<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="50" unitdist="mil" unit="mm" style="lines" multiple="1" display="no" altdistance="5" altunitdist="mil" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="16" fill="1" visible="no" active="no"/>
<layer number="3" name="Route3" color="17" fill="1" visible="no" active="no"/>
<layer number="4" name="Route4" color="18" fill="1" visible="no" active="no"/>
<layer number="5" name="Route5" color="19" fill="1" visible="no" active="no"/>
<layer number="6" name="Route6" color="25" fill="1" visible="no" active="no"/>
<layer number="7" name="Route7" color="26" fill="1" visible="no" active="no"/>
<layer number="8" name="Route8" color="27" fill="1" visible="no" active="no"/>
<layer number="9" name="Route9" color="28" fill="1" visible="no" active="no"/>
<layer number="10" name="Route10" color="29" fill="1" visible="no" active="no"/>
<layer number="11" name="Route11" color="30" fill="1" visible="no" active="no"/>
<layer number="12" name="Route12" color="20" fill="1" visible="no" active="no"/>
<layer number="13" name="Route13" color="21" fill="1" visible="no" active="no"/>
<layer number="14" name="Route14" color="22" fill="1" visible="no" active="no"/>
<layer number="15" name="Route15" color="23" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="0" y2="68.58" width="0.1524" layer="20"/>
<wire x1="0" y1="68.58" x2="57.15" y2="68.58" width="0.1524" layer="20"/>
<wire x1="57.15" y1="68.58" x2="57.15" y2="0" width="0.1524" layer="20"/>
<wire x1="57.15" y1="0" x2="0" y2="0" width="0.1524" layer="20"/>
</plain>
<libraries>
<library name="relay" urn="urn:adsk.eagle:library:339">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="9814-20" urn="urn:adsk.eagle:footprint:23947/1" library_version="5">
<description>&lt;b&gt;Surface Mount Reed Relays&lt;/b&gt; J-Lead&lt;p&gt;
Source: COTO TECHNOLOGY - 9852-03-00 - RELAY - 91349.pdf</description>
<wire x1="-4.9784" y1="2.3622" x2="4.9784" y2="2.3622" width="0.2032" layer="21"/>
<wire x1="4.9784" y1="2.3622" x2="4.9784" y2="-2.3622" width="0.2032" layer="51"/>
<wire x1="4.9784" y1="-2.3622" x2="-4.9784" y2="-2.3622" width="0.2032" layer="21"/>
<wire x1="-4.9784" y1="-2.3622" x2="-4.9784" y2="2.3622" width="0.2032" layer="51"/>
<wire x1="-4.9022" y1="2.032" x2="-4.9022" y2="1.016" width="0.2032" layer="51" curve="-180" cap="flat"/>
<smd name="1" x="-4.953" y="1.524" dx="1.524" dy="0.508" layer="1"/>
<smd name="3" x="-4.953" y="0.508" dx="1.524" dy="0.508" layer="1"/>
<smd name="5" x="-4.953" y="-0.508" dx="1.524" dy="0.508" layer="1"/>
<smd name="7" x="-4.953" y="-1.524" dx="1.524" dy="0.508" layer="1"/>
<smd name="8" x="4.953" y="-1.524" dx="1.524" dy="0.508" layer="1" rot="R180"/>
<smd name="6" x="4.953" y="-0.508" dx="1.524" dy="0.508" layer="1" rot="R180"/>
<smd name="4" x="4.953" y="0.508" dx="1.524" dy="0.508" layer="1" rot="R180"/>
<smd name="2" x="4.953" y="1.524" dx="1.524" dy="0.508" layer="1" rot="R180"/>
