<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.5.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.635" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="88" name="SimResults" color="9" fill="1" visible="yes" active="yes"/>
<layer number="89" name="SimProbes" color="9" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="yes"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="ic-package" urn="urn:adsk.eagle:library:239">
<description>&lt;b&gt;IC Packages an Sockets&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL28-6" urn="urn:adsk.eagle:footprint:770/1" library_version="4">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.6 inch</description>
<wire x1="-17.653" y1="-1.27" x2="-17.653" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="1.27" x2="-17.653" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="17.653" y1="-6.604" x2="17.653" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="6.604" x2="-17.653" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="6.604" x2="17.653" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="-6.604" x2="17.653" y2="-6.604" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-17.78" y="-6.35" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-14.605" y="-0.9398" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL28-3" urn="urn:adsk.eagle:footprint:771/1" library_version="4">
<description>&lt;b&gt;Dual In Line Package Small&lt;/b&gt;</description>
<wire x1="17.78" y1="2.921" x2="-17.78" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.921" x2="17.78" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="17.78" y1="2.921" x2="17.78" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.921" x2="-17.78" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.921" x2="-17.78" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.016" x2="-17.78" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-18.034" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-8.509" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL28-4" urn="urn:adsk.eagle:footprint:18037/1" library_version="4">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="17.78" y1="4.191" x2="-17.78" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-4.191" x2="17.78" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="17.78" y1="4.191" x2="17.78" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="4.191" x2="-17.78" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-4.191" x2="-17.78" y2="-1.016" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<text x="-18.161" y="-4.191" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-13.335" y="-1.016" size="1.778" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="DIL28-6" urn="urn:adsk.eagle:package:826/2" type="model" library_version="4">
<description>Dual In Line Package 0.6 inch</description>
<packageinstances>
<packageinstance name="DIL28-6"/>
</packageinstances>
</package3d>
<package3d name="DIL28-3" urn="urn:adsk.eagle:package:827/2" type="model" library_version="4">
<description>Dual In Line Package Small</description>
<packageinstances>
<packageinstance name="DIL28-3"/>
</packageinstances>
</package3d>
<package3d name="DIL28-4" urn="urn:adsk.eagle:package:18077/2" type="model" library_version="4">
<description>Dual In Line Package</description>
<packageinstances>
<packageinstance name="DIL28-4"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="DIL28" urn="urn:adsk.eagle:symbol:14360/1" library_version="4">
<wire x1="-5.08" y1="16.51" x2="-5.08" y2="-19.05" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-19.05" x2="5.08" y2="-19.05" width="0.254" layer="94"/>
<wire x1="5.08" y1="-19.05" x2="5.08" y2="16.51" width="0.254" layer="94"/>
<wire x1="5.08" y1="16.51" x2="2.54" y2="16.51" width="0.254" layer="94"/>
<wire x1="-5.08" y1="16.51" x2="-2.54" y2="16.51" width="0.254" layer="94"/>
<wire x1="-2.54" y1="16.51" x2="2.54" y2="16.51" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="17.145" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-21.59" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="13" x="-7.62" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="14" x="-7.62" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="15" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="18" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="20" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="22" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="23" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="24" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="25" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="26" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="27" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="28" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="DIL28" urn="urn:adsk.eagle:component:14481/4" prefix="IC" uservalue="yes" library_version="4">
<description>&lt;b&gt;Dual In Line&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="DIL28" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL28-6">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
<connect gate="G$1" pin="17" pad="17"/>
<connect gate="G$1" pin="18" pad="18"/>
<connect gate="G$1" pin="19" pad="19"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="20" pad="20"/>
<connect gate="G$1" pin="21" pad="21"/>
<connect gate="G$1" pin="22" pad="22"/>
<connect gate="G$1" pin="23" pad="23"/>
<connect gate="G$1" pin="24" pad="24"/>
<connect gate="G$1" pin="25" pad="25"/>
<connect gate="G$1" pin="26" pad="26"/>
<connect gate="G$1" pin="27" pad="27"/>
<connect gate="G$1" pin="28" pad="28"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:826/2"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="POPULARITY" value="0" constant="no"/>
</technology>
</technologies>
</device>
<device name="-3" package="DIL28-3">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:827/2"/>
<technologies>
<attribute name="POPULARITY" value="8" constant="no"/>
</technology>
</technologies>
</device>
<device name="-4" package="DIL28-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:18077/2"/>
<technologies>
<attribute name="POPULARITY" value="1" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="rcl" urn="urn:adsk.eagle:library:334">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="R0402" urn="urn:adsk.eagle:footprint:23043/3" library_version="11">
<description>&lt;b&gt;Chip RESISTOR 0402 EIA (1005 Metric)&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1" y1="0.483" x2="1" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1" y1="0.483" x2="1" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1" y1="-0.483" x2="-1" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1" y1="-0.483" x2="-1" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.5" y="0" dx="0.6" dy="0.7" layer="1"/>
<smd name="2" x="0.5" y="0" dx="0.6" dy="0.7" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.35" x2="0.1999" y2="0.35" layer="35"/>
</package>
<package name="R0603" urn="urn:adsk.eagle:footprint:23044/1" library_version="11">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R0805" urn="urn:adsk.eagle:footprint:23045/1" library_version="11">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="R0805W" urn="urn:adsk.eagle:footprint:23046/1" library_version="11">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; wave soldering&lt;p&gt;</description>
<smd name="1" x="-1.0525" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="1.0525" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R1206" urn="urn:adsk.eagle:footprint:23047/1" library_version="11">
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R1206W" urn="urn:adsk.eagle:footprint:23048/1" library_version="11">
wave soldering</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
</package>
<package name="R1210" urn="urn:adsk.eagle:footprint:23049/1" library_version="11">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
</package>
<package name="R1210W" urn="urn:adsk.eagle:footprint:23050/1" library_version="11">
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010" urn="urn:adsk.eagle:footprint:23051/1" library_version="11">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-3.175" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="R2010W" urn="urn:adsk.eagle:footprint:23052/1" library_version="11">
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
</package>
<package name="R2012" urn="urn:adsk.eagle:footprint:23053/1" library_version="11">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="R2012W" urn="urn:adsk.eagle:footprint:23054/1" library_version="11">
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R2512" urn="urn:adsk.eagle:footprint:23055/1" library_version="11">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R2512W" urn="urn:adsk.eagle:footprint:23056/1" library_version="11">
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3216" urn="urn:adsk.eagle:footprint:23057/1" library_version="11">
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="R3216W" urn="urn:adsk.eagle:footprint:23058/1" library_version="11">
</package>
<package name="R3225" urn="urn:adsk.eagle:footprint:23059/1" library_version="11">
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="R3225W" urn="urn:adsk.eagle:footprint:23060/1" library_version="11">
</package>
<package name="R5025" urn="urn:adsk.eagle:footprint:23061/1" library_version="11">
</package>
<package name="R5025W" urn="urn:adsk.eagle:footprint:23062/1" library_version="11">
</package>
<package name="R6332" urn="urn:adsk.eagle:footprint:23063/1" library_version="11">
Source: http://download.siliconexpert.com/pdfs/2005/02/24/Semi_Ap/2/VSH/Resistor/dcrcwfre.pdf</description>
<smd name="1" x="-3.1" y="0" dx="1" dy="3.2" layer="1"/>
<smd name="2" x="3.1" y="0" dx="1" dy="3.2" layer="1"/>
</package>
<package name="R6332W" urn="urn:adsk.eagle:footprint:25646/1" library_version="11">
<smd name="1" x="-3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
<smd name="2" x="3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
</package>
<package name="M0805" urn="urn:adsk.eagle:footprint:23065/1" library_version="11">
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="M1206" urn="urn:adsk.eagle:footprint:23066/1" library_version="11">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
</package>
<package name="M1406" urn="urn:adsk.eagle:footprint:23067/1" library_version="11">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
<package name="M2012" urn="urn:adsk.eagle:footprint:23068/1" library_version="11">
</package>
<package name="M2309" urn="urn:adsk.eagle:footprint:23069/1" library_version="11">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
</package>
<package name="M3216" urn="urn:adsk.eagle:footprint:23070/1" library_version="11">
</package>
<package name="M3516" urn="urn:adsk.eagle:footprint:23071/1" library_version="11">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M5923" urn="urn:adsk.eagle:footprint:23072/1" library_version="11">
</package>
<package name="0204/5" urn="urn:adsk.eagle:footprint:22991/1" library_version="11">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0204/7" urn="urn:adsk.eagle:footprint:22998/1" library_version="11">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0204V" urn="urn:adsk.eagle:footprint:22999/1" library_version="11">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10" urn="urn:adsk.eagle:footprint:22992/1" library_version="11">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12" urn="urn:adsk.eagle:footprint:22993/1" library_version="11">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/15" urn="urn:adsk.eagle:footprint:22997/1" library_version="11">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V" urn="urn:adsk.eagle:footprint:22994/1" library_version="11">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V" urn="urn:adsk.eagle:footprint:22995/1" library_version="11">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7" urn="urn:adsk.eagle:footprint:22996/1" library_version="11">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0309/10" urn="urn:adsk.eagle:footprint:23073/1" library_version="11">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
</package>
<package name="0309/12" urn="urn:adsk.eagle:footprint:23074/1" library_version="11">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="0309V" urn="urn:adsk.eagle:footprint:23075/1" library_version="11">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="0411/12" urn="urn:adsk.eagle:footprint:23076/1" library_version="11">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="0411/15" urn="urn:adsk.eagle:footprint:23077/1" library_version="11">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0411V" urn="urn:adsk.eagle:footprint:23078/1" library_version="11">
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="0414/15" urn="urn:adsk.eagle:footprint:23079/1" library_version="11">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
</package>
<package name="0414V" urn="urn:adsk.eagle:footprint:23080/1" library_version="11">
type 0414, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
</package>
<package name="0617/17" urn="urn:adsk.eagle:footprint:23081/1" library_version="11">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="0617/22" urn="urn:adsk.eagle:footprint:23082/1" library_version="11">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
<package name="0617V" urn="urn:adsk.eagle:footprint:23083/1" library_version="11">
type 0617, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="0922/22" urn="urn:adsk.eagle:footprint:23084/1" library_version="11">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="P0613V" urn="urn:adsk.eagle:footprint:23085/1" library_version="11">
type 0613, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="P0613/15" urn="urn:adsk.eagle:footprint:23086/1" library_version="11">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="P0817/22" urn="urn:adsk.eagle:footprint:23087/1" library_version="11">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
</package>
<package name="P0817V" urn="urn:adsk.eagle:footprint:23088/1" library_version="11">
type 0817, grid 6.35 mm</description>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
</package>
<package name="V234/12" urn="urn:adsk.eagle:footprint:23089/1" library_version="11">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
</package>
<package name="V235/17" urn="urn:adsk.eagle:footprint:23090/1" library_version="11">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="V526-0" urn="urn:adsk.eagle:footprint:23091/1" library_version="11">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102R" urn="urn:adsk.eagle:footprint:23092/1" library_version="11">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102W" urn="urn:adsk.eagle:footprint:23093/1" library_version="11">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0204R" urn="urn:adsk.eagle:footprint:25676/1" library_version="11">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="0.938" y1="0.6" x2="-0.938" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.938" y1="-0.6" x2="0.938" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0204W" urn="urn:adsk.eagle:footprint:25677/1" library_version="11">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="0.684" y1="0.6" x2="-0.684" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.684" y1="-0.6" x2="0.684" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0207R" urn="urn:adsk.eagle:footprint:25678/1" library_version="11">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="1.2125" y1="1" x2="-1.2125" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.2125" y1="-1" x2="1.2125" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0207W" urn="urn:adsk.eagle:footprint:25679/1" library_version="11">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="1.149" y1="1" x2="-1.149" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.149" y1="-1" x2="1.149" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="0922V" urn="urn:adsk.eagle:footprint:23098/1" library_version="11">
type 0922, grid 7.5 mm</description>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="RDH/15" urn="urn:adsk.eagle:footprint:23099/1" library_version="11">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="MINI_MELF-0102AX" urn="urn:adsk.eagle:footprint:23100/1" library_version="11">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<hole x="0" y="0" drill="1.3"/>
</package>
<package name="R0201" urn="urn:adsk.eagle:footprint:25683/1" library_version="11">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; chip&lt;p&gt;
Source: http://www.vishay.com/docs/20008/dcrcw.pdf</description>
<smd name="1" x="-0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<smd name="2" x="0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="0.15" layer="21"/>
</package>
<package name="VTA52" urn="urn:adsk.eagle:footprint:25684/1" library_version="11">
<description>&lt;b&gt;Bulk Metal® Foil Technology&lt;/b&gt;, Tubular Axial Lead Resistors, Meets or Exceeds MIL-R-39005 Requirements&lt;p&gt;
MIL SIZE RBR52&lt;br&gt;
Source: VISHAY .. vta56.pdf</description>
<wire x1="-15.24" y1="0" x2="-13.97" y2="0" width="0.6096" layer="51"/>
<wire x1="12.6225" y1="0.025" x2="12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="4.725" x2="-12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="4.725" x2="-12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="0.025" x2="-12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="-4.65" x2="12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="-4.65" x2="12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="13.97" y1="0" x2="15.24" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-15.24" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="15.24" y="0" drill="1.1" shape="octagon"/>
<text x="-3.81" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-13.97" y1="-0.3048" x2="-12.5675" y2="0.3048" layer="21"/>
<rectangle x1="12.5675" y1="-0.3048" x2="13.97" y2="0.3048" layer="21"/>
</package>
<package name="VTA53" urn="urn:adsk.eagle:footprint:25685/1" library_version="11">
MIL SIZE RBR53&lt;br&gt;
<wire x1="-12.065" y1="0" x2="-10.795" y2="0" width="0.6096" layer="51"/>
<wire x1="9.8975" y1="0" x2="9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="4.7" x2="-9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="4.7" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-4.675" x2="9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-4.675" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="10.795" y1="0" x2="12.065" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-12.065" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="12.065" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-10.795" y1="-0.3048" x2="-9.8425" y2="0.3048" layer="21"/>
<rectangle x1="9.8425" y1="-0.3048" x2="10.795" y2="0.3048" layer="21"/>
</package>
<package name="VTA54" urn="urn:adsk.eagle:footprint:25686/1" library_version="11">
MIL SIZE RBR54&lt;br&gt;
<wire x1="9.8975" y1="0" x2="9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="3.3" x2="-9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="3.3" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-3.3" x2="9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-3.3" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<text x="-3.81" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="VTA55" urn="urn:adsk.eagle:footprint:25687/1" library_version="11">
MIL SIZE RBR55&lt;br&gt;
<wire x1="-8.255" y1="0" x2="-6.985" y2="0" width="0.6096" layer="51"/>
<wire x1="6.405" y1="0" x2="6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="3.3" x2="-6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="3.3" x2="-6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="0" x2="-6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="-3.3" x2="6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="-3.3" x2="6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="6.985" y1="0" x2="8.255" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-8.255" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="8.255" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-6.985" y1="-0.3048" x2="-6.35" y2="0.3048" layer="21"/>
<rectangle x1="6.35" y1="-0.3048" x2="6.985" y2="0.3048" layer="21"/>
</package>
<package name="VTA56" urn="urn:adsk.eagle:footprint:25688/1" library_version="11">
MIL SIZE RBR56&lt;br&gt;
<wire x1="4.5" y1="0" x2="4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="3.3" x2="-4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="3.3" x2="-4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="0" x2="-4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="-3.3" x2="4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="-3.3" x2="4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-5.08" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
<rectangle x1="4.445" y1="-0.3048" x2="5.08" y2="0.3048" layer="21"/>
</package>
<package name="VMTA55" urn="urn:adsk.eagle:footprint:25689/1" library_version="11">
MIL SIZE RNC55&lt;br&gt;
<wire x1="-5.08" y1="0" x2="-4.26" y2="0" width="0.6096" layer="51"/>
<wire x1="3.3375" y1="-1.45" x2="3.3375" y2="1.45" width="0.1524" layer="21"/>
<wire x1="3.3375" y1="1.45" x2="-3.3625" y2="1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="1.45" x2="-3.3625" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="-1.45" x2="3.3375" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="4.235" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.1" shape="octagon"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.26" y1="-0.3048" x2="-3.3075" y2="0.3048" layer="21"/>
<rectangle x1="3.2825" y1="-0.3048" x2="4.235" y2="0.3048" layer="21"/>
</package>
<package name="VMTB60" urn="urn:adsk.eagle:footprint:25690/1" library_version="11">
MIL SIZE RNC60&lt;br&gt;
<wire x1="-6.35" y1="0" x2="-5.585" y2="0" width="0.6096" layer="51"/>
<wire x1="4.6875" y1="-1.95" x2="4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="4.6875" y1="1.95" x2="-4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="1.95" x2="-4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="-1.95" x2="4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="5.585" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<text x="-4.445" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.585" y1="-0.3048" x2="-4.6325" y2="0.3048" layer="21"/>
<rectangle x1="4.6325" y1="-0.3048" x2="5.585" y2="0.3048" layer="21"/>
</package>
<package name="R4527" urn="urn:adsk.eagle:footprint:13246/1" library_version="11">
<description>&lt;b&gt;Package 4527&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/31059/wsrhigh.pdf</description>
<wire x1="-5.675" y1="-3.375" x2="5.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.65" y1="-3.375" x2="5.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.65" y1="3.375" x2="-5.675" y2="3.375" width="0.2032" layer="21"/>
<wire x1="-5.675" y1="3.375" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<smd name="1" x="-4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<smd name="2" x="4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.715" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.715" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0001" urn="urn:adsk.eagle:footprint:25692/1" library_version="11">
<description>&lt;b&gt;Wirewound Resistors, Precision Power&lt;/b&gt;&lt;p&gt;
Source: VISHAY wscwsn.pdf</description>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="-3.075" y1="-1.8" x2="3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.075" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="1.606" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="-1.606" x2="-3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="1.606" x2="3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="-1.606" width="0.2032" layer="21"/>
<smd name="1" x="-2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<smd name="2" x="2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<text x="-2.544" y="2.229" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.501" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0002" urn="urn:adsk.eagle:footprint:25693/1" library_version="11">
<wire x1="-5.55" y1="3.375" x2="-5.55" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.55" y1="-3.375" x2="5.55" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.55" y1="-3.375" x2="5.55" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.55" y1="3.375" x2="-5.55" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-4.575" y="0.025" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.65" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.65" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC01/2" urn="urn:adsk.eagle:footprint:25694/1" library_version="11">
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="-1.475" width="0.2032" layer="51"/>
<wire x1="-2.45" y1="-1.475" x2="2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="1.475" width="0.2032" layer="51"/>
<wire x1="2.45" y1="1.475" x2="-2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="1.106" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="-1.106" x2="-2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="1.106" x2="2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="-1.106" width="0.2032" layer="21"/>
<smd name="1" x="-2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<smd name="2" x="2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<text x="-2.544" y="1.904" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.176" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC2515" urn="urn:adsk.eagle:footprint:25695/1" library_version="11">
<wire x1="-3.075" y1="-1.8" x2="3.05" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.05" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="1.606" x2="3.05" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="-1.606" width="0.2032" layer="21"/>
<text x="-3.2" y="2.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.2" y="-3.4" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC4527" urn="urn:adsk.eagle:footprint:25696/1" library_version="11">
<wire x1="-5.675" y1="3.4" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.675" y1="-3.375" x2="5.675" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.675" y1="-3.375" x2="5.675" y2="3.4" width="0.2032" layer="51"/>
<wire x1="5.675" y1="3.4" x2="-5.675" y2="3.4" width="0.2032" layer="21"/>
<text x="-5.775" y="3.925" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.775" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC6927" urn="urn:adsk.eagle:footprint:25697/1" library_version="11">
<wire x1="-8.65" y1="3.375" x2="-8.65" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-8.65" y1="-3.375" x2="8.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="8.65" y1="-3.375" x2="8.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="8.65" y1="3.375" x2="-8.65" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-7.95" y="0.025" dx="3.94" dy="5.97" layer="1"/>
<smd name="2" x="7.95" y="0" dx="3.94" dy="5.97" layer="1"/>
<text x="-8.75" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.75" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1218" urn="urn:adsk.eagle:footprint:25698/1" library_version="11">
<description>&lt;b&gt;CRCW1218 Thick Film, Rectangular Chip Resistors&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com .. dcrcw.pdf</description>
<wire x1="-0.913" y1="-2.219" x2="0.939" y2="-2.219" width="0.1524" layer="51"/>
<wire x1="0.913" y1="2.219" x2="-0.939" y2="2.219" width="0.1524" layer="51"/>
<smd name="1" x="-1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<smd name="2" x="1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.3" x2="-0.9009" y2="2.3" layer="51"/>
<rectangle x1="0.9144" y1="-2.3" x2="1.6645" y2="2.3" layer="51"/>
</package>
<package name="1812X7R" urn="urn:adsk.eagle:footprint:25699/1" library_version="11">
<description>&lt;b&gt;Chip Monolithic Ceramic Capacitors&lt;/b&gt; Medium Voltage High Capacitance for General Use&lt;p&gt;
Source: http://www.murata.com .. GRM43DR72E224KW01.pdf</description>
<wire x1="-1.1" y1="1.5" x2="1.1" y2="1.5" width="0.2032" layer="51"/>
<wire x1="1.1" y1="-1.5" x2="-1.1" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="-0.6" y1="1.5" x2="0.6" y2="1.5" width="0.2032" layer="21"/>
<wire x1="0.6" y1="-1.5" x2="-0.6" y2="-1.5" width="0.2032" layer="21"/>
<smd name="1" x="-1.425" y="0" dx="0.8" dy="3.5" layer="1"/>
<smd name="2" x="1.425" y="0" dx="0.8" dy="3.5" layer="1" rot="R180"/>
<text x="-1.9456" y="1.9958" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.9456" y="-3.7738" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.4" y1="-1.6" x2="-1.1" y2="1.6" layer="51"/>
<rectangle x1="1.1" y1="-1.6" x2="1.4" y2="1.6" layer="51" rot="R180"/>
</package>
<package name="PRL1632" urn="urn:adsk.eagle:footprint:25700/1" library_version="11">
<description>&lt;b&gt;PRL1632 are realized as 1W for 3.2 × 1.6mm(1206)&lt;/b&gt;&lt;p&gt;
Source: http://www.mouser.com/ds/2/392/products_18-2245.pdf</description>
<wire x1="0.7275" y1="-1.5228" x2="-0.7277" y2="-1.5228" width="0.1524" layer="51"/>
<wire x1="0.7275" y1="1.5228" x2="-0.7152" y2="1.5228" width="0.1524" layer="51"/>
<smd name="2" x="0.822" y="0" dx="1" dy="3.2" layer="1"/>
<smd name="1" x="-0.822" y="0" dx="1" dy="3.2" layer="1"/>
<text x="-1.4" y="1.8" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.4" y="-3" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-1.6" x2="-0.4" y2="1.6" layer="51"/>
<rectangle x1="0.4" y1="-1.6" x2="0.8" y2="1.6" layer="51"/>
</package>
<package name="R01005" urn="urn:adsk.eagle:footprint:25701/1" library_version="11">
<smd name="1" x="-0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<smd name="2" x="0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<text x="-0.4" y="0.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.4" y="-1.6" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2" y1="-0.1" x2="-0.075" y2="0.1" layer="51"/>
<rectangle x1="0.075" y1="-0.1" x2="0.2" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="0.05" x2="0.15" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="-0.1" x2="0.15" y2="-0.05" layer="51"/>
</package>
<package name="C0402" urn="urn:adsk.eagle:footprint:23121/1" library_version="11">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="C0504" urn="urn:adsk.eagle:footprint:23122/1" library_version="11">
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.294" y1="0.559" x2="0.294" y2="0.559" width="0.1016" layer="51"/>
<wire x1="-0.294" y1="-0.559" x2="0.294" y2="-0.559" width="0.1016" layer="51"/>
<smd name="1" x="-0.7" y="0" dx="1" dy="1.3" layer="1"/>
<smd name="2" x="0.7" y="0" dx="1" dy="1.3" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6604" y1="-0.6223" x2="-0.2804" y2="0.6276" layer="51"/>
<rectangle x1="0.2794" y1="-0.6223" x2="0.6594" y2="0.6276" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="C0603" urn="urn:adsk.eagle:footprint:23123/1" library_version="11">
<wire x1="-0.356" y1="0.432" x2="0.356" y2="0.432" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.419" x2="0.356" y2="-0.419" width="0.1016" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.1" dy="1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.1" dy="1" layer="1"/>
<rectangle x1="-0.8382" y1="-0.4699" x2="-0.3381" y2="0.4801" layer="51"/>
<rectangle x1="0.3302" y1="-0.4699" x2="0.8303" y2="0.4801" layer="51"/>
</package>
<package name="C0805" urn="urn:adsk.eagle:footprint:23124/1" library_version="11">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
</package>
<package name="C1206" urn="urn:adsk.eagle:footprint:23125/1" library_version="11">
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="C1210" urn="urn:adsk.eagle:footprint:23126/1" library_version="11">
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
</package>
<package name="C1310" urn="urn:adsk.eagle:footprint:23127/1" library_version="11">
<rectangle x1="-0.1001" y1="-0.3" x2="0.1001" y2="0.3" layer="35"/>
</package>
<package name="C1608" urn="urn:adsk.eagle:footprint:23128/1" library_version="11">
</package>
<package name="C1812" urn="urn:adsk.eagle:footprint:23129/1" library_version="11">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.4732" y1="1.6002" x2="1.4732" y2="1.6002" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-1.6002" x2="1.4732" y2="-1.6002" width="0.1016" layer="51"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<text x="-1.905" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3876" y1="-1.651" x2="-1.4376" y2="1.649" layer="51"/>
<rectangle x1="1.4478" y1="-1.651" x2="2.3978" y2="1.649" layer="51"/>
<rectangle x1="-0.3" y1="-0.4001" x2="0.3" y2="0.4001" layer="35"/>
</package>
<package name="C1825" urn="urn:adsk.eagle:footprint:23130/1" library_version="11">
<wire x1="-2.973" y1="3.483" x2="2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-3.483" x2="-2.973" y2="-3.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-3.483" x2="-2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="-1.4986" y1="3.2766" x2="1.4732" y2="3.2766" width="0.1016" layer="51"/>
<wire x1="-1.4732" y1="-3.2766" x2="1.4986" y2="-3.2766" width="0.1016" layer="51"/>
<wire x1="2.973" y1="3.483" x2="2.973" y2="-3.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<text x="-1.905" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.413" y1="-3.3528" x2="-1.463" y2="3.3472" layer="51"/>
<rectangle x1="1.4478" y1="-3.3528" x2="2.3978" y2="3.3472" layer="51"/>
<rectangle x1="-0.7" y1="-0.7" x2="0.7" y2="0.7" layer="35"/>
</package>
<package name="C2012" urn="urn:adsk.eagle:footprint:23131/1" library_version="11">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
</package>
<package name="C3216" urn="urn:adsk.eagle:footprint:23132/1" library_version="11">
<rectangle x1="-0.3" y1="-0.5001" x2="0.3" y2="0.5001" layer="35"/>
</package>
<package name="C3225" urn="urn:adsk.eagle:footprint:23133/1" library_version="11">
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="C4532" urn="urn:adsk.eagle:footprint:23134/1" library_version="11">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="C4564" urn="urn:adsk.eagle:footprint:23135/1" library_version="11">
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="C025-024X044" urn="urn:adsk.eagle:footprint:23136/1" library_version="11">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-025X050" urn="urn:adsk.eagle:footprint:23137/1" library_version="11">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-030X050" urn="urn:adsk.eagle:footprint:23138/1" library_version="11">
grid 2.5 mm, outline 3 x 5 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-040X050" urn="urn:adsk.eagle:footprint:23139/1" library_version="11">
grid 2.5 mm, outline 4 x 5 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-050X050" urn="urn:adsk.eagle:footprint:23140/1" library_version="11">
grid 2.5 mm, outline 5 x 5 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-060X050" urn="urn:adsk.eagle:footprint:23141/1" library_version="11">
grid 2.5 mm, outline 6 x 5 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-024X070" urn="urn:adsk.eagle:footprint:23142/1" library_version="11">
grid 2.5 mm + 5 mm, outline 2.4 x 7 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-1.143" x2="-3.9624" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-3.9624" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.635" x2="-4.191" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="0.635" x2="-4.191" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.699" y1="-0.635" x2="-4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-2.5654" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.143" x2="-2.5654" y2="-1.143" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.81" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-025X075" urn="urn:adsk.eagle:footprint:23143/1" library_version="11">
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="4.953" y1="1.016" x2="4.953" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.27" x2="4.953" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.27" x2="4.953" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.27" x2="4.699" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.762" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.254" x2="2.413" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="2.286" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="3.302" y2="0" width="0.1524" layer="51"/>
<pad name="3" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-035X075" urn="urn:adsk.eagle:footprint:23144/1" library_version="11">
grid 2.5 + 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-2.159" y1="1.778" x2="2.159" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.778" x2="-2.159" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.778" x2="2.413" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.524" x2="-2.159" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.778" x2="2.413" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.524" x2="-2.159" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="2.794" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.524" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.508" x2="2.413" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0" x2="0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-045X075" urn="urn:adsk.eagle:footprint:23145/1" library_version="11">
grid 2.5 + 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.032" x2="4.953" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.286" x2="4.953" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.286" x2="4.953" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.286" x2="4.699" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.286" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.397" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.762" x2="2.413" y2="-0.762" width="0.1524" layer="21"/>
<text x="-2.286" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C025_050-055X075" urn="urn:adsk.eagle:footprint:23146/1" library_version="11">
grid 2.5 + 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.794" x2="4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.794" x2="4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.794" x2="4.699" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.794" x2="2.794" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-2.032" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<text x="-2.286" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-024X044" urn="urn:adsk.eagle:footprint:23147/1" library_version="11">
grid 5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.159" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-2.159" y2="0.381" layer="51"/>
</package>
<package name="C050-025X075" urn="urn:adsk.eagle:footprint:23148/1" library_version="11">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-045X075" urn="urn:adsk.eagle:footprint:23149/1" library_version="11">
grid 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-030X075" urn="urn:adsk.eagle:footprint:23150/1" library_version="11">
grid 5 mm, outline 3 x 7.5 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-050X075" urn="urn:adsk.eagle:footprint:23151/1" library_version="11">
grid 5 mm, outline 5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-055X075" urn="urn:adsk.eagle:footprint:23152/1" library_version="11">
grid 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-075X075" urn="urn:adsk.eagle:footprint:23153/1" library_version="11">
grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050H075X075" urn="urn:adsk.eagle:footprint:23154/1" library_version="11">
Horizontal, grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-3.683" y1="7.112" x2="-3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0.508" x2="-3.302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.508" x2="-1.778" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="0.508" x2="1.778" y2="0.508" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.508" x2="3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.683" y1="0.508" x2="3.683" y2="7.112" width="0.1524" layer="21"/>
<wire x1="3.175" y1="7.62" x2="-3.175" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="2.413" x2="-0.3048" y2="1.778" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-0.3048" y2="1.143" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="2.413" x2="0.3302" y2="1.778" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="0.3302" y2="1.143" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="7.112" x2="-3.175" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.175" y1="7.62" x2="3.683" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="0.254" width="0.508" layer="51"/>
<wire x1="2.54" y1="0" x2="2.54" y2="0.254" width="0.508" layer="51"/>
<text x="-3.302" y="8.001" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="0.127" x2="-2.286" y2="0.508" layer="51"/>
<rectangle x1="2.286" y1="0.127" x2="2.794" y2="0.508" layer="51"/>
</package>
<package name="C075-032X103" urn="urn:adsk.eagle:footprint:23155/1" library_version="11">
grid 7.5 mm, outline 3.2 x 10.3 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" shape="octagon"/>
<text x="-4.826" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-042X103" urn="urn:adsk.eagle:footprint:23156/1" library_version="11">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<text x="-4.699" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-052X106" urn="urn:adsk.eagle:footprint:23157/1" library_version="11">
grid 7.5 mm, outline 5.2 x 10.6 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-043X133" urn="urn:adsk.eagle:footprint:23158/1" library_version="11">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-054X133" urn="urn:adsk.eagle:footprint:23159/1" library_version="11">
grid 10.2 mm, outline 5.4 x 13.3 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-064X133" urn="urn:adsk.eagle:footprint:23160/1" library_version="11">
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102_152-062X184" urn="urn:adsk.eagle:footprint:23161/1" library_version="11">
grid 10.2 mm + 15.2 mm, outline 6.2 x 18.4 mm</description>
<wire x1="-3.683" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="6.477" y1="0" x2="8.636" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="3.048" x2="6.223" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.048" x2="6.731" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.223" y1="-3.048" x2="6.731" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.54" x2="6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.176" y1="3.048" x2="11.684" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="11.176" y1="-3.048" x2="11.684" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="11.176" y1="-3.048" x2="7.112" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="7.112" y1="3.048" x2="11.176" y2="3.048" width="0.1524" layer="21"/>
<wire x1="11.684" y1="2.54" x2="11.684" y2="-2.54" width="0.1524" layer="21"/>
<pad name="3" x="10.033" y="0" drill="1.016" shape="octagon"/>
<text x="-5.969" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-054X183" urn="urn:adsk.eagle:footprint:23162/1" library_version="11">
grid 15 mm, outline 5.4 x 18.3 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" shape="octagon"/>
<text x="-8.382" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-064X183" urn="urn:adsk.eagle:footprint:23163/1" library_version="11">
grid 15 mm, outline 6.4 x 18.3 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C150-072X183" urn="urn:adsk.eagle:footprint:23164/1" library_version="11">
grid 15 mm, outline 7.2 x 18.3 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-084X183" urn="urn:adsk.eagle:footprint:23165/1" library_version="11">
grid 15 mm, outline 8.4 x 18.3 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-091X182" urn="urn:adsk.eagle:footprint:23166/1" library_version="11">
grid 15 mm, outline 9.1 x 18.2 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-062X268" urn="urn:adsk.eagle:footprint:23167/1" library_version="11">
grid 22.5 mm, outline 6.2 x 26.8 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" shape="octagon"/>
<text x="-12.7" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C225-074X268" urn="urn:adsk.eagle:footprint:23168/1" library_version="11">
grid 22.5 mm, outline 7.4 x 26.8 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="3.937" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-087X268" urn="urn:adsk.eagle:footprint:23169/1" library_version="11">
grid 22.5 mm, outline 8.7 x 26.8 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="4.699" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-108X268" urn="urn:adsk.eagle:footprint:23170/1" library_version="11">
grid 22.5 mm, outline 10.8 x 26.8 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.715" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-113X268" urn="urn:adsk.eagle:footprint:23171/1" library_version="11">
grid 22.5 mm, outline 11.3 x 26.8 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-093X316" urn="urn:adsk.eagle:footprint:23172/1" library_version="11">
grid 27.5 mm, outline 9.3 x 31.6 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" shape="octagon"/>
<text x="-15.24" y="4.953" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-113X316" urn="urn:adsk.eagle:footprint:23173/1" library_version="11">
grid 27.5 mm, outline 11.3 x 31.6 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-134X316" urn="urn:adsk.eagle:footprint:23174/1" library_version="11">
grid 27.5 mm, outline 13.4 x 31.6 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-205X316" urn="urn:adsk.eagle:footprint:23175/1" library_version="11">
grid 27.5 mm, outline 20.5 x 31.6 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-137X374" urn="urn:adsk.eagle:footprint:23176/1" library_version="11">
grid 32.5 mm, outline 13.7 x 37.4 mm</description>
<wire x1="-14.2748" y1="0" x2="-12.7" y2="0" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="1.905" x2="-11.811" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="0" x2="14.2748" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.811" y1="0" x2="-11.811" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-12.7" y1="0" x2="-12.7" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="18.542" y1="6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="6.731" x2="-18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="18.542" y1="6.731" x2="-18.542" y2="6.731" width="0.1524" layer="21"/>
<pad name="1" x="-16.256" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="16.256" y="0" drill="1.1938" shape="octagon"/>
<text x="-18.2372" y="7.0612" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.8458" y="-2.8702" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-162X374" urn="urn:adsk.eagle:footprint:23177/1" library_version="11">
grid 32.5 mm, outline 16.2 x 37.4 mm</description>
<wire x1="18.542" y1="8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="8.001" x2="-18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="18.542" y1="8.001" x2="-18.542" y2="8.001" width="0.1524" layer="21"/>
<text x="-18.3642" y="8.3312" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C325-182X374" urn="urn:adsk.eagle:footprint:23178/1" library_version="11">
grid 32.5 mm, outline 18.2 x 37.4 mm</description>
<wire x1="18.542" y1="9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="9.017" x2="-18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="18.542" y1="9.017" x2="-18.542" y2="9.017" width="0.1524" layer="21"/>
<text x="-18.3642" y="9.3472" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-192X418" urn="urn:adsk.eagle:footprint:23179/1" library_version="11">
grid 37.5 mm, outline 19.2 x 41.8 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" shape="octagon"/>
<text x="-20.447" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-203X418" urn="urn:adsk.eagle:footprint:23180/1" library_version="11">
grid 37.5 mm, outline 20.3 x 41.8 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-20.32" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C050-035X075" urn="urn:adsk.eagle:footprint:23181/1" library_version="11">
grid 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C375-155X418" urn="urn:adsk.eagle:footprint:23182/1" library_version="11">
grid 37.5 mm, outline 15.5 x 41.8 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-20.447" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C075-063X106" urn="urn:adsk.eagle:footprint:23183/1" library_version="11">
grid 7.5 mm, outline 6.3 x 10.6 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C275-154X316" urn="urn:adsk.eagle:footprint:23184/1" library_version="11">
grid 27.5 mm, outline 15.4 x 31.6 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-173X316" urn="urn:adsk.eagle:footprint:23185/1" library_version="11">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 27.5 mm, outline 17.3 x 31.6 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C0402K" urn="urn:adsk.eagle:footprint:23186/1" library_version="11">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0204 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1005</description>
<wire x1="-0.425" y1="0.2" x2="0.425" y2="0.2" width="0.1016" layer="51"/>
<wire x1="0.425" y1="-0.2" x2="-0.425" y2="-0.2" width="0.1016" layer="51"/>
<smd name="1" x="-0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<smd name="2" x="0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<text x="-0.5" y="0.425" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.5" y="-1.45" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5" y1="-0.25" x2="-0.225" y2="0.25" layer="51"/>
<rectangle x1="0.225" y1="-0.25" x2="0.5" y2="0.25" layer="51"/>
</package>
<package name="C0603K" urn="urn:adsk.eagle:footprint:23187/1" library_version="11">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0603 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1608</description>
<wire x1="-0.725" y1="0.35" x2="0.725" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.725" y1="-0.35" x2="-0.725" y2="-0.35" width="0.1016" layer="51"/>
<smd name="1" x="-0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<smd name="2" x="0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<text x="-0.8" y="0.65" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.65" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.4" x2="-0.45" y2="0.4" layer="51"/>
<rectangle x1="0.45" y1="-0.4" x2="0.8" y2="0.4" layer="51"/>
</package>
<package name="C0805K" urn="urn:adsk.eagle:footprint:23188/1" library_version="11">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="1" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1" y="0.875" size="1.016" layer="25">&gt;NAME</text>
<text x="-1" y="-1.9" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
</package>
<package name="C1206K" urn="urn:adsk.eagle:footprint:23189/1" library_version="11">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
<package name="C1210K" urn="urn:adsk.eagle:footprint:23190/1" library_version="11">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1210 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3225</description>
<wire x1="-1.525" y1="1.175" x2="1.525" y2="1.175" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-1.175" x2="-1.525" y2="-1.175" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<text x="-1.6" y="1.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-1.25" x2="-1.1" y2="1.25" layer="51"/>
<rectangle x1="1.1" y1="-1.25" x2="1.6" y2="1.25" layer="51"/>
</package>
<package name="C1812K" urn="urn:adsk.eagle:footprint:23191/1" library_version="11">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1812 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4532</description>
<wire x1="-2.175" y1="1.525" x2="2.175" y2="1.525" width="0.1016" layer="51"/>
<wire x1="2.175" y1="-1.525" x2="-2.175" y2="-1.525" width="0.1016" layer="51"/>
<smd name="1" x="-2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<smd name="2" x="2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<text x="-2.25" y="1.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.25" y="-2.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.25" y1="-1.6" x2="-1.65" y2="1.6" layer="51"/>
<rectangle x1="1.65" y1="-1.6" x2="2.25" y2="1.6" layer="51"/>
</package>
<package name="C1825K" urn="urn:adsk.eagle:footprint:23192/1" library_version="11">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1825 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4564</description>
<wire x1="-1.525" y1="3.125" x2="1.525" y2="3.125" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-3.125" x2="-1.525" y2="-3.125" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<text x="-1.6" y="3.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-4.625" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-3.2" x2="-1.1" y2="3.2" layer="51"/>
<rectangle x1="1.1" y1="-3.2" x2="1.6" y2="3.2" layer="51"/>
</package>
<package name="C2220K" urn="urn:adsk.eagle:footprint:23193/1" library_version="11">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2220 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5650</description>
<wire x1="-2.725" y1="2.425" x2="2.725" y2="2.425" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-2.425" x2="-2.725" y2="-2.425" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<text x="-2.8" y="2.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-3.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-2.5" x2="-2.2" y2="2.5" layer="51"/>
<rectangle x1="2.2" y1="-2.5" x2="2.8" y2="2.5" layer="51"/>
</package>
<package name="C2225K" urn="urn:adsk.eagle:footprint:23194/1" library_version="11">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2225 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5664</description>
<wire x1="-2.725" y1="3.075" x2="2.725" y2="3.075" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-3.075" x2="-2.725" y2="-3.075" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<text x="-2.8" y="3.6" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-4.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-3.15" x2="-2.2" y2="3.15" layer="51"/>
<rectangle x1="2.2" y1="-3.15" x2="2.8" y2="3.15" layer="51"/>
</package>
<package name="HPC0201" urn="urn:adsk.eagle:footprint:25783/1" library_version="11">
<description>&lt;b&gt; &lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/10129/hpc0201a.pdf</description>
<smd name="1" x="-0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<smd name="2" x="0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<text x="-0.75" y="0.74" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.785" y="-1.865" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.305" y1="-0.15" x2="0.305" y2="0.15" layer="51"/>
</package>
<package name="C0201" urn="urn:adsk.eagle:footprint:23196/1" library_version="11">
<description>Source: http://www.avxcorp.com/docs/catalogs/cx5r.pdf</description>
<smd name="1" x="-0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<smd name="2" x="0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="0.1" x2="0.15" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="-0.1" layer="51"/>
</package>
<package name="C1808" urn="urn:adsk.eagle:footprint:23197/1" library_version="11">
Source: AVX .. aphvc.pdf</description>
<wire x1="-1.4732" y1="0.9502" x2="1.4732" y2="0.9502" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-0.9502" x2="1.4732" y2="-0.9502" width="0.1016" layer="51"/>
<smd name="1" x="-1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<text x="-2.233" y="1.827" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.233" y="-2.842" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.275" y1="-1.015" x2="-1.225" y2="1.015" layer="51"/>
<rectangle x1="1.225" y1="-1.015" x2="2.275" y2="1.015" layer="51"/>
</package>
<package name="C3640" urn="urn:adsk.eagle:footprint:23198/1" library_version="11">
<wire x1="-3.8322" y1="5.0496" x2="3.8322" y2="5.0496" width="0.1016" layer="51"/>
<wire x1="-3.8322" y1="-5.0496" x2="3.8322" y2="-5.0496" width="0.1016" layer="51"/>
<smd name="1" x="-4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<smd name="2" x="4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<text x="-4.647" y="6.465" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.647" y="-7.255" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.57" y1="-5.1" x2="-3.05" y2="5.1" layer="51"/>
<rectangle x1="3.05" y1="-5.1" x2="4.5688" y2="5.1" layer="51"/>
</package>
<package name="C01005" urn="urn:adsk.eagle:footprint:23199/1" library_version="11">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
<rectangle x1="-0.2" y1="-0.1" x2="-0.075" y2="0.1" layer="51"/>
<rectangle x1="0.075" y1="-0.1" x2="0.2" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="0.05" x2="0.15" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="-0.1" x2="0.15" y2="-0.05" layer="51"/>
<smd name="1" x="-0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<smd name="2" x="0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<text x="-0.4" y="0.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.4" y="-1.6" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RTRIM3304W" urn="urn:adsk.eagle:footprint:23235/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; BOURNS&lt;p&gt;
0,1W 25%</description>
<wire x1="-1.9" y1="1.9" x2="1.9" y2="1.9" width="0.254" layer="51"/>
<wire x1="1.9" y1="1.9" x2="1.9" y2="-1.1" width="0.254" layer="21"/>
<wire x1="1.9" y1="-1.1" x2="1.9" y2="-1.9" width="0.254" layer="51"/>
<wire x1="1.9" y1="-1.9" x2="0.65" y2="-1.9" width="0.254" layer="51"/>
<wire x1="0.65" y1="-1.9" x2="0.65" y2="-1.1" width="0.254" layer="51"/>
<wire x1="0.65" y1="-1.1" x2="-0.65" y2="-1.1" width="0.254" layer="21"/>
<wire x1="-0.65" y1="-1.1" x2="-0.65" y2="-1.9" width="0.254" layer="51"/>
<wire x1="-0.65" y1="-1.9" x2="-1.9" y2="-1.9" width="0.254" layer="51"/>
<wire x1="-1.9" y1="-1.9" x2="-1.9" y2="-1.1" width="0.254" layer="51"/>
<wire x1="-1.9" y1="-1.1" x2="-1.9" y2="1.9" width="0.254" layer="21"/>
<circle x="0" y="0.4" radius="1.2" width="0.1016" layer="51"/>
<smd name="1" x="-1.25" y="-1.9" dx="1.4" dy="1.4" layer="1"/>
<smd name="3" x="1.25" y="-1.9" dx="1.4" dy="1.4" layer="1"/>
<smd name="2" x="0" y="1.6" dx="2.5" dy="1.4" layer="1"/>
<text x="-2.29" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.545" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1" y1="0.2" x2="1" y2="0.6" layer="51"/>
<rectangle x1="-0.2" y1="-0.6" x2="0.2" y2="1.4" layer="51"/>
</package>
<package name="RTRIM3165W" urn="urn:adsk.eagle:footprint:23236/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; MEGGIT</description>
<wire x1="-1.125" y1="1.75" x2="-1.875" y2="1" width="0.254" layer="21"/>
<wire x1="-1.875" y1="1" x2="-1.875" y2="-1.375" width="0.254" layer="21"/>
<wire x1="-1.875" y1="-1.375" x2="-1.875" y2="-2.25" width="0.254" layer="51"/>
<wire x1="-1.875" y1="-2.25" x2="-1.625" y2="-2.5" width="0.254" layer="51"/>
<wire x1="-1.625" y1="-2.5" x2="-1.125" y2="-2.5" width="0.254" layer="51"/>
<wire x1="-1.125" y1="-2.5" x2="-1.125" y2="-1.625" width="0.254" layer="51"/>
<wire x1="-1.125" y1="-1.625" x2="-0.25" y2="-1.625" width="0.254" layer="51"/>
<wire x1="-0.25" y1="-1.625" x2="-0.25" y2="-2.5" width="0.254" layer="51"/>
<wire x1="-0.25" y1="-2.5" x2="0.25" y2="-2.5" width="0.254" layer="51"/>
<wire x1="0.25" y1="-2.5" x2="0.25" y2="-1.625" width="0.254" layer="51"/>
<wire x1="0.25" y1="-1.625" x2="1.125" y2="-1.625" width="0.254" layer="51"/>
<wire x1="1.125" y1="-1.625" x2="1.125" y2="-2.5" width="0.254" layer="51"/>
<wire x1="1.125" y1="-2.5" x2="1.625" y2="-2.5" width="0.254" layer="51"/>
<wire x1="1.625" y1="-2.5" x2="1.875" y2="-2.25" width="0.254" layer="51"/>
<wire x1="1.875" y1="-2.25" x2="1.875" y2="-1.625" width="0.254" layer="51"/>
<wire x1="1.875" y1="-1.625" x2="1.875" y2="1" width="0.254" layer="21"/>
<wire x1="1.875" y1="1" x2="1.125" y2="1.75" width="0.254" layer="21"/>
<wire x1="1.125" y1="1.75" x2="-1.125" y2="1.75" width="0.254" layer="51"/>
<circle x="0" y="0" radius="1.3806" width="0.1016" layer="21"/>
<smd name="1" x="-1.35" y="-2" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="0" y="-2" dx="0.8" dy="1.6" layer="1"/>
<smd name="3" x="1.35" y="-2" dx="0.8" dy="1.6" layer="1"/>
<smd name="4" x="0" y="1.8" dx="2" dy="1" layer="1"/>
<text x="-2.54" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.25" y1="-1.125" x2="0.25" y2="1.125" layer="21"/>
<rectangle x1="-1.125" y1="-0.25" x2="1.125" y2="0.25" layer="21"/>
<hole x="0" y="0" drill="2"/>
</package>
<package name="RTRIM3202" urn="urn:adsk.eagle:footprint:23233/1" library_version="11">
<wire x1="-1.6" y1="1.4" x2="-1.6" y2="-1.4" width="0.254" layer="21"/>
<wire x1="-1.6" y1="-1.4" x2="1.6" y2="-1.4" width="0.254" layer="51"/>
<wire x1="1.6" y1="-1.4" x2="1.6" y2="1.4" width="0.254" layer="21"/>
<wire x1="1.6" y1="1.4" x2="-1.6" y2="1.4" width="0.254" layer="51"/>
<wire x1="-1.6" y1="1.4" x2="-1" y2="1.4" width="0.254" layer="21"/>
<wire x1="1" y1="1.4" x2="1.6" y2="1.4" width="0.254" layer="21"/>
<wire x1="-0.3" y1="-1.4" x2="0.3" y2="-1.4" width="0.254" layer="21"/>
<circle x="0" y="0" radius="1" width="0.1016" layer="51"/>
<smd name="2" x="0" y="1.6" dx="1.6" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.75" dx="0.9" dy="1.3" layer="1"/>
<smd name="3" x="0.95" y="-1.75" dx="0.9" dy="1.3" layer="1"/>
<text x="-1.99" y="-2.39" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.26" y="-2.39" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.2" y1="-1" x2="0.2" y2="1" layer="51"/>
</package>
<package name="RTRIM3314J" urn="urn:adsk.eagle:footprint:25586/1" library_version="11">
0,25W, 20%&lt;br&gt;
Source: &lt;a href="http://www.bourns.com/pdfs/3314.pdf"&gt; Data sheet&lt;/a&gt;</description>
<wire x1="2.15" y1="2.15" x2="2.15" y2="-2.15" width="0.254" layer="51"/>
<wire x1="2.15" y1="-2.15" x2="-2.15" y2="-2.15" width="0.254" layer="51"/>
<wire x1="-2.15" y1="-2.15" x2="-2.15" y2="2.15" width="0.254" layer="51"/>
<wire x1="-2.15" y1="2.15" x2="2.15" y2="2.15" width="0.254" layer="51"/>
<wire x1="2.15" y1="-0.8" x2="2.15" y2="2.15" width="0.254" layer="21"/>
<wire x1="2.15" y1="2.15" x2="1.2" y2="2.15" width="0.254" layer="21"/>
<wire x1="-1.2" y1="2.15" x2="-2.15" y2="2.15" width="0.254" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="-2.15" y2="-0.8" width="0.254" layer="21"/>
<wire x1="0.95" y1="-2.15" x2="-0.95" y2="-2.15" width="0.254" layer="21"/>
<wire x1="-0.5" y1="-0.9" x2="0.9" y2="0.5" width="0.1016" layer="21"/>
<wire x1="-0.85" y1="-0.55" x2="0.55" y2="0.85" width="0.1016" layer="21"/>
<circle x="0" y="0" radius="1.1" width="0.1016" layer="21"/>
<smd name="3" x="-1.8" y="-2" dx="1.3" dy="2" layer="1" rot="R180"/>
<smd name="1" x="1.8" y="-2" dx="1.3" dy="2" layer="1" rot="R180"/>
<smd name="2" x="0" y="2" dx="2" dy="2" layer="1"/>
<text x="-2.64" y="-2.99" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.01" y="-2.99" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM4G/J" urn="urn:adsk.eagle:footprint:23238/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; VISHAY</description>
<wire x1="-2.4" y1="2.4" x2="-2.4" y2="-2.4" width="0.254" layer="51"/>
<wire x1="-2.4" y1="-2.4" x2="2.4" y2="-2.4" width="0.254" layer="51"/>
<wire x1="2.4" y1="-2.4" x2="2.4" y2="2.4" width="0.254" layer="51"/>
<wire x1="2.4" y1="2.4" x2="-2.4" y2="2.4" width="0.254" layer="51"/>
<wire x1="-2.1" y1="-2.4" x2="-2.4" y2="-2.4" width="0.254" layer="21"/>
<wire x1="-2.4" y1="-2.4" x2="-2.4" y2="2.4" width="0.254" layer="21"/>
<wire x1="-2.4" y1="2.4" x2="-1.25" y2="2.4" width="0.254" layer="21"/>
<wire x1="2" y1="-2.4" x2="2.4" y2="-2.4" width="0.254" layer="21"/>
<wire x1="2.4" y1="-2.4" x2="2.4" y2="2.4" width="0.254" layer="21"/>
<wire x1="2.4" y1="2.4" x2="1.25" y2="2.4" width="0.254" layer="21"/>
<wire x1="-0.25" y1="-2.4" x2="0.25" y2="-2.4" width="0.254" layer="21"/>
<circle x="0" y="0" radius="1.85" width="0.1016" layer="21"/>
<smd name="1" x="-1.15" y="-2.75" dx="1.3" dy="1.3" layer="1"/>
<smd name="3" x="1.15" y="-2.75" dx="1.3" dy="1.3" layer="1"/>
<smd name="2" x="0" y="2.75" dx="2" dy="1.3" layer="1"/>
<text x="-2.875" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.045" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.3" y1="-0.2" x2="1.35" y2="0.2" layer="21"/>
<rectangle x1="-0.2" y1="-1.35" x2="0.2" y2="1.3" layer="21"/>
</package>
<package name="RTRIMCVR42A" urn="urn:adsk.eagle:footprint:23239/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; AVX</description>
<wire x1="-1.9" y1="1.9" x2="-1.9" y2="-1.9" width="0.254" layer="51"/>
<wire x1="-1.9" y1="-1.9" x2="1.9" y2="-1.9" width="0.254" layer="51"/>
<wire x1="1.9" y1="-1.9" x2="1.9" y2="1.9" width="0.254" layer="51"/>
<wire x1="1.9" y1="1.9" x2="-1.9" y2="1.9" width="0.254" layer="51"/>
<wire x1="-0.6" y1="-1.1" x2="0.6" y2="-1.1" width="0.8128" layer="51" curve="-302.779081" cap="flat"/>
<wire x1="-1.9" y1="-1.15" x2="-1.9" y2="1.9" width="0.254" layer="21"/>
<wire x1="-1.9" y1="1.9" x2="-1.35" y2="1.9" width="0.254" layer="21"/>
<wire x1="1.9" y1="-1.15" x2="1.9" y2="1.9" width="0.254" layer="21"/>
<wire x1="1.9" y1="1.9" x2="1.35" y2="1.9" width="0.254" layer="21"/>
<smd name="2" x="0" y="1.8" dx="2.3" dy="1.5" layer="1"/>
<smd name="1" x="-1.15" y="-2.05" dx="1.3" dy="1.4" layer="1"/>
<smd name="3" x="1.15" y="-2.05" dx="1.3" dy="1.4" layer="1"/>
<text x="-2.29" y="-2.69" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.51" y="-2.69" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.65" y1="-1.15" x2="0.65" y2="-0.75" layer="51"/>
<rectangle x1="-1.05" y1="-0.15" x2="1.05" y2="0.15" layer="21"/>
</package>
<package name="RTRIM3214W" urn="urn:adsk.eagle:footprint:23240/1" library_version="11">
SMD Cermet trimmer</description>
<wire x1="-2.3" y1="-1.85" x2="-2.3" y2="1.85" width="0.254" layer="51"/>
<wire x1="-2.3" y1="1.85" x2="2.3" y2="1.85" width="0.254" layer="51"/>
<wire x1="2.3" y1="1.85" x2="2.3" y2="-1.85" width="0.254" layer="51"/>
<wire x1="2.3" y1="-1.85" x2="-2.3" y2="-1.85" width="0.254" layer="51"/>
<wire x1="-2.3" y1="-1.85" x2="-2.3" y2="1.85" width="0.254" layer="21"/>
<wire x1="-2.3" y1="1.85" x2="-1.3" y2="1.85" width="0.254" layer="21"/>
<wire x1="2.3" y1="-1.85" x2="2.3" y2="1.85" width="0.254" layer="21"/>
<wire x1="2.3" y1="1.85" x2="1.3" y2="1.85" width="0.254" layer="21"/>
<wire x1="-0.4" y1="-1.85" x2="0.4" y2="-1.85" width="0.254" layer="21"/>
<circle x="1.2" y="0.65" radius="0.7" width="0.1016" layer="51"/>
<smd name="1" x="-1.275" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<smd name="3" x="1.275" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0" y="1.45" dx="2" dy="1.6" layer="1"/>
<text x="-2.54" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="0.55" y1="0.55" x2="1.85" y2="0.75" layer="51"/>
<rectangle x1="-1.8" y1="-2.1" x2="-0.75" y2="-1.95" layer="51"/>
<rectangle x1="0.75" y1="-2.1" x2="1.8" y2="-1.95" layer="51"/>
<rectangle x1="-0.75" y1="1.95" x2="0.75" y2="2.1" layer="51"/>
</package>
<package name="RTRIM3224G" urn="urn:adsk.eagle:footprint:23241/1" library_version="11">
Side Adjust</description>
<wire x1="2.25" y1="2.15" x2="2.25" y2="-2.15" width="0.254" layer="51"/>
<wire x1="2.25" y1="-2.15" x2="-2.25" y2="-2.15" width="0.254" layer="51"/>
<wire x1="-2.25" y1="-2.15" x2="-2.25" y2="2.15" width="0.254" layer="51"/>
<wire x1="-2.25" y1="2.15" x2="2.25" y2="2.15" width="0.254" layer="51"/>
<wire x1="-0.5" y1="2.05" x2="-0.5" y2="1.35" width="0.1016" layer="51"/>
<wire x1="-0.5" y1="1.35" x2="-1.9" y2="1.35" width="0.1016" layer="51"/>
<wire x1="-1.9" y1="1.35" x2="-1.9" y2="2.05" width="0.1016" layer="51"/>
<wire x1="-1.2" y1="2.15" x2="-2.25" y2="2.15" width="0.254" layer="21"/>
<wire x1="-2.25" y1="2.15" x2="-2.25" y2="-2.15" width="0.254" layer="21"/>
<wire x1="-2.25" y1="-2.15" x2="-2" y2="-2.15" width="0.254" layer="21"/>
<wire x1="-0.3" y1="-2.15" x2="0.3" y2="-2.15" width="0.254" layer="21"/>
<wire x1="1.2" y1="2.15" x2="2.25" y2="2.15" width="0.254" layer="21"/>
<wire x1="2.25" y1="2.15" x2="2.25" y2="-2.15" width="0.254" layer="21"/>
<wire x1="2.25" y1="-2.15" x2="2" y2="-2.15" width="0.254" layer="21"/>
<circle x="-1.2" y="1.7" radius="0.2" width="0" layer="21"/>
<smd name="1" x="-1.15" y="-2.6" dx="1.27" dy="1.27" layer="1"/>
<smd name="3" x="1.15" y="-2.6" dx="1.27" dy="1.27" layer="1"/>
<smd name="2" x="0" y="2.6" dx="2" dy="1.27" layer="1"/>
<text x="-2.49" y="-3.205" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-3.205" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.65" y1="2.25" x2="0.65" y2="3" layer="51"/>
<rectangle x1="-1.6" y1="-3" x2="-0.7" y2="-2.25" layer="51"/>
<rectangle x1="0.7" y1="-3" x2="1.6" y2="-2.25" layer="51"/>
</package>
<package name="RTRIM3224J" urn="urn:adsk.eagle:footprint:23242/1" library_version="11">
<wire x1="2.4" y1="2.3" x2="2.4" y2="-2.3" width="0.254" layer="51"/>
<wire x1="2.4" y1="-2.3" x2="-2.4" y2="-2.3" width="0.254" layer="51"/>
<wire x1="-2.4" y1="-2.3" x2="-2.4" y2="2.3" width="0.254" layer="51"/>
<wire x1="-2.4" y1="2.3" x2="2.4" y2="2.3" width="0.254" layer="51"/>
<wire x1="-0.5" y1="2.2" x2="-0.5" y2="1.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-0.5" y1="1.6" x2="-1.9" y2="1.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-1.9" y1="1.6" x2="-1.9" y2="2.2" width="0.1016" layer="51" style="shortdash"/>
<wire x1="1.4" y1="2.3" x2="2.4" y2="2.3" width="0.254" layer="21" style="shortdash"/>
<wire x1="2.4" y1="2.3" x2="2.4" y2="-2.3" width="0.254" layer="21"/>
<wire x1="2.4" y1="-2.3" x2="2.2" y2="-2.3" width="0.254" layer="21"/>
<wire x1="-2.1" y1="-2.3" x2="-2.4" y2="-2.3" width="0.254" layer="21"/>
<wire x1="-2.4" y1="-2.3" x2="-2.4" y2="2.3" width="0.254" layer="21"/>
<wire x1="-2.4" y1="2.3" x2="-1.4" y2="2.3" width="0.254" layer="21"/>
<wire x1="0.2" y1="-2.3" x2="-0.2" y2="-2.3" width="0.254" layer="21"/>
<circle x="-1.2" y="1.9" radius="0.1414" width="0" layer="21"/>
<smd name="3" x="1.15" y="-2" dx="1.3" dy="2" layer="1"/>
<smd name="1" x="-1.15" y="-2" dx="1.3" dy="2" layer="1"/>
<text x="2.74" y="2.405" size="1.27" layer="25" rot="R270">&gt;NAME</text>
<text x="-4.01" y="2.405" size="1.27" layer="27" rot="R270">&gt;VALUE</text>
<rectangle x1="-0.6" y1="2.4" x2="0.6" y2="2.5" layer="51"/>
<rectangle x1="0.7" y1="-2.5" x2="1.6" y2="-2.4" layer="51"/>
<rectangle x1="-1.6" y1="-2.5" x2="-0.7" y2="-2.4" layer="51"/>
</package>
<package name="RTRIM3224X" urn="urn:adsk.eagle:footprint:23243/1" library_version="11">
Top Adjust</description>
<wire x1="-2.25" y1="-1.6" x2="-2.25" y2="1.6" width="0.254" layer="51"/>
<wire x1="-2.25" y1="1.6" x2="2.25" y2="1.6" width="0.254" layer="51"/>
<wire x1="2.25" y1="1.6" x2="2.25" y2="-1.6" width="0.254" layer="51"/>
<wire x1="2.25" y1="-1.6" x2="-2.25" y2="-1.6" width="0.254" layer="51"/>
<wire x1="-2.25" y1="-1.6" x2="-2.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="-2.25" y1="1.6" x2="-1.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="1.25" y1="1.6" x2="2.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="2.25" y1="1.6" x2="2.25" y2="-1.6" width="0.254" layer="21"/>
<wire x1="-0.4" y1="-1.6" x2="0.4" y2="-1.6" width="0.254" layer="21"/>
<circle x="1.2" y="0.6" radius="0.5" width="0.1016" layer="21"/>
<smd name="1" x="-1.27" y="-2.54" dx="1.32" dy="1.9" layer="1"/>
<smd name="3" x="1.27" y="-2.54" dx="1.32" dy="1.9" layer="1"/>
<smd name="2" x="0" y="2.54" dx="2" dy="2" layer="1"/>
<text x="-2.64" y="-3.455" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.01" y="-3.455" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.7" y1="-2.85" x2="-0.9" y2="-1.7" layer="51"/>
<rectangle x1="0.9" y1="-2.85" x2="1.7" y2="-1.7" layer="51"/>
<rectangle x1="-0.65" y1="1.7" x2="0.65" y2="2.85" layer="51"/>
<rectangle x1="0.75" y1="0.5" x2="1.65" y2="0.7" layer="21"/>
</package>
<package name="RTRIM3103" urn="urn:adsk.eagle:footprint:23232/1" library_version="11">
<wire x1="-1.45" y1="1.75" x2="-1.45" y2="-1.65" width="0.254" layer="51"/>
<wire x1="-1.45" y1="-1.65" x2="1.45" y2="-1.65" width="0.254" layer="51"/>
<wire x1="1.45" y1="-1.65" x2="1.45" y2="1.75" width="0.254" layer="51"/>
<wire x1="1.45" y1="1.75" x2="-1.45" y2="1.75" width="0.254" layer="51"/>
<wire x1="-1.45" y1="-0.4" x2="-1.45" y2="1.75" width="0.254" layer="21"/>
<wire x1="-1.45" y1="1.75" x2="-0.85" y2="1.75" width="0.254" layer="21"/>
<wire x1="1.45" y1="-0.4" x2="1.45" y2="1.75" width="0.254" layer="21"/>
<wire x1="1.45" y1="1.75" x2="0.85" y2="1.75" width="0.254" layer="21"/>
<circle x="0" y="0" radius="1.15" width="0.1016" layer="51"/>
<smd name="2" x="0" y="1.3" dx="1.3" dy="1.3" layer="1"/>
<smd name="1" x="-1" y="-1.225" dx="1.2" dy="1.25" layer="1"/>
<smd name="3" x="1" y="-1.225" dx="1.2" dy="1.25" layer="1"/>
<text x="-1.905" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.175" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.15" y1="-0.15" x2="1.15" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-1.15" x2="0.15" y2="1.15" layer="51"/>
</package>
<package name="RTRIM5W" urn="urn:adsk.eagle:footprint:23244/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; Spectrol&lt;p&gt;
abgedichtet nach &lt;b&gt;IP67&lt;/b&gt;</description>
<wire x1="2.25" y1="1.6" x2="-2.25" y2="1.6" width="0.254" layer="51"/>
<wire x1="-2.25" y1="1.6" x2="-2.25" y2="-1.6" width="0.254" layer="51"/>
<wire x1="-2.25" y1="-1.6" x2="2.25" y2="-1.6" width="0.254" layer="51"/>
<wire x1="2.25" y1="-1.6" x2="2.25" y2="1.6" width="0.254" layer="51"/>
<wire x1="-1.25" y1="1.6" x2="-2.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="-2.25" y1="1.6" x2="-2.25" y2="-1.6" width="0.254" layer="21"/>
<wire x1="-0.3" y1="-1.6" x2="0.3" y2="-1.6" width="0.254" layer="21"/>
<circle x="1.55" y="0.95" radius="0.4" width="0.1016" layer="21"/>
<smd name="1" x="-1.25" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<smd name="3" x="1.25" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<text x="-2.625" y="-2.19" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.845" y="-2.19" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="1.15" y1="0.85" x2="1.95" y2="1.05" layer="21"/>
</package>
<package name="RTRIM5X" urn="urn:adsk.eagle:footprint:23245/1" library_version="11">
<wire x1="2.35" y1="2.35" x2="-2.35" y2="2.35" width="0.254" layer="51"/>
<wire x1="-2.35" y1="2.35" x2="-2.35" y2="-2.35" width="0.254" layer="51"/>
<wire x1="-2.35" y1="-2.35" x2="2.35" y2="-2.35" width="0.254" layer="51"/>
<wire x1="2.35" y1="-2.35" x2="2.35" y2="2.35" width="0.254" layer="51"/>
<wire x1="1.25" y1="2.35" x2="2.35" y2="2.35" width="0.254" layer="21"/>
<wire x1="2.35" y1="2.35" x2="2.35" y2="-2.35" width="0.254" layer="21"/>
<wire x1="2.35" y1="-2.35" x2="2.05" y2="-2.35" width="0.254" layer="21"/>
<wire x1="-2.05" y1="-2.35" x2="-2.35" y2="-2.35" width="0.254" layer="21"/>
<wire x1="-2.35" y1="-2.35" x2="-2.35" y2="2.35" width="0.254" layer="21"/>
<wire x1="-2.35" y1="2.35" x2="-1.25" y2="2.35" width="0.254" layer="21"/>
<wire x1="0.25" y1="-2.35" x2="-0.25" y2="-2.35" width="0.254" layer="21"/>
<wire x1="-1.1" y1="2.25" x2="-1.1" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-1.1" y1="1.6" x2="-2.05" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-2.05" y1="1.6" x2="-2.05" y2="2.25" width="0.1016" layer="21"/>
<text x="-3.175" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.445" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIMTSM53YJ" urn="urn:adsk.eagle:footprint:25595/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; VISHAY&lt;p&gt;
<wire x1="-2.25" y1="1.6" x2="-1.15" y2="1.6" width="0.254" layer="21"/>
<wire x1="2.25" y1="-1.6" x2="2.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="2.25" y1="1.6" x2="1.15" y2="1.6" width="0.254" layer="21"/>
<circle x="1.3" y="0.65" radius="0.7" width="0.1016" layer="51"/>
<smd name="2" x="0" y="1.45" dx="1.8" dy="1.6" layer="1"/>
<rectangle x1="-0.3" y1="1.7" x2="0.3" y2="1.9" layer="51"/>
<rectangle x1="-1.6" y1="-1.9" x2="-1" y2="-1.7" layer="51"/>
<rectangle x1="0.95" y1="-1.9" x2="1.55" y2="-1.7" layer="51"/>
<rectangle x1="1.2" y1="0" x2="1.4" y2="1.3" layer="21"/>
</package>
<package name="RTRIMTSM53YL" urn="urn:adsk.eagle:footprint:23247/1" library_version="11">
<wire x1="-0.35" y1="-1.6" x2="0.35" y2="-1.6" width="0.254" layer="21"/>
<smd name="1" x="-1.25" y="-1.9" dx="1.3" dy="2" layer="1"/>
<smd name="3" x="1.25" y="-1.9" dx="1.3" dy="2" layer="1"/>
<smd name="2" x="0" y="1.9" dx="1.8" dy="2" layer="1"/>
<text x="-2.59" y="-2.555" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.86" y="-2.555" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3" y1="1.7" x2="0.3" y2="2.55" layer="51"/>
<rectangle x1="-1.55" y1="-2.55" x2="-0.95" y2="-1.7" layer="51"/>
<rectangle x1="0.95" y1="-2.55" x2="1.55" y2="-1.7" layer="51"/>
</package>
<package name="RTRIMTS63X" urn="urn:adsk.eagle:footprint:23248/1" library_version="11">
<description>&lt;b&gt;Trimm resistror&lt;/b&gt; VISHAY&lt;p&gt;
seales container, solder immerson IP67</description>
<wire x1="3.3" y1="2.4" x2="-3.3" y2="2.4" width="0.254" layer="51"/>
<wire x1="-3.3" y1="2.4" x2="-3.3" y2="-2.4" width="0.254" layer="51"/>
<wire x1="-3.3" y1="-2.4" x2="3.3" y2="-2.4" width="0.254" layer="51"/>
<wire x1="3.3" y1="-2.4" x2="3.3" y2="2.4" width="0.254" layer="51"/>
<wire x1="0.8" y1="2.4" x2="3.3" y2="2.4" width="0.254" layer="21"/>
<wire x1="3.3" y1="2.4" x2="3.3" y2="-2.4" width="0.254" layer="21"/>
<wire x1="-0.8" y1="2.4" x2="-3.3" y2="2.4" width="0.254" layer="21"/>
<wire x1="-3.3" y1="2.4" x2="-3.3" y2="-2.4" width="0.254" layer="21"/>
<wire x1="-1.75" y1="-2.4" x2="1.75" y2="-2.4" width="0.254" layer="21"/>
<wire x1="4.3" y1="2.25" x2="3.4" y2="2.25" width="0.1016" layer="21"/>
<wire x1="4.3" y1="0.85" x2="4.3" y2="1.35" width="0.1016" layer="21"/>
<wire x1="4.3" y1="1.35" x2="4" y2="1.35" width="0.1016" layer="21"/>
<wire x1="4" y1="1.35" x2="4" y2="1.75" width="0.1016" layer="21"/>
<wire x1="4" y1="1.75" x2="4.3" y2="1.75" width="0.1016" layer="21"/>
<wire x1="4.3" y1="1.75" x2="4.3" y2="2.25" width="0.1016" layer="21"/>
<wire x1="4.3" y1="0.85" x2="3.4" y2="0.85" width="0.1016" layer="21"/>
<smd name="1" x="-2.55" y="-2.25" dx="1" dy="3" layer="1"/>
<smd name="2" x="0" y="2.25" dx="1" dy="3" layer="1"/>
<smd name="3" x="2.55" y="-2.25" dx="1" dy="3" layer="1"/>
<text x="-3.69" y="-3.34" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="6.06" y="-3.34" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.25" y1="2.5" x2="0.25" y2="3.35" layer="51"/>
<rectangle x1="2.3" y1="-3.35" x2="2.8" y2="-2.5" layer="51"/>
<rectangle x1="-2.8" y1="-3.35" x2="-2.3" y2="-2.5" layer="51"/>
</package>
<package name="RTRIMTS63Y" urn="urn:adsk.eagle:footprint:23249/1" library_version="11">
<wire x1="3.3" y1="2.35" x2="-3.3" y2="2.35" width="0.254" layer="51"/>
<wire x1="-3.3" y1="2.35" x2="-3.3" y2="-2.35" width="0.254" layer="51"/>
<wire x1="-3.3" y1="-2.35" x2="3.3" y2="-2.35" width="0.254" layer="51"/>
<wire x1="3.3" y1="-2.35" x2="3.3" y2="2.35" width="0.254" layer="51"/>
<wire x1="0.75" y1="2.35" x2="3.3" y2="2.35" width="0.254" layer="21"/>
<wire x1="3.3" y1="2.35" x2="3.3" y2="-2.35" width="0.254" layer="21"/>
<wire x1="1.75" y1="-2.35" x2="-1.75" y2="-2.35" width="0.254" layer="21"/>
<wire x1="-3.3" y1="-2.35" x2="-3.3" y2="2.35" width="0.254" layer="21"/>
<wire x1="-3.3" y1="2.35" x2="-0.75" y2="2.35" width="0.254" layer="21"/>
<circle x="-2.15" y="1.5" radius="0.6" width="0.1016" layer="21"/>
<text x="-3.74" y="-3.69" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.21" y="-3.69" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7" y1="1.4" x2="-1.6" y2="1.6" layer="21"/>
<rectangle x1="-0.3" y1="2.45" x2="0.3" y2="3" layer="51"/>
<rectangle x1="-2.85" y1="-3" x2="-2.25" y2="-2.45" layer="51"/>
<rectangle x1="2.25" y1="-3" x2="2.85" y2="-2.45" layer="51"/>
</package>
<package name="RTRIMTS63Z" urn="urn:adsk.eagle:footprint:23250/1" library_version="11">
<wire x1="-3.3" y1="3.3" x2="-3.3" y2="-3.3" width="0.254" layer="51"/>
<wire x1="-3.3" y1="-3.3" x2="3.3" y2="-3.3" width="0.254" layer="51"/>
<wire x1="3.3" y1="-3.3" x2="3.3" y2="3.3" width="0.254" layer="51"/>
<wire x1="3.3" y1="3.3" x2="-3.3" y2="3.3" width="0.254" layer="51"/>
<wire x1="-0.75" y1="3.3" x2="-3.3" y2="3.3" width="0.254" layer="21"/>
<wire x1="-3.3" y1="3.3" x2="-3.3" y2="-3.3" width="0.254" layer="21"/>
<wire x1="-1.75" y1="-3.3" x2="1.75" y2="-3.3" width="0.254" layer="21"/>
<wire x1="3.3" y1="-3.3" x2="3.3" y2="3.3" width="0.254" layer="21"/>
<wire x1="3.3" y1="3.3" x2="0.75" y2="3.3" width="0.254" layer="21"/>
<wire x1="-2.95" y1="3.45" x2="-2.95" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-2.95" y1="4.1" x2="-2.4" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-2.4" y1="4.1" x2="-2.4" y2="3.85" width="0.1016" layer="21"/>
<wire x1="-2.4" y1="3.85" x2="-1.8" y2="3.85" width="0.1016" layer="21"/>
<wire x1="-1.8" y1="3.85" x2="-1.8" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-1.8" y1="4.1" x2="-1.25" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-1.25" y1="4.1" x2="-1.25" y2="3.4" width="0.1016" layer="21"/>
<smd name="1" x="-2.55" y="-3.15" dx="1" dy="3" layer="1"/>
<smd name="2" x="0" y="3.15" dx="1" dy="3" layer="1"/>
<smd name="3" x="2.55" y="-3.15" dx="1" dy="3" layer="1"/>
<text x="-3.84" y="-3.44" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.16" y="-3.44" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3" y1="3.4" x2="0.3" y2="4.4" layer="51"/>
<rectangle x1="-2.85" y1="-4.4" x2="-2.25" y2="-3.4" layer="51"/>
<rectangle x1="2.25" y1="-4.4" x2="2.85" y2="-3.4" layer="51"/>
</package>
<package name="RTRIM3296P" urn="urn:adsk.eagle:footprint:25600/1" library_version="11">
Source: &lt;a href="http://www.bourns.com/pdfs/3296.pdf"&gt; Data sheet &lt;/a&gt;</description>
<wire x1="4.675" y1="4.65" x2="-5.1" y2="4.65" width="0.254" layer="21"/>
<wire x1="-5.1" y1="4.65" x2="-5.1" y2="-4.65" width="0.254" layer="21"/>
<wire x1="-5.1" y1="-4.65" x2="4.675" y2="-4.65" width="0.254" layer="21"/>
<wire x1="4.675" y1="-4.65" x2="4.675" y2="4.65" width="0.254" layer="21"/>
<wire x1="4.775" y1="-1.45" x2="6.125" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="6.125" y1="-1.45" x2="6.125" y2="-2.3" width="0.1524" layer="21"/>
<wire x1="6.125" y1="-2.3" x2="5.725" y2="-2.3" width="0.1524" layer="21"/>
<wire x1="5.725" y1="-2.3" x2="5.725" y2="-2.75" width="0.1524" layer="21"/>
<wire x1="5.725" y1="-2.75" x2="6.125" y2="-2.75" width="0.1524" layer="21"/>
<wire x1="6.125" y1="-2.75" x2="6.125" y2="-3.65" width="0.1524" layer="21"/>
<wire x1="6.125" y1="-3.65" x2="4.775" y2="-3.65" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-2.54" drill="0.6096"/>
<pad name="2" x="2.54" y="0" drill="0.6096"/>
<pad name="3" x="0" y="2.54" drill="0.6096"/>
<text x="-5.48" y="-4.5" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-2.17" y="-3.45" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM3296W" urn="urn:adsk.eagle:footprint:25601/1" library_version="11">
<wire x1="-2.25" y1="4.65" x2="2.25" y2="4.65" width="0.254" layer="21"/>
