<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="7" fill="1" visible="yes" active="yes"/>
<layer number="251" name="SMDround" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="MICROSD_MICROSD">
<wire x1="-7.3" y1="7.2" x2="-7.3" y2="5.9" width="0.127" layer="51"/>
<wire x1="-7.3" y1="5.9" x2="-6.2" y2="5.9" width="0.127" layer="51"/>
<wire x1="-6.2" y1="5.9" x2="-6.2" y2="5.4" width="0.127" layer="51"/>
<wire x1="-6.2" y1="5.4" x2="-7.3" y2="5.4" width="0.127" layer="51"/>
<wire x1="-7.3" y1="5.4" x2="-7.3" y2="-8" width="0.127" layer="51"/>
<wire x1="-7.3" y1="-8" x2="-1.8" y2="-8" width="0.127" layer="51"/>
<wire x1="-1.8" y1="-8" x2="-1.8" y2="-7" width="0.127" layer="51"/>
<wire x1="-1.8" y1="-7" x2="-1.5" y2="-7" width="0.127" layer="51"/>
<wire x1="-1.5" y1="-7" x2="-1.5" y2="-8" width="0.127" layer="51"/>
<wire x1="-1.5" y1="-8" x2="-0.1" y2="-8" width="0.127" layer="51"/>
<wire x1="-0.1" y1="-8" x2="-0.1" y2="-7" width="0.127" layer="51"/>
<wire x1="-0.1" y1="-7" x2="0.3" y2="-7" width="0.127" layer="51"/>
<wire x1="0.3" y1="-7" x2="0.3" y2="-8" width="0.127" layer="51"/>
<wire x1="0.3" y1="-8" x2="3.8" y2="-8" width="0.127" layer="51"/>
<wire x1="3.8" y1="-8" x2="3.8" y2="-7" width="0.127" layer="51"/>
<wire x1="3.8" y1="-7" x2="4.1" y2="-7" width="0.127" layer="51"/>
<wire x1="4.1" y1="-7" x2="4.1" y2="-8" width="0.127" layer="51"/>
<wire x1="4.1" y1="-8" x2="5.6" y2="-8" width="0.127" layer="51"/>
<wire x1="5.6" y1="-8" x2="5.6" y2="-7" width="0.127" layer="51"/>
<wire x1="5.6" y1="-7" x2="6" y2="-7" width="0.127" layer="51"/>
<wire x1="6" y1="-7" x2="6" y2="-8" width="0.127" layer="51"/>
<wire x1="6" y1="-8" x2="7" y2="-8" width="0.127" layer="51"/>
<wire x1="7" y1="-8" x2="7" y2="6.3" width="0.127" layer="51"/>
<wire x1="7" y1="6.3" x2="6.5" y2="6.3" width="0.127" layer="51"/>
<wire x1="-7.3" y1="7.2" x2="-5" y2="7.2" width="0.127" layer="51"/>
<wire x1="-5" y1="7.2" x2="-5" y2="6.5" width="0.127" layer="51"/>
<wire x1="-5" y1="6.5" x2="6.4" y2="6.2" width="0.127" layer="51" curve="57.449475"/>
<wire x1="6.4" y1="6.2" x2="6.5" y2="6.3" width="0.127" layer="51"/>
<wire x1="-4.9" y1="6.4" x2="-4.9" y2="8.1597" width="0" layer="51"/>
<wire x1="-4.2597" y1="8.8" x2="-4.9" y2="8.1597" width="0" layer="51" curve="90"/>
<wire x1="-4.2597" y1="8.8" x2="5.6929" y2="8.8" width="0" layer="51"/>
<wire x1="6.4" y1="8.0929" x2="5.6929" y2="8.8" width="0" layer="51" curve="89.983796"/>
<wire x1="6.4" y1="8.0929" x2="6.4" y2="6.3" width="0" layer="51"/>
<wire x1="-4.9" y1="8.6" x2="-4.9" y2="11.9597" width="0" layer="51"/>
<wire x1="-4.2597" y1="12.6" x2="-4.9" y2="11.9597" width="0" layer="51" curve="90"/>
<wire x1="-4.2597" y1="12.6" x2="5.6929" y2="12.6" width="0" layer="51"/>
