<root>
<document schema='101' license='1,,*****' title='' description='' target='PIC.18F.18F1220' >
	<config data='!0,f2ff!10,fefc!20,ffff!30,fffb!40,ffff!50,ffff!60,ffff%8,2%e,1%f,1%10,0%11,0%12,3%18,0%19,f%2f,1%30,1%32,0%37,1%40,1%41,1%4f,1%4e,1%50,1%51,1%5f,1%5e,1%5d,1%60,1%61,1%6e,1' clkspd='40000000' simspd='1' usewdt='1' constif='0' />
	<plugins >
		<dll_dbg_icd enabled='0' >
			<data name='debug' value='1' />
			<data name='userpins' value='0' />
			<data name='speed' value='0' />
			<data name='usev9' value='0' />
			<data name='breaks' value='8' />
			<data name='stacks' value='8' />
			<data name='clkport' value='1' />
			<data name='clkbit' value='6' />
			<data name='dataport' value='1' />
			<data name='databit' value='7' />
			<data name='ghostype' value='0' />
			<data name='monitor' value='1' />
			<data name='ictloop' value='0' />
			<data name='ictrate' value='20000' />
			<data name='ictmask' value='0' />
			<data name='anlpres' value='19' />
			<data name='digmask1' value='-1' />
			<data name='digmask2' value='-1' />
		</dll_dbg_icd>
		<dll_models enabled='1' />
		<dll_upgrader enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug />
	<ghost >
		<FK2 >
			<data name='FK2D0' port='4294967295' pin='4294967295' />
			<data name='FK2D1' port='4294967295' pin='4294967295' />
			<data name='FK2D2' port='4294967295' pin='4294967295' />
			<data name='FK2D3' port='4294967295' pin='4294967295' />
			<data name='FK2D4' port='4294967295' pin='4294967295' />
			<data name='FK2D5' port='4294967295' pin='4294967295' />
			<data name='FK2D6' port='4294967295' pin='4294967295' />
			<data name='FK2D7' port='4294967295' pin='4294967295' />
			<data name='FK2D8' port='4294967295' pin='4294967295' />
			<data name='FK2D9' port='4294967295' pin='4294967295' />
			<data name='FK2D10' port='4294967295' pin='4294967295' />
			<data name='FK2D11' port='4294967295' pin='4294967295' />
			<data name='FK2D12' port='4294967295' pin='4294967295' />
			<data name='FK2D13' port='4294967295' pin='4294967295' />
			<data name='FK2D14' port='4294967295' pin='4294967295' />
			<data name='FK2D15' port='4294967295' pin='4294967295' />
			<data name='FK2A0' port='4294967295' pin='4294967295' />
			<data name='FK2A1' port='4294967295' pin='4294967295' />
			<data name='FK2A2' port='4294967295' pin='4294967295' />
			<data name='FK2A3' port='4294967295' pin='4294967295' />
			<data name='FK2A4' port='4294967295' pin='4294967295' />
			<data name='FK2A5' port='4294967295' pin='4294967295' />
		</FK2>
		<ICD >
			<data name='AnalogPrescaleValue' value='19' />
			<data name='DigitalSampleRate' value='100000' />
			<data name='BreakpointCount' value='8' />
			<data name='CallStackDepthCount' value='8' />
			<data name='ClockPort' value='1' />
			<data name='ClockPin' value='6' />
			<data name='DataPort' value='1' />
			<data name='DataPin' value='7' />
			<data name='UseDefaultPins' value='1' />
			<data name='WrapEnabled' value='1' />
			<data name='CommsDelayOverridden' value='0' />
			<data name='CommsDelay' value='5' />
			<data name='CalculatedCommsDelay' value='5' />
		</ICD>
		<pins >
			<digital A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
			<analog A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
		</pins>
	</ghost>
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='0' iconpath='' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='in' type='u8' description='' isconst='0' isinit='0' usrinit='0' setinit='' />
				</variable>
					<def class_type='variable' name='false' type='b1' description='' isconst='1' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='pwm1' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='pwm' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='true' type='b1' description='' isconst='1' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='Main' description='' >
						<return name='Return' type='v0' description='' isconst='0' isinit='0' usrinit='' setinit='' />
						<command class_type='delay' title='Delay' textarea='36,0,511,300' cmdcolor='12632064' cmdcolor_sec='16769676' exp='500' type='1' />
						<command class_type='call' title='Call Component Macro' textarea='36,0,511,300' cmdcolor='1879295' cmdcolor_sec='5751039' component='v5__lcddisplay0' macro='Start' />
						<command class_type='call' title='Call Component Macro' textarea='36,0,511,300' cmdcolor='1879295' cmdcolor_sec='5751039' component='v5__lcddisplay0' macro='Clear' />
