<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="mm" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="16" fill="1" visible="no" active="yes"/>
<layer number="3" name="Route3" color="17" fill="1" visible="no" active="yes"/>
<layer number="4" name="Route4" color="18" fill="1" visible="no" active="yes"/>
<layer number="5" name="Route5" color="19" fill="1" visible="no" active="yes"/>
<layer number="6" name="Route6" color="25" fill="1" visible="no" active="yes"/>
<layer number="7" name="Route7" color="26" fill="1" visible="no" active="yes"/>
<layer number="8" name="Route8" color="27" fill="1" visible="no" active="yes"/>
<layer number="9" name="Route9" color="28" fill="1" visible="no" active="yes"/>
<layer number="10" name="Route10" color="29" fill="1" visible="no" active="yes"/>
<layer number="11" name="Route11" color="30" fill="1" visible="no" active="yes"/>
<layer number="12" name="Route12" color="20" fill="1" visible="no" active="yes"/>
<layer number="13" name="Route13" color="21" fill="1" visible="no" active="yes"/>
<layer number="14" name="Route14" color="22" fill="1" visible="no" active="yes"/>
<layer number="15" name="Route15" color="23" fill="1" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="WQE23">
<pad name="P$1" x="0" y="15.24" drill="0.8" diameter="1.9304"/>
<pad name="P$2" x="2.54" y="15.24" drill="0.8" diameter="1.9304"/>
<pad name="P$3" x="5.08" y="15.24" drill="0.8" diameter="1.9304"/>
<pad name="P$4" x="7.62" y="15.24" drill="0.8" diameter="1.9304"/>
<pad name="P$5" x="10.16" y="15.24" drill="0.8" diameter="1.9304"/>
<pad name="P$6" x="12.7" y="15.24" drill="0.8" diameter="1.9304"/>
<pad name="P$7" x="15.24" y="15.24" drill="0.8" diameter="1.9304"/>
<pad name="P$8" x="17.78" y="15.24" drill="0.8" diameter="1.9304"/>
<pad name="P$9" x="20.32" y="15.24" drill="0.8" diameter="1.9304"/>
<pad name="P$10" x="20.32" y="0" drill="0.8" diameter="1.9304"/>
<pad name="P$11" x="17.78" y="0" drill="0.8" diameter="1.9304"/>
<pad name="P$12" x="15.24" y="0" drill="0.8" diameter="1.9304"/>
<pad name="P$13" x="12.7" y="0" drill="0.8" diameter="1.9304"/>
<pad name="P$14" x="10.16" y="0" drill="0.8" diameter="1.9304"/>
<pad name="P$15" x="7.62" y="0" drill="0.8" diameter="1.9304"/>
<pad name="P$16" x="5.08" y="0" drill="0.8" diameter="1.9304"/>
<pad name="P$17" x="2.54" y="0" drill="0.8" diameter="1.9304"/>
<pad name="P$18" x="0" y="0" drill="0.8" diameter="1.9304"/>
<wire x1="-2.54" y1="17.78" x2="21.082" y2="17.78" width="0.1524" layer="21"/>
<wire x1="21.082" y1="17.78" x2="22.479" y2="16.383" width="0.1524" layer="21"/>
<wire x1="22.479" y1="16.383" x2="22.479" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="22.479" y1="-2.54" x2="-2.54" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="17.78" width="0.1524" layer="21"/>
<text x="-3.81" y="0" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<wire x1="8.026" y1="3.046" x2="8.28" y2="3.046" width="0.3048" layer="51"/>
<wire x1="8.153" y1="11.8892" x2="7.7212" y2="11.4574" width="0.254" layer="51"/>
<wire x1="7.7212" y1="11.4574" x2="7.0866" y2="8.3566" width="0.254" layer="51"/>
<wire x1="7.0866" y1="8.3566" x2="7.493" y2="7.9502" width="0.254" layer="51"/>