<wire x1="2.25" y1="4.65" x2="2.25" y2="-4.65" width="0.254" layer="21"/>
<wire x1="2.25" y1="-4.65" x2="-2.25" y2="-4.65" width="0.254" layer="21"/>
<wire x1="-2.25" y1="-4.65" x2="-2.25" y2="4.65" width="0.254" layer="21"/>
<circle x="0" y="-2.55" radius="1.1011" width="0.1524" layer="21"/>
<pad name="2" x="0" y="0" drill="0.6096"/>
<text x="-2.65" y="-4.5" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.95" y="-4.5" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.15" y1="-3.6" x2="0.15" y2="-1.5" layer="51"/>
</package>
<package name="RTRIM3296X" urn="urn:adsk.eagle:footprint:25602/1" library_version="11">
<wire x1="-1.1" y1="4.7" x2="-1.1" y2="5.9" width="0.1524" layer="21"/>
<wire x1="-1.1" y1="5.9" x2="-0.25" y2="5.9" width="0.1524" layer="21"/>
<wire x1="-0.25" y1="5.9" x2="-0.25" y2="5.4" width="0.1524" layer="21"/>
<wire x1="-0.25" y1="5.4" x2="0.25" y2="5.4" width="0.1524" layer="21"/>
<wire x1="0.25" y1="5.4" x2="0.25" y2="5.9" width="0.1524" layer="21"/>
<wire x1="0.25" y1="5.9" x2="1.1" y2="5.9" width="0.1524" layer="21"/>
<wire x1="1.1" y1="5.9" x2="1.1" y2="4.7" width="0.1524" layer="21"/>
</package>
<package name="RTRIM3296Y" urn="urn:adsk.eagle:footprint:25603/1" library_version="11">
<circle x="0" y="-2.55" radius="1.1011" width="0.1524" layer="51"/>
<pad name="1" x="1.27" y="-2.54" drill="0.6096"/>
<pad name="2" x="-1.27" y="0" drill="0.6096"/>
<pad name="3" x="1.27" y="2.54" drill="0.6096"/>
<rectangle x1="-0.15" y1="-3.6" x2="0.15" y2="-1.5" layer="21"/>
</package>
<package name="RTRIM74W" urn="urn:adsk.eagle:footprint:23255/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; Spectrol&lt;p&gt;</description>
<wire x1="2.15" y1="-3.1" x2="2.15" y2="3.1" width="0.1524" layer="21"/>
<wire x1="2.15" y1="3.1" x2="-2" y2="3.1" width="0.1524" layer="21"/>
<wire x1="-2" y1="3.1" x2="-2" y2="-3.1" width="0.1524" layer="21"/>
<wire x1="-2" y1="-3.1" x2="2.15" y2="-3.1" width="0.1524" layer="21"/>
<circle x="1.3" y="2.25" radius="0.5522" width="0.1016" layer="21"/>
<pad name="1" x="-1.25" y="-2.5" drill="0.6096"/>
<pad name="2" x="1.25" y="0" drill="0.6096"/>
<pad name="3" x="-1.25" y="2.5" drill="0.6096"/>
<text x="-2.3" y="-3.15" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.7" y="-3.15" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="0.8" y1="2.1" x2="1.8" y2="2.4" layer="21"/>
</package>
<package name="RTRIM74X" urn="urn:adsk.eagle:footprint:23256/1" library_version="11">
<wire x1="0.75" y1="-3.15" x2="0.75" y2="-3.7" width="0.1016" layer="25"/>
<wire x1="0.75" y1="-3.7" x2="1.15" y2="-3.7" width="0.1016" layer="25"/>
<wire x1="1.15" y1="-3.7" x2="1.15" y2="-3.5" width="0.1016" layer="25"/>
<wire x1="1.15" y1="-3.5" x2="1.45" y2="-3.5" width="0.1016" layer="25"/>
<wire x1="1.45" y1="-3.5" x2="1.45" y2="-3.7" width="0.1016" layer="25"/>
<wire x1="1.45" y1="-3.7" x2="1.85" y2="-3.7" width="0.1016" layer="25"/>
<wire x1="1.85" y1="-3.7" x2="1.85" y2="-3.15" width="0.1016" layer="25"/>
</package>
<package name="RTRIM3224W" urn="urn:adsk.eagle:footprint:23257/1" library_version="11">
<wire x1="2.3" y1="1.6" x2="2.3" y2="-1.6" width="0.254" layer="51"/>
<wire x1="2.3" y1="-1.6" x2="-2.3" y2="-1.6" width="0.254" layer="51"/>
<wire x1="-2.3" y1="-1.6" x2="-2.3" y2="1.6" width="0.254" layer="51"/>
<wire x1="-2.3" y1="1.6" x2="2.3" y2="1.6" width="0.254" layer="51"/>
<wire x1="1.3" y1="1.6" x2="2.3" y2="1.6" width="0.254" layer="21"/>
<wire x1="2.3" y1="1.6" x2="2.3" y2="-1.6" width="0.254" layer="21"/>
<wire x1="2.3" y1="-1.6" x2="2.1" y2="-1.6" width="0.254" layer="21"/>
<wire x1="-2.1" y1="-1.6" x2="-2.3" y2="-1.6" width="0.254" layer="21"/>
<wire x1="-2.3" y1="-1.6" x2="-2.3" y2="1.6" width="0.254" layer="21"/>
<wire x1="-2.3" y1="1.6" x2="-1.3" y2="1.6" width="0.254" layer="21"/>
<wire x1="0.35" y1="-1.6" x2="-0.35" y2="-1.6" width="0.254" layer="21"/>
<circle x="1.2" y="0.65" radius="0.65" width="0.1016" layer="51"/>
<text x="-2.59" y="-2.255" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.86" y="-2.255" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.7" y1="1.7" x2="0.7" y2="1.95" layer="51"/>
<rectangle x1="0.85" y1="-1.95" x2="1.65" y2="-1.7" layer="51"/>
<rectangle x1="-1.65" y1="-1.95" x2="-0.85" y2="-1.7" layer="51"/>
<rectangle x1="0.6" y1="0.55" x2="1.8" y2="0.75" layer="51"/>
</package>
<package name="RTRIM3339P" urn="urn:adsk.eagle:footprint:23258/1" library_version="11">
Cermet MIL-R-22097</description>
<circle x="0" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.4199" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.6096"/>
<pad name="2" x="0" y="-2.54" drill="0.6096"/>
<pad name="3" x="2.54" y="0" drill="0.6096"/>
<text x="-2.515" y="4.205" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.515" y="-5.605" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.016" y1="-0.254" x2="1.016" y2="0.254" layer="21"/>
<rectangle x1="-0.254" y1="-1.016" x2="0.254" y2="1.016" layer="21"/>
</package>
<package name="RTRIM64P" urn="urn:adsk.eagle:footprint:23259/1" library_version="11">
<wire x1="-4.15" y1="4.8" x2="4.8" y2="4.8" width="0.254" layer="21"/>
<wire x1="4.8" y1="4.8" x2="4.8" y2="-4.8" width="0.254" layer="21"/>
<wire x1="4.8" y1="-4.8" x2="-4.15" y2="-4.8" width="0.254" layer="21"/>
<wire x1="-4.8" y1="-3.9" x2="-4.15" y2="-3.25" width="0.254" layer="21"/>
<wire x1="-4.15" y1="-3.25" x2="-4.15" y2="3.25" width="0.254" layer="21"/>
<wire x1="-4.15" y1="3.25" x2="-4.8" y2="3.9" width="0.254" layer="21"/>
<wire x1="-4.8" y1="3.9" x2="-4.8" y2="4.15" width="0.254" layer="21"/>
<wire x1="-4.8" y1="4.15" x2="-4.15" y2="4.8" width="0.254" layer="21"/>
<wire x1="4.95" y1="-2.25" x2="6.15" y2="-2.25" width="0.1524" layer="21"/>
<wire x1="6.15" y1="-2.25" x2="6.15" y2="-3.05" width="0.1524" layer="21"/>
<wire x1="6.15" y1="-3.05" x2="5.7" y2="-3.05" width="0.1524" layer="21"/>
<wire x1="5.7" y1="-3.05" x2="5.7" y2="-3.6" width="0.1524" layer="21"/>
<wire x1="5.7" y1="-3.6" x2="6.15" y2="-3.6" width="0.1524" layer="21"/>
<wire x1="6.15" y1="-3.6" x2="6.15" y2="-4.45" width="0.1524" layer="21"/>
<wire x1="6.15" y1="-4.45" x2="4.95" y2="-4.45" width="0.1524" layer="21"/>
<wire x1="-4.8" y1="-4.15" x2="-4.8" y2="-3.9" width="0.254" layer="21"/>
<wire x1="-4.15" y1="-4.8" x2="-4.8" y2="-4.15" width="0.254" layer="21"/>
<text x="-4.75" y="-2.65" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-1.65" y="-3.2" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM64W" urn="urn:adsk.eagle:footprint:23260/1" library_version="11">
<wire x1="2.52" y1="-4.8" x2="-2.03" y2="-4.8" width="0.254" layer="21"/>
<wire x1="-2.03" y1="-4.8" x2="-2.03" y2="4.8" width="0.254" layer="21"/>
<wire x1="-2.03" y1="4.8" x2="2.52" y2="4.8" width="0.254" layer="21"/>
<wire x1="2.52" y1="4.8" x2="2.52" y2="3.2" width="0.254" layer="21"/>
<wire x1="2.52" y1="3.2" x2="2.27" y2="3.2" width="0.254" layer="21"/>
<wire x1="2.27" y1="3.2" x2="2.27" y2="-3.2" width="0.254" layer="21"/>
<wire x1="2.27" y1="-3.2" x2="2.52" y2="-3.2" width="0.254" layer="21"/>
<wire x1="2.52" y1="-3.2" x2="2.52" y2="-4.8" width="0.254" layer="21"/>
<circle x="-0.58" y="3.3" radius="1.1" width="0.1524" layer="21"/>
<pad name="2" x="1.27" y="0" drill="0.6096"/>
<text x="-2.62" y="-4.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.35" y="-4.95" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.78" y1="2.25" x2="-0.38" y2="4.35" layer="21"/>
</package>
<package name="RTRIM64X" urn="urn:adsk.eagle:footprint:23261/1" library_version="11">
<wire x1="-1.83" y1="4.95" x2="-1.83" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-1.83" y1="6.15" x2="-1.03" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-1.03" y1="6.15" x2="-1.03" y2="5.7" width="0.1524" layer="21"/>
<wire x1="-1.03" y1="5.7" x2="-0.48" y2="5.7" width="0.1524" layer="21"/>
<wire x1="-0.48" y1="5.7" x2="-0.48" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-0.48" y1="6.15" x2="0.37" y2="6.15" width="0.1524" layer="21"/>
<wire x1="0.37" y1="6.15" x2="0.37" y2="4.95" width="0.1524" layer="21"/>
<text x="-2.43" y="-4.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="0.07" y="-3.4" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM64Y" urn="urn:adsk.eagle:footprint:23262/1" library_version="11">
<wire x1="1.05" y1="-4.8" x2="-3.3" y2="-4.8" width="0.254" layer="21"/>
<wire x1="-3.3" y1="-4.8" x2="-3.3" y2="4.8" width="0.254" layer="21"/>
<wire x1="-3.3" y1="4.8" x2="1.05" y2="4.8" width="0.254" layer="21"/>
<wire x1="1.05" y1="4.8" x2="1.05" y2="3.2" width="0.254" layer="21"/>
<wire x1="1.05" y1="3.2" x2="0.8" y2="3.2" width="0.254" layer="21"/>
<wire x1="0.8" y1="3.2" x2="0.8" y2="-3.2" width="0.254" layer="21"/>
<wire x1="0.8" y1="-3.2" x2="1.05" y2="-3.2" width="0.254" layer="21"/>
<wire x1="1.05" y1="-3.2" x2="1.05" y2="-4.8" width="0.254" layer="21"/>
<circle x="-1.9" y="-3.35" radius="1.1" width="0.1524" layer="21"/>
<pad name="2" x="-2.54" y="0" drill="0.6096"/>
<text x="-3.84" y="-4.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.75" y="-4.95" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1" y1="-4.4" x2="-1.7" y2="-2.3" layer="21"/>
</package>
<package name="RTRIM64Z" urn="urn:adsk.eagle:footprint:23263/1" library_version="11">
<wire x1="-3.1" y1="4.95" x2="-3.1" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-3.1" y1="6.15" x2="-2.3" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-2.3" y1="6.15" x2="-2.3" y2="5.7" width="0.1524" layer="21"/>
<wire x1="-2.3" y1="5.7" x2="-1.75" y2="5.7" width="0.1524" layer="21"/>
<wire x1="-1.75" y1="5.7" x2="-1.75" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-1.75" y1="6.15" x2="-0.9" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-0.9" y1="6.15" x2="-0.9" y2="4.95" width="0.1524" layer="21"/>
<text x="-3.65" y="-4.9" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.69" y="-4.92" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM3059Y" urn="urn:adsk.eagle:footprint:23264/1" library_version="11">
waschfest MIL-R-22097</description>
<wire x1="-16.37" y1="2.2" x2="-16.37" y2="-2.2" width="0.254" layer="21"/>
<wire x1="-16.37" y1="-2.2" x2="-6.69" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.81" y1="-2.2" x2="15.36" y2="-2.2" width="0.254" layer="21"/>
<wire x1="15.36" y1="-2.2" x2="15.36" y2="2.2" width="0.254" layer="21"/>
<wire x1="15.36" y1="2.2" x2="8.81" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.81" y1="2.2" x2="8.71" y2="2.1" width="0.254" layer="21"/>
<wire x1="8.71" y1="2.1" x2="-6.59" y2="2.1" width="0.254" layer="21"/>
<wire x1="-6.59" y1="2.1" x2="-6.69" y2="2.2" width="0.254" layer="21"/>
<wire x1="-6.69" y1="2.2" x2="-16.37" y2="2.2" width="0.254" layer="21"/>
<wire x1="15.46" y1="1.35" x2="16.91" y2="1.35" width="0.1524" layer="21"/>
<wire x1="16.91" y1="1.35" x2="16.91" y2="0.35" width="0.1524" layer="21"/>
<wire x1="16.91" y1="0.35" x2="16.41" y2="0.35" width="0.1524" layer="21"/>
<wire x1="16.41" y1="0.35" x2="16.41" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="16.41" y1="-0.35" x2="16.91" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="16.91" y1="-0.35" x2="16.91" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="16.91" y1="-1.35" x2="15.46" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="-6.59" y1="-2.1" x2="-6.69" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.71" y1="-2.1" x2="8.81" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.71" y1="-2.1" x2="-6.59" y2="-2.1" width="0.254" layer="21"/>
<pad name="1" x="-6.35" y="1.27" drill="0.9"/>
<pad name="2" x="3.81" y="-1.27" drill="0.9"/>
<pad name="3" x="8.89" y="1.27" drill="0.9"/>
<text x="-16.32" y="2.7" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.49" y="0" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RTRIM70Y" urn="urn:adsk.eagle:footprint:23265/1" library_version="11">
</package>
<package name="RTRIM3374" urn="urn:adsk.eagle:footprint:23234/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; BOURNS</description>
<wire x1="-1.9" y1="2.35" x2="1.9" y2="2.35" width="0.254" layer="51"/>
<wire x1="1.9" y1="2.35" x2="1.9" y2="-2.35" width="0.254" layer="51"/>
<wire x1="1.9" y1="-2.35" x2="0.6" y2="-2.35" width="0.254" layer="51"/>
<wire x1="0.6" y1="-2.35" x2="0.6" y2="-2.15" width="0.254" layer="51"/>
<wire x1="0.6" y1="-2.15" x2="-0.6" y2="-2.15" width="0.254" layer="51"/>
<wire x1="-0.6" y1="-2.15" x2="-0.6" y2="-2.35" width="0.254" layer="51"/>
<wire x1="-0.6" y1="-2.35" x2="-1.9" y2="-2.35" width="0.254" layer="51"/>
<wire x1="-1.9" y1="-2.35" x2="-1.9" y2="2.35" width="0.254" layer="51"/>
<wire x1="-0.25" y1="-2.15" x2="0.25" y2="-2.15" width="0.254" layer="21"/>
<wire x1="-1.9" y1="-1.15" x2="-1.9" y2="2.35" width="0.254" layer="21"/>
<wire x1="-1.9" y1="2.35" x2="-1.2" y2="2.35" width="0.254" layer="21"/>
<wire x1="1.2" y1="2.35" x2="1.9" y2="2.35" width="0.254" layer="21"/>
<wire x1="1.9" y1="2.35" x2="1.9" y2="-1.15" width="0.254" layer="21"/>
<circle x="0" y="0" radius="1.65" width="0.1524" layer="51"/>
<smd name="2" x="0" y="2.1" dx="1.98" dy="2.17" layer="1"/>
<smd name="1" x="-1.25" y="-2.5" dx="1.5" dy="2.2" layer="1"/>
<smd name="3" x="1.25" y="-2.5" dx="1.5" dy="2.2" layer="1"/>
<text x="-2.2" y="-2.5" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.55" y="-2.5" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.25" y1="-1.3" x2="0.25" y2="1.3" layer="51"/>
<rectangle x1="-1.3" y1="-0.2" x2="1.3" y2="0.3" layer="51"/>
</package>
<package name="RTRIM3299W" urn="urn:adsk.eagle:footprint:23266/1" library_version="11">
<wire x1="-2.78" y1="4.35" x2="3.07" y2="4.35" width="0.254" layer="21"/>
<wire x1="3.07" y1="4.35" x2="3.07" y2="-4.35" width="0.254" layer="21"/>
<wire x1="3.07" y1="-4.35" x2="-2.78" y2="-4.35" width="0.254" layer="21"/>
<wire x1="-2.78" y1="-4.35" x2="-2.78" y2="4.35" width="0.254" layer="21"/>
<circle x="-1.23" y="2.75" radius="1.1011" width="0.1524" layer="21"/>
<text x="-3.38" y="-4.5" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.77" y="-4.5" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.38" y1="1.7" x2="-1.08" y2="3.8" layer="21"/>
</package>
<package name="RTRIM43P" urn="urn:adsk.eagle:footprint:23267/1" library_version="11">
<wire x1="-9.2" y1="2.2" x2="-9.2" y2="-2.2" width="0.254" layer="21"/>
<wire x1="-9.2" y1="-2.2" x2="8.1" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="-2.2" x2="8.1" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="2.2" x2="-9.2" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.2" y1="1.35" x2="9.65" y2="1.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="1.35" x2="9.65" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="0.35" x2="9.15" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.15" y1="0.35" x2="9.15" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.15" y1="-0.35" x2="9.65" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="-0.35" x2="9.65" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="-1.35" x2="8.2" y2="-1.35" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="1.27" drill="0.9"/>
<pad name="2" x="0" y="-1.27" drill="0.9"/>
<pad name="3" x="5.08" y="1.27" drill="0.9"/>
<text x="-9.15" y="2.7" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.3" y="0" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RTRIM3006P" urn="urn:adsk.eagle:footprint:23268/1" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; BOURNS&lt;p&gt;</description>
<wire x1="-10.6" y1="2.25" x2="-10.6" y2="-2.25" width="0.254" layer="21"/>
<wire x1="-10.6" y1="-2.25" x2="8.25" y2="-2.25" width="0.254" layer="21"/>
<wire x1="8.25" y1="-2.25" x2="8.25" y2="2.25" width="0.254" layer="21"/>
<wire x1="8.25" y1="2.25" x2="-10.6" y2="2.25" width="0.254" layer="21"/>
<wire x1="8.35" y1="1.35" x2="9.8" y2="1.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="1.35" x2="9.8" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="0.35" x2="9.3" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.3" y1="0.35" x2="9.3" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.3" y1="-0.35" x2="9.8" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="-0.35" x2="9.8" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="-1.35" x2="8.35" y2="-1.35" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="1.27" drill="0.6096"/>
<pad name="2" x="0" y="-1.27" drill="0.6096"/>
<pad name="3" x="5.08" y="1.27" drill="0.6096"/>
<text x="-10.7" y="2.7" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.05" y="-1.65" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RTRIMT18" urn="urn:adsk.eagle:footprint:23269/1" library_version="11">
abgedichtet nach IP67</description>
<wire x1="-10.75" y1="2.2" x2="-10.75" y2="-2.2" width="0.254" layer="21"/>
<wire x1="-10.75" y1="-2.2" x2="8.1" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="2.2" x2="-10.75" y2="2.2" width="0.254" layer="21"/>
<text x="-10.2" y="-1.65" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RTRIMT93XA" urn="urn:adsk.eagle:footprint:23270/1" library_version="11">
Cermet, abgedichtet nach IP67</description>
<wire x1="2.15" y1="-4.75" x2="2.15" y2="4.75" width="0.254" layer="21"/>
<wire x1="2.15" y1="4.75" x2="-2.55" y2="4.75" width="0.254" layer="21"/>
<wire x1="-2.55" y1="4.75" x2="-2.55" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-2.55" y1="-4.75" x2="2.15" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-0.3" y1="4.9" x2="-0.3" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-0.3" y1="6.05" x2="-1.1" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-1.1" y1="6.05" x2="-1.1" y2="5.85" width="0.1524" layer="21"/>
<wire x1="-1.1" y1="5.85" x2="-1.5" y2="5.85" width="0.1524" layer="21"/>
<wire x1="-1.5" y1="5.85" x2="-1.5" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-1.5" y1="6.05" x2="-2.3" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-2.3" y1="6.05" x2="-2.3" y2="4.9" width="0.1524" layer="21"/>
<text x="-3.04" y="-4.89" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.01" y="-4.89" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIMT93XB" urn="urn:adsk.eagle:footprint:23271/1" library_version="11">
<wire x1="2.35" y1="-4.75" x2="2.35" y2="4.75" width="0.254" layer="21"/>
<wire x1="2.35" y1="4.75" x2="-2.35" y2="4.75" width="0.254" layer="21"/>
<wire x1="-2.35" y1="4.75" x2="-2.35" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-2.35" y1="-4.75" x2="2.35" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-0.1" y1="4.9" x2="-0.1" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-0.1" y1="6.05" x2="-0.9" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-0.9" y1="6.05" x2="-0.9" y2="5.85" width="0.1524" layer="21"/>
<wire x1="-0.9" y1="5.85" x2="-1.3" y2="5.85" width="0.1524" layer="21"/>
<wire x1="-1.3" y1="5.85" x2="-1.3" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-1.3" y1="6.05" x2="-2.1" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-2.1" y1="6.05" x2="-2.1" y2="4.9" width="0.1524" layer="21"/>
<text x="-2.79" y="-4.89" size="1.27" layer="25" rot="R90">&gt;NAME</text>
</package>
<package name="RTRIMT93YA" urn="urn:adsk.eagle:footprint:23272/1" library_version="11">
<wire x1="-0.75" y1="2.6" x2="-0.3" y2="3.3" width="0.1524" layer="21" curve="-311.390901"/>
<wire x1="-0.75" y1="2.6" x2="-0.3" y2="3.3" width="0.1524" layer="51" curve="48.609099"/>
<rectangle x1="-1.45" y1="2.5" x2="-1.15" y2="4.4" layer="21"/>
</package>
<package name="RTRIMT93YB" urn="urn:adsk.eagle:footprint:23273/1" library_version="11">
<circle x="-1.05" y="3.45" radius="1.0049" width="0.1524" layer="21"/>
<rectangle x1="-1.2" y1="2.5" x2="-0.9" y2="4.4" layer="21"/>
</package>
<package name="RTRIM3314G" urn="urn:adsk.eagle:footprint:25623/1" library_version="11">
<wire x1="2.15" y1="-2.15" x2="2.15" y2="2.15" width="0.254" layer="21"/>
<wire x1="2.15" y1="2.15" x2="1.3" y2="2.15" width="0.254" layer="21"/>
<wire x1="-1.3" y1="2.15" x2="-2.15" y2="2.15" width="0.254" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="-2.15" y2="-2.15" width="0.254" layer="21"/>
<wire x1="0.1" y1="-2.15" x2="-0.1" y2="-2.15" width="0.254" layer="21"/>
<smd name="3" x="-1.15" y="-2.75" dx="1.3" dy="1.3" layer="1" rot="R180"/>
<smd name="1" x="1.15" y="-2.75" dx="1.3" dy="1.3" layer="1" rot="R180"/>
</package>
<package name="CT3216" urn="urn:adsk.eagle:footprint:22802/1" library_version="11">
<description>&lt;b&gt;TANTALUM CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.973" y1="1.483" x2="2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.483" x2="-2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.483" x2="-2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.483" x2="2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-1.651" y1="0.559" x2="-1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="1.651" y1="0.559" x2="1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="-1.535" y1="0.798" x2="-1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="-1.535" y1="-0.798" x2="1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="-0.798" x2="1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="0.798" x2="-1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="0" x2="-1.26" y2="0" width="0.2032" layer="51"/>
<wire x1="-0.97" y1="0.26" x2="-0.97" y2="-0.3" width="0.2032" layer="51"/>
<smd name="+" x="-1.4" y="0" dx="2" dy="1.2" layer="1"/>
<smd name="-" x="1.4" y="0" dx="2" dy="1.2" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="CT3528" urn="urn:adsk.eagle:footprint:22803/1" library_version="11">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-1.637" y1="-1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="-1.637" y2="-1.383" width="0.2032" layer="51"/>
<wire x1="1.778" y1="1.016" x2="1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-0.68" y1="0" x2="-1.31" y2="0" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.3" x2="-1" y2="-0.33" width="0.2032" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="2" dy="2.2" layer="1"/>
<smd name="-" x="1.5" y="0" dx="2" dy="2.2" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="CT6032" urn="urn:adsk.eagle:footprint:22804/1" library_version="11">
<wire x1="-4.473" y1="1.983" x2="4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.983" x2="-4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.983" x2="-4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.983" x2="4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.932" y1="-1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-3.073" y1="1.067" x2="-3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="-2.932" y2="-1.637" width="0.2032" layer="51"/>
<wire x1="3.073" y1="1.067" x2="3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="2.957" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-1.18" y1="0" x2="-2.45" y2="0" width="0.2032" layer="51"/>
<wire x1="-1.8" y1="0.63" x2="-1.8" y2="-0.64" width="0.2032" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="CT7343" urn="urn:adsk.eagle:footprint:22807/1" library_version="11">
<wire x1="-4.973" y1="2.483" x2="4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="-2.483" x2="-4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-4.973" y1="-2.483" x2="-4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="2.483" x2="4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-3.592" y1="-2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-3.734" y1="1.143" x2="-3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="-3.592" y2="-2.195" width="0.2032" layer="51"/>
<wire x1="3.734" y1="1.143" x2="3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="3.582" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-2.04" y1="0" x2="-3.09" y2="0" width="0.2032" layer="51"/>
<wire x1="-2.55" y1="0.52" x2="-2.55" y2="-0.52" width="0.2032" layer="51"/>
<smd name="+" x="-3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<smd name="-" x="3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="B45181A" urn="urn:adsk.eagle:footprint:22805/1" library_version="11">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
body 5 x 5 mm, rectangle, grid 2.54 mm</description>
<wire x1="2.032" y1="2.286" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.905" x2="2.413" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-2.286" x2="2.032" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.6764" x2="-1.778" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-1.4478" y1="1.3716" x2="-2.1082" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.286" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.032" y1="2.286" x2="2.413" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.032" y1="-2.286" x2="2.413" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.905" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="B45181B" urn="urn:adsk.eagle:footprint:22806/1" library_version="11">
body 7.6 x 5 mm, rectangle, grid 5.08 mm</description>
<wire x1="3.302" y1="2.413" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="3.683" y1="2.032" x2="3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="3.302" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.413" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.302" y1="-2.413" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-2.54" y="0" drill="0.8128"/>
<pad name="-" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.921" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.191" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="21"/>
</package>
<package name="B45181C" urn="urn:adsk.eagle:footprint:22810/1" library_version="11">
body 12.7 x 7.6 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="3.683" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.302" x2="6.223" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.6764" x2="-4.318" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-3.9878" y1="1.3716" x2="-4.6482" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.2192" x2="-0.254" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.762" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.2192" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.683" x2="6.223" y2="3.302" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-3.683" x2="6.223" y2="-3.302" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-5.08" y="0" drill="0.9144"/>
<pad name="-" x="5.08" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.334" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="B45181D" urn="urn:adsk.eagle:footprint:22816/1" library_version="11">
body 12.5 x 12.5 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.223" y1="5.842" x2="6.223" y2="-5.842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="5.842" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.223" x2="6.223" y2="5.842" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-6.223" x2="6.223" y2="-5.842" width="0.1524" layer="21" curve="90"/>
<text x="-5.08" y="6.604" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TT2D4" urn="urn:adsk.eagle:footprint:22809/1" library_version="11">
diameter 4 mm, grid 2.54 mm</description>
<wire x1="-1.016" y1="0" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.143" x2="-1.143" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.397" x2="-0.889" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<pad name="-" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128"/>
<text x="2.159" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="51"/>
</package>
<package name="TT2D4L" urn="urn:adsk.eagle:footprint:22808/1" library_version="11">
<wire x1="2.159" y1="7.747" x2="2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.016" x2="1.524" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.651" x2="-1.524" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="1.016" x2="2.159" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.762" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.429" x2="-1.016" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="3.81" x2="-1.397" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="-2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="2.159" y2="7.747" width="0.1524" layer="21" curve="-180"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="1.905" y="1.778" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="TT2D5" urn="urn:adsk.eagle:footprint:22811/1" library_version="11">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-1.27" y1="1.016" x2="-1.27" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.397" x2="-1.651" y2="1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.762" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6" urn="urn:adsk.eagle:footprint:22814/1" library_version="11">
diameter 6 mm, grid 2.54 mm</description>
<wire x1="-1.778" y1="1.524" x2="-1.016" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.143" x2="-1.397" y2="1.905" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="2.921" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.254" y="-2.286" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6L" urn="urn:adsk.eagle:footprint:22812/1" library_version="11">
<wire x1="3.048" y1="10.033" x2="3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="10.033" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.651" x2="-2.413" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.413" y1="1.016" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="10.033" x2="3.048" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<wire x1="-1.143" y1="2.413" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.413" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.524" x2="0.0762" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="1.524" x2="0.0762" y2="3.302" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="3.302" x2="-0.254" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="3.302" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.762" y1="2.413" x2="1.27" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.794" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="21"/>
<text x="-3.429" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="0.381" y1="1.4732" x2="0.8128" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7L" urn="urn:adsk.eagle:footprint:22813/1" library_version="11">
diameter 7 mm, grid 2.54 mm</description>
<wire x1="3.556" y1="10.16" x2="3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.016" x2="2.921" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-2.921" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.016" x2="3.556" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.556" y1="10.16" x2="-3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="10.16" x2="3.556" y2="10.16" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.032" y1="2.794" x2="-2.032" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="3.175" x2="-1.651" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.413" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.413" x2="-0.508" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.524" x2="-0.1778" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.524" x2="-0.1778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.302" x2="-0.508" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.302" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<text x="-3.937" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.905" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.048" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.4732" x2="0.5588" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7" urn="urn:adsk.eagle:footprint:22815/1" library_version="11">
<wire x1="-2.286" y1="0" x2="-3.048" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.556" width="0.1524" layer="21"/>
<text x="3.302" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.127" y="-2.667" size="1.27" layer="21" ratio="10">TT</text>
</package>
<package name="TT5D10" urn="urn:adsk.eagle:footprint:22817/1" library_version="11">
diameter 10 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.127" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.27" x2="-0.127" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-1.397" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.143" x2="-1.905" y2="2.159" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<text x="4.191" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.794" y="1.143" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11" urn="urn:adsk.eagle:footprint:22818/1" library_version="11">
diameter 11 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="1.651" x2="-2.286" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.159" x2="-1.778" y2="1.143" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.588" width="0.1524" layer="21"/>
<text x="4.572" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.175" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11L" urn="urn:adsk.eagle:footprint:22819/1" library_version="11">
<wire x1="-5.08" y1="12.954" x2="-5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.016" x2="4.445" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-4.445" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="4.445" y1="1.016" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="0" width="0.762" layer="21"/>
<wire x1="1.524" y1="0" x2="1.27" y2="0" width="0.762" layer="51"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="0" width="0.762" layer="21"/>
<wire x1="-1.524" y1="0" x2="-1.27" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="12.954" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="4.318" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.937" x2="-1.397" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.921" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.921" x2="-0.508" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.032" x2="-0.1778" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="2.032" x2="-0.1778" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.81" x2="-0.508" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.921" x2="1.27" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="12.954" x2="5.08" y2="12.954" width="0.1524" layer="21" curve="-180"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-5.461" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.413" y="5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="4.572" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="21"/>
<rectangle x1="1.651" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-1.651" y2="0.381" layer="51"/>
<rectangle x1="0.127" y1="1.9812" x2="0.5588" y2="3.8608" layer="21"/>
</package>
<package name="TT5D6" urn="urn:adsk.eagle:footprint:22820/1" library_version="11">
diameter 6 mm, grid 5.08 mm</description>
<wire x1="-2.908" y1="0.9307" x2="2.921" y2="0.889" width="0.1524" layer="21" curve="-145.325311"/>
<wire x1="2.8966" y1="-0.9655" x2="2.921" y2="0.889" width="0.1524" layer="51" curve="35.361865"/>
<wire x1="-2.921" y1="-0.889" x2="-2.8966" y2="0.9655" width="0.1524" layer="51" curve="-35.361865"/>
<wire x1="-2.9403" y1="-0.8232" x2="2.9211" y2="-0.889" width="0.1524" layer="21" curve="147.4323"/>
<wire x1="-1.524" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.27" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.651" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<text x="2.921" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.508" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="21"/>
</package>
<package name="TT5D6L" urn="urn:adsk.eagle:footprint:22821/1" library_version="11">
<wire x1="-1.143" y1="2.54" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.54" x2="-0.508" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.651" x2="-0.1778" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.651" x2="-0.1778" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.429" x2="-0.508" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.429" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.921" x2="-1.905" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="3.302" x2="-1.524" y2="3.302" width="0.1524" layer="21"/>
<text x="-3.429" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.524" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.6002" x2="0.5588" y2="3.4798" layer="21"/>
</package>
<package name="TT5D7" urn="urn:adsk.eagle:footprint:22822/1" library_version="11">
diameter 7 mm, grid 5.08 mm</description>
<wire x1="-2.286" y1="1.524" x2="-1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="2.032" width="0.1524" layer="21"/>
<text x="3.302" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.667" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D7L" urn="urn:adsk.eagle:footprint:22823/1" library_version="11">
<wire x1="-2.159" y1="3.683" x2="-2.159" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.302" x2="-1.778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.667" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.667" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.778" x2="-0.1778" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.778" x2="-0.1778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.556" x2="-0.508" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.556" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.667" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<text x="-3.937" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.445" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.175" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.7272" x2="0.5588" y2="3.6068" layer="21"/>
</package>
<package name="TT5D9" urn="urn:adsk.eagle:footprint:22824/1" library_version="11">
diameter 9 mm, grid 5.08 mm</description>
<wire x1="-2.794" y1="1.397" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.905" x2="-3.302" y2="0.889" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<text x="3.81" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.159" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D9L" urn="urn:adsk.eagle:footprint:22825/1" library_version="11">
<wire x1="-4.572" y1="10.033" x2="-4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.016" x2="3.937" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.651" x2="-3.937" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="3.937" y1="1.016" x2="4.572" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="10.033" x2="4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.937" x2="-1.778" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.556" x2="-1.397" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.794" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.794" x2="-0.381" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.905" x2="-0.0508" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="1.905" x2="-0.0508" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="3.683" x2="-0.381" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="3.683" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="1.397" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="10.033" x2="4.572" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<text x="-4.953" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.064" y="1.778" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.254" y1="1.8542" x2="0.6858" y2="3.7338" layer="21"/>
</package>
<package name="ETR1" urn="urn:adsk.eagle:footprint:22826/1" library_version="11">
<wire x1="2.159" y1="2.54" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.54" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.794" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.889" x2="-2.794" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.889" x2="-2.032" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.9304" x2="-1.27" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="1.6256" x2="-1.6002" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.889" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<text x="-2.032" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR2" urn="urn:adsk.eagle:footprint:22827/1" library_version="11">
<wire x1="-3.302" y1="-2.159" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.159" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.159" x2="3.302" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.81" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.762" x2="-3.81" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-0.762" x2="-3.302" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.889" x2="-1.27" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.159" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.159" width="0.1524" layer="21"/>
<text x="-3.302" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.683" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR3" urn="urn:adsk.eagle:footprint:22828/1" library_version="11">
<wire x1="-3.302" y1="-2.54" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.54" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.54" x2="3.302" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.54" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.54" width="0.1524" layer="21"/>
<text x="-3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR4" urn="urn:adsk.eagle:footprint:22829/1" library_version="11">
<wire x1="-0.762" y1="-1.0922" x2="-0.254" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.0922" x2="-0.254" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.0922" x2="-0.762" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.0922" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.81" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="5.842" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.524" x2="-6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="51"/>
<wire x1="3.683" y1="0" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.9652" x2="-1.651" y2="0.3302" width="0.1524" layer="21"/>
<wire x1="-1.3208" y1="0.635" x2="-1.9558" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-3.81" x2="5.842" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="3.81" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="0.8128"/>
<pad name="-" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-5.842" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.762" y2="1.143" layer="21"/>
</package>
<package name="ETR5" urn="urn:adsk.eagle:footprint:22830/1" library_version="11">
<wire x1="-5.842" y1="-6.1722" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.1722" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-6.1722" x2="5.842" y2="-6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-6.604" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.4986" x2="-6.604" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.4986" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.4986" x2="-5.842" y2="1.4986" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="0" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="0" x2="-1.2954" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="1.524" x2="-0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-1.2954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="-1.524" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.2954" x2="-1.905" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="0.9652" x2="-2.2352" y2="0.9652" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-6.1722" x2="5.842" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="6.1722" width="0.1524" layer="21"/>
<text x="-5.842" y="6.477" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="-1.6002" x2="0.3302" y2="1.6002" layer="21"/>
</package>
<package name="P128-35" urn="urn:adsk.eagle:footprint:25377/1" library_version="11">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="1.778" y1="2.54" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="1.397" x2="1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.635" x2="1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.635" x2="-1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="2.667" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.397" x2="-1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.762" y1="3.556" x2="-0.762" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-3.556" x2="0.762" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.016" x2="2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.159" y1="1.016" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.508" x2="-2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="1.016" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-1.016" x2="-2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.667" y2="-0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-2.667" y1="-0.508" x2="-2.667" y2="0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-1.143" y1="1.9304" x2="-1.143" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="1.6256" x2="-1.4732" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-2.54" x2="-0.762" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="-3.556" x2="1.778" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="3.556" x2="1.778" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="2.54" x2="-0.762" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<pad name="+" x="-2.667" y="0" drill="0.9144"/>
<pad name="-" x="2.667" y="0" drill="0.9144" shape="octagon"/>
<text x="-1.651" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-40" urn="urn:adsk.eagle:footprint:22832/1" library_version="11">
<wire x1="2.032" y1="2.54" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.143" x2="2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.762" x2="2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-0.762" x2="2.032" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.762" x2="-2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="2.54" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.143" x2="-2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.762" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="-1.016" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.556" x2="1.016" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.016" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.016" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="2.032" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.016" y1="-3.556" x2="2.032" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="2.54" x2="-1.016" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.032" y1="-2.54" x2="-1.016" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<text x="-2.032" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-5.207" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-50" urn="urn:adsk.eagle:footprint:22833/1" library_version="11">
<wire x1="2.54" y1="3.048" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.524" y1="4.064" x2="-1.524" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-4.064" x2="1.524" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.635" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.143" x2="-2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.143" x2="-2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.1684" x2="-1.27" y2="0.5334" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="0.8636" x2="-1.6002" y2="0.8636" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.667" y2="-0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="2.667" y1="-0.635" x2="2.667" y2="0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="1.524" y1="4.064" x2="2.54" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="3.048" x2="-1.524" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-3.048" x2="-1.524" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-4.064" x2="2.54" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<text x="-2.413" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-60" urn="urn:adsk.eagle:footprint:22834/1" library_version="11">
<wire x1="3.048" y1="3.048" x2="3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.032" y1="4.064" x2="-2.032" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.064" x2="2.032" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="3.048" x2="-3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-4.064" x2="3.048" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="3.048" x2="-2.032" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.048" y1="-3.048" x2="-2.032" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="4.064" x2="3.048" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-2.921" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TAP5-45" urn="urn:adsk.eagle:footprint:22835/1" library_version="11">
diameter 4.5 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.635" x2="-0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.635" x2="-0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.381" x2="-1.143" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.635" x2="-1.397" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.635" x2="0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.508" x2="0.3302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-1.9144" y1="-1.2492" x2="1.9144" y2="-1.2492" width="0.1524" layer="21" curve="113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="21" curve="-113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="-1.9144" y2="-1.2492" width="0.1524" layer="51" curve="66.251163"/>
<wire x1="1.9144" y1="-1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="51" curve="66.251163"/>
<text x="2.286" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.286" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-1.905" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-50" urn="urn:adsk.eagle:footprint:22836/1" library_version="11">
diameter 5.0 mm, grid 5.08 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="-1.143" y1="0.635" x2="-1.143" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.889" x2="0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.889" x2="0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.889" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.762" x2="0.3302" y2="0.762" width="0.1524" layer="21"/>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-70" urn="urn:adsk.eagle:footprint:22837/1" library_version="11">
diameter 7.0 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0.508" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.651" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.3749" y1="-1.1199" x2="3.3749" y2="-1.1199" width="0.1524" layer="21" curve="143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="21" curve="-143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="-3.3749" y2="-1.1199" width="0.1524" layer="51" curve="36.714997"/>
<wire x1="3.3749" y1="-1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="51" curve="36.714997"/>
<text x="3.175" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.413" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-60" urn="urn:adsk.eagle:footprint:22838/1" library_version="11">
diameter 6.0 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="2.921" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0" y="-2.54" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-80" urn="urn:adsk.eagle:footprint:22839/1" library_version="11">
diameter 8.0 mm, grid 5.08 mm</description>
<circle x="0" y="0" radius="4.318" width="0.1524" layer="21"/>
<text x="3.81" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.032" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="E1,8-4" urn="urn:adsk.eagle:footprint:22840/1" library_version="11">
grid 1.8 mm, diameter 4 mm</description>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="1.397" x2="-0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.143" x2="-0.762" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="-" x="0.889" y="0" drill="0.7112" diameter="1.1684" shape="octagon"/>
<pad name="+" x="-0.889" y="0" drill="0.7112" diameter="1.1684"/>
<text x="2.159" y="-1.778" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="51"/>
</package>
<package name="E15-5" urn="urn:adsk.eagle:footprint:22841/1" library_version="11">
grid 15.24 mm, diameter 5 mm</description>
<wire x1="-4.064" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-2.667" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-1.27" x2="-2.667" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.143" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="0.889" x2="-3.556" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.54" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.191" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.413" x2="-5.08" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.286" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.413" x2="5.461" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.445" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.54" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.826" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.032" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.159" x2="-4.445" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.286" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.715" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.286" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.413" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-4.318" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-2.413" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-2.4892" x2="-4.191" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.4892" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.4892" x2="-5.461" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.4892" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.2352" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.159" x2="-4.572" y2="2.159" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="6.477" y2="0" width="0.508" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.477" y2="0" width="0.508" layer="51"/>
<pad name="+" x="-7.62" y="0" drill="0.8128" diameter="2.159"/>
<pad name="-" x="7.62" y="0" drill="0.8128" diameter="2.159" shape="octagon"/>
<text x="-5.461" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.461" y="-4.1402" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.286" y1="-1.27" x2="-1.778" y2="1.27" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-5.715" y2="0.254" layer="21"/>
<rectangle x1="5.715" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
</package>
<package name="E15-6" urn="urn:adsk.eagle:footprint:22842/1" library_version="11">
grid 15.24 mm, diameter 6 mm</description>
<wire x1="-5.715" y1="-2.921" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.175" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.191" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.048" x2="-5.08" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.921" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.048" x2="5.461" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.445" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.175" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.667" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.794" x2="-4.445" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.921" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.715" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.921" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.175" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.175" x2="-5.08" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-4.318" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-3.1242" x2="-4.191" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.1242" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.1242" x2="-5.461" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.1242" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.8702" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.794" x2="-4.572" y2="2.794" width="0.3048" layer="21"/>
<text x="-5.461" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.8542" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E15-9" urn="urn:adsk.eagle:footprint:22843/1" library_version="11">
grid 15.24 mm, diameter 9 mm</description>
<wire x1="-4.445" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.27" x2="-3.048" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.27" x2="-3.048" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.27" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="5.588" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-4.191" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.572" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.572" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="4.572" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.445" x2="-5.461" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-5.461" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="4.318" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-5.207" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.445" x2="5.842" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-4.826" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.572" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-5.207" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.064" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.191" x2="-4.826" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.318" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="6.096" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-4.318" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.572" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-4.445" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.572" x2="-5.461" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.318" x2="-4.699" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-4.445" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-4.5212" x2="-4.572" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.5212" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.5212" x2="-5.842" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.5212" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.2672" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-4.953" y2="4.191" width="0.3048" layer="21"/>
<text x="-5.842" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-1.9812" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.667" y1="-1.27" x2="-2.159" y2="1.27" layer="21"/>
<rectangle x1="6.096" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-6.096" y2="0.254" layer="21"/>
</package>
<package name="E2,5-4R" urn="urn:adsk.eagle:footprint:22844/1" library_version="11">
grid 2.54 mm, diameter 4 mm</description>
<wire x1="-0.127" y1="0" x2="0.0762" y2="0" width="0.6096" layer="21"/>
<wire x1="-2.794" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="21" curve="320.718856"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="51" curve="-39.281144"/>
<text x="0.762" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.762" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-5" urn="urn:adsk.eagle:footprint:22845/1" library_version="11">
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E2,5-6" urn="urn:adsk.eagle:footprint:22846/1" library_version="11">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-7" urn="urn:adsk.eagle:footprint:22847/1" library_version="11">
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5RE" urn="urn:adsk.eagle:footprint:22848/1" library_version="11">
grid 2.54 mm, diameter 4 mm,</description>
<wire x1="0.254" y1="1.143" x2="0.254" y2="-1.143" width="0.1524" layer="21" curve="286.260205"/>
<wire x1="0.254" y1="-1.143" x2="0.254" y2="1.143" width="0.1524" layer="51" curve="73.739795"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<text x="0.635" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-4" urn="urn:adsk.eagle:footprint:22849/1" library_version="11">
grid 2 mm, diameter 4 mm</description>
<wire x1="-0.762" y1="1.524" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.27" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.889" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.159" width="0.1524" layer="21"/>
<pad name="-" x="1.016" y="0" drill="0.8128" diameter="1.27" shape="octagon"/>
<pad name="+" x="-1.016" y="0" drill="0.8128" diameter="1.27"/>
<text x="2.159" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-5" urn="urn:adsk.eagle:footprint:22850/1" library_version="11">
grid 2.032 mm, diameter 5 mm</description>
<wire x1="-1.27" y1="1.778" x2="-0.762" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.524" x2="-1.016" y2="2.032" width="0.1524" layer="21"/>
<text x="2.54" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-10" urn="urn:adsk.eagle:footprint:22851/1" library_version="11">
grid 22.86 mm, diameter 10 mm</description>
<wire x1="-6.35" y1="5.08" x2="8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="5.08" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="5.08" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-7.62" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.318" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.953" x2="8.509" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.826" x2="8.636" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.953" x2="-8.001" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.826" x2="-7.874" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.572" x2="-6.858" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.445" x2="-6.858" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.699" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-5.08" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.62" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="-6.604" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.318" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.826" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.953" x2="-8.001" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-4.572" x2="-6.858" y2="-4.572" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.953" x2="8.509" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-4.445" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-5.08" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.826" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="5.08" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.699" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.524" x2="-4.572" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.524" x2="-4.572" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.524" x2="-5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.27" x2="-5.842" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0.889" x2="-5.461" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.524" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="9.779" y2="0" width="0.762" layer="51"/>
<wire x1="-11.43" y1="0" x2="-9.779" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-11.43" y="0" drill="1.016" diameter="3.1496"/>
<pad name="-" x="11.43" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<text x="-8.509" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.7686" y="-2.3622" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="1.524" layer="21"/>
<rectangle x1="-9.779" y1="-0.381" x2="-8.89" y2="0.381" layer="21"/>
<rectangle x1="8.89" y1="-0.381" x2="9.779" y2="0.381" layer="21"/>
</package>
<package name="E22-6" urn="urn:adsk.eagle:footprint:22852/1" library_version="11">
grid 22.86 mm, diameter 6 mm</description>
<wire x1="-6.35" y1="3.175" x2="8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.175" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.175" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-7.62" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.413" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.048" x2="8.509" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="2.921" x2="8.636" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="-8.001" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="2.921" x2="-7.874" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.667" x2="-6.858" y2="2.667" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.54" x2="-6.858" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-2.794" x2="-8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.175" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.62" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="-6.604" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.413" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-2.921" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.048" x2="-8.001" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-2.667" x2="-6.858" y2="-2.667" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-3.048" x2="8.509" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.54" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.175" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-2.921" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.175" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.794" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<text x="-8.509" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.4836" y="-5.2832" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-9" urn="urn:adsk.eagle:footprint:22853/1" library_version="11">
grid 22.86 mm, diameter 9 mm</description>
<wire x1="-6.35" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.445" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-7.62" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="3.683" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.318" x2="8.509" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.191" x2="8.636" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.318" x2="-8.001" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.191" x2="-7.874" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.937" x2="-6.858" y2="3.937" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.81" x2="-6.858" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.064" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.445" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="-6.604" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="3.683" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.191" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.318" x2="-8.001" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-3.937" x2="-6.858" y2="-3.937" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.318" x2="8.509" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-3.81" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.191" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.064" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<text x="-8.509" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-10" urn="urn:adsk.eagle:footprint:22854/1" library_version="11">
grid 3.5 mm, diameter 10 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="4.064" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E25-10" urn="urn:adsk.eagle:footprint:22855/1" library_version="11">
grid 25.4 mm, diameter 10 mm</description>
<wire x1="-10.16" y1="4.826" x2="-9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="5.08" x2="-9.017" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="5.08" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.08" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="5.08" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-5.08" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="-8.001" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.826" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.572" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.953" x2="9.906" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.953" x2="-9.017" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.763" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.699" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.35" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="1.27" x2="-7.112" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0.889" x2="-6.731" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.524" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0" x2="-6.35" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.826" x2="-10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.08" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.953" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.0292" x2="-9.017" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.0292" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.763" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.7752" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.874" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="-8.001" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.747" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.0292" x2="9.906" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.953" x2="10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.699" x2="-8.128" y2="4.699" width="0.3048" layer="21"/>
<wire x1="12.7" y1="0" x2="11.049" y2="0" width="0.762" layer="51"/>
<wire x1="-12.7" y1="0" x2="-11.049" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-12.7" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="12.7" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-9.906" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.0386" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="1.524" layer="21"/>
<rectangle x1="-11.049" y1="-0.381" x2="-10.16" y2="0.381" layer="21"/>
<rectangle x1="10.16" y1="-0.381" x2="11.049" y2="0.381" layer="21"/>
</package>
<package name="E25-9" urn="urn:adsk.eagle:footprint:22856/1" library_version="11">
grid 25.4 mm, diameter 9 mm</description>
<wire x1="-10.16" y1="4.191" x2="-9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="4.445" x2="-9.017" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="4.445" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.445" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="4.445" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-4.445" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="-8.001" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.191" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="3.937" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.318" x2="9.906" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.318" x2="-9.017" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.763" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.064" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.445" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.318" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.3942" x2="-9.017" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.3942" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.763" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.1402" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.874" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="-8.001" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.747" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.3942" x2="9.906" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.318" x2="10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.064" x2="-8.128" y2="4.064" width="0.3048" layer="21"/>
<text x="-9.779" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-8" urn="urn:adsk.eagle:footprint:22857/1" library_version="11">
grid 3.5 mm, diameter 8 mm</description>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E30-10" urn="urn:adsk.eagle:footprint:22858/1" library_version="11">
grid 30.48 mm, diameter 10 mm</description>
<wire x1="12.7" y1="4.699" x2="12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="5.08" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-10.541" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.43" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-11.43" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="12.7" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="4.953" x2="-11.811" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="4.826" x2="-11.684" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.572" x2="-10.668" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.318" x2="-10.668" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="4.953" x2="12.319" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="4.826" x2="12.446" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-4.699" x2="-12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-5.08" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="-10.414" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-4.826" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-11.43" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.191" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-11.43" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-4.445" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.953" x2="12.319" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-4.953" x2="-11.811" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-4.572" x2="-10.668" y2="-4.572" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-4.699" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-5.08" x2="-10.16" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-4.826" x2="12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.7" y1="4.699" x2="12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.319" y1="5.08" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-1.524" x2="-7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.524" x2="-7.874" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="1.524" x2="-8.382" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="1.27" x2="-9.144" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0.889" x2="-8.763" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="1.524" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="0" x2="-8.382" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0" x2="13.462" y2="0" width="0.762" layer="51"/>
<wire x1="-15.24" y1="0" x2="-13.462" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-15.24" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="15.24" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-12.319" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.0706" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.366" y1="-1.524" x2="-6.858" y2="1.524" layer="21"/>
<rectangle x1="-13.462" y1="-0.381" x2="-12.7" y2="0.381" layer="21"/>
<rectangle x1="12.7" y1="-0.381" x2="13.462" y2="0.381" layer="21"/>
</package>
<package name="E30-12" urn="urn:adsk.eagle:footprint:22859/1" library_version="11">
grid 30.48 mm, diameter 12 mm</description>
<wire x1="12.7" y1="5.969" x2="12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.35" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-10.541" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.43" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-11.43" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="12.7" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.223" x2="-11.811" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="6.096" x2="-11.684" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.842" x2="-10.668" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.588" x2="-10.668" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="6.223" x2="12.319" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="6.096" x2="12.446" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-5.969" x2="-12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.35" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.35" x2="-10.414" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-6.096" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-11.43" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.461" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-11.43" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-5.715" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.223" x2="12.319" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-6.223" x2="-11.811" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-5.842" x2="-10.668" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-5.969" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-6.35" x2="-10.16" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-6.096" x2="12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.7" y1="5.969" x2="12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="12.319" y1="6.35" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<text x="-12.192" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E30-16" urn="urn:adsk.eagle:footprint:22860/1" library_version="11">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 30.48 mm, diameter 16 mm</description>
<wire x1="12.7" y1="7.747" x2="12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.128" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-10.541" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.43" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-11.43" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="12.7" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.001" x2="-11.811" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-11.684" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.62" x2="-10.668" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.366" x2="-10.668" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="8.001" x2="12.319" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="7.874" x2="12.446" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-7.62" x2="-12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-8.001" x2="-10.414" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-7.747" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-11.43" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.239" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-11.43" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-7.366" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-7.874" x2="12.319" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-7.874" x2="-11.811" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-7.493" x2="-10.668" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-7.62" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-8.001" x2="-10.16" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-7.747" x2="12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.7" y1="7.747" x2="12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="12.319" y1="8.128" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<text x="-12.319" y="8.382" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-12" urn="urn:adsk.eagle:footprint:22861/1" library_version="11">
grid 35.56 mm, diameter 12 mm</description>
<wire x1="15.24" y1="5.969" x2="15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.35" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-12.446" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.335" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-13.335" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="15.24" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.223" x2="-13.716" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="6.096" x2="-13.589" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.842" x2="-12.573" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.588" x2="-12.573" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="6.223" x2="14.859" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="6.096" x2="14.986" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-5.969" x2="-15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-6.35" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.35" x2="-12.319" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-6.096" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-13.335" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.461" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-13.335" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-5.715" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.223" x2="14.859" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-6.223" x2="-13.716" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-5.842" x2="-12.573" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-5.969" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-6.35" x2="-12.065" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-6.096" x2="14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.969" x2="14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="14.859" y1="6.35" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="-1.524" x2="-9.779" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-1.524" x2="-9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="1.524" x2="-10.287" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="1.27" x2="-11.049" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.889" x2="-10.668" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="1.524" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="0" x2="-10.287" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0" x2="14.097" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0" x2="16.002" y2="0" width="0.762" layer="51"/>
<wire x1="-17.78" y1="0" x2="-16.002" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-17.78" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="17.78" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-14.732" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.9756" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-9.271" y1="-1.524" x2="-8.763" y2="1.524" layer="21"/>
<rectangle x1="-16.129" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.129" y2="0.381" layer="21"/>
</package>
<package name="E35-14" urn="urn:adsk.eagle:footprint:22862/1" library_version="11">
grid 30.48 mm, diameter 14 mm</description>
<wire x1="15.24" y1="7.239" x2="15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.62" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-12.446" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.335" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-13.335" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="15.24" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.493" x2="-13.716" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="7.366" x2="-13.589" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.112" x2="-12.573" y2="7.112" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="6.858" x2="-12.573" y2="6.858" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="7.493" x2="14.859" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="7.366" x2="14.986" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.239" x2="-15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-7.62" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.62" x2="-12.319" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-7.366" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-13.335" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="6.731" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-13.335" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-6.985" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.493" x2="14.859" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-7.493" x2="-13.716" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.112" x2="-12.573" y2="-7.112" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.239" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-7.62" x2="-12.065" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-7.366" x2="14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.239" x2="14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="14.859" y1="7.62" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<text x="-14.859" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-16" urn="urn:adsk.eagle:footprint:22863/1" library_version="11">