<text x="-4.572" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.556" y="-0.508" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.588" y1="1.3208" x2="-4.7244" y2="1.7272" layer="51"/>
<rectangle x1="-5.588" y1="0.3048" x2="-4.7244" y2="0.7112" layer="51"/>
<rectangle x1="-5.588" y1="-0.7112" x2="-4.7244" y2="-0.3048" layer="51"/>
<rectangle x1="-5.588" y1="-1.7272" x2="-4.7244" y2="-1.3208" layer="51"/>
<rectangle x1="4.7244" y1="-1.7272" x2="5.588" y2="-1.3208" layer="51" rot="R180"/>
<rectangle x1="4.7244" y1="-0.7112" x2="5.588" y2="-0.3048" layer="51" rot="R180"/>
<rectangle x1="4.7244" y1="0.3048" x2="5.588" y2="0.7112" layer="51" rot="R180"/>
<rectangle x1="4.7244" y1="1.3208" x2="5.588" y2="1.7272" layer="51" rot="R180"/>
</package>
<package name="CB1" urn="urn:adsk.eagle:footprint:24128/1" library_version="5">
<description>&lt;b&gt;HIGH POWER AUTOMOTIVE RELAY&lt;/b&gt; NAiS&lt;p&gt;
Source: http://www.mew-europe.com/..  en_ds_61202_0000.pdf</description>
<wire x1="-12.4" y1="10.15" x2="-12.4" y2="-10.15" width="0.2032" layer="21"/>
<wire x1="-11.65" y1="-10.9" x2="11.65" y2="-10.9" width="0.2032" layer="21"/>
<wire x1="12.4" y1="-10.15" x2="12.4" y2="10.15" width="0.2032" layer="21"/>
<wire x1="11.65" y1="10.9" x2="-11.65" y2="10.9" width="0.2032" layer="21"/>
<wire x1="-12.4" y1="10.15" x2="-11.65" y2="10.9" width="0.2032" layer="21" curve="-90"/>
<wire x1="11.65" y1="10.9" x2="12.4" y2="10.15" width="0.2032" layer="21" curve="-90"/>
<wire x1="12.4" y1="-10.15" x2="11.65" y2="-10.9" width="0.2032" layer="21" curve="-90"/>
<wire x1="-11.65" y1="-10.9" x2="-12.4" y2="-10.15" width="0.2032" layer="21" curve="-90"/>
<pad name="30" x="8.95" y="0" drill="2.3" rot="R180"/>
<pad name="87" x="-8.95" y="0" drill="2.3" rot="R180"/>
<pad name="87A" x="-0.95" y="0" drill="2.3" rot="R180"/>
<pad name="86" x="-0.55" y="8.4" drill="2.3" rot="R180"/>
<pad name="85" x="-0.55" y="-8.4" drill="2.3" rot="R180"/>
<text x="-10.16" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.16" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="9814-20" urn="urn:adsk.eagle:package:24294/1" type="box" library_version="5">
<description>Surface Mount Reed Relays J-Lead
<packageinstances>
<packageinstance name="9814-20"/>
</packageinstances>
</package3d>
<package3d name="CB1" urn="urn:adsk.eagle:package:24437/1" type="box" library_version="5">
<description>HIGH POWER AUTOMOTIVE RELAY NAiS
<packageinstances>
<packageinstance name="CB1"/>
</packageinstances>
</package3d>
</packages3d>
</library>
<library name="opto-honeywell" urn="urn:adsk.eagle:library:315">
<description>&lt;b&gt;Honeywell Laser Opto Sensor Devices&lt;/b&gt;&lt;p&gt;
<packages>
<package name="ST2" urn="urn:adsk.eagle:footprint:21550/1" library_version="4">
<description>&lt;b&gt;OPTO SENSOR DEVICE&lt;/b&gt;</description>
<wire x1="-3.7465" y1="-6.1595" x2="-3.7465" y2="6.223" width="0.254" layer="21"/>
