cpldfit:  version P.20131013                        Xilinx Inc.
                                  Fitter Report
Design Name: slow_counter                        Date:  5-24-2021, 11:52AM
Device Used: XC9536XL-5-VQ44
Fitting Status: Successful
*************************  Mapped Resource Summary  **************************
Macrocells     Product Terms    Function Block   Registers      Pins
Used/Tot       Used/Tot         Inps Used/Tot    Used/Tot       Used/Tot
34 /36  ( 94%) 97  /180  ( 54%) 53 /108 ( 49%)   27 /36  ( 75%) 8  /34  ( 24%)
** Function Block Resources **
Function    Mcells      FB Inps     Pterms      IO
Block       Used/Tot    Used/Tot    Used/Tot    Used/Tot
FB1          18/18*      28/54       62/90       6/17
FB2          16/18       25/54       35/90       2/17
             34/36       53/108      97/180      8/34
* - Resource is exhausted
** Global Control Resources **
Global clock net(s) unused.
Global output enable net(s) unused.
Global set/reset net(s) unused.
** Pin Resources **
Signal Type    Required     Mapped  |  Pin Type            Used    Total
Input         :    1           1    |  I/O              :     6      28
Output        :    7           7    |  GCK/IO           :     2       3
Bidirectional :    0           0    |  GTS/IO           :     0       2
GCK           :    0           0    |  GSR/IO           :     0       1
GTS           :    0           0    |
GSR           :    0           0    |
        Total      8           8
** Power Data **
There are 34 macrocells in high performance mode (MCHP).
There are 0 macrocells in low power mode (MCLP).
End of Mapped Resource Summary
**************************  Errors and Warnings  ***************************
WARNING:Cpld - Unable to retrieve the path to the iSE Project Repository. Will
   use the default filename of 'slow_counter.ise'.
*************************  Summary of Mapped Logic  ************************
** 7 Outputs **
Signal              Total Total Loc     Pin  Pin     Pin     Pwr  Slew Reg Init
Name                Pts   Inps          No.  Type    Use     Mode Rate State
ssd<4>              2     4     FB1_1   40~  I/O     O       STD  FAST
ssd<3>              5     4     FB1_2   41~  I/O     O       STD  FAST
ssd<1>              4     4     FB1_3   43~  GCK/I/O O       STD  FAST
ssd<2>              3     4     FB1_4   42~  I/O     O       STD  FAST
ssd<0>              4     4     FB1_5   44~  GCK/I/O O       STD  FAST
ssd<5>              4     4     FB2_1   39~  I/O     O       STD  FAST
ssd<6>              4     4     FB2_2   38~  I/O     O       STD  FAST
** 27 Buried Nodes **
Signal              Total Total Loc     Pwr  Reg Init
Name                Pts   Inps          Mode State
counter2<0>         2     24    FB1_6   STD  RESET
counter1<21>        2     22    FB1_7   STD  RESET
counter2<2>         3     26    FB1_8   STD  RESET
counter1<9>         3     24    FB1_9   STD  RESET
counter1<8>         3     24    FB1_10  STD  RESET
counter1<22>        3     24    FB1_11  STD  RESET
counter1<19>        3     24    FB1_12  STD  RESET
counter1<18>        3     24    FB1_13  STD  RESET
counter1<14>        3     24    FB1_14  STD  RESET
counter1<11>        3     24    FB1_15  STD  RESET
counter2<3>         4     28    FB1_16  STD  RESET
counter2<1>         4     28    FB1_17  STD  RESET
counter1<6>         8     24    FB1_18  STD  RESET
counter1<0>         1     1     FB2_5   STD  RESET
counter1<7>         2     8     FB2_6   STD  RESET
counter1<5>         2     6     FB2_7   STD  RESET
counter1<4>         2     5     FB2_8   STD  RESET
counter1<3>         2     4     FB2_9   STD  RESET
counter1<2>         2     3     FB2_10  STD  RESET
counter1<20>        2     21    FB2_11  STD  RESET
counter1<1>         2     2     FB2_12  STD  RESET
counter1<17>        2     18    FB2_13  STD  RESET
counter1<16>        2     17    FB2_14  STD  RESET
counter1<15>        2     16    FB2_15  STD  RESET
counter1<13>        2     14    FB2_16  STD  RESET
counter1<12>        2     13    FB2_17  STD  RESET
counter1<10>        2     11    FB2_18  STD  RESET
** 1 Inputs **
Signal              Loc     Pin  Pin     Pin
Name                        No.  Type    Use
clk                 FB1_9   5~   I/O     I
Legend:
Pin No. - ~ - User Assigned
**************************  Function Block Details  ************************
Legend:
Total Pt     - Total product terms used by the macrocell signal
Imp Pt       - Product terms imported from other macrocells
Exp Pt       - Product terms exported to other macrocells
               in direction shown
Unused Pt    - Unused local product terms remaining in macrocell
Loc          - Location where logic was mapped in device
Pin Type/Use - I  - Input             GCK - Global Clock
               O  - Output            GTS - Global Output Enable
              (b) - Buried macrocell  GSR - Global Set/Reset
X            - Signal used as input to the macrocell logic.
