<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.6.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.3175" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<plain>
<text x="5.715" y="38.735" size="0.8128" layer="23">D7</text>
<text x="8.255" y="38.735" size="0.8128" layer="23">D6</text>
<text x="10.795" y="38.735" size="0.8128" layer="23">D5</text>
<text x="13.335" y="38.735" size="0.8128" layer="23">D4</text>
<text x="26.3525" y="38.735" size="0.8128" layer="23">E</text>
<text x="31.115" y="38.735" size="0.8128" layer="23">RS</text>
<text x="33.9725" y="38.735" size="0.8128" layer="23">C</text>
<text x="36.5125" y="38.735" size="0.8128" layer="23">+</text>
<text x="39.0525" y="38.735" size="0.8128" layer="23">-</text>
<text x="41.5925" y="38.735" size="0.8128" layer="23">L-</text>
<text x="43.815" y="38.735" size="0.8128" layer="23">L+</text>
<circle x="0.3175" y="43.18" radius="2.2225" width="1.27" layer="16"/>
<circle x="76.2" y="43.18" radius="2.2225" width="1.27" layer="16"/>
<rectangle x1="1.5875" y1="44.45" x2="3.175" y2="46.0375" layer="16"/>
<wire x1="7.62" y1="40.005" x2="6.985" y2="39.37" width="0.254" layer="23"/>
<wire x1="6.985" y1="39.37" x2="5.715" y2="39.37" width="0.254" layer="23"/>
<wire x1="5.715" y1="39.37" x2="5.08" y2="40.005" width="0.254" layer="23"/>
<wire x1="5.08" y1="40.005" x2="5.08" y2="41.275" width="0.254" layer="23"/>
<wire x1="5.08" y1="41.275" x2="5.715" y2="41.91" width="0.254" layer="23"/>
<wire x1="5.715" y1="41.91" x2="6.985" y2="41.91" width="0.254" layer="23"/>
<wire x1="6.985" y1="41.91" x2="7.62" y2="41.275" width="0.254" layer="23"/>
<wire x1="7.62" y1="41.275" x2="8.255" y2="41.91" width="0.254" layer="23"/>
<wire x1="8.255" y1="41.91" x2="9.525" y2="41.91" width="0.254" layer="23"/>
<wire x1="9.525" y1="41.91" x2="10.16" y2="41.275" width="0.254" layer="23"/>
<wire x1="10.16" y1="41.275" x2="10.795" y2="41.91" width="0.254" layer="23"/>
<wire x1="10.795" y1="41.91" x2="12.065" y2="41.91" width="0.254" layer="23"/>
<wire x1="12.065" y1="41.91" x2="12.7" y2="41.275" width="0.254" layer="23"/>
<wire x1="12.7" y1="41.275" x2="13.335" y2="41.91" width="0.254" layer="23"/>
<wire x1="13.335" y1="41.91" x2="14.605" y2="41.91" width="0.254" layer="23"/>
<wire x1="14.605" y1="41.91" x2="15.24" y2="41.275" width="0.254" layer="23"/>
<wire x1="15.24" y1="41.275" x2="15.875" y2="41.91" width="0.254" layer="23"/>
<wire x1="15.875" y1="41.91" x2="17.145" y2="41.91" width="0.254" layer="23"/>
<wire x1="17.145" y1="41.91" x2="17.78" y2="41.275" width="0.254" layer="23"/>
<wire x1="17.78" y1="41.275" x2="18.415" y2="41.91" width="0.254" layer="23"/>
<wire x1="18.415" y1="41.91" x2="19.685" y2="41.91" width="0.254" layer="23"/>
<wire x1="19.685" y1="41.91" x2="20.32" y2="41.275" width="0.254" layer="23"/>
<wire x1="20.32" y1="41.275" x2="20.955" y2="41.91" width="0.254" layer="23"/>
<wire x1="20.955" y1="41.91" x2="22.225" y2="41.91" width="0.254" layer="23"/>
<wire x1="22.225" y1="41.91" x2="22.86" y2="41.275" width="0.254" layer="23"/>
<wire x1="22.86" y1="41.275" x2="23.495" y2="41.91" width="0.254" layer="23"/>
<wire x1="23.495" y1="41.91" x2="24.765" y2="41.91" width="0.254" layer="23"/>
<wire x1="24.765" y1="41.91" x2="25.4" y2="41.275" width="0.254" layer="23"/>
<wire x1="25.4" y1="41.275" x2="26.035" y2="41.91" width="0.254" layer="23"/>
<wire x1="26.035" y1="41.91" x2="27.305" y2="41.91" width="0.254" layer="23"/>
<wire x1="27.305" y1="41.91" x2="27.94" y2="41.275" width="0.254" layer="23"/>
<wire x1="27.94" y1="41.275" x2="28.575" y2="41.91" width="0.254" layer="23"/>
<wire x1="28.575" y1="41.91" x2="29.845" y2="41.91" width="0.254" layer="23"/>
<wire x1="29.845" y1="41.91" x2="30.48" y2="41.275" width="0.254" layer="23"/>
<wire x1="30.48" y1="41.275" x2="31.115" y2="41.91" width="0.254" layer="23"/>
<wire x1="31.115" y1="41.91" x2="32.385" y2="41.91" width="0.254" layer="23"/>
<wire x1="32.385" y1="41.91" x2="33.02" y2="41.275" width="0.254" layer="23"/>
<wire x1="33.02" y1="41.275" x2="33.655" y2="41.91" width="0.254" layer="23"/>
<wire x1="33.655" y1="41.91" x2="34.925" y2="41.91" width="0.254" layer="23"/>
<wire x1="34.925" y1="41.91" x2="35.56" y2="41.275" width="0.254" layer="23"/>
<wire x1="35.56" y1="41.275" x2="36.195" y2="41.91" width="0.254" layer="23"/>
<wire x1="36.195" y1="41.91" x2="37.465" y2="41.91" width="0.254" layer="23"/>
<wire x1="37.465" y1="41.91" x2="38.1" y2="41.275" width="0.254" layer="23"/>
<wire x1="38.1" y1="41.275" x2="38.735" y2="41.91" width="0.254" layer="23"/>
<wire x1="38.735" y1="41.91" x2="40.005" y2="41.91" width="0.254" layer="23"/>
<wire x1="40.005" y1="41.91" x2="40.64" y2="41.275" width="0.254" layer="23"/>
<wire x1="40.64" y1="41.275" x2="41.275" y2="41.91" width="0.254" layer="23"/>
<wire x1="41.275" y1="41.91" x2="42.545" y2="41.91" width="0.254" layer="23"/>
<wire x1="42.545" y1="41.91" x2="43.18" y2="41.275" width="0.254" layer="23"/>
<wire x1="43.18" y1="41.275" x2="43.815" y2="41.91" width="0.254" layer="23"/>
<wire x1="43.815" y1="41.91" x2="45.085" y2="41.91" width="0.254" layer="23"/>
<wire x1="45.085" y1="41.91" x2="45.72" y2="41.275" width="0.254" layer="23"/>
<wire x1="45.72" y1="40.005" x2="45.085" y2="39.37" width="0.254" layer="23"/>
<wire x1="45.085" y1="39.37" x2="43.815" y2="39.37" width="0.254" layer="23"/>
<wire x1="43.815" y1="39.37" x2="43.18" y2="40.005" width="0.254" layer="23"/>
<wire x1="43.18" y1="40.005" x2="42.545" y2="39.37" width="0.254" layer="23"/>
<wire x1="42.545" y1="39.37" x2="41.275" y2="39.37" width="0.254" layer="23"/>
<wire x1="41.275" y1="39.37" x2="40.64" y2="40.005" width="0.254" layer="23"/>
<wire x1="40.64" y1="40.005" x2="40.005" y2="39.37" width="0.254" layer="23"/>
<wire x1="40.005" y1="39.37" x2="38.735" y2="39.37" width="0.254" layer="23"/>
<wire x1="38.735" y1="39.37" x2="38.1" y2="40.005" width="0.254" layer="23"/>
<wire x1="38.1" y1="40.005" x2="37.465" y2="39.37" width="0.254" layer="23"/>
<wire x1="37.465" y1="39.37" x2="36.195" y2="39.37" width="0.254" layer="23"/>
<wire x1="36.195" y1="39.37" x2="35.56" y2="40.005" width="0.254" layer="23"/>
<wire x1="35.56" y1="40.005" x2="34.925" y2="39.37" width="0.254" layer="23"/>
<wire x1="34.925" y1="39.37" x2="33.655" y2="39.37" width="0.254" layer="23"/>
<wire x1="33.655" y1="39.37" x2="33.02" y2="40.005" width="0.254" layer="23"/>
<wire x1="33.02" y1="40.005" x2="32.385" y2="39.37" width="0.254" layer="23"/>
<wire x1="32.385" y1="39.37" x2="31.115" y2="39.37" width="0.254" layer="23"/>
<wire x1="31.115" y1="39.37" x2="30.48" y2="40.005" width="0.254" layer="23"/>
<wire x1="30.48" y1="40.005" x2="29.845" y2="39.37" width="0.254" layer="23"/>
<wire x1="29.845" y1="39.37" x2="28.575" y2="39.37" width="0.254" layer="23"/>
<wire x1="28.575" y1="39.37" x2="27.94" y2="40.005" width="0.254" layer="23"/>
<wire x1="27.94" y1="40.005" x2="27.305" y2="39.37" width="0.254" layer="23"/>
<wire x1="27.305" y1="39.37" x2="26.035" y2="39.37" width="0.254" layer="23"/>
<wire x1="26.035" y1="39.37" x2="25.4" y2="40.005" width="0.254" layer="23"/>
<wire x1="25.4" y1="40.005" x2="24.765" y2="39.37" width="0.254" layer="23"/>
<wire x1="24.765" y1="39.37" x2="23.495" y2="39.37" width="0.254" layer="23"/>
<wire x1="23.495" y1="39.37" x2="22.86" y2="40.005" width="0.254" layer="23"/>
<wire x1="22.86" y1="40.005" x2="22.225" y2="39.37" width="0.254" layer="23"/>
<wire x1="22.225" y1="39.37" x2="20.955" y2="39.37" width="0.254" layer="23"/>
<wire x1="20.955" y1="39.37" x2="20.32" y2="40.005" width="0.254" layer="23"/>
<wire x1="20.32" y1="40.005" x2="19.685" y2="39.37" width="0.254" layer="23"/>
<wire x1="19.685" y1="39.37" x2="18.415" y2="39.37" width="0.254" layer="23"/>
<wire x1="18.415" y1="39.37" x2="17.78" y2="40.005" width="0.254" layer="23"/>
<wire x1="17.78" y1="40.005" x2="17.145" y2="39.37" width="0.254" layer="23"/>
<wire x1="17.145" y1="39.37" x2="15.875" y2="39.37" width="0.254" layer="23"/>
<wire x1="15.875" y1="39.37" x2="15.24" y2="40.005" width="0.254" layer="23"/>
<wire x1="15.24" y1="40.005" x2="14.605" y2="39.37" width="0.254" layer="23"/>
<wire x1="14.605" y1="39.37" x2="13.335" y2="39.37" width="0.254" layer="23"/>
<wire x1="13.335" y1="39.37" x2="12.7" y2="40.005" width="0.254" layer="23"/>
<wire x1="12.7" y1="40.005" x2="12.065" y2="39.37" width="0.254" layer="23"/>
<wire x1="12.065" y1="39.37" x2="10.795" y2="39.37" width="0.254" layer="23"/>
<wire x1="10.795" y1="39.37" x2="10.16" y2="40.005" width="0.254" layer="23"/>
<wire x1="10.16" y1="40.005" x2="9.525" y2="39.37" width="0.254" layer="23"/>
<wire x1="9.525" y1="39.37" x2="8.255" y2="39.37" width="0.254" layer="23"/>
<wire x1="8.255" y1="39.37" x2="7.62" y2="40.005" width="0.254" layer="23"/>
<wire x1="7.62" y1="40.005" x2="7.62" y2="41.275" width="0.254" layer="23"/>
<wire x1="10.16" y1="41.275" x2="10.16" y2="40.005" width="0.254" layer="23"/>
<wire x1="12.7" y1="41.275" x2="12.7" y2="40.005" width="0.254" layer="23"/>
<wire x1="15.24" y1="41.275" x2="15.24" y2="40.005" width="0.254" layer="23"/>
<wire x1="17.78" y1="41.275" x2="17.78" y2="40.005" width="0.254" layer="23"/>
<wire x1="20.32" y1="41.275" x2="20.32" y2="40.005" width="0.254" layer="23"/>
<wire x1="22.86" y1="40.005" x2="22.86" y2="41.275" width="0.254" layer="23"/>
<wire x1="25.4" y1="40.005" x2="25.4" y2="41.275" width="0.254" layer="23"/>
<wire x1="27.94" y1="40.005" x2="27.94" y2="41.275" width="0.254" layer="23"/>
<wire x1="30.48" y1="40.005" x2="30.48" y2="41.275" width="0.254" layer="23"/>
<wire x1="33.02" y1="40.005" x2="33.02" y2="41.275" width="0.254" layer="23"/>
<wire x1="35.56" y1="40.005" x2="35.56" y2="41.275" width="0.254" layer="23"/>
<wire x1="38.1" y1="40.005" x2="38.1" y2="41.275" width="0.254" layer="23"/>
<wire x1="40.64" y1="40.005" x2="40.64" y2="41.275" width="0.254" layer="23"/>
<wire x1="43.18" y1="40.005" x2="43.18" y2="41.275" width="0.254" layer="23"/>
<wire x1="45.72" y1="40.005" x2="45.72" y2="41.275" width="0.254" layer="23"/>
<wire x1="15.24" y1="55.5625" x2="40.64" y2="55.5625" width="0.254" layer="23"/>
<wire x1="40.64" y1="55.5625" x2="40.64" y2="53.0225" width="0.254" layer="23"/>
