y1="1.143" x2="-3.429" y2="2.0321" width="0.0508" layer="21" curve="-55.770993"/>
<wire x1="-5.715" y1="1.143" x2="-5.715" y2="2.159" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.032" x2="5.1091" y2="1.143" width="0.0508" layer="21" curve="-55.772485"/>
<wire x1="5.715" y1="1.143" x2="5.715" y2="2.159" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.27" x2="-3.429" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="3.429" y1="-2.032" x2="-3.429" y2="-2.032" width="0.0508" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="3.429" y2="1.27" width="0.0508" layer="21"/>
<wire x1="5.461" y1="-2.413" x2="-5.461" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-0.381" x2="6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="5.715" y1="0.381" x2="6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="6.477" y1="-0.381" x2="6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-2.413" x2="5.715" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.715" y1="-1.143" x2="5.715" y2="1.143" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-2.159" x2="5.715" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.27" x2="3.9826" y2="-1.143" width="0.0508" layer="21" curve="25.842828"/>
<wire x1="3.429" y1="1.27" x2="3.9826" y2="1.143" width="0.0508" layer="21" curve="-25.842828"/>
<wire x1="3.429" y1="-2.032" x2="5.109" y2="-1.1429" width="0.0508" layer="21" curve="55.771157"/>
<wire x1="3.9826" y1="-1.143" x2="3.9826" y2="1.143" width="0.0508" layer="51" curve="128.314524"/>
<wire x1="5.1091" y1="-1.143" x2="5.1091" y2="1.143" width="0.0508" layer="51" curve="68.456213"/>
<wire x1="-5.1091" y1="-1.143" x2="-3.429" y2="-2.032" width="0.0508" layer="21" curve="55.772485"/>
<wire x1="-3.9826" y1="-1.143" x2="-3.9826" y2="1.143" width="0.0508" layer="51" curve="-128.314524"/>
<wire x1="-3.9826" y1="-1.143" x2="-3.429" y2="-1.27" width="0.0508" layer="21" curve="25.842828"/>
<wire x1="-3.9826" y1="1.143" x2="-3.429" y2="1.27" width="0.0508" layer="21" curve="-25.842828"/>
<wire x1="-6.477" y1="-0.381" x2="-6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-5.1091" y1="-1.143" x2="-5.1091" y2="1.143" width="0.0508" layer="51" curve="-68.456213"/>
<wire x1="-5.715" y1="-1.143" x2="-5.715" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-0.381" x2="-5.715" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="0.381" x2="-5.715" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-2.159" x2="-5.715" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.159" x2="-5.461" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.715" y1="-0.381" x2="-6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="0.381" x2="-6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="2.032" x2="3.429" y2="2.032" width="0.0508" layer="21"/>
<wire x1="5.461" y1="2.413" x2="-5.461" y2="2.413" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.413" x2="5.715" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.715" y1="2.159" x2="-5.461" y2="2.413" width="0.1524" layer="21" curve="-90"/>
<wire x1="-0.254" y1="0.635" x2="-0.254" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.635" x2="0.254" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.635" x2="0.254" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="-0.254" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.635" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.016" y2="0" width="0.0508" layer="21"/>
<wire x1="0.635" y1="0.635" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.016" y2="0" width="0.0508" layer="21"/>
<smd name="1" x="-4.826" y="0" dx="5.334" dy="1.9304" layer="1"/>
<smd name="2" x="4.826" y="0" dx="5.334" dy="1.9304" layer="1"/>
<text x="-5.715" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.715" y="-4.191" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.604" y1="-3.048" x2="6.604" y2="3.048" layer="43"/>
</package>
<package name="HC13U-H" urn="urn:adsk.eagle:footprint:12000/1" library_version="1">
<wire x1="-9.906" y1="-3.048" x2="-9.271" y2="-3.048" width="1.27" layer="21"/>
<wire x1="-9.271" y1="-3.048" x2="9.271" y2="-3.048" width="1.27" layer="21"/>
<wire x1="9.271" y1="-3.048" x2="9.906" y2="-3.048" width="1.27" layer="21"/>
<wire x1="8.636" y1="33.401" x2="-8.636" y2="33.401" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="32.766" x2="-8.636" y2="33.401" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.636" y1="33.401" x2="9.271" y2="32.766" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.017" y1="15.24" x2="9.017" y2="15.24" width="0.6096" layer="21"/>
<wire x1="-0.3302" y1="21.59" x2="-0.3302" y2="19.05" width="0.3048" layer="21"/>
<wire x1="-0.3302" y1="19.05" x2="0.3048" y2="19.05" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="19.05" x2="0.3048" y2="21.59" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="21.59" x2="-0.3302" y2="21.59" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="21.59" x2="0.9398" y2="20.32" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="21.59" x2="-0.9398" y2="20.32" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="20.32" x2="1.905" y2="20.32" width="0.1524" layer="21"/>
<wire x1="0.9398" y1="20.32" x2="0.9398" y2="19.05" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="20.32" x2="-1.905" y2="20.32" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="20.32" x2="-0.9398" y2="19.05" width="0.3048" layer="21"/>
<wire x1="9.144" y1="15.24" x2="10.16" y2="15.24" width="0.6096" layer="51"/>
<wire x1="-10.16" y1="15.24" x2="-9.144" y2="15.24" width="0.6096" layer="51"/>
<wire x1="-6.223" y1="-3.175" x2="-6.223" y2="-5.08" width="0.8128" layer="51"/>
<wire x1="6.223" y1="-3.175" x2="6.223" y2="-5.08" width="0.8128" layer="51"/>
<wire x1="9.271" y1="15.748" x2="9.271" y2="32.766" width="0.1524" layer="21"/>
<wire x1="9.271" y1="14.732" x2="9.271" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="9.271" y1="15.748" x2="9.271" y2="14.732" width="0.1524" layer="51"/>
<wire x1="-9.271" y1="14.732" x2="-9.271" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="15.748" x2="-9.271" y2="32.766" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="15.748" x2="-9.271" y2="14.732" width="0.1524" layer="51"/>
<pad name="1" x="-6.223" y="-5.08" drill="1.016"/>
<pad name="2" x="6.223" y="-5.08" drill="1.016"/>
<pad name="M" x="-10.16" y="15.24" drill="0.8128"/>
<pad name="M1" x="10.16" y="15.24" drill="0.8128"/>
<text x="-10.16" y="0" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-5.08" y="-1.27" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-10.795" y1="-5.08" x2="10.795" y2="34.925" layer="43"/>
</package>
<package name="HC18U-H" urn="urn:adsk.eagle:footprint:12001/1" library_version="1">
<wire x1="5.461" y1="-3.175" x2="5.08" y2="-3.175" width="0.8128" layer="21"/>
<wire x1="5.08" y1="-3.175" x2="-5.08" y2="-3.175" width="0.8128" layer="21"/>
<wire x1="-5.08" y1="-3.175" x2="-5.461" y2="-3.175" width="0.8128" layer="21"/>
<wire x1="4.445" y1="10.16" x2="-4.445" y2="10.16" width="0.1524" layer="21"/>
<wire x1="4.445" y1="10.16" x2="5.08" y2="9.525" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="9.525" x2="-4.445" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-3.302" x2="-2.54" y2="-5.08" width="0.6096" layer="51"/>
<wire x1="2.54" y1="-3.302" x2="2.54" y2="-5.08" width="0.6096" layer="51"/>
<wire x1="5.08" y1="4.572" x2="5.08" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.445" x2="-5.08" y2="9.525" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-5.08" drill="0.8128"/>
<pad name="2" x="2.54" y="-5.08" drill="0.8128"/>
<text x="-5.08" y="10.668" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-0.889" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.35" y1="-5.08" x2="6.35" y2="10.795" layer="43"/>
</package>
<package name="HC18U-V" urn="urn:adsk.eagle:footprint:12002/1" library_version="1">
<wire x1="5.08" y1="-1.905" x2="5.08" y2="1.905" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="4.445" y2="2.54" width="0.4064" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="4.445" y2="-2.54" width="0.4064" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="5.08" y2="-1.905" width="0.4064" layer="21" curve="90"/>
<wire x1="4.445" y1="2.54" x2="5.08" y2="1.905" width="0.4064" layer="21" curve="-90"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.4064" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.905" x2="-4.445" y2="-2.54" width="0.4064" layer="21" curve="90"/>
<wire x1="-4.318" y1="-1.905" x2="4.318" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.905" x2="4.445" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.778" x2="4.445" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.318" y1="1.905" x2="4.445" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.318" y1="1.905" x2="-4.318" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.778" x2="-4.318" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.778" x2="-4.445" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-1.905" x2="-4.445" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-0.3302" y1="1.27" x2="-0.3302" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="-0.3302" y1="-1.27" x2="0.3048" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="-1.27" x2="0.3048" y2="1.27" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="1.27" x2="-0.3302" y2="1.27" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="1.27" x2="0.9398" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="1.27" x2="-0.9398" y2="0" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.9398" y1="0" x2="0.9398" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="0" x2="-0.9398" y2="-1.27" width="0.3048" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128"/>
<pad name="2" x="2.54" y="0" drill="0.8128"/>
<text x="-5.0546" y="3.2766" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.6228" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.715" y1="-3.175" x2="5.715" y2="3.175" layer="43"/>
</package>
<package name="HC33U-H" urn="urn:adsk.eagle:footprint:12003/1" library_version="1">
<wire x1="8.636" y1="16.51" x2="-8.636" y2="16.51" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="15.875" x2="-8.636" y2="16.51" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.636" y1="16.51" x2="9.271" y2="15.875" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.017" y1="7.62" x2="9.017" y2="7.62" width="0.6096" layer="21"/>
<wire x1="-0.3302" y1="13.97" x2="-0.3302" y2="11.43" width="0.3048" layer="21"/>
<wire x1="-0.3302" y1="11.43" x2="0.3048" y2="11.43" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="11.43" x2="0.3048" y2="13.97" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="13.97" x2="-0.3302" y2="13.97" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="13.97" x2="0.9398" y2="12.7" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="13.97" x2="-0.9398" y2="12.7" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="12.7" x2="1.905" y2="12.7" width="0.1524" layer="21"/>
<wire x1="0.9398" y1="12.7" x2="0.9398" y2="11.43" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="12.7" x2="-1.905" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="12.7" x2="-0.9398" y2="11.43" width="0.3048" layer="21"/>
<wire x1="9.144" y1="7.62" x2="10.16" y2="7.62" width="0.6096" layer="51"/>
<wire x1="-10.16" y1="7.62" x2="-9.144" y2="7.62" width="0.6096" layer="51"/>
<wire x1="9.271" y1="8.128" x2="9.271" y2="15.875" width="0.1524" layer="21"/>
<wire x1="9.271" y1="7.112" x2="9.271" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="9.271" y1="8.128" x2="9.271" y2="7.112" width="0.1524" layer="51"/>
<wire x1="-9.271" y1="7.112" x2="-9.271" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="8.128" x2="-9.271" y2="15.875" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="8.128" x2="-9.271" y2="7.112" width="0.1524" layer="51"/>
<pad name="M" x="-10.16" y="7.62" drill="0.8128"/>
<pad name="M1" x="10.16" y="7.62" drill="0.8128"/>
<text x="-7.62" y="17.272" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.62" y1="-3.175" x2="-6.985" y2="16.51" layer="21"/>
<rectangle x1="6.985" y1="-3.175" x2="7.62" y2="16.51" layer="21"/>
<rectangle x1="-10.795" y1="-5.715" x2="10.795" y2="17.145" layer="43"/>
</package>
<package name="HC33U-V" urn="urn:adsk.eagle:footprint:12004/1" library_version="1">
<wire x1="-0.3302" y1="2.54" x2="-0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3302" y1="0" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="2.54" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="2.54" x2="-0.3302" y2="2.54" width="0.3048" layer="21"/>
<wire x1="0.9652" y1="2.54" x2="0.9652" y2="1.27" width="0.3048" layer="21"/>
<wire x1="-0.9652" y1="2.54" x2="-0.9652" y2="1.27" width="0.3048" layer="21"/>
<wire x1="0.9652" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.9652" y1="1.27" x2="0.9652" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.9652" y1="1.27" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.9652" y1="1.27" x2="-0.9652" y2="0" width="0.3048" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="5.207" y2="4.064" width="0.254" layer="21"/>
<wire x1="-5.207" y1="-4.064" x2="5.207" y2="-4.064" width="0.254" layer="21"/>
<wire x1="-5.207" y1="-3.683" x2="5.207" y2="-3.683" width="0.0508" layer="21"/>
<wire x1="-5.207" y1="3.683" x2="5.207" y2="3.683" width="0.0508" layer="21"/>
<wire x1="-5.207" y1="-3.683" x2="-5.207" y2="3.683" width="0.0508" layer="21" curve="-180"/>
<wire x1="5.207" y1="3.683" x2="5.207" y2="-3.683" width="0.0508" layer="21" curve="-180"/>
<wire x1="5.207" y1="4.064" x2="5.207" y2="-4.064" width="0.254" layer="21" curve="-180"/>
<wire x1="-5.207" y1="4.064" x2="-5.207" y2="-4.064" width="0.254" layer="21" curve="180"/>
<pad name="1" x="-6.223" y="0" drill="1.016"/>
<pad name="2" x="6.223" y="0" drill="1.016"/>
<text x="-5.08" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.255" y1="-3.81" x2="-6.985" y2="3.81" layer="43"/>
<rectangle x1="-8.89" y1="-3.175" x2="-8.255" y2="3.175" layer="43"/>
<rectangle x1="-9.525" y1="-2.54" x2="-8.89" y2="2.54" layer="43"/>
<rectangle x1="-6.985" y1="-4.445" x2="6.985" y2="4.445" layer="43"/>
<rectangle x1="6.985" y1="-3.81" x2="8.255" y2="3.81" layer="43"/>
<rectangle x1="8.255" y1="-3.175" x2="8.89" y2="3.175" layer="43"/>
<rectangle x1="8.89" y1="-2.54" x2="9.525" y2="2.54" layer="43"/>
</package>
<package name="SM49" urn="urn:adsk.eagle:footprint:12005/1" library_version="1">
<wire x1="5.715" y1="-1.143" x2="5.715" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.143" x2="-5.715" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.413" x2="5.461" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.381" x2="-6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="1.143" x2="-5.715" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="2.159" x2="-5.715" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.9826" y1="1.143" x2="-3.9826" y2="-1.143" width="0.0508" layer="51" curve="128.314524"/>
<wire x1="-5.1091" y1="1.143" x2="-5.1091" y2="-1.143" width="0.0508" layer="51" curve="68.456213"/>
<wire x1="3.9826" y1="1.143" x2="3.9826" y2="-1.143" width="0.0508" layer="51" curve="-128.314524"/>
<wire x1="6.477" y1="0.381" x2="6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="5.1091" y1="1.143" x2="5.1091" y2="-1.143" width="0.0508" layer="51" curve="-68.456213"/>
<wire x1="5.715" y1="1.143" x2="5.715" y2="0.381" width="0.1524" layer="51"/>
<wire x1="5.715" y1="0.381" x2="5.715" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-0.381" x2="5.715" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="5.715" y1="2.159" x2="5.715" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.413" x2="5.461" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.143" y2="0" width="0.0508" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.0508" layer="21"/>
<smd name="1" x="-4.826" y="0" dx="5.08" dy="1.778" layer="1"/>
<smd name="2" x="4.826" y="0" dx="5.08" dy="1.778" layer="1"/>
<text x="-5.715" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.715" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.604" y1="-2.54" x2="6.604" y2="2.794" layer="43"/>
</package>
<package name="TC26H" urn="urn:adsk.eagle:footprint:12006/1" library_version="1">
<wire x1="-0.889" y1="1.651" x2="0.889" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.762" y1="7.747" x2="1.016" y2="7.493" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.016" y1="7.493" x2="-0.762" y2="7.747" width="0.1524" layer="21" curve="-90"/>
<wire x1="-0.762" y1="7.747" x2="0.762" y2="7.747" width="0.1524" layer="21"/>
<wire x1="0.889" y1="1.651" x2="0.889" y2="2.032" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.032" x2="1.016" y2="7.493" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.651" x2="-0.889" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.032" x2="-0.889" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.032" x2="-1.016" y2="7.493" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.762" x2="0.508" y2="1.143" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="1.27" width="0.4064" layer="21"/>
<wire x1="0.635" y1="0.635" x2="1.27" y2="0" width="0.4064" layer="51"/>
<wire x1="-0.635" y1="0.635" x2="-1.27" y2="0" width="0.4064" layer="51"/>
<wire x1="-0.508" y1="4.953" x2="-0.508" y2="4.572" width="0.1524" layer="21"/>
<wire x1="0.508" y1="4.572" x2="-0.508" y2="4.572" width="0.1524" layer="21"/>
<wire x1="0.508" y1="4.572" x2="0.508" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="4.953" x2="0.508" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="5.334" x2="0" y2="5.334" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="4.191" x2="0" y2="4.191" width="0.1524" layer="21"/>
<wire x1="0" y1="4.191" x2="0" y2="3.683" width="0.1524" layer="21"/>
<wire x1="0" y1="4.191" x2="0.508" y2="4.191" width="0.1524" layer="21"/>
<wire x1="0" y1="5.334" x2="0" y2="5.842" width="0.1524" layer="21"/>
<wire x1="0" y1="5.334" x2="0.508" y2="5.334" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.032" x2="0.889" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0.889" y1="2.032" x2="-0.889" y2="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="0.8128"/>
<pad name="2" x="1.27" y="0" drill="0.8128"/>
<text x="-1.397" y="2.032" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="2.032" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="0.3048" y1="1.016" x2="0.7112" y2="1.6002" layer="21"/>
<rectangle x1="-0.7112" y1="1.016" x2="-0.3048" y2="1.6002" layer="21"/>
<rectangle x1="-1.778" y1="0.762" x2="1.778" y2="8.382" layer="43"/>
</package>
<package name="TC26V" urn="urn:adsk.eagle:footprint:12007/1" library_version="1">
<wire x1="-0.127" y1="-0.508" x2="0.127" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0.127" y1="0.508" x2="0.127" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0.127" y1="0.508" x2="-0.127" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="-0.508" x2="-0.127" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-0.508" x2="-0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-0.508" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.381" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="0" x2="-0.381" y2="0.508" width="0.1524" layer="51"/>
<wire x1="0" y1="1.016" x2="0.7184" y2="0.7184" width="0.1524" layer="21" curve="-44.999323"/>
<wire x1="-0.7184" y1="0.7184" x2="0" y2="1.016" width="0.1524" layer="21" curve="-44.999323"/>
<wire x1="-0.7184" y1="-0.7184" x2="0" y2="-1.016" width="0.1524" layer="21" curve="44.999323"/>
<wire x1="0" y1="-1.016" x2="0.7184" y2="-0.7184" width="0.1524" layer="21" curve="44.999323"/>
<circle x="0" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-2.032" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TC38H" urn="urn:adsk.eagle:footprint:12008/1" library_version="1">
<wire x1="-1.397" y1="1.651" x2="1.397" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.27" y1="9.906" x2="1.524" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.524" y1="9.652" x2="-1.27" y2="9.906" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="9.906" x2="1.27" y2="9.906" width="0.1524" layer="21"/>
<wire x1="1.397" y1="1.651" x2="1.397" y2="2.032" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.032" x2="1.397" y2="2.032" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.032" x2="1.524" y2="9.652" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.651" x2="-1.397" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.032" x2="-1.397" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.032" x2="-1.524" y2="9.652" width="0.1524" layer="21"/>
<wire x1="1.397" y1="2.032" x2="-1.397" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0.5588" y1="0.7112" x2="0.508" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="1.016" width="0.4064" layer="21"/>
<wire x1="-0.5588" y1="0.7112" x2="-0.508" y2="0.762" width="0.4064" layer="21"/>
<wire x1="0.635" y1="0.635" x2="1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.635" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="5.588" x2="-0.762" y2="5.207" width="0.1524" layer="21"/>
<wire x1="0.762" y1="5.207" x2="-0.762" y2="5.207" width="0.1524" layer="21"/>
<wire x1="0.762" y1="5.207" x2="0.762" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="5.588" x2="0.762" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="5.969" x2="0" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="4.826" x2="0" y2="4.826" width="0.1524" layer="21"/>
<wire x1="0" y1="4.826" x2="0" y2="4.318" width="0.1524" layer="21"/>
<wire x1="0" y1="4.826" x2="0.762" y2="4.826" width="0.1524" layer="21"/>
<wire x1="0" y1="5.969" x2="0" y2="6.477" width="0.1524" layer="21"/>
<wire x1="0" y1="5.969" x2="0.762" y2="5.969" width="0.1524" layer="21"/>
<text x="-1.905" y="2.032" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.175" y="2.032" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.778" y1="1.016" x2="1.778" y2="10.414" layer="43"/>
</package>
<package name="86SMX" urn="urn:adsk.eagle:footprint:12009/1" library_version="1">
<description>&lt;b&gt;CRYSTAL RESONATOR&lt;/b&gt;</description>
<wire x1="-3.81" y1="1.905" x2="2.413" y2="1.905" width="0.0508" layer="21"/>
<wire x1="-3.81" y1="2.286" x2="2.413" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="2.413" y2="-1.905" width="0.0508" layer="21"/>
<wire x1="-3.81" y1="-2.286" x2="2.413" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.286" x2="-6.604" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="1.905" x2="-5.334" y2="1.016" width="0.0508" layer="51"/>
<wire x1="-5.334" y1="-1.905" x2="-3.81" y2="-1.905" width="0.0508" layer="51"/>
<wire x1="-6.35" y1="-2.286" x2="-5.969" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="-2.286" x2="-4.191" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-2.286" x2="-3.81" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="-2.54" x2="-4.191" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-2.2098" x2="-6.604" y2="-2.286" width="0.0508" layer="21"/>
<wire x1="-6.604" y1="-2.286" x2="-6.35" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-2.54" x2="-5.969" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-5.334" y1="1.016" x2="-5.334" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="-5.334" y1="-1.016" x2="-5.334" y2="-1.905" width="0.0508" layer="51"/>
<wire x1="-5.334" y1="-1.905" x2="-6.35" y2="-2.2098" width="0.0508" layer="51"/>
<wire x1="-4.191" y1="-2.54" x2="-4.191" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="2.54" x2="-4.191" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-5.334" y1="1.905" x2="-3.81" y2="1.905" width="0.0508" layer="51"/>
<wire x1="-6.35" y1="2.286" x2="-5.969" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="2.286" x2="-4.191" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="2.286" x2="-3.81" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="2.286" x2="-6.35" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="2.2098" x2="-6.604" y2="2.286" width="0.0508" layer="21"/>
<wire x1="-5.969" y1="2.54" x2="-5.969" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-5.334" y1="1.905" x2="-6.35" y2="2.2098" width="0.0508" layer="51"/>
<wire x1="-4.191" y1="2.54" x2="-4.191" y2="2.286" width="0.1524" layer="51"/>
<wire x1="6.604" y1="2.286" x2="6.604" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-1.905" x2="6.223" y2="1.905" width="0.0508" layer="21"/>
<wire x1="6.223" y1="-1.905" x2="6.604" y2="-2.286" width="0.0508" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="6.604" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-2.54" x2="5.842" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="2.794" y1="-2.286" x2="2.794" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="5.842" y1="-2.54" x2="5.842" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-2.286" x2="6.223" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.905" x2="6.223" y2="-1.905" width="0.0508" layer="51"/>
<wire x1="6.223" y1="1.905" x2="6.604" y2="2.286" width="0.0508" layer="21"/>
<wire x1="6.223" y1="2.286" x2="6.604" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="5.842" y2="2.54" width="0.1524" layer="51"/>
<wire x1="2.794" y1="2.286" x2="2.794" y2="2.54" width="0.1524" layer="51"/>
<wire x1="5.842" y1="2.54" x2="5.842" y2="2.286" width="0.1524" layer="51"/>
<wire x1="2.413" y1="1.905" x2="6.223" y2="1.905" width="0.0508" layer="51"/>
<wire x1="2.413" y1="2.286" x2="6.223" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.651" x2="-0.254" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="0.381" x2="0.254" y2="0.381" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.381" x2="0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.651" x2="-0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.651" x2="0.635" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.016" x2="0.635" y2="0.381" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.016" x2="1.016" y2="1.016" width="0.0508" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.635" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.016" x2="-0.635" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.016" x2="-1.016" y2="1.016" width="0.0508" layer="21"/>
<smd name="2" x="4.318" y="-2.286" dx="3.556" dy="2.1844" layer="1"/>
<smd name="3" x="4.318" y="2.286" dx="3.556" dy="2.1844" layer="1"/>
<smd name="1" x="-5.08" y="-2.286" dx="2.286" dy="2.1844" layer="1"/>
<smd name="4" x="-5.08" y="2.286" dx="2.286" dy="2.1844" layer="1"/>
<text x="-3.683" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MM20SS" urn="urn:adsk.eagle:footprint:12010/1" library_version="1">
<wire x1="-2.032" y1="-1.27" x2="2.032" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="-2.032" y1="-1.778" x2="2.032" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.27" x2="-2.032" y2="1.27" width="0.0508" layer="21"/>
<wire x1="-2.032" y1="1.778" x2="2.032" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.778" x2="-4.064" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.381" x2="-2.921" y2="-0.381" width="0.0508" layer="21"/>
<wire x1="-4.064" y1="-1.778" x2="-3.556" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.552" x2="-4.064" y2="-1.778" width="0.0508" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.921" y2="1.27" width="0.0508" layer="51"/>
<wire x1="-2.921" y1="1.27" x2="-2.921" y2="0.381" width="0.0508" layer="51"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-1.905" x2="-3.048" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-0.381" x2="-2.921" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="-2.921" y1="-1.27" x2="-2.032" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="-3.556" y1="-1.778" x2="-2.032" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-1.27" x2="-3.556" y2="-1.552" width="0.0508" layer="51"/>
<wire x1="-4.064" y1="1.778" x2="-3.556" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.552" x2="-4.064" y2="1.778" width="0.0508" layer="21"/>
<wire x1="-2.921" y1="1.27" x2="-3.556" y2="1.552" width="0.0508" layer="51"/>
<wire x1="-3.048" y1="1.778" x2="-3.048" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="1.778" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="1.905" x2="-2.54" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-3.556" y1="1.778" x2="-2.032" y2="1.778" width="0.1524" layer="51"/>
<wire x1="4.064" y1="-1.778" x2="4.064" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.27" x2="3.81" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="3.81" y1="-1.27" x2="4.064" y2="-1.778" width="0.0508" layer="21"/>
<wire x1="3.556" y1="-1.27" x2="3.81" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="3.556" y1="-1.778" x2="4.064" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.27" x2="3.556" y2="1.27" width="0.0508" layer="21"/>
<wire x1="3.556" y1="1.27" x2="2.032" y2="1.27" width="0.0508" layer="51"/>
<wire x1="3.048" y1="-1.905" x2="3.048" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.778" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.905" x2="3.048" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-1.27" x2="3.556" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="2.032" y1="-1.778" x2="3.556" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="3.81" y1="1.27" x2="4.064" y2="1.778" width="0.0508" layer="21"/>
<wire x1="3.556" y1="1.778" x2="4.064" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="1.778" width="0.1524" layer="51"/>
<wire x1="3.048" y1="1.778" x2="3.048" y2="1.905" width="0.1524" layer="51"/>
<wire x1="2.54" y1="1.905" x2="3.048" y2="1.905" width="0.1524" layer="51"/>
<wire x1="2.032" y1="1.778" x2="3.556" y2="1.778" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="-0.254" x2="-0.508" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.254" x2="-0.508" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.254" x2="-1.778" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.254" x2="-1.778" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.635" x2="-1.143" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.635" x2="-1.143" y2="1.016" width="0.0508" layer="21"/>
<wire x1="-1.778" y1="-0.635" x2="-1.143" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.635" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.635" x2="-1.143" y2="-1.016" width="0.0508" layer="21"/>
<circle x="3.048" y="0" radius="0.254" width="0.1524" layer="21"/>
<smd name="1" x="-2.794" y="-1.524" dx="1.27" dy="1.8796" layer="1"/>
<smd name="2" x="2.794" y="-1.524" dx="1.27" dy="1.8796" layer="1"/>
<smd name="3" x="2.794" y="1.524" dx="1.27" dy="1.8796" layer="1"/>
<smd name="4" x="-2.794" y="1.524" dx="1.27" dy="1.8796" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MM39SL" urn="urn:adsk.eagle:footprint:12011/1" library_version="1">
<wire x1="-3.683" y1="-1.651" x2="3.683" y2="-1.651" width="0.0508" layer="21"/>
<wire x1="-3.683" y1="-2.286" x2="3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="1.651" x2="-3.683" y2="1.651" width="0.0508" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-6.223" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="1.651" x2="-4.826" y2="0.762" width="0.0508" layer="51"/>
<wire x1="-5.715" y1="-2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-4.826" y1="-1.651" x2="-3.683" y2="-1.651" width="0.0508" layer="51"/>
<wire x1="-5.715" y1="-2.055" x2="-6.223" y2="-2.286" width="0.0508" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.715" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.762" x2="-4.826" y2="-0.762" width="0.0508" layer="21"/>
<wire x1="-4.826" y1="-0.762" x2="-4.826" y2="-1.651" width="0.0508" layer="51"/>
<wire x1="-4.826" y1="-1.651" x2="-5.715" y2="-2.055" width="0.0508" layer="51"/>
<wire x1="-5.715" y1="2.286" x2="-3.683" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="1.651" x2="-4.826" y2="1.651" width="0.0508" layer="51"/>
<wire x1="-6.223" y1="2.286" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.055" x2="-6.223" y2="2.286" width="0.0508" layer="21"/>
<wire x1="-4.826" y1="1.651" x2="-5.715" y2="2.055" width="0.0508" layer="51"/>
<wire x1="6.223" y1="-2.286" x2="6.223" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-1.651" x2="5.842" y2="1.651" width="0.0508" layer="21"/>
<wire x1="5.842" y1="-1.651" x2="6.223" y2="-2.286" width="0.0508" layer="21"/>
<wire x1="5.715" y1="-2.286" x2="6.223" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="5.715" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-1.651" x2="5.842" y2="-1.651" width="0.0508" layer="21"/>
<wire x1="3.683" y1="-1.651" x2="5.715" y2="-1.651" width="0.0508" layer="51"/>
<wire x1="5.842" y1="1.651" x2="6.223" y2="2.286" width="0.0508" layer="21"/>
<wire x1="5.842" y1="1.651" x2="5.715" y2="1.651" width="0.0508" layer="21"/>
<wire x1="5.715" y1="2.286" x2="6.223" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="2.286" x2="5.715" y2="2.286" width="0.1524" layer="51"/>
<wire x1="5.715" y1="1.651" x2="3.683" y2="1.651" width="0.0508" layer="51"/>
<wire x1="-3.81" y1="-0.254" x2="-2.54" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.254" x2="-3.81" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.254" x2="-3.81" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.175" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0.635" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0.635" x2="-3.175" y2="1.016" width="0.1016" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-3.175" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-3.175" y2="-1.016" width="0.1016" layer="21"/>
<circle x="5.08" y="0" radius="0.254" width="0.1524" layer="21"/>
<smd name="1" x="-4.699" y="-1.778" dx="1.778" dy="1.778" layer="1"/>
<smd name="2" x="4.699" y="-1.778" dx="1.778" dy="1.778" layer="1"/>
<smd name="3" x="4.699" y="1.778" dx="1.778" dy="1.778" layer="1"/>
<smd name="4" x="-4.699" y="1.778" dx="1.778" dy="1.778" layer="1"/>
<text x="-2.032" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="CTS406" urn="urn:adsk.eagle:footprint:12012/1" library_version="1">
<description>&lt;b&gt;Model 406 6.0x3.5mm Low Cost Surface Mount Crystal&lt;/b&gt;&lt;p&gt;
Source: 008-0260-0_E.pdf</description>
<wire x1="-2.475" y1="1.65" x2="-1.05" y2="1.65" width="0.2032" layer="51"/>
<wire x1="-1.05" y1="1.65" x2="1.05" y2="1.65" width="0.2032" layer="21"/>
<wire x1="1.05" y1="1.65" x2="2.475" y2="1.65" width="0.2032" layer="51"/>
<wire x1="2.9" y1="1.225" x2="2.9" y2="0.3" width="0.2032" layer="51"/>
<wire x1="2.9" y1="0.3" x2="2.9" y2="-0.3" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-0.3" x2="2.9" y2="-1.225" width="0.2032" layer="51"/>
<wire x1="2.475" y1="-1.65" x2="1.05" y2="-1.65" width="0.2032" layer="51"/>
<wire x1="1.05" y1="-1.65" x2="-1.05" y2="-1.65" width="0.2032" layer="21"/>
<wire x1="-1.05" y1="-1.65" x2="-2.475" y2="-1.65" width="0.2032" layer="51"/>
<wire x1="-2.9" y1="-1.225" x2="-2.9" y2="-0.3" width="0.2032" layer="51"/>
<wire x1="-2.9" y1="-0.3" x2="-2.9" y2="0.3" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="0.3" x2="-2.9" y2="1.225" width="0.2032" layer="51"/>
<wire x1="-2.9" y1="1.225" x2="-2.475" y2="1.65" width="0.2032" layer="51" curve="89.516721"/>
<wire x1="2.475" y1="1.65" x2="2.9" y2="1.225" width="0.2032" layer="51" curve="89.516721"/>
<wire x1="2.9" y1="-1.225" x2="2.475" y2="-1.65" width="0.2032" layer="51" curve="89.516721"/>
<wire x1="-2.475" y1="-1.65" x2="-2.9" y2="-1.225" width="0.2032" layer="51" curve="89.516721"/>
<circle x="-2.05" y="-0.2" radius="0.182" width="0" layer="21"/>
<smd name="1" x="-2.2" y="-1.2" dx="1.9" dy="1.4" layer="1"/>
<smd name="2" x="2.2" y="-1.2" dx="1.9" dy="1.4" layer="1"/>
<smd name="3" x="2.2" y="1.2" dx="1.9" dy="1.4" layer="1"/>
<smd name="4" x="-2.2" y="1.2" dx="1.9" dy="1.4" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="HC49/S" urn="urn:adsk.eagle:package:12071/1" type="box" library_version="1">
<description>CRYSTAL</description>
</package3d>
<package3d name="HC49GW" urn="urn:adsk.eagle:package:12072/1" type="box" library_version="1">
</package3d>
<package3d name="HC49TL-H" urn="urn:adsk.eagle:package:12073/1" type="box" library_version="1">
</package3d>
<package3d name="HC49U-H" urn="urn:adsk.eagle:package:12074/1" type="box" library_version="1">
</package3d>
<package3d name="HC49U-LM" urn="urn:adsk.eagle:package:12077/1" type="box" library_version="1">
</package3d>
<package3d name="HC49U-V" urn="urn:adsk.eagle:package:12075/1" type="box" library_version="1">
</package3d>
<package3d name="HC49U70" urn="urn:adsk.eagle:package:12079/1" type="box" library_version="1">
</package3d>
<package3d name="HC49UP" urn="urn:adsk.eagle:package:12078/1" type="box" library_version="1">
</package3d>
<package3d name="HC13U-H" urn="urn:adsk.eagle:package:12080/1" type="box" library_version="1">
</package3d>
<package3d name="HC18U-H" urn="urn:adsk.eagle:package:12081/1" type="box" library_version="1">
</package3d>
<package3d name="HC18U-V" urn="urn:adsk.eagle:package:12082/1" type="box" library_version="1">
</package3d>
<package3d name="HC33U-H" urn="urn:adsk.eagle:package:12083/1" type="box" library_version="1">
</package3d>
<package3d name="HC33U-V" urn="urn:adsk.eagle:package:12084/1" type="box" library_version="1">
</package3d>
<package3d name="SM49" urn="urn:adsk.eagle:package:12085/1" type="box" library_version="1">
</package3d>
<package3d name="TC26H" urn="urn:adsk.eagle:package:12086/1" type="box" library_version="1">
</package3d>
<package3d name="TC26V" urn="urn:adsk.eagle:package:12088/1" type="box" library_version="1">
</package3d>
<package3d name="TC38H" urn="urn:adsk.eagle:package:12087/1" type="box" library_version="1">
</package3d>
<package3d name="86SMX" urn="urn:adsk.eagle:package:12091/1" type="box" library_version="1">
<description>CRYSTAL RESONATOR</description>
</package3d>
<package3d name="MM20SS" urn="urn:adsk.eagle:package:12092/1" type="box" library_version="1">
</package3d>
<package3d name="MM39SL" urn="urn:adsk.eagle:package:12090/1" type="box" library_version="1">
</package3d>
<package3d name="CTS406" urn="urn:adsk.eagle:package:12089/1" type="box" library_version="1">
<description>Model 406 6.0x3.5mm Low Cost Surface Mount Crystal
</package3d>
</packages3d>
<symbols>
<symbol name="Q" urn="urn:adsk.eagle:symbol:11991/1" library_version="1">
<wire x1="1.016" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="0" x2="-1.016" y2="0" width="0.1524" layer="94"/>
<wire x1="-0.381" y1="1.524" x2="-0.381" y2="-1.524" width="0.254" layer="94"/>
<wire x1="-0.381" y1="-1.524" x2="0.381" y2="-1.524" width="0.254" layer="94"/>
<wire x1="0.381" y1="-1.524" x2="0.381" y2="1.524" width="0.254" layer="94"/>
<wire x1="0.381" y1="1.524" x2="-0.381" y2="1.524" width="0.254" layer="94"/>
<wire x1="1.016" y1="1.778" x2="1.016" y2="-1.778" width="0.254" layer="94"/>
<wire x1="-1.016" y1="1.778" x2="-1.016" y2="-1.778" width="0.254" layer="94"/>
<text x="2.54" y="1.016" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.159" y="-1.143" size="0.8636" layer="93">1</text>
<text x="1.524" y="-1.143" size="0.8636" layer="93">2</text>
<pin name="2" x="2.54" y="0" visible="off" length="point" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-2.54" y="0" visible="off" length="point" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="CRYSTAL" urn="urn:adsk.eagle:component:12141/1" prefix="Q" uservalue="yes" library_version="1">
<gates>
<gate name="G$1" symbol="Q" x="0" y="0"/>
</gates>
<devices>
<device name="HC49S" package="HC49/S">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12071/1"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="1667008" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
<device name="HC49GW" package="HC49GW">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12072/1"/>
<technologies>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
<device name="HC49TL-H" package="HC49TL-H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12073/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="HC49U-H" package="HC49U-H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12074/1"/>
<technologies>
<attribute name="OC_FARNELL" value="1666973" constant="no"/>
</technology>
</technologies>
</device>
<device name="HC49U-LM" package="HC49U-LM">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12077/1"/>
<technologies>
<attribute name="OC_FARNELL" value="1666956" constant="no"/>
</technology>
</technologies>
</device>
<device name="HC49U-V" package="HC49U-V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12075/1"/>
<technologies>
<attribute name="OC_FARNELL" value="1666969" constant="no"/>
</technology>
</technologies>
</device>
<device name="HC49U70" package="HC49U70">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12079/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="HC49UP" package="HC49UP">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12078/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="HC13U-H" package="HC13U-H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12080/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="HC18U-H" package="HC18U-H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12081/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="HC18U-V" package="HC18U-V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12082/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="HC33U-H" package="HC33U-H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12083/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="HC33U-V" package="HC33U-V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12084/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SM49" package="SM49">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12085/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TC26H" package="TC26H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12086/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TC26V" package="TC26V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12088/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TC38H" package="TC38H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12087/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="68SMX" package="86SMX">
<connects>
<connect gate="G$1" pin="2" pad="4"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12091/1"/>
<technologies>
<attribute name="OC_FARNELL" value="6344860" constant="no"/>
</technology>
</technologies>
</device>
<device name="MM20SS" package="MM20SS">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12092/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MM39SL" package="MM39SL">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12090/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CTS406" package="CTS406">
<connects>
<connect gate="G$1" pin="2" pad="3"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:12089/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="pinhead" urn="urn:adsk.eagle:library:325">
<packages>
<package name="1X01" urn="urn:adsk.eagle:footprint:22382/1" library_version="3">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" shape="octagon"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="1X01" urn="urn:adsk.eagle:package:22485/2" type="model" library_version="3">
<description>PIN HEADER</description>
</package3d>
</packages3d>
<symbols>
<symbol name="PINHD1" urn="urn:adsk.eagle:symbol:22381/1" library_version="3">
<wire x1="-6.35" y1="-2.54" x2="1.27" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.27" y2="2.54" width="0.4064" layer="94"/>
<wire x1="1.27" y1="2.54" x2="-6.35" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="2.54" x2="-6.35" y2="-2.54" width="0.4064" layer="94"/>
<text x="-6.35" y="3.175" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="PINHD-1X1" urn="urn:adsk.eagle:component:22540/2" prefix="JP" uservalue="yes" library_version="3">
<gates>
<gate name="G$1" symbol="PINHD1" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X01">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:22485/2"/>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1" urn="urn:adsk.eagle:library:371">
<packages>
</packages>
<symbols>
<symbol name="+5V" urn="urn:adsk.eagle:symbol:26929/1" library_version="1">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<text x="-2.54" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="+5V" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="GND" urn="urn:adsk.eagle:symbol:26925/1" library_version="1">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="+5V" urn="urn:adsk.eagle:component:26963/1" prefix="P+" library_version="1">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="+5V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GND" urn="urn:adsk.eagle:component:26954/1" prefix="GND" library_version="1">
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="display-kingbright" urn="urn:adsk.eagle:library:213">
<description>&lt;b&gt;KINGBRIGHT Numeric Displays&lt;/b&gt;&lt;p&gt;
&lt;author&gt;librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DA56" urn="urn:adsk.eagle:footprint:13070/1" library_version="1" library_locally_modified="yes">
<description>&lt;b&gt;14.22mm (0.56INCH) DUAL DIGIT NUMERIC DISPLAYS&lt;/b&gt;&lt;p&gt;
Source: DA56-11SRWA.pdf</description>
<wire x1="-12.425" y1="9.4" x2="12.395" y2="9.4" width="0.2032" layer="21"/>
<wire x1="12.395" y1="9.4" x2="12.395" y2="-9.4" width="0.2032" layer="21"/>
<wire x1="12.395" y1="-9.4" x2="-12.425" y2="-9.4" width="0.2032" layer="21"/>
<wire x1="-12.425" y1="-9.4" x2="-12.425" y2="9.4" width="0.2032" layer="21"/>
<circle x="-1.3517" y="-6.4231" radius="0.84" width="0" layer="21"/>
<circle x="11.2733" y="-6.4231" radius="0.84" width="0" layer="21"/>
<pad name="1" x="-10.26" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="2" x="-7.72" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="3" x="-5.18" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="4" x="-2.64" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="5" x="-0.1" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="6" x="2.44" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="7" x="4.98" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="8" x="7.52" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="9" x="10.06" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="10" x="10.26" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="11" x="7.72" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="12" x="5.18" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="13" x="2.64" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="14" x="0.1" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="15" x="-2.64" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="16" x="-5.18" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="17" x="-7.72" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="18" x="-10.26" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<text x="-12.165" y="10.16" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="0.535" y="10.16" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<polygon width="0.3976" layer="51" spacing="1.2428">
<vertex x="-7.3945" y="5.9694"/>
<vertex x="-7.2233" y="6.948"/>
<vertex x="-3.2037" y="6.948"/>
<vertex x="-3.326" y="5.9694"/>
</polygon>
<vertex x="-3.6132" y="1.0329"/>
<vertex x="-2.5796" y="6.9034"/>
<vertex x="-2.277" y="6.9114" curve="-104.731141"/>
<vertex x="-1.6592" y="6.071"/>
<vertex x="-2.6899" y="0.4893"/>
<vertex x="-3.1547" y="0.4893"/>
</polygon>
<vertex x="-8.8869" y="1.0764"/>
<vertex x="-7.8593" y="6.948"/>
<vertex x="-8.1285" y="6.948" curve="77.705866"/>
<vertex x="-9.0092" y="6.2385"/>
<vertex x="-10.0122" y="0.4893"/>
<vertex x="-9.4495" y="0.4893"/>
</polygon>
<polygon width="0.3976" layer="21" spacing="1.2428">
<vertex x="-8.9847" y="0.0245"/>
<vertex x="-8.3731" y="0.6361"/>
<vertex x="-4.1578" y="0.6361"/>
<vertex x="-3.7908" y="0.1223"/>
<vertex x="-4.2312" y="-0.3425"/>
<vertex x="-8.6177" y="-0.3425"/>
</polygon>
<vertex x="-5.3321" y="-5.7003"/>
<vertex x="-5.5033" y="-6.6789"/>
<vertex x="-9.5229" y="-6.6789"/>
<vertex x="-9.4006" y="-5.7003"/>
</polygon>
<vertex x="-9.1868" y="-0.7149"/>
<vertex x="-10.1471" y="-6.6343"/>
<vertex x="-10.4497" y="-6.6423" curve="-104.72259"/>
<vertex x="-11.0674" y="-5.8019"/>
<vertex x="-10.1101" y="-0.1713"/>
<vertex x="-9.6453" y="-0.1713"/>
</polygon>
<vertex x="-3.8887" y="-0.9541"/>
<vertex x="-4.8673" y="-6.6789"/>
<vertex x="-4.5982" y="-6.6789" curve="77.701982"/>
<vertex x="-3.7174" y="-5.9694"/>
<vertex x="-2.7878" y="-0.4159"/>
<vertex x="-3.3505" y="-0.4159"/>
</polygon>
<vertex x="5.3055" y="5.9694"/>
<vertex x="5.4767" y="6.948"/>
<vertex x="9.4963" y="6.948"/>
<vertex x="9.374" y="5.9694"/>
</polygon>
<vertex x="9.0868" y="1.0329"/>
<vertex x="10.1204" y="6.9034"/>
<vertex x="10.423" y="6.9114" curve="-104.731141"/>
<vertex x="11.0408" y="6.071"/>
<vertex x="10.0101" y="0.4893"/>
<vertex x="9.5453" y="0.4893"/>
</polygon>
<vertex x="3.8131" y="1.0764"/>
<vertex x="4.8407" y="6.948"/>
<vertex x="4.5715" y="6.948" curve="77.705866"/>
<vertex x="3.6908" y="6.2385"/>
<vertex x="2.6878" y="0.4893"/>
<vertex x="3.2505" y="0.4893"/>
</polygon>
<vertex x="3.7153" y="0.0245"/>
<vertex x="4.3269" y="0.6361"/>
<vertex x="8.5422" y="0.6361"/>
<vertex x="8.9092" y="0.1223"/>
<vertex x="8.4688" y="-0.3425"/>
<vertex x="4.0823" y="-0.3425"/>
</polygon>
<vertex x="7.3679" y="-5.7003"/>
<vertex x="7.1967" y="-6.6789"/>
<vertex x="3.1771" y="-6.6789"/>
<vertex x="3.2994" y="-5.7003"/>
</polygon>
<vertex x="3.5132" y="-0.7149"/>
<vertex x="2.5529" y="-6.6343"/>
<vertex x="2.2503" y="-6.6423" curve="-104.72259"/>
<vertex x="1.6326" y="-5.8019"/>
<vertex x="2.5899" y="-0.1713"/>
<vertex x="3.0547" y="-0.1713"/>
</polygon>
<vertex x="8.8113" y="-0.9541"/>
<vertex x="7.8327" y="-6.6789"/>
<vertex x="8.1018" y="-6.6789" curve="77.701982"/>
<vertex x="8.9826" y="-5.9694"/>
<vertex x="9.9122" y="-0.4159"/>
<vertex x="9.3495" y="-0.4159"/>
</polygon>
</package>
</packages>
<packages3d>
<package3d name="DA56" urn="urn:adsk.eagle:package:13085/1" type="box" library_version="1" library_locally_modified="yes">
<description>14.22mm (0.56INCH) DUAL DIGIT NUMERIC DISPLAYS
</package3d>
</packages3d>
<symbols>
<symbol name="7SEG-LED-COM1" urn="urn:adsk.eagle:symbol:13068/1" library_version="1" library_locally_modified="yes">
<wire x1="2.794" y1="-3.683" x2="3.048" y2="-3.683" width="0.3048" layer="94"/>
<wire x1="2.3368" y1="3.1242" x2="2.032" y2="2.8194" width="0.254" layer="94"/>
<wire x1="2.032" y1="2.8194" x2="1.6256" y2="0.6096" width="0.254" layer="94"/>
<wire x1="1.6256" y1="0.6096" x2="1.905" y2="0.3302" width="0.254" layer="94"/>
<wire x1="1.905" y1="0.3302" x2="2.159" y2="0.5842" width="0.254" layer="94"/>
<wire x1="2.159" y1="0.5842" x2="2.54" y2="2.921" width="0.254" layer="94"/>
<wire x1="2.54" y1="2.921" x2="2.3368" y2="3.1242" width="0.254" layer="94"/>
<wire x1="2.032" y1="3.429" x2="1.778" y2="3.175" width="0.254" layer="94"/>
<wire x1="1.778" y1="3.175" x2="-0.762" y2="3.175" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.175" x2="-1.016" y2="3.429" width="0.254" layer="94"/>
<wire x1="-1.016" y1="3.429" x2="-0.762" y2="3.683" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.683" x2="1.778" y2="3.683" width="0.254" layer="94"/>
<wire x1="1.778" y1="3.683" x2="2.032" y2="3.429" width="0.254" layer="94"/>
<wire x1="-1.3208" y1="3.1242" x2="-1.016" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-1.016" y1="2.8194" x2="-1.397" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-1.397" y1="0.6096" x2="-1.651" y2="0.3556" width="0.254" layer="94"/>
<wire x1="-1.651" y1="0.3556" x2="-1.905" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-1.905" y1="0.6096" x2="-1.524" y2="2.921" width="0.254" layer="94"/>
<wire x1="-1.524" y1="2.921" x2="-1.3208" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-1.4732" y1="-0.0762" x2="-1.143" y2="0.254" width="0.254" layer="94"/>
<wire x1="-1.143" y1="0.254" x2="1.3462" y2="0.254" width="0.254" layer="94"/>
<wire x1="1.3462" y1="0.254" x2="1.5494" y2="0.0508" width="0.254" layer="94"/>
<wire x1="1.5494" y1="0.0508" x2="1.2446" y2="-0.254" width="0.254" layer="94"/>
<wire x1="1.2446" y1="-0.254" x2="-1.2954" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-1.2954" y1="-0.254" x2="-1.4732" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="-1.8288" y1="-0.3302" x2="-1.5748" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-2.286" y1="-3.1242" x2="-1.9558" y2="-2.794" width="0.254" layer="94"/>
<wire x1="-1.9558" y1="-2.794" x2="-1.5748" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-1.8288" y1="-0.3302" x2="-2.1082" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="-2.1082" y1="-0.6096" x2="-2.4892" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-2.4892" y1="-2.921" x2="-2.286" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-1.9812" y1="-3.429" x2="-1.7272" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.175" x2="0.8128" y2="-3.175" width="0.254" layer="94"/>
<wire x1="0.8128" y1="-3.175" x2="1.0668" y2="-3.429" width="0.254" layer="94"/>
<wire x1="1.0668" y1="-3.429" x2="0.8128" y2="-3.683" width="0.254" layer="94"/>
<wire x1="0.8128" y1="-3.683" x2="-1.7272" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.683" x2="-1.9812" y2="-3.429" width="0.254" layer="94"/>
<wire x1="1.7018" y1="-0.4064" x2="1.4478" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="1.4478" y1="-0.6604" x2="1.0668" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="1.0668" y1="-2.8194" x2="1.3716" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="1.3716" y1="-3.1242" x2="1.5748" y2="-2.921" width="0.254" layer="94"/>
<wire x1="1.5748" y1="-2.921" x2="1.9558" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="1.9558" y1="-0.6604" x2="1.7018" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="2.286" y1="2.794" x2="1.905" y2="0.635" width="0.4064" layer="94"/>
<wire x1="1.778" y1="3.429" x2="-0.762" y2="3.429" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="2.794" x2="-1.651" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.4064" layer="94"/>
<wire x1="1.651" y1="-0.762" x2="1.27" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="0.762" y1="-3.429" x2="-1.651" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="-2.286" y1="-2.921" x2="-1.905" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="5.969" y1="8.89" x2="5.969" y2="7.62" width="0.4064" layer="94"/>
<wire x1="5.969" y1="7.62" x2="5.969" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="5.969" y1="-7.62" x2="5.969" y2="-8.89" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-8.89" x2="5.969" y2="-8.89" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-8.89" x2="-5.08" y2="8.89" width="0.4064" layer="94"/>
<wire x1="5.969" y1="8.89" x2="-5.08" y2="8.89" width="0.4064" layer="94"/>
<wire x1="7.62" y1="7.62" x2="5.969" y2="7.62" width="0.1524" layer="94"/>
<wire x1="7.62" y1="-7.62" x2="5.969" y2="-7.62" width="0.1524" layer="94"/>
<circle x="2.921" y="-3.683" radius="0.254" width="0.3048" layer="94"/>
<text x="-5.08" y="9.525" size="1.778" layer="95">&gt;NAME</text>
<text x="-5.08" y="-11.43" size="1.778" layer="96">&gt;VALUE</text>
<text x="-6.477" y="7.874" size="1.27" layer="95">a</text>
<text x="-6.477" y="5.334" size="1.27" layer="95">b</text>
<text x="-6.477" y="2.794" size="1.27" layer="95">c</text>
<text x="-6.477" y="0.254" size="1.27" layer="95">d</text>
<text x="-6.477" y="-2.286" size="1.27" layer="95">e</text>
<text x="-6.477" y="-4.826" size="1.27" layer="95">f</text>
<text x="-6.477" y="-7.366" size="1.27" layer="95">g</text>
<pin name="DP" x="10.16" y="-7.62" length="short" direction="pas" rot="R180"/>
<pin name="F" x="-10.16" y="-5.08" visible="pad" length="middle" direction="pas"/>
<pin name="D" x="-10.16" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="B" x="-10.16" y="5.08" visible="pad" length="middle" direction="pas"/>
<pin name="A" x="-10.16" y="7.62" visible="pad" length="middle" direction="pas"/>
<pin name="COM" x="10.16" y="7.62" length="short" direction="pas" rot="R180"/>
<pin name="C" x="-10.16" y="2.54" visible="pad" length="middle" direction="pas"/>
<pin name="E" x="-10.16" y="-2.54" visible="pad" length="middle" direction="pas"/>
<pin name="G" x="-10.16" y="-7.62" visible="pad" length="middle" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="DC56-11" urn="urn:adsk.eagle:component:13093/1" prefix="LED" library_version="1" library_locally_modified="yes">
Source: www.kingbright.com .. DA56-11SRWA.pdf</description>
<gates>
<gate name="DIG1" symbol="7SEG-LED-COM1" x="-15.24" y="0" addlevel="always"/>
<gate name="DIG2" symbol="7SEG-LED-COM1" x="15.24" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="DA56">
<connects>
<connect gate="DIG1" pin="A" pad="16"/>
<connect gate="DIG1" pin="B" pad="15"/>
<connect gate="DIG1" pin="C" pad="3"/>
<connect gate="DIG1" pin="COM" pad="14"/>
<connect gate="DIG1" pin="D" pad="2"/>
<connect gate="DIG1" pin="DP" pad="4"/>
<connect gate="DIG1" pin="E" pad="1"/>
<connect gate="DIG1" pin="F" pad="18"/>
<connect gate="DIG1" pin="G" pad="17"/>
<connect gate="DIG2" pin="A" pad="11"/>
<connect gate="DIG2" pin="B" pad="10"/>
<connect gate="DIG2" pin="C" pad="8"/>
<connect gate="DIG2" pin="COM" pad="13"/>
<connect gate="DIG2" pin="D" pad="6"/>
<connect gate="DIG2" pin="DP" pad="9"/>
<connect gate="DIG2" pin="E" pad="5"/>
<connect gate="DIG2" pin="F" pad="12"/>
<connect gate="DIG2" pin="G" pad="7"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:13085/1"/>
<technologies>
<technology name="EWA">
</technology>
<technology name="GWA">
</technology>
<technology name="SRWA">
</technology>
<technology name="YWA">
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="rcl" urn="urn:adsk.eagle:library:334">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C1206" urn="urn:adsk.eagle:footprint:23125/1" library_version="3">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="C0402" urn="urn:adsk.eagle:footprint:23121/1" library_version="3">
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="C0504" urn="urn:adsk.eagle:footprint:23122/1" library_version="3">
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.294" y1="0.559" x2="0.294" y2="0.559" width="0.1016" layer="51"/>
<wire x1="-0.294" y1="-0.559" x2="0.294" y2="-0.559" width="0.1016" layer="51"/>
<smd name="1" x="-0.7" y="0" dx="1" dy="1.3" layer="1"/>
<smd name="2" x="0.7" y="0" dx="1" dy="1.3" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6604" y1="-0.6223" x2="-0.2804" y2="0.6276" layer="51"/>
<rectangle x1="0.2794" y1="-0.6223" x2="0.6594" y2="0.6276" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="C0603" urn="urn:adsk.eagle:footprint:23123/1" library_version="3">
<wire x1="-0.356" y1="0.432" x2="0.356" y2="0.432" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.419" x2="0.356" y2="-0.419" width="0.1016" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.1" dy="1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.1" dy="1" layer="1"/>
<rectangle x1="-0.8382" y1="-0.4699" x2="-0.3381" y2="0.4801" layer="51"/>
<rectangle x1="0.3302" y1="-0.4699" x2="0.8303" y2="0.4801" layer="51"/>
</package>
<package name="C0805" urn="urn:adsk.eagle:footprint:23124/1" library_version="3">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
</package>
<package name="C1210" urn="urn:adsk.eagle:footprint:23126/1" library_version="3">
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
</package>
<package name="C1310" urn="urn:adsk.eagle:footprint:23127/1" library_version="3">
<rectangle x1="-0.1001" y1="-0.3" x2="0.1001" y2="0.3" layer="35"/>
</package>
<package name="C1608" urn="urn:adsk.eagle:footprint:23128/1" library_version="3">
</package>
<package name="C1812" urn="urn:adsk.eagle:footprint:23129/1" library_version="3">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.4732" y1="1.6002" x2="1.4732" y2="1.6002" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-1.6002" x2="1.4732" y2="-1.6002" width="0.1016" layer="51"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<text x="-1.905" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3876" y1="-1.651" x2="-1.4376" y2="1.649" layer="51"/>
<rectangle x1="1.4478" y1="-1.651" x2="2.3978" y2="1.649" layer="51"/>
<rectangle x1="-0.3" y1="-0.4001" x2="0.3" y2="0.4001" layer="35"/>
</package>
<package name="C1825" urn="urn:adsk.eagle:footprint:23130/1" library_version="3">
<wire x1="-2.973" y1="3.483" x2="2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-3.483" x2="-2.973" y2="-3.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-3.483" x2="-2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="-1.4986" y1="3.2766" x2="1.4732" y2="3.2766" width="0.1016" layer="51"/>
<wire x1="-1.4732" y1="-3.2766" x2="1.4986" y2="-3.2766" width="0.1016" layer="51"/>
<wire x1="2.973" y1="3.483" x2="2.973" y2="-3.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<text x="-1.905" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.413" y1="-3.3528" x2="-1.463" y2="3.3472" layer="51"/>
<rectangle x1="1.4478" y1="-3.3528" x2="2.3978" y2="3.3472" layer="51"/>
<rectangle x1="-0.7" y1="-0.7" x2="0.7" y2="0.7" layer="35"/>
</package>
<package name="C2012" urn="urn:adsk.eagle:footprint:23131/1" library_version="3">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
</package>
<package name="C3216" urn="urn:adsk.eagle:footprint:23132/1" library_version="3">
<rectangle x1="-0.3" y1="-0.5001" x2="0.3" y2="0.5001" layer="35"/>
</package>
<package name="C3225" urn="urn:adsk.eagle:footprint:23133/1" library_version="3">
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="C4532" urn="urn:adsk.eagle:footprint:23134/1" library_version="3">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="C4564" urn="urn:adsk.eagle:footprint:23135/1" library_version="3">
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="C025-024X044" urn="urn:adsk.eagle:footprint:23136/1" library_version="3">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-025X050" urn="urn:adsk.eagle:footprint:23137/1" library_version="3">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-030X050" urn="urn:adsk.eagle:footprint:23138/1" library_version="3">
grid 2.5 mm, outline 3 x 5 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-040X050" urn="urn:adsk.eagle:footprint:23139/1" library_version="3">
grid 2.5 mm, outline 4 x 5 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-050X050" urn="urn:adsk.eagle:footprint:23140/1" library_version="3">
grid 2.5 mm, outline 5 x 5 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-060X050" urn="urn:adsk.eagle:footprint:23141/1" library_version="3">
grid 2.5 mm, outline 6 x 5 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-024X070" urn="urn:adsk.eagle:footprint:23142/1" library_version="3">
grid 2.5 mm + 5 mm, outline 2.4 x 7 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-1.143" x2="-3.9624" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-3.9624" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.635" x2="-4.191" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="0.635" x2="-4.191" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.699" y1="-0.635" x2="-4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-2.5654" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.143" x2="-2.5654" y2="-1.143" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.81" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-025X075" urn="urn:adsk.eagle:footprint:23143/1" library_version="3">
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="4.953" y1="1.016" x2="4.953" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.27" x2="4.953" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.27" x2="4.953" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.27" x2="4.699" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.762" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.254" x2="2.413" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="2.286" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="3.302" y2="0" width="0.1524" layer="51"/>
<pad name="3" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-035X075" urn="urn:adsk.eagle:footprint:23144/1" library_version="3">
grid 2.5 + 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-2.159" y1="1.778" x2="2.159" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.778" x2="-2.159" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.778" x2="2.413" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.524" x2="-2.159" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.778" x2="2.413" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.524" x2="-2.159" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="2.794" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.524" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.508" x2="2.413" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0" x2="0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-045X075" urn="urn:adsk.eagle:footprint:23145/1" library_version="3">
grid 2.5 + 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.032" x2="4.953" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.286" x2="4.953" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.286" x2="4.953" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.286" x2="4.699" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.286" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.397" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.762" x2="2.413" y2="-0.762" width="0.1524" layer="21"/>
<text x="-2.286" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C025_050-055X075" urn="urn:adsk.eagle:footprint:23146/1" library_version="3">
grid 2.5 + 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.794" x2="4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.794" x2="4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.794" x2="4.699" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.794" x2="2.794" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-2.032" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<text x="-2.286" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-024X044" urn="urn:adsk.eagle:footprint:23147/1" library_version="3">
grid 5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.159" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-2.159" y2="0.381" layer="51"/>
</package>
<package name="C050-025X075" urn="urn:adsk.eagle:footprint:23148/1" library_version="3">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-045X075" urn="urn:adsk.eagle:footprint:23149/1" library_version="3">
grid 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-030X075" urn="urn:adsk.eagle:footprint:23150/1" library_version="3">
grid 5 mm, outline 3 x 7.5 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-050X075" urn="urn:adsk.eagle:footprint:23151/1" library_version="3">
grid 5 mm, outline 5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-055X075" urn="urn:adsk.eagle:footprint:23152/1" library_version="3">
grid 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-075X075" urn="urn:adsk.eagle:footprint:23153/1" library_version="3">
grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050H075X075" urn="urn:adsk.eagle:footprint:23154/1" library_version="3">
Horizontal, grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-3.683" y1="7.112" x2="-3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0.508" x2="-3.302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.508" x2="-1.778" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="0.508" x2="1.778" y2="0.508" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.508" x2="3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.683" y1="0.508" x2="3.683" y2="7.112" width="0.1524" layer="21"/>
<wire x1="3.175" y1="7.62" x2="-3.175" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="2.413" x2="-0.3048" y2="1.778" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-0.3048" y2="1.143" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="2.413" x2="0.3302" y2="1.778" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="0.3302" y2="1.143" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="7.112" x2="-3.175" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.175" y1="7.62" x2="3.683" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="0.254" width="0.508" layer="51"/>
<wire x1="2.54" y1="0" x2="2.54" y2="0.254" width="0.508" layer="51"/>
<text x="-3.302" y="8.001" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="0.127" x2="-2.286" y2="0.508" layer="51"/>
<rectangle x1="2.286" y1="0.127" x2="2.794" y2="0.508" layer="51"/>
</package>
<package name="C075-032X103" urn="urn:adsk.eagle:footprint:23155/1" library_version="3">
grid 7.5 mm, outline 3.2 x 10.3 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" shape="octagon"/>
<text x="-4.826" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-042X103" urn="urn:adsk.eagle:footprint:23156/1" library_version="3">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<text x="-4.699" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-052X106" urn="urn:adsk.eagle:footprint:23157/1" library_version="3">
grid 7.5 mm, outline 5.2 x 10.6 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-043X133" urn="urn:adsk.eagle:footprint:23158/1" library_version="3">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-054X133" urn="urn:adsk.eagle:footprint:23159/1" library_version="3">
grid 10.2 mm, outline 5.4 x 13.3 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-064X133" urn="urn:adsk.eagle:footprint:23160/1" library_version="3">
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102_152-062X184" urn="urn:adsk.eagle:footprint:23161/1" library_version="3">
grid 10.2 mm + 15.2 mm, outline 6.2 x 18.4 mm</description>
<wire x1="-3.683" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="6.477" y1="0" x2="8.636" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="3.048" x2="6.223" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.048" x2="6.731" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.223" y1="-3.048" x2="6.731" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.54" x2="6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.176" y1="3.048" x2="11.684" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="11.176" y1="-3.048" x2="11.684" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="11.176" y1="-3.048" x2="7.112" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="7.112" y1="3.048" x2="11.176" y2="3.048" width="0.1524" layer="21"/>
<wire x1="11.684" y1="2.54" x2="11.684" y2="-2.54" width="0.1524" layer="21"/>
<pad name="3" x="10.033" y="0" drill="1.016" shape="octagon"/>
<text x="-5.969" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-054X183" urn="urn:adsk.eagle:footprint:23162/1" library_version="3">
grid 15 mm, outline 5.4 x 18.3 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" shape="octagon"/>
<text x="-8.382" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-064X183" urn="urn:adsk.eagle:footprint:23163/1" library_version="3">
grid 15 mm, outline 6.4 x 18.3 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C150-072X183" urn="urn:adsk.eagle:footprint:23164/1" library_version="3">
grid 15 mm, outline 7.2 x 18.3 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-084X183" urn="urn:adsk.eagle:footprint:23165/1" library_version="3">
grid 15 mm, outline 8.4 x 18.3 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-091X182" urn="urn:adsk.eagle:footprint:23166/1" library_version="3">
grid 15 mm, outline 9.1 x 18.2 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-062X268" urn="urn:adsk.eagle:footprint:23167/1" library_version="3">
grid 22.5 mm, outline 6.2 x 26.8 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" shape="octagon"/>
<text x="-12.7" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C225-074X268" urn="urn:adsk.eagle:footprint:23168/1" library_version="3">
grid 22.5 mm, outline 7.4 x 26.8 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="3.937" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-087X268" urn="urn:adsk.eagle:footprint:23169/1" library_version="3">
grid 22.5 mm, outline 8.7 x 26.8 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="4.699" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-108X268" urn="urn:adsk.eagle:footprint:23170/1" library_version="3">
grid 22.5 mm, outline 10.8 x 26.8 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.715" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-113X268" urn="urn:adsk.eagle:footprint:23171/1" library_version="3">
