<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.01" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="16" fill="1" visible="no" active="yes"/>
<layer number="3" name="Route3" color="17" fill="1" visible="no" active="yes"/>
<layer number="4" name="Route4" color="18" fill="1" visible="no" active="yes"/>
<layer number="5" name="Route5" color="19" fill="1" visible="no" active="yes"/>
<layer number="6" name="Route6" color="25" fill="1" visible="no" active="yes"/>
<layer number="7" name="Route7" color="26" fill="1" visible="no" active="yes"/>
<layer number="8" name="Route8" color="27" fill="1" visible="no" active="yes"/>
<layer number="9" name="Route9" color="28" fill="1" visible="no" active="yes"/>
<layer number="10" name="Route10" color="29" fill="1" visible="no" active="yes"/>
<layer number="11" name="Route11" color="30" fill="1" visible="no" active="yes"/>
<layer number="12" name="Route12" color="20" fill="1" visible="no" active="yes"/>
<layer number="13" name="Route13" color="21" fill="1" visible="no" active="yes"/>
<layer number="14" name="Route14" color="22" fill="1" visible="no" active="yes"/>
<layer number="15" name="Route15" color="23" fill="1" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="WQE23">
<pad name="C1" x="-10.16" y="7.62" drill="0.8" diameter="1.9304"/>
<pad name="E1" x="-7.62" y="7.62" drill="0.8" diameter="1.9304"/>
<pad name="D1" x="-5.08" y="7.62" drill="0.8" diameter="1.9304"/>
<pad name="K1" x="-2.54" y="7.62" drill="0.8" diameter="1.9304"/>
<pad name="K2" x="0" y="7.62" drill="0.8" diameter="1.9304"/>
<pad name="D2" x="2.54" y="7.62" drill="0.8" diameter="1.9304"/>
<pad name="E2" x="5.08" y="7.62" drill="0.8" diameter="1.9304"/>
<pad name="C2" x="7.62" y="7.62" drill="0.8" diameter="1.9304"/>
<pad name="H2" x="10.16" y="7.62" drill="0.8" diameter="1.9304"/>
<pad name="G2" x="10.16" y="-7.62" drill="0.8" diameter="1.9304"/>
<pad name="A2" x="7.62" y="-7.62" drill="0.8" diameter="1.9304"/>
<pad name="F2" x="5.08" y="-7.62" drill="0.8" diameter="1.9304"/>
<pad name="B2" x="2.54" y="-7.62" drill="0.8" diameter="1.9304"/>
<pad name="B1" x="0" y="-7.62" drill="0.8" diameter="1.9304"/>
<pad name="F1" x="-2.54" y="-7.62" drill="0.8" diameter="1.9304"/>
<pad name="A1" x="-5.08" y="-7.62" drill="0.8" diameter="1.9304"/>
<pad name="G1" x="-7.62" y="-7.62" drill="0.8" diameter="1.9304"/>
<pad name="H1" x="-10.16" y="-7.62" drill="0.8" diameter="1.9304"/>
<wire x1="-12.7" y1="10.16" x2="10.922" y2="10.16" width="0.1524" layer="21"/>
<wire x1="10.922" y1="10.16" x2="12.319" y2="8.763" width="0.1524" layer="21"/>
<wire x1="12.319" y1="8.763" x2="12.319" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-10.16" x2="-12.7" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-10.16" x2="-12.7" y2="10.16" width="0.1524" layer="21"/>
<text x="-13.97" y="-7.62" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<wire x1="-2.134" y1="-4.574" x2="-1.88" y2="-4.574" width="0.3048" layer="51"/>
<wire x1="-2.007" y1="4.2692" x2="-2.4388" y2="3.8374" width="0.254" layer="51"/>
<wire x1="-2.4388" y1="3.8374" x2="-3.0734" y2="0.7366" width="0.254" layer="51"/>
<wire x1="-3.0734" y1="0.7366" x2="-2.667" y2="0.3302" width="0.254" layer="51"/>