<wire x1="40.64" y1="53.0225" x2="40.64" y2="51.435" width="0.254" layer="23"/>
<wire x1="40.64" y1="51.435" x2="40.64" y2="48.5775" width="0.254" layer="23"/>
<wire x1="40.64" y1="48.5775" x2="15.24" y2="48.5775" width="0.254" layer="23"/>
<wire x1="15.24" y1="48.5775" x2="15.24" y2="55.5625" width="0.254" layer="23"/>
<wire x1="40.64" y1="53.0225" x2="40.64" y2="51.435" width="0.254" layer="23" curve="180"/>
<wire x1="42.2275" y1="53.0225" x2="43.18" y2="53.975" width="0.254" layer="23" curve="-90"/>
<wire x1="43.18" y1="53.975" x2="44.1325" y2="53.0225" width="0.254" layer="23" curve="-90"/>
<wire x1="44.1325" y1="51.1175" x2="43.18" y2="50.165" width="0.254" layer="23" curve="-90"/>
<wire x1="43.18" y1="50.165" x2="42.2275" y2="51.1175" width="0.254" layer="23" curve="-90"/>
<wire x1="43.18" y1="54.61" x2="43.18" y2="53.975" width="0.254" layer="23"/>
<wire x1="42.2275" y1="53.0225" x2="42.2275" y2="51.1175" width="0.254" layer="23"/>
<wire x1="44.1325" y1="53.0225" x2="44.1325" y2="51.1175" width="0.254" layer="23"/>
<wire x1="43.18" y1="50.165" x2="43.18" y2="49.53" width="0.254" layer="23"/>
<wire x1="69.5325" y1="59.69" x2="79.0575" y2="59.69" width="0.254" layer="23"/>
<wire x1="79.0575" y1="59.69" x2="79.0575" y2="58.42" width="0.254" layer="23"/>
<wire x1="79.0575" y1="58.42" x2="79.0575" y2="56.515" width="0.254" layer="23"/>
<wire x1="79.0575" y1="56.515" x2="79.0575" y2="49.53" width="0.254" layer="23"/>
<wire x1="79.0575" y1="49.53" x2="69.5325" y2="49.53" width="0.254" layer="23"/>
<wire x1="69.5325" y1="49.53" x2="69.5325" y2="59.69" width="0.254" layer="23"/>
<wire x1="79.0575" y1="58.42" x2="80.645" y2="58.42" width="0.254" layer="23"/>
<wire x1="80.645" y1="58.42" x2="80.645" y2="56.515" width="0.254" layer="23"/>
<wire x1="80.645" y1="56.515" x2="79.0575" y2="56.515" width="0.254" layer="23"/>
<rectangle x1="69.215" y1="54.9275" x2="79.0575" y2="56.8325" layer="16"/>
<rectangle x1="72.0725" y1="45.72" x2="79.375" y2="53.975" layer="16"/>
<rectangle x1="71.4375" y1="38.735" x2="73.025" y2="46.0375" layer="16"/>
<rectangle x1="72.7075" y1="44.45" x2="73.9775" y2="46.355" layer="16"/>
<rectangle x1="74.295" y1="45.4025" x2="75.8825" y2="46.0375" layer="16"/>
<rectangle x1="46.6725" y1="38.4175" x2="67.6275" y2="40.3225" layer="16"/>
<rectangle x1="54.61" y1="46.0375" x2="59.055" y2="49.2125" layer="16"/>
<rectangle x1="59.69" y1="52.3875" x2="62.5475" y2="54.2925" layer="16"/>
<rectangle x1="59.3725" y1="54.9275" x2="68.58" y2="56.8325" layer="16"/>
<wire x1="49.53" y1="53.0225" x2="49.53" y2="52.07" width="0.254" layer="23"/>
<wire x1="49.53" y1="52.07" x2="49.53" y2="51.1175" width="0.254" layer="23"/>
<wire x1="49.53" y1="51.1175" x2="52.07" y2="51.1175" width="0.254" layer="23"/>
<wire x1="52.07" y1="51.1175" x2="52.07" y2="52.07" width="0.254" layer="23"/>
<wire x1="52.07" y1="52.07" x2="52.07" y2="53.0225" width="0.254" layer="23"/>
<wire x1="52.07" y1="53.0225" x2="49.53" y2="53.0225" width="0.254" layer="23"/>
<wire x1="47.625" y1="52.07" x2="49.53" y2="52.07" width="0.254" layer="23"/>
<wire x1="52.07" y1="52.07" x2="54.2925" y2="52.07" width="0.254" layer="23"/>
<wire x1="41.91" y1="45.72" x2="46.355" y2="45.72" width="0.254" layer="23"/>
<wire x1="33.9725" y1="43.18" x2="46.99" y2="43.18" width="0.254" layer="23"/>
<wire x1="60.0075" y1="54.2925" x2="60.0075" y2="49.8475" width="0.254" layer="23" curve="204.189514"/>
<wire x1="60.0075" y1="49.8475" x2="60.6425" y2="50.4825" width="0.254" layer="23"/>
<wire x1="60.6425" y1="50.4825" x2="60.6425" y2="53.6575" width="0.254" layer="23"/>
<wire x1="60.6425" y1="53.6575" x2="60.0075" y2="54.2925" width="0.254" layer="23"/>
<wire x1="56.8325" y1="52.07" x2="59.3725" y2="52.07" width="0.254" layer="23"/>
<wire x1="59.3725" y1="53.34" x2="59.3725" y2="54.61" width="0.254" layer="23"/>
<wire x1="59.3725" y1="50.8" x2="59.3725" y2="49.53" width="0.254" layer="23"/>
<rectangle x1="54.61" y1="54.9275" x2="59.055" y2="60.96" layer="16"/>
<rectangle x1="48.5775" y1="58.7375" x2="54.9275" y2="60.6425" layer="16"/>
<wire x1="50.8" y1="59.3725" x2="51.7525" y2="60.325" width="0.254" layer="23" curve="-90"/>
<wire x1="51.7525" y1="60.325" x2="52.705" y2="59.3725" width="0.254" layer="23" curve="-90"/>
<wire x1="52.705" y1="57.4675" x2="51.7525" y2="56.515" width="0.254" layer="23" curve="-90"/>
<wire x1="51.7525" y1="56.515" x2="50.8" y2="57.4675" width="0.254" layer="23" curve="-90"/>
<wire x1="51.7525" y1="60.96" x2="51.7525" y2="60.325" width="0.254" layer="23"/>
<wire x1="50.8" y1="59.3725" x2="50.8" y2="57.4675" width="0.254" layer="23"/>
<wire x1="52.705" y1="59.3725" x2="52.705" y2="57.4675" width="0.254" layer="23"/>
<wire x1="51.7525" y1="56.515" x2="51.7525" y2="55.88" width="0.254" layer="23"/>
<wire x1="46.355" y1="58.42" x2="46.355" y2="49.53" width="0.254" layer="23"/>
<wire x1="47.625" y1="59.3725" x2="48.5775" y2="60.325" width="0.254" layer="23" curve="-90"/>
<wire x1="48.5775" y1="60.325" x2="49.53" y2="59.3725" width="0.254" layer="23" curve="-90"/>
<wire x1="49.53" y1="57.4675" x2="48.5775" y2="56.515" width="0.254" layer="23" curve="-90"/>
<wire x1="48.5775" y1="56.515" x2="47.625" y2="57.4675" width="0.254" layer="23" curve="-90"/>
<wire x1="48.5775" y1="60.96" x2="48.5775" y2="60.325" width="0.254" layer="23"/>
<wire x1="47.625" y1="59.3725" x2="47.625" y2="57.4675" width="0.254" layer="23"/>
<wire x1="49.53" y1="59.3725" x2="49.53" y2="57.4675" width="0.254" layer="23"/>
<wire x1="48.5775" y1="56.515" x2="48.5775" y2="55.88" width="0.254" layer="23"/>
<rectangle x1="44.7675" y1="58.7375" x2="48.895" y2="60.6425" layer="16"/>
<wire x1="40.9575" y1="57.4675" x2="40.005" y2="58.42" width="0.254" layer="23" curve="-90"/>
<wire x1="40.005" y1="58.42" x2="40.9575" y2="59.3725" width="0.254" layer="23" curve="-90"/>
<wire x1="42.8625" y1="59.3725" x2="43.815" y2="58.42" width="0.254" layer="23" curve="-90"/>
<wire x1="43.815" y1="58.42" x2="42.8625" y2="57.4675" width="0.254" layer="23" curve="-90"/>
<wire x1="39.37" y1="58.42" x2="40.005" y2="58.42" width="0.254" layer="23"/>
<wire x1="40.9575" y1="57.4675" x2="42.8625" y2="57.4675" width="0.254" layer="23"/>
<wire x1="40.9575" y1="59.3725" x2="42.8625" y2="59.3725" width="0.254" layer="23"/>
<wire x1="43.815" y1="58.42" x2="44.45" y2="58.42" width="0.254" layer="23"/>
<wire x1="40.9575" y1="60.0075" x2="40.005" y2="60.96" width="0.254" layer="23" curve="-90"/>
<wire x1="40.005" y1="60.96" x2="40.9575" y2="61.9125" width="0.254" layer="23" curve="-90"/>
<wire x1="42.8625" y1="61.9125" x2="43.815" y2="60.96" width="0.254" layer="23" curve="-90"/>
<wire x1="43.815" y1="60.96" x2="42.8625" y2="60.0075" width="0.254" layer="23" curve="-90"/>
<wire x1="39.37" y1="60.96" x2="40.005" y2="60.96" width="0.254" layer="23"/>
<wire x1="40.9575" y1="60.0075" x2="42.8625" y2="60.0075" width="0.254" layer="23"/>
<wire x1="40.9575" y1="61.9125" x2="42.8625" y2="61.9125" width="0.254" layer="23"/>
<wire x1="43.815" y1="60.96" x2="44.45" y2="60.96" width="0.254" layer="23"/>
<wire x1="34.29" y1="57.785" x2="35.2425" y2="59.055" width="0.254" layer="23"/>
<wire x1="35.8775" y1="59.055" x2="36.83" y2="57.785" width="0.254" layer="23"/>
<wire x1="36.195" y1="59.055" x2="34.925" y2="59.055" width="0.254" layer="23"/>
<wire x1="34.925" y1="59.055" x2="34.925" y2="62.5475" width="0.254" layer="23"/>
<wire x1="36.195" y1="59.055" x2="36.195" y2="62.5475" width="0.254" layer="23"/>
<wire x1="34.925" y1="62.5475" x2="36.195" y2="62.5475" width="0.254" layer="23" curve="-180"/>
<rectangle x1="62.865" y1="57.4675" x2="80.01" y2="60.6425" layer="16"/>
<circle x="58.42" y="72.0725" radius="10.795" width="0.254" layer="25"/>
<circle x="58.42" y="72.0725" radius="10.164959375" width="0.254" layer="23"/>
<circle x="58.42" y="72.0725" radius="9.525" width="0.254" layer="23"/>
<wire x1="55.5625" y1="64.135" x2="55.5625" y2="83.185" width="0.254" layer="23"/>
<wire x1="61.2775" y1="64.135" x2="61.2775" y2="83.185" width="0.254" layer="23"/>
<rectangle x1="56.1975" y1="61.2775" x2="80.01" y2="64.4525" layer="16"/>
<rectangle x1="42.2275" y1="67.945" x2="44.45" y2="82.8675" layer="16"/>
<rectangle x1="44.45" y1="75.8825" x2="50.8" y2="83.185" layer="16"/>
<rectangle x1="47.3075" y1="67.6275" x2="50.8" y2="76.2" layer="16"/>
<rectangle x1="46.99" y1="67.6275" x2="47.625" y2="68.2625" layer="16"/>
<rectangle x1="50.4825" y1="67.6275" x2="69.85" y2="79.375" layer="16"/>
<rectangle x1="66.04" y1="79.0575" x2="69.85" y2="83.185" layer="16"/>
<wire x1="39.37" y1="70.485" x2="39.37" y2="71.755" width="0.254" layer="23"/>
<wire x1="39.37" y1="71.755" x2="39.37" y2="75.2475" width="0.254" layer="23"/>
<wire x1="38.4175" y1="71.755" x2="39.37" y2="71.755" width="0.254" layer="23"/>
<wire x1="39.37" y1="71.755" x2="40.3225" y2="71.755" width="0.254" layer="23"/>
<wire x1="38.4175" y1="73.9775" x2="40.3225" y2="73.9775" width="0.254" layer="23"/>
<wire x1="40.3225" y1="73.9775" x2="39.37" y2="71.755" width="0.254" layer="23"/>
<wire x1="39.37" y1="71.755" x2="38.4175" y2="73.9775" width="0.254" layer="23"/>
<rectangle x1="44.7675" y1="61.2775" x2="51.435" y2="64.4525" layer="16"/>
<wire x1="32.385" y1="81.915" x2="32.385" y2="79.0575" width="0.254" layer="23"/>
<wire x1="32.385" y1="79.0575" x2="31.75" y2="79.0575" width="0.254" layer="23"/>
<wire x1="31.75" y1="79.0575" x2="26.67" y2="79.0575" width="0.254" layer="23"/>
<wire x1="26.67" y1="79.0575" x2="26.035" y2="79.0575" width="0.254" layer="23"/>
<wire x1="26.035" y1="79.0575" x2="26.035" y2="81.915" width="0.254" layer="23"/>
<wire x1="26.67" y1="78.74" x2="26.67" y2="79.0575" width="0.254" layer="23"/>
<wire x1="31.75" y1="78.74" x2="31.75" y2="79.0575" width="0.254" layer="23"/>
<wire x1="26.035" y1="81.915" x2="27.94" y2="81.915" width="0.254" layer="23"/>
<wire x1="27.94" y1="81.915" x2="30.48" y2="81.915" width="0.254" layer="23"/>
<wire x1="30.48" y1="81.915" x2="32.385" y2="81.915" width="0.254" layer="23"/>
<wire x1="27.94" y1="81.915" x2="27.94" y2="83.185" width="0.254" layer="23"/>
<wire x1="27.94" y1="83.185" x2="30.48" y2="83.185" width="0.254" layer="23"/>