<wire x1="7.493" y1="7.9502" x2="7.874" y2="8.3312" width="0.254" layer="51"/>
<wire x1="7.874" y1="8.3312" x2="8.4832" y2="11.559" width="0.254" layer="51"/>
<wire x1="8.4832" y1="11.559" x2="8.153" y2="11.8892" width="0.254" layer="51"/>
<wire x1="7.8482" y1="12.194" x2="7.4672" y2="11.813" width="0.254" layer="51"/>
<wire x1="7.4672" y1="11.813" x2="4.0382" y2="11.813" width="0.254" layer="51"/>
<wire x1="4.0382" y1="11.813" x2="3.6572" y2="12.194" width="0.254" layer="51"/>
<wire x1="3.6572" y1="12.194" x2="4.0382" y2="12.575" width="0.254" layer="51"/>
<wire x1="4.0382" y1="12.575" x2="7.4672" y2="12.575" width="0.254" layer="51"/>
<wire x1="7.4672" y1="12.575" x2="7.8482" y2="12.194" width="0.254" layer="51"/>
<wire x1="3.3524" y1="11.8892" x2="3.7842" y2="11.4574" width="0.254" layer="51"/>
<wire x1="3.7842" y1="11.4574" x2="3.175" y2="8.3566" width="0.254" layer="51"/>
<wire x1="3.175" y1="8.3566" x2="2.667" y2="7.8486" width="0.254" layer="51"/>
<wire x1="2.667" y1="7.8486" x2="2.413" y2="8.1026" width="0.254" layer="51"/>
<wire x1="2.413" y1="8.1026" x2="3.0222" y2="11.559" width="0.254" layer="51"/>
<wire x1="3.0222" y1="11.559" x2="3.3524" y2="11.8892" width="0.254" layer="51"/>
<wire x1="2.9718" y1="7.5438" x2="3.429" y2="8.001" width="0.254" layer="51"/>
<wire x1="3.429" y1="8.001" x2="6.8072" y2="8.001" width="0.254" layer="51"/>
<wire x1="6.8072" y1="8.001" x2="7.1374" y2="7.6708" width="0.254" layer="51"/>
<wire x1="7.1374" y1="7.6708" x2="6.7056" y2="7.239" width="0.254" layer="51"/>
<wire x1="6.7056" y1="7.239" x2="3.2766" y2="7.239" width="0.254" layer="51"/>
<wire x1="3.2766" y1="7.239" x2="2.9718" y2="7.5438" width="0.254" layer="51"/>
<wire x1="2.6162" y1="7.2898" x2="2.9972" y2="6.9088" width="0.254" layer="51"/>
<wire x1="1.9808" y1="3.3508" x2="2.438" y2="3.808" width="0.254" layer="51"/>
<wire x1="2.438" y1="3.808" x2="2.9972" y2="6.9088" width="0.254" layer="51"/>
<wire x1="2.6162" y1="7.2898" x2="2.2098" y2="6.8834" width="0.254" layer="51"/>
<wire x1="2.2098" y1="6.8834" x2="1.6506" y2="3.681" width="0.254" layer="51"/>
<wire x1="1.6506" y1="3.681" x2="1.9808" y2="3.3508" width="0.254" layer="51"/>
<wire x1="2.2856" y1="3.046" x2="2.6666" y2="3.427" width="0.254" layer="51"/>
<wire x1="2.6666" y1="3.427" x2="6.0956" y2="3.427" width="0.254" layer="51"/>
<wire x1="6.0956" y1="3.427" x2="6.4766" y2="3.046" width="0.254" layer="51"/>
<wire x1="6.4766" y1="3.046" x2="6.0956" y2="2.665" width="0.254" layer="51"/>
<wire x1="6.0956" y1="2.665" x2="2.6666" y2="2.665" width="0.254" layer="51"/>
<wire x1="2.6666" y1="2.665" x2="2.2856" y2="3.046" width="0.254" layer="51"/>
<wire x1="7.4168" y1="7.3406" x2="6.9088" y2="6.8326" width="0.254" layer="51"/>
<wire x1="6.9088" y1="6.8326" x2="6.3496" y2="3.7826" width="0.254" layer="51"/>
<wire x1="6.3496" y1="3.7826" x2="6.7814" y2="3.3508" width="0.254" layer="51"/>
<wire x1="6.7814" y1="3.3508" x2="7.1116" y2="3.681" width="0.254" layer="51"/>
<wire x1="7.1116" y1="3.681" x2="7.6708" y2="7.0866" width="0.254" layer="51"/>
<wire x1="7.6708" y1="7.0866" x2="7.4168" y2="7.3406" width="0.254" layer="51"/>