<wire x1="-2.667" y1="0.3302" x2="-2.286" y2="0.7112" width="0.254" layer="51"/>
<wire x1="-2.286" y1="0.7112" x2="-1.6768" y2="3.939" width="0.254" layer="51"/>
<wire x1="-1.6768" y1="3.939" x2="-2.007" y2="4.2692" width="0.254" layer="51"/>
<wire x1="-2.3118" y1="4.574" x2="-2.6928" y2="4.193" width="0.254" layer="51"/>
<wire x1="-2.6928" y1="4.193" x2="-6.1218" y2="4.193" width="0.254" layer="51"/>
<wire x1="-6.1218" y1="4.193" x2="-6.5028" y2="4.574" width="0.254" layer="51"/>
<wire x1="-6.5028" y1="4.574" x2="-6.1218" y2="4.955" width="0.254" layer="51"/>
<wire x1="-6.1218" y1="4.955" x2="-2.6928" y2="4.955" width="0.254" layer="51"/>
<wire x1="-2.6928" y1="4.955" x2="-2.3118" y2="4.574" width="0.254" layer="51"/>
<wire x1="-6.8076" y1="4.2692" x2="-6.3758" y2="3.8374" width="0.254" layer="51"/>
<wire x1="-6.3758" y1="3.8374" x2="-6.985" y2="0.7366" width="0.254" layer="51"/>
<wire x1="-6.985" y1="0.7366" x2="-7.493" y2="0.2286" width="0.254" layer="51"/>
<wire x1="-7.493" y1="0.2286" x2="-7.747" y2="0.4826" width="0.254" layer="51"/>
<wire x1="-7.747" y1="0.4826" x2="-7.1378" y2="3.939" width="0.254" layer="51"/>
<wire x1="-7.1378" y1="3.939" x2="-6.8076" y2="4.2692" width="0.254" layer="51"/>
<wire x1="-7.1882" y1="-0.0762" x2="-6.731" y2="0.381" width="0.254" layer="51"/>
<wire x1="-6.731" y1="0.381" x2="-3.3528" y2="0.381" width="0.254" layer="51"/>
<wire x1="-3.3528" y1="0.381" x2="-3.0226" y2="0.0508" width="0.254" layer="51"/>
<wire x1="-3.0226" y1="0.0508" x2="-3.4544" y2="-0.381" width="0.254" layer="51"/>
<wire x1="-3.4544" y1="-0.381" x2="-6.8834" y2="-0.381" width="0.254" layer="51"/>
<wire x1="-6.8834" y1="-0.381" x2="-7.1882" y2="-0.0762" width="0.254" layer="51"/>
<wire x1="-7.5438" y1="-0.3302" x2="-7.1628" y2="-0.7112" width="0.254" layer="51"/>
<wire x1="-8.1792" y1="-4.2692" x2="-7.722" y2="-3.812" width="0.254" layer="51"/>
<wire x1="-7.722" y1="-3.812" x2="-7.1628" y2="-0.7112" width="0.254" layer="51"/>
<wire x1="-7.5438" y1="-0.3302" x2="-7.9502" y2="-0.7366" width="0.254" layer="51"/>
<wire x1="-7.9502" y1="-0.7366" x2="-8.5094" y2="-3.939" width="0.254" layer="51"/>
<wire x1="-8.5094" y1="-3.939" x2="-8.1792" y2="-4.2692" width="0.254" layer="51"/>
<wire x1="-7.8744" y1="-4.574" x2="-7.4934" y2="-4.193" width="0.254" layer="51"/>
<wire x1="-7.4934" y1="-4.193" x2="-4.0644" y2="-4.193" width="0.254" layer="51"/>
<wire x1="-4.0644" y1="-4.193" x2="-3.6834" y2="-4.574" width="0.254" layer="51"/>
<wire x1="-3.6834" y1="-4.574" x2="-4.0644" y2="-4.955" width="0.254" layer="51"/>
<wire x1="-4.0644" y1="-4.955" x2="-7.4934" y2="-4.955" width="0.254" layer="51"/>
<wire x1="-7.4934" y1="-4.955" x2="-7.8744" y2="-4.574" width="0.254" layer="51"/>
<wire x1="-2.7432" y1="-0.2794" x2="-3.2512" y2="-0.7874" width="0.254" layer="51"/>
<wire x1="-3.2512" y1="-0.7874" x2="-3.8104" y2="-3.8374" width="0.254" layer="51"/>
<wire x1="-3.8104" y1="-3.8374" x2="-3.3786" y2="-4.2692" width="0.254" layer="51"/>
<wire x1="-3.3786" y1="-4.2692" x2="-3.0484" y2="-3.939" width="0.254" layer="51"/>
<wire x1="-3.0484" y1="-3.939" x2="-2.4892" y2="-0.5334" width="0.254" layer="51"/>
