<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="mil" style="lines" multiple="1" display="yes" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="14" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="24" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="2" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="5" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="ReferenceLC" color="13" fill="1" visible="no" active="yes"/>
<layer number="50" name="ReferenceLS" color="12" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<text x="67.3" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="67.7" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="64.9" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="67.7" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D26</text>
<text x="71.904" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="72.304" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="69.504" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="72.304" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D25</text>
<text x="76.507" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="76.908" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="74.108" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="76.908" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D24</text>
<text x="81.111" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="81.511" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="78.711" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="81.511" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D23</text>
<text x="85.715" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="86.115" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="83.315" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="86.115" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D22</text>
<text x="90.319" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="90.719" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="87.919" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="90.719" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D21</text>
<text x="95.081" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="95.481" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="92.681" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="95.481" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D20</text>
<text x="99.685" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="100.085" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="97.285" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="100.085" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D19</text>
<text x="104.289" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="104.689" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="101.889" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="104.689" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D18</text>
<text x="108.892" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="109.293" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="106.493" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="109.293" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D17</text>
<text x="113.496" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="113.896" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="111.096" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="113.896" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D16</text>
<text x="118.1" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="118.5" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="115.7" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="118.5" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D15</text>
<text x="122.704" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="123.104" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="120.304" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="123.104" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D14</text>
<text x="127.307" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="127.707" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="124.908" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="127.707" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D13</text>
<text x="131.911" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="132.311" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="129.511" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="132.311" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D12</text>
<text x="136.515" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="136.915" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="134.115" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="136.915" y="33.442" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D1</text>
<text x="141.119" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="141.519" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="138.719" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="141.519" y="33.442" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D2</text>
<text x="145.722" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="146.122" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="143.322" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="146.122" y="33.442" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D3</text>
<text x="150.326" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="150.726" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="147.926" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="150.726" y="33.442" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D4</text>
<text x="154.93" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="155.33" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="152.53" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="155.33" y="33.442" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D5</text>
<text x="159.534" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="159.934" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="157.134" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="159.934" y="33.442" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D6</text>
<text x="164.137" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="164.538" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="161.738" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="164.538" y="33.442" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D7</text>
<text x="168.741" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="169.141" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="166.341" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="169.141" y="33.442" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D8</text>
<text x="174.932" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="175.332" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="172.533" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="175.332" y="33.442" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D9</text>
<text x="181.124" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="181.524" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="178.724" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="181.524" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D10</text>
<text x="187.315" y="34.7" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="187.715" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="184.915" y="32.43" size="0" layer="21" font="proportional" ratio="10" rot="SR270" align="center-left" distance="92"></text>
<text x="187.715" y="33.942" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">D11</text>
<text x="186.129" y="30.172" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="185.7" y="31.25" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="182.7" y="31.25" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="182.7" y="31.75" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="185.7" y="31.75" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="186.081" y="33.175" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q11</text>
<text x="179.83" y="29.244" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="179.401" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="176.401" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="176.401" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="179.401" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="179.783" y="32.246" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q10</text>
<text x="173.639" y="29.244" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="173.21" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="170.21" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="170.21" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="173.21" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="173.091" y="32.246" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q9</text>
<text x="168.242" y="29.244" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="167.812" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="164.812" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="164.812" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="167.812" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="167.694" y="32.246" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q8</text>
<text x="163.638" y="29.244" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="163.209" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="160.209" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="160.209" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="163.209" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="163.09" y="32.246" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q7</text>
<text x="159.034" y="29.244" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="158.605" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="155.605" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="155.605" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="158.605" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="158.486" y="32.246" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q6</text>
<text x="154.43" y="29.244" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="154.001" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="151.001" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="151.001" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="154.001" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="153.883" y="32.246" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q5</text>
<text x="147.329" y="29.244" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="146.9" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="143.9" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="143.9" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="146.9" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="146.781" y="32.246" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q4</text>
<text x="143.429" y="29.244" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="143" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="140" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="140" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="143" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="142.881" y="32.246" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q3</text>
<text x="139.529" y="29.244" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="139.1" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="136.1" y="30.321" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="136.1" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="139.1" y="30.821" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="138.981" y="32.246" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q2</text>
<text x="136.015" y="30.99" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="135.586" y="32.067" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="132.586" y="32.067" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="132.586" y="32.567" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="135.586" y="32.567" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="135.467" y="33.992" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q1</text>
<text x="122.204" y="30.99" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="121.775" y="32.067" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="118.775" y="32.067" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="118.775" y="32.567" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="121.775" y="32.567" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="122.156" y="33.992" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q12</text>
<text x="108.393" y="30.99" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="107.964" y="32.068" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="104.964" y="32.068" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="104.964" y="32.568" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="107.964" y="32.568" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="108.345" y="33.993" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q13</text>
<text x="94.423" y="30.99" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="93.994" y="32.067" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="90.994" y="32.067" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="90.994" y="32.567" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="93.994" y="32.567" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="94.375" y="33.992" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q14</text>
<text x="80.612" y="30.99" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="80.182" y="32.067" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="77.183" y="32.067" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="77.183" y="32.567" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="80.182" y="32.567" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="80.564" y="33.992" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q15</text>
<text x="66.829" y="32.372" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="66.4" y="33.45" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="63.4" y="33.45" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="63.4" y="33.95" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="66.4" y="33.95" size="0" layer="22" font="proportional" ratio="10" rot="MSR90" align="center-left" distance="92"></text>
<text x="66.781" y="35.375" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">Q16</text>
<text x="185.14" y="26.8" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="180.84" y="27.75" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="175.273" y="27.76" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="169.081" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="164.478" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="159.874" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="155.27" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="150.666" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="146.062" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="141.459" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="136.855" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="132.251" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="127.648" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="123.044" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="118.44" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="113.836" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="109.233" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="104.629" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="100.025" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="95.421" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="90.659" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="86.055" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="81.451" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="76.848" y="26.515" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="72.944" y="27.6" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="69.04" y="27.6" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">470</text>
<text x="114.8" y="21.74" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">10K</text>
<text x="100.837" y="32.547" size="0.987" layer="22" font="proportional" ratio="10" rot="MSR269.998947703871" align="bottom-left" distance="76">10K</text>
<text x="167.4" y="44.24" size="0.987" layer="22" font="proportional" ratio="10" rot="MR359.998316327028" align="bottom-left" distance="76">10K</text>
<text x="114.8" y="30.26" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="top-left" distance="76">10K</text>
<text x="114.8" y="33.46" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="top-left" distance="76">10K</text>
<text x="73.48" y="33.807" size="0.987" layer="22" font="proportional" ratio="10" rot="MSR269.998105867802" align="bottom-left" distance="76">10K</text>
<text x="70.2" y="37.96" size="0.987" layer="21" font="proportional" ratio="10" rot="SR180.001262754521" align="bottom-left" distance="76">1K</text>
<text x="69.722" y="33.817" size="0.987" layer="22" font="proportional" ratio="10" rot="MSR269.998105867802" align="bottom-left" distance="76">10K</text>
<text x="96.234" y="32.547" size="0.987" layer="22" font="proportional" ratio="10" rot="MSR269.997264030899" align="bottom-left" distance="76">10K</text>
<text x="-36.34" y="28.4" size="0.74" layer="21" font="proportional" ratio="10" rot="SR180" align="bottom-left" distance="76">100uF 16V</text>
<text x="124.06" y="34.4" size="0.987" layer="22" font="proportional" ratio="10" rot="MSR269.998105867802" align="bottom-left" distance="76">10K</text>
<text x="128.66" y="34.4" size="0.987" layer="22" font="proportional" ratio="10" rot="MSR269.998947703871" align="bottom-left" distance="76">10K</text>
<text x="111.8" y="26.26" size="0.987" layer="22" font="proportional" ratio="10" rot="MSR179.997895408576" align="bottom-left" distance="76">10K</text>
<text x="159.1" y="24.44" size="0.987" layer="22" font="proportional" ratio="10" rot="MR360" align="bottom-left" distance="76">10K</text>
<text x="124.6" y="23.64" size="0.987" layer="22" font="proportional" ratio="10" rot="MR359.998316327028" align="bottom-left" distance="76">10K</text>
<text x="176" y="42.84" size="0.987" layer="22" font="proportional" ratio="10" rot="MR359.998316327028" align="bottom-left" distance="76">10K</text>
<text x="180.9" y="39.04" size="0.987" layer="22" font="proportional" ratio="10" rot="MR359.998316327028" align="bottom-left" distance="76">10K</text>
<text x="156.8" y="40.04" size="0.987" layer="22" font="proportional" ratio="10" rot="MR359.998316327028" align="bottom-left" distance="76">10K</text>
<text x="-5.2" y="44.24" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">22pF</text>
<text x="-19.6" y="44.24" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">22pF</text>
<text x="11.815" y="22.891" size="0.987" layer="52" font="proportional" ratio="10" rot="MSR269.615907818146" align="center-left" distance="76">TLE4905</text>
<text x="-17.7" y="22.14" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">100nF</text>
<text x="-24" y="36.44" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10K</text>
<text x="-55.405" y="38.34" size="1.727" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">ICSP</text>
<text x="-45.476" y="30.224" size="0" layer="21" font="proportional" ratio="10" rot="R90" align="center-left" distance="92"></text>
<text x="-48.524" y="30.224" size="0" layer="21" font="proportional" ratio="10" rot="R90" align="center-left" distance="92"></text>
<text x="-45.476" y="33.776" size="0" layer="21" font="proportional" ratio="10" rot="R90" align="center-left" distance="92"></text>
<text x="-41.8" y="38.94" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10K</text>
<text x="-48.44" y="41.3" size="0.987" layer="21" font="proportional" ratio="10" rot="R90" align="bottom-left" distance="76">2K2</text>
<text x="-31.74" y="38.633" size="0.987" layer="21" font="proportional" ratio="10" rot="R90" align="bottom-left" distance="76">10K op</text>
<text x="-36.64" y="39.9" size="0.987" layer="21" font="proportional" ratio="10" rot="R90" align="bottom-left" distance="76">10K</text>
<text x="10.9" y="-15.16" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">100nF</text>
<text x="121.3" y="-2.26" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">100nF</text>
<text x="-24" y="28.94" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10K</text>
<text x="-3.6" y="19.46" size="0.987" layer="21" font="proportional" ratio="10" rot="SR180" align="bottom-left" distance="76">10K</text>
<text x="-32.14" y="28.133" size="0.987" layer="21" font="proportional" ratio="10" rot="R90" align="bottom-left" distance="76">100R</text>
<text x="30.197" y="34.39" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10u 25V</text>
<text x="55.911" y="29.047" size="0.987" layer="21" font="proportional" ratio="10" rot="SR90.0010522961288" align="bottom-left" distance="76">100K</text>
<text x="58.61" y="33.81" size="0.987" layer="21" font="proportional" ratio="10" rot="R90" align="bottom-left" distance="76">510K</text>
<text x="51.943" y="29.047" size="0.987" layer="21" font="proportional" ratio="10" rot="SR90.0010522961288" align="bottom-left" distance="76">100K</text>
<text x="54.006" y="34.445" size="0.987" layer="21" font="proportional" ratio="10" rot="SR90.0010522961288" align="bottom-left" distance="76">100K</text>
<hole x="66.3" y="52" drill="3"/>
<hole x="66.3" y="12" drill="3"/>
<text x="71.1" y="42.16" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="76">100nF</text>
<text x="49.86" y="39.349" size="0.987" layer="21" font="proportional" ratio="10" rot="SR90.0010522961288" align="bottom-left" distance="76">100K</text>
<text x="63.853" y="24.616" size="0.987" layer="21" font="proportional" ratio="10" rot="SR117.868877614063" align="top-left" distance="76">100nF</text>
<text x="22.31" y="38.04" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10K</text>
<text x="27.66" y="38.4" size="0.987" layer="21" font="proportional" ratio="10" rot="SR90.0010522961288" align="bottom-left" distance="76">10K</text>
<text x="46.41" y="28.08" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">1K</text>
<text x="23.4" y="24.04" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10K</text>
<text x="33.16" y="37.4" size="0.987" layer="21" font="proportional" ratio="10" rot="SR90.0010522961288" align="bottom-left" distance="76">100nF</text>
<text x="23.4" y="28.14" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10K</text>
<text x="53.82" y="26.7" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10K</text>
<hole x="-30.38" y="8.765" drill="3"/>
<hole x="-30.38" y="-31.235" drill="3"/>
<text x="-33.553" y="-7.69" size="0.987" layer="21" font="proportional" ratio="10" rot="SR180" align="bottom-left" distance="76">330uF 25V</text>
<text x="-19.107" y="-4.35" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">330uF 25V</text>
<text x="-44.51" y="-11.7" size="0.74" layer="21" font="proportional" ratio="10" rot="SR180" align="bottom-left" distance="76">47uF25V</text>
<text x="-44.49" y="-20.19" size="0.74" layer="21" font="proportional" ratio="10" rot="SR180" align="bottom-left" distance="76">47uF25V</text>
<text x="-19.9" y="-25.66" size="0.987" layer="21" font="proportional" ratio="10" rot="R0.00168367297225553" align="top-left" distance="76">100nF</text>
<text x="-23.63" y="0.3" size="0.987" layer="21" font="proportional" ratio="10" rot="SR90.0010522961288" align="top-left" distance="76">100nF</text>
<text x="-43.75" y="-21.747" size="0.987" layer="21" font="proportional" ratio="10" rot="SR270" align="top-left" distance="76">560 R</text>
<hole x="-30.39" y="-11.24" drill="3"/>
<text x="-19.75" y="-17.92" size="0.74" layer="21" font="proportional" ratio="10" rot="R90" align="bottom-left" distance="76">78l05</text>
<text x="15.4" y="-18.97" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">CR 1220</text>
<text x="-40.05" y="-25.13" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="76">Vagy</text>
<hole x="-30.39" y="-1.235" drill="2"/>
<hole x="-30.39" y="-21.235" drill="2"/>
<text x="21.457" y="34.45" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10u 16V</text>
<hole x="5" y="-22.5" drill="3"/>
<hole x="160" y="-13.5" drill="3"/>
<text x="3.9" y="-15.16" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">10K</text>
<text x="164.393" y="-29.307" size="0.987" layer="21" font="proportional" ratio="10" rot="SR225" align="bottom-left" distance="76">DC-10BS</text>
<text x="158.488" y="-24.817" size="0.987" layer="51" font="proportional" ratio="10" rot="SR225" align="center-left" distance="76">12V 2A</text>
<text x="127.3" y="-7.4" size="0.74" layer="21" font="proportional" ratio="10" rot="R270.001473213747" align="bottom-left" distance="76">100uF 16V</text>
<text x="142.533" y="-9.3" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="center-left" distance="76">cap 16,5mm</text>
<text x="101.26" y="-32.2" size="0.987" layer="21" font="proportional" ratio="10" rot="SR90.001894132198" align="bottom-left" distance="76">100K</text>
<text x="99.533" y="-24.26" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">220R</text>
<text x="98.36" y="-15.1" size="0.987" layer="21" font="proportional" ratio="10" rot="R90" align="bottom-left" distance="76">47K</text>
<text x="106.267" y="-23.05" size="0.74" layer="21" font="proportional" ratio="10" rot="SR180" align="bottom-left" distance="76">22uF 25V</text>
<text x="102.5" y="-9.175" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">470K</text>
<text x="89.135" y="-2.167" size="0.74" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">Relé LED</text>
<text x="94" y="-2.06" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">1K</text>
<text x="93.2" y="-7.86" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">1K</text>
<text x="92.2" y="-11.86" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="bottom-left" distance="76">100K</text>
<text x="84.935" y="-2.5" size="0.74" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">IR cLED</text>
<text x="80.635" y="-2.833" size="0.74" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">St LED</text>
<text x="76.335" y="-2.167" size="0.74" layer="21" font="proportional" ratio="10" rot="SR270" align="bottom-left" distance="76">DCF LED</text>
<wire layer="20" width="0.14" x1="-63.217" y1="58.667" x2="195.017" y2="58.667"/>
<wire layer="20" width="0.14" x1="195.017" y1="58.667" x2="195.017" y2="-39.068"/>
<wire layer="20" width="0.14" x1="195.017" y1="-39.068" x2="-63.217" y2="-39.068"/>
<wire layer="20" width="0.14" x1="-63.217" y1="-39.068" x2="-63.217" y2="58.667"/>
<text x="-58.201" y="37.06" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">MCLR</text>
<text x="-57.595" y="34.75" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">VDD</text>
<text x="-57.665" y="32.3" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">GND</text>
<text x="-57.535" y="29.68" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">PGD</text>
<text x="-57.446" y="26.98" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">PGC</text>
<wire layer="21" width="0.1" x1="-41.419" y1="27.027" x2="-34.275" y2="27.027"/>
<wire layer="21" width="0.1" x1="-34.275" y1="27.027" x2="-34.275" y2="20.836"/>
<wire layer="21" width="0.1" x1="-34.275" y1="20.836" x2="-41.419" y2="20.836"/>
<wire layer="21" width="0.1" x1="-41.419" y1="20.836" x2="-41.419" y2="27.027"/>
<circle layer="29" x="-34.189" y="34.222" radius="0.35" width="0"/>
<circle layer="29" x="-36.729" y="34.222" radius="0.35" width="0"/>
<circle layer="30" x="-36.729" y="34.222" radius="0.35" width="0"/>
<wire layer="46" width="0" x1="0" y1="0" x2="165" y2="0"/>
<wire layer="46" width="0" x1="165" y1="0" x2="165" y2="-35"/>
<wire layer="46" width="0" x1="165" y1="-35" x2="0" y2="-35"/>
<wire layer="46" width="0" x1="0" y1="-35" x2="0" y2="0"/>
<wire layer="46" width="0" x1="76.3" y1="56" x2="89.795" y2="45.166" curve="77.516928"/>
<wire layer="46" width="0" x1="89.795" y1="18.852" x2="76.3" y2="8.018" curve="77.516535"/>
<wire layer="46" width="0" x1="89.795" y1="45.166" x2="180.235" y2="45.197"/>
<wire layer="46" width="0" x1="43.44" y1="46.303" x2="56.299" y2="56" curve="71.403942"/>
<wire layer="46" width="0" x1="56.299" y1="8.045" x2="43.44" y2="17.741" curve="71.404202"/>
<wire layer="46" width="0" x1="76.326" y1="55.941" x2="56.272" y2="55.974" curve="109.219558"/>
<wire layer="46" width="0" x1="56.272" y1="8.051" x2="76.326" y2="8.084" curve="109.219558"/>
<wire layer="46" width="0" x1="180.235" y1="18.803" x2="180.235" y2="45.197" curve="166.480413"/>
<wire layer="46" width="0" x1="-46.951" y1="46.295" x2="-46.951" y2="17.705" curve="169.99982"/>
<wire layer="46" width="0" x1="89.795" y1="18.852" x2="180.235" y2="18.803"/>
<wire layer="46" width="0" x1="-46.951" y1="17.705" x2="43.44" y2="17.741"/>
<wire layer="46" width="0" x1="-46.951" y1="46.295" x2="43.44" y2="46.303"/>
<circle layer="46" x="-30.42" y="-11.205" radius="25" width="0"/>
<text x="-19.75" y="3.87" size="1.727" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">GND</text>
<text x="18" y="-0.1" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="76">5V</text>
<text x="31.8" y="-32.8" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">GND</text>
<text x="18" y="-13" size="0.74" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">INT</text>
<text x="26.9" y="-10.2" size="0.493" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">SCL</text>
<text x="26.8" y="-11.5" size="0.493" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">SDA</text>
<text x="155.6" y="-3.9" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">12 V</text>
<text x="155.6" y="-1.4" size="0.987" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">5 V</text>
<text x="96.9" y="-24.4" size="1.48" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">13</text>
<text x="88.6" y="-7.9" size="1.48" layer="21" font="proportional" ratio="10" rot="R0" align="top-left" distance="92">27</text>
</plain>
<libraries>
<library name="common">
<packages>
<package name="KINGBRIGHT_AA3528SGS">
<description>Part Number (Digi-Key): 754-1538-6-ND
Unique Name: KINGBRIGHT_AA3528SGS</description>
<smd name="2" x="1.4" y="0" layer="1" dx="1.5" dy="2.2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="1" x="-1.4" y="0" layer="1" dx="1.5" dy="2.2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.25" x1="-2.7" y1="1" x2="-2.7" y2="-1"/>
<wire layer="21" width="0.25" x1="-0.43" y1="1.4" x2="0.43" y2="1.4"/>
<wire layer="21" width="0.25" x1="-0.43" y1="-1.4" x2="0.43" y2="-1.4"/>
</package>
<package name="SOT23">
<smd name="1" x="-1.15" y="0.95" layer="1" dx="0.65" dy="1.05" roundness="50" rot="R90" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="-1.15" y="-0.95" layer="1" dx="0.65" dy="1.05" roundness="50" rot="R90" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="1.15" y="0" layer="1" dx="0.65" dy="1.05" roundness="50" rot="R90" stop="yes" cream="yes" thermals="no"/>
<circle layer="21" x="-1.524" y="1.734" radius="0.196" width="0"/>
<wire layer="21" width="0.25" x1="-0.25" y1="1.5" x2="-0.25" y2="-1.5"/>
<wire layer="21" width="0.25" x1="-0.25" y1="-1.5" x2="0.25" y2="-1.5"/>
<wire layer="21" width="0.25" x1="0.25" y1="-1.5" x2="0.25" y2="1.5"/>
<wire layer="21" width="0.25" x1="0.25" y1="1.5" x2="-0.25" y2="1.5"/>
</package>
<package name="RES_1206_M">
<description>Unique Name: RES_1206_INCH</description>
<smd name="1" x="-1.52" y="0" layer="1" dx="1.23" dy="1.87" roundness="41" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="1.52" y="0" layer="1" dx="1.23" dy="1.87" roundness="41" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.15" x1="-0.68" y1="0.88" x2="0.68" y2="0.88"/>
<wire layer="21" width="0.15" x1="-0.68" y1="-0.88" x2="0.68" y2="-0.88"/>
<wire layer="51" width="0.12" x1="-1.68" y1="0.88" x2="1.68" y2="0.88"/>
<wire layer="51" width="0.12" x1="1.68" y1="0.88" x2="1.68" y2="-0.88"/>
<wire layer="51" width="0.12" x1="1.68" y1="-0.88" x2="-1.68" y2="-0.88"/>
<wire layer="51" width="0.12" x1="-1.68" y1="-0.88" x2="-1.68" y2="0.88"/>
</package>
<package name="RES_1206_M_R1-26">
</package>
<package name="RES_1206_M_R1-29">
</package>
<package name="CAPAE660X600L260X70N">
<description>Part Number (Digi-Key): P16436DKR-ND
Unique Name: PANASONIC_SVP,SIZE_C6_CAPP</description>
<smd name="1" x="-2.595" y="0" layer="1" dx="3.3" dy="1.63" roundness="31" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="2.595" y="0" layer="1" dx="3.3" dy="1.63" roundness="31" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.12" x1="3.4" y1="1" x2="3.4" y2="3.4"/>
<wire layer="21" width="0.12" x1="3.4" y1="3.4" x2="-2.03" y2="3.4"/>
<wire layer="21" width="0.12" x1="-2.03" y1="3.4" x2="-3.4" y2="2.03"/>
<wire layer="21" width="0.12" x1="-3.4" y1="2.03" x2="-3.4" y2="1"/>
<wire layer="21" width="0.12" x1="3.4" y1="-1" x2="3.4" y2="-3.4"/>
<wire layer="21" width="0.12" x1="3.4" y1="-3.4" x2="-2.03" y2="-3.4"/>
<wire layer="21" width="0.12" x1="-2.03" y1="-3.4" x2="-3.4" y2="-2.03"/>
<wire layer="21" width="0.12" x1="-3.4" y1="-2.03" x2="-3.4" y2="-1"/>
<wire layer="51" width="0.12" x1="3.4" y1="3.4" x2="3.4" y2="-3.4"/>
<wire layer="51" width="0.12" x1="3.4" y1="-3.4" x2="-2.03" y2="-3.4"/>
<wire layer="51" width="0.12" x1="-2.03" y1="-3.4" x2="-3.4" y2="-2.04"/>
<wire layer="51" width="0.12" x1="-3.4" y1="-2.04" x2="-3.4" y2="2.03"/>
<wire layer="51" width="0.12" x1="-3.4" y1="2.03" x2="-2.03" y2="3.4"/>
<wire layer="51" width="0.12" x1="-2.03" y1="3.4" x2="3.4" y2="3.4"/>
<text x="-3.167" y="0" size="0.74" layer="51" font="vector" ratio="10" rot="R0" align="center-left" distance="76">Cap 6,3mm</text>
</package>
<package name="SOIC28P127_1790X1030X265L83X41N_AD1">
<description>Part Number (Digi-Key): PIC16F886-I/SO-ND
Unique Name: MICROCHIP_C04-052C</description>
<smd name="1" x="-8.255" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="-6.985" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="-5.715" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="4" x="-4.445" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="5" x="-3.175" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="6" x="-1.905" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="7" x="-0.635" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="8" x="0.635" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="9" x="1.905" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="10" x="3.175" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="11" x="4.445" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="12" x="5.715" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="13" x="6.985" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="14" x="8.255" y="-4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="15" x="8.255" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="16" x="6.985" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="17" x="5.715" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="18" x="4.445" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="19" x="3.175" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="20" x="1.905" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="21" x="0.635" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="22" x="-0.635" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="23" x="-1.905" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="24" x="-3.175" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="25" x="-4.445" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="26" x="-5.715" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="27" x="-6.985" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="28" x="-8.255" y="4.555" layer="1" dx="0.66" dy="2" roundness="52" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.12" x1="-8.77" y1="3.75" x2="-8.95" y2="3.75"/>
<wire layer="21" width="0.12" x1="-8.95" y1="3.75" x2="-8.95" y2="-3.75"/>
<wire layer="21" width="0.12" x1="-8.95" y1="-3.75" x2="-8.77" y2="-3.75"/>
<wire layer="21" width="0.12" x1="8.77" y1="3.75" x2="8.95" y2="3.75"/>
<wire layer="21" width="0.12" x1="8.95" y1="3.75" x2="8.95" y2="-3.75"/>
<wire layer="21" width="0.12" x1="8.95" y1="-3.75" x2="8.77" y2="-3.75"/>
<circle layer="21" x="-8.96" y="-5.31" radius="0.25" width="0"/>
<wire layer="51" width="0.12" x1="-8.95" y1="3.75" x2="8.95" y2="3.75"/>
<wire layer="51" width="0.12" x1="8.95" y1="3.75" x2="8.95" y2="-3.75"/>
<wire layer="51" width="0.12" x1="8.95" y1="-3.75" x2="-7.95" y2="-3.75"/>
<wire layer="51" width="0.12" x1="-7.95" y1="-3.75" x2="-8.95" y2="-2.75"/>