<wire x1="15.24" y1="7.874" x2="15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.255" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-12.446" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.335" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-13.335" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="15.24" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.128" x2="-13.716" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="8.001" x2="-13.589" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.747" x2="-12.573" y2="7.747" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.493" x2="-12.573" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="8.128" x2="14.859" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="8.001" x2="14.986" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.874" x2="-15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-8.255" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.255" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-8.001" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-13.335" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.366" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-13.335" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-7.62" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.128" x2="14.859" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-8.128" x2="-13.716" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.747" x2="-12.573" y2="-7.747" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.874" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-8.001" x2="14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.874" x2="14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="14.859" y1="8.255" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<text x="-14.859" y="8.636" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-18" urn="urn:adsk.eagle:footprint:22864/1" library_version="11">
grid 30.48 mm, diameter 18 mm</description>
<wire x1="15.24" y1="9.779" x2="15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.16" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-12.446" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.335" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-13.335" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="15.24" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.033" x2="-13.716" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="9.906" x2="-13.589" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.652" x2="-12.573" y2="9.652" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.398" x2="-12.573" y2="9.398" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="10.033" x2="14.859" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="9.906" x2="14.986" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-9.779" x2="-15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-10.16" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.16" x2="-12.319" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-9.906" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-13.335" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.271" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-13.335" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-9.525" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.033" x2="14.859" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-10.033" x2="-13.716" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-9.652" x2="-12.573" y2="-9.652" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-9.779" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-10.16" x2="-12.065" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-9.906" x2="14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.24" y1="9.779" x2="14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="14.859" y1="10.16" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<text x="-14.859" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-16.002" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.002" y2="0.381" layer="21"/>
</package>
<package name="E45-16" urn="urn:adsk.eagle:footprint:22865/1" library_version="11">
grid 45.72 mm, diameter 16 mm</description>
<wire x1="-20.32" y1="7.747" x2="-19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.255" x2="-18.288" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.255" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-7.747" x2="-19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-18.288" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.255" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-16.51" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-17.78" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.128" x2="-17.78" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.129" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="-16.002" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.2042" x2="-18.288" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="-16.002" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-17.78" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.6962" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.2042" x2="19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.255" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.128" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="-16.002" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.255" x2="19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-17.78" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.62" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.239" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.747" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.128" x2="-18.288" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.128" x2="19.812" y2="8.128" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.255" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.747" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.048" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.524" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.524" x2="-3.556" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.27" x2="-4.318" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.524" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="19.05" y2="0" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="7.62" x2="-16.637" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="7.874" x2="-18.034" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="7.366" x2="-16.637" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="7.874" x2="20.066" y2="7.874" width="0.3048" layer="21"/>
<wire x1="22.86" y1="0" x2="20.955" y2="0" width="0.762" layer="51"/>
<wire x1="-22.86" y1="0" x2="-20.955" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-22.86" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="22.86" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-19.812" y="8.763" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.2446" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.54" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="20.32" y1="-0.381" x2="20.828" y2="0.381" layer="21"/>
<rectangle x1="-20.828" y1="-0.381" x2="-20.32" y2="0.381" layer="21"/>
</package>
<package name="E45-18" urn="urn:adsk.eagle:footprint:22866/1" library_version="11">
grid 45.72 mm, diameter 18 mm</description>
<wire x1="-20.32" y1="8.382" x2="-19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.89" x2="-18.288" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.89" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-8.382" x2="-19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-18.288" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.89" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-16.51" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-17.78" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.763" x2="-17.78" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.129" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="-16.002" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.8392" x2="-18.288" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="-16.002" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-17.78" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.3312" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.8392" x2="19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.89" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.763" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="-16.002" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.89" x2="19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-17.78" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.255" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.874" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="8.382" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.763" x2="-18.288" y2="8.763" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.763" x2="19.812" y2="8.763" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.89" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.382" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="8.255" x2="-16.637" y2="8.255" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="8.509" x2="-18.034" y2="8.509" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="8.001" x2="-16.637" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="8.509" x2="20.066" y2="8.509" width="0.3048" layer="21"/>
<text x="-19.558" y="9.271" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-21" urn="urn:adsk.eagle:footprint:22867/1" library_version="11">
grid 45.72 mm, diameter 21 mm</description>
<wire x1="-20.32" y1="10.287" x2="-19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.795" x2="-18.288" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="10.795" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.287" x2="-19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-18.288" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-10.795" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-16.51" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-17.78" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.668" x2="-17.78" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.129" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="-16.002" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.7442" x2="-18.288" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="-16.002" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-17.78" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.2362" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.7442" x2="19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-10.795" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.668" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="-16.002" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="10.795" x2="19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-17.78" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.16" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="9.779" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.287" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.668" x2="-18.288" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.668" x2="19.812" y2="10.668" width="0.3048" layer="21"/>
<wire x1="19.812" y1="10.795" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.287" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.16" x2="-16.637" y2="10.16" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.414" x2="-18.034" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="9.906" x2="-16.637" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.414" x2="20.066" y2="10.414" width="0.3048" layer="21"/>
<text x="-19.685" y="11.176" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-22" urn="urn:adsk.eagle:footprint:22868/1" library_version="11">
grid 45.72 mm, diameter 22 mm</description>
<wire x1="-20.32" y1="10.541" x2="-19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="11.049" x2="-18.288" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="11.049" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.541" x2="-19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-18.288" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-11.049" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-16.51" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-17.78" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.922" x2="-17.78" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.129" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="-16.002" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.9982" x2="-18.288" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="-16.002" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-17.78" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.4902" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.9982" x2="19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-11.049" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.922" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="-16.002" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="11.049" x2="19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-17.78" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.414" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.033" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.541" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.922" x2="-18.288" y2="10.922" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.922" x2="19.812" y2="10.922" width="0.3048" layer="21"/>
<wire x1="19.812" y1="11.049" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.541" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.414" x2="-16.637" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.668" x2="-18.034" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.668" x2="20.066" y2="10.668" width="0.3048" layer="21"/>
<text x="-19.685" y="11.43" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-25" urn="urn:adsk.eagle:footprint:22869/1" library_version="11">
grid 45.72 mm, diameter 25 mm</description>
<wire x1="-20.32" y1="12.192" x2="-19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.7" x2="-18.288" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="12.7" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-18.288" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-12.7" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-16.51" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-17.78" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-12.573" x2="-17.78" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.129" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="-16.002" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.6492" x2="-18.288" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="-16.002" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-17.78" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.1412" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.6492" x2="19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-12.7" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-12.573" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="-16.002" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="12.7" x2="19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-17.78" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.065" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="11.684" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="12.192" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.573" x2="-18.288" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="12.573" x2="19.812" y2="12.573" width="0.3048" layer="21"/>
<wire x1="19.812" y1="12.7" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="20.32" y1="12.192" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="12.065" x2="-16.637" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="12.319" x2="-18.034" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="11.811" x2="-16.637" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="12.319" x2="20.066" y2="12.319" width="0.3048" layer="21"/>
<text x="-19.558" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5-10,5" urn="urn:adsk.eagle:footprint:22870/1" library_version="11">
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="E5-13" urn="urn:adsk.eagle:footprint:22871/1" library_version="11">
grid 5.08 mm, diameter 13 mm</description>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-0.889" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.27" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.445" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="6.985" width="0.1524" layer="21"/>
<text x="6.3754" y="4.1148" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-3.937" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.889" y2="1.27" layer="21"/>
</package>
<package name="E5-4" urn="urn:adsk.eagle:footprint:22872/1" library_version="11">
grid 5.05 mm, diameter 4 mm</description>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="-1.397" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.905"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.905" shape="octagon"/>
<text x="2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="21"/>
</package>
<package name="E5-5" urn="urn:adsk.eagle:footprint:22873/1" library_version="11">
grid 5.08 mm, diameter 5 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-6" urn="urn:adsk.eagle:footprint:22874/1" library_version="11">
grid 5.08 mm, diameter 6 mm</description>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="3.048" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-8,5" urn="urn:adsk.eagle:footprint:22875/1" library_version="11">
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E50-25" urn="urn:adsk.eagle:footprint:22876/1" library_version="11">
grid 50 mm, diameter 25 mm</description>
<wire x1="22.225" y1="-12.192" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-12.7" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="21.717" y1="12.7" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="22.225" y1="12.192" x2="22.225" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.352" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="12.7" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="21.717" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="12.065" x2="-19.177" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="11.811" x2="-19.177" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="12.573" x2="-20.828" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="12.319" x2="-22.479" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-22.479" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-20.701" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.701" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.574" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="12.573" x2="21.717" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="12.319" x2="-18.669" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="-18.669" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="21.971" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.479" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.192" x2="-18.669" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-20.32" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="11.684" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-22.352" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-12.573" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-20.32" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.065" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-22.352" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.6492" x2="-20.828" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.1412" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.7" x2="-18.542" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.6492" x2="21.717" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-12.573" x2="21.717" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.524" x2="-5.588" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-1.524" x2="-5.588" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="1.524" x2="-6.096" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="1.27" x2="-6.858" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="0.889" x2="-6.477" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.524" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="0" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0" x2="20.955" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="24.765" y1="0" x2="22.86" y2="0" width="0.762" layer="51"/>
<wire x1="-25.4" y1="0" x2="-23.495" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-25.4" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-22.098" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.7846" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="-1.524" x2="-4.572" y2="1.524" layer="21"/>
<rectangle x1="22.225" y1="-0.381" x2="22.733" y2="0.381" layer="21"/>
<rectangle x1="-23.368" y1="-0.381" x2="-22.86" y2="0.381" layer="21"/>
</package>
<package name="E50-30" urn="urn:adsk.eagle:footprint:22877/1" library_version="11">
grid 50 mm, diameter 30 mm</description>
<wire x1="22.225" y1="-14.732" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-15.24" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="21.717" y1="15.24" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="22.225" y1="14.732" x2="22.225" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.352" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="15.24" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="21.717" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.32" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-20.32" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="14.605" x2="-19.177" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="14.351" x2="-19.177" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="15.113" x2="-20.828" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="14.859" x2="-22.479" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-22.479" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-20.701" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.701" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.574" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="15.113" x2="21.717" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="14.859" x2="-18.669" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="-18.669" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="21.971" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.479" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.732" x2="-18.669" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-20.32" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.224" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-22.352" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-15.113" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-20.32" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.605" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-22.352" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.1892" x2="-20.828" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-20.32" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.6812" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.24" x2="-18.542" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.1892" x2="21.717" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-15.113" x2="21.717" y2="-15.24" width="0.1524" layer="21"/>
<pad name="+" x="-25.4" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-21.971" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E55-25" urn="urn:adsk.eagle:footprint:22878/1" library_version="11">
grid 55 mm, diameter 25 mm</description>
<wire x1="-25.4" y1="12.192" x2="-24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.7" x2="-23.368" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="12.7" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-12.192" x2="-25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-23.368" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-12.7" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-21.59" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.86" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-12.573" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.209" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="-21.082" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.6492" x2="-23.368" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="-21.082" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-22.86" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.1412" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.6492" x2="24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-12.7" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-12.573" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="-21.082" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="12.7" x2="24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-22.86" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.065" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="11.684" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.573" x2="-23.368" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="12.573" x2="24.892" y2="12.573" width="0.3048" layer="21"/>
<wire x1="24.892" y1="12.7" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="25.4" y1="12.192" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="24.13" y2="0" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="12.065" x2="-21.717" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="12.319" x2="-23.114" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="11.811" x2="-21.717" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="12.319" x2="25.146" y2="12.319" width="0.3048" layer="21"/>
<wire x1="27.94" y1="0" x2="26.035" y2="0" width="0.762" layer="51"/>
<wire x1="-27.94" y1="0" x2="-26.035" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-27.94" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-24.638" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="25.4" y1="-0.381" x2="25.908" y2="0.381" layer="21"/>
<rectangle x1="-25.908" y1="-0.381" x2="-25.4" y2="0.381" layer="21"/>
</package>
<package name="E55-30" urn="urn:adsk.eagle:footprint:22879/1" library_version="11">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 55 mm, diameter 30 mm</description>
<wire x1="-25.4" y1="14.732" x2="-24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.24" x2="-23.368" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="15.24" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-14.732" x2="-25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-23.368" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-15.24" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-21.59" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.86" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-15.113" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.209" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="-21.082" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.1892" x2="-23.368" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="-21.082" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-22.86" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.6812" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.1892" x2="24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-15.24" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-15.113" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="-21.082" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="15.24" x2="24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-22.86" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.605" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.224" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.113" x2="-23.368" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="15.113" x2="24.892" y2="15.113" width="0.3048" layer="21"/>
<wire x1="24.892" y1="15.24" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="25.4" y1="14.732" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="14.605" x2="-21.717" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="14.859" x2="-23.114" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="14.351" x2="-21.717" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="14.859" x2="25.146" y2="14.859" width="0.3048" layer="21"/>
<pad name="+" x="-27.94" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-24.511" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5R" urn="urn:adsk.eagle:footprint:22880/1" library_version="11">
grid 5.08 mm, diameter 9 mm</description>
<wire x1="-0.889" y1="0" x2="0.9398" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.588" y1="0" x2="-4.572" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.508" x2="-5.08" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="1.143" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.016" y2="0" width="0.6096" layer="51"/>
<wire x1="1.778" y1="-1.143" x2="1.7821" y2="1.1275" width="0.1524" layer="21" curve="-330.552701"/>
<wire x1="1.7732" y1="1.1613" x2="1.7781" y2="-1.143" width="0.1524" layer="51" curve="-29.895306"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="2.54" shape="octagon"/>
<text x="1.651" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E7,5-16" urn="urn:adsk.eagle:footprint:22881/1" library_version="11">
grid 7.62 mm, diameter 16 mm</description>
<wire x1="0.635" y1="0" x2="2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.905" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.905" x2="-0.254" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.905" x2="-0.254" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.905" x2="-0.889" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-5.969" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.762" x2="-6.731" y2="0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="8.255" width="0.1524" layer="21"/>
<pad name="-" x="3.81" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<pad name="+" x="-3.81" y="0" drill="1.016" diameter="3.1496"/>
<text x="7.874" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.2926" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.905" x2="0.889" y2="1.905" layer="21"/>
</package>
<package name="E7,5-18" urn="urn:adsk.eagle:footprint:22882/1" library_version="11">
grid 7.62 mm, diameter 18 mm</description>
<circle x="0" y="0" radius="8.89" width="0.1524" layer="21"/>
<text x="8.001" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB20D" urn="urn:adsk.eagle:footprint:22883/1" library_version="11">
grid 10.16 mm, diameter 20 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="10.16" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="7.62" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="2.0066" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="2.0066" diameter="4.5974" shape="octagon"/>
<text x="7.8994" y="7.366" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
<package name="EB22,5D" urn="urn:adsk.eagle:footprint:22884/1" library_version="11">
grid 10.16 mm, diameter 22.5 mm</description>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<circle x="0" y="0" radius="11.303" width="0.1524" layer="21"/>
<text x="8.4074" y="8.509" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB25D" urn="urn:adsk.eagle:footprint:22885/1" library_version="11">
grid 10.16 mm, diameter 25 mm</description>
<circle x="0" y="0" radius="12.7" width="0.254" layer="21"/>
<text x="9.6774" y="9.525" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB30D" urn="urn:adsk.eagle:footprint:22886/1" library_version="11">
grid 10.16 mm, diameter 30 mm</description>
<circle x="0" y="0" radius="15.24" width="0.254" layer="21"/>
<circle x="0" y="0" radius="12.065" width="0.254" layer="21"/>
<text x="10.8204" y="11.938" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB35D" urn="urn:adsk.eagle:footprint:22887/1" library_version="11">
grid 10.16 mm, diameter 35 mm</description>
<wire x1="1.397" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<circle x="0" y="0" radius="17.78" width="0.254" layer="21"/>
<circle x="0" y="0" radius="13.97" width="0.254" layer="21"/>
<text x="12.954" y="13.462" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="085CS_1R" urn="urn:adsk.eagle:footprint:22888/1" library_version="11">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; reflow soldering&lt;p&gt;
SMD (Chip) Standard 085 CS&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="5.7" y1="-0.95" x2="5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="-0.7" x2="5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="0.7" x2="5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.7" y1="0.95" x2="5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="5.8" y1="-0.75" x2="5.8" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-5.7" y1="0.95" x2="-5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="0.7" x2="-5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="-0.7" x2="-5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="-0.95" x2="-5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.8" y1="0.75" x2="-5.8" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.15" y1="-1.85" x2="5.15" y2="1.85" width="0.2032" layer="51"/>
<wire x1="5.15" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-1.35" x2="3.3" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="5.05" y1="1.35" x2="3.3" y2="1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-7" y1="2.2" x2="-7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="7" y1="2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="2.2" x2="7" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="-2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-5.31" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.31" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="3.3" y1="-1" x2="5.65" y2="1" layer="51"/>
<rectangle x1="-5.65" y1="-1" x2="-3.3" y2="1" layer="51"/>
</package>
<package name="085CS_1W" urn="urn:adsk.eagle:footprint:22889/1" library_version="11">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; wave soldering&lt;p&gt;
<wire x1="5.15" y1="1.85" x2="3.2" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.2" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-5.15" y1="-1.85" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.2" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-8.6" y1="4" x2="-8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="8.6" y1="4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="4" x2="8.6" y2="4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="-4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<smd name="+" x="5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="085CS_1AR" urn="urn:adsk.eagle:footprint:22890/1" library_version="11">
<wire x1="4.2" y1="-0.95" x2="4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="-0.7" x2="4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.7" x2="4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.2" y1="0.95" x2="4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-0.75" x2="4.3" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="0.95" x2="-4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.7" x2="-4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="-0.7" x2="-4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-4.2" y1="-0.95" x2="-4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.3" y1="0.75" x2="-4.3" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="3.65" y1="-1.85" x2="3.65" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.65" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.85" x2="-3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-3.65" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.6" y1="-1.35" x2="1.8" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="3.55" y1="1.35" x2="1.8" y2="1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-5.5" y1="2.2" x2="-5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="5.5" y1="2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="2.2" x2="5.5" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="-2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-3.81" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.8" y1="-1" x2="4.15" y2="1" layer="51"/>
<rectangle x1="-4.15" y1="-1" x2="-1.8" y2="1" layer="51"/>
</package>
<package name="085CS_1AW" urn="urn:adsk.eagle:footprint:22891/1" library_version="11">
<wire x1="3.65" y1="1.85" x2="1.7" y2="1.85" width="0.2032" layer="51"/>
<wire x1="1.7" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="-1.85" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.7" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-6.9" y1="4.1" x2="-6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="6.9" y1="4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="4.1" x2="6.9" y2="4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="-4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<smd name="+" x="4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="139CLL-2R" urn="urn:adsk.eagle:footprint:22892/1" library_version="11">
SMD (Chip) Long Life 139 CLL&lt;p&gt;
<wire x1="-8.1" y1="3.9" x2="-8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-3.9" x2="8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-3.9" x2="8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="3.9" x2="-8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="7.15" y1="-0.6" x2="6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="-0.85" x2="6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="0.85" x2="7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="7.15" y1="0.6" x2="7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="0.6" x2="-6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="0.85" x2="-6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="-0.85" x2="-7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="-0.6" x2="-7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="6.4" y1="-3.05" x2="-6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-1.6" x2="-6.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.05" x2="6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="1.6" x2="6.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2" x2="4.25" y2="-2.95" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2" x2="4.25" y2="2.95" width="0.2032" layer="21"/>
<smd name="+" x="6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<smd name="-" x="-6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.5" y1="-1" x2="6.85" y2="1" layer="51"/>
<rectangle x1="-6.85" y1="-1" x2="-4.5" y2="1" layer="51"/>
</package>
<package name="139CLL-2W" urn="urn:adsk.eagle:footprint:22893/1" library_version="11">
<wire x1="-10.15" y1="3.9" x2="-10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-10.15" y1="-3.9" x2="10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="-3.9" x2="10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="3.9" x2="-10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="3.05" width="0.2032" layer="51"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="-3.05" width="0.2032" layer="51"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="51"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="51"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
</package>
<package name="139CLL-3R" urn="urn:adsk.eagle:footprint:22894/1" library_version="11">
<wire x1="-8.1" y1="4.6" x2="-8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-4.6" x2="8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-4.6" x2="8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="4.6" x2="-8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="6.4" y1="-3.75" x2="-6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.75" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.75" x2="6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.75" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2.7" x2="4.5" y2="-2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2.7" x2="4.25" y2="-3.65" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2.7" x2="4.5" y2="2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2.7" x2="4.25" y2="3.65" width="0.2032" layer="21"/>
</package>
<package name="139CLL-3W" urn="urn:adsk.eagle:footprint:22895/1" library_version="11">
<wire x1="-10.6" y1="6.4" x2="-10.6" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="-10.6" y1="-6.4" x2="9.2" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="-6.4" x2="9.2" y2="6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="6.4" x2="-10.6" y2="6.4" width="0.2032" layer="39"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
</package>
<package name="140CLH-0810" urn="urn:adsk.eagle:footprint:22896/1" library_version="11">
<description>&lt;b&gt;Aluminum electrolytic capacitors SMD (Chip)&lt;/b&gt;&lt;p&gt;
Long life base plate, High temperature 140 CLH&lt;p&gt;
<wire x1="-4.85" y1="4.2" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="4.85" y2="1.45" width="0.2032" layer="21"/>
<wire x1="4.85" y1="1.45" x2="4.85" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="4.85" y1="-1.45" x2="4.85" y2="-2.75" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-4.2" x2="-4.85" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-4.2" x2="-4.85" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-1.45" x2="-4.85" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-4.85" y1="1.45" x2="-4.85" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-2.75" x2="3.4" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.4" x2="3.65" y2="1.4" width="0.2032" layer="21" curve="-138.030204"/>
<wire x1="3.65" y1="1.4" x2="3.65" y2="-1.4" width="0.2032" layer="51" curve="-41.969796"/>
<wire x1="-3.65" y1="-1.4" x2="3.65" y2="-1.4" width="0.2032" layer="21" curve="138.030204"/>
<wire x1="-3.65" y1="-1.4" x2="-3.65" y2="1.4" width="0.2032" layer="51" curve="-41.969796"/>
<smd name="+" x="3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<text x="-5.38" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="0.635" y="-3.175" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="140CLH-1010" urn="urn:adsk.eagle:footprint:22897/1" library_version="11">
<wire x1="-5.8" y1="5.15" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="5.8" y2="1.45" width="0.2032" layer="21"/>
<wire x1="5.8" y1="1.45" x2="5.8" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="5.8" y1="-1.45" x2="5.8" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="4.35" y1="-5.15" x2="-5.8" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-5.15" x2="-5.8" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-1.45" x2="-5.8" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-5.8" y1="1.45" x2="-5.8" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="-3.7" x2="4.35" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-1.4" x2="4.7" y2="-1.4" width="0.2032" layer="21" curve="146.825323"/>
<wire x1="4.7" y1="-1.4" x2="4.7" y2="1.4" width="0.2032" layer="51" curve="33.174677"/>
<wire x1="-4.7" y1="1.4" x2="4.7" y2="1.4" width="0.2032" layer="21" curve="-146.825323"/>
<wire x1="-4.7" y1="1.4" x2="-4.7" y2="-1.4" width="0.2032" layer="51" curve="33.174677"/>
<smd name="+" x="4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<smd name="-" x="-4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<text x="-2.74" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.375" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="140CLH-1014" urn="urn:adsk.eagle:footprint:22898/1" library_version="11">
<text x="-2.69" y="1.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.225" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-0810" urn="urn:adsk.eagle:footprint:22899/1" library_version="11">
Long life base plate, very low impedance 150 CLZ&lt;p&gt;
<text x="-5.43" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
</package>
<package name="150CLZ-1010" urn="urn:adsk.eagle:footprint:22900/1" library_version="11">
<text x="-2.79" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.075" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-1014" urn="urn:adsk.eagle:footprint:22901/1" library_version="11">
<wire x1="-4.7" y1="-1.4" x2="-4.7" y2="1.4" width="0.2032" layer="51" curve="-33.174677"/>
<text x="-2.74" y="1.88" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.025" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0405" urn="urn:adsk.eagle:footprint:22902/1" library_version="11">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt;&lt;p&gt;
SMD (Chip) Long Life Vertical 153 CLV&lt;p&gt;
<wire x1="1.25" y1="-2.15" x2="-2.15" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-2.15" x2="-2.15" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-1.1" x2="-2.15" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="1.1" x2="-2.15" y2="2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="1.25" y2="2.15" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.25" x2="2.15" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.1" x2="2.15" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.05" x2="2.15" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.15" y1="-1.25" x2="1.25" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.15" x2="2.15" y2="1.25" width="0.2032" layer="21"/>
<wire x1="-1.65" y1="-0.95" x2="1.65" y2="-0.95" width="0.2032" layer="21" curve="120.136976"/>
<wire x1="-1.65" y1="-0.95" x2="-1.65" y2="0.95" width="0.2032" layer="51" curve="-59.863024"/>
<wire x1="-1.65" y1="0.95" x2="1.65" y2="0.95" width="0.2032" layer="21" curve="-120.136976"/>
<wire x1="1.65" y1="-0.95" x2="1.65" y2="0.95" width="0.2032" layer="51" curve="59.863024"/>
<smd name="+" x="1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<smd name="-" x="-1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<text x="-2.24" y="2.48" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.275" y="-3.735" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0505" urn="urn:adsk.eagle:footprint:22903/1" library_version="11">
<wire x1="1.75" y1="-2.65" x2="-2.65" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-2.65" x2="-2.65" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-1.1" x2="-2.65" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.65" y1="1.1" x2="-2.65" y2="2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.65" x2="1.75" y2="2.65" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.75" x2="2.65" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.1" x2="2.65" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="2.65" y1="-1.1" x2="2.65" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.75" x2="1.75" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.65" x2="2.65" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-0.95" x2="2.2" y2="-0.95" width="0.2032" layer="21" curve="133.28887"/>
<wire x1="-2.2" y1="-0.95" x2="-2.2" y2="0.95" width="0.2032" layer="51" curve="-46.71113"/>
<wire x1="-2.2" y1="0.95" x2="2.2" y2="0.95" width="0.2032" layer="21" curve="-133.28887"/>
<wire x1="2.2" y1="-0.95" x2="2.2" y2="0.95" width="0.2032" layer="51" curve="46.71113"/>
<smd name="+" x="2.2" y="0" dx="3" dy="1.6" layer="1"/>
<smd name="-" x="-2.2" y="0" dx="3" dy="1.6" layer="1"/>
<text x="-2.74" y="2.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.775" y="-4.235" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0605" urn="urn:adsk.eagle:footprint:22904/1" library_version="11">
<wire x1="2.4" y1="-3.3" x2="-3.3" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-3.3" x2="-3.3" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-1.1" x2="-3.3" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-3.3" y1="1.1" x2="-3.3" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="3.3" x2="2.4" y2="3.3" width="0.2032" layer="21"/>
<wire x1="3.3" y1="2.4" x2="3.3" y2="1.1" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.1" x2="3.3" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.1" x2="3.3" y2="-2.4" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-2.4" x2="2.4" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.3" x2="3.3" y2="2.4" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="-0.9" x2="2.95" y2="-0.95" width="0.2032" layer="21" curve="145.181395"/>
<wire x1="-2.95" y1="-0.9" x2="-2.95" y2="0.95" width="0.2032" layer="51" curve="-34.818605"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.9" width="0.2032" layer="21" curve="-145.181395"/>
<wire x1="2.95" y1="-0.95" x2="2.95" y2="0.9" width="0.2032" layer="51" curve="34.818605"/>
<smd name="+" x="2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="-" x="-2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.39" y="3.63" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.425" y="-4.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0807" urn="urn:adsk.eagle:footprint:22905/1" library_version="11">
<wire x1="3.3" y1="-4.2" x2="-4.2" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.1" x2="-4.2" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.1" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="4.2" x2="3.3" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.1" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.1" x2="4.2" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.1" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-3.3" x2="3.3" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="3.3" y1="4.2" x2="4.2" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="-1.05" x2="3.75" y2="-1.05" width="0.2032" layer="21" curve="148.008335"/>
<wire x1="-3.75" y1="-1.05" x2="-3.75" y2="1.05" width="0.2032" layer="51" curve="-31.284493"/>
<wire x1="-3.75" y1="1.05" x2="3.75" y2="1.05" width="0.2032" layer="21" curve="-148.008335"/>
<wire x1="3.75" y1="1.05" x2="3.75" y2="-1.05" width="0.2032" layer="51" curve="-31.284493"/>
<smd name="+" x="3.05" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="-" x="-3.05" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-4.29" y="4.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.325" y="-5.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0810" urn="urn:adsk.eagle:footprint:22906/1" library_version="11">
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.5" x2="-4.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.5" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.5" x2="4.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.5" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="3.65" y1="-1.4" x2="3.65" y2="1.4" width="0.2032" layer="51" curve="41.969796"/>
</package>
<package name="153CLV-1010" urn="urn:adsk.eagle:footprint:22907/1" library_version="11">
<wire x1="4.3" y1="-5.2" x2="-5.2" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-5.2" x2="-5.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-1.5" x2="-5.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-5.2" y1="1.5" x2="-5.2" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="5.2" x2="4.3" y2="5.2" width="0.2032" layer="21"/>
<wire x1="5.2" y1="4.3" x2="5.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="5.2" y1="1.5" x2="5.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="5.2" y1="-1.5" x2="5.2" y2="-4.3" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-4.3" x2="4.3" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="4.3" y1="5.2" x2="5.2" y2="4.3" width="0.2032" layer="21"/>
<wire x1="4.65" y1="-1.55" x2="4.65" y2="1.55" width="0.2032" layer="51" curve="36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="-4.65" y2="1.55" width="0.2032" layer="51" curve="-36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="4.65" y2="-1.55" width="0.2032" layer="21" curve="143.130102"/>
<wire x1="-4.65" y1="1.55" x2="4.65" y2="1.55" width="0.2032" layer="21" curve="-143.130102"/>
<smd name="+" x="4" y="0" dx="4" dy="2.5" layer="1"/>
<smd name="-" x="-4" y="0" dx="4" dy="2.5" layer="1"/>
<text x="-5.29" y="5.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.325" y="-6.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-1012" urn="urn:adsk.eagle:footprint:22908/1" library_version="11">
</package>
<package name="153CLV-1014" urn="urn:adsk.eagle:footprint:22909/1" library_version="11">
</package>
<package name="175TMP-0808" urn="urn:adsk.eagle:footprint:22910/1" library_version="11">
High Temperature solid electrolytic SMD 175 TMP&lt;p&gt;
<wire x1="3.2" y1="-4.1" x2="-4.1" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1.55" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-1.55" x2="-4.1" y2="1.55" width="0.2032" layer="51"/>
<wire x1="-4.1" y1="1.55" x2="-4.1" y2="4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.2" y2="4.1" width="0.2032" layer="21"/>
<wire x1="4.1" y1="3.2" x2="4.1" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.1" y1="1.5" x2="4.1" y2="-1.55" width="0.2032" layer="51"/>
<wire x1="4.1" y1="-1.55" x2="4.1" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-3.2" x2="3.2" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="3.2" y1="4.1" x2="4.1" y2="3.2" width="0.2032" layer="21"/>
<wire x1="-3.6" y1="-1.45" x2="3.6" y2="-1.45" width="0.2032" layer="21" curve="136.123039"/>
<wire x1="-3.6" y1="-1.45" x2="-3.6" y2="1.45" width="0.2032" layer="51" curve="-43.876961"/>
<wire x1="-3.6" y1="1.45" x2="3.6" y2="1.45" width="0.2032" layer="21" curve="-136.123039"/>
<wire x1="3.6" y1="1.45" x2="3.6" y2="-1.45" width="0.2032" layer="51" curve="-43.876961"/>
<smd name="+" x="3.5" y="0" dx="3" dy="2.5" layer="1"/>
<smd name="-" x="-3.5" y="0" dx="3" dy="2.5" layer="1"/>
</package>
<package name="175TMP-0810" urn="urn:adsk.eagle:footprint:22911/1" library_version="11">
<wire x1="3.6" y1="-1.45" x2="3.6" y2="1.45" width="0.2032" layer="51" curve="43.876961"/>
</package>
<package name="A/3216-18R" urn="urn:adsk.eagle:footprint:22912/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 reflow solder&lt;/b&gt;&lt;p&gt;KEMET S / EIA 3216-12</description>
<wire x1="-1.45" y1="0.6" x2="1.45" y2="0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.6" x2="1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.6" x2="-1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.6" x2="-1.45" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<smd name="-" x="-1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<text x="-1.95" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.325" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.475" y2="0.6" layer="51"/>
<rectangle x1="1.475" y1="-0.6" x2="1.6" y2="0.6" layer="51"/>
<rectangle x1="0.8" y1="-0.625" x2="1.1" y2="0.625" layer="51"/>
</package>
<package name="A/3216-18W" urn="urn:adsk.eagle:footprint:22913/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="B/3528-21R" urn="urn:adsk.eagle:footprint:22914/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 reflow solder&lt;/b&gt;&lt;p&gt;KEMET T / EIA 3528-12</description>
<wire x1="-1.6" y1="1.2" x2="1.6" y2="1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.2" x2="1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.2" x2="-1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.2" x2="-1.6" y2="1.2" width="0.1016" layer="51"/>
<smd name="+" x="1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<smd name="-" x="-1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<text x="-1.95" y="1.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.925" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-0.6" x2="-1.625" y2="0.6" layer="51"/>
<rectangle x1="1.625" y1="-0.6" x2="1.75" y2="0.6" layer="51"/>
<rectangle x1="0.95" y1="-1.225" x2="1.25" y2="1.225" layer="51"/>
</package>
<package name="B/3528-21W" urn="urn:adsk.eagle:footprint:22915/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="C/6032-28R" urn="urn:adsk.eagle:footprint:22916/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 reflow solder&lt;/b&gt;&lt;p&gt;KEMET U / EIA 6032-15</description>
<wire x1="-2.8" y1="1.55" x2="2.8" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="1.55" x2="2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-1.55" x2="-2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.8" y1="-1.55" x2="-2.8" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<smd name="-" x="-2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<text x="-3" y="1.825" size="1.27" layer="25">&gt;NAME</text>
<text x="-3" y="-3.05" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3" y1="-1.1" x2="-2.85" y2="1.1" layer="51"/>
<rectangle x1="2.85" y1="-1.1" x2="3" y2="1.1" layer="51"/>
<rectangle x1="1.95" y1="-1.575" x2="2.45" y2="1.575" layer="51"/>
</package>
<package name="C/6032-28W" urn="urn:adsk.eagle:footprint:22917/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 Wafe solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
<smd name="-" x="-2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
</package>
<package name="D/7343-31R" urn="urn:adsk.eagle:footprint:22918/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET D / EIA 7343-21&lt;/b&gt;&lt;p&gt;KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 reflow solder</description>
<wire x1="-3.45" y1="2.1" x2="3.45" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.1" x2="3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.1" x2="-3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.1" x2="-3.45" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<text x="-3.65" y="2.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.65" y="-3.575" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.5" y2="1.2" layer="51"/>
<rectangle x1="3.5" y1="-1.2" x2="3.65" y2="1.2" layer="51"/>
<rectangle x1="2.675" y1="-2.125" x2="3.15" y2="2.125" layer="51"/>
</package>
<package name="D/7343-31W" urn="urn:adsk.eagle:footprint:22919/1" library_version="11">
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Wafe solder</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
</package>
<package name="E/7260-38R" urn="urn:adsk.eagle:footprint:22920/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 reflow solder&lt;/b&gt;</description>
<wire x1="-3.45" y1="2.95" x2="3.45" y2="2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.95" x2="3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.95" x2="-3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.95" x2="-3.45" y2="2.95" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<text x="-4.45" y="3.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.45" y="-4.475" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-2.05" x2="-3.5" y2="2.05" layer="51"/>
<rectangle x1="3.5" y1="-2.05" x2="3.65" y2="2.05" layer="51"/>
<rectangle x1="2.675" y1="-2.975" x2="3.15" y2="2.975" layer="51"/>
</package>
<package name="E/7260-38W" urn="urn:adsk.eagle:footprint:22921/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
</package>
<package name="R/2012-12R" urn="urn:adsk.eagle:footprint:22922/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 reflow solder&lt;/b&gt;</description>
<wire x1="-0.85" y1="0.6" x2="0.85" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="0.6" x2="0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="-0.6" x2="-0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-0.85" y1="-0.6" x2="-0.85" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<smd name="-" x="-1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<rectangle x1="-1" y1="-0.45" x2="-0.875" y2="0.45" layer="51"/>
<rectangle x1="0.875" y1="-0.45" x2="1" y2="0.45" layer="51"/>
<rectangle x1="0.3" y1="-0.625" x2="0.5" y2="0.625" layer="51"/>
</package>
<package name="R/2012-12W" urn="urn:adsk.eagle:footprint:22923/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
<smd name="-" x="-1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
</package>
<package name="PANASONIC_A" urn="urn:adsk.eagle:footprint:22924/1" library_version="11">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package A&lt;/b&gt;</description>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="1.6" x2="1.6" y2="0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="0.8" x2="1.6" y2="-0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-0.8" x2="0.8" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="0.95" x2="1.1" y2="0.95" width="0.1016" layer="21" curve="-98.369832"/>
<wire x1="-1.1" y1="-0.95" x2="1.15" y2="-0.9" width="0.1016" layer="21" curve="101.144396"/>
<wire x1="-1.6" y1="0.95" x2="-1.6" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="1.6" x2="1.5" y2="0.9" width="0.1016" layer="21"/>
<wire x1="1.5" y1="-0.9" x2="0.8" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="1.2" x2="-0.8" y2="-1.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.45" width="0.1016" layer="51"/>
<smd name="-" x="-1.3" y="0" dx="2" dy="1.5" layer="1"/>
<smd name="+" x="1.3" y="0" dx="2" dy="1.5" layer="1"/>
<text x="-1.65" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.65" y="-2.825" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.3" x2="-1.45" y2="0.3" layer="51"/>
<rectangle x1="1.45" y1="-0.3" x2="1.8" y2="0.3" layer="51"/>
<polygon width="0.1016" layer="51">
<vertex x="-0.85" y="1.1"/>
<vertex x="-1.15" y="0.8"/>
<vertex x="-1.35" y="0.3"/>
<vertex x="-1.35" y="-0.3"/>
<vertex x="-1.15" y="-0.8"/>
<vertex x="-0.85" y="-1.1"/>
<vertex x="-0.85" y="1.05"/>
</polygon>
</package>
<package name="PANASONIC_B" urn="urn:adsk.eagle:footprint:22925/1" library_version="11">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package B&lt;/b&gt;</description>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1" x2="2.1" y2="-1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.85" x2="1.75" y2="0.85" width="0.1016" layer="21" curve="-128.186984"/>
<wire x1="-1.75" y1="-0.85" x2="1.75" y2="-0.85" width="0.1016" layer="21" curve="128.186984"/>
<wire x1="-2.1" y1="0.85" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="-1.2" y1="1.5" x2="-1.2" y2="-1.5" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.95" width="0.1016" layer="51"/>
<smd name="-" x="-1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<smd name="+" x="1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<text x="-2.15" y="2.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.15" y="-3.275" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3" y1="-0.35" x2="-1.85" y2="0.35" layer="51"/>
<rectangle x1="1.9" y1="-0.35" x2="2.3" y2="0.35" layer="51"/>
<vertex x="-1.25" y="1.45"/>
<vertex x="-1.7" y="0.85"/>
<vertex x="-1.85" y="0.35"/>
<vertex x="-1.85" y="-0.4"/>
<vertex x="-1.7" y="-0.85"/>
<vertex x="-1.25" y="-1.4"/>
<vertex x="-1.25" y="1.4"/>
</polygon>
</package>
<package name="PANASONIC_C" urn="urn:adsk.eagle:footprint:22926/1" library_version="11">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package C&lt;/b&gt;</description>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="-1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="0.95" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="0.95" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-0.95" x2="2.6" y2="-1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.3" y1="0.85" x2="2.3" y2="0.85" width="0.1016" layer="21" curve="-139.434882"/>
<wire x1="-2.3" y1="-0.85" x2="2.3" y2="-0.85" width="0.1016" layer="21" curve="139.434882"/>
<wire x1="-1.55" y1="1.85" x2="-1.55" y2="-1.85" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="2.45" width="0.1016" layer="51"/>
<smd name="-" x="-2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<smd name="+" x="2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<text x="-2.6" y="2.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.65" y="-3.775" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.95" y1="-0.35" x2="-2.4" y2="0.35" layer="51"/>
<rectangle x1="2.4" y1="-0.35" x2="2.95" y2="0.35" layer="51"/>
<vertex x="-1.6" y="1.8"/>
<vertex x="-2" y="1.35"/>
<vertex x="-2.25" y="0.75"/>
<vertex x="-2.45" y="0.05"/>
<vertex x="-2.25" y="-0.75"/>
<vertex x="-1.95" y="-1.35"/>
<vertex x="-1.6" y="-1.8"/>
</polygon>
</package>
<package name="PANASONIC_D" urn="urn:adsk.eagle:footprint:22927/1" library_version="11">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D&lt;/b&gt;</description>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="0.95" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="0.95" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-0.95" x2="3.25" y2="-1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.95" width="0.1016" layer="21" curve="-144.299363"/>
<wire x1="-2.95" y1="-0.95" x2="2.95" y2="-0.95" width="0.1016" layer="21" curve="144.299363"/>
<wire x1="-2.1" y1="2.25" x2="-2.1" y2="-2.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="3.1" width="0.1016" layer="51"/>
<smd name="-" x="-2.4" y="0" dx="3" dy="1.4" layer="1"/>
<smd name="+" x="2.4" y="0" dx="3" dy="1.4" layer="1"/>
<text x="-1.75" y="1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-1.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-0.35" x2="-3.05" y2="0.35" layer="51"/>
<rectangle x1="3.05" y1="-0.35" x2="3.65" y2="0.35" layer="51"/>
<vertex x="-2.15" y="2.15"/>
<vertex x="-2.6" y="1.6"/>
<vertex x="-2.9" y="0.9"/>
<vertex x="-3.05" y="0"/>
<vertex x="-2.9" y="-0.95"/>
<vertex x="-2.55" y="-1.65"/>
<vertex x="-2.15" y="-2.15"/>
<vertex x="-2.15" y="2.1"/>
</polygon>
</package>
<package name="PANASONIC_E" urn="urn:adsk.eagle:footprint:22928/1" library_version="11">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package E&lt;/b&gt;</description>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="0.9" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="0.9" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-0.9" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-2.2" y1="3.25" x2="-2.2" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.9" x2="3.85" y2="0.9" width="0.1016" layer="21" curve="-153.684915"/>
<wire x1="-3.85" y1="-0.9" x2="3.85" y2="-0.9" width="0.1016" layer="21" curve="153.684915"/>
<circle x="0" y="0" radius="3.95" width="0.1016" layer="51"/>
<smd name="-" x="-3" y="0" dx="3.8" dy="1.4" layer="1"/>
<smd name="+" x="3" y="0" dx="3.8" dy="1.4" layer="1"/>
<text x="-1.8" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.8" y="-2.225" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5" y1="-0.35" x2="-3.8" y2="0.35" layer="51"/>
<rectangle x1="3.8" y1="-0.35" x2="4.5" y2="0.35" layer="51"/>
<vertex x="-2.25" y="3.2"/>
<vertex x="-3" y="2.5"/>
<vertex x="-3.6" y="1.5"/>
<vertex x="-3.85" y="0.65"/>
<vertex x="-3.85" y="-0.65"/>
<vertex x="-3.55" y="-1.6"/>
<vertex x="-2.95" y="-2.55"/>
<vertex x="-2.25" y="-3.2"/>
<vertex x="-2.25" y="3.15"/>
</polygon>
</package>
<package name="PANASONIC_F" urn="urn:adsk.eagle:footprint:22929/1" library_version="11">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package F&lt;/b&gt;</description>
<wire x1="-4.1" y1="1" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1" width="0.1016" layer="21"/>
<circle x="0" y="0" radius="4" width="0.001" layer="51"/>
<smd name="-" x="-3.55" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="+" x="3.55" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-1.75" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-2.375" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.85" y1="-0.45" x2="-3.9" y2="0.45" layer="51"/>
<rectangle x1="3.9" y1="-0.45" x2="4.85" y2="0.45" layer="51"/>
</polygon>
</package>
<package name="PANASONIC_G" urn="urn:adsk.eagle:footprint:22930/1" library_version="11">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G&lt;/b&gt;</description>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="-2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="1" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-1" x2="5.1" y2="-2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-1" width="0.1016" layer="21"/>
<wire x1="-4.85" y1="-1" x2="4.85" y2="-1" width="0.1016" layer="21" curve="156.699401"/>
<wire x1="-4.85" y1="1" x2="4.85" y2="1" width="0.1016" layer="21" curve="-156.699401"/>
<wire x1="-3.25" y1="3.7" x2="-3.25" y2="-3.65" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="4.95" width="0.1016" layer="51"/>
<smd name="-" x="-4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<smd name="+" x="4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<text x="-2.55" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.55" y="-2.675" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-5.85" y1="-0.45" x2="-4.9" y2="0.45" layer="51"/>
<rectangle x1="4.9" y1="-0.45" x2="5.85" y2="0.45" layer="51"/>
<vertex x="-3.3" y="3.6"/>
<vertex x="-4.05" y="2.75"/>
<vertex x="-4.65" y="1.55"/>
<vertex x="-4.85" y="0.45"/>
<vertex x="-4.85" y="-0.45"/>
<vertex x="-4.65" y="-1.55"/>
<vertex x="-4.05" y="-2.75"/>
<vertex x="-3.3" y="-3.6"/>
<vertex x="-3.3" y="3.55"/>
</polygon>
</package>
<package name="TT2D5L" urn="urn:adsk.eagle:footprint:22931/1" library_version="11">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-2.54" y1="8.89" x2="2.54" y2="8.89" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.54" y1="8.89" x2="2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="8.89" x2="-2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.651" x2="-1.905" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.905" y1="1.016" x2="2.54" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.54" x2="0.889" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="3.81" x2="-1.524" y2="3.048" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-2.921" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="2.286" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="E2,5-6E" urn="urn:adsk.eagle:footprint:22932/1" library_version="11">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.159" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.254" x2="-2.413" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="SMC_A" urn="urn:adsk.eagle:footprint:25479/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor &lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194, B 45 197, B 45 198&lt;br&gt;
Source: www.farnell.com/datasheets/247.pdf</description>
<wire x1="-1.45" y1="0.75" x2="1.45" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.75" x2="1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.75" x2="-1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.75" x2="-1.45" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1.6" y="0.975" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.4" y2="0.6" layer="51"/>
<rectangle x1="1.4" y1="-0.6" x2="1.6" y2="0.6" layer="51" rot="R180"/>
<rectangle x1="-1.45" y1="-0.75" x2="-0.8" y2="0.75" layer="51"/>
</package>
<package name="SMC_Z" urn="urn:adsk.eagle:footprint:25480/1" library_version="11">
<description>&lt;b&gt;Chip Capacitor&lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194&lt;br&gt;
<wire x1="-0.9" y1="0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="-0.9" y1="0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<smd name="+" x="-1" y="0" dx="1" dy="1.2" layer="1"/>
<smd name="-" x="1" y="0" dx="1" dy="1.2" layer="1"/>
<text x="-1" y="0.8" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.1" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.45" x2="-0.9" y2="0.45" layer="51"/>
<rectangle x1="0.9" y1="-0.45" x2="1" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-0.9" y1="-0.6" x2="-0.5" y2="0.6" layer="51"/>
</package>
<package name="SMC_P" urn="urn:adsk.eagle:footprint:25481/1" library_version="11">
<wire x1="-1.675" y1="0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.675" y1="0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.575" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.575" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.275" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.45" x2="-1.7" y2="0.45" layer="51"/>
<rectangle x1="1.7" y1="-0.45" x2="1.8" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-1.65" y1="-0.75" x2="-1.075" y2="0.725" layer="51"/>
</package>
<package name="SMC_B" urn="urn:adsk.eagle:footprint:25482/1" library_version="11">
<wire x1="-1.6" y1="1.35" x2="1.6" y2="1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.35" x2="1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.35" x2="-1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.35" x2="-1.6" y2="1.35" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="2.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="2.4" layer="1" rot="R180"/>
<text x="-1.905" y="1.905" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-1.1" x2="-1.55" y2="1.1" layer="51"/>
<rectangle x1="1.55" y1="-1.1" x2="1.75" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-1.6" y1="-1.35" x2="-0.95" y2="1.35" layer="51"/>
</package>
<package name="SMC_C" urn="urn:adsk.eagle:footprint:25483/1" library_version="11">
<wire x1="-2.85" y1="1.55" x2="2.85" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="1.55" x2="2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="-1.55" x2="-2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.85" y1="-1.55" x2="-2.85" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.4" dy="2.4" layer="1" rot="R180"/>
<rectangle x1="-3" y1="-1.1" x2="-2.8" y2="1.1" layer="51"/>
<rectangle x1="2.8" y1="-1.1" x2="3" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-2.85" y1="-1.55" x2="-1.9" y2="1.55" layer="51"/>
</package>
<package name="SMC_D" urn="urn:adsk.eagle:footprint:25484/1" library_version="11">
<wire x1="-3.5" y1="2.1" x2="3.5" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="2.1" x2="3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="-2.1" x2="-3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.5" y1="-2.1" x2="-3.5" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="-3.15" y="0" dx="2.4" dy="2.8" layer="1"/>
<smd name="-" x="3.15" y="0" dx="2.4" dy="2.8" layer="1" rot="R180"/>
<text x="-2.54" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.45" y2="1.2" layer="51"/>
<rectangle x1="3.45" y1="-1.2" x2="3.65" y2="1.2" layer="51" rot="R180"/>
<rectangle x1="-3.5" y1="-2.1" x2="-2.4" y2="2.1" layer="51"/>
</package>
<package name="SMC_E" urn="urn:adsk.eagle:footprint:25485/1" library_version="11">
</package>
<package name="SANYO-OSCON_9E" urn="urn:adsk.eagle:footprint:22940/1" library_version="11">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt;&lt;p&gt;
Source: e_os_all.pdf</description>
<wire x1="-3.55" y1="0" x2="-2.8" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9" width="0.2032" layer="21"/>
<pad name="-" x="-1.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.8" diameter="1.27"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SANYO-OSCON_9F" urn="urn:adsk.eagle:footprint:22941/1" library_version="11">
<wire x1="-4.55" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9" width="0.2032" layer="21"/>
<pad name="-" x="-2.5" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_A" urn="urn:adsk.eagle:footprint:22942/1" library_version="11">
<wire x1="-1.55" y1="-0.4" x2="-1.55" y2="0.4" width="0.4064" layer="51"/>
<circle x="0" y="0" radius="1.9" width="0.2032" layer="21"/>
<pad name="-" x="-1" y="0" drill="0.7" diameter="1.1"/>
<pad name="+" x="1" y="0" drill="0.7" diameter="1.1"/>
</package>
<package name="SANYO-OSCON_A'" urn="urn:adsk.eagle:footprint:22943/1" library_version="11">
<pad name="-" x="-0.75" y="0" drill="0.6" diameter="1"/>
<pad name="+" x="0.75" y="0" drill="0.6" diameter="1"/>
</package>
<package name="SANYO-OSCON_B" urn="urn:adsk.eagle:footprint:22944/1" library_version="11">
<wire x1="-1.9" y1="-0.4" x2="-1.9" y2="0.4" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="2.4" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_B'" urn="urn:adsk.eagle:footprint:22945/1" library_version="11">
</package>
<package name="SANYO-OSCON_C" urn="urn:adsk.eagle:footprint:22946/1" library_version="11">
<wire x1="-2.2" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.05" width="0.2032" layer="21"/>
<pad name="-" x="-1.25" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_C'" urn="urn:adsk.eagle:footprint:22947/1" library_version="11">
<circle x="0" y="0" radius="3.0504" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_C6" urn="urn:adsk.eagle:footprint:22948/1" library_version="11">
<pad name="-" x="-1.25" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.7" diameter="1.27"/>
<text x="-1.905" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="21">
<vertex x="-2.15" y="-2.1" curve="-41.039434"/>
<vertex x="-3" y="0.1" curve="-41.67409"/>
</polygon>
</package>
<package name="SANYO-OSCON_D" urn="urn:adsk.eagle:footprint:22949/1" library_version="11">
</package>
<package name="SANYO-OSCON_E" urn="urn:adsk.eagle:footprint:22950/1" library_version="11">
<wire x1="-3.5" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9003" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_E'" urn="urn:adsk.eagle:footprint:22951/1" library_version="11">
</package>
<package name="SANYO-OSCON_E1" urn="urn:adsk.eagle:footprint:22952/1" library_version="11">
<wire x1="-3.55" y1="0" x2="-2.75" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_E12" urn="urn:adsk.eagle:footprint:22953/1" library_version="11">
<vertex x="-2.65" y="2.7"/>
<vertex x="-2.65" y="-2.75" curve="-41.038922"/>
<vertex x="-3.8" y="0" curve="-41.675057"/>
</polygon>
</package>
<package name="SANYO-OSCON_E13" urn="urn:adsk.eagle:footprint:22954/1" library_version="11">
</polygon>
</package>
<package name="SANYO-OSCON_E7" urn="urn:adsk.eagle:footprint:22955/1" library_version="11">
<pad name="-" x="-1.75" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-2.65" y="2.8"/>
<vertex x="-2.65" y="-2.8" curve="-41.039891"/>
<vertex x="-3.85" y="0" curve="-41.675747"/>
</polygon>
</package>
<package name="SANYO-OSCON_E9" urn="urn:adsk.eagle:footprint:22956/1" library_version="11">
</polygon>
</package>
<package name="SANYO-OSCON_F" urn="urn:adsk.eagle:footprint:22957/1" library_version="11">
<wire x1="-4.5" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_F'" urn="urn:adsk.eagle:footprint:22958/1" library_version="11">
<wire x1="-3.55" y1="0" x2="-4.4" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9002" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_F0" urn="urn:adsk.eagle:footprint:22959/1" library_version="11">
</package>
<package name="SANYO-OSCON_F13" urn="urn:adsk.eagle:footprint:22960/1" library_version="11">
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.4" y="3.45"/>
<vertex x="-3.4" y="-3.4" curve="-41.039359"/>
<vertex x="-4.85" y="0" curve="-41.674636"/>
</polygon>
</package>
<package name="SANYO-OSCON_F8" urn="urn:adsk.eagle:footprint:22961/1" library_version="11">
<pad name="-" x="-2.5" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-3.6" y="3.2"/>
<vertex x="-3.6" y="-3.25" curve="-41.039474"/>
<vertex x="-4.85" y="0" curve="-41.675359"/>
</polygon>
</package>
<package name="SANYO-OSCON_G" urn="urn:adsk.eagle:footprint:22962/1" library_version="11">
<wire x1="-4.5" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="6.15" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_H" urn="urn:adsk.eagle:footprint:22963/1" library_version="11">
<wire x1="-7" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="7.9001" width="0.2032" layer="21"/>
<pad name="-" x="-3.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="3.75" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_SMD_A5" urn="urn:adsk.eagle:footprint:22964/1" library_version="11">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt; SMD type with conductive polymer electrolyte&lt;p&gt;
<wire x1="-2.05" y1="2.05" x2="1.25" y2="2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.05" x2="2.05" y2="1.25" width="0.2032" layer="21"/>
<wire x1="2.05" y1="1.25" x2="2.05" y2="-1.25" width="0.2032" layer="51"/>
<wire x1="2.05" y1="-1.25" x2="1.25" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="-2.05" x2="-2.05" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="-2.05" y1="-2.05" x2="-2.05" y2="2.05" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.85" width="0.2032" layer="51"/>
<text x="-1.905" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="51">
<vertex x="-1.2" y="-1.35"/>
<vertex x="-1.2" y="1.35" curve="44.759919"/>
<vertex x="-1.8" y="0" curve="39.027281"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_B6" urn="urn:adsk.eagle:footprint:22965/1" library_version="11">
<wire x1="-2.55" y1="2.55" x2="1.75" y2="2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.55" x2="2.55" y2="1.75" width="0.2032" layer="21"/>
<wire x1="2.55" y1="1.75" x2="2.55" y2="-1.75" width="0.2032" layer="51"/>
<wire x1="2.55" y1="-1.75" x2="1.75" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="-2.55" x2="-2.55" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="-2.55" y1="-2.55" x2="-2.55" y2="2.55" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.35" width="0.2032" layer="51"/>
<text x="-2.54" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-1.6" y="-1.65"/>
<vertex x="-1.6" y="1.65" curve="35.983944"/>
<vertex x="-2.3" y="0" curve="42.321615"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_C6" urn="urn:adsk.eagle:footprint:22966/1" library_version="11">
<wire x1="-3.2" y1="3.2" x2="2.4" y2="3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.2" x2="3.2" y2="2.4" width="0.2032" layer="21"/>
<wire x1="3.2" y1="2.4" x2="3.2" y2="-2.4" width="0.2032" layer="51"/>
<wire x1="3.2" y1="-2.4" x2="2.4" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="-3.2" x2="-3.2" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="-3.2" y1="-3.2" x2="-3.2" y2="3.2" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.95" width="0.2032" layer="51"/>
<smd name="-" x="-2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="+" x="2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.175" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="1.9"/>
<vertex x="-2.2" y="-1.9" curve="-39.18521"/>
<vertex x="-2.85" y="0" curve="-36.094684"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E12" urn="urn:adsk.eagle:footprint:22967/1" library_version="11">
<wire x1="-4.05" y1="4.05" x2="2.95" y2="4.05" width="0.2032" layer="21"/>
<wire x1="2.95" y1="4.05" x2="4.05" y2="2.95" width="0.2032" layer="21"/>
<wire x1="4.05" y1="2.95" x2="4.05" y2="-2.95" width="0.2032" layer="51"/>
<wire x1="2.95" y1="-4.05" x2="-4.05" y2="-4.05" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="-4.05" x2="-4.05" y2="4.05" width="0.2032" layer="51"/>
<wire x1="4.05" y1="-2.95" x2="2.95" y2="-4.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="3.85" width="0.2032" layer="51"/>