<wire x1="2.692" y1="3.046" x2="6.121" y2="3.046" width="0.6096" layer="51"/>
<wire x1="6.756" y1="3.808" x2="7.366" y2="6.985" width="0.6096" layer="51"/>
<wire x1="6.731" y1="7.62" x2="3.302" y2="7.62" width="0.6096" layer="51"/>
<wire x1="2.667" y1="6.985" x2="2.057" y2="3.808" width="0.6096" layer="51"/>
<wire x1="2.769" y1="8.28" x2="3.402" y2="11.457" width="0.6096" layer="51"/>
<wire x1="4.089" y1="12.194" x2="7.518" y2="12.194" width="0.6096" layer="51"/>
<wire x1="8.153" y1="11.559" x2="7.493" y2="8.382" width="0.6096" layer="51"/>
<circle x="8.153" y="3.046" radius="0.254" width="0.6096" layer="51"/>
<wire x1="18.186" y1="3.046" x2="18.44" y2="3.046" width="0.3048" layer="51"/>
<wire x1="18.313" y1="11.8892" x2="17.8812" y2="11.4574" width="0.254" layer="51"/>
<wire x1="17.8812" y1="11.4574" x2="17.2466" y2="8.3566" width="0.254" layer="51"/>
<wire x1="17.2466" y1="8.3566" x2="17.653" y2="7.9502" width="0.254" layer="51"/>
<wire x1="17.653" y1="7.9502" x2="18.034" y2="8.3312" width="0.254" layer="51"/>
<wire x1="18.034" y1="8.3312" x2="18.6432" y2="11.559" width="0.254" layer="51"/>
<wire x1="18.6432" y1="11.559" x2="18.313" y2="11.8892" width="0.254" layer="51"/>
<wire x1="18.0082" y1="12.194" x2="17.6272" y2="11.813" width="0.254" layer="51"/>
<wire x1="17.6272" y1="11.813" x2="14.1982" y2="11.813" width="0.254" layer="51"/>
<wire x1="14.1982" y1="11.813" x2="13.8172" y2="12.194" width="0.254" layer="51"/>
<wire x1="13.8172" y1="12.194" x2="14.1982" y2="12.575" width="0.254" layer="51"/>
<wire x1="14.1982" y1="12.575" x2="17.6272" y2="12.575" width="0.254" layer="51"/>
<wire x1="17.6272" y1="12.575" x2="18.0082" y2="12.194" width="0.254" layer="51"/>
<wire x1="13.5124" y1="11.8892" x2="13.9442" y2="11.4574" width="0.254" layer="51"/>
<wire x1="13.9442" y1="11.4574" x2="13.335" y2="8.3566" width="0.254" layer="51"/>
<wire x1="13.335" y1="8.3566" x2="12.827" y2="7.8486" width="0.254" layer="51"/>
<wire x1="12.827" y1="7.8486" x2="12.573" y2="8.1026" width="0.254" layer="51"/>
<wire x1="12.573" y1="8.1026" x2="13.1822" y2="11.559" width="0.254" layer="51"/>
<wire x1="13.1822" y1="11.559" x2="13.5124" y2="11.8892" width="0.254" layer="51"/>
<wire x1="13.1318" y1="7.5438" x2="13.589" y2="8.001" width="0.254" layer="51"/>
<wire x1="13.589" y1="8.001" x2="16.9672" y2="8.001" width="0.254" layer="51"/>
<wire x1="16.9672" y1="8.001" x2="17.2974" y2="7.6708" width="0.254" layer="51"/>
<wire x1="17.2974" y1="7.6708" x2="16.8656" y2="7.239" width="0.254" layer="51"/>
<wire x1="16.8656" y1="7.239" x2="13.4366" y2="7.239" width="0.254" layer="51"/>
<wire x1="13.4366" y1="7.239" x2="13.1318" y2="7.5438" width="0.254" layer="51"/>
<wire x1="12.7762" y1="7.2898" x2="13.1572" y2="6.9088" width="0.254" layer="51"/>
<wire x1="12.1408" y1="3.3508" x2="12.598" y2="3.808" width="0.254" layer="51"/>
<wire x1="12.598" y1="3.808" x2="13.1572" y2="6.9088" width="0.254" layer="51"/>
<wire x1="12.7762" y1="7.2898" x2="12.3698" y2="6.8834" width="0.254" layer="51"/>
<wire x1="12.3698" y1="6.8834" x2="11.8106" y2="3.681" width="0.254" layer="51"/>
<wire x1="11.8106" y1="3.681" x2="12.1408" y2="3.3508" width="0.254" layer="51"/>