<wire x1="30.48" y1="83.185" x2="30.48" y2="81.915" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="74.295" x2="1.27" y2="74.295" width="0.254" layer="23"/>
<wire x1="1.27" y1="74.295" x2="1.27" y2="73.66" width="0.254" layer="23"/>
<wire x1="1.27" y1="73.66" x2="1.27" y2="68.58" width="0.254" layer="23"/>
<wire x1="1.27" y1="68.58" x2="1.27" y2="67.945" width="0.254" layer="23"/>
<wire x1="1.27" y1="67.945" x2="-1.5875" y2="67.945" width="0.254" layer="23"/>
<wire x1="1.5875" y1="68.58" x2="1.27" y2="68.58" width="0.254" layer="23"/>
<wire x1="1.5875" y1="73.66" x2="1.27" y2="73.66" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="67.945" x2="-1.5875" y2="69.85" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="69.85" x2="-1.5875" y2="72.39" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="72.39" x2="-1.5875" y2="74.295" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="69.85" x2="-2.8575" y2="69.85" width="0.254" layer="23"/>
<wire x1="-2.8575" y1="69.85" x2="-2.8575" y2="72.39" width="0.254" layer="23"/>
<wire x1="-2.8575" y1="72.39" x2="-1.5875" y2="72.39" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="53.975" x2="1.27" y2="53.975" width="0.254" layer="23"/>
<wire x1="1.27" y1="53.975" x2="1.27" y2="53.34" width="0.254" layer="23"/>
<wire x1="1.27" y1="53.34" x2="1.27" y2="48.26" width="0.254" layer="23"/>
<wire x1="1.27" y1="48.26" x2="1.27" y2="47.625" width="0.254" layer="23"/>
<wire x1="1.27" y1="47.625" x2="-1.5875" y2="47.625" width="0.254" layer="23"/>
<wire x1="1.5875" y1="48.26" x2="1.27" y2="48.26" width="0.254" layer="23"/>
<wire x1="1.5875" y1="53.34" x2="1.27" y2="53.34" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="47.625" x2="-1.5875" y2="49.53" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="49.53" x2="-1.5875" y2="52.07" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="52.07" x2="-1.5875" y2="53.975" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="49.53" x2="-2.8575" y2="49.53" width="0.254" layer="23"/>
<wire x1="-2.8575" y1="49.53" x2="-2.8575" y2="52.07" width="0.254" layer="23"/>
<wire x1="-2.8575" y1="52.07" x2="-1.5875" y2="52.07" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="64.135" x2="1.27" y2="64.135" width="0.254" layer="23"/>
<wire x1="1.27" y1="64.135" x2="1.27" y2="63.5" width="0.254" layer="23"/>
<wire x1="1.27" y1="63.5" x2="1.27" y2="58.42" width="0.254" layer="23"/>
<wire x1="1.27" y1="58.42" x2="1.27" y2="57.785" width="0.254" layer="23"/>
<wire x1="1.27" y1="57.785" x2="-1.5875" y2="57.785" width="0.254" layer="23"/>
<wire x1="1.5875" y1="58.42" x2="1.27" y2="58.42" width="0.254" layer="23"/>
<wire x1="1.5875" y1="63.5" x2="1.27" y2="63.5" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="57.785" x2="-1.5875" y2="59.69" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="59.69" x2="-1.5875" y2="62.23" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="62.23" x2="-1.5875" y2="64.135" width="0.254" layer="23"/>
<wire x1="-1.5875" y1="59.69" x2="-2.8575" y2="59.69" width="0.254" layer="23"/>
<wire x1="-2.8575" y1="59.69" x2="-2.8575" y2="62.23" width="0.254" layer="23"/>
<wire x1="-2.8575" y1="62.23" x2="-1.5875" y2="62.23" width="0.254" layer="23"/>
<rectangle x1="-0.635" y1="71.755" x2="3.81" y2="76.835" layer="16"/>
<rectangle x1="0" y1="76.5175" x2="1.5875" y2="77.7875" layer="16"/>
<wire x1="46.355" y1="45.72" x2="46.355" y2="46.6725" width="0.254" layer="23"/>
<wire x1="46.355" y1="46.6725" x2="49.8475" y2="46.6725" width="0.254" layer="23"/>
<wire x1="49.8475" y1="46.6725" x2="49.8475" y2="45.72" width="0.254" layer="23"/>
<wire x1="49.8475" y1="45.72" x2="49.8475" y2="44.7675" width="0.254" layer="23"/>
<wire x1="49.8475" y1="44.7675" x2="46.355" y2="44.7675" width="0.254" layer="23"/>
<wire x1="46.355" y1="44.7675" x2="46.355" y2="45.72" width="0.254" layer="23"/>
<wire x1="49.8475" y1="45.72" x2="54.2925" y2="45.72" width="0.254" layer="23"/>
<wire x1="12.065" y1="57.15" x2="13.0175" y2="57.15" width="0.254" layer="23"/>
<wire x1="13.0175" y1="57.15" x2="13.97" y2="57.15" width="0.254" layer="23"/>
<wire x1="13.97" y1="57.15" x2="13.97" y2="59.69" width="0.254" layer="23"/>
<wire x1="13.97" y1="59.69" x2="13.0175" y2="59.69" width="0.254" layer="23"/>
<wire x1="13.0175" y1="59.69" x2="12.065" y2="59.69" width="0.254" layer="23"/>
<wire x1="12.065" y1="59.69" x2="12.065" y2="57.15" width="0.254" layer="23"/>
<wire x1="13.0175" y1="53.34" x2="13.0175" y2="57.15" width="0.254" layer="23"/>
<wire x1="13.0175" y1="59.69" x2="13.0175" y2="60.96" width="0.254" layer="23"/>
<wire x1="9.8425" y1="57.15" x2="10.795" y2="57.15" width="0.254" layer="23"/>
<wire x1="10.795" y1="57.15" x2="11.7475" y2="57.15" width="0.254" layer="23"/>
<wire x1="11.7475" y1="57.15" x2="11.7475" y2="59.69" width="0.254" layer="23"/>
<wire x1="11.7475" y1="59.69" x2="10.795" y2="59.69" width="0.254" layer="23"/>
<wire x1="10.795" y1="59.69" x2="9.8425" y2="59.69" width="0.254" layer="23"/>
<wire x1="9.8425" y1="59.69" x2="9.8425" y2="57.15" width="0.254" layer="23"/>
<wire x1="10.795" y1="55.88" x2="10.795" y2="57.15" width="0.254" layer="23"/>
<wire x1="10.795" y1="59.69" x2="10.795" y2="60.96" width="0.254" layer="23"/>
<wire x1="5.3975" y1="61.9125" x2="5.3975" y2="60.96" width="0.254" layer="23"/>
<wire x1="5.3975" y1="60.96" x2="5.3975" y2="60.0075" width="0.254" layer="23"/>
<wire x1="5.3975" y1="60.0075" x2="7.9375" y2="60.0075" width="0.254" layer="23"/>
<wire x1="7.9375" y1="60.0075" x2="7.9375" y2="60.96" width="0.254" layer="23"/>
<wire x1="7.9375" y1="60.96" x2="7.9375" y2="61.9125" width="0.254" layer="23"/>
<wire x1="7.9375" y1="61.9125" x2="5.3975" y2="61.9125" width="0.254" layer="23"/>
<wire x1="4.1275" y1="60.96" x2="5.3975" y2="60.96" width="0.254" layer="23"/>
<wire x1="7.9375" y1="60.96" x2="9.2075" y2="60.96" width="0.254" layer="23"/>
<rectangle x1="34.6075" y1="63.8175" x2="36.5125" y2="80.9625" layer="16"/>
<wire x1="36.5125" y1="64.4525" x2="44.7675" y2="64.4525" width="0.254" layer="23"/>
<wire x1="39.37" y1="68.8975" x2="35.56" y2="68.8975" width="0.254" layer="23"/>
<wire x1="35.56" y1="68.8975" x2="29.21" y2="68.8975" width="0.254" layer="23"/>
<wire x1="35.56" y1="67.945" x2="35.56" y2="68.8975" width="0.254" layer="23"/>
<wire x1="35.56" y1="68.8975" x2="35.56" y2="69.85" width="0.254" layer="23"/>
<wire x1="33.3375" y1="67.945" x2="33.3375" y2="69.85" width="0.254" layer="23"/>
<wire x1="33.3375" y1="69.85" x2="35.56" y2="68.8975" width="0.254" layer="23"/>
<wire x1="35.56" y1="68.8975" x2="33.3375" y2="67.945" width="0.254" layer="23"/>
<wire x1="31.75" y1="60.96" x2="31.75" y2="62.5475" width="0.254" layer="23"/>
<wire x1="31.75" y1="62.5475" x2="31.75" y2="66.04" width="0.254" layer="23"/>
<wire x1="30.7975" y1="62.5475" x2="31.75" y2="62.5475" width="0.254" layer="23"/>
<wire x1="31.75" y1="62.5475" x2="32.7025" y2="62.5475" width="0.254" layer="23"/>
<wire x1="30.7975" y1="64.77" x2="32.7025" y2="64.77" width="0.254" layer="23"/>
<wire x1="32.7025" y1="64.77" x2="31.75" y2="62.5475" width="0.254" layer="23"/>
<wire x1="31.75" y1="62.5475" x2="30.7975" y2="64.77" width="0.254" layer="23"/>
<wire x1="28.2575" y1="59.69" x2="29.21" y2="59.69" width="0.254" layer="23"/>
<wire x1="29.21" y1="59.69" x2="30.1625" y2="59.69" width="0.254" layer="23"/>
<wire x1="30.1625" y1="59.69" x2="30.1625" y2="62.23" width="0.254" layer="23"/>
<wire x1="30.1625" y1="62.23" x2="29.21" y2="62.23" width="0.254" layer="23"/>
<wire x1="29.21" y1="62.23" x2="28.2575" y2="62.23" width="0.254" layer="23"/>
<wire x1="28.2575" y1="62.23" x2="28.2575" y2="59.69" width="0.254" layer="23"/>
<wire x1="29.21" y1="58.42" x2="29.21" y2="59.69" width="0.254" layer="23"/>
<wire x1="29.21" y1="62.23" x2="29.21" y2="63.5" width="0.254" layer="23"/>
<rectangle x1="7.9375" y1="76.5175" x2="9.8425" y2="78.4225" layer="16"/>
<rectangle x1="4.445" y1="58.7375" x2="6.35" y2="60.6425" layer="16"/>
<wire x1="10.4775" y1="67.945" x2="14.9225" y2="67.945" width="0.254" layer="23" curve="204.189514"/>
<wire x1="14.9225" y1="67.945" x2="14.2875" y2="68.58" width="0.254" layer="23"/>
<wire x1="14.2875" y1="68.58" x2="11.1125" y2="68.58" width="0.254" layer="23"/>
<wire x1="11.1125" y1="68.58" x2="10.4775" y2="67.945" width="0.254" layer="23"/>
<wire x1="12.7" y1="64.77" x2="12.7" y2="67.31" width="0.254" layer="23"/>
<wire x1="11.43" y1="67.31" x2="10.16" y2="67.31" width="0.254" layer="23"/>
<wire x1="13.97" y1="67.31" x2="15.24" y2="67.31" width="0.254" layer="23"/>
<rectangle x1="3.175" y1="71.4375" x2="5.3975" y2="73.3425" layer="16"/>
<circle x="11.43" y="72.39" radius="2.559765625" width="0.254" layer="23"/>
<wire x1="20.0025" y1="69.215" x2="19.05" y2="70.1675" width="0.254" layer="23" curve="-90"/>
<wire x1="19.05" y1="70.1675" x2="20.0025" y2="71.12" width="0.254" layer="23" curve="-90"/>
<wire x1="21.9075" y1="71.12" x2="22.86" y2="70.1675" width="0.254" layer="23" curve="-90"/>
<wire x1="22.86" y1="70.1675" x2="21.9075" y2="69.215" width="0.254" layer="23" curve="-90"/>
<wire x1="18.415" y1="70.1675" x2="19.05" y2="70.1675" width="0.254" layer="23"/>
<wire x1="20.0025" y1="69.215" x2="21.9075" y2="69.215" width="0.254" layer="23"/>
<wire x1="20.0025" y1="71.12" x2="21.9075" y2="71.12" width="0.254" layer="23"/>
<wire x1="22.86" y1="70.1675" x2="23.495" y2="70.1675" width="0.254" layer="23"/>
<rectangle x1="14.9225" y1="67.6275" x2="18.7325" y2="72.0725" layer="16"/>
<rectangle x1="2.8575" y1="43.4975" x2="3.4925" y2="44.45" layer="16"/>
<rectangle x1="-2.54" y1="45.72" x2="3.81" y2="50.165" layer="16"/>
<rectangle x1="3.81" y1="81.5975" x2="36.5125" y2="82.8675" layer="16"/>
<rectangle x1="45.085" y1="69.215" x2="45.4025" y2="74.93" layer="16"/>
<rectangle x1="51.435" y1="61.2775" x2="56.8325" y2="64.4525" layer="16"/>
<rectangle x1="58.42" y1="57.4675" x2="63.5" y2="60.6425" layer="16"/>
<rectangle x1="67.31" y1="38.4175" x2="72.0725" y2="40.3225" layer="16"/>
<rectangle x1="61.2775" y1="45.72" x2="66.3575" y2="54.61" layer="16"/>
<rectangle x1="0.635" y1="76.5175" x2="3.175" y2="83.185" layer="16"/>
<rectangle x1="-2.8575" y1="50.4825" x2="-0.9525" y2="57.785" layer="16"/>
<rectangle x1="-2.54" y1="70.485" x2="-0.635" y2="76.5175" layer="16"/>
