    "author": {
        "email": "support.eagle@autodesk.com",
        "name": "Autodesk EAGLE"
    "description": {
        "EN": "EAGLE default single layer CAM job."
    "job_prefix": "job_outputs",
    "output_type": "directory",
    "outputs": [
            "filename_prefix": "CAMOutputs/GerberFiles",
            "format_specifier": {
                "decimal": 4,
                "integer": 3
            "generate_job_file": true,
            "output_type": "gerber",
            "outputs": [
            "version": "RS274X"
            "filename_prefix": "CAMOutputs/DrillFiles",
                "decimal": 3,
                "integer": 3
            "output_type": "drill",
            "outputs": [
                    "advanced_options": {
                        "mirror": false,
                        "offset_x": 0,
                        "offset_y": 0,
                        "rotate": false,
                        "upside_down": false
                    "filename_format": "%DRILLPREFIX/drill_%FROM_%TO.xln",
                    "name": "Auto Drill",
                    "type": "autodrills"
            "filename_prefix": "CAMOutputs/Assembly",
            "output_type": "assembly",
            "outputs": [
                    "filename_format": "%ASSEMBLYPREFIX/%N",
                    "list_attribute": true,
                    "list_type": "values",
                    "name": "Bill of Material",
                    "output_format": "txt",
                    "type": "bom"
                    "filename_format": "%ASSEMBLYPREFIX/PnP_%N_%BOARDSIDE",
                    "name": "Pick and Place",
                    "type": "pick_and_place"
            "filename_prefix": "CAMOutputs/DrawingFiles",
            "output_type": "drawing",
            "outputs": [
                    "filename_format": "%DRAWINGPREFIX/%N.dxf",
                    "name": "dxf",
                    "signals_on_individual_layers": false,
                    "type": "DXF"
    "timestamp": "2022-01-20T11:34:27",
    "type": "EAGLE CAM job",
    "units": "metric",
    "version": "9.2.0"