<wire x1="12.4456" y1="3.046" x2="12.8266" y2="3.427" width="0.254" layer="51"/>
<wire x1="12.8266" y1="3.427" x2="16.2556" y2="3.427" width="0.254" layer="51"/>
<wire x1="16.2556" y1="3.427" x2="16.6366" y2="3.046" width="0.254" layer="51"/>
<wire x1="16.6366" y1="3.046" x2="16.2556" y2="2.665" width="0.254" layer="51"/>
<wire x1="16.2556" y1="2.665" x2="12.8266" y2="2.665" width="0.254" layer="51"/>
<wire x1="12.8266" y1="2.665" x2="12.4456" y2="3.046" width="0.254" layer="51"/>
<wire x1="17.5768" y1="7.3406" x2="17.0688" y2="6.8326" width="0.254" layer="51"/>
<wire x1="17.0688" y1="6.8326" x2="16.5096" y2="3.7826" width="0.254" layer="51"/>
<wire x1="16.5096" y1="3.7826" x2="16.9414" y2="3.3508" width="0.254" layer="51"/>
<wire x1="16.9414" y1="3.3508" x2="17.2716" y2="3.681" width="0.254" layer="51"/>
<wire x1="17.2716" y1="3.681" x2="17.8308" y2="7.0866" width="0.254" layer="51"/>
<wire x1="17.8308" y1="7.0866" x2="17.5768" y2="7.3406" width="0.254" layer="51"/>
<wire x1="12.852" y1="3.046" x2="16.281" y2="3.046" width="0.6096" layer="51"/>
<wire x1="16.916" y1="3.808" x2="17.526" y2="6.985" width="0.6096" layer="51"/>
<wire x1="16.891" y1="7.62" x2="13.462" y2="7.62" width="0.6096" layer="51"/>
<wire x1="12.827" y1="6.985" x2="12.217" y2="3.808" width="0.6096" layer="51"/>
<wire x1="12.929" y1="8.28" x2="13.562" y2="11.457" width="0.6096" layer="51"/>
<wire x1="14.249" y1="12.194" x2="17.678" y2="12.194" width="0.6096" layer="51"/>
<wire x1="18.313" y1="11.559" x2="17.653" y2="8.382" width="0.6096" layer="51"/>
<circle x="18.313" y="3.046" radius="0.254" width="0.6096" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="WQE23">
<wire x1="2.794" y1="-3.683" x2="3.048" y2="-3.683" width="0.3048" layer="94"/>
<wire x1="2.3368" y1="3.1242" x2="2.032" y2="2.8194" width="0.254" layer="94"/>
<wire x1="2.032" y1="2.8194" x2="1.6256" y2="0.6096" width="0.254" layer="94"/>
<wire x1="1.6256" y1="0.6096" x2="1.905" y2="0.3302" width="0.254" layer="94"/>
<wire x1="1.905" y1="0.3302" x2="2.159" y2="0.5842" width="0.254" layer="94"/>
<wire x1="2.159" y1="0.5842" x2="2.54" y2="2.921" width="0.254" layer="94"/>
<wire x1="2.54" y1="2.921" x2="2.3368" y2="3.1242" width="0.254" layer="94"/>
<wire x1="2.032" y1="3.429" x2="1.778" y2="3.175" width="0.254" layer="94"/>
<wire x1="1.778" y1="3.175" x2="-0.762" y2="3.175" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.175" x2="-1.016" y2="3.429" width="0.254" layer="94"/>
<wire x1="-1.016" y1="3.429" x2="-0.762" y2="3.683" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.683" x2="1.778" y2="3.683" width="0.254" layer="94"/>
<wire x1="1.778" y1="3.683" x2="2.032" y2="3.429" width="0.254" layer="94"/>
<wire x1="-1.3208" y1="3.1242" x2="-1.016" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-1.016" y1="2.8194" x2="-1.397" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-1.397" y1="0.6096" x2="-1.651" y2="0.3556" width="0.254" layer="94"/>
<wire x1="-1.651" y1="0.3556" x2="-1.905" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-1.905" y1="0.6096" x2="-1.524" y2="2.921" width="0.254" layer="94"/>
<wire x1="-1.524" y1="2.921" x2="-1.3208" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-1.4732" y1="-0.0762" x2="-1.143" y2="0.254" width="0.254" layer="94"/>