*********************************** FB1  ***********************************
Number of function block inputs used/remaining:               28/26
Number of signals used by logic mapping into function block:  28
Signal              Total   Imp   Exp Unused  Loc     Pin   Pin     Pin
Name                Pt      Pt    Pt  Pt               #    Type    Use
ssd<4>                2       0   /\2   1     FB1_1   40~   I/O     O
ssd<3>                5       0     0   0     FB1_2   41~   I/O     O
ssd<1>                4       0     0   1     FB1_3   43~   GCK/I/O O
ssd<2>                3       0     0   2     FB1_4   42~   I/O     O
ssd<0>                4       0     0   1     FB1_5   44~   GCK/I/O O
counter2<0>           2       0     0   3     FB1_6   2     I/O     (b)
counter1<21>          2       0     0   3     FB1_7   1     GCK/I/O (b)
counter2<2>           3       0     0   2     FB1_8   3     I/O     (b)
counter1<9>           3       0     0   2     FB1_9   5     I/O     I
counter1<8>           3       0     0   2     FB1_10  6     I/O     (b)
counter1<22>          3       0     0   2     FB1_11  7     I/O     (b)
counter1<19>          3       0     0   2     FB1_12  8     I/O     (b)
counter1<18>          3       0     0   2     FB1_13  12    I/O     (b)
counter1<14>          3       0     0   2     FB1_14  13    I/O     (b)
counter1<11>          3       0     0   2     FB1_15  14    I/O     (b)
counter2<3>           4       0     0   1     FB1_16  16    I/O     (b)
counter2<1>           4       0   \/1   0     FB1_17  18    I/O     (b)
counter1<6>           8       3<-   0   0     FB1_18        (b)     (b)
Signals Used by Logic in Function Block
  1: clk               11: counter1<18>      20: counter1<5>
  2: counter1<0>       12: counter1<19>      21: counter1<6>
  3: counter1<10>      13: counter1<1>       22: counter1<7>
  4: counter1<11>      14: counter1<20>      23: counter1<8>
  5: counter1<12>      15: counter1<21>      24: counter1<9>
  6: counter1<13>      16: counter1<22>      25: counter2<0>
  7: counter1<14>      17: counter1<2>       26: counter2<1>
  8: counter1<15>      18: counter1<3>       27: counter2<2>
  9: counter1<16>      19: counter1<4>       28: counter2<3>
 10: counter1<17>
Signal                        1         2         3         4 FB
Name                0----+----0----+----0----+----0----+----0 Inputs
ssd<4>               ........................XXXX............ 4
ssd<3>               ........................XXXX............ 4
ssd<1>               ........................XXXX............ 4
ssd<2>               ........................XXXX............ 4
ssd<0>               ........................XXXX............ 4
counter2<0>          XXXXXXXXXXXXXXXXXXXXXXXX................ 24
counter1<21>         XXXXXXXXXXXXXX..XXXXXXXX................ 22
counter2<2>          XXXXXXXXXXXXXXXXXXXXXXXXXX.............. 26
counter1<9>          XXXXXXXXXXXXXXXXXXXXXXXX................ 24
counter1<8>          XXXXXXXXXXXXXXXXXXXXXXXX................ 24
counter1<22>         XXXXXXXXXXXXXXXXXXXXXXXX................ 24
counter1<19>         XXXXXXXXXXXXXXXXXXXXXXXX................ 24
counter1<18>         XXXXXXXXXXXXXXXXXXXXXXXX................ 24
counter1<14>         XXXXXXXXXXXXXXXXXXXXXXXX................ 24
counter1<11>         XXXXXXXXXXXXXXXXXXXXXXXX................ 24
counter2<3>          XXXXXXXXXXXXXXXXXXXXXXXXXXXX............ 28
counter2<1>          XXXXXXXXXXXXXXXXXXXXXXXXXXXX............ 28
counter1<6>          XXXXXXXXXXXXXXXXXXXXXXXX................ 24
                    0----+----1----+----2----+----3----+----4
