<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="BX56-12">
<description>&lt;b&gt;14.22mm (0.56INCH) THREE DIGIT NUMERIC DISPLAY&lt;/b&gt;&lt;p&gt;
Source: http://www.kingbright.com .. BA56-11EWA(Ver1189474895.pdf</description>
<wire x1="-25" y1="9.5" x2="25" y2="9.5" width="0.2032" layer="21"/>
<wire x1="25" y1="9.5" x2="25" y2="-9.5" width="0.2032" layer="21"/>
<wire x1="25" y1="-9.5" x2="-25" y2="-9.5" width="0.2032" layer="21"/>
<wire x1="-25" y1="-9.5" x2="-25" y2="9.5" width="0.2032" layer="21"/>
<pad name="1" x="-6.35" y="-7.62" drill="0.8" diameter="1.9304" shape="octagon"/>
<pad name="2" x="-3.81" y="-7.62" drill="0.8" diameter="1.9304" shape="octagon"/>
<pad name="3" x="-1.27" y="-7.62" drill="0.8" diameter="1.9304" shape="octagon"/>
<pad name="4" x="1.27" y="-7.62" drill="0.8" diameter="1.9304" shape="octagon"/>
<pad name="5" x="3.81" y="-7.62" drill="0.8" diameter="1.9304" shape="octagon"/>
<pad name="6" x="6.35" y="-7.62" drill="0.8" diameter="1.9304" shape="octagon"/>
<pad name="7" x="6.35" y="7.62" drill="0.8" diameter="1.9304" shape="octagon" rot="R180"/>
<pad name="8" x="3.81" y="7.62" drill="0.8" diameter="1.9304" shape="octagon" rot="R180"/>
<pad name="9" x="1.27" y="7.62" drill="0.8" diameter="1.9304" shape="octagon" rot="R180"/>
<pad name="10" x="-1.27" y="7.62" drill="0.8" diameter="1.9304" shape="octagon" rot="R180"/>
<pad name="11" x="-3.81" y="7.62" drill="0.8" diameter="1.9304" shape="octagon" rot="R180"/>
<pad name="12" x="-6.35" y="7.62" drill="0.8" diameter="1.9304" shape="octagon" rot="R180"/>
<text x="-18.415" y="10.16" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.715" y="10.16" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<polygon width="0.3976" layer="21" spacing="1.2428">
<vertex x="-18.0369" y="1.0764"/>
<vertex x="-17.0093" y="6.948"/>
<vertex x="-17.2785" y="6.948" curve="77.705866"/>
<vertex x="-18.1592" y="6.2385"/>
<vertex x="-19.1622" y="0.4893"/>
<vertex x="-18.5995" y="0.4893"/>
</polygon>
<vertex x="-16.5445" y="5.9694"/>
<vertex x="-16.3733" y="6.948"/>
<vertex x="-12.3537" y="6.948"/>
<vertex x="-12.476" y="5.9694"/>
</polygon>
<vertex x="-12.7632" y="1.0329"/>
<vertex x="-11.7296" y="6.9034"/>
<vertex x="-11.427" y="6.9114" curve="-104.731141"/>
<vertex x="-10.8092" y="6.071"/>
<vertex x="-11.8399" y="0.4893"/>
<vertex x="-12.3047" y="0.4893"/>
</polygon>
<vertex x="-18.1347" y="0.0245"/>
<vertex x="-17.5231" y="0.6361"/>
<vertex x="-13.3078" y="0.6361"/>
<vertex x="-12.9408" y="0.1223"/>
<vertex x="-13.3812" y="-0.3425"/>
<vertex x="-17.7677" y="-0.3425"/>
</polygon>
<vertex x="-18.3368" y="-0.7149"/>
<vertex x="-19.2971" y="-6.6343"/>
<vertex x="-19.5997" y="-6.6423" curve="-104.72259"/>
<vertex x="-20.2174" y="-5.8019"/>
<vertex x="-19.2601" y="-0.1713"/>
<vertex x="-18.7953" y="-0.1713"/>
</polygon>
<vertex x="-13.0387" y="-0.9541"/>
<vertex x="-14.0173" y="-6.6789"/>
<vertex x="-13.7482" y="-6.6789" curve="77.701982"/>