<wire x1="-2.4892" y1="-0.5334" x2="-2.7432" y2="-0.2794" width="0.254" layer="51"/>
<wire x1="-7.468" y1="-4.574" x2="-4.039" y2="-4.574" width="0.6096" layer="51"/>
<wire x1="-3.404" y1="-3.812" x2="-2.794" y2="-0.635" width="0.6096" layer="51"/>
<wire x1="-3.429" y1="0" x2="-6.858" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.493" y1="-0.635" x2="-8.103" y2="-3.812" width="0.6096" layer="51"/>
<wire x1="-7.391" y1="0.66" x2="-6.758" y2="3.837" width="0.6096" layer="51"/>
<wire x1="-6.071" y1="4.574" x2="-2.642" y2="4.574" width="0.6096" layer="51"/>
<wire x1="-2.007" y1="3.939" x2="-2.667" y2="0.762" width="0.6096" layer="51"/>
<circle x="-2.007" y="-4.574" radius="0.254" width="0.6096" layer="51"/>
<wire x1="8.026" y1="-4.574" x2="8.28" y2="-4.574" width="0.3048" layer="51"/>
<wire x1="8.153" y1="4.2692" x2="7.7212" y2="3.8374" width="0.254" layer="51"/>
<wire x1="7.7212" y1="3.8374" x2="7.0866" y2="0.7366" width="0.254" layer="51"/>
<wire x1="7.0866" y1="0.7366" x2="7.493" y2="0.3302" width="0.254" layer="51"/>
<wire x1="7.493" y1="0.3302" x2="7.874" y2="0.7112" width="0.254" layer="51"/>
<wire x1="7.874" y1="0.7112" x2="8.4832" y2="3.939" width="0.254" layer="51"/>
<wire x1="8.4832" y1="3.939" x2="8.153" y2="4.2692" width="0.254" layer="51"/>
<wire x1="7.8482" y1="4.574" x2="7.4672" y2="4.193" width="0.254" layer="51"/>
<wire x1="7.4672" y1="4.193" x2="4.0382" y2="4.193" width="0.254" layer="51"/>
<wire x1="4.0382" y1="4.193" x2="3.6572" y2="4.574" width="0.254" layer="51"/>
<wire x1="3.6572" y1="4.574" x2="4.0382" y2="4.955" width="0.254" layer="51"/>
<wire x1="4.0382" y1="4.955" x2="7.4672" y2="4.955" width="0.254" layer="51"/>
<wire x1="7.4672" y1="4.955" x2="7.8482" y2="4.574" width="0.254" layer="51"/>
<wire x1="3.3524" y1="4.2692" x2="3.7842" y2="3.8374" width="0.254" layer="51"/>
<wire x1="3.7842" y1="3.8374" x2="3.175" y2="0.7366" width="0.254" layer="51"/>
<wire x1="3.175" y1="0.7366" x2="2.667" y2="0.2286" width="0.254" layer="51"/>
<wire x1="2.667" y1="0.2286" x2="2.413" y2="0.4826" width="0.254" layer="51"/>
<wire x1="2.413" y1="0.4826" x2="3.0222" y2="3.939" width="0.254" layer="51"/>
<wire x1="3.0222" y1="3.939" x2="3.3524" y2="4.2692" width="0.254" layer="51"/>
<wire x1="2.9718" y1="-0.0762" x2="3.429" y2="0.381" width="0.254" layer="51"/>
<wire x1="3.429" y1="0.381" x2="6.8072" y2="0.381" width="0.254" layer="51"/>
<wire x1="6.8072" y1="0.381" x2="7.1374" y2="0.0508" width="0.254" layer="51"/>
<wire x1="7.1374" y1="0.0508" x2="6.7056" y2="-0.381" width="0.254" layer="51"/>
<wire x1="6.7056" y1="-0.381" x2="3.2766" y2="-0.381" width="0.254" layer="51"/>
<wire x1="3.2766" y1="-0.381" x2="2.9718" y2="-0.0762" width="0.254" layer="51"/>
<wire x1="2.6162" y1="-0.3302" x2="2.9972" y2="-0.7112" width="0.254" layer="51"/>
<wire x1="1.9808" y1="-4.2692" x2="2.438" y2="-3.812" width="0.254" layer="51"/>
<wire x1="2.438" y1="-3.812" x2="2.9972" y2="-0.7112" width="0.254" layer="51"/>
<wire x1="2.6162" y1="-0.3302" x2="2.2098" y2="-0.7366" width="0.254" layer="51"/>
<wire x1="2.2098" y1="-0.7366" x2="1.6506" y2="-3.939" width="0.254" layer="51"/>
<wire x1="1.6506" y1="-3.939" x2="1.9808" y2="-4.2692" width="0.254" layer="51"/>
