<root>
<document scada='0' schema='102' license='1,80636800,M9YG9R' title='' description='' fcversion='590336' target='PIC.16F.16F628A' >
	<config data='!0,3f6e%0,2%2,1%3,1%6,1%5,1%7,0%8,1%d,1' clkspd='4000000' simspd='1' usewdt='0' constif='0' Use3V3='0' />
	<plugins >
		<dll_models enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug >
		<watch expr='COUNT' />
		<watch expr='ENCODER_A' />
		<watch expr='ENCODER_B' />
		<watch expr='ENCODER_SW_' />
		<watch expr='ENCODER_X' />
	</debug>
	<traces />
	<ghost >
		<FK2 >
			<data name='FK2D0' port='4294967295' pin='4294967295' />
			<data name='FK2D1' port='4294967295' pin='4294967295' />
			<data name='FK2D2' port='4294967295' pin='4294967295' />
			<data name='FK2D3' port='4294967295' pin='4294967295' />
			<data name='FK2D4' port='4294967295' pin='4294967295' />
			<data name='FK2D5' port='4294967295' pin='4294967295' />
			<data name='FK2D6' port='4294967295' pin='4294967295' />
			<data name='FK2D7' port='4294967295' pin='4294967295' />
			<data name='FK2D8' port='4294967295' pin='4294967295' />
			<data name='FK2D9' port='4294967295' pin='4294967295' />
			<data name='FK2D10' port='4294967295' pin='4294967295' />
			<data name='FK2D11' port='4294967295' pin='4294967295' />
			<data name='FK2D12' port='4294967295' pin='4294967295' />
			<data name='FK2D13' port='4294967295' pin='4294967295' />
			<data name='FK2D14' port='4294967295' pin='4294967295' />
			<data name='FK2D15' port='4294967295' pin='4294967295' />
			<data name='FK2A0' port='4294967295' pin='4294967295' />
			<data name='FK2A1' port='4294967295' pin='4294967295' />
			<data name='FK2A2' port='4294967295' pin='4294967295' />
			<data name='FK2A3' port='4294967295' pin='4294967295' />
			<data name='FK2A4' port='4294967295' pin='4294967295' />
			<data name='FK2A5' port='4294967295' pin='4294967295' />
		</FK2>
		<ICD >
			<data name='AnalogPrescaleValue' value='19' />
			<data name='DigitalSampleRate' value='100000' />
			<data name='BreakpointCount' value='8' />
			<data name='CallStackDepthCount' value='8' />
			<data name='ClockPort' value='1' />
			<data name='ClockPin' value='6' />
			<data name='DataPort' value='1' />
			<data name='DataPin' value='7' />
			<data name='UseDefaultPins' value='1' />
			<data name='WrapEnabled' value='1' />
			<data name='CommsDelayOverridden' value='0' />
			<data name='CommsDelay' value='42' />
			<data name='CalculatedCommsDelay' value='42' />
			<data name='AnalogEB2PrescaleValue' value='2' />
			<data name='DigitalEB2SampleRate' value='100000' />
		</ICD>
		<pins >
			<digital A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
			<analog A='0' B='0' C='0' D='0' E='0' F='0' G='0' H='0' I='0' J='0' K='0' L='0' M='0' N='0' O='0' P='0' Q='0' R='0' S='0' T='0' U='0' V='0' W='0' X='0' Y='0' Z='0' />
		</pins>
	</ghost>
	<components >
		<settings autoimg='0' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='30655c2c-3fc0-4566-b9b0-cf8499bfc54d' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' category2='' category3='' bIs2dOnly='0' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='1' scadaCompatible='0' embeddedCompatible='1' iconpath='' />
		<gdiopts FullContainer='1' FullTransparency='1' ShowGdi='1' ShowOpengl='1' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='0' poslock='0' comp2dType='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='ENCODER_X' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='COUNT' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='false' type='b1' description='' isconst='1' isHidden='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='ENCODER_SW_' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='ENCODER_B' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='ENCODER_A' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='true' type='b1' description='' isconst='1' isHidden='0' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='ENCODER' description='' statediag='0' >
						<return name='Return' type='v0' description='' isconst='0' isHidden='0' isinit='0' usrinit='' setinit='' />
						<param name='INPUT_A' type='u8' description='ENCODER A' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
						<param name='INPUT_B' type='u8' description='ENCODER B' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
						<param name='INPUT_SW' type='u8' description='ENCODER SW' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