<vertex x="-12.8674" y="-5.9694"/>
<vertex x="-11.9378" y="-0.4159"/>
<vertex x="-12.5005" y="-0.4159"/>
</polygon>
<vertex x="-14.4821" y="-5.7003"/>
<vertex x="-14.6533" y="-6.6789"/>
<vertex x="-18.6729" y="-6.6789"/>
<vertex x="-18.5506" y="-5.7003"/>
</polygon>
<circle x="-11.6017" y="-6.5231" radius="0.7305" width="0" layer="21"/>
<vertex x="-7.3368" y="-0.7149"/>
<vertex x="-8.2971" y="-6.6343"/>
<vertex x="-8.5997" y="-6.6423" curve="-104.72259"/>
<vertex x="-9.2174" y="-5.8019"/>
<vertex x="-8.2601" y="-0.1713"/>
<vertex x="-7.7953" y="-0.1713"/>
</polygon>
<vertex x="-3.4821" y="-5.7003"/>
<vertex x="-3.6533" y="-6.6789"/>
<vertex x="-7.6729" y="-6.6789"/>
<vertex x="-7.5506" y="-5.7003"/>
</polygon>
<vertex x="-2.0387" y="-0.9541"/>
<vertex x="-3.0173" y="-6.6789"/>
<vertex x="-2.7482" y="-6.6789" curve="77.701982"/>
<vertex x="-1.8674" y="-5.9694"/>
<vertex x="-0.9378" y="-0.4159"/>
<vertex x="-1.5005" y="-0.4159"/>
</polygon>
<vertex x="-7.1347" y="0.0245"/>
<vertex x="-6.5231" y="0.6361"/>
<vertex x="-2.3078" y="0.6361"/>
<vertex x="-1.9408" y="0.1223"/>
<vertex x="-2.3812" y="-0.3425"/>
<vertex x="-6.7677" y="-0.3425"/>
</polygon>
<vertex x="-7.0369" y="1.0764"/>
<vertex x="-6.0093" y="6.948"/>
<vertex x="-6.2785" y="6.948" curve="77.705866"/>
<vertex x="-7.1592" y="6.2385"/>
<vertex x="-8.1622" y="0.4893"/>
<vertex x="-7.5995" y="0.4893"/>
</polygon>
<vertex x="-1.7632" y="1.0329"/>
<vertex x="-0.7296" y="6.9034"/>
<vertex x="-0.427" y="6.9114" curve="-104.731141"/>
<vertex x="0.1908" y="6.071"/>
<vertex x="-0.8399" y="0.4893"/>
<vertex x="-1.3047" y="0.4893"/>
</polygon>
<vertex x="-5.5445" y="5.9694"/>
<vertex x="-5.3733" y="6.948"/>
<vertex x="-1.3537" y="6.948"/>
<vertex x="-1.476" y="5.9694"/>
</polygon>
<circle x="-0.6017" y="-6.5231" radius="0.7305" width="0" layer="21"/>
<vertex x="3.6632" y="-0.7149"/>
<vertex x="2.7029" y="-6.6343"/>
<vertex x="2.4003" y="-6.6423" curve="-104.72259"/>
<vertex x="1.7826" y="-5.8019"/>
<vertex x="2.7399" y="-0.1713"/>
<vertex x="3.2047" y="-0.1713"/>
</polygon>
<vertex x="7.5179" y="-5.7003"/>
<vertex x="7.3467" y="-6.6789"/>
<vertex x="3.3271" y="-6.6789"/>
<vertex x="3.4494" y="-5.7003"/>
</polygon>
<vertex x="8.9613" y="-0.9541"/>
<vertex x="7.9827" y="-6.6789"/>
<vertex x="8.2518" y="-6.6789" curve="77.701982"/>
<vertex x="9.1326" y="-5.9694"/>
<vertex x="10.0622" y="-0.4159"/>
<vertex x="9.4995" y="-0.4159"/>
</polygon>
<vertex x="3.8653" y="0.0245"/>
<vertex x="4.4769" y="0.6361"/>
<vertex x="8.6922" y="0.6361"/>
<vertex x="9.0592" y="0.1223"/>
<vertex x="8.6188" y="-0.3425"/>
<vertex x="4.2323" y="-0.3425"/>
</polygon>
<vertex x="3.9631" y="1.0764"/>
<vertex x="4.9907" y="6.948"/>
<vertex x="4.7215" y="6.948" curve="77.705866"/>
<vertex x="3.8408" y="6.2385"/>
<vertex x="2.8378" y="0.4893"/>
<vertex x="3.4005" y="0.4893"/>
</polygon>
<vertex x="5.4555" y="5.9694"/>
<vertex x="5.6267" y="6.948"/>