<wire x1="-3.7465" y1="6.223" x2="1.397" y2="6.223" width="0.254" layer="21"/>
<wire x1="1.397" y1="6.223" x2="1.397" y2="-6.1595" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-6.1595" x2="-3.7465" y2="-6.1595" width="0.254" layer="21"/>
<wire x1="9.525" y1="-3.3655" x2="18.9865" y2="-3.3655" width="0.254" layer="21"/>
<wire x1="18.9865" y1="-3.3655" x2="18.9865" y2="-0.762" width="0.254" layer="21"/>
<wire x1="18.9865" y1="-0.762" x2="18.9865" y2="0.762" width="0.254" layer="21"/>
<wire x1="18.9865" y1="0.762" x2="18.9865" y2="3.3655" width="0.254" layer="21"/>
<wire x1="18.9865" y1="3.3655" x2="9.525" y2="3.3655" width="0.254" layer="21"/>
<wire x1="14.859" y1="3.429" x2="14.859" y2="4.0005" width="0.254" layer="21"/>
<wire x1="14.859" y1="4.0005" x2="16.129" y2="4.0005" width="0.254" layer="21"/>
<wire x1="16.129" y1="4.0005" x2="16.129" y2="3.429" width="0.254" layer="21"/>
<wire x1="16.129" y1="-3.429" x2="16.129" y2="-4.0005" width="0.254" layer="21"/>
<wire x1="16.129" y1="-4.0005" x2="14.859" y2="-4.0005" width="0.254" layer="21"/>
<wire x1="14.859" y1="-4.0005" x2="14.859" y2="-3.429" width="0.254" layer="21"/>
<wire x1="7" y1="3.8" x2="6.599" y2="3.4" width="0.1524" layer="21"/>
<wire x1="6.599" y1="3.4" x2="6.199" y2="3.8" width="0.1524" layer="21"/>
<wire x1="6.199" y1="3.8" x2="5.8" y2="3.4" width="0.1524" layer="21"/>
<wire x1="5.8" y1="3.4" x2="5.4" y2="3.8" width="0.1524" layer="21"/>
<wire x1="5.4" y1="3.8" x2="5" y2="3.4" width="0.1524" layer="21"/>
<wire x1="5" y1="3.4" x2="4.599" y2="3.8" width="0.1524" layer="21"/>
<wire x1="7" y1="-3.4" x2="6.599" y2="-3.8" width="0.1524" layer="21"/>
<wire x1="6.599" y1="-3.8" x2="6.199" y2="-3.4" width="0.1524" layer="21"/>
<wire x1="6.199" y1="-3.4" x2="5.8" y2="-3.8" width="0.1524" layer="21"/>
<wire x1="5.8" y1="-3.8" x2="5.4" y2="-3.4" width="0.1524" layer="21"/>
<wire x1="5.4" y1="-3.4" x2="5" y2="-3.8" width="0.1524" layer="21"/>
<wire x1="5" y1="-3.8" x2="4.599" y2="-3.4" width="0.1524" layer="21"/>
<wire x1="4.587" y1="3.8" x2="4.161" y2="3.4" width="0.1524" layer="21"/>
<wire x1="4.161" y1="3.4" x2="3.761" y2="3.8" width="0.1524" layer="21"/>
<wire x1="3.761" y1="3.8" x2="3.361" y2="3.4" width="0.1524" layer="21"/>
<wire x1="3.361" y1="3.4" x2="2.961" y2="3.8" width="0.1524" layer="21"/>
<wire x1="2.961" y1="3.8" x2="2.561" y2="3.4" width="0.1524" layer="21"/>
<wire x1="4.561" y1="-3.4" x2="4.161" y2="-3.8" width="0.1524" layer="21"/>
<wire x1="4.161" y1="-3.8" x2="3.761" y2="-3.4" width="0.1524" layer="21"/>
<wire x1="3.761" y1="-3.4" x2="3.361" y2="-3.8" width="0.1524" layer="21"/>
<wire x1="3.361" y1="-3.8" x2="2.961" y2="-3.4" width="0.1524" layer="21"/>
<wire x1="2.961" y1="-3.4" x2="2.561" y2="-3.8" width="0.1524" layer="21"/>
<wire x1="18.9865" y1="0.762" x2="12.7" y2="0.762" width="0.254" layer="21"/>
<wire x1="12.7" y1="-0.762" x2="18.9865" y2="-0.762" width="0.254" layer="21"/>