<wire x1="2.2856" y1="-4.574" x2="2.6666" y2="-4.193" width="0.254" layer="51"/>
<wire x1="2.6666" y1="-4.193" x2="6.0956" y2="-4.193" width="0.254" layer="51"/>
<wire x1="6.0956" y1="-4.193" x2="6.4766" y2="-4.574" width="0.254" layer="51"/>
<wire x1="6.4766" y1="-4.574" x2="6.0956" y2="-4.955" width="0.254" layer="51"/>
<wire x1="6.0956" y1="-4.955" x2="2.6666" y2="-4.955" width="0.254" layer="51"/>
<wire x1="2.6666" y1="-4.955" x2="2.2856" y2="-4.574" width="0.254" layer="51"/>
<wire x1="7.4168" y1="-0.2794" x2="6.9088" y2="-0.7874" width="0.254" layer="51"/>
<wire x1="6.9088" y1="-0.7874" x2="6.3496" y2="-3.8374" width="0.254" layer="51"/>
<wire x1="6.3496" y1="-3.8374" x2="6.7814" y2="-4.2692" width="0.254" layer="51"/>
<wire x1="6.7814" y1="-4.2692" x2="7.1116" y2="-3.939" width="0.254" layer="51"/>
<wire x1="7.1116" y1="-3.939" x2="7.6708" y2="-0.5334" width="0.254" layer="51"/>
<wire x1="7.6708" y1="-0.5334" x2="7.4168" y2="-0.2794" width="0.254" layer="51"/>
<wire x1="2.692" y1="-4.574" x2="6.121" y2="-4.574" width="0.6096" layer="51"/>
<wire x1="6.756" y1="-3.812" x2="7.366" y2="-0.635" width="0.6096" layer="51"/>
<wire x1="6.731" y1="0" x2="3.302" y2="0" width="0.6096" layer="51"/>
<wire x1="2.667" y1="-0.635" x2="2.057" y2="-3.812" width="0.6096" layer="51"/>
<wire x1="2.769" y1="0.66" x2="3.402" y2="3.837" width="0.6096" layer="51"/>
<wire x1="4.089" y1="4.574" x2="7.518" y2="4.574" width="0.6096" layer="51"/>
<wire x1="8.153" y1="3.939" x2="7.493" y2="0.762" width="0.6096" layer="51"/>
<circle x="8.153" y="-4.574" radius="0.254" width="0.6096" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="WQE23">
<wire x1="-0.508" y1="-3.683" x2="-0.254" y2="-3.683" width="0.3048" layer="94"/>
<wire x1="-0.9652" y1="3.1242" x2="-1.27" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-1.27" y1="2.8194" x2="-1.6764" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-1.6764" y1="0.6096" x2="-1.397" y2="0.3302" width="0.254" layer="94"/>
<wire x1="-1.397" y1="0.3302" x2="-1.143" y2="0.5842" width="0.254" layer="94"/>
<wire x1="-1.143" y1="0.5842" x2="-0.762" y2="2.921" width="0.254" layer="94"/>
<wire x1="-0.762" y1="2.921" x2="-0.9652" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-1.27" y1="3.429" x2="-1.524" y2="3.175" width="0.254" layer="94"/>
<wire x1="-1.524" y1="3.175" x2="-4.064" y2="3.175" width="0.254" layer="94"/>
<wire x1="-4.064" y1="3.175" x2="-4.318" y2="3.429" width="0.254" layer="94"/>
<wire x1="-4.318" y1="3.429" x2="-4.064" y2="3.683" width="0.254" layer="94"/>
<wire x1="-4.064" y1="3.683" x2="-1.524" y2="3.683" width="0.254" layer="94"/>
<wire x1="-1.524" y1="3.683" x2="-1.27" y2="3.429" width="0.254" layer="94"/>
<wire x1="-4.6228" y1="3.1242" x2="-4.318" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-4.318" y1="2.8194" x2="-4.699" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-4.699" y1="0.6096" x2="-4.953" y2="0.3556" width="0.254" layer="94"/>
<wire x1="-4.953" y1="0.3556" x2="-5.207" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-5.207" y1="0.6096" x2="-4.826" y2="2.921" width="0.254" layer="94"/>
<wire x1="-4.826" y1="2.921" x2="-4.6228" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-4.7752" y1="-0.0762" x2="-4.445" y2="0.254" width="0.254" layer="94"/>
