<root>
<file schema='102' />
<macros >
<macro >
<flowline name='ENCODER' description='' statediag='0' >
<return name='Return' type='v0' description='' isconst='0' isHidden='0' isinit='0' usrinit='' setinit='' />
<param name='INPUT_A' type='u8' description='ENCODER A' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
<param name='INPUT_B' type='u8' description='ENCODER B' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
<param name='INPUT_SW' type='u8' description='ENCODER SW' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
<param name='ENCODER_COUNT_X' type='u8' description='ENCODER_COUNT' isconst='0' isHidden='0' isinit='0' usrinit='0' setinit='' />
<local name='ENCODER_A' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
<local name='ENCODER_B' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
<local name='ENCODER_X' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
<command class_type='input' title='Input' cmdcolor='255' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' mode='1' port='1048577' mask='4' exp='ENCODER_SW_' usechipref='1' />
<command class_type='input' title='Input' cmdcolor='255' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' mode='1' port='1048577' mask='1' exp='ENCODER_A' usechipref='1' />
<command class_type='decision' title='ENCODER_A' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_A' swap='0' >
<flowline >
<command class_type='loop' title='Loop' textarea='73,80,73,80' cmdcolor='16711680' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' type='0' exp='ENCODER_A' >
<flowline >
<command class_type='comment' title='' comment='Ez a programrész csak akkor kell, ha az encoder nyomógombos,
vagy van külön nyomógomb az enkóderhez.
Ha az encoderhez nem kell nyomógomb, akkor törölhető az
&quot;ENCODER_SW_&quot;, az elágazás, és a Connection Point is.' textarea='12,0,12,0' cmdcolor='4399907' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' />
<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_SW_' swap='0' >
<flowline >
<command class_type='goto' title='Goto Connection Point' cmdcolor='13882323' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' labelid='0' labelname='' />
</flowline>
<flowline />
</command>
</flowline>
</command>
<command class_type='input' title='Input' cmdcolor='255' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' mode='1' port='1048577' mask='2' exp='ENCODER_B' usechipref='1' />
<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_B' swap='0' >
<flowline >
<command class_type='loop' title='Loop' cmdcolor='16711680' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' type='0' exp='ENCODER_B' >
<flowline >
<flowline >
</flowline>
<flowline />
</command>
</flowline>
</command>
<command class_type='calculation' title='Calculation' cmdcolor='598855' cmdcolor_sec='16772075' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' >
<exp exp='ENCODER_X = ENCODER_X + 1' />
<exp exp='' />
</command>
</flowline>
<flowline />
</command>
</flowline>
<flowline />
</command>
<command class_type='decision' title='ENCODER_A' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_B' swap='0' >
<flowline >
<flowline >
<flowline >
</flowline>
<flowline />
</command>
</flowline>
</command>
<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_A' swap='0' >
<flowline >
<command class_type='loop' title='Loop' cmdcolor='16711680' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='0' cmdopacity='1' type='0' exp='ENCODER_A' >
<flowline >
<flowline >
</flowline>
<flowline />
</command>
</flowline>
</command>
<exp exp='ENCODER_X = ENCODER_X - 1' />
<exp exp='' />
</command>
</flowline>
<flowline />
</command>
</flowline>
<flowline />
</command>
<command class_type='label' title='Declare Connection Point' cmdcolor='13882323' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' labelid='0' labelname='A' />
<command class_type='decision' title='Decision' cmdcolor='12632256' cmdcolor_sec='16777192' cmdcolor_txt='16777215' cmdgradient='4' cmdopacity='1' exp='ENCODER_X = 255' swap='0' >
<flowline >
<exp exp='ENCODER_X = 0' />
</command>
</flowline>
<flowline />
</command>
</flowline>
</macro>
</macros>
<variables >
<variable public='0' >
<def class_type='variable' name='ENCODER_X' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
</variable>
<def class_type='variable' name='ENCODER_SW_' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
</variable>
<def class_type='variable' name='ENCODER_B' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
</variable>
<def class_type='variable' name='ENCODER_A' type='u8' description='' isconst='0' isHidden='0' isinit='1' usrinit='0' setinit='0' />
</variable>
</variables>
</root>