grid 22.5 mm, outline 11.3 x 26.8 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-093X316" urn="urn:adsk.eagle:footprint:23172/1" library_version="3">
grid 27.5 mm, outline 9.3 x 31.6 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" shape="octagon"/>
<text x="-15.24" y="4.953" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-113X316" urn="urn:adsk.eagle:footprint:23173/1" library_version="3">
grid 27.5 mm, outline 11.3 x 31.6 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-134X316" urn="urn:adsk.eagle:footprint:23174/1" library_version="3">
grid 27.5 mm, outline 13.4 x 31.6 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-205X316" urn="urn:adsk.eagle:footprint:23175/1" library_version="3">
grid 27.5 mm, outline 20.5 x 31.6 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-137X374" urn="urn:adsk.eagle:footprint:23176/1" library_version="3">
grid 32.5 mm, outline 13.7 x 37.4 mm</description>
<wire x1="-14.2748" y1="0" x2="-12.7" y2="0" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="1.905" x2="-11.811" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="0" x2="14.2748" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.811" y1="0" x2="-11.811" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-12.7" y1="0" x2="-12.7" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="18.542" y1="6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="6.731" x2="-18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="18.542" y1="6.731" x2="-18.542" y2="6.731" width="0.1524" layer="21"/>
<pad name="1" x="-16.256" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="16.256" y="0" drill="1.1938" shape="octagon"/>
<text x="-18.2372" y="7.0612" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.8458" y="-2.8702" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-162X374" urn="urn:adsk.eagle:footprint:23177/1" library_version="3">
grid 32.5 mm, outline 16.2 x 37.4 mm</description>
<wire x1="18.542" y1="8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="8.001" x2="-18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="18.542" y1="8.001" x2="-18.542" y2="8.001" width="0.1524" layer="21"/>
<text x="-18.3642" y="8.3312" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C325-182X374" urn="urn:adsk.eagle:footprint:23178/1" library_version="3">
grid 32.5 mm, outline 18.2 x 37.4 mm</description>
<wire x1="18.542" y1="9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="9.017" x2="-18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="18.542" y1="9.017" x2="-18.542" y2="9.017" width="0.1524" layer="21"/>
<text x="-18.3642" y="9.3472" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-192X418" urn="urn:adsk.eagle:footprint:23179/1" library_version="3">
grid 37.5 mm, outline 19.2 x 41.8 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" shape="octagon"/>
<text x="-20.447" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-203X418" urn="urn:adsk.eagle:footprint:23180/1" library_version="3">
grid 37.5 mm, outline 20.3 x 41.8 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-20.32" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C050-035X075" urn="urn:adsk.eagle:footprint:23181/1" library_version="3">
grid 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C375-155X418" urn="urn:adsk.eagle:footprint:23182/1" library_version="3">
grid 37.5 mm, outline 15.5 x 41.8 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-20.447" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C075-063X106" urn="urn:adsk.eagle:footprint:23183/1" library_version="3">
grid 7.5 mm, outline 6.3 x 10.6 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C275-154X316" urn="urn:adsk.eagle:footprint:23184/1" library_version="3">
grid 27.5 mm, outline 15.4 x 31.6 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-173X316" urn="urn:adsk.eagle:footprint:23185/1" library_version="3">
grid 27.5 mm, outline 17.3 x 31.6 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C0402K" urn="urn:adsk.eagle:footprint:23186/1" library_version="3">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0204 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1005</description>
<wire x1="-0.425" y1="0.2" x2="0.425" y2="0.2" width="0.1016" layer="51"/>
<wire x1="0.425" y1="-0.2" x2="-0.425" y2="-0.2" width="0.1016" layer="51"/>
<smd name="1" x="-0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<smd name="2" x="0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<text x="-0.5" y="0.425" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.5" y="-1.45" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5" y1="-0.25" x2="-0.225" y2="0.25" layer="51"/>
<rectangle x1="0.225" y1="-0.25" x2="0.5" y2="0.25" layer="51"/>
</package>
<package name="C0603K" urn="urn:adsk.eagle:footprint:23187/1" library_version="3">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0603 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1608</description>
<wire x1="-0.725" y1="0.35" x2="0.725" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.725" y1="-0.35" x2="-0.725" y2="-0.35" width="0.1016" layer="51"/>
<smd name="1" x="-0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<smd name="2" x="0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<text x="-0.8" y="0.65" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.65" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.4" x2="-0.45" y2="0.4" layer="51"/>
<rectangle x1="0.45" y1="-0.4" x2="0.8" y2="0.4" layer="51"/>
</package>
<package name="C0805K" urn="urn:adsk.eagle:footprint:23188/1" library_version="3">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="1" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1" y="0.875" size="1.016" layer="25">&gt;NAME</text>
<text x="-1" y="-1.9" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
</package>
<package name="C1206K" urn="urn:adsk.eagle:footprint:23189/1" library_version="3">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
<package name="C1210K" urn="urn:adsk.eagle:footprint:23190/1" library_version="3">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1210 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3225</description>
<wire x1="-1.525" y1="1.175" x2="1.525" y2="1.175" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-1.175" x2="-1.525" y2="-1.175" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<text x="-1.6" y="1.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-1.25" x2="-1.1" y2="1.25" layer="51"/>
<rectangle x1="1.1" y1="-1.25" x2="1.6" y2="1.25" layer="51"/>
</package>
<package name="C1812K" urn="urn:adsk.eagle:footprint:23191/1" library_version="3">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1812 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4532</description>
<wire x1="-2.175" y1="1.525" x2="2.175" y2="1.525" width="0.1016" layer="51"/>
<wire x1="2.175" y1="-1.525" x2="-2.175" y2="-1.525" width="0.1016" layer="51"/>
<smd name="1" x="-2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<smd name="2" x="2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<text x="-2.25" y="1.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.25" y="-2.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.25" y1="-1.6" x2="-1.65" y2="1.6" layer="51"/>
<rectangle x1="1.65" y1="-1.6" x2="2.25" y2="1.6" layer="51"/>
</package>
<package name="C1825K" urn="urn:adsk.eagle:footprint:23192/1" library_version="3">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1825 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4564</description>
<wire x1="-1.525" y1="3.125" x2="1.525" y2="3.125" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-3.125" x2="-1.525" y2="-3.125" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<text x="-1.6" y="3.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-4.625" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-3.2" x2="-1.1" y2="3.2" layer="51"/>
<rectangle x1="1.1" y1="-3.2" x2="1.6" y2="3.2" layer="51"/>
</package>
<package name="C2220K" urn="urn:adsk.eagle:footprint:23193/1" library_version="3">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2220 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5650</description>
<wire x1="-2.725" y1="2.425" x2="2.725" y2="2.425" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-2.425" x2="-2.725" y2="-2.425" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<text x="-2.8" y="2.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-3.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-2.5" x2="-2.2" y2="2.5" layer="51"/>
<rectangle x1="2.2" y1="-2.5" x2="2.8" y2="2.5" layer="51"/>
</package>
<package name="C2225K" urn="urn:adsk.eagle:footprint:23194/1" library_version="3">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2225 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5664</description>
<wire x1="-2.725" y1="3.075" x2="2.725" y2="3.075" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-3.075" x2="-2.725" y2="-3.075" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<text x="-2.8" y="3.6" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-4.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-3.15" x2="-2.2" y2="3.15" layer="51"/>
<rectangle x1="2.2" y1="-3.15" x2="2.8" y2="3.15" layer="51"/>
</package>
<package name="HPC0201" urn="urn:adsk.eagle:footprint:23195/1" library_version="3">
<description>&lt;b&gt; &lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/10129/hpc0201a.pdf</description>
<smd name="1" x="-0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<smd name="2" x="0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<text x="-0.75" y="0.74" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.785" y="-1.865" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.305" y1="-0.15" x2="0.305" y2="0.15" layer="51"/>
</package>
<package name="C0201" urn="urn:adsk.eagle:footprint:23196/1" library_version="3">
<description>Source: http://www.avxcorp.com/docs/catalogs/cx5r.pdf</description>
<smd name="1" x="-0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<smd name="2" x="0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="0.1" x2="0.15" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="-0.1" layer="51"/>
</package>
<package name="C1808" urn="urn:adsk.eagle:footprint:23197/1" library_version="3">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
Source: AVX .. aphvc.pdf</description>
<wire x1="-1.4732" y1="0.9502" x2="1.4732" y2="0.9502" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-0.9502" x2="1.4732" y2="-0.9502" width="0.1016" layer="51"/>
<smd name="1" x="-1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<text x="-2.233" y="1.827" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.233" y="-2.842" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.275" y1="-1.015" x2="-1.225" y2="1.015" layer="51"/>
<rectangle x1="1.225" y1="-1.015" x2="2.275" y2="1.015" layer="51"/>
</package>
<package name="C3640" urn="urn:adsk.eagle:footprint:23198/1" library_version="3">
<wire x1="-3.8322" y1="5.0496" x2="3.8322" y2="5.0496" width="0.1016" layer="51"/>
<wire x1="-3.8322" y1="-5.0496" x2="3.8322" y2="-5.0496" width="0.1016" layer="51"/>
<smd name="1" x="-4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<smd name="2" x="4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<text x="-4.647" y="6.465" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.647" y="-7.255" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.57" y1="-5.1" x2="-3.05" y2="5.1" layer="51"/>
<rectangle x1="3.05" y1="-5.1" x2="4.5688" y2="5.1" layer="51"/>
</package>
<package name="C01005" urn="urn:adsk.eagle:footprint:23199/1" library_version="3">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
<rectangle x1="-0.2" y1="-0.1" x2="-0.075" y2="0.1" layer="51"/>
<rectangle x1="0.075" y1="-0.1" x2="0.2" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="0.05" x2="0.15" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="-0.1" x2="0.15" y2="-0.05" layer="51"/>
<smd name="1" x="-0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<smd name="2" x="0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<text x="-0.4" y="0.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.4" y="-1.6" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1206" urn="urn:adsk.eagle:footprint:23047/1" library_version="3">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R0402" urn="urn:adsk.eagle:footprint:23043/3" library_version="3">
<description>&lt;b&gt;Chip RESISTOR 0402 EIA (1005 Metric)&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1" y1="0.483" x2="1" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1" y1="0.483" x2="1" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1" y1="-0.483" x2="-1" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1" y1="-0.483" x2="-1" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.5" y="0" dx="0.6" dy="0.7" layer="1"/>
<smd name="2" x="0.5" y="0" dx="0.6" dy="0.7" layer="1"/>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.35" x2="0.1999" y2="0.35" layer="35"/>
</package>
<package name="R0603" urn="urn:adsk.eagle:footprint:23044/1" library_version="3">
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R0805" urn="urn:adsk.eagle:footprint:23045/1" library_version="3">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="R0805W" urn="urn:adsk.eagle:footprint:23046/1" library_version="3">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; wave soldering&lt;p&gt;</description>
<smd name="1" x="-1.0525" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="1.0525" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R1206W" urn="urn:adsk.eagle:footprint:23048/1" library_version="3">
wave soldering</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
</package>
<package name="R1210" urn="urn:adsk.eagle:footprint:23049/1" library_version="3">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
</package>
<package name="R1210W" urn="urn:adsk.eagle:footprint:23050/1" library_version="3">
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010" urn="urn:adsk.eagle:footprint:23051/1" library_version="3">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-3.175" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="R2010W" urn="urn:adsk.eagle:footprint:23052/1" library_version="3">
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
</package>
<package name="R2012" urn="urn:adsk.eagle:footprint:23053/1" library_version="3">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="R2012W" urn="urn:adsk.eagle:footprint:23054/1" library_version="3">
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R2512" urn="urn:adsk.eagle:footprint:23055/1" library_version="3">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R2512W" urn="urn:adsk.eagle:footprint:23056/1" library_version="3">
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3216" urn="urn:adsk.eagle:footprint:23057/1" library_version="3">
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="R3216W" urn="urn:adsk.eagle:footprint:23058/1" library_version="3">
</package>
<package name="R3225" urn="urn:adsk.eagle:footprint:23059/1" library_version="3">
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="R3225W" urn="urn:adsk.eagle:footprint:23060/1" library_version="3">
</package>
<package name="R5025" urn="urn:adsk.eagle:footprint:23061/1" library_version="3">
</package>
<package name="R5025W" urn="urn:adsk.eagle:footprint:23062/1" library_version="3">
</package>
<package name="R6332" urn="urn:adsk.eagle:footprint:23063/1" library_version="3">
Source: http://download.siliconexpert.com/pdfs/2005/02/24/Semi_Ap/2/VSH/Resistor/dcrcwfre.pdf</description>
<smd name="1" x="-3.1" y="0" dx="1" dy="3.2" layer="1"/>
<smd name="2" x="3.1" y="0" dx="1" dy="3.2" layer="1"/>
</package>
<package name="R6332W" urn="urn:adsk.eagle:footprint:23064/1" library_version="3">
<smd name="1" x="-3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
<smd name="2" x="3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
</package>
<package name="M0805" urn="urn:adsk.eagle:footprint:23065/1" library_version="3">
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="M1206" urn="urn:adsk.eagle:footprint:23066/1" library_version="3">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
</package>
<package name="M1406" urn="urn:adsk.eagle:footprint:23067/1" library_version="3">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
<package name="M2012" urn="urn:adsk.eagle:footprint:23068/1" library_version="3">
</package>
<package name="M2309" urn="urn:adsk.eagle:footprint:23069/1" library_version="3">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
</package>
<package name="M3216" urn="urn:adsk.eagle:footprint:23070/1" library_version="3">
</package>
<package name="M3516" urn="urn:adsk.eagle:footprint:23071/1" library_version="3">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M5923" urn="urn:adsk.eagle:footprint:23072/1" library_version="3">
</package>
<package name="0204/5" urn="urn:adsk.eagle:footprint:22991/1" library_version="3">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0204/7" urn="urn:adsk.eagle:footprint:22998/1" library_version="3">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0204V" urn="urn:adsk.eagle:footprint:22999/1" library_version="3">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10" urn="urn:adsk.eagle:footprint:22992/1" library_version="3">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12" urn="urn:adsk.eagle:footprint:22993/1" library_version="3">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/15" urn="urn:adsk.eagle:footprint:22997/1" library_version="3">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V" urn="urn:adsk.eagle:footprint:22994/1" library_version="3">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V" urn="urn:adsk.eagle:footprint:22995/1" library_version="3">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7" urn="urn:adsk.eagle:footprint:22996/1" library_version="3">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0309/10" urn="urn:adsk.eagle:footprint:23073/1" library_version="3">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
</package>
<package name="0309/12" urn="urn:adsk.eagle:footprint:23074/1" library_version="3">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="0309V" urn="urn:adsk.eagle:footprint:23075/1" library_version="3">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="0411/12" urn="urn:adsk.eagle:footprint:23076/1" library_version="3">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="0411/15" urn="urn:adsk.eagle:footprint:23077/1" library_version="3">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0411V" urn="urn:adsk.eagle:footprint:23078/1" library_version="3">
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="0414/15" urn="urn:adsk.eagle:footprint:23079/1" library_version="3">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
</package>
<package name="0414V" urn="urn:adsk.eagle:footprint:23080/1" library_version="3">
type 0414, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
</package>
<package name="0617/17" urn="urn:adsk.eagle:footprint:23081/1" library_version="3">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="0617/22" urn="urn:adsk.eagle:footprint:23082/1" library_version="3">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
<package name="0617V" urn="urn:adsk.eagle:footprint:23083/1" library_version="3">
type 0617, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="0922/22" urn="urn:adsk.eagle:footprint:23084/1" library_version="3">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="P0613V" urn="urn:adsk.eagle:footprint:23085/1" library_version="3">
type 0613, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="P0613/15" urn="urn:adsk.eagle:footprint:23086/1" library_version="3">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="P0817/22" urn="urn:adsk.eagle:footprint:23087/1" library_version="3">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
</package>
<package name="P0817V" urn="urn:adsk.eagle:footprint:23088/1" library_version="3">
type 0817, grid 6.35 mm</description>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
</package>
<package name="V234/12" urn="urn:adsk.eagle:footprint:23089/1" library_version="3">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
</package>
<package name="V235/17" urn="urn:adsk.eagle:footprint:23090/1" library_version="3">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="V526-0" urn="urn:adsk.eagle:footprint:23091/1" library_version="3">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102R" urn="urn:adsk.eagle:footprint:23092/1" library_version="3">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102W" urn="urn:adsk.eagle:footprint:23093/1" library_version="3">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0204R" urn="urn:adsk.eagle:footprint:23094/1" library_version="3">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="0.938" y1="0.6" x2="-0.938" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.938" y1="-0.6" x2="0.938" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0204W" urn="urn:adsk.eagle:footprint:23095/1" library_version="3">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="0.684" y1="0.6" x2="-0.684" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.684" y1="-0.6" x2="0.684" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0207R" urn="urn:adsk.eagle:footprint:23096/1" library_version="3">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="1.2125" y1="1" x2="-1.2125" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.2125" y1="-1" x2="1.2125" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0207W" urn="urn:adsk.eagle:footprint:23097/1" library_version="3">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="1.149" y1="1" x2="-1.149" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.149" y1="-1" x2="1.149" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="0922V" urn="urn:adsk.eagle:footprint:23098/1" library_version="3">
type 0922, grid 7.5 mm</description>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="RDH/15" urn="urn:adsk.eagle:footprint:23099/1" library_version="3">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="MINI_MELF-0102AX" urn="urn:adsk.eagle:footprint:23100/1" library_version="3">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<hole x="0" y="0" drill="1.3"/>
</package>
<package name="R0201" urn="urn:adsk.eagle:footprint:23101/1" library_version="3">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; chip&lt;p&gt;
Source: http://www.vishay.com/docs/20008/dcrcw.pdf</description>
<smd name="1" x="-0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<smd name="2" x="0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="0.15" layer="21"/>
</package>
<package name="VTA52" urn="urn:adsk.eagle:footprint:23102/1" library_version="3">
<description>&lt;b&gt;Bulk Metal® Foil Technology&lt;/b&gt;, Tubular Axial Lead Resistors, Meets or Exceeds MIL-R-39005 Requirements&lt;p&gt;
MIL SIZE RBR52&lt;br&gt;
Source: VISHAY .. vta56.pdf</description>
<wire x1="-15.24" y1="0" x2="-13.97" y2="0" width="0.6096" layer="51"/>
<wire x1="12.6225" y1="0.025" x2="12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="4.725" x2="-12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="4.725" x2="-12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="0.025" x2="-12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="-4.65" x2="12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="-4.65" x2="12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="13.97" y1="0" x2="15.24" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-15.24" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="15.24" y="0" drill="1.1" shape="octagon"/>
<text x="-3.81" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-13.97" y1="-0.3048" x2="-12.5675" y2="0.3048" layer="21"/>
<rectangle x1="12.5675" y1="-0.3048" x2="13.97" y2="0.3048" layer="21"/>
</package>
<package name="VTA53" urn="urn:adsk.eagle:footprint:23103/1" library_version="3">
MIL SIZE RBR53&lt;br&gt;
<wire x1="-12.065" y1="0" x2="-10.795" y2="0" width="0.6096" layer="51"/>
<wire x1="9.8975" y1="0" x2="9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="4.7" x2="-9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="4.7" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-4.675" x2="9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-4.675" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="10.795" y1="0" x2="12.065" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-12.065" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="12.065" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-10.795" y1="-0.3048" x2="-9.8425" y2="0.3048" layer="21"/>
<rectangle x1="9.8425" y1="-0.3048" x2="10.795" y2="0.3048" layer="21"/>
</package>
<package name="VTA54" urn="urn:adsk.eagle:footprint:23104/1" library_version="3">
MIL SIZE RBR54&lt;br&gt;
<wire x1="9.8975" y1="0" x2="9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="3.3" x2="-9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="3.3" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-3.3" x2="9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-3.3" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<text x="-3.81" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="VTA55" urn="urn:adsk.eagle:footprint:23105/1" library_version="3">
MIL SIZE RBR55&lt;br&gt;
<wire x1="-8.255" y1="0" x2="-6.985" y2="0" width="0.6096" layer="51"/>
<wire x1="6.405" y1="0" x2="6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="3.3" x2="-6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="3.3" x2="-6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="0" x2="-6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="-3.3" x2="6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="-3.3" x2="6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="6.985" y1="0" x2="8.255" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-8.255" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="8.255" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-6.985" y1="-0.3048" x2="-6.35" y2="0.3048" layer="21"/>
<rectangle x1="6.35" y1="-0.3048" x2="6.985" y2="0.3048" layer="21"/>
</package>
<package name="VTA56" urn="urn:adsk.eagle:footprint:23106/1" library_version="3">
MIL SIZE RBR56&lt;br&gt;
<wire x1="4.5" y1="0" x2="4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="3.3" x2="-4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="3.3" x2="-4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="0" x2="-4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="-3.3" x2="4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="-3.3" x2="4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-5.08" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
<rectangle x1="4.445" y1="-0.3048" x2="5.08" y2="0.3048" layer="21"/>
</package>
<package name="VMTA55" urn="urn:adsk.eagle:footprint:23107/1" library_version="3">
MIL SIZE RNC55&lt;br&gt;
<wire x1="-5.08" y1="0" x2="-4.26" y2="0" width="0.6096" layer="51"/>
<wire x1="3.3375" y1="-1.45" x2="3.3375" y2="1.45" width="0.1524" layer="21"/>
<wire x1="3.3375" y1="1.45" x2="-3.3625" y2="1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="1.45" x2="-3.3625" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="-1.45" x2="3.3375" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="4.235" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.1" shape="octagon"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.26" y1="-0.3048" x2="-3.3075" y2="0.3048" layer="21"/>
<rectangle x1="3.2825" y1="-0.3048" x2="4.235" y2="0.3048" layer="21"/>
</package>
<package name="VMTB60" urn="urn:adsk.eagle:footprint:23108/1" library_version="3">
MIL SIZE RNC60&lt;br&gt;
<wire x1="-6.35" y1="0" x2="-5.585" y2="0" width="0.6096" layer="51"/>
<wire x1="4.6875" y1="-1.95" x2="4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="4.6875" y1="1.95" x2="-4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="1.95" x2="-4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="-1.95" x2="4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="5.585" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<text x="-4.445" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.585" y1="-0.3048" x2="-4.6325" y2="0.3048" layer="21"/>
<rectangle x1="4.6325" y1="-0.3048" x2="5.585" y2="0.3048" layer="21"/>
</package>
<package name="R4527" urn="urn:adsk.eagle:footprint:23109/1" library_version="3">
<description>&lt;b&gt;Package 4527&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/31059/wsrhigh.pdf</description>
<wire x1="-5.675" y1="-3.375" x2="5.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.65" y1="-3.375" x2="5.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.65" y1="3.375" x2="-5.675" y2="3.375" width="0.2032" layer="21"/>
<wire x1="-5.675" y1="3.375" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<smd name="1" x="-4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<smd name="2" x="4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.715" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.715" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0001" urn="urn:adsk.eagle:footprint:23110/1" library_version="3">
<description>&lt;b&gt;Wirewound Resistors, Precision Power&lt;/b&gt;&lt;p&gt;
Source: VISHAY wscwsn.pdf</description>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="-3.075" y1="-1.8" x2="3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.075" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="1.606" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="-1.606" x2="-3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="1.606" x2="3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="-1.606" width="0.2032" layer="21"/>
<smd name="1" x="-2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<smd name="2" x="2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<text x="-2.544" y="2.229" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.501" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0002" urn="urn:adsk.eagle:footprint:23111/1" library_version="3">
<wire x1="-5.55" y1="3.375" x2="-5.55" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.55" y1="-3.375" x2="5.55" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.55" y1="-3.375" x2="5.55" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.55" y1="3.375" x2="-5.55" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-4.575" y="0.025" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.65" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.65" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC01/2" urn="urn:adsk.eagle:footprint:23112/1" library_version="3">
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="-1.475" width="0.2032" layer="51"/>
<wire x1="-2.45" y1="-1.475" x2="2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="1.475" width="0.2032" layer="51"/>
<wire x1="2.45" y1="1.475" x2="-2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="1.106" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="-1.106" x2="-2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="1.106" x2="2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="-1.106" width="0.2032" layer="21"/>
<smd name="1" x="-2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<smd name="2" x="2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<text x="-2.544" y="1.904" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.176" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC2515" urn="urn:adsk.eagle:footprint:23113/1" library_version="3">
<wire x1="-3.075" y1="-1.8" x2="3.05" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.05" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="1.606" x2="3.05" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="-1.606" width="0.2032" layer="21"/>
<text x="-3.2" y="2.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.2" y="-3.4" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC4527" urn="urn:adsk.eagle:footprint:23114/1" library_version="3">
<wire x1="-5.675" y1="3.4" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.675" y1="-3.375" x2="5.675" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.675" y1="-3.375" x2="5.675" y2="3.4" width="0.2032" layer="51"/>
<wire x1="5.675" y1="3.4" x2="-5.675" y2="3.4" width="0.2032" layer="21"/>
<text x="-5.775" y="3.925" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.775" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC6927" urn="urn:adsk.eagle:footprint:23115/1" library_version="3">
<wire x1="-8.65" y1="3.375" x2="-8.65" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-8.65" y1="-3.375" x2="8.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="8.65" y1="-3.375" x2="8.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="8.65" y1="3.375" x2="-8.65" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-7.95" y="0.025" dx="3.94" dy="5.97" layer="1"/>
<smd name="2" x="7.95" y="0" dx="3.94" dy="5.97" layer="1"/>
<text x="-8.75" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.75" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1218" urn="urn:adsk.eagle:footprint:23116/1" library_version="3">
<description>&lt;b&gt;CRCW1218 Thick Film, Rectangular Chip Resistors&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com .. dcrcw.pdf</description>
<wire x1="-0.913" y1="-2.219" x2="0.939" y2="-2.219" width="0.1524" layer="51"/>
<wire x1="0.913" y1="2.219" x2="-0.939" y2="2.219" width="0.1524" layer="51"/>
<smd name="1" x="-1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<smd name="2" x="1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.3" x2="-0.9009" y2="2.3" layer="51"/>
<rectangle x1="0.9144" y1="-2.3" x2="1.6645" y2="2.3" layer="51"/>
</package>
<package name="1812X7R" urn="urn:adsk.eagle:footprint:23117/1" library_version="3">
<description>&lt;b&gt;Chip Monolithic Ceramic Capacitors&lt;/b&gt; Medium Voltage High Capacitance for General Use&lt;p&gt;
Source: http://www.murata.com .. GRM43DR72E224KW01.pdf</description>
<wire x1="-1.1" y1="1.5" x2="1.1" y2="1.5" width="0.2032" layer="51"/>
<wire x1="1.1" y1="-1.5" x2="-1.1" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="-0.6" y1="1.5" x2="0.6" y2="1.5" width="0.2032" layer="21"/>
<wire x1="0.6" y1="-1.5" x2="-0.6" y2="-1.5" width="0.2032" layer="21"/>
<smd name="1" x="-1.425" y="0" dx="0.8" dy="3.5" layer="1"/>
<smd name="2" x="1.425" y="0" dx="0.8" dy="3.5" layer="1" rot="R180"/>
<text x="-1.9456" y="1.9958" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.9456" y="-3.7738" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.4" y1="-1.6" x2="-1.1" y2="1.6" layer="51"/>
<rectangle x1="1.1" y1="-1.6" x2="1.4" y2="1.6" layer="51" rot="R180"/>
</package>
<package name="PRL1632" urn="urn:adsk.eagle:footprint:23118/1" library_version="3">
<description>&lt;b&gt;PRL1632 are realized as 1W for 3.2 × 1.6mm(1206)&lt;/b&gt;&lt;p&gt;
Source: http://www.mouser.com/ds/2/392/products_18-2245.pdf</description>
<wire x1="0.7275" y1="-1.5228" x2="-0.7277" y2="-1.5228" width="0.1524" layer="51"/>
<wire x1="0.7275" y1="1.5228" x2="-0.7152" y2="1.5228" width="0.1524" layer="51"/>
<smd name="2" x="0.822" y="0" dx="1" dy="3.2" layer="1"/>
<smd name="1" x="-0.822" y="0" dx="1" dy="3.2" layer="1"/>
<text x="-1.4" y="1.8" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.4" y="-3" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-1.6" x2="-0.4" y2="1.6" layer="51"/>
<rectangle x1="0.4" y1="-1.6" x2="0.8" y2="1.6" layer="51"/>
</package>
<package name="R01005" urn="urn:adsk.eagle:footprint:23119/1" library_version="3">
<smd name="1" x="-0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<smd name="2" x="0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<text x="-0.4" y="0.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.4" y="-1.6" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2" y1="-0.1" x2="-0.075" y2="0.1" layer="51"/>
<rectangle x1="0.075" y1="-0.1" x2="0.2" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="0.05" x2="0.15" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="-0.1" x2="0.15" y2="-0.05" layer="51"/>
</package>
<package name="E3,5-8" urn="urn:adsk.eagle:footprint:22857/1" library_version="3">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 3.5 mm, diameter 8 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="CT3216" urn="urn:adsk.eagle:footprint:22802/1" library_version="3">
<description>&lt;b&gt;TANTALUM CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.973" y1="1.483" x2="2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.483" x2="-2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.483" x2="-2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.483" x2="2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-1.651" y1="0.559" x2="-1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="1.651" y1="0.559" x2="1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="-1.535" y1="0.798" x2="-1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="-1.535" y1="-0.798" x2="1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="-0.798" x2="1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="0.798" x2="-1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="0" x2="-1.26" y2="0" width="0.2032" layer="51"/>
<wire x1="-0.97" y1="0.26" x2="-0.97" y2="-0.3" width="0.2032" layer="51"/>
<smd name="+" x="-1.4" y="0" dx="2" dy="1.2" layer="1"/>
<smd name="-" x="1.4" y="0" dx="2" dy="1.2" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="CT3528" urn="urn:adsk.eagle:footprint:22803/1" library_version="3">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-1.637" y1="-1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="-1.637" y2="-1.383" width="0.2032" layer="51"/>
<wire x1="1.778" y1="1.016" x2="1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-0.68" y1="0" x2="-1.31" y2="0" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.3" x2="-1" y2="-0.33" width="0.2032" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="2" dy="2.2" layer="1"/>
<smd name="-" x="1.5" y="0" dx="2" dy="2.2" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="CT6032" urn="urn:adsk.eagle:footprint:22804/1" library_version="3">
<wire x1="-4.473" y1="1.983" x2="4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.983" x2="-4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.983" x2="-4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.983" x2="4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.932" y1="-1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-3.073" y1="1.067" x2="-3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="-2.932" y2="-1.637" width="0.2032" layer="51"/>
<wire x1="3.073" y1="1.067" x2="3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="2.957" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-1.18" y1="0" x2="-2.45" y2="0" width="0.2032" layer="51"/>
<wire x1="-1.8" y1="0.63" x2="-1.8" y2="-0.64" width="0.2032" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="CT7343" urn="urn:adsk.eagle:footprint:22807/1" library_version="3">
<wire x1="-4.973" y1="2.483" x2="4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="-2.483" x2="-4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-4.973" y1="-2.483" x2="-4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="2.483" x2="4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-3.592" y1="-2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-3.734" y1="1.143" x2="-3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="-3.592" y2="-2.195" width="0.2032" layer="51"/>
<wire x1="3.734" y1="1.143" x2="3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="3.582" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-2.04" y1="0" x2="-3.09" y2="0" width="0.2032" layer="51"/>
<wire x1="-2.55" y1="0.52" x2="-2.55" y2="-0.52" width="0.2032" layer="51"/>
<smd name="+" x="-3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<smd name="-" x="3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
</package>
<package name="B45181A" urn="urn:adsk.eagle:footprint:22805/1" library_version="3">
body 5 x 5 mm, rectangle, grid 2.54 mm</description>
<wire x1="2.032" y1="2.286" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.905" x2="2.413" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-2.286" x2="2.032" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.6764" x2="-1.778" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-1.4478" y1="1.3716" x2="-2.1082" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.286" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.032" y1="2.286" x2="2.413" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.032" y1="-2.286" x2="2.413" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.905" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="B45181B" urn="urn:adsk.eagle:footprint:22806/1" library_version="3">
body 7.6 x 5 mm, rectangle, grid 5.08 mm</description>
<wire x1="3.302" y1="2.413" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="3.683" y1="2.032" x2="3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="3.302" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.413" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.302" y1="-2.413" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-2.54" y="0" drill="0.8128"/>
<pad name="-" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.921" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.191" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="21"/>
</package>
<package name="B45181C" urn="urn:adsk.eagle:footprint:22810/1" library_version="3">
body 12.7 x 7.6 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="3.683" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.302" x2="6.223" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.6764" x2="-4.318" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-3.9878" y1="1.3716" x2="-4.6482" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.2192" x2="-0.254" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.762" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.2192" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.683" x2="6.223" y2="3.302" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-3.683" x2="6.223" y2="-3.302" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-5.08" y="0" drill="0.9144"/>
<pad name="-" x="5.08" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.334" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="B45181D" urn="urn:adsk.eagle:footprint:22816/1" library_version="3">
body 12.5 x 12.5 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.223" y1="5.842" x2="6.223" y2="-5.842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="5.842" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.223" x2="6.223" y2="5.842" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-6.223" x2="6.223" y2="-5.842" width="0.1524" layer="21" curve="90"/>
<text x="-5.08" y="6.604" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TT2D4" urn="urn:adsk.eagle:footprint:22809/1" library_version="3">
diameter 4 mm, grid 2.54 mm</description>
<wire x1="-1.016" y1="0" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.143" x2="-1.143" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.397" x2="-0.889" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<pad name="-" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128"/>
<text x="2.159" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="51"/>
</package>
<package name="TT2D4L" urn="urn:adsk.eagle:footprint:22808/1" library_version="3">
<wire x1="2.159" y1="7.747" x2="2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.016" x2="1.524" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.651" x2="-1.524" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="1.016" x2="2.159" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.762" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.429" x2="-1.016" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="3.81" x2="-1.397" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="-2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="2.159" y2="7.747" width="0.1524" layer="21" curve="-180"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="1.905" y="1.778" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="TT2D5" urn="urn:adsk.eagle:footprint:22811/1" library_version="3">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-1.27" y1="1.016" x2="-1.27" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.397" x2="-1.651" y2="1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.762" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6" urn="urn:adsk.eagle:footprint:22814/1" library_version="3">
diameter 6 mm, grid 2.54 mm</description>
<wire x1="-1.778" y1="1.524" x2="-1.016" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.143" x2="-1.397" y2="1.905" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="2.921" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.254" y="-2.286" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6L" urn="urn:adsk.eagle:footprint:22812/1" library_version="3">
<wire x1="3.048" y1="10.033" x2="3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="10.033" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.651" x2="-2.413" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.413" y1="1.016" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="10.033" x2="3.048" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<wire x1="-1.143" y1="2.413" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.413" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.524" x2="0.0762" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="1.524" x2="0.0762" y2="3.302" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="3.302" x2="-0.254" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="3.302" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.762" y1="2.413" x2="1.27" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.794" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="21"/>
<text x="-3.429" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="0.381" y1="1.4732" x2="0.8128" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7L" urn="urn:adsk.eagle:footprint:22813/1" library_version="3">
diameter 7 mm, grid 2.54 mm</description>
<wire x1="3.556" y1="10.16" x2="3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.016" x2="2.921" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-2.921" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.016" x2="3.556" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.556" y1="10.16" x2="-3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="10.16" x2="3.556" y2="10.16" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.032" y1="2.794" x2="-2.032" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="3.175" x2="-1.651" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.413" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.413" x2="-0.508" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.524" x2="-0.1778" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.524" x2="-0.1778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.302" x2="-0.508" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.302" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<text x="-3.937" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.905" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.048" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.4732" x2="0.5588" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7" urn="urn:adsk.eagle:footprint:22815/1" library_version="3">
<wire x1="-2.286" y1="0" x2="-3.048" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.556" width="0.1524" layer="21"/>
<text x="3.302" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.127" y="-2.667" size="1.27" layer="21" ratio="10">TT</text>
</package>
<package name="TT5D10" urn="urn:adsk.eagle:footprint:22817/1" library_version="3">
diameter 10 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.127" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.27" x2="-0.127" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-1.397" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.143" x2="-1.905" y2="2.159" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<text x="4.191" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.794" y="1.143" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11" urn="urn:adsk.eagle:footprint:22818/1" library_version="3">
diameter 11 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="1.651" x2="-2.286" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.159" x2="-1.778" y2="1.143" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.588" width="0.1524" layer="21"/>
<text x="4.572" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.175" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11L" urn="urn:adsk.eagle:footprint:22819/1" library_version="3">
<wire x1="-5.08" y1="12.954" x2="-5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.016" x2="4.445" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-4.445" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="4.445" y1="1.016" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="0" width="0.762" layer="21"/>
<wire x1="1.524" y1="0" x2="1.27" y2="0" width="0.762" layer="51"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="0" width="0.762" layer="21"/>
<wire x1="-1.524" y1="0" x2="-1.27" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="12.954" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="4.318" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.937" x2="-1.397" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.921" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.921" x2="-0.508" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.032" x2="-0.1778" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="2.032" x2="-0.1778" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.81" x2="-0.508" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.921" x2="1.27" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="12.954" x2="5.08" y2="12.954" width="0.1524" layer="21" curve="-180"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-5.461" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.413" y="5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="4.572" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="21"/>
<rectangle x1="1.651" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-1.651" y2="0.381" layer="51"/>
<rectangle x1="0.127" y1="1.9812" x2="0.5588" y2="3.8608" layer="21"/>
</package>
<package name="TT5D6" urn="urn:adsk.eagle:footprint:22820/1" library_version="3">
diameter 6 mm, grid 5.08 mm</description>
<wire x1="-2.908" y1="0.9307" x2="2.921" y2="0.889" width="0.1524" layer="21" curve="-145.325311"/>
<wire x1="2.8966" y1="-0.9655" x2="2.921" y2="0.889" width="0.1524" layer="51" curve="35.361865"/>
<wire x1="-2.921" y1="-0.889" x2="-2.8966" y2="0.9655" width="0.1524" layer="51" curve="-35.361865"/>
<wire x1="-2.9403" y1="-0.8232" x2="2.9211" y2="-0.889" width="0.1524" layer="21" curve="147.4323"/>
<wire x1="-1.524" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.27" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.651" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<text x="2.921" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.508" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="21"/>
</package>
<package name="TT5D6L" urn="urn:adsk.eagle:footprint:22821/1" library_version="3">
<wire x1="-1.143" y1="2.54" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.54" x2="-0.508" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.651" x2="-0.1778" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.651" x2="-0.1778" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.429" x2="-0.508" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.429" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.921" x2="-1.905" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="3.302" x2="-1.524" y2="3.302" width="0.1524" layer="21"/>
<text x="-3.429" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.524" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.6002" x2="0.5588" y2="3.4798" layer="21"/>
</package>
<package name="TT5D7" urn="urn:adsk.eagle:footprint:22822/1" library_version="3">
diameter 7 mm, grid 5.08 mm</description>
<wire x1="-2.286" y1="1.524" x2="-1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="2.032" width="0.1524" layer="21"/>
<text x="3.302" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.667" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D7L" urn="urn:adsk.eagle:footprint:22823/1" library_version="3">
<wire x1="-2.159" y1="3.683" x2="-2.159" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.302" x2="-1.778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.667" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.667" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.778" x2="-0.1778" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.778" x2="-0.1778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.556" x2="-0.508" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.556" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.667" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<text x="-3.937" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.445" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.175" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.7272" x2="0.5588" y2="3.6068" layer="21"/>
</package>
<package name="TT5D9" urn="urn:adsk.eagle:footprint:22824/1" library_version="3">
diameter 9 mm, grid 5.08 mm</description>
<wire x1="-2.794" y1="1.397" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.905" x2="-3.302" y2="0.889" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<text x="3.81" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.159" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D9L" urn="urn:adsk.eagle:footprint:22825/1" library_version="3">
<wire x1="-4.572" y1="10.033" x2="-4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.016" x2="3.937" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.651" x2="-3.937" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="3.937" y1="1.016" x2="4.572" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="10.033" x2="4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.937" x2="-1.778" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.556" x2="-1.397" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.794" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.794" x2="-0.381" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.905" x2="-0.0508" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="1.905" x2="-0.0508" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="3.683" x2="-0.381" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="3.683" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="1.397" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="10.033" x2="4.572" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<text x="-4.953" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.064" y="1.778" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.254" y1="1.8542" x2="0.6858" y2="3.7338" layer="21"/>
</package>
<package name="ETR1" urn="urn:adsk.eagle:footprint:22826/1" library_version="3">
<wire x1="2.159" y1="2.54" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.54" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.794" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.889" x2="-2.794" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.889" x2="-2.032" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.9304" x2="-1.27" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="1.6256" x2="-1.6002" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.889" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<text x="-2.032" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR2" urn="urn:adsk.eagle:footprint:22827/1" library_version="3">
<wire x1="-3.302" y1="-2.159" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.159" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.159" x2="3.302" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.81" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.762" x2="-3.81" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-0.762" x2="-3.302" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.889" x2="-1.27" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.159" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.159" width="0.1524" layer="21"/>
<text x="-3.302" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.683" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR3" urn="urn:adsk.eagle:footprint:22828/1" library_version="3">
<wire x1="-3.302" y1="-2.54" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.54" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.54" x2="3.302" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.54" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.54" width="0.1524" layer="21"/>
<text x="-3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR4" urn="urn:adsk.eagle:footprint:22829/1" library_version="3">
<wire x1="-0.762" y1="-1.0922" x2="-0.254" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.0922" x2="-0.254" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.0922" x2="-0.762" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.0922" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.81" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="5.842" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.524" x2="-6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="51"/>
<wire x1="3.683" y1="0" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.9652" x2="-1.651" y2="0.3302" width="0.1524" layer="21"/>
<wire x1="-1.3208" y1="0.635" x2="-1.9558" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-3.81" x2="5.842" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="3.81" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="0.8128"/>
<pad name="-" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-5.842" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.762" y2="1.143" layer="21"/>
</package>
<package name="ETR5" urn="urn:adsk.eagle:footprint:22830/1" library_version="3">
<wire x1="-5.842" y1="-6.1722" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.1722" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-6.1722" x2="5.842" y2="-6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-6.604" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.4986" x2="-6.604" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.4986" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.4986" x2="-5.842" y2="1.4986" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="0" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="0" x2="-1.2954" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="1.524" x2="-0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-1.2954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="-1.524" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.2954" x2="-1.905" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="0.9652" x2="-2.2352" y2="0.9652" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-6.1722" x2="5.842" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="6.1722" width="0.1524" layer="21"/>
<text x="-5.842" y="6.477" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="-1.6002" x2="0.3302" y2="1.6002" layer="21"/>
</package>
<package name="P128-35" urn="urn:adsk.eagle:footprint:22831/1" library_version="3">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="1.778" y1="2.54" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="1.397" x2="1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.635" x2="1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.635" x2="-1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="2.667" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.397" x2="-1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.762" y1="3.556" x2="-0.762" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-3.556" x2="0.762" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.016" x2="2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.159" y1="1.016" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.508" x2="-2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="1.016" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-1.016" x2="-2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.667" y2="-0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-2.667" y1="-0.508" x2="-2.667" y2="0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-1.143" y1="1.9304" x2="-1.143" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="1.6256" x2="-1.4732" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-2.54" x2="-0.762" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="-3.556" x2="1.778" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="3.556" x2="1.778" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="2.54" x2="-0.762" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<pad name="+" x="-2.667" y="0" drill="0.9144"/>
<pad name="-" x="2.667" y="0" drill="0.9144" shape="octagon"/>
<text x="-1.651" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-40" urn="urn:adsk.eagle:footprint:22832/1" library_version="3">
<wire x1="2.032" y1="2.54" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.143" x2="2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.762" x2="2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-0.762" x2="2.032" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.762" x2="-2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="2.54" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.143" x2="-2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.762" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="-1.016" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.556" x2="1.016" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.016" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.016" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="2.032" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.016" y1="-3.556" x2="2.032" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="2.54" x2="-1.016" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.032" y1="-2.54" x2="-1.016" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<text x="-2.032" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-5.207" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-50" urn="urn:adsk.eagle:footprint:22833/1" library_version="3">
<wire x1="2.54" y1="3.048" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.524" y1="4.064" x2="-1.524" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-4.064" x2="1.524" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.635" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.143" x2="-2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.143" x2="-2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.1684" x2="-1.27" y2="0.5334" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="0.8636" x2="-1.6002" y2="0.8636" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.667" y2="-0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="2.667" y1="-0.635" x2="2.667" y2="0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="1.524" y1="4.064" x2="2.54" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="3.048" x2="-1.524" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-3.048" x2="-1.524" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-4.064" x2="2.54" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<text x="-2.413" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-60" urn="urn:adsk.eagle:footprint:22834/1" library_version="3">
<wire x1="3.048" y1="3.048" x2="3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.032" y1="4.064" x2="-2.032" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.064" x2="2.032" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="3.048" x2="-3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-4.064" x2="3.048" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="3.048" x2="-2.032" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.048" y1="-3.048" x2="-2.032" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="4.064" x2="3.048" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-2.921" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TAP5-45" urn="urn:adsk.eagle:footprint:22835/1" library_version="3">
diameter 4.5 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.635" x2="-0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.635" x2="-0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.381" x2="-1.143" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.635" x2="-1.397" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.635" x2="0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.508" x2="0.3302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-1.9144" y1="-1.2492" x2="1.9144" y2="-1.2492" width="0.1524" layer="21" curve="113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="21" curve="-113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="-1.9144" y2="-1.2492" width="0.1524" layer="51" curve="66.251163"/>
<wire x1="1.9144" y1="-1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="51" curve="66.251163"/>
<text x="2.286" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.286" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-1.905" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-50" urn="urn:adsk.eagle:footprint:22836/1" library_version="3">
diameter 5.0 mm, grid 5.08 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="-1.143" y1="0.635" x2="-1.143" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.889" x2="0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.889" x2="0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.889" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.762" x2="0.3302" y2="0.762" width="0.1524" layer="21"/>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-70" urn="urn:adsk.eagle:footprint:22837/1" library_version="3">
diameter 7.0 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0.508" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.651" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.3749" y1="-1.1199" x2="3.3749" y2="-1.1199" width="0.1524" layer="21" curve="143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="21" curve="-143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="-3.3749" y2="-1.1199" width="0.1524" layer="51" curve="36.714997"/>
<wire x1="3.3749" y1="-1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="51" curve="36.714997"/>
<text x="3.175" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.413" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-60" urn="urn:adsk.eagle:footprint:22838/1" library_version="3">
diameter 6.0 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="2.921" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0" y="-2.54" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-80" urn="urn:adsk.eagle:footprint:22839/1" library_version="3">
diameter 8.0 mm, grid 5.08 mm</description>
<circle x="0" y="0" radius="4.318" width="0.1524" layer="21"/>
<text x="3.81" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.032" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="E1,8-4" urn="urn:adsk.eagle:footprint:22840/1" library_version="3">
grid 1.8 mm, diameter 4 mm</description>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="1.397" x2="-0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.143" x2="-0.762" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="-" x="0.889" y="0" drill="0.7112" diameter="1.1684" shape="octagon"/>
<pad name="+" x="-0.889" y="0" drill="0.7112" diameter="1.1684"/>
<text x="2.159" y="-1.778" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="51"/>
</package>
<package name="E15-5" urn="urn:adsk.eagle:footprint:22841/1" library_version="3">
grid 15.24 mm, diameter 5 mm</description>
<wire x1="-4.064" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-2.667" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-1.27" x2="-2.667" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.143" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="0.889" x2="-3.556" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.54" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.191" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.413" x2="-5.08" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.286" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.413" x2="5.461" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.445" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.54" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.826" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.032" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.159" x2="-4.445" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.286" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.715" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.286" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.413" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-4.318" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-2.413" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-2.4892" x2="-4.191" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.4892" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.4892" x2="-5.461" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.4892" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.2352" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.159" x2="-4.572" y2="2.159" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="6.477" y2="0" width="0.508" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.477" y2="0" width="0.508" layer="51"/>
<pad name="+" x="-7.62" y="0" drill="0.8128" diameter="2.159"/>
<pad name="-" x="7.62" y="0" drill="0.8128" diameter="2.159" shape="octagon"/>
<text x="-5.461" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.461" y="-4.1402" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.286" y1="-1.27" x2="-1.778" y2="1.27" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-5.715" y2="0.254" layer="21"/>
<rectangle x1="5.715" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
</package>
<package name="E15-6" urn="urn:adsk.eagle:footprint:22842/1" library_version="3">
grid 15.24 mm, diameter 6 mm</description>
<wire x1="-5.715" y1="-2.921" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.175" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.191" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.048" x2="-5.08" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.921" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.048" x2="5.461" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.445" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.175" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.667" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.794" x2="-4.445" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.921" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.715" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.921" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.175" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.175" x2="-5.08" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-4.318" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-3.1242" x2="-4.191" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.1242" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.1242" x2="-5.461" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.1242" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.8702" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.794" x2="-4.572" y2="2.794" width="0.3048" layer="21"/>
<text x="-5.461" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.8542" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E15-9" urn="urn:adsk.eagle:footprint:22843/1" library_version="3">
grid 15.24 mm, diameter 9 mm</description>