<wire x1="-4.445" y1="0.254" x2="-1.9558" y2="0.254" width="0.254" layer="94"/>
<wire x1="-1.9558" y1="0.254" x2="-1.7526" y2="0.0508" width="0.254" layer="94"/>
<wire x1="-1.7526" y1="0.0508" x2="-2.0574" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-2.0574" y1="-0.254" x2="-4.5974" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-4.5974" y1="-0.254" x2="-4.7752" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="-5.1308" y1="-0.3302" x2="-4.8768" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-5.588" y1="-3.1242" x2="-5.2578" y2="-2.794" width="0.254" layer="94"/>
<wire x1="-5.2578" y1="-2.794" x2="-4.8768" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-5.1308" y1="-0.3302" x2="-5.4102" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="-5.4102" y1="-0.6096" x2="-5.7912" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-5.7912" y1="-2.921" x2="-5.588" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-5.2832" y1="-3.429" x2="-5.0292" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-5.0292" y1="-3.175" x2="-2.4892" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-2.4892" y1="-3.175" x2="-2.2352" y2="-3.429" width="0.254" layer="94"/>
<wire x1="-2.2352" y1="-3.429" x2="-2.4892" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-2.4892" y1="-3.683" x2="-5.0292" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-5.0292" y1="-3.683" x2="-5.2832" y2="-3.429" width="0.254" layer="94"/>
<wire x1="-1.6002" y1="-0.4064" x2="-1.8542" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="-1.8542" y1="-0.6604" x2="-2.2352" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="-2.2352" y1="-2.8194" x2="-1.9304" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-1.9304" y1="-3.1242" x2="-1.7272" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-2.921" x2="-1.3462" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="-1.3462" y1="-0.6604" x2="-1.6002" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="-1.016" y1="2.794" x2="-1.397" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-1.524" y1="3.429" x2="-4.064" y2="3.429" width="0.4064" layer="94"/>
<wire x1="-4.572" y1="2.794" x2="-4.953" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-4.572" y1="0" x2="-2.032" y2="0" width="0.4064" layer="94"/>
<wire x1="-1.651" y1="-0.762" x2="-2.032" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="-3.429" x2="-4.953" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="-5.588" y1="-2.921" x2="-5.207" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="9.398" y1="8.89" x2="9.398" y2="-13.97" width="0.4064" layer="94"/>
<wire x1="-8.382" y1="-13.97" x2="9.398" y2="-13.97" width="0.4064" layer="94"/>
<wire x1="-8.382" y1="-13.97" x2="-8.382" y2="8.89" width="0.4064" layer="94"/>
<wire x1="9.398" y1="8.89" x2="-8.382" y2="8.89" width="0.4064" layer="94"/>
<circle x="-0.381" y="-3.683" radius="0.254" width="0.3048" layer="94"/>
<text x="-5.842" y="9.525" size="1.778" layer="95">&gt;NAME</text>
<text x="-5.842" y="-16.51" size="1.778" layer="96">&gt;VALUE</text>
<wire x1="7.112" y1="-3.683" x2="7.366" y2="-3.683" width="0.3048" layer="94"/>
