#ifndef _DCF77_H
#define _DCF77_H
#ifndef DCF77_PIN_DATA
#error DCF77 digital input pin has to be define!
#endif
/* --- defines ------------------------------------------------------------- */
/* time for bit low */
#define DCF77_BIT_LOW_MIN     60//60
#define DCF77_BIT_LOW_MAX     140//140
/* time for bit high */
#define DCF77_BIT_HIGH_MIN    160//160
#define DCF77_BIT_HIGH_MAX    240//240
#define DCF77_BIT_IDLE_MIN    (1000 - (DCF77_BIT_HIGH_MAX))
#define DCF77_BIT_IDLE_MAX    (1000 - (DCF77_BIT_LOW_MIN))
/* start of minute */
#define DCF77_SIG_START_MIN   1300//1800//***************************************************************************
#define DCF77_SIG_START_MAX   2700//2200//***************************************************************************
/* DFC77 input debounce time */
#define DCF77_DEBOUNCE_TIME   35
/* DCF77 synchronization states */
#define DCF77_SYNC_WAIT       0
#define DCF77_SYNC_FIRST      1
#define DCF77_SYNC_OK         2
/* --- global variables ---------------------------------------------------- */
static bool   dcf77_pinold_b = FALSE;          /* debounced DCF77 input pin state */
static bool   dcf77_newdata_b = FALSE;         /* new data flag */
static uint8  dcf77_bitpos_u8 = 0;             /* current bit position of DCF77 signal */
static uint16 dcf77_cntms_u16 = 0;             /* 1ms counter for DCF77 signal sampling */
static uint8  dfc77_datatmp_au8[8];            /* data which is currently sampled */
static uint8  dcf77_data_au8[8];               /* valid DCF77 data */
static uint8  dcf77_sync_u8 = DCF77_SYNC_WAIT; /* DCF77 sync state */
 * dcf77_get_sync
bool dcf77_get_sync(void)
    return (dcf77_sync_u8 == DCF77_SYNC_OK);
 * dcf77_get_min (bitpos 21-27)
uint8 dcf77_get_min(void)
    uint8 data1;
    uint8 data2;
    data1 = ((dcf77_data_au8[2] & 0xE0) >> 5);
    data2 = ((dcf77_data_au8[3] & 0x0F) << 3);
    data1 = data1 | data2;
    return (data1);
 * dcf77_get_hrs (bitpos 29-34)
uint8 dcf77_get_hrs(void)
    uint8 data1;
    uint8 data2;
    data1 = ((dcf77_data_au8[3] & 0xE0) >> 5);
    data2 = ((dcf77_data_au8[4] & 0x07) << 3);
    return (data1);
 * dcf77_get_day (bitpos 36-41)
uint8 dcf77_get_day(void)
    uint8 data1;
    uint8 data2;
    data1 = ((dcf77_data_au8[4] & 0xF0) >> 4);
    data2 = ((dcf77_data_au8[5] & 0x03) << 4);
    return (data1);
 * dcf77_get_dow (42 - 44)
uint8 dcf77_get_dow(void)
    uint8 data;
    data = ((dcf77_data_au8[5] >> 2) & 0x7);
    return (data);
 * dcf77_get_month (45 - 49)
uint8 dcf77_get_month(void)
    uint8 data1;
    uint8 data2;
    data1 = ((dcf77_data_au8[5] & 0xE0) >> 5);
    data2 = ((dcf77_data_au8[6] & 0x03) << 3);
    return (data1);
 * dcf77_get_year (50 - 57)
uint16 dcf77_get_year(void)
    uint16 year;
    uint8 data1;
    uint8 data2;
    data1 = ((dcf77_data_au8[6] & 0xFC) >> 2);
    data2 = ((dcf77_data_au8[7] & 0x03) << 6);
    year = data1 | data2;
    /* add century */
    year = year | 0x2000;
    return (year);
 * dcf77_calc_parity
bool dcf77_calc_parity(uint8 data, bool parity)
    uint8 i;
    for (i=0; i < 8; i++)
        parity = parity ^ bit_test(data, i);
    return (parity);
 * dcf77_check_parity
bool dcf77_check_parity(bool parity_in, bool parity)
//printf("dcf77_check_parity\n\r");//******************************************************************************************************
    /* even parity, hence result must be zero for valid parity */
    parity = parity_in ^ parity;
//printf("parity:%x\n\r" parity);//*****************************************************************************************************
    return (parity == 0);
 * dcf77_newdata
bool dcf77_newdata(void)
 //printf("dcf77_newdata\n\r");   
    bool valid;
    bool parity;
    uint8 data;
    /* if sync is OK and */
    /* start of new minute is 0 (start of minute is always 1) */
    /* start of time data is 1 (Zeitbeginn always 1) */
    if ( (dcf77_sync_u8 == DCF77_SYNC_OK) &&
         (!bit_test(dcf77_data_au8[0], 0)) &&
         (bit_test(dcf77_data_au8[2], 4)) )
        /* check for valid minute */
        data = dcf77_get_min();
        parity = dcf77_calc_parity(data, 0);
        valid = dcf77_check_parity(parity, bit_test(dcf77_data_au8[3], 4));
        /* check for valid hour */
        data = dcf77_get_hrs();
        valid = dcf77_check_parity(parity, bit_test(dcf77_data_au8[4], 3));
        /* check for valid date */
        parity = 0;
        data = dcf77_get_day();
        parity = dcf77_calc_parity(data, parity);
        data = dcf77_get_dow();
        data = dcf77_get_month();
        data = dcf77_get_year();