                              0         0         0         0
*********************************** FB2  ***********************************
Number of function block inputs used/remaining:               25/29
Number of signals used by logic mapping into function block:  25
ssd<5>                4       0     0   1     FB2_1   39~   I/O     O
ssd<6>                4       0     0   1     FB2_2   38~   I/O     O
(unused)              0       0     0   5     FB2_3   36    GTS/I/O
(unused)              0       0     0   5     FB2_4   37    I/O
counter1<0>           1       0     0   4     FB2_5   34    GTS/I/O (b)
counter1<7>           2       0     0   3     FB2_6   33    GSR/I/O (b)
counter1<5>           2       0     0   3     FB2_7   32    I/O     (b)
counter1<4>           2       0     0   3     FB2_8   31    I/O     (b)
counter1<3>           2       0     0   3     FB2_9   30    I/O     (b)
counter1<2>           2       0     0   3     FB2_10  29    I/O     (b)
counter1<20>          2       0     0   3     FB2_11  28    I/O     (b)
counter1<1>           2       0     0   3     FB2_12  27    I/O     (b)
counter1<17>          2       0     0   3     FB2_13  23    I/O     (b)
counter1<16>          2       0     0   3     FB2_14  22    I/O     (b)
counter1<15>          2       0     0   3     FB2_15  21    I/O     (b)
counter1<13>          2       0     0   3     FB2_16  20    I/O     (b)
counter1<12>          2       0     0   3     FB2_17  19    I/O     (b)
counter1<10>          2       0     0   3     FB2_18        (b)     (b)
  1: clk               10: counter1<17>      18: counter1<6>
  2: counter1<0>       11: counter1<18>      19: counter1<7>
  3: counter1<10>      12: counter1<19>      20: counter1<8>
  4: counter1<11>      13: counter1<1>       21: counter1<9>
  5: counter1<12>      14: counter1<2>       22: counter2<0>
  6: counter1<13>      15: counter1<3>       23: counter2<1>
  7: counter1<14>      16: counter1<4>       24: counter2<2>
  8: counter1<15>      17: counter1<5>       25: counter2<3>
  9: counter1<16>
Signal                        1         2         3         4 FB
ssd<5>               .....................XXXX............... 4
ssd<6>               .....................XXXX............... 4
counter1<0>          X....................................... 1
counter1<7>          XX..........XXXXXX...................... 8
counter1<5>          XX..........XXXX........................ 6
counter1<4>          XX..........XXX......................... 5
counter1<3>          XX..........XX.......................... 4
counter1<2>          XX..........X........................... 3
counter1<20>         XXXXXXXXXXXXXXXXXXXXX................... 21
counter1<1>          XX...................................... 2
counter1<17>         XXXXXXXXX...XXXXXXXXX................... 18
counter1<16>         XXXXXXXX....XXXXXXXXX................... 17
counter1<15>         XXXXXXX.....XXXXXXXXX................... 16
counter1<13>         XXXXX.......XXXXXXXXX................... 14
counter1<12>         XXXX........XXXXXXXXX................... 13
counter1<10>         XX..........XXXXXXXXX................... 11
                              0         0         0         0
*******************************  Equations  ********************************
********** Mapped Logic **********
FTCPE_counter10: FTCPE port map (counter1(0),'1',clk,'0','0');
FTCPE_counter11: FTCPE port map (counter1(1),counter1(0),clk,'0','0');
FTCPE_counter12: FTCPE port map (counter1(2),counter1_T(2),clk,'0','0');
counter1_T(2) <= (counter1(0) AND counter1(1));