<wire x1="6.6548" y1="3.1242" x2="6.35" y2="2.8194" width="0.254" layer="94"/>
<wire x1="6.35" y1="2.8194" x2="5.9436" y2="0.6096" width="0.254" layer="94"/>
<wire x1="5.9436" y1="0.6096" x2="6.223" y2="0.3302" width="0.254" layer="94"/>
<wire x1="6.223" y1="0.3302" x2="6.477" y2="0.5842" width="0.254" layer="94"/>
<wire x1="6.477" y1="0.5842" x2="6.858" y2="2.921" width="0.254" layer="94"/>
<wire x1="6.858" y1="2.921" x2="6.6548" y2="3.1242" width="0.254" layer="94"/>
<wire x1="6.35" y1="3.429" x2="6.096" y2="3.175" width="0.254" layer="94"/>
<wire x1="6.096" y1="3.175" x2="3.556" y2="3.175" width="0.254" layer="94"/>
<wire x1="3.556" y1="3.175" x2="3.302" y2="3.429" width="0.254" layer="94"/>
<wire x1="3.302" y1="3.429" x2="3.556" y2="3.683" width="0.254" layer="94"/>
<wire x1="3.556" y1="3.683" x2="6.096" y2="3.683" width="0.254" layer="94"/>
<wire x1="6.096" y1="3.683" x2="6.35" y2="3.429" width="0.254" layer="94"/>
<wire x1="2.9972" y1="3.1242" x2="3.302" y2="2.8194" width="0.254" layer="94"/>
<wire x1="3.302" y1="2.8194" x2="2.921" y2="0.6096" width="0.254" layer="94"/>
<wire x1="2.921" y1="0.6096" x2="2.667" y2="0.3556" width="0.254" layer="94"/>
<wire x1="2.667" y1="0.3556" x2="2.413" y2="0.6096" width="0.254" layer="94"/>
<wire x1="2.413" y1="0.6096" x2="2.794" y2="2.921" width="0.254" layer="94"/>
<wire x1="2.794" y1="2.921" x2="2.9972" y2="3.1242" width="0.254" layer="94"/>
<wire x1="2.8448" y1="-0.0762" x2="3.175" y2="0.254" width="0.254" layer="94"/>
<wire x1="3.175" y1="0.254" x2="5.6642" y2="0.254" width="0.254" layer="94"/>
<wire x1="5.6642" y1="0.254" x2="5.8674" y2="0.0508" width="0.254" layer="94"/>
<wire x1="5.8674" y1="0.0508" x2="5.5626" y2="-0.254" width="0.254" layer="94"/>
<wire x1="5.5626" y1="-0.254" x2="3.0226" y2="-0.254" width="0.254" layer="94"/>
<wire x1="3.0226" y1="-0.254" x2="2.8448" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="2.4892" y1="-0.3302" x2="2.7432" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="2.032" y1="-3.1242" x2="2.3622" y2="-2.794" width="0.254" layer="94"/>
<wire x1="2.3622" y1="-2.794" x2="2.7432" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="2.4892" y1="-0.3302" x2="2.2098" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="2.2098" y1="-0.6096" x2="1.8288" y2="-2.921" width="0.254" layer="94"/>
<wire x1="1.8288" y1="-2.921" x2="2.032" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="2.3368" y1="-3.429" x2="2.5908" y2="-3.175" width="0.254" layer="94"/>
<wire x1="2.5908" y1="-3.175" x2="5.1308" y2="-3.175" width="0.254" layer="94"/>
<wire x1="5.1308" y1="-3.175" x2="5.3848" y2="-3.429" width="0.254" layer="94"/>
<wire x1="5.3848" y1="-3.429" x2="5.1308" y2="-3.683" width="0.254" layer="94"/>
<wire x1="5.1308" y1="-3.683" x2="2.5908" y2="-3.683" width="0.254" layer="94"/>
<wire x1="2.5908" y1="-3.683" x2="2.3368" y2="-3.429" width="0.254" layer="94"/>
<wire x1="6.0198" y1="-0.4064" x2="5.7658" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="5.7658" y1="-0.6604" x2="5.3848" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="5.3848" y1="-2.8194" x2="5.6896" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="5.6896" y1="-3.1242" x2="5.8928" y2="-2.921" width="0.254" layer="94"/>