<wire x1="6.4" y1="11.8929" x2="5.6929" y2="12.6" width="0" layer="51" curve="89.983796"/>
<wire x1="6.4" y1="11.8929" x2="6.4" y2="8.4" width="0" layer="51"/>
<wire x1="-7.3" y1="4.9" x2="-7.3" y2="-8" width="0.127" layer="21"/>
<wire x1="-7.3" y1="-8" x2="-2.05" y2="-8" width="0.127" layer="21"/>
<wire x1="6.125" y1="-8" x2="7" y2="-8" width="0.127" layer="21"/>
<wire x1="7" y1="-8" x2="7" y2="3.8" width="0.127" layer="21"/>
<wire x1="0.425" y1="-8" x2="3.675" y2="-8" width="0.127" layer="21"/>
<wire x1="-5" y1="6.5" x2="5.4614" y2="5.7728" width="0.127" layer="21" curve="57.453442"/>
<smd name="1" x="-1.94" y="2.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="2" x="-0.84" y="2.3" dx="0.8" dy="1.5" layer="1"/>
<smd name="3" x="0.26" y="2.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="4" x="1.36" y="2.9" dx="0.8" dy="1.5" layer="1"/>
<smd name="5" x="2.46" y="2.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="3.56" y="2.9" dx="0.8" dy="1.5" layer="1"/>
<smd name="7" x="4.66" y="2.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="8" x="5.76" y="2.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="NC" x="-6.85" y="6.55" dx="1.4" dy="1.9" layer="1"/>
<smd name="NC1" x="-0.75" y="-7.6" dx="1.8" dy="1.4" layer="1"/>
<smd name="NC2" x="4.95" y="-7.6" dx="1.8" dy="1.4" layer="1"/>
<smd name="NC3" x="6.55" y="5.55" dx="1.4" dy="1.9" layer="1"/>
<text x="-0.7" y="7.8" size="0.8128" layer="51">card IN</text>
<text x="-1.3" y="11.6" size="0.8128" layer="51">card OUT</text>
<text x="-5.08" y="-3.81" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="MICROSD_MICROSD_CARD">
<wire x1="0" y1="0" x2="0" y2="2" width="0.127" layer="21"/>
<wire x1="0" y1="2" x2="0" y2="15" width="0.127" layer="21"/>
<wire x1="0" y1="15" x2="9.6" y2="15" width="0.127" layer="51"/>
<wire x1="9.6" y1="15" x2="9.6" y2="10.1" width="0.127" layer="21"/>
<wire x1="9.6" y1="10.1" x2="10.9" y2="8.8" width="0.127" layer="21"/>
<wire x1="10.9" y1="8.8" x2="10.9" y2="2" width="0.127" layer="21"/>
<wire x1="10.9" y1="2" x2="10.9" y2="0" width="0.127" layer="21"/>
<wire x1="10.9" y1="0" x2="0" y2="0" width="0.127" layer="21"/>
<wire x1="0" y1="2" x2="10.9" y2="2" width="0.127" layer="21"/>
<smd name="1" x="8.8" y="13" dx="0.8" dy="4" layer="1"/>
<smd name="2" x="7.7" y="13" dx="0.8" dy="4" layer="1"/>
<smd name="3" x="6.5" y="13" dx="0.8" dy="4" layer="1"/>
<smd name="4" x="5.4" y="13.1" dx="0.8" dy="4.2" layer="1"/>
<smd name="5" x="4.3" y="13" dx="0.8" dy="4" layer="1"/>
<smd name="6" x="3.2" y="13.1" dx="0.8" dy="4.2" layer="1"/>
<smd name="7" x="2" y="13" dx="0.8" dy="4" layer="1"/>
<smd name="8" x="0.9" y="13" dx="0.8" dy="4" layer="1"/>
<text x="1.27" y="6.35" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="SDCMF-10915W010">