<wire x1="-4.445" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.27" x2="-3.048" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.27" x2="-3.048" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.27" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="5.588" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-4.191" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.572" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.572" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="4.572" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.445" x2="-5.461" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-5.461" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="4.318" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-5.207" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.445" x2="5.842" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-4.826" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.572" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-5.207" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.064" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.191" x2="-4.826" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.318" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="6.096" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-4.318" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.572" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-4.445" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.572" x2="-5.461" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.318" x2="-4.699" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-4.445" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-4.5212" x2="-4.572" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.5212" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.5212" x2="-5.842" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.5212" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.2672" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-4.953" y2="4.191" width="0.3048" layer="21"/>
<text x="-5.842" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-1.9812" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.667" y1="-1.27" x2="-2.159" y2="1.27" layer="21"/>
<rectangle x1="6.096" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-6.096" y2="0.254" layer="21"/>
</package>
<package name="E2,5-4R" urn="urn:adsk.eagle:footprint:22844/1" library_version="3">
grid 2.54 mm, diameter 4 mm</description>
<wire x1="-0.127" y1="0" x2="0.0762" y2="0" width="0.6096" layer="21"/>
<wire x1="-2.794" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="21" curve="320.718856"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="51" curve="-39.281144"/>
<text x="0.762" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.762" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-5" urn="urn:adsk.eagle:footprint:22845/1" library_version="3">
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E2,5-6" urn="urn:adsk.eagle:footprint:22846/1" library_version="3">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-7" urn="urn:adsk.eagle:footprint:22847/1" library_version="3">
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5RE" urn="urn:adsk.eagle:footprint:22848/1" library_version="3">
grid 2.54 mm, diameter 4 mm,</description>
<wire x1="0.254" y1="1.143" x2="0.254" y2="-1.143" width="0.1524" layer="21" curve="286.260205"/>
<wire x1="0.254" y1="-1.143" x2="0.254" y2="1.143" width="0.1524" layer="51" curve="73.739795"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<text x="0.635" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-4" urn="urn:adsk.eagle:footprint:22849/1" library_version="3">
grid 2 mm, diameter 4 mm</description>
<wire x1="-0.762" y1="1.524" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.27" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.889" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.159" width="0.1524" layer="21"/>
<pad name="-" x="1.016" y="0" drill="0.8128" diameter="1.27" shape="octagon"/>
<pad name="+" x="-1.016" y="0" drill="0.8128" diameter="1.27"/>
<text x="2.159" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-5" urn="urn:adsk.eagle:footprint:22850/1" library_version="3">
grid 2.032 mm, diameter 5 mm</description>
<wire x1="-1.27" y1="1.778" x2="-0.762" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.524" x2="-1.016" y2="2.032" width="0.1524" layer="21"/>
<text x="2.54" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-10" urn="urn:adsk.eagle:footprint:22851/1" library_version="3">
grid 22.86 mm, diameter 10 mm</description>
<wire x1="-6.35" y1="5.08" x2="8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="5.08" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="5.08" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-7.62" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.318" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.953" x2="8.509" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.826" x2="8.636" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.953" x2="-8.001" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.826" x2="-7.874" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.572" x2="-6.858" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.445" x2="-6.858" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.699" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-5.08" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.62" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="-6.604" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.318" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.826" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.953" x2="-8.001" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-4.572" x2="-6.858" y2="-4.572" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.953" x2="8.509" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-4.445" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-5.08" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.826" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="5.08" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.699" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.524" x2="-4.572" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.524" x2="-4.572" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.524" x2="-5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.27" x2="-5.842" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0.889" x2="-5.461" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.524" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="9.779" y2="0" width="0.762" layer="51"/>
<wire x1="-11.43" y1="0" x2="-9.779" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-11.43" y="0" drill="1.016" diameter="3.1496"/>
<pad name="-" x="11.43" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<text x="-8.509" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.7686" y="-2.3622" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="1.524" layer="21"/>
<rectangle x1="-9.779" y1="-0.381" x2="-8.89" y2="0.381" layer="21"/>
<rectangle x1="8.89" y1="-0.381" x2="9.779" y2="0.381" layer="21"/>
</package>
<package name="E22-6" urn="urn:adsk.eagle:footprint:22852/1" library_version="3">
grid 22.86 mm, diameter 6 mm</description>
<wire x1="-6.35" y1="3.175" x2="8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.175" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.175" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-7.62" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.413" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.048" x2="8.509" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="2.921" x2="8.636" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="-8.001" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="2.921" x2="-7.874" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.667" x2="-6.858" y2="2.667" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.54" x2="-6.858" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-2.794" x2="-8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.175" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.62" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="-6.604" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.413" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-2.921" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.048" x2="-8.001" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-2.667" x2="-6.858" y2="-2.667" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-3.048" x2="8.509" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.54" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.175" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-2.921" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.175" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.794" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<text x="-8.509" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.4836" y="-5.2832" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-9" urn="urn:adsk.eagle:footprint:22853/1" library_version="3">
grid 22.86 mm, diameter 9 mm</description>
<wire x1="-6.35" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.445" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-7.62" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="3.683" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.318" x2="8.509" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.191" x2="8.636" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.318" x2="-8.001" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.191" x2="-7.874" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.937" x2="-6.858" y2="3.937" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.81" x2="-6.858" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.064" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.445" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="-6.604" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="3.683" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.191" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.318" x2="-8.001" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-3.937" x2="-6.858" y2="-3.937" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.318" x2="8.509" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-3.81" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.191" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.064" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<text x="-8.509" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-10" urn="urn:adsk.eagle:footprint:22854/1" library_version="3">
grid 3.5 mm, diameter 10 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="4.064" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E25-10" urn="urn:adsk.eagle:footprint:22855/1" library_version="3">
grid 25.4 mm, diameter 10 mm</description>
<wire x1="-10.16" y1="4.826" x2="-9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="5.08" x2="-9.017" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="5.08" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.08" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="5.08" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-5.08" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="-8.001" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.826" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.572" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.953" x2="9.906" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.953" x2="-9.017" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.763" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.699" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.35" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="1.27" x2="-7.112" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0.889" x2="-6.731" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.524" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0" x2="-6.35" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.826" x2="-10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.08" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.953" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.0292" x2="-9.017" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.0292" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.763" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.7752" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.874" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="-8.001" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.747" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.0292" x2="9.906" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.953" x2="10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.699" x2="-8.128" y2="4.699" width="0.3048" layer="21"/>
<wire x1="12.7" y1="0" x2="11.049" y2="0" width="0.762" layer="51"/>
<wire x1="-12.7" y1="0" x2="-11.049" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-12.7" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="12.7" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-9.906" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.0386" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="1.524" layer="21"/>
<rectangle x1="-11.049" y1="-0.381" x2="-10.16" y2="0.381" layer="21"/>
<rectangle x1="10.16" y1="-0.381" x2="11.049" y2="0.381" layer="21"/>
</package>
<package name="E25-9" urn="urn:adsk.eagle:footprint:22856/1" library_version="3">
grid 25.4 mm, diameter 9 mm</description>
<wire x1="-10.16" y1="4.191" x2="-9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="4.445" x2="-9.017" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="4.445" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.445" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="4.445" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-4.445" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="-8.001" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.191" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="3.937" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.318" x2="9.906" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.318" x2="-9.017" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.763" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.064" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.445" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.318" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.3942" x2="-9.017" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.3942" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.763" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.1402" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.874" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="-8.001" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.747" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.3942" x2="9.906" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.318" x2="10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.064" x2="-8.128" y2="4.064" width="0.3048" layer="21"/>
<text x="-9.779" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E30-10" urn="urn:adsk.eagle:footprint:22858/1" library_version="3">
grid 30.48 mm, diameter 10 mm</description>
<wire x1="12.7" y1="4.699" x2="12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="5.08" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-10.541" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.43" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-11.43" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="12.7" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="4.953" x2="-11.811" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="4.826" x2="-11.684" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.572" x2="-10.668" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.318" x2="-10.668" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="4.953" x2="12.319" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="4.826" x2="12.446" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-4.699" x2="-12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-5.08" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="-10.414" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-4.826" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-11.43" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.191" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-11.43" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-4.445" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.953" x2="12.319" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-4.953" x2="-11.811" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-4.572" x2="-10.668" y2="-4.572" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-4.699" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-5.08" x2="-10.16" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-4.826" x2="12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.7" y1="4.699" x2="12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.319" y1="5.08" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-1.524" x2="-7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.524" x2="-7.874" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="1.524" x2="-8.382" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="1.27" x2="-9.144" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0.889" x2="-8.763" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="1.524" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="0" x2="-8.382" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0" x2="13.462" y2="0" width="0.762" layer="51"/>
<wire x1="-15.24" y1="0" x2="-13.462" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-15.24" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="15.24" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-12.319" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.0706" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.366" y1="-1.524" x2="-6.858" y2="1.524" layer="21"/>
<rectangle x1="-13.462" y1="-0.381" x2="-12.7" y2="0.381" layer="21"/>
<rectangle x1="12.7" y1="-0.381" x2="13.462" y2="0.381" layer="21"/>
</package>
<package name="E30-12" urn="urn:adsk.eagle:footprint:22859/1" library_version="3">
grid 30.48 mm, diameter 12 mm</description>
<wire x1="12.7" y1="5.969" x2="12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.35" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-10.541" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.43" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-11.43" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="12.7" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.223" x2="-11.811" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="6.096" x2="-11.684" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.842" x2="-10.668" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.588" x2="-10.668" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="6.223" x2="12.319" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="6.096" x2="12.446" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-5.969" x2="-12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.35" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.35" x2="-10.414" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-6.096" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-11.43" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.461" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-11.43" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-5.715" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.223" x2="12.319" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-6.223" x2="-11.811" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-5.842" x2="-10.668" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-5.969" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-6.35" x2="-10.16" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-6.096" x2="12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.7" y1="5.969" x2="12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="12.319" y1="6.35" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<text x="-12.192" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E30-16" urn="urn:adsk.eagle:footprint:22860/1" library_version="3">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 30.48 mm, diameter 16 mm</description>
<wire x1="12.7" y1="7.747" x2="12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.128" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-10.541" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.43" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-11.43" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="12.7" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.001" x2="-11.811" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-11.684" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.62" x2="-10.668" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.366" x2="-10.668" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="8.001" x2="12.319" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="7.874" x2="12.446" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-7.62" x2="-12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-8.001" x2="-10.414" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-7.747" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-11.43" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.239" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-11.43" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-7.366" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-7.874" x2="12.319" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-7.874" x2="-11.811" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-7.493" x2="-10.668" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-7.62" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-8.001" x2="-10.16" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-7.747" x2="12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.7" y1="7.747" x2="12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="12.319" y1="8.128" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<text x="-12.319" y="8.382" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-12" urn="urn:adsk.eagle:footprint:22861/1" library_version="3">
grid 35.56 mm, diameter 12 mm</description>
<wire x1="15.24" y1="5.969" x2="15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.35" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-12.446" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.335" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-13.335" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="15.24" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.223" x2="-13.716" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="6.096" x2="-13.589" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.842" x2="-12.573" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.588" x2="-12.573" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="6.223" x2="14.859" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="6.096" x2="14.986" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-5.969" x2="-15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-6.35" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.35" x2="-12.319" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-6.096" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-13.335" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.461" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-13.335" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-5.715" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.223" x2="14.859" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-6.223" x2="-13.716" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-5.842" x2="-12.573" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-5.969" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-6.35" x2="-12.065" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-6.096" x2="14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.969" x2="14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="14.859" y1="6.35" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="-1.524" x2="-9.779" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-1.524" x2="-9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="1.524" x2="-10.287" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="1.27" x2="-11.049" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.889" x2="-10.668" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="1.524" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="0" x2="-10.287" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0" x2="14.097" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0" x2="16.002" y2="0" width="0.762" layer="51"/>
<wire x1="-17.78" y1="0" x2="-16.002" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-17.78" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="17.78" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-14.732" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.9756" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-9.271" y1="-1.524" x2="-8.763" y2="1.524" layer="21"/>
<rectangle x1="-16.129" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.129" y2="0.381" layer="21"/>
</package>
<package name="E35-14" urn="urn:adsk.eagle:footprint:22862/1" library_version="3">
grid 30.48 mm, diameter 14 mm</description>
<wire x1="15.24" y1="7.239" x2="15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.62" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-12.446" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.335" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-13.335" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="15.24" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.493" x2="-13.716" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="7.366" x2="-13.589" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.112" x2="-12.573" y2="7.112" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="6.858" x2="-12.573" y2="6.858" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="7.493" x2="14.859" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="7.366" x2="14.986" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.239" x2="-15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-7.62" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.62" x2="-12.319" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-7.366" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-13.335" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="6.731" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-13.335" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-6.985" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.493" x2="14.859" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-7.493" x2="-13.716" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.112" x2="-12.573" y2="-7.112" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.239" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-7.62" x2="-12.065" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-7.366" x2="14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.239" x2="14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="14.859" y1="7.62" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<text x="-14.859" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-16" urn="urn:adsk.eagle:footprint:22863/1" library_version="3">
<wire x1="15.24" y1="7.874" x2="15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.255" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-12.446" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.335" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-13.335" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="15.24" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.128" x2="-13.716" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="8.001" x2="-13.589" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.747" x2="-12.573" y2="7.747" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.493" x2="-12.573" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="8.128" x2="14.859" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="8.001" x2="14.986" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.874" x2="-15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-8.255" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.255" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-8.001" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-13.335" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.366" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-13.335" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-7.62" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.128" x2="14.859" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-8.128" x2="-13.716" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.747" x2="-12.573" y2="-7.747" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.874" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-8.001" x2="14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.874" x2="14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="14.859" y1="8.255" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<text x="-14.859" y="8.636" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-18" urn="urn:adsk.eagle:footprint:22864/1" library_version="3">
grid 30.48 mm, diameter 18 mm</description>
<wire x1="15.24" y1="9.779" x2="15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.16" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-12.446" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.335" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-13.335" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="15.24" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.033" x2="-13.716" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="9.906" x2="-13.589" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.652" x2="-12.573" y2="9.652" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.398" x2="-12.573" y2="9.398" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="10.033" x2="14.859" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="9.906" x2="14.986" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-9.779" x2="-15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-10.16" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.16" x2="-12.319" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-9.906" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-13.335" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.271" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-13.335" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-9.525" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.033" x2="14.859" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-10.033" x2="-13.716" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-9.652" x2="-12.573" y2="-9.652" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-9.779" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-10.16" x2="-12.065" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-9.906" x2="14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.24" y1="9.779" x2="14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="14.859" y1="10.16" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<text x="-14.859" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-16.002" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.002" y2="0.381" layer="21"/>
</package>
<package name="E45-16" urn="urn:adsk.eagle:footprint:22865/1" library_version="3">
grid 45.72 mm, diameter 16 mm</description>
<wire x1="-20.32" y1="7.747" x2="-19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.255" x2="-18.288" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.255" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-7.747" x2="-19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-18.288" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.255" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-16.51" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-17.78" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.128" x2="-17.78" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.129" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="-16.002" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.2042" x2="-18.288" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="-16.002" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-17.78" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.6962" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.2042" x2="19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.255" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.128" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="-16.002" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.255" x2="19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-17.78" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.62" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.239" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.747" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.128" x2="-18.288" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.128" x2="19.812" y2="8.128" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.255" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.747" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.048" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.524" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.524" x2="-3.556" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.27" x2="-4.318" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.524" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="19.05" y2="0" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="7.62" x2="-16.637" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="7.874" x2="-18.034" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="7.366" x2="-16.637" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="7.874" x2="20.066" y2="7.874" width="0.3048" layer="21"/>
<wire x1="22.86" y1="0" x2="20.955" y2="0" width="0.762" layer="51"/>
<wire x1="-22.86" y1="0" x2="-20.955" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-22.86" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="22.86" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-19.812" y="8.763" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.2446" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.54" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="20.32" y1="-0.381" x2="20.828" y2="0.381" layer="21"/>
<rectangle x1="-20.828" y1="-0.381" x2="-20.32" y2="0.381" layer="21"/>
</package>
<package name="E45-18" urn="urn:adsk.eagle:footprint:22866/1" library_version="3">
grid 45.72 mm, diameter 18 mm</description>
<wire x1="-20.32" y1="8.382" x2="-19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.89" x2="-18.288" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.89" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-8.382" x2="-19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-18.288" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.89" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-16.51" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-17.78" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.763" x2="-17.78" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.129" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="-16.002" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.8392" x2="-18.288" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="-16.002" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-17.78" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.3312" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.8392" x2="19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.89" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.763" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="-16.002" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.89" x2="19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-17.78" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.255" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.874" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="8.382" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.763" x2="-18.288" y2="8.763" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.763" x2="19.812" y2="8.763" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.89" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.382" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="8.255" x2="-16.637" y2="8.255" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="8.509" x2="-18.034" y2="8.509" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="8.001" x2="-16.637" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="8.509" x2="20.066" y2="8.509" width="0.3048" layer="21"/>
<text x="-19.558" y="9.271" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-21" urn="urn:adsk.eagle:footprint:22867/1" library_version="3">
grid 45.72 mm, diameter 21 mm</description>
<wire x1="-20.32" y1="10.287" x2="-19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.795" x2="-18.288" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="10.795" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.287" x2="-19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-18.288" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-10.795" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-16.51" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-17.78" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.668" x2="-17.78" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.129" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="-16.002" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.7442" x2="-18.288" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="-16.002" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-17.78" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.2362" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.7442" x2="19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-10.795" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.668" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="-16.002" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="10.795" x2="19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-17.78" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.16" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="9.779" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.287" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.668" x2="-18.288" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.668" x2="19.812" y2="10.668" width="0.3048" layer="21"/>
<wire x1="19.812" y1="10.795" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.287" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.16" x2="-16.637" y2="10.16" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.414" x2="-18.034" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="9.906" x2="-16.637" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.414" x2="20.066" y2="10.414" width="0.3048" layer="21"/>
<text x="-19.685" y="11.176" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-22" urn="urn:adsk.eagle:footprint:22868/1" library_version="3">
grid 45.72 mm, diameter 22 mm</description>
<wire x1="-20.32" y1="10.541" x2="-19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="11.049" x2="-18.288" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="11.049" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.541" x2="-19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-18.288" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-11.049" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-16.51" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-17.78" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.922" x2="-17.78" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.129" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="-16.002" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.9982" x2="-18.288" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="-16.002" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-17.78" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.4902" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.9982" x2="19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-11.049" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.922" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="-16.002" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="11.049" x2="19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-17.78" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.414" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.033" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.541" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.922" x2="-18.288" y2="10.922" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.922" x2="19.812" y2="10.922" width="0.3048" layer="21"/>
<wire x1="19.812" y1="11.049" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.541" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.414" x2="-16.637" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.668" x2="-18.034" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.668" x2="20.066" y2="10.668" width="0.3048" layer="21"/>
<text x="-19.685" y="11.43" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-25" urn="urn:adsk.eagle:footprint:22869/1" library_version="3">
grid 45.72 mm, diameter 25 mm</description>
<wire x1="-20.32" y1="12.192" x2="-19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.7" x2="-18.288" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="12.7" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-18.288" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-12.7" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-16.51" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-17.78" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-12.573" x2="-17.78" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.129" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="-16.002" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.6492" x2="-18.288" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="-16.002" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-17.78" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.1412" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.6492" x2="19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-12.7" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-12.573" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="-16.002" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="12.7" x2="19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-17.78" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.065" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="11.684" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="12.192" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.573" x2="-18.288" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="12.573" x2="19.812" y2="12.573" width="0.3048" layer="21"/>
<wire x1="19.812" y1="12.7" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="20.32" y1="12.192" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="12.065" x2="-16.637" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="12.319" x2="-18.034" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="11.811" x2="-16.637" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="12.319" x2="20.066" y2="12.319" width="0.3048" layer="21"/>
<text x="-19.558" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5-10,5" urn="urn:adsk.eagle:footprint:22870/1" library_version="3">
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="E5-13" urn="urn:adsk.eagle:footprint:22871/1" library_version="3">
grid 5.08 mm, diameter 13 mm</description>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-0.889" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.27" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.445" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="6.985" width="0.1524" layer="21"/>
<text x="6.3754" y="4.1148" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-3.937" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.889" y2="1.27" layer="21"/>
</package>
<package name="E5-4" urn="urn:adsk.eagle:footprint:22872/1" library_version="3">
grid 5.05 mm, diameter 4 mm</description>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="-1.397" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.905"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.905" shape="octagon"/>
<text x="2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="21"/>
</package>
<package name="E5-5" urn="urn:adsk.eagle:footprint:22873/1" library_version="3">
grid 5.08 mm, diameter 5 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-6" urn="urn:adsk.eagle:footprint:22874/1" library_version="3">
grid 5.08 mm, diameter 6 mm</description>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="3.048" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-8,5" urn="urn:adsk.eagle:footprint:22875/1" library_version="3">
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E50-25" urn="urn:adsk.eagle:footprint:22876/1" library_version="3">
grid 50 mm, diameter 25 mm</description>
<wire x1="22.225" y1="-12.192" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-12.7" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="21.717" y1="12.7" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="22.225" y1="12.192" x2="22.225" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.352" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="12.7" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="21.717" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="12.065" x2="-19.177" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="11.811" x2="-19.177" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="12.573" x2="-20.828" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="12.319" x2="-22.479" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-22.479" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-20.701" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.701" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.574" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="12.573" x2="21.717" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="12.319" x2="-18.669" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="-18.669" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="21.971" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.479" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.192" x2="-18.669" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-20.32" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="11.684" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-22.352" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-12.573" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-20.32" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.065" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-22.352" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.6492" x2="-20.828" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.1412" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.7" x2="-18.542" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.6492" x2="21.717" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-12.573" x2="21.717" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.524" x2="-5.588" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-1.524" x2="-5.588" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="1.524" x2="-6.096" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="1.27" x2="-6.858" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="0.889" x2="-6.477" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.524" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="0" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0" x2="20.955" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="24.765" y1="0" x2="22.86" y2="0" width="0.762" layer="51"/>
<wire x1="-25.4" y1="0" x2="-23.495" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-25.4" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-22.098" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.7846" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="-1.524" x2="-4.572" y2="1.524" layer="21"/>
<rectangle x1="22.225" y1="-0.381" x2="22.733" y2="0.381" layer="21"/>
<rectangle x1="-23.368" y1="-0.381" x2="-22.86" y2="0.381" layer="21"/>
</package>
<package name="E50-30" urn="urn:adsk.eagle:footprint:22877/1" library_version="3">
grid 50 mm, diameter 30 mm</description>
<wire x1="22.225" y1="-14.732" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-15.24" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="21.717" y1="15.24" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="22.225" y1="14.732" x2="22.225" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.352" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="15.24" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="21.717" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.32" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-20.32" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="14.605" x2="-19.177" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="14.351" x2="-19.177" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="15.113" x2="-20.828" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="14.859" x2="-22.479" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-22.479" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-20.701" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.701" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.574" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="15.113" x2="21.717" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="14.859" x2="-18.669" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="-18.669" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="21.971" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.479" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.732" x2="-18.669" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-20.32" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.224" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-22.352" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-15.113" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-20.32" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.605" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-22.352" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.1892" x2="-20.828" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-20.32" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.6812" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.24" x2="-18.542" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.1892" x2="21.717" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-15.113" x2="21.717" y2="-15.24" width="0.1524" layer="21"/>
<pad name="+" x="-25.4" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-21.971" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E55-25" urn="urn:adsk.eagle:footprint:22878/1" library_version="3">
grid 55 mm, diameter 25 mm</description>
<wire x1="-25.4" y1="12.192" x2="-24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.7" x2="-23.368" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="12.7" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-12.192" x2="-25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-23.368" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-12.7" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-21.59" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.86" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-12.573" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.209" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="-21.082" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.6492" x2="-23.368" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="-21.082" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-22.86" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.1412" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.6492" x2="24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-12.7" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-12.573" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="-21.082" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="12.7" x2="24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-22.86" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.065" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="11.684" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.573" x2="-23.368" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="12.573" x2="24.892" y2="12.573" width="0.3048" layer="21"/>
<wire x1="24.892" y1="12.7" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="25.4" y1="12.192" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="24.13" y2="0" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="12.065" x2="-21.717" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="12.319" x2="-23.114" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="11.811" x2="-21.717" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="12.319" x2="25.146" y2="12.319" width="0.3048" layer="21"/>
<wire x1="27.94" y1="0" x2="26.035" y2="0" width="0.762" layer="51"/>
<wire x1="-27.94" y1="0" x2="-26.035" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-27.94" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-24.638" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="25.4" y1="-0.381" x2="25.908" y2="0.381" layer="21"/>
<rectangle x1="-25.908" y1="-0.381" x2="-25.4" y2="0.381" layer="21"/>
</package>
<package name="E55-30" urn="urn:adsk.eagle:footprint:22879/1" library_version="3">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 55 mm, diameter 30 mm</description>
<wire x1="-25.4" y1="14.732" x2="-24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.24" x2="-23.368" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="15.24" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-14.732" x2="-25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-23.368" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-15.24" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-21.59" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.86" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-15.113" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.209" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="-21.082" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.1892" x2="-23.368" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="-21.082" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-22.86" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.6812" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.1892" x2="24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-15.24" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-15.113" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="-21.082" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="15.24" x2="24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-22.86" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.605" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.224" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.113" x2="-23.368" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="15.113" x2="24.892" y2="15.113" width="0.3048" layer="21"/>
<wire x1="24.892" y1="15.24" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="25.4" y1="14.732" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="14.605" x2="-21.717" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="14.859" x2="-23.114" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="14.351" x2="-21.717" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="14.859" x2="25.146" y2="14.859" width="0.3048" layer="21"/>
<pad name="+" x="-27.94" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-24.511" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5R" urn="urn:adsk.eagle:footprint:22880/1" library_version="3">
grid 5.08 mm, diameter 9 mm</description>
<wire x1="-0.889" y1="0" x2="0.9398" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.588" y1="0" x2="-4.572" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.508" x2="-5.08" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="1.143" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.016" y2="0" width="0.6096" layer="51"/>
<wire x1="1.778" y1="-1.143" x2="1.7821" y2="1.1275" width="0.1524" layer="21" curve="-330.552701"/>
<wire x1="1.7732" y1="1.1613" x2="1.7781" y2="-1.143" width="0.1524" layer="51" curve="-29.895306"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="2.54" shape="octagon"/>
<text x="1.651" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E7,5-16" urn="urn:adsk.eagle:footprint:22881/1" library_version="3">
grid 7.62 mm, diameter 16 mm</description>
<wire x1="0.635" y1="0" x2="2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.905" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.905" x2="-0.254" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.905" x2="-0.254" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.905" x2="-0.889" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-5.969" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.762" x2="-6.731" y2="0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="8.255" width="0.1524" layer="21"/>
<pad name="-" x="3.81" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<pad name="+" x="-3.81" y="0" drill="1.016" diameter="3.1496"/>
<text x="7.874" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.2926" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.905" x2="0.889" y2="1.905" layer="21"/>
</package>
<package name="E7,5-18" urn="urn:adsk.eagle:footprint:22882/1" library_version="3">
grid 7.62 mm, diameter 18 mm</description>
<circle x="0" y="0" radius="8.89" width="0.1524" layer="21"/>
<text x="8.001" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB20D" urn="urn:adsk.eagle:footprint:22883/1" library_version="3">
grid 10.16 mm, diameter 20 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="10.16" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="7.62" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="2.0066" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="2.0066" diameter="4.5974" shape="octagon"/>
<text x="7.8994" y="7.366" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
<package name="EB22,5D" urn="urn:adsk.eagle:footprint:22884/1" library_version="3">
grid 10.16 mm, diameter 22.5 mm</description>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<circle x="0" y="0" radius="11.303" width="0.1524" layer="21"/>
<text x="8.4074" y="8.509" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB25D" urn="urn:adsk.eagle:footprint:22885/1" library_version="3">
grid 10.16 mm, diameter 25 mm</description>
<circle x="0" y="0" radius="12.7" width="0.254" layer="21"/>
<text x="9.6774" y="9.525" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB30D" urn="urn:adsk.eagle:footprint:22886/1" library_version="3">
grid 10.16 mm, diameter 30 mm</description>
<circle x="0" y="0" radius="15.24" width="0.254" layer="21"/>
<circle x="0" y="0" radius="12.065" width="0.254" layer="21"/>
<text x="10.8204" y="11.938" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB35D" urn="urn:adsk.eagle:footprint:22887/1" library_version="3">
grid 10.16 mm, diameter 35 mm</description>
<wire x1="1.397" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<circle x="0" y="0" radius="17.78" width="0.254" layer="21"/>
<circle x="0" y="0" radius="13.97" width="0.254" layer="21"/>
<text x="12.954" y="13.462" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="085CS_1R" urn="urn:adsk.eagle:footprint:22888/1" library_version="3">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; reflow soldering&lt;p&gt;
SMD (Chip) Standard 085 CS&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="5.7" y1="-0.95" x2="5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="-0.7" x2="5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="0.7" x2="5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.7" y1="0.95" x2="5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="5.8" y1="-0.75" x2="5.8" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-5.7" y1="0.95" x2="-5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="0.7" x2="-5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="-0.7" x2="-5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="-0.95" x2="-5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.8" y1="0.75" x2="-5.8" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.15" y1="-1.85" x2="5.15" y2="1.85" width="0.2032" layer="51"/>
<wire x1="5.15" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-1.35" x2="3.3" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="5.05" y1="1.35" x2="3.3" y2="1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-7" y1="2.2" x2="-7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="7" y1="2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="2.2" x2="7" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="-2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-5.31" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.31" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="3.3" y1="-1" x2="5.65" y2="1" layer="51"/>
<rectangle x1="-5.65" y1="-1" x2="-3.3" y2="1" layer="51"/>
</package>
<package name="085CS_1W" urn="urn:adsk.eagle:footprint:22889/1" library_version="3">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; wave soldering&lt;p&gt;
<wire x1="5.15" y1="1.85" x2="3.2" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.2" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-5.15" y1="-1.85" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.2" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-8.6" y1="4" x2="-8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="8.6" y1="4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="4" x2="8.6" y2="4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="-4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<smd name="+" x="5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="085CS_1AR" urn="urn:adsk.eagle:footprint:22890/1" library_version="3">
<wire x1="4.2" y1="-0.95" x2="4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="-0.7" x2="4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.7" x2="4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.2" y1="0.95" x2="4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-0.75" x2="4.3" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="0.95" x2="-4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.7" x2="-4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="-0.7" x2="-4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-4.2" y1="-0.95" x2="-4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.3" y1="0.75" x2="-4.3" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="3.65" y1="-1.85" x2="3.65" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.65" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.85" x2="-3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-3.65" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.6" y1="-1.35" x2="1.8" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="3.55" y1="1.35" x2="1.8" y2="1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-5.5" y1="2.2" x2="-5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="5.5" y1="2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="2.2" x2="5.5" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="-2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-3.81" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.8" y1="-1" x2="4.15" y2="1" layer="51"/>
<rectangle x1="-4.15" y1="-1" x2="-1.8" y2="1" layer="51"/>
</package>
<package name="085CS_1AW" urn="urn:adsk.eagle:footprint:22891/1" library_version="3">
<wire x1="3.65" y1="1.85" x2="1.7" y2="1.85" width="0.2032" layer="51"/>
<wire x1="1.7" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="-1.85" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.7" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-6.9" y1="4.1" x2="-6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="6.9" y1="4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="4.1" x2="6.9" y2="4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="-4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<smd name="+" x="4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="139CLL-2R" urn="urn:adsk.eagle:footprint:22892/1" library_version="3">
SMD (Chip) Long Life 139 CLL&lt;p&gt;
<wire x1="-8.1" y1="3.9" x2="-8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-3.9" x2="8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-3.9" x2="8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="3.9" x2="-8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="7.15" y1="-0.6" x2="6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="-0.85" x2="6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="0.85" x2="7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="7.15" y1="0.6" x2="7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="0.6" x2="-6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="0.85" x2="-6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="-0.85" x2="-7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="-0.6" x2="-7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="6.4" y1="-3.05" x2="-6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-1.6" x2="-6.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.05" x2="6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="1.6" x2="6.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2" x2="4.25" y2="-2.95" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2" x2="4.25" y2="2.95" width="0.2032" layer="21"/>
<smd name="+" x="6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<smd name="-" x="-6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.5" y1="-1" x2="6.85" y2="1" layer="51"/>
<rectangle x1="-6.85" y1="-1" x2="-4.5" y2="1" layer="51"/>
</package>
<package name="139CLL-2W" urn="urn:adsk.eagle:footprint:22893/1" library_version="3">
<wire x1="-10.15" y1="3.9" x2="-10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-10.15" y1="-3.9" x2="10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="-3.9" x2="10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="3.9" x2="-10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="3.05" width="0.2032" layer="51"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="-3.05" width="0.2032" layer="51"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="51"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="51"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
</package>
<package name="139CLL-3R" urn="urn:adsk.eagle:footprint:22894/1" library_version="3">
<wire x1="-8.1" y1="4.6" x2="-8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-4.6" x2="8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-4.6" x2="8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="4.6" x2="-8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="6.4" y1="-3.75" x2="-6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.75" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.75" x2="6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.75" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2.7" x2="4.5" y2="-2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2.7" x2="4.25" y2="-3.65" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2.7" x2="4.5" y2="2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2.7" x2="4.25" y2="3.65" width="0.2032" layer="21"/>
</package>
<package name="139CLL-3W" urn="urn:adsk.eagle:footprint:22895/1" library_version="3">
<wire x1="-10.6" y1="6.4" x2="-10.6" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="-10.6" y1="-6.4" x2="9.2" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="-6.4" x2="9.2" y2="6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="6.4" x2="-10.6" y2="6.4" width="0.2032" layer="39"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
</package>
<package name="140CLH-0810" urn="urn:adsk.eagle:footprint:22896/1" library_version="3">
<description>&lt;b&gt;Aluminum electrolytic capacitors SMD (Chip)&lt;/b&gt;&lt;p&gt;
Long life base plate, High temperature 140 CLH&lt;p&gt;
<wire x1="-4.85" y1="4.2" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="4.85" y2="1.45" width="0.2032" layer="21"/>
<wire x1="4.85" y1="1.45" x2="4.85" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="4.85" y1="-1.45" x2="4.85" y2="-2.75" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-4.2" x2="-4.85" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-4.2" x2="-4.85" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-1.45" x2="-4.85" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-4.85" y1="1.45" x2="-4.85" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-2.75" x2="3.4" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.4" x2="3.65" y2="1.4" width="0.2032" layer="21" curve="-138.030204"/>
<wire x1="3.65" y1="1.4" x2="3.65" y2="-1.4" width="0.2032" layer="51" curve="-41.969796"/>
<wire x1="-3.65" y1="-1.4" x2="3.65" y2="-1.4" width="0.2032" layer="21" curve="138.030204"/>
<wire x1="-3.65" y1="-1.4" x2="-3.65" y2="1.4" width="0.2032" layer="51" curve="-41.969796"/>
<smd name="+" x="3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<text x="-5.38" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="0.635" y="-3.175" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="140CLH-1010" urn="urn:adsk.eagle:footprint:22897/1" library_version="3">
<wire x1="-5.8" y1="5.15" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="5.8" y2="1.45" width="0.2032" layer="21"/>
<wire x1="5.8" y1="1.45" x2="5.8" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="5.8" y1="-1.45" x2="5.8" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="4.35" y1="-5.15" x2="-5.8" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-5.15" x2="-5.8" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-1.45" x2="-5.8" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-5.8" y1="1.45" x2="-5.8" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="-3.7" x2="4.35" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-1.4" x2="4.7" y2="-1.4" width="0.2032" layer="21" curve="146.825323"/>
<wire x1="4.7" y1="-1.4" x2="4.7" y2="1.4" width="0.2032" layer="51" curve="33.174677"/>
<wire x1="-4.7" y1="1.4" x2="4.7" y2="1.4" width="0.2032" layer="21" curve="-146.825323"/>
<wire x1="-4.7" y1="1.4" x2="-4.7" y2="-1.4" width="0.2032" layer="51" curve="33.174677"/>
<smd name="+" x="4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<smd name="-" x="-4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<text x="-2.74" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.375" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="140CLH-1014" urn="urn:adsk.eagle:footprint:22898/1" library_version="3">
<text x="-2.69" y="1.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.225" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-0810" urn="urn:adsk.eagle:footprint:22899/1" library_version="3">
Long life base plate, very low impedance 150 CLZ&lt;p&gt;
<text x="-5.43" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
</package>
<package name="150CLZ-1010" urn="urn:adsk.eagle:footprint:22900/1" library_version="3">
<text x="-2.79" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.075" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-1014" urn="urn:adsk.eagle:footprint:22901/1" library_version="3">
<wire x1="-4.7" y1="-1.4" x2="-4.7" y2="1.4" width="0.2032" layer="51" curve="-33.174677"/>
<text x="-2.74" y="1.88" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.025" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0405" urn="urn:adsk.eagle:footprint:22902/1" library_version="3">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt;&lt;p&gt;
SMD (Chip) Long Life Vertical 153 CLV&lt;p&gt;
<wire x1="1.25" y1="-2.15" x2="-2.15" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-2.15" x2="-2.15" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-1.1" x2="-2.15" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="1.1" x2="-2.15" y2="2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="1.25" y2="2.15" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.25" x2="2.15" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.1" x2="2.15" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.05" x2="2.15" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.15" y1="-1.25" x2="1.25" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.15" x2="2.15" y2="1.25" width="0.2032" layer="21"/>