<wire x1="5.8928" y1="-2.921" x2="6.2738" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="6.2738" y1="-0.6604" x2="6.0198" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="6.604" y1="2.794" x2="6.223" y2="0.635" width="0.4064" layer="94"/>
<wire x1="6.096" y1="3.429" x2="3.556" y2="3.429" width="0.4064" layer="94"/>
<wire x1="3.048" y1="2.794" x2="2.667" y2="0.635" width="0.4064" layer="94"/>
<wire x1="3.048" y1="0" x2="5.588" y2="0" width="0.4064" layer="94"/>
<wire x1="5.969" y1="-0.762" x2="5.588" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-3.429" x2="2.667" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="2.032" y1="-2.921" x2="2.413" y2="-0.635" width="0.4064" layer="94"/>
<circle x="7.239" y="-3.683" radius="0.254" width="0.3048" layer="94"/>
<pin name="P$1" x="-13.462" y="7.62" visible="pad" length="middle"/>
<pin name="P$2" x="-13.462" y="5.08" visible="pad" length="middle"/>
<pin name="P$3" x="-13.462" y="2.54" visible="pad" length="middle"/>
<pin name="P$4" x="-13.462" y="0" visible="pad" length="middle"/>
<pin name="P$5" x="-13.462" y="-2.54" visible="pad" length="middle"/>
<pin name="P$6" x="-13.462" y="-5.08" visible="pad" length="middle"/>
<pin name="P$7" x="-13.462" y="-7.62" visible="pad" length="middle"/>
<pin name="P$8" x="-13.462" y="-10.16" visible="pad" length="middle"/>
<pin name="P$9" x="-13.462" y="-12.7" visible="pad" length="middle"/>
<pin name="P$10" x="14.478" y="-12.7" visible="pad" length="middle" rot="R180"/>
<pin name="P$11" x="14.478" y="-10.16" visible="pad" length="middle" rot="R180"/>
<pin name="P$12" x="14.478" y="-7.62" visible="pad" length="middle" rot="R180"/>
<pin name="P$13" x="14.478" y="-5.08" visible="pad" length="middle" rot="R180"/>
<pin name="P$14" x="14.478" y="-2.54" visible="pad" length="middle" rot="R180"/>
<pin name="P$15" x="14.478" y="0" visible="pad" length="middle" rot="R180"/>
<pin name="P$16" x="14.478" y="2.54" visible="pad" length="middle" rot="R180"/>
<pin name="P$17" x="14.478" y="5.08" visible="pad" length="middle" rot="R180"/>
<pin name="P$18" x="14.478" y="7.62" visible="pad" length="middle" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="WQE23">
<description>niedziela 2021</description>
<gates>
<gate name="G$1" symbol="WQE23" x="-2.54" y="7.62"/>
</gates>
<devices>
<device name="" package="WQE23">
<connects>
<connect gate="G$1" pin="P$1" pad="C1"/>
<connect gate="G$1" pin="P$10" pad="G2"/>
<connect gate="G$1" pin="P$11" pad="A2"/>
<connect gate="G$1" pin="P$12" pad="F2"/>
<connect gate="G$1" pin="P$13" pad="B2"/>
<connect gate="G$1" pin="P$14" pad="B1"/>
<connect gate="G$1" pin="P$15" pad="F1"/>
<connect gate="G$1" pin="P$16" pad="A1"/>
<connect gate="G$1" pin="P$17" pad="G1"/>
<connect gate="G$1" pin="P$18" pad="H1"/>
<connect gate="G$1" pin="P$2" pad="E1"/>
<connect gate="G$1" pin="P$3" pad="D1"/>
<connect gate="G$1" pin="P$4" pad="K1"/>
<connect gate="G$1" pin="P$5" pad="K2"/>
<connect gate="G$1" pin="P$6" pad="D2"/>
<connect gate="G$1" pin="P$7" pad="E2"/>
<connect gate="G$1" pin="P$8" pad="C2"/>
<connect gate="G$1" pin="P$9" pad="H2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