<rectangle x1="-0.635" y1="70.485" x2="4.1275" y2="71.755" layer="16"/>
<rectangle x1="1.905" y1="64.135" x2="3.81" y2="65.405" layer="16"/>
<rectangle x1="-3.175" y1="76.5175" x2="-2.8575" y2="76.835" layer="16"/>
<rectangle x1="72.7075" y1="38.4175" x2="73.9775" y2="46.0375" layer="16"/>
<rectangle x1="73.3425" y1="44.7675" x2="74.6125" y2="46.355" layer="16"/>
<rectangle x1="73.025" y1="68.8975" x2="79.375" y2="72.0725" layer="16"/>
<rectangle x1="71.4375" y1="69.215" x2="72.7075" y2="74.93" layer="16"/>
<rectangle x1="72.7075" y1="69.215" x2="73.3425" y2="73.9775" layer="16"/>
<wire x1="23.1775" y1="59.69" x2="24.13" y2="59.69" width="0.254" layer="23"/>
<wire x1="24.13" y1="59.69" x2="25.0825" y2="59.69" width="0.254" layer="23"/>
<wire x1="25.0825" y1="59.69" x2="25.0825" y2="62.23" width="0.254" layer="23"/>
<wire x1="25.0825" y1="62.23" x2="24.13" y2="62.23" width="0.254" layer="23"/>
<wire x1="24.13" y1="62.23" x2="23.1775" y2="62.23" width="0.254" layer="23"/>
<wire x1="23.1775" y1="62.23" x2="23.1775" y2="59.69" width="0.254" layer="23"/>
<wire x1="24.13" y1="58.42" x2="24.13" y2="59.69" width="0.254" layer="23"/>
<wire x1="24.13" y1="62.23" x2="24.13" y2="63.5" width="0.254" layer="23"/>
<rectangle x1="39.6875" y1="73.3425" x2="41.5925" y2="83.185" layer="16"/>
<rectangle x1="26.3525" y1="63.8175" x2="28.8925" y2="66.04" layer="16"/>
<rectangle x1="10.4775" y1="75.2475" x2="28.8925" y2="78.4225" layer="16"/>
<rectangle x1="23.8125" y1="65.0875" x2="26.3525" y2="72.0725" layer="16"/>
<wire x1="20.955" y1="60.96" x2="20.955" y2="62.865" width="0.254" layer="23"/>
<wire x1="20.955" y1="62.865" x2="20.955" y2="67.31" width="0.254" layer="23"/>
<wire x1="20.0025" y1="62.865" x2="20.955" y2="62.865" width="0.254" layer="23"/>
<wire x1="20.955" y1="62.865" x2="21.9075" y2="62.865" width="0.254" layer="23"/>
<wire x1="20.0025" y1="65.0875" x2="21.9075" y2="65.0875" width="0.254" layer="23"/>
<wire x1="21.9075" y1="65.0875" x2="20.955" y2="62.865" width="0.254" layer="23"/>
<wire x1="20.955" y1="62.865" x2="20.0025" y2="65.0875" width="0.254" layer="23"/>
<rectangle x1="29.5275" y1="59.055" x2="31.115" y2="60.325" layer="16"/>
<text x="26.035" y="51.1175" size="1.778" layer="23">Ic1</text>
<text x="13.97" y="63.5" size="1.778" layer="23">Ic2</text>
<text x="9.525" y="75.2475" size="1.778" layer="23">C1</text>
<text x="19.685" y="69.5325" size="1.27" layer="23">C2</text>
<text x="43.815" y="51.1175" size="1.27" layer="23" rot="R90">C3</text>
<text x="52.3875" y="57.15" size="1.27" layer="23" rot="R90">C4</text>
<text x="49.2125" y="57.15" size="1.27" layer="23" rot="R90">C5</text>
<text x="40.64" y="60.325" size="1.27" layer="23">C6</text>
<text x="40.64" y="57.785" size="1.27" layer="23">C7</text>
<text x="61.2775" y="51.7525" size="1.27" layer="23">T1</text>
<text x="73.66" y="53.975" size="1.27" layer="23">P1</text>
<text x="5.715" y="60.325" size="1.27" layer="23">R1</text>
<text x="11.43" y="57.15" size="1.27" layer="23" rot="R90">R2</text>
<text x="13.6525" y="57.4675" size="1.27" layer="23" rot="R90">R3</text>
<text x="24.765" y="59.69" size="1.27" layer="23" rot="R90">R4</text>
<text x="29.845" y="59.69" size="1.27" layer="23" rot="R90">R5</text>
<text x="49.53" y="51.435" size="1.27" layer="23">R6</text>
<text x="46.99" y="45.085" size="1.27" layer="23">R7</text>
<text x="36.83" y="61.9125" size="1.27" layer="23">Q1</text>
<text x="53.6575" y="71.755" size="1.778" layer="23">CR2032</text>
<text x="84.455" y="53.0225" size="1.778" layer="23">IC1         =  PIC18F14K22
IC2         =  78L05
T1           =  BC337
C1           = 10uF
C2,3,4    =  100nF
C5           =  1uF
C6,7        =  33pF
R1,2,3     =  2,2K
R4,5,6     =  1K
R7            =  0.022K
Q1           = 32.768KHz
Diódák     = BAT 46</text>
</plain>
<libraries>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
</elements>
<signals>
<signal name="S$1">
<via x="6.35" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="6.35" y1="40.64" x2="6.35" y2="49.53" width="1.27" layer="16"/>
<via x="29.21" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="6.35" y1="49.53" x2="6.35" y2="50.8" width="1.27" layer="16"/>
<wire x1="6.35" y1="50.8" x2="7.62" y2="50.8" width="1.27" layer="16"/>
<wire x1="7.62" y1="50.8" x2="27.94" y2="50.8" width="1.27" layer="16"/>
<wire x1="27.94" y1="50.8" x2="29.21" y2="50.8" width="1.27" layer="16"/>
<wire x1="29.21" y1="50.8" x2="29.21" y2="49.53" width="1.27" layer="16"/>
<wire x1="29.21" y1="49.53" x2="29.21" y2="48.26" width="1.27" layer="16"/>
<wire x1="29.21" y1="49.53" x2="27.94" y2="50.8" width="1.27" layer="16"/>
<wire x1="6.35" y1="49.53" x2="7.62" y2="50.8" width="1.27" layer="16"/>
<wire x1="29.21" y1="50.8" x2="30.48" y2="50.8" width="1.27" layer="16"/>
<wire x1="30.48" y1="50.8" x2="31.75" y2="50.8" width="1.27" layer="16"/>
<wire x1="29.21" y1="49.53" x2="30.48" y2="50.8" width="1.27" layer="16"/>
</signal>
<signal name="S$3">
<via x="11.43" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="11.43" y1="40.64" x2="11.43" y2="44.45" width="1.27" layer="16"/>
<wire x1="11.43" y1="44.45" x2="11.43" y2="45.72" width="1.27" layer="16"/>
<wire x1="11.43" y1="45.72" x2="12.7" y2="45.72" width="1.27" layer="16"/>
<via x="19.05" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="12.7" y1="45.72" x2="17.78" y2="45.72" width="1.27" layer="16"/>
<wire x1="17.78" y1="45.72" x2="19.05" y2="45.72" width="1.27" layer="16"/>
<wire x1="19.05" y1="45.72" x2="19.05" y2="46.99" width="1.27" layer="16"/>
<wire x1="19.05" y1="46.99" x2="19.05" y2="48.26" width="1.27" layer="16"/>
<wire x1="11.43" y1="44.45" x2="12.7" y2="45.72" width="1.27" layer="16"/>
<wire x1="17.78" y1="45.72" x2="19.05" y2="46.99" width="1.27" layer="16"/>
</signal>
<signal name="S$4">
<via x="13.97" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="13.97" y1="40.64" x2="13.97" y2="41.91" width="1.27" layer="16"/>
<wire x1="13.97" y1="41.91" x2="13.97" y2="43.18" width="1.27" layer="16"/>
<wire x1="13.97" y1="43.18" x2="15.24" y2="43.18" width="1.27" layer="16"/>
<via x="21.59" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="15.24" y1="43.18" x2="20.32" y2="43.18" width="1.27" layer="16"/>
<wire x1="20.32" y1="43.18" x2="21.59" y2="43.18" width="1.27" layer="16"/>
<wire x1="21.59" y1="43.18" x2="21.59" y2="44.1325" width="1.27" layer="16"/>
<wire x1="21.59" y1="44.1325" x2="21.59" y2="48.26" width="1.27" layer="16"/>
<wire x1="13.97" y1="41.91" x2="15.24" y2="43.18" width="1.27" layer="16"/>
<wire x1="20.32" y1="43.18" x2="21.59" y2="44.1325" width="1.27" layer="16"/>
</signal>
<signal name="S$6">
<via x="19.05" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$7">
<via x="21.59" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$12">
<via x="34.29" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="34.29" y="43.18" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="34.29" y1="40.64" x2="34.29" y2="43.18" width="1.27" layer="16"/>
</signal>
<signal name="S$15">
<via x="41.91" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="41.91" y1="40.64" x2="41.91" y2="45.72" width="1.27" layer="16"/>
<via x="41.91" y="45.72" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$83">
<via x="39.37" y="70.485" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="39.37" y1="66.04" x2="39.37" y2="65.7225" width="1.27" layer="16"/>
<wire x1="39.37" y1="65.7225" x2="39.37" y2="64.77" width="1.27" layer="16"/>
<wire x1="39.37" y1="64.77" x2="40.64" y2="64.77" width="1.27" layer="16"/>
<wire x1="39.37" y1="66.04" x2="40.64" y2="64.77" width="1.27" layer="16"/>
<wire x1="40.64" y1="64.77" x2="41.91" y2="64.77" width="1.27" layer="16"/>
<wire x1="39.37" y1="63.5" x2="39.37" y2="64.77" width="1.27" layer="16"/>
<wire x1="40.64" y1="63.5" x2="39.37" y2="63.5" width="1.27" layer="16"/>
<wire x1="41.91" y1="64.77" x2="41.91" y2="63.5" width="1.27" layer="16"/>
<wire x1="41.91" y1="63.5" x2="40.64" y2="63.5" width="1.27" layer="16"/>
<wire x1="41.91" y1="63.5" x2="41.91" y2="62.23" width="1.27" layer="16"/>
<wire x1="41.91" y1="62.23" x2="40.64" y2="63.5" width="1.27" layer="16"/>
<wire x1="41.91" y1="62.23" x2="41.91" y2="59.3725" width="1.27" layer="16"/>
<wire x1="39.37" y1="70.485" x2="39.37" y2="66.04" width="1.27" layer="16"/>
</signal>
<signal name="S$39">
<via x="44.45" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="44.45" y1="40.64" x2="44.45" y2="44.45" width="1.27" layer="16"/>
<wire x1="44.45" y1="44.45" x2="44.45" y2="45.72" width="1.27" layer="16"/>
<wire x1="44.45" y1="45.72" x2="45.72" y2="45.72" width="1.27" layer="16"/>
<wire x1="45.72" y1="45.72" x2="48.895" y2="45.72" width="1.27" layer="16"/>
<via x="39.37" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="43.18" y="54.61" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="48.895" y1="45.72" x2="50.4825" y2="45.72" width="1.27" layer="16"/>
<wire x1="50.4825" y1="45.72" x2="51.7525" y2="45.72" width="1.27" layer="16"/>
<wire x1="51.7525" y1="45.72" x2="51.7525" y2="54.61" width="1.27" layer="16"/>
<wire x1="39.37" y1="55.88" x2="40.64" y2="55.88" width="1.27" layer="16"/>
<wire x1="40.64" y1="55.88" x2="41.91" y2="55.88" width="1.27" layer="16"/>
<wire x1="41.91" y1="55.88" x2="43.18" y2="55.88" width="1.27" layer="16"/>
<wire x1="43.18" y1="55.88" x2="43.18" y2="54.61" width="1.27" layer="16"/>
<wire x1="43.18" y1="54.61" x2="39.37" y2="54.61" width="1.27" layer="16"/>
<wire x1="39.37" y1="54.61" x2="39.37" y2="55.5625" width="1.27" layer="16"/>
<wire x1="51.7525" y1="54.61" x2="50.4825" y2="54.61" width="1.27" layer="16"/>
<wire x1="50.4825" y1="54.61" x2="48.895" y2="54.61" width="1.27" layer="16"/>
<wire x1="48.895" y1="54.61" x2="43.18" y2="54.61" width="1.27" layer="16"/>
<wire x1="44.45" y1="44.45" x2="45.72" y2="45.72" width="1.27" layer="16"/>
<wire x1="43.18" y1="55.88" x2="51.7525" y2="55.88" width="1.27" layer="16"/>
<wire x1="51.7525" y1="55.88" x2="51.7525" y2="54.61" width="1.27" layer="16"/>
<wire x1="41.91" y1="55.88" x2="41.91" y2="57.15" width="1.27" layer="16"/>
<wire x1="41.91" y1="57.15" x2="41.91" y2="59.3725" width="1.27" layer="16"/>
<wire x1="40.64" y1="55.88" x2="41.91" y2="57.15" width="1.27" layer="16"/>