<wire layer="51" width="0.12" x1="-8.95" y1="-2.75" x2="-8.95" y2="3.75"/>
</package>
<package name="SIP226W48P254L1483H495Q6_AP1">
<pad name="1" x="0" y="0" drill="0.6" shape="long" diameter="1" rot="R90" stop="yes" thermals="no"/>
<pad name="2" x="1.27" y="0" drill="0.6" shape="square" diameter="1" rot="R0" stop="no" thermals="no"/>
<polygon layer="1" width="0.002">
<vertex x="0.771" y="0.999"/>
<vertex x="1.769" y="0.999"/>
<vertex x="1.769" y="-0.999"/>
<vertex x="0.771" y="-0.999"/>
</polygon>
<polygon layer="16" width="0.002">
</polygon>
<rectangle x1="0.72" y1="1.05" x2="1.82" y2="-1.05" layer="30" rot="R0"/>
<rectangle x1="0.67" y1="1.1" x2="1.87" y2="-1.1" layer="29" rot="R0"/>
<pad name="3" x="2.54" y="0" drill="0.6" shape="long" diameter="1" rot="R90" stop="yes" thermals="no"/>
<wire layer="21" width="0.25" x1="-0.903" y1="5.606" x2="3.384" y2="5.606"/>
<wire layer="21" width="0.25" x1="3.384" y1="5.606" x2="3.384" y2="-1.379"/>
<wire layer="21" width="0.25" x1="3.384" y1="-1.379" x2="-0.903" y2="-1.379"/>
<wire layer="21" width="0.25" x1="-0.903" y1="-1.379" x2="-0.903" y2="5.606"/>
<text x="-0.3" y="2.85" size="0.987" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">1</text>
<text x="-1.5" y="0.8" size="1.974" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">.</text>
<text x="0.85" y="2.85" size="0.987" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">2</text>
<text x="2.15" y="2.85" size="0.987" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">3</text>
<text x="-1.275" y="-0.386" size="0.987" layer="21" font="vector" ratio="10" rot="R90" align="bottom-left" distance="76">Hall IC</text>
</package>
<package name="ICSP">
<pad name="1" x="0" y="0" drill="1" shape="square" diameter="2" rot="R0" stop="yes" thermals="no"/>
<pad name="2" x="2.54" y="0" drill="1" diameter="2" rot="R0" stop="yes" thermals="no"/>
<pad name="3" x="5.08" y="0" drill="1" diameter="2" rot="R0" stop="yes" thermals="no"/>
<pad name="4" x="7.62" y="0" drill="1" diameter="2" rot="R0" stop="yes" thermals="no"/>
<pad name="5" x="10.16" y="0" drill="1" diameter="2" rot="R0" stop="yes" thermals="no"/>
<wire layer="21" width="0.12" x1="-0.15" y1="1.3" x2="-0.75" y2="1.3"/>
<wire layer="21" width="0.12" x1="-0.75" y1="1.3" x2="-0.75" y2="-1.15"/>
<wire layer="21" width="0.12" x1="-0.75" y1="-1.15" x2="-0.2" y2="-1.15"/>
<wire layer="21" width="0.12" x1="11.2" y1="1.3" x2="11.65" y2="1.3"/>
<wire layer="21" width="0.12" x1="11.65" y1="1.3" x2="11.65" y2="-1.15"/>
<wire layer="21" width="0.12" x1="11.65" y1="-1.15" x2="11.15" y2="-1.15"/>
<circle layer="21" x="0.05" y="-1.5" radius="0.25" width="0"/>
<wire layer="51" width="0.12" x1="-1.02" y1="1.19" x2="11.8" y2="1.2"/>
<wire layer="51" width="0.12" x1="11.8" y1="1.2" x2="11.8" y2="-1.05"/>
<wire layer="51" width="0.12" x1="11.8" y1="-1.05" x2="-1.02" y2="-1.07"/>
<wire layer="51" width="0.12" x1="-1.02" y1="-1.07" x2="-1.02" y2="-0.317"/>
<wire layer="51" width="0.12" x1="-1.02" y1="-0.317" x2="-0.85" y2="0.05"/>
<wire layer="51" width="0.12" x1="-0.85" y1="0.05" x2="-1.02" y2="0.437"/>
<wire layer="51" width="0.12" x1="-1.02" y1="0.437" x2="-1.02" y2="1.19"/>
</package>
<package name="TSOP18XX">
<description>Description: Remote Receiver Sensor, 36.0kHz 45m Through Hole</description>
<pad name="GND" x="-0.001" y="-0.027" drill="0.813" shape="square" diameter="1.321" rot="R180" stop="no" thermals="no"/>
<vertex x="0.658" y="-1.347"/>
<vertex x="-0.661" y="-1.347"/>
<vertex x="-0.661" y="1.293"/>
<vertex x="0.658" y="1.293"/>
</polygon>
</polygon>
<rectangle x1="-0.712" y1="1.344" x2="0.709" y2="-1.397" layer="30" rot="R180"/>
<rectangle x1="-0.762" y1="1.394" x2="0.759" y2="-1.447" layer="29" rot="R180"/>
<pad name="OUT" x="-2.501" y="-0.027" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="VCC" x="2.499" y="-0.027" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<wire layer="21" width="0.127" x1="-2.501" y1="-2.027" x2="-3.001" y2="-0.027"/>
<wire layer="21" width="0.127" x1="-3.001" y1="-0.027" x2="-2.501" y2="1.973"/>
<wire layer="21" width="0.127" x1="-2.501" y1="1.973" x2="2.499" y2="1.973"/>
<wire layer="21" width="0.127" x1="2.499" y1="1.973" x2="2.999" y2="-0.027"/>
<wire layer="21" width="0.127" x1="2.999" y1="-0.027" x2="2.499" y2="-2.027"/>
<wire layer="21" width="0.127" x1="2.499" y1="-2.027" x2="1.999" y2="-2.027"/>
<wire layer="21" width="0.127" x1="1.999" y1="-2.027" x2="-2.001" y2="-2.027"/>
<wire layer="21" width="0.127" x1="-2.001" y1="-2.027" x2="-2.501" y2="-2.027"/>
<wire layer="21" width="0.127" x1="-2.001" y1="-2.027" x2="1.999" y2="-2.027" curve="138.892671"/>
<text x="-3.168" y="1.973" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">TSOP4836</text>
</package>
<package name="CAP-2.54/6.6x3">
<description>Unique Name: CAP-2.54/6.6x3</description>
<pad name="2" x="1.27" y="0" drill="1" diameter="2" rot="R0" stop="yes" thermals="no"/>
<pad name="1" x="-1.27" y="0" drill="1" shape="square" diameter="1.6" rot="R0" stop="yes" thermals="no"/>
<wire layer="21" width="0.25" x1="-1.776" y1="-1.524" x2="1.776" y2="-1.524"/>
<wire layer="21" width="0.25" x1="-1.776" y1="1.524" x2="1.776" y2="1.524"/>
<wire layer="21" width="0.25" x1="1.776" y1="-1.524" x2="1.776" y2="1.524" curve="180.115235"/>
<wire layer="21" width="0.25" x1="-1.776" y1="1.524" x2="-1.776" y2="-1.524" curve="180.115235"/>
<text x="-2.833" y="1.524" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">JUMPER</text>
</package>
<package name="BPX_81">
<pad name="1" x="0" y="-0.778" drill="1" diameter="2" rot="R180" stop="no" thermals="no"/>
<pad name="2" x="0" y="1.762" drill="1" diameter="2" rot="R180" stop="no" thermals="no"/>
<circle layer="21" x="-0.03" y="-2.618" radius="0.143" width="0.2"/>
<circle layer="51" x="-0.03" y="-2.618" radius="0.143" width="0.2"/>
<wire layer="51" width="0.127" x1="-0.575" y1="1.542" x2="0.575" y2="1.542"/>
<wire layer="51" width="0.127" x1="0.575" y1="1.542" x2="0.575" y2="-0.558"/>
<wire layer="51" width="0.127" x1="0.575" y1="-0.558" x2="-0.575" y2="-0.558"/>
<wire layer="51" width="0.127" x1="-0.575" y1="-0.558" x2="-0.575" y2="1.542"/>
<wire layer="21" width="0.127" x1="-0.575" y1="0.292" x2="-0.575" y2="0.692"/>
<wire layer="21" width="0.127" x1="0.575" y1="0.292" x2="0.575" y2="0.692"/>
<wire layer="51" width="0.25" x1="-1.27" y1="1.83" x2="1.27" y2="1.83"/>
<wire layer="51" width="0.25" x1="1.27" y1="1.83" x2="1.27" y2="-0.71"/>
<wire layer="51" width="0.25" x1="1.27" y1="-0.71" x2="-1.27" y2="-0.71"/>
<wire layer="51" width="0.25" x1="-1.27" y1="-0.71" x2="-1.27" y2="1.83"/>
<text x="0.952" y="-0.794" size="1.233" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">C</text>
<text x="1.429" y="1.111" size="1.48" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">-</text>
<text x="-1.27" y="-2.333" size="0.74" layer="21" font="vector" ratio="10" rot="R90" align="bottom-left" distance="76">BPX 81</text>
</package>
<package name="SO8-7_5">
<description>Description: Real Time Clock (RTC) IC Clock/Calendar 240B I&#178;C, 2-Wire Serial 8-SOIC (0.295&quot;, 7.50mm Width)</description>
<smd name="3" x="0.635" y="-4.845" layer="1" dx="0.8" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="5" x="1.905" y="4.845" layer="1" dx="0.8" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="6" x="0.635" y="4.845" layer="1" dx="0.8" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="7" x="-0.635" y="4.845" layer="1" dx="0.8" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="1" x="-1.905" y="-4.845" layer="1" dx="0.8" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="-0.635" y="-4.845" layer="1" dx="0.8" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="4" x="1.905" y="-4.845" layer="1" dx="0.8" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="8" x="-1.905" y="4.845" layer="1" dx="0.8" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.203" x1="-3.7" y1="-3.7" x2="3.7" y2="-3.7"/>
<wire layer="21" width="0.203" x1="3.7" y1="-3.7" x2="3.7" y2="3.7"/>
<wire layer="21" width="0.203" x1="3.7" y1="3.7" x2="-3.7" y2="3.7"/>
<wire layer="21" width="0.203" x1="-3.7" y1="3.7" x2="-3.7" y2="-3.7"/>
<wire layer="21" width="0.203" x1="-3.5" y1="-3" x2="3.5" y2="-3"/>
<wire layer="21" width="0.203" x1="-3.75" y1="-1" x2="-3.75" y2="1" curve="180"/>
<text x="-3.75" y="-2.667" size="0.74" layer="21" font="vector" ratio="10" rot="R90" align="bottom-left" distance="76">PCF8583</text>
<rectangle x1="-2.155" y1="-3.75" x2="-1.655" y2="-5.3" layer="51" rot="R0"/>
<rectangle x1="-0.885" y1="-3.75" x2="-0.385" y2="-5.3" layer="51" rot="R0"/>
<rectangle x1="0.385" y1="-3.75" x2="0.885" y2="-5.3" layer="51" rot="R0"/>
<rectangle x1="1.655" y1="-3.75" x2="2.155" y2="-5.3" layer="51" rot="R0"/>
<rectangle x1="1.655" y1="5.3" x2="2.155" y2="3.75" layer="51" rot="R0"/>
<rectangle x1="0.385" y1="5.3" x2="0.885" y2="3.75" layer="51" rot="R0"/>
<rectangle x1="-0.885" y1="5.3" x2="-0.385" y2="3.75" layer="51" rot="R0"/>
</package>
<package name="SOT95P280X145-5N">
<description>Description: Temperature Sensor Digital, Local -55&#176;C ~ 125&#176;C 11 b SOT-23-5</description>
<smd name="1" x="-1.255" y="0.95" layer="1" dx="1.21" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="-1.255" y="0" layer="1" dx="1.21" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="-1.255" y="-0.95" layer="1" dx="1.21" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="4" x="1.255" y="-0.95" layer="1" dx="1.21" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="5" x="1.255" y="0.95" layer="1" dx="1.21" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<circle layer="21" x="-2.41" y="1.05" radius="0.1" width="0"/>
<circle layer="51" x="-2.41" y="1.05" radius="0.1" width="0"/>
<text x="-4.2" y="1.7" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">MCP9800A5T</text>
<wire layer="21" width="0.127" x1="-0.8" y1="1.565" x2="0.8" y2="1.565"/>
<wire layer="21" width="0.127" x1="0.8" y1="-1.565" x2="-0.8" y2="-1.565"/>
<wire layer="51" width="0.127" x1="-0.8" y1="-1.45" x2="-0.8" y2="1.45"/>
<wire layer="51" width="0.127" x1="0.8" y1="1.45" x2="0.8" y2="-1.45"/>
<wire layer="51" width="0.127" x1="-0.8" y1="1.45" x2="0.8" y2="1.45"/>
<wire layer="51" width="0.127" x1="0.8" y1="-1.45" x2="-0.8" y2="-1.45"/>
</package>
<package name="SOD2513X120N">
<description>Description: Diode Schottky 30V 200mA (DC) Surface Mount SOD-323</description>
<smd name="C" x="-1.19" y="0" layer="1" dx="1.04" dy="0.46" roundness="50" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="A" x="1.19" y="0" layer="1" dx="1.04" dy="0.46" roundness="50" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="51" width="0.127" x1="-0.9" y1="-0.7" x2="-0.9" y2="0.7"/>
<wire layer="51" width="0.127" x1="-0.9" y1="0.7" x2="0.9" y2="0.7"/>
<wire layer="51" width="0.127" x1="0.9" y1="0.7" x2="0.9" y2="-0.7"/>
<wire layer="51" width="0.127" x1="0.9" y1="-0.7" x2="-0.9" y2="-0.7"/>
<wire layer="21" width="0.127" x1="-0.84" y1="0.7" x2="0.84" y2="0.7"/>
<wire layer="21" width="0.127" x1="-0.84" y1="-0.7" x2="0.84" y2="-0.7"/>
<circle layer="21" x="-2.2" y="0" radius="0.1" width="0"/>
<circle layer="51" x="-2.2" y="0" radius="0.1" width="0"/>
<text x="-3.337" y="0.95" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">BAT43WS</text>
</package>
<package name="8-30_pF">
<smd name="1" x="-2.064" y="0" layer="1" dx="1.23" dy="1.87" roundness="41" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="2.064" y="0" layer="1" dx="1.23" dy="1.87" roundness="41" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.15" x1="0.635" y1="-0.594" x2="0.635" y2="0.766"/>
<wire layer="21" width="0.15" x1="-0.476" y1="-0.607" x2="-0.476" y2="0.753"/>
<wire layer="51" width="0.12" x1="-2.25" y1="1.6" x2="2.25" y2="1.6"/>
<wire layer="51" width="0.12" x1="2.25" y1="1.6" x2="2.25" y2="-1.6"/>
<wire layer="51" width="0.12" x1="2.25" y1="-1.6" x2="-2.25" y2="-1.6"/>
<wire layer="51" width="0.12" x1="-2.25" y1="-1.6" x2="-2.25" y2="1.6"/>
<text x="-2" y="-1.6" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="76">8-30 pF</text>
</package>
<package name="JXS32_20Mhz">
<smd name="2" x="-1.044" y="-1.097" layer="1" dx="1.1" dy="1.3" rot="R270" stop="yes" cream="yes" thermals="no"/>
<smd name="4" x="1.495" y="1.097" layer="1" dx="1.1" dy="1.3" rot="R270" stop="yes" cream="yes" thermals="no"/>
<smd name="1" x="-1.159" y="1.097" layer="1" dx="1.1" dy="1.3" rot="R270" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="1.495" y="-1.097" layer="1" dx="1.1" dy="1.3" rot="R270" stop="yes" cream="yes" thermals="no"/>
<wire layer="51" width="0.127" x1="1.813" y1="1.284" x2="1.813" y2="-1.097"/>
<wire layer="51" width="0.127" x1="1.813" y1="-1.097" x2="-1.409" y2="-1.077"/>
<wire layer="51" width="0.127" x1="-1.409" y1="-1.077" x2="-1.409" y2="1.423"/>
<wire layer="51" width="0.127" x1="-1.409" y1="1.423" x2="1.813" y2="1.442"/>
<circle layer="21" x="-2.059" y="1.072" radius="0.086" width="0"/>
<text x="-4" y="1.647" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">JXS32 20Mhz</text>
</package>
<package name="JTX310_32,768_Mhz">
<wire layer="51" width="0.25" x1="-0.794" y1="0" x2="-0.476" y2="0"/>
<wire layer="51" width="0.25" x1="-0.317" y1="0.317" x2="-0.317" y2="-0.317"/>
<wire layer="51" width="0.25" x1="0.317" y1="0.317" x2="0.317" y2="-0.317"/>
<wire layer="51" width="0.25" x1="0.476" y1="0" x2="0.794" y2="0"/>
<wire layer="51" width="0.25" x1="-0.159" y1="0.317" x2="0.159" y2="0.317"/>
<wire layer="51" width="0.25" x1="0.159" y1="0.317" x2="0.159" y2="-0.317"/>
<wire layer="51" width="0.25" x1="0.159" y1="-0.317" x2="-0.159" y2="-0.317"/>
<wire layer="51" width="0.25" x1="-0.159" y1="-0.317" x2="-0.159" y2="0.317"/>
<text x="-5.5" y="0.935" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">JTX310 32,768 Mhz</text>
</package>
<package name="CAPAE430X550L200X70N">
<description>Part Number (Digi-Key): P16427DKR-ND
Unique Name: PANASONIC_SVP,SIZE_A5_CAPP</description>
<smd name="1" x="-1.745" y="0" layer="1" dx="2.7" dy="1.63" roundness="31" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="1.745" y="0" layer="1" dx="2.7" dy="1.63" roundness="31" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.12" x1="2.25" y1="1" x2="2.25" y2="2.25"/>
<wire layer="21" width="0.12" x1="2.25" y1="2.25" x2="-1.34" y2="2.25"/>
<wire layer="21" width="0.12" x1="-1.34" y1="2.25" x2="-2.25" y2="1.34"/>
<wire layer="21" width="0.12" x1="-2.25" y1="1.34" x2="-2.25" y2="1"/>
<wire layer="21" width="0.12" x1="2.25" y1="-1" x2="2.25" y2="-2.25"/>
<wire layer="21" width="0.12" x1="2.25" y1="-2.25" x2="-1.34" y2="-2.25"/>
<wire layer="21" width="0.12" x1="-1.34" y1="-2.25" x2="-2.25" y2="-1.34"/>
<wire layer="21" width="0.12" x1="-2.25" y1="-1.34" x2="-2.25" y2="-1"/>
<wire layer="51" width="0.12" x1="2.25" y1="2.25" x2="2.25" y2="-2.25"/>
<wire layer="51" width="0.12" x1="2.25" y1="-2.25" x2="-1.34" y2="-2.25"/>
<wire layer="51" width="0.12" x1="-1.34" y1="-2.25" x2="-2.25" y2="-1.35"/>
<wire layer="51" width="0.12" x1="-2.25" y1="-1.35" x2="-2.25" y2="1.34"/>
<wire layer="51" width="0.12" x1="-2.25" y1="1.34" x2="-1.34" y2="2.25"/>
<wire layer="51" width="0.12" x1="-1.34" y1="2.25" x2="2.25" y2="2.25"/>
<text x="-2.667" y="0" size="0.74" layer="51" font="vector" ratio="10" rot="R0" align="center-left" distance="76">Cap 4mm</text>
</package>
<package name="IRF7416">
<smd name="1" x="-1.933" y="1.867" layer="1" dx="1.97" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="-1.933" y="0.597" layer="1" dx="1.97" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="-1.933" y="-0.673" layer="1" dx="1.97" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="4" x="-1.933" y="-1.942" layer="1" dx="1.97" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="5" x="3.018" y="-1.942" layer="1" dx="1.97" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="6" x="3.018" y="-0.673" layer="1" dx="1.97" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="7" x="3.018" y="0.597" layer="1" dx="1.97" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="8" x="3.018" y="1.867" layer="1" dx="1.97" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<circle layer="21" x="-3.903" y="2.457" radius="0.1" width="0"/>
<circle layer="51" x="-3.903" y="2.457" radius="0.1" width="0"/>
<wire layer="51" width="0.127" x1="-1.408" y1="2.413" x2="2.492" y2="2.413"/>
<wire layer="51" width="0.127" x1="-1.408" y1="-2.487" x2="2.492" y2="-2.487"/>
<wire layer="21" width="0.127" x1="-1.408" y1="2.482" x2="2.492" y2="2.482"/>
<wire layer="21" width="0.127" x1="-1.408" y1="-2.558" x2="2.492" y2="-2.558"/>
<wire layer="51" width="0.127" x1="-1.408" y1="2.413" x2="-1.408" y2="-2.487"/>
<wire layer="51" width="0.127" x1="2.492" y1="2.413" x2="2.492" y2="-2.487"/>
<text x="-0.251" y="2.344" size="0.493" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">S</text>
<text x="-0.251" y="-0.196" size="0.493" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">S</text>
<text x="-0.251" y="1.074" size="0.493" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">S</text>
<text x="0.86" y="1.074" size="0.493" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">D</text>
<text x="0.86" y="2.344" size="0.493" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">D</text>
<text x="0.86" y="-0.196" size="0.493" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">D</text>
<text x="0.86" y="-1.466" size="0.493" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">D</text>
<text x="-0.251" y="-1.466" size="0.493" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">G</text>
<text x="-2.333" y="2.558" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">IRF7416</text>
</package>
<package name="SOIC127P600X175-8N">
<description>Description: General Purpose Amplifier 2 Circuit  8-SOIC</description>
<smd name="8" x="2.475" y="1.905" layer="1" dx="1.97" dy="0.57" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="-2.475" y="0.635" layer="1" dx="1.97" dy="0.57" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="-2.475" y="-0.635" layer="1" dx="1.97" dy="0.57" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="6" x="2.475" y="-0.635" layer="1" dx="1.97" dy="0.57" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="5" x="2.475" y="-1.905" layer="1" dx="1.97" dy="0.57" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="1" x="-2.475" y="1.905" layer="1" dx="1.97" dy="0.57" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="7" x="2.475" y="0.635" layer="1" dx="1.97" dy="0.57" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="4" x="-2.475" y="-1.905" layer="1" dx="1.97" dy="0.57" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="51" width="0" x1="-2.007" y1="1.651" x2="-2.007" y2="2.159"/>
<wire layer="51" width="0" x1="-2.007" y1="2.159" x2="-3.099" y2="2.159"/>
<wire layer="51" width="0" x1="-3.099" y1="2.159" x2="-3.099" y2="1.651"/>
<wire layer="51" width="0" x1="-3.099" y1="1.651" x2="-2.007" y2="1.651"/>
<wire layer="51" width="0" x1="-2.007" y1="0.381" x2="-2.007" y2="0.889"/>
<wire layer="51" width="0" x1="-2.007" y1="0.889" x2="-3.099" y2="0.889"/>
<wire layer="51" width="0" x1="-3.099" y1="0.889" x2="-3.099" y2="0.381"/>
<wire layer="51" width="0" x1="-3.099" y1="0.381" x2="-2.007" y2="0.381"/>
<wire layer="51" width="0" x1="-2.007" y1="-0.889" x2="-2.007" y2="-0.381"/>
<wire layer="51" width="0" x1="-2.007" y1="-0.381" x2="-3.099" y2="-0.381"/>
<wire layer="51" width="0" x1="-3.099" y1="-0.381" x2="-3.099" y2="-0.889"/>
<wire layer="51" width="0" x1="-3.099" y1="-0.889" x2="-2.007" y2="-0.889"/>
<wire layer="51" width="0" x1="-2.007" y1="-2.159" x2="-2.007" y2="-1.651"/>
<wire layer="51" width="0" x1="-2.007" y1="-1.651" x2="-3.099" y2="-1.651"/>
<wire layer="51" width="0" x1="-3.099" y1="-1.651" x2="-3.099" y2="-2.159"/>
<wire layer="51" width="0" x1="-3.099" y1="-2.159" x2="-2.007" y2="-2.159"/>
<wire layer="51" width="0" x1="2.007" y1="-1.651" x2="2.007" y2="-2.159"/>
<wire layer="51" width="0" x1="2.007" y1="-2.159" x2="3.099" y2="-2.159"/>
<wire layer="51" width="0" x1="3.099" y1="-2.159" x2="3.099" y2="-1.651"/>
<wire layer="51" width="0" x1="3.099" y1="-1.651" x2="2.007" y2="-1.651"/>
<wire layer="51" width="0" x1="2.007" y1="-0.381" x2="2.007" y2="-0.889"/>
<wire layer="51" width="0" x1="2.007" y1="-0.889" x2="3.099" y2="-0.889"/>
<wire layer="51" width="0" x1="3.099" y1="-0.889" x2="3.099" y2="-0.381"/>
<wire layer="51" width="0" x1="3.099" y1="-0.381" x2="2.007" y2="-0.381"/>
<wire layer="51" width="0" x1="2.007" y1="0.889" x2="2.007" y2="0.381"/>
<wire layer="51" width="0" x1="2.007" y1="0.381" x2="3.099" y2="0.381"/>
<wire layer="51" width="0" x1="3.099" y1="0.381" x2="3.099" y2="0.889"/>
<wire layer="51" width="0" x1="3.099" y1="0.889" x2="2.007" y2="0.889"/>
<wire layer="51" width="0" x1="2.007" y1="2.159" x2="2.007" y2="1.651"/>
<wire layer="51" width="0" x1="2.007" y1="1.651" x2="3.099" y2="1.651"/>
<wire layer="51" width="0" x1="3.099" y1="1.651" x2="3.099" y2="2.159"/>
<wire layer="51" width="0" x1="3.099" y1="2.159" x2="2.007" y2="2.159"/>
<wire layer="51" width="0.127" x1="-1.95" y1="-2.45" x2="1.95" y2="-2.45"/>
<wire layer="51" width="0.127" x1="1.95" y1="-2.45" x2="1.95" y2="2.45"/>
<wire layer="51" width="0.127" x1="1.95" y1="2.45" x2="-1.95" y2="2.45"/>
<wire layer="51" width="0.127" x1="-1.95" y1="2.45" x2="-1.95" y2="-2.45"/>
<text x="-2.912" y="-2.75" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="76">LM358DT</text>
<circle layer="21" x="-4.1" y="1.905" radius="0.1" width="0"/>
<wire layer="21" width="0.127" x1="-1.95" y1="2.45" x2="1.95" y2="2.45"/>
</package>
<package name="RES_1206_M_Cap-18">
</package>
<package name="SOT95P230X110-3N">
<description>Description: Bipolar (BJT) Transistor NPN 45V 500mA 100MHz 250mW Surface Mount TO-236AB</description>
<smd name="1" x="-0.98" y="0.95" layer="1" dx="1.26" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="-0.98" y="-0.95" layer="1" dx="1.26" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="0.98" y="0" layer="1" dx="1.26" dy="0.59" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="51" width="0.127" x1="-0.7" y1="-1.5" x2="0.7" y2="-1.5"/>
<wire layer="51" width="0.127" x1="0.7" y1="-1.5" x2="0.7" y2="1.5"/>
<wire layer="51" width="0.127" x1="0.7" y1="1.5" x2="-0.7" y2="1.5"/>
<wire layer="51" width="0.127" x1="-0.7" y1="1.5" x2="-0.7" y2="-1.5"/>
<wire layer="21" width="0.127" x1="-0.7" y1="1.559" x2="0.7" y2="1.559"/>
<wire layer="21" width="0.127" x1="0.7" y1="1.559" x2="0.7" y2="0.609"/>
<wire layer="21" width="0.127" x1="-0.7" y1="-1.559" x2="0.7" y2="-1.559"/>
<wire layer="21" width="0.127" x1="0.7" y1="-1.559" x2="0.7" y2="-0.609"/>
<circle layer="21" x="-1.3" y="1.7" radius="0.1" width="0"/>
<circle layer="51" x="-1.3" y="1.7" radius="0.1" width="0"/>
<text x="-2" y="1.8" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">BC817</text>
</package>
<package name="CAPAE830X700L290X70N">
<description>Part Number (Digi-Key): P16428DKR-ND
Unique Name: PANASONIC_SVP,SIZE_E7_CAPP</description>
<smd name="1" x="-3.295" y="0" layer="1" dx="3.6" dy="1.63" roundness="31" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="3.295" y="0" layer="1" dx="3.6" dy="1.63" roundness="31" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.12" x1="4.25" y1="1" x2="4.25" y2="4.25"/>
<wire layer="21" width="0.12" x1="4.25" y1="4.25" x2="-2.55" y2="4.25"/>
<wire layer="21" width="0.12" x1="-2.55" y1="4.25" x2="-4.25" y2="2.55"/>
<wire layer="21" width="0.12" x1="-4.25" y1="2.55" x2="-4.25" y2="1"/>
<wire layer="21" width="0.12" x1="4.25" y1="-1" x2="4.25" y2="-4.25"/>
<wire layer="21" width="0.12" x1="4.25" y1="-4.25" x2="-2.55" y2="-4.25"/>
<wire layer="21" width="0.12" x1="-2.55" y1="-4.25" x2="-4.25" y2="-2.55"/>
<wire layer="21" width="0.12" x1="-4.25" y1="-2.55" x2="-4.25" y2="-1"/>
<wire layer="51" width="0.12" x1="4.25" y1="4.25" x2="4.25" y2="-4.25"/>
<wire layer="51" width="0.12" x1="4.25" y1="-4.25" x2="-2.55" y2="-4.25"/>
<wire layer="51" width="0.12" x1="-2.55" y1="-4.25" x2="-4.25" y2="-2.55"/>
<wire layer="51" width="0.12" x1="-4.25" y1="-2.55" x2="-4.25" y2="2.55"/>
<wire layer="51" width="0.12" x1="-4.25" y1="2.55" x2="-2.55" y2="4.25"/>
<wire layer="51" width="0.12" x1="-2.55" y1="4.25" x2="4.25" y2="4.25"/>
<text x="-3.5" y="0" size="0.987" layer="51" font="vector" ratio="10" rot="R0" align="center-left" distance="76">cap 8mm</text>
</package>
<package name="DIOAD1720W120L750D440P">
<pad name="C" x="-8.6" y="0" drill="1.45" shape="square" diameter="3.5" rot="R90" stop="yes" thermals="no"/>
<pad name="A" x="8.6" y="0" drill="1.45" diameter="3.5" rot="R90" stop="yes" thermals="no"/>
<wire layer="21" width="0.2" x1="-3.75" y1="2.2" x2="3.75" y2="2.2"/>
<wire layer="21" width="0.2" x1="3.75" y1="2.2" x2="3.75" y2="0"/>
<wire layer="21" width="0.2" x1="3.75" y1="0" x2="3.75" y2="-2.2"/>
<wire layer="21" width="0.2" x1="3.75" y1="-2.2" x2="-3.75" y2="-2.2"/>
<wire layer="21" width="0.2" x1="-3.75" y1="-2.2" x2="-3.75" y2="0"/>
<wire layer="21" width="0.2" x1="-3.75" y1="0" x2="-3.75" y2="2.2"/>
<wire layer="21" width="0.2" x1="-6.6" y1="0" x2="-3.75" y2="0"/>
<wire layer="21" width="0.2" x1="3.75" y1="0" x2="6.6" y2="0"/>
<rectangle x1="-3.892" y1="2.2" x2="-1.8" y2="-2.356" layer="21" rot="R0"/>
<text x="-4" y="2.45" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">Zener 12V 5W</text>
</package>
<package name="Untitled">
<smd name="1@_1" x="1.429" y="7.303" layer="1" dx="1.8" dy="4" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="1@_2" x="6.826" y="7.303" layer="1" dx="1.8" dy="4" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="1@_3" x="1.429" y="-0.953" layer="1" dx="1.8" dy="4" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="1@" x="6.826" y="-0.953" layer="1" dx="1.8" dy="4" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.25" x1="0" y1="6.4" x2="8.3" y2="6.4"/>
<wire layer="21" width="0.25" x1="8.3" y1="6.4" x2="8.3" y2="0"/>
<wire layer="21" width="0.25" x1="8.3" y1="0" x2="0" y2="0"/>
<wire layer="21" width="0.25" x1="0" y1="0" x2="0" y2="6.4"/>
<text x="1.746" y="3.969" size="0.987" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">B380S</text>
<rectangle x1="6.191" y1="8.255" x2="7.461" y2="5.874" layer="21" rot="R0"/>
<rectangle x1="0.794" y1="8.255" x2="2.064" y2="5.874" layer="21" rot="R0"/>
<rectangle x1="0.794" y1="0.476" x2="2.064" y2="-1.905" layer="21" rot="R0"/>
<rectangle x1="6.191" y1="0.476" x2="7.461" y2="-1.905" layer="21" rot="R0"/>
<text x="0.635" y="5.239" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">AC</text>
<text x="6.033" y="5.239" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">AC</text>
<text x="0.99" y="2.381" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">+</text>
<text x="6.505" y="2.381" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">-</text>
</package>
<package name="SOD2513X120N_U19">
<text x="-2.3" y="-3.167" size="0.74" layer="21" font="vector" ratio="10" rot="R90" align="bottom-left" distance="76">BAT43WS</text>
</package>
<package name="RENESAS_PLZZ0004CA-A">
<smd name="1" x="-1.5" y="-1.435" layer="1" dx="0.69" dy="2.19" roundness="49" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="0" y="0" layer="1" dx="0.74" dy="0.74" roundness="100" rot="R0" stop="no" cream="no" thermals="no"/>
<vertex x="0.369" y="-2.529"/>
<vertex x="0.369" y="-0.72"/>
<vertex x="1.004" y="-0.085"/>
<vertex x="1.004" y="2.33"/>
<vertex x="0.805" y="2.529"/>
<vertex x="-0.805" y="2.529"/>
<vertex x="-1.004" y="2.33"/>
<vertex x="-1.004" y="-0.085"/>
<vertex x="-0.369" y="-0.72"/>
<vertex x="-0.369" y="-2.529"/>
</polygon>
<polygon layer="29" width="0.002">
<vertex x="0.42" y="-2.58"/>
<vertex x="0.42" y="-0.741"/>
<vertex x="1.055" y="-0.106"/>
<vertex x="1.055" y="2.351"/>
<vertex x="0.826" y="2.58"/>
<vertex x="-0.826" y="2.58"/>
<vertex x="-1.055" y="2.351"/>
<vertex x="-1.055" y="-0.106"/>
<vertex x="-0.42" y="-0.741"/>
<vertex x="-0.42" y="-2.58"/>
</polygon>
<polygon layer="31" width="0.002">
<vertex x="0.32" y="-2.48"/>
<vertex x="0.32" y="-0.699"/>
<vertex x="0.955" y="-0.064"/>
<vertex x="0.955" y="2.309"/>
<vertex x="0.784" y="2.48"/>
<vertex x="-0.784" y="2.48"/>
<vertex x="-0.955" y="2.309"/>
<vertex x="-0.955" y="-0.064"/>
<vertex x="-0.32" y="-0.699"/>
<vertex x="-0.32" y="-2.48"/>
</polygon>
<smd name="3" x="1.5" y="-1.435" layer="1" dx="0.69" dy="2.19" roundness="49" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.12" x1="-1.19" y1="1.775" x2="-2.3" y2="1.775"/>
<wire layer="21" width="0.12" x1="-2.3" y1="1.775" x2="-2.3" y2="-0.825"/>
<wire layer="21" width="0.12" x1="-2.3" y1="-0.825" x2="-2.03" y2="-0.825"/>
<wire layer="21" width="0.12" x1="1.19" y1="1.775" x2="2.3" y2="1.775"/>
<wire layer="21" width="0.12" x1="2.3" y1="1.775" x2="2.3" y2="-0.825"/>
<wire layer="21" width="0.12" x1="2.3" y1="-0.825" x2="2.03" y2="-0.825"/>
<circle layer="21" x="-2.22" y="-2.28" radius="0.25" width="0"/>
<wire layer="51" width="0.12" x1="-1.433" y1="-0.825" x2="-2.3" y2="0.042"/>
<wire layer="51" width="0.12" x1="-2.3" y1="0.042" x2="-2.3" y2="1.775"/>
<wire layer="51" width="0.12" x1="-2.3" y1="1.775" x2="2.3" y2="1.775"/>
<wire layer="51" width="0.12" x1="2.3" y1="1.775" x2="2.3" y2="-0.825"/>
<wire layer="51" width="0.12" x1="2.3" y1="-0.825" x2="-1.433" y2="-0.825"/>
</package>
<package name="P243">
<pad name="1@_1" x="-2.285" y="0" drill="1" diameter="3" rot="R0" stop="yes" thermals="no"/>
<pad name="1@" x="7.697" y="0" drill="1" diameter="3" rot="R0" stop="yes" thermals="no"/>
<hole x="-2.285" y="4.75" drill="1.6"/>
<hole x="1.815" y="-2.4" drill="1.6"/>
<hole x="-6.385" y="-2.35" drill="1.6"/>
<text x="6.25" y="6.844" size="2.467" layer="51" font="vector" ratio="10" rot="R0" align="top-left" distance="92">+</text>
<circle layer="21" x="-2.285" y="0" radius="7.53" width="0.25"/>
<circle layer="21" x="-2.285" y="0" radius="6.25" width="0.25"/>
<wire layer="21" width="0.25" x1="4.965" y1="2.05" x2="9.765" y2="2.05"/>
<wire layer="21" width="0.25" x1="9.815" y1="1.95" x2="9.815" y2="-1.95"/>
<wire layer="21" width="0.25" x1="9.815" y1="-2" x2="5.065" y2="-2"/>
</package>
<package name="SOIC127P1030X265-28N">
<description>Description: PIC PIC&#174; 18F Microcontroller IC 8-Bit 48MHz 32KB (16K x 16) FLASH 28-SOIC</description>
<smd name="20" x="4.605" y="-1.905" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="1" x="-4.605" y="8.255" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="14" x="-4.605" y="-8.255" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="-4.605" y="6.985" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="-4.605" y="5.715" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="9" x="-4.605" y="-1.905" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="4" x="-4.605" y="4.445" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="5" x="-4.605" y="3.175" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="6" x="-4.605" y="1.905" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="7" x="-4.605" y="0.635" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="21" x="4.605" y="-0.635" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="22" x="4.605" y="0.635" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="23" x="4.605" y="1.905" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="24" x="4.605" y="3.175" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="25" x="4.605" y="4.445" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="26" x="4.605" y="5.715" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="27" x="4.605" y="6.985" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="28" x="4.605" y="8.255" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="8" x="-4.605" y="-0.635" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="10" x="-4.605" y="-3.175" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="11" x="-4.605" y="-4.445" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="12" x="-4.605" y="-5.715" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="13" x="-4.605" y="-6.985" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="15" x="4.605" y="-8.255" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="16" x="4.605" y="-6.985" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="17" x="4.605" y="-5.715" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="18" x="4.605" y="-4.445" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="19" x="4.605" y="-3.175" layer="1" dx="1.9" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<circle layer="21" x="-6.505" y="8.855" radius="0.1" width="0"/>
<circle layer="51" x="-6.505" y="8.855" radius="0.1" width="0"/>
<wire layer="51" width="0.127" x1="-3.75" y1="8.95" x2="3.75" y2="8.95"/>
<wire layer="51" width="0.127" x1="-3.75" y1="-8.95" x2="3.75" y2="-8.95"/>
<wire layer="21" width="0.127" x1="-3.75" y1="8.95" x2="3.75" y2="8.95"/>
<wire layer="21" width="0.127" x1="-3.75" y1="-8.95" x2="3.75" y2="-8.95"/>
<wire layer="51" width="0.127" x1="-3.75" y1="8.95" x2="-3.75" y2="-8.95"/>
<wire layer="51" width="0.127" x1="3.75" y1="8.95" x2="3.75" y2="-8.95"/>
<text x="-0.4" y="-6.667" size="0.987" layer="21" font="vector" ratio="10" rot="R90" align="center-left" distance="76">PIC18F2550-I/SO</text>
</package>
<package name="SOD3715X135N">
<description>Description: Diode Schottky 100V 150mA (DC) Surface Mount SOD-123</description>
<smd name="C" x="-1.68" y="0" layer="1" dx="1.21" dy="0.73" roundness="18" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="A" x="1.68" y="0" layer="1" dx="1.21" dy="0.73" roundness="18" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="51" width="0.127" x1="-1.43" y1="-0.85" x2="-1.43" y2="0.85"/>
<wire layer="51" width="0.127" x1="-1.43" y1="0.85" x2="1.43" y2="0.85"/>
<wire layer="51" width="0.127" x1="1.43" y1="0.85" x2="1.43" y2="-0.85"/>
<wire layer="51" width="0.127" x1="1.43" y1="-0.85" x2="-1.43" y2="-0.85"/>
<wire layer="21" width="0.127" x1="-1.35" y1="0.85" x2="1.35" y2="0.85"/>
<wire layer="21" width="0.127" x1="-1.35" y1="-0.85" x2="1.35" y2="-0.85"/>
<circle layer="21" x="-2.8" y="0" radius="0.1" width="0"/>
<circle layer="51" x="-2.8" y="0" radius="0.1" width="0"/>
<text x="-4.847" y="1.1" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">BAT46-SOD123</text>
</package>
<package name="SODFL2512X100N">
<description>Description: Diode Standard 75V 300mA (DC) Surface Mount SOD-323</description>
<smd name="A" x="1.4" y="0" layer="1" dx="1.05" dy="0.6" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="C" x="-1.4" y="0" layer="1" dx="1.05" dy="0.6" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="51" width="0.127" x1="0.85" y1="0.625" x2="0.85" y2="-0.625"/>
<wire layer="51" width="0.127" x1="-0.85" y1="-0.625" x2="-0.85" y2="0.625"/>
<text x="-3.333" y="0.9" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">1N4148WS</text>
<rectangle x1="-0.625" y1="0.625" x2="-0.2" y2="-0.625" layer="21" rot="R0"/>
</package>
<package name="DC-10BS">
<smd name="VCC1" x="6" y="-5" layer="1" dx="3" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="SHUNT" x="-6" y="-11" layer="1" dx="3" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="GND" x="-6" y="-5" layer="1" dx="3" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="VCC2" x="6" y="-11" layer="1" dx="3" dy="2" rot="R0" stop="yes" cream="yes" thermals="no"/>
<hole x="0" y="-9.5" drill="2"/>
<hole x="0" y="-5.1" drill="2"/>
<wire layer="21" width="0.127" x1="4.45" y1="-13.2" x2="4.45" y2="-3"/>
<wire layer="21" width="0.127" x1="4.45" y1="-3" x2="4.45" y2="-0.68"/>
<wire layer="21" width="0.127" x1="4.45" y1="-0.68" x2="3.77" y2="0" curve="89.904507"/>
<wire layer="21" width="0.127" x1="3.77" y1="0" x2="-3.823" y2="0"/>
<wire layer="21" width="0.127" x1="-3.823" y1="0" x2="-4.45" y2="-0.627" curve="89.924916"/>
<wire layer="21" width="0.127" x1="-4.45" y1="-0.627" x2="-4.45" y2="-3"/>
<wire layer="21" width="0.127" x1="-4.45" y1="-3" x2="-4.45" y2="-14.7"/>
<wire layer="21" width="0.127" x1="-4.45" y1="-14.7" x2="-1.45" y2="-14.7"/>
<wire layer="21" width="0.127" x1="-1.45" y1="-14.7" x2="-1.45" y2="-13.2"/>
<wire layer="21" width="0.127" x1="-1.45" y1="-13.2" x2="-1" y2="-13.2"/>
<wire layer="21" width="0.127" x1="-1" y1="-13.2" x2="1" y2="-13.2"/>
<wire layer="21" width="0.127" x1="1" y1="-13.2" x2="4.45" y2="-13.2"/>
<wire layer="21" width="0.127" x1="-4.45" y1="-3" x2="-3" y2="-3"/>
<wire layer="21" width="0.127" x1="-3" y1="-3" x2="-3" y2="-7.838"/>
<wire layer="21" width="0.127" x1="-3" y1="-7.838" x2="0.162" y2="-11" curve="89.986719"/>
<wire layer="21" width="0.127" x1="0.162" y1="-11" x2="3" y2="-8.162" curve="90.018381"/>
<wire layer="21" width="0.127" x1="3" y1="-8.162" x2="3" y2="-3"/>
<wire layer="21" width="0.127" x1="3" y1="-3" x2="4.45" y2="-3"/>
<wire layer="21" width="0.127" x1="-1" y1="-13.5" x2="1" y2="-13.5"/>
<wire layer="21" width="0.127" x1="1" y1="-13.5" x2="1" y2="-13.2"/>
<wire layer="21" width="0.127" x1="-1" y1="-13.5" x2="-1" y2="-13.2"/>
</package>