        valid = dcf77_check_parity(parity, bit_test(dcf77_data_au8[7], 2));
    else
        valid = FALSE;
        //printf("parity valid false!\n\r");//*************************************************************************************
    /* if data is valid and new data available */
    valid = (valid && dcf77_newdata_b) ? TRUE : FALSE;
    /* reset new data flag */
    return (valid);
 * dcf77_1ms_task (needs to be called exactly every 1ms, e.g. in timer
 * timer interrupt service routine)
void dcf77_1ms_task(void)
    static uint8 debcnt = 0;
    static bool pindeb_b = 0;
    uint8 index;
    bool data_b;
    bool pin_b;
    /* increment 1ms counter */
    dcf77_cntms_u16 ++;
    /* get current state of data pin */
    pin_b = input(DCF77_PIN_DATA);
    /* --- debounce pin state ---------------------------------------------- */
    if (pin_b == pindeb_b)
        debcnt = 0;
    else
        debcnt ++;
        if (debcnt >= DCF77_DEBOUNCE_TIME)
            pindeb_b = pin_b;
            debcnt = 0;
    /* --- decode DFC77 signal --------------------------------------------- */
    /* check if state of pin has changed */
    if (dcf77_pinold_b != pindeb_b)
        /* falling edge of signal */
        if (pindeb_b == FALSE)
#ifdef DCF77_LED_PULSE
            /* output signal pulse onto LED */
            //output_high(DCF77_LED_PULSE);
#endif /* DCF77_LED_PULSE */
            /* check for start */
            if ( (dcf77_cntms_u16 > DCF77_SIG_START_MIN) && (dcf77_cntms_u16 < DCF77_SIG_START_MAX) )
                /* if we where waiting for 1st sync */
                if (dcf77_sync_u8 == DCF77_SYNC_WAIT)
                    dcf77_sync_u8 = DCF77_SYNC_FIRST;
                    //printf("dcf77_sync_first\n\r");//*************************************************************************************
                /* if 1 valid cycle has been received */
                else if ( (dcf77_sync_u8 >= DCF77_SYNC_FIRST) && (dcf77_bitpos_u8 == 59) )
                    dcf77_sync_u8 = DCF77_SYNC_OK;
                    memcpy(dcf77_data_au8, dfc77_datatmp_au8, 8);
                    dcf77_newdata_b = TRUE;
                    //printf("first valid cycle\n\r");//**************************************************************************************
                /* valid start condition but wrong number of bits deteced during last cycle */
                else
                    //printf("valid start condition but wrong number of bits deteced\n\r");//**************************************************************************************
            /* check for invalid idle time (FIXME: after high wait 800ms idle, after low 900ms idle) */
            else if ( (dcf77_cntms_u16 < DCF77_BIT_IDLE_MIN) || (dcf77_cntms_u16 > DCF77_BIT_IDLE_MAX) )
                //printf("check for invalid idle time\n\r");//*************************************************************************************
            else
                /* bit time OK, keep state */
        /* rising edge of signal */
        else
            /* check for logic "0" */
            if ( (dcf77_cntms_u16 > DCF77_BIT_LOW_MIN) && (dcf77_cntms_u16 < DCF77_BIT_LOW_MAX) )
                data_b = 0;
                //printf("data_b=0\n\r");//*************************************************************************************
            /* check for logic "1" */
            else if ( (dcf77_cntms_u16 > DCF77_BIT_HIGH_MIN) && (dcf77_cntms_u16 < DCF77_BIT_HIGH_MAX) )
                data_b = 1;
                //printf("data_b=1\n\r");//*************************************************************************************
            /* wrong timing detected */
            else
                //printf("wrong timing detect\n\r");//**************************************************************************************
            /* if synchronized and current bit position is valid save bit state */
            if ( (dcf77_sync_u8 >= DCF77_SYNC_FIRST) && (dcf77_bitpos_u8 <= 59) )
                index = dcf77_bitpos_u8 / 8;
                if (data_b)
                    dfc77_datatmp_au8[index] |= (1 << (dcf77_bitpos_u8 % 8));
                else
                    dfc77_datatmp_au8[index] &= ~(1 << (dcf77_bitpos_u8 % 8));
                dcf77_bitpos_u8 ++;
            else
                /* if bit position is greater than 59 then there is something wrong */
            /* output signal pulse onto led */
            //output_low(DCF77_LED_PULSE);
        /* reset ms counter */
    /* save state of data pin */
    dcf77_pinold_b = pindeb_b;
#endif /* _DCF77_H */