<wire x1="-1.65" y1="-0.95" x2="1.65" y2="-0.95" width="0.2032" layer="21" curve="120.136976"/>
<wire x1="-1.65" y1="-0.95" x2="-1.65" y2="0.95" width="0.2032" layer="51" curve="-59.863024"/>
<wire x1="-1.65" y1="0.95" x2="1.65" y2="0.95" width="0.2032" layer="21" curve="-120.136976"/>
<wire x1="1.65" y1="-0.95" x2="1.65" y2="0.95" width="0.2032" layer="51" curve="59.863024"/>
<smd name="+" x="1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<smd name="-" x="-1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<text x="-2.24" y="2.48" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.275" y="-3.735" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0505" urn="urn:adsk.eagle:footprint:22903/1" library_version="3">
<wire x1="1.75" y1="-2.65" x2="-2.65" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-2.65" x2="-2.65" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-1.1" x2="-2.65" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.65" y1="1.1" x2="-2.65" y2="2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.65" x2="1.75" y2="2.65" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.75" x2="2.65" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.1" x2="2.65" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="2.65" y1="-1.1" x2="2.65" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.75" x2="1.75" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.65" x2="2.65" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-0.95" x2="2.2" y2="-0.95" width="0.2032" layer="21" curve="133.28887"/>
<wire x1="-2.2" y1="-0.95" x2="-2.2" y2="0.95" width="0.2032" layer="51" curve="-46.71113"/>
<wire x1="-2.2" y1="0.95" x2="2.2" y2="0.95" width="0.2032" layer="21" curve="-133.28887"/>
<wire x1="2.2" y1="-0.95" x2="2.2" y2="0.95" width="0.2032" layer="51" curve="46.71113"/>
<smd name="+" x="2.2" y="0" dx="3" dy="1.6" layer="1"/>
<smd name="-" x="-2.2" y="0" dx="3" dy="1.6" layer="1"/>
<text x="-2.74" y="2.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.775" y="-4.235" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0605" urn="urn:adsk.eagle:footprint:22904/1" library_version="3">
<wire x1="2.4" y1="-3.3" x2="-3.3" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-3.3" x2="-3.3" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-1.1" x2="-3.3" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-3.3" y1="1.1" x2="-3.3" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="3.3" x2="2.4" y2="3.3" width="0.2032" layer="21"/>
<wire x1="3.3" y1="2.4" x2="3.3" y2="1.1" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.1" x2="3.3" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.1" x2="3.3" y2="-2.4" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-2.4" x2="2.4" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.3" x2="3.3" y2="2.4" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="-0.9" x2="2.95" y2="-0.95" width="0.2032" layer="21" curve="145.181395"/>
<wire x1="-2.95" y1="-0.9" x2="-2.95" y2="0.95" width="0.2032" layer="51" curve="-34.818605"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.9" width="0.2032" layer="21" curve="-145.181395"/>
<wire x1="2.95" y1="-0.95" x2="2.95" y2="0.9" width="0.2032" layer="51" curve="34.818605"/>
<smd name="+" x="2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="-" x="-2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.39" y="3.63" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.425" y="-4.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0807" urn="urn:adsk.eagle:footprint:22905/1" library_version="3">
<wire x1="3.3" y1="-4.2" x2="-4.2" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.1" x2="-4.2" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.1" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="4.2" x2="3.3" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.1" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.1" x2="4.2" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.1" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-3.3" x2="3.3" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="3.3" y1="4.2" x2="4.2" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="-1.05" x2="3.75" y2="-1.05" width="0.2032" layer="21" curve="148.008335"/>
<wire x1="-3.75" y1="-1.05" x2="-3.75" y2="1.05" width="0.2032" layer="51" curve="-31.284493"/>
<wire x1="-3.75" y1="1.05" x2="3.75" y2="1.05" width="0.2032" layer="21" curve="-148.008335"/>
<wire x1="3.75" y1="1.05" x2="3.75" y2="-1.05" width="0.2032" layer="51" curve="-31.284493"/>
<smd name="+" x="3.05" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="-" x="-3.05" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-4.29" y="4.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.325" y="-5.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0810" urn="urn:adsk.eagle:footprint:22906/1" library_version="3">
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.5" x2="-4.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.5" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.5" x2="4.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.5" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="3.65" y1="-1.4" x2="3.65" y2="1.4" width="0.2032" layer="51" curve="41.969796"/>
</package>
<package name="153CLV-1010" urn="urn:adsk.eagle:footprint:22907/1" library_version="3">
<wire x1="4.3" y1="-5.2" x2="-5.2" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-5.2" x2="-5.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-1.5" x2="-5.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-5.2" y1="1.5" x2="-5.2" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="5.2" x2="4.3" y2="5.2" width="0.2032" layer="21"/>
<wire x1="5.2" y1="4.3" x2="5.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="5.2" y1="1.5" x2="5.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="5.2" y1="-1.5" x2="5.2" y2="-4.3" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-4.3" x2="4.3" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="4.3" y1="5.2" x2="5.2" y2="4.3" width="0.2032" layer="21"/>
<wire x1="4.65" y1="-1.55" x2="4.65" y2="1.55" width="0.2032" layer="51" curve="36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="-4.65" y2="1.55" width="0.2032" layer="51" curve="-36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="4.65" y2="-1.55" width="0.2032" layer="21" curve="143.130102"/>
<wire x1="-4.65" y1="1.55" x2="4.65" y2="1.55" width="0.2032" layer="21" curve="-143.130102"/>
<smd name="+" x="4" y="0" dx="4" dy="2.5" layer="1"/>
<smd name="-" x="-4" y="0" dx="4" dy="2.5" layer="1"/>
<text x="-5.29" y="5.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.325" y="-6.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-1012" urn="urn:adsk.eagle:footprint:22908/1" library_version="3">
</package>
<package name="153CLV-1014" urn="urn:adsk.eagle:footprint:22909/1" library_version="3">
</package>
<package name="175TMP-0808" urn="urn:adsk.eagle:footprint:22910/1" library_version="3">
High Temperature solid electrolytic SMD 175 TMP&lt;p&gt;
<wire x1="3.2" y1="-4.1" x2="-4.1" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1.55" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-1.55" x2="-4.1" y2="1.55" width="0.2032" layer="51"/>
<wire x1="-4.1" y1="1.55" x2="-4.1" y2="4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.2" y2="4.1" width="0.2032" layer="21"/>
<wire x1="4.1" y1="3.2" x2="4.1" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.1" y1="1.5" x2="4.1" y2="-1.55" width="0.2032" layer="51"/>
<wire x1="4.1" y1="-1.55" x2="4.1" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-3.2" x2="3.2" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="3.2" y1="4.1" x2="4.1" y2="3.2" width="0.2032" layer="21"/>
<wire x1="-3.6" y1="-1.45" x2="3.6" y2="-1.45" width="0.2032" layer="21" curve="136.123039"/>
<wire x1="-3.6" y1="-1.45" x2="-3.6" y2="1.45" width="0.2032" layer="51" curve="-43.876961"/>
<wire x1="-3.6" y1="1.45" x2="3.6" y2="1.45" width="0.2032" layer="21" curve="-136.123039"/>
<wire x1="3.6" y1="1.45" x2="3.6" y2="-1.45" width="0.2032" layer="51" curve="-43.876961"/>
<smd name="+" x="3.5" y="0" dx="3" dy="2.5" layer="1"/>
<smd name="-" x="-3.5" y="0" dx="3" dy="2.5" layer="1"/>
</package>
<package name="175TMP-0810" urn="urn:adsk.eagle:footprint:22911/1" library_version="3">
<wire x1="3.6" y1="-1.45" x2="3.6" y2="1.45" width="0.2032" layer="51" curve="43.876961"/>
</package>
<package name="A/3216-18R" urn="urn:adsk.eagle:footprint:22912/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 reflow solder&lt;/b&gt;&lt;p&gt;KEMET S / EIA 3216-12</description>
<wire x1="-1.45" y1="0.6" x2="1.45" y2="0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.6" x2="1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.6" x2="-1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.6" x2="-1.45" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<smd name="-" x="-1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<text x="-1.95" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.325" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.475" y2="0.6" layer="51"/>
<rectangle x1="1.475" y1="-0.6" x2="1.6" y2="0.6" layer="51"/>
<rectangle x1="0.8" y1="-0.625" x2="1.1" y2="0.625" layer="51"/>
</package>
<package name="A/3216-18W" urn="urn:adsk.eagle:footprint:22913/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="B/3528-21R" urn="urn:adsk.eagle:footprint:22914/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 reflow solder&lt;/b&gt;&lt;p&gt;KEMET T / EIA 3528-12</description>
<wire x1="-1.6" y1="1.2" x2="1.6" y2="1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.2" x2="1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.2" x2="-1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.2" x2="-1.6" y2="1.2" width="0.1016" layer="51"/>
<smd name="+" x="1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<smd name="-" x="-1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<text x="-1.95" y="1.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.925" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-0.6" x2="-1.625" y2="0.6" layer="51"/>
<rectangle x1="1.625" y1="-0.6" x2="1.75" y2="0.6" layer="51"/>
<rectangle x1="0.95" y1="-1.225" x2="1.25" y2="1.225" layer="51"/>
</package>
<package name="B/3528-21W" urn="urn:adsk.eagle:footprint:22915/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="C/6032-28R" urn="urn:adsk.eagle:footprint:22916/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 reflow solder&lt;/b&gt;&lt;p&gt;KEMET U / EIA 6032-15</description>
<wire x1="-2.8" y1="1.55" x2="2.8" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="1.55" x2="2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-1.55" x2="-2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.8" y1="-1.55" x2="-2.8" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<smd name="-" x="-2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<text x="-3" y="1.825" size="1.27" layer="25">&gt;NAME</text>
<text x="-3" y="-3.05" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3" y1="-1.1" x2="-2.85" y2="1.1" layer="51"/>
<rectangle x1="2.85" y1="-1.1" x2="3" y2="1.1" layer="51"/>
<rectangle x1="1.95" y1="-1.575" x2="2.45" y2="1.575" layer="51"/>
</package>
<package name="C/6032-28W" urn="urn:adsk.eagle:footprint:22917/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 Wafe solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
<smd name="-" x="-2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
</package>
<package name="D/7343-31R" urn="urn:adsk.eagle:footprint:22918/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET D / EIA 7343-21&lt;/b&gt;&lt;p&gt;KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 reflow solder</description>
<wire x1="-3.45" y1="2.1" x2="3.45" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.1" x2="3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.1" x2="-3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.1" x2="-3.45" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<text x="-3.65" y="2.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.65" y="-3.575" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.5" y2="1.2" layer="51"/>
<rectangle x1="3.5" y1="-1.2" x2="3.65" y2="1.2" layer="51"/>
<rectangle x1="2.675" y1="-2.125" x2="3.15" y2="2.125" layer="51"/>
</package>
<package name="D/7343-31W" urn="urn:adsk.eagle:footprint:22919/1" library_version="3">
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Wafe solder</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
</package>
<package name="E/7260-38R" urn="urn:adsk.eagle:footprint:22920/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 reflow solder&lt;/b&gt;</description>
<wire x1="-3.45" y1="2.95" x2="3.45" y2="2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.95" x2="3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.95" x2="-3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.95" x2="-3.45" y2="2.95" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<text x="-4.45" y="3.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.45" y="-4.475" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-2.05" x2="-3.5" y2="2.05" layer="51"/>
<rectangle x1="3.5" y1="-2.05" x2="3.65" y2="2.05" layer="51"/>
<rectangle x1="2.675" y1="-2.975" x2="3.15" y2="2.975" layer="51"/>
</package>
<package name="E/7260-38W" urn="urn:adsk.eagle:footprint:22921/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
</package>
<package name="R/2012-12R" urn="urn:adsk.eagle:footprint:22922/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 reflow solder&lt;/b&gt;</description>
<wire x1="-0.85" y1="0.6" x2="0.85" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="0.6" x2="0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="-0.6" x2="-0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-0.85" y1="-0.6" x2="-0.85" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<smd name="-" x="-1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<rectangle x1="-1" y1="-0.45" x2="-0.875" y2="0.45" layer="51"/>
<rectangle x1="0.875" y1="-0.45" x2="1" y2="0.45" layer="51"/>
<rectangle x1="0.3" y1="-0.625" x2="0.5" y2="0.625" layer="51"/>
</package>
<package name="R/2012-12W" urn="urn:adsk.eagle:footprint:22923/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
<smd name="-" x="-1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
</package>
<package name="PANASONIC_A" urn="urn:adsk.eagle:footprint:22924/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package A&lt;/b&gt;</description>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="1.6" x2="1.6" y2="0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="0.8" x2="1.6" y2="-0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-0.8" x2="0.8" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="0.95" x2="1.1" y2="0.95" width="0.1016" layer="21" curve="-98.369832"/>
<wire x1="-1.1" y1="-0.95" x2="1.15" y2="-0.9" width="0.1016" layer="21" curve="101.144396"/>
<wire x1="-1.6" y1="0.95" x2="-1.6" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="1.6" x2="1.5" y2="0.9" width="0.1016" layer="21"/>
<wire x1="1.5" y1="-0.9" x2="0.8" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="1.2" x2="-0.8" y2="-1.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.45" width="0.1016" layer="51"/>
<smd name="-" x="-1.3" y="0" dx="2" dy="1.5" layer="1"/>
<smd name="+" x="1.3" y="0" dx="2" dy="1.5" layer="1"/>
<text x="-1.65" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.65" y="-2.825" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.3" x2="-1.45" y2="0.3" layer="51"/>
<rectangle x1="1.45" y1="-0.3" x2="1.8" y2="0.3" layer="51"/>
<polygon width="0.1016" layer="51">
<vertex x="-0.85" y="1.1"/>
<vertex x="-1.15" y="0.8"/>
<vertex x="-1.35" y="0.3"/>
<vertex x="-1.35" y="-0.3"/>
<vertex x="-1.15" y="-0.8"/>
<vertex x="-0.85" y="-1.1"/>
<vertex x="-0.85" y="1.05"/>
</polygon>
</package>
<package name="PANASONIC_B" urn="urn:adsk.eagle:footprint:22925/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package B&lt;/b&gt;</description>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1" x2="2.1" y2="-1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.85" x2="1.75" y2="0.85" width="0.1016" layer="21" curve="-128.186984"/>
<wire x1="-1.75" y1="-0.85" x2="1.75" y2="-0.85" width="0.1016" layer="21" curve="128.186984"/>
<wire x1="-2.1" y1="0.85" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="-1.2" y1="1.5" x2="-1.2" y2="-1.5" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.95" width="0.1016" layer="51"/>
<smd name="-" x="-1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<smd name="+" x="1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<text x="-2.15" y="2.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.15" y="-3.275" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3" y1="-0.35" x2="-1.85" y2="0.35" layer="51"/>
<rectangle x1="1.9" y1="-0.35" x2="2.3" y2="0.35" layer="51"/>
<vertex x="-1.25" y="1.45"/>
<vertex x="-1.7" y="0.85"/>
<vertex x="-1.85" y="0.35"/>
<vertex x="-1.85" y="-0.4"/>
<vertex x="-1.7" y="-0.85"/>
<vertex x="-1.25" y="-1.4"/>
<vertex x="-1.25" y="1.4"/>
</polygon>
</package>
<package name="PANASONIC_C" urn="urn:adsk.eagle:footprint:22926/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package C&lt;/b&gt;</description>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="-1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="0.95" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="0.95" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-0.95" x2="2.6" y2="-1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.3" y1="0.85" x2="2.3" y2="0.85" width="0.1016" layer="21" curve="-139.434882"/>
<wire x1="-2.3" y1="-0.85" x2="2.3" y2="-0.85" width="0.1016" layer="21" curve="139.434882"/>
<wire x1="-1.55" y1="1.85" x2="-1.55" y2="-1.85" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="2.45" width="0.1016" layer="51"/>
<smd name="-" x="-2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<smd name="+" x="2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<text x="-2.6" y="2.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.65" y="-3.775" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.95" y1="-0.35" x2="-2.4" y2="0.35" layer="51"/>
<rectangle x1="2.4" y1="-0.35" x2="2.95" y2="0.35" layer="51"/>
<vertex x="-1.6" y="1.8"/>
<vertex x="-2" y="1.35"/>
<vertex x="-2.25" y="0.75"/>
<vertex x="-2.45" y="0.05"/>
<vertex x="-2.25" y="-0.75"/>
<vertex x="-1.95" y="-1.35"/>
<vertex x="-1.6" y="-1.8"/>
</polygon>
</package>
<package name="PANASONIC_D" urn="urn:adsk.eagle:footprint:22927/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D&lt;/b&gt;</description>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="0.95" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="0.95" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-0.95" x2="3.25" y2="-1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.95" width="0.1016" layer="21" curve="-144.299363"/>
<wire x1="-2.95" y1="-0.95" x2="2.95" y2="-0.95" width="0.1016" layer="21" curve="144.299363"/>
<wire x1="-2.1" y1="2.25" x2="-2.1" y2="-2.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="3.1" width="0.1016" layer="51"/>
<smd name="-" x="-2.4" y="0" dx="3" dy="1.4" layer="1"/>
<smd name="+" x="2.4" y="0" dx="3" dy="1.4" layer="1"/>
<text x="-1.75" y="1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-1.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-0.35" x2="-3.05" y2="0.35" layer="51"/>
<rectangle x1="3.05" y1="-0.35" x2="3.65" y2="0.35" layer="51"/>
<vertex x="-2.15" y="2.15"/>
<vertex x="-2.6" y="1.6"/>
<vertex x="-2.9" y="0.9"/>
<vertex x="-3.05" y="0"/>
<vertex x="-2.9" y="-0.95"/>
<vertex x="-2.55" y="-1.65"/>
<vertex x="-2.15" y="-2.15"/>
<vertex x="-2.15" y="2.1"/>
</polygon>
</package>
<package name="PANASONIC_E" urn="urn:adsk.eagle:footprint:22928/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package E&lt;/b&gt;</description>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="0.9" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="0.9" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-0.9" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-2.2" y1="3.25" x2="-2.2" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.9" x2="3.85" y2="0.9" width="0.1016" layer="21" curve="-153.684915"/>
<wire x1="-3.85" y1="-0.9" x2="3.85" y2="-0.9" width="0.1016" layer="21" curve="153.684915"/>
<circle x="0" y="0" radius="3.95" width="0.1016" layer="51"/>
<smd name="-" x="-3" y="0" dx="3.8" dy="1.4" layer="1"/>
<smd name="+" x="3" y="0" dx="3.8" dy="1.4" layer="1"/>
<text x="-1.8" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.8" y="-2.225" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5" y1="-0.35" x2="-3.8" y2="0.35" layer="51"/>
<rectangle x1="3.8" y1="-0.35" x2="4.5" y2="0.35" layer="51"/>
<vertex x="-2.25" y="3.2"/>
<vertex x="-3" y="2.5"/>
<vertex x="-3.6" y="1.5"/>
<vertex x="-3.85" y="0.65"/>
<vertex x="-3.85" y="-0.65"/>
<vertex x="-3.55" y="-1.6"/>
<vertex x="-2.95" y="-2.55"/>
<vertex x="-2.25" y="-3.2"/>
<vertex x="-2.25" y="3.15"/>
</polygon>
</package>
<package name="PANASONIC_F" urn="urn:adsk.eagle:footprint:22929/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package F&lt;/b&gt;</description>
<wire x1="-4.1" y1="1" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1" width="0.1016" layer="21"/>
<circle x="0" y="0" radius="4" width="0.001" layer="51"/>
<smd name="-" x="-3.55" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="+" x="3.55" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-1.75" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-2.375" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.85" y1="-0.45" x2="-3.9" y2="0.45" layer="51"/>
<rectangle x1="3.9" y1="-0.45" x2="4.85" y2="0.45" layer="51"/>
</polygon>
</package>
<package name="PANASONIC_G" urn="urn:adsk.eagle:footprint:22930/1" library_version="3">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G&lt;/b&gt;</description>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="-2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="1" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-1" x2="5.1" y2="-2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-1" width="0.1016" layer="21"/>
<wire x1="-4.85" y1="-1" x2="4.85" y2="-1" width="0.1016" layer="21" curve="156.699401"/>
<wire x1="-4.85" y1="1" x2="4.85" y2="1" width="0.1016" layer="21" curve="-156.699401"/>
<wire x1="-3.25" y1="3.7" x2="-3.25" y2="-3.65" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="4.95" width="0.1016" layer="51"/>
<smd name="-" x="-4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<smd name="+" x="4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<text x="-2.55" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.55" y="-2.675" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-5.85" y1="-0.45" x2="-4.9" y2="0.45" layer="51"/>
<rectangle x1="4.9" y1="-0.45" x2="5.85" y2="0.45" layer="51"/>
<vertex x="-3.3" y="3.6"/>
<vertex x="-4.05" y="2.75"/>
<vertex x="-4.65" y="1.55"/>
<vertex x="-4.85" y="0.45"/>
<vertex x="-4.85" y="-0.45"/>
<vertex x="-4.65" y="-1.55"/>
<vertex x="-4.05" y="-2.75"/>
<vertex x="-3.3" y="-3.6"/>
<vertex x="-3.3" y="3.55"/>
</polygon>
</package>
<package name="TT2D5L" urn="urn:adsk.eagle:footprint:22931/1" library_version="3">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-2.54" y1="8.89" x2="2.54" y2="8.89" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.54" y1="8.89" x2="2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="8.89" x2="-2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.651" x2="-1.905" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.905" y1="1.016" x2="2.54" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.54" x2="0.889" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="3.81" x2="-1.524" y2="3.048" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-2.921" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="2.286" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="E2,5-6E" urn="urn:adsk.eagle:footprint:22932/1" library_version="3">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.159" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.254" x2="-2.413" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="SMC_A" urn="urn:adsk.eagle:footprint:22933/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor &lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194, B 45 197, B 45 198&lt;br&gt;
Source: www.farnell.com/datasheets/247.pdf</description>
<wire x1="-1.45" y1="0.75" x2="1.45" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.75" x2="1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.75" x2="-1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.75" x2="-1.45" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1.6" y="0.975" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.4" y2="0.6" layer="51"/>
<rectangle x1="1.4" y1="-0.6" x2="1.6" y2="0.6" layer="51" rot="R180"/>
<rectangle x1="-1.45" y1="-0.75" x2="-0.8" y2="0.75" layer="51"/>
</package>
<package name="SMC_Z" urn="urn:adsk.eagle:footprint:22934/1" library_version="3">
<description>&lt;b&gt;Chip Capacitor&lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194&lt;br&gt;
<wire x1="-0.9" y1="0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="-0.9" y1="0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<smd name="+" x="-1" y="0" dx="1" dy="1.2" layer="1"/>
<smd name="-" x="1" y="0" dx="1" dy="1.2" layer="1"/>
<text x="-1" y="0.8" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.1" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.45" x2="-0.9" y2="0.45" layer="51"/>
<rectangle x1="0.9" y1="-0.45" x2="1" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-0.9" y1="-0.6" x2="-0.5" y2="0.6" layer="51"/>
</package>
<package name="SMC_P" urn="urn:adsk.eagle:footprint:22935/1" library_version="3">
<wire x1="-1.675" y1="0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.675" y1="0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.575" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.575" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.275" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.45" x2="-1.7" y2="0.45" layer="51"/>
<rectangle x1="1.7" y1="-0.45" x2="1.8" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-1.65" y1="-0.75" x2="-1.075" y2="0.725" layer="51"/>
</package>
<package name="SMC_B" urn="urn:adsk.eagle:footprint:22936/1" library_version="3">
<wire x1="-1.6" y1="1.35" x2="1.6" y2="1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.35" x2="1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.35" x2="-1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.35" x2="-1.6" y2="1.35" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="2.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="2.4" layer="1" rot="R180"/>
<text x="-1.905" y="1.905" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-1.1" x2="-1.55" y2="1.1" layer="51"/>
<rectangle x1="1.55" y1="-1.1" x2="1.75" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-1.6" y1="-1.35" x2="-0.95" y2="1.35" layer="51"/>
</package>
<package name="SMC_C" urn="urn:adsk.eagle:footprint:22937/1" library_version="3">
<wire x1="-2.85" y1="1.55" x2="2.85" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="1.55" x2="2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="-1.55" x2="-2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.85" y1="-1.55" x2="-2.85" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.4" dy="2.4" layer="1" rot="R180"/>
<rectangle x1="-3" y1="-1.1" x2="-2.8" y2="1.1" layer="51"/>
<rectangle x1="2.8" y1="-1.1" x2="3" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-2.85" y1="-1.55" x2="-1.9" y2="1.55" layer="51"/>
</package>
<package name="SMC_D" urn="urn:adsk.eagle:footprint:22938/1" library_version="3">
<wire x1="-3.5" y1="2.1" x2="3.5" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="2.1" x2="3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="-2.1" x2="-3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.5" y1="-2.1" x2="-3.5" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="-3.15" y="0" dx="2.4" dy="2.8" layer="1"/>
<smd name="-" x="3.15" y="0" dx="2.4" dy="2.8" layer="1" rot="R180"/>
<text x="-2.54" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.45" y2="1.2" layer="51"/>
<rectangle x1="3.45" y1="-1.2" x2="3.65" y2="1.2" layer="51" rot="R180"/>
<rectangle x1="-3.5" y1="-2.1" x2="-2.4" y2="2.1" layer="51"/>
</package>
<package name="SMC_E" urn="urn:adsk.eagle:footprint:22939/1" library_version="3">
</package>
<package name="SANYO-OSCON_9E" urn="urn:adsk.eagle:footprint:22940/1" library_version="3">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt;&lt;p&gt;
Source: e_os_all.pdf</description>
<wire x1="-3.55" y1="0" x2="-2.8" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9" width="0.2032" layer="21"/>
<pad name="-" x="-1.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.8" diameter="1.27"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SANYO-OSCON_9F" urn="urn:adsk.eagle:footprint:22941/1" library_version="3">
<wire x1="-4.55" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9" width="0.2032" layer="21"/>
<pad name="-" x="-2.5" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_A" urn="urn:adsk.eagle:footprint:22942/1" library_version="3">
<wire x1="-1.55" y1="-0.4" x2="-1.55" y2="0.4" width="0.4064" layer="51"/>
<circle x="0" y="0" radius="1.9" width="0.2032" layer="21"/>
<pad name="-" x="-1" y="0" drill="0.7" diameter="1.1"/>
<pad name="+" x="1" y="0" drill="0.7" diameter="1.1"/>
</package>
<package name="SANYO-OSCON_A'" urn="urn:adsk.eagle:footprint:22943/1" library_version="3">
<pad name="-" x="-0.75" y="0" drill="0.6" diameter="1"/>
<pad name="+" x="0.75" y="0" drill="0.6" diameter="1"/>
</package>
<package name="SANYO-OSCON_B" urn="urn:adsk.eagle:footprint:22944/1" library_version="3">
<wire x1="-1.9" y1="-0.4" x2="-1.9" y2="0.4" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="2.4" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_B'" urn="urn:adsk.eagle:footprint:22945/1" library_version="3">
</package>
<package name="SANYO-OSCON_C" urn="urn:adsk.eagle:footprint:22946/1" library_version="3">
<wire x1="-2.2" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.05" width="0.2032" layer="21"/>
<pad name="-" x="-1.25" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_C'" urn="urn:adsk.eagle:footprint:22947/1" library_version="3">
<circle x="0" y="0" radius="3.0504" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_C6" urn="urn:adsk.eagle:footprint:22948/1" library_version="3">
<pad name="-" x="-1.25" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.7" diameter="1.27"/>
<text x="-1.905" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="21">
<vertex x="-2.15" y="-2.1" curve="-41.039434"/>
<vertex x="-3" y="0.1" curve="-41.67409"/>
</polygon>
</package>
<package name="SANYO-OSCON_D" urn="urn:adsk.eagle:footprint:22949/1" library_version="3">
</package>
<package name="SANYO-OSCON_E" urn="urn:adsk.eagle:footprint:22950/1" library_version="3">
<wire x1="-3.5" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9003" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_E'" urn="urn:adsk.eagle:footprint:22951/1" library_version="3">
</package>
<package name="SANYO-OSCON_E1" urn="urn:adsk.eagle:footprint:22952/1" library_version="3">
<wire x1="-3.55" y1="0" x2="-2.75" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_E12" urn="urn:adsk.eagle:footprint:22953/1" library_version="3">
<vertex x="-2.65" y="2.7"/>
<vertex x="-2.65" y="-2.75" curve="-41.038922"/>
<vertex x="-3.8" y="0" curve="-41.675057"/>
</polygon>
</package>
<package name="SANYO-OSCON_E13" urn="urn:adsk.eagle:footprint:22954/1" library_version="3">
</polygon>
</package>
<package name="SANYO-OSCON_E7" urn="urn:adsk.eagle:footprint:22955/1" library_version="3">
<pad name="-" x="-1.75" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-2.65" y="2.8"/>
<vertex x="-2.65" y="-2.8" curve="-41.039891"/>
<vertex x="-3.85" y="0" curve="-41.675747"/>
</polygon>
</package>
<package name="SANYO-OSCON_E9" urn="urn:adsk.eagle:footprint:22956/1" library_version="3">
</polygon>
</package>
<package name="SANYO-OSCON_F" urn="urn:adsk.eagle:footprint:22957/1" library_version="3">
<wire x1="-4.5" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_F'" urn="urn:adsk.eagle:footprint:22958/1" library_version="3">
<wire x1="-3.55" y1="0" x2="-4.4" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9002" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_F0" urn="urn:adsk.eagle:footprint:22959/1" library_version="3">
</package>
<package name="SANYO-OSCON_F13" urn="urn:adsk.eagle:footprint:22960/1" library_version="3">
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.4" y="3.45"/>
<vertex x="-3.4" y="-3.4" curve="-41.039359"/>
<vertex x="-4.85" y="0" curve="-41.674636"/>
</polygon>
</package>
<package name="SANYO-OSCON_F8" urn="urn:adsk.eagle:footprint:22961/1" library_version="3">
<pad name="-" x="-2.5" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-3.6" y="3.2"/>
<vertex x="-3.6" y="-3.25" curve="-41.039474"/>
<vertex x="-4.85" y="0" curve="-41.675359"/>
</polygon>
</package>
<package name="SANYO-OSCON_G" urn="urn:adsk.eagle:footprint:22962/1" library_version="3">
<wire x1="-4.5" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="6.15" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_H" urn="urn:adsk.eagle:footprint:22963/1" library_version="3">
<wire x1="-7" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="7.9001" width="0.2032" layer="21"/>
<pad name="-" x="-3.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="3.75" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_SMD_A5" urn="urn:adsk.eagle:footprint:22964/1" library_version="3">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt; SMD type with conductive polymer electrolyte&lt;p&gt;
<wire x1="-2.05" y1="2.05" x2="1.25" y2="2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.05" x2="2.05" y2="1.25" width="0.2032" layer="21"/>
<wire x1="2.05" y1="1.25" x2="2.05" y2="-1.25" width="0.2032" layer="51"/>
<wire x1="2.05" y1="-1.25" x2="1.25" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="-2.05" x2="-2.05" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="-2.05" y1="-2.05" x2="-2.05" y2="2.05" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.85" width="0.2032" layer="51"/>
<text x="-1.905" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="51">
<vertex x="-1.2" y="-1.35"/>
<vertex x="-1.2" y="1.35" curve="44.759919"/>
<vertex x="-1.8" y="0" curve="39.027281"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_B6" urn="urn:adsk.eagle:footprint:22965/1" library_version="3">
<wire x1="-2.55" y1="2.55" x2="1.75" y2="2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.55" x2="2.55" y2="1.75" width="0.2032" layer="21"/>
<wire x1="2.55" y1="1.75" x2="2.55" y2="-1.75" width="0.2032" layer="51"/>
<wire x1="2.55" y1="-1.75" x2="1.75" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="-2.55" x2="-2.55" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="-2.55" y1="-2.55" x2="-2.55" y2="2.55" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.35" width="0.2032" layer="51"/>
<text x="-2.54" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-1.6" y="-1.65"/>
<vertex x="-1.6" y="1.65" curve="35.983944"/>
<vertex x="-2.3" y="0" curve="42.321615"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_C6" urn="urn:adsk.eagle:footprint:22966/1" library_version="3">
<wire x1="-3.2" y1="3.2" x2="2.4" y2="3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.2" x2="3.2" y2="2.4" width="0.2032" layer="21"/>
<wire x1="3.2" y1="2.4" x2="3.2" y2="-2.4" width="0.2032" layer="51"/>
<wire x1="3.2" y1="-2.4" x2="2.4" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="-3.2" x2="-3.2" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="-3.2" y1="-3.2" x2="-3.2" y2="3.2" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.95" width="0.2032" layer="51"/>
<smd name="-" x="-2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="+" x="2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.175" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="1.9"/>
<vertex x="-2.2" y="-1.9" curve="-39.18521"/>
<vertex x="-2.85" y="0" curve="-36.094684"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E12" urn="urn:adsk.eagle:footprint:22967/1" library_version="3">
<wire x1="-4.05" y1="4.05" x2="2.95" y2="4.05" width="0.2032" layer="21"/>
<wire x1="2.95" y1="4.05" x2="4.05" y2="2.95" width="0.2032" layer="21"/>
<wire x1="4.05" y1="2.95" x2="4.05" y2="-2.95" width="0.2032" layer="51"/>
<wire x1="2.95" y1="-4.05" x2="-4.05" y2="-4.05" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="-4.05" x2="-4.05" y2="4.05" width="0.2032" layer="51"/>
<wire x1="4.05" y1="-2.95" x2="2.95" y2="-4.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="3.85" width="0.2032" layer="51"/>
<smd name="-" x="-3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<smd name="+" x="3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<text x="-3.81" y="4.445" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.6" y="-2.75"/>
<vertex x="-2.6" y="2.75" curve="44.955417"/>
<vertex x="-3.85" y="0" curve="45.23973"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E7" urn="urn:adsk.eagle:footprint:22968/1" library_version="3">
<vertex x="-2.7" y="2.65"/>
<vertex x="-2.7" y="-2.65" curve="-47.290335"/>
<vertex x="-3.8" y="0" curve="-44.001093"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F12" urn="urn:adsk.eagle:footprint:22969/1" library_version="3">
<wire x1="-5.05" y1="5.05" x2="3.95" y2="5.05" width="0.2032" layer="21"/>
<wire x1="3.95" y1="5.05" x2="5.05" y2="3.95" width="0.2032" layer="21"/>
<wire x1="5.05" y1="3.95" x2="5.05" y2="-3.95" width="0.2032" layer="51"/>
<wire x1="3.95" y1="-5.05" x2="-5.05" y2="-5.05" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="-5.05" x2="-5.05" y2="5.05" width="0.2032" layer="51"/>
<wire x1="5.05" y1="-3.95" x2="3.95" y2="-5.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="4.8" width="0.2032" layer="51"/>
<smd name="-" x="-4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<smd name="+" x="4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<text x="-5.08" y="5.715" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="-3.65"/>
<vertex x="-3.05" y="3.65" curve="48.708973"/>
<vertex x="-4.75" y="0" curve="43.982679"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F8" urn="urn:adsk.eagle:footprint:22970/1" library_version="3">
<vertex x="-3.05" y="3.65" curve="41.376652"/>
<vertex x="-4.75" y="0" curve="43.010397"/>
</polygon>
</package>
<package name="UD-10X10_NICHICON" urn="urn:adsk.eagle:footprint:22971/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 10 x 10 mm&lt;p&gt;
Source: http://products.nichicon.co.jp/en/pdf/XJA043/e-ud.pdf</description>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="4.3" x2="5.1" y2="-4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-4.875" y1="0.85" x2="4.875" y2="0.85" width="0.1016" layer="21" curve="-160.259855"/>
<wire x1="-5.1" y1="0.875" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="4.875" y1="-0.85" x2="-4.875" y2="-0.85" width="0.1016" layer="21" curve="-160.259855"/>
<smd name="-" x="-3.95" y="0" dx="3.6" dy="1.3" layer="1"/>
<smd name="+" x="3.925" y="0" dx="3.6" dy="1.3" layer="1"/>
<text x="-5.08" y="5.715" size="1.016" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.35" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-4.05" y="2.8" curve="69.465624"/>
<vertex x="-4.05" y="-2.825"/>
</polygon>
</package>
<package name="UD-4X5,8_NICHICON" urn="urn:adsk.eagle:footprint:22972/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 4 x 5.8 mm&lt;p&gt;
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1.3" x2="2.1" y2="-1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.875" x2="1.75" y2="0.875" width="0.1016" layer="21" curve="-126.263848"/>
<wire x1="-2.1" y1="0.9" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="1.75" y1="-0.875" x2="-1.75" y2="-0.875" width="0.1016" layer="21" curve="-126.263848"/>
<circle x="0" y="0" radius="1.9527" width="0.1016" layer="51"/>
<smd name="-" x="-1.425" y="0" dx="2" dy="1" layer="1"/>
<smd name="+" x="1.425" y="0" dx="2" dy="1" layer="1"/>
<text x="-1.905" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-1.55" y="1.175" curve="72.275472"/>
<vertex x="-1.55" y="-1.175"/>
</polygon>
</package>
<package name="UD-5X5,8_NICHICON" urn="urn:adsk.eagle:footprint:22973/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 5 x 5.8 mm&lt;p&gt;
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.8" x2="2.6" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.3" y1="0.85" x2="2.275" y2="0.9" width="0.1016" layer="21" curve="-137.986421"/>
<wire x1="-2.6" y1="0.7" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="2.3" y1="-0.85" x2="-2.275" y2="-0.9" width="0.1016" layer="21" curve="-137.986421"/>
<circle x="0" y="0" radius="2.4501" width="0.1016" layer="51"/>
<smd name="-" x="-1.7" y="0" dx="2.3" dy="1" layer="1"/>
<smd name="+" x="1.725" y="0" dx="2.3" dy="1" layer="1"/>
<text x="-2.54" y="3.175" size="1.016" layer="25">&gt;NAME</text>
<vertex x="-1.55" y="1.875" curve="100.118878"/>
<vertex x="-1.55" y="-1.875"/>
</polygon>
</package>
<package name="UD-6,3X5,8_NICHICON" urn="urn:adsk.eagle:footprint:22974/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 5.8 mm&lt;p&gt;
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="2.45" x2="3.25" y2="-2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3" y1="0.775" x2="2.975" y2="0.85" width="0.1016" layer="21" curve="-149.753145"/>
<wire x1="-3.25" y1="0.8" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="3" y1="-0.775" x2="-2.975" y2="-0.85" width="0.1016" layer="21" curve="-149.753145"/>
<circle x="0" y="0" radius="3.1001" width="0.1016" layer="51"/>
<smd name="-" x="-2.35" y="0" dx="2.8" dy="1" layer="1"/>
<smd name="+" x="2.35" y="0" dx="2.8" dy="1" layer="1"/>
<text x="-3.175" y="3.81" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.175" y="-4.445" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="2.15" curve="88.581463"/>
<vertex x="-2.2" y="-2.15"/>
</polygon>
</package>
<package name="UD-6,3X7,7_NICHICON" urn="urn:adsk.eagle:footprint:22975/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 7.7 mm&lt;p&gt;
</polygon>
</package>
<package name="UD-8X10_NICHICON" urn="urn:adsk.eagle:footprint:22976/1" library_version="3">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 8 x 10 mm&lt;p&gt;
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="3.3" x2="4.1" y2="-3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.875" x2="3.85" y2="0.875" width="0.1016" layer="21" curve="-154.459402"/>
<wire x1="-4.1" y1="0.825" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="3.85" y1="-0.875" x2="-3.85" y2="-0.875" width="0.1016" layer="21" curve="-154.459402"/>
<smd name="-" x="-3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<smd name="+" x="3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<text x="-3.81" y="4.445" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="2.475" curve="77.887741"/>
<vertex x="-3.05" y="-2.475"/>
</polygon>
</package>
</packages>
<packages3d>
<package3d name="C1206" urn="urn:adsk.eagle:package:23618/2" type="model" library_version="3">
<description>CAPACITOR</description>
</package3d>
<package3d name="C0402" urn="urn:adsk.eagle:package:23626/1" type="box" library_version="3">
</package3d>
<package3d name="C0504" urn="urn:adsk.eagle:package:23624/1" type="box" library_version="3">
</package3d>
<package3d name="C0603" urn="urn:adsk.eagle:package:23616/2" type="model" library_version="3">
</package3d>
<package3d name="C0805" urn="urn:adsk.eagle:package:23617/2" type="model" library_version="3">
</package3d>
<package3d name="C1210" urn="urn:adsk.eagle:package:23619/2" type="model" library_version="3">
</package3d>
<package3d name="C1310" urn="urn:adsk.eagle:package:23620/1" type="box" library_version="3">
</package3d>
<package3d name="C1608" urn="urn:adsk.eagle:package:23621/2" type="model" library_version="3">
</package3d>
<package3d name="C1812" urn="urn:adsk.eagle:package:23622/2" type="model" library_version="3">
</package3d>
<package3d name="C1825" urn="urn:adsk.eagle:package:23623/2" type="model" library_version="3">
</package3d>
<package3d name="C2012" urn="urn:adsk.eagle:package:23625/2" type="model" library_version="3">
</package3d>
<package3d name="C3216" urn="urn:adsk.eagle:package:23628/2" type="model" library_version="3">
</package3d>
<package3d name="C3225" urn="urn:adsk.eagle:package:23655/2" type="model" library_version="3">
</package3d>
<package3d name="C4532" urn="urn:adsk.eagle:package:23627/2" type="model" library_version="3">
</package3d>
<package3d name="C4564" urn="urn:adsk.eagle:package:23648/2" type="model" library_version="3">
</package3d>
<package3d name="C025-024X044" urn="urn:adsk.eagle:package:23630/1" type="box" library_version="3">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
</package3d>
<package3d name="C025-025X050" urn="urn:adsk.eagle:package:23629/2" type="model" library_version="3">
grid 2.5 mm, outline 2.5 x 5 mm</description>
</package3d>
<package3d name="C025-030X050" urn="urn:adsk.eagle:package:23631/1" type="box" library_version="3">
grid 2.5 mm, outline 3 x 5 mm</description>
</package3d>
<package3d name="C025-040X050" urn="urn:adsk.eagle:package:23634/1" type="box" library_version="3">
grid 2.5 mm, outline 4 x 5 mm</description>
</package3d>
<package3d name="C025-050X050" urn="urn:adsk.eagle:package:23633/1" type="box" library_version="3">
grid 2.5 mm, outline 5 x 5 mm</description>
</package3d>
<package3d name="C025-060X050" urn="urn:adsk.eagle:package:23632/1" type="box" library_version="3">
grid 2.5 mm, outline 6 x 5 mm</description>
</package3d>
<package3d name="C025_050-024X070" urn="urn:adsk.eagle:package:23639/1" type="box" library_version="3">
grid 2.5 mm + 5 mm, outline 2.4 x 7 mm</description>
</package3d>
<package3d name="C025_050-025X075" urn="urn:adsk.eagle:package:23641/1" type="box" library_version="3">
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
</package3d>
<package3d name="C025_050-035X075" urn="urn:adsk.eagle:package:23651/1" type="box" library_version="3">
grid 2.5 + 5 mm, outline 3.5 x 7.5 mm</description>
</package3d>
<package3d name="C025_050-045X075" urn="urn:adsk.eagle:package:23635/1" type="box" library_version="3">
grid 2.5 + 5 mm, outline 4.5 x 7.5 mm</description>
</package3d>
<package3d name="C025_050-055X075" urn="urn:adsk.eagle:package:23636/1" type="box" library_version="3">
grid 2.5 + 5 mm, outline 5.5 x 7.5 mm</description>
</package3d>
<package3d name="C050-024X044" urn="urn:adsk.eagle:package:23643/1" type="box" library_version="3">
grid 5 mm, outline 2.4 x 4.4 mm</description>
</package3d>
<package3d name="C050-025X075" urn="urn:adsk.eagle:package:23637/1" type="box" library_version="3">
grid 5 mm, outline 2.5 x 7.5 mm</description>
</package3d>
<package3d name="C050-045X075" urn="urn:adsk.eagle:package:23638/1" type="box" library_version="3">
grid 5 mm, outline 4.5 x 7.5 mm</description>
</package3d>
<package3d name="C050-030X075" urn="urn:adsk.eagle:package:23640/1" type="box" library_version="3">
grid 5 mm, outline 3 x 7.5 mm</description>
</package3d>
<package3d name="C050-050X075" urn="urn:adsk.eagle:package:23665/1" type="box" library_version="3">
grid 5 mm, outline 5 x 7.5 mm</description>
</package3d>
<package3d name="C050-055X075" urn="urn:adsk.eagle:package:23642/1" type="box" library_version="3">
grid 5 mm, outline 5.5 x 7.5 mm</description>
</package3d>
<package3d name="C050-075X075" urn="urn:adsk.eagle:package:23645/1" type="box" library_version="3">
grid 5 mm, outline 7.5 x 7.5 mm</description>
</package3d>
<package3d name="C050H075X075" urn="urn:adsk.eagle:package:23644/1" type="box" library_version="3">
Horizontal, grid 5 mm, outline 7.5 x 7.5 mm</description>
</package3d>
<package3d name="C075-032X103" urn="urn:adsk.eagle:package:23646/1" type="box" library_version="3">
grid 7.5 mm, outline 3.2 x 10.3 mm</description>
</package3d>
<package3d name="C075-042X103" urn="urn:adsk.eagle:package:23656/1" type="box" library_version="3">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
</package3d>
<package3d name="C075-052X106" urn="urn:adsk.eagle:package:23650/1" type="box" library_version="3">
grid 7.5 mm, outline 5.2 x 10.6 mm</description>
</package3d>
<package3d name="C102-043X133" urn="urn:adsk.eagle:package:23647/1" type="box" library_version="3">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
</package3d>
<package3d name="C102-054X133" urn="urn:adsk.eagle:package:23649/1" type="box" library_version="3">
grid 10.2 mm, outline 5.4 x 13.3 mm</description>
</package3d>
<package3d name="C102-064X133" urn="urn:adsk.eagle:package:23653/1" type="box" library_version="3">
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
</package3d>
<package3d name="C102_152-062X184" urn="urn:adsk.eagle:package:23652/1" type="box" library_version="3">
grid 10.2 mm + 15.2 mm, outline 6.2 x 18.4 mm</description>
</package3d>
<package3d name="C150-054X183" urn="urn:adsk.eagle:package:23669/1" type="box" library_version="3">
grid 15 mm, outline 5.4 x 18.3 mm</description>
</package3d>
<package3d name="C150-064X183" urn="urn:adsk.eagle:package:23654/1" type="box" library_version="3">
grid 15 mm, outline 6.4 x 18.3 mm</description>
</package3d>
<package3d name="C150-072X183" urn="urn:adsk.eagle:package:23657/1" type="box" library_version="3">
grid 15 mm, outline 7.2 x 18.3 mm</description>
</package3d>
<package3d name="C150-084X183" urn="urn:adsk.eagle:package:23658/1" type="box" library_version="3">
grid 15 mm, outline 8.4 x 18.3 mm</description>
</package3d>
<package3d name="C150-091X182" urn="urn:adsk.eagle:package:23659/1" type="box" library_version="3">
grid 15 mm, outline 9.1 x 18.2 mm</description>
</package3d>
<package3d name="C225-062X268" urn="urn:adsk.eagle:package:23661/1" type="box" library_version="3">
grid 22.5 mm, outline 6.2 x 26.8 mm</description>
</package3d>
<package3d name="C225-074X268" urn="urn:adsk.eagle:package:23660/1" type="box" library_version="3">
grid 22.5 mm, outline 7.4 x 26.8 mm</description>
</package3d>
<package3d name="C225-087X268" urn="urn:adsk.eagle:package:23662/1" type="box" library_version="3">
grid 22.5 mm, outline 8.7 x 26.8 mm</description>
</package3d>
<package3d name="C225-108X268" urn="urn:adsk.eagle:package:23663/1" type="box" library_version="3">
grid 22.5 mm, outline 10.8 x 26.8 mm</description>
</package3d>
<package3d name="C225-113X268" urn="urn:adsk.eagle:package:23667/1" type="box" library_version="3">
grid 22.5 mm, outline 11.3 x 26.8 mm</description>
</package3d>
<package3d name="C275-093X316" urn="urn:adsk.eagle:package:23701/1" type="box" library_version="3">
grid 27.5 mm, outline 9.3 x 31.6 mm</description>
</package3d>
<package3d name="C275-113X316" urn="urn:adsk.eagle:package:23673/1" type="box" library_version="3">
grid 27.5 mm, outline 11.3 x 31.6 mm</description>
</package3d>
<package3d name="C275-134X316" urn="urn:adsk.eagle:package:23664/1" type="box" library_version="3">
grid 27.5 mm, outline 13.4 x 31.6 mm</description>
</package3d>
<package3d name="C275-205X316" urn="urn:adsk.eagle:package:23666/1" type="box" library_version="3">
grid 27.5 mm, outline 20.5 x 31.6 mm</description>
</package3d>
<package3d name="C325-137X374" urn="urn:adsk.eagle:package:23672/1" type="box" library_version="3">
grid 32.5 mm, outline 13.7 x 37.4 mm</description>
</package3d>
<package3d name="C325-162X374" urn="urn:adsk.eagle:package:23670/1" type="box" library_version="3">
grid 32.5 mm, outline 16.2 x 37.4 mm</description>
</package3d>
<package3d name="C325-182X374" urn="urn:adsk.eagle:package:23668/1" type="box" library_version="3">
grid 32.5 mm, outline 18.2 x 37.4 mm</description>
</package3d>
<package3d name="C375-192X418" urn="urn:adsk.eagle:package:23674/1" type="box" library_version="3">
grid 37.5 mm, outline 19.2 x 41.8 mm</description>
</package3d>
<package3d name="C375-203X418" urn="urn:adsk.eagle:package:23671/1" type="box" library_version="3">
grid 37.5 mm, outline 20.3 x 41.8 mm</description>
</package3d>
<package3d name="C050-035X075" urn="urn:adsk.eagle:package:23677/1" type="box" library_version="3">
grid 5 mm, outline 3.5 x 7.5 mm</description>
</package3d>
<package3d name="C375-155X418" urn="urn:adsk.eagle:package:23675/1" type="box" library_version="3">
grid 37.5 mm, outline 15.5 x 41.8 mm</description>
</package3d>
<package3d name="C075-063X106" urn="urn:adsk.eagle:package:23678/1" type="box" library_version="3">
grid 7.5 mm, outline 6.3 x 10.6 mm</description>
</package3d>
<package3d name="C275-154X316" urn="urn:adsk.eagle:package:23685/1" type="box" library_version="3">
grid 27.5 mm, outline 15.4 x 31.6 mm</description>
</package3d>
<package3d name="C275-173X316" urn="urn:adsk.eagle:package:23676/1" type="box" library_version="3">
grid 27.5 mm, outline 17.3 x 31.6 mm</description>
</package3d>
<package3d name="C0402K" urn="urn:adsk.eagle:package:23679/2" type="model" library_version="3">
<description>Ceramic Chip Capacitor KEMET 0204 reflow solder
Metric Code Size 1005</description>
</package3d>
<package3d name="C0603K" urn="urn:adsk.eagle:package:23680/2" type="model" library_version="3">
<description>Ceramic Chip Capacitor KEMET 0603 reflow solder
Metric Code Size 1608</description>
</package3d>
<package3d name="C0805K" urn="urn:adsk.eagle:package:23681/2" type="model" library_version="3">
<description>Ceramic Chip Capacitor KEMET 0805 reflow solder
Metric Code Size 2012</description>
</package3d>
<package3d name="C1206K" urn="urn:adsk.eagle:package:23682/2" type="model" library_version="3">
<description>Ceramic Chip Capacitor KEMET 1206 reflow solder
Metric Code Size 3216</description>
</package3d>
<package3d name="C1210K" urn="urn:adsk.eagle:package:23683/2" type="model" library_version="3">
<description>Ceramic Chip Capacitor KEMET 1210 reflow solder
Metric Code Size 3225</description>
</package3d>
<package3d name="C1812K" urn="urn:adsk.eagle:package:23686/2" type="model" library_version="3">
<description>Ceramic Chip Capacitor KEMET 1812 reflow solder
Metric Code Size 4532</description>
</package3d>
<package3d name="C1825K" urn="urn:adsk.eagle:package:23684/1" type="box" library_version="3">
<description>Ceramic Chip Capacitor KEMET 1825 reflow solder
Metric Code Size 4564</description>
</package3d>
<package3d name="C2220K" urn="urn:adsk.eagle:package:23687/2" type="model" library_version="3">
<description>Ceramic Chip Capacitor KEMET 2220 reflow solderMetric Code Size 5650</description>
</package3d>
<package3d name="C2225K" urn="urn:adsk.eagle:package:23692/2" type="model" library_version="3">
<description>Ceramic Chip Capacitor KEMET 2225 reflow solderMetric Code Size 5664</description>
</package3d>
<package3d name="HPC0201" urn="urn:adsk.eagle:package:23688/1" type="box" library_version="3">
<description>
Source: http://www.vishay.com/docs/10129/hpc0201a.pdf</description>
</package3d>
<package3d name="C0201" urn="urn:adsk.eagle:package:23690/2" type="model" library_version="3">
<description>Source: http://www.avxcorp.com/docs/catalogs/cx5r.pdf</description>
</package3d>
<package3d name="C1808" urn="urn:adsk.eagle:package:23689/2" type="model" library_version="3">
Source: AVX .. aphvc.pdf</description>
</package3d>
<package3d name="C3640" urn="urn:adsk.eagle:package:23693/2" type="model" library_version="3">
</package3d>
<package3d name="C01005" urn="urn:adsk.eagle:package:23691/1" type="box" library_version="3">
</package3d>
<package3d name="R1206" urn="urn:adsk.eagle:package:23540/2" type="model" library_version="3">
<description>RESISTOR</description>
</package3d>
<package3d name="R0402" urn="urn:adsk.eagle:package:23547/2" type="box" library_version="3">
<description>Chip RESISTOR 0402 EIA (1005 Metric)</description>
</package3d>
<package3d name="R0603" urn="urn:adsk.eagle:package:23555/2" type="model" library_version="3">
</package3d>
<package3d name="R0805" urn="urn:adsk.eagle:package:23553/2" type="model" library_version="3">
</package3d>
<package3d name="R0805W" urn="urn:adsk.eagle:package:23537/1" type="box" library_version="3">
<description>RESISTOR wave soldering</description>
</package3d>
<package3d name="R1206W" urn="urn:adsk.eagle:package:23539/1" type="box" library_version="3">
</package3d>
<package3d name="R1210" urn="urn:adsk.eagle:package:23554/2" type="model" library_version="3">
</package3d>
<package3d name="R1210W" urn="urn:adsk.eagle:package:23541/1" type="box" library_version="3">
</package3d>
<package3d name="R2010" urn="urn:adsk.eagle:package:23551/2" type="model" library_version="3">
</package3d>
<package3d name="R2010W" urn="urn:adsk.eagle:package:23542/1" type="box" library_version="3">
</package3d>
<package3d name="R2012" urn="urn:adsk.eagle:package:23543/2" type="model" library_version="3">
</package3d>
<package3d name="R2012W" urn="urn:adsk.eagle:package:23544/1" type="box" library_version="3">
</package3d>
<package3d name="R2512" urn="urn:adsk.eagle:package:23545/2" type="model" library_version="3">
</package3d>
<package3d name="R2512W" urn="urn:adsk.eagle:package:23565/1" type="box" library_version="3">
</package3d>
<package3d name="R3216" urn="urn:adsk.eagle:package:23557/2" type="model" library_version="3">
</package3d>
<package3d name="R3216W" urn="urn:adsk.eagle:package:23548/1" type="box" library_version="3">
</package3d>
<package3d name="R3225" urn="urn:adsk.eagle:package:23549/2" type="model" library_version="3">
</package3d>
<package3d name="R3225W" urn="urn:adsk.eagle:package:23550/1" type="box" library_version="3">
</package3d>
<package3d name="R5025" urn="urn:adsk.eagle:package:23552/2" type="model" library_version="3">
</package3d>
<package3d name="R5025W" urn="urn:adsk.eagle:package:23558/1" type="box" library_version="3">
</package3d>
<package3d name="R6332" urn="urn:adsk.eagle:package:23559/2" type="model" library_version="3">
Source: http://download.siliconexpert.com/pdfs/2005/02/24/Semi_Ap/2/VSH/Resistor/dcrcwfre.pdf</description>
</package3d>
<package3d name="R6332W" urn="urn:adsk.eagle:package:23560/1" type="box" library_version="3">
</package3d>
<package3d name="M0805" urn="urn:adsk.eagle:package:23556/1" type="box" library_version="3">
MELF 0.10 W</description>
</package3d>
<package3d name="M1206" urn="urn:adsk.eagle:package:23566/1" type="box" library_version="3">
MELF 0.25 W</description>
</package3d>
<package3d name="M1406" urn="urn:adsk.eagle:package:23569/1" type="box" library_version="3">
MELF 0.12 W</description>
</package3d>
<package3d name="M2012" urn="urn:adsk.eagle:package:23561/1" type="box" library_version="3">
</package3d>
<package3d name="M2309" urn="urn:adsk.eagle:package:23562/1" type="box" library_version="3">
</package3d>
<package3d name="M3216" urn="urn:adsk.eagle:package:23563/1" type="box" library_version="3">
</package3d>
<package3d name="M3516" urn="urn:adsk.eagle:package:23573/1" type="box" library_version="3">
</package3d>
<package3d name="M5923" urn="urn:adsk.eagle:package:23564/1" type="box" library_version="3">
</package3d>
<package3d name="0204/5" urn="urn:adsk.eagle:package:23488/1" type="box" library_version="3">
type 0204, grid 5 mm</description>
</package3d>
<package3d name="0204/7" urn="urn:adsk.eagle:package:23498/1" type="box" library_version="3">
type 0204, grid 7.5 mm</description>
</package3d>
<package3d name="0204V" urn="urn:adsk.eagle:package:23495/1" type="box" library_version="3">
type 0204, grid 2.5 mm</description>
</package3d>
<package3d name="0207/10" urn="urn:adsk.eagle:package:23491/1" type="box" library_version="3">
type 0207, grid 10 mm</description>
</package3d>
<package3d name="0207/12" urn="urn:adsk.eagle:package:23489/1" type="box" library_version="3">
type 0207, grid 12 mm</description>
</package3d>
<package3d name="0207/15" urn="urn:adsk.eagle:package:23492/1" type="box" library_version="3">
type 0207, grid 15mm</description>
</package3d>
<package3d name="0207/2V" urn="urn:adsk.eagle:package:23490/1" type="box" library_version="3">
type 0207, grid 2.5 mm</description>
</package3d>
<package3d name="0207/5V" urn="urn:adsk.eagle:package:23502/1" type="box" library_version="3">
type 0207, grid 5 mm</description>
</package3d>
<package3d name="0207/7" urn="urn:adsk.eagle:package:23493/1" type="box" library_version="3">
type 0207, grid 7.5 mm</description>
</package3d>
<package3d name="0309/10" urn="urn:adsk.eagle:package:23567/1" type="box" library_version="3">
type 0309, grid 10mm</description>
</package3d>
<package3d name="0309/12" urn="urn:adsk.eagle:package:23571/1" type="box" library_version="3">
type 0309, grid 12.5 mm</description>
</package3d>
<package3d name="0309V" urn="urn:adsk.eagle:package:23572/1" type="box" library_version="3">
type 0309, grid 2.5 mm</description>
</package3d>
<package3d name="0411/12" urn="urn:adsk.eagle:package:23578/1" type="box" library_version="3">
type 0411, grid 12.5 mm</description>
</package3d>
<package3d name="0411/15" urn="urn:adsk.eagle:package:23568/1" type="box" library_version="3">
type 0411, grid 15 mm</description>
</package3d>
<package3d name="0411V" urn="urn:adsk.eagle:package:23570/1" type="box" library_version="3">
type 0411, grid 3.81 mm</description>
</package3d>
<package3d name="0414/15" urn="urn:adsk.eagle:package:23579/1" type="box" library_version="3">
type 0414, grid 15 mm</description>
</package3d>
<package3d name="0414V" urn="urn:adsk.eagle:package:23574/1" type="box" library_version="3">
type 0414, grid 5 mm</description>
</package3d>
<package3d name="0617/17" urn="urn:adsk.eagle:package:23575/1" type="box" library_version="3">
type 0617, grid 17.5 mm</description>
</package3d>
<package3d name="0617/22" urn="urn:adsk.eagle:package:23577/1" type="box" library_version="3">
type 0617, grid 22.5 mm</description>
</package3d>
<package3d name="0617V" urn="urn:adsk.eagle:package:23576/1" type="box" library_version="3">
type 0617, grid 5 mm</description>
</package3d>
<package3d name="0922/22" urn="urn:adsk.eagle:package:23580/1" type="box" library_version="3">
type 0922, grid 22.5 mm</description>
</package3d>
<package3d name="P0613V" urn="urn:adsk.eagle:package:23582/1" type="box" library_version="3">
type 0613, grid 5 mm</description>
</package3d>
<package3d name="P0613/15" urn="urn:adsk.eagle:package:23581/1" type="box" library_version="3">
type 0613, grid 15 mm</description>
</package3d>
<package3d name="P0817/22" urn="urn:adsk.eagle:package:23583/1" type="box" library_version="3">
type 0817, grid 22.5 mm</description>
</package3d>
<package3d name="P0817V" urn="urn:adsk.eagle:package:23608/1" type="box" library_version="3">
type 0817, grid 6.35 mm</description>
</package3d>
<package3d name="V234/12" urn="urn:adsk.eagle:package:23592/1" type="box" library_version="3">
type V234, grid 12.5 mm</description>
</package3d>
<package3d name="V235/17" urn="urn:adsk.eagle:package:23586/1" type="box" library_version="3">
type V235, grid 17.78 mm</description>
</package3d>
<package3d name="V526-0" urn="urn:adsk.eagle:package:23590/1" type="box" library_version="3">
type V526-0, grid 2.5 mm</description>
</package3d>
<package3d name="MINI_MELF-0102R" urn="urn:adsk.eagle:package:23591/1" type="box" library_version="3">
<description>CECC Size RC2211 Reflow Soldering
source Beyschlag</description>
</package3d>
<package3d name="MINI_MELF-0102W" urn="urn:adsk.eagle:package:23588/1" type="box" library_version="3">
<description>CECC Size RC2211 Wave Soldering
</package3d>
<package3d name="MINI_MELF-0204R" urn="urn:adsk.eagle:package:23587/1" type="box" library_version="3">
<description>CECC Size RC3715 Reflow Soldering
</package3d>
<package3d name="MINI_MELF-0204W" urn="urn:adsk.eagle:package:23584/1" type="box" library_version="3">
<description>CECC Size RC3715 Wave Soldering
</package3d>
<package3d name="MINI_MELF-0207R" urn="urn:adsk.eagle:package:23585/1" type="box" library_version="3">
<description>CECC Size RC6123 Reflow Soldering
</package3d>
<package3d name="MINI_MELF-0207W" urn="urn:adsk.eagle:package:23597/1" type="box" library_version="3">
<description>CECC Size RC6123 Wave Soldering
</package3d>
<package3d name="0922V" urn="urn:adsk.eagle:package:23589/1" type="box" library_version="3">
type 0922, grid 7.5 mm</description>
</package3d>
<package3d name="RDH/15" urn="urn:adsk.eagle:package:23595/1" type="box" library_version="3">
type RDH, grid 15 mm</description>
</package3d>
<package3d name="MINI_MELF-0102AX" urn="urn:adsk.eagle:package:23594/1" type="box" library_version="3">
<description>Mini MELF 0102 Axial</description>
</package3d>
<package3d name="R0201" urn="urn:adsk.eagle:package:23593/1" type="box" library_version="3">
<description>RESISTOR chip
Source: http://www.vishay.com/docs/20008/dcrcw.pdf</description>
</package3d>
<package3d name="VTA52" urn="urn:adsk.eagle:package:23596/1" type="box" library_version="3">
<description>Bulk Metal® Foil Technology, Tubular Axial Lead Resistors, Meets or Exceeds MIL-R-39005 Requirements
MIL SIZE RBR52
Source: VISHAY .. vta56.pdf</description>
</package3d>
<package3d name="VTA53" urn="urn:adsk.eagle:package:23603/1" type="box" library_version="3">
MIL SIZE RBR53
</package3d>
<package3d name="VTA54" urn="urn:adsk.eagle:package:23598/1" type="box" library_version="3">
MIL SIZE RBR54
</package3d>
<package3d name="VTA55" urn="urn:adsk.eagle:package:23606/1" type="box" library_version="3">
MIL SIZE RBR55
</package3d>
<package3d name="VTA56" urn="urn:adsk.eagle:package:23599/1" type="box" library_version="3">
MIL SIZE RBR56
</package3d>
<package3d name="VMTA55" urn="urn:adsk.eagle:package:23600/1" type="box" library_version="3">
MIL SIZE RNC55
</package3d>
<package3d name="VMTB60" urn="urn:adsk.eagle:package:23607/1" type="box" library_version="3">
MIL SIZE RNC60
</package3d>
<package3d name="R4527" urn="urn:adsk.eagle:package:23615/1" type="box" library_version="3">
<description>Package 4527
Source: http://www.vishay.com/docs/31059/wsrhigh.pdf</description>
</package3d>
<package3d name="WSC0001" urn="urn:adsk.eagle:package:23601/1" type="box" library_version="3">
<description>Wirewound Resistors, Precision Power
Source: VISHAY wscwsn.pdf</description>
</package3d>
<package3d name="WSC0002" urn="urn:adsk.eagle:package:23605/1" type="box" library_version="3">
</package3d>
<package3d name="WSC01/2" urn="urn:adsk.eagle:package:23602/1" type="box" library_version="3">
</package3d>
<package3d name="WSC2515" urn="urn:adsk.eagle:package:23604/1" type="box" library_version="3">
</package3d>
<package3d name="WSC4527" urn="urn:adsk.eagle:package:23611/1" type="box" library_version="3">
</package3d>
<package3d name="WSC6927" urn="urn:adsk.eagle:package:23610/1" type="box" library_version="3">
</package3d>
<package3d name="R1218" urn="urn:adsk.eagle:package:23614/1" type="box" library_version="3">
<description>CRCW1218 Thick Film, Rectangular Chip Resistors
Source: http://www.vishay.com .. dcrcw.pdf</description>
</package3d>
<package3d name="1812X7R" urn="urn:adsk.eagle:package:23609/1" type="box" library_version="3">
<description>Chip Monolithic Ceramic Capacitors Medium Voltage High Capacitance for General Use
Source: http://www.murata.com .. GRM43DR72E224KW01.pdf</description>
</package3d>
<package3d name="PRL1632" urn="urn:adsk.eagle:package:23612/1" type="box" library_version="3">
<description>PRL1632 are realized as 1W for 3.2 × 1.6mm(1206)
Source: http://www.mouser.com/ds/2/392/products_18-2245.pdf</description>
</package3d>
<package3d name="R01005" urn="urn:adsk.eagle:package:23613/1" type="box" library_version="3">
</package3d>
<package3d name="E3,5-8" urn="urn:adsk.eagle:package:23360/2" type="model" library_version="3">
<description>ELECTROLYTIC CAPACITOR
grid 3.5 mm, diameter 8 mm</description>
</package3d>
<package3d name="CT3216" urn="urn:adsk.eagle:package:23327/2" type="model" library_version="3">
<description>TANTALUM CAPACITOR</description>
</package3d>
<package3d name="CT3528" urn="urn:adsk.eagle:package:23325/2" type="model" library_version="3">
</package3d>
<package3d name="CT6032" urn="urn:adsk.eagle:package:23305/2" type="model" library_version="3">
</package3d>
<package3d name="CT7343" urn="urn:adsk.eagle:package:23304/2" type="model" library_version="3">
</package3d>
<package3d name="B45181A" urn="urn:adsk.eagle:package:23316/1" type="box" library_version="3">
body 5 x 5 mm, rectangle, grid 2.54 mm</description>
</package3d>
<package3d name="B45181B" urn="urn:adsk.eagle:package:23320/1" type="box" library_version="3">
body 7.6 x 5 mm, rectangle, grid 5.08 mm</description>
</package3d>
<package3d name="B45181C" urn="urn:adsk.eagle:package:23306/1" type="box" library_version="3">
body 12.7 x 7.6 mm, rectangle, grid 10.16 mm</description>
</package3d>
<package3d name="B45181D" urn="urn:adsk.eagle:package:23308/1" type="box" library_version="3">
body 12.5 x 12.5 mm, rectangle, grid 10.16 mm</description>
</package3d>
<package3d name="TT2D4" urn="urn:adsk.eagle:package:23310/1" type="box" library_version="3">
diameter 4 mm, grid 2.54 mm</description>
</package3d>
<package3d name="TT2D4L" urn="urn:adsk.eagle:package:23321/1" type="box" library_version="3">
</package3d>
<package3d name="TT2D5" urn="urn:adsk.eagle:package:23300/1" type="box" library_version="3">
</package3d>
<package3d name="TT2D6" urn="urn:adsk.eagle:package:23303/1" type="box" library_version="3">
diameter 6 mm, grid 2.54 mm</description>
</package3d>
<package3d name="TT2D6L" urn="urn:adsk.eagle:package:23323/1" type="box" library_version="3">
</package3d>
<package3d name="TT2D7L" urn="urn:adsk.eagle:package:23329/1" type="box" library_version="3">
diameter 7 mm, grid 2.54 mm</description>
</package3d>
<package3d name="TT2D7" urn="urn:adsk.eagle:package:23319/1" type="box" library_version="3">
</package3d>
<package3d name="TT5D10" urn="urn:adsk.eagle:package:23302/1" type="box" library_version="3">
diameter 10 mm, grid 5.08 mm</description>
</package3d>
<package3d name="TT5D11" urn="urn:adsk.eagle:package:23309/1" type="box" library_version="3">
diameter 11 mm, grid 5.08 mm</description>
</package3d>
<package3d name="TT5D11L" urn="urn:adsk.eagle:package:23312/1" type="box" library_version="3">
</package3d>
<package3d name="TT5D6" urn="urn:adsk.eagle:package:23307/1" type="box" library_version="3">
diameter 6 mm, grid 5.08 mm</description>
</package3d>
<package3d name="TT5D6L" urn="urn:adsk.eagle:package:23324/1" type="box" library_version="3">
</package3d>
<package3d name="TT5D7" urn="urn:adsk.eagle:package:23314/1" type="box" library_version="3">
diameter 7 mm, grid 5.08 mm</description>
</package3d>
<package3d name="TT5D7L" urn="urn:adsk.eagle:package:23318/1" type="box" library_version="3">
</package3d>
<package3d name="TT5D9" urn="urn:adsk.eagle:package:23301/1" type="box" library_version="3">
diameter 9 mm, grid 5.08 mm</description>
</package3d>
<package3d name="TT5D9L" urn="urn:adsk.eagle:package:23313/1" type="box" library_version="3">
</package3d>
<package3d name="ETR1" urn="urn:adsk.eagle:package:23322/1" type="box" library_version="3">
</package3d>
<package3d name="ETR2" urn="urn:adsk.eagle:package:23315/1" type="box" library_version="3">
</package3d>
<package3d name="ETR3" urn="urn:adsk.eagle:package:23311/1" type="box" library_version="3">
</package3d>
<package3d name="ETR4" urn="urn:adsk.eagle:package:23317/1" type="box" library_version="3">
</package3d>
<package3d name="ETR5" urn="urn:adsk.eagle:package:23328/1" type="box" library_version="3">
</package3d>
<package3d name="P128-35" urn="urn:adsk.eagle:package:23326/1" type="box" library_version="3">
<description>ELECTROLYTIC CAPACITOR</description>
</package3d>
<package3d name="P128-40" urn="urn:adsk.eagle:package:23331/1" type="box" library_version="3">
</package3d>
<package3d name="P128-50" urn="urn:adsk.eagle:package:23330/1" type="box" library_version="3">
</package3d>
<package3d name="P128-60" urn="urn:adsk.eagle:package:23337/1" type="box" library_version="3">