<wire x1="-12.7" y1="12.7" x2="11.684" y2="12.7" width="0.127" layer="21"/>
<wire x1="-12.7" y1="12.7" x2="-12.7" y2="-3.556" width="0.127" layer="21"/>
<wire x1="-12.7" y1="-3.556" x2="-11.43" y2="-3.556" width="0.127" layer="21"/>
<wire x1="-11.43" y1="-3.556" x2="12.192" y2="-3.556" width="0.127" layer="20"/>
<wire x1="12.192" y1="-3.556" x2="13.462" y2="-3.556" width="0.127" layer="21"/>
<wire x1="13.462" y1="-3.556" x2="13.462" y2="5.334" width="0.127" layer="21"/>
<wire x1="11.684" y1="12.7" x2="11.684" y2="7.62" width="0.127" layer="21"/>
<wire x1="11.684" y1="7.62" x2="13.462" y2="5.334" width="0.127" layer="21"/>
<wire x1="-11.43" y1="-12.192" x2="-11.43" y2="-11.684" width="0.127" layer="21"/>
<wire x1="-11.43" y1="-3.556" x2="-11.43" y2="-23.368" width="0.127" layer="21"/>
<wire x1="-11.43" y1="-23.368" x2="12.192" y2="-23.368" width="0.127" layer="21"/>
<wire x1="12.192" y1="-23.368" x2="12.192" y2="-3.556" width="0.127" layer="21"/>
<smd name="M4" x="-13.208" y="11.43" dx="2.54" dy="1.27" layer="1" rot="R90"/>
<smd name="M3" x="-13.208" y="-2.54" dx="2.54" dy="1.27" layer="1" rot="R90"/>
<smd name="M2" x="13.97" y="-2.54" dx="2.54" dy="1.27" layer="1" rot="R90"/>
<smd name="M1" x="12.192" y="11.43" dx="2.54" dy="1.27" layer="1" rot="R90"/>
<smd name="10" x="-11.938" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="11" x="-10.668" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="8" x="-9.398" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="7" x="-7.874" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="6" x="-5.334" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="5" x="-2.794" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="4" x="-0.254" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="3" x="2.286" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="2" x="4.826" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="1" x="7.366" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<smd name="9" x="9.906" y="13.462" dx="1.4224" dy="0.7112" layer="1" rot="R90"/>
<text x="7.112" y="-16.764" size="1.27" layer="21" rot="R180">SD/MMC Card</text>
<text x="-7.62" y="5.08" size="1.27" layer="22">Amphenol MMC/SD</text>
<hole x="9.906" y="10.414" drill="1.6"/>
<hole x="-11.176" y="10.414" drill="1.1"/>
</package>
<package name="TRANSFLASH-LOCK-SOCK">
<wire x1="-6.78" y1="8.89" x2="6.78" y2="8.89" width="0.127" layer="21"/>
<wire x1="6.78" y1="8.89" x2="6.78" y2="-4.41" width="0.127" layer="21"/>
<wire x1="-6.78" y1="-5.51" x2="-6.78" y2="8.89" width="0.127" layer="21"/>
<wire x1="-6.78" y1="-5.51" x2="-5.28" y2="-5.51" width="0.127" layer="21"/>
<wire x1="6.78" y1="-4.41" x2="6.78" y2="-5.51" width="0.127" layer="21"/>