<vertex x="9.6463" y="6.948"/>
<vertex x="9.524" y="5.9694"/>
</polygon>
<vertex x="9.2368" y="1.0329"/>
<vertex x="10.2704" y="6.9034"/>
<vertex x="10.573" y="6.9114" curve="-104.731141"/>
<vertex x="11.1908" y="6.071"/>
<vertex x="10.1601" y="0.4893"/>
<vertex x="9.6953" y="0.4893"/>
</polygon>
<circle x="10.3983" y="-6.5231" radius="0.7305" width="0" layer="21"/>
<vertex x="14.6632" y="-0.7149"/>
<vertex x="13.7029" y="-6.6343"/>
<vertex x="13.4003" y="-6.6423" curve="-104.72259"/>
<vertex x="12.7826" y="-5.8019"/>
<vertex x="13.7399" y="-0.1713"/>
<vertex x="14.2047" y="-0.1713"/>
</polygon>
<vertex x="18.5179" y="-5.7003"/>
<vertex x="18.3467" y="-6.6789"/>
<vertex x="14.3271" y="-6.6789"/>
<vertex x="14.4494" y="-5.7003"/>
</polygon>
<vertex x="19.9613" y="-0.9541"/>
<vertex x="18.9827" y="-6.6789"/>
<vertex x="19.2518" y="-6.6789" curve="77.701982"/>
<vertex x="20.1326" y="-5.9694"/>
<vertex x="21.0622" y="-0.4159"/>
<vertex x="20.4995" y="-0.4159"/>
</polygon>
<circle x="21.3983" y="-6.5231" radius="0.7305" width="0" layer="21"/>
<vertex x="14.8653" y="0.0245"/>
<vertex x="15.4769" y="0.6361"/>
<vertex x="19.6922" y="0.6361"/>
<vertex x="20.0592" y="0.1223"/>
<vertex x="19.6188" y="-0.3425"/>
<vertex x="15.2323" y="-0.3425"/>
</polygon>
<vertex x="14.9631" y="1.0764"/>
<vertex x="15.9907" y="6.948"/>
<vertex x="15.7215" y="6.948" curve="77.705866"/>
<vertex x="14.8408" y="6.2385"/>
<vertex x="13.8378" y="0.4893"/>
<vertex x="14.4005" y="0.4893"/>
</polygon>
<vertex x="20.2368" y="1.0329"/>
<vertex x="21.2704" y="6.9034"/>
<vertex x="21.573" y="6.9114" curve="-104.731141"/>
<vertex x="22.1908" y="6.071"/>
<vertex x="21.1601" y="0.4893"/>
<vertex x="20.6953" y="0.4893"/>
</polygon>
<vertex x="16.4555" y="5.9694"/>
<vertex x="16.6267" y="6.948"/>
<vertex x="20.6463" y="6.948"/>
<vertex x="20.524" y="5.9694"/>
</polygon>
</package>
</packages>
<symbols>
<symbol name="4DIGIT">
<wire x1="-38.1" y1="15.24" x2="43.18" y2="15.24" width="0.254" layer="94"/>
<wire x1="43.18" y1="15.24" x2="43.18" y2="-15.24" width="0.254" layer="94"/>
<wire x1="43.18" y1="-15.24" x2="-38.1" y2="-15.24" width="0.254" layer="94"/>
<wire x1="-38.1" y1="-15.24" x2="-38.1" y2="15.24" width="0.254" layer="94"/>
<wire x1="-30.48" y1="10.16" x2="-17.78" y2="10.16" width="0.254" layer="94"/>
<wire x1="-17.78" y1="10.16" x2="-17.78" y2="0" width="0.254" layer="94"/>
<wire x1="-17.78" y1="0" x2="-30.48" y2="0" width="0.254" layer="94"/>
<wire x1="-30.48" y1="0" x2="-30.48" y2="10.16" width="0.254" layer="94"/>
<wire x1="-30.48" y1="0" x2="-30.48" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-30.48" y1="-10.16" x2="-17.78" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-17.78" y1="-10.16" x2="-17.78" y2="0" width="0.254" layer="94"/>
<wire x1="-15.24" y1="10.16" x2="-15.24" y2="0" width="0.254" layer="94"/>