<package name="Fuse_holder">
<smd name="1" x="-3.81" y="0" layer="1" dx="4.24" dy="3.81" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="3.016" y="0" layer="1" dx="4.24" dy="3.81" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.25" x1="-5.183" y1="2.515" x2="4.547" y2="2.515"/>
<wire layer="21" width="0.25" x1="4.547" y1="2.515" x2="4.547" y2="-2.515"/>
<wire layer="21" width="0.25" x1="4.547" y1="-2.515" x2="-5.183" y2="-2.515"/>
<wire layer="21" width="0.25" x1="-5.183" y1="-2.515" x2="-5.183" y2="2.515"/>
<wire layer="21" width="0.25" x1="-3.368" y1="1.27" x2="2.732" y2="1.27"/>
<wire layer="21" width="0.25" x1="2.732" y1="1.27" x2="2.732" y2="-1.27"/>
<wire layer="21" width="0.25" x1="2.732" y1="-1.27" x2="-3.368" y2="-1.27"/>
<wire layer="21" width="0.25" x1="-3.368" y1="-1.27" x2="-3.368" y2="1.27"/>
<text x="-3.016" y="1.27" size="1.48" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="92">FUSE</text>
</package>
<package name="DPAK229P990X238-4N">
<description>Description: Linear Voltage Regulator IC Positive Fixed 1 Output  1A DPAK</description>
<smd name="1" x="-2.29" y="-4.14" layer="1" dx="2.83" dy="0.97" rot="R90" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="2.29" y="-4.14" layer="1" dx="2.83" dy="0.97" rot="R90" stop="yes" cream="yes" thermals="no"/>
<smd name="4" x="0" y="2.51" layer="1" dx="6.09" dy="5.63" rot="R90" stop="yes" cream="no" thermals="no"/>
<wire layer="51" width="0.127" x1="-3.37" y1="4.093" x2="3.37" y2="4.093"/>
<wire layer="51" width="0.127" x1="3.37" y1="4.093" x2="3.37" y2="-2.128"/>
<wire layer="51" width="0.127" x1="3.37" y1="-2.128" x2="-3.37" y2="-2.128"/>
<wire layer="51" width="0.127" x1="-3.37" y1="-2.128" x2="-3.37" y2="4.093"/>
<wire layer="21" width="0.127" x1="-3.37" y1="-2.128" x2="-3.37" y2="4.093"/>
<wire layer="21" width="0.127" x1="3.37" y1="4.093" x2="3.37" y2="-2.128"/>
<wire layer="21" width="0.127" x1="3.37" y1="-2.128" x2="-3.37" y2="-2.128"/>
<circle layer="21" x="-2.3" y="-6.4" radius="0.1" width="0"/>
<circle layer="51" x="-2.3" y="-6.4" radius="0.1" width="0"/>
<text x="-4.5" y="5.81" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">MC7805 DPAK</text>
<rectangle x1="-0.655" y1="3.24" x2="0.655" y2="1.78" layer="31" rot="R0"/>
<rectangle x1="-2.535" y1="3.24" x2="-1.225" y2="1.78" layer="31" rot="R0"/>
<rectangle x1="1.225" y1="3.24" x2="2.535" y2="1.78" layer="31" rot="R0"/>
<rectangle x1="-2.535" y1="5.27" x2="-1.225" y2="3.81" layer="31" rot="R0"/>
<rectangle x1="-0.655" y1="5.27" x2="0.655" y2="3.81" layer="31" rot="R0"/>
<rectangle x1="1.225" y1="5.27" x2="2.535" y2="3.81" layer="31" rot="R0"/>
<rectangle x1="-2.535" y1="1.21" x2="-1.225" y2="-0.25" layer="31" rot="R0"/>
<rectangle x1="-0.655" y1="1.21" x2="0.655" y2="-0.25" layer="31" rot="R0"/>
</package>
<package name="2200-3300uF">
<smd name="1" x="-6.75" y="0.2" layer="1" dx="6.31" dy="2.51" roundness="20" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="6.75" y="0.2" layer="1" dx="6.31" dy="2.51" roundness="20" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.12" x1="8.05" y1="0.9" x2="8.05" y2="8.1"/>
<wire layer="21" width="0.12" x1="8.05" y1="8.1" x2="-4.8" y2="8.1"/>
<wire layer="21" width="0.12" x1="-4.8" y1="8.1" x2="-8.25" y2="4.66"/>
<wire layer="21" width="0.12" x1="-8.25" y1="4.66" x2="-8.25" y2="0.94"/>
<wire layer="21" width="0.12" x1="8.05" y1="-0.9" x2="8.05" y2="-8.2"/>
<wire layer="21" width="0.12" x1="8.05" y1="-8.2" x2="-4.8" y2="-8.1"/>
<wire layer="21" width="0.12" x1="-4.8" y1="-8.1" x2="-8.25" y2="-4.66"/>
<wire layer="21" width="0.12" x1="-8.25" y1="-4.66" x2="-8.25" y2="-0.94"/>
<wire layer="51" width="0.12" x1="8.05" y1="8.1" x2="8.05" y2="-8.2"/>
<wire layer="51" width="0.12" x1="8.05" y1="-8.2" x2="-4.8" y2="-8.3"/>
<wire layer="51" width="0.12" x1="-4.8" y1="-8.3" x2="-8.25" y2="-4.86"/>
<wire layer="51" width="0.12" x1="-8.25" y1="-4.86" x2="-8.25" y2="4.66"/>
<wire layer="51" width="0.12" x1="-8.25" y1="4.66" x2="-4.55" y2="8.2"/>
<wire layer="51" width="0.12" x1="-4.55" y1="8.2" x2="8.05" y2="8.1"/>
<text x="-5.333" y="8.3" size="0.987" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">2200-3300uF</text>
</package>
<package name="JMP3">
<pad name="1" x="-2.54" y="0" drill="0.965" shape="square" diameter="1.8" rot="R0" stop="no" thermals="no"/>
<vertex x="-3.439" y="1.499"/>
<vertex x="-1.641" y="1.499"/>
<vertex x="-1.641" y="-1.499"/>
<vertex x="-3.439" y="-1.499"/>
</polygon>
</polygon>
<rectangle x1="-3.49" y1="1.55" x2="-1.59" y2="-1.55" layer="30" rot="R0"/>
<rectangle x1="-3.54" y1="1.6" x2="-1.54" y2="-1.6" layer="29" rot="R0"/>
<pad name="2" x="0" y="0" drill="0.965" diameter="1.79" rot="R0" stop="no" thermals="no"/>
<vertex x="0.899" y="0"/>
<vertex x="0.855" y="0.463"/>
<vertex x="0.727" y="0.881"/>
<vertex x="0.528" y="1.213"/>
<vertex x="0.278" y="1.426"/>
<vertex x="0" y="1.499"/>
<vertex x="-0.278" y="1.426"/>
<vertex x="-0.528" y="1.213"/>
<vertex x="-0.727" y="0.881"/>
<vertex x="-0.855" y="0.463"/>
<vertex x="-0.899" y="0"/>
<vertex x="-0.855" y="-0.463"/>
<vertex x="-0.727" y="-0.881"/>
<vertex x="-0.528" y="-1.213"/>
<vertex x="-0.278" y="-1.426"/>
<vertex x="0" y="-1.499"/>
<vertex x="0.278" y="-1.426"/>
<vertex x="0.528" y="-1.213"/>
<vertex x="0.727" y="-0.881"/>
<vertex x="0.855" y="-0.463"/>
</polygon>
</polygon>
<polygon layer="30" width="0.002">
<vertex x="0.95" y="0"/>
<vertex x="0.904" y="0.479"/>
<vertex x="0.769" y="0.911"/>
<vertex x="0.558" y="1.254"/>
<vertex x="0.294" y="1.474"/>
<vertex x="0" y="1.55"/>
<vertex x="-0.294" y="1.474"/>
<vertex x="-0.558" y="1.254"/>
<vertex x="-0.769" y="0.911"/>
<vertex x="-0.904" y="0.479"/>
<vertex x="-0.95" y="0"/>
<vertex x="-0.904" y="-0.479"/>
<vertex x="-0.769" y="-0.911"/>
<vertex x="-0.558" y="-1.254"/>
<vertex x="-0.294" y="-1.474"/>
<vertex x="0" y="-1.55"/>
<vertex x="0.294" y="-1.474"/>
<vertex x="0.558" y="-1.254"/>
<vertex x="0.769" y="-0.911"/>
<vertex x="0.904" y="-0.479"/>
</polygon>
</polygon>
<pad name="3" x="2.54" y="0" drill="0.965" diameter="1.79" rot="R0" stop="no" thermals="no"/>
<vertex x="3.439" y="0"/>
<vertex x="3.395" y="0.463"/>
<vertex x="3.267" y="0.881"/>
<vertex x="3.068" y="1.213"/>
<vertex x="2.818" y="1.426"/>
<vertex x="2.54" y="1.499"/>
<vertex x="2.262" y="1.426"/>
<vertex x="2.012" y="1.213"/>
<vertex x="1.813" y="0.881"/>
<vertex x="1.685" y="0.463"/>
<vertex x="1.641" y="0"/>
<vertex x="1.685" y="-0.463"/>
<vertex x="1.813" y="-0.881"/>
<vertex x="2.012" y="-1.213"/>
<vertex x="2.262" y="-1.426"/>
<vertex x="2.54" y="-1.499"/>
<vertex x="2.818" y="-1.426"/>
<vertex x="3.068" y="-1.213"/>
<vertex x="3.267" y="-0.881"/>
<vertex x="3.395" y="-0.463"/>
</polygon>
</polygon>
<vertex x="3.49" y="0"/>
<vertex x="3.444" y="0.479"/>
<vertex x="3.309" y="0.911"/>
<vertex x="3.098" y="1.254"/>
<vertex x="2.834" y="1.474"/>
<vertex x="2.54" y="1.55"/>
<vertex x="2.246" y="1.474"/>
<vertex x="1.982" y="1.254"/>
<vertex x="1.771" y="0.911"/>
<vertex x="1.636" y="0.479"/>
<vertex x="1.59" y="0"/>
<vertex x="1.636" y="-0.479"/>
<vertex x="1.771" y="-0.911"/>
<vertex x="1.982" y="-1.254"/>
<vertex x="2.246" y="-1.474"/>
<vertex x="2.54" y="-1.55"/>
<vertex x="2.834" y="-1.474"/>
<vertex x="3.098" y="-1.254"/>
<vertex x="3.309" y="-0.911"/>
<vertex x="3.444" y="-0.479"/>
</polygon>
</polygon>
<wire layer="51" width="0.12" x1="3.556" y1="1.27" x2="1.524" y2="1.27"/>
<wire layer="51" width="0.12" x1="1.524" y1="1.27" x2="1.27" y2="1.016"/>
<wire layer="51" width="0.12" x1="1.27" y1="1.016" x2="1.016" y2="1.27"/>
<wire layer="51" width="0.12" x1="1.016" y1="1.27" x2="-1.016" y2="1.27"/>
<wire layer="51" width="0.12" x1="-1.016" y1="1.27" x2="-1.27" y2="1.016"/>
<wire layer="51" width="0.12" x1="-1.27" y1="1.016" x2="-1.524" y2="1.27"/>
<wire layer="51" width="0.12" x1="-1.524" y1="1.27" x2="-3.556" y2="1.27"/>
<wire layer="51" width="0.12" x1="-3.556" y1="1.27" x2="-3.81" y2="1.016"/>
<wire layer="51" width="0.12" x1="-3.81" y1="1.016" x2="-3.81" y2="-1.016"/>
<wire layer="51" width="0.12" x1="-3.81" y1="-1.016" x2="-3.556" y2="-1.27"/>
<wire layer="51" width="0.12" x1="-3.556" y1="-1.27" x2="-1.524" y2="-1.27"/>
<wire layer="51" width="0.12" x1="-1.524" y1="-1.27" x2="-1.27" y2="-1.016"/>
<wire layer="51" width="0.12" x1="-1.27" y1="-1.016" x2="-1.016" y2="-1.27"/>
<wire layer="51" width="0.12" x1="-1.016" y1="-1.27" x2="1.016" y2="-1.27"/>
<wire layer="51" width="0.12" x1="1.016" y1="-1.27" x2="1.27" y2="-1.016"/>
<wire layer="51" width="0.12" x1="1.27" y1="-1.016" x2="1.524" y2="-1.27"/>
<wire layer="51" width="0.12" x1="1.524" y1="-1.27" x2="3.556" y2="-1.27"/>
<wire layer="51" width="0.12" x1="3.556" y1="-1.27" x2="3.81" y2="-1.016"/>
<wire layer="51" width="0.12" x1="3.81" y1="-1.016" x2="3.81" y2="1.016"/>
<wire layer="51" width="0.12" x1="3.81" y1="1.016" x2="3.556" y2="1.27"/>
<wire layer="21" width="0.12" x1="3.556" y1="1.27" x2="1.524" y2="1.27"/>
<wire layer="21" width="0.12" x1="1.524" y1="1.27" x2="1.27" y2="1.016"/>
<wire layer="21" width="0.12" x1="1.27" y1="1.016" x2="1.016" y2="1.27"/>
<wire layer="21" width="0.12" x1="1.016" y1="1.27" x2="-1.016" y2="1.27"/>
<wire layer="21" width="0.12" x1="-1.016" y1="1.27" x2="-1.27" y2="1.016"/>
<wire layer="21" width="0.12" x1="-1.27" y1="1.016" x2="-1.524" y2="1.27"/>
<wire layer="21" width="0.12" x1="-1.524" y1="1.27" x2="-3.556" y2="1.27"/>
<wire layer="21" width="0.12" x1="-3.556" y1="1.27" x2="-3.81" y2="1.016"/>
<wire layer="21" width="0.12" x1="-3.81" y1="1.016" x2="-3.81" y2="-1.016"/>
<wire layer="21" width="0.12" x1="-3.81" y1="-1.016" x2="-3.556" y2="-1.27"/>
<wire layer="21" width="0.12" x1="-3.556" y1="-1.27" x2="-1.524" y2="-1.27"/>
<wire layer="21" width="0.12" x1="-1.524" y1="-1.27" x2="-1.27" y2="-1.016"/>
<wire layer="21" width="0.12" x1="-1.27" y1="-1.016" x2="-1.016" y2="-1.27"/>
<wire layer="21" width="0.12" x1="-1.016" y1="-1.27" x2="1.016" y2="-1.27"/>
<wire layer="21" width="0.12" x1="1.016" y1="-1.27" x2="1.27" y2="-1.016"/>
<wire layer="21" width="0.12" x1="1.27" y1="-1.016" x2="1.524" y2="-1.27"/>
<wire layer="21" width="0.12" x1="1.524" y1="-1.27" x2="3.556" y2="-1.27"/>
<wire layer="21" width="0.12" x1="3.556" y1="-1.27" x2="3.81" y2="-1.016"/>
<wire layer="21" width="0.12" x1="3.81" y1="-1.016" x2="3.81" y2="1.016"/>
<wire layer="21" width="0.12" x1="3.81" y1="1.016" x2="3.556" y2="1.27"/>
</package>
<package name="VREG_TPS79625KTTR">
<description>Description: 1-A, 26-V, high-PSRR, adjustable low-dropout voltage regulator with enable from -40C to +125C 5-DDPAK/TO-263 -40 to 125</description>
<smd name="4" x="-10.6" y="-1.7" layer="1" dx="3.4" dy="1" rot="R0" stop="no" cream="no" thermals="no"/>
<smd name="1" x="-10.6" y="3.4" layer="1" dx="3.4" dy="1" rot="R0" stop="no" cream="no" thermals="no"/>
<smd name="2" x="-10.6" y="1.7" layer="1" dx="3.4" dy="1" rot="R0" stop="no" cream="no" thermals="no"/>
<smd name="5" x="-10.6" y="-3.4" layer="1" dx="3.4" dy="1" rot="R0" stop="no" cream="no" thermals="no"/>
<smd name="3" x="-10.6" y="0" layer="1" dx="3.4" dy="1" rot="R0" stop="no" cream="no" thermals="no"/>
<smd name="6" x="0" y="0" layer="1" dx="8.6" dy="10.7" rot="R0" stop="no" cream="no" thermals="no"/>
<circle layer="21" x="-13.2" y="3.4" radius="0.1" width="0"/>
<circle layer="51" x="-13.2" y="3.4" radius="0.1" width="0"/>
<text x="-9.708" y="0" size="1.48" layer="21" font="vector" ratio="10" rot="R0" align="center-left" distance="76">LM2941S</text>
<wire layer="51" width="0.127" x1="-6.905" y1="5.08" x2="-6.905" y2="-5.08"/>
<wire layer="51" width="0.127" x1="-6.905" y1="-5.08" x2="2.02" y2="-5.08"/>
<wire layer="51" width="0.127" x1="2.02" y1="-5.08" x2="2.02" y2="5.08"/>
<wire layer="51" width="0.127" x1="2.02" y1="5.08" x2="-6.905" y2="5.08"/>
<wire layer="21" width="0.127" x1="-4.62" y1="5.08" x2="-6.905" y2="5.08"/>
<wire layer="21" width="0.127" x1="-6.905" y1="5.08" x2="-6.905" y2="-5.08"/>
<wire layer="21" width="0.127" x1="-6.905" y1="-5.08" x2="-4.62" y2="-5.08"/>
<rectangle x1="-4.25" y1="5.3" x2="4.25" y2="-5.3" layer="31" rot="R0"/>
<rectangle x1="-12.25" y1="0.45" x2="-8.95" y2="-0.45" layer="31" rot="R0"/>
<rectangle x1="-12.25" y1="2.15" x2="-8.95" y2="1.25" layer="31" rot="R0"/>
<rectangle x1="-12.25" y1="3.85" x2="-8.95" y2="2.95" layer="31" rot="R0"/>
<rectangle x1="-12.25" y1="-1.25" x2="-8.95" y2="-2.15" layer="31" rot="R0"/>
<rectangle x1="-12.25" y1="-2.95" x2="-8.95" y2="-3.85" layer="31" rot="R0"/>
<rectangle x1="-4.37" y1="5.42" x2="4.37" y2="-5.42" layer="29" rot="R0"/>
<rectangle x1="-12.37" y1="0.57" x2="-8.83" y2="-0.57" layer="29" rot="R0"/>
<rectangle x1="-12.37" y1="2.27" x2="-8.83" y2="1.13" layer="29" rot="R0"/>
<rectangle x1="-12.37" y1="3.97" x2="-8.83" y2="2.83" layer="29" rot="R0"/>
<rectangle x1="-12.37" y1="-1.13" x2="-8.83" y2="-2.27" layer="29" rot="R0"/>
</package>
<package name="SK_10100">
<smd name="1" x="2.286" y="4.13" layer="1" dx="0.95" dy="2.59" roundness="26" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="0" y="-2.72" layer="1" dx="5.63" dy="5.94" roundness="10" rot="R180" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="-2.286" y="4.13" layer="1" dx="0.95" dy="2.59" roundness="26" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="51" width="0.127" x1="3.35" y1="-4.319" x2="-3.35" y2="-4.319"/>
<wire layer="51" width="0.127" x1="-3.35" y1="-4.319" x2="-3.35" y2="1.88"/>
<wire layer="51" width="0.127" x1="-3.35" y1="1.88" x2="3.35" y2="1.88"/>
<wire layer="51" width="0.127" x1="3.35" y1="1.88" x2="3.35" y2="-4.319"/>
<wire layer="21" width="0.127" x1="-3.35" y1="-4.319" x2="-3.35" y2="1.88"/>
<wire layer="21" width="0.127" x1="-3.35" y1="1.88" x2="3.35" y2="1.88"/>
<wire layer="21" width="0.127" x1="3.35" y1="1.88" x2="3.35" y2="-4.319"/>
<wire layer="21" width="0.127" x1="3.35" y1="-4.319" x2="3" y2="-4.319"/>
<wire layer="21" width="0.127" x1="-3" y1="-4.319" x2="-3.35" y2="-4.319"/>
<circle layer="21" x="2.25" y="5.839" radius="0.1" width="0"/>
<wire layer="21" width="0.25" x1="-0.1" y1="3.071" x2="-0.1" y2="-2.23"/>
<wire layer="21" width="0.25" x1="-0.8" y1="2.27" x2="0.6" y2="2.27"/>
<wire layer="21" width="0.25" x1="-0.8" y1="2.27" x2="-0.1" y2="1.37"/>
<wire layer="21" width="0.25" x1="-0.1" y1="1.37" x2="0.6" y2="2.27"/>
<wire layer="21" width="0.25" x1="-0.7" y1="1.27" x2="0.6" y2="1.27"/>
<text x="-2.833" y="5.939" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">SK 10100</text>
</package>
<package name="DPAK508P1524X483-3N">
<description>Description: N-Channel 100V 17A (Tc) 3.8W (Ta), 79W (Tc) Surface Mount D2PAK</description>
<smd name="1" x="-2.54" y="-6.4" layer="1" dx="1.06" dy="3.78" roundness="54" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="2.54" y="-6.4" layer="1" dx="1.06" dy="3.78" roundness="54" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="0" y="4.29" layer="1" dx="6.39" dy="8" rot="R0" stop="no" cream="no" thermals="no"/>
<wire layer="51" width="0.12" x1="-5.34" y1="-3.24" x2="-5.34" y2="6.42"/>
<wire layer="21" width="0.12" x1="-5.34" y1="-3.24" x2="5.32" y2="-3.24"/>
<wire layer="51" width="0.12" x1="5.34" y1="6.42" x2="5.34" y2="-3.24"/>
<circle layer="21" x="-4.05" y="-6.8" radius="0.25" width="0"/>
<text x="-2.5" y="8.54" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">IRL530N</text>
<rectangle x1="-4.687" y1="8.4" x2="3.3" y2="0.284" layer="29" rot="R0"/>
<rectangle x1="-1.111" y1="8.194" x2="0.8" y2="8.15" layer="31" rot="R0"/>
<rectangle x1="-4.295" y1="5.4" x2="-1.45" y2="4.435" layer="31" rot="R0"/>
<rectangle x1="-1.126" y1="5.4" x2="0.8" y2="4.435" layer="31" rot="R0"/>
<rectangle x1="2.031" y1="5.4" x2="3.05" y2="4.412" layer="31" rot="R0"/>
<rectangle x1="-4.314" y1="2.65" x2="-1.45" y2="0.565" layer="31" rot="R0"/>
<rectangle x1="-1.138" y1="2.65" x2="0.8" y2="0.568" layer="31" rot="R0"/>
<rectangle x1="2.024" y1="2.65" x2="3.05" y2="0.557" layer="31" rot="R0"/>
<rectangle x1="-4.242" y1="8.205" x2="-1.45" y2="8.15" layer="31" rot="R0"/>
<rectangle x1="2.036" y1="8.286" x2="3.05" y2="8.15" layer="31" rot="R0"/>
</package>
<package name="JUMPER6">
<pad name="1" x="-3.81" y="0" drill="0.965" shape="square" diameter="1.8" rot="R0" stop="no" thermals="no"/>
<vertex x="-4.709" y="1.299"/>
<vertex x="-2.911" y="1.299"/>
<vertex x="-2.911" y="-1.299"/>
<vertex x="-4.709" y="-1.299"/>
</polygon>
</polygon>
<rectangle x1="-4.76" y1="1.35" x2="-2.86" y2="-1.35" layer="30" rot="R0"/>
<rectangle x1="-4.81" y1="1.4" x2="-2.81" y2="-1.4" layer="29" rot="R0"/>
<pad name="2" x="-1.27" y="0" drill="0.965" diameter="1.787" rot="R0" stop="no" thermals="no"/>
<vertex x="-0.371" y="0"/>
<vertex x="-0.415" y="0.401"/>
<vertex x="-0.543" y="0.764"/>
<vertex x="-0.742" y="1.051"/>
<vertex x="-0.992" y="1.235"/>
<vertex x="-1.27" y="1.299"/>
<vertex x="-1.548" y="1.235"/>
<vertex x="-1.798" y="1.051"/>
<vertex x="-1.997" y="0.764"/>
<vertex x="-2.125" y="0.401"/>
<vertex x="-2.169" y="0"/>
<vertex x="-2.125" y="-0.401"/>
<vertex x="-1.997" y="-0.764"/>
<vertex x="-1.798" y="-1.051"/>
<vertex x="-1.548" y="-1.235"/>
<vertex x="-1.27" y="-1.299"/>
<vertex x="-0.992" y="-1.235"/>
<vertex x="-0.742" y="-1.051"/>
<vertex x="-0.543" y="-0.764"/>
<vertex x="-0.415" y="-0.401"/>
</polygon>
</polygon>
<vertex x="-0.32" y="0"/>
<vertex x="-0.366" y="0.417"/>
<vertex x="-0.501" y="0.794"/>
<vertex x="-0.712" y="1.092"/>
<vertex x="-0.976" y="1.284"/>
<vertex x="-1.27" y="1.35"/>
<vertex x="-1.564" y="1.284"/>
<vertex x="-1.828" y="1.092"/>
<vertex x="-2.039" y="0.794"/>
<vertex x="-2.174" y="0.417"/>
<vertex x="-2.22" y="0"/>
<vertex x="-2.174" y="-0.417"/>
<vertex x="-2.039" y="-0.794"/>
<vertex x="-1.828" y="-1.092"/>
<vertex x="-1.564" y="-1.284"/>
<vertex x="-1.27" y="-1.35"/>
<vertex x="-0.976" y="-1.284"/>
<vertex x="-0.712" y="-1.092"/>
<vertex x="-0.501" y="-0.794"/>
<vertex x="-0.366" y="-0.417"/>
</polygon>
</polygon>
<pad name="3" x="1.27" y="0" drill="0.965" diameter="1.787" rot="R0" stop="no" thermals="no"/>
<vertex x="2.169" y="0"/>
<vertex x="2.125" y="0.401"/>
<vertex x="1.997" y="0.764"/>
<vertex x="1.798" y="1.051"/>
<vertex x="1.548" y="1.235"/>
<vertex x="1.27" y="1.299"/>
<vertex x="0.992" y="1.235"/>
<vertex x="0.742" y="1.051"/>
<vertex x="0.543" y="0.764"/>
<vertex x="0.415" y="0.401"/>
<vertex x="0.371" y="0"/>
<vertex x="0.415" y="-0.401"/>
<vertex x="0.543" y="-0.764"/>
<vertex x="0.742" y="-1.051"/>
<vertex x="0.992" y="-1.235"/>
<vertex x="1.27" y="-1.299"/>
<vertex x="1.548" y="-1.235"/>
<vertex x="1.798" y="-1.051"/>
<vertex x="1.997" y="-0.764"/>
<vertex x="2.125" y="-0.401"/>
</polygon>
</polygon>
<vertex x="2.22" y="0"/>
<vertex x="2.174" y="0.417"/>
<vertex x="2.039" y="0.794"/>
<vertex x="1.828" y="1.092"/>
<vertex x="1.564" y="1.284"/>
<vertex x="1.27" y="1.35"/>
<vertex x="0.976" y="1.284"/>
<vertex x="0.712" y="1.092"/>
<vertex x="0.501" y="0.794"/>
<vertex x="0.366" y="0.417"/>
<vertex x="0.32" y="0"/>
<vertex x="0.366" y="-0.417"/>
<vertex x="0.501" y="-0.794"/>
<vertex x="0.712" y="-1.092"/>
<vertex x="0.976" y="-1.284"/>
<vertex x="1.27" y="-1.35"/>
<vertex x="1.564" y="-1.284"/>
<vertex x="1.828" y="-1.092"/>
<vertex x="2.039" y="-0.794"/>
<vertex x="2.174" y="-0.417"/>
</polygon>
</polygon>
<pad name="4@_1" x="3.81" y="0" drill="0.965" diameter="1.787" rot="R0" stop="no" thermals="no"/>
<vertex x="4.709" y="0"/>
<vertex x="4.665" y="0.401"/>
<vertex x="4.537" y="0.764"/>
<vertex x="4.338" y="1.051"/>
<vertex x="4.088" y="1.235"/>
<vertex x="3.81" y="1.299"/>
<vertex x="3.532" y="1.235"/>
<vertex x="3.282" y="1.051"/>
<vertex x="3.083" y="0.764"/>
<vertex x="2.955" y="0.401"/>
<vertex x="2.911" y="0"/>
<vertex x="2.955" y="-0.401"/>
<vertex x="3.083" y="-0.764"/>
<vertex x="3.282" y="-1.051"/>
<vertex x="3.532" y="-1.235"/>
<vertex x="3.81" y="-1.299"/>
<vertex x="4.088" y="-1.235"/>
<vertex x="4.338" y="-1.051"/>
<vertex x="4.537" y="-0.764"/>
<vertex x="4.665" y="-0.401"/>
</polygon>
</polygon>
<vertex x="4.76" y="0"/>
<vertex x="4.714" y="0.417"/>
<vertex x="4.579" y="0.794"/>
<vertex x="4.368" y="1.092"/>
<vertex x="4.104" y="1.284"/>
<vertex x="3.81" y="1.35"/>
<vertex x="3.516" y="1.284"/>
<vertex x="3.252" y="1.092"/>
<vertex x="3.041" y="0.794"/>
<vertex x="2.906" y="0.417"/>
<vertex x="2.86" y="0"/>
<vertex x="2.906" y="-0.417"/>
<vertex x="3.041" y="-0.794"/>
<vertex x="3.252" y="-1.092"/>
<vertex x="3.516" y="-1.284"/>
<vertex x="3.81" y="-1.35"/>
<vertex x="4.104" y="-1.284"/>
<vertex x="4.368" y="-1.092"/>
<vertex x="4.579" y="-0.794"/>
<vertex x="4.714" y="-0.417"/>
</polygon>
</polygon>
<pad name="4@_2" x="6.35" y="0" drill="0.965" diameter="1.787" rot="R0" stop="no" thermals="no"/>
<polygon layer="1" width="0.002">
<vertex x="7.249" y="0"/>
<vertex x="7.205" y="0.401"/>
<vertex x="7.077" y="0.764"/>
<vertex x="6.878" y="1.051"/>
<vertex x="6.628" y="1.235"/>
<vertex x="6.35" y="1.299"/>
<vertex x="6.072" y="1.235"/>
<vertex x="5.822" y="1.051"/>
<vertex x="5.623" y="0.764"/>
<vertex x="5.495" y="0.401"/>
<vertex x="5.451" y="0"/>
<vertex x="5.495" y="-0.401"/>
<vertex x="5.623" y="-0.764"/>
<vertex x="5.822" y="-1.051"/>
<vertex x="6.072" y="-1.235"/>
<vertex x="6.35" y="-1.299"/>
<vertex x="6.628" y="-1.235"/>
<vertex x="6.878" y="-1.051"/>
<vertex x="7.077" y="-0.764"/>
<vertex x="7.205" y="-0.401"/>
</polygon>
<polygon layer="16" width="0.002">
</polygon>
<vertex x="7.3" y="0"/>
<vertex x="7.254" y="0.417"/>
<vertex x="7.119" y="0.794"/>
<vertex x="6.908" y="1.092"/>
<vertex x="6.644" y="1.284"/>
<vertex x="6.35" y="1.35"/>
<vertex x="6.056" y="1.284"/>
<vertex x="5.792" y="1.092"/>
<vertex x="5.581" y="0.794"/>
<vertex x="5.446" y="0.417"/>
<vertex x="5.4" y="0"/>
<vertex x="5.446" y="-0.417"/>
<vertex x="5.581" y="-0.794"/>
<vertex x="5.792" y="-1.092"/>
<vertex x="6.056" y="-1.284"/>
<vertex x="6.35" y="-1.35"/>
<vertex x="6.644" y="-1.284"/>
<vertex x="6.908" y="-1.092"/>
<vertex x="7.119" y="-0.794"/>
<vertex x="7.254" y="-0.417"/>
</polygon>
</polygon>
<pad name="4@" x="8.89" y="0" drill="0.965" diameter="1.787" rot="R0" stop="no" thermals="no"/>
<vertex x="9.789" y="0"/>
<vertex x="9.745" y="0.401"/>
<vertex x="9.617" y="0.764"/>
<vertex x="9.418" y="1.051"/>
<vertex x="9.168" y="1.235"/>
<vertex x="8.89" y="1.299"/>
<vertex x="8.612" y="1.235"/>
<vertex x="8.362" y="1.051"/>
<vertex x="8.163" y="0.764"/>
<vertex x="8.035" y="0.401"/>
<vertex x="7.991" y="0"/>
<vertex x="8.035" y="-0.401"/>
<vertex x="8.163" y="-0.764"/>
<vertex x="8.362" y="-1.051"/>
<vertex x="8.612" y="-1.235"/>
<vertex x="8.89" y="-1.299"/>
<vertex x="9.168" y="-1.235"/>
<vertex x="9.418" y="-1.051"/>
<vertex x="9.617" y="-0.764"/>
<vertex x="9.745" y="-0.401"/>
</polygon>
</polygon>
<vertex x="9.84" y="0"/>
<vertex x="9.794" y="0.417"/>
<vertex x="9.659" y="0.794"/>
<vertex x="9.448" y="1.092"/>
<vertex x="9.184" y="1.284"/>
<vertex x="8.89" y="1.35"/>
<vertex x="8.596" y="1.284"/>
<vertex x="8.332" y="1.092"/>
<vertex x="8.121" y="0.794"/>
<vertex x="7.986" y="0.417"/>
<vertex x="7.94" y="0"/>
<vertex x="7.986" y="-0.417"/>
<vertex x="8.121" y="-0.794"/>
<vertex x="8.332" y="-1.092"/>
<vertex x="8.596" y="-1.284"/>
<vertex x="8.89" y="-1.35"/>
<vertex x="9.184" y="-1.284"/>
<vertex x="9.448" y="-1.092"/>
<vertex x="9.659" y="-0.794"/>
<vertex x="9.794" y="-0.417"/>
</polygon>
</polygon>
<wire layer="51" width="0.12" x1="9.906" y1="1.27" x2="7.874" y2="1.27"/>
<wire layer="51" width="0.12" x1="7.874" y1="1.27" x2="7.62" y2="1.016"/>
<wire layer="51" width="0.12" x1="7.62" y1="1.016" x2="7.366" y2="1.27"/>
<wire layer="51" width="0.12" x1="7.366" y1="1.27" x2="5.334" y2="1.27"/>
<wire layer="51" width="0.12" x1="5.334" y1="1.27" x2="5.08" y2="1.016"/>
<wire layer="51" width="0.12" x1="5.08" y1="1.016" x2="4.826" y2="1.27"/>
<wire layer="51" width="0.12" x1="4.826" y1="1.27" x2="2.794" y2="1.27"/>
<wire layer="51" width="0.12" x1="2.794" y1="1.27" x2="2.54" y2="1.016"/>
<wire layer="51" width="0.12" x1="2.54" y1="1.016" x2="2.286" y2="1.27"/>
<wire layer="51" width="0.12" x1="2.286" y1="1.27" x2="0.254" y2="1.27"/>
<wire layer="51" width="0.12" x1="0.254" y1="1.27" x2="0" y2="1.016"/>
<wire layer="51" width="0.12" x1="0" y1="1.016" x2="0" y2="-1.016"/>
<wire layer="51" width="0.12" x1="0" y1="-1.016" x2="0.254" y2="-1.27"/>
<wire layer="51" width="0.12" x1="0.254" y1="-1.27" x2="2.286" y2="-1.27"/>
<wire layer="51" width="0.12" x1="2.286" y1="-1.27" x2="2.54" y2="-1.016"/>
<wire layer="51" width="0.12" x1="2.54" y1="-1.016" x2="2.794" y2="-1.27"/>
<wire layer="51" width="0.12" x1="2.794" y1="-1.27" x2="4.826" y2="-1.27"/>
<wire layer="51" width="0.12" x1="4.826" y1="-1.27" x2="5.08" y2="-1.016"/>
<wire layer="51" width="0.12" x1="5.08" y1="-1.016" x2="5.334" y2="-1.27"/>
<wire layer="51" width="0.12" x1="5.334" y1="-1.27" x2="7.366" y2="-1.27"/>
<wire layer="51" width="0.12" x1="7.366" y1="-1.27" x2="7.62" y2="-1.016"/>
<wire layer="51" width="0.12" x1="7.62" y1="-1.016" x2="7.874" y2="-1.27"/>
<wire layer="51" width="0.12" x1="7.874" y1="-1.27" x2="9.906" y2="-1.27"/>
<wire layer="51" width="0.12" x1="9.906" y1="-1.27" x2="10.16" y2="-1.016"/>
<wire layer="51" width="0.12" x1="10.16" y1="-1.016" x2="10.16" y2="1.016"/>
<wire layer="51" width="0.12" x1="10.16" y1="1.016" x2="9.906" y2="1.27"/>
<wire layer="51" width="0.12" x1="0" y1="1.016" x2="-0.254" y2="1.27"/>
<wire layer="51" width="0.12" x1="-0.254" y1="1.27" x2="-2.286" y2="1.27"/>
<wire layer="51" width="0.12" x1="-2.286" y1="1.27" x2="-2.54" y2="1.016"/>
<wire layer="51" width="0.12" x1="-2.54" y1="1.016" x2="-2.794" y2="1.27"/>
<wire layer="51" width="0.12" x1="-2.794" y1="1.27" x2="-4.826" y2="1.27"/>
<wire layer="51" width="0.12" x1="-4.826" y1="1.27" x2="-5.08" y2="1.016"/>
<wire layer="51" width="0.12" x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016"/>
<wire layer="51" width="0.12" x1="-5.08" y1="-1.016" x2="-4.826" y2="-1.27"/>
<wire layer="51" width="0.12" x1="-4.826" y1="-1.27" x2="-2.794" y2="-1.27"/>
<wire layer="51" width="0.12" x1="-2.794" y1="-1.27" x2="-2.54" y2="-1.016"/>
<wire layer="51" width="0.12" x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27"/>
<wire layer="51" width="0.12" x1="-2.286" y1="-1.27" x2="-0.254" y2="-1.27"/>
<wire layer="51" width="0.12" x1="-0.254" y1="-1.27" x2="0" y2="-1.016"/>
<wire layer="51" width="0.12" x1="0" y1="-1.016" x2="0" y2="-1.016"/>
<wire layer="51" width="0.25" x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016"/>
<wire layer="51" width="0.25" x1="-2.54" y1="-1.016" x2="-2.54" y2="-1.016"/>
<wire layer="21" width="0.12" x1="4.826" y1="1.27" x2="2.794" y2="1.27"/>
<wire layer="21" width="0.12" x1="2.794" y1="1.27" x2="2.54" y2="1.016"/>
<wire layer="21" width="0.12" x1="2.54" y1="1.016" x2="2.286" y2="1.27"/>
<wire layer="21" width="0.12" x1="2.286" y1="1.27" x2="0.254" y2="1.27"/>
<wire layer="21" width="0.12" x1="0.254" y1="1.27" x2="0" y2="1.016"/>
<wire layer="21" width="0.12" x1="0" y1="1.016" x2="-0.254" y2="1.27"/>
<wire layer="21" width="0.12" x1="-0.254" y1="1.27" x2="-2.286" y2="1.27"/>
<wire layer="21" width="0.12" x1="-2.286" y1="1.27" x2="-2.54" y2="1.016"/>
<wire layer="21" width="0.12" x1="-2.54" y1="1.016" x2="-2.794" y2="1.27"/>
<wire layer="21" width="0.12" x1="-2.794" y1="1.27" x2="-4.826" y2="1.27"/>
<wire layer="21" width="0.12" x1="-4.826" y1="1.27" x2="-5.08" y2="1.016"/>
<wire layer="21" width="0.12" x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016"/>
<wire layer="21" width="0.12" x1="-5.08" y1="-1.016" x2="-4.826" y2="-1.27"/>
<wire layer="21" width="0.12" x1="-4.826" y1="-1.27" x2="-2.794" y2="-1.27"/>
<wire layer="21" width="0.12" x1="-2.794" y1="-1.27" x2="-2.54" y2="-1.016"/>
<wire layer="21" width="0.12" x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27"/>
<wire layer="21" width="0.12" x1="-2.286" y1="-1.27" x2="-0.254" y2="-1.27"/>
<wire layer="21" width="0.12" x1="-0.254" y1="-1.27" x2="0" y2="-1.016"/>
<wire layer="21" width="0.12" x1="0" y1="-1.016" x2="0.254" y2="-1.27"/>
<wire layer="21" width="0.12" x1="0.254" y1="-1.27" x2="2.286" y2="-1.27"/>
<wire layer="21" width="0.12" x1="2.286" y1="-1.27" x2="2.54" y2="-1.016"/>
<wire layer="21" width="0.12" x1="2.54" y1="-1.016" x2="2.794" y2="-1.27"/>
<wire layer="21" width="0.12" x1="2.794" y1="-1.27" x2="4.826" y2="-1.27"/>
<wire layer="21" width="0.12" x1="4.826" y1="-1.27" x2="5.08" y2="-1.016"/>
<wire layer="21" width="0.12" x1="5.08" y1="-1.016" x2="5.08" y2="1.016"/>
<wire layer="21" width="0.12" x1="5.08" y1="1.016" x2="4.826" y2="1.27"/>
<wire layer="51" width="0.25" x1="2.54" y1="1.016" x2="2.54" y2="-1.016"/>
<wire layer="51" width="0.25" x1="2.54" y1="-1.016" x2="2.54" y2="-1.016"/>
<wire layer="51" width="0.25" x1="7.62" y1="1.016" x2="7.62" y2="-1.016"/>
<wire layer="51" width="0.25" x1="7.62" y1="-1.016" x2="7.62" y2="-1.016"/>
<wire layer="21" width="0.12" x1="5.08" y1="0.952" x2="5.334" y2="1.27"/>
<wire layer="21" width="0.12" x1="5.334" y1="1.27" x2="7.366" y2="1.27"/>
<wire layer="21" width="0.12" x1="7.366" y1="1.27" x2="7.62" y2="1.016"/>
<wire layer="21" width="0.12" x1="7.62" y1="1.016" x2="7.874" y2="1.27"/>
<wire layer="21" width="0.12" x1="7.874" y1="1.27" x2="9.906" y2="1.27"/>
<wire layer="21" width="0.12" x1="9.906" y1="1.27" x2="10.16" y2="1.016"/>
<wire layer="21" width="0.12" x1="10.16" y1="1.016" x2="10.16" y2="-1.016"/>
<wire layer="21" width="0.12" x1="10.16" y1="-1.016" x2="9.906" y2="-1.27"/>
<wire layer="21" width="0.12" x1="9.906" y1="-1.27" x2="7.874" y2="-1.27"/>
<wire layer="21" width="0.12" x1="7.874" y1="-1.27" x2="7.62" y2="-1.016"/>
<wire layer="21" width="0.12" x1="7.62" y1="-1.016" x2="7.366" y2="-1.27"/>
<wire layer="21" width="0.12" x1="7.366" y1="-1.27" x2="5.334" y2="-1.27"/>
<wire layer="21" width="0.12" x1="5.334" y1="-1.27" x2="5.08" y2="-1.016"/>
<wire layer="21" width="0.12" x1="5.08" y1="-1.016" x2="5.08" y2="0.952"/>
<wire layer="21" width="0.12" x1="7.62" y1="1.016" x2="7.62" y2="-1.016"/>
<wire layer="21" width="0.12" x1="2.54" y1="1.016" x2="2.54" y2="-1.016"/>
<wire layer="21" width="0.12" x1="0" y1="1.016" x2="0" y2="-1.016"/>
<wire layer="21" width="0.12" x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016"/>
<wire layer="51" width="0.25" x1="5.08" y1="1.016" x2="5.08" y2="-1.016"/>
</package>
<package name="CAPAE530X600L230X70N">
<description>Part Number (Digi-Key): P16435DKR-ND
Unique Name: PANASONIC_SVP,SIZE_B6_CAPP</description>
<smd name="1" x="-2.095" y="0" layer="1" dx="3" dy="1.63" roundness="31" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="2.095" y="0" layer="1" dx="3" dy="1.63" roundness="31" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.12" x1="2.75" y1="1" x2="2.75" y2="2.75"/>
<wire layer="21" width="0.12" x1="2.75" y1="2.75" x2="-1.65" y2="2.75"/>
<wire layer="21" width="0.12" x1="-1.65" y1="2.75" x2="-2.75" y2="1.65"/>
<wire layer="21" width="0.12" x1="-2.75" y1="1.65" x2="-2.75" y2="1"/>
<wire layer="21" width="0.12" x1="2.75" y1="-1" x2="2.75" y2="-2.75"/>
<wire layer="21" width="0.12" x1="2.75" y1="-2.75" x2="-1.65" y2="-2.75"/>
<wire layer="21" width="0.12" x1="-1.65" y1="-2.75" x2="-2.75" y2="-1.65"/>
<wire layer="21" width="0.12" x1="-2.75" y1="-1.65" x2="-2.75" y2="-1"/>
<wire layer="51" width="0.12" x1="2.75" y1="2.75" x2="2.75" y2="-2.75"/>
<wire layer="51" width="0.12" x1="2.75" y1="-2.75" x2="-1.65" y2="-2.75"/>
<wire layer="51" width="0.12" x1="-1.65" y1="-2.75" x2="-2.75" y2="-1.65"/>
<wire layer="51" width="0.12" x1="-2.75" y1="-1.65" x2="-2.75" y2="1.65"/>
<wire layer="51" width="0.12" x1="-2.75" y1="1.65" x2="-1.65" y2="2.75"/>
<wire layer="51" width="0.12" x1="-1.65" y1="2.75" x2="2.75" y2="2.75"/>
<text x="-2.667" y="0" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="center-left" distance="76">Cap 5mm</text>
</package>
<package name="3314G-1-504">
<smd name="1" x="1.15" y="-1.675" layer="1" dx="2" dy="1.3" rot="R90" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="-1.15" y="-1.675" layer="1" dx="2" dy="1.3" rot="R270" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="0" y="2.325" layer="1" dx="2" dy="2" rot="R180" stop="yes" cream="yes" thermals="no"/>
<circle layer="51" x="1.28" y="-3.275" radius="0.05" width="0"/>
<circle layer="21" x="1.28" y="-3.275" radius="0.05" width="0"/>
<wire layer="51" width="0.127" x1="-2.25" y1="2.575" x2="2.25" y2="2.575"/>
<wire layer="51" width="0.127" x1="2.25" y1="2.575" x2="2.25" y2="-1.925"/>
<wire layer="51" width="0.127" x1="2.25" y1="-1.925" x2="-2.25" y2="-1.925"/>
<wire layer="51" width="0.127" x1="-2.25" y1="-1.925" x2="-2.25" y2="2.575"/>
<wire layer="21" width="0.127" x1="-1.315" y1="2.575" x2="-2.25" y2="2.575"/>
<wire layer="21" width="0.127" x1="-2.25" y1="2.575" x2="-2.25" y2="-1.925"/>
<wire layer="21" width="0.127" x1="-2.25" y1="-1.925" x2="-2.15" y2="-1.925"/>
<wire layer="21" width="0.127" x1="2.15" y1="-1.925" x2="2.25" y2="-1.925"/>
<wire layer="21" width="0.127" x1="2.25" y1="-1.925" x2="2.25" y2="2.575"/>
<wire layer="21" width="0.127" x1="2.25" y1="2.575" x2="1.315" y2="2.575"/>
<wire layer="21" width="0.12" x1="-1.6" y1="-0.575" x2="-1.2" y2="-0.075"/>
<wire layer="21" width="0.12" x1="-1.2" y1="-0.075" x2="-0.9" y2="-0.575"/>
<wire layer="21" width="0.12" x1="-0.9" y1="-0.575" x2="-0.5" y2="-0.075"/>
<wire layer="21" width="0.12" x1="-0.5" y1="-0.075" x2="-0.2" y2="-0.675"/>
<wire layer="21" width="0.12" x1="-0.2" y1="-0.675" x2="0.2" y2="-0.075"/>
<wire layer="21" width="0.12" x1="0.2" y1="-0.075" x2="0.5" y2="-0.575"/>
<wire layer="21" width="0.12" x1="0.5" y1="-0.575" x2="0.9" y2="-0.075"/>
<wire layer="21" width="0.12" x1="0.9" y1="-0.075" x2="1.3" y2="-0.575"/>
<wire layer="21" width="0.12" x1="1.3" y1="-0.575" x2="1.5" y2="-0.175"/>
<wire layer="21" width="0.25" x1="0" y1="1.325" x2="0" y2="0.125"/>
<wire layer="21" width="0.25" x1="-0.3" y1="0.525" x2="0" y2="0.125"/>
<wire layer="21" width="0.25" x1="0" y1="0.125" x2="0.4" y2="0.525"/>
<text x="-3.5" y="-3.325" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="76">3314G-1-504</text>
</package>
<package name="SOT95P237X111-3N">
<description>Description: Bipolar (BJT) Transistor NPN 45 V 100 mA 100MHz 300 mW Surface Mount SOT-23-3 (TO-236)</description>
<smd name="1" x="-1.06" y="0.95" layer="1" dx="1.23" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="-1.06" y="-0.95" layer="1" dx="1.23" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="3" x="1.06" y="0" layer="1" dx="1.23" dy="0.6" roundness="26" rot="R0" stop="yes" cream="yes" thermals="no"/>
<wire layer="51" width="0.127" x1="0.65" y1="1.45" x2="0.65" y2="-1.45"/>
<wire layer="51" width="0.127" x1="0.65" y1="-1.45" x2="-0.65" y2="-1.45"/>
<wire layer="51" width="0.127" x1="-0.65" y1="-1.45" x2="-0.65" y2="1.45"/>
<wire layer="51" width="0.127" x1="-0.65" y1="1.45" x2="0.65" y2="1.45"/>
<wire layer="21" width="0.127" x1="-0.65" y1="1.564" x2="0.65" y2="1.564"/>
<wire layer="21" width="0.127" x1="0.65" y1="-1.564" x2="-0.65" y2="-1.564"/>
<wire layer="21" width="0.127" x1="0.65" y1="-1.564" x2="0.65" y2="-0.614"/>
<text x="-2.765" y="1.7" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="bottom-left" distance="76">BC847B</text>
<wire layer="21" width="0.127" x1="0.65" y1="1.564" x2="0.65" y2="0.614"/>
<circle layer="21" x="-2.36" y="0.95" radius="0.1" width="0"/>
<circle layer="51" x="-2.36" y="0.95" radius="0.1" width="0"/>
</package>
<package name="P355">
<smd name="1" x="-1.702" y="0" layer="1" dx="1.23" dy="1.87" roundness="41" rot="R0" stop="yes" cream="yes" thermals="no"/>
<smd name="2" x="1.337" y="0" layer="1" dx="1.23" dy="1.87" roundness="41" rot="R180" stop="yes" cream="yes" thermals="no"/>
<wire layer="21" width="0.15" x1="-0.862" y1="0.88" x2="0.497" y2="0.88"/>
<wire layer="21" width="0.15" x1="-0.862" y1="-0.88" x2="0.497" y2="-0.88"/>
<wire layer="51" width="0.12" x1="-1.862" y1="0.88" x2="1.497" y2="0.88"/>
<wire layer="51" width="0.12" x1="1.497" y1="0.88" x2="1.497" y2="-0.88"/>
<wire layer="51" width="0.12" x1="1.497" y1="-0.88" x2="-1.862" y2="-0.88"/>
<wire layer="51" width="0.12" x1="-1.862" y1="-0.88" x2="-1.862" y2="0.88"/>
<wire layer="21" width="0.25" x1="2.317" y1="0.8" x2="2.317" y2="-0.9"/>
</package>
<package name="DIL28/3">
<description>Description: PIC PIC&#174; 18F Microcontroller IC 8-Bit 48MHz 32KB (16K x 16) FLASH 28-SPDIP</description>