</package3d>
<package3d name="TAP5-45" urn="urn:adsk.eagle:package:23333/3" type="model" library_version="3">
diameter 4.5 mm, grid 5.08 mm</description>
</package3d>
<package3d name="TAP5-50" urn="urn:adsk.eagle:package:23335/1" type="box" library_version="3">
diameter 5.0 mm, grid 5.08 mm</description>
</package3d>
<package3d name="TAP5-70" urn="urn:adsk.eagle:package:23332/1" type="box" library_version="3">
diameter 7.0 mm, grid 5.08 mm</description>
</package3d>
<package3d name="TAP5-60" urn="urn:adsk.eagle:package:23334/1" type="box" library_version="3">
diameter 6.0 mm, grid 5.08 mm</description>
</package3d>
<package3d name="TAP5-80" urn="urn:adsk.eagle:package:23338/1" type="box" library_version="3">
diameter 8.0 mm, grid 5.08 mm</description>
</package3d>
<package3d name="E1,8-4" urn="urn:adsk.eagle:package:23336/2" type="model" library_version="3">
grid 1.8 mm, diameter 4 mm</description>
</package3d>
<package3d name="E15-5" urn="urn:adsk.eagle:package:23341/1" type="box" library_version="3">
grid 15.24 mm, diameter 5 mm</description>
</package3d>
<package3d name="E15-6" urn="urn:adsk.eagle:package:23339/1" type="box" library_version="3">
grid 15.24 mm, diameter 6 mm</description>
</package3d>
<package3d name="E15-9" urn="urn:adsk.eagle:package:23340/1" type="box" library_version="3">
grid 15.24 mm, diameter 9 mm</description>
</package3d>
<package3d name="E2,5-4R" urn="urn:adsk.eagle:package:23342/1" type="box" library_version="3">
grid 2.54 mm, diameter 4 mm</description>
</package3d>
<package3d name="E2,5-5" urn="urn:adsk.eagle:package:23344/1" type="box" library_version="3">
grid 2.54 mm, diameter 5 mm</description>
</package3d>
<package3d name="E2,5-6" urn="urn:adsk.eagle:package:23349/1" type="box" library_version="3">
</package3d>
<package3d name="E2,5-7" urn="urn:adsk.eagle:package:23345/1" type="box" library_version="3">
grid 2.54 mm, diameter 7 mm</description>
</package3d>
<package3d name="E2,5RE" urn="urn:adsk.eagle:package:23343/1" type="box" library_version="3">
grid 2.54 mm, diameter 4 mm,</description>
</package3d>
<package3d name="E2-4" urn="urn:adsk.eagle:package:23347/1" type="box" library_version="3">
grid 2 mm, diameter 4 mm</description>
</package3d>
<package3d name="E2-5" urn="urn:adsk.eagle:package:23346/2" type="model" library_version="3">
grid 2.032 mm, diameter 5 mm</description>
</package3d>
<package3d name="E22-10" urn="urn:adsk.eagle:package:23348/1" type="box" library_version="3">
grid 22.86 mm, diameter 10 mm</description>
</package3d>
<package3d name="E22-6" urn="urn:adsk.eagle:package:23359/1" type="box" library_version="3">
grid 22.86 mm, diameter 6 mm</description>
</package3d>
<package3d name="E22-9" urn="urn:adsk.eagle:package:23350/1" type="box" library_version="3">
grid 22.86 mm, diameter 9 mm</description>
</package3d>
<package3d name="E3,5-10" urn="urn:adsk.eagle:package:23351/1" type="box" library_version="3">
grid 3.5 mm, diameter 10 mm</description>
</package3d>
<package3d name="E25-10" urn="urn:adsk.eagle:package:23352/1" type="box" library_version="3">
grid 25.4 mm, diameter 10 mm</description>
</package3d>
<package3d name="E25-9" urn="urn:adsk.eagle:package:23358/1" type="box" library_version="3">
grid 25.4 mm, diameter 9 mm</description>
</package3d>
<package3d name="E30-10" urn="urn:adsk.eagle:package:23355/1" type="box" library_version="3">
grid 30.48 mm, diameter 10 mm</description>
</package3d>
<package3d name="E30-12" urn="urn:adsk.eagle:package:23354/1" type="box" library_version="3">
grid 30.48 mm, diameter 12 mm</description>
</package3d>
<package3d name="E30-16" urn="urn:adsk.eagle:package:23353/1" type="box" library_version="3">
grid 30.48 mm, diameter 16 mm</description>
</package3d>
<package3d name="E35-12" urn="urn:adsk.eagle:package:23357/1" type="box" library_version="3">
grid 35.56 mm, diameter 12 mm</description>
</package3d>
<package3d name="E35-14" urn="urn:adsk.eagle:package:23377/1" type="box" library_version="3">
grid 30.48 mm, diameter 14 mm</description>
</package3d>
<package3d name="E35-16" urn="urn:adsk.eagle:package:23362/1" type="box" library_version="3">
</package3d>
<package3d name="E35-18" urn="urn:adsk.eagle:package:23356/1" type="box" library_version="3">
grid 30.48 mm, diameter 18 mm</description>
</package3d>
<package3d name="E45-16" urn="urn:adsk.eagle:package:23365/1" type="box" library_version="3">
grid 45.72 mm, diameter 16 mm</description>
</package3d>
<package3d name="E45-18" urn="urn:adsk.eagle:package:23361/1" type="box" library_version="3">
grid 45.72 mm, diameter 18 mm</description>
</package3d>
<package3d name="E45-21" urn="urn:adsk.eagle:package:23363/1" type="box" library_version="3">
grid 45.72 mm, diameter 21 mm</description>
</package3d>
<package3d name="E45-22" urn="urn:adsk.eagle:package:23366/1" type="box" library_version="3">
grid 45.72 mm, diameter 22 mm</description>
</package3d>
<package3d name="E45-25" urn="urn:adsk.eagle:package:23364/1" type="box" library_version="3">
grid 45.72 mm, diameter 25 mm</description>
</package3d>
<package3d name="E5-10,5" urn="urn:adsk.eagle:package:23372/1" type="box" library_version="3">
grid 5.08 mm, diameter 10.5 mm</description>
</package3d>
<package3d name="E5-13" urn="urn:adsk.eagle:package:23375/1" type="box" library_version="3">
grid 5.08 mm, diameter 13 mm</description>
</package3d>
<package3d name="E5-4" urn="urn:adsk.eagle:package:23370/1" type="box" library_version="3">
grid 5.05 mm, diameter 4 mm</description>
</package3d>
<package3d name="E5-5" urn="urn:adsk.eagle:package:23367/1" type="box" library_version="3">
grid 5.08 mm, diameter 5 mm</description>
</package3d>
<package3d name="E5-6" urn="urn:adsk.eagle:package:23368/1" type="box" library_version="3">
grid 5.08 mm, diameter 6 mm</description>
</package3d>
<package3d name="E5-8,5" urn="urn:adsk.eagle:package:23374/1" type="box" library_version="3">
grid 5.08 mm, diameter 8.5 mm</description>
</package3d>
<package3d name="E50-25" urn="urn:adsk.eagle:package:23369/1" type="box" library_version="3">
grid 50 mm, diameter 25 mm</description>
</package3d>
<package3d name="E50-30" urn="urn:adsk.eagle:package:23371/1" type="box" library_version="3">
grid 50 mm, diameter 30 mm</description>
</package3d>
<package3d name="E55-25" urn="urn:adsk.eagle:package:23376/1" type="box" library_version="3">
grid 55 mm, diameter 25 mm</description>
</package3d>
<package3d name="E55-30" urn="urn:adsk.eagle:package:23378/1" type="box" library_version="3">
grid 55 mm, diameter 30 mm</description>
</package3d>
<package3d name="E5R" urn="urn:adsk.eagle:package:23373/1" type="box" library_version="3">
grid 5.08 mm, diameter 9 mm</description>
</package3d>
<package3d name="E7,5-16" urn="urn:adsk.eagle:package:23382/2" type="model" library_version="3">
grid 7.62 mm, diameter 16 mm</description>
</package3d>
<package3d name="E7,5-18" urn="urn:adsk.eagle:package:23379/1" type="box" library_version="3">
grid 7.62 mm, diameter 18 mm</description>
</package3d>
<package3d name="EB20D" urn="urn:adsk.eagle:package:23381/1" type="box" library_version="3">
grid 10.16 mm, diameter 20 mm</description>
</package3d>
<package3d name="EB22,5D" urn="urn:adsk.eagle:package:23380/1" type="box" library_version="3">
grid 10.16 mm, diameter 22.5 mm</description>
</package3d>
<package3d name="EB25D" urn="urn:adsk.eagle:package:23399/1" type="box" library_version="3">
grid 10.16 mm, diameter 25 mm</description>
</package3d>
<package3d name="EB30D" urn="urn:adsk.eagle:package:23389/1" type="box" library_version="3">
grid 10.16 mm, diameter 30 mm</description>
</package3d>
<package3d name="EB35D" urn="urn:adsk.eagle:package:23395/1" type="box" library_version="3">
grid 10.16 mm, diameter 35 mm</description>
</package3d>
<package3d name="085CS_1R" urn="urn:adsk.eagle:package:23383/1" type="box" library_version="3">
<description>Aluminum electrolytic capacitors reflow soldering
SMD (Chip) Standard 085 CS
http://www.bccomponents.com/</description>
</package3d>
<package3d name="085CS_1W" urn="urn:adsk.eagle:package:23384/1" type="box" library_version="3">
<description>Aluminum electrolytic capacitors wave soldering
</package3d>
<package3d name="085CS_1AR" urn="urn:adsk.eagle:package:23396/1" type="box" library_version="3">
</package3d>
<package3d name="085CS_1AW" urn="urn:adsk.eagle:package:23385/1" type="box" library_version="3">
</package3d>
<package3d name="139CLL-2R" urn="urn:adsk.eagle:package:23387/1" type="box" library_version="3">
SMD (Chip) Long Life 139 CLL
</package3d>
<package3d name="139CLL-2W" urn="urn:adsk.eagle:package:23386/1" type="box" library_version="3">
</package3d>
<package3d name="139CLL-3R" urn="urn:adsk.eagle:package:23388/1" type="box" library_version="3">
</package3d>
<package3d name="139CLL-3W" urn="urn:adsk.eagle:package:23390/1" type="box" library_version="3">
</package3d>
<package3d name="140CLH-0810" urn="urn:adsk.eagle:package:23392/1" type="box" library_version="3">
<description>Aluminum electrolytic capacitors SMD (Chip)
Long life base plate, High temperature 140 CLH
</package3d>
<package3d name="140CLH-1010" urn="urn:adsk.eagle:package:23391/1" type="box" library_version="3">
</package3d>
<package3d name="140CLH-1014" urn="urn:adsk.eagle:package:23393/1" type="box" library_version="3">
</package3d>
<package3d name="150CLZ-0810" urn="urn:adsk.eagle:package:23394/1" type="box" library_version="3">
Long life base plate, very low impedance 150 CLZ
</package3d>
<package3d name="150CLZ-1010" urn="urn:adsk.eagle:package:23403/1" type="box" library_version="3">
</package3d>
<package3d name="150CLZ-1014" urn="urn:adsk.eagle:package:23405/1" type="box" library_version="3">
</package3d>
<package3d name="153CLV-0405" urn="urn:adsk.eagle:package:23397/1" type="box" library_version="3">
SMD (Chip) Long Life Vertical 153 CLV
</package3d>
<package3d name="153CLV-0505" urn="urn:adsk.eagle:package:23402/1" type="box" library_version="3">
</package3d>
<package3d name="153CLV-0605" urn="urn:adsk.eagle:package:23398/1" type="box" library_version="3">
</package3d>
<package3d name="153CLV-0807" urn="urn:adsk.eagle:package:23400/1" type="box" library_version="3">
</package3d>
<package3d name="153CLV-0810" urn="urn:adsk.eagle:package:23401/1" type="box" library_version="3">
</package3d>
<package3d name="153CLV-1010" urn="urn:adsk.eagle:package:23413/1" type="box" library_version="3">
</package3d>
<package3d name="153CLV-1012" urn="urn:adsk.eagle:package:23404/1" type="box" library_version="3">
</package3d>
<package3d name="153CLV-1014" urn="urn:adsk.eagle:package:23406/1" type="box" library_version="3">
</package3d>
<package3d name="175TMP-0808" urn="urn:adsk.eagle:package:23412/1" type="box" library_version="3">
High Temperature solid electrolytic SMD 175 TMP
</package3d>
<package3d name="175TMP-0810" urn="urn:adsk.eagle:package:23407/1" type="box" library_version="3">
</package3d>
<package3d name="A/3216-18R" urn="urn:adsk.eagle:package:23410/2" type="model" library_version="3">
<description>Chip Capacitor Type KEMET A / EIA 3216-18 reflow solderKEMET S / EIA 3216-12</description>
</package3d>
<package3d name="A/3216-18W" urn="urn:adsk.eagle:package:23408/2" type="model" library_version="3">
<description>Chip Capacitor Type KEMET A / EIA 3216-18 Wave solder
</package3d>
<package3d name="B/3528-21R" urn="urn:adsk.eagle:package:23409/2" type="model" library_version="3">
<description>Chip Capacitor Type KEMET B / EIA 3528-21 reflow solderKEMET T / EIA 3528-12</description>
</package3d>
<package3d name="B/3528-21W" urn="urn:adsk.eagle:package:23411/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET B / EIA 3528-21 Wave solder
</package3d>
<package3d name="C/6032-28R" urn="urn:adsk.eagle:package:23415/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET C / EIA 6032-28 reflow solderKEMET U / EIA 6032-15</description>
</package3d>
<package3d name="C/6032-28W" urn="urn:adsk.eagle:package:23420/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET C / EIA 6032-28 Wafe solder
</package3d>
<package3d name="D/7343-31R" urn="urn:adsk.eagle:package:23417/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET D / EIA 7343-21KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 reflow solder</description>
</package3d>
<package3d name="D/7343-31W" urn="urn:adsk.eagle:package:23414/1" type="box" library_version="3">
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Wafe solder</description>
</package3d>
<package3d name="E/7260-38R" urn="urn:adsk.eagle:package:23416/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET E / EIA 7260-38 reflow solder</description>
</package3d>
<package3d name="E/7260-38W" urn="urn:adsk.eagle:package:23423/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET E / EIA 7260-38 Wafe solder</description>
</package3d>
<package3d name="R/2012-12R" urn="urn:adsk.eagle:package:23426/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET R/EIA 2012-12 reflow solder</description>
</package3d>
<package3d name="R/2012-12W" urn="urn:adsk.eagle:package:23419/1" type="box" library_version="3">
<description>Chip Capacitor Type KEMET R/EIA 2012-12 Wafe solder</description>
</package3d>
<package3d name="PANASONIC_A" urn="urn:adsk.eagle:package:23418/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package A</description>
</package3d>
<package3d name="PANASONIC_B" urn="urn:adsk.eagle:package:23421/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package B</description>
</package3d>
<package3d name="PANASONIC_C" urn="urn:adsk.eagle:package:23422/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package C</description>
</package3d>
<package3d name="PANASONIC_D" urn="urn:adsk.eagle:package:23424/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D</description>
</package3d>
<package3d name="PANASONIC_E" urn="urn:adsk.eagle:package:23425/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package E</description>
</package3d>
<package3d name="PANASONIC_F" urn="urn:adsk.eagle:package:23428/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package F</description>
</package3d>
<package3d name="PANASONIC_G" urn="urn:adsk.eagle:package:23427/2" type="model" library_version="3">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G</description>
</package3d>
<package3d name="TT2D5L" urn="urn:adsk.eagle:package:23429/1" type="box" library_version="3">
diameter 5 mm, grid 2.54 mm</description>
</package3d>
<package3d name="E2,5-6E" urn="urn:adsk.eagle:package:23430/1" type="box" library_version="3">
grid 2.54 mm, diameter 6 mm</description>
</package3d>
<package3d name="SMC_A" urn="urn:adsk.eagle:package:23431/1" type="box" library_version="3">
<description>Chip Capacitor  Polar tantalum capacitors with solid electrolyte
Siemens Matsushita Components B 45 194, B 45 197, B 45 198
Source: www.farnell.com/datasheets/247.pdf</description>
</package3d>
<package3d name="SMC_Z" urn="urn:adsk.eagle:package:23433/1" type="box" library_version="3">
</package3d>
<package3d name="SMC_P" urn="urn:adsk.eagle:package:23432/1" type="box" library_version="3">
</package3d>
<package3d name="SMC_B" urn="urn:adsk.eagle:package:23436/1" type="box" library_version="3">
</package3d>
<package3d name="SMC_C" urn="urn:adsk.eagle:package:23435/1" type="box" library_version="3">
</package3d>
<package3d name="SMC_D" urn="urn:adsk.eagle:package:23434/1" type="box" library_version="3">
</package3d>
<package3d name="SMC_E" urn="urn:adsk.eagle:package:23446/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_9E" urn="urn:adsk.eagle:package:23439/1" type="box" library_version="3">
<description>SANYO OSCON Capacitor
Source: e_os_all.pdf</description>
</package3d>
<package3d name="SANYO-OSCON_9F" urn="urn:adsk.eagle:package:23437/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_A" urn="urn:adsk.eagle:package:23438/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_A'" urn="urn:adsk.eagle:package:23440/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_B" urn="urn:adsk.eagle:package:23449/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_B'" urn="urn:adsk.eagle:package:23442/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_C" urn="urn:adsk.eagle:package:23441/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_C'" urn="urn:adsk.eagle:package:23443/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_C6" urn="urn:adsk.eagle:package:23444/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_D" urn="urn:adsk.eagle:package:23445/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_E" urn="urn:adsk.eagle:package:23451/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_E'" urn="urn:adsk.eagle:package:23453/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_E1" urn="urn:adsk.eagle:package:23447/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_E12" urn="urn:adsk.eagle:package:23448/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_E13" urn="urn:adsk.eagle:package:23454/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_E7" urn="urn:adsk.eagle:package:23452/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_E9" urn="urn:adsk.eagle:package:23457/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_F" urn="urn:adsk.eagle:package:23462/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_F'" urn="urn:adsk.eagle:package:23450/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_F0" urn="urn:adsk.eagle:package:23459/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_F13" urn="urn:adsk.eagle:package:23455/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_F8" urn="urn:adsk.eagle:package:23456/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_G" urn="urn:adsk.eagle:package:23458/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_H" urn="urn:adsk.eagle:package:23463/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_SMD_A5" urn="urn:adsk.eagle:package:23460/1" type="box" library_version="3">
<description>SANYO OSCON Capacitor SMD type with conductive polymer electrolyte
</package3d>
<package3d name="SANYO-OSCON_SMD_B6" urn="urn:adsk.eagle:package:23461/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_SMD_C6" urn="urn:adsk.eagle:package:23465/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_SMD_E12" urn="urn:adsk.eagle:package:23464/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_SMD_E7" urn="urn:adsk.eagle:package:23467/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_SMD_F12" urn="urn:adsk.eagle:package:23468/1" type="box" library_version="3">
</package3d>
<package3d name="SANYO-OSCON_SMD_F8" urn="urn:adsk.eagle:package:23466/1" type="box" library_version="3">
</package3d>
<package3d name="UD-10X10_NICHICON" urn="urn:adsk.eagle:package:23469/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 10 x 10 mm
</package3d>
<package3d name="UD-4X5,8_NICHICON" urn="urn:adsk.eagle:package:23474/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 4 x 5.8 mm
</package3d>
<package3d name="UD-5X5,8_NICHICON" urn="urn:adsk.eagle:package:23470/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 5 x 5.8 mm
</package3d>
<package3d name="UD-6,3X5,8_NICHICON" urn="urn:adsk.eagle:package:23471/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 6.3 x 5.8 mm
</package3d>
<package3d name="UD-6,3X7,7_NICHICON" urn="urn:adsk.eagle:package:23472/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 6.3 x 7.7 mm
</package3d>
<package3d name="UD-8X10_NICHICON" urn="urn:adsk.eagle:package:23473/1" type="box" library_version="3">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 8 x 10 mm
</package3d>
</packages3d>
<symbols>
<symbol name="C-EU" urn="urn:adsk.eagle:symbol:23120/1" library_version="3">
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
<symbol name="R-EU" urn="urn:adsk.eagle:symbol:23042/1" library_version="3">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="CPOL" urn="urn:adsk.eagle:symbol:22801/1" library_version="3">
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="-1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="1.524" y2="0" width="0.254" layer="94"/>
<text x="1.143" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="-0.5842" y="0.4064" size="1.27" layer="94" rot="R90">+</text>
<text x="1.143" y="-4.5974" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.54" x2="1.651" y2="-1.651" layer="94"/>
<pin name="-" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="+" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="C-EU" urn="urn:adsk.eagle:component:23793/42" prefix="C" uservalue="yes" library_version="3">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="C-EU" x="0" y="0"/>
</gates>
<devices>
<device name="C0402" package="C0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23626/1"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="SPICEPREFIX" value="C" constant="no"/>
</technology>
</technologies>
</device>
<device name="C0504" package="C0504">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23624/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C0603" package="C0603">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23616/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C0805" package="C0805">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23617/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1206" package="C1206">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23618/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1210" package="C1210">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23619/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1310" package="C1310">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23620/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1608" package="C1608">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23621/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1812" package="C1812">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23622/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1825" package="C1825">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23623/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C2012" package="C2012">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23625/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C3216" package="C3216">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23628/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C3225" package="C3225">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23655/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C4532" package="C4532">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23627/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C4564" package="C4564">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23648/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025-024X044" package="C025-024X044">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23630/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025-025X050" package="C025-025X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23629/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025-030X050" package="C025-030X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23631/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025-040X050" package="C025-040X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23634/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025-050X050" package="C025-050X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23633/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025-060X050" package="C025-060X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23632/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C025_050-024X070" package="C025_050-024X070">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23639/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025_050-025X075" package="C025_050-025X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23641/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025_050-035X075" package="C025_050-035X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23651/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025_050-045X075" package="C025_050-045X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23635/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025_050-055X075" package="C025_050-055X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23636/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-024X044" package="C050-024X044">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23643/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-025X075" package="C050-025X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23637/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-045X075" package="C050-045X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23638/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-030X075" package="C050-030X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23640/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-050X075" package="C050-050X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23665/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-055X075" package="C050-055X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23642/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-075X075" package="C050-075X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23645/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050H075X075" package="C050H075X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23644/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="075-032X103" package="C075-032X103">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23646/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="075-042X103" package="C075-042X103">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23656/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="075-052X106" package="C075-052X106">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23650/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="102-043X133" package="C102-043X133">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23647/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="102-054X133" package="C102-054X133">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23649/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="102-064X133" package="C102-064X133">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23653/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="102_152-062X184" package="C102_152-062X184">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23652/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-054X183" package="C150-054X183">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23669/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-064X183" package="C150-064X183">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23654/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-072X183" package="C150-072X183">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23657/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-084X183" package="C150-084X183">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23658/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-091X182" package="C150-091X182">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23659/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-062X268" package="C225-062X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23661/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-074X268" package="C225-074X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23660/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-087X268" package="C225-087X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23662/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-108X268" package="C225-108X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23663/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-113X268" package="C225-113X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23667/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-093X316" package="C275-093X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23701/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-113X316" package="C275-113X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23673/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-134X316" package="C275-134X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23664/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-205X316" package="C275-205X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23666/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="325-137X374" package="C325-137X374">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23672/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="325-162X374" package="C325-162X374">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23670/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="325-182X374" package="C325-182X374">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23668/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="375-192X418" package="C375-192X418">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23674/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="375-203X418" package="C375-203X418">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23671/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-035X075" package="C050-035X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23677/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="375-155X418" package="C375-155X418">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23675/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="075-063X106" package="C075-063X106">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23678/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-154X316" package="C275-154X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23685/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-173X316" package="C275-173X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23676/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C0402K" package="C0402K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23679/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C0603K" package="C0603K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23680/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C0805K" package="C0805K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23681/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1206K" package="C1206K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23682/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1210K" package="C1210K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23683/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1812K" package="C1812K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23686/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1825K" package="C1825K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23684/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C2220K" package="C2220K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23687/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C2225K" package="C2225K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23692/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="HPC0201" package="HPC0201">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23688/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C0201" package="C0201">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23690/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1808" package="C1808">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23689/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C3640" package="C3640">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23693/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="01005" package="C01005">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23691/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
<spice>
<pinmapping spiceprefix="C">
<pinmap gate="G$1" pin="1" pinorder="1"/>
<pinmap gate="G$1" pin="2" pinorder="2"/>
</pinmapping>
</spice>
</deviceset>
<deviceset name="R-EU_" urn="urn:adsk.eagle:component:23791/14" prefix="R" uservalue="yes" library_version="3">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="R-EU" x="0" y="0"/>
</gates>
<devices>
<device name="R0402" package="R0402">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23547/2"/>
<technologies>
<attribute name="SPICEPREFIX" value="R" constant="no"/>
</technology>
</technologies>
</device>
<device name="R0603" package="R0603">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23555/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R0805" package="R0805">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23553/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R0805W" package="R0805W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23537/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R1206" package="R1206">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23540/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R1206W" package="R1206W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23539/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R1210" package="R1210">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23554/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R1210W" package="R1210W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23541/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2010" package="R2010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23551/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2010W" package="R2010W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23542/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2012" package="R2012">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23543/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2012W" package="R2012W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23544/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2512" package="R2512">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23545/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2512W" package="R2512W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23565/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R3216" package="R3216">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23557/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R3216W" package="R3216W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23548/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R3225" package="R3225">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23549/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R3225W" package="R3225W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23550/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R5025" package="R5025">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23552/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R5025W" package="R5025W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23558/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R6332" package="R6332">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23559/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R6332W" package="R6332W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23560/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M0805" package="M0805">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23556/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M1206" package="M1206">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23566/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M1406" package="M1406">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23569/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M2012" package="M2012">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23561/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M2309" package="M2309">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23562/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M3216" package="M3216">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23563/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M3516" package="M3516">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23573/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M5923" package="M5923">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23564/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23488/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23498/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0204/2V" package="0204V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23495/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23491/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23489/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23492/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23490/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23502/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23493/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0309/10" package="0309/10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23567/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0309/12" package="0309/12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23571/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0309/V" package="0309V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23572/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0411/12" package="0411/12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23578/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0411/15" package="0411/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23568/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0411/3V" package="0411V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23570/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0414/15" package="0414/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23579/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0414/5V" package="0414V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23574/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0617/17" package="0617/17">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23575/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0617/22" package="0617/22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23577/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0617/5V" package="0617V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23576/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0922/22" package="0922/22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23580/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0613/5V" package="P0613V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23582/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0613/15" package="P0613/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23581/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0817/22" package="P0817/22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23583/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0817/7V" package="P0817V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23608/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="V234/12" package="V234/12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23592/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="V235/17" package="V235/17">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23586/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="V526-0" package="V526-0">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23590/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0102R" package="MINI_MELF-0102R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23591/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0102W" package="MINI_MELF-0102W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23588/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0204R" package="MINI_MELF-0204R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23587/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0204W" package="MINI_MELF-0204W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23584/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0207R" package="MINI_MELF-0207R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23585/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0207W" package="MINI_MELF-0207W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23597/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0922V" package="0922V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23589/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="RDH/15" package="RDH/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23595/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0102AX" package="MINI_MELF-0102AX">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23594/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R0201" package="R0201">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23593/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA52" package="VTA52">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23596/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA53" package="VTA53">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23603/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA54" package="VTA54">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23598/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA55" package="VTA55">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23606/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA56" package="VTA56">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23599/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VMTA55" package="VMTA55">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23600/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VMTB60" package="VMTB60">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23607/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R4527" package="R4527">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23615/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC0001" package="WSC0001">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23601/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC0002" package="WSC0002">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23605/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC01/2" package="WSC01/2">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23602/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC2515" package="WSC2515">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23604/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC4527" package="WSC4527">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23611/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC6927" package="WSC6927">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23610/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R1218" package="R1218">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23614/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="1812X7R" package="1812X7R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23609/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="PRL1632" package="PRL1632">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23612/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="01005" package="R01005">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23613/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
<spice>
<pinmapping spiceprefix="R">
</pinmapping>
</spice>
</deviceset>
<deviceset name="CPOL-EU" urn="urn:adsk.eagle:component:23787/21" prefix="C" uservalue="yes" library_version="3">
<description>&lt;B&gt;POLARIZED CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="CPOL" x="0" y="0"/>
</gates>
<devices>
<device name="CT3216" package="CT3216">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23327/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CT3528" package="CT3528">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23325/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CT6032" package="CT6032">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23305/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CT7343" package="CT7343">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23304/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181A" package="B45181A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23316/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181B" package="B45181B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23320/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181C" package="B45181C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23306/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181D" package="B45181D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23308/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D4" package="TT2D4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23310/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D4L" package="TT2D4L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23321/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D5" package="TT2D5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23300/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D6" package="TT2D6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23303/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D6L" package="TT2D6L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23323/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D7L" package="TT2D7L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23329/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D7" package="TT2D7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23319/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D10" package="TT5D10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23302/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D11" package="TT5D11">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23309/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D11L" package="TT5D11L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23312/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT6D6" package="TT5D6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23307/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D6L" package="TT5D6L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23324/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D7" package="TT5D7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23314/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D7L" package="TT5D7L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23318/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D9" package="TT5D9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23301/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D9L" package="TT5D9L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23313/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR1" package="ETR1">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23322/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR2" package="ETR2">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23315/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR3" package="ETR3">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23311/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR4" package="ETR4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23317/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR5" package="ETR5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23328/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-35" package="P128-35">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23326/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-40" package="P128-40">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23331/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-50" package="P128-50">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23330/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-60" package="P128-60">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23337/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-45" package="TAP5-45">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23333/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-50" package="TAP5-50">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23335/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-70" package="TAP5-70">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23332/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-60" package="TAP5-60">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23334/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-80" package="TAP5-80">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23338/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E1.8-4" package="E1,8-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23336/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E15-5AXIAL" package="E15-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23341/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E15-6AXIAL" package="E15-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23339/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E15-9AXIAL" package="E15-9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23340/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-5V" package="E2,5-4R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23342/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-5" package="E2,5-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23344/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-6" package="E2,5-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23349/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-7" package="E2,5-7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23345/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-4V" package="E2,5RE">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23343/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2-4" package="E2-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23347/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2-5" package="E2-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23346/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E22-10AXIAL" package="E22-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23348/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E22-6AXIAL" package="E22-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23359/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E22-9AXIAL" package="E22-9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23350/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E3.5-10" package="E3,5-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23351/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E25-10AXIAL" package="E25-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23352/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E25-9AXIAL" package="E25-9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23358/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E3.5-8" package="E3,5-8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23360/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E30-10AXIAL" package="E30-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23355/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E30-12AXIAL" package="E30-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23354/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E30-16AXIAL" package="E30-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23353/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-12AXIAL" package="E35-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23357/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-14AXIAL" package="E35-14">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23377/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-16AXIAL" package="E35-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23362/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-18AXIAL" package="E35-18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23356/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-16AXIAL" package="E45-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23365/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-18AXIAL" package="E45-18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23361/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-21AXIAL" package="E45-21">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23363/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-22AXIAL" package="E45-22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23366/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-25AXIAL" package="E45-25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23364/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-10.5" package="E5-10,5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23372/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-13" package="E5-13">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23375/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-4" package="E5-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23370/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-5" package="E5-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23367/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-6" package="E5-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23368/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-8.5" package="E5-8,5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23374/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E50-25AXIAL" package="E50-25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23369/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E50-30AXIAL" package="E50-30">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23371/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E55-25AXIAL" package="E55-25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23376/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E55-30AXIAL" package="E55-30">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23378/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-9VAXIAL" package="E5R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23373/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E7.5-16" package="E7,5-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23382/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E7.5-18" package="E7,5-18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23379/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-20" package="EB20D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23381/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-22.5" package="EB22,5D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23380/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-25" package="EB25D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23399/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-30" package="EB30D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23389/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-35" package="EB35D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23395/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1R" package="085CS_1R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23383/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1W" package="085CS_1W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23384/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1AR" package="085CS_1AR">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23396/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1AW" package="085CS_1AW">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23385/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-2R" package="139CLL-2R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23387/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-2W" package="139CLL-2W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23386/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-3R" package="139CLL-3R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23388/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-3W" package="139CLL-3W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23390/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="140CLH-0810" package="140CLH-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23392/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="140CLH-1010" package="140CLH-1010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23391/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="140CLH-1014" package="140CLH-1014">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23393/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150CLZ-0810" package="150CLZ-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23394/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150CLZ-1010" package="150CLZ-1010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23403/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150CLZ-1014" package="150CLZ-1014">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23405/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0405" package="153CLV-0405">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23397/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0505" package="153CLV-0505">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23402/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0605" package="153CLV-0605">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23398/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0807" package="153CLV-0807">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23400/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0810" package="153CLV-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23401/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-1010" package="153CLV-1010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23413/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-1012" package="153CLV-1012">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23404/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-1014" package="153CLV-1014">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23406/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="175TMP-0808" package="175TMP-0808">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23412/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="175TMP-0810" package="175TMP-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23407/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="A/3216-18R" package="A/3216-18R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23410/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="A/3216-18W" package="A/3216-18W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23408/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B/3528-21R" package="B/3528-21R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23409/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B/3528-21W" package="B/3528-21W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23411/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C/6032-28R" package="C/6032-28R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23415/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C/6032-28W" package="C/6032-28W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23420/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D/7343-31R" package="D/7343-31R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23417/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D/7343-31W" package="D/7343-31W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23414/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E/7260-38R" package="E/7260-38R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23416/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E/7260-38W" package="E/7260-38W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23423/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R/2012-12R" package="R/2012-12R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23426/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R/2012-12W" package="R/2012-12W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23419/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="A" package="PANASONIC_A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23418/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B" package="PANASONIC_B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23421/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C" package="PANASONIC_C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23422/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D" package="PANASONIC_D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23424/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E" package="PANASONIC_E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23425/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="F" package="PANASONIC_F">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23428/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="G" package="PANASONIC_G">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23427/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D5L" package="TT2D5L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23429/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2,5-6E" package="E2,5-6E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23430/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCA" package="SMC_A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23431/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCZ" package="SMC_Z">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23433/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCP" package="SMC_P">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23432/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCB" package="SMC_B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23436/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCC" package="SMC_C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23435/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCD" package="SMC_D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23434/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCE" package="SMC_E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23446/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_9E" package="SANYO-OSCON_9E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23439/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_9F" package="SANYO-OSCON_9F">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23437/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_A" package="SANYO-OSCON_A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23438/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_A'" package="SANYO-OSCON_A'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23440/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_B" package="SANYO-OSCON_B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23449/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_B'" package="SANYO-OSCON_B'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23442/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_C" package="SANYO-OSCON_C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23441/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_C'" package="SANYO-OSCON_C'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23443/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_C6" package="SANYO-OSCON_C6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23444/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_D" package="SANYO-OSCON_D">
<connects>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23445/1"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="SPICEPREFIX" value="C" constant="no"/>
</technology>
</technologies>
</device>
<device name="SANYO_E" package="SANYO-OSCON_E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23451/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E'" package="SANYO-OSCON_E'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23453/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E1" package="SANYO-OSCON_E1">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23447/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E12" package="SANYO-OSCON_E12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23448/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E13" package="SANYO-OSCON_E13">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23454/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E7" package="SANYO-OSCON_E7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23452/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E9" package="SANYO-OSCON_E9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23457/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F" package="SANYO-OSCON_F">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23462/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F'" package="SANYO-OSCON_F'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23450/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F0" package="SANYO-OSCON_F0">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23459/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F13" package="SANYO-OSCON_F13">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23455/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F8" package="SANYO-OSCON_F8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23456/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_G" package="SANYO-OSCON_G">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23458/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_H" package="SANYO-OSCON_H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23463/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_A5" package="SANYO-OSCON_SMD_A5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23460/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_B6" package="SANYO-OSCON_SMD_B6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23461/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_C6" package="SANYO-OSCON_SMD_C6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23465/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_E12" package="SANYO-OSCON_SMD_E12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23464/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_E7" package="SANYO-OSCON_SMD_E7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23467/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_F12" package="SANYO-OSCON_SMD_F12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23468/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_F8" package="SANYO-OSCON_SMD_F8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23466/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-10X10" package="UD-10X10_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23469/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-4X5,8" package="UD-4X5,8_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23474/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-5X5,8" package="UD-5X5,8_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23470/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-6,3X8,8" package="UD-6,3X5,8_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23471/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-6,3X7,7" package="UD-6,3X7,7_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23472/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-8X10" package="UD-8X10_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23473/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
<spice>
<pinmap gate="G$1" pin="+" pinorder="1"/>
<pinmap gate="G$1" pin="-" pinorder="2"/>
</pinmapping>
</spice>
</deviceset>
</devicesets>
</library>
<library name="transistor-npn" urn="urn:adsk.eagle:library:398">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SOT23" urn="urn:adsk.eagle:footprint:28932/1" library_version="2">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="SOT23" urn="urn:adsk.eagle:package:28984/2" type="model" library_version="2">
<description>SOT-23</description>
</package3d>
</packages3d>
<symbols>
<symbol name="NPN" urn="urn:adsk.eagle:symbol:28915/1" library_version="2">
<wire x1="2.54" y1="2.54" x2="0.508" y2="1.524" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-1.524" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.778" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.54" y1="-2.04" x2="0.308" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-2.413" x2="2.286" y2="-2.413" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.413" x2="1.778" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.778" x2="1.524" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.524" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.032" width="0.254" layer="94"/>
<text x="-10.16" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="E" x="2.54" y="-5.08" visible="off" length="short" direction="pas" swaplevel="3" rot="R90"/>
<pin name="C" x="2.54" y="5.08" visible="off" length="short" direction="pas" swaplevel="2" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="BC847*" urn="urn:adsk.eagle:component:29099/2" prefix="Q" library_version="2">
<description>NPN Transistor</description>
<gates>
<gate name="G$1" symbol="NPN" x="0" y="0"/>
</gates>
<devices>
<device name="SMD" package="SOT23">
<connects>
<connect gate="G$1" pin="B" pad="1"/>
<connect gate="G$1" pin="C" pad="3"/>
<connect gate="G$1" pin="E" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28984/2"/>
<technologies>
<technology name=""/>
<technology name="A"/>
<technology name="ALT1"/>
<technology name="B"/>
<technology name="BLT1"/>
<technology name="C"/>
<technology name="CLT1"/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="diode" urn="urn:adsk.eagle:library:210">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO-214AC" urn="urn:adsk.eagle:footprint:43216/1" library_version="2">
<description>&lt;b&gt;SURFACE MOUNT GENERAL RECTIFIER&lt;/b&gt; JEDEC DO-214AC molded platic body&lt;p&gt;
Method 2026&lt;br&gt;
Source: http://www.kingtronics.com/SMD_M7/M7_SMD_4007.pdf</description>
<wire x1="-2.15" y1="1.3" x2="2.15" y2="1.3" width="0.2032" layer="51"/>
<wire x1="2.15" y1="1.3" x2="2.15" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.3" x2="-2.15" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="-1.3" x2="-2.15" y2="1.3" width="0.2032" layer="51"/>
<wire x1="-1.035" y1="1.3" x2="1.025" y2="1.3" width="0.2032" layer="21"/>
<wire x1="1.025" y1="-1.3" x2="-1.035" y2="-1.3" width="0.2032" layer="21"/>
<smd name="C" x="-2.025" y="0" dx="1.8" dy="2.4" layer="1"/>
<smd name="A" x="2.025" y="0" dx="1.8" dy="2.4" layer="1" rot="R180"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.825" y1="-1.1" x2="-2.175" y2="1.1" layer="51"/>
<rectangle x1="2.175" y1="-1.1" x2="2.825" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-1.065" y1="-1.225" x2="-0.39" y2="1.225" layer="21"/>
<rectangle x1="-1.75" y1="-1.225" x2="-1.075" y2="1.225" layer="51"/>
</package>
<package name="DO41-10" urn="urn:adsk.eagle:footprint:43094/1" library_version="2">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="DO35-10" urn="urn:adsk.eagle:footprint:43092/1" library_version="2">
diameter 2 mm, horizontal, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-0.762" x2="2.286" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO204-10" urn="urn:adsk.eagle:footprint:43129/1" library_version="2">
diameter 4 mm, horizontal, grid 10 mm</description>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="2.5255" y2="0.6542" width="0.1524" layer="21" curve="-105.826017"/>
<wire x1="-2.5255" y1="-0.6542" x2="2.54" y2="-0.635" width="0.1524" layer="21" curve="105.826017"/>
<wire x1="2.54" y1="0.635" x2="2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.508" x2="2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.508" x2="2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.508" x2="3.048" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.508" x2="-2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.508" x2="-2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.508" x2="-3.048" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="-1.016" width="0.6096" layer="21"/>