<wire x1="-15.24" y1="0" x2="-15.24" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-15.24" y1="-10.16" x2="-2.54" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-10.16" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="-15.24" y1="0" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="10.16" width="0.254" layer="94"/>
<wire x1="-2.54" y1="10.16" x2="-15.24" y2="10.16" width="0.254" layer="94"/>
<circle x="2.54" y="7.62" radius="2.54" width="0.254" layer="94"/>
<circle x="2.54" y="-5.08" radius="2.54" width="0.254" layer="94"/>
<wire x1="7.62" y1="10.16" x2="7.62" y2="0" width="0.254" layer="94"/>
<wire x1="7.62" y1="0" x2="20.32" y2="0" width="0.254" layer="94"/>
<wire x1="20.32" y1="0" x2="20.32" y2="10.16" width="0.254" layer="94"/>
<wire x1="20.32" y1="10.16" x2="7.62" y2="10.16" width="0.254" layer="94"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-10.16" width="0.254" layer="94"/>
<wire x1="7.62" y1="-10.16" x2="20.32" y2="-10.16" width="0.254" layer="94"/>
<wire x1="20.32" y1="-10.16" x2="20.32" y2="0" width="0.254" layer="94"/>
<wire x1="22.86" y1="10.16" x2="22.86" y2="0" width="0.254" layer="94"/>
<wire x1="35.56" y1="0" x2="22.86" y2="0" width="0.254" layer="94"/>
<wire x1="22.86" y1="0" x2="22.86" y2="-10.16" width="0.254" layer="94"/>
<wire x1="22.86" y1="-10.16" x2="35.56" y2="-10.16" width="0.254" layer="94"/>
<wire x1="35.56" y1="-10.16" x2="35.56" y2="0" width="0.254" layer="94"/>
<wire x1="35.56" y1="0" x2="35.56" y2="10.16" width="0.254" layer="94"/>
<wire x1="35.56" y1="10.16" x2="22.86" y2="10.16" width="0.254" layer="94"/>
<pin name="E" x="-30.48" y="-20.32" length="middle" rot="R90"/>
<pin name="D" x="-17.78" y="-20.32" length="middle" rot="R90"/>
<pin name="DECIMAL" x="-5.08" y="-20.32" length="middle" rot="R90"/>
<pin name="C" x="7.62" y="-20.32" length="middle" rot="R90"/>
<pin name="G" x="20.32" y="-20.32" length="middle" rot="R90"/>
<pin name="D4" x="33.02" y="-20.32" length="middle" rot="R90"/>
<pin name="B" x="33.02" y="20.32" length="middle" rot="R270"/>
<pin name="D3" x="20.32" y="20.32" length="middle" rot="R270"/>
<pin name="D2" x="7.62" y="20.32" length="middle" rot="R270"/>
<pin name="F" x="-5.08" y="20.32" length="middle" rot="R270"/>
<pin name="A" x="-17.78" y="20.32" length="middle" rot="R270"/>
<pin name="D1" x="-30.48" y="20.32" length="middle" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="7SEG">
<gates>
<gate name="G$1" symbol="4DIGIT" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="BX56-12">
<connects>
<connect gate="G$1" pin="A" pad="11"/>
<connect gate="G$1" pin="B" pad="7"/>
<connect gate="G$1" pin="C" pad="4"/>
<connect gate="G$1" pin="D" pad="2"/>
<connect gate="G$1" pin="D1" pad="12"/>
<connect gate="G$1" pin="D2" pad="9"/>
<connect gate="G$1" pin="D3" pad="8"/>
<connect gate="G$1" pin="D4" pad="6"/>
<connect gate="G$1" pin="DECIMAL" pad="3"/>
<connect gate="G$1" pin="E" pad="1"/>
<connect gate="G$1" pin="F" pad="10"/>
<connect gate="G$1" pin="G" pad="5"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