<wire x1="41.91" y1="57.15" x2="43.18" y2="55.88" width="1.27" layer="16"/>
<wire x1="50.4825" y1="45.72" x2="50.4825" y2="54.61" width="1.27" layer="16"/>
<wire x1="50.165" y1="53.975" x2="50.165" y2="53.34" width="1.27" layer="16"/>
<wire x1="50.165" y1="53.34" x2="50.165" y2="46.99" width="1.27" layer="16"/>
<wire x1="50.165" y1="46.99" x2="50.165" y2="46.355" width="1.27" layer="16"/>
<wire x1="48.895" y1="45.72" x2="50.165" y2="46.99" width="1.27" layer="16"/>
<wire x1="50.165" y1="53.34" x2="48.895" y2="54.61" width="1.27" layer="16"/>
</signal>
<signal name="S$10">
<via x="46.99" y="43.18" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="46.99" y1="43.18" x2="67.6275" y2="43.18" width="1.27" layer="16"/>
<wire x1="67.6275" y1="43.18" x2="68.8975" y2="43.18" width="1.27" layer="16"/>
<wire x1="68.8975" y1="43.18" x2="68.8975" y2="44.45" width="1.27" layer="16"/>
<wire x1="67.6275" y1="43.18" x2="68.8975" y2="44.45" width="1.27" layer="16"/>
<via x="68.8975" y="52.07" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="68.8975" y1="44.45" x2="68.8975" y2="52.07" width="1.27" layer="16"/>
</signal>
<signal name="S$17">
<via x="36.83" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="36.83" y1="48.26" x2="36.83" y2="49.53" width="1.27" layer="16"/>
</signal>
<signal name="S$5">
<via x="34.29" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="34.29" y1="48.26" x2="34.29" y2="50.8" width="1.27" layer="16"/>
<wire x1="34.29" y1="50.8" x2="34.29" y2="52.07" width="1.27" layer="16"/>
<wire x1="34.29" y1="52.07" x2="35.56" y2="52.07" width="1.27" layer="16"/>
<via x="47.625" y="52.07" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="35.56" y1="52.07" x2="47.625" y2="52.07" width="1.27" layer="16"/>
<wire x1="34.29" y1="50.8" x2="35.56" y2="52.07" width="1.27" layer="16"/>
</signal>
<signal name="S$18">
<wire x1="31.75" y1="45.72" x2="33.02" y2="45.72" width="1.27" layer="16"/>
<via x="36.83" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="33.02" y1="45.72" x2="35.56" y2="45.72" width="1.27" layer="16"/>
<wire x1="35.56" y1="45.72" x2="36.83" y2="45.72" width="1.27" layer="16"/>
<wire x1="36.83" y1="45.72" x2="36.83" y2="44.45" width="1.27" layer="16"/>
<via x="31.75" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="36.83" y1="44.45" x2="36.83" y2="40.64" width="1.27" layer="16"/>
<wire x1="31.75" y1="45.72" x2="31.75" y2="46.99" width="1.27" layer="16"/>
<wire x1="31.75" y1="46.99" x2="31.75" y2="48.26" width="1.27" layer="16"/>
<wire x1="35.56" y1="45.72" x2="36.83" y2="44.45" width="1.27" layer="16"/>
<wire x1="31.75" y1="46.99" x2="33.02" y2="45.72" width="1.27" layer="16"/>
</signal>
<signal name="S$21">
<via x="26.67" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="26.67" y1="48.26" x2="26.67" y2="47.3075" width="1.27" layer="16"/>
<wire x1="26.67" y1="47.3075" x2="26.67" y2="45.72" width="1.27" layer="16"/>
<wire x1="26.67" y1="45.72" x2="28.2575" y2="45.72" width="1.27" layer="16"/>
<wire x1="28.2575" y1="45.72" x2="29.21" y2="45.72" width="1.27" layer="16"/>
<wire x1="29.21" y1="45.72" x2="29.21" y2="44.45" width="1.27" layer="16"/>
<wire x1="29.21" y1="44.45" x2="29.21" y2="43.18" width="1.27" layer="16"/>
<wire x1="29.21" y1="43.18" x2="30.48" y2="43.18" width="1.27" layer="16"/>
<via x="31.75" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="30.48" y1="43.18" x2="31.75" y2="43.18" width="1.27" layer="16"/>
<wire x1="31.75" y1="43.18" x2="31.75" y2="41.91" width="1.27" layer="16"/>
<wire x1="31.75" y1="41.91" x2="31.75" y2="40.64" width="1.27" layer="16"/>
<wire x1="29.21" y1="44.45" x2="28.2575" y2="45.72" width="1.27" layer="16"/>
<wire x1="29.21" y1="44.45" x2="30.48" y2="43.18" width="1.27" layer="16"/>
<wire x1="30.48" y1="43.18" x2="31.75" y2="41.91" width="1.27" layer="16"/>
<wire x1="28.2575" y1="45.72" x2="26.67" y2="47.3075" width="1.27" layer="16"/>
</signal>
<signal name="S$22">
<via x="24.13" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="24.13" y1="48.26" x2="24.13" y2="44.45" width="1.27" layer="16"/>
<wire x1="24.13" y1="44.45" x2="24.13" y2="43.18" width="1.27" layer="16"/>
<wire x1="24.13" y1="43.18" x2="25.4" y2="43.18" width="1.27" layer="16"/>
<via x="26.67" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="25.4" y1="43.18" x2="26.67" y2="43.18" width="1.27" layer="16"/>
<wire x1="26.67" y1="43.18" x2="26.67" y2="41.91" width="1.27" layer="16"/>
<wire x1="26.67" y1="41.91" x2="26.67" y2="40.64" width="1.27" layer="16"/>
<wire x1="26.67" y1="41.91" x2="25.4" y2="43.18" width="1.27" layer="16"/>
<wire x1="25.4" y1="43.18" x2="24.13" y2="44.45" width="1.27" layer="16"/>
</signal>
<signal name="S$25">
<via x="16.51" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="8.89" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="16.51" y1="48.26" x2="10.16" y2="48.26" width="1.27" layer="16"/>
<wire x1="10.16" y1="48.26" x2="8.89" y2="48.26" width="1.27" layer="16"/>
<wire x1="8.89" y1="48.26" x2="8.89" y2="46.99" width="1.27" layer="16"/>
<wire x1="8.89" y1="46.99" x2="8.89" y2="40.64" width="1.27" layer="16"/>
<wire x1="8.89" y1="46.99" x2="10.16" y2="48.26" width="1.27" layer="16"/>
</signal>
<signal name="S$29">
<via x="36.83" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="36.83" y1="55.88" x2="36.83" y2="57.15" width="1.27" layer="16"/>
<wire x1="36.83" y1="57.15" x2="36.83" y2="58.42" width="1.27" layer="16"/>
<wire x1="36.83" y1="58.42" x2="38.1" y2="58.42" width="1.27" layer="16"/>
<wire x1="38.1" y1="58.42" x2="39.37" y2="58.42" width="1.27" layer="16"/>
<wire x1="36.83" y1="57.15" x2="38.1" y2="58.42" width="1.27" layer="16"/>
<wire x1="36.83" y1="55.88" x2="36.83" y2="54.61" width="1.27" layer="16"/>
</signal>
<signal name="S$30">
<via x="34.29" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$31">
<via x="31.75" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="31.75" y1="55.88" x2="31.75" y2="54.61" width="1.27" layer="16"/>
<wire x1="31.75" y1="54.61" x2="31.75" y2="53.34" width="1.27" layer="16"/>
<wire x1="31.75" y1="53.34" x2="30.48" y2="53.34" width="1.27" layer="16"/>
<wire x1="30.48" y1="53.34" x2="24.13" y2="53.34" width="1.27" layer="16"/>
<wire x1="30.48" y1="53.34" x2="31.75" y2="54.61" width="1.27" layer="16"/>
</signal>
<signal name="S$33">
<via x="26.67" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="26.67" y1="55.88" x2="26.67" y2="60.96" width="1.27" layer="16"/>
</signal>
<signal name="S$37">
<via x="16.51" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="1.5875" y="58.42" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="16.51" y1="55.88" x2="2.8575" y2="55.88" width="1.27" layer="16"/>
<wire x1="2.8575" y1="55.88" x2="1.5875" y2="55.88" width="1.27" layer="16"/>
<wire x1="1.5875" y1="55.88" x2="1.5875" y2="57.15" width="1.27" layer="16"/>
<wire x1="1.5875" y1="57.15" x2="1.5875" y2="58.42" width="1.27" layer="16"/>
<wire x1="1.5875" y1="57.15" x2="2.8575" y2="55.88" width="1.27" layer="16"/>
</signal>
<signal name="S$2">
<wire x1="0.3175" y1="45.4025" x2="-2.8575" y2="45.4025" width="1.27" layer="16"/>
</signal>
<signal name="S$9">
<wire x1="2.54" y1="42.8625" x2="2.54" y2="38.4175" width="1.27" layer="16"/>
</signal>
<signal name="S$11">
<wire x1="2.2225" y1="39.0525" x2="-3.175" y2="39.0525" width="1.27" layer="16"/>
<wire x1="-3.175" y1="39.0525" x2="-3.175" y2="44.45" width="1.27" layer="16"/>
<wire x1="-3.175" y1="44.45" x2="-2.2225" y2="44.45" width="1.27" layer="16"/>
<wire x1="-2.2225" y1="44.45" x2="-2.2225" y2="40.005" width="1.27" layer="16"/>
<wire x1="-2.2225" y1="40.005" x2="1.5875" y2="40.005" width="1.27" layer="16"/>
<wire x1="1.5875" y1="40.005" x2="1.5875" y2="40.64" width="1.27" layer="16"/>
<wire x1="1.5875" y1="40.64" x2="-1.27" y2="40.64" width="1.27" layer="16"/>
</signal>
<signal name="S$14">
<wire x1="74.295" y1="40.3225" x2="78.74" y2="40.3225" width="1.27" layer="16"/>
<wire x1="78.74" y1="40.3225" x2="78.74" y2="44.45" width="1.27" layer="16"/>
<wire x1="78.74" y1="44.45" x2="79.375" y2="44.45" width="1.27" layer="16"/>
<wire x1="79.375" y1="44.45" x2="79.375" y2="39.37" width="1.27" layer="16"/>
<wire x1="79.375" y1="39.37" x2="74.6125" y2="39.37" width="1.27" layer="16"/>
</signal>
<signal name="S$19">
<wire x1="78.105" y1="40.64" x2="78.105" y2="41.275" width="1.27" layer="16"/>
</signal>
<signal name="S$24">
<wire x1="-3.175" y1="83.5025" x2="3.4925" y2="83.5025" width="1.27" layer="16"/>
<wire x1="3.4925" y1="83.5025" x2="34.29" y2="83.5025" width="1.27" layer="16"/>
<wire x1="34.29" y1="83.5025" x2="36.83" y2="83.5025" width="1.27" layer="16"/>
<wire x1="34.29" y1="80.01" x2="34.29" y2="83.5025" width="1.27" layer="16"/>
<wire x1="36.83" y1="63.5" x2="36.83" y2="81.28" width="1.27" layer="16"/>
<wire x1="36.83" y1="81.28" x2="36.83" y2="83.5025" width="1.27" layer="16"/>
<wire x1="3.4925" y1="81.28" x2="3.4925" y2="83.5025" width="1.27" layer="16"/>
<wire x1="34.29" y1="64.77" x2="34.29" y2="80.01" width="1.27" layer="16"/>
<wire x1="36.83" y1="63.5" x2="34.29" y2="63.5" width="1.27" layer="16"/>
<wire x1="34.29" y1="63.5" x2="34.29" y2="64.77" width="1.27" layer="16"/>
<wire x1="33.02" y1="63.5" x2="34.29" y2="63.5" width="1.27" layer="16"/>
<wire x1="33.02" y1="63.5" x2="34.29" y2="64.77" width="1.27" layer="16"/>
<wire x1="26.67" y1="72.39" x2="23.495" y2="72.39" width="1.27" layer="16"/>
<wire x1="3.4925" y1="71.12" x2="3.4925" y2="81.28" width="1.27" layer="16"/>
<wire x1="4.445" y1="81.28" x2="3.4925" y2="81.28" width="1.27" layer="16"/>
<wire x1="4.445" y1="81.28" x2="3.81" y2="73.9775" width="1.27" layer="16"/>
<wire x1="36.83" y1="81.28" x2="33.02" y2="81.28" width="1.27" layer="16"/>
<wire x1="34.29" y1="80.01" x2="33.02" y2="81.28" width="1.27" layer="16"/>
<wire x1="33.02" y1="81.28" x2="6.35" y2="81.28" width="1.27" layer="16"/>
<wire x1="6.35" y1="81.28" x2="5.08" y2="81.28" width="1.27" layer="16"/>
<wire x1="5.08" y1="81.28" x2="4.445" y2="81.28" width="1.27" layer="16"/>
<wire x1="4.1275" y1="71.12" x2="3.4925" y2="71.12" width="1.27" layer="16"/>
<wire x1="26.67" y1="64.77" x2="26.67" y2="67.6275" width="1.27" layer="16"/>