<smd name="-" x="-3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<smd name="+" x="3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<text x="-3.81" y="4.445" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.6" y="-2.75"/>
<vertex x="-2.6" y="2.75" curve="44.955417"/>
<vertex x="-3.85" y="0" curve="45.23973"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E7" urn="urn:adsk.eagle:footprint:22968/1" library_version="11">
<vertex x="-2.7" y="2.65"/>
<vertex x="-2.7" y="-2.65" curve="-47.290335"/>
<vertex x="-3.8" y="0" curve="-44.001093"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F12" urn="urn:adsk.eagle:footprint:22969/1" library_version="11">
<wire x1="-5.05" y1="5.05" x2="3.95" y2="5.05" width="0.2032" layer="21"/>
<wire x1="3.95" y1="5.05" x2="5.05" y2="3.95" width="0.2032" layer="21"/>
<wire x1="5.05" y1="3.95" x2="5.05" y2="-3.95" width="0.2032" layer="51"/>
<wire x1="3.95" y1="-5.05" x2="-5.05" y2="-5.05" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="-5.05" x2="-5.05" y2="5.05" width="0.2032" layer="51"/>
<wire x1="5.05" y1="-3.95" x2="3.95" y2="-5.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="4.8" width="0.2032" layer="51"/>
<smd name="-" x="-4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<smd name="+" x="4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<text x="-5.08" y="5.715" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="-3.65"/>
<vertex x="-3.05" y="3.65" curve="48.708973"/>
<vertex x="-4.75" y="0" curve="43.982679"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F8" urn="urn:adsk.eagle:footprint:22970/1" library_version="11">
<vertex x="-3.05" y="3.65" curve="41.376652"/>
<vertex x="-4.75" y="0" curve="43.010397"/>
</polygon>
</package>
<package name="UD-10X10_NICHICON" urn="urn:adsk.eagle:footprint:22971/1" library_version="11">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 10 x 10 mm&lt;p&gt;
Source: http://products.nichicon.co.jp/en/pdf/XJA043/e-ud.pdf</description>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="4.3" x2="5.1" y2="-4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-4.875" y1="0.85" x2="4.875" y2="0.85" width="0.1016" layer="21" curve="-160.259855"/>
<wire x1="-5.1" y1="0.875" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="4.875" y1="-0.85" x2="-4.875" y2="-0.85" width="0.1016" layer="21" curve="-160.259855"/>
<smd name="-" x="-3.95" y="0" dx="3.6" dy="1.3" layer="1"/>
<smd name="+" x="3.925" y="0" dx="3.6" dy="1.3" layer="1"/>
<text x="-5.08" y="5.715" size="1.016" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.35" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-4.05" y="2.8" curve="69.465624"/>
<vertex x="-4.05" y="-2.825"/>
</polygon>
</package>
<package name="UD-4X5,8_NICHICON" urn="urn:adsk.eagle:footprint:22972/1" library_version="11">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 4 x 5.8 mm&lt;p&gt;
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1.3" x2="2.1" y2="-1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.875" x2="1.75" y2="0.875" width="0.1016" layer="21" curve="-126.263848"/>
<wire x1="-2.1" y1="0.9" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="1.75" y1="-0.875" x2="-1.75" y2="-0.875" width="0.1016" layer="21" curve="-126.263848"/>
<circle x="0" y="0" radius="1.9527" width="0.1016" layer="51"/>
<smd name="-" x="-1.425" y="0" dx="2" dy="1" layer="1"/>
<smd name="+" x="1.425" y="0" dx="2" dy="1" layer="1"/>
<text x="-1.905" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-1.55" y="1.175" curve="72.275472"/>
<vertex x="-1.55" y="-1.175"/>
</polygon>
</package>
<package name="UD-5X5,8_NICHICON" urn="urn:adsk.eagle:footprint:22973/1" library_version="11">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 5 x 5.8 mm&lt;p&gt;
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.8" x2="2.6" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.3" y1="0.85" x2="2.275" y2="0.9" width="0.1016" layer="21" curve="-137.986421"/>
<wire x1="-2.6" y1="0.7" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="2.3" y1="-0.85" x2="-2.275" y2="-0.9" width="0.1016" layer="21" curve="-137.986421"/>
<circle x="0" y="0" radius="2.4501" width="0.1016" layer="51"/>
<smd name="-" x="-1.7" y="0" dx="2.3" dy="1" layer="1"/>
<smd name="+" x="1.725" y="0" dx="2.3" dy="1" layer="1"/>
<text x="-2.54" y="3.175" size="1.016" layer="25">&gt;NAME</text>
<vertex x="-1.55" y="1.875" curve="100.118878"/>
<vertex x="-1.55" y="-1.875"/>
</polygon>
</package>
<package name="UD-6,3X5,8_NICHICON" urn="urn:adsk.eagle:footprint:22974/1" library_version="11">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 5.8 mm&lt;p&gt;
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="2.45" x2="3.25" y2="-2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3" y1="0.775" x2="2.975" y2="0.85" width="0.1016" layer="21" curve="-149.753145"/>
<wire x1="-3.25" y1="0.8" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="3" y1="-0.775" x2="-2.975" y2="-0.85" width="0.1016" layer="21" curve="-149.753145"/>
<circle x="0" y="0" radius="3.1001" width="0.1016" layer="51"/>
<smd name="-" x="-2.35" y="0" dx="2.8" dy="1" layer="1"/>
<smd name="+" x="2.35" y="0" dx="2.8" dy="1" layer="1"/>
<text x="-3.175" y="3.81" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.175" y="-4.445" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="2.15" curve="88.581463"/>
<vertex x="-2.2" y="-2.15"/>
</polygon>
</package>
<package name="UD-6,3X7,7_NICHICON" urn="urn:adsk.eagle:footprint:22975/1" library_version="11">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 7.7 mm&lt;p&gt;
</polygon>
</package>
<package name="UD-8X10_NICHICON" urn="urn:adsk.eagle:footprint:22976/1" library_version="11">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 8 x 10 mm&lt;p&gt;
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="3.3" x2="4.1" y2="-3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.875" x2="3.85" y2="0.875" width="0.1016" layer="21" curve="-154.459402"/>
<wire x1="-4.1" y1="0.825" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="3.85" y1="-0.875" x2="-3.85" y2="-0.875" width="0.1016" layer="21" curve="-154.459402"/>
<smd name="-" x="-3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<smd name="+" x="3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<text x="-3.81" y="4.445" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="2.475" curve="77.887741"/>
<vertex x="-3.05" y="-2.475"/>
</polygon>
</package>
</packages>
<packages3d>
<package3d name="R0402" urn="urn:adsk.eagle:package:23547/3" type="model" library_version="11">
<description>Chip RESISTOR 0402 EIA (1005 Metric)</description>
<packageinstances>
<packageinstance name="R0402"/>
</packageinstances>
</package3d>
<package3d name="R0603" urn="urn:adsk.eagle:package:23555/3" type="model" library_version="11">
<description>RESISTOR</description>
<packageinstances>
<packageinstance name="R0603"/>
</packageinstances>
</package3d>
<package3d name="R0805" urn="urn:adsk.eagle:package:23553/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R0805"/>
</packageinstances>
</package3d>
<package3d name="R0805W" urn="urn:adsk.eagle:package:23537/2" type="model" library_version="11">
<description>RESISTOR wave soldering</description>
<packageinstances>
<packageinstance name="R0805W"/>
</packageinstances>
</package3d>
<package3d name="R1206" urn="urn:adsk.eagle:package:23540/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R1206"/>
</packageinstances>
</package3d>
<package3d name="R1206W" urn="urn:adsk.eagle:package:23539/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R1206W"/>
</packageinstances>
</package3d>
<package3d name="R1210" urn="urn:adsk.eagle:package:23554/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R1210"/>
</packageinstances>
</package3d>
<package3d name="R1210W" urn="urn:adsk.eagle:package:23541/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R1210W"/>
</packageinstances>
</package3d>
<package3d name="R2010" urn="urn:adsk.eagle:package:23551/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R2010"/>
</packageinstances>
</package3d>
<package3d name="R2010W" urn="urn:adsk.eagle:package:23542/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R2010W"/>
</packageinstances>
</package3d>
<package3d name="R2012" urn="urn:adsk.eagle:package:23543/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R2012"/>
</packageinstances>
</package3d>
<package3d name="R2012W" urn="urn:adsk.eagle:package:23544/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R2012W"/>
</packageinstances>
</package3d>
<package3d name="R2512" urn="urn:adsk.eagle:package:23545/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R2512"/>
</packageinstances>
</package3d>
<package3d name="R2512W" urn="urn:adsk.eagle:package:23565/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R2512W"/>
</packageinstances>
</package3d>
<package3d name="R3216" urn="urn:adsk.eagle:package:23557/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R3216"/>
</packageinstances>
</package3d>
<package3d name="R3216W" urn="urn:adsk.eagle:package:23548/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R3216W"/>
</packageinstances>
</package3d>
<package3d name="R3225" urn="urn:adsk.eagle:package:23549/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R3225"/>
</packageinstances>
</package3d>
<package3d name="R3225W" urn="urn:adsk.eagle:package:23550/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R3225W"/>
</packageinstances>
</package3d>
<package3d name="R5025" urn="urn:adsk.eagle:package:23552/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R5025"/>
</packageinstances>
</package3d>
<package3d name="R5025W" urn="urn:adsk.eagle:package:23558/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R5025W"/>
</packageinstances>
</package3d>
<package3d name="R6332" urn="urn:adsk.eagle:package:23559/2" type="model" library_version="11">
Source: http://download.siliconexpert.com/pdfs/2005/02/24/Semi_Ap/2/VSH/Resistor/dcrcwfre.pdf</description>
<packageinstances>
<packageinstance name="R6332"/>
</packageinstances>
</package3d>
<package3d name="R6332W" urn="urn:adsk.eagle:package:26078/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="R6332W"/>
</packageinstances>
</package3d>
<package3d name="M0805" urn="urn:adsk.eagle:package:23556/2" type="model" library_version="11">
MELF 0.10 W</description>
<packageinstances>
<packageinstance name="M0805"/>
</packageinstances>
</package3d>
<package3d name="M1206" urn="urn:adsk.eagle:package:23566/2" type="model" library_version="11">
MELF 0.25 W</description>
<packageinstances>
<packageinstance name="M1206"/>
</packageinstances>
</package3d>
<package3d name="M1406" urn="urn:adsk.eagle:package:23569/2" type="model" library_version="11">
MELF 0.12 W</description>
<packageinstances>
<packageinstance name="M1406"/>
</packageinstances>
</package3d>
<package3d name="M2012" urn="urn:adsk.eagle:package:23561/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="M2012"/>
</packageinstances>
</package3d>
<package3d name="M2309" urn="urn:adsk.eagle:package:23562/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="M2309"/>
</packageinstances>
</package3d>
<package3d name="M3216" urn="urn:adsk.eagle:package:23563/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="M3216"/>
</packageinstances>
</package3d>
<package3d name="M3516" urn="urn:adsk.eagle:package:23573/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="M3516"/>
</packageinstances>
</package3d>
<package3d name="M5923" urn="urn:adsk.eagle:package:23564/3" type="model" library_version="11">
<packageinstances>
<packageinstance name="M5923"/>
</packageinstances>
</package3d>
<package3d name="0204/5" urn="urn:adsk.eagle:package:23488/1" type="box" library_version="11">
type 0204, grid 5 mm</description>
<packageinstances>
<packageinstance name="0204/5"/>
</packageinstances>
</package3d>
<package3d name="0204/7" urn="urn:adsk.eagle:package:23498/2" type="model" library_version="11">
type 0204, grid 7.5 mm</description>
<packageinstances>
<packageinstance name="0204/7"/>
</packageinstances>
</package3d>
<package3d name="0204V" urn="urn:adsk.eagle:package:23495/1" type="box" library_version="11">
type 0204, grid 2.5 mm</description>
<packageinstances>
<packageinstance name="0204V"/>
</packageinstances>
</package3d>
<package3d name="0207/10" urn="urn:adsk.eagle:package:23491/2" type="model" library_version="11">
type 0207, grid 10 mm</description>
<packageinstances>
<packageinstance name="0207/10"/>
</packageinstances>
</package3d>
<package3d name="0207/12" urn="urn:adsk.eagle:package:23489/1" type="box" library_version="11">
type 0207, grid 12 mm</description>
<packageinstances>
<packageinstance name="0207/12"/>
</packageinstances>
</package3d>
<package3d name="0207/15" urn="urn:adsk.eagle:package:23492/1" type="box" library_version="11">
type 0207, grid 15mm</description>
<packageinstances>
<packageinstance name="0207/15"/>
</packageinstances>
</package3d>
<package3d name="0207/2V" urn="urn:adsk.eagle:package:23490/1" type="box" library_version="11">
type 0207, grid 2.5 mm</description>
<packageinstances>
<packageinstance name="0207/2V"/>
</packageinstances>
</package3d>
<package3d name="0207/5V" urn="urn:adsk.eagle:package:23502/1" type="box" library_version="11">
type 0207, grid 5 mm</description>
<packageinstances>
<packageinstance name="0207/5V"/>
</packageinstances>
</package3d>
<package3d name="0207/7" urn="urn:adsk.eagle:package:23493/2" type="model" library_version="11">
type 0207, grid 7.5 mm</description>
<packageinstances>
<packageinstance name="0207/7"/>
</packageinstances>
</package3d>
<package3d name="0309/10" urn="urn:adsk.eagle:package:23567/2" type="model" library_version="11">
type 0309, grid 10mm</description>
<packageinstances>
<packageinstance name="0309/10"/>
</packageinstances>
</package3d>
<package3d name="0309/12" urn="urn:adsk.eagle:package:23571/1" type="box" library_version="11">
type 0309, grid 12.5 mm</description>
<packageinstances>
<packageinstance name="0309/12"/>
</packageinstances>
</package3d>
<package3d name="0309V" urn="urn:adsk.eagle:package:23572/1" type="box" library_version="11">
type 0309, grid 2.5 mm</description>
<packageinstances>
<packageinstance name="0309V"/>
</packageinstances>
</package3d>
<package3d name="0411/12" urn="urn:adsk.eagle:package:23578/1" type="box" library_version="11">
type 0411, grid 12.5 mm</description>
<packageinstances>
<packageinstance name="0411/12"/>
</packageinstances>
</package3d>
<package3d name="0411/15" urn="urn:adsk.eagle:package:23568/2" type="model" library_version="11">
type 0411, grid 15 mm</description>
<packageinstances>
<packageinstance name="0411/15"/>
</packageinstances>
</package3d>
<package3d name="0411V" urn="urn:adsk.eagle:package:23570/1" type="box" library_version="11">
type 0411, grid 3.81 mm</description>
<packageinstances>
<packageinstance name="0411V"/>
</packageinstances>
</package3d>
<package3d name="0414/15" urn="urn:adsk.eagle:package:23579/2" type="model" library_version="11">
type 0414, grid 15 mm</description>
<packageinstances>
<packageinstance name="0414/15"/>
</packageinstances>
</package3d>
<package3d name="0414V" urn="urn:adsk.eagle:package:23574/1" type="box" library_version="11">
type 0414, grid 5 mm</description>
<packageinstances>
<packageinstance name="0414V"/>
</packageinstances>
</package3d>
<package3d name="0617/17" urn="urn:adsk.eagle:package:23575/2" type="model" library_version="11">
type 0617, grid 17.5 mm</description>
<packageinstances>
<packageinstance name="0617/17"/>
</packageinstances>
</package3d>
<package3d name="0617/22" urn="urn:adsk.eagle:package:23577/1" type="box" library_version="11">
type 0617, grid 22.5 mm</description>
<packageinstances>
<packageinstance name="0617/22"/>
</packageinstances>
</package3d>
<package3d name="0617V" urn="urn:adsk.eagle:package:23576/1" type="box" library_version="11">
type 0617, grid 5 mm</description>
<packageinstances>
<packageinstance name="0617V"/>
</packageinstances>
</package3d>
<package3d name="0922/22" urn="urn:adsk.eagle:package:23580/2" type="model" library_version="11">
type 0922, grid 22.5 mm</description>
<packageinstances>
<packageinstance name="0922/22"/>
</packageinstances>
</package3d>
<package3d name="P0613V" urn="urn:adsk.eagle:package:23582/1" type="box" library_version="11">
type 0613, grid 5 mm</description>
<packageinstances>
<packageinstance name="P0613V"/>
</packageinstances>
</package3d>
<package3d name="P0613/15" urn="urn:adsk.eagle:package:23581/2" type="model" library_version="11">
type 0613, grid 15 mm</description>
<packageinstances>
<packageinstance name="P0613/15"/>
</packageinstances>
</package3d>
<package3d name="P0817/22" urn="urn:adsk.eagle:package:23583/1" type="box" library_version="11">
type 0817, grid 22.5 mm</description>
<packageinstances>
<packageinstance name="P0817/22"/>
</packageinstances>
</package3d>
<package3d name="P0817V" urn="urn:adsk.eagle:package:23608/1" type="box" library_version="11">
type 0817, grid 6.35 mm</description>
<packageinstances>
<packageinstance name="P0817V"/>
</packageinstances>
</package3d>
<package3d name="V234/12" urn="urn:adsk.eagle:package:23592/1" type="box" library_version="11">
type V234, grid 12.5 mm</description>
<packageinstances>
<packageinstance name="V234/12"/>
</packageinstances>
</package3d>
<package3d name="V235/17" urn="urn:adsk.eagle:package:23586/2" type="model" library_version="11">
type V235, grid 17.78 mm</description>
<packageinstances>
<packageinstance name="V235/17"/>
</packageinstances>
</package3d>
<package3d name="V526-0" urn="urn:adsk.eagle:package:23590/1" type="box" library_version="11">
type V526-0, grid 2.5 mm</description>
<packageinstances>
<packageinstance name="V526-0"/>
</packageinstances>
</package3d>
<package3d name="MINI_MELF-0102R" urn="urn:adsk.eagle:package:23591/2" type="model" library_version="11">
<description>CECC Size RC2211 Reflow Soldering
source Beyschlag</description>
<packageinstances>
<packageinstance name="MINI_MELF-0102R"/>
</packageinstances>
</package3d>
<package3d name="MINI_MELF-0102W" urn="urn:adsk.eagle:package:23588/2" type="model" library_version="11">
<description>CECC Size RC2211 Wave Soldering
<packageinstances>
<packageinstance name="MINI_MELF-0102W"/>
</packageinstances>
</package3d>
<package3d name="MINI_MELF-0204R" urn="urn:adsk.eagle:package:26109/2" type="model" library_version="11">
<description>CECC Size RC3715 Reflow Soldering
<packageinstances>
<packageinstance name="MINI_MELF-0204R"/>
</packageinstances>
</package3d>
<package3d name="MINI_MELF-0204W" urn="urn:adsk.eagle:package:26111/2" type="model" library_version="11">
<description>CECC Size RC3715 Wave Soldering
<packageinstances>
<packageinstance name="MINI_MELF-0204W"/>
</packageinstances>
</package3d>
<package3d name="MINI_MELF-0207R" urn="urn:adsk.eagle:package:26113/2" type="model" library_version="11">
<description>CECC Size RC6123 Reflow Soldering
<packageinstances>
<packageinstance name="MINI_MELF-0207R"/>
</packageinstances>
</package3d>
<package3d name="MINI_MELF-0207W" urn="urn:adsk.eagle:package:26112/2" type="model" library_version="11">
<description>CECC Size RC6123 Wave Soldering
<packageinstances>
<packageinstance name="MINI_MELF-0207W"/>
</packageinstances>
</package3d>
<package3d name="0922V" urn="urn:adsk.eagle:package:23589/1" type="box" library_version="11">
type 0922, grid 7.5 mm</description>
<packageinstances>
<packageinstance name="0922V"/>
</packageinstances>
</package3d>
<package3d name="RDH/15" urn="urn:adsk.eagle:package:23595/1" type="box" library_version="11">
type RDH, grid 15 mm</description>
<packageinstances>
<packageinstance name="RDH/15"/>
</packageinstances>
</package3d>
<package3d name="MINI_MELF-0102AX" urn="urn:adsk.eagle:package:23594/1" type="box" library_version="11">
<description>Mini MELF 0102 Axial</description>
<packageinstances>
<packageinstance name="MINI_MELF-0102AX"/>
</packageinstances>
</package3d>
<package3d name="R0201" urn="urn:adsk.eagle:package:26117/2" type="model" library_version="11">
<description>RESISTOR chip
Source: http://www.vishay.com/docs/20008/dcrcw.pdf</description>
<packageinstances>
<packageinstance name="R0201"/>
</packageinstances>
</package3d>
<package3d name="VTA52" urn="urn:adsk.eagle:package:26116/2" type="model" library_version="11">
<description>Bulk Metal® Foil Technology, Tubular Axial Lead Resistors, Meets or Exceeds MIL-R-39005 Requirements
MIL SIZE RBR52
Source: VISHAY .. vta56.pdf</description>
<packageinstances>
<packageinstance name="VTA52"/>
</packageinstances>
</package3d>
<package3d name="VTA53" urn="urn:adsk.eagle:package:26118/2" type="model" library_version="11">
MIL SIZE RBR53
<packageinstances>
<packageinstance name="VTA53"/>
</packageinstances>
</package3d>
<package3d name="VTA54" urn="urn:adsk.eagle:package:26119/2" type="model" library_version="11">
MIL SIZE RBR54
<packageinstances>
<packageinstance name="VTA54"/>
</packageinstances>
</package3d>
<package3d name="VTA55" urn="urn:adsk.eagle:package:26120/2" type="model" library_version="11">
MIL SIZE RBR55
<packageinstances>
<packageinstance name="VTA55"/>
</packageinstances>
</package3d>
<package3d name="VTA56" urn="urn:adsk.eagle:package:26129/3" type="model" library_version="11">
MIL SIZE RBR56
<packageinstances>
<packageinstance name="VTA56"/>
</packageinstances>
</package3d>
<package3d name="VMTA55" urn="urn:adsk.eagle:package:26121/2" type="model" library_version="11">
MIL SIZE RNC55
<packageinstances>
<packageinstance name="VMTA55"/>
</packageinstances>
</package3d>
<package3d name="VMTB60" urn="urn:adsk.eagle:package:26122/2" type="model" library_version="11">
MIL SIZE RNC60
<packageinstances>
<packageinstance name="VMTB60"/>
</packageinstances>
</package3d>
<package3d name="R4527" urn="urn:adsk.eagle:package:13310/2" type="model" library_version="11">
<description>Package 4527
Source: http://www.vishay.com/docs/31059/wsrhigh.pdf</description>
<packageinstances>
<packageinstance name="R4527"/>
</packageinstances>
</package3d>
<package3d name="WSC0001" urn="urn:adsk.eagle:package:26123/2" type="model" library_version="11">
<description>Wirewound Resistors, Precision Power
Source: VISHAY wscwsn.pdf</description>
<packageinstances>
<packageinstance name="WSC0001"/>
</packageinstances>
</package3d>
<package3d name="WSC0002" urn="urn:adsk.eagle:package:26125/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="WSC0002"/>
</packageinstances>
</package3d>
<package3d name="WSC01/2" urn="urn:adsk.eagle:package:26127/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="WSC01/2"/>
</packageinstances>
</package3d>
<package3d name="WSC2515" urn="urn:adsk.eagle:package:26134/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="WSC2515"/>
</packageinstances>
</package3d>
<package3d name="WSC4527" urn="urn:adsk.eagle:package:26126/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="WSC4527"/>
</packageinstances>
</package3d>
<package3d name="WSC6927" urn="urn:adsk.eagle:package:26128/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="WSC6927"/>
</packageinstances>
</package3d>
<package3d name="R1218" urn="urn:adsk.eagle:package:26131/2" type="model" library_version="11">
<description>CRCW1218 Thick Film, Rectangular Chip Resistors
Source: http://www.vishay.com .. dcrcw.pdf</description>
<packageinstances>
<packageinstance name="R1218"/>
</packageinstances>
</package3d>
<package3d name="1812X7R" urn="urn:adsk.eagle:package:26130/2" type="model" library_version="11">
<description>Chip Monolithic Ceramic Capacitors Medium Voltage High Capacitance for General Use
Source: http://www.murata.com .. GRM43DR72E224KW01.pdf</description>
<packageinstances>
<packageinstance name="1812X7R"/>
</packageinstances>
</package3d>
<package3d name="PRL1632" urn="urn:adsk.eagle:package:26132/2" type="model" library_version="11">
<description>PRL1632 are realized as 1W for 3.2 × 1.6mm(1206)
Source: http://www.mouser.com/ds/2/392/products_18-2245.pdf</description>
<packageinstances>
<packageinstance name="PRL1632"/>
</packageinstances>
</package3d>
<package3d name="R01005" urn="urn:adsk.eagle:package:26133/2" type="model" library_version="11">
<description>Chip, 0.40 X 0.20 X 0.16 mm body
&lt;p&gt;Chip package with body size 0.40 X 0.20 X 0.16 mm&lt;/p&gt;</description>
<packageinstances>
<packageinstance name="R01005"/>
</packageinstances>
</package3d>
<package3d name="CAPC1005X60" urn="urn:adsk.eagle:package:23626/2" type="model" library_version="11">
<description>Chip, 1.00 X 0.50 X 0.60 mm body
&lt;p&gt;Chip package with body size 1.00 X 0.50 X 0.60 mm&lt;/p&gt;</description>
<packageinstances>
<packageinstance name="C0402"/>
</packageinstances>
</package3d>
<package3d name="C0504" urn="urn:adsk.eagle:package:23624/2" type="model" library_version="11">
<description>CAPACITOR</description>
<packageinstances>
<packageinstance name="C0504"/>
</packageinstances>
</package3d>
<package3d name="C0603" urn="urn:adsk.eagle:package:23616/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C0603"/>
</packageinstances>
</package3d>
<package3d name="C0805" urn="urn:adsk.eagle:package:23617/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C0805"/>
</packageinstances>
</package3d>
<package3d name="C1206" urn="urn:adsk.eagle:package:23618/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C1206"/>
</packageinstances>
</package3d>
<package3d name="C1210" urn="urn:adsk.eagle:package:23619/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C1210"/>
</packageinstances>
</package3d>
<package3d name="C1310" urn="urn:adsk.eagle:package:23620/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C1310"/>
</packageinstances>
</package3d>
<package3d name="C1608" urn="urn:adsk.eagle:package:23621/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C1608"/>
</packageinstances>
</package3d>
<package3d name="C1812" urn="urn:adsk.eagle:package:23622/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C1812"/>
</packageinstances>
</package3d>
<package3d name="C1825" urn="urn:adsk.eagle:package:23623/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C1825"/>
</packageinstances>
</package3d>
<package3d name="C2012" urn="urn:adsk.eagle:package:23625/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C2012"/>
</packageinstances>
</package3d>
<package3d name="C3216" urn="urn:adsk.eagle:package:23628/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C3216"/>
</packageinstances>
</package3d>
<package3d name="C3225" urn="urn:adsk.eagle:package:23655/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C3225"/>
</packageinstances>
</package3d>
<package3d name="C4532" urn="urn:adsk.eagle:package:23627/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C4532"/>
</packageinstances>
</package3d>
<package3d name="C4564" urn="urn:adsk.eagle:package:23648/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C4564"/>
</packageinstances>
</package3d>
<package3d name="C025-024X044" urn="urn:adsk.eagle:package:23630/1" type="box" library_version="11">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<packageinstances>
<packageinstance name="C025-024X044"/>
</packageinstances>
</package3d>
<package3d name="C025-025X050" urn="urn:adsk.eagle:package:23629/2" type="model" library_version="11">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<packageinstances>
<packageinstance name="C025-025X050"/>
</packageinstances>
</package3d>
<package3d name="C025-030X050" urn="urn:adsk.eagle:package:23631/1" type="box" library_version="11">
grid 2.5 mm, outline 3 x 5 mm</description>
<packageinstances>
<packageinstance name="C025-030X050"/>
</packageinstances>
</package3d>
<package3d name="C025-040X050" urn="urn:adsk.eagle:package:23634/1" type="box" library_version="11">
grid 2.5 mm, outline 4 x 5 mm</description>
<packageinstances>
<packageinstance name="C025-040X050"/>
</packageinstances>
</package3d>
<package3d name="C025-050X050" urn="urn:adsk.eagle:package:23633/1" type="box" library_version="11">
grid 2.5 mm, outline 5 x 5 mm</description>
<packageinstances>
<packageinstance name="C025-050X050"/>
</packageinstances>
</package3d>
<package3d name="C025-060X050" urn="urn:adsk.eagle:package:23632/1" type="box" library_version="11">
grid 2.5 mm, outline 6 x 5 mm</description>
<packageinstances>
<packageinstance name="C025-060X050"/>
</packageinstances>
</package3d>
<package3d name="C025_050-024X070" urn="urn:adsk.eagle:package:23639/1" type="box" library_version="11">
grid 2.5 mm + 5 mm, outline 2.4 x 7 mm</description>
<packageinstances>
<packageinstance name="C025_050-024X070"/>
</packageinstances>
</package3d>
<package3d name="C025_050-025X075" urn="urn:adsk.eagle:package:23641/1" type="box" library_version="11">
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C025_050-025X075"/>
</packageinstances>
</package3d>
<package3d name="C025_050-035X075" urn="urn:adsk.eagle:package:23651/1" type="box" library_version="11">
grid 2.5 + 5 mm, outline 3.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C025_050-035X075"/>
</packageinstances>
</package3d>
<package3d name="C025_050-045X075" urn="urn:adsk.eagle:package:23635/1" type="box" library_version="11">
grid 2.5 + 5 mm, outline 4.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C025_050-045X075"/>
</packageinstances>
</package3d>
<package3d name="C025_050-055X075" urn="urn:adsk.eagle:package:23636/1" type="box" library_version="11">
grid 2.5 + 5 mm, outline 5.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C025_050-055X075"/>
</packageinstances>
</package3d>
<package3d name="C050-024X044" urn="urn:adsk.eagle:package:23643/1" type="box" library_version="11">
grid 5 mm, outline 2.4 x 4.4 mm</description>
<packageinstances>
<packageinstance name="C050-024X044"/>
</packageinstances>
</package3d>
<package3d name="C050-025X075" urn="urn:adsk.eagle:package:23637/1" type="box" library_version="11">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C050-025X075"/>
</packageinstances>
</package3d>
<package3d name="C050-045X075" urn="urn:adsk.eagle:package:23638/1" type="box" library_version="11">
grid 5 mm, outline 4.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C050-045X075"/>
</packageinstances>
</package3d>
<package3d name="C050-030X075" urn="urn:adsk.eagle:package:23640/1" type="box" library_version="11">
grid 5 mm, outline 3 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C050-030X075"/>
</packageinstances>
</package3d>
<package3d name="C050-050X075" urn="urn:adsk.eagle:package:23665/1" type="box" library_version="11">
grid 5 mm, outline 5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C050-050X075"/>
</packageinstances>
</package3d>
<package3d name="C050-055X075" urn="urn:adsk.eagle:package:23642/1" type="box" library_version="11">
grid 5 mm, outline 5.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C050-055X075"/>
</packageinstances>
</package3d>
<package3d name="C050-075X075" urn="urn:adsk.eagle:package:23645/1" type="box" library_version="11">
grid 5 mm, outline 7.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C050-075X075"/>
</packageinstances>
</package3d>
<package3d name="C050H075X075" urn="urn:adsk.eagle:package:23644/1" type="box" library_version="11">
Horizontal, grid 5 mm, outline 7.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C050H075X075"/>
</packageinstances>
</package3d>
<package3d name="C075-032X103" urn="urn:adsk.eagle:package:23646/1" type="box" library_version="11">
grid 7.5 mm, outline 3.2 x 10.3 mm</description>
<packageinstances>
<packageinstance name="C075-032X103"/>
</packageinstances>
</package3d>
<package3d name="C075-042X103" urn="urn:adsk.eagle:package:23656/1" type="box" library_version="11">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
<packageinstances>
<packageinstance name="C075-042X103"/>
</packageinstances>
</package3d>
<package3d name="C075-052X106" urn="urn:adsk.eagle:package:23650/1" type="box" library_version="11">
grid 7.5 mm, outline 5.2 x 10.6 mm</description>
<packageinstances>
<packageinstance name="C075-052X106"/>
</packageinstances>
</package3d>
<package3d name="C102-043X133" urn="urn:adsk.eagle:package:23647/1" type="box" library_version="11">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
<packageinstances>
<packageinstance name="C102-043X133"/>
</packageinstances>
</package3d>
<package3d name="C102-054X133" urn="urn:adsk.eagle:package:23649/1" type="box" library_version="11">
grid 10.2 mm, outline 5.4 x 13.3 mm</description>
<packageinstances>
<packageinstance name="C102-054X133"/>
</packageinstances>
</package3d>
<package3d name="C102-064X133" urn="urn:adsk.eagle:package:23653/1" type="box" library_version="11">
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
<packageinstances>
<packageinstance name="C102-064X133"/>
</packageinstances>
</package3d>
<package3d name="C102_152-062X184" urn="urn:adsk.eagle:package:23652/1" type="box" library_version="11">
grid 10.2 mm + 15.2 mm, outline 6.2 x 18.4 mm</description>
<packageinstances>
<packageinstance name="C102_152-062X184"/>
</packageinstances>
</package3d>
<package3d name="C150-054X183" urn="urn:adsk.eagle:package:23669/1" type="box" library_version="11">
grid 15 mm, outline 5.4 x 18.3 mm</description>
<packageinstances>
<packageinstance name="C150-054X183"/>
</packageinstances>
</package3d>
<package3d name="C150-064X183" urn="urn:adsk.eagle:package:23654/1" type="box" library_version="11">
grid 15 mm, outline 6.4 x 18.3 mm</description>
<packageinstances>
<packageinstance name="C150-064X183"/>
</packageinstances>
</package3d>
<package3d name="C150-072X183" urn="urn:adsk.eagle:package:23657/1" type="box" library_version="11">
grid 15 mm, outline 7.2 x 18.3 mm</description>
<packageinstances>
<packageinstance name="C150-072X183"/>
</packageinstances>
</package3d>
<package3d name="C150-084X183" urn="urn:adsk.eagle:package:23658/1" type="box" library_version="11">
grid 15 mm, outline 8.4 x 18.3 mm</description>
<packageinstances>
<packageinstance name="C150-084X183"/>
</packageinstances>
</package3d>
<package3d name="C150-091X182" urn="urn:adsk.eagle:package:23659/1" type="box" library_version="11">
grid 15 mm, outline 9.1 x 18.2 mm</description>
<packageinstances>
<packageinstance name="C150-091X182"/>
</packageinstances>
</package3d>
<package3d name="C225-062X268" urn="urn:adsk.eagle:package:23661/1" type="box" library_version="11">
grid 22.5 mm, outline 6.2 x 26.8 mm</description>
<packageinstances>
<packageinstance name="C225-062X268"/>
</packageinstances>
</package3d>
<package3d name="C225-074X268" urn="urn:adsk.eagle:package:23660/1" type="box" library_version="11">
grid 22.5 mm, outline 7.4 x 26.8 mm</description>
<packageinstances>
<packageinstance name="C225-074X268"/>
</packageinstances>
</package3d>
<package3d name="C225-087X268" urn="urn:adsk.eagle:package:23662/1" type="box" library_version="11">
grid 22.5 mm, outline 8.7 x 26.8 mm</description>
<packageinstances>
<packageinstance name="C225-087X268"/>
</packageinstances>
</package3d>
<package3d name="C225-108X268" urn="urn:adsk.eagle:package:23663/1" type="box" library_version="11">
grid 22.5 mm, outline 10.8 x 26.8 mm</description>
<packageinstances>
<packageinstance name="C225-108X268"/>
</packageinstances>
</package3d>
<package3d name="C225-113X268" urn="urn:adsk.eagle:package:23667/1" type="box" library_version="11">
grid 22.5 mm, outline 11.3 x 26.8 mm</description>
<packageinstances>
<packageinstance name="C225-113X268"/>
</packageinstances>
</package3d>
<package3d name="C275-093X316" urn="urn:adsk.eagle:package:23701/1" type="box" library_version="11">
grid 27.5 mm, outline 9.3 x 31.6 mm</description>
<packageinstances>
<packageinstance name="C275-093X316"/>
</packageinstances>
</package3d>
<package3d name="C275-113X316" urn="urn:adsk.eagle:package:23673/1" type="box" library_version="11">
grid 27.5 mm, outline 11.3 x 31.6 mm</description>
<packageinstances>
<packageinstance name="C275-113X316"/>
</packageinstances>
</package3d>
<package3d name="C275-134X316" urn="urn:adsk.eagle:package:23664/1" type="box" library_version="11">
grid 27.5 mm, outline 13.4 x 31.6 mm</description>
<packageinstances>
<packageinstance name="C275-134X316"/>
</packageinstances>
</package3d>
<package3d name="C275-205X316" urn="urn:adsk.eagle:package:23666/1" type="box" library_version="11">
grid 27.5 mm, outline 20.5 x 31.6 mm</description>
<packageinstances>
<packageinstance name="C275-205X316"/>
</packageinstances>
</package3d>
<package3d name="C325-137X374" urn="urn:adsk.eagle:package:23672/1" type="box" library_version="11">
grid 32.5 mm, outline 13.7 x 37.4 mm</description>
<packageinstances>
<packageinstance name="C325-137X374"/>
</packageinstances>
</package3d>
<package3d name="C325-162X374" urn="urn:adsk.eagle:package:23670/1" type="box" library_version="11">
grid 32.5 mm, outline 16.2 x 37.4 mm</description>
<packageinstances>
<packageinstance name="C325-162X374"/>
</packageinstances>
</package3d>
<package3d name="C325-182X374" urn="urn:adsk.eagle:package:23668/1" type="box" library_version="11">
grid 32.5 mm, outline 18.2 x 37.4 mm</description>
<packageinstances>
<packageinstance name="C325-182X374"/>
</packageinstances>
</package3d>
<package3d name="C375-192X418" urn="urn:adsk.eagle:package:23674/1" type="box" library_version="11">
grid 37.5 mm, outline 19.2 x 41.8 mm</description>
<packageinstances>
<packageinstance name="C375-192X418"/>
</packageinstances>
</package3d>
<package3d name="C375-203X418" urn="urn:adsk.eagle:package:23671/1" type="box" library_version="11">
grid 37.5 mm, outline 20.3 x 41.8 mm</description>
<packageinstances>
<packageinstance name="C375-203X418"/>
</packageinstances>
</package3d>
<package3d name="C050-035X075" urn="urn:adsk.eagle:package:23677/1" type="box" library_version="11">
grid 5 mm, outline 3.5 x 7.5 mm</description>
<packageinstances>
<packageinstance name="C050-035X075"/>
</packageinstances>
</package3d>
<package3d name="C375-155X418" urn="urn:adsk.eagle:package:23675/1" type="box" library_version="11">
grid 37.5 mm, outline 15.5 x 41.8 mm</description>
<packageinstances>
<packageinstance name="C375-155X418"/>
</packageinstances>
</package3d>
<package3d name="C075-063X106" urn="urn:adsk.eagle:package:23678/1" type="box" library_version="11">
grid 7.5 mm, outline 6.3 x 10.6 mm</description>
<packageinstances>
<packageinstance name="C075-063X106"/>
</packageinstances>
</package3d>
<package3d name="C275-154X316" urn="urn:adsk.eagle:package:23685/1" type="box" library_version="11">
grid 27.5 mm, outline 15.4 x 31.6 mm</description>
<packageinstances>
<packageinstance name="C275-154X316"/>
</packageinstances>
</package3d>
<package3d name="C275-173X316" urn="urn:adsk.eagle:package:23676/1" type="box" library_version="11">
grid 27.5 mm, outline 17.3 x 31.6 mm</description>
<packageinstances>
<packageinstance name="C275-173X316"/>
</packageinstances>
</package3d>
<package3d name="C0402K" urn="urn:adsk.eagle:package:23679/2" type="model" library_version="11">
<description>Ceramic Chip Capacitor KEMET 0204 reflow solder
Metric Code Size 1005</description>
<packageinstances>
<packageinstance name="C0402K"/>
</packageinstances>
</package3d>
<package3d name="C0603K" urn="urn:adsk.eagle:package:23680/2" type="model" library_version="11">
<description>Ceramic Chip Capacitor KEMET 0603 reflow solder
Metric Code Size 1608</description>
<packageinstances>
<packageinstance name="C0603K"/>
</packageinstances>
</package3d>
<package3d name="C0805K" urn="urn:adsk.eagle:package:23681/2" type="model" library_version="11">
<description>Ceramic Chip Capacitor KEMET 0805 reflow solder
Metric Code Size 2012</description>
<packageinstances>
<packageinstance name="C0805K"/>
</packageinstances>
</package3d>
<package3d name="C1206K" urn="urn:adsk.eagle:package:23682/2" type="model" library_version="11">
<description>Ceramic Chip Capacitor KEMET 1206 reflow solder
Metric Code Size 3216</description>
<packageinstances>
<packageinstance name="C1206K"/>
</packageinstances>
</package3d>
<package3d name="C1210K" urn="urn:adsk.eagle:package:23683/2" type="model" library_version="11">
<description>Ceramic Chip Capacitor KEMET 1210 reflow solder
Metric Code Size 3225</description>
<packageinstances>
<packageinstance name="C1210K"/>
</packageinstances>
</package3d>
<package3d name="C1812K" urn="urn:adsk.eagle:package:23686/2" type="model" library_version="11">
<description>Ceramic Chip Capacitor KEMET 1812 reflow solder
Metric Code Size 4532</description>
<packageinstances>
<packageinstance name="C1812K"/>
</packageinstances>
</package3d>
<package3d name="C1825K" urn="urn:adsk.eagle:package:23684/2" type="model" library_version="11">
<description>Ceramic Chip Capacitor KEMET 1825 reflow solder
Metric Code Size 4564</description>
<packageinstances>
<packageinstance name="C1825K"/>
</packageinstances>
</package3d>
<package3d name="C2220K" urn="urn:adsk.eagle:package:23687/2" type="model" library_version="11">
<description>Ceramic Chip Capacitor KEMET 2220 reflow solderMetric Code Size 5650</description>
<packageinstances>
<packageinstance name="C2220K"/>
</packageinstances>
</package3d>
<package3d name="C2225K" urn="urn:adsk.eagle:package:23692/2" type="model" library_version="11">
<description>Ceramic Chip Capacitor KEMET 2225 reflow solderMetric Code Size 5664</description>
<packageinstances>
<packageinstance name="C2225K"/>
</packageinstances>
</package3d>
<package3d name="HPC0201" urn="urn:adsk.eagle:package:26213/1" type="box" library_version="11">
<description>
Source: http://www.vishay.com/docs/10129/hpc0201a.pdf</description>
<packageinstances>
<packageinstance name="HPC0201"/>
</packageinstances>
</package3d>
<package3d name="C0201" urn="urn:adsk.eagle:package:23690/2" type="model" library_version="11">
<description>Source: http://www.avxcorp.com/docs/catalogs/cx5r.pdf</description>
<packageinstances>
<packageinstance name="C0201"/>
</packageinstances>
</package3d>
<package3d name="C1808" urn="urn:adsk.eagle:package:23689/2" type="model" library_version="11">
Source: AVX .. aphvc.pdf</description>
<packageinstances>
<packageinstance name="C1808"/>
</packageinstances>
</package3d>
<package3d name="C3640" urn="urn:adsk.eagle:package:23693/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="C3640"/>
</packageinstances>
</package3d>
<package3d name="C01005" urn="urn:adsk.eagle:package:23691/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="C01005"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3304W" urn="urn:adsk.eagle:package:23725/1" type="box" library_version="11">
<description>Trimm resistor BOURNS
0,1W 25%</description>
<packageinstances>
<packageinstance name="RTRIM3304W"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3165W" urn="urn:adsk.eagle:package:23723/1" type="box" library_version="11">
<description>Trimm resistor MEGGIT</description>
<packageinstances>
<packageinstance name="RTRIM3165W"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3202" urn="urn:adsk.eagle:package:23719/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM3202"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3314J" urn="urn:adsk.eagle:package:26019/1" type="box" library_version="11">
0,25W, 20%
Source:  Data sheet</description>
<packageinstances>
<packageinstance name="RTRIM3314J"/>
</packageinstances>
</package3d>
<package3d name="RTRIM4G/J" urn="urn:adsk.eagle:package:23728/1" type="box" library_version="11">
<description>Trimm resistor VISHAY</description>
<packageinstances>
<packageinstance name="RTRIM4G/J"/>
</packageinstances>
</package3d>
<package3d name="RTRIMCVR42A" urn="urn:adsk.eagle:package:23735/1" type="box" library_version="11">
<description>Trimm resistor AVX</description>
<packageinstances>
<packageinstance name="RTRIMCVR42A"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3214W" urn="urn:adsk.eagle:package:23729/1" type="box" library_version="11">
SMD Cermet trimmer</description>
<packageinstances>
<packageinstance name="RTRIM3214W"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3224G" urn="urn:adsk.eagle:package:23730/1" type="box" library_version="11">
Side Adjust</description>
<packageinstances>
<packageinstance name="RTRIM3224G"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3224J" urn="urn:adsk.eagle:package:23734/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM3224J"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3224X" urn="urn:adsk.eagle:package:23732/1" type="box" library_version="11">
Top Adjust</description>
<packageinstances>
<packageinstance name="RTRIM3224X"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3103" urn="urn:adsk.eagle:package:23720/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM3103"/>
</packageinstances>
</package3d>
<package3d name="RTRIM5W" urn="urn:adsk.eagle:package:23731/1" type="box" library_version="11">
<description>Trimm resistor Spectrol
abgedichtet nach IP67</description>
<packageinstances>
<packageinstance name="RTRIM5W"/>
</packageinstances>
</package3d>
<package3d name="RTRIM5X" urn="urn:adsk.eagle:package:23743/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM5X"/>
</packageinstances>
</package3d>
<package3d name="RTRIMTSM53YJ" urn="urn:adsk.eagle:package:26035/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIMTSM53YJ"/>
</packageinstances>
</package3d>
<package3d name="RTRIMTSM53YL" urn="urn:adsk.eagle:package:23733/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIMTSM53YL"/>
</packageinstances>
</package3d>
<package3d name="RTRIMTS63X" urn="urn:adsk.eagle:package:23736/1" type="box" library_version="11">
<description>Trimm resistror VISHAY
seales container, solder immerson IP67</description>
<packageinstances>
<packageinstance name="RTRIMTS63X"/>
</packageinstances>
</package3d>
<package3d name="RTRIMTS63Y" urn="urn:adsk.eagle:package:23740/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIMTS63Y"/>
</packageinstances>
</package3d>
<package3d name="RTRIMTS63Z" urn="urn:adsk.eagle:package:23742/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIMTS63Z"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3296P" urn="urn:adsk.eagle:package:26032/1" type="box" library_version="11">
Source:  Data sheet </description>
<packageinstances>
<packageinstance name="RTRIM3296P"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3296W" urn="urn:adsk.eagle:package:26033/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM3296W"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3296X" urn="urn:adsk.eagle:package:26034/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM3296X"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3296Y" urn="urn:adsk.eagle:package:26036/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM3296Y"/>
</packageinstances>
</package3d>
<package3d name="RTRIM74W" urn="urn:adsk.eagle:package:23745/1" type="box" library_version="11">
<description>Trimm resistor Spectrol</description>
<packageinstances>
<packageinstance name="RTRIM74W"/>
</packageinstances>
</package3d>
<package3d name="RTRIM74X" urn="urn:adsk.eagle:package:23746/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM74X"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3224W" urn="urn:adsk.eagle:package:23744/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM3224W"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3339P" urn="urn:adsk.eagle:package:23757/1" type="box" library_version="11">
Cermet MIL-R-22097</description>
<packageinstances>
<packageinstance name="RTRIM3339P"/>
</packageinstances>
</package3d>
<package3d name="RTRIM64P" urn="urn:adsk.eagle:package:23747/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM64P"/>
</packageinstances>
</package3d>
<package3d name="RTRIM64W" urn="urn:adsk.eagle:package:23748/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM64W"/>
</packageinstances>
</package3d>
<package3d name="RTRIM64X" urn="urn:adsk.eagle:package:23749/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM64X"/>
</packageinstances>
</package3d>
<package3d name="RTRIM64Y" urn="urn:adsk.eagle:package:23750/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM64Y"/>
</packageinstances>
</package3d>
<package3d name="RTRIM64Z" urn="urn:adsk.eagle:package:23754/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM64Z"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3059Y" urn="urn:adsk.eagle:package:23752/1" type="box" library_version="11">
waschfest MIL-R-22097</description>
<packageinstances>
<packageinstance name="RTRIM3059Y"/>
</packageinstances>
</package3d>
<package3d name="RTRIM70Y" urn="urn:adsk.eagle:package:23753/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM70Y"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3374" urn="urn:adsk.eagle:package:23724/1" type="box" library_version="11">
<description>Trimm resistor BOURNS</description>
<packageinstances>
<packageinstance name="RTRIM3374"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3299W" urn="urn:adsk.eagle:package:23755/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM3299W"/>
</packageinstances>
</package3d>
<package3d name="RTRIM43P" urn="urn:adsk.eagle:package:23756/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM43P"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3006P" urn="urn:adsk.eagle:package:23758/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIM3006P"/>
</packageinstances>
</package3d>
<package3d name="RTRIMT18" urn="urn:adsk.eagle:package:23760/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIMT18"/>
</packageinstances>
</package3d>
<package3d name="RTRIMT93XA" urn="urn:adsk.eagle:package:23759/1" type="box" library_version="11">
Cermet, abgedichtet nach IP67</description>
<packageinstances>
<packageinstance name="RTRIMT93XA"/>
</packageinstances>
</package3d>
<package3d name="RTRIMT93XB" urn="urn:adsk.eagle:package:23761/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIMT93XB"/>
</packageinstances>
</package3d>
<package3d name="RTRIMT93YA" urn="urn:adsk.eagle:package:23764/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIMT93YA"/>
</packageinstances>
</package3d>
<package3d name="RTRIMT93YB" urn="urn:adsk.eagle:package:23763/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="RTRIMT93YB"/>
</packageinstances>
</package3d>
<package3d name="RTRIM3314G" urn="urn:adsk.eagle:package:26056/1" type="box" library_version="11">
0,25W, 20%
<packageinstances>
<packageinstance name="RTRIM3314G"/>
</packageinstances>
</package3d>
<package3d name="CT3216" urn="urn:adsk.eagle:package:23327/2" type="model" library_version="11">
<description>TANTALUM CAPACITOR</description>
<packageinstances>
<packageinstance name="CT3216"/>
</packageinstances>
</package3d>
<package3d name="CT3528" urn="urn:adsk.eagle:package:23325/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="CT3528"/>
</packageinstances>
</package3d>
<package3d name="CT6032" urn="urn:adsk.eagle:package:23305/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="CT6032"/>
</packageinstances>
</package3d>
<package3d name="CT7343" urn="urn:adsk.eagle:package:23304/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="CT7343"/>
</packageinstances>
</package3d>
<package3d name="B45181A" urn="urn:adsk.eagle:package:23316/1" type="box" library_version="11">
<description>ELECTROLYTIC CAPACITOR
body 5 x 5 mm, rectangle, grid 2.54 mm</description>
<packageinstances>
<packageinstance name="B45181A"/>
</packageinstances>
</package3d>
<package3d name="B45181B" urn="urn:adsk.eagle:package:23320/1" type="box" library_version="11">
body 7.6 x 5 mm, rectangle, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="B45181B"/>
</packageinstances>
</package3d>
<package3d name="B45181C" urn="urn:adsk.eagle:package:23306/1" type="box" library_version="11">
body 12.7 x 7.6 mm, rectangle, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="B45181C"/>
</packageinstances>
</package3d>
<package3d name="B45181D" urn="urn:adsk.eagle:package:23308/1" type="box" library_version="11">
body 12.5 x 12.5 mm, rectangle, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="B45181D"/>
</packageinstances>
</package3d>
<package3d name="TT2D4" urn="urn:adsk.eagle:package:23310/1" type="box" library_version="11">
diameter 4 mm, grid 2.54 mm</description>
<packageinstances>
<packageinstance name="TT2D4"/>
</packageinstances>
</package3d>
<package3d name="TT2D4L" urn="urn:adsk.eagle:package:23321/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="TT2D4L"/>
</packageinstances>
</package3d>
<package3d name="TT2D5" urn="urn:adsk.eagle:package:23300/1" type="box" library_version="11">
diameter 5 mm, grid 2.54 mm</description>
<packageinstances>
<packageinstance name="TT2D5"/>
</packageinstances>
</package3d>
<package3d name="TT2D6" urn="urn:adsk.eagle:package:23303/1" type="box" library_version="11">
diameter 6 mm, grid 2.54 mm</description>
<packageinstances>
<packageinstance name="TT2D6"/>
</packageinstances>
</package3d>
<package3d name="TT2D6L" urn="urn:adsk.eagle:package:23323/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="TT2D6L"/>
</packageinstances>
</package3d>
<package3d name="TT2D7L" urn="urn:adsk.eagle:package:23329/1" type="box" library_version="11">
diameter 7 mm, grid 2.54 mm</description>
<packageinstances>
<packageinstance name="TT2D7L"/>
</packageinstances>
</package3d>
<package3d name="TT2D7" urn="urn:adsk.eagle:package:23319/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="TT2D7"/>
</packageinstances>
</package3d>
<package3d name="TT5D10" urn="urn:adsk.eagle:package:23302/1" type="box" library_version="11">
diameter 10 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D10"/>
</packageinstances>
</package3d>
<package3d name="TT5D11" urn="urn:adsk.eagle:package:23309/1" type="box" library_version="11">
diameter 11 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D11"/>
</packageinstances>
</package3d>
<package3d name="TT5D11L" urn="urn:adsk.eagle:package:23312/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="TT5D11L"/>
</packageinstances>
</package3d>
<package3d name="TT5D6" urn="urn:adsk.eagle:package:23307/1" type="box" library_version="11">
diameter 6 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D6"/>
</packageinstances>
</package3d>
<package3d name="TT5D6L" urn="urn:adsk.eagle:package:23324/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="TT5D6L"/>
</packageinstances>
</package3d>
<package3d name="TT5D7" urn="urn:adsk.eagle:package:23314/1" type="box" library_version="11">
diameter 7 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D7"/>
</packageinstances>
</package3d>
<package3d name="TT5D7L" urn="urn:adsk.eagle:package:23318/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="TT5D7L"/>
</packageinstances>
</package3d>
<package3d name="TT5D9" urn="urn:adsk.eagle:package:23301/1" type="box" library_version="11">
diameter 9 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TT5D9"/>
</packageinstances>
</package3d>
<package3d name="TT5D9L" urn="urn:adsk.eagle:package:23313/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="TT5D9L"/>
</packageinstances>
</package3d>
<package3d name="ETR1" urn="urn:adsk.eagle:package:23322/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="ETR1"/>
</packageinstances>
</package3d>
<package3d name="ETR2" urn="urn:adsk.eagle:package:23315/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="ETR2"/>
</packageinstances>
</package3d>
<package3d name="ETR3" urn="urn:adsk.eagle:package:23311/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="ETR3"/>
</packageinstances>
</package3d>
<package3d name="ETR4" urn="urn:adsk.eagle:package:23317/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="ETR4"/>
</packageinstances>
</package3d>
<package3d name="ETR5" urn="urn:adsk.eagle:package:23328/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="ETR5"/>
</packageinstances>
</package3d>
<package3d name="P128-35" urn="urn:adsk.eagle:package:25807/1" type="box" library_version="11">
<description>ELECTROLYTIC CAPACITOR</description>
<packageinstances>
<packageinstance name="P128-35"/>
</packageinstances>
</package3d>
<package3d name="P128-40" urn="urn:adsk.eagle:package:23331/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="P128-40"/>
</packageinstances>
</package3d>
<package3d name="P128-50" urn="urn:adsk.eagle:package:23330/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="P128-50"/>
</packageinstances>
</package3d>
<package3d name="P128-60" urn="urn:adsk.eagle:package:23337/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="P128-60"/>
</packageinstances>
</package3d>
<package3d name="TAP5-45" urn="urn:adsk.eagle:package:23333/3" type="model" library_version="11">
diameter 4.5 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-45"/>
</packageinstances>
</package3d>
<package3d name="TAP5-50" urn="urn:adsk.eagle:package:23335/1" type="box" library_version="11">
diameter 5.0 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-50"/>
</packageinstances>
</package3d>
<package3d name="TAP5-70" urn="urn:adsk.eagle:package:23332/1" type="box" library_version="11">
diameter 7.0 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-70"/>
</packageinstances>
</package3d>
<package3d name="TAP5-60" urn="urn:adsk.eagle:package:23334/1" type="box" library_version="11">
diameter 6.0 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-60"/>
</packageinstances>
</package3d>
<package3d name="TAP5-80" urn="urn:adsk.eagle:package:23338/1" type="box" library_version="11">
diameter 8.0 mm, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="TAP5-80"/>
</packageinstances>
</package3d>
<package3d name="E1,8-4" urn="urn:adsk.eagle:package:23336/2" type="model" library_version="11">
grid 1.8 mm, diameter 4 mm</description>
<packageinstances>
<packageinstance name="E1,8-4"/>
</packageinstances>
</package3d>
<package3d name="E15-5" urn="urn:adsk.eagle:package:23341/1" type="box" library_version="11">
grid 15.24 mm, diameter 5 mm</description>
<packageinstances>
<packageinstance name="E15-5"/>
</packageinstances>
</package3d>
<package3d name="E15-6" urn="urn:adsk.eagle:package:23339/1" type="box" library_version="11">
grid 15.24 mm, diameter 6 mm</description>
<packageinstances>
<packageinstance name="E15-6"/>
</packageinstances>
</package3d>
<package3d name="E15-9" urn="urn:adsk.eagle:package:23340/1" type="box" library_version="11">
grid 15.24 mm, diameter 9 mm</description>
<packageinstances>
<packageinstance name="E15-9"/>
</packageinstances>
</package3d>
<package3d name="E2,5-4R" urn="urn:adsk.eagle:package:23342/1" type="box" library_version="11">
grid 2.54 mm, diameter 4 mm</description>
<packageinstances>
<packageinstance name="E2,5-4R"/>
</packageinstances>
</package3d>
<package3d name="E2,5-5" urn="urn:adsk.eagle:package:23344/1" type="box" library_version="11">
grid 2.54 mm, diameter 5 mm</description>
<packageinstances>
<packageinstance name="E2,5-5"/>
</packageinstances>
</package3d>
<package3d name="E2,5-6" urn="urn:adsk.eagle:package:23349/1" type="box" library_version="11">
grid 2.54 mm, diameter 6 mm</description>
<packageinstances>
<packageinstance name="E2,5-6"/>
</packageinstances>
</package3d>
<package3d name="E2,5-7" urn="urn:adsk.eagle:package:23345/1" type="box" library_version="11">
grid 2.54 mm, diameter 7 mm</description>
<packageinstances>
<packageinstance name="E2,5-7"/>
</packageinstances>
</package3d>
<package3d name="E2,5RE" urn="urn:adsk.eagle:package:23343/1" type="box" library_version="11">
grid 2.54 mm, diameter 4 mm,</description>
<packageinstances>
<packageinstance name="E2,5RE"/>
</packageinstances>
</package3d>
<package3d name="E2-4" urn="urn:adsk.eagle:package:23347/1" type="box" library_version="11">
grid 2 mm, diameter 4 mm</description>
<packageinstances>
<packageinstance name="E2-4"/>
</packageinstances>
</package3d>
<package3d name="E2-5" urn="urn:adsk.eagle:package:23346/2" type="model" library_version="11">
grid 2.032 mm, diameter 5 mm</description>
<packageinstances>
<packageinstance name="E2-5"/>
</packageinstances>
</package3d>
<package3d name="E22-10" urn="urn:adsk.eagle:package:23348/1" type="box" library_version="11">
grid 22.86 mm, diameter 10 mm</description>
<packageinstances>
<packageinstance name="E22-10"/>
</packageinstances>
</package3d>
<package3d name="E22-6" urn="urn:adsk.eagle:package:23359/1" type="box" library_version="11">
grid 22.86 mm, diameter 6 mm</description>
<packageinstances>
<packageinstance name="E22-6"/>
</packageinstances>
</package3d>
<package3d name="E22-9" urn="urn:adsk.eagle:package:23350/1" type="box" library_version="11">
grid 22.86 mm, diameter 9 mm</description>
<packageinstances>
<packageinstance name="E22-9"/>
</packageinstances>
</package3d>
<package3d name="E3,5-10" urn="urn:adsk.eagle:package:23351/1" type="box" library_version="11">
grid 3.5 mm, diameter 10 mm</description>
<packageinstances>
<packageinstance name="E3,5-10"/>
</packageinstances>
</package3d>
<package3d name="E25-10" urn="urn:adsk.eagle:package:23352/1" type="box" library_version="11">
grid 25.4 mm, diameter 10 mm</description>
<packageinstances>
<packageinstance name="E25-10"/>
</packageinstances>
</package3d>
<package3d name="E25-9" urn="urn:adsk.eagle:package:23358/1" type="box" library_version="11">
grid 25.4 mm, diameter 9 mm</description>
<packageinstances>
<packageinstance name="E25-9"/>
</packageinstances>
</package3d>
<package3d name="E3,5-8" urn="urn:adsk.eagle:package:23360/2" type="model" library_version="11">
grid 3.5 mm, diameter 8 mm</description>
<packageinstances>
<packageinstance name="E3,5-8"/>
</packageinstances>
</package3d>
<package3d name="E30-10" urn="urn:adsk.eagle:package:23355/1" type="box" library_version="11">
grid 30.48 mm, diameter 10 mm</description>
<packageinstances>
<packageinstance name="E30-10"/>
</packageinstances>
</package3d>
<package3d name="E30-12" urn="urn:adsk.eagle:package:23354/1" type="box" library_version="11">
grid 30.48 mm, diameter 12 mm</description>
<packageinstances>
<packageinstance name="E30-12"/>
</packageinstances>
</package3d>
<package3d name="E30-16" urn="urn:adsk.eagle:package:23353/1" type="box" library_version="11">
grid 30.48 mm, diameter 16 mm</description>
<packageinstances>
<packageinstance name="E30-16"/>
</packageinstances>
</package3d>
<package3d name="E35-12" urn="urn:adsk.eagle:package:23357/1" type="box" library_version="11">
grid 35.56 mm, diameter 12 mm</description>
<packageinstances>
<packageinstance name="E35-12"/>
</packageinstances>
</package3d>
<package3d name="E35-14" urn="urn:adsk.eagle:package:23377/1" type="box" library_version="11">
grid 30.48 mm, diameter 14 mm</description>
<packageinstances>
<packageinstance name="E35-14"/>
</packageinstances>
</package3d>
<package3d name="E35-16" urn="urn:adsk.eagle:package:23362/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="E35-16"/>
</packageinstances>
</package3d>
<package3d name="E35-18" urn="urn:adsk.eagle:package:23356/1" type="box" library_version="11">
grid 30.48 mm, diameter 18 mm</description>
<packageinstances>
<packageinstance name="E35-18"/>
</packageinstances>
</package3d>
<package3d name="E45-16" urn="urn:adsk.eagle:package:23365/1" type="box" library_version="11">
grid 45.72 mm, diameter 16 mm</description>
<packageinstances>
<packageinstance name="E45-16"/>
</packageinstances>
</package3d>
<package3d name="E45-18" urn="urn:adsk.eagle:package:23361/1" type="box" library_version="11">
grid 45.72 mm, diameter 18 mm</description>
<packageinstances>
<packageinstance name="E45-18"/>
</packageinstances>
</package3d>
<package3d name="E45-21" urn="urn:adsk.eagle:package:23363/1" type="box" library_version="11">
grid 45.72 mm, diameter 21 mm</description>
<packageinstances>
<packageinstance name="E45-21"/>
</packageinstances>
</package3d>
<package3d name="E45-22" urn="urn:adsk.eagle:package:23366/1" type="box" library_version="11">
grid 45.72 mm, diameter 22 mm</description>
<packageinstances>
<packageinstance name="E45-22"/>
</packageinstances>
</package3d>
<package3d name="E45-25" urn="urn:adsk.eagle:package:23364/1" type="box" library_version="11">
grid 45.72 mm, diameter 25 mm</description>
<packageinstances>
<packageinstance name="E45-25"/>
</packageinstances>
</package3d>
<package3d name="E5-10,5" urn="urn:adsk.eagle:package:23372/2" type="model" library_version="11">
grid 5.08 mm, diameter 10.5 mm</description>
<packageinstances>
<packageinstance name="E5-10,5"/>
</packageinstances>
</package3d>
<package3d name="E5-13" urn="urn:adsk.eagle:package:23375/1" type="box" library_version="11">
grid 5.08 mm, diameter 13 mm</description>
<packageinstances>
<packageinstance name="E5-13"/>
</packageinstances>
</package3d>
<package3d name="E5-4" urn="urn:adsk.eagle:package:23370/1" type="box" library_version="11">
grid 5.05 mm, diameter 4 mm</description>
<packageinstances>
<packageinstance name="E5-4"/>
</packageinstances>
</package3d>
<package3d name="E5-5" urn="urn:adsk.eagle:package:23367/2" type="model" library_version="11">
grid 5.08 mm, diameter 5 mm</description>
<packageinstances>
<packageinstance name="E5-5"/>
</packageinstances>
</package3d>
<package3d name="E5-6" urn="urn:adsk.eagle:package:23368/1" type="box" library_version="11">
grid 5.08 mm, diameter 6 mm</description>
<packageinstances>
<packageinstance name="E5-6"/>
</packageinstances>
</package3d>
<package3d name="E5-8,5" urn="urn:adsk.eagle:package:23374/1" type="box" library_version="11">
grid 5.08 mm, diameter 8.5 mm</description>
<packageinstances>
<packageinstance name="E5-8,5"/>
</packageinstances>
</package3d>
<package3d name="E50-25" urn="urn:adsk.eagle:package:23369/1" type="box" library_version="11">
grid 50 mm, diameter 25 mm</description>
<packageinstances>
<packageinstance name="E50-25"/>
</packageinstances>
</package3d>
<package3d name="E50-30" urn="urn:adsk.eagle:package:23371/1" type="box" library_version="11">
grid 50 mm, diameter 30 mm</description>
<packageinstances>
<packageinstance name="E50-30"/>
</packageinstances>
</package3d>
<package3d name="E55-25" urn="urn:adsk.eagle:package:23376/1" type="box" library_version="11">
grid 55 mm, diameter 25 mm</description>
<packageinstances>
<packageinstance name="E55-25"/>
</packageinstances>
</package3d>
<package3d name="E55-30" urn="urn:adsk.eagle:package:23378/1" type="box" library_version="11">
grid 55 mm, diameter 30 mm</description>
<packageinstances>
<packageinstance name="E55-30"/>
</packageinstances>
</package3d>
<package3d name="E5R" urn="urn:adsk.eagle:package:23373/1" type="box" library_version="11">
grid 5.08 mm, diameter 9 mm</description>
<packageinstances>
<packageinstance name="E5R"/>
</packageinstances>
</package3d>
<package3d name="E7,5-16" urn="urn:adsk.eagle:package:23382/2" type="model" library_version="11">
grid 7.62 mm, diameter 16 mm</description>
<packageinstances>
<packageinstance name="E7,5-16"/>
</packageinstances>
</package3d>
<package3d name="E7,5-18" urn="urn:adsk.eagle:package:23379/1" type="box" library_version="11">
grid 7.62 mm, diameter 18 mm</description>
<packageinstances>
<packageinstance name="E7,5-18"/>
</packageinstances>
</package3d>
<package3d name="EB20D" urn="urn:adsk.eagle:package:23381/1" type="box" library_version="11">
grid 10.16 mm, diameter 20 mm</description>
<packageinstances>
<packageinstance name="EB20D"/>
</packageinstances>
</package3d>
<package3d name="EB22,5D" urn="urn:adsk.eagle:package:23380/1" type="box" library_version="11">
grid 10.16 mm, diameter 22.5 mm</description>
<packageinstances>
<packageinstance name="EB22,5D"/>
</packageinstances>
</package3d>
<package3d name="EB25D" urn="urn:adsk.eagle:package:23399/1" type="box" library_version="11">
grid 10.16 mm, diameter 25 mm</description>
<packageinstances>
<packageinstance name="EB25D"/>
</packageinstances>
</package3d>
<package3d name="EB30D" urn="urn:adsk.eagle:package:23389/1" type="box" library_version="11">
grid 10.16 mm, diameter 30 mm</description>
<packageinstances>
<packageinstance name="EB30D"/>
</packageinstances>
</package3d>
<package3d name="EB35D" urn="urn:adsk.eagle:package:23395/1" type="box" library_version="11">
grid 10.16 mm, diameter 35 mm</description>
<packageinstances>
<packageinstance name="EB35D"/>
</packageinstances>
</package3d>
<package3d name="085CS_1R" urn="urn:adsk.eagle:package:23383/1" type="box" library_version="11">
<description>Aluminum electrolytic capacitors reflow soldering
SMD (Chip) Standard 085 CS
http://www.bccomponents.com/</description>
<packageinstances>
<packageinstance name="085CS_1R"/>
</packageinstances>
</package3d>
<package3d name="085CS_1W" urn="urn:adsk.eagle:package:23384/1" type="box" library_version="11">
<description>Aluminum electrolytic capacitors wave soldering
<packageinstances>
<packageinstance name="085CS_1W"/>
</packageinstances>
</package3d>
<package3d name="085CS_1AR" urn="urn:adsk.eagle:package:23396/3" type="box" library_version="11">
<packageinstances>
<packageinstance name="085CS_1AR"/>
</packageinstances>
</package3d>
<package3d name="085CS_1AW" urn="urn:adsk.eagle:package:23385/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="085CS_1AW"/>
</packageinstances>
</package3d>
<package3d name="139CLL-2R" urn="urn:adsk.eagle:package:23387/3" type="model" library_version="11">
SMD (Chip) Long Life 139 CLL
<packageinstances>
<packageinstance name="139CLL-2R"/>
</packageinstances>
</package3d>
<package3d name="139CLL-2W" urn="urn:adsk.eagle:package:23386/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="139CLL-2W"/>
</packageinstances>
</package3d>
<package3d name="139CLL-3R" urn="urn:adsk.eagle:package:23388/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="139CLL-3R"/>
</packageinstances>
</package3d>
<package3d name="139CLL-3W" urn="urn:adsk.eagle:package:23390/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="139CLL-3W"/>
</packageinstances>
</package3d>
<package3d name="140CLH-0810" urn="urn:adsk.eagle:package:23392/2" type="model" library_version="11">
<description>Aluminum electrolytic capacitors SMD (Chip)
Long life base plate, High temperature 140 CLH
<packageinstances>
<packageinstance name="140CLH-0810"/>
</packageinstances>
</package3d>
<package3d name="140CLH-1010" urn="urn:adsk.eagle:package:23391/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="140CLH-1010"/>
</packageinstances>
</package3d>
<package3d name="140CLH-1014" urn="urn:adsk.eagle:package:23393/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="140CLH-1014"/>
</packageinstances>
</package3d>
<package3d name="150CLZ-0810" urn="urn:adsk.eagle:package:23394/2" type="model" library_version="11">
Long life base plate, very low impedance 150 CLZ
<packageinstances>
<packageinstance name="150CLZ-0810"/>
</packageinstances>
</package3d>
<package3d name="150CLZ-1010" urn="urn:adsk.eagle:package:23403/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="150CLZ-1010"/>
</packageinstances>
</package3d>
<package3d name="150CLZ-1014" urn="urn:adsk.eagle:package:23405/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="150CLZ-1014"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0405" urn="urn:adsk.eagle:package:23397/2" type="model" library_version="11">
SMD (Chip) Long Life Vertical 153 CLV
<packageinstances>
<packageinstance name="153CLV-0405"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0505" urn="urn:adsk.eagle:package:23402/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="153CLV-0505"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0605" urn="urn:adsk.eagle:package:23398/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="153CLV-0605"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0807" urn="urn:adsk.eagle:package:23400/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="153CLV-0807"/>
</packageinstances>
</package3d>
<package3d name="153CLV-0810" urn="urn:adsk.eagle:package:23401/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="153CLV-0810"/>
</packageinstances>
</package3d>
<package3d name="153CLV-1010" urn="urn:adsk.eagle:package:23413/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="153CLV-1010"/>
</packageinstances>
</package3d>
<package3d name="153CLV-1012" urn="urn:adsk.eagle:package:23404/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="153CLV-1012"/>
</packageinstances>
</package3d>
<package3d name="153CLV-1014" urn="urn:adsk.eagle:package:23406/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="153CLV-1014"/>
</packageinstances>
</package3d>
<package3d name="175TMP-0808" urn="urn:adsk.eagle:package:23412/2" type="model" library_version="11">
High Temperature solid electrolytic SMD 175 TMP
<packageinstances>
<packageinstance name="175TMP-0808"/>
</packageinstances>
</package3d>
<package3d name="175TMP-0810" urn="urn:adsk.eagle:package:23407/3" type="model" library_version="11">
<packageinstances>
<packageinstance name="175TMP-0810"/>
</packageinstances>
</package3d>
<package3d name="A/3216-18R" urn="urn:adsk.eagle:package:23410/2" type="model" library_version="11">
<description>Chip Capacitor Type KEMET A / EIA 3216-18 reflow solderKEMET S / EIA 3216-12</description>
<packageinstances>
<packageinstance name="A/3216-18R"/>
</packageinstances>
</package3d>
<package3d name="A/3216-18W" urn="urn:adsk.eagle:package:23408/2" type="model" library_version="11">
<description>Chip Capacitor Type KEMET A / EIA 3216-18 Wave solder
<packageinstances>
<packageinstance name="A/3216-18W"/>
</packageinstances>
</package3d>
<package3d name="B/3528-21R" urn="urn:adsk.eagle:package:23409/2" type="model" library_version="11">
<description>Chip Capacitor Type KEMET B / EIA 3528-21 reflow solderKEMET T / EIA 3528-12</description>
<packageinstances>
<packageinstance name="B/3528-21R"/>
</packageinstances>
</package3d>
<package3d name="B/3528-21W" urn="urn:adsk.eagle:package:23411/1" type="box" library_version="11">
<description>Chip Capacitor Type KEMET B / EIA 3528-21 Wave solder
<packageinstances>
<packageinstance name="B/3528-21W"/>
</packageinstances>
</package3d>
<package3d name="C/6032-28R" urn="urn:adsk.eagle:package:23415/2" type="model" library_version="11">
<description>Chip Capacitor Type KEMET C / EIA 6032-28 reflow solderKEMET U / EIA 6032-15</description>
<packageinstances>
<packageinstance name="C/6032-28R"/>
</packageinstances>
</package3d>
<package3d name="C/6032-28W" urn="urn:adsk.eagle:package:23420/2" type="model" library_version="11">
<description>Chip Capacitor Type KEMET C / EIA 6032-28 Wafe solder
<packageinstances>
<packageinstance name="C/6032-28W"/>
</packageinstances>
</package3d>
<package3d name="D/7343-31R" urn="urn:adsk.eagle:package:23417/2" type="model" library_version="11">
<description>Chip Capacitor Type KEMET D / EIA 7343-21KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 reflow solder</description>
<packageinstances>
<packageinstance name="D/7343-31R"/>
</packageinstances>
</package3d>
<package3d name="D/7343-31W" urn="urn:adsk.eagle:package:23414/2" type="model" library_version="11">
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Wafe solder</description>
<packageinstances>
<packageinstance name="D/7343-31W"/>
</packageinstances>
</package3d>
<package3d name="E/7260-38R" urn="urn:adsk.eagle:package:23416/1" type="box" library_version="11">
<description>Chip Capacitor Type KEMET E / EIA 7260-38 reflow solder</description>
<packageinstances>
<packageinstance name="E/7260-38R"/>
</packageinstances>
</package3d>
<package3d name="E/7260-38W" urn="urn:adsk.eagle:package:23423/1" type="box" library_version="11">
<description>Chip Capacitor Type KEMET E / EIA 7260-38 Wafe solder</description>
<packageinstances>
<packageinstance name="E/7260-38W"/>
</packageinstances>
</package3d>
<package3d name="R/2012-12R" urn="urn:adsk.eagle:package:23426/2" type="model" library_version="11">
<description>Chip Capacitor Type KEMET R/EIA 2012-12 reflow solder</description>
<packageinstances>
<packageinstance name="R/2012-12R"/>
</packageinstances>
</package3d>
<package3d name="R/2012-12W" urn="urn:adsk.eagle:package:23419/2" type="model" library_version="11">
<description>Chip Capacitor Type KEMET R/EIA 2012-12 Wafe solder</description>
<packageinstances>
<packageinstance name="R/2012-12W"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_A" urn="urn:adsk.eagle:package:23418/2" type="model" library_version="11">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package A</description>
<packageinstances>
<packageinstance name="PANASONIC_A"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_B" urn="urn:adsk.eagle:package:23421/2" type="model" library_version="11">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package B</description>
<packageinstances>
<packageinstance name="PANASONIC_B"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_C" urn="urn:adsk.eagle:package:23422/2" type="model" library_version="11">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package C</description>
<packageinstances>
<packageinstance name="PANASONIC_C"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_D" urn="urn:adsk.eagle:package:23424/2" type="model" library_version="11">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D</description>
<packageinstances>
<packageinstance name="PANASONIC_D"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_E" urn="urn:adsk.eagle:package:23425/2" type="model" library_version="11">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package E</description>
<packageinstances>
<packageinstance name="PANASONIC_E"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_F" urn="urn:adsk.eagle:package:23428/2" type="model" library_version="11">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package F</description>
<packageinstances>
<packageinstance name="PANASONIC_F"/>
</packageinstances>
</package3d>
<package3d name="PANASONIC_G" urn="urn:adsk.eagle:package:23427/2" type="model" library_version="11">
<description>Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G</description>
<packageinstances>
<packageinstance name="PANASONIC_G"/>
</packageinstances>
</package3d>
<package3d name="TT2D5L" urn="urn:adsk.eagle:package:23429/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="TT2D5L"/>
</packageinstances>
</package3d>
<package3d name="E2,5-6E" urn="urn:adsk.eagle:package:23430/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="E2,5-6E"/>
</packageinstances>
</package3d>
<package3d name="SMC_A" urn="urn:adsk.eagle:package:25926/3" type="model" library_version="11">
<description>Chip Capacitor  Polar tantalum capacitors with solid electrolyte
Siemens Matsushita Components B 45 194, B 45 197, B 45 198
Source: www.farnell.com/datasheets/247.pdf</description>
<packageinstances>
<packageinstance name="SMC_A"/>
</packageinstances>
</package3d>
<package3d name="SMC_Z" urn="urn:adsk.eagle:package:25927/3" type="model" library_version="11">
<packageinstances>
<packageinstance name="SMC_Z"/>
</packageinstances>
</package3d>
<package3d name="SMC_P" urn="urn:adsk.eagle:package:25919/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="SMC_P"/>
</packageinstances>
</package3d>
<package3d name="SMC_B" urn="urn:adsk.eagle:package:25920/5" type="model" library_version="11">
<packageinstances>
<packageinstance name="SMC_B"/>
</packageinstances>
</package3d>
<package3d name="SMC_C" urn="urn:adsk.eagle:package:25921/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="SMC_C"/>
</packageinstances>
</package3d>
<package3d name="SMC_D" urn="urn:adsk.eagle:package:25923/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="SMC_D"/>
</packageinstances>
</package3d>
<package3d name="SMC_E" urn="urn:adsk.eagle:package:25922/2" type="model" library_version="11">
<packageinstances>
<packageinstance name="SMC_E"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_9E" urn="urn:adsk.eagle:package:23439/1" type="box" library_version="11">
<description>SANYO OSCON Capacitor
Source: e_os_all.pdf</description>
<packageinstances>
<packageinstance name="SANYO-OSCON_9E"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_9F" urn="urn:adsk.eagle:package:23437/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_9F"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_A" urn="urn:adsk.eagle:package:23438/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_A"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_A'" urn="urn:adsk.eagle:package:23440/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_A'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_B" urn="urn:adsk.eagle:package:23449/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_B"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_B'" urn="urn:adsk.eagle:package:23442/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_B'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_C" urn="urn:adsk.eagle:package:23441/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_C"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_C'" urn="urn:adsk.eagle:package:23443/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_C'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_C6" urn="urn:adsk.eagle:package:23444/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_C6"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_D" urn="urn:adsk.eagle:package:23445/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_D"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E" urn="urn:adsk.eagle:package:23451/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_E"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E'" urn="urn:adsk.eagle:package:23453/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_E'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E1" urn="urn:adsk.eagle:package:23447/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_E1"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E12" urn="urn:adsk.eagle:package:23448/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_E12"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E13" urn="urn:adsk.eagle:package:23454/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_E13"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E7" urn="urn:adsk.eagle:package:23452/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_E7"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_E9" urn="urn:adsk.eagle:package:23457/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_E9"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F" urn="urn:adsk.eagle:package:23462/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_F"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F'" urn="urn:adsk.eagle:package:23450/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_F'"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F0" urn="urn:adsk.eagle:package:23459/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_F0"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F13" urn="urn:adsk.eagle:package:23455/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_F13"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_F8" urn="urn:adsk.eagle:package:23456/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_F8"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_G" urn="urn:adsk.eagle:package:23458/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_G"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_H" urn="urn:adsk.eagle:package:23463/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_H"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_A5" urn="urn:adsk.eagle:package:23460/1" type="box" library_version="11">
<description>SANYO OSCON Capacitor SMD type with conductive polymer electrolyte