<wire x1="-2.286" y1="0.508" x2="-2.286" y2="-0.508" width="0.6096" layer="21"/>
<wire x1="-2.032" y1="-0.762" x2="-2.286" y2="-0.508" width="0.6096" layer="21"/>
<wire x1="-2.286" y1="0.508" x2="-2.032" y2="0.762" width="0.6096" layer="21"/>
<wire x1="-2.794" y1="0.381" x2="-2.794" y2="-0.381" width="0.6096" layer="21"/>
<wire x1="2.794" y1="0.381" x2="2.794" y2="-0.381" width="0.6096" layer="21"/>
<wire x1="5.08" y1="0" x2="3.683" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.683" y2="0" width="0.8128" layer="51"/>
<wire x1="-0.889" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.508" x2="0.508" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.508" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.508" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.508" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.1176" shape="long"/>
<text x="-2.54" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.048" y1="-0.4064" x2="3.6068" y2="0.4064" layer="21"/>
<rectangle x1="-3.6068" y1="-0.4064" x2="-3.048" y2="0.4064" layer="21"/>
</package>
<package name="DO15-12" urn="urn:adsk.eagle:footprint:43132/1" library_version="2">
diameter 3.5 mm, horizontal, grid 12.7 mm</description>
<wire x1="-3.81" y1="-1.778" x2="3.81" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.778" x2="-3.81" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.778" x2="3.81" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.778" x2="-3.81" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.762" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.1176" shape="long"/>
<text x="-3.683" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.778" x2="-2.413" y2="1.778" layer="21"/>
<rectangle x1="-5.207" y1="-0.381" x2="-3.81" y2="0.381" layer="21"/>
<rectangle x1="3.81" y1="-0.381" x2="5.207" y2="0.381" layer="21"/>
</package>
<package name="SOD57-10" urn="urn:adsk.eagle:footprint:43130/1" library_version="2">
diameter 4 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-1.143" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="2.286" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.016" x2="1.397" y2="-1.016" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.286" y1="1.016" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.397" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.016" x2="2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.1938" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.1938" shape="long"/>
<text x="-2.286" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.8354" y1="-0.4064" x2="-2.286" y2="0.4064" layer="21"/>
<rectangle x1="2.286" y1="-0.4064" x2="3.8354" y2="0.4064" layer="21"/>
</package>
<package name="DO201-15" urn="urn:adsk.eagle:footprint:43127/1" library_version="2">
diameter 5.6 mm, horizontal, grid 15.24 mm</description>
<wire x1="-1.27" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.143" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.5842" x2="1.143" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.794" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.794" x2="-5.08" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.223" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.223" y2="0" width="1.27" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.4986" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.4986" shape="long"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.191" y1="-2.794" x2="-3.429" y2="2.794" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-5.08" y2="0.635" layer="21"/>
<rectangle x1="5.08" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
</package>
<package name="DO07" urn="urn:adsk.eagle:footprint:43160/1" library_version="2">
<wire x1="3.302" y1="1.27" x2="3.556" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.556" y1="1.016" x2="-3.302" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.556" y1="-1.016" x2="-3.302" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="3.302" y1="-1.27" x2="3.556" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="3.556" y1="-1.016" x2="3.556" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.016" x2="-3.556" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.27" x2="3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.27" x2="3.302" y2="-1.27" width="0.1524" layer="21"/>
<text x="-3.429" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="1.27" layer="21"/>
<rectangle x1="3.556" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-3.556" y2="0.254" layer="21"/>
</package>
<package name="P1-10" urn="urn:adsk.eagle:footprint:43138/1" library_version="2">
diameter 3 mm, horizontal, grid 10.16 mm</description>
<wire x1="-3.175" y1="-1.524" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.524" x2="-3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<text x="-3.048" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-3.175" y2="0.381" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
</package>
<package name="P2-15" urn="urn:adsk.eagle:footprint:43106/1" library_version="2">
diameter 5 mm, horizontal, grid 12.7 mm</description>
<wire x1="-4.826" y1="-2.54" x2="-4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.54" x2="4.826" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.54" x2="4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.54" x2="-4.826" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<text x="-4.8006" y="2.8194" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.9022" y="-4.699" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-2.54" x2="-2.921" y2="2.54" layer="21"/>
<rectangle x1="4.826" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-4.826" y2="0.635" layer="21"/>
</package>
<package name="DO34-7" urn="urn:adsk.eagle:footprint:43109/1" library_version="2">
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
</package>
<package name="SOT54H" urn="urn:adsk.eagle:footprint:43111/1" library_version="2">
2-lead plastic, vertical</description>
<wire x1="-1.651" y1="2.032" x2="1.651" y2="2.032" width="0.1524" layer="21" curve="280.388858"/>
<wire x1="1.651" y1="2.032" x2="-1.651" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-1.905" x2="0.508" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="-0.381" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.381" y1="-1.27" x2="0.508" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-0.508" y1="-1.905" x2="-0.508" y2="-0.635" width="0.2032" layer="21"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SOD523" urn="urn:adsk.eagle:footprint:43179/1" library_version="2">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="-0.59" y1="0.4" x2="0.59" y2="0.4" width="0.1016" layer="51"/>
<wire x1="0.59" y1="0.4" x2="0.59" y2="-0.4" width="0.1016" layer="51"/>
<wire x1="0.59" y1="-0.4" x2="-0.59" y2="-0.4" width="0.1016" layer="51"/>
<wire x1="-0.59" y1="-0.4" x2="-0.59" y2="0.4" width="0.1016" layer="51"/>
<smd name="A" x="0.7" y="0" dx="0.7" dy="0.5" layer="1"/>
<smd name="C" x="-0.6" y="0" dx="0.7" dy="0.5" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.75" y1="-0.17" x2="-0.54" y2="0.17" layer="51"/>
<rectangle x1="0.54" y1="-0.17" x2="0.75" y2="0.17" layer="51"/>
<rectangle x1="-0.59" y1="-0.4" x2="-0.3" y2="0.4" layer="51"/>
</package>
<package name="TO18D" urn="urn:adsk.eagle:footprint:43190/1" library_version="2">
2-lead metall, vertical</description>
<wire x1="1.651" y1="-2.286" x2="2.286" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-2.921" x2="2.921" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-2.286" x2="2.286" y2="-1.651" width="0.1524" layer="21"/>
<circle x="0" y="0.0254" radius="2.7686" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.0508" layer="21"/>
<text x="3.175" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.143" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C1702-05" urn="urn:adsk.eagle:footprint:43191/1" library_version="2">
diameter 3.5 mm, vertical, grid 5.08 mm</description>
<wire x1="2.54" y1="0" x2="0.762" y2="0" width="1.0668" layer="51"/>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="1.0668" layer="51"/>
<circle x="-2.54" y="0" radius="1.778" width="0.1524" layer="21"/>
<pad name="C" x="-2.54" y="0" drill="1.397" shape="octagon"/>
<pad name="A" x="2.54" y="0" drill="1.397" shape="octagon"/>
<text x="-4.318" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.7366" y1="-0.5334" x2="0.635" y2="0.5334" layer="21"/>
</package>
<package name="C1702-15" urn="urn:adsk.eagle:footprint:43117/1" library_version="2">
diameter 3.5 mm, horizontal, grid 15.24 mm</description>
<wire x1="-4.572" y1="-1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.1176" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.1176" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.397" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.397" shape="long"/>
<text x="-4.572" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-1.778" x2="-3.302" y2="1.778" layer="21"/>
<rectangle x1="4.572" y1="-0.5334" x2="5.9436" y2="0.5334" layer="21"/>
<rectangle x1="-5.9436" y1="-0.5334" x2="-4.572" y2="0.5334" layer="21"/>
</package>
<package name="SGA-10" urn="urn:adsk.eagle:footprint:43154/1" library_version="2">
<wire x1="5.08" y1="0" x2="3.175" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.175" y2="0" width="0.8128" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.508" x2="0.635" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-0.508" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="1.016" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="0.635" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.508" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.381" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.381" x2="2.032" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.1938" x2="-1.397" y2="-1.1938" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="1.0414" x2="-1.5748" y2="-1.016" width="0.254" layer="21"/>
<wire x1="-2.032" y1="0.381" x2="-2.032" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.381" x2="2.032" y2="0.381" width="0.1524" layer="21" curve="-145.291951"/>
<wire x1="-2.032" y1="-0.381" x2="2.032" y2="-0.381" width="0.1524" layer="21" curve="145.291951"/>
<rectangle x1="2.032" y1="-0.4064" x2="3.8608" y2="0.4064" layer="21"/>
<rectangle x1="-3.8608" y1="-0.4064" x2="-2.032" y2="0.4064" layer="21"/>
</package>
<package name="SOD64-10" urn="urn:adsk.eagle:footprint:43140/1" library_version="2">
diameter 4.8 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-2.54" y1="1.397" x2="-2.54" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.397" x2="2.54" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.397" x2="1.397" y2="-1.397" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.54" y1="1.397" x2="-1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.397" x2="-1.397" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.397" x2="2.54" y2="-1.397" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.6002" shape="long"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.397" x2="-1.397" y2="1.397" layer="21"/>
<rectangle x1="2.54" y1="-0.6604" x2="3.3274" y2="0.6604" layer="21"/>
<rectangle x1="-3.3274" y1="-0.6604" x2="-2.54" y2="0.6604" layer="21"/>
</package>
<package name="SOD61A" urn="urn:adsk.eagle:footprint:43141/1" library_version="2">
diameter 3.5 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6604" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6604" layer="51"/>
<wire x1="-2.54" y1="0.635" x2="-2.921" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.381" x2="-2.921" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-0.381" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.921" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.921" y1="0.381" x2="2.921" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.921" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.54" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-0.381" x2="2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.508" x2="2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.508" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.921" y1="0.381" x2="2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.508" x2="2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.508" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.381" x2="-2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-0.381" x2="-2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.508" x2="-2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.508" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0.381" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.54" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-0.381" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.381" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.381" x2="-2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.54" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.381" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.381" x2="-2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="2.5178" y2="0.655" width="0.1524" layer="21" curve="-84.093979"/>
<wire x1="-2.5178" y1="-0.655" x2="2.54" y2="-0.635" width="0.1524" layer="21" curve="84.093979"/>
<pad name="C" x="-5.08" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.9144" shape="long"/>
<text x="-2.54" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.921" y1="-0.3302" x2="4.0132" y2="0.3302" layer="21"/>
<rectangle x1="-4.0132" y1="-0.3302" x2="-2.921" y2="0.3302" layer="21"/>
<rectangle x1="2.54" y1="-0.381" x2="2.921" y2="0.381" layer="21"/>
<rectangle x1="-2.921" y1="-0.381" x2="-2.54" y2="0.381" layer="21"/>
</package>
<package name="SOD61B" urn="urn:adsk.eagle:footprint:43142/1" library_version="2">
diameter 3.5 mm, vertical, grid 15.24 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6604" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6604" layer="51"/>
<wire x1="-4.445" y1="0.635" x2="-4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.635" x2="-4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.381" x2="-4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.381" x2="-4.445" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.635" x2="4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.381" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.381" x2="4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.508" x2="4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.508" x2="4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.381" x2="4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.508" x2="4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.508" x2="4.445" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.381" x2="-4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.381" x2="-4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.445" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="4.699" y1="0.381" x2="4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.381" x2="4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-0.381" x2="4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.381" x2="4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.381" x2="-4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.381" x2="-4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0.381" x2="-4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.381" x2="-4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.635" x2="4.4429" y2="0.636" width="0.1524" layer="21" curve="-52.21463"/>
<wire x1="-4.4429" y1="-0.636" x2="4.445" y2="-0.635" width="0.1524" layer="21" curve="52.21463"/>
<pad name="C" x="-7.62" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="7.62" y="0" drill="0.9144" shape="long"/>
<text x="-2.794" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.381" x2="4.826" y2="0.381" layer="21"/>
<rectangle x1="-4.826" y1="-0.381" x2="-4.445" y2="0.381" layer="21"/>
<rectangle x1="4.826" y1="-0.3302" x2="6.5278" y2="0.3302" layer="21"/>
<rectangle x1="-6.5278" y1="-0.3302" x2="-4.826" y2="0.3302" layer="21"/>
</package>
<package name="SOD61C" urn="urn:adsk.eagle:footprint:43143/1" library_version="2">
diameter 3.5 mm, vertical, grid 17.78 mm</description>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="0.6604" layer="51"/>
<wire x1="-8.89" y1="0" x2="-7.874" y2="0" width="0.6604" layer="51"/>
<wire x1="-5.588" y1="0.635" x2="-5.969" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.635" x2="-5.588" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="0.381" x2="-5.969" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-0.381" x2="-5.588" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.635" x2="5.969" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.969" y1="0.381" x2="5.969" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.635" x2="5.969" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.635" x2="5.588" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-0.381" x2="5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.508" x2="5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.508" x2="5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.969" y1="0.381" x2="5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.508" x2="5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.508" x2="5.588" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="0.381" x2="-5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.508" x2="-5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.508" x2="-5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-0.381" x2="-5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-0.508" x2="-5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-0.508" x2="-5.588" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.381" x2="5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.381" x2="5.588" y2="0.508" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-0.381" x2="5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.381" x2="5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-0.381" x2="-5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-0.381" x2="-5.588" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="0.381" x2="-5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.381" x2="-5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.55" y1="0.65" x2="-4.55" y2="1" width="0.1524" layer="21"/>
<wire x1="-4.55" y1="1" x2="-3.4" y2="1.3" width="0.1524" layer="21"/>
<wire x1="-3.4" y1="1.3" x2="-2.05" y2="1.55" width="0.1524" layer="21"/>
<wire x1="-2.05" y1="1.55" x2="-1" y2="1.65" width="0.1524" layer="21"/>
<wire x1="-1" y1="1.65" x2="0" y2="1.7" width="0.1524" layer="21"/>
<wire x1="5.55" y1="-0.65" x2="4.55" y2="-1" width="0.1524" layer="21"/>
<wire x1="4.55" y1="-1" x2="3.4" y2="-1.3" width="0.1524" layer="21"/>
<wire x1="3.4" y1="-1.3" x2="2.05" y2="-1.55" width="0.1524" layer="21"/>
<wire x1="2.05" y1="-1.55" x2="1" y2="-1.65" width="0.1524" layer="21"/>
<wire x1="1" y1="-1.65" x2="0" y2="-1.7" width="0.1524" layer="21"/>
<wire x1="5.55" y1="0.65" x2="4.55" y2="1" width="0.1524" layer="21"/>
<wire x1="4.55" y1="1" x2="3.4" y2="1.3" width="0.1524" layer="21"/>
<wire x1="3.4" y1="1.3" x2="2.05" y2="1.55" width="0.1524" layer="21"/>
<wire x1="2.05" y1="1.55" x2="1" y2="1.65" width="0.1524" layer="21"/>
<wire x1="1" y1="1.65" x2="0" y2="1.7" width="0.1524" layer="21"/>
<wire x1="-5.55" y1="-0.65" x2="-4.55" y2="-1" width="0.1524" layer="21"/>
<wire x1="-4.55" y1="-1" x2="-3.4" y2="-1.3" width="0.1524" layer="21"/>
<wire x1="-3.4" y1="-1.3" x2="-2.05" y2="-1.55" width="0.1524" layer="21"/>
<wire x1="-2.05" y1="-1.55" x2="-1" y2="-1.65" width="0.1524" layer="21"/>
<wire x1="-1" y1="-1.65" x2="0" y2="-1.7" width="0.1524" layer="21"/>
<pad name="C" x="-8.89" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="8.89" y="0" drill="0.9144" shape="long"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="5.588" y1="-0.381" x2="5.969" y2="0.381" layer="21"/>
<rectangle x1="-5.969" y1="-0.381" x2="-5.588" y2="0.381" layer="21"/>
<rectangle x1="5.969" y1="-0.3302" x2="7.8232" y2="0.3302" layer="21"/>
<rectangle x1="-7.8232" y1="-0.3302" x2="-5.969" y2="0.3302" layer="21"/>
</package>
<package name="SOD61D" urn="urn:adsk.eagle:footprint:43144/1" library_version="2">
<wire x1="-4.826" y1="0.635" x2="-5.207" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.635" x2="-4.826" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="0.381" x2="-5.207" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-0.381" x2="-4.826" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.635" x2="5.207" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0.381" x2="5.207" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.635" x2="5.207" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.635" x2="4.826" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-0.381" x2="5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.508" x2="5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.508" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0.381" x2="5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.508" x2="5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.508" x2="4.826" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="0.381" x2="-5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.508" x2="-5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.508" x2="-4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-0.381" x2="-5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.508" x2="-5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.508" x2="-4.826" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.381" x2="4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.381" x2="4.826" y2="0.508" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.381" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.381" x2="4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.381" x2="-4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.381" x2="-4.826" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.381" x2="-4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.635" x2="4.8254" y2="0.6353" width="0.1524" layer="21" curve="-49.511667"/>
<wire x1="-4.8254" y1="-0.6353" x2="4.826" y2="-0.635" width="0.1524" layer="21" curve="49.511667"/>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.826" y1="-0.381" x2="5.207" y2="0.381" layer="21"/>
<rectangle x1="-5.207" y1="-0.381" x2="-4.826" y2="0.381" layer="21"/>
<rectangle x1="5.207" y1="-0.3302" x2="6.5278" y2="0.3302" layer="21"/>
<rectangle x1="-6.5278" y1="-0.3302" x2="-5.207" y2="0.3302" layer="21"/>
</package>
<package name="SOD61E" urn="urn:adsk.eagle:footprint:43145/1" library_version="2">
diameter 3.5 mm, vertical, grid 20.32 mm</description>
<wire x1="10.16" y1="0" x2="9.144" y2="0" width="0.6604" layer="51"/>
<wire x1="-10.16" y1="0" x2="-9.144" y2="0" width="0.6604" layer="51"/>
<wire x1="-6.35" y1="0.635" x2="-6.731" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0.381" x2="-6.731" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.381" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.731" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.731" y1="0.381" x2="6.731" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.731" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.35" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-0.381" x2="6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.508" x2="6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.508" x2="6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.731" y1="0.381" x2="6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.508" x2="6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.508" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0.381" x2="-6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.508" x2="-6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.508" x2="-6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.381" x2="-6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.508" x2="-6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.508" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.604" y1="0.381" x2="6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.381" x2="6.35" y2="0.508" width="0.1524" layer="21"/>
<wire x1="6.604" y1="-0.381" x2="6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.381" x2="6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-0.381" x2="-6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.381" x2="-6.35" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="0.381" x2="-6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.381" x2="-6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="6.3161" y2="0.6464" width="0.1524" layer="21" curve="-37.137105"/>
<wire x1="-6.3161" y1="-0.6464" x2="6.35" y2="-0.635" width="0.1524" layer="21" curve="37.137105"/>
<pad name="C" x="-10.16" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="10.16" y="0" drill="0.9144" shape="long"/>
<text x="-3.048" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.35" y1="-0.381" x2="6.731" y2="0.381" layer="21"/>
<rectangle x1="-6.731" y1="-0.381" x2="-6.35" y2="0.381" layer="21"/>
<rectangle x1="6.731" y1="-0.3302" x2="9.0678" y2="0.3302" layer="21"/>
<rectangle x1="-9.0678" y1="-0.3302" x2="-6.731" y2="0.3302" layer="21"/>
</package>
<package name="DO27-15" urn="urn:adsk.eagle:footprint:43095/1" library_version="2">
diameter 5 mm, horizontal, grid 15.24 mm</description>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<text x="-5.08" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.191" y1="-2.54" x2="-3.429" y2="2.54" layer="21"/>
</package>
<package name="SOD81" urn="urn:adsk.eagle:footprint:43125/1" library_version="2">
diameter 2.3 mm, vertical, grid 10.16 mm</description>
<wire x1="-1.905" y1="1.143" x2="1.905" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.159" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.381" x2="2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.508" x2="2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.508" x2="2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.508" x2="2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.508" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.381" x2="-2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.508" x2="-2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.508" x2="-2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.508" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.508" x2="-2.159" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.381" x2="2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.381" x2="2.159" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.381" x2="2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.381" x2="2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.381" x2="-2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.381" x2="-2.159" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="0.381" x2="-2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.381" x2="-2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.143" x2="2.159" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.159" y1="0.889" x2="-1.905" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.905" y1="1.143" x2="2.159" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.889" x2="-1.905" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.905" y1="-1.143" x2="1.905" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="0.889" width="0.1524" layer="21"/>
<text x="-2.032" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-1.651" y1="-1.143" x2="-1.143" y2="1.143" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.159" y2="0.381" layer="21"/>
<rectangle x1="2.159" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
</package>
<package name="SOD84" urn="urn:adsk.eagle:footprint:43139/1" library_version="2">
diameter 3.3 mm, vertical, grid 10.16 mm</description>
<wire x1="-1.905" y1="1.651" x2="1.905" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.651" x2="2.159" y2="-1.397" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.159" y1="1.397" x2="-1.905" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.905" y1="1.651" x2="2.159" y2="1.397" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-1.397" x2="-1.905" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.905" y1="-1.651" x2="1.905" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="1.397" width="0.1524" layer="21"/>
<text x="-2.032" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.651" x2="-1.143" y2="1.651" layer="21"/>
</package>
<package name="F126-10" urn="urn:adsk.eagle:footprint:43161/1" library_version="2">
<pad name="C" x="-5.08" y="0" drill="1.016" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.016" shape="long"/>
<text x="-3.175" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-2.54" y1="-1.524" x2="-1.778" y2="1.524" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="3.7338" y2="0.4064" layer="21"/>
<rectangle x1="-3.7338" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
</package>
<package name="DO220S" urn="urn:adsk.eagle:footprint:43133/1" library_version="2">
2-lead molded, vertical</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="C" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-4.572" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
<rectangle x1="-1.651" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
</package>
<package name="TO220AC" urn="urn:adsk.eagle:footprint:43128/1" library_version="2">
2-lead molded, horizontal</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="2.921" width="0" layer="42"/>
<circle x="0" y="11.176" radius="2.921" width="0" layer="43"/>
<pad name="C" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.461" y="-1.27" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="10">A17,5mm</text>
<rectangle x1="2.159" y1="-4.445" x2="2.921" y2="-3.81" layer="21"/>
<rectangle x1="-2.921" y1="-4.445" x2="-2.159" y2="-3.81" layer="21"/>
<rectangle x1="-3.175" y1="-3.81" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-3.81" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-6.35" x2="2.921" y2="-4.445" layer="51"/>
<rectangle x1="-2.921" y1="-6.35" x2="-2.159" y2="-4.445" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<package name="TO220ACS" urn="urn:adsk.eagle:footprint:43137/1" library_version="2">
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="G4-12" urn="urn:adsk.eagle:footprint:43131/1" library_version="2">
diameter 7.62 mm, horizontal, grid 12.7 mm</description>
<wire x1="3.556" y1="1.27" x2="3.556" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="-3.556" y1="-1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="1.27" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="1.27" layer="51"/>
<wire x1="3.937" y1="0.889" x2="4.318" y2="0.508" width="0.6096" layer="21"/>
<wire x1="4.318" y1="-0.508" x2="3.937" y2="-0.889" width="0.6096" layer="21"/>
<wire x1="-4.318" y1="0.508" x2="-3.937" y2="0.889" width="0.6096" layer="21"/>
<wire x1="-4.318" y1="-0.508" x2="-3.937" y2="-0.889" width="0.6096" layer="21"/>
<wire x1="-2.667" y1="-2.286" x2="-2.667" y2="2.286" width="0.6096" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.6096" layer="21"/>
<wire x1="-3.556" y1="1.016" x2="-3.556" y2="-1.016" width="0.6096" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-2.921" y2="-2.032" width="0.6096" layer="21"/>
<wire x1="-2.921" y1="2.032" x2="-3.175" y2="1.524" width="0.6096" layer="21"/>
<circle x="0" y="0" radius="3.81" width="0.1524" layer="21"/>
<pad name="C" x="-6.35" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.6002" shape="long"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.81" y1="-0.635" x2="4.953" y2="0.635" layer="21"/>
<rectangle x1="-4.953" y1="-0.635" x2="-3.81" y2="0.635" layer="21"/>
</package>
<package name="SOD83-12" urn="urn:adsk.eagle:footprint:43146/1" library_version="2">
diameter 4.8 mm, vertical, grid 12.7 mm</description>
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="1.3716" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="1.3716" layer="51"/>
<wire x1="-3.81" y1="1.397" x2="-3.81" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.397" x2="3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.397" x2="-2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="3.81" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="2.6841" y2="1.3841" width="0.1524" layer="21" curve="-74.015899"/>
<wire x1="-2.6841" y1="-1.3841" x2="2.667" y2="-1.397" width="0.1524" layer="21" curve="74.015899"/>
<rectangle x1="-3.175" y1="-1.397" x2="-2.667" y2="1.397" layer="21"/>
<rectangle x1="3.81" y1="-0.6604" x2="4.6228" y2="0.6604" layer="21"/>
<rectangle x1="-4.6228" y1="-0.6604" x2="-3.81" y2="0.6604" layer="21"/>
</package>
<package name="SMB" urn="urn:adsk.eagle:footprint:43181/1" library_version="2">
<wire x1="-2.2606" y1="1.905" x2="2.2606" y2="1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="2.2606" y2="-1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="-2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="2.2606" y1="-1.905" x2="2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="0.193" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.193" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.193" y1="-1" x2="0.193" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="A" x="2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<text x="-2.159" y="2.159" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.0922" x2="-2.2606" y2="1.0922" layer="51"/>
<rectangle x1="2.2606" y1="-1.0922" x2="2.794" y2="1.0922" layer="51"/>
<rectangle x1="-1.35" y1="-1.9" x2="-0.8" y2="1.9" layer="51"/>
</package>
<package name="P6-15" urn="urn:adsk.eagle:footprint:43097/1" library_version="2">
diameter 9 mm, horizontal, grid 15.24 mm</description>
<wire x1="-4.699" y1="-4.572" x2="-4.699" y2="4.572" width="0.1524" layer="21"/>
<wire x1="4.699" y1="4.572" x2="4.699" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="4.572" x2="4.699" y2="4.572" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.572" x2="-4.699" y2="-4.572" width="0.1524" layer="21"/>
<pad name="C" x="-7.62" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.6002" shape="long"/>
<text x="-4.6736" y="4.8514" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.3622" y="-3.302" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-4.572" x2="-2.921" y2="4.572" layer="21"/>
<rectangle x1="4.699" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-4.699" y2="0.635" layer="21"/>
</package>
<package name="C2673" urn="urn:adsk.eagle:footprint:43156/1" library_version="2">
diameter 5.2 mm, horizontal, grid 15.24 mm</description>
<wire x1="4.826" y1="-2.667" x2="-4.826" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.667" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.826" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.27" layer="51"/>
<text x="-4.699" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.937" y1="-2.667" x2="-2.54" y2="2.667" layer="21"/>
</package>
<package name="C221B1A" urn="urn:adsk.eagle:footprint:43158/1" library_version="2">
<wire x1="5.207" y1="14.478" x2="-5.207" y2="14.478" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.001" x2="-5.207" y2="8.001" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.001" x2="5.207" y2="14.478" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="8.001" x2="-5.207" y2="14.478" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="8.001" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="8.001" width="0.1524" layer="21"/>
<wire x1="4.953" y1="6.731" x2="4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="4.953" y1="6.731" x2="-4.953" y2="6.731" width="0.0508" layer="21"/>
<wire x1="4.953" y1="-1.016" x2="-4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="-4.953" y1="6.731" x2="-4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="-2.794" y1="-4.191" x2="-3.175" y2="-3.81" width="0.508" layer="21"/>
<wire x1="3.175" y1="-3.81" x2="2.794" y2="-4.191" width="0.508" layer="21"/>
<text x="-2.54" y="4.191" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="1.651" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.826" y="8.382" size="0.9906" layer="21" ratio="10">A17,5mm</text>
<rectangle x1="-3.429" y1="-3.81" x2="-2.159" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-3.81" x2="3.429" y2="-1.27" layer="21"/>
</package>
<package name="SOD80C" urn="urn:adsk.eagle:footprint:43180/1" library_version="2">
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
<package name="D-10" urn="urn:adsk.eagle:footprint:43192/1" library_version="2">
<description>&lt;b&gt;DIODE&lt;/b&gt;</description>
<wire x1="-3.175" y1="0" x2="-3.937" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="3.937" y1="0" x2="3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="0" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.286" y1="-1.524" x2="-1.524" y2="1.524" layer="21"/>
</package>
<package name="D-12.5" urn="urn:adsk.eagle:footprint:43193/1" library_version="2">
<wire x1="-3.175" y1="0" x2="-5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0" x2="3.175" y2="0" width="0.1524" layer="21"/>
<pad name="A" x="6.35" y="0" drill="0.8128" shape="long"/>
<pad name="C" x="-6.35" y="0" drill="0.8128" shape="long"/>
</package>
<package name="D-2.5" urn="urn:adsk.eagle:footprint:43194/1" library_version="2">
<wire x1="0.508" y1="0.762" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-0.762" x2="0.508" y2="0.762" width="0.1524" layer="21"/>
<text x="-1.651" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="D-5" urn="urn:adsk.eagle:footprint:43195/1" library_version="2">
<wire x1="1.397" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-0.889" x2="1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0.889" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-0.889" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0" x2="-1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0" x2="1.397" y2="0.889" width="0.1524" layer="21"/>
<pad name="A" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.905" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-1.016" y1="-0.889" x2="-0.508" y2="0.889" layer="21"/>
</package>
<package name="D-7.5" urn="urn:adsk.eagle:footprint:43196/1" library_version="2">
<wire x1="1.905" y1="0.889" x2="-1.905" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-0.889" x2="1.905" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0.889" x2="-1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-0.889" x2="1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.905" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.905" y1="0" x2="1.905" y2="0.889" width="0.1524" layer="21"/>
<rectangle x1="-1.27" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
</package>
<package name="SOD106-R" urn="urn:adsk.eagle:footprint:43197/1" library_version="2">
<description>&lt;b&gt;SOD106 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="1.8208" y1="0.7874" x2="-1.8208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.8208" y1="-0.7874" x2="-1.8208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.127" y1="0.6" x2="-0.873" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.873" y1="0" x2="0.127" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.127" y1="-0.6" x2="0.127" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-2.25" y="0" dx="1.6" dy="2.1" layer="1"/>
<smd name="A" x="2.25" y="0" dx="1.6" dy="2.1" layer="1"/>
<text x="-1.524" y="1.293" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.563" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3542" y1="-0.8636" x2="-1.7954" y2="0.8636" layer="51"/>
<rectangle x1="1.7954" y1="-0.8636" x2="2.3542" y2="0.8636" layer="51"/>
<rectangle x1="-1.3636" y1="-0.7874" x2="-0.754" y2="0.7874" layer="21"/>
</package>
<package name="SMC" urn="urn:adsk.eagle:footprint:43198/1" library_version="2">
<wire x1="-3.5606" y1="3.105" x2="3.5606" y2="3.105" width="0.1016" layer="21"/>
<wire x1="-3.5606" y1="-3.105" x2="3.5606" y2="-3.105" width="0.1016" layer="21"/>
<wire x1="-3.5606" y1="-3.105" x2="-3.5606" y2="3.105" width="0.1016" layer="51"/>
<wire x1="3.5606" y1="-3.105" x2="3.5606" y2="3.105" width="0.1016" layer="51"/>
<wire x1="0.543" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.543" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.543" y1="-1" x2="0.543" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-3.7" y="0" dx="2.8" dy="3.8" layer="1"/>
<smd name="A" x="3.7" y="0" dx="2.8" dy="3.8" layer="1"/>
<text x="-3.459" y="3.359" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.459" y="-4.629" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.094" y1="-1.0922" x2="-3.5606" y2="1.0922" layer="51"/>
<rectangle x1="3.5606" y1="-1.0922" x2="4.094" y2="1.0922" layer="51"/>
<rectangle x1="-2.1" y1="-3.1" x2="-0.85" y2="3.1" layer="21"/>
</package>
<package name="SOD106-W" urn="urn:adsk.eagle:footprint:43199/1" library_version="2">
<description>&lt;b&gt;SOD106 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-2.85" y="0" dx="2.3" dy="3.2" layer="1"/>
<smd name="A" x="2.85" y="0" dx="2.3" dy="3.2" layer="1"/>
<text x="-3.374" y="1.793" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.324" y="-3.163" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SOD106A-R" urn="urn:adsk.eagle:footprint:43200/1" library_version="2">
<description>&lt;b&gt;SOD106A Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-2.2" y="0" dx="1.7" dy="2.1" layer="1"/>
<smd name="A" x="2.2" y="0" dx="1.7" dy="2.1" layer="1"/>
<text x="-2.374" y="1.293" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.374" y="-2.513" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.3636" y1="-0.7874" x2="-0.754" y2="0.7874" layer="51"/>
</package>
<package name="SOD110-W" urn="urn:adsk.eagle:footprint:43201/1" library_version="2">
<description>&lt;b&gt;SOD110 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1" y1="0.5" x2="1.05" y2="0.5" width="0.1016" layer="51"/>
<wire x1="1.05" y1="0.5" x2="1.05" y2="-0.5" width="0.1016" layer="51"/>
<wire x1="1.05" y1="-0.5" x2="-1" y2="-0.5" width="0.1016" layer="51"/>
<wire x1="-1" y1="-0.5" x2="-1" y2="0.5" width="0.1016" layer="51"/>
<smd name="C" x="-1.15" y="0" dx="1" dy="1.2" layer="1"/>
<smd name="A" x="1.15" y="0" dx="1" dy="1.2" layer="1"/>
<rectangle x1="-0.65" y1="-0.45" x2="-0.4" y2="0.45" layer="51"/>
</package>
<package name="SOD110-R" urn="urn:adsk.eagle:footprint:43202/1" library_version="2">
<description>&lt;b&gt;SOD110 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-0.95" y="0" dx="0.8" dy="1" layer="1"/>
<smd name="A" x="0.95" y="0" dx="0.8" dy="1" layer="1"/>
</package>
<package name="SOD123" urn="urn:adsk.eagle:footprint:43203/1" library_version="2">
<description>&lt;b&gt;Diode&lt;/b&gt;</description>
<wire x1="-1.1" y1="0.7" x2="1.1" y2="0.7" width="0.254" layer="51"/>
<wire x1="1.1" y1="0.7" x2="1.1" y2="-0.7" width="0.254" layer="51"/>
<wire x1="1.1" y1="-0.7" x2="-1.1" y2="-0.7" width="0.254" layer="51"/>
<wire x1="-1.1" y1="-0.7" x2="-1.1" y2="0.7" width="0.254" layer="51"/>
<smd name="C" x="-1.9" y="0" dx="1.4" dy="1.4" layer="1"/>
<smd name="A" x="1.9" y="0" dx="1.4" dy="1.4" layer="1"/>
<text x="-1.1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.1" y="-2.3" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.95" y1="-0.45" x2="-1.2" y2="0.4" layer="51"/>
<rectangle x1="1.2" y1="-0.45" x2="1.95" y2="0.4" layer="51"/>
<rectangle x1="-1.05" y1="-0.65" x2="-0.15" y2="0.7" layer="51"/>
</package>
<package name="SOD323-R" urn="urn:adsk.eagle:footprint:43204/1" library_version="2">
<description>&lt;b&gt;SOD323 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1" y1="0.7" x2="1" y2="0.7" width="0.1524" layer="21"/>
<wire x1="1" y1="0.7" x2="1" y2="-0.7" width="0.1524" layer="51"/>
<wire x1="1" y1="-0.7" x2="-1" y2="-0.7" width="0.1524" layer="21"/>
<wire x1="-1" y1="-0.7" x2="-1" y2="0.7" width="0.1524" layer="51"/>
<wire x1="-0.5" y1="0" x2="0.1" y2="0.4" width="0.1524" layer="21"/>
<wire x1="0.1" y1="0.4" x2="0.1" y2="-0.4" width="0.1524" layer="21"/>
<wire x1="0.1" y1="-0.4" x2="-0.5" y2="0" width="0.1524" layer="21"/>
<smd name="C" x="-1.1" y="0" dx="0.6" dy="0.6" layer="1"/>
<smd name="A" x="1.1" y="0" dx="0.6" dy="0.6" layer="1"/>
<rectangle x1="-0.7" y1="-0.7" x2="-0.5" y2="0.7" layer="51"/>
</package>
<package name="SOD323-W" urn="urn:adsk.eagle:footprint:43205/1" library_version="2">
<description>&lt;b&gt;SOD323 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1" y1="0.7" x2="1" y2="0.7" width="0.1524" layer="51"/>
<wire x1="1" y1="-0.7" x2="-1" y2="-0.7" width="0.1524" layer="51"/>
<smd name="C" x="-1.45" y="0" dx="1.5" dy="1.2" layer="1"/>
<smd name="A" x="1.45" y="0" dx="1.5" dy="1.2" layer="1"/>
</package>
<package name="GF1" urn="urn:adsk.eagle:footprint:43206/1" library_version="2">
<description>&lt;b&gt;GF1&lt;/b&gt;&lt;p&gt;
General Semiconductor</description>
<wire x1="-2.24" y1="1.32" x2="2.24" y2="1.32" width="0.254" layer="21"/>
<wire x1="2.24" y1="1.32" x2="2.24" y2="-1.32" width="0.254" layer="21"/>
<wire x1="2.24" y1="-1.32" x2="-2.24" y2="-1.32" width="0.254" layer="21"/>
<wire x1="-2.24" y1="-1.32" x2="-2.24" y2="1.32" width="0.254" layer="21"/>
<smd name="C" x="-2.12" y="0" dx="1.32" dy="1.68" layer="1"/>
<smd name="A" x="1.87" y="0" dx="1.85" dy="1.68" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.86" y1="-0.84" x2="-2.32" y2="0.84" layer="51"/>
<rectangle x1="2.34" y1="-0.84" x2="2.86" y2="0.84" layer="51"/>
<rectangle x1="-1.9" y1="-1.05" x2="-1.25" y2="1.05" layer="51"/>
<rectangle x1="-1.4" y1="-1.05" x2="-1.25" y2="1.05" layer="21"/>
</package>
<package name="MINIMELF" urn="urn:adsk.eagle:footprint:43207/1" library_version="2">
<description>&lt;b&gt;Mini Melf Diode&lt;/b&gt;</description>
<wire x1="0.5" y1="0.5" x2="-0.5" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.5" y1="0" x2="0.5" y2="-0.5" width="0.2032" layer="21"/>
<wire x1="0.5" y1="-0.5" x2="0.5" y2="0.5" width="0.2032" layer="21"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MELF-MLL41" urn="urn:adsk.eagle:footprint:43208/1" library_version="2">
<description>&lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;
Package DO-213AB = http://www.diotec.com/pdf/sm4001.pdf</description>
<wire x1="2.0828" y1="1.1938" x2="-2.159" y2="1.1938" width="0.1524" layer="51"/>
<wire x1="2.0828" y1="-1.1938" x2="-2.1336" y2="-1.1938" width="0.1524" layer="51"/>
<wire x1="0.627" y1="1" x2="-0.746" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.746" y1="0" x2="0.627" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-1" x2="0.627" y2="1" width="0.2032" layer="21"/>
<wire x1="1.1208" y1="1.1938" x2="-1.097" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="1.1208" y1="-1.1938" x2="-1.0716" y2="-1.1938" width="0.1524" layer="21"/>
<smd name="C" x="-2.625" y="0" dx="2.5" dy="3" layer="1"/>
<smd name="A" x="2.625" y="0" dx="2.5" dy="3" layer="1"/>
<text x="-2.663" y="1.724" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.663" y="-2.994" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.0574" y1="-1.27" x2="2.5654" y2="1.27" layer="51"/>
<rectangle x1="-2.6162" y1="-1.27" x2="-2.1082" y2="1.27" layer="51"/>
<rectangle x1="-1.4478" y1="-1.1938" x2="-0.5588" y2="1.1938" layer="51"/>
</package>
<package name="MICROMELF-R" urn="urn:adsk.eagle:footprint:43209/1" library_version="2">
<description>&lt;b&gt;Micro Melf Diode Reflow soldering&lt;/b&gt; VISHAY mcl4148.pdf</description>
<wire x1="-0.65" y1="0.55" x2="0.65" y2="0.55" width="0.1524" layer="51"/>
<wire x1="-0.65" y1="-0.55" x2="0.65" y2="-0.55" width="0.1524" layer="51"/>
<smd name="C" x="-0.8" y="0" dx="0.8" dy="1.2" layer="1"/>
<smd name="A" x="0.8" y="0" dx="0.8" dy="1.2" layer="1"/>
<text x="-1.201" y="0.843" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.201" y="-2.063" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.95" y1="-0.65" x2="-0.65" y2="0.65" layer="51"/>
<rectangle x1="0.65" y1="-0.65" x2="0.95" y2="0.65" layer="51"/>
<rectangle x1="-0.5" y1="-0.55" x2="-0.2" y2="0.55" layer="51"/>
</package>
<package name="MICROMELF-W" urn="urn:adsk.eagle:footprint:43210/1" library_version="2">
<description>&lt;b&gt;Micro Melf Diode Wave soldering&lt;/b&gt; VISHAY mcl4148.pdf</description>
<smd name="C" x="-0.95" y="0" dx="0.9" dy="1.4" layer="1"/>
<smd name="A" x="0.95" y="0" dx="0.9" dy="1.4" layer="1"/>
<rectangle x1="-0.5" y1="-0.5" x2="-0.2" y2="0.55" layer="51"/>
</package>
<package name="SC79_INFINEON" urn="urn:adsk.eagle:footprint:43211/1" library_version="2">
<description>&lt;b&gt;Diode Package&lt;/b&gt; Reflow soldering&lt;p&gt;
INFINEON, www.infineon.com/cmc_upload/0/000/010/257/eh_db_5b.pdf</description>
<wire x1="-0.55" y1="0.35" x2="0.55" y2="0.35" width="0.1016" layer="21"/>
<wire x1="0.55" y1="0.35" x2="0.55" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="0.55" y1="-0.35" x2="-0.55" y2="-0.35" width="0.1016" layer="21"/>
<wire x1="-0.55" y1="-0.35" x2="-0.55" y2="0.35" width="0.1016" layer="51"/>
<smd name="C" x="-0.675" y="0" dx="0.35" dy="0.35" layer="1"/>
<smd name="A" x="0.675" y="0" dx="0.35" dy="0.35" layer="1"/>
<text x="-0.8" y="0.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.8" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.15" x2="-0.55" y2="0.15" layer="51"/>
<rectangle x1="0.55" y1="-0.15" x2="0.8" y2="0.15" layer="51"/>
<rectangle x1="-0.55" y1="-0.35" x2="0" y2="0.35" layer="51"/>
</package>
<package name="SCD80_INFINEON" urn="urn:adsk.eagle:footprint:43212/1" library_version="2">
<wire x1="-0.6" y1="0.35" x2="-0.6" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="-0.6" y1="-0.35" x2="0.6" y2="-0.35" width="0.1016" layer="21"/>
<wire x1="0.6" y1="-0.35" x2="0.6" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.6" y1="0.35" x2="-0.6" y2="0.35" width="0.1016" layer="21"/>
<smd name="C" x="-0.725" y="0" dx="0.35" dy="0.35" layer="1"/>
<smd name="A" x="0.725" y="0" dx="0.35" dy="0.35" layer="1"/>
<text x="-0.9" y="0.5" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.9" y="-1.8" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6" y1="-0.35" x2="0" y2="0.35" layer="51"/>
<rectangle x1="-0.85" y1="-0.15" x2="-0.6" y2="0.15" layer="51"/>
<rectangle x1="0.6" y1="-0.15" x2="0.85" y2="0.15" layer="51"/>
</package>
<package name="DO214AA" urn="urn:adsk.eagle:footprint:43213/1" library_version="2">
<wire x1="-2.4" y1="1.1" x2="2.4" y2="1.1" width="0.254" layer="51"/>
<wire x1="2.4" y1="1.1" x2="2.4" y2="-1.1" width="0.254" layer="51"/>
<wire x1="2.4" y1="-1.1" x2="-2.4" y2="-1.1" width="0.254" layer="51"/>
<wire x1="-2.4" y1="-1.1" x2="-2.4" y2="1.1" width="0.254" layer="51"/>
<wire x1="-1.2" y1="0" x2="0.05" y2="0.7" width="0.254" layer="21"/>
<wire x1="0.05" y1="0.7" x2="0.05" y2="-0.7" width="0.254" layer="21"/>
<wire x1="0.05" y1="-0.7" x2="-1.2" y2="0" width="0.254" layer="21"/>
<smd name="C" x="-2.55" y="0" dx="1.8" dy="2.2" layer="1"/>
<smd name="A" x="2.55" y="0" dx="1.8" dy="2.2" layer="1"/>
<text x="-2.64" y="1.436" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.64" y="-2.706" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.75" y1="-0.7" x2="-2.5" y2="0.65" layer="51"/>
<rectangle x1="2.5" y1="-0.7" x2="2.75" y2="0.65" layer="51"/>
<rectangle x1="-1.4" y1="-1.05" x2="-1.1" y2="1.05" layer="21"/>
</package>
<package name="DO214AC" urn="urn:adsk.eagle:footprint:43214/1" library_version="2">
<wire x1="-2.3" y1="1" x2="2.3" y2="1" width="0.254" layer="51"/>
<wire x1="2.3" y1="1" x2="2.3" y2="-0.95" width="0.254" layer="51"/>
<wire x1="2.3" y1="-0.95" x2="-2.3" y2="-0.95" width="0.254" layer="51"/>
<wire x1="-2.3" y1="-0.95" x2="-2.3" y2="1" width="0.254" layer="51"/>
<wire x1="-0.8" y1="0" x2="0.25" y2="0.75" width="0.254" layer="21"/>
<wire x1="0.25" y1="0.75" x2="0.25" y2="-0.7" width="0.254" layer="21"/>
<wire x1="0.25" y1="-0.7" x2="-0.8" y2="0" width="0.254" layer="21"/>
<smd name="C" x="-2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<smd name="A" x="2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<text x="-2.64" y="1.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.64" y="-2.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.65" y1="-0.7" x2="-2.4" y2="0.65" layer="51"/>
<rectangle x1="2.4" y1="-0.7" x2="2.65" y2="0.65" layer="51"/>
<rectangle x1="-1" y1="-1.05" x2="-0.7" y2="1.05" layer="21"/>
</package>
<package name="DO214BA" urn="urn:adsk.eagle:footprint:43215/1" library_version="2">
<wire x1="-2.5" y1="1.35" x2="2.5" y2="1.35" width="0.254" layer="51"/>
<wire x1="2.5" y1="1.35" x2="2.5" y2="-1.35" width="0.254" layer="51"/>
<wire x1="2.5" y1="-1.35" x2="-2.5" y2="-1.35" width="0.254" layer="51"/>
<wire x1="-2.5" y1="-1.35" x2="-2.5" y2="1.35" width="0.254" layer="51"/>
<wire x1="-0.8" y1="0" x2="0.65" y2="0.95" width="0.254" layer="21"/>
<wire x1="0.65" y1="0.95" x2="0.65" y2="-0.95" width="0.254" layer="21"/>
<wire x1="0.65" y1="-0.95" x2="-0.8" y2="0" width="0.254" layer="21"/>
<text x="-2.64" y="1.736" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.64" y="-3.056" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.85" y1="-0.7" x2="-2.6" y2="0.65" layer="51"/>
<rectangle x1="2.6" y1="-0.7" x2="2.85" y2="0.65" layer="51"/>
</package>
<package name="DO41-7.6" urn="urn:adsk.eagle:footprint:43217/1" library_version="2">
<description>&lt;b&gt;DO41&lt;/b&gt; 7.6mm x 2mm&lt;p&gt;
Source: http://www.diodes.com/datasheets/ds23001.pdf</description>
<wire x1="2.082" y1="-0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="2.082" y1="-0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.494" y2="0" width="0.85" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.519" y2="0" width="0.85" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="1.1" diameter="1.7"/>
<pad name="A" x="3.81" y="0" drill="1.1" diameter="1.7"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.95" x2="-1.143" y2="0.92" layer="21"/>
<rectangle x1="2.082" y1="-0.425" x2="2.717" y2="0.425" layer="21"/>
<rectangle x1="-2.717" y1="-0.425" x2="-2.082" y2="0.425" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="DO-214AC" urn="urn:adsk.eagle:package:43416/2" type="model" library_version="2">
<description>SURFACE MOUNT GENERAL RECTIFIER JEDEC DO-214AC molded platic body
Method 2026
Source: http://www.kingtronics.com/SMD_M7/M7_SMD_4007.pdf</description>
</package3d>
<package3d name="DO41-10" urn="urn:adsk.eagle:package:43336/1" type="box" library_version="2">
<description>DIODE
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
</package3d>
<package3d name="DO35-10" urn="urn:adsk.eagle:package:43344/2" type="model" library_version="2">
<description>DIODE
diameter 2 mm, horizontal, grid 10.16 mm</description>
</package3d>
<package3d name="DO204-10" urn="urn:adsk.eagle:package:43366/1" type="box" library_version="2">
<description>DIODE
diameter 4 mm, horizontal, grid 10 mm</description>
</package3d>
<package3d name="DO15-12" urn="urn:adsk.eagle:package:43369/1" type="box" library_version="2">
<description>DIODE
diameter 3.5 mm, horizontal, grid 12.7 mm</description>
</package3d>
<package3d name="SOD57-10" urn="urn:adsk.eagle:package:43367/1" type="box" library_version="2">
<description>DIODE
diameter 4 mm, vertical, grid 10.16 mm</description>
</package3d>
<package3d name="DO201-15" urn="urn:adsk.eagle:package:43365/1" type="box" library_version="2">
<description>DIODE
diameter 5.6 mm, horizontal, grid 15.24 mm</description>
</package3d>
<package3d name="DO07" urn="urn:adsk.eagle:package:43394/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="P1-10" urn="urn:adsk.eagle:package:43375/1" type="box" library_version="2">
<description>DIODE
diameter 3 mm, horizontal, grid 10.16 mm</description>
</package3d>
<package3d name="P2-15" urn="urn:adsk.eagle:package:43345/1" type="box" library_version="2">
<description>DIODE
diameter 5 mm, horizontal, grid 12.7 mm</description>
</package3d>
<package3d name="DO34-7" urn="urn:adsk.eagle:package:43348/1" type="box" library_version="2">
<description>DIODE
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
</package3d>
<package3d name="SOT54H" urn="urn:adsk.eagle:package:43359/1" type="box" library_version="2">
<description>DIODE
2-lead plastic, vertical</description>
</package3d>
<package3d name="SOD523" urn="urn:adsk.eagle:package:43410/1" type="box" library_version="2">
<description>DIODE</description>
</package3d>
<package3d name="TO18D" urn="urn:adsk.eagle:package:43443/1" type="box" library_version="2">
<description>DIODE
2-lead metall, vertical</description>
</package3d>
<package3d name="C1702-05" urn="urn:adsk.eagle:package:43430/1" type="box" library_version="2">
<description>DIODE
diameter 3.5 mm, vertical, grid 5.08 mm</description>
</package3d>
<package3d name="C1702-15" urn="urn:adsk.eagle:package:43351/1" type="box" library_version="2">
<description>DIODE
diameter 3.5 mm, horizontal, grid 15.24 mm</description>
</package3d>
<package3d name="SGA-10" urn="urn:adsk.eagle:package:43388/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD64-10" urn="urn:adsk.eagle:package:43385/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD61A" urn="urn:adsk.eagle:package:43377/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD61B" urn="urn:adsk.eagle:package:43379/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD61C" urn="urn:adsk.eagle:package:43378/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD61D" urn="urn:adsk.eagle:package:43381/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD61E" urn="urn:adsk.eagle:package:43380/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="DO27-15" urn="urn:adsk.eagle:package:43337/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD81" urn="urn:adsk.eagle:package:43363/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD84" urn="urn:adsk.eagle:package:43376/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="F126-10" urn="urn:adsk.eagle:package:43396/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="DO220S" urn="urn:adsk.eagle:package:43371/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="TO220AC" urn="urn:adsk.eagle:package:43370/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="TO220ACS" urn="urn:adsk.eagle:package:43373/2" type="model" library_version="2">
<description>DIODE
</package3d>
<package3d name="G4-12" urn="urn:adsk.eagle:package:43368/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD83-12" urn="urn:adsk.eagle:package:43382/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SMB" urn="urn:adsk.eagle:package:43404/2" type="model" library_version="2">
</package3d>
<package3d name="P6-15" urn="urn:adsk.eagle:package:43343/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="C2673" urn="urn:adsk.eagle:package:43390/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="C221B1A" urn="urn:adsk.eagle:package:43391/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="SOD80C" urn="urn:adsk.eagle:package:43405/2" type="model" library_version="2">
</package3d>
<package3d name="D-10" urn="urn:adsk.eagle:package:43434/1" type="box" library_version="2">
</package3d>
<package3d name="D-12.5" urn="urn:adsk.eagle:package:43427/1" type="box" library_version="2">
</package3d>
<package3d name="D-2.5" urn="urn:adsk.eagle:package:43419/1" type="box" library_version="2">
</package3d>
<package3d name="D-5" urn="urn:adsk.eagle:package:43440/1" type="box" library_version="2">
</package3d>
<package3d name="D-7.5" urn="urn:adsk.eagle:package:43423/1" type="box" library_version="2">
</package3d>
<package3d name="SOD106-R" urn="urn:adsk.eagle:package:43424/2" type="model" library_version="2">
<description>SOD106 Reflow soldering Philips SC01_Mounting_1996.pdf</description>
</package3d>
<package3d name="SMC" urn="urn:adsk.eagle:package:43425/2" type="model" library_version="2">
</package3d>
<package3d name="SOD106-W" urn="urn:adsk.eagle:package:43431/1" type="box" library_version="2">
<description>SOD106 Wave soldering Philips SC01_Mounting_1996.pdf</description>
</package3d>
<package3d name="SOD106A-R" urn="urn:adsk.eagle:package:43438/2" type="model" library_version="2">
<description>SOD106A Reflow soldering Philips SC01_Mounting_1996.pdf</description>
</package3d>
<package3d name="SOD110-W" urn="urn:adsk.eagle:package:43428/1" type="box" library_version="2">
<description>SOD110 Wave soldering Philips SC01_Mounting_1996.pdf</description>
</package3d>
<package3d name="SOD110-R" urn="urn:adsk.eagle:package:43426/1" type="box" library_version="2">
<description>SOD110 Reflow soldering Philips SC01_Mounting_1996.pdf</description>
</package3d>
<package3d name="SOD123" urn="urn:adsk.eagle:package:43420/1" type="box" library_version="2">
<description>Diode</description>
</package3d>
<package3d name="SOD323-R" urn="urn:adsk.eagle:package:43437/1" type="box" library_version="2">
<description>SOD323 Reflow soldering Philips SC01_Mounting_1996.pdf</description>
</package3d>
<package3d name="SOD323-W" urn="urn:adsk.eagle:package:43418/1" type="box" library_version="2">
<description>SOD323 Wave soldering Philips SC01_Mounting_1996.pdf</description>
</package3d>
<package3d name="GF1" urn="urn:adsk.eagle:package:43422/1" type="box" library_version="2">
<description>GF1
</package3d>
<package3d name="MINIMELF" urn="urn:adsk.eagle:package:43429/1" type="box" library_version="2">
<description>Mini Melf Diode</description>
</package3d>
<package3d name="MELF-MLL41" urn="urn:adsk.eagle:package:43444/1" type="box" library_version="2">
<description>DIODE
</package3d>
<package3d name="MICROMELF-R" urn="urn:adsk.eagle:package:43436/1" type="box" library_version="2">
<description>Micro Melf Diode Reflow soldering VISHAY mcl4148.pdf</description>
</package3d>
<package3d name="MICROMELF-W" urn="urn:adsk.eagle:package:43441/1" type="box" library_version="2">
<description>Micro Melf Diode Wave soldering VISHAY mcl4148.pdf</description>
</package3d>
<package3d name="SC79_INFINEON" urn="urn:adsk.eagle:package:43432/1" type="box" library_version="2">
<description>Diode Package Reflow soldering
</package3d>
<package3d name="SCD80_INFINEON" urn="urn:adsk.eagle:package:43414/1" type="box" library_version="2">
</package3d>
<package3d name="DO214AA" urn="urn:adsk.eagle:package:43433/2" type="model" library_version="2">
</package3d>
<package3d name="DO214AC" urn="urn:adsk.eagle:package:43417/2" type="model" library_version="2">
</package3d>
<package3d name="DO214BA" urn="urn:adsk.eagle:package:43453/2" type="model" library_version="2">
</package3d>
<package3d name="DO41-7.6" urn="urn:adsk.eagle:package:43421/1" type="box" library_version="2">
<description>DO41 7.6mm x 2mm
</package3d>
</packages3d>
<symbols>
<symbol name="D" urn="urn:adsk.eagle:symbol:43091/1" library_version="2">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<text x="2.54" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.3114" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="0" size="0.4064" layer="99" align="center">SpiceOrder 1</text>
<text x="2.54" y="0" size="0.4064" layer="99" align="center">SpiceOrder 2</text>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="DIODE-" urn="urn:adsk.eagle:component:43657/13" prefix="D" uservalue="yes" library_version="2">
<gates>
<gate name="G$1" symbol="D" x="0" y="0"/>
</gates>
<devices>
<device name="DO41-10" package="DO41-10">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43336/1"/>
</package3dinstances>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="DO35-10" package="DO35-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43344/2"/>
<technologies>
</technologies>
</device>
<device name="DO204-10" package="DO204-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43366/1"/>
<technologies>
</technologies>
</device>
<device name="DO15-12" package="DO15-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43369/1"/>
<technologies>
</technologies>
</device>
<device name="SOD57-10" package="SOD57-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43367/1"/>
<technologies>
</technologies>
</device>
<device name="DO201-15" package="DO201-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43365/1"/>
<technologies>
</technologies>
</device>
<device name="DO07" package="DO07">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43394/1"/>
<technologies>
</technologies>
</device>
<device name="P1-10" package="P1-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43375/1"/>
<technologies>
</technologies>
</device>
<device name="P2-15" package="P2-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43345/1"/>
<technologies>
</technologies>
</device>
<device name="DO34-7" package="DO34-7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43348/1"/>
<technologies>
</technologies>
</device>
<device name="SOT54H" package="SOT54H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43359/1"/>
<technologies>
</technologies>
</device>
<device name="SOD523" package="SOD523">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43410/1"/>
<technologies>
</technologies>
</device>
<device name="TO18D" package="TO18D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43443/1"/>
<technologies>
</technologies>
</device>
<device name="C1702-05" package="C1702-05">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43430/1"/>
<technologies>
</technologies>
</device>
<device name="C1702-15" package="C1702-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43351/1"/>
<technologies>
</technologies>
</device>
<device name="SGA-10" package="SGA-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43388/1"/>
<technologies>
</technologies>
</device>
<device name="SOD64-10" package="SOD64-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43385/1"/>
<technologies>
</technologies>
</device>
<device name="SOD61A" package="SOD61A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43377/1"/>
<technologies>
</technologies>
</device>
<device name="SOD61B" package="SOD61B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43379/1"/>
<technologies>
</technologies>
</device>
<device name="SOD61C" package="SOD61C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43378/1"/>
<technologies>
</technologies>
</device>
<device name="SOD61D" package="SOD61D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43381/1"/>
<technologies>
</technologies>
</device>
<device name="SOD61E" package="SOD61E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43380/1"/>
<technologies>
</technologies>
</device>
<device name="DO27-15" package="DO27-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43337/1"/>
<technologies>
</technologies>
</device>
<device name="SOD81" package="SOD81">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43363/1"/>
<technologies>
</technologies>
</device>
<device name="SOD84" package="SOD84">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43376/1"/>
<technologies>
</technologies>
</device>
<device name="F126-10" package="F126-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43396/1"/>
<technologies>
</technologies>
</device>
<device name="DO220S" package="DO220S">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43371/1"/>
<technologies>
</technologies>
</device>
<device name="TO220H" package="TO220AC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43370/1"/>
<technologies>
</technologies>
</device>
<device name="TO220V" package="TO220ACS">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43373/2"/>
<technologies>
</technologies>
</device>
<device name="G4-12" package="G4-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43368/1"/>
<technologies>
</technologies>
</device>
<device name="SOD83-12" package="SOD83-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43382/1"/>
<technologies>
</technologies>
</device>
<device name="SMB" package="SMB">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43404/2"/>
<technologies>
</technologies>
</device>
<device name="P6-15" package="P6-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43343/1"/>
<technologies>
</technologies>
</device>
<device name="C2673" package="C2673">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43390/1"/>
<technologies>
</technologies>
</device>
<device name="C221B1A" package="C221B1A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43391/1"/>
<technologies>
</technologies>
</device>
<device name="SOD80C" package="SOD80C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43405/2"/>
<technologies>
</technologies>
</device>
<device name="D-10" package="D-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43434/1"/>
<technologies>
</technologies>
</device>
<device name="D-12.5" package="D-12.5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43427/1"/>
<technologies>
</technologies>
</device>
<device name="D-2.5" package="D-2.5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43419/1"/>
<technologies>
</technologies>
</device>
<device name="D-5" package="D-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43440/1"/>
<technologies>
</technologies>
</device>
<device name="D-7.5" package="D-7.5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43423/1"/>
<technologies>
</technologies>
</device>
<device name="SOD106-R" package="SOD106-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43424/2"/>
<technologies>
</technologies>
</device>
<device name="SMC" package="SMC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43425/2"/>
<technologies>
</technologies>
</device>
<device name="SOD106-W" package="SOD106-W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43431/1"/>
<technologies>
</technologies>
</device>
<device name="SOD106A-R" package="SOD106A-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43438/2"/>
<technologies>
</technologies>
</device>
<device name="SOD110-W" package="SOD110-W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43428/1"/>
<technologies>
</technologies>
</device>
<device name="SOD110-R" package="SOD110-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43426/1"/>
<technologies>
</technologies>
</device>
<device name="SOD123" package="SOD123">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43420/1"/>
<technologies>
</technologies>
</device>
<device name="SOD323-R" package="SOD323-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43437/1"/>
<technologies>
</technologies>
</device>
<device name="SOD323-W" package="SOD323-W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43418/1"/>
<technologies>
</technologies>
</device>
<device name="GF1" package="GF1">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43422/1"/>
<technologies>
</technologies>
</device>
<device name="MINIMELF" package="MINIMELF">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43429/1"/>
<technologies>
</technologies>
</device>
<device name="MELF-MLL41" package="MELF-MLL41">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43444/1"/>
<technologies>
</technologies>
</device>
<device name="MICROMELF-R" package="MICROMELF-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43436/1"/>
<technologies>
</technologies>
</device>
<device name="MICROMELF-W" package="MICROMELF-W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43441/1"/>
<technologies>
</technologies>
</device>
<device name="SC79_INFINEON" package="SC79_INFINEON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43432/1"/>
<technologies>
</technologies>
</device>
<device name="SCD80-INFINEON" package="SCD80_INFINEON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43414/1"/>
<technologies>
</technologies>
</device>
<device name="DO214AA" package="DO214AA">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43433/2"/>
<technologies>
</technologies>
</device>
<device name="DO214AC" package="DO214AC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43417/2"/>
<technologies>
</technologies>
</device>
<device name="DO214BA" package="DO214BA">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43453/2"/>
<technologies>
</technologies>
</device>
<device name="DO-214AC" package="DO-214AC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43416/2"/>
<technologies>
</technologies>
</device>
<device name="DO41-7.6" package="DO41-7.6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43421/1"/>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="74xx-us" urn="urn:adsk.eagle:library:88">
<description>&lt;b&gt;TTL Devices, 74xx Series with US Symbols&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Texas Instruments &lt;i&gt;TTL Data Book&lt;/i&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;Volume 1, 1996.