<via x="29.21" y="63.5" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="26.67" y1="67.6275" x2="26.67" y2="72.39" width="1.27" layer="16"/>
<wire x1="29.21" y1="63.5" x2="30.48" y2="63.5" width="1.27" layer="16"/>
<wire x1="30.48" y1="63.5" x2="33.02" y2="63.5" width="1.27" layer="16"/>
<wire x1="4.1275" y1="71.12" x2="5.3975" y2="69.85" width="1.27" layer="16"/>
<wire x1="23.495" y1="72.39" x2="23.495" y2="66.04" width="1.27" layer="16"/>
<wire x1="5.3975" y1="63.5" x2="5.3975" y2="69.85" width="1.27" layer="16"/>
<wire x1="5.3975" y1="69.85" x2="5.3975" y2="71.12" width="1.27" layer="16"/>
<wire x1="5.3975" y1="71.12" x2="4.1275" y2="71.12" width="1.27" layer="16"/>
<wire x1="5.08" y1="80.01" x2="5.08" y2="81.28" width="1.27" layer="16"/>
<wire x1="5.08" y1="80.01" x2="6.35" y2="81.28" width="1.27" layer="16"/>
<wire x1="4.445" y1="73.66" x2="3.81" y2="73.66" width="1.27" layer="16"/>
<wire x1="4.445" y1="73.66" x2="5.08" y2="75.2475" width="1.27" layer="16"/>
<wire x1="5.08" y1="75.2475" x2="5.08" y2="80.01" width="1.27" layer="16"/>
<wire x1="5.3975" y1="71.12" x2="5.3975" y2="73.66" width="1.27" layer="16"/>
<wire x1="5.3975" y1="73.66" x2="4.445" y2="73.66" width="1.27" layer="16"/>
<wire x1="29.21" y1="63.5" x2="12.7" y2="63.5" width="1.27" layer="16"/>
<wire x1="12.7" y1="63.5" x2="5.3975" y2="63.5" width="1.27" layer="16"/>
<wire x1="13.97" y1="64.77" x2="22.5425" y2="64.77" width="1.27" layer="16"/>
<via x="12.7" y="72.39" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="22.5425" y1="64.77" x2="26.67" y2="64.77" width="1.27" layer="16"/>
<wire x1="12.7" y1="66.04" x2="12.7" y2="72.39" width="1.27" layer="16"/>
<wire x1="12.7" y1="66.04" x2="13.97" y2="64.77" width="1.27" layer="16"/>
<wire x1="12.7" y1="63.5" x2="12.7" y2="64.77" width="1.27" layer="16"/>
<wire x1="12.7" y1="64.77" x2="12.7" y2="66.04" width="1.27" layer="16"/>
<wire x1="12.7" y1="64.77" x2="13.97" y2="64.77" width="1.27" layer="16"/>
<wire x1="5.3975" y1="73.66" x2="6.6675" y2="73.66" width="1.27" layer="16"/>
<wire x1="5.08" y1="75.2475" x2="6.6675" y2="73.66" width="1.27" layer="16"/>
<wire x1="12.7" y1="64.77" x2="11.43" y2="64.77" width="1.27" layer="16"/>
<wire x1="11.43" y1="64.77" x2="12.7" y2="66.04" width="1.27" layer="16"/>
<wire x1="11.43" y1="64.77" x2="7.9375" y2="64.77" width="1.27" layer="16"/>
<wire x1="6.6675" y1="73.66" x2="6.6675" y2="66.04" width="1.27" layer="16"/>
<wire x1="6.6675" y1="66.04" x2="7.9375" y2="64.77" width="1.27" layer="16"/>
<wire x1="6.6675" y1="66.04" x2="6.6675" y2="64.77" width="1.27" layer="16"/>
<wire x1="6.6675" y1="64.77" x2="6.6675" y2="63.8175" width="1.27" layer="16"/>
<wire x1="7.9375" y1="64.77" x2="6.6675" y2="64.77" width="1.27" layer="16"/>
<wire x1="-3.175" y1="83.5025" x2="-3.175" y2="81.28" width="1.27" layer="16"/>
<wire x1="5.3975" y1="63.5" x2="4.1275" y2="63.5" width="1.27" layer="16"/>
<wire x1="4.1275" y1="63.5" x2="4.1275" y2="66.04" width="1.27" layer="16"/>
<wire x1="4.1275" y1="66.04" x2="4.1275" y2="67.31" width="1.27" layer="16"/>
<wire x1="4.1275" y1="67.31" x2="4.1275" y2="69.85" width="1.27" layer="16"/>
<wire x1="4.1275" y1="69.85" x2="4.1275" y2="70.485" width="1.27" layer="16"/>
<wire x1="2.8575" y1="71.12" x2="4.1275" y2="69.85" width="1.27" layer="16"/>
<via x="1.5875" y="63.5" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="4.1275" y1="63.5" x2="1.5875" y2="63.5" width="1.27" layer="16"/>
<wire x1="1.5875" y1="63.5" x2="1.5875" y2="66.04" width="1.27" layer="16"/>
<wire x1="1.5875" y1="66.04" x2="2.8575" y2="66.04" width="1.27" layer="16"/>
<wire x1="2.8575" y1="66.04" x2="4.1275" y2="66.04" width="1.27" layer="16"/>
<wire x1="2.8575" y1="66.04" x2="4.1275" y2="67.31" width="1.27" layer="16"/>
<wire x1="29.21" y1="63.5" x2="29.21" y2="64.77" width="1.27" layer="16"/>
<wire x1="29.21" y1="64.77" x2="29.21" y2="66.3575" width="1.27" layer="16"/>
<wire x1="29.21" y1="66.3575" x2="27.94" y2="66.3575" width="1.27" layer="16"/>
<wire x1="27.94" y1="66.3575" x2="26.9875" y2="66.3575" width="1.27" layer="16"/>
<wire x1="27.94" y1="66.3575" x2="26.67" y2="67.6275" width="1.27" layer="16"/>
<wire x1="29.21" y1="64.77" x2="30.48" y2="63.5" width="1.27" layer="16"/>
<wire x1="22.5425" y1="64.77" x2="23.495" y2="66.04" width="1.27" layer="16"/>
<wire x1="23.495" y1="66.04" x2="23.495" y2="65.405" width="1.27" layer="16"/>
</signal>
<signal name="S$26">
<via x="44.45" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="44.45" y1="60.96" x2="44.45" y2="64.77" width="1.27" layer="16"/>
<wire x1="51.7525" y1="64.77" x2="79.6925" y2="64.77" width="1.27" layer="16"/>
<wire x1="44.45" y1="60.96" x2="44.45" y2="58.42" width="1.27" layer="16"/>
<wire x1="44.45" y1="58.42" x2="46.355" y2="58.42" width="1.27" layer="16"/>
<wire x1="46.355" y1="58.42" x2="53.0225" y2="58.42" width="1.27" layer="16"/>
<wire x1="53.0225" y1="58.42" x2="54.2925" y2="58.42" width="1.27" layer="16"/>
<wire x1="54.2925" y1="58.42" x2="54.2925" y2="57.15" width="1.27" layer="16"/>
<via x="59.3725" y="54.61" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="54.2925" y1="57.15" x2="54.2925" y2="54.61" width="1.27" layer="16"/>
<wire x1="59.3725" y1="54.61" x2="59.3725" y2="53.34" width="1.27" layer="16"/>
<wire x1="59.3725" y1="53.34" x2="59.3725" y2="52.07" width="1.27" layer="16"/>
<wire x1="59.3725" y1="52.07" x2="60.6425" y2="52.07" width="1.27" layer="16"/>
<wire x1="60.6425" y1="52.07" x2="61.9125" y2="52.07" width="1.27" layer="16"/>
<wire x1="61.9125" y1="52.07" x2="61.9125" y2="51.1175" width="1.27" layer="16"/>
<wire x1="61.9125" y1="51.1175" x2="61.9125" y2="45.72" width="1.27" layer="16"/>
<wire x1="61.9125" y1="45.72" x2="66.3575" y2="45.72" width="1.27" layer="16"/>
<via x="68.8975" y="54.61" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="68.8975" y="57.15" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="39.37" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="39.37" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="16.51" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="24.13" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="68.8975" y1="54.61" x2="68.8975" y2="57.15" width="1.27" layer="16"/>
<wire x1="16.51" y1="40.64" x2="24.13" y2="40.64" width="1.27" layer="16"/>
<wire x1="24.13" y1="40.64" x2="24.13" y2="39.37" width="1.27" layer="16"/>
<via x="29.21" y="40.64" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="24.13" y1="39.37" x2="24.13" y2="38.1" width="1.27" layer="16"/>
<wire x1="24.13" y1="38.1" x2="25.4" y2="38.1" width="1.27" layer="16"/>
<wire x1="25.4" y1="38.1" x2="27.94" y2="38.1" width="1.27" layer="16"/>
<wire x1="27.94" y1="38.1" x2="29.21" y2="38.1" width="1.27" layer="16"/>
<wire x1="29.21" y1="38.1" x2="29.21" y2="39.37" width="1.27" layer="16"/>
<wire x1="29.21" y1="39.37" x2="29.21" y2="40.64" width="1.27" layer="16"/>
<wire x1="29.21" y1="38.1" x2="30.48" y2="38.1" width="1.27" layer="16"/>
<wire x1="30.48" y1="38.1" x2="38.1" y2="38.1" width="1.27" layer="16"/>
<wire x1="38.1" y1="38.1" x2="39.37" y2="38.1" width="1.27" layer="16"/>
<wire x1="39.37" y1="40.64" x2="39.37" y2="39.37" width="1.27" layer="16"/>
<wire x1="39.37" y1="39.37" x2="39.37" y2="38.1" width="1.27" layer="16"/>
<wire x1="39.37" y1="48.26" x2="39.37" y2="46.99" width="1.27" layer="16"/>
<wire x1="39.37" y1="46.99" x2="39.37" y2="40.64" width="1.27" layer="16"/>
<wire x1="39.37" y1="48.26" x2="40.64" y2="48.26" width="1.27" layer="16"/>
<via x="43.18" y="49.53" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="40.64" y1="48.26" x2="43.18" y2="48.26" width="1.27" layer="16"/>
<wire x1="43.18" y1="48.26" x2="43.18" y2="49.53" width="1.27" layer="16"/>
<wire x1="43.18" y1="49.53" x2="39.37" y2="49.53" width="1.27" layer="16"/>
<wire x1="39.37" y1="49.53" x2="39.37" y2="48.26" width="1.27" layer="16"/>
<wire x1="24.13" y1="38.1" x2="15.24" y2="38.1" width="1.27" layer="16"/>
<wire x1="15.24" y1="38.1" x2="4.7625" y2="38.1" width="1.27" layer="16"/>
<wire x1="4.7625" y1="38.1" x2="3.81" y2="38.1" width="1.27" layer="16"/>
<wire x1="3.81" y1="38.1" x2="-3.175" y2="38.1" width="1.27" layer="16"/>
<wire x1="-3.175" y1="38.1" x2="-3.175" y2="50.8" width="1.27" layer="16"/>
<wire x1="-3.175" y1="50.8" x2="-3.175" y2="58.42" width="1.27" layer="16"/>
<wire x1="-3.175" y1="58.42" x2="-3.175" y2="59.69" width="1.27" layer="16"/>
<wire x1="-3.175" y1="59.69" x2="-3.175" y2="69.85" width="1.27" layer="16"/>
<wire x1="-3.175" y1="69.85" x2="-3.175" y2="76.835" width="1.27" layer="16"/>
<wire x1="79.6925" y1="60.96" x2="79.6925" y2="57.15" width="1.27" layer="16"/>
<wire x1="79.6925" y1="57.15" x2="79.6925" y2="54.61" width="1.27" layer="16"/>
<wire x1="79.6925" y1="54.61" x2="79.6925" y2="45.4025" width="1.27" layer="16"/>
<wire x1="79.6925" y1="45.4025" x2="79.6925" y2="38.1" width="1.27" layer="16"/>
<wire x1="79.6925" y1="38.1" x2="73.9775" y2="38.1" width="1.27" layer="16"/>
<wire x1="73.9775" y1="38.1" x2="46.99" y2="38.1" width="1.27" layer="16"/>
<wire x1="46.99" y1="38.1" x2="45.72" y2="38.1" width="1.27" layer="16"/>
<wire x1="45.72" y1="38.1" x2="40.3225" y2="38.1" width="1.27" layer="16"/>
<wire x1="40.3225" y1="38.1" x2="39.37" y2="38.1" width="1.27" layer="16"/>
<wire x1="76.2" y1="45.4025" x2="79.6925" y2="45.4025" width="1.27" layer="16"/>
<wire x1="73.9775" y1="43.18" x2="73.9775" y2="38.1" width="1.27" layer="16"/>
<wire x1="39.37" y1="39.37" x2="40.3225" y2="38.1" width="1.27" layer="16"/>
<wire x1="39.37" y1="39.37" x2="38.1" y2="38.1" width="1.27" layer="16"/>
<wire x1="29.21" y1="39.37" x2="27.94" y2="38.1" width="1.27" layer="16"/>
<wire x1="29.21" y1="39.37" x2="30.48" y2="38.1" width="1.27" layer="16"/>
<wire x1="25.4" y1="38.1" x2="24.13" y2="39.37" width="1.27" layer="16"/>
<wire x1="15.24" y1="38.1" x2="16.51" y2="39.37" width="1.27" layer="16"/>
<wire x1="16.51" y1="39.37" x2="16.51" y2="40.64" width="1.27" layer="16"/>
<wire x1="16.51" y1="39.37" x2="23.8125" y2="39.37" width="1.27" layer="16"/>
<wire x1="39.37" y1="46.99" x2="40.64" y2="48.26" width="1.27" layer="16"/>
<wire x1="3.81" y1="50.8" x2="3.81" y2="39.37" width="1.27" layer="16"/>
