Timing Report
Need help reading this report?
Design Name CPLDLED
Device, Speed (SpeedFile Version) XC9536XL, -5 (3.0)
Date Created Sun May 23 11:20:43 2021
Created By Timing Report Generator: version P.20131013
Copyright Copyright (c) 1995-2013 Xilinx, Inc. All rights reserved.
Summary
Notes and Warnings
Note: This design contains no timing constraints.
Note: A default set of constraints using a delay of 0.000ns will be used for analysis.
Performance Summary
Pad to Pad Delay (tPD) 5.000 ns.
Timing Constraints
Constraint Name Requirement (ns) Delay (ns) Paths Paths Failing
AUTO_TS_F2F 0.0 0.0 0 0
AUTO_TS_P2P 0.0 5.0 1 1
AUTO_TS_P2F 0.0 0.0 0 0
AUTO_TS_F2P 0.0 0.0 0 0
Constraint: AUTO_TS_F2F
Description: MAXDELAY:FROM:FFS(*):TO:FFS(*):0.000 nS
Path Requirement (ns) Delay (ns) Slack (ns)
Constraint: AUTO_TS_P2P
Description: MAXDELAY:FROM:PADS(*):TO:PADS(*):0.000 nS
CLK to OUTLED 0.000 5.000 -5.000
Constraint: AUTO_TS_P2F
Description: MAXDELAY:FROM:PADS(*):TO:FFS(*):0.000 nS
Constraint: AUTO_TS_F2P
Description: MAXDELAY:FROM:FFS(*):TO:PADS(*):0.000 nS
Number of constraints not met: 1
Data Sheet Report
Pad to Pad List
Source Pad Destination Pad Delay
CLK OUTLED 5.000
Number of paths analyzed: 1
Number of Timing errors: 1
Analysis Completed: Sun May 23 11:20:43 2021