&lt;li&gt;TTL Data Book, Volume 2 , 1993
&lt;li&gt;National Seminconductor Databook 1990, ALS/LS Logic
&lt;li&gt;ttl 74er digital data dictionary, ECA Electronic + Acustic GmbH, ISBN 3-88109-032-0
&lt;li&gt;http://icmaster.com/ViewCompare.asp
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL14" urn="urn:adsk.eagle:footprint:2523/1" library_version="1">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SO14" urn="urn:adsk.eagle:footprint:2524/1" library_version="1">
<description>&lt;b&gt;Small Outline package&lt;/b&gt; 150 mil</description>
<wire x1="4.064" y1="1.9558" x2="-4.064" y2="1.9558" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.9558" x2="4.445" y2="-1.5748" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.445" y1="1.5748" x2="-4.064" y2="1.9558" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.064" y1="1.9558" x2="4.445" y2="1.5748" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.445" y1="-1.5748" x2="-4.064" y2="-1.9558" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.064" y1="-1.9558" x2="4.064" y2="-1.9558" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.5748" x2="4.445" y2="1.5748" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.5748" x2="-4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.445" y2="-1.5748" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="-0.508" width="0.1524" layer="21" curve="-180"/>
<wire x1="-4.445" y1="-1.6002" x2="4.445" y2="-1.6002" width="0.0508" layer="21"/>
<smd name="1" x="-3.81" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="-3.81" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-2.54" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-1.27" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="-2.54" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="-1.27" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="0" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="0" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="1.27" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="2.54" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="1.27" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="2.54" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="3.81" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="3.81" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<text x="-3.556" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.699" y="-1.778" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-0.254" y1="1.9558" x2="0.254" y2="3.0988" layer="51"/>
<rectangle x1="-4.064" y1="-3.0988" x2="-3.556" y2="-1.9558" layer="51"/>
<rectangle x1="-2.794" y1="-3.0988" x2="-2.286" y2="-1.9558" layer="51"/>
<rectangle x1="-1.524" y1="-3.0734" x2="-1.016" y2="-1.9304" layer="51"/>
<rectangle x1="-0.254" y1="-3.0988" x2="0.254" y2="-1.9558" layer="51"/>
<rectangle x1="-1.524" y1="1.9558" x2="-1.016" y2="3.0988" layer="51"/>
<rectangle x1="-2.794" y1="1.9558" x2="-2.286" y2="3.0988" layer="51"/>
<rectangle x1="-4.064" y1="1.9558" x2="-3.556" y2="3.0988" layer="51"/>
<rectangle x1="1.016" y1="1.9558" x2="1.524" y2="3.0988" layer="51"/>
<rectangle x1="2.286" y1="1.9558" x2="2.794" y2="3.0988" layer="51"/>
<rectangle x1="3.556" y1="1.9558" x2="4.064" y2="3.0988" layer="51"/>
<rectangle x1="1.016" y1="-3.0988" x2="1.524" y2="-1.9558" layer="51"/>
<rectangle x1="2.286" y1="-3.0988" x2="2.794" y2="-1.9558" layer="51"/>
<rectangle x1="3.556" y1="-3.0988" x2="4.064" y2="-1.9558" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="DIL14" urn="urn:adsk.eagle:package:2921/1" type="box" library_version="1">
<description>Dual In Line Package</description>
</package3d>
<package3d name="SO14" urn="urn:adsk.eagle:package:2917/1" type="box" library_version="1">
<description>Small Outline package 150 mil</description>
</package3d>
</packages3d>
<symbols>
<symbol name="PWRN" urn="urn:adsk.eagle:symbol:2522/1" library_version="1">
<text x="-0.635" y="-0.635" size="1.778" layer="95">&gt;NAME</text>
<text x="1.905" y="-7.62" size="1.27" layer="95" rot="R90">GND</text>
<text x="1.905" y="5.08" size="1.27" layer="95" rot="R90">VCC</text>
<pin name="GND" x="0" y="-10.16" visible="pad" direction="pwr" rot="R90"/>
<pin name="VCC" x="0" y="10.16" visible="pad" direction="pwr" rot="R270"/>
</symbol>
<symbol name="74HC73" urn="urn:adsk.eagle:symbol:2860/1" library_version="1">
<wire x1="-7.62" y1="-7.62" x2="7.62" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-7.62" x2="7.62" y2="10.16" width="0.4064" layer="94"/>
<wire x1="7.62" y1="10.16" x2="-7.62" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="10.16" x2="-7.62" y2="-7.62" width="0.4064" layer="94"/>
<text x="-7.62" y="10.795" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<pin name="CP" x="-12.7" y="2.54" length="middle" direction="in" function="dot"/>
<pin name="R" x="-12.7" y="-5.08" length="middle" direction="in" function="dot"/>
<pin name="K" x="-12.7" y="-2.54" length="middle" direction="in"/>
<pin name="Q" x="12.7" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="!Q" x="12.7" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="J" x="-12.7" y="7.62" length="middle" direction="in"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="74HC*73" urn="urn:adsk.eagle:component:3025/1" prefix="IC" library_version="1">
<description>Dual J-K &lt;b&gt;FLIP FLOP&lt;/b&gt;, clear</description>
<gates>
<gate name="A" symbol="74HC73" x="20.32" y="0" swaplevel="1"/>
<gate name="B" symbol="74HC73" x="20.32" y="-25.4" swaplevel="1"/>
<gate name="P" symbol="PWRN" x="-5.08" y="0" addlevel="request"/>
</gates>
<devices>
<device name="N" package="DIL14">
<connects>
<connect gate="A" pin="!Q" pad="13"/>
<connect gate="A" pin="CP" pad="1"/>
<connect gate="A" pin="J" pad="14"/>
<connect gate="A" pin="K" pad="3"/>
<connect gate="A" pin="Q" pad="12"/>
<connect gate="A" pin="R" pad="2"/>
<connect gate="B" pin="!Q" pad="8"/>
<connect gate="B" pin="CP" pad="5"/>
<connect gate="B" pin="J" pad="7"/>
<connect gate="B" pin="K" pad="10"/>
<connect gate="B" pin="Q" pad="9"/>
<connect gate="B" pin="R" pad="6"/>
<connect gate="P" pin="GND" pad="11"/>
<connect gate="P" pin="VCC" pad="4"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:2921/1"/>
<technologies>
<technology name="T"/>
</technologies>
</device>
<device name="D" package="SO14">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:2917/1"/>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="solpad" urn="urn:adsk.eagle:library:364">
<description>&lt;b&gt;Solder Pads/Test Points&lt;/b&gt;&lt;p&gt;
<packages>
<package name="LSP10" urn="urn:adsk.eagle:footprint:26494/1" library_version="1">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt;
drill 1.0 mm</description>
<wire x1="-1.27" y1="0.254" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.254" x2="0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="-0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<pad name="MP" x="0" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-1.27" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.254" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="LSP10" urn="urn:adsk.eagle:package:26501/1" type="box" library_version="1">
<description>SOLDER PAD
</package3d>
</packages3d>
<symbols>
<symbol name="LSP" urn="urn:adsk.eagle:symbol:26492/1" library_version="1">
<wire x1="-1.016" y1="2.032" x2="1.016" y2="0" width="0.254" layer="94"/>
<wire x1="-1.016" y1="0" x2="1.016" y2="2.032" width="0.254" layer="94"/>
<circle x="0" y="1.016" radius="1.016" width="0.4064" layer="94"/>
<text x="-1.27" y="2.921" size="1.778" layer="95">&gt;NAME</text>
<pin name="MP" x="0" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="LSP10" urn="urn:adsk.eagle:component:26508/1" prefix="LSP" library_version="1">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt; drill 1.0 mm, distributor Buerklin, 12H555</description>
<gates>
<gate name="1" symbol="LSP" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LSP10">
<connects>
<connect gate="1" pin="MP" pad="MP"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26501/1"/>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-hirose" urn="urn:adsk.eagle:library:152">
<description>&lt;b&gt;Hirose Connectors&lt;/b&gt;&lt;p&gt;
www.hirose.co.jp&lt;p&gt;
Include : &lt;br&gt;
con-hirose-df12d(3.0)60dp0.5v80.lbr from Bob Starr &amp;lt;rtzaudio@mindspring.com&amp;gt;&lt;br&gt;
con-hirose.lbr from Bob Starr &amp;lt;rtzaudio@mindspring.com&amp;gt;&lt;br&gt;</description>
<packages>
<package name="UX60A-MB-5ST" urn="urn:adsk.eagle:footprint:7171/1" library_version="1">
<description>&lt;b&gt;MINI USB Connector HI-SPEED Certified&lt;/b&gt; Metal Shield SMT Type Without Positioning Post&lt;p&gt;
Source: http://www.hirose.co.jp/cataloge_hp/e24000019.pdf</description>
<wire x1="-6.3509" y1="3.8059" x2="2.5511" y2="3.8059" width="0.1016" layer="21"/>
<wire x1="2.5511" y1="3.8059" x2="2.5511" y2="2.5442" width="0.1016" layer="21"/>
<wire x1="2.5511" y1="2.5442" x2="2.1866" y2="2.1797" width="0.1016" layer="21" curve="-90.031447"/>
<wire x1="2.1866" y1="2.1797" x2="1.6539" y2="2.1797" width="0.1016" layer="21"/>
<wire x1="1.6539" y1="2.1797" x2="1.2894" y2="1.8152" width="0.1016" layer="51" curve="90"/>
<wire x1="1.2894" y1="1.8152" x2="1.2894" y2="-1.8578" width="0.1016" layer="51"/>
<wire x1="1.2894" y1="-1.8578" x2="1.6118" y2="-2.1802" width="0.1016" layer="51" curve="90"/>
<wire x1="1.6118" y1="-2.1802" x2="2.2006" y2="-2.1802" width="0.1016" layer="21"/>
<wire x1="2.2006" y1="-2.1802" x2="2.5511" y2="-2.5307" width="0.1016" layer="21" curve="-90.032703"/>
<wire x1="2.5511" y1="-2.5307" x2="2.5511" y2="-3.8064" width="0.1016" layer="21"/>
<wire x1="2.5511" y1="-3.8064" x2="-2.7341" y2="-3.8064" width="0.1016" layer="21"/>
<wire x1="-2.7341" y1="-3.8064" x2="-6.3509" y2="-3.8064" width="0.1016" layer="21"/>
<wire x1="-6.3509" y1="-3.8064" x2="-6.3509" y2="3.8059" width="0.1016" layer="21"/>
<wire x1="2.5511" y1="-3.8064" x2="2.5511" y2="-4.7457" width="0.1016" layer="21"/>
<wire x1="2.5511" y1="-4.7457" x2="2.3968" y2="-4.8999" width="0.1016" layer="21" curve="-90.409919"/>
<wire x1="2.3968" y1="-4.8999" x2="2.3969" y2="-4.8999" width="0.1016" layer="21"/>
<wire x1="2.3969" y1="-4.8999" x2="2.2287" y2="-4.7317" width="0.1016" layer="21" curve="-90"/>
<wire x1="2.2287" y1="-4.7317" x2="2.2287" y2="-4.5775" width="0.1016" layer="21"/>
<wire x1="2.2287" y1="-4.5775" x2="2.0044" y2="-4.3532" width="0.1016" layer="21" curve="90.153471"/>
<wire x1="2.0044" y1="-4.3532" x2="1.9763" y2="-4.3532" width="0.1016" layer="21"/>
<wire x1="1.9763" y1="-4.3532" x2="1.752" y2="-4.5775" width="0.1016" layer="21" curve="90"/>
<wire x1="1.752" y1="-4.5775" x2="1.752" y2="-4.7457" width="0.1016" layer="21"/>
<wire x1="1.752" y1="-4.7457" x2="1.5978" y2="-4.8999" width="0.1016" layer="21" curve="-90"/>
<wire x1="1.5978" y1="-4.8999" x2="1.4296" y2="-4.7317" width="0.1016" layer="21" curve="-90"/>
<wire x1="1.4296" y1="-4.7317" x2="1.4296" y2="-3.8625" width="0.1016" layer="21"/>
<wire x1="-2.7341" y1="-3.8064" x2="-2.7341" y2="-4.7457" width="0.1016" layer="21"/>
<wire x1="-2.7341" y1="-4.7457" x2="-2.8884" y2="-4.8999" width="0.1016" layer="21" curve="-90.484765"/>
<wire x1="-2.8884" y1="-4.8999" x2="-2.8883" y2="-4.8999" width="0.1016" layer="21"/>
<wire x1="-2.8883" y1="-4.8999" x2="-3.0565" y2="-4.7317" width="0.1016" layer="21" curve="-90"/>
<wire x1="-3.0565" y1="-4.7317" x2="-3.0565" y2="-4.5775" width="0.1016" layer="21"/>
<wire x1="-3.0565" y1="-4.5775" x2="-3.2808" y2="-4.3532" width="0.1016" layer="21" curve="90.153471"/>
<wire x1="-3.2808" y1="-4.3532" x2="-3.3089" y2="-4.3532" width="0.1016" layer="21"/>
<wire x1="-3.3089" y1="-4.3532" x2="-3.5332" y2="-4.5775" width="0.1016" layer="21" curve="90.051111"/>
<wire x1="-3.5332" y1="-4.5775" x2="-3.5332" y2="-4.7457" width="0.1016" layer="21"/>
<wire x1="-3.5332" y1="-4.7457" x2="-3.6874" y2="-4.8999" width="0.1016" layer="21" curve="-90"/>
<wire x1="-3.6874" y1="-4.8999" x2="-3.8556" y2="-4.7317" width="0.1016" layer="21" curve="-90"/>
<wire x1="-3.8556" y1="-4.7317" x2="-3.8556" y2="-3.8625" width="0.1016" layer="21"/>
<wire x1="-3.8555" y1="3.8058" x2="-3.8555" y2="4.7451" width="0.1016" layer="21"/>
<wire x1="-3.8555" y1="4.7451" x2="-3.7012" y2="4.8993" width="0.1016" layer="21" curve="-90.484765"/>
<wire x1="-3.7012" y1="4.8993" x2="-3.7013" y2="4.8993" width="0.1016" layer="21"/>
<wire x1="-3.7013" y1="4.8993" x2="-3.5331" y2="4.7311" width="0.1016" layer="21" curve="-90"/>
<wire x1="-3.5331" y1="4.7311" x2="-3.5331" y2="4.5769" width="0.1016" layer="21"/>
<wire x1="-3.5331" y1="4.5769" x2="-3.3088" y2="4.3526" width="0.1016" layer="21" curve="90.102268"/>
<wire x1="-3.3088" y1="4.3526" x2="-3.2807" y2="4.3526" width="0.1016" layer="21"/>
<wire x1="-3.2807" y1="4.3526" x2="-3.0564" y2="4.5769" width="0.1016" layer="21" curve="90.102268"/>
<wire x1="-3.0564" y1="4.5769" x2="-3.0564" y2="4.7451" width="0.1016" layer="21"/>
<wire x1="-3.0564" y1="4.7451" x2="-2.9022" y2="4.8993" width="0.1016" layer="21" curve="-90"/>
<wire x1="-2.9022" y1="4.8993" x2="-2.734" y2="4.7311" width="0.1016" layer="21" curve="-90"/>
<wire x1="-2.734" y1="4.7311" x2="-2.734" y2="3.8619" width="0.1016" layer="21"/>
<wire x1="1.4297" y1="3.8058" x2="1.4297" y2="4.7451" width="0.1016" layer="21"/>
<wire x1="1.4297" y1="4.7451" x2="1.584" y2="4.8993" width="0.1016" layer="21" curve="-90.335171"/>
<wire x1="1.584" y1="4.8993" x2="1.5839" y2="4.8993" width="0.1016" layer="21"/>
<wire x1="1.5839" y1="4.8993" x2="1.7521" y2="4.7311" width="0.1016" layer="21" curve="-90"/>
<wire x1="1.7521" y1="4.7311" x2="1.7521" y2="4.5769" width="0.1016" layer="21"/>
<wire x1="1.7521" y1="4.5769" x2="1.9764" y2="4.3526" width="0.1016" layer="21" curve="90"/>
<wire x1="1.9764" y1="4.3526" x2="2.0045" y2="4.3526" width="0.1016" layer="21"/>
<wire x1="2.0045" y1="4.3526" x2="2.2288" y2="4.5769" width="0.1016" layer="21" curve="90.051111"/>
<wire x1="2.2288" y1="4.5769" x2="2.2288" y2="4.7451" width="0.1016" layer="21"/>
<wire x1="2.2288" y1="4.7451" x2="2.383" y2="4.8993" width="0.1016" layer="21" curve="-90"/>
<wire x1="2.383" y1="4.8993" x2="2.5512" y2="4.7311" width="0.1016" layer="21" curve="-90"/>
<wire x1="2.5512" y1="4.7311" x2="2.5512" y2="3.7918" width="0.1016" layer="21"/>
<wire x1="-5.1593" y1="3.7498" x2="-5.1593" y2="2.2077" width="0.1016" layer="21"/>
<wire x1="-5.1593" y1="2.2077" x2="-4.8088" y2="1.8572" width="0.1016" layer="21" curve="90.032703"/>
<wire x1="-4.8088" y1="1.8572" x2="-4.7668" y2="1.8572" width="0.1016" layer="21"/>
<wire x1="-4.7668" y1="1.8572" x2="-1.0938" y2="1.689" width="0.1016" layer="21"/>
<wire x1="-1.0938" y1="1.689" x2="-1.0798" y2="1.9834" width="0.1016" layer="21" curve="179.766458"/>
<wire x1="-1.0798" y1="1.9834" x2="-4.4724" y2="2.2077" width="0.1016" layer="21"/>
<wire x1="-4.4724" y1="2.2077" x2="-4.4584" y2="2.6984" width="0.1016" layer="21" curve="-175.705121"/>
<wire x1="-4.4584" y1="2.6984" x2="-1.0518" y2="2.9227" width="0.1016" layer="21"/>
<wire x1="-1.0518" y1="2.9227" x2="-0.9396" y2="3.0488" width="0.1016" layer="21" curve="89.143172"/>
<wire x1="-0.9396" y1="3.0488" x2="-0.9396" y2="3.7498" width="0.1016" layer="21"/>
<wire x1="-0.6452" y1="0.7497" x2="-0.9817" y2="1.0862" width="0.1016" layer="21" curve="89.931933"/>
<wire x1="-0.9817" y1="1.0862" x2="-5.0051" y2="1.2965" width="0.1016" layer="21"/>
<wire x1="-5.0051" y1="1.2965" x2="-5.0191" y2="1.0301" width="0.1016" layer="21" curve="180"/>
<wire x1="-5.0191" y1="1.0301" x2="-1.9069" y2="0.8619" width="0.1016" layer="21"/>
<wire x1="-1.9069" y1="0.8619" x2="-1.4723" y2="0.4273" width="0.1016" layer="21" curve="-90"/>
<wire x1="-1.4723" y1="0.4273" x2="-1.4723" y2="-0.4559" width="0.1016" layer="21"/>
<wire x1="-1.4723" y1="-0.4559" x2="-1.8929" y2="-0.8765" width="0.1016" layer="21" curve="-90"/>
<wire x1="-1.8929" y1="-0.8765" x2="-1.963" y2="-0.8765" width="0.1016" layer="21"/>
<wire x1="-1.963" y1="-0.8765" x2="-5.0051" y2="-1.0167" width="0.1016" layer="21"/>
<wire x1="-5.0051" y1="-1.0167" x2="-5.0051" y2="-1.297" width="0.1016" layer="21" curve="174.689178"/>
<wire x1="-5.0051" y1="-1.297" x2="-1.0097" y2="-1.0868" width="0.1016" layer="21"/>
<wire x1="-1.0097" y1="-1.0868" x2="-0.6452" y2="-0.7223" width="0.1016" layer="21" curve="90"/>
<wire x1="-0.6452" y1="-0.7223" x2="-0.6452" y2="0.7497" width="0.1016" layer="21"/>
<wire x1="-5.1592" y1="-3.7504" x2="-5.1592" y2="-2.2083" width="0.1016" layer="21"/>
<wire x1="-5.1592" y1="-2.2083" x2="-4.8087" y2="-1.8578" width="0.1016" layer="21" curve="-89.967316"/>
<wire x1="-4.8087" y1="-1.8578" x2="-4.7667" y2="-1.8578" width="0.1016" layer="21"/>
<wire x1="-4.7667" y1="-1.8578" x2="-1.0937" y2="-1.6896" width="0.1016" layer="21"/>
<wire x1="-1.0937" y1="-1.6896" x2="-1.0797" y2="-1.984" width="0.1016" layer="21" curve="-179.766458"/>
<wire x1="-1.0797" y1="-1.984" x2="-4.4723" y2="-2.2083" width="0.1016" layer="21"/>
<wire x1="-4.4723" y1="-2.2083" x2="-4.4583" y2="-2.699" width="0.1016" layer="21" curve="175.705121"/>
<wire x1="-4.4583" y1="-2.699" x2="-1.0517" y2="-2.9233" width="0.1016" layer="21"/>
<wire x1="-1.0517" y1="-2.9233" x2="-0.9395" y2="-3.0494" width="0.1016" layer="21" curve="-89.143172"/>
<wire x1="-0.9395" y1="-3.0494" x2="-0.9395" y2="-3.7504" width="0.1016" layer="21"/>
<smd name="M3" x="2" y="4.2" dx="2.2" dy="2.5" layer="1"/>
<smd name="M4" x="2" y="-4.2" dx="2.2" dy="2.5" layer="1"/>
<smd name="M2" x="-3.3" y="4.2" dx="2.2" dy="2.5" layer="1"/>
<smd name="M1" x="-3.3" y="-4.2" dx="2.2" dy="2.5" layer="1"/>
<smd name="1" x="2.25" y="1.6" dx="2" dy="0.5" layer="1"/>
<smd name="2" x="2.25" y="0.8" dx="2" dy="0.5" layer="1"/>
<smd name="3" x="2.25" y="0" dx="2" dy="0.5" layer="1"/>
<smd name="4" x="2.25" y="-0.8" dx="2" dy="0.5" layer="1"/>
<smd name="5" x="2.25" y="-1.6" dx="2" dy="0.5" layer="1"/>
<text x="5.08" y="-4.445" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-4.445" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.3034" y1="1.4367" x2="2.6072" y2="1.7731" layer="51"/>
<rectangle x1="1.3034" y1="0.6376" x2="2.6072" y2="0.974" layer="51"/>
<rectangle x1="1.3034" y1="-0.1615" x2="2.6072" y2="0.1749" layer="51"/>
<rectangle x1="1.3034" y1="-0.9606" x2="2.6072" y2="-0.6242" layer="51"/>
<rectangle x1="1.3034" y1="-1.7596" x2="2.6072" y2="-1.4232" layer="51"/>
<rectangle x1="-6.4" y1="-3.85" x2="-4.425" y2="3.85" layer="41"/>
<rectangle x1="-2.175" y1="-3.85" x2="-0.45" y2="3.85" layer="41"/>
<rectangle x1="-4.425" y1="-2.925" x2="-2.175" y2="2.925" layer="41"/>
<rectangle x1="-0.45" y1="-1.85" x2="1.225" y2="1.85" layer="41"/>
</package>
<package name="UX60-MB-5S8" urn="urn:adsk.eagle:footprint:7172/1" library_version="1">
<description>&lt;b&gt;MINI USB Connector HI-SPEED Certified&lt;/b&gt; Metal Shield Dip Type With Positioning Post&lt;p&gt;
<wire x1="0.0491" y1="3.8059" x2="8.9511" y2="3.8059" width="0.1016" layer="21"/>
<wire x1="8.9511" y1="3.8059" x2="8.9511" y2="2.5442" width="0.1016" layer="21"/>
<wire x1="8.9511" y1="2.5442" x2="8.5866" y2="2.1797" width="0.1016" layer="21" curve="-90.031447"/>
<wire x1="8.5866" y1="2.1797" x2="8.0539" y2="2.1797" width="0.1016" layer="21"/>
<wire x1="8.0539" y1="2.1797" x2="7.6894" y2="1.8152" width="0.1016" layer="51" curve="90"/>
<wire x1="7.6894" y1="1.8152" x2="7.6894" y2="-1.8578" width="0.1016" layer="51"/>
<wire x1="7.6894" y1="-1.8578" x2="8.0118" y2="-2.1802" width="0.1016" layer="51" curve="90"/>
<wire x1="8.0118" y1="-2.1802" x2="8.6006" y2="-2.1802" width="0.1016" layer="21"/>
<wire x1="8.6006" y1="-2.1802" x2="8.9511" y2="-2.5307" width="0.1016" layer="21" curve="-90.032703"/>
<wire x1="8.9511" y1="-2.5307" x2="8.9511" y2="-3.8064" width="0.1016" layer="21"/>
<wire x1="8.9511" y1="-3.8064" x2="0.0491" y2="-3.8064" width="0.1016" layer="21"/>
<wire x1="0.0491" y1="-3.8064" x2="0.0491" y2="3.8059" width="0.1016" layer="21"/>
<wire x1="1.2407" y1="3.7498" x2="1.2407" y2="2.2077" width="0.1016" layer="21"/>
<wire x1="1.2407" y1="2.2077" x2="1.5912" y2="1.8572" width="0.1016" layer="21" curve="90.032703"/>
<wire x1="1.5912" y1="1.8572" x2="1.6332" y2="1.8572" width="0.1016" layer="21"/>
<wire x1="1.6332" y1="1.8572" x2="5.3062" y2="1.689" width="0.1016" layer="21"/>
<wire x1="5.3062" y1="1.689" x2="5.3202" y2="1.9834" width="0.1016" layer="21" curve="179.766458"/>
<wire x1="5.3202" y1="1.9834" x2="1.9276" y2="2.2077" width="0.1016" layer="21"/>
<wire x1="1.9276" y1="2.2077" x2="1.9416" y2="2.6984" width="0.1016" layer="21" curve="-175.705121"/>
<wire x1="1.9416" y1="2.6984" x2="5.3482" y2="2.9227" width="0.1016" layer="21"/>
<wire x1="5.3482" y1="2.9227" x2="5.4604" y2="3.0488" width="0.1016" layer="21" curve="89.143172"/>
<wire x1="5.4604" y1="3.0488" x2="5.4604" y2="3.7498" width="0.1016" layer="21"/>
<wire x1="5.7548" y1="0.7497" x2="5.4183" y2="1.0862" width="0.1016" layer="21" curve="89.965956"/>
<wire x1="5.4183" y1="1.0862" x2="1.3949" y2="1.2965" width="0.1016" layer="21"/>
<wire x1="1.3949" y1="1.2965" x2="1.3809" y2="1.0301" width="0.1016" layer="21" curve="180"/>
<wire x1="1.3809" y1="1.0301" x2="4.4931" y2="0.8619" width="0.1016" layer="21"/>
<wire x1="4.4931" y1="0.8619" x2="4.9277" y2="0.4273" width="0.1016" layer="21" curve="-90"/>
<wire x1="4.9277" y1="0.4273" x2="4.9277" y2="-0.4559" width="0.1016" layer="21"/>
<wire x1="4.9277" y1="-0.4559" x2="4.5071" y2="-0.8765" width="0.1016" layer="21" curve="-90"/>
<wire x1="4.5071" y1="-0.8765" x2="4.437" y2="-0.8765" width="0.1016" layer="21"/>
<wire x1="4.437" y1="-0.8765" x2="1.3949" y2="-1.0167" width="0.1016" layer="21"/>
<wire x1="1.3949" y1="-1.0167" x2="1.3949" y2="-1.297" width="0.1016" layer="21" curve="174.689178"/>
<wire x1="1.3949" y1="-1.297" x2="5.3903" y2="-1.0868" width="0.1016" layer="21"/>
<wire x1="5.3903" y1="-1.0868" x2="5.7548" y2="-0.7223" width="0.1016" layer="21" curve="89.968571"/>
<wire x1="5.7548" y1="-0.7223" x2="5.7548" y2="0.7497" width="0.1016" layer="21"/>
<wire x1="1.2408" y1="-3.7504" x2="1.2408" y2="-2.2083" width="0.1016" layer="21"/>
<wire x1="1.2408" y1="-2.2083" x2="1.5913" y2="-1.8578" width="0.1016" layer="21" curve="-89.967316"/>
<wire x1="1.5913" y1="-1.8578" x2="1.6333" y2="-1.8578" width="0.1016" layer="21"/>
<wire x1="1.6333" y1="-1.8578" x2="5.3063" y2="-1.6896" width="0.1016" layer="21"/>
<wire x1="5.3063" y1="-1.6896" x2="5.3203" y2="-1.984" width="0.1016" layer="21" curve="-179.766458"/>
<wire x1="5.3203" y1="-1.984" x2="1.9277" y2="-2.2083" width="0.1016" layer="21"/>
<wire x1="1.9277" y1="-2.2083" x2="1.9417" y2="-2.699" width="0.1016" layer="21" curve="175.705121"/>
<wire x1="1.9417" y1="-2.699" x2="5.3483" y2="-2.9233" width="0.1016" layer="21"/>
<wire x1="5.3483" y1="-2.9233" x2="5.4605" y2="-3.0494" width="0.1016" layer="21" curve="-89.143172"/>
<wire x1="5.4605" y1="-3.0494" x2="5.4605" y2="-3.7504" width="0.1016" layer="21"/>
<wire x1="8.9" y1="-3.25" x2="9.3" y2="-3.65" width="0" layer="46" curve="-90"/>
<wire x1="9.3" y1="-3.65" x2="8.9" y2="-4.05" width="0" layer="46" curve="-90"/>
<wire x1="8.9" y1="-4.05" x2="7.9" y2="-4.05" width="0" layer="46"/>
<wire x1="7.9" y1="-4.05" x2="7.5" y2="-3.65" width="0" layer="46" curve="-90"/>
<wire x1="7.5" y1="-3.65" x2="7.9" y2="-3.25" width="0" layer="46" curve="-90"/>
<wire x1="7.9" y1="-3.25" x2="8.9" y2="-3.25" width="0" layer="46"/>
<wire x1="8.9" y1="4.05" x2="9.3" y2="3.65" width="0" layer="46" curve="-90"/>
<wire x1="9.3" y1="3.65" x2="8.9" y2="3.25" width="0" layer="46" curve="-90"/>
<wire x1="8.9" y1="3.25" x2="7.9" y2="3.25" width="0" layer="46"/>
<wire x1="7.9" y1="3.25" x2="7.5" y2="3.65" width="0" layer="46" curve="-90"/>
<wire x1="7.5" y1="3.65" x2="7.9" y2="4.05" width="0" layer="46" curve="-90"/>
<wire x1="7.9" y1="4.05" x2="8.9" y2="4.05" width="0" layer="46"/>
<wire x1="3.6" y1="-3.25" x2="4" y2="-3.65" width="0" layer="46" curve="-90"/>
<wire x1="4" y1="-3.65" x2="3.6" y2="-4.05" width="0" layer="46" curve="-90"/>
<wire x1="3.6" y1="-4.05" x2="2.6" y2="-4.05" width="0" layer="46"/>
<wire x1="2.6" y1="-4.05" x2="2.2" y2="-3.65" width="0" layer="46" curve="-90"/>
<wire x1="2.2" y1="-3.65" x2="2.6" y2="-3.25" width="0" layer="46" curve="-90"/>
<wire x1="2.6" y1="-3.25" x2="3.6" y2="-3.25" width="0" layer="46"/>
<wire x1="3.6" y1="4.05" x2="4" y2="3.65" width="0" layer="46" curve="-90"/>
<wire x1="4" y1="3.65" x2="3.6" y2="3.25" width="0" layer="46" curve="-90"/>
<wire x1="3.6" y1="3.25" x2="2.6" y2="3.25" width="0" layer="46"/>
<wire x1="2.6" y1="3.25" x2="2.2" y2="3.65" width="0" layer="46" curve="-90"/>
<wire x1="2.2" y1="3.65" x2="2.6" y2="4.05" width="0" layer="46" curve="-90"/>
<wire x1="2.6" y1="4.05" x2="3.6" y2="4.05" width="0" layer="46"/>
<pad name="M4" x="8.4" y="-3.65" drill="0.8" shape="long"/>
<pad name="M3" x="8.4" y="3.65" drill="0.8" shape="long"/>
<pad name="M1" x="3.1" y="-3.65" drill="0.8" shape="long"/>
<pad name="M2" x="3.1" y="3.65" drill="0.8" shape="long"/>
<smd name="1" x="8.65" y="1.6" dx="2" dy="0.5" layer="1"/>
<smd name="2" x="8.65" y="0.8" dx="2" dy="0.5" layer="1"/>
<smd name="3" x="8.65" y="0" dx="2" dy="0.5" layer="1"/>
<smd name="4" x="8.65" y="-0.8" dx="2" dy="0.5" layer="1"/>
<smd name="5" x="8.65" y="-1.6" dx="2" dy="0.5" layer="1"/>
<text x="11.43" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="1.27" y="-5.715" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="7.7034" y1="1.4367" x2="9.0072" y2="1.7731" layer="51"/>
<rectangle x1="7.7034" y1="0.6376" x2="9.0072" y2="0.974" layer="51"/>
<rectangle x1="7.7034" y1="-0.1615" x2="9.0072" y2="0.1749" layer="51"/>
<rectangle x1="7.7034" y1="-0.9606" x2="9.0072" y2="-0.6242" layer="51"/>
<rectangle x1="7.7034" y1="-1.7596" x2="9.0072" y2="-1.4232" layer="51"/>
<rectangle x1="0" y1="-3.85" x2="1.975" y2="3.85" layer="41"/>
<rectangle x1="4.225" y1="-3.85" x2="5.95" y2="3.85" layer="41"/>
<rectangle x1="1.975" y1="-2.925" x2="4.225" y2="2.925" layer="41"/>
<rectangle x1="5.95" y1="-1.85" x2="7.625" y2="1.85" layer="41"/>
<rectangle x1="0" y1="-3.85" x2="1.775" y2="3.85" layer="39"/>
<rectangle x1="1.775" y1="-2.975" x2="4.425" y2="2.975" layer="39"/>
<rectangle x1="4.425" y1="-3.85" x2="5.95" y2="3.85" layer="39"/>
<rectangle x1="6.85" y1="-1.85" x2="7.625" y2="1.85" layer="39"/>
<rectangle x1="5.95" y1="-1.3" x2="6.85" y2="1.3" layer="39"/>
<hole x="6.4" y="-1.75" drill="0.9"/>
<hole x="6.4" y="1.75" drill="0.9"/>
</package>
<package name="UX60-MB-5ST" urn="urn:adsk.eagle:footprint:7173/1" library_version="1">
<description>&lt;b&gt;MINI USB Connector HI-SPEED Certified&lt;/b&gt; Metal Shield SMT Type With Positioning Post&lt;p&gt;
<wire x1="-2.7341" y1="-4.7457" x2="-2.8884" y2="-4.8999" width="0.1016" layer="21" curve="-90.409919"/>
<wire x1="-3.0565" y1="-4.5775" x2="-3.2808" y2="-4.3532" width="0.1016" layer="21" curve="90.102268"/>
<wire x1="-3.3089" y1="-4.3532" x2="-3.5332" y2="-4.5775" width="0.1016" layer="21" curve="89.948934"/>
<wire x1="-3.8555" y1="4.7451" x2="-3.7012" y2="4.8993" width="0.1016" layer="21" curve="-90.409919"/>
<wire x1="-3.5331" y1="4.5769" x2="-3.3088" y2="4.3526" width="0.1016" layer="21" curve="90.051111"/>
<wire x1="-0.6452" y1="0.7497" x2="-0.9817" y2="1.0862" width="0.1016" layer="21" curve="89.965956"/>
<text x="5.08" y="-3.81" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<rectangle x1="0.45" y1="-1.85" x2="1.225" y2="1.85" layer="41"/>
<rectangle x1="-0.45" y1="-1.3" x2="0.45" y2="1.3" layer="41"/>
<hole x="0" y="-1.75" drill="0.9"/>
<hole x="0" y="1.75" drill="0.9"/>
</package>
</packages>
<packages3d>
<package3d name="UX60A-MB-5ST" urn="urn:adsk.eagle:package:7263/1" type="box" library_version="1">
<description>MINI USB Connector HI-SPEED Certified Metal Shield SMT Type Without Positioning Post
</package3d>
<package3d name="UX60-MB-5S8" urn="urn:adsk.eagle:package:7264/1" type="box" library_version="1">
<description>MINI USB Connector HI-SPEED Certified Metal Shield Dip Type With Positioning Post
</package3d>
<package3d name="UX60-MB-5ST" urn="urn:adsk.eagle:package:7266/1" type="box" library_version="1">
<description>MINI USB Connector HI-SPEED Certified Metal Shield SMT Type With Positioning Post
</package3d>
</packages3d>
<symbols>
<symbol name="MINI-USB" urn="urn:adsk.eagle:symbol:7170/1" library_version="1">
<wire x1="-2.54" y1="6.35" x2="-2.54" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-6.35" x2="-1.27" y2="-7.62" width="0.254" layer="94" curve="90"/>
<wire x1="-1.27" y1="-7.62" x2="0" y2="-7.62" width="0.254" layer="94"/>
<wire x1="0" y1="-7.62" x2="1.016" y2="-8.128" width="0.254" layer="94" curve="-53.130102"/>
<wire x1="1.016" y1="-8.128" x2="2.54" y2="-8.89" width="0.254" layer="94" curve="53.130102"/>
<wire x1="2.54" y1="-8.89" x2="5.08" y2="-8.89" width="0.254" layer="94"/>
<wire x1="5.08" y1="-8.89" x2="6.35" y2="-7.62" width="0.254" layer="94" curve="90"/>
<wire x1="6.35" y1="-7.62" x2="6.35" y2="7.62" width="0.254" layer="94"/>
<wire x1="-2.54" y1="6.35" x2="-1.27" y2="7.62" width="0.254" layer="94" curve="-90"/>
<wire x1="-1.27" y1="7.62" x2="0" y2="7.62" width="0.254" layer="94"/>
<wire x1="0" y1="7.62" x2="1.016" y2="8.128" width="0.254" layer="94" curve="53.130102"/>
<wire x1="1.016" y1="8.128" x2="2.54" y2="8.89" width="0.254" layer="94" curve="-53.130102"/>
<wire x1="2.54" y1="8.89" x2="5.08" y2="8.89" width="0.254" layer="94"/>
<wire x1="5.08" y1="8.89" x2="6.35" y2="7.62" width="0.254" layer="94" curve="-90"/>
<wire x1="0" y1="5.08" x2="0" y2="-5.08" width="0.254" layer="94"/>
<wire x1="0" y1="-5.08" x2="1.27" y2="-6.35" width="0.254" layer="94"/>
<wire x1="1.27" y1="-6.35" x2="3.81" y2="-6.35" width="0.254" layer="94"/>
<wire x1="3.81" y1="-6.35" x2="3.81" y2="6.35" width="0.254" layer="94"/>
<wire x1="3.81" y1="6.35" x2="1.27" y2="6.35" width="0.254" layer="94"/>
<wire x1="1.27" y1="6.35" x2="0" y2="5.08" width="0.254" layer="94"/>
<text x="-2.54" y="11.43" size="1.778" layer="95">&gt;NAME</text>
<text x="10.16" y="-7.62" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="1" x="-5.08" y="5.08" visible="pin" direction="in"/>
<pin name="2" x="-5.08" y="2.54" visible="pin" direction="in"/>
<pin name="3" x="-5.08" y="0" visible="pin" direction="in"/>
<pin name="4" x="-5.08" y="-2.54" visible="pin" direction="in"/>
<pin name="5" x="-5.08" y="-5.08" visible="pin" direction="in"/>
</symbol>
<symbol name="USB-SHIELD" urn="urn:adsk.eagle:symbol:7174/1" library_version="1">
<wire x1="-7.62" y1="0" x2="1.27" y2="0" width="0.254" layer="94" style="shortdash"/>
<wire x1="1.27" y1="0" x2="2.54" y2="1.27" width="0.254" layer="94" style="shortdash" curve="90"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="19.05" width="0.254" layer="94" style="shortdash"/>
<wire x1="-7.62" y1="20.32" x2="1.27" y2="20.32" width="0.254" layer="94" style="shortdash"/>
<wire x1="1.27" y1="20.32" x2="2.54" y2="19.05" width="0.254" layer="94" style="shortdash" curve="-90"/>
<text x="3.81" y="-2.54" size="1.778" layer="95">&gt;NAME</text>
<pin name="S1" x="-7.62" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="S2" x="-5.08" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="S3" x="-2.54" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="S4" x="0" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MINI-USB-SHIELD-" urn="urn:adsk.eagle:component:7338/1" prefix="X" library_version="1">
<description>&lt;b&gt;MINI USB Connector&lt;/b&gt;&lt;p&gt;
<gates>
<gate name="G$1" symbol="MINI-USB" x="0" y="0"/>
<gate name="S" symbol="USB-SHIELD" x="5.08" y="-10.16" addlevel="request"/>
</gates>
<devices>
<device name="UX60A-MB-5ST" package="UX60A-MB-5ST">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="S" pin="S1" pad="M1"/>
<connect gate="S" pin="S2" pad="M2"/>
<connect gate="S" pin="S3" pad="M3"/>
<connect gate="S" pin="S4" pad="M4"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:7263/1"/>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
<device name="UX60-MB-5ST" package="UX60-MB-5ST">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:7266/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UX60-MB-5S8" package="UX60-MB-5S8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:7264/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1">
<packages>
</packages>
<symbols>
<symbol name="GND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="GND" prefix="GND">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor-small-signal" urn="urn:adsk.eagle:library:401">
<description>&lt;b&gt;Small Signal Transistors&lt;/b&gt;&lt;p&gt;
Packages from :&lt;br&gt;
www.infineon.com; &lt;br&gt;
www.semiconductors.com;&lt;br&gt;
www.irf.com&lt;p&gt;
<packages>
<package name="SOT23" urn="urn:adsk.eagle:footprint:29641/1" library_version="1">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="SOT23" urn="urn:adsk.eagle:package:29752/1" type="box" library_version="1">
<description>SOT-23</description>
</package3d>
</packages3d>
<symbols>
<symbol name="JFETN" urn="urn:adsk.eagle:symbol:29612/1" library_version="1">
<wire x1="2.54" y1="-1.905" x2="0.5334" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="2.54" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.667" x2="2.54" y2="1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="1.905" x2="0.508" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-0.254" y1="0" x2="-1.524" y2="0.508" width="0.1524" layer="94"/>
<wire x1="-1.524" y1="0.508" x2="-1.524" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="-1.524" y1="-0.508" x2="-0.254" y2="0" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="0" x2="-0.762" y2="0" width="0.1524" layer="94"/>
<wire x1="-0.762" y1="0" x2="-0.635" y2="0" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="0" x2="-0.254" y2="0" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="0" x2="-1.397" y2="0.254" width="0.3048" layer="94"/>
<wire x1="-1.397" y1="0.254" x2="-1.397" y2="-0.254" width="0.3048" layer="94"/>
<wire x1="-1.397" y1="-0.254" x2="-0.762" y2="0" width="0.3048" layer="94"/>
<text x="5.08" y="0" size="1.778" layer="95">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="2.54" size="0.8128" layer="93">D</text>
<text x="1.27" y="-3.175" size="0.8128" layer="93">S</text>
<text x="-3.175" y="-1.27" size="0.8128" layer="93">G</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<pin name="G" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="D" x="2.54" y="5.08" visible="off" length="short" direction="pas" rot="R270"/>
<pin name="S" x="2.54" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MMBFJ3*" urn="urn:adsk.eagle:component:29811/1" prefix="Q" library_version="1">
<description>&lt;b&gt;N-Channel RF Amplifier&lt;/b&gt;&lt;p&gt;
Source: http://www.fairchildsemi.com/pf/J3/J310.html</description>
<gates>
<gate name="G$1" symbol="JFETN" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOT23">
<connects>
<connect gate="G$1" pin="D" pad="1"/>
<connect gate="G$1" pin="G" pad="3"/>
<connect gate="G$1" pin="S" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29752/1"/>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="IC1" library="atmel" library_urn="urn:adsk.eagle:library:105" deviceset="MEGA8-P" device="" package3d_urn="urn:adsk.eagle:package:4320/1"/>
<part name="C1" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n"/>
<part name="C2" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n"/>
<part name="C3" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n"/>
<part name="C4" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n"/>
<part name="C5" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="22p"/>
<part name="C6" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="22p"/>
<part name="Q1" library="crystal" library_urn="urn:adsk.eagle:library:204" deviceset="CRYSTAL" device="HC49S" package3d_urn="urn:adsk.eagle:package:12071/1" value="16000kHz"/>
<part name="T1" library="transistor-npn" library_urn="urn:adsk.eagle:library:398" deviceset="BC847*" device="SMD" package3d_urn="urn:adsk.eagle:package:28984/2" value="BC847"/>
<part name="T2" library="transistor-npn" library_urn="urn:adsk.eagle:library:398" deviceset="BC847*" device="SMD" package3d_urn="urn:adsk.eagle:package:28984/2" value="BC847"/>
<part name="T3" library="transistor-npn" library_urn="urn:adsk.eagle:library:398" deviceset="BC847*" device="SMD" package3d_urn="urn:adsk.eagle:package:28984/2" value="BC847"/>
<part name="T4" library="transistor-npn" library_urn="urn:adsk.eagle:library:398" deviceset="BC847*" device="SMD" package3d_urn="urn:adsk.eagle:package:28984/2" value="BC847"/>
<part name="R1" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="1k"/>
<part name="R2" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="1k"/>
<part name="R3" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="1k"/>
<part name="R4" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="1k"/>
<part name="P+1" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="L1" library="rcl" deviceset="L-EU" device="0207/2V" value="100µH"/>
<part name="R5" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="220k"/>
<part name="R6" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="68k"/>
<part name="R7" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="27k"/>
<part name="C7" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10n"/>
<part name="GND2" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="JP2" library="pinhead" library_urn="urn:adsk.eagle:library:325" deviceset="PINHD-1X1" device="" package3d_urn="urn:adsk.eagle:package:22485/2" value="Input"/>
<part name="T5" library="transistor-npn" library_urn="urn:adsk.eagle:library:398" deviceset="BC847*" device="SMD" package3d_urn="urn:adsk.eagle:package:28984/2" value="BF311-BC547C"/>
<part name="R8" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="470-4,7k"/>
<part name="R9" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="10k-2,2M"/>
<part name="C9" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10n-3,3n"/>
<part name="R10" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="X-33k"/>
<part name="D1" library="diode" library_urn="urn:adsk.eagle:library:210" deviceset="DIODE-" device="DO-214AC" package3d_urn="urn:adsk.eagle:package:43416/2"/>
<part name="C11" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n"/>
<part name="R11" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="1M"/>
<part name="R12" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="180"/>
<part name="R13" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="180"/>
<part name="R14" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="180"/>
<part name="R15" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="180"/>
<part name="R16" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="180"/>
<part name="R17" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="180"/>
<part name="R18" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="180"/>
<part name="R19" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="180"/>
<part name="C10" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="CPOL-EU" device="E3.5-8" package3d_urn="urn:adsk.eagle:package:23360/2" value="100µF"/>
<part name="JP3" library="pinhead" library_urn="urn:adsk.eagle:library:325" deviceset="PINHD-1X1" device="" package3d_urn="urn:adsk.eagle:package:22485/2" value="Clock Out"/>
<part name="R20" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="150"/>
<part name="LED1" library="display-kingbright" library_urn="urn:adsk.eagle:library:213" deviceset="DC56-11" device="" package3d_urn="urn:adsk.eagle:package:13085/1" technology="GWA"/>
<part name="LED2" library="display-kingbright" library_urn="urn:adsk.eagle:library:213" deviceset="DC56-11" device="" package3d_urn="urn:adsk.eagle:package:13085/1" technology="GWA"/>
<part name="IC3" library="74xx-us" library_urn="urn:adsk.eagle:library:88" deviceset="74HC*73" device="D" package3d_urn="urn:adsk.eagle:package:2917/1"/>
<part name="LSP1" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="LSP2" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="LSP3" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="LSP4" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="LSP5" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="LSP6" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="X1" library="con-hirose" library_urn="urn:adsk.eagle:library:152" deviceset="MINI-USB-SHIELD-" device="UX60A-MB-5ST" package3d_urn="urn:adsk.eagle:package:7263/1" value="Micro USB"/>
<part name="GND1" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="LSP7" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="LSP8" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="GND3" library="supply1" deviceset="GND" device=""/>
<part name="R23" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="220"/>
<part name="Q2" library="transistor-small-signal" library_urn="urn:adsk.eagle:library:401" deviceset="MMBFJ3*" device="" package3d_urn="urn:adsk.eagle:package:29752/1" value="BF545"/>
<part name="C12" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10nF-X"/>
<part name="R27" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="2M"/>
<part name="R21" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="X-00"/>
<part name="R22" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="00-X"/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="IC1" gate="G$1" x="15.24" y="0" smashed="yes">
<attribute name="NAME" x="-2.54" y="-38.1" size="1.778" layer="95"/>
<attribute name="VALUE" x="10.16" y="33.02" size="1.778" layer="96"/>
</instance>
<instance part="C1" gate="G$1" x="-58.42" y="-30.48" smashed="yes" rot="R180">
<attribute name="NAME" x="-59.944" y="-30.861" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-59.944" y="-25.781" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C2" gate="G$1" x="-50.8" y="-22.86" smashed="yes" rot="R180">
<attribute name="NAME" x="-52.324" y="-23.241" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-52.324" y="-18.161" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C3" gate="G$1" x="-30.48" y="-25.4" smashed="yes" rot="R180">
<attribute name="NAME" x="-32.004" y="-25.781" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-32.004" y="-20.701" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C4" gate="G$1" x="-50.8" y="27.94" smashed="yes" rot="R90">
<attribute name="NAME" x="-51.181" y="29.464" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="-46.101" y="29.464" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C5" gate="G$1" x="-45.72" y="-12.7" smashed="yes" rot="R180">
<attribute name="NAME" x="-47.244" y="-13.081" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-47.244" y="-8.001" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C6" gate="G$1" x="-35.56" y="-12.7" smashed="yes" rot="R180">
<attribute name="NAME" x="-37.084" y="-13.081" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-37.084" y="-8.001" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="Q1" gate="G$1" x="-40.64" y="5.08" smashed="yes" rot="R180">
<attribute name="NAME" x="-43.18" y="4.064" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-43.18" y="7.62" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="T1" gate="G$1" x="104.14" y="-35.56" smashed="yes">
<attribute name="NAME" x="106.68" y="-35.56" size="1.778" layer="95"/>
<attribute name="VALUE" x="88.9" y="-38.1" size="1.778" layer="96"/>
</instance>
<instance part="T2" gate="G$1" x="127" y="-35.56" smashed="yes">
<attribute name="NAME" x="129.54" y="-35.56" size="1.778" layer="95"/>
<attribute name="VALUE" x="111.76" y="-38.1" size="1.778" layer="96"/>
</instance>
<instance part="T3" gate="G$1" x="149.86" y="-35.56" smashed="yes">
<attribute name="NAME" x="152.4" y="-35.56" size="1.778" layer="95"/>
<attribute name="VALUE" x="134.62" y="-38.1" size="1.778" layer="96"/>
</instance>
<instance part="T4" gate="G$1" x="172.72" y="-35.56" smashed="yes">
<attribute name="NAME" x="175.26" y="-35.56" size="1.778" layer="95"/>
<attribute name="VALUE" x="157.48" y="-38.1" size="1.778" layer="96"/>
</instance>
<instance part="R1" gate="G$1" x="165.1" y="-22.86" smashed="yes">
<attribute name="NAME" x="163.83" y="-21.3614" size="1.778" layer="95"/>
<attribute name="VALUE" x="163.83" y="-26.162" size="1.778" layer="96"/>
</instance>
<instance part="R2" gate="G$1" x="139.7" y="-25.4" smashed="yes">
<attribute name="NAME" x="138.43" y="-23.9014" size="1.778" layer="95"/>
<attribute name="VALUE" x="138.43" y="-28.702" size="1.778" layer="96"/>
</instance>
<instance part="R3" gate="G$1" x="119.38" y="-27.94" smashed="yes">
<attribute name="NAME" x="118.11" y="-26.4414" size="1.778" layer="95"/>
<attribute name="VALUE" x="118.11" y="-31.242" size="1.778" layer="96"/>
</instance>
<instance part="R4" gate="G$1" x="96.52" y="-30.48" smashed="yes">
<attribute name="NAME" x="95.25" y="-28.9814" size="1.778" layer="95"/>
<attribute name="VALUE" x="95.25" y="-33.782" size="1.778" layer="96"/>
</instance>
<instance part="P+1" gate="1" x="-30.48" y="45.72" smashed="yes">
<attribute name="VALUE" x="-33.02" y="40.64" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="L1" gate="G$1" x="-40.64" y="15.24" smashed="yes" rot="R90">