<wire x1="3.81" y1="39.37" x2="3.81" y2="38.1" width="1.27" layer="16"/>
<wire x1="3.81" y1="39.37" x2="4.7625" y2="38.1" width="1.27" layer="16"/>
<wire x1="3.81" y1="50.8" x2="0.3175" y2="50.8" width="1.27" layer="16"/>
<wire x1="0.3175" y1="50.8" x2="-3.175" y2="50.8" width="1.27" layer="16"/>
<wire x1="68.8975" y1="57.15" x2="79.6925" y2="57.15" width="1.27" layer="16"/>
<wire x1="68.8975" y1="54.61" x2="70.1675" y2="54.61" width="1.27" layer="16"/>
<wire x1="70.1675" y1="54.61" x2="79.6925" y2="54.61" width="1.27" layer="16"/>
<wire x1="46.99" y1="40.64" x2="46.99" y2="39.37" width="1.27" layer="16"/>
<wire x1="46.99" y1="39.37" x2="46.99" y2="38.1" width="1.27" layer="16"/>
<wire x1="46.99" y1="40.64" x2="70.1675" y2="40.64" width="1.27" layer="16"/>
<wire x1="70.1675" y1="40.64" x2="71.4375" y2="40.64" width="1.27" layer="16"/>
<wire x1="71.4375" y1="40.64" x2="71.4375" y2="41.91" width="1.27" layer="16"/>
<wire x1="71.4375" y1="41.91" x2="71.4375" y2="53.34" width="1.27" layer="16"/>
<wire x1="71.4375" y1="53.34" x2="71.4375" y2="54.2925" width="1.27" layer="16"/>
<wire x1="43.18" y1="49.53" x2="46.355" y2="49.53" width="1.27" layer="16"/>
<wire x1="46.355" y1="49.53" x2="46.355" y2="48.26" width="1.27" layer="16"/>
<wire x1="46.355" y1="48.26" x2="43.18" y2="48.26" width="1.27" layer="16"/>
<wire x1="59.3725" y1="54.61" x2="67.6275" y2="54.61" width="1.27" layer="16"/>
<wire x1="67.6275" y1="54.61" x2="68.8975" y2="54.61" width="1.27" layer="16"/>
<wire x1="71.4375" y1="53.34" x2="70.1675" y2="54.61" width="1.27" layer="16"/>
<wire x1="66.3575" y1="53.34" x2="67.6275" y2="54.61" width="1.27" layer="16"/>
<wire x1="59.3725" y1="54.61" x2="59.3725" y2="57.15" width="1.27" layer="16"/>
<wire x1="59.3725" y1="57.15" x2="68.8975" y2="57.15" width="1.27" layer="16"/>
<wire x1="60.6425" y1="52.07" x2="61.9125" y2="51.1175" width="1.27" layer="16"/>
<wire x1="45.72" y1="38.1" x2="46.99" y2="39.37" width="1.27" layer="16"/>
<wire x1="70.1675" y1="40.64" x2="71.4375" y2="41.91" width="1.27" layer="16"/>
<wire x1="54.2925" y1="54.61" x2="58.1025" y2="54.61" width="1.27" layer="16"/>
<wire x1="58.1025" y1="54.61" x2="59.3725" y2="54.61" width="1.27" layer="16"/>
<wire x1="58.1025" y1="54.61" x2="59.3725" y2="53.34" width="1.27" layer="16"/>
<wire x1="54.2925" y1="57.15" x2="53.0225" y2="58.42" width="1.27" layer="16"/>
<wire x1="44.45" y1="60.96" x2="51.7525" y2="60.96" width="1.27" layer="16"/>
<via x="46.355" y="58.42" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="51.7525" y1="60.96" x2="79.6925" y2="60.96" width="1.27" layer="16"/>
<wire x1="46.355" y1="49.53" x2="47.625" y2="49.53" width="1.27" layer="16"/>
<wire x1="47.625" y1="49.53" x2="47.625" y2="48.26" width="1.27" layer="16"/>
<wire x1="47.625" y1="48.26" x2="46.355" y2="48.26" width="1.27" layer="16"/>
<wire x1="66.3575" y1="45.72" x2="66.3575" y2="53.34" width="1.27" layer="16"/>
<wire x1="79.6925" y1="64.77" x2="79.6925" y2="60.96" width="1.27" layer="16"/>
<via x="51.7525" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="51.7525" y1="64.77" x2="51.7525" y2="60.96" width="1.27" layer="16"/>
<wire x1="44.45" y1="64.77" x2="51.7525" y2="64.77" width="1.27" layer="16"/>
<wire x1="-0.9525" y1="52.07" x2="0.3175" y2="50.8" width="1.27" layer="16"/>
<wire x1="-0.9525" y1="52.07" x2="-0.9525" y2="58.42" width="1.27" layer="16"/>
<wire x1="-0.9525" y1="58.42" x2="-1.905" y2="58.42" width="1.27" layer="16"/>
<wire x1="-1.905" y1="58.42" x2="-3.175" y2="58.42" width="1.27" layer="16"/>
<wire x1="-1.905" y1="58.42" x2="-3.175" y2="59.69" width="1.27" layer="16"/>
<wire x1="-3.175" y1="69.85" x2="-1.905" y2="71.12" width="1.27" layer="16"/>
<wire x1="-3.175" y1="81.28" x2="-1.27" y2="81.28" width="1.27" layer="16"/>
<wire x1="-1.27" y1="81.28" x2="0.3175" y2="81.28" width="1.27" layer="16"/>
<wire x1="-1.27" y1="81.28" x2="-1.27" y2="76.835" width="1.27" layer="16" curve="-180"/>
<wire x1="-1.27" y1="76.835" x2="-3.175" y2="76.835" width="1.27" layer="16"/>
</signal>
<signal name="S$38">
<wire x1="0.635" y1="82.2325" x2="-3.175" y2="82.2325" width="1.27" layer="16"/>
</signal>
<signal name="S$41">
<via x="54.2925" y="52.07" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="56.8325" y="52.07" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="54.2925" y1="52.07" x2="56.8325" y2="52.07" width="1.27" layer="16"/>
</signal>
<signal name="S$42">
<via x="54.2925" y="45.72" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="54.2925" y1="45.72" x2="54.2925" y2="49.53" width="1.27" layer="16"/>
<wire x1="54.2925" y1="49.53" x2="59.3725" y2="49.53" width="1.27" layer="16"/>
<via x="59.3725" y="49.53" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="59.3725" y1="49.53" x2="59.3725" y2="45.72" width="1.27" layer="16"/>
<wire x1="59.3725" y1="45.72" x2="54.2925" y2="45.72" width="1.27" layer="16"/>
</signal>
<signal name="S$8">
<via x="36.83" y="57.785" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$13">
<via x="34.29" y="57.785" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$43">
<wire x1="34.29" y1="54.61" x2="34.29" y2="59.69" width="1.27" layer="16"/>
<wire x1="34.29" y1="59.69" x2="34.29" y2="60.96" width="1.27" layer="16"/>
<wire x1="34.29" y1="60.96" x2="35.56" y2="60.96" width="1.27" layer="16"/>
<wire x1="35.56" y1="60.96" x2="39.37" y2="60.96" width="1.27" layer="16"/>
<wire x1="34.29" y1="59.69" x2="35.56" y2="60.96" width="1.27" layer="16"/>
</signal>
<signal name="S$46">
<via x="51.7525" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$28">
<via x="46.355" y="49.53" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$45">
<via x="48.5775" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$47">
<via x="48.5775" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$27">
<via x="39.37" y="58.42" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$40">
<via x="44.45" y="58.42" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$48">
<via x="39.37" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$50">
<wire x1="46.99" y1="75.565" x2="44.45" y2="75.565" width="1.27" layer="16"/>
<wire x1="44.45" y1="75.565" x2="44.45" y2="68.58" width="1.27" layer="16"/>
<wire x1="44.45" y1="68.58" x2="46.99" y2="68.58" width="1.27" layer="16"/>
<wire x1="46.99" y1="68.58" x2="46.99" y2="75.565" width="1.27" layer="16"/>
</signal>
<signal name="S$51">
<wire x1="79.6925" y1="68.58" x2="69.85" y2="68.58" width="1.27" layer="16"/>
<wire x1="69.85" y1="68.58" x2="69.85" y2="75.565" width="1.27" layer="16"/>
</signal>
<signal name="S$53">
<via x="39.37" y="75.2475" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$54">
<via x="55.5625" y="64.135" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$55">
<via x="61.2775" y="64.135" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$57">
<via x="55.5625" y="83.185" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$58">
<via x="61.2775" y="83.185" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$59">
<wire x1="63.1825" y1="83.5025" x2="53.6575" y2="83.5025" width="1.27" layer="16"/>
<wire x1="53.6575" y1="83.5025" x2="53.6575" y2="82.2325" width="1.27" layer="16"/>
<wire x1="53.6575" y1="82.2325" x2="63.1825" y2="82.2325" width="1.27" layer="16"/>
<wire x1="63.1825" y1="82.2325" x2="63.1825" y2="83.5025" width="1.27" layer="16"/>
</signal>
<signal name="S$16">
<via x="1.5875" y="48.26" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$44">
<via x="1.5875" y="53.34" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="21.59" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="1.5875" y1="53.34" x2="20.32" y2="53.34" width="1.27" layer="16"/>
<wire x1="20.32" y1="53.34" x2="21.59" y2="53.34" width="1.27" layer="16"/>
<wire x1="21.59" y1="53.34" x2="21.59" y2="54.61" width="1.27" layer="16"/>
<wire x1="21.59" y1="54.61" x2="21.59" y2="55.88" width="1.27" layer="16"/>
<wire x1="21.59" y1="54.61" x2="20.32" y2="53.34" width="1.27" layer="16"/>
</signal>
<signal name="S$61">
<via x="19.05" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="4.1275" y1="60.96" x2="4.1275" y2="59.69" width="1.27" layer="16"/>
<wire x1="4.1275" y1="59.69" x2="4.1275" y2="58.42" width="1.27" layer="16"/>
<wire x1="4.1275" y1="58.42" x2="6.6675" y2="58.42" width="1.27" layer="16"/>
<wire x1="6.6675" y1="58.42" x2="7.9375" y2="58.42" width="1.27" layer="16"/>
<wire x1="7.9375" y1="58.42" x2="17.78" y2="58.42" width="1.27" layer="16"/>
<wire x1="17.78" y1="58.42" x2="19.05" y2="58.42" width="1.27" layer="16"/>
<wire x1="19.05" y1="58.42" x2="19.05" y2="57.15" width="1.27" layer="16"/>
<wire x1="19.05" y1="57.15" x2="19.05" y2="55.88" width="1.27" layer="16"/>
<wire x1="19.05" y1="57.15" x2="17.78" y2="58.42" width="1.27" layer="16"/>
<wire x1="6.6675" y1="60.96" x2="6.6675" y2="59.69" width="1.27" layer="16"/>
<wire x1="6.6675" y1="59.69" x2="6.6675" y2="58.42" width="1.27" layer="16"/>
<wire x1="6.6675" y1="59.69" x2="7.9375" y2="58.42" width="1.27" layer="16"/>
<wire x1="6.6675" y1="60.96" x2="4.1275" y2="60.96" width="1.27" layer="16"/>
<via x="1.5875" y="68.58" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="-0.635" y1="60.96" x2="-0.635" y2="62.23" width="1.27" layer="16"/>
<wire x1="-0.635" y1="62.23" x2="-0.635" y2="67.31" width="1.27" layer="16"/>
<wire x1="-0.635" y1="67.31" x2="-0.635" y2="68.58" width="1.27" layer="16"/>
<wire x1="-0.635" y1="68.58" x2="0.635" y2="68.58" width="1.27" layer="16"/>
<wire x1="0.635" y1="68.58" x2="1.5875" y2="68.58" width="1.27" layer="16"/>
<wire x1="4.1275" y1="60.96" x2="2.8575" y2="60.96" width="1.27" layer="16"/>
<wire x1="2.8575" y1="60.96" x2="0.635" y2="60.96" width="1.27" layer="16"/>
<wire x1="0.635" y1="60.96" x2="-0.635" y2="60.96" width="1.27" layer="16"/>
<wire x1="0.635" y1="68.58" x2="-0.635" y2="67.31" width="1.27" layer="16"/>
<wire x1="-0.635" y1="62.23" x2="0.635" y2="60.96" width="1.27" layer="16"/>
<wire x1="4.1275" y1="59.69" x2="2.8575" y2="60.96" width="1.27" layer="16"/>
</signal>
<signal name="S$62">
<via x="1.5875" y="73.66" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$49">
<via x="13.0175" y="53.34" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$65">