<pad name="1" x="-16.51" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="8" x="1.27" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="9" x="3.81" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="10" x="6.35" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="11" x="8.89" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="12" x="11.43" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="13" x="13.97" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="14" x="16.51" y="-3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="15" x="16.51" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="16" x="13.97" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="17" x="11.43" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="18" x="8.89" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="20" x="3.81" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="21" x="1.27" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="22" x="-1.27" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="23" x="-3.81" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="24" x="-6.35" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="25" x="-8.89" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="26" x="-11.43" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="27" x="-13.97" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="28" x="-16.51" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<pad name="19" x="6.35" y="3.81" drill="0.813" shape="long" diameter="1.321" rot="R270" stop="yes" thermals="no"/>
<wire layer="21" width="0.152" x1="17.78" y1="2.921" x2="-17.78" y2="2.921"/>
<wire layer="21" width="0.152" x1="-17.78" y1="-2.921" x2="17.78" y2="-2.921"/>
<wire layer="21" width="0.152" x1="17.78" y1="2.921" x2="17.78" y2="-2.921"/>
<wire layer="21" width="0.152" x1="-17.78" y1="2.921" x2="-17.78" y2="1.016"/>
<wire layer="21" width="0.152" x1="-17.78" y1="-2.921" x2="-17.78" y2="-1.016"/>
<wire layer="21" width="0.152" x1="-17.78" y1="-1.016" x2="-17.78" y2="1.016" curve="180"/>
<text x="-3.5" y="0" size="0.74" layer="21" font="vector" ratio="10" rot="R0" align="center-left" distance="76">PIC18F2550</text>
</package>
<package name="Pad">
<pad name="GND" x="0" y="0" drill="1" shape="square" diameter="1.5" rot="R0" stop="no" thermals="no"/>
<vertex x="-1.499" y="0.749"/>
<vertex x="1.499" y="0.749"/>
<vertex x="1.499" y="-0.749"/>
<vertex x="-1.499" y="-0.749"/>
</polygon>
</polygon>
<rectangle x1="-1.55" y1="0.8" x2="1.55" y2="-0.8" layer="30" rot="R0"/>
<rectangle x1="-1.6" y1="0.85" x2="1.6" y2="-0.85" layer="29" rot="R0"/>
</package>
<package name="5V+">
<pad name="1" x="0" y="0" drill="1" diameter="1.493" rot="R0" stop="no" thermals="no"/>
<vertex x="1.499" y="0"/>
<vertex x="1.426" y="0.231"/>
<vertex x="1.213" y="0.44"/>
<vertex x="0.881" y="0.606"/>
<vertex x="0.463" y="0.712"/>
<vertex x="0" y="0.749"/>
<vertex x="-0.463" y="0.712"/>
<vertex x="-0.881" y="0.606"/>
<vertex x="-1.213" y="0.44"/>
<vertex x="-1.426" y="0.231"/>
<vertex x="-1.499" y="0"/>
<vertex x="-1.426" y="-0.231"/>
<vertex x="-1.213" y="-0.44"/>
<vertex x="-0.881" y="-0.606"/>
<vertex x="-0.463" y="-0.712"/>
<vertex x="0" y="-0.749"/>
<vertex x="0.463" y="-0.712"/>
<vertex x="0.881" y="-0.606"/>
<vertex x="1.213" y="-0.44"/>
<vertex x="1.426" y="-0.231"/>
</polygon>
</polygon>
<vertex x="1.55" y="0"/>
<vertex x="1.474" y="0.247"/>
<vertex x="1.254" y="0.47"/>
<vertex x="0.911" y="0.647"/>
<vertex x="0.479" y="0.761"/>
<vertex x="0" y="0.8"/>
<vertex x="-0.479" y="0.761"/>
<vertex x="-0.911" y="0.647"/>
<vertex x="-1.254" y="0.47"/>
<vertex x="-1.474" y="0.247"/>
<vertex x="-1.55" y="0"/>
<vertex x="-1.474" y="-0.247"/>
<vertex x="-1.254" y="-0.47"/>
<vertex x="-0.911" y="-0.647"/>
<vertex x="-0.479" y="-0.761"/>
<vertex x="0" y="-0.8"/>
<vertex x="0.479" y="-0.761"/>
<vertex x="0.911" y="-0.647"/>
<vertex x="1.254" y="-0.47"/>
<vertex x="1.474" y="-0.247"/>
</polygon>
</polygon>
<text x="-1.5" y="-0.75" size="0.987" layer="21" font="vector" ratio="10" rot="R0" align="top-left" distance="76">5V+</text>
</package>
<package name="12V+">
</polygon>
</polygon>
</polygon>
</polygon>
<text x="1.5" y="2" size="0.987" layer="21" font="vector" ratio="10" rot="SR270" align="bottom-left" distance="76">12V+</text>
</package>
<package name="Pad_Pad5">
<smd name="1" x="0" y="0" layer="1" dx="2.7" dy="2.7" roundness="100" rot="R0" stop="yes" cream="yes" thermals="no"/>
</package>
<package name="Pad_Pad34">
</package>
<package name="Pad_Pad39">
<smd name="1" x="0" y="0" layer="1" dx="2.5" dy="2.5" roundness="100" rot="R0" stop="yes" cream="yes" thermals="no"/>
</package>
<package name="Pad_Pad44">
</package>
<package name="5V+_Pad47">
</polygon>
</polygon>
</polygon>
</polygon>
<text x="-1.5" y="-1.5" size="0.987" layer="21" font="vector" ratio="10" rot="R90" align="bottom-left" distance="76">5V+</text>
</package>
<package name="Pad_Pad50">
</polygon>
</polygon>
</package>
<package name="Pad_Pad51">
<smd name="1" x="0" y="0" layer="1" dx="6" dy="6" roundness="100" rot="R0" stop="yes" cream="yes" thermals="no"/>
</package>
<package name="Pad_Pad52">
<smd name="1" x="0" y="0" layer="1" dx="2" dy="2" roundness="100" rot="R0" stop="no" cream="no" thermals="no"/>
<vertex x="0.999" y="0"/>
<vertex x="0.95" y="0.618"/>
<vertex x="0.808" y="1.175"/>
<vertex x="0.587" y="1.617"/>
<vertex x="0.309" y="1.901"/>
<vertex x="0" y="1.999"/>
<vertex x="-0.309" y="1.901"/>
<vertex x="-0.587" y="1.617"/>
<vertex x="-0.808" y="1.175"/>
<vertex x="-0.95" y="0.618"/>
<vertex x="-0.999" y="0"/>
<vertex x="-0.95" y="-0.618"/>
<vertex x="-0.808" y="-1.175"/>
<vertex x="-0.587" y="-1.617"/>
<vertex x="-0.309" y="-1.901"/>
<vertex x="0" y="-1.999"/>
<vertex x="0.309" y="-1.901"/>
<vertex x="0.587" y="-1.617"/>
<vertex x="0.808" y="-1.175"/>
<vertex x="0.95" y="-0.618"/>
</polygon>
<vertex x="1.05" y="0"/>
<vertex x="0.999" y="0.633"/>
<vertex x="0.849" y="1.205"/>
<vertex x="0.617" y="1.658"/>
<vertex x="0.324" y="1.95"/>
<vertex x="0" y="2.05"/>
<vertex x="-0.324" y="1.95"/>
<vertex x="-0.617" y="1.658"/>
<vertex x="-0.849" y="1.205"/>
<vertex x="-0.999" y="0.633"/>
<vertex x="-1.05" y="0"/>
<vertex x="-0.999" y="-0.633"/>
<vertex x="-0.849" y="-1.205"/>
<vertex x="-0.617" y="-1.658"/>
<vertex x="-0.324" y="-1.95"/>
<vertex x="0" y="-2.05"/>
<vertex x="0.324" y="-1.95"/>
<vertex x="0.617" y="-1.658"/>
<vertex x="0.849" y="-1.205"/>
<vertex x="0.999" y="-0.633"/>
</polygon>
<vertex x="0.904" y="0.603"/>
<vertex x="0.769" y="1.146"/>
<vertex x="0.558" y="1.578"/>
<vertex x="0.294" y="1.855"/>
<vertex x="0" y="1.95"/>
<vertex x="-0.294" y="1.855"/>
<vertex x="-0.558" y="1.578"/>
<vertex x="-0.769" y="1.146"/>
<vertex x="-0.904" y="0.603"/>
<vertex x="-0.904" y="-0.603"/>
<vertex x="-0.769" y="-1.146"/>
<vertex x="-0.558" y="-1.578"/>
<vertex x="-0.294" y="-1.855"/>
<vertex x="0" y="-1.95"/>
<vertex x="0.294" y="-1.855"/>
<vertex x="0.558" y="-1.578"/>
<vertex x="0.769" y="-1.146"/>
<vertex x="0.904" y="-0.603"/>
</polygon>
</package>
<package name="Pad_Pad78">
<smd name="1" x="0" y="0" layer="1" dx="0.5" dy="0.5" roundness="100" rot="R0" stop="no" cream="no" thermals="no"/>
<vertex x="0.249" y="0"/>
<vertex x="0.237" y="0.078"/>
<vertex x="0.201" y="0.149"/>
<vertex x="0.146" y="0.205"/>
<vertex x="0.077" y="0.242"/>
<vertex x="0" y="0.254"/>
<vertex x="-0.077" y="0.242"/>
<vertex x="-0.146" y="0.205"/>
<vertex x="-0.201" y="0.149"/>
<vertex x="-0.237" y="0.078"/>
<vertex x="-0.249" y="0"/>
<vertex x="-0.237" y="-0.078"/>
<vertex x="-0.201" y="-0.149"/>
<vertex x="-0.146" y="-0.205"/>
<vertex x="-0.077" y="-0.242"/>
<vertex x="0" y="-0.254"/>
<vertex x="0.077" y="-0.242"/>
<vertex x="0.146" y="-0.205"/>
<vertex x="0.201" y="-0.149"/>
<vertex x="0.237" y="-0.078"/>
</polygon>
<vertex x="0.3" y="0"/>
<vertex x="0.285" y="0.094"/>
<vertex x="0.243" y="0.179"/>
<vertex x="0.176" y="0.247"/>
<vertex x="0.093" y="0.29"/>
<vertex x="0" y="0.305"/>
<vertex x="-0.093" y="0.29"/>
<vertex x="-0.176" y="0.247"/>
<vertex x="-0.243" y="0.179"/>
<vertex x="-0.285" y="0.094"/>
<vertex x="-0.3" y="0"/>
<vertex x="-0.285" y="-0.094"/>
<vertex x="-0.243" y="-0.179"/>
<vertex x="-0.176" y="-0.247"/>
<vertex x="-0.093" y="-0.29"/>
<vertex x="0" y="-0.305"/>
<vertex x="0.093" y="-0.29"/>
<vertex x="0.176" y="-0.247"/>
<vertex x="0.243" y="-0.179"/>
<vertex x="0.285" y="-0.094"/>
</polygon>
<vertex x="0.2" y="0"/>
<vertex x="0.19" y="0.063"/>
<vertex x="0.162" y="0.12"/>
<vertex x="0.118" y="0.166"/>
<vertex x="0.062" y="0.195"/>
<vertex x="0" y="0.205"/>
<vertex x="-0.062" y="0.195"/>
<vertex x="-0.118" y="0.166"/>
<vertex x="-0.162" y="0.12"/>
<vertex x="-0.19" y="0.063"/>
<vertex x="-0.2" y="0"/>
<vertex x="-0.19" y="-0.063"/>
<vertex x="-0.162" y="-0.12"/>
<vertex x="-0.118" y="-0.166"/>
<vertex x="-0.062" y="-0.195"/>
<vertex x="0" y="-0.205"/>
<vertex x="0.062" y="-0.195"/>
<vertex x="0.118" y="-0.166"/>
<vertex x="0.162" y="-0.12"/>
<vertex x="0.19" y="-0.063"/>
</polygon>
</package>
</packages>
</library>
</libraries>
<attributes/>
<variantdefs/>
<classes>
<class number="0" name="Default" width="0.33" drill="0">
<clearance class="0" value="0.33"/>
</class>
</classes>
<designrules name="default *">
<description language="en">EAGLE Design Rules</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="0.61mm"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="0mil"/>
<param name="rlMaxPadTop" value="0mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="0mil"/>
<param name="rlMaxPadBottom" value="0mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="2mil"/>
<param name="mlMaxStopFrame" value="2mil"/>
<param name="mlMinCreamFrame" value="2mil"/>
<param name="mlMaxCreamFrame" value="2mil"/>
<param name="mlViaStopLimit" value="79mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="29"/>
<param name="maxErrors" value="50"/>
</designrules>
<elements>
<element name="D26" library="common" package="KINGBRIGHT_AA3528SGS" value="LED" x="66.3" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="66.3" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="66.3" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="66.3" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="66.3" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D25" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="70.903767" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="70.903767" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="70.903767" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="70.903767" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="70.903767" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D24" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="75.5075" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="75.5075" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="75.5075" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="75.5075" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="75.5075" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D23" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="80.111233" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="80.111233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="80.111233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="80.111233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="80.111233" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D22" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="84.715" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="84.715" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="84.715" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="84.715" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="84.715" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D21" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="89.318733" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="89.318733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="89.318733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="89.318733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="89.318733" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D20" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="94.081267" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="94.081267" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="94.081267" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="94.081267" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="94.081267" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D19" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="98.685" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="98.685" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="98.685" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="98.685" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="98.685" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D18" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="103.288733" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="103.288733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="103.288733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="103.288733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="103.288733" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D17" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="107.8925" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="107.8925" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="107.8925" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="107.8925" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="107.8925" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D16" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="112.496267" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="112.496267" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="112.496267" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="112.496267" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="112.496267" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D15" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="117.1" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="117.1" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="117.1" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="117.1" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="117.1" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D14" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="121.703733" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="121.703733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="121.703733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="121.703733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="121.703733" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D13" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="126.3075" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="126.3075" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="126.3075" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="126.3075" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="126.3075" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D12" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="130.911233" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="130.911233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="130.911233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="130.911233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="130.911233" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D1" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="135.515" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="135.515" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="135.515" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="135.515" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="135.515" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D2" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="140.118733" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="140.118733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="140.118733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="140.118733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="140.118733" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D3" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="144.7225" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="144.7225" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="144.7225" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="144.7225" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="144.7225" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D4" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="149.326233" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="149.326233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="149.326233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="149.326233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="149.326233" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D5" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="153.93" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="153.93" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="153.93" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="153.93" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="153.93" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D6" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="158.533733" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="158.533733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="158.533733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="158.533733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="158.533733" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D7" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="163.1375" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="163.1375" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="163.1375" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="163.1375" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="163.1375" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D8" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="167.741233" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="167.741233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="167.741233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="167.741233" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="167.741233" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D9" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="173.9325" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="173.9325" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="173.9325" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="173.9325" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="173.9325" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D10" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="180.123733" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="180.123733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="180.123733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="180.123733" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="180.123733" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="D11" library="common" package="KINGBRIGHT_AA3528SGS" value="AA3528SGS" x="186.315" y="32" rot="R270">
<attribute name="MANUFACTURER" value="Kingbright" x="186.315" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/sensors_led/AA3528SGS.pdf" x="186.315" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="754-1538-6-ND" x="186.315" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="KINGBRIGHT_AA3528SGS" x="186.315" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="Q11" library="common" package="SOT23" value="SOT23" x="184.2" y="31.5" rot="MR-270"/>
<element name="Q10" library="common" package="SOT23" value="SOT23" x="177.901233" y="30.571267" rot="MR-270"/>
<element name="Q9" library="common" package="SOT23" value="SOT23" x="171.71" y="30.571267" rot="MR-270"/>
<element name="Q8" library="common" package="SOT23" value="SOT23" x="166.3125" y="30.571267" rot="MR-270"/>
<element name="Q7" library="common" package="SOT23" value="SOT23" x="161.708733" y="30.571267" rot="MR-270"/>
<element name="Q6" library="common" package="SOT23" value="SOT23" x="157.105" y="30.571267" rot="MR-270"/>
<element name="Q5" library="common" package="SOT23" value="SOT23" x="152.501233" y="30.571267" rot="MR-270"/>
<element name="Q4" library="common" package="SOT23" value="SOT23" x="145.4" y="30.571267" rot="MR-270"/>
<element name="Q3" library="common" package="SOT23" value="SOT23" x="141.5" y="30.571267" rot="MR-270"/>
<element name="Q2" library="common" package="SOT23" value="SOT23" x="137.6" y="30.571267" rot="MR-270"/>
<element name="Q1" library="common" package="SOT23" value="SOT23" x="134.086233" y="32.3175" rot="MR-270"/>
<element name="Q12" library="common" package="SOT23" value="SOT23" x="120.275" y="32.3175" rot="MR-270"/>
<element name="Q13" library="common" package="SOT23" value="SOT23" x="106.463733" y="32.317533" rot="MR-270"/>
<element name="Q14" library="common" package="SOT23" value="SOT23" x="92.493733" y="32.3175" rot="MR-270"/>
<element name="Q15" library="common" package="SOT23" value="SOT23" x="78.6825" y="32.3175" rot="MR-270"/>
<element name="Q16" library="common" package="SOT23" value="SOT23" x="64.9" y="33.7" rot="MR-270"/>
<element name="R1-1206" library="common" package="RES_1206_M" value="470" x="183.8" y="25.3" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="183.8" y="25.3" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-1" library="common" package="RES_1206_M" value="470" x="179.5" y="26.25" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="179.5" y="26.25" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-2" library="common" package="RES_1206_M" value="470" x="173.9325" y="26.26" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="173.9325" y="26.26" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-3" library="common" package="RES_1206_M" value="470" x="167.741233" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="167.741233" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-4" library="common" package="RES_1206_M" value="470" x="163.1375" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="163.1375" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-5" library="common" package="RES_1206_M" value="470" x="158.533733" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="158.533733" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-6" library="common" package="RES_1206_M" value="470" x="153.93" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="153.93" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-7" library="common" package="RES_1206_M" value="470" x="149.326233" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="149.326233" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-8" library="common" package="RES_1206_M" value="470" x="144.7225" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="144.7225" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-9" library="common" package="RES_1206_M" value="470" x="140.118733" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="140.118733" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-10" library="common" package="RES_1206_M" value="470" x="135.515" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="135.515" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-11" library="common" package="RES_1206_M" value="470" x="130.911233" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="130.911233" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-12" library="common" package="RES_1206_M" value="470" x="126.3075" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="126.3075" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-13" library="common" package="RES_1206_M" value="470" x="121.703733" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="121.703733" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-14" library="common" package="RES_1206_M" value="470" x="117.1" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="117.1" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-15" library="common" package="RES_1206_M" value="470" x="112.496233" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="112.496233" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-16" library="common" package="RES_1206_M" value="470" x="107.8925" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="107.8925" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-17" library="common" package="RES_1206_M" value="470" x="103.288733" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="103.288733" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-18" library="common" package="RES_1206_M" value="470" x="98.685" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="98.685" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-19" library="common" package="RES_1206_M" value="470" x="94.081233" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="94.081233" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-20" library="common" package="RES_1206_M" value="470" x="89.318733" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="89.318733" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-21" library="common" package="RES_1206_M" value="470" x="84.715" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="84.715" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-22" library="common" package="RES_1206_M" value="470" x="80.111233" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="80.111233" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-23" library="common" package="RES_1206_M" value="470" x="75.5075" y="25.015" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="75.5075" y="25.015" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-24" library="common" package="RES_1206_M" value="470" x="71.603733" y="26.1" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="71.603733" y="26.1" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-25" library="common" package="RES_1206_M" value="470" x="67.7" y="26.1" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="67.7" y="26.1" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-26" library="common" package="RES_1206_M_R1-26" value="10K" x="113.3" y="20.4" rot="MR-360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="113.3" y="20.4" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-27" library="common" package="RES_1206_M_R1-26" value="10K" x="102.1775" y="31.0475" rot="MR-450.001052296129">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="102.1775" y="31.0475" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-28" library="common" package="RES_1206_M_R1-26" value="10K" x="165.9" y="42.9" rot="MR-720.001683672972">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="165.9" y="42.9" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-29" library="common" package="RES_1206_M_R1-29" value="10K" x="113.3" y="31.6" rot="MR0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="113.3" y="31.6" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-30" library="common" package="RES_1206_M_R1-29" value="10K" x="113.3" y="34.8" rot="MR0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="113.3" y="34.8" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-31" library="common" package="RES_1206_M_R1-26" value="10K" x="74.82" y="32.3075" rot="MR-810.001894132198">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="74.82" y="32.3075" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-32" library="common" package="RES_1206_M" value="1K" x="69.2" y="39.3" rot="R540.001262754521">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="69.2" y="39.3" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-33" library="common" package="RES_1206_M_R1-26" value="10K" x="71.0625" y="32.3175" rot="MR-810.001894132198">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="71.0625" y="32.3175" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-34" library="common" package="RES_1206_M_R1-26" value="10K" x="97.573733" y="31.0475" rot="MR-1170.0027359691">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="97.573733" y="31.0475" size="1.778" layer="28" display="off"/>
</element>
<element name="C3" library="common" package="CAPAE660X600L260X70N" value="100uF 16V" x="-39.34" y="32" rot="R180">
<attribute name="MANUFACTURER" value="Panasonic" x="-39.34" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/cap/svp.pdf" x="-39.34" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="P16436DKR-ND" x="-39.34" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="PANASONIC_SVP,SIZE_C6_CAPP" x="-39.34" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="R1-35" library="common" package="RES_1206_M_R1-26" value="10K" x="125.4" y="32.9" rot="MR-810.001894132198">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="125.4" y="32.9" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-36" library="common" package="RES_1206_M_R1-26" value="10K" x="130" y="32.9" rot="MR-450.001052296129">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="130" y="32.9" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-37" library="common" package="RES_1206_M_R1-26" value="10K" x="113.3" y="27.6" rot="MR-900.002104591424">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="113.3" y="27.6" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-38" library="common" package="RES_1206_M_R1-26" value="10K" x="157.6" y="23.1" rot="MR-360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="157.6" y="23.1" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-39" library="common" package="RES_1206_M_R1-26" value="10K" x="123.1" y="22.3" rot="MR-720.001683672972">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="123.1" y="22.3" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-40" library="common" package="RES_1206_M_R1-26" value="10K" x="174.5" y="41.5" rot="MR-720.001683672972">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="174.5" y="41.5" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-41" library="common" package="RES_1206_M_R1-26" value="10K" x="179.4" y="37.7" rot="MR-720.001683672972">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="179.4" y="37.7" size="1.778" layer="28" display="off"/>
</element>
<element name="R1-42" library="common" package="RES_1206_M_R1-26" value="10K" x="155.3" y="38.7" rot="MR-720.001683672972">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="155.3" y="38.7" size="1.778" layer="28" display="off"/>
</element>
<element name="U1" library="common" package="SOIC28P127_1790X1030X265L83X41N_AD1" value="PIC16F886-I/SO" x="-8.7" y="32" rot="R180">
<attribute name="MANUFACTURER" value="Microchip" x="-8.7" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/microchip/40001291h.pdf" x="-8.7" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="PIC16F886-I/SO-ND" x="-8.7" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="MICROCHIP_C04-052C" x="-8.7" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="Pad1" library="common" package="Pad" value="GND" x="66.3" y="47.2" rot="R0"/>
<element name="Cap-1" library="common" package="RES_1206_M" value="22pF" x="-3.2" y="42.9" rot="R0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-3.2" y="42.9" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-2" library="common" package="RES_1206_M" value="22pF" x="-17.6" y="42.9" rot="R0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-17.6" y="42.9" size="1.778" layer="27" display="off"/>
</element>
<element name="U2" library="common" package="SIP226W48P254L1483H495Q6_AP1" value="TLE4905" x="13.909716" y="25.800093" rot="MR-90.384092181854">
<attribute name="MANUFACTURER" value="Bourns" x="13.909716" y="25.800093" size="1.778" layer="28" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/rc_networks/4300R.pdf" x="13.909716" y="25.800093" size="1.778" layer="28" display="off"/>
</element>
<element name="Cap-3" library="common" package="RES_1206_M" value="100nF" x="-15.2" y="20.8" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-15.2" y="20.8" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-4" library="common" package="RES_1206_M" value="10K" x="-22.5" y="35.1" rot="R0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-22.5" y="35.1" size="1.778" layer="27" display="off"/>
</element>
<element name="U3" library="common" package="ICSP" value="ICSP" x="-52.25" y="37.07" rot="R270">
<attribute name="MANUFACTURER" value="Bourns" x="-52.25" y="37.07" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/rc_networks/4300R.pdf" x="-52.25" y="37.07" size="1.778" layer="27" display="off"/>
</element>
<element name="U4" library="common" package="TSOP18XX" value="TSOP4836" x="-43.006235" y="24.011267" rot="R270">
<attribute name="DESCRIPTION" value="Remote Receiver Sensor, 36.0kHz 45m Through Hole" x="-43.006235" y="24.011267" size="1.778" layer="27" display="off"/>
</element>
<element name="C1" library="common" package="CAP-2.54/6.6x3" value="JUMPER" x="-47" y="32" rot="R90">
<attribute name="UNIQUE_NAME" value="CAP-2.54/6.6x3" x="-47" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-5" library="common" package="RES_1206_M" value="10K" x="-40.3" y="37.6" rot="R0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-40.3" y="37.6" size="1.778" layer="27" display="off"/>
</element>
<element name="U5" library="common" package="BPX_81" value="BPX 81" x="-41.9" y="42.5" rot="R270"/>
<element name="Cap-6" library="common" package="RES_1206_M" value="2K2" x="-47.1" y="42.8" rot="R90">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-47.1" y="42.8" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-7" library="common" package="RES_1206_M" value="10K op" x="-30.4" y="41.3" rot="R90">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-30.4" y="41.3" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-8" library="common" package="RES_1206_M" value="10K" x="-35.3" y="41.4" rot="R90">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-35.3" y="41.4" size="1.778" layer="27" display="off"/>
</element>
<element name="IC1" library="common" package="SO8-7_5" value="PCF8583" x="13.4" y="-10.1" rot="R270">
<attribute name="DESCRIPTION" value="Real Time Clock (RTC) IC Clock/Calendar 240B I&#178;C, 2-Wire Serial 8-SOIC (0.295&quot;, 7.50mm Width)" x="13.4" y="-10.1" size="1.778" layer="27" display="off"/>
</element>
<element name="U6" library="common" package="SOT95P280X145-5N" value="MCP9800A5T" x="51.6" y="3.9" rot="R270">
<attribute name="DESCRIPTION" value="Temperature Sensor Digital, Local -55&#176;C ~ 125&#176;C 11 b SOT-23-5" x="51.6" y="3.9" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-9" library="common" package="RES_1206_M" value="100nF" x="13.4" y="-16.5" rot="R0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="13.4" y="-16.5" size="1.778" layer="27" display="off"/>
</element>
<element name="U8" library="common" package="SOD2513X120N" value="BAT43WS" x="-46.8" y="37.7" rot="R360">
<attribute name="DESCRIPTION" value="Diode Schottky 30V 200mA (DC) Surface Mount SOD-323" x="-46.8" y="37.7" size="1.778" layer="27" display="off"/>
</element>
<element name="U11" library="common" package="8-30_pF" value="8-30 PF" x="8" y="-3.2" rot="R0"/>
<element name="U9" library="common" package="JXS32_20Mhz" value="JXS32 20MHZ" x="-10.673733" y="42.27" rot="R0"/>
<element name="U10" library="common" package="JTX310_32,768_Mhz" value="JTX310 32,768 MHZ" x="4.1" y="-8" rot="R90"/>
<element name="U12" library="common" package="SOD2513X120N" value="1N 4148WS" x="32.3" y="23.1" rot="R360">
<attribute name="DESCRIPTION" value="Diode Schottky 30V 200mA (DC) Surface Mount SOD-323" x="32.3" y="23.1" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-10" library="common" package="RES_1206_M" value="100nF" x="123.8" y="-3.6" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="123.8" y="-3.6" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-11" library="common" package="RES_1206_M" value="10K" x="-22.5" y="27.6" rot="R0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-22.5" y="27.6" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-12" library="common" package="RES_1206_M" value="10K" x="-5.1" y="20.8" rot="R180">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-5.1" y="20.8" size="1.778" layer="27" display="off"/>
</element>
<element name="Pad2" library="common" package="5V+" value="5V+" x="66.3" y="16.8" rot="R0"/>
<element name="Cap-13" library="common" package="RES_1206_M" value="100R" x="-30.8" y="30.3" rot="R90">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-30.8" y="30.3" size="1.778" layer="27" display="off"/>
</element>
<element name="C9" library="common" package="CAPAE430X550L200X70N" value="10u 25V" x="32.53" y="31.94" rot="R0">
<attribute name="MANUFACTURER" value="Panasonic" x="32.53" y="31.94" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/cap/svp.pdf" x="32.53" y="31.94" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="P16427DKR-ND" x="32.53" y="31.94" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="PANASONIC_SVP,SIZE_A5_CAPP" x="32.53" y="31.94" size="1.778" layer="27" display="off"/>
</element>
<element name="U13" library="common" package="IRF7416" value="IRF7416" x="59.6325" y="41.683767" rot="R360"/>
<element name="U14" library="common" package="SOIC127P600X175-8N" value="LM358DT" x="41.79" y="27.03" rot="R270">