						<command class_type='call' title='Call Component Macro' textarea='36,0,511,300' cmdcolor='1879295' cmdcolor_sec='5751039' component='v5__rc50' macro='RXEnable' />
						<command class_type='loop' title='Loop' textarea='36,0,511,300' cmdcolor='12615680' cmdcolor_sec='15376912' type='0' exp='1' >
							<flowline >
								<command class_type='call' title='Call Component Macro' textarea='36,0,511,300' cmdcolor='1879295' cmdcolor_sec='5751039' component='v5__rc50' macro='CheckRx' >
									<return exp='in' />
								</command>
								<command class_type='call' title='Call Component Macro' textarea='36,0,511,300' cmdcolor='1879295' cmdcolor_sec='5751039' component='v5__rc50' macro='CollectData' >
									<return exp='in' />
									<argument exp='0' />
								</command>
								<command class_type='label' title='Connection Point' textmode='2' cmdcolor='12615680' cmdcolor_sec='15376912' labelid='0' labelname='A' />
								<command class_type='decision' title='0 val belépés ' textmode='2' cmdcolor='12615680' cmdcolor_sec='15376912' exp='in = 0x00FF4AB5' swap='0' >
									<flowline >
										<command class_type='loop' title='Loop' textmode='2' cmdcolor='12615680' cmdcolor_sec='15376912' type='0' exp='1' >
											<flowline >
													<return exp='in' />
												</command>
													<return exp='in' />
												</command>
												<command class_type='switch' title='Switch' textmode='2' textarea='36,25,36,25' cmdcolor='12615680' cmdcolor_sec='15376912' exp='in' >
													<case >
														<flowline />
													</case>
													<case exp='0x00FF629D' >
														<flowline >
															<command class_type='comment' title='' comment='Nyíl fel ' textmode='2' textarea='12,0,12,0' cmdcolor='10944511' cmdcolor_sec='11465458' />
															<command class_type='calculation' title='Calculation' textmode='2' cmdcolor='16760919' cmdcolor_sec='16760832' >
																<exp exp='pwm = pwm + 10' />
															</command>
															<command class_type='delay' title='Delay' textmode='2' cmdcolor='12632064' cmdcolor_sec='16769676' exp='300' type='1' />
														</flowline>
													</case>
													<case exp='0x00FFA857' >
														<flowline >
															<command class_type='comment' title='' comment='Nyíl le' textmode='2' textarea='12,0,12,0' cmdcolor='10944511' cmdcolor_sec='11465458' />
																<exp exp='pwm = pwm - 10' />
															</command>
														</flowline>
													</case>
													<case exp='0x00FF22DD' >
														<flowline >
															<command class_type='comment' title='' comment='Nyíl balra' textmode='2' textarea='12,0,12,0' cmdcolor='10944511' cmdcolor_sec='11465458' />
																<exp exp='pwm1 = pwm1 + 10' />
															</command>
														</flowline>
													</case>
													<case exp='0x00FFC23D' >
														<flowline >
															<command class_type='comment' title='' comment='Nyíl jobbra' textmode='2' textarea='12,0,12,0' cmdcolor='10944511' cmdcolor_sec='11465458' />
															</command>
														</flowline>
													</case>
													<case exp='0x00FF02FD' >
														<flowline >
															<command class_type='comment' title='' comment='Ok gombbal kilépés ' textmode='2' textarea='12,0,12,0' cmdcolor='10944511' cmdcolor_sec='11465458' />
															<command class_type='goto' title='Goto Connection Point' textmode='2' cmdcolor='12615680' cmdcolor_sec='15376912' labelid='0' labelname='' />
														</flowline>
													</case>
												</command>
												<command class_type='call' title='Call Component Macro' textarea='36,0,511,300' cmdcolor='1879295' cmdcolor_sec='5751039' component='v5__lcddisplay0' macro='Cursor' >
													<argument exp='1' />
												</command>
												<command class_type='call' title='Call Component Macro' textarea='36,0,511,300' cmdcolor='1879295' cmdcolor_sec='5751039' component='v5__lcddisplay0' macro='PrintNumber' >
													<argument exp='pwm' />
												</command>
												</command>
													<argument exp='pwm1' />
												</command>
											</flowline>
										</command>
									</flowline>
									<flowline >
										<command class_type='comment' title='' comment='Lcd kiírás' textmode='2' textarea='12,0,12,0' cmdcolor='10944511' cmdcolor_sec='11465458' />
										</command>