<wire x1="12.7" y1="-0.762" x2="12.7" y2="0.762" width="0.254" layer="21" curve="-180"/>
<wire x1="9.451" y1="3.8" x2="9.451" y2="-3.331" width="0.1524" layer="21"/>
<wire x1="9.451" y1="3.8" x2="9.051" y2="3.4" width="0.1524" layer="21"/>
<wire x1="9.051" y1="3.4" x2="8.651" y2="3.8" width="0.1524" layer="21"/>
<wire x1="9.451" y1="-3.4" x2="9.051" y2="-3.8" width="0.1524" layer="21"/>
<wire x1="9.051" y1="-3.8" x2="8.651" y2="-3.4" width="0.1524" layer="21"/>
<wire x1="8.651" y1="3.8" x2="8.25" y2="3.4" width="0.1524" layer="21"/>
<wire x1="8.25" y1="3.4" x2="7.85" y2="3.8" width="0.1524" layer="21"/>
<wire x1="8.651" y1="-3.4" x2="8.25" y2="-3.8" width="0.1524" layer="21"/>
<wire x1="8.25" y1="-3.8" x2="7.85" y2="-3.4" width="0.1524" layer="21"/>
<wire x1="7.825" y1="3.8" x2="7.425" y2="3.4" width="0.1524" layer="21"/>
<wire x1="7.425" y1="3.4" x2="7.025" y2="3.8" width="0.1524" layer="21"/>
<wire x1="7.825" y1="-3.4" x2="7.425" y2="-3.8" width="0.1524" layer="21"/>
<wire x1="7.425" y1="-3.8" x2="7.025" y2="-3.4" width="0.1524" layer="21"/>
<wire x1="7.063" y1="2.517" x2="6.726" y2="1.305" width="0.1524" layer="51"/>
<wire x1="6.726" y1="1.305" x2="6.263" y2="2.517" width="0.1524" layer="51"/>
<wire x1="6.263" y1="2.517" x2="5.927" y2="1.305" width="0.1524" layer="51"/>
<wire x1="5.927" y1="1.305" x2="5.463" y2="2.517" width="0.1524" layer="51"/>
<wire x1="5.463" y1="2.517" x2="5.127" y2="1.305" width="0.1524" layer="51"/>
<wire x1="5.127" y1="1.305" x2="4.663" y2="2.517" width="0.1524" layer="51"/>
<wire x1="4.625" y1="2.517" x2="4.288" y2="1.305" width="0.1524" layer="51"/>
<wire x1="4.288" y1="1.305" x2="3.825" y2="2.517" width="0.1524" layer="51"/>
<wire x1="3.825" y1="2.517" x2="3.488" y2="1.305" width="0.1524" layer="51"/>
<wire x1="3.488" y1="1.305" x2="3.024" y2="2.517" width="0.1524" layer="51"/>
<wire x1="3.024" y1="2.517" x2="2.688" y2="1.305" width="0.1524" layer="51"/>
<wire x1="9.413" y1="2.517" x2="9.178" y2="1.305" width="0.1524" layer="51"/>
<wire x1="9.178" y1="1.305" x2="8.689" y2="2.517" width="0.1524" layer="51"/>
<wire x1="8.689" y1="2.517" x2="8.377" y2="1.305" width="0.1524" layer="51"/>
<wire x1="8.377" y1="1.305" x2="7.914" y2="2.517" width="0.1524" layer="51"/>
<wire x1="7.889" y1="2.517" x2="7.552" y2="1.305" width="0.1524" layer="51"/>
<wire x1="7.552" y1="1.305" x2="7.088" y2="2.517" width="0.1524" layer="51"/>
<wire x1="2.548" y1="3.4" x2="2.072" y2="3.876" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.778" x2="2.2098" y2="2.54" width="0.1524" layer="51"/>
<wire x1="2.2098" y1="2.54" x2="2.072" y2="3.876" width="0.1524" layer="51"/>
<wire x1="2.675" y1="1.33" x2="2.212" y2="2.543" width="0.1524" layer="51"/>
<wire x1="7.266" y1="-1.318" x2="6.93" y2="-2.48" width="0.1524" layer="51"/>
<wire x1="6.93" y1="-2.48" x2="6.466" y2="-1.318" width="0.1524" layer="51"/>
<wire x1="6.466" y1="-1.318" x2="6.13" y2="-2.48" width="0.1524" layer="51"/>