<wire x1="6.78" y1="-5.51" x2="5.28" y2="-5.51" width="0.127" layer="21"/>
<wire x1="-5.08" y1="-5.08" x2="0" y2="-4.445" width="0.127" layer="21"/>
<wire x1="5.08" y1="-5.08" x2="0" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-5.08" y1="-5.08" x2="-5.28" y2="-5.51" width="0.127" layer="21"/>
<wire x1="5.08" y1="-5.08" x2="5.28" y2="-5.51" width="0.127" layer="21"/>
<smd name="1" x="3.3" y="-0.46" dx="0.8" dy="1.5" layer="1"/>
<smd name="2" x="2.2" y="-0.46" dx="0.8" dy="1.5" layer="1"/>
<smd name="3" x="1.1" y="-0.46" dx="0.8" dy="1.5" layer="1"/>
<smd name="4" x="0" y="-0.46" dx="0.8" dy="1.5" layer="1"/>
<smd name="5" x="-1.1" y="-0.46" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="-2.2" y="-0.46" dx="0.8" dy="1.5" layer="1"/>
<smd name="7" x="-3.3" y="-0.46" dx="0.8" dy="1.5" layer="1"/>
<smd name="8" x="-4.4" y="-0.46" dx="0.8" dy="1.5" layer="1"/>
<smd name="S1" x="-6.875" y="-3.06" dx="1.45" dy="2" layer="1"/>
<smd name="S2" x="-6.875" y="5.24" dx="1.45" dy="2" layer="1"/>
<smd name="S3" x="6.875" y="5.24" dx="1.45" dy="2" layer="1"/>
<smd name="S4" x="6.875" y="-3.06" dx="1.45" dy="2" layer="1"/>
<text x="-7.62" y="-1.27" size="1.016" layer="25" ratio="18" rot="R90">&gt;NAME</text>
<text x="-6.35" y="6.985" size="1.016" layer="27" ratio="18">&gt;VALUE</text>
</package>
<package name="TF-PULL">
<description>TF / Micro SD socket is PUSH-PUSH type, the card can be pushed into and auto locked and pushed out by simply press the card.
&lt;p&gt;
Surface Mounting type.</description>
<wire x1="7.4" y1="-7.25" x2="7.4" y2="6.75" width="0.127" layer="21"/>
<wire x1="7.4" y1="6.75" x2="-1.4" y2="6.75" width="0.127" layer="21"/>
<wire x1="-1.4" y1="6.75" x2="-4.4" y2="7.55" width="0.127" layer="21"/>
<wire x1="-4.4" y1="7.55" x2="-7.4" y2="7.55" width="0.127" layer="21"/>
<wire x1="-7.4" y1="7.55" x2="-7.4" y2="-5.8" width="0.127" layer="21"/>
<wire x1="-7.4" y1="-5.8" x2="-6.1" y2="-5.8" width="0.127" layer="21"/>
<wire x1="-6.1" y1="-5.8" x2="-6.1" y2="-7.25" width="0.127" layer="21"/>
<wire x1="-6.1" y1="-7.25" x2="7.4" y2="-7.25" width="0.127" layer="21"/>
<smd name="S1" x="-7.9" y="2.85" dx="1.4" dy="2" layer="1"/>
<smd name="S2" x="7.9" y="2.85" dx="1.4" dy="2" layer="1"/>
<smd name="S3" x="7.96" y="-6.75" dx="1.28" dy="1.4" layer="1"/>
<smd name="S4" x="-7.025" y="-6.75" dx="1.95" dy="1.4" layer="1"/>
<smd name="1" x="-2.2" y="-7.62" dx="0.7" dy="1.4" layer="1"/>
<smd name="2" x="-1.1" y="-7.62" dx="0.7" dy="1.4" layer="1"/>
<smd name="3" x="0" y="-7.62" dx="0.7" dy="1.4" layer="1"/>
<smd name="4" x="1.1" y="-7.62" dx="0.7" dy="1.4" layer="1"/>
<smd name="5" x="2.2" y="-7.62" dx="0.7" dy="1.4" layer="1"/>
<smd name="6" x="3.3" y="-7.62" dx="0.7" dy="1.4" layer="1"/>
<smd name="7" x="4.4" y="-7.62" dx="0.7" dy="1.4" layer="1"/>