						<param name='ENCODER_COUNT_X' type='u8' description='ENCODER_COUNT' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
						<local name='ENCODER_A' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
						<local name='ENCODER_B' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
						<local name='ENCODER_X' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
						<command class_type='input' title='Input' cmdcolor='255' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' mode='1' port='1048577' mask='4' exp='ENCODER_SW_' usechipref='1' />
						<command class_type='input' title='Input' cmdcolor='255' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' mode='1' port='1048577' mask='1' exp='ENCODER_A' usechipref='1' />
						<command class_type='decision' title='ENCODER_A' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_A' swap='0' >
							<flowline >
								<command class_type='loop' title='Loop' textarea='73,80,73,80' cmdcolor='16711680' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' type='0' exp='ENCODER_A' >
									<flowline >
										<command class_type='comment' title='' comment='Ez a programrész csak akkor kell, ha az encoder nyomógombos,
vagy van külön nyomógomb az enkóderhez.
Ha az encoderhez nem kell nyomógomb, akkor törölhető az
&quot;ENCODER_SW_&quot;, az elágazás, és a Connection Point is.' textarea='12,0,12,0' cmdcolor='4399907' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' />
										<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_SW_' swap='0' >
											<flowline >
												<command class_type='goto' title='Goto Connection Point' cmdcolor='13882323' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' labelid='0' labelname='' />
											</flowline>
											<flowline />
										</command>
									</flowline>
								</command>
								<command class_type='input' title='Input' cmdcolor='255' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' mode='1' port='1048577' mask='2' exp='ENCODER_B' usechipref='1' />
								<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_B' swap='0' >
									<flowline >
										<command class_type='loop' title='Loop' cmdcolor='16711680' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' type='0' exp='ENCODER_B' >
											<flowline >
													<flowline >
													</flowline>
													<flowline />
												</command>
											</flowline>
										</command>
										<command class_type='calculation' title='Calculation' cmdcolor='598855' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' >
											<exp exp='ENCODER_X = ENCODER_X + 1' />
											<exp exp='' />
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
							<flowline />
						</command>
						<command class_type='decision' title='ENCODER_A' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_B' swap='0' >
							<flowline >
									<flowline >
											<flowline >
											</flowline>
											<flowline />
										</command>
									</flowline>
								</command>
								<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_A' swap='0' >
									<flowline >
										<command class_type='loop' title='Loop' cmdcolor='16711680' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' type='0' exp='ENCODER_A' >
											<flowline >
													<flowline >
													</flowline>
													<flowline />
												</command>
											</flowline>
										</command>
											<exp exp='ENCODER_X = ENCODER_X - 1' />
											<exp exp='' />
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
							<flowline />
						</command>
						<command class_type='label' title='Declare Connection Point' cmdcolor='13882323' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' labelid='0' labelname='A' />
						<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_X = 255' swap='0' >
							<flowline >
									<exp exp='ENCODER_X = 0' />
								</command>
							</flowline>
							<flowline />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Main' description='' statediag='0' >
						<command class_type='loop' title='Loop' cmdcolor='16711680' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' type='0' exp='1' >
							<flowline >
								<command class_type='call' title='User Macro' cmdcolor='1262987' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' macro='ENCODER' >
									<argument exp='ENCODER_A' />
									<argument exp='ENCODER_B' />