<attribute name="DESCRIPTION" value="General Purpose Amplifier 2 Circuit  8-SOIC" x="41.79" y="27.03" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-14" library="common" package="RES_1206_M" value="100K" x="57.251233" y="31.0475" rot="R450.001052296129">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="57.251233" y="31.0475" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-15" library="common" package="RES_1206_M" value="510K" x="59.95" y="35.81" rot="R90">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="59.95" y="35.81" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-16" library="common" package="RES_1206_M" value="100K" x="53.2825" y="31.0475" rot="R450.001052296129">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="53.2825" y="31.0475" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-17" library="common" package="RES_1206_M" value="100K" x="55.346233" y="36.445" rot="R450.001052296129">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="55.346233" y="36.445" size="1.778" layer="27" display="off"/>
</element>
<element name="Pad3" library="common" package="12V+" value="12V+" x="66.3" y="45" rot="R0"/>
<element name="Pad4" library="common" package="12V+" value="ADAT" x="66.3" y="19" rot="R0"/>
<element name="Cap-18" library="common" package="RES_1206_M_Cap-18" value="100nF" x="73.6" y="43.5" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="73.6" y="43.5" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-19" library="common" package="RES_1206_M" value="100K" x="51.2" y="41.348767" rot="R450.001052296129">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="51.2" y="41.348767" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-20" library="common" package="RES_1206_M_Cap-18" value="100nF" x="61.5" y="26.2" rot="R117.868877614063">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="61.5" y="26.2" size="1.778" layer="27" display="off"/>
</element>
<element name="Q17" library="common" package="SOT95P230X110-3N" value="BC817" x="50.6" y="23.89" rot="R450.001052296129">
<attribute name="DESCRIPTION" value="Bipolar (BJT) Transistor NPN 45V 500mA 100MHz 250mW Surface Mount TO-236AB" x="50.6" y="23.89" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-21" library="common" package="RES_1206_M" value="10K" x="23.81" y="36.7" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="23.81" y="36.7" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-22" library="common" package="RES_1206_M" value="10K" x="29" y="39.9" rot="R450.001052296129">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="29" y="39.9" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-23" library="common" package="RES_1206_M" value="1K" x="47.41" y="26.74" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="47.41" y="26.74" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-24" library="common" package="RES_1206_M" value="10K" x="24.9" y="22.7" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="24.9" y="22.7" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-25" library="common" package="RES_1206_M" value="100nF" x="34.5" y="39.9" rot="R450.001052296129">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="34.5" y="39.9" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-26" library="common" package="RES_1206_M" value="10K" x="24.9" y="26.8" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="24.9" y="26.8" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-27" library="common" package="RES_1206_M" value="10K" x="55.32" y="25.36" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="55.32" y="25.36" size="1.778" layer="27" display="off"/>
</element>
<element name="Pad5" library="common" package="Pad_Pad5" value="PAD" x="171.3" y="20.8" rot="R0"/>
<element name="Pad6" library="common" package="Pad_Pad5" value="PAD" x="171.3" y="43.2" rot="R0"/>
<element name="Pad7" library="common" package="Pad_Pad5" value="PAD" x="166.3" y="20.8" rot="R0"/>
<element name="Pad8" library="common" package="Pad_Pad5" value="PAD" x="161.3" y="20.8" rot="R0"/>
<element name="Pad9" library="common" package="Pad_Pad5" value="PAD" x="156.3" y="20.8" rot="R0"/>
<element name="Pad10" library="common" package="Pad_Pad5" value="PAD" x="151.3" y="20.8" rot="R0"/>
<element name="Pad11" library="common" package="Pad_Pad5" value="PAD" x="146.3" y="20.8" rot="R0"/>
<element name="Pad12" library="common" package="Pad_Pad5" value="PAD" x="141.3" y="20.8" rot="R0"/>
<element name="Pad13" library="common" package="Pad_Pad5" value="PAD" x="136.3" y="20.8" rot="R0"/>
<element name="Pad14" library="common" package="Pad_Pad5" value="PAD" x="131.3" y="20.8" rot="R0"/>
<element name="Pad15" library="common" package="Pad_Pad5" value="PAD" x="126.3" y="20.8" rot="R0"/>
<element name="Pad16" library="common" package="Pad_Pad5" value="PAD" x="166.3" y="43.2" rot="R0"/>
<element name="Pad17" library="common" package="Pad_Pad5" value="PAD" x="161.3" y="43.2" rot="R0"/>
<element name="Pad18" library="common" package="Pad_Pad5" value="PAD" x="156.3" y="43.2" rot="R0"/>
<element name="Pad19" library="common" package="Pad_Pad5" value="PAD" x="151.3" y="43.2" rot="R0"/>
<element name="Pad20" library="common" package="Pad_Pad5" value="PAD" x="146.3" y="43.2" rot="R0"/>
<element name="Pad21" library="common" package="Pad_Pad5" value="PAD" x="141.3" y="43.2" rot="R0"/>
<element name="Pad22" library="common" package="Pad_Pad5" value="PAD" x="136.3" y="43.2" rot="R0"/>
<element name="Pad23" library="common" package="Pad_Pad5" value="PAD" x="131.3" y="43.2" rot="R0"/>
<element name="Pad24" library="common" package="Pad_Pad5" value="PAD" x="126.3" y="43.2" rot="R0"/>
<element name="Pad25" library="common" package="Pad_Pad5" value="PAD" x="176.3" y="43.2" rot="R0"/>
<element name="Pad26" library="common" package="Pad_Pad5" value="PAD" x="181.3" y="43.2" rot="R0"/>
<element name="Pad27" library="common" package="Pad_Pad5" value="PAD" x="176.3" y="20.8" rot="R0"/>
<element name="Pad28" library="common" package="Pad_Pad5" value="PAD" x="181.3" y="20.8" rot="R0"/>
<element name="Pad29" library="common" package="Pad_Pad5" value="PAD" x="190" y="32" rot="R0"/>
<element name="Pad30" library="common" package="Pad_Pad5" value="PAD" x="187.17" y="24.56" rot="R0"/>
<element name="Pad31" library="common" package="Pad_Pad5" value="PAD" x="189.41" y="27.98" rot="R0"/>
<element name="Pad32" library="common" package="Pad_Pad5" value="PAD" x="189.41" y="36.02" rot="R0"/>
<element name="Pad33" library="common" package="Pad_Pad5" value="PAD" x="187.17" y="39.44" rot="R0"/>
<element name="Pad34" library="common" package="Pad_Pad34" value="PAD" x="190" y="32" rot="MR0"/>
<element name="Pad35" library="common" package="Pad_Pad34" value="PAD" x="189.41" y="27.98" rot="MR0"/>
<element name="Pad36" library="common" package="Pad_Pad34" value="PAD" x="187.17" y="24.56" rot="MR0"/>
<element name="Pad37" library="common" package="Pad_Pad34" value="PAD" x="189.41" y="36.02" rot="MR0"/>
<element name="Pad38" library="common" package="Pad_Pad34" value="PAD" x="187.17" y="39.44" rot="MR0"/>
<element name="Pad39" library="common" package="Pad_Pad39" value="PAD" x="-58.3" y="32" rot="R0"/>
<element name="Pad40" library="common" package="Pad_Pad39" value="PAD" x="-57.21" y="26.98" rot="R0"/>
<element name="Pad41" library="common" package="Pad_Pad39" value="PAD" x="-54.62" y="23.17" rot="R0"/>
<element name="Pad42" library="common" package="Pad_Pad39" value="PAD" x="-57.21" y="37.02" rot="R0"/>
<element name="Pad43" library="common" package="Pad_Pad39" value="PAD" x="-54.62" y="40.83" rot="R0"/>
<element name="Pad44" library="common" package="Pad_Pad44" value="PAD" x="-54.62" y="40.83" rot="MR0"/>
<element name="Pad45" library="common" package="Pad_Pad44" value="PAD" x="-54.62" y="23.17" rot="MR0"/>
<element name="Pad46" library="common" package="Pad_Pad44" value="PAD" x="-58.3" y="32" rot="MR0"/>
<element name="Pad47" library="common" package="5V+_Pad47" value="5V+" x="-30.38" y="-26.435" rot="R0"/>
<element name="Pad48" library="common" package="12V+" value="ADAT" x="-30.38" y="-24.235" rot="R0"/>
<element name="Pad49" library="common" package="12V+" value="12V+" x="-30.38" y="1.765" rot="R0"/>
<element name="Pad50" library="common" package="Pad_Pad50" value="GND" x="-30.38" y="3.965" rot="R0"/>
<element name="C4" library="common" package="CAPAE830X700L290X70N" value="330uF 25V" x="-37.72" y="-3.24" rot="R180">
<attribute name="MANUFACTURER" value="Panasonic" x="-37.72" y="-3.24" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/cap/svp.pdf" x="-37.72" y="-3.24" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="P16428DKR-ND" x="-37.72" y="-3.24" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="PANASONIC_SVP,SIZE_E7_CAPP" x="-37.72" y="-3.24" size="1.778" layer="27" display="off"/>
</element>
<element name="C6" library="common" package="CAPAE830X700L290X70N" value="330uF 25V" x="-14.94" y="-8.8" rot="R0">
<attribute name="MANUFACTURER" value="Panasonic" x="-14.94" y="-8.8" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/cap/svp.pdf" x="-14.94" y="-8.8" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="P16428DKR-ND" x="-14.94" y="-8.8" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="PANASONIC_SVP,SIZE_E7_CAPP" x="-14.94" y="-8.8" size="1.778" layer="27" display="off"/>
</element>
<element name="C7" library="common" package="CAPAE660X600L260X70N" value="47uF25V" x="-47.01" y="-8.1" rot="R180">
<attribute name="MANUFACTURER" value="Panasonic" x="-47.01" y="-8.1" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/cap/svp.pdf" x="-47.01" y="-8.1" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="P16436DKR-ND" x="-47.01" y="-8.1" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="PANASONIC_SVP,SIZE_C6_CAPP" x="-47.01" y="-8.1" size="1.778" layer="27" display="off"/>
</element>
<element name="U17" library="common" package="DIOAD1720W120L750D440P" value="ZENER 12V 5W" x="-23.14" y="-11.22" rot="R90"/>
<element name="C8" library="common" package="CAPAE660X600L260X70N" value="47uF25V" x="-46.99" y="-16.59" rot="R180">
<attribute name="MANUFACTURER" value="Panasonic" x="-46.99" y="-16.59" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/cap/svp.pdf" x="-46.99" y="-16.59" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="P16436DKR-ND" x="-46.99" y="-16.59" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="PANASONIC_SVP,SIZE_C6_CAPP" x="-46.99" y="-16.59" size="1.778" layer="27" display="off"/>
</element>
<element name="U18" library="common" package="Untitled" value="UNTITLED" x="-33.59" y="-11.98" rot="R180"/>
<element name="Cap-28" library="common" package="RES_1206_M_Cap-18" value="100nF" x="-17.4" y="-24.32" rot="R720.001683672972">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-17.4" y="-24.32" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-29" library="common" package="RES_1206_M_Cap-18" value="100nF" x="-24.97" y="2.8" rot="R450.001052296129">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-24.97" y="2.8" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-30" library="common" package="RES_1206_M_Cap-18" value="560 R" x="-42.41" y="-24.08" rot="R270">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-42.41" y="-24.08" size="1.778" layer="27" display="off"/>
</element>
<element name="U19" library="common" package="SOD2513X120N_U19" value="BAT43WS" x="-17.28" y="-21.34" rot="R360">
<attribute name="DESCRIPTION" value="Diode Schottky 30V 200mA (DC) Surface Mount SOD-323" x="-17.28" y="-21.34" size="1.778" layer="27" display="off"/>
</element>
<element name="U21" library="common" package="RENESAS_PLZZ0004CA-A" value="78l05" x="-17.02" y="-16.42" rot="R90">
<attribute name="MANUFACTURER" value="Renesas Electronics" x="-17.02" y="-16.42" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/renesas/rqk0607aqdqs.pdf" x="-17.02" y="-16.42" size="1.778" layer="27" display="off"/>
</element>
<element name="U7" library="common" package="P243" value="CR 1220" x="17.9" y="-26.5" rot="R360"/>
<element name="Pad51" library="common" package="Pad_Pad51" value="PAD" x="-17.63" y="2.42" rot="R0"/>
<element name="Cap-31" library="common" package="RES_1206_M_Cap-18" value="Vagy" x="-38.05" y="-23.79" rot="R0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="-38.05" y="-23.79" size="1.778" layer="27" display="off"/>
</element>
<element name="Pad52" library="common" package="Pad_Pad52" value="PAD" x="-6.84" y="-11.24" rot="MR0"/>
<element name="Pad53" library="common" package="Pad_Pad52" value="PAD" x="-53.94" y="-11.24" rot="MR0"/>
<element name="Pad54" library="common" package="Pad_Pad52" value="PAD" x="-7.42" y="-5.85" rot="MR-13.1952180216121"/>
<element name="Pad55" library="common" package="Pad_Pad52" value="PAD" x="-53.36" y="-16.63" rot="MR-13.1952180216121"/>
<element name="Pad56" library="common" package="Pad_Pad52" value="PAD" x="-34.6" y="11.9" rot="MR-283.195849399289"/>
<element name="Pad57" library="common" package="Pad_Pad52" value="PAD" x="-21.04" y="-32.66" rot="MR-111.915846122546"/>
<element name="Pad58" library="common" package="Pad_Pad52" value="PAD" x="-7.42" y="-16.63" rot="MR-349.292260645873"/>
<element name="Pad59" library="common" package="Pad_Pad52" value="PAD" x="-53.36" y="-5.85" rot="MR-349.292260645873"/>
<element name="Pad60" library="common" package="Pad_Pad52" value="PAD" x="-9.42" y="-0.91" rot="MR-206.597121768548"/>
<element name="Pad61" library="common" package="Pad_Pad52" value="PAD" x="-51.36" y="-0.91" rot="MR-335.409493269964"/>
<element name="Pad62" library="common" package="Pad_Pad52" value="PAD" x="-48.7" y="3.47" rot="MR-321.624128718851"/>
<element name="Pad63" library="common" package="Pad_Pad52" value="PAD" x="-12.08" y="3.47" rot="MR-38.8178906204134"/>
<element name="Pad64" library="common" package="Pad_Pad52" value="PAD" x="-44.8" y="7.3" rot="MR-309.374291059085"/>
<element name="Pad65" library="common" package="Pad_Pad52" value="PAD" x="-15.98" y="7.3" rot="MR-51.245345196769"/>
<element name="Pad66" library="common" package="Pad_Pad52" value="PAD" x="-39.74" y="10.18" rot="MR-294.614898256676"/>
<element name="Pad67" library="common" package="Pad_Pad52" value="PAD" x="-21.04" y="10.18" rot="MR-246.291637814628"/>
<element name="Pad68" library="common" package="Pad_Pad52" value="PAD" x="-26.3" y="11.9" rot="MR-260.512450289879"/>
<element name="Pad69" library="common" package="Pad_Pad52" value="PAD" x="-9.42" y="-21.57" rot="MR-331.410247859261"/>
<element name="Pad70" library="common" package="Pad_Pad52" value="PAD" x="-51.36" y="-21.57" rot="MR-31.3236026601596"/>
<element name="Pad71" library="common" package="Pad_Pad52" value="PAD" x="-48.7" y="-25.95" rot="MR-41.3274457630558"/>
<element name="Pad72" library="common" package="Pad_Pad52" value="PAD" x="-12.08" y="-25.95" rot="MR-321.624128718851"/>
<element name="Pad73" library="common" package="Pad_Pad52" value="PAD" x="-15.98" y="-29.78" rot="MR-306.641282375733"/>
<element name="Pad74" library="common" package="Pad_Pad52" value="PAD" x="-44.8" y="-29.78" rot="MR-232.254171834189"/>
<element name="Pad75" library="common" package="Pad_Pad52" value="PAD" x="-39.74" y="-32.66" rot="MR-68.5085635635964"/>
<element name="Pad76" library="common" package="Pad_Pad52" value="PAD" x="-26.24" y="-34.36" rot="MR-100.554093045726"/>
<element name="Pad77" library="common" package="Pad_Pad52" value="PAD" x="-34.54" y="-34.36" rot="MR-78.9593137470775"/>
<element name="U20" library="common" package="SOD2513X120N" value="1N 4148WS" x="32.3" y="26.8" rot="R360">
<attribute name="DESCRIPTION" value="Diode Schottky 30V 200mA (DC) Surface Mount SOD-323" x="32.3" y="26.8" size="1.778" layer="27" display="off"/>
</element>
<element name="C10" library="common" package="CAPAE430X550L200X70N" value="10u 16V" x="23.79" y="32" rot="R0">
<attribute name="MANUFACTURER" value="Panasonic" x="23.79" y="32" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/cap/svp.pdf" x="23.79" y="32" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="P16427DKR-ND" x="23.79" y="32" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="PANASONIC_SVP,SIZE_A5_CAPP" x="23.79" y="32" size="1.778" layer="27" display="off"/>
</element>
<element name="Pad78" library="common" package="Pad_Pad78" value="PAD" x="55.4" y="14.8" rot="R0"/>
<element name="U15" library="common" package="SOIC127P1030X265-28N" value="PIC18F2550-I/SO" x="63.3" y="-17.1" rot="R270">
<attribute name="DESCRIPTION" value="PIC PIC&#174; 18F Microcontroller IC 8-Bit 48MHz 32KB (16K x 16) FLASH 28-SOIC" x="63.3" y="-17.1" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-32" library="common" package="RES_1206_M" value="10K" x="5.4" y="-16.5" rot="R0">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="5.4" y="-16.5" size="1.778" layer="27" display="off"/>
</element>
<element name="U16" library="common" package="SOD3715X135N" value="BAT46-SOD123" x="21.5" y="-6.3" rot="R270">
<attribute name="DESCRIPTION" value="Diode Schottky 100V 150mA (DC) Surface Mount SOD-123" x="21.5" y="-6.3" size="1.778" layer="27" display="off"/>
</element>
<element name="D27" library="common" package="SODFL2512X100N" value="1N4148WS" x="16.9" y="-3.4" rot="R180">
<attribute name="DESCRIPTION" value="Diode Standard 75V 300mA (DC) Surface Mount SOD-323" x="16.9" y="-3.4" size="1.778" layer="27" display="off"/>
</element>
<element name="U22" library="common" package="DC-10BS" value="12V 2A" x="161.800002" y="-31.900002" rot="R225"/>
<element name="U23" library="common" package="Untitled" value="UNTITLED" x="137.499893" y="-18.900082" rot="R630.001473213747"/>
<element name="U24" library="common" package="Fuse_holder" value="750mA" x="141.6" y="-31.5" rot="R360"/>
<element name="C2" library="common" package="CAPAE660X600L260X70N" value="100uF 16V" x="123.7" y="-10.4" rot="R630.001473213747">
<attribute name="MANUFACTURER" value="Panasonic" x="123.7" y="-10.4" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/cap/svp.pdf" x="123.7" y="-10.4" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="P16436DKR-ND" x="123.7" y="-10.4" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="PANASONIC_SVP,SIZE_C6_CAPP" x="123.7" y="-10.4" size="1.778" layer="27" display="off"/>
</element>
<element name="U25" library="common" package="DPAK229P990X238-4N" value="MC7805 DPAK" x="132.8" y="-8.2" rot="R180">
<attribute name="DESCRIPTION" value="Linear Voltage Regulator IC Positive Fixed 1 Output  1A DPAK" x="132.8" y="-8.2" size="1.778" layer="27" display="off"/>
</element>
<element name="C" library="common" package="2200-3300uF" value="cap 16,5mm" x="147.2" y="-9.3" rot="R0"/>
<element name="J1" library="common" package="JMP3" value="JMP3" x="160.8" y="-4.9" rot="R90"/>
<element name="U26" library="common" package="VREG_TPS79625KTTR" value="LM2941S" x="112.7" y="-7.3" rot="R90">
<attribute name="DESCRIPTION" value="1-A, 26-V, high-PSRR, adjustable low-dropout voltage regulator with enable from -40C to +125C 5-DDPAK/TO-263 -40 to 125" x="112.7" y="-7.3" size="1.778" layer="27" display="off"/>
</element>
<element name="U27" library="common" package="SK_10100" value="SK 10100" x="127.7" y="-26.9" rot="R540.001262754521"/>
<element name="U28" library="common" package="DPAK508P1524X483-3N" value="D2pak" x="114.1" y="-28.1" rot="R270">
<attribute name="DESCRIPTION" value="N-Channel 100V 17A (Tc) 3.8W (Ta), 79W (Tc) Surface Mount D2PAK" x="114.1" y="-28.1" size="1.778" layer="27" display="off"/>
</element>
<element name="Jumper1" library="common" package="JUMPER6" value="JUMPER6" x="123.9" y="-17.6" rot="R0"/>
<element name="Cap-33" library="common" package="RES_1206_M" value="100K" x="102.6" y="-30.2" rot="R810.001894132198">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="102.6" y="-30.2" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-34" library="common" package="RES_1206_M" value="220R" x="101.7" y="-25.6" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="101.7" y="-25.6" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-35" library="common" package="RES_1206_M" value="47K" x="99.7" y="-13.6" rot="R90">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="99.7" y="-13.6" size="1.778" layer="27" display="off"/>
</element>
<element name="C11" library="common" package="CAPAE530X600L230X70N" value="22uF 25V" x="103.6" y="-20.1" rot="R180">
<attribute name="MANUFACTURER" value="Panasonic" x="103.6" y="-20.1" size="1.778" layer="27" display="off"/>
<attribute name="DATASHEET" value="http://datasheets.diptrace.com/cap/svp.pdf" x="103.6" y="-20.1" size="1.778" layer="27" display="off"/>
<attribute name="PART_NUMBER_(DIGI-KEY)" value="P16435DKR-ND" x="103.6" y="-20.1" size="1.778" layer="27" display="off"/>
<attribute name="UNIQUE_NAME" value="PANASONIC_SVP,SIZE_B6_CAPP" x="103.6" y="-20.1" size="1.778" layer="27" display="off"/>
</element>
<element name="U29" library="common" package="3314G-1-504" value="470K" x="104" y="-12.5" rot="R0"/>
<element name="U30" library="common" package="SOT95P237X111-3N" value="BC847B" x="100.2" y="-7.9" rot="R360">
<attribute name="DESCRIPTION" value="Bipolar (BJT) Transistor NPN 45 V 100 mA 100MHz 300 mW Surface Mount SOT-23-3 (TO-236)" x="100.2" y="-7.9" size="1.778" layer="27" display="off"/>
</element>
<element name="D28" library="common" package="SODFL2512X100N" value="1N4148WS" x="103.1" y="-3.6" rot="R360">
<attribute name="DESCRIPTION" value="Diode Standard 75V 300mA (DC) Surface Mount SOD-323" x="103.1" y="-3.6" size="1.778" layer="27" display="off"/>
</element>
<element name="U31" library="common" package="P355" value="Rel&#233; LED" x="88.2" y="-5" rot="R270"/>
<element name="Cap-37" library="common" package="RES_1206_M" value="1K" x="95" y="-3.4" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="95" y="-3.4" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-38" library="common" package="RES_1206_M" value="1K" x="94.2" y="-9.2" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="94.2" y="-9.2" size="1.778" layer="27" display="off"/>
</element>
<element name="Cap-39" library="common" package="RES_1206_M" value="100K" x="94.2" y="-13.2" rot="R360">
<attribute name="UNIQUE_NAME" value="RES_1206_INCH" x="94.2" y="-13.2" size="1.778" layer="27" display="off"/>
</element>
<element name="U32" library="common" package="P355" value="IR cLED" x="84" y="-5" rot="R270"/>
<element name="U33" library="common" package="P355" value="St LED" x="79.7" y="-5" rot="R270"/>
<element name="U34" library="common" package="P355" value="DCF LED" x="75.4" y="-5" rot="R270"/>
<element name="U35" library="common" package="DIL28/3" value="PIC18F2550" x="63" y="-28.5" rot="R0">
<attribute name="DESCRIPTION" value="PIC PIC&#174; 18F Microcontroller IC 8-Bit 48MHz 32KB (16K x 16) FLASH 28-SPDIP" x="63" y="-28.5" size="1.778" layer="27" display="off"/>
</element>
</elements>
<signals>
<signal name="Net_0">
<contactref element="D26" pad="2"/>
<contactref element="R1-25" pad="1"/>
<wire layer="1" width="0.5" x1="66.3" y1="30.6" x2="66.3" y2="29.9"/>
<wire layer="1" width="0.5" x1="66.3" y1="29.9" x2="67.7" y2="28.5"/>
<wire layer="1" width="0.5" x1="67.7" y1="28.5" x2="67.7" y2="27.62"/>
</signal>
<signal name="Net_1">
<contactref element="D25" pad="2"/>
<contactref element="R1-24" pad="1"/>
<wire layer="1" width="0.5" x1="70.903767" y1="30.6" x2="70.903767" y2="27.62"/>
<wire layer="1" width="0.5" x1="70.903767" y1="27.62" x2="71.603733" y2="27.62"/>
</signal>
<signal name="Net_2">
<contactref element="D24" pad="2"/>
<contactref element="R1-23" pad="1"/>
<wire layer="1" width="0.5" x1="75.5075" y1="30.6" x2="75.5075" y2="26.535"/>
</signal>
<signal name="Net_3">
<contactref element="D23" pad="2"/>
<contactref element="R1-22" pad="1"/>
<wire layer="1" width="0.5" x1="80.111233" y1="30.6" x2="80.111233" y2="26.535"/>
</signal>
<signal name="Net_4">
<contactref element="D22" pad="2"/>
<contactref element="R1-21" pad="1"/>
<wire layer="1" width="0.5" x1="84.715" y1="30.6" x2="84.715" y2="26.535"/>
</signal>
<signal name="Net_5">
<contactref element="D21" pad="2"/>
<contactref element="R1-20" pad="1"/>
<wire layer="1" width="0.5" x1="89.318733" y1="30.6" x2="89.318733" y2="26.535"/>
</signal>
<signal name="Net_6">
<contactref element="D20" pad="2"/>
<contactref element="R1-19" pad="1"/>
<wire layer="1" width="0.5" x1="94.081267" y1="30.6" x2="94.081233" y2="26.535"/>
</signal>
<signal name="Net_7">
<contactref element="D19" pad="2"/>
<contactref element="R1-18" pad="1"/>
<wire layer="1" width="0.5" x1="98.685" y1="30.6" x2="98.685" y2="26.535"/>
</signal>
<signal name="Net_8">
<contactref element="D18" pad="2"/>
<contactref element="R1-17" pad="1"/>
<wire layer="1" width="0.5" x1="103.288733" y1="30.6" x2="103.288733" y2="26.535"/>
</signal>
<signal name="Net_9">
<contactref element="D17" pad="2"/>
<contactref element="R1-16" pad="1"/>
<wire layer="1" width="0.5" x1="107.8925" y1="30.6" x2="107.8925" y2="26.535"/>
</signal>
<signal name="Net_10">
<contactref element="D16" pad="2"/>
<contactref element="R1-15" pad="1"/>
<wire layer="1" width="0.5" x1="112.496267" y1="30.6" x2="112.496267" y2="26.535033"/>
<wire layer="1" width="0.5" x1="112.496267" y1="26.535033" x2="112.496233" y2="26.535"/>
</signal>
<signal name="Net_11">
<contactref element="D15" pad="2"/>
<contactref element="R1-14" pad="1"/>
<wire layer="1" width="0.5" x1="117.1" y1="30.6" x2="117.1" y2="26.535"/>
</signal>
<signal name="Net_12">
<contactref element="D14" pad="2"/>
<contactref element="R1-13" pad="1"/>
<wire layer="1" width="0.5" x1="121.703733" y1="30.6" x2="121.703733" y2="26.535"/>
</signal>
<signal name="Net_13">
<contactref element="D13" pad="2"/>
<contactref element="R1-12" pad="1"/>
<wire layer="1" width="0.5" x1="126.3075" y1="30.6" x2="126.3075" y2="26.535"/>
</signal>
<signal name="Net_14">
<contactref element="D12" pad="2"/>
<contactref element="R1-11" pad="1"/>
<wire layer="1" width="0.5" x1="130.911233" y1="30.6" x2="130.911233" y2="26.535"/>
</signal>
<signal name="Net_15">
<contactref element="D1" pad="2"/>
<contactref element="R1-10" pad="1"/>
<wire layer="1" width="0.5" x1="135.515" y1="30.6" x2="135.515" y2="26.535"/>
</signal>
<signal name="Net_16">
<contactref element="D2" pad="2"/>
<contactref element="R1-9" pad="1"/>
<wire layer="1" width="0.5" x1="140.118733" y1="30.6" x2="140.118733" y2="30.218733"/>
<wire layer="1" width="0.5" x1="140.118733" y1="30.218733" x2="138.9" y2="29"/>
<wire layer="1" width="0.5" x1="138.9" y1="29" x2="138.9" y2="27.5"/>
<wire layer="1" width="0.5" x1="138.9" y1="27.5" x2="139.865" y2="26.535"/>
<wire layer="1" width="0.5" x1="139.865" y1="26.535" x2="140.118733" y2="26.535"/>
</signal>
<signal name="Net_17">
<contactref element="D3" pad="2"/>
<contactref element="R1-8" pad="1"/>
<wire layer="1" width="0.5" x1="144.7225" y1="30.6" x2="144.6" y2="30.6"/>
<wire layer="1" width="0.5" x1="144.6" y1="30.6" x2="143" y2="29"/>
<wire layer="1" width="0.5" x1="143" y1="29" x2="143" y2="27.7"/>
<wire layer="1" width="0.5" x1="143" y1="27.7" x2="144.165" y2="26.535"/>
<wire layer="1" width="0.5" x1="144.165" y1="26.535" x2="144.7225" y2="26.535"/>
</signal>
<signal name="Net_18">
<contactref element="D4" pad="2"/>
<contactref element="R1-7" pad="1"/>
<wire layer="1" width="0.5" x1="149.326233" y1="30.6" x2="149.326233" y2="26.535"/>
</signal>
<signal name="Net_19">
<contactref element="D5" pad="2"/>
<contactref element="R1-6" pad="1"/>
<wire layer="1" width="0.5" x1="153.93" y1="30.6" x2="153.93" y2="26.535"/>
</signal>
<signal name="Net_20">
<contactref element="D6" pad="2"/>
<contactref element="R1-5" pad="1"/>
<wire layer="1" width="0.5" x1="158.533733" y1="30.6" x2="158.533733" y2="26.535"/>
</signal>
<signal name="Net_21">
<contactref element="D7" pad="2"/>
<contactref element="R1-4" pad="1"/>
<wire layer="1" width="0.5" x1="163.1375" y1="30.6" x2="163.1375" y2="26.535"/>
</signal>
<signal name="Net_22">
<contactref element="D8" pad="2"/>
<contactref element="R1-3" pad="1"/>
<wire layer="1" width="0.5" x1="167.741233" y1="30.6" x2="167.741233" y2="26.535"/>
</signal>
<signal name="Net_23">
<contactref element="D9" pad="2"/>
<contactref element="R1-2" pad="1"/>
<wire layer="1" width="0.5" x1="173.9325" y1="30.6" x2="173.9325" y2="27.78"/>
</signal>
<signal name="Net_24">
<contactref element="D10" pad="2"/>
<contactref element="R1-1" pad="1"/>
<wire layer="1" width="0.5" x1="180.123733" y1="30.6" x2="180.123733" y2="27.77"/>
<wire layer="1" width="0.5" x1="180.123733" y1="27.77" x2="179.5" y2="27.77"/>
</signal>
<signal name="Net_25">
<contactref element="D11" pad="2"/>
<contactref element="R1-1206" pad="1"/>
<wire layer="1" width="0.5" x1="186.315" y1="30.6" x2="186.315" y2="29.175"/>
<wire layer="1" width="0.5" x1="186.315" y1="29.175" x2="183.96" y2="26.82"/>
<wire layer="1" width="0.5" x1="183.96" y1="26.82" x2="183.8" y2="26.82"/>
</signal>
<signal name="Net_26">
<contactref element="D11" pad="1"/>
<contactref element="Q11" pad="3"/>
<via x="184.8" y="35.2" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="184.2" y1="32.65" x2="184.2" y2="33.3775"/>
<wire layer="16" width="0.5" x1="184.2" y1="33.3775" x2="184.8" y2="33.9775"/>
<wire layer="16" width="0.5" x1="184.8" y1="33.9775" x2="184.8" y2="35.2"/>
<wire layer="1" width="0.5" x1="184.8" y1="35.2" x2="184.8" y2="33.4"/>
<wire layer="1" width="0.5" x1="184.8" y1="33.4" x2="186.315" y2="33.4"/>
</signal>
<signal name="Net_27">
<contactref element="D10" pad="1"/>
<contactref element="Q10" pad="3"/>
<via x="180.123733" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="177.901233" y1="31.721267" x2="177.901233" y2="33.269967"/>
<wire layer="16" width="0.5" x1="177.901233" y1="33.269967" x2="179.806267" y2="35.175"/>
<wire layer="16" width="0.5" x1="179.806267" y1="35.175" x2="180.123733" y2="35.175"/>
<wire layer="1" width="0.5" x1="180.123733" y1="35.175" x2="180.123733" y2="33.4"/>
</signal>
<signal name="Net_28">
<contactref element="Pad49" pad="1"/>
<contactref element="Pad50" pad="GND"/>
<contactref element="C4" pad="1"/>
<contactref element="C4" pad="2"/>
<contactref element="C6" pad="1"/>
<contactref element="C6" pad="2"/>
<contactref element="C7" pad="2"/>
<contactref element="U17" pad="C"/>
<contactref element="U17" pad="A"/>
<contactref element="C8" pad="2"/>
<contactref element="U18" pad="1@_1"/>
<contactref element="U18" pad="1@_2"/>
<contactref element="U18" pad="1@_3"/>
<contactref element="U18" pad="1@"/>
<contactref element="Cap-28" pad="2"/>
<contactref element="Cap-29" pad="1"/>
<contactref element="Cap-29" pad="2"/>
<contactref element="Cap-30" pad="1"/>
<via x="-38.61" y="3.87" extent="1-16" drill="1" diameter="3" shape="round" alwaysstop="no"/>
<via x="-22.76" y="-27.04" extent="1-16" drill="1" diameter="3" shape="round" alwaysstop="no"/>
<contactref element="U21" pad="2"/>
<contactref element="U21" pad="3"/>
<contactref element="Pad51" pad="1"/>
<contactref element="Cap-31" pad="2"/>
<wire layer="1" width="1" x1="-24.970033" y1="4.32" x2="-24.970033" y2="4.67"/>
<wire layer="1" width="2" x1="-24.970033" y1="4.67" x2="-19.54" y2="4.67"/>
<wire layer="1" width="2" x1="-19.54" y1="4.67" x2="-17.63" y2="2.76"/>
<wire layer="1" width="2" x1="-17.63" y1="2.76" x2="-17.63" y2="2.42"/>
<wire layer="1" width="2" x1="-23.14" y1="-2.62" x2="-22.8" y2="-2.62"/>
<wire layer="1" width="2" x1="-22.8" y1="-2.62" x2="-17.76" y2="2.42"/>
<wire layer="1" width="1" x1="-17.76" y1="2.42" x2="-17.63" y2="2.42"/>
<wire layer="1" width="2" x1="-17.63" y1="2.42" x2="-9.99" y2="-5.22"/>
<wire layer="1" width="2" x1="-9.99" y1="-5.22" x2="-9.99" y2="-8.8"/>
<wire layer="1" width="1" x1="-9.99" y1="-8.8" x2="-11.645" y2="-8.8"/>
<wire layer="1" width="1" x1="-11.645" y1="-8.8" x2="-9.9" y2="-8.8"/>
<wire layer="1" width="2" x1="-9.9" y1="-8.8" x2="-9.9" y2="-15.1"/>
<wire layer="1" width="2" x1="-9.9" y1="-15.1" x2="-10.65" y2="-15.85"/>
<wire layer="1" width="2" x1="-10.65" y1="-15.85" x2="-10.65" y2="-16.42"/>
<wire layer="1" width="2" x1="-10.65" y1="-16.42" x2="-10.65" y2="-21.78"/>
<wire layer="1" width="2" x1="-10.65" y1="-21.78" x2="-13.189967" y2="-24.319967"/>
<wire layer="1" width="2" x1="-13.189967" y1="-24.319967" x2="-15.88" y2="-24.319967"/>
<wire layer="1" width="0.6" x1="-17.02" y1="-16.42" x2="-10.65" y2="-16.42"/>
<wire layer="1" width="1.5" x1="-30.38" y1="3.965" x2="-25.325033" y2="3.965"/>
<wire layer="1" width="1" x1="-25.325033" y1="3.965" x2="-24.970033" y2="4.32"/>
<wire layer="1" width="1" x1="-40.416267" y1="-11.0275" x2="-40.416267" y2="-5.905067"/>
<wire layer="1" width="1" x1="-40.416267" y1="-5.905067" x2="-43.081333" y2="-3.24"/>
<wire layer="1" width="2" x1="-43.081333" y1="-3.24" x2="-46.78" y2="-3.24"/>
<wire layer="1" width="2" x1="-46.78" y1="-3.24" x2="-46.78" y2="2.55"/>
<wire layer="1" width="2" x1="-46.78" y1="2.55" x2="-41.44" y2="7.89"/>
<wire layer="1" width="2" x1="-41.44" y1="7.89" x2="-35.9" y2="7.89"/>
<wire layer="1" width="1.5" x1="-35.9" y1="7.89" x2="-31.975" y2="3.965"/>
<wire layer="1" width="1" x1="-31.975" y1="3.965" x2="-30.38" y2="3.965"/>
<wire layer="1" width="2" x1="-49.605" y1="-8.1" x2="-50.82" y2="-8.1"/>
<wire layer="1" width="2" x1="-50.82" y1="-8.1" x2="-50.82" y2="-4.23"/>
<wire layer="1" width="2" x1="-50.82" y1="-4.23" x2="-49.83" y2="-3.24"/>
<wire layer="1" width="2" x1="-49.83" y1="-3.24" x2="-46.78" y2="-3.24"/>
<wire layer="1" width="2" x1="-49.605" y1="-8.1" x2="-50.876933" y2="-8.1"/>
<wire layer="1" width="2" x1="-50.876933" y1="-8.1" x2="-50.876933" y2="-16.59"/>
<wire layer="1" width="2" x1="-50.876933" y1="-16.59" x2="-49.585" y2="-16.59"/>
<wire layer="1" width="1" x1="-40.416267" y1="-19.2825" x2="-40.416267" y2="-18.676267"/>
<wire layer="1" width="1" x1="-40.416267" y1="-18.676267" x2="-37.76" y2="-16.02"/>
<wire layer="1" width="1" x1="-37.76" y1="-16.02" x2="-37.76" y2="2.44"/>
<wire layer="1" width="1" x1="-37.76" y1="2.44" x2="-38.61" y2="3.29"/>
<wire layer="1" width="1" x1="-38.61" y1="3.29" x2="-38.61" y2="3.87"/>
<wire layer="1" width="1" x1="-35.018733" y1="-19.2825" x2="-35.018733" y2="-17.51"/>
<wire layer="1" width="1" x1="-35.018733" y1="-17.51" x2="-29.01" y2="-17.51"/>
<wire layer="1" width="1" x1="-29.01" y1="-17.51" x2="-26.68" y2="-19.84"/>
<wire layer="1" width="1" x1="-26.68" y1="-19.84" x2="-26.68" y2="-23.22"/>
<wire layer="1" width="1" x1="-26.68" y1="-23.22" x2="-22.86" y2="-27.04"/>
<wire layer="1" width="1" x1="-22.86" y1="-27.04" x2="-22.76" y2="-27.04"/>
<wire layer="1" width="1" x1="-40.416267" y1="-19.2825" x2="-40.416267" y2="-20.566267"/>
<wire layer="1" width="1" x1="-40.416267" y1="-20.566267" x2="-42.41" y2="-22.56"/>
<wire layer="1" width="1" x1="-35.018733" y1="-19.2825" x2="-35.17" y2="-19.433767"/>
<wire layer="1" width="1" x1="-35.17" y1="-19.433767" x2="-35.17" y2="-22.43"/>
<wire layer="1" width="1" x1="-35.17" y1="-22.43" x2="-36.53" y2="-23.79"/>
<wire layer="1" width="1" x1="-35.018733" y1="-11.0275" x2="-35.018733" y2="-3.833733"/>
<wire layer="1" width="1" x1="-35.018733" y1="-3.833733" x2="-34.425" y2="-3.24"/>
<wire layer="1" width="1" x1="-15.585" y1="-14.92" x2="-15.585" y2="-11.45"/>
<wire layer="1" width="1" x1="-15.585" y1="-11.45" x2="-18.235" y2="-8.8"/>
<wire layer="1" width="1" x1="-18.235" y1="-8.8" x2="-18.235" y2="-10.525"/>
<wire layer="1" width="1" x1="-18.235" y1="-10.525" x2="-22.090633" y2="-14.380633"/>
<wire layer="1" width="1" x1="-22.090633" y1="-14.380633" x2="-23.14" y2="-15.43"/>
<wire layer="1" width="1" x1="-23.14" y1="-15.43" x2="-23.14" y2="-19.82"/>
<wire layer="1" width="1" x1="-30.38" y1="1.765" x2="-30.38" y2="1.39"/>
<wire layer="1" width="1" x1="-30.38" y1="1.39" x2="-27" y2="1.39"/>
<wire layer="1" width="1" x1="-27" y1="1.39" x2="-27" y2="1.11"/>
<wire layer="1" width="1" x1="-27" y1="1.11" x2="-26.59" y2="1.11"/>
<wire layer="1" width="1" x1="-26.59" y1="1.11" x2="-25.139967" y2="1.11"/>
<wire layer="1" width="1" x1="-25.139967" y1="1.11" x2="-24.969967" y2="1.28"/>
<wire layer="1" width="1" x1="-26.59" y1="1.11" x2="-26.59" y2="-6.08"/>
<wire layer="1" width="1" x1="-26.59" y1="-6.08" x2="-27" y2="-6.08"/>
<wire layer="1" width="1" x1="-27" y1="-6.08" x2="-27" y2="-7.3"/>
<wire layer="1" width="1" x1="-27" y1="-7.3" x2="-22.090633" y2="-12.209367"/>
<wire layer="1" width="1" x1="-22.090633" y1="-12.209367" x2="-22.090633" y2="-14.380633"/>
<wire layer="1" width="1" x1="-27" y1="-6.08" x2="-31.585" y2="-6.08"/>
<wire layer="1" width="1" x1="-31.585" y1="-6.08" x2="-34.425" y2="-3.24"/>
<wire layer="1" width="1" x1="-41.015" y1="-3.24" x2="-41.015" y2="-3.24"/>
<wire layer="1" width="1" x1="-41.015" y1="-3.24" x2="-43.081333" y2="-3.24"/>
</signal>
<signal name="Net_29">
<contactref element="D9" pad="1"/>
<contactref element="Q9" pad="3"/>
<via x="173.9325" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="171.71" y1="31.721267" x2="171.71" y2="33.27"/>
<wire layer="16" width="0.5" x1="171.71" y1="33.27" x2="173.615" y2="35.175"/>
<wire layer="16" width="0.5" x1="173.615" y1="35.175" x2="173.9325" y2="35.175"/>