<via x="13.0175" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$66">
<via x="10.795" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$67">
<via x="10.795" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$68">
<via x="4.1275" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$69">
<via x="9.2075" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="9.2075" y1="60.96" x2="20.32" y2="60.96" width="1.27" layer="16"/>
<via x="24.13" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="20.32" y1="60.96" x2="24.13" y2="60.96" width="1.27" layer="16"/>
<wire x1="24.13" y1="60.96" x2="24.13" y2="57.15" width="1.27" layer="16"/>
<wire x1="24.13" y1="57.15" x2="24.13" y2="55.88" width="1.27" layer="16"/>
<wire x1="20.32" y1="60.96" x2="24.13" y2="57.15" width="1.27" layer="16"/>
</signal>
<signal name="S$70">
<wire x1="23.8125" y1="58.7375" x2="22.225" y2="60.325" width="1.27" layer="16"/>
<wire x1="22.225" y1="60.325" x2="23.1775" y2="60.0075" width="1.27" layer="16"/>
</signal>
<signal name="S$56">
<via x="44.7675" y="64.4525" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$71">
<via x="36.5125" y="64.4525" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$72">
<via x="39.37" y="68.8975" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$74">
<via x="29.21" y="55.88" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="29.21" y1="58.42" x2="29.21" y2="57.15" width="1.27" layer="16"/>
<via x="29.21" y="58.42" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="29.21" y1="57.15" x2="29.21" y2="55.88" width="1.27" layer="16"/>
<wire x1="29.21" y1="58.42" x2="29.21" y2="60.96" width="1.27" layer="16"/>
<via x="31.75" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="29.21" y1="60.96" x2="31.75" y2="60.96" width="1.27" layer="16"/>
<wire x1="31.75" y1="60.96" x2="31.75" y2="58.42" width="1.27" layer="16"/>
<wire x1="31.75" y1="58.42" x2="30.48" y2="58.42" width="1.27" layer="16"/>
<wire x1="30.48" y1="58.42" x2="29.21" y2="58.42" width="1.27" layer="16"/>
<wire x1="29.21" y1="57.15" x2="30.48" y2="58.42" width="1.27" layer="16"/>
</signal>
<signal name="S$84">
<via x="29.21" y="68.8975" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="29.21" y1="68.8975" x2="29.21" y2="74.93" width="1.27" layer="16"/>
<via x="10.16" y="67.31" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="7.62" y="76.2" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="29.21" y1="74.93" x2="29.21" y2="78.74" width="1.27" layer="16"/>
<wire x1="7.62" y1="76.2" x2="7.62" y2="78.74" width="1.27" layer="16"/>
<via x="26.67" y="78.74" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="7.62" y1="78.74" x2="10.16" y2="78.74" width="1.27" layer="16"/>
<wire x1="10.16" y1="78.74" x2="26.67" y2="78.74" width="1.27" layer="16"/>
<wire x1="7.62" y1="76.2" x2="7.9375" y2="76.2" width="1.27" layer="16"/>
<wire x1="7.9375" y1="76.2" x2="9.2075" y2="76.2" width="1.27" layer="16"/>
<wire x1="9.2075" y1="76.2" x2="10.16" y2="76.2" width="1.27" layer="16"/>
<wire x1="10.16" y1="76.2" x2="10.16" y2="78.74" width="1.27" layer="16"/>
<wire x1="10.16" y1="67.31" x2="10.16" y2="72.39" width="1.27" layer="16"/>
<wire x1="10.16" y1="72.39" x2="10.16" y2="76.2" width="1.27" layer="16"/>
<wire x1="9.2075" y1="76.2" x2="9.2075" y2="74.93" width="1.27" layer="16"/>
<via x="10.16" y="72.39" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="9.2075" y1="74.93" x2="9.2075" y2="67.31" width="1.27" layer="16"/>
<wire x1="9.2075" y1="67.31" x2="10.16" y2="67.31" width="1.27" layer="16"/>
<wire x1="9.2075" y1="74.93" x2="7.9375" y2="76.2" width="1.27" layer="16"/>
<wire x1="29.21" y1="78.74" x2="26.67" y2="78.74" width="1.27" layer="16"/>
<wire x1="29.21" y1="74.93" x2="22.225" y2="74.93" width="1.27" layer="16"/>
<wire x1="22.225" y1="74.93" x2="20.955" y2="74.93" width="1.27" layer="16"/>
<wire x1="20.955" y1="74.93" x2="19.685" y2="74.93" width="1.27" layer="16"/>
<wire x1="19.685" y1="74.93" x2="9.525" y2="74.93" width="1.27" layer="16"/>
<wire x1="20.955" y1="74.93" x2="20.955" y2="73.66" width="1.27" layer="16"/>
<wire x1="20.955" y1="73.66" x2="20.955" y2="67.31" width="1.27" layer="16"/>
<wire x1="20.955" y1="73.66" x2="19.685" y2="74.93" width="1.27" layer="16"/>
<wire x1="20.955" y1="73.66" x2="22.225" y2="74.93" width="1.27" layer="16"/>
</signal>
<signal name="S$85">
<via x="31.75" y="66.04" extent="1-16" drill="0.6" diameter="1.27"/>
<via x="31.75" y="78.74" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="31.75" y1="66.04" x2="31.75" y2="78.74" width="1.27" layer="16"/>
</signal>
<signal name="S$32">
<via x="12.7" y="64.77" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$34">
<via x="15.24" y="67.31" extent="1-16" drill="0.6" diameter="1.27"/>
<wire x1="15.24" y1="67.31" x2="18.415" y2="67.31" width="1.27" layer="16"/>
<wire x1="18.415" y1="67.31" x2="18.415" y2="72.39" width="1.27" layer="16"/>
<wire x1="18.415" y1="72.39" x2="15.24" y2="72.39" width="1.27" layer="16"/>
<wire x1="15.24" y1="72.39" x2="15.24" y2="67.31" width="1.27" layer="16"/>
</signal>
<signal name="S$64">
<via x="16.8275" y="71.12" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$73">
<via x="25.0825" y="71.12" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$75">
<via x="18.415" y="70.1675" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$76">
<via x="23.495" y="70.1675" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$23">
<wire x1="77.7875" y1="81.28" x2="77.7875" y2="76.835" width="1.27" layer="16" curve="180"/>
<wire x1="73.66" y1="83.5025" x2="79.6925" y2="83.5025" width="1.27" layer="16"/>
<wire x1="77.7875" y1="76.835" x2="79.6925" y2="76.835" width="1.27" layer="16"/>
<wire x1="79.6925" y1="74.93" x2="79.6925" y2="76.835" width="1.27" layer="16"/>
<wire x1="73.66" y1="79.0575" x2="73.66" y2="83.5025" width="1.27" layer="16"/>
<wire x1="73.66" y1="79.0575" x2="77.7875" y2="74.93" width="1.27" layer="16" curve="90"/>
<wire x1="77.7875" y1="74.93" x2="79.6925" y2="74.93" width="1.27" layer="16"/>
<wire x1="79.6925" y1="83.5025" x2="79.6925" y2="82.55" width="1.27" layer="16"/>
<wire x1="79.6925" y1="82.55" x2="79.6925" y2="81.28" width="1.27" layer="16"/>
<wire x1="79.6925" y1="81.28" x2="77.7875" y2="81.28" width="1.27" layer="16"/>
<wire x1="79.6925" y1="82.55" x2="74.295" y2="82.55" width="1.27" layer="16"/>
</signal>
<signal name="S$20">
<wire x1="71.12" y1="79.0575" x2="78.105" y2="72.39" width="1.27" layer="16" curve="95.582097"/>
<wire x1="69.85" y1="79.0575" x2="69.85" y2="83.5025" width="1.27" layer="16"/>
<wire x1="69.85" y1="83.5025" x2="65.7225" y2="83.5025" width="1.27" layer="16"/>
<wire x1="65.7225" y1="83.5025" x2="65.7225" y2="80.9625" width="1.27" layer="16"/>
<wire x1="65.7225" y1="80.9625" x2="65.7225" y2="79.6925" width="1.27" layer="16"/>
<wire x1="65.7225" y1="79.6925" x2="64.4525" y2="79.6925" width="1.27" layer="16"/>
<wire x1="64.4525" y1="79.6925" x2="52.3875" y2="79.6925" width="1.27" layer="16"/>
<wire x1="52.3875" y1="79.6925" x2="51.1175" y2="79.6925" width="1.27" layer="16"/>
<wire x1="51.1175" y1="79.6925" x2="51.1175" y2="80.9625" width="1.27" layer="16"/>
<wire x1="51.1175" y1="80.9625" x2="51.1175" y2="83.5025" width="1.27" layer="16"/>
<wire x1="41.91" y1="83.5025" x2="41.91" y2="73.025" width="1.27" layer="16"/>
<wire x1="41.91" y1="73.025" x2="41.91" y2="71.755" width="1.27" layer="16"/>
<wire x1="41.91" y1="71.755" x2="41.91" y2="67.31" width="1.27" layer="16"/>
<wire x1="51.1175" y1="83.5025" x2="41.91" y2="83.5025" width="1.27" layer="16"/>
<wire x1="41.91" y1="67.31" x2="79.6925" y2="67.31" width="1.27" layer="16"/>
<wire x1="79.6925" y1="67.31" x2="79.6925" y2="72.39" width="1.27" layer="16"/>
<wire x1="51.1175" y1="80.9625" x2="52.3875" y2="79.6925" width="1.27" layer="16"/>
<wire x1="64.4525" y1="79.6925" x2="65.7225" y2="80.9625" width="1.27" layer="16"/>
<wire x1="39.37" y1="83.5025" x2="41.91" y2="83.5025" width="1.27" layer="16"/>
<wire x1="78.105" y1="72.39" x2="79.6925" y2="72.39" width="1.27" layer="16"/>
<wire x1="71.12" y1="79.0575" x2="71.12" y2="83.5025" width="1.27" layer="16"/>
<wire x1="71.12" y1="83.5025" x2="69.85" y2="83.5025" width="1.27" layer="16"/>
<wire x1="41.91" y1="73.025" x2="40.64" y2="73.025" width="1.27" layer="16"/>
<wire x1="40.64" y1="73.025" x2="39.37" y2="73.025" width="1.27" layer="16"/>
<wire x1="39.37" y1="73.025" x2="39.37" y2="83.5025" width="1.27" layer="16"/>
<wire x1="40.64" y1="73.025" x2="41.91" y2="71.755" width="1.27" layer="16"/>
</signal>
<signal name="S$36">
<wire x1="70.485" y1="75.8825" x2="70.485" y2="78.74" width="1.27" layer="16"/>
</signal>
<signal name="S$52">
<wire x1="77.47" y1="81.5975" x2="74.93" y2="81.5975" width="1.27" layer="16"/>
<wire x1="74.93" y1="81.5975" x2="74.6125" y2="81.5975" width="1.27" layer="16"/>
<wire x1="74.93" y1="81.5975" x2="74.93" y2="77.47" width="1.27" layer="16"/>
</signal>
<signal name="S$60">
<wire x1="75.565" y1="80.645" x2="75.565" y2="80.9625" width="1.27" layer="16"/>
</signal>
<signal name="S$77">
<wire x1="79.375" y1="75.8825" x2="76.2" y2="75.8825" width="1.27" layer="16"/>
<wire x1="76.2" y1="75.8825" x2="76.2" y2="76.835" width="1.27" layer="16"/>
<wire x1="76.2" y1="76.835" x2="75.565" y2="76.835" width="1.27" layer="16"/>
</signal>
<signal name="S$78">
<wire x1="71.755" y1="75.565" x2="70.1675" y2="75.565" width="1.27" layer="16"/>
</signal>
<signal name="S$79">
<wire x1="77.47" y1="72.39" x2="73.3425" y2="72.39" width="1.27" layer="16"/>
<wire x1="73.3425" y1="72.39" x2="73.3425" y2="72.7075" width="1.27" layer="16"/>
</signal>
<signal name="S$81">
<via x="24.13" y="63.5" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$82">
<via x="24.13" y="58.42" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$35">
<via x="20.955" y="60.96" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
<signal name="S$63">
<via x="20.955" y="67.31" extent="1-16" drill="0.6" diameter="1.27"/>
</signal>
</signals>
</board>
</drawing>
<compatibility>
<note version="6.3" minversion="6.2.2" severity="warning">
Since Version 6.2.2 text objects can contain more than one line,
which will not be processed correctly with this version.
</note>
</compatibility>
</eagle>