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_A5"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_B6" urn="urn:adsk.eagle:package:23461/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_B6"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_C6" urn="urn:adsk.eagle:package:23465/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_C6"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_E12" urn="urn:adsk.eagle:package:23464/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_E12"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_E7" urn="urn:adsk.eagle:package:23467/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_E7"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_F12" urn="urn:adsk.eagle:package:23468/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_F12"/>
</packageinstances>
</package3d>
<package3d name="SANYO-OSCON_SMD_F8" urn="urn:adsk.eagle:package:23466/1" type="box" library_version="11">
<packageinstances>
<packageinstance name="SANYO-OSCON_SMD_F8"/>
</packageinstances>
</package3d>
<package3d name="UD-10X10_NICHICON" urn="urn:adsk.eagle:package:23469/1" type="box" library_version="11">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 10 x 10 mm
Source: http://products.nichicon.co.jp/en/pdf/XJA043/e-ud.pdf</description>
<packageinstances>
<packageinstance name="UD-10X10_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-4X5,8_NICHICON" urn="urn:adsk.eagle:package:23474/1" type="box" library_version="11">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 4 x 5.8 mm
<packageinstances>
<packageinstance name="UD-4X5,8_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-5X5,8_NICHICON" urn="urn:adsk.eagle:package:23470/1" type="box" library_version="11">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 5 x 5.8 mm
<packageinstances>
<packageinstance name="UD-5X5,8_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-6,3X5,8_NICHICON" urn="urn:adsk.eagle:package:23471/1" type="box" library_version="11">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 6.3 x 5.8 mm
<packageinstances>
<packageinstance name="UD-6,3X5,8_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-6,3X7,7_NICHICON" urn="urn:adsk.eagle:package:23472/1" type="box" library_version="11">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 6.3 x 7.7 mm
<packageinstances>
<packageinstance name="UD-6,3X7,7_NICHICON"/>
</packageinstances>
</package3d>
<package3d name="UD-8X10_NICHICON" urn="urn:adsk.eagle:package:23473/1" type="box" library_version="11">
<description>ALUMINUM ELECTROLYTIC CAPACITORS UD Series 8 x 10 mm
<packageinstances>
<packageinstance name="UD-8X10_NICHICON"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="R-EU" urn="urn:adsk.eagle:symbol:23042/1" library_version="11">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="C-EU" urn="urn:adsk.eagle:symbol:23120/1" library_version="11">
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
<symbol name="R-TRIM" urn="urn:adsk.eagle:symbol:23231/1" library_version="11">
<wire x1="0.762" y1="2.54" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="-0.762" y1="2.54" x2="-0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0.762" y1="-2.54" x2="0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="1.651" y2="0" width="0.1524" layer="94"/>
<wire x1="1.651" y1="0" x2="-1.8796" y2="1.7526" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="5.08" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="-0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="-0.762" y1="-2.54" x2="0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-2.286" y1="1.27" x2="-1.651" y2="2.413" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-3.048" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-2.032" y2="-1.524" width="0.1524" layer="94"/>
<text x="-5.969" y="-3.81" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="A" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="E" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="S" x="5.08" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="CPOL" urn="urn:adsk.eagle:symbol:22801/1" library_version="11">
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="-1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="1.524" y2="0" width="0.254" layer="94"/>
<text x="1.143" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="-0.5842" y="0.4064" size="1.27" layer="94" rot="R90">+</text>
<text x="1.143" y="-4.5974" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.54" x2="1.651" y2="-1.651" layer="94"/>
<pin name="-" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="+" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="R-EU_" urn="urn:adsk.eagle:component:23791/21" prefix="R" uservalue="yes" library_version="11">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="R-EU" x="0" y="0"/>
</gates>
<devices>
<device name="R0402" package="R0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23547/3"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="POPULARITY" value="0" constant="no"/>
<attribute name="SPICEPREFIX" value="R" constant="no"/>
</technology>
</technologies>
</device>
<device name="R0603" package="R0603">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23555/3"/>
<technologies>
<attribute name="POPULARITY" value="70" constant="no"/>
</technology>
</technologies>
</device>
<device name="R0805" package="R0805">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23553/2"/>
<technologies>
<attribute name="POPULARITY" value="86" constant="no"/>
</technology>
</technologies>
</device>
<device name="R0805W" package="R0805W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23537/2"/>
<technologies>
<attribute name="POPULARITY" value="3" constant="no"/>
</technology>
</technologies>
</device>
<device name="R1206" package="R1206">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23540/2"/>
<technologies>
<attribute name="POPULARITY" value="41" constant="no"/>
</technology>
</technologies>
</device>
<device name="R1206W" package="R1206W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23539/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R1210" package="R1210">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23554/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R1210W" package="R1210W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23541/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2010" package="R2010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23551/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2010W" package="R2010W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23542/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2012" package="R2012">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23543/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2012W" package="R2012W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23544/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2512" package="R2512">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23545/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R2512W" package="R2512W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23565/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R3216" package="R3216">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23557/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R3216W" package="R3216W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23548/2"/>
<technologies>
<attribute name="POPULARITY" value="5" constant="no"/>
</technology>
</technologies>
</device>
<device name="R3225" package="R3225">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23549/2"/>
<technologies>
<attribute name="POPULARITY" value="1" constant="no"/>
</technology>
</technologies>
</device>
<device name="R3225W" package="R3225W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23550/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R5025" package="R5025">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23552/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R5025W" package="R5025W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23558/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R6332" package="R6332">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23559/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R6332W" package="R6332W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26078/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M0805" package="M0805">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23556/2"/>
<technologies>
<attribute name="POPULARITY" value="45" constant="no"/>
</technology>
</technologies>
</device>
<device name="M1206" package="M1206">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23566/2"/>
<technologies>
<attribute name="POPULARITY" value="17" constant="no"/>
</technology>
</technologies>
</device>
<device name="M1406" package="M1406">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23569/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M2012" package="M2012">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23561/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M2309" package="M2309">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23562/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M3216" package="M3216">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23563/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M3516" package="M3516">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23573/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="M5923" package="M5923">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23564/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23488/1"/>
<technologies>
<attribute name="POPULARITY" value="35" constant="no"/>
</technology>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23498/2"/>
<technologies>
<attribute name="POPULARITY" value="79" constant="no"/>
</technology>
</technologies>
</device>
<device name="0204/2V" package="0204V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23495/1"/>
<technologies>
<attribute name="POPULARITY" value="11" constant="no"/>
</technology>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23491/2"/>
<technologies>
<attribute name="POPULARITY" value="81" constant="no"/>
</technology>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23489/1"/>
<technologies>
<attribute name="POPULARITY" value="9" constant="no"/>
</technology>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23492/1"/>
<technologies>
<attribute name="POPULARITY" value="2" constant="no"/>
</technology>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23490/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23502/1"/>
<technologies>
<attribute name="POPULARITY" value="4" constant="no"/>
</technology>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23493/2"/>
<technologies>
<attribute name="POPULARITY" value="46" constant="no"/>
</technology>
</technologies>
</device>
<device name="0309/10" package="0309/10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23567/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0309/12" package="0309/12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23571/1"/>
<technologies>
<attribute name="POPULARITY" value="6" constant="no"/>
</technology>
</technologies>
</device>
<device name="0309/V" package="0309V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23572/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0411/12" package="0411/12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23578/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0411/15" package="0411/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23568/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0411/3V" package="0411V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23570/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0414/15" package="0414/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23579/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0414/5V" package="0414V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23574/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0617/17" package="0617/17">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23575/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0617/22" package="0617/22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23577/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0617/5V" package="0617V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23576/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0922/22" package="0922/22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23580/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0613/5V" package="P0613V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23582/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0613/15" package="P0613/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23581/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0817/22" package="P0817/22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23583/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0817/7V" package="P0817V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23608/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="V234/12" package="V234/12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23592/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="V235/17" package="V235/17">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23586/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="V526-0" package="V526-0">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23590/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0102R" package="MINI_MELF-0102R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23591/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0102W" package="MINI_MELF-0102W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23588/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0204R" package="MINI_MELF-0204R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26109/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0204W" package="MINI_MELF-0204W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26111/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0207R" package="MINI_MELF-0207R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26113/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0207W" package="MINI_MELF-0207W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26112/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="0922V" package="0922V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23589/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="RDH/15" package="RDH/15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23595/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MELF0102AX" package="MINI_MELF-0102AX">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23594/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R0201" package="R0201">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26117/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA52" package="VTA52">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26116/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA53" package="VTA53">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26118/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA54" package="VTA54">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26119/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA55" package="VTA55">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26120/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VTA56" package="VTA56">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26129/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VMTA55" package="VMTA55">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26121/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="VMTB60" package="VMTB60">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26122/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R4527" package="R4527">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:13310/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC0001" package="WSC0001">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26123/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC0002" package="WSC0002">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26125/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC01/2" package="WSC01/2">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26127/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC2515" package="WSC2515">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26134/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC4527" package="WSC4527">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26126/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="WSC6927" package="WSC6927">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26128/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R1218" package="R1218">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26131/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="1812X7R" package="1812X7R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26130/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="PRL1632" package="PRL1632">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26132/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="01005" package="R01005">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26133/2"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
<spice>
<pinmapping spiceprefix="R">
<pinmap gate="G$1" pin="1" pinorder="1"/>
<pinmap gate="G$1" pin="2" pinorder="2"/>
</pinmapping>
</spice>
</deviceset>
<deviceset name="C-EU" urn="urn:adsk.eagle:component:23793/46" prefix="C" uservalue="yes" library_version="11">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="C-EU" x="0" y="0"/>
</gates>
<devices>
<device name="C0402" package="C0402">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23626/2"/>
<technologies>
<attribute name="POPULARITY" value="18" constant="no"/>
<attribute name="SPICEPREFIX" value="C" constant="no"/>
</technology>
</technologies>
</device>
<device name="C0504" package="C0504">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23624/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C0603" package="C0603">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23616/2"/>
<technologies>
<attribute name="POPULARITY" value="73" constant="no"/>
</technology>
</technologies>
</device>
<device name="C0805" package="C0805">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23617/2"/>
<technologies>
<attribute name="POPULARITY" value="88" constant="no"/>
</technology>
</technologies>
</device>
<device name="C1206" package="C1206">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23618/2"/>
<technologies>
<attribute name="POPULARITY" value="54" constant="no"/>
</technology>
</technologies>
</device>
<device name="C1210" package="C1210">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23619/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1310" package="C1310">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23620/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1608" package="C1608">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23621/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1812" package="C1812">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23622/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1825" package="C1825">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23623/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C2012" package="C2012">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23625/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C3216" package="C3216">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23628/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C3225" package="C3225">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23655/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C4532" package="C4532">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23627/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C4564" package="C4564">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23648/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025-024X044" package="C025-024X044">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23630/1"/>
<technologies>
<attribute name="POPULARITY" value="56" constant="no"/>
</technology>
</technologies>
</device>
<device name="025-025X050" package="C025-025X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23629/2"/>
<technologies>
<attribute name="POPULARITY" value="65" constant="no"/>
</technology>
</technologies>
</device>
<device name="025-030X050" package="C025-030X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23631/1"/>
<technologies>
<attribute name="POPULARITY" value="14" constant="no"/>
</technology>
</technologies>
</device>
<device name="025-040X050" package="C025-040X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23634/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025-050X050" package="C025-050X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23633/1"/>
<technologies>
<attribute name="POPULARITY" value="16" constant="no"/>
</technology>
</technologies>
</device>
<device name="025-060X050" package="C025-060X050">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23632/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C025_050-024X070" package="C025_050-024X070">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23639/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025_050-025X075" package="C025_050-025X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23641/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025_050-035X075" package="C025_050-035X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23651/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025_050-045X075" package="C025_050-045X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23635/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="025_050-055X075" package="C025_050-055X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23636/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-024X044" package="C050-024X044">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23643/1"/>
<technologies>
<attribute name="POPULARITY" value="33" constant="no"/>
</technology>
</technologies>
</device>
<device name="050-025X075" package="C050-025X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23637/1"/>
<technologies>
<attribute name="POPULARITY" value="29" constant="no"/>
</technology>
</technologies>
</device>
<device name="050-045X075" package="C050-045X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23638/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-030X075" package="C050-030X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23640/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-050X075" package="C050-050X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23665/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-055X075" package="C050-055X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23642/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-075X075" package="C050-075X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23645/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050H075X075" package="C050H075X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23644/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="075-032X103" package="C075-032X103">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23646/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="075-042X103" package="C075-042X103">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23656/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="075-052X106" package="C075-052X106">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23650/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="102-043X133" package="C102-043X133">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23647/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="102-054X133" package="C102-054X133">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23649/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="102-064X133" package="C102-064X133">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23653/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="102_152-062X184" package="C102_152-062X184">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23652/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-054X183" package="C150-054X183">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23669/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-064X183" package="C150-064X183">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23654/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-072X183" package="C150-072X183">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23657/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-084X183" package="C150-084X183">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23658/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150-091X182" package="C150-091X182">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23659/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-062X268" package="C225-062X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23661/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-074X268" package="C225-074X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23660/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-087X268" package="C225-087X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23662/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-108X268" package="C225-108X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23663/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="225-113X268" package="C225-113X268">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23667/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-093X316" package="C275-093X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23701/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-113X316" package="C275-113X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23673/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-134X316" package="C275-134X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23664/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-205X316" package="C275-205X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23666/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="325-137X374" package="C325-137X374">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23672/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="325-162X374" package="C325-162X374">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23670/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="325-182X374" package="C325-182X374">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23668/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="375-192X418" package="C375-192X418">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23674/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="375-203X418" package="C375-203X418">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23671/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="050-035X075" package="C050-035X075">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23677/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="375-155X418" package="C375-155X418">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23675/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="075-063X106" package="C075-063X106">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23678/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-154X316" package="C275-154X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23685/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="275-173X316" package="C275-173X316">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23676/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C0402K" package="C0402K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23679/2"/>
<technologies>
<attribute name="POPULARITY" value="15" constant="no"/>
</technology>
</technologies>
</device>
<device name="C0603K" package="C0603K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23680/2"/>
<technologies>
<attribute name="POPULARITY" value="30" constant="no"/>
</technology>
</technologies>
</device>
<device name="C0805K" package="C0805K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23681/2"/>
<technologies>
<attribute name="POPULARITY" value="52" constant="no"/>
</technology>
</technologies>
</device>
<device name="C1206K" package="C1206K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23682/2"/>
<technologies>
<attribute name="POPULARITY" value="13" constant="no"/>
</technology>
</technologies>
</device>
<device name="C1210K" package="C1210K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23683/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1812K" package="C1812K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23686/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1825K" package="C1825K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23684/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C2220K" package="C2220K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23687/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C2225K" package="C2225K">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23692/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="HPC0201" package="HPC0201">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26213/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C0201" package="C0201">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23690/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1808" package="C1808">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23689/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C3640" package="C3640">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23693/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="01005" package="C01005">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23691/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
<spice>
<pinmapping spiceprefix="C">
</pinmapping>
</spice>
</deviceset>
<deviceset name="R-TRIMM" urn="urn:adsk.eagle:component:23798/5" prefix="R" uservalue="yes" library_version="11">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="R-TRIM" x="0" y="0"/>
</gates>
<devices>
<device name="3304W" package="RTRIM3304W">
<connects>
<connect gate="G$1" pin="A" pad="1"/>
<connect gate="G$1" pin="E" pad="3"/>
<connect gate="G$1" pin="S" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23725/1"/>
<technologies>
<attribute name="SPICEMODEL" value="X" constant="no"/>
<attribute name="SPICEPREFIXL" value="POT" constant="no"/>
</technology>
</technologies>
</device>
<device name="3165W" package="RTRIM3165W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23723/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3202" package="RTRIM3202">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23719/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3314J" package="RTRIM3314J">
<connects>
<connect gate="G$1" pin="A" pad="3"/>
<connect gate="G$1" pin="E" pad="1"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26019/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="4G/J" package="RTRIM4G/J">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23728/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CVR42A" package="RTRIMCVR42A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23735/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3214W" package="RTRIM3214W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23729/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3224G" package="RTRIM3224G">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23730/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3224J" package="RTRIM3224J">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23734/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3224X" package="RTRIM3224X">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23732/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3103" package="RTRIM3103">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23720/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="5W" package="RTRIM5W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23731/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="5X" package="RTRIM5X">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23743/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TSM53YJ" package="RTRIMTSM53YJ">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26035/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TSM53YL" package="RTRIMTSM53YL">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23733/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TS63X" package="RTRIMTS63X">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23736/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TS63Y" package="RTRIMTS63Y">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23740/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TS63Z" package="RTRIMTS63Z">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23742/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3296P" package="RTRIM3296P">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26032/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3296W" package="RTRIM3296W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26033/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3296X" package="RTRIM3296X">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26034/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3296Y" package="RTRIM3296Y">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26036/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="74W" package="RTRIM74W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23745/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="74X" package="RTRIM74X">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23746/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3224W" package="RTRIM3224W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23744/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3339P" package="RTRIM3339P">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23757/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="64P" package="RTRIM64P">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23747/1"/>
<technologies>
<attribute name="POPULARITY" value="21" constant="no"/>
</technology>
</technologies>
</device>
<device name="64W" package="RTRIM64W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23748/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="64X" package="RTRIM64X">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23749/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="64Y" package="RTRIM64Y">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23750/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="64Z" package="RTRIM64Z">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23754/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3059Y" package="RTRIM3059Y">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23752/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="70Y" package="RTRIM70Y">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23753/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3374" package="RTRIM3374">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23724/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3299W" package="RTRIM3299W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23755/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="43P" package="RTRIM43P">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23756/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3006P" package="RTRIM3006P">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23758/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="T18" package="RTRIMT18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23760/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="T93XA" package="RTRIMT93XA">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23759/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="T93XB" package="RTRIMT93XB">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23761/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="T93YA" package="RTRIMT93YA">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23764/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="T93YB" package="RTRIMT93YB">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23763/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="3314G" package="RTRIM3314G">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26056/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
<spice>
<pinmapping spiceprefix="X">
<pinmap gate="G$1" pin="A" pinorder="1"/>
<pinmap gate="G$1" pin="E" pinorder="2"/>
<pinmap gate="G$1" pin="S" pinorder="3"/>
</pinmapping>
<model name="POT">
* Autodesk EAGLE - Spice Model File
* Date: 9/25/17
* Variable resistor PIN1 ---/\/\/\/\--- PIN2
*                              PIN3
.subckt POT 1 2 3
R1 1 3 {val*var/100}
R2 3 2 {val-val*var/100}
.ends POT</model>
</spice>
</deviceset>
<deviceset name="CPOL-EU" urn="urn:adsk.eagle:component:23787/28" prefix="C" uservalue="yes" library_version="11">
<description>&lt;B&gt;POLARIZED CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="CPOL" x="0" y="0"/>
</gates>
<devices>
<device name="CT3216" package="CT3216">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23327/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CT3528" package="CT3528">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23325/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CT6032" package="CT6032">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23305/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="CT7343" package="CT7343">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23304/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181A" package="B45181A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23316/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181B" package="B45181B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23320/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181C" package="B45181C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23306/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B45181D" package="B45181D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23308/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D4" package="TT2D4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23310/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D4L" package="TT2D4L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23321/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D5" package="TT2D5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23300/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D6" package="TT2D6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23303/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D6L" package="TT2D6L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23323/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D7L" package="TT2D7L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23329/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT2D7" package="TT2D7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23319/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D10" package="TT5D10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23302/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D11" package="TT5D11">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23309/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D11L" package="TT5D11L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23312/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT6D6" package="TT5D6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23307/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D6L" package="TT5D6L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23324/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D7" package="TT5D7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23314/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D7L" package="TT5D7L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23318/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D9" package="TT5D9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23301/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TT5D9L" package="TT5D9L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23313/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR1" package="ETR1">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23322/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR2" package="ETR2">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23315/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR3" package="ETR3">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23311/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR4" package="ETR4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23317/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="ETR5" package="ETR5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23328/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-35" package="P128-35">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:25807/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-40" package="P128-40">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23331/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-50" package="P128-50">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23330/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P128-60" package="P128-60">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23337/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-45" package="TAP5-45">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23333/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-50" package="TAP5-50">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23335/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-70" package="TAP5-70">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23332/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-60" package="TAP5-60">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23334/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TAP5-80" package="TAP5-80">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23338/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E1.8-4" package="E1,8-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23336/2"/>
<technologies>
<attribute name="POPULARITY" value="12" constant="no"/>
</technology>
</technologies>
</device>
<device name="E15-5AXIAL" package="E15-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23341/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E15-6AXIAL" package="E15-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23339/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E15-9AXIAL" package="E15-9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23340/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-5V" package="E2,5-4R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23342/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-5" package="E2,5-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23344/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-6" package="E2,5-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23349/1"/>
<technologies>
<attribute name="POPULARITY" value="26" constant="no"/>
</technology>
</technologies>
</device>
<device name="E2.5-7" package="E2,5-7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23345/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2.5-4V" package="E2,5RE">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23343/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E2-4" package="E2-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23347/1"/>
<technologies>
<attribute name="POPULARITY" value="7" constant="no"/>
</technology>
</technologies>
</device>
<device name="E2-5" package="E2-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23346/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E22-10AXIAL" package="E22-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23348/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E22-6AXIAL" package="E22-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23359/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E22-9AXIAL" package="E22-9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23350/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E3.5-10" package="E3,5-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23351/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E25-10AXIAL" package="E25-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23352/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E25-9AXIAL" package="E25-9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23358/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E3.5-8" package="E3,5-8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23360/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E30-10AXIAL" package="E30-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23355/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E30-12AXIAL" package="E30-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23354/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E30-16AXIAL" package="E30-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23353/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-12AXIAL" package="E35-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23357/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-14AXIAL" package="E35-14">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23377/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-16AXIAL" package="E35-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23362/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E35-18AXIAL" package="E35-18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23356/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-16AXIAL" package="E45-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23365/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-18AXIAL" package="E45-18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23361/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-21AXIAL" package="E45-21">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23363/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-22AXIAL" package="E45-22">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23366/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E45-25AXIAL" package="E45-25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23364/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-10.5" package="E5-10,5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23372/2"/>
<technologies>
<attribute name="POPULARITY" value="23" constant="no"/>
</technology>
</technologies>
</device>
<device name="E5-13" package="E5-13">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23375/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-4" package="E5-4">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23370/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-5" package="E5-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23367/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-6" package="E5-6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23368/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-8.5" package="E5-8,5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23374/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E50-25AXIAL" package="E50-25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23369/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E50-30AXIAL" package="E50-30">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23371/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E55-25AXIAL" package="E55-25">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23376/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E55-30AXIAL" package="E55-30">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23378/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E5-9VAXIAL" package="E5R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23373/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E7.5-16" package="E7,5-16">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23382/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E7.5-18" package="E7,5-18">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23379/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-20" package="EB20D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23381/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-22.5" package="EB22,5D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23380/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-25" package="EB25D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23399/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-30" package="EB30D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23389/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E10-35" package="EB35D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23395/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1R" package="085CS_1R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23383/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1W" package="085CS_1W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23384/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1AR" package="085CS_1AR">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23396/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="085CS-1AW" package="085CS_1AW">
<connects>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23385/1"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="POPULARITY" value="0" constant="no"/>
</technology>
</technologies>
</device>
<device name="139CLL-2R" package="139CLL-2R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23387/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-2W" package="139CLL-2W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23386/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-3R" package="139CLL-3R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23388/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="139CLL-3W" package="139CLL-3W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23390/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="140CLH-0810" package="140CLH-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23392/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="140CLH-1010" package="140CLH-1010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23391/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="140CLH-1014" package="140CLH-1014">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23393/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150CLZ-0810" package="150CLZ-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23394/2"/>
<technologies>
<attribute name="POPULARITY" value="3" constant="no"/>
</technology>
</technologies>
</device>
<device name="150CLZ-1010" package="150CLZ-1010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23403/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="150CLZ-1014" package="150CLZ-1014">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23405/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0405" package="153CLV-0405">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23397/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0505" package="153CLV-0505">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23402/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0605" package="153CLV-0605">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23398/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0807" package="153CLV-0807">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23400/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-0810" package="153CLV-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23401/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-1010" package="153CLV-1010">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23413/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-1012" package="153CLV-1012">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23404/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="153CLV-1014" package="153CLV-1014">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23406/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="175TMP-0808" package="175TMP-0808">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23412/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="175TMP-0810" package="175TMP-0810">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23407/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="A/3216-18R" package="A/3216-18R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23410/2"/>
<technologies>
<attribute name="POPULARITY" value="1" constant="no"/>
</technology>
</technologies>
</device>
<device name="A/3216-18W" package="A/3216-18W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23408/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B/3528-21R" package="B/3528-21R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23409/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B/3528-21W" package="B/3528-21W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23411/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C/6032-28R" package="C/6032-28R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23415/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C/6032-28W" package="C/6032-28W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23420/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D/7343-31R" package="D/7343-31R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23417/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D/7343-31W" package="D/7343-31W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23414/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E/7260-38R" package="E/7260-38R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23416/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E/7260-38W" package="E/7260-38W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23423/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R/2012-12R" package="R/2012-12R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23426/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="R/2012-12W" package="R/2012-12W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23419/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="A" package="PANASONIC_A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23418/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="B" package="PANASONIC_B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23421/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C" package="PANASONIC_C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23422/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D" package="PANASONIC_D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23424/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="E" package="PANASONIC_E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23425/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="F" package="PANASONIC_F">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23428/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="G" package="PANASONIC_G">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23427/2"/>
<technologies>
<attribute name="POPULARITY" value="2" constant="no"/>
</technology>
</technologies>
</device>
<device name="TT2D5L" package="TT2D5L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23429/1"/>
<technologies>
<attribute name="POPULARITY" value="10" constant="no"/>
</technology>
</technologies>
</device>
<device name="E2,5-6E" package="E2,5-6E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23430/1"/>
<technologies>
<attribute name="POPULARITY" value="27" constant="no"/>
</technology>
</technologies>
</device>
<device name="SMCA" package="SMC_A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:25926/3"/>
<technologies>
<attribute name="POPULARITY" value="4" constant="no"/>
</technology>
</technologies>
</device>
<device name="SMCZ" package="SMC_Z">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:25927/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCP" package="SMC_P">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:25919/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCB" package="SMC_B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:25920/5"/>
<technologies>
<attribute name="POPULARITY" value="25" constant="no"/>
</technology>
</technologies>
</device>
<device name="SMCC" package="SMC_C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:25921/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCD" package="SMC_D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:25923/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMCE" package="SMC_E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:25922/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_9E" package="SANYO-OSCON_9E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23439/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_9F" package="SANYO-OSCON_9F">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23437/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_A" package="SANYO-OSCON_A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23438/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_A'" package="SANYO-OSCON_A'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23440/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_B" package="SANYO-OSCON_B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23449/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_B'" package="SANYO-OSCON_B'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23442/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_C" package="SANYO-OSCON_C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23441/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_C'" package="SANYO-OSCON_C'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23443/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_C6" package="SANYO-OSCON_C6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23444/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_D" package="SANYO-OSCON_D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23445/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E" package="SANYO-OSCON_E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23451/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E'" package="SANYO-OSCON_E'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23453/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E1" package="SANYO-OSCON_E1">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23447/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E12" package="SANYO-OSCON_E12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23448/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E13" package="SANYO-OSCON_E13">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23454/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E7" package="SANYO-OSCON_E7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23452/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_E9" package="SANYO-OSCON_E9">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23457/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F" package="SANYO-OSCON_F">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23462/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F'" package="SANYO-OSCON_F'">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23450/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F0" package="SANYO-OSCON_F0">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23459/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F13" package="SANYO-OSCON_F13">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23455/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_F8" package="SANYO-OSCON_F8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23456/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_G" package="SANYO-OSCON_G">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23458/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_H" package="SANYO-OSCON_H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23463/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_A5" package="SANYO-OSCON_SMD_A5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23460/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_B6" package="SANYO-OSCON_SMD_B6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23461/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_C6" package="SANYO-OSCON_SMD_C6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23465/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_E12" package="SANYO-OSCON_SMD_E12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23464/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_E7" package="SANYO-OSCON_SMD_E7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23467/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_F12" package="SANYO-OSCON_SMD_F12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23468/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SANYO_SMD_F8" package="SANYO-OSCON_SMD_F8">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23466/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-10X10" package="UD-10X10_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23469/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-4X5,8" package="UD-4X5,8_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23474/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-5X5,8" package="UD-5X5,8_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23470/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-6,3X8,8" package="UD-6,3X5,8_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23471/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-6,3X7,7" package="UD-6,3X7,7_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23472/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="UD-8X10" package="UD-8X10_NICHICON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:23473/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
<spice>
<pinmap gate="G$1" pin="+" pinorder="1"/>
<pinmap gate="G$1" pin="-" pinorder="2"/>
</pinmapping>
</spice>
</deviceset>
</devicesets>
</library>
<library name="supply1" urn="urn:adsk.eagle:library:371">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
 &lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
</packages>
<symbols>
<symbol name="GND" urn="urn:adsk.eagle:symbol:26925/1" library_version="1">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="+5V" urn="urn:adsk.eagle:symbol:26929/1" library_version="1">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<text x="-2.54" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="+5V" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="-5V" urn="urn:adsk.eagle:symbol:26930/1" library_version="1">
<wire x1="-1.27" y1="1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="1.27" y2="1.905" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="-5V" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="GND" urn="urn:adsk.eagle:component:26954/1" prefix="GND" library_version="1">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="+5V" urn="urn:adsk.eagle:component:26963/1" prefix="P+" library_version="1">
<gates>
<gate name="1" symbol="+5V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="-5V" urn="urn:adsk.eagle:component:26958/1" prefix="P-" library_version="1">
<gates>
<gate name="1" symbol="-5V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="v-reg" urn="urn:adsk.eagle:library:409">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO92-CLP" urn="urn:adsk.eagle:footprint:30307/1" library_version="4">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-0.7863" y2="2.5485" width="0.1524" layer="21" curve="-111.098957"/>
<wire x1="0.7868" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.09954"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.1524" layer="51" curve="-34.293591"/>
<pad name="R" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="A" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="C" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.3175" y="0.635" size="0.8128" layer="21">A</text>
<text x="-1.5875" y="-1.27" size="0.8128" layer="21">R</text>
<text x="0.9525" y="-1.27" size="0.8128" layer="21">C</text>
</package>
</packages>
<packages3d>
<package3d name="TO92-CLP" urn="urn:adsk.eagle:package:30363/1" type="box" library_version="4">
<description>VOLTAGE REGULATOR</description>
<packageinstances>
<packageinstance name="TO92-CLP"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="TL431LP" urn="urn:adsk.eagle:symbol:30306/1" library_version="4">
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-1.27" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="0.635" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0.635" x2="-2.54" y2="1.27" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0" y1="-1.27" x2="-0.635" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="0.635" y2="1.905" width="0.254" layer="94"/>
<wire x1="0" y1="5.08" x2="-1.27" y2="5.08" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="-1.27" y2="0.635" width="0.1524" layer="94"/>
<text x="-3.81" y="-3.81" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="R" x="2.54" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="TL431CLP" urn="urn:adsk.eagle:component:30410/2" prefix="VR" uservalue="yes" library_version="4">
<gates>
<gate name="G$1" symbol="TL431LP" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO92-CLP">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
<connect gate="G$1" pin="R" pad="R"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:30363/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="jumper" urn="urn:adsk.eagle:library:252">
<description>&lt;b&gt;Jumpers&lt;/b&gt;&lt;p&gt;
<packages>
<package name="JP1" urn="urn:adsk.eagle:footprint:15398/1" library_version="2">
<description>&lt;b&gt;JUMPER&lt;/b&gt;</description>
<wire x1="-1.016" y1="0" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.54" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="1.016" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-1.27" drill="0.9144" shape="long"/>
<pad name="2" x="0" y="1.27" drill="0.9144" shape="long"/>
<text x="-1.651" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.921" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="0.9652" x2="0.3048" y2="1.5748" layer="51"/>
<rectangle x1="-0.3048" y1="-1.5748" x2="0.3048" y2="-0.9652" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="JP1" urn="urn:adsk.eagle:package:15455/1" type="box" library_version="2">
<description>JUMPER</description>
<packageinstances>
<packageinstance name="JP1"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="JP2E" urn="urn:adsk.eagle:symbol:15391/1" library_version="2">
<wire x1="0" y1="0" x2="0" y2="1.27" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="1.27" width="0.4064" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="1.27" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="1.27" width="0.4064" layer="94"/>
<wire x1="-0.635" y1="0" x2="3.175" y2="0" width="0.4064" layer="94"/>
<wire x1="3.175" y1="0" x2="3.175" y2="0.635" width="0.4064" layer="94"/>
<wire x1="3.175" y1="0.635" x2="-0.635" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-0.635" y1="0.635" x2="-0.635" y2="0" width="0.4064" layer="94"/>
<text x="-1.27" y="0" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="5.715" y="0" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="1" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="2" x="2.54" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="JP1E" urn="urn:adsk.eagle:component:15487/2" prefix="JP" uservalue="yes" library_version="2">
<gates>
<gate name="A" symbol="JP2E" x="2.54" y="0"/>
</gates>
<devices>
<device name="" package="JP1">
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="2" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:15455/1"/>
<technologies>
<attribute name="POPULARITY" value="61" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="diode" urn="urn:adsk.eagle:library:210">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO41-10" urn="urn:adsk.eagle:footprint:43094/1" library_version="8">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="DO35-10" urn="urn:adsk.eagle:footprint:43092/1" library_version="8">
diameter 2 mm, horizontal, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-0.762" x2="2.286" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO204-10" urn="urn:adsk.eagle:footprint:43129/1" library_version="8">
diameter 4 mm, horizontal, grid 10 mm</description>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="2.5255" y2="0.6542" width="0.1524" layer="21" curve="-105.826017"/>
<wire x1="-2.5255" y1="-0.6542" x2="2.54" y2="-0.635" width="0.1524" layer="21" curve="105.826017"/>
<wire x1="2.54" y1="0.635" x2="2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.508" x2="2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.508" x2="2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.508" x2="3.048" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.508" x2="-2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.508" x2="-2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.508" x2="-3.048" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="-1.016" width="0.6096" layer="21"/>
<wire x1="-2.286" y1="0.508" x2="-2.286" y2="-0.508" width="0.6096" layer="21"/>
<wire x1="-2.032" y1="-0.762" x2="-2.286" y2="-0.508" width="0.6096" layer="21"/>
<wire x1="-2.286" y1="0.508" x2="-2.032" y2="0.762" width="0.6096" layer="21"/>
<wire x1="-2.794" y1="0.381" x2="-2.794" y2="-0.381" width="0.6096" layer="21"/>
<wire x1="2.794" y1="0.381" x2="2.794" y2="-0.381" width="0.6096" layer="21"/>
<wire x1="5.08" y1="0" x2="3.683" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.683" y2="0" width="0.8128" layer="51"/>
<wire x1="-0.889" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.508" x2="0.508" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.508" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.508" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.508" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.1176" shape="long"/>
<text x="-2.54" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.048" y1="-0.4064" x2="3.6068" y2="0.4064" layer="21"/>
<rectangle x1="-3.6068" y1="-0.4064" x2="-3.048" y2="0.4064" layer="21"/>
</package>
<package name="DO15-12" urn="urn:adsk.eagle:footprint:43132/1" library_version="8">
diameter 3.5 mm, horizontal, grid 12.7 mm</description>
<wire x1="-3.81" y1="-1.778" x2="3.81" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.778" x2="-3.81" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.778" x2="3.81" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.778" x2="-3.81" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.762" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.1176" shape="long"/>
<text x="-3.683" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.778" x2="-2.413" y2="1.778" layer="21"/>
<rectangle x1="-5.207" y1="-0.381" x2="-3.81" y2="0.381" layer="21"/>
<rectangle x1="3.81" y1="-0.381" x2="5.207" y2="0.381" layer="21"/>
</package>
<package name="SOD57-10" urn="urn:adsk.eagle:footprint:43130/1" library_version="8">
diameter 4 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-1.143" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="2.286" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.016" x2="1.397" y2="-1.016" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.286" y1="1.016" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.397" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.016" x2="2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.1938" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.1938" shape="long"/>
<text x="-2.286" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.8354" y1="-0.4064" x2="-2.286" y2="0.4064" layer="21"/>
<rectangle x1="2.286" y1="-0.4064" x2="3.8354" y2="0.4064" layer="21"/>
</package>
<package name="DO201-15" urn="urn:adsk.eagle:footprint:43127/1" library_version="8">
diameter 5.6 mm, horizontal, grid 15.24 mm</description>
<wire x1="-1.27" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.143" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.5842" x2="1.143" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.794" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.794" x2="-5.08" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.223" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.223" y2="0" width="1.27" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.4986" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.4986" shape="long"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.191" y1="-2.794" x2="-3.429" y2="2.794" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-5.08" y2="0.635" layer="21"/>
<rectangle x1="5.08" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
</package>
<package name="DO07" urn="urn:adsk.eagle:footprint:43160/1" library_version="8">
<wire x1="3.302" y1="1.27" x2="3.556" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.556" y1="1.016" x2="-3.302" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.556" y1="-1.016" x2="-3.302" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="3.302" y1="-1.27" x2="3.556" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="3.556" y1="-1.016" x2="3.556" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.016" x2="-3.556" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.27" x2="3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.27" x2="3.302" y2="-1.27" width="0.1524" layer="21"/>
<text x="-3.429" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="1.27" layer="21"/>
<rectangle x1="3.556" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-3.556" y2="0.254" layer="21"/>
</package>
<package name="P1-10" urn="urn:adsk.eagle:footprint:43138/1" library_version="8">
diameter 3 mm, horizontal, grid 10.16 mm</description>
<wire x1="-3.175" y1="-1.524" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.524" x2="-3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<text x="-3.048" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-3.175" y2="0.381" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
</package>
<package name="P2-15" urn="urn:adsk.eagle:footprint:43106/1" library_version="8">
diameter 5 mm, horizontal, grid 12.7 mm</description>
<wire x1="-4.826" y1="-2.54" x2="-4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.54" x2="4.826" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.54" x2="4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.54" x2="-4.826" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<text x="-4.8006" y="2.8194" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.9022" y="-4.699" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-2.54" x2="-2.921" y2="2.54" layer="21"/>
<rectangle x1="4.826" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-4.826" y2="0.635" layer="21"/>
</package>
<package name="DO34-7" urn="urn:adsk.eagle:footprint:43109/1" library_version="8">
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
</package>
<package name="SOT54H" urn="urn:adsk.eagle:footprint:43111/1" library_version="8">
2-lead plastic, vertical</description>
<wire x1="-1.651" y1="2.032" x2="1.651" y2="2.032" width="0.1524" layer="21" curve="280.388858"/>
<wire x1="1.651" y1="2.032" x2="-1.651" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-1.905" x2="0.508" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="-0.381" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.381" y1="-1.27" x2="0.508" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-0.508" y1="-1.905" x2="-0.508" y2="-0.635" width="0.2032" layer="21"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
</package>
<package name="SOD523" urn="urn:adsk.eagle:footprint:43179/1" library_version="8">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="-0.59" y1="0.4" x2="0.59" y2="0.4" width="0.1016" layer="51"/>
<wire x1="0.59" y1="0.4" x2="0.59" y2="-0.4" width="0.1016" layer="51"/>
<wire x1="0.59" y1="-0.4" x2="-0.59" y2="-0.4" width="0.1016" layer="51"/>
<wire x1="-0.59" y1="-0.4" x2="-0.59" y2="0.4" width="0.1016" layer="51"/>
<smd name="A" x="0.7" y="0" dx="0.7" dy="0.5" layer="1"/>
<smd name="C" x="-0.6" y="0" dx="0.7" dy="0.5" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.75" y1="-0.17" x2="-0.54" y2="0.17" layer="51"/>
<rectangle x1="0.54" y1="-0.17" x2="0.75" y2="0.17" layer="51"/>
<rectangle x1="-0.59" y1="-0.4" x2="-0.3" y2="0.4" layer="51"/>
</package>
<package name="TO18D" urn="urn:adsk.eagle:footprint:43190/1" library_version="8">
2-lead metall, vertical</description>
<wire x1="1.651" y1="-2.286" x2="2.286" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-2.921" x2="2.921" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-2.286" x2="2.286" y2="-1.651" width="0.1524" layer="21"/>
<circle x="0" y="0.0254" radius="2.7686" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.0508" layer="21"/>
<text x="3.175" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.143" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C1702-05" urn="urn:adsk.eagle:footprint:43191/1" library_version="8">
diameter 3.5 mm, vertical, grid 5.08 mm</description>
<wire x1="2.54" y1="0" x2="0.762" y2="0" width="1.0668" layer="51"/>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="1.0668" layer="51"/>
<circle x="-2.54" y="0" radius="1.778" width="0.1524" layer="21"/>
<pad name="C" x="-2.54" y="0" drill="1.397" shape="octagon"/>
<pad name="A" x="2.54" y="0" drill="1.397" shape="octagon"/>
<text x="-4.318" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.7366" y1="-0.5334" x2="0.635" y2="0.5334" layer="21"/>
</package>
<package name="C1702-15" urn="urn:adsk.eagle:footprint:43117/1" library_version="8">
diameter 3.5 mm, horizontal, grid 15.24 mm</description>
<wire x1="-4.572" y1="-1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.1176" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.1176" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.397" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.397" shape="long"/>
<text x="-4.572" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-1.778" x2="-3.302" y2="1.778" layer="21"/>
<rectangle x1="4.572" y1="-0.5334" x2="5.9436" y2="0.5334" layer="21"/>
<rectangle x1="-5.9436" y1="-0.5334" x2="-4.572" y2="0.5334" layer="21"/>
</package>
<package name="SGA-10" urn="urn:adsk.eagle:footprint:43154/1" library_version="8">
<wire x1="5.08" y1="0" x2="3.175" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.175" y2="0" width="0.8128" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.508" x2="0.635" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-0.508" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="1.016" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="0.635" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.508" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.381" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.381" x2="2.032" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.1938" x2="-1.397" y2="-1.1938" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="1.0414" x2="-1.5748" y2="-1.016" width="0.254" layer="21"/>
<wire x1="-2.032" y1="0.381" x2="-2.032" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.381" x2="2.032" y2="0.381" width="0.1524" layer="21" curve="-145.291951"/>
<wire x1="-2.032" y1="-0.381" x2="2.032" y2="-0.381" width="0.1524" layer="21" curve="145.291951"/>
<rectangle x1="2.032" y1="-0.4064" x2="3.8608" y2="0.4064" layer="21"/>
<rectangle x1="-3.8608" y1="-0.4064" x2="-2.032" y2="0.4064" layer="21"/>
</package>
<package name="SOD64-10" urn="urn:adsk.eagle:footprint:43140/1" library_version="8">
diameter 4.8 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-2.54" y1="1.397" x2="-2.54" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.397" x2="2.54" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.397" x2="1.397" y2="-1.397" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.54" y1="1.397" x2="-1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.397" x2="-1.397" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.397" x2="2.54" y2="-1.397" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.6002" shape="long"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.397" x2="-1.397" y2="1.397" layer="21"/>
<rectangle x1="2.54" y1="-0.6604" x2="3.3274" y2="0.6604" layer="21"/>
<rectangle x1="-3.3274" y1="-0.6604" x2="-2.54" y2="0.6604" layer="21"/>
</package>
<package name="SOD61A" urn="urn:adsk.eagle:footprint:43141/1" library_version="8">
diameter 3.5 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6604" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6604" layer="51"/>
<wire x1="-2.54" y1="0.635" x2="-2.921" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.381" x2="-2.921" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-0.381" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.921" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.921" y1="0.381" x2="2.921" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.921" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.54" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-0.381" x2="2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.508" x2="2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.508" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.921" y1="0.381" x2="2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.508" x2="2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.508" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.381" x2="-2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-0.381" x2="-2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.508" x2="-2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.508" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0.381" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.54" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-0.381" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.381" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.381" x2="-2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.54" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.381" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.381" x2="-2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="2.5178" y2="0.655" width="0.1524" layer="21" curve="-84.093979"/>
<wire x1="-2.5178" y1="-0.655" x2="2.54" y2="-0.635" width="0.1524" layer="21" curve="84.093979"/>
<pad name="C" x="-5.08" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.9144" shape="long"/>