									<argument exp='ENCODER_SW_' />
									<argument exp='ENCODER_X' />
								</command>
									<exp exp='COUNT = ENCODER_X' />
								</command>
									<flowline >
										<command class_type='call' title='Component Macro' textarea='36,-6,36,-6' cmdcolor='5000268' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' component='SevenSeg_74HC595' macro='ShowDigits' >
											<argument exp='COUNT / 100' />
											<argument exp='COUNT MOD 100 / 10' />
											<argument exp='COUNT MOD 10' />
											<argument exp='16' />
											<argument exp='7' />
										</command>
									</flowline>
									<flowline />
								</command>
									<argument exp='0' />
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='5c1da48f-ce54-4622-bdd9-fc812e373696' vmin='1' vmaj='1' codename='SWITCH_ENCODER_A' x='-25.3473' y='0.962554' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='1' poslock='0' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTB.0' />
					<value target='polarity' data='000' />
					<value target='debounce' data='0' />
					<value target='operation' data='000' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='5c1da48f-ce54-4622-bdd9-fc812e373696' vmin='1' vmaj='1' codename='SWITCH_ENCODER_B' x='0.748874' y='0.962554' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='1' poslock='0' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTB.1' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='bddc472f-59dc-4705-997e-662768d643cd' vmin='0' vmaj='1' codename='SevenSeg_74HC595' x='6.41703' y='36.2562' z='0' xsz='76.2167' ysz='20' zsz='7.675' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='1' poslock='0' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='Num7Segs' data='003' />
					<value target='Display_Type' data='001' />
					<value target='ShowSegLabels' data='0' />
					<value target='DATA_PIN' data='$PORTA.0' />
					<value target='CLK_PIN' data='$PORTA.1' />
					<value target='LATCH_PIN' data='$PORTA.2' />
					<value target='FGColor' data='65280' />
					<value target='BGColor' data='2960685' />
					<value target='LabelColor' data='16777215' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='5c1da48f-ce54-4622-bdd9-fc812e373696' vmin='1' vmaj='1' codename='ENCODER_GOMB' x='-14.7064' y='-32.214' z='1.75' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' scadavisible='1' interactive='1' solid='1' layer='1' poslock='0' comp2dType='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTB.2' />
					<value target='debounce' data='20' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<scadaresourcelookup />
	<keymap >
		<key code='49' >
			<event path='panel.SWITCH_ENCODER_A.button' />
		</key>
	</keymap>
	<panel2d shadows='0' lighting='1' brightness='-179' >
		<background rgb='0' img='' style='0' />
		<camera xe='0' ye='0' ze='105.885' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<viewport dx='219' dy='313' zoom='250.261' fix_topleft='0' />
		<page x='1000' y='1000' show='0' rgb='7360576' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='0' perspective='1' >
		<background rgb='8409120' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='0' />
		<camera xe='0' ye='0' ze='781.66' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey0 xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
		<camerakey1 xe='-3.67394e-14' ye='0' ze='-300' xt='0' yt='0' zt='0' xquat='0' yquat='1' zquat='0' wquat='6.12323e-17' />
		<camerakey2 xe='0' ye='-300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.707107' yquat='0' zquat='0' wquat='0.707107' />
		<camerakey3 xe='-3.67394e-14' ye='300' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-4.32978e-17' yquat='0.707107' zquat='0.707107' wquat='4.32978e-17' />
		<camerakey4 xe='-300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='0.5' zquat='0.5' wquat='0.5' />
		<camerakey5 xe='300' ye='-6.66134e-14' ze='6.66134e-14' xt='0' yt='0' zt='0' xquat='-0.5' yquat='-0.5' zquat='-0.5' wquat='0.5' />
		<camerakey6 xe='-173.205' ye='-173.205' ze='173.205' xt='0' yt='0' zt='0' xquat='-0.424708' yquat='0.17592' zquat='0.339851' wquat='0.820473' />
	</panel3d>
	<layout >
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAAUgQAAFYCAAA' zoom='75' scrollx='94' scrolly='166' flags='0' />
		<view type='0' name='ENCODER' mode='0' placement='LAAAAAAAAAABAAAA---------------------wUAAAAYAAAAUgQAAFYCAAA' zoom='60' scrollx='0' scrolly='116' flags='0' />
	</layout>
</document>
</root>
