===DTC C1279=== Code: C1279 - This code is set when the output signal of the sensor is greater than 4.65V or less than 0.25V. Module: Anti-Lock Brake / Traction Control Module Diagnostic Trouble Code details Yaw Rate Sensor Circuit Failure ===DTC C1280=== Code: C1280 - This code is set when the signal from the sensor is inconsistent with the vehicle position. Module: Anti-Lock Brake / Traction Control Module Diagnostic Trouble Code details Yaw Rate Sensor Signal Fault This DTC may be caused by : Sensor Internal Hardware Fault This code is set when the signal from the sensor is inconsistent with the vehicle position. Loose or improperly installed sensor. ===END DTC C1280===