<attribute name="NAME" x="-36.83" y="13.7414" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-36.83" y="18.542" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R5" gate="G$1" x="63.5" y="-81.28" smashed="yes" rot="R90">
<attribute name="NAME" x="62.0014" y="-85.09" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="66.802" y="-85.09" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R6" gate="G$1" x="55.88" y="22.86" smashed="yes" rot="R180">
<attribute name="NAME" x="59.69" y="21.3614" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="59.69" y="26.162" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R7" gate="G$1" x="55.88" y="7.62" smashed="yes" rot="R180">
<attribute name="NAME" x="59.69" y="6.1214" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="59.69" y="10.922" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C7" gate="G$1" x="55.88" y="15.24" smashed="yes" rot="R90">
<attribute name="NAME" x="55.499" y="16.764" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="60.579" y="16.764" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND2" gate="1" x="58.42" y="-111.76" smashed="yes">
<attribute name="VALUE" x="55.88" y="-114.3" size="1.778" layer="96"/>
</instance>
<instance part="JP2" gate="G$1" x="-60.96" y="-86.36" smashed="yes" rot="R180">
<attribute name="NAME" x="-54.61" y="-89.535" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-54.61" y="-81.28" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="T5" gate="G$1" x="96.52" y="-91.44" smashed="yes">
<attribute name="NAME" x="99.06" y="-91.44" size="1.778" layer="95"/>
<attribute name="VALUE" x="88.9" y="-96.52" size="1.778" layer="96"/>
</instance>
<instance part="R8" gate="G$1" x="81.28" y="-71.12" smashed="yes" rot="R180">
<attribute name="NAME" x="85.09" y="-72.6186" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="85.09" y="-67.818" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R9" gate="G$1" x="91.44" y="-81.28" smashed="yes" rot="R90">
<attribute name="NAME" x="89.9414" y="-85.09" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="94.742" y="-85.09" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C9" gate="G$1" x="83.82" y="-91.44" smashed="yes" rot="R270">
<attribute name="NAME" x="84.201" y="-92.964" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="79.121" y="-92.964" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R10" gate="G$1" x="71.12" y="-91.44" smashed="yes" rot="R180">
<attribute name="NAME" x="74.93" y="-92.9386" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="74.93" y="-88.138" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D1" gate="G$1" x="-30.48" y="35.56" smashed="yes" rot="R270">
<attribute name="NAME" x="-29.9974" y="33.02" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="-32.7914" y="33.02" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="C11" gate="G$1" x="175.26" y="-83.82" smashed="yes" rot="R180">
<attribute name="NAME" x="173.736" y="-84.201" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="173.736" y="-79.121" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R11" gate="G$1" x="43.18" y="-81.28" smashed="yes" rot="R90">
<attribute name="NAME" x="41.6814" y="-85.09" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="46.482" y="-85.09" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R12" gate="G$1" x="71.12" y="35.56" smashed="yes" rot="R270">
<attribute name="NAME" x="72.6186" y="39.37" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="67.818" y="39.37" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R13" gate="G$1" x="73.66" y="20.32" smashed="yes" rot="R270">
<attribute name="NAME" x="75.1586" y="24.13" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="70.358" y="24.13" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R14" gate="G$1" x="76.2" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="77.6986" y="34.29" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="72.898" y="34.29" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R15" gate="G$1" x="78.74" y="15.24" smashed="yes" rot="R270">
<attribute name="NAME" x="80.2386" y="19.05" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="75.438" y="19.05" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R16" gate="G$1" x="81.28" y="25.4" smashed="yes" rot="R270">
<attribute name="NAME" x="82.7786" y="29.21" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="77.978" y="29.21" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R17" gate="G$1" x="83.82" y="10.16" smashed="yes" rot="R270">
<attribute name="NAME" x="85.3186" y="13.97" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="80.518" y="13.97" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R18" gate="G$1" x="86.36" y="20.32" smashed="yes" rot="R270">
<attribute name="NAME" x="87.8586" y="24.13" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="83.058" y="24.13" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R19" gate="G$1" x="88.9" y="5.08" smashed="yes" rot="R270">
<attribute name="NAME" x="90.3986" y="8.89" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="85.598" y="8.89" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="C10" gate="G$1" x="-12.7" y="-27.94" smashed="yes">
<attribute name="NAME" x="-11.557" y="-27.4574" size="1.778" layer="95"/>
<attribute name="VALUE" x="-11.557" y="-32.5374" size="1.778" layer="96"/>
</instance>
<instance part="JP3" gate="G$1" x="-60.96" y="-66.04" smashed="yes" rot="R180">
<attribute name="NAME" x="-54.61" y="-69.215" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-54.61" y="-60.96" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R20" gate="G$1" x="-40.64" y="-66.04" smashed="yes" rot="R180">
<attribute name="NAME" x="-36.83" y="-67.5386" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-36.83" y="-62.738" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="LED1" gate="DIG1" x="147.32" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="156.845" y="35.56" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="135.89" y="35.56" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="LED1" gate="DIG2" x="170.18" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="179.705" y="35.56" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="158.75" y="35.56" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="LED2" gate="DIG1" x="101.6" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="111.125" y="35.56" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="90.17" y="35.56" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="LED2" gate="DIG2" x="124.46" y="30.48" smashed="yes" rot="R270">
<attribute name="NAME" x="133.985" y="35.56" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="113.03" y="35.56" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="IC3" gate="A" x="119.38" y="-81.28" smashed="yes">
<attribute name="NAME" x="111.76" y="-70.485" size="1.778" layer="95"/>
<attribute name="VALUE" x="111.76" y="-91.44" size="1.778" layer="96"/>
</instance>
<instance part="IC3" gate="B" x="149.86" y="-81.28" smashed="yes">
<attribute name="NAME" x="142.24" y="-70.485" size="1.778" layer="95"/>
<attribute name="VALUE" x="142.24" y="-91.44" size="1.778" layer="96"/>
</instance>
<instance part="IC3" gate="P" x="167.64" y="-81.28" smashed="yes">
<attribute name="NAME" x="167.005" y="-81.915" size="1.778" layer="95"/>
</instance>
<instance part="LSP1" gate="1" x="-25.4" y="45.72" smashed="yes">
<attribute name="NAME" x="-26.67" y="48.641" size="1.778" layer="95"/>
</instance>
<instance part="LSP2" gate="1" x="-50.8" y="-63.5" smashed="yes">
<attribute name="NAME" x="-52.07" y="-60.579" size="1.778" layer="95"/>
</instance>
<instance part="LSP3" gate="1" x="-50.8" y="-83.82" smashed="yes">
<attribute name="NAME" x="-52.07" y="-80.899" size="1.778" layer="95"/>
</instance>
<instance part="LSP4" gate="1" x="63.5" y="-104.14" smashed="yes">
<attribute name="NAME" x="62.23" y="-101.219" size="1.778" layer="95"/>
</instance>
<instance part="LSP5" gate="1" x="185.42" y="-55.88" smashed="yes">
<attribute name="NAME" x="184.15" y="-52.959" size="1.778" layer="95"/>
</instance>
<instance part="LSP6" gate="1" x="185.42" y="-88.9" smashed="yes">
<attribute name="NAME" x="184.15" y="-85.979" size="1.778" layer="95"/>
</instance>
<instance part="X1" gate="G$1" x="-2.54" y="48.26" smashed="yes" rot="R90">
<attribute name="NAME" x="-13.97" y="45.72" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="5.08" y="58.42" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND1" gate="1" x="2.54" y="35.56" smashed="yes">
<attribute name="VALUE" x="0" y="33.02" size="1.778" layer="96"/>
</instance>
<instance part="LSP7" gate="1" x="81.28" y="-104.14" smashed="yes">
<attribute name="NAME" x="80.01" y="-101.219" size="1.778" layer="95"/>
</instance>
<instance part="LSP8" gate="1" x="71.12" y="-104.14" smashed="yes">
<attribute name="NAME" x="69.85" y="-101.219" size="1.778" layer="95"/>
</instance>
<instance part="GND3" gate="1" x="22.86" y="-111.76" smashed="yes">
<attribute name="VALUE" x="20.32" y="-114.3" size="1.778" layer="96"/>
</instance>
<instance part="R23" gate="G$1" x="0" y="-101.6" smashed="yes" rot="R270">
<attribute name="NAME" x="-1.651" y="-104.2924" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="3.4544" y="-104.2162" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="Q2" gate="G$1" x="-2.54" y="-86.36" smashed="yes" rot="MR180">
<attribute name="NAME" x="2.54" y="-86.36" size="1.778" layer="95" rot="MR180"/>
<attribute name="VALUE" x="2.54" y="-83.82" size="1.778" layer="96" rot="MR180"/>
</instance>
<instance part="C12" gate="G$1" x="-17.78" y="-86.36" smashed="yes" rot="R270">
<attribute name="NAME" x="-17.7292" y="-85.6996" size="1.778" layer="95"/>
<attribute name="VALUE" x="-17.78" y="-88.9508" size="1.778" layer="96"/>
</instance>
<instance part="R27" gate="G$1" x="-10.16" y="-99.06" smashed="yes" rot="R270">
<attribute name="NAME" x="-11.811" y="-101.7524" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="-6.7056" y="-101.6762" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R21" gate="G$1" x="50.8" y="-96.52" smashed="yes">
<attribute name="NAME" x="46.99" y="-95.0214" size="1.778" layer="95"/>
<attribute name="VALUE" x="46.99" y="-99.822" size="1.778" layer="96"/>
</instance>
<instance part="R22" gate="G$1" x="0" y="-68.58" smashed="yes" rot="R90">
<attribute name="NAME" x="-1.4986" y="-72.39" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="3.302" y="-72.39" size="1.778" layer="96" rot="R90"/>
</instance>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<wire x1="-45.72" y1="27.94" x2="-7.62" y2="27.94" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PC6(/RESET)"/>
<pinref part="C4" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<wire x1="-7.62" y1="20.32" x2="-58.42" y2="20.32" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="20.32" x2="-58.42" y2="-25.4" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="AREF"/>
<pinref part="C1" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<wire x1="-7.62" y1="17.78" x2="-50.8" y2="17.78" width="0.1524" layer="91"/>
<wire x1="-50.8" y1="17.78" x2="-50.8" y2="15.24" width="0.1524" layer="91"/>
<wire x1="-50.8" y1="15.24" x2="-50.8" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="-45.72" y1="15.24" x2="-50.8" y2="15.24" width="0.1524" layer="91"/>
<junction x="-50.8" y="15.24"/>
<pinref part="C2" gate="G$1" pin="2"/>
<pinref part="IC1" gate="G$1" pin="AVCC"/>
<pinref part="L1" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<wire x1="-45.72" y1="-7.62" x2="-45.72" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-45.72" y1="5.08" x2="-45.72" y2="10.16" width="0.1524" layer="91"/>
<wire x1="-45.72" y1="10.16" x2="-7.62" y2="10.16" width="0.1524" layer="91"/>
<wire x1="-43.18" y1="5.08" x2="-45.72" y2="5.08" width="0.1524" layer="91"/>
<junction x="-45.72" y="5.08"/>
<pinref part="C5" gate="G$1" pin="2"/>
<pinref part="IC1" gate="G$1" pin="PB6(XTAL1/TOSC1)"/>
<pinref part="Q1" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<wire x1="-35.56" y1="-7.62" x2="-35.56" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-35.56" y1="5.08" x2="-7.62" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-38.1" y1="5.08" x2="-35.56" y2="5.08" width="0.1524" layer="91"/>
<junction x="-35.56" y="5.08"/>
<pinref part="C6" gate="G$1" pin="2"/>
<pinref part="IC1" gate="G$1" pin="PB7(XTAL2/TOSC2)"/>
<pinref part="Q1" gate="G$1" pin="1"/>
</segment>
</net>
<net name="A" class="0">
<segment>
<wire x1="109.22" y1="53.34" x2="109.22" y2="40.64" width="0.1524" layer="91"/>
<wire x1="71.12" y1="40.64" x2="71.12" y2="53.34" width="0.1524" layer="91"/>
<wire x1="71.12" y1="53.34" x2="109.22" y2="53.34" width="0.1524" layer="91"/>
<wire x1="177.8" y1="40.64" x2="177.8" y2="53.34" width="0.1524" layer="91"/>
<wire x1="177.8" y1="53.34" x2="154.94" y2="53.34" width="0.1524" layer="91"/>
<wire x1="154.94" y1="40.64" x2="154.94" y2="53.34" width="0.1524" layer="91"/>
<wire x1="154.94" y1="53.34" x2="132.08" y2="53.34" width="0.1524" layer="91"/>
<wire x1="132.08" y1="53.34" x2="109.22" y2="53.34" width="0.1524" layer="91"/>
<wire x1="132.08" y1="40.64" x2="132.08" y2="53.34" width="0.1524" layer="91"/>
<junction x="109.22" y="53.34"/>
<junction x="154.94" y="53.34"/>
<junction x="132.08" y="53.34"/>
<pinref part="R12" gate="G$1" pin="1"/>
<pinref part="LED1" gate="DIG2" pin="A"/>
<pinref part="LED1" gate="DIG1" pin="A"/>
<pinref part="LED2" gate="DIG2" pin="A"/>
<pinref part="LED2" gate="DIG1" pin="A"/>
</segment>
</net>
<net name="B" class="0">
<segment>
<wire x1="73.66" y1="25.4" x2="73.66" y2="55.88" width="0.1524" layer="91"/>
<wire x1="106.68" y1="55.88" x2="106.68" y2="40.64" width="0.1524" layer="91"/>
<wire x1="106.68" y1="55.88" x2="73.66" y2="55.88" width="0.1524" layer="91"/>
<wire x1="175.26" y1="40.64" x2="175.26" y2="55.88" width="0.1524" layer="91"/>
<wire x1="175.26" y1="55.88" x2="152.4" y2="55.88" width="0.1524" layer="91"/>
<wire x1="152.4" y1="40.64" x2="152.4" y2="55.88" width="0.1524" layer="91"/>
<wire x1="152.4" y1="55.88" x2="129.54" y2="55.88" width="0.1524" layer="91"/>
<wire x1="129.54" y1="55.88" x2="106.68" y2="55.88" width="0.1524" layer="91"/>
<wire x1="129.54" y1="40.64" x2="129.54" y2="55.88" width="0.1524" layer="91"/>
<junction x="106.68" y="55.88"/>
<junction x="152.4" y="55.88"/>
<junction x="129.54" y="55.88"/>
<pinref part="R13" gate="G$1" pin="1"/>
<pinref part="LED1" gate="DIG2" pin="B"/>
<pinref part="LED1" gate="DIG1" pin="B"/>
<pinref part="LED2" gate="DIG2" pin="B"/>
<pinref part="LED2" gate="DIG1" pin="B"/>
</segment>
</net>
<net name="C" class="0">
<segment>
<wire x1="104.14" y1="58.42" x2="104.14" y2="40.64" width="0.1524" layer="91"/>
<wire x1="76.2" y1="58.42" x2="104.14" y2="58.42" width="0.1524" layer="91"/>
<wire x1="172.72" y1="40.64" x2="172.72" y2="58.42" width="0.1524" layer="91"/>
<wire x1="172.72" y1="58.42" x2="149.86" y2="58.42" width="0.1524" layer="91"/>
<wire x1="149.86" y1="40.64" x2="149.86" y2="58.42" width="0.1524" layer="91"/>
<wire x1="149.86" y1="58.42" x2="127" y2="58.42" width="0.1524" layer="91"/>
<wire x1="127" y1="58.42" x2="104.14" y2="58.42" width="0.1524" layer="91"/>
<wire x1="127" y1="40.64" x2="127" y2="58.42" width="0.1524" layer="91"/>
<wire x1="76.2" y1="35.56" x2="76.2" y2="58.42" width="0.1524" layer="91"/>
<junction x="104.14" y="58.42"/>
<junction x="149.86" y="58.42"/>
<junction x="127" y="58.42"/>
<pinref part="R14" gate="G$1" pin="1"/>
<pinref part="LED1" gate="DIG2" pin="C"/>
<pinref part="LED1" gate="DIG1" pin="C"/>
<pinref part="LED2" gate="DIG2" pin="C"/>
<pinref part="LED2" gate="DIG1" pin="C"/>
</segment>
</net>
<net name="D" class="0">
<segment>
<wire x1="170.18" y1="40.64" x2="170.18" y2="60.96" width="0.1524" layer="91"/>
<wire x1="147.32" y1="60.96" x2="170.18" y2="60.96" width="0.1524" layer="91"/>
<wire x1="147.32" y1="40.64" x2="147.32" y2="60.96" width="0.1524" layer="91"/>
<wire x1="101.6" y1="40.64" x2="101.6" y2="60.96" width="0.1524" layer="91"/>
<wire x1="101.6" y1="60.96" x2="78.74" y2="60.96" width="0.1524" layer="91"/>
<wire x1="101.6" y1="60.96" x2="124.46" y2="60.96" width="0.1524" layer="91"/>
<wire x1="124.46" y1="60.96" x2="147.32" y2="60.96" width="0.1524" layer="91"/>
<wire x1="124.46" y1="40.64" x2="124.46" y2="60.96" width="0.1524" layer="91"/>
<wire x1="78.74" y1="20.32" x2="78.74" y2="60.96" width="0.1524" layer="91"/>
<junction x="147.32" y="60.96"/>
<junction x="101.6" y="60.96"/>
<junction x="124.46" y="60.96"/>
<pinref part="R15" gate="G$1" pin="1"/>
<pinref part="LED1" gate="DIG2" pin="D"/>
<pinref part="LED1" gate="DIG1" pin="D"/>
<pinref part="LED2" gate="DIG2" pin="D"/>
<pinref part="LED2" gate="DIG1" pin="D"/>
</segment>
</net>
<net name="E" class="0">
<segment>
<wire x1="99.06" y1="63.5" x2="99.06" y2="40.64" width="0.1524" layer="91"/>
<wire x1="81.28" y1="63.5" x2="99.06" y2="63.5" width="0.1524" layer="91"/>
<wire x1="167.64" y1="40.64" x2="167.64" y2="63.5" width="0.1524" layer="91"/>
<wire x1="167.64" y1="63.5" x2="144.78" y2="63.5" width="0.1524" layer="91"/>
<wire x1="144.78" y1="40.64" x2="144.78" y2="63.5" width="0.1524" layer="91"/>
<wire x1="144.78" y1="63.5" x2="121.92" y2="63.5" width="0.1524" layer="91"/>
<wire x1="121.92" y1="63.5" x2="99.06" y2="63.5" width="0.1524" layer="91"/>
<wire x1="121.92" y1="40.64" x2="121.92" y2="63.5" width="0.1524" layer="91"/>
<wire x1="81.28" y1="30.48" x2="81.28" y2="63.5" width="0.1524" layer="91"/>
<junction x="99.06" y="63.5"/>
<junction x="144.78" y="63.5"/>
<junction x="121.92" y="63.5"/>
<pinref part="R16" gate="G$1" pin="1"/>
<pinref part="LED1" gate="DIG2" pin="E"/>
<pinref part="LED1" gate="DIG1" pin="E"/>
<pinref part="LED2" gate="DIG2" pin="E"/>
<pinref part="LED2" gate="DIG1" pin="E"/>
</segment>
</net>
<net name="G" class="0">
<segment>
<wire x1="93.98" y1="68.58" x2="93.98" y2="40.64" width="0.1524" layer="91"/>
<wire x1="162.56" y1="40.64" x2="162.56" y2="68.58" width="0.1524" layer="91"/>
<wire x1="162.56" y1="68.58" x2="139.7" y2="68.58" width="0.1524" layer="91"/>
<wire x1="139.7" y1="40.64" x2="139.7" y2="68.58" width="0.1524" layer="91"/>
<wire x1="139.7" y1="68.58" x2="116.84" y2="68.58" width="0.1524" layer="91"/>
<wire x1="116.84" y1="68.58" x2="93.98" y2="68.58" width="0.1524" layer="91"/>
<wire x1="116.84" y1="40.64" x2="116.84" y2="68.58" width="0.1524" layer="91"/>
<wire x1="86.36" y1="68.58" x2="93.98" y2="68.58" width="0.1524" layer="91"/>
<wire x1="86.36" y1="25.4" x2="86.36" y2="68.58" width="0.1524" layer="91"/>
<junction x="93.98" y="68.58"/>
<junction x="139.7" y="68.58"/>
<junction x="116.84" y="68.58"/>
<pinref part="R18" gate="G$1" pin="1"/>
<pinref part="LED1" gate="DIG2" pin="G"/>
<pinref part="LED1" gate="DIG1" pin="G"/>
<pinref part="LED2" gate="DIG2" pin="G"/>
<pinref part="LED2" gate="DIG1" pin="G"/>
</segment>
</net>
<net name="F" class="0">
<segment>
<wire x1="96.52" y1="66.04" x2="96.52" y2="40.64" width="0.1524" layer="91"/>
<wire x1="165.1" y1="40.64" x2="165.1" y2="66.04" width="0.1524" layer="91"/>
<wire x1="165.1" y1="66.04" x2="142.24" y2="66.04" width="0.1524" layer="91"/>
<wire x1="142.24" y1="40.64" x2="142.24" y2="66.04" width="0.1524" layer="91"/>
<wire x1="142.24" y1="66.04" x2="119.38" y2="66.04" width="0.1524" layer="91"/>
<wire x1="119.38" y1="66.04" x2="96.52" y2="66.04" width="0.1524" layer="91"/>
<wire x1="119.38" y1="40.64" x2="119.38" y2="66.04" width="0.1524" layer="91"/>
<wire x1="96.52" y1="66.04" x2="83.82" y2="66.04" width="0.1524" layer="91"/>
<wire x1="83.82" y1="15.24" x2="83.82" y2="66.04" width="0.1524" layer="91"/>
<junction x="96.52" y="66.04"/>
<junction x="142.24" y="66.04"/>
<junction x="119.38" y="66.04"/>
<pinref part="R17" gate="G$1" pin="1"/>
<pinref part="LED1" gate="DIG2" pin="F"/>
<pinref part="LED1" gate="DIG1" pin="F"/>
<pinref part="LED2" gate="DIG2" pin="F"/>
<pinref part="LED2" gate="DIG1" pin="F"/>
</segment>
</net>
<net name="DP" class="0">
<segment>
<wire x1="93.98" y1="17.78" x2="93.98" y2="20.32" width="0.1524" layer="91"/>
<wire x1="116.84" y1="20.32" x2="116.84" y2="17.78" width="0.1524" layer="91"/>
<wire x1="139.7" y1="20.32" x2="139.7" y2="17.78" width="0.1524" layer="91"/>
<wire x1="139.7" y1="17.78" x2="116.84" y2="17.78" width="0.1524" layer="91"/>
<wire x1="116.84" y1="17.78" x2="93.98" y2="17.78" width="0.1524" layer="91"/>
<wire x1="88.9" y1="17.78" x2="93.98" y2="17.78" width="0.1524" layer="91"/>
<wire x1="88.9" y1="10.16" x2="88.9" y2="17.78" width="0.1524" layer="91"/>
<wire x1="162.56" y1="20.32" x2="162.56" y2="17.78" width="0.1524" layer="91"/>
<wire x1="139.7" y1="17.78" x2="162.56" y2="17.78" width="0.1524" layer="91"/>
<junction x="116.84" y="17.78"/>
<junction x="93.98" y="17.78"/>
<junction x="139.7" y="17.78"/>
<pinref part="R19" gate="G$1" pin="1"/>
<pinref part="LED1" gate="DIG2" pin="DP"/>
<pinref part="LED1" gate="DIG1" pin="DP"/>
<pinref part="LED2" gate="DIG2" pin="DP"/>
<pinref part="LED2" gate="DIG1" pin="DP"/>
</segment>
</net>
<net name="4" class="0">
<segment>
<wire x1="106.68" y1="20.32" x2="109.22" y2="20.32" width="0.1524" layer="91"/>
<wire x1="106.68" y1="-30.48" x2="106.68" y2="20.32" width="0.1524" layer="91"/>
<pinref part="T1" gate="G$1" pin="C"/>
<pinref part="LED2" gate="DIG1" pin="COM"/>
</segment>
</net>
<net name="3" class="0">
<segment>
<wire x1="129.54" y1="20.32" x2="132.08" y2="20.32" width="0.1524" layer="91"/>
<wire x1="129.54" y1="-30.48" x2="129.54" y2="20.32" width="0.1524" layer="91"/>
<pinref part="T2" gate="G$1" pin="C"/>
<pinref part="LED2" gate="DIG2" pin="COM"/>
</segment>
</net>
<net name="1" class="0">
<segment>
<wire x1="175.26" y1="20.32" x2="177.8" y2="20.32" width="0.1524" layer="91"/>
<wire x1="175.26" y1="-30.48" x2="175.26" y2="20.32" width="0.1524" layer="91"/>
<pinref part="T4" gate="G$1" pin="C"/>
<pinref part="LED1" gate="DIG2" pin="COM"/>
</segment>
</net>
<net name="GND" class="0">
<segment>
<pinref part="X1" gate="G$1" pin="4"/>
<pinref part="X1" gate="G$1" pin="5"/>
<wire x1="0" y1="43.18" x2="2.54" y2="43.18" width="0.1524" layer="91"/>
<pinref part="GND1" gate="1" pin="GND"/>
<wire x1="2.54" y1="43.18" x2="2.54" y2="38.1" width="0.1524" layer="91"/>
<junction x="2.54" y="43.18"/>
</segment>
<segment>
<wire x1="22.86" y1="-109.22" x2="22.86" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="0" y1="-106.68" x2="22.86" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="0" y1="-106.68" x2="-10.16" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="-10.16" y1="-106.68" x2="-10.16" y2="-104.14" width="0.1524" layer="91"/>
<junction x="22.86" y="-106.68"/>
<junction x="0" y="-106.68"/>
<pinref part="GND3" gate="1" pin="GND"/>
<pinref part="R23" gate="G$1" pin="2"/>
<pinref part="R27" gate="G$1" pin="2"/>
<wire x1="185.42" y1="-106.68" x2="185.42" y2="-91.44" width="0.1524" layer="91"/>
<wire x1="175.26" y1="-45.72" x2="175.26" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="152.4" y1="-45.72" x2="175.26" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="152.4" y1="-40.64" x2="152.4" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="129.54" y1="-45.72" x2="152.4" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="129.54" y1="-40.64" x2="129.54" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="106.68" y1="-45.72" x2="129.54" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="106.68" y1="-40.64" x2="106.68" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-12.7" y1="-45.72" x2="106.68" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-25.4" y1="-45.72" x2="-12.7" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-7.62" y1="-2.54" x2="-25.4" y2="-2.54" width="0.1524" layer="91"/>
<wire x1="-25.4" y1="-2.54" x2="-25.4" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-50.8" y1="-25.4" x2="-50.8" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-45.72" y1="-15.24" x2="-45.72" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-35.56" y1="-15.24" x2="-35.56" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-30.48" y1="-27.94" x2="-30.48" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-30.48" y1="-45.72" x2="-35.56" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-35.56" y1="-45.72" x2="-45.72" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-63.5" y1="27.94" x2="-53.34" y2="27.94" width="0.1524" layer="91"/>
<wire x1="-63.5" y1="22.86" x2="-63.5" y2="27.94" width="0.1524" layer="91"/>
<wire x1="-7.62" y1="22.86" x2="-63.5" y2="22.86" width="0.1524" layer="91"/>
<wire x1="-63.5" y1="22.86" x2="-63.5" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="-45.72" x2="-58.42" y2="-33.02" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="-45.72" x2="-63.5" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="-45.72" x2="-50.8" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-50.8" y1="-45.72" x2="-45.72" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-45.72" y1="-45.72" x2="-30.48" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-30.48" y1="-45.72" x2="-25.4" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="58.42" y1="-109.22" x2="58.42" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="63.5" y1="-106.68" x2="71.12" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="71.12" y1="-106.68" x2="81.28" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="81.28" y1="-106.68" x2="58.42" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="58.42" y1="-106.68" x2="99.06" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-106.68" x2="175.26" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="175.26" y1="-106.68" x2="180.34" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="180.34" y1="-106.68" x2="185.42" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-96.52" x2="99.06" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="175.26" y1="-86.36" x2="175.26" y2="-91.44" width="0.1524" layer="91"/>
<wire x1="175.26" y1="-91.44" x2="175.26" y2="-106.68" width="0.1524" layer="91"/>
<wire x1="-12.7" y1="-33.02" x2="-12.7" y2="-45.72" width="0.1524" layer="91"/>
<junction x="152.4" y="-45.72"/>
<junction x="129.54" y="-45.72"/>
<junction x="106.68" y="-45.72"/>
<junction x="-25.4" y="-45.72"/>
<junction x="-35.56" y="-45.72"/>
<junction x="-63.5" y="22.86"/>
<junction x="-58.42" y="-45.72"/>
<junction x="-50.8" y="-45.72"/>
<junction x="-45.72" y="-45.72"/>
<junction x="-30.48" y="-45.72"/>
<junction x="58.42" y="-106.68"/>
<junction x="99.06" y="-106.68"/>
<junction x="175.26" y="-91.44"/>
<junction x="175.26" y="-106.68"/>
<junction x="-12.7" y="-45.72"/>
<pinref part="T4" gate="G$1" pin="E"/>
<pinref part="T3" gate="G$1" pin="E"/>
<pinref part="T2" gate="G$1" pin="E"/>
<pinref part="T1" gate="G$1" pin="E"/>
<pinref part="IC1" gate="G$1" pin="GND@1"/>
<pinref part="C2" gate="G$1" pin="1"/>
<pinref part="C5" gate="G$1" pin="1"/>
<pinref part="C6" gate="G$1" pin="1"/>
<pinref part="C3" gate="G$1" pin="1"/>
<pinref part="C4" gate="G$1" pin="1"/>
<pinref part="IC1" gate="G$1" pin="GND"/>
<pinref part="C1" gate="G$1" pin="1"/>
<pinref part="GND2" gate="1" pin="GND"/>
<pinref part="T5" gate="G$1" pin="E"/>
<pinref part="C11" gate="G$1" pin="1"/>
<pinref part="C10" gate="G$1" pin="-"/>
<pinref part="IC3" gate="P" pin="GND"/>
<wire x1="175.26" y1="-91.44" x2="167.64" y2="-91.44" width="0.1524" layer="91"/>
<pinref part="LSP4" gate="1" pin="MP"/>
<pinref part="LSP6" gate="1" pin="MP"/>
<pinref part="LSP7" gate="1" pin="MP"/>
<junction x="81.28" y="-106.68"/>
<pinref part="LSP8" gate="1" pin="MP"/>
<junction x="71.12" y="-106.68"/>
<junction x="167.64" y="-91.44"/>
<wire x1="175.26" y1="-45.72" x2="180.34" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="180.34" y1="-45.72" x2="180.34" y2="-106.68" width="0.1524" layer="91"/>
<junction x="175.26" y="-45.72"/>
<junction x="180.34" y="-106.68"/>
<wire x1="22.86" y1="-106.68" x2="58.42" y2="-106.68" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<wire x1="40.64" y1="5.08" x2="71.12" y2="5.08" width="0.1524" layer="91"/>
<wire x1="71.12" y1="5.08" x2="71.12" y2="30.48" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PD0(RXD)"/>
<pinref part="R12" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<wire x1="73.66" y1="15.24" x2="73.66" y2="2.54" width="0.1524" layer="91"/>
<wire x1="73.66" y1="2.54" x2="40.64" y2="2.54" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PD1(TXD)"/>
<pinref part="R13" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<wire x1="40.64" y1="0" x2="76.2" y2="0" width="0.1524" layer="91"/>
<wire x1="76.2" y1="0" x2="76.2" y2="25.4" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PD2(INT0)"/>
<pinref part="R14" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<wire x1="40.64" y1="-2.54" x2="78.74" y2="-2.54" width="0.1524" layer="91"/>
<wire x1="78.74" y1="-2.54" x2="78.74" y2="10.16" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PD3(INT1)"/>
<pinref part="R15" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<wire x1="40.64" y1="-5.08" x2="81.28" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="81.28" y1="-5.08" x2="81.28" y2="20.32" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PD4(XCK/T0)"/>
<pinref part="R16" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<wire x1="40.64" y1="-10.16" x2="83.82" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="83.82" y1="-10.16" x2="83.82" y2="5.08" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PD6(AIN0)"/>
<pinref part="R17" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<wire x1="101.6" y1="-30.48" x2="101.6" y2="-35.56" width="0.1524" layer="91"/>
<pinref part="R4" gate="G$1" pin="2"/>
<pinref part="T1" gate="G$1" pin="B"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="T4" gate="G$1" pin="B"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="170.18" y1="-22.86" x2="170.18" y2="-35.56" width="0.1524" layer="91"/>
</segment>
</net>
<net name="2" class="0">
<segment>
<wire x1="154.94" y1="20.32" x2="152.4" y2="20.32" width="0.1524" layer="91"/>
<wire x1="152.4" y1="20.32" x2="152.4" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="T3" gate="G$1" pin="C"/>
<pinref part="LED1" gate="DIG1" pin="COM"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<wire x1="40.64" y1="-12.7" x2="86.36" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="86.36" y1="-12.7" x2="86.36" y2="15.24" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PD7(AIN1)"/>
<pinref part="R18" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<wire x1="40.64" y1="-20.32" x2="88.9" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-20.32" x2="88.9" y2="0" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PB1(OC1A)"/>
<pinref part="R19" gate="G$1" pin="2"/>
</segment>
</net>
<net name="INPUT" class="0">
<segment>
<wire x1="43.18" y1="-91.44" x2="63.5" y2="-91.44" width="0.1524" layer="91"/>
<wire x1="63.5" y1="-91.44" x2="63.5" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="66.04" y1="-91.44" x2="63.5" y2="-91.44" width="0.1524" layer="91"/>
<wire x1="43.18" y1="-86.36" x2="43.18" y2="-91.44" width="0.1524" layer="91"/>
<junction x="63.5" y="-91.44"/>
<pinref part="R5" gate="G$1" pin="1"/>
<pinref part="R10" gate="G$1" pin="2"/>
<pinref part="R11" gate="G$1" pin="1"/>
<pinref part="JP2" gate="G$1" pin="1"/>
<wire x1="-58.42" y1="-86.36" x2="-50.8" y2="-86.36" width="0.1524" layer="91"/>
<pinref part="LSP3" gate="1" pin="MP"/>
<pinref part="C12" gate="G$1" pin="2"/>
<wire x1="-50.8" y1="-86.36" x2="-22.86" y2="-86.36" width="0.1524" layer="91"/>
<junction x="-50.8" y="-86.36"/>
<wire x1="-22.86" y1="-86.36" x2="-22.86" y2="-58.42" width="0.1524" layer="91"/>
<wire x1="-22.86" y1="-58.42" x2="30.48" y2="-58.42" width="0.1524" layer="91"/>
<junction x="-22.86" y="-86.36"/>
<wire x1="30.48" y1="-58.42" x2="30.48" y2="-91.44" width="0.1524" layer="91"/>
<wire x1="30.48" y1="-91.44" x2="43.18" y2="-91.44" width="0.1524" layer="91"/>
<junction x="43.18" y="-91.44"/>
</segment>
</net>
<net name="N$38" class="0">
<segment>
<wire x1="40.64" y1="15.24" x2="40.64" y2="7.62" width="0.1524" layer="91"/>
<wire x1="40.64" y1="7.62" x2="50.8" y2="7.62" width="0.1524" layer="91"/>
<pinref part="R7" gate="G$1" pin="2"/>
<pinref part="IC1" gate="G$1" pin="PC5(ADC5/SCL)"/>
</segment>
</net>
<net name="N$37" class="0">
<segment>
<wire x1="45.72" y1="-58.42" x2="185.42" y2="-58.42" width="0.1524" layer="91"/>
<wire x1="185.42" y1="-58.42" x2="185.42" y2="-81.28" width="0.1524" layer="91"/>
<wire x1="40.64" y1="22.86" x2="45.72" y2="22.86" width="0.1524" layer="91"/>
<wire x1="45.72" y1="-58.42" x2="45.72" y2="22.86" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PC2(ADC2)"/>
<pinref part="LSP5" gate="1" pin="MP"/>
<junction x="185.42" y="-58.42"/>
</segment>
</net>
<net name="N$42" class="0">
<segment>
<wire x1="93.98" y1="-91.44" x2="91.44" y2="-91.44" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-91.44" x2="91.44" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-91.44" x2="86.36" y2="-91.44" width="0.1524" layer="91"/>
<junction x="91.44" y="-91.44"/>
<pinref part="T5" gate="G$1" pin="B"/>
<pinref part="R9" gate="G$1" pin="1"/>
<pinref part="C9" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<pinref part="R21" gate="G$1" pin="1"/>
<pinref part="R23" gate="G$1" pin="1"/>
<wire x1="45.72" y1="-96.52" x2="0" y2="-96.52" width="0.1524" layer="91"/>
<pinref part="Q2" gate="G$1" pin="D"/>
<wire x1="0" y1="-91.44" x2="0" y2="-96.52" width="0.1524" layer="91"/>
<junction x="0" y="-96.52"/>
</segment>
</net>
<net name="+5V" class="0">
<segment>
<wire x1="-30.48" y1="38.1" x2="-30.48" y2="43.18" width="0.1524" layer="91"/>
<pinref part="P+1" gate="1" pin="+5V"/>
<pinref part="D1" gate="G$1" pin="A"/>
<pinref part="LSP1" gate="1" pin="MP"/>
<wire x1="-25.4" y1="43.18" x2="-30.48" y2="43.18" width="0.1524" layer="91"/>
<junction x="-30.48" y="43.18"/>
<pinref part="X1" gate="G$1" pin="1"/>
<wire x1="-25.4" y1="43.18" x2="-7.62" y2="43.18" width="0.1524" layer="91"/>
<junction x="-25.4" y="43.18"/>
</segment>
</net>
<net name="N$41" class="0">
<segment>
<wire x1="40.64" y1="-7.62" x2="60.96" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-7.62" x2="60.96" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-60.96" x2="165.1" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="165.1" y1="-60.96" x2="165.1" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="165.1" y1="-76.2" x2="162.56" y2="-76.2" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="PD5(T1)"/>
<pinref part="IC3" gate="B" pin="Q"/>
<junction x="162.56" y="-76.2"/>
</segment>
</net>
<net name="N$43" class="0">
<segment>
<wire x1="132.08" y1="-76.2" x2="132.08" y2="-78.74" width="0.1524" layer="91"/>
<wire x1="132.08" y1="-78.74" x2="137.16" y2="-78.74" width="0.1524" layer="91"/>
<pinref part="IC3" gate="B" pin="CP"/>
<pinref part="IC3" gate="A" pin="Q"/>
<junction x="132.08" y="-76.2"/>
<junction x="137.16" y="-78.74"/>
</segment>
</net>
<net name="N$39" class="0">
<segment>
<wire x1="63.5" y1="7.62" x2="63.5" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="40.64" y1="-17.78" x2="63.5" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="63.5" y1="-17.78" x2="63.5" y2="-76.2" width="0.1524" layer="91"/>
<wire x1="60.96" y1="7.62" x2="63.5" y2="7.62" width="0.1524" layer="91"/>
<wire x1="63.5" y1="7.62" x2="63.5" y2="15.24" width="0.1524" layer="91"/>
<wire x1="63.5" y1="15.24" x2="60.96" y2="15.24" width="0.1524" layer="91"/>
<wire x1="63.5" y1="15.24" x2="63.5" y2="22.86" width="0.1524" layer="91"/>
<wire x1="63.5" y1="22.86" x2="60.96" y2="22.86" width="0.1524" layer="91"/>
<wire x1="40.64" y1="27.94" x2="63.5" y2="27.94" width="0.1524" layer="91"/>
<wire x1="63.5" y1="22.86" x2="63.5" y2="27.94" width="0.1524" layer="91"/>
<junction x="63.5" y="-17.78"/>
<junction x="63.5" y="22.86"/>
<junction x="63.5" y="15.24"/>
<junction x="63.5" y="7.62"/>
<pinref part="R7" gate="G$1" pin="1"/>
<pinref part="IC1" gate="G$1" pin="PB0(ICP)"/>
<pinref part="R5" gate="G$1" pin="2"/>
<pinref part="C7" gate="G$1" pin="2"/>
<pinref part="R6" gate="G$1" pin="1"/>
<pinref part="IC1" gate="G$1" pin="PC0(ADC0)"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<wire x1="50.8" y1="15.24" x2="53.34" y2="15.24" width="0.1524" layer="91"/>
<wire x1="50.8" y1="22.86" x2="50.8" y2="17.78" width="0.1524" layer="91"/>
<wire x1="40.64" y1="17.78" x2="50.8" y2="17.78" width="0.1524" layer="91"/>
<wire x1="50.8" y1="17.78" x2="50.8" y2="15.24" width="0.1524" layer="91"/>
<junction x="50.8" y="17.78"/>
<pinref part="C7" gate="G$1" pin="1"/>
<pinref part="R6" gate="G$1" pin="2"/>
<pinref part="IC1" gate="G$1" pin="PC4(ADC4/SDA)"/>
</segment>
</net>
<net name="N$44" class="0">
<segment>
<wire x1="43.18" y1="-76.2" x2="43.18" y2="20.32" width="0.1524" layer="91"/>
<wire x1="40.64" y1="20.32" x2="43.18" y2="20.32" width="0.1524" layer="91"/>
<pinref part="R11" gate="G$1" pin="2"/>
<pinref part="IC1" gate="G$1" pin="PC3(ADC3)"/>
</segment>
</net>
<net name="CLOUT" class="0">
<segment>
<wire x1="-45.72" y1="-66.04" x2="-50.8" y2="-66.04" width="0.1524" layer="91"/>
<pinref part="R20" gate="G$1" pin="2"/>
<pinref part="JP3" gate="G$1" pin="1"/>
<pinref part="LSP2" gate="1" pin="MP"/>
<wire x1="-50.8" y1="-66.04" x2="-58.42" y2="-66.04" width="0.1524" layer="91"/>
<junction x="-50.8" y="-66.04"/>
</segment>
</net>
<net name="N$47" class="0">
<segment>
<wire x1="48.26" y1="-48.26" x2="48.26" y2="25.4" width="0.1524" layer="91"/>
<wire x1="48.26" y1="25.4" x2="40.64" y2="25.4" width="0.1524" layer="91"/>
<pinref part="R20" gate="G$1" pin="1"/>
<pinref part="IC1" gate="G$1" pin="PC1(ADC1)"/>
<wire x1="-35.56" y1="-66.04" x2="-35.56" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="-35.56" y1="-48.26" x2="48.26" y2="-48.26" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="IC3" gate="B" pin="!Q"/>
<junction x="162.56" y="-86.36"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="IC3" gate="A" pin="!Q"/>
<junction x="132.08" y="-86.36"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="T3" gate="G$1" pin="B"/>
<pinref part="R2" gate="G$1" pin="2"/>
<wire x1="147.32" y1="-25.4" x2="147.32" y2="-35.56" width="0.1524" layer="91"/>
<wire x1="144.78" y1="-25.4" x2="147.32" y2="-25.4" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="T2" gate="G$1" pin="B"/>
<pinref part="R3" gate="G$1" pin="2"/>
<wire x1="124.46" y1="-27.94" x2="124.46" y2="-35.56" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="PB5(SCK)"/>
<pinref part="R4" gate="G$1" pin="1"/>
<wire x1="40.64" y1="-30.48" x2="91.44" y2="-30.48" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="PB4(MISO)"/>
<pinref part="R3" gate="G$1" pin="1"/>
<wire x1="40.64" y1="-27.94" x2="114.3" y2="-27.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="PB3(MOSI/OC2)"/>
<pinref part="R2" gate="G$1" pin="1"/>
<wire x1="40.64" y1="-25.4" x2="134.62" y2="-25.4" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="PB2(SS/OC1B)"/>
<pinref part="R1" gate="G$1" pin="1"/>
<wire x1="40.64" y1="-22.86" x2="160.02" y2="-22.86" width="0.1524" layer="91"/>
</segment>
</net>
<net name="VCC" class="0">
<segment>
<wire x1="134.62" y1="-83.82" x2="134.62" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="134.62" y1="-86.36" x2="137.16" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="137.16" y1="-86.36" x2="139.7" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="134.62" y1="-73.66" x2="134.62" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="134.62" y1="-83.82" x2="137.16" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="134.62" y1="-53.34" x2="134.62" y2="-73.66" width="0.1524" layer="91"/>
<wire x1="134.62" y1="-73.66" x2="137.16" y2="-73.66" width="0.1524" layer="91"/>
<wire x1="101.6" y1="-86.36" x2="101.6" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="106.68" y1="-83.82" x2="101.6" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="101.6" y1="-83.82" x2="101.6" y2="-73.66" width="0.1524" layer="91"/>
<wire x1="106.68" y1="-73.66" x2="101.6" y2="-73.66" width="0.1524" layer="91"/>
<wire x1="101.6" y1="-73.66" x2="101.6" y2="-53.34" width="0.1524" layer="91"/>
<wire x1="101.6" y1="-53.34" x2="134.62" y2="-53.34" width="0.1524" layer="91"/>
<wire x1="101.6" y1="-40.64" x2="101.6" y2="-53.34" width="0.1524" layer="91"/>
<wire x1="-7.62" y1="-40.64" x2="0" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="0" y1="-40.64" x2="76.2" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-40.64" x2="101.6" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="-7.62" y1="-7.62" x2="-7.62" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="-7.62" y1="-7.62" x2="-12.7" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="-12.7" y1="-7.62" x2="-30.48" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="-30.48" y1="-7.62" x2="-30.48" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="-30.48" y1="-7.62" x2="-30.48" y2="15.24" width="0.1524" layer="91"/>
<wire x1="-30.48" y1="15.24" x2="-35.56" y2="15.24" width="0.1524" layer="91"/>
<wire x1="-30.48" y1="15.24" x2="-30.48" y2="33.02" width="0.1524" layer="91"/>
<wire x1="175.26" y1="-78.74" x2="175.26" y2="-71.12" width="0.1524" layer="91"/>
<wire x1="134.62" y1="-53.34" x2="175.26" y2="-53.34" width="0.1524" layer="91"/>
<wire x1="175.26" y1="-53.34" x2="175.26" y2="-71.12" width="0.1524" layer="91"/>
<wire x1="-12.7" y1="-25.4" x2="-12.7" y2="-7.62" width="0.1524" layer="91"/>
<junction x="101.6" y="-53.34"/>
<junction x="-7.62" y="-7.62"/>
<junction x="-30.48" y="-7.62"/>
<junction x="-30.48" y="15.24"/>
<junction x="101.6" y="-73.66"/>
<junction x="101.6" y="-83.82"/>
<junction x="134.62" y="-83.82"/>
<junction x="134.62" y="-73.66"/>
<junction x="175.26" y="-71.12"/>
<junction x="134.62" y="-53.34"/>
<junction x="-12.7" y="-7.62"/>
<pinref part="L1" gate="G$1" pin="2"/>
<pinref part="C3" gate="G$1" pin="2"/>
<pinref part="R8" gate="G$1" pin="2"/>
<pinref part="IC1" gate="G$1" pin="VCC@1"/>
<pinref part="D1" gate="G$1" pin="C"/>
<pinref part="C11" gate="G$1" pin="2"/>
<pinref part="C10" gate="G$1" pin="+"/>
<pinref part="IC3" gate="A" pin="K"/>
<pinref part="IC3" gate="A" pin="J"/>
<pinref part="IC3" gate="B" pin="K"/>
<pinref part="IC3" gate="B" pin="J"/>
<pinref part="IC3" gate="B" pin="R"/>
<junction x="137.16" y="-86.36"/>
<pinref part="IC3" gate="P" pin="VCC"/>
<wire x1="175.26" y1="-71.12" x2="167.64" y2="-71.12" width="0.1524" layer="91"/>
<pinref part="IC3" gate="A" pin="R"/>
<wire x1="101.6" y1="-86.36" x2="106.68" y2="-86.36" width="0.1524" layer="91"/>
<junction x="137.16" y="-83.82"/>
<junction x="137.16" y="-73.66"/>
<junction x="106.68" y="-86.36"/>
<junction x="106.68" y="-83.82"/>
<junction x="106.68" y="-73.66"/>
<junction x="167.64" y="-71.12"/>
<wire x1="76.2" y1="-71.12" x2="76.2" y2="-40.64" width="0.1524" layer="91"/>
<junction x="76.2" y="-40.64"/>
<pinref part="R22" gate="G$1" pin="2"/>
<wire x1="0" y1="-63.5" x2="0" y2="-40.64" width="0.1524" layer="91"/>
<junction x="0" y="-40.64"/>
</segment>
</net>
<net name="N$51" class="0">
<segment>
<wire x1="-15.24" y1="-86.36" x2="-10.16" y2="-86.36" width="0.1524" layer="91"/>
<wire x1="-10.16" y1="-86.36" x2="-7.62" y2="-86.36" width="0.1524" layer="91"/>
<pinref part="C12" gate="G$1" pin="1"/>
<pinref part="R27" gate="G$1" pin="1"/>
<pinref part="Q2" gate="G$1" pin="G"/>
<wire x1="-10.16" y1="-93.98" x2="-10.16" y2="-86.36" width="0.1524" layer="91"/>
<junction x="-10.16" y="-86.36"/>
</segment>
</net>
<net name="N$52" class="0">
<segment>
<wire x1="91.44" y1="-71.12" x2="86.36" y2="-71.12" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-86.36" x2="99.06" y2="-78.74" width="0.1524" layer="91"/>
<wire x1="106.68" y1="-78.74" x2="99.06" y2="-78.74" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-78.74" x2="99.06" y2="-71.12" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-71.12" x2="91.44" y2="-71.12" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-76.2" x2="91.44" y2="-71.12" width="0.1524" layer="91"/>
<junction x="91.44" y="-71.12"/>
<junction x="99.06" y="-78.74"/>
<pinref part="R8" gate="G$1" pin="1"/>
<pinref part="T5" gate="G$1" pin="C"/>
<pinref part="R9" gate="G$1" pin="2"/>
<pinref part="IC3" gate="A" pin="CP"/>
<junction x="106.68" y="-78.74"/>
</segment>
</net>
<net name="N$36" class="0">
<segment>
<pinref part="R10" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-96.52" x2="76.2" y2="-91.44" width="0.1524" layer="91"/>
<junction x="76.2" y="-91.44"/>
<wire x1="76.2" y1="-91.44" x2="78.74" y2="-91.44" width="0.1524" layer="91"/>
<pinref part="C9" gate="G$1" pin="2"/>
<pinref part="R21" gate="G$1" pin="2"/>
<wire x1="55.88" y1="-96.52" x2="76.2" y2="-96.52" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="Q2" gate="G$1" pin="S"/>
<pinref part="R22" gate="G$1" pin="1"/>
<wire x1="0" y1="-81.28" x2="0" y2="-73.66" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
<note version="8.4" severity="warning">
Since Version 8.4, EAGLE supports properties for SPICE simulation.
Probes in schematics and SPICE mapping objects found in parts and library devices
will not be understood with this version. Update EAGLE to the latest version
for full support of SPICE simulation.
</note>
</compatibility>
</eagle>