<smd name="8" x="5.5" y="-7.62" dx="0.7" dy="1.4" layer="1"/>
<smd name="9" x="6.6" y="-7.62" dx="0.7" dy="1.4" layer="1"/>
<text x="7.7" y="1.1" size="1.016" layer="25" ratio="18" rot="R270">&gt;NAME</text>
<hole x="-3.1" y="3.25" drill="1.25"/>
<hole x="4.9" y="3.25" drill="1.25"/>
</package>
<package name="ATTEND-112">
<smd name="VDD" x="-0.35" y="8.62" dx="2" dy="0.7" layer="1" rot="R90"/>
<smd name="CLK" x="-1.45" y="8.62" dx="2" dy="0.7" layer="1" rot="R90"/>
<smd name="VSS" x="-2.55" y="8.62" dx="2" dy="0.7" layer="1" rot="R90"/>
<smd name="DAT0" x="-3.65" y="8.62" dx="2" dy="0.7" layer="1" rot="R90"/>
<smd name="DAT1" x="-4.75" y="8.62" dx="2" dy="0.7" layer="1" rot="R90"/>
<smd name="CMD" x="0.75" y="8.62" dx="2" dy="0.7" layer="1" rot="R90"/>
<smd name="DAT3" x="1.85" y="8.62" dx="2" dy="0.7" layer="1" rot="R90"/>
<smd name="DAT2" x="2.95" y="8.62" dx="2" dy="0.7" layer="1" rot="R90"/>
<smd name="GND" x="4.2" y="8.62" dx="2" dy="0.85" layer="1" rot="R90"/>
<smd name="CD" x="5.35" y="8.62" dx="2" dy="0.85" layer="1" rot="R90"/>
<hole x="-5" y="5.02" drill="1.5"/>
<hole x="5" y="5.02" drill="1.5"/>
<smd name="S2" x="7.3" y="0.22" dx="2" dy="1.2" layer="1" rot="R90"/>
<smd name="S1" x="-7.3" y="0.22" dx="2" dy="1.2" layer="1" rot="R90"/>
<wire x1="5.65" y1="-4.48" x2="5.65" y2="-10.6397" width="0.127" layer="21"/>
<wire x1="5.0097" y1="-11.28" x2="5.65" y2="-10.6397" width="0.127" layer="21" curve="90"/>
<wire x1="5.0097" y1="-11.28" x2="-4.9429" y2="-11.28" width="0.127" layer="21"/>
<wire x1="-5.65" y1="-10.5729" x2="-4.9429" y2="-11.28" width="0.127" layer="21" curve="89.983796"/>
<wire x1="-5.65" y1="-10.5729" x2="-5.65" y2="-4.48" width="0.127" layer="21"/>
<text x="0" y="-9.38" size="0.8128" layer="51" font="vector" ratio="18" rot="R180" align="center">card IN</text>
<wire x1="6.65" y1="7.62" x2="-6.65" y2="7.62" width="0.127" layer="21"/>
<wire x1="-6.65" y1="7.62" x2="-6.65" y2="-4.48" width="0.127" layer="21"/>
<wire x1="6.65" y1="7.62" x2="6.65" y2="-4.48" width="0.127" layer="21"/>
<wire x1="-5.65" y1="-4.48" x2="-6.65" y2="-4.48" width="0.127" layer="21"/>
<wire x1="6.65" y1="-4.48" x2="5.65" y2="-4.48" width="0.127" layer="21"/>
<wire x1="5.65" y1="-4.48" x2="4.4" y2="-3.23" width="0.127" layer="21" style="longdash" curve="90"/>
<wire x1="4.4" y1="-3.23" x2="-4.4" y2="-3.23" width="0.127" layer="21" style="longdash"/>
<wire x1="-5.65" y1="-4.48" x2="-4.4" y2="-3.23" width="0.127" layer="21" style="longdash" curve="-90"/>
<text x="0" y="2.05" size="0.8128" layer="25" font="vector" ratio="18" rot="R180" align="center">&gt;NAME</text>
</package>
</packages>
<symbols>
<symbol name="SDCARD_SYMBOL">
<wire x1="-12.7" y1="-12.7" x2="12.7" y2="-12.7" width="0.254" layer="94"/>