<text x="-2.54" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.921" y1="-0.3302" x2="4.0132" y2="0.3302" layer="21"/>
<rectangle x1="-4.0132" y1="-0.3302" x2="-2.921" y2="0.3302" layer="21"/>
<rectangle x1="2.54" y1="-0.381" x2="2.921" y2="0.381" layer="21"/>
<rectangle x1="-2.921" y1="-0.381" x2="-2.54" y2="0.381" layer="21"/>
</package>
<package name="SOD61B" urn="urn:adsk.eagle:footprint:43142/1" library_version="8">
diameter 3.5 mm, vertical, grid 15.24 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6604" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6604" layer="51"/>
<wire x1="-4.445" y1="0.635" x2="-4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.635" x2="-4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.381" x2="-4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.381" x2="-4.445" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.635" x2="4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.381" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.381" x2="4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.508" x2="4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.508" x2="4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.381" x2="4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.508" x2="4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.508" x2="4.445" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.381" x2="-4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.381" x2="-4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.445" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="4.699" y1="0.381" x2="4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.381" x2="4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-0.381" x2="4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.381" x2="4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.381" x2="-4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.381" x2="-4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0.381" x2="-4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.381" x2="-4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.635" x2="4.4429" y2="0.636" width="0.1524" layer="21" curve="-52.21463"/>
<wire x1="-4.4429" y1="-0.636" x2="4.445" y2="-0.635" width="0.1524" layer="21" curve="52.21463"/>
<pad name="C" x="-7.62" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="7.62" y="0" drill="0.9144" shape="long"/>
<text x="-2.794" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.381" x2="4.826" y2="0.381" layer="21"/>
<rectangle x1="-4.826" y1="-0.381" x2="-4.445" y2="0.381" layer="21"/>
<rectangle x1="4.826" y1="-0.3302" x2="6.5278" y2="0.3302" layer="21"/>
<rectangle x1="-6.5278" y1="-0.3302" x2="-4.826" y2="0.3302" layer="21"/>
</package>
<package name="SOD61C" urn="urn:adsk.eagle:footprint:43143/1" library_version="8">
diameter 3.5 mm, vertical, grid 17.78 mm</description>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="0.6604" layer="51"/>
<wire x1="-8.89" y1="0" x2="-7.874" y2="0" width="0.6604" layer="51"/>
<wire x1="-5.588" y1="0.635" x2="-5.969" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.635" x2="-5.588" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="0.381" x2="-5.969" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-0.381" x2="-5.588" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.635" x2="5.969" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.969" y1="0.381" x2="5.969" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.635" x2="5.969" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.635" x2="5.588" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-0.381" x2="5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.508" x2="5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.508" x2="5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.969" y1="0.381" x2="5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.508" x2="5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.508" x2="5.588" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="0.381" x2="-5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.508" x2="-5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.508" x2="-5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-0.381" x2="-5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-0.508" x2="-5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-0.508" x2="-5.588" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.381" x2="5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.381" x2="5.588" y2="0.508" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-0.381" x2="5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.381" x2="5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-0.381" x2="-5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-0.381" x2="-5.588" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="0.381" x2="-5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.381" x2="-5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.55" y1="0.65" x2="-4.55" y2="1" width="0.1524" layer="21"/>
<wire x1="-4.55" y1="1" x2="-3.4" y2="1.3" width="0.1524" layer="21"/>
<wire x1="-3.4" y1="1.3" x2="-2.05" y2="1.55" width="0.1524" layer="21"/>
<wire x1="-2.05" y1="1.55" x2="-1" y2="1.65" width="0.1524" layer="21"/>
<wire x1="-1" y1="1.65" x2="0" y2="1.7" width="0.1524" layer="21"/>
<wire x1="5.55" y1="-0.65" x2="4.55" y2="-1" width="0.1524" layer="21"/>
<wire x1="4.55" y1="-1" x2="3.4" y2="-1.3" width="0.1524" layer="21"/>
<wire x1="3.4" y1="-1.3" x2="2.05" y2="-1.55" width="0.1524" layer="21"/>
<wire x1="2.05" y1="-1.55" x2="1" y2="-1.65" width="0.1524" layer="21"/>
<wire x1="1" y1="-1.65" x2="0" y2="-1.7" width="0.1524" layer="21"/>
<wire x1="5.55" y1="0.65" x2="4.55" y2="1" width="0.1524" layer="21"/>
<wire x1="4.55" y1="1" x2="3.4" y2="1.3" width="0.1524" layer="21"/>
<wire x1="3.4" y1="1.3" x2="2.05" y2="1.55" width="0.1524" layer="21"/>
<wire x1="2.05" y1="1.55" x2="1" y2="1.65" width="0.1524" layer="21"/>
<wire x1="1" y1="1.65" x2="0" y2="1.7" width="0.1524" layer="21"/>
<wire x1="-5.55" y1="-0.65" x2="-4.55" y2="-1" width="0.1524" layer="21"/>
<wire x1="-4.55" y1="-1" x2="-3.4" y2="-1.3" width="0.1524" layer="21"/>
<wire x1="-3.4" y1="-1.3" x2="-2.05" y2="-1.55" width="0.1524" layer="21"/>
<wire x1="-2.05" y1="-1.55" x2="-1" y2="-1.65" width="0.1524" layer="21"/>
<wire x1="-1" y1="-1.65" x2="0" y2="-1.7" width="0.1524" layer="21"/>
<pad name="C" x="-8.89" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="8.89" y="0" drill="0.9144" shape="long"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="5.588" y1="-0.381" x2="5.969" y2="0.381" layer="21"/>
<rectangle x1="-5.969" y1="-0.381" x2="-5.588" y2="0.381" layer="21"/>
<rectangle x1="5.969" y1="-0.3302" x2="7.8232" y2="0.3302" layer="21"/>
<rectangle x1="-7.8232" y1="-0.3302" x2="-5.969" y2="0.3302" layer="21"/>
</package>
<package name="SOD61D" urn="urn:adsk.eagle:footprint:43144/1" library_version="8">
<wire x1="-4.826" y1="0.635" x2="-5.207" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.635" x2="-4.826" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="0.381" x2="-5.207" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-0.381" x2="-4.826" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.635" x2="5.207" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0.381" x2="5.207" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.635" x2="5.207" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.635" x2="4.826" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-0.381" x2="5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.508" x2="5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.508" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0.381" x2="5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.508" x2="5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.508" x2="4.826" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="0.381" x2="-5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.508" x2="-5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.508" x2="-4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-0.381" x2="-5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.508" x2="-5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.508" x2="-4.826" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.381" x2="4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.381" x2="4.826" y2="0.508" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.381" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.381" x2="4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.381" x2="-4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.381" x2="-4.826" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.381" x2="-4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.635" x2="4.8254" y2="0.6353" width="0.1524" layer="21" curve="-49.511667"/>
<wire x1="-4.8254" y1="-0.6353" x2="4.826" y2="-0.635" width="0.1524" layer="21" curve="49.511667"/>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.826" y1="-0.381" x2="5.207" y2="0.381" layer="21"/>
<rectangle x1="-5.207" y1="-0.381" x2="-4.826" y2="0.381" layer="21"/>
<rectangle x1="5.207" y1="-0.3302" x2="6.5278" y2="0.3302" layer="21"/>
<rectangle x1="-6.5278" y1="-0.3302" x2="-5.207" y2="0.3302" layer="21"/>
</package>
<package name="SOD61E" urn="urn:adsk.eagle:footprint:43145/1" library_version="8">
diameter 3.5 mm, vertical, grid 20.32 mm</description>
<wire x1="10.16" y1="0" x2="9.144" y2="0" width="0.6604" layer="51"/>
<wire x1="-10.16" y1="0" x2="-9.144" y2="0" width="0.6604" layer="51"/>
<wire x1="-6.35" y1="0.635" x2="-6.731" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0.381" x2="-6.731" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.381" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.731" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.731" y1="0.381" x2="6.731" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.731" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.35" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-0.381" x2="6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.508" x2="6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.508" x2="6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.731" y1="0.381" x2="6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.508" x2="6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.508" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0.381" x2="-6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.508" x2="-6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.508" x2="-6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.381" x2="-6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.508" x2="-6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.508" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.604" y1="0.381" x2="6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.381" x2="6.35" y2="0.508" width="0.1524" layer="21"/>
<wire x1="6.604" y1="-0.381" x2="6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.381" x2="6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-0.381" x2="-6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.381" x2="-6.35" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="0.381" x2="-6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.381" x2="-6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="6.3161" y2="0.6464" width="0.1524" layer="21" curve="-37.137105"/>
<wire x1="-6.3161" y1="-0.6464" x2="6.35" y2="-0.635" width="0.1524" layer="21" curve="37.137105"/>
<pad name="C" x="-10.16" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="10.16" y="0" drill="0.9144" shape="long"/>
<text x="-3.048" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.35" y1="-0.381" x2="6.731" y2="0.381" layer="21"/>
<rectangle x1="-6.731" y1="-0.381" x2="-6.35" y2="0.381" layer="21"/>
<rectangle x1="6.731" y1="-0.3302" x2="9.0678" y2="0.3302" layer="21"/>
<rectangle x1="-9.0678" y1="-0.3302" x2="-6.731" y2="0.3302" layer="21"/>
</package>
<package name="DO27-15" urn="urn:adsk.eagle:footprint:43095/1" library_version="8">
diameter 5 mm, horizontal, grid 15.24 mm</description>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<text x="-5.08" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.191" y1="-2.54" x2="-3.429" y2="2.54" layer="21"/>
</package>
<package name="SOD81" urn="urn:adsk.eagle:footprint:43125/1" library_version="8">
diameter 2.3 mm, vertical, grid 10.16 mm</description>
<wire x1="-1.905" y1="1.143" x2="1.905" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.159" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.381" x2="2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.508" x2="2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.508" x2="2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.508" x2="2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.508" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.381" x2="-2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.508" x2="-2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.508" x2="-2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.508" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.508" x2="-2.159" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.381" x2="2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.381" x2="2.159" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.381" x2="2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.381" x2="2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.381" x2="-2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.381" x2="-2.159" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="0.381" x2="-2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.381" x2="-2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.143" x2="2.159" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.159" y1="0.889" x2="-1.905" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.905" y1="1.143" x2="2.159" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.889" x2="-1.905" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.905" y1="-1.143" x2="1.905" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="0.889" width="0.1524" layer="21"/>
<text x="-2.032" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-1.651" y1="-1.143" x2="-1.143" y2="1.143" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.159" y2="0.381" layer="21"/>
<rectangle x1="2.159" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
</package>
<package name="SOD84" urn="urn:adsk.eagle:footprint:43139/1" library_version="8">
diameter 3.3 mm, vertical, grid 10.16 mm</description>
<wire x1="-1.905" y1="1.651" x2="1.905" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.651" x2="2.159" y2="-1.397" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.159" y1="1.397" x2="-1.905" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.905" y1="1.651" x2="2.159" y2="1.397" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-1.397" x2="-1.905" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.905" y1="-1.651" x2="1.905" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="1.397" width="0.1524" layer="21"/>
<text x="-2.032" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.651" x2="-1.143" y2="1.651" layer="21"/>
</package>
<package name="F126-10" urn="urn:adsk.eagle:footprint:43161/1" library_version="8">
<pad name="C" x="-5.08" y="0" drill="1.016" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.016" shape="long"/>
<text x="-3.175" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-2.54" y1="-1.524" x2="-1.778" y2="1.524" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="3.7338" y2="0.4064" layer="21"/>
<rectangle x1="-3.7338" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
</package>
<package name="DO220S" urn="urn:adsk.eagle:footprint:43133/1" library_version="8">
2-lead molded, vertical</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="C" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-4.572" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
<rectangle x1="-1.651" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
</package>
<package name="TO220AC" urn="urn:adsk.eagle:footprint:43128/1" library_version="8">
2-lead molded, horizontal</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="2.921" width="0" layer="42"/>
<circle x="0" y="11.176" radius="2.921" width="0" layer="43"/>
<pad name="C" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.461" y="-1.27" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="10">A17,5mm</text>
<rectangle x1="2.159" y1="-4.445" x2="2.921" y2="-3.81" layer="21"/>
<rectangle x1="-2.921" y1="-4.445" x2="-2.159" y2="-3.81" layer="21"/>
<rectangle x1="-3.175" y1="-3.81" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-3.81" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-6.35" x2="2.921" y2="-4.445" layer="51"/>
<rectangle x1="-2.921" y1="-6.35" x2="-2.159" y2="-4.445" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<package name="TO220ACS" urn="urn:adsk.eagle:footprint:43137/1" library_version="8">
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="G4-12" urn="urn:adsk.eagle:footprint:43131/1" library_version="8">
diameter 7.62 mm, horizontal, grid 12.7 mm</description>
<wire x1="3.556" y1="1.27" x2="3.556" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="-3.556" y1="-1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="1.27" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="1.27" layer="51"/>
<wire x1="3.937" y1="0.889" x2="4.318" y2="0.508" width="0.6096" layer="21"/>
<wire x1="4.318" y1="-0.508" x2="3.937" y2="-0.889" width="0.6096" layer="21"/>
<wire x1="-4.318" y1="0.508" x2="-3.937" y2="0.889" width="0.6096" layer="21"/>
<wire x1="-4.318" y1="-0.508" x2="-3.937" y2="-0.889" width="0.6096" layer="21"/>
<wire x1="-2.667" y1="-2.286" x2="-2.667" y2="2.286" width="0.6096" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.6096" layer="21"/>
<wire x1="-3.556" y1="1.016" x2="-3.556" y2="-1.016" width="0.6096" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-2.921" y2="-2.032" width="0.6096" layer="21"/>
<wire x1="-2.921" y1="2.032" x2="-3.175" y2="1.524" width="0.6096" layer="21"/>
<circle x="0" y="0" radius="3.81" width="0.1524" layer="21"/>
<pad name="C" x="-6.35" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.6002" shape="long"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.81" y1="-0.635" x2="4.953" y2="0.635" layer="21"/>
<rectangle x1="-4.953" y1="-0.635" x2="-3.81" y2="0.635" layer="21"/>
</package>
<package name="SOD83-12" urn="urn:adsk.eagle:footprint:43146/1" library_version="8">
diameter 4.8 mm, vertical, grid 12.7 mm</description>
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="1.3716" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="1.3716" layer="51"/>
<wire x1="-3.81" y1="1.397" x2="-3.81" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.397" x2="3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.397" x2="-2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="3.81" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="2.6841" y2="1.3841" width="0.1524" layer="21" curve="-74.015899"/>
<wire x1="-2.6841" y1="-1.3841" x2="2.667" y2="-1.397" width="0.1524" layer="21" curve="74.015899"/>
<rectangle x1="-3.175" y1="-1.397" x2="-2.667" y2="1.397" layer="21"/>
<rectangle x1="3.81" y1="-0.6604" x2="4.6228" y2="0.6604" layer="21"/>
<rectangle x1="-4.6228" y1="-0.6604" x2="-3.81" y2="0.6604" layer="21"/>
</package>
<package name="SMB" urn="urn:adsk.eagle:footprint:43181/1" library_version="8">
<wire x1="-2.2606" y1="1.905" x2="2.2606" y2="1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="2.2606" y2="-1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="-2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="2.2606" y1="-1.905" x2="2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="0.193" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.193" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.193" y1="-1" x2="0.193" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="A" x="2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<text x="-2.159" y="2.159" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.0922" x2="-2.2606" y2="1.0922" layer="51"/>
<rectangle x1="2.2606" y1="-1.0922" x2="2.794" y2="1.0922" layer="51"/>
<rectangle x1="-1.35" y1="-1.9" x2="-0.8" y2="1.9" layer="51"/>
</package>
<package name="P6-15" urn="urn:adsk.eagle:footprint:43097/1" library_version="8">
diameter 9 mm, horizontal, grid 15.24 mm</description>
<wire x1="-4.699" y1="-4.572" x2="-4.699" y2="4.572" width="0.1524" layer="21"/>
<wire x1="4.699" y1="4.572" x2="4.699" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="4.572" x2="4.699" y2="4.572" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.572" x2="-4.699" y2="-4.572" width="0.1524" layer="21"/>
<pad name="C" x="-7.62" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.6002" shape="long"/>
<text x="-4.6736" y="4.8514" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.3622" y="-3.302" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-4.572" x2="-2.921" y2="4.572" layer="21"/>
<rectangle x1="4.699" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-4.699" y2="0.635" layer="21"/>
</package>
<package name="C2673" urn="urn:adsk.eagle:footprint:43156/1" library_version="8">
diameter 5.2 mm, horizontal, grid 15.24 mm</description>
<wire x1="4.826" y1="-2.667" x2="-4.826" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.667" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.826" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.27" layer="51"/>
<text x="-4.699" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.937" y1="-2.667" x2="-2.54" y2="2.667" layer="21"/>
</package>
<package name="C221B1A" urn="urn:adsk.eagle:footprint:43158/1" library_version="8">
<wire x1="5.207" y1="14.478" x2="-5.207" y2="14.478" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.001" x2="-5.207" y2="8.001" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.001" x2="5.207" y2="14.478" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="8.001" x2="-5.207" y2="14.478" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="8.001" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="8.001" width="0.1524" layer="21"/>
<wire x1="4.953" y1="6.731" x2="4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="4.953" y1="6.731" x2="-4.953" y2="6.731" width="0.0508" layer="21"/>
<wire x1="4.953" y1="-1.016" x2="-4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="-4.953" y1="6.731" x2="-4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="-2.794" y1="-4.191" x2="-3.175" y2="-3.81" width="0.508" layer="21"/>
<wire x1="3.175" y1="-3.81" x2="2.794" y2="-4.191" width="0.508" layer="21"/>
<text x="-2.54" y="4.191" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="1.651" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.826" y="8.382" size="0.9906" layer="21" ratio="10">A17,5mm</text>
<rectangle x1="-3.429" y1="-3.81" x2="-2.159" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-3.81" x2="3.429" y2="-1.27" layer="21"/>
</package>
<package name="SOD80C" urn="urn:adsk.eagle:footprint:43180/1" library_version="8">
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
<package name="D-10" urn="urn:adsk.eagle:footprint:43192/1" library_version="8">
<description>&lt;b&gt;DIODE&lt;/b&gt;</description>
<wire x1="-3.175" y1="0" x2="-3.937" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="3.937" y1="0" x2="3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="0" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.286" y1="-1.524" x2="-1.524" y2="1.524" layer="21"/>
</package>
<package name="D-12.5" urn="urn:adsk.eagle:footprint:43193/1" library_version="8">
<wire x1="-3.175" y1="0" x2="-5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0" x2="3.175" y2="0" width="0.1524" layer="21"/>
<pad name="A" x="6.35" y="0" drill="0.8128" shape="long"/>
<pad name="C" x="-6.35" y="0" drill="0.8128" shape="long"/>
</package>
<package name="D-2.5" urn="urn:adsk.eagle:footprint:43194/1" library_version="8">
<wire x1="0.508" y1="0.762" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-0.762" x2="0.508" y2="0.762" width="0.1524" layer="21"/>
<text x="-1.651" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="D-5" urn="urn:adsk.eagle:footprint:43195/1" library_version="8">
<wire x1="1.397" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-0.889" x2="1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0.889" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-0.889" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0" x2="-1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0" x2="1.397" y2="0.889" width="0.1524" layer="21"/>
<pad name="A" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.905" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-1.016" y1="-0.889" x2="-0.508" y2="0.889" layer="21"/>
</package>
<package name="D-7.5" urn="urn:adsk.eagle:footprint:43196/1" library_version="8">
<wire x1="1.905" y1="0.889" x2="-1.905" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-0.889" x2="1.905" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0.889" x2="-1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-0.889" x2="1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.905" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.905" y1="0" x2="1.905" y2="0.889" width="0.1524" layer="21"/>
<rectangle x1="-1.27" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
</package>
<package name="SOD106-R" urn="urn:adsk.eagle:footprint:43197/1" library_version="8">
<description>&lt;b&gt;SOD106 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="1.8208" y1="0.7874" x2="-1.8208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.8208" y1="-0.7874" x2="-1.8208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.127" y1="0.6" x2="-0.873" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.873" y1="0" x2="0.127" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.127" y1="-0.6" x2="0.127" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-2.25" y="0" dx="1.6" dy="2.1" layer="1"/>
<smd name="A" x="2.25" y="0" dx="1.6" dy="2.1" layer="1"/>
<text x="-1.524" y="1.293" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.563" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3542" y1="-0.8636" x2="-1.7954" y2="0.8636" layer="51"/>
<rectangle x1="1.7954" y1="-0.8636" x2="2.3542" y2="0.8636" layer="51"/>
<rectangle x1="-1.3636" y1="-0.7874" x2="-0.754" y2="0.7874" layer="21"/>
</package>
<package name="SMC" urn="urn:adsk.eagle:footprint:43198/1" library_version="8">
<wire x1="-3.5606" y1="3.105" x2="3.5606" y2="3.105" width="0.1016" layer="21"/>
<wire x1="-3.5606" y1="-3.105" x2="3.5606" y2="-3.105" width="0.1016" layer="21"/>
<wire x1="-3.5606" y1="-3.105" x2="-3.5606" y2="3.105" width="0.1016" layer="51"/>
<wire x1="3.5606" y1="-3.105" x2="3.5606" y2="3.105" width="0.1016" layer="51"/>
<wire x1="0.543" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.543" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.543" y1="-1" x2="0.543" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-3.7" y="0" dx="2.8" dy="3.8" layer="1"/>
<smd name="A" x="3.7" y="0" dx="2.8" dy="3.8" layer="1"/>
<text x="-3.459" y="3.359" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.459" y="-4.629" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.094" y1="-1.0922" x2="-3.5606" y2="1.0922" layer="51"/>
<rectangle x1="3.5606" y1="-1.0922" x2="4.094" y2="1.0922" layer="51"/>
<rectangle x1="-2.1" y1="-3.1" x2="-0.85" y2="3.1" layer="21"/>
</package>
<package name="SOD106-W" urn="urn:adsk.eagle:footprint:43199/1" library_version="8">
<description>&lt;b&gt;SOD106 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-2.85" y="0" dx="2.3" dy="3.2" layer="1"/>
<smd name="A" x="2.85" y="0" dx="2.3" dy="3.2" layer="1"/>
<text x="-3.374" y="1.793" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.324" y="-3.163" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SOD106A-R" urn="urn:adsk.eagle:footprint:43200/1" library_version="8">
<description>&lt;b&gt;SOD106A Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-2.2" y="0" dx="1.7" dy="2.1" layer="1"/>
<smd name="A" x="2.2" y="0" dx="1.7" dy="2.1" layer="1"/>
<text x="-2.374" y="1.293" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.374" y="-2.513" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.3636" y1="-0.7874" x2="-0.754" y2="0.7874" layer="51"/>
</package>
<package name="SOD110-W" urn="urn:adsk.eagle:footprint:43201/1" library_version="8">
<description>&lt;b&gt;SOD110 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1" y1="0.5" x2="1.05" y2="0.5" width="0.1016" layer="51"/>
<wire x1="1.05" y1="0.5" x2="1.05" y2="-0.5" width="0.1016" layer="51"/>
<wire x1="1.05" y1="-0.5" x2="-1" y2="-0.5" width="0.1016" layer="51"/>
<wire x1="-1" y1="-0.5" x2="-1" y2="0.5" width="0.1016" layer="51"/>
<smd name="C" x="-1.15" y="0" dx="1" dy="1.2" layer="1"/>
<smd name="A" x="1.15" y="0" dx="1" dy="1.2" layer="1"/>
<rectangle x1="-0.65" y1="-0.45" x2="-0.4" y2="0.45" layer="51"/>
</package>
<package name="SOD110-R" urn="urn:adsk.eagle:footprint:43202/1" library_version="8">
<description>&lt;b&gt;SOD110 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-0.95" y="0" dx="0.8" dy="1" layer="1"/>
<smd name="A" x="0.95" y="0" dx="0.8" dy="1" layer="1"/>
</package>
<package name="SOD123" urn="urn:adsk.eagle:footprint:43203/1" library_version="8">
<description>&lt;b&gt;Diode&lt;/b&gt;</description>
<wire x1="-1.1" y1="0.7" x2="1.1" y2="0.7" width="0.254" layer="51"/>
<wire x1="1.1" y1="0.7" x2="1.1" y2="-0.7" width="0.254" layer="51"/>
<wire x1="1.1" y1="-0.7" x2="-1.1" y2="-0.7" width="0.254" layer="51"/>
<wire x1="-1.1" y1="-0.7" x2="-1.1" y2="0.7" width="0.254" layer="51"/>
<smd name="C" x="-1.9" y="0" dx="1.4" dy="1.4" layer="1"/>
<smd name="A" x="1.9" y="0" dx="1.4" dy="1.4" layer="1"/>
<text x="-1.1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.1" y="-2.3" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.95" y1="-0.45" x2="-1.2" y2="0.4" layer="51"/>
<rectangle x1="1.2" y1="-0.45" x2="1.95" y2="0.4" layer="51"/>
<rectangle x1="-1.05" y1="-0.65" x2="-0.15" y2="0.7" layer="51"/>
</package>
<package name="SOD323-R" urn="urn:adsk.eagle:footprint:43204/1" library_version="8">
<description>&lt;b&gt;SOD323 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1" y1="0.7" x2="1" y2="0.7" width="0.1524" layer="21"/>
<wire x1="1" y1="0.7" x2="1" y2="-0.7" width="0.1524" layer="51"/>
<wire x1="1" y1="-0.7" x2="-1" y2="-0.7" width="0.1524" layer="21"/>
<wire x1="-1" y1="-0.7" x2="-1" y2="0.7" width="0.1524" layer="51"/>
<wire x1="-0.5" y1="0" x2="0.1" y2="0.4" width="0.1524" layer="21"/>
<wire x1="0.1" y1="0.4" x2="0.1" y2="-0.4" width="0.1524" layer="21"/>
<wire x1="0.1" y1="-0.4" x2="-0.5" y2="0" width="0.1524" layer="21"/>
<smd name="C" x="-1.1" y="0" dx="0.6" dy="0.6" layer="1"/>
<smd name="A" x="1.1" y="0" dx="0.6" dy="0.6" layer="1"/>
<rectangle x1="-0.7" y1="-0.7" x2="-0.5" y2="0.7" layer="51"/>
</package>
<package name="SOD323-W" urn="urn:adsk.eagle:footprint:43205/1" library_version="8">
<description>&lt;b&gt;SOD323 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1" y1="0.7" x2="1" y2="0.7" width="0.1524" layer="51"/>
<wire x1="1" y1="-0.7" x2="-1" y2="-0.7" width="0.1524" layer="51"/>
<smd name="C" x="-1.45" y="0" dx="1.5" dy="1.2" layer="1"/>
<smd name="A" x="1.45" y="0" dx="1.5" dy="1.2" layer="1"/>
</package>
<package name="GF1" urn="urn:adsk.eagle:footprint:43206/1" library_version="8">
<description>&lt;b&gt;GF1&lt;/b&gt;&lt;p&gt;
General Semiconductor</description>
<wire x1="-2.24" y1="1.32" x2="2.24" y2="1.32" width="0.254" layer="21"/>
<wire x1="2.24" y1="1.32" x2="2.24" y2="-1.32" width="0.254" layer="21"/>
<wire x1="2.24" y1="-1.32" x2="-2.24" y2="-1.32" width="0.254" layer="21"/>
<wire x1="-2.24" y1="-1.32" x2="-2.24" y2="1.32" width="0.254" layer="21"/>
<smd name="C" x="-2.12" y="0" dx="1.32" dy="1.68" layer="1"/>
<smd name="A" x="1.87" y="0" dx="1.85" dy="1.68" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.86" y1="-0.84" x2="-2.32" y2="0.84" layer="51"/>
<rectangle x1="2.34" y1="-0.84" x2="2.86" y2="0.84" layer="51"/>
<rectangle x1="-1.9" y1="-1.05" x2="-1.25" y2="1.05" layer="51"/>
<rectangle x1="-1.4" y1="-1.05" x2="-1.25" y2="1.05" layer="21"/>
</package>
<package name="MINIMELF" urn="urn:adsk.eagle:footprint:43207/1" library_version="8">
<description>&lt;b&gt;Mini Melf Diode&lt;/b&gt;</description>
<wire x1="0.5" y1="0.5" x2="-0.5" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.5" y1="0" x2="0.5" y2="-0.5" width="0.2032" layer="21"/>
<wire x1="0.5" y1="-0.5" x2="0.5" y2="0.5" width="0.2032" layer="21"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MELF-MLL41" urn="urn:adsk.eagle:footprint:43208/1" library_version="8">
<description>&lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;
Package DO-213AB = http://www.diotec.com/pdf/sm4001.pdf</description>
<wire x1="2.0828" y1="1.1938" x2="-2.159" y2="1.1938" width="0.1524" layer="51"/>
<wire x1="2.0828" y1="-1.1938" x2="-2.1336" y2="-1.1938" width="0.1524" layer="51"/>
<wire x1="0.627" y1="1" x2="-0.746" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.746" y1="0" x2="0.627" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-1" x2="0.627" y2="1" width="0.2032" layer="21"/>
<wire x1="1.1208" y1="1.1938" x2="-1.097" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="1.1208" y1="-1.1938" x2="-1.0716" y2="-1.1938" width="0.1524" layer="21"/>
<smd name="C" x="-2.625" y="0" dx="2.5" dy="3" layer="1"/>
<smd name="A" x="2.625" y="0" dx="2.5" dy="3" layer="1"/>
<text x="-2.663" y="1.724" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.663" y="-2.994" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.0574" y1="-1.27" x2="2.5654" y2="1.27" layer="51"/>
<rectangle x1="-2.6162" y1="-1.27" x2="-2.1082" y2="1.27" layer="51"/>
<rectangle x1="-1.4478" y1="-1.1938" x2="-0.5588" y2="1.1938" layer="51"/>
</package>
<package name="MICROMELF-R" urn="urn:adsk.eagle:footprint:43209/1" library_version="8">
<description>&lt;b&gt;Micro Melf Diode Reflow soldering&lt;/b&gt; VISHAY mcl4148.pdf</description>
<wire x1="-0.65" y1="0.55" x2="0.65" y2="0.55" width="0.1524" layer="51"/>
<wire x1="-0.65" y1="-0.55" x2="0.65" y2="-0.55" width="0.1524" layer="51"/>
<smd name="C" x="-0.8" y="0" dx="0.8" dy="1.2" layer="1"/>
<smd name="A" x="0.8" y="0" dx="0.8" dy="1.2" layer="1"/>
<text x="-1.201" y="0.843" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.201" y="-2.063" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.95" y1="-0.65" x2="-0.65" y2="0.65" layer="51"/>
<rectangle x1="0.65" y1="-0.65" x2="0.95" y2="0.65" layer="51"/>
<rectangle x1="-0.5" y1="-0.55" x2="-0.2" y2="0.55" layer="51"/>
</package>
<package name="MICROMELF-W" urn="urn:adsk.eagle:footprint:43210/1" library_version="8">
<description>&lt;b&gt;Micro Melf Diode Wave soldering&lt;/b&gt; VISHAY mcl4148.pdf</description>
<smd name="C" x="-0.95" y="0" dx="0.9" dy="1.4" layer="1"/>
<smd name="A" x="0.95" y="0" dx="0.9" dy="1.4" layer="1"/>
<rectangle x1="-0.5" y1="-0.5" x2="-0.2" y2="0.55" layer="51"/>
</package>
<package name="SC79_INFINEON" urn="urn:adsk.eagle:footprint:43211/1" library_version="8">
<description>&lt;b&gt;Diode Package&lt;/b&gt; Reflow soldering&lt;p&gt;
INFINEON, www.infineon.com/cmc_upload/0/000/010/257/eh_db_5b.pdf</description>
<wire x1="-0.55" y1="0.35" x2="0.55" y2="0.35" width="0.1016" layer="21"/>
<wire x1="0.55" y1="0.35" x2="0.55" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="0.55" y1="-0.35" x2="-0.55" y2="-0.35" width="0.1016" layer="21"/>
<wire x1="-0.55" y1="-0.35" x2="-0.55" y2="0.35" width="0.1016" layer="51"/>
<smd name="C" x="-0.675" y="0" dx="0.35" dy="0.35" layer="1"/>
<smd name="A" x="0.675" y="0" dx="0.35" dy="0.35" layer="1"/>
<text x="-0.8" y="0.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.8" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.15" x2="-0.55" y2="0.15" layer="51"/>
<rectangle x1="0.55" y1="-0.15" x2="0.8" y2="0.15" layer="51"/>
<rectangle x1="-0.55" y1="-0.35" x2="0" y2="0.35" layer="51"/>
</package>
<package name="SCD80_INFINEON" urn="urn:adsk.eagle:footprint:43212/1" library_version="8">
<wire x1="-0.6" y1="0.35" x2="-0.6" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="-0.6" y1="-0.35" x2="0.6" y2="-0.35" width="0.1016" layer="21"/>
<wire x1="0.6" y1="-0.35" x2="0.6" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.6" y1="0.35" x2="-0.6" y2="0.35" width="0.1016" layer="21"/>
<smd name="C" x="-0.725" y="0" dx="0.35" dy="0.35" layer="1"/>
<smd name="A" x="0.725" y="0" dx="0.35" dy="0.35" layer="1"/>
<text x="-0.9" y="0.5" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.9" y="-1.8" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6" y1="-0.35" x2="0" y2="0.35" layer="51"/>
<rectangle x1="-0.85" y1="-0.15" x2="-0.6" y2="0.15" layer="51"/>
<rectangle x1="0.6" y1="-0.15" x2="0.85" y2="0.15" layer="51"/>
</package>
<package name="DO214AA" urn="urn:adsk.eagle:footprint:43213/1" library_version="8">
<wire x1="-2.4" y1="1.1" x2="2.4" y2="1.1" width="0.254" layer="51"/>
<wire x1="2.4" y1="1.1" x2="2.4" y2="-1.1" width="0.254" layer="51"/>
<wire x1="2.4" y1="-1.1" x2="-2.4" y2="-1.1" width="0.254" layer="51"/>
<wire x1="-2.4" y1="-1.1" x2="-2.4" y2="1.1" width="0.254" layer="51"/>
<wire x1="-1.2" y1="0" x2="0.05" y2="0.7" width="0.254" layer="21"/>
<wire x1="0.05" y1="0.7" x2="0.05" y2="-0.7" width="0.254" layer="21"/>
<wire x1="0.05" y1="-0.7" x2="-1.2" y2="0" width="0.254" layer="21"/>
<smd name="C" x="-2.55" y="0" dx="1.8" dy="2.2" layer="1"/>
<smd name="A" x="2.55" y="0" dx="1.8" dy="2.2" layer="1"/>
<text x="-2.64" y="1.436" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.64" y="-2.706" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.75" y1="-0.7" x2="-2.5" y2="0.65" layer="51"/>
<rectangle x1="2.5" y1="-0.7" x2="2.75" y2="0.65" layer="51"/>
<rectangle x1="-1.4" y1="-1.05" x2="-1.1" y2="1.05" layer="21"/>
</package>
<package name="DO214AC" urn="urn:adsk.eagle:footprint:43214/1" library_version="8">
<wire x1="-2.3" y1="1" x2="2.3" y2="1" width="0.254" layer="51"/>
<wire x1="2.3" y1="1" x2="2.3" y2="-0.95" width="0.254" layer="51"/>
<wire x1="2.3" y1="-0.95" x2="-2.3" y2="-0.95" width="0.254" layer="51"/>
<wire x1="-2.3" y1="-0.95" x2="-2.3" y2="1" width="0.254" layer="51"/>
<wire x1="-0.8" y1="0" x2="0.25" y2="0.75" width="0.254" layer="21"/>
<wire x1="0.25" y1="0.75" x2="0.25" y2="-0.7" width="0.254" layer="21"/>
<wire x1="0.25" y1="-0.7" x2="-0.8" y2="0" width="0.254" layer="21"/>
<smd name="C" x="-2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<smd name="A" x="2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<text x="-2.64" y="1.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.64" y="-2.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.65" y1="-0.7" x2="-2.4" y2="0.65" layer="51"/>
<rectangle x1="2.4" y1="-0.7" x2="2.65" y2="0.65" layer="51"/>
<rectangle x1="-1" y1="-1.05" x2="-0.7" y2="1.05" layer="21"/>
</package>
<package name="DO214BA" urn="urn:adsk.eagle:footprint:43215/1" library_version="8">
<wire x1="-2.5" y1="1.35" x2="2.5" y2="1.35" width="0.254" layer="51"/>
<wire x1="2.5" y1="1.35" x2="2.5" y2="-1.35" width="0.254" layer="51"/>
<wire x1="2.5" y1="-1.35" x2="-2.5" y2="-1.35" width="0.254" layer="51"/>
<wire x1="-2.5" y1="-1.35" x2="-2.5" y2="1.35" width="0.254" layer="51"/>
<wire x1="-0.8" y1="0" x2="0.65" y2="0.95" width="0.254" layer="21"/>
<wire x1="0.65" y1="0.95" x2="0.65" y2="-0.95" width="0.254" layer="21"/>
<wire x1="0.65" y1="-0.95" x2="-0.8" y2="0" width="0.254" layer="21"/>
<text x="-2.64" y="1.736" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.64" y="-3.056" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.85" y1="-0.7" x2="-2.6" y2="0.65" layer="51"/>
<rectangle x1="2.6" y1="-0.7" x2="2.85" y2="0.65" layer="51"/>
</package>
<package name="DO-214AC" urn="urn:adsk.eagle:footprint:43216/1" library_version="8">
<description>&lt;b&gt;SURFACE MOUNT GENERAL RECTIFIER&lt;/b&gt; JEDEC DO-214AC molded platic body&lt;p&gt;
Method 2026&lt;br&gt;
Source: http://www.kingtronics.com/SMD_M7/M7_SMD_4007.pdf</description>
<wire x1="-2.15" y1="1.3" x2="2.15" y2="1.3" width="0.2032" layer="51"/>
<wire x1="2.15" y1="1.3" x2="2.15" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.3" x2="-2.15" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="-1.3" x2="-2.15" y2="1.3" width="0.2032" layer="51"/>
<wire x1="-1.035" y1="1.3" x2="1.025" y2="1.3" width="0.2032" layer="21"/>
<wire x1="1.025" y1="-1.3" x2="-1.035" y2="-1.3" width="0.2032" layer="21"/>
<smd name="C" x="-2.025" y="0" dx="1.8" dy="2.4" layer="1"/>
<smd name="A" x="2.025" y="0" dx="1.8" dy="2.4" layer="1" rot="R180"/>
<rectangle x1="-2.825" y1="-1.1" x2="-2.175" y2="1.1" layer="51"/>
<rectangle x1="2.175" y1="-1.1" x2="2.825" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-1.065" y1="-1.225" x2="-0.39" y2="1.225" layer="21"/>
<rectangle x1="-1.75" y1="-1.225" x2="-1.075" y2="1.225" layer="51"/>
</package>
<package name="DO41-7.6" urn="urn:adsk.eagle:footprint:43217/1" library_version="8">
<description>&lt;b&gt;DO41&lt;/b&gt; 7.6mm x 2mm&lt;p&gt;
Source: http://www.diodes.com/datasheets/ds23001.pdf</description>
<wire x1="2.082" y1="-0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="2.082" y1="-0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.494" y2="0" width="0.85" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.519" y2="0" width="0.85" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="1.1" diameter="1.7"/>
<pad name="A" x="3.81" y="0" drill="1.1" diameter="1.7"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.95" x2="-1.143" y2="0.92" layer="21"/>
<rectangle x1="2.082" y1="-0.425" x2="2.717" y2="0.425" layer="21"/>
<rectangle x1="-2.717" y1="-0.425" x2="-2.082" y2="0.425" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="DO41-10" urn="urn:adsk.eagle:package:43336/1" type="box" library_version="8">
<description>DIODE
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="DO41-10"/>
</packageinstances>
</package3d>
<package3d name="DO35-10" urn="urn:adsk.eagle:package:43344/2" type="model" library_version="8">
<description>DIODE
diameter 2 mm, horizontal, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="DO35-10"/>
</packageinstances>
</package3d>
<package3d name="DO204-10" urn="urn:adsk.eagle:package:43366/1" type="box" library_version="8">
<description>DIODE
diameter 4 mm, horizontal, grid 10 mm</description>
<packageinstances>
<packageinstance name="DO204-10"/>
</packageinstances>
</package3d>
<package3d name="DO15-12" urn="urn:adsk.eagle:package:43369/2" type="model" library_version="8">
<description>DIODE
diameter 3.5 mm, horizontal, grid 12.7 mm</description>
<packageinstances>
<packageinstance name="DO15-12"/>
</packageinstances>
</package3d>
<package3d name="SOD57-10" urn="urn:adsk.eagle:package:43367/1" type="box" library_version="8">
<description>DIODE
diameter 4 mm, vertical, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="SOD57-10"/>
</packageinstances>
</package3d>
<package3d name="DO201-15" urn="urn:adsk.eagle:package:43365/2" type="model" library_version="8">
<description>DIODE
diameter 5.6 mm, horizontal, grid 15.24 mm</description>
<packageinstances>
<packageinstance name="DO201-15"/>
</packageinstances>
</package3d>
<package3d name="DO07" urn="urn:adsk.eagle:package:43394/2" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="DO07"/>
</packageinstances>
</package3d>
<package3d name="P1-10" urn="urn:adsk.eagle:package:43375/1" type="box" library_version="8">
<description>DIODE
diameter 3 mm, horizontal, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="P1-10"/>
</packageinstances>
</package3d>
<package3d name="P2-15" urn="urn:adsk.eagle:package:43345/2" type="model" library_version="8">
<description>DIODE
diameter 5 mm, horizontal, grid 12.7 mm</description>
<packageinstances>
<packageinstance name="P2-15"/>
</packageinstances>
</package3d>
<package3d name="DO34-7" urn="urn:adsk.eagle:package:43348/1" type="box" library_version="8">
<description>DIODE
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<packageinstances>
<packageinstance name="DO34-7"/>
</packageinstances>
</package3d>
<package3d name="SOT54H" urn="urn:adsk.eagle:package:43359/1" type="box" library_version="8">
<description>DIODE
2-lead plastic, vertical</description>
<packageinstances>
<packageinstance name="SOT54H"/>
</packageinstances>
</package3d>
<package3d name="SOD523" urn="urn:adsk.eagle:package:43410/4" type="model" library_version="8">
<description>DIODE</description>
<packageinstances>
<packageinstance name="SOD523"/>
</packageinstances>
</package3d>
<package3d name="TO18D" urn="urn:adsk.eagle:package:43443/1" type="box" library_version="8">
<description>DIODE
2-lead metall, vertical</description>
<packageinstances>
<packageinstance name="TO18D"/>
</packageinstances>
</package3d>
<package3d name="C1702-05" urn="urn:adsk.eagle:package:43430/1" type="box" library_version="8">
<description>DIODE
diameter 3.5 mm, vertical, grid 5.08 mm</description>
<packageinstances>
<packageinstance name="C1702-05"/>
</packageinstances>
</package3d>
<package3d name="C1702-15" urn="urn:adsk.eagle:package:43351/1" type="box" library_version="8">
<description>DIODE
diameter 3.5 mm, horizontal, grid 15.24 mm</description>
<packageinstances>
<packageinstance name="C1702-15"/>
</packageinstances>
</package3d>
<package3d name="SGA-10" urn="urn:adsk.eagle:package:43388/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="SGA-10"/>
</packageinstances>
</package3d>
<package3d name="SOD64-10" urn="urn:adsk.eagle:package:43385/1" type="box" library_version="8">
<description>DIODE
diameter 4.8 mm, vertical, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="SOD64-10"/>
</packageinstances>
</package3d>
<package3d name="SOD61A" urn="urn:adsk.eagle:package:43377/1" type="box" library_version="8">
<description>DIODE
diameter 3.5 mm, vertical, grid 10.16 mm</description>
<packageinstances>
<packageinstance name="SOD61A"/>
</packageinstances>
</package3d>
<package3d name="SOD61B" urn="urn:adsk.eagle:package:43379/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="SOD61B"/>
</packageinstances>
</package3d>
<package3d name="SOD61C" urn="urn:adsk.eagle:package:43378/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="SOD61C"/>
</packageinstances>
</package3d>
<package3d name="SOD61D" urn="urn:adsk.eagle:package:43381/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="SOD61D"/>
</packageinstances>
</package3d>
<package3d name="SOD61E" urn="urn:adsk.eagle:package:43380/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="SOD61E"/>
</packageinstances>
</package3d>
<package3d name="DO27-15" urn="urn:adsk.eagle:package:43337/3" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="DO27-15"/>
</packageinstances>
</package3d>
<package3d name="SOD81" urn="urn:adsk.eagle:package:43363/2" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="SOD81"/>
</packageinstances>
</package3d>
<package3d name="SOD84" urn="urn:adsk.eagle:package:43376/2" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="SOD84"/>
</packageinstances>
</package3d>
<package3d name="F126-10" urn="urn:adsk.eagle:package:43396/2" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="F126-10"/>
</packageinstances>
</package3d>
<package3d name="DO220S" urn="urn:adsk.eagle:package:43371/4" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="DO220S"/>
</packageinstances>
</package3d>
<package3d name="TO220AC" urn="urn:adsk.eagle:package:43370/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="TO220AC"/>
</packageinstances>
</package3d>
<package3d name="TO220ACS" urn="urn:adsk.eagle:package:43373/3" type="model" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="TO220ACS"/>
</packageinstances>
</package3d>
<package3d name="G4-12" urn="urn:adsk.eagle:package:43368/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="G4-12"/>
</packageinstances>
</package3d>
<package3d name="SOD83-12" urn="urn:adsk.eagle:package:43382/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="SOD83-12"/>
</packageinstances>
</package3d>
<package3d name="SMB" urn="urn:adsk.eagle:package:43404/2" type="model" library_version="8">
<packageinstances>
<packageinstance name="SMB"/>
</packageinstances>
</package3d>
<package3d name="P6-15" urn="urn:adsk.eagle:package:43343/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="P6-15"/>
</packageinstances>
</package3d>
<package3d name="C2673" urn="urn:adsk.eagle:package:43390/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="C2673"/>
</packageinstances>
</package3d>
<package3d name="C221B1A" urn="urn:adsk.eagle:package:43391/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="C221B1A"/>
</packageinstances>
</package3d>
<package3d name="SOD80C" urn="urn:adsk.eagle:package:43405/2" type="model" library_version="8">
<packageinstances>
<packageinstance name="SOD80C"/>
</packageinstances>
</package3d>
<package3d name="D-10" urn="urn:adsk.eagle:package:43434/1" type="box" library_version="8">
<packageinstances>
<packageinstance name="D-10"/>
</packageinstances>
</package3d>
<package3d name="D-12.5" urn="urn:adsk.eagle:package:43427/1" type="box" library_version="8">
<packageinstances>
<packageinstance name="D-12.5"/>
</packageinstances>
</package3d>
<package3d name="D-2.5" urn="urn:adsk.eagle:package:43419/1" type="box" library_version="8">
<packageinstances>
<packageinstance name="D-2.5"/>
</packageinstances>
</package3d>
<package3d name="D-5" urn="urn:adsk.eagle:package:43440/1" type="box" library_version="8">
<packageinstances>
<packageinstance name="D-5"/>
</packageinstances>
</package3d>
<package3d name="D-7.5" urn="urn:adsk.eagle:package:43423/1" type="box" library_version="8">
<packageinstances>
<packageinstance name="D-7.5"/>
</packageinstances>
</package3d>
<package3d name="SOD106-R" urn="urn:adsk.eagle:package:43424/2" type="model" library_version="8">
<description>SOD106 Reflow soldering Philips SC01_Mounting_1996.pdf</description>
<packageinstances>
<packageinstance name="SOD106-R"/>
</packageinstances>
</package3d>
<package3d name="SMC" urn="urn:adsk.eagle:package:43425/2" type="model" library_version="8">
<packageinstances>
<packageinstance name="SMC"/>
</packageinstances>
</package3d>
<package3d name="SOD106-W" urn="urn:adsk.eagle:package:43431/2" type="model" library_version="8">
<description>SOD106 Wave soldering Philips SC01_Mounting_1996.pdf</description>
<packageinstances>
<packageinstance name="SOD106-W"/>
</packageinstances>
</package3d>
<package3d name="SOD106A-R" urn="urn:adsk.eagle:package:43438/2" type="model" library_version="8">
<description>SOD106A Reflow soldering Philips SC01_Mounting_1996.pdf</description>
<packageinstances>
<packageinstance name="SOD106A-R"/>
</packageinstances>
</package3d>
<package3d name="SOD110-W" urn="urn:adsk.eagle:package:43428/2" type="model" library_version="8">
<description>SOD110 Wave soldering Philips SC01_Mounting_1996.pdf</description>
<packageinstances>
<packageinstance name="SOD110-W"/>
</packageinstances>
</package3d>
<package3d name="SOD110-R" urn="urn:adsk.eagle:package:43426/2" type="model" library_version="8">
<description>SOD110 Reflow soldering Philips SC01_Mounting_1996.pdf</description>
<packageinstances>
<packageinstance name="SOD110-R"/>
</packageinstances>
</package3d>
<package3d name="SOD123" urn="urn:adsk.eagle:package:43420/1" type="box" library_version="8">
<description>Diode</description>
<packageinstances>
<packageinstance name="SOD123"/>
</packageinstances>
</package3d>
<package3d name="SOD323-R" urn="urn:adsk.eagle:package:43437/1" type="box" library_version="8">
<description>SOD323 Reflow soldering Philips SC01_Mounting_1996.pdf</description>
<packageinstances>
<packageinstance name="SOD323-R"/>
</packageinstances>
</package3d>
<package3d name="SOD323-W" urn="urn:adsk.eagle:package:43418/1" type="box" library_version="8">
<description>SOD323 Wave soldering Philips SC01_Mounting_1996.pdf</description>
<packageinstances>
<packageinstance name="SOD323-W"/>
</packageinstances>
</package3d>
<package3d name="GF1" urn="urn:adsk.eagle:package:43422/1" type="box" library_version="8">
<description>GF1
<packageinstances>
<packageinstance name="GF1"/>
</packageinstances>
</package3d>
<package3d name="MINIMELF" urn="urn:adsk.eagle:package:43429/2" type="model" library_version="8">
<description>Mini Melf Diode</description>
<packageinstances>
<packageinstance name="MINIMELF"/>
</packageinstances>
</package3d>
<package3d name="MELF-MLL41" urn="urn:adsk.eagle:package:43444/1" type="box" library_version="8">
<description>DIODE
<packageinstances>
<packageinstance name="MELF-MLL41"/>
</packageinstances>
</package3d>
<package3d name="MICROMELF-R" urn="urn:adsk.eagle:package:43436/2" type="model" library_version="8">
<description>Micro Melf Diode Reflow soldering VISHAY mcl4148.pdf</description>
<packageinstances>
<packageinstance name="MICROMELF-R"/>
</packageinstances>
</package3d>
<package3d name="MICROMELF-W" urn="urn:adsk.eagle:package:43441/2" type="model" library_version="8">
<description>Micro Melf Diode Wave soldering VISHAY mcl4148.pdf</description>
<packageinstances>
<packageinstance name="MICROMELF-W"/>
</packageinstances>
</package3d>
<package3d name="SC79_INFINEON" urn="urn:adsk.eagle:package:43432/2" type="model" library_version="8">
<description>Diode Package Reflow soldering
<packageinstances>
<packageinstance name="SC79_INFINEON"/>
</packageinstances>
</package3d>
<package3d name="SCD80_INFINEON" urn="urn:adsk.eagle:package:43414/1" type="box" library_version="8">
<packageinstances>
<packageinstance name="SCD80_INFINEON"/>
</packageinstances>
</package3d>
<package3d name="DO214AA" urn="urn:adsk.eagle:package:43433/2" type="model" library_version="8">
<packageinstances>
<packageinstance name="DO214AA"/>
</packageinstances>
</package3d>
<package3d name="DO214AC" urn="urn:adsk.eagle:package:43417/2" type="model" library_version="8">
<packageinstances>
<packageinstance name="DO214AC"/>
</packageinstances>
</package3d>
<package3d name="DO214BA" urn="urn:adsk.eagle:package:43453/2" type="model" library_version="8">
<packageinstances>
<packageinstance name="DO214BA"/>
</packageinstances>
</package3d>
<package3d name="DO-214AC" urn="urn:adsk.eagle:package:43416/2" type="model" library_version="8">
<description>SURFACE MOUNT GENERAL RECTIFIER JEDEC DO-214AC molded platic body
Method 2026
<packageinstances>
<packageinstance name="DO-214AC"/>
</packageinstances>
</package3d>
<package3d name="DO41-7.6" urn="urn:adsk.eagle:package:43421/1" type="box" library_version="8">
<description>DO41 7.6mm x 2mm
<packageinstances>
<packageinstance name="DO41-7.6"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="D" urn="urn:adsk.eagle:symbol:43091/2" library_version="8">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="1.27" y2="0" width="0.254" layer="94"/>
<text x="2.54" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.3114" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="0" size="0.4064" layer="99" align="center">SpiceOrder 1</text>
<text x="2.54" y="0" size="0.4064" layer="99" align="center">SpiceOrder 2</text>
<pin name="A" x="-2.54" y="0" visible="off" length="point" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="point" direction="pas" rot="R180"/>
</symbol>
<symbol name="SCHOTTKY" urn="urn:adsk.eagle:symbol:43101/2" library_version="8">
<wire x1="1.905" y1="1.27" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.27" x2="1.905" y2="1.016" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="0.635" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0.635" y1="-1.016" x2="0.635" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.254" layer="94"/>
<text x="-2.286" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="MBRS130LT3" urn="urn:adsk.eagle:component:43637/4" prefix="D" library_version="8">
<description>&lt;b&gt;Schottky Power Rectifier&lt;/b&gt;&lt;p&gt;
Source: http://www.onsemi.com/pub/Collateral/MBRS130LT3-D.PDF</description>
<gates>
<gate name="G$1" symbol="SCHOTTKY" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SMB">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43404/2"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="POPULARITY" value="5" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE-" urn="urn:adsk.eagle:component:43657/21" prefix="D" uservalue="yes" library_version="8">
<gates>
<gate name="G$1" symbol="D" x="0" y="0"/>
</gates>
<devices>
<device name="DO41-10" package="DO41-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43336/1"/>
<technologies>
<attribute name="POPULARITY" value="2" constant="no"/>
</technology>
</technologies>
</device>
<device name="DO35-10" package="DO35-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43344/2"/>
<technologies>
<attribute name="POPULARITY" value="1" constant="no"/>
</technology>
</technologies>
</device>
<device name="DO204-10" package="DO204-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43366/1"/>
<technologies>
<attribute name="POPULARITY" value="0" constant="no"/>
</technology>
</technologies>
</device>
<device name="DO15-12" package="DO15-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43369/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD57-10" package="SOD57-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43367/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="DO201-15" package="DO201-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43365/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="DO07" package="DO07">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43394/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P1-10" package="P1-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43375/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="P2-15" package="P2-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43345/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="DO34-7" package="DO34-7">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43348/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOT54H" package="SOT54H">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43359/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD523" package="SOD523">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43410/4"/>
<technologies>
<attribute name="POPULARITY" value="3" constant="no"/>
</technology>
</technologies>
</device>
<device name="TO18D" package="TO18D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43443/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1702-05" package="C1702-05">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43430/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C1702-15" package="C1702-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43351/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SGA-10" package="SGA-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43388/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD64-10" package="SOD64-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43385/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD61A" package="SOD61A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43377/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD61B" package="SOD61B">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43379/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD61C" package="SOD61C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43378/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD61D" package="SOD61D">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43381/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD61E" package="SOD61E">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43380/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="DO27-15" package="DO27-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43337/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD81" package="SOD81">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43363/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD84" package="SOD84">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43376/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="F126-10" package="F126-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43396/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="DO220S" package="DO220S">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43371/4"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO220H" package="TO220AC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43370/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO220V" package="TO220ACS">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43373/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="G4-12" package="G4-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43368/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD83-12" package="SOD83-12">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43382/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMB" package="SMB">
<connects>
</connects>
<technologies>
<attribute name="POPULARITY" value="11" constant="no"/>
</technology>
</technologies>
</device>
<device name="P6-15" package="P6-15">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43343/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C2673" package="C2673">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43390/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="C221B1A" package="C221B1A">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43391/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD80C" package="SOD80C">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43405/2"/>
<technologies>
<attribute name="POPULARITY" value="9" constant="no"/>
</technology>
</technologies>
</device>
<device name="D-10" package="D-10">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43434/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D-12.5" package="D-12.5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43427/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="D-2.5" package="D-2.5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43419/1"/>
<technologies>
<attribute name="POPULARITY" value="10" constant="no"/>
</technology>
</technologies>
</device>
<device name="D-5" package="D-5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43440/1"/>
<technologies>
<attribute name="POPULARITY" value="8" constant="no"/>
</technology>
</technologies>
</device>
<device name="D-7.5" package="D-7.5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43423/1"/>
<technologies>
<attribute name="POPULARITY" value="4" constant="no"/>
</technology>
</technologies>
</device>
<device name="SOD106-R" package="SOD106-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43424/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SMC" package="SMC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43425/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD106-W" package="SOD106-W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43431/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD106A-R" package="SOD106A-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43438/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD110-W" package="SOD110-W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43428/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD110-R" package="SOD110-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43426/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD123" package="SOD123">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43420/1"/>
<technologies>
<attribute name="POPULARITY" value="22" constant="no"/>
</technology>
</technologies>
</device>
<device name="SOD323-R" package="SOD323-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43437/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOD323-W" package="SOD323-W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43418/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="GF1" package="GF1">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43422/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MINIMELF" package="MINIMELF">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43429/2"/>
<technologies>
<attribute name="POPULARITY" value="25" constant="no"/>
</technology>
</technologies>
</device>
<device name="MELF-MLL41" package="MELF-MLL41">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43444/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MICROMELF-R" package="MICROMELF-R">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43436/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="MICROMELF-W" package="MICROMELF-W">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43441/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SC79_INFINEON" package="SC79_INFINEON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43432/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SCD80-INFINEON" package="SCD80_INFINEON">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43414/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="DO214AA" package="DO214AA">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43433/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="DO214AC" package="DO214AC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43417/2"/>
<technologies>
<attribute name="POPULARITY" value="14" constant="no"/>
</technology>
</technologies>
</device>
<device name="DO214BA" package="DO214BA">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43453/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="DO-214AC" package="DO-214AC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43416/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="DO41-7.6" package="DO41-7.6">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:43421/1"/>
<technologies>
<attribute name="POPULARITY" value="7" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N581*" urn="urn:adsk.eagle:component:43644/3" prefix="D" library_version="8">
<description>&lt;b&gt;1.0A SCHOTTKY BARRIER RECTIFIER&lt;/b&gt;&lt;p&gt;
<gates>
</gates>
<devices>
<device name="" package="DO41-7.6">
<connects>
</connects>
<technologies>
<technology name="7-B">
</technology>
<technology name="7-T">
</technology>
<technology name="8-B">
</technology>
<technology name="8-T">
</technology>
<technology name="9-B">
</technology>
<technology name="9-T">
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="inductor-neosid" urn="urn:adsk.eagle:library:241">
<description>&lt;b&gt;Neosid Chokes and Transformers&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Electronic Component Book, Part 2 : Chokes, Fixed Value Inductors
&lt;li&gt;Part 3 : Filters, Coil Assemblies, Thermoplastic Parts
&lt;li&gt;Part 4 : SMD Filters, Coils, Fixed Value Inductors
&lt;li&gt;www.neosid.de
&lt;/ul&gt;
 &lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="MS50" urn="urn:adsk.eagle:footprint:14563/1" library_version="3">
<description>SMD &lt;B&gt;POWER INDUCTOR&lt;/B&gt;&lt;p&gt;
high current</description>
<wire x1="-0.9" y1="-2.3" x2="0.9" y2="-2.3" width="0.2032" layer="51"/>
<wire x1="-1.5" y1="1.3" x2="-1.5" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="-1.5" y1="-1.3" x2="-0.7" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="-1.3" x2="0.7" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="0.7" y1="-1.3" x2="1.5" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="1.5" y1="-1.3" x2="1.5" y2="1.3" width="0.2032" layer="51"/>
<wire x1="1.5" y1="1.3" x2="0.7" y2="1.3" width="0.2032" layer="51"/>
<wire x1="0.7" y1="1.3" x2="-0.7" y2="1.3" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="1.3" x2="-1.5" y2="1.3" width="0.2032" layer="51"/>
<wire x1="-0.9" y1="-2.3" x2="-0.7" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="0.9" y1="-2.3" x2="0.7" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="0.9" y1="2.3" x2="-0.9" y2="2.3" width="0.2032" layer="51"/>
<wire x1="0.9" y1="2.3" x2="0.7" y2="1.4" width="0.2032" layer="51"/>
<wire x1="-0.9" y1="2.3" x2="-0.7" y2="1.4" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="1.3" x2="-0.7" y2="-1.3" width="0.2032" layer="51" curve="120.036721"/>
<wire x1="0.7" y1="-1.3" x2="0.7" y2="1.3" width="0.2032" layer="51" curve="120.036721"/>
<wire x1="-1.5" y1="0.8" x2="-1.5" y2="-0.8" width="0.2032" layer="21"/>
<wire x1="1.5" y1="0.8" x2="1.5" y2="-0.8" width="0.2032" layer="21"/>
<smd name="1" x="0" y="-1.7" dx="2.8" dy="1.4" layer="1"/>
<smd name="2" x="0" y="1.7" dx="2.8" dy="1.4" layer="1"/>
<text x="-1.8" y="-1.7" size="0.8128" layer="25" rot="R90">&gt;NAME</text>
<text x="2.6" y="-1.7" size="0.8128" layer="27" rot="R90">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="MS50" urn="urn:adsk.eagle:package:14699/1" type="box" library_version="3">
<description>SMD POWER INDUCTOR
<packageinstances>
<packageinstance name="MS50"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="L" urn="urn:adsk.eagle:symbol:14504/1" library_version="3">
<text x="-3.81" y="1.778" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.556" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-1.27" x2="3.81" y2="1.27" layer="94"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MS50" urn="urn:adsk.eagle:component:14757/2" prefix="L" uservalue="yes" library_version="3">
<description>&lt;b&gt;INDUCTOR&lt;/b&gt;&lt;p&gt;
SMD power inductor</description>
<gates>
<gate name="G$1" symbol="L" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MS50">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:14699/1"/>
<technologies>
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="led" urn="urn:adsk.eagle:library:259">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="DUOLED-C-5MM" urn="urn:adsk.eagle:footprint:15723/1" library_version="5">
<description>&lt;B&gt;DUO LED&lt;/B&gt;&lt;P&gt;
2 colors (red/green, red/yellow), 5 mm, round, common Cathode&lt;BR&gt;
&lt;I&gt;www.ligitek.com&lt;/I&gt; or other producers.</description>
<wire x1="-2.794" y1="0.8636" x2="-2.794" y2="-0.8636" width="0.254" layer="51" curve="34.351807"/>
<wire x1="2.3876" y1="-0.8636" x2="2.3876" y2="0.8636" width="0.1524" layer="51" curve="39.77033"/>
<wire x1="2.54" y1="1.4478" x2="2.54" y2="0.889" width="0.254" layer="21"/>
<wire x1="-2.3876" y1="-0.8636" x2="2.3876" y2="-0.8636" width="0.1524" layer="21" curve="140.22967"/>
<wire x1="-2.7933" y1="0.8634" x2="2.54" y2="1.4478" width="0.254" layer="21" curve="-133.151599"/>
<wire x1="-2.3876" y1="0.8636" x2="-2.3876" y2="-0.8636" width="0.1524" layer="51" curve="39.77033"/>
<wire x1="-2.794" y1="-0.8636" x2="2.5407" y2="-1.4482" width="0.254" layer="21" curve="133.133633"/>
<wire x1="-2.3876" y1="0.8636" x2="2.3876" y2="0.8636" width="0.1524" layer="21" curve="-140.22967"/>
<wire x1="2.54" y1="0.9398" x2="2.54" y2="-0.889" width="0.254" layer="51"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="-1.4478" width="0.254" layer="21"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90"/>
<pad name="AX" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="C" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="AR" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="3.81" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.81" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="DUOLED-C-5MM" urn="urn:adsk.eagle:package:15851/1" type="box" library_version="5">
<description>DUO LED
www.ligitek.com or other producers.</description>
<packageinstances>
<packageinstance name="DUOLED-C-5MM"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="DUOLED-RG-C" urn="urn:adsk.eagle:symbol:15722/2" library_version="5">
<wire x1="1.27" y1="5.08" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="-1.27" y2="5.08" width="0.254" layer="94"/>
<wire x1="1.27" y1="2.54" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="-1.27" y2="2.54" width="0.254" layer="94"/>
<wire x1="1.27" y1="5.08" x2="0" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="5.08" x2="-1.27" y2="5.08" width="0.254" layer="94"/>
<wire x1="-2.032" y1="4.318" x2="-3.429" y2="2.921" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="3.175" x2="-3.302" y2="1.778" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="-5.08" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="1.27" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-2.54" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-5.08" x2="0" y2="-5.08" width="0.254" layer="94"/>
<wire x1="0" y1="-5.08" x2="1.27" y2="-5.08" width="0.254" layer="94"/>
<wire x1="2.032" y1="-4.318" x2="3.429" y2="-2.921" width="0.1524" layer="94"/>
<wire x1="1.905" y1="-3.175" x2="3.302" y2="-1.778" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="-2.54" width="0.1524" layer="94"/>
<circle x="0" y="0" radius="0.254" width="0.4064" layer="94"/>
<text x="6.35" y="-5.08" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="8.89" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<text x="2.54" y="3.81" size="1.016" layer="94" ratio="10" rot="R90">red</text>
<text x="-2.54" y="-5.08" size="1.016" layer="94" ratio="10" rot="R90">green</text>
<pin name="C" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="AR" x="0" y="7.62" visible="off" length="short" direction="pas" rot="R270"/>
<pin name="AG" x="0" y="-7.62" visible="off" length="short" direction="pas" rot="R90"/>
<polygon width="0.1524" layer="94">
<vertex x="-3.429" y="2.921"/>
<vertex x="-3.048" y="3.81"/>
<vertex x="-2.54" y="3.302"/>
</polygon>
<vertex x="-3.302" y="1.778"/>
<vertex x="-2.921" y="2.667"/>
<vertex x="-2.413" y="2.159"/>
</polygon>
<vertex x="2.413" y="-2.159"/>
<vertex x="3.302" y="-1.778"/>
<vertex x="2.921" y="-2.667"/>
</polygon>
<vertex x="2.54" y="-3.302"/>
<vertex x="3.429" y="-2.921"/>
<vertex x="3.048" y="-3.81"/>
</polygon>
</symbol>
</symbols>
<devicesets>
<deviceset name="DUOLED-RG-C" urn="urn:adsk.eagle:component:15929/3" prefix="LD" uservalue="yes" library_version="5">
2 colors (red/green), 5 mm, round, common Cathode&lt;BR&gt;
<gates>
<gate name="G$1" symbol="DUOLED-RG-C" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DUOLED-C-5MM">
<connects>
<connect gate="G$1" pin="AG" pad="AX"/>
<connect gate="G$1" pin="AR" pad="AR"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:15851/1"/>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="display-kingbright" urn="urn:adsk.eagle:library:213">
<description>&lt;b&gt;KINGBRIGHT Numeric Displays&lt;/b&gt;&lt;p&gt;
&lt;author&gt;librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="BX56-12" urn="urn:adsk.eagle:footprint:13072/1" library_version="1">
<description>&lt;b&gt;14.22mm (0.56INCH) THREE DIGIT NUMERIC DISPLAY&lt;/b&gt;&lt;p&gt;
Source: http://www.kingbright.com .. BA56-11EWA(Ver1189474895.pdf</description>
<wire x1="-18.675" y1="9.4" x2="18.7" y2="9.4" width="0.2032" layer="21"/>
<wire x1="18.7" y1="9.4" x2="18.7" y2="-9.4" width="0.2032" layer="21"/>
<wire x1="18.7" y1="-9.4" x2="-18.675" y2="-9.4" width="0.2032" layer="21"/>
<wire x1="-18.675" y1="-9.4" x2="-18.675" y2="9.4" width="0.2032" layer="21"/>
<circle x="-7.6017" y="-6.5231" radius="0.7305" width="0" layer="21"/>
<circle x="5.0233" y="-6.5731" radius="0.7305" width="0" layer="21"/>
<circle x="17.6983" y="-6.4481" radius="0.7305" width="0" layer="21"/>
<pad name="1" x="-6.35" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="2" x="-3.81" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="3" x="-1.27" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="4" x="1.27" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="5" x="3.81" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="6" x="6.35" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="7" x="6.35" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="8" x="3.81" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="9" x="1.27" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="10" x="-1.27" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="11" x="-3.81" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="12" x="-6.35" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<text x="-18.415" y="10.16" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.715" y="10.16" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<polygon width="0.3976" layer="21" spacing="1.2428">
<vertex x="-13.5445" y="5.9694"/>
<vertex x="-13.3733" y="6.948"/>
<vertex x="-9.3537" y="6.948"/>
<vertex x="-9.476" y="5.9694"/>
</polygon>
<vertex x="-9.7632" y="1.0329"/>
<vertex x="-8.7296" y="6.9034"/>
<vertex x="-8.427" y="6.9114" curve="-104.731141"/>
<vertex x="-7.8092" y="6.071"/>
<vertex x="-8.8399" y="0.4893"/>
<vertex x="-9.3047" y="0.4893"/>
</polygon>
<vertex x="-15.0369" y="1.0764"/>
<vertex x="-14.0093" y="6.948"/>
<vertex x="-14.2785" y="6.948" curve="77.705866"/>
<vertex x="-15.1592" y="6.2385"/>
<vertex x="-16.1622" y="0.4893"/>
<vertex x="-15.5995" y="0.4893"/>
</polygon>
<vertex x="-15.1347" y="0.0245"/>
<vertex x="-14.5231" y="0.6361"/>
<vertex x="-10.3078" y="0.6361"/>
<vertex x="-9.9408" y="0.1223"/>
<vertex x="-10.3812" y="-0.3425"/>
<vertex x="-14.7677" y="-0.3425"/>
</polygon>
<vertex x="-11.4821" y="-5.7003"/>
<vertex x="-11.6533" y="-6.6789"/>
<vertex x="-15.6729" y="-6.6789"/>
<vertex x="-15.5506" y="-5.7003"/>
</polygon>
<vertex x="-15.3368" y="-0.7149"/>
<vertex x="-16.2971" y="-6.6343"/>
<vertex x="-16.5997" y="-6.6423" curve="-104.72259"/>
<vertex x="-17.2174" y="-5.8019"/>
<vertex x="-16.2601" y="-0.1713"/>
<vertex x="-15.7953" y="-0.1713"/>
</polygon>
<vertex x="-10.0387" y="-0.9541"/>
<vertex x="-11.0173" y="-6.6789"/>
<vertex x="-10.7482" y="-6.6789" curve="77.701982"/>
<vertex x="-9.8674" y="-5.9694"/>
<vertex x="-8.9378" y="-0.4159"/>
<vertex x="-9.5005" y="-0.4159"/>
</polygon>
<polygon width="0.3976" layer="51" spacing="1.2428">
<vertex x="-1.0445" y="5.9694"/>
<vertex x="-0.8733" y="6.948"/>
<vertex x="3.1463" y="6.948"/>
<vertex x="3.024" y="5.9694"/>
</polygon>
<vertex x="2.7368" y="1.0329"/>
<vertex x="3.7704" y="6.9034"/>
<vertex x="4.073" y="6.9114" curve="-104.731141"/>
<vertex x="4.6908" y="6.071"/>
<vertex x="3.6601" y="0.4893"/>
<vertex x="3.1953" y="0.4893"/>
</polygon>
<vertex x="-2.5369" y="1.0764"/>
<vertex x="-1.5093" y="6.948"/>
<vertex x="-1.7785" y="6.948" curve="77.705866"/>
<vertex x="-2.6592" y="6.2385"/>
<vertex x="-3.6622" y="0.4893"/>
<vertex x="-3.0995" y="0.4893"/>
</polygon>
<vertex x="-2.6347" y="0.0245"/>
<vertex x="-2.0231" y="0.6361"/>
<vertex x="2.1922" y="0.6361"/>
<vertex x="2.5592" y="0.1223"/>
<vertex x="2.1188" y="-0.3425"/>
<vertex x="-2.2677" y="-0.3425"/>
</polygon>
<vertex x="1.0179" y="-5.7003"/>
<vertex x="0.8467" y="-6.6789"/>
<vertex x="-3.1729" y="-6.6789"/>
<vertex x="-3.0506" y="-5.7003"/>
</polygon>
<vertex x="-2.8368" y="-0.7149"/>
<vertex x="-3.7971" y="-6.6343"/>
<vertex x="-4.0997" y="-6.6423" curve="-104.72259"/>
<vertex x="-4.7174" y="-5.8019"/>
<vertex x="-3.7601" y="-0.1713"/>
<vertex x="-3.2953" y="-0.1713"/>
</polygon>
<vertex x="2.4613" y="-0.9541"/>
<vertex x="1.4827" y="-6.6789"/>
<vertex x="1.7518" y="-6.6789" curve="77.701982"/>
<vertex x="2.6326" y="-5.9694"/>
<vertex x="3.5622" y="-0.4159"/>
<vertex x="2.9995" y="-0.4159"/>
</polygon>
<vertex x="11.4555" y="5.9694"/>
<vertex x="11.6267" y="6.948"/>
<vertex x="15.6463" y="6.948"/>
<vertex x="15.524" y="5.9694"/>
</polygon>
<vertex x="15.2368" y="1.0329"/>
<vertex x="16.2704" y="6.9034"/>
<vertex x="16.573" y="6.9114" curve="-104.731141"/>
<vertex x="17.1908" y="6.071"/>
<vertex x="16.1601" y="0.4893"/>
<vertex x="15.6953" y="0.4893"/>
</polygon>
<vertex x="9.9631" y="1.0764"/>
<vertex x="10.9907" y="6.948"/>
<vertex x="10.7215" y="6.948" curve="77.705866"/>
<vertex x="9.8408" y="6.2385"/>
<vertex x="8.8378" y="0.4893"/>
<vertex x="9.4005" y="0.4893"/>
</polygon>
<vertex x="9.8653" y="0.0245"/>
<vertex x="10.4769" y="0.6361"/>
<vertex x="14.6922" y="0.6361"/>
<vertex x="15.0592" y="0.1223"/>
<vertex x="14.6188" y="-0.3425"/>
<vertex x="10.2323" y="-0.3425"/>
</polygon>
<vertex x="13.5179" y="-5.7003"/>
<vertex x="13.3467" y="-6.6789"/>
<vertex x="9.3271" y="-6.6789"/>
<vertex x="9.4494" y="-5.7003"/>
</polygon>
<vertex x="9.6632" y="-0.7149"/>
<vertex x="8.7029" y="-6.6343"/>
<vertex x="8.4003" y="-6.6423" curve="-104.72259"/>
<vertex x="7.7826" y="-5.8019"/>
<vertex x="8.7399" y="-0.1713"/>
<vertex x="9.2047" y="-0.1713"/>
</polygon>
<vertex x="14.9613" y="-0.9541"/>
<vertex x="13.9827" y="-6.6789"/>
<vertex x="14.2518" y="-6.6789" curve="77.701982"/>
<vertex x="15.1326" y="-5.9694"/>
<vertex x="16.0622" y="-0.4159"/>
<vertex x="15.4995" y="-0.4159"/>
</polygon>
</package>
</packages>
<packages3d>
<package3d name="BX56-12" urn="urn:adsk.eagle:package:13083/1" type="box" library_version="1">
<description>14.22mm (0.56INCH) THREE DIGIT NUMERIC DISPLAY
<packageinstances>
<packageinstance name="BX56-12"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="7SEG-3-COM" urn="urn:adsk.eagle:symbol:13071/1" library_version="1">
<wire x1="-5.2832" y1="3.1242" x2="-5.588" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-5.588" y1="2.8194" x2="-5.9944" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-5.9944" y1="0.6096" x2="-5.715" y2="0.3302" width="0.254" layer="94"/>
<wire x1="-5.715" y1="0.3302" x2="-5.461" y2="0.5842" width="0.254" layer="94"/>
<wire x1="-5.461" y1="0.5842" x2="-5.08" y2="2.921" width="0.254" layer="94"/>
<wire x1="-5.08" y1="2.921" x2="-5.2832" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-5.588" y1="3.429" x2="-5.842" y2="3.175" width="0.254" layer="94"/>
<wire x1="-5.842" y1="3.175" x2="-8.382" y2="3.175" width="0.254" layer="94"/>
<wire x1="-8.382" y1="3.175" x2="-8.636" y2="3.429" width="0.254" layer="94"/>
<wire x1="-8.636" y1="3.429" x2="-8.382" y2="3.683" width="0.254" layer="94"/>
<wire x1="-8.382" y1="3.683" x2="-5.842" y2="3.683" width="0.254" layer="94"/>
<wire x1="-5.842" y1="3.683" x2="-5.588" y2="3.429" width="0.254" layer="94"/>
<wire x1="-8.9408" y1="3.1242" x2="-8.636" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-8.636" y1="2.8194" x2="-9.017" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-9.017" y1="0.6096" x2="-9.271" y2="0.3556" width="0.254" layer="94"/>
<wire x1="-9.271" y1="0.3556" x2="-9.525" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-9.525" y1="0.6096" x2="-9.144" y2="2.921" width="0.254" layer="94"/>
<wire x1="-9.144" y1="2.921" x2="-8.9408" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-9.0932" y1="-0.0762" x2="-8.763" y2="0.254" width="0.254" layer="94"/>
<wire x1="-8.763" y1="0.254" x2="-6.2738" y2="0.254" width="0.254" layer="94"/>
<wire x1="-6.2738" y1="0.254" x2="-6.0706" y2="0.0508" width="0.254" layer="94"/>
<wire x1="-6.0706" y1="0.0508" x2="-6.3754" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-6.3754" y1="-0.254" x2="-8.9154" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-8.9154" y1="-0.254" x2="-9.0932" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="-9.4488" y1="-0.3302" x2="-9.1948" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-9.906" y1="-3.1242" x2="-9.5758" y2="-2.794" width="0.254" layer="94"/>