<wire x1="-1.143" y1="0.254" x2="1.3462" y2="0.254" width="0.254" layer="94"/>
<wire x1="1.3462" y1="0.254" x2="1.5494" y2="0.0508" width="0.254" layer="94"/>
<wire x1="1.5494" y1="0.0508" x2="1.2446" y2="-0.254" width="0.254" layer="94"/>
<wire x1="1.2446" y1="-0.254" x2="-1.2954" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-1.2954" y1="-0.254" x2="-1.4732" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="-1.8288" y1="-0.3302" x2="-1.5748" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-2.286" y1="-3.1242" x2="-1.9558" y2="-2.794" width="0.254" layer="94"/>
<wire x1="-1.9558" y1="-2.794" x2="-1.5748" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-1.8288" y1="-0.3302" x2="-2.1082" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="-2.1082" y1="-0.6096" x2="-2.4892" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-2.4892" y1="-2.921" x2="-2.286" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-1.9812" y1="-3.429" x2="-1.7272" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.175" x2="0.8128" y2="-3.175" width="0.254" layer="94"/>
<wire x1="0.8128" y1="-3.175" x2="1.0668" y2="-3.429" width="0.254" layer="94"/>
<wire x1="1.0668" y1="-3.429" x2="0.8128" y2="-3.683" width="0.254" layer="94"/>
<wire x1="0.8128" y1="-3.683" x2="-1.7272" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.683" x2="-1.9812" y2="-3.429" width="0.254" layer="94"/>
<wire x1="1.7018" y1="-0.4064" x2="1.4478" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="1.4478" y1="-0.6604" x2="1.0668" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="1.0668" y1="-2.8194" x2="1.3716" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="1.3716" y1="-3.1242" x2="1.5748" y2="-2.921" width="0.254" layer="94"/>
<wire x1="1.5748" y1="-2.921" x2="1.9558" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="1.9558" y1="-0.6604" x2="1.7018" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="2.286" y1="2.794" x2="1.905" y2="0.635" width="0.4064" layer="94"/>
<wire x1="1.778" y1="3.429" x2="-0.762" y2="3.429" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="2.794" x2="-1.651" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.4064" layer="94"/>
<wire x1="1.651" y1="-0.762" x2="1.27" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="0.762" y1="-3.429" x2="-1.651" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="-2.286" y1="-2.921" x2="-1.905" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="12.7" y1="8.89" x2="12.7" y2="-13.97" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-13.97" x2="12.7" y2="-13.97" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-13.97" x2="-5.08" y2="8.89" width="0.4064" layer="94"/>
<wire x1="12.7" y1="8.89" x2="-5.08" y2="8.89" width="0.4064" layer="94"/>
<circle x="2.921" y="-3.683" radius="0.254" width="0.3048" layer="94"/>
<text x="-2.54" y="9.525" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="-16.51" size="1.778" layer="96">&gt;VALUE</text>
<wire x1="10.414" y1="-3.683" x2="10.668" y2="-3.683" width="0.3048" layer="94"/>
<wire x1="9.9568" y1="3.1242" x2="9.652" y2="2.8194" width="0.254" layer="94"/>