<wire x1="12.7" y1="-12.7" x2="12.7" y2="12.7" width="0.254" layer="94"/>
<wire x1="12.7" y1="12.7" x2="-12.7" y2="12.7" width="0.254" layer="94"/>
<wire x1="-12.7" y1="12.7" x2="-12.7" y2="-12.7" width="0.254" layer="94"/>
<text x="-10.16" y="13.208" size="1.27" layer="95">&gt;NAME</text>
<text x="-10.16" y="-15.24" size="1.27" layer="96">&gt;VALUE</text>
<pin name="DAT0/DO" x="-15.24" y="-5.08" length="short"/>
<pin name="DAT1" x="-15.24" y="-7.62" length="short"/>
<pin name="DAT2" x="-15.24" y="-10.16" length="short"/>
<pin name="CD/DAT3/CS" x="-15.24" y="10.16" length="short"/>
<pin name="CMD/DI" x="-15.24" y="7.62" length="short"/>
<pin name="CLK/SCLK" x="-15.24" y="0" length="short"/>
<pin name="GND@1" x="15.24" y="-2.54" length="short" direction="pwr" rot="R180"/>
<pin name="GND@2" x="15.24" y="-5.08" length="short" direction="pwr" rot="R180"/>
<pin name="GND@3" x="15.24" y="-7.62" length="short" direction="pwr" rot="R180"/>
<pin name="GND@4" x="15.24" y="-10.16" length="short" direction="pwr" rot="R180"/>
<pin name="VSS2" x="-15.24" y="-2.54" length="short" direction="pwr"/>
<pin name="VSS1" x="-15.24" y="5.08" length="short" direction="pwr"/>
<pin name="VDD" x="-15.24" y="2.54" length="short" direction="pwr"/>
<pin name="WP" x="15.24" y="5.08" length="short" direction="out" rot="R180"/>
<pin name="CDI#" x="15.24" y="10.16" length="short" direction="out" rot="R180"/>
</symbol>
<symbol name="SDCARD">
<wire x1="12.7" y1="-12.7" x2="12.7" y2="10.16" width="0.254" layer="94"/>
<wire x1="12.7" y1="10.16" x2="-12.7" y2="10.16" width="0.254" layer="94"/>
<wire x1="-12.7" y1="10.16" x2="-12.7" y2="-12.7" width="0.254" layer="94"/>
<text x="-10.16" y="10.668" size="1.27" layer="95">&gt;NAME</text>
<pin name="DAT0(DO)" x="-15.24" y="-7.62" length="short"/>
<pin name="DAT1" x="-15.24" y="-10.16" length="short"/>
<pin name="DAT2" x="-15.24" y="7.62" length="short"/>
<pin name="CD/DAT3(!CS!)" x="-15.24" y="5.08" length="short"/>
<pin name="CMD(DI)" x="-15.24" y="2.54" length="short"/>
<pin name="CLK(SCLK)" x="-15.24" y="-2.54" length="short"/>
<pin name="S@1" x="15.24" y="-2.54" length="short" direction="pas" rot="R180"/>
<pin name="S@2" x="15.24" y="-5.08" length="short" direction="pas" rot="R180"/>
<pin name="S@3" x="15.24" y="-7.62" length="short" direction="pas" rot="R180"/>
<pin name="S@4" x="15.24" y="-10.16" length="short" direction="pas" rot="R180"/>
<pin name="GND" x="-15.24" y="-5.08" length="short" direction="pwr"/>
<pin name="VDD" x="-15.24" y="0" length="short" direction="pwr"/>
</symbol>
<symbol name="TF9">
<wire x1="-7.62" y1="12.7" x2="-7.62" y2="-12.7" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-12.7" x2="10.16" y2="-12.7" width="0.254" layer="94"/>