<wire x1="6.13" y1="-2.48" x2="5.666" y2="-1.318" width="0.1524" layer="51"/>
<wire x1="5.666" y1="-1.318" x2="5.33" y2="-2.48" width="0.1524" layer="51"/>
<wire x1="5.33" y1="-2.48" x2="4.866" y2="-1.318" width="0.1524" layer="51"/>
<wire x1="4.828" y1="-1.318" x2="4.491" y2="-2.48" width="0.1524" layer="51"/>
<wire x1="4.491" y1="-2.48" x2="4.028" y2="-1.318" width="0.1524" layer="51"/>
<wire x1="4.028" y1="-1.318" x2="3.691" y2="-2.48" width="0.1524" layer="51"/>
<wire x1="3.691" y1="-2.48" x2="3.228" y2="-1.318" width="0.1524" layer="51"/>
<wire x1="3.228" y1="-1.318" x2="2.891" y2="-2.48" width="0.1524" layer="51"/>
<wire x1="9.381" y1="-2.48" x2="8.892" y2="-1.318" width="0.1524" layer="51"/>
<wire x1="8.892" y1="-1.318" x2="8.581" y2="-2.48" width="0.1524" layer="51"/>
<wire x1="8.581" y1="-2.48" x2="8.117" y2="-1.318" width="0.1524" layer="51"/>
<wire x1="8.117" y1="-1.318" x2="7.755" y2="-2.48" width="0.1524" layer="51"/>
<wire x1="7.755" y1="-2.48" x2="7.292" y2="-1.318" width="0.1524" layer="51"/>
<wire x1="2.878" y1="-2.455" x2="2.415" y2="-1.293" width="0.1524" layer="51"/>
<wire x1="2.415" y1="-1.293" x2="2.079" y2="-2.455" width="0.1524" layer="51"/>
<wire x1="2.548" y1="-3.8" x2="2.097" y2="-3.349" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.4036" x2="2.6924" y2="1.3716" width="0.1524" layer="51"/>
<wire x1="2.9718" y1="3.7846" x2="3.0226" y2="2.4892" width="0.1524" layer="51"/>
<wire x1="3.3274" y1="3.3782" x2="3.4798" y2="1.3462" width="0.1524" layer="51"/>
<wire x1="3.7592" y1="3.7592" x2="3.81" y2="2.4638" width="0.1524" layer="51"/>
<wire x1="4.1656" y1="3.4036" x2="4.2926" y2="1.3462" width="0.1524" layer="51"/>
<wire x1="4.5974" y1="3.7846" x2="4.6482" y2="2.4638" width="0.1524" layer="51"/>
<wire x1="5.0038" y1="3.4036" x2="5.1308" y2="1.3462" width="0.1524" layer="51"/>
<wire x1="5.4102" y1="3.7592" x2="5.461" y2="2.4384" width="0.1524" layer="51"/>
<wire x1="5.7912" y1="3.4036" x2="5.9182" y2="1.397" width="0.1524" layer="51"/>
<wire x1="6.1976" y1="3.7846" x2="6.2738" y2="2.4638" width="0.1524" layer="51"/>
<wire x1="6.604" y1="3.4036" x2="6.731" y2="1.3716" width="0.1524" layer="51"/>
<wire x1="7.0104" y1="3.7846" x2="7.0866" y2="2.4638" width="0.1524" layer="51"/>
<wire x1="7.4168" y1="3.4036" x2="7.5438" y2="1.397" width="0.1524" layer="51"/>
<wire x1="7.8232" y1="3.7846" x2="7.8994" y2="2.4638" width="0.1524" layer="51"/>
<wire x1="8.255" y1="3.4036" x2="8.382" y2="1.3716" width="0.1524" layer="51"/>
<wire x1="8.6614" y1="3.7592" x2="8.6868" y2="2.4384" width="0.1524" layer="51"/>
<wire x1="9.0424" y1="3.4036" x2="9.1694" y2="1.3716" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.3716" x2="2.5654" y2="-3.7846" width="0.1524" layer="51"/>
<wire x1="2.8956" y1="-2.4384" x2="2.9718" y2="-3.4036" width="0.1524" layer="51"/>
<wire x1="3.2258" y1="-1.4224" x2="3.3782" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="3.683" y1="-2.413" x2="3.7592" y2="-3.4036" width="0.1524" layer="51"/>
