| Environment Settings | ||
| Environment Variable | xst | ngdbuild |
| PATHEXT | .COM; .EXE; .BAT; .CMD; .VBS; .VBE; .JS; .JSE; .WSF; .WSH; .MSC |
| Path | C:\Xilinx\14.7\ISE_DS\ISE\\lib\nt64; C:\Xilinx\14.7\ISE_DS\ISE\\bin\nt64; C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64; C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64; C:\Xilinx\14.7\ISE_DS\ISE\..\..\..\DocNav; C:\Xilinx\14.7\ISE_DS\PlanAhead\bin; C:\Xilinx\14.7\ISE_DS\EDK\bin\nt64; C:\Xilinx\14.7\ISE_DS\EDK\lib\nt64; C:\Xilinx\14.7\ISE_DS\EDK\gnu\microblaze\nt\bin; C:\Xilinx\14.7\ISE_DS\EDK\gnu\powerpc-eabi\nt\bin; C:\Xilinx\14.7\ISE_DS\EDK\gnuwin\bin; C:\Xilinx\14.7\ISE_DS\EDK\gnu\arm\nt\bin; C:\Xilinx\14.7\ISE_DS\EDK\gnu\microblaze\linux_toolchain\nt64_be\bin; C:\Xilinx\14.7\ISE_DS\EDK\gnu\microblaze\linux_toolchain\nt64_le\bin; C:\Xilinx\14.7\ISE_DS\common\bin\nt64; C:\Xilinx\14.7\ISE_DS\common\lib\nt64; C:\Program Files (x86)\Microchip\xc8\v1.20\bin; C:\Windows\system32; C:\Windows; C:\Windows\System32\Wbem; C:\Windows\System32\WindowsPowerShell\v1.0\; C:\Program Files (x86)\AMD\ATI.ACE\Core-Static; C:\Program Files (x86)\Microchip\xc16\v1.22\bin; C:\Program Files (x86)\Microchip\xc16\v1.41\bin; C:\Program Files (x86)\Microchip\xc32\v2.10\bin; C:\Program Files (x86)\Microchip\xc32\v2.30\bin; C:\Cadence\SPB_16.6\openaccess\bin\win32\opt; C:\Cadence\SPB_16.6\tools\capture; C:\Cadence\SPB_16.6\tools\pspice; C:\Cadence\SPB_16.6\tools\specctra\bin; C:\Cadence\SPB_16.6\tools\fet\bin; C:\Cadence\SPB_16.6\tools\libutil\bin; C:\Cadence\SPB_16.6\tools\bin; C:\Cadence\SPB_16.6\tools\pcb\bin; C:\modeltech64_10.7\win64; C:\modeltech64_10.5\win64; C:\modeltech64_10.1c\win64; C:\modeltech64_10.6d\win64; C:\Modeltech_pe_edu_10.4a\win32pe_edu |
| XILINX | C:\Xilinx\14.7\ISE_DS\ISE\ | C:\Xilinx\14.7\ISE_DS\ISE\ |
| XILINX_DSP | C:\Xilinx\14.7\ISE_DS\ISE | C:\Xilinx\14.7\ISE_DS\ISE |
| XILINX_EDK | C:\Xilinx\14.7\ISE_DS\EDK | C:\Xilinx\14.7\ISE_DS\EDK |
| XILINX_FOR_ALTIUM_OVERRIDE | ||
| XILINX_PLANAHEAD | C:\Xilinx\14.7\ISE_DS\PlanAhead | C:\Xilinx\14.7\ISE_DS\PlanAhead |
| Synthesis Property Settings | |||
| Switch Name | Property Name | Value | Default Value |
| -ifn | CPLDLED.prj | ||
| -ifmt | mixed | MIXED | |
| -ofn | CPLDLED | ||
| -ofmt | NGC | NGC | |
| -p | xc9500xl | ||
| -top | CPLDLED | ||
| -opt_mode | Optimization Goal | Speed | SPEED |
| -opt_level | Optimization Effort | 1 | 1 |
| -iuc | Use synthesis Constraints File | NO | NO |
| -keep_hierarchy | Keep Hierarchy | Yes | YES |
| -netlist_hierarchy | Netlist Hierarchy | As_Optimized | as_optimized |
| -rtlview | Generate RTL Schematic | Yes | NO |
| -bus_delimiter | Bus Delimiter | <> | <> |
| -verilog2001 | Verilog 2001 | YES | YES |
| -fsm_extract | YES | YES | |
| -fsm_encoding | Auto | AUTO | |
| -safe_implementation | No | NO | |
| -resource_sharing | YES | YES | |
| -iobuf | YES | YES | |
| -equivalent_register_removal | YES | YES | |
| Translation Property Settings | |||
| -intstyle | ise | None | |
| -dd | _ngo | None | |
| -p | xc9536xl-VQ44-5 | None | |
| -uc | PIN.ucf | None | |
| Operating System Information | ||
| Operating System Information | xst | ngdbuild |
| CPU Architecture/Speed | AMD A10-6800K APU with Radeon(tm) HD Graphics /4089 MHz | AMD A10-6800K APU with Radeon(tm) HD Graphics /4089 MHz |
| Host | DR-PC | DR-PC |
| OS Name | Microsoft Windows 7 , 64-bit | Microsoft Windows 7 , 64-bit |
| OS Release | Service Pack 1 (build 7601) | Service Pack 1 (build 7601) |