<wire x1="10.16" y1="-12.7" x2="10.16" y2="12.7" width="0.254" layer="94"/>
<wire x1="10.16" y1="12.7" x2="-7.62" y2="12.7" width="0.254" layer="94"/>
<text x="-5.08" y="13.208" size="1.6764" layer="95">&gt;NAME</text>
<text x="10.668" y="10.16" size="1.6764" layer="96" rot="R270">&gt;VALUE</text>
<text x="9.398" y="-12.192" size="1.016" layer="97" rot="R90">TransFlash holder</text>
<pin name="DAT2" x="-12.7" y="10.16" length="middle"/>
<pin name="CD/DAT3(!CS!)" x="-12.7" y="7.62" length="middle"/>
<pin name="CMD(DI)" x="-12.7" y="5.08" length="middle"/>
<pin name="VDD" x="-12.7" y="2.54" length="middle" direction="pwr"/>
<pin name="CLK(SCLK)" x="-12.7" y="0" length="middle" direction="in"/>
<pin name="VSS" x="-12.7" y="-2.54" length="middle" direction="pwr"/>
<pin name="DAT0(DO)" x="-12.7" y="-5.08" length="middle"/>
<pin name="DAT1" x="-12.7" y="-7.62" length="middle"/>
<pin name="!CARD" x="-12.7" y="-10.16" length="middle" direction="pas"/>
<pin name="S1" x="-2.54" y="-15.24" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="S2" x="0" y="-15.24" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="S3" x="2.54" y="-15.24" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="S4" x="5.08" y="-15.24" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="112I">
<pin name="DAT0(DO)" x="-15.24" y="-7.62" visible="pin" length="short"/>
<pin name="DAT1" x="-15.24" y="-10.16" visible="pin" length="short"/>
<pin name="DAT2" x="-15.24" y="7.62" visible="pin" length="short"/>
<pin name="CD/DAT3(!CS!)" x="-15.24" y="5.08" visible="pin" length="short"/>
<pin name="CMD(DI)" x="-15.24" y="2.54" visible="pin" length="short"/>
<pin name="CLK(SCLK)" x="-15.24" y="-2.54" visible="pin" length="short"/>
<pin name="S@1" x="15.24" y="-7.62" visible="pin" length="short" direction="pas" rot="R180"/>
<pin name="S@2" x="15.24" y="-10.16" visible="pin" length="short" direction="pas" rot="R180"/>
<pin name="CD" x="15.24" y="7.62" visible="pin" length="short" direction="oc" rot="R180"/>
<pin name="GND" x="15.24" y="5.08" visible="pin" length="short" direction="pas" rot="R180"/>
<pin name="VSS(GND)" x="-15.24" y="-5.08" visible="pin" length="short" direction="pwr"/>
<pin name="VDD" x="-15.24" y="0" visible="pin" length="short" direction="pwr"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="SDCARD" prefix="J" uservalue="yes">
<description>SD card connector
KINGFONT SDCMF-10915W010</description>
<gates>
<gate name="G$1" symbol="SDCARD_SYMBOL" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SDCMF-10915W010">
<connects>
<connect gate="G$1" pin="CD/DAT3/CS" pad="1"/>
<connect gate="G$1" pin="CDI#" pad="10"/>
<connect gate="G$1" pin="CLK/SCLK" pad="5"/>
<connect gate="G$1" pin="CMD/DI" pad="2"/>
<connect gate="G$1" pin="DAT0/DO" pad="7"/>