<wire x1="-9.4488" y1="-0.3302" x2="-9.7282" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="-9.7282" y1="-0.6096" x2="-10.1092" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-10.1092" y1="-2.921" x2="-9.906" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-9.6012" y1="-3.429" x2="-9.3472" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-9.3472" y1="-3.175" x2="-6.8072" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-6.8072" y1="-3.175" x2="-6.5532" y2="-3.429" width="0.254" layer="94"/>
<wire x1="-6.5532" y1="-3.429" x2="-6.8072" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-6.8072" y1="-3.683" x2="-9.3472" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-9.3472" y1="-3.683" x2="-9.6012" y2="-3.429" width="0.254" layer="94"/>
<wire x1="-5.9182" y1="-0.4064" x2="-6.1722" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="-6.1722" y1="-0.6604" x2="-6.5532" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="-6.5532" y1="-2.8194" x2="-6.2484" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-6.2484" y1="-3.1242" x2="-6.0452" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-6.0452" y1="-2.921" x2="-5.6642" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="-5.6642" y1="-0.6604" x2="-5.9182" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="-5.334" y1="2.794" x2="-5.715" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-5.842" y1="3.429" x2="-8.382" y2="3.429" width="0.4064" layer="94"/>
<wire x1="-8.89" y1="2.794" x2="-9.271" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-8.89" y1="0" x2="-6.35" y2="0" width="0.4064" layer="94"/>
<wire x1="-5.969" y1="-0.762" x2="-6.35" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="-6.858" y1="-3.429" x2="-9.271" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="-9.906" y1="-2.921" x2="-9.525" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="-11.43" y1="5.08" x2="11.43" y2="5.08" width="0.4064" layer="94"/>
<wire x1="11.43" y1="-5.08" x2="11.43" y2="5.08" width="0.4064" layer="94"/>
<wire x1="11.43" y1="-5.08" x2="-11.43" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-11.43" y1="5.08" x2="-11.43" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-4.953" x2="7.62" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-4.953" x2="5.08" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="0" y1="-4.953" x2="0" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-4.953" x2="-5.08" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="-4.953" x2="-7.62" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="10.16" y1="10.16" x2="10.16" y2="4.953" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-4.953" x2="-2.54" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-4.953" x2="2.54" y2="-10.16" width="0.1524" layer="94"/>
<wire x1="7.62" y1="10.16" x2="7.62" y2="4.953" width="0.1524" layer="94"/>
<wire x1="-5.207" y1="-3.429" x2="-4.953" y2="-3.429" width="0.3048" layer="94"/>
<wire x1="5.08" y1="10.16" x2="5.08" y2="4.953" width="0.1524" layer="94"/>
<wire x1="-9.5758" y1="-2.794" x2="-9.1948" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="2.3368" y1="3.1242" x2="2.032" y2="2.8194" width="0.254" layer="94"/>
<wire x1="2.032" y1="2.8194" x2="1.6256" y2="0.6096" width="0.254" layer="94"/>
<wire x1="1.6256" y1="0.6096" x2="1.905" y2="0.3302" width="0.254" layer="94"/>
<wire x1="1.905" y1="0.3302" x2="2.159" y2="0.5842" width="0.254" layer="94"/>
<wire x1="2.159" y1="0.5842" x2="2.54" y2="2.921" width="0.254" layer="94"/>
<wire x1="2.54" y1="2.921" x2="2.3368" y2="3.1242" width="0.254" layer="94"/>
<wire x1="2.032" y1="3.429" x2="1.778" y2="3.175" width="0.254" layer="94"/>
<wire x1="1.778" y1="3.175" x2="-0.762" y2="3.175" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.175" x2="-1.016" y2="3.429" width="0.254" layer="94"/>
<wire x1="-1.016" y1="3.429" x2="-0.762" y2="3.683" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.683" x2="1.778" y2="3.683" width="0.254" layer="94"/>
<wire x1="1.778" y1="3.683" x2="2.032" y2="3.429" width="0.254" layer="94"/>
<wire x1="-1.3208" y1="3.1242" x2="-1.016" y2="2.8194" width="0.254" layer="94"/>
<wire x1="-1.016" y1="2.8194" x2="-1.397" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-1.397" y1="0.6096" x2="-1.651" y2="0.3556" width="0.254" layer="94"/>
<wire x1="-1.651" y1="0.3556" x2="-1.905" y2="0.6096" width="0.254" layer="94"/>
<wire x1="-1.905" y1="0.6096" x2="-1.524" y2="2.921" width="0.254" layer="94"/>
<wire x1="-1.524" y1="2.921" x2="-1.3208" y2="3.1242" width="0.254" layer="94"/>
<wire x1="-1.4732" y1="-0.0762" x2="-1.143" y2="0.254" width="0.254" layer="94"/>
<wire x1="-1.143" y1="0.254" x2="1.3462" y2="0.254" width="0.254" layer="94"/>
<wire x1="1.3462" y1="0.254" x2="1.5494" y2="0.0508" width="0.254" layer="94"/>
<wire x1="1.5494" y1="0.0508" x2="1.2446" y2="-0.254" width="0.254" layer="94"/>
<wire x1="1.2446" y1="-0.254" x2="-1.2954" y2="-0.254" width="0.254" layer="94"/>
<wire x1="-1.2954" y1="-0.254" x2="-1.4732" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="-1.8288" y1="-0.3302" x2="-1.5748" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="-2.286" y1="-3.1242" x2="-1.9558" y2="-2.794" width="0.254" layer="94"/>
<wire x1="-1.8288" y1="-0.3302" x2="-2.1082" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="-2.1082" y1="-0.6096" x2="-2.4892" y2="-2.921" width="0.254" layer="94"/>
<wire x1="-2.4892" y1="-2.921" x2="-2.286" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="-1.9812" y1="-3.429" x2="-1.7272" y2="-3.175" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.175" x2="0.8128" y2="-3.175" width="0.254" layer="94"/>
<wire x1="0.8128" y1="-3.175" x2="1.0668" y2="-3.429" width="0.254" layer="94"/>
<wire x1="1.0668" y1="-3.429" x2="0.8128" y2="-3.683" width="0.254" layer="94"/>
<wire x1="0.8128" y1="-3.683" x2="-1.7272" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-1.7272" y1="-3.683" x2="-1.9812" y2="-3.429" width="0.254" layer="94"/>
<wire x1="1.7018" y1="-0.4064" x2="1.4478" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="1.4478" y1="-0.6604" x2="1.0668" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="1.0668" y1="-2.8194" x2="1.3716" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="1.3716" y1="-3.1242" x2="1.5748" y2="-2.921" width="0.254" layer="94"/>
<wire x1="1.5748" y1="-2.921" x2="1.9558" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="1.9558" y1="-0.6604" x2="1.7018" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="2.286" y1="2.794" x2="1.905" y2="0.635" width="0.4064" layer="94"/>
<wire x1="1.778" y1="3.429" x2="-0.762" y2="3.429" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="2.794" x2="-1.651" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.4064" layer="94"/>
<wire x1="1.651" y1="-0.762" x2="1.27" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="0.762" y1="-3.429" x2="-1.651" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="-2.286" y1="-2.921" x2="-1.905" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="2.413" y1="-3.429" x2="2.667" y2="-3.429" width="0.3048" layer="94"/>
<wire x1="-1.9558" y1="-2.794" x2="-1.5748" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="9.9568" y1="3.1242" x2="9.652" y2="2.8194" width="0.254" layer="94"/>
<wire x1="9.652" y1="2.8194" x2="9.2456" y2="0.6096" width="0.254" layer="94"/>
<wire x1="9.2456" y1="0.6096" x2="9.525" y2="0.3302" width="0.254" layer="94"/>
<wire x1="9.525" y1="0.3302" x2="9.779" y2="0.5842" width="0.254" layer="94"/>
<wire x1="9.779" y1="0.5842" x2="10.16" y2="2.921" width="0.254" layer="94"/>
<wire x1="10.16" y1="2.921" x2="9.9568" y2="3.1242" width="0.254" layer="94"/>
<wire x1="9.652" y1="3.429" x2="9.398" y2="3.175" width="0.254" layer="94"/>
<wire x1="9.398" y1="3.175" x2="6.858" y2="3.175" width="0.254" layer="94"/>
<wire x1="6.858" y1="3.175" x2="6.604" y2="3.429" width="0.254" layer="94"/>
<wire x1="6.604" y1="3.429" x2="6.858" y2="3.683" width="0.254" layer="94"/>
<wire x1="6.858" y1="3.683" x2="9.398" y2="3.683" width="0.254" layer="94"/>
<wire x1="9.398" y1="3.683" x2="9.652" y2="3.429" width="0.254" layer="94"/>
<wire x1="6.2992" y1="3.1242" x2="6.604" y2="2.8194" width="0.254" layer="94"/>
<wire x1="6.604" y1="2.8194" x2="6.223" y2="0.6096" width="0.254" layer="94"/>
<wire x1="6.223" y1="0.6096" x2="5.969" y2="0.3556" width="0.254" layer="94"/>
<wire x1="5.969" y1="0.3556" x2="5.715" y2="0.6096" width="0.254" layer="94"/>
<wire x1="5.715" y1="0.6096" x2="6.096" y2="2.921" width="0.254" layer="94"/>
<wire x1="6.096" y1="2.921" x2="6.2992" y2="3.1242" width="0.254" layer="94"/>
<wire x1="6.1468" y1="-0.0762" x2="6.477" y2="0.254" width="0.254" layer="94"/>
<wire x1="6.477" y1="0.254" x2="8.9662" y2="0.254" width="0.254" layer="94"/>
<wire x1="8.9662" y1="0.254" x2="9.1694" y2="0.0508" width="0.254" layer="94"/>
<wire x1="9.1694" y1="0.0508" x2="8.8646" y2="-0.254" width="0.254" layer="94"/>
<wire x1="8.8646" y1="-0.254" x2="6.3246" y2="-0.254" width="0.254" layer="94"/>
<wire x1="6.3246" y1="-0.254" x2="6.1468" y2="-0.0762" width="0.254" layer="94"/>
<wire x1="5.7912" y1="-0.3302" x2="6.0452" y2="-0.5842" width="0.254" layer="94"/>
<wire x1="5.334" y1="-3.1242" x2="5.6642" y2="-2.794" width="0.254" layer="94"/>
<wire x1="5.7912" y1="-0.3302" x2="5.5118" y2="-0.6096" width="0.254" layer="94"/>
<wire x1="5.5118" y1="-0.6096" x2="5.1308" y2="-2.921" width="0.254" layer="94"/>
<wire x1="5.1308" y1="-2.921" x2="5.334" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="5.6388" y1="-3.429" x2="5.8928" y2="-3.175" width="0.254" layer="94"/>
<wire x1="5.8928" y1="-3.175" x2="8.4328" y2="-3.175" width="0.254" layer="94"/>
<wire x1="8.4328" y1="-3.175" x2="8.6868" y2="-3.429" width="0.254" layer="94"/>
<wire x1="8.6868" y1="-3.429" x2="8.4328" y2="-3.683" width="0.254" layer="94"/>
<wire x1="8.4328" y1="-3.683" x2="5.8928" y2="-3.683" width="0.254" layer="94"/>
<wire x1="5.8928" y1="-3.683" x2="5.6388" y2="-3.429" width="0.254" layer="94"/>
<wire x1="9.3218" y1="-0.4064" x2="9.0678" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="9.0678" y1="-0.6604" x2="8.6868" y2="-2.8194" width="0.254" layer="94"/>
<wire x1="8.6868" y1="-2.8194" x2="8.9916" y2="-3.1242" width="0.254" layer="94"/>
<wire x1="8.9916" y1="-3.1242" x2="9.1948" y2="-2.921" width="0.254" layer="94"/>
<wire x1="9.1948" y1="-2.921" x2="9.5758" y2="-0.6604" width="0.254" layer="94"/>
<wire x1="9.5758" y1="-0.6604" x2="9.3218" y2="-0.4064" width="0.254" layer="94"/>
<wire x1="9.906" y1="2.794" x2="9.525" y2="0.635" width="0.4064" layer="94"/>
<wire x1="9.398" y1="3.429" x2="6.858" y2="3.429" width="0.4064" layer="94"/>
<wire x1="6.35" y1="2.794" x2="5.969" y2="0.635" width="0.4064" layer="94"/>
<wire x1="6.35" y1="0" x2="8.89" y2="0" width="0.4064" layer="94"/>
<wire x1="9.271" y1="-0.762" x2="8.89" y2="-2.794" width="0.4064" layer="94"/>
<wire x1="8.382" y1="-3.429" x2="5.969" y2="-3.429" width="0.4064" layer="94"/>
<wire x1="5.334" y1="-2.921" x2="5.715" y2="-0.635" width="0.4064" layer="94"/>
<wire x1="10.033" y1="-3.429" x2="10.287" y2="-3.429" width="0.3048" layer="94"/>
<wire x1="5.6642" y1="-2.794" x2="6.0452" y2="-0.5842" width="0.254" layer="94"/>
<circle x="-5.08" y="-3.429" radius="0.254" width="0.3048" layer="94"/>
<circle x="2.54" y="-3.429" radius="0.254" width="0.3048" layer="94"/>
<circle x="10.16" y="-3.429" radius="0.254" width="0.3048" layer="94"/>
<text x="-12.065" y="-5.08" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="13.97" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<text x="9.906" y="6.096" size="1.27" layer="95" rot="R90">CA3</text>
<text x="7.366" y="6.096" size="1.27" layer="95" rot="R90">CA2</text>
<text x="-7.874" y="-7.239" size="1.27" layer="95" rot="R90">a</text>
<text x="-5.334" y="-7.239" size="1.27" layer="95" rot="R90">b</text>
<text x="-2.794" y="-7.239" size="1.27" layer="95" rot="R90">c</text>
<text x="-0.254" y="-7.239" size="1.27" layer="95" rot="R90">d</text>
<text x="2.286" y="-7.239" size="1.27" layer="95" rot="R90">e</text>
<text x="4.826" y="-7.239" size="1.27" layer="95" rot="R90">f</text>
<text x="7.366" y="-7.239" size="1.27" layer="95" rot="R90">g</text>
<text x="10.414" y="-7.62" size="1.27" layer="95" rot="MR90">dp</text>
<text x="4.826" y="6.096" size="1.27" layer="95" rot="R90">CA1</text>
<pin name="DP" x="10.16" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="F" x="5.08" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="D" x="0" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="B" x="-5.08" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="A" x="-7.62" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="CA@3" x="10.16" y="10.16" visible="off" length="middle" direction="pas" rot="R270"/>
<pin name="C" x="-2.54" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="E" x="2.54" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="G" x="7.62" y="-10.16" visible="off" length="middle" direction="pas" rot="R90"/>
<pin name="CA@2" x="7.62" y="10.16" visible="off" length="middle" direction="pas" rot="R270"/>
<pin name="CA@1" x="5.08" y="10.16" visible="off" length="middle" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="B?56-12*WA" urn="urn:adsk.eagle:component:13088/1" prefix="LED" library_version="1">
<gates>
<gate name="DIG1" symbol="7SEG-3-COM" x="0" y="0"/>
</gates>
<devices>
<device name="A" package="BX56-12">
<connects>
<connect gate="DIG1" pin="A" pad="11"/>
<connect gate="DIG1" pin="B" pad="7"/>
<connect gate="DIG1" pin="C" pad="4"/>
<connect gate="DIG1" pin="CA@1" pad="12"/>
<connect gate="DIG1" pin="CA@2" pad="9"/>
<connect gate="DIG1" pin="CA@3" pad="8"/>
<connect gate="DIG1" pin="D" pad="2"/>
<connect gate="DIG1" pin="DP" pad="3"/>
<connect gate="DIG1" pin="E" pad="1"/>
<connect gate="DIG1" pin="F" pad="10"/>
<connect gate="DIG1" pin="G" pad="5"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:13083/1"/>
<technologies>
<technology name="E">
</technology>
<technology name="G">
</technology>
<technology name="SR">
</technology>
<technology name="Y">
</technology>
</technologies>
</device>
<device name="C" package="BX56-12">
<connects>
</connects>
<technologies>
</technology>
</technology>
</technology>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="linear" urn="urn:adsk.eagle:library:262">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="TO99" urn="urn:adsk.eagle:footprint:16138/1" library_version="5">
<description>&lt;b&gt;Metal Can Package&lt;/b&gt;</description>
<wire x1="-4.572" y1="0.508" x2="-5.334" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-0.508" x2="-5.334" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-0.508" x2="-4.572" y2="-0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.8608" width="0.0508" layer="21"/>
<pad name="4" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="8" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="6" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="1" x="-1.778" y="-1.778" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.778" y="-1.778" drill="0.8128" shape="octagon"/>
<pad name="5" x="1.778" y="1.778" drill="0.8128" shape="octagon"/>
<pad name="7" x="-1.778" y="1.778" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.667" y="-5.969" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SO08" urn="urn:adsk.eagle:footprint:16130/1" library_version="5">
<description>&lt;b&gt;Small Outline Package 8&lt;/b&gt;&lt;br&gt;
NS Package M08A</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
<package name="DIL08" urn="urn:adsk.eagle:footprint:16129/1" library_version="5">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="TO99" urn="urn:adsk.eagle:package:16405/1" type="box" library_version="5">
<description>Metal Can Package</description>
<packageinstances>
<packageinstance name="TO99"/>
</packageinstances>
</package3d>
<package3d name="SO08" urn="urn:adsk.eagle:package:16404/2" type="model" library_version="5">
<description>Small Outline Package 8
<packageinstances>
<packageinstance name="SO08"/>
</packageinstances>
</package3d>
<package3d name="DIL08" urn="urn:adsk.eagle:package:16409/2" type="model" library_version="5">
<description>Dual In Line Package</description>
<packageinstances>
<packageinstance name="DIL08"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="2NUL" urn="urn:adsk.eagle:symbol:16132/1" library_version="5">
<wire x1="-3.81" y1="3.175" x2="-3.81" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="3.8862" width="0.1524" layer="94"/>
<wire x1="0" y1="5.0546" x2="0" y2="2.6162" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.6162" x2="0" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-3.9116" x2="-2.54" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="5.08" y1="2.54" x2="2.6162" y2="1.3208" width="0.1524" layer="94"/>
<wire x1="5.08" y1="0" x2="-5.08" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="0" width="0.4064" layer="94"/>
<text x="2.54" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="3.175" size="0.8128" layer="93" rot="R90">ON1</text>
<text x="3.175" y="2.54" size="0.8128" layer="93" rot="R90">ON2</text>
<text x="1.27" y="-5.08" size="0.8128" layer="93" rot="R90">OPT</text>
<text x="-1.27" y="4.445" size="0.8128" layer="93" rot="R90">V+</text>
<text x="-1.27" y="-5.715" size="0.8128" layer="93" rot="R90">V-</text>
<pin name="ON2" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="ON1" x="0" y="7.62" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="-IN" x="-7.62" y="-2.54" visible="pad" length="short" direction="in"/>
<pin name="+IN" x="-7.62" y="2.54" visible="pad" length="short" direction="in"/>
<pin name="OUT" x="7.62" y="0" visible="pad" length="short" direction="out" rot="R180"/>
<pin name="OPT" x="0" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="V+" x="-2.54" y="7.62" visible="pad" length="short" direction="pwr" rot="R270"/>
<pin name="V-" x="-2.54" y="-7.62" visible="pad" length="short" direction="pwr" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="OP07*" urn="urn:adsk.eagle:component:16573/4" prefix="IC" library_version="5">
<description>&lt;b&gt;OP AMP&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="2NUL" x="5.08" y="0"/>
</gates>
<devices>
<device name="H" package="TO99">
<connects>
<connect gate="A" pin="+IN" pad="3"/>
<connect gate="A" pin="-IN" pad="2"/>
<connect gate="A" pin="ON1" pad="1"/>
<connect gate="A" pin="ON2" pad="8"/>
<connect gate="A" pin="OPT" pad="5"/>
<connect gate="A" pin="OUT" pad="6"/>
<connect gate="A" pin="V+" pad="7"/>
<connect gate="A" pin="V-" pad="4"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:16405/1"/>
<technologies>
</technology>
<technology name="A">
</technology>
<technology name="C">
</technology>
<technology name="D">
</technology>
</technology>
</technologies>
</device>
<device name="R" package="SO08">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:16404/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="N" package="DIL08">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:16409/2"/>
<technologies>
</technology>
</technology>
</technology>
</technology>
<technology name="Z">
</technology>
</technologies>
</device>
<device name="" package="DIL08">
<connects>
</connects>
<technologies>
<technology name="CQ">
</technology>
<technology name="DQ">
</technology>
<technology name="EQ">
</technology>
<technology name="Q">
</technology>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="switch-alps" urn="urn:adsk.eagle:library:373">
<description>ALPS Switch from Markus Faust &amp;lt;mfaust@htwm.de&amp;gt;&lt;p&gt;
Source: EC12E.scr from eagle.support.ger on news.cadsoft.de at 08.10.2007</description>
<packages>
<package name="ALPS_EC12E_SW" urn="urn:adsk.eagle:footprint:27082/1" library_version="2">
<description>ALPS rotary encoder&lt;br&gt;
EC12E series with push-on switch</description>
<wire x1="-6.2" y1="-6.6" x2="6.2" y2="-6.6" width="0.127" layer="21"/>
<wire x1="6.2" y1="-6.6" x2="6.2" y2="6.6" width="0.127" layer="21"/>
<wire x1="6.2" y1="6.6" x2="-6.2" y2="6.6" width="0.127" layer="21"/>
<wire x1="-6.2" y1="6.6" x2="-6.2" y2="-6.6" width="0.127" layer="21"/>
<wire x1="-2.6" y1="1.5" x2="2.6" y2="1.5" width="0.127" layer="21"/>
<circle x="0" y="0" radius="3" width="0.127" layer="21"/>
<pad name="A" x="-2.5" y="-7.5" drill="1" shape="square"/>
<pad name="C" x="0" y="-7.5" drill="1" shape="square"/>
<pad name="B" x="2.5" y="-7.5" drill="1" shape="square"/>
<pad name="D" x="-2.5" y="7" drill="1" shape="square"/>
<pad name="E" x="2.5" y="7" drill="1" shape="square"/>
<pad name="GND1" x="-6.1" y="0" drill="2.2" shape="square"/>
<pad name="GND2" x="6.1" y="0" drill="2.2" shape="square"/>
<text x="-2.5" y="8.5" size="1.27" layer="25">&gt;NAME</text>
<text x="3.5" y="-9" size="1.27" layer="27" rot="R180">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="ALPS_EC12E_SW" urn="urn:adsk.eagle:package:27083/1" type="box" library_version="2">
<packageinstances>
<packageinstance name="ALPS_EC12E_SW"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="ENCODER" urn="urn:adsk.eagle:symbol:27079/1" library_version="2">
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="4.1275" width="0.3048" layer="94"/>
<wire x1="-2.54" y1="4.1275" x2="-0.9525" y2="1.905" width="0.3048" layer="94"/>
<wire x1="-1.905" y1="1.905" x2="-2.54" y2="1.905" width="0.3048" layer="94"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="0" width="0.3048" layer="94"/>
<wire x1="2.54" y1="5.08" x2="2.54" y2="4.1275" width="0.3048" layer="94"/>
<wire x1="2.54" y1="4.1275" x2="4.1275" y2="1.905" width="0.3048" layer="94"/>
<wire x1="3.175" y1="1.905" x2="2.54" y2="1.905" width="0.3048" layer="94"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="0" width="0.3048" layer="94"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<circle x="0" y="0" radius="0.5679" width="0" layer="94"/>
<text x="-3.81" y="0" size="1.27" layer="95" rot="R90">&gt;PART</text>
<text x="6.35" y="0" size="1.27" layer="96" rot="R90">&gt;VALUE</text>
<pin name="C" x="0" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="A" x="-2.54" y="7.62" visible="off" length="short" direction="pas" rot="R270"/>
<pin name="B" x="2.54" y="7.62" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="TASTER" urn="urn:adsk.eagle:symbol:27080/1" library_version="2">
<wire x1="-2.54" y1="0" x2="-1.5875" y2="0" width="0.3048" layer="94"/>
<wire x1="-1.5875" y1="0" x2="0.635" y2="1.5875" width="0.3048" layer="94"/>
<wire x1="0.635" y1="0.635" x2="0.635" y2="0" width="0.3048" layer="94"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.3048" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="3.81" width="0.127" layer="94" style="shortdash"/>
<wire x1="-0.635" y1="3.81" x2="0.635" y2="3.81" width="0.127" layer="94"/>
<wire x1="-0.635" y1="3.81" x2="-0.635" y2="3.4925" width="0.127" layer="94"/>
<wire x1="0.635" y1="3.81" x2="0.635" y2="3.4925" width="0.127" layer="94"/>
<text x="-5.08" y="5.08" size="1.27" layer="95">&gt;PART</text>
<text x="-5.08" y="-2.54" size="1.27" layer="96">&gt;VALUE</text>
<pin name="1" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="GEHAEUSEANSCHLUSS" urn="urn:adsk.eagle:symbol:27081/1" library_version="2">
<wire x1="0" y1="0" x2="0.9525" y2="0" width="0.254" layer="94"/>
<wire x1="1.5875" y1="0" x2="2.2225" y2="0" width="0.254" layer="94"/>
<wire x1="2.8575" y1="0" x2="3.4925" y2="0" width="0.254" layer="94"/>
<wire x1="4.1275" y1="0" x2="5.08" y2="0" width="0.254" layer="94"/>
<pin name="G" x="0" y="0" visible="pad" length="point" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="EC12E_SW" urn="urn:adsk.eagle:component:27084/2" prefix="SW" library_version="2">
<description>ALPS rotary Encoder EC12E series with switch</description>
<gates>
<gate name="G$1" symbol="ENCODER" x="-10.16" y="-2.54" addlevel="always"/>
<gate name="G$2" symbol="TASTER" x="10.16" y="5.08" addlevel="always"/>
<gate name="G$3" symbol="GEHAEUSEANSCHLUSS" x="10.16" y="-5.08" addlevel="request"/>
<gate name="G$4" symbol="GEHAEUSEANSCHLUSS" x="10.16" y="-7.62" addlevel="request"/>
</gates>
<devices>
<device name="" package="ALPS_EC12E_SW">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="B" pad="B"/>
<connect gate="G$1" pin="C" pad="C"/>
<connect gate="G$2" pin="1" pad="D"/>
<connect gate="G$2" pin="2" pad="E"/>
<connect gate="G$3" pin="G" pad="GND1"/>
<connect gate="G$4" pin="G" pad="GND2"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:27083/1"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="MPN" value="EC12E2424407" constant="no"/>
<attribute name="OC_FARNELL" value="1520813" constant="no"/>
<attribute name="OC_NEWARK" value="74M1068" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor-power" urn="urn:adsk.eagle:library:400">
<description>&lt;b&gt;Power Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO220BH" urn="urn:adsk.eagle:footprint:29377/1" library_version="4">
<description>&lt;b&gt;Molded Package&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="G" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="D" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="S" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="1.016" layer="21" ratio="10">A17,5mm</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<package name="TO220BV" urn="urn:adsk.eagle:footprint:29371/1" library_version="4">
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="G" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="D" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="S" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
<packages3d>
<package3d name="TO220BH" urn="urn:adsk.eagle:package:29490/1" type="box" library_version="4">
<description>Molded Package
<packageinstances>
<packageinstance name="TO220BH"/>
</packageinstances>
</package3d>
<package3d name="TO220BV" urn="urn:adsk.eagle:package:29484/3" type="model" library_version="4">
<packageinstances>
<packageinstance name="TO220BV"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="MFP" urn="urn:adsk.eagle:symbol:29395/1" library_version="4">
<wire x1="-1.016" y1="2.54" x2="-1.016" y2="-2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.905" x2="0.5334" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="2.54" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="2.2352" y1="0" x2="2.286" y2="0" width="0.1524" layer="94"/>
<wire x1="2.286" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="1.905" x2="0.508" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-1.016" y1="2.54" x2="-2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="2.286" y1="0" x2="1.016" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="1.016" y1="-0.508" x2="1.016" y2="0.508" width="0.1524" layer="94"/>
<wire x1="1.016" y1="0.508" x2="2.286" y2="0" width="0.1524" layer="94"/>
<wire x1="1.143" y1="0" x2="0.254" y2="0" width="0.1524" layer="94"/>
<wire x1="1.143" y1="0.254" x2="2.032" y2="0" width="0.3048" layer="94"/>
<wire x1="2.032" y1="0" x2="1.143" y2="-0.254" width="0.3048" layer="94"/>
<wire x1="1.143" y1="-0.254" x2="1.143" y2="0" width="0.3048" layer="94"/>
<wire x1="1.143" y1="0" x2="1.397" y2="0" width="0.3048" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="1.905" width="0.1524" layer="94"/>
<circle x="2.54" y="1.905" radius="0.127" width="0.4064" layer="94"/>
<text x="5.08" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<text x="5.08" y="0" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.397" y="-3.175" size="0.8128" layer="93">D</text>
<text x="1.397" y="2.413" size="0.8128" layer="93">S</text>
<text x="-2.54" y="1.397" size="0.8128" layer="93">G</text>
<rectangle x1="-0.254" y1="1.27" x2="0.508" y2="2.54" layer="94"/>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="-1.27" layer="94"/>
<rectangle x1="-0.254" y1="-0.889" x2="0.508" y2="0.889" layer="94"/>
<pin name="G" x="-5.08" y="2.54" visible="off" length="short" direction="pas"/>
<pin name="D" x="2.54" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="S" x="2.54" y="5.08" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="PMOSFET_P" urn="urn:adsk.eagle:component:29569/4" prefix="Q" uservalue="yes" library_version="4">
<description>&lt;b&gt;Power MOSFET P-Channel&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="MFP" x="0" y="0"/>
</gates>
<devices>
<device name="TO220BH" package="TO220BH">
<connects>
<connect gate="G$1" pin="D" pad="D"/>
<connect gate="G$1" pin="G" pad="G"/>
<connect gate="G$1" pin="S" pad="S"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29490/1"/>
<technologies>
<attribute name="POPULARITY" value="1" constant="no"/>
</technology>
</technologies>
</device>
<device name="TO220BV" package="TO220BV">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29484/3"/>
<technologies>
<attribute name="POPULARITY" value="2" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-ptr500" urn="urn:adsk.eagle:library:181">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/2" urn="urn:adsk.eagle:footprint:9854/1" library_version="2">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-5.08" y1="-3.556" x2="-5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.556" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.588" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="3.175" x2="-5.588" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="2.032" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="-5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.159" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="-1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="3.5306" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-1.4986" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.5306" y1="-1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.4986" y1="-1.016" x2="3.5306" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-3.5306" y1="-1.016" x2="-1.4986" y2="1.016" width="0.6096" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="1.4986" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.5306" y1="1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-3.5306" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-1.4986" y1="1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<circle x="2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="0.635" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<rectangle x1="-0.381" y1="-1.905" x2="0.381" y2="1.905" layer="21"/>
</package>
</packages>
<packages3d>
<package3d name="AK500/2" urn="urn:adsk.eagle:package:9880/1" type="box" library_version="2">
<description>CONNECTOR</description>
<packageinstances>
<packageinstance name="AK500/2"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="KL" urn="urn:adsk.eagle:symbol:9841/1" library_version="2">
<circle x="1.27" y="0" radius="1.27" width="0.254" layer="94"/>
<text x="-1.27" y="0.889" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<pin name="KL" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="KLV" urn="urn:adsk.eagle:symbol:9842/1" library_version="2">
<text x="-3.81" y="-3.683" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="AK500/2" urn="urn:adsk.eagle:component:9906/2" prefix="X" uservalue="yes" library_version="2">
<gates>
<gate name="-1" symbol="KL" x="0" y="5.08" addlevel="always"/>
<gate name="-2" symbol="KLV" x="0" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="AK500/2">
<connects>
<connect gate="-1" pin="KL" pad="1"/>
<connect gate="-2" pin="KL" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:9880/1"/>
<technologies>
<attribute name="POPULARITY" value="14" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor" urn="urn:adsk.eagle:library:402">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TO3" urn="urn:adsk.eagle:footprint:29823/1" library_version="6">
<description>&lt;b&gt;TO-3&lt;/b&gt;</description>
<wire x1="6.3754" y1="-10.9982" x2="17.3736" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="5.969" y1="11.2014" x2="17.3736" y2="4.5212" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="10.9982" x2="-17.272" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.9436" y1="-11.2268" x2="-17.2466" y2="-4.5974" width="0.1524" layer="21"/>
<wire x1="17.3366" y1="4.545" x2="19.812" y2="0" width="0.1524" layer="21" curve="-57.1487"/>
<wire x1="17.3366" y1="-4.545" x2="19.812" y2="0" width="0.1524" layer="21" curve="57.1487"/>
<wire x1="-19.812" y1="0" x2="-17.0927" y2="4.6935" width="0.1524" layer="21" curve="-60.1731"/>
<wire x1="-19.812" y1="0" x2="-17.1555" y2="-4.657" width="0.1524" layer="21" curve="59.4042"/>
<wire x1="0" y1="-12.7" x2="6.3718" y2="-10.9859" width="0.1524" layer="21" curve="30.1136"/>
<wire x1="-5.9765" y1="-11.2059" x2="0" y2="-12.7" width="0.1524" layer="21" curve="28.0726"/>
<wire x1="-6.3718" y1="10.9859" x2="0" y2="12.7" width="0.1524" layer="21" curve="-30.1136"/>
<wire x1="0" y1="12.7" x2="5.9765" y2="11.2059" width="0.1524" layer="21" curve="-28.0726"/>
<circle x="0" y="0" radius="9.3726" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="11.684" width="0.0508" layer="21"/>
<circle x="15.113" y="0" radius="2.159" width="0.1524" layer="51"/>
<circle x="-15.113" y="0" radius="2.159" width="0.1524" layer="51"/>
<pad name="E" x="-1.778" y="-5.461" drill="1.1938" diameter="3.1496" shape="long"/>
<pad name="B" x="-1.778" y="5.461" drill="1.1938" diameter="3.1496" shape="long"/>
<pad name="C" x="15.113" y="0" drill="4.1148" diameter="6.477"/>
<pad name="C/" x="-15.113" y="0" drill="4.1148" diameter="6.477"/>
<text x="-5.08" y="1.27" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="15.24" y="-4.953" size="1.27" layer="51" ratio="10" rot="R90">C</text>
<text x="-3.81" y="-6.223" size="1.27" layer="51" ratio="10" rot="R90">E</text>
<text x="-3.81" y="4.572" size="1.27" layer="51" ratio="10" rot="R90">B</text>
</package>
<package name="TO18" urn="urn:adsk.eagle:footprint:28463/1" library_version="6">
<description>&lt;b&gt;TO 18&lt;/b&gt;</description>
<wire x1="0.9289" y1="2.227" x2="2.227" y2="0.9289" width="0.0508" layer="51" curve="-44.7172"/>
<wire x1="0.9289" y1="-2.227" x2="2.227" y2="-0.9289" width="0.0508" layer="51" curve="44.7172"/>
<wire x1="-3.937" y1="-0.508" x2="-3.937" y2="0.508" width="0.127" layer="21"/>
<wire x1="-2.227" y1="-0.9289" x2="0.929" y2="2.2271" width="0.0508" layer="21" curve="-135.281"/>
<wire x1="-2.227" y1="-0.9289" x2="-0.9289" y2="-2.227" width="0.0508" layer="51" curve="44.7172"/>
<wire x1="-3.937" y1="-0.508" x2="-2.8765" y2="-0.508" width="0.127" layer="21"/>
<wire x1="-0.9289" y1="-2.227" x2="0.9289" y2="-2.227" width="0.0508" layer="21" curve="45.2828"/>
<wire x1="-3.937" y1="0.508" x2="-2.8765" y2="0.508" width="0.127" layer="21"/>
<wire x1="2.227" y1="-0.9289" x2="2.227" y2="0.9289" width="0.0508" layer="21" curve="45.2828"/>
<circle x="0" y="0" radius="2.921" width="0.127" layer="21"/>
<pad name="1" x="-1.27" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="1.27" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.905" y="-1.27" size="1.27" layer="51" ratio="10">1</text>
<text x="0.635" y="-1.27" size="1.27" layer="51" ratio="10">2</text>
<text x="0" y="0.635" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="TO18-" urn="urn:adsk.eagle:footprint:28930/1" library_version="6">
<description>&lt;b&gt;TO-18&lt;/b&gt;</description>
<wire x1="-2.2098" y1="-0.9692" x2="2.2098" y2="-0.9692" width="0.0508" layer="21" curve="132.636"/>
<wire x1="-0.9692" y1="2.2098" x2="0.9692" y2="2.2098" width="0.0508" layer="51" curve="-47.3637"/>
<wire x1="-2.2098" y1="0.9692" x2="-2.2098" y2="-0.9692" width="0.0508" layer="51" curve="47.3637"/>
<wire x1="-2.2098" y1="0.9692" x2="-0.9692" y2="2.2098" width="0.0508" layer="21" curve="-42.6363"/>
<wire x1="2.2098" y1="-0.9692" x2="2.2098" y2="0.9692" width="0.0508" layer="51" curve="47.3637"/>
<wire x1="1.649" y1="-2.411" x2="2.413" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="2.411" y1="-1.649" x2="3.175" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-3.175" x2="3.175" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="0.9692" y1="2.2098" x2="2.2098" y2="0.9692" width="0.0508" layer="21" curve="-42.6363"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<pad name="1" x="1.905" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.905" y="0" drill="0.8128" shape="octagon"/>
<text x="3.302" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.302" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="1.016" y="-1.143" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.508" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-1.905" y="-1.27" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="TO202" urn="urn:adsk.eagle:footprint:28460/1" library_version="6">
<description>&lt;b&gt;TO 202 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="7.3406" x2="-3.5052" y2="8.8138" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="8.8138" x2="-5.207" y2="8.8138" width="0.127" layer="21"/>
<wire x1="5.207" y1="8.8138" x2="3.5052" y2="8.8138" width="0.127" layer="21"/>
<wire x1="3.5052" y1="8.8138" x2="3.5052" y2="7.3406" width="0.127" layer="21"/>
<wire x1="5.2578" y1="-1.27" x2="5.2578" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-5.207" y1="7.3406" x2="-3.5052" y2="7.3406" width="0.127" layer="21"/>
<wire x1="3.8354" y1="-1.27" x2="3.8354" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="3.8354" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="21.717" x2="5.207" y2="8.8138" width="0.127" layer="21"/>
<wire x1="5.207" y1="21.717" x2="-5.207" y2="21.717" width="0.127" layer="21"/>
<wire x1="-5.207" y1="21.717" x2="-5.207" y2="8.8138" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="7.3406" x2="3.5052" y2="7.3406" width="0.127" layer="21"/>
<wire x1="3.8354" y1="-1.27" x2="5.2578" y2="-1.27" width="0.127" layer="21"/>
<wire x1="3.8354" y1="7.3406" x2="5.2578" y2="7.3406" width="0.127" layer="21"/>
<wire x1="3.5052" y1="7.3406" x2="3.8354" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-1.016" x2="4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="4.953" y1="7.112" x2="4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="4.953" y1="7.112" x2="-4.953" y2="7.112" width="0.0508" layer="21"/>
<wire x1="-4.953" y1="-1.016" x2="-4.953" y2="7.112" width="0.0508" layer="21"/>
<circle x="-3.7592" y="-0.2286" radius="0.4318" width="0" layer="21"/>
<circle x="0" y="17.78" radius="1.651" width="0.127" layer="21"/>
<circle x="0" y="17.78" radius="4.191" width="0" layer="42"/>
<circle x="0" y="17.78" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<text x="-2.54" y="4.318" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-0.635" size="1.27" layer="21" ratio="10">1</text>
<text x="-0.635" y="-0.635" size="1.27" layer="21" ratio="10">2</text>
<text x="1.905" y="-0.635" size="1.27" layer="21" ratio="10">3</text>
<rectangle x1="-0.635" y1="-2.54" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-2.54" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-3.175" y1="-2.54" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-3.429" x2="2.921" y2="-2.54" layer="21"/>
<rectangle x1="2.159" y1="-5.08" x2="2.921" y2="-3.429" layer="51"/>
<rectangle x1="-0.381" y1="-3.429" x2="0.381" y2="-2.54" layer="21"/>
<rectangle x1="-2.921" y1="-3.429" x2="-2.159" y2="-2.54" layer="21"/>
<rectangle x1="-0.381" y1="-5.08" x2="0.381" y2="-3.429" layer="51"/>
<rectangle x1="-2.921" y1="-5.08" x2="-2.159" y2="-3.429" layer="51"/>
<hole x="0" y="17.78" drill="3.302"/>
</package>
<package name="TO202V" urn="urn:adsk.eagle:footprint:28675/1" library_version="6">
<description>&lt;b&gt;TO 202 vertical&lt;/b&gt;</description>
<wire x1="-4.826" y1="-4.7498" x2="2.794" y2="-4.7498" width="0.127" layer="21"/>
<wire x1="-4.826" y1="-0.127" x2="4.8006" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.794" y1="-4.7498" x2="4.8006" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-4.826" y1="-4.7498" x2="-4.826" y2="-0.127" width="0.127" layer="21"/>
<wire x1="4.8006" y1="-0.127" x2="4.8006" y2="-2.794" width="0.127" layer="21"/>
<circle x="-4.064" y="-3.9878" radius="0.4318" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<text x="-4.445" y="-6.985" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-8.89" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-1.905" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-1.905" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-1.905" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="3.429" y1="-2.794" x2="4.826" y2="-2.286" layer="21"/>
<rectangle x1="0.889" y1="-2.794" x2="1.651" y2="-2.286" layer="21"/>
<rectangle x1="-1.651" y1="-2.794" x2="-0.889" y2="-2.286" layer="21"/>
<rectangle x1="-4.826" y1="-2.794" x2="-3.429" y2="-2.286" layer="21"/>
<rectangle x1="-3.429" y1="-2.794" x2="-1.651" y2="-2.286" layer="51"/>
<rectangle x1="-0.889" y1="-2.794" x2="0.889" y2="-2.286" layer="51"/>
<rectangle x1="1.651" y1="-2.794" x2="3.429" y2="-2.286" layer="51"/>
</package>
<package name="SOT93" urn="urn:adsk.eagle:footprint:29366/1" library_version="6">
<description>SOT-93&lt;p&gt;
grid 5.45 mm</description>
<wire x1="-7.62" y1="-6.35" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="6.985" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.223" x2="-6.985" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.223" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.985" x2="-7.62" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="6.985" x2="-7.62" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="9.525" x2="-3.1242" y2="13.3096" width="0.1524" layer="21"/>
<wire x1="6.985" y1="6.223" x2="6.985" y2="6.985" width="0.1524" layer="21"/>
<wire x1="6.985" y1="6.223" x2="-6.985" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.985" y1="6.985" x2="7.62" y2="6.985" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.985" x2="7.62" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-5.715" x2="6.985" y2="-5.715" width="0.0508" layer="21"/>
<wire x1="6.985" y1="5.715" x2="6.985" y2="-5.715" width="0.0508" layer="21"/>
<wire x1="6.985" y1="5.715" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-5.715" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="0" y1="14.605" x2="3.1431" y2="13.3031" width="0.1524" layer="21" curve="-45.0001"/>
<wire x1="-3.1431" y1="13.3031" x2="0" y2="14.605" width="0.1524" layer="21" curve="-45.0001"/>
<wire x1="7.62" y1="9.525" x2="3.1242" y2="13.335" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-5.715" x2="7.62" y2="-6.35" width="0.0508" layer="51"/>
<wire x1="6.985" y1="5.715" x2="7.62" y2="6.35" width="0.0508" layer="51"/>
<wire x1="-6.985" y1="5.715" x2="-7.62" y2="6.35" width="0.0508" layer="51"/>
<wire x1="-6.985" y1="-5.715" x2="-7.62" y2="-6.35" width="0.0508" layer="51"/>
<circle x="0" y="10.16" radius="2.159" width="0.1524" layer="21"/>
<circle x="0" y="10.16" radius="5.08" width="0" layer="42"/>
<circle x="0" y="10.16" radius="5.08" width="0" layer="43"/>
<pad name="B" x="-5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="2.54" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="0" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.477" y="6.604" size="1.016" layer="21" ratio="10">A20,3mm</text>
<rectangle x1="-6.096" y1="-7.366" x2="-4.318" y2="-6.35" layer="21"/>
<rectangle x1="4.318" y1="-7.366" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-1.143" y1="-7.366" x2="1.143" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-8.128" x2="-4.826" y2="-6.35" layer="21"/>
<rectangle x1="-0.635" y1="-8.128" x2="0.635" y2="-6.35" layer="21"/>
<rectangle x1="4.826" y1="-8.128" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-10.287" x2="-4.826" y2="-8.128" layer="51"/>
<rectangle x1="-0.635" y1="-10.287" x2="0.635" y2="-8.128" layer="51"/>
<rectangle x1="4.826" y1="-10.287" x2="6.096" y2="-8.128" layer="51"/>
<hole x="0" y="10.16" drill="4.1148"/>
</package>
<package name="SOT93V" urn="urn:adsk.eagle:footprint:28676/1" library_version="6">
<wire x1="7.62" y1="-2.032" x2="3.429" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-2.032" x2="2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.032" x2="-2.032" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="-2.032" x2="-3.429" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.032" x2="-7.62" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-7.62" y1="0" x2="7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-5.08" x2="7.239" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.032" x2="-7.239" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-2.032" x2="7.239" y2="-5.08" width="0.1524" layer="21"/>
<pad name="B" x="-5.461" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<text x="-1.397" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.62" y="-6.858" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-7.62" y1="-2.032" x2="7.62" y2="0" layer="51"/>
</package>
<package name="TO126" urn="urn:adsk.eagle:footprint:29831/1" library_version="6">
<description>&lt;b&gt;TO 126 horizontal&lt;/b&gt;</description>
<wire x1="-3.937" y1="-1.27" x2="-3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="-3.937" y1="9.144" x2="3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="3.937" y1="9.144" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="1.2393" y1="3.1591" x2="1.9493" y2="3.8858" width="0.127" layer="21" curve="25.6775"/>
<wire x1="0.7687" y1="3.6188" x2="1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-0.7687" y1="3.6188" x2="-1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-1.4787" y1="4.3456" x2="-1.9493" y2="3.8858" width="0.127" layer="21"/>
<wire x1="-1.9493" y1="3.8858" x2="-1.2393" y2="3.1591" width="0.127" layer="21" curve="25.6775"/>
<wire x1="0.508" y1="6.6509" x2="0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="6.6509" x2="-0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="7.3088" x2="0.508" y2="7.3088" width="0.127" layer="21" curve="-25.6796"/>
<wire x1="1.4787" y1="4.3456" x2="1.9493" y2="3.8858" width="0.127" layer="21"/>
<circle x="-3.1242" y="-0.4826" radius="0.4318" width="0" layer="21"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="42"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="43"/>
<circle x="0" y="5.08" radius="1.651" width="0.127" layer="21"/>
<pad name="1" x="-2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<text x="-2.54" y="7.62" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-0.889" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.508" y="-0.889" size="1.27" layer="51" ratio="10">2</text>
<text x="1.778" y="-0.889" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-0.635" y1="-3.048" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-3.429" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-5.207" x2="-1.905" y2="-3.429" layer="51"/>
<rectangle x1="-0.381" y1="-3.429" x2="0.381" y2="-1.27" layer="21"/>
<rectangle x1="-0.381" y1="-5.207" x2="0.381" y2="-3.429" layer="51"/>
<rectangle x1="1.905" y1="-3.429" x2="2.667" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-5.207" x2="2.667" y2="-3.429" layer="51"/>
<hole x="0" y="5.08" drill="3.302"/>
</package>
<package name="TO126V" urn="urn:adsk.eagle:footprint:28677/1" library_version="6">
<description>&lt;b&gt;TO 126 vertical&lt;/b&gt;</description>
<wire x1="-3.937" y1="-0.127" x2="-3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="-3.683" y2="-2.794" width="0.127" layer="21"/>
<wire x1="3.683" y1="-2.794" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="3.937" y1="-1.27" x2="3.937" y2="-0.127" width="0.127" layer="21"/>
<wire x1="-3.683" y1="-2.794" x2="-2.794" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-2.794" y1="-2.794" x2="-1.778" y2="-2.794" width="0.127" layer="51"/>
<wire x1="-1.778" y1="-2.794" x2="-0.508" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-0.508" y1="-2.794" x2="0.508" y2="-2.794" width="0.127" layer="51"/>
<wire x1="0.508" y1="-2.794" x2="1.778" y2="-2.794" width="0.127" layer="21"/>
<wire x1="1.778" y1="-2.794" x2="2.794" y2="-2.794" width="0.127" layer="51"/>
<wire x1="2.794" y1="-2.794" x2="3.683" y2="-2.794" width="0.127" layer="21"/>
<circle x="-3.175" y="-2.159" radius="0.4064" width="0.127" layer="51"/>
<pad name="1" x="-2.286" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.286" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<text x="-3.9624" y="-4.5466" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.9878" y="-6.3246" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-1.905" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.381" y="-1.905" size="1.27" layer="51" ratio="10">2</text>
<text x="2.032" y="-1.905" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-3.937" y1="-0.381" x2="-3.175" y2="0" layer="21"/>
<rectangle x1="-1.397" y1="-0.381" x2="-0.889" y2="0" layer="21"/>
<rectangle x1="0.889" y1="-0.381" x2="1.397" y2="0" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="3.937" y2="0" layer="21"/>
<rectangle x1="-3.175" y1="-0.381" x2="-1.397" y2="0" layer="51"/>
<rectangle x1="-0.889" y1="-0.381" x2="0.889" y2="0" layer="51"/>
<rectangle x1="1.397" y1="-0.381" x2="3.175" y2="0" layer="51"/>
</package>
<package name="TO218" urn="urn:adsk.eagle:footprint:28455/1" library_version="6">
<description>&lt;b&gt;TO 218 horizontal&lt;/b&gt;</description>
<wire x1="-7.62" y1="-6.35" x2="7.62" y2="-6.35" width="0.127" layer="21"/>
<wire x1="7.62" y1="6.223" x2="7.62" y2="0" width="0.127" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.127" layer="21"/>
<wire x1="7.62" y1="-3.81" x2="7.62" y2="-6.35" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-7.62" y2="-3.81" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="0" width="0.127" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="7.62" y1="6.223" x2="-7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="6.985" y1="0.508" x2="6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="7.62" y1="12.065" x2="5.08" y2="14.605" width="0.127" layer="21"/>
<wire x1="7.62" y1="12.065" x2="7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="5.08" y1="14.605" x2="-5.08" y2="14.605" width="0.127" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-5.08" y2="14.605" width="0.127" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.127" layer="21" curve="180"/>
<wire x1="6.985" y1="-5.715" x2="6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="6.9522" y1="0.4991" x2="6.9851" y2="-4.3178" width="0.0508" layer="21" curve="149.733"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-3.81" width="0.127" layer="21" curve="-180"/>
<wire x1="-6.985" y1="-5.715" x2="-6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="0.508" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-4.318" x2="-6.985" y2="0.508" width="0.0508" layer="21" curve="150.513"/>
<circle x="0" y="10.16" radius="2.159" width="0.127" layer="21"/>
<pad name="1" x="-5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="-5.08" size="1.27" layer="21" ratio="10">1</text>
<text x="-0.635" y="-5.08" size="1.27" layer="21" ratio="10">2</text>
<text x="4.445" y="-5.08" size="1.27" layer="21" ratio="10">3</text>
</package>
<package name="TO218V" urn="urn:adsk.eagle:footprint:28456/1" library_version="6">
<description>&lt;b&gt;TO 218 vertical&lt;/b&gt;</description>
<wire x1="-6.985" y1="-5.08" x2="6.985" y2="-5.08" width="0.127" layer="21"/>
<wire x1="6.985" y1="-5.08" x2="7.366" y2="-4.699" width="0.127" layer="21"/>
<wire x1="7.366" y1="-4.699" x2="7.62" y2="-1.524" width="0.127" layer="21"/>
<wire x1="-6.985" y1="-5.08" x2="-7.366" y2="-4.699" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-4.699" x2="-7.62" y2="-1.524" width="0.127" layer="21"/>
<pad name="1" x="-5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<text x="-1.016" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.096" y="-4.445" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-4.445" size="1.27" layer="51" ratio="10">2</text>
<text x="4.826" y="-4.445" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-7.874" y1="-1.143" x2="7.874" y2="0" layer="21"/>
<rectangle x1="-3.556" y1="-2.032" x2="-1.905" y2="-1.143" layer="21"/>
<rectangle x1="1.905" y1="-2.032" x2="3.556" y2="-1.143" layer="21"/>
<rectangle x1="-7.874" y1="-2.032" x2="-7.239" y2="-1.143" layer="21"/>
<rectangle x1="7.239" y1="-2.032" x2="7.874" y2="-1.143" layer="21"/>
<rectangle x1="3.556" y1="-2.032" x2="7.239" y2="-1.143" layer="51"/>
<rectangle x1="-7.239" y1="-2.032" x2="-3.556" y2="-1.143" layer="51"/>
<rectangle x1="-1.905" y1="-2.032" x2="1.905" y2="-1.143" layer="51"/>
</package>
<package name="TO220" urn="urn:adsk.eagle:footprint:28453/1" library_version="6">
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="TO220V" urn="urn:adsk.eagle:footprint:28680/1" library_version="6">
<description>&lt;b&gt;TO 220 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
</package>
<package name="TO225AA" urn="urn:adsk.eagle:footprint:29839/1" library_version="6">
<description>&lt;b&gt;TO-225&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, vertical</description>
<wire x1="-3.4925" y1="-6.985" x2="-3.4925" y2="3.81" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="3.81" x2="3.4925" y2="3.81" width="0.127" layer="21"/>
<wire x1="3.4925" y1="3.81" x2="3.4925" y2="-6.985" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="-6.985" x2="3.4925" y2="-6.985" width="0.127" layer="21"/>
<wire x1="-2.381" y1="-8.096" x2="-2.381" y2="-9.525" width="0.4064" layer="21"/>
<wire x1="0" y1="-7.779" x2="0" y2="-9.525" width="0.4064" layer="21"/>
<wire x1="2.3813" y1="-8.0963" x2="2.381" y2="-9.525" width="0.4064" layer="21"/>
<wire x1="-2.54" y1="3.175" x2="-2.54" y2="-3.334" width="0.127" layer="51"/>
<wire x1="-2.54" y1="-3.334" x2="2.54" y2="-3.334" width="0.127" layer="51"/>
<wire x1="2.54" y1="-3.334" x2="2.54" y2="3.175" width="0.127" layer="51"/>
<wire x1="2.54" y1="3.175" x2="-2.54" y2="3.175" width="0.127" layer="51"/>
<wire x1="-1.949" y1="1.194" x2="-1.2391" y2="1.9206" width="0.127" layer="21" curve="-25.6749"/>
<wire x1="-0.769" y1="1.461" x2="-1.239" y2="1.921" width="0.127" layer="21"/>
<wire x1="0.769" y1="1.461" x2="1.239" y2="1.921" width="0.127" layer="21"/>
<wire x1="1.479" y1="0.734" x2="1.949" y2="1.194" width="0.127" layer="21"/>
<wire x1="1.239" y1="1.921" x2="1.949" y2="1.1944" width="0.127" layer="21" curve="-25.6741"/>
<wire x1="-0.508" y1="-1.571" x2="-0.508" y2="-2.229" width="0.127" layer="21"/>
<wire x1="0.508" y1="-1.571" x2="0.508" y2="-2.229" width="0.127" layer="21"/>
<wire x1="-0.508" y1="-2.229" x2="0.508" y2="-2.229" width="0.127" layer="21" curve="25.6785"/>
<wire x1="-1.479" y1="0.734" x2="-1.949" y2="1.194" width="0.127" layer="21"/>
<circle x="0" y="0" radius="3.81" width="0" layer="42"/>
<circle x="0" y="0" radius="3.81" width="0" layer="43"/>
<circle x="0" y="0" radius="1.651" width="0.127" layer="21"/>
<pad name="1" x="-2.3813" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="2.3813" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.6988" y="-6.6675" size="1.27" layer="51">1</text>
<text x="-0.4763" y="-6.6675" size="1.27" layer="51">2</text>
<text x="1.905" y="-6.6675" size="1.27" layer="51">3</text>
<text x="3.0163" y="5.3975" size="1.27" layer="25" ratio="10" rot="R180">&gt;NAME</text>
<text x="3.4925" y="-3.7783" size="1.27" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="-2.6988" y1="-8.255" x2="-2.0638" y2="-6.985" layer="21"/>
<rectangle x1="2.0638" y1="-8.255" x2="2.6988" y2="-6.985" layer="21"/>
<rectangle x1="-0.3175" y1="-7.9375" x2="0.3175" y2="-6.985" layer="21"/>
<hole x="0" y="0" drill="3.302"/>
</package>
<package name="TO39" urn="urn:adsk.eagle:footprint:28658/1" library_version="6">
<description>&lt;b&gt;TO-39&lt;/b&gt;</description>
<wire x1="-4.0386" y1="-3.5306" x2="-3.5052" y2="-2.9972" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-3.5306" x2="-3.5052" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-4.064" x2="-4.0386" y2="-3.5306" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO5" urn="urn:adsk.eagle:footprint:28657/1" library_version="6">
<description>&lt;b&gt;TO 5&lt;/b&gt;</description>
<wire x1="-4.0386" y1="-3.5306" x2="-3.5052" y2="-2.9972" width="0.127" layer="21"/>
<wire x1="-2.9718" y1="-3.5306" x2="-3.5052" y2="-4.064" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="-4.064" x2="-4.0386" y2="-3.5306" width="0.127" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.127" layer="21"/>
</package>
<package name="TO66" urn="urn:adsk.eagle:footprint:29176/1" library_version="6">
<description>&lt;b&gt;TO-66&lt;/b&gt;</description>
<wire x1="-3.501" y1="-7.895" x2="3.5012" y2="-7.895" width="0.1524" layer="21" curve="47.8332"/>
<wire x1="-3.501" y1="7.895" x2="3.5012" y2="7.895" width="0.1524" layer="21" curve="-47.8332"/>
<wire x1="-13.711" y1="3.3666" x2="-13.711" y2="-3.367" width="0.1524" layer="21" curve="132.168"/>
<wire x1="-3.501" y1="-7.895" x2="-13.711" y2="-3.367" width="0.1524" layer="21"/>
<wire x1="-3.501" y1="7.895" x2="-13.711" y2="3.367" width="0.1524" layer="21"/>
<wire x1="13.711" y1="-3.367" x2="13.711" y2="3.3666" width="0.1524" layer="21" curve="132.168"/>
<wire x1="3.501" y1="-7.895" x2="13.711" y2="-3.367" width="0.1524" layer="21"/>
<wire x1="3.501" y1="7.895" x2="13.711" y2="3.367" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="7.874" width="0.0508" layer="21"/>
<circle x="0" y="0" radius="6.35" width="0.1524" layer="21"/>
<circle x="-12.192" y="0" radius="1.905" width="0.1524" layer="51"/>
<circle x="12.192" y="0" radius="1.905" width="0.1524" layer="51"/>
<pad name="TO66" x="-12.192" y="0" drill="3.302" diameter="6.35"/>
<pad name="3" x="12.192" y="0" drill="3.302" diameter="6.35"/>
<pad name="2" x="-2.54" y="2.54" drill="1.1176" diameter="2.54" shape="long"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.1176" diameter="2.54" shape="long"/>
<text x="8.89" y="-4.445" size="1.27" layer="21" ratio="10">3</text>
<text x="1.27" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.175" y="-3.175" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-5.08" y="1.905" size="1.27" layer="21" ratio="10">2</text>
<text x="-5.08" y="-3.175" size="1.27" layer="21" ratio="10">1</text>
</package>
<package name="TO92" urn="urn:adsk.eagle:footprint:28459/1" library_version="6">
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-2.6549" y2="-0.254" width="0.127" layer="21" curve="-32.781"/>
<wire x1="-2.6549" y1="-0.254" x2="-0.7863" y2="2.5485" width="0.127" layer="21" curve="-78.3185"/>
<wire x1="0.7863" y1="2.5484" x2="2.0945" y2="-1.651" width="0.127" layer="21" curve="-111.1"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.2537" y1="-0.254" x2="-0.2863" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.2863" y1="-0.254" x2="2.2537" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.127" layer="51" curve="-34.2936"/>
<pad name="1" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.635" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-2.159" y="0" size="1.27" layer="51" ratio="10">3</text>
<text x="1.143" y="0" size="1.27" layer="51" ratio="10">1</text>
</package>
<package name="TO92-EBC" urn="urn:adsk.eagle:footprint:29852/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line E B C from top&lt;p&gt;</description>
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO92-E1" urn="urn:adsk.eagle:footprint:29853/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads Triangle Reverse</description>
<wire x1="-2.095" y1="-1.651" x2="-0.7869" y2="2.5484" width="0.127" layer="21" curve="-111.098"/>
<wire x1="0.7869" y1="2.5484" x2="2.095" y2="-1.651" width="0.127" layer="21" curve="-111.098"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.254" y1="-0.254" x2="-0.286" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.286" y1="-0.254" x2="0.286" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.286" y1="-0.254" x2="2.254" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7864" y1="2.5484" x2="0.7864" y2="2.5484" width="0.127" layer="51" curve="-34.299"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
</package>
<package name="TO92L" urn="urn:adsk.eagle:footprint:29854/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
grid 5.08 mm</description>
<wire x1="-1.1359" y1="2.413" x2="-0.127" y2="2.664" width="0.1524" layer="51" curve="-22.4788"/>
<wire x1="-0.127" y1="2.664" x2="1.1359" y2="2.413" width="0.1524" layer="51" curve="-27.9376"/>
<wire x1="-1.1359" y1="-2.413" x2="-0.127" y2="-2.664" width="0.1524" layer="51" curve="22.4788"/>
<wire x1="-0.127" y1="-2.664" x2="1.1359" y2="-2.413" width="0.1524" layer="51" curve="27.9376"/>
<wire x1="-1.651" y1="2.095" x2="-1.651" y2="-2.095" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.404" x2="-0.127" y2="1.404" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-2.664" x2="-0.127" y2="-1.404" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.095" x2="-1.1118" y2="-2.4247" width="0.1524" layer="21" curve="13.6094"/>
<wire x1="-0.127" y1="1.404" x2="-0.127" y2="2.664" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="2.095" x2="-1.1359" y2="2.4135" width="0.1524" layer="21" curve="-13.0385"/>
<wire x1="2.413" y1="-1.1359" x2="2.413" y2="1.1359" width="0.1524" layer="51" curve="50.4167"/>
<wire x1="1.1359" y1="-2.413" x2="2.413" y2="-1.1359" width="0.1524" layer="21" curve="39.5833"/>
<wire x1="1.1359" y1="2.413" x2="2.413" y2="1.1359" width="0.1524" layer="21" curve="-39.5833"/>
<pad name="1" x="0" y="-2.54" drill="0.8128" shape="long"/>
<pad name="3" x="0" y="2.54" drill="0.8128" shape="long"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="3.556" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-4.953" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TOP3" urn="urn:adsk.eagle:footprint:28457/1" library_version="6">
<description>&lt;b&gt;TOP 3 horizontal&lt;/b&gt;</description>
<wire x1="-7.874" y1="-1.778" x2="7.874" y2="-1.778" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="-1.778" width="0.127" layer="21"/>
<wire x1="-7.874" y1="-1.778" x2="-7.874" y2="8.763" width="0.127" layer="21"/>
<wire x1="-7.874" y1="8.763" x2="-7.874" y2="11.811" width="0.127" layer="21"/>
<wire x1="-7.874" y1="11.811" x2="-3.1242" y2="15.8496" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="-7.874" y2="8.763" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="11.811" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="0" y1="17.145" x2="3.1431" y2="15.8431" width="0.127" layer="21" curve="-45.0001"/>
<wire x1="-3.1431" y1="15.8431" x2="0" y2="17.145" width="0.127" layer="21" curve="-45.0001"/>
<wire x1="7.874" y1="11.811" x2="3.1242" y2="15.875" width="0.127" layer="21"/>
<circle x="0" y="12.7" radius="2.159" width="0.127" layer="21"/>
<circle x="0" y="12.7" radius="5.08" width="0" layer="42"/>
<circle x="0" y="12.7" radius="5.08" width="0" layer="43"/>
<pad name="1" x="-5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.366" y="9.144" size="0.9906" layer="21" ratio="12">A20,3mm</text>
<text x="-5.715" y="-0.635" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="4.445" y="-0.635" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-6.223" y1="-3.81" x2="-3.81" y2="-1.778" layer="21"/>
<rectangle x1="-1.397" y1="-3.81" x2="1.397" y2="-1.778" layer="21"/>
<rectangle x1="3.81" y1="-3.81" x2="6.223" y2="-1.778" layer="21"/>
<rectangle x1="-6.223" y1="-5.715" x2="-4.953" y2="-3.81" layer="21"/>
<rectangle x1="-6.223" y1="-7.62" x2="-4.953" y2="-5.715" layer="51"/>
<rectangle x1="-0.635" y1="-5.715" x2="0.635" y2="-3.81" layer="21"/>
<rectangle x1="-0.635" y1="-7.62" x2="0.635" y2="-5.715" layer="51"/>
<rectangle x1="4.953" y1="-5.715" x2="6.223" y2="-3.81" layer="21"/>
<rectangle x1="4.953" y1="-7.62" x2="6.223" y2="-5.715" layer="51"/>
<hole x="0" y="12.7" drill="4.1148"/>
</package>
<package name="TOP3V" urn="urn:adsk.eagle:footprint:28684/1" library_version="6">
<description>&lt;b&gt;TOP 3 vertical&lt;/b&gt;</description>
<wire x1="7.366" y1="-4.699" x2="7.493" y2="-1.524" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-4.699" x2="-7.493" y2="-1.524" width="0.127" layer="21"/>
<wire x1="6.985" y1="-5.08" x2="6.35" y2="-5.08" width="0.127" layer="21"/>
<wire x1="6.35" y1="-5.08" x2="4.572" y2="-5.08" width="0.127" layer="51"/>
<wire x1="4.572" y1="-5.08" x2="0.889" y2="-5.08" width="0.127" layer="21"/>
<wire x1="0.889" y1="-5.08" x2="-0.889" y2="-5.08" width="0.127" layer="51"/>
<wire x1="-0.889" y1="-5.08" x2="-4.572" y2="-5.08" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-5.08" x2="-6.35" y2="-5.08" width="0.127" layer="51"/>
<wire x1="-6.35" y1="-5.08" x2="-6.985" y2="-5.08" width="0.127" layer="21"/>
<pad name="B" x="-5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<text x="-1.524" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.096" y="-4.445" size="1.27" layer="51" ratio="10">B</text>
<text x="-0.635" y="-4.445" size="1.27" layer="51" ratio="10">C</text>
<text x="4.826" y="-4.445" size="1.27" layer="51" ratio="10">E</text>
<rectangle x1="-7.874" y1="-1.524" x2="-6.858" y2="-1.143" layer="21"/>
<rectangle x1="-4.064" y1="-1.524" x2="-1.397" y2="-1.143" layer="21"/>
<rectangle x1="1.397" y1="-1.524" x2="4.064" y2="-1.143" layer="21"/>
<rectangle x1="6.858" y1="-1.524" x2="7.874" y2="-1.143" layer="21"/>
<rectangle x1="-6.858" y1="-1.524" x2="-4.064" y2="-1.143" layer="51"/>
<rectangle x1="-1.397" y1="-1.524" x2="1.397" y2="-1.143" layer="51"/>
<rectangle x1="4.064" y1="-1.524" x2="6.858" y2="-1.143" layer="51"/>
</package>
<package name="SOT23-BEC" urn="urn:adsk.eagle:footprint:28685/1" library_version="6">
<description>TO-236 ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
<package name="SOT23-EBC" urn="urn:adsk.eagle:footprint:28686/1" library_version="6">
<description>&lt;b&gt;SOT-23 (EBC)&lt;/b&gt;</description>
<smd name="B" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
</package>
<package name="TO92-BCE" urn="urn:adsk.eagle:footprint:29858/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line B C E from top&lt;p&gt;</description>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-0.127" x2="-1.136" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-0.127" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-1.1359" x2="-2.095" y2="-1.651" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-0.127" x2="-1.404" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.664" y2="-0.127" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-0.127" x2="1.404" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.404" y1="-0.127" x2="1.136" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.095" y1="-1.651" x2="2.4247" y2="-1.1118" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO92-CBE" urn="urn:adsk.eagle:footprint:29859/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line  C B E from top&lt;p&gt;</description>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="TO92-BEC" urn="urn:adsk.eagle:footprint:29860/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line  B E C from top&lt;p&gt;</description>
<pad name="C" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="TO92-CEB" urn="urn:adsk.eagle:footprint:29861/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line C E B from top&lt;p&gt;</description>
<pad name="B" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="SC59-BEC" urn="urn:adsk.eagle:footprint:28691/1" library_version="6">
<description>SC59 (SOT23) Motorola</description>
<wire x1="1.4224" y1="0.8604" x2="1.4224" y2="-0.8604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.8604" x2="-1.4224" y2="-0.8604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.8604" x2="-1.4224" y2="0.8604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.8604" x2="1.4224" y2="0.8604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.2" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.2" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.2" dx="1" dy="1.4" layer="1"/>
<rectangle x1="-0.2286" y1="0.9112" x2="0.2286" y2="1.4954" layer="51"/>
<rectangle x1="0.7112" y1="-1.4954" x2="1.1684" y2="-0.9112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.4954" x2="-0.7112" y2="-0.9112" layer="51"/>
</package>
<package name="SOT89-BCE" urn="urn:adsk.eagle:footprint:29863/1" library_version="6">
<description>SOT89 Basis Collector Emitter</description>
<wire x1="2.235" y1="-1.245" x2="-2.235" y2="-1.245" width="0.127" layer="51"/>
<wire x1="2.235" y1="1.219" x2="2.235" y2="-1.245" width="0.127" layer="51"/>
<wire x1="-2.235" y1="-1.245" x2="-2.235" y2="1.219" width="0.127" layer="51"/>
<wire x1="-2.235" y1="1.219" x2="2.235" y2="1.219" width="0.127" layer="51"/>
<wire x1="-0.7874" y1="1.5748" x2="-0.3556" y2="2.0066" width="0.1998" layer="51"/>
<wire x1="-0.3556" y1="2.0066" x2="0.3556" y2="2.0066" width="0.1998" layer="51"/>
<wire x1="0.3556" y1="2.0066" x2="0.7874" y2="1.5748" width="0.1998" layer="51"/>
<wire x1="0.7874" y1="1.5748" x2="0.7874" y2="1.2954" width="0.1998" layer="51"/>
<wire x1="0.7874" y1="1.2954" x2="-0.7874" y2="1.2954" width="0.1998" layer="51"/>
<wire x1="-0.7874" y1="1.2954" x2="-0.7874" y2="1.5748" width="0.1998" layer="51"/>
<smd name="B" x="-1.499" y="-1.981" dx="0.8" dy="1.4" layer="1"/>
<smd name="E" x="1.499" y="-1.981" dx="0.8" dy="1.4" layer="1"/>
<smd name="C" x="0" y="-1.727" dx="0.8" dy="1.9" layer="1" stop="no" cream="no"/>
<text x="-2.54" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.4051" y="-4.3449" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7272" y1="-2.1082" x2="-1.27" y2="-1.27" layer="51"/>
<rectangle x1="1.27" y1="-2.1082" x2="1.7272" y2="-1.27" layer="51"/>
<rectangle x1="-0.2794" y1="-2.1082" x2="0.2794" y2="-1.27" layer="51"/>
<rectangle x1="-0.4" y1="-2.68" x2="0.4" y2="-1.28" layer="31"/>
<rectangle x1="-0.5" y1="-2.78" x2="0.5" y2="-1.18" layer="29"/>
<polygon width="0.1998" layer="51">
<vertex x="-0.7874" y="1.3208"/>
<vertex x="-0.7874" y="1.5748"/>
<vertex x="-0.3556" y="2.0066"/>
<vertex x="0.3048" y="2.0066"/>
<vertex x="0.3556" y="2.0066"/>
<vertex x="0.7874" y="1.5748"/>
<vertex x="0.7874" y="1.2954"/>
<vertex x="-0.7874" y="1.2954"/>
</polygon>
<polygon width="1.7" layer="29">
<vertex x="-0.275" y="2.025"/>
<vertex x="-0.275" y="-0.15"/>
<vertex x="0.25" y="-0.15"/>
<vertex x="0.25" y="2.025"/>
</polygon>
<polygon width="1.3" layer="31">
<vertex x="-0.25" y="2.05"/>
<vertex x="0.275" y="2.05"/>
<vertex x="0.275" y="-0.125"/>
<vertex x="-0.25" y="-0.125"/>
</polygon>
<polygon width="0.3" layer="1">
<vertex x="0.25" y="-2.05"/>
<vertex x="-0.25" y="-2.05"/>
<vertex x="-0.25" y="-0.75" curve="-90"/>
<vertex x="-0.875" y="-0.125"/>
<vertex x="-0.875" y="2.05" curve="-90"/>
<vertex x="-0.225" y="2.625"/>
<vertex x="0.25" y="2.625" curve="-90"/>
<vertex x="0.875" y="2.025"/>
<vertex x="0.875" y="-0.125" curve="-90"/>
<vertex x="0.25" y="-0.75"/>
</polygon>
</package>
<package name="SOT37" urn="urn:adsk.eagle:footprint:28693/1" library_version="6">
<description>&lt;b&gt;SOT-37&lt;/b&gt;&lt;p&gt;
Motorola CASE 317A-01 ISSUE B&lt;br&gt;
http://www.ee.siue.edu/~alozows/library/datasheets/BFR96.pdf</description>
<wire x1="5.3086" y1="0.508" x2="5.3086" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-5.3086" x2="0.508" y2="-5.3086" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="6.5024" x2="0.508" y2="6.5024" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-2.2352" x2="0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.794" x2="0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.048" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-3.429" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-3.429" x2="0.508" y2="-5.3086" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-2.2352" x2="-0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.794" x2="-0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.048" x2="-0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-3.429" x2="-0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-3.429" x2="-0.508" y2="-5.3086" width="0.1524" layer="51"/>
<wire x1="2.2352" y1="-0.508" x2="2.794" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-0.635" x2="2.794" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.635" x2="3.429" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.508" x2="3.429" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.508" x2="5.3086" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.2098" y1="0.508" x2="2.794" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0.635" x2="2.794" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.635" x2="3.429" y2="0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0.508" x2="3.429" y2="0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0.508" x2="5.3086" y2="0.508" width="0.1524" layer="51"/>
<wire x1="0.508" y1="2.2352" x2="0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="3.048" x2="0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="3.429" x2="0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="3.429" x2="0.508" y2="6.5024" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="2.2352" x2="-0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.794" x2="-0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.048" x2="-0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="3.429" x2="-0.508" y2="6.5024" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-2.794" x2="-0.635" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.794" x2="0.635" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.635" x2="2.794" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.635" x2="2.794" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="0.635" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.794" x2="-0.635" y2="3.048" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.286" width="0.1524" layer="21"/>
<circle x="0" y="1.524" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.175" width="0" layer="41"/>
<circle x="0" y="0" radius="3.175" width="0" layer="42"/>
<smd name="3" x="0" y="-5.08" dx="1.9304" dy="3.81" layer="1"/>
<smd name="2" x="5.08" y="0" dx="3.81" dy="1.9304" layer="1"/>
<smd name="1" x="0" y="5.08" dx="1.9304" dy="3.81" layer="1"/>
<text x="4.445" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.35" y="1.27" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.175" y="-2.286" size="1.016" layer="21" ratio="10">E</text>
<text x="1.27" y="-4.191" size="1.016" layer="21" ratio="10">B</text>
<text x="1.27" y="3.175" size="1.016" layer="21" ratio="10">C</text>
<text x="-1.524" y="-4.318" size="1.27" layer="47">5,1</text>
<rectangle x1="-0.508" y1="-2.794" x2="0.508" y2="-2.413" layer="21"/>
<rectangle x1="-0.635" y1="-3.048" x2="0.635" y2="-2.794" layer="21"/>
<rectangle x1="-0.635" y1="-3.429" x2="0.635" y2="-3.048" layer="51"/>
<rectangle x1="-0.508" y1="-5.334" x2="0.508" y2="-3.429" layer="51"/>
<rectangle x1="2.413" y1="-0.508" x2="2.794" y2="0.508" layer="21"/>
<rectangle x1="2.794" y1="-0.635" x2="3.048" y2="0.635" layer="21"/>
<rectangle x1="3.048" y1="-0.635" x2="3.429" y2="0.635" layer="51"/>
<rectangle x1="3.429" y1="-0.508" x2="5.334" y2="0.508" layer="51"/>
<rectangle x1="-0.508" y1="3.429" x2="0.508" y2="6.477" layer="51"/>
<rectangle x1="-0.635" y1="3.048" x2="0.635" y2="3.429" layer="51"/>
<rectangle x1="-0.635" y1="2.794" x2="0.635" y2="3.048" layer="21"/>
<rectangle x1="-0.508" y1="2.413" x2="0.508" y2="2.794" layer="21"/>
<hole x="0" y="0" drill="5.08"/>
</package>
<package name="TO92-ECB" urn="urn:adsk.eagle:footprint:29865/1" library_version="6">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line E C B from top&lt;p&gt;</description>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9407"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9333"/>
<pad name="E" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
</packages>
<packages3d>
<package3d name="TO3" urn="urn:adsk.eagle:package:29899/2" type="model" library_version="6">
<description>TO-3</description>
<packageinstances>
<packageinstance name="TO3"/>
</packageinstances>
</package3d>
<package3d name="TO18" urn="urn:adsk.eagle:package:28526/2" type="model" library_version="6">
<description>TO 18</description>
<packageinstances>
<packageinstance name="TO18"/>
</packageinstances>
</package3d>
<package3d name="TO18-" urn="urn:adsk.eagle:package:28983/2" type="model" library_version="6">
<description>TO-18</description>
<packageinstances>
<packageinstance name="TO18-"/>
</packageinstances>
</package3d>
<package3d name="TO202" urn="urn:adsk.eagle:package:28525/1" type="box" library_version="6">
<description>TO 202 horizontal</description>
<packageinstances>
<packageinstance name="TO202"/>
</packageinstances>
</package3d>
<package3d name="TO202V" urn="urn:adsk.eagle:package:28741/1" type="box" library_version="6">
<description>TO 202 vertical</description>
<packageinstances>
<packageinstance name="TO202V"/>
</packageinstances>
</package3d>
<package3d name="SOT93" urn="urn:adsk.eagle:package:29486/1" type="box" library_version="6">
<description>SOT-93
<packageinstances>
<packageinstance name="SOT93"/>
</packageinstances>
</package3d>
<package3d name="SOT93V" urn="urn:adsk.eagle:package:28764/1" type="box" library_version="6">
<description>SOT-93
<packageinstances>
<packageinstance name="SOT93V"/>
</packageinstances>
</package3d>
<package3d name="TO126" urn="urn:adsk.eagle:package:29898/1" type="box" library_version="6">
<description>TO 126 horizontal</description>
<packageinstances>
<packageinstance name="TO126"/>
</packageinstances>
</package3d>
<package3d name="TO126V" urn="urn:adsk.eagle:package:28743/1" type="box" library_version="6">
<description>TO 126 vertical</description>
<packageinstances>
<packageinstance name="TO126V"/>
</packageinstances>
</package3d>
<package3d name="TO218" urn="urn:adsk.eagle:package:28522/1" type="box" library_version="6">
<description>TO 218 horizontal</description>
<packageinstances>
<packageinstance name="TO218"/>
</packageinstances>
</package3d>
<package3d name="TO218V" urn="urn:adsk.eagle:package:28519/1" type="box" library_version="6">
<description>TO 218 vertical</description>
<packageinstances>
<packageinstance name="TO218V"/>
</packageinstances>
</package3d>
<package3d name="TO220" urn="urn:adsk.eagle:package:28520/1" type="box" library_version="6">
<description>TO 220 horizontal</description>
<packageinstances>
<packageinstance name="TO220"/>
</packageinstances>
</package3d>
<package3d name="TO220V" urn="urn:adsk.eagle:package:28746/2" type="model" library_version="6">
<description>TO 220 vertical</description>
<packageinstances>
<packageinstance name="TO220V"/>
</packageinstances>
</package3d>
<package3d name="TO225AA" urn="urn:adsk.eagle:package:29905/1" type="box" library_version="6">
<description>TO-225
<packageinstances>
<packageinstance name="TO225AA"/>
</packageinstances>
</package3d>
<package3d name="TO39" urn="urn:adsk.eagle:package:28730/1" type="box" library_version="6">
<description>TO-39</description>
<packageinstances>
<packageinstance name="TO39"/>
</packageinstances>
</package3d>
<package3d name="TO5" urn="urn:adsk.eagle:package:28729/1" type="box" library_version="6">
<description>TO 5</description>
<packageinstances>
<packageinstance name="TO5"/>
</packageinstances>
</package3d>
<package3d name="TO66" urn="urn:adsk.eagle:package:29220/1" type="box" library_version="6">
<description>TO-66</description>
<packageinstances>
<packageinstance name="TO66"/>
</packageinstances>
</package3d>
<package3d name="TO92" urn="urn:adsk.eagle:package:28523/2" type="model" library_version="6">
<description>TO 92</description>
<packageinstances>
<packageinstance name="TO92"/>
</packageinstances>
</package3d>
<package3d name="TO92-EBC" urn="urn:adsk.eagle:package:29915/2" type="model" library_version="6">
<description>TO-92 Pads In Line E B C from top</description>
<packageinstances>
<packageinstance name="TO92-EBC"/>
</packageinstances>
</package3d>
<package3d name="TO92-E1" urn="urn:adsk.eagle:package:29916/2" type="model" library_version="6">
<description>TO-92 Pads Triangle Reverse</description>
<packageinstances>
<packageinstance name="TO92-E1"/>
</packageinstances>
</package3d>
<package3d name="TO92L" urn="urn:adsk.eagle:package:29918/1" type="box" library_version="6">
<description>TO-92
<packageinstances>
<packageinstance name="TO92L"/>
</packageinstances>
</package3d>
<package3d name="TOP3" urn="urn:adsk.eagle:package:28521/1" type="box" library_version="6">
<description>TOP 3 horizontal</description>
<packageinstances>
<packageinstance name="TOP3"/>
</packageinstances>
</package3d>
<package3d name="TOP3V" urn="urn:adsk.eagle:package:28768/1" type="box" library_version="6">
<description>TOP 3 vertical</description>
<packageinstances>
<packageinstance name="TOP3V"/>
</packageinstances>
</package3d>
<package3d name="SOT23-BEC" urn="urn:adsk.eagle:package:28748/2" type="model" library_version="6">
<packageinstances>
<packageinstance name="SOT23-BEC"/>
</packageinstances>
</package3d>
<package3d name="SOT23-EBC" urn="urn:adsk.eagle:package:28750/3" type="model" library_version="6">
<description>SOT-23 (EBC)</description>
<packageinstances>
<packageinstance name="SOT23-EBC"/>
</packageinstances>
</package3d>
<package3d name="TO92-BCE" urn="urn:adsk.eagle:package:29924/2" type="model" library_version="6">
<description>TO-92 Pads In Line B C E from top</description>
<packageinstances>
<packageinstance name="TO92-BCE"/>
</packageinstances>
</package3d>
<package3d name="TO92-CBE" urn="urn:adsk.eagle:package:29921/2" type="model" library_version="6">
<description>TO-92 Pads In Line  C B E from top</description>
<packageinstances>
<packageinstance name="TO92-CBE"/>
</packageinstances>
</package3d>
<package3d name="TO92-BEC" urn="urn:adsk.eagle:package:29922/2" type="model" library_version="6">
<description>TO-92 Pads In Line  B E C from top</description>
<packageinstances>
<packageinstance name="TO92-BEC"/>
</packageinstances>
</package3d>
<package3d name="TO92-CEB" urn="urn:adsk.eagle:package:29923/2" type="model" library_version="6">
<description>TO-92 Pads In Line C E B from top</description>
<packageinstances>
<packageinstance name="TO92-CEB"/>
</packageinstances>
</package3d>
<package3d name="SC59-BEC" urn="urn:adsk.eagle:package:28754/2" type="model" library_version="6">
<packageinstances>
<packageinstance name="SC59-BEC"/>
</packageinstances>
</package3d>
<package3d name="SOT89-BCE" urn="urn:adsk.eagle:package:29925/3" type="model" library_version="6">
<packageinstances>
<packageinstance name="SOT89-BCE"/>
</packageinstances>
</package3d>
<package3d name="SOT37" urn="urn:adsk.eagle:package:28760/1" type="box" library_version="6">
<description>SOT-37
<packageinstances>
<packageinstance name="SOT37"/>
</packageinstances>
</package3d>
<package3d name="TO92-ECB" urn="urn:adsk.eagle:package:29929/2" type="model" library_version="6">
<description>TO-92 Pads In Line E C B from top</description>
<packageinstances>
<packageinstance name="TO92-ECB"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="NPN" urn="urn:adsk.eagle:symbol:29821/1" library_version="6">
<wire x1="2.54" y1="2.54" x2="0.508" y2="1.524" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-1.524" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.778" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.54" y1="-2.04" x2="0.308" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-2.413" x2="2.286" y2="-2.413" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.413" x2="1.778" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.778" x2="1.524" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.524" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.032" width="0.254" layer="94"/>