<wire x1="4.0386" y1="-1.397" x2="4.1656" y2="-3.7846" width="0.1524" layer="51"/>
<wire x1="4.4958" y1="-2.413" x2="4.572" y2="-3.4036" width="0.1524" layer="51"/>
<wire x1="4.8514" y1="-1.3716" x2="5.0038" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="5.334" y1="-2.4384" x2="5.4102" y2="-3.4036" width="0.1524" layer="51"/>
<wire x1="5.6642" y1="-1.397" x2="5.7912" y2="-3.7846" width="0.1524" layer="51"/>
<wire x1="6.1214" y1="-2.3876" x2="6.1976" y2="-3.4036" width="0.1524" layer="51"/>
<wire x1="6.477" y1="-1.4478" x2="6.604" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="6.9342" y1="-2.413" x2="7.0104" y2="-3.4036" width="0.1524" layer="51"/>
<wire x1="7.2898" y1="-1.3716" x2="7.4422" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="7.747" y1="-2.3876" x2="7.8232" y2="-3.4036" width="0.1524" layer="51"/>
<wire x1="8.128" y1="-1.4224" x2="8.255" y2="-3.7592" width="0.1524" layer="51"/>
<wire x1="8.5852" y1="-2.413" x2="8.6614" y2="-3.4036" width="0.1524" layer="51"/>
<wire x1="8.89" y1="-1.3716" x2="9.0678" y2="-3.7846" width="0.1524" layer="51"/>
<wire x1="1.9685" y1="3.3655" x2="1.524" y2="3.3655" width="0.1524" layer="21"/>
<wire x1="1.9685" y1="3.3655" x2="1.9685" y2="-3.3655" width="0.1524" layer="21"/>
<wire x1="1.9685" y1="-3.3655" x2="1.524" y2="-3.3655" width="0.1524" layer="21"/>
<wire x1="1.9685" y1="3.3655" x2="1.9685" y2="3.8735" width="0.1524" layer="21"/>
<wire x1="1.9685" y1="3.8735" x2="2.0955" y2="3.8735" width="0.1524" layer="21"/>
<circle x="0" y="4.7625" radius="1.524" width="1.27" layer="42"/>
<circle x="0" y="-4.7625" radius="1.524" width="1.27" layer="42"/>
<pad name="1" x="-6.985" y="-1.27" drill="0.6096" shape="octagon"/>
<pad name="2" x="-5.715" y="0" drill="0.6096" shape="octagon"/>
<pad name="3" x="-6.985" y="1.27" drill="0.6096" shape="octagon"/>
<text x="-2.921" y="-2.286" size="1.27" layer="21">1</text>
<text x="-3.175" y="1.016" size="1.27" layer="21">3</text>
<text x="-1.905" y="-0.635" size="1.27" layer="21">2</text>
<text x="-5.08" y="6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.35" y="-8.255" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-6.9215" y1="1.016" x2="-5.7785" y2="1.524" layer="51"/>
<rectangle x1="-5.6515" y1="-0.254" x2="-4.5085" y2="0.254" layer="51"/>
<rectangle x1="-6.9215" y1="-1.524" x2="-5.7785" y2="-1.016" layer="51"/>
<rectangle x1="-5.7785" y1="1.016" x2="-3.8735" y2="1.524" layer="21"/>
<rectangle x1="-4.5085" y1="-0.254" x2="-3.8735" y2="0.254" layer="21"/>
<rectangle x1="-5.7785" y1="-1.524" x2="-3.8735" y2="-1.016" layer="21"/>
<rectangle x1="-4.064" y1="-6.604" x2="1.778" y2="6.604" layer="41"/>
<rectangle x1="-4.064" y1="-6.604" x2="1.778" y2="6.604" layer="43"/>
<hole x="0" y="-4.7625" drill="1.778"/>
<hole x="0" y="4.7625" drill="1.778"/>
</package>
</packages>
<packages3d>
<package3d name="ST2" urn="urn:adsk.eagle:package:21608/1" type="box" library_version="4">