<connect gate="G$1" pin="DAT1" pad="8"/>
<connect gate="G$1" pin="DAT2" pad="9"/>
<connect gate="G$1" pin="GND@1" pad="M1"/>
<connect gate="G$1" pin="GND@2" pad="M2"/>
<connect gate="G$1" pin="GND@3" pad="M3"/>
<connect gate="G$1" pin="GND@4" pad="M4"/>
<connect gate="G$1" pin="VDD" pad="4"/>
<connect gate="G$1" pin="VSS1" pad="3"/>
<connect gate="G$1" pin="VSS2" pad="6"/>
<connect gate="G$1" pin="WP" pad="11"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TRANSFLASH" prefix="J">
<description>TransFlash TF Micro SD Card Socket Adapter</description>
<gates>
<gate name="G$1" symbol="SDCARD" x="0" y="0"/>
</gates>
<devices>
<device name="-PUSH" package="MICROSD_MICROSD">
<connects>
<connect gate="G$1" pin="CD/DAT3(!CS!)" pad="2"/>
<connect gate="G$1" pin="CLK(SCLK)" pad="5"/>
<connect gate="G$1" pin="CMD(DI)" pad="3"/>
<connect gate="G$1" pin="DAT0(DO)" pad="7"/>
<connect gate="G$1" pin="DAT2" pad="1"/>
<connect gate="G$1" pin="GND" pad="6"/>
<connect gate="G$1" pin="S@1" pad="NC"/>
<connect gate="G$1" pin="S@2" pad="NC1"/>
<connect gate="G$1" pin="S@3" pad="NC2"/>
<connect gate="G$1" pin="S@4" pad="NC3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-LOCK" package="TRANSFLASH-LOCK-SOCK">
<connects>
<connect gate="G$1" pin="S@1" pad="S1"/>
<connect gate="G$1" pin="S@2" pad="S2"/>
<connect gate="G$1" pin="S@3" pad="S3"/>
<connect gate="G$1" pin="S@4" pad="S4"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TF-HOLDER" prefix="SD">
&lt;p&gt;
<gates>
<gate name="G$1" symbol="TF9" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TF-PULL">
<connects>
<connect gate="G$1" pin="!CARD" pad="9"/>
<connect gate="G$1" pin="S1" pad="S1"/>
<connect gate="G$1" pin="S2" pad="S2"/>
<connect gate="G$1" pin="S3" pad="S3"/>
<connect gate="G$1" pin="S4" pad="S4"/>
<connect gate="G$1" pin="VSS" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ATTEND-MICROSD-112" prefix="J">
<description>&lt;p&gt;&lt;b&gt;Attend microSD socket&lt;/b&gt;&lt;/p&gt;
&lt;p&gt;Datasheet: &lt;a href="http://www.soselectronic.com/a_info/resource/f/112I-TXAR-R_B_1.pdf"&gt;Attend 112 microSD socket&lt;/a&gt;.&lt;/p&gt;</description>
<gates>
<gate name="G$1" symbol="112I" x="0" y="0"/>
</gates>
<devices>
<device name="" package="ATTEND-112">
<connects>
<connect gate="G$1" pin="CD" pad="CD"/>
<connect gate="G$1" pin="CD/DAT3(!CS!)" pad="DAT3"/>
<connect gate="G$1" pin="CLK(SCLK)" pad="CLK"/>
<connect gate="G$1" pin="CMD(DI)" pad="CMD"/>
<connect gate="G$1" pin="DAT0(DO)" pad="DAT0"/>
<connect gate="G$1" pin="DAT1" pad="DAT1"/>
<connect gate="G$1" pin="DAT2" pad="DAT2"/>
<connect gate="G$1" pin="GND" pad="GND"/>
<connect gate="G$1" pin="VDD" pad="VDD"/>
<connect gate="G$1" pin="VSS(GND)" pad="VSS"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