<wire layer="1" width="0.5" x1="173.9325" y1="35.175" x2="173.9325" y2="33.4"/>
</signal>
<signal name="Net_30">
<contactref element="D8" pad="1"/>
<contactref element="Q8" pad="3"/>
<via x="167.741233" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="166.3125" y1="31.721267" x2="166.3125" y2="33.746267"/>
<wire layer="16" width="0.5" x1="166.3125" y1="33.746267" x2="167.741233" y2="35.175"/>
<wire layer="1" width="0.5" x1="167.741233" y1="35.175" x2="167.741233" y2="33.4"/>
</signal>
<signal name="Net_31">
<contactref element="D7" pad="1"/>
<contactref element="Q7" pad="3"/>
<via x="163.1375" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="161.708733" y1="31.721267" x2="161.708733" y2="33.746233"/>
<wire layer="16" width="0.5" x1="161.708733" y1="33.746233" x2="163.1375" y2="35.175"/>
<wire layer="1" width="0.5" x1="163.1375" y1="35.175" x2="163.1375" y2="33.4"/>
</signal>
<signal name="Net_32">
<contactref element="D6" pad="1"/>
<contactref element="Q6" pad="3"/>
<via x="158.533733" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="157.105" y1="31.721267" x2="157.105" y2="33.746267"/>
<wire layer="16" width="0.5" x1="157.105" y1="33.746267" x2="158.533733" y2="35.175"/>
<wire layer="1" width="0.5" x1="158.533733" y1="35.175" x2="158.533733" y2="33.4"/>
</signal>
<signal name="Net_33">
<contactref element="D5" pad="1"/>
<contactref element="Q5" pad="3"/>
<via x="153.93" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="152.501233" y1="31.721267" x2="152.501233" y2="33.746267"/>
<wire layer="16" width="0.5" x1="152.501233" y1="33.746267" x2="153.93" y2="35.175"/>
<wire layer="1" width="0.5" x1="153.93" y1="35.175" x2="153.93" y2="33.4"/>
</signal>
<signal name="Net_34">
<contactref element="D4" pad="1"/>
<contactref element="Q4" pad="3"/>
<via x="147.5" y="36.3" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="145.4" y1="31.721267" x2="145.4" y2="34.2"/>
<wire layer="16" width="0.5" x1="145.4" y1="34.2" x2="147.5" y2="36.3"/>
<wire layer="1" width="0.5" x1="147.5" y1="36.3" x2="147.5" y2="36.2"/>
<wire layer="1" width="0.5" x1="147.5" y1="36.2" x2="149.326233" y2="34.373767"/>
<wire layer="1" width="0.5" x1="149.326233" y1="34.373767" x2="149.326233" y2="33.4"/>
</signal>
<signal name="Net_35">
<contactref element="D3" pad="1"/>
<contactref element="Q3" pad="3"/>
<via x="144.7225" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="141.5" y1="31.721267" x2="141.5" y2="31.9525"/>
<wire layer="16" width="0.5" x1="141.5" y1="31.9525" x2="144.7225" y2="35.175"/>
<wire layer="1" width="0.5" x1="144.7225" y1="35.175" x2="144.7225" y2="33.4"/>
</signal>
<signal name="Net_36">
<contactref element="D2" pad="1"/>
<contactref element="Q2" pad="3"/>
<via x="140.118733" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="137.6" y1="31.721267" x2="137.6" y2="32.656267"/>
<wire layer="16" width="0.5" x1="137.6" y1="32.656267" x2="140.118733" y2="35.175"/>
<wire layer="1" width="0.5" x1="140.118733" y1="35.175" x2="140.118733" y2="33.4"/>
</signal>
<signal name="Net_37">
<contactref element="D1" pad="1"/>
<contactref element="Q1" pad="3"/>
<via x="135.515" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="134.086233" y1="33.4675" x2="134.086233" y2="33.746233"/>
<wire layer="16" width="0.5" x1="134.086233" y1="33.746233" x2="135.515" y2="35.175"/>
<wire layer="1" width="0.5" x1="135.515" y1="35.175" x2="135.515" y2="33.4"/>
</signal>
<signal name="Net_38">
<contactref element="D14" pad="1"/>
<contactref element="D13" pad="1"/>
<contactref element="D12" pad="1"/>
<contactref element="Q12" pad="3"/>
<via x="121.703733" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="120.275" y1="33.4675" x2="120.275" y2="33.746267"/>
<wire layer="16" width="0.5" x1="120.275" y1="33.746267" x2="121.703733" y2="35.175"/>
<wire layer="1" width="0.5" x1="121.703733" y1="35.175" x2="121.703733" y2="33.4"/>
<wire layer="1" width="0.5" x1="121.703733" y1="33.4" x2="126.3075" y2="33.4"/>
<wire layer="1" width="0.5" x1="130.911233" y1="33.4" x2="126.3075" y2="33.4"/>
</signal>
<signal name="Net_39">
<contactref element="D17" pad="1"/>
<contactref element="D16" pad="1"/>
<contactref element="D15" pad="1"/>
<contactref element="Q13" pad="3"/>
<via x="107.8925" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="106.463733" y1="33.467533" x2="106.463733" y2="33.746233"/>
<wire layer="16" width="0.5" x1="106.463733" y1="33.746233" x2="107.8925" y2="35.175"/>
<wire layer="1" width="0.5" x1="107.8925" y1="35.175" x2="107.8925" y2="33.4"/>
<wire layer="1" width="0.5" x1="117.1" y1="33.4" x2="112.496267" y2="33.4"/>
<wire layer="1" width="0.5" x1="112.496267" y1="33.4" x2="107.8925" y2="33.4"/>
</signal>
<signal name="Net_40">
<contactref element="D20" pad="1"/>
<contactref element="D19" pad="1"/>
<contactref element="D18" pad="1"/>
<contactref element="Q14" pad="3"/>
<via x="94.081233" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="92.493733" y1="33.4675" x2="92.493733" y2="33.5875"/>
<wire layer="16" width="0.5" x1="92.493733" y1="33.5875" x2="94.081233" y2="35.175"/>
<wire layer="1" width="0.5" x1="94.081233" y1="35.175" x2="94.081267" y2="33.4"/>
<wire layer="1" width="0.5" x1="103.288733" y1="33.4" x2="98.685" y2="33.4"/>
<wire layer="1" width="0.5" x1="98.685" y1="33.4" x2="94.081267" y2="33.4"/>
</signal>
<signal name="Net_41">
<contactref element="D23" pad="1"/>
<contactref element="D22" pad="1"/>
<contactref element="D21" pad="1"/>
<contactref element="Q15" pad="3"/>
<via x="80.111233" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="78.6825" y1="33.4675" x2="78.6825" y2="33.746267"/>
<wire layer="16" width="0.5" x1="78.6825" y1="33.746267" x2="80.111233" y2="35.175"/>
<wire layer="1" width="0.5" x1="80.111233" y1="35.175" x2="80.111233" y2="33.4"/>
<wire layer="1" width="0.5" x1="89.318733" y1="33.4" x2="84.715" y2="33.4"/>
<wire layer="1" width="0.5" x1="84.715" y1="33.4" x2="80.111233" y2="33.4"/>
</signal>
<signal name="Net_42">
<contactref element="D26" pad="1"/>
<contactref element="D25" pad="1"/>
<contactref element="D24" pad="1"/>
<contactref element="Q16" pad="3"/>
<via x="66.3" y="35.175" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="64.9" y1="34.85" x2="65.975" y2="34.85"/>
<wire layer="16" width="0.5" x1="65.975" y1="34.85" x2="66.3" y2="35.175"/>
<wire layer="1" width="0.5" x1="66.3" y1="35.175" x2="66.3" y2="33.4"/>
<wire layer="1" width="0.5" x1="75.5075" y1="33.4" x2="70.903767" y2="33.4"/>
<wire layer="1" width="0.5" x1="70.903767" y1="33.4" x2="66.3" y2="33.4"/>
</signal>
<signal name="Net_43">
<contactref element="R1-1206" pad="2"/>
<contactref element="R1-1" pad="2"/>
<contactref element="R1-2" pad="2"/>
<contactref element="R1-3" pad="2"/>
<contactref element="R1-4" pad="2"/>
<contactref element="R1-5" pad="2"/>
<contactref element="R1-6" pad="2"/>
<contactref element="R1-7" pad="2"/>
<contactref element="R1-8" pad="2"/>
<contactref element="R1-9" pad="2"/>
<contactref element="R1-10" pad="2"/>
<contactref element="R1-11" pad="2"/>
<contactref element="R1-12" pad="2"/>
<contactref element="R1-13" pad="2"/>
<contactref element="R1-14" pad="2"/>
<contactref element="R1-15" pad="2"/>
<contactref element="R1-16" pad="2"/>
<contactref element="R1-17" pad="2"/>
<contactref element="R1-18" pad="2"/>
<contactref element="R1-19" pad="2"/>
<contactref element="R1-20" pad="2"/>
<contactref element="R1-21" pad="2"/>
<contactref element="R1-22" pad="2"/>
<contactref element="R1-23" pad="2"/>
<contactref element="R1-24" pad="2"/>
<contactref element="R1-25" pad="2"/>
<contactref element="R1-32" pad="2"/>
<contactref element="U13" pad="5"/>
<contactref element="U13" pad="6"/>
<contactref element="U13" pad="7"/>
<contactref element="U13" pad="8"/>
<contactref element="Cap-15" pad="2"/>
<wire layer="1" width="0.5" x1="67.7" y1="24.58" x2="68.12" y2="24.58"/>
<wire layer="1" width="0.5" x1="68.12" y1="24.58" x2="68.12" y2="24.58"/>
<wire layer="1" width="0.5" x1="68.12" y1="24.58" x2="71.603733" y2="24.58"/>
<wire layer="1" width="0.5" x1="71.603733" y1="24.58" x2="75.5075" y2="24.58"/>
<wire layer="1" width="0.5" x1="75.5075" y1="24.58" x2="75.5075" y2="23.495"/>
<wire layer="1" width="0.5" x1="75.5075" y1="23.495" x2="80.111233" y2="23.495"/>
<wire layer="1" width="0.5" x1="80.111233" y1="23.495" x2="84.715" y2="23.495"/>
<wire layer="1" width="0.5" x1="84.715" y1="23.495" x2="89.318733" y2="23.495"/>
<wire layer="1" width="0.5" x1="89.318733" y1="23.495" x2="94.081233" y2="23.495"/>
<wire layer="1" width="0.5" x1="94.081233" y1="23.495" x2="98.685" y2="23.495"/>
<wire layer="1" width="0.5" x1="98.685" y1="23.495" x2="103.288733" y2="23.495"/>
<wire layer="1" width="0.5" x1="103.288733" y1="23.495" x2="107.8925" y2="23.495"/>
<wire layer="1" width="0.5" x1="107.8925" y1="23.495" x2="112.496233" y2="23.495"/>
<wire layer="1" width="0.5" x1="112.496233" y1="23.495" x2="117.1" y2="23.495"/>
<wire layer="1" width="0.5" x1="117.1" y1="23.495" x2="121.703733" y2="23.495"/>
<wire layer="1" width="0.5" x1="121.703733" y1="23.495" x2="126.3075" y2="23.495"/>
<wire layer="1" width="0.5" x1="126.3075" y1="23.495" x2="130.911233" y2="23.495"/>
<wire layer="1" width="0.5" x1="130.911233" y1="23.495" x2="135.515" y2="23.495"/>
<wire layer="1" width="0.5" x1="135.515" y1="23.495" x2="140.118733" y2="23.495"/>
<wire layer="1" width="0.5" x1="140.118733" y1="23.495" x2="144.7225" y2="23.495"/>
<wire layer="1" width="0.5" x1="144.7225" y1="23.495" x2="149.326233" y2="23.495"/>
<wire layer="1" width="0.5" x1="149.326233" y1="23.495" x2="153.93" y2="23.495"/>
<wire layer="1" width="0.5" x1="153.93" y1="23.495" x2="158.533733" y2="23.495"/>
<wire layer="1" width="0.5" x1="158.533733" y1="23.495" x2="163.1375" y2="23.495"/>
<wire layer="1" width="0.5" x1="163.1375" y1="23.495" x2="167.741233" y2="23.495"/>
<wire layer="1" width="0.5" x1="167.741233" y1="23.495" x2="167.741233" y2="23.586267"/>
<wire layer="1" width="0.5" x1="167.741233" y1="23.586267" x2="171.726267" y2="23.586267"/>
<wire layer="1" width="0.5" x1="171.726267" y1="23.586267" x2="173.02" y2="24.88"/>
<wire layer="1" width="0.5" x1="173.02" y1="24.88" x2="173.9325" y2="24.88"/>
<wire layer="1" width="0.5" x1="173.9325" y1="24.88" x2="173.9325" y2="24.74"/>
<wire layer="1" width="0.5" x1="173.9325" y1="24.74" x2="173.9325" y2="24.94"/>
<wire layer="1" width="0.5" x1="173.9325" y1="24.94" x2="179.5" y2="24.94"/>
<wire layer="1" width="0.5" x1="179.5" y1="24.94" x2="179.5" y2="24.73"/>
<wire layer="1" width="0.5" x1="179.5" y1="24.73" x2="179.5" y2="24.94"/>
<wire layer="1" width="0.5" x1="179.5" y1="24.94" x2="181" y2="24.94"/>
<wire layer="1" width="0.5" x1="181" y1="24.94" x2="182.353733" y2="23.586267"/>
<wire layer="1" width="0.5" x1="182.353733" y1="23.586267" x2="183.8" y2="23.586267"/>
<wire layer="1" width="0.5" x1="183.8" y1="23.586267" x2="183.8" y2="23.78"/>
<wire layer="1" width="0.5" x1="67.68" y1="39.299967" x2="62.8075" y2="39.299967"/>
<wire layer="1" width="0.5" x1="62.8075" y1="39.299967" x2="62.8075" y2="37.33"/>
<wire layer="1" width="0.5" x1="62.8075" y1="37.33" x2="62.8075" y2="30.7925"/>
<wire layer="1" width="0.5" x1="62.8075" y1="30.7925" x2="65.665" y2="27.935"/>
<wire layer="1" width="0.5" x1="65.665" y1="27.935" x2="65.665" y2="25.535"/>
<wire layer="1" width="0.5" x1="65.665" y1="25.535" x2="66.62" y2="24.58"/>
<wire layer="1" width="0.5" x1="66.62" y1="24.58" x2="67.7" y2="24.58"/>
<wire layer="1" width="0.5" x1="62.65" y1="43.551267" x2="62.65" y2="42.281267"/>
<wire layer="1" width="0.5" x1="62.65" y1="42.281267" x2="62.65" y2="41.011267"/>
<wire layer="1" width="0.5" x1="62.65" y1="41.011267" x2="62.65" y2="39.741267"/>
<wire layer="1" width="0.5" x1="62.65" y1="39.741267" x2="62.65" y2="39.299967"/>
<wire layer="1" width="0.5" x1="62.65" y1="39.299967" x2="67.68" y2="39.299967"/>
<wire layer="1" width="0.5" x1="59.95" y1="37.33" x2="62.8075" y2="37.33"/>
</signal>
<signal name="Net_44">
<contactref element="Q16" pad="1"/>
<contactref element="R1-33" pad="2"/>
<wire layer="16" width="0.5" x1="65.85" y1="32.55" x2="65.85" y2="31.603167"/>
<wire layer="16" width="0.5" x1="65.85" y1="31.603167" x2="66.8819" y2="30.571267"/>
<wire layer="16" width="0.5" x1="66.8819" y1="30.571267" x2="70.836333" y2="30.571267"/>
<wire layer="16" width="0.5" x1="70.836333" y1="30.571267" x2="71.062567" y2="30.7975"/>
</signal>
<signal name="Net_45">
<contactref element="U1" pad="20"/>
<contactref element="U2" pad="1"/>
<contactref element="Cap-3" pad="2"/>
<contactref element="Cap-4" pad="1"/>
<contactref element="U3" pad="2"/>
<contactref element="Cap-5" pad="2"/>
<contactref element="Cap-6" pad="2"/>
<contactref element="Cap-8" pad="2"/>
<contactref element="Cap-11" pad="1"/>
<contactref element="Cap-12" pad="1"/>
<contactref element="Pad2" pad="1"/>
<contactref element="Cap-13" pad="2"/>
<via x="56.1" y="27.5" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<contactref element="Cap-27" pad="2"/>
<via x="-28.7" y="34.3" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="-25.6" y="34.3" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="56.1" y1="27.5" x2="60.83" y2="27.5"/>
<wire layer="16" width="0.5" x1="60.83" y1="27.5" x2="68.83" y2="19.5"/>
<wire layer="16" width="0.5" x1="68.83" y1="19.5" x2="68.83" y2="17.56"/>
<wire layer="16" width="0.5" x1="68.83" y1="17.56" x2="68.07" y2="16.8"/>
<wire layer="16" width="0.5" x1="68.07" y1="16.8" x2="66.3" y2="16.8"/>
<wire layer="16" width="0.5" x1="-28.7" y1="34.3" x2="-25.6" y2="34.3"/>
<wire layer="1" width="0.5" x1="56.84" y1="25.36" x2="56.84" y2="25.42"/>
<wire layer="1" width="0.5" x1="56.84" y1="25.42" x2="56.1" y2="26.16"/>
<wire layer="1" width="0.5" x1="56.1" y1="26.16" x2="56.1" y2="27.5"/>
<wire layer="1" width="0.5" x1="-3.58" y1="20.8" x2="-3.58" y2="18.08"/>
<wire layer="1" width="0.5" x1="-3.58" y1="18.08" x2="17.407433" y2="18.08"/>
<wire layer="1" width="0.5" x1="17.407433" y1="18.08" x2="50.03" y2="18.08"/>
<wire layer="1" width="0.5" x1="50.03" y1="18.08" x2="51.31" y2="16.8"/>
<wire layer="1" width="0.5" x1="51.31" y1="16.8" x2="66.3" y2="16.8"/>
<wire layer="1" width="0.5" x1="-10.605" y1="27.445" x2="-10.605" y2="18.905"/>
<wire layer="1" width="0.5" x1="-10.605" y1="18.905" x2="-9.78" y2="18.08"/>
<wire layer="1" width="0.5" x1="-9.78" y1="18.08" x2="-3.58" y2="18.08"/>
<wire layer="1" width="0.5" x1="-13.68" y1="20.8" x2="-12.5" y2="20.8"/>
<wire layer="1" width="0.5" x1="-12.5" y1="20.8" x2="-10.605" y2="18.905"/>
<wire layer="1" width="0.5" x1="-24.02" y1="35.1" x2="-24.02" y2="27.6"/>
<wire layer="1" width="0.5" x1="-24.02" y1="27.6" x2="-24.02" y2="26.72"/>
<wire layer="1" width="0.5" x1="-24.02" y1="26.72" x2="-22.4" y2="25.1"/>
<wire layer="1" width="0.5" x1="-22.4" y1="25.1" x2="-17.1" y2="25.1"/>
<wire layer="1" width="0.5" x1="-17.1" y1="25.1" x2="-13.68" y2="21.68"/>
<wire layer="1" width="0.5" x1="-13.68" y1="21.68" x2="-13.68" y2="20.8"/>
<wire layer="1" width="0.5" x1="13.9097" y1="25.8001" x2="15.7999" y2="25.8001"/>
<wire layer="1" width="0.5" x1="15.7999" y1="25.8001" x2="17.407433" y2="24.192567"/>
<wire layer="1" width="0.5" x1="17.407433" y1="24.192567" x2="17.407433" y2="18.08"/>
<wire layer="1" width="0.5" x1="-25.6" y1="34.3" x2="-24.02" y2="34.3"/>
<wire layer="1" width="0.5" x1="-24.02" y1="34.3" x2="-24.02" y2="35.1"/>
<wire layer="1" width="0.5" x1="-52.25" y1="34.53" x2="-52.56" y2="34.53"/>
<wire layer="1" width="0.5" x1="-52.56" y1="34.53" x2="-54.13" y2="36.1"/>
<wire layer="1" width="0.5" x1="-54.13" y1="36.1" x2="-54.13" y2="38.3"/>
<wire layer="1" width="0.5" x1="-54.13" y1="38.3" x2="-53.25" y2="39.18"/>
<wire layer="1" width="0.5" x1="-53.25" y1="39.18" x2="-50.418467" y2="39.18"/>
<wire layer="1" width="0.5" x1="-50.418467" y1="39.18" x2="-40.36" y2="39.18"/>
<wire layer="1" width="0.5" x1="-40.36" y1="39.18" x2="-38.78" y2="37.6"/>
<wire layer="1" width="0.5" x1="-38.78" y1="37.6" x2="-39.150533" y2="37.6"/>
<wire layer="1" width="0.5" x1="-39.150533" y1="37.6" x2="-35.2" y2="37.6"/>
<wire layer="1" width="0.5" x1="-35.2" y1="37.6" x2="-31.9543" y2="34.3543"/>
<wire layer="1" width="0.5" x1="-31.9543" y1="34.3543" x2="-31.9543" y2="34.3"/>
<wire layer="1" width="0.5" x1="-31.9543" y1="34.3" x2="-28.7" y2="34.3"/>
<wire layer="1" width="0.5" x1="-47.1" y1="44.32" x2="-48.68" y2="44.32"/>
<wire layer="1" width="0.5" x1="-48.68" y1="44.32" x2="-50.418467" y2="42.581533"/>
<wire layer="1" width="0.5" x1="-50.418467" y1="42.581533" x2="-50.418467" y2="39.18"/>
<wire layer="1" width="0.5" x1="-35.3" y1="42.92" x2="-36.38" y2="42.92"/>
<wire layer="1" width="0.5" x1="-36.38" y1="42.92" x2="-39.150533" y2="40.149467"/>
<wire layer="1" width="0.5" x1="-39.150533" y1="40.149467" x2="-39.150533" y2="37.6"/>
<wire layer="1" width="0.5" x1="-30.8" y1="31.82" x2="-30.8" y2="33.1457"/>
<wire layer="1" width="0.5" x1="-30.8" y1="33.1457" x2="-31.9543" y2="34.3"/>
</signal>
<signal name="Net_46">
<contactref element="Q14" pad="1"/>
<contactref element="R1-34" pad="2"/>
<wire layer="16" width="0.5" x1="93.443733" y1="31.1675" x2="93.961233" y2="31.1675"/>
<wire layer="16" width="0.5" x1="93.961233" y1="31.1675" x2="95.601233" y2="29.5275"/>
<wire layer="16" width="0.5" x1="95.601233" y1="29.5275" x2="97.5738" y2="29.5275"/>
</signal>
<signal name="Net_47">
<contactref element="Q13" pad="1"/>
<contactref element="R1-27" pad="2"/>
<wire layer="16" width="0.5" x1="107.413733" y1="31.167533" x2="107.413733" y2="30.013733"/>
<wire layer="16" width="0.5" x1="107.413733" y1="30.013733" x2="105.6" y2="28.2"/>
<wire layer="16" width="0.5" x1="105.6" y1="28.2" x2="103.505033" y2="28.2"/>
<wire layer="16" width="0.5" x1="103.505033" y1="28.2" x2="102.177533" y2="29.5275"/>
</signal>
<signal name="Net_48">
<contactref element="Q11" pad="2"/>
<contactref element="Q10" pad="2"/>
<contactref element="Q9" pad="2"/>
<contactref element="Q8" pad="2"/>
<contactref element="Q7" pad="2"/>
<contactref element="Q6" pad="2"/>
<contactref element="Q5" pad="2"/>
<contactref element="Q4" pad="2"/>
<contactref element="Q3" pad="2"/>
<contactref element="Q2" pad="2"/>
<contactref element="Q1" pad="2"/>
<contactref element="Q12" pad="2"/>
<contactref element="Q13" pad="2"/>
<contactref element="Q14" pad="2"/>
<contactref element="Q15" pad="2"/>
<contactref element="Q16" pad="2"/>
<via x="165.36" y="28.5075" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<contactref element="R1-32" pad="1"/>
<via x="176.948733" y="28.5075" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="183.3" y="29.3" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="170.7575" y="28.5075" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="160.756233" y="28.5075" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="156.1525" y="28.5075" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="151.548733" y="28.5075" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="144.4" y="28.5" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="140.5" y="28.5" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="137" y="28.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="133.133733" y="30.253767" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="119.3225" y="30.253767" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="105.511233" y="30.253767" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="91.541233" y="30.253767" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="77.73" y="30.253767" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="64" y="31.4" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<contactref element="C3" pad="2"/>
<contactref element="U1" pad="8"/>
<contactref element="U1" pad="19"/>
<contactref element="Pad1" pad="GND"/>
<contactref element="Cap-1" pad="2"/>
<contactref element="Cap-2" pad="1"/>
<contactref element="U2" pad="2"/>
<contactref element="Cap-3" pad="1"/>
<contactref element="U3" pad="3"/>
<contactref element="U4" pad="GND"/>
<contactref element="U5" pad="2"/>
<contactref element="Cap-7" pad="2"/>
<contactref element="C9" pad="2"/>
<contactref element="U14" pad="4"/>
<via x="39.9" y="31.43" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<contactref element="Cap-14" pad="1"/>
<contactref element="Cap-16" pad="1"/>
<via x="60.426233" y="31.841267" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<contactref element="Cap-18" pad="2"/>
<contactref element="Cap-20" pad="2"/>
<contactref element="Q17" pad="2"/>
<contactref element="Cap-21" pad="2"/>
<contactref element="Cap-22" pad="1"/>
<contactref element="Cap-25" pad="1"/>
<via x="36.23" y="32" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="53.28" y="30.57" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="57.21" y="30.61" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<contactref element="C10" pad="2"/>
<via x="-17.8" y="23.4" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="-11.9" y="23.4" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5121" x1="63.95" y1="32.55" x2="63.95" y2="31.45"/>
<wire layer="16" width="0.5121" x1="63.95" y1="31.45" x2="64" y2="31.4"/>
<wire layer="16" width="0.5" x1="60.426233" y1="31.841267" x2="63.558733" y2="31.841267"/>
<wire layer="16" width="0.5" x1="63.558733" y1="31.841267" x2="64" y2="31.4"/>
<wire layer="16" width="0.5" x1="36.23" y1="32" x2="36.23" y2="32.13"/>
<wire layer="16" width="0.5" x1="36.23" y1="32.13" x2="37.2" y2="33.1"/>
<wire layer="16" width="0.5" x1="37.2" y1="33.1" x2="39.9" y2="33.1"/>
<wire layer="16" width="0.5" x1="39.9" y1="33.1" x2="44.75" y2="33.1"/>
<wire layer="16" width="0.5" x1="44.75" y1="33.1" x2="47.15" y2="30.7"/>
<wire layer="16" width="0.5" x1="47.15" y1="30.7" x2="53.28" y2="30.7"/>
<wire layer="16" width="0.5" x1="53.28" y1="30.7" x2="53.28" y2="30.61"/>
<wire layer="16" width="0.5" x1="53.28" y1="30.61" x2="57.25" y2="30.61"/>
<wire layer="16" width="0.5" x1="57.25" y1="30.61" x2="59.194967" y2="30.61"/>
<wire layer="16" width="0.5" x1="59.194967" y1="30.61" x2="60.426233" y2="31.841267"/>
<wire layer="16" width="0.5" x1="53.28" y1="30.57" x2="53.28" y2="30.61"/>
<wire layer="16" width="0.5" x1="57.21" y1="30.61" x2="57.25" y2="30.61"/>
<wire layer="16" width="0.5" x1="39.9" y1="31.43" x2="39.9" y2="33.1"/>
<wire layer="16" width="0.5" x1="77.7325" y1="31.1675" x2="77.7325" y2="30.256267"/>
<wire layer="16" width="0.5" x1="77.7325" y1="30.256267" x2="77.73" y2="30.253767"/>
<wire layer="16" width="0.5" x1="91.543733" y1="31.1675" x2="91.543733" y2="30.256267"/>
<wire layer="16" width="0.5" x1="91.543733" y1="30.256267" x2="91.541233" y2="30.253767"/>
<wire layer="16" width="0.5" x1="105.513733" y1="31.167533" x2="105.513733" y2="30.256267"/>
<wire layer="16" width="0.5" x1="105.513733" y1="30.256267" x2="105.511233" y2="30.253767"/>
<wire layer="16" width="0.5" x1="119.325" y1="31.1675" x2="119.325" y2="30.256267"/>
<wire layer="16" width="0.5" x1="119.325" y1="30.256267" x2="119.3225" y2="30.253767"/>
<wire layer="16" width="0.5" x1="133.136233" y1="31.1675" x2="133.136233" y2="30.256267"/>
<wire layer="16" width="0.5" x1="133.136233" y1="30.256267" x2="133.133733" y2="30.253767"/>
<wire layer="16" width="0.5" x1="136.65" y1="29.421267" x2="136.65" y2="29.05"/>
<wire layer="16" width="0.5" x1="136.65" y1="29.05" x2="137" y2="28.7"/>
<wire layer="16" width="0.5" x1="140.55" y1="29.421267" x2="140.55" y2="28.55"/>
<wire layer="16" width="0.5" x1="140.55" y1="28.55" x2="140.5" y2="28.5"/>
<wire layer="16" width="0.5" x1="144.45" y1="29.421267" x2="144.45" y2="28.55"/>
<wire layer="16" width="0.5" x1="144.45" y1="28.55" x2="144.4" y2="28.5"/>
<wire layer="16" width="0.5" x1="151.551233" y1="29.421267" x2="151.551233" y2="28.51"/>
<wire layer="16" width="0.5" x1="151.551233" y1="28.51" x2="151.548733" y2="28.5075"/>
<wire layer="16" width="0.5" x1="156.155" y1="29.421267" x2="156.155" y2="28.51"/>
<wire layer="16" width="0.5" x1="156.155" y1="28.51" x2="156.1525" y2="28.5075"/>
<wire layer="16" width="0.5" x1="160.758733" y1="29.421267" x2="160.758733" y2="28.51"/>
<wire layer="16" width="0.5" x1="160.758733" y1="28.51" x2="160.756233" y2="28.5075"/>
<wire layer="16" width="0.5" x1="165.3625" y1="29.421267" x2="165.3625" y2="28.51"/>
<wire layer="16" width="0.5" x1="165.3625" y1="28.51" x2="165.36" y2="28.5075"/>
<wire layer="16" width="0.5" x1="170.76" y1="29.421267" x2="170.76" y2="28.51"/>
<wire layer="16" width="0.5" x1="170.76" y1="28.51" x2="170.7575" y2="28.5075"/>
<wire layer="16" width="0.5" x1="176.951233" y1="29.421267" x2="176.951233" y2="28.51"/>
<wire layer="16" width="0.5" x1="176.951233" y1="28.51" x2="176.948733" y2="28.5075"/>
<wire layer="16" width="0.5" x1="183.25" y1="30.35" x2="183.25" y2="29.35"/>
<wire layer="16" width="0.5" x1="183.25" y1="29.35" x2="183.3" y2="29.3"/>
<wire layer="16" width="0.5" x1="-17.8" y1="23.4" x2="-11.9" y2="23.4"/>
<wire layer="16" width="0.5" x1="-11.9" y1="23.4" x2="-11.9" y2="23.4"/>
<wire layer="1" width="0.5" x1="-40.138333" y1="42.5" x2="-40" y2="42.5"/>
<wire layer="1" width="1" x1="-40" y1="42.5" x2="-36.81" y2="45.69"/>
<wire layer="1" width="1" x1="-36.81" y1="45.69" x2="-30.4" y2="45.69"/>
<wire layer="1" width="1" x1="-30.4" y1="45.69" x2="-27.2" y2="45.69"/>
<wire layer="1" width="1" x1="-27.2" y1="45.69" x2="-19.12" y2="45.69"/>
<wire layer="1" width="1" x1="-19.12" y1="45.69" x2="-1.68" y2="45.69"/>
<wire layer="1" width="1" x1="-1.68" y1="45.69" x2="6.7" y2="45.69"/>
<wire layer="1" width="1" x1="6.7" y1="45.69" x2="49.52" y2="45.69"/>
<wire layer="1" width="1" x1="49.52" y1="45.69" x2="51.03" y2="47.2"/>
<wire layer="1" width="1" x1="51.03" y1="47.2" x2="66.3" y2="47.2"/>
<wire layer="1" width="0.5" x1="-1.68" y1="42.9" x2="-1.68" y2="45.69"/>
<wire layer="1" width="0.5121" x1="66.3" y1="47.2" x2="73" y2="47.2"/>
<wire layer="1" width="0.5121" x1="73" y1="47.2" x2="75.12" y2="45.08"/>
<wire layer="1" width="0.5121" x1="75.12" y1="45.08" x2="75.12" y2="43.5"/>
<wire layer="1" width="0.5121" x1="70.72" y1="39.300033" x2="75.12" y2="39.300033"/>
<wire layer="1" width="0.5121" x1="75.12" y1="39.300033" x2="75.12" y2="43.5"/>
<wire layer="1" width="0.5121" x1="64" y1="31.4" x2="64" y2="35.213667"/>
<wire layer="1" width="0.5121" x1="64" y1="35.213667" x2="65.586333" y2="36.8"/>
<wire layer="1" width="0.5121" x1="65.586333" y1="36.8" x2="69.7" y2="36.8"/>
<wire layer="1" width="0.5121" x1="69.7" y1="36.8" x2="70.72" y2="37.82"/>
<wire layer="1" width="0.5121" x1="70.72" y1="37.82" x2="70.72" y2="39.300033"/>
<wire layer="1" width="0.5121" x1="70.72" y1="39.300033" x2="75.899967" y2="39.300033"/>
<wire layer="1" width="0.5121" x1="75.899967" y1="39.300033" x2="77.299967" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="77.299967" y1="37.900033" x2="77.73" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="77.73" y1="37.900033" x2="91.541233" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="91.541233" y1="37.900033" x2="105.511233" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="105.511233" y1="37.900033" x2="119.3225" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="119.3225" y1="37.900033" x2="133.133733" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="133.133733" y1="37.900033" x2="137.8" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="137.8" y1="37.900033" x2="142.3" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="142.3" y1="37.900033" x2="146.1" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="146.1" y1="37.900033" x2="151.548733" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="151.548733" y1="37.900033" x2="156.1525" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="156.1525" y1="37.900033" x2="160.756233" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="160.756233" y1="37.900033" x2="165.36" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="165.36" y1="37.900033" x2="165.36" y2="40.7"/>
<wire layer="1" width="0.5121" x1="165.36" y1="40.7" x2="173.3" y2="40.7"/>
<wire layer="1" width="0.5121" x1="173.3" y1="40.7" x2="176.8" y2="40.7"/>
<wire layer="1" width="0.5121" x1="176.8" y1="40.7" x2="179.6262" y2="37.8738"/>
<wire layer="1" width="0.5121" x1="179.6262" y1="37.8738" x2="181.9562" y2="37.8738"/>
<wire layer="1" width="0.5121" x1="181.9562" y1="37.8738" x2="183.3" y2="36.53"/>
<wire layer="1" width="0.5121" x1="183.3" y1="36.53" x2="183.3" y2="29.3"/>
<wire layer="1" width="0.5121" x1="176.948733" y1="28.5075" x2="176.948733" y2="29.542567"/>
<wire layer="1" width="0.5121" x1="176.948733" y1="29.542567" x2="177" y2="29.593833"/>
<wire layer="1" width="0.5121" x1="177" y1="29.593833" x2="177" y2="34.3"/>
<wire layer="1" width="0.5121" x1="177" y1="34.3" x2="179.6262" y2="36.9262"/>
<wire layer="1" width="0.5121" x1="179.6262" y1="36.9262" x2="179.6262" y2="37.8738"/>
<wire layer="1" width="0.5121" x1="170.7575" y1="28.5075" x2="170.7575" y2="34.1575"/>
<wire layer="1" width="0.5121" x1="170.7575" y1="34.1575" x2="173.3" y2="36.7"/>
<wire layer="1" width="0.5121" x1="173.3" y1="36.7" x2="173.3" y2="40.7"/>
<wire layer="1" width="0.5121" x1="165.36" y1="28.5075" x2="165.36" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="160.756233" y1="28.5075" x2="160.756233" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="156.1525" y1="28.5075" x2="156.1525" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="151.548733" y1="28.5075" x2="151.548733" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="144.4" y1="28.5" x2="145.9" y2="28.5"/>
<wire layer="1" width="0.5121" x1="145.9" y1="28.5" x2="146.9" y2="29.5"/>
<wire layer="1" width="0.5121" x1="146.9" y1="29.5" x2="146.9" y2="34.5"/>
<wire layer="1" width="0.5121" x1="146.9" y1="34.5" x2="146.1" y2="35.3"/>
<wire layer="1" width="0.5121" x1="146.1" y1="35.3" x2="146.1" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="140.5" y1="28.5" x2="141.1" y2="28.5"/>
<wire layer="1" width="0.5121" x1="141.1" y1="28.5" x2="142.3" y2="29.7"/>
<wire layer="1" width="0.5121" x1="142.3" y1="29.7" x2="142.3" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="137" y1="28.7" x2="137" y2="28.8"/>
<wire layer="1" width="0.5121" x1="137" y1="28.8" x2="137.8" y2="29.6"/>
<wire layer="1" width="0.5121" x1="137.8" y1="29.6" x2="137.8" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="133.133733" y1="30.253767" x2="133.133733" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="119.3225" y1="30.253767" x2="119.3225" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="105.511233" y1="30.253767" x2="105.511233" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="91.541233" y1="30.253767" x2="91.541233" y2="37.900033"/>
<wire layer="1" width="0.5121" x1="77.73" y1="30.253767" x2="77.73" y2="37.900033"/>
<wire layer="1" width="0.5" x1="60.426233" y1="31.841267" x2="60.426233" y2="28.823767"/>
<wire layer="1" width="0.5" x1="60.426233" y1="28.823767" x2="60.789467" y2="28.460533"/>
<wire layer="1" width="0.5" x1="60.789467" y1="28.460533" x2="60.789467" y2="27.5437"/>
<wire layer="1" width="0.5" x1="53.28" y1="30.57" x2="53.28" y2="29.530033"/>
<wire layer="1" width="0.5" x1="53.28" y1="29.530033" x2="53.282533" y2="29.5275"/>
<wire layer="1" width="0.5" x1="57.21" y1="30.61" x2="57.21" y2="29.568767"/>
<wire layer="1" width="0.5" x1="57.21" y1="29.568767" x2="57.251267" y2="29.5275"/>
<wire layer="1" width="0.5" x1="34.275" y1="31.94" x2="36.17" y2="31.94"/>
<wire layer="1" width="0.5" x1="36.17" y1="31.94" x2="36.23" y2="32"/>
<wire layer="1" width="0.5" x1="25.535" y1="32" x2="25.535" y2="34.205767"/>
<wire layer="1" width="0.5" x1="25.535" y1="34.205767" x2="25.535" y2="36.495"/>
<wire layer="1" width="0.5" x1="25.535" y1="36.495" x2="25.33" y2="36.7"/>
<wire layer="1" width="0.5" x1="25.535" y1="34.205767" x2="29.000033" y2="34.205767"/>
<wire layer="1" width="0.5" x1="29.000033" y1="34.205767" x2="32.009233" y2="34.205767"/>
<wire layer="1" width="0.5" x1="32.009233" y1="34.205767" x2="34.275" y2="31.94"/>
<wire layer="1" width="0.5" x1="39.9" y1="31.43" x2="39.9" y2="29.52"/>
<wire layer="1" width="0.5" x1="39.9" y1="29.52" x2="39.885" y2="29.505"/>
<wire layer="1" width="0.5" x1="29.000033" y1="38.38" x2="29.000033" y2="34.205767"/>
<wire layer="1" width="0.5" x1="29.000033" y1="38.38" x2="34.500033" y2="38.38"/>
<wire layer="1" width="0.5" x1="34.500033" y1="38.38" x2="34.500033" y2="38.38"/>
<wire layer="1" width="0.5" x1="57.251267" y1="29.5275" x2="56.9" y2="29.5275"/>
<wire layer="1" width="0.5" x1="56.9" y1="29.5275" x2="56.9" y2="28.7"/>
<wire layer="1" width="0.5" x1="56.9" y1="28.7" x2="58.4" y2="27.2"/>
<wire layer="1" width="0.5" x1="58.4" y1="27.2" x2="58.4" y2="24.833167"/>
<wire layer="1" width="0.5" x1="58.4" y1="24.833167" x2="56.866833" y2="23.3"/>
<wire layer="1" width="0.5" x1="56.866833" y1="23.3" x2="51.550033" y2="23.3"/>
<wire layer="1" width="0.5" x1="51.550033" y1="23.3" x2="51.550033" y2="22.910033"/>
<wire layer="1" width="0.5" x1="-27.2" y1="45.69" x2="-27.2" y2="25.1"/>
<wire layer="1" width="0.5" x1="-27.2" y1="25.1" x2="-23.6" y2="21.5"/>
<wire layer="1" width="0.5" x1="-23.6" y1="21.5" x2="-17.8" y2="21.5"/>
<wire layer="1" width="0.5" x1="-17.8" y1="21.5" x2="-17.42" y2="21.5"/>
<wire layer="1" width="0.5" x1="-17.42" y1="21.5" x2="-16.72" y2="20.8"/>
<wire layer="1" width="0.5" x1="13.918233" y1="24.530133" x2="7.769867" y2="24.530133"/>
<wire layer="1" width="0.5" x1="7.769867" y1="24.530133" x2="6.7" y2="25.6"/>
<wire layer="1" width="0.5" x1="6.7" y1="25.6" x2="6.7" y2="45.69"/>
<wire layer="1" width="0.5" x1="-9.335" y1="36.555" x2="-9.335" y2="38.565"/>
<wire layer="1" width="0.5" x1="-9.335" y1="38.565" x2="-8.1" y2="39.8"/>
<wire layer="1" width="0.5" x1="-8.1" y1="39.8" x2="-3.9" y2="39.8"/>
<wire layer="1" width="0.5" x1="-3.9" y1="39.8" x2="-1.68" y2="42.02"/>
<wire layer="1" width="0.5" x1="-1.68" y1="42.02" x2="-1.68" y2="42.9"/>
<wire layer="1" width="0.5" x1="-52.25" y1="31.99" x2="-52.51" y2="31.99"/>
<wire layer="1" width="0.5" x1="-52.51" y1="31.99" x2="-54.1" y2="30.4"/>
<wire layer="1" width="0.5" x1="-54.1" y1="30.4" x2="-54.1" y2="26"/>
<wire layer="1" width="0.5" x1="-54.1" y1="26" x2="-47.3" y2="19.2"/>
<wire layer="1" width="0.5" x1="-47.3" y1="19.2" x2="-46.5" y2="19.2"/>
<wire layer="1" width="0.5" x1="-46.5" y1="19.2" x2="-26.1" y2="19.2"/>
<wire layer="1" width="0.5" x1="-26.1" y1="19.2" x2="-23.8" y2="21.5"/>
<wire layer="1" width="0.5" x1="-23.8" y1="21.5" x2="-23.6" y2="21.5"/>
<wire layer="1" width="0.5" x1="-11.875" y1="27.445" x2="-11.875" y2="23.425"/>
<wire layer="1" width="0.5" x1="-11.875" y1="23.425" x2="-11.9" y2="23.4"/>
<wire layer="1" width="0.5" x1="-17.8" y1="23.4" x2="-17.8" y2="21.5"/>
<wire layer="1" width="0.5" x1="-19.12" y1="42.9" x2="-19.12" y2="45.69"/>
<wire layer="1" width="0.5" x1="-30.4" y1="42.82" x2="-30.4" y2="45.69"/>
<wire layer="1" width="0.5" x1="-43.0329" y1="24.0126" x2="-45.439333" y2="24.0126"/>
<wire layer="1" width="0.5" x1="-45.439333" y1="24.0126" x2="-46.5" y2="22.951933"/>
<wire layer="1" width="0.5" x1="-46.5" y1="22.951933" x2="-46.5" y2="19.2"/>
<wire layer="1" width="0.5" x1="-41.935" y1="32" x2="-41.935" y2="29.835"/>
<wire layer="1" width="0.5" x1="-41.935" y1="29.835" x2="-40" y2="27.9"/>
<wire layer="1" width="0.5" x1="-40" y1="27.9" x2="-40" y2="24.6"/>
<wire layer="1" width="0.5" x1="-40" y1="24.6" x2="-40.5874" y2="24.0126"/>
<wire layer="1" width="0.5" x1="-40.5874" y1="24.0126" x2="-43.0329" y2="24.0126"/>
</signal>
<signal name="Net_49">
<contactref element="U1" pad="10"/>
<contactref element="Cap-2" pad="2"/>
<contactref element="U9" pad="1"/>
<wire layer="1" width="0.5" x1="-11.833233" y1="43.3675" x2="-15.6125" y2="43.3675"/>
<wire layer="1" width="0.5" x1="-15.6125" y1="43.3675" x2="-16.08" y2="42.9"/>
<wire layer="1" width="0.5" x1="-11.875" y1="36.555" x2="-11.875" y2="38.401267"/>
<wire layer="1" width="0.5" x1="-11.875" y1="38.401267" x2="-16.08" y2="42.606267"/>
<wire layer="1" width="0.5" x1="-16.08" y1="42.606267" x2="-16.08" y2="42.9"/>
</signal>
<signal name="Net_50">
<contactref element="Q12" pad="1"/>
<contactref element="R1-35" pad="2"/>
<wire layer="16" width="0.5" x1="121.225" y1="31.1675" x2="121.901233" y2="31.1675"/>
<wire layer="16" width="0.5" x1="121.901233" y1="31.1675" x2="122.113733" y2="31.38"/>
<wire layer="16" width="0.5" x1="122.113733" y1="31.38" x2="125.400067" y2="31.38"/>
</signal>
<signal name="Net_51">
<contactref element="Q1" pad="1"/>
<contactref element="R1-36" pad="2"/>
<wire layer="16" width="0.5" x1="135.036233" y1="31.1675" x2="135.036233" y2="28.986233"/>
<wire layer="16" width="0.5" x1="135.036233" y1="28.986233" x2="134.5575" y2="28.5075"/>
<wire layer="16" width="0.5" x1="134.5575" y1="28.5075" x2="132.872533" y2="28.5075"/>
<wire layer="16" width="0.5" x1="132.872533" y1="28.5075" x2="130.000033" y2="31.38"/>
</signal>
<signal name="Net_52">
<contactref element="U1" pad="9"/>
<contactref element="Cap-1" pad="1"/>
<contactref element="U9" pad="3"/>
<wire layer="1" width="0.5" x1="-9.178233" y1="41.1725" x2="-9.178233" y2="40.569033"/>