FTCPE_counter13: FTCPE port map (counter1(3),counter1_T(3),clk,'0','0');
counter1_T(3) <= (counter1(0) AND counter1(1) AND counter1(2));
FTCPE_counter14: FTCPE port map (counter1(4),counter1_T(4),clk,'0','0');
counter1_T(4) <= (counter1(0) AND counter1(1) AND counter1(2) AND
	counter1(3));
FTCPE_counter15: FTCPE port map (counter1(5),counter1_T(5),clk,'0','0');
counter1_T(5) <= (counter1(0) AND counter1(1) AND counter1(2) AND
	counter1(3) AND counter1(4));
FTCPE_counter16: FTCPE port map (counter1(6),counter1_T(6),clk,'0','0');
counter1_T(6) <= ((NOT counter1(0))
	OR (NOT counter1(1))
	OR (NOT counter1(2))
	OR (NOT counter1(3))
	OR (NOT counter1(5))
	OR (NOT counter1(10) AND counter1(11) AND NOT counter1(12) AND
	NOT counter1(13) AND counter1(14) AND NOT counter1(15) AND NOT counter1(16) AND
	NOT counter1(17) AND counter1(18) AND counter1(19) AND NOT counter1(20) AND
	NOT counter1(21) AND NOT counter1(6) AND NOT counter1(7) AND counter1(8) AND
	counter1(9) AND counter1(22))
	OR (NOT counter1(4)));
FTCPE_counter17: FTCPE port map (counter1(7),counter1_T(7),clk,'0','0');
counter1_T(7) <= (counter1(0) AND counter1(1) AND counter1(2) AND
	counter1(3) AND counter1(4) AND counter1(5) AND counter1(6));
FTCPE_counter18: FTCPE port map (counter1(8),counter1_T(8),clk,'0','0');
counter1_T(8) <= ((counter1(0) AND counter1(1) AND counter1(2) AND
	counter1(3) AND counter1(4) AND counter1(5) AND counter1(6) AND
	counter1(7))
	OR (counter1(0) AND NOT counter1(10) AND counter1(11) AND
	NOT counter1(12) AND NOT counter1(13) AND counter1(14) AND NOT counter1(15) AND
	NOT counter1(16) AND NOT counter1(17) AND counter1(18) AND counter1(19) AND
	counter1(1) AND NOT counter1(20) AND NOT counter1(21) AND counter1(2) AND
	counter1(3) AND counter1(4) AND counter1(5) AND NOT counter1(6) AND
	NOT counter1(7) AND counter1(8) AND counter1(9) AND counter1(22)));
FTCPE_counter19: FTCPE port map (counter1(9),counter1_T(9),clk,'0','0');
counter1_T(9) <= ((counter1(0) AND counter1(1) AND counter1(2) AND
	counter1(7) AND counter1(8))
FTCPE_counter110: FTCPE port map (counter1(10),counter1_T(10),clk,'0','0');
counter1_T(10) <= (counter1(0) AND counter1(1) AND counter1(2) AND
	counter1(7) AND counter1(8) AND counter1(9));
FTCPE_counter111: FTCPE port map (counter1(11),counter1_T(11),clk,'0','0');
counter1_T(11) <= ((counter1(0) AND counter1(10) AND counter1(1) AND
	counter1(2) AND counter1(3) AND counter1(4) AND counter1(5) AND
	counter1(6) AND counter1(7) AND counter1(8) AND counter1(9))
FTCPE_counter112: FTCPE port map (counter1(12),counter1_T(12),clk,'0','0');
counter1_T(12) <= (counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(1) AND counter1(2) AND counter1(3) AND counter1(4) AND
	counter1(5) AND counter1(6) AND counter1(7) AND counter1(8) AND
	counter1(9));
FTCPE_counter113: FTCPE port map (counter1(13),counter1_T(13),clk,'0','0');
counter1_T(13) <= (counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(12) AND counter1(1) AND counter1(2) AND counter1(3) AND
	counter1(4) AND counter1(5) AND counter1(6) AND counter1(7) AND
FTCPE_counter114: FTCPE port map (counter1(14),counter1_T(14),clk,'0','0');
counter1_T(14) <= ((counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(12) AND counter1(13) AND counter1(1) AND counter1(2) AND
FTCPE_counter115: FTCPE port map (counter1(15),counter1_T(15),clk,'0','0');
counter1_T(15) <= (counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(12) AND counter1(13) AND counter1(14) AND counter1(1) AND
	counter1(6) AND counter1(7) AND counter1(8) AND counter1(9));
FTCPE_counter116: FTCPE port map (counter1(16),counter1_T(16),clk,'0','0');