										</command>
										</command>
										</command>
									</flowline>
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='81e90a9f-1594-4b34-8aef-5dd671dddc30' vmin='2' vmaj='1' codename='v5__rc50' x='-1028' y='2300' z='0' xsz='10.8571' ysz='10.8571' zsz='1.14286' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='ir_freq' data='36000' />
					<value target='timer_enval' data='2' />
					<value target='timer_avr_enval' data='' />
					<value target='timer_pre_val' data='117' />
					<value target='timer_arm_enval' data='' />
					<value target='lwidth' data='3' />
					<value target='hwidth' data='23' />
					<value target='cwidth' data='11' />
					<value target='pwm_period' data='138' />
					<value target='pwm_duty' data='69' />
					<value target='pwm_scaler' data='0' />
					<value target='rx_mode' data='1' />
					<value target='rx_invert_signal' data='1' />
					<value target='rx_addr_mask' data='0' />
					<value target='rx_addr_val' data='0' />
					<value target='rx_a0' data='0' />
					<value target='rx_a1' data='0' />
					<value target='rx_a2' data='0' />
					<value target='rx_a3' data='0' />
					<value target='rx_a4' data='0' />
					<value target='rx_pin' data='$PORTA.2' />
					<value target='v5rxaddress' data='0' />
					<value target='tx_mode' data='0' />
					<value target='tx_modulation' data='1' />
					<value target='tx_pwm_chan' data='0' />
					<value target='tx_pin' data='$PORTA.2' />
					<value target='tx_pwm_pin' data='$PORTC.2' />
					<value target='RemapPin' data='' />
					<value target='label' data='RC5' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='0953aac0-9c23-4c2f-9843-88954a4191ea' vmin='4' vmaj='2' codename='v5__lcddisplay0' x='-952' y='2080' z='0' xsz='62.5714' ysz='10.5714' zsz='1.14286' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='LCD_Mode' data='000' />
					<value target='Pin_Data_0' data='$PORTB0.0' />
					<value target='Pin_Data_1' data='$PORTB0.1' />
					<value target='Pin_Data_2' data='$PORTB0.2' />
					<value target='Pin_Data_3' data='$PORTB0.3' />
					<value target='Pin_Data_4' data='$PORTA.1' />
					<value target='Pin_Data_5' data='$PORTA.1' />
					<value target='Pin_Data_6' data='$PORTA.1' />
					<value target='Pin_Data_7' data='$PORTA.1' />
					<value target='LCD_Port' data='$PORTA' />
					<value target='Pin_RS' data='$PORTB0.4' />
					<value target='Pin_E' data='$PORTB0.5' />
					<value target='LCD_Use_Write' data='0' />
					<value target='Pin_RW' data='$PORTA.0' />
					<value target='Rows' data='2' />
					<value target='Columns' data='16' />
					<value target='RemapCharacters' data='0' />
					<value target='DelayTiming' data='100' />
					<value target='BackgroundColor' data='0x808080' />
					<value target='LineColor' data='0' />
					<value target='TextColor' data='0x000000' />
					<value target='Font' data='Fixedsys' />
					<value target='CursorPosX' data='0' />
					<value target='CursorPosY' data='0' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<keymap />
	<panel2d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='7292207' img='' style='0' />
		<camera xe='41.9339' ye='51.2645' ze='1056.52' xt='41.9339' yt='51.2645' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='8409120' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='0' />
		<camera xe='-961.457' ye='2087.77' ze='265.705' xt='-961.457' yt='2087.77' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey0 xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey1 xe='-3.67394e-14' ye='0' ze='-300' xt='0' yt='0' zt='0' xquat='0' yquat='1' zquat='0' wquat='6.12323e-17' />
		<camerakey2 xe='0' ye='-300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.707107' yquat='0' zquat='0' wquat='0.707107' />
		<camerakey3 xe='-3.67394e-14' ye='300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-4.32978e-17' yquat='0.707107' zquat='0.707107' wquat='4.32978e-17' />
		<camerakey4 xe='-300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='0.5' zquat='0.5' wquat='0.5' />
		<camerakey5 xe='300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='-0.5' zquat='-0.5' wquat='0.5' />
		<camerakey6 xe='-173.205' ye='-173.205' ze='173.205' xt='0' yt='0' zt='0' xquat='-0.424708' yquat='0.17592' zquat='0.339851' wquat='0.820473' />
	</panel3d>
	<layout >
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAAaQYAAGADAAA' zoom='75' scrollx='0' scrolly='0' flags='0' />
	</layout>
</document>
</root>