<wire x1="9.652" y1="2.8194" x2="9.2456" y2="0.6096" width="0.254" layer="94"/>
<wire x1="9.2456" y1="0.6096" x2="9.525" y2="0.3302" width="0.254" layer="94"/>
<wire x1="9.525" y1="0.3302" x2="9.779" y2="0.5842" width="0.254" layer="94"/>
<wire x1="9.779" y1="0.5842" x2="10.16" y2="2.921" width="0.254" layer="94"/>
<wire x1="10.16" y1="2.921" x2="9.9568" y2="3.1242" width="0.254" layer="94"/>
<wire x1="9.652" y1="3.429" x2="9.398" y2="3.175" width="0.254" layer="94"/>
<wire x1="9.398" y1="3.175" x2="6.858" y2="3.175" width="0.254" layer="94"/>
<wire x1="6.858" y1="3.175" x2="6.604" y2="3.429" width="0.254" layer="94"/>
<wire x1="6.604" y1="3.429" x2="6.858" y2="3.683" width="0.254" layer="94"/>
<wire x1="6.858" y1="3.683" x2="9.398" y2="3.683" width="0.254" layer="94"/>
<wire x1="9.398" y1="3.683" x2="9.652" y2="3.429" width="0.254" layer="94"/>
<wire x1="6.2992" y1="3.1242" x2="6.604" y2="2.8194" width="0.254" layer="94"/>
<wire x1="6.604" y1="2.8194" x2="6.223" y2="0.6096" width="0.254" layer="94"/>
<wire x1="6.223" y1="0.6096" x2="5.969" y2="0.3556" width="0.254" layer="94"/>
<wire x1="5.969" y1="0.3556" x2="5.715" y2="0.6096" width="0.254" layer="94"/>
<wire x1="5.715" y1="0.6096" x2="6.096" y2="2.921" width="0.254" layer="94"/>
<wire x1="6.096" y1="2.921" x2="6.2992" y2="3.1242" width="0.254" layer="94"/>
<wire x1="6.1468" y1="-0.0762" x2="6.477" y2="0.254" width="0.254" layer="94"/>
<wire x1="6.477" y1="0.254" x2="8.9662" y2="0.254" width="0.254" layer="94"/>
<wire x1="8.9662" y1="0.254" x2="9.1694" y2="0.0508" width="0.254" layer="94"/>
<wire x1="9.1694" y1="0.0508" x2="8.8646" y2="-0.254" width="0.254" layer="94"/>
<wire x1="8.8646" y1="-0.254" x2="6.3246" y2="-0.254" width="0.254" layer="94"/>
<wire x1="6.3246" y1="-0.254" x2="6.1468" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="5.7912" y1="-0.3302" x2="6.0452" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="5.334" y1="-3.1242" x2="5.6642" y2="-2.794" width="0.254" layer="94"/>
<wire x1="5.6642" y1="-2.794" x2="6.0452" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="5.7912" y1="-0.3302" x2="5.5118" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="5.5118" y1="-0.6096" x2="5.1308" y2="-2.921" width="0.254" layer="94"/>
<wire x1="5.1308" y1="-2.921" x2="5.334" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="5.6388" y1="-3.429" x2="5.8928" y2="-3.175" width="0.254" layer="94"/>
<wire x1="5.8928" y1="-3.175" x2="8.4328" y2="-3.175" width="0.254" layer="94"/>
<wire x1="8.4328" y1="-3.175" x2="8.6868" y2="-3.429" width="0.254" layer="94"/>
<wire x1="8.6868" y1="-3.429" x2="8.4328" y2="-3.683" width="0.254" layer="94"/>
<wire x1="8.4328" y1="-3.683" x2="5.8928" y2="-3.683" width="0.254" layer="94"/>
<wire x1="5.8928" y1="-3.683" x2="5.6388" y2="-3.429" width="0.254" layer="94"/>
<wire x1="9.3218" y1="-0.4064" x2="9.0678" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="9.0678" y1="-0.6604" x2="8.6868" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="8.6868" y1="-2.8194" x2="8.9916" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="8.9916" y1="-3.1242" x2="9.1948" y2="-2.921" width="0.254" layer="94"/>