<description>OPTO SENSOR DEVICE</description>
<packageinstances>
<packageinstance name="ST2"/>
</packageinstances>
</package3d>
</packages3d>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="6mil"/>
<param name="mdWirePad" value="6mil"/>
<param name="mdWireVia" value="6mil"/>
<param name="mdPadPad" value="6mil"/>
<param name="mdPadVia" value="6mil"/>
<param name="mdViaVia" value="6mil"/>
<param name="mdSmdPad" value="6mil"/>
<param name="mdSmdVia" value="6mil"/>
<param name="mdSmdSmd" value="6mil"/>
<param name="mdViaViaSameLayer" value="6mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="6mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="6mil"/>
<param name="msDrill" value="0.35mm"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="checkStop" value="0"/>
<param name="checkValues" value="0"/>
<param name="checkNames" value="1"/>
<param name="checkWireStubs" value="1"/>
<param name="checkPolygonWidth" value="0"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="a"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="a"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="IC1" library="relay" library_urn="urn:adsk.eagle:library:339" package="9814-20" package3d_urn="urn:adsk.eagle:package:24294/1" value="" x="17.78" y="34.29" smashed="yes">
<attribute name="NAME" x="17.018" y="38.1" size="1.27" layer="25"/>
<attribute name="VALUE" x="14.224" y="33.782" size="1.27" layer="27"/>
</element>
<element name="IC2" library="relay" library_urn="urn:adsk.eagle:library:339" package="9814-20" package3d_urn="urn:adsk.eagle:package:24294/1" value="" x="36.83" y="34.29" smashed="yes">
<attribute name="NAME" x="34.798" y="38.1" size="1.27" layer="25"/>
<attribute name="VALUE" x="33.274" y="33.782" size="1.27" layer="27"/>
</element>
<element name="APK3" library="relay" library_urn="urn:adsk.eagle:library:339" package="CB1" package3d_urn="urn:adsk.eagle:package:24437/1" value="" x="25.4" y="19.05" smashed="yes">
<attribute name="NAME" x="39.37" y="17.78" size="1.27" layer="25"/>
<attribute name="VALUE" x="15.24" y="13.97" size="1.27" layer="27"/>
</element>
<element name="BNCAK125" library="opto-honeywell" library_urn="urn:adsk.eagle:library:315" package="ST2" package3d_urn="urn:adsk.eagle:package:21608/1" value="" x="17.78" y="52.07" smashed="yes">
<attribute name="NAME" x="25.4" y="59.055" size="1.27" layer="25"/>
<attribute name="VALUE" x="11.43" y="43.815" size="1.27" layer="27"/>
</element>
</elements>
<signals>
</signals>
<mfgpreviewcolors>
<mfgpreviewcolor name="soldermaskcolor" color="0xC8008000"/>
<mfgpreviewcolor name="silkscreencolor" color="0xFFFEFEFE"/>
<mfgpreviewcolor name="backgroundcolor" color="0xFF282828"/>
<mfgpreviewcolor name="coppercolor" color="0xFFFFBF00"/>
<mfgpreviewcolor name="substratecolor" color="0xFF786E46"/>
</mfgpreviewcolors>
</board>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
</compatibility>
</eagle>
