| Option | Value |
| Device(s) Specified | xc9536xl-5-VQ44 |
| Optimization Method | SPEED |
| Multi-Level Logic Optimization | ON |
| Ignore Timing Specifications | OFF |
| Default Register Power Up Value | LOW |
| Slew Rate | FAST |
| Keep User Location Constraints | ON |
| What-You-See-Is-What-You-Get | OFF |
| Exhaustive Fitting | OFF |
| Keep Unused Inputs | OFF |
| Power Mode | STD |
| Ground on Unused IOs | OFF |
| Global Clock Optimization | ON |
| Global Set/Reset Optimization | ON |
| Global Ouput Enable Optimization | ON |
| Set I/O Pin Termination | KEEPER |
| Input Limit (2-54) | 54 |
| Pterm Limit (1-90) | 25 |