<wire layer="1" width="0.5" x1="-9.178233" y1="40.569033" x2="-10.605" y2="39.142267"/>
<wire layer="1" width="0.5" x1="-10.605" y1="39.142267" x2="-10.605" y2="36.555"/>
<wire layer="1" width="0.5" x1="-9.178233" y1="41.1725" x2="-6.4475" y2="41.1725"/>
<wire layer="1" width="0.5" x1="-6.4475" y1="41.1725" x2="-4.72" y2="42.9"/>
</signal>
<signal name="Net_53">
<contactref element="U4" pad="OUT"/>
<contactref element="C1" pad="1"/>
<wire layer="1" width="0.5" x1="-43.0329" y1="26.5126" x2="-43.0329" y2="26.7629"/>
<wire layer="1" width="0.5" x1="-43.0329" y1="26.7629" x2="-47" y2="30.73"/>
</signal>
<signal name="Net_54">
<contactref element="C1" pad="2"/>
<contactref element="Cap-5" pad="1"/>
<contactref element="U8" pad="A"/>
<wire layer="1" width="0.5" x1="-47" y1="33.27" x2="-47" y2="35.27"/>
<wire layer="1" width="0.5" x1="-47" y1="35.27" x2="-44.67" y2="37.6"/>
<wire layer="1" width="0.5" x1="-44.67" y1="37.6" x2="-41.82" y2="37.6"/>
<wire layer="1" width="0.5" x1="-41.82" y1="37.6" x2="-45.9" y2="37.6"/>
<wire layer="1" width="0.5" x1="-45.9" y1="37.6" x2="-45.9" y2="37.7"/>
<wire layer="1" width="0.46" x1="-45.9" y1="37.7" x2="-45.61" y2="37.7"/>
</signal>
<signal name="Net_55">
<contactref element="U1" pad="1"/>
<contactref element="U3" pad="1"/>
<contactref element="U8" pad="C"/>
<via x="-17.8" y="34.3" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-52.25" y1="37.07" x2="-20.57" y2="37.07"/>
<wire layer="16" width="0.5" x1="-20.57" y1="37.07" x2="-17.8" y2="34.3"/>
<wire layer="1" width="0.46" x1="-47.99" y1="37.7" x2="-51.81" y2="37.7"/>
<wire layer="1" width="0.5" x1="-51.81" y1="37.7" x2="-51.81" y2="36.87"/>
<wire layer="1" width="0.5" x1="-51.81" y1="36.87" x2="-52.05" y2="36.87"/>
<wire layer="1" width="0.5" x1="-52.05" y1="36.87" x2="-52.25" y2="37.07"/>
<wire layer="1" width="0.5" x1="-0.445" y1="36.555" x2="-0.445" y2="34.455"/>
<wire layer="1" width="0.5" x1="-0.445" y1="34.455" x2="-2.6" y2="32.3"/>
<wire layer="1" width="0.5" x1="-2.6" y1="32.3" x2="-16" y2="32.3"/>
<wire layer="1" width="0.5" x1="-16" y1="32.3" x2="-17.8" y2="34.1"/>
<wire layer="1" width="0.5" x1="-17.8" y1="34.1" x2="-17.8" y2="34.3"/>
</signal>
<signal name="Net_56">
<contactref element="Q2" pad="1"/>
<contactref element="R1-30" pad="1"/>
<wire layer="16" width="0.5" x1="138.55" y1="29.421267" x2="138.55" y2="27.9106"/>
<wire layer="16" width="0.5" x1="138.55" y1="27.9106" x2="137.9394" y2="27.3"/>
<wire layer="16" width="0.5" x1="137.9394" y1="27.3" x2="120.3" y2="27.3"/>
<wire layer="16" width="0.5" x1="120.3" y1="27.3" x2="117.7" y2="29.9"/>
<wire layer="16" width="0.5" x1="117.7" y1="29.9" x2="117.7" y2="33.6"/>
<wire layer="16" width="0.5" x1="117.7" y1="33.6" x2="116.5" y2="34.8"/>
<wire layer="16" width="0.5" x1="116.5" y1="34.8" x2="114.82" y2="34.8"/>
</signal>
<signal name="Net_57">
<contactref element="Q3" pad="1"/>
<contactref element="R1-29" pad="1"/>
<wire layer="16" width="0.5" x1="142.45" y1="29.421267" x2="142.45" y2="28.9894"/>
<wire layer="16" width="0.5" x1="142.45" y1="28.9894" x2="142.5" y2="28.9394"/>
<wire layer="16" width="0.5" x1="142.5" y1="28.9394" x2="142.5" y2="28.6"/>
<wire layer="16" width="0.5" x1="142.5" y1="28.6" x2="140.1" y2="26.2"/>
<wire layer="16" width="0.5" x1="140.1" y1="26.2" x2="119.7" y2="26.2"/>
<wire layer="16" width="0.5" x1="119.7" y1="26.2" x2="116.5" y2="29.4"/>
<wire layer="16" width="0.5" x1="116.5" y1="29.4" x2="116.5" y2="30.3"/>
<wire layer="16" width="0.5" x1="116.5" y1="30.3" x2="115.2" y2="31.6"/>
<wire layer="16" width="0.5" x1="115.2" y1="31.6" x2="114.82" y2="31.6"/>
</signal>
<signal name="Net_58">
<contactref element="U14" pad="3"/>
<contactref element="Cap-14" pad="2"/>
<contactref element="Cap-15" pad="1"/>
<wire layer="1" width="0.5" x1="59.95" y1="34.29" x2="58.89" y2="34.29"/>
<wire layer="1" width="0.5" x1="58.89" y1="34.29" x2="57.2512" y2="32.6512"/>
<wire layer="1" width="0.5" x1="57.2512" y1="32.6512" x2="57.2512" y2="32.5675"/>
<wire layer="1" width="0.5" x1="57.2512" y1="32.5675" x2="56.4069" y2="32.5675"/>
<wire layer="1" width="0.5" x1="56.4069" y1="32.5675" x2="55.346233" y2="31.506833"/>
<wire layer="1" width="0.5" x1="55.346233" y1="31.506833" x2="55.346233" y2="28.746233"/>
<wire layer="1" width="0.5" x1="55.346233" y1="28.746233" x2="54.32" y2="27.72"/>
<wire layer="1" width="0.5" x1="54.32" y1="27.72" x2="52.18" y2="27.72"/>
<wire layer="1" width="0.5" x1="52.18" y1="27.72" x2="50.52" y2="29.38"/>
<wire layer="1" width="0.5" x1="50.52" y1="29.38" x2="50.52" y2="32.88"/>
<wire layer="1" width="0.5" x1="50.52" y1="32.88" x2="49.5" y2="33.9"/>
<wire layer="1" width="0.5" x1="49.5" y1="33.9" x2="44.1" y2="33.9"/>
<wire layer="1" width="0.5" x1="44.1" y1="33.9" x2="41.155" y2="30.955"/>
<wire layer="1" width="0.5" x1="41.155" y1="30.955" x2="41.155" y2="29.505"/>
</signal>
<signal name="Net_59">
<contactref element="U14" pad="6"/>
<contactref element="Cap-22" pad="2"/>
<contactref element="Cap-25" pad="2"/>
<contactref element="Cap-26" pad="1"/>
<wire layer="1" width="0.5" x1="23.38" y1="26.8" x2="21.6" y2="26.8"/>
<wire layer="1" width="0.5" x1="21.6" y1="26.8" x2="19.9" y2="25.1"/>
<wire layer="1" width="0.5" x1="19.9" y1="25.1" x2="19.9" y2="21.9"/>
<wire layer="1" width="0.5" x1="19.9" y1="21.9" x2="21.92" y2="19.88"/>
<wire layer="1" width="0.5" x1="21.92" y1="19.88" x2="38.25" y2="19.88"/>
<wire layer="1" width="0.5" x1="38.25" y1="19.88" x2="41.155" y2="22.785"/>
<wire layer="1" width="0.5" x1="41.155" y1="22.785" x2="41.155" y2="24.555"/>
<wire layer="1" width="0.5" x1="19.9" y1="25.1" x2="19.9" y2="25.5"/>
<wire layer="1" width="0.5" x1="19.9" y1="25.5" x2="19.2" y2="26.2"/>
<wire layer="1" width="0.5" x1="19.2" y1="26.2" x2="19.2" y2="37.75"/>
<wire layer="1" width="0.5" x1="19.2" y1="37.75" x2="22.87" y2="41.42"/>
<wire layer="1" width="0.5" x1="22.87" y1="41.42" x2="28.999967" y2="41.42"/>
<wire layer="1" width="0.5" x1="28.999967" y1="41.42" x2="34.499967" y2="41.42"/>
<wire layer="1" width="0.5" x1="34.499967" y1="41.42" x2="34.499967" y2="41.42"/>
</signal>
<signal name="Net_60">
<contactref element="Q4" pad="1"/>
<contactref element="R1-37" pad="2"/>
<wire layer="16" width="0.5" x1="146.35" y1="29.421267" x2="146.35" y2="28.55"/>
<wire layer="16" width="0.5" x1="146.35" y1="28.55" x2="142.9" y2="25.1"/>
<wire layer="16" width="0.5" x1="142.9" y1="25.1" x2="119.2" y2="25.1"/>
<wire layer="16" width="0.5" x1="119.2" y1="25.1" x2="116.699933" y2="27.600067"/>
<wire layer="16" width="0.5" x1="116.699933" y1="27.600067" x2="114.82" y2="27.600067"/>
</signal>
<signal name="Net_61">
<contactref element="Q5" pad="1"/>
<contactref element="R1-26" pad="1"/>
<wire layer="16" width="0.5" x1="153.451233" y1="29.421267" x2="153.451233" y2="20.151233"/>
<wire layer="16" width="0.5" x1="153.451233" y1="20.151233" x2="152.8" y2="19.5"/>
<wire layer="16" width="0.5" x1="152.8" y1="19.5" x2="115.72" y2="19.5"/>
<wire layer="16" width="0.5" x1="115.72" y1="19.5" x2="114.82" y2="20.4"/>
</signal>
<signal name="Net_62">
<contactref element="U14" pad="7"/>
<contactref element="Cap-23" pad="1"/>
<wire layer="1" width="0.5" x1="42.425" y1="24.555" x2="42.425" y2="25.965"/>
<wire layer="1" width="0.5" x1="42.425" y1="25.965" x2="42.85" y2="26.39"/>
<wire layer="1" width="0.5" x1="42.85" y1="26.39" x2="45.43" y2="26.39"/>
<wire layer="1" width="0.5" x1="45.43" y1="26.39" x2="45.78" y2="26.74"/>
<wire layer="1" width="0.5" x1="45.78" y1="26.74" x2="45.89" y2="26.74"/>
</signal>
<signal name="Net_63">
<contactref element="Q6" pad="1"/>
<contactref element="R1-38" pad="1"/>
<wire layer="16" width="0.5" x1="158.055" y1="29.421267" x2="158.055" y2="25.045"/>
<wire layer="16" width="0.5" x1="158.055" y1="25.045" x2="159.12" y2="23.98"/>
<wire layer="16" width="0.5" x1="159.12" y1="23.98" x2="159.12" y2="23.1"/>
</signal>
<signal name="Net_64">
<contactref element="Q17" pad="1"/>
<contactref element="Cap-23" pad="2"/>
<wire layer="1" width="0.5" x1="48.93" y1="26.74" x2="48.93" y2="23.63"/>
<wire layer="1" width="0.5" x1="48.93" y1="23.63" x2="49.65" y2="22.91"/>
</signal>
<signal name="Net_65">
<contactref element="Q7" pad="1"/>
<contactref element="R1-39" pad="1"/>
<wire layer="16" width="0.5" x1="124.62" y1="22.300033" x2="149.200033" y2="22.300033"/>
<wire layer="16" width="0.5" x1="149.200033" y1="22.300033" x2="150.1" y2="23.2"/>
<wire layer="16" width="0.5" x1="150.1" y1="23.2" x2="150.1" y2="33.2"/>
<wire layer="16" width="0.5" x1="150.1" y1="33.2" x2="153.6" y2="36.7"/>
<wire layer="16" width="0.5" x1="153.6" y1="36.7" x2="161" y2="36.7"/>
<wire layer="16" width="0.5" x1="161" y1="36.7" x2="161" y2="35.4"/>
<wire layer="16" width="0.5" x1="161" y1="35.4" x2="159.3" y2="33.7"/>
<wire layer="16" width="0.5" x1="159.3" y1="33.7" x2="159.3" y2="28.1"/>
<wire layer="16" width="0.5" x1="159.3" y1="28.1" x2="160.2" y2="27.2"/>
<wire layer="16" width="0.5" x1="160.2" y1="27.2" x2="161.9" y2="27.2"/>
<wire layer="16" width="0.5" x1="161.9" y1="27.2" x2="162.658733" y2="27.958733"/>
<wire layer="16" width="0.5" x1="162.658733" y1="27.958733" x2="162.658733" y2="29.421267"/>
</signal>
<signal name="Net_66">
<contactref element="R1-31" pad="1"/>
<contactref element="R1-33" pad="1"/>
<contactref element="U1" pad="4"/>
<via x="-4.24" y="38.08" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="71.062433" y1="33.8375" x2="74.809933" y2="33.8375"/>
<wire layer="16" width="0.5" x1="74.809933" y1="33.8375" x2="74.819933" y2="33.8275"/>
<wire layer="16" width="0.5" x1="-4.24" y1="38.08" x2="-4.24" y2="37.94"/>
<wire layer="16" width="0.5" x1="-4.24" y1="37.94" x2="-2.1" y2="35.8"/>
<wire layer="16" width="0.5" x1="-2.1" y1="35.8" x2="44.9" y2="35.8"/>
<wire layer="16" width="0.5" x1="44.9" y1="35.8" x2="47.25" y2="38.15"/>
<wire layer="16" width="0.5" x1="47.25" y1="38.15" x2="56.79" y2="38.15"/>
<wire layer="16" width="0.5" x1="56.79" y1="38.15" x2="58.04" y2="36.9"/>
<wire layer="16" width="0.5" x1="58.04" y1="36.9" x2="69.09" y2="36.9"/>
<wire layer="16" width="0.5" x1="69.09" y1="36.9" x2="71.062433" y2="34.927567"/>
<wire layer="16" width="0.5" x1="71.062433" y1="34.927567" x2="71.062433" y2="33.8375"/>
<wire layer="1" width="0.5" x1="-4.24" y1="38.08" x2="-4.24" y2="36.57"/>
<wire layer="1" width="0.5" x1="-4.24" y1="36.57" x2="-4.255" y2="36.555"/>
</signal>
<signal name="Net_67">
<contactref element="Q11" pad="1"/>
<contactref element="R1-28" pad="1"/>
<wire layer="16" width="0.5" x1="185.15" y1="30.35" x2="185.65" y2="30.35"/>
<wire layer="16" width="0.5" x1="185.65" y1="30.35" x2="186.3" y2="31"/>
<wire layer="16" width="0.5" x1="186.3" y1="31" x2="186.3" y2="35.9"/>
<wire layer="16" width="0.5" x1="186.3" y1="35.9" x2="178.8" y2="43.4"/>
<wire layer="16" width="0.5" x1="178.8" y1="43.4" x2="167.42" y2="43.4"/>
<wire layer="16" width="0.5" x1="167.42" y1="43.4" x2="167.42" y2="42.900033"/>
</signal>
<signal name="Net_68">
<contactref element="R1-34" pad="1"/>
<contactref element="U1" pad="5"/>
<via x="-5.52" y="38.08" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-5.52" y1="38.08" x2="-5.52" y2="38.68"/>
<wire layer="16" width="0.5" x1="-5.52" y1="38.68" x2="-3.7" y2="40.5"/>
<wire layer="16" width="0.5" x1="-3.7" y1="40.5" x2="3.5" y2="40.5"/>
<wire layer="16" width="0.5" x1="3.5" y1="40.5" x2="7.2" y2="36.8"/>
<wire layer="16" width="0.5" x1="7.2" y1="36.8" x2="44.3" y2="36.8"/>
<wire layer="16" width="0.5" x1="44.3" y1="36.8" x2="46.72" y2="39.22"/>
<wire layer="16" width="0.5" x1="46.72" y1="39.22" x2="57.06" y2="39.22"/>
<wire layer="16" width="0.5" x1="57.06" y1="39.22" x2="58.38" y2="37.9"/>
<wire layer="16" width="0.5" x1="58.38" y1="37.9" x2="72.5" y2="37.9"/>
<wire layer="16" width="0.5" x1="72.5" y1="37.9" x2="72.8" y2="37.6"/>
<wire layer="16" width="0.5" x1="72.8" y1="37.6" x2="95.21" y2="37.6"/>
<wire layer="16" width="0.5" x1="95.21" y1="37.6" x2="97.573667" y2="35.236333"/>
<wire layer="16" width="0.5" x1="97.573667" y1="35.236333" x2="97.573667" y2="32.5675"/>
<wire layer="1" width="0.5" x1="-5.52" y1="38.08" x2="-5.52" y2="36.56"/>
<wire layer="1" width="0.5" x1="-5.52" y1="36.56" x2="-5.525" y2="36.555"/>
</signal>
<signal name="Net_69">
<contactref element="Q9" pad="1"/>
<contactref element="R1-40" pad="1"/>
<via x="175.9" y="35.4" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="175" y="38.6" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="175" y1="38.6" x2="175.7" y2="39.3"/>
<wire layer="16" width="0.5" x1="175.7" y1="39.3" x2="175.7" y2="40.967833"/>
<wire layer="16" width="0.5" x1="175.7" y1="40.967833" x2="176.02" y2="41.287833"/>
<wire layer="16" width="0.5" x1="176.02" y1="41.287833" x2="176.02" y2="41.500033"/>
<wire layer="16" width="0.5" x1="172.66" y1="29.421267" x2="173.121267" y2="29.421267"/>
<wire layer="16" width="0.5" x1="173.121267" y1="29.421267" x2="175.9" y2="32.2"/>
<wire layer="16" width="0.5" x1="175.9" y1="32.2" x2="175.9" y2="35.4"/>
<wire layer="1" width="0.5" x1="175" y1="38.6" x2="175" y2="36.5"/>
<wire layer="1" width="0.5" x1="175" y1="36.5" x2="175.9" y2="35.6"/>
<wire layer="1" width="0.5" x1="175.9" y1="35.6" x2="175.9" y2="35.4"/>
</signal>
<signal name="Net_70">
<contactref element="R1-27" pad="1"/>
<contactref element="U1" pad="6"/>
<via x="-6.77" y="38.08" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-6.77" y1="38.08" x2="-6.77" y2="38.92"/>
<wire layer="16" width="0.5" x1="-6.77" y1="38.92" x2="-3.89" y2="41.8"/>
<wire layer="16" width="0.5" x1="-3.89" y1="41.8" x2="3.8" y2="41.8"/>
<wire layer="16" width="0.5" x1="3.8" y1="41.8" x2="7.8" y2="37.8"/>
<wire layer="16" width="0.5" x1="7.8" y1="37.8" x2="43.8" y2="37.8"/>
<wire layer="16" width="0.5" x1="43.8" y1="37.8" x2="46.25" y2="40.25"/>
<wire layer="16" width="0.5" x1="46.25" y1="40.25" x2="57.43" y2="40.25"/>
<wire layer="16" width="0.5" x1="57.43" y1="40.25" x2="58.78" y2="38.9"/>
<wire layer="16" width="0.5" x1="58.78" y1="38.9" x2="73" y2="38.9"/>
<wire layer="16" width="0.5" x1="73" y1="38.9" x2="73.3" y2="38.6"/>
<wire layer="16" width="0.5" x1="73.3" y1="38.6" x2="97.25" y2="38.6"/>
<wire layer="16" width="0.5" x1="97.25" y1="38.6" x2="102.177467" y2="33.672533"/>
<wire layer="16" width="0.5" x1="102.177467" y1="33.672533" x2="102.177467" y2="32.5675"/>
<wire layer="1" width="0.5" x1="-6.77" y1="38.08" x2="-6.77" y2="36.58"/>
<wire layer="1" width="0.5" x1="-6.77" y1="36.58" x2="-6.795" y2="36.555"/>
</signal>
<signal name="Net_71">
<contactref element="Q10" pad="1"/>
<contactref element="R1-41" pad="1"/>
<wire layer="16" width="0.5" x1="178.851233" y1="29.421267" x2="179.656833" y2="29.421267"/>
<wire layer="16" width="0.5" x1="179.656833" y1="29.421267" x2="182.2" y2="31.964433"/>
<wire layer="16" width="0.5" x1="182.2" y1="31.964433" x2="182.2" y2="36"/>
<wire layer="16" width="0.5" x1="182.2" y1="36" x2="180.92" y2="37.28"/>
<wire layer="16" width="0.5" x1="180.92" y1="37.28" x2="180.92" y2="37.700033"/>
</signal>
<signal name="Net_72">
<contactref element="R1-40" pad="2"/>
<contactref element="U1" pad="17"/>
<via x="-14.4" y="29.1" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="17.4" y="41.8" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="17.4" y="32.8" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="17.4" y1="41.8" x2="42" y2="41.8"/>
<wire layer="16" width="0.5" x1="42" y1="41.8" x2="44.9" y2="44.7"/>
<wire layer="16" width="0.5" x1="44.9" y1="44.7" x2="59" y2="44.7"/>
<wire layer="16" width="0.5" x1="59" y1="44.7" x2="60.7" y2="43"/>
<wire layer="16" width="0.5" x1="60.7" y1="43" x2="74.8" y2="43"/>
<wire layer="16" width="0.5" x1="74.8" y1="43" x2="75.4" y2="42.4"/>
<wire layer="16" width="0.5" x1="75.4" y1="42.4" x2="159.3" y2="42.4"/>
<wire layer="16" width="0.5" x1="159.3" y1="42.4" x2="160.8" y2="40.9"/>
<wire layer="16" width="0.5" x1="160.8" y1="40.9" x2="172.8" y2="40.9"/>
<wire layer="16" width="0.5" x1="172.8" y1="40.9" x2="172.98" y2="41.08"/>
<wire layer="16" width="0.5" x1="172.98" y1="41.08" x2="172.98" y2="41.499967"/>
<wire layer="16" width="0.5" x1="-14.4" y1="29.1" x2="-14.4" y2="29.5"/>
<wire layer="16" width="0.5" x1="-14.4" y1="29.5" x2="-11.1" y2="32.8"/>
<wire layer="16" width="0.5" x1="-11.1" y1="32.8" x2="17.4" y2="32.8"/>
<wire layer="1" width="0.5" x1="17.4" y1="41.8" x2="17.4" y2="32.8"/>
<wire layer="1" width="0.5" x1="-14.4" y1="29.1" x2="-14.4" y2="27.46"/>
<wire layer="1" width="0.5" x1="-14.4" y1="27.46" x2="-14.415" y2="27.445"/>
</signal>
<signal name="Net_73">
<contactref element="Q15" pad="1"/>
<contactref element="R1-31" pad="2"/>
<wire layer="16" width="0.5" x1="79.6325" y1="31.1675" x2="79.6325" y2="29.616233"/>
<wire layer="16" width="0.5" x1="79.6325" y1="29.616233" x2="78.523767" y2="28.5075"/>
<wire layer="16" width="0.5" x1="78.523767" y1="28.5075" x2="77.100067" y2="28.5075"/>
<wire layer="16" width="0.5" x1="77.100067" y1="28.5075" x2="74.820067" y2="30.7875"/>
</signal>
<signal name="Net_74">
<contactref element="R1-28" pad="2"/>
<contactref element="U1" pad="18"/>
<via x="-13.1" y="29.1" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="15.2" y="42.8" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="15.2" y="31.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="164.38" y1="42.899967" x2="164.38" y2="43.3"/>
<wire layer="16" width="0.5" x1="164.38" y1="43.3" x2="75.919333" y2="43.3"/>
<wire layer="16" width="0.5" x1="75.919333" y1="43.3" x2="71.4" y2="47.819333"/>
<wire layer="16" width="0.5" x1="71.4" y1="47.819333" x2="71.4" y2="54.4"/>
<wire layer="16" width="0.5" x1="71.4" y1="54.4" x2="69.4" y2="56.4"/>
<wire layer="16" width="0.5" x1="69.4" y1="56.4" x2="63.6" y2="56.4"/>
<wire layer="16" width="0.5" x1="63.6" y1="56.4" x2="61.5" y2="54.3"/>
<wire layer="16" width="0.5" x1="61.5" y1="54.3" x2="61.5" y2="48.2"/>
<wire layer="16" width="0.5" x1="61.5" y1="48.2" x2="59" y2="45.7"/>
<wire layer="16" width="0.5" x1="59" y1="45.7" x2="44.5" y2="45.7"/>
<wire layer="16" width="0.5" x1="44.5" y1="45.7" x2="41.6" y2="42.8"/>
<wire layer="16" width="0.5" x1="41.6" y1="42.8" x2="15.2" y2="42.8"/>
<wire layer="16" width="0.5" x1="15.2" y1="42.8" x2="15.2" y2="42.8"/>
<wire layer="16" width="0.5" x1="15.2" y1="31.7" x2="15.2" y2="31.8"/>
<wire layer="16" width="0.5" x1="15.2" y1="31.8" x2="-10.5" y2="31.8"/>
<wire layer="16" width="0.5" x1="-10.5" y1="31.8" x2="-13.1" y2="29.2"/>
<wire layer="16" width="0.5" x1="-13.1" y1="29.2" x2="-13.1" y2="29.1"/>
<wire layer="1" width="0.5" x1="15.2" y1="42.8" x2="15.2" y2="31.7"/>
<wire layer="1" width="0.5" x1="-13.1" y1="29.1" x2="-13.1" y2="27.49"/>
<wire layer="1" width="0.5" x1="-13.1" y1="27.49" x2="-13.145" y2="27.445"/>
</signal>
<signal name="Net_75">
<contactref element="R1-39" pad="2"/>
<wire layer="16" width="0.5" x1="121.58" y1="22.299967" x2="118.300033" y2="22.299967"/>
<wire layer="16" width="0.5" x1="118.300033" y1="22.299967" x2="116.6" y2="24"/>
<wire layer="16" width="0.5" x1="116.6" y1="24" x2="110" y2="24"/>
<wire layer="16" width="0.5" x1="110" y1="24" x2="107.5" y2="21.5"/>
<wire layer="16" width="0.5" x1="107.5" y1="21.5" x2="76.9" y2="21.5"/>
<wire layer="16" width="0.5" x1="76.9" y1="21.5" x2="74.7" y2="19.3"/>
<wire layer="16" width="0.5" x1="74.7" y1="19.3" x2="74.7" y2="14"/>
</signal>
<signal name="Net_76">
<contactref element="U1" pad="28"/>
<contactref element="U3" pad="4"/>
<via x="-20.1" y="32.2" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="-0.4" y="25.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-0.4" y1="25.7" x2="-0.4" y2="23"/>
<wire layer="16" width="0.5" x1="-0.4" y1="23" x2="1.1" y2="21.5"/>
<wire layer="16" width="0.5" x1="1.1" y1="21.5" x2="55.4" y2="21.5"/>
<wire layer="16" width="0.5" x1="55.4" y1="21.5" x2="59" y2="17.9"/>
<wire layer="16" width="0.5" x1="59" y1="17.9" x2="59" y2="13.9"/>
<wire layer="16" width="0.5" x1="-52.25" y1="29.45" x2="-50.55" y2="29.45"/>
<wire layer="16" width="0.5" x1="-50.55" y1="29.45" x2="-50" y2="28.9"/>
<wire layer="16" width="0.5" x1="-50" y1="28.9" x2="-45.7" y2="28.9"/>
<wire layer="16" width="0.5" x1="-45.7" y1="28.9" x2="-42.4" y2="32.2"/>
<wire layer="16" width="0.5" x1="-42.4" y1="32.2" x2="-20.1" y2="32.2"/>
<wire layer="1" width="0.5" x1="-0.445" y1="27.445" x2="-0.445" y2="25.745"/>
<wire layer="1" width="0.5" x1="-0.445" y1="25.745" x2="-0.4" y2="25.7"/>
<wire layer="1" width="0.5" x1="-20.1" y1="32.2" x2="-18.4" y2="32.2"/>
<wire layer="1" width="0.5" x1="-18.4" y1="32.2" x2="-17.5" y2="31.3"/>
<wire layer="1" width="0.5" x1="-17.5" y1="31.3" x2="-2.6" y2="31.3"/>
<wire layer="1" width="0.5" x1="-2.6" y1="31.3" x2="-0.445" y2="29.145"/>
<wire layer="1" width="0.5" x1="-0.445" y1="29.145" x2="-0.445" y2="27.445"/>
</signal>
<signal name="Net_77">
<contactref element="Cap-26" pad="2"/>
<contactref element="U20" pad="C"/>
<wire layer="1" width="0.5" x1="31.11" y1="26.8" x2="28.7" y2="26.8"/>
<wire layer="1" width="0.5" x1="28.7" y1="26.8" x2="28.7" y2="26.8"/>
<wire layer="1" width="0.5" x1="28.7" y1="26.8" x2="26.42" y2="26.8"/>
</signal>
<signal name="Net_78">
<contactref element="U12" pad="C"/>
<contactref element="Cap-24" pad="2"/>
<wire layer="1" width="0.5" x1="31.11" y1="23.1" x2="26.82" y2="23.1"/>
<wire layer="1" width="0.5" x1="26.82" y1="23.1" x2="26.42" y2="22.7"/>
</signal>
<signal name="Net_79">
<contactref element="U14" pad="5"/>
<contactref element="Cap-21" pad="1"/>
<contactref element="Cap-24" pad="1"/>
<contactref element="C10" pad="1"/>
<wire layer="1" width="0.5" x1="23.38" y1="22.7" x2="23.38" y2="21.62"/>
<wire layer="1" width="0.5" x1="23.38" y1="21.62" x2="24.1" y2="20.9"/>
<wire layer="1" width="0.5" x1="24.1" y1="20.9" x2="36.23" y2="20.9"/>
<wire layer="1" width="0.5" x1="36.23" y1="20.9" x2="39.885" y2="24.555"/>
<wire layer="1" width="0.5" x1="23.38" y1="22.7" x2="23.38" y2="22.850667"/>
<wire layer="1" width="0.5" x1="23.38" y1="22.850667" x2="24.9" y2="24.370667"/>
<wire layer="1" width="0.5" x1="24.9" y1="24.370667" x2="24.9" y2="28.329333"/>
<wire layer="1" width="0.5" x1="24.9" y1="28.329333" x2="23.629333" y2="29.6"/>
<wire layer="1" width="0.5" x1="23.629333" y1="29.6" x2="23.1" y2="29.6"/>
<wire layer="1" width="0.5" x1="23.1" y1="29.6" x2="22.045" y2="30.655"/>
<wire layer="1" width="0.5" x1="22.045" y1="30.655" x2="22.045" y2="32"/>
<wire layer="1" width="0.5" x1="22.29" y1="36.7" x2="22.29" y2="32.245"/>
<wire layer="1" width="0.5" x1="22.29" y1="32.245" x2="22.045" y2="32"/>
</signal>
<signal name="Net_80">
<contactref element="C9" pad="1"/>
<contactref element="U14" pad="2"/>
<contactref element="Cap-16" pad="2"/>
<contactref element="Cap-17" pad="1"/>
<wire layer="1" width="0.5" x1="53.282467" y1="32.5675" x2="54.235" y2="32.5675"/>
<wire layer="1" width="0.5" x1="54.235" y1="32.5675" x2="54.235" y2="33.27"/>
<wire layer="1" width="0.5" x1="54.235" y1="33.27" x2="55.346267" y2="34.381267"/>
<wire layer="1" width="0.5" x1="55.346267" y1="34.381267" x2="55.346267" y2="34.925"/>
<wire layer="1" width="0.5" x1="30.785" y1="31.94" x2="30.785" y2="30.860667"/>
<wire layer="1" width="0.5" x1="30.785" y1="30.860667" x2="31.845667" y2="29.8"/>
<wire layer="1" width="0.5" x1="31.845667" y1="29.8" x2="37.66" y2="29.8"/>
<wire layer="1" width="0.5" x1="37.66" y1="29.8" x2="37.66" y2="33.56"/>
<wire layer="1" width="0.5" x1="37.66" y1="33.56" x2="39.37" y2="35.27"/>
<wire layer="1" width="0.5" x1="39.37" y1="35.27" x2="50.579967" y2="35.27"/>
<wire layer="1" width="0.5" x1="50.579967" y1="35.27" x2="53.282467" y2="32.5675"/>
<wire layer="1" width="0.5" x1="31.845667" y1="29.8" x2="37.700767" y2="29.8"/>
<wire layer="1" width="0.5" x1="37.700767" y1="29.8" x2="37.700767" y2="29.099233"/>
<wire layer="1" width="0.5" x1="37.700767" y1="29.099233" x2="39.08" y2="27.72"/>
<wire layer="1" width="0.5" x1="39.08" y1="27.72" x2="42.425" y2="27.72"/>
<wire layer="1" width="0.5" x1="42.425" y1="27.72" x2="42.425" y2="29.505"/>
</signal>
<signal name="Net_81">
<contactref element="U1" pad="2"/>
<contactref element="U5" pad="1"/>
<contactref element="Cap-6" pad="1"/>
<via x="-16.1" y="34.3" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-42.678333" y1="42.5" x2="-42.678333" y2="41.478333"/>
<wire layer="16" width="0.5" x1="-42.678333" y1="41.478333" x2="-39.4" y2="38.2"/>
<wire layer="16" width="0.5" x1="-39.4" y1="38.2" x2="-20" y2="38.2"/>
<wire layer="16" width="0.5" x1="-20" y1="38.2" x2="-16.1" y2="34.3"/>
<wire layer="1" width="0.5" x1="-42.678333" y1="42.5" x2="-45.88" y2="42.5"/>
<wire layer="1" width="0.5" x1="-45.88" y1="42.5" x2="-47.1" y2="41.28"/>
<wire layer="1" width="0.5" x1="-1.715" y1="36.555" x2="-1.715" y2="34.685"/>
<wire layer="1" width="0.5" x1="-1.715" y1="34.685" x2="-3.1" y2="33.3"/>
<wire layer="1" width="0.5" x1="-3.1" y1="33.3" x2="-15.1" y2="33.3"/>
<wire layer="1" width="0.5" x1="-15.1" y1="33.3" x2="-16.1" y2="34.3"/>
</signal>
<signal name="Net_82">
<contactref element="U1" pad="13"/>
<contactref element="Cap-17" pad="2"/>
<via x="-15.67" y="38.13" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="55.39" y="37" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="55.39" y1="37" x2="47.7" y2="37"/>
<wire layer="16" width="0.5" x1="47.7" y1="37" x2="45.5" y2="34.8"/>
<wire layer="16" width="0.5" x1="45.5" y1="34.8" x2="-12.98" y2="34.8"/>
<wire layer="16" width="0.5" x1="-12.98" y1="34.8" x2="-15.67" y2="37.49"/>
<wire layer="16" width="0.5" x1="-15.67" y1="37.49" x2="-15.67" y2="38.13"/>
<wire layer="1" width="0.5" x1="55.3462" y1="37.965" x2="55.3462" y2="37.0438"/>
<wire layer="1" width="0.5" x1="55.3462" y1="37.0438" x2="55.39" y2="37"/>
<wire layer="1" width="0.5" x1="-15.67" y1="38.13" x2="-15.67" y2="36.57"/>
<wire layer="1" width="0.5" x1="-15.67" y1="36.57" x2="-15.685" y2="36.555"/>
</signal>
<signal name="Net_83">
<contactref element="U1" pad="16"/>
<contactref element="Q17" pad="3"/>
<via x="49.1" y="29.1" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<contactref element="Cap-27" pad="1"/>
<via x="-15.7" y="29.1" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="49.1" y1="29.1" x2="49" y2="29.1"/>
<wire layer="16" width="0.5" x1="49" y1="29.1" x2="48.53" y2="29.57"/>
<wire layer="16" width="0.5" x1="48.53" y1="29.57" x2="36.23" y2="29.57"/>
<wire layer="16" width="0.5" x1="36.23" y1="29.57" x2="34.599967" y2="31.200033"/>
<wire layer="16" width="0.5" x1="34.599967" y1="31.200033" x2="34.599967" y2="33.8"/>
<wire layer="16" width="0.5" x1="34.599967" y1="33.8" x2="-11.7" y2="33.8"/>
<wire layer="16" width="0.5" x1="-11.7" y1="33.8" x2="-15.7" y2="29.8"/>
<wire layer="16" width="0.5" x1="-15.7" y1="29.8" x2="-15.7" y2="29.1"/>
<wire layer="1" width="0.5" x1="50.599967" y1="24.87" x2="51.48" y2="24.87"/>
<wire layer="1" width="0.5" x1="51.48" y1="24.87" x2="52.32" y2="25.71"/>
<wire layer="1" width="0.5" x1="52.32" y1="25.71" x2="53.8" y2="25.71"/>
<wire layer="1" width="0.5" x1="53.8" y1="25.71" x2="53.8" y2="25.36"/>
<wire layer="1" width="0.5" x1="53.8" y1="25.36" x2="53.8" y2="25.74"/>
<wire layer="1" width="0.5" x1="53.8" y1="25.74" x2="52.46" y2="25.74"/>
<wire layer="1" width="0.5" x1="52.46" y1="25.74" x2="49.1" y2="29.1"/>
<wire layer="1" width="0.5" x1="-15.7" y1="29.1" x2="-15.7" y2="27.46"/>
<wire layer="1" width="0.5" x1="-15.7" y1="27.46" x2="-15.685" y2="27.445"/>
</signal>
<signal name="Net_84">
<contactref element="Pad48" pad="1"/>
<contactref element="Cap-30" pad="2"/>
<contactref element="Cap-31" pad="1"/>
<wire layer="1" width="1" x1="-42.41" y1="-25.6" x2="-40.953667" y2="-25.6"/>
<wire layer="1" width="1" x1="-40.953667" y1="-25.6" x2="-39.156833" y2="-23.803167"/>
<wire layer="1" width="1" x1="-39.156833" y1="-23.803167" x2="-39.156833" y2="-23.79"/>
<wire layer="1" width="1" x1="-39.156833" y1="-23.79" x2="-39.57" y2="-23.79"/>
<wire layer="1" width="1" x1="-39.156833" y1="-23.79" x2="-39.92" y2="-23.79"/>
<wire layer="1" width="1" x1="-39.92" y1="-23.79" x2="-39.92" y2="-25.593167"/>
<wire layer="1" width="1" x1="-39.92" y1="-25.593167" x2="-38.253167" y2="-27.26"/>
<wire layer="1" width="1" x1="-38.253167" y1="-27.26" x2="-35.88" y2="-27.26"/>
<wire layer="1" width="1" x1="-35.88" y1="-27.26" x2="-32.855" y2="-24.235"/>
<wire layer="1" width="1" x1="-32.855" y1="-24.235" x2="-30.38" y2="-24.235"/>
</signal>
<signal name="Net_85">
<contactref element="Pad47" pad="1"/>
<contactref element="C7" pad="1"/>
<contactref element="C8" pad="1"/>
<contactref element="Cap-28" pad="1"/>
<contactref element="U19" pad="C"/>
<wire layer="1" width="1" x1="-44.415" y1="-8.1" x2="-44.415" y2="-16.59"/>
<wire layer="1" width="1" x1="-44.415" y1="-16.59" x2="-44.395" y2="-16.59"/>
<wire layer="1" width="1" x1="-44.395" y1="-16.59" x2="-44.395" y2="-17.575"/>
<wire layer="1" width="1" x1="-44.395" y1="-17.575" x2="-46.89" y2="-20.07"/>
<wire layer="1" width="1" x1="-46.89" y1="-20.07" x2="-46.89" y2="-26.08"/>
<wire layer="1" width="1" x1="-46.89" y1="-26.08" x2="-41.85" y2="-31.12"/>
<wire layer="1" width="1" x1="-41.85" y1="-31.12" x2="-36.35" y2="-31.12"/>
<wire layer="1" width="1" x1="-36.35" y1="-31.12" x2="-31.665" y2="-26.435"/>
<wire layer="1" width="1" x1="-31.665" y1="-26.435" x2="-30.38" y2="-26.435"/>
<wire layer="1" width="1" x1="-18.92" y1="-24.320033" x2="-19.08" y2="-24.320033"/>
<wire layer="1" width="1" x1="-19.08" y1="-24.320033" x2="-19.08" y2="-21.34"/>
<wire layer="1" width="1" x1="-19.08" y1="-21.34" x2="-18.47" y2="-21.34"/>
<wire layer="1" width="1" x1="-30.38" y1="-26.435" x2="-29.075" y2="-26.435"/>
<wire layer="1" width="1" x1="-29.075" y1="-26.435" x2="-25.19" y2="-30.32"/>
<wire layer="1" width="1" x1="-25.19" y1="-30.32" x2="-21.241333" y2="-30.32"/>
<wire layer="1" width="1" x1="-21.241333" y1="-30.32" x2="-19.12" y2="-28.198667"/>
<wire layer="1" width="1" x1="-19.12" y1="-28.198667" x2="-19.12" y2="-24.320033"/>
<wire layer="1" width="1" x1="-19.12" y1="-24.320033" x2="-18.92" y2="-24.320033"/>
</signal>
<signal name="Net_86">
<contactref element="U19" pad="A"/>
<contactref element="U21" pad="1"/>
<wire layer="1" width="1" x1="-15.585" y1="-17.92" x2="-15.3" y2="-17.92"/>
<wire layer="1" width="1" x1="-15.3" y1="-17.92" x2="-15.3" y2="-21.34"/>
<wire layer="1" width="1" x1="-15.3" y1="-21.34" x2="-16.09" y2="-21.34"/>
</signal>
<signal name="Net_87">
<contactref element="R1-35" pad="1"/>
<contactref element="U1" pad="7"/>
<via x="-8.04" y="38.05" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-8.04" y1="38.05" x2="-8.04" y2="39.14"/>
<wire layer="16" width="0.5" x1="-8.04" y1="39.14" x2="-4.18" y2="43"/>
<wire layer="16" width="0.5" x1="-4.18" y1="43" x2="4.2" y2="43"/>
<wire layer="16" width="0.5" x1="4.2" y1="43" x2="8.4" y2="38.8"/>
<wire layer="16" width="0.5" x1="8.4" y1="38.8" x2="43.3" y2="38.8"/>
<wire layer="16" width="0.5" x1="43.3" y1="38.8" x2="45.87" y2="41.37"/>
<wire layer="16" width="0.5" x1="45.87" y1="41.37" x2="57.82" y2="41.37"/>
<wire layer="16" width="0.5" x1="57.82" y1="41.37" x2="59.19" y2="40"/>
<wire layer="16" width="0.5" x1="59.19" y1="40" x2="73.5" y2="40"/>
<wire layer="16" width="0.5" x1="73.5" y1="40" x2="73.9" y2="39.6"/>
<wire layer="16" width="0.5" x1="73.9" y1="39.6" x2="119.85" y2="39.6"/>
<wire layer="16" width="0.5" x1="119.85" y1="39.6" x2="125.03" y2="34.42"/>
<wire layer="16" width="0.5" x1="125.03" y1="34.42" x2="125.399933" y2="34.42"/>
<wire layer="1" width="0.5" x1="-8.04" y1="38.05" x2="-8.04" y2="36.58"/>
<wire layer="1" width="0.5" x1="-8.04" y1="36.58" x2="-8.065" y2="36.555"/>
</signal>
<signal name="Net_88">
<contactref element="R1-36" pad="1"/>
<contactref element="U1" pad="11"/>
<via x="-13.16" y="38.16" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-13.16" y1="38.16" x2="-13.16" y2="38.74"/>
<wire layer="16" width="0.5" x1="-13.16" y1="38.74" x2="-7.8" y2="44.1"/>
<wire layer="16" width="0.5" x1="-7.8" y1="44.1" x2="4.7" y2="44.1"/>
<wire layer="16" width="0.5" x1="4.7" y1="44.1" x2="9" y2="39.8"/>
<wire layer="16" width="0.5" x1="9" y1="39.8" x2="42.8" y2="39.8"/>
<wire layer="16" width="0.5" x1="42.8" y1="39.8" x2="45.54" y2="42.54"/>
<wire layer="16" width="0.5" x1="45.54" y1="42.54" x2="58.16" y2="42.54"/>
<wire layer="16" width="0.5" x1="58.16" y1="42.54" x2="59.7" y2="41"/>
<wire layer="16" width="0.5" x1="59.7" y1="41" x2="74" y2="41"/>
<wire layer="16" width="0.5" x1="74" y1="41" x2="74.44" y2="40.56"/>
<wire layer="16" width="0.5" x1="74.44" y1="40.56" x2="121.51" y2="40.56"/>
<wire layer="16" width="0.5" x1="121.51" y1="40.56" x2="127.65" y2="34.42"/>
<wire layer="16" width="0.5" x1="127.65" y1="34.42" x2="129.999967" y2="34.42"/>
<wire layer="1" width="0.5" x1="-13.16" y1="38.16" x2="-13.16" y2="36.57"/>
<wire layer="1" width="0.5" x1="-13.16" y1="36.57" x2="-13.145" y2="36.555"/>
</signal>
<signal name="Net_89">
<contactref element="R1-41" pad="2"/>
<contactref element="U1" pad="12"/>
<via x="-14.41" y="38.15" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="177.88" y1="37.699967" x2="177.88" y2="37.1"/>
<wire layer="16" width="0.5" x1="177.88" y1="37.1" x2="172.7" y2="37.1"/>
<wire layer="16" width="0.5" x1="172.7" y1="37.1" x2="170" y2="39.8"/>
<wire layer="16" width="0.5" x1="170" y1="39.8" x2="160.5" y2="39.8"/>
<wire layer="16" width="0.5" x1="160.5" y1="39.8" x2="158.8" y2="41.5"/>
<wire layer="16" width="0.5" x1="158.8" y1="41.5" x2="74.9" y2="41.5"/>
<wire layer="16" width="0.5" x1="74.9" y1="41.5" x2="74.4" y2="42"/>
<wire layer="16" width="0.5" x1="74.4" y1="42" x2="60.21" y2="42"/>
<wire layer="16" width="0.5" x1="60.21" y1="42" x2="58.54" y2="43.67"/>
<wire layer="16" width="0.5" x1="58.54" y1="43.67" x2="45.27" y2="43.67"/>
<wire layer="16" width="0.5" x1="45.27" y1="43.67" x2="42.4" y2="40.8"/>
<wire layer="16" width="0.5" x1="42.4" y1="40.8" x2="9.7" y2="40.8"/>
<wire layer="16" width="0.5" x1="9.7" y1="40.8" x2="5.3" y2="45.2"/>
<wire layer="16" width="0.5" x1="5.3" y1="45.2" x2="-8.3" y2="45.2"/>
<wire layer="16" width="0.5" x1="-8.3" y1="45.2" x2="-14.41" y2="39.09"/>
<wire layer="16" width="0.5" x1="-14.41" y1="39.09" x2="-14.41" y2="38.15"/>
<wire layer="1" width="0.5" x1="-14.41" y1="38.15" x2="-14.41" y2="36.56"/>
<wire layer="1" width="0.5" x1="-14.41" y1="36.56" x2="-14.415" y2="36.555"/>
</signal>
<signal name="Net_90">
<contactref element="U1" pad="27"/>
<contactref element="U3" pad="5"/>
<via x="-20.1" y="30.3" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="-1.7" y="25.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-1.7" y1="25.7" x2="-1.7" y2="22.3"/>
<wire layer="16" width="0.5" x1="-1.7" y1="22.3" x2="0.1" y2="20.5"/>
<wire layer="16" width="0.5" x1="0.1" y1="20.5" x2="54.3" y2="20.5"/>
<wire layer="16" width="0.5" x1="54.3" y1="20.5" x2="57.9" y2="16.9"/>
<wire layer="16" width="0.5" x1="57.9" y1="16.9" x2="57.9" y2="14.1"/>
<wire layer="16" width="0.5" x1="-20.1" y1="30.3" x2="-42.6" y2="30.3"/>
<wire layer="16" width="0.5" x1="-42.6" y1="30.3" x2="-45.2" y2="27.7"/>
<wire layer="16" width="0.5" x1="-45.2" y1="27.7" x2="-49.9" y2="27.7"/>
<wire layer="16" width="0.5" x1="-49.9" y1="27.7" x2="-50.69" y2="26.91"/>
<wire layer="16" width="0.5" x1="-50.69" y1="26.91" x2="-52.25" y2="26.91"/>
<wire layer="1" width="0.5" x1="-1.715" y1="27.445" x2="-1.715" y2="25.715"/>
<wire layer="1" width="0.5" x1="-20.1" y1="30.3" x2="-20.1" y2="30.3"/>
<wire layer="1" width="0.5" x1="-20.1" y1="30.3" x2="-3.1" y2="30.3"/>
<wire layer="1" width="0.5" x1="-3.1" y1="30.3" x2="-1.715" y2="28.915"/>
<wire layer="1" width="0.5" x1="-1.715" y1="28.915" x2="-1.715" y2="27.445"/>
</signal>
<signal name="Net_91">
<contactref element="U1" pad="26"/>
<via x="-3" y="25.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-3" y1="25.7" x2="-3" y2="21.9"/>
<wire layer="16" width="0.5" x1="-3" y1="21.9" x2="-0.6" y2="19.5"/>
<wire layer="16" width="0.5" x1="-0.6" y1="19.5" x2="53.3" y2="19.5"/>
<wire layer="16" width="0.5" x1="53.3" y1="19.5" x2="56.7" y2="16.1"/>
<wire layer="16" width="0.5" x1="56.7" y1="16.1" x2="56.7" y2="14"/>
<wire layer="1" width="0.5" x1="-2.985" y1="27.445" x2="-2.985" y2="25.715"/>
<wire layer="1" width="0.5" x1="-2.985" y1="25.715" x2="-3" y2="25.7"/>
</signal>
<signal name="Net_92">
<contactref element="U13" pad="1"/>
<contactref element="U13" pad="2"/>
<contactref element="U13" pad="3"/>
<contactref element="U14" pad="8"/>
<contactref element="Pad3" pad="1"/>
<contactref element="Cap-18" pad="1"/>
<contactref element="Cap-19" pad="2"/>
<contactref element="Cap-20" pad="1"/>
<wire layer="1" width="0.5" x1="57.7" y1="43.551267" x2="57.7" y2="42.281267"/>
<wire layer="1" width="0.5" x1="57.7" y1="42.281267" x2="57.7" y2="41.011267"/>
<wire layer="1" width="0.5" x1="57.7" y1="43.551267" x2="57.848767" y2="43.551267"/>
<wire layer="1" width="0.5" x1="57.848767" y1="43.551267" x2="59.4075" y2="45.11"/>
<wire layer="1" width="0.5" x1="59.4075" y1="45.11" x2="66.3" y2="45.11"/>
<wire layer="1" width="0.5" x1="66.3" y1="45.11" x2="66.3" y2="45"/>
<wire layer="1" width="0.5" x1="66.3" y1="45" x2="70.58" y2="45"/>
<wire layer="1" width="0.5" x1="70.58" y1="45" x2="72.08" y2="43.5"/>