counter1_T(16) <= (counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(12) AND counter1(13) AND counter1(14) AND counter1(15) AND
	counter1(9));
FTCPE_counter117: FTCPE port map (counter1(17),counter1_T(17),clk,'0','0');
counter1_T(17) <= (counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(16) AND counter1(1) AND counter1(2) AND counter1(3) AND
FTCPE_counter118: FTCPE port map (counter1(18),counter1_T(18),clk,'0','0');
counter1_T(18) <= ((counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(16) AND counter1(17) AND counter1(1) AND counter1(2) AND
FTCPE_counter119: FTCPE port map (counter1(19),counter1_T(19),clk,'0','0');
counter1_T(19) <= ((counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(16) AND counter1(17) AND counter1(18) AND counter1(1) AND
FTCPE_counter120: FTCPE port map (counter1(20),counter1_T(20),clk,'0','0');
counter1_T(20) <= (counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(16) AND counter1(17) AND counter1(18) AND counter1(19) AND
	counter1(9));
FTCPE_counter121: FTCPE port map (counter1(21),counter1_T(21),clk,'0','0');
counter1_T(21) <= (counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(1) AND counter1(20) AND counter1(2) AND counter1(3) AND
FTCPE_counter122: FTCPE port map (counter1(22),counter1_T(22),clk,'0','0');
counter1_T(22) <= ((counter1(0) AND counter1(10) AND counter1(11) AND
	counter1(1) AND counter1(20) AND counter1(21) AND counter1(2) AND
FTCPE_counter20: FTCPE port map (counter2(0),'1',clk,'0','0',counter2_CE(0));
counter2_CE(0) <= (counter1(0) AND NOT counter1(10) AND counter1(11) AND
	NOT counter1(7) AND counter1(8) AND counter1(9) AND counter1(22));
FTCPE_counter21: FTCPE port map (counter2(1),counter2_T(1),clk,'0','0',counter2_CE(1));
counter2_T(1) <= ((NOT counter2(0))
	OR (NOT counter2(1) AND NOT counter2(2) AND counter2(3) AND
	counter1(0) AND NOT counter1(10) AND counter1(11) AND NOT counter1(12) AND
	NOT counter1(17) AND counter1(18) AND counter1(19) AND counter1(1) AND
	NOT counter1(20) AND NOT counter1(21) AND counter1(2) AND counter1(3) AND
	counter1(4) AND counter1(5) AND NOT counter1(6) AND NOT counter1(7) AND
counter2_CE(1) <= (counter1(0) AND NOT counter1(10) AND counter1(11) AND
FTCPE_counter22: FTCPE port map (counter2(2),counter2_T(2),clk,'0','0',counter2_CE(2));
counter2_T(2) <= (counter2(1) AND counter2(0));
counter2_CE(2) <= (counter1(0) AND NOT counter1(10) AND counter1(11) AND
FTCPE_counter23: FTCPE port map (counter2(3),counter2_T(3),clk,'0','0',counter2_CE(3));
counter2_T(3) <= ((counter2(1) AND counter2(2) AND counter2(0))
	OR (NOT counter2(1) AND NOT counter2(2) AND counter2(0) AND
	counter2(3) AND counter1(0) AND NOT counter1(10) AND counter1(11) AND
counter2_CE(3) <= (counter1(0) AND NOT counter1(10) AND counter1(11) AND
ssd(0) <= ((counter2(1) AND NOT counter2(3))
	OR (NOT counter2(1) AND NOT counter2(2) AND counter2(3))
	OR (counter2(2) AND counter2(0) AND NOT counter2(3))
	OR (NOT counter2(2) AND NOT counter2(0) AND NOT counter2(3)));
ssd(1) <= ((NOT counter2(1) AND NOT counter2(2))
	OR (NOT counter2(2) AND NOT counter2(3))
	OR (counter2(1) AND counter2(0) AND NOT counter2(3))
	OR (NOT counter2(1) AND NOT counter2(0) AND NOT counter2(3)));
ssd(2) <= ((NOT counter2(1) AND NOT counter2(2))
	OR (counter2(2) AND NOT counter2(3))
	OR (counter2(0) AND NOT counter2(3)));
ssd(3) <= ((counter2(1) AND NOT counter2(2) AND NOT counter2(3))
	OR (counter2(1) AND NOT counter2(0) AND NOT counter2(3))
	OR (NOT counter2(1) AND counter2(2) AND counter2(0) AND
	NOT counter2(3)));
ssd(4) <= ((counter2(1) AND NOT counter2(0) AND NOT counter2(3))
	OR (NOT counter2(1) AND NOT counter2(2) AND NOT counter2(0)));