<wire x1="9.1948" y1="-2.921" x2="9.5758" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="9.5758" y1="-0.6604" x2="9.3218" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="9.906" y1="2.794" x2="9.525" y2="0.635" width="0.4064" layer="94"/>
<wire x1="9.398" y1="3.429" x2="6.858" y2="3.429" width="0.4064" layer="94"/>
<wire x1="6.35" y1="2.794" x2="5.969" y2="0.635" width="0.4064" layer="94"/>
<wire x1="6.35" y1="0" x2="8.89" y2="0" width="0.4064" layer="94"/>
<wire x1="9.271" y1="-0.762" x2="8.89" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="8.382" y1="-3.429" x2="5.969" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="5.334" y1="-2.921" x2="5.715" y2="-0.635" width="0.4064" layer="94"/>
<circle x="10.541" y="-3.683" radius="0.254" width="0.3048" layer="94"/>
<pin name="P$1" x="-10.16" y="7.62" visible="off" length="middle"/>
<pin name="P$2" x="-10.16" y="5.08" visible="off" length="middle"/>
<pin name="P$3" x="-10.16" y="2.54" visible="off" length="middle"/>
<pin name="P$4" x="-10.16" y="0" visible="off" length="middle"/>
<pin name="P$5" x="-10.16" y="-2.54" visible="off" length="middle"/>
<pin name="P$6" x="-10.16" y="-5.08" visible="off" length="middle"/>
<pin name="P$7" x="-10.16" y="-7.62" visible="off" length="middle"/>
<pin name="P$8" x="-10.16" y="-10.16" visible="off" length="middle"/>
<pin name="P$9" x="-10.16" y="-12.7" visible="off" length="middle"/>
<pin name="P$10" x="17.78" y="-12.7" visible="off" length="middle" rot="R180"/>
<pin name="P$11" x="17.78" y="-10.16" visible="off" length="middle" rot="R180"/>
<pin name="P$12" x="17.78" y="-7.62" visible="off" length="middle" rot="R180"/>
<pin name="P$13" x="17.78" y="-5.08" visible="off" length="middle" rot="R180"/>
<pin name="P$14" x="17.78" y="-2.54" visible="off" length="middle" rot="R180"/>
<pin name="P$15" x="17.78" y="0" visible="off" length="middle" rot="R180"/>
<pin name="P$16" x="17.78" y="2.54" visible="off" length="middle" rot="R180"/>
<pin name="P$17" x="17.78" y="5.08" visible="off" length="middle" rot="R180"/>
<pin name="P$18" x="17.78" y="7.62" visible="off" length="middle" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="WQE23">
<description>niedziela 2021</description>
<gates>
<gate name="G$1" symbol="WQE23" x="-2.54" y="7.62"/>
</gates>
<devices>
<device name="" package="WQE23">
<connects>
<connect gate="G$1" pin="P$1" pad="P$1"/>
<connect gate="G$1" pin="P$10" pad="P$10"/>
<connect gate="G$1" pin="P$11" pad="P$11"/>
<connect gate="G$1" pin="P$12" pad="P$12"/>
<connect gate="G$1" pin="P$13" pad="P$13"/>
<connect gate="G$1" pin="P$14" pad="P$14"/>
<connect gate="G$1" pin="P$15" pad="P$15"/>
<connect gate="G$1" pin="P$16" pad="P$16"/>
<connect gate="G$1" pin="P$17" pad="P$17"/>
<connect gate="G$1" pin="P$18" pad="P$18"/>
<connect gate="G$1" pin="P$2" pad="P$2"/>
<connect gate="G$1" pin="P$3" pad="P$3"/>
<connect gate="G$1" pin="P$4" pad="P$4"/>
<connect gate="G$1" pin="P$5" pad="P$5"/>
<connect gate="G$1" pin="P$6" pad="P$6"/>
<connect gate="G$1" pin="P$7" pad="P$7"/>
<connect gate="G$1" pin="P$8" pad="P$8"/>
<connect gate="G$1" pin="P$9" pad="P$9"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