<wire layer="1" width="0.5" x1="51.199967" y1="42.868767" x2="51.199967" y2="43.49"/>
<wire layer="1" width="0.5" x1="51.199967" y1="43.49" x2="57.638733" y2="43.49"/>
<wire layer="1" width="0.5" x1="57.638733" y1="43.49" x2="57.7" y2="43.551267"/>
<wire layer="1" width="0.5" x1="57.7" y1="41.011267" x2="59.035" y2="41.011267"/>
<wire layer="1" width="0.5" x1="59.035" y1="41.011267" x2="59.6325" y2="40.413767"/>
<wire layer="1" width="0.5" x1="59.6325" y1="40.413767" x2="59.6325" y2="39.3025"/>
<wire layer="1" width="0.5" x1="59.6325" y1="39.3025" x2="58.9975" y2="38.6675"/>
<wire layer="1" width="0.5" x1="58.9975" y1="38.6675" x2="58.203733" y2="38.6675"/>
<wire layer="1" width="0.5" x1="58.203733" y1="38.6675" x2="57.568733" y2="38.0325"/>
<wire layer="1" width="0.5" x1="57.568733" y1="38.0325" x2="57.568733" y2="36.286267"/>
<wire layer="1" width="0.5" x1="57.568733" y1="36.286267" x2="58.203733" y2="35.651267"/>
<wire layer="1" width="0.5" x1="58.203733" y1="35.651267" x2="61.328133" y2="35.651267"/>
<wire layer="1" width="0.5" x1="61.328133" y1="35.651267" x2="61.696233" y2="35.283167"/>
<wire layer="1" width="0.5" x1="61.696233" y1="35.283167" x2="61.696233" y2="29.573433"/>
<wire layer="1" width="0.5" x1="61.696233" y1="29.573433" x2="63.3" y2="27.969667"/>
<wire layer="1" width="0.5" x1="63.3" y1="27.969667" x2="63.3" y2="26.4676"/>
<wire layer="1" width="0.5" x1="63.3" y1="26.4676" x2="62.210533" y2="25.378133"/>
<wire layer="1" width="0.5" x1="62.210533" y1="25.378133" x2="62.210533" y2="24.8563"/>
<wire layer="1" width="0.5" x1="62.210533" y1="24.8563" x2="62.210533" y2="24.6"/>
<wire layer="1" width="0.5" x1="62.210533" y1="24.6" x2="60" y2="24.6"/>
<wire layer="1" width="0.5" x1="60" y1="24.6" x2="56.7" y2="21.3"/>
<wire layer="1" width="0.5" x1="56.7" y1="21.3" x2="44.755667" y2="21.3"/>
<wire layer="1" width="0.5" x1="44.755667" y1="21.3" x2="43.695" y2="22.360667"/>
<wire layer="1" width="0.5" x1="43.695" y1="22.360667" x2="43.695" y2="24.555"/>
<wire layer="1" width="0.5" x1="62.210533" y1="24.8563" x2="62.210533" y2="24.8563"/>
</signal>
<signal name="Net_93">
<contactref element="U12" pad="A"/>
<via x="34.9" y="28.5" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<contactref element="Pad4" pad="1"/>
<contactref element="U20" pad="A"/>
<wire layer="16" width="0.5" x1="34.9" y1="28.5" x2="35.5" y2="27.9"/>
<wire layer="16" width="0.5" x1="35.5" y1="27.9" x2="52.9" y2="27.9"/>
<wire layer="16" width="0.5" x1="52.9" y1="27.9" x2="54.6" y2="26.2"/>
<wire layer="16" width="0.5" x1="54.6" y1="26.2" x2="60.54" y2="26.2"/>
<wire layer="16" width="0.5" x1="60.54" y1="26.2" x2="66.3" y2="20.44"/>
<wire layer="16" width="0.5" x1="66.3" y1="20.44" x2="66.3" y2="19"/>
<wire layer="1" width="0.46" x1="33.49" y1="26.8" x2="33.49" y2="26.49"/>
<wire layer="1" width="0.46" x1="33.49" y1="26.49" x2="33.49" y2="24.92"/>
<wire layer="1" width="0.5" x1="33.49" y1="24.92" x2="33.49" y2="23.1"/>
<wire layer="1" width="0.5" x1="33.49" y1="26.49" x2="34.9" y2="27.9"/>
<wire layer="1" width="0.5" x1="34.9" y1="27.9" x2="34.9" y2="28.5"/>
</signal>
<signal name="Net_94">
<contactref element="U13" pad="4"/>
<contactref element="U14" pad="1"/>
<contactref element="Cap-19" pad="1"/>
<via x="52.4" y="35.5" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="48.8" y="32.2" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="48.8" y1="32.2" x2="48.9" y2="32.2"/>
<wire layer="16" width="0.5" x1="48.9" y1="32.2" x2="52.2" y2="35.5"/>
<wire layer="16" width="0.5" x1="52.2" y1="35.5" x2="52.4" y2="35.5"/>
<wire layer="1" width="0.5" x1="43.695" y1="29.505" x2="46.105" y2="29.505"/>
<wire layer="1" width="0.5" x1="46.105" y1="29.505" x2="48.8" y2="32.2"/>
<wire layer="1" width="0.5" x1="51.200033" y1="39.828767" x2="51.7" y2="39.828767"/>
<wire layer="1" width="0.5" x1="51.7" y1="39.828767" x2="51.7" y2="36.6"/>
<wire layer="1" width="0.5" x1="51.7" y1="36.6" x2="52.4" y2="35.9"/>
<wire layer="1" width="0.5" x1="52.4" y1="35.9" x2="52.4" y2="35.5"/>
<wire layer="1" width="0.5" x1="51.200033" y1="39.828767" x2="51.200033" y2="39.741267"/>
<wire layer="1" width="0.5" x1="51.200033" y1="39.741267" x2="57.7" y2="39.741267"/>
</signal>
<signal name="Net_95">
<contactref element="U1" pad="25"/>
<via x="-4.3" y="25.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-4.3" y1="25.7" x2="-4.3" y2="21.5"/>
<wire layer="16" width="0.5" x1="-4.3" y1="21.5" x2="-1.3" y2="18.5"/>
<wire layer="16" width="0.5" x1="-1.3" y1="18.5" x2="52.5" y2="18.5"/>
<wire layer="16" width="0.5" x1="52.5" y1="18.5" x2="55.4" y2="15.6"/>
<wire layer="16" width="0.5" x1="55.4" y1="15.6" x2="55.4" y2="14.6"/>
<wire layer="1" width="0.5" x1="-4.255" y1="27.445" x2="-4.255" y2="25.745"/>
<wire layer="1" width="0.5" x1="-4.255" y1="25.745" x2="-4.3" y2="25.7"/>
</signal>
<signal name="Net_96">
<contactref element="U1" pad="24"/>
<via x="-5.5" y="25.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="13.1" y="27.4" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="9.3" y="27.4" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-5.5" y1="25.7" x2="-5.5" y2="26.6"/>
<wire layer="16" width="0.5" x1="-5.5" y1="26.6" x2="-4.7" y2="27.4"/>
<wire layer="16" width="0.5" x1="-4.7" y1="27.4" x2="9.3" y2="27.4"/>
<wire layer="16" width="0.5" x1="13.1" y1="27.4" x2="29.5" y2="27.4"/>
<wire layer="16" width="0.5" x1="29.5" y1="27.4" x2="34.4" y2="22.5"/>
<wire layer="16" width="0.5" x1="34.4" y1="22.5" x2="56.6" y2="22.5"/>
<wire layer="16" width="0.5" x1="56.6" y1="22.5" x2="60.1" y2="19"/>
<wire layer="16" width="0.5" x1="60.1" y1="19" x2="60.1" y2="14"/>
<wire layer="1" width="0.5" x1="-5.525" y1="27.445" x2="-5.525" y2="25.725"/>
<wire layer="1" width="0.5" x1="-5.525" y1="25.725" x2="-5.5" y2="25.7"/>
<wire layer="1" width="0.5" x1="13.1" y1="27.4" x2="9.3" y2="27.4"/>
<wire layer="1" width="0.5" x1="9.3" y1="27.4" x2="9.3" y2="27.4"/>
</signal>
<signal name="Net_97">
<contactref element="R1-29" pad="2"/>
<contactref element="U1" pad="23"/>
<via x="14.1" y="28.5" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="-6.8" y="25.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="10.4" y="28.5" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="70" y="20.4" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="63.1" y="20.5" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-6.8" y1="25.7" x2="-6.8" y2="27"/>
<wire layer="16" width="0.5" x1="-6.8" y1="27" x2="-5.3" y2="28.5"/>
<wire layer="16" width="0.5" x1="-5.3" y1="28.5" x2="10.4" y2="28.5"/>
<wire layer="16" width="0.5" x1="10.4" y1="28.5" x2="10.4" y2="28.5"/>
<wire layer="16" width="0.5" x1="63.1" y1="20.5" x2="60.7" y2="20.5"/>
<wire layer="16" width="0.5" x1="60.7" y1="20.5" x2="57.6" y2="23.6"/>
<wire layer="16" width="0.5" x1="57.6" y1="23.6" x2="34.9" y2="23.6"/>
<wire layer="16" width="0.5" x1="34.9" y1="23.6" x2="30" y2="28.5"/>
<wire layer="16" width="0.5" x1="30" y1="28.5" x2="14.1" y2="28.5"/>
<wire layer="16" width="0.5" x1="70" y1="20.4" x2="70" y2="20.6"/>
<wire layer="16" width="0.5" x1="70" y1="20.6" x2="73.9" y2="24.5"/>
<wire layer="16" width="0.5" x1="73.9" y1="24.5" x2="105.2" y2="24.5"/>
<wire layer="16" width="0.5" x1="105.2" y1="24.5" x2="109.8" y2="29.1"/>
<wire layer="16" width="0.5" x1="109.8" y1="29.1" x2="109.8" y2="30.1"/>
<wire layer="16" width="0.5" x1="109.8" y1="30.1" x2="111.3" y2="31.6"/>
<wire layer="16" width="0.5" x1="111.3" y1="31.6" x2="111.78" y2="31.6"/>
<wire layer="1" width="0.5" x1="-6.795" y1="27.445" x2="-6.8" y2="25.7"/>
<wire layer="1" width="0.5" x1="14.1" y1="28.5" x2="14.1" y2="28.5"/>
<wire layer="1" width="0.5" x1="14.1" y1="28.5" x2="10.4" y2="28.5"/>
<wire layer="1" width="0.5" x1="63.1" y1="20.5" x2="64.2" y2="20.5"/>
<wire layer="1" width="0.5" x1="64.2" y1="20.5" x2="64.6" y2="20.9"/>
<wire layer="1" width="0.5" x1="64.6" y1="20.9" x2="68.3" y2="20.9"/>
<wire layer="1" width="0.5" x1="68.3" y1="20.9" x2="68.8" y2="20.4"/>
<wire layer="1" width="0.5" x1="68.8" y1="20.4" x2="70" y2="20.4"/>
</signal>
<signal name="Net_98">
<contactref element="R1-30" pad="2"/>
<contactref element="U1" pad="22"/>
<via x="13.2" y="29.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="-8.1" y="25.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="9.4" y="29.6" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="69.2" y="21.9" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="61.4" y="22" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-8.1" y1="25.7" x2="-8.1" y2="27.4"/>
<wire layer="16" width="0.5" x1="-8.1" y1="27.4" x2="-5.8" y2="29.7"/>
<wire layer="16" width="0.5" x1="-5.8" y1="29.7" x2="9.4" y2="29.7"/>
<wire layer="16" width="0.5" x1="9.4" y1="29.7" x2="9.4" y2="29.6"/>
<wire layer="16" width="0.5" x1="61.4" y1="22" x2="58.6" y2="24.8"/>
<wire layer="16" width="0.5" x1="58.6" y1="24.8" x2="35.3" y2="24.8"/>
<wire layer="16" width="0.5" x1="35.3" y1="24.8" x2="30.4" y2="29.7"/>
<wire layer="16" width="0.5" x1="30.4" y1="29.7" x2="13.2" y2="29.7"/>
<wire layer="16" width="0.5" x1="69.2" y1="21.9" x2="72.8" y2="25.5"/>
<wire layer="16" width="0.5" x1="72.8" y1="25.5" x2="104.6" y2="25.5"/>
<wire layer="16" width="0.5" x1="104.6" y1="25.5" x2="108.6" y2="29.5"/>
<wire layer="16" width="0.5" x1="108.6" y1="29.5" x2="108.6" y2="33.1"/>
<wire layer="16" width="0.5" x1="108.6" y1="33.1" x2="110.3" y2="34.8"/>
<wire layer="16" width="0.5" x1="110.3" y1="34.8" x2="111.78" y2="34.8"/>
<wire layer="1" width="0.5" x1="-8.065" y1="27.445" x2="-8.1" y2="25.7"/>
<wire layer="1" width="0.5" x1="13.2" y1="29.7" x2="13.2" y2="29.7"/>
<wire layer="1" width="0.5" x1="13.2" y1="29.7" x2="9.4" y2="29.7"/>
<wire layer="1" width="0.5" x1="9.4" y1="29.7" x2="9.4" y2="29.6"/>
<wire layer="1" width="0.5" x1="61.4" y1="22" x2="61.4" y2="22"/>
<wire layer="1" width="0.5" x1="61.4" y1="22" x2="69.1" y2="22"/>
<wire layer="1" width="0.5" x1="69.1" y1="22" x2="69.2" y2="21.9"/>
</signal>
<signal name="Net_99">
<contactref element="U1" pad="21"/>
<contactref element="U2" pad="3"/>
<contactref element="Cap-12" pad="2"/>
<via x="-9.4" y="25.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-9.4" y1="25.7" x2="-9.4" y2="27.8"/>
<wire layer="16" width="0.5" x1="-9.4" y1="27.8" x2="-6.4" y2="30.8"/>
<wire layer="16" width="0.5" x1="-6.4" y1="30.8" x2="10.8" y2="30.8"/>
<wire layer="16" width="0.5" x1="10.8" y1="30.8" x2="11.7" y2="29.9"/>
<wire layer="16" width="0.5" x1="11.7" y1="29.9" x2="11.7" y2="23.260133"/>
<wire layer="16" width="0.5" x1="11.7" y1="23.260133" x2="13.926733" y2="23.260133"/>
<wire layer="1" width="0.5" x1="-9.335" y1="27.445" x2="-9.335" y2="25.765"/>
<wire layer="1" width="0.5" x1="-9.335" y1="25.765" x2="-9.4" y2="25.7"/>
<wire layer="1" width="0.5" x1="-9.4" y1="25.7" x2="-9.4" y2="23.58"/>
<wire layer="1" width="0.5" x1="-9.4" y1="23.58" x2="-6.62" y2="20.8"/>
</signal>
<signal name="Net_100">
<contactref element="U1" pad="14"/>
<contactref element="Cap-4" pad="2"/>
<wire layer="1" width="0.5" x1="-16.955" y1="36.555" x2="-19.525" y2="36.555"/>
<wire layer="1" width="0.5" x1="-19.525" y1="36.555" x2="-20.98" y2="35.1"/>
</signal>
<signal name="Net_101">
<contactref element="U1" pad="15"/>
<contactref element="Cap-11" pad="2"/>
<wire layer="1" width="0.5" x1="-16.955" y1="27.445" x2="-20.825" y2="27.445"/>
<wire layer="1" width="0.5" x1="-20.825" y1="27.445" x2="-20.98" y2="27.6"/>
</signal>
<signal name="Net_102">
<contactref element="U1" pad="3"/>
<contactref element="Cap-7" pad="1"/>
<contactref element="Cap-8" pad="1"/>
<via x="-14.5" y="34.6" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="-28.9" y="39.8" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="-28.9" y1="39.8" x2="-19.7" y2="39.8"/>
<wire layer="16" width="0.5" x1="-19.7" y1="39.8" x2="-14.5" y2="34.6"/>
<wire layer="1" width="0.5" x1="-14.5" y1="34.6" x2="-14.5" y2="34.4"/>
<wire layer="1" width="0.5" x1="-14.5" y1="34.4" x2="-3.6" y2="34.4"/>
<wire layer="1" width="0.5" x1="-3.6" y1="34.4" x2="-2.985" y2="35.015"/>
<wire layer="1" width="0.5" x1="-2.985" y1="35.015" x2="-2.985" y2="36.555"/>
<wire layer="1" width="0.5" x1="-35.3" y1="39.88" x2="-30.4" y2="39.88"/>
<wire layer="1" width="0.5" x1="-30.4" y1="39.88" x2="-30.4" y2="39.78"/>
<wire layer="1" width="0.5" x1="-30.4" y1="39.78" x2="-28.92" y2="39.78"/>
<wire layer="1" width="0.5" x1="-28.92" y1="39.78" x2="-28.9" y2="39.8"/>
</signal>
<signal name="Net_103">
<contactref element="C3" pad="1"/>
<contactref element="U4" pad="VCC"/>
<contactref element="Cap-13" pad="1"/>
<wire layer="1" width="0.5" x1="-36.745" y1="32" x2="-36.745" y2="31.345"/>
<wire layer="1" width="0.5" x1="-36.745" y1="31.345" x2="-34.18" y2="28.78"/>
<wire layer="1" width="0.5" x1="-34.18" y1="28.78" x2="-33.4" y2="28.78"/>
<wire layer="1" width="0.5" x1="-33.4" y1="28.78" x2="-30.8" y2="28.78"/>
<wire layer="1" width="0.5" x1="-43.0329" y1="21.5126" x2="-38.6674" y2="21.5126"/>
<wire layer="1" width="0.5" x1="-38.6674" y1="21.5126" x2="-33.4" y2="26.78"/>
<wire layer="1" width="0.5" x1="-33.4" y1="26.78" x2="-33.4" y2="28.78"/>
</signal>
<signal name="Net_104">
<contactref element="R1-26" pad="2"/>
<wire layer="16" width="0.5" x1="111.78" y1="20.4" x2="111.78" y2="19.5"/>
<wire layer="16" width="0.5" x1="111.78" y1="19.5" x2="78.8" y2="19.5"/>
<wire layer="16" width="0.5" x1="78.8" y1="19.5" x2="77.2" y2="17.9"/>
<wire layer="16" width="0.5" x1="77.2" y1="17.9" x2="77.2" y2="14.4"/>
</signal>
<signal name="Net_105">
<contactref element="R1-38" pad="2"/>
<via x="156.2" y="25.1" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="151.6" y="25.1" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="156.08" y1="23.1" x2="156.08" y2="24.98"/>
<wire layer="16" width="0.5" x1="156.08" y1="24.98" x2="156.2" y2="25.1"/>
<wire layer="16" width="0.5" x1="151.6" y1="25.1" x2="151.6" y2="21.1"/>
<wire layer="16" width="0.5" x1="151.6" y1="21.1" x2="151" y2="20.5"/>
<wire layer="16" width="0.5" x1="151" y1="20.5" x2="118.2" y2="20.5"/>
<wire layer="16" width="0.5" x1="118.2" y1="20.5" x2="115.9" y2="22.8"/>
<wire layer="16" width="0.5" x1="115.9" y1="22.8" x2="110.8" y2="22.8"/>
<wire layer="16" width="0.5" x1="110.8" y1="22.8" x2="108.5" y2="20.5"/>
<wire layer="16" width="0.5" x1="108.5" y1="20.5" x2="77.9" y2="20.5"/>
<wire layer="16" width="0.5" x1="77.9" y1="20.5" x2="75.9" y2="18.5"/>
<wire layer="16" width="0.5" x1="75.9" y1="18.5" x2="75.9" y2="14.2"/>
<wire layer="1" width="0.5" x1="151.6" y1="25.1" x2="151.6" y2="25"/>
<wire layer="1" width="0.5" x1="151.6" y1="25" x2="156.1" y2="25"/>
<wire layer="1" width="0.5" x1="156.1" y1="25" x2="156.2" y2="25.1"/>
</signal>
<signal name="Net_106">
<contactref element="R1-37" pad="1"/>
<wire layer="16" width="0.5" x1="111.78" y1="27.599933" x2="109.899933" y2="27.599933"/>
<wire layer="16" width="0.5" x1="109.899933" y1="27.599933" x2="105.8" y2="23.5"/>
<wire layer="16" width="0.5" x1="105.8" y1="23.5" x2="74.9" y2="23.5"/>
<wire layer="16" width="0.5" x1="74.9" y1="23.5" x2="72.5" y2="21.1"/>
<wire layer="16" width="0.5" x1="72.5" y1="21.1" x2="72.5" y2="13.6"/>
</signal>
<signal name="Net_107">
<contactref element="Q8" pad="1"/>
<contactref element="R1-42" pad="1"/>
<wire layer="16" width="0.5" x1="167.2625" y1="29.421267" x2="168.021267" y2="29.421267"/>
<wire layer="16" width="0.5" x1="168.021267" y1="29.421267" x2="169.3" y2="30.7"/>
<wire layer="16" width="0.5" x1="169.3" y1="30.7" x2="169.3" y2="34.4"/>
<wire layer="16" width="0.5" x1="169.3" y1="34.4" x2="170.2" y2="35.3"/>
<wire layer="16" width="0.5" x1="170.2" y1="35.3" x2="170.2" y2="36.9"/>
<wire layer="16" width="0.5" x1="170.2" y1="36.9" x2="168.399967" y2="38.700033"/>
<wire layer="16" width="0.5" x1="168.399967" y1="38.700033" x2="156.82" y2="38.700033"/>
</signal>
<signal name="Net_108">
<contactref element="R1-42" pad="2"/>
<wire layer="16" width="0.5" x1="153.78" y1="38.699967" x2="153.599967" y2="38.699967"/>
<wire layer="16" width="0.5" x1="153.599967" y1="38.699967" x2="148.4" y2="33.5"/>
<wire layer="16" width="0.5" x1="148.4" y1="33.5" x2="148.4" y2="25.4"/>
<wire layer="16" width="0.5" x1="148.4" y1="25.4" x2="147" y2="24"/>
<wire layer="16" width="0.5" x1="147" y1="24" x2="118.5" y2="24"/>
<wire layer="16" width="0.5" x1="118.5" y1="24" x2="117.2" y2="25.3"/>
<wire layer="16" width="0.5" x1="117.2" y1="25.3" x2="109.5" y2="25.3"/>
<wire layer="16" width="0.5" x1="109.5" y1="25.3" x2="106.7" y2="22.5"/>
<wire layer="16" width="0.5" x1="106.7" y1="22.5" x2="75.9" y2="22.5"/>
<wire layer="16" width="0.5" x1="75.9" y1="22.5" x2="73.6" y2="20.2"/>
<wire layer="16" width="0.5" x1="73.6" y1="20.2" x2="73.6" y2="14.1"/>
</signal>
<signal name="Net_109">
<contactref element="IC1" pad="1"/>
<contactref element="U11" pad="1"/>
<contactref element="U10" pad="2"/>
<wire layer="1" width="0.5" x1="4.1" y1="-6.48" x2="6.84" y2="-6.48"/>
<wire layer="1" width="0.5" x1="6.84" y1="-6.48" x2="8.555" y2="-8.195"/>
<wire layer="1" width="0.5" x1="5.936267" y1="-3.2" x2="6.836267" y2="-6.587667"/>
<wire layer="1" width="0.5" x1="6.836267" y1="-6.587667" x2="8.555" y2="-8.195"/>
</signal>
<signal name="Net_110">
<contactref element="IC1" pad="2"/>
<contactref element="U10" pad="1"/>
<wire layer="1" width="0.5" x1="4.1" y1="-9.52" x2="8.47" y2="-9.52"/>
<wire layer="1" width="0.5" x1="8.47" y1="-9.52" x2="8.525" y2="-9.465"/>
<wire layer="1" width="0.5" x1="8.525" y1="-9.465" x2="8.555" y2="-9.465"/>
</signal>
<signal name="Net_111">
<contactref element="IC1" pad="8"/>
<contactref element="Cap-9" pad="2"/>
<contactref element="U11" pad="2"/>
<contactref element="U16" pad="C"/>
<contactref element="D27" pad="C"/>
<wire layer="1" width="0.5" x1="10.063733" y1="-3.2" x2="10.063733" y2="-4.563733"/>
<wire layer="1" width="0.5" x1="10.063733" y1="-4.563733" x2="13" y2="-7.5"/>
<wire layer="1" width="0.5" x1="13" y1="-7.5" x2="18.245" y2="-7.5"/>
<wire layer="1" width="0.5" x1="18.245" y1="-7.5" x2="18.245" y2="-8.195"/>
<wire layer="1" width="0.5" x1="18.3" y1="-3.4" x2="18.6" y2="-3.4"/>
<wire layer="1" width="0.5" x1="18.6" y1="-3.4" x2="18.6" y2="-4.62"/>
<wire layer="1" width="0.5" x1="18.6" y1="-4.62" x2="21.5" y2="-4.62"/>
<wire layer="1" width="0.5" x1="18.6" y1="-4.62" x2="18.6" y2="-7.84"/>
<wire layer="1" width="0.5" x1="18.6" y1="-7.84" x2="18.245" y2="-8.195"/>
<wire layer="1" width="0.5" x1="13" y1="-7.5" x2="12.9" y2="-7.5"/>
<wire layer="1" width="0.5" x1="12.9" y1="-7.5" x2="12.9" y2="-13.3"/>
<wire layer="1" width="0.5" x1="12.9" y1="-13.3" x2="14.92" y2="-15.32"/>
<wire layer="1" width="0.5" x1="14.92" y1="-15.32" x2="14.92" y2="-16.5"/>
</signal>
<signal name="Net_112">
<contactref element="Cap-10" pad="2"/>
<contactref element="Cap-32" pad="1"/>
<contactref element="D27" pad="A"/>
<contactref element="C2" pad="1"/>
<contactref element="U25" pad="3"/>
<contactref element="J1" pad="3"/>
<wire layer="1" width="0.5" x1="125.32" y1="-3.6" x2="125.32" y2="-1.22"/>
<wire layer="1" width="0.5" x1="125.32" y1="-1.22" x2="124.9" y2="-0.8"/>
<wire layer="1" width="1" x1="124.9" y1="-0.8" x2="16.1" y2="-0.8"/>
<wire layer="1" width="0.5" x1="16.1" y1="-0.8" x2="15.5" y2="-1.4"/>
<wire layer="1" width="0.5" x1="15.5" y1="-1.4" x2="15.5" y2="-3.4"/>
<wire layer="1" width="0.5" x1="3.88" y1="-16.5" x2="3.88" y2="-13.58"/>
<wire layer="1" width="0.5" x1="3.88" y1="-13.58" x2="1.7" y2="-11.4"/>
<wire layer="1" width="0.5" x1="1.7" y1="-11.4" x2="1.7" y2="-1.4"/>
<wire layer="1" width="0.5" x1="1.7" y1="-1.4" x2="2.3" y2="-0.8"/>
<wire layer="1" width="0.5" x1="2.3" y1="-0.8" x2="12.824" y2="-0.8"/>
<wire layer="1" width="1" x1="12.824" y1="-0.8" x2="16.1" y2="-0.8"/>
<wire layer="1" width="0.5" x1="130.51" y1="-4.06" x2="125.3" y2="-4.06"/>
<wire layer="1" width="0.5" x1="125.3" y1="-4.06" x2="125.3" y2="-5.9"/>
<wire layer="1" width="0.5" x1="125.3" y1="-5.9" x2="123.699933" y2="-7.500067"/>
<wire layer="1" width="0.5" x1="123.699933" y1="-7.500067" x2="123.699933" y2="-7.805"/>
<wire layer="1" width="0.5" x1="125.32" y1="-3.6" x2="125.3" y2="-3.6"/>
<wire layer="1" width="0.5" x1="125.3" y1="-3.6" x2="125.3" y2="-4.06"/>
<wire layer="1" width="1" x1="124.9" y1="-0.8" x2="159.739333" y2="-0.8"/>
<wire layer="1" width="1" x1="159.739333" y1="-0.8" x2="160.8" y2="-1.860667"/>
<wire layer="1" width="0.5" x1="160.8" y1="-1.860667" x2="160.8" y2="-2.36"/>
</signal>
<signal name="Net_113">
<contactref element="IC1" pad="3"/>
<contactref element="IC1" pad="4"/>
<contactref element="Cap-9" pad="1"/>
<contactref element="Cap-10" pad="1"/>
<contactref element="U7" pad="1@_1"/>
<contactref element="U7" pad="1@"/>
<contactref element="Cap-32" pad="2"/>
<contactref element="U16" pad="A"/>
<contactref element="U22" pad="SHUNT"/>
<contactref element="U22" pad="GND"/>
<contactref element="U23" pad="1@_1"/>
<contactref element="U23" pad="1@_2"/>
<contactref element="U23" pad="1@_3"/>
<contactref element="U23" pad="1@"/>
<contactref element="U24" pad="1"/>
<contactref element="C2" pad="2"/>
<contactref element="U25" pad="1"/>
<contactref element="U25" pad="4"/>
<contactref element="C" pad="1"/>
<contactref element="C" pad="2"/>
<contactref element="J1" pad="1"/>
<contactref element="J1" pad="2"/>
<contactref element="U26" pad="5"/>
<contactref element="U26" pad="3"/>
<contactref element="U26" pad="6"/>
<contactref element="U28" pad="3"/>
<contactref element="Jumper1" pad="2"/>
<contactref element="Jumper1" pad="3"/>
<contactref element="Jumper1" pad="4@_1"/>
<contactref element="Jumper1" pad="4@_2"/>
<contactref element="Jumper1" pad="4@"/>
<via x="136" y="-13.3" extent="1-16" drill="1" diameter="2" shape="round" alwaysstop="no"/>
<via x="145.4" y="-13.3" extent="1-16" drill="1" diameter="2" shape="round" alwaysstop="no"/>
<contactref element="Cap-33" pad="1"/>
<contactref element="Cap-35" pad="1"/>
<contactref element="C11" pad="1"/>
<contactref element="C11" pad="2"/>
<via x="116.2" y="-21" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="101.9" y="-18.2" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="112.7" y="-20.4" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<contactref element="U29" pad="1"/>
<contactref element="U29" pad="2"/>
<contactref element="U30" pad="2"/>
<contactref element="D28" pad="C"/>
<contactref element="Cap-37" pad="2"/>
<contactref element="Cap-39" pad="2"/>
<via x="100.1" y="-3.6" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="1" x1="136" y1="-13.3" x2="145.4" y2="-13.3"/>
<wire layer="16" width="0.5" x1="116.2" y1="-21" x2="126.3" y2="-21"/>
<wire layer="16" width="0.5" x1="126.3" y1="-21" x2="127.71" y2="-19.59"/>
<wire layer="16" width="0.5" x1="127.71" y1="-19.59" x2="127.71" y2="-17.6"/>
<wire layer="16" width="0.5" x1="101.9" y1="-18.2" x2="104.1" y2="-18.2"/>
<wire layer="16" width="0.5" x1="104.1" y1="-18.2" x2="106.3" y2="-20.4"/>
<wire layer="16" width="0.5" x1="106.3" y1="-20.4" x2="112.7" y2="-20.4"/>
<wire layer="16" width="1" x1="122.63" y1="-17.6" x2="122.63" y2="-4.03"/>
<wire layer="16" width="1" x1="122.63" y1="-4.03" x2="119.4" y2="-0.8"/>
<wire layer="16" width="1" x1="119.4" y1="-0.8" x2="100.1" y2="-0.8"/>
<wire layer="16" width="1" x1="100.1" y1="-0.8" x2="58.3" y2="-0.8"/>
<wire layer="16" width="0.5" x1="100.1" y1="-3.6" x2="100.1" y2="-0.8"/>
<wire layer="1" width="0.5" x1="6.92" y1="-16.5" x2="6.92" y2="-18.02"/>
<wire layer="1" width="0.5" x1="6.92" y1="-18.02" x2="11.88" y2="-22.98"/>
<wire layer="1" width="0.5" x1="11.88" y1="-22.98" x2="15.9336" y2="-27.0336"/>
<wire layer="1" width="0.5" x1="15.9336" y1="-27.0336" x2="15.9336" y2="-26.8186"/>
<wire layer="1" width="0.5" x1="15.9336" y1="-26.8186" x2="15.615" y2="-26.5"/>
<wire layer="1" width="0.5" x1="8.555" y1="-10.735" x2="8.555" y2="-12.005"/>
<wire layer="1" width="0.5" x1="6.92" y1="-16.5" x2="6.92" y2="-13.64"/>
<wire layer="1" width="0.5" x1="6.92" y1="-13.64" x2="8.555" y2="-12.005"/>
<wire layer="1" width="0.5" x1="21.5" y1="-7.98" x2="21.5" y2="-22.403"/>
<wire layer="1" width="0.5" x1="21.5" y1="-22.403" x2="25.597" y2="-26.5"/>
<wire layer="1" width="0.5" x1="11.88" y1="-16.5" x2="11.88" y2="-22.98"/>
<wire layer="1" width="1" x1="136.547567" y1="-25.726367" x2="135.773633" y2="-25.726367"/>
<wire layer="1" width="1" x1="135.773633" y1="-25.726367" x2="132.9" y2="-28.6"/>
<wire layer="1" width="1" x1="132.9" y1="-28.6" x2="132.9" y2="-33.4"/>
<wire layer="1" width="1" x1="132.9" y1="-33.4" x2="132.3" y2="-34"/>
<wire layer="1" width="1" x1="132.3" y1="-34" x2="107.7" y2="-34"/>
<wire layer="1" width="1" x1="107.7" y1="-34" x2="102.600033" y2="-34"/>
<wire layer="1" width="1" x1="102.600033" y1="-34" x2="15.9336" y2="-34"/>
<wire layer="1" width="0.5" x1="15.9336" y1="-34" x2="15.9336" y2="-27.0336"/>
<wire layer="1" width="1" x1="158.264467" y1="-19.8792" x2="162.5071" y2="-24.121833"/>
<wire layer="1" width="1" x1="162.5071" y1="-24.121833" x2="162.5071" y2="-24.121833"/>
<wire layer="1" width="1" x1="158.264467" y1="-19.8792" x2="145.251867" y2="-19.8792"/>
<wire layer="1" width="1" x1="145.251867" y1="-19.8792" x2="144.802433" y2="-20.328633"/>
<wire layer="1" width="1" x1="137.79" y1="-31.5" x2="137.79" y2="-30.51"/>
<wire layer="1" width="1" x1="137.79" y1="-30.51" x2="142.573833" y2="-25.726167"/>
<wire layer="1" width="1" x1="142.573833" y1="-25.726167" x2="144.802567" y2="-25.726167"/>
<wire layer="1" width="1" x1="136.547433" y1="-20.328833" x2="136.547433" y2="-18.152567"/>
<wire layer="1" width="1" x1="136.547433" y1="-18.152567" x2="140.45" y2="-14.25"/>
<wire layer="1" width="1" x1="140.45" y1="-14.25" x2="140.45" y2="-9.1"/>
<wire layer="1" width="1" x1="136.547567" y1="-25.726367" x2="137.473633" y2="-25.726367"/>
<wire layer="1" width="1" x1="137.473633" y1="-25.726367" x2="140.6" y2="-22.6"/>
<wire layer="1" width="1" x1="140.6" y1="-22.6" x2="140.6" y2="-19"/>
<wire layer="1" width="1" x1="140.6" y1="-19" x2="146.3" y2="-13.3"/>
<wire layer="1" width="1" x1="146.3" y1="-13.3" x2="150.5" y2="-9.1"/>
<wire layer="1" width="1" x1="150.5" y1="-9.1" x2="153.95" y2="-9.1"/>
<wire layer="1" width="1" x1="140.45" y1="-9.1" x2="140.45" y2="-6.459333"/>
<wire layer="1" width="1" x1="140.45" y1="-6.459333" x2="142.109333" y2="-4.8"/>
<wire layer="1" width="1" x1="142.109333" y1="-4.8" x2="160.8" y2="-4.8"/>
<wire layer="1" width="0.5" x1="160.8" y1="-4.8" x2="160.8" y2="-4.9"/>
<wire layer="1" width="0.5" x1="135.09" y1="-4.06" x2="135.09" y2="-4.2"/>
<wire layer="1" width="1" x1="135.09" y1="-4.2" x2="135.7" y2="-4.2"/>
<wire layer="1" width="1" x1="135.7" y1="-4.2" x2="137.959333" y2="-6.459333"/>
<wire layer="1" width="1" x1="137.959333" y1="-6.459333" x2="140.45" y2="-6.459333"/>
<wire layer="1" width="1" x1="123.700067" y1="-12.995" x2="130.515" y2="-12.995"/>
<wire layer="1" width="0.5" x1="130.515" y1="-12.995" x2="132.8" y2="-10.71"/>
<wire layer="1" width="0.5" x1="122.28" y1="-3.6" x2="122.28" y2="-4.02"/>
<wire layer="1" width="0.5" x1="122.28" y1="-4.02" x2="121.5" y2="-4.8"/>
<wire layer="1" width="0.5" x1="121.5" y1="-4.8" x2="121.5" y2="-10.794933"/>
<wire layer="1" width="0.5" x1="121.5" y1="-10.794933" x2="123.700067" y2="-12.995"/>
<wire layer="1" width="0.5" x1="153.95" y1="-9.1" x2="155.9" y2="-9.1"/>
<wire layer="1" width="1" x1="155.9" y1="-9.1" x2="157.56" y2="-7.44"/>
<wire layer="1" width="1" x1="157.56" y1="-7.44" x2="160.8" y2="-7.44"/>
<wire layer="1" width="1" x1="132.8" y1="-10.71" x2="133.41" y2="-10.71"/>
<wire layer="1" width="1" x1="133.41" y1="-10.71" x2="136" y2="-13.3"/>
<wire layer="1" width="1" x1="145.4" y1="-13.3" x2="146.3" y2="-13.3"/>
<wire layer="1" width="1" x1="112.7" y1="-17.9" x2="112.7" y2="-7.3"/>
<wire layer="1" width="0.5" x1="107.7" y1="-30.64" x2="107.7" y2="-34"/>
<wire layer="1" width="0.5" x1="123.700067" y1="-12.995" x2="123.700067" y2="-14.000067"/>
<wire layer="1" width="0.5" x1="123.700067" y1="-14.000067" x2="125.17" y2="-15.47"/>
<wire layer="1" width="0.5" x1="125.17" y1="-15.47" x2="125.17" y2="-17.6"/>
<wire layer="1" width="0.5" x1="102.600067" y1="-31.72" x2="102.600033" y2="-34"/>
<wire layer="1" width="0.5" x1="122.63" y1="-17.6" x2="122.63" y2="-18.43"/>
<wire layer="1" width="0.5" x1="122.63" y1="-18.43" x2="124" y2="-19.8"/>
<wire layer="1" width="0.5" x1="124" y1="-19.8" x2="129.6" y2="-19.8"/>
<wire layer="1" width="0.5" x1="129.6" y1="-19.8" x2="130.25" y2="-19.15"/>
<wire layer="1" width="0.5" x1="130.25" y1="-19.15" x2="130.25" y2="-17.6"/>
<wire layer="1" width="0.5" x1="129.6" y1="-19.8" x2="136.0186" y2="-19.8"/>
<wire layer="1" width="0.5" x1="136.0186" y1="-19.8" x2="136.547433" y2="-20.328833"/>
<wire layer="1" width="0.5" x1="112.7" y1="-7.3" x2="118.58" y2="-7.3"/>
<wire layer="1" width="0.5" x1="118.58" y1="-7.3" x2="122.28" y2="-3.6"/>
<wire layer="1" width="0.5" x1="116.2" y1="-21" x2="116.2" y2="-18"/>
<wire layer="1" width="0.5" x1="116.2" y1="-18" x2="116.1" y2="-17.9"/>
<wire layer="1" width="0.5" x1="105.695" y1="-20.1" x2="107.2" y2="-20.1"/>
<wire layer="1" width="0.5" x1="107.2" y1="-20.1" x2="108.9" y2="-21.8"/>
<wire layer="1" width="0.5" x1="108.9" y1="-21.8" x2="115.4" y2="-21.8"/>
<wire layer="1" width="0.5" x1="115.4" y1="-21.8" x2="116.2" y2="-21"/>
<wire layer="1" width="0.5" x1="105.15" y1="-14.175" x2="105.15" y2="-19.555"/>
<wire layer="1" width="0.5" x1="105.15" y1="-19.555" x2="105.695" y2="-20.1"/>
<wire layer="1" width="0.5" x1="104" y1="-10.175" x2="104" y2="-11.2"/>
<wire layer="1" width="0.5" x1="104" y1="-11.2" x2="105.15" y2="-12.35"/>
<wire layer="1" width="0.5" x1="105.15" y1="-12.35" x2="105.15" y2="-14.175"/>
<wire layer="1" width="0.5" x1="112.7" y1="-20.4" x2="112.7" y2="-17.9"/>
<wire layer="1" width="0.5" x1="101.9" y1="-18.2" x2="101.9" y2="-19.705"/>
<wire layer="1" width="0.5" x1="101.9" y1="-19.705" x2="101.505" y2="-20.1"/>
<wire layer="1" width="0.5" x1="99.7" y1="-15.12" x2="99.7" y2="-16"/>
<wire layer="1" width="0.5" x1="99.7" y1="-16" x2="101.9" y2="-18.2"/>
<wire layer="1" width="0.5" x1="101.7" y1="-3.6" x2="100.1" y2="-3.6"/>
<wire layer="1" width="0.5" x1="100.1" y1="-3.6" x2="96.72" y2="-3.6"/>
<wire layer="1" width="0.5" x1="96.72" y1="-3.6" x2="96.52" y2="-3.4"/>
<wire layer="1" width="0.5" x1="99.14" y1="-8.85" x2="99.14" y2="-9.46"/>
<wire layer="1" width="0.5" x1="99.14" y1="-9.46" x2="97.7" y2="-10.9"/>
<wire layer="1" width="0.5" x1="97.7" y1="-10.9" x2="97.7" y2="-12.8959"/>
<wire layer="1" width="0.5" x1="97.7" y1="-12.8959" x2="97.7" y2="-13.12"/>
<wire layer="1" width="0.5" x1="97.7" y1="-13.12" x2="99.7" y2="-15.12"/>
<wire layer="1" width="0.5" x1="95.72" y1="-13.2" x2="97.3959" y2="-13.2"/>
<wire layer="1" width="0.5" x1="97.3959" y1="-13.2" x2="97.7" y2="-12.8959"/>
</signal>
<signal name="Net_114">
<contactref element="IC1" pad="6"/>
<via x="16.7" y="-10.7" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="16.7" y1="-10.7" x2="28.2" y2="-10.7"/>
<wire layer="1" width="0.5" x1="16.7" y1="-10.7" x2="18.21" y2="-10.7"/>
<wire layer="1" width="0.5" x1="18.21" y1="-10.7" x2="18.245" y2="-10.735"/>
</signal>
<signal name="Net_115">
<contactref element="IC1" pad="5"/>
<via x="16.7" y="-12" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="16.7" y1="-12" x2="28" y2="-12"/>
<wire layer="1" width="0.5" x1="16.7" y1="-12" x2="18.24" y2="-12"/>
<wire layer="1" width="0.5" x1="18.24" y1="-12" x2="18.245" y2="-12.005"/>
</signal>
<signal name="Net_116">
<contactref element="IC1" pad="7"/>
<via x="18.8" y="-15.6" extent="1-16" drill="1" diameter="2.5" shape="round" alwaysstop="no"/>
<wire layer="1" width="0.5" x1="18.245" y1="-9.465" x2="15.635" y2="-9.465"/>
<wire layer="1" width="0.5" x1="15.635" y1="-9.465" x2="15.3" y2="-9.8"/>
<wire layer="1" width="0.5" x1="15.3" y1="-9.8" x2="15.3" y2="-13.4"/>
<wire layer="1" width="0.5" x1="15.3" y1="-13.4" x2="17.5" y2="-15.6"/>
<wire layer="1" width="0.5" x1="17.5" y1="-15.6" x2="18.8" y2="-15.6"/>
</signal>
<signal name="Net_117">
<contactref element="U22" pad="VCC1"/>
<contactref element="U22" pad="VCC2"/>
<contactref element="U24" pad="2"/>
<wire layer="1" width="1" x1="149.7792" y1="-28.364467" x2="154.021833" y2="-32.6071"/>
<wire layer="1" width="1" x1="154.021833" y1="-32.6071" x2="154.021833" y2="-32.6071"/>
<wire layer="1" width="1" x1="144.616" y1="-31.5" x2="152.914733" y2="-31.5"/>
<wire layer="1" width="1" x1="152.914733" y1="-31.5" x2="154.021833" y2="-32.6071"/>
</signal>
<signal name="Net_118">
<contactref element="U27" pad="1"/>
<contactref element="U27" pad="3"/>
<contactref element="U28" pad="2"/>
<wire layer="1" width="0.95" x1="129.986" y1="-31.0305" x2="125.414" y2="-31.0305"/>
<wire layer="1" width="0.5" x1="118.39" y1="-28.1" x2="119.2" y2="-28.1"/>
<wire layer="1" width="0.5" x1="119.2" y1="-28.1" x2="122.1305" y2="-31.0305"/>
<wire layer="1" width="0.5" x1="122.1305" y1="-31.0305" x2="125.414" y2="-31.0305"/>
</signal>
<signal name="Net_119">
<contactref element="U27" pad="2"/>
<contactref element="Jumper1" pad="1"/>
<wire layer="1" width="0.5" x1="120.09" y1="-17.6" x2="120.09" y2="-19.79"/>
<wire layer="1" width="0.5" x1="120.09" y1="-19.79" x2="124.4805" y2="-24.1805"/>
<wire layer="1" width="0.5" x1="124.4805" y1="-24.1805" x2="127.7" y2="-24.1805"/>
</signal>
<signal name="Net_120">
<contactref element="U28" pad="1"/>
<contactref element="Cap-33" pad="2"/>
<contactref element="Cap-34" pad="2"/>
<wire layer="1" width="0.5" x1="102.599967" y1="-28.68" x2="104.58" y2="-28.68"/>
<wire layer="1" width="0.5" x1="104.58" y1="-28.68" x2="107.7" y2="-25.56"/>
<wire layer="1" width="0.5" x1="103.22" y1="-25.599967" x2="103.22" y2="-28.059967"/>
<wire layer="1" width="0.5" x1="103.22" y1="-28.059967" x2="102.599967" y2="-28.68"/>
</signal>
<signal name="Net_121">
<contactref element="Cap-34" pad="1"/>
<wire layer="1" width="0.5" x1="100.18" y1="-25.600033" x2="96.100033" y2="-25.600033"/>
</signal>
<signal name="Net_122">
<contactref element="U26" pad="1"/>
<contactref element="Cap-35" pad="2"/>
<contactref element="U29" pad="3"/>
<via x="109.2" y="-15.3" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<via x="102.9" y="-15.8" extent="1-16" drill="0.485667" diameter="1.016" shape="round" alwaysstop="no"/>
<wire layer="16" width="0.5" x1="102.9" y1="-15.8" x2="108.7" y2="-15.8"/>
<wire layer="16" width="0.5" x1="108.7" y1="-15.8" x2="109.2" y2="-15.3"/>
<wire layer="1" width="0.5" x1="102.9" y1="-15.8" x2="102.9" y2="-14.225"/>
<wire layer="1" width="0.5" x1="102.9" y1="-14.225" x2="102.85" y2="-14.175"/>
<wire layer="1" width="0.5" x1="109.2" y1="-15.3" x2="109.2" y2="-17.8"/>
<wire layer="1" width="0.5" x1="109.2" y1="-17.8" x2="109.3" y2="-17.9"/>
<wire layer="1" width="0.5" x1="99.7" y1="-12.08" x2="100.755" y2="-12.08"/>
<wire layer="1" width="0.5" x1="100.755" y1="-12.08" x2="102.85" y2="-14.175"/>
</signal>
<signal name="Net_123">
<contactref element="U30" pad="3"/>
<contactref element="D28" pad="A"/>
<contactref element="U31" pad="2"/>
<wire layer="1" width="0.5" x1="104.5" y1="-3.6" x2="104.5" y2="-4.86"/>
<wire layer="1" width="0.5" x1="104.5" y1="-4.86" x2="102.872933" y2="-6.487067"/>
<wire layer="1" width="0.5" x1="102.872933" y1="-6.487067" x2="102.672933" y2="-6.487067"/>
<wire layer="1" width="0.5" x1="102.672933" y1="-6.487067" x2="101.26" y2="-7.9"/>
<wire layer="1" width="0.5" x1="88.2" y1="-6.3375" x2="91.5625" y2="-6.3375"/>
<wire layer="1" width="0.5" x1="91.5625" y1="-6.3375" x2="92.4" y2="-5.5"/>
<wire layer="1" width="0.5" x1="92.4" y1="-5.5" x2="101.8859" y2="-5.5"/>
<wire layer="1" width="0.5" x1="101.8859" y1="-5.5" x2="102.872933" y2="-6.487067"/>
</signal>
<signal name="Net_124">
<contactref element="U31" pad="1"/>
<contactref element="Cap-37" pad="1"/>
<wire layer="1" width="0.5" x1="88.2" y1="-3.2975" x2="93.3775" y2="-3.2975"/>
<wire layer="1" width="0.5" x1="93.3775" y1="-3.2975" x2="93.48" y2="-3.4"/>
</signal>
<signal name="Net_125">
<contactref element="U30" pad="1"/>
<contactref element="Cap-38" pad="2"/>
<contactref element="Cap-39" pad="1"/>
<wire layer="1" width="0.5" x1="99.14" y1="-6.95" x2="97.97" y2="-6.95"/>
<wire layer="1" width="0.5" x1="97.97" y1="-6.95" x2="95.72" y2="-9.2"/>
<wire layer="1" width="0.5" x1="95.72" y1="-9.2" x2="95.72" y2="-10.16"/>
<wire layer="1" width="0.5" x1="95.72" y1="-10.16" x2="92.68" y2="-13.2"/>
</signal>
<signal name="Net_126">
<contactref element="Cap-38" pad="1"/>
<wire layer="1" width="0.5" x1="92.68" y1="-9.2" x2="88.4" y2="-9.2"/>
</signal>
<signal name="N$1">
<wire layer="16" width="0.5" x1="55.4" y1="14.775" x2="77.203" y2="14.5" curve="181.445223"/>
</signal>
<signal name="N$2">
<wire layer="16" width="0.5" x1="56.68" y1="14.3" x2="75.92" y2="14.3" curve="180"/>
</signal>
<signal name="N$3">
<wire layer="16" width="0.5" x1="57.887" y1="14.2" x2="74.713" y2="14.2" curve="180"/>
</signal>
<signal name="N$4">
<wire layer="16" width="0.5" x1="58.987" y1="14.2" x2="73.613" y2="14.2" curve="180"/>
</signal>
<signal name="N$5">
<wire layer="16" width="0.5" x1="60.087" y1="14.2" x2="72.513" y2="14.2" curve="180"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