<text x="-10.16" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="E" x="2.54" y="-5.08" visible="off" length="short" direction="pas" swaplevel="3" rot="R90"/>
<pin name="C" x="2.54" y="5.08" visible="off" length="short" direction="pas" swaplevel="2" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="*-NPN-" urn="urn:adsk.eagle:component:30081/23" prefix="T" uservalue="yes" library_version="6">
<description>NPN Transistror&lt;p&gt;
BF959 corrected 2008.03.06&lt;br&gt;</description>
<gates>
<gate name="G$1" symbol="NPN" x="0" y="0"/>
</gates>
<devices>
<device name="TO3/" package="TO3">
<connects>
<connect gate="G$1" pin="B" pad="B"/>
<connect gate="G$1" pin="C" pad="C"/>
<connect gate="G$1" pin="E" pad="E"/>
</connects>
<package3dinstances>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29899/2"/>
</package3dinstances>
<technologies>
<technology name="">
<attribute name="POPULARITY" value="0" constant="no"/>
</technology>
</technologies>
</device>
<device name="TO18-EBC" package="TO18">
<connects>
<connect gate="G$1" pin="B" pad="2"/>
<connect gate="G$1" pin="C" pad="3"/>
<connect gate="G$1" pin="E" pad="1"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28526/2"/>
<technologies>
<technology name="2N2218">
</technology>
<technology name="2N2222">
</technology>
<technology name="2N2222A">
</technology>
<technology name="2N2369">
</technology>
<technology name="2N2369A">
</technology>
<technology name="2N2484">
</technology>
<technology name="2N2896">
</technology>
<technology name="2N3700">
</technology>
<technology name="2N930">
</technology>
<technology name="BC107A">
</technology>
<technology name="BC107B">
</technology>
<technology name="BC108B">
</technology>
<technology name="BC108C">
</technology>
<technology name="BCY58-IX">
</technology>
<technology name="BCY58-VIII">
</technology>
<technology name="BCY59-VII">
</technology>
<technology name="BCY59-VIII">
</technology>
<technology name="BCY59-X">
</technology>
<technology name="BSS71">
</technology>
<technology name="BSS72">
</technology>
<technology name="BSS73">
</technology>
<technology name="BSX20">
</technology>
</technologies>
</device>
<device name="TO18-" package="TO18-">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28983/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO202" package="TO202">
<connects>
<connect gate="G$1" pin="B" pad="3"/>
<connect gate="G$1" pin="C" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28525/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO202V" package="TO202V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28741/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOT93" package="SOT93">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29486/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOT93V" package="SOT93V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28764/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO126" package="TO126">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29898/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO126V" package="TO126V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28743/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO218" package="TO218">
<connects>
<connect gate="G$1" pin="B" pad="1"/>
<connect gate="G$1" pin="E" pad="3"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28522/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO218V" package="TO218V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28519/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO220" package="TO220">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28520/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO220V" package="TO220V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28746/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO225AA" package="TO225AA">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29905/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO39-EBC" package="TO39">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28730/1"/>
<technologies>
<technology name="2N1613">
</technology>
<technology name="2N1711">
</technology>
<technology name="2N1893">
</technology>
<technology name="2N2102">
</technology>
</technology>
<technology name="2N2219">
</technology>
<technology name="2N2219A">
</technology>
<technology name="2N3019">
</technology>
<technology name="2N3020">
</technology>
<technology name="2N3439">
</technology>
<technology name="2N3440">
</technology>
<technology name="BC140-10">
</technology>
<technology name="BC140-16">
</technology>
<technology name="BC141-10">
</technology>
<technology name="BC141-16">
</technology>
<technology name="BFY50">
</technology>
<technology name="BSX45-16">
</technology>
<technology name="BSX46-10">
</technology>
<technology name="BSX46-16">
</technology>
</technologies>
</device>
<device name="TO5" package="TO5">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28729/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO66" package="TO66">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29220/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO92" package="TO92">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28523/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO92-EBC" package="TO92-EBC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29915/2"/>
<technologies>
</technology>
<technology name="29">
</technology>
<technology name="92">
</technology>
<technology name="BC317">
</technology>
<technology name="BC318">
</technology>
<technology name="BC319">
</technology>
<technology name="MPSA06">
</technology>
<technology name="MPSA13">
</technology>
<technology name="MPSA14">
</technology>
<technology name="MPSA18">
</technology>
<technology name="MPSA28">
</technology>
<technology name="MPSA42">
</technology>
<technology name="MPSA44">
</technology>
</technologies>
</device>
<device name="TO92-E1" package="TO92-E1">
<connects>
<connect gate="G$1" pin="C" pad="1"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29916/2"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO92L" package="TO92L">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29918/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TOP3" package="TOP3">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28521/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TOP3V" package="TOP3V">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28768/1"/>
<technologies>
</technology>
</technologies>
</device>
<device name="SOT23-BEC" package="SOT23-BEC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28748/2"/>
<technologies>
<technology name="BC808">
</technology>
<technology name="BC817">
</technology>
<technology name="BC817-16">
</technology>
<technology name="BC817-16LT1">
</technology>
<technology name="BC817-25">
</technology>
<technology name="BC817-25LT1">
</technology>
<technology name="BC817-40">
</technology>
<technology name="BC817-40LT1">
</technology>
<technology name="BC818">
</technology>
<technology name="BC818-16">
</technology>
<technology name="BC818-25">
</technology>
<technology name="BC818-40">
</technology>
<technology name="BC846">
</technology>
<technology name="BC846A">
</technology>
<technology name="BC846ALT1">
</technology>
<technology name="BC846B">
</technology>
<technology name="BC846BLT1">
</technology>
<technology name="BC847">
</technology>
<technology name="BC847A">
</technology>
<technology name="BC847ALT1">
</technology>
<technology name="BC847B">
</technology>
<technology name="BC847BLT1">
</technology>
<technology name="BC847C">
</technology>
<technology name="BC847CLT1">
</technology>
<technology name="BC848">
</technology>
<technology name="BC848A">
</technology>
<technology name="BC848ALT1">
</technology>
<technology name="BC848B">
</technology>
<technology name="BC848BLT1">
</technology>
<technology name="BC848C">
</technology>
<technology name="BC848CLT1">
</technology>
<technology name="BC849">
</technology>
<technology name="BC850">
</technology>
<technology name="BCF29">
</technology>
<technology name="BCF30">
</technology>
<technology name="BCF32">
</technology>
<technology name="BCF33">
</technology>
<technology name="BCF81">
</technology>
<technology name="BCV71">
</technology>
<technology name="BCV72">
</technology>
<technology name="BCW31">
</technology>
<technology name="BCW32">
</technology>
<technology name="BCW33">
</technology>
<technology name="BCW60">
</technology>
<technology name="BCW71">
</technology>
<technology name="BCW72">
</technology>
<technology name="BCW81">
</technology>
<technology name="BCX19">
</technology>
<technology name="BCX20">
</technology>
<technology name="BCX70">
</technology>
<technology name="BF820">
</technology>
<technology name="BF822">
</technology>
<technology name="BFR53">
</technology>
<technology name="BFR92">
</technology>
<technology name="BFR92A">
</technology>
<technology name="BFR93">
</technology>
<technology name="BFR93A">
</technology>
<technology name="BFS17">
</technology>
<technology name="BFS19">
</technology>
<technology name="BFS20">
</technology>
<technology name="BFT25">
</technology>
<technology name="BSR12">
</technology>
<technology name="BSR13">
</technology>
<technology name="BSR14">
</technology>
<technology name="BSV52LT1">
</technology>
<technology name="MMBT2222ALT1">
</technology>
<technology name="MMBT2369LT1">
</technology>
<technology name="MMBT2484LT1">
</technology>
<technology name="MMBT3904LT1">
</technology>
<technology name="MMBT4401LT1">
</technology>
<technology name="MMBT5551LT1">
</technology>
<technology name="MMBT6429LT1">
</technology>
<technology name="MMBT6517LT1">
</technology>
<technology name="MMBT918LT1">
</technology>
<technology name="MMBTA42LT1">
</technology>
<technology name="MMBTH10LT1">
</technology>
<technology name="MMBTH24LT1">
</technology>
</technologies>
</device>
<device name="SOT23-EBC" package="SOT23-EBC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28750/3"/>
<technologies>
</technology>
</technologies>
</device>
<device name="TO92-BCE" package="TO92-BCE">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29924/2"/>
<technologies>
<technology name="BF420">
</technology>
<technology name="BF422">
</technology>
</technologies>
</device>
<device name="TO92-CBE" package="TO92-CBE">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29921/2"/>
<technologies>
<technology name="2N4124">
</technology>
<technology name="2N5400">
</technology>
<technology name="2N5401">
</technology>
<technology name="2N5550">
</technology>
<technology name="2N5551">
</technology>
<technology name="2N6427">
</technology>
<technology name="2N6517">
</technology>
<technology name="2N6520">
</technology>
<technology name="BC237">
</technology>
<technology name="BC238">
</technology>
<technology name="BC239">
</technology>
<technology name="BC328">
</technology>
<technology name="BC337">
</technology>
<technology name="BC337-16">
</technology>
<technology name="BC337-25">
</technology>
<technology name="BC337-40">
</technology>
<technology name="BC338-16">
</technology>
<technology name="BC338-25">
</technology>
<technology name="BC338-40">
</technology>
<technology name="BC372">
</technology>
<technology name="BC373">
</technology>
<technology name="BC447">
</technology>
<technology name="BC449">
</technology>
<technology name="BC449A">
</technology>
<technology name="BC485">
</technology>
<technology name="BC487">
</technology>
<technology name="BC489">
</technology>
<technology name="BC517">
</technology>
<technology name="BC546">
</technology>
<technology name="BC547">
</technology>
<technology name="BC547A">
</technology>
<technology name="BC547B">
</technology>
<technology name="BC548">
</technology>
<technology name="BC549">
</technology>
<technology name="BC550">
</technology>
<technology name="BC618">
</technology>
<technology name="BF391">
</technology>
<technology name="BF393">
</technology>
<technology name="BF844">
</technology>
<technology name="MPS2222A">
</technology>
<technology name="MPSL51">
</technology>
<technology name="MPSW42">
</technology>
</technologies>
</device>
<device name="TO92-BEC" package="TO92-BEC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29922/2"/>
<technologies>
<technology name="BF199">
</technology>
<technology name="BF224">
</technology>
<technology name="BF240">
</technology>
</technologies>
</device>
<device name="TO92-CEB" package="TO92-CEB">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29923/2"/>
<technologies>
<technology name="BF374">
</technology>
<technology name="BF959">
</technology>
<technology name="MPHS10">
</technology>
</technologies>
</device>
<device name="SC59-BEC" package="SC59-BEC">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28754/2"/>
<technologies>
<technology name="MMUN2211LT1">
</technology>
<technology name="MMUN2212LT1">
</technology>
<technology name="MMUN2213LT1">
</technology>
<technology name="MMUN2214LT1">
</technology>
</technologies>
</device>
<device name="SOT89-BCE" package="SOT89-BCE">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29925/3"/>
<technologies>
</technology>
<technology name="BC868">
</technology>
<technology name="BCX54">
</technology>
<technology name="BCX55">
</technology>
<technology name="BCX56">
</technology>
<technology name="BF622">
</technology>
</technologies>
</device>
<device name="SOT-37" package="SOT37">
<connects>
<connect gate="G$1" pin="E" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:28760/1"/>
<technologies>
<technology name="BFR96">
</technology>
</technologies>
</device>
<device name="TO92-ECB" package="TO92-ECB">
<connects>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29929/2"/>
<technologies>
</technology>
<technology name="BC167">
</technology>
<technology name="BC168">
</technology>
<technology name="BC169">
</technology>
<technology name="BC368">
</technology>
<technology name="BC635">
</technology>
<technology name="BC637">
</technology>
<technology name="BC639">
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="mc34063">
<description>&lt;b&gt;MC34063: 1.5 A, Step-Up/Down/Inverting Switching Regulator&lt;/b&gt;
&lt;p&gt;&lt;b&gt;Doublecheck before using!&lt;/b&gt;&lt;/p&gt;</description>
<packages>
<package name="DIL08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SOIC8">
<description>&lt;b&gt;Small Outline IC&lt;/b&gt;</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="MC34063">
<wire x1="10.16" y1="2.54" x2="-10.16" y2="2.54" width="0.254" layer="94"/>
<wire x1="-10.16" y1="2.54" x2="-10.16" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-10.16" x2="10.16" y2="-10.16" width="0.254" layer="94"/>
<wire x1="10.16" y1="-10.16" x2="10.16" y2="2.54" width="0.254" layer="94"/>
<text x="-10.16" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
<pin name="DC" x="-15.24" y="0" length="middle" direction="pas"/>
<pin name="VCC" x="-15.24" y="-5.08" length="middle" direction="pas"/>
<pin name="IS" x="-15.24" y="-2.54" length="middle" direction="pas"/>
<pin name="FB" x="-15.24" y="-7.62" length="middle" direction="pas"/>
<pin name="SWC" x="15.24" y="0" length="middle" direction="pas" rot="R180"/>
<pin name="SWE" x="15.24" y="-2.54" length="middle" direction="pas" rot="R180"/>
<pin name="TC" x="15.24" y="-5.08" length="middle" direction="pas" rot="R180"/>
<pin name="GND" x="15.24" y="-7.62" length="middle" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MC34063" prefix="IC">
<gates>
<gate name="G$1" symbol="MC34063" x="0" y="0"/>
</gates>
<devices>
<device name="AP" package="DIL08">
<connects>
<connect gate="G$1" pin="DC" pad="8"/>
<connect gate="G$1" pin="FB" pad="5"/>
<connect gate="G$1" pin="GND" pad="4"/>
<connect gate="G$1" pin="IS" pad="7"/>
<connect gate="G$1" pin="SWC" pad="1"/>
<connect gate="G$1" pin="SWE" pad="2"/>
<connect gate="G$1" pin="TC" pad="3"/>
<connect gate="G$1" pin="VCC" pad="6"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="AD" package="SOIC8">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="maxim" urn="urn:adsk.eagle:library:269">
<description>&lt;b&gt;Maxim Components&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL08" urn="urn:adsk.eagle:footprint:29416/1" library_version="4">
</package>
</packages>
<packages3d>
<package3d name="DIL08" urn="urn:adsk.eagle:package:29519/2" type="model" library_version="4">
<description>Dual In Line Package</description>
<packageinstances>
<packageinstance name="DIL08"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="ICL7660" urn="urn:adsk.eagle:symbol:17160/1" library_version="4">
<wire x1="-10.16" y1="-10.16" x2="-10.16" y2="10.16" width="0.4064" layer="94"/>
<wire x1="7.62" y1="10.16" x2="-10.16" y2="10.16" width="0.4064" layer="94"/>
<wire x1="7.62" y1="10.16" x2="7.62" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="-10.16" x2="7.62" y2="-10.16" width="0.4064" layer="94"/>
<text x="-10.16" y="10.795" size="1.778" layer="95">&gt;NAME</text>
<pin name="LV" x="-15.24" y="7.62" length="middle" direction="pas"/>
<pin name="CAP-" x="-15.24" y="-2.54" length="middle" direction="pas"/>
<pin name="NC" x="-15.24" y="-7.62" length="middle" direction="nc"/>
<pin name="VOUT" x="12.7" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="GND" x="12.7" y="-7.62" length="middle" direction="pwr" rot="R180"/>
<pin name="V+" x="12.7" y="-2.54" length="middle" direction="pwr" rot="R180"/>
<pin name="OSC" x="12.7" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="CAP+" x="-15.24" y="2.54" length="middle" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="ICL7660CPA" urn="urn:adsk.eagle:component:17639/3" prefix="IC" library_version="4">
<description>&lt;b&gt;VOLTAGE CONVERTER&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="ICL7660" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL08">
<connects>
<connect gate="G$1" pin="CAP+" pad="2"/>
<connect gate="G$1" pin="CAP-" pad="4"/>
<connect gate="G$1" pin="GND" pad="3"/>
<connect gate="G$1" pin="LV" pad="6"/>
<connect gate="G$1" pin="NC" pad="1"/>
<connect gate="G$1" pin="OSC" pad="7"/>
<connect gate="G$1" pin="V+" pad="8"/>
<connect gate="G$1" pin="VOUT" pad="5"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:29519/2"/>
<technologies>
<attribute name="MF" value="INTERSIL" constant="no"/>
<attribute name="MPN" value="ICL7660CPA" constant="no"/>
<attribute name="OC_FARNELL" value="1018170" constant="no"/>
<attribute name="OC_NEWARK" value="06F7441" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="frames" urn="urn:adsk.eagle:library:229">
<description>&lt;b&gt;Frames for Sheet and Layout&lt;/b&gt;</description>
<packages>
</packages>
<symbols>
<symbol name="A5L-LOC" urn="urn:adsk.eagle:symbol:13879/1" library_version="1">
<wire x1="85.09" y1="3.81" x2="85.09" y2="24.13" width="0.1016" layer="94"/>
<wire x1="85.09" y1="24.13" x2="139.065" y2="24.13" width="0.1016" layer="94"/>
<wire x1="139.065" y1="24.13" x2="180.34" y2="24.13" width="0.1016" layer="94"/>
<wire x1="170.18" y1="3.81" x2="170.18" y2="8.89" width="0.1016" layer="94"/>
<wire x1="170.18" y1="8.89" x2="180.34" y2="8.89" width="0.1016" layer="94"/>
<wire x1="170.18" y1="8.89" x2="139.065" y2="8.89" width="0.1016" layer="94"/>
<wire x1="139.065" y1="8.89" x2="139.065" y2="3.81" width="0.1016" layer="94"/>
<wire x1="139.065" y1="8.89" x2="139.065" y2="13.97" width="0.1016" layer="94"/>
<wire x1="139.065" y1="13.97" x2="180.34" y2="13.97" width="0.1016" layer="94"/>
<wire x1="139.065" y1="13.97" x2="139.065" y2="19.05" width="0.1016" layer="94"/>
<wire x1="139.065" y1="19.05" x2="180.34" y2="19.05" width="0.1016" layer="94"/>
<wire x1="139.065" y1="19.05" x2="139.065" y2="24.13" width="0.1016" layer="94"/>
<text x="140.97" y="15.24" size="2.54" layer="94">&gt;DRAWING_NAME</text>
<text x="140.97" y="10.16" size="2.286" layer="94">&gt;LAST_DATE_TIME</text>
<text x="154.305" y="5.08" size="2.54" layer="94">&gt;SHEET</text>
<text x="140.716" y="4.953" size="2.54" layer="94">Sheet:</text>
<frame x1="0" y1="0" x2="184.15" y2="133.35" columns="4" rows="4" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="A5L-LOC" urn="urn:adsk.eagle:component:13933/1" prefix="FRAME" uservalue="yes" library_version="1">
<description>A5L LOC</description>
<gates>
<gate name="G$1" symbol="A5L-LOC" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="inductors" urn="urn:adsk.eagle:library:243">
<description>&lt;b&gt;Inductors and Filters&lt;/b&gt;&lt;p&gt;
Based on the previous library ind-a.lbr&lt;p&gt;
<packages>
<package name="82114R" urn="urn:adsk.eagle:footprint:15015/1" library_version="3">
<description>&lt;B&gt;INDUCTOR&lt;/B&gt;&lt;p&gt;
manufacturer Siemens</description>
<wire x1="0.3302" y1="2.2098" x2="1.6002" y2="0.9398" width="0.1524" layer="51"/>
<wire x1="-0.3048" y1="1.5748" x2="0.9652" y2="0.3048" width="0.1524" layer="51"/>
<wire x1="-1.5748" y1="-0.9652" x2="-0.3048" y2="-2.2352" width="0.1524" layer="51"/>
<wire x1="-0.9398" y1="-0.3302" x2="0.3302" y2="-1.6002" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="1.651" x2="1.651" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="1.016" x2="1.016" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="1.016" y1="-1.651" x2="1.664" y2="-1.0284" width="0.1524" layer="51" curve="182.298596"/>
<wire x1="1.5748" y1="-0.3048" x2="2.2228" y2="0.3178" width="0.1524" layer="21" curve="182.298596"/>
<wire x1="-0.3302" y1="-2.2098" x2="0.3178" y2="-1.5872" width="0.1524" layer="51" curve="182.298596"/>
<wire x1="-0.3178" y1="1.5872" x2="0.3302" y2="2.2098" width="0.1524" layer="51" curve="-182.298596"/>
<wire x1="-2.2228" y1="-0.3178" x2="-1.5748" y2="0.3048" width="0.1524" layer="21" curve="-182.298596"/>
<wire x1="-1.664" y1="1.0284" x2="-1.016" y2="1.651" width="0.1524" layer="51" curve="-182.298596"/>
<wire x1="-1.5748" y1="0.3048" x2="-0.9398" y2="-0.3302" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-0.3302" x2="-1.5748" y2="-0.9652" width="0.1524" layer="21"/>
<wire x1="0.9652" y1="0.3048" x2="1.6002" y2="-0.3302" width="0.1524" layer="21"/>
<wire x1="1.6002" y1="0.9398" x2="2.2352" y2="0.3048" width="0.1524" layer="21"/>
<wire x1="1.905" y1="0" x2="1.27" y2="0.635" width="0.8128" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.27" y2="-0.635" width="0.8128" layer="21"/>
<wire x1="0" y1="-1.905" x2="-1.27" y2="-0.635" width="0.8128" layer="51"/>
<wire x1="0" y1="1.905" x2="1.27" y2="0.635" width="0.8128" layer="51"/>
<wire x1="1.397" y1="-1.397" x2="0.254" y2="-0.254" width="0.8128" layer="51"/>
<wire x1="0.254" y1="-0.254" x2="-0.254" y2="0.254" width="0.8128" layer="21"/>
<wire x1="-0.254" y1="0.254" x2="-1.397" y2="1.397" width="0.8128" layer="51"/>
<circle x="0" y="0" radius="3.175" width="0.1524" layer="21"/>
<pad name="1" x="0" y="1.905" drill="0.8128" shape="long"/>
<pad name="2" x="0" y="-1.905" drill="0.8128" shape="long"/>
<text x="-2.54" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-4.699" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="82114R" urn="urn:adsk.eagle:package:15100/1" type="box" library_version="3">
<description>INDUCTOR
<packageinstances>
<packageinstance name="82114R"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="DRK" urn="urn:adsk.eagle:symbol:14966/1" library_version="3">
<wire x1="-3.81" y1="1.651" x2="3.81" y2="1.651" width="0.254" layer="94"/>
<text x="-3.81" y="2.286" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.937" y="-3.048" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-0.889" x2="3.81" y2="0.889" layer="94"/>
<pin name="2" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="82114R" urn="urn:adsk.eagle:component:15190/3" prefix="L" library_version="3">
<description>&lt;B&gt;INDUCTOR&lt;/B&gt;</description>
<gates>
<gate name="1" symbol="DRK" x="0" y="0"/>
</gates>
<devices>
<device name="" package="82114R">
<connects>
<connect gate="1" pin="1" pad="1"/>
<connect gate="1" pin="2" pad="2"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:15100/1"/>
<technologies>
<attribute name="POPULARITY" value="2" constant="no"/>
<attribute name="SPICEPREFIX" value="L" constant="no"/>
</technology>
</technologies>
</device>
</devices>
<spice>
<pinmapping spiceprefix="L">
<pinmap gate="1" pin="1" pinorder="1"/>
<pinmap gate="1" pin="2" pinorder="2"/>
</pinmapping>
</spice>
</deviceset>
</devicesets>
</library>
<library name="solpad" urn="urn:adsk.eagle:library:364">
<description>&lt;b&gt;Solder Pads/Test Points&lt;/b&gt;&lt;p&gt;
<packages>
<package name="LSP10" urn="urn:adsk.eagle:footprint:26494/1" library_version="2">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt;
drill 1.0 mm</description>
<wire x1="-1.27" y1="0.254" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.254" x2="0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="-0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<pad name="MP" x="0" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-1.27" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.254" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
<packages3d>
<package3d name="LSP10" urn="urn:adsk.eagle:package:26501/1" type="box" library_version="2">
<description>SOLDER PAD
<packageinstances>
<packageinstance name="LSP10"/>
</packageinstances>
</package3d>
</packages3d>
<symbols>
<symbol name="LSP" urn="urn:adsk.eagle:symbol:26492/1" library_version="2">
<wire x1="-1.016" y1="2.032" x2="1.016" y2="0" width="0.254" layer="94"/>
<wire x1="-1.016" y1="0" x2="1.016" y2="2.032" width="0.254" layer="94"/>
<circle x="0" y="1.016" radius="1.016" width="0.4064" layer="94"/>
<text x="-1.27" y="2.921" size="1.778" layer="95">&gt;NAME</text>
<pin name="MP" x="0" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="LSP10" urn="urn:adsk.eagle:component:26508/2" prefix="LSP" library_version="2">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt; drill 1.0 mm, distributor Buerklin, 12H555</description>
<gates>
<gate name="1" symbol="LSP" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LSP10">
<connects>
<connect gate="1" pin="MP" pad="MP"/>
</connects>
<package3dinstance package3d_urn="urn:adsk.eagle:package:26501/1"/>
<technologies>
<attribute name="POPULARITY" value="52" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="IC1" library="ic-package" library_urn="urn:adsk.eagle:library:239" deviceset="DIL28" device="-3" package3d_urn="urn:adsk.eagle:package:827/2" value="ATMEGA8L"/>
<part name="R1" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="10k"/>
<part name="C2" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n"/>
<part name="GND7" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R13" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-TRIMM" device="43P" package3d_urn="urn:adsk.eagle:package:23756/1" value="25k"/>
<part name="P+1" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="R21" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="1.8k"/>
<part name="VR1" library="v-reg" library_urn="urn:adsk.eagle:library:409" deviceset="TL431CLP" device="" package3d_urn="urn:adsk.eagle:package:30363/1" value="TL431"/>
<part name="C20" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF"/>
<part name="R23" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="22"/>
<part name="JP1" library="jumper" library_urn="urn:adsk.eagle:library:252" deviceset="JP1E" device="" package3d_urn="urn:adsk.eagle:package:15455/1"/>
<part name="D1" library="diode" library_urn="urn:adsk.eagle:library:210" deviceset="DIODE-" device="SOD80C" package3d_urn="urn:adsk.eagle:package:43405/2"/>
<part name="D2" library="diode" library_urn="urn:adsk.eagle:library:210" deviceset="DIODE-" device="SOD80C" package3d_urn="urn:adsk.eagle:package:43405/2"/>
<part name="D3" library="diode" library_urn="urn:adsk.eagle:library:210" deviceset="MBRS130LT3" device="" package3d_urn="urn:adsk.eagle:package:43404/2"/>
<part name="L1" library="inductor-neosid" library_urn="urn:adsk.eagle:library:241" deviceset="MS50" device="" package3d_urn="urn:adsk.eagle:package:14699/1"/>
<part name="LD1" library="led" library_urn="urn:adsk.eagle:library:259" deviceset="DUOLED-RG-C" device="" package3d_urn="urn:adsk.eagle:package:15851/1"/>
<part name="R3" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="1.8k"/>
<part name="R4" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="1.8k"/>
<part name="GND1" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND2" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="LED1" library="display-kingbright" library_urn="urn:adsk.eagle:library:213" deviceset="B?56-12*WA" device="A" package3d_urn="urn:adsk.eagle:package:13083/1" technology="SR"/>
<part name="GND3" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="IC2" library="linear" library_urn="urn:adsk.eagle:library:262" deviceset="OP07*" device="" package3d_urn="urn:adsk.eagle:package:16409/2" technology="CQ">
<attribute name="SPICEPREFIX" value="X"/>
</part>
<part name="R2" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-TRIMM" device="43P" package3d_urn="urn:adsk.eagle:package:23756/1" value="25k"/>
<part name="L2" library="inductor-neosid" library_urn="urn:adsk.eagle:library:241" deviceset="MS50" device="" package3d_urn="urn:adsk.eagle:package:14699/1"/>
<part name="C1" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF"/>
<part name="P+2" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="SW1" library="switch-alps" library_urn="urn:adsk.eagle:library:373" deviceset="EC12E_SW" device="" package3d_urn="urn:adsk.eagle:package:27083/1"/>
<part name="GND4" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R5" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="00"/>
<part name="R6" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="00"/>
<part name="R7" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="00"/>
<part name="R8" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="00"/>
<part name="C3" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF"/>
<part name="C4" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF"/>
<part name="C5" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n"/>
<part name="C6" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n"/>
<part name="GND5" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND6" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="P-1" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="-5V" device=""/>
<part name="R9" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="00"/>
<part name="R10" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="00"/>
<part name="P+4" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="P+5" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="Q1" library="transistor-power" library_urn="urn:adsk.eagle:library:400" deviceset="PMOSFET_P" device="TO220BH" package3d_urn="urn:adsk.eagle:package:29490/1"/>
<part name="X1" library="con-ptr500" library_urn="urn:adsk.eagle:library:181" deviceset="AK500/2" device="" package3d_urn="urn:adsk.eagle:package:9880/1"/>
<part name="GND8" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="T1" library="transistor" library_urn="urn:adsk.eagle:library:402" deviceset="*-NPN-" device="TO92-CBE" package3d_urn="urn:adsk.eagle:package:29921/2" technology="2N6520"/>
<part name="R11" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="00"/>
<part name="GND9" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R12" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="00"/>
<part name="R14" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="00"/>
<part name="X2" library="con-ptr500" library_urn="urn:adsk.eagle:library:181" deviceset="AK500/2" device="" package3d_urn="urn:adsk.eagle:package:9880/1"/>
<part name="GND10" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND11" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="R15" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="00"/>
<part name="IC3" library="mc34063" deviceset="MC34063" device="AP"/>
<part name="IC4" library="maxim" library_urn="urn:adsk.eagle:library:269" deviceset="ICL7660CPA" device="" package3d_urn="urn:adsk.eagle:package:29519/2"/>
<part name="R16" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="00"/>
<part name="C8" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="100n"/>
<part name="R17" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="00"/>
<part name="R18" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="R1206" package3d_urn="urn:adsk.eagle:package:23540/2" value="00"/>
<part name="FRAME1" library="frames" library_urn="urn:adsk.eagle:library:229" deviceset="A5L-LOC" device=""/>
<part name="GND12" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="GND13" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C10" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="CPOL-EU" device="E3.5-8" package3d_urn="urn:adsk.eagle:package:23360/2"/>
<part name="L3" library="inductors" library_urn="urn:adsk.eagle:library:243" deviceset="82114R" device="" package3d_urn="urn:adsk.eagle:package:15100/1"/>
<part name="D5" library="diode" library_urn="urn:adsk.eagle:library:210" deviceset="1N581*" device="" package3d_urn="urn:adsk.eagle:package:43421/1" technology="9-B"/>
<part name="GND14" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="P+3" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="C12" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2"/>
<part name="C13" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2"/>
<part name="GND15" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="P+6" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="+5V" device=""/>
<part name="P-2" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="-5V" device=""/>
<part name="LSP1" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="LSP2" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="LSP3" library="solpad" library_urn="urn:adsk.eagle:library:364" deviceset="LSP10" device="" package3d_urn="urn:adsk.eagle:package:26501/1"/>
<part name="C7" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF"/>
<part name="C11" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="CPOL-EU" device="E2,5-6E" package3d_urn="urn:adsk.eagle:package:23430/1"/>
<part name="R19" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="R-EU_" device="M1406" package3d_urn="urn:adsk.eagle:package:23569/2" value="00"/>
<part name="GND16" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C14" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF"/>
<part name="D6" library="diode" library_urn="urn:adsk.eagle:library:210" deviceset="MBRS130LT3" device="" package3d_urn="urn:adsk.eagle:package:43404/2"/>
<part name="L4" library="inductor-neosid" library_urn="urn:adsk.eagle:library:241" deviceset="MS50" device="" package3d_urn="urn:adsk.eagle:package:14699/1"/>
<part name="C15" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF"/>
<part name="GND17" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C16" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF"/>
<part name="GND18" library="supply1" library_urn="urn:adsk.eagle:library:371" deviceset="GND" device=""/>
<part name="C9" library="rcl" library_urn="urn:adsk.eagle:library:334" deviceset="C-EU" device="C1206" package3d_urn="urn:adsk.eagle:package:23618/2" value="10uF"/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
</instances>
<busses>
</busses>
<nets>
</nets>
</sheet>
<sheet>
<plain>
<wire x1="0" y1="0" x2="0" y2="147.955" width="0.1524" layer="99"/>
<wire x1="0" y1="147.955" x2="181.61" y2="147.32" width="0.1524" layer="99"/>
<wire x1="181.61" y1="147.32" x2="181.61" y2="-0.635" width="0.1524" layer="99"/>
<wire x1="181.61" y1="-0.635" x2="0" y2="0" width="0.1524" layer="99"/>
<text x="66.675" y="69.215" size="1.778" layer="97">SP</text>
<text x="140.335" y="15.24" size="2.1844" layer="94">Hakko forr.áll. Atmega8 led</text>
<text x="140.97" y="20.32" size="2.54" layer="94">zamatőr</text>
<text x="55.245" y="41.275" size="2.54" layer="97">+</text>
<text x="62.865" y="43.18" size="2.54" layer="97">_</text>
<text x="54.61" y="35.56" size="2.54" layer="97">16-24V</text>
</plain>
<instances>
<instance part="IC1" gate="G$1" x="86.995" y="97.155" smashed="yes">
<attribute name="NAME" x="82.55" y="114.3" size="1.778" layer="95"/>
<attribute name="VALUE" x="80.645" y="75.2475" size="1.778" layer="96"/>
</instance>
<instance part="R1" gate="G$1" x="74.295" y="120.65" smashed="yes" rot="R180">
<attribute name="NAME" x="69.85" y="122.1486" size="1.778" layer="95"/>
<attribute name="VALUE" x="73.2155" y="118.745" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="C2" gate="G$1" x="74.295" y="114.935" smashed="yes" rot="R90">
<attribute name="NAME" x="72.136" y="117.094" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="78.8035" y="118.6815" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND7" gate="1" x="69.85" y="84.455" smashed="yes">
<attribute name="VALUE" x="71.12" y="85.09" size="1.778" layer="96"/>
</instance>
<instance part="R13" gate="G$1" x="39.37" y="88.9" smashed="yes" rot="MR180">
<attribute name="NAME" x="38.1" y="92.329" size="1.778" layer="95" rot="MR0"/>
<attribute name="VALUE" x="36.83" y="88.9" size="1.778" layer="96" rot="MR270"/>
</instance>
<instance part="P+1" gate="1" x="67.31" y="123.19" smashed="yes">
<attribute name="VALUE" x="64.77" y="123.19" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R21" gate="G$1" x="126.365" y="102.87" smashed="yes" rot="R180">
<attribute name="NAME" x="128.905" y="106.4514" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="128.905" y="106.172" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="VR1" gate="G$1" x="120.015" y="100.33" smashed="yes" rot="R90">
<attribute name="NAME" x="126.365" y="97.79" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="129.54" y="99.695" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C20" gate="G$1" x="110.49" y="97.79" smashed="yes" rot="R180">
<attribute name="NAME" x="110.236" y="102.489" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="108.966" y="101.854" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R23" gate="G$1" x="79.375" y="67.945" smashed="yes" rot="R270">
<attribute name="NAME" x="73.66" y="71.3486" size="1.778" layer="95"/>
<attribute name="VALUE" x="74.93" y="67.818" size="1.778" layer="96"/>
</instance>
<instance part="JP1" gate="A" x="66.675" y="65.405" smashed="yes">
<attribute name="NAME" x="65.405" y="67.945" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="72.39" y="65.405" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="D1" gate="G$1" x="22.225" y="70.485" smashed="yes" rot="R90">
<attribute name="NAME" x="22.86" y="76.3524" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="24.5364" y="73.025" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="D2" gate="G$1" x="18.415" y="70.485" smashed="yes" rot="R270">
<attribute name="NAME" x="15.875" y="74.7776" size="1.778" layer="95"/>
<attribute name="VALUE" x="16.1036" y="67.945" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="D3" gate="G$1" x="67.31" y="97.155" smashed="yes">
<attribute name="NAME" x="65.024" y="99.06" size="1.778" layer="95"/>
<attribute name="VALUE" x="65.024" y="93.726" size="1.778" layer="96"/>
</instance>
<instance part="L1" gate="G$1" x="121.92" y="87.63" smashed="yes">
<attribute name="NAME" x="118.11" y="89.408" size="1.778" layer="95"/>
<attribute name="VALUE" x="118.11" y="84.074" size="1.778" layer="96"/>
</instance>
<instance part="LD1" gate="G$1" x="108.585" y="117.475" smashed="yes" rot="R90">
<attribute name="NAME" x="113.665" y="123.825" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="113.665" y="126.365" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R3" gate="G$1" x="100.965" y="112.395" smashed="yes" rot="R270">
<attribute name="NAME" x="97.3836" y="114.935" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="97.663" y="114.935" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R4" gate="G$1" x="116.205" y="112.395" smashed="yes" rot="R270">
<attribute name="NAME" x="112.6236" y="114.935" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="112.903" y="114.935" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND1" gate="1" x="108.585" y="110.49" smashed="yes">
<attribute name="VALUE" x="106.045" y="107.315" size="1.778" layer="96"/>
</instance>
<instance part="GND2" gate="1" x="103.505" y="92.71" smashed="yes">
<attribute name="VALUE" x="101.6" y="90.17" size="1.778" layer="96"/>
</instance>
<instance part="LED1" gate="DIG1" x="121.285" y="69.215" smashed="yes">
<attribute name="NAME" x="109.22" y="64.135" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="124.46" y="77.47" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND3" gate="1" x="67.31" y="112.395" smashed="yes">
<attribute name="VALUE" x="60.96" y="112.395" size="1.778" layer="96"/>
</instance>
<instance part="IC2" gate="A" x="31.75" y="75.565" smashed="yes" rot="MR180">
<attribute name="NAME" x="27.94" y="76.835" size="1.778" layer="95" rot="MR180"/>
<attribute name="VALUE" x="34.29" y="80.645" size="1.778" layer="96" rot="MR180"/>
</instance>
<instance part="R2" gate="G$1" x="38.735" y="66.04" smashed="yes" rot="R270">
<attribute name="NAME" x="38.1" y="69.469" size="1.778" layer="95"/>
<attribute name="VALUE" x="38.735" y="68.58" size="1.778" layer="96"/>
</instance>
<instance part="L2" gate="G$1" x="59.69" y="83.82" smashed="yes">
<attribute name="NAME" x="55.88" y="85.598" size="1.778" layer="95"/>
<attribute name="VALUE" x="55.88" y="80.264" size="1.778" layer="96"/>
</instance>
<instance part="C1" gate="G$1" x="110.49" y="90.17" smashed="yes" rot="R180">
<attribute name="NAME" x="110.236" y="94.869" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="117.221" y="94.234" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P+2" gate="1" x="131.445" y="109.22" smashed="yes">
<attribute name="VALUE" x="128.905" y="109.22" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SW1" gate="G$1" x="23.495" y="107.95" smashed="yes">
<attribute name="PART" x="19.685" y="107.95" size="1.27" layer="95" rot="R90"/>
<attribute name="VALUE" x="27.94" y="117.475" size="1.27" layer="96" rot="R180"/>
</instance>
<instance part="SW1" gate="G$2" x="24.13" y="121.92" smashed="yes">
<attribute name="PART" x="19.05" y="127" size="1.27" layer="95"/>
<attribute name="VALUE" x="19.05" y="119.38" size="1.27" layer="96"/>
</instance>
<instance part="GND4" gate="1" x="15.875" y="102.87" smashed="yes">
<attribute name="VALUE" x="17.145" y="103.505" size="1.778" layer="96"/>
</instance>
<instance part="R5" gate="G$1" x="36.83" y="113.03" smashed="yes" rot="R180">
<attribute name="NAME" x="35.7886" y="111.76" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="31.115" y="113.2205" size="1.778" layer="96"/>
</instance>
<instance part="R6" gate="G$1" x="36.83" y="107.315" smashed="yes" rot="R180">
<attribute name="NAME" x="35.7886" y="106.045" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="32.385" y="108.1405" size="1.778" layer="96"/>
</instance>
<instance part="R7" gate="G$1" x="36.83" y="102.235" smashed="yes" rot="R180">
<attribute name="NAME" x="35.7886" y="100.965" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="31.75" y="103.0605" size="1.778" layer="96"/>
</instance>
<instance part="R8" gate="G$1" x="36.83" y="118.11" smashed="yes" rot="R180">
<attribute name="NAME" x="35.7886" y="116.84" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="31.115" y="119.5705" size="1.778" layer="96"/>
</instance>
<instance part="C3" gate="G$1" x="29.21" y="55.88" smashed="yes" rot="R180">
<attribute name="NAME" x="28.956" y="60.579" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="30.226" y="60.579" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C4" gate="G$1" x="26.67" y="85.725" smashed="yes" rot="R270">
<attribute name="NAME" x="21.209" y="86.741" size="1.778" layer="95"/>
<attribute name="VALUE" x="23.749" y="86.106" size="1.778" layer="96"/>
</instance>
<instance part="C5" gate="G$1" x="41.91" y="55.88" smashed="yes" rot="R180">
<attribute name="NAME" x="37.084" y="58.166" size="1.778" layer="95"/>
<attribute name="VALUE" x="38.1635" y="60.3885" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="C6" gate="G$1" x="26.67" y="91.44" smashed="yes" rot="R270">
<attribute name="NAME" x="21.209" y="92.456" size="1.778" layer="95"/>
<attribute name="VALUE" x="22.7965" y="92.7735" size="1.778" layer="96"/>
</instance>
<instance part="GND5" gate="1" x="34.29" y="50.8" smashed="yes">
<attribute name="VALUE" x="35.56" y="51.435" size="1.778" layer="96"/>
</instance>
<instance part="GND6" gate="1" x="21.59" y="80.645" smashed="yes">
<attribute name="VALUE" x="15.24" y="81.28" size="1.778" layer="96"/>
</instance>
<instance part="P-1" gate="1" x="29.21" y="93.98" smashed="yes" rot="R180">
<attribute name="VALUE" x="27.305" y="94.615" size="1.778" layer="96"/>
</instance>
<instance part="R9" gate="G$1" x="29.21" y="97.79" smashed="yes" rot="R180">
<attribute name="NAME" x="27.305" y="99.9236" size="1.778" layer="95"/>
<attribute name="VALUE" x="24.13" y="98.6155" size="1.778" layer="96"/>
</instance>
<instance part="R10" gate="G$1" x="44.45" y="75.565" smashed="yes" rot="R180">
<attribute name="NAME" x="42.545" y="77.0636" size="1.778" layer="95"/>
<attribute name="VALUE" x="39.37" y="76.3905" size="1.778" layer="96"/>
</instance>
<instance part="P+4" gate="1" x="57.785" y="100.965" smashed="yes">
<attribute name="VALUE" x="63.5" y="100.965" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P+5" gate="1" x="59.055" y="65.405" smashed="yes">
<attribute name="VALUE" x="56.515" y="65.405" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="Q1" gate="G$1" x="32.385" y="40.005" smashed="yes" rot="MR90">
<attribute name="NAME" x="33.655" y="44.45" size="1.778" layer="95" rot="MR0"/>
<attribute name="VALUE" x="32.385" y="45.085" size="1.778" layer="96" rot="MR90"/>
</instance>
<instance part="X1" gate="-1" x="10.795" y="42.545" smashed="yes">
<attribute name="NAME" x="9.525" y="43.434" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X1" gate="-2" x="10.16" y="9.525" smashed="yes">
<attribute name="NAME" x="8.89" y="10.414" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="6.35" y="5.842" size="1.778" layer="96"/>
</instance>
<instance part="GND8" gate="1" x="27.305" y="6.985" smashed="yes">
<attribute name="VALUE" x="28.575" y="7.62" size="1.778" layer="96"/>
</instance>
<instance part="T1" gate="G$1" x="45.085" y="17.145" smashed="yes" rot="MR0">
<attribute name="NAME" x="41.91" y="17.145" size="1.778" layer="95" rot="MR0"/>
<attribute name="VALUE" x="55.245" y="22.225" size="1.778" layer="96" rot="MR0"/>
</instance>
<instance part="R11" gate="G$1" x="34.925" y="27.305" smashed="yes" rot="R90">
<attribute name="NAME" x="33.655" y="28.3464" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="35.7505" y="32.385" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND9" gate="1" x="42.545" y="6.985" smashed="yes">
<attribute name="VALUE" x="43.815" y="7.62" size="1.778" layer="96"/>
</instance>
<instance part="R12" gate="G$1" x="47.625" y="26.035" smashed="yes" rot="R270">
<attribute name="NAME" x="42.545" y="28.8036" size="1.778" layer="95"/>
<attribute name="VALUE" x="46.7995" y="20.955" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R14" gate="G$1" x="41.91" y="37.465" smashed="yes" rot="R270">
<attribute name="NAME" x="36.195" y="38.9636" size="1.778" layer="95"/>
<attribute name="VALUE" x="41.0845" y="32.385" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="X2" gate="-1" x="66.675" y="47.625" smashed="yes" rot="R270">
<attribute name="NAME" x="69.85" y="51.054" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="X2" gate="-2" x="53.975" y="47.625" smashed="yes" rot="R270">
<attribute name="NAME" x="56.515" y="50.419" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="50.292" y="51.435" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND10" gate="1" x="66.675" y="38.735" smashed="yes">
<attribute name="VALUE" x="67.31" y="40.005" size="1.778" layer="96"/>
</instance>
<instance part="GND11" gate="1" x="22.225" y="65.405" smashed="yes">
<attribute name="VALUE" x="23.495" y="66.04" size="1.778" layer="96"/>
</instance>
<instance part="R15" gate="G$1" x="15.875" y="53.34" smashed="yes" rot="R270">
<attribute name="NAME" x="17.145" y="52.2986" size="1.778" layer="95"/>
<attribute name="VALUE" x="15.0495" y="48.26" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="IC3" gate="G$1" x="128.905" y="48.26" smashed="yes">
<attribute name="NAME" x="118.745" y="50.8" size="1.778" layer="95"/>
<attribute name="VALUE" x="122.555" y="43.815" size="1.778" layer="96"/>
</instance>
<instance part="IC4" gate="G$1" x="158.75" y="88.9" smashed="yes">
<attribute name="NAME" x="148.59" y="99.695" size="1.778" layer="95"/>
<attribute name="VALUE" x="148.59" y="76.2" size="1.778" layer="96"/>
</instance>
<instance part="R16" gate="G$1" x="90.805" y="40.64" smashed="yes" rot="R270">
<attribute name="NAME" x="85.09" y="37.6936" size="1.778" layer="95"/>
<attribute name="VALUE" x="89.9795" y="35.56" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C8" gate="G$1" x="99.06" y="40.64" smashed="yes">
<attribute name="NAME" x="98.171" y="42.164" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="105.4735" y="42.4815" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R17" gate="G$1" x="118.745" y="31.75" smashed="yes">
<attribute name="NAME" x="120.65" y="34.6964" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="120.015" y="30.2895" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R18" gate="G$1" x="108.585" y="31.75" smashed="yes" rot="R180">
<attribute name="NAME" x="106.68" y="33.2486" size="1.778" layer="95"/>
<attribute name="VALUE" x="107.315" y="28.1305" size="1.778" layer="96"/>
</instance>
<instance part="FRAME1" gate="G$1" x="0" y="0" smashed="yes">
<attribute name="LAST_DATE_TIME" x="140.97" y="10.16" size="2.286" layer="94"/>
<attribute name="SHEET" x="154.305" y="5.08" size="2.54" layer="94"/>
</instance>
<instance part="GND12" gate="1" x="99.06" y="26.67" smashed="yes">
<attribute name="VALUE" x="99.695" y="27.94" size="1.778" layer="96"/>
</instance>
<instance part="GND13" gate="1" x="144.145" y="29.845" smashed="yes">
<attribute name="VALUE" x="138.43" y="31.75" size="1.778" layer="96"/>
</instance>
<instance part="C10" gate="G$1" x="172.085" y="38.1" smashed="yes">
<attribute name="NAME" x="173.228" y="38.5826" size="1.778" layer="95"/>
<attribute name="VALUE" x="173.228" y="33.5026" size="1.778" layer="96"/>
</instance>
<instance part="L3" gate="1" x="164.465" y="45.72" smashed="yes" rot="R180">
<attribute name="NAME" x="168.275" y="43.434" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="168.402" y="48.768" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D5" gate="G$1" x="156.845" y="38.735" smashed="yes" rot="R90">
<attribute name="NAME" x="154.94" y="36.449" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="160.274" y="36.449" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND14" gate="1" x="172.085" y="29.845" smashed="yes">
<attribute name="VALUE" x="166.37" y="31.75" size="1.778" layer="96"/>
</instance>
<instance part="P+3" gate="1" x="172.085" y="54.61" smashed="yes">
<attribute name="VALUE" x="169.545" y="54.61" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C12" gate="G$1" x="136.525" y="88.9" smashed="yes">
<attribute name="NAME" x="138.049" y="89.281" size="1.778" layer="95"/>
<attribute name="VALUE" x="138.049" y="84.201" size="1.778" layer="96"/>
</instance>
<instance part="C13" gate="G$1" x="175.895" y="93.98" smashed="yes">
<attribute name="NAME" x="177.419" y="94.361" size="1.778" layer="95"/>
<attribute name="VALUE" x="177.419" y="89.281" size="1.778" layer="96"/>
</instance>
<instance part="GND15" gate="1" x="175.895" y="78.105" smashed="yes">
<attribute name="VALUE" x="169.545" y="78.105" size="1.778" layer="96"/>
</instance>
<instance part="P+6" gate="1" x="173.99" y="90.17" smashed="yes">
<attribute name="VALUE" x="171.45" y="90.17" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P-2" gate="1" x="161.29" y="113.03" smashed="yes" rot="R180">
<attribute name="VALUE" x="159.385" y="113.665" size="1.778" layer="96"/>
</instance>
<instance part="LSP1" gate="1" x="74.93" y="45.085" smashed="yes">
<attribute name="NAME" x="73.66" y="48.006" size="1.778" layer="95"/>
</instance>
<instance part="LSP2" gate="1" x="80.645" y="45.085" smashed="yes">
<attribute name="NAME" x="79.375" y="48.006" size="1.778" layer="95"/>
</instance>
<instance part="LSP3" gate="1" x="85.725" y="45.085" smashed="yes">
<attribute name="NAME" x="84.455" y="48.006" size="1.778" layer="95"/>
</instance>
<instance part="C7" gate="G$1" x="19.685" y="12.065" smashed="yes" rot="R180">
<attribute name="NAME" x="19.431" y="16.764" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="20.701" y="16.764" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C11" gate="G$1" x="103.505" y="40.64" smashed="yes">
<attribute name="NAME" x="104.648" y="41.1226" size="1.778" layer="95"/>
<attribute name="VALUE" x="104.648" y="36.0426" size="1.778" layer="96"/>
</instance>
<instance part="R19" gate="G$1" x="10.795" y="83.185" smashed="yes" rot="R270">
<attribute name="NAME" x="8.6614" y="81.28" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="9.9695" y="78.105" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND16" gate="1" x="10.795" y="75.565" smashed="yes">
<attribute name="VALUE" x="12.065" y="76.2" size="1.778" layer="96"/>
</instance>
<instance part="C14" gate="G$1" x="69.85" y="89.535" smashed="yes" rot="R180">
<attribute name="NAME" x="69.596" y="94.234" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="76.581" y="93.599" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D6" gate="G$1" x="27.305" y="12.065" smashed="yes" rot="R90">
<attribute name="NAME" x="25.4" y="9.779" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="30.734" y="9.779" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="L4" gate="G$1" x="170.815" y="103.505" smashed="yes">
<attribute name="NAME" x="167.005" y="105.283" size="1.778" layer="95"/>
<attribute name="VALUE" x="167.005" y="99.949" size="1.778" layer="96"/>
</instance>
<instance part="C15" gate="G$1" x="49.53" y="70.485" smashed="yes" rot="R180">
<attribute name="NAME" x="49.276" y="75.184" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="56.261" y="74.549" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND17" gate="1" x="49.53" y="65.405" smashed="yes">
<attribute name="VALUE" x="50.8" y="66.04" size="1.778" layer="96"/>
</instance>
<instance part="C16" gate="G$1" x="10.16" y="67.945" smashed="yes" rot="R180">
<attribute name="NAME" x="9.906" y="72.644" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="16.891" y="72.009" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND18" gate="1" x="10.16" y="62.865" smashed="yes">
<attribute name="VALUE" x="11.43" y="63.5" size="1.778" layer="96"/>
</instance>
<instance part="C9" gate="G$1" x="147.32" y="34.925" smashed="yes" rot="R180">
<attribute name="NAME" x="147.066" y="39.624" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="154.051" y="38.989" size="1.778" layer="96" rot="R180"/>
</instance>
</instances>
<busses>
<bus name="A,B,C,CA1,CA2,CA3,D,DP,E,F,G">
<segment>
<wire x1="75.565" y1="107.315" x2="75.565" y2="74.93" width="0.762" layer="92"/>
<wire x1="75.565" y1="74.93" x2="98.425" y2="74.93" width="0.762" layer="92"/>
<wire x1="98.425" y1="74.93" x2="98.425" y2="83.82" width="0.762" layer="92"/>
<wire x1="98.425" y1="83.82" x2="98.425" y2="89.535" width="0.762" layer="92"/>
<wire x1="131.445" y1="83.82" x2="98.425" y2="83.82" width="0.762" layer="92"/>
<wire x1="131.445" y1="57.785" x2="98.425" y2="57.785" width="0.762" layer="92"/>
<wire x1="98.425" y1="57.785" x2="98.425" y2="74.93" width="0.762" layer="92"/>
</segment>
</bus>
</busses>
<nets>
<net name="GND" class="0">
<segment>
<pinref part="LD1" gate="G$1" pin="C"/>
<pinref part="GND1" gate="1" pin="GND"/>
<wire x1="108.585" y1="113.03" x2="108.585" y2="114.935" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C2" gate="G$1" pin="1"/>
<pinref part="GND3" gate="1" pin="GND"/>
<wire x1="71.755" y1="114.935" x2="67.31" y2="114.935" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC1" gate="G$1" pin="8"/>
<pinref part="GND7" gate="1" pin="GND"/>
<pinref part="C14" gate="G$1" pin="1"/>
<junction x="69.85" y="86.995"/>
<wire x1="69.85" y1="86.995" x2="73.025" y2="86.995" width="0.1524" layer="91"/>
<wire x1="73.025" y1="86.995" x2="73.025" y2="94.615" width="0.1524" layer="91"/>
<wire x1="73.025" y1="94.615" x2="79.375" y2="94.615" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="VR1" gate="G$1" pin="A"/>
<pinref part="C20" gate="G$1" pin="1"/>
<wire x1="110.49" y1="95.25" x2="120.015" y2="95.25" width="0.1524" layer="91"/>
<junction x="110.49" y="95.25"/>
<pinref part="C1" gate="G$1" pin="2"/>
<pinref part="GND2" gate="1" pin="GND"/>
<wire x1="110.49" y1="95.25" x2="103.505" y2="95.25" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="22"/>
<wire x1="103.505" y1="97.155" x2="94.615" y2="97.155" width="0.1524" layer="91"/>
<wire x1="103.505" y1="97.155" x2="103.505" y2="95.25" width="0.1524" layer="91"/>
<junction x="103.505" y="95.25"/>
</segment>
<segment>
<pinref part="SW1" gate="G$1" pin="C"/>
<pinref part="GND4" gate="1" pin="GND"/>
<wire x1="23.495" y1="105.41" x2="15.875" y2="105.41" width="0.1524" layer="91"/>
<pinref part="SW1" gate="G$2" pin="2"/>
<wire x1="15.875" y1="105.41" x2="15.875" y2="121.92" width="0.1524" layer="91"/>
<wire x1="15.875" y1="121.92" x2="19.05" y2="121.92" width="0.1524" layer="91"/>
<junction x="15.875" y="105.41"/>
</segment>
<segment>
<pinref part="C3" gate="G$1" pin="1"/>
<pinref part="C5" gate="G$1" pin="1"/>
<wire x1="29.21" y1="53.34" x2="41.91" y2="53.34" width="0.1524" layer="91"/>
<pinref part="GND5" gate="1" pin="GND"/>
<junction x="41.91" y="53.34"/>
<wire x1="41.91" y1="53.34" x2="34.29" y2="53.34" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C6" gate="G$1" pin="2"/>
<pinref part="C4" gate="G$1" pin="2"/>
<wire x1="21.59" y1="91.44" x2="21.59" y2="83.185" width="0.1524" layer="91"/>
<pinref part="GND6" gate="1" pin="GND"/>
<junction x="21.59" y="83.185"/>
<wire x1="21.59" y1="83.185" x2="21.59" y2="85.725" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="15.24" y1="9.525" x2="19.685" y2="9.525" width="0.1524" layer="91"/>
<pinref part="X1" gate="-2" pin="KL"/>
<pinref part="GND8" gate="1" pin="GND"/>
<pinref part="C7" gate="G$1" pin="1"/>
<wire x1="19.685" y1="9.525" x2="27.305" y2="9.525" width="0.1524" layer="91"/>
<junction x="19.685" y="9.525"/>
<pinref part="D6" gate="G$1" pin="A"/>
<junction x="27.305" y="9.525"/>
</segment>
<segment>
<pinref part="T1" gate="G$1" pin="E"/>
<pinref part="GND9" gate="1" pin="GND"/>
<wire x1="42.545" y1="9.525" x2="42.545" y2="12.065" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="D2" gate="G$1" pin="C"/>
<pinref part="D1" gate="G$1" pin="A"/>
<wire x1="18.415" y1="67.945" x2="22.225" y2="67.945" width="0.1524" layer="91"/>
<pinref part="GND11" gate="1" pin="GND"/>
<junction x="22.225" y="67.945"/>
</segment>
<segment>
<pinref part="C8" gate="G$1" pin="2"/>
<pinref part="GND12" gate="1" pin="GND"/>
<wire x1="99.06" y1="29.21" x2="99.06" y2="31.75" width="0.1524" layer="91"/>
<pinref part="R18" gate="G$1" pin="2"/>
<wire x1="99.06" y1="31.75" x2="99.06" y2="35.56" width="0.1524" layer="91"/>
<wire x1="103.505" y1="31.75" x2="99.06" y2="31.75" width="0.1524" layer="91"/>
<junction x="99.06" y="31.75"/>
<pinref part="C11" gate="G$1" pin="-"/>
<wire x1="103.505" y1="35.56" x2="103.505" y2="31.75" width="0.1524" layer="91"/>
<junction x="103.505" y="31.75"/>
</segment>
<segment>
<pinref part="IC3" gate="G$1" pin="GND"/>
<pinref part="GND13" gate="1" pin="GND"/>
<wire x1="144.145" y1="32.385" x2="144.145" y2="40.64" width="0.1524" layer="91"/>
<junction x="144.145" y="32.385"/>
<pinref part="D5" gate="G$1" pin="A"/>
<wire x1="156.845" y1="36.195" x2="156.845" y2="32.385" width="0.1524" layer="91"/>
<wire x1="156.845" y1="32.385" x2="147.32" y2="32.385" width="0.1524" layer="91"/>
<pinref part="C9" gate="G$1" pin="1"/>
<wire x1="147.32" y1="32.385" x2="144.145" y2="32.385" width="0.1524" layer="91"/>
<junction x="147.32" y="32.385"/>
</segment>
<segment>
<pinref part="C10" gate="G$1" pin="-"/>
<pinref part="GND14" gate="1" pin="GND"/>
<wire x1="172.085" y1="32.385" x2="172.085" y2="33.02" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC4" gate="G$1" pin="GND"/>
<wire x1="171.45" y1="81.28" x2="175.895" y2="81.28" width="0.1524" layer="91"/>
<pinref part="C13" gate="G$1" pin="2"/>
<wire x1="175.895" y1="81.28" x2="175.895" y2="88.9" width="0.1524" layer="91"/>
<pinref part="GND15" gate="1" pin="GND"/>
<wire x1="175.895" y1="80.645" x2="175.895" y2="81.28" width="0.1524" layer="91"/>
<junction x="175.895" y="81.28"/>
</segment>
<segment>
<pinref part="X2" gate="-1" pin="KL"/>
<pinref part="GND10" gate="1" pin="GND"/>
<wire x1="66.675" y1="42.545" x2="66.675" y2="41.275" width="0.1524" layer="91"/>
<pinref part="LSP2" gate="1" pin="MP"/>
<pinref part="LSP1" gate="1" pin="MP"/>
<wire x1="80.645" y1="42.545" x2="74.93" y2="42.545" width="0.1524" layer="91"/>
<wire x1="74.93" y1="42.545" x2="66.675" y2="42.545" width="0.1524" layer="91"/>
<junction x="74.93" y="42.545"/>
<junction x="66.675" y="42.545"/>
<pinref part="LSP3" gate="1" pin="MP"/>
<wire x1="80.645" y1="42.545" x2="85.725" y2="42.545" width="0.1524" layer="91"/>
<junction x="80.645" y="42.545"/>
</segment>
<segment>
<pinref part="R19" gate="G$1" pin="2"/>
<pinref part="GND16" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="C15" gate="G$1" pin="1"/>
<pinref part="GND17" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="C16" gate="G$1" pin="1"/>
<pinref part="GND18" gate="1" pin="GND"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="1"/>
<pinref part="C2" gate="G$1" pin="2"/>
<wire x1="79.375" y1="112.395" x2="79.375" y2="114.935" width="0.1524" layer="91"/>
<pinref part="R1" gate="G$1" pin="1"/>
<wire x1="79.375" y1="120.65" x2="79.375" y2="114.935" width="0.1524" layer="91"/>
<junction x="79.375" y="114.935"/>
</segment>
</net>
<net name="+5V" class="0">
<segment>
<pinref part="P+1" gate="1" pin="+5V"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="69.215" y1="120.65" x2="67.31" y2="120.65" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="L1" gate="G$1" pin="2"/>
<wire x1="131.445" y1="87.63" x2="127" y2="87.63" width="0.1524" layer="91"/>
<pinref part="R21" gate="G$1" pin="1"/>
<wire x1="131.445" y1="87.63" x2="131.445" y2="102.87" width="0.1524" layer="91"/>
<pinref part="P+2" gate="1" pin="+5V"/>
<wire x1="131.445" y1="102.87" x2="131.445" y2="106.68" width="0.1524" layer="91"/>
<junction x="131.445" y="102.87"/>
</segment>
<segment>
<pinref part="JP1" gate="A" pin="1"/>
<pinref part="P+5" gate="1" pin="+5V"/>
<wire x1="66.675" y1="62.865" x2="59.055" y2="62.865" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="D3" gate="G$1" pin="A"/>
<pinref part="L2" gate="G$1" pin="2"/>
<wire x1="64.77" y1="83.82" x2="64.77" y2="97.155" width="0.1524" layer="91"/>
<wire x1="64.77" y1="97.155" x2="57.785" y2="97.155" width="0.1524" layer="91"/>
<junction x="64.77" y="97.155"/>
<pinref part="P+4" gate="1" pin="+5V"/>
<wire x1="57.785" y1="97.155" x2="57.785" y2="98.425" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="L3" gate="1" pin="1"/>
<pinref part="C10" gate="G$1" pin="+"/>
<wire x1="172.085" y1="45.72" x2="172.085" y2="40.64" width="0.1524" layer="91"/>
<wire x1="172.085" y1="40.64" x2="159.385" y2="40.64" width="0.1524" layer="91"/>
<wire x1="159.385" y1="40.64" x2="159.385" y2="26.67" width="0.1524" layer="91"/>
<junction x="172.085" y="40.64"/>
<wire x1="159.385" y1="26.67" x2="123.825" y2="26.67" width="0.1524" layer="91"/>
<pinref part="R17" gate="G$1" pin="2"/>
<wire x1="123.825" y1="26.67" x2="123.825" y2="31.75" width="0.1524" layer="91"/>
<pinref part="P+3" gate="1" pin="+5V"/>
<wire x1="172.085" y1="45.72" x2="172.085" y2="52.07" width="0.1524" layer="91"/>
<junction x="172.085" y="45.72"/>
</segment>
<segment>
<pinref part="IC4" gate="G$1" pin="V+"/>
<wire x1="171.45" y1="86.36" x2="173.99" y2="86.36" width="0.1524" layer="91"/>
<pinref part="P+6" gate="1" pin="+5V"/>
<wire x1="173.99" y1="86.36" x2="173.99" y2="87.63" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$62" class="0">
<segment>
<pinref part="R23" gate="G$1" pin="1"/>
<pinref part="IC1" gate="G$1" pin="14"/>
<wire x1="79.375" y1="73.025" x2="79.375" y2="79.375" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="R23" gate="G$1" pin="2"/>
<wire x1="69.215" y1="62.865" x2="79.375" y2="62.865" width="0.1524" layer="91"/>
<pinref part="JP1" gate="A" pin="2"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="LD1" gate="G$1" pin="AR"/>
<pinref part="R3" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="LD1" gate="G$1" pin="AG"/>
<pinref part="R4" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="R3" gate="G$1" pin="2"/>
<pinref part="IC1" gate="G$1" pin="26"/>
<wire x1="100.965" y1="107.315" x2="94.615" y2="107.315" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="25"/>
<pinref part="R4" gate="G$1" pin="2"/>
<wire x1="94.615" y1="104.775" x2="116.205" y2="104.775" width="0.1524" layer="91"/>
<wire x1="116.205" y1="104.775" x2="116.205" y2="107.315" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$1" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="7"/>
<wire x1="79.375" y1="97.155" x2="69.85" y2="97.155" width="0.1524" layer="91"/>
<pinref part="D3" gate="G$1" pin="C"/>
<pinref part="C14" gate="G$1" pin="2"/>
<wire x1="69.85" y1="94.615" x2="69.85" y2="97.155" width="0.1524" layer="91"/>
<junction x="69.85" y="97.155"/>
</segment>
</net>
<net name="CA3" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="3"/>
<wire x1="79.375" y1="107.315" x2="75.565" y2="107.315" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="CA@3"/>
<wire x1="131.445" y1="79.375" x2="131.445" y2="83.82" width="0.1524" layer="91"/>
</segment>
</net>
<net name="CA1" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="9"/>
<wire x1="79.375" y1="92.075" x2="75.565" y2="92.075" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="CA@1"/>
<wire x1="126.365" y1="79.375" x2="126.365" y2="83.82" width="0.1524" layer="91"/>
</segment>
</net>
<net name="CA2" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="6"/>
<wire x1="79.375" y1="99.695" x2="75.565" y2="99.695" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="CA@2"/>
<wire x1="128.905" y1="79.375" x2="128.905" y2="83.82" width="0.1524" layer="91"/>
</segment>
</net>
<net name="A" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="10"/>
<wire x1="79.375" y1="89.535" x2="75.565" y2="89.535" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="A"/>
<wire x1="113.665" y1="59.055" x2="113.665" y2="57.785" width="0.1524" layer="91"/>
</segment>
</net>
<net name="F" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="11"/>
<wire x1="79.375" y1="86.995" x2="75.565" y2="86.995" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="F"/>
<wire x1="126.365" y1="59.055" x2="126.365" y2="57.785" width="0.1524" layer="91"/>
</segment>
</net>
<net name="B" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="12"/>
<wire x1="79.375" y1="84.455" x2="75.565" y2="84.455" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="B"/>
<wire x1="116.205" y1="59.055" x2="116.205" y2="57.785" width="0.1524" layer="91"/>
</segment>
</net>
<net name="G" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="13"/>
<wire x1="79.375" y1="81.915" x2="75.565" y2="81.915" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="G"/>
<wire x1="128.905" y1="59.055" x2="128.905" y2="57.785" width="0.1524" layer="91"/>
</segment>
</net>
<net name="D" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="19"/>
<wire x1="94.615" y1="89.535" x2="98.425" y2="89.535" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="D"/>
<wire x1="121.285" y1="59.055" x2="121.285" y2="57.785" width="0.1524" layer="91"/>
</segment>
</net>
<net name="E" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="18"/>
<wire x1="94.615" y1="86.995" x2="98.425" y2="86.995" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="E"/>
<wire x1="123.825" y1="59.055" x2="123.825" y2="57.785" width="0.1524" layer="91"/>
</segment>
</net>
<net name="DP" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="17"/>
<wire x1="94.615" y1="84.455" x2="98.425" y2="84.455" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="DP"/>
<wire x1="131.445" y1="59.055" x2="131.445" y2="57.785" width="0.1524" layer="91"/>
</segment>
</net>
<net name="C" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="16"/>
<wire x1="94.615" y1="81.915" x2="98.425" y2="81.915" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="LED1" gate="DIG1" pin="C"/>
<wire x1="118.745" y1="59.055" x2="118.745" y2="57.785" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="21"/>
<pinref part="C20" gate="G$1" pin="2"/>
<pinref part="VR1" gate="G$1" pin="R"/>
<wire x1="110.49" y1="102.87" x2="114.935" y2="102.87" width="0.1524" layer="91"/>
<junction x="110.49" y="102.87"/>
<pinref part="VR1" gate="G$1" pin="C"/>
<wire x1="114.935" y1="102.87" x2="120.015" y2="102.87" width="0.1524" layer="91"/>
<junction x="114.935" y="102.87"/>
<pinref part="R21" gate="G$1" pin="2"/>
<wire x1="120.015" y1="102.87" x2="121.285" y2="102.87" width="0.1524" layer="91"/>
<junction x="120.015" y="102.87"/>
<wire x1="94.615" y1="94.615" x2="100.33" y2="94.615" width="0.1524" layer="91"/>
<wire x1="100.33" y1="94.615" x2="100.33" y2="102.87" width="0.1524" layer="91"/>
<wire x1="100.33" y1="102.87" x2="110.49" y2="102.87" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="L1" gate="G$1" pin="1"/>
<pinref part="C1" gate="G$1" pin="1"/>
<wire x1="116.84" y1="87.63" x2="110.49" y2="87.63" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="20"/>
<wire x1="100.33" y1="87.63" x2="100.33" y2="92.075" width="0.1524" layer="91"/>
<wire x1="100.33" y1="92.075" x2="94.615" y2="92.075" width="0.1524" layer="91"/>
<wire x1="110.49" y1="87.63" x2="100.33" y2="87.63" width="0.1524" layer="91"/>
<junction x="110.49" y="87.63"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="SW1" gate="G$2" pin="1"/>
<wire x1="29.21" y1="121.92" x2="45.72" y2="121.92" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="2"/>
<wire x1="45.72" y1="121.92" x2="45.72" y2="109.855" width="0.1524" layer="91"/>
<wire x1="45.72" y1="109.855" x2="79.375" y2="109.855" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="4"/>
<wire x1="79.375" y1="104.775" x2="43.815" y2="104.775" width="0.1524" layer="91"/>
<pinref part="R5" gate="G$1" pin="1"/>
<pinref part="R8" gate="G$1" pin="1"/>
<wire x1="41.91" y1="118.11" x2="41.91" y2="113.03" width="0.1524" layer="91"/>
<wire x1="43.815" y1="104.775" x2="43.815" y2="113.03" width="0.1524" layer="91"/>
<wire x1="43.815" y1="113.03" x2="41.91" y2="113.03" width="0.1524" layer="91"/>
<junction x="41.91" y="113.03"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="5"/>
<wire x1="79.375" y1="102.235" x2="41.91" y2="102.235" width="0.1524" layer="91"/>
<pinref part="R6" gate="G$1" pin="1"/>
<pinref part="R7" gate="G$1" pin="1"/>
<wire x1="41.91" y1="102.235" x2="41.91" y2="107.315" width="0.1524" layer="91"/>
<junction x="41.91" y="102.235"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="R8" gate="G$1" pin="2"/>
<pinref part="SW1" gate="G$1" pin="A"/>
<wire x1="31.75" y1="118.11" x2="29.845" y2="118.11" width="0.1524" layer="91"/>
<wire x1="29.845" y1="118.11" x2="20.955" y2="118.11" width="0.1524" layer="91"/>
<wire x1="20.955" y1="118.11" x2="20.955" y2="115.57" width="0.1524" layer="91"/>
<pinref part="R7" gate="G$1" pin="2"/>
<wire x1="31.75" y1="102.235" x2="29.845" y2="102.235" width="0.1524" layer="91"/>
<wire x1="29.845" y1="102.235" x2="29.845" y2="118.11" width="0.1524" layer="91"/>
<junction x="29.845" y="118.11"/>
</segment>
</net>
<net name="-5V" class="0">
<segment>
<pinref part="IC2" gate="A" pin="V-"/>
<pinref part="C4" gate="G$1" pin="1"/>
<pinref part="C6" gate="G$1" pin="1"/>
<wire x1="29.21" y1="83.185" x2="29.21" y2="91.44" width="0.1524" layer="91"/>
<junction x="29.21" y="83.185"/>
<pinref part="P-1" gate="1" pin="-5V"/>
<junction x="29.21" y="91.44"/>
<wire x1="29.21" y1="83.185" x2="29.21" y2="85.725" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="L4" gate="G$1" pin="1"/>
<pinref part="P-2" gate="1" pin="-5V"/>
<wire x1="165.735" y1="103.505" x2="161.29" y2="103.505" width="0.1524" layer="91"/>
<wire x1="161.29" y1="103.505" x2="161.29" y2="110.49" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="R9" gate="G$1" pin="2"/>
<wire x1="24.13" y1="97.79" x2="15.24" y2="97.79" width="0.1524" layer="91"/>
<wire x1="15.24" y1="97.79" x2="15.24" y2="88.265" width="0.1524" layer="91"/>
<pinref part="IC2" gate="A" pin="-IN"/>
<wire x1="15.24" y1="88.265" x2="15.24" y2="78.105" width="0.1524" layer="91"/>
<wire x1="15.24" y1="78.105" x2="24.13" y2="78.105" width="0.1524" layer="91"/>
<pinref part="R19" gate="G$1" pin="1"/>
<wire x1="10.795" y1="88.265" x2="15.24" y2="88.265" width="0.1524" layer="91"/>
<junction x="15.24" y="88.265"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="IC2" gate="A" pin="+IN"/>
<pinref part="D1" gate="G$1" pin="C"/>
<wire x1="24.13" y1="73.025" x2="22.225" y2="73.025" width="0.1524" layer="91"/>
<pinref part="D2" gate="G$1" pin="A"/>
<wire x1="22.225" y1="73.025" x2="18.415" y2="73.025" width="0.1524" layer="91"/>
<junction x="22.225" y="73.025"/>
<pinref part="R15" gate="G$1" pin="1"/>
<junction x="18.415" y="73.025"/>
<wire x1="15.875" y1="58.42" x2="15.875" y2="73.025" width="0.1524" layer="91"/>
<wire x1="15.875" y1="73.025" x2="18.415" y2="73.025" width="0.1524" layer="91"/>
<pinref part="C16" gate="G$1" pin="2"/>
<wire x1="10.16" y1="73.025" x2="15.875" y2="73.025" width="0.1524" layer="91"/>
<junction x="15.875" y="73.025"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="R10" gate="G$1" pin="1"/>
<wire x1="49.53" y1="75.565" x2="49.53" y2="125.73" width="0.1524" layer="91"/>
<wire x1="49.53" y1="125.73" x2="96.52" y2="125.73" width="0.1524" layer="91"/>
<wire x1="96.52" y1="125.73" x2="96.52" y2="99.695" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="23"/>
<wire x1="96.52" y1="99.695" x2="94.615" y2="99.695" width="0.1524" layer="91"/>
<pinref part="C15" gate="G$1" pin="2"/>
<junction x="49.53" y="75.565"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="R2" gate="G$1" pin="S"/>
<pinref part="IC2" gate="A" pin="V+"/>
<wire x1="38.735" y1="60.96" x2="41.91" y2="60.96" width="0.1524" layer="91"/>
<wire x1="41.91" y1="60.96" x2="29.21" y2="60.96" width="0.1524" layer="91"/>
<wire x1="29.21" y1="60.96" x2="29.21" y2="67.945" width="0.1524" layer="91"/>
<pinref part="C3" gate="G$1" pin="2"/>
<junction x="29.21" y="60.96"/>
<pinref part="C5" gate="G$1" pin="2"/>
<junction x="41.91" y="60.96"/>
<pinref part="L2" gate="G$1" pin="1"/>
<wire x1="54.61" y1="83.82" x2="54.61" y2="60.96" width="0.1524" layer="91"/>
<wire x1="54.61" y1="60.96" x2="38.735" y2="60.96" width="0.1524" layer="91"/>
<junction x="38.735" y="60.96"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="X1" gate="-1" pin="KL"/>
<pinref part="Q1" gate="G$1" pin="D"/>
<wire x1="15.875" y1="42.545" x2="19.685" y2="42.545" width="0.1524" layer="91"/>
<wire x1="19.685" y1="42.545" x2="27.305" y2="42.545" width="0.1524" layer="91"/>
<wire x1="27.305" y1="14.605" x2="27.305" y2="42.545" width="0.1524" layer="91"/>
<junction x="27.305" y="42.545"/>
<pinref part="R15" gate="G$1" pin="2"/>
<wire x1="15.875" y1="48.26" x2="15.875" y2="42.545" width="0.1524" layer="91"/>
<junction x="15.875" y="42.545"/>
<pinref part="C7" gate="G$1" pin="2"/>
<wire x1="19.685" y1="17.145" x2="19.685" y2="42.545" width="0.1524" layer="91"/>
<junction x="19.685" y="42.545"/>
<pinref part="D6" gate="G$1" pin="C"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<pinref part="Q1" gate="G$1" pin="G"/>
<pinref part="R11" gate="G$1" pin="2"/>
<pinref part="R14" gate="G$1" pin="2"/>
<wire x1="34.925" y1="32.385" x2="34.925" y2="34.925" width="0.1524" layer="91"/>
<wire x1="41.91" y1="32.385" x2="34.925" y2="32.385" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="R11" gate="G$1" pin="1"/>
<pinref part="T1" gate="G$1" pin="C"/>
<wire x1="42.545" y1="22.225" x2="34.925" y2="22.225" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<pinref part="T1" gate="G$1" pin="B"/>
<pinref part="R12" gate="G$1" pin="2"/>
<wire x1="47.625" y1="20.955" x2="47.625" y2="17.145" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="R12" gate="G$1" pin="1"/>
<wire x1="47.625" y1="31.115" x2="47.625" y2="57.15" width="0.1524" layer="91"/>
<wire x1="47.625" y1="57.15" x2="94.615" y2="57.15" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="15"/>
<wire x1="94.615" y1="57.15" x2="94.615" y2="79.375" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="SWC"/>
<wire x1="144.145" y1="48.26" x2="144.145" y2="52.705" width="0.1524" layer="91"/>
<wire x1="144.145" y1="52.705" x2="98.425" y2="52.705" width="0.1524" layer="91"/>
<wire x1="98.425" y1="52.705" x2="98.425" y2="45.72" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="IS"/>
<wire x1="98.425" y1="45.72" x2="113.665" y2="45.72" width="0.1524" layer="91"/>
<pinref part="R16" gate="G$1" pin="1"/>
<wire x1="90.805" y1="45.72" x2="98.425" y2="45.72" width="0.1524" layer="91"/>
<junction x="98.425" y="45.72"/>
<pinref part="IC3" gate="G$1" pin="DC"/>
<wire x1="113.665" y1="48.26" x2="113.665" y2="45.72" width="0.1524" layer="91"/>
<junction x="113.665" y="45.72"/>
</segment>
</net>
<net name="N$31" class="0">
<segment>
<pinref part="R18" gate="G$1" pin="1"/>
<pinref part="R17" gate="G$1" pin="1"/>
<pinref part="IC3" gate="G$1" pin="FB"/>
<wire x1="113.665" y1="31.75" x2="113.665" y2="40.64" width="0.1524" layer="91"/>
<junction x="113.665" y="31.75"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="TC"/>
<wire x1="144.145" y1="43.18" x2="147.32" y2="43.18" width="0.1524" layer="91"/>
<wire x1="147.32" y1="43.18" x2="147.32" y2="40.005" width="0.1524" layer="91"/>
<pinref part="C9" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="IC3" gate="G$1" pin="SWE"/>
<pinref part="L3" gate="1" pin="2"/>
<wire x1="144.145" y1="45.72" x2="156.845" y2="45.72" width="0.1524" layer="91"/>
<pinref part="D5" gate="G$1" pin="C"/>
<wire x1="156.845" y1="45.72" x2="156.845" y2="41.275" width="0.1524" layer="91"/>
<junction x="156.845" y="45.72"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="CAP-"/>
<pinref part="C12" gate="G$1" pin="2"/>
<wire x1="143.51" y1="86.36" x2="143.51" y2="83.82" width="0.1524" layer="91"/>
<wire x1="143.51" y1="83.82" x2="136.525" y2="83.82" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="CAP+"/>
<pinref part="C12" gate="G$1" pin="1"/>
<wire x1="143.51" y1="91.44" x2="136.525" y2="91.44" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<pinref part="R13" gate="G$1" pin="A"/>
<pinref part="R9" gate="G$1" pin="1"/>
<wire x1="39.37" y1="97.79" x2="34.29" y2="97.79" width="0.1524" layer="91"/>
<wire x1="39.37" y1="93.98" x2="39.37" y2="97.79" width="0.1524" layer="91"/>
<pinref part="R13" gate="G$1" pin="S"/>
<wire x1="44.45" y1="88.9" x2="44.45" y2="93.98" width="0.1524" layer="91"/>
<wire x1="44.45" y1="93.98" x2="39.37" y2="93.98" width="0.1524" layer="91"/>
<junction x="39.37" y="93.98"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="IC2" gate="A" pin="ON1"/>
<pinref part="R2" gate="G$1" pin="A"/>
<wire x1="31.75" y1="67.945" x2="31.75" y2="66.04" width="0.1524" layer="91"/>
<wire x1="31.75" y1="66.04" x2="33.655" y2="66.04" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="IC2" gate="A" pin="ON2"/>
<pinref part="R2" gate="G$1" pin="E"/>
<wire x1="39.37" y1="73.025" x2="43.815" y2="73.025" width="0.1524" layer="91"/>
<wire x1="43.815" y1="73.025" x2="43.815" y2="66.04" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="IC2" gate="A" pin="OUT"/>
<pinref part="R10" gate="G$1" pin="2"/>
<pinref part="R13" gate="G$1" pin="E"/>
<wire x1="39.37" y1="75.565" x2="39.37" y2="83.82" width="0.1524" layer="91"/>
<junction x="39.37" y="75.565"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="R14" gate="G$1" pin="1"/>
<pinref part="Q1" gate="G$1" pin="S"/>
<wire x1="37.465" y1="42.545" x2="41.91" y2="42.545" width="0.1524" layer="91"/>
<pinref part="X2" gate="-2" pin="KL"/>
<wire x1="41.91" y1="42.545" x2="53.975" y2="42.545" width="0.1524" layer="91"/>
<junction x="41.91" y="42.545"/>
<pinref part="IC3" gate="G$1" pin="VCC"/>
<wire x1="113.665" y1="43.18" x2="103.505" y2="43.18" width="0.1524" layer="91"/>
<wire x1="103.505" y1="43.18" x2="99.06" y2="43.18" width="0.1524" layer="91"/>
<wire x1="99.06" y1="43.18" x2="93.98" y2="43.18" width="0.1524" layer="91"/>
<wire x1="93.98" y1="43.18" x2="93.98" y2="32.385" width="0.1524" layer="91"/>
<pinref part="R16" gate="G$1" pin="2"/>
<pinref part="C8" gate="G$1" pin="1"/>
<junction x="99.06" y="43.18"/>
<wire x1="90.805" y1="32.385" x2="93.98" y2="32.385" width="0.1524" layer="91"/>
<wire x1="90.805" y1="35.56" x2="90.805" y2="32.385" width="0.1524" layer="91"/>
<junction x="90.805" y="32.385"/>
<wire x1="53.975" y1="32.385" x2="90.805" y2="32.385" width="0.1524" layer="91"/>
<wire x1="53.975" y1="42.545" x2="53.975" y2="32.385" width="0.1524" layer="91"/>
<junction x="53.975" y="42.545"/>
<pinref part="C11" gate="G$1" pin="+"/>
<junction x="103.505" y="43.18"/>
</segment>
</net>
<net name="N$39" class="0">
<segment>
<pinref part="SW1" gate="G$1" pin="B"/>
<pinref part="R5" gate="G$1" pin="2"/>
<wire x1="26.035" y1="115.57" x2="31.75" y2="115.57" width="0.1524" layer="91"/>
<wire x1="31.75" y1="115.57" x2="31.75" y2="113.03" width="0.1524" layer="91"/>
<pinref part="R6" gate="G$1" pin="2"/>
<wire x1="31.75" y1="113.03" x2="31.75" y2="107.315" width="0.1524" layer="91"/>
<junction x="31.75" y="113.03"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="IC4" gate="G$1" pin="VOUT"/>
<pinref part="C13" gate="G$1" pin="1"/>
<wire x1="171.45" y1="96.52" x2="175.895" y2="96.52" width="0.1524" layer="91"/>
<pinref part="L4" gate="G$1" pin="2"/>
<wire x1="175.895" y1="103.505" x2="175.895" y2="96.52" width="0.1524" layer="91"/>
<junction x="175.895" y="96.52"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
<compatibility>
<note version="8.2" severity="warning">
Since Version 8.2, EAGLE supports online libraries. The ids
of those online libraries will not be understood (or retained)
with this version.
</note>
<note version="8.3" severity="warning">
Since Version 8.3, EAGLE supports URNs for individual library
assets (packages, symbols, and devices). The URNs of those assets
will not be understood (or retained) with this version.
</note>
Since Version 8.3, EAGLE supports the association of 3D packages
with devices in libraries, schematics, and board files. Those 3D
packages will not be understood (or retained) with this version.
</note>
<note version="8.4" severity="warning">
Since Version 8.4, EAGLE supports properties for SPICE simulation.
Probes in schematics and SPICE mapping objects found in parts and library devices
will not be understood with this version. Update EAGLE to the latest version
for full support of SPICE simulation.
</note>
</compatibility>
</eagle>