ssd(5) <= ((NOT counter2(1) AND counter2(2) AND NOT counter2(3))
	OR (counter2(2) AND NOT counter2(0) AND NOT counter2(3)));
ssd(6) <= ((counter2(1) AND NOT counter2(2) AND NOT counter2(3))
	OR (NOT counter2(1) AND counter2(2) AND NOT counter2(3))
Register Legend:
 FDCPE (Q,D,C,CLR,PRE,CE);
 FTCPE (Q,D,C,CLR,PRE,CE);
 LDCP  (Q,D,G,CLR,PRE);
******************************  Device Pin Out *****************************
Device : XC9536XL-5-VQ44
  /44 43 42 41 40 39 38 37 36 35 34 \
 | 1                             33 |
 | 2                             32 |
 | 3                             31 |
 | 4                             30 |
 | 5         XC9536XL-5-VQ44     29 |
 | 6                             28 |
 | 7                             27 |
 | 8                             26 |
 | 9                             25 |
 | 10                            24 |
 | 11                            23 |
 \ 12 13 14 15 16 17 18 19 20 21 22 /
Pin Signal                         Pin Signal
No. Name                           No. Name
  1 KPR                              23 KPR
  2 KPR                              24 TDO
  3 KPR                              25 GND
  4 GND                              26 VCC
  5 clk                              27 KPR
  6 KPR                              28 KPR
  7 KPR                              29 KPR
  8 KPR                              30 KPR
  9 TDI                              31 KPR
 10 TMS                              32 KPR
 11 TCK                              33 KPR
 12 KPR                              34 KPR
 13 KPR                              35 VCC
 14 KPR                              36 KPR
 15 VCC                              37 KPR
 16 KPR                              38 ssd<6>
 17 GND                              39 ssd<5>
 18 KPR                              40 ssd<4>
 19 KPR                              41 ssd<3>
 20 KPR                              42 ssd<2>
 21 KPR                              43 ssd<1>
 22 KPR                              44 ssd<0>
Legend :  NC  = Not Connected, unbonded pin
         PGND = Unused I/O configured as additional Ground pin
         TIE  = Unused I/O floating -- must tie to VCC, GND or other signal
         KPR  = Unused I/O with weak keeper (leave unconnected)
         VCC  = Dedicated Power Pin
         GND  = Dedicated Ground Pin
         TDI  = Test Data In, JTAG pin
         TDO  = Test Data Out, JTAG pin
         TCK  = Test Clock, JTAG pin
         TMS  = Test Mode Select, JTAG pin
  PROHIBITED  = User reserved pin
****************************  Compiler Options  ****************************
Following is a list of all global compiler options used by the fitter run.
Device(s) Specified                         : xc9536xl-5-VQ44
Optimization Method                         : SPEED
Multi-Level Logic Optimization              : ON
Ignore Timing Specifications                : OFF
Default Register Power Up Value             : LOW
Keep User Location Constraints              : ON
What-You-See-Is-What-You-Get                : OFF
Exhaustive Fitting                          : OFF
Keep Unused Inputs                          : OFF
Slew Rate                                   : FAST
Power Mode                                  : STD
Ground on Unused IOs                        : OFF
Set I/O Pin Termination                     : KEEPER
Global Clock Optimization                   : ON
Global Set/Reset Optimization               : ON
Global Ouput Enable Optimization            : ON
Input Limit                                 : 54
Pterm Limit                                 : 25
